<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="9.5.1">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.3175" unitdist="mm" unit="mm" style="lines" multiple="1" display="yes" altdistance="5" altunitdist="mil" altunit="mil"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="16" fill="1" visible="no" active="no"/>
<layer number="3" name="Route3" color="17" fill="1" visible="no" active="no"/>
<layer number="4" name="Route4" color="18" fill="1" visible="no" active="no"/>
<layer number="5" name="Route5" color="19" fill="1" visible="no" active="no"/>
<layer number="6" name="Route6" color="25" fill="1" visible="no" active="no"/>
<layer number="7" name="Route7" color="26" fill="1" visible="no" active="no"/>
<layer number="8" name="Route8" color="27" fill="1" visible="no" active="no"/>
<layer number="9" name="Route9" color="28" fill="1" visible="no" active="no"/>
<layer number="10" name="Route10" color="29" fill="1" visible="no" active="no"/>
<layer number="11" name="Route11" color="30" fill="1" visible="no" active="no"/>
<layer number="12" name="Route12" color="20" fill="1" visible="no" active="no"/>
<layer number="13" name="Route13" color="21" fill="1" visible="no" active="no"/>
<layer number="14" name="Route14" color="22" fill="1" visible="no" active="no"/>
<layer number="15" name="Route15" color="23" fill="1" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="no" active="yes"/>
<layer number="20" name="Dimension" color="24" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="no" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="no" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="yes"/>
<layer number="50" name="dxf" color="7" fill="1" visible="no" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="88" name="SimResults" color="9" fill="1" visible="no" active="no"/>
<layer number="89" name="SimProbes" color="9" fill="1" visible="no" active="no"/>
<layer number="90" name="Modules" color="5" fill="1" visible="no" active="no"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
<layer number="99" name="SpiceOrder" color="5" fill="1" visible="no" active="no"/>
</layers>
<board>
<plain>
<wire x1="0" y1="0" x2="100" y2="0" width="0" layer="20"/>
<wire x1="100" y1="0" x2="100" y2="80" width="0" layer="20"/>
<wire x1="100" y1="80" x2="0" y2="80" width="0" layer="20"/>
<wire x1="0" y1="80" x2="0" y2="0" width="0" layer="20"/>
<text x="21.2725" y="48.895" size="5.08" layer="201" font="vector" ratio="18">+</text>
<text x="56.515" y="77.7875" size="1.778" layer="51">b</text>
<text x="61.595" y="77.7875" size="1.778" layer="51">e</text>
<text x="66.3575" y="77.7875" size="1.778" layer="51">e</text>
<text x="71.4375" y="77.7875" size="1.778" layer="51">e</text>
<text x="76.5175" y="78.105" size="1.778" layer="51">c</text>
<text x="92.3925" y="51.435" size="2.54" layer="51" font="vector" ratio="18">+</text>
<text x="91.7575" y="20.32" size="2.54" layer="51" font="vector" ratio="18">+</text>
<text x="92.71" y="46.6725" size="2.54" layer="51" font="vector" ratio="18">_</text>
<text x="92.075" y="16.1925" size="2.54" layer="51" font="vector" ratio="18">_</text>
<text x="92.075" y="10.4775" size="2.54" layer="51" font="vector" ratio="18">~</text>
<text x="11.43" y="67.31" size="3" layer="16" font="vector" ratio="18" rot="MR270">100x80</text>
<text x="67.31" y="60.6425" size="3" layer="16" font="vector" ratio="18" rot="MR0">zamatőr</text>
<text x="5.715" y="69.215" size="2.54" layer="16" font="vector" ratio="15" rot="MR270">2022-01-04</text>
<text x="95.885" y="17.78" size="2.54" layer="51" font="vector" ratio="15">Be DC 35V</text>
<text x="95.885" y="10.16" size="2.54" layer="51" font="vector" ratio="15">Be AC O</text>
<wire x1="104.775" y1="10.16" x2="107.95" y2="12.065" width="0.3048" layer="51"/>
<text x="92.075" y="47.9425" size="2.54" layer="51" font="vector" ratio="15">Ki 0-30V 0-3A</text>
<text x="60.0075" y="81.915" size="2.54" layer="51" font="vector" ratio="15">3x2N3055</text>
<text x="80.01" y="12.7" size="1.778" layer="51">U</text>
<text x="80.3275" y="7.62" size="1.778" layer="51">I</text>
<text x="82.55" y="6.35" size="1.778" layer="51">GND</text>
<wire x1="79.6925" y1="10.795" x2="80.3275" y2="10.795" width="0.3048" layer="51"/>
<wire x1="80.3275" y1="10.795" x2="82.55" y2="8.5725" width="0.3048" layer="51"/>
<text x="75.565" y="3.81" size="1.778" layer="51">DVM-hez</text>
<text x="47.625" y="106.045" size="5.08" layer="201" font="vector" ratio="18" rot="R90">+</text>
<wire x1="36.5125" y1="93.345" x2="36.5125" y2="101.6" width="0.0762" layer="51" style="shortdash"/>
<wire x1="36.5125" y1="101.6" x2="80.01" y2="101.6" width="0.0762" layer="51" style="shortdash"/>
<wire x1="80.01" y1="101.6" x2="80.01" y2="93.345" width="0.0762" layer="51" style="shortdash"/>
<wire x1="80.01" y1="93.345" x2="36.5125" y2="93.345" width="0.0762" layer="51" style="shortdash"/>
<wire x1="36.5125" y1="93.345" x2="36.5125" y2="101.6" width="0.0762" layer="20" style="shortdash"/>
<wire x1="36.5125" y1="101.6" x2="80.01" y2="101.6" width="0.0762" layer="20" style="shortdash"/>
<wire x1="80.01" y1="101.6" x2="80.01" y2="93.345" width="0.0762" layer="20" style="shortdash"/>
<wire x1="80.01" y1="93.345" x2="36.5125" y2="93.345" width="0.0762" layer="20" style="shortdash"/>
<wire x1="10.16" y1="166.6875" x2="10.16" y2="162.2425" width="0" layer="20"/>
<wire x1="10.16" y1="162.2425" x2="8.5725" y2="160.655" width="0" layer="20" curve="-90"/>
<wire x1="8.5725" y1="160.655" x2="0" y2="160.655" width="0" layer="20"/>
<wire x1="10.16" y1="166.6875" x2="54.2925" y2="166.6875" width="0" layer="20"/>
<circle x="78.4225" y="133.0325" radius="3.54975625" width="0.254" layer="21"/>
<circle x="7.3025" y="120.3325" radius="3.716240625" width="0.254" layer="21"/>
<circle x="12.7" y="98.1075" radius="3.716240625" width="0.254" layer="21"/>
<wire x1="54.2925" y1="166.6875" x2="54.2925" y2="164.465" width="0.0762" layer="20"/>
<wire x1="54.2925" y1="164.465" x2="55.88" y2="163.5125" width="0.0762" layer="20" curve="90"/>
<wire x1="55.88" y1="163.5125" x2="78.105" y2="163.5125" width="0.0762" layer="20"/>
<wire x1="78.105" y1="163.5125" x2="79.6925" y2="164.465" width="0.0762" layer="20" curve="90"/>
<wire x1="79.6925" y1="164.465" x2="79.6925" y2="166.6875" width="0.0762" layer="20"/>
<wire x1="100.0125" y1="141.2875" x2="93.345" y2="141.2875" width="0.0762" layer="20"/>
<wire x1="93.345" y1="141.2875" x2="91.44" y2="139.3825" width="0.0762" layer="20" curve="90"/>
<wire x1="91.44" y1="139.3825" x2="91.44" y2="133.0325" width="0.0762" layer="20"/>
<wire x1="91.44" y1="133.0325" x2="93.345" y2="131.1275" width="0.0762" layer="20" curve="90"/>
<wire x1="93.345" y1="131.1275" x2="100.0125" y2="131.1275" width="0.0762" layer="20"/>
<wire x1="100.0125" y1="110.8075" x2="93.345" y2="110.8075" width="0.0762" layer="20"/>
<wire x1="93.345" y1="110.8075" x2="91.1225" y2="108.9025" width="0.0762" layer="20" curve="90"/>
<wire x1="91.1225" y1="108.9025" x2="91.1225" y2="97.79" width="0.0762" layer="20"/>
<wire x1="91.1225" y1="97.79" x2="93.6625" y2="95.5675" width="0.0762" layer="20" curve="90"/>
<wire x1="93.6625" y1="95.5675" x2="100.0125" y2="95.5675" width="0.0762" layer="20"/>
<wire x1="100.0125" y1="141.2875" x2="100.0125" y2="166.6875" width="0.0762" layer="20"/>
<wire x1="100.0125" y1="166.6875" x2="79.6925" y2="166.6875" width="0.0762" layer="20"/>
<wire x1="100.0125" y1="131.1275" x2="100.0125" y2="110.8075" width="0.0762" layer="20"/>
<wire x1="100.0125" y1="95.5675" x2="100.0125" y2="86.6775" width="0.0762" layer="20"/>
<wire x1="0" y1="160.655" x2="0" y2="86.6775" width="0.0762" layer="20"/>
<wire x1="0" y1="86.6775" x2="100.0125" y2="86.6775" width="0.0762" layer="20"/>
<wire x1="128.5875" y1="36.195" x2="253.0475" y2="36.195" width="0.1016" layer="20"/>
<wire x1="253.0475" y1="36.195" x2="253.0475" y2="0" width="0.1016" layer="20"/>
<wire x1="253.0475" y1="0" x2="128.5875" y2="0" width="0.1016" layer="20"/>
<wire x1="128.5875" y1="0" x2="128.5875" y2="36.195" width="0.1016" layer="20"/>
<text x="162.8775" y="15.875" size="2.54" layer="51" font="vector" ratio="20">+</text>
<text x="157.7975" y="15.875" size="2.54" layer="51" font="vector" ratio="20">-</text>
<text x="222.5675" y="7.62" size="2.1844" layer="21" font="vector" ratio="20">15</text>
<text x="222.5675" y="5.08" size="2.1844" layer="21" font="vector" ratio="20">16</text>
<text x="222.5675" y="2.54" size="2.1844" layer="21" font="vector" ratio="20">17</text>
<text x="215.5825" y="19.685" size="2.1844" layer="51">+</text>
<text x="225.1075" y="20.955" size="2.1844" layer="51" font="vector" ratio="20">_</text>
<text x="215.5825" y="19.685" size="2.1844" layer="51" font="vector" ratio="20">+</text>
<text x="129.54" y="9.525" size="2.54" layer="51" font="vector" ratio="20">~</text>
<text x="184.785" y="2.54" size="2.54" layer="16" font="vector" ratio="15" rot="MR0">125x36</text>
<text x="184.785" y="12.065" size="2.54" layer="16" font="vector" ratio="15" rot="MR0">zamator</text>
<text x="172.72" y="14.9225" size="1.9304" layer="16" font="vector" ratio="15" rot="MR0">,</text>
<text x="173.6725" y="14.9225" size="1.9304" layer="16" font="vector" ratio="15" rot="MR0">,</text>
<text x="193.675" y="-3.175" size="2.54" layer="21" font="vector" ratio="20">+</text>
<text x="212.4075" y="1.5875" size="2.54" layer="21" font="vector" ratio="17">sen</text>
<text x="197.1675" y="-2.54" size="2.54" layer="21" font="vector" ratio="17">sen</text>
<text x="233.045" y="7.62" size="2.1844" layer="21" font="vector" ratio="17">PWM</text>
<text x="247.3325" y="8.255" size="2.54" layer="21" font="vector" ratio="17">ON</text>
<wire x1="220.98" y1="3.4925" x2="219.71" y2="2.2225" width="0.4064" layer="21"/>
<wire x1="210.185" y1="3.4925" x2="210.185" y2="3.175" width="0.4064" layer="21"/>
<wire x1="210.185" y1="3.175" x2="211.1375" y2="2.2225" width="0.4064" layer="21"/>
<wire x1="199.39" y1="-0.3175" x2="199.7075" y2="0" width="0.4064" layer="21"/>
<wire x1="199.7075" y1="0" x2="199.7075" y2="1.905" width="0.4064" layer="21"/>
<wire x1="194.31" y1="1.905" x2="194.31" y2="0.3175" width="0.4064" layer="21"/>
<wire x1="194.31" y1="0.3175" x2="194.6275" y2="0" width="0.4064" layer="21"/>
<wire x1="189.865" y1="1.5875" x2="189.865" y2="-0.3175" width="0.4064" layer="21"/>
<wire x1="189.865" y1="-0.3175" x2="189.5475" y2="-0.635" width="0.4064" layer="21"/>
<wire x1="234.315" y1="5.08" x2="233.045" y2="3.81" width="0.4064" layer="21"/>
<wire x1="233.045" y1="3.81" x2="230.505" y2="3.81" width="0.4064" layer="21"/>
<wire x1="231.4575" y1="8.89" x2="226.695" y2="8.89" width="0.4064" layer="21"/>
<wire x1="229.87" y1="3.81" x2="227.0125" y2="3.81" width="0.4064" layer="21"/>
<text x="232.41" y="22.225" size="2.1844" layer="51" font="vector" ratio="20">+</text>
<text x="239.0775" y="23.495" size="2.1844" layer="51" font="vector" ratio="20">_</text>
<text x="237.49" y="19.3675" size="2.54" layer="21" font="vector" ratio="17">o</text>
<wire x1="237.49" y1="19.3675" x2="239.395" y2="21.2725" width="0.3048" layer="21"/>
<text x="236.22" y="17.145" size="1.778" layer="21" font="vector" ratio="17">GND</text>
<text x="237.1725" y="22.5425" size="1.778" layer="21" font="vector" ratio="17">5V</text>
<wire x1="227.6475" y1="18.7325" x2="233.045" y2="19.3675" width="0.3048" layer="21"/>
<text x="162.56" y="1.5875" size="1.778" layer="21" font="vector" ratio="17">GND</text>
<text x="187.6425" y="-2.8575" size="1.778" layer="21" font="vector" ratio="17">GND</text>
<text x="192.405" y="-5.08" size="1.778" layer="21" font="vector" ratio="17">páka</text>
<text x="158.75" y="22.225" size="1.778" layer="21" font="vector" ratio="17">+20/35V</text>
<text x="180.34" y="24.13" size="1.778" layer="21" font="vector" ratio="17">+20V páka</text>
<wire x1="248.285" y1="13.6525" x2="247.9675" y2="13.6525" width="0.3048" layer="21"/>
<wire x1="247.9675" y1="13.6525" x2="247.9675" y2="13.97" width="0.3048" layer="21"/>
<wire x1="247.9675" y1="13.97" x2="248.285" y2="13.6525" width="0.3048" layer="21"/>
<circle x="140.0175" y="42.8625" radius="0.3175" width="2.54" layer="51"/>
<circle x="148.59" y="42.8625" radius="0.3175" width="2.54" layer="51"/>
<circle x="148.59" y="48.895" radius="0.3175" width="2.54" layer="51"/>
<circle x="140.0175" y="48.895" radius="0.3175" width="2.54" layer="51"/>
<circle x="140.0175" y="54.2925" radius="0.3175" width="2.54" layer="51"/>
<circle x="148.59" y="54.2925" radius="0.3175" width="2.54" layer="51"/>
<wire x1="146.685" y1="54.2925" x2="145.415" y2="54.2925" width="0.4064" layer="51"/>
<wire x1="145.415" y1="54.2925" x2="145.415" y2="50.165" width="0.4064" layer="51"/>
<wire x1="141.9225" y1="54.2925" x2="143.1925" y2="54.2925" width="0.4064" layer="51"/>
<wire x1="143.1925" y1="54.2925" x2="143.1925" y2="50.165" width="0.4064" layer="51"/>
<wire x1="141.9225" y1="42.8625" x2="143.1925" y2="42.8625" width="0.4064" layer="51"/>
<wire x1="143.1925" y1="42.8625" x2="143.1925" y2="47.625" width="0.4064" layer="51"/>
<wire x1="145.415" y1="47.625" x2="145.415" y2="42.8625" width="0.4064" layer="51"/>
<wire x1="145.415" y1="42.8625" x2="146.685" y2="42.8625" width="0.4064" layer="51"/>
<wire x1="146.685" y1="48.895" x2="145.0975" y2="49.8475" width="0.4064" layer="51"/>
<wire x1="143.51" y1="49.8475" x2="141.9225" y2="48.895" width="0.4064" layer="51"/>
<circle x="121.92" y="42.545" radius="0.3175" width="2.54" layer="51"/>
<circle x="121.92" y="47.9425" radius="0.3175" width="2.54" layer="51"/>
<circle x="121.92" y="53.975" radius="0.3175" width="2.54" layer="51"/>
<wire x1="121.92" y1="41.91" x2="121.6025" y2="23.495" width="0.4064" layer="51" style="shortdash"/>
<wire x1="121.6025" y1="23.495" x2="123.5075" y2="20.0025" width="0.4064" layer="51" style="shortdash"/>
<wire x1="123.5075" y1="20.0025" x2="125.4125" y2="20.0025" width="0.4064" layer="51" style="shortdash"/>
<wire x1="138.1125" y1="48.895" x2="124.7775" y2="48.895" width="0.4064" layer="51" style="shortdash"/>
<wire x1="124.7775" y1="48.895" x2="124.46" y2="26.035" width="0.4064" layer="51" style="shortdash"/>
<wire x1="124.46" y1="26.035" x2="125.73" y2="24.765" width="0.4064" layer="51" style="shortdash"/>
<wire x1="122.8725" y1="46.99" x2="125.4125" y2="42.8625" width="0.4064" layer="51" style="shortdash"/>
<wire x1="125.4125" y1="42.8625" x2="139.3825" y2="42.8625" width="0.4064" layer="51" style="shortdash"/>
<wire x1="122.8725" y1="53.975" x2="139.065" y2="53.975" width="0.4064" layer="51" style="shortdash"/>
<wire x1="139.065" y1="53.975" x2="139.3825" y2="54.2925" width="0.4064" layer="51" style="shortdash"/>
<wire x1="161.29" y1="23.495" x2="161.29" y2="38.4175" width="0.4064" layer="51" style="shortdash"/>
<wire x1="161.29" y1="38.4175" x2="155.8925" y2="42.8625" width="0.4064" layer="51" style="shortdash"/>
<wire x1="155.8925" y1="42.8625" x2="148.9075" y2="42.8625" width="0.4064" layer="51" style="shortdash"/>
<wire x1="148.9075" y1="42.8625" x2="148.59" y2="42.545" width="0.4064" layer="51" style="shortdash"/>
<wire x1="148.59" y1="48.895" x2="184.4675" y2="48.895" width="0.4064" layer="51" style="shortdash"/>
<wire x1="184.4675" y1="48.895" x2="246.38" y2="48.895" width="0.4064" layer="51" style="shortdash"/>
<wire x1="246.38" y1="48.895" x2="256.8575" y2="39.37" width="0.4064" layer="51" style="shortdash"/>
<wire x1="256.8575" y1="39.37" x2="256.8575" y2="17.145" width="0.4064" layer="51" style="shortdash"/>
<wire x1="256.8575" y1="17.145" x2="247.65" y2="17.145" width="0.4064" layer="51" style="shortdash"/>
<wire x1="247.65" y1="21.9075" x2="253.0475" y2="21.9075" width="0.4064" layer="51" style="shortdash"/>
<wire x1="253.0475" y1="21.9075" x2="254" y2="22.86" width="0.4064" layer="51" style="shortdash"/>
<wire x1="254" y1="22.86" x2="254" y2="38.1" width="0.4064" layer="51" style="shortdash"/>
<wire x1="254" y1="38.1" x2="249.8725" y2="41.275" width="0.4064" layer="51" style="shortdash"/>
<wire x1="249.8725" y1="41.275" x2="187.6425" y2="41.275" width="0.4064" layer="51" style="shortdash"/>
<wire x1="187.6425" y1="41.275" x2="185.1025" y2="40.3225" width="0.4064" layer="51" style="shortdash"/>
<wire x1="185.1025" y1="40.3225" x2="185.1025" y2="24.765" width="0.4064" layer="51" style="shortdash"/>
<wire x1="185.1025" y1="24.765" x2="186.055" y2="23.8125" width="0.4064" layer="51" style="shortdash"/>
<text x="116.205" y="40.3225" size="3.81" layer="51">0</text>
<text x="106.9975" y="45.72" size="3.81" layer="51">~16V</text>
<text x="107.315" y="52.07" size="3.81" layer="51">~24V</text>
<circle x="187.0075" y="46.99" radius="0.3175" width="2.54" layer="51"/>
<circle x="187.0075" y="41.5925" radius="0.3175" width="2.54" layer="51"/>
<wire x1="186.69" y1="46.6725" x2="184.4675" y2="48.895" width="0.4064" layer="51" style="shortdash"/>
<wire x1="187.325" y1="46.99" x2="188.9125" y2="48.895" width="0.4064" layer="51" style="shortdash"/>
<wire x1="188.9125" y1="48.895" x2="190.8175" y2="48.895" width="0.4064" layer="51" style="shortdash"/>
<wire x1="183.515" y1="47.3075" x2="183.515" y2="43.815" width="0.6096" layer="51"/>
<wire x1="183.515" y1="43.815" x2="183.515" y2="40.9575" width="0.6096" layer="51"/>
<wire x1="183.515" y1="43.815" x2="182.245" y2="43.815" width="0.6096" layer="51"/>
<wire x1="181.9275" y1="45.085" x2="181.9275" y2="42.8625" width="0.6096" layer="51"/>
<text x="159.7025" y="42.8625" size="2.54" layer="51">Forrasztó ON</text>
<text x="152.0825" y="52.3875" size="2.54" layer="51">K1 labortáp 0-30V vagy labortáp 0-18V és forrasztó</text>
<text x="133.35" y="5.3975" size="2.54" layer="16" font="vector" ratio="15" rot="MR0">~</text>
<wire x1="164.1475" y1="23.1775" x2="167.3225" y2="20.0025" width="0.3048" layer="51" style="shortdash"/>
<wire x1="167.3225" y1="20.0025" x2="167.3225" y2="0.635" width="0.3048" layer="51" style="shortdash"/>
<wire x1="162.56" y1="8.255" x2="160.9725" y2="8.255" width="0.3048" layer="51" style="shortdash"/>
<wire x1="160.9725" y1="8.255" x2="157.7975" y2="5.08" width="0.3048" layer="51" style="shortdash"/>
<wire x1="157.7975" y1="5.08" x2="157.7975" y2="0.635" width="0.3048" layer="51" style="shortdash"/>
<wire x1="130.4925" y1="13.97" x2="128.27" y2="11.7475" width="0.3048" layer="51" style="shortdash"/>
<wire x1="128.27" y1="11.7475" x2="128.27" y2="0.635" width="0.3048" layer="51" style="shortdash"/>
<text x="138.1125" y="0.635" size="1.778" layer="51">Labortáphoz</text>
<text x="129.54" y="-0.635" size="2.54" layer="51" font="vector" ratio="20">~</text>
<text x="160.9725" y="-2.2225" size="1.778" layer="21" font="vector" ratio="17">GND</text>
<text x="167.9575" y="0.3175" size="2.54" layer="51" font="vector" ratio="20">+</text>
<wire x1="127.9525" y1="-0.3175" x2="167.64" y2="-0.3175" width="0.3048" layer="51" style="shortdash"/>
<text x="166.37" y="12.065" size="2.54" layer="16" font="vector" ratio="15" rot="MR0">2022-01-06</text>
<text x="212.4075" y="44.1325" size="1.9304" layer="51" font="vector" ratio="15">páka vezérlore-táp</text>
<text x="212.4075" y="-3.81" size="1.9304" layer="51" font="vector" ratio="15">páka vezérlore</text>
<text x="203.835" y="-0.3175" size="1.9304" layer="51" font="vector" ratio="15">senzor,PWM,relé vez.,ON-OFF</text>
<wire x1="221.615" y1="21.2725" x2="230.1875" y2="29.845" width="0.3048" layer="51" style="shortdash"/>
<wire x1="230.1875" y1="29.845" x2="230.505" y2="42.8625" width="0.3048" layer="51" style="shortdash"/>
<wire x1="230.505" y1="42.8625" x2="213.0425" y2="42.8625" width="0.3048" layer="51" style="shortdash"/>
<wire x1="230.505" y1="42.8625" x2="240.9825" y2="42.8625" width="0.3048" layer="51" style="shortdash"/>
<wire x1="227.6475" y1="9.525" x2="225.425" y2="7.3025" width="0.3048" layer="51" style="shortdash"/>
<wire x1="225.425" y1="7.3025" x2="225.425" y2="2.2225" width="0.3048" layer="51" style="shortdash"/>
<wire x1="225.425" y1="2.2225" x2="207.645" y2="2.2225" width="0.3048" layer="51" style="shortdash"/>
<wire x1="207.645" y1="2.2225" x2="204.47" y2="2.2225" width="0.3048" layer="51" style="shortdash"/>
<wire x1="225.425" y1="2.2225" x2="247.65" y2="2.2225" width="0.3048" layer="51" style="shortdash"/>
<wire x1="207.9625" y1="5.08" x2="207.9625" y2="2.54" width="0.3048" layer="51" style="shortdash"/>
<wire x1="207.9625" y1="2.54" x2="207.645" y2="2.2225" width="0.3048" layer="51" style="shortdash"/>
<text x="231.4575" y="5.3975" size="1.9304" layer="51" font="vector" ratio="15">ON-OFF</text>
<text x="230.8225" y="-3.4925" size="1.9304" layer="51" font="vector" ratio="15">"</text>
<text x="230.8225" y="44.45" size="1.9304" layer="51" font="vector" ratio="15">"</text>
<wire x1="216.8525" y1="29.21" x2="209.55" y2="29.21" width="0.1524" layer="51" style="shortdash"/>
<wire x1="209.55" y1="29.21" x2="207.3275" y2="31.4325" width="0.1524" layer="51" style="shortdash"/>
<wire x1="207.3275" y1="31.4325" x2="207.3275" y2="42.545" width="0.1524" layer="51" style="shortdash"/>
<wire x1="207.3275" y1="42.545" x2="206.375" y2="43.4975" width="0.1524" layer="51" style="shortdash"/>
<wire x1="206.375" y1="43.4975" x2="191.135" y2="43.4975" width="0.1524" layer="51" style="shortdash"/>
<wire x1="191.135" y1="43.815" x2="191.135" y2="43.4975" width="0.1524" layer="51" style="shortdash"/>
<text x="190.8175" y="44.7675" size="1.778" layer="51">+5V DC -OFF</text>
<wire x1="128.905" y1="79.0575" x2="253.365" y2="79.0575" width="0.1016" layer="20"/>
<wire x1="253.365" y1="79.0575" x2="253.365" y2="42.8625" width="0.1016" layer="20"/>
<wire x1="253.365" y1="42.8625" x2="128.905" y2="42.8625" width="0.1016" layer="20"/>
<wire x1="128.905" y1="42.8625" x2="128.905" y2="79.0575" width="0.1016" layer="20"/>
<text x="188.2775" y="46.99" size="3.81" layer="16" font="vector" ratio="15" rot="MR0">+</text>
<text x="188.2775" y="46.355" size="3.81" layer="16" font="vector" ratio="15" rot="MR0">_</text>
<circle x="191.135" y="56.8325" radius="3.5069" width="0.1524" layer="20"/>
<circle x="133.35" y="46.6725" radius="3.4925" width="0.1524" layer="20"/>
<circle x="133.35" y="75.2475" radius="3.4925" width="0.0762" layer="20"/>
<wire x1="127" y1="85.725" x2="251.46" y2="85.725" width="0.1016" layer="37"/>
<wire x1="251.46" y1="85.725" x2="251.46" y2="49.53" width="0.1016" layer="37"/>
<wire x1="251.46" y1="49.53" x2="127" y2="49.53" width="0.1016" layer="37"/>
<wire x1="127" y1="49.53" x2="127" y2="85.725" width="0.1016" layer="37"/>
<text x="235.9025" y="59.69" size="2.54" layer="16" font="vector" ratio="15" rot="MR0">2022-01-25</text>
<text x="229.87" y="73.025" size="2.54" layer="16" font="vector" ratio="15" rot="MR0">124x36</text>
<text x="230.1875" y="46.0375" size="2.54" layer="16" font="vector" ratio="15" rot="MR0">zamator</text>
<text x="218.1225" y="48.5775" size="1.9304" layer="16" font="vector" ratio="15" rot="MR0">,</text>
<text x="219.075" y="48.5775" size="1.9304" layer="16" font="vector" ratio="15" rot="MR0">,</text>
<wire x1="141.605" y1="69.5325" x2="141.605" y2="59.69" width="0.2" layer="37"/>
<wire x1="149.5425" y1="70.485" x2="149.5425" y2="62.23" width="0.2" layer="37"/>
<text x="185.42" y="54.61" size="1.9304" layer="37" font="vector" ratio="15">+</text>
<text x="183.515" y="70.8025" size="1.9304" layer="37" font="vector" ratio="15">+</text>
<text x="185.42" y="53.0225" size="1.9304" layer="37" font="vector" ratio="15">_</text>
<text x="183.515" y="69.215" size="1.9304" layer="37" font="vector" ratio="15">_</text>
<text x="234.315" y="66.3575" size="1.9304" layer="37" font="vector" ratio="15">~230V</text>
<text x="125.4125" y="61.9125" size="1.9304" layer="37" font="vector" ratio="15" rot="R90">Be ~8.5V</text>
<wire x1="127" y1="49.53" x2="127" y2="85.725" width="0.2" layer="38"/>
<wire x1="127" y1="85.725" x2="251.46" y2="85.725" width="0.2" layer="38"/>
<wire x1="251.46" y1="85.725" x2="251.46" y2="49.53" width="0.2" layer="38"/>
<wire x1="251.46" y1="49.53" x2="127" y2="49.53" width="0.2" layer="38"/>
<text x="141.2875" y="60.0075" size="1.4224" layer="27" rot="R90">+8V.GND+12V.</text>
<text x="149.225" y="62.5475" size="1.4224" layer="27" rot="R90">-8V.GND+8V.</text>
<text x="189.865" y="71.12" size="2.54" layer="27">+</text>
<text x="182.5625" y="54.61" size="2.54" layer="27">+</text>
<text x="182.5625" y="53.6575" size="2.54" layer="27">_</text>
<text x="190.1825" y="70.1675" size="2.54" layer="27">_</text>
<text x="126.0475" y="86.6775" size="2.54" layer="27">Be~8.5V</text>
<text x="228.6" y="66.04" size="2.54" layer="27">Be~230V</text>
<text x="146.685" y="51.1175" size="2.54" layer="27">Ki</text>
<text x="139.3825" y="49.8475" size="1.778" layer="27">Ki</text>
<wire x1="187.63" y1="146.9925" x2="106.3625" y2="146.9925" width="0" layer="20"/>
<wire x1="106.3625" y1="146.9925" x2="106.3625" y2="108.2675" width="0" layer="20"/>
<text x="143.8275" y="131.1275" size="2.1844" layer="1" font="vector" ratio="15">zamatőr</text>
<text x="128.27" y="106.9975" size="2.1844" layer="1" font="vector" ratio="15">V1</text>
<text x="111.125" y="114.6175" size="2.1844" layer="1" font="vector" ratio="15">V2</text>
<text x="162.56" y="112.7125" size="2.1844" layer="1" font="vector" ratio="15">A1</text>
<wire x1="131.7625" y1="106.045" x2="213.0425" y2="106.045" width="0" layer="51"/>
<wire x1="213.0425" y1="106.045" x2="213.0425" y2="152.0825" width="0" layer="51"/>
<wire x1="213.0425" y1="152.0825" x2="131.7625" y2="152.0825" width="0" layer="51"/>
<wire x1="131.7625" y1="152.0825" x2="131.7625" y2="106.045" width="0" layer="51"/>
<wire x1="106.3625" y1="147.0025" x2="187.6425" y2="147.0025" width="0.4064" layer="20"/>
<wire x1="187.6425" y1="147.0025" x2="187.6425" y2="108.2675" width="0.4064" layer="20"/>
<wire x1="187.6425" y1="108.2675" x2="167.9575" y2="108.2675" width="0.4064" layer="20"/>
<wire x1="167.9575" y1="108.2675" x2="160.655" y2="100.965" width="0.4064" layer="20"/>
<wire x1="160.655" y1="100.965" x2="133.0325" y2="100.965" width="0.4064" layer="20"/>
<wire x1="133.0325" y1="100.965" x2="125.73" y2="108.2675" width="0.4064" layer="20"/>
<wire x1="125.73" y1="108.2675" x2="106.3625" y2="108.2675" width="0.4064" layer="20"/>
<wire x1="106.3625" y1="108.2675" x2="106.3625" y2="147.0025" width="0.4064" layer="20"/>
<wire x1="116.84" y1="144.145" x2="153.67" y2="144.145" width="0" layer="20"/>
<wire x1="131.7625" y1="152.0825" x2="213.0425" y2="152.0825" width="0.508" layer="37"/>
<wire x1="213.0425" y1="152.0825" x2="213.0425" y2="113.3475" width="0.508" layer="37"/>
<wire x1="213.0425" y1="113.3475" x2="193.3575" y2="113.3475" width="0.508" layer="37"/>
<wire x1="193.3575" y1="113.3475" x2="186.055" y2="106.045" width="0.508" layer="37"/>
<wire x1="186.055" y1="106.045" x2="158.4325" y2="106.045" width="0.508" layer="37"/>
<wire x1="158.4325" y1="106.045" x2="151.13" y2="113.3475" width="0.508" layer="37"/>
<wire x1="151.13" y1="113.3475" x2="131.7625" y2="113.3475" width="0.508" layer="37"/>
<wire x1="131.7625" y1="113.3475" x2="131.7625" y2="152.0825" width="0.508" layer="37"/>
<text x="132.3975" y="113.9825" size="2.54" layer="1" font="vector" ratio="15">82x46</text>
<text x="143.51" y="139.7" size="2.3" layer="28" font="vector" ratio="15" rot="MR0">1</text>
<text x="173.99" y="125.73" size="2.3" layer="28" font="vector" ratio="15" rot="MR0">PWM</text>
<text x="152.7175" y="144.145" size="2.3" layer="28" font="vector" ratio="15" rot="MR0">relé</text>
<text x="184.4675" y="147.0025" size="1.778" layer="52" font="vector" ratio="15" rot="MR0">-</text>
<text x="181.9275" y="147.0025" size="1.778" layer="52" font="vector" ratio="15" rot="MR0">+</text>
<text x="155.8925" y="112.7125" size="1.778" layer="52" font="vector" ratio="15" rot="MR0">V1</text>
<text x="139.3825" y="120.015" size="1.778" layer="52" font="vector" ratio="15" rot="MR0">V2</text>
<text x="207.9625" y="141.2875" size="2.54" layer="52" font="vector" ratio="15" rot="MR0">+</text>
<text x="207.3275" y="137.16" size="2.54" layer="52" font="vector" ratio="15" rot="MR0">_</text>
<text x="211.1375" y="138.7475" size="1.778" layer="52" font="vector" ratio="15" rot="MR0">GND</text>
<text x="204.1525" y="127.635" size="2.54" layer="52" font="vector" ratio="15" rot="MR0">1</text>
<text x="191.135" y="123.19" size="2.1844" layer="52" font="vector" ratio="15" rot="MR0">A1</text>
<wire x1="154.94" y1="117.1575" x2="154.94" y2="117.7925" width="0.1524" layer="52"/>
<wire x1="154.94" y1="117.7925" x2="157.48" y2="120.3325" width="0.1524" layer="52"/>
<wire x1="154.305" y1="116.205" x2="150.1775" y2="116.205" width="0.1524" layer="52"/>
<wire x1="150.1775" y1="116.205" x2="148.59" y2="117.7925" width="0.1524" layer="52"/>
<wire x1="135.89" y1="124.7775" x2="135.89" y2="127.635" width="0.1524" layer="52"/>
<wire x1="135.89" y1="127.635" x2="137.4775" y2="129.2225" width="0.1524" layer="52"/>
<text x="191.77" y="117.1575" size="1.778" layer="52" font="vector" ratio="15" rot="MR0">GND</text>
<text x="139.065" y="145.0975" size="2.54" layer="52" font="vector" ratio="15" rot="MR0">1</text>
<text x="185.7375" y="119.0625" size="1.9304" layer="1" font="vector" ratio="16" rot="R90">2022-02-04</text>
<wire x1="150.495" y1="125.73" x2="151.765" y2="125.73" width="0.3048" layer="51"/>
<wire x1="150.495" y1="124.7775" x2="151.765" y2="124.7775" width="0.3048" layer="51"/>
<wire x1="151.765" y1="124.7775" x2="151.13" y2="125.4125" width="0.3048" layer="51"/>
<wire x1="151.13" y1="125.4125" x2="150.495" y2="124.7775" width="0.3048" layer="51"/>
<text x="206.375" y="144.4625" size="1.9304" layer="52" font="vector" ratio="16" rot="MR0">8V</text>
<wire x1="260.985" y1="137.795" x2="260.985" y2="142.24" width="0.4064" layer="22" style="shortdash" locked="yes"/>
<text x="253.365" y="145.415" size="2.1844" layer="22" font="vector" ratio="19" rot="MR0">1</text>
<text x="236.855" y="136.525" size="2.1844" layer="22" font="vector" ratio="19" rot="MR0">1</text>
<text x="230.8225" y="160.655" size="2.1844" layer="22" font="vector" ratio="19" rot="MR0">1</text>
<text x="280.9875" y="148.2725" size="2.1844" layer="22" font="vector" ratio="19" rot="MR0">+</text>
<text x="284.1625" y="148.59" size="2.1844" layer="22" font="vector" ratio="19" rot="MR0">-</text>
<text x="282.8925" y="153.9875" size="2.1844" layer="22" font="vector" ratio="19" rot="MR0">Sp</text>
<text x="285.115" y="160.02" size="2.1844" layer="22" font="vector" ratio="19" rot="MR0">Standby</text>
<wire x1="194.6275" y1="96.8375" x2="276.5425" y2="96.8375" width="0.1524" layer="20"/>
<wire x1="276.5425" y1="96.8375" x2="276.5425" y2="163.83" width="0.1524" layer="20"/>
<wire x1="276.5425" y1="163.83" x2="194.6275" y2="163.83" width="0.1524" layer="20"/>
<wire x1="194.6275" y1="163.83" x2="194.6275" y2="96.8375" width="0.1524" layer="20"/>
<text x="272.7325" y="109.22" size="2.54" layer="1" font="vector" ratio="18" rot="R90">zamatőr</text>
<rectangle x1="257.81" y1="100.965" x2="259.715" y2="106.045" layer="1"/>
<rectangle x1="261.62" y1="100.965" x2="263.525" y2="106.045" layer="1"/>
<text x="272.7325" y="142.24" size="2.54" layer="1" font="vector" ratio="15" rot="R90">82x67</text>
<text x="198.4375" y="99.3775" size="2.54" layer="1" font="vector" ratio="15">2022-01-04</text>
<text x="299.72" y="134.3025" size="2.1844" layer="51" font="vector" ratio="15">PWM</text>
<text x="299.4025" y="136.8425" size="2.1844" layer="51" font="vector" ratio="15">AUT.ON-OF</text>
<text x="299.72" y="139.3825" size="2.1844" layer="51" font="vector" ratio="15">ON-OFF</text>
<text x="226.06" y="105.0925" size="2.1844" layer="51" font="vector" ratio="15">+</text>
<text x="226.3775" y="111.125" size="2.1844" layer="51" font="vector" ratio="15">_</text>
<text x="222.5675" y="107.6325" size="2.1844" layer="51" font="vector" ratio="15">GND</text>
<text x="225.7425" y="101.2825" size="2.1844" layer="51" font="vector" ratio="15">5V.</text>
<text x="274.6375" y="162.2425" size="2.1844" layer="51" font="vector" ratio="15">standby</text>
<wire x1="276.5425" y1="159.7025" x2="276.5425" y2="161.6075" width="0.508" layer="51"/>
<text x="230.1875" y="160.655" size="2.1844" layer="51" font="vector" ratio="15">1</text>
<text x="292.4175" y="103.505" size="2.1844" layer="51" font="vector" ratio="15">senzor</text>
<text x="250.19" y="143.1925" size="2.1844" layer="51" font="vector" ratio="15">1</text>
<text x="234.95" y="138.1125" size="2.1844" layer="51" font="vector" ratio="15">1</text>
<wire x1="273.05" y1="103.8225" x2="273.05" y2="103.1875" width="0.3048" layer="51"/>
<wire x1="273.05" y1="103.1875" x2="271.78" y2="101.9175" width="0.3048" layer="51"/>
<wire x1="271.78" y1="101.9175" x2="274.32" y2="101.9175" width="0.3048" layer="51"/>
<wire x1="274.32" y1="101.9175" x2="273.05" y2="103.1875" width="0.3048" layer="51"/>
<wire x1="287.9725" y1="157.48" x2="289.2425" y2="157.48" width="0.3048" layer="51"/>
<wire x1="289.2425" y1="157.48" x2="288.6075" y2="156.845" width="0.3048" layer="51"/>
<wire x1="288.6075" y1="156.845" x2="287.9725" y2="157.48" width="0.3048" layer="51"/>
<wire x1="288.29" y1="156.5275" x2="288.925" y2="156.5275" width="0.3048" layer="51"/>
<text x="301.625" y="109.22" size="2.1844" layer="52" font="vector" ratio="15" rot="MR0">senzor</text>
<text x="224.79" y="105.0925" size="2.1844" layer="52" font="vector" ratio="15" rot="MR0">+</text>
<text x="224.79" y="111.125" size="2.1844" layer="52" font="vector" ratio="15" rot="MR0">_</text>
<text x="225.425" y="107.6325" size="2.1844" layer="52" font="vector" ratio="15" rot="MR0">GND</text>
<text x="229.87" y="100.33" size="2.1844" layer="52" font="vector" ratio="15" rot="MR0">5V</text>
<text x="310.1975" y="139.3825" size="2.1844" layer="52" font="vector" ratio="15" rot="MR0">ON-OFF</text>
<text x="316.5475" y="136.2075" size="2.1844" layer="52" font="vector" ratio="15" rot="MR0">AUT.ON-OFF</text>
<text x="305.7525" y="133.6675" size="2.1844" layer="52" font="vector" ratio="15" rot="MR0">PWM</text>
<text x="279.4" y="148.59" size="2.1844" layer="51" font="vector" ratio="15">+</text>
<text x="282.8925" y="149.225" size="2.1844" layer="51" font="vector" ratio="15">_</text>
<text x="283.21" y="146.3675" size="2.1844" layer="52" font="vector" ratio="15" rot="MR0">sp</text>
<text x="280.3525" y="146.3675" size="2.1844" layer="51" font="vector" ratio="15">sp</text>
<text x="238.76" y="104.14" size="2.54" layer="52" font="vector" ratio="15" rot="MR0">S1</text>
<text x="255.5875" y="103.8225" size="2.54" layer="52" font="vector" ratio="15" rot="MR0">S2</text>
<text x="272.415" y="103.8225" size="2.54" layer="52" font="vector" ratio="15" rot="MR0">S3</text>
<text x="289.56" y="103.8225" size="2.54" layer="52" font="vector" ratio="15" rot="MR0">S4</text>
<circle x="225.07575" y="158.6865" radius="0.835209375" width="0.8128" layer="48"/>
<circle x="225.07575" y="127.6985" radius="0.830975" width="0.8128" layer="48"/>
<circle x="300.06925" y="127.6985" radius="0.833396875" width="0.8128" layer="48"/>
<circle x="300.06925" y="158.6865" radius="0.84719375" width="0.8128" layer="48"/>
<text x="264.16" y="150.1775" size="1.778" layer="52" rot="MR0">Ofset-0 beáll.</text>
<wire x1="227.0125" y1="150.495" x2="229.5525" y2="147.955" width="0.2032" layer="52" style="shortdash"/>
<wire x1="229.5525" y1="147.955" x2="248.6025" y2="147.955" width="0.2032" layer="52" style="shortdash"/>
<wire x1="248.6025" y1="147.955" x2="248.92" y2="147.6375" width="0.2032" layer="52" style="shortdash"/>
<wire x1="248.92" y1="147.6375" x2="248.92" y2="140.6525" width="0.2032" layer="52" style="shortdash"/>
<wire x1="248.92" y1="147.6375" x2="248.92" y2="147.955" width="0.2032" layer="52" style="shortdash"/>
<wire x1="248.92" y1="147.955" x2="250.5075" y2="149.5425" width="0.2032" layer="52" style="shortdash"/>
<wire x1="250.5075" y1="149.5425" x2="262.89" y2="149.5425" width="0.2032" layer="52" style="shortdash"/>
<text x="259.3975" y="125.095" size="1.778" layer="52" rot="MR0">Ofset-0 beáll.</text>
<wire x1="241.6175" y1="124.7775" x2="242.8875" y2="123.5075" width="0.2032" layer="52" style="shortdash"/>
<wire x1="242.8875" y1="123.5075" x2="258.7625" y2="123.5075" width="0.2032" layer="52" style="shortdash"/>
<wire x1="248.6025" y1="147.955" x2="245.11" y2="151.4475" width="0.2032" layer="52" style="shortdash"/>
<wire x1="245.11" y1="151.4475" x2="245.11" y2="154.305" width="0.2032" layer="52" style="shortdash"/>
<wire x1="245.11" y1="154.305" x2="244.7925" y2="154.6225" width="0.2032" layer="52" style="shortdash"/>
<wire x1="244.7925" y1="154.6225" x2="236.855" y2="154.6225" width="0.2032" layer="52" style="shortdash"/>
<wire x1="256.8575" y1="129.8575" x2="239.7125" y2="129.8575" width="0.2032" layer="52" style="shortdash"/>
<wire x1="239.7125" y1="129.8575" x2="239.395" y2="130.175" width="0.2032" layer="52" style="shortdash"/>
<wire x1="239.395" y1="130.175" x2="239.395" y2="132.715" width="0.2032" layer="52" style="shortdash"/>
<wire x1="239.395" y1="132.715" x2="238.76" y2="133.35" width="0.2032" layer="52" style="shortdash"/>
<text x="229.87" y="152.4" size="1.778" layer="52" rot="MR0">GND</text>
<text x="250.5075" y="136.2075" size="1.778" layer="52" rot="MR0">Mp.</text>
<text x="268.2875" y="117.7925" size="1.778" layer="52" rot="MR0">zöld/piros</text>
<text x="267.6525" y="121.285" size="1.778" layer="52" rot="MR0">led</text>
</plain>
<libraries>
<library name="rcl" urn="urn:adsk.eagle:library:334">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
http://www.secc.co.jp/pdf/os_e/2004/e_os_all.pdf &lt;b&gt;(SANYO)&lt;/b&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0&gt;
&lt;tr valign="top"&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;</description>
<packages>
<package name="E2,5-7" urn="urn:adsk.eagle:footprint:22847/1" library_version="11">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 2.54 mm, diameter 7 mm</description>
<wire x1="-3.048" y1="0" x2="-2.286" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="-0.381" x2="-2.667" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.762" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="3.429" width="0.1524" layer="21"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.6002"/>
<text x="3.048" y="2.032" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.048" y="-3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="C050-030X075" urn="urn:adsk.eagle:footprint:23150/1" library_version="11">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 5 mm, outline 3 x 7.5 mm</description>
<wire x1="-0.3048" y1="0.635" x2="-0.3048" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-0.3048" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="0.635" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.27" x2="-3.683" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.524" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.27" x2="3.683" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.524" x2="-3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.524" x2="3.683" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.524" x2="3.683" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.27" x2="-3.429" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.27" x2="-3.429" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.556" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.556" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0207/10" urn="urn:adsk.eagle:footprint:22992/1" library_version="11">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
type 0207, grid 10 mm</description>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-1.143" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-1.016" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="-2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.143" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-1.143" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.048" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.2606" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.175" y1="-0.3048" x2="4.0386" y2="0.3048" layer="21"/>
<rectangle x1="-4.0386" y1="-0.3048" x2="-3.175" y2="0.3048" layer="21"/>
</package>
<package name="RTRIM64W" urn="urn:adsk.eagle:footprint:23260/1" library_version="11">
<description>&lt;b&gt;Trimm resistor&lt;/b&gt; Spectrol&lt;p&gt;
Cermet MIL-R-22097</description>
<wire x1="2.52" y1="-4.8" x2="-2.03" y2="-4.8" width="0.254" layer="21"/>
<wire x1="-2.03" y1="-4.8" x2="-2.03" y2="4.8" width="0.254" layer="21"/>
<wire x1="-2.03" y1="4.8" x2="2.52" y2="4.8" width="0.254" layer="21"/>
<wire x1="2.52" y1="4.8" x2="2.52" y2="3.2" width="0.254" layer="21"/>
<wire x1="2.52" y1="3.2" x2="2.27" y2="3.2" width="0.254" layer="21"/>
<wire x1="2.27" y1="3.2" x2="2.27" y2="-3.2" width="0.254" layer="21"/>
<wire x1="2.27" y1="-3.2" x2="2.52" y2="-3.2" width="0.254" layer="21"/>
<wire x1="2.52" y1="-3.2" x2="2.52" y2="-4.8" width="0.254" layer="21"/>
<circle x="-0.58" y="3.3" radius="1.1" width="0.1524" layer="21"/>
<pad name="1" x="1.27" y="-2.54" drill="0.6096"/>
<pad name="2" x="1.27" y="0" drill="0.6096"/>
<pad name="3" x="1.27" y="2.54" drill="0.6096"/>
<text x="-2.62" y="-4.95" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="4.35" y="-4.95" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.78" y1="2.25" x2="-0.38" y2="4.35" layer="21"/>
</package>
<package name="P0613/15" urn="urn:adsk.eagle:footprint:23086/1" library_version="11">
type 0613, grid 15 mm</description>
<wire x1="7.62" y1="0" x2="6.985" y2="0" width="0.8128" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.985" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.477" y1="2.032" x2="-6.223" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.477" y1="-2.032" x2="-6.223" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="6.223" y1="-2.286" x2="6.477" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="6.223" y1="2.286" x2="6.477" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.223" y1="2.286" x2="-5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.159" x2="-5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="-2.286" x2="-5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-2.159" x2="-5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="5.207" y1="2.159" x2="5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="5.207" y1="2.159" x2="-5.207" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.159" x2="5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.159" x2="-5.207" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="6.223" y1="2.286" x2="5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="6.223" y1="-2.286" x2="5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-0.635" x2="6.477" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-0.635" x2="6.477" y2="0.635" width="0.1524" layer="51"/>
<wire x1="6.477" y1="2.032" x2="6.477" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="-2.032" x2="-6.477" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="0.635" x2="-6.477" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-6.477" y1="0.635" x2="-6.477" y2="2.032" width="0.1524" layer="21"/>
<pad name="1" x="-7.62" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="1.016" shape="octagon"/>
<text x="-6.477" y="2.6924" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.318" y="-0.7112" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-7.0358" y1="-0.4064" x2="-6.477" y2="0.4064" layer="51"/>
<rectangle x1="6.477" y1="-0.4064" x2="7.0358" y2="0.4064" layer="51"/>
</package>
<package name="M1206" urn="urn:adsk.eagle:footprint:23066/1" library_version="11">
MELF 0.25 W</description>
<wire x1="-2.473" y1="1.483" x2="2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-1.483" x2="-2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-1.483" x2="-2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="1.483" x2="2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="1.143" y1="0.8382" x2="-1.143" y2="0.8382" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-0.8382" x2="-1.143" y2="-0.8382" width="0.1524" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.7018" y1="-0.9144" x2="-1.1176" y2="0.9144" layer="51"/>
<rectangle x1="1.1176" y1="-0.9144" x2="1.7018" y2="0.9144" layer="51"/>
<rectangle x1="-0.3" y1="-0.8001" x2="0.3" y2="0.8001" layer="35"/>
</package>
<package name="EB22,5D" urn="urn:adsk.eagle:footprint:22884/1" library_version="11">
grid 10.16 mm, diameter 22.5 mm</description>
<wire x1="-2.54" y1="0" x2="-1.5748" y2="0" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="0" x2="-1.5748" y2="2.54" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="2.54" x2="-0.4318" y2="2.54" width="0.254" layer="21"/>
<wire x1="-0.4318" y1="2.54" x2="-0.4318" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-0.4318" y1="-2.54" x2="-1.5748" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="-2.54" x2="-1.5748" y2="0" width="0.254" layer="21"/>
<wire x1="0.635" y1="0" x2="2.54" y2="0" width="0.254" layer="21"/>
<wire x1="-2.794" y1="2.54" x2="-2.794" y2="1.27" width="0.254" layer="21"/>
<wire x1="-2.159" y1="1.905" x2="-3.429" y2="1.905" width="0.254" layer="21"/>
<circle x="0" y="0" radius="8.89" width="0.254" layer="21"/>
<circle x="0" y="0" radius="11.303" width="0.1524" layer="21"/>
<pad name="+" x="-5.08" y="0" drill="2.0066" diameter="4.5974"/>
<pad name="-" x="5.08" y="0" drill="2.0066" diameter="4.5974" shape="octagon"/>
<text x="8.4074" y="8.509" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.0546" y="-5.715" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.3302" y1="-2.54" x2="1.6002" y2="2.54" layer="21"/>
</package>
<package name="C1206" urn="urn:adsk.eagle:footprint:23125/1" library_version="11">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;</description>
<wire x1="-2.473" y1="0.983" x2="2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-0.983" x2="-2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-0.983" x2="-2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="0.983" x2="2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-0.965" y1="0.787" x2="0.965" y2="0.787" width="0.1016" layer="51"/>
<wire x1="-0.965" y1="-0.787" x2="0.965" y2="-0.787" width="0.1016" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<rectangle x1="-1.7018" y1="-0.8509" x2="-0.9517" y2="0.8491" layer="51"/>
<rectangle x1="0.9517" y1="-0.8491" x2="1.7018" y2="0.8509" layer="51"/>
<rectangle x1="-0.1999" y1="-0.4001" x2="0.1999" y2="0.4001" layer="35"/>
</package>
<package name="E3,5-8" urn="urn:adsk.eagle:footprint:22857/1" library_version="11">
grid 3.5 mm, diameter 8 mm</description>
<wire x1="-3.429" y1="1.143" x2="-2.667" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="0.762" x2="-3.048" y2="1.524" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="4.064" width="0.1524" layer="21"/>
<pad name="-" x="1.778" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.778" y="0" drill="0.8128" diameter="1.6002"/>
<text x="3.302" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="M1406" urn="urn:adsk.eagle:footprint:23067/1" library_version="11">
MELF 0.12 W</description>
<wire x1="-2.973" y1="0.983" x2="2.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-0.983" x2="-2.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-0.983" x2="-2.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="0.983" x2="2.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.3208" y1="0.762" x2="-1.3208" y2="0.762" width="0.1524" layer="51"/>
<wire x1="1.3208" y1="-0.762" x2="-1.3208" y2="-0.762" width="0.1524" layer="51"/>
<smd name="1" x="-1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<smd name="2" x="1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<rectangle x1="-1.8542" y1="-0.8382" x2="-1.2954" y2="0.8382" layer="51"/>
<rectangle x1="1.2954" y1="-0.8382" x2="1.8542" y2="0.8382" layer="51"/>
<rectangle x1="-0.3" y1="-0.7" x2="0.3" y2="0.7" layer="35"/>
</package>
<package name="E5-10,5" urn="urn:adsk.eagle:footprint:22870/1" library_version="11">
grid 5.08 mm, diameter 10.5 mm</description>
<wire x1="-1.143" y1="0" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.143" x2="-0.254" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.143" x2="-0.254" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.143" x2="-0.889" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.143" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.143" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.651" x2="-3.81" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="1.27" x2="-4.191" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="0" x2="-1.143" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="5.08" width="0.1524" layer="21"/>
<pad name="+" x="-2.54" y="0" drill="1.016" diameter="2.54"/>
<pad name="-" x="2.54" y="0" drill="1.016" diameter="2.54" shape="octagon"/>
<text x="4.699" y="2.7432" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.1242" y="-3.2258" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.143" x2="0.889" y2="1.143" layer="21"/>
</package>
<package name="RTRIM4G/J" urn="urn:adsk.eagle:footprint:23238/1" library_version="11">
<description>&lt;b&gt;Trimm resistor&lt;/b&gt; VISHAY</description>
<wire x1="-2.4" y1="2.4" x2="-2.4" y2="-2.4" width="0.254" layer="51"/>
<wire x1="-2.4" y1="-2.4" x2="2.4" y2="-2.4" width="0.254" layer="51"/>
<wire x1="2.4" y1="-2.4" x2="2.4" y2="2.4" width="0.254" layer="51"/>
<wire x1="2.4" y1="2.4" x2="-2.4" y2="2.4" width="0.254" layer="51"/>
<wire x1="-2.1" y1="-2.4" x2="-2.4" y2="-2.4" width="0.254" layer="21"/>
<wire x1="-2.4" y1="-2.4" x2="-2.4" y2="2.4" width="0.254" layer="21"/>
<wire x1="-2.4" y1="2.4" x2="-1.25" y2="2.4" width="0.254" layer="21"/>
<wire x1="2" y1="-2.4" x2="2.4" y2="-2.4" width="0.254" layer="21"/>
<wire x1="2.4" y1="-2.4" x2="2.4" y2="2.4" width="0.254" layer="21"/>
<wire x1="2.4" y1="2.4" x2="1.25" y2="2.4" width="0.254" layer="21"/>
<wire x1="-0.25" y1="-2.4" x2="0.25" y2="-2.4" width="0.254" layer="21"/>
<circle x="0" y="0" radius="1.85" width="0.1016" layer="21"/>
<smd name="1" x="-1.15" y="-2.75" dx="1.3" dy="1.3" layer="1"/>
<smd name="3" x="1.15" y="-2.75" dx="1.3" dy="1.3" layer="1"/>
<smd name="2" x="0" y="2.75" dx="2" dy="1.3" layer="1"/>
<text x="-2.875" y="-2.54" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="4.045" y="-2.54" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-1.3" y1="-0.2" x2="1.35" y2="0.2" layer="21"/>
<rectangle x1="-0.2" y1="-1.35" x2="0.2" y2="1.3" layer="21"/>
</package>
<package name="R1206" urn="urn:adsk.eagle:footprint:23047/1" library_version="11">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;</description>
<wire x1="0.9525" y1="-0.8128" x2="-0.9652" y2="-0.8128" width="0.1524" layer="51"/>
<wire x1="0.9525" y1="0.8128" x2="-0.9652" y2="0.8128" width="0.1524" layer="51"/>
<smd name="2" x="1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<smd name="1" x="-1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<rectangle x1="-1.6891" y1="-0.8763" x2="-0.9525" y2="0.8763" layer="51"/>
<rectangle x1="0.9525" y1="-0.8763" x2="1.6891" y2="0.8763" layer="51"/>
</package>
<package name="C1210" urn="urn:adsk.eagle:footprint:23126/1" library_version="11">
<wire x1="-0.9652" y1="1.2446" x2="0.9652" y2="1.2446" width="0.1016" layer="51"/>
<wire x1="-0.9652" y1="-1.2446" x2="0.9652" y2="-1.2446" width="0.1016" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.7018" y1="-1.2954" x2="-0.9517" y2="1.3045" layer="51"/>
<rectangle x1="0.9517" y1="-1.3045" x2="1.7018" y2="1.2954" layer="51"/>
</package>
<package name="RTRIM43P" urn="urn:adsk.eagle:footprint:23267/1" library_version="11">
waschfest MIL-R-22097</description>
<wire x1="-9.2" y1="2.2" x2="-9.2" y2="-2.2" width="0.254" layer="21"/>
<wire x1="-9.2" y1="-2.2" x2="8.1" y2="-2.2" width="0.254" layer="21"/>
<wire x1="8.1" y1="-2.2" x2="8.1" y2="2.2" width="0.254" layer="21"/>
<wire x1="8.1" y1="2.2" x2="-9.2" y2="2.2" width="0.254" layer="21"/>
<wire x1="8.2" y1="1.35" x2="9.65" y2="1.35" width="0.1524" layer="21"/>
<wire x1="9.65" y1="1.35" x2="9.65" y2="0.35" width="0.1524" layer="21"/>
<wire x1="9.65" y1="0.35" x2="9.15" y2="0.35" width="0.1524" layer="21"/>
<wire x1="9.15" y1="0.35" x2="9.15" y2="-0.35" width="0.1524" layer="21"/>
<wire x1="9.15" y1="-0.35" x2="9.65" y2="-0.35" width="0.1524" layer="21"/>
<wire x1="9.65" y1="-0.35" x2="9.65" y2="-1.35" width="0.1524" layer="21"/>
<wire x1="9.65" y1="-1.35" x2="8.2" y2="-1.35" width="0.1524" layer="21"/>
<pad name="1" x="-7.62" y="1.27" drill="0.9"/>
<pad name="2" x="0" y="-1.27" drill="0.9"/>
<pad name="3" x="5.08" y="1.27" drill="0.9"/>
<text x="-9.15" y="2.7" size="1.27" layer="25">&gt;NAME</text>
<text x="-6.3" y="0" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="C1808" urn="urn:adsk.eagle:footprint:23197/1" library_version="11">
Source: AVX .. aphvc.pdf</description>
<wire x1="-1.4732" y1="0.9502" x2="1.4732" y2="0.9502" width="0.1016" layer="51"/>
<wire x1="-1.4478" y1="-0.9502" x2="1.4732" y2="-0.9502" width="0.1016" layer="51"/>
<smd name="1" x="-1.95" y="0" dx="1.6" dy="2.2" layer="1"/>
<smd name="2" x="1.95" y="0" dx="1.6" dy="2.2" layer="1"/>
<text x="-2.233" y="1.827" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.233" y="-2.842" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.275" y1="-1.015" x2="-1.225" y2="1.015" layer="51"/>
<rectangle x1="1.225" y1="-1.015" x2="2.275" y2="1.015" layer="51"/>
</package>
</packages>
<packages3d>
<package3d name="E2,5-7" urn="urn:adsk.eagle:package:23345/1" type="box" library_version="11">
<description>ELECTROLYTIC CAPACITOR
<packageinstances>
<packageinstance name="E2,5-7"/>
</packageinstances>
</package3d>
<package3d name="C050-030X075" urn="urn:adsk.eagle:package:23640/1" type="box" library_version="11">
<description>CAPACITOR
<packageinstances>
<packageinstance name="C050-030X075"/>
</packageinstances>
</package3d>
<package3d name="0207/10" urn="urn:adsk.eagle:package:23491/2" type="model" library_version="11">
<description>RESISTOR
<packageinstances>
<packageinstance name="0207/10"/>
</packageinstances>
</package3d>
<package3d name="RTRIM64W" urn="urn:adsk.eagle:package:23748/1" type="box" library_version="11">
<description>Trimm resistor Spectrol
<packageinstances>
<packageinstance name="RTRIM64W"/>
</packageinstances>
</package3d>
<package3d name="P0613/15" urn="urn:adsk.eagle:package:23581/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="P0613/15"/>
</packageinstances>
</package3d>
<package3d name="M1206" urn="urn:adsk.eagle:package:23566/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="M1206"/>
</packageinstances>
</package3d>
<package3d name="EB22,5D" urn="urn:adsk.eagle:package:23380/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="EB22,5D"/>
</packageinstances>
</package3d>
<package3d name="C1206" urn="urn:adsk.eagle:package:23618/2" type="model" library_version="11">
<description>CAPACITOR</description>
<packageinstances>
<packageinstance name="C1206"/>
</packageinstances>
</package3d>
<package3d name="E3,5-8" urn="urn:adsk.eagle:package:23360/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="E3,5-8"/>
</packageinstances>
</package3d>
<package3d name="M1406" urn="urn:adsk.eagle:package:23569/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="M1406"/>
</packageinstances>
</package3d>
<package3d name="E5-10,5" urn="urn:adsk.eagle:package:23372/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="E5-10,5"/>
</packageinstances>
</package3d>
<package3d name="RTRIM4G/J" urn="urn:adsk.eagle:package:23728/1" type="box" library_version="11">
<description>Trimm resistor VISHAY</description>
<packageinstances>
<packageinstance name="RTRIM4G/J"/>
</packageinstances>
</package3d>
<package3d name="R1206" urn="urn:adsk.eagle:package:23540/2" type="model" library_version="11">
<description>RESISTOR</description>
<packageinstances>
<packageinstance name="R1206"/>
</packageinstances>
</package3d>
<package3d name="C1210" urn="urn:adsk.eagle:package:23619/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="C1210"/>
</packageinstances>
</package3d>
<package3d name="RTRIM43P" urn="urn:adsk.eagle:package:23756/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="RTRIM43P"/>
</packageinstances>
</package3d>
<package3d name="C1808" urn="urn:adsk.eagle:package:23689/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="C1808"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="diode" urn="urn:adsk.eagle:library:210">
<description>&lt;b&gt;Diodes&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Motorola : www.onsemi.com
&lt;li&gt;Fairchild : www.fairchildsemi.com
&lt;li&gt;Philips : www.semiconductors.com
&lt;li&gt;Vishay : www.vishay.de
&lt;/ul&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="DO35-10" urn="urn:adsk.eagle:footprint:43092/1" library_version="8">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
diameter 2 mm, horizontal, grid 10.16 mm</description>
<wire x1="5.08" y1="0" x2="4.191" y2="0" width="0.508" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.191" y2="0" width="0.508" layer="51"/>
<wire x1="-0.635" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.635" x2="1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="2.032" y1="1.016" x2="2.286" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.286" y1="0.762" x2="-2.032" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.286" y1="-0.762" x2="-2.032" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.032" y1="-1.016" x2="2.286" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="-0.762" x2="2.286" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0.762" x2="-2.286" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.016" x2="2.032" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-1.016" x2="2.032" y2="-1.016" width="0.1524" layer="21"/>
<pad name="C" x="-5.08" y="0" drill="0.8128" shape="long"/>
<pad name="A" x="5.08" y="0" drill="0.8128" shape="long"/>
<text x="-2.159" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.905" y1="-1.016" x2="-1.397" y2="1.016" layer="21"/>
<rectangle x1="2.286" y1="-0.254" x2="4.191" y2="0.254" layer="21"/>
<rectangle x1="-4.191" y1="-0.254" x2="-2.286" y2="0.254" layer="21"/>
</package>
<package name="CB429-15" urn="urn:adsk.eagle:footprint:43102/1" library_version="8">
diameter 5 mm, horizontal, grid 15.24 mm</description>
<wire x1="-1.27" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.27" y2="0.5842" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.5842" x2="1.27" y2="-0.5842" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-0.5842" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="2.54" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.5842" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.54" x2="-5.08" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.54" x2="5.08" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.54" x2="5.08" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-2.54" x2="-5.08" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="0" y1="-0.5842" x2="0.381" y2="-0.5842" width="0.1524" layer="21"/>
<wire x1="7.62" y1="0" x2="6.096" y2="0" width="1.016" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.096" y2="0" width="1.016" layer="51"/>
<wire x1="0" y1="0.5842" x2="0" y2="0" width="0.1524" layer="21"/>
<pad name="C" x="-7.62" y="0" drill="1.397" shape="long"/>
<pad name="A" x="7.62" y="0" drill="1.397" shape="long"/>
<text x="-2.54" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-5.08" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-4.318" y1="-2.54" x2="-3.302" y2="2.54" layer="21"/>
<rectangle x1="-5.969" y1="-0.508" x2="-5.08" y2="0.508" layer="21"/>
<rectangle x1="5.08" y1="-0.508" x2="5.969" y2="0.508" layer="21"/>
</package>
<package name="DO27-15" urn="urn:adsk.eagle:footprint:43095/1" library_version="8">
<wire x1="0" y1="0" x2="1.143" y2="0.5842" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.5842" x2="1.143" y2="-0.5842" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-0.5842" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="2.286" y2="0" width="0.1524" layer="21"/>
<wire x1="7.62" y1="0" x2="6.223" y2="0" width="1.27" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.223" y2="0" width="1.27" layer="51"/>
<pad name="C" x="-7.62" y="0" drill="1.4986" shape="long"/>
<pad name="A" x="7.62" y="0" drill="1.4986" shape="long"/>
<rectangle x1="-4.191" y1="-2.54" x2="-3.429" y2="2.54" layer="21"/>
<rectangle x1="-5.969" y1="-0.635" x2="-5.08" y2="0.635" layer="21"/>
<rectangle x1="5.08" y1="-0.635" x2="5.969" y2="0.635" layer="21"/>
</package>
<package name="F126Z12" urn="urn:adsk.eagle:footprint:43121/1" library_version="8">
diameter 3 mm, horizontal, grid 12.7 mm</description>
<wire x1="-3.175" y1="-1.524" x2="3.175" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.175" y1="1.524" x2="-3.175" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.524" x2="3.175" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.524" x2="-3.175" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0" x2="4.826" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.35" y1="0" x2="-4.826" y2="0" width="0.8128" layer="51"/>
<wire x1="0.254" y1="0.635" x2="0" y2="0.635" width="0.1524" layer="21"/>
<pad name="C" x="-6.35" y="0" drill="1.016" shape="long"/>
<pad name="A" x="6.35" y="0" drill="1.016" shape="long"/>
<text x="-3.175" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.54" y1="-1.524" x2="-1.778" y2="1.524" layer="21"/>
<rectangle x1="-4.8514" y1="-0.4064" x2="-3.175" y2="0.4064" layer="21"/>
<rectangle x1="3.175" y1="-0.4064" x2="4.8514" y2="0.4064" layer="21"/>
</package>
<package name="DO41-10" urn="urn:adsk.eagle:footprint:43094/1" library_version="8">
diameter 2.54 mm, horizontal, grid 10.16 mm</description>
<wire x1="2.032" y1="-1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.762" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.762" layer="51"/>
<pad name="A" x="5.08" y="0" drill="1.1176"/>
<pad name="C" x="-5.08" y="0" drill="1.1176"/>
<text x="-2.032" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-1.27" x2="-1.143" y2="1.27" layer="21"/>
<rectangle x1="2.032" y1="-0.381" x2="3.937" y2="0.381" layer="21"/>
<rectangle x1="-3.937" y1="-0.381" x2="-2.032" y2="0.381" layer="21"/>
</package>
<package name="SOD81" urn="urn:adsk.eagle:footprint:43125/1" library_version="8">
diameter 2.3 mm, vertical, grid 10.16 mm</description>
<wire x1="-1.905" y1="1.143" x2="1.905" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.635" x2="-2.54" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.635" x2="-2.159" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.381" x2="-2.54" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.381" x2="-2.159" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-0.635" x2="-2.159" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="2.159" y1="0.635" x2="2.54" y2="0.381" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.381" x2="2.54" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.635" x2="2.54" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.381" x2="2.413" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.508" x2="2.413" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.508" x2="2.159" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.381" x2="2.413" y2="0.381" width="0.1524" layer="21"/>
<wire x1="2.159" y1="0.508" x2="2.413" y2="0.381" width="0.1524" layer="21"/>
<wire x1="2.159" y1="0.508" x2="2.159" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.381" x2="-2.413" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.508" x2="-2.413" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.508" x2="-2.159" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.381" x2="-2.413" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-0.508" x2="-2.413" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-0.508" x2="-2.159" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="2.413" y1="0.381" x2="2.159" y2="0.381" width="0.1524" layer="21"/>
<wire x1="2.159" y1="0.381" x2="2.159" y2="0.508" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-0.381" x2="2.159" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.381" x2="2.159" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-0.381" x2="-2.159" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-0.381" x2="-2.159" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="0.381" x2="-2.159" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.381" x2="-2.159" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.143" x2="2.159" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.159" y1="0.889" x2="-1.905" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="1.905" y1="1.143" x2="2.159" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.159" y1="-0.889" x2="-1.905" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="-1.905" y1="-1.143" x2="1.905" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="2.159" y1="0.635" x2="2.159" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.635" x2="-2.159" y2="0.889" width="0.1524" layer="21"/>
<pad name="C" x="-5.08" y="0" drill="1.1176" shape="long"/>
<pad name="A" x="5.08" y="0" drill="1.1176" shape="long"/>
<text x="-2.032" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-1.651" y1="-1.143" x2="-1.143" y2="1.143" layer="21"/>
<rectangle x1="-3.937" y1="-0.381" x2="-2.159" y2="0.381" layer="21"/>
<rectangle x1="2.159" y1="-0.381" x2="3.937" y2="0.381" layer="21"/>
</package>
<package name="SOD80C" urn="urn:adsk.eagle:footprint:43180/1" library_version="8">
<description>&lt;B&gt;DIODE&lt;/B&gt;</description>
<wire x1="1.3208" y1="0.7874" x2="-1.3208" y2="0.7874" width="0.1524" layer="51"/>
<wire x1="1.3208" y1="-0.7874" x2="-1.3208" y2="-0.7874" width="0.1524" layer="51"/>
<wire x1="0.627" y1="0.6" x2="-0.373" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.373" y1="0" x2="0.627" y2="-0.6" width="0.2032" layer="21"/>
<wire x1="0.627" y1="-0.6" x2="0.627" y2="0.6" width="0.2032" layer="21"/>
<smd name="C" x="-1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<smd name="A" x="1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<text x="-1.524" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.524" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.8542" y1="-0.8636" x2="-1.2954" y2="0.8636" layer="51"/>
<rectangle x1="1.2954" y1="-0.8636" x2="1.8542" y2="0.8636" layer="51"/>
<rectangle x1="-0.8636" y1="-0.7874" x2="-0.254" y2="0.7874" layer="21"/>
</package>
<package name="SMB" urn="urn:adsk.eagle:footprint:43181/1" library_version="8">
<wire x1="-2.2606" y1="1.905" x2="2.2606" y2="1.905" width="0.1016" layer="21"/>
<wire x1="-2.2606" y1="-1.905" x2="2.2606" y2="-1.905" width="0.1016" layer="21"/>
<wire x1="-2.2606" y1="-1.905" x2="-2.2606" y2="1.905" width="0.1016" layer="51"/>
<wire x1="2.2606" y1="-1.905" x2="2.2606" y2="1.905" width="0.1016" layer="51"/>
<wire x1="0.193" y1="1" x2="-0.83" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.83" y1="0" x2="0.193" y2="-1" width="0.2032" layer="21"/>
<wire x1="0.193" y1="-1" x2="0.193" y2="1" width="0.2032" layer="21"/>
<smd name="C" x="-2.2" y="0" dx="2.4" dy="2.4" layer="1"/>
<smd name="A" x="2.2" y="0" dx="2.4" dy="2.4" layer="1"/>
<text x="-2.159" y="2.159" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.159" y="-3.429" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.794" y1="-1.0922" x2="-2.2606" y2="1.0922" layer="51"/>
<rectangle x1="2.2606" y1="-1.0922" x2="2.794" y2="1.0922" layer="51"/>
<rectangle x1="-1.35" y1="-1.9" x2="-0.8" y2="1.9" layer="51"/>
</package>
</packages>
<packages3d>
<package3d name="DO35-10" urn="urn:adsk.eagle:package:43344/2" type="model" library_version="8">
<description>DIODE
<packageinstances>
<packageinstance name="DO35-10"/>
</packageinstances>
</package3d>
<package3d name="CB429-15" urn="urn:adsk.eagle:package:43338/2" type="model" library_version="8">
<description>DIODE
<packageinstances>
<packageinstance name="CB429-15"/>
</packageinstances>
</package3d>
<package3d name="DO27-15" urn="urn:adsk.eagle:package:43337/3" type="model" library_version="8">
<description>DIODE
<packageinstances>
<packageinstance name="DO27-15"/>
</packageinstances>
</package3d>
<package3d name="F126Z12" urn="urn:adsk.eagle:package:43358/1" type="box" library_version="8">
<description>DIODE
<packageinstances>
<packageinstance name="F126Z12"/>
</packageinstances>
</package3d>
<package3d name="DO41-10" urn="urn:adsk.eagle:package:43336/1" type="box" library_version="8">
<description>DIODE
<packageinstances>
<packageinstance name="DO41-10"/>
</packageinstances>
</package3d>
<package3d name="SOD81" urn="urn:adsk.eagle:package:43363/2" type="model" library_version="8">
<description>DIODE
<packageinstances>
<packageinstance name="SOD81"/>
</packageinstances>
</package3d>
<package3d name="SOD80C" urn="urn:adsk.eagle:package:43405/2" type="model" library_version="8">
<description>DIODE</description>
<packageinstances>
<packageinstance name="SOD80C"/>
</packageinstances>
</package3d>
<package3d name="SMB" urn="urn:adsk.eagle:package:43404/2" type="model" library_version="8">
<packageinstances>
<packageinstance name="SMB"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="linear" urn="urn:adsk.eagle:library:262">
<description>&lt;b&gt;Linear Devices&lt;/b&gt;&lt;p&gt;
Operational amplifiers,  comparators, voltage regulators, ADCs, DACs, etc.&lt;p&gt;
<packages>
<package name="DIL14" urn="urn:adsk.eagle:footprint:16136/1" library_version="5">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="8.89" y1="2.921" x2="-8.89" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-2.921" x2="8.89" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="8.89" y1="2.921" x2="8.89" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.921" x2="-8.89" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-2.921" x2="-8.89" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="1.016" x2="-8.89" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="0" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="0" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="-2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="-5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="-7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-9.271" y="-3.048" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-6.731" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL08" urn="urn:adsk.eagle:footprint:16129/1" library_version="5">
<wire x1="5.08" y1="2.921" x2="-5.08" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.921" x2="-5.08" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="-5.08" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.016" x2="-5.08" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-3.81" y="-3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="2" x="-1.27" y="-3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="7" x="-1.27" y="3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="8" x="-3.81" y="3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="3" x="1.27" y="-3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="4" x="3.81" y="-3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="6" x="1.27" y="3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="5" x="3.81" y="3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<text x="-5.334" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-3.556" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="DIL14" urn="urn:adsk.eagle:package:16407/2" type="model" library_version="5">
<description>Dual In Line Package</description>
<packageinstances>
<packageinstance name="DIL14"/>
</packageinstances>
</package3d>
<package3d name="DIL08" urn="urn:adsk.eagle:package:16409/2" type="model" library_version="5">
<packageinstances>
<packageinstance name="DIL08"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="led" urn="urn:adsk.eagle:library:259">
<description>&lt;b&gt;LEDs&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;br&gt;
Extended by Federico Battaglin &lt;author&gt;&amp;lt;federico.rd@fdpinternational.com&amp;gt;&lt;/author&gt; with DUOLED</description>
<packages>
<package name="LED5MM" urn="urn:adsk.eagle:footprint:15655/1" library_version="5">
<description>&lt;B&gt;LED&lt;/B&gt;&lt;p&gt;
5 mm, round</description>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="1.905" width="0.2032" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="1.905" width="0.254" layer="21" curve="-286.260205"/>
<wire x1="-1.143" y1="0" x2="0" y2="1.143" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-1.143" x2="1.143" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="-1.651" y1="0" x2="0" y2="1.651" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-1.651" x2="1.651" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="-2.159" y1="0" x2="0" y2="2.159" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-2.159" x2="2.159" y2="0" width="0.1524" layer="51" curve="90"/>
<circle x="0" y="0" radius="2.54" width="0.1524" layer="21"/>
<pad name="A" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="K" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="3.175" y="0.5334" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.2004" y="-1.8034" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="LED3MM" urn="urn:adsk.eagle:footprint:15654/1" library_version="5">
3 mm, round</description>
<wire x1="1.5748" y1="-1.27" x2="1.5748" y2="1.27" width="0.254" layer="51"/>
<wire x1="-1.524" y1="0" x2="-1.1708" y2="0.9756" width="0.1524" layer="51" curve="-39.80361"/>
<wire x1="-1.524" y1="0" x2="-1.1391" y2="-1.0125" width="0.1524" layer="51" curve="41.633208"/>
<wire x1="1.1571" y1="0.9918" x2="1.524" y2="0" width="0.1524" layer="51" curve="-40.601165"/>
<wire x1="1.1708" y1="-0.9756" x2="1.524" y2="0" width="0.1524" layer="51" curve="39.80361"/>
<wire x1="0" y1="1.524" x2="1.2401" y2="0.8858" width="0.1524" layer="21" curve="-54.461337"/>
<wire x1="-1.2192" y1="0.9144" x2="0" y2="1.524" width="0.1524" layer="21" curve="-53.130102"/>
<wire x1="0" y1="-1.524" x2="1.203" y2="-0.9356" width="0.1524" layer="21" curve="52.126876"/>
<wire x1="-1.203" y1="-0.9356" x2="0" y2="-1.524" width="0.1524" layer="21" curve="52.126876"/>
<wire x1="-0.635" y1="0" x2="0" y2="0.635" width="0.1524" layer="51" curve="-90"/>
<wire x1="-1.016" y1="0" x2="0" y2="1.016" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-0.635" x2="0.635" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="0" y1="-1.016" x2="1.016" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="0" y1="2.032" x2="1.561" y2="1.3009" width="0.254" layer="21" curve="-50.193108"/>
<wire x1="-1.7929" y1="0.9562" x2="0" y2="2.032" width="0.254" layer="21" curve="-61.926949"/>
<wire x1="0" y1="-2.032" x2="1.5512" y2="-1.3126" width="0.254" layer="21" curve="49.763022"/>
<wire x1="-1.7643" y1="-1.0082" x2="0" y2="-2.032" width="0.254" layer="21" curve="60.255215"/>
<wire x1="-2.032" y1="0" x2="-1.7891" y2="0.9634" width="0.254" layer="51" curve="-28.301701"/>
<wire x1="-2.032" y1="0" x2="-1.7306" y2="-1.065" width="0.254" layer="51" curve="31.60822"/>
<text x="1.905" y="0.381" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="1.905" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="LED5MM" urn="urn:adsk.eagle:package:15799/2" type="model" library_version="5">
<description>LED
<packageinstances>
<packageinstance name="LED5MM"/>
</packageinstances>
</package3d>
<package3d name="LED3MM" urn="urn:adsk.eagle:package:15797/1" type="box" library_version="5">
<description>LED
<packageinstances>
<packageinstance name="LED3MM"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="transistor" urn="urn:adsk.eagle:library:402">
<description>&lt;b&gt;Transistors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="TO92L" urn="urn:adsk.eagle:footprint:29854/1" library_version="6">
<description>&lt;b&gt;TO-92&lt;/b&gt;&lt;p&gt;
grid 5.08 mm</description>
<wire x1="-1.1359" y1="2.413" x2="-0.127" y2="2.664" width="0.1524" layer="51" curve="-22.4788"/>
<wire x1="-0.127" y1="2.664" x2="1.1359" y2="2.413" width="0.1524" layer="51" curve="-27.9376"/>
<wire x1="-1.1359" y1="-2.413" x2="-0.127" y2="-2.664" width="0.1524" layer="51" curve="22.4788"/>
<wire x1="-0.127" y1="-2.664" x2="1.1359" y2="-2.413" width="0.1524" layer="51" curve="27.9376"/>
<wire x1="-1.651" y1="2.095" x2="-1.651" y2="-2.095" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="-1.404" x2="-0.127" y2="1.404" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="-2.664" x2="-0.127" y2="-1.404" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-2.095" x2="-1.1118" y2="-2.4247" width="0.1524" layer="21" curve="13.6094"/>
<wire x1="-0.127" y1="1.404" x2="-0.127" y2="2.664" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="2.095" x2="-1.1359" y2="2.4135" width="0.1524" layer="21" curve="-13.0385"/>
<wire x1="2.413" y1="-1.1359" x2="2.413" y2="1.1359" width="0.1524" layer="51" curve="50.4167"/>
<wire x1="1.1359" y1="-2.413" x2="2.413" y2="-1.1359" width="0.1524" layer="21" curve="39.5833"/>
<wire x1="1.1359" y1="2.413" x2="2.413" y2="1.1359" width="0.1524" layer="21" curve="-39.5833"/>
<pad name="1" x="0" y="-2.54" drill="0.8128" shape="long"/>
<pad name="3" x="0" y="2.54" drill="0.8128" shape="long"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="long"/>
<text x="-1.524" y="3.556" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-4.953" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TO92-CBE" urn="urn:adsk.eagle:footprint:29859/1" library_version="6">
<description>&lt;b&gt;TO-92&lt;/b&gt; Pads In Line  C B E from top&lt;p&gt;</description>
<wire x1="-2.095" y1="-1.651" x2="2.095" y2="-1.651" width="0.127" layer="21"/>
<wire x1="-2.413" y1="1.1359" x2="2.413" y2="1.1359" width="0.127" layer="21" curve="-129.583"/>
<wire x1="1.136" y1="-0.127" x2="-1.136" y2="-0.127" width="0.127" layer="51"/>
<wire x1="-2.413" y1="1.1359" x2="-2.664" y2="-0.127" width="0.127" layer="51" curve="27.9376"/>
<wire x1="-2.664" y1="-0.127" x2="-2.413" y2="-1.1359" width="0.127" layer="51" curve="22.4788"/>
<wire x1="-1.404" y1="-0.127" x2="-2.664" y2="-0.127" width="0.127" layer="51"/>
<wire x1="-2.4135" y1="-1.1359" x2="-2.095" y2="-1.651" width="0.127" layer="21" curve="13.0385"/>
<wire x1="-1.136" y1="-0.127" x2="-1.404" y2="-0.127" width="0.127" layer="21"/>
<wire x1="2.413" y1="-1.1359" x2="2.664" y2="-0.127" width="0.127" layer="51" curve="22.4788"/>
<wire x1="2.664" y1="-0.127" x2="2.413" y2="1.1359" width="0.127" layer="51" curve="27.9376"/>
<wire x1="2.664" y1="-0.127" x2="1.404" y2="-0.127" width="0.127" layer="51"/>
<wire x1="1.404" y1="-0.127" x2="1.136" y2="-0.127" width="0.127" layer="21"/>
<wire x1="2.095" y1="-1.651" x2="2.4247" y2="-1.1118" width="0.127" layer="21" curve="13.6094"/>
<pad name="C" x="-2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="E" x="2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="B" x="0" y="0" drill="0.8128" shape="long" rot="R90"/>
<text x="-2.54" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="TO92L" urn="urn:adsk.eagle:package:29918/1" type="box" library_version="6">
<description>TO-92
<packageinstances>
<packageinstance name="TO92L"/>
</packageinstances>
</package3d>
<package3d name="TO92-CBE" urn="urn:adsk.eagle:package:29921/2" type="model" library_version="6">
<description>TO-92 Pads In Line  C B E from top</description>
<packageinstances>
<packageinstance name="TO92-CBE"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="con-ptr500" urn="urn:adsk.eagle:library:181">
<description>&lt;b&gt;PTR Connectors&lt;/b&gt;&lt;p&gt;
Aug. 2004 / PTR Meßtechnik:&lt;br&gt;
Die Bezeichnung der Serie AK505 wurde geändert.&lt;br&gt;
Es handelt sich hierbei um AK500 in horizontaler Ausführung.&lt;p&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=LEFT&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Alte Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Neue Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2DS,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2DS-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AKZ505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AKZ500/2-5.08-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TABLE&gt;
<packages>
<package name="AK500/2" urn="urn:adsk.eagle:footprint:9854/1" library_version="2">
<description>&lt;b&gt;CONNECTOR&lt;/b&gt;</description>
<wire x1="-5.08" y1="-3.556" x2="-5.08" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="5.08" y1="3.937" x2="-5.08" y2="3.937" width="0.1524" layer="21"/>
<wire x1="5.08" y1="3.937" x2="5.08" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.556" x2="5.08" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.048" x2="-5.588" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.048" x2="-5.08" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="3.175" x2="-5.588" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="2.032" x2="-5.08" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.159" x2="-5.08" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.159" x2="5.08" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.159" x2="5.08" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.159" x2="5.08" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.159" x2="-5.08" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-2.159" x2="5.08" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="1.4986" y1="-1.397" x2="3.9116" y2="1.016" width="0.1524" layer="51"/>
<wire x1="1.1176" y1="-1.016" x2="3.5306" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-3.9116" y1="-1.016" x2="-1.4986" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-3.5306" y1="-1.397" x2="-1.1176" y2="1.016" width="0.1524" layer="51"/>
<wire x1="1.4986" y1="-1.016" x2="3.5306" y2="1.016" width="0.6096" layer="51"/>
<wire x1="-3.5306" y1="-1.016" x2="-1.4986" y2="1.016" width="0.6096" layer="51"/>
<wire x1="1.1176" y1="-1.016" x2="1.4986" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="3.5306" y1="1.397" x2="3.9116" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-3.9116" y1="-1.016" x2="-3.5306" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-1.4986" y1="1.397" x2="-1.1176" y2="1.016" width="0.1524" layer="51"/>
<circle x="2.5146" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="-2.5146" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="2.5146" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="-2.5146" y="0" radius="1.778" width="0.1524" layer="51"/>
<pad name="1" x="-2.5146" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="2" x="2.5146" y="0" drill="1.3208" shape="long" rot="R90"/>
<text x="-5.08" y="4.445" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-5.715" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.445" y="2.54" size="0.9906" layer="21" ratio="12">1</text>
<text x="0.635" y="2.54" size="0.9906" layer="21" ratio="12">2</text>
<rectangle x1="-0.381" y1="-1.905" x2="0.381" y2="1.905" layer="21"/>
</package>
<package name="AK500/3" urn="urn:adsk.eagle:footprint:9855/1" library_version="2">
<wire x1="-7.5184" y1="-3.556" x2="-7.5184" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="7.5184" y1="3.937" x2="-7.5184" y2="3.937" width="0.1524" layer="21"/>
<wire x1="7.5184" y1="3.937" x2="7.5184" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="-3.556" x2="7.5184" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="3.048" x2="-8.0264" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="3.048" x2="-7.5184" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.0264" y1="3.175" x2="-8.0264" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-8.0264" y1="2.032" x2="-7.5184" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="2.159" x2="-7.5184" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="2.159" x2="7.5184" y2="2.159" width="0.1524" layer="21"/>
<wire x1="7.5184" y1="2.159" x2="7.5184" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="-2.159" x2="7.5184" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="-2.159" x2="-7.5184" y2="2.159" width="0.1524" layer="21"/>
<wire x1="7.5184" y1="-2.159" x2="7.5184" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-1.397" x2="1.397" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-1.397" y1="-1.016" x2="1.016" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-6.4008" y1="-1.016" x2="-3.9878" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-6.0198" y1="-1.397" x2="-3.6068" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-1.016" y1="-1.016" x2="1.016" y2="1.016" width="0.6096" layer="51"/>
<wire x1="-6.0198" y1="-1.016" x2="-3.9878" y2="1.016" width="0.6096" layer="51"/>
<wire x1="-1.397" y1="-1.016" x2="-1.016" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="1.016" y1="1.397" x2="1.397" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-6.4008" y1="-1.016" x2="-6.0198" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-3.9878" y1="1.397" x2="-3.6068" y2="1.016" width="0.1524" layer="51"/>
<wire x1="3.9878" y1="-1.016" x2="6.0198" y2="1.016" width="0.6096" layer="51"/>
<wire x1="3.9878" y1="-1.397" x2="6.4008" y2="1.016" width="0.1524" layer="51"/>
<wire x1="3.6068" y1="-1.016" x2="6.0198" y2="1.397" width="0.1524" layer="51"/>
<wire x1="3.6068" y1="-1.016" x2="3.9878" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="6.0198" y1="1.397" x2="6.4008" y2="1.016" width="0.1524" layer="51"/>
<circle x="0" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="-5.0038" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="-5.0038" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="5.0038" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="5.0038" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<pad name="1" x="-5.0038" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="2" x="0" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="3" x="5.0038" y="0" drill="1.3208" shape="long" rot="R90"/>
<text x="-7.5946" y="4.445" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-7.5946" y="-5.715" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.731" y="2.54" size="0.9906" layer="21" ratio="12">1</text>
<text x="-1.905" y="2.54" size="0.9906" layer="21" ratio="12">2</text>
<text x="3.175" y="2.54" size="0.9906" layer="21" ratio="12">3</text>
<rectangle x1="-2.8956" y1="-1.905" x2="-2.1336" y2="1.905" layer="21"/>
<rectangle x1="2.1336" y1="-1.905" x2="2.8956" y2="1.905" layer="21"/>
</package>
<package name="AK500/5" urn="urn:adsk.eagle:footprint:9857/1" library_version="2">
<wire x1="-12.5222" y1="-3.556" x2="-12.5222" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-12.5222" y1="-3.556" x2="-2.4892" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-12.5222" y1="3.048" x2="-13.0302" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-12.5222" y1="3.048" x2="-12.5222" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-13.0302" y1="3.175" x2="-13.0302" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-13.0302" y1="2.032" x2="-12.5222" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-12.5222" y1="2.159" x2="-12.5222" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-12.5222" y1="2.159" x2="-2.4892" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-12.5222" y1="-2.159" x2="-2.4892" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-12.5222" y1="-2.159" x2="-12.5222" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-1.016" x2="-9.017" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-11.049" y1="-1.397" x2="-8.636" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-11.049" y1="-1.016" x2="-9.017" y2="1.016" width="0.6096" layer="51"/>
<wire x1="-11.43" y1="-1.016" x2="-11.049" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-9.017" y1="1.397" x2="-8.636" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-2.4892" y1="-3.556" x2="-2.4892" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="12.5222" y1="3.937" x2="-2.4892" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-2.4892" y1="2.159" x2="-2.4892" y2="3.937" width="0.1524" layer="21"/>
<wire x1="12.5222" y1="3.937" x2="12.5222" y2="2.159" width="0.1524" layer="21"/>
<wire x1="12.5222" y1="2.159" x2="12.5222" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-2.4892" y1="-2.159" x2="12.5222" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-2.4892" y1="-2.159" x2="-2.4892" y2="2.159" width="0.1524" layer="21"/>
<wire x1="12.5222" y1="-2.159" x2="12.5222" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="8.9916" y1="-1.016" x2="11.0236" y2="1.016" width="0.6096" layer="51"/>
<wire x1="8.9916" y1="-1.397" x2="11.4046" y2="1.016" width="0.1524" layer="51"/>
<wire x1="8.6106" y1="-1.016" x2="11.0236" y2="1.397" width="0.1524" layer="51"/>
<wire x1="8.6106" y1="-1.016" x2="8.9916" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="11.0236" y1="1.397" x2="11.4046" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-2.4892" y1="-3.556" x2="12.5222" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-2.4892" y1="2.159" x2="12.5222" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-2.4892" y1="3.937" x2="-12.5222" y2="3.937" width="0.1524" layer="21"/>
<circle x="-10.033" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="-10.033" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="10.0076" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="10.0076" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<pad name="1" x="-10.033" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="2" x="-5.0038" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="3" x="0" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="4" x="5.0038" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="5" x="10.0076" y="0" drill="1.3208" shape="long" rot="R90"/>
<text x="-12.5984" y="4.445" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-12.5984" y="-5.715" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-11.8872" y="2.54" size="0.9906" layer="21" ratio="12">1</text>
<text x="-7.0612" y="2.54" size="0.9906" layer="21" ratio="12">2</text>
<text x="-1.7272" y="2.54" size="0.9906" layer="21" ratio="12">3</text>
<text x="3.0988" y="2.54" size="0.9906" layer="21" ratio="12">4</text>
<text x="8.1788" y="2.54" size="0.9906" layer="21" ratio="12">5</text>
<rectangle x1="-7.8994" y1="-1.905" x2="-7.1374" y2="1.905" layer="21"/>
<rectangle x1="2.1082" y1="-1.905" x2="2.8702" y2="1.905" layer="21"/>
<rectangle x1="7.1374" y1="-1.905" x2="7.8994" y2="1.905" layer="21"/>
</package>
</packages>
<packages3d>
<package3d name="AK500/2" urn="urn:adsk.eagle:package:9880/1" type="box" library_version="2">
<description>CONNECTOR</description>
<packageinstances>
<packageinstance name="AK500/2"/>
</packageinstances>
</package3d>
<package3d name="AK500/3" urn="urn:adsk.eagle:package:9883/1" type="box" library_version="2">
<packageinstances>
<packageinstance name="AK500/3"/>
</packageinstances>
</package3d>
<package3d name="AK500/5" urn="urn:adsk.eagle:package:9890/1" type="box" library_version="2">
<packageinstances>
<packageinstance name="AK500/5"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="con-molex" urn="urn:adsk.eagle:library:165">
<description>&lt;b&gt;Molex Connectors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="22-23-2031" urn="urn:adsk.eagle:footprint:8078260/1" library_version="4">
<description>&lt;b&gt;KK® 254 Solid Header, Vertical, with Friction Lock, 3 Circuits, Tin (Sn) Plating&lt;/b&gt;&lt;p&gt;&lt;a href =http://www.molex.com/pdm_docs/sd/022232031_sd.pdf&gt;Datasheet &lt;/a&gt;</description>
<wire x1="-3.81" y1="3.175" x2="3.81" y2="3.175" width="0.254" layer="21"/>
<wire x1="3.81" y1="3.175" x2="3.81" y2="1.27" width="0.254" layer="21"/>
<wire x1="3.81" y1="1.27" x2="3.81" y2="-3.175" width="0.254" layer="21"/>
<wire x1="3.81" y1="-3.175" x2="-3.81" y2="-3.175" width="0.254" layer="21"/>
<wire x1="-3.81" y1="-3.175" x2="-3.81" y2="1.27" width="0.254" layer="21"/>
<wire x1="-3.81" y1="1.27" x2="-3.81" y2="3.175" width="0.254" layer="21"/>
<wire x1="-3.81" y1="1.27" x2="3.81" y2="1.27" width="0.254" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="1" shape="long" rot="R90"/>
<pad name="2" x="0" y="0" drill="1" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="0" drill="1" shape="long" rot="R90"/>
<text x="-3.81" y="3.81" size="1.016" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-5.08" size="1.016" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="22-23-2021" urn="urn:adsk.eagle:footprint:8078259/1" library_version="4">
<description>&lt;b&gt;KK® 254 Solid Header, Vertical, with Friction Lock, 2 Circuits, Tin (Sn) Plating&lt;/b&gt;&lt;p&gt;&lt;a href =http://www.molex.com/pdm_docs/sd/022232021_sd.pdf&gt;Datasheet &lt;/a&gt;</description>
<wire x1="-2.54" y1="3.175" x2="2.54" y2="3.175" width="0.254" layer="21"/>
<wire x1="2.54" y1="3.175" x2="2.54" y2="1.27" width="0.254" layer="21"/>
<wire x1="2.54" y1="1.27" x2="2.54" y2="-3.175" width="0.254" layer="21"/>
<wire x1="2.54" y1="-3.175" x2="-2.54" y2="-3.175" width="0.254" layer="21"/>
<wire x1="-2.54" y1="-3.175" x2="-2.54" y2="1.27" width="0.254" layer="21"/>
<wire x1="-2.54" y1="1.27" x2="-2.54" y2="3.175" width="0.254" layer="21"/>
<wire x1="-2.54" y1="1.27" x2="2.54" y2="1.27" width="0.254" layer="21"/>
<pad name="1" x="-1.27" y="0" drill="1" shape="long" rot="R90"/>
<pad name="2" x="1.27" y="0" drill="1" shape="long" rot="R90"/>
<text x="-2.54" y="3.81" size="1.016" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-5.08" size="1.016" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="6410-03" urn="urn:adsk.eagle:footprint:8078273/1" library_version="4">
<description>&lt;b&gt;KK® 254 Wire-to-Board Header, Vertical, with Friction Lock, 3 Circuits, Tin (Sn) Plating&lt;/b&gt;&lt;p&gt;&lt;a href =http://www.molex.com/pdm_docs/sd/022272031_sd.pdf&gt;Datasheet &lt;/a&gt;</description>
<wire x1="-2.54" y1="2.54" x2="-2.54" y2="2.921" width="0.127" layer="21"/>
<wire x1="-3.81" y1="0" x2="-3.81" y2="2.921" width="0.254" layer="21"/>
<wire x1="-3.81" y1="2.921" x2="-2.54" y2="2.921" width="0.254" layer="21"/>
<wire x1="-2.286" y1="2.921" x2="-2.54" y2="2.921" width="0.127" layer="21"/>
<wire x1="-2.54" y1="2.921" x2="-1.27" y2="2.921" width="0.254" layer="21"/>
<wire x1="3.81" y1="0" x2="3.81" y2="2.921" width="0.254" layer="21"/>
<wire x1="3.81" y1="2.921" x2="-1.27" y2="2.921" width="0.254" layer="21"/>
<wire x1="-3.81" y1="0" x2="-3.81" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-3.81" y1="-2.921" x2="-1.27" y2="-2.921" width="0.127" layer="21"/>
<wire x1="3.81" y1="0" x2="3.81" y2="-2.921" width="0.254" layer="21"/>
<wire x1="3.175" y1="-2.921" x2="1.905" y2="-2.921" width="0.254" layer="21"/>
<wire x1="0.635" y1="-2.921" x2="-0.635" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-2.921" x2="-1.27" y2="-2.921" width="0.127" layer="21"/>
<wire x1="-3.556" y1="-2.921" x2="-3.175" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-3.175" y1="-2.921" x2="-3.175" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-3.175" y1="-2.286" x2="-1.905" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-2.286" x2="-1.905" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-2.921" x2="-3.175" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-2.921" x2="-0.635" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-2.921" x2="-0.635" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-2.286" x2="0.635" y2="-2.286" width="0.254" layer="21"/>
<wire x1="0.635" y1="-2.286" x2="0.635" y2="-2.921" width="0.254" layer="21"/>
<wire x1="0.635" y1="-2.921" x2="1.905" y2="-2.921" width="0.254" layer="21"/>
<wire x1="1.905" y1="-2.921" x2="1.905" y2="-2.286" width="0.254" layer="21"/>
<wire x1="1.905" y1="-2.286" x2="3.175" y2="-2.286" width="0.254" layer="21"/>
<wire x1="3.175" y1="-2.286" x2="3.175" y2="-2.921" width="0.254" layer="21"/>
<wire x1="3.175" y1="-2.921" x2="3.81" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-2.54" y2="2.921" width="0.254" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-2.286" y2="1.905" width="0.254" layer="21"/>
<wire x1="-2.286" y1="1.905" x2="2.286" y2="1.905" width="0.254" layer="21"/>
<wire x1="2.286" y1="1.905" x2="2.54" y2="1.905" width="0.254" layer="21"/>
<wire x1="2.54" y1="1.905" x2="2.54" y2="2.921" width="0.254" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-2.286" y2="1.397" width="0.254" layer="21"/>
<wire x1="-2.286" y1="2.921" x2="-2.286" y2="1.905" width="0.254" layer="21"/>
<wire x1="-2.286" y1="1.397" x2="2.286" y2="1.397" width="0.254" layer="21"/>
<wire x1="2.286" y1="1.397" x2="2.54" y2="1.905" width="0.254" layer="21"/>
<wire x1="2.286" y1="2.921" x2="2.286" y2="1.905" width="0.254" layer="21"/>
<pad name="3" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-3.7831" y="3.2751" size="1.016" layer="25" ratio="10">&gt;NAME</text>
<text x="4.4181" y="-0.7381" size="1.27" layer="21" ratio="14">1</text>
<text x="-4.9799" y="-0.6873" size="1.27" layer="21" ratio="14">3</text>
<text x="-3.7831" y="-4.5989" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.794" y1="-0.254" x2="-2.286" y2="0.254" layer="51"/>
<rectangle x1="-0.254" y1="-0.254" x2="0.254" y2="0.254" layer="51"/>
<rectangle x1="2.286" y1="-0.254" x2="2.794" y2="0.254" layer="51"/>
</package>
</packages>
<packages3d>
<package3d name="22-23-2031" urn="urn:adsk.eagle:package:8078634/1" type="box" library_version="4">
<packageinstances>
<packageinstance name="22-23-2031"/>
</packageinstances>
</package3d>
<package3d name="22-23-2021" urn="urn:adsk.eagle:package:8078633/1" type="box" library_version="4">
<packageinstances>
<packageinstance name="22-23-2021"/>
</packageinstances>
</package3d>
<package3d name="6410-03" urn="urn:adsk.eagle:package:8078647/1" type="box" library_version="4">
<packageinstances>
<packageinstance name="6410-03"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="transistor-pnp" urn="urn:adsk.eagle:library:399">
<description>&lt;b&gt;PNP Transistors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="TO220" urn="urn:adsk.eagle:footprint:29166/1" library_version="5">
<description>&lt;b&gt;TO-220&lt;/b&gt;&lt;p&gt;
grid 2.54 mm, horinzontal</description>
<wire x1="-5.207" y1="-1.27" x2="5.207" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.207" y1="14.605" x2="-5.207" y2="14.605" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-1.27" x2="5.207" y2="11.176" width="0.1524" layer="21"/>
<wire x1="5.207" y1="11.176" x2="4.318" y2="11.176" width="0.1524" layer="21"/>
<wire x1="4.318" y1="11.176" x2="4.318" y2="12.7" width="0.1524" layer="21"/>
<wire x1="4.318" y1="12.7" x2="5.207" y2="12.7" width="0.1524" layer="21"/>
<wire x1="5.207" y1="12.7" x2="5.207" y2="14.605" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-1.27" x2="-5.207" y2="11.176" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="11.176" x2="-4.318" y2="11.176" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="11.176" x2="-4.318" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="12.7" x2="-5.207" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="12.7" x2="-5.207" y2="14.605" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<circle x="0" y="11.176" radius="1.8034" width="0.1524" layer="21"/>
<circle x="0" y="11.176" radius="4.191" width="0" layer="42"/>
<circle x="0" y="11.176" radius="4.191" width="0" layer="43"/>
<pad name="1" x="-2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="2" x="0" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<text x="-3.81" y="5.207" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.937" y="2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.445" y="7.874" size="1.016" layer="21" ratio="10">A17,5mm</text>
<text x="-3.175" y="0" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.635" y="0" size="1.27" layer="51" ratio="10">2</text>
<text x="1.905" y="0" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="2.159" y1="-4.699" x2="2.921" y2="-4.064" layer="21"/>
<rectangle x1="-0.381" y1="-4.699" x2="0.381" y2="-4.064" layer="21"/>
<rectangle x1="-2.921" y1="-4.699" x2="-2.159" y2="-4.064" layer="21"/>
<rectangle x1="-3.175" y1="-4.064" x2="-1.905" y2="-1.27" layer="21"/>
<rectangle x1="-0.635" y1="-4.064" x2="0.635" y2="-1.27" layer="21"/>
<rectangle x1="1.905" y1="-4.064" x2="3.175" y2="-1.27" layer="21"/>
<rectangle x1="-2.921" y1="-6.604" x2="-2.159" y2="-4.699" layer="51"/>
<rectangle x1="-0.381" y1="-6.604" x2="0.381" y2="-4.699" layer="51"/>
<rectangle x1="2.159" y1="-6.604" x2="2.921" y2="-4.699" layer="51"/>
<hole x="0" y="11.176" drill="3.302"/>
</package>
<package name="TO92-EBC" urn="urn:adsk.eagle:footprint:29181/1" library_version="5">
<wire x1="-2.095" y1="-2.921" x2="2.095" y2="-2.921" width="0.127" layer="21"/>
<wire x1="-2.413" y1="-0.1341" x2="2.413" y2="-0.1341" width="0.127" layer="21" curve="-129.583"/>
<wire x1="1.136" y1="-1.397" x2="-1.136" y2="-1.397" width="0.127" layer="51"/>
<wire x1="-2.413" y1="-0.1341" x2="-2.413" y2="-2.4059" width="0.127" layer="51" curve="50.4167"/>
<wire x1="-1.404" y1="-1.397" x2="-2.664" y2="-1.397" width="0.127" layer="51"/>
<wire x1="-2.4135" y1="-2.4059" x2="-2.095" y2="-2.921" width="0.127" layer="21" curve="13.0385"/>
<wire x1="-1.136" y1="-1.397" x2="-1.404" y2="-1.397" width="0.127" layer="21"/>
<wire x1="2.413" y1="-2.4059" x2="2.413" y2="-0.1341" width="0.127" layer="51" curve="50.4167"/>
<wire x1="2.664" y1="-1.397" x2="1.404" y2="-1.397" width="0.127" layer="51"/>
<wire x1="1.404" y1="-1.397" x2="1.136" y2="-1.397" width="0.127" layer="21"/>
<wire x1="2.095" y1="-2.921" x2="2.4247" y2="-2.3818" width="0.127" layer="21" curve="13.6094"/>
<pad name="C" x="-2.54" y="-1.27" drill="0.8128" shape="long" rot="R90"/>
<pad name="E" x="2.54" y="-1.27" drill="0.8128" shape="long" rot="R90"/>
<pad name="B" x="0" y="-1.27" drill="0.8128" shape="long" rot="R90"/>
<text x="-2.54" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-4.572" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="TO220" urn="urn:adsk.eagle:package:29212/1" type="box" library_version="5">
<description>TO-220
<packageinstances>
<packageinstance name="TO220"/>
</packageinstances>
</package3d>
<package3d name="TO92-EBC" urn="urn:adsk.eagle:package:29218/2" type="model" library_version="5">
<description>TO-92
<packageinstances>
<packageinstance name="TO92-EBC"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="transistor-small-signal" urn="urn:adsk.eagle:library:401">
<description>&lt;b&gt;Small Signal Transistors&lt;/b&gt;&lt;p&gt;
Packages from :&lt;br&gt;
www.infineon.com; &lt;br&gt;
www.semiconductors.com;&lt;br&gt;
www.irf.com&lt;p&gt;
<packages>
<package name="SOT23" urn="urn:adsk.eagle:footprint:28669/1" library_version="5">
<description>&lt;b&gt;SOT-23&lt;/b&gt;</description>
<wire x1="1.4224" y1="0.6604" x2="1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="1.4224" y1="-0.6604" x2="-1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="-0.6604" x2="-1.4224" y2="0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="0.6604" x2="1.4224" y2="0.6604" width="0.1524" layer="51"/>
<smd name="3" x="0" y="1.1" dx="1" dy="1.4" layer="1"/>
<smd name="2" x="0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<smd name="1" x="-0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<rectangle x1="-0.2286" y1="0.7112" x2="0.2286" y2="1.2954" layer="51"/>
<rectangle x1="0.7112" y1="-1.2954" x2="1.1684" y2="-0.7112" layer="51"/>
<rectangle x1="-1.1684" y1="-1.2954" x2="-0.7112" y2="-0.7112" layer="51"/>
</package>
</packages>
<packages3d>
<package3d name="SOT23" urn="urn:adsk.eagle:package:28738/2" type="model" library_version="5">
<description>SOT-23</description>
<packageinstances>
<packageinstance name="SOT23"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="transistor-npn" urn="urn:adsk.eagle:library:398">
<description>&lt;b&gt;NPN Transistors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="TO92-EBC" urn="urn:adsk.eagle:footprint:28938/1" library_version="4">
<wire x1="-2.413" y1="-0.1341" x2="-2.664" y2="-1.397" width="0.127" layer="51" curve="27.9376"/>
<wire x1="-2.664" y1="-1.397" x2="-2.413" y2="-2.4059" width="0.127" layer="51" curve="22.4788"/>
<wire x1="2.413" y1="-2.4059" x2="2.664" y2="-1.397" width="0.127" layer="51" curve="22.4788"/>
<wire x1="2.664" y1="-1.397" x2="2.413" y2="-0.1341" width="0.127" layer="51" curve="27.9376"/>
</package>
</packages>
<packages3d>
<package3d name="TO92-EBC" urn="urn:adsk.eagle:package:28989/2" type="model" library_version="4">
<description>TO-92
<packageinstances>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="solpad" urn="urn:adsk.eagle:library:364">
<description>&lt;b&gt;Solder Pads/Test Points&lt;/b&gt;&lt;p&gt;
<packages>
<package name="LSP10" urn="urn:adsk.eagle:footprint:26494/1" library_version="2">
<description>&lt;b&gt;SOLDER PAD&lt;/b&gt;&lt;p&gt;
drill 1.0 mm</description>
<wire x1="-1.27" y1="0.254" x2="-1.27" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.254" x2="1.27" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.254" x2="1.143" y2="0.254" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-0.254" x2="1.143" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-0.254" x2="-1.143" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0.254" x2="-1.143" y2="0.254" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.254" x2="0.635" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-1.143" y1="-0.254" x2="-0.635" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0.254" x2="0.635" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0.254" x2="-0.635" y2="0.254" width="0.1524" layer="51"/>
<wire x1="0.635" y1="-0.254" x2="1.143" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="0.254" x2="-0.635" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="0.254" x2="-1.143" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-0.254" x2="0.635" y2="-0.254" width="0.1524" layer="51"/>
<pad name="MP" x="0" y="0" drill="1.016" diameter="2.159" shape="octagon"/>
<text x="-1.27" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0" y="0.254" size="0.0254" layer="27">&gt;VALUE</text>
</package>
<package name="SE11" urn="urn:adsk.eagle:footprint:26498/1" library_version="2">
drill 1.1 mm</description>
<wire x1="-1.397" y1="0.508" x2="-1.397" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.508" y1="-1.397" x2="1.397" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.508" y1="1.397" x2="1.397" y2="0.508" width="0.1524" layer="21"/>
<wire x1="1.397" y1="0.508" x2="1.397" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="0.508" x2="-0.508" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="1.397" x2="0.508" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="-1.397" x2="-1.397" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.508" y1="-1.397" x2="-0.508" y2="-1.397" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="0.762" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="0.381" width="0.254" layer="51"/>
<pad name="MP" x="0" y="0" drill="1.1176" diameter="2.159" shape="octagon"/>
<text x="-1.27" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0" y="0.381" size="0.0254" layer="27">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="LSP10" urn="urn:adsk.eagle:package:26501/1" type="box" library_version="2">
<description>SOLDER PAD
<packageinstances>
<packageinstance name="LSP10"/>
</packageinstances>
</package3d>
<package3d name="SE11" urn="urn:adsk.eagle:package:26506/1" type="box" library_version="2">
<packageinstances>
<packageinstance name="SE11"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="jumper" urn="urn:adsk.eagle:library:252">
<description>&lt;b&gt;Jumpers&lt;/b&gt;&lt;p&gt;
<packages>
<package name="JP2" urn="urn:adsk.eagle:footprint:15390/1" library_version="2">
<description>&lt;b&gt;JUMPER&lt;/b&gt;</description>
<wire x1="-3.81" y1="-1.016" x2="-3.81" y2="1.016" width="0.1524" layer="21"/>
<wire x1="3.556" y1="1.27" x2="1.524" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.27" y1="1.016" x2="1.524" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.556" y1="-1.27" x2="1.524" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-1.016" x2="1.524" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.556" y1="-1.27" x2="3.81" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="3.556" y1="1.27" x2="3.81" y2="1.016" width="0.1524" layer="21"/>
<wire x1="3.81" y1="1.016" x2="3.81" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.016" y1="1.27" x2="1.27" y2="1.016" width="0.1524" layer="21"/>
<wire x1="1.016" y1="1.27" x2="-1.016" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="1.016" x2="-1.016" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="1.27" x2="-1.27" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.016" x2="-3.556" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="1.27" x2="-3.556" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-1.27" x2="1.27" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-1.016" x2="-1.016" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-1.27" x2="-1.27" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-1.016" x2="-3.556" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-1.27" x2="-1.016" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-1.27" x2="-3.556" y2="-1.27" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="2" x="0" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="0" drill="0.9144" shape="long" rot="R90"/>
<text x="-3.556" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-2.667" size="0.9906" layer="21" ratio="12">1</text>
<text x="0" y="-2.667" size="0.9906" layer="21" ratio="12">2</text>
<text x="2.54" y="-2.667" size="0.9906" layer="21" ratio="12">3</text>
<text x="-3.556" y="-4.318" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.8448" y1="-0.3048" x2="-2.2352" y2="0.3048" layer="51"/>
<rectangle x1="-0.3048" y1="-0.3048" x2="0.3048" y2="0.3048" layer="51"/>
<rectangle x1="2.2352" y1="-0.3048" x2="2.8448" y2="0.3048" layer="51"/>
</package>
<package name="JP1" urn="urn:adsk.eagle:footprint:15398/1" library_version="2">
<wire x1="-1.016" y1="0" x2="-1.27" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="0" x2="-1.27" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0" x2="1.27" y2="0.254" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0" x2="1.27" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-0.254" x2="1.27" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-2.54" x2="1.27" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="1.27" y1="2.286" x2="1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="1.27" y1="2.286" x2="1.27" y2="0.254" width="0.1524" layer="21"/>
<wire x1="1.016" y1="2.54" x2="-1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="2.286" x2="-1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="2.286" x2="-1.27" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-0.254" x2="-1.27" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-2.54" x2="-1.27" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-2.54" x2="1.016" y2="-2.54" width="0.1524" layer="21"/>
<pad name="1" x="0" y="-1.27" drill="0.9144" shape="long"/>
<pad name="2" x="0" y="1.27" drill="0.9144" shape="long"/>
<text x="-1.651" y="-2.54" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="2.921" y="-2.54" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.3048" y1="0.9652" x2="0.3048" y2="1.5748" layer="51"/>
<rectangle x1="-0.3048" y1="-1.5748" x2="0.3048" y2="-0.9652" layer="51"/>
</package>
</packages>
<packages3d>
<package3d name="JP2" urn="urn:adsk.eagle:package:15452/1" type="box" library_version="2">
<description>JUMPER</description>
<packageinstances>
<packageinstance name="JP2"/>
</packageinstances>
</package3d>
<package3d name="JP1" urn="urn:adsk.eagle:package:15455/1" type="box" library_version="2">
<packageinstances>
<packageinstance name="JP1"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="SIF422-relé">
<packages>
<package name="SIF422">
<description>SIF422 relé 4xON 2Xoff</description>
<wire x1="-26.8" y1="-16.8" x2="-26.8" y2="16.8" width="0.127" layer="21"/>
<wire x1="-26.8" y1="16.8" x2="26.8" y2="16.8" width="0.127" layer="21"/>
<wire x1="26.8" y1="16.8" x2="26.8" y2="-16.8" width="0.127" layer="21"/>
<wire x1="26.8" y1="-16.8" x2="-26.8" y2="-16.8" width="0.127" layer="21"/>
<pad name="P$1" x="-23.7" y="-15.2" drill="0.8" diameter="2.54"/>
<pad name="P$2" x="23.7" y="-15.2" drill="0.8" diameter="2.54"/>
<pad name="P$3" x="-7.9" y="0.3" drill="0.8" diameter="2.54"/>
<pad name="P$4" x="-23.7" y="0.3" drill="0.8" diameter="2.54"/>
<pad name="P$5" x="7.8" y="0.3" drill="0.8" diameter="2.54"/>
<pad name="P$6" x="23.7" y="0.3" drill="0.8" diameter="2.54"/>
<pad name="P$7" x="-7.9" y="7.7" drill="0.8" diameter="2.54"/>
<pad name="P$8" x="-23.7" y="7.7" drill="0.8" diameter="2.54"/>
<pad name="P$9" x="7.8" y="7.7" drill="0.8" diameter="2.54"/>
<pad name="P$10" x="23.7" y="7.7" drill="0.8" diameter="2.54"/>
<pad name="P$11" x="-7.9" y="15.2" drill="0.8" diameter="2.54"/>
<pad name="P$12" x="-23.7" y="15.2" drill="0.8" diameter="2.54"/>
<pad name="P$13" x="7.8" y="15.2" drill="0.8" diameter="2.54"/>
<pad name="P$14" x="23.7" y="15.2" drill="0.8" diameter="2.54"/>
</package>
</packages>
</library>
<library name="con-rib" urn="urn:adsk.eagle:library:183">
<description>&lt;b&gt;Ribbon Cable Connectors&lt;/b&gt; Flachstecker / Faston&lt;p&gt;
Width 2,8 mm, 4,8 mm, 6,3 mm&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="ST4,8" urn="urn:adsk.eagle:footprint:9972/1" library_version="1">
<description>&lt;b&gt;RIBBON CABLE CONNECTOR&lt;/b&gt;&lt;p&gt;
Flachstecker / Faston</description>
<wire x1="2.5654" y1="-0.3302" x2="2.5654" y2="0.3302" width="0.254" layer="51"/>
<wire x1="2.5654" y1="0.3302" x2="-2.5146" y2="0.3302" width="0.254" layer="51"/>
<wire x1="-2.5146" y1="0.3302" x2="-2.5146" y2="-0.3302" width="0.254" layer="51"/>
<wire x1="-2.5146" y1="-0.3302" x2="-0.635" y2="-0.3302" width="0.254" layer="51"/>
<wire x1="-0.635" y1="-0.3302" x2="0.635" y2="-0.3302" width="0.254" layer="51"/>
<wire x1="0.635" y1="-0.3302" x2="2.5654" y2="-0.3302" width="0.254" layer="51"/>
<wire x1="2.5654" y1="0.3302" x2="4.1402" y2="0.3302" width="0.254" layer="51"/>
<wire x1="4.1402" y1="0.3302" x2="4.1402" y2="-0.3302" width="0.254" layer="51"/>
<wire x1="4.1402" y1="-0.3302" x2="2.5654" y2="-0.3302" width="0.254" layer="51"/>
<wire x1="-2.5146" y1="0.3302" x2="-4.1148" y2="0.3302" width="0.254" layer="51"/>
<wire x1="-4.1148" y1="0.3302" x2="-4.1148" y2="-0.3302" width="0.254" layer="51"/>
<wire x1="-4.1148" y1="-0.3302" x2="-2.5146" y2="-0.3302" width="0.254" layer="51"/>
<wire x1="-1.778" y1="-0.635" x2="-1.27" y2="-0.635" width="0.254" layer="51"/>
<wire x1="1.524" y1="0.508" x2="1.8508" y2="-0.66" width="0.254" layer="51" curve="-282.34222"/>
<wire x1="-1.778" y1="-0.635" x2="-1.5258" y2="0.5706" width="0.254" layer="51" curve="-283.240738"/>
<wire x1="-1.27" y1="-0.635" x2="-0.635" y2="-0.3302" width="0.254" layer="51"/>
<wire x1="-1.27" y1="-0.635" x2="0" y2="-0.635" width="0.254" layer="51"/>
<wire x1="-0.635" y1="-0.3302" x2="-0.635" y2="0.635" width="0.254" layer="51"/>
<wire x1="-0.635" y1="-0.3302" x2="0" y2="-0.635" width="0.254" layer="51"/>
<wire x1="0" y1="-0.635" x2="1.27" y2="-0.635" width="0.254" layer="51"/>
<wire x1="0" y1="-0.635" x2="0.635" y2="-0.3302" width="0.254" layer="51"/>
<wire x1="0.635" y1="-0.3302" x2="0.635" y2="0.635" width="0.254" layer="51"/>
<wire x1="0.635" y1="-0.3302" x2="1.27" y2="-0.635" width="0.254" layer="51"/>
<wire x1="1.27" y1="-0.635" x2="1.905" y2="-0.635" width="0.254" layer="51"/>
<wire x1="0.635" y1="0.635" x2="0.3302" y2="0.9652" width="0.254" layer="51"/>
<wire x1="-0.635" y1="0.635" x2="-0.3048" y2="0.9652" width="0.254" layer="51"/>
<wire x1="-0.3048" y1="0.9652" x2="0.3302" y2="0.9652" width="0.254" layer="51"/>
<wire x1="-0.4064" y1="0.3302" x2="0.4064" y2="0.3302" width="0.254" layer="21"/>
<wire x1="-0.4064" y1="-0.3302" x2="0.4064" y2="-0.3302" width="0.254" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="1.397" shape="long" rot="R90"/>
<pad name="2" x="2.54" y="0" drill="1.397" shape="long" rot="R90"/>
<text x="-3.302" y="2.2352" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="ST4,8" urn="urn:adsk.eagle:package:9988/1" type="box" library_version="1">
<description>RIBBON CABLE CONNECTOR
<packageinstances>
<packageinstance name="ST4,8"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="rectifier">
<description>&lt;b&gt;Rectifiers&lt;/b&gt;&lt;p&gt;
General Instrument, Semikron, Diotec, Fagor&lt;p&gt;
<packages>
<package name="GBU4S">
<description>&lt;b&gt;GENERAL INSTRUMENT RECTIFIER&lt;/b&gt;</description>
<wire x1="-11.43" y1="-1.27" x2="-11.43" y2="2.54" width="0.1524" layer="21"/>
<wire x1="11.43" y1="2.54" x2="11.43" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="2.54" x2="6.35" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.35" y1="2.54" x2="11.43" y2="2.54" width="0.1524" layer="21"/>
<wire x1="10.16" y1="1.905" x2="10.16" y2="0.635" width="0.1524" layer="21"/>
<wire x1="9.525" y1="1.27" x2="10.795" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="1.27" x2="-9.525" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-5.0546" y1="1.27" x2="-4.3942" y2="1.27" width="0.1524" layer="21" curve="180"/>
<wire x1="-5.715" y1="1.27" x2="-5.0546" y2="1.27" width="0.1524" layer="21" curve="-180"/>
<wire x1="0.0254" y1="1.27" x2="0.6858" y2="1.27" width="0.1524" layer="21" curve="180"/>
<wire x1="-0.635" y1="1.27" x2="0.0254" y2="1.27" width="0.1524" layer="21" curve="-180"/>
<wire x1="11.43" y1="-1.27" x2="8.89" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="8.89" y1="-1.27" x2="6.35" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="3.81" y1="-1.27" x2="6.35" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-1.27" x2="1.27" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="-1.27" x2="1.27" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-1.27" x2="-3.81" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-6.35" y1="-1.27" x2="-3.81" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="6.35" y1="2.54" x2="6.35" y2="1.27" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-1.27" x2="6.35" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-6.35" y1="-1.27" x2="-8.89" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-8.89" y1="-1.27" x2="-11.43" y2="-1.27" width="0.1524" layer="21"/>
<pad name="-" x="-7.62" y="0" drill="1.4986" shape="long" rot="R90"/>
<pad name="AC2" x="-2.54" y="0" drill="1.4986" shape="long" rot="R90"/>
<pad name="AC1" x="2.54" y="0" drill="1.4986" shape="long" rot="R90"/>
<pad name="+" x="7.62" y="0" drill="1.4986" shape="long" rot="R90"/>
<text x="-11.43" y="3.048" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="3.048" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-11.43" y1="-1.905" x2="11.43" y2="2.54" layer="43"/>
</package>
</packages>
</library>
<library name="rcl">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
http://www.secc.co.jp/pdf/os_e/2004/e_os_all.pdf &lt;b&gt;(SANYO)&lt;/b&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0&gt;
&lt;tr valign="top"&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;</description>
<packages>
<package name="C1206">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;</description>
<wire x1="-2.473" y1="0.983" x2="2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-0.983" x2="-2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-0.983" x2="-2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="0.983" x2="2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-0.965" y1="0.787" x2="0.965" y2="0.787" width="0.1016" layer="51"/>
<wire x1="-0.965" y1="-0.787" x2="0.965" y2="-0.787" width="0.1016" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.7018" y1="-0.8509" x2="-0.9517" y2="0.8491" layer="51"/>
<rectangle x1="0.9517" y1="-0.8491" x2="1.7018" y2="0.8509" layer="51"/>
<rectangle x1="-0.1999" y1="-0.4001" x2="0.1999" y2="0.4001" layer="35"/>
</package>
<package name="E5-10,5">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 5.08 mm, diameter 10.5 mm</description>
<wire x1="-1.143" y1="0" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.143" x2="-0.254" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.143" x2="-0.254" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.143" x2="-0.889" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.143" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.143" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.651" x2="-3.81" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="1.27" x2="-4.191" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="0" x2="-1.143" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="5.08" width="0.1524" layer="21"/>
<pad name="+" x="-2.54" y="0" drill="1.016" diameter="2.54"/>
<pad name="-" x="2.54" y="0" drill="1.016" diameter="2.54" shape="octagon"/>
<text x="4.699" y="2.7432" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.1242" y="-3.2258" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.143" x2="0.889" y2="1.143" layer="21"/>
</package>
<package name="R1206">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;</description>
<wire x1="0.9525" y1="-0.8128" x2="-0.9652" y2="-0.8128" width="0.1524" layer="51"/>
<wire x1="0.9525" y1="0.8128" x2="-0.9652" y2="0.8128" width="0.1524" layer="51"/>
<smd name="2" x="1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<smd name="1" x="-1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<rectangle x1="-1.6891" y1="-0.8763" x2="-0.9525" y2="0.8763" layer="51"/>
<rectangle x1="0.9525" y1="-0.8763" x2="1.6891" y2="0.8763" layer="51"/>
<rectangle x1="-0.3" y1="-0.7" x2="0.3" y2="0.7" layer="35"/>
</package>
<package name="E3,5-8">
grid 3.5 mm, diameter 8 mm</description>
<wire x1="-3.429" y1="1.143" x2="-2.667" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="0.762" x2="-3.048" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.762" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="4.064" width="0.1524" layer="21"/>
<pad name="-" x="1.778" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.778" y="0" drill="0.8128" diameter="1.6002"/>
<text x="3.302" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="C1210">
<wire x1="-2.473" y1="1.483" x2="2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-1.483" x2="-2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-1.483" x2="-2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="-0.9652" y1="1.2446" x2="0.9652" y2="1.2446" width="0.1016" layer="51"/>
<wire x1="-0.9652" y1="-1.2446" x2="0.9652" y2="-1.2446" width="0.1016" layer="51"/>
<wire x1="2.473" y1="1.483" x2="2.473" y2="-1.483" width="0.0508" layer="39"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.7018" y1="-1.2954" x2="-0.9517" y2="1.3045" layer="51"/>
<rectangle x1="0.9517" y1="-1.3045" x2="1.7018" y2="1.2954" layer="51"/>
</package>
<package name="M1406">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
MELF 0.12 W</description>
<wire x1="-2.973" y1="0.983" x2="2.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-0.983" x2="-2.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-0.983" x2="-2.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="0.983" x2="2.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.3208" y1="0.762" x2="-1.3208" y2="0.762" width="0.1524" layer="51"/>
<wire x1="1.3208" y1="-0.762" x2="-1.3208" y2="-0.762" width="0.1524" layer="51"/>
<smd name="1" x="-1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<smd name="2" x="1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<rectangle x1="-1.8542" y1="-0.8382" x2="-1.2954" y2="0.8382" layer="51"/>
<rectangle x1="1.2954" y1="-0.8382" x2="1.8542" y2="0.8382" layer="51"/>
</package>
</packages>
</library>
<library name="diode">
<description>&lt;b&gt;Diodes&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Motorola : www.onsemi.com
&lt;li&gt;Fairchild : www.fairchildsemi.com
&lt;li&gt;Philips : www.semiconductors.com
&lt;li&gt;Vishay : www.vishay.de
&lt;/ul&gt;
<packages>
<package name="DO41Z10">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
diameter 2.54 mm, horizontal, grid 10.16 mm</description>
<wire x1="2.032" y1="-1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0" x2="3.937" y2="0" width="0.762" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.762" layer="51"/>
<wire x1="-0.635" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.635" x2="1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0.635" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<pad name="C" x="-5.08" y="0" drill="1.1176"/>
<pad name="A" x="5.08" y="0" drill="1.1176"/>
<text x="-1.905" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.905" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-1.27" x2="-1.143" y2="1.27" layer="21"/>
<rectangle x1="2.032" y1="-0.381" x2="3.937" y2="0.381" layer="21"/>
<rectangle x1="-3.937" y1="-0.381" x2="-2.032" y2="0.381" layer="21"/>
</package>
<package name="MELF-MLL41">
<description>&lt;b&gt;DIODE&lt;/b&gt;&lt;p&gt;
Package DO-213AB = http://www.diotec.com/pdf/sm4001.pdf</description>
<wire x1="2.0828" y1="1.1938" x2="-2.159" y2="1.1938" width="0.1524" layer="51"/>
<wire x1="2.0828" y1="-1.1938" x2="-2.1336" y2="-1.1938" width="0.1524" layer="51"/>
<wire x1="0.627" y1="1" x2="-0.746" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.746" y1="0" x2="0.627" y2="-1" width="0.2032" layer="21"/>
<wire x1="0.627" y1="-1" x2="0.627" y2="1" width="0.2032" layer="21"/>
<wire x1="1.1208" y1="1.1938" x2="-1.097" y2="1.1938" width="0.1524" layer="21"/>
<wire x1="1.1208" y1="-1.1938" x2="-1.0716" y2="-1.1938" width="0.1524" layer="21"/>
<smd name="C" x="-2.625" y="0" dx="2.5" dy="3" layer="1"/>
<smd name="A" x="2.625" y="0" dx="2.5" dy="3" layer="1"/>
<text x="-2.663" y="1.724" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.663" y="-2.994" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="2.0574" y1="-1.27" x2="2.5654" y2="1.27" layer="51"/>
<rectangle x1="-2.6162" y1="-1.27" x2="-2.1082" y2="1.27" layer="51"/>
<rectangle x1="-1.4478" y1="-1.1938" x2="-0.5588" y2="1.1938" layer="51"/>
</package>
<package name="SOD80C">
<description>&lt;B&gt;DIODE&lt;/B&gt;</description>
<wire x1="1.3208" y1="0.7874" x2="-1.3208" y2="0.7874" width="0.1524" layer="51"/>
<wire x1="1.3208" y1="-0.7874" x2="-1.3208" y2="-0.7874" width="0.1524" layer="51"/>
<wire x1="0.627" y1="0.6" x2="-0.373" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.373" y1="0" x2="0.627" y2="-0.6" width="0.2032" layer="21"/>
<wire x1="0.627" y1="-0.6" x2="0.627" y2="0.6" width="0.2032" layer="21"/>
<smd name="C" x="-1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<smd name="A" x="1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<text x="-1.524" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.524" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.8542" y1="-0.8636" x2="-1.2954" y2="0.8636" layer="51"/>
<rectangle x1="1.2954" y1="-0.8636" x2="1.8542" y2="0.8636" layer="51"/>
<rectangle x1="-0.8636" y1="-0.7874" x2="-0.254" y2="0.7874" layer="21"/>
</package>
</packages>
</library>
<library name="led">
<description>&lt;b&gt;LEDs&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;br&gt;
Extended by Federico Battaglin &lt;author&gt;&amp;lt;federico.rd@fdpinternational.com&amp;gt;&lt;/author&gt; with DUOLED</description>
<packages>
<package name="LED5MM">
<description>&lt;B&gt;LED&lt;/B&gt;&lt;p&gt;
5 mm, round</description>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="1.905" width="0.2032" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="1.905" width="0.254" layer="21" curve="-286.260205"/>
<wire x1="-1.143" y1="0" x2="0" y2="1.143" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-1.143" x2="1.143" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="-1.651" y1="0" x2="0" y2="1.651" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-1.651" x2="1.651" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="-2.159" y1="0" x2="0" y2="2.159" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-2.159" x2="2.159" y2="0" width="0.1524" layer="51" curve="90"/>
<circle x="0" y="0" radius="2.54" width="0.1524" layer="21"/>
<pad name="A" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="K" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="3.175" y="0.5334" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.2004" y="-1.8034" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="transistor-power">
<description>&lt;b&gt;Power Transistors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="TO220BV">
<description>&lt;b&gt;Molded Package&lt;/b&gt;&lt;p&gt;
grid 2.54 mm</description>
<wire x1="4.699" y1="-4.318" x2="4.953" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="-4.699" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-4.699" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.143" x2="4.953" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-5.08" y2="-1.143" width="0.1524" layer="21"/>
<circle x="-4.4958" y="-3.7084" radius="0.254" width="0" layer="21"/>
<pad name="G" x="-2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="D" x="0" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="S" x="2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<text x="-5.08" y="-6.0452" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-7.62" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.334" y1="-0.762" x2="5.334" y2="0" layer="21"/>
<rectangle x1="-5.334" y1="-1.27" x2="-3.429" y2="-0.762" layer="21"/>
<rectangle x1="-1.651" y1="-1.27" x2="-0.889" y2="-0.762" layer="21"/>
<rectangle x1="-3.429" y1="-1.27" x2="-1.651" y2="-0.762" layer="51"/>
<rectangle x1="0.889" y1="-1.27" x2="1.651" y2="-0.762" layer="21"/>
<rectangle x1="3.429" y1="-1.27" x2="5.334" y2="-0.762" layer="21"/>
<rectangle x1="-0.889" y1="-1.27" x2="0.889" y2="-0.762" layer="51"/>
<rectangle x1="1.651" y1="-1.27" x2="3.429" y2="-0.762" layer="51"/>
</package>
</packages>
</library>
<library name="transistor">
<description>&lt;b&gt;Transistors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="TO92-CBE">
<description>&lt;b&gt;TO-92&lt;/b&gt; Pads In Line  C B E from top&lt;p&gt;</description>
<wire x1="-2.095" y1="-1.651" x2="2.095" y2="-1.651" width="0.127" layer="21"/>
<wire x1="-2.413" y1="1.1359" x2="2.413" y2="1.1359" width="0.127" layer="21" curve="-129.583"/>
<wire x1="1.136" y1="-0.127" x2="-1.136" y2="-0.127" width="0.127" layer="51"/>
<wire x1="-2.413" y1="1.1359" x2="-2.664" y2="-0.127" width="0.127" layer="51" curve="27.9376"/>
<wire x1="-2.664" y1="-0.127" x2="-2.413" y2="-1.1359" width="0.127" layer="51" curve="22.4788"/>
<wire x1="-1.404" y1="-0.127" x2="-2.664" y2="-0.127" width="0.127" layer="51"/>
<wire x1="-2.4135" y1="-1.1359" x2="-2.095" y2="-1.651" width="0.127" layer="21" curve="13.0385"/>
<wire x1="-1.136" y1="-0.127" x2="-1.404" y2="-0.127" width="0.127" layer="21"/>
<wire x1="2.413" y1="-1.1359" x2="2.664" y2="-0.127" width="0.127" layer="51" curve="22.4788"/>
<wire x1="2.664" y1="-0.127" x2="2.413" y2="1.1359" width="0.127" layer="51" curve="27.9376"/>
<wire x1="2.664" y1="-0.127" x2="1.404" y2="-0.127" width="0.127" layer="51"/>
<wire x1="1.404" y1="-0.127" x2="1.136" y2="-0.127" width="0.127" layer="21"/>
<wire x1="2.095" y1="-1.651" x2="2.4247" y2="-1.1118" width="0.127" layer="21" curve="13.6094"/>
<pad name="C" x="-2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="E" x="2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="B" x="0" y="0" drill="0.8128" shape="long" rot="R90"/>
<text x="-2.54" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="con-ptr500">
<description>&lt;b&gt;PTR Connectors&lt;/b&gt;&lt;p&gt;
Aug. 2004 / PTR Meßtechnik:&lt;br&gt;
Die Bezeichnung der Serie AK505 wurde geändert.&lt;br&gt;
Es handelt sich hierbei um AK500 in horizontaler Ausführung.&lt;p&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=LEFT&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Alte Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Neue Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2DS,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2DS-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AKZ505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AKZ500/2-5.08-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TABLE&gt;
<packages>
<package name="AK500/2">
<description>&lt;b&gt;CONNECTOR&lt;/b&gt;</description>
<wire x1="-5.08" y1="-3.556" x2="-5.08" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="5.08" y1="3.937" x2="-5.08" y2="3.937" width="0.1524" layer="21"/>
<wire x1="5.08" y1="3.937" x2="5.08" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.556" x2="5.08" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.048" x2="-5.588" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.048" x2="-5.08" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="3.175" x2="-5.588" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="2.032" x2="-5.08" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.159" x2="-5.08" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.159" x2="5.08" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.159" x2="5.08" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.159" x2="5.08" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.159" x2="-5.08" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-2.159" x2="5.08" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="1.4986" y1="-1.397" x2="3.9116" y2="1.016" width="0.1524" layer="51"/>
<wire x1="1.1176" y1="-1.016" x2="3.5306" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-3.9116" y1="-1.016" x2="-1.4986" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-3.5306" y1="-1.397" x2="-1.1176" y2="1.016" width="0.1524" layer="51"/>
<wire x1="1.4986" y1="-1.016" x2="3.5306" y2="1.016" width="0.6096" layer="51"/>
<wire x1="-3.5306" y1="-1.016" x2="-1.4986" y2="1.016" width="0.6096" layer="51"/>
<wire x1="1.1176" y1="-1.016" x2="1.4986" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="3.5306" y1="1.397" x2="3.9116" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-3.9116" y1="-1.016" x2="-3.5306" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-1.4986" y1="1.397" x2="-1.1176" y2="1.016" width="0.1524" layer="51"/>
<circle x="2.5146" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="-2.5146" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="2.5146" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="-2.5146" y="0" radius="1.778" width="0.1524" layer="51"/>
<pad name="1" x="-2.5146" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="2" x="2.5146" y="0" drill="1.3208" shape="long" rot="R90"/>
<text x="-5.08" y="4.445" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-5.715" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.445" y="2.54" size="0.9906" layer="21" ratio="12">1</text>
<text x="0.635" y="2.54" size="0.9906" layer="21" ratio="12">2</text>
<rectangle x1="-0.381" y1="-1.905" x2="0.381" y2="1.905" layer="21"/>
</package>
</packages>
</library>
<library name="fuse">
<description>&lt;b&gt;Fuses and Fuse Holders&lt;/b&gt;&lt;p&gt;
<packages>
<package name="SHK20L">
<description>&lt;b&gt;FUSE HOLDER&lt;/b&gt;&lt;p&gt; 5 x 20 mm, SH contact, SHH1 Schukat / E1073 Buerklin</description>
<wire x1="-5.334" y1="2.921" x2="5.334" y2="2.921" width="0.0508" layer="21"/>
<wire x1="-3.302" y1="0" x2="3.302" y2="0" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="3.683" x2="-5.969" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-3.683" x2="-10.414" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-2.54" x2="-5.969" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="3.683" x2="-10.414" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="2.54" x2="-5.969" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="-3.683" x2="-10.414" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="-3.683" x2="-5.969" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-3.683" x2="-11.049" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-11.049" y1="-3.683" x2="-11.049" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="-2.032" x2="-10.795" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="-3.429" x2="-10.414" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-3.429" x2="-10.414" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="2.54" x2="-5.969" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-11.049" y1="-2.032" x2="-11.049" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-11.049" y1="-1.27" x2="-10.795" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-10.795" y1="-1.27" x2="-10.795" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="-3.302" y1="0" x2="-5.334" y2="0" width="0.1524" layer="51"/>
<wire x1="5.334" y1="-2.921" x2="-5.334" y2="-2.921" width="0.0508" layer="21"/>
<wire x1="10.414" y1="-3.683" x2="5.969" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="10.414" y1="3.683" x2="10.414" y2="3.429" width="0.1524" layer="21"/>
<wire x1="10.414" y1="2.54" x2="5.969" y2="2.54" width="0.1524" layer="21"/>
<wire x1="10.414" y1="-3.683" x2="10.414" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="10.414" y1="-2.54" x2="5.969" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.969" y1="3.683" x2="10.414" y2="3.683" width="0.1524" layer="21"/>
<wire x1="5.969" y1="3.683" x2="5.969" y2="2.54" width="0.1524" layer="21"/>
<wire x1="10.414" y1="3.683" x2="11.049" y2="3.683" width="0.1524" layer="21"/>
<wire x1="11.049" y1="3.683" x2="11.049" y2="2.032" width="0.1524" layer="21"/>
<wire x1="10.795" y1="2.032" x2="10.795" y2="3.429" width="0.1524" layer="21"/>
<wire x1="10.795" y1="3.429" x2="10.414" y2="3.429" width="0.1524" layer="21"/>
<wire x1="10.414" y1="3.429" x2="10.414" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.969" y1="-2.54" x2="5.969" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="11.049" y1="2.032" x2="11.049" y2="1.27" width="0.1524" layer="51"/>
<wire x1="11.049" y1="1.27" x2="10.795" y2="1.27" width="0.1524" layer="51"/>
<wire x1="10.795" y1="1.27" x2="10.795" y2="2.032" width="0.1524" layer="51"/>
<wire x1="3.302" y1="0" x2="5.334" y2="0" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-3.683" x2="11.049" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="11.049" y1="-2.032" x2="11.049" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-3.429" x2="10.795" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-3.429" x2="10.414" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="10.414" y1="-3.429" x2="10.414" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="11.049" y1="1.27" x2="11.049" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="10.795" y1="1.27" x2="10.795" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="-10.795" y1="2.032" x2="-10.795" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-11.049" y1="2.032" x2="-11.049" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="3.683" x2="-11.049" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="3.429" x2="-10.414" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="3.429" x2="-10.414" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="3.429" x2="-10.795" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-11.049" y1="2.032" x2="-11.049" y2="3.683" width="0.1524" layer="21"/>
<pad name="1A" x="-10.414" y="0" drill="1.3208" diameter="2.54" shape="long" rot="R90"/>
<pad name="2A" x="10.414" y="0" drill="1.3208" diameter="2.54" shape="long" rot="R90"/>
<pad name="2B" x="5.334" y="0" drill="1.3208" diameter="2.54" shape="long" rot="R90"/>
<pad name="1B" x="-5.334" y="0" drill="1.3208" diameter="2.54" shape="long" rot="R90"/>
<text x="-3.81" y="3.175" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-5.08" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-10.033" y1="-2.032" x2="-9.652" y2="2.032" layer="51"/>
<rectangle x1="-5.969" y1="-3.175" x2="-5.334" y2="-2.032" layer="21"/>
<rectangle x1="-5.969" y1="2.032" x2="-5.334" y2="3.175" layer="21"/>
<rectangle x1="-5.969" y1="-2.032" x2="-5.334" y2="2.032" layer="51"/>
<rectangle x1="9.652" y1="-2.032" x2="10.033" y2="2.032" layer="51"/>
<rectangle x1="5.334" y1="2.032" x2="5.969" y2="3.175" layer="21"/>
<rectangle x1="5.334" y1="-3.175" x2="5.969" y2="-2.032" layer="21"/>
<rectangle x1="5.334" y1="-2.032" x2="5.969" y2="2.032" layer="51"/>
<rectangle x1="4.064" y1="1.651" x2="5.334" y2="2.159" layer="51"/>
<rectangle x1="4.064" y1="-2.159" x2="5.334" y2="-1.651" layer="51"/>
<rectangle x1="-5.334" y1="1.651" x2="-4.064" y2="2.159" layer="51"/>
<rectangle x1="-5.334" y1="-2.159" x2="-4.064" y2="-1.651" layer="51"/>
<rectangle x1="-10.414" y1="-2.54" x2="-5.969" y2="-2.032" layer="21"/>
<rectangle x1="-4.064" y1="-2.159" x2="4.064" y2="-1.651" layer="21"/>
<rectangle x1="-4.064" y1="1.651" x2="4.064" y2="2.159" layer="21"/>
<rectangle x1="-6.223" y1="1.905" x2="-5.969" y2="2.032" layer="51"/>
<rectangle x1="5.969" y1="1.905" x2="6.223" y2="2.032" layer="51"/>
<rectangle x1="5.969" y1="-2.032" x2="6.223" y2="-1.905" layer="51"/>
<rectangle x1="9.398" y1="1.905" x2="9.652" y2="2.032" layer="51"/>
<rectangle x1="9.398" y1="-2.032" x2="9.652" y2="-1.905" layer="51"/>
<rectangle x1="6.223" y1="-2.032" x2="9.398" y2="-1.905" layer="21"/>
<rectangle x1="6.223" y1="1.905" x2="9.398" y2="2.032" layer="21"/>
<rectangle x1="5.969" y1="2.032" x2="10.033" y2="2.54" layer="21"/>
<rectangle x1="5.969" y1="-2.54" x2="10.033" y2="-2.032" layer="21"/>
<rectangle x1="-10.033" y1="2.032" x2="-5.969" y2="2.54" layer="21"/>
<rectangle x1="-9.398" y1="1.905" x2="-6.223" y2="2.032" layer="21"/>
<rectangle x1="-9.652" y1="1.905" x2="-9.398" y2="2.032" layer="51"/>
<rectangle x1="-6.223" y1="-2.032" x2="-5.969" y2="-1.905" layer="51"/>
<rectangle x1="-9.398" y1="-2.032" x2="-6.223" y2="-1.905" layer="21"/>
<rectangle x1="-9.652" y1="-2.032" x2="-9.398" y2="-1.905" layer="51"/>
</package>
</packages>
</library>
<library name="v-reg">
<description>&lt;b&gt;Voltage Regulators&lt;/b&gt;&lt;p&gt;
<packages>
<package name="78MXXS">
<description>&lt;b&gt;VOLTAGE REGULATOR&lt;/b&gt;</description>
<wire x1="-4.826" y1="-4.7498" x2="2.794" y2="-4.7498" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-0.127" x2="4.8006" y2="-0.127" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-4.7498" x2="4.8006" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-4.7498" x2="-4.826" y2="-0.127" width="0.1524" layer="21"/>
<wire x1="4.8006" y1="-0.127" x2="4.8006" y2="-2.794" width="0.1524" layer="21"/>
<circle x="-4.064" y="-3.9878" radius="0.4318" width="0" layer="21"/>
<pad name="IN" x="-2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="GND" x="0" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="OUT" x="2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<text x="-4.826" y="-6.477" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.826" y="-8.128" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-0.508" y="-1.778" size="1.27" layer="51" ratio="10">-</text>
<text x="-3.048" y="-1.778" size="1.27" layer="51" ratio="10">I</text>
<text x="2.032" y="-1.778" size="1.27" layer="51" ratio="10">O</text>
<rectangle x1="3.429" y1="-2.794" x2="4.826" y2="-2.286" layer="21"/>
<rectangle x1="0.889" y1="-2.794" x2="1.651" y2="-2.286" layer="21"/>
<rectangle x1="-1.651" y1="-2.794" x2="-0.889" y2="-2.286" layer="21"/>
<rectangle x1="-4.826" y1="-2.794" x2="-3.429" y2="-2.286" layer="21"/>
<rectangle x1="-3.429" y1="-2.794" x2="-1.651" y2="-2.286" layer="51"/>
<rectangle x1="-0.889" y1="-2.794" x2="0.889" y2="-2.286" layer="51"/>
<rectangle x1="1.651" y1="-2.794" x2="3.429" y2="-2.286" layer="51"/>
</package>
</packages>
</library>
<library name="texas">
<description>&lt;b&gt;Texas Instruments Devices&lt;/b&gt;&lt;p&gt;
<packages>
<package name="DIL08">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="5.08" y1="2.921" x2="-5.08" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.921" x2="-5.08" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="-5.08" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.016" x2="-5.08" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-3.81" y="-3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="2" x="-1.27" y="-3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="7" x="-1.27" y="3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="8" x="-3.81" y="3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="3" x="1.27" y="-3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="4" x="3.81" y="-3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="6" x="1.27" y="3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="5" x="3.81" y="3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<text x="-5.334" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-3.556" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="relay">
<description>&lt;b&gt;Relays&lt;/b&gt;&lt;p&gt;
&lt;ul&gt;
&lt;li&gt;Eichhoff
&lt;li&gt;Finder
&lt;li&gt;Fujitsu
&lt;li&gt;HAMLIN
&lt;li&gt;OMRON
&lt;li&gt;Matsushita
&lt;li&gt;NAiS
&lt;li&gt;Siemens
&lt;li&gt;Schrack
&lt;/ul&gt;
<packages>
<package name="G2R2">
<description>&lt;b&gt;RELAY&lt;/b&gt;&lt;p&gt;
2 x switch, Omron</description>
<wire x1="-4.699" y1="-6.604" x2="24.384" y2="-6.604" width="0.1524" layer="21"/>
<wire x1="24.384" y1="6.477" x2="24.384" y2="-6.604" width="0.1524" layer="21"/>
<wire x1="24.384" y1="6.477" x2="-4.699" y2="6.477" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-6.604" x2="-4.699" y2="6.477" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="2.0574" x2="-2.54" y2="1.1938" width="0.1524" layer="21"/>
<wire x1="-0.6604" y1="1.1938" x2="-0.6604" y2="-1.3208" width="0.254" layer="21"/>
<wire x1="-4.4196" y1="-1.3208" x2="-4.4196" y2="1.1938" width="0.254" layer="21"/>
<wire x1="-4.4196" y1="1.1938" x2="-2.54" y2="1.1938" width="0.254" layer="21"/>
<wire x1="-2.54" y1="1.1938" x2="-1.2954" y2="1.1938" width="0.254" layer="21"/>
<wire x1="-3.7846" y1="-1.3208" x2="-4.4196" y2="-1.3208" width="0.254" layer="21"/>
<wire x1="-1.2954" y1="1.1938" x2="-3.7846" y2="-1.3208" width="0.1524" layer="21"/>
<wire x1="-1.2954" y1="1.1938" x2="-0.6604" y2="1.1938" width="0.254" layer="21"/>
<wire x1="-0.6604" y1="-1.3208" x2="-2.54" y2="-1.3208" width="0.254" layer="21"/>
<wire x1="-2.54" y1="-1.3208" x2="-2.54" y2="-1.9304" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.3208" x2="-3.7846" y2="-1.3208" width="0.254" layer="21"/>
<wire x1="16.637" y1="0.508" x2="16.9672" y2="0.8382" width="0.254" layer="21"/>
<wire x1="16.9672" y1="0.8382" x2="12.446" y2="0.8382" width="0.1524" layer="21"/>
<wire x1="16.9672" y1="0.8382" x2="17.526" y2="1.397" width="0.254" layer="21"/>
<wire x1="12.446" y1="0.8382" x2="12.446" y2="1.9812" width="0.1524" layer="21"/>
<wire x1="18.4912" y1="0.8382" x2="22.479" y2="0.8382" width="0.1524" layer="21"/>
<wire x1="22.479" y1="0.8382" x2="22.479" y2="1.9812" width="0.1524" layer="21"/>
<wire x1="17.526" y1="1.905" x2="17.526" y2="1.397" width="0.1524" layer="21"/>
<wire x1="16.637" y1="-0.381" x2="16.9672" y2="-0.7112" width="0.254" layer="21"/>
<wire x1="16.9672" y1="-0.7112" x2="12.446" y2="-0.7112" width="0.1524" layer="21"/>
<wire x1="16.9672" y1="-0.7112" x2="17.526" y2="-1.27" width="0.254" layer="21"/>
<wire x1="12.446" y1="-0.7112" x2="12.446" y2="-1.8542" width="0.1524" layer="21"/>
<wire x1="18.4912" y1="-0.7112" x2="22.479" y2="-0.7112" width="0.1524" layer="21"/>
<wire x1="22.479" y1="-0.7112" x2="22.479" y2="-1.8542" width="0.1524" layer="21"/>
<wire x1="17.526" y1="-1.778" x2="17.526" y2="-1.27" width="0.1524" layer="21"/>
<pad name="2" x="-2.54" y="3.81" drill="1.3208" shape="long" rot="R90"/>
<pad name="1" x="-2.54" y="-3.683" drill="1.3208" shape="long" rot="R90"/>
<pad name="O1" x="12.4714" y="3.81" drill="1.3208" shape="long" rot="R90"/>
<pad name="P1" x="17.4498" y="3.81" drill="1.3208" shape="long" rot="R90"/>
<pad name="S1" x="22.4536" y="3.81" drill="1.3208" shape="long" rot="R90"/>
<pad name="O2" x="12.4714" y="-3.683" drill="1.3208" shape="long" rot="R90"/>
<pad name="P2" x="17.4498" y="-3.683" drill="1.3208" shape="long" rot="R90"/>
<pad name="S2" x="22.4536" y="-3.683" drill="1.3208" shape="long" rot="R90"/>
<text x="26.6446" y="-6.2992" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="3.81" y="-5.08" size="1.778" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="jumper">
<description>&lt;b&gt;Jumpers&lt;/b&gt;&lt;p&gt;
<packages>
<package name="JP2">
<description>&lt;b&gt;JUMPER&lt;/b&gt;</description>
<wire x1="-3.81" y1="-1.016" x2="-3.81" y2="1.016" width="0.1524" layer="21"/>
<wire x1="3.556" y1="1.27" x2="1.524" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.27" y1="1.016" x2="1.524" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.556" y1="-1.27" x2="1.524" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-1.016" x2="1.524" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.556" y1="-1.27" x2="3.81" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="3.556" y1="1.27" x2="3.81" y2="1.016" width="0.1524" layer="21"/>
<wire x1="3.81" y1="1.016" x2="3.81" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.016" y1="1.27" x2="1.27" y2="1.016" width="0.1524" layer="21"/>
<wire x1="1.016" y1="1.27" x2="-1.016" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="1.016" x2="-1.016" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="1.27" x2="-1.27" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.016" x2="-3.556" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="1.27" x2="-3.556" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-1.27" x2="1.27" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-1.016" x2="-1.016" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-1.27" x2="-1.27" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-1.016" x2="-3.556" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-1.27" x2="-1.016" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-1.27" x2="-3.556" y2="-1.27" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="2" x="0" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="0" drill="0.9144" shape="long" rot="R90"/>
<text x="-3.556" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-2.667" size="0.9906" layer="21" ratio="12">1</text>
<text x="0" y="-2.667" size="0.9906" layer="21" ratio="12">2</text>
<text x="2.54" y="-2.667" size="0.9906" layer="21" ratio="12">3</text>
<text x="-3.556" y="-4.318" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.8448" y1="-0.3048" x2="-2.2352" y2="0.3048" layer="51"/>
<rectangle x1="-0.3048" y1="-0.3048" x2="0.3048" y2="0.3048" layer="51"/>
<rectangle x1="2.2352" y1="-0.3048" x2="2.8448" y2="0.3048" layer="51"/>
</package>
</packages>
</library>
<library name="con-molex">
<description>&lt;b&gt;Molex Connectors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="6410-03">
<description>&lt;b&gt;KK® 254 Wire-to-Board Header, Vertical, with Friction Lock, 3 Circuits, Tin (Sn) Plating&lt;/b&gt;&lt;p&gt;&lt;a href =http://www.molex.com/pdm_docs/sd/022272031_sd.pdf&gt;Datasheet &lt;/a&gt;</description>
<wire x1="-2.54" y1="2.54" x2="-2.54" y2="2.921" width="0.127" layer="21"/>
<wire x1="-3.81" y1="0" x2="-3.81" y2="2.921" width="0.254" layer="21"/>
<wire x1="-3.81" y1="2.921" x2="-2.54" y2="2.921" width="0.254" layer="21"/>
<wire x1="-2.286" y1="2.921" x2="-2.54" y2="2.921" width="0.127" layer="21"/>
<wire x1="-2.54" y1="2.921" x2="-1.27" y2="2.921" width="0.254" layer="21"/>
<wire x1="3.81" y1="0" x2="3.81" y2="2.921" width="0.254" layer="21"/>
<wire x1="3.81" y1="2.921" x2="-1.27" y2="2.921" width="0.254" layer="21"/>
<wire x1="-3.81" y1="0" x2="-3.81" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-3.81" y1="-2.921" x2="-1.27" y2="-2.921" width="0.127" layer="21"/>
<wire x1="3.81" y1="0" x2="3.81" y2="-2.921" width="0.254" layer="21"/>
<wire x1="3.175" y1="-2.921" x2="1.905" y2="-2.921" width="0.254" layer="21"/>
<wire x1="0.635" y1="-2.921" x2="-0.635" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-2.921" x2="-1.27" y2="-2.921" width="0.127" layer="21"/>
<wire x1="-3.556" y1="-2.921" x2="-3.175" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-3.175" y1="-2.921" x2="-3.175" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-3.175" y1="-2.286" x2="-1.905" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-2.286" x2="-1.905" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-2.921" x2="-3.175" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-2.921" x2="-0.635" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-2.921" x2="-0.635" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-2.286" x2="0.635" y2="-2.286" width="0.254" layer="21"/>
<wire x1="0.635" y1="-2.286" x2="0.635" y2="-2.921" width="0.254" layer="21"/>
<wire x1="0.635" y1="-2.921" x2="1.905" y2="-2.921" width="0.254" layer="21"/>
<wire x1="1.905" y1="-2.921" x2="1.905" y2="-2.286" width="0.254" layer="21"/>
<wire x1="1.905" y1="-2.286" x2="3.175" y2="-2.286" width="0.254" layer="21"/>
<wire x1="3.175" y1="-2.286" x2="3.175" y2="-2.921" width="0.254" layer="21"/>
<wire x1="3.175" y1="-2.921" x2="3.81" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-2.54" y2="2.921" width="0.254" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-2.286" y2="1.905" width="0.254" layer="21"/>
<wire x1="-2.286" y1="1.905" x2="2.286" y2="1.905" width="0.254" layer="21"/>
<wire x1="2.286" y1="1.905" x2="2.54" y2="1.905" width="0.254" layer="21"/>
<wire x1="2.54" y1="1.905" x2="2.54" y2="2.921" width="0.254" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-2.286" y2="1.397" width="0.254" layer="21"/>
<wire x1="-2.286" y1="2.921" x2="-2.286" y2="1.905" width="0.254" layer="21"/>
<wire x1="-2.286" y1="1.397" x2="2.286" y2="1.397" width="0.254" layer="21"/>
<wire x1="2.286" y1="1.397" x2="2.54" y2="1.905" width="0.254" layer="21"/>
<wire x1="2.286" y1="2.921" x2="2.286" y2="1.905" width="0.254" layer="21"/>
<pad name="3" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-3.7831" y="3.2751" size="1.016" layer="25" ratio="10">&gt;NAME</text>
<text x="4.4181" y="-0.7381" size="1.27" layer="21" ratio="14">1</text>
<text x="-4.9799" y="-0.6873" size="1.27" layer="21" ratio="14">3</text>
<text x="-3.7831" y="-4.5989" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.794" y1="-0.254" x2="-2.286" y2="0.254" layer="51"/>
<rectangle x1="-0.254" y1="-0.254" x2="0.254" y2="0.254" layer="51"/>
<rectangle x1="2.286" y1="-0.254" x2="2.794" y2="0.254" layer="51"/>
</package>
</packages>
</library>
<library name="v-reg" urn="urn:adsk.eagle:library:409">
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="78MXXS" urn="urn:adsk.eagle:footprint:30286/1" library_version="4">
</package>
<package name="TO92-CLP" urn="urn:adsk.eagle:footprint:30307/1" library_version="4">
<wire x1="-2.0946" y1="-1.651" x2="-0.7863" y2="2.5485" width="0.1524" layer="21" curve="-111.098957"/>
<wire x1="0.7868" y1="2.5484" x2="2.095" y2="-1.651" width="0.1524" layer="21" curve="-111.09954"/>
<wire x1="-2.095" y1="-1.651" x2="2.095" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-2.655" y1="-0.254" x2="-2.254" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="2.254" y1="-0.254" x2="2.655" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-0.7863" y1="2.5485" x2="0.7863" y2="2.5485" width="0.1524" layer="51" curve="-34.293591"/>
<pad name="R" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="A" x="0" y="1.905" drill="0.8128" shape="octagon"/>
<pad name="C" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="3.175" y="0.635" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-1.27" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-0.3175" y="0.635" size="0.8128" layer="21">A</text>
<text x="-1.5875" y="-1.27" size="0.8128" layer="21">R</text>
<text x="0.9525" y="-1.27" size="0.8128" layer="21">C</text>
</package>
</packages>
<packages3d>
<package3d name="78MXXS" urn="urn:adsk.eagle:package:30347/1" type="box" library_version="4">
<description>VOLTAGE REGULATOR</description>
<packageinstances>
<packageinstance name="78MXXS"/>
</packageinstances>
</package3d>
<package3d name="TO92-CLP" urn="urn:adsk.eagle:package:30363/1" type="box" library_version="4">
<packageinstances>
<packageinstance name="TO92-CLP"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="optocoupler" urn="urn:adsk.eagle:library:320">
<description>&lt;b&gt;Opto Couplers&lt;/b&gt;&lt;p&gt;
Siemens, Hewlett-Packard, Texas Instuments, Sharp, Motorola&lt;p&gt;
<packages>
<package name="DIL04" urn="urn:adsk.eagle:footprint:21858/1" library_version="3">
<wire x1="2.54" y1="2.921" x2="-2.54" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-2.921" x2="2.54" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="2.54" y1="2.921" x2="2.54" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="2.921" x2="-2.54" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-2.921" x2="-2.54" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.016" x2="-2.54" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-1.27" y="-3.81" drill="0.8128" shape="offset" rot="R270"/>
<pad name="2" x="1.27" y="-3.81" drill="0.8128" shape="offset" rot="R270"/>
<pad name="3" x="1.27" y="3.81" drill="0.8128" shape="offset" rot="R90"/>
<pad name="4" x="-1.27" y="3.81" drill="0.8128" shape="offset" rot="R90"/>
<text x="4.191" y="-2.921" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="-2.921" y="-2.667" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
</package>
</packages>
<packages3d>
<package3d name="DIL04" urn="urn:adsk.eagle:package:21938/1" type="box" library_version="3">
<description>Dual In Line Package</description>
<packageinstances>
<packageinstance name="DIL04"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="fuse" urn="urn:adsk.eagle:library:233">
<packages>
<package name="TE5" urn="urn:adsk.eagle:footprint:14038/1" library_version="2">
<description>&lt;b&gt;FUSE&lt;/b&gt;&lt;p&gt;
Wickmann</description>
<wire x1="3.683" y1="2.032" x2="4.318" y2="1.397" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.683" y1="-2.032" x2="4.318" y2="-1.397" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.318" y1="-1.397" x2="-3.683" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.318" y1="1.397" x2="-3.683" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.683" y1="2.032" x2="-3.683" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="1.397" x2="-4.318" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="-2.032" x2="3.683" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-1.397" x2="4.318" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0" x2="2.159" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="0.381" x2="-1.27" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="-0.381" x2="1.27" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="1.27" y1="0.381" x2="1.27" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="1.27" y1="0.381" x2="-1.27" y2="0.381" width="0.1524" layer="51"/>
<pad name="1" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-4.191" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.318" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="TE5" urn="urn:adsk.eagle:package:14069/1" type="box" library_version="2">
<description>FUSE
<packageinstances>
<packageinstance name="TE5"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="rectifier" urn="urn:adsk.eagle:library:336">
<description>&lt;b&gt;Rectifiers&lt;/b&gt;&lt;p&gt;
General Instrument, Semikron, Diotec, Fagor&lt;p&gt;
<packages>
<package name="DBS" urn="urn:adsk.eagle:footprint:23859/1" library_version="3">
<description>&lt;b&gt;Single Phase 1.0 AMP Glass Passivated Bridge Rectifier&lt;/b&gt;&lt;p&gt;
Taiwan Semiconductor Co.,Ltd. - TSC&lt;br&gt;
Source: http://www.taiwansemi.com/TSCbig5/ezcatfiles/cust/img/img/db101g.pdf</description>
<wire x1="-4.05" y1="3.1" x2="4.05" y2="3.1" width="0.254" layer="21"/>
<wire x1="4.05" y1="3.1" x2="4.05" y2="-3.1" width="0.254" layer="21"/>
<wire x1="4.05" y1="-3.1" x2="-3.55" y2="-3.1" width="0.254" layer="21"/>
<wire x1="-3.55" y1="-3.1" x2="-4.05" y2="-3.1" width="0.254" layer="21"/>
<wire x1="-4.05" y1="-3.1" x2="-4.05" y2="3.1" width="0.254" layer="21"/>
<wire x1="-3.075" y1="2.175" x2="-2.6" y2="2.175" width="0.1016" layer="21" curve="-116.315085"/>
<wire x1="-2.125" y1="2.175" x2="-2.6" y2="2.175" width="0.1016" layer="21" curve="-116.315085"/>
<wire x1="2.125" y1="2.175" x2="2.6" y2="2.175" width="0.1016" layer="21" curve="-116.315085"/>
<wire x1="3.075" y1="2.175" x2="2.6" y2="2.175" width="0.1016" layer="21" curve="-116.315085"/>
<wire x1="-3.075" y1="-2.175" x2="-2.125" y2="-2.175" width="0.1016" layer="21"/>
<wire x1="2.125" y1="-2.175" x2="3.075" y2="-2.175" width="0.1016" layer="21"/>
<wire x1="-2.6" y1="-2.65" x2="-2.6" y2="-1.7" width="0.1016" layer="21"/>
<wire x1="-3.55" y1="-3.1" x2="-3.55" y2="3.1" width="0.254" layer="21"/>
<smd name="+" x="-2.55" y="-4.5" dx="1.7" dy="1.9" layer="1"/>
<smd name="-" x="2.55" y="-4.5" dx="1.7" dy="1.9" layer="1"/>
<smd name="AC2" x="2.55" y="4.5" dx="1.7" dy="1.9" layer="1" rot="R180"/>
<smd name="AC1" x="-2.55" y="4.5" dx="1.7" dy="1.9" layer="1" rot="R180"/>
<text x="-4.445" y="-3.175" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-3.175" y="-0.635" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.2" y1="-5.1" x2="-1.9" y2="-3.2" layer="51"/>
<rectangle x1="1.9" y1="-5.1" x2="3.2" y2="-3.2" layer="51"/>
<rectangle x1="1.9" y1="3.2" x2="3.2" y2="5.1" layer="51" rot="R180"/>
<rectangle x1="-3.2" y1="3.2" x2="-1.9" y2="5.1" layer="51" rot="R180"/>
</package>
</packages>
<packages3d>
<package3d name="DBS" urn="urn:adsk.eagle:package:23898/1" type="box" library_version="3">
<description>Single Phase 1.0 AMP Glass Passivated Bridge Rectifier
<packageinstances>
<packageinstance name="DBS"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="transistor-power" urn="urn:adsk.eagle:library:400">
<packages>
<package name="TO220BV" urn="urn:adsk.eagle:footprint:29371/1" library_version="4">
</package>
</packages>
<packages3d>
<package3d name="TO220BV" urn="urn:adsk.eagle:package:29484/3" type="model" library_version="4">
<description>Molded Package
<packageinstances>
<packageinstance name="TO220BV"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="display-lcd" urn="urn:adsk.eagle:library:214">
<description>&lt;b&gt;Hitachi, Data Modul, Tuxgraphics - LCD Displays&lt;/b&gt;&lt;p&gt;
<packages>
<package name="TUXGR_16X2_R2" urn="urn:adsk.eagle:footprint:13120/1" library_version="2">
<description>&lt;b&gt;Tuxgraphics LCD display 16x2 characters&lt;/b&gt; reflective, without background light&lt;p&gt;
Source: tuxgr_12x2_r2.pdf</description>
<wire x1="-39.9" y1="17.9" x2="39.9" y2="17.9" width="0.2032" layer="21"/>
<wire x1="39.9" y1="17.9" x2="39.9" y2="-17.9" width="0.2032" layer="21"/>
<wire x1="39.9" y1="-17.9" x2="-39.9" y2="-17.9" width="0.2032" layer="21"/>
<wire x1="-39.9" y1="-17.9" x2="-39.9" y2="17.9" width="0.2032" layer="21"/>
<wire x1="-36.75" y1="12" x2="36.75" y2="12" width="0.2032" layer="21"/>
<wire x1="36.75" y1="12" x2="36.75" y2="-12.6" width="0.2032" layer="21"/>
<wire x1="36.75" y1="-12.6" x2="-36.75" y2="-12.6" width="0.2032" layer="21"/>
<wire x1="-36.75" y1="-12.6" x2="-36.75" y2="12" width="0.2032" layer="21"/>
<wire x1="-32.15" y1="6.5" x2="32.15" y2="6.5" width="0.2032" layer="21"/>
<wire x1="32.15" y1="6.5" x2="32.15" y2="-7.1" width="0.2032" layer="21"/>
<wire x1="32.15" y1="-7.1" x2="-32.15" y2="-7.1" width="0.2032" layer="21"/>
<wire x1="-32.15" y1="-7.1" x2="-32.15" y2="6.5" width="0.2032" layer="21"/>
<pad name="1" x="-32" y="15.5" drill="1" diameter="1.6764"/>
<pad name="2" x="-29.46" y="15.5" drill="1" diameter="1.6764"/>
<pad name="3" x="-26.92" y="15.5" drill="1" diameter="1.6764"/>
<pad name="4" x="-24.38" y="15.5" drill="1" diameter="1.6764"/>
<pad name="5" x="-21.84" y="15.5" drill="1" diameter="1.6764"/>
<pad name="6" x="-19.3" y="15.5" drill="1" diameter="1.6764"/>
<pad name="7" x="-16.76" y="15.5" drill="1" diameter="1.6764"/>
<pad name="8" x="-14.22" y="15.5" drill="1" diameter="1.6764"/>
<pad name="9" x="-11.68" y="15.5" drill="1" diameter="1.6764"/>
<pad name="10" x="-9.14" y="15.5" drill="1" diameter="1.6764"/>
<pad name="11" x="-6.6" y="15.5" drill="1" diameter="1.6764"/>
<pad name="12" x="-4.06" y="15.5" drill="1" diameter="1.6764"/>
<pad name="13" x="-1.52" y="15.5" drill="1" diameter="1.6764"/>
<pad name="14" x="1.02" y="15.5" drill="1" diameter="1.6764"/>
<pad name="15" x="3.56" y="15.5" drill="1" diameter="1.6764"/>
<pad name="16" x="6.1" y="15.5" drill="1" diameter="1.6764"/>
<text x="-38.1" y="18.415" size="1.27" layer="25">&gt;NAME</text>
<text x="0.635" y="18.415" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-28.85" y1="0.1" x2="-25.9" y2="4.45" layer="21"/>
<rectangle x1="-28.85" y1="-5.05" x2="-25.9" y2="-0.7" layer="21"/>
<rectangle x1="-25.2" y1="0.1" x2="-22.25" y2="4.45" layer="21"/>
<rectangle x1="-25.2" y1="-5.05" x2="-22.25" y2="-0.7" layer="21"/>
<rectangle x1="-21.55" y1="0.1" x2="-18.6" y2="4.45" layer="21"/>
<rectangle x1="-21.55" y1="-5.05" x2="-18.6" y2="-0.7" layer="21"/>
<rectangle x1="-17.9" y1="0.1" x2="-14.95" y2="4.45" layer="21"/>
<rectangle x1="-17.9" y1="-5.05" x2="-14.95" y2="-0.7" layer="21"/>
<rectangle x1="-14.25" y1="0.1" x2="-11.3" y2="4.45" layer="21"/>
<rectangle x1="-14.25" y1="-5.05" x2="-11.3" y2="-0.7" layer="21"/>
<rectangle x1="-10.6" y1="0.1" x2="-7.65" y2="4.45" layer="21"/>
<rectangle x1="-10.6" y1="-5.05" x2="-7.65" y2="-0.7" layer="21"/>
<rectangle x1="-6.95" y1="0.1" x2="-4" y2="4.45" layer="21"/>
<rectangle x1="-6.95" y1="-5.05" x2="-4" y2="-0.7" layer="21"/>
<rectangle x1="-3.3" y1="0.1" x2="-0.35" y2="4.45" layer="21"/>
<rectangle x1="-3.3" y1="-5.05" x2="-0.35" y2="-0.7" layer="21"/>
<rectangle x1="0.35" y1="0.1" x2="3.3" y2="4.45" layer="21"/>
<rectangle x1="0.35" y1="-5.05" x2="3.3" y2="-0.7" layer="21"/>
<rectangle x1="4" y1="0.1" x2="6.95" y2="4.45" layer="21"/>
<rectangle x1="4" y1="-5.05" x2="6.95" y2="-0.7" layer="21"/>
<rectangle x1="7.65" y1="0.1" x2="10.6" y2="4.45" layer="21"/>
<rectangle x1="7.65" y1="-5.05" x2="10.6" y2="-0.7" layer="21"/>
<rectangle x1="11.3" y1="0.1" x2="14.25" y2="4.45" layer="21"/>
<rectangle x1="11.3" y1="-5.05" x2="14.25" y2="-0.7" layer="21"/>
<rectangle x1="14.95" y1="0.1" x2="17.9" y2="4.45" layer="21"/>
<rectangle x1="14.95" y1="-5.05" x2="17.9" y2="-0.7" layer="21"/>
<rectangle x1="18.6" y1="0.1" x2="21.55" y2="4.45" layer="21"/>
<rectangle x1="18.6" y1="-5.05" x2="21.55" y2="-0.7" layer="21"/>
<rectangle x1="22.25" y1="0.1" x2="25.2" y2="4.45" layer="21"/>
<rectangle x1="22.25" y1="-5.05" x2="25.2" y2="-0.7" layer="21"/>
<rectangle x1="25.9" y1="0.1" x2="28.85" y2="4.45" layer="21"/>
<rectangle x1="25.9" y1="-5.05" x2="28.85" y2="-0.7" layer="21"/>
<hole x="-37.5" y="-15.5" drill="2.5"/>
<hole x="37.5" y="-15.5" drill="2.5"/>
<hole x="-37.5" y="15.5" drill="2.5"/>
<hole x="37.5" y="15.5" drill="2.5"/>
</package>
</packages>
<packages3d>
<package3d name="TUXGR_16X2_R2" urn="urn:adsk.eagle:package:13139/1" type="box" library_version="2">
<description>Tuxgraphics LCD display 16x2 characters reflective, without background light
<packageinstances>
<packageinstance name="TUXGR_16X2_R2"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="ic-package" urn="urn:adsk.eagle:library:239">
<description>&lt;b&gt;IC Packages an Sockets&lt;/b&gt;&lt;p&gt;
<packages>
<package name="DIL28-3" urn="urn:adsk.eagle:footprint:771/1" library_version="4">
<description>&lt;b&gt;Dual In Line Package Small&lt;/b&gt;</description>
<wire x1="17.78" y1="2.921" x2="-17.78" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-2.921" x2="17.78" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="17.78" y1="2.921" x2="17.78" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="2.921" x2="-17.78" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-2.921" x2="-17.78" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="1.016" x2="-17.78" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-16.51" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-13.97" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="13.97" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="16.51" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="16.51" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="13.97" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="-6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="-8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="-11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="-13.97" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="-16.51" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-18.034" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-8.509" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="DIL28-3" urn="urn:adsk.eagle:package:827/2" type="model" library_version="4">
<description>Dual In Line Package Small</description>
<packageinstances>
<packageinstance name="DIL28-3"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="switch-omron" urn="urn:adsk.eagle:library:377">
<description>&lt;b&gt;Omron Switches&lt;/b&gt;&lt;p&gt;
<packages>
<package name="B3F-10XX" urn="urn:adsk.eagle:footprint:27476/1" library_version="3">
<description>&lt;b&gt;OMRON SWITCH&lt;/b&gt;</description>
<wire x1="3.302" y1="-0.762" x2="3.048" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-0.762" x2="3.302" y2="0.762" width="0.1524" layer="21"/>
<wire x1="3.048" y1="0.762" x2="3.302" y2="0.762" width="0.1524" layer="21"/>
<wire x1="3.048" y1="1.016" x2="3.048" y2="2.54" width="0.1524" layer="51"/>
<wire x1="-3.302" y1="0.762" x2="-3.048" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.762" x2="-3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-0.762" x2="-3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="3.048" y1="2.54" x2="2.54" y2="3.048" width="0.1524" layer="51"/>
<wire x1="2.54" y1="-3.048" x2="3.048" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="3.048" y1="-2.54" x2="3.048" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="3.048" x2="-3.048" y2="2.54" width="0.1524" layer="51"/>
<wire x1="-3.048" y1="2.54" x2="-3.048" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-3.048" x2="-3.048" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="-3.048" y1="-2.54" x2="-3.048" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="-1.27" width="0.0508" layer="51"/>
<wire x1="1.27" y1="-1.27" x2="-1.27" y2="-1.27" width="0.0508" layer="51"/>
<wire x1="1.27" y1="-1.27" x2="1.27" y2="1.27" width="0.0508" layer="51"/>
<wire x1="-1.27" y1="1.27" x2="1.27" y2="1.27" width="0.0508" layer="51"/>
<wire x1="-1.27" y1="3.048" x2="-1.27" y2="2.794" width="0.0508" layer="21"/>
<wire x1="1.27" y1="2.794" x2="-1.27" y2="2.794" width="0.0508" layer="21"/>
<wire x1="1.27" y1="2.794" x2="1.27" y2="3.048" width="0.0508" layer="21"/>
<wire x1="1.143" y1="-2.794" x2="-1.27" y2="-2.794" width="0.0508" layer="21"/>
<wire x1="1.143" y1="-2.794" x2="1.143" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="-1.27" y1="-2.794" x2="-1.27" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="2.54" y1="-3.048" x2="2.159" y2="-3.048" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-3.048" x2="-2.159" y2="-3.048" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="-3.048" x2="-1.27" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="3.048" x2="-2.159" y2="3.048" width="0.1524" layer="51"/>
<wire x1="2.54" y1="3.048" x2="2.159" y2="3.048" width="0.1524" layer="51"/>
<wire x1="2.159" y1="3.048" x2="1.27" y2="3.048" width="0.1524" layer="21"/>
<wire x1="1.27" y1="3.048" x2="-1.27" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="3.048" x2="-2.159" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-3.048" x2="1.143" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-3.048" x2="2.159" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-0.762" x2="3.048" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="3.048" y1="0.762" x2="3.048" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-0.762" x2="-3.048" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="0.762" x2="-3.048" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-2.159" x2="1.27" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="1.27" y1="2.286" x2="-1.27" y2="2.286" width="0.1524" layer="51"/>
<wire x1="-2.413" y1="1.27" x2="-2.413" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-2.413" y1="-0.508" x2="-2.413" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-2.413" y1="0.508" x2="-2.159" y2="-0.381" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="1.778" width="0.1524" layer="21"/>
<circle x="-2.159" y="-2.159" radius="0.508" width="0.1524" layer="51"/>
<circle x="2.159" y="-2.032" radius="0.508" width="0.1524" layer="51"/>
<circle x="2.159" y="2.159" radius="0.508" width="0.1524" layer="51"/>
<circle x="-2.159" y="2.159" radius="0.508" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="0.635" width="0.0508" layer="51"/>
<circle x="0" y="0" radius="0.254" width="0.1524" layer="21"/>
<pad name="1" x="-3.2512" y="2.2606" drill="1.016" shape="long"/>
<pad name="3" x="-3.2512" y="-2.2606" drill="1.016" shape="long"/>
<pad name="2" x="3.2512" y="2.2606" drill="1.016" shape="long"/>
<pad name="4" x="3.2512" y="-2.2606" drill="1.016" shape="long"/>
<text x="-3.048" y="3.683" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.048" y="-5.08" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.318" y="1.651" size="1.27" layer="51" ratio="10">1</text>
<text x="3.556" y="1.524" size="1.27" layer="51" ratio="10">2</text>
<text x="-4.572" y="-2.794" size="1.27" layer="51" ratio="10">3</text>
<text x="3.556" y="-2.794" size="1.27" layer="51" ratio="10">4</text>
</package>
</packages>
<packages3d>
<package3d name="B3F-10XX" urn="urn:adsk.eagle:package:27496/1" type="box" library_version="3">
<description>OMRON SWITCH</description>
<packageinstances>
<packageinstance name="B3F-10XX"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="inductor-neosid" urn="urn:adsk.eagle:library:241">
<description>&lt;b&gt;Neosid Chokes and Transformers&lt;/b&gt;&lt;p&gt;
&lt;ul&gt;
&lt;li&gt;Electronic Component Book, Part 2 : Chokes, Fixed Value Inductors
&lt;li&gt;Part 3 : Filters, Coil Assemblies, Thermoplastic Parts
&lt;li&gt;Part 4 : SMD Filters, Coils, Fixed Value Inductors
&lt;li&gt;www.neosid.de
&lt;/ul&gt;
<packages>
<package name="MS50" urn="urn:adsk.eagle:footprint:14563/1" library_version="3">
<description>SMD &lt;B&gt;POWER INDUCTOR&lt;/B&gt;&lt;p&gt;
high current</description>
<wire x1="-0.9" y1="-2.3" x2="0.9" y2="-2.3" width="0.2032" layer="51"/>
<wire x1="-1.5" y1="1.3" x2="-1.5" y2="-1.3" width="0.2032" layer="51"/>
<wire x1="-1.5" y1="-1.3" x2="-0.7" y2="-1.3" width="0.2032" layer="51"/>
<wire x1="-0.7" y1="-1.3" x2="0.7" y2="-1.3" width="0.2032" layer="51"/>
<wire x1="0.7" y1="-1.3" x2="1.5" y2="-1.3" width="0.2032" layer="51"/>
<wire x1="1.5" y1="-1.3" x2="1.5" y2="1.3" width="0.2032" layer="51"/>
<wire x1="1.5" y1="1.3" x2="0.7" y2="1.3" width="0.2032" layer="51"/>
<wire x1="0.7" y1="1.3" x2="-0.7" y2="1.3" width="0.2032" layer="51"/>
<wire x1="-0.7" y1="1.3" x2="-1.5" y2="1.3" width="0.2032" layer="51"/>
<wire x1="-0.9" y1="-2.3" x2="-0.7" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="0.9" y1="-2.3" x2="0.7" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="0.9" y1="2.3" x2="-0.9" y2="2.3" width="0.2032" layer="51"/>
<wire x1="0.9" y1="2.3" x2="0.7" y2="1.4" width="0.2032" layer="51"/>
<wire x1="-0.9" y1="2.3" x2="-0.7" y2="1.4" width="0.2032" layer="51"/>
<wire x1="-0.7" y1="1.3" x2="-0.7" y2="-1.3" width="0.2032" layer="51" curve="120.036721"/>
<wire x1="0.7" y1="-1.3" x2="0.7" y2="1.3" width="0.2032" layer="51" curve="120.036721"/>
<wire x1="-1.5" y1="0.8" x2="-1.5" y2="-0.8" width="0.2032" layer="21"/>
<wire x1="1.5" y1="0.8" x2="1.5" y2="-0.8" width="0.2032" layer="21"/>
<smd name="1" x="0" y="-1.7" dx="2.8" dy="1.4" layer="1"/>
<smd name="2" x="0" y="1.7" dx="2.8" dy="1.4" layer="1"/>
<text x="-1.8" y="-1.7" size="0.8128" layer="25" rot="R90">&gt;NAME</text>
<text x="2.6" y="-1.7" size="0.8128" layer="27" rot="R90">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="MS50" urn="urn:adsk.eagle:package:14699/1" type="box" library_version="3">
<description>SMD POWER INDUCTOR
<packageinstances>
<packageinstance name="MS50"/>
</packageinstances>
</package3d>
</packages3d>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules name="default *">
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="6mil"/>
<param name="mdWirePad" value="6mil"/>
<param name="mdWireVia" value="6mil"/>
<param name="mdPadPad" value="6mil"/>
<param name="mdPadVia" value="6mil"/>
<param name="mdViaVia" value="6mil"/>
<param name="mdSmdPad" value="6mil"/>
<param name="mdSmdVia" value="6mil"/>
<param name="mdSmdSmd" value="6mil"/>
<param name="mdViaViaSameLayer" value="6mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="6mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="6mil"/>
<param name="msDrill" value="0.35mm"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="22mil"/>
<param name="rlMaxPadTop" value="22mil"/>
<param name="rlMinPadInner" value="22mil"/>
<param name="rlMaxPadInner" value="22mil"/>
<param name="rlMinPadBottom" value="22mil"/>
<param name="rlMaxPadBottom" value="22mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="1"/>
<param name="psBottom" value="1"/>
<param name="psFirst" value="1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="20mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="checkStop" value="0"/>
<param name="checkValues" value="0"/>
<param name="checkNames" value="1"/>
<param name="checkWireStubs" value="1"/>
<param name="checkPolygonWidth" value="0"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="AutoGrid" value="1"/>
<param name="Efforts" value="0"/>
<param name="TopRouterVariant" value="1"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="a"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="a"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="C1" library="rcl" library_urn="urn:adsk.eagle:library:334" package="E2,5-7" package3d_urn="urn:adsk.eagle:package:23345/1" value="47uF" x="12.7" y="11.7475" smashed="yes" rot="R90">
<attribute name="NAME" x="10.668" y="14.7955" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="POPULARITY" value="17" x="106.68" y="71.4375" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="106.68" y="71.4375" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="15.0495" y="16.8275" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C2" library="rcl" library_urn="urn:adsk.eagle:library:334" package="E2,5-7" package3d_urn="urn:adsk.eagle:package:23345/1" value="47uF" x="7.3025" y="33.655" smashed="yes">
<attribute name="NAME" x="10.3505" y="35.687" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="17" x="77.1525" y="-60.325" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="77.1525" y="-60.325" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="3.3655" y="37.465" size="1.27" layer="27" ratio="10"/>
</element>
<element name="C3" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C050-030X075" package3d_urn="urn:adsk.eagle:package:23640/1" value="1n" x="57.4675" y="41.91" smashed="yes" rot="R90">
<attribute name="NAME" x="55.5625" y="38.354" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="POPULARITY" value="9" x="157.7975" y="138.43" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="157.7975" y="138.43" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="58.4835" y="47.498" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C4" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C050-030X075" package3d_urn="urn:adsk.eagle:package:23640/1" value="1n" x="58.1025" y="29.21" smashed="yes" rot="R90">
<attribute name="NAME" x="56.1975" y="25.654" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="POPULARITY" value="9" x="158.4325" y="134.62" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="158.4325" y="134.62" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="59.1185" y="34.798" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="D1" library="diode" library_urn="urn:adsk.eagle:library:210" package="DO35-10" package3d_urn="urn:adsk.eagle:package:43344/2" value="1N4148" x="65.7225" y="36.83" smashed="yes" rot="R90">
<attribute name="NAME" x="64.4525" y="34.671" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="POPULARITY" value="21" x="167.3225" y="104.14" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="63.246" y="43.053" size="1.27" layer="27" ratio="10"/>
</element>
<element name="D2" library="diode" library_urn="urn:adsk.eagle:library:210" package="DO27-15" package3d_urn="urn:adsk.eagle:package:43337/3" value="SB560" x="87.63" y="64.77" smashed="yes" rot="R270">
<attribute name="NAME" x="91.059" y="72.009" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="POPULARITY" value="0" x="6.35" y="11.43" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="86.9315" y="61.214" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="D3" library="diode" library_urn="urn:adsk.eagle:library:210" package="DO41-10" package3d_urn="urn:adsk.eagle:package:43336/1" value="1N4001" x="6.0325" y="20.32" smashed="yes" rot="R270">
<attribute name="NAME" x="9.2075" y="25.4" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="POPULARITY" value="82" x="-86.6775" y="-2.54" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="2.921" y="22.86" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="D4" library="diode" library_urn="urn:adsk.eagle:library:210" package="DO41-10" package3d_urn="urn:adsk.eagle:package:43336/1" value="1N4001" x="10.4775" y="24.13" smashed="yes" rot="R90">
<attribute name="NAME" x="7.3025" y="19.05" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="POPULARITY" value="82" x="103.1875" y="67.31" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="8.8265" y="23.1775" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="D5" library="diode" library_urn="urn:adsk.eagle:library:210" package="CB429-15" package3d_urn="urn:adsk.eagle:package:43338/2" value="1N4002" x="80.3275" y="60.325" smashed="yes" rot="R270">
<attribute name="NAME" x="83.7565" y="67.564" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="POPULARITY" value="0" x="-0.9525" y="-18.415" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="79.3115" y="56.4515" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="D6" library="diode" library_urn="urn:adsk.eagle:library:210" package="F126Z12" package3d_urn="urn:adsk.eagle:package:43358/1" value="BY500" x="74.295" y="59.055" smashed="yes" rot="R270">
<attribute name="NAME" x="77.724" y="66.294" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="POPULARITY" value="0" x="-6.985" y="-45.085" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="72.009" y="67.3735" size="1.27" layer="27" ratio="10"/>
</element>
<element name="IC1" library="linear" library_urn="urn:adsk.eagle:library:262" package="DIL14" package3d_urn="urn:adsk.eagle:package:16407/2" value="LM324N" x="49.8475" y="35.56" smashed="yes" rot="R270">
<attribute name="NAME" x="46.7995" y="44.831" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="9" x="-21.2725" y="-6.35" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="49.2125" y="39.116" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="LED1" library="led" library_urn="urn:adsk.eagle:library:259" package="LED5MM" package3d_urn="urn:adsk.eagle:package:15799/2" value="" x="49.2125" y="10.795" smashed="yes" rot="R180">
<attribute name="NAME" x="46.0375" y="10.2616" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="POPULARITY" value="93" x="-49.8475" y="104.775" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="46.0121" y="12.5984" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R1" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="820" x="37.1475" y="38.1" smashed="yes" rot="R90">
<attribute name="NAME" x="35.6235" y="35.052" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="POPULARITY" value="81" x="143.8275" y="57.15" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="143.8275" y="57.15" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="37.7825" y="36.7919" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="R10" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="4.7k" x="65.7225" y="24.13" smashed="yes" rot="R270">
<attribute name="NAME" x="67.2465" y="27.178" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="POPULARITY" value="81" x="-46.0375" y="-7.62" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="-46.0375" y="-7.62" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="65.0875" y="25.7556" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R11" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="47k" x="70.8025" y="36.83" smashed="yes" rot="R270">
<attribute name="NAME" x="72.3265" y="39.878" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="POPULARITY" value="81" x="-40.9575" y="-7.62" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="-40.9575" y="-7.62" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="70.1675" y="38.4556" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R12" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="1k" x="61.9125" y="36.83" smashed="yes" rot="R90">
<attribute name="NAME" x="60.3885" y="33.782" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="POPULARITY" value="81" x="173.6725" y="93.98" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="173.6725" y="93.98" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="62.5475" y="36.1569" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="R13" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="120k" x="19.3675" y="30.48" smashed="yes" rot="R270">
<attribute name="NAME" x="20.8915" y="33.528" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="POPULARITY" value="81" x="-92.3925" y="-39.37" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="-92.3925" y="-39.37" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="18.7325" y="32.4231" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R14" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="18k" x="51.7525" y="22.86" smashed="yes">
<attribute name="NAME" x="48.7045" y="24.384" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="81" x="134.3025" y="-88.9" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="134.3025" y="-88.9" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="50.4444" y="22.225" size="1.27" layer="27" ratio="10"/>
</element>
<element name="R15" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="1k" x="61.9125" y="24.13" smashed="yes" rot="R90">
<attribute name="NAME" x="60.3885" y="21.082" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="POPULARITY" value="81" x="173.6725" y="119.38" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="173.6725" y="119.38" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="62.5475" y="23.1394" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="R16" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="1k" x="45.085" y="51.435" smashed="yes">
<attribute name="NAME" x="42.037" y="52.959" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="81" x="153.035" y="-60.325" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="153.035" y="-60.325" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="44.0944" y="50.8" size="1.27" layer="27" ratio="10"/>
</element>
<element name="R17" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="1k" x="34.6075" y="56.515" smashed="yes" rot="R270">
<attribute name="NAME" x="36.1315" y="59.563" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="POPULARITY" value="81" x="-82.2325" y="37.465" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="-82.2325" y="37.465" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="33.9725" y="57.1881" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R18" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="120k" x="68.2625" y="46.355" smashed="yes">
<attribute name="NAME" x="65.2145" y="47.879" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="81" x="100.0125" y="-70.485" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="100.0125" y="-70.485" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="66.0019" y="45.72" size="1.27" layer="27" ratio="10"/>
</element>
<element name="R19" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="2.2k" x="40.64" y="69.215" smashed="yes" rot="R270">
<attribute name="NAME" x="42.164" y="72.263" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="POPULARITY" value="81" x="-76.2" y="24.765" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="-76.2" y="24.765" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="40.005" y="71.1581" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R2" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="2.2k" x="23.8125" y="30.48" smashed="yes" rot="R270">
<attribute name="NAME" x="25.3365" y="33.528" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="POPULARITY" value="81" x="-82.8675" y="-1.27" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="-82.8675" y="-1.27" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="23.1775" y="32.1056" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R20" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="1.5k" x="20.6375" y="59.055" smashed="yes">
<attribute name="NAME" x="17.5895" y="60.579" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="81" x="77.7875" y="-57.785" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="77.7875" y="-57.785" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="18.3769" y="58.42" size="1.27" layer="27" ratio="10"/>
</element>
<element name="R21" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="3.3k" x="43.815" y="59.055" smashed="yes">
<attribute name="NAME" x="43.307" y="60.579" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="81" x="113.665" y="-57.785" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="113.665" y="-57.785" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="42.1894" y="58.42" size="1.27" layer="27" ratio="10"/>
</element>
<element name="R29" library="rcl" library_urn="urn:adsk.eagle:library:334" package="P0613/15" package3d_urn="urn:adsk.eagle:package:23581/2" value="0.68" x="87.9475" y="40.3225" smashed="yes" rot="R180">
<attribute name="NAME" x="98.1075" y="35.2171" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="POPULARITY" value="0" x="11.7475" y="72.0725" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="11.7475" y="72.0725" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="89.9795" y="40.9067" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R3" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="10k" x="51.7525" y="19.05" smashed="yes" rot="R180">
<attribute name="NAME" x="54.8005" y="17.526" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="POPULARITY" value="81" x="7.3025" y="125.73" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="7.3025" y="125.73" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="53.3781" y="19.685" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R30" library="rcl" library_urn="urn:adsk.eagle:library:334" package="P0613/15" package3d_urn="urn:adsk.eagle:package:23581/2" value="0.68" x="87.9475" y="34.29" smashed="yes" rot="R180">
<attribute name="NAME" x="98.1075" y="29.1846" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="POPULARITY" value="0" x="-13.6525" y="66.04" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="-13.6525" y="66.04" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="90.297" y="34.8742" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R31" library="rcl" library_urn="urn:adsk.eagle:library:334" package="P0613/15" package3d_urn="urn:adsk.eagle:package:23581/2" value="0.68" x="87.9475" y="27.94" smashed="yes" rot="R180">
<attribute name="NAME" x="98.1075" y="22.8346" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="POPULARITY" value="0" x="62.5475" y="86.36" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="62.5475" y="86.36" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="90.297" y="28.5242" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R32" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="100" x="48.895" y="66.675" smashed="yes" rot="R270">
<attribute name="NAME" x="50.419" y="69.723" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="POPULARITY" value="81" x="-73.025" y="-3.175" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="-73.025" y="-3.175" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="48.26" y="67.9831" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R36" library="rcl" library_urn="urn:adsk.eagle:library:334" package="RTRIM64W" package3d_urn="urn:adsk.eagle:package:23748/1" value="5k" x="76.2" y="23.495" smashed="yes" rot="R180">
<attribute name="NAME" x="78.82" y="28.445" size="1.27" layer="25" rot="R270"/>
<attribute name="POPULARITY" value="0" x="48.26" y="107.315" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="SPICEMODEL" value="X" x="48.26" y="107.315" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="SPICEPREFIXL" value="POT" x="48.26" y="107.315" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="75.3775" y="28.67" size="1.27" layer="27"/>
</element>
<element name="R37" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="22k" x="33.02" y="38.4175" smashed="yes" rot="R270">
<attribute name="NAME" x="34.544" y="41.4655" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="POPULARITY" value="81" x="-88.9" y="-44.1325" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="-88.9" y="-44.1325" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="32.385" y="39.7256" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R38" library="rcl" library_urn="urn:adsk.eagle:library:334" package="RTRIM64W" package3d_urn="urn:adsk.eagle:package:23748/1" value="50k" x="23.1775" y="18.415" smashed="yes" rot="R180">
<attribute name="NAME" x="25.7975" y="23.365" size="1.27" layer="25" rot="R270"/>
<attribute name="POPULARITY" value="0" x="-12.3825" y="102.235" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="SPICEMODEL" value="X" x="-12.3825" y="102.235" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="SPICEPREFIXL" value="POT" x="-12.3825" y="102.235" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="17.5925" y="18.8275" size="1.27" layer="27"/>
</element>
<element name="R39" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="75" x="17.78" y="5.715" smashed="yes">
<attribute name="NAME" x="14.732" y="7.239" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="81" x="113.03" y="-116.205" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="113.03" y="-116.205" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="16.7894" y="5.08" size="1.27" layer="27" ratio="10"/>
</element>
<element name="R4" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="5.6k" x="23.8125" y="43.815" smashed="yes" rot="R270">
<attribute name="NAME" x="25.3365" y="46.863" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="POPULARITY" value="81" x="-82.8675" y="-13.335" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="-82.8675" y="-13.335" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="23.1775" y="45.4406" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R40" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="3.3k" x="14.2875" y="38.735" smashed="yes">
<attribute name="NAME" x="11.2395" y="40.259" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="81" x="122.2375" y="-83.185" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="122.2375" y="-83.185" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="12.0269" y="38.1" size="1.27" layer="27" ratio="10"/>
</element>
<element name="R5" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="47k" x="41.5925" y="38.1" smashed="yes" rot="R270">
<attribute name="NAME" x="43.1165" y="41.148" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="POPULARITY" value="81" x="-65.0875" y="-31.75" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="-65.0875" y="-31.75" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="40.9575" y="39.4081" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R6" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="3.9k" x="41.5925" y="24.13" smashed="yes" rot="R90">
<attribute name="NAME" x="40.0685" y="21.082" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="POPULARITY" value="81" x="148.2725" y="106.68" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="148.2725" y="106.68" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="42.2275" y="22.1869" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="R7" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="12k" x="37.1475" y="24.13" smashed="yes" rot="R90">
<attribute name="NAME" x="35.6235" y="21.082" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="POPULARITY" value="81" x="143.8275" y="119.38" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="143.8275" y="119.38" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="37.7825" y="22.5044" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="R8" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="47k" x="28.2575" y="16.51" smashed="yes" rot="R90">
<attribute name="NAME" x="26.7335" y="13.462" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="POPULARITY" value="81" x="134.9375" y="124.46" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="134.9375" y="124.46" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="28.8925" y="15.2019" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="R9" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="4.7k" x="70.8025" y="24.13" smashed="yes" rot="R270">
<attribute name="NAME" x="72.3265" y="27.178" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="POPULARITY" value="81" x="-40.9575" y="5.08" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="-40.9575" y="5.08" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="70.1675" y="25.7556" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="T1" library="transistor" library_urn="urn:adsk.eagle:library:402" package="TO92L" package3d_urn="urn:adsk.eagle:package:29918/1" value="BC337" x="29.21" y="61.595" smashed="yes">
<attribute name="NAME" x="26.67" y="66.675" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="0" x="46.99" y="-9.525" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="21.59" y="62.5475" size="1.27" layer="27" ratio="10"/>
</element>
<element name="T2" library="transistor-pnp" library_urn="urn:adsk.eagle:library:399" package="TO220" package3d_urn="urn:adsk.eagle:package:29212/1" value="BD244" x="28.2575" y="71.755" smashed="yes" rot="R90">
<attribute name="NAME" x="23.0505" y="67.945" size="1.778" layer="25" ratio="10" rot="R90"/>
<attribute name="POPULARITY" value="0" x="63.8175" y="130.175" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="25.7175" y="67.818" size="1.778" layer="27" ratio="10" rot="R90"/>
</element>
<element name="T6" library="transistor" library_urn="urn:adsk.eagle:library:402" package="TO92L" package3d_urn="urn:adsk.eagle:package:29918/1" value="BC337" x="14.2875" y="50.165" smashed="yes" rot="R270">
<attribute name="NAME" x="19.3675" y="52.705" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="POPULARITY" value="0" x="-56.8325" y="22.225" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="11.7475" y="52.705" size="1.27" layer="27" ratio="10"/>
</element>
<element name="X1" library="con-ptr500" library_urn="urn:adsk.eagle:library:181" package="AK500/2" package3d_urn="urn:adsk.eagle:package:9880/1" value="" x="87.63" y="49.53" smashed="yes" rot="R90">
<attribute name="MF" value="" x="157.48" y="140.97" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="" x="157.48" y="140.97" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="NAME" x="83.185" y="44.45" size="1.778" layer="25" ratio="10" rot="R90"/>
<attribute name="OC_FARNELL" value="unknown" x="157.48" y="140.97" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="157.48" y="140.97" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="POPULARITY" value="14" x="157.48" y="140.97" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="93.345" y="44.45" size="1.778" layer="27" ratio="10" rot="R90"/>
</element>
<element name="X3" library="con-ptr500" library_urn="urn:adsk.eagle:library:181" package="AK500/3" package3d_urn="urn:adsk.eagle:package:9883/1" value="" x="86.995" y="16.51" smashed="yes" rot="R270">
<attribute name="MF" value="" x="17.145" y="-60.96" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MPN" value="" x="17.145" y="-60.96" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="NAME" x="91.44" y="24.1046" size="1.778" layer="25" ratio="10" rot="R270"/>
<attribute name="OC_FARNELL" value="unknown" x="17.145" y="-60.96" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="17.145" y="-60.96" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="POPULARITY" value="3" x="17.145" y="-60.96" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="81.28" y="24.1046" size="1.778" layer="27" ratio="10" rot="R270"/>
</element>
<element name="Z1" library="diode" library_urn="urn:adsk.eagle:library:210" package="SOD81" package3d_urn="urn:adsk.eagle:package:43363/2" value="6.8ZV" x="28.2575" y="30.48" smashed="yes" rot="R270">
<attribute name="NAME" x="29.6545" y="32.512" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="POPULARITY" value="1" x="-73.3425" y="10.16" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="25.4635" y="32.512" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="Z2" library="diode" library_urn="urn:adsk.eagle:library:210" package="SOD81" package3d_urn="urn:adsk.eagle:package:43363/2" value="5.1ZV" x="14.9225" y="30.48" smashed="yes" rot="R90">
<attribute name="NAME" x="13.5255" y="28.448" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="POPULARITY" value="1" x="116.5225" y="64.77" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="13.2715" y="29.718" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="Z3" library="diode" library_urn="urn:adsk.eagle:library:210" package="SOD81" package3d_urn="urn:adsk.eagle:package:43363/2" value="24ZV" x="33.3375" y="24.13" smashed="yes" rot="R270">
<attribute name="NAME" x="34.7345" y="26.162" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="POPULARITY" value="1" x="-68.2625" y="-24.13" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="30.5435" y="26.162" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="C5" library="rcl" library_urn="urn:adsk.eagle:library:334" package="E2,5-7" package3d_urn="urn:adsk.eagle:package:23345/1" value="4.7uF" x="78.4225" y="46.355" smashed="yes">
<attribute name="NAME" x="81.4705" y="48.387" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="17" x="78.4225" y="46.355" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="78.4225" y="46.355" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="72.263" y="49.2125" size="1.27" layer="27" ratio="10"/>
</element>
<element name="R42" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="470k" x="70.8025" y="10.795" smashed="yes" rot="R270">
<attribute name="NAME" x="72.3265" y="13.843" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="POPULARITY" value="81" x="70.8025" y="10.795" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="70.8025" y="10.795" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="70.1675" y="13.0556" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R43" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="470k" x="33.3375" y="10.795" smashed="yes" rot="R90">
<attribute name="NAME" x="31.8135" y="7.747" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="POPULARITY" value="81" x="33.3375" y="10.795" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="33.3375" y="10.795" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="33.9725" y="8.5344" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="X4" library="con-molex" library_urn="urn:adsk.eagle:library:165" package="22-23-2031" package3d_urn="urn:adsk.eagle:package:8078634/1" value="22-23-2031" x="75.8825" y="10.795" smashed="yes" rot="R270">
<attribute name="MF" value="MOLEX" x="75.8825" y="10.795" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MPN" value="22-23-2031" x="75.8825" y="10.795" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="NAME" x="79.6925" y="14.605" size="1.016" layer="25" ratio="10" rot="R270"/>
<attribute name="OC_FARNELL" value="1462950" x="75.8825" y="10.795" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_NEWARK" value="30C0862" x="75.8825" y="10.795" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="POPULARITY" value="35" x="75.8825" y="10.795" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="73.025" y="15.24" size="1.016" layer="27" ratio="10"/>
</element>
<element name="R33" library="rcl" library_urn="urn:adsk.eagle:library:334" package="P0613/15" package3d_urn="urn:adsk.eagle:package:23581/2" value="0-22" x="57.15" y="60.325" smashed="yes" rot="R90">
<attribute name="NAME" x="54.4576" y="53.848" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="POPULARITY" value="0" x="57.15" y="60.325" size="2.54" layer="27" font="vector" ratio="20" rot="R90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="57.15" y="60.325" size="2.54" layer="27" font="vector" ratio="20" rot="R90" display="off"/>
<attribute name="VALUE" x="58.928" y="61.9887" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R34" library="rcl" library_urn="urn:adsk.eagle:library:334" package="P0613/15" package3d_urn="urn:adsk.eagle:package:23581/2" value="0.22" x="63.1825" y="60.325" smashed="yes" rot="R90">
<attribute name="NAME" x="60.4901" y="53.848" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="POPULARITY" value="0" x="63.1825" y="60.325" size="2.54" layer="27" font="vector" ratio="20" rot="R90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="63.1825" y="60.325" size="2.54" layer="27" font="vector" ratio="20" rot="R90" display="off"/>
<attribute name="VALUE" x="64.9605" y="61.9887" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R35" library="rcl" library_urn="urn:adsk.eagle:library:334" package="P0613/15" package3d_urn="urn:adsk.eagle:package:23581/2" value="0.22" x="69.215" y="60.325" smashed="yes" rot="R90">
<attribute name="NAME" x="66.5226" y="53.848" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="POPULARITY" value="0" x="69.215" y="60.325" size="2.54" layer="27" font="vector" ratio="20" rot="R90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="69.215" y="60.325" size="2.54" layer="27" font="vector" ratio="20" rot="R90" display="off"/>
<attribute name="VALUE" x="70.993" y="61.9887" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="X5" library="con-ptr500" library_urn="urn:adsk.eagle:library:181" package="AK500/5" package3d_urn="urn:adsk.eagle:package:9890/1" value="" x="66.9925" y="73.025" smashed="yes">
<attribute name="MF" value="" x="66.9925" y="73.025" size="2.54" layer="27" font="vector" ratio="20" display="off"/>
<attribute name="MPN" value="" x="66.9925" y="73.025" size="2.54" layer="27" font="vector" ratio="20" display="off"/>
<attribute name="NAME" x="54.3941" y="77.47" size="1.778" layer="25" ratio="10"/>
<attribute name="OC_FARNELL" value="unknown" x="66.9925" y="73.025" size="2.54" layer="27" font="vector" ratio="20" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="66.9925" y="73.025" size="2.54" layer="27" font="vector" ratio="20" display="off"/>
<attribute name="POPULARITY" value="1" x="66.9925" y="73.025" size="2.54" layer="27" font="vector" ratio="20" display="off"/>
<attribute name="VALUE" x="54.3941" y="67.31" size="1.778" layer="27" ratio="10"/>
</element>
<element name="X2" library="con-molex" library_urn="urn:adsk.eagle:library:165" package="22-23-2031" package3d_urn="urn:adsk.eagle:package:8078634/1" value="10k Amper" x="40.9575" y="10.795" smashed="yes" rot="R180">
<attribute name="MF" value="MOLEX" x="40.9575" y="10.795" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="22-23-2031" x="40.9575" y="10.795" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="44.7675" y="6.985" size="1.016" layer="25" ratio="10" rot="R180"/>
<attribute name="OC_FARNELL" value="1462950" x="40.9575" y="10.795" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_NEWARK" value="30C0862" x="40.9575" y="10.795" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="POPULARITY" value="35" x="40.9575" y="10.795" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="44.7675" y="15.875" size="1.016" layer="27" ratio="10" rot="R180"/>
</element>
<element name="X6" library="con-molex" library_urn="urn:adsk.eagle:library:165" package="22-23-2031" package3d_urn="urn:adsk.eagle:package:8078634/1" value="10k Volt" x="64.4525" y="10.795" smashed="yes" rot="R180">
<attribute name="MF" value="MOLEX" x="64.4525" y="10.795" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="22-23-2031" x="64.4525" y="10.795" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="68.2625" y="6.985" size="1.016" layer="25" ratio="10" rot="R180"/>
<attribute name="OC_FARNELL" value="1462950" x="64.4525" y="10.795" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_NEWARK" value="30C0862" x="64.4525" y="10.795" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="POPULARITY" value="35" x="64.4525" y="10.795" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="68.2625" y="15.875" size="1.016" layer="27" ratio="10" rot="R180"/>
</element>
<element name="X7" library="con-molex" library_urn="urn:adsk.eagle:library:165" package="22-23-2021" package3d_urn="urn:adsk.eagle:package:8078633/1" value="DC ON-OFF" x="56.1975" y="10.795" smashed="yes" rot="R180">
<attribute name="MF" value="MOLEX" x="56.1975" y="10.795" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="22-23-2021" x="56.1975" y="10.795" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="58.7375" y="6.985" size="1.016" layer="25" ratio="10" rot="R180"/>
<attribute name="OC_FARNELL" value="1462926" x="56.1975" y="10.795" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_NEWARK" value="25C3832" x="56.1975" y="10.795" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="POPULARITY" value="40" x="56.1975" y="10.795" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="58.7375" y="15.875" size="1.016" layer="27" ratio="10" rot="R180"/>
</element>
<element name="X8" library="con-molex" library_urn="urn:adsk.eagle:library:165" package="22-23-2021" package3d_urn="urn:adsk.eagle:package:8078633/1" value="22-23-2021" x="49.2125" y="10.795" smashed="yes" rot="R180">
<attribute name="MF" value="MOLEX" x="49.2125" y="10.795" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="22-23-2021" x="49.2125" y="10.795" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="51.7525" y="6.985" size="1.016" layer="25" ratio="10" rot="R180"/>
<attribute name="OC_FARNELL" value="1462926" x="49.2125" y="10.795" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_NEWARK" value="25C3832" x="49.2125" y="10.795" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="POPULARITY" value="40" x="49.2125" y="10.795" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="51.7525" y="15.875" size="1.016" layer="27" ratio="10" rot="R180"/>
</element>
<element name="D7" library="diode" library_urn="urn:adsk.eagle:library:210" package="DO35-10" package3d_urn="urn:adsk.eagle:package:43344/2" value="1N4148DO35-10" x="9.525" y="138.43" smashed="yes" rot="R90">
<attribute name="NAME" x="8.255" y="136.271" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="POPULARITY" value="21" x="37.465" y="176.53" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="12.827" y="131.826" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="IC2" library="linear" library_urn="urn:adsk.eagle:library:262" package="DIL08" package3d_urn="urn:adsk.eagle:package:16409/2" value="LM358N" x="33.02" y="113.03" smashed="yes">
<attribute name="NAME" x="27.686" y="110.109" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="POPULARITY" value="7" x="52.07" y="93.98" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="29.464" y="112.395" size="1.27" layer="27" ratio="10"/>
</element>
<element name="Q1" library="transistor-small-signal" library_urn="urn:adsk.eagle:library:401" package="SOT23" package3d_urn="urn:adsk.eagle:package:28738/2" value="BSS123" x="9.8425" y="114.3" smashed="yes" rot="MR270">
<attribute name="NAME" x="7.9375" y="116.205" size="1.27" layer="26" rot="MR270"/>
<attribute name="POPULARITY" value="21" x="28.8925" y="74.93" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="VALUE" x="13.0175" y="116.205" size="1.27" layer="28" rot="MR270"/>
</element>
<element name="Q2" library="transistor-npn" library_urn="urn:adsk.eagle:library:398" package="TO92-EBC" package3d_urn="urn:adsk.eagle:package:28989/2" value="S8050" x="6.985" y="145.415" smashed="yes" rot="R180">
<attribute name="NAME" x="9.525" y="143.637" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="POPULARITY" value="0" x="-23.495" y="165.735" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="9.525" y="149.987" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R22" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="5.6k" x="9.8425" y="113.03" smashed="yes" rot="R180">
<attribute name="NAME" x="11.1125" y="111.76" size="1.27" layer="25" rot="R180"/>
<attribute name="POPULARITY" value="81" x="-25.7175" y="147.32" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="-25.7175" y="147.32" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="11.43" y="113.665" size="1.27" layer="27" rot="R180"/>
</element>
<element name="R44" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="150" x="37.465" y="120.65" smashed="yes">
<attribute name="NAME" x="36.195" y="121.92" size="1.27" layer="25"/>
<attribute name="POPULARITY" value="81" x="79.375" y="80.01" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="79.375" y="80.01" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="35.2425" y="121.285" size="1.27" layer="27"/>
</element>
<element name="R45" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1206" package3d_urn="urn:adsk.eagle:package:23566/2" value="100k" x="41.5925" y="116.84" smashed="yes" rot="MR0">
<attribute name="NAME" x="42.8625" y="118.11" size="1.27" layer="26" rot="MR0"/>
<attribute name="POPULARITY" value="17" x="12.3825" y="82.55" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="12.3825" y="82.55" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="VALUE" x="43.18" y="116.205" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="R46" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1206" package3d_urn="urn:adsk.eagle:package:23566/2" value="1.2k" x="41.5925" y="113.3475" smashed="yes" rot="MR180">
<attribute name="NAME" x="40.3225" y="112.0775" size="1.27" layer="26" rot="MR180"/>
<attribute name="POPULARITY" value="17" x="58.1025" y="153.9875" size="1.778" layer="28" rot="MR180" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="58.1025" y="153.9875" size="1.778" layer="28" rot="MR180" display="off"/>
<attribute name="VALUE" x="40.005" y="113.9825" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="R23" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="9.1k" x="12.065" y="109.22" smashed="yes">
<attribute name="NAME" x="10.795" y="110.49" size="1.27" layer="25"/>
<attribute name="POPULARITY" value="81" x="53.975" y="74.93" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="53.975" y="74.93" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="10.4775" y="108.585" size="1.27" layer="27"/>
</element>
<element name="R24" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="910" x="12.065" y="106.3625" smashed="yes" rot="R180">
<attribute name="NAME" x="13.97" y="106.3625" size="1.27" layer="25" rot="R180"/>
<attribute name="POPULARITY" value="81" x="-9.525" y="147.0025" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="-9.525" y="147.0025" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="10.16" y="105.7275" size="1.27" layer="27"/>
</element>
<element name="R25" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="150" x="20.0025" y="114.3" smashed="yes" rot="R270">
<attribute name="NAME" x="21.2725" y="115.57" size="1.27" layer="25" rot="R270"/>
<attribute name="POPULARITY" value="81" x="-20.6375" y="87.63" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="-20.6375" y="87.63" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="20.6375" y="113.03" size="1.27" layer="27" rot="R90"/>
</element>
<element name="R26" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="100k" x="39.37" y="106.3625" smashed="yes">
<attribute name="NAME" x="38.1" y="107.6325" size="1.27" layer="25"/>
<attribute name="POPULARITY" value="81" x="55.88" y="72.0725" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="55.88" y="72.0725" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="37.7825" y="105.7275" size="1.27" layer="27"/>
</element>
<element name="R27" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="1k" x="23.8125" y="114.3" smashed="yes" rot="R270">
<attribute name="NAME" x="25.4" y="115.2525" size="1.27" layer="25" rot="R270"/>
<attribute name="POPULARITY" value="81" x="-16.8275" y="82.55" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="-16.8275" y="82.55" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="23.1775" y="115.57" size="1.27" layer="27" rot="R270"/>
</element>
<element name="R28" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="10k" x="4.445" y="135.89" smashed="yes" rot="R90">
<attribute name="NAME" x="3.175" y="134.62" size="1.27" layer="25" rot="R90"/>
<attribute name="POPULARITY" value="81" x="45.085" y="172.72" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="45.085" y="172.72" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="5.08" y="134.62" size="1.27" layer="27" rot="R90"/>
</element>
<element name="R41" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/2" value="120k" x="12.3825" y="128.27" smashed="yes" rot="R90">
<attribute name="NAME" x="11.1125" y="127" size="1.27" layer="25" rot="R90"/>
<attribute name="POPULARITY" value="81" x="46.6725" y="151.13" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="46.6725" y="151.13" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="13.0175" y="126.6825" size="1.27" layer="27" rot="R90"/>
</element>
<element name="JP1" library="jumper" library_urn="urn:adsk.eagle:library:252" package="JP2" package3d_urn="urn:adsk.eagle:package:15452/1" value="" x="30.48" y="97.4725" smashed="yes" rot="R90">
<attribute name="NAME" x="28.829" y="93.9165" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="POPULARITY" value="34" x="30.48" y="97.4725" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="34.798" y="93.9165" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="LSP1" library="solpad" library_urn="urn:adsk.eagle:library:364" package="LSP10" package3d_urn="urn:adsk.eagle:package:26501/1" value="LSP10" x="47.3075" y="106.3625" smashed="yes">
<attribute name="NAME" x="46.0375" y="107.6325" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="52" x="47.3075" y="106.3625" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="47.9425" y="106.6165" size="0.0254" layer="27"/>
</element>
<element name="LSP2" library="solpad" library_urn="urn:adsk.eagle:library:364" package="LSP10" package3d_urn="urn:adsk.eagle:package:26501/1" value="LSP10" x="45.72" y="116.84" smashed="yes">
<attribute name="NAME" x="44.45" y="118.11" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="52" x="45.72" y="116.84" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="45.085" y="116.1415" size="0.0254" layer="27"/>
</element>
<element name="U$1" library="SIF422-relé" package="SIF422" value="SIF422" x="40.64" y="139.3825" smashed="yes" rot="R180"/>
<element name="Q3" library="transistor-small-signal" library_urn="urn:adsk.eagle:library:401" package="SOT23" package3d_urn="urn:adsk.eagle:package:28738/2" value="BSS123" x="61.595" y="106.045" smashed="yes" rot="MR270">
<attribute name="NAME" x="59.69" y="107.95" size="1.27" layer="26" rot="MR270"/>
<attribute name="POPULARITY" value="21" x="61.595" y="106.045" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="VALUE" x="64.77" y="107.95" size="1.27" layer="28" rot="MR270"/>
</element>
<element name="R47" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1206" package3d_urn="urn:adsk.eagle:package:23566/2" value="150" x="64.135" y="109.855" smashed="yes" rot="MR0">
<attribute name="NAME" x="67.183" y="111.379" size="1.27" layer="26" ratio="10" rot="MR0"/>
<attribute name="POPULARITY" value="17" x="64.135" y="109.855" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="64.135" y="109.855" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="VALUE" x="66.3956" y="109.22" size="1.27" layer="28" ratio="10" rot="MR0"/>
</element>
<element name="LSP3" library="solpad" library_urn="urn:adsk.eagle:library:364" package="LSP10" package3d_urn="urn:adsk.eagle:package:26501/1" value="LSP10" x="67.945" y="107.315" smashed="yes">
<attribute name="NAME" x="66.675" y="108.585" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="52" x="67.945" y="107.315" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="67.945" y="107.569" size="0.0254" layer="27"/>
</element>
<element name="X9" library="con-molex" library_urn="urn:adsk.eagle:library:165" package="22-23-2021" package3d_urn="urn:adsk.eagle:package:8078633/1" value="22-23-2021" x="51.435" y="113.3475" smashed="yes" rot="R180">
<attribute name="MF" value="MOLEX" x="51.435" y="113.3475" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="22-23-2021" x="51.435" y="113.3475" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="53.975" y="109.5375" size="1.016" layer="25" ratio="10" rot="R180"/>
<attribute name="OC_FARNELL" value="1462926" x="51.435" y="113.3475" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_NEWARK" value="25C3832" x="51.435" y="113.3475" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="POPULARITY" value="40" x="51.435" y="113.3475" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="53.975" y="118.4275" size="1.016" layer="27" ratio="10" rot="R180"/>
</element>
<element name="X10" library="con-molex" library_urn="urn:adsk.eagle:library:165" package="22-23-2021" package3d_urn="urn:adsk.eagle:package:8078633/1" value="22-23-2021" x="56.8325" y="110.8075" smashed="yes" rot="R180">
<attribute name="MF" value="MOLEX" x="56.8325" y="110.8075" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="22-23-2021" x="56.8325" y="110.8075" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="59.3725" y="106.9975" size="1.016" layer="25" ratio="10" rot="R180"/>
<attribute name="OC_FARNELL" value="1462926" x="56.8325" y="110.8075" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_NEWARK" value="25C3832" x="56.8325" y="110.8075" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="POPULARITY" value="40" x="56.8325" y="110.8075" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="59.3725" y="115.8875" size="1.016" layer="27" ratio="10" rot="R180"/>
</element>
<element name="JP2" library="jumper" library_urn="urn:adsk.eagle:library:252" package="JP1" package3d_urn="urn:adsk.eagle:package:15455/1" value="" x="56.8325" y="106.045" smashed="yes" rot="R270">
<attribute name="NAME" x="54.2925" y="107.696" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="61" x="56.8325" y="106.045" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="54.2925" y="103.124" size="1.27" layer="27" ratio="10"/>
</element>
<element name="LED2" library="led" library_urn="urn:adsk.eagle:library:259" package="LED5MM" package3d_urn="urn:adsk.eagle:package:15799/2" value="" x="51.435" y="113.3475" smashed="yes">
<attribute name="NAME" x="54.61" y="113.8809" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="93" x="51.435" y="113.3475" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="54.6354" y="111.5441" size="1.27" layer="27" ratio="10"/>
</element>
<element name="X11" library="con-rib" library_urn="urn:adsk.eagle:library:183" package="ST4,8" package3d_urn="urn:adsk.eagle:package:9988/1" value="" x="73.025" y="126.365" smashed="yes" rot="R180">
<attribute name="MF" value="" x="73.025" y="126.365" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="73.025" y="126.365" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="76.327" y="124.1298" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="OC_FARNELL" value="unknown" x="73.025" y="126.365" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="73.025" y="126.365" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="76.835" y="130.175" size="1.27" layer="27" rot="R180"/>
</element>
<element name="X12" library="con-rib" library_urn="urn:adsk.eagle:library:183" package="ST4,8" package3d_urn="urn:adsk.eagle:package:9988/1" value="" x="73.025" y="116.205" smashed="yes" rot="R180">
<attribute name="MF" value="" x="73.025" y="116.205" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="73.025" y="116.205" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="76.327" y="113.9698" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="OC_FARNELL" value="unknown" x="73.025" y="116.205" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="73.025" y="116.205" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="76.835" y="120.015" size="1.27" layer="27" rot="R180"/>
</element>
<element name="X13" library="con-rib" library_urn="urn:adsk.eagle:library:183" package="ST4,8" package3d_urn="urn:adsk.eagle:package:9988/1" value="" x="72.7075" y="148.2725" smashed="yes" rot="R180">
<attribute name="MF" value="" x="72.7075" y="148.2725" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="72.7075" y="148.2725" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="76.0095" y="146.0373" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="OC_FARNELL" value="unknown" x="72.7075" y="148.2725" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="72.7075" y="148.2725" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="76.5175" y="152.0825" size="1.27" layer="27" rot="R180"/>
</element>
<element name="X14" library="con-rib" library_urn="urn:adsk.eagle:library:183" package="ST4,8" package3d_urn="urn:adsk.eagle:package:9988/1" value="" x="73.025" y="121.285" smashed="yes" rot="R180">
<attribute name="MF" value="" x="73.025" y="121.285" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="73.025" y="121.285" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="76.327" y="119.0498" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="OC_FARNELL" value="unknown" x="73.025" y="121.285" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="73.025" y="121.285" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="76.835" y="125.095" size="1.27" layer="27" rot="R180"/>
</element>
<element name="X15" library="con-rib" library_urn="urn:adsk.eagle:library:183" package="ST4,8" package3d_urn="urn:adsk.eagle:package:9988/1" value="" x="72.7075" y="143.1925" smashed="yes" rot="R180">
<attribute name="MF" value="" x="72.7075" y="143.1925" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="72.7075" y="143.1925" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="76.0095" y="140.9573" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="OC_FARNELL" value="unknown" x="72.7075" y="143.1925" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="72.7075" y="143.1925" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="76.5175" y="147.0025" size="1.27" layer="27" rot="R180"/>
</element>
<element name="B1" library="rectifier" package="GBU4S" value="GBU8G " x="139.3825" y="12.7" smashed="yes" rot="R90">
<attribute name="NAME" x="136.3345" y="1.27" size="1.778" layer="25" ratio="10" rot="R90"/>
<attribute name="POPULARITY" value="1" x="221.9325" y="110.49" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="148.9075" y="25.8445" size="1.778" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C23" library="rcl" package="E5-10,5" value="220uF" x="202.8825" y="28.575" smashed="yes" rot="R180">
<attribute name="NAME" x="198.1835" y="25.8318" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="POPULARITY" value="23" x="96.2025" y="90.805" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="96.2025" y="90.805" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="200.3933" y="31.0642" size="1.27" layer="27" ratio="10"/>
</element>
<element name="C24" library="rcl" package="C1206" value="100n" x="209.8675" y="24.765" smashed="yes" rot="MR180">
<attribute name="NAME" x="208.5975" y="23.495" size="1.27" layer="26" rot="MR180"/>
<attribute name="POPULARITY" value="54" x="226.3775" y="133.985" size="1.778" layer="28" rot="MR180" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="226.3775" y="133.985" size="1.778" layer="28" rot="MR180" display="off"/>
<attribute name="VALUE" x="211.7725" y="26.035" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="D10" library="diode" package="DO41Z10" value="ZPY18" x="206.0575" y="15.24" smashed="yes" rot="R180">
<attribute name="NAME" x="207.5815" y="14.097" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="POPULARITY" value="0" x="151.4475" y="130.81" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="208.8515" y="18.288" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="D8" library="diode" package="MELF-MLL41" value="SK54-DIO" x="192.0875" y="8.255" smashed="yes" rot="MR0">
<attribute name="NAME" x="194.7505" y="9.979" size="1.27" layer="26" rot="MR0"/>
<attribute name="POPULARITY" value="3" x="117.1575" y="-85.725" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="VALUE" x="186.8845" y="11.884" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="D9" library="diode" package="MELF-MLL41" value="1N4007" x="204.7875" y="19.685" smashed="yes" rot="MR0">
<attribute name="NAME" x="207.4505" y="21.409" size="1.27" layer="26" rot="MR0"/>
<attribute name="POPULARITY" value="3" x="112.0775" y="-74.295" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="VALUE" x="207.4505" y="22.406" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="LED3" library="led" package="LED5MM" value="piros" x="223.2025" y="12.7" smashed="yes" rot="R180">
<attribute name="NAME" x="225.1075" y="10.795" size="1.27" layer="25" rot="R180"/>
<attribute name="POPULARITY" value="93" x="174.9425" y="106.68" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="220.6625" y="15.875" size="1.27" layer="27" rot="R180"/>
</element>
<element name="Q4" library="transistor-power" package="TO220BV" value="IRF4905" x="195.8975" y="17.145" smashed="yes" rot="R180">
<attribute name="NAME" x="200.9775" y="23.1902" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="POPULARITY" value="4" x="141.2875" y="94.615" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="193.3575" y="22.225" size="1.27" layer="27" ratio="10"/>
</element>
<element name="R49" library="rcl" package="M1406" value="3.3k" x="222.5675" y="8.255" smashed="yes" rot="MR180">
<attribute name="NAME" x="222.5675" y="10.795" size="1.27" layer="26" rot="MR180"/>
<attribute name="POPULARITY" value="0" x="270.8275" y="117.475" size="1.778" layer="28" rot="MR180" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="270.8275" y="117.475" size="1.778" layer="28" rot="MR180" display="off"/>
<attribute name="VALUE" x="220.98" y="10.795" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="R50" library="rcl" package="R1206" value="6.8k" x="215.5825" y="13.97" smashed="yes" rot="MR0">
<attribute name="NAME" x="216.8525" y="15.24" size="1.27" layer="26" rot="MR0"/>
<attribute name="POPULARITY" value="41" x="160.9725" y="-95.25" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="160.9725" y="-95.25" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="VALUE" x="213.6775" y="16.51" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="R51" library="rcl" package="R1206" value="1k" x="215.5825" y="4.597" smashed="yes" rot="MR270">
<attribute name="NAME" x="213.6775" y="7.772" size="1.27" layer="26" rot="MR270"/>
<attribute name="POPULARITY" value="41" x="309.5625" y="-36.043" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="309.5625" y="-36.043" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="VALUE" x="214.7955" y="8.255" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="R52" library="rcl" package="M1406" value="150" x="203.555" y="10.8835" smashed="yes" rot="MR90">
<attribute name="NAME" x="201.015" y="9.6135" size="1.27" layer="26" rot="MR90"/>
<attribute name="POPULARITY" value="0" x="87.985" y="51.5235" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="87.985" y="51.5235" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="VALUE" x="205.334" y="13.3725" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="R48" library="rcl" package="M1406" value="680" x="227.0125" y="11.43" smashed="yes" rot="MR90">
<attribute name="NAME" x="228.9175" y="12.065" size="1.27" layer="26" rot="MR90"/>
<attribute name="POPULARITY" value="0" x="117.7925" y="92.71" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="117.7925" y="92.71" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="VALUE" x="225.425" y="14.9225" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="T5" library="transistor" package="TO92-CBE" value="BC557" x="207.3275" y="9.525" smashed="yes" rot="R270">
<attribute name="NAME" x="210.3755" y="12.065" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="POPULARITY" value="0" x="123.5075" y="-17.145" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="200.9775" y="11.938" size="1.27" layer="27" ratio="10"/>
</element>
<element name="T3" library="transistor" package="TO92-CBE" value="BC547" x="218.1225" y="8.89" smashed="yes" rot="R270">
<attribute name="NAME" x="221.1705" y="11.43" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="POPULARITY" value="0" x="134.3025" y="-33.02" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="214.9475" y="4.0005" size="1.27" layer="27" ratio="10"/>
</element>
<element name="T4" library="transistor" package="TO92-CBE" value="BC547" x="212.4075" y="9.525" smashed="yes" rot="R270">
<attribute name="NAME" x="215.4555" y="12.065" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="POPULARITY" value="0" x="128.5875" y="-40.005" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="212.09" y="13.208" size="1.27" layer="27" ratio="10"/>
</element>
<element name="F1" library="fuse" package="SHK20L" value="3.15A" x="150.8125" y="29.845" smashed="yes" rot="R180">
<attribute name="MF" value="" x="150.8125" y="29.845" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="150.8125" y="29.845" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="154.6225" y="26.67" size="1.778" layer="25" ratio="10" rot="R180"/>
<attribute name="OC_FARNELL" value="unknown" x="150.8125" y="29.845" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="150.8125" y="29.845" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="POPULARITY" value="2" x="150.8125" y="29.845" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="147.6375" y="33.655" size="1.778" layer="27" ratio="10"/>
</element>
<element name="IC3" library="v-reg" package="78MXXS" value="7805" x="216.2175" y="32.0675" smashed="yes">
<attribute name="NAME" x="211.3915" y="25.5905" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="1" x="189.5475" y="61.9125" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="217.8685" y="33.8455" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C9" library="rcl" package="C1206" value="100n" x="192.405" y="30.48" smashed="yes" rot="MR90">
<attribute name="NAME" x="193.675" y="29.21" size="1.27" layer="26" rot="MR90"/>
<attribute name="POPULARITY" value="54" x="231.775" y="30.48" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="231.775" y="30.48" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="VALUE" x="194.31" y="33.02" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="C10" library="rcl" package="C1206" value="100n" x="216.8525" y="17.78" smashed="yes" rot="MR180">
<attribute name="NAME" x="215.5825" y="16.51" size="1.27" layer="26" rot="MR180"/>
<attribute name="POPULARITY" value="54" x="211.1375" y="-15.24" size="1.778" layer="28" rot="MR180" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="211.1375" y="-15.24" size="1.778" layer="28" rot="MR180" display="off"/>
<attribute name="VALUE" x="218.7575" y="19.05" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="C11" library="rcl" package="E3,5-8" value="220uF" x="215.5825" y="21.59" smashed="yes" rot="R180">
<attribute name="NAME" x="212.2805" y="18.796" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="POPULARITY" value="13" x="215.5825" y="4.445" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="215.5825" y="4.445" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="213.2965" y="22.987" size="1.27" layer="27" ratio="10"/>
</element>
<element name="T7" library="transistor" package="TO92-CBE" value="BC547" x="229.5525" y="13.97" smashed="yes" rot="R270">
<attribute name="NAME" x="232.6005" y="16.51" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="POPULARITY" value="0" x="213.6775" y="43.815" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="230.8225" y="13.208" size="1.27" layer="27" ratio="10"/>
</element>
<element name="D11" library="diode" package="SOD80C" value="1N4148" x="239.0775" y="28.2575" smashed="yes" rot="MR0">
<attribute name="NAME" x="240.6015" y="29.4005" size="1.27" layer="26" rot="MR0"/>
<attribute name="POPULARITY" value="9" x="265.1125" y="12.3825" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="VALUE" x="241.8715" y="23.3045" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="R53" library="rcl" package="M1406" value="3.3k" x="232.7275" y="11.43" smashed="yes" rot="MR270">
<attribute name="NAME" x="231.4575" y="12.7" size="1.27" layer="26" rot="MR270"/>
<attribute name="POPULARITY" value="0" x="254.9525" y="31.75" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="254.9525" y="31.75" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="VALUE" x="230.8225" y="15.24" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="IC4" library="texas" package="DIL08" value="TL7660P" x="226.3775" y="24.765" smashed="yes" rot="R90">
<attribute name="MF" value="" x="286.7025" y="-8.89" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="TL7660CP" x="286.7025" y="-8.89" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="NAME" x="229.2985" y="19.431" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="OC_FARNELL" value="1755283" x="286.7025" y="-8.89" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_NEWARK" value="14M2447" x="286.7025" y="-8.89" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="POPULARITY" value="0" x="286.7025" y="-8.89" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="229.9335" y="31.75" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C13" library="rcl" package="C1210" value="10uF" x="233.3625" y="24.765" smashed="yes" rot="MR270">
<attribute name="NAME" x="231.4575" y="26.67" size="1.27" layer="26" rot="MR270"/>
<attribute name="POPULARITY" value="0" x="293.6875" y="72.39" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="293.6875" y="72.39" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="VALUE" x="231.4575" y="28.575" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="C14" library="rcl" package="C1210" value="10uF" x="225.7425" y="29.21" smashed="yes" rot="MR270">
<attribute name="NAME" x="223.8375" y="31.115" size="1.27" layer="26" rot="MR270"/>
<attribute name="POPULARITY" value="0" x="293.6875" y="82.55" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="293.6875" y="82.55" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="VALUE" x="223.8375" y="33.02" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="K1" library="relay" package="G2R2" value="G2R2" x="239.0775" y="27.94" smashed="yes" rot="R270">
<attribute name="MF" value="OMRON COMPONENTS USA" x="239.0775" y="27.94" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MPN" value="G2R-2-DC6" x="239.0775" y="27.94" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="NAME" x="232.7783" y="1.2954" size="1.778" layer="25" ratio="10"/>
<attribute name="OC_FARNELL" value="unknown" x="239.0775" y="27.94" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_NEWARK" value="89C5317" x="239.0775" y="27.94" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="POPULARITY" value="0" x="239.0775" y="27.94" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="235.9025" y="26.035" size="1.778" layer="27" ratio="10"/>
</element>
<element name="X16" library="con-ptr500" package="AK500/2" value="" x="132.3975" y="19.05" smashed="yes" rot="R270">
<attribute name="MF" value="" x="132.3975" y="19.05" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MPN" value="" x="132.3975" y="19.05" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="NAME" x="136.8425" y="24.13" size="1.778" layer="25" ratio="10" rot="R270"/>
<attribute name="OC_FARNELL" value="unknown" x="132.3975" y="19.05" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="132.3975" y="19.05" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="POPULARITY" value="14" x="132.3975" y="19.05" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="126.6825" y="24.13" size="1.778" layer="27" ratio="10" rot="R270"/>
</element>
<element name="JP3" library="jumper" package="JP2" value="" x="223.2025" y="17.78" smashed="yes" rot="R180">
<attribute name="NAME" x="226.7585" y="16.129" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="POPULARITY" value="34" x="223.2025" y="17.78" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="226.7585" y="22.098" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C6" library="rcl" package="E3,5-8" value="220uF" x="185.1025" y="30.48" smashed="yes" rot="R270">
<attribute name="NAME" x="187.8965" y="27.178" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="POPULARITY" value="13" x="185.1025" y="30.48" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="185.1025" y="30.48" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="179.6415" y="34.417" size="1.27" layer="27" ratio="10"/>
</element>
<element name="J1" library="con-molex" package="6410-03" value="22-27-2031-03" x="229.5525" y="6.35" smashed="yes" rot="R90">
<attribute name="MF" value="MOLEX" x="229.5525" y="6.35" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="" x="229.5525" y="6.35" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="NAME" x="226.2774" y="2.5669" size="1.016" layer="25" ratio="10" rot="R90"/>
<attribute name="OC_FARNELL" value="unknown" x="229.5525" y="6.35" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="229.5525" y="6.35" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="POPULARITY" value="0" x="229.5525" y="6.35" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="231.1131" y="1.4239" size="0.8128" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C7" library="rcl" library_urn="urn:adsk.eagle:library:334" package="EB22,5D" package3d_urn="urn:adsk.eagle:package:23380/1" value="4700uF" x="152.7175" y="13.335" smashed="yes" rot="R270">
<attribute name="NAME" x="161.2265" y="4.9276" size="1.778" layer="25" ratio="10" rot="R270"/>
<attribute name="POPULARITY" value="1" x="152.7175" y="13.335" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="152.7175" y="13.335" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="148.59" y="9.8679" size="1.778" layer="27" ratio="10" rot="R90"/>
</element>
<element name="C8" library="rcl" library_urn="urn:adsk.eagle:library:334" package="EB22,5D" package3d_urn="urn:adsk.eagle:package:23380/1" value="4700uF" x="176.8475" y="13.335" smashed="yes" rot="R270">
<attribute name="NAME" x="185.3565" y="4.9276" size="1.778" layer="25" ratio="10" rot="R270"/>
<attribute name="POPULARITY" value="1" x="176.8475" y="13.335" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="176.8475" y="13.335" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="171.1325" y="18.3896" size="1.778" layer="27" ratio="10" rot="R270"/>
</element>
<element name="LSP4" library="solpad" library_urn="urn:adsk.eagle:library:364" package="LSP10" package3d_urn="urn:adsk.eagle:package:26501/1" value="LSP10" x="187.96" y="20.32" smashed="yes">
<attribute name="NAME" x="186.69" y="21.59" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="52" x="187.96" y="20.32" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="187.96" y="20.574" size="0.0254" layer="27"/>
</element>
<element name="LSP5" library="solpad" library_urn="urn:adsk.eagle:library:364" package="LSP10" package3d_urn="urn:adsk.eagle:package:26501/1" value="LSP10" x="163.5125" y="20.32" smashed="yes">
<attribute name="NAME" x="162.2425" y="21.59" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="52" x="163.5125" y="20.32" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="163.5125" y="20.574" size="0.0254" layer="27"/>
</element>
<element name="X17" library="con-ptr500" library_urn="urn:adsk.eagle:library:181" package="AK500/3" package3d_urn="urn:adsk.eagle:package:9883/1" value="" x="194.6275" y="5.08" smashed="yes" rot="R180">
<attribute name="MF" value="" x="194.6275" y="5.08" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="194.6275" y="5.08" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="202.2221" y="0.635" size="1.778" layer="25" ratio="10" rot="R180"/>
<attribute name="OC_FARNELL" value="unknown" x="194.6275" y="5.08" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="194.6275" y="5.08" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="POPULARITY" value="3" x="194.6275" y="5.08" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="202.2221" y="10.795" size="1.778" layer="27" ratio="10" rot="R180"/>
</element>
<element name="LSP6" library="solpad" library_urn="urn:adsk.eagle:library:364" package="LSP10" package3d_urn="urn:adsk.eagle:package:26501/1" value="LSP10" x="209.8675" y="3.81" smashed="yes">
<attribute name="NAME" x="208.5975" y="5.08" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="52" x="209.8675" y="3.81" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="209.8675" y="4.064" size="0.0254" layer="27"/>
</element>
<element name="LSP7" library="solpad" library_urn="urn:adsk.eagle:library:364" package="LSP10" package3d_urn="urn:adsk.eagle:package:26501/1" value="LSP10" x="166.0525" y="20.32" smashed="yes">
<attribute name="NAME" x="164.7825" y="21.59" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="52" x="166.0525" y="20.32" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="166.0525" y="20.574" size="0.0254" layer="27"/>
</element>
<element name="LSP8" library="solpad" library_urn="urn:adsk.eagle:library:364" package="LSP10" package3d_urn="urn:adsk.eagle:package:26501/1" value="LSP10" x="164.7825" y="5.08" smashed="yes">
<attribute name="NAME" x="163.5125" y="6.35" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="52" x="164.7825" y="5.08" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="164.7825" y="5.334" size="0.0254" layer="27"/>
</element>
<element name="LSP9" library="solpad" library_urn="urn:adsk.eagle:library:364" package="LSP10" package3d_urn="urn:adsk.eagle:package:26501/1" value="LSP10" x="221.2975" y="3.81" smashed="yes">
<attribute name="NAME" x="220.0275" y="5.08" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="52" x="221.2975" y="3.81" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="221.2975" y="4.064" size="0.0254" layer="27"/>
</element>
<element name="JP4" library="jumper" library_urn="urn:adsk.eagle:library:252" package="JP1" package3d_urn="urn:adsk.eagle:package:15455/1" value="" x="197.1675" y="10.795" smashed="yes" rot="R90">
<attribute name="NAME" x="199.7075" y="9.144" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="POPULARITY" value="61" x="197.1675" y="10.795" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="199.7075" y="13.716" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="LSP10" library="solpad" library_urn="urn:adsk.eagle:library:364" package="LSP10" package3d_urn="urn:adsk.eagle:package:26501/1" value="LSP10" x="132.3975" y="11.1125" smashed="yes">
<attribute name="NAME" x="131.1275" y="12.3825" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="52" x="132.3975" y="11.1125" size="2.54" layer="27" font="vector" ratio="20" display="off"/>
<attribute name="VALUE" x="132.3975" y="11.3665" size="0.0254" layer="27"/>
</element>
<element name="X18" library="con-ptr500" package="AK500/2" value="" x="249.555" y="12.3825" smashed="yes" rot="R90">
<attribute name="MF" value="" x="249.555" y="12.3825" size="1.778" layer="27" font="vector" ratio="17" rot="R90" display="off"/>
<attribute name="MPN" value="" x="249.555" y="12.3825" size="1.778" layer="27" font="vector" ratio="17" rot="R90" display="off"/>
<attribute name="NAME" x="245.11" y="7.3025" size="1.778" layer="25" ratio="10" rot="R90"/>
<attribute name="OC_FARNELL" value="unknown" x="249.555" y="12.3825" size="1.778" layer="27" font="vector" ratio="17" rot="R90" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="249.555" y="12.3825" size="1.778" layer="27" font="vector" ratio="17" rot="R90" display="off"/>
<attribute name="POPULARITY" value="14" x="249.555" y="12.3825" size="1.778" layer="27" font="vector" ratio="17" rot="R90" display="off"/>
<attribute name="VALUE" x="255.27" y="7.3025" size="1.778" layer="27" ratio="10" rot="R90"/>
</element>
<element name="LSP11" library="solpad" library_urn="urn:adsk.eagle:library:364" package="LSP10" package3d_urn="urn:adsk.eagle:package:26501/1" value="LSP10" x="142.24" y="20.32" smashed="yes">
<attribute name="NAME" x="140.97" y="21.59" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="52" x="142.24" y="20.32" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="142.24" y="20.574" size="0.0254" layer="27"/>
</element>
<element name="IC5" library="v-reg" library_urn="urn:adsk.eagle:library:409" package="78MXXS" package3d_urn="urn:adsk.eagle:package:30347/1" value="7812" x="173.355" y="32.0675" smashed="yes">
<attribute name="NAME" x="168.529" y="25.5905" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="1" x="173.355" y="32.0675" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="172.0215" y="33.4645" size="1.27" layer="27" ratio="10"/>
</element>
<element name="OK1" library="optocoupler" library_urn="urn:adsk.eagle:library:320" package="DIL04" package3d_urn="urn:adsk.eagle:package:21938/1" value="PC817" x="248.6025" y="22.225" smashed="yes">
<attribute name="MF" value="" x="248.6025" y="22.225" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="PC817X4J000F" x="248.6025" y="22.225" size="1.778" layer="27" display="off"/>
<attribute name="NAME" x="245.6815" y="19.558" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="OC_FARNELL" value="9707727" x="248.6025" y="22.225" size="1.778" layer="27" display="off"/>
<attribute name="OC_NEWARK" value="97K7059" x="248.6025" y="22.225" size="1.778" layer="27" display="off"/>
<attribute name="POPULARITY" value="20" x="248.6025" y="22.225" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="252.7935" y="19.304" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="R54" library="rcl" package="M1406" value="3.3k" x="243.5225" y="23.8125" smashed="yes" rot="MR90">
<attribute name="NAME" x="244.7925" y="22.5425" size="1.27" layer="26" rot="MR90"/>
<attribute name="POPULARITY" value="0" x="243.5225" y="23.8125" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="243.5225" y="23.8125" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="VALUE" x="240.9825" y="22.5425" size="1.27" layer="28" rot="MR90"/>
</element>
<element name="JP5" library="jumper" library_urn="urn:adsk.eagle:library:252" package="JP1" package3d_urn="urn:adsk.eagle:package:15455/1" value="" x="248.6025" y="27.6225" smashed="yes" rot="R90">
<attribute name="NAME" x="251.1425" y="25.9715" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="POPULARITY" value="61" x="248.6025" y="27.6225" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="251.1425" y="30.5435" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="IC6" library="v-reg" package="78MXXS" value="7808" x="156.5275" y="72.7075" smashed="yes" rot="R270">
<attribute name="NAME" x="150.0505" y="77.5335" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="POPULARITY" value="1" x="186.3725" y="99.3775" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="156.2735" y="78.9305" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C12" library="rcl" package="C1206" value="100n" x="147.955" y="69.5325" smashed="yes" rot="MR270">
<attribute name="NAME" x="146.685" y="70.8025" size="1.27" layer="26" rot="MR270"/>
<attribute name="POPULARITY" value="54" x="108.585" y="69.5325" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="108.585" y="69.5325" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="VALUE" x="146.685" y="73.3425" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="C15" library="rcl" package="C1206" value="100n" x="156.21" y="67.31" smashed="yes" rot="MR0">
<attribute name="NAME" x="157.48" y="68.58" size="1.27" layer="26" rot="MR0"/>
<attribute name="POPULARITY" value="54" x="161.925" y="100.33" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="161.925" y="100.33" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="VALUE" x="155.575" y="69.85" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="C16" library="rcl" package="E3,5-8" value="100uF" x="156.21" y="62.865" smashed="yes">
<attribute name="NAME" x="159.512" y="65.659" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="13" x="156.21" y="80.01" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="156.21" y="80.01" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="158.496" y="61.468" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="IC7" library="texas" package="DIL08" value="TL7660P" x="159.7025" y="53.0225" smashed="yes" rot="R270">
<attribute name="MF" value="" x="99.3775" y="86.6775" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MPN" value="TL7660CP" x="99.3775" y="86.6775" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="NAME" x="156.7815" y="58.3565" size="1.27" layer="25" ratio="10"/>
<attribute name="OC_FARNELL" value="1755283" x="99.3775" y="86.6775" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_NEWARK" value="14M2447" x="99.3775" y="86.6775" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="POPULARITY" value="0" x="99.3775" y="86.6775" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="156.1465" y="46.0375" size="1.27" layer="27" ratio="10"/>
</element>
<element name="C17" library="rcl" package="C1210" value="10uF" x="159.0675" y="51.1175" smashed="yes" rot="MR90">
<attribute name="NAME" x="160.9725" y="49.2125" size="1.27" layer="26" rot="MR90"/>
<attribute name="POPULARITY" value="0" x="98.7425" y="3.4925" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="98.7425" y="3.4925" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="VALUE" x="161.29" y="53.975" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="C18" library="rcl" package="C1210" value="10uF" x="166.6875" y="50.4825" smashed="yes" rot="MR270">
<attribute name="NAME" x="164.7825" y="52.3875" size="1.27" layer="26" rot="MR270"/>
<attribute name="POPULARITY" value="0" x="234.6325" y="103.8225" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="234.6325" y="103.8225" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="VALUE" x="164.7825" y="54.2925" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="C19" library="rcl" library_urn="urn:adsk.eagle:library:334" package="E5-10,5" package3d_urn="urn:adsk.eagle:package:23372/2" value="1000uF" x="144.78" y="70.8025" smashed="yes" rot="R90">
<attribute name="NAME" x="141.986" y="74.1045" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="POPULARITY" value="23" x="144.78" y="70.8025" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="144.78" y="70.8025" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="148.0185" y="77.343" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="X19" library="con-ptr500" library_urn="urn:adsk.eagle:library:181" package="AK500/2" package3d_urn="urn:adsk.eagle:package:9880/1" value="" x="133.985" y="55.245" smashed="yes" rot="R180">
<attribute name="MF" value="" x="133.985" y="55.245" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="133.985" y="55.245" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="139.065" y="50.8" size="1.778" layer="25" ratio="10" rot="R180"/>
<attribute name="OC_FARNELL" value="unknown" x="133.985" y="55.245" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="133.985" y="55.245" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="POPULARITY" value="14" x="133.985" y="55.245" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="139.065" y="60.96" size="1.778" layer="27" ratio="10" rot="R180"/>
</element>
<element name="F2" library="fuse" library_urn="urn:adsk.eagle:library:233" package="TE5" package3d_urn="urn:adsk.eagle:package:14069/1" value="0.5A" x="134.3025" y="60.96" smashed="yes" rot="R180">
<attribute name="MF" value="" x="134.3025" y="60.96" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="134.3025" y="60.96" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="138.4935" y="58.42" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="OC_FARNELL" value="unknown" x="134.3025" y="60.96" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="134.3025" y="60.96" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="POPULARITY" value="0" x="134.3025" y="60.96" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="138.6205" y="64.77" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="IC8" library="linear" library_urn="urn:adsk.eagle:library:262" package="DIL08" package3d_urn="urn:adsk.eagle:package:16409/2" value="LM358N" x="167.005" y="71.12" smashed="yes">
<attribute name="NAME" x="161.671" y="68.199" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="POPULARITY" value="7" x="167.005" y="71.12" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="163.7665" y="71.755" size="1.27" layer="27" ratio="10"/>
</element>
<element name="R55" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1206" package3d_urn="urn:adsk.eagle:package:23566/2" value="2.2k" x="177.4825" y="64.135" smashed="yes" rot="MR270">
<attribute name="NAME" x="176.2125" y="65.405" size="1.27" layer="26" rot="MR270"/>
<attribute name="POPULARITY" value="17" x="177.4825" y="64.135" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="177.4825" y="64.135" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="VALUE" x="176.2125" y="67.31" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="R56" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1406" package3d_urn="urn:adsk.eagle:package:23569/2" value="10k" x="182.88" y="62.865" smashed="yes" rot="MR90">
<attribute name="NAME" x="184.15" y="61.595" size="1.27" layer="26" rot="MR90"/>
<attribute name="POPULARITY" value="0" x="182.88" y="62.865" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="182.88" y="62.865" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="VALUE" x="184.4675" y="65.405" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="R57" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1406" package3d_urn="urn:adsk.eagle:package:23569/2" value="1k" x="169.545" y="56.515" smashed="yes" rot="MR0">
<attribute name="NAME" x="170.815" y="57.785" size="1.27" layer="26" rot="MR0"/>
<attribute name="POPULARITY" value="0" x="169.545" y="56.515" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="169.545" y="56.515" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="VALUE" x="170.18" y="57.785" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="R58" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1206" package3d_urn="urn:adsk.eagle:package:23566/2" value="10k" x="183.8325" y="68.8975" smashed="yes" rot="MR0">
<attribute name="NAME" x="185.1025" y="70.1675" size="1.27" layer="26" rot="MR0"/>
<attribute name="POPULARITY" value="17" x="183.8325" y="68.8975" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="183.8325" y="68.8975" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="VALUE" x="185.42" y="70.485" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="R59" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1206" package3d_urn="urn:adsk.eagle:package:23566/2" value="3.3k" x="175.895" y="58.42" smashed="yes" rot="MR0">
<attribute name="NAME" x="177.165" y="59.69" size="1.27" layer="26" rot="MR0"/>
<attribute name="POPULARITY" value="17" x="175.895" y="58.42" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="175.895" y="58.42" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="VALUE" x="177.4825" y="59.69" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="R60" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1406" package3d_urn="urn:adsk.eagle:package:23569/2" value="00" x="175.895" y="73.025" smashed="yes" rot="MR0">
<attribute name="NAME" x="177.165" y="74.295" size="1.27" layer="26" rot="MR0"/>
<attribute name="POPULARITY" value="0" x="175.895" y="73.025" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="175.895" y="73.025" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="VALUE" x="176.8475" y="74.295" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="R61" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1206" package3d_urn="urn:adsk.eagle:package:23566/2" value="1k" x="166.6875" y="69.85" smashed="yes" rot="MR0">
<attribute name="NAME" x="167.9575" y="71.12" size="1.27" layer="26" rot="MR0"/>
<attribute name="POPULARITY" value="17" x="166.6875" y="69.85" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="166.6875" y="69.85" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="VALUE" x="167.64" y="71.12" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="R62" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1206" package3d_urn="urn:adsk.eagle:package:23566/2" value="1k" x="170.4975" y="61.2775" smashed="yes" rot="MR270">
<attribute name="NAME" x="169.2275" y="62.5475" size="1.27" layer="26" rot="MR270"/>
<attribute name="POPULARITY" value="17" x="170.4975" y="61.2775" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="170.4975" y="61.2775" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="VALUE" x="169.545" y="64.77" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="R63" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1206" package3d_urn="urn:adsk.eagle:package:23566/2" value="22k" x="174.625" y="64.135" smashed="yes" rot="MR90">
<attribute name="NAME" x="175.895" y="62.865" size="1.27" layer="26" rot="MR90"/>
<attribute name="POPULARITY" value="17" x="174.625" y="64.135" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="174.625" y="64.135" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="VALUE" x="175.5775" y="66.04" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="LED4" library="led" library_urn="urn:adsk.eagle:library:259" package="LED5MM" package3d_urn="urn:adsk.eagle:package:15799/2" value="led" x="179.07" y="51.1175" smashed="yes" rot="R270">
<attribute name="NAME" x="179.6034" y="47.9425" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="POPULARITY" value="93" x="179.07" y="51.1175" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="177.8254" y="46.7741" size="1.27" layer="27" ratio="10"/>
</element>
<element name="X20" library="con-molex" library_urn="urn:adsk.eagle:library:165" package="22-23-2021" package3d_urn="urn:adsk.eagle:package:8078633/1" value="vent." x="188.2775" y="63.8175" smashed="yes" rot="R270">
<attribute name="MF" value="MOLEX" x="188.2775" y="63.8175" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MPN" value="22-23-2021" x="188.2775" y="63.8175" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="NAME" x="192.0875" y="66.3575" size="1.016" layer="25" ratio="10" rot="R270"/>
<attribute name="OC_FARNELL" value="1462926" x="188.2775" y="63.8175" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_NEWARK" value="25C3832" x="188.2775" y="63.8175" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="POPULARITY" value="40" x="188.2775" y="63.8175" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="189.865" y="66.9925" size="1.016" layer="27" ratio="10"/>
</element>
<element name="C20" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="100n" x="166.6875" y="62.865" smashed="yes" rot="MR270">
<attribute name="NAME" x="165.4175" y="64.135" size="1.27" layer="26" rot="MR270"/>
<attribute name="POPULARITY" value="54" x="166.6875" y="62.865" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="166.6875" y="62.865" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="VALUE" x="164.1475" y="66.04" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="C21" library="rcl" library_urn="urn:adsk.eagle:library:334" package="E3,5-8" package3d_urn="urn:adsk.eagle:package:23360/2" value="100uF" x="188.2775" y="72.39" smashed="yes" rot="R90">
<attribute name="NAME" x="185.4835" y="75.692" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="POPULARITY" value="13" x="188.2775" y="72.39" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="188.2775" y="72.39" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="190.881" y="77.978" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="Q5" library="transistor-power" library_urn="urn:adsk.eagle:library:400" package="TO220BV" package3d_urn="urn:adsk.eagle:package:29484/3" value="IRF540" x="173.6725" y="49.8475" smashed="yes" rot="R270">
<attribute name="NAME" x="178.8795" y="53.6575" size="1.778" layer="25" ratio="10" rot="R270"/>
<attribute name="POPULARITY" value="3" x="173.6725" y="49.8475" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="166.5605" y="55.5625" size="1.778" layer="27" ratio="10"/>
</element>
<element name="Q6" library="transistor-pnp" library_urn="urn:adsk.eagle:library:399" package="TO92-EBC" package3d_urn="urn:adsk.eagle:package:29218/2" value="BC556A" x="177.4825" y="70.1675" smashed="yes">
<attribute name="NAME" x="174.9425" y="71.9455" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="0" x="177.4825" y="70.1675" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="173.99" y="65.5955" size="1.27" layer="27" ratio="10"/>
</element>
<element name="JP6" library="jumper" library_urn="urn:adsk.eagle:library:252" package="JP1" package3d_urn="urn:adsk.eagle:package:15455/1" value="10k term." x="180.6575" y="73.9775" smashed="yes" rot="R270">
<attribute name="NAME" x="178.1175" y="75.6285" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="61" x="180.6575" y="73.9775" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="178.1175" y="76.1365" size="1.27" layer="27" ratio="10"/>
</element>
<element name="R64" library="rcl" library_urn="urn:adsk.eagle:library:334" package="RTRIM64W" package3d_urn="urn:adsk.eagle:package:23748/1" value="3.3k" x="178.7525" y="60.325" smashed="yes">
<attribute name="NAME" x="176.1325" y="55.375" size="1.27" layer="25" rot="R90"/>
<attribute name="POPULARITY" value="0" x="178.7525" y="60.325" size="1.778" layer="27" display="off"/>
<attribute name="SPICEMODEL" value="X" x="178.7525" y="60.325" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIXL" value="POT" x="178.7525" y="60.325" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="176.4" y="61.1825" size="1.27" layer="27" rot="R180"/>
</element>
<element name="B2" library="rectifier" library_urn="urn:adsk.eagle:library:336" package="DBS" package3d_urn="urn:adsk.eagle:package:23898/1" value="DBLS202G" x="144.4625" y="61.2775" smashed="yes" rot="MR270">
<attribute name="NAME" x="147.6375" y="65.7225" size="1.778" layer="26" ratio="10" rot="MR0"/>
<attribute name="POPULARITY" value="0" x="144.4625" y="61.2775" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="VALUE" x="138.43" y="67.31" size="1.778" layer="28" ratio="10" rot="MR180"/>
</element>
<element name="X21" library="con-ptr500" library_urn="urn:adsk.eagle:library:181" package="AK500/2" package3d_urn="urn:adsk.eagle:package:9880/1" value="" x="133.985" y="66.9925" smashed="yes" rot="R180">
<attribute name="MF" value="" x="133.985" y="66.9925" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="133.985" y="66.9925" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="139.065" y="62.5475" size="1.778" layer="25" ratio="10" rot="R180"/>
<attribute name="OC_FARNELL" value="unknown" x="133.985" y="66.9925" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="133.985" y="66.9925" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="POPULARITY" value="14" x="133.985" y="66.9925" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="139.065" y="72.7075" size="1.778" layer="27" ratio="10" rot="R180"/>
</element>
<element name="X22" library="con-molex" library_urn="urn:adsk.eagle:library:165" package="22-23-2031" package3d_urn="urn:adsk.eagle:package:8078634/1" value="-5V GND+5V" x="150.495" y="51.7525" smashed="yes" rot="R270">
<attribute name="MF" value="MOLEX" x="150.495" y="51.7525" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MPN" value="22-23-2031" x="150.495" y="51.7525" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="NAME" x="154.305" y="55.5625" size="1.016" layer="25" ratio="10" rot="R270"/>
<attribute name="OC_FARNELL" value="1462950" x="150.495" y="51.7525" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_NEWARK" value="30C0862" x="150.495" y="51.7525" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="POPULARITY" value="35" x="150.495" y="51.7525" size="1.778" layer="27" rot="R270" display="off"/>
</element>
<element name="X23" library="con-molex" library_urn="urn:adsk.eagle:library:165" package="22-23-2031" package3d_urn="urn:adsk.eagle:package:8078634/1" value="+5V GND+12V" x="142.24" y="49.2125" smashed="yes" rot="R90">
<attribute name="MF" value="MOLEX" x="142.24" y="49.2125" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="22-23-2031" x="142.24" y="49.2125" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="NAME" x="138.43" y="45.4025" size="1.016" layer="25" ratio="10" rot="R90"/>
<attribute name="OC_FARNELL" value="1462950" x="142.24" y="49.2125" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_NEWARK" value="30C0862" x="142.24" y="49.2125" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="POPULARITY" value="35" x="142.24" y="49.2125" size="1.778" layer="27" rot="R90" display="off"/>
</element>
<element name="X24" library="con-ptr500" library_urn="urn:adsk.eagle:library:181" package="AK500/2" package3d_urn="urn:adsk.eagle:package:9880/1" value="" x="249.555" y="60.96" smashed="yes" rot="R90">
<attribute name="MF" value="" x="249.555" y="60.96" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="" x="249.555" y="60.96" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="NAME" x="245.11" y="55.88" size="1.778" layer="25" ratio="10" rot="R90"/>
<attribute name="OC_FARNELL" value="unknown" x="249.555" y="60.96" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="249.555" y="60.96" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="POPULARITY" value="14" x="249.555" y="60.96" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="255.27" y="55.88" size="1.778" layer="27" ratio="10" rot="R90"/>
</element>
<element name="X25" library="con-molex" library_urn="urn:adsk.eagle:library:165" package="22-23-2021" package3d_urn="urn:adsk.eagle:package:8078633/1" value="USB +5V" x="190.1825" y="47.625" smashed="yes" rot="R270">
<attribute name="MF" value="MOLEX" x="190.1825" y="47.625" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MPN" value="22-23-2021" x="190.1825" y="47.625" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="NAME" x="193.9925" y="50.165" size="1.016" layer="25" ratio="10" rot="R270"/>
<attribute name="OC_FARNELL" value="1462926" x="190.1825" y="47.625" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_NEWARK" value="25C3832" x="190.1825" y="47.625" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="POPULARITY" value="40" x="190.1825" y="47.625" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="187.0075" y="51.1175" size="1.016" layer="27" ratio="10"/>
</element>
<element name="R65" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1206" package3d_urn="urn:adsk.eagle:package:23566/2" value="3.3k" x="157.7975" y="75.565" smashed="yes" rot="MR90">
<attribute name="NAME" x="159.0675" y="74.295" size="1.27" layer="26" rot="MR90"/>
<attribute name="POPULARITY" value="17" x="157.7975" y="75.565" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="157.7975" y="75.565" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="VALUE" x="159.0675" y="77.47" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="R66" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1206" package3d_urn="urn:adsk.eagle:package:23566/2" value="3.3k" x="160.3375" y="72.7075" smashed="yes" rot="MR270">
<attribute name="NAME" x="159.0675" y="73.9775" size="1.27" layer="26" rot="MR270"/>
<attribute name="POPULARITY" value="17" x="160.3375" y="72.7075" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="160.3375" y="72.7075" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="VALUE" x="159.0675" y="76.2" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="C22" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="100n" x="138.1125" y="123.19" smashed="yes" rot="R90">
<attribute name="NAME" x="136.8425" y="121.92" size="1.27" layer="25" rot="R90"/>
<attribute name="POPULARITY" value="54" x="209.2325" y="200.66" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="209.2325" y="200.66" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="138.7475" y="126.6825" size="1.27" layer="27" rot="R180"/>
</element>
<element name="C25" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="100n" x="162.56" y="141.9225" smashed="yes" rot="R90">
<attribute name="NAME" x="161.29" y="140.6525" size="1.27" layer="25" rot="R90"/>
<attribute name="POPULARITY" value="54" x="233.68" y="224.4725" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="233.68" y="224.4725" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="164.7825" y="145.415" size="1.27" layer="27" rot="R180"/>
</element>
<element name="C26" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="100n" x="118.4275" y="132.3975" smashed="yes" rot="R180">
<attribute name="NAME" x="119.6975" y="131.1275" size="1.27" layer="25" rot="R180"/>
<attribute name="POPULARITY" value="54" x="103.1875" y="209.8675" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="103.1875" y="209.8675" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="120.9675" y="134.9375" size="1.27" layer="27" rot="R180"/>
</element>
<element name="C27" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="100n" x="110.1725" y="126.365" smashed="yes" rot="R90">
<attribute name="NAME" x="108.9025" y="125.095" size="1.27" layer="25" rot="R90"/>
<attribute name="POPULARITY" value="54" x="187.6425" y="146.685" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="187.6425" y="146.685" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="112.0775" y="129.8575" size="1.27" layer="27" rot="R180"/>
</element>
<element name="C28" library="rcl" library_urn="urn:adsk.eagle:library:334" package="E2,5-7" package3d_urn="urn:adsk.eagle:package:23345/1" value="220uF" x="158.75" y="133.0325" smashed="yes" rot="MR270">
<attribute name="NAME" x="156.718" y="129.9845" size="1.27" layer="26" ratio="10" rot="MR270"/>
<attribute name="POPULARITY" value="17" x="224.79" y="113.9825" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="224.79" y="113.9825" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="VALUE" x="159.258" y="137.795" size="1.27" layer="28" ratio="10" rot="MR180"/>
</element>
<element name="C29" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="100n" x="141.605" y="123.19" smashed="yes" rot="R270">
<attribute name="NAME" x="142.875" y="124.46" size="1.27" layer="25" rot="R270"/>
<attribute name="POPULARITY" value="54" x="64.135" y="97.79" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="64.135" y="97.79" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="140.0175" y="125.4125" size="1.27" layer="27"/>
</element>
<element name="DIS1" library="display-lcd" library_urn="urn:adsk.eagle:library:214" package="TUXGR_16X2_R2" package3d_urn="urn:adsk.eagle:package:13139/1" value="TUXGR_16X2_R2" x="147.0025" y="127.3175" smashed="yes">
<attribute name="MF" value="" x="200.3425" y="108.2675" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="" x="200.3425" y="108.2675" size="1.778" layer="27" display="off"/>
<attribute name="NAME" x="108.9025" y="145.7325" size="1.27" layer="25"/>
<attribute name="OC_FARNELL" value="unknown" x="200.3425" y="108.2675" size="1.778" layer="27" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="200.3425" y="108.2675" size="1.778" layer="27" display="off"/>
<attribute name="POPULARITY" value="5" x="200.3425" y="108.2675" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="127.3175" y="144.78" size="1.27" layer="27"/>
</element>
<element name="IC9" library="ic-package" library_urn="urn:adsk.eagle:library:239" package="DIL28-3" package3d_urn="urn:adsk.eagle:package:827/2" value="Atmega 8A" x="136.8425" y="132.08" smashed="yes" rot="MR180">
<attribute name="NAME" x="118.8085" y="135.001" size="1.27" layer="26" ratio="10" rot="MR270"/>
<attribute name="POPULARITY" value="8" x="168.5925" y="177.8" size="1.778" layer="28" rot="MR180" display="off"/>
<attribute name="VALUE" x="131.826" y="132.715" size="1.27" layer="28" ratio="10" rot="MR180"/>
</element>
<element name="L1" library="inductor-neosid" library_urn="urn:adsk.eagle:library:241" package="MS50" package3d_urn="urn:adsk.eagle:package:14699/1" value="22uH" x="138.1125" y="132.3975" smashed="yes" rot="R270">
<attribute name="MF" value="" x="138.1125" y="132.3975" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MPN" value="" x="138.1125" y="132.3975" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="NAME" x="139.8635" y="134.4785" size="1.27" layer="25" rot="R270"/>
<attribute name="OC_FARNELL" value="unknown" x="138.1125" y="132.3975" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="138.1125" y="132.3975" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="POPULARITY" value="0" x="73.3425" y="87.9475" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="139.8415" y="133.52" size="1.27" layer="27"/>
</element>
<element name="LSP12" library="solpad" library_urn="urn:adsk.eagle:library:364" package="LSP10" package3d_urn="urn:adsk.eagle:package:26501/1" value="LSP10" x="114.3" y="118.4275" smashed="yes" rot="R90">
<attribute name="NAME" x="113.03" y="117.1575" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="POPULARITY" value="52" x="185.42" y="165.4175" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="114.046" y="118.4275" size="0.0254" layer="27" rot="R90"/>
</element>
<element name="V1" library="solpad" library_urn="urn:adsk.eagle:library:364" package="LSP10" package3d_urn="urn:adsk.eagle:package:26501/1" value="V1" x="129.2225" y="111.125" smashed="yes" rot="R90">
<attribute name="NAME" x="127.9525" y="109.855" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="POPULARITY" value="52" x="200.3425" y="183.515" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="128.9685" y="111.125" size="0.0254" layer="27" rot="R90"/>
</element>
<element name="R67" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1206" package3d_urn="urn:adsk.eagle:package:23566/2" value="47k" x="112.7125" y="121.285" smashed="yes">
<attribute name="NAME" x="111.4425" y="122.555" size="1.27" layer="25"/>
<attribute name="POPULARITY" value="17" x="163.5125" y="56.515" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="163.5125" y="56.515" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="113.665" y="123.825" size="1.27" layer="27" rot="R180"/>
</element>
<element name="R70" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1206" package3d_urn="urn:adsk.eagle:package:23566/2" value="15k" x="125.4125" y="111.125" smashed="yes">
<attribute name="NAME" x="124.1425" y="112.395" size="1.27" layer="25"/>
<attribute name="POPULARITY" value="17" x="150.8125" y="38.735" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="150.8125" y="38.735" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="123.825" y="112.395" size="1.27" layer="27"/>
</element>
<element name="R71" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1406" package3d_urn="urn:adsk.eagle:package:23569/2" value="100k" x="129.2225" y="115.57" smashed="yes" rot="R90">
<attribute name="NAME" x="127.9525" y="114.3" size="1.27" layer="25" rot="R90"/>
<attribute name="POPULARITY" value="0" x="201.6125" y="146.05" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="201.6125" y="146.05" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="128.27" y="117.475" size="1.27" layer="27" rot="R180"/>
</element>
<element name="R72" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1206" package3d_urn="urn:adsk.eagle:package:23566/2" value="15k" x="118.11" y="117.475" smashed="yes" rot="R90">
<attribute name="NAME" x="116.84" y="116.205" size="1.27" layer="25" rot="R90"/>
<attribute name="POPULARITY" value="17" x="190.5" y="153.035" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="190.5" y="153.035" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="119.6975" y="120.9675" size="1.27" layer="27" rot="R180"/>
</element>
<element name="R73" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1206" package3d_urn="urn:adsk.eagle:package:23566/2" value="10k" x="113.9825" y="129.54" smashed="yes">
<attribute name="NAME" x="112.7125" y="130.81" size="1.27" layer="25"/>
<attribute name="POPULARITY" value="17" x="154.6225" y="57.15" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="154.6225" y="57.15" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="112.7125" y="130.81" size="1.27" layer="27"/>
</element>
<element name="R74" library="rcl" library_urn="urn:adsk.eagle:library:334" package="RTRIM64W" package3d_urn="urn:adsk.eagle:package:23748/1" value="10k-DVM" x="117.7925" y="124.46" smashed="yes" rot="MR270">
<attribute name="NAME" x="122.7425" y="128.3" size="1.27" layer="26" rot="MR0"/>
<attribute name="POPULARITY" value="0" x="163.5125" y="71.12" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="SPICEMODEL" value="X" x="163.5125" y="71.12" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="SPICEPREFIXL" value="POT" x="163.5125" y="71.12" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="VALUE" x="118.615" y="127.425" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="R75" library="rcl" library_urn="urn:adsk.eagle:library:334" package="RTRIM64W" package3d_urn="urn:adsk.eagle:package:23748/1" value="10k -10V." x="118.745" y="112.395" smashed="yes" rot="MR270">
<attribute name="NAME" x="123.695" y="116.235" size="1.27" layer="26" rot="MR0"/>
<attribute name="POPULARITY" value="0" x="164.465" y="36.195" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="SPICEMODEL" value="X" x="164.465" y="36.195" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="SPICEPREFIXL" value="POT" x="164.465" y="36.195" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="VALUE" x="116.6525" y="116.415" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="R76" library="rcl" library_urn="urn:adsk.eagle:library:334" package="RTRIM64W" package3d_urn="urn:adsk.eagle:package:23748/1" value="10k -30V" x="133.0325" y="118.11" smashed="yes" rot="MR90">
<attribute name="NAME" x="128.0825" y="114.27" size="1.27" layer="26" rot="MR180"/>
<attribute name="POPULARITY" value="0" x="75.8825" y="132.08" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEMODEL" value="X" x="75.8825" y="132.08" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIXL" value="POT" x="75.8825" y="132.08" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="VALUE" x="129.9875" y="122.765" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="R68" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1206" package3d_urn="urn:adsk.eagle:package:23566/2" value="100k" x="129.2225" y="123.5075" smashed="yes">
<attribute name="NAME" x="127.9525" y="124.7775" size="1.27" layer="25"/>
<attribute name="POPULARITY" value="17" x="144.4625" y="51.1175" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="144.4625" y="51.1175" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="128.905" y="124.7775" size="1.27" layer="27"/>
</element>
<element name="R69" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1406" package3d_urn="urn:adsk.eagle:package:23569/2" value="10k" x="121.92" y="117.7925" smashed="yes" rot="R90">
<attribute name="NAME" x="120.65" y="116.5225" size="1.27" layer="25" rot="R90"/>
<attribute name="POPULARITY" value="0" x="194.31" y="138.1125" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="194.31" y="138.1125" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="123.5075" y="121.285" size="1.27" layer="27" rot="R180"/>
</element>
<element name="S1" library="switch-omron" library_urn="urn:adsk.eagle:library:377" package="B3F-10XX" package3d_urn="urn:adsk.eagle:package:27496/1" value="K1" x="136.525" y="106.9975" smashed="yes" rot="R270">
<attribute name="MF" value="" x="81.915" y="68.8975" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MPN" value="B3F-1000" x="81.915" y="68.8975" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="NAME" x="140.208" y="110.0455" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="OC_FARNELL" value="176432" x="81.915" y="68.8975" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_NEWARK" value="36M3542" x="81.915" y="68.8975" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="POPULARITY" value="72" x="81.915" y="68.8975" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="135.6995" y="111.76" size="1.27" layer="27" ratio="10"/>
</element>
<element name="S2" library="switch-omron" library_urn="urn:adsk.eagle:library:377" package="B3F-10XX" package3d_urn="urn:adsk.eagle:package:27496/1" value="K2" x="147.0025" y="106.9975" smashed="yes" rot="R270">
<attribute name="MF" value="" x="92.3925" y="58.7375" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MPN" value="B3F-1000" x="92.3925" y="58.7375" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="NAME" x="150.6855" y="110.0455" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="OC_FARNELL" value="176432" x="92.3925" y="58.7375" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_NEWARK" value="36M3542" x="92.3925" y="58.7375" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="POPULARITY" value="72" x="92.3925" y="58.7375" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="146.177" y="111.4425" size="1.27" layer="27" ratio="10"/>
</element>
<element name="S3" library="switch-omron" library_urn="urn:adsk.eagle:library:377" package="B3F-10XX" package3d_urn="urn:adsk.eagle:package:27496/1" value="K3" x="157.48" y="106.9975" smashed="yes" rot="R90">
<attribute name="MF" value="" x="212.09" y="165.4175" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="B3F-1000" x="212.09" y="165.4175" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="NAME" x="153.797" y="103.9495" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="OC_FARNELL" value="176432" x="212.09" y="165.4175" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_NEWARK" value="36M3542" x="212.09" y="165.4175" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="POPULARITY" value="72" x="212.09" y="165.4175" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="158.623" y="112.395" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R77" library="rcl" library_urn="urn:adsk.eagle:library:334" package="RTRIM4G/J" package3d_urn="urn:adsk.eagle:package:23728/1" value="5k" x="113.9825" y="135.5725" smashed="yes" rot="R270">
<attribute name="NAME" x="111.4425" y="138.4475" size="1.27" layer="25"/>
<attribute name="POPULARITY" value="1" x="113.9825" y="135.5725" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEMODEL" value="X" x="113.9825" y="135.5725" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIXL" value="POT" x="113.9825" y="135.5725" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="113.3475" y="138.83" size="1.27" layer="27"/>
</element>
<element name="C30" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="100n" x="136.8425" y="138.43" smashed="yes" rot="R180">
<attribute name="NAME" x="138.1125" y="137.16" size="1.27" layer="25" rot="R180"/>
<attribute name="POPULARITY" value="54" x="136.8425" y="138.43" size="2.1844" layer="27" font="vector" ratio="15" rot="R180" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="136.8425" y="138.43" size="2.1844" layer="27" font="vector" ratio="15" rot="R180" display="off"/>
<attribute name="VALUE" x="138.1125" y="140.97" size="1.27" layer="27" rot="R180"/>
</element>
<element name="V2" library="solpad" library_urn="urn:adsk.eagle:library:364" package="LSP10" package3d_urn="urn:adsk.eagle:package:26501/1" value="LSP10" x="111.125" y="118.4275" smashed="yes">
<attribute name="NAME" x="109.855" y="119.6975" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="52" x="111.125" y="118.4275" size="2.1844" layer="27" font="vector" ratio="15" display="off"/>
<attribute name="VALUE" x="111.125" y="118.6815" size="0.0254" layer="27"/>
</element>
<element name="R78" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1206" package3d_urn="urn:adsk.eagle:package:23566/2" value="360" x="157.48" y="143.1925" smashed="yes" rot="R180">
<attribute name="NAME" x="158.75" y="141.9225" size="1.27" layer="25" rot="R180"/>
<attribute name="POPULARITY" value="17" x="157.48" y="143.1925" size="2.54" layer="27" font="vector" ratio="15" rot="R180" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="157.48" y="143.1925" size="2.54" layer="27" font="vector" ratio="15" rot="R180" display="off"/>
<attribute name="VALUE" x="158.75" y="145.7325" size="1.27" layer="27" rot="R180"/>
</element>
<element name="RELé" library="solpad" library_urn="urn:adsk.eagle:library:364" package="LSP10" package3d_urn="urn:adsk.eagle:package:26501/1" value="relé" x="129.54" y="140.0175" smashed="yes">
<attribute name="NAME" x="128.27" y="141.2875" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="52" x="129.54" y="140.0175" size="2.54" layer="27" font="vector" ratio="15" display="off"/>
<attribute name="VALUE" x="129.54" y="140.2715" size="0.0254" layer="27"/>
</element>
<element name="PWM" library="solpad" library_urn="urn:adsk.eagle:library:364" package="LSP10" package3d_urn="urn:adsk.eagle:package:26501/1" value="LSP10" x="145.7325" y="124.46" smashed="yes">
<attribute name="NAME" x="144.4625" y="125.73" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="52" x="145.7325" y="124.46" size="2.54" layer="27" font="vector" ratio="15" display="off"/>
<attribute name="VALUE" x="145.7325" y="124.714" size="0.0254" layer="27"/>
</element>
<element name="R79" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1206" package3d_urn="urn:adsk.eagle:package:23566/2" value="1k" x="142.24" y="138.43" smashed="yes" rot="R180">
<attribute name="NAME" x="143.51" y="137.16" size="1.27" layer="25" rot="R180"/>
<attribute name="POPULARITY" value="17" x="142.24" y="138.43" size="1.778" layer="27" font="vector" ratio="15" rot="R180" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="142.24" y="138.43" size="1.778" layer="27" font="vector" ratio="15" rot="R180" display="off"/>
<attribute name="VALUE" x="141.9225" y="140.97" size="1.27" layer="27" rot="R180"/>
</element>
<element name="LED5" library="led" library_urn="urn:adsk.eagle:library:259" package="LED3MM" package3d_urn="urn:adsk.eagle:package:15797/1" value="piros" x="157.1625" y="140.0175" smashed="yes" rot="MR180">
<attribute name="NAME" x="160.3375" y="139.4841" size="1.27" layer="26" ratio="10" rot="MR180"/>
<attribute name="POPULARITY" value="97" x="157.1625" y="140.0175" size="1.778" layer="28" font="vector" ratio="15" rot="MR180" display="off"/>
<attribute name="VALUE" x="155.6004" y="144.9959" size="1.27" layer="28" ratio="10" rot="MR180"/>
</element>
<element name="IC10" library="linear" library_urn="urn:adsk.eagle:library:262" package="DIL08" package3d_urn="urn:adsk.eagle:package:16409/2" value="TLC272P" x="171.7675" y="128.27" smashed="yes" rot="MR0">
<attribute name="NAME" x="177.1015" y="125.349" size="1.27" layer="26" ratio="10" rot="MR90"/>
<attribute name="POPULARITY" value="1" x="171.7675" y="128.27" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="VALUE" x="175.3235" y="127.635" size="1.27" layer="28" ratio="10" rot="MR0"/>
</element>
<element name="R80" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1206" package3d_urn="urn:adsk.eagle:package:23566/2" value="100k" x="171.7675" y="138.1125" smashed="yes">
<attribute name="NAME" x="170.4975" y="139.3825" size="1.27" layer="25"/>
<attribute name="POPULARITY" value="17" x="171.7675" y="138.1125" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="171.7675" y="138.1125" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="169.8625" y="139.3825" size="1.27" layer="27"/>
</element>
<element name="R81" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1206" package3d_urn="urn:adsk.eagle:package:23566/2" value="10k" x="171.7675" y="134.9375" smashed="yes" rot="R180">
<attribute name="NAME" x="173.0375" y="133.6675" size="1.27" layer="25" rot="R180"/>
<attribute name="POPULARITY" value="17" x="171.7675" y="134.9375" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="171.7675" y="134.9375" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="170.18" y="136.8425" size="1.27" layer="27" rot="R180"/>
</element>
<element name="R82" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1406" package3d_urn="urn:adsk.eagle:package:23569/2" value="10k" x="177.8" y="127.3175" smashed="yes" rot="R270">
<attribute name="NAME" x="179.07" y="128.5875" size="1.27" layer="25" rot="R270"/>
<attribute name="POPULARITY" value="0" x="177.8" y="127.3175" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="177.8" y="127.3175" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="175.895" y="129.2225" size="1.27" layer="27"/>
</element>
<element name="R83" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1206" package3d_urn="urn:adsk.eagle:package:23566/2" value="100k" x="178.7525" y="121.6025" smashed="yes" rot="R180">
<attribute name="NAME" x="180.0225" y="120.3325" size="1.27" layer="25" rot="R180"/>
<attribute name="POPULARITY" value="17" x="178.7525" y="121.6025" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="178.7525" y="121.6025" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="180.6575" y="124.1425" size="1.27" layer="27" rot="R180"/>
</element>
<element name="R84" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1206" package3d_urn="urn:adsk.eagle:package:23566/2" value="5.1k" x="178.7525" y="117.475" smashed="yes" rot="R180">
<attribute name="NAME" x="180.0225" y="116.205" size="1.27" layer="25" rot="R180"/>
<attribute name="POPULARITY" value="17" x="178.7525" y="117.475" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="178.7525" y="117.475" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="180.0225" y="120.015" size="1.27" layer="27" rot="R180"/>
</element>
<element name="R85" library="rcl" library_urn="urn:adsk.eagle:library:334" package="RTRIM64W" package3d_urn="urn:adsk.eagle:package:23748/1" value="2k A" x="173.0375" y="116.205" smashed="yes" rot="MR90">
<attribute name="NAME" x="168.0875" y="113.585" size="1.27" layer="26" rot="MR180"/>
<attribute name="POPULARITY" value="0" x="173.0375" y="116.205" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEMODEL" value="X" x="173.0375" y="116.205" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIXL" value="POT" x="173.0375" y="116.205" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="VALUE" x="170.31" y="120.555" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="R86" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1206" package3d_urn="urn:adsk.eagle:package:23566/2" value="150" x="170.4975" y="113.665" smashed="yes" rot="R90">
<attribute name="NAME" x="169.2275" y="112.395" size="1.27" layer="25" rot="R90"/>
<attribute name="POPULARITY" value="17" x="170.4975" y="113.665" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="170.4975" y="113.665" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="169.545" y="116.5225" size="1.27" layer="27" rot="R180"/>
</element>
<element name="C31" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="100n" x="165.735" y="136.525" smashed="yes" rot="R270">
<attribute name="NAME" x="167.005" y="137.795" size="1.27" layer="25" rot="R270"/>
<attribute name="POPULARITY" value="54" x="165.735" y="136.525" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="165.735" y="136.525" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="163.5125" y="138.7475" size="1.27" layer="27"/>
</element>
<element name="C32" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="100n" x="159.0675" y="119.6975" smashed="yes" rot="R90">
<attribute name="NAME" x="157.7975" y="118.4275" size="1.27" layer="25" rot="R90"/>
<attribute name="POPULARITY" value="54" x="159.0675" y="119.6975" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="159.0675" y="119.6975" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="160.02" y="122.8725" size="1.27" layer="27" rot="R180"/>
</element>
<element name="R87" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1206" package3d_urn="urn:adsk.eagle:package:23566/2" value="150+0.23" x="159.385" y="114.3" smashed="yes">
<attribute name="NAME" x="158.115" y="115.57" size="1.27" layer="25"/>
<attribute name="POPULARITY" value="17" x="159.385" y="114.3" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="159.385" y="114.3" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="155.2575" y="115.57" size="1.27" layer="27"/>
</element>
<element name="A1" library="solpad" library_urn="urn:adsk.eagle:library:364" package="LSP10" package3d_urn="urn:adsk.eagle:package:26501/1" value="DND1" x="164.1475" y="116.5225" smashed="yes">
<attribute name="NAME" x="162.8775" y="117.7925" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="52" x="164.1475" y="116.5225" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="164.1475" y="116.7765" size="0.0254" layer="27"/>
</element>
<element name="GND" library="solpad" library_urn="urn:adsk.eagle:library:364" package="LSP10" package3d_urn="urn:adsk.eagle:package:26501/1" value="GND2" x="164.1475" y="110.1725" smashed="yes">
<attribute name="NAME" x="162.8775" y="111.4425" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="52" x="164.1475" y="110.1725" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="164.1475" y="110.4265" size="0.0254" layer="27"/>
</element>
<element name="JP7" library="jumper" library_urn="urn:adsk.eagle:library:252" package="JP2" package3d_urn="urn:adsk.eagle:package:15452/1" value="" x="162.8775" y="127" smashed="yes" rot="R270">
<attribute name="NAME" x="164.5285" y="130.556" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="POPULARITY" value="34" x="162.8775" y="127" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="158.5595" y="130.556" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="JP8" library="jumper" library_urn="urn:adsk.eagle:library:252" package="JP2" package3d_urn="urn:adsk.eagle:package:15452/1" value="" x="179.07" y="134.62" smashed="yes" rot="R90">
<attribute name="NAME" x="177.419" y="131.064" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="POPULARITY" value="34" x="179.07" y="134.62" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="183.388" y="131.064" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="C33" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="100n" x="133.0325" y="131.1275" smashed="yes" rot="R270">
<attribute name="NAME" x="134.3025" y="132.3975" size="1.27" layer="25" rot="R270"/>
<attribute name="POPULARITY" value="54" x="133.0325" y="131.1275" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="133.0325" y="131.1275" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="131.7625" y="133.35" size="1.27" layer="27"/>
</element>
<element name="C34" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="100n" x="130.4925" y="131.1275" smashed="yes" rot="R270">
<attribute name="NAME" x="131.7625" y="132.3975" size="1.27" layer="25" rot="R270"/>
<attribute name="POPULARITY" value="54" x="130.4925" y="131.1275" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="130.4925" y="131.1275" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="127.635" y="133.35" size="1.27" layer="27"/>
</element>
<element name="C35" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="100n" x="125.4125" y="131.1275" smashed="yes" rot="R270">
<attribute name="NAME" x="126.6825" y="132.3975" size="1.27" layer="25" rot="R270"/>
<attribute name="POPULARITY" value="54" x="125.4125" y="131.1275" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="125.4125" y="131.1275" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="122.8725" y="133.35" size="1.27" layer="27"/>
</element>
<element name="D12" library="diode" library_urn="urn:adsk.eagle:library:210" package="SOD80C" package3d_urn="urn:adsk.eagle:package:43405/2" value="8.2ZV" x="125.73" y="120.015" smashed="yes" rot="R270">
<attribute name="NAME" x="126.873" y="121.539" size="1.27" layer="25" rot="R270"/>
<attribute name="POPULARITY" value="6" x="125.73" y="120.015" size="1.9304" layer="27" font="vector" ratio="15" rot="R270" display="off"/>
<attribute name="VALUE" x="122.301" y="122.3645" size="1.27" layer="27"/>
</element>
<element name="R88" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1206" package3d_urn="urn:adsk.eagle:package:23566/2" value="100k" x="120.3325" y="125.73" smashed="yes" rot="R180">
<attribute name="NAME" x="121.6025" y="124.46" size="1.27" layer="25" rot="R180"/>
<attribute name="POPULARITY" value="17" x="120.3325" y="125.73" size="2.1844" layer="27" font="vector" ratio="15" rot="R180" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="120.3325" y="125.73" size="2.1844" layer="27" font="vector" ratio="15" rot="R180" display="off"/>
<attribute name="VALUE" x="119.0625" y="127.9525" size="1.27" layer="27" rot="R180"/>
</element>
<element name="C36" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="100n" x="175.26" y="142.24" smashed="yes" rot="R180">
<attribute name="NAME" x="176.53" y="140.97" size="1.27" layer="25" rot="R180"/>
<attribute name="POPULARITY" value="54" x="175.26" y="142.24" size="2.1844" layer="27" font="vector" ratio="15" rot="R180" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="175.26" y="142.24" size="2.1844" layer="27" font="vector" ratio="15" rot="R180" display="off"/>
<attribute name="VALUE" x="176.53" y="144.78" size="1.27" layer="27" rot="R180"/>
</element>
<element name="C37" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="100n" x="167.9575" y="127.635" smashed="yes">
<attribute name="NAME" x="166.6875" y="128.905" size="1.27" layer="25"/>
<attribute name="POPULARITY" value="54" x="167.9575" y="127.635" size="2.1844" layer="27" font="vector" ratio="15" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="167.9575" y="127.635" size="2.1844" layer="27" font="vector" ratio="15" display="off"/>
<attribute name="VALUE" x="166.37" y="128.905" size="1.27" layer="27"/>
</element>
<element name="IC11" library="v-reg" library_urn="urn:adsk.eagle:library:409" package="78MXXS" package3d_urn="urn:adsk.eagle:package:30347/1" value="4274V50" x="168.91" y="145.7325" smashed="yes" rot="MR0">
<attribute name="NAME" x="173.736" y="139.2555" size="1.27" layer="26" ratio="10" rot="MR0"/>
<attribute name="POPULARITY" value="1" x="168.91" y="145.7325" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="VALUE" x="181.0385" y="144.5895" size="1.27" layer="28" ratio="10" rot="MR0"/>
</element>
<element name="C38" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="100n" x="220.0275" y="130.175" smashed="yes">
<attribute name="NAME" x="218.7575" y="131.445" size="1.27" layer="25"/>
<attribute name="POPULARITY" value="54" x="288.6075" y="28.575" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="288.6075" y="28.575" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="220.0275" y="131.445" size="1.27" layer="27"/>
</element>
<element name="C42" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C1210" package3d_urn="urn:adsk.eagle:package:23619/2" value="10uF" x="200.3425" y="113.9825" smashed="yes">
<attribute name="NAME" x="198.4375" y="116.5225" size="1.27" layer="25"/>
<attribute name="POPULARITY" value="0" x="282.8925" y="28.8925" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="282.8925" y="28.8925" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="202.565" y="117.1575" size="1.27" layer="27" rot="R180"/>
</element>
<element name="C43" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="10uF" x="203.5175" y="148.9075" smashed="yes" rot="R180">
<attribute name="NAME" x="205.4225" y="147.0025" size="1.27" layer="25" rot="R180"/>
<attribute name="POPULARITY" value="54" x="143.8275" y="242.8875" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="143.8275" y="242.8875" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="205.74" y="148.2725" size="1.27" layer="27"/>
</element>
<element name="C44" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="100n" x="203.5175" y="146.3675" smashed="yes">
<attribute name="NAME" x="202.2475" y="147.6375" size="1.27" layer="25"/>
<attribute name="POPULARITY" value="54" x="310.1975" y="44.7675" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="310.1975" y="44.7675" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="209.2325" y="147.0025" size="1.27" layer="27" rot="R180"/>
</element>
<element name="C45" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="100n" x="200.3425" y="118.745" smashed="yes" rot="R180">
<attribute name="NAME" x="202.5755" y="116.918" size="1.27" layer="25" rot="R180"/>
<attribute name="POPULARITY" value="54" x="100.0125" y="212.725" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="100.0125" y="212.725" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="202.258" y="121.2695" size="1.27" layer="27" rot="R180"/>
</element>
<element name="C39" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="100n" x="224.79" y="146.05" smashed="yes">
<attribute name="NAME" x="223.52" y="147.32" size="1.27" layer="25"/>
<attribute name="POPULARITY" value="54" x="299.72" y="44.45" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="299.72" y="44.45" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="223.901" y="147.3835" size="1.27" layer="27"/>
</element>
<element name="C46" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="10uF" x="248.92" y="124.46" smashed="yes" rot="R270">
<attribute name="NAME" x="250.825" y="126.365" size="1.27" layer="25" rot="R270"/>
<attribute name="POPULARITY" value="54" x="154.94" y="58.42" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="154.94" y="58.42" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="247.015" y="126.365" size="1.27" layer="27"/>
</element>
<element name="C47" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="220n" x="252.4125" y="124.46" smashed="yes" rot="R270">
<attribute name="NAME" x="253.6825" y="125.73" size="1.27" layer="25" rot="R270"/>
<attribute name="POPULARITY" value="54" x="150.8125" y="11.43" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="150.8125" y="11.43" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="251.46" y="126.6825" size="1.27" layer="27"/>
</element>
<element name="C40" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="220n" x="242.57" y="145.0975" smashed="yes" rot="R180">
<attribute name="NAME" x="243.84" y="143.8275" size="1.27" layer="25" rot="R180"/>
<attribute name="POPULARITY" value="54" x="161.29" y="246.6975" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="161.29" y="246.6975" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="245.745" y="147.7645" size="1.27" layer="27" rot="R180"/>
</element>
<element name="C48" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C1210" package3d_urn="urn:adsk.eagle:package:23619/2" value="22uF" x="258.1275" y="156.21" smashed="yes" rot="R270">
<attribute name="NAME" x="260.6675" y="158.115" size="1.27" layer="25" rot="R270"/>
<attribute name="POPULARITY" value="0" x="173.0375" y="92.71" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="173.0375" y="92.71" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="256.2225" y="158.4325" size="1.27" layer="27"/>
</element>
<element name="C49" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C1210" package3d_urn="urn:adsk.eagle:package:23619/2" value="22uF" x="236.22" y="128.905" smashed="yes" rot="R90">
<attribute name="NAME" x="234.315" y="127" size="1.27" layer="25" rot="R90"/>
<attribute name="POPULARITY" value="0" x="330.2" y="182.245" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="330.2" y="182.245" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="234.823" y="131.191" size="1.27" layer="27" rot="R180"/>
</element>
<element name="C41" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="100n" x="242.8875" y="130.81" smashed="yes" rot="R180">
<attribute name="NAME" x="244.1575" y="129.54" size="1.27" layer="25" rot="R180"/>
<attribute name="POPULARITY" value="54" x="155.2575" y="232.41" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="155.2575" y="232.41" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="237.1725" y="130.81" size="1.27" layer="27"/>
</element>
<element name="C50" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C1808" package3d_urn="urn:adsk.eagle:package:23689/2" value="47uF" x="251.1425" y="110.49" smashed="yes" rot="R270">
<attribute name="NAME" x="252.4125" y="111.125" size="1.27" layer="25" rot="R270"/>
<attribute name="POPULARITY" value="0" x="149.5425" y="48.26" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="149.5425" y="48.26" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="251.7775" y="114.3" size="1.27" layer="27" rot="R180"/>
</element>
<element name="D13" library="diode" library_urn="urn:adsk.eagle:library:210" package="SOD80C" package3d_urn="urn:adsk.eagle:package:43405/2" value="1n4148" x="261.62" y="155.8925" smashed="yes" rot="R90">
<attribute name="NAME" x="260.477" y="154.3685" size="1.27" layer="25" rot="R90"/>
<attribute name="POPULARITY" value="9" x="377.19" y="221.9325" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="265.3665" y="161.163" size="1.27" layer="27" rot="R180"/>
</element>
<element name="D14" library="diode" library_urn="urn:adsk.eagle:library:210" package="SMB" package3d_urn="urn:adsk.eagle:package:43404/2" value="SS14" x="246.0625" y="101.9175" smashed="yes" rot="R270">
<attribute name="NAME" x="247.2055" y="103.4415" size="1.27" layer="25" rot="R270"/>
<attribute name="POPULARITY" value="11" x="130.4925" y="23.1775" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="243.7765" y="103.0605" size="1.27" layer="27" rot="R180"/>
</element>
<element name="D15" library="diode" library_urn="urn:adsk.eagle:library:210" package="SOD80C" package3d_urn="urn:adsk.eagle:package:43405/2" value="3.3ZV" x="234.315" y="110.1725" smashed="yes" rot="R90">
<attribute name="NAME" x="233.172" y="108.6485" size="1.27" layer="25" rot="R90"/>
<attribute name="POPULARITY" value="6" x="349.885" y="182.5625" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="235.5215" y="113.538" size="1.27" layer="27" rot="R180"/>
</element>
<element name="DIS2" library="display-lcd" library_urn="urn:adsk.eagle:library:214" package="TUXGR_16X2_R2" package3d_urn="urn:adsk.eagle:package:13139/1" value="TUXGR_16X2_R2" x="235.585" y="142.24" smashed="yes">
<attribute name="MF" value="" x="288.925" y="123.19" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="" x="288.925" y="123.19" size="1.778" layer="27" display="off"/>
<attribute name="NAME" x="197.485" y="160.655" size="1.27" layer="25"/>
<attribute name="OC_FARNELL" value="unknown" x="288.925" y="123.19" size="1.778" layer="27" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="288.925" y="123.19" size="1.778" layer="27" display="off"/>
<attribute name="POPULARITY" value="5" x="288.925" y="123.19" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="218.7575" y="160.02" size="1.27" layer="27"/>
</element>
<element name="IC12" library="ic-package" library_urn="urn:adsk.eagle:library:239" package="DIL28-3" package3d_urn="urn:adsk.eagle:package:827/2" value="ATMEGA8L" x="242.57" y="139.065" smashed="yes" rot="MR180">
<attribute name="NAME" x="224.536" y="141.986" size="1.27" layer="26" ratio="10" rot="MR270"/>
<attribute name="POPULARITY" value="8" x="285.75" y="201.295" size="1.778" layer="28" rot="MR180" display="off"/>
<attribute name="VALUE" x="237.871" y="139.7" size="1.27" layer="28" ratio="10" rot="MR180"/>
</element>
<element name="IC13" library="linear" library_urn="urn:adsk.eagle:library:262" package="DIL08" package3d_urn="urn:adsk.eagle:package:16409/2" value="OP07CQ" x="202.565" y="139.7" smashed="yes" rot="MR0">
<attribute name="NAME" x="207.899" y="136.779" size="1.27" layer="26" ratio="10" rot="MR90"/>
<attribute name="POPULARITY" value="0" x="160.655" y="66.04" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="VALUE" x="198.374" y="140.335" size="1.27" layer="28" ratio="10" rot="MR180"/>
</element>
<element name="LED6" library="led" library_urn="urn:adsk.eagle:library:259" package="LED5MM" package3d_urn="urn:adsk.eagle:package:15799/2" value="piros" x="235.585" y="121.285" smashed="yes" rot="R270">
<attribute name="NAME" x="236.1184" y="118.11" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="POPULARITY" value="93" x="133.985" y="90.805" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="232.8291" y="122.3264" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="LSP13" library="solpad" library_urn="urn:adsk.eagle:library:364" package="LSP10" package3d_urn="urn:adsk.eagle:package:26501/1" value="LSP10" x="249.555" y="157.1625" smashed="yes">
<attribute name="NAME" x="248.285" y="158.4325" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="52" x="277.495" y="36.5125" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="249.555" y="157.4165" size="0.0254" layer="27"/>
</element>
<element name="Q7" library="transistor-small-signal" library_urn="urn:adsk.eagle:library:401" package="SOT23" package3d_urn="urn:adsk.eagle:package:28738/2" value="BSS123" x="255.5875" y="109.5375" smashed="yes" rot="R180">
<attribute name="NAME" x="257.4925" y="107.6325" size="1.27" layer="25" rot="R180"/>
<attribute name="POPULARITY" value="21" x="236.5375" y="203.5175" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="252.095" y="111.125" size="1.27" layer="27"/>
</element>
<element name="Q8" library="transistor-small-signal" library_urn="urn:adsk.eagle:library:401" package="SOT23" package3d_urn="urn:adsk.eagle:package:28738/2" value="BSS123" x="265.7475" y="116.205" smashed="yes" rot="R180">
<attribute name="NAME" x="267.6525" y="114.3" size="1.27" layer="25" rot="R180"/>
<attribute name="POPULARITY" value="21" x="239.0775" y="210.185" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="263.525" y="117.7925" size="1.27" layer="27"/>
</element>
<element name="R89" library="rcl" library_urn="urn:adsk.eagle:library:334" package="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="10k" x="221.9325" y="148.9075" smashed="yes" rot="R180">
<attribute name="NAME" x="223.2025" y="147.6375" size="1.27" layer="25" rot="R180"/>
<attribute name="POPULARITY" value="41" x="155.8925" y="258.1275" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="155.8925" y="258.1275" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="220.4085" y="150.368" size="1.27" layer="27"/>
</element>
<element name="R99" library="rcl" library_urn="urn:adsk.eagle:library:334" package="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="22k" x="253.365" y="154.94" smashed="yes" rot="R180">
<attribute name="NAME" x="254.635" y="153.67" size="1.27" layer="25" rot="R180"/>
<attribute name="POPULARITY" value="41" x="156.845" y="264.16" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="156.845" y="264.16" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="248.92" y="154.305" size="1.27" layer="27"/>
</element>
<element name="R100" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1406" package3d_urn="urn:adsk.eagle:package:23569/2" value="10k" x="266.7" y="155.575" smashed="yes" rot="R90">
<attribute name="NAME" x="265.43" y="154.305" size="1.27" layer="25" rot="R90"/>
<attribute name="POPULARITY" value="0" x="375.92" y="257.175" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="375.92" y="257.175" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="267.97" y="159.0675" size="1.27" layer="27" rot="R180"/>
</element>
<element name="R101" library="rcl" library_urn="urn:adsk.eagle:library:334" package="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="1k" x="253.365" y="157.48" smashed="yes">
<attribute name="NAME" x="252.095" y="158.75" size="1.27" layer="25"/>
<attribute name="POPULARITY" value="41" x="360.045" y="48.26" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="360.045" y="48.26" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="252.095" y="159.0675" size="1.27" layer="27"/>
</element>
<element name="R92" library="rcl" library_urn="urn:adsk.eagle:library:334" package="RTRIM43P" package3d_urn="urn:adsk.eagle:package:23756/1" value="100k páka hőfok beáll." x="208.915" y="125.095" smashed="yes" rot="MR90">
<attribute name="NAME" x="203.965" y="122.475" size="1.27" layer="26" rot="MR180"/>
<attribute name="POPULARITY" value="4" x="145.415" y="193.675" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEMODEL" value="X" x="145.415" y="193.675" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIXL" value="POT" x="145.415" y="193.675" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="VALUE" x="230.375" y="129.9525" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="R104" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1406" package3d_urn="urn:adsk.eagle:package:23569/2" value="1M" x="235.9025" y="103.505" smashed="yes" rot="R270">
<attribute name="NAME" x="237.1725" y="104.775" size="1.27" layer="25" rot="R270"/>
<attribute name="POPULARITY" value="0" x="126.6825" y="-8.255" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="126.6825" y="-8.255" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="234.6325" y="105.7275" size="1.27" layer="27"/>
</element>
<element name="R106" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1206" package3d_urn="urn:adsk.eagle:package:23566/2" value="100k" x="250.5075" y="103.01425" smashed="yes" rot="R270">
<attribute name="NAME" x="251.7775" y="104.28425" size="1.27" layer="25" rot="R270"/>
<attribute name="POPULARITY" value="17" x="141.2875" y="73.80425" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="141.2875" y="73.80425" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="248.14075" y="105.41" size="1.27" layer="27"/>
</element>
<element name="R107" library="rcl" library_urn="urn:adsk.eagle:library:334" package="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="100" x="254.3175" y="100.33" smashed="yes">
<attribute name="NAME" x="253.0475" y="101.6" size="1.27" layer="25"/>
<attribute name="POPULARITY" value="41" x="274.6375" y="-15.24" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="274.6375" y="-15.24" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="257.4925" y="102.87" size="1.27" layer="27" rot="R180"/>
</element>
<element name="R95" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1406" package3d_urn="urn:adsk.eagle:package:23569/2" value="33" x="243.7275" y="139.065" smashed="yes">
<attribute name="NAME" x="242.4575" y="140.335" size="1.27" layer="25"/>
<attribute name="POPULARITY" value="0" x="269.1275" y="23.495" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="269.1275" y="23.495" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="242.775" y="140.335" size="1.27" layer="27"/>
</element>
<element name="R96" library="rcl" library_urn="urn:adsk.eagle:library:334" package="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="1.8k" x="248.92" y="130.175" smashed="yes" rot="R90">
<attribute name="NAME" x="247.65" y="128.905" size="1.27" layer="25" rot="R90"/>
<attribute name="POPULARITY" value="41" x="358.14" y="172.085" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="358.14" y="172.085" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="253.6825" y="131.445" size="1.27" layer="27" rot="R180"/>
</element>
<element name="R97" library="rcl" library_urn="urn:adsk.eagle:library:334" package="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="150" x="246.0625" y="127.3175" smashed="yes" rot="R90">
<attribute name="NAME" x="244.7925" y="126.0475" size="1.27" layer="25" rot="R90"/>
<attribute name="POPULARITY" value="41" x="361.6325" y="157.7975" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="361.6325" y="157.7975" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="247.9675" y="130.4925" size="1.27" layer="27" rot="R180"/>
</element>
<element name="R98" library="rcl" library_urn="urn:adsk.eagle:library:334" package="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="22" x="259.08" y="146.685" smashed="yes" rot="R90">
<attribute name="NAME" x="257.81" y="145.415" size="1.27" layer="25" rot="R90"/>
<attribute name="POPULARITY" value="41" x="374.65" y="182.245" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="374.65" y="182.245" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="259.715" y="149.86" size="1.27" layer="27" rot="R180"/>
</element>
<element name="R94" library="rcl" library_urn="urn:adsk.eagle:library:334" package="RTRIM43P" package3d_urn="urn:adsk.eagle:package:23756/1" value="10k ofset-0" x="213.6775" y="143.51" smashed="yes" rot="MR90">
<attribute name="NAME" x="208.7275" y="140.89" size="1.27" layer="26" rot="MR180"/>
<attribute name="POPULARITY" value="4" x="150.1775" y="222.25" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEMODEL" value="X" x="150.1775" y="222.25" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIXL" value="POT" x="150.1775" y="222.25" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="VALUE" x="209.9975" y="155.48" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="R93" library="rcl" library_urn="urn:adsk.eagle:library:334" package="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="360" x="240.9825" y="154.6225" smashed="yes" rot="R180">
<attribute name="NAME" x="242.2525" y="153.3525" size="1.27" layer="25" rot="R180"/>
<attribute name="POPULARITY" value="41" x="169.8625" y="263.8425" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="169.8625" y="263.8425" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="236.22" y="154.305" size="1.27" layer="27"/>
</element>
<element name="R108" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1406" package3d_urn="urn:adsk.eagle:package:23569/2" value="100" x="266.7" y="121.92" smashed="yes" rot="R270">
<attribute name="NAME" x="267.97" y="123.19" size="1.27" layer="25" rot="R270"/>
<attribute name="POPULARITY" value="0" x="151.13" y="76.2" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="151.13" y="76.2" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="262.5725" y="122.2375" size="1.27" layer="27"/>
</element>
<element name="R105" library="rcl" library_urn="urn:adsk.eagle:library:334" package="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="5.1k" x="237.1725" y="110.1725" smashed="yes" rot="R270">
<attribute name="NAME" x="238.4425" y="111.4425" size="1.27" layer="25" rot="R270"/>
<attribute name="POPULARITY" value="41" x="127.9525" y="49.2125" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="127.9525" y="49.2125" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="239.7125" y="113.665" size="1.27" layer="27" rot="R180"/>
</element>
<element name="R90" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1406" package3d_urn="urn:adsk.eagle:package:23569/2" value="180k" x="218.645" y="138.43" smashed="yes">
<attribute name="NAME" x="217.375" y="139.7" size="1.27" layer="25"/>
<attribute name="POPULARITY" value="0" x="241.505" y="29.21" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="241.505" y="29.21" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="214.1365" y="139.827" size="1.27" layer="27"/>
</element>
<element name="R91" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1406" package3d_urn="urn:adsk.eagle:package:23569/2" value="68k" x="214.0095" y="129.54" smashed="yes">
<attribute name="NAME" x="210.8345" y="131.445" size="1.27" layer="25"/>
<attribute name="POPULARITY" value="0" x="247.0295" y="35.56" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="247.0295" y="35.56" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="216.0125" y="132.7785" size="1.27" layer="27" rot="R180"/>
</element>
<element name="R102" library="rcl" library_urn="urn:adsk.eagle:library:334" package="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="470" x="209.247" y="121.285" smashed="yes">
<attribute name="NAME" x="207.977" y="122.555" size="1.27" layer="25"/>
<attribute name="POPULARITY" value="41" x="295.607" y="12.065" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="295.607" y="12.065" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="207.6595" y="122.555" size="1.27" layer="27"/>
</element>
<element name="R103" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1406" package3d_urn="urn:adsk.eagle:package:23569/2" value="1k" x="215.5825" y="119.38" smashed="yes" rot="R270">
<attribute name="NAME" x="217.4875" y="120.015" size="1.27" layer="25" rot="R270"/>
<attribute name="POPULARITY" value="0" x="106.3625" y="27.94" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="106.3625" y="27.94" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="214.63" y="121.6025" size="1.27" layer="27"/>
</element>
<element name="S4" library="switch-omron" library_urn="urn:adsk.eagle:library:377" package="B3F-10XX" package3d_urn="urn:adsk.eagle:package:27496/1" value="S1" x="210.185" y="110.8075" smashed="yes" rot="R270">
<attribute name="MF" value="" x="137.795" y="44.7675" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MPN" value="B3F-1000" x="137.795" y="44.7675" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="NAME" x="213.868" y="113.8555" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="OC_FARNELL" value="176432" x="137.795" y="44.7675" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_NEWARK" value="36M3542" x="137.795" y="44.7675" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="POPULARITY" value="72" x="137.795" y="44.7675" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="211.328" y="116.205" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="S5" library="switch-omron" library_urn="urn:adsk.eagle:library:377" package="B3F-10XX" package3d_urn="urn:adsk.eagle:package:27496/1" value="S2" x="227.0125" y="110.8075" smashed="yes" rot="R90">
<attribute name="MF" value="" x="299.4025" y="187.0075" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="B3F-1000" x="299.4025" y="187.0075" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="NAME" x="223.3295" y="107.7595" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="OC_FARNELL" value="176432" x="299.4025" y="187.0075" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_NEWARK" value="36M3542" x="299.4025" y="187.0075" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="POPULARITY" value="72" x="299.4025" y="187.0075" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="225.8695" y="115.2525" size="1.27" layer="27" ratio="10"/>
</element>
<element name="S6" library="switch-omron" library_urn="urn:adsk.eagle:library:377" package="B3F-10XX" package3d_urn="urn:adsk.eagle:package:27496/1" value="S3" x="243.84" y="110.8075" smashed="yes" rot="R270">
<attribute name="MF" value="" x="171.45" y="24.4475" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MPN" value="B3F-1000" x="171.45" y="24.4475" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="NAME" x="247.523" y="113.8555" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="OC_FARNELL" value="176432" x="171.45" y="24.4475" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_NEWARK" value="36M3542" x="171.45" y="24.4475" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="POPULARITY" value="72" x="171.45" y="24.4475" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="244.983" y="116.205" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="S7" library="switch-omron" library_urn="urn:adsk.eagle:library:377" package="B3F-10XX" package3d_urn="urn:adsk.eagle:package:27496/1" value="S4" x="260.6675" y="110.8075" smashed="yes" rot="R270">
<attribute name="MF" value="" x="188.2775" y="14.2875" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MPN" value="B3F-1000" x="188.2775" y="14.2875" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="NAME" x="264.3505" y="113.8555" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="OC_FARNELL" value="176432" x="188.2775" y="14.2875" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_NEWARK" value="36M3542" x="188.2775" y="14.2875" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="POPULARITY" value="72" x="188.2775" y="14.2875" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="261.8105" y="116.205" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="T8" library="transistor" library_urn="urn:adsk.eagle:library:402" package="TO92-CBE" package3d_urn="urn:adsk.eagle:package:29921/2" value="BC547" x="264.16" y="150.8125" smashed="yes" rot="MR0">
<attribute name="NAME" x="266.7" y="153.8605" size="1.27" layer="26" ratio="10" rot="MR0"/>
<attribute name="POPULARITY" value="0" x="207.01" y="66.9925" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="VALUE" x="261.62" y="155.3845" size="1.27" layer="28" ratio="10" rot="MR180"/>
</element>
<element name="VR1" library="v-reg" library_urn="urn:adsk.eagle:library:409" package="TO92-CLP" package3d_urn="urn:adsk.eagle:package:30363/1" value="TL431" x="242.2525" y="126.0475" smashed="yes" rot="MR180">
<attribute name="NAME" x="245.4275" y="125.4125" size="1.27" layer="26" ratio="10" rot="MR180"/>
<attribute name="POPULARITY" value="1" x="263.8425" y="246.6975" size="1.778" layer="28" rot="MR180" display="off"/>
<attribute name="VALUE" x="244.7925" y="128.27" size="1.27" layer="28" ratio="10" rot="MR0"/>
</element>
<element name="JP9" library="jumper" library_urn="urn:adsk.eagle:library:252" package="JP1" package3d_urn="urn:adsk.eagle:package:15455/1" value="" x="254.635" y="150.8125" smashed="yes" rot="MR90">
<attribute name="NAME" x="252.095" y="149.1615" size="1.27" layer="26" ratio="10" rot="MR180"/>
<attribute name="POPULARITY" value="61" x="254.635" y="150.8125" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="VALUE" x="252.095" y="153.7335" size="1.27" layer="28" ratio="10" rot="MR180"/>
</element>
<element name="OFSETMéRőP." library="solpad" library_urn="urn:adsk.eagle:library:364" package="SE11" package3d_urn="urn:adsk.eagle:package:26506/1" value="ofset mérőp." x="221.9325" y="138.43" smashed="yes">
<attribute name="NAME" x="220.6625" y="140.081" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="2" x="221.9325" y="138.43" size="2.1844" layer="27" font="vector" ratio="15" display="off"/>
<attribute name="VALUE" x="221.9325" y="138.811" size="0.0254" layer="27"/>
</element>
<element name="C51" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C1210" package3d_urn="urn:adsk.eagle:package:23619/2" value="10uF" x="219.71" y="123.5075" smashed="yes" rot="R180">
<attribute name="NAME" x="221.615" y="121.6025" size="1.27" layer="25" rot="R180"/>
<attribute name="POPULARITY" value="0" x="219.71" y="123.5075" size="2.1844" layer="27" font="vector" ratio="15" rot="R180" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="219.71" y="123.5075" size="2.1844" layer="27" font="vector" ratio="15" rot="R180" display="off"/>
<attribute name="VALUE" x="217.805" y="125.095" size="1.27" layer="27"/>
</element>
<element name="JP10" library="jumper" library_urn="urn:adsk.eagle:library:252" package="JP1" package3d_urn="urn:adsk.eagle:package:15455/1" value="" x="263.8425" y="134.3025" smashed="yes" rot="MR0">
<attribute name="NAME" x="265.4935" y="131.7625" size="1.27" layer="26" ratio="10" rot="MR90"/>
<attribute name="POPULARITY" value="61" x="263.8425" y="134.3025" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="VALUE" x="260.9215" y="131.7625" size="1.27" layer="28" ratio="10" rot="MR90"/>
</element>
<element name="LED7" library="led" library_urn="urn:adsk.eagle:library:259" package="LED5MM" package3d_urn="urn:adsk.eagle:package:15799/2" value="zöld" x="235.585" y="121.285" smashed="yes" rot="R90">
<attribute name="NAME" x="235.0516" y="124.46" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="POPULARITY" value="93" x="235.585" y="121.285" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="241.2746" y="122.1359" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="LSP14" library="solpad" library_urn="urn:adsk.eagle:library:364" package="SE11" package3d_urn="urn:adsk.eagle:package:26506/1" value="SE11" x="270.1925" y="106.045" smashed="yes">
<attribute name="NAME" x="268.9225" y="107.696" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="2" x="270.1925" y="106.045" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="270.1925" y="106.426" size="0.0254" layer="27"/>
</element>
<element name="J2" library="con-molex" library_urn="urn:adsk.eagle:library:165" package="6410-03" package3d_urn="urn:adsk.eagle:package:8078647/1" value="22-27-2031-03" x="202.409425" y="107.6325" smashed="yes" rot="MR270">
<attribute name="MF" value="MOLEX" x="202.409425" y="107.6325" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="MPN" value="" x="202.409425" y="107.6325" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="NAME" x="199.134325" y="111.4156" size="1.016" layer="26" ratio="10" rot="MR270"/>
<attribute name="OC_FARNELL" value="unknown" x="202.409425" y="107.6325" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="202.409425" y="107.6325" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="POPULARITY" value="0" x="202.409425" y="107.6325" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="VALUE" x="199.261325" y="113.8189" size="0.8128" layer="28" ratio="10" rot="MR180"/>
</element>
<element name="JP11" library="jumper" library_urn="urn:adsk.eagle:library:252" package="JP2" package3d_urn="urn:adsk.eagle:package:15452/1" value="" x="270.51" y="136.8425" smashed="yes" rot="MR270">
<attribute name="NAME" x="268.859" y="140.3985" size="1.27" layer="26" ratio="10" rot="MR270"/>
<attribute name="POPULARITY" value="34" x="270.51" y="136.8425" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="VALUE" x="274.828" y="140.3985" size="1.27" layer="28" ratio="10" rot="MR270"/>
</element>
<element name="L2" library="inductor-neosid" library_urn="urn:adsk.eagle:library:241" package="MS50" package3d_urn="urn:adsk.eagle:package:14699/1" value="100uH" x="260.6675" y="103.505" smashed="yes" rot="R90">
<attribute name="MF" value="" x="260.6675" y="103.505" size="2.54" layer="27" font="vector" ratio="18" rot="R90" display="off"/>
<attribute name="MPN" value="" x="260.6675" y="103.505" size="2.54" layer="27" font="vector" ratio="18" rot="R90" display="off"/>
<attribute name="NAME" x="262.3675" y="101.705" size="0.8128" layer="25" rot="R180"/>
<attribute name="OC_FARNELL" value="unknown" x="260.6675" y="103.505" size="2.54" layer="27" font="vector" ratio="18" rot="R90" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="260.6675" y="103.505" size="2.54" layer="27" font="vector" ratio="18" rot="R90" display="off"/>
<attribute name="POPULARITY" value="0" x="260.6675" y="103.505" size="2.54" layer="27" font="vector" ratio="18" rot="R90" display="off"/>
<attribute name="VALUE" x="262.3675" y="106.105" size="0.8128" layer="27" rot="R180"/>
</element>
<element name="R109" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1406" package3d_urn="urn:adsk.eagle:package:23569/2" value="00" x="256.8575" y="124.46" smashed="yes" rot="R270">
<attribute name="NAME" x="258.1275" y="125.73" size="1.27" layer="25" rot="R270"/>
<attribute name="POPULARITY" value="0" x="256.8575" y="124.46" size="2.1844" layer="27" font="vector" ratio="15" rot="R270" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="256.8575" y="124.46" size="2.1844" layer="27" font="vector" ratio="15" rot="R270" display="off"/>
<attribute name="VALUE" x="256.2225" y="126.6825" size="1.27" layer="27"/>
</element>
<element name="R110" library="rcl" library_urn="urn:adsk.eagle:library:334" package="M1406" package3d_urn="urn:adsk.eagle:package:23569/2" value="680" x="259.715" y="124.46" smashed="yes" rot="R90">
<attribute name="NAME" x="258.445" y="123.19" size="1.27" layer="25" rot="R90"/>
<attribute name="POPULARITY" value="0" x="259.715" y="124.46" size="2.1844" layer="27" font="vector" ratio="15" rot="R90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="259.715" y="124.46" size="2.1844" layer="27" font="vector" ratio="15" rot="R90" display="off"/>
<attribute name="VALUE" x="261.62" y="127.9525" size="1.27" layer="27" rot="R180"/>
</element>
<element name="JP12" library="jumper" library_urn="urn:adsk.eagle:library:252" package="JP1" package3d_urn="urn:adsk.eagle:package:15455/1" value="ofset-0" x="214.3125" y="125.4125" smashed="yes" rot="R90">
<attribute name="NAME" x="216.8525" y="123.7615" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="POPULARITY" value="61" x="214.3125" y="125.4125" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="216.8525" y="128.016" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="LSP15" library="solpad" library_urn="urn:adsk.eagle:library:364" package="SE11" package3d_urn="urn:adsk.eagle:package:26506/1" value="SE11" x="200.025" y="149.86" smashed="yes">
<attribute name="NAME" x="198.755" y="151.511" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="2" x="200.025" y="149.86" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="200.025" y="150.241" size="0.0254" layer="27"/>
</element>
<element name="R111" library="rcl" library_urn="urn:adsk.eagle:library:334" package="RTRIM4G/J" package3d_urn="urn:adsk.eagle:package:23728/1" value="5k" x="205.105" y="152.7175" smashed="yes" rot="R270">
<attribute name="NAME" x="202.565" y="155.5925" size="1.27" layer="25"/>
<attribute name="POPULARITY" value="1" x="205.105" y="152.7175" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEMODEL" value="X" x="205.105" y="152.7175" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIXL" value="POT" x="205.105" y="152.7175" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="200.66" y="152.4825" size="1.27" layer="27"/>
</element>
</elements>
<signals>
<signal name="TáP+35V">
<contactref element="X3" pad="1"/>
<contactref element="R1" pad="2"/>
<contactref element="X5" pad="5"/>
<wire x1="86.995" y1="21.5138" x2="86.995" y2="39.6875" width="3" layer="16"/>
<wire x1="93.0275" y1="45.72" x2="93.0275" y2="66.9925" width="3" layer="16"/>
<wire x1="86.995" y1="39.6875" x2="93.0275" y2="45.72" width="3" layer="16"/>
<wire x1="77.6351" y1="72.39" x2="77.0001" y2="73.025" width="3" layer="16"/>
<wire x1="37.1475" y1="43.18" x2="37.1475" y2="44.7675" width="0.8128" layer="16"/>
<via x="37.1475" y="44.7675" extent="1-16" drill="0.8" diameter="1.8"/>
<wire x1="73.5076" y1="76.5175" x2="77.0001" y2="73.025" width="1.27" layer="16"/>
<wire x1="73.5076" y1="76.5175" x2="42.8625" y2="76.5175" width="1.27" layer="16"/>
<contactref element="R19" pad="1"/>
<contactref element="T2" pad="3"/>
<contactref element="D2" pad="C"/>
<wire x1="34.6075" y1="74.295" x2="40.64" y2="74.295" width="1.27" layer="16"/>
<wire x1="93.0275" y1="66.9925" x2="87.63" y2="72.39" width="3" layer="16"/>
<wire x1="87.63" y1="72.39" x2="77.6351" y2="72.39" width="3" layer="16"/>
<wire x1="42.8625" y1="76.5175" x2="40.64" y2="74.295" width="1.27" layer="16"/>
<via x="37.1475" y="53.975" extent="1-16" drill="0.8" diameter="1.8"/>
<wire x1="37.1475" y1="44.7675" x2="37.1475" y2="53.975" width="0.8128" layer="1"/>
<wire x1="37.1475" y1="53.975" x2="26.67" y2="53.975" width="0.8128" layer="16"/>
<wire x1="26.67" y1="53.975" x2="22.86" y2="57.785" width="0.8128" layer="16"/>
<wire x1="22.86" y1="57.785" x2="22.86" y2="64.4525" width="0.8128" layer="16"/>
<wire x1="22.86" y1="64.4525" x2="32.7025" y2="74.295" width="0.8128" layer="16"/>
<wire x1="32.7025" y1="74.295" x2="34.6075" y2="74.295" width="0.8128" layer="16"/>
</signal>
<signal name="N$2">
<contactref element="R19" pad="2"/>
<contactref element="T2" pad="1"/>
<contactref element="T1" pad="3"/>
<wire x1="29.21" y1="64.135" x2="34.6075" y2="64.135" width="0.8128" layer="16"/>
<wire x1="34.6075" y1="64.135" x2="40.64" y2="64.135" width="0.8128" layer="16"/>
<wire x1="34.6075" y1="69.215" x2="34.6075" y2="64.135" width="0.8128" layer="16"/>
</signal>
<signal name="N$3">
<contactref element="T2" pad="2"/>
<contactref element="R32" pad="1"/>
<contactref element="X5" pad="1"/>
<wire x1="34.6075" y1="71.755" x2="48.895" y2="71.755" width="1.27" layer="16"/>
<wire x1="48.895" y1="71.755" x2="55.6895" y2="71.755" width="1.27" layer="16"/>
<wire x1="55.6895" y1="71.755" x2="56.9595" y2="73.025" width="1.27" layer="16"/>
</signal>
<signal name="+24V">
<contactref element="R1" pad="1"/>
<contactref element="R5" pad="2"/>
<contactref element="R7" pad="2"/>
<contactref element="Z3" pad="C"/>
<contactref element="IC1" pad="4"/>
<wire x1="33.3375" y1="29.21" x2="37.1475" y2="29.21" width="0.8128" layer="16"/>
<wire x1="37.1475" y1="33.02" x2="37.1475" y2="29.21" width="0.8128" layer="16"/>
<wire x1="37.1475" y1="33.02" x2="41.5925" y2="33.02" width="0.8128" layer="16"/>
<wire x1="46.0375" y1="35.56" x2="45.4025" y2="35.56" width="0.8128" layer="16"/>
<wire x1="45.4025" y1="35.56" x2="42.8625" y2="33.02" width="0.8128" layer="16"/>
<wire x1="41.5925" y1="33.02" x2="42.8625" y2="33.02" width="0.8128" layer="16"/>
</signal>
<signal name="N$7">
<contactref element="IC1" pad="5"/>
<contactref element="R8" pad="2"/>
<contactref element="R7" pad="1"/>
<wire x1="37.1475" y1="19.05" x2="37.1475" y2="21.59" width="0.8128" layer="16"/>
<wire x1="39.37" y1="23.8125" x2="39.37" y2="29.845" width="0.8128" layer="16"/>
<wire x1="39.37" y1="29.845" x2="40.64" y2="31.115" width="0.8128" layer="16"/>
<wire x1="40.64" y1="31.115" x2="43.4975" y2="31.115" width="0.8128" layer="16"/>
<wire x1="45.4025" y1="33.02" x2="46.0375" y2="33.02" width="0.8128" layer="16"/>
<wire x1="45.4025" y1="33.02" x2="43.4975" y2="31.115" width="0.8128" layer="16"/>
<wire x1="28.2575" y1="21.59" x2="37.1475" y2="21.59" width="0.8128" layer="16"/>
<wire x1="37.1475" y1="21.59" x2="39.37" y2="23.8125" width="0.8128" layer="16"/>
</signal>
<signal name="N$8">
<contactref element="IC1" pad="6"/>
<contactref element="R14" pad="1"/>
<wire x1="46.0375" y1="30.48" x2="47.3075" y2="30.48" width="0.8128" layer="16"/>
<wire x1="47.3075" y1="30.48" x2="48.26" y2="29.5275" width="0.8128" layer="16"/>
<wire x1="48.26" y1="29.5275" x2="48.26" y2="24.4475" width="0.8128" layer="16"/>
<wire x1="48.26" y1="24.4475" x2="46.6725" y2="22.86" width="0.8128" layer="16"/>
</signal>
<signal name="N$9">
<contactref element="IC1" pad="9"/>
<contactref element="R15" pad="2"/>
<contactref element="C4" pad="2"/>
<wire x1="53.6575" y1="30.48" x2="58.1025" y2="30.48" width="0.8128" layer="16"/>
<wire x1="60.6425" y1="29.21" x2="61.9125" y2="29.21" width="0.8128" layer="16"/>
<wire x1="58.1025" y1="30.48" x2="59.3725" y2="29.21" width="0.8128" layer="16"/>
<wire x1="59.3725" y1="29.21" x2="61.9125" y2="29.21" width="0.8128" layer="16"/>
<wire x1="58.1025" y1="30.48" x2="58.1025" y2="31.75" width="0.8128" layer="16"/>
</signal>
<signal name="N$10">
<contactref element="LED1" pad="A"/>
<contactref element="R6" pad="1"/>
<wire x1="50.4825" y1="10.795" x2="50.4825" y2="12.065" width="0.8128" layer="16"/>
<wire x1="50.4825" y1="12.065" x2="43.4975" y2="19.05" width="0.8128" layer="16"/>
<wire x1="43.4975" y1="19.05" x2="41.5925" y2="19.05" width="0.8128" layer="16"/>
<contactref element="X8" pad="1"/>
</signal>
<signal name="N$11">
<contactref element="Z1" pad="A"/>
<contactref element="R2" pad="2"/>
<contactref element="IC1" pad="2"/>
<wire x1="46.0375" y1="40.64" x2="45.4025" y2="40.64" width="0.8128" layer="16"/>
<wire x1="45.4025" y1="40.64" x2="42.8625" y2="38.1" width="0.8128" layer="16"/>
<wire x1="42.8625" y1="38.1" x2="34.6075" y2="38.1" width="0.8128" layer="16"/>
<wire x1="30.7975" y1="27.94" x2="28.2575" y2="25.4" width="0.8128" layer="16"/>
<wire x1="28.2575" y1="25.4" x2="23.8125" y2="25.4" width="0.8128" layer="16"/>
<wire x1="34.6075" y1="38.1" x2="30.7975" y2="34.29" width="0.8128" layer="16"/>
<wire x1="30.7975" y1="34.29" x2="30.7975" y2="27.94" width="0.8128" layer="16"/>
</signal>
<signal name="-5V">
<contactref element="R2" pad="1"/>
<contactref element="R4" pad="2"/>
<contactref element="R40" pad="2"/>
<contactref element="IC1" pad="11"/>
<contactref element="Z2" pad="A"/>
<wire x1="53.6575" y1="35.56" x2="53.0225" y2="35.56" width="0.8128" layer="16"/>
<wire x1="53.0225" y1="35.56" x2="49.8475" y2="38.735" width="0.8128" layer="16"/>
<wire x1="49.8475" y1="46.6725" x2="49.8475" y2="38.735" width="0.8128" layer="16"/>
<via x="49.8475" y="46.6725" extent="1-16" drill="0.8" diameter="2"/>
<wire x1="49.8475" y1="46.6725" x2="39.0525" y2="46.6725" width="0.8128" layer="1"/>
<via x="39.0525" y="46.6725" extent="1-16" drill="0.8" diameter="2"/>
<wire x1="14.9225" y1="35.56" x2="18.0975" y2="38.735" width="0.8128" layer="16"/>
<wire x1="18.0975" y1="38.735" x2="19.3675" y2="38.735" width="0.8128" layer="16"/>
<wire x1="19.3675" y1="38.735" x2="23.8125" y2="38.735" width="0.8128" layer="16"/>
<wire x1="23.8125" y1="38.735" x2="23.8125" y2="35.56" width="0.8128" layer="16"/>
<wire x1="39.0525" y1="46.6725" x2="31.75" y2="46.6725" width="0.8128" layer="16"/>
<wire x1="31.75" y1="46.6725" x2="23.8125" y2="38.735" width="0.8128" layer="16"/>
<contactref element="IC4" pad="5"/>
<contactref element="C14" pad="2"/>
<wire x1="225.8725" y1="27.94" x2="223.2025" y2="27.94" width="0.8128" layer="16"/>
<wire x1="222.5675" y1="28.575" x2="223.2025" y2="27.94" width="0.8128" layer="16"/>
<contactref element="JP3" pad="1"/>
<wire x1="225.7425" y1="27.81" x2="225.8725" y2="27.94" width="0.8128" layer="16"/>
<wire x1="225.7425" y1="27.81" x2="225.7425" y2="17.78" width="0.8128" layer="16"/>
<contactref element="IC13" pad="4"/>
<contactref element="C45" pad="1"/>
<contactref element="C42" pad="2"/>
<contactref element="J2" pad="3"/>
<wire x1="202.3775" y1="129.7275" x2="202.3775" y2="118.745" width="0.8128" layer="1"/>
<wire x1="202.3775" y1="118.745" x2="202.3775" y2="114.6175" width="0.8128" layer="1"/>
<wire x1="202.3775" y1="114.6175" x2="201.7425" y2="113.9825" width="0.8128" layer="1"/>
<wire x1="202.409425" y1="110.1725" x2="202.3775" y2="110.204425" width="0.8128" layer="1"/>
<wire x1="202.3775" y1="129.7275" x2="198.755" y2="133.35" width="0.8128" layer="1"/>
<wire x1="198.755" y1="133.35" x2="198.755" y2="135.89" width="0.8128" layer="1"/>
<wire x1="202.3775" y1="114.6175" x2="202.3775" y2="113.9825" width="0.8128" layer="1"/>
<wire x1="202.3775" y1="113.9825" x2="202.3775" y2="110.204425" width="0.8128" layer="1"/>
<wire x1="201.7425" y1="118.745" x2="202.3775" y2="118.745" width="0.8128" layer="1"/>
<wire x1="201.7425" y1="113.9825" x2="202.3775" y2="113.9825" width="0.8128" layer="1"/>
<wire x1="202.409425" y1="110.1725" x2="222.5675" y2="28.575" width="0" layer="19" extent="1-1"/>
<wire x1="49.8475" y1="46.6725" x2="202.409425" y2="110.1725" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$13">
<contactref element="R4" pad="1"/>
<contactref element="T6" pad="2"/>
<contactref element="R5" pad="1"/>
<wire x1="40.005" y1="48.895" x2="23.8125" y2="48.895" width="0.8128" layer="16"/>
<wire x1="40.005" y1="48.895" x2="41.5925" y2="47.3075" width="0.8128" layer="16"/>
<wire x1="41.5925" y1="47.3075" x2="41.5925" y2="43.18" width="0.8128" layer="16"/>
<wire x1="22.5425" y1="47.625" x2="23.8125" y2="48.895" width="0.8128" layer="16"/>
<wire x1="22.5425" y1="47.625" x2="14.2875" y2="47.625" width="0.8128" layer="16"/>
</signal>
<signal name="N$14">
<contactref element="D1" pad="A"/>
<contactref element="R12" pad="2"/>
<wire x1="65.7225" y1="41.91" x2="61.9125" y2="41.91" width="0.8128" layer="16"/>
</signal>
<signal name="N$15">
<contactref element="R10" pad="1"/>
<contactref element="IC1" pad="12"/>
<contactref element="R12" pad="1"/>
<wire x1="53.6575" y1="38.1" x2="55.5625" y2="38.1" width="0.8128" layer="16"/>
<wire x1="55.5625" y1="38.1" x2="61.9125" y2="31.75" width="0.8128" layer="16"/>
<wire x1="64.4525" y1="34.29" x2="61.9125" y2="31.75" width="0.8128" layer="16"/>
<wire x1="66.675" y1="34.29" x2="67.945" y2="33.02" width="0.8128" layer="16"/>
<wire x1="67.945" y1="33.02" x2="67.945" y2="31.115" width="0.8128" layer="16"/>
<wire x1="67.945" y1="31.115" x2="66.04" y2="29.21" width="0.8128" layer="16"/>
<wire x1="65.7225" y1="29.21" x2="66.04" y2="29.21" width="0.8128" layer="16"/>
<wire x1="64.4525" y1="34.29" x2="66.675" y2="34.29" width="0.8128" layer="16"/>
</signal>
<signal name="N$16">
<contactref element="R3" pad="2"/>
<contactref element="IC1" pad="3"/>
<contactref element="R37" pad="2"/>
<wire x1="33.02" y1="33.3375" x2="35.2425" y2="35.56" width="0.8128" layer="16"/>
<wire x1="35.2425" y1="35.56" x2="42.8625" y2="35.56" width="0.8128" layer="16"/>
<wire x1="45.4025" y1="38.1" x2="42.8625" y2="35.56" width="0.8128" layer="16"/>
<wire x1="45.4025" y1="38.1" x2="46.0375" y2="38.1" width="0.8128" layer="16"/>
<wire x1="46.0375" y1="38.1" x2="47.9425" y2="38.1" width="0.8128" layer="16"/>
<wire x1="47.9425" y1="38.1" x2="49.8475" y2="36.195" width="0.8128" layer="16"/>
<wire x1="49.8475" y1="22.225" x2="46.6725" y2="19.05" width="0.8128" layer="16"/>
<wire x1="49.8475" y1="36.195" x2="49.8475" y2="22.225" width="0.8128" layer="16"/>
</signal>
<signal name="N$17">
<contactref element="R9" pad="1"/>
<contactref element="R10" pad="2"/>
<wire x1="65.7225" y1="19.05" x2="70.8025" y2="24.13" width="0.8128" layer="16"/>
<wire x1="70.8025" y1="24.13" x2="70.8025" y2="29.21" width="0.8128" layer="16"/>
<contactref element="X7" pad="1"/>
<wire x1="57.4675" y1="10.795" x2="65.7225" y2="19.05" width="0.8128" layer="16"/>
</signal>
<signal name="N$18">
<contactref element="R36" pad="3"/>
<contactref element="R36" pad="2"/>
<wire x1="74.93" y1="16.8275" x2="74.93" y2="20.955" width="0.8128" layer="16"/>
<wire x1="68.8975" y1="10.795" x2="74.93" y2="16.8275" width="0.8128" layer="16"/>
<wire x1="74.93" y1="20.955" x2="74.93" y2="23.495" width="0.8128" layer="16"/>
<contactref element="X6" pad="1"/>
<wire x1="66.9925" y1="10.795" x2="68.8975" y2="10.795" width="0.8128" layer="16"/>
</signal>
<signal name="N$19">
<contactref element="IC1" pad="1"/>
<contactref element="R36" pad="1"/>
<contactref element="R13" pad="1"/>
<contactref element="R37" pad="1"/>
<contactref element="Z1" pad="C"/>
<wire x1="75.2475" y1="40.3225" x2="75.2475" y2="26.3525" width="0.8128" layer="16"/>
<wire x1="75.2475" y1="26.3525" x2="74.93" y2="26.035" width="0.8128" layer="16"/>
<wire x1="55.88" y1="49.53" x2="66.04" y2="49.53" width="0.8128" layer="16"/>
<wire x1="45.4025" y1="43.18" x2="46.0375" y2="43.18" width="0.8128" layer="16"/>
<wire x1="45.4025" y1="43.18" x2="42.545" y2="40.3225" width="0.8128" layer="16"/>
<wire x1="42.545" y1="40.3225" x2="33.02" y2="40.3225" width="0.8128" layer="16"/>
<wire x1="19.3675" y1="35.56" x2="22.5425" y2="32.385" width="0.8128" layer="16"/>
<wire x1="25.0825" y1="32.385" x2="28.2575" y2="35.56" width="0.8128" layer="16"/>
<wire x1="22.5425" y1="32.385" x2="25.0825" y2="32.385" width="0.8128" layer="16"/>
<wire x1="66.04" y1="49.53" x2="75.2475" y2="40.3225" width="0.8128" layer="16"/>
<wire x1="46.0375" y1="51.1175" x2="48.895" y2="53.975" width="0.8128" layer="16"/>
<wire x1="48.895" y1="53.975" x2="51.435" y2="53.975" width="0.8128" layer="16"/>
<wire x1="51.435" y1="53.975" x2="55.88" y2="49.53" width="0.8128" layer="16"/>
<wire x1="46.0375" y1="43.18" x2="46.0375" y2="51.1175" width="0.8128" layer="16"/>
<wire x1="28.2575" y1="35.56" x2="33.02" y2="40.3225" width="0.8128" layer="16"/>
<wire x1="33.02" y1="43.4975" x2="33.02" y2="40.3225" width="0.8128" layer="16"/>
</signal>
<signal name="N$20">
<contactref element="R9" pad="2"/>
<contactref element="R42" pad="1"/>
<wire x1="64.4525" y1="12.065" x2="68.2625" y2="15.875" width="0.8128" layer="16"/>
<wire x1="70.8025" y1="15.875" x2="68.2625" y2="15.875" width="0.8128" layer="16"/>
<wire x1="70.8025" y1="15.875" x2="70.8025" y2="19.05" width="0.8128" layer="16"/>
<contactref element="X6" pad="2"/>
<wire x1="64.4525" y1="10.795" x2="64.4525" y2="12.065" width="0.8128" layer="16"/>
</signal>
<signal name="GND">
<contactref element="R11" pad="2"/>
<contactref element="R3" pad="1"/>
<contactref element="R15" pad="1"/>
<contactref element="X1" pad="1"/>
<contactref element="R31" pad="2"/>
<contactref element="R30" pad="2"/>
<contactref element="R29" pad="2"/>
<contactref element="D5" pad="A"/>
<contactref element="D6" pad="A"/>
<wire x1="54.9275" y1="17.145" x2="56.8325" y2="19.05" width="0.8128" layer="16"/>
<wire x1="56.8325" y1="19.05" x2="61.9125" y2="19.05" width="0.8128" layer="16"/>
<wire x1="70.8025" y1="31.75" x2="68.2625" y2="29.21" width="0.8128" layer="16"/>
<wire x1="68.2625" y1="25.4" x2="61.9125" y2="19.05" width="0.8128" layer="16"/>
<wire x1="68.2625" y1="29.21" x2="68.2625" y2="25.4" width="0.8128" layer="16"/>
<contactref element="C5" pad="-"/>
<wire x1="56.1975" y1="8.255" x2="54.9275" y2="9.525" width="1.016" layer="16"/>
<contactref element="X4" pad="2"/>
<wire x1="69.5325" y1="8.255" x2="72.0725" y2="10.795" width="1.016" layer="16"/>
<wire x1="72.0725" y1="10.795" x2="75.8825" y2="10.795" width="1.016" layer="16"/>
<wire x1="56.1975" y1="8.255" x2="61.9125" y2="8.255" width="1.016" layer="16"/>
<wire x1="61.9125" y1="8.255" x2="69.5325" y2="8.255" width="1.016" layer="16"/>
<wire x1="75.8825" y1="10.795" x2="76.5175" y2="10.795" width="1.016" layer="16"/>
<wire x1="75.8825" y1="10.795" x2="78.4225" y2="10.795" width="1.016" layer="16"/>
<wire x1="78.4225" y1="10.795" x2="80.3275" y2="12.7" width="1.016" layer="16"/>
<wire x1="80.3275" y1="12.7" x2="80.3275" y2="27.94" width="1.016" layer="16"/>
<wire x1="80.3275" y1="34.29" x2="80.3275" y2="27.94" width="3" layer="16"/>
<wire x1="80.3275" y1="40.3225" x2="80.3275" y2="34.29" width="3" layer="16"/>
<wire x1="80.3275" y1="40.3479" x2="80.3275" y2="40.3225" width="3" layer="16"/>
<wire x1="80.3275" y1="52.705" x2="74.295" y2="52.705" width="3" layer="16"/>
<wire x1="80.3275" y1="46.6725" x2="80.3275" y2="40.3225" width="3" layer="16"/>
<wire x1="80.3275" y1="46.6725" x2="80.3275" y2="52.705" width="3" layer="16"/>
<wire x1="87.63" y1="47.0154" x2="87.2871" y2="46.6725" width="3" layer="16"/>
<wire x1="87.2871" y1="46.6725" x2="80.3275" y2="46.6725" width="3" layer="16"/>
<wire x1="79.6925" y1="46.355" x2="80.3529" y2="47.0154" width="1.27" layer="16"/>
<wire x1="80.3529" y1="47.0154" x2="87.63" y2="47.0154" width="1.27" layer="16"/>
<contactref element="X6" pad="3"/>
<wire x1="61.9125" y1="10.795" x2="61.9125" y2="8.255" width="1.016" layer="16"/>
<contactref element="X7" pad="2"/>
<wire x1="54.9275" y1="10.795" x2="54.9275" y2="17.145" width="0.8128" layer="16"/>
<contactref element="R24" pad="1"/>
<contactref element="Q1" pad="2"/>
<contactref element="R28" pad="2"/>
<contactref element="Q2" pad="E"/>
<contactref element="IC2" pad="4"/>
<contactref element="R44" pad="2"/>
<polygon width="0.8128" layer="16" spacing="2.1844" pour="hatch" isolate="1.27">
<vertex x="-0.3175" y="166.6875"/>
<vertex x="100.0125" y="166.6875"/>
<vertex x="100.0125" y="86.6775"/>
<vertex x="-0.3175" y="86.6775"/>
</polygon>
<contactref element="JP1" pad="2"/>
<contactref element="Q3" pad="2"/>
<contactref element="X9" pad="1"/>
<contactref element="X10" pad="2"/>
<contactref element="JP2" pad="1"/>
<contactref element="LED2" pad="K"/>
<contactref element="IC4" pad="3"/>
<contactref element="C9" pad="1"/>
<contactref element="C10" pad="1"/>
<contactref element="C11" pad="-"/>
<contactref element="IC3" pad="GND"/>
<contactref element="T7" pad="E"/>
<contactref element="C14" pad="1"/>
<contactref element="D8" pad="A"/>
<contactref element="B1" pad="-"/>
<contactref element="R51" pad="2"/>
<contactref element="T5" pad="C"/>
<polygon width="0.508" layer="16" spacing="1.6764" pour="hatch" isolate="0.6096">
<vertex x="128.5875" y="0"/>
<vertex x="128.5875" y="36.195"/>
<vertex x="253.0475" y="36.195"/>
<vertex x="253.0475" y="0"/>
</polygon>
<contactref element="K1" pad="P2"/>
<contactref element="K1" pad="O2"/>
<contactref element="C6" pad="-"/>
<wire x1="230.1875" y1="26.035" x2="228.9175" y2="26.035" width="0.8128" layer="16"/>
<wire x1="216.2175" y1="29.5275" x2="216.2175" y2="27.6225" width="0.8128" layer="16"/>
<wire x1="216.2175" y1="29.5275" x2="216.2175" y2="31.4325" width="0.8128" layer="16"/>
<contactref element="C8" pad="-"/>
<contactref element="C7" pad="-"/>
<contactref element="X17" pad="3"/>
<wire x1="139.3825" y1="5.08" x2="149.5425" y2="5.08" width="2.54" layer="16"/>
<wire x1="149.5425" y1="5.08" x2="152.7175" y2="8.255" width="2.54" layer="16"/>
<wire x1="152.7175" y1="8.255" x2="164.7825" y2="8.255" width="2.54" layer="16"/>
<wire x1="164.7825" y1="8.255" x2="176.2125" y2="8.255" width="2.54" layer="16"/>
<wire x1="176.8475" y1="8.255" x2="189.4625" y2="8.255" width="2.54" layer="16"/>
<wire x1="189.5475" y1="8.255" x2="189.6237" y2="8.1788" width="2.54" layer="16"/>
<wire x1="189.6237" y1="5.08" x2="189.6237" y2="8.1788" width="2.54" layer="16"/>
<wire x1="189.4625" y1="8.255" x2="189.5475" y2="8.255" width="2.54" layer="16"/>
<contactref element="LSP8" pad="MP"/>
<wire x1="164.7825" y1="8.255" x2="164.7825" y2="5.08" width="2.54" layer="16"/>
<wire x1="235.3945" y1="10.4902" x2="235.3945" y2="11.4173" width="0.8128" layer="16"/>
<wire x1="235.4072" y1="11.43" x2="235.3945" y2="11.4173" width="0.8128" layer="16"/>
<wire x1="235.4072" y1="11.43" x2="229.5525" y2="11.43" width="0.8128" layer="16"/>
<wire x1="229.5525" y1="11.43" x2="227.6475" y2="11.43" width="0.8128" layer="16"/>
<wire x1="185.1025" y1="28.702" x2="185.1025" y2="29.845" width="0.8128" layer="16"/>
<wire x1="212.4075" y1="21.59" x2="213.8045" y2="21.59" width="0.8128" layer="16"/>
<wire x1="213.8045" y1="21.59" x2="215.5825" y2="21.59" width="0.8128" layer="16"/>
<wire x1="207.3275" y1="12.065" x2="206.0575" y2="12.065" width="0.8128" layer="16"/>
<wire x1="207.3275" y1="12.065" x2="208.5975" y2="12.065" width="0.8128" layer="16"/>
<wire x1="235.3945" y1="10.4902" x2="235.3945" y2="13.208" width="0.8128" layer="16"/>
<wire x1="235.3945" y1="13.208" x2="235.2675" y2="13.335" width="0.8128" layer="16"/>
<wire x1="235.3945" y1="10.4902" x2="235.3945" y2="9.652" width="0.8128" layer="16"/>
<wire x1="235.3945" y1="9.652" x2="235.2675" y2="9.525" width="0.8128" layer="16"/>
<contactref element="JP3" pad="2"/>
<wire x1="223.2025" y1="17.78" x2="223.2025" y2="16.51" width="0.8128" layer="16"/>
<contactref element="C23" pad="-"/>
<contactref element="C24" pad="2"/>
<contactref element="LED3" pad="K"/>
<wire x1="200.3425" y1="28.575" x2="200.3425" y2="30.48" width="0.8128" layer="16"/>
<contactref element="IC5" pad="GND"/>
<wire x1="173.355" y1="31.115" x2="173.355" y2="29.5275" width="1.016" layer="16"/>
<wire x1="173.355" y1="29.5275" x2="173.355" y2="27.94" width="1.016" layer="16"/>
<contactref element="OK1" pad="3"/>
<contactref element="OK1" pad="2"/>
<contactref element="JP5" pad="1"/>
<contactref element="IC7" pad="3"/>
<contactref element="C12" pad="1"/>
<contactref element="C15" pad="1"/>
<contactref element="C16" pad="-"/>
<contactref element="IC6" pad="GND"/>
<contactref element="C18" pad="1"/>
<contactref element="C19" pad="-"/>
<contactref element="R61" pad="2"/>
<contactref element="R62" pad="2"/>
<contactref element="C21" pad="-"/>
<contactref element="Q5" pad="S"/>
<contactref element="IC8" pad="4"/>
<contactref element="B2" pad="-"/>
<contactref element="X22" pad="2"/>
<contactref element="X23" pad="2"/>
<wire x1="155.8925" y1="51.7525" x2="150.495" y2="51.7525" width="0.8128" layer="16"/>
<wire x1="150.495" y1="51.7525" x2="148.9075" y2="51.7525" width="0.8128" layer="16"/>
<wire x1="142.24" y1="49.2125" x2="144.145" y2="49.2125" width="0.8128" layer="16"/>
<wire x1="153.9875" y1="72.7075" x2="152.0825" y2="72.7075" width="0.8128" layer="16"/>
<wire x1="153.9875" y1="72.7075" x2="155.575" y2="72.7075" width="0.8128" layer="16"/>
<wire x1="170.815" y1="67.31" x2="172.085" y2="67.31" width="0.8128" layer="16"/>
<wire x1="188.2775" y1="74.168" x2="186.817" y2="74.168" width="0.8128" layer="16"/>
<wire x1="186.817" y1="74.168" x2="186.69" y2="74.295" width="0.8128" layer="16"/>
<wire x1="188.2775" y1="74.168" x2="189.738" y2="74.168" width="0.8128" layer="16"/>
<wire x1="189.738" y1="74.168" x2="189.865" y2="74.295" width="0.8128" layer="16"/>
<wire x1="171.1325" y1="47.3075" x2="169.545" y2="47.3075" width="0.8128" layer="16"/>
<wire x1="171.1325" y1="47.3075" x2="172.72" y2="47.3075" width="0.8128" layer="16"/>
<polygon width="0.508" layer="16" spacing="1.778" pour="hatch" isolate="0.6096">
<vertex x="128.905" y="79.0575"/>
<vertex x="192.0875" y="79.0575"/>
<vertex x="199.39" y="71.755"/>
<vertex x="199.39" y="42.8625"/>
<vertex x="128.905" y="42.8625"/>
</polygon>
<contactref element="R66" pad="2"/>
<wire x1="144.78" y1="73.3425" x2="146.685" y2="73.3425" width="0.8128" layer="16"/>
<wire x1="144.78" y1="73.3425" x2="142.875" y2="73.3425" width="0.8128" layer="16"/>
<wire x1="142.24" y1="49.2125" x2="139.7" y2="49.2125" width="0.8128" layer="16"/>
<wire x1="144.145" y1="49.2125" x2="144.78" y2="49.8475" width="0.8128" layer="16"/>
<contactref element="C28" pad="-"/>
<contactref element="C27" pad="1"/>
<contactref element="R74" pad="1"/>
<contactref element="R72" pad="2"/>
<contactref element="R76" pad="3"/>
<contactref element="C25" pad="2"/>
<contactref element="IC9" pad="22"/>
<contactref element="C29" pad="2"/>
<contactref element="C22" pad="1"/>
<contactref element="DIS1" pad="1"/>
<contactref element="C26" pad="1"/>
<polygon width="0.6096" layer="1" spacing="1.778" pour="hatch" isolate="0.6096">
<vertex x="106.045" y="147.0025"/>
<vertex x="187.96" y="147.0025"/>
<vertex x="187.96" y="100.6475"/>
<vertex x="106.045" y="100.6475"/>
</polygon>
<contactref element="S3" pad="3"/>
<contactref element="S3" pad="4"/>
<contactref element="S2" pad="3"/>
<contactref element="S2" pad="4"/>
<contactref element="S1" pad="3"/>
<contactref element="S1" pad="4"/>
<contactref element="R77" pad="1"/>
<contactref element="C30" pad="1"/>
<wire x1="135.5725" y1="128.27" x2="135.5725" y2="126.6825" width="0.8128" layer="1"/>
<wire x1="135.5725" y1="128.27" x2="135.5725" y2="129.54" width="0.8128" layer="1"/>
<contactref element="R78" pad="1"/>
<contactref element="LED5" pad="K"/>
<contactref element="IC9" pad="8"/>
<wire x1="138.1125" y1="135.89" x2="138.1125" y2="136.525" width="0.8128" layer="1"/>
<wire x1="138.1125" y1="135.89" x2="138.1125" y2="134.62" width="0.8128" layer="1"/>
<wire x1="138.1125" y1="135.89" x2="138.1125" y2="138.3" width="0.8128" layer="1"/>
<wire x1="138.1125" y1="138.3" x2="138.2425" y2="138.43" width="0.8128" layer="1"/>
<contactref element="C31" pad="1"/>
<contactref element="R86" pad="1"/>
<contactref element="C32" pad="1"/>
<contactref element="IC10" pad="5"/>
<contactref element="R87" pad="1"/>
<contactref element="GND" pad="MP"/>
<contactref element="JP8" pad="2"/>
<contactref element="C33" pad="1"/>
<contactref element="C34" pad="1"/>
<contactref element="C35" pad="1"/>
<wire x1="179.07" y1="134.62" x2="180.975" y2="134.62" width="0.8128" layer="1"/>
<wire x1="167.9575" y1="132.08" x2="166.37" y2="132.08" width="0.8128" layer="1"/>
<wire x1="164.1475" y1="110.1725" x2="165.735" y2="110.1725" width="0.8128" layer="1"/>
<wire x1="164.1475" y1="110.1725" x2="162.56" y2="110.1725" width="0.8128" layer="1"/>
<contactref element="D12" pad="A"/>
<contactref element="C37" pad="1"/>
<contactref element="C36" pad="1"/>
<wire x1="115.0025" y1="142.8175" x2="113.405" y2="142.8175" width="0.8128" layer="1"/>
<wire x1="113.405" y1="142.8175" x2="113.3475" y2="142.875" width="0.8128" layer="1"/>
<contactref element="IC11" pad="GND"/>
<wire x1="168.91" y1="141.605" x2="168.91" y2="143.1925" width="0.8128" layer="1"/>
<wire x1="168.91" y1="143.1925" x2="168.91" y2="144.78" width="0.8128" layer="1"/>
<contactref element="DIS2" pad="16"/>
<contactref element="C40" pad="1"/>
<contactref element="R102" pad="2"/>
<contactref element="Q8" pad="2"/>
<contactref element="C44" pad="1"/>
<contactref element="C43" pad="2"/>
<contactref element="C45" pad="2"/>
<contactref element="C42" pad="1"/>
<contactref element="T8" pad="E"/>
<contactref element="D13" pad="A"/>
<contactref element="C48" pad="1"/>
<contactref element="C39" pad="1"/>
<contactref element="DIS2" pad="1"/>
<contactref element="C38" pad="2"/>
<contactref element="R105" pad="1"/>
<contactref element="D15" pad="A"/>
<contactref element="D14" pad="A"/>
<contactref element="C50" pad="1"/>
<contactref element="IC12" pad="8"/>
<contactref element="C51" pad="1"/>
<wire x1="243.84" y1="142.875" x2="243.84" y2="144.9675" width="0.8128" layer="1"/>
<wire x1="243.84" y1="144.9675" x2="243.97" y2="145.0975" width="0.8128" layer="1"/>
<wire x1="243.84" y1="142.875" x2="243.84" y2="141.2875" width="0.8128" layer="1"/>
<contactref element="J2" pad="2"/>
<wire x1="203.585" y1="157.74" x2="203.585" y2="156.2775" width="0.8128" layer="1"/>
<wire x1="203.585" y1="157.74" x2="203.585" y2="159.3175" width="0.8128" layer="1"/>
<wire x1="203.585" y1="159.3175" x2="203.5175" y2="159.385" width="0.8128" layer="1"/>
<wire x1="241.685" y1="157.74" x2="241.7425" y2="157.7975" width="0.8128" layer="1"/>
<wire x1="241.7425" y1="157.7975" x2="243.205" y2="157.7975" width="0.8128" layer="1"/>
<wire x1="241.685" y1="157.74" x2="241.685" y2="159.135" width="0.8128" layer="1"/>
<wire x1="202.1175" y1="148.9075" x2="202.1175" y2="146.3675" width="0.8128" layer="1"/>
<wire x1="202.1175" y1="146.3675" x2="200.025" y2="146.3675" width="0.8128" layer="1"/>
<wire x1="203.585" y1="156.2775" x2="202.3751" y2="155.0676" width="0.8128" layer="1"/>
<wire x1="202.3751" y1="155.0676" x2="198.12" y2="155.0676" width="0.8128" layer="1"/>
<wire x1="198.12" y1="155.0676" x2="197.1675" y2="154.1151" width="0.8128" layer="1"/>
<wire x1="197.1675" y1="154.1151" x2="197.1675" y2="149.225" width="0.8128" layer="1"/>
<wire x1="197.1675" y1="149.225" x2="200.025" y2="146.3675" width="0.8128" layer="1"/>
<polygon width="0.508" layer="1" spacing="1.6764" pour="hatch" isolate="0.6096">
<vertex x="194.6275" y="163.83"/>
<vertex x="276.5425" y="163.83"/>
<vertex x="276.5425" y="96.8375"/>
<vertex x="194.6275" y="96.8375"/>
</polygon>
<wire x1="199.869425" y1="107.6325" x2="202.409425" y2="107.6325" width="0.8128" layer="1"/>
<wire x1="202.409425" y1="107.6325" x2="204.7875" y2="107.6325" width="0.8128" layer="1"/>
<wire x1="213.0425" y1="125.4125" x2="213.0425" y2="127" width="0.8128" layer="1"/>
<wire x1="213.0425" y1="125.4125" x2="213.0425" y2="123.825" width="0.8128" layer="1"/>
<contactref element="S4" pad="3"/>
<contactref element="S4" pad="4"/>
<contactref element="S5" pad="1"/>
<contactref element="S5" pad="2"/>
<contactref element="S7" pad="2"/>
<contactref element="S7" pad="1"/>
<contactref element="C47" pad="2"/>
<contactref element="IC12" pad="22"/>
<contactref element="C41" pad="2"/>
<contactref element="VR1" pad="A"/>
<contactref element="C46" pad="2"/>
<contactref element="C49" pad="1"/>
<wire x1="241.3" y1="135.255" x2="241.3" y2="133.985" width="0.8128" layer="1"/>
<wire x1="241.3" y1="135.255" x2="241.3" y2="136.8425" width="0.8128" layer="1"/>
<contactref element="S6" pad="1"/>
<contactref element="S6" pad="2"/>
<wire x1="242.2525" y1="124.1425" x2="242.2525" y2="122.555" width="0.8128" layer="1"/>
<contactref element="JP12" pad="2"/>
<contactref element="LSP15" pad="MP"/>
<contactref element="R111" pad="1"/>
<wire x1="54.9275" y1="9.525" x2="54.9275" y2="10.795" width="0" layer="19" extent="16-16"/>
<wire x1="139.7" y1="49.2125" x2="87.63" y2="47.0154" width="0" layer="19" extent="16-16"/>
<wire x1="173.355" y1="31.115" x2="172.72" y2="47.3075" width="0" layer="19" extent="16-16"/>
<wire x1="144.7419" y1="103.7463" x2="144.78" y2="73.3425" width="0" layer="19" extent="1-1"/>
<wire x1="198.9425" y1="118.745" x2="180.975" y2="134.62" width="0" layer="19" extent="1-1"/>
<wire x1="62.695" y1="105.095" x2="110.1725" y2="124.965" width="0" layer="19" extent="1-16"/>
</signal>
<signal name="N$4">
<contactref element="R11" pad="1"/>
<contactref element="R18" pad="1"/>
<contactref element="IC1" pad="13"/>
<contactref element="C3" pad="1"/>
<wire x1="57.4675" y1="40.64" x2="63.1825" y2="46.355" width="0.8128" layer="16"/>
<wire x1="53.6575" y1="40.64" x2="57.4675" y2="40.64" width="0.8128" layer="16"/>
<wire x1="57.4675" y1="39.37" x2="57.4675" y2="40.64" width="0.8128" layer="16"/>
<wire x1="57.4675" y1="39.37" x2="68.2625" y2="39.37" width="0.8128" layer="16"/>
<wire x1="68.2625" y1="39.37" x2="70.8025" y2="41.91" width="0.8128" layer="16"/>
</signal>
<signal name="N$21">
<contactref element="IC1" pad="14"/>
<contactref element="R16" pad="2"/>
<contactref element="C3" pad="2"/>
<wire x1="53.6575" y1="43.18" x2="53.6575" y2="44.45" width="0.8128" layer="16"/>
<wire x1="53.6575" y1="47.9425" x2="50.165" y2="51.435" width="0.8128" layer="16"/>
<wire x1="53.6575" y1="47.9425" x2="53.6575" y2="44.45" width="0.8128" layer="16"/>
<wire x1="57.4675" y1="44.45" x2="53.6575" y2="44.45" width="0.8128" layer="16"/>
</signal>
<signal name="N$22">
<contactref element="R16" pad="1"/>
<contactref element="T6" pad="3"/>
<contactref element="R17" pad="2"/>
<wire x1="40.005" y1="51.435" x2="39.6875" y2="51.1175" width="1.016" layer="16"/>
<wire x1="34.6075" y1="51.435" x2="18.0975" y2="51.435" width="0.8128" layer="16"/>
<wire x1="18.0975" y1="51.435" x2="16.8275" y2="50.165" width="0.8128" layer="16"/>
<wire x1="34.6075" y1="51.435" x2="39.37" y2="51.435" width="0.8128" layer="16"/>
<wire x1="39.37" y1="51.435" x2="39.6875" y2="51.1175" width="0.8128" layer="16"/>
</signal>
<signal name="N$23">
<contactref element="R17" pad="1"/>
<contactref element="T1" pad="2"/>
<wire x1="31.75" y1="61.595" x2="34.6075" y2="61.595" width="0.8128" layer="16"/>
</signal>
<signal name="N$25">
<contactref element="R38" pad="2"/>
<contactref element="R38" pad="3"/>
<wire x1="21.9075" y1="18.415" x2="21.9075" y2="15.875" width="0.8128" layer="16"/>
<wire x1="21.9075" y1="15.875" x2="28.2575" y2="15.875" width="0.8128" layer="16"/>
<wire x1="33.3375" y1="10.795" x2="28.2575" y2="15.875" width="0.8128" layer="16"/>
<contactref element="X2" pad="3"/>
<wire x1="38.4175" y1="10.795" x2="33.3375" y2="10.795" width="0.8128" layer="16"/>
</signal>
<signal name="N$26">
<contactref element="IC1" pad="10"/>
<wire x1="51.435" y1="31.4325" x2="51.435" y2="15.24" width="0.8128" layer="16"/>
<wire x1="51.435" y1="15.24" x2="52.07" y2="14.605" width="0.8128" layer="16"/>
<wire x1="51.435" y1="31.4325" x2="53.0225" y2="33.02" width="0.8128" layer="16"/>
<wire x1="53.0225" y1="33.02" x2="53.6575" y2="33.02" width="0.8128" layer="16"/>
<contactref element="R43" pad="2"/>
<wire x1="41.5925" y1="14.605" x2="40.9575" y2="14.605" width="0.8128" layer="16"/>
<wire x1="40.9575" y1="14.605" x2="34.6075" y2="14.605" width="0.8128" layer="16"/>
<wire x1="34.6075" y1="14.605" x2="33.3375" y2="15.875" width="0.8128" layer="16"/>
<via x="40.9575" y="14.605" extent="1-16" drill="0.8" diameter="2"/>
<wire x1="52.07" y1="14.605" x2="40.9575" y2="14.605" width="0.8128" layer="1"/>
<via x="52.07" y="14.605" extent="1-16" drill="0.8" diameter="2"/>
<contactref element="X2" pad="2"/>
<wire x1="40.9575" y1="10.795" x2="40.9575" y2="14.605" width="0.8128" layer="16"/>
</signal>
<signal name="N$27">
<contactref element="IC1" pad="7"/>
<contactref element="R6" pad="2"/>
<wire x1="46.0375" y1="27.94" x2="42.8625" y2="27.94" width="0.8128" layer="16"/>
<wire x1="42.8625" y1="27.94" x2="41.5925" y2="29.21" width="0.8128" layer="16"/>
</signal>
<signal name="~TáP">
<contactref element="R39" pad="2"/>
<contactref element="X3" pad="3"/>
<wire x1="25.0825" y1="3.4925" x2="22.86" y2="5.715" width="1.016" layer="16"/>
<wire x1="25.0825" y1="3.4925" x2="80.01" y2="3.4925" width="1.016" layer="16"/>
<wire x1="80.01" y1="3.4925" x2="86.995" y2="10.4775" width="1.016" layer="16"/>
<wire x1="86.995" y1="10.4775" x2="86.995" y2="11.5062" width="1.016" layer="16"/>
</signal>
<signal name="N$30">
<contactref element="R39" pad="1"/>
<contactref element="C1" pad="+"/>
<wire x1="12.7" y1="10.4775" x2="12.7" y2="5.715" width="1.016" layer="16"/>
</signal>
<signal name="N$31">
<contactref element="C1" pad="-"/>
<contactref element="D4" pad="C"/>
<contactref element="D3" pad="A"/>
<wire x1="12.7" y1="13.0175" x2="10.4775" y2="15.24" width="1.016" layer="16"/>
<wire x1="10.4775" y1="15.24" x2="10.4775" y2="19.05" width="1.016" layer="16"/>
<wire x1="6.0325" y1="15.24" x2="10.4775" y2="15.24" width="1.016" layer="16"/>
</signal>
<signal name="N$32">
<contactref element="D4" pad="A"/>
<contactref element="R40" pad="1"/>
<contactref element="C2" pad="-"/>
<wire x1="10.4775" y1="29.21" x2="10.4775" y2="33.655" width="0.8128" layer="16"/>
<wire x1="10.4775" y1="33.655" x2="10.4775" y2="37.465" width="0.8128" layer="16"/>
<wire x1="10.4775" y1="37.465" x2="9.2075" y2="38.735" width="0.8128" layer="16"/>
<wire x1="8.5725" y1="33.655" x2="10.4775" y2="33.655" width="0.8128" layer="16"/>
</signal>
<signal name="N$33">
<contactref element="IC1" pad="8"/>
<contactref element="D1" pad="C"/>
<contactref element="R14" pad="2"/>
<contactref element="C4" pad="1"/>
<wire x1="65.7225" y1="31.75" x2="65.0875" y2="31.75" width="0.8128" layer="16"/>
<wire x1="65.0875" y1="31.75" x2="63.8175" y2="30.48" width="0.8128" layer="16"/>
<wire x1="63.8175" y1="30.48" x2="63.8175" y2="27.94" width="0.8128" layer="16"/>
<wire x1="63.8175" y1="27.94" x2="62.5475" y2="26.67" width="0.8128" layer="16"/>
<wire x1="62.5475" y1="26.67" x2="58.1025" y2="26.67" width="0.8128" layer="16"/>
<wire x1="58.1025" y1="26.67" x2="56.8325" y2="26.67" width="0.8128" layer="16"/>
<wire x1="56.8325" y1="26.67" x2="54.9275" y2="26.67" width="0.8128" layer="16"/>
<wire x1="54.9275" y1="26.67" x2="53.6575" y2="27.94" width="0.8128" layer="16"/>
<wire x1="56.8325" y1="22.86" x2="56.8325" y2="26.67" width="0.8128" layer="16"/>
</signal>
<signal name="N$34">
<contactref element="R20" pad="2"/>
<contactref element="R21" pad="1"/>
<contactref element="T1" pad="1"/>
<wire x1="29.21" y1="59.055" x2="25.7175" y2="59.055" width="0.8128" layer="16"/>
<wire x1="29.21" y1="59.055" x2="38.735" y2="59.055" width="0.8128" layer="16"/>
</signal>
<signal name="N$39">
<contactref element="R13" pad="2"/>
<contactref element="R38" pad="1"/>
<wire x1="19.3675" y1="23.495" x2="21.9075" y2="20.955" width="0.8128" layer="16"/>
<wire x1="19.3675" y1="23.495" x2="19.3675" y2="25.4" width="0.8128" layer="16"/>
</signal>
<signal name="TáP-">
<contactref element="R8" pad="1"/>
<contactref element="LED1" pad="K"/>
<contactref element="Z3" pad="A"/>
<contactref element="R31" pad="1"/>
<contactref element="R30" pad="1"/>
<contactref element="R29" pad="1"/>
<contactref element="D3" pad="C"/>
<contactref element="C2" pad="+"/>
<contactref element="Z2" pad="C"/>
<contactref element="T6" pad="1"/>
<contactref element="R20" pad="1"/>
<contactref element="R42" pad="2"/>
<contactref element="R43" pad="1"/>
<wire x1="33.3375" y1="19.05" x2="35.56" y2="16.8275" width="0.8128" layer="16"/>
<wire x1="47.9425" y1="11.43" x2="42.545" y2="16.8275" width="0.8128" layer="16"/>
<wire x1="47.9425" y1="11.43" x2="47.9425" y2="10.795" width="0.8128" layer="16"/>
<wire x1="35.56" y1="16.8275" x2="42.545" y2="16.8275" width="0.8128" layer="16"/>
<wire x1="94.2975" y1="40.3225" x2="95.5675" y2="40.3225" width="3" layer="16"/>
<wire x1="95.5675" y1="34.29" x2="94.2975" y2="34.29" width="3" layer="16"/>
<wire x1="95.5675" y1="27.94" x2="94.2975" y2="27.94" width="3" layer="16"/>
<contactref element="X3" pad="2"/>
<wire x1="26.9875" y1="5.715" x2="14.9225" y2="17.78" width="1.27" layer="16"/>
<wire x1="26.9875" y1="5.715" x2="28.2575" y2="5.715" width="1.27" layer="16"/>
<wire x1="28.2575" y1="5.715" x2="33.3375" y2="5.715" width="1.27" layer="16"/>
<wire x1="77.7875" y1="5.715" x2="83.5025" y2="11.43" width="1.27" layer="16"/>
<wire x1="94.2975" y1="22.5425" x2="88.265" y2="16.51" width="3" layer="16"/>
<wire x1="86.995" y1="16.51" x2="88.265" y2="16.51" width="3" layer="16"/>
<wire x1="94.2975" y1="22.5425" x2="94.2975" y2="27.94" width="3" layer="16"/>
<wire x1="94.2975" y1="27.94" x2="94.2975" y2="34.29" width="3" layer="16"/>
<wire x1="94.2975" y1="34.29" x2="94.2975" y2="40.3225" width="3" layer="16"/>
<wire x1="14.9225" y1="25.4" x2="14.9225" y2="24.765" width="1.27" layer="16"/>
<wire x1="28.2575" y1="11.43" x2="28.2575" y2="5.715" width="1.27" layer="16"/>
<wire x1="33.3375" y1="5.715" x2="43.4975" y2="5.715" width="1.27" layer="16"/>
<wire x1="43.4975" y1="5.715" x2="47.9425" y2="5.715" width="1.27" layer="16"/>
<wire x1="47.9425" y1="10.795" x2="47.9425" y2="5.715" width="1.27" layer="16"/>
<wire x1="47.9425" y1="5.715" x2="70.8025" y2="5.715" width="1.27" layer="16"/>
<wire x1="70.8025" y1="5.715" x2="75.8825" y2="5.715" width="1.27" layer="16"/>
<wire x1="75.8825" y1="5.715" x2="77.7875" y2="5.715" width="1.27" layer="16"/>
<wire x1="14.9225" y1="25.4" x2="14.9225" y2="17.78" width="1.27" layer="16"/>
<wire x1="14.9225" y1="25.4" x2="6.0325" y2="25.4" width="1.27" layer="16"/>
<contactref element="X4" pad="3"/>
<wire x1="75.8825" y1="8.255" x2="75.8825" y2="5.715" width="1.016" layer="16"/>
<wire x1="6.0325" y1="25.4" x2="6.0325" y2="33.655" width="1.016" layer="16"/>
<wire x1="6.0325" y1="33.655" x2="6.0325" y2="44.45" width="1.016" layer="16"/>
<wire x1="6.0325" y1="44.45" x2="11.7475" y2="50.165" width="1.016" layer="16"/>
<wire x1="15.5575" y1="59.055" x2="15.5575" y2="53.975" width="1.016" layer="16"/>
<wire x1="15.5575" y1="53.975" x2="11.7475" y2="50.165" width="1.016" layer="16"/>
<wire x1="83.5025" y1="14.605" x2="83.5025" y2="11.43" width="1.27" layer="16"/>
<wire x1="86.995" y1="16.51" x2="85.4075" y2="16.51" width="1.27" layer="16"/>
<wire x1="85.4075" y1="16.51" x2="83.5025" y2="14.605" width="1.27" layer="16"/>
<contactref element="X2" pad="1"/>
<wire x1="43.4975" y1="10.795" x2="43.4975" y2="5.715" width="1.27" layer="16"/>
<contactref element="X8" pad="2"/>
</signal>
<signal name="KI.0-30V">
<contactref element="R18" pad="2"/>
<contactref element="R32" pad="2"/>
<contactref element="D2" pad="A"/>
<contactref element="X1" pad="2"/>
<contactref element="R21" pad="2"/>
<contactref element="D5" pad="C"/>
<contactref element="D6" pad="C"/>
<contactref element="C5" pad="+"/>
<contactref element="X4" pad="1"/>
<wire x1="73.3425" y1="46.355" x2="77.1525" y2="42.2275" width="1.016" layer="16"/>
<wire x1="77.1525" y1="14.605" x2="77.1525" y2="42.2275" width="1.016" layer="16"/>
<wire x1="75.8825" y1="13.335" x2="77.1525" y2="14.605" width="1.016" layer="16"/>
<contactref element="R33" pad="1"/>
<contactref element="R34" pad="1"/>
<contactref element="R35" pad="1"/>
<wire x1="87.63" y1="52.0446" x2="87.63" y2="57.15" width="3" layer="16"/>
<wire x1="69.215" y1="52.705" x2="63.1825" y2="52.705" width="3" layer="16"/>
<wire x1="63.1825" y1="52.705" x2="57.15" y2="52.705" width="3" layer="16"/>
<wire x1="69.215" y1="52.705" x2="69.215" y2="55.88" width="3" layer="16"/>
<wire x1="77.1525" y1="46.355" x2="73.3425" y2="46.355" width="2" layer="16"/>
<wire x1="87.63" y1="57.15" x2="85.725" y2="59.055" width="3" layer="16"/>
<wire x1="72.39" y1="59.055" x2="69.215" y2="55.88" width="3" layer="16"/>
<wire x1="85.725" y1="59.055" x2="80.3275" y2="59.055" width="3" layer="16"/>
<wire x1="80.3275" y1="59.055" x2="74.295" y2="59.055" width="3" layer="16"/>
<wire x1="74.295" y1="59.055" x2="72.39" y2="59.055" width="3" layer="16"/>
<wire x1="80.3275" y1="67.945" x2="80.3275" y2="59.055" width="3" layer="16"/>
<wire x1="74.295" y1="65.405" x2="74.295" y2="59.055" width="3" layer="16"/>
<wire x1="57.15" y1="52.705" x2="50.8" y2="59.055" width="1.27" layer="16"/>
<wire x1="50.8" y1="59.055" x2="48.895" y2="59.055" width="1.27" layer="16"/>
<wire x1="48.895" y1="61.595" x2="48.895" y2="59.055" width="1.27" layer="16"/>
<wire x1="73.3425" y1="46.355" x2="69.215" y2="50.4825" width="3" layer="16"/>
<wire x1="69.215" y1="50.4825" x2="69.215" y2="52.705" width="3" layer="16"/>
</signal>
<signal name="N$40">
<via x="94.9325" y="5.08" extent="1-16" drill="0.8" diameter="3"/>
</signal>
<signal name="N$24">
<via x="94.9325" y="74.93" extent="1-16" drill="0.8" diameter="3"/>
</signal>
<signal name="N$28">
<via x="5.08" y="5.08" extent="1-16" drill="0.8" diameter="3"/>
</signal>
<signal name="N$42">
<via x="5.08" y="74.93" extent="1-16" drill="0.8" diameter="3"/>
</signal>
<signal name="N$41">
<contactref element="R35" pad="2"/>
<contactref element="X5" pad="4"/>
<wire x1="69.215" y1="67.945" x2="71.9963" y2="70.7263" width="2" layer="16"/>
<wire x1="71.9963" y1="70.7263" x2="71.9963" y2="73.025" width="2" layer="16"/>
</signal>
<signal name="N$43">
<contactref element="R34" pad="2"/>
<contactref element="X5" pad="3"/>
<wire x1="63.1825" y1="67.945" x2="66.9925" y2="71.755" width="2" layer="16"/>
<wire x1="66.9925" y1="71.755" x2="66.9925" y2="73.025" width="2" layer="16"/>
</signal>
<signal name="N$44">
<contactref element="R33" pad="2"/>
<contactref element="X5" pad="2"/>
<wire x1="57.15" y1="67.945" x2="61.9887" y2="72.7837" width="2" layer="16"/>
<wire x1="61.9887" y1="72.7837" x2="61.9887" y2="73.025" width="2" layer="16"/>
</signal>
<signal name="N$1">
<polygon width="0.6096" layer="16" spacing="1.9304" pour="hatch" isolate="1.016">
<vertex x="0" y="79.6925"/>
<vertex x="100.0125" y="79.6925"/>
<vertex x="100.0125" y="0"/>
<vertex x="0" y="0"/>
</polygon>
</signal>
<signal name="N$5">
<contactref element="R22" pad="1"/>
<contactref element="R23" pad="2"/>
<contactref element="IC2" pad="2"/>
<wire x1="31.75" y1="109.22" x2="31.75" y2="110.8075" width="0.8128" layer="16"/>
<wire x1="31.75" y1="110.8075" x2="29.5275" y2="113.03" width="0.8128" layer="16"/>
<wire x1="29.5275" y1="113.03" x2="14.9225" y2="113.03" width="0.8128" layer="16"/>
<wire x1="17.145" y1="113.03" x2="17.145" y2="109.22" width="0.8128" layer="16"/>
<wire x1="17.145" y1="113.03" x2="14.9225" y2="113.03" width="0.8128" layer="16"/>
</signal>
<signal name="N$6">
<contactref element="R23" pad="1"/>
<contactref element="R24" pad="2"/>
<contactref element="Q1" pad="3"/>
<wire x1="6.985" y1="109.22" x2="6.985" y2="106.3625" width="0.8128" layer="16"/>
<wire x1="6.985" y1="109.22" x2="6.985" y2="112.5425" width="0.8128" layer="16"/>
<wire x1="6.985" y1="112.5425" x2="8.7425" y2="114.3" width="0.8128" layer="16"/>
</signal>
<signal name="N$12">
<contactref element="R25" pad="1"/>
<contactref element="Q1" pad="1"/>
<wire x1="20.0025" y1="119.38" x2="15.5575" y2="119.38" width="0.8128" layer="16"/>
<wire x1="15.5575" y1="119.38" x2="11.4275" y2="115.25" width="0.8128" layer="16"/>
<wire x1="11.4275" y1="115.25" x2="10.9425" y2="115.25" width="0.8128" layer="16"/>
</signal>
<signal name="N$29">
<contactref element="IC2" pad="1"/>
<contactref element="R25" pad="2"/>
<contactref element="R27" pad="2"/>
<wire x1="29.21" y1="109.22" x2="23.8125" y2="109.22" width="0.8128" layer="16"/>
<wire x1="23.8125" y1="109.22" x2="20.0025" y2="109.22" width="0.8128" layer="16"/>
</signal>
<signal name="N$35">
<contactref element="R26" pad="1"/>
<contactref element="IC2" pad="3"/>
<wire x1="34.29" y1="109.22" x2="34.29" y2="106.3625" width="0.8128" layer="16"/>
</signal>
<signal name="N$36">
<contactref element="R27" pad="1"/>
<contactref element="R28" pad="1"/>
<contactref element="Q2" pad="B"/>
<wire x1="6.985" y1="130.81" x2="6.985" y2="146.685" width="0.8128" layer="16"/>
<wire x1="19.3675" y1="127" x2="10.795" y2="127" width="0.8128" layer="16"/>
<wire x1="10.795" y1="127" x2="6.985" y2="130.81" width="0.8128" layer="16"/>
<wire x1="6.985" y1="130.81" x2="4.445" y2="130.81" width="0.8128" layer="16"/>
<wire x1="23.8125" y1="119.38" x2="23.8125" y2="122.555" width="0.8128" layer="16"/>
<wire x1="23.8125" y1="122.555" x2="19.3675" y2="127" width="0.8128" layer="16"/>
</signal>
<signal name="+12V">
<contactref element="IC2" pad="8"/>
<contactref element="D7" pad="C"/>
<contactref element="JP1" pad="3"/>
<wire x1="29.21" y1="116.84" x2="29.21" y2="120.3325" width="0.8128" layer="16"/>
<wire x1="29.21" y1="120.3325" x2="20.6375" y2="128.905" width="0.8128" layer="16"/>
<wire x1="29.21" y1="116.84" x2="26.67" y2="116.84" width="0.8128" layer="16"/>
<via x="26.67" y="116.84" extent="1-16" drill="0.8" diameter="1.7"/>
<wire x1="26.67" y1="116.84" x2="26.67" y2="106.9975" width="0.8128" layer="1"/>
<via x="26.67" y="106.9975" extent="1-16" drill="0.8" diameter="1.7"/>
<wire x1="26.67" y1="106.9975" x2="30.48" y2="103.1875" width="0.8128" layer="16"/>
<wire x1="30.48" y1="103.1875" x2="30.48" y2="100.0125" width="0.8128" layer="16"/>
<contactref element="U$1" pad="P$1"/>
<wire x1="9.525" y1="133.35" x2="9.525" y2="139.3825" width="0.8128" layer="16"/>
<wire x1="9.525" y1="139.3825" x2="24.765" y2="154.6225" width="0.8128" layer="16"/>
<wire x1="24.765" y1="154.6225" x2="64.3" y2="154.6225" width="0.8128" layer="16"/>
<wire x1="64.3" y1="154.6225" x2="64.34" y2="154.5825" width="0.8128" layer="16"/>
<wire x1="12.065" y1="128.905" x2="9.525" y2="131.445" width="0.8128" layer="16"/>
<wire x1="9.525" y1="131.445" x2="9.525" y2="133.35" width="0.8128" layer="16"/>
<wire x1="20.6375" y1="128.905" x2="12.065" y2="128.905" width="0.8128" layer="16"/>
<contactref element="IC3" pad="IN"/>
<contactref element="C9" pad="2"/>
<contactref element="C6" pad="+"/>
<wire x1="192.405" y1="31.88" x2="192.027" y2="32.258" width="0.8128" layer="16"/>
<wire x1="192.027" y1="32.258" x2="185.1025" y2="32.258" width="0.8128" layer="16"/>
<wire x1="192.405" y1="31.88" x2="193.545" y2="33.02" width="0.8128" layer="16"/>
<wire x1="193.545" y1="33.02" x2="213.6775" y2="33.02" width="0.8128" layer="16"/>
<wire x1="213.6775" y1="29.5275" x2="213.6775" y2="33.02" width="0.8128" layer="16"/>
<contactref element="IC5" pad="OUT"/>
<wire x1="175.895" y1="29.5275" x2="178.6255" y2="32.258" width="1.016" layer="16"/>
<wire x1="178.6255" y1="32.258" x2="185.1025" y2="32.258" width="1.016" layer="16"/>
<contactref element="R54" pad="2"/>
<contactref element="D11" pad="C"/>
<contactref element="K1" pad="2"/>
<wire x1="240.3475" y1="33.02" x2="242.8875" y2="30.48" width="0.8128" layer="16"/>
<wire x1="213.6775" y1="33.02" x2="240.3475" y2="33.02" width="0.8128" layer="16"/>
<wire x1="242.8875" y1="30.48" x2="243.5225" y2="29.845" width="0.8128" layer="16"/>
<wire x1="243.5225" y1="29.845" x2="243.5225" y2="28.2575" width="0.8128" layer="16"/>
<wire x1="243.5225" y1="28.2575" x2="243.5225" y2="25.5125" width="0.8128" layer="16"/>
<wire x1="240.7775" y1="28.2575" x2="243.5225" y2="28.2575" width="0.8128" layer="16"/>
<contactref element="R55" pad="2"/>
<contactref element="R58" pad="1"/>
<contactref element="X20" pad="1"/>
<contactref element="C21" pad="+"/>
<contactref element="R64" pad="3"/>
<contactref element="JP6" pad="2"/>
<contactref element="IC8" pad="8"/>
<wire x1="180.0225" y1="62.865" x2="180.0225" y2="63.37" width="0.8128" layer="16"/>
<wire x1="185.42" y1="69.085" x2="185.2325" y2="68.8975" width="0.8128" layer="16"/>
<wire x1="157.7975" y1="77.1525" x2="155.8925" y2="77.1525" width="1.27" layer="16"/>
<wire x1="157.7975" y1="77.1525" x2="163.195" y2="77.1525" width="1.27" layer="16"/>
<wire x1="163.195" y1="77.1525" x2="180.975" y2="77.1525" width="1.27" layer="16"/>
<wire x1="180.975" y1="77.1525" x2="181.9275" y2="76.2" width="1.27" layer="16"/>
<wire x1="181.9275" y1="76.2" x2="181.9275" y2="73.9775" width="1.27" layer="16"/>
<wire x1="144.78" y1="56.1975" x2="142.24" y2="53.6575" width="1.27" layer="16"/>
<wire x1="144.78" y1="56.1975" x2="144.78" y2="68.1325" width="1.27" layer="16"/>
<wire x1="180.0225" y1="62.865" x2="177.6125" y2="62.865" width="0.8128" layer="16"/>
<wire x1="177.4825" y1="62.735" x2="177.6125" y2="62.865" width="0.8128" layer="16"/>
<wire x1="180.0225" y1="62.865" x2="184.785" y2="62.865" width="0.8128" layer="16"/>
<wire x1="188.2775" y1="65.0875" x2="188.2775" y2="70.612" width="1.27" layer="16"/>
<wire x1="188.2775" y1="70.612" x2="185.293" y2="70.612" width="1.27" layer="16"/>
<wire x1="185.293" y1="70.612" x2="181.9275" y2="73.9775" width="1.27" layer="16"/>
<wire x1="187.0075" y1="65.0875" x2="188.2775" y2="65.0875" width="0.8128" layer="16"/>
<wire x1="184.785" y1="62.865" x2="187.0075" y2="65.0875" width="0.8128" layer="16"/>
<wire x1="185.2325" y1="68.8975" x2="185.2325" y2="70.5515" width="0.8128" layer="16"/>
<wire x1="185.2325" y1="70.5515" x2="185.293" y2="70.612" width="0.8128" layer="16"/>
<contactref element="X23" pad="3"/>
<wire x1="142.24" y1="53.6575" x2="142.24" y2="51.7525" width="1.27" layer="16"/>
<contactref element="R65" pad="2"/>
<wire x1="157.7975" y1="76.965" x2="157.7975" y2="77.1525" width="0.508" layer="16"/>
<wire x1="163.195" y1="74.93" x2="163.195" y2="77.1525" width="0.6096" layer="16"/>
<contactref element="IC6" pad="IN"/>
<contactref element="C12" pad="2"/>
<contactref element="C19" pad="+"/>
<contactref element="B2" pad="+"/>
<wire x1="144.78" y1="68.2625" x2="144.907" y2="68.8975" width="1.27" layer="16"/>
<wire x1="148.9625" y1="63.8275" x2="147.955" y2="64.835" width="1.27" layer="16"/>
<wire x1="147.955" y1="67.31" x2="147.955" y2="64.835" width="1.27" layer="16"/>
<wire x1="144.78" y1="68.2625" x2="144.602821875" y2="68.439678125" width="1.27" layer="16"/>
<wire x1="144.602821875" y1="68.439678125" x2="144.4625" y2="68.45" width="1.27" layer="16"/>
<wire x1="144.78" y1="68.2625" x2="143.66875" y2="68.2625" width="1.27" layer="16"/>
<wire x1="143.66875" y1="68.2625" x2="140.335" y2="70.9295" width="1.27" layer="16"/>
<wire x1="140.335" y1="70.9295" x2="140.335" y2="74.93" width="1.27" layer="16"/>
<wire x1="140.335" y1="74.93" x2="142.5575" y2="77.1525" width="1.27" layer="16"/>
<wire x1="142.5575" y1="77.1525" x2="152.0825" y2="77.1525" width="1.27" layer="16"/>
<wire x1="152.0825" y1="77.1525" x2="153.9875" y2="75.2475" width="1.27" layer="16"/>
<wire x1="147.955" y1="68.1325" x2="147.955" y2="67.31" width="0.508" layer="16"/>
<wire x1="144.78" y1="68.2625" x2="144.91" y2="68.1325" width="0.508" layer="16"/>
<wire x1="144.91" y1="68.1325" x2="147.955" y2="68.1325" width="0.508" layer="16"/>
<wire x1="155.8925" y1="77.1525" x2="153.9875" y2="75.2475" width="1.27" layer="16"/>
<wire x1="144.78" y1="68.2625" x2="144.78" y2="68.1325" width="0" layer="19" extent="16-16"/>
<wire x1="185.1025" y1="32.258" x2="180.0225" y2="62.865" width="0" layer="19" extent="1-1"/>
<wire x1="64.34" y1="154.5825" x2="144.907" y2="68.8975" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$37">
<contactref element="Q2" pad="C"/>
<contactref element="D7" pad="A"/>
<contactref element="U$1" pad="P$2"/>
<wire x1="16.1525" y1="154.5825" x2="16.94" y2="154.5825" width="0.8128" layer="16"/>
<wire x1="9.525" y1="146.685" x2="9.525" y2="143.51" width="0.8128" layer="16"/>
<wire x1="16.94" y1="154.5825" x2="9.525" y2="147.1675" width="0.8128" layer="16"/>
<wire x1="9.525" y1="146.685" x2="9.525" y2="147.1675" width="0.8128" layer="16"/>
</signal>
<signal name="+8V">
<contactref element="R22" pad="2"/>
<contactref element="R41" pad="1"/>
<contactref element="JP1" pad="1"/>
<wire x1="30.48" y1="94.9325" x2="14.9225" y2="94.9325" width="0.8128" layer="16"/>
<wire x1="4.7625" y1="113.03" x2="4.7625" y2="115.57" width="0.8128" layer="16"/>
<wire x1="4.7625" y1="115.57" x2="12.3825" y2="123.19" width="0.8128" layer="16"/>
<wire x1="4.7625" y1="113.03" x2="4.7625" y2="105.0925" width="0.8128" layer="16"/>
<wire x1="4.7625" y1="105.0925" x2="14.9225" y2="94.9325" width="0.8128" layer="16"/>
<contactref element="IC6" pad="OUT"/>
<contactref element="C16" pad="+"/>
<contactref element="C15" pad="2"/>
<wire x1="153.9875" y1="70.1675" x2="154.4925" y2="69.6625" width="0.8128" layer="16"/>
<wire x1="154.4925" y1="69.6625" x2="154.4925" y2="67.6275" width="0.8128" layer="16"/>
<wire x1="154.4925" y1="67.6275" x2="154.81" y2="67.31" width="0.8128" layer="16"/>
<wire x1="154.81" y1="67.31" x2="154.4925" y2="66.9925" width="0.8128" layer="16"/>
<wire x1="154.4925" y1="66.9925" x2="154.4925" y2="62.9255" width="0.8128" layer="16"/>
<wire x1="154.4925" y1="62.9255" x2="154.432" y2="62.865" width="0.8128" layer="16"/>
<wire x1="154.432" y1="62.865" x2="154.432" y2="59.69" width="0.8128" layer="16"/>
<wire x1="161.29" y1="59.69" x2="154.432" y2="59.69" width="0.8128" layer="16"/>
<wire x1="161.29" y1="59.69" x2="163.5125" y2="57.4675" width="0.8128" layer="16"/>
<wire x1="154.432" y1="58.2295" x2="154.432" y2="59.69" width="0.8128" layer="16"/>
<contactref element="IC7" pad="8"/>
<contactref element="X23" pad="1"/>
<wire x1="142.24" y1="46.6725" x2="144.145" y2="46.6725" width="0.8128" layer="16"/>
<wire x1="146.3675" y1="48.895" x2="146.3675" y2="52.07" width="0.8128" layer="16"/>
<wire x1="146.3675" y1="52.07" x2="148.59" y2="54.2925" width="0.8128" layer="16"/>
<wire x1="144.145" y1="46.6725" x2="146.3675" y2="48.895" width="0.8128" layer="16"/>
<contactref element="X22" pad="1"/>
<wire x1="148.59" y1="54.2925" x2="150.495" y2="54.2925" width="0.8128" layer="16"/>
<wire x1="150.495" y1="54.2925" x2="154.432" y2="58.2295" width="0.8128" layer="16"/>
<wire x1="163.5125" y1="57.4675" x2="163.5125" y2="56.8325" width="0" layer="19" extent="16-16"/>
<wire x1="30.48" y1="94.9325" x2="142.24" y2="46.6725" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$38">
<contactref element="R41" pad="2"/>
<contactref element="R44" pad="1"/>
<contactref element="IC2" pad="6"/>
<wire x1="34.29" y1="116.84" x2="34.29" y2="118.745" width="0.8128" layer="16"/>
<wire x1="34.29" y1="118.745" x2="32.7025" y2="120.3325" width="0.8128" layer="16"/>
<wire x1="32.385" y1="120.65" x2="18.7325" y2="134.3025" width="0.8128" layer="16"/>
<wire x1="12.3825" y1="133.35" x2="13.335" y2="134.3025" width="0.8128" layer="16"/>
<wire x1="18.7325" y1="134.3025" x2="13.335" y2="134.3025" width="0.8128" layer="16"/>
<wire x1="32.385" y1="120.65" x2="32.7025" y2="120.3325" width="0.8128" layer="16"/>
</signal>
<signal name="N$45">
<contactref element="IC2" pad="5"/>
<contactref element="R45" pad="2"/>
<wire x1="40.1925" y1="116.84" x2="36.83" y2="116.84" width="0.8128" layer="16"/>
</signal>
<signal name="N$46">
<contactref element="IC2" pad="7"/>
<contactref element="R46" pad="1"/>
<wire x1="31.75" y1="116.84" x2="31.75" y2="115.2525" width="0.8128" layer="16"/>
<wire x1="31.75" y1="115.2525" x2="33.655" y2="113.3475" width="0.8128" layer="16"/>
<wire x1="40.1925" y1="113.3475" x2="33.655" y2="113.3475" width="0.8128" layer="16"/>
</signal>
<signal name="N$47">
<contactref element="R46" pad="2"/>
<contactref element="X9" pad="2"/>
<wire x1="50.165" y1="113.3475" x2="42.9925" y2="113.3475" width="0.8128" layer="16"/>
<contactref element="LED2" pad="A"/>
</signal>
<signal name="N$48">
<contactref element="R26" pad="2"/>
<contactref element="LSP1" pad="MP"/>
<wire x1="47.3075" y1="106.3625" x2="44.45" y2="106.3625" width="0.8128" layer="16"/>
</signal>
<signal name="N$49">
<contactref element="R45" pad="1"/>
<contactref element="LSP2" pad="MP"/>
<wire x1="42.9925" y1="116.84" x2="45.72" y2="116.84" width="0.8128" layer="16"/>
</signal>
<signal name="N$53">
<via x="94.9325" y="91.7575" extent="1-16" drill="0.8" diameter="3"/>
</signal>
<signal name="N$54">
<via x="94.9325" y="161.6075" extent="1-16" drill="0.8" diameter="3"/>
</signal>
<signal name="N$55">
<via x="5.08" y="91.7575" extent="1-16" drill="0.8" diameter="3"/>
</signal>
<signal name="~TáP1">
<via x="86.995" y="98.1075" extent="1-16" drill="0.8" diameter="3"/>
</signal>
<signal name="TáP-1">
<via x="86.995" y="103.1875" extent="1-16" drill="0.8" diameter="3"/>
</signal>
<signal name="KI.0-30V1">
<via x="87.63" y="138.7475" extent="1-16" drill="0.8" diameter="3"/>
</signal>
<signal name="N$56">
</signal>
<signal name="N$57">
</signal>
<signal name="N$58">
</signal>
<signal name="N$59">
<via x="56.8325" y="159.7025" extent="1-16" drill="0.8" diameter="3"/>
</signal>
<signal name="N$60">
<via x="61.9125" y="159.7025" extent="1-16" drill="0.8" diameter="3"/>
</signal>
<signal name="N$61">
<via x="66.9925" y="159.7025" extent="1-16" drill="0.8" diameter="3"/>
</signal>
<signal name="N$62">
<via x="72.0725" y="159.7025" extent="1-16" drill="0.8" diameter="3"/>
</signal>
<signal name="N$63">
<via x="77.1525" y="159.7025" extent="1-16" drill="0.8" diameter="3"/>
</signal>
<signal name="N$64">
<via x="87.63" y="133.6675" extent="1-16" drill="0.8" diameter="3"/>
</signal>
<signal name="N$65">
<via x="86.995" y="108.2675" extent="1-16" drill="0.8" diameter="3"/>
</signal>
<signal name="N$66">
<via x="23.8125" y="101.9175" extent="1-16" drill="0.8" diameter="3"/>
</signal>
<signal name="N$67">
<via x="76.835" y="106.9975" extent="1-16" drill="0.8" diameter="3"/>
</signal>
<signal name="N$68">
<via x="5.3975" y="154.305" extent="1-16" drill="0.8" diameter="3.5"/>
</signal>
<signal name="KI-DC20V.">
<contactref element="U$1" pad="P$5"/>
<wire x1="32.84" y1="139.0825" x2="36.95" y2="143.1925" width="2.54" layer="16"/>
<contactref element="X15" pad="2"/>
<contactref element="X15" pad="1"/>
<wire x1="36.95" y1="143.1925" x2="70.1675" y2="143.1925" width="2.54" layer="16"/>
<wire x1="70.1675" y1="143.1925" x2="75.2475" y2="143.1925" width="2.54" layer="16"/>
</signal>
<signal name="BE-DC20V.">
<contactref element="U$1" pad="P$6"/>
<contactref element="X13" pad="2"/>
<contactref element="X13" pad="1"/>
<wire x1="26.13" y1="148.2725" x2="70.1675" y2="148.2725" width="2.54" layer="16"/>
<wire x1="16.94" y1="139.0825" x2="26.13" y2="148.2725" width="2.54" layer="16"/>
<wire x1="70.1675" y1="148.2725" x2="75.2475" y2="148.2725" width="2.54" layer="16"/>
</signal>
<signal name="KI-AC16-24V.">
<contactref element="U$1" pad="P$4"/>
<contactref element="U$1" pad="P$8"/>
<wire x1="64.34" y1="139.0825" x2="64.34" y2="131.6825" width="2.54" layer="16"/>
<wire x1="64.34" y1="131.6825" x2="64.3438" y2="131.6863" width="2.54" layer="16"/>
<contactref element="X11" pad="2"/>
<contactref element="X11" pad="1"/>
<wire x1="64.34" y1="131.6825" x2="64.5325" y2="131.6825" width="2.54" layer="16"/>
<wire x1="69.85" y1="126.365" x2="64.5325" y2="131.6825" width="2.54" layer="16"/>
<wire x1="69.85" y1="126.365" x2="70.485" y2="126.365" width="2.54" layer="16"/>
<wire x1="70.485" y1="126.365" x2="75.565" y2="126.365" width="2.54" layer="16"/>
</signal>
<signal name="BE-AC16V.">
<contactref element="U$1" pad="P$3"/>
<wire x1="48.54" y1="139.0825" x2="48.8775" y2="139.0825" width="2.54" layer="16"/>
<wire x1="48.8775" y1="139.0825" x2="58.89625" y2="129.06375" width="2.54" layer="16"/>
<contactref element="X14" pad="2"/>
<contactref element="X14" pad="1"/>
<wire x1="75.565" y1="121.285" x2="70.485" y2="121.285" width="2.54" layer="16"/>
<wire x1="70.485" y1="121.285" x2="69.85" y2="120.65" width="2.54" layer="16"/>
<wire x1="69.85" y1="120.65" x2="63.1825" y2="120.65" width="2.54" layer="16"/>
<wire x1="63.1825" y1="120.65" x2="58.89625" y2="124.93625" width="2.54" layer="16"/>
<wire x1="58.89625" y1="124.93625" x2="58.89625" y2="129.06375" width="2.54" layer="16"/>
</signal>
<signal name="BE-AC24V.">
<contactref element="U$1" pad="P$7"/>
<wire x1="48.54" y1="131.6825" x2="48.975" y2="131.6825" width="2.54" layer="16"/>
<wire x1="48.975" y1="131.6825" x2="54.45125" y2="126.20625" width="2.54" layer="16"/>
<contactref element="X12" pad="2"/>
<contactref element="X12" pad="1"/>
<wire x1="70.485" y1="116.205" x2="75.565" y2="116.205" width="2.54" layer="16"/>
<wire x1="70.485" y1="116.205" x2="61.2775" y2="116.205" width="2.54" layer="16"/>
<wire x1="54.45125" y1="123.03125" x2="54.45125" y2="126.20625" width="2.54" layer="16"/>
<wire x1="61.2775" y1="116.205" x2="54.45125" y2="123.03125" width="2.54" layer="16"/>
</signal>
<signal name="N$50">
<contactref element="Q3" pad="1"/>
<contactref element="R47" pad="2"/>
<wire x1="62.735" y1="109.855" x2="62.695" y2="109.815" width="0.8128" layer="16"/>
<wire x1="62.695" y1="106.995" x2="62.695" y2="109.815" width="0.8128" layer="16"/>
</signal>
<signal name="N$51">
<contactref element="R47" pad="1"/>
<contactref element="LSP3" pad="MP"/>
<wire x1="68.2625" y1="107.315" x2="65.62875" y2="109.94875" width="0.8128" layer="16"/>
<wire x1="65.62875" y1="109.94875" x2="65.535" y2="109.855" width="0.8128" layer="16"/>
<wire x1="68.2625" y1="107.315" x2="67.945" y2="107.315" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$52">
<contactref element="X10" pad="1"/>
<contactref element="Q3" pad="3"/>
<contactref element="JP2" pad="2"/>
<wire x1="58.1025" y1="106.045" x2="58.1025" y2="110.8075" width="0.8128" layer="16"/>
<wire x1="60.495" y1="106.045" x2="58.1025" y2="106.045" width="0.8128" layer="16"/>
</signal>
<signal name="N$69">
<contactref element="R49" pad="1"/>
<contactref element="T3" pad="B"/>
<wire x1="220.8675" y1="8.255" x2="220.2325" y2="8.89" width="0.8128" layer="16"/>
<wire x1="220.2325" y1="8.89" x2="218.1225" y2="8.89" width="0.8128" layer="16"/>
</signal>
<signal name="N$70">
<contactref element="T3" pad="E"/>
<contactref element="R51" pad="1"/>
<wire x1="218.1225" y1="6.35" x2="217.7915" y2="6.019" width="0.8128" layer="16"/>
<wire x1="217.7915" y1="6.019" x2="215.5825" y2="6.019" width="0.8128" layer="16"/>
</signal>
<signal name="N$71">
<contactref element="T3" pad="C"/>
<contactref element="R50" pad="1"/>
<contactref element="T4" pad="B"/>
<contactref element="T5" pad="B"/>
<wire x1="212.4075" y1="9.525" x2="212.5595" y2="9.373" width="0.8128" layer="16"/>
<wire x1="207.3275" y1="9.525" x2="212.4075" y2="9.525" width="0.8128" layer="16"/>
<wire x1="212.4075" y1="9.525" x2="214.9475" y2="9.525" width="0.8128" layer="16"/>
<wire x1="216.8525" y1="11.43" x2="214.9475" y2="9.525" width="0.8128" layer="16"/>
<wire x1="218.1225" y1="11.43" x2="216.8525" y2="11.43" width="0.8128" layer="16"/>
<wire x1="217.0045" y1="13.97" x2="217.0045" y2="11.43" width="0.8128" layer="16"/>
<wire x1="218.1225" y1="11.43" x2="217.0045" y2="11.43" width="0.8128" layer="16"/>
</signal>
<signal name="N$72">
<contactref element="R52" pad="1"/>
<contactref element="T4" pad="E"/>
<contactref element="T5" pad="E"/>
<wire x1="203.555" y1="9.1835" x2="204.19" y2="9.1835" width="0.8128" layer="16"/>
<wire x1="206.3885" y1="6.985" x2="204.19" y2="9.1835" width="0.8128" layer="16"/>
<wire x1="206.3885" y1="6.985" x2="207.3275" y2="6.985" width="0.8128" layer="16"/>
<wire x1="207.3275" y1="6.985" x2="207.9625" y2="7.62" width="0.8128" layer="16"/>
<wire x1="211.7725" y1="7.62" x2="207.9625" y2="7.62" width="0.8128" layer="16"/>
<wire x1="211.7725" y1="7.62" x2="212.4075" y2="6.985" width="0.8128" layer="16"/>
</signal>
<signal name="N$78">
<contactref element="D10" pad="A"/>
<contactref element="Q4" pad="G"/>
<contactref element="R52" pad="2"/>
<wire x1="203.555" y1="12.5835" x2="200.9775" y2="15.161" width="0.8128" layer="16"/>
<wire x1="200.9775" y1="15.161" x2="200.9775" y2="15.24" width="0.8128" layer="16"/>
<wire x1="200.9775" y1="15.24" x2="198.4375" y2="17.78" width="0.8128" layer="16"/>
<wire x1="198.4375" y1="17.78" x2="198.4375" y2="19.685" width="0.8128" layer="16"/>
</signal>
<signal name="N$73">
<contactref element="R48" pad="2"/>
<contactref element="LED3" pad="A"/>
<wire x1="224.4725" y1="12.7" x2="224.9025" y2="13.13" width="0.8128" layer="16"/>
<wire x1="224.9025" y1="13.13" x2="227.0125" y2="13.13" width="0.8128" layer="16"/>
</signal>
<signal name="N$74">
<contactref element="Q4" pad="D"/>
<contactref element="D8" pad="C"/>
<wire x1="194.6021" y1="8.1446" x2="194.7125" y2="8.255" width="2" layer="16"/>
<wire x1="195.8975" y1="9.44" x2="194.7125" y2="8.255" width="2" layer="16"/>
<wire x1="195.8975" y1="9.44" x2="195.8975" y2="19.685" width="2" layer="16"/>
<contactref element="X17" pad="2"/>
<wire x1="194.6275" y1="5.08" x2="194.6021" y2="5.1054" width="2" layer="16"/>
<wire x1="194.6021" y1="5.1054" x2="194.6021" y2="8.1446" width="2" layer="16"/>
<contactref element="JP4" pad="2"/>
<wire x1="195.8975" y1="10.795" x2="195.8975" y2="9.44" width="0.8128" layer="16"/>
</signal>
<signal name="N$75">
<contactref element="R50" pad="2"/>
<contactref element="T4" pad="C"/>
<contactref element="D10" pad="C"/>
<contactref element="D9" pad="C"/>
<contactref element="C23" pad="+"/>
<contactref element="C24" pad="1"/>
<wire x1="207.4125" y1="19.685" x2="207.9625" y2="19.685" width="0.8128" layer="16"/>
<wire x1="208.4675" y1="24.765" x2="208.4675" y2="25.27" width="0.8128" layer="16"/>
<wire x1="207.9625" y1="19.685" x2="207.9625" y2="18.415" width="0.8128" layer="16"/>
<wire x1="207.3275" y1="19.685" x2="207.4125" y2="19.685" width="0.8128" layer="16"/>
<wire x1="211.1375" y1="15.24" x2="207.9625" y2="18.415" width="0.8128" layer="16"/>
<wire x1="214.1605" y1="13.97" x2="214.1605" y2="13.818" width="0.8128" layer="16"/>
<wire x1="212.4075" y1="12.065" x2="212.4075" y2="13.97" width="0.8128" layer="16"/>
<wire x1="212.4075" y1="13.97" x2="211.1375" y2="15.24" width="0.8128" layer="16"/>
<wire x1="214.1605" y1="13.97" x2="212.4075" y2="13.97" width="0.8128" layer="16"/>
<wire x1="207.9625" y1="24.765" x2="207.9625" y2="27.305" width="0.8128" layer="16"/>
<wire x1="207.9625" y1="24.765" x2="207.9625" y2="20.32" width="0.8128" layer="16"/>
<wire x1="207.9625" y1="20.32" x2="207.3275" y2="19.685" width="0.8128" layer="16"/>
<wire x1="208.4675" y1="24.765" x2="207.9625" y2="24.765" width="0.8128" layer="16"/>
<contactref element="IC5" pad="IN"/>
<wire x1="208.4675" y1="25.27" x2="172.72" y2="25.27" width="1.016" layer="16"/>
<wire x1="172.72" y1="25.27" x2="170.815" y2="27.175" width="1.016" layer="16"/>
<wire x1="170.815" y1="27.175" x2="170.815" y2="29.5275" width="1.016" layer="16"/>
<wire x1="205.4225" y1="28.575" x2="206.6925" y2="28.575" width="1.016" layer="16"/>
<wire x1="206.6925" y1="28.575" x2="207.9625" y2="27.305" width="1.016" layer="16"/>
<wire x1="207.9625" y1="27.305" x2="207.9625" y2="20.32" width="1.016" layer="16"/>
</signal>
<signal name="N$94">
<via x="133.0325" y="3.81" extent="1-16" drill="0.8" diameter="3"/>
</signal>
<signal name="N$95">
<via x="133.0325" y="32.385" extent="1-16" drill="0.8" diameter="3"/>
</signal>
<signal name="N$96">
<via x="249.2375" y="32.385" extent="1-16" drill="0.8" diameter="3"/>
</signal>
<signal name="N$97">
<via x="249.2375" y="3.81" extent="1-16" drill="0.8" diameter="3"/>
</signal>
<signal name="N$76">
<contactref element="F1" pad="2A"/>
<contactref element="X16" pad="1"/>
<wire x1="132.3975" y1="21.5646" x2="132.3975" y2="23.749" width="2.54" layer="16"/>
<wire x1="138.4935" y1="29.845" x2="140.3985" y2="29.845" width="2.54" layer="16"/>
<wire x1="138.4935" y1="29.845" x2="132.3975" y2="23.749" width="2.54" layer="16"/>
<wire x1="145.415" y1="29.845" x2="140.3985" y2="29.845" width="2.54" layer="16"/>
</signal>
<signal name="+5V">
<contactref element="IC3" pad="OUT"/>
<contactref element="C11" pad="+"/>
<contactref element="C10" pad="2"/>
<contactref element="IC4" pad="8"/>
<contactref element="JP3" pad="3"/>
<wire x1="218.7575" y1="29.5275" x2="218.7575" y2="26.035" width="0.8128" layer="16"/>
<wire x1="218.7575" y1="26.035" x2="218.7575" y2="22.987" width="0.8128" layer="16"/>
<wire x1="218.7575" y1="22.987" x2="217.3605" y2="21.59" width="0.8128" layer="16"/>
<wire x1="217.3605" y1="21.59" x2="218.6305" y2="20.32" width="0.8128" layer="16"/>
<wire x1="218.6305" y1="20.32" x2="218.6305" y2="18.158" width="0.8128" layer="16"/>
<wire x1="218.2525" y1="17.78" x2="218.6305" y2="18.158" width="0.8128" layer="16"/>
<wire x1="222.5675" y1="20.955" x2="220.6625" y2="19.05" width="0.8128" layer="16"/>
<wire x1="220.6625" y1="17.78" x2="220.6625" y2="19.05" width="0.8128" layer="16"/>
<wire x1="220.6625" y1="17.78" x2="218.2525" y2="17.78" width="0.8128" layer="16"/>
<via x="218.7575" y="26.035" extent="1-16" drill="0.35" diameter="1.15"/>
<contactref element="R100" pad="2"/>
<contactref element="R99" pad="2"/>
<contactref element="DIS2" pad="2"/>
<contactref element="R89" pad="2"/>
<contactref element="C38" pad="1"/>
<contactref element="C40" pad="2"/>
<contactref element="R93" pad="1"/>
<contactref element="R107" pad="1"/>
<contactref element="R104" pad="2"/>
<contactref element="R106" pad="2"/>
<contactref element="C44" pad="2"/>
<contactref element="C43" pad="1"/>
<contactref element="IC13" pad="7"/>
<contactref element="R95" pad="1"/>
<contactref element="JP9" pad="1"/>
<contactref element="IC12" pad="7"/>
<wire x1="241.3" y1="142.875" x2="241.17" y2="143.005" width="0.8128" layer="1"/>
<wire x1="241.17" y1="143.005" x2="241.17" y2="145.0975" width="0.8128" layer="1"/>
<contactref element="R94" pad="2"/>
<wire x1="208.0875" y1="160.655" x2="206.125" y2="158.6925" width="0.8128" layer="1"/>
<wire x1="206.125" y1="157.74" x2="206.125" y2="158.6925" width="0.8128" layer="1"/>
<wire x1="245.11" y1="160.655" x2="208.0875" y2="160.655" width="0.8128" layer="1"/>
<wire x1="245.11" y1="160.655" x2="263.2075" y2="160.655" width="0.8128" layer="1"/>
<wire x1="245.11" y1="154.6225" x2="247.3325" y2="154.6225" width="0.8128" layer="1"/>
<wire x1="241.3" y1="142.875" x2="241.3" y2="139.7925" width="0.8128" layer="1"/>
<wire x1="241.3" y1="139.7925" x2="242.0275" y2="139.065" width="0.8128" layer="1"/>
<wire x1="241.17" y1="145.0975" x2="241.17" y2="146.2375" width="0.8128" layer="1"/>
<wire x1="241.17" y1="146.2375" x2="242.2525" y2="147.32" width="0.8128" layer="1"/>
<wire x1="242.2525" y1="147.32" x2="245.745" y2="147.32" width="0.8128" layer="1"/>
<wire x1="245.745" y1="147.32" x2="247.3325" y2="145.7325" width="0.8128" layer="1"/>
<via x="247.3325" y="145.7325" extent="1-16" drill="0.8"/>
<wire x1="247.3325" y1="145.7325" x2="247.3325" y2="154.6225" width="0.8128" layer="16"/>
<via x="247.3325" y="154.6225" extent="1-16" drill="0.8"/>
<wire x1="251.7775" y1="154.4705" x2="251.6255" y2="154.6225" width="0.8128" layer="1"/>
<wire x1="251.6255" y1="154.6225" x2="247.3325" y2="154.6225" width="0.8128" layer="1"/>
<wire x1="210.185" y1="147.32" x2="213.6775" y2="150.8125" width="0.8128" layer="1"/>
<wire x1="220.5105" y1="148.9075" x2="218.44" y2="148.9075" width="0.8128" layer="1"/>
<wire x1="218.44" y1="143.51" x2="212.4075" y2="143.51" width="0.8128" layer="1"/>
<wire x1="206.125" y1="157.74" x2="206.0575" y2="157.6725" width="0.8128" layer="1"/>
<wire x1="206.0575" y1="157.6725" x2="206.0575" y2="151.4475" width="0.8128" layer="1"/>
<wire x1="206.0575" y1="151.4475" x2="206.0575" y2="148.9075" width="0.8128" layer="1"/>
<wire x1="206.0575" y1="148.9075" x2="206.0575" y2="147.32" width="0.8128" layer="1"/>
<wire x1="206.0575" y1="147.32" x2="206.0575" y2="146.3675" width="0.8128" layer="1"/>
<wire x1="204.47" y1="145.92" x2="204.47" y2="144.145" width="0.8128" layer="1"/>
<wire x1="204.47" y1="144.145" x2="203.835" y2="143.51" width="0.8128" layer="1"/>
<wire x1="210.185" y1="147.32" x2="206.0575" y2="147.32" width="0.8128" layer="1"/>
<wire x1="204.9175" y1="146.3675" x2="204.47" y2="145.92" width="0.8128" layer="1"/>
<wire x1="206.0575" y1="146.3675" x2="204.9175" y2="146.3675" width="0.8128" layer="1"/>
<wire x1="204.9175" y1="148.9075" x2="206.0575" y2="148.9075" width="0.8128" layer="1"/>
<via x="245.11" y="154.6225" extent="1-16" drill="0.8"/>
<wire x1="242.4045" y1="154.6225" x2="245.11" y2="154.6225" width="0.8128" layer="1"/>
<via x="245.11" y="160.3375" extent="1-16" drill="0.8"/>
<wire x1="245.11" y1="154.6225" x2="245.11" y2="160.3375" width="0.8128" layer="16"/>
<contactref element="J2" pad="1"/>
<wire x1="263.2075" y1="160.655" x2="266.5875" y2="157.275" width="0.8128" layer="1"/>
<wire x1="266.5875" y1="157.275" x2="266.7" y2="157.275" width="0.8128" layer="1"/>
<wire x1="251.943" y1="152.2345" x2="251.943" y2="154.94" width="0.8128" layer="1"/>
<wire x1="252.8955" y1="100.33" x2="251.639" y2="100.33" width="0.8128" layer="1"/>
<wire x1="251.639" y1="100.33" x2="250.521" y2="101.448" width="0.8128" layer="1"/>
<wire x1="226.3775" y1="127.635" x2="226.3775" y2="119.6975" width="0.8128" layer="1"/>
<via x="226.3775" y="127.635" extent="1-16" drill="0.8" diameter="1.7"/>
<wire x1="226.3775" y1="127.635" x2="218.44" y2="127.635" width="0.8128" layer="16"/>
<via x="218.44" y="127.635" extent="1-16" drill="0.8" diameter="1.7"/>
<wire x1="218.44" y1="127.635" x2="218.44" y2="129.9875" width="0.8128" layer="1"/>
<wire x1="218.44" y1="129.9875" x2="218.6275" y2="130.175" width="0.8128" layer="1"/>
<wire x1="218.6275" y1="130.175" x2="218.44" y2="130.3625" width="0.8128" layer="1"/>
<wire x1="218.44" y1="130.3625" x2="218.44" y2="132.715" width="0.8128" layer="1"/>
<via x="218.44" y="132.715" extent="1-16" drill="0.8" diameter="1.7"/>
<wire x1="218.44" y1="132.715" x2="218.44" y2="143.51" width="0.8128" layer="16"/>
<via x="218.44" y="143.51" extent="1-16" drill="0.8" diameter="1.7"/>
<wire x1="218.44" y1="143.51" x2="218.44" y2="148.9075" width="0.8128" layer="1"/>
<wire x1="216.535" y1="150.8125" x2="218.44" y2="148.9075" width="0.8128" layer="1"/>
<wire x1="213.6775" y1="150.8125" x2="216.535" y2="150.8125" width="0.8128" layer="1"/>
<wire x1="245.11" y1="160.3375" x2="245.11" y2="160.655" width="0.8128" layer="1"/>
<wire x1="202.409425" y1="105.0925" x2="214.9475" y2="105.0925" width="0.8128" layer="1"/>
<wire x1="253.365" y1="150.8125" x2="251.943" y2="152.2345" width="0.8128" layer="1"/>
<wire x1="220.18625" y1="113.50625" x2="226.3775" y2="119.6975" width="0.8128" layer="1"/>
<wire x1="214.9475" y1="105.0925" x2="219.075" y2="105.0925" width="0.8128" layer="1"/>
<wire x1="217.32875" y1="113.50625" x2="220.18625" y2="113.50625" width="0.8128" layer="1"/>
<wire x1="214.9475" y1="105.0925" x2="214.9475" y2="111.125" width="0.8128" layer="1"/>
<wire x1="214.9475" y1="111.125" x2="217.32875" y2="113.50625" width="0.8128" layer="1"/>
<wire x1="222.3625" y1="101.805" x2="235.9025" y2="101.805" width="0.8128" layer="1"/>
<wire x1="219.075" y1="105.0925" x2="222.3625" y2="101.805" width="0.8128" layer="1"/>
<wire x1="235.9025" y1="101.805" x2="236.015" y2="101.9175" width="0.8128" layer="1"/>
<wire x1="250.20425" y1="101.9175" x2="250.5075" y2="101.61425" width="0.8128" layer="1"/>
<wire x1="236.015" y1="101.9175" x2="250.20425" y2="101.9175" width="0.8128" layer="1"/>
<contactref element="R111" pad="3"/>
<wire x1="202.355" y1="151.5675" x2="205.9375" y2="151.5675" width="0.8128" layer="1"/>
<wire x1="205.9375" y1="151.5675" x2="206.0575" y2="151.4475" width="0.8128" layer="1"/>
<wire x1="235.9025" y1="101.805" x2="218.7575" y2="29.5275" width="0" layer="19" extent="1-1"/>
<wire x1="250.521" y1="101.448" x2="250.5075" y2="101.61425" width="0" layer="19" extent="1-1"/>
<wire x1="251.943" y1="154.94" x2="251.7775" y2="154.4705" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$77">
<contactref element="R53" pad="1"/>
<contactref element="T7" pad="B"/>
<wire x1="232.7275" y1="13.13" x2="231.8875" y2="13.97" width="0.8128" layer="16"/>
<wire x1="229.5525" y1="13.97" x2="231.8875" y2="13.97" width="0.8128" layer="16"/>
</signal>
<signal name="N$79">
<contactref element="K1" pad="S1"/>
<wire x1="242.8875" y1="5.715" x2="242.8875" y2="5.4864" width="2.54" layer="16"/>
<contactref element="X18" pad="1"/>
<wire x1="249.555" y1="9.8679" x2="247.040409375" y2="9.867909375" width="2.54" layer="16"/>
<wire x1="247.040409375" y1="9.867909375" x2="242.8875" y2="5.715" width="2.54" layer="16"/>
</signal>
<signal name="N$80">
<contactref element="K1" pad="P1"/>
<contactref element="K1" pad="O1"/>
<wire x1="242.8875" y1="10.4902" x2="242.8875" y2="15.4686" width="2.54" layer="16"/>
<wire x1="243.84" y1="14.8971" x2="243.2685" y2="15.4686" width="2.54" layer="16"/>
<wire x1="243.2685" y1="15.4686" x2="242.8875" y2="15.4686" width="2.54" layer="16"/>
<contactref element="X18" pad="2"/>
<wire x1="249.555" y1="14.8971" x2="243.84" y2="14.8971" width="2.54" layer="16"/>
</signal>
<signal name="N$81">
<contactref element="IC4" pad="4"/>
<contactref element="C13" pad="1"/>
<wire x1="230.1875" y1="28.575" x2="230.9525" y2="28.575" width="0.8128" layer="16"/>
<wire x1="230.9525" y1="28.575" x2="233.3625" y2="26.165" width="0.8128" layer="16"/>
</signal>
<signal name="N$82">
<contactref element="IC4" pad="2"/>
<contactref element="C13" pad="2"/>
<wire x1="230.1875" y1="23.495" x2="233.2325" y2="23.495" width="0.8128" layer="16"/>
<wire x1="233.2325" y1="23.495" x2="233.3625" y2="23.365" width="0.8128" layer="16"/>
</signal>
<signal name="N$83">
<contactref element="K1" pad="S2"/>
<wire x1="233.7181" y1="3.81" x2="235.3945" y2="5.4864" width="0.8128" layer="16"/>
<contactref element="LSP9" pad="MP"/>
<contactref element="J1" pad="3"/>
<wire x1="221.2975" y1="3.81" x2="229.5525" y2="3.81" width="0.8128" layer="16"/>
<wire x1="229.5525" y1="3.81" x2="233.7181" y2="3.81" width="0.8128" layer="16"/>
</signal>
<signal name="N$84">
<contactref element="R49" pad="2"/>
<contactref element="R48" pad="1"/>
<contactref element="J1" pad="1"/>
<wire x1="224.2675" y1="8.255" x2="224.9025" y2="8.89" width="0.8128" layer="16"/>
<wire x1="224.9025" y1="8.89" x2="227.0125" y2="8.89" width="0.8128" layer="16"/>
<wire x1="227.0125" y1="8.89" x2="229.5525" y2="8.89" width="0.8128" layer="16"/>
<wire x1="227.0125" y1="9.73" x2="227.0125" y2="8.89" width="0.8128" layer="16"/>
</signal>
<signal name="N$85">
<contactref element="Q4" pad="S"/>
<contactref element="D9" pad="A"/>
<wire x1="195.2625" y1="22.225" x2="193.3575" y2="20.32" width="0.8128" layer="16"/>
<wire x1="193.3575" y1="19.685" x2="193.3575" y2="20.32" width="0.8128" layer="16"/>
<wire x1="202.1625" y1="19.685" x2="202.1625" y2="19.77" width="0.8128" layer="16"/>
<wire x1="202.1625" y1="19.77" x2="199.7075" y2="22.225" width="0.8128" layer="16"/>
<contactref element="LSP4" pad="MP"/>
<wire x1="199.7075" y1="22.225" x2="195.2625" y2="22.225" width="0.8128" layer="16"/>
<wire x1="192.0875" y1="19.685" x2="188.595" y2="19.685" width="2.54" layer="16"/>
<wire x1="188.595" y1="19.685" x2="187.96" y2="20.32" width="2.54" layer="16"/>
<wire x1="193.3575" y1="19.685" x2="192.0875" y2="19.685" width="2" layer="16"/>
</signal>
<signal name="N$86">
<contactref element="B1" pad="AC1"/>
<contactref element="F1" pad="1A"/>
<wire x1="139.3825" y1="15.24" x2="135.89" y2="18.7325" width="2.54" layer="16"/>
<wire x1="155.829" y1="29.845" x2="161.2265" y2="29.845" width="2.54" layer="16"/>
<wire x1="155.829" y1="29.845" x2="152.019" y2="26.035" width="2.54" layer="16"/>
<wire x1="140.0175" y1="26.035" x2="152.019" y2="26.035" width="2.54" layer="16"/>
<wire x1="135.89" y1="18.7325" x2="135.89" y2="21.9075" width="2.54" layer="16"/>
<wire x1="135.89" y1="21.9075" x2="140.0175" y2="26.035" width="2.54" layer="16"/>
</signal>
<signal name="N$87">
<contactref element="B1" pad="AC2"/>
<contactref element="X16" pad="2"/>
<wire x1="139.3825" y1="10.16" x2="138.7729" y2="10.16" width="2.54" layer="16"/>
<wire x1="138.7729" y1="10.16" x2="132.3975" y2="16.5354" width="2.54" layer="16"/>
<contactref element="LSP10" pad="MP"/>
<wire x1="132.3975" y1="11.1125" x2="132.3975" y2="16.5354" width="0.8128" layer="16"/>
</signal>
<signal name="N$88">
<contactref element="X17" pad="1"/>
<contactref element="LSP6" pad="MP"/>
<wire x1="209.8675" y1="3.81" x2="200.9013" y2="3.81" width="0.8128" layer="16"/>
<wire x1="199.6313" y1="5.08" x2="200.9013" y2="3.81" width="0.8128" layer="16"/>
<contactref element="JP4" pad="1"/>
<wire x1="199.6313" y1="5.08" x2="198.4375" y2="6.2738" width="0.8128" layer="16"/>
<wire x1="198.4375" y1="6.2738" x2="198.4375" y2="10.795" width="0.8128" layer="16"/>
</signal>
<signal name="N$98">
<via x="190.8175" y="13.97" extent="1-16" drill="0.8" diameter="3"/>
</signal>
<signal name="N$89">
<contactref element="J1" pad="2"/>
<contactref element="R53" pad="2"/>
<wire x1="229.5525" y1="6.35" x2="230.8225" y2="6.35" width="0.8128" layer="16"/>
<wire x1="230.8225" y1="6.35" x2="232.7275" y2="8.255" width="0.8128" layer="16"/>
<wire x1="232.7275" y1="8.255" x2="232.7275" y2="9.73" width="0.8128" layer="16"/>
</signal>
<signal name="N$90">
<contactref element="C8" pad="+"/>
<contactref element="C7" pad="+"/>
<contactref element="LSP11" pad="MP"/>
<contactref element="B1" pad="+"/>
<contactref element="LSP7" pad="MP"/>
<contactref element="LSP5" pad="MP"/>
<wire x1="139.3825" y1="20.32" x2="142.24" y2="20.32" width="2.54" layer="16"/>
<wire x1="142.24" y1="20.32" x2="144.145" y2="18.415" width="2.54" layer="16"/>
<wire x1="163.5125" y1="20.32" x2="161.6075" y2="18.415" width="2.54" layer="16"/>
<wire x1="152.7175" y1="18.415" x2="144.145" y2="18.415" width="2.54" layer="16"/>
<wire x1="161.6075" y1="18.415" x2="152.7175" y2="18.415" width="2.54" layer="16"/>
<wire x1="163.5125" y1="20.32" x2="166.0525" y2="20.32" width="2.54" layer="16"/>
<wire x1="167.9575" y1="18.415" x2="166.0525" y2="20.32" width="2.54" layer="16"/>
<wire x1="167.9575" y1="18.415" x2="176.8475" y2="18.415" width="2.54" layer="16"/>
</signal>
<signal name="N$99">
<wire x1="155.8925" y1="29.845" x2="161.29" y2="29.845" width="2.54" layer="16"/>
</signal>
<signal name="N$91">
<contactref element="OK1" pad="1"/>
<contactref element="R54" pad="1"/>
<wire x1="243.5225" y1="22.1125" x2="247.22" y2="18.415" width="0.8128" layer="16"/>
<wire x1="247.22" y1="18.415" x2="247.3325" y2="18.415" width="0.8128" layer="16"/>
</signal>
<signal name="N$92">
<contactref element="D11" pad="A"/>
<contactref element="T7" pad="C"/>
<contactref element="K1" pad="1"/>
<wire x1="235.3945" y1="30.48" x2="235.3945" y2="30.2405" width="0.8128" layer="16"/>
<wire x1="235.3945" y1="30.2405" x2="237.3775" y2="28.2575" width="0.8128" layer="16"/>
<wire x1="237.3775" y1="28.2575" x2="237.3775" y2="22.1125" width="0.8128" layer="16"/>
<wire x1="237.3775" y1="22.1125" x2="231.775" y2="16.51" width="0.8128" layer="16"/>
<wire x1="231.775" y1="16.51" x2="229.5525" y2="16.51" width="0.8128" layer="16"/>
</signal>
<signal name="N$93">
<contactref element="OK1" pad="4"/>
<contactref element="JP5" pad="2"/>
<wire x1="247.3325" y1="27.6225" x2="247.3325" y2="26.035" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$118">
<via x="133.35" y="46.6725" extent="1-16" drill="0.8" diameter="3"/>
</signal>
<signal name="N$119">
<via x="133.35" y="75.2475" extent="1-16" drill="0.8" diameter="3"/>
</signal>
<signal name="N$120">
<via x="249.555" y="75.2475" extent="1-16" drill="0.8" diameter="3"/>
</signal>
<signal name="N$121">
<via x="249.555" y="46.6725" extent="1-16" drill="0.8" diameter="3"/>
</signal>
<signal name="N$100">
<contactref element="IC7" pad="4"/>
<contactref element="C17" pad="1"/>
<wire x1="159.0675" y1="49.7175" x2="158.5625" y2="49.2125" width="0.8128" layer="16"/>
<wire x1="155.8925" y1="49.2125" x2="158.5625" y2="49.2125" width="0.8128" layer="16"/>
</signal>
<signal name="N$101">
<contactref element="IC7" pad="2"/>
<contactref element="C17" pad="2"/>
<wire x1="159.0675" y1="52.5175" x2="157.2925" y2="54.2925" width="0.8128" layer="16"/>
<wire x1="155.8925" y1="54.2925" x2="157.2925" y2="54.2925" width="0.8128" layer="16"/>
</signal>
<signal name="N$122">
<via x="191.135" y="56.8325" extent="1-16" drill="0.8" diameter="3"/>
</signal>
<signal name="N$102">
<contactref element="X19" pad="2"/>
<contactref element="F2" pad="2"/>
<contactref element="X21" pad="2"/>
<wire x1="131.4704" y1="55.245" x2="131.4704" y2="60.96" width="1.27" layer="16"/>
<wire x1="131.7625" y1="60.96" x2="131.4704" y2="60.96" width="1.27" layer="16"/>
<wire x1="131.4704" y1="60.96" x2="131.4704" y2="66.9925" width="1.27" layer="16"/>
</signal>
<signal name="N$103">
<contactref element="F2" pad="1"/>
<contactref element="B2" pad="AC1"/>
<wire x1="139.9625" y1="63.8275" x2="139.71" y2="63.8275" width="1.27" layer="16"/>
<wire x1="139.71" y1="63.8275" x2="136.8425" y2="60.96" width="1.27" layer="16"/>
</signal>
<signal name="N$104">
<contactref element="X19" pad="1"/>
<contactref element="B2" pad="AC2"/>
<contactref element="X21" pad="1"/>
<wire x1="136.4996" y1="55.245" x2="137.795" y2="55.245" width="1.27" layer="16"/>
<wire x1="139.9625" y1="57.4125" x2="139.9625" y2="58.7275" width="1.27" layer="16"/>
<wire x1="137.795" y1="55.245" x2="139.9625" y2="57.4125" width="1.27" layer="16"/>
<wire x1="136.4996" y1="66.9925" x2="134.3025" y2="64.7954" width="1.27" layer="16"/>
<wire x1="134.3025" y1="57.4421" x2="136.4996" y2="55.245" width="1.27" layer="16"/>
<wire x1="134.3025" y1="64.7954" x2="134.3025" y2="57.4421" width="1.27" layer="16"/>
</signal>
<signal name="N$105">
<contactref element="Q5" pad="G"/>
<contactref element="R57" pad="1"/>
<wire x1="171.245" y1="56.515" x2="171.245" y2="52.5" width="0.8128" layer="16"/>
<wire x1="171.245" y1="52.5" x2="171.1325" y2="52.3875" width="0.8128" layer="16"/>
</signal>
<signal name="N$106">
<contactref element="R57" pad="2"/>
<contactref element="IC8" pad="1"/>
<contactref element="C20" pad="2"/>
<wire x1="163.195" y1="67.31" x2="163.195" y2="64.135" width="0.8128" layer="16"/>
<wire x1="165.865" y1="61.465" x2="166.6875" y2="61.465" width="0.8128" layer="16"/>
<wire x1="163.195" y1="64.135" x2="165.865" y2="61.465" width="0.8128" layer="16"/>
<wire x1="166.6875" y1="61.465" x2="167.64" y2="60.5125" width="0.8128" layer="16"/>
<wire x1="167.64" y1="60.5125" x2="167.64" y2="56.72" width="0.8128" layer="16"/>
<wire x1="167.64" y1="56.72" x2="167.845" y2="56.515" width="0.8128" layer="16"/>
</signal>
<signal name="N$107">
<contactref element="C20" pad="1"/>
<contactref element="Q6" pad="C"/>
<contactref element="IC8" pad="2"/>
<contactref element="R63" pad="2"/>
<wire x1="165.735" y1="67.31" x2="165.735" y2="66.805" width="0.8128" layer="16"/>
<wire x1="165.735" y1="67.31" x2="165.735" y2="64.4525" width="0.8128" layer="16"/>
<wire x1="165.735" y1="64.4525" x2="166.0525" y2="64.135" width="0.8128" layer="16"/>
<wire x1="166.0525" y1="64.135" x2="166.5575" y2="64.135" width="0.8128" layer="16"/>
<wire x1="166.5575" y1="64.135" x2="166.6875" y2="64.265" width="0.8128" layer="16"/>
<wire x1="166.6875" y1="64.265" x2="167.51" y2="65.0875" width="0.8128" layer="16"/>
<wire x1="174.1775" y1="65.0875" x2="174.625" y2="65.535" width="0.8128" layer="16"/>
<wire x1="167.51" y1="65.0875" x2="174.1775" y2="65.0875" width="0.8128" layer="16"/>
<wire x1="174.625" y1="68.58" x2="174.625" y2="65.535" width="0.8128" layer="16"/>
<wire x1="174.625" y1="68.58" x2="174.9425" y2="68.8975" width="0.8128" layer="16"/>
</signal>
<signal name="N$108">
<contactref element="IC8" pad="3"/>
<contactref element="R61" pad="1"/>
<contactref element="R60" pad="2"/>
<wire x1="168.0875" y1="69.85" x2="168.199215625" y2="69.961715625" width="0.8128" layer="16"/>
<wire x1="168.0875" y1="69.85" x2="168.275" y2="69.6625" width="0.8128" layer="16"/>
<wire x1="168.275" y1="69.6625" x2="168.275" y2="67.31" width="0.8128" layer="16"/>
<wire x1="168.0875" y1="69.85" x2="168.7225" y2="70.485" width="0.8128" layer="16"/>
<wire x1="171.655" y1="70.485" x2="168.7225" y2="70.485" width="0.8128" layer="16"/>
<wire x1="171.655" y1="70.485" x2="174.195" y2="73.025" width="0.8128" layer="16"/>
</signal>
<signal name="N$109">
<contactref element="R59" pad="2"/>
<contactref element="R62" pad="1"/>
<contactref element="R63" pad="1"/>
<wire x1="170.4975" y1="62.6775" x2="170.7575" y2="62.4175" width="0.8128" layer="16"/>
<wire x1="174.625" y1="62.735" x2="174.625" y2="62.6775" width="0.8128" layer="16"/>
<wire x1="174.625" y1="62.735" x2="170.555" y2="62.735" width="0.8128" layer="16"/>
<wire x1="170.555" y1="62.735" x2="170.4975" y2="62.6775" width="0.8128" layer="16"/>
<wire x1="174.625" y1="62.735" x2="174.625" y2="58.55" width="0.8128" layer="16"/>
<wire x1="174.495" y1="58.42" x2="174.625" y2="58.55" width="0.8128" layer="16"/>
</signal>
<signal name="N$110">
<contactref element="R55" pad="1"/>
<contactref element="R56" pad="2"/>
<contactref element="Q6" pad="B"/>
<wire x1="177.4825" y1="68.8975" x2="177.4825" y2="65.535" width="0.8128" layer="16"/>
<wire x1="182.88" y1="64.565" x2="181.91" y2="65.535" width="0.8128" layer="16"/>
<wire x1="181.91" y1="65.535" x2="177.4825" y2="65.535" width="0.8128" layer="16"/>
</signal>
<signal name="N$111">
<contactref element="R56" pad="1"/>
<contactref element="LED4" pad="A"/>
<wire x1="182.88" y1="61.165" x2="182.88" y2="56.1975" width="0.8128" layer="16"/>
<wire x1="182.88" y1="56.1975" x2="179.07" y2="52.3875" width="0.8128" layer="16"/>
</signal>
<signal name="N$112">
<contactref element="LED4" pad="K"/>
<contactref element="Q5" pad="D"/>
<contactref element="X20" pad="2"/>
<wire x1="171.1325" y1="49.8475" x2="179.07" y2="49.8475" width="1.27" layer="16"/>
<wire x1="179.07" y1="49.8475" x2="180.6575" y2="49.8475" width="1.27" layer="16"/>
<wire x1="180.6575" y1="49.8475" x2="184.785" y2="53.975" width="1.27" layer="16"/>
<wire x1="184.785" y1="53.975" x2="184.785" y2="59.055" width="1.27" layer="16"/>
<wire x1="184.785" y1="59.055" x2="188.2775" y2="62.5475" width="1.27" layer="16"/>
</signal>
<signal name="N$113">
<contactref element="R59" pad="1"/>
<contactref element="R64" pad="1"/>
<contactref element="R64" pad="2"/>
<wire x1="179.705" y1="58.1025" x2="180.0225" y2="57.785" width="0.8128" layer="16"/>
<wire x1="180.0225" y1="57.785" x2="180.0225" y2="58.42" width="0.8128" layer="16"/>
<wire x1="180.0225" y1="58.42" x2="180.0225" y2="60.325" width="0.8128" layer="16"/>
<wire x1="177.295" y1="58.42" x2="180.0225" y2="58.42" width="0.8128" layer="16"/>
</signal>
<signal name="N$114">
<contactref element="JP6" pad="1"/>
<contactref element="R60" pad="1"/>
<wire x1="178.435" y1="73.025" x2="179.3875" y2="73.9775" width="0.8128" layer="16"/>
<wire x1="178.435" y1="73.025" x2="177.595" y2="73.025" width="0.8128" layer="16"/>
</signal>
<signal name="N$115">
<contactref element="Q6" pad="E"/>
<contactref element="R58" pad="2"/>
<wire x1="180.0225" y1="68.8975" x2="182.4325" y2="68.8975" width="0.8128" layer="16"/>
</signal>
<signal name="N$123">
<via x="240.9825" y="70.1675" extent="1-16" drill="0.8" diameter="2.5"/>
<wire x1="240.9825" y1="70.1675" x2="247.65" y2="63.5" width="1.016" layer="16"/>
<wire x1="247.65" y1="63.5" x2="249.555" y2="63.5" width="1.016" layer="16"/>
</signal>
<signal name="N$124">
<via x="240.9825" y="51.7525" extent="1-16" drill="0.8" diameter="2.5"/>
<wire x1="249.555" y1="58.42" x2="247.65" y2="58.42" width="1.016" layer="16"/>
<wire x1="247.65" y1="58.42" x2="240.9825" y2="51.7525" width="1.016" layer="16"/>
</signal>
<signal name="N$125">
<via x="201.295" y="51.435" extent="1-16" drill="0.8" diameter="2.5"/>
<wire x1="190.5" y1="48.895" x2="198.755" y2="48.895" width="0.8128" layer="16"/>
<wire x1="198.755" y1="48.895" x2="201.295" y2="51.435" width="0.8128" layer="16"/>
<via x="201.295" y="70.485" extent="1-16" drill="0.8" diameter="2.5"/>
<wire x1="201.295" y1="51.435" x2="201.295" y2="70.485" width="0.8128" layer="16"/>
</signal>
<signal name="N$126">
<via x="240.9825" y="75.2475" extent="1-16" drill="0.8" diameter="2.5"/>
</signal>
<signal name="N$127">
<via x="240.9825" y="46.6725" extent="1-16" drill="0.8" diameter="2.5"/>
</signal>
<signal name="N$128">
<via x="195.8975" y="65.0875" extent="1-16" drill="0.8" diameter="2.5"/>
</signal>
<signal name="Q1">
<polygon width="0.508" layer="16" pour="hatch" isolate="3.81">
<vertex x="202.565" y="42.8625"/>
<vertex x="253.365" y="42.8625"/>
<vertex x="253.365" y="79.0575"/>
<vertex x="202.565" y="79.0575"/>
</polygon>
</signal>
<signal name="N$116">
<contactref element="IC8" pad="6"/>
<contactref element="IC8" pad="7"/>
<wire x1="165.735" y1="74.93" x2="168.275" y2="74.93" width="0.6096" layer="16"/>
</signal>
<signal name="N$117">
<contactref element="R66" pad="1"/>
<contactref element="IC8" pad="5"/>
<contactref element="R65" pad="1"/>
<wire x1="157.7975" y1="74.165" x2="160.28" y2="74.165" width="0.508" layer="16"/>
<wire x1="160.28" y1="74.165" x2="160.3375" y2="74.1075" width="0.508" layer="16"/>
<wire x1="160.3375" y1="74.1075" x2="160.9725" y2="74.1075" width="0.6096" layer="16"/>
<wire x1="162.055" y1="73.025" x2="160.9725" y2="74.1075" width="0.6096" layer="16"/>
<wire x1="162.055" y1="73.025" x2="168.5925" y2="73.025" width="0.6096" layer="16"/>
<wire x1="168.5925" y1="73.025" x2="170.4975" y2="74.93" width="0.6096" layer="16"/>
<wire x1="170.4975" y1="74.93" x2="170.815" y2="74.93" width="0.6096" layer="16"/>
</signal>
<signal name="N$129">
<via x="203.5175" y="73.66" extent="1-16" drill="0.8" diameter="2.5"/>
<wire x1="203.5175" y1="73.66" x2="205.4225" y2="71.755" width="0.8128" layer="16"/>
<wire x1="205.4225" y1="71.755" x2="205.4225" y2="50.165" width="0.8128" layer="16"/>
<via x="203.5175" y="48.26" extent="1-16" drill="0.8" diameter="2.5"/>
<wire x1="190.5" y1="46.355" x2="201.6125" y2="46.355" width="0.8128" layer="16"/>
<wire x1="201.6125" y1="46.355" x2="203.5175" y2="48.26" width="0.8128" layer="16"/>
<wire x1="205.4225" y1="50.165" x2="203.5175" y2="48.26" width="0.8128" layer="16"/>
</signal>
<signal name="-8V">
<contactref element="IC7" pad="5"/>
<contactref element="C18" pad="2"/>
<wire x1="163.5125" y1="49.2125" x2="161.29" y2="46.99" width="0.8128" layer="16"/>
<wire x1="161.29" y1="46.99" x2="152.7175" y2="46.99" width="0.8128" layer="16"/>
<wire x1="163.5125" y1="49.2125" x2="166.5575" y2="49.2125" width="0.8128" layer="16"/>
<wire x1="166.5575" y1="49.2125" x2="166.6875" y2="49.0825" width="0.8128" layer="16"/>
<contactref element="X22" pad="3"/>
<wire x1="152.7175" y1="46.99" x2="150.495" y2="49.2125" width="0.8128" layer="16"/>
</signal>
<signal name="N$130">
<contactref element="IC9" pad="14"/>
<contactref element="S1" pad="1"/>
<via x="153.9875" y="116.5225" extent="1-16" drill="0.8" diameter="1.7"/>
<wire x1="153.9875" y1="116.5225" x2="147.0025" y2="116.5225" width="0.6096" layer="16"/>
<via x="147.0025" y="116.5225" extent="1-16" drill="0.8" diameter="1.7"/>
<wire x1="138.7856" y1="110.2487" x2="141.3256" y2="110.2487" width="0.8128" layer="1"/>
<wire x1="141.3256" y1="110.2487" x2="147.0025" y2="115.9256" width="0.8128" layer="1"/>
<wire x1="147.0025" y1="116.5225" x2="147.0025" y2="115.9256" width="0.8128" layer="1"/>
<wire x1="153.3525" y1="135.89" x2="154.6225" y2="135.89" width="0.8128" layer="1"/>
<wire x1="154.6225" y1="135.89" x2="156.21" y2="134.3025" width="0.8128" layer="1"/>
<wire x1="156.21" y1="134.3025" x2="156.21" y2="123.5456" width="0.8128" layer="1"/>
<wire x1="156.21" y1="123.5456" x2="153.9875" y2="121.3231" width="0.8128" layer="1"/>
<wire x1="153.9875" y1="121.3231" x2="153.9875" y2="116.5225" width="0.8128" layer="1"/>
</signal>
<signal name="N$131">
<contactref element="IC9" pad="15"/>
<contactref element="S2" pad="1"/>
<wire x1="149.2631" y1="110.2487" x2="148.9456" y2="110.5662" width="0.8128" layer="1"/>
<wire x1="148.9456" y1="110.5662" x2="148.9456" y2="120.0912" width="0.8128" layer="1"/>
<wire x1="148.9456" y1="120.0912" x2="153.3525" y2="124.4981" width="0.8128" layer="1"/>
<wire x1="153.3525" y1="124.4981" x2="153.3525" y2="128.27" width="0.8128" layer="1"/>
</signal>
<signal name="N$132">
<contactref element="IC9" pad="16"/>
<via x="150.8125" y="124.7775" extent="1-16" drill="0.8" diameter="1.7"/>
<wire x1="150.8125" y1="124.7775" x2="150.8125" y2="119.38" width="0.6096" layer="16"/>
<via x="150.8125" y="119.38" extent="1-16" drill="0.8" diameter="1.7"/>
<contactref element="S3" pad="2"/>
<wire x1="150.8125" y1="128.27" x2="150.8125" y2="124.7775" width="0.8128" layer="1"/>
<wire x1="150.8125" y1="119.38" x2="150.8125" y2="114.6556" width="0.8128" layer="1"/>
<wire x1="150.8125" y1="114.6556" x2="155.2194" y2="110.2487" width="0.8128" layer="1"/>
</signal>
<signal name="N$133">
<contactref element="L1" pad="1"/>
<contactref element="C25" pad="1"/>
<contactref element="C27" pad="2"/>
<contactref element="C28" pad="+"/>
<contactref element="DIS1" pad="2"/>
<contactref element="R73" pad="1"/>
<contactref element="IC9" pad="7"/>
<contactref element="DIS1" pad="15"/>
<contactref element="R77" pad="3"/>
<wire x1="136.28" y1="133.35" x2="136.4125" y2="132.3975" width="0.6096" layer="1"/>
<wire x1="135.5725" y1="136.28" x2="135.5725" y2="135.89" width="0.6096" layer="1"/>
<wire x1="158.75" y1="134.3025" x2="158.75" y2="134.3125" width="0.6096" layer="1"/>
<wire x1="158.75" y1="134.3125" x2="155.2625" y2="137.8" width="0.6096" layer="1"/>
<via x="152.0825" y="138.43" extent="1-16" drill="0.8" diameter="1.7"/>
<wire x1="151.8325" y1="141.23" x2="151.8325" y2="140.97" width="0.6096" layer="1"/>
<wire x1="151.8325" y1="138.68" x2="152.0825" y2="138.43" width="0.6096" layer="1"/>
<wire x1="133.6675" y1="138.43" x2="152.0825" y2="138.43" width="0.6096" layer="16"/>
<via x="133.6675" y="138.43" extent="1-16" drill="0.8" diameter="1.7"/>
<wire x1="133.6675" y1="138.43" x2="116.5225" y2="138.43" width="0.6096" layer="16"/>
<via x="116.5225" y="138.43" extent="1-16" drill="0.8" diameter="1.7"/>
<wire x1="110.1725" y1="128.27" x2="110.1725" y2="127.765" width="0.6096" layer="1"/>
<contactref element="C30" pad="2"/>
<wire x1="112.5825" y1="129.54" x2="112.7125" y2="129.54" width="0.6096" layer="1"/>
<wire x1="135.4425" y1="138.43" x2="135.5725" y2="138.43" width="0.6096" layer="1"/>
<wire x1="135.5725" y1="138.43" x2="135.5725" y2="135.89" width="0.6096" layer="1"/>
<wire x1="110.1725" y1="127.765" x2="111.9475" y2="129.54" width="0.8128" layer="1"/>
<wire x1="111.9475" y1="129.54" x2="112.7125" y2="129.54" width="0.8128" layer="1"/>
<wire x1="133.6675" y1="138.43" x2="135.4425" y2="138.43" width="0.8128" layer="1"/>
<wire x1="135.5725" y1="138.43" x2="135.5725" y2="136.28" width="0.8128" layer="1"/>
<wire x1="150.5625" y1="142.8175" x2="150.5625" y2="142.5" width="0.8128" layer="1"/>
<wire x1="150.5625" y1="142.5" x2="151.8325" y2="141.23" width="0.8128" layer="1"/>
<wire x1="151.8325" y1="140.97" x2="151.8325" y2="138.68" width="0.8128" layer="1"/>
<wire x1="152.0825" y1="138.43" x2="152.7125" y2="137.8" width="0.8128" layer="1"/>
<wire x1="152.7125" y1="137.8" x2="155.2625" y2="137.8" width="0.8128" layer="1"/>
<wire x1="155.2625" y1="137.8" x2="155.2625" y2="137.79" width="0.8128" layer="1"/>
<wire x1="155.2625" y1="137.79" x2="158.75" y2="134.3025" width="0.8128" layer="1"/>
<wire x1="117.5425" y1="142.8175" x2="117.5425" y2="139.45" width="0.8128" layer="1"/>
<wire x1="117.5425" y1="139.45" x2="116.5225" y2="138.43" width="0.8128" layer="1"/>
<wire x1="116.5225" y1="138.43" x2="115.57" y2="138.43" width="0.8128" layer="1"/>
<wire x1="115.57" y1="138.43" x2="114.6175" y2="137.4775" width="0.8128" layer="1"/>
<wire x1="114.6175" y1="137.4775" x2="114.6175" y2="134.3025" width="0.8128" layer="1"/>
<wire x1="114.6175" y1="134.3025" x2="114.6175" y2="133.985" width="0.8128" layer="1"/>
<wire x1="112.5825" y1="131.95" x2="112.5825" y2="129.54" width="0.8128" layer="1"/>
<wire x1="114.6175" y1="133.985" x2="112.5825" y2="131.95" width="0.8128" layer="1"/>
<wire x1="111.2325" y1="134.4225" x2="114.4975" y2="134.4225" width="0.8128" layer="1"/>
<wire x1="114.4975" y1="134.4225" x2="114.6175" y2="134.3025" width="0.8128" layer="1"/>
<wire x1="158.75" y1="134.3025" x2="162.56" y2="138.1125" width="0.8128" layer="1"/>
<wire x1="162.56" y1="138.1125" x2="162.56" y2="140.5225" width="0.8128" layer="1"/>
<wire x1="135.5725" y1="135.89" x2="135.5725" y2="135.3275" width="0.8128" layer="1"/>
<wire x1="135.5725" y1="135.3275" x2="136.28" y2="134.62" width="0.8128" layer="1"/>
<wire x1="136.28" y1="134.62" x2="136.28" y2="133.35" width="0.8128" layer="1"/>
<wire x1="162.56" y1="140.5225" x2="164.335" y2="140.5225" width="0.8128" layer="1"/>
<contactref element="IC11" pad="OUT"/>
<wire x1="166.37" y1="142.5575" x2="166.37" y2="143.1925" width="0.8128" layer="1"/>
<wire x1="164.335" y1="140.5225" x2="166.37" y2="142.5575" width="0.8128" layer="1"/>
</signal>
<signal name="N$134">
<contactref element="IC9" pad="25"/>
<via x="127.9525" y="126.365" extent="1-16" drill="0.8" diameter="1.7"/>
<wire x1="160.3375" y1="126.365" x2="127.9525" y2="126.365" width="0.6096" layer="16"/>
<via x="160.3375" y="126.365" extent="1-16" drill="0.8" diameter="1.7"/>
<wire x1="127.9525" y1="126.365" x2="127.9525" y2="128.27" width="0.8128" layer="1"/>
<contactref element="JP7" pad="2"/>
<wire x1="162.8775" y1="127" x2="162.2425" y2="126.365" width="0.8128" layer="1"/>
<wire x1="162.2425" y1="126.365" x2="160.3375" y2="126.365" width="0.8128" layer="1"/>
</signal>
<signal name="N$135">
<contactref element="IC9" pad="26"/>
<wire x1="125.4125" y1="127.9525" x2="125.4125" y2="128.27" width="0.8128" layer="1"/>
<contactref element="C35" pad="2"/>
<contactref element="R88" pad="1"/>
<wire x1="121.7325" y1="125.73" x2="123.19" y2="125.73" width="0.8128" layer="1"/>
<wire x1="123.19" y1="125.73" x2="125.4125" y2="127.9525" width="0.8128" layer="1"/>
<wire x1="125.4125" y1="129.7275" x2="125.4125" y2="128.27" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$136">
<contactref element="R67" pad="2"/>
<contactref element="R74" pad="3"/>
<wire x1="115.2525" y1="123.19" x2="115.2525" y2="122.125" width="0.8128" layer="1"/>
<wire x1="115.2525" y1="122.125" x2="114.1125" y2="121.285" width="0.8128" layer="1"/>
</signal>
<signal name="N$137">
<contactref element="R67" pad="1"/>
<contactref element="LSP12" pad="MP"/>
<contactref element="V2" pad="MP"/>
<wire x1="114.3" y1="118.4275" x2="111.125" y2="118.4275" width="0.8128" layer="1"/>
<wire x1="111.125" y1="118.4275" x2="111.125" y2="121.0975" width="0.8128" layer="1"/>
<wire x1="111.125" y1="121.0975" x2="111.3125" y2="121.285" width="0.8128" layer="1"/>
</signal>
<signal name="N$138">
<contactref element="IC9" pad="24"/>
<contactref element="R68" pad="2"/>
<wire x1="130.4925" y1="123.6375" x2="130.6225" y2="123.5075" width="0.6096" layer="1"/>
<wire x1="130.4925" y1="128.27" x2="130.4925" y2="123.6375" width="0.8128" layer="1"/>
<contactref element="C34" pad="2"/>
<wire x1="130.4925" y1="128.27" x2="130.4925" y2="129.7275" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$139">
<contactref element="R68" pad="1"/>
<contactref element="R69" pad="2"/>
<wire x1="127.8225" y1="123.5075" x2="127.635" y2="123.5075" width="0.6096" layer="1"/>
<wire x1="127.635" y1="123.5075" x2="126.6825" y2="123.5075" width="0.6096" layer="1"/>
<wire x1="127.5225" y1="123.395" x2="127.635" y2="123.5075" width="0.8128" layer="1"/>
<wire x1="127.5225" y1="123.395" x2="127.5225" y2="123.19" width="0.8128" layer="1"/>
<contactref element="D12" pad="C"/>
<wire x1="125.73" y1="121.715" x2="124.1425" y2="121.715" width="0.8128" layer="1"/>
<wire x1="124.1425" y1="121.715" x2="121.92" y2="119.4925" width="0.8128" layer="1"/>
<wire x1="125.73" y1="121.715" x2="125.4125" y2="122.0325" width="0.8128" layer="1"/>
<wire x1="125.73" y1="121.715" x2="125.73" y2="122.555" width="0.8128" layer="1"/>
<wire x1="125.73" y1="122.555" x2="126.6825" y2="123.5075" width="0.8128" layer="1"/>
<wire x1="126.6825" y1="123.5075" x2="127.8225" y2="123.5075" width="0.8128" layer="1"/>
</signal>
<signal name="N$140">
<contactref element="R75" pad="2"/>
<contactref element="R69" pad="1"/>
<wire x1="121.92" y1="115.57" x2="118.745" y2="112.395" width="0.8128" layer="1"/>
<wire x1="118.745" y1="111.125" x2="118.745" y2="112.395" width="0.8128" layer="1"/>
<wire x1="121.92" y1="115.57" x2="121.92" y2="116.0925" width="0.8128" layer="1"/>
</signal>
<signal name="N$141">
<contactref element="R75" pad="1"/>
<contactref element="R70" pad="1"/>
<wire x1="121.285" y1="111.125" x2="124.0125" y2="111.125" width="0.8128" layer="1"/>
</signal>
<signal name="N$142">
<contactref element="R70" pad="2"/>
<contactref element="V1" pad="MP"/>
<contactref element="R71" pad="1"/>
<wire x1="126.8125" y1="111.125" x2="129.2225" y2="111.125" width="0.8128" layer="1"/>
<wire x1="129.2225" y1="111.125" x2="129.2225" y2="113.87" width="0.8128" layer="1"/>
</signal>
<signal name="N$143">
<contactref element="R72" pad="1"/>
<contactref element="R75" pad="3"/>
<wire x1="118.11" y1="114.649475" x2="118.11" y2="116.075" width="0.8128" layer="1"/>
<wire x1="116.205" y1="111.125" x2="116.205" y2="112.744475" width="0.8128" layer="1"/>
<wire x1="116.205" y1="112.744475" x2="118.11" y2="114.649475" width="0.8128" layer="1"/>
</signal>
<signal name="N$144">
<contactref element="R71" pad="2"/>
<contactref element="R76" pad="1"/>
<wire x1="129.2225" y1="117.27" x2="129.41" y2="117.1575" width="0.6096" layer="1"/>
<wire x1="129.2225" y1="117.27" x2="129.2225" y2="118.11" width="0.8128" layer="1"/>
<wire x1="129.2225" y1="118.11" x2="130.4925" y2="119.38" width="0.8128" layer="1"/>
</signal>
<signal name="N$145">
<contactref element="IC9" pad="23"/>
<contactref element="R76" pad="2"/>
<wire x1="133.0325" y1="128.27" x2="133.0325" y2="119.38" width="0.8128" layer="1"/>
<contactref element="C33" pad="2"/>
<wire x1="133.0325" y1="128.27" x2="133.0325" y2="129.7275" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$146">
<contactref element="C22" pad="2"/>
<contactref element="IC9" pad="21"/>
<wire x1="138.1125" y1="128.27" x2="138.1125" y2="124.59" width="0.8128" layer="1"/>
</signal>
<signal name="N$147">
<contactref element="IC9" pad="20"/>
<contactref element="C29" pad="1"/>
<contactref element="L1" pad="2"/>
<wire x1="141.605" y1="124.59" x2="141.605003125" y2="126.364996875" width="0.6096" layer="1"/>
<wire x1="140.6525" y1="128.27" x2="140.6525" y2="127.3175" width="0.8128" layer="1"/>
<wire x1="140.6525" y1="127.3175" x2="141.605003125" y2="126.364996875" width="0.8128" layer="1"/>
<wire x1="141.605003125" y1="126.364996875" x2="141.60500625" y2="126.36499375" width="0.8128" layer="1"/>
<wire x1="141.60500625" y1="126.36499375" x2="141.60500625" y2="124.59000625" width="0.8128" layer="1"/>
<wire x1="141.60500625" y1="124.59000625" x2="141.605" y2="124.59" width="0.8128" layer="1"/>
<wire x1="140.6525" y1="128.27" x2="140.6525" y2="131.5575" width="0.8128" layer="1"/>
<wire x1="140.6525" y1="131.5575" x2="139.8125" y2="132.3975" width="0.8128" layer="1"/>
</signal>
<signal name="N$148">
<contactref element="C26" pad="2"/>
<contactref element="R73" pad="2"/>
<contactref element="IC9" pad="1"/>
<wire x1="120.3325" y1="135.89" x2="117.0275" y2="132.585" width="0.8128" layer="1"/>
<wire x1="117.0275" y1="132.585" x2="117.0275" y2="132.3975" width="0.8128" layer="1"/>
<wire x1="115.3825" y1="129.54" x2="116.205" y2="129.54" width="0.8128" layer="1"/>
<wire x1="117.0275" y1="130.3625" x2="117.0275" y2="132.3975" width="0.8128" layer="1"/>
<wire x1="116.205" y1="129.54" x2="117.0275" y2="130.3625" width="0.8128" layer="1"/>
</signal>
<signal name="RS">
<contactref element="DIS1" pad="4"/>
<contactref element="IC9" pad="2"/>
<wire x1="122.6225" y1="142.8175" x2="122.6225" y2="136.14" width="0.8128" layer="1"/>
<wire x1="122.6225" y1="136.14" x2="122.8725" y2="135.89" width="0.8128" layer="1"/>
</signal>
<signal name="RW">
<contactref element="DIS1" pad="5"/>
<contactref element="IC9" pad="3"/>
<wire x1="125.1625" y1="142.8175" x2="125.1625" y2="136.14" width="0.8128" layer="1"/>
<wire x1="125.1625" y1="136.14" x2="125.4125" y2="135.89" width="0.8128" layer="1"/>
</signal>
<signal name="E">
<contactref element="DIS1" pad="6"/>
<contactref element="IC9" pad="4"/>
<wire x1="127.9525" y1="136.525" x2="127.9525" y2="136.8425" width="0.6096" layer="1"/>
<wire x1="127.7025" y1="142.8175" x2="127.7025" y2="141.865" width="0.8128" layer="1"/>
<wire x1="127.7025" y1="141.865" x2="127.0675" y2="141.23" width="0.8128" layer="1"/>
<wire x1="127.0675" y1="141.23" x2="127.0675" y2="137.7275" width="0.8128" layer="1"/>
<wire x1="127.0675" y1="137.7275" x2="127.9525" y2="136.8425" width="0.8128" layer="1"/>
<wire x1="127.9525" y1="135.89" x2="127.9525" y2="136.525" width="0.8128" layer="1"/>
</signal>
<signal name="DB4">
<contactref element="DIS1" pad="11"/>
<contactref element="IC9" pad="6"/>
<wire x1="140.6525" y1="141.9225" x2="139.3825" y2="140.6525" width="0.6096" layer="1"/>
<wire x1="140.6525" y1="141.9225" x2="140.6525" y2="142.5675" width="0.6096" layer="1"/>
<wire x1="140.6525" y1="142.5675" x2="140.4025" y2="142.8175" width="0.6096" layer="1"/>
<wire x1="133.0325" y1="135.89" x2="133.0325" y2="136.525" width="0.8128" layer="1"/>
<wire x1="133.0325" y1="136.525" x2="131.7625" y2="137.795" width="0.8128" layer="1"/>
<wire x1="131.7625" y1="137.795" x2="131.7625" y2="139.3825" width="0.8128" layer="1"/>
<wire x1="131.7625" y1="139.3825" x2="133.0325" y2="140.6525" width="0.8128" layer="1"/>
<wire x1="133.0325" y1="140.6525" x2="139.3825" y2="140.6525" width="0.8128" layer="1"/>
<wire x1="139.3825" y1="140.6525" x2="140.4025" y2="141.6725" width="0.8128" layer="1"/>
<wire x1="140.4025" y1="141.6725" x2="140.4025" y2="142.7226" width="0.8128" layer="1"/>
</signal>
<signal name="DB5">
<contactref element="DIS1" pad="12"/>
<contactref element="IC9" pad="11"/>
<wire x1="142.9425" y1="142.8175" x2="142.9425" y2="142.49" width="0.8128" layer="1"/>
<wire x1="142.9425" y1="142.49" x2="146.3675" y2="139.065" width="0.8128" layer="1"/>
<wire x1="146.3675" y1="139.065" x2="146.3675" y2="136.525" width="0.8128" layer="1"/>
<wire x1="146.3675" y1="136.525" x2="145.7325" y2="135.89" width="0.8128" layer="1"/>
</signal>
<signal name="DB6">
<contactref element="DIS1" pad="13"/>
<contactref element="IC9" pad="12"/>
<wire x1="145.4825" y1="142.8175" x2="145.4825" y2="142.49" width="0.8128" layer="1"/>
<wire x1="145.4825" y1="142.49" x2="148.2725" y2="139.7" width="0.8128" layer="1"/>
<wire x1="148.2725" y1="139.7" x2="148.2725" y2="135.89" width="0.8128" layer="1"/>
</signal>
<signal name="DB7">
<contactref element="DIS1" pad="14"/>
<contactref element="IC9" pad="13"/>
<wire x1="148.0225" y1="142.8175" x2="148.0225" y2="142.5" width="0.8128" layer="1"/>
<wire x1="148.0225" y1="142.5" x2="150.245" y2="140.2775" width="0.8128" layer="1"/>
<wire x1="150.245" y1="140.2775" x2="150.245" y2="137.41" width="0.8128" layer="1"/>
<wire x1="150.8125" y1="136.8425" x2="150.245" y2="137.41" width="0.8128" layer="1"/>
<wire x1="150.8125" y1="135.89" x2="150.8125" y2="136.8425" width="0.8128" layer="1"/>
</signal>
<signal name="N$149">
<contactref element="DIS1" pad="16"/>
<contactref element="R78" pad="2"/>
<wire x1="156.08" y1="143.1925" x2="155.705" y2="142.8175" width="0.6096" layer="1"/>
<wire x1="153.1025" y1="142.8175" x2="155.705" y2="142.8175" width="0.8128" layer="1"/>
</signal>
<signal name="N$150">
<contactref element="R77" pad="2"/>
<contactref element="DIS1" pad="3"/>
<wire x1="120.3325" y1="141.9225" x2="120.3325" y2="142.5675" width="0.6096" layer="1"/>
<wire x1="116.7325" y1="135.5725" x2="120.3325" y2="139.1725" width="0.8128" layer="1"/>
<wire x1="120.3325" y1="139.1725" x2="120.3325" y2="141.9225" width="0.8128" layer="1"/>
<wire x1="120.0825" y1="142.8175" x2="120.3325" y2="142.5675" width="0.8128" layer="1"/>
</signal>
<signal name="N$167">
<via x="136.525" y="106.9975" extent="1-16" drill="0.8" diameter="1.7"/>
</signal>
<signal name="N$168">
<via x="147.0025" y="106.9975" extent="1-16" drill="0.8" diameter="1.7"/>
</signal>
<signal name="N$169">
<via x="157.48" y="106.9975" extent="1-16" drill="0.8" diameter="1.7"/>
</signal>
<signal name="N$170">
<via x="109.5375" y="142.875" extent="1-16" drill="0.8" diameter="1.7"/>
</signal>
<signal name="N$171">
<via x="109.5375" y="111.76" extent="1-16" drill="0.8" diameter="1.7"/>
</signal>
<signal name="N$172">
<via x="184.4675" y="111.76" extent="1-16" drill="0.8" diameter="1.7"/>
</signal>
<signal name="N$173">
<via x="184.4675" y="142.875" extent="1-16" drill="0.8" diameter="1.7"/>
</signal>
<signal name="N$151">
<contactref element="IC9" pad="5"/>
<contactref element="RELé" pad="MP"/>
<wire x1="130.4925" y1="136.8425" x2="130.4925" y2="135.89" width="0.6096" layer="1"/>
<wire x1="129.54" y1="140.0175" x2="129.54" y2="137.795" width="0.8128" layer="1"/>
<wire x1="129.54" y1="137.795" x2="130.4925" y2="136.8425" width="0.8128" layer="1"/>
</signal>
<signal name="N$152">
<contactref element="IC9" pad="17"/>
<contactref element="PWM" pad="MP"/>
<wire x1="148.2725" y1="128.27" x2="148.2725" y2="127" width="0.8128" layer="1"/>
<wire x1="148.2725" y1="127" x2="145.7325" y2="124.46" width="0.8128" layer="1"/>
</signal>
<signal name="N$153">
<contactref element="R79" pad="1"/>
<contactref element="LED5" pad="A"/>
<via x="142.875" y="140.0175" extent="1-16" drill="0.8" diameter="1.7"/>
<wire x1="142.875" y1="140.0175" x2="153.67" y2="140.0175" width="0.6096" layer="16"/>
<via x="153.67" y="140.0175" extent="1-16" drill="0.8" diameter="1.7"/>
<wire x1="142.875" y1="140.0175" x2="143.3225" y2="139.57" width="0.8128" layer="1"/>
<wire x1="143.3225" y1="139.57" x2="143.3225" y2="139.3825" width="0.8128" layer="1"/>
<wire x1="143.64" y1="139.065" x2="143.64" y2="138.43" width="0.8128" layer="1"/>
<wire x1="143.64" y1="139.065" x2="143.3225" y2="139.3825" width="0.8128" layer="1"/>
<wire x1="153.67" y1="140.0175" x2="155.8925" y2="140.0175" width="0.8128" layer="1"/>
</signal>
<signal name="N$154">
<contactref element="IC9" pad="9"/>
<contactref element="R79" pad="2"/>
<wire x1="140.6525" y1="135.89" x2="140.84" y2="136.0775" width="0.8128" layer="1"/>
<wire x1="140.84" y1="136.0775" x2="140.84" y2="138.43" width="0.8128" layer="1"/>
</signal>
<signal name="N$155">
<contactref element="IC10" pad="1"/>
<contactref element="R84" pad="1"/>
<contactref element="R82" pad="2"/>
<contactref element="R83" pad="1"/>
<wire x1="175.5775" y1="124.46" x2="176.735" y2="125.6175" width="0.8128" layer="1"/>
<wire x1="176.735" y1="125.6175" x2="177.8" y2="125.6175" width="0.8128" layer="1"/>
<wire x1="177.8" y1="125.6175" x2="180.1525" y2="123.265" width="0.8128" layer="1"/>
<wire x1="180.1525" y1="123.265" x2="180.1525" y2="121.6025" width="0.8128" layer="1"/>
<wire x1="180.1525" y1="121.6025" x2="180.1525" y2="117.475" width="0.8128" layer="1"/>
</signal>
<signal name="N$156">
<contactref element="R82" pad="1"/>
<contactref element="IC10" pad="6"/>
<contactref element="R81" pad="2"/>
<wire x1="170.3675" y1="134.9375" x2="170.3675" y2="132.21" width="0.8128" layer="1"/>
<wire x1="170.3675" y1="132.21" x2="170.4975" y2="132.08" width="0.8128" layer="1"/>
<wire x1="177.8" y1="129.0175" x2="171.3375" y2="129.0175" width="0.8128" layer="1"/>
<wire x1="170.3675" y1="129.9875" x2="170.3675" y2="132.21" width="0.8128" layer="1"/>
<wire x1="171.3375" y1="129.0175" x2="170.3675" y2="129.9875" width="0.8128" layer="1"/>
</signal>
<signal name="N$157">
<contactref element="R81" pad="1"/>
<contactref element="R80" pad="2"/>
<contactref element="IC10" pad="7"/>
<wire x1="173.1675" y1="138.1125" x2="173.1675" y2="134.9375" width="0.8128" layer="1"/>
<wire x1="173.1675" y1="134.9375" x2="173.1675" y2="132.21" width="0.8128" layer="1"/>
<wire x1="173.1675" y1="132.21" x2="173.0375" y2="132.08" width="0.8128" layer="1"/>
</signal>
<signal name="N$158">
<contactref element="R85" pad="3"/>
<contactref element="R84" pad="2"/>
<wire x1="177.3525" y1="117.475" x2="175.5775" y2="117.475" width="0.8128" layer="16"/>
<wire x1="177.3525" y1="117.475" x2="175.5775" y2="117.475" width="0.8128" layer="1"/>
</signal>
<signal name="N$159">
<contactref element="R85" pad="1"/>
<contactref element="R86" pad="2"/>
<wire x1="170.4975" y1="115.065" x2="170.4975" y2="117.475" width="0.8128" layer="16"/>
<wire x1="170.4975" y1="115.065" x2="170.4975" y2="117.475" width="0.8128" layer="1"/>
</signal>
<signal name="N$160">
<contactref element="R80" pad="1"/>
<contactref element="C31" pad="2"/>
<contactref element="JP7" pad="1"/>
<wire x1="166.745" y1="135.125" x2="165.735" y2="135.125" width="0.8128" layer="1"/>
<wire x1="165.735" y1="135.125" x2="162.8775" y2="132.2675" width="0.8128" layer="1"/>
<wire x1="162.8775" y1="132.2675" x2="162.8775" y2="129.54" width="0.8128" layer="1"/>
<wire x1="170.3675" y1="138.1125" x2="169.7325" y2="138.1125" width="0.8128" layer="1"/>
<wire x1="169.7325" y1="138.1125" x2="166.745" y2="135.125" width="0.8128" layer="1"/>
</signal>
<signal name="N$161">
<contactref element="C32" pad="2"/>
<contactref element="R83" pad="2"/>
<contactref element="JP7" pad="3"/>
<wire x1="162.8775" y1="124.46" x2="162.8775" y2="122.8725" width="0.8128" layer="1"/>
<wire x1="162.8775" y1="122.8725" x2="161.6075" y2="121.6025" width="0.8128" layer="1"/>
<wire x1="159.0675" y1="121.6025" x2="159.0675" y2="121.0975" width="0.8128" layer="1"/>
<wire x1="177.3525" y1="121.6025" x2="175.5775" y2="121.6025" width="0.8128" layer="1"/>
<via x="175.5775" y="121.6025" extent="1-16" drill="0.8" diameter="1.8"/>
<wire x1="175.5775" y1="121.6025" x2="161.6075" y2="121.6025" width="0.8128" layer="16"/>
<via x="161.6075" y="121.6025" extent="1-16" drill="0.8" diameter="1.8"/>
<wire x1="161.6075" y1="121.6025" x2="159.0675" y2="121.6025" width="0.8128" layer="1"/>
</signal>
<signal name="N$162">
<contactref element="IC10" pad="3"/>
<contactref element="R87" pad="2"/>
<contactref element="A1" pad="MP"/>
<wire x1="164.1475" y1="116.5225" x2="163.0075" y2="116.5225" width="0.8128" layer="1"/>
<wire x1="163.0075" y1="116.5225" x2="160.785" y2="114.3" width="0.8128" layer="1"/>
<wire x1="170.4975" y1="124.46" x2="170.4975" y2="123.19" width="0.8128" layer="1"/>
<wire x1="170.4975" y1="123.19" x2="169.2275" y2="121.92" width="0.8128" layer="1"/>
<wire x1="169.2275" y1="121.92" x2="167.64" y2="121.92" width="0.8128" layer="1"/>
<wire x1="167.64" y1="121.92" x2="164.1475" y2="118.4275" width="0.8128" layer="1"/>
<wire x1="164.1475" y1="118.4275" x2="164.1475" y2="116.5225" width="0.8128" layer="1"/>
</signal>
<signal name="N$163">
<contactref element="IC10" pad="4"/>
<contactref element="JP8" pad="1"/>
<wire x1="179.07" y1="132.08" x2="180.34" y2="130.81" width="0.8128" layer="1"/>
<wire x1="180.34" y1="130.81" x2="180.34" y2="127.9525" width="0.8128" layer="1"/>
<wire x1="170.18" y1="127.3175" x2="169.8625" y2="127" width="0.8128" layer="1"/>
<wire x1="169.8625" y1="127" x2="167.9575" y2="125.095" width="0.8128" layer="1"/>
<wire x1="167.9575" y1="125.095" x2="167.9575" y2="124.46" width="0.8128" layer="1"/>
<wire x1="180.34" y1="127.9525" x2="179.705" y2="127.3175" width="0.8128" layer="1"/>
<wire x1="179.705" y1="127.3175" x2="170.18" y2="127.3175" width="0.8128" layer="1"/>
<contactref element="C37" pad="2"/>
<wire x1="169.3575" y1="127.635" x2="169.8625" y2="127.13" width="0.8128" layer="1"/>
<wire x1="169.8625" y1="127.13" x2="169.8625" y2="127" width="0.8128" layer="1"/>
</signal>
<signal name="N$164">
<contactref element="R74" pad="2"/>
<contactref element="R88" pad="2"/>
<wire x1="117.7925" y1="123.19" x2="117.7925" y2="124.59" width="0.8128" layer="1"/>
<wire x1="117.7925" y1="124.59" x2="118.9325" y2="125.73" width="0.8128" layer="1"/>
</signal>
<signal name="N$165">
<contactref element="R85" pad="2"/>
<contactref element="IC10" pad="2"/>
<wire x1="173.0375" y1="117.475" x2="173.0375" y2="124.46" width="0.8128" layer="1"/>
</signal>
<signal name="N$166">
<contactref element="IC10" pad="8"/>
<contactref element="JP8" pad="3"/>
<contactref element="C36" pad="2"/>
<contactref element="IC11" pad="IN"/>
<wire x1="171.45" y1="143.1925" x2="172.4025" y2="142.24" width="0.8128" layer="1"/>
<wire x1="172.4025" y1="142.24" x2="173.86" y2="142.24" width="0.8128" layer="1"/>
<wire x1="173.86" y1="142.24" x2="173.86" y2="141.1" width="0.8128" layer="1"/>
<wire x1="173.86" y1="141.1" x2="177.8" y2="137.16" width="0.8128" layer="1"/>
<wire x1="177.8" y1="137.16" x2="179.07" y2="137.16" width="0.8128" layer="1"/>
<wire x1="175.5775" y1="132.08" x2="175.5775" y2="134.9375" width="0.8128" layer="1"/>
<wire x1="175.5775" y1="134.9375" x2="177.8" y2="137.16" width="0.8128" layer="1"/>
</signal>
<signal name="N$174">
<contactref element="IC12" pad="2"/>
<contactref element="DIS2" pad="4"/>
<wire x1="228.6" y1="142.875" x2="228.6" y2="147.955" width="0.8128" layer="1"/>
<wire x1="228.6" y1="147.955" x2="224.155" y2="152.4" width="0.8128" layer="1"/>
<wire x1="224.155" y1="152.4" x2="213.995" y2="152.4" width="0.8128" layer="1"/>
<wire x1="213.995" y1="152.4" x2="211.1375" y2="155.2575" width="0.8128" layer="1"/>
<wire x1="211.1375" y1="155.2575" x2="211.1375" y2="157.6725" width="0.8128" layer="1"/>
<wire x1="211.1375" y1="157.6725" x2="211.205" y2="157.74" width="0.8128" layer="1"/>
</signal>
<signal name="N$175">
<contactref element="IC12" pad="3"/>
<contactref element="DIS2" pad="5"/>
<wire x1="231.14" y1="142.875" x2="231.14" y2="147.6375" width="0.8128" layer="1"/>
<wire x1="231.14" y1="147.6375" x2="224.79" y2="153.9875" width="0.8128" layer="1"/>
<wire x1="224.79" y1="153.9875" x2="215.5825" y2="153.9875" width="0.8128" layer="1"/>
<wire x1="215.5825" y1="153.9875" x2="213.6775" y2="155.8925" width="0.8128" layer="1"/>
<wire x1="213.6775" y1="155.8925" x2="213.6775" y2="157.6725" width="0.8128" layer="1"/>
<wire x1="213.6775" y1="157.6725" x2="213.745" y2="157.74" width="0.8128" layer="1"/>
</signal>
<signal name="N$176">
<contactref element="IC12" pad="4"/>
<contactref element="DIS2" pad="6"/>
<wire x1="233.68" y1="142.875" x2="233.68" y2="147.32" width="0.8128" layer="1"/>
<wire x1="233.68" y1="147.32" x2="225.425" y2="155.575" width="0.8128" layer="1"/>
<wire x1="225.425" y1="155.575" x2="217.4875" y2="155.575" width="0.8128" layer="1"/>
<wire x1="217.4875" y1="155.575" x2="216.285" y2="156.7775" width="0.8128" layer="1"/>
<wire x1="216.285" y1="156.7775" x2="216.285" y2="157.74" width="0.8128" layer="1"/>
</signal>
<signal name="N$177">
<contactref element="DIS2" pad="11"/>
<contactref element="IC12" pad="6"/>
<wire x1="238.76" y1="142.875" x2="238.76" y2="144.4625" width="0.8128" layer="1"/>
<wire x1="238.76" y1="144.4625" x2="228.985" y2="154.2375" width="0.8128" layer="1"/>
<wire x1="228.985" y1="154.2375" x2="228.985" y2="157.74" width="0.8128" layer="1"/>
</signal>
<signal name="N$178">
<contactref element="IC12" pad="11"/>
<contactref element="DIS2" pad="12"/>
<wire x1="231.525" y1="157.74" x2="231.525" y2="153.92" width="0.8128" layer="1"/>
<wire x1="251.46" y1="144.78" x2="251.46" y2="142.875" width="0.8128" layer="1"/>
<wire x1="251.46" y1="144.78" x2="247.3325" y2="148.9075" width="0.8128" layer="1"/>
<wire x1="231.525" y1="153.92" x2="236.5375" y2="148.9075" width="0.8128" layer="1"/>
<wire x1="236.5375" y1="148.9075" x2="247.3325" y2="148.9075" width="0.8128" layer="1"/>
</signal>
<signal name="N$179">
<contactref element="IC12" pad="12"/>
<contactref element="DIS2" pad="13"/>
<wire x1="234.065" y1="157.74" x2="234.065" y2="153.6025" width="0.8128" layer="1"/>
<wire x1="254" y1="144.78" x2="254" y2="142.875" width="0.8128" layer="1"/>
<wire x1="234.065" y1="153.6025" x2="237.1725" y2="150.495" width="0.8128" layer="1"/>
<wire x1="237.1725" y1="150.495" x2="248.285" y2="150.495" width="0.8128" layer="1"/>
<wire x1="248.285" y1="150.495" x2="254" y2="144.78" width="0.8128" layer="1"/>
</signal>
<signal name="N$180">
<contactref element="DIS2" pad="14"/>
<contactref element="IC12" pad="13"/>
<wire x1="236.605" y1="157.74" x2="236.605" y2="153.285" width="0.8128" layer="1"/>
<wire x1="249.2375" y1="152.0825" x2="256.54" y2="144.78" width="0.8128" layer="1"/>
<wire x1="256.54" y1="144.78" x2="256.54" y2="142.875" width="0.8128" layer="1"/>
<wire x1="236.605" y1="153.285" x2="237.8075" y2="152.0825" width="0.8128" layer="1"/>
<wire x1="237.8075" y1="152.0825" x2="249.2375" y2="152.0825" width="0.8128" layer="1"/>
</signal>
<signal name="N$181">
<contactref element="IC12" pad="26"/>
<contactref element="S6" pad="3"/>
<wire x1="241.5413" y1="114.0587" x2="241.5794" y2="114.0587" width="0.8128" layer="1"/>
<wire x1="241.5794" y1="114.0587" x2="240.6269" y2="115.0112" width="0.8128" layer="1"/>
<wire x1="240.6269" y1="115.0112" x2="233.9213" y2="115.0112" width="0.8128" layer="1"/>
<wire x1="233.9213" y1="115.0112" x2="230.505" y2="118.4275" width="0.8128" layer="1"/>
<wire x1="230.505" y1="133.985" x2="230.505" y2="118.4275" width="0.8128" layer="1"/>
<wire x1="231.14" y1="134.62" x2="231.14" y2="135.255" width="0.8128" layer="1"/>
<wire x1="231.14" y1="134.62" x2="230.505" y2="133.985" width="0.8128" layer="1"/>
</signal>
<signal name="N$182">
<contactref element="IC12" pad="27"/>
<wire x1="228.6" y1="135.255" x2="228.6" y2="114.7318" width="0.8128" layer="1"/>
<contactref element="S5" pad="4"/>
<wire x1="228.6" y1="114.7318" x2="229.2731" y2="114.0587" width="0.8128" layer="1"/>
</signal>
<signal name="N$183">
<contactref element="IC12" pad="28"/>
<wire x1="226.06" y1="135.255" x2="226.06" y2="130.4925" width="0.8128" layer="1"/>
<wire x1="226.06" y1="130.4925" x2="224.155" y2="128.5875" width="0.8128" layer="1"/>
<wire x1="224.155" y1="128.5875" x2="224.155" y2="119.9007" width="0.8128" layer="1"/>
<contactref element="S4" pad="1"/>
<wire x1="224.155" y1="119.9007" x2="219.583" y2="115.3287" width="0.8128" layer="1"/>
<wire x1="219.583" y1="115.3287" x2="213.7156" y2="115.3287" width="0.8128" layer="1"/>
<wire x1="213.7156" y1="115.3287" x2="212.4456" y2="114.0587" width="0.8128" layer="1"/>
</signal>
<signal name="N$184">
<contactref element="IC12" pad="19"/>
<contactref element="R109" pad="1"/>
<wire x1="256.8575" y1="126.16" x2="256.8575" y2="127.3175" width="0.8128" layer="1"/>
<wire x1="256.8575" y1="127.3175" x2="248.92" y2="135.255" width="0.8128" layer="1"/>
</signal>
<signal name="N$185">
<contactref element="IC12" pad="1"/>
<contactref element="C39" pad="2"/>
<contactref element="R89" pad="1"/>
<wire x1="226.19" y1="147.77710625" x2="225.05960625" y2="148.9075" width="0.8128" layer="1"/>
<wire x1="223.3545" y1="148.9075" x2="225.05960625" y2="148.9075" width="0.8128" layer="1"/>
<wire x1="226.19" y1="147.77710625" x2="226.19" y2="146.05" width="0.8128" layer="1"/>
<wire x1="226.19" y1="146.05" x2="226.06" y2="146.044084375" width="0.8128" layer="1"/>
<wire x1="226.06" y1="142.875" x2="226.06" y2="146.044084375" width="0.8128" layer="1"/>
</signal>
<signal name="N$186">
<contactref element="C41" pad="1"/>
<contactref element="IC12" pad="21"/>
<contactref element="R97" pad="2"/>
<wire x1="243.84" y1="135.255" x2="243.84" y2="131.2575" width="0.8128" layer="1"/>
<wire x1="243.84" y1="131.2575" x2="244.2875" y2="130.81" width="0.8128" layer="1"/>
<wire x1="246.0625" y1="128.7395" x2="246.0625" y2="129.035" width="0.8128" layer="1"/>
<wire x1="246.0625" y1="129.035" x2="244.2875" y2="130.81" width="0.8128" layer="1"/>
</signal>
<signal name="ON-OFF">
<contactref element="IC12" pad="17"/>
<wire x1="254" y1="135.255" x2="254" y2="135.89" width="0.8128" layer="1"/>
<wire x1="254" y1="135.89" x2="257.4925" y2="139.3825" width="0.8128" layer="1"/>
<wire x1="257.4925" y1="139.3825" x2="270.51" y2="139.3825" width="0.8128" layer="1"/>
<contactref element="JP11" pad="1"/>
</signal>
<signal name="N$187">
<contactref element="DIS2" pad="15"/>
<contactref element="R93" pad="2"/>
<wire x1="239.145" y1="157.74" x2="239.145" y2="154.6225" width="0.8128" layer="1"/>
<wire x1="239.145" y1="154.6225" x2="239.5605" y2="154.6225" width="0.8128" layer="1"/>
</signal>
<signal name="N$188">
<contactref element="IC13" pad="1"/>
<contactref element="R94" pad="1"/>
<wire x1="214.9475" y1="135.89" x2="206.375" y2="135.89" width="0.8128" layer="1"/>
</signal>
<signal name="N$189">
<contactref element="IC13" pad="8"/>
<contactref element="R94" pad="3"/>
<wire x1="213.995" y1="148.59" x2="214.9475" y2="148.59" width="0.8128" layer="1"/>
<wire x1="213.995" y1="148.59" x2="208.915" y2="143.51" width="0.8128" layer="1"/>
<wire x1="208.915" y1="143.51" x2="206.375" y2="143.51" width="0.8128" layer="1"/>
</signal>
<signal name="N$190">
<contactref element="R90" pad="1"/>
<contactref element="IC13" pad="6"/>
<contactref element="R91" pad="2"/>
<wire x1="216.945" y1="134.7125" x2="216.945" y2="138.43" width="0.8128" layer="1"/>
<wire x1="205.4225" y1="138.43" x2="201.295" y2="142.5575" width="0.8128" layer="1"/>
<wire x1="201.295" y1="143.51" x2="201.295" y2="142.5575" width="0.8128" layer="1"/>
<wire x1="205.4225" y1="138.43" x2="216.945" y2="138.43" width="0.8128" layer="1"/>
<wire x1="215.7095" y1="129.54" x2="215.432146875" y2="129.817353125" width="0.8128" layer="1"/>
<wire x1="215.7095" y1="129.54" x2="215.7095" y2="133.477" width="0.8128" layer="1"/>
<wire x1="215.7095" y1="133.477" x2="216.945" y2="134.7125" width="0.8128" layer="1"/>
</signal>
<signal name="N$191">
<contactref element="IC12" pad="18"/>
<wire x1="251.46" y1="135.255" x2="251.46" y2="135.0895" width="0.8128" layer="1"/>
<contactref element="R110" pad="2"/>
<wire x1="259.715" y1="126.8345" x2="259.715" y2="126.16" width="0.8128" layer="1"/>
<wire x1="251.46" y1="135.0895" x2="259.715" y2="126.8345" width="0.8128" layer="1"/>
</signal>
<signal name="N$192">
<contactref element="R95" pad="2"/>
<contactref element="IC12" pad="20"/>
<contactref element="R96" pad="2"/>
<contactref element="C47" pad="1"/>
<wire x1="248.92" y1="131.597" x2="249.072" y2="131.445" width="0.8128" layer="1"/>
<wire x1="246.38" y1="135.255" x2="245.4275" y2="136.2075" width="0.8128" layer="1"/>
<wire x1="245.4275" y1="139.065" x2="245.4275" y2="136.2075" width="0.8128" layer="1"/>
<wire x1="246.38" y1="135.255" x2="246.38" y2="135.0895" width="0.8128" layer="1"/>
<wire x1="248.92" y1="132.5495" x2="248.92" y2="131.597" width="0.8128" layer="1"/>
<wire x1="248.92" y1="132.5495" x2="246.38" y2="135.0895" width="0.8128" layer="1"/>
<wire x1="248.92" y1="131.597" x2="250.038" y2="131.597" width="0.8128" layer="1"/>
<wire x1="250.038" y1="131.597" x2="252.4125" y2="129.2225" width="0.8128" layer="1"/>
<wire x1="252.4125" y1="129.2225" x2="252.4125" y2="125.86" width="0.8128" layer="1"/>
</signal>
<signal name="N$193">
<contactref element="R98" pad="1"/>
<contactref element="IC12" pad="14"/>
<wire x1="259.08" y1="145.263" x2="259.08" y2="142.875" width="0.8128" layer="1"/>
</signal>
<signal name="N$194">
<contactref element="R96" pad="1"/>
<contactref element="R97" pad="1"/>
<contactref element="C46" pad="1"/>
<contactref element="VR1" pad="C"/>
<contactref element="VR1" pad="R"/>
<wire x1="248.79" y1="125.73" x2="248.92" y2="125.86" width="0.8128" layer="1"/>
<wire x1="243.6525" y1="126.1775" x2="246.0625" y2="126.1775" width="0.8128" layer="1"/>
<wire x1="246.38" y1="125.86" x2="248.92" y2="125.86" width="0.8128" layer="1"/>
<wire x1="248.92" y1="128.753" x2="248.92" y2="125.86" width="0.8128" layer="1"/>
<wire x1="246.0625" y1="125.8955" x2="246.0625" y2="126.1775" width="0.8128" layer="1"/>
<wire x1="246.0625" y1="126.1775" x2="246.38" y2="125.86" width="0.8128" layer="1"/>
<wire x1="243.5225" y1="126.0475" x2="240.9825" y2="126.0475" width="0.8128" layer="1"/>
<wire x1="243.5225" y1="126.0475" x2="243.6525" y2="126.1775" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$195">
<contactref element="IC12" pad="25"/>
<contactref element="S7" pad="3"/>
<wire x1="233.68" y1="135.255" x2="233.68" y2="134.3025" width="0.8128" layer="1"/>
<wire x1="233.68" y1="134.3025" x2="232.41" y2="133.0325" width="0.8128" layer="1"/>
<wire x1="232.41" y1="119.0625" x2="232.41" y2="133.0325" width="0.8128" layer="1"/>
<wire x1="232.41" y1="119.0625" x2="234.6325" y2="116.84" width="0.8128" layer="1"/>
<wire x1="255.6256" y1="116.84" x2="258.4069" y2="114.0587" width="0.8128" layer="1"/>
<wire x1="234.6325" y1="116.84" x2="255.6256" y2="116.84" width="0.8128" layer="1"/>
</signal>
<signal name="N$196">
<contactref element="LED6" pad="K"/>
<contactref element="LED7" pad="A"/>
<wire x1="235.585" y1="120.015" x2="237.1725" y2="118.4275" width="0.8128" layer="1"/>
<contactref element="R110" pad="1"/>
<wire x1="256.8575" y1="118.4275" x2="259.715" y2="121.285" width="0.8128" layer="1"/>
<wire x1="259.715" y1="121.285" x2="259.715" y2="122.76" width="0.8128" layer="1"/>
<wire x1="237.1725" y1="118.4275" x2="256.8575" y2="118.4275" width="0.8128" layer="1"/>
</signal>
<signal name="N$197">
<contactref element="DIS2" pad="3"/>
<contactref element="R111" pad="2"/>
<wire x1="208.665" y1="152.7175" x2="208.665" y2="157.74" width="0.8128" layer="1"/>
<wire x1="207.855" y1="152.7175" x2="208.665" y2="152.7175" width="0.8128" layer="1"/>
</signal>
<signal name="N$198">
<contactref element="T8" pad="B"/>
<contactref element="D13" pad="C"/>
<contactref element="R101" pad="2"/>
<contactref element="R99" pad="1"/>
<contactref element="C48" pad="2"/>
<wire x1="258.1275" y1="154.81" x2="261.0025" y2="154.81" width="0.8128" layer="1"/>
<wire x1="261.0025" y1="154.81" x2="261.62" y2="154.1925" width="0.8128" layer="1"/>
<wire x1="261.62" y1="154.1925" x2="262.685" y2="154.1925" width="0.8128" layer="1"/>
<wire x1="262.685" y1="154.1925" x2="264.16" y2="152.7175" width="0.8128" layer="1"/>
<wire x1="264.16" y1="152.7175" x2="264.16" y2="150.8125" width="0.8128" layer="1"/>
<wire x1="254.635" y1="157.328" x2="254.635" y2="155.092" width="0.8128" layer="1"/>
<wire x1="254.787" y1="154.94" x2="254.635" y2="155.092" width="0.8128" layer="1"/>
<wire x1="254.635" y1="157.328" x2="254.787" y2="157.48" width="0.8128" layer="1"/>
<wire x1="258.1275" y1="154.81" x2="254.635" y2="154.81" width="0.8128" layer="1"/>
<wire x1="254.635" y1="154.81" x2="254.787" y2="154.94" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$199">
<contactref element="T8" pad="C"/>
<contactref element="R100" pad="1"/>
<contactref element="JP10" pad="2"/>
<wire x1="266.7" y1="153.875" x2="266.7" y2="150.8125" width="0.8128" layer="1"/>
<via x="266.7" y="135.5725" extent="1-16" drill="0.8"/>
<via x="266.7" y="146.05" extent="1-16" drill="0.8"/>
<wire x1="266.7" y1="146.05" x2="266.7" y2="150.8125" width="0.8128" layer="1"/>
<wire x1="266.7" y1="146.05" x2="266.7" y2="135.5725" width="0.508" layer="16"/>
<wire x1="266.7" y1="135.5725" x2="263.8425" y2="135.5725" width="0.8128" layer="1"/>
</signal>
<signal name="N$200">
<contactref element="LSP13" pad="MP"/>
<contactref element="R101" pad="1"/>
<wire x1="251.943" y1="157.48" x2="251.6255" y2="157.1625" width="0.8128" layer="1"/>
<wire x1="251.6255" y1="157.1625" x2="249.555" y2="157.1625" width="0.8128" layer="1"/>
</signal>
<signal name="D">
<contactref element="R106" pad="1"/>
<contactref element="Q7" pad="3"/>
<contactref element="D14" pad="C"/>
<contactref element="C50" pad="2"/>
<wire x1="250.5075" y1="104.41425" x2="250.21075" y2="104.1175" width="0.8128" layer="1"/>
<wire x1="250.21075" y1="104.1175" x2="246.0625" y2="104.1175" width="0.8128" layer="1"/>
<contactref element="L2" pad="2"/>
<wire x1="258.9675" y1="103.505" x2="255.5875" y2="106.885" width="0.8128" layer="1"/>
<wire x1="255.5875" y1="106.885" x2="255.5875" y2="108.4375" width="0.8128" layer="1"/>
<wire x1="251.1425" y1="108.54" x2="251.245" y2="108.4375" width="0.8128" layer="1"/>
<wire x1="251.245" y1="108.4375" x2="255.5875" y2="108.4375" width="0.8128" layer="1"/>
<wire x1="250.5075" y1="104.41425" x2="250.5075" y2="107.905" width="0.8128" layer="1"/>
<wire x1="250.5075" y1="107.905" x2="251.1425" y2="108.54" width="0.8128" layer="1"/>
</signal>
<signal name="S">
<contactref element="Q7" pad="2"/>
<contactref element="R104" pad="1"/>
<contactref element="R105" pad="2"/>
<contactref element="R103" pad="2"/>
<contactref element="D15" pad="C"/>
<wire x1="215.5825" y1="117.68" x2="215.695" y2="117.7925" width="0.8128" layer="1"/>
<wire x1="243.205" y1="108.9025" x2="244.475" y2="108.9025" width="0.8128" layer="1"/>
<wire x1="243.205" y1="108.9025" x2="242.57" y2="109.5375" width="0.8128" layer="1"/>
<wire x1="242.57" y1="109.5375" x2="240.3475" y2="109.5375" width="0.8128" layer="1"/>
<wire x1="239.5605" y1="108.7505" x2="237.1725" y2="108.7505" width="0.8128" layer="1"/>
<wire x1="240.3475" y1="109.5375" x2="239.5605" y2="108.7505" width="0.8128" layer="1"/>
<wire x1="236.8945" y1="108.4725" x2="237.1725" y2="108.7505" width="0.8128" layer="1"/>
<wire x1="234.315" y1="108.4725" x2="235.9025" y2="108.4725" width="0.8128" layer="1"/>
<wire x1="235.9025" y1="108.4725" x2="236.8945" y2="108.4725" width="0.8128" layer="1"/>
<wire x1="235.9025" y1="108.4725" x2="235.9025" y2="105.205" width="0.8128" layer="1"/>
<wire x1="215.7875" y1="117.475" x2="215.5825" y2="117.68" width="0.8128" layer="1"/>
<wire x1="235.9025" y1="105.205" x2="235.2675" y2="105.54" width="0.8128" layer="1"/>
<wire x1="235.2675" y1="105.54" x2="222.4375" y2="105.54" width="0.8128" layer="1"/>
<wire x1="222.4375" y1="105.54" x2="218.7575" y2="109.22" width="0.8128" layer="1"/>
<via x="218.7575" y="109.22" extent="1-16" drill="0.8" diameter="1.7"/>
<wire x1="218.7575" y1="109.22" x2="218.7575" y2="117.475" width="0.8128" layer="16"/>
<via x="218.7575" y="117.475" extent="1-16" drill="0.8" diameter="1.7"/>
<wire x1="218.7575" y1="117.475" x2="215.7875" y2="117.475" width="0.8128" layer="1"/>
<wire x1="244.475" y1="108.9025" x2="246.0625" y2="110.49" width="0.8128" layer="1"/>
<wire x1="254.49" y1="110.49" x2="254.6375" y2="110.6375" width="0.8128" layer="1"/>
<wire x1="246.0625" y1="110.49" x2="254.49" y2="110.49" width="0.8128" layer="1"/>
</signal>
<signal name="N$201">
<contactref element="R103" pad="1"/>
<contactref element="IC13" pad="3"/>
<contactref element="C51" pad="2"/>
<wire x1="201.295" y1="135.89" x2="201.295" y2="133.6675" width="0.8128" layer="1"/>
<wire x1="201.295" y1="133.6675" x2="203.835" y2="131.1275" width="0.8128" layer="1"/>
<wire x1="203.835" y1="131.1275" x2="207.01" y2="131.1275" width="0.8128" layer="1"/>
<wire x1="207.01" y1="131.1275" x2="208.28" y2="132.3975" width="0.8128" layer="1"/>
<wire x1="208.28" y1="132.3975" x2="212.725" y2="132.3975" width="0.8128" layer="1"/>
<wire x1="212.725" y1="132.3975" x2="213.995" y2="131.1275" width="0.8128" layer="1"/>
<wire x1="213.995" y1="127.635" x2="215.5825" y2="126.0475" width="0.8128" layer="1"/>
<wire x1="215.5825" y1="126.0475" x2="215.5825" y2="125.4125" width="0.8128" layer="1"/>
<wire x1="213.995" y1="131.1275" x2="213.995" y2="127.635" width="0.8128" layer="1"/>
<wire x1="215.5825" y1="121.08" x2="215.5825" y2="123.5075" width="0.8128" layer="1"/>
<wire x1="215.5825" y1="123.5075" x2="215.5825" y2="125.4125" width="0.8128" layer="1"/>
<wire x1="218.31" y1="123.5075" x2="215.5825" y2="123.5075" width="0.8128" layer="1"/>
<contactref element="JP12" pad="1"/>
</signal>
<signal name="G">
<contactref element="Q8" pad="3"/>
<contactref element="Q7" pad="1"/>
<contactref element="R107" pad="2"/>
<wire x1="258.2975" y1="110.6375" x2="256.5375" y2="110.6375" width="0.8128" layer="1"/>
<wire x1="258.2975" y1="110.6375" x2="260.0325" y2="108.9025" width="0.8128" layer="1"/>
<wire x1="260.0325" y1="108.9025" x2="260.6675" y2="108.9025" width="0.8128" layer="1"/>
<wire x1="260.6675" y1="100.33" x2="260.6675" y2="108.9025" width="0.8128" layer="1"/>
<wire x1="260.0325" y1="99.695" x2="256.54" y2="99.695" width="0.8128" layer="1"/>
<wire x1="256.54" y1="99.695" x2="255.905" y2="100.33" width="0.8128" layer="1"/>
<wire x1="255.7395" y1="100.33" x2="255.905" y2="100.33" width="0.8128" layer="1"/>
<wire x1="260.6675" y1="100.33" x2="260.0325" y2="99.695" width="0.8128" layer="1"/>
<wire x1="260.6675" y1="108.9025" x2="261.3025" y2="108.9025" width="0.8128" layer="1"/>
<wire x1="261.3025" y1="108.9025" x2="265.7475" y2="113.3475" width="0.8128" layer="1"/>
<wire x1="265.7475" y1="113.3475" x2="265.7475" y2="115.105" width="0.8128" layer="1"/>
</signal>
<signal name="N$202">
<contactref element="Q8" pad="1"/>
<contactref element="R108" pad="2"/>
<wire x1="266.7" y1="120.22" x2="266.7" y2="117.3075" width="0.8128" layer="1"/>
<wire x1="266.6975" y1="117.305" x2="266.7" y2="117.3075" width="0.8128" layer="1"/>
</signal>
<signal name="N$203">
<contactref element="R98" pad="2"/>
<contactref element="JP9" pad="2"/>
<wire x1="255.905" y1="150.8125" x2="257.175" y2="150.8125" width="0.8128" layer="1"/>
<wire x1="257.175" y1="150.8125" x2="259.08" y2="148.9075" width="0.8128" layer="1"/>
<wire x1="259.08" y1="148.9075" x2="259.08" y2="148.107" width="0.8128" layer="1"/>
</signal>
<signal name="N$210">
<via x="227.0125" y="110.8075" extent="1-16" drill="0.8" diameter="0.9"/>
</signal>
<signal name="N$211">
<via x="243.84" y="110.8075" extent="1-16" drill="0.8" diameter="0.9"/>
</signal>
<signal name="N$212">
<via x="260.6675" y="110.8075" extent="1-16" drill="0.8" diameter="0.9"/>
</signal>
<signal name="N$213">
<via x="210.185" y="110.8075" extent="1-16" drill="0.8" diameter="0.9"/>
</signal>
<signal name="N$204">
<contactref element="IC12" pad="24"/>
<contactref element="JP10" pad="1"/>
<wire x1="236.22" y1="135.255" x2="236.22" y2="133.0325" width="0.8128" layer="1"/>
<via x="236.22" y="133.0325" extent="1-16" drill="0.8"/>
<wire x1="236.22" y1="133.0325" x2="261.3025" y2="133.0325" width="0.8128" layer="16"/>
<via x="261.3025" y="133.0325" extent="1-16" drill="0.8"/>
<wire x1="261.3025" y1="133.0325" x2="263.8425" y2="133.0325" width="0.8128" layer="1"/>
</signal>
<signal name="N$205">
<contactref element="R92" pad="3"/>
<contactref element="R91" pad="1"/>
<wire x1="212.3095" y1="129.54" x2="211.6745" y2="130.175" width="0.8128" layer="1"/>
<wire x1="211.6745" y1="130.175" x2="210.185" y2="130.175" width="0.8128" layer="1"/>
</signal>
<signal name="N$206">
<contactref element="R92" pad="2"/>
<contactref element="R102" pad="1"/>
<contactref element="R92" pad="1"/>
<contactref element="IC13" pad="2"/>
<wire x1="210.185" y1="117.475" x2="207.645" y2="120.015" width="0.8128" layer="1"/>
<wire x1="207.645" y1="125.095" x2="207.645" y2="125.73" width="0.8128" layer="1"/>
<wire x1="207.645" y1="125.73" x2="205.105" y2="128.27" width="0.8128" layer="1"/>
<wire x1="205.105" y1="128.27" x2="205.105" y2="128.905" width="0.8128" layer="1"/>
<via x="205.105" y="128.905" extent="1-16" drill="0.8" diameter="1.7"/>
<wire x1="205.105" y1="133.35" x2="205.105" y2="128.905" width="0.8128" layer="16"/>
<via x="205.105" y="133.35" extent="1-16" drill="0.8" diameter="1.7"/>
<wire x1="203.835" y1="135.89" x2="203.835" y2="134.62" width="0.8128" layer="1"/>
<wire x1="205.105" y1="133.35" x2="203.835" y2="134.62" width="0.8128" layer="1"/>
<wire x1="207.645" y1="120.015" x2="207.645" y2="121.285" width="0.8128" layer="1"/>
<wire x1="207.645" y1="121.285" x2="207.645" y2="125.095" width="0.8128" layer="1"/>
<wire x1="207.825" y1="121.285" x2="207.645" y2="121.285" width="0.8128" layer="1"/>
</signal>
<signal name="PWM">
<contactref element="IC12" pad="15"/>
<wire x1="259.08" y1="135.255" x2="259.08" y2="132.08" width="0.8128" layer="1"/>
<contactref element="JP11" pad="3"/>
<contactref element="R108" pad="1"/>
<wire x1="260.35" y1="130.81" x2="266.7" y2="130.81" width="0.8128" layer="1"/>
<wire x1="270.1925" y1="134.3025" x2="266.7" y2="130.81" width="0.8128" layer="1"/>
<wire x1="270.1925" y1="134.3025" x2="270.51" y2="134.3025" width="0.8128" layer="1"/>
<wire x1="259.08" y1="132.08" x2="260.35" y2="130.81" width="0.8128" layer="1"/>
<wire x1="266.7" y1="123.62" x2="266.7" y2="130.81" width="0.8128" layer="1"/>
</signal>
<signal name="AUT.ON-OFF">
<contactref element="IC12" pad="16"/>
<wire x1="256.54" y1="135.255" x2="256.54" y2="135.89" width="0.8128" layer="1"/>
<wire x1="256.54" y1="135.89" x2="258.445" y2="137.795" width="0.8128" layer="1"/>
<wire x1="258.445" y1="137.795" x2="267.97" y2="137.795" width="0.8128" layer="1"/>
<contactref element="JP11" pad="2"/>
<wire x1="270.51" y1="136.8425" x2="268.9225" y2="136.8425" width="0.8128" layer="1"/>
<wire x1="268.9225" y1="136.8425" x2="267.97" y2="137.795" width="0.8128" layer="1"/>
</signal>
<signal name="N$207">
<contactref element="LSP14" pad="MP"/>
<contactref element="L2" pad="1"/>
<wire x1="270.1925" y1="106.045" x2="267.6525" y2="103.505" width="0.8128" layer="1"/>
<wire x1="267.6525" y1="103.505" x2="262.3675" y2="103.505" width="0.8128" layer="1"/>
</signal>
<signal name="N$208">
<contactref element="R90" pad="2"/>
<contactref element="IC12" pad="23"/>
<contactref element="C49" pad="2"/>
<contactref element="OFSETMéRőP." pad="MP"/>
<wire x1="238.76" y1="135.255" x2="238.76" y2="132.21" width="0.8128" layer="1"/>
<wire x1="238.76" y1="132.21" x2="236.855" y2="130.305" width="0.8128" layer="1"/>
<wire x1="236.855" y1="130.305" x2="236.22" y2="130.305" width="0.8128" layer="1"/>
<wire x1="238.76" y1="135.255" x2="238.76" y2="136.8425" width="0.8128" layer="1"/>
<wire x1="238.76" y1="136.8425" x2="237.1725" y2="138.43" width="0.8128" layer="1"/>
<wire x1="237.1725" y1="138.43" x2="221.9325" y2="138.43" width="0.8128" layer="1"/>
<wire x1="220.345" y1="138.43" x2="221.9325" y2="138.43" width="0.8128" layer="1"/>
</signal>
<signal name="N$209">
<contactref element="LED6" pad="A"/>
<contactref element="LED7" pad="K"/>
<contactref element="R109" pad="2"/>
<wire x1="235.585" y1="122.555" x2="236.22" y2="122.555" width="0.8128" layer="1"/>
<wire x1="236.22" y1="122.555" x2="238.76" y2="120.015" width="0.8128" layer="1"/>
<wire x1="256.8575" y1="120.9675" x2="256.8575" y2="122.76" width="0.8128" layer="1"/>
<wire x1="238.76" y1="120.015" x2="255.905" y2="120.015" width="0.8128" layer="1"/>
<wire x1="255.905" y1="120.015" x2="256.8575" y2="120.9675" width="0.8128" layer="1"/>
</signal>
<signal name="N$214">
<via x="198.08825" y="157.734" extent="1-16" drill="0.35"/>
</signal>
<signal name="N$215">
<via x="273.08175" y="157.70225" extent="1-16" drill="0.35"/>
</signal>
<signal name="N$216">
<via x="273.08175" y="126.71425" extent="1-16" drill="0.35"/>
</signal>
<signal name="N$217">
<via x="198.12" y="126.71425" extent="1-16" drill="0.35"/>
</signal>
</signals>
<mfgpreviewcolors>
<mfgpreviewcolor name="soldermaskcolor" color="0xC8008000"/>
<mfgpreviewcolor name="silkscreencolor" color="0xFFFEFEFE"/>
<mfgpreviewcolor name="backgroundcolor" color="0xFF282828"/>
<mfgpreviewcolor name="coppercolor" color="0xFFFFBF00"/>
<mfgpreviewcolor name="substratecolor" color="0xFF786E46"/>
</mfgpreviewcolors>
</board>
</drawing>
<compatibility>
<note version="8.2" severity="warning">
Since Version 8.2, EAGLE supports online libraries. The ids
of those online libraries will not be understood (or retained)
with this version.
</note>
<note version="8.3" severity="warning">
Since Version 8.3, EAGLE supports URNs for individual library
assets (packages, symbols, and devices). The URNs of those assets
will not be understood (or retained) with this version.
</note>
Since Version 8.3, EAGLE supports the association of 3D packages
with devices in libraries, schematics, and board files. Those 3D
packages will not be understood (or retained) with this version.
</note>
<note version="8.5" severity="warning">
Since Version 8.5, EAGLE supports locking for holes, vias, wires and polygons.
The locking property on all objects of these types will not be understood in this version.
</note>
</compatibility>
</eagle>
