#include <PCD8544.h>
static const byte sensorPin = 0;
static const byte ledPin = 13;
// The dimensions of the LCD (in pixels)...
static const byte LCD_WIDTH = 84;
static const byte LCD_HEIGHT = 48;
// The number of lines for the temperature chart...
static const byte CHART_HEIGHT = 5;
// A custom "degrees" symbol...
static const byte DEGREES_CHAR = 1;
static const byte degrees_glyph[] = { 0x00, 0x07, 0x05, 0x07, 0x00 };
// A bitmap graphic (10x2) of a thermometer...
static const byte THERMO_WIDTH = 10;
static const byte THERMO_HEIGHT = 2;
static const byte thermometer[] = { 0x00, 0x00, 0x48, 0xfe, 0x01, 0xfe, 0x00, 0x02, 0x05, 0x02,
                                    0x00, 0x00, 0x62, 0xff, 0xfe, 0xff, 0x60, 0x00, 0x00, 0x00};
static PCD8544 lcd;
void setup() {
  lcd.begin(LCD_WIDTH, LCD_HEIGHT);
  // Register the custom symbol...
  lcd.createChar(DEGREES_CHAR, degrees_glyph);
  pinMode(ledPin, OUTPUT);
  // The internal 1.1V reference provides for better
  // resolution from the LM35, and is also more stable
  // when powered from either a battery or USB...
  analogReference(DEFAULT);
void loop() {
  // Start beyond the edge of the screen...
  static byte xChart = LCD_WIDTH;
  digitalWrite(ledPin, HIGH);
  // Read the temperature (in celsius)...
  float temp = (1.1 * analogRead(sensorPin) * 100.0) / 1024.0;
  // Print the temperature (using the custom "degrees" symbol)...
  lcd.setCursor(0, 0);
  lcd.print("Temp: ");
  lcd.print(temp, 1);
  lcd.print(" \001C ");
  // Draw the thermometer bitmap at the bottom left corner...
  lcd.setCursor(0, LCD_HEIGHT/8 - THERMO_HEIGHT);
  lcd.drawBitmap(thermometer, THERMO_WIDTH, THERMO_HEIGHT);
  // Wrap the chart's current position...
  if (xChart >= LCD_WIDTH) {
    xChart = THERMO_WIDTH + 2;
  // Update the temperature chart...  
  lcd.setCursor(xChart, 1);
  lcd.drawColumn(CHART_HEIGHT, map(temp, 0, 45, 0, CHART_HEIGHT*8));  // ...clipped to the 0-45C range.
  lcd.drawColumn(CHART_HEIGHT, 0);         // ...with a clear marker to see the current chart position.
  xChart++;
  digitalWrite(ledPin, LOW);  
  delay(500);
