<root>
<document scada='0' schema='102' license='1,80636800,6RRVYP' title='' description='' fcversion='590336' target='PIC.16F.16F876A' >
	<config data='!0,3f32%0,2%2,0%3,0%6,0%7,0%9,3%b,1%8,1%d,1' clkspd='20000000' simspd='1' usewdt='0' constif='0' Use3V3='0' />
	<plugins >
		<dll_models enabled='1' />
	</plugins>
	<supplement use='0' head='' body='' />
	<debug >
		<watch expr='TEMP' />
		<watch expr='Sense' />
		<watch expr='HUM' />
	</debug>
	<traces />
	<ghost >
		<FK2 >
			<data name='FK2D0' port='4294967295' pin='4294967295' />
			<data name='FK2D1' port='4294967295' pin='4294967295' />
			<data name='FK2D2' port='4294967295' pin='4294967295' />
			<data name='FK2D3' port='4294967295' pin='4294967295' />
			<data name='FK2D4' port='4294967295' pin='4294967295' />
			<data name='FK2D5' port='4294967295' pin='4294967295' />
			<data name='FK2D6' port='4294967295' pin='4294967295' />
			<data name='FK2D7' port='4294967295' pin='4294967295' />
			<data name='FK2D8' port='4294967295' pin='4294967295' />
			<data name='FK2D9' port='4294967295' pin='4294967295' />
			<data name='FK2D10' port='4294967295' pin='4294967295' />
			<data name='FK2D11' port='4294967295' pin='4294967295' />
			<data name='FK2D12' port='4294967295' pin='4294967295' />
			<data name='FK2D13' port='4294967295' pin='4294967295' />
			<data name='FK2D14' port='4294967295' pin='4294967295' />
			<data name='FK2D15' port='4294967295' pin='4294967295' />
			<data name='FK2A0' port='4294967295' pin='4294967295' />
			<data name='FK2A1' port='4294967295' pin='4294967295' />
			<data name='FK2A2' port='4294967295' pin='4294967295' />
			<data name='FK2A3' port='4294967295' pin='4294967295' />
			<data name='FK2A4' port='4294967295' pin='4294967295' />
			<data name='FK2A5' port='4294967295' pin='4294967295' />
		</FK2>
		<ICD >
			<data name='AnalogPrescaleValue' value='19' />
			<data name='DigitalSampleRate' value='100000' />
			<data name='BreakpointCount' value='8' />
			<data name='CallStackDepthCount' value='8' />
			<data name='ClockPort' value='1' />
			<data name='ClockPin' value='6' />
			<data name='DataPort' value='1' />
			<data name='DataPin' value='7' />
			<data name='UseDefaultPins' value='1' />
			<data name='WrapEnabled' value='1' />
			<data name='CommsDelayOverridden' value='0' />
			<data name='CommsDelay' value='9' />
			<data name='CalculatedCommsDelay' value='9' />
			<data name='AnalogEB2PrescaleValue' value='2' />
			<data name='DigitalEB2SampleRate' value='100000' />
		</ICD>
		<pins >
			<digital A='0' B='0' C='0' D='0' E='0' F='0' G='0' H='0' I='0' J='0' K='0' L='0' M='0' N='0' O='0' P='0' Q='0' R='0' S='0' T='0' U='0' V='0' W='0' X='0' Y='0' Z='0' />
			<analog A='0' B='0' C='0' D='0' E='0' F='0' G='0' H='0' I='0' J='0' K='0' L='0' M='0' N='0' O='0' P='0' Q='0' R='0' S='0' T='0' U='0' V='0' W='0' X='0' Y='0' Z='0' />
		</pins>
	</ghost>
	<components >
		<settings autoimg='1' center='1' unitscale='0' fixedscale='0' fixedx='1' fixedy='1' fixedz='1' headcode='0' />
		<definition guid='9c9febe3-e17a-4d2b-8546-468abe678c2e' vstate='40' vmin='0' vmaj='1' srcleaf='' visiblename='' description='' category='' category2='' category3='' bIs2dOnly='0' catenable='1' author='' manuname='' manucode='' sysinfo='0' keywords='' dynamic='0' scadaCompatible='0' embeddedCompatible='1' iconpath='' />
		<gdiopts FullContainer='1' FullTransparency='1' ShowGdi='1' ShowOpengl='1' />
		<component class_type='root' codename='panel' x='0' y='0' z='0' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' scadavisible='1' interactive='1' solid='1' layer='0' poslock='0' comp2dType='0' >
			<resources />
			<properties />
			<values />
			<events />
			<apis />
			<variables >
				<variable public='0' >
					<def class_type='variable' name='false' type='b1' description='' isconst='1' isHidden='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='TEMP' type='f32' description='' isconst='0' isHidden='0' isinit='0' usrinit='0.0' setinit='' />
				</variable>
					<def class_type='variable' name='SWITCH' type='u8' description='' isconst='0' isHidden='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='HUM' type='f32' description='' isconst='0' isHidden='0' isinit='0' usrinit='0.0' setinit='' />
				</variable>
					<def class_type='variable' name='SENSE' type='u8' description='' isconst='0' isHidden='0' isinit='0' usrinit='0' setinit='' />
				</variable>
					<def class_type='variable' name='true' type='b1' description='' isconst='1' isHidden='0' isinit='1' usrinit='1' setinit='1' />
				</variable>
			</variables>
			<macros >
				<macro >
					<flowline name='Main' description='' statediag='0' >
						<return name='Return' type='v0' description='' isconst='0' isHidden='0' isinit='0' usrinit='' setinit='' />
						<command class_type='comment' title='' comment='Csak belso, szobai homero, es paratartalom mero.
0 celsius alatt &quot;---&quot; kijelzés' textarea='12,0,12,0' cmdcolor='4399907' cmdcolor_sec='16772075' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='1' />
						<command class_type='interrupt' title='Interrupt' cmdcolor='128' cmdcolor_sec='16772075' cmdcolor_txt='16777215' cmdgradient='0' cmdopacity='1' enable='1' name='TMR2' call='INT' >
							<settings timer='1' prescale='1' postscale='2' rollover='250' bitcount='-1' trigger='3' maskhi='--------------------------------------------------------------------------------------------------------------------------------------------------------------------------8' masklo='--------------------------------------------------------------------------------------------------------------------------------------------------------------------------8' >
								<option value='0' />
								<option value='1' />
								<option value='250' />
								<option value='-1' />
							</settings>
						</command>
						<command class_type='delay' title='Delay' cmdcolor='11119017' cmdcolor_sec='16772075' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='1' exp='2' type='2' />
						<command class_type='loop' title='Loop' cmdcolor='16711680' cmdcolor_sec='16777192' cmdcolor_txt='16777215' cmdgradient='0' cmdopacity='1' type='0' exp='1' >
							<flowline >
								<command class_type='call' title='Call Component Macro' cmdcolor='5000268' cmdcolor_sec='16772075' cmdcolor_txt='16777215' cmdgradient='0' cmdopacity='1' component='DHT22' macro='SampleSensor' >
									<return exp='SENSE' />
								</command>
								<command class_type='decision' title='Decision' cmdcolor='12632256' cmdcolor_sec='16777192' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='1' exp='SENSE = 1' swap='0' >
									<flowline >
										<command class_type='comment' title='' comment='Sensor not found: &quot; EEE &quot;' textarea='12,0,12,0' cmdcolor='4399907' cmdcolor_sec='16772075' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='1' />
										<command class_type='call' title='Component Macro' cmdcolor='5000268' cmdcolor_sec='16772075' cmdcolor_txt='16777215' cmdgradient='0' cmdopacity='1' component='DISP_74HC595' macro='ShowSegments' >
											<argument exp='0' />
											<argument exp='121' />
										</command>
											<argument exp='1' />
										</command>
											<argument exp='2' />
										</command>
									</flowline>
									<flowline />
								</command>
								<command class_type='decision' title='Decision' cmdcolor='12632256' cmdcolor_sec='16777192' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='1' exp='SENSE = 2' swap='0' >
									<flowline >
										<command class_type='comment' title='' comment='CRC error: &quot;crc&quot;' textarea='36,34,36,34' cmdcolor='4399907' cmdcolor_sec='16772075' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='1' />
											<argument exp='88' />
										</command>
											<argument exp='80' />
										</command>
										</command>
									</flowline>
									<flowline />
								</command>
								<command class_type='decision' title='Decision' cmdcolor='12632256' cmdcolor_sec='16777192' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='1' exp='SENSE = 0' swap='0' >
									<flowline >
										<command class_type='call' title='Component Macro' cmdcolor='5000268' cmdcolor_sec='16772075' cmdcolor_txt='16777215' cmdgradient='0' cmdopacity='1' component='DHT22' macro='GetTempFloat' >
											<return exp='TEMP' />
										</command>
										<command class_type='call' title='Component Macro' cmdcolor='5000268' cmdcolor_sec='16772075' cmdcolor_txt='16777215' cmdgradient='0' cmdopacity='1' component='DHT22' macro='GetHumidityFloat' >
											<return exp='HUM' />
										</command>
										<command class_type='calculation' title='Calculation' cmdcolor='598855' cmdcolor_sec='16772075' cmdcolor_txt='16777215' cmdgradient='0' cmdopacity='1' >
											<exp exp='TEMP = TEMP * 10' />
											<exp exp='HUM = HUM * 10' />
										</command>
										<command class_type='decision' title='Decision' cmdcolor='12632256' cmdcolor_sec='16777192' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='1' exp='HUM &gt; 999' swap='0' >
											<flowline >
													<exp exp='HUM = 999' />
												</command>
											</flowline>
											<flowline />
										</command>
										<command class_type='decision' title='Decision' cmdcolor='12632256' cmdcolor_sec='16777192' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='1' exp='SWITCH = 1' swap='0' >
											<flowline >
												<command class_type='call' title='Component Macro' cmdcolor='5000268' cmdcolor_sec='16772075' cmdcolor_txt='16777215' cmdgradient='0' cmdopacity='1' component='DISP_74HC595' macro='ShowDigits' >
													<argument exp='HUM / 100' />
													<argument exp='HUM / 10 MOD 10' />
													<argument exp='HUM MOD 10' />
													<argument exp='16' />
												</command>
												<command class_type='call' title='Component Macro' cmdcolor='5000268' cmdcolor_sec='16772075' cmdcolor_txt='16777215' cmdgradient='0' cmdopacity='1' component='UNIT_74HC595' macro='ShowSegments' >
													<argument exp='99' />
												</command>
													<argument exp='92' />
												</command>
											</flowline>
											<flowline >
												<command class_type='decision' title='Decision' cmdcolor='12632256' cmdcolor_sec='16777192' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='1' exp='TEMP &lt; 0' swap='0' >
													<flowline >
															<argument exp='64' />
														</command>
														</command>
														</command>
													</flowline>
													<flowline >
															<argument exp='TEMP / 100' />
															<argument exp='TEMP / 10 MOD 10' />
															<argument exp='TEMP MOD 10' />
														</command>
														</command>
															<argument exp='57' />
														</command>
													</flowline>
												</command>
											</flowline>
										</command>
									</flowline>
									<flowline >
										</command>
										</command>
									</flowline>
								</command>
								<command class_type='delay' title='Delay' cmdcolor='11119017' cmdcolor_sec='16772075' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='1' exp='500' type='1' />
							</flowline>
						</command>
					</flowline>
				</macro>
				<macro >
					<flowline name='INT' description='' statediag='0' >
						<command class_type='input' title='Input' cmdcolor='255' cmdcolor_sec='16772075' cmdcolor_txt='16777215' cmdgradient='0' cmdopacity='1' mode='1' port='1048576' mask='1' exp='SWITCH' usechipref='1' />
					</flowline>
				</macro>
			</macros>
			<component class_type='ref' guid='95a1525b-7e03-4836-8c09-59bf174f603b' vmin='2' vmaj='1' codename='DHT22' x='-26.4956' y='60.1232' z='254.015' xsz='13.7655' ysz='13.7655' zsz='13.7655' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' scadavisible='1' interactive='1' solid='1' layer='1' poslock='0' comp2dType='0' >
				<resources />
				<properties />
				<values >
					<value target='dpin' data='$PORTA.1' />
					<value target='csum' data='1' />
					<value target='ClockAdjust' data='000' />
					<value target='Nop30us' data='140.000000' />
					<value target='DeviceFamily' data='PIC' />
					<value target='InstPerMicro' data='5.000000' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='ref' guid='bddc472f-59dc-4705-997e-662768d643cd' vmin='0' vmaj='1' codename='DISP_74HC595' x='-28.2906' y='0.309924' z='21.0983' xsz='91.7093' ysz='35.4926' zsz='23.1676' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' scadavisible='1' interactive='1' solid='1' layer='1' poslock='0' comp2dType='0' >
				<resources />
				<properties />
				<values >
					<value target='Num7Segs' data='003' />
					<value target='Display_Type' data='001' />
					<value target='ShowSegLabels' data='0' />
					<value target='DATA_PIN' data='$PORTB.7' />
					<value target='CLK_PIN' data='$PORTB.6' />
					<value target='LATCH_PIN' data='$PORTB.5' />
					<value target='FGColor' data='65280' />
					<value target='BGColor' data='2960685' />
					<value target='LabelColor' data='16777215' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='ref' guid='e8f04af0-03d9-4b1c-83d3-9d0b1dc0f80a' vmin='1' vmaj='1' codename='sw_toggle_mtl_pnl1' x='-80.5887' y='28.6976' z='0' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' scadavisible='1' interactive='1' solid='1' layer='1' poslock='0' comp2dType='0' >
				<resources />
				<properties />
				<values >
					<value target='pin' data='$PORTA.0' />
					<value target='polarity' data='000' />
					<value target='debounce' data='10' />
					<value target='operation' data='000' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='ref' guid='bddc472f-59dc-4705-997e-662768d643cd' vmin='0' vmaj='1' codename='UNIT_74HC595' x='9.93346' y='5.69875' z='267.881' xsz='74.3688' ysz='18.1521' zsz='5.82712' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' scadavisible='1' interactive='1' solid='1' layer='1' poslock='0' comp2dType='0' >
				<resources />
				<properties />
				<values >
					<value target='Num7Segs' data='002' />
					<value target='DATA_PIN' data='$PORTB.0' />
					<value target='CLK_PIN' data='$PORTB.1' />
					<value target='LATCH_PIN' data='$PORTB.2' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
		</component>
	</components>
	<scadaresourcelookup />
	<keymap />
	<panel2d shadows='1' lighting='0' brightness='0' >
		<background rgb='9737364' img='' style='0' />
		<camera xe='-41.2133' ye='45.3077' ze='101.175' xt='-41.2133' yt='45.3077' zt='0' xquat='0' yquat='0' zquat='0' wquat='1' />
		<viewport dx='231' dy='233' zoom='276.265' fix_topleft='0' />
		<page x='1000' y='1000' show='0' rgb='7360576' />
	</panel2d>
	<panel3d shadows='0' lighting='2' brightness='128' perspective='1' >
		<background rgb='65280' img='' style='0' />
		<table rgb='7360576' img='' style='0' size='70' />
		<camera xe='89.5348' ye='68.2384' ze='635.911' xt='89.5348' yt='68.2384' zt='0' xquat='0' yquat='0' zquat='0' wquat='1' />
		<camerakey0 xe='0' ye='0' ze='300' xt='0' yt='0' zt='0' xquat='0' yquat='0' zquat='0' wquat='1' />
		<camerakey1 xe='-3.67394e-14' ye='0' ze='-300' xt='0' yt='0' zt='0' xquat='0' yquat='1' zquat='0' wquat='6.12323e-17' />
		<camerakey2 xe='0' ye='-300' ze='6.66134e-14' xt='0' yt='0' zt='0' xquat='-0.707107' yquat='0' zquat='0' wquat='0.707107' />
		<camerakey3 xe='-3.67394e-14' ye='300' ze='6.66134e-14' xt='0' yt='0' zt='0' xquat='-4.32978e-17' yquat='0.707107' zquat='0.707107' wquat='4.32978e-17' />
		<camerakey4 xe='-300' ye='-6.66134e-14' ze='6.66134e-14' xt='0' yt='0' zt='0' xquat='-0.5' yquat='0.5' zquat='0.5' wquat='0.5' />
		<camerakey5 xe='300' ye='-6.66134e-14' ze='6.66134e-14' xt='0' yt='0' zt='0' xquat='-0.5' yquat='-0.5' zquat='-0.5' wquat='0.5' />
		<camerakey6 xe='-173.205' ye='-173.205' ze='173.205' xt='0' yt='0' zt='0' xquat='-0.424708' yquat='0.17592' zquat='0.339851' wquat='0.820473' />
	</panel3d>
	<layout >
		<view type='0' name='Main' mode='0' placement='LAAAAAAAAAABAAAA---------------------wUAAAAYAAAAEQQAAFYCAAA' zoom='45' scrollx='0' scrolly='0' flags='0' />
		<view type='0' name='INT' mode='0' placement='LAAAAAAAAAABAAAA---------------------wUAAAAYAAAAEQQAAFYCAAA' zoom='75' scrollx='0' scrolly='0' flags='0' />
	</layout>
</document>
</root>
