; Source created with Parsic Version 3.x
; at              : 2008.11.09. 10:57:20
; Project File    : C:\PROGRA~1\Parsic\Examples\HE\FUTF_01.PIC
; Project Version : 1.0.2
; Created         : 2008.11.09. 10:55:58
; Last change     : 2008.11.09. 10:57:18
	PROCESSOR 16F628
	INCLUDE P16F628.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_ON & _WDT_OFF & _BODEN_ON & _INTRC_OSC_NOCLKOUT & _LVP_OFF & _MCLRE_OFF
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
S0	= 32	; located in Bank 0
TR1	= 33	; located in Bank 0
TR1_HI	= 34	; located in Bank 0
ZV1	= 35	; located in Bank 0
ZV1_FD	= 36	; located in Bank 0
S1	= 37	; located in Bank 0
RAM	= 38	; located in Bank 0
SYS_WSAV	= 112	; located in Bank 0, 1, 2, 3
SYS_SSAV	= 113	; located in Bank 0, 1, 2, 3
SYS_FSAV	= 114	; located in Bank 0, 1, 2, 3
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	CLRF STATUS	; switch to RAM-Bank 0
	GOTO SYS_INIT
	NOP
	NOP
;Interrupt-Adress
	MOVWF SYS_WSAV	; save register
	SWAPF STATUS,W
	CLRF STATUS	; bank 0
	MOVWF SYS_SSAV
	MOVFW FSR
	MOVWF SYS_FSAV
	BTFSS INTCON,T0IF	; TMR0 ?
	GOTO NOTMR0INT
	BCF INTCON,T0IF	; Interrupt quitieren
	BCF STATUS,RP0	; Bank 0
	BCF STATUS,RP1	; Bank 0
	INCFSZ TR1,F
	GOTO SYS_INT_LABEL_0
	INCF TR1_HI,F
SYS_INT_LABEL_0
NOTMR0INT
EXITINT
	MOVFW SYS_FSAV
	MOVWF FSR
	SWAPF SYS_SSAV,W	; Register zurück
	MOVWF STATUS
	SWAPF SYS_WSAV,F
	SWAPF SYS_WSAV,W
	RETFIE
; Subroutines
;Initialisierung
SYS_INIT
	MOVLW B'00100000'
	MOVWF INTCON
; Set output before direction
	MOVLW B'00000000'
	MOVWF PORTA
	MOVLW B'00000000'
	MOVWF PORTB
	MOVLW 15
	BSF STATUS,RP0	; Bank 1
	MOVWF OPTION_REG
; Richtung setzen
	MOVLW B'11111111'
	MOVWF TRISA
	MOVLW B'11111111'
	MOVWF TRISB
	MOVLW 7	; Comparators off
	MOVWF CMCON
; init vars
; Clear RAM
	BCF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	BTFSS FSR,7
	GOTO CR1
	BSF FSR,5
CR2
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR2
	BSF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR3
	CLRF INDF
	INCF FSR,F
	MOVLW H'50'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR3
	CLRF TMR0
	BCF INTCON,T0IF
	BSF INTCON,GIE	; Interrupt freigeben
;******* Haupt-Programm ***********
MAIN
; Vergleich -> IF1
	MOVLW 8
	SUBWF ZV1,W	; F - W -> W
LABEL_IF1_CHECK
	BTFSS STATUS,CARRY	; Test auf -> >
	GOTO LABEL_IF1_FALSE
	BTFSC STATUS,ZERO
LABEL_IF1_TRUE
	BSF S0,1
	GOTO LABEL_IF1_EXIT
LABEL_IF1_FALSE
	BCF S0,1
LABEL_IF1_EXIT
; Timer -> TR1
	MOVLW 0	; Test auf >=
	SUBWF TR1_HI,W	;F-W -> W
	BTFSS STATUS,ZERO
	GOTO LABEL_TR1_CHECK
	MOVLW 195
	SUBWF TR1,W	;F-W -> W
LABEL_TR1_CHECK
	BTFSS STATUS,CARRY
	GOTO LABEL_TR1_ENDE
LABEL_TR1_RESET
	SUBWF TR1_HI,F	;F-W -> F
	MOVLW 195
	SUBWF TR1,F	;F-W -> F
	BTFSS STATUS,CARRY
	DECF TR1_HI,F
LABEL_TR1_SET	; toggel output
	BTFSC S0,0
	GOTO LABEL_TR1_CLR
	BSF S0,0
	GOTO LABEL_TR1_ENDE
LABEL_TR1_CLR
	BCF S0,0
LABEL_TR1_ENDE
; Zähler -> ZV1
	BTFSS S0,2	; Reset ?
	GOTO LABEL_ZV1_COUNT
	CLRF ZV1
	GOTO LABEL_ZV1_SETOUT
LABEL_ZV1_COUNT
; Test auf positive Flanke
	BTFSS S0,0
	GOTO LABEL_ZV1_SETFD
	BTFSC ZV1_FD,0
	BSF ZV1_FD,0
	BTFSC S0,4	; Vorwärts oder Rückwärts ?
	GOTO LABEL_ZV1_BACKWARD
	INCF ZV1,F
LABEL_ZV1_BACKWARD
	DECF ZV1,F
LABEL_ZV1_SETOUT
LABEL_ZV1_SETFD
; Test auf negative Flanke
	BTFSC S0,0
	GOTO LABEL_ZV1_EXIT
	BCF ZV1_FD,0
LABEL_ZV1_EXIT
; RS-FLIP-FLOP -> RS1
	BTFSC S0,3
	GOTO LABEL_RS1_RESET
	BTFSS S0,1
	GOTO LABEL_RS1_ENDE
	BSF S0,4	; Ausgang setzen
	GOTO LABEL_RS1_ENDE
LABEL_RS1_RESET
	BCF S0,4	; Ausgang zurücksetzen
LABEL_RS1_ENDE
; Vergleich -> IF2
	MOVLW 0
LABEL_IF2_CHECK
	BTFSS STATUS,ZERO	; Test auf -> =
	GOTO LABEL_IF2_FALSE
LABEL_IF2_TRUE
	BSF S0,3
	GOTO LABEL_IF2_EXIT
LABEL_IF2_FALSE
	BCF S0,3
LABEL_IF2_EXIT
; Vergleich -> IF3
	MOVLW 0
LABEL_IF3_CHECK
	GOTO LABEL_IF3_FALSE
LABEL_IF3_TRUE
	BSF S0,5
	GOTO LABEL_IF3_EXIT
LABEL_IF3_FALSE
	BCF S0,5
LABEL_IF3_EXIT
; Vergleich -> IF4
	MOVLW 1
LABEL_IF4_CHECK
	GOTO LABEL_IF4_FALSE
LABEL_IF4_TRUE
	BSF S0,6
	GOTO LABEL_IF4_EXIT
LABEL_IF4_FALSE
	BCF S0,6
LABEL_IF4_EXIT
; Vergleich -> IF5
	MOVLW 2
LABEL_IF5_CHECK
	GOTO LABEL_IF5_FALSE
LABEL_IF5_TRUE
	BSF S0,7
	GOTO LABEL_IF5_EXIT
LABEL_IF5_FALSE
	BCF S0,7
LABEL_IF5_EXIT
; Vergleich -> IF6
	MOVLW 3
LABEL_IF6_CHECK
	GOTO LABEL_IF6_FALSE
LABEL_IF6_TRUE
	BSF S1,0
	GOTO LABEL_IF6_EXIT
LABEL_IF6_FALSE
	BCF S1,0
LABEL_IF6_EXIT
; Vergleich -> IF7
	MOVLW 4
LABEL_IF7_CHECK
	GOTO LABEL_IF7_FALSE
LABEL_IF7_TRUE
	BSF S1,1
	GOTO LABEL_IF7_EXIT
LABEL_IF7_FALSE
	BCF S1,1
LABEL_IF7_EXIT
; Vergleich -> IF8
	MOVLW 5
LABEL_IF8_CHECK
	GOTO LABEL_IF8_FALSE
LABEL_IF8_TRUE
	BSF S1,2
	GOTO LABEL_IF8_EXIT
LABEL_IF8_FALSE
	BCF S1,2
LABEL_IF8_EXIT
; Vergleich -> IF9
	MOVLW 6
LABEL_IF9_CHECK
	GOTO LABEL_IF9_FALSE
LABEL_IF9_TRUE
	BSF S1,3
	GOTO LABEL_IF9_EXIT
LABEL_IF9_FALSE
	BCF S1,3
LABEL_IF9_EXIT
; Vergleich -> IF10
	MOVLW 7
LABEL_IF10_CHECK
	GOTO LABEL_IF10_FALSE
LABEL_IF10_TRUE
	BSF S1,4
	GOTO LABEL_IF10_EXIT
LABEL_IF10_FALSE
	BCF S1,4
LABEL_IF10_EXIT
; Vergleich -> IF11
	MOVLW 8
LABEL_IF11_CHECK
	GOTO LABEL_IF11_FALSE
LABEL_IF11_TRUE
	BSF S1,5
	GOTO LABEL_IF11_EXIT
LABEL_IF11_FALSE
	BCF S1,5
LABEL_IF11_EXIT
; GND
	BCF S0,2	; immer Low
	GOTO MAIN
	END
