<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="7.5.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="yes" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="yes" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="50" name="dxf" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="53" name="tGND_GNDA" color="7" fill="1" visible="no" active="no"/>
<layer number="54" name="bGND_GNDA" color="7" fill="1" visible="no" active="no"/>
<layer number="56" name="wert" color="7" fill="1" visible="no" active="no"/>
<layer number="88" name="SimResults" color="9" fill="1" visible="yes" active="yes"/>
<layer number="89" name="SimProbes" color="9" fill="1" visible="yes" active="yes"/>
<layer number="90" name="Modules" color="5" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="yes" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
<layer number="99" name="SpiceOrder" color="5" fill="1" visible="yes" active="yes"/>
<layer number="100" name="Muster" color="7" fill="1" visible="no" active="no"/>
<layer number="101" name="Hidden" color="15" fill="1" visible="yes" active="yes"/>
<layer number="102" name="Changes" color="12" fill="1" visible="yes" active="yes"/>
<layer number="103" name="tMap" color="7" fill="1" visible="yes" active="yes"/>
<layer number="104" name="Name" color="16" fill="1" visible="yes" active="yes"/>
<layer number="105" name="tPlate" color="7" fill="1" visible="yes" active="yes"/>
<layer number="106" name="bPlate" color="7" fill="1" visible="yes" active="yes"/>
<layer number="107" name="Crop" color="7" fill="1" visible="yes" active="yes"/>
<layer number="108" name="tplace-old" color="10" fill="1" visible="yes" active="yes"/>
<layer number="109" name="ref-old" color="11" fill="1" visible="yes" active="yes"/>
<layer number="116" name="Patch_BOT" color="9" fill="4" visible="yes" active="yes"/>
<layer number="121" name="_tsilk" color="7" fill="1" visible="yes" active="yes"/>
<layer number="122" name="_bsilk" color="7" fill="1" visible="yes" active="yes"/>
<layer number="125" name="_tNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="144" name="Drill_legend" color="7" fill="1" visible="no" active="yes"/>
<layer number="151" name="L$151" color="7" fill="1" visible="yes" active="yes"/>
<layer number="199" name="Contour" color="7" fill="1" visible="yes" active="yes"/>
<layer number="200" name="200bmp" color="1" fill="10" visible="yes" active="yes"/>
<layer number="201" name="201bmp" color="2" fill="10" visible="yes" active="yes"/>
<layer number="202" name="202bmp" color="3" fill="10" visible="yes" active="yes"/>
<layer number="203" name="203bmp" color="4" fill="10" visible="yes" active="yes"/>
<layer number="204" name="204bmp" color="5" fill="10" visible="yes" active="yes"/>
<layer number="205" name="205bmp" color="6" fill="10" visible="yes" active="yes"/>
<layer number="206" name="206bmp" color="7" fill="10" visible="yes" active="yes"/>
<layer number="207" name="207bmp" color="8" fill="10" visible="yes" active="yes"/>
<layer number="208" name="208bmp" color="9" fill="10" visible="yes" active="yes"/>
<layer number="209" name="209bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="210" name="210bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="211" name="211bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="212" name="212bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="213" name="213bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="214" name="214bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="215" name="215bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="216" name="216bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="217" name="217bmp" color="18" fill="1" visible="no" active="no"/>
<layer number="218" name="218bmp" color="19" fill="1" visible="no" active="no"/>
<layer number="219" name="219bmp" color="20" fill="1" visible="no" active="no"/>
<layer number="220" name="220bmp" color="21" fill="1" visible="no" active="no"/>
<layer number="221" name="221bmp" color="22" fill="1" visible="no" active="no"/>
<layer number="222" name="222bmp" color="23" fill="1" visible="no" active="no"/>
<layer number="223" name="223bmp" color="24" fill="1" visible="no" active="no"/>
<layer number="224" name="224bmp" color="25" fill="1" visible="no" active="no"/>
<layer number="250" name="Descript" color="3" fill="1" visible="no" active="no"/>
<layer number="251" name="SMDround" color="12" fill="11" visible="no" active="no"/>
<layer number="254" name="OrgLBR" color="13" fill="1" visible="yes" active="yes"/>
</layers>
<library>
<description>&lt;b&gt;Numeric Display&lt;/b&gt;&lt;p&gt;
(make-group2pac.ulp)&lt;br&gt;
&lt;br&gt;</description>
<packages>
<package name="4DIGIT_0-56">
<description>&lt;b&gt;14.22mm (0.56INCH) 4 DIGIT NUMERIC DISPLAY&lt;/b&gt;&lt;p&gt;</description>
<wire x1="-14.5796" y1="-6.1849" x2="-14.4018" y2="-6.1849" width="0.3048" layer="51"/>
<wire x1="-14.3002" y1="6.4389" x2="-14.986" y2="5.7531" width="0.4064" layer="51"/>
<wire x1="-14.986" y1="5.7531" x2="-15.8242" y2="0.9525" width="0.4064" layer="51"/>
<wire x1="-15.8242" y1="0.9525" x2="-15.3416" y2="0.4699" width="0.4064" layer="51"/>
<wire x1="-15.3416" y1="0.4699" x2="-14.732" y2="1.0795" width="0.4064" layer="51"/>
<wire x1="-14.732" y1="1.0795" x2="-13.8938" y2="6.0325" width="0.4064" layer="51"/>
<wire x1="-13.8938" y1="6.0325" x2="-14.3002" y2="6.4389" width="0.4064" layer="51"/>
<wire x1="-14.7574" y1="6.8961" x2="-15.3924" y2="6.2611" width="0.4064" layer="51"/>
<wire x1="-15.3924" y1="6.2611" x2="-20.6756" y2="6.2611" width="0.4064" layer="51"/>
<wire x1="-20.6756" y1="6.2611" x2="-21.3614" y2="6.9469" width="0.4064" layer="51"/>
<wire x1="-21.3614" y1="6.9469" x2="-21.0312" y2="7.2771" width="0.4064" layer="51"/>
<wire x1="-21.0312" y1="7.2771" x2="-15.1384" y2="7.2771" width="0.4064" layer="51"/>
<wire x1="-15.1384" y1="7.2771" x2="-14.7574" y2="6.8961" width="0.4064" layer="51"/>
<wire x1="-21.8186" y1="6.4897" x2="-21.1836" y2="5.8547" width="0.4064" layer="51"/>
<wire x1="-21.1836" y1="5.8547" x2="-22.0218" y2="0.9779" width="0.4064" layer="51"/>
<wire x1="-22.0218" y1="0.9779" x2="-22.606" y2="0.3937" width="0.4064" layer="51"/>
<wire x1="-22.606" y1="0.3937" x2="-23.0886" y2="0.8763" width="0.4064" layer="51"/>
<wire x1="-23.0886" y1="0.8763" x2="-22.1742" y2="6.1341" width="0.4064" layer="51"/>
<wire x1="-22.1742" y1="6.1341" x2="-21.8186" y2="6.4897" width="0.4064" layer="51"/>
<wire x1="-22.1234" y1="-0.0889" x2="-21.4884" y2="0.5461" width="0.4064" layer="51"/>
<wire x1="-21.4884" y1="0.5461" x2="-16.3576" y2="0.5461" width="0.4064" layer="51"/>
<wire x1="-16.3576" y1="0.5461" x2="-15.8496" y2="0.0381" width="0.4064" layer="51"/>
<wire x1="-15.8496" y1="0.0381" x2="-16.3576" y2="-0.4699" width="0.4064" layer="51"/>
<wire x1="-16.3576" y1="-0.4699" x2="-21.7424" y2="-0.4699" width="0.4064" layer="51"/>
<wire x1="-21.7424" y1="-0.4699" x2="-22.1234" y2="-0.0889" width="0.4064" layer="51"/>
<wire x1="-22.606" y1="-0.5715" x2="-22.352" y2="-0.8255" width="0.4064" layer="51"/>
<wire x1="-23.7998" y1="-6.3881" x2="-23.2156" y2="-5.8039" width="0.4064" layer="51"/>
<wire x1="-23.2156" y1="-5.8039" x2="-22.352" y2="-0.8255" width="0.4064" layer="51"/>
<wire x1="-22.606" y1="-0.5715" x2="-23.495" y2="-1.4605" width="0.4064" layer="51"/>
<wire x1="-23.495" y1="-1.4605" x2="-24.2824" y2="-5.9055" width="0.4064" layer="51"/>
<wire x1="-24.2824" y1="-5.9055" x2="-23.7998" y2="-6.3881" width="0.4064" layer="51"/>
<wire x1="-23.3172" y1="-6.8707" x2="-22.6314" y2="-6.1849" width="0.4064" layer="51"/>
<wire x1="-22.6314" y1="-6.1849" x2="-17.3736" y2="-6.1849" width="0.4064" layer="51"/>
<wire x1="-17.3736" y1="-6.1849" x2="-16.6878" y2="-6.8707" width="0.4064" layer="51"/>
<wire x1="-16.6878" y1="-6.8707" x2="-17.018" y2="-7.2009" width="0.4064" layer="51"/>
<wire x1="-17.018" y1="-7.2009" x2="-22.987" y2="-7.2009" width="0.4064" layer="51"/>
<wire x1="-22.987" y1="-7.2009" x2="-23.3172" y2="-6.8707" width="0.4064" layer="51"/>
<wire x1="-15.367" y1="-0.4191" x2="-16.2052" y2="-1.2573" width="0.4064" layer="51"/>
<wire x1="-16.2052" y1="-1.2573" x2="-16.9672" y2="-5.6515" width="0.4064" layer="51"/>
<wire x1="-16.9672" y1="-5.6515" x2="-16.2052" y2="-6.4135" width="0.4064" layer="51"/>
<wire x1="-16.2052" y1="-6.4135" x2="-16.002" y2="-6.2103" width="0.4064" layer="51"/>
<wire x1="-16.002" y1="-6.2103" x2="-15.0876" y2="-0.6985" width="0.4064" layer="51"/>
<wire x1="-15.0876" y1="-0.6985" x2="-15.367" y2="-0.4191" width="0.4064" layer="51"/>
<wire x1="-15.5702" y1="-1.0033" x2="-16.4084" y2="-5.8293" width="0.8128" layer="51"/>
<wire x1="-17.272" y1="-6.6929" x2="-22.733" y2="-6.6929" width="0.8128" layer="51"/>
<wire x1="-23.6982" y1="-5.7785" x2="-22.8346" y2="-1.1303" width="0.8128" layer="51"/>
<wire x1="-22.5806" y1="1.0033" x2="-21.717" y2="5.8801" width="0.8128" layer="51"/>
<wire x1="-20.8026" y1="6.7691" x2="-15.24" y2="6.7691" width="0.8128" layer="51"/>
<wire x1="-14.478" y1="5.9309" x2="-15.2908" y2="1.0795" width="0.8128" layer="51"/>
<wire x1="-16.383" y1="0.0381" x2="-21.5646" y2="0.0381" width="0.8128" layer="51"/>
<wire x1="-1.8796" y1="-6.1849" x2="-1.7018" y2="-6.1849" width="0.3048" layer="51"/>
<wire x1="-1.6002" y1="6.4389" x2="-2.286" y2="5.7531" width="0.4064" layer="51"/>
<wire x1="-2.286" y1="5.7531" x2="-3.1242" y2="0.9525" width="0.4064" layer="51"/>
<wire x1="-3.1242" y1="0.9525" x2="-2.6416" y2="0.4699" width="0.4064" layer="51"/>
<wire x1="-2.6416" y1="0.4699" x2="-2.032" y2="1.0795" width="0.4064" layer="51"/>
<wire x1="-2.032" y1="1.0795" x2="-1.1938" y2="6.0325" width="0.4064" layer="51"/>
<wire x1="-1.1938" y1="6.0325" x2="-1.6002" y2="6.4389" width="0.4064" layer="51"/>
<wire x1="-2.0574" y1="6.8961" x2="-2.6924" y2="6.2611" width="0.4064" layer="51"/>
<wire x1="-2.6924" y1="6.2611" x2="-7.9756" y2="6.2611" width="0.4064" layer="51"/>
<wire x1="-7.9756" y1="6.2611" x2="-8.6614" y2="6.9469" width="0.4064" layer="51"/>
<wire x1="-8.6614" y1="6.9469" x2="-8.3312" y2="7.2771" width="0.4064" layer="51"/>
<wire x1="-8.3312" y1="7.2771" x2="-2.4384" y2="7.2771" width="0.4064" layer="51"/>
<wire x1="-2.4384" y1="7.2771" x2="-2.0574" y2="6.8961" width="0.4064" layer="51"/>
<wire x1="-9.1186" y1="6.4897" x2="-8.4836" y2="5.8547" width="0.4064" layer="51"/>
<wire x1="-8.4836" y1="5.8547" x2="-9.3218" y2="0.9779" width="0.4064" layer="51"/>
<wire x1="-9.3218" y1="0.9779" x2="-9.906" y2="0.3937" width="0.4064" layer="51"/>
<wire x1="-9.906" y1="0.3937" x2="-10.3886" y2="0.8763" width="0.4064" layer="51"/>
<wire x1="-10.3886" y1="0.8763" x2="-9.4742" y2="6.1341" width="0.4064" layer="51"/>
<wire x1="-9.4742" y1="6.1341" x2="-9.1186" y2="6.4897" width="0.4064" layer="51"/>
<wire x1="-9.4234" y1="-0.0889" x2="-8.7884" y2="0.5461" width="0.4064" layer="51"/>
<wire x1="-8.7884" y1="0.5461" x2="-3.6576" y2="0.5461" width="0.4064" layer="51"/>
<wire x1="-3.6576" y1="0.5461" x2="-3.1496" y2="0.0381" width="0.4064" layer="51"/>
<wire x1="-3.1496" y1="0.0381" x2="-3.6576" y2="-0.4699" width="0.4064" layer="51"/>
<wire x1="-3.6576" y1="-0.4699" x2="-9.0424" y2="-0.4699" width="0.4064" layer="51"/>
<wire x1="-9.0424" y1="-0.4699" x2="-9.4234" y2="-0.0889" width="0.4064" layer="51"/>
<wire x1="-9.906" y1="-0.5715" x2="-9.652" y2="-0.8255" width="0.4064" layer="51"/>
<wire x1="-11.0998" y1="-6.3881" x2="-10.5156" y2="-5.8039" width="0.4064" layer="51"/>
<wire x1="-10.5156" y1="-5.8039" x2="-9.652" y2="-0.8255" width="0.4064" layer="51"/>
<wire x1="-9.906" y1="-0.5715" x2="-10.795" y2="-1.4605" width="0.4064" layer="51"/>
<wire x1="-10.795" y1="-1.4605" x2="-11.5824" y2="-5.9055" width="0.4064" layer="51"/>
<wire x1="-11.5824" y1="-5.9055" x2="-11.0998" y2="-6.3881" width="0.4064" layer="51"/>
<wire x1="-10.6172" y1="-6.8707" x2="-9.9314" y2="-6.1849" width="0.4064" layer="51"/>
<wire x1="-9.9314" y1="-6.1849" x2="-4.6736" y2="-6.1849" width="0.4064" layer="51"/>
<wire x1="-4.6736" y1="-6.1849" x2="-3.9878" y2="-6.8707" width="0.4064" layer="51"/>
<wire x1="-3.9878" y1="-6.8707" x2="-4.318" y2="-7.2009" width="0.4064" layer="51"/>
<wire x1="-4.318" y1="-7.2009" x2="-10.287" y2="-7.2009" width="0.4064" layer="51"/>
<wire x1="-10.287" y1="-7.2009" x2="-10.6172" y2="-6.8707" width="0.4064" layer="51"/>
<wire x1="-2.667" y1="-0.4191" x2="-3.5052" y2="-1.2573" width="0.4064" layer="51"/>
<wire x1="-3.5052" y1="-1.2573" x2="-4.2672" y2="-5.6515" width="0.4064" layer="51"/>
<wire x1="-4.2672" y1="-5.6515" x2="-3.5052" y2="-6.4135" width="0.4064" layer="51"/>
<wire x1="-3.5052" y1="-6.4135" x2="-3.302" y2="-6.2103" width="0.4064" layer="51"/>
<wire x1="-3.302" y1="-6.2103" x2="-2.3876" y2="-0.6985" width="0.4064" layer="51"/>
<wire x1="-2.3876" y1="-0.6985" x2="-2.667" y2="-0.4191" width="0.4064" layer="51"/>
<wire x1="-2.8702" y1="-1.0033" x2="-3.7084" y2="-5.8293" width="0.8128" layer="51"/>
<wire x1="-4.572" y1="-6.6929" x2="-10.033" y2="-6.6929" width="0.8128" layer="51"/>
<wire x1="-10.9982" y1="-5.7785" x2="-10.1346" y2="-1.1303" width="0.8128" layer="51"/>
<wire x1="-9.8806" y1="1.0033" x2="-9.017" y2="5.8801" width="0.8128" layer="51"/>
<wire x1="-8.1026" y1="6.7691" x2="-2.54" y2="6.7691" width="0.8128" layer="51"/>
<wire x1="-1.778" y1="5.9309" x2="-2.5908" y2="1.0795" width="0.8128" layer="51"/>
<wire x1="-3.683" y1="0.0381" x2="-8.8646" y2="0.0381" width="0.8128" layer="51"/>
<wire x1="10.8204" y1="-6.1849" x2="10.9982" y2="-6.1849" width="0.3048" layer="51"/>
<wire x1="11.0998" y1="6.4389" x2="10.414" y2="5.7531" width="0.4064" layer="51"/>
<wire x1="10.414" y1="5.7531" x2="9.5758" y2="0.9525" width="0.4064" layer="51"/>
<wire x1="9.5758" y1="0.9525" x2="10.0584" y2="0.4699" width="0.4064" layer="51"/>
<wire x1="10.0584" y1="0.4699" x2="10.668" y2="1.0795" width="0.4064" layer="51"/>
<wire x1="10.668" y1="1.0795" x2="11.5062" y2="6.0325" width="0.4064" layer="51"/>
<wire x1="11.5062" y1="6.0325" x2="11.0998" y2="6.4389" width="0.4064" layer="51"/>
<wire x1="10.6426" y1="6.8961" x2="10.0076" y2="6.2611" width="0.4064" layer="51"/>
<wire x1="10.0076" y1="6.2611" x2="4.7244" y2="6.2611" width="0.4064" layer="51"/>
<wire x1="4.7244" y1="6.2611" x2="4.0386" y2="6.9469" width="0.4064" layer="51"/>
<wire x1="4.0386" y1="6.9469" x2="4.3688" y2="7.2771" width="0.4064" layer="51"/>
<wire x1="4.3688" y1="7.2771" x2="10.2616" y2="7.2771" width="0.4064" layer="51"/>
<wire x1="10.2616" y1="7.2771" x2="10.6426" y2="6.8961" width="0.4064" layer="51"/>
<wire x1="3.5814" y1="6.4897" x2="4.2164" y2="5.8547" width="0.4064" layer="51"/>
<wire x1="4.2164" y1="5.8547" x2="3.3782" y2="0.9779" width="0.4064" layer="51"/>
<wire x1="3.3782" y1="0.9779" x2="2.794" y2="0.3937" width="0.4064" layer="51"/>
<wire x1="2.794" y1="0.3937" x2="2.3114" y2="0.8763" width="0.4064" layer="51"/>
<wire x1="2.3114" y1="0.8763" x2="3.2258" y2="6.1341" width="0.4064" layer="51"/>
<wire x1="3.2258" y1="6.1341" x2="3.5814" y2="6.4897" width="0.4064" layer="51"/>
<wire x1="3.2766" y1="-0.0889" x2="3.9116" y2="0.5461" width="0.4064" layer="51"/>
<wire x1="3.9116" y1="0.5461" x2="9.0424" y2="0.5461" width="0.4064" layer="51"/>
<wire x1="9.0424" y1="0.5461" x2="9.5504" y2="0.0381" width="0.4064" layer="51"/>
<wire x1="9.5504" y1="0.0381" x2="9.0424" y2="-0.4699" width="0.4064" layer="51"/>
<wire x1="9.0424" y1="-0.4699" x2="3.6576" y2="-0.4699" width="0.4064" layer="51"/>
<wire x1="3.6576" y1="-0.4699" x2="3.2766" y2="-0.0889" width="0.4064" layer="51"/>
<wire x1="2.794" y1="-0.5715" x2="3.048" y2="-0.8255" width="0.4064" layer="51"/>
<wire x1="1.6002" y1="-6.3881" x2="2.1844" y2="-5.8039" width="0.4064" layer="51"/>
<wire x1="2.1844" y1="-5.8039" x2="3.048" y2="-0.8255" width="0.4064" layer="51"/>
<wire x1="2.794" y1="-0.5715" x2="1.905" y2="-1.4605" width="0.4064" layer="51"/>
<wire x1="1.905" y1="-1.4605" x2="1.1176" y2="-5.9055" width="0.4064" layer="51"/>
<wire x1="1.1176" y1="-5.9055" x2="1.6002" y2="-6.3881" width="0.4064" layer="51"/>
<wire x1="2.0828" y1="-6.8707" x2="2.7686" y2="-6.1849" width="0.4064" layer="51"/>
<wire x1="2.7686" y1="-6.1849" x2="8.0264" y2="-6.1849" width="0.4064" layer="51"/>
<wire x1="8.0264" y1="-6.1849" x2="8.7122" y2="-6.8707" width="0.4064" layer="51"/>
<wire x1="8.7122" y1="-6.8707" x2="8.382" y2="-7.2009" width="0.4064" layer="51"/>
<wire x1="8.382" y1="-7.2009" x2="2.413" y2="-7.2009" width="0.4064" layer="51"/>
<wire x1="2.413" y1="-7.2009" x2="2.0828" y2="-6.8707" width="0.4064" layer="51"/>
<wire x1="10.033" y1="-0.4191" x2="9.1948" y2="-1.2573" width="0.4064" layer="51"/>
<wire x1="9.1948" y1="-1.2573" x2="8.4328" y2="-5.6515" width="0.4064" layer="51"/>
<wire x1="8.4328" y1="-5.6515" x2="9.1948" y2="-6.4135" width="0.4064" layer="51"/>
<wire x1="9.1948" y1="-6.4135" x2="9.398" y2="-6.2103" width="0.4064" layer="51"/>
<wire x1="9.398" y1="-6.2103" x2="10.3124" y2="-0.6985" width="0.4064" layer="51"/>
<wire x1="10.3124" y1="-0.6985" x2="10.033" y2="-0.4191" width="0.4064" layer="51"/>
<wire x1="9.8298" y1="-1.0033" x2="8.9916" y2="-5.8293" width="0.8128" layer="51"/>
<wire x1="8.128" y1="-6.6929" x2="2.667" y2="-6.6929" width="0.8128" layer="51"/>
<wire x1="1.7018" y1="-5.7785" x2="2.5654" y2="-1.1303" width="0.8128" layer="51"/>
<wire x1="2.8194" y1="1.0033" x2="3.683" y2="5.8801" width="0.8128" layer="51"/>
<wire x1="4.5974" y1="6.7691" x2="10.16" y2="6.7691" width="0.8128" layer="51"/>
<wire x1="10.922" y1="5.9309" x2="10.1092" y2="1.0795" width="0.8128" layer="51"/>
<wire x1="9.017" y1="0.0381" x2="3.8354" y2="0.0381" width="0.8128" layer="51"/>
<wire x1="-25.146" y1="9.4996" x2="-25.146" y2="-9.4996" width="0.1524" layer="21"/>
<wire x1="-25.146" y1="9.4996" x2="25.146" y2="9.4996" width="0.1524" layer="21"/>
<wire x1="25.146" y1="9.4996" x2="25.146" y2="-9.4996" width="0.1524" layer="21"/>
<wire x1="25.146" y1="-9.4996" x2="-25.146" y2="-9.4996" width="0.1524" layer="21"/>
<circle x="-14.478" y="-6.1849" radius="0.381" width="0.762" layer="51"/>
<circle x="-1.778" y="-6.1849" radius="0.381" width="0.762" layer="51"/>
<circle x="10.922" y="-6.1849" radius="0.381" width="0.762" layer="51"/>
<pad name="1" x="-6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="-1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="-3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="-6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<text x="-25.4" y="10.16" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-25.4" y="-11.43" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<wire x1="23.5204" y1="-6.1849" x2="23.6982" y2="-6.1849" width="0.3048" layer="51"/>
<wire x1="23.7998" y1="6.4389" x2="23.114" y2="5.7531" width="0.4064" layer="51"/>
<wire x1="23.114" y1="5.7531" x2="22.2758" y2="0.9525" width="0.4064" layer="51"/>
<wire x1="22.2758" y1="0.9525" x2="22.7584" y2="0.4699" width="0.4064" layer="51"/>
<wire x1="22.7584" y1="0.4699" x2="23.368" y2="1.0795" width="0.4064" layer="51"/>
<wire x1="23.368" y1="1.0795" x2="24.2062" y2="6.0325" width="0.4064" layer="51"/>
<wire x1="24.2062" y1="6.0325" x2="23.7998" y2="6.4389" width="0.4064" layer="51"/>
<wire x1="23.3426" y1="6.8961" x2="22.7076" y2="6.2611" width="0.4064" layer="51"/>
<wire x1="22.7076" y1="6.2611" x2="17.4244" y2="6.2611" width="0.4064" layer="51"/>
<wire x1="17.4244" y1="6.2611" x2="16.7386" y2="6.9469" width="0.4064" layer="51"/>
<wire x1="16.7386" y1="6.9469" x2="17.0688" y2="7.2771" width="0.4064" layer="51"/>
<wire x1="17.0688" y1="7.2771" x2="22.9616" y2="7.2771" width="0.4064" layer="51"/>
<wire x1="22.9616" y1="7.2771" x2="23.3426" y2="6.8961" width="0.4064" layer="51"/>
<wire x1="16.2814" y1="6.4897" x2="16.9164" y2="5.8547" width="0.4064" layer="51"/>
<wire x1="16.9164" y1="5.8547" x2="16.0782" y2="0.9779" width="0.4064" layer="51"/>
<wire x1="16.0782" y1="0.9779" x2="15.494" y2="0.3937" width="0.4064" layer="51"/>
<wire x1="15.494" y1="0.3937" x2="15.0114" y2="0.8763" width="0.4064" layer="51"/>
<wire x1="15.0114" y1="0.8763" x2="15.9258" y2="6.1341" width="0.4064" layer="51"/>
<wire x1="15.9258" y1="6.1341" x2="16.2814" y2="6.4897" width="0.4064" layer="51"/>
<wire x1="15.9766" y1="-0.0889" x2="16.6116" y2="0.5461" width="0.4064" layer="51"/>
<wire x1="16.6116" y1="0.5461" x2="21.7424" y2="0.5461" width="0.4064" layer="51"/>
<wire x1="21.7424" y1="0.5461" x2="22.2504" y2="0.0381" width="0.4064" layer="51"/>
<wire x1="22.2504" y1="0.0381" x2="21.7424" y2="-0.4699" width="0.4064" layer="51"/>
<wire x1="21.7424" y1="-0.4699" x2="16.3576" y2="-0.4699" width="0.4064" layer="51"/>
<wire x1="16.3576" y1="-0.4699" x2="15.9766" y2="-0.0889" width="0.4064" layer="51"/>
<wire x1="15.494" y1="-0.5715" x2="15.748" y2="-0.8255" width="0.4064" layer="51"/>
<wire x1="14.3002" y1="-6.3881" x2="14.8844" y2="-5.8039" width="0.4064" layer="51"/>
<wire x1="14.8844" y1="-5.8039" x2="15.748" y2="-0.8255" width="0.4064" layer="51"/>
<wire x1="15.494" y1="-0.5715" x2="14.605" y2="-1.4605" width="0.4064" layer="51"/>
<wire x1="14.605" y1="-1.4605" x2="13.8176" y2="-5.9055" width="0.4064" layer="51"/>
<wire x1="13.8176" y1="-5.9055" x2="14.3002" y2="-6.3881" width="0.4064" layer="51"/>
<wire x1="14.7828" y1="-6.8707" x2="15.4686" y2="-6.1849" width="0.4064" layer="51"/>
<wire x1="15.4686" y1="-6.1849" x2="20.7264" y2="-6.1849" width="0.4064" layer="51"/>
<wire x1="20.7264" y1="-6.1849" x2="21.4122" y2="-6.8707" width="0.4064" layer="51"/>
<wire x1="21.4122" y1="-6.8707" x2="21.082" y2="-7.2009" width="0.4064" layer="51"/>
<wire x1="21.082" y1="-7.2009" x2="15.113" y2="-7.2009" width="0.4064" layer="51"/>
<wire x1="15.113" y1="-7.2009" x2="14.7828" y2="-6.8707" width="0.4064" layer="51"/>
<wire x1="22.733" y1="-0.4191" x2="21.8948" y2="-1.2573" width="0.4064" layer="51"/>
<wire x1="21.8948" y1="-1.2573" x2="21.1328" y2="-5.6515" width="0.4064" layer="51"/>
<wire x1="21.1328" y1="-5.6515" x2="21.8948" y2="-6.4135" width="0.4064" layer="51"/>
<wire x1="21.8948" y1="-6.4135" x2="22.098" y2="-6.2103" width="0.4064" layer="51"/>
<wire x1="22.098" y1="-6.2103" x2="23.0124" y2="-0.6985" width="0.4064" layer="51"/>
<wire x1="23.0124" y1="-0.6985" x2="22.733" y2="-0.4191" width="0.4064" layer="51"/>
<wire x1="22.5298" y1="-1.0033" x2="21.6916" y2="-5.8293" width="0.8128" layer="51"/>
<wire x1="20.828" y1="-6.6929" x2="15.367" y2="-6.6929" width="0.8128" layer="51"/>
<wire x1="14.4018" y1="-5.7785" x2="15.2654" y2="-1.1303" width="0.8128" layer="51"/>
<wire x1="15.5194" y1="1.0033" x2="16.383" y2="5.8801" width="0.8128" layer="51"/>
<wire x1="17.2974" y1="6.7691" x2="22.86" y2="6.7691" width="0.8128" layer="51"/>
<wire x1="23.622" y1="5.9309" x2="22.8092" y2="1.0795" width="0.8128" layer="51"/>
<wire x1="21.717" y1="0.0381" x2="16.5354" y2="0.0381" width="0.8128" layer="51"/>
<circle x="23.622" y="-6.1849" radius="0.381" width="0.762" layer="51"/>
</package>
<package name="4DIGIT_0-8">
<description>&lt;b&gt;LED DISPLAY&lt;/b&gt;&lt;p&gt;
 20-mm 4 character 7 segment, decimal point right</description>
<wire x1="-35.306" y1="12.0396" x2="-35.306" y2="-13.3096" width="0.1524" layer="21"/>
<wire x1="-35.306" y1="12.0396" x2="36.576" y2="12.0396" width="0.1524" layer="21"/>
<wire x1="36.576" y1="12.0396" x2="36.576" y2="-13.3096" width="0.1524" layer="21"/>
<wire x1="36.576" y1="-13.3096" x2="-35.306" y2="-13.3096" width="0.1524" layer="21"/>
<pad name="1" x="-13.97" y="10.16" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-11.43" y="10.16" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-8.89" y="10.16" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-6.35" y="10.16" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-3.81" y="10.16" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-1.27" y="10.16" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="1.27" y="10.16" drill="0.8128" shape="long" rot="R270"/>
<pad name="8" x="3.81" y="10.16" drill="0.8128" shape="long" rot="R270"/>
<pad name="9" x="6.35" y="10.16" drill="0.8128" shape="long" rot="R270"/>
<pad name="10" x="8.89" y="10.16" drill="0.8128" shape="long" rot="R270"/>
<pad name="11" x="11.43" y="10.16" drill="0.8128" shape="long" rot="R270"/>
<pad name="12" x="13.97" y="10.16" drill="0.8128" shape="long" rot="R270"/>
<text x="-35.56" y="12.7" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-35.56" y="-15.24" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="2DIGIT_0-56">
<description>&lt;b&gt;14.22mm (0.56INCH) 2 DIGIT NUMERIC DISPLAY&lt;/b&gt;&lt;p&gt;</description>
<wire x1="-12.525" y1="9.5" x2="12.55" y2="9.5" width="0.2032" layer="21"/>
<wire x1="12.55" y1="9.5" x2="12.55" y2="-9.5" width="0.2032" layer="21"/>
<wire x1="12.55" y1="-9.5" x2="-12.525" y2="-9.5" width="0.2032" layer="21"/>
<wire x1="-12.525" y1="-9.5" x2="-12.525" y2="9.5" width="0.2032" layer="21"/>
<circle x="-1.2517" y="-6.5231" radius="0.7305" width="0" layer="21"/>
<circle x="11.3733" y="-6.5731" radius="0.7305" width="0" layer="21"/>
<pad name="1" x="-5.08" y="-7.62" drill="0.8" diameter="1.4224"/>
<pad name="2" x="-2.54" y="-7.62" drill="0.8" diameter="1.4224"/>
<pad name="3" x="0" y="-7.62" drill="0.8" diameter="1.4224"/>
<pad name="4" x="2.54" y="-7.62" drill="0.8" diameter="1.4224"/>
<pad name="5" x="5.08" y="-7.62" drill="0.8" diameter="1.4224"/>
<pad name="6" x="5.08" y="7.62" drill="0.8" diameter="1.4224" rot="R180"/>
<pad name="7" x="2.54" y="7.62" drill="0.8" diameter="1.4224" rot="R180"/>
<pad name="8" x="0" y="7.62" drill="0.8" diameter="1.4224" rot="R180"/>
<pad name="9" x="-2.54" y="7.62" drill="0.8" diameter="1.4224" rot="R180"/>
<pad name="10" x="-5.08" y="7.62" drill="0.8" diameter="1.4224" rot="R180"/>
<text x="-12.065" y="10.16" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="0.635" y="10.16" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<polygon width="0.3976" layer="51" spacing="1.2428">
<vertex x="-7.1945" y="5.9694"/>
<vertex x="-7.0233" y="6.948"/>
<vertex x="-3.0037" y="6.948"/>
<vertex x="-3.126" y="5.9694"/>
</polygon>
<vertex x="-3.4132" y="1.0329"/>
<vertex x="-2.3796" y="6.9034"/>
<vertex x="-2.077" y="6.9114" curve="-104.731141"/>
<vertex x="-1.4592" y="6.071"/>
<vertex x="-2.4899" y="0.4893"/>
<vertex x="-2.9547" y="0.4893"/>
</polygon>
<vertex x="-8.6869" y="1.0764"/>
<vertex x="-7.6593" y="6.948"/>
<vertex x="-7.9285" y="6.948" curve="77.705866"/>
<vertex x="-8.8092" y="6.2385"/>
<vertex x="-9.8122" y="0.4893"/>
<vertex x="-9.2495" y="0.4893"/>
</polygon>
<polygon width="0.3976" layer="21" spacing="1.2428">
<vertex x="-8.7847" y="0.0245"/>
<vertex x="-8.1731" y="0.6361"/>
<vertex x="-3.9578" y="0.6361"/>
<vertex x="-3.5908" y="0.1223"/>
<vertex x="-4.0312" y="-0.3425"/>
<vertex x="-8.4177" y="-0.3425"/>
</polygon>
<vertex x="-5.1321" y="-5.7003"/>
<vertex x="-5.3033" y="-6.6789"/>
<vertex x="-9.3229" y="-6.6789"/>
<vertex x="-9.2006" y="-5.7003"/>
</polygon>
<vertex x="-8.9868" y="-0.7149"/>
<vertex x="-9.9471" y="-6.6343"/>
<vertex x="-10.2497" y="-6.6423" curve="-104.72259"/>
<vertex x="-10.8674" y="-5.8019"/>
<vertex x="-9.9101" y="-0.1713"/>
<vertex x="-9.4453" y="-0.1713"/>
</polygon>
<vertex x="-3.6887" y="-0.9541"/>
<vertex x="-4.6673" y="-6.6789"/>
<vertex x="-4.3982" y="-6.6789" curve="77.701982"/>
<vertex x="-3.5174" y="-5.9694"/>
<vertex x="-2.5878" y="-0.4159"/>
<vertex x="-3.1505" y="-0.4159"/>
</polygon>
<vertex x="5.3055" y="5.9694"/>
<vertex x="5.4767" y="6.948"/>
<vertex x="9.4963" y="6.948"/>
<vertex x="9.374" y="5.9694"/>
</polygon>
<vertex x="9.0868" y="1.0329"/>
<vertex x="10.1204" y="6.9034"/>
<vertex x="10.423" y="6.9114" curve="-104.731141"/>
<vertex x="11.0408" y="6.071"/>
<vertex x="10.0101" y="0.4893"/>
<vertex x="9.5453" y="0.4893"/>
</polygon>
<vertex x="3.8131" y="1.0764"/>
<vertex x="4.8407" y="6.948"/>
<vertex x="4.5715" y="6.948" curve="77.705866"/>
<vertex x="3.6908" y="6.2385"/>
<vertex x="2.6878" y="0.4893"/>
<vertex x="3.2505" y="0.4893"/>
</polygon>
<vertex x="3.7153" y="0.0245"/>
<vertex x="4.3269" y="0.6361"/>
<vertex x="8.5422" y="0.6361"/>
<vertex x="8.9092" y="0.1223"/>
<vertex x="8.4688" y="-0.3425"/>
<vertex x="4.0823" y="-0.3425"/>
</polygon>
<vertex x="7.3679" y="-5.7003"/>
<vertex x="7.1967" y="-6.6789"/>
<vertex x="3.1771" y="-6.6789"/>
<vertex x="3.2994" y="-5.7003"/>
</polygon>
<vertex x="3.5132" y="-0.7149"/>
<vertex x="2.5529" y="-6.6343"/>
<vertex x="2.2503" y="-6.6423" curve="-104.72259"/>
<vertex x="1.6326" y="-5.8019"/>
<vertex x="2.5899" y="-0.1713"/>
<vertex x="3.0547" y="-0.1713"/>
</polygon>
<vertex x="8.8113" y="-0.9541"/>
<vertex x="7.8327" y="-6.6789"/>
<vertex x="8.1018" y="-6.6789" curve="77.701982"/>
<vertex x="8.9826" y="-5.9694"/>
<vertex x="9.9122" y="-0.4159"/>
<vertex x="9.3495" y="-0.4159"/>
</polygon>
</package>
</packages>
<symbols>
<symbol name="4DIGIT_0-56">
<wire x1="-4.826" y1="-3.683" x2="-4.572" y2="-3.683" width="0.3048" layer="94"/>
<wire x1="-5.2832" y1="3.1242" x2="-5.588" y2="2.8194" width="0.254" layer="94"/>
<wire x1="-5.588" y1="2.8194" x2="-5.9944" y2="0.6096" width="0.254" layer="94"/>
<wire x1="-5.9944" y1="0.6096" x2="-5.715" y2="0.3302" width="0.254" layer="94"/>
<wire x1="-5.715" y1="0.3302" x2="-5.461" y2="0.5842" width="0.254" layer="94"/>
<wire x1="-5.461" y1="0.5842" x2="-5.08" y2="2.921" width="0.254" layer="94"/>
<wire x1="-5.08" y1="2.921" x2="-5.2832" y2="3.1242" width="0.254" layer="94"/>
<wire x1="-5.588" y1="3.429" x2="-5.842" y2="3.175" width="0.254" layer="94"/>
<wire x1="-5.842" y1="3.175" x2="-8.382" y2="3.175" width="0.254" layer="94"/>
<wire x1="-8.382" y1="3.175" x2="-8.636" y2="3.429" width="0.254" layer="94"/>
<wire x1="-8.636" y1="3.429" x2="-8.382" y2="3.683" width="0.254" layer="94"/>
<wire x1="-8.382" y1="3.683" x2="-5.842" y2="3.683" width="0.254" layer="94"/>
<wire x1="-5.842" y1="3.683" x2="-5.588" y2="3.429" width="0.254" layer="94"/>
<wire x1="-8.9408" y1="3.1242" x2="-8.636" y2="2.8194" width="0.254" layer="94"/>
<wire x1="-8.636" y1="2.8194" x2="-9.017" y2="0.6096" width="0.254" layer="94"/>
<wire x1="-9.017" y1="0.6096" x2="-9.271" y2="0.3556" width="0.254" layer="94"/>
<wire x1="-9.271" y1="0.3556" x2="-9.525" y2="0.6096" width="0.254" layer="94"/>
<wire x1="-9.525" y1="0.6096" x2="-9.144" y2="2.921" width="0.254" layer="94"/>
<wire x1="-9.144" y1="2.921" x2="-8.9408" y2="3.1242" width="0.254" layer="94"/>
<wire x1="-9.0932" y1="-0.0762" x2="-8.763" y2="0.254" width="0.254" layer="94"/>
<wire x1="-8.763" y1="0.254" x2="-6.2738" y2="0.254" width="0.254" layer="94"/>
<wire x1="-6.2738" y1="0.254" x2="-6.0706" y2="0.0508" width="0.254" layer="94"/>
<wire x1="-6.0706" y1="0.0508" x2="-6.3754" y2="-0.254" width="0.254" layer="94"/>
<wire x1="-6.3754" y1="-0.254" x2="-8.9154" y2="-0.254" width="0.254" layer="94"/>
<wire x1="-8.9154" y1="-0.254" x2="-9.0932" y2="-0.0762" width="0.254" layer="94"/>
<wire x1="-9.4488" y1="-0.3302" x2="-9.1948" y2="-0.5842" width="0.254" layer="94"/>
<wire x1="-9.906" y1="-3.1242" x2="-9.5758" y2="-2.794" width="0.254" layer="94"/>
<wire x1="-9.5758" y1="-2.794" x2="-9.1948" y2="-0.5842" width="0.254" layer="94"/>
<wire x1="-9.4488" y1="-0.3302" x2="-9.7282" y2="-0.6096" width="0.254" layer="94"/>
<wire x1="-9.7282" y1="-0.6096" x2="-10.1092" y2="-2.921" width="0.254" layer="94"/>
<wire x1="-10.1092" y1="-2.921" x2="-9.906" y2="-3.1242" width="0.254" layer="94"/>
<wire x1="-9.6012" y1="-3.429" x2="-9.3472" y2="-3.175" width="0.254" layer="94"/>
<wire x1="-9.3472" y1="-3.175" x2="-6.8072" y2="-3.175" width="0.254" layer="94"/>
<wire x1="-6.8072" y1="-3.175" x2="-6.5532" y2="-3.429" width="0.254" layer="94"/>
<wire x1="-6.5532" y1="-3.429" x2="-6.8072" y2="-3.683" width="0.254" layer="94"/>
<wire x1="-6.8072" y1="-3.683" x2="-9.3472" y2="-3.683" width="0.254" layer="94"/>
<wire x1="-9.3472" y1="-3.683" x2="-9.6012" y2="-3.429" width="0.254" layer="94"/>
<wire x1="-5.9182" y1="-0.4064" x2="-6.1722" y2="-0.6604" width="0.254" layer="94"/>
<wire x1="-6.1722" y1="-0.6604" x2="-6.5532" y2="-2.8194" width="0.254" layer="94"/>
<wire x1="-6.5532" y1="-2.8194" x2="-6.2484" y2="-3.1242" width="0.254" layer="94"/>
<wire x1="-6.2484" y1="-3.1242" x2="-6.0452" y2="-2.921" width="0.254" layer="94"/>
<wire x1="-6.0452" y1="-2.921" x2="-5.6642" y2="-0.6604" width="0.254" layer="94"/>
<wire x1="-5.6642" y1="-0.6604" x2="-5.9182" y2="-0.4064" width="0.254" layer="94"/>
<wire x1="-5.334" y1="2.794" x2="-5.715" y2="0.635" width="0.4064" layer="94"/>
<wire x1="-5.842" y1="3.429" x2="-8.382" y2="3.429" width="0.4064" layer="94"/>
<wire x1="-8.89" y1="2.794" x2="-9.271" y2="0.635" width="0.4064" layer="94"/>
<wire x1="-8.89" y1="0" x2="-6.35" y2="0" width="0.4064" layer="94"/>
<wire x1="-5.969" y1="-0.762" x2="-6.35" y2="-2.794" width="0.4064" layer="94"/>
<wire x1="-6.858" y1="-3.429" x2="-9.271" y2="-3.429" width="0.4064" layer="94"/>
<wire x1="-9.906" y1="-2.921" x2="-9.525" y2="-0.635" width="0.4064" layer="94"/>
<wire x1="-12.7" y1="5.08" x2="-12.7" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="20.32" y1="-5.08" x2="20.32" y2="5.08" width="0.4064" layer="94"/>
<wire x1="-12.7" y1="5.08" x2="20.32" y2="5.08" width="0.4064" layer="94"/>
<wire x1="20.32" y1="-5.08" x2="-12.7" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="2.794" y1="-3.683" x2="3.048" y2="-3.683" width="0.3048" layer="94"/>
<wire x1="2.3368" y1="3.1242" x2="2.032" y2="2.8194" width="0.254" layer="94"/>
<wire x1="2.032" y1="2.8194" x2="1.6256" y2="0.6096" width="0.254" layer="94"/>
<wire x1="1.6256" y1="0.6096" x2="1.905" y2="0.3302" width="0.254" layer="94"/>
<wire x1="1.905" y1="0.3302" x2="2.159" y2="0.5842" width="0.254" layer="94"/>
<wire x1="2.159" y1="0.5842" x2="2.54" y2="2.921" width="0.254" layer="94"/>
<wire x1="2.54" y1="2.921" x2="2.3368" y2="3.1242" width="0.254" layer="94"/>
<wire x1="2.032" y1="3.429" x2="1.778" y2="3.175" width="0.254" layer="94"/>
<wire x1="1.778" y1="3.175" x2="-0.762" y2="3.175" width="0.254" layer="94"/>
<wire x1="-0.762" y1="3.175" x2="-1.016" y2="3.429" width="0.254" layer="94"/>
<wire x1="-1.016" y1="3.429" x2="-0.762" y2="3.683" width="0.254" layer="94"/>
<wire x1="-0.762" y1="3.683" x2="1.778" y2="3.683" width="0.254" layer="94"/>
<wire x1="1.778" y1="3.683" x2="2.032" y2="3.429" width="0.254" layer="94"/>
<wire x1="-1.3208" y1="3.1242" x2="-1.016" y2="2.8194" width="0.254" layer="94"/>
<wire x1="-1.016" y1="2.8194" x2="-1.397" y2="0.6096" width="0.254" layer="94"/>
<wire x1="-1.397" y1="0.6096" x2="-1.651" y2="0.3556" width="0.254" layer="94"/>
<wire x1="-1.651" y1="0.3556" x2="-1.905" y2="0.6096" width="0.254" layer="94"/>
<wire x1="-1.905" y1="0.6096" x2="-1.524" y2="2.921" width="0.254" layer="94"/>
<wire x1="-1.524" y1="2.921" x2="-1.3208" y2="3.1242" width="0.254" layer="94"/>
<wire x1="-1.4732" y1="-0.0762" x2="-1.143" y2="0.254" width="0.254" layer="94"/>
<wire x1="-1.143" y1="0.254" x2="1.3462" y2="0.254" width="0.254" layer="94"/>
<wire x1="1.3462" y1="0.254" x2="1.5494" y2="0.0508" width="0.254" layer="94"/>
<wire x1="1.5494" y1="0.0508" x2="1.2446" y2="-0.254" width="0.254" layer="94"/>
<wire x1="1.2446" y1="-0.254" x2="-1.2954" y2="-0.254" width="0.254" layer="94"/>
<wire x1="-1.2954" y1="-0.254" x2="-1.4732" y2="-0.0762" width="0.254" layer="94"/>
<wire x1="-1.8288" y1="-0.3302" x2="-1.5748" y2="-0.5842" width="0.254" layer="94"/>
<wire x1="-2.286" y1="-3.1242" x2="-1.9558" y2="-2.794" width="0.254" layer="94"/>
<wire x1="-1.9558" y1="-2.794" x2="-1.5748" y2="-0.5842" width="0.254" layer="94"/>
<wire x1="-1.8288" y1="-0.3302" x2="-2.1082" y2="-0.6096" width="0.254" layer="94"/>
<wire x1="-2.1082" y1="-0.6096" x2="-2.4892" y2="-2.921" width="0.254" layer="94"/>
<wire x1="-2.4892" y1="-2.921" x2="-2.286" y2="-3.1242" width="0.254" layer="94"/>
<wire x1="-1.9812" y1="-3.429" x2="-1.7272" y2="-3.175" width="0.254" layer="94"/>
<wire x1="-1.7272" y1="-3.175" x2="0.8128" y2="-3.175" width="0.254" layer="94"/>
<wire x1="0.8128" y1="-3.175" x2="1.0668" y2="-3.429" width="0.254" layer="94"/>
<wire x1="1.0668" y1="-3.429" x2="0.8128" y2="-3.683" width="0.254" layer="94"/>
<wire x1="0.8128" y1="-3.683" x2="-1.7272" y2="-3.683" width="0.254" layer="94"/>
<wire x1="-1.7272" y1="-3.683" x2="-1.9812" y2="-3.429" width="0.254" layer="94"/>
<wire x1="1.7018" y1="-0.4064" x2="1.4478" y2="-0.6604" width="0.254" layer="94"/>
<wire x1="1.4478" y1="-0.6604" x2="1.0668" y2="-2.8194" width="0.254" layer="94"/>
<wire x1="1.0668" y1="-2.8194" x2="1.3716" y2="-3.1242" width="0.254" layer="94"/>
<wire x1="1.3716" y1="-3.1242" x2="1.5748" y2="-2.921" width="0.254" layer="94"/>
<wire x1="1.5748" y1="-2.921" x2="1.9558" y2="-0.6604" width="0.254" layer="94"/>
<wire x1="1.9558" y1="-0.6604" x2="1.7018" y2="-0.4064" width="0.254" layer="94"/>
<wire x1="2.286" y1="2.794" x2="1.905" y2="0.635" width="0.4064" layer="94"/>
<wire x1="1.778" y1="3.429" x2="-0.762" y2="3.429" width="0.4064" layer="94"/>
<wire x1="-1.27" y1="2.794" x2="-1.651" y2="0.635" width="0.4064" layer="94"/>
<wire x1="-1.27" y1="0" x2="1.27" y2="0" width="0.4064" layer="94"/>
<wire x1="1.651" y1="-0.762" x2="1.27" y2="-2.794" width="0.4064" layer="94"/>
<wire x1="0.762" y1="-3.429" x2="-1.651" y2="-3.429" width="0.4064" layer="94"/>
<wire x1="-2.286" y1="-2.921" x2="-1.905" y2="-0.635" width="0.4064" layer="94"/>
<wire x1="10.414" y1="-3.683" x2="10.668" y2="-3.683" width="0.3048" layer="94"/>
<wire x1="9.9568" y1="3.1242" x2="9.652" y2="2.8194" width="0.254" layer="94"/>
<wire x1="9.652" y1="2.8194" x2="9.2456" y2="0.6096" width="0.254" layer="94"/>
<wire x1="9.2456" y1="0.6096" x2="9.525" y2="0.3302" width="0.254" layer="94"/>
<wire x1="9.525" y1="0.3302" x2="9.779" y2="0.5842" width="0.254" layer="94"/>
<wire x1="9.779" y1="0.5842" x2="10.16" y2="2.921" width="0.254" layer="94"/>
<wire x1="10.16" y1="2.921" x2="9.9568" y2="3.1242" width="0.254" layer="94"/>
<wire x1="9.652" y1="3.429" x2="9.398" y2="3.175" width="0.254" layer="94"/>
<wire x1="9.398" y1="3.175" x2="6.858" y2="3.175" width="0.254" layer="94"/>
<wire x1="6.858" y1="3.175" x2="6.604" y2="3.429" width="0.254" layer="94"/>
<wire x1="6.604" y1="3.429" x2="6.858" y2="3.683" width="0.254" layer="94"/>
<wire x1="6.858" y1="3.683" x2="9.398" y2="3.683" width="0.254" layer="94"/>
<wire x1="9.398" y1="3.683" x2="9.652" y2="3.429" width="0.254" layer="94"/>
<wire x1="6.2992" y1="3.1242" x2="6.604" y2="2.8194" width="0.254" layer="94"/>
<wire x1="6.604" y1="2.8194" x2="6.223" y2="0.6096" width="0.254" layer="94"/>
<wire x1="6.223" y1="0.6096" x2="5.969" y2="0.3556" width="0.254" layer="94"/>
<wire x1="5.969" y1="0.3556" x2="5.715" y2="0.6096" width="0.254" layer="94"/>
<wire x1="5.715" y1="0.6096" x2="6.096" y2="2.921" width="0.254" layer="94"/>
<wire x1="6.096" y1="2.921" x2="6.2992" y2="3.1242" width="0.254" layer="94"/>
<wire x1="6.1468" y1="-0.0762" x2="6.477" y2="0.254" width="0.254" layer="94"/>
<wire x1="6.477" y1="0.254" x2="8.9662" y2="0.254" width="0.254" layer="94"/>
<wire x1="8.9662" y1="0.254" x2="9.1694" y2="0.0508" width="0.254" layer="94"/>
<wire x1="9.1694" y1="0.0508" x2="8.8646" y2="-0.254" width="0.254" layer="94"/>
<wire x1="8.8646" y1="-0.254" x2="6.3246" y2="-0.254" width="0.254" layer="94"/>
<wire x1="6.3246" y1="-0.254" x2="6.1468" y2="-0.0762" width="0.254" layer="94"/>
<wire x1="5.7912" y1="-0.3302" x2="6.0452" y2="-0.5842" width="0.254" layer="94"/>
<wire x1="5.334" y1="-3.1242" x2="5.6642" y2="-2.794" width="0.254" layer="94"/>
<wire x1="5.6642" y1="-2.794" x2="6.0452" y2="-0.5842" width="0.254" layer="94"/>
<wire x1="5.7912" y1="-0.3302" x2="5.5118" y2="-0.6096" width="0.254" layer="94"/>
<wire x1="5.5118" y1="-0.6096" x2="5.1308" y2="-2.921" width="0.254" layer="94"/>
<wire x1="5.1308" y1="-2.921" x2="5.334" y2="-3.1242" width="0.254" layer="94"/>
<wire x1="5.6388" y1="-3.429" x2="5.8928" y2="-3.175" width="0.254" layer="94"/>
<wire x1="5.8928" y1="-3.175" x2="8.4328" y2="-3.175" width="0.254" layer="94"/>
<wire x1="8.4328" y1="-3.175" x2="8.6868" y2="-3.429" width="0.254" layer="94"/>
<wire x1="8.6868" y1="-3.429" x2="8.4328" y2="-3.683" width="0.254" layer="94"/>
<wire x1="8.4328" y1="-3.683" x2="5.8928" y2="-3.683" width="0.254" layer="94"/>
<wire x1="5.8928" y1="-3.683" x2="5.6388" y2="-3.429" width="0.254" layer="94"/>
<wire x1="9.3218" y1="-0.4064" x2="9.0678" y2="-0.6604" width="0.254" layer="94"/>
<wire x1="9.0678" y1="-0.6604" x2="8.6868" y2="-2.8194" width="0.254" layer="94"/>
<wire x1="8.6868" y1="-2.8194" x2="8.9916" y2="-3.1242" width="0.254" layer="94"/>
<wire x1="8.9916" y1="-3.1242" x2="9.1948" y2="-2.921" width="0.254" layer="94"/>
<wire x1="9.1948" y1="-2.921" x2="9.5758" y2="-0.6604" width="0.254" layer="94"/>
<wire x1="9.5758" y1="-0.6604" x2="9.3218" y2="-0.4064" width="0.254" layer="94"/>
<wire x1="9.906" y1="2.794" x2="9.525" y2="0.635" width="0.4064" layer="94"/>
<wire x1="9.398" y1="3.429" x2="6.858" y2="3.429" width="0.4064" layer="94"/>
<wire x1="6.35" y1="2.794" x2="5.969" y2="0.635" width="0.4064" layer="94"/>
<wire x1="6.35" y1="0" x2="8.89" y2="0" width="0.4064" layer="94"/>
<wire x1="9.271" y1="-0.762" x2="8.89" y2="-2.794" width="0.4064" layer="94"/>
<wire x1="8.382" y1="-3.429" x2="5.969" y2="-3.429" width="0.4064" layer="94"/>
<wire x1="5.334" y1="-2.921" x2="5.715" y2="-0.635" width="0.4064" layer="94"/>
<wire x1="7.62" y1="-4.953" x2="7.62" y2="-10.16" width="0.1524" layer="94"/>
<wire x1="5.08" y1="-4.953" x2="5.08" y2="-10.16" width="0.1524" layer="94"/>
<wire x1="0" y1="-4.953" x2="0" y2="-10.16" width="0.1524" layer="94"/>
<wire x1="-5.08" y1="-4.953" x2="-5.08" y2="-10.16" width="0.1524" layer="94"/>
<wire x1="-7.62" y1="-4.953" x2="-7.62" y2="-10.16" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="-4.953" x2="-2.54" y2="-10.16" width="0.1524" layer="94"/>
<wire x1="2.54" y1="-4.953" x2="2.54" y2="-10.16" width="0.1524" layer="94"/>
<wire x1="15.24" y1="-4.953" x2="15.24" y2="-10.16" width="0.1524" layer="94"/>
<wire x1="0" y1="10.16" x2="0" y2="4.953" width="0.1524" layer="94"/>
<wire x1="-7.62" y1="10.16" x2="-7.62" y2="4.953" width="0.1524" layer="94"/>
<wire x1="7.62" y1="10.16" x2="7.62" y2="4.953" width="0.1524" layer="94"/>
<circle x="-4.699" y="-3.683" radius="0.254" width="0.3048" layer="94"/>
<circle x="2.921" y="-3.683" radius="0.254" width="0.3048" layer="94"/>
<circle x="10.541" y="-3.683" radius="0.254" width="0.3048" layer="94"/>
<text x="-13.335" y="-5.08" size="1.778" layer="95" rot="R90">&gt;NAME</text>
<text x="22.86" y="-5.08" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<text x="-7.874" y="-8.509" size="1.27" layer="95" rot="R90">A</text>
<text x="-5.334" y="-8.509" size="1.27" layer="95" rot="R90">B</text>
<text x="-2.794" y="-8.509" size="1.27" layer="95" rot="R90">C</text>
<text x="-0.254" y="-8.509" size="1.27" layer="95" rot="R90">D</text>
<text x="2.286" y="-8.509" size="1.27" layer="95" rot="R90">E</text>
<text x="4.826" y="-8.509" size="1.27" layer="95" rot="R90">F</text>
<text x="7.366" y="-8.509" size="1.27" layer="95" rot="R90">G</text>
<text x="14.986" y="-8.509" size="1.27" layer="95" rot="R90">DP</text>
<text x="-7.874" y="6.096" size="1.27" layer="95" rot="R90">CC1</text>
<text x="-0.254" y="6.096" size="1.27" layer="95" rot="R90">CC2</text>
<text x="7.366" y="6.096" size="1.27" layer="95" rot="R90">CC3</text>
<pin name="F" x="5.08" y="-15.24" visible="pad" length="middle" direction="pas" rot="R90"/>
<pin name="D" x="0" y="-15.24" visible="pad" length="middle" direction="pas" rot="R90"/>
<pin name="B" x="-5.08" y="-15.24" visible="pad" length="middle" direction="pas" rot="R90"/>
<pin name="A" x="-7.62" y="-15.24" visible="pad" length="middle" direction="pas" rot="R90"/>
<pin name="C" x="-2.54" y="-15.24" visible="pad" length="middle" direction="pas" rot="R90"/>
<pin name="E" x="2.54" y="-15.24" visible="pad" length="middle" direction="pas" rot="R90"/>
<pin name="G" x="7.62" y="-15.24" visible="pad" length="middle" direction="pas" rot="R90"/>
<pin name="DP" x="15.24" y="-15.24" visible="pad" length="middle" direction="pas" rot="R90"/>
<pin name="CC2" x="0" y="15.24" visible="pad" length="middle" direction="pas" rot="R270"/>
<pin name="CC1" x="-7.62" y="15.24" visible="pad" length="middle" direction="pas" rot="R270"/>
<pin name="CC3" x="7.62" y="15.24" visible="pad" length="middle" direction="pas" rot="R270"/>
<wire x1="18.034" y1="-3.683" x2="18.288" y2="-3.683" width="0.3048" layer="94"/>
<wire x1="17.5768" y1="3.1242" x2="17.272" y2="2.8194" width="0.254" layer="94"/>
<wire x1="17.272" y1="2.8194" x2="16.8656" y2="0.6096" width="0.254" layer="94"/>
<wire x1="16.8656" y1="0.6096" x2="17.145" y2="0.3302" width="0.254" layer="94"/>
<wire x1="17.145" y1="0.3302" x2="17.399" y2="0.5842" width="0.254" layer="94"/>
<wire x1="17.399" y1="0.5842" x2="17.78" y2="2.921" width="0.254" layer="94"/>
<wire x1="17.78" y1="2.921" x2="17.5768" y2="3.1242" width="0.254" layer="94"/>
<wire x1="17.272" y1="3.429" x2="17.018" y2="3.175" width="0.254" layer="94"/>
<wire x1="17.018" y1="3.175" x2="14.478" y2="3.175" width="0.254" layer="94"/>
<wire x1="14.478" y1="3.175" x2="14.224" y2="3.429" width="0.254" layer="94"/>
<wire x1="14.224" y1="3.429" x2="14.478" y2="3.683" width="0.254" layer="94"/>
<wire x1="14.478" y1="3.683" x2="17.018" y2="3.683" width="0.254" layer="94"/>
<wire x1="17.018" y1="3.683" x2="17.272" y2="3.429" width="0.254" layer="94"/>
<wire x1="13.9192" y1="3.1242" x2="14.224" y2="2.8194" width="0.254" layer="94"/>
<wire x1="14.224" y1="2.8194" x2="13.843" y2="0.6096" width="0.254" layer="94"/>
<wire x1="13.843" y1="0.6096" x2="13.589" y2="0.3556" width="0.254" layer="94"/>
<wire x1="13.589" y1="0.3556" x2="13.335" y2="0.6096" width="0.254" layer="94"/>
<wire x1="13.335" y1="0.6096" x2="13.716" y2="2.921" width="0.254" layer="94"/>
<wire x1="13.716" y1="2.921" x2="13.9192" y2="3.1242" width="0.254" layer="94"/>
<wire x1="13.7668" y1="-0.0762" x2="14.097" y2="0.254" width="0.254" layer="94"/>
<wire x1="14.097" y1="0.254" x2="16.5862" y2="0.254" width="0.254" layer="94"/>
<wire x1="16.5862" y1="0.254" x2="16.7894" y2="0.0508" width="0.254" layer="94"/>
<wire x1="16.7894" y1="0.0508" x2="16.4846" y2="-0.254" width="0.254" layer="94"/>
<wire x1="16.4846" y1="-0.254" x2="13.9446" y2="-0.254" width="0.254" layer="94"/>
<wire x1="13.9446" y1="-0.254" x2="13.7668" y2="-0.0762" width="0.254" layer="94"/>
<wire x1="13.4112" y1="-0.3302" x2="13.6652" y2="-0.5842" width="0.254" layer="94"/>
<wire x1="12.954" y1="-3.1242" x2="13.2842" y2="-2.794" width="0.254" layer="94"/>
<wire x1="13.2842" y1="-2.794" x2="13.6652" y2="-0.5842" width="0.254" layer="94"/>
<wire x1="13.4112" y1="-0.3302" x2="13.1318" y2="-0.6096" width="0.254" layer="94"/>
<wire x1="13.1318" y1="-0.6096" x2="12.7508" y2="-2.921" width="0.254" layer="94"/>
<wire x1="12.7508" y1="-2.921" x2="12.954" y2="-3.1242" width="0.254" layer="94"/>
<wire x1="13.2588" y1="-3.429" x2="13.5128" y2="-3.175" width="0.254" layer="94"/>
<wire x1="13.5128" y1="-3.175" x2="16.0528" y2="-3.175" width="0.254" layer="94"/>
<wire x1="16.0528" y1="-3.175" x2="16.3068" y2="-3.429" width="0.254" layer="94"/>
<wire x1="16.3068" y1="-3.429" x2="16.0528" y2="-3.683" width="0.254" layer="94"/>
<wire x1="16.0528" y1="-3.683" x2="13.5128" y2="-3.683" width="0.254" layer="94"/>
<wire x1="13.5128" y1="-3.683" x2="13.2588" y2="-3.429" width="0.254" layer="94"/>
<wire x1="16.9418" y1="-0.4064" x2="16.6878" y2="-0.6604" width="0.254" layer="94"/>
<wire x1="16.6878" y1="-0.6604" x2="16.3068" y2="-2.8194" width="0.254" layer="94"/>
<wire x1="16.3068" y1="-2.8194" x2="16.6116" y2="-3.1242" width="0.254" layer="94"/>
<wire x1="16.6116" y1="-3.1242" x2="16.8148" y2="-2.921" width="0.254" layer="94"/>
<wire x1="16.8148" y1="-2.921" x2="17.1958" y2="-0.6604" width="0.254" layer="94"/>
<wire x1="17.1958" y1="-0.6604" x2="16.9418" y2="-0.4064" width="0.254" layer="94"/>
<wire x1="17.526" y1="2.794" x2="17.145" y2="0.635" width="0.4064" layer="94"/>
<wire x1="17.018" y1="3.429" x2="14.478" y2="3.429" width="0.4064" layer="94"/>
<wire x1="13.97" y1="2.794" x2="13.589" y2="0.635" width="0.4064" layer="94"/>
<wire x1="13.97" y1="0" x2="16.51" y2="0" width="0.4064" layer="94"/>
<wire x1="16.891" y1="-0.762" x2="16.51" y2="-2.794" width="0.4064" layer="94"/>
<wire x1="16.002" y1="-3.429" x2="13.589" y2="-3.429" width="0.4064" layer="94"/>
<wire x1="12.954" y1="-2.921" x2="13.335" y2="-0.635" width="0.4064" layer="94"/>
<circle x="18.161" y="-3.683" radius="0.254" width="0.3048" layer="94"/>
<wire x1="15.24" y1="10.16" x2="15.24" y2="4.953" width="0.1524" layer="94"/>
<text x="14.986" y="6.096" size="1.27" layer="95" rot="R90">CC4</text>
<pin name="CC4" x="15.24" y="15.24" visible="pad" length="middle" direction="pas" rot="R270"/>
</symbol>
<symbol name="4DIGIT_0-8">
<description>&lt;b&gt;LED DISPLAY&lt;/b&gt;&lt;p&gt;</description>
</symbol>
<symbol name="2DIGIT_0-56">
<wire x1="-0.2032" y1="3.1242" x2="-0.508" y2="2.8194" width="0.254" layer="94"/>
<wire x1="-0.508" y1="2.8194" x2="-0.9144" y2="0.6096" width="0.254" layer="94"/>
<wire x1="-0.9144" y1="0.6096" x2="-0.635" y2="0.3302" width="0.254" layer="94"/>
<wire x1="-0.635" y1="0.3302" x2="-0.381" y2="0.5842" width="0.254" layer="94"/>
<wire x1="-0.381" y1="0.5842" x2="0" y2="2.921" width="0.254" layer="94"/>
<wire x1="0" y1="2.921" x2="-0.2032" y2="3.1242" width="0.254" layer="94"/>
<wire x1="-0.508" y1="3.429" x2="-0.762" y2="3.175" width="0.254" layer="94"/>
<wire x1="-0.762" y1="3.175" x2="-3.302" y2="3.175" width="0.254" layer="94"/>
<wire x1="-3.302" y1="3.175" x2="-3.556" y2="3.429" width="0.254" layer="94"/>
<wire x1="-3.556" y1="3.429" x2="-3.302" y2="3.683" width="0.254" layer="94"/>
<wire x1="-3.302" y1="3.683" x2="-0.762" y2="3.683" width="0.254" layer="94"/>
<wire x1="-0.762" y1="3.683" x2="-0.508" y2="3.429" width="0.254" layer="94"/>
<wire x1="-3.8608" y1="3.1242" x2="-3.556" y2="2.8194" width="0.254" layer="94"/>
<wire x1="-3.556" y1="2.8194" x2="-3.937" y2="0.6096" width="0.254" layer="94"/>
<wire x1="-3.937" y1="0.6096" x2="-4.191" y2="0.3556" width="0.254" layer="94"/>
<wire x1="-4.191" y1="0.3556" x2="-4.445" y2="0.6096" width="0.254" layer="94"/>
<wire x1="-4.445" y1="0.6096" x2="-4.064" y2="2.921" width="0.254" layer="94"/>
<wire x1="-4.064" y1="2.921" x2="-3.8608" y2="3.1242" width="0.254" layer="94"/>
<wire x1="-4.0132" y1="-0.0762" x2="-3.683" y2="0.254" width="0.254" layer="94"/>
<wire x1="-3.683" y1="0.254" x2="-1.1938" y2="0.254" width="0.254" layer="94"/>
<wire x1="-1.1938" y1="0.254" x2="-0.9906" y2="0.0508" width="0.254" layer="94"/>
<wire x1="-0.9906" y1="0.0508" x2="-1.2954" y2="-0.254" width="0.254" layer="94"/>
<wire x1="-1.2954" y1="-0.254" x2="-3.8354" y2="-0.254" width="0.254" layer="94"/>
<wire x1="-3.8354" y1="-0.254" x2="-4.0132" y2="-0.0762" width="0.254" layer="94"/>
<wire x1="-4.3688" y1="-0.3302" x2="-4.1148" y2="-0.5842" width="0.254" layer="94"/>
<wire x1="-4.826" y1="-3.1242" x2="-4.4958" y2="-2.794" width="0.254" layer="94"/>
<wire x1="-4.3688" y1="-0.3302" x2="-4.6482" y2="-0.6096" width="0.254" layer="94"/>
<wire x1="-4.6482" y1="-0.6096" x2="-5.0292" y2="-2.921" width="0.254" layer="94"/>
<wire x1="-5.0292" y1="-2.921" x2="-4.826" y2="-3.1242" width="0.254" layer="94"/>
<wire x1="-4.5212" y1="-3.429" x2="-4.2672" y2="-3.175" width="0.254" layer="94"/>
<wire x1="-4.2672" y1="-3.175" x2="-1.7272" y2="-3.175" width="0.254" layer="94"/>
<wire x1="-1.7272" y1="-3.175" x2="-1.4732" y2="-3.429" width="0.254" layer="94"/>
<wire x1="-1.4732" y1="-3.429" x2="-1.7272" y2="-3.683" width="0.254" layer="94"/>
<wire x1="-1.7272" y1="-3.683" x2="-4.2672" y2="-3.683" width="0.254" layer="94"/>
<wire x1="-4.2672" y1="-3.683" x2="-4.5212" y2="-3.429" width="0.254" layer="94"/>
<wire x1="-0.8382" y1="-0.4064" x2="-1.0922" y2="-0.6604" width="0.254" layer="94"/>
<wire x1="-1.0922" y1="-0.6604" x2="-1.4732" y2="-2.8194" width="0.254" layer="94"/>
<wire x1="-1.4732" y1="-2.8194" x2="-1.1684" y2="-3.1242" width="0.254" layer="94"/>
<wire x1="-1.1684" y1="-3.1242" x2="-0.9652" y2="-2.921" width="0.254" layer="94"/>
<wire x1="-0.9652" y1="-2.921" x2="-0.5842" y2="-0.6604" width="0.254" layer="94"/>
<wire x1="-0.5842" y1="-0.6604" x2="-0.8382" y2="-0.4064" width="0.254" layer="94"/>
<wire x1="-0.254" y1="2.794" x2="-0.635" y2="0.635" width="0.4064" layer="94"/>
<wire x1="-0.762" y1="3.429" x2="-3.302" y2="3.429" width="0.4064" layer="94"/>
<wire x1="-3.81" y1="2.794" x2="-4.191" y2="0.635" width="0.4064" layer="94"/>
<wire x1="-3.81" y1="0" x2="-1.27" y2="0" width="0.4064" layer="94"/>
<wire x1="-0.889" y1="-0.762" x2="-1.27" y2="-2.794" width="0.4064" layer="94"/>
<wire x1="-1.778" y1="-3.429" x2="-4.191" y2="-3.429" width="0.4064" layer="94"/>
<wire x1="-4.826" y1="-2.921" x2="-4.445" y2="-0.635" width="0.4064" layer="94"/>
<wire x1="-8.89" y1="5.08" x2="11.43" y2="5.08" width="0.4064" layer="94"/>
<wire x1="11.43" y1="-5.08" x2="11.43" y2="5.08" width="0.4064" layer="94"/>
<wire x1="11.43" y1="-5.08" x2="-8.89" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="-8.89" y1="5.08" x2="-8.89" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="-0.127" y1="-3.429" x2="0.127" y2="-3.429" width="0.3048" layer="94"/>
<wire x1="-4.4958" y1="-2.794" x2="-4.1148" y2="-0.5842" width="0.254" layer="94"/>
<wire x1="7.4168" y1="3.1242" x2="7.112" y2="2.8194" width="0.254" layer="94"/>
<wire x1="7.112" y1="2.8194" x2="6.7056" y2="0.6096" width="0.254" layer="94"/>
<wire x1="6.7056" y1="0.6096" x2="6.985" y2="0.3302" width="0.254" layer="94"/>
<wire x1="6.985" y1="0.3302" x2="7.239" y2="0.5842" width="0.254" layer="94"/>
<wire x1="7.239" y1="0.5842" x2="7.62" y2="2.921" width="0.254" layer="94"/>
<wire x1="7.62" y1="2.921" x2="7.4168" y2="3.1242" width="0.254" layer="94"/>
<wire x1="7.112" y1="3.429" x2="6.858" y2="3.175" width="0.254" layer="94"/>
<wire x1="6.858" y1="3.175" x2="4.318" y2="3.175" width="0.254" layer="94"/>
<wire x1="4.318" y1="3.175" x2="4.064" y2="3.429" width="0.254" layer="94"/>
<wire x1="4.064" y1="3.429" x2="4.318" y2="3.683" width="0.254" layer="94"/>
<wire x1="4.318" y1="3.683" x2="6.858" y2="3.683" width="0.254" layer="94"/>
<wire x1="6.858" y1="3.683" x2="7.112" y2="3.429" width="0.254" layer="94"/>
<wire x1="3.7592" y1="3.1242" x2="4.064" y2="2.8194" width="0.254" layer="94"/>
<wire x1="4.064" y1="2.8194" x2="3.683" y2="0.6096" width="0.254" layer="94"/>
<wire x1="3.683" y1="0.6096" x2="3.429" y2="0.3556" width="0.254" layer="94"/>
<wire x1="3.429" y1="0.3556" x2="3.175" y2="0.6096" width="0.254" layer="94"/>
<wire x1="3.175" y1="0.6096" x2="3.556" y2="2.921" width="0.254" layer="94"/>
<wire x1="3.556" y1="2.921" x2="3.7592" y2="3.1242" width="0.254" layer="94"/>
<wire x1="3.6068" y1="-0.0762" x2="3.937" y2="0.254" width="0.254" layer="94"/>
<wire x1="3.937" y1="0.254" x2="6.4262" y2="0.254" width="0.254" layer="94"/>
<wire x1="6.4262" y1="0.254" x2="6.6294" y2="0.0508" width="0.254" layer="94"/>
<wire x1="6.6294" y1="0.0508" x2="6.3246" y2="-0.254" width="0.254" layer="94"/>
<wire x1="6.3246" y1="-0.254" x2="3.7846" y2="-0.254" width="0.254" layer="94"/>
<wire x1="3.7846" y1="-0.254" x2="3.6068" y2="-0.0762" width="0.254" layer="94"/>
<wire x1="3.2512" y1="-0.3302" x2="3.5052" y2="-0.5842" width="0.254" layer="94"/>
<wire x1="2.794" y1="-3.1242" x2="3.1242" y2="-2.794" width="0.254" layer="94"/>
<wire x1="3.2512" y1="-0.3302" x2="2.9718" y2="-0.6096" width="0.254" layer="94"/>
<wire x1="2.9718" y1="-0.6096" x2="2.5908" y2="-2.921" width="0.254" layer="94"/>
<wire x1="2.5908" y1="-2.921" x2="2.794" y2="-3.1242" width="0.254" layer="94"/>
<wire x1="3.0988" y1="-3.429" x2="3.3528" y2="-3.175" width="0.254" layer="94"/>
<wire x1="3.3528" y1="-3.175" x2="5.8928" y2="-3.175" width="0.254" layer="94"/>
<wire x1="5.8928" y1="-3.175" x2="6.1468" y2="-3.429" width="0.254" layer="94"/>
<wire x1="6.1468" y1="-3.429" x2="5.8928" y2="-3.683" width="0.254" layer="94"/>
<wire x1="5.8928" y1="-3.683" x2="3.3528" y2="-3.683" width="0.254" layer="94"/>
<wire x1="3.3528" y1="-3.683" x2="3.0988" y2="-3.429" width="0.254" layer="94"/>
<wire x1="6.7818" y1="-0.4064" x2="6.5278" y2="-0.6604" width="0.254" layer="94"/>
<wire x1="6.5278" y1="-0.6604" x2="6.1468" y2="-2.8194" width="0.254" layer="94"/>
<wire x1="6.1468" y1="-2.8194" x2="6.4516" y2="-3.1242" width="0.254" layer="94"/>
<wire x1="6.4516" y1="-3.1242" x2="6.6548" y2="-2.921" width="0.254" layer="94"/>
<wire x1="6.6548" y1="-2.921" x2="7.0358" y2="-0.6604" width="0.254" layer="94"/>
<wire x1="7.0358" y1="-0.6604" x2="6.7818" y2="-0.4064" width="0.254" layer="94"/>
<wire x1="7.366" y1="2.794" x2="6.985" y2="0.635" width="0.4064" layer="94"/>
<wire x1="6.858" y1="3.429" x2="4.318" y2="3.429" width="0.4064" layer="94"/>
<wire x1="3.81" y1="2.794" x2="3.429" y2="0.635" width="0.4064" layer="94"/>
<wire x1="3.81" y1="0" x2="6.35" y2="0" width="0.4064" layer="94"/>
<wire x1="6.731" y1="-0.762" x2="6.35" y2="-2.794" width="0.4064" layer="94"/>
<wire x1="5.842" y1="-3.429" x2="3.429" y2="-3.429" width="0.4064" layer="94"/>
<wire x1="2.794" y1="-2.921" x2="3.175" y2="-0.635" width="0.4064" layer="94"/>
<wire x1="7.493" y1="-3.429" x2="7.747" y2="-3.429" width="0.3048" layer="94"/>
<wire x1="3.1242" y1="-2.794" x2="3.5052" y2="-0.5842" width="0.254" layer="94"/>
<circle x="0" y="-3.429" radius="0.254" width="0.3048" layer="94"/>
<circle x="7.62" y="-3.429" radius="0.254" width="0.3048" layer="94"/>
<text x="-9.525" y="-5.08" size="1.778" layer="95" rot="R90">&gt;NAME</text>
<text x="13.97" y="-5.08" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<text x="4.826" y="6.096" size="1.27" layer="95" rot="R90">CC2</text>
<text x="-7.874" y="-7.239" size="1.27" layer="95" rot="R90">a</text>
<text x="-5.334" y="-7.239" size="1.27" layer="95" rot="R90">b</text>
<text x="-2.794" y="-7.239" size="1.27" layer="95" rot="R90">c</text>
<text x="-0.254" y="-7.239" size="1.27" layer="95" rot="R90">d</text>
<text x="2.286" y="-7.239" size="1.27" layer="95" rot="R90">e</text>
<text x="4.826" y="-7.239" size="1.27" layer="95" rot="R90">f</text>
<text x="7.366" y="-7.239" size="1.27" layer="95" rot="R90">g</text>
<text x="10.414" y="-7.62" size="1.27" layer="95" rot="MR90">dp</text>
<text x="-2.794" y="6.096" size="1.27" layer="95" rot="R90">CC1</text>
<pin name="DP" x="10.16" y="-10.16" visible="off" length="middle" direction="pas" rot="R90"/>
<pin name="F" x="5.08" y="-10.16" visible="off" length="middle" direction="pas" rot="R90"/>
<pin name="D" x="0" y="-10.16" visible="off" length="middle" direction="pas" rot="R90"/>
<pin name="B" x="-5.08" y="-10.16" visible="off" length="middle" direction="pas" rot="R90"/>
<pin name="A" x="-7.62" y="-10.16" visible="off" length="middle" direction="pas" rot="R90"/>
<pin name="C" x="-2.54" y="-10.16" visible="off" length="middle" direction="pas" rot="R90"/>
<pin name="E" x="2.54" y="-10.16" visible="off" length="middle" direction="pas" rot="R90"/>
<pin name="G" x="7.62" y="-10.16" visible="off" length="middle" direction="pas" rot="R90"/>
<pin name="CC@2" x="5.08" y="10.16" visible="off" length="middle" direction="pas" rot="R270"/>
<pin name="CC@1" x="-2.54" y="10.16" visible="off" length="middle" direction="pas" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="4DIGIT_0-56" prefix="LED">
<gates>
<gate name="G$1" symbol="4DIGIT_0-56" x="0" y="0"/>
</gates>
<devices>
<device name="" package="4DIGIT_0-56">
<connects>
<connect gate="G$1" pin="A" pad="11"/>
<connect gate="G$1" pin="B" pad="7"/>
<connect gate="G$1" pin="C" pad="4"/>
<connect gate="G$1" pin="CC1" pad="12"/>
<connect gate="G$1" pin="CC2" pad="9"/>
<connect gate="G$1" pin="CC3" pad="8"/>
<connect gate="G$1" pin="CC4" pad="6"/>
<connect gate="G$1" pin="D" pad="2"/>
<connect gate="G$1" pin="DP" pad="3"/>
<connect gate="G$1" pin="E" pad="1"/>
<connect gate="G$1" pin="F" pad="10"/>
<connect gate="G$1" pin="G" pad="5"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="4DIGIT_0-8" prefix="LED">
<gates>
<gate name="G$1" symbol="4DIGIT_0-8" x="0" y="0"/>
</gates>
<devices>
<device name="" package="4DIGIT_0-8">
<connects>
<connect gate="G$1" pin="B" pad="4"/>
<connect gate="G$1" pin="C" pad="2"/>
<connect gate="G$1" pin="CC1" pad="1"/>
<connect gate="G$1" pin="CC2" pad="3"/>
<connect gate="G$1" pin="CC3" pad="10"/>
<connect gate="G$1" pin="CC4" pad="12"/>
<connect gate="G$1" pin="D" pad="5"/>
<connect gate="G$1" pin="DP" pad="6"/>
<connect gate="G$1" pin="E" pad="7"/>
<connect gate="G$1" pin="F" pad="8"/>
<connect gate="G$1" pin="G" pad="9"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="2DIGIT_0-56" prefix="LED">
<gates>
<gate name="DIG1" symbol="2DIGIT_0-56" x="0" y="0"/>
</gates>
<devices>
<device name="A" package="2DIGIT_0-56">
<connects>
<connect gate="DIG1" pin="A" pad="10"/>
<connect gate="DIG1" pin="B" pad="9"/>
<connect gate="DIG1" pin="C" pad="1"/>
<connect gate="DIG1" pin="CC@1" pad="8"/>
<connect gate="DIG1" pin="CC@2" pad="7"/>
<connect gate="DIG1" pin="D" pad="4"/>
<connect gate="DIG1" pin="DP" pad="2"/>
<connect gate="DIG1" pin="E" pad="3"/>
<connect gate="DIG1" pin="F" pad="6"/>
<connect gate="DIG1" pin="G" pad="5"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
