<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="7.5.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.05" unitdist="inch" unit="mm" style="lines" multiple="1" display="yes" altdistance="0.025" altunitdist="inch" altunit="mm"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="yes" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="yes" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
</layers>
<library>
<description>&lt;b&gt;Hitachi, Data Modul, Tuxgraphics - LCD Displays&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="H1333C">
<description>&lt;b&gt;LCD DISPLAY&lt;/b&gt;&lt;p&gt;
4-character 7 segment</description>
<wire x1="-25.4" y1="-15.24" x2="25.4" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="25.4" y1="15.24" x2="-25.4" y2="15.24" width="0.1524" layer="21"/>
<wire x1="25.4" y1="-15.24" x2="25.4" y2="-11.43" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="-11.43" x2="-25.4" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="25.4" y1="-11.43" x2="-25.4" y2="-11.43" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="15.24" x2="-25.4" y2="11.43" width="0.1524" layer="21"/>
<wire x1="25.4" y1="-11.43" x2="25.4" y2="11.43" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="11.43" x2="25.4" y2="11.43" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="11.43" x2="-25.4" y2="-11.43" width="0.1524" layer="21"/>
<wire x1="25.4" y1="11.43" x2="25.4" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-20.955" y1="8.89" x2="-21.59" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="8.255" x2="-21.59" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-8.255" x2="-20.955" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="-20.955" y1="-8.89" x2="20.955" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="20.955" y1="-8.89" x2="21.59" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="21.59" y1="-8.255" x2="21.59" y2="8.255" width="0.1524" layer="21"/>
<wire x1="21.59" y1="8.255" x2="20.955" y2="8.89" width="0.1524" layer="21"/>
<wire x1="20.955" y1="8.89" x2="-20.955" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="5.715" x2="-17.78" y2="0.762" width="1.27" layer="21"/>
<wire x1="-17.78" y1="-0.762" x2="-17.78" y2="-5.715" width="1.27" layer="21"/>
<wire x1="-16.383" y1="-6.35" x2="-14.097" y2="-6.35" width="1.27" layer="21"/>
<wire x1="-12.7" y1="-5.715" x2="-12.7" y2="-0.762" width="1.27" layer="21"/>
<wire x1="-12.7" y1="0.762" x2="-12.7" y2="5.715" width="1.27" layer="21"/>
<wire x1="-16.383" y1="6.35" x2="-14.097" y2="6.35" width="1.27" layer="21"/>
<wire x1="-16.383" y1="0" x2="-14.097" y2="0" width="1.27" layer="21"/>
<wire x1="12.7" y1="5.715" x2="12.7" y2="0.762" width="1.27" layer="21"/>
<wire x1="12.7" y1="-0.762" x2="12.7" y2="-5.715" width="1.27" layer="21"/>
<wire x1="14.097" y1="-6.35" x2="16.383" y2="-6.35" width="1.27" layer="21"/>
<wire x1="17.78" y1="-5.715" x2="17.78" y2="-0.762" width="1.27" layer="21"/>
<wire x1="17.78" y1="0.762" x2="17.78" y2="5.715" width="1.27" layer="21"/>
<wire x1="14.097" y1="6.35" x2="16.383" y2="6.35" width="1.27" layer="21"/>
<wire x1="14.097" y1="0" x2="16.383" y2="0" width="1.27" layer="21"/>
<wire x1="-7.62" y1="5.715" x2="-7.62" y2="0.762" width="1.27" layer="21"/>
<wire x1="-7.62" y1="-0.762" x2="-7.62" y2="-5.715" width="1.27" layer="21"/>
<wire x1="-6.223" y1="-6.35" x2="-3.937" y2="-6.35" width="1.27" layer="21"/>
<wire x1="-2.54" y1="-5.715" x2="-2.54" y2="-0.762" width="1.27" layer="21"/>
<wire x1="-2.54" y1="0.762" x2="-2.54" y2="5.715" width="1.27" layer="21"/>
<wire x1="-6.223" y1="6.35" x2="-3.937" y2="6.35" width="1.27" layer="21"/>
<wire x1="-6.223" y1="0" x2="-3.937" y2="0" width="1.27" layer="21"/>
<wire x1="2.54" y1="5.715" x2="2.54" y2="0.762" width="1.27" layer="21"/>
<wire x1="2.54" y1="-0.762" x2="2.54" y2="-5.715" width="1.27" layer="21"/>
<wire x1="3.937" y1="-6.35" x2="6.223" y2="-6.35" width="1.27" layer="21"/>
<wire x1="7.62" y1="-5.715" x2="7.62" y2="-0.762" width="1.27" layer="21"/>
<wire x1="7.62" y1="0.762" x2="7.62" y2="5.715" width="1.27" layer="21"/>
<wire x1="3.937" y1="6.35" x2="6.223" y2="6.35" width="1.27" layer="21"/>
<wire x1="3.937" y1="0" x2="6.223" y2="0" width="1.27" layer="21"/>
<pad name="1" x="-24.13" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-21.59" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-19.05" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-16.51" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-13.97" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-11.43" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-8.89" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-6.35" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="-3.81" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="-1.27" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="1.27" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="3.81" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="6.35" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="8.89" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="11.43" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="13.97" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="16.51" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="19.05" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="21.59" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="24.13" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="24.13" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="21.59" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="19.05" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="16.51" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="13.97" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="11.43" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="8.89" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="6.35" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="29" x="3.81" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="30" x="1.27" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="31" x="-1.27" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="32" x="-3.81" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="33" x="-6.35" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="34" x="-8.89" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="35" x="-11.43" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="36" x="-13.97" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="37" x="-16.51" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="38" x="-19.05" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="39" x="-21.59" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="40" x="-24.13" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<text x="-23.241" y="-2.54" size="1.778" layer="21" ratio="10" rot="R90">LCD</text>
<text x="-25.4" y="17.78" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="24.638" y="-5.08" size="1.778" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-24.765" y1="-15.24" x2="-23.495" y2="-11.43" layer="21"/>
<rectangle x1="-22.225" y1="-15.24" x2="-20.955" y2="-11.43" layer="21"/>
<rectangle x1="-19.685" y1="-15.24" x2="-18.415" y2="-11.43" layer="21"/>
<rectangle x1="-17.145" y1="-15.24" x2="-15.875" y2="-11.43" layer="21"/>
<rectangle x1="-14.605" y1="-15.24" x2="-13.335" y2="-11.43" layer="21"/>
<rectangle x1="-12.065" y1="-15.24" x2="-10.795" y2="-11.43" layer="21"/>
<rectangle x1="-9.525" y1="-15.24" x2="-8.255" y2="-11.43" layer="21"/>
<rectangle x1="-6.985" y1="-15.24" x2="-5.715" y2="-11.43" layer="21"/>
<rectangle x1="-4.445" y1="-15.24" x2="-3.175" y2="-11.43" layer="21"/>
<rectangle x1="-1.905" y1="-15.24" x2="-0.635" y2="-11.43" layer="21"/>
<rectangle x1="0.635" y1="-15.24" x2="1.905" y2="-11.43" layer="21"/>
<rectangle x1="3.175" y1="-15.24" x2="4.445" y2="-11.43" layer="21"/>
<rectangle x1="5.715" y1="-15.24" x2="6.985" y2="-11.43" layer="21"/>
<rectangle x1="8.255" y1="-15.24" x2="9.525" y2="-11.43" layer="21"/>
<rectangle x1="10.795" y1="-15.24" x2="12.065" y2="-11.43" layer="21"/>
<rectangle x1="13.335" y1="-15.24" x2="14.605" y2="-11.43" layer="21"/>
<rectangle x1="15.875" y1="-15.24" x2="17.145" y2="-11.43" layer="21"/>
<rectangle x1="18.415" y1="-15.24" x2="19.685" y2="-11.43" layer="21"/>
<rectangle x1="20.955" y1="-15.24" x2="22.225" y2="-11.43" layer="21"/>
<rectangle x1="23.495" y1="-15.24" x2="24.765" y2="-11.43" layer="21"/>
<rectangle x1="23.495" y1="11.43" x2="24.765" y2="15.24" layer="21"/>
<rectangle x1="20.955" y1="11.43" x2="22.225" y2="15.24" layer="21"/>
<rectangle x1="18.415" y1="11.43" x2="19.685" y2="15.24" layer="21"/>
<rectangle x1="15.875" y1="11.43" x2="17.145" y2="15.24" layer="21"/>
<rectangle x1="13.335" y1="11.43" x2="14.605" y2="15.24" layer="21"/>
<rectangle x1="10.795" y1="11.43" x2="12.065" y2="15.24" layer="21"/>
<rectangle x1="8.255" y1="11.43" x2="9.525" y2="15.24" layer="21"/>
<rectangle x1="5.715" y1="11.43" x2="6.985" y2="15.24" layer="21"/>
<rectangle x1="3.175" y1="11.43" x2="4.445" y2="15.24" layer="21"/>
<rectangle x1="0.635" y1="11.43" x2="1.905" y2="15.24" layer="21"/>
<rectangle x1="-1.905" y1="11.43" x2="-0.635" y2="15.24" layer="21"/>
<rectangle x1="-4.445" y1="11.43" x2="-3.175" y2="15.24" layer="21"/>
<rectangle x1="-6.985" y1="11.43" x2="-5.715" y2="15.24" layer="21"/>
<rectangle x1="-9.525" y1="11.43" x2="-8.255" y2="15.24" layer="21"/>
<rectangle x1="-12.065" y1="11.43" x2="-10.795" y2="15.24" layer="21"/>
<rectangle x1="-14.605" y1="11.43" x2="-13.335" y2="15.24" layer="21"/>
<rectangle x1="-17.145" y1="11.43" x2="-15.875" y2="15.24" layer="21"/>
<rectangle x1="-19.685" y1="11.43" x2="-18.415" y2="15.24" layer="21"/>
<rectangle x1="-22.225" y1="11.43" x2="-20.955" y2="15.24" layer="21"/>
<rectangle x1="-24.765" y1="11.43" x2="-23.495" y2="15.24" layer="21"/>
<rectangle x1="-10.795" y1="-6.985" x2="-9.525" y2="-5.715" layer="21"/>
<rectangle x1="-0.635" y1="-6.985" x2="0.635" y2="-5.715" layer="21"/>
<rectangle x1="-0.635" y1="-3.175" x2="0.635" y2="-1.905" layer="21"/>
<rectangle x1="-0.635" y1="1.905" x2="0.635" y2="3.175" layer="21"/>
<rectangle x1="9.525" y1="-6.985" x2="10.795" y2="-5.715" layer="21"/>
</package>
<package name="H1331C">
3 1/2-character 7 segment</description>
<wire x1="-19.177" y1="5.08" x2="-17.907" y2="6.35" width="0.3048" layer="21"/>
<wire x1="-17.907" y1="6.35" x2="-17.907" y2="3.81" width="0.3048" layer="21"/>
<wire x1="-17.907" y1="3.81" x2="-19.177" y2="5.08" width="0.3048" layer="21"/>
<rectangle x1="-19.685" y1="-0.635" x2="-14.605" y2="0.635" layer="21"/>
<rectangle x1="-17.78" y1="1.27" x2="-16.51" y2="2.54" layer="21"/>
<rectangle x1="-17.78" y1="-2.54" x2="-16.51" y2="-1.27" layer="21"/>
<rectangle x1="-19.05" y1="4.953" x2="-18.542" y2="5.207" layer="21"/>
<rectangle x1="-18.923" y1="5.207" x2="-18.542" y2="5.334" layer="21"/>
<rectangle x1="-18.796" y1="5.334" x2="-18.542" y2="5.461" layer="21"/>
<rectangle x1="-18.669" y1="5.461" x2="-18.542" y2="5.588" layer="21"/>
<rectangle x1="-18.923" y1="4.826" x2="-18.542" y2="4.953" layer="21"/>
<rectangle x1="-18.796" y1="4.699" x2="-18.542" y2="4.826" layer="21"/>
<rectangle x1="-18.669" y1="4.572" x2="-18.542" y2="4.699" layer="21"/>
<rectangle x1="-18.415" y1="5.715" x2="-17.907" y2="5.969" layer="21"/>
<rectangle x1="-18.161" y1="5.969" x2="-17.907" y2="6.096" layer="21"/>
<rectangle x1="-18.415" y1="4.191" x2="-17.907" y2="4.445" layer="21"/>
<rectangle x1="-18.161" y1="4.064" x2="-17.907" y2="4.191" layer="21"/>
<rectangle x1="-18.542" y1="4.445" x2="-14.732" y2="5.715" layer="21"/>
</package>
<package name="H1335C">
6-character 7 segment</description>
<wire x1="-34.925" y1="-15.24" x2="34.925" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="34.925" y1="15.24" x2="-34.925" y2="15.24" width="0.1524" layer="21"/>
<wire x1="34.925" y1="-15.24" x2="34.925" y2="-11.43" width="0.1524" layer="21"/>
<wire x1="-34.925" y1="-11.43" x2="-34.925" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="34.925" y1="-11.43" x2="-34.925" y2="-11.43" width="0.1524" layer="21"/>
<wire x1="-34.925" y1="15.24" x2="-34.925" y2="11.43" width="0.1524" layer="21"/>
<wire x1="34.925" y1="-11.43" x2="34.925" y2="11.43" width="0.1524" layer="21"/>
<wire x1="-34.925" y1="11.43" x2="34.925" y2="11.43" width="0.1524" layer="21"/>
<wire x1="-34.925" y1="11.43" x2="-34.925" y2="-11.43" width="0.1524" layer="21"/>
<wire x1="34.925" y1="11.43" x2="34.925" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-30.48" y1="8.89" x2="-31.115" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-31.115" y1="8.255" x2="-31.115" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-31.115" y1="-8.255" x2="-30.48" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="-30.48" y1="-8.89" x2="30.48" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="30.48" y1="-8.89" x2="31.115" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="31.115" y1="-8.255" x2="31.115" y2="8.255" width="0.1524" layer="21"/>
<wire x1="31.115" y1="8.255" x2="30.48" y2="8.89" width="0.1524" layer="21"/>
<wire x1="30.48" y1="8.89" x2="-30.48" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-27.94" y1="5.715" x2="-27.94" y2="0.762" width="1.27" layer="21"/>
<wire x1="-27.94" y1="-0.762" x2="-27.94" y2="-5.715" width="1.27" layer="21"/>
<wire x1="-26.543" y1="-6.35" x2="-24.257" y2="-6.35" width="1.27" layer="21"/>
<wire x1="-22.86" y1="-5.715" x2="-22.86" y2="-0.762" width="1.27" layer="21"/>
<wire x1="-22.86" y1="0.762" x2="-22.86" y2="5.715" width="1.27" layer="21"/>
<wire x1="-26.543" y1="6.35" x2="-24.257" y2="6.35" width="1.27" layer="21"/>
<wire x1="-26.543" y1="0" x2="-24.257" y2="0" width="1.27" layer="21"/>
<wire x1="22.86" y1="5.715" x2="22.86" y2="0.762" width="1.27" layer="21"/>
<wire x1="22.86" y1="-0.762" x2="22.86" y2="-5.715" width="1.27" layer="21"/>
<wire x1="24.257" y1="-6.35" x2="26.543" y2="-6.35" width="1.27" layer="21"/>
<wire x1="27.94" y1="-5.715" x2="27.94" y2="-0.762" width="1.27" layer="21"/>
<wire x1="27.94" y1="0.762" x2="27.94" y2="5.715" width="1.27" layer="21"/>
<wire x1="24.257" y1="6.35" x2="26.543" y2="6.35" width="1.27" layer="21"/>
<wire x1="24.257" y1="0" x2="26.543" y2="0" width="1.27" layer="21"/>
<pad name="1" x="-30.48" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-27.94" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-25.4" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-22.86" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-20.32" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-17.78" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-15.24" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-12.7" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="10.16" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="12.7" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="15.24" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="17.78" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="20.32" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="22.86" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="25.4" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="27.94" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="30.48" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="30.48" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="27.94" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="25.4" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="29" x="22.86" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="30" x="20.32" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="31" x="17.78" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="32" x="15.24" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="33" x="12.7" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="34" x="10.16" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="43" x="-12.7" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="44" x="-15.24" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="45" x="-17.78" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="46" x="-20.32" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="47" x="-22.86" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="48" x="-25.4" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="49" x="-27.94" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="50" x="-30.48" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="-10.16" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="-7.62" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="-5.08" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="-2.54" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="0" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="2.54" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="5.08" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="7.62" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="35" x="7.62" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="36" x="5.08" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="37" x="2.54" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="38" x="0" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="39" x="-2.54" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="40" x="-5.08" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="41" x="-7.62" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="42" x="-10.16" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<text x="-32.131" y="-2.54" size="1.778" layer="21" ratio="10" rot="R90">LCD</text>
<text x="-31.75" y="17.78" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="34.163" y="-5.08" size="1.778" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="-26.035" y="-8.509" size="1.27" layer="21" ratio="10">6</text>
<text x="-15.875" y="-8.509" size="1.27" layer="21" ratio="10">5</text>
<text x="-5.715" y="-8.509" size="1.27" layer="21" ratio="10">4</text>
<text x="4.445" y="-8.509" size="1.27" layer="21" ratio="10">3</text>
<text x="14.605" y="-8.509" size="1.27" layer="21" ratio="10">2</text>
<text x="25.4" y="-8.509" size="1.27" layer="21" ratio="10">1 </text>
<rectangle x1="-31.115" y1="-15.24" x2="-29.845" y2="-11.43" layer="21"/>
<rectangle x1="-28.575" y1="-15.24" x2="-27.305" y2="-11.43" layer="21"/>
<rectangle x1="-26.035" y1="-15.24" x2="-24.765" y2="-11.43" layer="21"/>
<rectangle x1="-23.495" y1="-15.24" x2="-22.225" y2="-11.43" layer="21"/>
<rectangle x1="-20.955" y1="-15.24" x2="-19.685" y2="-11.43" layer="21"/>
<rectangle x1="-18.415" y1="-15.24" x2="-17.145" y2="-11.43" layer="21"/>
<rectangle x1="-15.875" y1="-15.24" x2="-14.605" y2="-11.43" layer="21"/>
<rectangle x1="-13.335" y1="-15.24" x2="-12.065" y2="-11.43" layer="21"/>
<rectangle x1="9.525" y1="-15.24" x2="10.795" y2="-11.43" layer="21"/>
<rectangle x1="12.065" y1="-15.24" x2="13.335" y2="-11.43" layer="21"/>
<rectangle x1="14.605" y1="-15.24" x2="15.875" y2="-11.43" layer="21"/>
<rectangle x1="17.145" y1="-15.24" x2="18.415" y2="-11.43" layer="21"/>
<rectangle x1="19.685" y1="-15.24" x2="20.955" y2="-11.43" layer="21"/>
<rectangle x1="22.225" y1="-15.24" x2="23.495" y2="-11.43" layer="21"/>
<rectangle x1="24.765" y1="-15.24" x2="26.035" y2="-11.43" layer="21"/>
<rectangle x1="27.305" y1="-15.24" x2="28.575" y2="-11.43" layer="21"/>
<rectangle x1="29.845" y1="-15.24" x2="31.115" y2="-11.43" layer="21"/>
<rectangle x1="29.845" y1="11.43" x2="31.115" y2="15.24" layer="21"/>
<rectangle x1="27.305" y1="11.43" x2="28.575" y2="15.24" layer="21"/>
<rectangle x1="24.765" y1="11.43" x2="26.035" y2="15.24" layer="21"/>
<rectangle x1="22.225" y1="11.43" x2="23.495" y2="15.24" layer="21"/>
<rectangle x1="19.685" y1="11.43" x2="20.955" y2="15.24" layer="21"/>
<rectangle x1="17.145" y1="11.43" x2="18.415" y2="15.24" layer="21"/>
<rectangle x1="14.605" y1="11.43" x2="15.875" y2="15.24" layer="21"/>
<rectangle x1="12.065" y1="11.43" x2="13.335" y2="15.24" layer="21"/>
<rectangle x1="9.525" y1="11.43" x2="10.795" y2="15.24" layer="21"/>
<rectangle x1="-13.335" y1="11.43" x2="-12.065" y2="15.24" layer="21"/>
<rectangle x1="-15.875" y1="11.43" x2="-14.605" y2="15.24" layer="21"/>
<rectangle x1="-18.415" y1="11.43" x2="-17.145" y2="15.24" layer="21"/>
<rectangle x1="-20.955" y1="11.43" x2="-19.685" y2="15.24" layer="21"/>
<rectangle x1="-23.495" y1="11.43" x2="-22.225" y2="15.24" layer="21"/>
<rectangle x1="-26.035" y1="11.43" x2="-24.765" y2="15.24" layer="21"/>
<rectangle x1="-28.575" y1="11.43" x2="-27.305" y2="15.24" layer="21"/>
<rectangle x1="-31.115" y1="11.43" x2="-29.845" y2="15.24" layer="21"/>
<rectangle x1="-20.955" y1="-6.985" x2="-19.685" y2="-5.715" layer="21"/>
<rectangle x1="9.525" y1="-3.175" x2="10.795" y2="-1.905" layer="21"/>
<rectangle x1="9.525" y1="1.905" x2="10.795" y2="3.175" layer="21"/>
<rectangle x1="19.685" y1="-6.985" x2="20.955" y2="-5.715" layer="21"/>
<rectangle x1="-10.795" y1="-15.24" x2="-9.525" y2="-11.43" layer="21"/>
<rectangle x1="-8.255" y1="-15.24" x2="-6.985" y2="-11.43" layer="21"/>
<rectangle x1="-5.715" y1="-15.24" x2="-4.445" y2="-11.43" layer="21"/>
<rectangle x1="-3.175" y1="-15.24" x2="-1.905" y2="-11.43" layer="21"/>
<rectangle x1="-0.635" y1="-15.24" x2="0.635" y2="-11.43" layer="21"/>
<rectangle x1="1.905" y1="-15.24" x2="3.175" y2="-11.43" layer="21"/>
<rectangle x1="4.445" y1="-15.24" x2="5.715" y2="-11.43" layer="21"/>
<rectangle x1="6.985" y1="-15.24" x2="8.255" y2="-11.43" layer="21"/>
<rectangle x1="6.985" y1="11.43" x2="8.255" y2="15.24" layer="21"/>
<rectangle x1="4.445" y1="11.43" x2="5.715" y2="15.24" layer="21"/>
<rectangle x1="1.905" y1="11.43" x2="3.175" y2="15.24" layer="21"/>
<rectangle x1="-0.635" y1="11.43" x2="0.635" y2="15.24" layer="21"/>
<rectangle x1="-3.175" y1="11.43" x2="-1.905" y2="15.24" layer="21"/>
<rectangle x1="-5.715" y1="11.43" x2="-4.445" y2="15.24" layer="21"/>
<rectangle x1="-8.255" y1="11.43" x2="-6.985" y2="15.24" layer="21"/>
<rectangle x1="-10.795" y1="11.43" x2="-9.525" y2="15.24" layer="21"/>
<rectangle x1="-10.795" y1="-3.175" x2="-9.525" y2="-1.905" layer="21"/>
<rectangle x1="-10.795" y1="1.905" x2="-9.525" y2="3.175" layer="21"/>
</package>
<package name="LS021C">
<wire x1="-25.4" y1="-11.176" x2="25.4" y2="-11.176" width="0.1524" layer="21"/>
<wire x1="25.4" y1="11.176" x2="-25.4" y2="11.176" width="0.1524" layer="21"/>
<wire x1="25.4" y1="-11.176" x2="25.4" y2="-8.636" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="-8.636" x2="-25.4" y2="-11.176" width="0.1524" layer="21"/>
<wire x1="25.4" y1="-8.636" x2="-25.4" y2="-8.636" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="11.176" x2="-25.4" y2="8.636" width="0.1524" layer="21"/>
<wire x1="25.4" y1="-8.636" x2="25.4" y2="8.636" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="8.636" x2="25.4" y2="8.636" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="8.636" x2="-25.4" y2="-8.636" width="0.1524" layer="21"/>
<wire x1="25.4" y1="8.636" x2="25.4" y2="11.176" width="0.1524" layer="21"/>
<wire x1="-20.955" y1="6.985" x2="-21.59" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="6.35" x2="-21.59" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-6.35" x2="-20.955" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="-20.955" y1="-6.985" x2="20.955" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="20.955" y1="-6.985" x2="21.59" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="21.59" y1="-6.35" x2="21.59" y2="6.35" width="0.1524" layer="21"/>
<wire x1="21.59" y1="6.35" x2="20.955" y2="6.985" width="0.1524" layer="21"/>
<wire x1="20.955" y1="6.985" x2="-20.955" y2="6.985" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="-3.81" x2="-12.7" y2="-0.762" width="1.27" layer="21"/>
<wire x1="-12.7" y1="0.762" x2="-12.7" y2="3.81" width="1.27" layer="21"/>
<wire x1="12.7" y1="3.81" x2="12.7" y2="0.762" width="1.27" layer="21"/>
<wire x1="12.7" y1="-0.762" x2="12.7" y2="-3.81" width="1.27" layer="21"/>
<wire x1="14.097" y1="-4.445" x2="16.383" y2="-4.445" width="1.27" layer="21"/>
<wire x1="17.78" y1="-3.81" x2="17.78" y2="-0.762" width="1.27" layer="21"/>
<wire x1="17.78" y1="0.762" x2="17.78" y2="3.81" width="1.27" layer="21"/>
<wire x1="14.097" y1="4.445" x2="16.383" y2="4.445" width="1.27" layer="21"/>
<wire x1="-7.62" y1="3.81" x2="-7.62" y2="0.762" width="1.27" layer="21"/>
<wire x1="-7.62" y1="-0.762" x2="-7.62" y2="-3.81" width="1.27" layer="21"/>
<wire x1="-6.223" y1="-4.445" x2="-3.937" y2="-4.445" width="1.27" layer="21"/>
<wire x1="-2.54" y1="-3.81" x2="-2.54" y2="-0.762" width="1.27" layer="21"/>
<wire x1="-2.54" y1="0.762" x2="-2.54" y2="3.81" width="1.27" layer="21"/>
<wire x1="-6.223" y1="4.445" x2="-3.937" y2="4.445" width="1.27" layer="21"/>
<wire x1="2.54" y1="3.81" x2="2.54" y2="0.762" width="1.27" layer="21"/>
<wire x1="2.54" y1="-0.762" x2="2.54" y2="-3.81" width="1.27" layer="21"/>
<wire x1="3.937" y1="-4.445" x2="6.223" y2="-4.445" width="1.27" layer="21"/>
<wire x1="7.62" y1="-3.81" x2="7.62" y2="-0.762" width="1.27" layer="21"/>
<wire x1="7.62" y1="0.762" x2="7.62" y2="3.81" width="1.27" layer="21"/>
<wire x1="3.937" y1="4.445" x2="6.223" y2="4.445" width="1.27" layer="21"/>
<wire x1="-19.939" y1="3.683" x2="-18.669" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-18.669" y1="4.953" x2="-18.669" y2="2.413" width="0.3048" layer="21"/>
<wire x1="-18.669" y1="2.413" x2="-19.939" y2="3.683" width="0.3048" layer="21"/>
<pad name="1" x="-24.13" y="-12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-21.59" y="-12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-19.05" y="-12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-16.51" y="-12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-13.97" y="-12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-11.43" y="-12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-8.89" y="-12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-6.35" y="-12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="-3.81" y="-12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="-1.27" y="-12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="1.27" y="-12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="3.81" y="-12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="6.35" y="-12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="8.89" y="-12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="11.43" y="-12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="13.97" y="-12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="16.51" y="-12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="19.05" y="-12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="21.59" y="-12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="24.13" y="-12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="24.13" y="12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="21.59" y="12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="19.05" y="12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="16.51" y="12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="13.97" y="12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="11.43" y="12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="8.89" y="12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="6.35" y="12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="29" x="3.81" y="12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="30" x="1.27" y="12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="31" x="-1.27" y="12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="32" x="-3.81" y="12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="33" x="-6.35" y="12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="34" x="-8.89" y="12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="35" x="-11.43" y="12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="36" x="-13.97" y="12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="37" x="-16.51" y="12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="38" x="-19.05" y="12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="39" x="-21.59" y="12.446" drill="0.8128" shape="long" rot="R90"/>
<pad name="40" x="-24.13" y="12.446" drill="0.8128" shape="long" rot="R90"/>
<text x="-25.4" y="13.716" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-10.795" y1="-5.08" x2="-9.525" y2="-3.81" layer="21"/>
<rectangle x1="-0.635" y1="-5.08" x2="0.635" y2="-3.81" layer="21"/>
<rectangle x1="-0.635" y1="-2.413" x2="0.635" y2="-1.143" layer="21"/>
<rectangle x1="-0.635" y1="1.143" x2="0.635" y2="2.413" layer="21"/>
<rectangle x1="9.525" y1="-5.08" x2="10.795" y2="-3.81" layer="21"/>
<rectangle x1="-19.812" y1="3.556" x2="-19.304" y2="3.81" layer="21"/>
<rectangle x1="-19.685" y1="3.81" x2="-19.304" y2="3.937" layer="21"/>
<rectangle x1="-19.558" y1="3.937" x2="-19.304" y2="4.064" layer="21"/>
<rectangle x1="-19.431" y1="4.064" x2="-19.304" y2="4.191" layer="21"/>
<rectangle x1="-19.685" y1="3.429" x2="-19.304" y2="3.556" layer="21"/>
<rectangle x1="-19.558" y1="3.302" x2="-19.304" y2="3.429" layer="21"/>
<rectangle x1="-19.431" y1="3.175" x2="-19.304" y2="3.302" layer="21"/>
<rectangle x1="-19.177" y1="4.318" x2="-18.669" y2="4.572" layer="21"/>
<rectangle x1="-18.923" y1="4.572" x2="-18.669" y2="4.699" layer="21"/>
<rectangle x1="-19.177" y1="2.794" x2="-18.669" y2="3.048" layer="21"/>
<rectangle x1="-18.923" y1="2.667" x2="-18.669" y2="2.794" layer="21"/>
<rectangle x1="-19.304" y1="3.048" x2="-15.494" y2="4.318" layer="21"/>
<rectangle x1="-24.765" y1="-11.176" x2="-23.495" y2="-8.636" layer="21"/>
<rectangle x1="-22.225" y1="-11.176" x2="-20.955" y2="-8.636" layer="21"/>
<rectangle x1="-19.685" y1="-11.176" x2="-18.415" y2="-8.636" layer="21"/>
<rectangle x1="-17.145" y1="-11.176" x2="-15.875" y2="-8.636" layer="21"/>
<rectangle x1="-14.605" y1="-11.176" x2="-13.335" y2="-8.636" layer="21"/>
<rectangle x1="-12.065" y1="-11.176" x2="-10.795" y2="-8.636" layer="21"/>
<rectangle x1="-9.525" y1="-11.176" x2="-8.255" y2="-8.636" layer="21"/>
<rectangle x1="-6.985" y1="-11.176" x2="-5.715" y2="-8.636" layer="21"/>
<rectangle x1="-4.445" y1="-11.176" x2="-3.175" y2="-8.636" layer="21"/>
<rectangle x1="-1.905" y1="-11.176" x2="-0.635" y2="-8.636" layer="21"/>
<rectangle x1="0.635" y1="-11.176" x2="1.905" y2="-8.636" layer="21"/>
<rectangle x1="3.175" y1="-11.176" x2="4.445" y2="-8.636" layer="21"/>
<rectangle x1="5.715" y1="-11.176" x2="6.985" y2="-8.636" layer="21"/>
<rectangle x1="8.255" y1="-11.176" x2="9.525" y2="-8.636" layer="21"/>
<rectangle x1="10.795" y1="-11.176" x2="12.065" y2="-8.636" layer="21"/>
<rectangle x1="13.335" y1="-11.176" x2="14.605" y2="-8.636" layer="21"/>
<rectangle x1="15.875" y1="-11.176" x2="17.145" y2="-8.636" layer="21"/>
<rectangle x1="18.415" y1="-11.176" x2="19.685" y2="-8.636" layer="21"/>
<rectangle x1="20.955" y1="-11.176" x2="22.225" y2="-8.636" layer="21"/>
<rectangle x1="23.495" y1="-11.176" x2="24.765" y2="-8.636" layer="21"/>
<rectangle x1="23.495" y1="8.636" x2="24.765" y2="11.176" layer="21"/>
<rectangle x1="20.955" y1="8.636" x2="22.225" y2="11.176" layer="21"/>
<rectangle x1="18.415" y1="8.636" x2="19.685" y2="11.176" layer="21"/>
<rectangle x1="15.875" y1="8.636" x2="17.145" y2="11.176" layer="21"/>
<rectangle x1="13.335" y1="8.636" x2="14.605" y2="11.176" layer="21"/>
<rectangle x1="10.795" y1="8.636" x2="12.065" y2="11.176" layer="21"/>
<rectangle x1="8.255" y1="8.636" x2="9.525" y2="11.176" layer="21"/>
<rectangle x1="5.715" y1="8.636" x2="6.985" y2="11.176" layer="21"/>
<rectangle x1="3.175" y1="8.636" x2="4.445" y2="11.176" layer="21"/>
<rectangle x1="0.635" y1="8.636" x2="1.905" y2="11.176" layer="21"/>
<rectangle x1="-1.905" y1="8.636" x2="-0.635" y2="11.176" layer="21"/>
<rectangle x1="-4.445" y1="8.636" x2="-3.175" y2="11.176" layer="21"/>
<rectangle x1="-6.985" y1="8.636" x2="-5.715" y2="11.176" layer="21"/>
<rectangle x1="-9.525" y1="8.636" x2="-8.255" y2="11.176" layer="21"/>
<rectangle x1="-12.065" y1="8.636" x2="-10.795" y2="11.176" layer="21"/>
<rectangle x1="-14.605" y1="8.636" x2="-13.335" y2="11.176" layer="21"/>
<rectangle x1="-17.145" y1="8.636" x2="-15.875" y2="11.176" layer="21"/>
<rectangle x1="-19.685" y1="8.636" x2="-18.415" y2="11.176" layer="21"/>
<rectangle x1="-22.225" y1="8.636" x2="-20.955" y2="11.176" layer="21"/>
<rectangle x1="-24.765" y1="8.636" x2="-23.495" y2="11.176" layer="21"/>
</package>
<package name="LS022C">
<wire x1="-16.383" y1="4.445" x2="-14.097" y2="4.445" width="1.27" layer="21"/>
<wire x1="-16.383" y1="-4.445" x2="-14.097" y2="-4.445" width="1.27" layer="21"/>
<wire x1="-17.78" y1="-0.762" x2="-17.78" y2="-3.81" width="1.27" layer="21"/>
<wire x1="-17.78" y1="3.81" x2="-17.78" y2="0.762" width="1.27" layer="21"/>
</package>
<package name="LS023C">
4 1/2-character 7 segment</description>
<wire x1="-23.495" y1="6.985" x2="-24.13" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-24.13" y1="6.35" x2="-24.13" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-24.13" y1="-6.35" x2="-23.495" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="-23.495" y1="-6.985" x2="23.495" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="23.495" y1="-6.985" x2="24.13" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="24.13" y1="-6.35" x2="24.13" y2="6.35" width="0.1524" layer="21"/>
<wire x1="24.13" y1="6.35" x2="23.495" y2="6.985" width="0.1524" layer="21"/>
<wire x1="23.495" y1="6.985" x2="-23.495" y2="6.985" width="0.1524" layer="21"/>
<wire x1="-15.494" y1="-3.81" x2="-15.494" y2="-0.762" width="1.27" layer="21"/>
<wire x1="-15.494" y1="0.762" x2="-15.494" y2="3.81" width="1.27" layer="21"/>
<wire x1="16.764" y1="3.81" x2="16.764" y2="0.762" width="1.27" layer="21"/>
<wire x1="16.764" y1="-0.762" x2="16.764" y2="-3.81" width="1.27" layer="21"/>
<wire x1="18.161" y1="-4.445" x2="20.447" y2="-4.445" width="1.27" layer="21"/>
<wire x1="21.844" y1="-3.81" x2="21.844" y2="-0.762" width="1.27" layer="21"/>
<wire x1="21.844" y1="0.762" x2="21.844" y2="3.81" width="1.27" layer="21"/>
<wire x1="18.161" y1="4.445" x2="20.447" y2="4.445" width="1.27" layer="21"/>
<wire x1="18.161" y1="0" x2="20.447" y2="0" width="1.27" layer="21"/>
<wire x1="-1.778" y1="3.81" x2="-1.778" y2="0.762" width="1.27" layer="21"/>
<wire x1="-1.778" y1="-0.762" x2="-1.778" y2="-3.81" width="1.27" layer="21"/>
<wire x1="-0.381" y1="-4.445" x2="1.905" y2="-4.445" width="1.27" layer="21"/>
<wire x1="3.302" y1="-3.81" x2="3.302" y2="-0.762" width="1.27" layer="21"/>
<wire x1="3.302" y1="0.762" x2="3.302" y2="3.81" width="1.27" layer="21"/>
<wire x1="-0.381" y1="4.445" x2="1.905" y2="4.445" width="1.27" layer="21"/>
<wire x1="-0.381" y1="0" x2="1.905" y2="0" width="1.27" layer="21"/>
<wire x1="7.62" y1="3.81" x2="7.62" y2="0.762" width="1.27" layer="21"/>
<wire x1="7.62" y1="-0.762" x2="7.62" y2="-3.81" width="1.27" layer="21"/>
<wire x1="9.017" y1="-4.445" x2="11.303" y2="-4.445" width="1.27" layer="21"/>
<wire x1="12.7" y1="-3.81" x2="12.7" y2="-0.762" width="1.27" layer="21"/>
<wire x1="12.7" y1="0.762" x2="12.7" y2="3.81" width="1.27" layer="21"/>
<wire x1="9.017" y1="4.445" x2="11.303" y2="4.445" width="1.27" layer="21"/>
<wire x1="9.017" y1="0" x2="11.303" y2="0" width="1.27" layer="21"/>
<wire x1="-22.733" y1="3.683" x2="-21.463" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-21.463" y1="4.953" x2="-21.463" y2="2.413" width="0.3048" layer="21"/>
<wire x1="-21.463" y1="2.413" x2="-22.733" y2="3.683" width="0.3048" layer="21"/>
<wire x1="-11.176" y1="3.81" x2="-11.176" y2="0.762" width="1.27" layer="21"/>
<wire x1="-11.176" y1="-0.762" x2="-11.176" y2="-3.81" width="1.27" layer="21"/>
<wire x1="-9.779" y1="-4.445" x2="-7.493" y2="-4.445" width="1.27" layer="21"/>
<wire x1="-6.096" y1="-3.81" x2="-6.096" y2="-0.762" width="1.27" layer="21"/>
<wire x1="-6.096" y1="0.762" x2="-6.096" y2="3.81" width="1.27" layer="21"/>
<wire x1="-9.779" y1="4.445" x2="-7.493" y2="4.445" width="1.27" layer="21"/>
<wire x1="-9.779" y1="0" x2="-7.493" y2="0" width="1.27" layer="21"/>
<text x="-25.527" y="-15.875" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-22.479" y1="-0.635" x2="-17.399" y2="0.635" layer="21"/>
<rectangle x1="-20.574" y1="1.27" x2="-19.304" y2="2.54" layer="21"/>
<rectangle x1="-20.574" y1="-2.54" x2="-19.304" y2="-1.27" layer="21"/>
<rectangle x1="-13.97" y1="-5.08" x2="-12.7" y2="-3.81" layer="21"/>
<rectangle x1="4.826" y1="-5.08" x2="6.096" y2="-3.81" layer="21"/>
<rectangle x1="4.826" y1="-2.413" x2="6.096" y2="-1.143" layer="21"/>
<rectangle x1="4.826" y1="1.143" x2="6.096" y2="2.413" layer="21"/>
<rectangle x1="14.097" y1="-5.08" x2="15.367" y2="-3.81" layer="21"/>
<rectangle x1="-22.606" y1="3.556" x2="-22.098" y2="3.81" layer="21"/>
<rectangle x1="-22.479" y1="3.81" x2="-22.098" y2="3.937" layer="21"/>
<rectangle x1="-22.352" y1="3.937" x2="-22.098" y2="4.064" layer="21"/>
<rectangle x1="-22.225" y1="4.064" x2="-22.098" y2="4.191" layer="21"/>
<rectangle x1="-22.479" y1="3.429" x2="-22.098" y2="3.556" layer="21"/>
<rectangle x1="-22.352" y1="3.302" x2="-22.098" y2="3.429" layer="21"/>
<rectangle x1="-22.225" y1="3.175" x2="-22.098" y2="3.302" layer="21"/>
<rectangle x1="-21.971" y1="4.318" x2="-21.463" y2="4.572" layer="21"/>
<rectangle x1="-21.717" y1="4.572" x2="-21.463" y2="4.699" layer="21"/>
<rectangle x1="-21.971" y1="2.794" x2="-21.463" y2="3.048" layer="21"/>
<rectangle x1="-21.717" y1="2.667" x2="-21.463" y2="2.794" layer="21"/>
<rectangle x1="-22.098" y1="3.048" x2="-18.288" y2="4.318" layer="21"/>
<rectangle x1="-4.572" y1="-5.08" x2="-3.302" y2="-3.81" layer="21"/>
<rectangle x1="-4.572" y1="-2.413" x2="-3.302" y2="-1.143" layer="21"/>
<rectangle x1="-4.572" y1="1.143" x2="-3.302" y2="2.413" layer="21"/>
</package>
<package name="LS024C">
5-character 7 segment</description>
<wire x1="-22.225" y1="8.89" x2="-22.86" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="8.255" x2="-22.86" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-8.255" x2="-22.225" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="-22.225" y1="-8.89" x2="22.225" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="22.225" y1="-8.89" x2="22.86" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="22.86" y1="-8.255" x2="22.86" y2="8.255" width="0.1524" layer="21"/>
<wire x1="22.86" y1="8.255" x2="22.225" y2="8.89" width="0.1524" layer="21"/>
<wire x1="22.225" y1="8.89" x2="-22.225" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-11.684" y1="3.81" x2="-11.684" y2="0.762" width="1.27" layer="21"/>
<wire x1="-11.684" y1="-0.762" x2="-11.684" y2="-3.81" width="1.27" layer="21"/>
<wire x1="-10.287" y1="-4.445" x2="-8.001" y2="-4.445" width="1.27" layer="21"/>
<wire x1="-6.604" y1="-3.81" x2="-6.604" y2="-0.762" width="1.27" layer="21"/>
<wire x1="-6.604" y1="0.762" x2="-6.604" y2="3.81" width="1.27" layer="21"/>
<wire x1="-10.287" y1="4.445" x2="-8.001" y2="4.445" width="1.27" layer="21"/>
<wire x1="-10.287" y1="0" x2="-8.001" y2="0" width="1.27" layer="21"/>
<wire x1="16.002" y1="3.81" x2="16.002" y2="0.762" width="1.27" layer="21"/>
<wire x1="16.002" y1="-0.762" x2="16.002" y2="-3.81" width="1.27" layer="21"/>
<wire x1="17.399" y1="-4.445" x2="19.177" y2="-4.445" width="1.27" layer="21"/>
<wire x1="20.574" y1="-3.81" x2="20.574" y2="-0.762" width="1.27" layer="21"/>
<wire x1="20.574" y1="0.762" x2="20.574" y2="3.81" width="1.27" layer="21"/>
<wire x1="17.399" y1="4.445" x2="19.177" y2="4.445" width="1.27" layer="21"/>
<wire x1="17.399" y1="0" x2="19.177" y2="0" width="1.27" layer="21"/>
<wire x1="-2.286" y1="3.81" x2="-2.286" y2="0.762" width="1.27" layer="21"/>
<wire x1="-2.286" y1="-0.762" x2="-2.286" y2="-3.81" width="1.27" layer="21"/>
<wire x1="-0.889" y1="-4.445" x2="1.397" y2="-4.445" width="1.27" layer="21"/>
<wire x1="2.794" y1="-3.81" x2="2.794" y2="-0.762" width="1.27" layer="21"/>
<wire x1="2.794" y1="0.762" x2="2.794" y2="3.81" width="1.27" layer="21"/>
<wire x1="-0.889" y1="4.445" x2="1.397" y2="4.445" width="1.27" layer="21"/>
<wire x1="-0.889" y1="0" x2="1.397" y2="0" width="1.27" layer="21"/>
<wire x1="7.112" y1="3.81" x2="7.112" y2="0.762" width="1.27" layer="21"/>
<wire x1="7.112" y1="-0.762" x2="7.112" y2="-3.81" width="1.27" layer="21"/>
<wire x1="8.509" y1="-4.445" x2="10.287" y2="-4.445" width="1.27" layer="21"/>
<wire x1="11.684" y1="-3.81" x2="11.684" y2="-0.762" width="1.27" layer="21"/>
<wire x1="11.684" y1="0.762" x2="11.684" y2="3.81" width="1.27" layer="21"/>
<wire x1="8.509" y1="4.445" x2="10.287" y2="4.445" width="1.27" layer="21"/>
<wire x1="8.509" y1="0" x2="10.287" y2="0" width="1.27" layer="21"/>
<wire x1="-20.574" y1="3.81" x2="-20.574" y2="0.762" width="1.27" layer="21"/>
<wire x1="-20.574" y1="-0.762" x2="-20.574" y2="-3.81" width="1.27" layer="21"/>
<wire x1="-19.177" y1="-4.445" x2="-17.399" y2="-4.445" width="1.27" layer="21"/>
<wire x1="-16.002" y1="-3.81" x2="-16.002" y2="-0.762" width="1.27" layer="21"/>
<wire x1="-16.002" y1="0.762" x2="-16.002" y2="3.81" width="1.27" layer="21"/>
<wire x1="-19.177" y1="4.445" x2="-17.399" y2="4.445" width="1.27" layer="21"/>
<wire x1="-19.177" y1="0" x2="-17.399" y2="0" width="1.27" layer="21"/>
<text x="-20.828" y="-7.62" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="4.318" y1="-5.08" x2="5.588" y2="-3.81" layer="21"/>
<rectangle x1="-5.08" y1="-3.048" x2="-3.81" y2="-1.778" layer="21"/>
<rectangle x1="-5.08" y1="1.905" x2="-3.81" y2="3.175" layer="21"/>
<rectangle x1="13.208" y1="-5.08" x2="14.478" y2="-3.81" layer="21"/>
<rectangle x1="-14.478" y1="-3.048" x2="-13.208" y2="-1.778" layer="21"/>
<rectangle x1="-14.478" y1="1.905" x2="-13.208" y2="3.175" layer="21"/>
</package>
<package name="LS026C">
8-character 7 segment</description>
<wire x1="-46.228" y1="-15.24" x2="47.625" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="47.625" y1="15.24" x2="-46.228" y2="15.24" width="0.1524" layer="21"/>
<wire x1="47.625" y1="-15.24" x2="47.625" y2="-11.43" width="0.1524" layer="21"/>
<wire x1="-46.228" y1="-11.43" x2="-46.228" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="47.625" y1="-11.43" x2="-46.228" y2="-11.43" width="0.1524" layer="21"/>
<wire x1="-46.228" y1="15.24" x2="-46.228" y2="11.43" width="0.1524" layer="21"/>
<wire x1="47.625" y1="-11.43" x2="47.625" y2="11.43" width="0.1524" layer="21"/>
<wire x1="-46.228" y1="11.43" x2="47.625" y2="11.43" width="0.1524" layer="21"/>
<wire x1="-46.228" y1="11.43" x2="-46.228" y2="-11.43" width="0.1524" layer="21"/>
<wire x1="47.625" y1="11.43" x2="47.625" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-40.64" y1="8.89" x2="-41.275" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-41.275" y1="8.255" x2="-41.275" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-41.275" y1="-8.255" x2="-40.64" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="-40.64" y1="-8.89" x2="43.18" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="43.18" y1="-8.89" x2="43.815" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="43.815" y1="-8.255" x2="43.815" y2="8.255" width="0.1524" layer="21"/>
<wire x1="43.815" y1="8.255" x2="43.18" y2="8.89" width="0.1524" layer="21"/>
<wire x1="43.18" y1="8.89" x2="-40.64" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="5.715" x2="-16.51" y2="0.762" width="1.27" layer="21"/>
<wire x1="-16.51" y1="-0.762" x2="-16.51" y2="-5.715" width="1.27" layer="21"/>
<wire x1="-15.113" y1="-6.35" x2="-12.827" y2="-6.35" width="1.27" layer="21"/>
<wire x1="-11.43" y1="-5.715" x2="-11.43" y2="-0.762" width="1.27" layer="21"/>
<wire x1="-11.43" y1="0.762" x2="-11.43" y2="5.715" width="1.27" layer="21"/>
<wire x1="-15.113" y1="6.35" x2="-12.827" y2="6.35" width="1.27" layer="21"/>
<wire x1="-15.113" y1="0" x2="-12.827" y2="0" width="1.27" layer="21"/>
<wire x1="34.29" y1="5.715" x2="34.29" y2="0.762" width="1.27" layer="21"/>
<wire x1="34.29" y1="-0.762" x2="34.29" y2="-5.715" width="1.27" layer="21"/>
<wire x1="35.687" y1="-6.35" x2="37.973" y2="-6.35" width="1.27" layer="21"/>
<wire x1="39.37" y1="-5.715" x2="39.37" y2="-0.762" width="1.27" layer="21"/>
<wire x1="39.37" y1="0.762" x2="39.37" y2="5.715" width="1.27" layer="21"/>
<wire x1="35.687" y1="6.35" x2="37.973" y2="6.35" width="1.27" layer="21"/>
<wire x1="35.687" y1="0" x2="37.973" y2="0" width="1.27" layer="21"/>
<wire x1="-6.35" y1="5.715" x2="-6.35" y2="0.762" width="1.27" layer="21"/>
<wire x1="-6.35" y1="-0.762" x2="-6.35" y2="-5.715" width="1.27" layer="21"/>
<wire x1="-4.953" y1="-6.35" x2="-2.667" y2="-6.35" width="1.27" layer="21"/>
<wire x1="-1.27" y1="-5.715" x2="-1.27" y2="-0.762" width="1.27" layer="21"/>
<wire x1="-1.27" y1="0.762" x2="-1.27" y2="5.715" width="1.27" layer="21"/>
<wire x1="-4.953" y1="6.35" x2="-2.667" y2="6.35" width="1.27" layer="21"/>
<wire x1="-4.953" y1="0" x2="-2.667" y2="0" width="1.27" layer="21"/>
<wire x1="24.13" y1="5.715" x2="24.13" y2="0.762" width="1.27" layer="21"/>
<wire x1="24.13" y1="-0.762" x2="24.13" y2="-5.715" width="1.27" layer="21"/>
<wire x1="25.527" y1="-6.35" x2="27.813" y2="-6.35" width="1.27" layer="21"/>
<wire x1="29.21" y1="-5.715" x2="29.21" y2="-0.762" width="1.27" layer="21"/>
<wire x1="29.21" y1="0.762" x2="29.21" y2="5.715" width="1.27" layer="21"/>
<wire x1="25.527" y1="6.35" x2="27.813" y2="6.35" width="1.27" layer="21"/>
<wire x1="25.527" y1="0" x2="27.813" y2="0" width="1.27" layer="21"/>
<wire x1="13.97" y1="5.715" x2="13.97" y2="0.762" width="1.27" layer="21"/>
<wire x1="13.97" y1="-0.762" x2="13.97" y2="-5.715" width="1.27" layer="21"/>
<wire x1="15.367" y1="-6.35" x2="17.653" y2="-6.35" width="1.27" layer="21"/>
<wire x1="19.05" y1="-5.715" x2="19.05" y2="-0.762" width="1.27" layer="21"/>
<wire x1="19.05" y1="0.762" x2="19.05" y2="5.715" width="1.27" layer="21"/>
<wire x1="15.367" y1="6.35" x2="17.653" y2="6.35" width="1.27" layer="21"/>
<wire x1="15.367" y1="0" x2="17.653" y2="0" width="1.27" layer="21"/>
<wire x1="3.81" y1="5.715" x2="3.81" y2="0.762" width="1.27" layer="21"/>
<wire x1="3.81" y1="-0.762" x2="3.81" y2="-5.715" width="1.27" layer="21"/>
<wire x1="5.207" y1="-6.35" x2="7.493" y2="-6.35" width="1.27" layer="21"/>
<wire x1="8.89" y1="-5.715" x2="8.89" y2="-0.762" width="1.27" layer="21"/>
<wire x1="8.89" y1="0.762" x2="8.89" y2="5.715" width="1.27" layer="21"/>
<wire x1="5.207" y1="6.35" x2="7.493" y2="6.35" width="1.27" layer="21"/>
<wire x1="5.207" y1="0" x2="7.493" y2="0" width="1.27" layer="21"/>
<wire x1="-36.83" y1="5.715" x2="-36.83" y2="0.762" width="1.27" layer="21"/>
<wire x1="-36.83" y1="-0.762" x2="-36.83" y2="-5.715" width="1.27" layer="21"/>
<wire x1="-35.433" y1="-6.35" x2="-33.147" y2="-6.35" width="1.27" layer="21"/>
<wire x1="-31.75" y1="-5.715" x2="-31.75" y2="-0.762" width="1.27" layer="21"/>
<wire x1="-31.75" y1="0.762" x2="-31.75" y2="5.715" width="1.27" layer="21"/>
<wire x1="-35.433" y1="6.35" x2="-33.147" y2="6.35" width="1.27" layer="21"/>
<wire x1="-35.433" y1="0" x2="-33.147" y2="0" width="1.27" layer="21"/>
<wire x1="-26.67" y1="5.715" x2="-26.67" y2="0.762" width="1.27" layer="21"/>
<wire x1="-26.67" y1="-0.762" x2="-26.67" y2="-5.715" width="1.27" layer="21"/>
<wire x1="-25.273" y1="-6.35" x2="-22.987" y2="-6.35" width="1.27" layer="21"/>
<wire x1="-21.59" y1="-5.715" x2="-21.59" y2="-0.762" width="1.27" layer="21"/>
<wire x1="-21.59" y1="0.762" x2="-21.59" y2="5.715" width="1.27" layer="21"/>
<wire x1="-25.273" y1="6.35" x2="-22.987" y2="6.35" width="1.27" layer="21"/>
<wire x1="-25.273" y1="0" x2="-22.987" y2="0" width="1.27" layer="21"/>
<pad name="1" x="-39.37" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-36.83" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-34.29" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-31.75" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-29.21" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-26.67" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-24.13" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-21.59" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="1.27" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="3.81" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="6.35" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="8.89" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="11.43" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="13.97" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="16.51" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="19.05" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="21.59" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="24.13" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="26.67" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="29.21" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="29" x="31.75" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="30" x="34.29" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="31" x="36.83" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="32" x="39.37" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="33" x="41.91" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="34" x="44.45" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="43" x="24.13" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="44" x="21.59" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="45" x="19.05" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="46" x="16.51" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="47" x="13.97" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="48" x="11.43" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="49" x="8.89" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="50" x="6.35" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="-19.05" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="-16.51" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="-13.97" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="-11.43" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="-8.89" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="-6.35" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="-3.81" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="-1.27" y="-16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="35" x="44.45" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="36" x="41.91" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="37" x="39.37" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="38" x="36.83" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="39" x="34.29" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="40" x="31.75" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="41" x="29.21" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="42" x="26.67" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="51" x="3.81" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="52" x="1.27" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="53" x="-1.27" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="54" x="-3.81" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="55" x="-6.35" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="56" x="-8.89" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="57" x="-11.43" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="58" x="-13.97" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="59" x="-16.51" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="60" x="-19.05" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="61" x="-21.59" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="62" x="-24.13" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="63" x="-26.67" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="64" x="-29.21" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="65" x="-31.75" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="66" x="-34.29" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="67" x="-36.83" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<pad name="68" x="-39.37" y="16.51" drill="0.8128" shape="long" rot="R90"/>
<text x="-42.291" y="-2.54" size="1.778" layer="21" ratio="10" rot="R90">LCD</text>
<text x="-40.64" y="17.78" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="46.863" y="-5.08" size="1.778" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="-14.605" y="-8.509" size="1.27" layer="21" ratio="10">6</text>
<text x="-4.445" y="-8.509" size="1.27" layer="21" ratio="10">5</text>
<text x="5.715" y="-8.509" size="1.27" layer="21" ratio="10">4</text>
<text x="15.875" y="-8.509" size="1.27" layer="21" ratio="10">3</text>
<text x="26.035" y="-8.509" size="1.27" layer="21" ratio="10">2</text>
<text x="-24.765" y="-8.509" size="1.27" layer="21" ratio="10">7</text>
<text x="-34.925" y="-8.509" size="1.27" layer="21" ratio="10">8</text>
<text x="36.83" y="-8.509" size="1.27" layer="21" ratio="10">1 </text>
<rectangle x1="-40.005" y1="-15.24" x2="-38.735" y2="-11.43" layer="21"/>
<rectangle x1="-37.465" y1="-15.24" x2="-36.195" y2="-11.43" layer="21"/>
<rectangle x1="-34.925" y1="-15.24" x2="-33.655" y2="-11.43" layer="21"/>
<rectangle x1="-32.385" y1="-15.24" x2="-31.115" y2="-11.43" layer="21"/>
<rectangle x1="-29.845" y1="-15.24" x2="-28.575" y2="-11.43" layer="21"/>
<rectangle x1="-27.305" y1="-15.24" x2="-26.035" y2="-11.43" layer="21"/>
<rectangle x1="43.815" y1="-15.24" x2="45.085" y2="-11.43" layer="21"/>
<rectangle x1="41.275" y1="-15.24" x2="42.545" y2="-11.43" layer="21"/>
<rectangle x1="38.735" y1="-15.24" x2="40.005" y2="-11.43" layer="21"/>
<rectangle x1="36.195" y1="-15.24" x2="37.465" y2="-11.43" layer="21"/>
<rectangle x1="33.655" y1="-15.24" x2="34.925" y2="-11.43" layer="21"/>
<rectangle x1="31.115" y1="-15.24" x2="32.385" y2="-11.43" layer="21"/>
<rectangle x1="28.575" y1="-15.24" x2="29.845" y2="-11.43" layer="21"/>
<rectangle x1="26.035" y1="-15.24" x2="27.305" y2="-11.43" layer="21"/>
<rectangle x1="-9.525" y1="-6.985" x2="-8.255" y2="-5.715" layer="21"/>
<rectangle x1="20.955" y1="-6.985" x2="22.225" y2="-5.715" layer="21"/>
<rectangle x1="20.955" y1="-3.175" x2="22.225" y2="-1.905" layer="21"/>
<rectangle x1="20.955" y1="1.905" x2="22.225" y2="3.175" layer="21"/>
<rectangle x1="31.115" y1="-6.985" x2="32.385" y2="-5.715" layer="21"/>
<rectangle x1="43.815" y1="11.43" x2="45.085" y2="15.24" layer="21"/>
<rectangle x1="41.275" y1="11.43" x2="42.545" y2="15.24" layer="21"/>
<rectangle x1="38.735" y1="11.43" x2="40.005" y2="15.24" layer="21"/>
<rectangle x1="36.195" y1="11.43" x2="37.465" y2="15.24" layer="21"/>
<rectangle x1="33.655" y1="11.43" x2="34.925" y2="15.24" layer="21"/>
<rectangle x1="31.115" y1="11.43" x2="32.385" y2="15.24" layer="21"/>
<rectangle x1="28.575" y1="11.43" x2="29.845" y2="15.24" layer="21"/>
<rectangle x1="26.035" y1="11.43" x2="27.305" y2="15.24" layer="21"/>
<rectangle x1="0.635" y1="-6.985" x2="1.905" y2="-5.715" layer="21"/>
<rectangle x1="0.635" y1="-3.175" x2="1.905" y2="-1.905" layer="21"/>
<rectangle x1="0.635" y1="1.905" x2="1.905" y2="3.175" layer="21"/>
<rectangle x1="10.795" y1="-6.985" x2="12.065" y2="-5.715" layer="21"/>
<rectangle x1="-27.305" y1="11.43" x2="-26.035" y2="15.24" layer="21"/>
<rectangle x1="-29.845" y1="11.43" x2="-28.575" y2="15.24" layer="21"/>
<rectangle x1="-32.385" y1="11.43" x2="-31.115" y2="15.24" layer="21"/>
<rectangle x1="-34.925" y1="11.43" x2="-33.655" y2="15.24" layer="21"/>
<rectangle x1="-37.465" y1="11.43" x2="-36.195" y2="15.24" layer="21"/>
<rectangle x1="-40.005" y1="11.43" x2="-38.735" y2="15.24" layer="21"/>
<rectangle x1="-29.845" y1="-6.985" x2="-28.575" y2="-5.715" layer="21"/>
<rectangle x1="-19.685" y1="-6.985" x2="-18.415" y2="-5.715" layer="21"/>
<rectangle x1="-19.685" y1="-3.175" x2="-18.415" y2="-1.905" layer="21"/>
<rectangle x1="-19.685" y1="1.905" x2="-18.415" y2="3.175" layer="21"/>
</package>
<package name="H1332C">
<wire x1="-22.86" y1="8.89" x2="-23.495" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-23.495" y1="8.255" x2="-23.495" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-23.495" y1="-8.255" x2="-22.86" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-8.89" x2="22.86" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="22.86" y1="-8.89" x2="23.495" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="23.495" y1="-8.255" x2="23.495" y2="8.255" width="0.1524" layer="21"/>
<wire x1="23.495" y1="8.255" x2="22.86" y2="8.89" width="0.1524" layer="21"/>
<wire x1="22.86" y1="8.89" x2="-22.86" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-15.494" y1="-5.715" x2="-15.494" y2="-0.762" width="1.27" layer="21"/>
<wire x1="-15.494" y1="0.762" x2="-15.494" y2="6.35" width="1.27" layer="21"/>
<wire x1="16.764" y1="5.715" x2="16.764" y2="0.762" width="1.27" layer="21"/>
<wire x1="16.764" y1="-0.762" x2="16.764" y2="-5.715" width="1.27" layer="21"/>
<wire x1="18.161" y1="-6.35" x2="20.447" y2="-6.35" width="1.27" layer="21"/>
<wire x1="21.844" y1="-5.715" x2="21.844" y2="-0.762" width="1.27" layer="21"/>
<wire x1="21.844" y1="0.762" x2="21.844" y2="5.715" width="1.27" layer="21"/>
<wire x1="18.161" y1="6.35" x2="20.447" y2="6.35" width="1.27" layer="21"/>
<wire x1="-1.778" y1="5.715" x2="-1.778" y2="0.762" width="1.27" layer="21"/>
<wire x1="-1.778" y1="-0.762" x2="-1.778" y2="-5.715" width="1.27" layer="21"/>
<wire x1="-0.381" y1="-6.35" x2="1.905" y2="-6.35" width="1.27" layer="21"/>
<wire x1="3.302" y1="-5.715" x2="3.302" y2="-0.762" width="1.27" layer="21"/>
<wire x1="3.302" y1="0.762" x2="3.302" y2="5.715" width="1.27" layer="21"/>
<wire x1="-0.381" y1="6.35" x2="1.905" y2="6.35" width="1.27" layer="21"/>
<wire x1="7.62" y1="5.715" x2="7.62" y2="0.762" width="1.27" layer="21"/>
<wire x1="7.62" y1="-0.762" x2="7.62" y2="-5.715" width="1.27" layer="21"/>
<wire x1="9.017" y1="-6.35" x2="11.303" y2="-6.35" width="1.27" layer="21"/>
<wire x1="12.7" y1="-5.715" x2="12.7" y2="-0.762" width="1.27" layer="21"/>
<wire x1="12.7" y1="0.762" x2="12.7" y2="5.715" width="1.27" layer="21"/>
<wire x1="9.017" y1="6.35" x2="11.303" y2="6.35" width="1.27" layer="21"/>
<wire x1="-22.733" y1="5.08" x2="-21.463" y2="6.35" width="0.3048" layer="21"/>
<wire x1="-21.463" y1="6.35" x2="-21.463" y2="3.81" width="0.3048" layer="21"/>
<wire x1="-21.463" y1="3.81" x2="-22.733" y2="5.08" width="0.3048" layer="21"/>
<wire x1="-11.176" y1="5.715" x2="-11.176" y2="0.762" width="1.27" layer="21"/>
<wire x1="-11.176" y1="-0.762" x2="-11.176" y2="-5.715" width="1.27" layer="21"/>
<wire x1="-9.779" y1="-6.35" x2="-7.493" y2="-6.35" width="1.27" layer="21"/>
<wire x1="-6.096" y1="-5.715" x2="-6.096" y2="-0.762" width="1.27" layer="21"/>
<wire x1="-6.096" y1="0.762" x2="-6.096" y2="5.715" width="1.27" layer="21"/>
<wire x1="-9.779" y1="6.35" x2="-7.493" y2="6.35" width="1.27" layer="21"/>
<text x="-25.527" y="-19.685" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-13.97" y1="-6.35" x2="-12.7" y2="-5.08" layer="21"/>
<rectangle x1="4.826" y1="-6.35" x2="6.096" y2="-5.08" layer="21"/>
<rectangle x1="4.826" y1="-3.048" x2="6.096" y2="-1.778" layer="21"/>
<rectangle x1="14.097" y1="-6.35" x2="15.367" y2="-5.08" layer="21"/>
<rectangle x1="-22.606" y1="4.953" x2="-22.098" y2="5.207" layer="21"/>
<rectangle x1="-22.479" y1="5.207" x2="-22.098" y2="5.334" layer="21"/>
<rectangle x1="-22.352" y1="5.334" x2="-22.098" y2="5.461" layer="21"/>
<rectangle x1="-22.225" y1="5.461" x2="-22.098" y2="5.588" layer="21"/>
<rectangle x1="-22.479" y1="4.826" x2="-22.098" y2="4.953" layer="21"/>
<rectangle x1="-22.352" y1="4.699" x2="-22.098" y2="4.826" layer="21"/>
<rectangle x1="-22.225" y1="4.572" x2="-22.098" y2="4.699" layer="21"/>
<rectangle x1="-21.971" y1="5.715" x2="-21.463" y2="5.969" layer="21"/>
<rectangle x1="-21.717" y1="5.969" x2="-21.463" y2="6.096" layer="21"/>
<rectangle x1="-21.971" y1="4.191" x2="-21.463" y2="4.445" layer="21"/>
<rectangle x1="-21.717" y1="4.064" x2="-21.463" y2="4.191" layer="21"/>
<rectangle x1="-22.098" y1="4.445" x2="-18.288" y2="5.715" layer="21"/>
<rectangle x1="-4.572" y1="-6.35" x2="-3.302" y2="-5.08" layer="21"/>
<rectangle x1="-4.572" y1="-3.048" x2="-3.302" y2="-1.778" layer="21"/>
</package>
<package name="LCD-DIP128-64">
<description>&lt;b&gt;LCD-GRAFIK MODUL 128x64 PIXEL&lt;/b&gt;&lt;p&gt;
Source: www.lcd-module.de dip126-6.pdf</description>
<wire x1="-40.9" y1="22.8" x2="33.9" y2="22.8" width="0.2032" layer="21"/>
<wire x1="33.9" y1="22.8" x2="33.9" y2="-22.8" width="0.2032" layer="21"/>
<wire x1="33.9" y1="-22.8" x2="-40.9" y2="-22.8" width="0.2032" layer="21"/>
<wire x1="-40.9" y1="-22.8" x2="-40.9" y2="22.8" width="0.2032" layer="21"/>
<wire x1="-30.5" y1="19" x2="30.5" y2="19" width="0.002" layer="21"/>
<wire x1="30.5" y1="19" x2="30.5" y2="-19" width="0.002" layer="21"/>
<wire x1="30.5" y1="-19" x2="-30.5" y2="-19" width="0.002" layer="21"/>
<wire x1="-30.5" y1="-19" x2="-30.5" y2="19" width="0.002" layer="21"/>
<pad name="1" x="-31.75" y="13.97" drill="0.8" diameter="1.27"/>
<pad name="13" x="31.75" y="-13.97" drill="0.8" diameter="1.27"/>
<pad name="2" x="-31.75" y="11.43" drill="0.8" diameter="1.27"/>
<pad name="3" x="-31.75" y="8.89" drill="0.8" diameter="1.27"/>
<pad name="4" x="-31.75" y="6.35" drill="0.8" diameter="1.27"/>
<pad name="5" x="-31.75" y="3.81" drill="0.8" diameter="1.27"/>
<pad name="6" x="-31.75" y="1.27" drill="0.8" diameter="1.27"/>
<pad name="7" x="-31.75" y="-1.27" drill="0.8" diameter="1.27"/>
<pad name="8" x="-31.75" y="-3.81" drill="0.8" diameter="1.27"/>
<pad name="9" x="-31.75" y="-6.35" drill="0.8" diameter="1.27"/>
<pad name="10" x="-31.75" y="-8.89" drill="0.8" diameter="1.27"/>
<pad name="11" x="-31.75" y="-11.43" drill="0.8" diameter="1.27"/>
<pad name="12" x="-31.75" y="-13.97" drill="0.8" diameter="1.27"/>
<pad name="14" x="31.75" y="-11.43" drill="0.8" diameter="1.27"/>
<pad name="15" x="31.75" y="-8.89" drill="0.8" diameter="1.27"/>
<pad name="16" x="31.75" y="-6.35" drill="0.8" diameter="1.27"/>
<pad name="17" x="31.75" y="-3.81" drill="0.8" diameter="1.27"/>
<pad name="18" x="31.75" y="-1.27" drill="0.8" diameter="1.27"/>
<pad name="19" x="31.75" y="1.27" drill="0.8" diameter="1.27"/>
<pad name="20" x="31.75" y="3.81" drill="0.8" diameter="1.27"/>
<pad name="21" x="31.75" y="6.35" drill="0.8" diameter="1.27"/>
<pad name="22" x="31.75" y="8.89" drill="0.8" diameter="1.27"/>
<pad name="23" x="31.75" y="11.43" drill="0.8" diameter="1.27"/>
<pad name="24" x="31.75" y="13.97" drill="0.8" diameter="1.27"/>
<text x="-40.64" y="23.495" size="1.27" layer="25">&gt;NAME</text>
<text x="-40.64" y="-24.765" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-28.15" y1="16.13" x2="-27.73" y2="16.63" layer="51"/>
<rectangle x1="-27.71" y1="16.13" x2="-27.29" y2="16.63" layer="51"/>
<rectangle x1="-27.27" y1="16.13" x2="-26.85" y2="16.63" layer="51"/>
<rectangle x1="-26.83" y1="16.13" x2="-26.41" y2="16.63" layer="51"/>
<rectangle x1="-26.39" y1="16.13" x2="-25.97" y2="16.63" layer="51"/>
<rectangle x1="-25.95" y1="16.13" x2="-25.53" y2="16.63" layer="51"/>
<rectangle x1="-25.51" y1="16.13" x2="-25.09" y2="16.63" layer="51"/>
<rectangle x1="-25.07" y1="16.13" x2="-24.65" y2="16.63" layer="51"/>
<rectangle x1="-24.63" y1="16.13" x2="-24.21" y2="16.63" layer="51"/>
<rectangle x1="-24.19" y1="16.13" x2="-23.77" y2="16.63" layer="51"/>
<rectangle x1="-23.75" y1="16.13" x2="-23.33" y2="16.63" layer="51"/>
<rectangle x1="-23.31" y1="16.13" x2="-22.89" y2="16.63" layer="51"/>
<rectangle x1="-22.87" y1="16.13" x2="-22.45" y2="16.63" layer="51"/>
<rectangle x1="-22.43" y1="16.13" x2="-22.01" y2="16.63" layer="51"/>
<rectangle x1="-21.99" y1="16.13" x2="-21.57" y2="16.63" layer="51"/>
<rectangle x1="-21.55" y1="16.13" x2="-21.13" y2="16.63" layer="51"/>
<rectangle x1="-21.11" y1="16.13" x2="-20.69" y2="16.63" layer="51"/>
<rectangle x1="-20.67" y1="16.13" x2="-20.25" y2="16.63" layer="51"/>
<rectangle x1="-20.23" y1="16.13" x2="-19.81" y2="16.63" layer="51"/>
<rectangle x1="-19.79" y1="16.13" x2="-19.37" y2="16.63" layer="51"/>
<rectangle x1="-19.35" y1="16.13" x2="-18.93" y2="16.63" layer="51"/>
<rectangle x1="-18.91" y1="16.13" x2="-18.49" y2="16.63" layer="51"/>
<rectangle x1="-18.47" y1="16.13" x2="-18.05" y2="16.63" layer="51"/>
<rectangle x1="-18.03" y1="16.13" x2="-17.61" y2="16.63" layer="51"/>
<rectangle x1="-17.59" y1="16.13" x2="-17.17" y2="16.63" layer="51"/>
<rectangle x1="-17.15" y1="16.13" x2="-16.73" y2="16.63" layer="51"/>
<rectangle x1="-16.71" y1="16.13" x2="-16.29" y2="16.63" layer="51"/>
<rectangle x1="-16.27" y1="16.13" x2="-15.85" y2="16.63" layer="51"/>
<rectangle x1="-15.83" y1="16.13" x2="-15.41" y2="16.63" layer="51"/>
<rectangle x1="-15.39" y1="16.13" x2="-14.97" y2="16.63" layer="51"/>
<rectangle x1="-14.95" y1="16.13" x2="-14.53" y2="16.63" layer="51"/>
<rectangle x1="-14.51" y1="16.13" x2="-14.09" y2="16.63" layer="51"/>
<rectangle x1="-14.07" y1="16.13" x2="-13.65" y2="16.63" layer="51"/>
<rectangle x1="-13.63" y1="16.13" x2="-13.21" y2="16.63" layer="51"/>
<rectangle x1="-13.19" y1="16.13" x2="-12.77" y2="16.63" layer="51"/>
<rectangle x1="-12.75" y1="16.13" x2="-12.33" y2="16.63" layer="51"/>
<rectangle x1="-12.31" y1="16.13" x2="-11.89" y2="16.63" layer="51"/>
<rectangle x1="-11.87" y1="16.13" x2="-11.45" y2="16.63" layer="51"/>
<rectangle x1="-11.43" y1="16.13" x2="-11.01" y2="16.63" layer="51"/>
<rectangle x1="-10.99" y1="16.13" x2="-10.57" y2="16.63" layer="51"/>
<rectangle x1="-10.55" y1="16.13" x2="-10.13" y2="16.63" layer="51"/>
<rectangle x1="-10.11" y1="16.13" x2="-9.69" y2="16.63" layer="51"/>
<rectangle x1="-9.67" y1="16.13" x2="-9.25" y2="16.63" layer="51"/>
<rectangle x1="-9.23" y1="16.13" x2="-8.81" y2="16.63" layer="51"/>
<rectangle x1="-8.79" y1="16.13" x2="-8.37" y2="16.63" layer="51"/>
<rectangle x1="-8.35" y1="16.13" x2="-7.93" y2="16.63" layer="51"/>
<rectangle x1="-7.91" y1="16.13" x2="-7.49" y2="16.63" layer="51"/>
<rectangle x1="-7.47" y1="16.13" x2="-7.05" y2="16.63" layer="51"/>
<rectangle x1="-7.03" y1="16.13" x2="-6.61" y2="16.63" layer="51"/>
<rectangle x1="-6.59" y1="16.13" x2="-6.17" y2="16.63" layer="51"/>
<rectangle x1="-6.15" y1="16.13" x2="-5.73" y2="16.63" layer="51"/>
<rectangle x1="-5.71" y1="16.13" x2="-5.29" y2="16.63" layer="51"/>
<rectangle x1="-5.27" y1="16.13" x2="-4.85" y2="16.63" layer="51"/>
<rectangle x1="-4.83" y1="16.13" x2="-4.41" y2="16.63" layer="51"/>
<rectangle x1="-4.39" y1="16.13" x2="-3.97" y2="16.63" layer="51"/>
<rectangle x1="-3.95" y1="16.13" x2="-3.53" y2="16.63" layer="51"/>
<rectangle x1="-3.51" y1="16.13" x2="-3.09" y2="16.63" layer="51"/>
<rectangle x1="-3.07" y1="16.13" x2="-2.65" y2="16.63" layer="51"/>
<rectangle x1="-2.63" y1="16.13" x2="-2.21" y2="16.63" layer="51"/>
<rectangle x1="-2.19" y1="16.13" x2="-1.77" y2="16.63" layer="51"/>
<rectangle x1="-1.75" y1="16.13" x2="-1.33" y2="16.63" layer="51"/>
<rectangle x1="-1.31" y1="16.13" x2="-0.89" y2="16.63" layer="51"/>
<rectangle x1="-0.87" y1="16.13" x2="-0.45" y2="16.63" layer="51"/>
<rectangle x1="-0.43" y1="16.13" x2="-0.01" y2="16.63" layer="51"/>
<rectangle x1="0.01" y1="16.13" x2="0.43" y2="16.63" layer="51"/>
<rectangle x1="0.45" y1="16.13" x2="0.87" y2="16.63" layer="51"/>
<rectangle x1="0.89" y1="16.13" x2="1.31" y2="16.63" layer="51"/>
<rectangle x1="1.33" y1="16.13" x2="1.75" y2="16.63" layer="51"/>
<rectangle x1="1.77" y1="16.13" x2="2.19" y2="16.63" layer="51"/>
<rectangle x1="2.21" y1="16.13" x2="2.63" y2="16.63" layer="51"/>
<rectangle x1="2.65" y1="16.13" x2="3.07" y2="16.63" layer="51"/>
<rectangle x1="3.09" y1="16.13" x2="3.51" y2="16.63" layer="51"/>
<rectangle x1="3.53" y1="16.13" x2="3.95" y2="16.63" layer="51"/>
<rectangle x1="3.97" y1="16.13" x2="4.39" y2="16.63" layer="51"/>
<rectangle x1="4.41" y1="16.13" x2="4.83" y2="16.63" layer="51"/>
<rectangle x1="4.85" y1="16.13" x2="5.27" y2="16.63" layer="51"/>
<rectangle x1="5.29" y1="16.13" x2="5.71" y2="16.63" layer="51"/>
<rectangle x1="5.73" y1="16.13" x2="6.15" y2="16.63" layer="51"/>
<rectangle x1="6.17" y1="16.13" x2="6.59" y2="16.63" layer="51"/>
<rectangle x1="6.61" y1="16.13" x2="7.03" y2="16.63" layer="51"/>
<rectangle x1="7.05" y1="16.13" x2="7.47" y2="16.63" layer="51"/>
<rectangle x1="7.49" y1="16.13" x2="7.91" y2="16.63" layer="51"/>
<rectangle x1="7.93" y1="16.13" x2="8.35" y2="16.63" layer="51"/>
<rectangle x1="8.37" y1="16.13" x2="8.79" y2="16.63" layer="51"/>
<rectangle x1="8.81" y1="16.13" x2="9.23" y2="16.63" layer="51"/>
<rectangle x1="9.25" y1="16.13" x2="9.67" y2="16.63" layer="51"/>
<rectangle x1="9.69" y1="16.13" x2="10.11" y2="16.63" layer="51"/>
<rectangle x1="10.13" y1="16.13" x2="10.55" y2="16.63" layer="51"/>
<rectangle x1="10.57" y1="16.13" x2="10.99" y2="16.63" layer="51"/>
<rectangle x1="11.01" y1="16.13" x2="11.43" y2="16.63" layer="51"/>
<rectangle x1="11.45" y1="16.13" x2="11.87" y2="16.63" layer="51"/>
<rectangle x1="11.89" y1="16.13" x2="12.31" y2="16.63" layer="51"/>
<rectangle x1="12.33" y1="16.13" x2="12.75" y2="16.63" layer="51"/>
<rectangle x1="12.77" y1="16.13" x2="13.19" y2="16.63" layer="51"/>
<rectangle x1="13.21" y1="16.13" x2="13.63" y2="16.63" layer="51"/>
<rectangle x1="13.65" y1="16.13" x2="14.07" y2="16.63" layer="51"/>
<rectangle x1="14.09" y1="16.13" x2="14.51" y2="16.63" layer="51"/>
<rectangle x1="14.53" y1="16.13" x2="14.95" y2="16.63" layer="51"/>
<rectangle x1="14.97" y1="16.13" x2="15.39" y2="16.63" layer="51"/>
<rectangle x1="15.41" y1="16.13" x2="15.83" y2="16.63" layer="51"/>
<rectangle x1="15.85" y1="16.13" x2="16.27" y2="16.63" layer="51"/>
<rectangle x1="16.29" y1="16.13" x2="16.71" y2="16.63" layer="51"/>
<rectangle x1="16.73" y1="16.13" x2="17.15" y2="16.63" layer="51"/>
<rectangle x1="17.17" y1="16.13" x2="17.59" y2="16.63" layer="51"/>
<rectangle x1="17.61" y1="16.13" x2="18.03" y2="16.63" layer="51"/>
<rectangle x1="18.05" y1="16.13" x2="18.47" y2="16.63" layer="51"/>
<rectangle x1="18.49" y1="16.13" x2="18.91" y2="16.63" layer="51"/>
<rectangle x1="18.93" y1="16.13" x2="19.35" y2="16.63" layer="51"/>
<rectangle x1="19.37" y1="16.13" x2="19.79" y2="16.63" layer="51"/>
<rectangle x1="19.81" y1="16.13" x2="20.23" y2="16.63" layer="51"/>
<rectangle x1="20.25" y1="16.13" x2="20.67" y2="16.63" layer="51"/>
<rectangle x1="20.69" y1="16.13" x2="21.11" y2="16.63" layer="51"/>
<rectangle x1="21.13" y1="16.13" x2="21.55" y2="16.63" layer="51"/>
<rectangle x1="21.57" y1="16.13" x2="21.99" y2="16.63" layer="51"/>
<rectangle x1="22.01" y1="16.13" x2="22.43" y2="16.63" layer="51"/>
<rectangle x1="22.45" y1="16.13" x2="22.87" y2="16.63" layer="51"/>
<rectangle x1="22.89" y1="16.13" x2="23.31" y2="16.63" layer="51"/>
<rectangle x1="23.33" y1="16.13" x2="23.75" y2="16.63" layer="51"/>
<rectangle x1="23.77" y1="16.13" x2="24.19" y2="16.63" layer="51"/>
<rectangle x1="24.21" y1="16.13" x2="24.63" y2="16.63" layer="51"/>
<rectangle x1="24.65" y1="16.13" x2="25.07" y2="16.63" layer="51"/>
<rectangle x1="25.09" y1="16.13" x2="25.51" y2="16.63" layer="51"/>
<rectangle x1="25.53" y1="16.13" x2="25.95" y2="16.63" layer="51"/>
<rectangle x1="25.97" y1="16.13" x2="26.39" y2="16.63" layer="51"/>
<rectangle x1="26.41" y1="16.13" x2="26.83" y2="16.63" layer="51"/>
<rectangle x1="26.85" y1="16.13" x2="27.27" y2="16.63" layer="51"/>
<rectangle x1="27.29" y1="16.13" x2="27.71" y2="16.63" layer="51"/>
<rectangle x1="27.73" y1="16.13" x2="28.15" y2="16.63" layer="51"/>
<rectangle x1="-28.15" y1="15.61" x2="-27.73" y2="16.11" layer="51"/>
<rectangle x1="-27.71" y1="15.61" x2="-27.29" y2="16.11" layer="51"/>
<rectangle x1="-27.27" y1="15.61" x2="-26.85" y2="16.11" layer="51"/>
<rectangle x1="-26.83" y1="15.61" x2="-26.41" y2="16.11" layer="51"/>
<rectangle x1="-26.39" y1="15.61" x2="-25.97" y2="16.11" layer="51"/>
<rectangle x1="-25.95" y1="15.61" x2="-25.53" y2="16.11" layer="51"/>
<rectangle x1="-25.51" y1="15.61" x2="-25.09" y2="16.11" layer="51"/>
<rectangle x1="-25.07" y1="15.61" x2="-24.65" y2="16.11" layer="51"/>
<rectangle x1="-24.63" y1="15.61" x2="-24.21" y2="16.11" layer="51"/>
<rectangle x1="-24.19" y1="15.61" x2="-23.77" y2="16.11" layer="51"/>
<rectangle x1="-23.75" y1="15.61" x2="-23.33" y2="16.11" layer="51"/>
<rectangle x1="-23.31" y1="15.61" x2="-22.89" y2="16.11" layer="51"/>
<rectangle x1="-22.87" y1="15.61" x2="-22.45" y2="16.11" layer="51"/>
<rectangle x1="-22.43" y1="15.61" x2="-22.01" y2="16.11" layer="51"/>
<rectangle x1="-21.99" y1="15.61" x2="-21.57" y2="16.11" layer="51"/>
<rectangle x1="-21.55" y1="15.61" x2="-21.13" y2="16.11" layer="51"/>
<rectangle x1="-21.11" y1="15.61" x2="-20.69" y2="16.11" layer="51"/>
<rectangle x1="-20.67" y1="15.61" x2="-20.25" y2="16.11" layer="51"/>
<rectangle x1="-20.23" y1="15.61" x2="-19.81" y2="16.11" layer="51"/>
<rectangle x1="-19.79" y1="15.61" x2="-19.37" y2="16.11" layer="51"/>
<rectangle x1="-19.35" y1="15.61" x2="-18.93" y2="16.11" layer="51"/>
<rectangle x1="-18.91" y1="15.61" x2="-18.49" y2="16.11" layer="51"/>
<rectangle x1="-18.47" y1="15.61" x2="-18.05" y2="16.11" layer="51"/>
<rectangle x1="-18.03" y1="15.61" x2="-17.61" y2="16.11" layer="51"/>
<rectangle x1="-17.59" y1="15.61" x2="-17.17" y2="16.11" layer="51"/>
<rectangle x1="-17.15" y1="15.61" x2="-16.73" y2="16.11" layer="51"/>
<rectangle x1="-16.71" y1="15.61" x2="-16.29" y2="16.11" layer="51"/>
<rectangle x1="-16.27" y1="15.61" x2="-15.85" y2="16.11" layer="51"/>
<rectangle x1="-15.83" y1="15.61" x2="-15.41" y2="16.11" layer="51"/>
<rectangle x1="-15.39" y1="15.61" x2="-14.97" y2="16.11" layer="51"/>
<rectangle x1="-14.95" y1="15.61" x2="-14.53" y2="16.11" layer="51"/>
<rectangle x1="-14.51" y1="15.61" x2="-14.09" y2="16.11" layer="51"/>
<rectangle x1="-14.07" y1="15.61" x2="-13.65" y2="16.11" layer="51"/>
<rectangle x1="-13.63" y1="15.61" x2="-13.21" y2="16.11" layer="51"/>
<rectangle x1="-13.19" y1="15.61" x2="-12.77" y2="16.11" layer="51"/>
<rectangle x1="-12.75" y1="15.61" x2="-12.33" y2="16.11" layer="51"/>
<rectangle x1="-12.31" y1="15.61" x2="-11.89" y2="16.11" layer="51"/>
<rectangle x1="-11.87" y1="15.61" x2="-11.45" y2="16.11" layer="51"/>
<rectangle x1="-11.43" y1="15.61" x2="-11.01" y2="16.11" layer="51"/>
<rectangle x1="-10.99" y1="15.61" x2="-10.57" y2="16.11" layer="51"/>
<rectangle x1="-10.55" y1="15.61" x2="-10.13" y2="16.11" layer="51"/>
<rectangle x1="-10.11" y1="15.61" x2="-9.69" y2="16.11" layer="51"/>
<rectangle x1="-9.67" y1="15.61" x2="-9.25" y2="16.11" layer="51"/>
<rectangle x1="-9.23" y1="15.61" x2="-8.81" y2="16.11" layer="51"/>
<rectangle x1="-8.79" y1="15.61" x2="-8.37" y2="16.11" layer="51"/>
<rectangle x1="-8.35" y1="15.61" x2="-7.93" y2="16.11" layer="51"/>
<rectangle x1="-7.91" y1="15.61" x2="-7.49" y2="16.11" layer="51"/>
<rectangle x1="-7.47" y1="15.61" x2="-7.05" y2="16.11" layer="51"/>
<rectangle x1="-7.03" y1="15.61" x2="-6.61" y2="16.11" layer="51"/>
<rectangle x1="-6.59" y1="15.61" x2="-6.17" y2="16.11" layer="51"/>
<rectangle x1="-6.15" y1="15.61" x2="-5.73" y2="16.11" layer="51"/>
<rectangle x1="-5.71" y1="15.61" x2="-5.29" y2="16.11" layer="51"/>
<rectangle x1="-5.27" y1="15.61" x2="-4.85" y2="16.11" layer="51"/>
<rectangle x1="-4.83" y1="15.61" x2="-4.41" y2="16.11" layer="51"/>
<rectangle x1="-4.39" y1="15.61" x2="-3.97" y2="16.11" layer="51"/>
<rectangle x1="-3.95" y1="15.61" x2="-3.53" y2="16.11" layer="51"/>
<rectangle x1="-3.51" y1="15.61" x2="-3.09" y2="16.11" layer="51"/>
<rectangle x1="-3.07" y1="15.61" x2="-2.65" y2="16.11" layer="51"/>
<rectangle x1="-2.63" y1="15.61" x2="-2.21" y2="16.11" layer="51"/>
<rectangle x1="-2.19" y1="15.61" x2="-1.77" y2="16.11" layer="51"/>
<rectangle x1="-1.75" y1="15.61" x2="-1.33" y2="16.11" layer="51"/>
<rectangle x1="-1.31" y1="15.61" x2="-0.89" y2="16.11" layer="51"/>
<rectangle x1="-0.87" y1="15.61" x2="-0.45" y2="16.11" layer="51"/>
<rectangle x1="-0.43" y1="15.61" x2="-0.01" y2="16.11" layer="51"/>
<rectangle x1="0.01" y1="15.61" x2="0.43" y2="16.11" layer="51"/>
<rectangle x1="0.45" y1="15.61" x2="0.87" y2="16.11" layer="51"/>
<rectangle x1="0.89" y1="15.61" x2="1.31" y2="16.11" layer="51"/>
<rectangle x1="1.33" y1="15.61" x2="1.75" y2="16.11" layer="51"/>
<rectangle x1="1.77" y1="15.61" x2="2.19" y2="16.11" layer="51"/>
<rectangle x1="2.21" y1="15.61" x2="2.63" y2="16.11" layer="51"/>
<rectangle x1="2.65" y1="15.61" x2="3.07" y2="16.11" layer="51"/>
<rectangle x1="3.09" y1="15.61" x2="3.51" y2="16.11" layer="51"/>
<rectangle x1="3.53" y1="15.61" x2="3.95" y2="16.11" layer="51"/>
<rectangle x1="3.97" y1="15.61" x2="4.39" y2="16.11" layer="51"/>
<rectangle x1="4.41" y1="15.61" x2="4.83" y2="16.11" layer="51"/>
<rectangle x1="4.85" y1="15.61" x2="5.27" y2="16.11" layer="51"/>
<rectangle x1="5.29" y1="15.61" x2="5.71" y2="16.11" layer="51"/>
<rectangle x1="5.73" y1="15.61" x2="6.15" y2="16.11" layer="51"/>
<rectangle x1="6.17" y1="15.61" x2="6.59" y2="16.11" layer="51"/>
<rectangle x1="6.61" y1="15.61" x2="7.03" y2="16.11" layer="51"/>
<rectangle x1="7.05" y1="15.61" x2="7.47" y2="16.11" layer="51"/>
<rectangle x1="7.49" y1="15.61" x2="7.91" y2="16.11" layer="51"/>
<rectangle x1="7.93" y1="15.61" x2="8.35" y2="16.11" layer="51"/>
<rectangle x1="8.37" y1="15.61" x2="8.79" y2="16.11" layer="51"/>
<rectangle x1="8.81" y1="15.61" x2="9.23" y2="16.11" layer="51"/>
<rectangle x1="9.25" y1="15.61" x2="9.67" y2="16.11" layer="51"/>
<rectangle x1="9.69" y1="15.61" x2="10.11" y2="16.11" layer="51"/>
<rectangle x1="10.13" y1="15.61" x2="10.55" y2="16.11" layer="51"/>
<rectangle x1="10.57" y1="15.61" x2="10.99" y2="16.11" layer="51"/>
<rectangle x1="11.01" y1="15.61" x2="11.43" y2="16.11" layer="51"/>
<rectangle x1="11.45" y1="15.61" x2="11.87" y2="16.11" layer="51"/>
<rectangle x1="11.89" y1="15.61" x2="12.31" y2="16.11" layer="51"/>
<rectangle x1="12.33" y1="15.61" x2="12.75" y2="16.11" layer="51"/>
<rectangle x1="12.77" y1="15.61" x2="13.19" y2="16.11" layer="51"/>
<rectangle x1="13.21" y1="15.61" x2="13.63" y2="16.11" layer="51"/>
<rectangle x1="13.65" y1="15.61" x2="14.07" y2="16.11" layer="51"/>
<rectangle x1="14.09" y1="15.61" x2="14.51" y2="16.11" layer="51"/>
<rectangle x1="14.53" y1="15.61" x2="14.95" y2="16.11" layer="51"/>
<rectangle x1="14.97" y1="15.61" x2="15.39" y2="16.11" layer="51"/>
<rectangle x1="15.41" y1="15.61" x2="15.83" y2="16.11" layer="51"/>
<rectangle x1="15.85" y1="15.61" x2="16.27" y2="16.11" layer="51"/>
<rectangle x1="16.29" y1="15.61" x2="16.71" y2="16.11" layer="51"/>
<rectangle x1="16.73" y1="15.61" x2="17.15" y2="16.11" layer="51"/>
<rectangle x1="17.17" y1="15.61" x2="17.59" y2="16.11" layer="51"/>
<rectangle x1="17.61" y1="15.61" x2="18.03" y2="16.11" layer="51"/>
<rectangle x1="18.05" y1="15.61" x2="18.47" y2="16.11" layer="51"/>
<rectangle x1="18.49" y1="15.61" x2="18.91" y2="16.11" layer="51"/>
<rectangle x1="18.93" y1="15.61" x2="19.35" y2="16.11" layer="51"/>
<rectangle x1="19.37" y1="15.61" x2="19.79" y2="16.11" layer="51"/>
<rectangle x1="19.81" y1="15.61" x2="20.23" y2="16.11" layer="51"/>
<rectangle x1="20.25" y1="15.61" x2="20.67" y2="16.11" layer="51"/>
<rectangle x1="20.69" y1="15.61" x2="21.11" y2="16.11" layer="51"/>
<rectangle x1="21.13" y1="15.61" x2="21.55" y2="16.11" layer="51"/>
<rectangle x1="21.57" y1="15.61" x2="21.99" y2="16.11" layer="51"/>
<rectangle x1="22.01" y1="15.61" x2="22.43" y2="16.11" layer="51"/>
<rectangle x1="22.45" y1="15.61" x2="22.87" y2="16.11" layer="51"/>
<rectangle x1="22.89" y1="15.61" x2="23.31" y2="16.11" layer="51"/>
<rectangle x1="23.33" y1="15.61" x2="23.75" y2="16.11" layer="51"/>
<rectangle x1="23.77" y1="15.61" x2="24.19" y2="16.11" layer="51"/>
<rectangle x1="24.21" y1="15.61" x2="24.63" y2="16.11" layer="51"/>
<rectangle x1="24.65" y1="15.61" x2="25.07" y2="16.11" layer="51"/>
<rectangle x1="25.09" y1="15.61" x2="25.51" y2="16.11" layer="51"/>
<rectangle x1="25.53" y1="15.61" x2="25.95" y2="16.11" layer="51"/>
<rectangle x1="25.97" y1="15.61" x2="26.39" y2="16.11" layer="51"/>
<rectangle x1="26.41" y1="15.61" x2="26.83" y2="16.11" layer="51"/>
<rectangle x1="26.85" y1="15.61" x2="27.27" y2="16.11" layer="51"/>
<rectangle x1="27.29" y1="15.61" x2="27.71" y2="16.11" layer="51"/>
<rectangle x1="27.73" y1="15.61" x2="28.15" y2="16.11" layer="51"/>
<rectangle x1="-28.15" y1="15.09" x2="-27.73" y2="15.59" layer="51"/>
<rectangle x1="-27.71" y1="15.09" x2="-27.29" y2="15.59" layer="51"/>
<rectangle x1="-27.27" y1="15.09" x2="-26.85" y2="15.59" layer="51"/>
<rectangle x1="-26.83" y1="15.09" x2="-26.41" y2="15.59" layer="51"/>
<rectangle x1="-26.39" y1="15.09" x2="-25.97" y2="15.59" layer="51"/>
<rectangle x1="-25.95" y1="15.09" x2="-25.53" y2="15.59" layer="51"/>
<rectangle x1="-25.51" y1="15.09" x2="-25.09" y2="15.59" layer="51"/>
<rectangle x1="-25.07" y1="15.09" x2="-24.65" y2="15.59" layer="51"/>
<rectangle x1="-24.63" y1="15.09" x2="-24.21" y2="15.59" layer="51"/>
<rectangle x1="-24.19" y1="15.09" x2="-23.77" y2="15.59" layer="51"/>
<rectangle x1="-23.75" y1="15.09" x2="-23.33" y2="15.59" layer="51"/>
<rectangle x1="-23.31" y1="15.09" x2="-22.89" y2="15.59" layer="51"/>
<rectangle x1="-22.87" y1="15.09" x2="-22.45" y2="15.59" layer="51"/>
<rectangle x1="-22.43" y1="15.09" x2="-22.01" y2="15.59" layer="51"/>
<rectangle x1="-21.99" y1="15.09" x2="-21.57" y2="15.59" layer="51"/>
<rectangle x1="-21.55" y1="15.09" x2="-21.13" y2="15.59" layer="51"/>
<rectangle x1="-21.11" y1="15.09" x2="-20.69" y2="15.59" layer="51"/>
<rectangle x1="-20.67" y1="15.09" x2="-20.25" y2="15.59" layer="51"/>
<rectangle x1="-20.23" y1="15.09" x2="-19.81" y2="15.59" layer="51"/>
<rectangle x1="-19.79" y1="15.09" x2="-19.37" y2="15.59" layer="51"/>
<rectangle x1="-19.35" y1="15.09" x2="-18.93" y2="15.59" layer="51"/>
<rectangle x1="-18.91" y1="15.09" x2="-18.49" y2="15.59" layer="51"/>
<rectangle x1="-18.47" y1="15.09" x2="-18.05" y2="15.59" layer="51"/>
<rectangle x1="-18.03" y1="15.09" x2="-17.61" y2="15.59" layer="51"/>
<rectangle x1="-17.59" y1="15.09" x2="-17.17" y2="15.59" layer="51"/>
<rectangle x1="-17.15" y1="15.09" x2="-16.73" y2="15.59" layer="51"/>
<rectangle x1="-16.71" y1="15.09" x2="-16.29" y2="15.59" layer="51"/>
<rectangle x1="-16.27" y1="15.09" x2="-15.85" y2="15.59" layer="51"/>
<rectangle x1="-15.83" y1="15.09" x2="-15.41" y2="15.59" layer="51"/>
<rectangle x1="-15.39" y1="15.09" x2="-14.97" y2="15.59" layer="51"/>
<rectangle x1="-14.95" y1="15.09" x2="-14.53" y2="15.59" layer="51"/>
<rectangle x1="-14.51" y1="15.09" x2="-14.09" y2="15.59" layer="51"/>
<rectangle x1="-14.07" y1="15.09" x2="-13.65" y2="15.59" layer="51"/>
<rectangle x1="-13.63" y1="15.09" x2="-13.21" y2="15.59" layer="51"/>
<rectangle x1="-13.19" y1="15.09" x2="-12.77" y2="15.59" layer="51"/>
<rectangle x1="-12.75" y1="15.09" x2="-12.33" y2="15.59" layer="51"/>
<rectangle x1="-12.31" y1="15.09" x2="-11.89" y2="15.59" layer="51"/>
<rectangle x1="-11.87" y1="15.09" x2="-11.45" y2="15.59" layer="51"/>
<rectangle x1="-11.43" y1="15.09" x2="-11.01" y2="15.59" layer="51"/>
<rectangle x1="-10.99" y1="15.09" x2="-10.57" y2="15.59" layer="51"/>
<rectangle x1="-10.55" y1="15.09" x2="-10.13" y2="15.59" layer="51"/>
<rectangle x1="-10.11" y1="15.09" x2="-9.69" y2="15.59" layer="51"/>
<rectangle x1="-9.67" y1="15.09" x2="-9.25" y2="15.59" layer="51"/>
<rectangle x1="-9.23" y1="15.09" x2="-8.81" y2="15.59" layer="51"/>
<rectangle x1="-8.79" y1="15.09" x2="-8.37" y2="15.59" layer="51"/>
<rectangle x1="-8.35" y1="15.09" x2="-7.93" y2="15.59" layer="51"/>
<rectangle x1="-7.91" y1="15.09" x2="-7.49" y2="15.59" layer="51"/>
<rectangle x1="-7.47" y1="15.09" x2="-7.05" y2="15.59" layer="51"/>
<rectangle x1="-7.03" y1="15.09" x2="-6.61" y2="15.59" layer="51"/>
<rectangle x1="-6.59" y1="15.09" x2="-6.17" y2="15.59" layer="51"/>
<rectangle x1="-6.15" y1="15.09" x2="-5.73" y2="15.59" layer="51"/>
<rectangle x1="-5.71" y1="15.09" x2="-5.29" y2="15.59" layer="51"/>
<rectangle x1="-5.27" y1="15.09" x2="-4.85" y2="15.59" layer="51"/>
<rectangle x1="-4.83" y1="15.09" x2="-4.41" y2="15.59" layer="51"/>
<rectangle x1="-4.39" y1="15.09" x2="-3.97" y2="15.59" layer="51"/>
<rectangle x1="-3.95" y1="15.09" x2="-3.53" y2="15.59" layer="51"/>
<rectangle x1="-3.51" y1="15.09" x2="-3.09" y2="15.59" layer="51"/>
<rectangle x1="-3.07" y1="15.09" x2="-2.65" y2="15.59" layer="51"/>
<rectangle x1="-2.63" y1="15.09" x2="-2.21" y2="15.59" layer="51"/>
<rectangle x1="-2.19" y1="15.09" x2="-1.77" y2="15.59" layer="51"/>
<rectangle x1="-1.75" y1="15.09" x2="-1.33" y2="15.59" layer="51"/>
<rectangle x1="-1.31" y1="15.09" x2="-0.89" y2="15.59" layer="51"/>
<rectangle x1="-0.87" y1="15.09" x2="-0.45" y2="15.59" layer="51"/>
<rectangle x1="-0.43" y1="15.09" x2="-0.01" y2="15.59" layer="51"/>
<rectangle x1="0.01" y1="15.09" x2="0.43" y2="15.59" layer="51"/>
<rectangle x1="0.45" y1="15.09" x2="0.87" y2="15.59" layer="51"/>
<rectangle x1="0.89" y1="15.09" x2="1.31" y2="15.59" layer="51"/>
<rectangle x1="1.33" y1="15.09" x2="1.75" y2="15.59" layer="51"/>
<rectangle x1="1.77" y1="15.09" x2="2.19" y2="15.59" layer="51"/>
<rectangle x1="2.21" y1="15.09" x2="2.63" y2="15.59" layer="51"/>
<rectangle x1="2.65" y1="15.09" x2="3.07" y2="15.59" layer="51"/>
<rectangle x1="3.09" y1="15.09" x2="3.51" y2="15.59" layer="51"/>
<rectangle x1="3.53" y1="15.09" x2="3.95" y2="15.59" layer="51"/>
<rectangle x1="3.97" y1="15.09" x2="4.39" y2="15.59" layer="51"/>
<rectangle x1="4.41" y1="15.09" x2="4.83" y2="15.59" layer="51"/>
<rectangle x1="4.85" y1="15.09" x2="5.27" y2="15.59" layer="51"/>
<rectangle x1="5.29" y1="15.09" x2="5.71" y2="15.59" layer="51"/>
<rectangle x1="5.73" y1="15.09" x2="6.15" y2="15.59" layer="51"/>
<rectangle x1="6.17" y1="15.09" x2="6.59" y2="15.59" layer="51"/>
<rectangle x1="6.61" y1="15.09" x2="7.03" y2="15.59" layer="51"/>
<rectangle x1="7.05" y1="15.09" x2="7.47" y2="15.59" layer="51"/>
<rectangle x1="7.49" y1="15.09" x2="7.91" y2="15.59" layer="51"/>
<rectangle x1="7.93" y1="15.09" x2="8.35" y2="15.59" layer="51"/>
<rectangle x1="8.37" y1="15.09" x2="8.79" y2="15.59" layer="51"/>
<rectangle x1="8.81" y1="15.09" x2="9.23" y2="15.59" layer="51"/>
<rectangle x1="9.25" y1="15.09" x2="9.67" y2="15.59" layer="51"/>
<rectangle x1="9.69" y1="15.09" x2="10.11" y2="15.59" layer="51"/>
<rectangle x1="10.13" y1="15.09" x2="10.55" y2="15.59" layer="51"/>
<rectangle x1="10.57" y1="15.09" x2="10.99" y2="15.59" layer="51"/>
<rectangle x1="11.01" y1="15.09" x2="11.43" y2="15.59" layer="51"/>
<rectangle x1="11.45" y1="15.09" x2="11.87" y2="15.59" layer="51"/>
<rectangle x1="11.89" y1="15.09" x2="12.31" y2="15.59" layer="51"/>
<rectangle x1="12.33" y1="15.09" x2="12.75" y2="15.59" layer="51"/>
<rectangle x1="12.77" y1="15.09" x2="13.19" y2="15.59" layer="51"/>
<rectangle x1="13.21" y1="15.09" x2="13.63" y2="15.59" layer="51"/>
<rectangle x1="13.65" y1="15.09" x2="14.07" y2="15.59" layer="51"/>
<rectangle x1="14.09" y1="15.09" x2="14.51" y2="15.59" layer="51"/>
<rectangle x1="14.53" y1="15.09" x2="14.95" y2="15.59" layer="51"/>
<rectangle x1="14.97" y1="15.09" x2="15.39" y2="15.59" layer="51"/>
<rectangle x1="15.41" y1="15.09" x2="15.83" y2="15.59" layer="51"/>
<rectangle x1="15.85" y1="15.09" x2="16.27" y2="15.59" layer="51"/>
<rectangle x1="16.29" y1="15.09" x2="16.71" y2="15.59" layer="51"/>
<rectangle x1="16.73" y1="15.09" x2="17.15" y2="15.59" layer="51"/>
<rectangle x1="17.17" y1="15.09" x2="17.59" y2="15.59" layer="51"/>
<rectangle x1="17.61" y1="15.09" x2="18.03" y2="15.59" layer="51"/>
<rectangle x1="18.05" y1="15.09" x2="18.47" y2="15.59" layer="51"/>
<rectangle x1="18.49" y1="15.09" x2="18.91" y2="15.59" layer="51"/>
<rectangle x1="18.93" y1="15.09" x2="19.35" y2="15.59" layer="51"/>
<rectangle x1="19.37" y1="15.09" x2="19.79" y2="15.59" layer="51"/>
<rectangle x1="19.81" y1="15.09" x2="20.23" y2="15.59" layer="51"/>
<rectangle x1="20.25" y1="15.09" x2="20.67" y2="15.59" layer="51"/>
<rectangle x1="20.69" y1="15.09" x2="21.11" y2="15.59" layer="51"/>
<rectangle x1="21.13" y1="15.09" x2="21.55" y2="15.59" layer="51"/>
<rectangle x1="21.57" y1="15.09" x2="21.99" y2="15.59" layer="51"/>
<rectangle x1="22.01" y1="15.09" x2="22.43" y2="15.59" layer="51"/>
<rectangle x1="22.45" y1="15.09" x2="22.87" y2="15.59" layer="51"/>
<rectangle x1="22.89" y1="15.09" x2="23.31" y2="15.59" layer="51"/>
<rectangle x1="23.33" y1="15.09" x2="23.75" y2="15.59" layer="51"/>
<rectangle x1="23.77" y1="15.09" x2="24.19" y2="15.59" layer="51"/>
<rectangle x1="24.21" y1="15.09" x2="24.63" y2="15.59" layer="51"/>
<rectangle x1="24.65" y1="15.09" x2="25.07" y2="15.59" layer="51"/>
<rectangle x1="25.09" y1="15.09" x2="25.51" y2="15.59" layer="51"/>
<rectangle x1="25.53" y1="15.09" x2="25.95" y2="15.59" layer="51"/>
<rectangle x1="25.97" y1="15.09" x2="26.39" y2="15.59" layer="51"/>
<rectangle x1="26.41" y1="15.09" x2="26.83" y2="15.59" layer="51"/>
<rectangle x1="26.85" y1="15.09" x2="27.27" y2="15.59" layer="51"/>
<rectangle x1="27.29" y1="15.09" x2="27.71" y2="15.59" layer="51"/>
<rectangle x1="27.73" y1="15.09" x2="28.15" y2="15.59" layer="51"/>
<rectangle x1="-28.15" y1="14.57" x2="-27.73" y2="15.07" layer="51"/>
<rectangle x1="-27.71" y1="14.57" x2="-27.29" y2="15.07" layer="51"/>
<rectangle x1="-27.27" y1="14.57" x2="-26.85" y2="15.07" layer="51"/>
<rectangle x1="-26.83" y1="14.57" x2="-26.41" y2="15.07" layer="51"/>
<rectangle x1="-26.39" y1="14.57" x2="-25.97" y2="15.07" layer="51"/>
<rectangle x1="-25.95" y1="14.57" x2="-25.53" y2="15.07" layer="51"/>
<rectangle x1="-25.51" y1="14.57" x2="-25.09" y2="15.07" layer="51"/>
<rectangle x1="-25.07" y1="14.57" x2="-24.65" y2="15.07" layer="51"/>
<rectangle x1="-24.63" y1="14.57" x2="-24.21" y2="15.07" layer="51"/>
<rectangle x1="-24.19" y1="14.57" x2="-23.77" y2="15.07" layer="51"/>
<rectangle x1="-23.75" y1="14.57" x2="-23.33" y2="15.07" layer="51"/>
<rectangle x1="-23.31" y1="14.57" x2="-22.89" y2="15.07" layer="51"/>
<rectangle x1="-22.87" y1="14.57" x2="-22.45" y2="15.07" layer="51"/>
<rectangle x1="-22.43" y1="14.57" x2="-22.01" y2="15.07" layer="51"/>
<rectangle x1="-21.99" y1="14.57" x2="-21.57" y2="15.07" layer="51"/>
<rectangle x1="-21.55" y1="14.57" x2="-21.13" y2="15.07" layer="51"/>
<rectangle x1="-21.11" y1="14.57" x2="-20.69" y2="15.07" layer="51"/>
<rectangle x1="-20.67" y1="14.57" x2="-20.25" y2="15.07" layer="51"/>
<rectangle x1="-20.23" y1="14.57" x2="-19.81" y2="15.07" layer="51"/>
<rectangle x1="-19.79" y1="14.57" x2="-19.37" y2="15.07" layer="51"/>
<rectangle x1="-19.35" y1="14.57" x2="-18.93" y2="15.07" layer="51"/>
<rectangle x1="-18.91" y1="14.57" x2="-18.49" y2="15.07" layer="51"/>
<rectangle x1="-18.47" y1="14.57" x2="-18.05" y2="15.07" layer="51"/>
<rectangle x1="-18.03" y1="14.57" x2="-17.61" y2="15.07" layer="51"/>
<rectangle x1="-17.59" y1="14.57" x2="-17.17" y2="15.07" layer="51"/>
<rectangle x1="-17.15" y1="14.57" x2="-16.73" y2="15.07" layer="51"/>
<rectangle x1="-16.71" y1="14.57" x2="-16.29" y2="15.07" layer="51"/>
<rectangle x1="-16.27" y1="14.57" x2="-15.85" y2="15.07" layer="51"/>
<rectangle x1="-15.83" y1="14.57" x2="-15.41" y2="15.07" layer="51"/>
<rectangle x1="-15.39" y1="14.57" x2="-14.97" y2="15.07" layer="51"/>
<rectangle x1="-14.95" y1="14.57" x2="-14.53" y2="15.07" layer="51"/>
<rectangle x1="-14.51" y1="14.57" x2="-14.09" y2="15.07" layer="51"/>
<rectangle x1="-14.07" y1="14.57" x2="-13.65" y2="15.07" layer="51"/>
<rectangle x1="-13.63" y1="14.57" x2="-13.21" y2="15.07" layer="51"/>
<rectangle x1="-13.19" y1="14.57" x2="-12.77" y2="15.07" layer="51"/>
<rectangle x1="-12.75" y1="14.57" x2="-12.33" y2="15.07" layer="51"/>
<rectangle x1="-12.31" y1="14.57" x2="-11.89" y2="15.07" layer="51"/>
<rectangle x1="-11.87" y1="14.57" x2="-11.45" y2="15.07" layer="51"/>
<rectangle x1="-11.43" y1="14.57" x2="-11.01" y2="15.07" layer="51"/>
<rectangle x1="-10.99" y1="14.57" x2="-10.57" y2="15.07" layer="51"/>
<rectangle x1="-10.55" y1="14.57" x2="-10.13" y2="15.07" layer="51"/>
<rectangle x1="-10.11" y1="14.57" x2="-9.69" y2="15.07" layer="51"/>
<rectangle x1="-9.67" y1="14.57" x2="-9.25" y2="15.07" layer="51"/>
<rectangle x1="-9.23" y1="14.57" x2="-8.81" y2="15.07" layer="51"/>
<rectangle x1="-8.79" y1="14.57" x2="-8.37" y2="15.07" layer="51"/>
<rectangle x1="-8.35" y1="14.57" x2="-7.93" y2="15.07" layer="51"/>
<rectangle x1="-7.91" y1="14.57" x2="-7.49" y2="15.07" layer="51"/>
<rectangle x1="-7.47" y1="14.57" x2="-7.05" y2="15.07" layer="51"/>
<rectangle x1="-7.03" y1="14.57" x2="-6.61" y2="15.07" layer="51"/>
<rectangle x1="-6.59" y1="14.57" x2="-6.17" y2="15.07" layer="51"/>
<rectangle x1="-6.15" y1="14.57" x2="-5.73" y2="15.07" layer="51"/>
<rectangle x1="-5.71" y1="14.57" x2="-5.29" y2="15.07" layer="51"/>
<rectangle x1="-5.27" y1="14.57" x2="-4.85" y2="15.07" layer="51"/>
<rectangle x1="-4.83" y1="14.57" x2="-4.41" y2="15.07" layer="51"/>
<rectangle x1="-4.39" y1="14.57" x2="-3.97" y2="15.07" layer="51"/>
<rectangle x1="-3.95" y1="14.57" x2="-3.53" y2="15.07" layer="51"/>
<rectangle x1="-3.51" y1="14.57" x2="-3.09" y2="15.07" layer="51"/>
<rectangle x1="-3.07" y1="14.57" x2="-2.65" y2="15.07" layer="51"/>
<rectangle x1="-2.63" y1="14.57" x2="-2.21" y2="15.07" layer="51"/>
<rectangle x1="-2.19" y1="14.57" x2="-1.77" y2="15.07" layer="51"/>
<rectangle x1="-1.75" y1="14.57" x2="-1.33" y2="15.07" layer="51"/>
<rectangle x1="-1.31" y1="14.57" x2="-0.89" y2="15.07" layer="51"/>
<rectangle x1="-0.87" y1="14.57" x2="-0.45" y2="15.07" layer="51"/>
<rectangle x1="-0.43" y1="14.57" x2="-0.01" y2="15.07" layer="51"/>
<rectangle x1="0.01" y1="14.57" x2="0.43" y2="15.07" layer="51"/>
<rectangle x1="0.45" y1="14.57" x2="0.87" y2="15.07" layer="51"/>
<rectangle x1="0.89" y1="14.57" x2="1.31" y2="15.07" layer="51"/>
<rectangle x1="1.33" y1="14.57" x2="1.75" y2="15.07" layer="51"/>
<rectangle x1="1.77" y1="14.57" x2="2.19" y2="15.07" layer="51"/>
<rectangle x1="2.21" y1="14.57" x2="2.63" y2="15.07" layer="51"/>
<rectangle x1="2.65" y1="14.57" x2="3.07" y2="15.07" layer="51"/>
<rectangle x1="3.09" y1="14.57" x2="3.51" y2="15.07" layer="51"/>
<rectangle x1="3.53" y1="14.57" x2="3.95" y2="15.07" layer="51"/>
<rectangle x1="3.97" y1="14.57" x2="4.39" y2="15.07" layer="51"/>
<rectangle x1="4.41" y1="14.57" x2="4.83" y2="15.07" layer="51"/>
<rectangle x1="4.85" y1="14.57" x2="5.27" y2="15.07" layer="51"/>
<rectangle x1="5.29" y1="14.57" x2="5.71" y2="15.07" layer="51"/>
<rectangle x1="5.73" y1="14.57" x2="6.15" y2="15.07" layer="51"/>
<rectangle x1="6.17" y1="14.57" x2="6.59" y2="15.07" layer="51"/>
<rectangle x1="6.61" y1="14.57" x2="7.03" y2="15.07" layer="51"/>
<rectangle x1="7.05" y1="14.57" x2="7.47" y2="15.07" layer="51"/>
<rectangle x1="7.49" y1="14.57" x2="7.91" y2="15.07" layer="51"/>
<rectangle x1="7.93" y1="14.57" x2="8.35" y2="15.07" layer="51"/>
<rectangle x1="8.37" y1="14.57" x2="8.79" y2="15.07" layer="51"/>
<rectangle x1="8.81" y1="14.57" x2="9.23" y2="15.07" layer="51"/>
<rectangle x1="9.25" y1="14.57" x2="9.67" y2="15.07" layer="51"/>
<rectangle x1="9.69" y1="14.57" x2="10.11" y2="15.07" layer="51"/>
<rectangle x1="10.13" y1="14.57" x2="10.55" y2="15.07" layer="51"/>
<rectangle x1="10.57" y1="14.57" x2="10.99" y2="15.07" layer="51"/>
<rectangle x1="11.01" y1="14.57" x2="11.43" y2="15.07" layer="51"/>
<rectangle x1="11.45" y1="14.57" x2="11.87" y2="15.07" layer="51"/>
<rectangle x1="11.89" y1="14.57" x2="12.31" y2="15.07" layer="51"/>
<rectangle x1="12.33" y1="14.57" x2="12.75" y2="15.07" layer="51"/>
<rectangle x1="12.77" y1="14.57" x2="13.19" y2="15.07" layer="51"/>
<rectangle x1="13.21" y1="14.57" x2="13.63" y2="15.07" layer="51"/>
<rectangle x1="13.65" y1="14.57" x2="14.07" y2="15.07" layer="51"/>
<rectangle x1="14.09" y1="14.57" x2="14.51" y2="15.07" layer="51"/>
<rectangle x1="14.53" y1="14.57" x2="14.95" y2="15.07" layer="51"/>
<rectangle x1="14.97" y1="14.57" x2="15.39" y2="15.07" layer="51"/>
<rectangle x1="15.41" y1="14.57" x2="15.83" y2="15.07" layer="51"/>
<rectangle x1="15.85" y1="14.57" x2="16.27" y2="15.07" layer="51"/>
<rectangle x1="16.29" y1="14.57" x2="16.71" y2="15.07" layer="51"/>
<rectangle x1="16.73" y1="14.57" x2="17.15" y2="15.07" layer="51"/>
<rectangle x1="17.17" y1="14.57" x2="17.59" y2="15.07" layer="51"/>
<rectangle x1="17.61" y1="14.57" x2="18.03" y2="15.07" layer="51"/>
<rectangle x1="18.05" y1="14.57" x2="18.47" y2="15.07" layer="51"/>
<rectangle x1="18.49" y1="14.57" x2="18.91" y2="15.07" layer="51"/>
<rectangle x1="18.93" y1="14.57" x2="19.35" y2="15.07" layer="51"/>
<rectangle x1="19.37" y1="14.57" x2="19.79" y2="15.07" layer="51"/>
<rectangle x1="19.81" y1="14.57" x2="20.23" y2="15.07" layer="51"/>
<rectangle x1="20.25" y1="14.57" x2="20.67" y2="15.07" layer="51"/>
<rectangle x1="20.69" y1="14.57" x2="21.11" y2="15.07" layer="51"/>
<rectangle x1="21.13" y1="14.57" x2="21.55" y2="15.07" layer="51"/>
<rectangle x1="21.57" y1="14.57" x2="21.99" y2="15.07" layer="51"/>
<rectangle x1="22.01" y1="14.57" x2="22.43" y2="15.07" layer="51"/>
<rectangle x1="22.45" y1="14.57" x2="22.87" y2="15.07" layer="51"/>
<rectangle x1="22.89" y1="14.57" x2="23.31" y2="15.07" layer="51"/>
<rectangle x1="23.33" y1="14.57" x2="23.75" y2="15.07" layer="51"/>
<rectangle x1="23.77" y1="14.57" x2="24.19" y2="15.07" layer="51"/>
<rectangle x1="24.21" y1="14.57" x2="24.63" y2="15.07" layer="51"/>
<rectangle x1="24.65" y1="14.57" x2="25.07" y2="15.07" layer="51"/>
<rectangle x1="25.09" y1="14.57" x2="25.51" y2="15.07" layer="51"/>
<rectangle x1="25.53" y1="14.57" x2="25.95" y2="15.07" layer="51"/>
<rectangle x1="25.97" y1="14.57" x2="26.39" y2="15.07" layer="51"/>
<rectangle x1="26.41" y1="14.57" x2="26.83" y2="15.07" layer="51"/>
<rectangle x1="26.85" y1="14.57" x2="27.27" y2="15.07" layer="51"/>
<rectangle x1="27.29" y1="14.57" x2="27.71" y2="15.07" layer="51"/>
<rectangle x1="27.73" y1="14.57" x2="28.15" y2="15.07" layer="51"/>
<rectangle x1="-28.15" y1="14.05" x2="-27.73" y2="14.55" layer="51"/>
<rectangle x1="-27.71" y1="14.05" x2="-27.29" y2="14.55" layer="51"/>
<rectangle x1="-27.27" y1="14.05" x2="-26.85" y2="14.55" layer="51"/>
<rectangle x1="-26.83" y1="14.05" x2="-26.41" y2="14.55" layer="51"/>
<rectangle x1="-26.39" y1="14.05" x2="-25.97" y2="14.55" layer="51"/>
<rectangle x1="-25.95" y1="14.05" x2="-25.53" y2="14.55" layer="51"/>
<rectangle x1="-25.51" y1="14.05" x2="-25.09" y2="14.55" layer="51"/>
<rectangle x1="-25.07" y1="14.05" x2="-24.65" y2="14.55" layer="51"/>
<rectangle x1="-24.63" y1="14.05" x2="-24.21" y2="14.55" layer="51"/>
<rectangle x1="-24.19" y1="14.05" x2="-23.77" y2="14.55" layer="51"/>
<rectangle x1="-23.75" y1="14.05" x2="-23.33" y2="14.55" layer="51"/>
<rectangle x1="-23.31" y1="14.05" x2="-22.89" y2="14.55" layer="51"/>
<rectangle x1="-22.87" y1="14.05" x2="-22.45" y2="14.55" layer="51"/>
<rectangle x1="-22.43" y1="14.05" x2="-22.01" y2="14.55" layer="51"/>
<rectangle x1="-21.99" y1="14.05" x2="-21.57" y2="14.55" layer="51"/>
<rectangle x1="-21.55" y1="14.05" x2="-21.13" y2="14.55" layer="51"/>
<rectangle x1="-21.11" y1="14.05" x2="-20.69" y2="14.55" layer="51"/>
<rectangle x1="-20.67" y1="14.05" x2="-20.25" y2="14.55" layer="51"/>
<rectangle x1="-20.23" y1="14.05" x2="-19.81" y2="14.55" layer="51"/>
<rectangle x1="-19.79" y1="14.05" x2="-19.37" y2="14.55" layer="51"/>
<rectangle x1="-19.35" y1="14.05" x2="-18.93" y2="14.55" layer="51"/>
<rectangle x1="-18.91" y1="14.05" x2="-18.49" y2="14.55" layer="51"/>
<rectangle x1="-18.47" y1="14.05" x2="-18.05" y2="14.55" layer="51"/>
<rectangle x1="-18.03" y1="14.05" x2="-17.61" y2="14.55" layer="51"/>
<rectangle x1="-17.59" y1="14.05" x2="-17.17" y2="14.55" layer="51"/>
<rectangle x1="-17.15" y1="14.05" x2="-16.73" y2="14.55" layer="51"/>
<rectangle x1="-16.71" y1="14.05" x2="-16.29" y2="14.55" layer="51"/>
<rectangle x1="-16.27" y1="14.05" x2="-15.85" y2="14.55" layer="51"/>
<rectangle x1="-15.83" y1="14.05" x2="-15.41" y2="14.55" layer="51"/>
<rectangle x1="-15.39" y1="14.05" x2="-14.97" y2="14.55" layer="51"/>
<rectangle x1="-14.95" y1="14.05" x2="-14.53" y2="14.55" layer="51"/>
<rectangle x1="-14.51" y1="14.05" x2="-14.09" y2="14.55" layer="51"/>
<rectangle x1="-14.07" y1="14.05" x2="-13.65" y2="14.55" layer="51"/>
<rectangle x1="-13.63" y1="14.05" x2="-13.21" y2="14.55" layer="51"/>
<rectangle x1="-13.19" y1="14.05" x2="-12.77" y2="14.55" layer="51"/>
<rectangle x1="-12.75" y1="14.05" x2="-12.33" y2="14.55" layer="51"/>
<rectangle x1="-12.31" y1="14.05" x2="-11.89" y2="14.55" layer="51"/>
<rectangle x1="-11.87" y1="14.05" x2="-11.45" y2="14.55" layer="51"/>
<rectangle x1="-11.43" y1="14.05" x2="-11.01" y2="14.55" layer="51"/>
<rectangle x1="-10.99" y1="14.05" x2="-10.57" y2="14.55" layer="51"/>
<rectangle x1="-10.55" y1="14.05" x2="-10.13" y2="14.55" layer="51"/>
<rectangle x1="-10.11" y1="14.05" x2="-9.69" y2="14.55" layer="51"/>
<rectangle x1="-9.67" y1="14.05" x2="-9.25" y2="14.55" layer="51"/>
<rectangle x1="-9.23" y1="14.05" x2="-8.81" y2="14.55" layer="51"/>
<rectangle x1="-8.79" y1="14.05" x2="-8.37" y2="14.55" layer="51"/>
<rectangle x1="-8.35" y1="14.05" x2="-7.93" y2="14.55" layer="51"/>
<rectangle x1="-7.91" y1="14.05" x2="-7.49" y2="14.55" layer="51"/>
<rectangle x1="-7.47" y1="14.05" x2="-7.05" y2="14.55" layer="51"/>
<rectangle x1="-7.03" y1="14.05" x2="-6.61" y2="14.55" layer="51"/>
<rectangle x1="-6.59" y1="14.05" x2="-6.17" y2="14.55" layer="51"/>
<rectangle x1="-6.15" y1="14.05" x2="-5.73" y2="14.55" layer="51"/>
<rectangle x1="-5.71" y1="14.05" x2="-5.29" y2="14.55" layer="51"/>
<rectangle x1="-5.27" y1="14.05" x2="-4.85" y2="14.55" layer="51"/>
<rectangle x1="-4.83" y1="14.05" x2="-4.41" y2="14.55" layer="51"/>
<rectangle x1="-4.39" y1="14.05" x2="-3.97" y2="14.55" layer="51"/>
<rectangle x1="-3.95" y1="14.05" x2="-3.53" y2="14.55" layer="51"/>
<rectangle x1="-3.51" y1="14.05" x2="-3.09" y2="14.55" layer="51"/>
<rectangle x1="-3.07" y1="14.05" x2="-2.65" y2="14.55" layer="51"/>
<rectangle x1="-2.63" y1="14.05" x2="-2.21" y2="14.55" layer="51"/>
<rectangle x1="-2.19" y1="14.05" x2="-1.77" y2="14.55" layer="51"/>
<rectangle x1="-1.75" y1="14.05" x2="-1.33" y2="14.55" layer="51"/>
<rectangle x1="-1.31" y1="14.05" x2="-0.89" y2="14.55" layer="51"/>
<rectangle x1="-0.87" y1="14.05" x2="-0.45" y2="14.55" layer="51"/>
<rectangle x1="-0.43" y1="14.05" x2="-0.01" y2="14.55" layer="51"/>
<rectangle x1="0.01" y1="14.05" x2="0.43" y2="14.55" layer="51"/>
<rectangle x1="0.45" y1="14.05" x2="0.87" y2="14.55" layer="51"/>
<rectangle x1="0.89" y1="14.05" x2="1.31" y2="14.55" layer="51"/>
<rectangle x1="1.33" y1="14.05" x2="1.75" y2="14.55" layer="51"/>
<rectangle x1="1.77" y1="14.05" x2="2.19" y2="14.55" layer="51"/>
<rectangle x1="2.21" y1="14.05" x2="2.63" y2="14.55" layer="51"/>
<rectangle x1="2.65" y1="14.05" x2="3.07" y2="14.55" layer="51"/>
<rectangle x1="3.09" y1="14.05" x2="3.51" y2="14.55" layer="51"/>
<rectangle x1="3.53" y1="14.05" x2="3.95" y2="14.55" layer="51"/>
<rectangle x1="3.97" y1="14.05" x2="4.39" y2="14.55" layer="51"/>
<rectangle x1="4.41" y1="14.05" x2="4.83" y2="14.55" layer="51"/>
<rectangle x1="4.85" y1="14.05" x2="5.27" y2="14.55" layer="51"/>
<rectangle x1="5.29" y1="14.05" x2="5.71" y2="14.55" layer="51"/>
<rectangle x1="5.73" y1="14.05" x2="6.15" y2="14.55" layer="51"/>
<rectangle x1="6.17" y1="14.05" x2="6.59" y2="14.55" layer="51"/>
<rectangle x1="6.61" y1="14.05" x2="7.03" y2="14.55" layer="51"/>
<rectangle x1="7.05" y1="14.05" x2="7.47" y2="14.55" layer="51"/>
<rectangle x1="7.49" y1="14.05" x2="7.91" y2="14.55" layer="51"/>
<rectangle x1="7.93" y1="14.05" x2="8.35" y2="14.55" layer="51"/>
<rectangle x1="8.37" y1="14.05" x2="8.79" y2="14.55" layer="51"/>
<rectangle x1="8.81" y1="14.05" x2="9.23" y2="14.55" layer="51"/>
<rectangle x1="9.25" y1="14.05" x2="9.67" y2="14.55" layer="51"/>
<rectangle x1="9.69" y1="14.05" x2="10.11" y2="14.55" layer="51"/>
<rectangle x1="10.13" y1="14.05" x2="10.55" y2="14.55" layer="51"/>
<rectangle x1="10.57" y1="14.05" x2="10.99" y2="14.55" layer="51"/>
<rectangle x1="11.01" y1="14.05" x2="11.43" y2="14.55" layer="51"/>
<rectangle x1="11.45" y1="14.05" x2="11.87" y2="14.55" layer="51"/>
<rectangle x1="11.89" y1="14.05" x2="12.31" y2="14.55" layer="51"/>
<rectangle x1="12.33" y1="14.05" x2="12.75" y2="14.55" layer="51"/>
<rectangle x1="12.77" y1="14.05" x2="13.19" y2="14.55" layer="51"/>
<rectangle x1="13.21" y1="14.05" x2="13.63" y2="14.55" layer="51"/>
<rectangle x1="13.65" y1="14.05" x2="14.07" y2="14.55" layer="51"/>
<rectangle x1="14.09" y1="14.05" x2="14.51" y2="14.55" layer="51"/>
<rectangle x1="14.53" y1="14.05" x2="14.95" y2="14.55" layer="51"/>
<rectangle x1="14.97" y1="14.05" x2="15.39" y2="14.55" layer="51"/>
<rectangle x1="15.41" y1="14.05" x2="15.83" y2="14.55" layer="51"/>
<rectangle x1="15.85" y1="14.05" x2="16.27" y2="14.55" layer="51"/>
<rectangle x1="16.29" y1="14.05" x2="16.71" y2="14.55" layer="51"/>
<rectangle x1="16.73" y1="14.05" x2="17.15" y2="14.55" layer="51"/>
<rectangle x1="17.17" y1="14.05" x2="17.59" y2="14.55" layer="51"/>
<rectangle x1="17.61" y1="14.05" x2="18.03" y2="14.55" layer="51"/>
<rectangle x1="18.05" y1="14.05" x2="18.47" y2="14.55" layer="51"/>
<rectangle x1="18.49" y1="14.05" x2="18.91" y2="14.55" layer="51"/>
<rectangle x1="18.93" y1="14.05" x2="19.35" y2="14.55" layer="51"/>
<rectangle x1="19.37" y1="14.05" x2="19.79" y2="14.55" layer="51"/>
<rectangle x1="19.81" y1="14.05" x2="20.23" y2="14.55" layer="51"/>
<rectangle x1="20.25" y1="14.05" x2="20.67" y2="14.55" layer="51"/>
<rectangle x1="20.69" y1="14.05" x2="21.11" y2="14.55" layer="51"/>
<rectangle x1="21.13" y1="14.05" x2="21.55" y2="14.55" layer="51"/>
<rectangle x1="21.57" y1="14.05" x2="21.99" y2="14.55" layer="51"/>
<rectangle x1="22.01" y1="14.05" x2="22.43" y2="14.55" layer="51"/>
<rectangle x1="22.45" y1="14.05" x2="22.87" y2="14.55" layer="51"/>
<rectangle x1="22.89" y1="14.05" x2="23.31" y2="14.55" layer="51"/>
<rectangle x1="23.33" y1="14.05" x2="23.75" y2="14.55" layer="51"/>
<rectangle x1="23.77" y1="14.05" x2="24.19" y2="14.55" layer="51"/>
<rectangle x1="24.21" y1="14.05" x2="24.63" y2="14.55" layer="51"/>
<rectangle x1="24.65" y1="14.05" x2="25.07" y2="14.55" layer="51"/>
<rectangle x1="25.09" y1="14.05" x2="25.51" y2="14.55" layer="51"/>
<rectangle x1="25.53" y1="14.05" x2="25.95" y2="14.55" layer="51"/>
<rectangle x1="25.97" y1="14.05" x2="26.39" y2="14.55" layer="51"/>
<rectangle x1="26.41" y1="14.05" x2="26.83" y2="14.55" layer="51"/>
<rectangle x1="26.85" y1="14.05" x2="27.27" y2="14.55" layer="51"/>
<rectangle x1="27.29" y1="14.05" x2="27.71" y2="14.55" layer="51"/>
<rectangle x1="27.73" y1="14.05" x2="28.15" y2="14.55" layer="51"/>
<rectangle x1="-28.15" y1="13.53" x2="-27.73" y2="14.03" layer="51"/>
<rectangle x1="-27.71" y1="13.53" x2="-27.29" y2="14.03" layer="51"/>
<rectangle x1="-27.27" y1="13.53" x2="-26.85" y2="14.03" layer="51"/>
<rectangle x1="-26.83" y1="13.53" x2="-26.41" y2="14.03" layer="51"/>
<rectangle x1="-26.39" y1="13.53" x2="-25.97" y2="14.03" layer="51"/>
<rectangle x1="-25.95" y1="13.53" x2="-25.53" y2="14.03" layer="51"/>
<rectangle x1="-25.51" y1="13.53" x2="-25.09" y2="14.03" layer="51"/>
<rectangle x1="-25.07" y1="13.53" x2="-24.65" y2="14.03" layer="51"/>
<rectangle x1="-24.63" y1="13.53" x2="-24.21" y2="14.03" layer="51"/>
<rectangle x1="-24.19" y1="13.53" x2="-23.77" y2="14.03" layer="51"/>
<rectangle x1="-23.75" y1="13.53" x2="-23.33" y2="14.03" layer="51"/>
<rectangle x1="-23.31" y1="13.53" x2="-22.89" y2="14.03" layer="51"/>
<rectangle x1="-22.87" y1="13.53" x2="-22.45" y2="14.03" layer="51"/>
<rectangle x1="-22.43" y1="13.53" x2="-22.01" y2="14.03" layer="51"/>
<rectangle x1="-21.99" y1="13.53" x2="-21.57" y2="14.03" layer="51"/>
<rectangle x1="-21.55" y1="13.53" x2="-21.13" y2="14.03" layer="51"/>
<rectangle x1="-21.11" y1="13.53" x2="-20.69" y2="14.03" layer="51"/>
<rectangle x1="-20.67" y1="13.53" x2="-20.25" y2="14.03" layer="51"/>
<rectangle x1="-20.23" y1="13.53" x2="-19.81" y2="14.03" layer="51"/>
<rectangle x1="-19.79" y1="13.53" x2="-19.37" y2="14.03" layer="51"/>
<rectangle x1="-19.35" y1="13.53" x2="-18.93" y2="14.03" layer="51"/>
<rectangle x1="-18.91" y1="13.53" x2="-18.49" y2="14.03" layer="51"/>
<rectangle x1="-18.47" y1="13.53" x2="-18.05" y2="14.03" layer="51"/>
<rectangle x1="-18.03" y1="13.53" x2="-17.61" y2="14.03" layer="51"/>
<rectangle x1="-17.59" y1="13.53" x2="-17.17" y2="14.03" layer="51"/>
<rectangle x1="-17.15" y1="13.53" x2="-16.73" y2="14.03" layer="51"/>
<rectangle x1="-16.71" y1="13.53" x2="-16.29" y2="14.03" layer="51"/>
<rectangle x1="-16.27" y1="13.53" x2="-15.85" y2="14.03" layer="51"/>
<rectangle x1="-15.83" y1="13.53" x2="-15.41" y2="14.03" layer="51"/>
<rectangle x1="-15.39" y1="13.53" x2="-14.97" y2="14.03" layer="51"/>
<rectangle x1="-14.95" y1="13.53" x2="-14.53" y2="14.03" layer="51"/>
<rectangle x1="-14.51" y1="13.53" x2="-14.09" y2="14.03" layer="51"/>
<rectangle x1="-14.07" y1="13.53" x2="-13.65" y2="14.03" layer="51"/>
<rectangle x1="-13.63" y1="13.53" x2="-13.21" y2="14.03" layer="51"/>
<rectangle x1="-13.19" y1="13.53" x2="-12.77" y2="14.03" layer="51"/>
<rectangle x1="-12.75" y1="13.53" x2="-12.33" y2="14.03" layer="51"/>
<rectangle x1="-12.31" y1="13.53" x2="-11.89" y2="14.03" layer="51"/>
<rectangle x1="-11.87" y1="13.53" x2="-11.45" y2="14.03" layer="51"/>
<rectangle x1="-11.43" y1="13.53" x2="-11.01" y2="14.03" layer="51"/>
<rectangle x1="-10.99" y1="13.53" x2="-10.57" y2="14.03" layer="51"/>
<rectangle x1="-10.55" y1="13.53" x2="-10.13" y2="14.03" layer="51"/>
<rectangle x1="-10.11" y1="13.53" x2="-9.69" y2="14.03" layer="51"/>
<rectangle x1="-9.67" y1="13.53" x2="-9.25" y2="14.03" layer="51"/>
<rectangle x1="-9.23" y1="13.53" x2="-8.81" y2="14.03" layer="51"/>
<rectangle x1="-8.79" y1="13.53" x2="-8.37" y2="14.03" layer="51"/>
<rectangle x1="-8.35" y1="13.53" x2="-7.93" y2="14.03" layer="51"/>
<rectangle x1="-7.91" y1="13.53" x2="-7.49" y2="14.03" layer="51"/>
<rectangle x1="-7.47" y1="13.53" x2="-7.05" y2="14.03" layer="51"/>
<rectangle x1="-7.03" y1="13.53" x2="-6.61" y2="14.03" layer="51"/>
<rectangle x1="-6.59" y1="13.53" x2="-6.17" y2="14.03" layer="51"/>
<rectangle x1="-6.15" y1="13.53" x2="-5.73" y2="14.03" layer="51"/>
<rectangle x1="-5.71" y1="13.53" x2="-5.29" y2="14.03" layer="51"/>
<rectangle x1="-5.27" y1="13.53" x2="-4.85" y2="14.03" layer="51"/>
<rectangle x1="-4.83" y1="13.53" x2="-4.41" y2="14.03" layer="51"/>
<rectangle x1="-4.39" y1="13.53" x2="-3.97" y2="14.03" layer="51"/>
<rectangle x1="-3.95" y1="13.53" x2="-3.53" y2="14.03" layer="51"/>
<rectangle x1="-3.51" y1="13.53" x2="-3.09" y2="14.03" layer="51"/>
<rectangle x1="-3.07" y1="13.53" x2="-2.65" y2="14.03" layer="51"/>
<rectangle x1="-2.63" y1="13.53" x2="-2.21" y2="14.03" layer="51"/>
<rectangle x1="-2.19" y1="13.53" x2="-1.77" y2="14.03" layer="51"/>
<rectangle x1="-1.75" y1="13.53" x2="-1.33" y2="14.03" layer="51"/>
<rectangle x1="-1.31" y1="13.53" x2="-0.89" y2="14.03" layer="51"/>
<rectangle x1="-0.87" y1="13.53" x2="-0.45" y2="14.03" layer="51"/>
<rectangle x1="-0.43" y1="13.53" x2="-0.01" y2="14.03" layer="51"/>
<rectangle x1="0.01" y1="13.53" x2="0.43" y2="14.03" layer="51"/>
<rectangle x1="0.45" y1="13.53" x2="0.87" y2="14.03" layer="51"/>
<rectangle x1="0.89" y1="13.53" x2="1.31" y2="14.03" layer="51"/>
<rectangle x1="1.33" y1="13.53" x2="1.75" y2="14.03" layer="51"/>
<rectangle x1="1.77" y1="13.53" x2="2.19" y2="14.03" layer="51"/>
<rectangle x1="2.21" y1="13.53" x2="2.63" y2="14.03" layer="51"/>
<rectangle x1="2.65" y1="13.53" x2="3.07" y2="14.03" layer="51"/>
<rectangle x1="3.09" y1="13.53" x2="3.51" y2="14.03" layer="51"/>
<rectangle x1="3.53" y1="13.53" x2="3.95" y2="14.03" layer="51"/>
<rectangle x1="3.97" y1="13.53" x2="4.39" y2="14.03" layer="51"/>
<rectangle x1="4.41" y1="13.53" x2="4.83" y2="14.03" layer="51"/>
<rectangle x1="4.85" y1="13.53" x2="5.27" y2="14.03" layer="51"/>
<rectangle x1="5.29" y1="13.53" x2="5.71" y2="14.03" layer="51"/>
<rectangle x1="5.73" y1="13.53" x2="6.15" y2="14.03" layer="51"/>
<rectangle x1="6.17" y1="13.53" x2="6.59" y2="14.03" layer="51"/>
<rectangle x1="6.61" y1="13.53" x2="7.03" y2="14.03" layer="51"/>
<rectangle x1="7.05" y1="13.53" x2="7.47" y2="14.03" layer="51"/>
<rectangle x1="7.49" y1="13.53" x2="7.91" y2="14.03" layer="51"/>
<rectangle x1="7.93" y1="13.53" x2="8.35" y2="14.03" layer="51"/>
<rectangle x1="8.37" y1="13.53" x2="8.79" y2="14.03" layer="51"/>
<rectangle x1="8.81" y1="13.53" x2="9.23" y2="14.03" layer="51"/>
<rectangle x1="9.25" y1="13.53" x2="9.67" y2="14.03" layer="51"/>
<rectangle x1="9.69" y1="13.53" x2="10.11" y2="14.03" layer="51"/>
<rectangle x1="10.13" y1="13.53" x2="10.55" y2="14.03" layer="51"/>
<rectangle x1="10.57" y1="13.53" x2="10.99" y2="14.03" layer="51"/>
<rectangle x1="11.01" y1="13.53" x2="11.43" y2="14.03" layer="51"/>
<rectangle x1="11.45" y1="13.53" x2="11.87" y2="14.03" layer="51"/>
<rectangle x1="11.89" y1="13.53" x2="12.31" y2="14.03" layer="51"/>
<rectangle x1="12.33" y1="13.53" x2="12.75" y2="14.03" layer="51"/>
<rectangle x1="12.77" y1="13.53" x2="13.19" y2="14.03" layer="51"/>
<rectangle x1="13.21" y1="13.53" x2="13.63" y2="14.03" layer="51"/>
<rectangle x1="13.65" y1="13.53" x2="14.07" y2="14.03" layer="51"/>
<rectangle x1="14.09" y1="13.53" x2="14.51" y2="14.03" layer="51"/>
<rectangle x1="14.53" y1="13.53" x2="14.95" y2="14.03" layer="51"/>
<rectangle x1="14.97" y1="13.53" x2="15.39" y2="14.03" layer="51"/>
<rectangle x1="15.41" y1="13.53" x2="15.83" y2="14.03" layer="51"/>
<rectangle x1="15.85" y1="13.53" x2="16.27" y2="14.03" layer="51"/>
<rectangle x1="16.29" y1="13.53" x2="16.71" y2="14.03" layer="51"/>
<rectangle x1="16.73" y1="13.53" x2="17.15" y2="14.03" layer="51"/>
<rectangle x1="17.17" y1="13.53" x2="17.59" y2="14.03" layer="51"/>
<rectangle x1="17.61" y1="13.53" x2="18.03" y2="14.03" layer="51"/>
<rectangle x1="18.05" y1="13.53" x2="18.47" y2="14.03" layer="51"/>
<rectangle x1="18.49" y1="13.53" x2="18.91" y2="14.03" layer="51"/>
<rectangle x1="18.93" y1="13.53" x2="19.35" y2="14.03" layer="51"/>
<rectangle x1="19.37" y1="13.53" x2="19.79" y2="14.03" layer="51"/>
<rectangle x1="19.81" y1="13.53" x2="20.23" y2="14.03" layer="51"/>
<rectangle x1="20.25" y1="13.53" x2="20.67" y2="14.03" layer="51"/>
<rectangle x1="20.69" y1="13.53" x2="21.11" y2="14.03" layer="51"/>
<rectangle x1="21.13" y1="13.53" x2="21.55" y2="14.03" layer="51"/>
<rectangle x1="21.57" y1="13.53" x2="21.99" y2="14.03" layer="51"/>
<rectangle x1="22.01" y1="13.53" x2="22.43" y2="14.03" layer="51"/>
<rectangle x1="22.45" y1="13.53" x2="22.87" y2="14.03" layer="51"/>
<rectangle x1="22.89" y1="13.53" x2="23.31" y2="14.03" layer="51"/>
<rectangle x1="23.33" y1="13.53" x2="23.75" y2="14.03" layer="51"/>
<rectangle x1="23.77" y1="13.53" x2="24.19" y2="14.03" layer="51"/>
<rectangle x1="24.21" y1="13.53" x2="24.63" y2="14.03" layer="51"/>
<rectangle x1="24.65" y1="13.53" x2="25.07" y2="14.03" layer="51"/>
<rectangle x1="25.09" y1="13.53" x2="25.51" y2="14.03" layer="51"/>
<rectangle x1="25.53" y1="13.53" x2="25.95" y2="14.03" layer="51"/>
<rectangle x1="25.97" y1="13.53" x2="26.39" y2="14.03" layer="51"/>
<rectangle x1="26.41" y1="13.53" x2="26.83" y2="14.03" layer="51"/>
<rectangle x1="26.85" y1="13.53" x2="27.27" y2="14.03" layer="51"/>
<rectangle x1="27.29" y1="13.53" x2="27.71" y2="14.03" layer="51"/>
<rectangle x1="27.73" y1="13.53" x2="28.15" y2="14.03" layer="51"/>
<rectangle x1="-28.15" y1="13.01" x2="-27.73" y2="13.51" layer="51"/>
<rectangle x1="-27.71" y1="13.01" x2="-27.29" y2="13.51" layer="51"/>
<rectangle x1="-27.27" y1="13.01" x2="-26.85" y2="13.51" layer="51"/>
<rectangle x1="-26.83" y1="13.01" x2="-26.41" y2="13.51" layer="51"/>
<rectangle x1="-26.39" y1="13.01" x2="-25.97" y2="13.51" layer="51"/>
<rectangle x1="-25.95" y1="13.01" x2="-25.53" y2="13.51" layer="51"/>
<rectangle x1="-25.51" y1="13.01" x2="-25.09" y2="13.51" layer="51"/>
<rectangle x1="-25.07" y1="13.01" x2="-24.65" y2="13.51" layer="51"/>
<rectangle x1="-24.63" y1="13.01" x2="-24.21" y2="13.51" layer="51"/>
<rectangle x1="-24.19" y1="13.01" x2="-23.77" y2="13.51" layer="51"/>
<rectangle x1="-23.75" y1="13.01" x2="-23.33" y2="13.51" layer="51"/>
<rectangle x1="-23.31" y1="13.01" x2="-22.89" y2="13.51" layer="51"/>
<rectangle x1="-22.87" y1="13.01" x2="-22.45" y2="13.51" layer="51"/>
<rectangle x1="-22.43" y1="13.01" x2="-22.01" y2="13.51" layer="51"/>
<rectangle x1="-21.99" y1="13.01" x2="-21.57" y2="13.51" layer="51"/>
<rectangle x1="-21.55" y1="13.01" x2="-21.13" y2="13.51" layer="51"/>
<rectangle x1="-21.11" y1="13.01" x2="-20.69" y2="13.51" layer="51"/>
<rectangle x1="-20.67" y1="13.01" x2="-20.25" y2="13.51" layer="51"/>
<rectangle x1="-20.23" y1="13.01" x2="-19.81" y2="13.51" layer="51"/>
<rectangle x1="-19.79" y1="13.01" x2="-19.37" y2="13.51" layer="51"/>
<rectangle x1="-19.35" y1="13.01" x2="-18.93" y2="13.51" layer="51"/>
<rectangle x1="-18.91" y1="13.01" x2="-18.49" y2="13.51" layer="51"/>
<rectangle x1="-18.47" y1="13.01" x2="-18.05" y2="13.51" layer="51"/>
<rectangle x1="-18.03" y1="13.01" x2="-17.61" y2="13.51" layer="51"/>
<rectangle x1="-17.59" y1="13.01" x2="-17.17" y2="13.51" layer="51"/>
<rectangle x1="-17.15" y1="13.01" x2="-16.73" y2="13.51" layer="51"/>
<rectangle x1="-16.71" y1="13.01" x2="-16.29" y2="13.51" layer="51"/>
<rectangle x1="-16.27" y1="13.01" x2="-15.85" y2="13.51" layer="51"/>
<rectangle x1="-15.83" y1="13.01" x2="-15.41" y2="13.51" layer="51"/>
<rectangle x1="-15.39" y1="13.01" x2="-14.97" y2="13.51" layer="51"/>
<rectangle x1="-14.95" y1="13.01" x2="-14.53" y2="13.51" layer="51"/>
<rectangle x1="-14.51" y1="13.01" x2="-14.09" y2="13.51" layer="51"/>
<rectangle x1="-14.07" y1="13.01" x2="-13.65" y2="13.51" layer="51"/>
<rectangle x1="-13.63" y1="13.01" x2="-13.21" y2="13.51" layer="51"/>
<rectangle x1="-13.19" y1="13.01" x2="-12.77" y2="13.51" layer="51"/>
<rectangle x1="-12.75" y1="13.01" x2="-12.33" y2="13.51" layer="51"/>
<rectangle x1="-12.31" y1="13.01" x2="-11.89" y2="13.51" layer="51"/>
<rectangle x1="-11.87" y1="13.01" x2="-11.45" y2="13.51" layer="51"/>
<rectangle x1="-11.43" y1="13.01" x2="-11.01" y2="13.51" layer="51"/>
<rectangle x1="-10.99" y1="13.01" x2="-10.57" y2="13.51" layer="51"/>
<rectangle x1="-10.55" y1="13.01" x2="-10.13" y2="13.51" layer="51"/>
<rectangle x1="-10.11" y1="13.01" x2="-9.69" y2="13.51" layer="51"/>
<rectangle x1="-9.67" y1="13.01" x2="-9.25" y2="13.51" layer="51"/>
<rectangle x1="-9.23" y1="13.01" x2="-8.81" y2="13.51" layer="51"/>
<rectangle x1="-8.79" y1="13.01" x2="-8.37" y2="13.51" layer="51"/>
<rectangle x1="-8.35" y1="13.01" x2="-7.93" y2="13.51" layer="51"/>
<rectangle x1="-7.91" y1="13.01" x2="-7.49" y2="13.51" layer="51"/>
<rectangle x1="-7.47" y1="13.01" x2="-7.05" y2="13.51" layer="51"/>
<rectangle x1="-7.03" y1="13.01" x2="-6.61" y2="13.51" layer="51"/>
<rectangle x1="-6.59" y1="13.01" x2="-6.17" y2="13.51" layer="51"/>
<rectangle x1="-6.15" y1="13.01" x2="-5.73" y2="13.51" layer="51"/>
<rectangle x1="-5.71" y1="13.01" x2="-5.29" y2="13.51" layer="51"/>
<rectangle x1="-5.27" y1="13.01" x2="-4.85" y2="13.51" layer="51"/>
<rectangle x1="-4.83" y1="13.01" x2="-4.41" y2="13.51" layer="51"/>
<rectangle x1="-4.39" y1="13.01" x2="-3.97" y2="13.51" layer="51"/>
<rectangle x1="-3.95" y1="13.01" x2="-3.53" y2="13.51" layer="51"/>
<rectangle x1="-3.51" y1="13.01" x2="-3.09" y2="13.51" layer="51"/>
<rectangle x1="-3.07" y1="13.01" x2="-2.65" y2="13.51" layer="51"/>
<rectangle x1="-2.63" y1="13.01" x2="-2.21" y2="13.51" layer="51"/>
<rectangle x1="-2.19" y1="13.01" x2="-1.77" y2="13.51" layer="51"/>
<rectangle x1="-1.75" y1="13.01" x2="-1.33" y2="13.51" layer="51"/>
<rectangle x1="-1.31" y1="13.01" x2="-0.89" y2="13.51" layer="51"/>
<rectangle x1="-0.87" y1="13.01" x2="-0.45" y2="13.51" layer="51"/>
<rectangle x1="-0.43" y1="13.01" x2="-0.01" y2="13.51" layer="51"/>
<rectangle x1="0.01" y1="13.01" x2="0.43" y2="13.51" layer="51"/>
<rectangle x1="0.45" y1="13.01" x2="0.87" y2="13.51" layer="51"/>
<rectangle x1="0.89" y1="13.01" x2="1.31" y2="13.51" layer="51"/>
<rectangle x1="1.33" y1="13.01" x2="1.75" y2="13.51" layer="51"/>
<rectangle x1="1.77" y1="13.01" x2="2.19" y2="13.51" layer="51"/>
<rectangle x1="2.21" y1="13.01" x2="2.63" y2="13.51" layer="51"/>
<rectangle x1="2.65" y1="13.01" x2="3.07" y2="13.51" layer="51"/>
<rectangle x1="3.09" y1="13.01" x2="3.51" y2="13.51" layer="51"/>
<rectangle x1="3.53" y1="13.01" x2="3.95" y2="13.51" layer="51"/>
<rectangle x1="3.97" y1="13.01" x2="4.39" y2="13.51" layer="51"/>
<rectangle x1="4.41" y1="13.01" x2="4.83" y2="13.51" layer="51"/>
<rectangle x1="4.85" y1="13.01" x2="5.27" y2="13.51" layer="51"/>
<rectangle x1="5.29" y1="13.01" x2="5.71" y2="13.51" layer="51"/>
<rectangle x1="5.73" y1="13.01" x2="6.15" y2="13.51" layer="51"/>
<rectangle x1="6.17" y1="13.01" x2="6.59" y2="13.51" layer="51"/>
<rectangle x1="6.61" y1="13.01" x2="7.03" y2="13.51" layer="51"/>
<rectangle x1="7.05" y1="13.01" x2="7.47" y2="13.51" layer="51"/>
<rectangle x1="7.49" y1="13.01" x2="7.91" y2="13.51" layer="51"/>
<rectangle x1="7.93" y1="13.01" x2="8.35" y2="13.51" layer="51"/>
<rectangle x1="8.37" y1="13.01" x2="8.79" y2="13.51" layer="51"/>
<rectangle x1="8.81" y1="13.01" x2="9.23" y2="13.51" layer="51"/>
<rectangle x1="9.25" y1="13.01" x2="9.67" y2="13.51" layer="51"/>
<rectangle x1="9.69" y1="13.01" x2="10.11" y2="13.51" layer="51"/>
<rectangle x1="10.13" y1="13.01" x2="10.55" y2="13.51" layer="51"/>
<rectangle x1="10.57" y1="13.01" x2="10.99" y2="13.51" layer="51"/>
<rectangle x1="11.01" y1="13.01" x2="11.43" y2="13.51" layer="51"/>
<rectangle x1="11.45" y1="13.01" x2="11.87" y2="13.51" layer="51"/>
<rectangle x1="11.89" y1="13.01" x2="12.31" y2="13.51" layer="51"/>
<rectangle x1="12.33" y1="13.01" x2="12.75" y2="13.51" layer="51"/>
<rectangle x1="12.77" y1="13.01" x2="13.19" y2="13.51" layer="51"/>
<rectangle x1="13.21" y1="13.01" x2="13.63" y2="13.51" layer="51"/>
<rectangle x1="13.65" y1="13.01" x2="14.07" y2="13.51" layer="51"/>
<rectangle x1="14.09" y1="13.01" x2="14.51" y2="13.51" layer="51"/>
<rectangle x1="14.53" y1="13.01" x2="14.95" y2="13.51" layer="51"/>
<rectangle x1="14.97" y1="13.01" x2="15.39" y2="13.51" layer="51"/>
<rectangle x1="15.41" y1="13.01" x2="15.83" y2="13.51" layer="51"/>
<rectangle x1="15.85" y1="13.01" x2="16.27" y2="13.51" layer="51"/>
<rectangle x1="16.29" y1="13.01" x2="16.71" y2="13.51" layer="51"/>
<rectangle x1="16.73" y1="13.01" x2="17.15" y2="13.51" layer="51"/>
<rectangle x1="17.17" y1="13.01" x2="17.59" y2="13.51" layer="51"/>
<rectangle x1="17.61" y1="13.01" x2="18.03" y2="13.51" layer="51"/>
<rectangle x1="18.05" y1="13.01" x2="18.47" y2="13.51" layer="51"/>
<rectangle x1="18.49" y1="13.01" x2="18.91" y2="13.51" layer="51"/>
<rectangle x1="18.93" y1="13.01" x2="19.35" y2="13.51" layer="51"/>
<rectangle x1="19.37" y1="13.01" x2="19.79" y2="13.51" layer="51"/>
<rectangle x1="19.81" y1="13.01" x2="20.23" y2="13.51" layer="51"/>
<rectangle x1="20.25" y1="13.01" x2="20.67" y2="13.51" layer="51"/>
<rectangle x1="20.69" y1="13.01" x2="21.11" y2="13.51" layer="51"/>
<rectangle x1="21.13" y1="13.01" x2="21.55" y2="13.51" layer="51"/>
<rectangle x1="21.57" y1="13.01" x2="21.99" y2="13.51" layer="51"/>
<rectangle x1="22.01" y1="13.01" x2="22.43" y2="13.51" layer="51"/>
<rectangle x1="22.45" y1="13.01" x2="22.87" y2="13.51" layer="51"/>
<rectangle x1="22.89" y1="13.01" x2="23.31" y2="13.51" layer="51"/>
<rectangle x1="23.33" y1="13.01" x2="23.75" y2="13.51" layer="51"/>
<rectangle x1="23.77" y1="13.01" x2="24.19" y2="13.51" layer="51"/>
<rectangle x1="24.21" y1="13.01" x2="24.63" y2="13.51" layer="51"/>
<rectangle x1="24.65" y1="13.01" x2="25.07" y2="13.51" layer="51"/>
<rectangle x1="25.09" y1="13.01" x2="25.51" y2="13.51" layer="51"/>
<rectangle x1="25.53" y1="13.01" x2="25.95" y2="13.51" layer="51"/>
<rectangle x1="25.97" y1="13.01" x2="26.39" y2="13.51" layer="51"/>
<rectangle x1="26.41" y1="13.01" x2="26.83" y2="13.51" layer="51"/>
<rectangle x1="26.85" y1="13.01" x2="27.27" y2="13.51" layer="51"/>
<rectangle x1="27.29" y1="13.01" x2="27.71" y2="13.51" layer="51"/>
<rectangle x1="27.73" y1="13.01" x2="28.15" y2="13.51" layer="51"/>
<rectangle x1="-28.15" y1="12.49" x2="-27.73" y2="12.99" layer="51"/>
<rectangle x1="-27.71" y1="12.49" x2="-27.29" y2="12.99" layer="51"/>
<rectangle x1="-27.27" y1="12.49" x2="-26.85" y2="12.99" layer="51"/>
<rectangle x1="-26.83" y1="12.49" x2="-26.41" y2="12.99" layer="51"/>
<rectangle x1="-26.39" y1="12.49" x2="-25.97" y2="12.99" layer="51"/>
<rectangle x1="-25.95" y1="12.49" x2="-25.53" y2="12.99" layer="51"/>
<rectangle x1="-25.51" y1="12.49" x2="-25.09" y2="12.99" layer="51"/>
<rectangle x1="-25.07" y1="12.49" x2="-24.65" y2="12.99" layer="51"/>
<rectangle x1="-24.63" y1="12.49" x2="-24.21" y2="12.99" layer="51"/>
<rectangle x1="-24.19" y1="12.49" x2="-23.77" y2="12.99" layer="51"/>
<rectangle x1="-23.75" y1="12.49" x2="-23.33" y2="12.99" layer="51"/>
<rectangle x1="-23.31" y1="12.49" x2="-22.89" y2="12.99" layer="51"/>
<rectangle x1="-22.87" y1="12.49" x2="-22.45" y2="12.99" layer="51"/>
<rectangle x1="-22.43" y1="12.49" x2="-22.01" y2="12.99" layer="51"/>
<rectangle x1="-21.99" y1="12.49" x2="-21.57" y2="12.99" layer="51"/>
<rectangle x1="-21.55" y1="12.49" x2="-21.13" y2="12.99" layer="51"/>
<rectangle x1="-21.11" y1="12.49" x2="-20.69" y2="12.99" layer="51"/>
<rectangle x1="-20.67" y1="12.49" x2="-20.25" y2="12.99" layer="51"/>
<rectangle x1="-20.23" y1="12.49" x2="-19.81" y2="12.99" layer="51"/>
<rectangle x1="-19.79" y1="12.49" x2="-19.37" y2="12.99" layer="51"/>
<rectangle x1="-19.35" y1="12.49" x2="-18.93" y2="12.99" layer="51"/>
<rectangle x1="-18.91" y1="12.49" x2="-18.49" y2="12.99" layer="51"/>
<rectangle x1="-18.47" y1="12.49" x2="-18.05" y2="12.99" layer="51"/>
<rectangle x1="-18.03" y1="12.49" x2="-17.61" y2="12.99" layer="51"/>
<rectangle x1="-17.59" y1="12.49" x2="-17.17" y2="12.99" layer="51"/>
<rectangle x1="-17.15" y1="12.49" x2="-16.73" y2="12.99" layer="51"/>
<rectangle x1="-16.71" y1="12.49" x2="-16.29" y2="12.99" layer="51"/>
<rectangle x1="-16.27" y1="12.49" x2="-15.85" y2="12.99" layer="51"/>
<rectangle x1="-15.83" y1="12.49" x2="-15.41" y2="12.99" layer="51"/>
<rectangle x1="-15.39" y1="12.49" x2="-14.97" y2="12.99" layer="51"/>
<rectangle x1="-14.95" y1="12.49" x2="-14.53" y2="12.99" layer="51"/>
<rectangle x1="-14.51" y1="12.49" x2="-14.09" y2="12.99" layer="51"/>
<rectangle x1="-14.07" y1="12.49" x2="-13.65" y2="12.99" layer="51"/>
<rectangle x1="-13.63" y1="12.49" x2="-13.21" y2="12.99" layer="51"/>
<rectangle x1="-13.19" y1="12.49" x2="-12.77" y2="12.99" layer="51"/>
<rectangle x1="-12.75" y1="12.49" x2="-12.33" y2="12.99" layer="51"/>
<rectangle x1="-12.31" y1="12.49" x2="-11.89" y2="12.99" layer="51"/>
<rectangle x1="-11.87" y1="12.49" x2="-11.45" y2="12.99" layer="51"/>
<rectangle x1="-11.43" y1="12.49" x2="-11.01" y2="12.99" layer="51"/>
<rectangle x1="-10.99" y1="12.49" x2="-10.57" y2="12.99" layer="51"/>
<rectangle x1="-10.55" y1="12.49" x2="-10.13" y2="12.99" layer="51"/>
<rectangle x1="-10.11" y1="12.49" x2="-9.69" y2="12.99" layer="51"/>
<rectangle x1="-9.67" y1="12.49" x2="-9.25" y2="12.99" layer="51"/>
<rectangle x1="-9.23" y1="12.49" x2="-8.81" y2="12.99" layer="51"/>
<rectangle x1="-8.79" y1="12.49" x2="-8.37" y2="12.99" layer="51"/>
<rectangle x1="-8.35" y1="12.49" x2="-7.93" y2="12.99" layer="51"/>
<rectangle x1="-7.91" y1="12.49" x2="-7.49" y2="12.99" layer="51"/>
<rectangle x1="-7.47" y1="12.49" x2="-7.05" y2="12.99" layer="51"/>
<rectangle x1="-7.03" y1="12.49" x2="-6.61" y2="12.99" layer="51"/>
<rectangle x1="-6.59" y1="12.49" x2="-6.17" y2="12.99" layer="51"/>
<rectangle x1="-6.15" y1="12.49" x2="-5.73" y2="12.99" layer="51"/>
<rectangle x1="-5.71" y1="12.49" x2="-5.29" y2="12.99" layer="51"/>
<rectangle x1="-5.27" y1="12.49" x2="-4.85" y2="12.99" layer="51"/>
<rectangle x1="-4.83" y1="12.49" x2="-4.41" y2="12.99" layer="51"/>
<rectangle x1="-4.39" y1="12.49" x2="-3.97" y2="12.99" layer="51"/>
<rectangle x1="-3.95" y1="12.49" x2="-3.53" y2="12.99" layer="51"/>
<rectangle x1="-3.51" y1="12.49" x2="-3.09" y2="12.99" layer="51"/>
<rectangle x1="-3.07" y1="12.49" x2="-2.65" y2="12.99" layer="51"/>
<rectangle x1="-2.63" y1="12.49" x2="-2.21" y2="12.99" layer="51"/>
<rectangle x1="-2.19" y1="12.49" x2="-1.77" y2="12.99" layer="51"/>
<rectangle x1="-1.75" y1="12.49" x2="-1.33" y2="12.99" layer="51"/>
<rectangle x1="-1.31" y1="12.49" x2="-0.89" y2="12.99" layer="51"/>
<rectangle x1="-0.87" y1="12.49" x2="-0.45" y2="12.99" layer="51"/>
<rectangle x1="-0.43" y1="12.49" x2="-0.01" y2="12.99" layer="51"/>
<rectangle x1="0.01" y1="12.49" x2="0.43" y2="12.99" layer="51"/>
<rectangle x1="0.45" y1="12.49" x2="0.87" y2="12.99" layer="51"/>
<rectangle x1="0.89" y1="12.49" x2="1.31" y2="12.99" layer="51"/>
<rectangle x1="1.33" y1="12.49" x2="1.75" y2="12.99" layer="51"/>
<rectangle x1="1.77" y1="12.49" x2="2.19" y2="12.99" layer="51"/>
<rectangle x1="2.21" y1="12.49" x2="2.63" y2="12.99" layer="51"/>
<rectangle x1="2.65" y1="12.49" x2="3.07" y2="12.99" layer="51"/>
<rectangle x1="3.09" y1="12.49" x2="3.51" y2="12.99" layer="51"/>
<rectangle x1="3.53" y1="12.49" x2="3.95" y2="12.99" layer="51"/>
<rectangle x1="3.97" y1="12.49" x2="4.39" y2="12.99" layer="51"/>
<rectangle x1="4.41" y1="12.49" x2="4.83" y2="12.99" layer="51"/>
<rectangle x1="4.85" y1="12.49" x2="5.27" y2="12.99" layer="51"/>
<rectangle x1="5.29" y1="12.49" x2="5.71" y2="12.99" layer="51"/>
<rectangle x1="5.73" y1="12.49" x2="6.15" y2="12.99" layer="51"/>
<rectangle x1="6.17" y1="12.49" x2="6.59" y2="12.99" layer="51"/>
<rectangle x1="6.61" y1="12.49" x2="7.03" y2="12.99" layer="51"/>
<rectangle x1="7.05" y1="12.49" x2="7.47" y2="12.99" layer="51"/>
<rectangle x1="7.49" y1="12.49" x2="7.91" y2="12.99" layer="51"/>
<rectangle x1="7.93" y1="12.49" x2="8.35" y2="12.99" layer="51"/>
<rectangle x1="8.37" y1="12.49" x2="8.79" y2="12.99" layer="51"/>
<rectangle x1="8.81" y1="12.49" x2="9.23" y2="12.99" layer="51"/>
<rectangle x1="9.25" y1="12.49" x2="9.67" y2="12.99" layer="51"/>
<rectangle x1="9.69" y1="12.49" x2="10.11" y2="12.99" layer="51"/>
<rectangle x1="10.13" y1="12.49" x2="10.55" y2="12.99" layer="51"/>
<rectangle x1="10.57" y1="12.49" x2="10.99" y2="12.99" layer="51"/>
<rectangle x1="11.01" y1="12.49" x2="11.43" y2="12.99" layer="51"/>
<rectangle x1="11.45" y1="12.49" x2="11.87" y2="12.99" layer="51"/>
<rectangle x1="11.89" y1="12.49" x2="12.31" y2="12.99" layer="51"/>
<rectangle x1="12.33" y1="12.49" x2="12.75" y2="12.99" layer="51"/>
<rectangle x1="12.77" y1="12.49" x2="13.19" y2="12.99" layer="51"/>
<rectangle x1="13.21" y1="12.49" x2="13.63" y2="12.99" layer="51"/>
<rectangle x1="13.65" y1="12.49" x2="14.07" y2="12.99" layer="51"/>
<rectangle x1="14.09" y1="12.49" x2="14.51" y2="12.99" layer="51"/>
<rectangle x1="14.53" y1="12.49" x2="14.95" y2="12.99" layer="51"/>
<rectangle x1="14.97" y1="12.49" x2="15.39" y2="12.99" layer="51"/>
<rectangle x1="15.41" y1="12.49" x2="15.83" y2="12.99" layer="51"/>
<rectangle x1="15.85" y1="12.49" x2="16.27" y2="12.99" layer="51"/>
<rectangle x1="16.29" y1="12.49" x2="16.71" y2="12.99" layer="51"/>
<rectangle x1="16.73" y1="12.49" x2="17.15" y2="12.99" layer="51"/>
<rectangle x1="17.17" y1="12.49" x2="17.59" y2="12.99" layer="51"/>
<rectangle x1="17.61" y1="12.49" x2="18.03" y2="12.99" layer="51"/>
<rectangle x1="18.05" y1="12.49" x2="18.47" y2="12.99" layer="51"/>
<rectangle x1="18.49" y1="12.49" x2="18.91" y2="12.99" layer="51"/>
<rectangle x1="18.93" y1="12.49" x2="19.35" y2="12.99" layer="51"/>
<rectangle x1="19.37" y1="12.49" x2="19.79" y2="12.99" layer="51"/>
<rectangle x1="19.81" y1="12.49" x2="20.23" y2="12.99" layer="51"/>
<rectangle x1="20.25" y1="12.49" x2="20.67" y2="12.99" layer="51"/>
<rectangle x1="20.69" y1="12.49" x2="21.11" y2="12.99" layer="51"/>
<rectangle x1="21.13" y1="12.49" x2="21.55" y2="12.99" layer="51"/>
<rectangle x1="21.57" y1="12.49" x2="21.99" y2="12.99" layer="51"/>
<rectangle x1="22.01" y1="12.49" x2="22.43" y2="12.99" layer="51"/>
<rectangle x1="22.45" y1="12.49" x2="22.87" y2="12.99" layer="51"/>
<rectangle x1="22.89" y1="12.49" x2="23.31" y2="12.99" layer="51"/>
<rectangle x1="23.33" y1="12.49" x2="23.75" y2="12.99" layer="51"/>
<rectangle x1="23.77" y1="12.49" x2="24.19" y2="12.99" layer="51"/>
<rectangle x1="24.21" y1="12.49" x2="24.63" y2="12.99" layer="51"/>
<rectangle x1="24.65" y1="12.49" x2="25.07" y2="12.99" layer="51"/>
<rectangle x1="25.09" y1="12.49" x2="25.51" y2="12.99" layer="51"/>
<rectangle x1="25.53" y1="12.49" x2="25.95" y2="12.99" layer="51"/>
<rectangle x1="25.97" y1="12.49" x2="26.39" y2="12.99" layer="51"/>
<rectangle x1="26.41" y1="12.49" x2="26.83" y2="12.99" layer="51"/>
<rectangle x1="26.85" y1="12.49" x2="27.27" y2="12.99" layer="51"/>
<rectangle x1="27.29" y1="12.49" x2="27.71" y2="12.99" layer="51"/>
<rectangle x1="27.73" y1="12.49" x2="28.15" y2="12.99" layer="51"/>
<rectangle x1="-28.15" y1="11.97" x2="-27.73" y2="12.47" layer="51"/>
<rectangle x1="-27.71" y1="11.97" x2="-27.29" y2="12.47" layer="51"/>
<rectangle x1="-27.27" y1="11.97" x2="-26.85" y2="12.47" layer="51"/>
<rectangle x1="-26.83" y1="11.97" x2="-26.41" y2="12.47" layer="51"/>
<rectangle x1="-26.39" y1="11.97" x2="-25.97" y2="12.47" layer="51"/>
<rectangle x1="-25.95" y1="11.97" x2="-25.53" y2="12.47" layer="51"/>
<rectangle x1="-25.51" y1="11.97" x2="-25.09" y2="12.47" layer="51"/>
<rectangle x1="-25.07" y1="11.97" x2="-24.65" y2="12.47" layer="51"/>
<rectangle x1="-24.63" y1="11.97" x2="-24.21" y2="12.47" layer="51"/>
<rectangle x1="-24.19" y1="11.97" x2="-23.77" y2="12.47" layer="51"/>
<rectangle x1="-23.75" y1="11.97" x2="-23.33" y2="12.47" layer="51"/>
<rectangle x1="-23.31" y1="11.97" x2="-22.89" y2="12.47" layer="51"/>
<rectangle x1="-22.87" y1="11.97" x2="-22.45" y2="12.47" layer="51"/>
<rectangle x1="-22.43" y1="11.97" x2="-22.01" y2="12.47" layer="51"/>
<rectangle x1="-21.99" y1="11.97" x2="-21.57" y2="12.47" layer="51"/>
<rectangle x1="-21.55" y1="11.97" x2="-21.13" y2="12.47" layer="51"/>
<rectangle x1="-21.11" y1="11.97" x2="-20.69" y2="12.47" layer="51"/>
<rectangle x1="-20.67" y1="11.97" x2="-20.25" y2="12.47" layer="51"/>
<rectangle x1="-20.23" y1="11.97" x2="-19.81" y2="12.47" layer="51"/>
<rectangle x1="-19.79" y1="11.97" x2="-19.37" y2="12.47" layer="51"/>
<rectangle x1="-19.35" y1="11.97" x2="-18.93" y2="12.47" layer="51"/>
<rectangle x1="-18.91" y1="11.97" x2="-18.49" y2="12.47" layer="51"/>
<rectangle x1="-18.47" y1="11.97" x2="-18.05" y2="12.47" layer="51"/>
<rectangle x1="-18.03" y1="11.97" x2="-17.61" y2="12.47" layer="51"/>
<rectangle x1="-17.59" y1="11.97" x2="-17.17" y2="12.47" layer="51"/>
<rectangle x1="-17.15" y1="11.97" x2="-16.73" y2="12.47" layer="51"/>
<rectangle x1="-16.71" y1="11.97" x2="-16.29" y2="12.47" layer="51"/>
<rectangle x1="-16.27" y1="11.97" x2="-15.85" y2="12.47" layer="51"/>
<rectangle x1="-15.83" y1="11.97" x2="-15.41" y2="12.47" layer="51"/>
<rectangle x1="-15.39" y1="11.97" x2="-14.97" y2="12.47" layer="51"/>
<rectangle x1="-14.95" y1="11.97" x2="-14.53" y2="12.47" layer="51"/>
<rectangle x1="-14.51" y1="11.97" x2="-14.09" y2="12.47" layer="51"/>
<rectangle x1="-14.07" y1="11.97" x2="-13.65" y2="12.47" layer="51"/>
<rectangle x1="-13.63" y1="11.97" x2="-13.21" y2="12.47" layer="51"/>
<rectangle x1="-13.19" y1="11.97" x2="-12.77" y2="12.47" layer="51"/>
<rectangle x1="-12.75" y1="11.97" x2="-12.33" y2="12.47" layer="51"/>
<rectangle x1="-12.31" y1="11.97" x2="-11.89" y2="12.47" layer="51"/>
<rectangle x1="-11.87" y1="11.97" x2="-11.45" y2="12.47" layer="51"/>
<rectangle x1="-11.43" y1="11.97" x2="-11.01" y2="12.47" layer="51"/>
<rectangle x1="-10.99" y1="11.97" x2="-10.57" y2="12.47" layer="51"/>
<rectangle x1="-10.55" y1="11.97" x2="-10.13" y2="12.47" layer="51"/>
<rectangle x1="-10.11" y1="11.97" x2="-9.69" y2="12.47" layer="51"/>
<rectangle x1="-9.67" y1="11.97" x2="-9.25" y2="12.47" layer="51"/>
<rectangle x1="-9.23" y1="11.97" x2="-8.81" y2="12.47" layer="51"/>
<rectangle x1="-8.79" y1="11.97" x2="-8.37" y2="12.47" layer="51"/>
<rectangle x1="-8.35" y1="11.97" x2="-7.93" y2="12.47" layer="51"/>
<rectangle x1="-7.91" y1="11.97" x2="-7.49" y2="12.47" layer="51"/>
<rectangle x1="-7.47" y1="11.97" x2="-7.05" y2="12.47" layer="51"/>
<rectangle x1="-7.03" y1="11.97" x2="-6.61" y2="12.47" layer="51"/>
<rectangle x1="-6.59" y1="11.97" x2="-6.17" y2="12.47" layer="51"/>
<rectangle x1="-6.15" y1="11.97" x2="-5.73" y2="12.47" layer="51"/>
<rectangle x1="-5.71" y1="11.97" x2="-5.29" y2="12.47" layer="51"/>
<rectangle x1="-5.27" y1="11.97" x2="-4.85" y2="12.47" layer="51"/>
<rectangle x1="-4.83" y1="11.97" x2="-4.41" y2="12.47" layer="51"/>
<rectangle x1="-4.39" y1="11.97" x2="-3.97" y2="12.47" layer="51"/>
<rectangle x1="-3.95" y1="11.97" x2="-3.53" y2="12.47" layer="51"/>
<rectangle x1="-3.51" y1="11.97" x2="-3.09" y2="12.47" layer="51"/>
<rectangle x1="-3.07" y1="11.97" x2="-2.65" y2="12.47" layer="51"/>
<rectangle x1="-2.63" y1="11.97" x2="-2.21" y2="12.47" layer="51"/>
<rectangle x1="-2.19" y1="11.97" x2="-1.77" y2="12.47" layer="51"/>
<rectangle x1="-1.75" y1="11.97" x2="-1.33" y2="12.47" layer="51"/>
<rectangle x1="-1.31" y1="11.97" x2="-0.89" y2="12.47" layer="51"/>
<rectangle x1="-0.87" y1="11.97" x2="-0.45" y2="12.47" layer="51"/>
<rectangle x1="-0.43" y1="11.97" x2="-0.01" y2="12.47" layer="51"/>
<rectangle x1="0.01" y1="11.97" x2="0.43" y2="12.47" layer="51"/>
<rectangle x1="0.45" y1="11.97" x2="0.87" y2="12.47" layer="51"/>
<rectangle x1="0.89" y1="11.97" x2="1.31" y2="12.47" layer="51"/>
<rectangle x1="1.33" y1="11.97" x2="1.75" y2="12.47" layer="51"/>
<rectangle x1="1.77" y1="11.97" x2="2.19" y2="12.47" layer="51"/>
<rectangle x1="2.21" y1="11.97" x2="2.63" y2="12.47" layer="51"/>
<rectangle x1="2.65" y1="11.97" x2="3.07" y2="12.47" layer="51"/>
<rectangle x1="3.09" y1="11.97" x2="3.51" y2="12.47" layer="51"/>
<rectangle x1="3.53" y1="11.97" x2="3.95" y2="12.47" layer="51"/>
<rectangle x1="3.97" y1="11.97" x2="4.39" y2="12.47" layer="51"/>
<rectangle x1="4.41" y1="11.97" x2="4.83" y2="12.47" layer="51"/>
<rectangle x1="4.85" y1="11.97" x2="5.27" y2="12.47" layer="51"/>
<rectangle x1="5.29" y1="11.97" x2="5.71" y2="12.47" layer="51"/>
<rectangle x1="5.73" y1="11.97" x2="6.15" y2="12.47" layer="51"/>
<rectangle x1="6.17" y1="11.97" x2="6.59" y2="12.47" layer="51"/>
<rectangle x1="6.61" y1="11.97" x2="7.03" y2="12.47" layer="51"/>
<rectangle x1="7.05" y1="11.97" x2="7.47" y2="12.47" layer="51"/>
<rectangle x1="7.49" y1="11.97" x2="7.91" y2="12.47" layer="51"/>
<rectangle x1="7.93" y1="11.97" x2="8.35" y2="12.47" layer="51"/>
<rectangle x1="8.37" y1="11.97" x2="8.79" y2="12.47" layer="51"/>
<rectangle x1="8.81" y1="11.97" x2="9.23" y2="12.47" layer="51"/>
<rectangle x1="9.25" y1="11.97" x2="9.67" y2="12.47" layer="51"/>
<rectangle x1="9.69" y1="11.97" x2="10.11" y2="12.47" layer="51"/>
<rectangle x1="10.13" y1="11.97" x2="10.55" y2="12.47" layer="51"/>
<rectangle x1="10.57" y1="11.97" x2="10.99" y2="12.47" layer="51"/>
<rectangle x1="11.01" y1="11.97" x2="11.43" y2="12.47" layer="51"/>
<rectangle x1="11.45" y1="11.97" x2="11.87" y2="12.47" layer="51"/>
<rectangle x1="11.89" y1="11.97" x2="12.31" y2="12.47" layer="51"/>
<rectangle x1="12.33" y1="11.97" x2="12.75" y2="12.47" layer="51"/>
<rectangle x1="12.77" y1="11.97" x2="13.19" y2="12.47" layer="51"/>
<rectangle x1="13.21" y1="11.97" x2="13.63" y2="12.47" layer="51"/>
<rectangle x1="13.65" y1="11.97" x2="14.07" y2="12.47" layer="51"/>
<rectangle x1="14.09" y1="11.97" x2="14.51" y2="12.47" layer="51"/>
<rectangle x1="14.53" y1="11.97" x2="14.95" y2="12.47" layer="51"/>
<rectangle x1="14.97" y1="11.97" x2="15.39" y2="12.47" layer="51"/>
<rectangle x1="15.41" y1="11.97" x2="15.83" y2="12.47" layer="51"/>
<rectangle x1="15.85" y1="11.97" x2="16.27" y2="12.47" layer="51"/>
<rectangle x1="16.29" y1="11.97" x2="16.71" y2="12.47" layer="51"/>
<rectangle x1="16.73" y1="11.97" x2="17.15" y2="12.47" layer="51"/>
<rectangle x1="17.17" y1="11.97" x2="17.59" y2="12.47" layer="51"/>
<rectangle x1="17.61" y1="11.97" x2="18.03" y2="12.47" layer="51"/>
<rectangle x1="18.05" y1="11.97" x2="18.47" y2="12.47" layer="51"/>
<rectangle x1="18.49" y1="11.97" x2="18.91" y2="12.47" layer="51"/>
<rectangle x1="18.93" y1="11.97" x2="19.35" y2="12.47" layer="51"/>
<rectangle x1="19.37" y1="11.97" x2="19.79" y2="12.47" layer="51"/>
<rectangle x1="19.81" y1="11.97" x2="20.23" y2="12.47" layer="51"/>
<rectangle x1="20.25" y1="11.97" x2="20.67" y2="12.47" layer="51"/>
<rectangle x1="20.69" y1="11.97" x2="21.11" y2="12.47" layer="51"/>
<rectangle x1="21.13" y1="11.97" x2="21.55" y2="12.47" layer="51"/>
<rectangle x1="21.57" y1="11.97" x2="21.99" y2="12.47" layer="51"/>
<rectangle x1="22.01" y1="11.97" x2="22.43" y2="12.47" layer="51"/>
<rectangle x1="22.45" y1="11.97" x2="22.87" y2="12.47" layer="51"/>
<rectangle x1="22.89" y1="11.97" x2="23.31" y2="12.47" layer="51"/>
<rectangle x1="23.33" y1="11.97" x2="23.75" y2="12.47" layer="51"/>
<rectangle x1="23.77" y1="11.97" x2="24.19" y2="12.47" layer="51"/>
<rectangle x1="24.21" y1="11.97" x2="24.63" y2="12.47" layer="51"/>
<rectangle x1="24.65" y1="11.97" x2="25.07" y2="12.47" layer="51"/>
<rectangle x1="25.09" y1="11.97" x2="25.51" y2="12.47" layer="51"/>
<rectangle x1="25.53" y1="11.97" x2="25.95" y2="12.47" layer="51"/>
<rectangle x1="25.97" y1="11.97" x2="26.39" y2="12.47" layer="51"/>
<rectangle x1="26.41" y1="11.97" x2="26.83" y2="12.47" layer="51"/>
<rectangle x1="26.85" y1="11.97" x2="27.27" y2="12.47" layer="51"/>
<rectangle x1="27.29" y1="11.97" x2="27.71" y2="12.47" layer="51"/>
<rectangle x1="27.73" y1="11.97" x2="28.15" y2="12.47" layer="51"/>
<rectangle x1="-28.15" y1="11.45" x2="-27.73" y2="11.95" layer="51"/>
<rectangle x1="-27.71" y1="11.45" x2="-27.29" y2="11.95" layer="51"/>
<rectangle x1="-27.27" y1="11.45" x2="-26.85" y2="11.95" layer="51"/>
<rectangle x1="-26.83" y1="11.45" x2="-26.41" y2="11.95" layer="51"/>
<rectangle x1="-26.39" y1="11.45" x2="-25.97" y2="11.95" layer="51"/>
<rectangle x1="-25.95" y1="11.45" x2="-25.53" y2="11.95" layer="51"/>
<rectangle x1="-25.51" y1="11.45" x2="-25.09" y2="11.95" layer="51"/>
<rectangle x1="-25.07" y1="11.45" x2="-24.65" y2="11.95" layer="51"/>
<rectangle x1="-24.63" y1="11.45" x2="-24.21" y2="11.95" layer="51"/>
<rectangle x1="-24.19" y1="11.45" x2="-23.77" y2="11.95" layer="51"/>
<rectangle x1="-23.75" y1="11.45" x2="-23.33" y2="11.95" layer="51"/>
<rectangle x1="-23.31" y1="11.45" x2="-22.89" y2="11.95" layer="51"/>
<rectangle x1="-22.87" y1="11.45" x2="-22.45" y2="11.95" layer="51"/>
<rectangle x1="-22.43" y1="11.45" x2="-22.01" y2="11.95" layer="51"/>
<rectangle x1="-21.99" y1="11.45" x2="-21.57" y2="11.95" layer="51"/>
<rectangle x1="-21.55" y1="11.45" x2="-21.13" y2="11.95" layer="51"/>
<rectangle x1="-21.11" y1="11.45" x2="-20.69" y2="11.95" layer="51"/>
<rectangle x1="-20.67" y1="11.45" x2="-20.25" y2="11.95" layer="51"/>
<rectangle x1="-20.23" y1="11.45" x2="-19.81" y2="11.95" layer="51"/>
<rectangle x1="-19.79" y1="11.45" x2="-19.37" y2="11.95" layer="51"/>
<rectangle x1="-19.35" y1="11.45" x2="-18.93" y2="11.95" layer="51"/>
<rectangle x1="-18.91" y1="11.45" x2="-18.49" y2="11.95" layer="51"/>
<rectangle x1="-18.47" y1="11.45" x2="-18.05" y2="11.95" layer="51"/>
<rectangle x1="-18.03" y1="11.45" x2="-17.61" y2="11.95" layer="51"/>
<rectangle x1="-17.59" y1="11.45" x2="-17.17" y2="11.95" layer="51"/>
<rectangle x1="-17.15" y1="11.45" x2="-16.73" y2="11.95" layer="51"/>
<rectangle x1="-16.71" y1="11.45" x2="-16.29" y2="11.95" layer="51"/>
<rectangle x1="-16.27" y1="11.45" x2="-15.85" y2="11.95" layer="51"/>
<rectangle x1="-15.83" y1="11.45" x2="-15.41" y2="11.95" layer="51"/>
<rectangle x1="-15.39" y1="11.45" x2="-14.97" y2="11.95" layer="51"/>
<rectangle x1="-14.95" y1="11.45" x2="-14.53" y2="11.95" layer="51"/>
<rectangle x1="-14.51" y1="11.45" x2="-14.09" y2="11.95" layer="51"/>
<rectangle x1="-14.07" y1="11.45" x2="-13.65" y2="11.95" layer="51"/>
<rectangle x1="-13.63" y1="11.45" x2="-13.21" y2="11.95" layer="51"/>
<rectangle x1="-13.19" y1="11.45" x2="-12.77" y2="11.95" layer="51"/>
<rectangle x1="-12.75" y1="11.45" x2="-12.33" y2="11.95" layer="51"/>
<rectangle x1="-12.31" y1="11.45" x2="-11.89" y2="11.95" layer="51"/>
<rectangle x1="-11.87" y1="11.45" x2="-11.45" y2="11.95" layer="51"/>
<rectangle x1="-11.43" y1="11.45" x2="-11.01" y2="11.95" layer="51"/>
<rectangle x1="-10.99" y1="11.45" x2="-10.57" y2="11.95" layer="51"/>
<rectangle x1="-10.55" y1="11.45" x2="-10.13" y2="11.95" layer="51"/>
<rectangle x1="-10.11" y1="11.45" x2="-9.69" y2="11.95" layer="51"/>
<rectangle x1="-9.67" y1="11.45" x2="-9.25" y2="11.95" layer="51"/>
<rectangle x1="-9.23" y1="11.45" x2="-8.81" y2="11.95" layer="51"/>
<rectangle x1="-8.79" y1="11.45" x2="-8.37" y2="11.95" layer="51"/>
<rectangle x1="-8.35" y1="11.45" x2="-7.93" y2="11.95" layer="51"/>
<rectangle x1="-7.91" y1="11.45" x2="-7.49" y2="11.95" layer="51"/>
<rectangle x1="-7.47" y1="11.45" x2="-7.05" y2="11.95" layer="51"/>
<rectangle x1="-7.03" y1="11.45" x2="-6.61" y2="11.95" layer="51"/>
<rectangle x1="-6.59" y1="11.45" x2="-6.17" y2="11.95" layer="51"/>
<rectangle x1="-6.15" y1="11.45" x2="-5.73" y2="11.95" layer="51"/>
<rectangle x1="-5.71" y1="11.45" x2="-5.29" y2="11.95" layer="51"/>
<rectangle x1="-5.27" y1="11.45" x2="-4.85" y2="11.95" layer="51"/>
<rectangle x1="-4.83" y1="11.45" x2="-4.41" y2="11.95" layer="51"/>
<rectangle x1="-4.39" y1="11.45" x2="-3.97" y2="11.95" layer="51"/>
<rectangle x1="-3.95" y1="11.45" x2="-3.53" y2="11.95" layer="51"/>
<rectangle x1="-3.51" y1="11.45" x2="-3.09" y2="11.95" layer="51"/>
<rectangle x1="-3.07" y1="11.45" x2="-2.65" y2="11.95" layer="51"/>
<rectangle x1="-2.63" y1="11.45" x2="-2.21" y2="11.95" layer="51"/>
<rectangle x1="-2.19" y1="11.45" x2="-1.77" y2="11.95" layer="51"/>
<rectangle x1="-1.75" y1="11.45" x2="-1.33" y2="11.95" layer="51"/>
<rectangle x1="-1.31" y1="11.45" x2="-0.89" y2="11.95" layer="51"/>
<rectangle x1="-0.87" y1="11.45" x2="-0.45" y2="11.95" layer="51"/>
<rectangle x1="-0.43" y1="11.45" x2="-0.01" y2="11.95" layer="51"/>
<rectangle x1="0.01" y1="11.45" x2="0.43" y2="11.95" layer="51"/>
<rectangle x1="0.45" y1="11.45" x2="0.87" y2="11.95" layer="51"/>
<rectangle x1="0.89" y1="11.45" x2="1.31" y2="11.95" layer="51"/>
<rectangle x1="1.33" y1="11.45" x2="1.75" y2="11.95" layer="51"/>
<rectangle x1="1.77" y1="11.45" x2="2.19" y2="11.95" layer="51"/>
<rectangle x1="2.21" y1="11.45" x2="2.63" y2="11.95" layer="51"/>
<rectangle x1="2.65" y1="11.45" x2="3.07" y2="11.95" layer="51"/>
<rectangle x1="3.09" y1="11.45" x2="3.51" y2="11.95" layer="51"/>
<rectangle x1="3.53" y1="11.45" x2="3.95" y2="11.95" layer="51"/>
<rectangle x1="3.97" y1="11.45" x2="4.39" y2="11.95" layer="51"/>
<rectangle x1="4.41" y1="11.45" x2="4.83" y2="11.95" layer="51"/>
<rectangle x1="4.85" y1="11.45" x2="5.27" y2="11.95" layer="51"/>
<rectangle x1="5.29" y1="11.45" x2="5.71" y2="11.95" layer="51"/>
<rectangle x1="5.73" y1="11.45" x2="6.15" y2="11.95" layer="51"/>
<rectangle x1="6.17" y1="11.45" x2="6.59" y2="11.95" layer="51"/>
<rectangle x1="6.61" y1="11.45" x2="7.03" y2="11.95" layer="51"/>
<rectangle x1="7.05" y1="11.45" x2="7.47" y2="11.95" layer="51"/>
<rectangle x1="7.49" y1="11.45" x2="7.91" y2="11.95" layer="51"/>
<rectangle x1="7.93" y1="11.45" x2="8.35" y2="11.95" layer="51"/>
<rectangle x1="8.37" y1="11.45" x2="8.79" y2="11.95" layer="51"/>
<rectangle x1="8.81" y1="11.45" x2="9.23" y2="11.95" layer="51"/>
<rectangle x1="9.25" y1="11.45" x2="9.67" y2="11.95" layer="51"/>
<rectangle x1="9.69" y1="11.45" x2="10.11" y2="11.95" layer="51"/>
<rectangle x1="10.13" y1="11.45" x2="10.55" y2="11.95" layer="51"/>
<rectangle x1="10.57" y1="11.45" x2="10.99" y2="11.95" layer="51"/>
<rectangle x1="11.01" y1="11.45" x2="11.43" y2="11.95" layer="51"/>
<rectangle x1="11.45" y1="11.45" x2="11.87" y2="11.95" layer="51"/>
<rectangle x1="11.89" y1="11.45" x2="12.31" y2="11.95" layer="51"/>
<rectangle x1="12.33" y1="11.45" x2="12.75" y2="11.95" layer="51"/>
<rectangle x1="12.77" y1="11.45" x2="13.19" y2="11.95" layer="51"/>
<rectangle x1="13.21" y1="11.45" x2="13.63" y2="11.95" layer="51"/>
<rectangle x1="13.65" y1="11.45" x2="14.07" y2="11.95" layer="51"/>
<rectangle x1="14.09" y1="11.45" x2="14.51" y2="11.95" layer="51"/>
<rectangle x1="14.53" y1="11.45" x2="14.95" y2="11.95" layer="51"/>
<rectangle x1="14.97" y1="11.45" x2="15.39" y2="11.95" layer="51"/>
<rectangle x1="15.41" y1="11.45" x2="15.83" y2="11.95" layer="51"/>
<rectangle x1="15.85" y1="11.45" x2="16.27" y2="11.95" layer="51"/>
<rectangle x1="16.29" y1="11.45" x2="16.71" y2="11.95" layer="51"/>
<rectangle x1="16.73" y1="11.45" x2="17.15" y2="11.95" layer="51"/>
<rectangle x1="17.17" y1="11.45" x2="17.59" y2="11.95" layer="51"/>
<rectangle x1="17.61" y1="11.45" x2="18.03" y2="11.95" layer="51"/>
<rectangle x1="18.05" y1="11.45" x2="18.47" y2="11.95" layer="51"/>
<rectangle x1="18.49" y1="11.45" x2="18.91" y2="11.95" layer="51"/>
<rectangle x1="18.93" y1="11.45" x2="19.35" y2="11.95" layer="51"/>
<rectangle x1="19.37" y1="11.45" x2="19.79" y2="11.95" layer="51"/>
<rectangle x1="19.81" y1="11.45" x2="20.23" y2="11.95" layer="51"/>
<rectangle x1="20.25" y1="11.45" x2="20.67" y2="11.95" layer="51"/>
<rectangle x1="20.69" y1="11.45" x2="21.11" y2="11.95" layer="51"/>
<rectangle x1="21.13" y1="11.45" x2="21.55" y2="11.95" layer="51"/>
<rectangle x1="21.57" y1="11.45" x2="21.99" y2="11.95" layer="51"/>
<rectangle x1="22.01" y1="11.45" x2="22.43" y2="11.95" layer="51"/>
<rectangle x1="22.45" y1="11.45" x2="22.87" y2="11.95" layer="51"/>
<rectangle x1="22.89" y1="11.45" x2="23.31" y2="11.95" layer="51"/>
<rectangle x1="23.33" y1="11.45" x2="23.75" y2="11.95" layer="51"/>
<rectangle x1="23.77" y1="11.45" x2="24.19" y2="11.95" layer="51"/>
<rectangle x1="24.21" y1="11.45" x2="24.63" y2="11.95" layer="51"/>
<rectangle x1="24.65" y1="11.45" x2="25.07" y2="11.95" layer="51"/>
<rectangle x1="25.09" y1="11.45" x2="25.51" y2="11.95" layer="51"/>
<rectangle x1="25.53" y1="11.45" x2="25.95" y2="11.95" layer="51"/>
<rectangle x1="25.97" y1="11.45" x2="26.39" y2="11.95" layer="51"/>
<rectangle x1="26.41" y1="11.45" x2="26.83" y2="11.95" layer="51"/>
<rectangle x1="26.85" y1="11.45" x2="27.27" y2="11.95" layer="51"/>
<rectangle x1="27.29" y1="11.45" x2="27.71" y2="11.95" layer="51"/>
<rectangle x1="27.73" y1="11.45" x2="28.15" y2="11.95" layer="51"/>
<rectangle x1="-28.15" y1="10.93" x2="-27.73" y2="11.43" layer="51"/>
<rectangle x1="-27.71" y1="10.93" x2="-27.29" y2="11.43" layer="51"/>
<rectangle x1="-27.27" y1="10.93" x2="-26.85" y2="11.43" layer="51"/>
<rectangle x1="-26.83" y1="10.93" x2="-26.41" y2="11.43" layer="51"/>
<rectangle x1="-26.39" y1="10.93" x2="-25.97" y2="11.43" layer="51"/>
<rectangle x1="-25.95" y1="10.93" x2="-25.53" y2="11.43" layer="51"/>
<rectangle x1="-25.51" y1="10.93" x2="-25.09" y2="11.43" layer="51"/>
<rectangle x1="-25.07" y1="10.93" x2="-24.65" y2="11.43" layer="51"/>
<rectangle x1="-24.63" y1="10.93" x2="-24.21" y2="11.43" layer="51"/>
<rectangle x1="-24.19" y1="10.93" x2="-23.77" y2="11.43" layer="51"/>
<rectangle x1="-23.75" y1="10.93" x2="-23.33" y2="11.43" layer="51"/>
<rectangle x1="-23.31" y1="10.93" x2="-22.89" y2="11.43" layer="51"/>
<rectangle x1="-22.87" y1="10.93" x2="-22.45" y2="11.43" layer="51"/>
<rectangle x1="-22.43" y1="10.93" x2="-22.01" y2="11.43" layer="51"/>
<rectangle x1="-21.99" y1="10.93" x2="-21.57" y2="11.43" layer="51"/>
<rectangle x1="-21.55" y1="10.93" x2="-21.13" y2="11.43" layer="51"/>
<rectangle x1="-21.11" y1="10.93" x2="-20.69" y2="11.43" layer="51"/>
<rectangle x1="-20.67" y1="10.93" x2="-20.25" y2="11.43" layer="51"/>
<rectangle x1="-20.23" y1="10.93" x2="-19.81" y2="11.43" layer="51"/>
<rectangle x1="-19.79" y1="10.93" x2="-19.37" y2="11.43" layer="51"/>
<rectangle x1="-19.35" y1="10.93" x2="-18.93" y2="11.43" layer="51"/>
<rectangle x1="-18.91" y1="10.93" x2="-18.49" y2="11.43" layer="51"/>
<rectangle x1="-18.47" y1="10.93" x2="-18.05" y2="11.43" layer="51"/>
<rectangle x1="-18.03" y1="10.93" x2="-17.61" y2="11.43" layer="51"/>
<rectangle x1="-17.59" y1="10.93" x2="-17.17" y2="11.43" layer="51"/>
<rectangle x1="-17.15" y1="10.93" x2="-16.73" y2="11.43" layer="51"/>
<rectangle x1="-16.71" y1="10.93" x2="-16.29" y2="11.43" layer="51"/>
<rectangle x1="-16.27" y1="10.93" x2="-15.85" y2="11.43" layer="51"/>
<rectangle x1="-15.83" y1="10.93" x2="-15.41" y2="11.43" layer="51"/>
<rectangle x1="-15.39" y1="10.93" x2="-14.97" y2="11.43" layer="51"/>
<rectangle x1="-14.95" y1="10.93" x2="-14.53" y2="11.43" layer="51"/>
<rectangle x1="-14.51" y1="10.93" x2="-14.09" y2="11.43" layer="51"/>
<rectangle x1="-14.07" y1="10.93" x2="-13.65" y2="11.43" layer="51"/>
<rectangle x1="-13.63" y1="10.93" x2="-13.21" y2="11.43" layer="51"/>
<rectangle x1="-13.19" y1="10.93" x2="-12.77" y2="11.43" layer="51"/>
<rectangle x1="-12.75" y1="10.93" x2="-12.33" y2="11.43" layer="51"/>
<rectangle x1="-12.31" y1="10.93" x2="-11.89" y2="11.43" layer="51"/>
<rectangle x1="-11.87" y1="10.93" x2="-11.45" y2="11.43" layer="51"/>
<rectangle x1="-11.43" y1="10.93" x2="-11.01" y2="11.43" layer="51"/>
<rectangle x1="-10.99" y1="10.93" x2="-10.57" y2="11.43" layer="51"/>
<rectangle x1="-10.55" y1="10.93" x2="-10.13" y2="11.43" layer="51"/>
<rectangle x1="-10.11" y1="10.93" x2="-9.69" y2="11.43" layer="51"/>
<rectangle x1="-9.67" y1="10.93" x2="-9.25" y2="11.43" layer="51"/>
<rectangle x1="-9.23" y1="10.93" x2="-8.81" y2="11.43" layer="51"/>
<rectangle x1="-8.79" y1="10.93" x2="-8.37" y2="11.43" layer="51"/>
<rectangle x1="-8.35" y1="10.93" x2="-7.93" y2="11.43" layer="51"/>
<rectangle x1="-7.91" y1="10.93" x2="-7.49" y2="11.43" layer="51"/>
<rectangle x1="-7.47" y1="10.93" x2="-7.05" y2="11.43" layer="51"/>
<rectangle x1="-7.03" y1="10.93" x2="-6.61" y2="11.43" layer="51"/>
<rectangle x1="-6.59" y1="10.93" x2="-6.17" y2="11.43" layer="51"/>
<rectangle x1="-6.15" y1="10.93" x2="-5.73" y2="11.43" layer="51"/>
<rectangle x1="-5.71" y1="10.93" x2="-5.29" y2="11.43" layer="51"/>
<rectangle x1="-5.27" y1="10.93" x2="-4.85" y2="11.43" layer="51"/>
<rectangle x1="-4.83" y1="10.93" x2="-4.41" y2="11.43" layer="51"/>
<rectangle x1="-4.39" y1="10.93" x2="-3.97" y2="11.43" layer="51"/>
<rectangle x1="-3.95" y1="10.93" x2="-3.53" y2="11.43" layer="51"/>
<rectangle x1="-3.51" y1="10.93" x2="-3.09" y2="11.43" layer="51"/>
<rectangle x1="-3.07" y1="10.93" x2="-2.65" y2="11.43" layer="51"/>
<rectangle x1="-2.63" y1="10.93" x2="-2.21" y2="11.43" layer="51"/>
<rectangle x1="-2.19" y1="10.93" x2="-1.77" y2="11.43" layer="51"/>
<rectangle x1="-1.75" y1="10.93" x2="-1.33" y2="11.43" layer="51"/>
<rectangle x1="-1.31" y1="10.93" x2="-0.89" y2="11.43" layer="51"/>
<rectangle x1="-0.87" y1="10.93" x2="-0.45" y2="11.43" layer="51"/>
<rectangle x1="-0.43" y1="10.93" x2="-0.01" y2="11.43" layer="51"/>
<rectangle x1="0.01" y1="10.93" x2="0.43" y2="11.43" layer="51"/>
<rectangle x1="0.45" y1="10.93" x2="0.87" y2="11.43" layer="51"/>
<rectangle x1="0.89" y1="10.93" x2="1.31" y2="11.43" layer="51"/>
<rectangle x1="1.33" y1="10.93" x2="1.75" y2="11.43" layer="51"/>
<rectangle x1="1.77" y1="10.93" x2="2.19" y2="11.43" layer="51"/>
<rectangle x1="2.21" y1="10.93" x2="2.63" y2="11.43" layer="51"/>
<rectangle x1="2.65" y1="10.93" x2="3.07" y2="11.43" layer="51"/>
<rectangle x1="3.09" y1="10.93" x2="3.51" y2="11.43" layer="51"/>
<rectangle x1="3.53" y1="10.93" x2="3.95" y2="11.43" layer="51"/>
<rectangle x1="3.97" y1="10.93" x2="4.39" y2="11.43" layer="51"/>
<rectangle x1="4.41" y1="10.93" x2="4.83" y2="11.43" layer="51"/>
<rectangle x1="4.85" y1="10.93" x2="5.27" y2="11.43" layer="51"/>
<rectangle x1="5.29" y1="10.93" x2="5.71" y2="11.43" layer="51"/>
<rectangle x1="5.73" y1="10.93" x2="6.15" y2="11.43" layer="51"/>
<rectangle x1="6.17" y1="10.93" x2="6.59" y2="11.43" layer="51"/>
<rectangle x1="6.61" y1="10.93" x2="7.03" y2="11.43" layer="51"/>
<rectangle x1="7.05" y1="10.93" x2="7.47" y2="11.43" layer="51"/>
<rectangle x1="7.49" y1="10.93" x2="7.91" y2="11.43" layer="51"/>
<rectangle x1="7.93" y1="10.93" x2="8.35" y2="11.43" layer="51"/>
<rectangle x1="8.37" y1="10.93" x2="8.79" y2="11.43" layer="51"/>
<rectangle x1="8.81" y1="10.93" x2="9.23" y2="11.43" layer="51"/>
<rectangle x1="9.25" y1="10.93" x2="9.67" y2="11.43" layer="51"/>
<rectangle x1="9.69" y1="10.93" x2="10.11" y2="11.43" layer="51"/>
<rectangle x1="10.13" y1="10.93" x2="10.55" y2="11.43" layer="51"/>
<rectangle x1="10.57" y1="10.93" x2="10.99" y2="11.43" layer="51"/>
<rectangle x1="11.01" y1="10.93" x2="11.43" y2="11.43" layer="51"/>
<rectangle x1="11.45" y1="10.93" x2="11.87" y2="11.43" layer="51"/>
<rectangle x1="11.89" y1="10.93" x2="12.31" y2="11.43" layer="51"/>
<rectangle x1="12.33" y1="10.93" x2="12.75" y2="11.43" layer="51"/>
<rectangle x1="12.77" y1="10.93" x2="13.19" y2="11.43" layer="51"/>
<rectangle x1="13.21" y1="10.93" x2="13.63" y2="11.43" layer="51"/>
<rectangle x1="13.65" y1="10.93" x2="14.07" y2="11.43" layer="51"/>
<rectangle x1="14.09" y1="10.93" x2="14.51" y2="11.43" layer="51"/>
<rectangle x1="14.53" y1="10.93" x2="14.95" y2="11.43" layer="51"/>
<rectangle x1="14.97" y1="10.93" x2="15.39" y2="11.43" layer="51"/>
<rectangle x1="15.41" y1="10.93" x2="15.83" y2="11.43" layer="51"/>
<rectangle x1="15.85" y1="10.93" x2="16.27" y2="11.43" layer="51"/>
<rectangle x1="16.29" y1="10.93" x2="16.71" y2="11.43" layer="51"/>
<rectangle x1="16.73" y1="10.93" x2="17.15" y2="11.43" layer="51"/>
<rectangle x1="17.17" y1="10.93" x2="17.59" y2="11.43" layer="51"/>
<rectangle x1="17.61" y1="10.93" x2="18.03" y2="11.43" layer="51"/>
<rectangle x1="18.05" y1="10.93" x2="18.47" y2="11.43" layer="51"/>
<rectangle x1="18.49" y1="10.93" x2="18.91" y2="11.43" layer="51"/>
<rectangle x1="18.93" y1="10.93" x2="19.35" y2="11.43" layer="51"/>
<rectangle x1="19.37" y1="10.93" x2="19.79" y2="11.43" layer="51"/>
<rectangle x1="19.81" y1="10.93" x2="20.23" y2="11.43" layer="51"/>
<rectangle x1="20.25" y1="10.93" x2="20.67" y2="11.43" layer="51"/>
<rectangle x1="20.69" y1="10.93" x2="21.11" y2="11.43" layer="51"/>
<rectangle x1="21.13" y1="10.93" x2="21.55" y2="11.43" layer="51"/>
<rectangle x1="21.57" y1="10.93" x2="21.99" y2="11.43" layer="51"/>
<rectangle x1="22.01" y1="10.93" x2="22.43" y2="11.43" layer="51"/>
<rectangle x1="22.45" y1="10.93" x2="22.87" y2="11.43" layer="51"/>
<rectangle x1="22.89" y1="10.93" x2="23.31" y2="11.43" layer="51"/>
<rectangle x1="23.33" y1="10.93" x2="23.75" y2="11.43" layer="51"/>
<rectangle x1="23.77" y1="10.93" x2="24.19" y2="11.43" layer="51"/>
<rectangle x1="24.21" y1="10.93" x2="24.63" y2="11.43" layer="51"/>
<rectangle x1="24.65" y1="10.93" x2="25.07" y2="11.43" layer="51"/>
<rectangle x1="25.09" y1="10.93" x2="25.51" y2="11.43" layer="51"/>
<rectangle x1="25.53" y1="10.93" x2="25.95" y2="11.43" layer="51"/>
<rectangle x1="25.97" y1="10.93" x2="26.39" y2="11.43" layer="51"/>
<rectangle x1="26.41" y1="10.93" x2="26.83" y2="11.43" layer="51"/>
<rectangle x1="26.85" y1="10.93" x2="27.27" y2="11.43" layer="51"/>
<rectangle x1="27.29" y1="10.93" x2="27.71" y2="11.43" layer="51"/>
<rectangle x1="27.73" y1="10.93" x2="28.15" y2="11.43" layer="51"/>
<rectangle x1="-28.15" y1="10.41" x2="-27.73" y2="10.91" layer="51"/>
<rectangle x1="-27.71" y1="10.41" x2="-27.29" y2="10.91" layer="51"/>
<rectangle x1="-27.27" y1="10.41" x2="-26.85" y2="10.91" layer="51"/>
<rectangle x1="-26.83" y1="10.41" x2="-26.41" y2="10.91" layer="51"/>
<rectangle x1="-26.39" y1="10.41" x2="-25.97" y2="10.91" layer="51"/>
<rectangle x1="-25.95" y1="10.41" x2="-25.53" y2="10.91" layer="51"/>
<rectangle x1="-25.51" y1="10.41" x2="-25.09" y2="10.91" layer="51"/>
<rectangle x1="-25.07" y1="10.41" x2="-24.65" y2="10.91" layer="51"/>
<rectangle x1="-24.63" y1="10.41" x2="-24.21" y2="10.91" layer="51"/>
<rectangle x1="-24.19" y1="10.41" x2="-23.77" y2="10.91" layer="51"/>
<rectangle x1="-23.75" y1="10.41" x2="-23.33" y2="10.91" layer="51"/>
<rectangle x1="-23.31" y1="10.41" x2="-22.89" y2="10.91" layer="51"/>
<rectangle x1="-22.87" y1="10.41" x2="-22.45" y2="10.91" layer="51"/>
<rectangle x1="-22.43" y1="10.41" x2="-22.01" y2="10.91" layer="51"/>
<rectangle x1="-21.99" y1="10.41" x2="-21.57" y2="10.91" layer="51"/>
<rectangle x1="-21.55" y1="10.41" x2="-21.13" y2="10.91" layer="51"/>
<rectangle x1="-21.11" y1="10.41" x2="-20.69" y2="10.91" layer="51"/>
<rectangle x1="-20.67" y1="10.41" x2="-20.25" y2="10.91" layer="51"/>
<rectangle x1="-20.23" y1="10.41" x2="-19.81" y2="10.91" layer="51"/>
<rectangle x1="-19.79" y1="10.41" x2="-19.37" y2="10.91" layer="51"/>
<rectangle x1="-19.35" y1="10.41" x2="-18.93" y2="10.91" layer="51"/>
<rectangle x1="-18.91" y1="10.41" x2="-18.49" y2="10.91" layer="51"/>
<rectangle x1="-18.47" y1="10.41" x2="-18.05" y2="10.91" layer="51"/>
<rectangle x1="-18.03" y1="10.41" x2="-17.61" y2="10.91" layer="51"/>
<rectangle x1="-17.59" y1="10.41" x2="-17.17" y2="10.91" layer="51"/>
<rectangle x1="-17.15" y1="10.41" x2="-16.73" y2="10.91" layer="51"/>
<rectangle x1="-16.71" y1="10.41" x2="-16.29" y2="10.91" layer="51"/>
<rectangle x1="-16.27" y1="10.41" x2="-15.85" y2="10.91" layer="51"/>
<rectangle x1="-15.83" y1="10.41" x2="-15.41" y2="10.91" layer="51"/>
<rectangle x1="-15.39" y1="10.41" x2="-14.97" y2="10.91" layer="51"/>
<rectangle x1="-14.95" y1="10.41" x2="-14.53" y2="10.91" layer="51"/>
<rectangle x1="-14.51" y1="10.41" x2="-14.09" y2="10.91" layer="51"/>
<rectangle x1="-14.07" y1="10.41" x2="-13.65" y2="10.91" layer="51"/>
<rectangle x1="-13.63" y1="10.41" x2="-13.21" y2="10.91" layer="51"/>
<rectangle x1="-13.19" y1="10.41" x2="-12.77" y2="10.91" layer="51"/>
<rectangle x1="-12.75" y1="10.41" x2="-12.33" y2="10.91" layer="51"/>
<rectangle x1="-12.31" y1="10.41" x2="-11.89" y2="10.91" layer="51"/>
<rectangle x1="-11.87" y1="10.41" x2="-11.45" y2="10.91" layer="51"/>
<rectangle x1="-11.43" y1="10.41" x2="-11.01" y2="10.91" layer="51"/>
<rectangle x1="-10.99" y1="10.41" x2="-10.57" y2="10.91" layer="51"/>
<rectangle x1="-10.55" y1="10.41" x2="-10.13" y2="10.91" layer="51"/>
<rectangle x1="-10.11" y1="10.41" x2="-9.69" y2="10.91" layer="51"/>
<rectangle x1="-9.67" y1="10.41" x2="-9.25" y2="10.91" layer="51"/>
<rectangle x1="-9.23" y1="10.41" x2="-8.81" y2="10.91" layer="51"/>
<rectangle x1="-8.79" y1="10.41" x2="-8.37" y2="10.91" layer="51"/>
<rectangle x1="-8.35" y1="10.41" x2="-7.93" y2="10.91" layer="51"/>
<rectangle x1="-7.91" y1="10.41" x2="-7.49" y2="10.91" layer="51"/>
<rectangle x1="-7.47" y1="10.41" x2="-7.05" y2="10.91" layer="51"/>
<rectangle x1="-7.03" y1="10.41" x2="-6.61" y2="10.91" layer="51"/>
<rectangle x1="-6.59" y1="10.41" x2="-6.17" y2="10.91" layer="51"/>
<rectangle x1="-6.15" y1="10.41" x2="-5.73" y2="10.91" layer="51"/>
<rectangle x1="-5.71" y1="10.41" x2="-5.29" y2="10.91" layer="51"/>
<rectangle x1="-5.27" y1="10.41" x2="-4.85" y2="10.91" layer="51"/>
<rectangle x1="-4.83" y1="10.41" x2="-4.41" y2="10.91" layer="51"/>
<rectangle x1="-4.39" y1="10.41" x2="-3.97" y2="10.91" layer="51"/>
<rectangle x1="-3.95" y1="10.41" x2="-3.53" y2="10.91" layer="51"/>
<rectangle x1="-3.51" y1="10.41" x2="-3.09" y2="10.91" layer="51"/>
<rectangle x1="-3.07" y1="10.41" x2="-2.65" y2="10.91" layer="51"/>
<rectangle x1="-2.63" y1="10.41" x2="-2.21" y2="10.91" layer="51"/>
<rectangle x1="-2.19" y1="10.41" x2="-1.77" y2="10.91" layer="51"/>
<rectangle x1="-1.75" y1="10.41" x2="-1.33" y2="10.91" layer="51"/>
<rectangle x1="-1.31" y1="10.41" x2="-0.89" y2="10.91" layer="51"/>
<rectangle x1="-0.87" y1="10.41" x2="-0.45" y2="10.91" layer="51"/>
<rectangle x1="-0.43" y1="10.41" x2="-0.01" y2="10.91" layer="51"/>
<rectangle x1="0.01" y1="10.41" x2="0.43" y2="10.91" layer="51"/>
<rectangle x1="0.45" y1="10.41" x2="0.87" y2="10.91" layer="51"/>
<rectangle x1="0.89" y1="10.41" x2="1.31" y2="10.91" layer="51"/>
<rectangle x1="1.33" y1="10.41" x2="1.75" y2="10.91" layer="51"/>
<rectangle x1="1.77" y1="10.41" x2="2.19" y2="10.91" layer="51"/>
<rectangle x1="2.21" y1="10.41" x2="2.63" y2="10.91" layer="51"/>
<rectangle x1="2.65" y1="10.41" x2="3.07" y2="10.91" layer="51"/>
<rectangle x1="3.09" y1="10.41" x2="3.51" y2="10.91" layer="51"/>
<rectangle x1="3.53" y1="10.41" x2="3.95" y2="10.91" layer="51"/>
<rectangle x1="3.97" y1="10.41" x2="4.39" y2="10.91" layer="51"/>
<rectangle x1="4.41" y1="10.41" x2="4.83" y2="10.91" layer="51"/>
<rectangle x1="4.85" y1="10.41" x2="5.27" y2="10.91" layer="51"/>
<rectangle x1="5.29" y1="10.41" x2="5.71" y2="10.91" layer="51"/>
<rectangle x1="5.73" y1="10.41" x2="6.15" y2="10.91" layer="51"/>
<rectangle x1="6.17" y1="10.41" x2="6.59" y2="10.91" layer="51"/>
<rectangle x1="6.61" y1="10.41" x2="7.03" y2="10.91" layer="51"/>
<rectangle x1="7.05" y1="10.41" x2="7.47" y2="10.91" layer="51"/>
<rectangle x1="7.49" y1="10.41" x2="7.91" y2="10.91" layer="51"/>
<rectangle x1="7.93" y1="10.41" x2="8.35" y2="10.91" layer="51"/>
<rectangle x1="8.37" y1="10.41" x2="8.79" y2="10.91" layer="51"/>
<rectangle x1="8.81" y1="10.41" x2="9.23" y2="10.91" layer="51"/>
<rectangle x1="9.25" y1="10.41" x2="9.67" y2="10.91" layer="51"/>
<rectangle x1="9.69" y1="10.41" x2="10.11" y2="10.91" layer="51"/>
<rectangle x1="10.13" y1="10.41" x2="10.55" y2="10.91" layer="51"/>
<rectangle x1="10.57" y1="10.41" x2="10.99" y2="10.91" layer="51"/>
<rectangle x1="11.01" y1="10.41" x2="11.43" y2="10.91" layer="51"/>
<rectangle x1="11.45" y1="10.41" x2="11.87" y2="10.91" layer="51"/>
<rectangle x1="11.89" y1="10.41" x2="12.31" y2="10.91" layer="51"/>
<rectangle x1="12.33" y1="10.41" x2="12.75" y2="10.91" layer="51"/>
<rectangle x1="12.77" y1="10.41" x2="13.19" y2="10.91" layer="51"/>
<rectangle x1="13.21" y1="10.41" x2="13.63" y2="10.91" layer="51"/>
<rectangle x1="13.65" y1="10.41" x2="14.07" y2="10.91" layer="51"/>
<rectangle x1="14.09" y1="10.41" x2="14.51" y2="10.91" layer="51"/>
<rectangle x1="14.53" y1="10.41" x2="14.95" y2="10.91" layer="51"/>
<rectangle x1="14.97" y1="10.41" x2="15.39" y2="10.91" layer="51"/>
<rectangle x1="15.41" y1="10.41" x2="15.83" y2="10.91" layer="51"/>
<rectangle x1="15.85" y1="10.41" x2="16.27" y2="10.91" layer="51"/>
<rectangle x1="16.29" y1="10.41" x2="16.71" y2="10.91" layer="51"/>
<rectangle x1="16.73" y1="10.41" x2="17.15" y2="10.91" layer="51"/>
<rectangle x1="17.17" y1="10.41" x2="17.59" y2="10.91" layer="51"/>
<rectangle x1="17.61" y1="10.41" x2="18.03" y2="10.91" layer="51"/>
<rectangle x1="18.05" y1="10.41" x2="18.47" y2="10.91" layer="51"/>
<rectangle x1="18.49" y1="10.41" x2="18.91" y2="10.91" layer="51"/>
<rectangle x1="18.93" y1="10.41" x2="19.35" y2="10.91" layer="51"/>
<rectangle x1="19.37" y1="10.41" x2="19.79" y2="10.91" layer="51"/>
<rectangle x1="19.81" y1="10.41" x2="20.23" y2="10.91" layer="51"/>
<rectangle x1="20.25" y1="10.41" x2="20.67" y2="10.91" layer="51"/>
<rectangle x1="20.69" y1="10.41" x2="21.11" y2="10.91" layer="51"/>
<rectangle x1="21.13" y1="10.41" x2="21.55" y2="10.91" layer="51"/>
<rectangle x1="21.57" y1="10.41" x2="21.99" y2="10.91" layer="51"/>
<rectangle x1="22.01" y1="10.41" x2="22.43" y2="10.91" layer="51"/>
<rectangle x1="22.45" y1="10.41" x2="22.87" y2="10.91" layer="51"/>
<rectangle x1="22.89" y1="10.41" x2="23.31" y2="10.91" layer="51"/>
<rectangle x1="23.33" y1="10.41" x2="23.75" y2="10.91" layer="51"/>
<rectangle x1="23.77" y1="10.41" x2="24.19" y2="10.91" layer="51"/>
<rectangle x1="24.21" y1="10.41" x2="24.63" y2="10.91" layer="51"/>
<rectangle x1="24.65" y1="10.41" x2="25.07" y2="10.91" layer="51"/>
<rectangle x1="25.09" y1="10.41" x2="25.51" y2="10.91" layer="51"/>
<rectangle x1="25.53" y1="10.41" x2="25.95" y2="10.91" layer="51"/>
<rectangle x1="25.97" y1="10.41" x2="26.39" y2="10.91" layer="51"/>
<rectangle x1="26.41" y1="10.41" x2="26.83" y2="10.91" layer="51"/>
<rectangle x1="26.85" y1="10.41" x2="27.27" y2="10.91" layer="51"/>
<rectangle x1="27.29" y1="10.41" x2="27.71" y2="10.91" layer="51"/>
<rectangle x1="27.73" y1="10.41" x2="28.15" y2="10.91" layer="51"/>
<rectangle x1="-28.15" y1="9.89" x2="-27.73" y2="10.39" layer="51"/>
<rectangle x1="-27.71" y1="9.89" x2="-27.29" y2="10.39" layer="51"/>
<rectangle x1="-27.27" y1="9.89" x2="-26.85" y2="10.39" layer="51"/>
<rectangle x1="-26.83" y1="9.89" x2="-26.41" y2="10.39" layer="51"/>
<rectangle x1="-26.39" y1="9.89" x2="-25.97" y2="10.39" layer="51"/>
<rectangle x1="-25.95" y1="9.89" x2="-25.53" y2="10.39" layer="51"/>
<rectangle x1="-25.51" y1="9.89" x2="-25.09" y2="10.39" layer="51"/>
<rectangle x1="-25.07" y1="9.89" x2="-24.65" y2="10.39" layer="51"/>
<rectangle x1="-24.63" y1="9.89" x2="-24.21" y2="10.39" layer="51"/>
<rectangle x1="-24.19" y1="9.89" x2="-23.77" y2="10.39" layer="51"/>
<rectangle x1="-23.75" y1="9.89" x2="-23.33" y2="10.39" layer="51"/>
<rectangle x1="-23.31" y1="9.89" x2="-22.89" y2="10.39" layer="51"/>
<rectangle x1="-22.87" y1="9.89" x2="-22.45" y2="10.39" layer="51"/>
<rectangle x1="-22.43" y1="9.89" x2="-22.01" y2="10.39" layer="51"/>
<rectangle x1="-21.99" y1="9.89" x2="-21.57" y2="10.39" layer="51"/>
<rectangle x1="-21.55" y1="9.89" x2="-21.13" y2="10.39" layer="51"/>
<rectangle x1="-21.11" y1="9.89" x2="-20.69" y2="10.39" layer="51"/>
<rectangle x1="-20.67" y1="9.89" x2="-20.25" y2="10.39" layer="51"/>
<rectangle x1="-20.23" y1="9.89" x2="-19.81" y2="10.39" layer="51"/>
<rectangle x1="-19.79" y1="9.89" x2="-19.37" y2="10.39" layer="51"/>
<rectangle x1="-19.35" y1="9.89" x2="-18.93" y2="10.39" layer="51"/>
<rectangle x1="-18.91" y1="9.89" x2="-18.49" y2="10.39" layer="51"/>
<rectangle x1="-18.47" y1="9.89" x2="-18.05" y2="10.39" layer="51"/>
<rectangle x1="-18.03" y1="9.89" x2="-17.61" y2="10.39" layer="51"/>
<rectangle x1="-17.59" y1="9.89" x2="-17.17" y2="10.39" layer="51"/>
<rectangle x1="-17.15" y1="9.89" x2="-16.73" y2="10.39" layer="51"/>
<rectangle x1="-16.71" y1="9.89" x2="-16.29" y2="10.39" layer="51"/>
<rectangle x1="-16.27" y1="9.89" x2="-15.85" y2="10.39" layer="51"/>
<rectangle x1="-15.83" y1="9.89" x2="-15.41" y2="10.39" layer="51"/>
<rectangle x1="-15.39" y1="9.89" x2="-14.97" y2="10.39" layer="51"/>
<rectangle x1="-14.95" y1="9.89" x2="-14.53" y2="10.39" layer="51"/>
<rectangle x1="-14.51" y1="9.89" x2="-14.09" y2="10.39" layer="51"/>
<rectangle x1="-14.07" y1="9.89" x2="-13.65" y2="10.39" layer="51"/>
<rectangle x1="-13.63" y1="9.89" x2="-13.21" y2="10.39" layer="51"/>
<rectangle x1="-13.19" y1="9.89" x2="-12.77" y2="10.39" layer="51"/>
<rectangle x1="-12.75" y1="9.89" x2="-12.33" y2="10.39" layer="51"/>
<rectangle x1="-12.31" y1="9.89" x2="-11.89" y2="10.39" layer="51"/>
<rectangle x1="-11.87" y1="9.89" x2="-11.45" y2="10.39" layer="51"/>
<rectangle x1="-11.43" y1="9.89" x2="-11.01" y2="10.39" layer="51"/>
<rectangle x1="-10.99" y1="9.89" x2="-10.57" y2="10.39" layer="51"/>
<rectangle x1="-10.55" y1="9.89" x2="-10.13" y2="10.39" layer="51"/>
<rectangle x1="-10.11" y1="9.89" x2="-9.69" y2="10.39" layer="51"/>
<rectangle x1="-9.67" y1="9.89" x2="-9.25" y2="10.39" layer="51"/>
<rectangle x1="-9.23" y1="9.89" x2="-8.81" y2="10.39" layer="51"/>
<rectangle x1="-8.79" y1="9.89" x2="-8.37" y2="10.39" layer="51"/>
<rectangle x1="-8.35" y1="9.89" x2="-7.93" y2="10.39" layer="51"/>
<rectangle x1="-7.91" y1="9.89" x2="-7.49" y2="10.39" layer="51"/>
<rectangle x1="-7.47" y1="9.89" x2="-7.05" y2="10.39" layer="51"/>
<rectangle x1="-7.03" y1="9.89" x2="-6.61" y2="10.39" layer="51"/>
<rectangle x1="-6.59" y1="9.89" x2="-6.17" y2="10.39" layer="51"/>
<rectangle x1="-6.15" y1="9.89" x2="-5.73" y2="10.39" layer="51"/>
<rectangle x1="-5.71" y1="9.89" x2="-5.29" y2="10.39" layer="51"/>
<rectangle x1="-5.27" y1="9.89" x2="-4.85" y2="10.39" layer="51"/>
<rectangle x1="-4.83" y1="9.89" x2="-4.41" y2="10.39" layer="51"/>
<rectangle x1="-4.39" y1="9.89" x2="-3.97" y2="10.39" layer="51"/>
<rectangle x1="-3.95" y1="9.89" x2="-3.53" y2="10.39" layer="51"/>
<rectangle x1="-3.51" y1="9.89" x2="-3.09" y2="10.39" layer="51"/>
<rectangle x1="-3.07" y1="9.89" x2="-2.65" y2="10.39" layer="51"/>
<rectangle x1="-2.63" y1="9.89" x2="-2.21" y2="10.39" layer="51"/>
<rectangle x1="-2.19" y1="9.89" x2="-1.77" y2="10.39" layer="51"/>
<rectangle x1="-1.75" y1="9.89" x2="-1.33" y2="10.39" layer="51"/>
<rectangle x1="-1.31" y1="9.89" x2="-0.89" y2="10.39" layer="51"/>
<rectangle x1="-0.87" y1="9.89" x2="-0.45" y2="10.39" layer="51"/>
<rectangle x1="-0.43" y1="9.89" x2="-0.01" y2="10.39" layer="51"/>
<rectangle x1="0.01" y1="9.89" x2="0.43" y2="10.39" layer="51"/>
<rectangle x1="0.45" y1="9.89" x2="0.87" y2="10.39" layer="51"/>
<rectangle x1="0.89" y1="9.89" x2="1.31" y2="10.39" layer="51"/>
<rectangle x1="1.33" y1="9.89" x2="1.75" y2="10.39" layer="51"/>
<rectangle x1="1.77" y1="9.89" x2="2.19" y2="10.39" layer="51"/>
<rectangle x1="2.21" y1="9.89" x2="2.63" y2="10.39" layer="51"/>
<rectangle x1="2.65" y1="9.89" x2="3.07" y2="10.39" layer="51"/>
<rectangle x1="3.09" y1="9.89" x2="3.51" y2="10.39" layer="51"/>
<rectangle x1="3.53" y1="9.89" x2="3.95" y2="10.39" layer="51"/>
<rectangle x1="3.97" y1="9.89" x2="4.39" y2="10.39" layer="51"/>
<rectangle x1="4.41" y1="9.89" x2="4.83" y2="10.39" layer="51"/>
<rectangle x1="4.85" y1="9.89" x2="5.27" y2="10.39" layer="51"/>
<rectangle x1="5.29" y1="9.89" x2="5.71" y2="10.39" layer="51"/>
<rectangle x1="5.73" y1="9.89" x2="6.15" y2="10.39" layer="51"/>
<rectangle x1="6.17" y1="9.89" x2="6.59" y2="10.39" layer="51"/>
<rectangle x1="6.61" y1="9.89" x2="7.03" y2="10.39" layer="51"/>
<rectangle x1="7.05" y1="9.89" x2="7.47" y2="10.39" layer="51"/>
<rectangle x1="7.49" y1="9.89" x2="7.91" y2="10.39" layer="51"/>
<rectangle x1="7.93" y1="9.89" x2="8.35" y2="10.39" layer="51"/>
<rectangle x1="8.37" y1="9.89" x2="8.79" y2="10.39" layer="51"/>
<rectangle x1="8.81" y1="9.89" x2="9.23" y2="10.39" layer="51"/>
<rectangle x1="9.25" y1="9.89" x2="9.67" y2="10.39" layer="51"/>
<rectangle x1="9.69" y1="9.89" x2="10.11" y2="10.39" layer="51"/>
<rectangle x1="10.13" y1="9.89" x2="10.55" y2="10.39" layer="51"/>
<rectangle x1="10.57" y1="9.89" x2="10.99" y2="10.39" layer="51"/>
<rectangle x1="11.01" y1="9.89" x2="11.43" y2="10.39" layer="51"/>
<rectangle x1="11.45" y1="9.89" x2="11.87" y2="10.39" layer="51"/>
<rectangle x1="11.89" y1="9.89" x2="12.31" y2="10.39" layer="51"/>
<rectangle x1="12.33" y1="9.89" x2="12.75" y2="10.39" layer="51"/>
<rectangle x1="12.77" y1="9.89" x2="13.19" y2="10.39" layer="51"/>
<rectangle x1="13.21" y1="9.89" x2="13.63" y2="10.39" layer="51"/>
<rectangle x1="13.65" y1="9.89" x2="14.07" y2="10.39" layer="51"/>
<rectangle x1="14.09" y1="9.89" x2="14.51" y2="10.39" layer="51"/>
<rectangle x1="14.53" y1="9.89" x2="14.95" y2="10.39" layer="51"/>
<rectangle x1="14.97" y1="9.89" x2="15.39" y2="10.39" layer="51"/>
<rectangle x1="15.41" y1="9.89" x2="15.83" y2="10.39" layer="51"/>
<rectangle x1="15.85" y1="9.89" x2="16.27" y2="10.39" layer="51"/>
<rectangle x1="16.29" y1="9.89" x2="16.71" y2="10.39" layer="51"/>
<rectangle x1="16.73" y1="9.89" x2="17.15" y2="10.39" layer="51"/>
<rectangle x1="17.17" y1="9.89" x2="17.59" y2="10.39" layer="51"/>
<rectangle x1="17.61" y1="9.89" x2="18.03" y2="10.39" layer="51"/>
<rectangle x1="18.05" y1="9.89" x2="18.47" y2="10.39" layer="51"/>
<rectangle x1="18.49" y1="9.89" x2="18.91" y2="10.39" layer="51"/>
<rectangle x1="18.93" y1="9.89" x2="19.35" y2="10.39" layer="51"/>
<rectangle x1="19.37" y1="9.89" x2="19.79" y2="10.39" layer="51"/>
<rectangle x1="19.81" y1="9.89" x2="20.23" y2="10.39" layer="51"/>
<rectangle x1="20.25" y1="9.89" x2="20.67" y2="10.39" layer="51"/>
<rectangle x1="20.69" y1="9.89" x2="21.11" y2="10.39" layer="51"/>
<rectangle x1="21.13" y1="9.89" x2="21.55" y2="10.39" layer="51"/>
<rectangle x1="21.57" y1="9.89" x2="21.99" y2="10.39" layer="51"/>
<rectangle x1="22.01" y1="9.89" x2="22.43" y2="10.39" layer="51"/>
<rectangle x1="22.45" y1="9.89" x2="22.87" y2="10.39" layer="51"/>
<rectangle x1="22.89" y1="9.89" x2="23.31" y2="10.39" layer="51"/>
<rectangle x1="23.33" y1="9.89" x2="23.75" y2="10.39" layer="51"/>
<rectangle x1="23.77" y1="9.89" x2="24.19" y2="10.39" layer="51"/>
<rectangle x1="24.21" y1="9.89" x2="24.63" y2="10.39" layer="51"/>
<rectangle x1="24.65" y1="9.89" x2="25.07" y2="10.39" layer="51"/>
<rectangle x1="25.09" y1="9.89" x2="25.51" y2="10.39" layer="51"/>
<rectangle x1="25.53" y1="9.89" x2="25.95" y2="10.39" layer="51"/>
<rectangle x1="25.97" y1="9.89" x2="26.39" y2="10.39" layer="51"/>
<rectangle x1="26.41" y1="9.89" x2="26.83" y2="10.39" layer="51"/>
<rectangle x1="26.85" y1="9.89" x2="27.27" y2="10.39" layer="51"/>
<rectangle x1="27.29" y1="9.89" x2="27.71" y2="10.39" layer="51"/>
<rectangle x1="27.73" y1="9.89" x2="28.15" y2="10.39" layer="51"/>
<rectangle x1="-28.15" y1="9.37" x2="-27.73" y2="9.87" layer="51"/>
<rectangle x1="-27.71" y1="9.37" x2="-27.29" y2="9.87" layer="51"/>
<rectangle x1="-27.27" y1="9.37" x2="-26.85" y2="9.87" layer="51"/>
<rectangle x1="-26.83" y1="9.37" x2="-26.41" y2="9.87" layer="51"/>
<rectangle x1="-26.39" y1="9.37" x2="-25.97" y2="9.87" layer="51"/>
<rectangle x1="-25.95" y1="9.37" x2="-25.53" y2="9.87" layer="51"/>
<rectangle x1="-25.51" y1="9.37" x2="-25.09" y2="9.87" layer="51"/>
<rectangle x1="-25.07" y1="9.37" x2="-24.65" y2="9.87" layer="51"/>
<rectangle x1="-24.63" y1="9.37" x2="-24.21" y2="9.87" layer="51"/>
<rectangle x1="-24.19" y1="9.37" x2="-23.77" y2="9.87" layer="51"/>
<rectangle x1="-23.75" y1="9.37" x2="-23.33" y2="9.87" layer="51"/>
<rectangle x1="-23.31" y1="9.37" x2="-22.89" y2="9.87" layer="51"/>
<rectangle x1="-22.87" y1="9.37" x2="-22.45" y2="9.87" layer="51"/>
<rectangle x1="-22.43" y1="9.37" x2="-22.01" y2="9.87" layer="51"/>
<rectangle x1="-21.99" y1="9.37" x2="-21.57" y2="9.87" layer="51"/>
<rectangle x1="-21.55" y1="9.37" x2="-21.13" y2="9.87" layer="51"/>
<rectangle x1="-21.11" y1="9.37" x2="-20.69" y2="9.87" layer="51"/>
<rectangle x1="-20.67" y1="9.37" x2="-20.25" y2="9.87" layer="51"/>
<rectangle x1="-20.23" y1="9.37" x2="-19.81" y2="9.87" layer="51"/>
<rectangle x1="-19.79" y1="9.37" x2="-19.37" y2="9.87" layer="51"/>
<rectangle x1="-19.35" y1="9.37" x2="-18.93" y2="9.87" layer="51"/>
<rectangle x1="-18.91" y1="9.37" x2="-18.49" y2="9.87" layer="51"/>
<rectangle x1="-18.47" y1="9.37" x2="-18.05" y2="9.87" layer="51"/>
<rectangle x1="-18.03" y1="9.37" x2="-17.61" y2="9.87" layer="51"/>
<rectangle x1="-17.59" y1="9.37" x2="-17.17" y2="9.87" layer="51"/>
<rectangle x1="-17.15" y1="9.37" x2="-16.73" y2="9.87" layer="51"/>
<rectangle x1="-16.71" y1="9.37" x2="-16.29" y2="9.87" layer="51"/>
<rectangle x1="-16.27" y1="9.37" x2="-15.85" y2="9.87" layer="51"/>
<rectangle x1="-15.83" y1="9.37" x2="-15.41" y2="9.87" layer="51"/>
<rectangle x1="-15.39" y1="9.37" x2="-14.97" y2="9.87" layer="51"/>
<rectangle x1="-14.95" y1="9.37" x2="-14.53" y2="9.87" layer="51"/>
<rectangle x1="-14.51" y1="9.37" x2="-14.09" y2="9.87" layer="51"/>
<rectangle x1="-14.07" y1="9.37" x2="-13.65" y2="9.87" layer="51"/>
<rectangle x1="-13.63" y1="9.37" x2="-13.21" y2="9.87" layer="51"/>
<rectangle x1="-13.19" y1="9.37" x2="-12.77" y2="9.87" layer="51"/>
<rectangle x1="-12.75" y1="9.37" x2="-12.33" y2="9.87" layer="51"/>
<rectangle x1="-12.31" y1="9.37" x2="-11.89" y2="9.87" layer="51"/>
<rectangle x1="-11.87" y1="9.37" x2="-11.45" y2="9.87" layer="51"/>
<rectangle x1="-11.43" y1="9.37" x2="-11.01" y2="9.87" layer="51"/>
<rectangle x1="-10.99" y1="9.37" x2="-10.57" y2="9.87" layer="51"/>
<rectangle x1="-10.55" y1="9.37" x2="-10.13" y2="9.87" layer="51"/>
<rectangle x1="-10.11" y1="9.37" x2="-9.69" y2="9.87" layer="51"/>
<rectangle x1="-9.67" y1="9.37" x2="-9.25" y2="9.87" layer="51"/>
<rectangle x1="-9.23" y1="9.37" x2="-8.81" y2="9.87" layer="51"/>
<rectangle x1="-8.79" y1="9.37" x2="-8.37" y2="9.87" layer="51"/>
<rectangle x1="-8.35" y1="9.37" x2="-7.93" y2="9.87" layer="51"/>
<rectangle x1="-7.91" y1="9.37" x2="-7.49" y2="9.87" layer="51"/>
<rectangle x1="-7.47" y1="9.37" x2="-7.05" y2="9.87" layer="51"/>
<rectangle x1="-7.03" y1="9.37" x2="-6.61" y2="9.87" layer="51"/>
<rectangle x1="-6.59" y1="9.37" x2="-6.17" y2="9.87" layer="51"/>
<rectangle x1="-6.15" y1="9.37" x2="-5.73" y2="9.87" layer="51"/>
<rectangle x1="-5.71" y1="9.37" x2="-5.29" y2="9.87" layer="51"/>
<rectangle x1="-5.27" y1="9.37" x2="-4.85" y2="9.87" layer="51"/>
<rectangle x1="-4.83" y1="9.37" x2="-4.41" y2="9.87" layer="51"/>
<rectangle x1="-4.39" y1="9.37" x2="-3.97" y2="9.87" layer="51"/>
<rectangle x1="-3.95" y1="9.37" x2="-3.53" y2="9.87" layer="51"/>
<rectangle x1="-3.51" y1="9.37" x2="-3.09" y2="9.87" layer="51"/>
<rectangle x1="-3.07" y1="9.37" x2="-2.65" y2="9.87" layer="51"/>
<rectangle x1="-2.63" y1="9.37" x2="-2.21" y2="9.87" layer="51"/>
<rectangle x1="-2.19" y1="9.37" x2="-1.77" y2="9.87" layer="51"/>
<rectangle x1="-1.75" y1="9.37" x2="-1.33" y2="9.87" layer="51"/>
<rectangle x1="-1.31" y1="9.37" x2="-0.89" y2="9.87" layer="51"/>
<rectangle x1="-0.87" y1="9.37" x2="-0.45" y2="9.87" layer="51"/>
<rectangle x1="-0.43" y1="9.37" x2="-0.01" y2="9.87" layer="51"/>
<rectangle x1="0.01" y1="9.37" x2="0.43" y2="9.87" layer="51"/>
<rectangle x1="0.45" y1="9.37" x2="0.87" y2="9.87" layer="51"/>
<rectangle x1="0.89" y1="9.37" x2="1.31" y2="9.87" layer="51"/>
<rectangle x1="1.33" y1="9.37" x2="1.75" y2="9.87" layer="51"/>
<rectangle x1="1.77" y1="9.37" x2="2.19" y2="9.87" layer="51"/>
<rectangle x1="2.21" y1="9.37" x2="2.63" y2="9.87" layer="51"/>
<rectangle x1="2.65" y1="9.37" x2="3.07" y2="9.87" layer="51"/>
<rectangle x1="3.09" y1="9.37" x2="3.51" y2="9.87" layer="51"/>
<rectangle x1="3.53" y1="9.37" x2="3.95" y2="9.87" layer="51"/>
<rectangle x1="3.97" y1="9.37" x2="4.39" y2="9.87" layer="51"/>
<rectangle x1="4.41" y1="9.37" x2="4.83" y2="9.87" layer="51"/>
<rectangle x1="4.85" y1="9.37" x2="5.27" y2="9.87" layer="51"/>
<rectangle x1="5.29" y1="9.37" x2="5.71" y2="9.87" layer="51"/>
<rectangle x1="5.73" y1="9.37" x2="6.15" y2="9.87" layer="51"/>
<rectangle x1="6.17" y1="9.37" x2="6.59" y2="9.87" layer="51"/>
<rectangle x1="6.61" y1="9.37" x2="7.03" y2="9.87" layer="51"/>
<rectangle x1="7.05" y1="9.37" x2="7.47" y2="9.87" layer="51"/>
<rectangle x1="7.49" y1="9.37" x2="7.91" y2="9.87" layer="51"/>
<rectangle x1="7.93" y1="9.37" x2="8.35" y2="9.87" layer="51"/>
<rectangle x1="8.37" y1="9.37" x2="8.79" y2="9.87" layer="51"/>
<rectangle x1="8.81" y1="9.37" x2="9.23" y2="9.87" layer="51"/>
<rectangle x1="9.25" y1="9.37" x2="9.67" y2="9.87" layer="51"/>
<rectangle x1="9.69" y1="9.37" x2="10.11" y2="9.87" layer="51"/>
<rectangle x1="10.13" y1="9.37" x2="10.55" y2="9.87" layer="51"/>
<rectangle x1="10.57" y1="9.37" x2="10.99" y2="9.87" layer="51"/>
<rectangle x1="11.01" y1="9.37" x2="11.43" y2="9.87" layer="51"/>
<rectangle x1="11.45" y1="9.37" x2="11.87" y2="9.87" layer="51"/>
<rectangle x1="11.89" y1="9.37" x2="12.31" y2="9.87" layer="51"/>
<rectangle x1="12.33" y1="9.37" x2="12.75" y2="9.87" layer="51"/>
<rectangle x1="12.77" y1="9.37" x2="13.19" y2="9.87" layer="51"/>
<rectangle x1="13.21" y1="9.37" x2="13.63" y2="9.87" layer="51"/>
<rectangle x1="13.65" y1="9.37" x2="14.07" y2="9.87" layer="51"/>
<rectangle x1="14.09" y1="9.37" x2="14.51" y2="9.87" layer="51"/>
<rectangle x1="14.53" y1="9.37" x2="14.95" y2="9.87" layer="51"/>
<rectangle x1="14.97" y1="9.37" x2="15.39" y2="9.87" layer="51"/>
<rectangle x1="15.41" y1="9.37" x2="15.83" y2="9.87" layer="51"/>
<rectangle x1="15.85" y1="9.37" x2="16.27" y2="9.87" layer="51"/>
<rectangle x1="16.29" y1="9.37" x2="16.71" y2="9.87" layer="51"/>
<rectangle x1="16.73" y1="9.37" x2="17.15" y2="9.87" layer="51"/>
<rectangle x1="17.17" y1="9.37" x2="17.59" y2="9.87" layer="51"/>
<rectangle x1="17.61" y1="9.37" x2="18.03" y2="9.87" layer="51"/>
<rectangle x1="18.05" y1="9.37" x2="18.47" y2="9.87" layer="51"/>
<rectangle x1="18.49" y1="9.37" x2="18.91" y2="9.87" layer="51"/>
<rectangle x1="18.93" y1="9.37" x2="19.35" y2="9.87" layer="51"/>
<rectangle x1="19.37" y1="9.37" x2="19.79" y2="9.87" layer="51"/>
<rectangle x1="19.81" y1="9.37" x2="20.23" y2="9.87" layer="51"/>
<rectangle x1="20.25" y1="9.37" x2="20.67" y2="9.87" layer="51"/>
<rectangle x1="20.69" y1="9.37" x2="21.11" y2="9.87" layer="51"/>
<rectangle x1="21.13" y1="9.37" x2="21.55" y2="9.87" layer="51"/>
<rectangle x1="21.57" y1="9.37" x2="21.99" y2="9.87" layer="51"/>
<rectangle x1="22.01" y1="9.37" x2="22.43" y2="9.87" layer="51"/>
<rectangle x1="22.45" y1="9.37" x2="22.87" y2="9.87" layer="51"/>
<rectangle x1="22.89" y1="9.37" x2="23.31" y2="9.87" layer="51"/>
<rectangle x1="23.33" y1="9.37" x2="23.75" y2="9.87" layer="51"/>
<rectangle x1="23.77" y1="9.37" x2="24.19" y2="9.87" layer="51"/>
<rectangle x1="24.21" y1="9.37" x2="24.63" y2="9.87" layer="51"/>
<rectangle x1="24.65" y1="9.37" x2="25.07" y2="9.87" layer="51"/>
<rectangle x1="25.09" y1="9.37" x2="25.51" y2="9.87" layer="51"/>
<rectangle x1="25.53" y1="9.37" x2="25.95" y2="9.87" layer="51"/>
<rectangle x1="25.97" y1="9.37" x2="26.39" y2="9.87" layer="51"/>
<rectangle x1="26.41" y1="9.37" x2="26.83" y2="9.87" layer="51"/>
<rectangle x1="26.85" y1="9.37" x2="27.27" y2="9.87" layer="51"/>
<rectangle x1="27.29" y1="9.37" x2="27.71" y2="9.87" layer="51"/>
<rectangle x1="27.73" y1="9.37" x2="28.15" y2="9.87" layer="51"/>
<rectangle x1="-28.15" y1="8.85" x2="-27.73" y2="9.35" layer="51"/>
<rectangle x1="-27.71" y1="8.85" x2="-27.29" y2="9.35" layer="51"/>
<rectangle x1="-27.27" y1="8.85" x2="-26.85" y2="9.35" layer="51"/>
<rectangle x1="-26.83" y1="8.85" x2="-26.41" y2="9.35" layer="51"/>
<rectangle x1="-26.39" y1="8.85" x2="-25.97" y2="9.35" layer="51"/>
<rectangle x1="-25.95" y1="8.85" x2="-25.53" y2="9.35" layer="51"/>
<rectangle x1="-25.51" y1="8.85" x2="-25.09" y2="9.35" layer="51"/>
<rectangle x1="-25.07" y1="8.85" x2="-24.65" y2="9.35" layer="51"/>
<rectangle x1="-24.63" y1="8.85" x2="-24.21" y2="9.35" layer="51"/>
<rectangle x1="-24.19" y1="8.85" x2="-23.77" y2="9.35" layer="51"/>
<rectangle x1="-23.75" y1="8.85" x2="-23.33" y2="9.35" layer="51"/>
<rectangle x1="-23.31" y1="8.85" x2="-22.89" y2="9.35" layer="51"/>
<rectangle x1="-22.87" y1="8.85" x2="-22.45" y2="9.35" layer="51"/>
<rectangle x1="-22.43" y1="8.85" x2="-22.01" y2="9.35" layer="51"/>
<rectangle x1="-21.99" y1="8.85" x2="-21.57" y2="9.35" layer="51"/>
<rectangle x1="-21.55" y1="8.85" x2="-21.13" y2="9.35" layer="51"/>
<rectangle x1="-21.11" y1="8.85" x2="-20.69" y2="9.35" layer="51"/>
<rectangle x1="-20.67" y1="8.85" x2="-20.25" y2="9.35" layer="51"/>
<rectangle x1="-20.23" y1="8.85" x2="-19.81" y2="9.35" layer="51"/>
<rectangle x1="-19.79" y1="8.85" x2="-19.37" y2="9.35" layer="51"/>
<rectangle x1="-19.35" y1="8.85" x2="-18.93" y2="9.35" layer="51"/>
<rectangle x1="-18.91" y1="8.85" x2="-18.49" y2="9.35" layer="51"/>
<rectangle x1="-18.47" y1="8.85" x2="-18.05" y2="9.35" layer="51"/>
<rectangle x1="-18.03" y1="8.85" x2="-17.61" y2="9.35" layer="51"/>
<rectangle x1="-17.59" y1="8.85" x2="-17.17" y2="9.35" layer="51"/>
<rectangle x1="-17.15" y1="8.85" x2="-16.73" y2="9.35" layer="51"/>
<rectangle x1="-16.71" y1="8.85" x2="-16.29" y2="9.35" layer="51"/>
<rectangle x1="-16.27" y1="8.85" x2="-15.85" y2="9.35" layer="51"/>
<rectangle x1="-15.83" y1="8.85" x2="-15.41" y2="9.35" layer="51"/>
<rectangle x1="-15.39" y1="8.85" x2="-14.97" y2="9.35" layer="51"/>
<rectangle x1="-14.95" y1="8.85" x2="-14.53" y2="9.35" layer="51"/>
<rectangle x1="-14.51" y1="8.85" x2="-14.09" y2="9.35" layer="51"/>
<rectangle x1="-14.07" y1="8.85" x2="-13.65" y2="9.35" layer="51"/>
<rectangle x1="-13.63" y1="8.85" x2="-13.21" y2="9.35" layer="51"/>
<rectangle x1="-13.19" y1="8.85" x2="-12.77" y2="9.35" layer="51"/>
<rectangle x1="-12.75" y1="8.85" x2="-12.33" y2="9.35" layer="51"/>
<rectangle x1="-12.31" y1="8.85" x2="-11.89" y2="9.35" layer="51"/>
<rectangle x1="-11.87" y1="8.85" x2="-11.45" y2="9.35" layer="51"/>
<rectangle x1="-11.43" y1="8.85" x2="-11.01" y2="9.35" layer="51"/>
<rectangle x1="-10.99" y1="8.85" x2="-10.57" y2="9.35" layer="51"/>
<rectangle x1="-10.55" y1="8.85" x2="-10.13" y2="9.35" layer="51"/>
<rectangle x1="-10.11" y1="8.85" x2="-9.69" y2="9.35" layer="51"/>
<rectangle x1="-9.67" y1="8.85" x2="-9.25" y2="9.35" layer="51"/>
<rectangle x1="-9.23" y1="8.85" x2="-8.81" y2="9.35" layer="51"/>
<rectangle x1="-8.79" y1="8.85" x2="-8.37" y2="9.35" layer="51"/>
<rectangle x1="-8.35" y1="8.85" x2="-7.93" y2="9.35" layer="51"/>
<rectangle x1="-7.91" y1="8.85" x2="-7.49" y2="9.35" layer="51"/>
<rectangle x1="-7.47" y1="8.85" x2="-7.05" y2="9.35" layer="51"/>
<rectangle x1="-7.03" y1="8.85" x2="-6.61" y2="9.35" layer="51"/>
<rectangle x1="-6.59" y1="8.85" x2="-6.17" y2="9.35" layer="51"/>
<rectangle x1="-6.15" y1="8.85" x2="-5.73" y2="9.35" layer="51"/>
<rectangle x1="-5.71" y1="8.85" x2="-5.29" y2="9.35" layer="51"/>
<rectangle x1="-5.27" y1="8.85" x2="-4.85" y2="9.35" layer="51"/>
<rectangle x1="-4.83" y1="8.85" x2="-4.41" y2="9.35" layer="51"/>
<rectangle x1="-4.39" y1="8.85" x2="-3.97" y2="9.35" layer="51"/>
<rectangle x1="-3.95" y1="8.85" x2="-3.53" y2="9.35" layer="51"/>
<rectangle x1="-3.51" y1="8.85" x2="-3.09" y2="9.35" layer="51"/>
<rectangle x1="-3.07" y1="8.85" x2="-2.65" y2="9.35" layer="51"/>
<rectangle x1="-2.63" y1="8.85" x2="-2.21" y2="9.35" layer="51"/>
<rectangle x1="-2.19" y1="8.85" x2="-1.77" y2="9.35" layer="51"/>
<rectangle x1="-1.75" y1="8.85" x2="-1.33" y2="9.35" layer="51"/>
<rectangle x1="-1.31" y1="8.85" x2="-0.89" y2="9.35" layer="51"/>
<rectangle x1="-0.87" y1="8.85" x2="-0.45" y2="9.35" layer="51"/>
<rectangle x1="-0.43" y1="8.85" x2="-0.01" y2="9.35" layer="51"/>
<rectangle x1="0.01" y1="8.85" x2="0.43" y2="9.35" layer="51"/>
<rectangle x1="0.45" y1="8.85" x2="0.87" y2="9.35" layer="51"/>
<rectangle x1="0.89" y1="8.85" x2="1.31" y2="9.35" layer="51"/>
<rectangle x1="1.33" y1="8.85" x2="1.75" y2="9.35" layer="51"/>
<rectangle x1="1.77" y1="8.85" x2="2.19" y2="9.35" layer="51"/>
<rectangle x1="2.21" y1="8.85" x2="2.63" y2="9.35" layer="51"/>
<rectangle x1="2.65" y1="8.85" x2="3.07" y2="9.35" layer="51"/>
<rectangle x1="3.09" y1="8.85" x2="3.51" y2="9.35" layer="51"/>
<rectangle x1="3.53" y1="8.85" x2="3.95" y2="9.35" layer="51"/>
<rectangle x1="3.97" y1="8.85" x2="4.39" y2="9.35" layer="51"/>
<rectangle x1="4.41" y1="8.85" x2="4.83" y2="9.35" layer="51"/>
<rectangle x1="4.85" y1="8.85" x2="5.27" y2="9.35" layer="51"/>
<rectangle x1="5.29" y1="8.85" x2="5.71" y2="9.35" layer="51"/>
<rectangle x1="5.73" y1="8.85" x2="6.15" y2="9.35" layer="51"/>
<rectangle x1="6.17" y1="8.85" x2="6.59" y2="9.35" layer="51"/>
<rectangle x1="6.61" y1="8.85" x2="7.03" y2="9.35" layer="51"/>
<rectangle x1="7.05" y1="8.85" x2="7.47" y2="9.35" layer="51"/>
<rectangle x1="7.49" y1="8.85" x2="7.91" y2="9.35" layer="51"/>
<rectangle x1="7.93" y1="8.85" x2="8.35" y2="9.35" layer="51"/>
<rectangle x1="8.37" y1="8.85" x2="8.79" y2="9.35" layer="51"/>
<rectangle x1="8.81" y1="8.85" x2="9.23" y2="9.35" layer="51"/>
<rectangle x1="9.25" y1="8.85" x2="9.67" y2="9.35" layer="51"/>
<rectangle x1="9.69" y1="8.85" x2="10.11" y2="9.35" layer="51"/>
<rectangle x1="10.13" y1="8.85" x2="10.55" y2="9.35" layer="51"/>
<rectangle x1="10.57" y1="8.85" x2="10.99" y2="9.35" layer="51"/>
<rectangle x1="11.01" y1="8.85" x2="11.43" y2="9.35" layer="51"/>
<rectangle x1="11.45" y1="8.85" x2="11.87" y2="9.35" layer="51"/>
<rectangle x1="11.89" y1="8.85" x2="12.31" y2="9.35" layer="51"/>
<rectangle x1="12.33" y1="8.85" x2="12.75" y2="9.35" layer="51"/>
<rectangle x1="12.77" y1="8.85" x2="13.19" y2="9.35" layer="51"/>
<rectangle x1="13.21" y1="8.85" x2="13.63" y2="9.35" layer="51"/>
<rectangle x1="13.65" y1="8.85" x2="14.07" y2="9.35" layer="51"/>
<rectangle x1="14.09" y1="8.85" x2="14.51" y2="9.35" layer="51"/>
<rectangle x1="14.53" y1="8.85" x2="14.95" y2="9.35" layer="51"/>
<rectangle x1="14.97" y1="8.85" x2="15.39" y2="9.35" layer="51"/>
<rectangle x1="15.41" y1="8.85" x2="15.83" y2="9.35" layer="51"/>
<rectangle x1="15.85" y1="8.85" x2="16.27" y2="9.35" layer="51"/>
<rectangle x1="16.29" y1="8.85" x2="16.71" y2="9.35" layer="51"/>
<rectangle x1="16.73" y1="8.85" x2="17.15" y2="9.35" layer="51"/>
<rectangle x1="17.17" y1="8.85" x2="17.59" y2="9.35" layer="51"/>
<rectangle x1="17.61" y1="8.85" x2="18.03" y2="9.35" layer="51"/>
<rectangle x1="18.05" y1="8.85" x2="18.47" y2="9.35" layer="51"/>
<rectangle x1="18.49" y1="8.85" x2="18.91" y2="9.35" layer="51"/>
<rectangle x1="18.93" y1="8.85" x2="19.35" y2="9.35" layer="51"/>
<rectangle x1="19.37" y1="8.85" x2="19.79" y2="9.35" layer="51"/>
<rectangle x1="19.81" y1="8.85" x2="20.23" y2="9.35" layer="51"/>
<rectangle x1="20.25" y1="8.85" x2="20.67" y2="9.35" layer="51"/>
<rectangle x1="20.69" y1="8.85" x2="21.11" y2="9.35" layer="51"/>
<rectangle x1="21.13" y1="8.85" x2="21.55" y2="9.35" layer="51"/>
<rectangle x1="21.57" y1="8.85" x2="21.99" y2="9.35" layer="51"/>
<rectangle x1="22.01" y1="8.85" x2="22.43" y2="9.35" layer="51"/>
<rectangle x1="22.45" y1="8.85" x2="22.87" y2="9.35" layer="51"/>
<rectangle x1="22.89" y1="8.85" x2="23.31" y2="9.35" layer="51"/>
<rectangle x1="23.33" y1="8.85" x2="23.75" y2="9.35" layer="51"/>
<rectangle x1="23.77" y1="8.85" x2="24.19" y2="9.35" layer="51"/>
<rectangle x1="24.21" y1="8.85" x2="24.63" y2="9.35" layer="51"/>
<rectangle x1="24.65" y1="8.85" x2="25.07" y2="9.35" layer="51"/>
<rectangle x1="25.09" y1="8.85" x2="25.51" y2="9.35" layer="51"/>
<rectangle x1="25.53" y1="8.85" x2="25.95" y2="9.35" layer="51"/>
<rectangle x1="25.97" y1="8.85" x2="26.39" y2="9.35" layer="51"/>
<rectangle x1="26.41" y1="8.85" x2="26.83" y2="9.35" layer="51"/>
<rectangle x1="26.85" y1="8.85" x2="27.27" y2="9.35" layer="51"/>
<rectangle x1="27.29" y1="8.85" x2="27.71" y2="9.35" layer="51"/>
<rectangle x1="27.73" y1="8.85" x2="28.15" y2="9.35" layer="51"/>
<rectangle x1="-28.15" y1="8.33" x2="-27.73" y2="8.83" layer="51"/>
<rectangle x1="-27.71" y1="8.33" x2="-27.29" y2="8.83" layer="51"/>
<rectangle x1="-27.27" y1="8.33" x2="-26.85" y2="8.83" layer="51"/>
<rectangle x1="-26.83" y1="8.33" x2="-26.41" y2="8.83" layer="51"/>
<rectangle x1="-26.39" y1="8.33" x2="-25.97" y2="8.83" layer="51"/>
<rectangle x1="-25.95" y1="8.33" x2="-25.53" y2="8.83" layer="51"/>
<rectangle x1="-25.51" y1="8.33" x2="-25.09" y2="8.83" layer="51"/>
<rectangle x1="-25.07" y1="8.33" x2="-24.65" y2="8.83" layer="51"/>
<rectangle x1="-24.63" y1="8.33" x2="-24.21" y2="8.83" layer="51"/>
<rectangle x1="-24.19" y1="8.33" x2="-23.77" y2="8.83" layer="51"/>
<rectangle x1="-23.75" y1="8.33" x2="-23.33" y2="8.83" layer="51"/>
<rectangle x1="-23.31" y1="8.33" x2="-22.89" y2="8.83" layer="51"/>
<rectangle x1="-22.87" y1="8.33" x2="-22.45" y2="8.83" layer="51"/>
<rectangle x1="-22.43" y1="8.33" x2="-22.01" y2="8.83" layer="51"/>
<rectangle x1="-21.99" y1="8.33" x2="-21.57" y2="8.83" layer="51"/>
<rectangle x1="-21.55" y1="8.33" x2="-21.13" y2="8.83" layer="51"/>
<rectangle x1="-21.11" y1="8.33" x2="-20.69" y2="8.83" layer="51"/>
<rectangle x1="-20.67" y1="8.33" x2="-20.25" y2="8.83" layer="51"/>
<rectangle x1="-20.23" y1="8.33" x2="-19.81" y2="8.83" layer="51"/>
<rectangle x1="-19.79" y1="8.33" x2="-19.37" y2="8.83" layer="51"/>
<rectangle x1="-19.35" y1="8.33" x2="-18.93" y2="8.83" layer="51"/>
<rectangle x1="-18.91" y1="8.33" x2="-18.49" y2="8.83" layer="51"/>
<rectangle x1="-18.47" y1="8.33" x2="-18.05" y2="8.83" layer="51"/>
<rectangle x1="-18.03" y1="8.33" x2="-17.61" y2="8.83" layer="51"/>
<rectangle x1="-17.59" y1="8.33" x2="-17.17" y2="8.83" layer="51"/>
<rectangle x1="-17.15" y1="8.33" x2="-16.73" y2="8.83" layer="51"/>
<rectangle x1="-16.71" y1="8.33" x2="-16.29" y2="8.83" layer="51"/>
<rectangle x1="-16.27" y1="8.33" x2="-15.85" y2="8.83" layer="51"/>
<rectangle x1="-15.83" y1="8.33" x2="-15.41" y2="8.83" layer="51"/>
<rectangle x1="-15.39" y1="8.33" x2="-14.97" y2="8.83" layer="51"/>
<rectangle x1="-14.95" y1="8.33" x2="-14.53" y2="8.83" layer="51"/>
<rectangle x1="-14.51" y1="8.33" x2="-14.09" y2="8.83" layer="51"/>
<rectangle x1="-14.07" y1="8.33" x2="-13.65" y2="8.83" layer="51"/>
<rectangle x1="-13.63" y1="8.33" x2="-13.21" y2="8.83" layer="51"/>
<rectangle x1="-13.19" y1="8.33" x2="-12.77" y2="8.83" layer="51"/>
<rectangle x1="-12.75" y1="8.33" x2="-12.33" y2="8.83" layer="51"/>
<rectangle x1="-12.31" y1="8.33" x2="-11.89" y2="8.83" layer="51"/>
<rectangle x1="-11.87" y1="8.33" x2="-11.45" y2="8.83" layer="51"/>
<rectangle x1="-11.43" y1="8.33" x2="-11.01" y2="8.83" layer="51"/>
<rectangle x1="-10.99" y1="8.33" x2="-10.57" y2="8.83" layer="51"/>
<rectangle x1="-10.55" y1="8.33" x2="-10.13" y2="8.83" layer="51"/>
<rectangle x1="-10.11" y1="8.33" x2="-9.69" y2="8.83" layer="51"/>
<rectangle x1="-9.67" y1="8.33" x2="-9.25" y2="8.83" layer="51"/>
<rectangle x1="-9.23" y1="8.33" x2="-8.81" y2="8.83" layer="51"/>
<rectangle x1="-8.79" y1="8.33" x2="-8.37" y2="8.83" layer="51"/>
<rectangle x1="-8.35" y1="8.33" x2="-7.93" y2="8.83" layer="51"/>
<rectangle x1="-7.91" y1="8.33" x2="-7.49" y2="8.83" layer="51"/>
<rectangle x1="-7.47" y1="8.33" x2="-7.05" y2="8.83" layer="51"/>
<rectangle x1="-7.03" y1="8.33" x2="-6.61" y2="8.83" layer="51"/>
<rectangle x1="-6.59" y1="8.33" x2="-6.17" y2="8.83" layer="51"/>
<rectangle x1="-6.15" y1="8.33" x2="-5.73" y2="8.83" layer="51"/>
<rectangle x1="-5.71" y1="8.33" x2="-5.29" y2="8.83" layer="51"/>
<rectangle x1="-5.27" y1="8.33" x2="-4.85" y2="8.83" layer="51"/>
<rectangle x1="-4.83" y1="8.33" x2="-4.41" y2="8.83" layer="51"/>
<rectangle x1="-4.39" y1="8.33" x2="-3.97" y2="8.83" layer="51"/>
<rectangle x1="-3.95" y1="8.33" x2="-3.53" y2="8.83" layer="51"/>
<rectangle x1="-3.51" y1="8.33" x2="-3.09" y2="8.83" layer="51"/>
<rectangle x1="-3.07" y1="8.33" x2="-2.65" y2="8.83" layer="51"/>
<rectangle x1="-2.63" y1="8.33" x2="-2.21" y2="8.83" layer="51"/>
<rectangle x1="-2.19" y1="8.33" x2="-1.77" y2="8.83" layer="51"/>
<rectangle x1="-1.75" y1="8.33" x2="-1.33" y2="8.83" layer="51"/>
<rectangle x1="-1.31" y1="8.33" x2="-0.89" y2="8.83" layer="51"/>
<rectangle x1="-0.87" y1="8.33" x2="-0.45" y2="8.83" layer="51"/>
<rectangle x1="-0.43" y1="8.33" x2="-0.01" y2="8.83" layer="51"/>
<rectangle x1="0.01" y1="8.33" x2="0.43" y2="8.83" layer="51"/>
<rectangle x1="0.45" y1="8.33" x2="0.87" y2="8.83" layer="51"/>
<rectangle x1="0.89" y1="8.33" x2="1.31" y2="8.83" layer="51"/>
<rectangle x1="1.33" y1="8.33" x2="1.75" y2="8.83" layer="51"/>
<rectangle x1="1.77" y1="8.33" x2="2.19" y2="8.83" layer="51"/>
<rectangle x1="2.21" y1="8.33" x2="2.63" y2="8.83" layer="51"/>
<rectangle x1="2.65" y1="8.33" x2="3.07" y2="8.83" layer="51"/>
<rectangle x1="3.09" y1="8.33" x2="3.51" y2="8.83" layer="51"/>
<rectangle x1="3.53" y1="8.33" x2="3.95" y2="8.83" layer="51"/>
<rectangle x1="3.97" y1="8.33" x2="4.39" y2="8.83" layer="51"/>
<rectangle x1="4.41" y1="8.33" x2="4.83" y2="8.83" layer="51"/>
<rectangle x1="4.85" y1="8.33" x2="5.27" y2="8.83" layer="51"/>
<rectangle x1="5.29" y1="8.33" x2="5.71" y2="8.83" layer="51"/>
<rectangle x1="5.73" y1="8.33" x2="6.15" y2="8.83" layer="51"/>
<rectangle x1="6.17" y1="8.33" x2="6.59" y2="8.83" layer="51"/>
<rectangle x1="6.61" y1="8.33" x2="7.03" y2="8.83" layer="51"/>
<rectangle x1="7.05" y1="8.33" x2="7.47" y2="8.83" layer="51"/>
<rectangle x1="7.49" y1="8.33" x2="7.91" y2="8.83" layer="51"/>
<rectangle x1="7.93" y1="8.33" x2="8.35" y2="8.83" layer="51"/>
<rectangle x1="8.37" y1="8.33" x2="8.79" y2="8.83" layer="51"/>
<rectangle x1="8.81" y1="8.33" x2="9.23" y2="8.83" layer="51"/>
<rectangle x1="9.25" y1="8.33" x2="9.67" y2="8.83" layer="51"/>
<rectangle x1="9.69" y1="8.33" x2="10.11" y2="8.83" layer="51"/>
<rectangle x1="10.13" y1="8.33" x2="10.55" y2="8.83" layer="51"/>
<rectangle x1="10.57" y1="8.33" x2="10.99" y2="8.83" layer="51"/>
<rectangle x1="11.01" y1="8.33" x2="11.43" y2="8.83" layer="51"/>
<rectangle x1="11.45" y1="8.33" x2="11.87" y2="8.83" layer="51"/>
<rectangle x1="11.89" y1="8.33" x2="12.31" y2="8.83" layer="51"/>
<rectangle x1="12.33" y1="8.33" x2="12.75" y2="8.83" layer="51"/>
<rectangle x1="12.77" y1="8.33" x2="13.19" y2="8.83" layer="51"/>
<rectangle x1="13.21" y1="8.33" x2="13.63" y2="8.83" layer="51"/>
<rectangle x1="13.65" y1="8.33" x2="14.07" y2="8.83" layer="51"/>
<rectangle x1="14.09" y1="8.33" x2="14.51" y2="8.83" layer="51"/>
<rectangle x1="14.53" y1="8.33" x2="14.95" y2="8.83" layer="51"/>
<rectangle x1="14.97" y1="8.33" x2="15.39" y2="8.83" layer="51"/>
<rectangle x1="15.41" y1="8.33" x2="15.83" y2="8.83" layer="51"/>
<rectangle x1="15.85" y1="8.33" x2="16.27" y2="8.83" layer="51"/>
<rectangle x1="16.29" y1="8.33" x2="16.71" y2="8.83" layer="51"/>
<rectangle x1="16.73" y1="8.33" x2="17.15" y2="8.83" layer="51"/>
<rectangle x1="17.17" y1="8.33" x2="17.59" y2="8.83" layer="51"/>
<rectangle x1="17.61" y1="8.33" x2="18.03" y2="8.83" layer="51"/>
<rectangle x1="18.05" y1="8.33" x2="18.47" y2="8.83" layer="51"/>
<rectangle x1="18.49" y1="8.33" x2="18.91" y2="8.83" layer="51"/>
<rectangle x1="18.93" y1="8.33" x2="19.35" y2="8.83" layer="51"/>
<rectangle x1="19.37" y1="8.33" x2="19.79" y2="8.83" layer="51"/>
<rectangle x1="19.81" y1="8.33" x2="20.23" y2="8.83" layer="51"/>
<rectangle x1="20.25" y1="8.33" x2="20.67" y2="8.83" layer="51"/>
<rectangle x1="20.69" y1="8.33" x2="21.11" y2="8.83" layer="51"/>
<rectangle x1="21.13" y1="8.33" x2="21.55" y2="8.83" layer="51"/>
<rectangle x1="21.57" y1="8.33" x2="21.99" y2="8.83" layer="51"/>
<rectangle x1="22.01" y1="8.33" x2="22.43" y2="8.83" layer="51"/>
<rectangle x1="22.45" y1="8.33" x2="22.87" y2="8.83" layer="51"/>
<rectangle x1="22.89" y1="8.33" x2="23.31" y2="8.83" layer="51"/>
<rectangle x1="23.33" y1="8.33" x2="23.75" y2="8.83" layer="51"/>
<rectangle x1="23.77" y1="8.33" x2="24.19" y2="8.83" layer="51"/>
<rectangle x1="24.21" y1="8.33" x2="24.63" y2="8.83" layer="51"/>
<rectangle x1="24.65" y1="8.33" x2="25.07" y2="8.83" layer="51"/>
<rectangle x1="25.09" y1="8.33" x2="25.51" y2="8.83" layer="51"/>
<rectangle x1="25.53" y1="8.33" x2="25.95" y2="8.83" layer="51"/>
<rectangle x1="25.97" y1="8.33" x2="26.39" y2="8.83" layer="51"/>
<rectangle x1="26.41" y1="8.33" x2="26.83" y2="8.83" layer="51"/>
<rectangle x1="26.85" y1="8.33" x2="27.27" y2="8.83" layer="51"/>
<rectangle x1="27.29" y1="8.33" x2="27.71" y2="8.83" layer="51"/>
<rectangle x1="27.73" y1="8.33" x2="28.15" y2="8.83" layer="51"/>
<rectangle x1="-28.15" y1="7.81" x2="-27.73" y2="8.31" layer="51"/>
<rectangle x1="-27.71" y1="7.81" x2="-27.29" y2="8.31" layer="51"/>
<rectangle x1="-27.27" y1="7.81" x2="-26.85" y2="8.31" layer="51"/>
<rectangle x1="-26.83" y1="7.81" x2="-26.41" y2="8.31" layer="51"/>
<rectangle x1="-26.39" y1="7.81" x2="-25.97" y2="8.31" layer="51"/>
<rectangle x1="-25.95" y1="7.81" x2="-25.53" y2="8.31" layer="51"/>
<rectangle x1="-25.51" y1="7.81" x2="-25.09" y2="8.31" layer="51"/>
<rectangle x1="-25.07" y1="7.81" x2="-24.65" y2="8.31" layer="51"/>
<rectangle x1="-24.63" y1="7.81" x2="-24.21" y2="8.31" layer="51"/>
<rectangle x1="-24.19" y1="7.81" x2="-23.77" y2="8.31" layer="51"/>
<rectangle x1="-23.75" y1="7.81" x2="-23.33" y2="8.31" layer="51"/>
<rectangle x1="-23.31" y1="7.81" x2="-22.89" y2="8.31" layer="51"/>
<rectangle x1="-22.87" y1="7.81" x2="-22.45" y2="8.31" layer="51"/>
<rectangle x1="-22.43" y1="7.81" x2="-22.01" y2="8.31" layer="51"/>
<rectangle x1="-21.99" y1="7.81" x2="-21.57" y2="8.31" layer="51"/>
<rectangle x1="-21.55" y1="7.81" x2="-21.13" y2="8.31" layer="51"/>
<rectangle x1="-21.11" y1="7.81" x2="-20.69" y2="8.31" layer="51"/>
<rectangle x1="-20.67" y1="7.81" x2="-20.25" y2="8.31" layer="51"/>
<rectangle x1="-20.23" y1="7.81" x2="-19.81" y2="8.31" layer="51"/>
<rectangle x1="-19.79" y1="7.81" x2="-19.37" y2="8.31" layer="51"/>
<rectangle x1="-19.35" y1="7.81" x2="-18.93" y2="8.31" layer="51"/>
<rectangle x1="-18.91" y1="7.81" x2="-18.49" y2="8.31" layer="51"/>
<rectangle x1="-18.47" y1="7.81" x2="-18.05" y2="8.31" layer="51"/>
<rectangle x1="-18.03" y1="7.81" x2="-17.61" y2="8.31" layer="51"/>
<rectangle x1="-17.59" y1="7.81" x2="-17.17" y2="8.31" layer="51"/>
<rectangle x1="-17.15" y1="7.81" x2="-16.73" y2="8.31" layer="51"/>
<rectangle x1="-16.71" y1="7.81" x2="-16.29" y2="8.31" layer="51"/>
<rectangle x1="-16.27" y1="7.81" x2="-15.85" y2="8.31" layer="51"/>
<rectangle x1="-15.83" y1="7.81" x2="-15.41" y2="8.31" layer="51"/>
<rectangle x1="-15.39" y1="7.81" x2="-14.97" y2="8.31" layer="51"/>
<rectangle x1="-14.95" y1="7.81" x2="-14.53" y2="8.31" layer="51"/>
<rectangle x1="-14.51" y1="7.81" x2="-14.09" y2="8.31" layer="51"/>
<rectangle x1="-14.07" y1="7.81" x2="-13.65" y2="8.31" layer="51"/>
<rectangle x1="-13.63" y1="7.81" x2="-13.21" y2="8.31" layer="51"/>
<rectangle x1="-13.19" y1="7.81" x2="-12.77" y2="8.31" layer="51"/>
<rectangle x1="-12.75" y1="7.81" x2="-12.33" y2="8.31" layer="51"/>
<rectangle x1="-12.31" y1="7.81" x2="-11.89" y2="8.31" layer="51"/>
<rectangle x1="-11.87" y1="7.81" x2="-11.45" y2="8.31" layer="51"/>
<rectangle x1="-11.43" y1="7.81" x2="-11.01" y2="8.31" layer="51"/>
<rectangle x1="-10.99" y1="7.81" x2="-10.57" y2="8.31" layer="51"/>
<rectangle x1="-10.55" y1="7.81" x2="-10.13" y2="8.31" layer="51"/>
<rectangle x1="-10.11" y1="7.81" x2="-9.69" y2="8.31" layer="51"/>
<rectangle x1="-9.67" y1="7.81" x2="-9.25" y2="8.31" layer="51"/>
<rectangle x1="-9.23" y1="7.81" x2="-8.81" y2="8.31" layer="51"/>
<rectangle x1="-8.79" y1="7.81" x2="-8.37" y2="8.31" layer="51"/>
<rectangle x1="-8.35" y1="7.81" x2="-7.93" y2="8.31" layer="51"/>
<rectangle x1="-7.91" y1="7.81" x2="-7.49" y2="8.31" layer="51"/>
<rectangle x1="-7.47" y1="7.81" x2="-7.05" y2="8.31" layer="51"/>
<rectangle x1="-7.03" y1="7.81" x2="-6.61" y2="8.31" layer="51"/>
<rectangle x1="-6.59" y1="7.81" x2="-6.17" y2="8.31" layer="51"/>
<rectangle x1="-6.15" y1="7.81" x2="-5.73" y2="8.31" layer="51"/>
<rectangle x1="-5.71" y1="7.81" x2="-5.29" y2="8.31" layer="51"/>
<rectangle x1="-5.27" y1="7.81" x2="-4.85" y2="8.31" layer="51"/>
<rectangle x1="-4.83" y1="7.81" x2="-4.41" y2="8.31" layer="51"/>
<rectangle x1="-4.39" y1="7.81" x2="-3.97" y2="8.31" layer="51"/>
<rectangle x1="-3.95" y1="7.81" x2="-3.53" y2="8.31" layer="51"/>
<rectangle x1="-3.51" y1="7.81" x2="-3.09" y2="8.31" layer="51"/>
<rectangle x1="-3.07" y1="7.81" x2="-2.65" y2="8.31" layer="51"/>
<rectangle x1="-2.63" y1="7.81" x2="-2.21" y2="8.31" layer="51"/>
<rectangle x1="-2.19" y1="7.81" x2="-1.77" y2="8.31" layer="51"/>
<rectangle x1="-1.75" y1="7.81" x2="-1.33" y2="8.31" layer="51"/>
<rectangle x1="-1.31" y1="7.81" x2="-0.89" y2="8.31" layer="51"/>
<rectangle x1="-0.87" y1="7.81" x2="-0.45" y2="8.31" layer="51"/>
<rectangle x1="-0.43" y1="7.81" x2="-0.01" y2="8.31" layer="51"/>
<rectangle x1="0.01" y1="7.81" x2="0.43" y2="8.31" layer="51"/>
<rectangle x1="0.45" y1="7.81" x2="0.87" y2="8.31" layer="51"/>
<rectangle x1="0.89" y1="7.81" x2="1.31" y2="8.31" layer="51"/>
<rectangle x1="1.33" y1="7.81" x2="1.75" y2="8.31" layer="51"/>
<rectangle x1="1.77" y1="7.81" x2="2.19" y2="8.31" layer="51"/>
<rectangle x1="2.21" y1="7.81" x2="2.63" y2="8.31" layer="51"/>
<rectangle x1="2.65" y1="7.81" x2="3.07" y2="8.31" layer="51"/>
<rectangle x1="3.09" y1="7.81" x2="3.51" y2="8.31" layer="51"/>
<rectangle x1="3.53" y1="7.81" x2="3.95" y2="8.31" layer="51"/>
<rectangle x1="3.97" y1="7.81" x2="4.39" y2="8.31" layer="51"/>
<rectangle x1="4.41" y1="7.81" x2="4.83" y2="8.31" layer="51"/>
<rectangle x1="4.85" y1="7.81" x2="5.27" y2="8.31" layer="51"/>
<rectangle x1="5.29" y1="7.81" x2="5.71" y2="8.31" layer="51"/>
<rectangle x1="5.73" y1="7.81" x2="6.15" y2="8.31" layer="51"/>
<rectangle x1="6.17" y1="7.81" x2="6.59" y2="8.31" layer="51"/>
<rectangle x1="6.61" y1="7.81" x2="7.03" y2="8.31" layer="51"/>
<rectangle x1="7.05" y1="7.81" x2="7.47" y2="8.31" layer="51"/>
<rectangle x1="7.49" y1="7.81" x2="7.91" y2="8.31" layer="51"/>
<rectangle x1="7.93" y1="7.81" x2="8.35" y2="8.31" layer="51"/>
<rectangle x1="8.37" y1="7.81" x2="8.79" y2="8.31" layer="51"/>
<rectangle x1="8.81" y1="7.81" x2="9.23" y2="8.31" layer="51"/>
<rectangle x1="9.25" y1="7.81" x2="9.67" y2="8.31" layer="51"/>
<rectangle x1="9.69" y1="7.81" x2="10.11" y2="8.31" layer="51"/>
<rectangle x1="10.13" y1="7.81" x2="10.55" y2="8.31" layer="51"/>
<rectangle x1="10.57" y1="7.81" x2="10.99" y2="8.31" layer="51"/>
<rectangle x1="11.01" y1="7.81" x2="11.43" y2="8.31" layer="51"/>
<rectangle x1="11.45" y1="7.81" x2="11.87" y2="8.31" layer="51"/>
<rectangle x1="11.89" y1="7.81" x2="12.31" y2="8.31" layer="51"/>
<rectangle x1="12.33" y1="7.81" x2="12.75" y2="8.31" layer="51"/>
<rectangle x1="12.77" y1="7.81" x2="13.19" y2="8.31" layer="51"/>
<rectangle x1="13.21" y1="7.81" x2="13.63" y2="8.31" layer="51"/>
<rectangle x1="13.65" y1="7.81" x2="14.07" y2="8.31" layer="51"/>
<rectangle x1="14.09" y1="7.81" x2="14.51" y2="8.31" layer="51"/>
<rectangle x1="14.53" y1="7.81" x2="14.95" y2="8.31" layer="51"/>
<rectangle x1="14.97" y1="7.81" x2="15.39" y2="8.31" layer="51"/>
<rectangle x1="15.41" y1="7.81" x2="15.83" y2="8.31" layer="51"/>
<rectangle x1="15.85" y1="7.81" x2="16.27" y2="8.31" layer="51"/>
<rectangle x1="16.29" y1="7.81" x2="16.71" y2="8.31" layer="51"/>
<rectangle x1="16.73" y1="7.81" x2="17.15" y2="8.31" layer="51"/>
<rectangle x1="17.17" y1="7.81" x2="17.59" y2="8.31" layer="51"/>
<rectangle x1="17.61" y1="7.81" x2="18.03" y2="8.31" layer="51"/>
<rectangle x1="18.05" y1="7.81" x2="18.47" y2="8.31" layer="51"/>
<rectangle x1="18.49" y1="7.81" x2="18.91" y2="8.31" layer="51"/>
<rectangle x1="18.93" y1="7.81" x2="19.35" y2="8.31" layer="51"/>
<rectangle x1="19.37" y1="7.81" x2="19.79" y2="8.31" layer="51"/>
<rectangle x1="19.81" y1="7.81" x2="20.23" y2="8.31" layer="51"/>
<rectangle x1="20.25" y1="7.81" x2="20.67" y2="8.31" layer="51"/>
<rectangle x1="20.69" y1="7.81" x2="21.11" y2="8.31" layer="51"/>
<rectangle x1="21.13" y1="7.81" x2="21.55" y2="8.31" layer="51"/>
<rectangle x1="21.57" y1="7.81" x2="21.99" y2="8.31" layer="51"/>
<rectangle x1="22.01" y1="7.81" x2="22.43" y2="8.31" layer="51"/>
<rectangle x1="22.45" y1="7.81" x2="22.87" y2="8.31" layer="51"/>
<rectangle x1="22.89" y1="7.81" x2="23.31" y2="8.31" layer="51"/>
<rectangle x1="23.33" y1="7.81" x2="23.75" y2="8.31" layer="51"/>
<rectangle x1="23.77" y1="7.81" x2="24.19" y2="8.31" layer="51"/>
<rectangle x1="24.21" y1="7.81" x2="24.63" y2="8.31" layer="51"/>
<rectangle x1="24.65" y1="7.81" x2="25.07" y2="8.31" layer="51"/>
<rectangle x1="25.09" y1="7.81" x2="25.51" y2="8.31" layer="51"/>
<rectangle x1="25.53" y1="7.81" x2="25.95" y2="8.31" layer="51"/>
<rectangle x1="25.97" y1="7.81" x2="26.39" y2="8.31" layer="51"/>
<rectangle x1="26.41" y1="7.81" x2="26.83" y2="8.31" layer="51"/>
<rectangle x1="26.85" y1="7.81" x2="27.27" y2="8.31" layer="51"/>
<rectangle x1="27.29" y1="7.81" x2="27.71" y2="8.31" layer="51"/>
<rectangle x1="27.73" y1="7.81" x2="28.15" y2="8.31" layer="51"/>
<rectangle x1="-28.15" y1="7.29" x2="-27.73" y2="7.79" layer="51"/>
<rectangle x1="-27.71" y1="7.29" x2="-27.29" y2="7.79" layer="51"/>
<rectangle x1="-27.27" y1="7.29" x2="-26.85" y2="7.79" layer="51"/>
<rectangle x1="-26.83" y1="7.29" x2="-26.41" y2="7.79" layer="51"/>
<rectangle x1="-26.39" y1="7.29" x2="-25.97" y2="7.79" layer="51"/>
<rectangle x1="-25.95" y1="7.29" x2="-25.53" y2="7.79" layer="51"/>
<rectangle x1="-25.51" y1="7.29" x2="-25.09" y2="7.79" layer="51"/>
<rectangle x1="-25.07" y1="7.29" x2="-24.65" y2="7.79" layer="51"/>
<rectangle x1="-24.63" y1="7.29" x2="-24.21" y2="7.79" layer="51"/>
<rectangle x1="-24.19" y1="7.29" x2="-23.77" y2="7.79" layer="51"/>
<rectangle x1="-23.75" y1="7.29" x2="-23.33" y2="7.79" layer="51"/>
<rectangle x1="-23.31" y1="7.29" x2="-22.89" y2="7.79" layer="51"/>
<rectangle x1="-22.87" y1="7.29" x2="-22.45" y2="7.79" layer="51"/>
<rectangle x1="-22.43" y1="7.29" x2="-22.01" y2="7.79" layer="51"/>
<rectangle x1="-21.99" y1="7.29" x2="-21.57" y2="7.79" layer="51"/>
<rectangle x1="-21.55" y1="7.29" x2="-21.13" y2="7.79" layer="51"/>
<rectangle x1="-21.11" y1="7.29" x2="-20.69" y2="7.79" layer="51"/>
<rectangle x1="-20.67" y1="7.29" x2="-20.25" y2="7.79" layer="51"/>
<rectangle x1="-20.23" y1="7.29" x2="-19.81" y2="7.79" layer="51"/>
<rectangle x1="-19.79" y1="7.29" x2="-19.37" y2="7.79" layer="51"/>
<rectangle x1="-19.35" y1="7.29" x2="-18.93" y2="7.79" layer="51"/>
<rectangle x1="-18.91" y1="7.29" x2="-18.49" y2="7.79" layer="51"/>
<rectangle x1="-18.47" y1="7.29" x2="-18.05" y2="7.79" layer="51"/>
<rectangle x1="-18.03" y1="7.29" x2="-17.61" y2="7.79" layer="51"/>
<rectangle x1="-17.59" y1="7.29" x2="-17.17" y2="7.79" layer="51"/>
<rectangle x1="-17.15" y1="7.29" x2="-16.73" y2="7.79" layer="51"/>
<rectangle x1="-16.71" y1="7.29" x2="-16.29" y2="7.79" layer="51"/>
<rectangle x1="-16.27" y1="7.29" x2="-15.85" y2="7.79" layer="51"/>
<rectangle x1="-15.83" y1="7.29" x2="-15.41" y2="7.79" layer="51"/>
<rectangle x1="-15.39" y1="7.29" x2="-14.97" y2="7.79" layer="51"/>
<rectangle x1="-14.95" y1="7.29" x2="-14.53" y2="7.79" layer="51"/>
<rectangle x1="-14.51" y1="7.29" x2="-14.09" y2="7.79" layer="51"/>
<rectangle x1="-14.07" y1="7.29" x2="-13.65" y2="7.79" layer="51"/>
<rectangle x1="-13.63" y1="7.29" x2="-13.21" y2="7.79" layer="51"/>
<rectangle x1="-13.19" y1="7.29" x2="-12.77" y2="7.79" layer="51"/>
<rectangle x1="-12.75" y1="7.29" x2="-12.33" y2="7.79" layer="51"/>
<rectangle x1="-12.31" y1="7.29" x2="-11.89" y2="7.79" layer="51"/>
<rectangle x1="-11.87" y1="7.29" x2="-11.45" y2="7.79" layer="51"/>
<rectangle x1="-11.43" y1="7.29" x2="-11.01" y2="7.79" layer="51"/>
<rectangle x1="-10.99" y1="7.29" x2="-10.57" y2="7.79" layer="51"/>
<rectangle x1="-10.55" y1="7.29" x2="-10.13" y2="7.79" layer="51"/>
<rectangle x1="-10.11" y1="7.29" x2="-9.69" y2="7.79" layer="51"/>
<rectangle x1="-9.67" y1="7.29" x2="-9.25" y2="7.79" layer="51"/>
<rectangle x1="-9.23" y1="7.29" x2="-8.81" y2="7.79" layer="51"/>
<rectangle x1="-8.79" y1="7.29" x2="-8.37" y2="7.79" layer="51"/>
<rectangle x1="-8.35" y1="7.29" x2="-7.93" y2="7.79" layer="51"/>
<rectangle x1="-7.91" y1="7.29" x2="-7.49" y2="7.79" layer="51"/>
<rectangle x1="-7.47" y1="7.29" x2="-7.05" y2="7.79" layer="51"/>
<rectangle x1="-7.03" y1="7.29" x2="-6.61" y2="7.79" layer="51"/>
<rectangle x1="-6.59" y1="7.29" x2="-6.17" y2="7.79" layer="51"/>
<rectangle x1="-6.15" y1="7.29" x2="-5.73" y2="7.79" layer="51"/>
<rectangle x1="-5.71" y1="7.29" x2="-5.29" y2="7.79" layer="51"/>
<rectangle x1="-5.27" y1="7.29" x2="-4.85" y2="7.79" layer="51"/>
<rectangle x1="-4.83" y1="7.29" x2="-4.41" y2="7.79" layer="51"/>
<rectangle x1="-4.39" y1="7.29" x2="-3.97" y2="7.79" layer="51"/>
<rectangle x1="-3.95" y1="7.29" x2="-3.53" y2="7.79" layer="51"/>
<rectangle x1="-3.51" y1="7.29" x2="-3.09" y2="7.79" layer="51"/>
<rectangle x1="-3.07" y1="7.29" x2="-2.65" y2="7.79" layer="51"/>
<rectangle x1="-2.63" y1="7.29" x2="-2.21" y2="7.79" layer="51"/>
<rectangle x1="-2.19" y1="7.29" x2="-1.77" y2="7.79" layer="51"/>
<rectangle x1="-1.75" y1="7.29" x2="-1.33" y2="7.79" layer="51"/>
<rectangle x1="-1.31" y1="7.29" x2="-0.89" y2="7.79" layer="51"/>
<rectangle x1="-0.87" y1="7.29" x2="-0.45" y2="7.79" layer="51"/>
<rectangle x1="-0.43" y1="7.29" x2="-0.01" y2="7.79" layer="51"/>
<rectangle x1="0.01" y1="7.29" x2="0.43" y2="7.79" layer="51"/>
<rectangle x1="0.45" y1="7.29" x2="0.87" y2="7.79" layer="51"/>
<rectangle x1="0.89" y1="7.29" x2="1.31" y2="7.79" layer="51"/>
<rectangle x1="1.33" y1="7.29" x2="1.75" y2="7.79" layer="51"/>
<rectangle x1="1.77" y1="7.29" x2="2.19" y2="7.79" layer="51"/>
<rectangle x1="2.21" y1="7.29" x2="2.63" y2="7.79" layer="51"/>
<rectangle x1="2.65" y1="7.29" x2="3.07" y2="7.79" layer="51"/>
<rectangle x1="3.09" y1="7.29" x2="3.51" y2="7.79" layer="51"/>
<rectangle x1="3.53" y1="7.29" x2="3.95" y2="7.79" layer="51"/>
<rectangle x1="3.97" y1="7.29" x2="4.39" y2="7.79" layer="51"/>
<rectangle x1="4.41" y1="7.29" x2="4.83" y2="7.79" layer="51"/>
<rectangle x1="4.85" y1="7.29" x2="5.27" y2="7.79" layer="51"/>
<rectangle x1="5.29" y1="7.29" x2="5.71" y2="7.79" layer="51"/>
<rectangle x1="5.73" y1="7.29" x2="6.15" y2="7.79" layer="51"/>
<rectangle x1="6.17" y1="7.29" x2="6.59" y2="7.79" layer="51"/>
<rectangle x1="6.61" y1="7.29" x2="7.03" y2="7.79" layer="51"/>
<rectangle x1="7.05" y1="7.29" x2="7.47" y2="7.79" layer="51"/>
<rectangle x1="7.49" y1="7.29" x2="7.91" y2="7.79" layer="51"/>
<rectangle x1="7.93" y1="7.29" x2="8.35" y2="7.79" layer="51"/>
<rectangle x1="8.37" y1="7.29" x2="8.79" y2="7.79" layer="51"/>
<rectangle x1="8.81" y1="7.29" x2="9.23" y2="7.79" layer="51"/>
<rectangle x1="9.25" y1="7.29" x2="9.67" y2="7.79" layer="51"/>
<rectangle x1="9.69" y1="7.29" x2="10.11" y2="7.79" layer="51"/>
<rectangle x1="10.13" y1="7.29" x2="10.55" y2="7.79" layer="51"/>
<rectangle x1="10.57" y1="7.29" x2="10.99" y2="7.79" layer="51"/>
<rectangle x1="11.01" y1="7.29" x2="11.43" y2="7.79" layer="51"/>
<rectangle x1="11.45" y1="7.29" x2="11.87" y2="7.79" layer="51"/>
<rectangle x1="11.89" y1="7.29" x2="12.31" y2="7.79" layer="51"/>
<rectangle x1="12.33" y1="7.29" x2="12.75" y2="7.79" layer="51"/>
<rectangle x1="12.77" y1="7.29" x2="13.19" y2="7.79" layer="51"/>
<rectangle x1="13.21" y1="7.29" x2="13.63" y2="7.79" layer="51"/>
<rectangle x1="13.65" y1="7.29" x2="14.07" y2="7.79" layer="51"/>
<rectangle x1="14.09" y1="7.29" x2="14.51" y2="7.79" layer="51"/>
<rectangle x1="14.53" y1="7.29" x2="14.95" y2="7.79" layer="51"/>
<rectangle x1="14.97" y1="7.29" x2="15.39" y2="7.79" layer="51"/>
<rectangle x1="15.41" y1="7.29" x2="15.83" y2="7.79" layer="51"/>
<rectangle x1="15.85" y1="7.29" x2="16.27" y2="7.79" layer="51"/>
<rectangle x1="16.29" y1="7.29" x2="16.71" y2="7.79" layer="51"/>
<rectangle x1="16.73" y1="7.29" x2="17.15" y2="7.79" layer="51"/>
<rectangle x1="17.17" y1="7.29" x2="17.59" y2="7.79" layer="51"/>
<rectangle x1="17.61" y1="7.29" x2="18.03" y2="7.79" layer="51"/>
<rectangle x1="18.05" y1="7.29" x2="18.47" y2="7.79" layer="51"/>
<rectangle x1="18.49" y1="7.29" x2="18.91" y2="7.79" layer="51"/>
<rectangle x1="18.93" y1="7.29" x2="19.35" y2="7.79" layer="51"/>
<rectangle x1="19.37" y1="7.29" x2="19.79" y2="7.79" layer="51"/>
<rectangle x1="19.81" y1="7.29" x2="20.23" y2="7.79" layer="51"/>
<rectangle x1="20.25" y1="7.29" x2="20.67" y2="7.79" layer="51"/>
<rectangle x1="20.69" y1="7.29" x2="21.11" y2="7.79" layer="51"/>
<rectangle x1="21.13" y1="7.29" x2="21.55" y2="7.79" layer="51"/>
<rectangle x1="21.57" y1="7.29" x2="21.99" y2="7.79" layer="51"/>
<rectangle x1="22.01" y1="7.29" x2="22.43" y2="7.79" layer="51"/>
<rectangle x1="22.45" y1="7.29" x2="22.87" y2="7.79" layer="51"/>
<rectangle x1="22.89" y1="7.29" x2="23.31" y2="7.79" layer="51"/>
<rectangle x1="23.33" y1="7.29" x2="23.75" y2="7.79" layer="51"/>
<rectangle x1="23.77" y1="7.29" x2="24.19" y2="7.79" layer="51"/>
<rectangle x1="24.21" y1="7.29" x2="24.63" y2="7.79" layer="51"/>
<rectangle x1="24.65" y1="7.29" x2="25.07" y2="7.79" layer="51"/>
<rectangle x1="25.09" y1="7.29" x2="25.51" y2="7.79" layer="51"/>
<rectangle x1="25.53" y1="7.29" x2="25.95" y2="7.79" layer="51"/>
<rectangle x1="25.97" y1="7.29" x2="26.39" y2="7.79" layer="51"/>
<rectangle x1="26.41" y1="7.29" x2="26.83" y2="7.79" layer="51"/>
<rectangle x1="26.85" y1="7.29" x2="27.27" y2="7.79" layer="51"/>
<rectangle x1="27.29" y1="7.29" x2="27.71" y2="7.79" layer="51"/>
<rectangle x1="27.73" y1="7.29" x2="28.15" y2="7.79" layer="51"/>
<rectangle x1="-28.15" y1="6.77" x2="-27.73" y2="7.27" layer="51"/>
<rectangle x1="-27.71" y1="6.77" x2="-27.29" y2="7.27" layer="51"/>
<rectangle x1="-27.27" y1="6.77" x2="-26.85" y2="7.27" layer="51"/>
<rectangle x1="-26.83" y1="6.77" x2="-26.41" y2="7.27" layer="51"/>
<rectangle x1="-26.39" y1="6.77" x2="-25.97" y2="7.27" layer="51"/>
<rectangle x1="-25.95" y1="6.77" x2="-25.53" y2="7.27" layer="51"/>
<rectangle x1="-25.51" y1="6.77" x2="-25.09" y2="7.27" layer="51"/>
<rectangle x1="-25.07" y1="6.77" x2="-24.65" y2="7.27" layer="51"/>
<rectangle x1="-24.63" y1="6.77" x2="-24.21" y2="7.27" layer="51"/>
<rectangle x1="-24.19" y1="6.77" x2="-23.77" y2="7.27" layer="51"/>
<rectangle x1="-23.75" y1="6.77" x2="-23.33" y2="7.27" layer="51"/>
<rectangle x1="-23.31" y1="6.77" x2="-22.89" y2="7.27" layer="51"/>
<rectangle x1="-22.87" y1="6.77" x2="-22.45" y2="7.27" layer="51"/>
<rectangle x1="-22.43" y1="6.77" x2="-22.01" y2="7.27" layer="51"/>
<rectangle x1="-21.99" y1="6.77" x2="-21.57" y2="7.27" layer="51"/>
<rectangle x1="-21.55" y1="6.77" x2="-21.13" y2="7.27" layer="51"/>
<rectangle x1="-21.11" y1="6.77" x2="-20.69" y2="7.27" layer="51"/>
<rectangle x1="-20.67" y1="6.77" x2="-20.25" y2="7.27" layer="51"/>
<rectangle x1="-20.23" y1="6.77" x2="-19.81" y2="7.27" layer="51"/>
<rectangle x1="-19.79" y1="6.77" x2="-19.37" y2="7.27" layer="51"/>
<rectangle x1="-19.35" y1="6.77" x2="-18.93" y2="7.27" layer="51"/>
<rectangle x1="-18.91" y1="6.77" x2="-18.49" y2="7.27" layer="51"/>
<rectangle x1="-18.47" y1="6.77" x2="-18.05" y2="7.27" layer="51"/>
<rectangle x1="-18.03" y1="6.77" x2="-17.61" y2="7.27" layer="51"/>
<rectangle x1="-17.59" y1="6.77" x2="-17.17" y2="7.27" layer="51"/>
<rectangle x1="-17.15" y1="6.77" x2="-16.73" y2="7.27" layer="51"/>
<rectangle x1="-16.71" y1="6.77" x2="-16.29" y2="7.27" layer="51"/>
<rectangle x1="-16.27" y1="6.77" x2="-15.85" y2="7.27" layer="51"/>
<rectangle x1="-15.83" y1="6.77" x2="-15.41" y2="7.27" layer="51"/>
<rectangle x1="-15.39" y1="6.77" x2="-14.97" y2="7.27" layer="51"/>
<rectangle x1="-14.95" y1="6.77" x2="-14.53" y2="7.27" layer="51"/>
<rectangle x1="-14.51" y1="6.77" x2="-14.09" y2="7.27" layer="51"/>
<rectangle x1="-14.07" y1="6.77" x2="-13.65" y2="7.27" layer="51"/>
<rectangle x1="-13.63" y1="6.77" x2="-13.21" y2="7.27" layer="51"/>
<rectangle x1="-13.19" y1="6.77" x2="-12.77" y2="7.27" layer="51"/>
<rectangle x1="-12.75" y1="6.77" x2="-12.33" y2="7.27" layer="51"/>
<rectangle x1="-12.31" y1="6.77" x2="-11.89" y2="7.27" layer="51"/>
<rectangle x1="-11.87" y1="6.77" x2="-11.45" y2="7.27" layer="51"/>
<rectangle x1="-11.43" y1="6.77" x2="-11.01" y2="7.27" layer="51"/>
<rectangle x1="-10.99" y1="6.77" x2="-10.57" y2="7.27" layer="51"/>
<rectangle x1="-10.55" y1="6.77" x2="-10.13" y2="7.27" layer="51"/>
<rectangle x1="-10.11" y1="6.77" x2="-9.69" y2="7.27" layer="51"/>
<rectangle x1="-9.67" y1="6.77" x2="-9.25" y2="7.27" layer="51"/>
<rectangle x1="-9.23" y1="6.77" x2="-8.81" y2="7.27" layer="51"/>
<rectangle x1="-8.79" y1="6.77" x2="-8.37" y2="7.27" layer="51"/>
<rectangle x1="-8.35" y1="6.77" x2="-7.93" y2="7.27" layer="51"/>
<rectangle x1="-7.91" y1="6.77" x2="-7.49" y2="7.27" layer="51"/>
<rectangle x1="-7.47" y1="6.77" x2="-7.05" y2="7.27" layer="51"/>
<rectangle x1="-7.03" y1="6.77" x2="-6.61" y2="7.27" layer="51"/>
<rectangle x1="-6.59" y1="6.77" x2="-6.17" y2="7.27" layer="51"/>
<rectangle x1="-6.15" y1="6.77" x2="-5.73" y2="7.27" layer="51"/>
<rectangle x1="-5.71" y1="6.77" x2="-5.29" y2="7.27" layer="51"/>
<rectangle x1="-5.27" y1="6.77" x2="-4.85" y2="7.27" layer="51"/>
<rectangle x1="-4.83" y1="6.77" x2="-4.41" y2="7.27" layer="51"/>
<rectangle x1="-4.39" y1="6.77" x2="-3.97" y2="7.27" layer="51"/>
<rectangle x1="-3.95" y1="6.77" x2="-3.53" y2="7.27" layer="51"/>
<rectangle x1="-3.51" y1="6.77" x2="-3.09" y2="7.27" layer="51"/>
<rectangle x1="-3.07" y1="6.77" x2="-2.65" y2="7.27" layer="51"/>
<rectangle x1="-2.63" y1="6.77" x2="-2.21" y2="7.27" layer="51"/>
<rectangle x1="-2.19" y1="6.77" x2="-1.77" y2="7.27" layer="51"/>
<rectangle x1="-1.75" y1="6.77" x2="-1.33" y2="7.27" layer="51"/>
<rectangle x1="-1.31" y1="6.77" x2="-0.89" y2="7.27" layer="51"/>
<rectangle x1="-0.87" y1="6.77" x2="-0.45" y2="7.27" layer="51"/>
<rectangle x1="-0.43" y1="6.77" x2="-0.01" y2="7.27" layer="51"/>
<rectangle x1="0.01" y1="6.77" x2="0.43" y2="7.27" layer="51"/>
<rectangle x1="0.45" y1="6.77" x2="0.87" y2="7.27" layer="51"/>
<rectangle x1="0.89" y1="6.77" x2="1.31" y2="7.27" layer="51"/>
<rectangle x1="1.33" y1="6.77" x2="1.75" y2="7.27" layer="51"/>
<rectangle x1="1.77" y1="6.77" x2="2.19" y2="7.27" layer="51"/>
<rectangle x1="2.21" y1="6.77" x2="2.63" y2="7.27" layer="51"/>
<rectangle x1="2.65" y1="6.77" x2="3.07" y2="7.27" layer="51"/>
<rectangle x1="3.09" y1="6.77" x2="3.51" y2="7.27" layer="51"/>
<rectangle x1="3.53" y1="6.77" x2="3.95" y2="7.27" layer="51"/>
<rectangle x1="3.97" y1="6.77" x2="4.39" y2="7.27" layer="51"/>
<rectangle x1="4.41" y1="6.77" x2="4.83" y2="7.27" layer="51"/>
<rectangle x1="4.85" y1="6.77" x2="5.27" y2="7.27" layer="51"/>
<rectangle x1="5.29" y1="6.77" x2="5.71" y2="7.27" layer="51"/>
<rectangle x1="5.73" y1="6.77" x2="6.15" y2="7.27" layer="51"/>
<rectangle x1="6.17" y1="6.77" x2="6.59" y2="7.27" layer="51"/>
<rectangle x1="6.61" y1="6.77" x2="7.03" y2="7.27" layer="51"/>
<rectangle x1="7.05" y1="6.77" x2="7.47" y2="7.27" layer="51"/>
<rectangle x1="7.49" y1="6.77" x2="7.91" y2="7.27" layer="51"/>
<rectangle x1="7.93" y1="6.77" x2="8.35" y2="7.27" layer="51"/>
<rectangle x1="8.37" y1="6.77" x2="8.79" y2="7.27" layer="51"/>
<rectangle x1="8.81" y1="6.77" x2="9.23" y2="7.27" layer="51"/>
<rectangle x1="9.25" y1="6.77" x2="9.67" y2="7.27" layer="51"/>
<rectangle x1="9.69" y1="6.77" x2="10.11" y2="7.27" layer="51"/>
<rectangle x1="10.13" y1="6.77" x2="10.55" y2="7.27" layer="51"/>
<rectangle x1="10.57" y1="6.77" x2="10.99" y2="7.27" layer="51"/>
<rectangle x1="11.01" y1="6.77" x2="11.43" y2="7.27" layer="51"/>
<rectangle x1="11.45" y1="6.77" x2="11.87" y2="7.27" layer="51"/>
<rectangle x1="11.89" y1="6.77" x2="12.31" y2="7.27" layer="51"/>
<rectangle x1="12.33" y1="6.77" x2="12.75" y2="7.27" layer="51"/>
<rectangle x1="12.77" y1="6.77" x2="13.19" y2="7.27" layer="51"/>
<rectangle x1="13.21" y1="6.77" x2="13.63" y2="7.27" layer="51"/>
<rectangle x1="13.65" y1="6.77" x2="14.07" y2="7.27" layer="51"/>
<rectangle x1="14.09" y1="6.77" x2="14.51" y2="7.27" layer="51"/>
<rectangle x1="14.53" y1="6.77" x2="14.95" y2="7.27" layer="51"/>
<rectangle x1="14.97" y1="6.77" x2="15.39" y2="7.27" layer="51"/>
<rectangle x1="15.41" y1="6.77" x2="15.83" y2="7.27" layer="51"/>
<rectangle x1="15.85" y1="6.77" x2="16.27" y2="7.27" layer="51"/>
<rectangle x1="16.29" y1="6.77" x2="16.71" y2="7.27" layer="51"/>
<rectangle x1="16.73" y1="6.77" x2="17.15" y2="7.27" layer="51"/>
<rectangle x1="17.17" y1="6.77" x2="17.59" y2="7.27" layer="51"/>
<rectangle x1="17.61" y1="6.77" x2="18.03" y2="7.27" layer="51"/>
<rectangle x1="18.05" y1="6.77" x2="18.47" y2="7.27" layer="51"/>
<rectangle x1="18.49" y1="6.77" x2="18.91" y2="7.27" layer="51"/>
<rectangle x1="18.93" y1="6.77" x2="19.35" y2="7.27" layer="51"/>
<rectangle x1="19.37" y1="6.77" x2="19.79" y2="7.27" layer="51"/>
<rectangle x1="19.81" y1="6.77" x2="20.23" y2="7.27" layer="51"/>
<rectangle x1="20.25" y1="6.77" x2="20.67" y2="7.27" layer="51"/>
<rectangle x1="20.69" y1="6.77" x2="21.11" y2="7.27" layer="51"/>
<rectangle x1="21.13" y1="6.77" x2="21.55" y2="7.27" layer="51"/>
<rectangle x1="21.57" y1="6.77" x2="21.99" y2="7.27" layer="51"/>
<rectangle x1="22.01" y1="6.77" x2="22.43" y2="7.27" layer="51"/>
<rectangle x1="22.45" y1="6.77" x2="22.87" y2="7.27" layer="51"/>
<rectangle x1="22.89" y1="6.77" x2="23.31" y2="7.27" layer="51"/>
<rectangle x1="23.33" y1="6.77" x2="23.75" y2="7.27" layer="51"/>
<rectangle x1="23.77" y1="6.77" x2="24.19" y2="7.27" layer="51"/>
<rectangle x1="24.21" y1="6.77" x2="24.63" y2="7.27" layer="51"/>
<rectangle x1="24.65" y1="6.77" x2="25.07" y2="7.27" layer="51"/>
<rectangle x1="25.09" y1="6.77" x2="25.51" y2="7.27" layer="51"/>
<rectangle x1="25.53" y1="6.77" x2="25.95" y2="7.27" layer="51"/>
<rectangle x1="25.97" y1="6.77" x2="26.39" y2="7.27" layer="51"/>
<rectangle x1="26.41" y1="6.77" x2="26.83" y2="7.27" layer="51"/>
<rectangle x1="26.85" y1="6.77" x2="27.27" y2="7.27" layer="51"/>
<rectangle x1="27.29" y1="6.77" x2="27.71" y2="7.27" layer="51"/>
<rectangle x1="27.73" y1="6.77" x2="28.15" y2="7.27" layer="51"/>
<rectangle x1="-28.15" y1="6.25" x2="-27.73" y2="6.75" layer="51"/>
<rectangle x1="-27.71" y1="6.25" x2="-27.29" y2="6.75" layer="51"/>
<rectangle x1="-27.27" y1="6.25" x2="-26.85" y2="6.75" layer="51"/>
<rectangle x1="-26.83" y1="6.25" x2="-26.41" y2="6.75" layer="51"/>
<rectangle x1="-26.39" y1="6.25" x2="-25.97" y2="6.75" layer="51"/>
<rectangle x1="-25.95" y1="6.25" x2="-25.53" y2="6.75" layer="51"/>
<rectangle x1="-25.51" y1="6.25" x2="-25.09" y2="6.75" layer="51"/>
<rectangle x1="-25.07" y1="6.25" x2="-24.65" y2="6.75" layer="51"/>
<rectangle x1="-24.63" y1="6.25" x2="-24.21" y2="6.75" layer="51"/>
<rectangle x1="-24.19" y1="6.25" x2="-23.77" y2="6.75" layer="51"/>
<rectangle x1="-23.75" y1="6.25" x2="-23.33" y2="6.75" layer="51"/>
<rectangle x1="-23.31" y1="6.25" x2="-22.89" y2="6.75" layer="51"/>
<rectangle x1="-22.87" y1="6.25" x2="-22.45" y2="6.75" layer="51"/>
<rectangle x1="-22.43" y1="6.25" x2="-22.01" y2="6.75" layer="51"/>
<rectangle x1="-21.99" y1="6.25" x2="-21.57" y2="6.75" layer="51"/>
<rectangle x1="-21.55" y1="6.25" x2="-21.13" y2="6.75" layer="51"/>
<rectangle x1="-21.11" y1="6.25" x2="-20.69" y2="6.75" layer="51"/>
<rectangle x1="-20.67" y1="6.25" x2="-20.25" y2="6.75" layer="51"/>
<rectangle x1="-20.23" y1="6.25" x2="-19.81" y2="6.75" layer="51"/>
<rectangle x1="-19.79" y1="6.25" x2="-19.37" y2="6.75" layer="51"/>
<rectangle x1="-19.35" y1="6.25" x2="-18.93" y2="6.75" layer="51"/>
<rectangle x1="-18.91" y1="6.25" x2="-18.49" y2="6.75" layer="51"/>
<rectangle x1="-18.47" y1="6.25" x2="-18.05" y2="6.75" layer="51"/>
<rectangle x1="-18.03" y1="6.25" x2="-17.61" y2="6.75" layer="51"/>
<rectangle x1="-17.59" y1="6.25" x2="-17.17" y2="6.75" layer="51"/>
<rectangle x1="-17.15" y1="6.25" x2="-16.73" y2="6.75" layer="51"/>
<rectangle x1="-16.71" y1="6.25" x2="-16.29" y2="6.75" layer="51"/>
<rectangle x1="-16.27" y1="6.25" x2="-15.85" y2="6.75" layer="51"/>
<rectangle x1="-15.83" y1="6.25" x2="-15.41" y2="6.75" layer="51"/>
<rectangle x1="-15.39" y1="6.25" x2="-14.97" y2="6.75" layer="51"/>
<rectangle x1="-14.95" y1="6.25" x2="-14.53" y2="6.75" layer="51"/>
<rectangle x1="-14.51" y1="6.25" x2="-14.09" y2="6.75" layer="51"/>
<rectangle x1="-14.07" y1="6.25" x2="-13.65" y2="6.75" layer="51"/>
<rectangle x1="-13.63" y1="6.25" x2="-13.21" y2="6.75" layer="51"/>
<rectangle x1="-13.19" y1="6.25" x2="-12.77" y2="6.75" layer="51"/>
<rectangle x1="-12.75" y1="6.25" x2="-12.33" y2="6.75" layer="51"/>
<rectangle x1="-12.31" y1="6.25" x2="-11.89" y2="6.75" layer="51"/>
<rectangle x1="-11.87" y1="6.25" x2="-11.45" y2="6.75" layer="51"/>
<rectangle x1="-11.43" y1="6.25" x2="-11.01" y2="6.75" layer="51"/>
<rectangle x1="-10.99" y1="6.25" x2="-10.57" y2="6.75" layer="51"/>
<rectangle x1="-10.55" y1="6.25" x2="-10.13" y2="6.75" layer="51"/>
<rectangle x1="-10.11" y1="6.25" x2="-9.69" y2="6.75" layer="51"/>
<rectangle x1="-9.67" y1="6.25" x2="-9.25" y2="6.75" layer="51"/>
<rectangle x1="-9.23" y1="6.25" x2="-8.81" y2="6.75" layer="51"/>
<rectangle x1="-8.79" y1="6.25" x2="-8.37" y2="6.75" layer="51"/>
<rectangle x1="-8.35" y1="6.25" x2="-7.93" y2="6.75" layer="51"/>
<rectangle x1="-7.91" y1="6.25" x2="-7.49" y2="6.75" layer="51"/>
<rectangle x1="-7.47" y1="6.25" x2="-7.05" y2="6.75" layer="51"/>
<rectangle x1="-7.03" y1="6.25" x2="-6.61" y2="6.75" layer="51"/>
<rectangle x1="-6.59" y1="6.25" x2="-6.17" y2="6.75" layer="51"/>
<rectangle x1="-6.15" y1="6.25" x2="-5.73" y2="6.75" layer="51"/>
<rectangle x1="-5.71" y1="6.25" x2="-5.29" y2="6.75" layer="51"/>
<rectangle x1="-5.27" y1="6.25" x2="-4.85" y2="6.75" layer="51"/>
<rectangle x1="-4.83" y1="6.25" x2="-4.41" y2="6.75" layer="51"/>
<rectangle x1="-4.39" y1="6.25" x2="-3.97" y2="6.75" layer="51"/>
<rectangle x1="-3.95" y1="6.25" x2="-3.53" y2="6.75" layer="51"/>
<rectangle x1="-3.51" y1="6.25" x2="-3.09" y2="6.75" layer="51"/>
<rectangle x1="-3.07" y1="6.25" x2="-2.65" y2="6.75" layer="51"/>
<rectangle x1="-2.63" y1="6.25" x2="-2.21" y2="6.75" layer="51"/>
<rectangle x1="-2.19" y1="6.25" x2="-1.77" y2="6.75" layer="51"/>
<rectangle x1="-1.75" y1="6.25" x2="-1.33" y2="6.75" layer="51"/>
<rectangle x1="-1.31" y1="6.25" x2="-0.89" y2="6.75" layer="51"/>
<rectangle x1="-0.87" y1="6.25" x2="-0.45" y2="6.75" layer="51"/>
<rectangle x1="-0.43" y1="6.25" x2="-0.01" y2="6.75" layer="51"/>
<rectangle x1="0.01" y1="6.25" x2="0.43" y2="6.75" layer="51"/>
<rectangle x1="0.45" y1="6.25" x2="0.87" y2="6.75" layer="51"/>
<rectangle x1="0.89" y1="6.25" x2="1.31" y2="6.75" layer="51"/>
<rectangle x1="1.33" y1="6.25" x2="1.75" y2="6.75" layer="51"/>
<rectangle x1="1.77" y1="6.25" x2="2.19" y2="6.75" layer="51"/>
<rectangle x1="2.21" y1="6.25" x2="2.63" y2="6.75" layer="51"/>
<rectangle x1="2.65" y1="6.25" x2="3.07" y2="6.75" layer="51"/>
<rectangle x1="3.09" y1="6.25" x2="3.51" y2="6.75" layer="51"/>
<rectangle x1="3.53" y1="6.25" x2="3.95" y2="6.75" layer="51"/>
<rectangle x1="3.97" y1="6.25" x2="4.39" y2="6.75" layer="51"/>
<rectangle x1="4.41" y1="6.25" x2="4.83" y2="6.75" layer="51"/>
<rectangle x1="4.85" y1="6.25" x2="5.27" y2="6.75" layer="51"/>
<rectangle x1="5.29" y1="6.25" x2="5.71" y2="6.75" layer="51"/>
<rectangle x1="5.73" y1="6.25" x2="6.15" y2="6.75" layer="51"/>
<rectangle x1="6.17" y1="6.25" x2="6.59" y2="6.75" layer="51"/>
<rectangle x1="6.61" y1="6.25" x2="7.03" y2="6.75" layer="51"/>
<rectangle x1="7.05" y1="6.25" x2="7.47" y2="6.75" layer="51"/>
<rectangle x1="7.49" y1="6.25" x2="7.91" y2="6.75" layer="51"/>
<rectangle x1="7.93" y1="6.25" x2="8.35" y2="6.75" layer="51"/>
<rectangle x1="8.37" y1="6.25" x2="8.79" y2="6.75" layer="51"/>
<rectangle x1="8.81" y1="6.25" x2="9.23" y2="6.75" layer="51"/>
<rectangle x1="9.25" y1="6.25" x2="9.67" y2="6.75" layer="51"/>
<rectangle x1="9.69" y1="6.25" x2="10.11" y2="6.75" layer="51"/>
<rectangle x1="10.13" y1="6.25" x2="10.55" y2="6.75" layer="51"/>
<rectangle x1="10.57" y1="6.25" x2="10.99" y2="6.75" layer="51"/>
<rectangle x1="11.01" y1="6.25" x2="11.43" y2="6.75" layer="51"/>
<rectangle x1="11.45" y1="6.25" x2="11.87" y2="6.75" layer="51"/>
<rectangle x1="11.89" y1="6.25" x2="12.31" y2="6.75" layer="51"/>
<rectangle x1="12.33" y1="6.25" x2="12.75" y2="6.75" layer="51"/>
<rectangle x1="12.77" y1="6.25" x2="13.19" y2="6.75" layer="51"/>
<rectangle x1="13.21" y1="6.25" x2="13.63" y2="6.75" layer="51"/>
<rectangle x1="13.65" y1="6.25" x2="14.07" y2="6.75" layer="51"/>
<rectangle x1="14.09" y1="6.25" x2="14.51" y2="6.75" layer="51"/>
<rectangle x1="14.53" y1="6.25" x2="14.95" y2="6.75" layer="51"/>
<rectangle x1="14.97" y1="6.25" x2="15.39" y2="6.75" layer="51"/>
<rectangle x1="15.41" y1="6.25" x2="15.83" y2="6.75" layer="51"/>
<rectangle x1="15.85" y1="6.25" x2="16.27" y2="6.75" layer="51"/>
<rectangle x1="16.29" y1="6.25" x2="16.71" y2="6.75" layer="51"/>
<rectangle x1="16.73" y1="6.25" x2="17.15" y2="6.75" layer="51"/>
<rectangle x1="17.17" y1="6.25" x2="17.59" y2="6.75" layer="51"/>
<rectangle x1="17.61" y1="6.25" x2="18.03" y2="6.75" layer="51"/>
<rectangle x1="18.05" y1="6.25" x2="18.47" y2="6.75" layer="51"/>
<rectangle x1="18.49" y1="6.25" x2="18.91" y2="6.75" layer="51"/>
<rectangle x1="18.93" y1="6.25" x2="19.35" y2="6.75" layer="51"/>
<rectangle x1="19.37" y1="6.25" x2="19.79" y2="6.75" layer="51"/>
<rectangle x1="19.81" y1="6.25" x2="20.23" y2="6.75" layer="51"/>
<rectangle x1="20.25" y1="6.25" x2="20.67" y2="6.75" layer="51"/>
<rectangle x1="20.69" y1="6.25" x2="21.11" y2="6.75" layer="51"/>
<rectangle x1="21.13" y1="6.25" x2="21.55" y2="6.75" layer="51"/>
<rectangle x1="21.57" y1="6.25" x2="21.99" y2="6.75" layer="51"/>
<rectangle x1="22.01" y1="6.25" x2="22.43" y2="6.75" layer="51"/>
<rectangle x1="22.45" y1="6.25" x2="22.87" y2="6.75" layer="51"/>
<rectangle x1="22.89" y1="6.25" x2="23.31" y2="6.75" layer="51"/>
<rectangle x1="23.33" y1="6.25" x2="23.75" y2="6.75" layer="51"/>
<rectangle x1="23.77" y1="6.25" x2="24.19" y2="6.75" layer="51"/>
<rectangle x1="24.21" y1="6.25" x2="24.63" y2="6.75" layer="51"/>
<rectangle x1="24.65" y1="6.25" x2="25.07" y2="6.75" layer="51"/>
<rectangle x1="25.09" y1="6.25" x2="25.51" y2="6.75" layer="51"/>
<rectangle x1="25.53" y1="6.25" x2="25.95" y2="6.75" layer="51"/>
<rectangle x1="25.97" y1="6.25" x2="26.39" y2="6.75" layer="51"/>
<rectangle x1="26.41" y1="6.25" x2="26.83" y2="6.75" layer="51"/>
<rectangle x1="26.85" y1="6.25" x2="27.27" y2="6.75" layer="51"/>
<rectangle x1="27.29" y1="6.25" x2="27.71" y2="6.75" layer="51"/>
<rectangle x1="27.73" y1="6.25" x2="28.15" y2="6.75" layer="51"/>
<rectangle x1="-28.15" y1="5.73" x2="-27.73" y2="6.23" layer="51"/>
<rectangle x1="-27.71" y1="5.73" x2="-27.29" y2="6.23" layer="51"/>
<rectangle x1="-27.27" y1="5.73" x2="-26.85" y2="6.23" layer="51"/>
<rectangle x1="-26.83" y1="5.73" x2="-26.41" y2="6.23" layer="51"/>
<rectangle x1="-26.39" y1="5.73" x2="-25.97" y2="6.23" layer="51"/>
<rectangle x1="-25.95" y1="5.73" x2="-25.53" y2="6.23" layer="51"/>
<rectangle x1="-25.51" y1="5.73" x2="-25.09" y2="6.23" layer="51"/>
<rectangle x1="-25.07" y1="5.73" x2="-24.65" y2="6.23" layer="51"/>
<rectangle x1="-24.63" y1="5.73" x2="-24.21" y2="6.23" layer="51"/>
<rectangle x1="-24.19" y1="5.73" x2="-23.77" y2="6.23" layer="51"/>
<rectangle x1="-23.75" y1="5.73" x2="-23.33" y2="6.23" layer="51"/>
<rectangle x1="-23.31" y1="5.73" x2="-22.89" y2="6.23" layer="51"/>
<rectangle x1="-22.87" y1="5.73" x2="-22.45" y2="6.23" layer="51"/>
<rectangle x1="-22.43" y1="5.73" x2="-22.01" y2="6.23" layer="51"/>
<rectangle x1="-21.99" y1="5.73" x2="-21.57" y2="6.23" layer="51"/>
<rectangle x1="-21.55" y1="5.73" x2="-21.13" y2="6.23" layer="51"/>
<rectangle x1="-21.11" y1="5.73" x2="-20.69" y2="6.23" layer="51"/>
<rectangle x1="-20.67" y1="5.73" x2="-20.25" y2="6.23" layer="51"/>
<rectangle x1="-20.23" y1="5.73" x2="-19.81" y2="6.23" layer="51"/>
<rectangle x1="-19.79" y1="5.73" x2="-19.37" y2="6.23" layer="51"/>
<rectangle x1="-19.35" y1="5.73" x2="-18.93" y2="6.23" layer="51"/>
<rectangle x1="-18.91" y1="5.73" x2="-18.49" y2="6.23" layer="51"/>
<rectangle x1="-18.47" y1="5.73" x2="-18.05" y2="6.23" layer="51"/>
<rectangle x1="-18.03" y1="5.73" x2="-17.61" y2="6.23" layer="51"/>
<rectangle x1="-17.59" y1="5.73" x2="-17.17" y2="6.23" layer="51"/>
<rectangle x1="-17.15" y1="5.73" x2="-16.73" y2="6.23" layer="51"/>
<rectangle x1="-16.71" y1="5.73" x2="-16.29" y2="6.23" layer="51"/>
<rectangle x1="-16.27" y1="5.73" x2="-15.85" y2="6.23" layer="51"/>
<rectangle x1="-15.83" y1="5.73" x2="-15.41" y2="6.23" layer="51"/>
<rectangle x1="-15.39" y1="5.73" x2="-14.97" y2="6.23" layer="51"/>
<rectangle x1="-14.95" y1="5.73" x2="-14.53" y2="6.23" layer="51"/>
<rectangle x1="-14.51" y1="5.73" x2="-14.09" y2="6.23" layer="51"/>
<rectangle x1="-14.07" y1="5.73" x2="-13.65" y2="6.23" layer="51"/>
<rectangle x1="-13.63" y1="5.73" x2="-13.21" y2="6.23" layer="51"/>
<rectangle x1="-13.19" y1="5.73" x2="-12.77" y2="6.23" layer="51"/>
<rectangle x1="-12.75" y1="5.73" x2="-12.33" y2="6.23" layer="51"/>
<rectangle x1="-12.31" y1="5.73" x2="-11.89" y2="6.23" layer="51"/>
<rectangle x1="-11.87" y1="5.73" x2="-11.45" y2="6.23" layer="51"/>
<rectangle x1="-11.43" y1="5.73" x2="-11.01" y2="6.23" layer="51"/>
<rectangle x1="-10.99" y1="5.73" x2="-10.57" y2="6.23" layer="51"/>
<rectangle x1="-10.55" y1="5.73" x2="-10.13" y2="6.23" layer="51"/>
<rectangle x1="-10.11" y1="5.73" x2="-9.69" y2="6.23" layer="51"/>
<rectangle x1="-9.67" y1="5.73" x2="-9.25" y2="6.23" layer="51"/>
<rectangle x1="-9.23" y1="5.73" x2="-8.81" y2="6.23" layer="51"/>
<rectangle x1="-8.79" y1="5.73" x2="-8.37" y2="6.23" layer="51"/>
<rectangle x1="-8.35" y1="5.73" x2="-7.93" y2="6.23" layer="51"/>
<rectangle x1="-7.91" y1="5.73" x2="-7.49" y2="6.23" layer="51"/>
<rectangle x1="-7.47" y1="5.73" x2="-7.05" y2="6.23" layer="51"/>
<rectangle x1="-7.03" y1="5.73" x2="-6.61" y2="6.23" layer="51"/>
<rectangle x1="-6.59" y1="5.73" x2="-6.17" y2="6.23" layer="51"/>
<rectangle x1="-6.15" y1="5.73" x2="-5.73" y2="6.23" layer="51"/>
<rectangle x1="-5.71" y1="5.73" x2="-5.29" y2="6.23" layer="51"/>
<rectangle x1="-5.27" y1="5.73" x2="-4.85" y2="6.23" layer="51"/>
<rectangle x1="-4.83" y1="5.73" x2="-4.41" y2="6.23" layer="51"/>
<rectangle x1="-4.39" y1="5.73" x2="-3.97" y2="6.23" layer="51"/>
<rectangle x1="-3.95" y1="5.73" x2="-3.53" y2="6.23" layer="51"/>
<rectangle x1="-3.51" y1="5.73" x2="-3.09" y2="6.23" layer="51"/>
<rectangle x1="-3.07" y1="5.73" x2="-2.65" y2="6.23" layer="51"/>
<rectangle x1="-2.63" y1="5.73" x2="-2.21" y2="6.23" layer="51"/>
<rectangle x1="-2.19" y1="5.73" x2="-1.77" y2="6.23" layer="51"/>
<rectangle x1="-1.75" y1="5.73" x2="-1.33" y2="6.23" layer="51"/>
<rectangle x1="-1.31" y1="5.73" x2="-0.89" y2="6.23" layer="51"/>
<rectangle x1="-0.87" y1="5.73" x2="-0.45" y2="6.23" layer="51"/>
<rectangle x1="-0.43" y1="5.73" x2="-0.01" y2="6.23" layer="51"/>
<rectangle x1="0.01" y1="5.73" x2="0.43" y2="6.23" layer="51"/>
<rectangle x1="0.45" y1="5.73" x2="0.87" y2="6.23" layer="51"/>
<rectangle x1="0.89" y1="5.73" x2="1.31" y2="6.23" layer="51"/>
<rectangle x1="1.33" y1="5.73" x2="1.75" y2="6.23" layer="51"/>
<rectangle x1="1.77" y1="5.73" x2="2.19" y2="6.23" layer="51"/>
<rectangle x1="2.21" y1="5.73" x2="2.63" y2="6.23" layer="51"/>
<rectangle x1="2.65" y1="5.73" x2="3.07" y2="6.23" layer="51"/>
<rectangle x1="3.09" y1="5.73" x2="3.51" y2="6.23" layer="51"/>
<rectangle x1="3.53" y1="5.73" x2="3.95" y2="6.23" layer="51"/>
<rectangle x1="3.97" y1="5.73" x2="4.39" y2="6.23" layer="51"/>
<rectangle x1="4.41" y1="5.73" x2="4.83" y2="6.23" layer="51"/>
<rectangle x1="4.85" y1="5.73" x2="5.27" y2="6.23" layer="51"/>
<rectangle x1="5.29" y1="5.73" x2="5.71" y2="6.23" layer="51"/>
<rectangle x1="5.73" y1="5.73" x2="6.15" y2="6.23" layer="51"/>
<rectangle x1="6.17" y1="5.73" x2="6.59" y2="6.23" layer="51"/>
<rectangle x1="6.61" y1="5.73" x2="7.03" y2="6.23" layer="51"/>
<rectangle x1="7.05" y1="5.73" x2="7.47" y2="6.23" layer="51"/>
<rectangle x1="7.49" y1="5.73" x2="7.91" y2="6.23" layer="51"/>
<rectangle x1="7.93" y1="5.73" x2="8.35" y2="6.23" layer="51"/>
<rectangle x1="8.37" y1="5.73" x2="8.79" y2="6.23" layer="51"/>
<rectangle x1="8.81" y1="5.73" x2="9.23" y2="6.23" layer="51"/>
<rectangle x1="9.25" y1="5.73" x2="9.67" y2="6.23" layer="51"/>
<rectangle x1="9.69" y1="5.73" x2="10.11" y2="6.23" layer="51"/>
<rectangle x1="10.13" y1="5.73" x2="10.55" y2="6.23" layer="51"/>
<rectangle x1="10.57" y1="5.73" x2="10.99" y2="6.23" layer="51"/>
<rectangle x1="11.01" y1="5.73" x2="11.43" y2="6.23" layer="51"/>
<rectangle x1="11.45" y1="5.73" x2="11.87" y2="6.23" layer="51"/>
<rectangle x1="11.89" y1="5.73" x2="12.31" y2="6.23" layer="51"/>
<rectangle x1="12.33" y1="5.73" x2="12.75" y2="6.23" layer="51"/>
<rectangle x1="12.77" y1="5.73" x2="13.19" y2="6.23" layer="51"/>
<rectangle x1="13.21" y1="5.73" x2="13.63" y2="6.23" layer="51"/>
<rectangle x1="13.65" y1="5.73" x2="14.07" y2="6.23" layer="51"/>
<rectangle x1="14.09" y1="5.73" x2="14.51" y2="6.23" layer="51"/>
<rectangle x1="14.53" y1="5.73" x2="14.95" y2="6.23" layer="51"/>
<rectangle x1="14.97" y1="5.73" x2="15.39" y2="6.23" layer="51"/>
<rectangle x1="15.41" y1="5.73" x2="15.83" y2="6.23" layer="51"/>
<rectangle x1="15.85" y1="5.73" x2="16.27" y2="6.23" layer="51"/>
<rectangle x1="16.29" y1="5.73" x2="16.71" y2="6.23" layer="51"/>
<rectangle x1="16.73" y1="5.73" x2="17.15" y2="6.23" layer="51"/>
<rectangle x1="17.17" y1="5.73" x2="17.59" y2="6.23" layer="51"/>
<rectangle x1="17.61" y1="5.73" x2="18.03" y2="6.23" layer="51"/>
<rectangle x1="18.05" y1="5.73" x2="18.47" y2="6.23" layer="51"/>
<rectangle x1="18.49" y1="5.73" x2="18.91" y2="6.23" layer="51"/>
<rectangle x1="18.93" y1="5.73" x2="19.35" y2="6.23" layer="51"/>
<rectangle x1="19.37" y1="5.73" x2="19.79" y2="6.23" layer="51"/>
<rectangle x1="19.81" y1="5.73" x2="20.23" y2="6.23" layer="51"/>
<rectangle x1="20.25" y1="5.73" x2="20.67" y2="6.23" layer="51"/>
<rectangle x1="20.69" y1="5.73" x2="21.11" y2="6.23" layer="51"/>
<rectangle x1="21.13" y1="5.73" x2="21.55" y2="6.23" layer="51"/>
<rectangle x1="21.57" y1="5.73" x2="21.99" y2="6.23" layer="51"/>
<rectangle x1="22.01" y1="5.73" x2="22.43" y2="6.23" layer="51"/>
<rectangle x1="22.45" y1="5.73" x2="22.87" y2="6.23" layer="51"/>
<rectangle x1="22.89" y1="5.73" x2="23.31" y2="6.23" layer="51"/>
<rectangle x1="23.33" y1="5.73" x2="23.75" y2="6.23" layer="51"/>
<rectangle x1="23.77" y1="5.73" x2="24.19" y2="6.23" layer="51"/>
<rectangle x1="24.21" y1="5.73" x2="24.63" y2="6.23" layer="51"/>
<rectangle x1="24.65" y1="5.73" x2="25.07" y2="6.23" layer="51"/>
<rectangle x1="25.09" y1="5.73" x2="25.51" y2="6.23" layer="51"/>
<rectangle x1="25.53" y1="5.73" x2="25.95" y2="6.23" layer="51"/>
<rectangle x1="25.97" y1="5.73" x2="26.39" y2="6.23" layer="51"/>
<rectangle x1="26.41" y1="5.73" x2="26.83" y2="6.23" layer="51"/>
<rectangle x1="26.85" y1="5.73" x2="27.27" y2="6.23" layer="51"/>
<rectangle x1="27.29" y1="5.73" x2="27.71" y2="6.23" layer="51"/>
<rectangle x1="27.73" y1="5.73" x2="28.15" y2="6.23" layer="51"/>
<rectangle x1="-28.15" y1="5.21" x2="-27.73" y2="5.71" layer="51"/>
<rectangle x1="-27.71" y1="5.21" x2="-27.29" y2="5.71" layer="51"/>
<rectangle x1="-27.27" y1="5.21" x2="-26.85" y2="5.71" layer="51"/>
<rectangle x1="-26.83" y1="5.21" x2="-26.41" y2="5.71" layer="51"/>
<rectangle x1="-26.39" y1="5.21" x2="-25.97" y2="5.71" layer="51"/>
<rectangle x1="-25.95" y1="5.21" x2="-25.53" y2="5.71" layer="51"/>
<rectangle x1="-25.51" y1="5.21" x2="-25.09" y2="5.71" layer="51"/>
<rectangle x1="-25.07" y1="5.21" x2="-24.65" y2="5.71" layer="51"/>
<rectangle x1="-24.63" y1="5.21" x2="-24.21" y2="5.71" layer="51"/>
<rectangle x1="-24.19" y1="5.21" x2="-23.77" y2="5.71" layer="51"/>
<rectangle x1="-23.75" y1="5.21" x2="-23.33" y2="5.71" layer="51"/>
<rectangle x1="-23.31" y1="5.21" x2="-22.89" y2="5.71" layer="51"/>
<rectangle x1="-22.87" y1="5.21" x2="-22.45" y2="5.71" layer="51"/>
<rectangle x1="-22.43" y1="5.21" x2="-22.01" y2="5.71" layer="51"/>
<rectangle x1="-21.99" y1="5.21" x2="-21.57" y2="5.71" layer="51"/>
<rectangle x1="-21.55" y1="5.21" x2="-21.13" y2="5.71" layer="51"/>
<rectangle x1="-21.11" y1="5.21" x2="-20.69" y2="5.71" layer="51"/>
<rectangle x1="-20.67" y1="5.21" x2="-20.25" y2="5.71" layer="51"/>
<rectangle x1="-20.23" y1="5.21" x2="-19.81" y2="5.71" layer="51"/>
<rectangle x1="-19.79" y1="5.21" x2="-19.37" y2="5.71" layer="51"/>
<rectangle x1="-19.35" y1="5.21" x2="-18.93" y2="5.71" layer="51"/>
<rectangle x1="-18.91" y1="5.21" x2="-18.49" y2="5.71" layer="51"/>
<rectangle x1="-18.47" y1="5.21" x2="-18.05" y2="5.71" layer="51"/>
<rectangle x1="-18.03" y1="5.21" x2="-17.61" y2="5.71" layer="51"/>
<rectangle x1="-17.59" y1="5.21" x2="-17.17" y2="5.71" layer="51"/>
<rectangle x1="-17.15" y1="5.21" x2="-16.73" y2="5.71" layer="51"/>
<rectangle x1="-16.71" y1="5.21" x2="-16.29" y2="5.71" layer="51"/>
<rectangle x1="-16.27" y1="5.21" x2="-15.85" y2="5.71" layer="51"/>
<rectangle x1="-15.83" y1="5.21" x2="-15.41" y2="5.71" layer="51"/>
<rectangle x1="-15.39" y1="5.21" x2="-14.97" y2="5.71" layer="51"/>
<rectangle x1="-14.95" y1="5.21" x2="-14.53" y2="5.71" layer="51"/>
<rectangle x1="-14.51" y1="5.21" x2="-14.09" y2="5.71" layer="51"/>
<rectangle x1="-14.07" y1="5.21" x2="-13.65" y2="5.71" layer="51"/>
<rectangle x1="-13.63" y1="5.21" x2="-13.21" y2="5.71" layer="51"/>
<rectangle x1="-13.19" y1="5.21" x2="-12.77" y2="5.71" layer="51"/>
<rectangle x1="-12.75" y1="5.21" x2="-12.33" y2="5.71" layer="51"/>
<rectangle x1="-12.31" y1="5.21" x2="-11.89" y2="5.71" layer="51"/>
<rectangle x1="-11.87" y1="5.21" x2="-11.45" y2="5.71" layer="51"/>
<rectangle x1="-11.43" y1="5.21" x2="-11.01" y2="5.71" layer="51"/>
<rectangle x1="-10.99" y1="5.21" x2="-10.57" y2="5.71" layer="51"/>
<rectangle x1="-10.55" y1="5.21" x2="-10.13" y2="5.71" layer="51"/>
<rectangle x1="-10.11" y1="5.21" x2="-9.69" y2="5.71" layer="51"/>
<rectangle x1="-9.67" y1="5.21" x2="-9.25" y2="5.71" layer="51"/>
<rectangle x1="-9.23" y1="5.21" x2="-8.81" y2="5.71" layer="51"/>
<rectangle x1="-8.79" y1="5.21" x2="-8.37" y2="5.71" layer="51"/>
<rectangle x1="-8.35" y1="5.21" x2="-7.93" y2="5.71" layer="51"/>
<rectangle x1="-7.91" y1="5.21" x2="-7.49" y2="5.71" layer="51"/>
<rectangle x1="-7.47" y1="5.21" x2="-7.05" y2="5.71" layer="51"/>
<rectangle x1="-7.03" y1="5.21" x2="-6.61" y2="5.71" layer="51"/>
<rectangle x1="-6.59" y1="5.21" x2="-6.17" y2="5.71" layer="51"/>
<rectangle x1="-6.15" y1="5.21" x2="-5.73" y2="5.71" layer="51"/>
<rectangle x1="-5.71" y1="5.21" x2="-5.29" y2="5.71" layer="51"/>
<rectangle x1="-5.27" y1="5.21" x2="-4.85" y2="5.71" layer="51"/>
<rectangle x1="-4.83" y1="5.21" x2="-4.41" y2="5.71" layer="51"/>
<rectangle x1="-4.39" y1="5.21" x2="-3.97" y2="5.71" layer="51"/>
<rectangle x1="-3.95" y1="5.21" x2="-3.53" y2="5.71" layer="51"/>
<rectangle x1="-3.51" y1="5.21" x2="-3.09" y2="5.71" layer="51"/>
<rectangle x1="-3.07" y1="5.21" x2="-2.65" y2="5.71" layer="51"/>
<rectangle x1="-2.63" y1="5.21" x2="-2.21" y2="5.71" layer="51"/>
<rectangle x1="-2.19" y1="5.21" x2="-1.77" y2="5.71" layer="51"/>
<rectangle x1="-1.75" y1="5.21" x2="-1.33" y2="5.71" layer="51"/>
<rectangle x1="-1.31" y1="5.21" x2="-0.89" y2="5.71" layer="51"/>
<rectangle x1="-0.87" y1="5.21" x2="-0.45" y2="5.71" layer="51"/>
<rectangle x1="-0.43" y1="5.21" x2="-0.01" y2="5.71" layer="51"/>
<rectangle x1="0.01" y1="5.21" x2="0.43" y2="5.71" layer="51"/>
<rectangle x1="0.45" y1="5.21" x2="0.87" y2="5.71" layer="51"/>
<rectangle x1="0.89" y1="5.21" x2="1.31" y2="5.71" layer="51"/>
<rectangle x1="1.33" y1="5.21" x2="1.75" y2="5.71" layer="51"/>
<rectangle x1="1.77" y1="5.21" x2="2.19" y2="5.71" layer="51"/>
<rectangle x1="2.21" y1="5.21" x2="2.63" y2="5.71" layer="51"/>
<rectangle x1="2.65" y1="5.21" x2="3.07" y2="5.71" layer="51"/>
<rectangle x1="3.09" y1="5.21" x2="3.51" y2="5.71" layer="51"/>
<rectangle x1="3.53" y1="5.21" x2="3.95" y2="5.71" layer="51"/>
<rectangle x1="3.97" y1="5.21" x2="4.39" y2="5.71" layer="51"/>
<rectangle x1="4.41" y1="5.21" x2="4.83" y2="5.71" layer="51"/>
<rectangle x1="4.85" y1="5.21" x2="5.27" y2="5.71" layer="51"/>
<rectangle x1="5.29" y1="5.21" x2="5.71" y2="5.71" layer="51"/>
<rectangle x1="5.73" y1="5.21" x2="6.15" y2="5.71" layer="51"/>
<rectangle x1="6.17" y1="5.21" x2="6.59" y2="5.71" layer="51"/>
<rectangle x1="6.61" y1="5.21" x2="7.03" y2="5.71" layer="51"/>
<rectangle x1="7.05" y1="5.21" x2="7.47" y2="5.71" layer="51"/>
<rectangle x1="7.49" y1="5.21" x2="7.91" y2="5.71" layer="51"/>
<rectangle x1="7.93" y1="5.21" x2="8.35" y2="5.71" layer="51"/>
<rectangle x1="8.37" y1="5.21" x2="8.79" y2="5.71" layer="51"/>
<rectangle x1="8.81" y1="5.21" x2="9.23" y2="5.71" layer="51"/>
<rectangle x1="9.25" y1="5.21" x2="9.67" y2="5.71" layer="51"/>
<rectangle x1="9.69" y1="5.21" x2="10.11" y2="5.71" layer="51"/>
<rectangle x1="10.13" y1="5.21" x2="10.55" y2="5.71" layer="51"/>
<rectangle x1="10.57" y1="5.21" x2="10.99" y2="5.71" layer="51"/>
<rectangle x1="11.01" y1="5.21" x2="11.43" y2="5.71" layer="51"/>
<rectangle x1="11.45" y1="5.21" x2="11.87" y2="5.71" layer="51"/>
<rectangle x1="11.89" y1="5.21" x2="12.31" y2="5.71" layer="51"/>
<rectangle x1="12.33" y1="5.21" x2="12.75" y2="5.71" layer="51"/>
<rectangle x1="12.77" y1="5.21" x2="13.19" y2="5.71" layer="51"/>
<rectangle x1="13.21" y1="5.21" x2="13.63" y2="5.71" layer="51"/>
<rectangle x1="13.65" y1="5.21" x2="14.07" y2="5.71" layer="51"/>
<rectangle x1="14.09" y1="5.21" x2="14.51" y2="5.71" layer="51"/>
<rectangle x1="14.53" y1="5.21" x2="14.95" y2="5.71" layer="51"/>
<rectangle x1="14.97" y1="5.21" x2="15.39" y2="5.71" layer="51"/>
<rectangle x1="15.41" y1="5.21" x2="15.83" y2="5.71" layer="51"/>
<rectangle x1="15.85" y1="5.21" x2="16.27" y2="5.71" layer="51"/>
<rectangle x1="16.29" y1="5.21" x2="16.71" y2="5.71" layer="51"/>
<rectangle x1="16.73" y1="5.21" x2="17.15" y2="5.71" layer="51"/>
<rectangle x1="17.17" y1="5.21" x2="17.59" y2="5.71" layer="51"/>
<rectangle x1="17.61" y1="5.21" x2="18.03" y2="5.71" layer="51"/>
<rectangle x1="18.05" y1="5.21" x2="18.47" y2="5.71" layer="51"/>
<rectangle x1="18.49" y1="5.21" x2="18.91" y2="5.71" layer="51"/>
<rectangle x1="18.93" y1="5.21" x2="19.35" y2="5.71" layer="51"/>
<rectangle x1="19.37" y1="5.21" x2="19.79" y2="5.71" layer="51"/>
<rectangle x1="19.81" y1="5.21" x2="20.23" y2="5.71" layer="51"/>
<rectangle x1="20.25" y1="5.21" x2="20.67" y2="5.71" layer="51"/>
<rectangle x1="20.69" y1="5.21" x2="21.11" y2="5.71" layer="51"/>
<rectangle x1="21.13" y1="5.21" x2="21.55" y2="5.71" layer="51"/>
<rectangle x1="21.57" y1="5.21" x2="21.99" y2="5.71" layer="51"/>
<rectangle x1="22.01" y1="5.21" x2="22.43" y2="5.71" layer="51"/>
<rectangle x1="22.45" y1="5.21" x2="22.87" y2="5.71" layer="51"/>
<rectangle x1="22.89" y1="5.21" x2="23.31" y2="5.71" layer="51"/>
<rectangle x1="23.33" y1="5.21" x2="23.75" y2="5.71" layer="51"/>
<rectangle x1="23.77" y1="5.21" x2="24.19" y2="5.71" layer="51"/>
<rectangle x1="24.21" y1="5.21" x2="24.63" y2="5.71" layer="51"/>
<rectangle x1="24.65" y1="5.21" x2="25.07" y2="5.71" layer="51"/>
<rectangle x1="25.09" y1="5.21" x2="25.51" y2="5.71" layer="51"/>
<rectangle x1="25.53" y1="5.21" x2="25.95" y2="5.71" layer="51"/>
<rectangle x1="25.97" y1="5.21" x2="26.39" y2="5.71" layer="51"/>
<rectangle x1="26.41" y1="5.21" x2="26.83" y2="5.71" layer="51"/>
<rectangle x1="26.85" y1="5.21" x2="27.27" y2="5.71" layer="51"/>
<rectangle x1="27.29" y1="5.21" x2="27.71" y2="5.71" layer="51"/>
<rectangle x1="27.73" y1="5.21" x2="28.15" y2="5.71" layer="51"/>
<rectangle x1="-28.15" y1="4.69" x2="-27.73" y2="5.19" layer="51"/>
<rectangle x1="-27.71" y1="4.69" x2="-27.29" y2="5.19" layer="51"/>
<rectangle x1="-27.27" y1="4.69" x2="-26.85" y2="5.19" layer="51"/>
<rectangle x1="-26.83" y1="4.69" x2="-26.41" y2="5.19" layer="51"/>
<rectangle x1="-26.39" y1="4.69" x2="-25.97" y2="5.19" layer="51"/>
<rectangle x1="-25.95" y1="4.69" x2="-25.53" y2="5.19" layer="51"/>
<rectangle x1="-25.51" y1="4.69" x2="-25.09" y2="5.19" layer="51"/>
<rectangle x1="-25.07" y1="4.69" x2="-24.65" y2="5.19" layer="51"/>
<rectangle x1="-24.63" y1="4.69" x2="-24.21" y2="5.19" layer="51"/>
<rectangle x1="-24.19" y1="4.69" x2="-23.77" y2="5.19" layer="51"/>
<rectangle x1="-23.75" y1="4.69" x2="-23.33" y2="5.19" layer="51"/>
<rectangle x1="-23.31" y1="4.69" x2="-22.89" y2="5.19" layer="51"/>
<rectangle x1="-22.87" y1="4.69" x2="-22.45" y2="5.19" layer="51"/>
<rectangle x1="-22.43" y1="4.69" x2="-22.01" y2="5.19" layer="51"/>
<rectangle x1="-21.99" y1="4.69" x2="-21.57" y2="5.19" layer="51"/>
<rectangle x1="-21.55" y1="4.69" x2="-21.13" y2="5.19" layer="51"/>
<rectangle x1="-21.11" y1="4.69" x2="-20.69" y2="5.19" layer="51"/>
<rectangle x1="-20.67" y1="4.69" x2="-20.25" y2="5.19" layer="51"/>
<rectangle x1="-20.23" y1="4.69" x2="-19.81" y2="5.19" layer="51"/>
<rectangle x1="-19.79" y1="4.69" x2="-19.37" y2="5.19" layer="51"/>
<rectangle x1="-19.35" y1="4.69" x2="-18.93" y2="5.19" layer="51"/>
<rectangle x1="-18.91" y1="4.69" x2="-18.49" y2="5.19" layer="51"/>
<rectangle x1="-18.47" y1="4.69" x2="-18.05" y2="5.19" layer="51"/>
<rectangle x1="-18.03" y1="4.69" x2="-17.61" y2="5.19" layer="51"/>
<rectangle x1="-17.59" y1="4.69" x2="-17.17" y2="5.19" layer="51"/>
<rectangle x1="-17.15" y1="4.69" x2="-16.73" y2="5.19" layer="51"/>
<rectangle x1="-16.71" y1="4.69" x2="-16.29" y2="5.19" layer="51"/>
<rectangle x1="-16.27" y1="4.69" x2="-15.85" y2="5.19" layer="51"/>
<rectangle x1="-15.83" y1="4.69" x2="-15.41" y2="5.19" layer="51"/>
<rectangle x1="-15.39" y1="4.69" x2="-14.97" y2="5.19" layer="51"/>
<rectangle x1="-14.95" y1="4.69" x2="-14.53" y2="5.19" layer="51"/>
<rectangle x1="-14.51" y1="4.69" x2="-14.09" y2="5.19" layer="51"/>
<rectangle x1="-14.07" y1="4.69" x2="-13.65" y2="5.19" layer="51"/>
<rectangle x1="-13.63" y1="4.69" x2="-13.21" y2="5.19" layer="51"/>
<rectangle x1="-13.19" y1="4.69" x2="-12.77" y2="5.19" layer="51"/>
<rectangle x1="-12.75" y1="4.69" x2="-12.33" y2="5.19" layer="51"/>
<rectangle x1="-12.31" y1="4.69" x2="-11.89" y2="5.19" layer="51"/>
<rectangle x1="-11.87" y1="4.69" x2="-11.45" y2="5.19" layer="51"/>
<rectangle x1="-11.43" y1="4.69" x2="-11.01" y2="5.19" layer="51"/>
<rectangle x1="-10.99" y1="4.69" x2="-10.57" y2="5.19" layer="51"/>
<rectangle x1="-10.55" y1="4.69" x2="-10.13" y2="5.19" layer="51"/>
<rectangle x1="-10.11" y1="4.69" x2="-9.69" y2="5.19" layer="51"/>
<rectangle x1="-9.67" y1="4.69" x2="-9.25" y2="5.19" layer="51"/>
<rectangle x1="-9.23" y1="4.69" x2="-8.81" y2="5.19" layer="51"/>
<rectangle x1="-8.79" y1="4.69" x2="-8.37" y2="5.19" layer="51"/>
<rectangle x1="-8.35" y1="4.69" x2="-7.93" y2="5.19" layer="51"/>
<rectangle x1="-7.91" y1="4.69" x2="-7.49" y2="5.19" layer="51"/>
<rectangle x1="-7.47" y1="4.69" x2="-7.05" y2="5.19" layer="51"/>
<rectangle x1="-7.03" y1="4.69" x2="-6.61" y2="5.19" layer="51"/>
<rectangle x1="-6.59" y1="4.69" x2="-6.17" y2="5.19" layer="51"/>
<rectangle x1="-6.15" y1="4.69" x2="-5.73" y2="5.19" layer="51"/>
<rectangle x1="-5.71" y1="4.69" x2="-5.29" y2="5.19" layer="51"/>
<rectangle x1="-5.27" y1="4.69" x2="-4.85" y2="5.19" layer="51"/>
<rectangle x1="-4.83" y1="4.69" x2="-4.41" y2="5.19" layer="51"/>
<rectangle x1="-4.39" y1="4.69" x2="-3.97" y2="5.19" layer="51"/>
<rectangle x1="-3.95" y1="4.69" x2="-3.53" y2="5.19" layer="51"/>
<rectangle x1="-3.51" y1="4.69" x2="-3.09" y2="5.19" layer="51"/>
<rectangle x1="-3.07" y1="4.69" x2="-2.65" y2="5.19" layer="51"/>
<rectangle x1="-2.63" y1="4.69" x2="-2.21" y2="5.19" layer="51"/>
<rectangle x1="-2.19" y1="4.69" x2="-1.77" y2="5.19" layer="51"/>
<rectangle x1="-1.75" y1="4.69" x2="-1.33" y2="5.19" layer="51"/>
<rectangle x1="-1.31" y1="4.69" x2="-0.89" y2="5.19" layer="51"/>
<rectangle x1="-0.87" y1="4.69" x2="-0.45" y2="5.19" layer="51"/>
<rectangle x1="-0.43" y1="4.69" x2="-0.01" y2="5.19" layer="51"/>
<rectangle x1="0.01" y1="4.69" x2="0.43" y2="5.19" layer="51"/>
<rectangle x1="0.45" y1="4.69" x2="0.87" y2="5.19" layer="51"/>
<rectangle x1="0.89" y1="4.69" x2="1.31" y2="5.19" layer="51"/>
<rectangle x1="1.33" y1="4.69" x2="1.75" y2="5.19" layer="51"/>
<rectangle x1="1.77" y1="4.69" x2="2.19" y2="5.19" layer="51"/>
<rectangle x1="2.21" y1="4.69" x2="2.63" y2="5.19" layer="51"/>
<rectangle x1="2.65" y1="4.69" x2="3.07" y2="5.19" layer="51"/>
<rectangle x1="3.09" y1="4.69" x2="3.51" y2="5.19" layer="51"/>
<rectangle x1="3.53" y1="4.69" x2="3.95" y2="5.19" layer="51"/>
<rectangle x1="3.97" y1="4.69" x2="4.39" y2="5.19" layer="51"/>
<rectangle x1="4.41" y1="4.69" x2="4.83" y2="5.19" layer="51"/>
<rectangle x1="4.85" y1="4.69" x2="5.27" y2="5.19" layer="51"/>
<rectangle x1="5.29" y1="4.69" x2="5.71" y2="5.19" layer="51"/>
<rectangle x1="5.73" y1="4.69" x2="6.15" y2="5.19" layer="51"/>
<rectangle x1="6.17" y1="4.69" x2="6.59" y2="5.19" layer="51"/>
<rectangle x1="6.61" y1="4.69" x2="7.03" y2="5.19" layer="51"/>
<rectangle x1="7.05" y1="4.69" x2="7.47" y2="5.19" layer="51"/>
<rectangle x1="7.49" y1="4.69" x2="7.91" y2="5.19" layer="51"/>
<rectangle x1="7.93" y1="4.69" x2="8.35" y2="5.19" layer="51"/>
<rectangle x1="8.37" y1="4.69" x2="8.79" y2="5.19" layer="51"/>
<rectangle x1="8.81" y1="4.69" x2="9.23" y2="5.19" layer="51"/>
<rectangle x1="9.25" y1="4.69" x2="9.67" y2="5.19" layer="51"/>
<rectangle x1="9.69" y1="4.69" x2="10.11" y2="5.19" layer="51"/>
<rectangle x1="10.13" y1="4.69" x2="10.55" y2="5.19" layer="51"/>
<rectangle x1="10.57" y1="4.69" x2="10.99" y2="5.19" layer="51"/>
<rectangle x1="11.01" y1="4.69" x2="11.43" y2="5.19" layer="51"/>
<rectangle x1="11.45" y1="4.69" x2="11.87" y2="5.19" layer="51"/>
<rectangle x1="11.89" y1="4.69" x2="12.31" y2="5.19" layer="51"/>
<rectangle x1="12.33" y1="4.69" x2="12.75" y2="5.19" layer="51"/>
<rectangle x1="12.77" y1="4.69" x2="13.19" y2="5.19" layer="51"/>
<rectangle x1="13.21" y1="4.69" x2="13.63" y2="5.19" layer="51"/>
<rectangle x1="13.65" y1="4.69" x2="14.07" y2="5.19" layer="51"/>
<rectangle x1="14.09" y1="4.69" x2="14.51" y2="5.19" layer="51"/>
<rectangle x1="14.53" y1="4.69" x2="14.95" y2="5.19" layer="51"/>
<rectangle x1="14.97" y1="4.69" x2="15.39" y2="5.19" layer="51"/>
<rectangle x1="15.41" y1="4.69" x2="15.83" y2="5.19" layer="51"/>
<rectangle x1="15.85" y1="4.69" x2="16.27" y2="5.19" layer="51"/>
<rectangle x1="16.29" y1="4.69" x2="16.71" y2="5.19" layer="51"/>
<rectangle x1="16.73" y1="4.69" x2="17.15" y2="5.19" layer="51"/>
<rectangle x1="17.17" y1="4.69" x2="17.59" y2="5.19" layer="51"/>
<rectangle x1="17.61" y1="4.69" x2="18.03" y2="5.19" layer="51"/>
<rectangle x1="18.05" y1="4.69" x2="18.47" y2="5.19" layer="51"/>
<rectangle x1="18.49" y1="4.69" x2="18.91" y2="5.19" layer="51"/>
<rectangle x1="18.93" y1="4.69" x2="19.35" y2="5.19" layer="51"/>
<rectangle x1="19.37" y1="4.69" x2="19.79" y2="5.19" layer="51"/>
<rectangle x1="19.81" y1="4.69" x2="20.23" y2="5.19" layer="51"/>
<rectangle x1="20.25" y1="4.69" x2="20.67" y2="5.19" layer="51"/>
<rectangle x1="20.69" y1="4.69" x2="21.11" y2="5.19" layer="51"/>
<rectangle x1="21.13" y1="4.69" x2="21.55" y2="5.19" layer="51"/>
<rectangle x1="21.57" y1="4.69" x2="21.99" y2="5.19" layer="51"/>
<rectangle x1="22.01" y1="4.69" x2="22.43" y2="5.19" layer="51"/>
<rectangle x1="22.45" y1="4.69" x2="22.87" y2="5.19" layer="51"/>
<rectangle x1="22.89" y1="4.69" x2="23.31" y2="5.19" layer="51"/>
<rectangle x1="23.33" y1="4.69" x2="23.75" y2="5.19" layer="51"/>
<rectangle x1="23.77" y1="4.69" x2="24.19" y2="5.19" layer="51"/>
<rectangle x1="24.21" y1="4.69" x2="24.63" y2="5.19" layer="51"/>
<rectangle x1="24.65" y1="4.69" x2="25.07" y2="5.19" layer="51"/>
<rectangle x1="25.09" y1="4.69" x2="25.51" y2="5.19" layer="51"/>
<rectangle x1="25.53" y1="4.69" x2="25.95" y2="5.19" layer="51"/>
<rectangle x1="25.97" y1="4.69" x2="26.39" y2="5.19" layer="51"/>
<rectangle x1="26.41" y1="4.69" x2="26.83" y2="5.19" layer="51"/>
<rectangle x1="26.85" y1="4.69" x2="27.27" y2="5.19" layer="51"/>
<rectangle x1="27.29" y1="4.69" x2="27.71" y2="5.19" layer="51"/>
<rectangle x1="27.73" y1="4.69" x2="28.15" y2="5.19" layer="51"/>
<rectangle x1="-28.15" y1="4.17" x2="-27.73" y2="4.67" layer="51"/>
<rectangle x1="-27.71" y1="4.17" x2="-27.29" y2="4.67" layer="51"/>
<rectangle x1="-27.27" y1="4.17" x2="-26.85" y2="4.67" layer="51"/>
<rectangle x1="-26.83" y1="4.17" x2="-26.41" y2="4.67" layer="51"/>
<rectangle x1="-26.39" y1="4.17" x2="-25.97" y2="4.67" layer="51"/>
<rectangle x1="-25.95" y1="4.17" x2="-25.53" y2="4.67" layer="51"/>
<rectangle x1="-25.51" y1="4.17" x2="-25.09" y2="4.67" layer="51"/>
<rectangle x1="-25.07" y1="4.17" x2="-24.65" y2="4.67" layer="51"/>
<rectangle x1="-24.63" y1="4.17" x2="-24.21" y2="4.67" layer="51"/>
<rectangle x1="-24.19" y1="4.17" x2="-23.77" y2="4.67" layer="51"/>
<rectangle x1="-23.75" y1="4.17" x2="-23.33" y2="4.67" layer="51"/>
<rectangle x1="-23.31" y1="4.17" x2="-22.89" y2="4.67" layer="51"/>
<rectangle x1="-22.87" y1="4.17" x2="-22.45" y2="4.67" layer="51"/>
<rectangle x1="-22.43" y1="4.17" x2="-22.01" y2="4.67" layer="51"/>
<rectangle x1="-21.99" y1="4.17" x2="-21.57" y2="4.67" layer="51"/>
<rectangle x1="-21.55" y1="4.17" x2="-21.13" y2="4.67" layer="51"/>
<rectangle x1="-21.11" y1="4.17" x2="-20.69" y2="4.67" layer="51"/>
<rectangle x1="-20.67" y1="4.17" x2="-20.25" y2="4.67" layer="51"/>
<rectangle x1="-20.23" y1="4.17" x2="-19.81" y2="4.67" layer="51"/>
<rectangle x1="-19.79" y1="4.17" x2="-19.37" y2="4.67" layer="51"/>
<rectangle x1="-19.35" y1="4.17" x2="-18.93" y2="4.67" layer="51"/>
<rectangle x1="-18.91" y1="4.17" x2="-18.49" y2="4.67" layer="51"/>
<rectangle x1="-18.47" y1="4.17" x2="-18.05" y2="4.67" layer="51"/>
<rectangle x1="-18.03" y1="4.17" x2="-17.61" y2="4.67" layer="51"/>
<rectangle x1="-17.59" y1="4.17" x2="-17.17" y2="4.67" layer="51"/>
<rectangle x1="-17.15" y1="4.17" x2="-16.73" y2="4.67" layer="51"/>
<rectangle x1="-16.71" y1="4.17" x2="-16.29" y2="4.67" layer="51"/>
<rectangle x1="-16.27" y1="4.17" x2="-15.85" y2="4.67" layer="51"/>
<rectangle x1="-15.83" y1="4.17" x2="-15.41" y2="4.67" layer="51"/>
<rectangle x1="-15.39" y1="4.17" x2="-14.97" y2="4.67" layer="51"/>
<rectangle x1="-14.95" y1="4.17" x2="-14.53" y2="4.67" layer="51"/>
<rectangle x1="-14.51" y1="4.17" x2="-14.09" y2="4.67" layer="51"/>
<rectangle x1="-14.07" y1="4.17" x2="-13.65" y2="4.67" layer="51"/>
<rectangle x1="-13.63" y1="4.17" x2="-13.21" y2="4.67" layer="51"/>
<rectangle x1="-13.19" y1="4.17" x2="-12.77" y2="4.67" layer="51"/>
<rectangle x1="-12.75" y1="4.17" x2="-12.33" y2="4.67" layer="51"/>
<rectangle x1="-12.31" y1="4.17" x2="-11.89" y2="4.67" layer="51"/>
<rectangle x1="-11.87" y1="4.17" x2="-11.45" y2="4.67" layer="51"/>
<rectangle x1="-11.43" y1="4.17" x2="-11.01" y2="4.67" layer="51"/>
<rectangle x1="-10.99" y1="4.17" x2="-10.57" y2="4.67" layer="51"/>
<rectangle x1="-10.55" y1="4.17" x2="-10.13" y2="4.67" layer="51"/>
<rectangle x1="-10.11" y1="4.17" x2="-9.69" y2="4.67" layer="51"/>
<rectangle x1="-9.67" y1="4.17" x2="-9.25" y2="4.67" layer="51"/>
<rectangle x1="-9.23" y1="4.17" x2="-8.81" y2="4.67" layer="51"/>
<rectangle x1="-8.79" y1="4.17" x2="-8.37" y2="4.67" layer="51"/>
<rectangle x1="-8.35" y1="4.17" x2="-7.93" y2="4.67" layer="51"/>
<rectangle x1="-7.91" y1="4.17" x2="-7.49" y2="4.67" layer="51"/>
<rectangle x1="-7.47" y1="4.17" x2="-7.05" y2="4.67" layer="51"/>
<rectangle x1="-7.03" y1="4.17" x2="-6.61" y2="4.67" layer="51"/>
<rectangle x1="-6.59" y1="4.17" x2="-6.17" y2="4.67" layer="51"/>
<rectangle x1="-6.15" y1="4.17" x2="-5.73" y2="4.67" layer="51"/>
<rectangle x1="-5.71" y1="4.17" x2="-5.29" y2="4.67" layer="51"/>
<rectangle x1="-5.27" y1="4.17" x2="-4.85" y2="4.67" layer="51"/>
<rectangle x1="-4.83" y1="4.17" x2="-4.41" y2="4.67" layer="51"/>
<rectangle x1="-4.39" y1="4.17" x2="-3.97" y2="4.67" layer="51"/>
<rectangle x1="-3.95" y1="4.17" x2="-3.53" y2="4.67" layer="51"/>
<rectangle x1="-3.51" y1="4.17" x2="-3.09" y2="4.67" layer="51"/>
<rectangle x1="-3.07" y1="4.17" x2="-2.65" y2="4.67" layer="51"/>
<rectangle x1="-2.63" y1="4.17" x2="-2.21" y2="4.67" layer="51"/>
<rectangle x1="-2.19" y1="4.17" x2="-1.77" y2="4.67" layer="51"/>
<rectangle x1="-1.75" y1="4.17" x2="-1.33" y2="4.67" layer="51"/>
<rectangle x1="-1.31" y1="4.17" x2="-0.89" y2="4.67" layer="51"/>
<rectangle x1="-0.87" y1="4.17" x2="-0.45" y2="4.67" layer="51"/>
<rectangle x1="-0.43" y1="4.17" x2="-0.01" y2="4.67" layer="51"/>
<rectangle x1="0.01" y1="4.17" x2="0.43" y2="4.67" layer="51"/>
<rectangle x1="0.45" y1="4.17" x2="0.87" y2="4.67" layer="51"/>
<rectangle x1="0.89" y1="4.17" x2="1.31" y2="4.67" layer="51"/>
<rectangle x1="1.33" y1="4.17" x2="1.75" y2="4.67" layer="51"/>
<rectangle x1="1.77" y1="4.17" x2="2.19" y2="4.67" layer="51"/>
<rectangle x1="2.21" y1="4.17" x2="2.63" y2="4.67" layer="51"/>
<rectangle x1="2.65" y1="4.17" x2="3.07" y2="4.67" layer="51"/>
<rectangle x1="3.09" y1="4.17" x2="3.51" y2="4.67" layer="51"/>
<rectangle x1="3.53" y1="4.17" x2="3.95" y2="4.67" layer="51"/>
<rectangle x1="3.97" y1="4.17" x2="4.39" y2="4.67" layer="51"/>
<rectangle x1="4.41" y1="4.17" x2="4.83" y2="4.67" layer="51"/>
<rectangle x1="4.85" y1="4.17" x2="5.27" y2="4.67" layer="51"/>
<rectangle x1="5.29" y1="4.17" x2="5.71" y2="4.67" layer="51"/>
<rectangle x1="5.73" y1="4.17" x2="6.15" y2="4.67" layer="51"/>
<rectangle x1="6.17" y1="4.17" x2="6.59" y2="4.67" layer="51"/>
<rectangle x1="6.61" y1="4.17" x2="7.03" y2="4.67" layer="51"/>
<rectangle x1="7.05" y1="4.17" x2="7.47" y2="4.67" layer="51"/>
<rectangle x1="7.49" y1="4.17" x2="7.91" y2="4.67" layer="51"/>
<rectangle x1="7.93" y1="4.17" x2="8.35" y2="4.67" layer="51"/>
<rectangle x1="8.37" y1="4.17" x2="8.79" y2="4.67" layer="51"/>
<rectangle x1="8.81" y1="4.17" x2="9.23" y2="4.67" layer="51"/>
<rectangle x1="9.25" y1="4.17" x2="9.67" y2="4.67" layer="51"/>
<rectangle x1="9.69" y1="4.17" x2="10.11" y2="4.67" layer="51"/>
<rectangle x1="10.13" y1="4.17" x2="10.55" y2="4.67" layer="51"/>
<rectangle x1="10.57" y1="4.17" x2="10.99" y2="4.67" layer="51"/>
<rectangle x1="11.01" y1="4.17" x2="11.43" y2="4.67" layer="51"/>
<rectangle x1="11.45" y1="4.17" x2="11.87" y2="4.67" layer="51"/>
<rectangle x1="11.89" y1="4.17" x2="12.31" y2="4.67" layer="51"/>
<rectangle x1="12.33" y1="4.17" x2="12.75" y2="4.67" layer="51"/>
<rectangle x1="12.77" y1="4.17" x2="13.19" y2="4.67" layer="51"/>
<rectangle x1="13.21" y1="4.17" x2="13.63" y2="4.67" layer="51"/>
<rectangle x1="13.65" y1="4.17" x2="14.07" y2="4.67" layer="51"/>
<rectangle x1="14.09" y1="4.17" x2="14.51" y2="4.67" layer="51"/>
<rectangle x1="14.53" y1="4.17" x2="14.95" y2="4.67" layer="51"/>
<rectangle x1="14.97" y1="4.17" x2="15.39" y2="4.67" layer="51"/>
<rectangle x1="15.41" y1="4.17" x2="15.83" y2="4.67" layer="51"/>
<rectangle x1="15.85" y1="4.17" x2="16.27" y2="4.67" layer="51"/>
<rectangle x1="16.29" y1="4.17" x2="16.71" y2="4.67" layer="51"/>
<rectangle x1="16.73" y1="4.17" x2="17.15" y2="4.67" layer="51"/>
<rectangle x1="17.17" y1="4.17" x2="17.59" y2="4.67" layer="51"/>
<rectangle x1="17.61" y1="4.17" x2="18.03" y2="4.67" layer="51"/>
<rectangle x1="18.05" y1="4.17" x2="18.47" y2="4.67" layer="51"/>
<rectangle x1="18.49" y1="4.17" x2="18.91" y2="4.67" layer="51"/>
<rectangle x1="18.93" y1="4.17" x2="19.35" y2="4.67" layer="51"/>
<rectangle x1="19.37" y1="4.17" x2="19.79" y2="4.67" layer="51"/>
<rectangle x1="19.81" y1="4.17" x2="20.23" y2="4.67" layer="51"/>
<rectangle x1="20.25" y1="4.17" x2="20.67" y2="4.67" layer="51"/>
<rectangle x1="20.69" y1="4.17" x2="21.11" y2="4.67" layer="51"/>
<rectangle x1="21.13" y1="4.17" x2="21.55" y2="4.67" layer="51"/>
<rectangle x1="21.57" y1="4.17" x2="21.99" y2="4.67" layer="51"/>
<rectangle x1="22.01" y1="4.17" x2="22.43" y2="4.67" layer="51"/>
<rectangle x1="22.45" y1="4.17" x2="22.87" y2="4.67" layer="51"/>
<rectangle x1="22.89" y1="4.17" x2="23.31" y2="4.67" layer="51"/>
<rectangle x1="23.33" y1="4.17" x2="23.75" y2="4.67" layer="51"/>
<rectangle x1="23.77" y1="4.17" x2="24.19" y2="4.67" layer="51"/>
<rectangle x1="24.21" y1="4.17" x2="24.63" y2="4.67" layer="51"/>
<rectangle x1="24.65" y1="4.17" x2="25.07" y2="4.67" layer="51"/>
<rectangle x1="25.09" y1="4.17" x2="25.51" y2="4.67" layer="51"/>
<rectangle x1="25.53" y1="4.17" x2="25.95" y2="4.67" layer="51"/>
<rectangle x1="25.97" y1="4.17" x2="26.39" y2="4.67" layer="51"/>
<rectangle x1="26.41" y1="4.17" x2="26.83" y2="4.67" layer="51"/>
<rectangle x1="26.85" y1="4.17" x2="27.27" y2="4.67" layer="51"/>
<rectangle x1="27.29" y1="4.17" x2="27.71" y2="4.67" layer="51"/>
<rectangle x1="27.73" y1="4.17" x2="28.15" y2="4.67" layer="51"/>
<rectangle x1="-28.15" y1="3.65" x2="-27.73" y2="4.15" layer="51"/>
<rectangle x1="-27.71" y1="3.65" x2="-27.29" y2="4.15" layer="51"/>
<rectangle x1="-27.27" y1="3.65" x2="-26.85" y2="4.15" layer="51"/>
<rectangle x1="-26.83" y1="3.65" x2="-26.41" y2="4.15" layer="51"/>
<rectangle x1="-26.39" y1="3.65" x2="-25.97" y2="4.15" layer="51"/>
<rectangle x1="-25.95" y1="3.65" x2="-25.53" y2="4.15" layer="51"/>
<rectangle x1="-25.51" y1="3.65" x2="-25.09" y2="4.15" layer="51"/>
<rectangle x1="-25.07" y1="3.65" x2="-24.65" y2="4.15" layer="51"/>
<rectangle x1="-24.63" y1="3.65" x2="-24.21" y2="4.15" layer="51"/>
<rectangle x1="-24.19" y1="3.65" x2="-23.77" y2="4.15" layer="51"/>
<rectangle x1="-23.75" y1="3.65" x2="-23.33" y2="4.15" layer="51"/>
<rectangle x1="-23.31" y1="3.65" x2="-22.89" y2="4.15" layer="51"/>
<rectangle x1="-22.87" y1="3.65" x2="-22.45" y2="4.15" layer="51"/>
<rectangle x1="-22.43" y1="3.65" x2="-22.01" y2="4.15" layer="51"/>
<rectangle x1="-21.99" y1="3.65" x2="-21.57" y2="4.15" layer="51"/>
<rectangle x1="-21.55" y1="3.65" x2="-21.13" y2="4.15" layer="51"/>
<rectangle x1="-21.11" y1="3.65" x2="-20.69" y2="4.15" layer="51"/>
<rectangle x1="-20.67" y1="3.65" x2="-20.25" y2="4.15" layer="51"/>
<rectangle x1="-20.23" y1="3.65" x2="-19.81" y2="4.15" layer="51"/>
<rectangle x1="-19.79" y1="3.65" x2="-19.37" y2="4.15" layer="51"/>
<rectangle x1="-19.35" y1="3.65" x2="-18.93" y2="4.15" layer="51"/>
<rectangle x1="-18.91" y1="3.65" x2="-18.49" y2="4.15" layer="51"/>
<rectangle x1="-18.47" y1="3.65" x2="-18.05" y2="4.15" layer="51"/>
<rectangle x1="-18.03" y1="3.65" x2="-17.61" y2="4.15" layer="51"/>
<rectangle x1="-17.59" y1="3.65" x2="-17.17" y2="4.15" layer="51"/>
<rectangle x1="-17.15" y1="3.65" x2="-16.73" y2="4.15" layer="51"/>
<rectangle x1="-16.71" y1="3.65" x2="-16.29" y2="4.15" layer="51"/>
<rectangle x1="-16.27" y1="3.65" x2="-15.85" y2="4.15" layer="51"/>
<rectangle x1="-15.83" y1="3.65" x2="-15.41" y2="4.15" layer="51"/>
<rectangle x1="-15.39" y1="3.65" x2="-14.97" y2="4.15" layer="51"/>
<rectangle x1="-14.95" y1="3.65" x2="-14.53" y2="4.15" layer="51"/>
<rectangle x1="-14.51" y1="3.65" x2="-14.09" y2="4.15" layer="51"/>
<rectangle x1="-14.07" y1="3.65" x2="-13.65" y2="4.15" layer="51"/>
<rectangle x1="-13.63" y1="3.65" x2="-13.21" y2="4.15" layer="51"/>
<rectangle x1="-13.19" y1="3.65" x2="-12.77" y2="4.15" layer="51"/>
<rectangle x1="-12.75" y1="3.65" x2="-12.33" y2="4.15" layer="51"/>
<rectangle x1="-12.31" y1="3.65" x2="-11.89" y2="4.15" layer="51"/>
<rectangle x1="-11.87" y1="3.65" x2="-11.45" y2="4.15" layer="51"/>
<rectangle x1="-11.43" y1="3.65" x2="-11.01" y2="4.15" layer="51"/>
<rectangle x1="-10.99" y1="3.65" x2="-10.57" y2="4.15" layer="51"/>
<rectangle x1="-10.55" y1="3.65" x2="-10.13" y2="4.15" layer="51"/>
<rectangle x1="-10.11" y1="3.65" x2="-9.69" y2="4.15" layer="51"/>
<rectangle x1="-9.67" y1="3.65" x2="-9.25" y2="4.15" layer="51"/>
<rectangle x1="-9.23" y1="3.65" x2="-8.81" y2="4.15" layer="51"/>
<rectangle x1="-8.79" y1="3.65" x2="-8.37" y2="4.15" layer="51"/>
<rectangle x1="-8.35" y1="3.65" x2="-7.93" y2="4.15" layer="51"/>
<rectangle x1="-7.91" y1="3.65" x2="-7.49" y2="4.15" layer="51"/>
<rectangle x1="-7.47" y1="3.65" x2="-7.05" y2="4.15" layer="51"/>
<rectangle x1="-7.03" y1="3.65" x2="-6.61" y2="4.15" layer="51"/>
<rectangle x1="-6.59" y1="3.65" x2="-6.17" y2="4.15" layer="51"/>
<rectangle x1="-6.15" y1="3.65" x2="-5.73" y2="4.15" layer="51"/>
<rectangle x1="-5.71" y1="3.65" x2="-5.29" y2="4.15" layer="51"/>
<rectangle x1="-5.27" y1="3.65" x2="-4.85" y2="4.15" layer="51"/>
<rectangle x1="-4.83" y1="3.65" x2="-4.41" y2="4.15" layer="51"/>
<rectangle x1="-4.39" y1="3.65" x2="-3.97" y2="4.15" layer="51"/>
<rectangle x1="-3.95" y1="3.65" x2="-3.53" y2="4.15" layer="51"/>
<rectangle x1="-3.51" y1="3.65" x2="-3.09" y2="4.15" layer="51"/>
<rectangle x1="-3.07" y1="3.65" x2="-2.65" y2="4.15" layer="51"/>
<rectangle x1="-2.63" y1="3.65" x2="-2.21" y2="4.15" layer="51"/>
<rectangle x1="-2.19" y1="3.65" x2="-1.77" y2="4.15" layer="51"/>
<rectangle x1="-1.75" y1="3.65" x2="-1.33" y2="4.15" layer="51"/>
<rectangle x1="-1.31" y1="3.65" x2="-0.89" y2="4.15" layer="51"/>
<rectangle x1="-0.87" y1="3.65" x2="-0.45" y2="4.15" layer="51"/>
<rectangle x1="-0.43" y1="3.65" x2="-0.01" y2="4.15" layer="51"/>
<rectangle x1="0.01" y1="3.65" x2="0.43" y2="4.15" layer="51"/>
<rectangle x1="0.45" y1="3.65" x2="0.87" y2="4.15" layer="51"/>
<rectangle x1="0.89" y1="3.65" x2="1.31" y2="4.15" layer="51"/>
<rectangle x1="1.33" y1="3.65" x2="1.75" y2="4.15" layer="51"/>
<rectangle x1="1.77" y1="3.65" x2="2.19" y2="4.15" layer="51"/>
<rectangle x1="2.21" y1="3.65" x2="2.63" y2="4.15" layer="51"/>
<rectangle x1="2.65" y1="3.65" x2="3.07" y2="4.15" layer="51"/>
<rectangle x1="3.09" y1="3.65" x2="3.51" y2="4.15" layer="51"/>
<rectangle x1="3.53" y1="3.65" x2="3.95" y2="4.15" layer="51"/>
<rectangle x1="3.97" y1="3.65" x2="4.39" y2="4.15" layer="51"/>
<rectangle x1="4.41" y1="3.65" x2="4.83" y2="4.15" layer="51"/>
<rectangle x1="4.85" y1="3.65" x2="5.27" y2="4.15" layer="51"/>
<rectangle x1="5.29" y1="3.65" x2="5.71" y2="4.15" layer="51"/>
<rectangle x1="5.73" y1="3.65" x2="6.15" y2="4.15" layer="51"/>
<rectangle x1="6.17" y1="3.65" x2="6.59" y2="4.15" layer="51"/>
<rectangle x1="6.61" y1="3.65" x2="7.03" y2="4.15" layer="51"/>
<rectangle x1="7.05" y1="3.65" x2="7.47" y2="4.15" layer="51"/>
<rectangle x1="7.49" y1="3.65" x2="7.91" y2="4.15" layer="51"/>
<rectangle x1="7.93" y1="3.65" x2="8.35" y2="4.15" layer="51"/>
<rectangle x1="8.37" y1="3.65" x2="8.79" y2="4.15" layer="51"/>
<rectangle x1="8.81" y1="3.65" x2="9.23" y2="4.15" layer="51"/>
<rectangle x1="9.25" y1="3.65" x2="9.67" y2="4.15" layer="51"/>
<rectangle x1="9.69" y1="3.65" x2="10.11" y2="4.15" layer="51"/>
<rectangle x1="10.13" y1="3.65" x2="10.55" y2="4.15" layer="51"/>
<rectangle x1="10.57" y1="3.65" x2="10.99" y2="4.15" layer="51"/>
<rectangle x1="11.01" y1="3.65" x2="11.43" y2="4.15" layer="51"/>
<rectangle x1="11.45" y1="3.65" x2="11.87" y2="4.15" layer="51"/>
<rectangle x1="11.89" y1="3.65" x2="12.31" y2="4.15" layer="51"/>
<rectangle x1="12.33" y1="3.65" x2="12.75" y2="4.15" layer="51"/>
<rectangle x1="12.77" y1="3.65" x2="13.19" y2="4.15" layer="51"/>
<rectangle x1="13.21" y1="3.65" x2="13.63" y2="4.15" layer="51"/>
<rectangle x1="13.65" y1="3.65" x2="14.07" y2="4.15" layer="51"/>
<rectangle x1="14.09" y1="3.65" x2="14.51" y2="4.15" layer="51"/>
<rectangle x1="14.53" y1="3.65" x2="14.95" y2="4.15" layer="51"/>
<rectangle x1="14.97" y1="3.65" x2="15.39" y2="4.15" layer="51"/>
<rectangle x1="15.41" y1="3.65" x2="15.83" y2="4.15" layer="51"/>
<rectangle x1="15.85" y1="3.65" x2="16.27" y2="4.15" layer="51"/>
<rectangle x1="16.29" y1="3.65" x2="16.71" y2="4.15" layer="51"/>
<rectangle x1="16.73" y1="3.65" x2="17.15" y2="4.15" layer="51"/>
<rectangle x1="17.17" y1="3.65" x2="17.59" y2="4.15" layer="51"/>
<rectangle x1="17.61" y1="3.65" x2="18.03" y2="4.15" layer="51"/>
<rectangle x1="18.05" y1="3.65" x2="18.47" y2="4.15" layer="51"/>
<rectangle x1="18.49" y1="3.65" x2="18.91" y2="4.15" layer="51"/>
<rectangle x1="18.93" y1="3.65" x2="19.35" y2="4.15" layer="51"/>
<rectangle x1="19.37" y1="3.65" x2="19.79" y2="4.15" layer="51"/>
<rectangle x1="19.81" y1="3.65" x2="20.23" y2="4.15" layer="51"/>
<rectangle x1="20.25" y1="3.65" x2="20.67" y2="4.15" layer="51"/>
<rectangle x1="20.69" y1="3.65" x2="21.11" y2="4.15" layer="51"/>
<rectangle x1="21.13" y1="3.65" x2="21.55" y2="4.15" layer="51"/>
<rectangle x1="21.57" y1="3.65" x2="21.99" y2="4.15" layer="51"/>
<rectangle x1="22.01" y1="3.65" x2="22.43" y2="4.15" layer="51"/>
<rectangle x1="22.45" y1="3.65" x2="22.87" y2="4.15" layer="51"/>
<rectangle x1="22.89" y1="3.65" x2="23.31" y2="4.15" layer="51"/>
<rectangle x1="23.33" y1="3.65" x2="23.75" y2="4.15" layer="51"/>
<rectangle x1="23.77" y1="3.65" x2="24.19" y2="4.15" layer="51"/>
<rectangle x1="24.21" y1="3.65" x2="24.63" y2="4.15" layer="51"/>
<rectangle x1="24.65" y1="3.65" x2="25.07" y2="4.15" layer="51"/>
<rectangle x1="25.09" y1="3.65" x2="25.51" y2="4.15" layer="51"/>
<rectangle x1="25.53" y1="3.65" x2="25.95" y2="4.15" layer="51"/>
<rectangle x1="25.97" y1="3.65" x2="26.39" y2="4.15" layer="51"/>
<rectangle x1="26.41" y1="3.65" x2="26.83" y2="4.15" layer="51"/>
<rectangle x1="26.85" y1="3.65" x2="27.27" y2="4.15" layer="51"/>
<rectangle x1="27.29" y1="3.65" x2="27.71" y2="4.15" layer="51"/>
<rectangle x1="27.73" y1="3.65" x2="28.15" y2="4.15" layer="51"/>
<rectangle x1="-28.15" y1="3.13" x2="-27.73" y2="3.63" layer="51"/>
<rectangle x1="-27.71" y1="3.13" x2="-27.29" y2="3.63" layer="51"/>
<rectangle x1="-27.27" y1="3.13" x2="-26.85" y2="3.63" layer="51"/>
<rectangle x1="-26.83" y1="3.13" x2="-26.41" y2="3.63" layer="51"/>
<rectangle x1="-26.39" y1="3.13" x2="-25.97" y2="3.63" layer="51"/>
<rectangle x1="-25.95" y1="3.13" x2="-25.53" y2="3.63" layer="51"/>
<rectangle x1="-25.51" y1="3.13" x2="-25.09" y2="3.63" layer="51"/>
<rectangle x1="-25.07" y1="3.13" x2="-24.65" y2="3.63" layer="51"/>
<rectangle x1="-24.63" y1="3.13" x2="-24.21" y2="3.63" layer="51"/>
<rectangle x1="-24.19" y1="3.13" x2="-23.77" y2="3.63" layer="51"/>
<rectangle x1="-23.75" y1="3.13" x2="-23.33" y2="3.63" layer="51"/>
<rectangle x1="-23.31" y1="3.13" x2="-22.89" y2="3.63" layer="51"/>
<rectangle x1="-22.87" y1="3.13" x2="-22.45" y2="3.63" layer="51"/>
<rectangle x1="-22.43" y1="3.13" x2="-22.01" y2="3.63" layer="51"/>
<rectangle x1="-21.99" y1="3.13" x2="-21.57" y2="3.63" layer="51"/>
<rectangle x1="-21.55" y1="3.13" x2="-21.13" y2="3.63" layer="51"/>
<rectangle x1="-21.11" y1="3.13" x2="-20.69" y2="3.63" layer="51"/>
<rectangle x1="-20.67" y1="3.13" x2="-20.25" y2="3.63" layer="51"/>
<rectangle x1="-20.23" y1="3.13" x2="-19.81" y2="3.63" layer="51"/>
<rectangle x1="-19.79" y1="3.13" x2="-19.37" y2="3.63" layer="51"/>
<rectangle x1="-19.35" y1="3.13" x2="-18.93" y2="3.63" layer="51"/>
<rectangle x1="-18.91" y1="3.13" x2="-18.49" y2="3.63" layer="51"/>
<rectangle x1="-18.47" y1="3.13" x2="-18.05" y2="3.63" layer="51"/>
<rectangle x1="-18.03" y1="3.13" x2="-17.61" y2="3.63" layer="51"/>
<rectangle x1="-17.59" y1="3.13" x2="-17.17" y2="3.63" layer="51"/>
<rectangle x1="-17.15" y1="3.13" x2="-16.73" y2="3.63" layer="51"/>
<rectangle x1="-16.71" y1="3.13" x2="-16.29" y2="3.63" layer="51"/>
<rectangle x1="-16.27" y1="3.13" x2="-15.85" y2="3.63" layer="51"/>
<rectangle x1="-15.83" y1="3.13" x2="-15.41" y2="3.63" layer="51"/>
<rectangle x1="-15.39" y1="3.13" x2="-14.97" y2="3.63" layer="51"/>
<rectangle x1="-14.95" y1="3.13" x2="-14.53" y2="3.63" layer="51"/>
<rectangle x1="-14.51" y1="3.13" x2="-14.09" y2="3.63" layer="51"/>
<rectangle x1="-14.07" y1="3.13" x2="-13.65" y2="3.63" layer="51"/>
<rectangle x1="-13.63" y1="3.13" x2="-13.21" y2="3.63" layer="51"/>
<rectangle x1="-13.19" y1="3.13" x2="-12.77" y2="3.63" layer="51"/>
<rectangle x1="-12.75" y1="3.13" x2="-12.33" y2="3.63" layer="51"/>
<rectangle x1="-12.31" y1="3.13" x2="-11.89" y2="3.63" layer="51"/>
<rectangle x1="-11.87" y1="3.13" x2="-11.45" y2="3.63" layer="51"/>
<rectangle x1="-11.43" y1="3.13" x2="-11.01" y2="3.63" layer="51"/>
<rectangle x1="-10.99" y1="3.13" x2="-10.57" y2="3.63" layer="51"/>
<rectangle x1="-10.55" y1="3.13" x2="-10.13" y2="3.63" layer="51"/>
<rectangle x1="-10.11" y1="3.13" x2="-9.69" y2="3.63" layer="51"/>
<rectangle x1="-9.67" y1="3.13" x2="-9.25" y2="3.63" layer="51"/>
<rectangle x1="-9.23" y1="3.13" x2="-8.81" y2="3.63" layer="51"/>
<rectangle x1="-8.79" y1="3.13" x2="-8.37" y2="3.63" layer="51"/>
<rectangle x1="-8.35" y1="3.13" x2="-7.93" y2="3.63" layer="51"/>
<rectangle x1="-7.91" y1="3.13" x2="-7.49" y2="3.63" layer="51"/>
<rectangle x1="-7.47" y1="3.13" x2="-7.05" y2="3.63" layer="51"/>
<rectangle x1="-7.03" y1="3.13" x2="-6.61" y2="3.63" layer="51"/>
<rectangle x1="-6.59" y1="3.13" x2="-6.17" y2="3.63" layer="51"/>
<rectangle x1="-6.15" y1="3.13" x2="-5.73" y2="3.63" layer="51"/>
<rectangle x1="-5.71" y1="3.13" x2="-5.29" y2="3.63" layer="51"/>
<rectangle x1="-5.27" y1="3.13" x2="-4.85" y2="3.63" layer="51"/>
<rectangle x1="-4.83" y1="3.13" x2="-4.41" y2="3.63" layer="51"/>
<rectangle x1="-4.39" y1="3.13" x2="-3.97" y2="3.63" layer="51"/>
<rectangle x1="-3.95" y1="3.13" x2="-3.53" y2="3.63" layer="51"/>
<rectangle x1="-3.51" y1="3.13" x2="-3.09" y2="3.63" layer="51"/>
<rectangle x1="-3.07" y1="3.13" x2="-2.65" y2="3.63" layer="51"/>
<rectangle x1="-2.63" y1="3.13" x2="-2.21" y2="3.63" layer="51"/>
<rectangle x1="-2.19" y1="3.13" x2="-1.77" y2="3.63" layer="51"/>
<rectangle x1="-1.75" y1="3.13" x2="-1.33" y2="3.63" layer="51"/>
<rectangle x1="-1.31" y1="3.13" x2="-0.89" y2="3.63" layer="51"/>
<rectangle x1="-0.87" y1="3.13" x2="-0.45" y2="3.63" layer="51"/>
<rectangle x1="-0.43" y1="3.13" x2="-0.01" y2="3.63" layer="51"/>
<rectangle x1="0.01" y1="3.13" x2="0.43" y2="3.63" layer="51"/>
<rectangle x1="0.45" y1="3.13" x2="0.87" y2="3.63" layer="51"/>
<rectangle x1="0.89" y1="3.13" x2="1.31" y2="3.63" layer="51"/>
<rectangle x1="1.33" y1="3.13" x2="1.75" y2="3.63" layer="51"/>
<rectangle x1="1.77" y1="3.13" x2="2.19" y2="3.63" layer="51"/>
<rectangle x1="2.21" y1="3.13" x2="2.63" y2="3.63" layer="51"/>
<rectangle x1="2.65" y1="3.13" x2="3.07" y2="3.63" layer="51"/>
<rectangle x1="3.09" y1="3.13" x2="3.51" y2="3.63" layer="51"/>
<rectangle x1="3.53" y1="3.13" x2="3.95" y2="3.63" layer="51"/>
<rectangle x1="3.97" y1="3.13" x2="4.39" y2="3.63" layer="51"/>
<rectangle x1="4.41" y1="3.13" x2="4.83" y2="3.63" layer="51"/>
<rectangle x1="4.85" y1="3.13" x2="5.27" y2="3.63" layer="51"/>
<rectangle x1="5.29" y1="3.13" x2="5.71" y2="3.63" layer="51"/>
<rectangle x1="5.73" y1="3.13" x2="6.15" y2="3.63" layer="51"/>
<rectangle x1="6.17" y1="3.13" x2="6.59" y2="3.63" layer="51"/>
<rectangle x1="6.61" y1="3.13" x2="7.03" y2="3.63" layer="51"/>
<rectangle x1="7.05" y1="3.13" x2="7.47" y2="3.63" layer="51"/>
<rectangle x1="7.49" y1="3.13" x2="7.91" y2="3.63" layer="51"/>
<rectangle x1="7.93" y1="3.13" x2="8.35" y2="3.63" layer="51"/>
<rectangle x1="8.37" y1="3.13" x2="8.79" y2="3.63" layer="51"/>
<rectangle x1="8.81" y1="3.13" x2="9.23" y2="3.63" layer="51"/>
<rectangle x1="9.25" y1="3.13" x2="9.67" y2="3.63" layer="51"/>
<rectangle x1="9.69" y1="3.13" x2="10.11" y2="3.63" layer="51"/>
<rectangle x1="10.13" y1="3.13" x2="10.55" y2="3.63" layer="51"/>
<rectangle x1="10.57" y1="3.13" x2="10.99" y2="3.63" layer="51"/>
<rectangle x1="11.01" y1="3.13" x2="11.43" y2="3.63" layer="51"/>
<rectangle x1="11.45" y1="3.13" x2="11.87" y2="3.63" layer="51"/>
<rectangle x1="11.89" y1="3.13" x2="12.31" y2="3.63" layer="51"/>
<rectangle x1="12.33" y1="3.13" x2="12.75" y2="3.63" layer="51"/>
<rectangle x1="12.77" y1="3.13" x2="13.19" y2="3.63" layer="51"/>
<rectangle x1="13.21" y1="3.13" x2="13.63" y2="3.63" layer="51"/>
<rectangle x1="13.65" y1="3.13" x2="14.07" y2="3.63" layer="51"/>
<rectangle x1="14.09" y1="3.13" x2="14.51" y2="3.63" layer="51"/>
<rectangle x1="14.53" y1="3.13" x2="14.95" y2="3.63" layer="51"/>
<rectangle x1="14.97" y1="3.13" x2="15.39" y2="3.63" layer="51"/>
<rectangle x1="15.41" y1="3.13" x2="15.83" y2="3.63" layer="51"/>
<rectangle x1="15.85" y1="3.13" x2="16.27" y2="3.63" layer="51"/>
<rectangle x1="16.29" y1="3.13" x2="16.71" y2="3.63" layer="51"/>
<rectangle x1="16.73" y1="3.13" x2="17.15" y2="3.63" layer="51"/>
<rectangle x1="17.17" y1="3.13" x2="17.59" y2="3.63" layer="51"/>
<rectangle x1="17.61" y1="3.13" x2="18.03" y2="3.63" layer="51"/>
<rectangle x1="18.05" y1="3.13" x2="18.47" y2="3.63" layer="51"/>
<rectangle x1="18.49" y1="3.13" x2="18.91" y2="3.63" layer="51"/>
<rectangle x1="18.93" y1="3.13" x2="19.35" y2="3.63" layer="51"/>
<rectangle x1="19.37" y1="3.13" x2="19.79" y2="3.63" layer="51"/>
<rectangle x1="19.81" y1="3.13" x2="20.23" y2="3.63" layer="51"/>
<rectangle x1="20.25" y1="3.13" x2="20.67" y2="3.63" layer="51"/>
<rectangle x1="20.69" y1="3.13" x2="21.11" y2="3.63" layer="51"/>
<rectangle x1="21.13" y1="3.13" x2="21.55" y2="3.63" layer="51"/>
<rectangle x1="21.57" y1="3.13" x2="21.99" y2="3.63" layer="51"/>
<rectangle x1="22.01" y1="3.13" x2="22.43" y2="3.63" layer="51"/>
<rectangle x1="22.45" y1="3.13" x2="22.87" y2="3.63" layer="51"/>
<rectangle x1="22.89" y1="3.13" x2="23.31" y2="3.63" layer="51"/>
<rectangle x1="23.33" y1="3.13" x2="23.75" y2="3.63" layer="51"/>
<rectangle x1="23.77" y1="3.13" x2="24.19" y2="3.63" layer="51"/>
<rectangle x1="24.21" y1="3.13" x2="24.63" y2="3.63" layer="51"/>
<rectangle x1="24.65" y1="3.13" x2="25.07" y2="3.63" layer="51"/>
<rectangle x1="25.09" y1="3.13" x2="25.51" y2="3.63" layer="51"/>
<rectangle x1="25.53" y1="3.13" x2="25.95" y2="3.63" layer="51"/>
<rectangle x1="25.97" y1="3.13" x2="26.39" y2="3.63" layer="51"/>
<rectangle x1="26.41" y1="3.13" x2="26.83" y2="3.63" layer="51"/>
<rectangle x1="26.85" y1="3.13" x2="27.27" y2="3.63" layer="51"/>
<rectangle x1="27.29" y1="3.13" x2="27.71" y2="3.63" layer="51"/>
<rectangle x1="27.73" y1="3.13" x2="28.15" y2="3.63" layer="51"/>
<rectangle x1="-28.15" y1="2.61" x2="-27.73" y2="3.11" layer="51"/>
<rectangle x1="-27.71" y1="2.61" x2="-27.29" y2="3.11" layer="51"/>
<rectangle x1="-27.27" y1="2.61" x2="-26.85" y2="3.11" layer="51"/>
<rectangle x1="-26.83" y1="2.61" x2="-26.41" y2="3.11" layer="51"/>
<rectangle x1="-26.39" y1="2.61" x2="-25.97" y2="3.11" layer="51"/>
<rectangle x1="-25.95" y1="2.61" x2="-25.53" y2="3.11" layer="51"/>
<rectangle x1="-25.51" y1="2.61" x2="-25.09" y2="3.11" layer="51"/>
<rectangle x1="-25.07" y1="2.61" x2="-24.65" y2="3.11" layer="51"/>
<rectangle x1="-24.63" y1="2.61" x2="-24.21" y2="3.11" layer="51"/>
<rectangle x1="-24.19" y1="2.61" x2="-23.77" y2="3.11" layer="51"/>
<rectangle x1="-23.75" y1="2.61" x2="-23.33" y2="3.11" layer="51"/>
<rectangle x1="-23.31" y1="2.61" x2="-22.89" y2="3.11" layer="51"/>
<rectangle x1="-22.87" y1="2.61" x2="-22.45" y2="3.11" layer="51"/>
<rectangle x1="-22.43" y1="2.61" x2="-22.01" y2="3.11" layer="51"/>
<rectangle x1="-21.99" y1="2.61" x2="-21.57" y2="3.11" layer="51"/>
<rectangle x1="-21.55" y1="2.61" x2="-21.13" y2="3.11" layer="51"/>
<rectangle x1="-21.11" y1="2.61" x2="-20.69" y2="3.11" layer="51"/>
<rectangle x1="-20.67" y1="2.61" x2="-20.25" y2="3.11" layer="51"/>
<rectangle x1="-20.23" y1="2.61" x2="-19.81" y2="3.11" layer="51"/>
<rectangle x1="-19.79" y1="2.61" x2="-19.37" y2="3.11" layer="51"/>
<rectangle x1="-19.35" y1="2.61" x2="-18.93" y2="3.11" layer="51"/>
<rectangle x1="-18.91" y1="2.61" x2="-18.49" y2="3.11" layer="51"/>
<rectangle x1="-18.47" y1="2.61" x2="-18.05" y2="3.11" layer="51"/>
<rectangle x1="-18.03" y1="2.61" x2="-17.61" y2="3.11" layer="51"/>
<rectangle x1="-17.59" y1="2.61" x2="-17.17" y2="3.11" layer="51"/>
<rectangle x1="-17.15" y1="2.61" x2="-16.73" y2="3.11" layer="51"/>
<rectangle x1="-16.71" y1="2.61" x2="-16.29" y2="3.11" layer="51"/>
<rectangle x1="-16.27" y1="2.61" x2="-15.85" y2="3.11" layer="51"/>
<rectangle x1="-15.83" y1="2.61" x2="-15.41" y2="3.11" layer="51"/>
<rectangle x1="-15.39" y1="2.61" x2="-14.97" y2="3.11" layer="51"/>
<rectangle x1="-14.95" y1="2.61" x2="-14.53" y2="3.11" layer="51"/>
<rectangle x1="-14.51" y1="2.61" x2="-14.09" y2="3.11" layer="51"/>
<rectangle x1="-14.07" y1="2.61" x2="-13.65" y2="3.11" layer="51"/>
<rectangle x1="-13.63" y1="2.61" x2="-13.21" y2="3.11" layer="51"/>
<rectangle x1="-13.19" y1="2.61" x2="-12.77" y2="3.11" layer="51"/>
<rectangle x1="-12.75" y1="2.61" x2="-12.33" y2="3.11" layer="51"/>
<rectangle x1="-12.31" y1="2.61" x2="-11.89" y2="3.11" layer="51"/>
<rectangle x1="-11.87" y1="2.61" x2="-11.45" y2="3.11" layer="51"/>
<rectangle x1="-11.43" y1="2.61" x2="-11.01" y2="3.11" layer="51"/>
<rectangle x1="-10.99" y1="2.61" x2="-10.57" y2="3.11" layer="51"/>
<rectangle x1="-10.55" y1="2.61" x2="-10.13" y2="3.11" layer="51"/>
<rectangle x1="-10.11" y1="2.61" x2="-9.69" y2="3.11" layer="51"/>
<rectangle x1="-9.67" y1="2.61" x2="-9.25" y2="3.11" layer="51"/>
<rectangle x1="-9.23" y1="2.61" x2="-8.81" y2="3.11" layer="51"/>
<rectangle x1="-8.79" y1="2.61" x2="-8.37" y2="3.11" layer="51"/>
<rectangle x1="-8.35" y1="2.61" x2="-7.93" y2="3.11" layer="51"/>
<rectangle x1="-7.91" y1="2.61" x2="-7.49" y2="3.11" layer="51"/>
<rectangle x1="-7.47" y1="2.61" x2="-7.05" y2="3.11" layer="51"/>
<rectangle x1="-7.03" y1="2.61" x2="-6.61" y2="3.11" layer="51"/>
<rectangle x1="-6.59" y1="2.61" x2="-6.17" y2="3.11" layer="51"/>
<rectangle x1="-6.15" y1="2.61" x2="-5.73" y2="3.11" layer="51"/>
<rectangle x1="-5.71" y1="2.61" x2="-5.29" y2="3.11" layer="51"/>
<rectangle x1="-5.27" y1="2.61" x2="-4.85" y2="3.11" layer="51"/>
<rectangle x1="-4.83" y1="2.61" x2="-4.41" y2="3.11" layer="51"/>
<rectangle x1="-4.39" y1="2.61" x2="-3.97" y2="3.11" layer="51"/>
<rectangle x1="-3.95" y1="2.61" x2="-3.53" y2="3.11" layer="51"/>
<rectangle x1="-3.51" y1="2.61" x2="-3.09" y2="3.11" layer="51"/>
<rectangle x1="-3.07" y1="2.61" x2="-2.65" y2="3.11" layer="51"/>
<rectangle x1="-2.63" y1="2.61" x2="-2.21" y2="3.11" layer="51"/>
<rectangle x1="-2.19" y1="2.61" x2="-1.77" y2="3.11" layer="51"/>
<rectangle x1="-1.75" y1="2.61" x2="-1.33" y2="3.11" layer="51"/>
<rectangle x1="-1.31" y1="2.61" x2="-0.89" y2="3.11" layer="51"/>
<rectangle x1="-0.87" y1="2.61" x2="-0.45" y2="3.11" layer="51"/>
<rectangle x1="-0.43" y1="2.61" x2="-0.01" y2="3.11" layer="51"/>
<rectangle x1="0.01" y1="2.61" x2="0.43" y2="3.11" layer="51"/>
<rectangle x1="0.45" y1="2.61" x2="0.87" y2="3.11" layer="51"/>
<rectangle x1="0.89" y1="2.61" x2="1.31" y2="3.11" layer="51"/>
<rectangle x1="1.33" y1="2.61" x2="1.75" y2="3.11" layer="51"/>
<rectangle x1="1.77" y1="2.61" x2="2.19" y2="3.11" layer="51"/>
<rectangle x1="2.21" y1="2.61" x2="2.63" y2="3.11" layer="51"/>
<rectangle x1="2.65" y1="2.61" x2="3.07" y2="3.11" layer="51"/>
<rectangle x1="3.09" y1="2.61" x2="3.51" y2="3.11" layer="51"/>
<rectangle x1="3.53" y1="2.61" x2="3.95" y2="3.11" layer="51"/>
<rectangle x1="3.97" y1="2.61" x2="4.39" y2="3.11" layer="51"/>
<rectangle x1="4.41" y1="2.61" x2="4.83" y2="3.11" layer="51"/>
<rectangle x1="4.85" y1="2.61" x2="5.27" y2="3.11" layer="51"/>
<rectangle x1="5.29" y1="2.61" x2="5.71" y2="3.11" layer="51"/>
<rectangle x1="5.73" y1="2.61" x2="6.15" y2="3.11" layer="51"/>
<rectangle x1="6.17" y1="2.61" x2="6.59" y2="3.11" layer="51"/>
<rectangle x1="6.61" y1="2.61" x2="7.03" y2="3.11" layer="51"/>
<rectangle x1="7.05" y1="2.61" x2="7.47" y2="3.11" layer="51"/>
<rectangle x1="7.49" y1="2.61" x2="7.91" y2="3.11" layer="51"/>
<rectangle x1="7.93" y1="2.61" x2="8.35" y2="3.11" layer="51"/>
<rectangle x1="8.37" y1="2.61" x2="8.79" y2="3.11" layer="51"/>
<rectangle x1="8.81" y1="2.61" x2="9.23" y2="3.11" layer="51"/>
<rectangle x1="9.25" y1="2.61" x2="9.67" y2="3.11" layer="51"/>
<rectangle x1="9.69" y1="2.61" x2="10.11" y2="3.11" layer="51"/>
<rectangle x1="10.13" y1="2.61" x2="10.55" y2="3.11" layer="51"/>
<rectangle x1="10.57" y1="2.61" x2="10.99" y2="3.11" layer="51"/>
<rectangle x1="11.01" y1="2.61" x2="11.43" y2="3.11" layer="51"/>
<rectangle x1="11.45" y1="2.61" x2="11.87" y2="3.11" layer="51"/>
<rectangle x1="11.89" y1="2.61" x2="12.31" y2="3.11" layer="51"/>
<rectangle x1="12.33" y1="2.61" x2="12.75" y2="3.11" layer="51"/>
<rectangle x1="12.77" y1="2.61" x2="13.19" y2="3.11" layer="51"/>
<rectangle x1="13.21" y1="2.61" x2="13.63" y2="3.11" layer="51"/>
<rectangle x1="13.65" y1="2.61" x2="14.07" y2="3.11" layer="51"/>
<rectangle x1="14.09" y1="2.61" x2="14.51" y2="3.11" layer="51"/>
<rectangle x1="14.53" y1="2.61" x2="14.95" y2="3.11" layer="51"/>
<rectangle x1="14.97" y1="2.61" x2="15.39" y2="3.11" layer="51"/>
<rectangle x1="15.41" y1="2.61" x2="15.83" y2="3.11" layer="51"/>
<rectangle x1="15.85" y1="2.61" x2="16.27" y2="3.11" layer="51"/>
<rectangle x1="16.29" y1="2.61" x2="16.71" y2="3.11" layer="51"/>
<rectangle x1="16.73" y1="2.61" x2="17.15" y2="3.11" layer="51"/>
<rectangle x1="17.17" y1="2.61" x2="17.59" y2="3.11" layer="51"/>
<rectangle x1="17.61" y1="2.61" x2="18.03" y2="3.11" layer="51"/>
<rectangle x1="18.05" y1="2.61" x2="18.47" y2="3.11" layer="51"/>
<rectangle x1="18.49" y1="2.61" x2="18.91" y2="3.11" layer="51"/>
<rectangle x1="18.93" y1="2.61" x2="19.35" y2="3.11" layer="51"/>
<rectangle x1="19.37" y1="2.61" x2="19.79" y2="3.11" layer="51"/>
<rectangle x1="19.81" y1="2.61" x2="20.23" y2="3.11" layer="51"/>
<rectangle x1="20.25" y1="2.61" x2="20.67" y2="3.11" layer="51"/>
<rectangle x1="20.69" y1="2.61" x2="21.11" y2="3.11" layer="51"/>
<rectangle x1="21.13" y1="2.61" x2="21.55" y2="3.11" layer="51"/>
<rectangle x1="21.57" y1="2.61" x2="21.99" y2="3.11" layer="51"/>
<rectangle x1="22.01" y1="2.61" x2="22.43" y2="3.11" layer="51"/>
<rectangle x1="22.45" y1="2.61" x2="22.87" y2="3.11" layer="51"/>
<rectangle x1="22.89" y1="2.61" x2="23.31" y2="3.11" layer="51"/>
<rectangle x1="23.33" y1="2.61" x2="23.75" y2="3.11" layer="51"/>
<rectangle x1="23.77" y1="2.61" x2="24.19" y2="3.11" layer="51"/>
<rectangle x1="24.21" y1="2.61" x2="24.63" y2="3.11" layer="51"/>
<rectangle x1="24.65" y1="2.61" x2="25.07" y2="3.11" layer="51"/>
<rectangle x1="25.09" y1="2.61" x2="25.51" y2="3.11" layer="51"/>
<rectangle x1="25.53" y1="2.61" x2="25.95" y2="3.11" layer="51"/>
<rectangle x1="25.97" y1="2.61" x2="26.39" y2="3.11" layer="51"/>
<rectangle x1="26.41" y1="2.61" x2="26.83" y2="3.11" layer="51"/>
<rectangle x1="26.85" y1="2.61" x2="27.27" y2="3.11" layer="51"/>
<rectangle x1="27.29" y1="2.61" x2="27.71" y2="3.11" layer="51"/>
<rectangle x1="27.73" y1="2.61" x2="28.15" y2="3.11" layer="51"/>
<rectangle x1="-28.15" y1="2.09" x2="-27.73" y2="2.59" layer="51"/>
<rectangle x1="-27.71" y1="2.09" x2="-27.29" y2="2.59" layer="51"/>
<rectangle x1="-27.27" y1="2.09" x2="-26.85" y2="2.59" layer="51"/>
<rectangle x1="-26.83" y1="2.09" x2="-26.41" y2="2.59" layer="51"/>
<rectangle x1="-26.39" y1="2.09" x2="-25.97" y2="2.59" layer="51"/>
<rectangle x1="-25.95" y1="2.09" x2="-25.53" y2="2.59" layer="51"/>
<rectangle x1="-25.51" y1="2.09" x2="-25.09" y2="2.59" layer="51"/>
<rectangle x1="-25.07" y1="2.09" x2="-24.65" y2="2.59" layer="51"/>
<rectangle x1="-24.63" y1="2.09" x2="-24.21" y2="2.59" layer="51"/>
<rectangle x1="-24.19" y1="2.09" x2="-23.77" y2="2.59" layer="51"/>
<rectangle x1="-23.75" y1="2.09" x2="-23.33" y2="2.59" layer="51"/>
<rectangle x1="-23.31" y1="2.09" x2="-22.89" y2="2.59" layer="51"/>
<rectangle x1="-22.87" y1="2.09" x2="-22.45" y2="2.59" layer="51"/>
<rectangle x1="-22.43" y1="2.09" x2="-22.01" y2="2.59" layer="51"/>
<rectangle x1="-21.99" y1="2.09" x2="-21.57" y2="2.59" layer="51"/>
<rectangle x1="-21.55" y1="2.09" x2="-21.13" y2="2.59" layer="51"/>
<rectangle x1="-21.11" y1="2.09" x2="-20.69" y2="2.59" layer="51"/>
<rectangle x1="-20.67" y1="2.09" x2="-20.25" y2="2.59" layer="51"/>
<rectangle x1="-20.23" y1="2.09" x2="-19.81" y2="2.59" layer="51"/>
<rectangle x1="-19.79" y1="2.09" x2="-19.37" y2="2.59" layer="51"/>
<rectangle x1="-19.35" y1="2.09" x2="-18.93" y2="2.59" layer="51"/>
<rectangle x1="-18.91" y1="2.09" x2="-18.49" y2="2.59" layer="51"/>
<rectangle x1="-18.47" y1="2.09" x2="-18.05" y2="2.59" layer="51"/>
<rectangle x1="-18.03" y1="2.09" x2="-17.61" y2="2.59" layer="51"/>
<rectangle x1="-17.59" y1="2.09" x2="-17.17" y2="2.59" layer="51"/>
<rectangle x1="-17.15" y1="2.09" x2="-16.73" y2="2.59" layer="51"/>
<rectangle x1="-16.71" y1="2.09" x2="-16.29" y2="2.59" layer="51"/>
<rectangle x1="-16.27" y1="2.09" x2="-15.85" y2="2.59" layer="51"/>
<rectangle x1="-15.83" y1="2.09" x2="-15.41" y2="2.59" layer="51"/>
<rectangle x1="-15.39" y1="2.09" x2="-14.97" y2="2.59" layer="51"/>
<rectangle x1="-14.95" y1="2.09" x2="-14.53" y2="2.59" layer="51"/>
<rectangle x1="-14.51" y1="2.09" x2="-14.09" y2="2.59" layer="51"/>
<rectangle x1="-14.07" y1="2.09" x2="-13.65" y2="2.59" layer="51"/>
<rectangle x1="-13.63" y1="2.09" x2="-13.21" y2="2.59" layer="51"/>
<rectangle x1="-13.19" y1="2.09" x2="-12.77" y2="2.59" layer="51"/>
<rectangle x1="-12.75" y1="2.09" x2="-12.33" y2="2.59" layer="51"/>
<rectangle x1="-12.31" y1="2.09" x2="-11.89" y2="2.59" layer="51"/>
<rectangle x1="-11.87" y1="2.09" x2="-11.45" y2="2.59" layer="51"/>
<rectangle x1="-11.43" y1="2.09" x2="-11.01" y2="2.59" layer="51"/>
<rectangle x1="-10.99" y1="2.09" x2="-10.57" y2="2.59" layer="51"/>
<rectangle x1="-10.55" y1="2.09" x2="-10.13" y2="2.59" layer="51"/>
<rectangle x1="-10.11" y1="2.09" x2="-9.69" y2="2.59" layer="51"/>
<rectangle x1="-9.67" y1="2.09" x2="-9.25" y2="2.59" layer="51"/>
<rectangle x1="-9.23" y1="2.09" x2="-8.81" y2="2.59" layer="51"/>
<rectangle x1="-8.79" y1="2.09" x2="-8.37" y2="2.59" layer="51"/>
<rectangle x1="-8.35" y1="2.09" x2="-7.93" y2="2.59" layer="51"/>
<rectangle x1="-7.91" y1="2.09" x2="-7.49" y2="2.59" layer="51"/>
<rectangle x1="-7.47" y1="2.09" x2="-7.05" y2="2.59" layer="51"/>
<rectangle x1="-7.03" y1="2.09" x2="-6.61" y2="2.59" layer="51"/>
<rectangle x1="-6.59" y1="2.09" x2="-6.17" y2="2.59" layer="51"/>
<rectangle x1="-6.15" y1="2.09" x2="-5.73" y2="2.59" layer="51"/>
<rectangle x1="-5.71" y1="2.09" x2="-5.29" y2="2.59" layer="51"/>
<rectangle x1="-5.27" y1="2.09" x2="-4.85" y2="2.59" layer="51"/>
<rectangle x1="-4.83" y1="2.09" x2="-4.41" y2="2.59" layer="51"/>
<rectangle x1="-4.39" y1="2.09" x2="-3.97" y2="2.59" layer="51"/>
<rectangle x1="-3.95" y1="2.09" x2="-3.53" y2="2.59" layer="51"/>
<rectangle x1="-3.51" y1="2.09" x2="-3.09" y2="2.59" layer="51"/>
<rectangle x1="-3.07" y1="2.09" x2="-2.65" y2="2.59" layer="51"/>
<rectangle x1="-2.63" y1="2.09" x2="-2.21" y2="2.59" layer="51"/>
<rectangle x1="-2.19" y1="2.09" x2="-1.77" y2="2.59" layer="51"/>
<rectangle x1="-1.75" y1="2.09" x2="-1.33" y2="2.59" layer="51"/>
<rectangle x1="-1.31" y1="2.09" x2="-0.89" y2="2.59" layer="51"/>
<rectangle x1="-0.87" y1="2.09" x2="-0.45" y2="2.59" layer="51"/>
<rectangle x1="-0.43" y1="2.09" x2="-0.01" y2="2.59" layer="51"/>
<rectangle x1="0.01" y1="2.09" x2="0.43" y2="2.59" layer="51"/>
<rectangle x1="0.45" y1="2.09" x2="0.87" y2="2.59" layer="51"/>
<rectangle x1="0.89" y1="2.09" x2="1.31" y2="2.59" layer="51"/>
<rectangle x1="1.33" y1="2.09" x2="1.75" y2="2.59" layer="51"/>
<rectangle x1="1.77" y1="2.09" x2="2.19" y2="2.59" layer="51"/>
<rectangle x1="2.21" y1="2.09" x2="2.63" y2="2.59" layer="51"/>
<rectangle x1="2.65" y1="2.09" x2="3.07" y2="2.59" layer="51"/>
<rectangle x1="3.09" y1="2.09" x2="3.51" y2="2.59" layer="51"/>
<rectangle x1="3.53" y1="2.09" x2="3.95" y2="2.59" layer="51"/>
<rectangle x1="3.97" y1="2.09" x2="4.39" y2="2.59" layer="51"/>
<rectangle x1="4.41" y1="2.09" x2="4.83" y2="2.59" layer="51"/>
<rectangle x1="4.85" y1="2.09" x2="5.27" y2="2.59" layer="51"/>
<rectangle x1="5.29" y1="2.09" x2="5.71" y2="2.59" layer="51"/>
<rectangle x1="5.73" y1="2.09" x2="6.15" y2="2.59" layer="51"/>
<rectangle x1="6.17" y1="2.09" x2="6.59" y2="2.59" layer="51"/>
<rectangle x1="6.61" y1="2.09" x2="7.03" y2="2.59" layer="51"/>
<rectangle x1="7.05" y1="2.09" x2="7.47" y2="2.59" layer="51"/>
<rectangle x1="7.49" y1="2.09" x2="7.91" y2="2.59" layer="51"/>
<rectangle x1="7.93" y1="2.09" x2="8.35" y2="2.59" layer="51"/>
<rectangle x1="8.37" y1="2.09" x2="8.79" y2="2.59" layer="51"/>
<rectangle x1="8.81" y1="2.09" x2="9.23" y2="2.59" layer="51"/>
<rectangle x1="9.25" y1="2.09" x2="9.67" y2="2.59" layer="51"/>
<rectangle x1="9.69" y1="2.09" x2="10.11" y2="2.59" layer="51"/>
<rectangle x1="10.13" y1="2.09" x2="10.55" y2="2.59" layer="51"/>
<rectangle x1="10.57" y1="2.09" x2="10.99" y2="2.59" layer="51"/>
<rectangle x1="11.01" y1="2.09" x2="11.43" y2="2.59" layer="51"/>
<rectangle x1="11.45" y1="2.09" x2="11.87" y2="2.59" layer="51"/>
<rectangle x1="11.89" y1="2.09" x2="12.31" y2="2.59" layer="51"/>
<rectangle x1="12.33" y1="2.09" x2="12.75" y2="2.59" layer="51"/>
<rectangle x1="12.77" y1="2.09" x2="13.19" y2="2.59" layer="51"/>
<rectangle x1="13.21" y1="2.09" x2="13.63" y2="2.59" layer="51"/>
<rectangle x1="13.65" y1="2.09" x2="14.07" y2="2.59" layer="51"/>
<rectangle x1="14.09" y1="2.09" x2="14.51" y2="2.59" layer="51"/>
<rectangle x1="14.53" y1="2.09" x2="14.95" y2="2.59" layer="51"/>
<rectangle x1="14.97" y1="2.09" x2="15.39" y2="2.59" layer="51"/>
<rectangle x1="15.41" y1="2.09" x2="15.83" y2="2.59" layer="51"/>
<rectangle x1="15.85" y1="2.09" x2="16.27" y2="2.59" layer="51"/>
<rectangle x1="16.29" y1="2.09" x2="16.71" y2="2.59" layer="51"/>
<rectangle x1="16.73" y1="2.09" x2="17.15" y2="2.59" layer="51"/>
<rectangle x1="17.17" y1="2.09" x2="17.59" y2="2.59" layer="51"/>
<rectangle x1="17.61" y1="2.09" x2="18.03" y2="2.59" layer="51"/>
<rectangle x1="18.05" y1="2.09" x2="18.47" y2="2.59" layer="51"/>
<rectangle x1="18.49" y1="2.09" x2="18.91" y2="2.59" layer="51"/>
<rectangle x1="18.93" y1="2.09" x2="19.35" y2="2.59" layer="51"/>
<rectangle x1="19.37" y1="2.09" x2="19.79" y2="2.59" layer="51"/>
<rectangle x1="19.81" y1="2.09" x2="20.23" y2="2.59" layer="51"/>
<rectangle x1="20.25" y1="2.09" x2="20.67" y2="2.59" layer="51"/>
<rectangle x1="20.69" y1="2.09" x2="21.11" y2="2.59" layer="51"/>
<rectangle x1="21.13" y1="2.09" x2="21.55" y2="2.59" layer="51"/>
<rectangle x1="21.57" y1="2.09" x2="21.99" y2="2.59" layer="51"/>
<rectangle x1="22.01" y1="2.09" x2="22.43" y2="2.59" layer="51"/>
<rectangle x1="22.45" y1="2.09" x2="22.87" y2="2.59" layer="51"/>
<rectangle x1="22.89" y1="2.09" x2="23.31" y2="2.59" layer="51"/>
<rectangle x1="23.33" y1="2.09" x2="23.75" y2="2.59" layer="51"/>
<rectangle x1="23.77" y1="2.09" x2="24.19" y2="2.59" layer="51"/>
<rectangle x1="24.21" y1="2.09" x2="24.63" y2="2.59" layer="51"/>
<rectangle x1="24.65" y1="2.09" x2="25.07" y2="2.59" layer="51"/>
<rectangle x1="25.09" y1="2.09" x2="25.51" y2="2.59" layer="51"/>
<rectangle x1="25.53" y1="2.09" x2="25.95" y2="2.59" layer="51"/>
<rectangle x1="25.97" y1="2.09" x2="26.39" y2="2.59" layer="51"/>
<rectangle x1="26.41" y1="2.09" x2="26.83" y2="2.59" layer="51"/>
<rectangle x1="26.85" y1="2.09" x2="27.27" y2="2.59" layer="51"/>
<rectangle x1="27.29" y1="2.09" x2="27.71" y2="2.59" layer="51"/>
<rectangle x1="27.73" y1="2.09" x2="28.15" y2="2.59" layer="51"/>
<rectangle x1="-28.15" y1="1.57" x2="-27.73" y2="2.07" layer="51"/>
<rectangle x1="-27.71" y1="1.57" x2="-27.29" y2="2.07" layer="51"/>
<rectangle x1="-27.27" y1="1.57" x2="-26.85" y2="2.07" layer="51"/>
<rectangle x1="-26.83" y1="1.57" x2="-26.41" y2="2.07" layer="51"/>
<rectangle x1="-26.39" y1="1.57" x2="-25.97" y2="2.07" layer="51"/>
<rectangle x1="-25.95" y1="1.57" x2="-25.53" y2="2.07" layer="51"/>
<rectangle x1="-25.51" y1="1.57" x2="-25.09" y2="2.07" layer="51"/>
<rectangle x1="-25.07" y1="1.57" x2="-24.65" y2="2.07" layer="51"/>
<rectangle x1="-24.63" y1="1.57" x2="-24.21" y2="2.07" layer="51"/>
<rectangle x1="-24.19" y1="1.57" x2="-23.77" y2="2.07" layer="51"/>
<rectangle x1="-23.75" y1="1.57" x2="-23.33" y2="2.07" layer="51"/>
<rectangle x1="-23.31" y1="1.57" x2="-22.89" y2="2.07" layer="51"/>
<rectangle x1="-22.87" y1="1.57" x2="-22.45" y2="2.07" layer="51"/>
<rectangle x1="-22.43" y1="1.57" x2="-22.01" y2="2.07" layer="51"/>
<rectangle x1="-21.99" y1="1.57" x2="-21.57" y2="2.07" layer="51"/>
<rectangle x1="-21.55" y1="1.57" x2="-21.13" y2="2.07" layer="51"/>
<rectangle x1="-21.11" y1="1.57" x2="-20.69" y2="2.07" layer="51"/>
<rectangle x1="-20.67" y1="1.57" x2="-20.25" y2="2.07" layer="51"/>
<rectangle x1="-20.23" y1="1.57" x2="-19.81" y2="2.07" layer="51"/>
<rectangle x1="-19.79" y1="1.57" x2="-19.37" y2="2.07" layer="51"/>
<rectangle x1="-19.35" y1="1.57" x2="-18.93" y2="2.07" layer="51"/>
<rectangle x1="-18.91" y1="1.57" x2="-18.49" y2="2.07" layer="51"/>
<rectangle x1="-18.47" y1="1.57" x2="-18.05" y2="2.07" layer="51"/>
<rectangle x1="-18.03" y1="1.57" x2="-17.61" y2="2.07" layer="51"/>
<rectangle x1="-17.59" y1="1.57" x2="-17.17" y2="2.07" layer="51"/>
<rectangle x1="-17.15" y1="1.57" x2="-16.73" y2="2.07" layer="51"/>
<rectangle x1="-16.71" y1="1.57" x2="-16.29" y2="2.07" layer="51"/>
<rectangle x1="-16.27" y1="1.57" x2="-15.85" y2="2.07" layer="51"/>
<rectangle x1="-15.83" y1="1.57" x2="-15.41" y2="2.07" layer="51"/>
<rectangle x1="-15.39" y1="1.57" x2="-14.97" y2="2.07" layer="51"/>
<rectangle x1="-14.95" y1="1.57" x2="-14.53" y2="2.07" layer="51"/>
<rectangle x1="-14.51" y1="1.57" x2="-14.09" y2="2.07" layer="51"/>
<rectangle x1="-14.07" y1="1.57" x2="-13.65" y2="2.07" layer="51"/>
<rectangle x1="-13.63" y1="1.57" x2="-13.21" y2="2.07" layer="51"/>
<rectangle x1="-13.19" y1="1.57" x2="-12.77" y2="2.07" layer="51"/>
<rectangle x1="-12.75" y1="1.57" x2="-12.33" y2="2.07" layer="51"/>
<rectangle x1="-12.31" y1="1.57" x2="-11.89" y2="2.07" layer="51"/>
<rectangle x1="-11.87" y1="1.57" x2="-11.45" y2="2.07" layer="51"/>
<rectangle x1="-11.43" y1="1.57" x2="-11.01" y2="2.07" layer="51"/>
<rectangle x1="-10.99" y1="1.57" x2="-10.57" y2="2.07" layer="51"/>
<rectangle x1="-10.55" y1="1.57" x2="-10.13" y2="2.07" layer="51"/>
<rectangle x1="-10.11" y1="1.57" x2="-9.69" y2="2.07" layer="51"/>
<rectangle x1="-9.67" y1="1.57" x2="-9.25" y2="2.07" layer="51"/>
<rectangle x1="-9.23" y1="1.57" x2="-8.81" y2="2.07" layer="51"/>
<rectangle x1="-8.79" y1="1.57" x2="-8.37" y2="2.07" layer="51"/>
<rectangle x1="-8.35" y1="1.57" x2="-7.93" y2="2.07" layer="51"/>
<rectangle x1="-7.91" y1="1.57" x2="-7.49" y2="2.07" layer="51"/>
<rectangle x1="-7.47" y1="1.57" x2="-7.05" y2="2.07" layer="51"/>
<rectangle x1="-7.03" y1="1.57" x2="-6.61" y2="2.07" layer="51"/>
<rectangle x1="-6.59" y1="1.57" x2="-6.17" y2="2.07" layer="51"/>
<rectangle x1="-6.15" y1="1.57" x2="-5.73" y2="2.07" layer="51"/>
<rectangle x1="-5.71" y1="1.57" x2="-5.29" y2="2.07" layer="51"/>
<rectangle x1="-5.27" y1="1.57" x2="-4.85" y2="2.07" layer="51"/>
<rectangle x1="-4.83" y1="1.57" x2="-4.41" y2="2.07" layer="51"/>
<rectangle x1="-4.39" y1="1.57" x2="-3.97" y2="2.07" layer="51"/>
<rectangle x1="-3.95" y1="1.57" x2="-3.53" y2="2.07" layer="51"/>
<rectangle x1="-3.51" y1="1.57" x2="-3.09" y2="2.07" layer="51"/>
<rectangle x1="-3.07" y1="1.57" x2="-2.65" y2="2.07" layer="51"/>
<rectangle x1="-2.63" y1="1.57" x2="-2.21" y2="2.07" layer="51"/>
<rectangle x1="-2.19" y1="1.57" x2="-1.77" y2="2.07" layer="51"/>
<rectangle x1="-1.75" y1="1.57" x2="-1.33" y2="2.07" layer="51"/>
<rectangle x1="-1.31" y1="1.57" x2="-0.89" y2="2.07" layer="51"/>
<rectangle x1="-0.87" y1="1.57" x2="-0.45" y2="2.07" layer="51"/>
<rectangle x1="-0.43" y1="1.57" x2="-0.01" y2="2.07" layer="51"/>
<rectangle x1="0.01" y1="1.57" x2="0.43" y2="2.07" layer="51"/>
<rectangle x1="0.45" y1="1.57" x2="0.87" y2="2.07" layer="51"/>
<rectangle x1="0.89" y1="1.57" x2="1.31" y2="2.07" layer="51"/>
<rectangle x1="1.33" y1="1.57" x2="1.75" y2="2.07" layer="51"/>
<rectangle x1="1.77" y1="1.57" x2="2.19" y2="2.07" layer="51"/>
<rectangle x1="2.21" y1="1.57" x2="2.63" y2="2.07" layer="51"/>
<rectangle x1="2.65" y1="1.57" x2="3.07" y2="2.07" layer="51"/>
<rectangle x1="3.09" y1="1.57" x2="3.51" y2="2.07" layer="51"/>
<rectangle x1="3.53" y1="1.57" x2="3.95" y2="2.07" layer="51"/>
<rectangle x1="3.97" y1="1.57" x2="4.39" y2="2.07" layer="51"/>
<rectangle x1="4.41" y1="1.57" x2="4.83" y2="2.07" layer="51"/>
<rectangle x1="4.85" y1="1.57" x2="5.27" y2="2.07" layer="51"/>
<rectangle x1="5.29" y1="1.57" x2="5.71" y2="2.07" layer="51"/>
<rectangle x1="5.73" y1="1.57" x2="6.15" y2="2.07" layer="51"/>
<rectangle x1="6.17" y1="1.57" x2="6.59" y2="2.07" layer="51"/>
<rectangle x1="6.61" y1="1.57" x2="7.03" y2="2.07" layer="51"/>
<rectangle x1="7.05" y1="1.57" x2="7.47" y2="2.07" layer="51"/>
<rectangle x1="7.49" y1="1.57" x2="7.91" y2="2.07" layer="51"/>
<rectangle x1="7.93" y1="1.57" x2="8.35" y2="2.07" layer="51"/>
<rectangle x1="8.37" y1="1.57" x2="8.79" y2="2.07" layer="51"/>
<rectangle x1="8.81" y1="1.57" x2="9.23" y2="2.07" layer="51"/>
<rectangle x1="9.25" y1="1.57" x2="9.67" y2="2.07" layer="51"/>
<rectangle x1="9.69" y1="1.57" x2="10.11" y2="2.07" layer="51"/>
<rectangle x1="10.13" y1="1.57" x2="10.55" y2="2.07" layer="51"/>
<rectangle x1="10.57" y1="1.57" x2="10.99" y2="2.07" layer="51"/>
<rectangle x1="11.01" y1="1.57" x2="11.43" y2="2.07" layer="51"/>
<rectangle x1="11.45" y1="1.57" x2="11.87" y2="2.07" layer="51"/>
<rectangle x1="11.89" y1="1.57" x2="12.31" y2="2.07" layer="51"/>
<rectangle x1="12.33" y1="1.57" x2="12.75" y2="2.07" layer="51"/>
<rectangle x1="12.77" y1="1.57" x2="13.19" y2="2.07" layer="51"/>
<rectangle x1="13.21" y1="1.57" x2="13.63" y2="2.07" layer="51"/>
<rectangle x1="13.65" y1="1.57" x2="14.07" y2="2.07" layer="51"/>
<rectangle x1="14.09" y1="1.57" x2="14.51" y2="2.07" layer="51"/>
<rectangle x1="14.53" y1="1.57" x2="14.95" y2="2.07" layer="51"/>
<rectangle x1="14.97" y1="1.57" x2="15.39" y2="2.07" layer="51"/>
<rectangle x1="15.41" y1="1.57" x2="15.83" y2="2.07" layer="51"/>
<rectangle x1="15.85" y1="1.57" x2="16.27" y2="2.07" layer="51"/>
<rectangle x1="16.29" y1="1.57" x2="16.71" y2="2.07" layer="51"/>
<rectangle x1="16.73" y1="1.57" x2="17.15" y2="2.07" layer="51"/>
<rectangle x1="17.17" y1="1.57" x2="17.59" y2="2.07" layer="51"/>
<rectangle x1="17.61" y1="1.57" x2="18.03" y2="2.07" layer="51"/>
<rectangle x1="18.05" y1="1.57" x2="18.47" y2="2.07" layer="51"/>
<rectangle x1="18.49" y1="1.57" x2="18.91" y2="2.07" layer="51"/>
<rectangle x1="18.93" y1="1.57" x2="19.35" y2="2.07" layer="51"/>
<rectangle x1="19.37" y1="1.57" x2="19.79" y2="2.07" layer="51"/>
<rectangle x1="19.81" y1="1.57" x2="20.23" y2="2.07" layer="51"/>
<rectangle x1="20.25" y1="1.57" x2="20.67" y2="2.07" layer="51"/>
<rectangle x1="20.69" y1="1.57" x2="21.11" y2="2.07" layer="51"/>
<rectangle x1="21.13" y1="1.57" x2="21.55" y2="2.07" layer="51"/>
<rectangle x1="21.57" y1="1.57" x2="21.99" y2="2.07" layer="51"/>
<rectangle x1="22.01" y1="1.57" x2="22.43" y2="2.07" layer="51"/>
<rectangle x1="22.45" y1="1.57" x2="22.87" y2="2.07" layer="51"/>
<rectangle x1="22.89" y1="1.57" x2="23.31" y2="2.07" layer="51"/>
<rectangle x1="23.33" y1="1.57" x2="23.75" y2="2.07" layer="51"/>
<rectangle x1="23.77" y1="1.57" x2="24.19" y2="2.07" layer="51"/>
<rectangle x1="24.21" y1="1.57" x2="24.63" y2="2.07" layer="51"/>
<rectangle x1="24.65" y1="1.57" x2="25.07" y2="2.07" layer="51"/>
<rectangle x1="25.09" y1="1.57" x2="25.51" y2="2.07" layer="51"/>
<rectangle x1="25.53" y1="1.57" x2="25.95" y2="2.07" layer="51"/>
<rectangle x1="25.97" y1="1.57" x2="26.39" y2="2.07" layer="51"/>
<rectangle x1="26.41" y1="1.57" x2="26.83" y2="2.07" layer="51"/>
<rectangle x1="26.85" y1="1.57" x2="27.27" y2="2.07" layer="51"/>
<rectangle x1="27.29" y1="1.57" x2="27.71" y2="2.07" layer="51"/>
<rectangle x1="27.73" y1="1.57" x2="28.15" y2="2.07" layer="51"/>
<rectangle x1="-28.15" y1="1.05" x2="-27.73" y2="1.55" layer="51"/>
<rectangle x1="-27.71" y1="1.05" x2="-27.29" y2="1.55" layer="51"/>
<rectangle x1="-27.27" y1="1.05" x2="-26.85" y2="1.55" layer="51"/>
<rectangle x1="-26.83" y1="1.05" x2="-26.41" y2="1.55" layer="51"/>
<rectangle x1="-26.39" y1="1.05" x2="-25.97" y2="1.55" layer="51"/>
<rectangle x1="-25.95" y1="1.05" x2="-25.53" y2="1.55" layer="51"/>
<rectangle x1="-25.51" y1="1.05" x2="-25.09" y2="1.55" layer="51"/>
<rectangle x1="-25.07" y1="1.05" x2="-24.65" y2="1.55" layer="51"/>
<rectangle x1="-24.63" y1="1.05" x2="-24.21" y2="1.55" layer="51"/>
<rectangle x1="-24.19" y1="1.05" x2="-23.77" y2="1.55" layer="51"/>
<rectangle x1="-23.75" y1="1.05" x2="-23.33" y2="1.55" layer="51"/>
<rectangle x1="-23.31" y1="1.05" x2="-22.89" y2="1.55" layer="51"/>
<rectangle x1="-22.87" y1="1.05" x2="-22.45" y2="1.55" layer="51"/>
<rectangle x1="-22.43" y1="1.05" x2="-22.01" y2="1.55" layer="51"/>
<rectangle x1="-21.99" y1="1.05" x2="-21.57" y2="1.55" layer="51"/>
<rectangle x1="-21.55" y1="1.05" x2="-21.13" y2="1.55" layer="51"/>
<rectangle x1="-21.11" y1="1.05" x2="-20.69" y2="1.55" layer="51"/>
<rectangle x1="-20.67" y1="1.05" x2="-20.25" y2="1.55" layer="51"/>
<rectangle x1="-20.23" y1="1.05" x2="-19.81" y2="1.55" layer="51"/>
<rectangle x1="-19.79" y1="1.05" x2="-19.37" y2="1.55" layer="51"/>
<rectangle x1="-19.35" y1="1.05" x2="-18.93" y2="1.55" layer="51"/>
<rectangle x1="-18.91" y1="1.05" x2="-18.49" y2="1.55" layer="51"/>
<rectangle x1="-18.47" y1="1.05" x2="-18.05" y2="1.55" layer="51"/>
<rectangle x1="-18.03" y1="1.05" x2="-17.61" y2="1.55" layer="51"/>
<rectangle x1="-17.59" y1="1.05" x2="-17.17" y2="1.55" layer="51"/>
<rectangle x1="-17.15" y1="1.05" x2="-16.73" y2="1.55" layer="51"/>
<rectangle x1="-16.71" y1="1.05" x2="-16.29" y2="1.55" layer="51"/>
<rectangle x1="-16.27" y1="1.05" x2="-15.85" y2="1.55" layer="51"/>
<rectangle x1="-15.83" y1="1.05" x2="-15.41" y2="1.55" layer="51"/>
<rectangle x1="-15.39" y1="1.05" x2="-14.97" y2="1.55" layer="51"/>
<rectangle x1="-14.95" y1="1.05" x2="-14.53" y2="1.55" layer="51"/>
<rectangle x1="-14.51" y1="1.05" x2="-14.09" y2="1.55" layer="51"/>
<rectangle x1="-14.07" y1="1.05" x2="-13.65" y2="1.55" layer="51"/>
<rectangle x1="-13.63" y1="1.05" x2="-13.21" y2="1.55" layer="51"/>
<rectangle x1="-13.19" y1="1.05" x2="-12.77" y2="1.55" layer="51"/>
<rectangle x1="-12.75" y1="1.05" x2="-12.33" y2="1.55" layer="51"/>
<rectangle x1="-12.31" y1="1.05" x2="-11.89" y2="1.55" layer="51"/>
<rectangle x1="-11.87" y1="1.05" x2="-11.45" y2="1.55" layer="51"/>
<rectangle x1="-11.43" y1="1.05" x2="-11.01" y2="1.55" layer="51"/>
<rectangle x1="-10.99" y1="1.05" x2="-10.57" y2="1.55" layer="51"/>
<rectangle x1="-10.55" y1="1.05" x2="-10.13" y2="1.55" layer="51"/>
<rectangle x1="-10.11" y1="1.05" x2="-9.69" y2="1.55" layer="51"/>
<rectangle x1="-9.67" y1="1.05" x2="-9.25" y2="1.55" layer="51"/>
<rectangle x1="-9.23" y1="1.05" x2="-8.81" y2="1.55" layer="51"/>
<rectangle x1="-8.79" y1="1.05" x2="-8.37" y2="1.55" layer="51"/>
<rectangle x1="-8.35" y1="1.05" x2="-7.93" y2="1.55" layer="51"/>
<rectangle x1="-7.91" y1="1.05" x2="-7.49" y2="1.55" layer="51"/>
<rectangle x1="-7.47" y1="1.05" x2="-7.05" y2="1.55" layer="51"/>
<rectangle x1="-7.03" y1="1.05" x2="-6.61" y2="1.55" layer="51"/>
<rectangle x1="-6.59" y1="1.05" x2="-6.17" y2="1.55" layer="51"/>
<rectangle x1="-6.15" y1="1.05" x2="-5.73" y2="1.55" layer="51"/>
<rectangle x1="-5.71" y1="1.05" x2="-5.29" y2="1.55" layer="51"/>
<rectangle x1="-5.27" y1="1.05" x2="-4.85" y2="1.55" layer="51"/>
<rectangle x1="-4.83" y1="1.05" x2="-4.41" y2="1.55" layer="51"/>
<rectangle x1="-4.39" y1="1.05" x2="-3.97" y2="1.55" layer="51"/>
<rectangle x1="-3.95" y1="1.05" x2="-3.53" y2="1.55" layer="51"/>
<rectangle x1="-3.51" y1="1.05" x2="-3.09" y2="1.55" layer="51"/>
<rectangle x1="-3.07" y1="1.05" x2="-2.65" y2="1.55" layer="51"/>
<rectangle x1="-2.63" y1="1.05" x2="-2.21" y2="1.55" layer="51"/>
<rectangle x1="-2.19" y1="1.05" x2="-1.77" y2="1.55" layer="51"/>
<rectangle x1="-1.75" y1="1.05" x2="-1.33" y2="1.55" layer="51"/>
<rectangle x1="-1.31" y1="1.05" x2="-0.89" y2="1.55" layer="51"/>
<rectangle x1="-0.87" y1="1.05" x2="-0.45" y2="1.55" layer="51"/>
<rectangle x1="-0.43" y1="1.05" x2="-0.01" y2="1.55" layer="51"/>
<rectangle x1="0.01" y1="1.05" x2="0.43" y2="1.55" layer="51"/>
<rectangle x1="0.45" y1="1.05" x2="0.87" y2="1.55" layer="51"/>
<rectangle x1="0.89" y1="1.05" x2="1.31" y2="1.55" layer="51"/>
<rectangle x1="1.33" y1="1.05" x2="1.75" y2="1.55" layer="51"/>
<rectangle x1="1.77" y1="1.05" x2="2.19" y2="1.55" layer="51"/>
<rectangle x1="2.21" y1="1.05" x2="2.63" y2="1.55" layer="51"/>
<rectangle x1="2.65" y1="1.05" x2="3.07" y2="1.55" layer="51"/>
<rectangle x1="3.09" y1="1.05" x2="3.51" y2="1.55" layer="51"/>
<rectangle x1="3.53" y1="1.05" x2="3.95" y2="1.55" layer="51"/>
<rectangle x1="3.97" y1="1.05" x2="4.39" y2="1.55" layer="51"/>
<rectangle x1="4.41" y1="1.05" x2="4.83" y2="1.55" layer="51"/>
<rectangle x1="4.85" y1="1.05" x2="5.27" y2="1.55" layer="51"/>
<rectangle x1="5.29" y1="1.05" x2="5.71" y2="1.55" layer="51"/>
<rectangle x1="5.73" y1="1.05" x2="6.15" y2="1.55" layer="51"/>
<rectangle x1="6.17" y1="1.05" x2="6.59" y2="1.55" layer="51"/>
<rectangle x1="6.61" y1="1.05" x2="7.03" y2="1.55" layer="51"/>
<rectangle x1="7.05" y1="1.05" x2="7.47" y2="1.55" layer="51"/>
<rectangle x1="7.49" y1="1.05" x2="7.91" y2="1.55" layer="51"/>
<rectangle x1="7.93" y1="1.05" x2="8.35" y2="1.55" layer="51"/>
<rectangle x1="8.37" y1="1.05" x2="8.79" y2="1.55" layer="51"/>
<rectangle x1="8.81" y1="1.05" x2="9.23" y2="1.55" layer="51"/>
<rectangle x1="9.25" y1="1.05" x2="9.67" y2="1.55" layer="51"/>
<rectangle x1="9.69" y1="1.05" x2="10.11" y2="1.55" layer="51"/>
<rectangle x1="10.13" y1="1.05" x2="10.55" y2="1.55" layer="51"/>
<rectangle x1="10.57" y1="1.05" x2="10.99" y2="1.55" layer="51"/>
<rectangle x1="11.01" y1="1.05" x2="11.43" y2="1.55" layer="51"/>
<rectangle x1="11.45" y1="1.05" x2="11.87" y2="1.55" layer="51"/>
<rectangle x1="11.89" y1="1.05" x2="12.31" y2="1.55" layer="51"/>
<rectangle x1="12.33" y1="1.05" x2="12.75" y2="1.55" layer="51"/>
<rectangle x1="12.77" y1="1.05" x2="13.19" y2="1.55" layer="51"/>
<rectangle x1="13.21" y1="1.05" x2="13.63" y2="1.55" layer="51"/>
<rectangle x1="13.65" y1="1.05" x2="14.07" y2="1.55" layer="51"/>
<rectangle x1="14.09" y1="1.05" x2="14.51" y2="1.55" layer="51"/>
<rectangle x1="14.53" y1="1.05" x2="14.95" y2="1.55" layer="51"/>
<rectangle x1="14.97" y1="1.05" x2="15.39" y2="1.55" layer="51"/>
<rectangle x1="15.41" y1="1.05" x2="15.83" y2="1.55" layer="51"/>
<rectangle x1="15.85" y1="1.05" x2="16.27" y2="1.55" layer="51"/>
<rectangle x1="16.29" y1="1.05" x2="16.71" y2="1.55" layer="51"/>
<rectangle x1="16.73" y1="1.05" x2="17.15" y2="1.55" layer="51"/>
<rectangle x1="17.17" y1="1.05" x2="17.59" y2="1.55" layer="51"/>
<rectangle x1="17.61" y1="1.05" x2="18.03" y2="1.55" layer="51"/>
<rectangle x1="18.05" y1="1.05" x2="18.47" y2="1.55" layer="51"/>
<rectangle x1="18.49" y1="1.05" x2="18.91" y2="1.55" layer="51"/>
<rectangle x1="18.93" y1="1.05" x2="19.35" y2="1.55" layer="51"/>
<rectangle x1="19.37" y1="1.05" x2="19.79" y2="1.55" layer="51"/>
<rectangle x1="19.81" y1="1.05" x2="20.23" y2="1.55" layer="51"/>
<rectangle x1="20.25" y1="1.05" x2="20.67" y2="1.55" layer="51"/>
<rectangle x1="20.69" y1="1.05" x2="21.11" y2="1.55" layer="51"/>
<rectangle x1="21.13" y1="1.05" x2="21.55" y2="1.55" layer="51"/>
<rectangle x1="21.57" y1="1.05" x2="21.99" y2="1.55" layer="51"/>
<rectangle x1="22.01" y1="1.05" x2="22.43" y2="1.55" layer="51"/>
<rectangle x1="22.45" y1="1.05" x2="22.87" y2="1.55" layer="51"/>
<rectangle x1="22.89" y1="1.05" x2="23.31" y2="1.55" layer="51"/>
<rectangle x1="23.33" y1="1.05" x2="23.75" y2="1.55" layer="51"/>
<rectangle x1="23.77" y1="1.05" x2="24.19" y2="1.55" layer="51"/>
<rectangle x1="24.21" y1="1.05" x2="24.63" y2="1.55" layer="51"/>
<rectangle x1="24.65" y1="1.05" x2="25.07" y2="1.55" layer="51"/>
<rectangle x1="25.09" y1="1.05" x2="25.51" y2="1.55" layer="51"/>
<rectangle x1="25.53" y1="1.05" x2="25.95" y2="1.55" layer="51"/>
<rectangle x1="25.97" y1="1.05" x2="26.39" y2="1.55" layer="51"/>
<rectangle x1="26.41" y1="1.05" x2="26.83" y2="1.55" layer="51"/>
<rectangle x1="26.85" y1="1.05" x2="27.27" y2="1.55" layer="51"/>
<rectangle x1="27.29" y1="1.05" x2="27.71" y2="1.55" layer="51"/>
<rectangle x1="27.73" y1="1.05" x2="28.15" y2="1.55" layer="51"/>
<rectangle x1="-28.15" y1="0.53" x2="-27.73" y2="1.03" layer="51"/>
<rectangle x1="-27.71" y1="0.53" x2="-27.29" y2="1.03" layer="51"/>
<rectangle x1="-27.27" y1="0.53" x2="-26.85" y2="1.03" layer="51"/>
<rectangle x1="-26.83" y1="0.53" x2="-26.41" y2="1.03" layer="51"/>
<rectangle x1="-26.39" y1="0.53" x2="-25.97" y2="1.03" layer="51"/>
<rectangle x1="-25.95" y1="0.53" x2="-25.53" y2="1.03" layer="51"/>
<rectangle x1="-25.51" y1="0.53" x2="-25.09" y2="1.03" layer="51"/>
<rectangle x1="-25.07" y1="0.53" x2="-24.65" y2="1.03" layer="51"/>
<rectangle x1="-24.63" y1="0.53" x2="-24.21" y2="1.03" layer="51"/>
<rectangle x1="-24.19" y1="0.53" x2="-23.77" y2="1.03" layer="51"/>
<rectangle x1="-23.75" y1="0.53" x2="-23.33" y2="1.03" layer="51"/>
<rectangle x1="-23.31" y1="0.53" x2="-22.89" y2="1.03" layer="51"/>
<rectangle x1="-22.87" y1="0.53" x2="-22.45" y2="1.03" layer="51"/>
<rectangle x1="-22.43" y1="0.53" x2="-22.01" y2="1.03" layer="51"/>
<rectangle x1="-21.99" y1="0.53" x2="-21.57" y2="1.03" layer="51"/>
<rectangle x1="-21.55" y1="0.53" x2="-21.13" y2="1.03" layer="51"/>
<rectangle x1="-21.11" y1="0.53" x2="-20.69" y2="1.03" layer="51"/>
<rectangle x1="-20.67" y1="0.53" x2="-20.25" y2="1.03" layer="51"/>
<rectangle x1="-20.23" y1="0.53" x2="-19.81" y2="1.03" layer="51"/>
<rectangle x1="-19.79" y1="0.53" x2="-19.37" y2="1.03" layer="51"/>
<rectangle x1="-19.35" y1="0.53" x2="-18.93" y2="1.03" layer="51"/>
<rectangle x1="-18.91" y1="0.53" x2="-18.49" y2="1.03" layer="51"/>
<rectangle x1="-18.47" y1="0.53" x2="-18.05" y2="1.03" layer="51"/>
<rectangle x1="-18.03" y1="0.53" x2="-17.61" y2="1.03" layer="51"/>
<rectangle x1="-17.59" y1="0.53" x2="-17.17" y2="1.03" layer="51"/>
<rectangle x1="-17.15" y1="0.53" x2="-16.73" y2="1.03" layer="51"/>
<rectangle x1="-16.71" y1="0.53" x2="-16.29" y2="1.03" layer="51"/>
<rectangle x1="-16.27" y1="0.53" x2="-15.85" y2="1.03" layer="51"/>
<rectangle x1="-15.83" y1="0.53" x2="-15.41" y2="1.03" layer="51"/>
<rectangle x1="-15.39" y1="0.53" x2="-14.97" y2="1.03" layer="51"/>
<rectangle x1="-14.95" y1="0.53" x2="-14.53" y2="1.03" layer="51"/>
<rectangle x1="-14.51" y1="0.53" x2="-14.09" y2="1.03" layer="51"/>
<rectangle x1="-14.07" y1="0.53" x2="-13.65" y2="1.03" layer="51"/>
<rectangle x1="-13.63" y1="0.53" x2="-13.21" y2="1.03" layer="51"/>
<rectangle x1="-13.19" y1="0.53" x2="-12.77" y2="1.03" layer="51"/>
<rectangle x1="-12.75" y1="0.53" x2="-12.33" y2="1.03" layer="51"/>
<rectangle x1="-12.31" y1="0.53" x2="-11.89" y2="1.03" layer="51"/>
<rectangle x1="-11.87" y1="0.53" x2="-11.45" y2="1.03" layer="51"/>
<rectangle x1="-11.43" y1="0.53" x2="-11.01" y2="1.03" layer="51"/>
<rectangle x1="-10.99" y1="0.53" x2="-10.57" y2="1.03" layer="51"/>
<rectangle x1="-10.55" y1="0.53" x2="-10.13" y2="1.03" layer="51"/>
<rectangle x1="-10.11" y1="0.53" x2="-9.69" y2="1.03" layer="51"/>
<rectangle x1="-9.67" y1="0.53" x2="-9.25" y2="1.03" layer="51"/>
<rectangle x1="-9.23" y1="0.53" x2="-8.81" y2="1.03" layer="51"/>
<rectangle x1="-8.79" y1="0.53" x2="-8.37" y2="1.03" layer="51"/>
<rectangle x1="-8.35" y1="0.53" x2="-7.93" y2="1.03" layer="51"/>
<rectangle x1="-7.91" y1="0.53" x2="-7.49" y2="1.03" layer="51"/>
<rectangle x1="-7.47" y1="0.53" x2="-7.05" y2="1.03" layer="51"/>
<rectangle x1="-7.03" y1="0.53" x2="-6.61" y2="1.03" layer="51"/>
<rectangle x1="-6.59" y1="0.53" x2="-6.17" y2="1.03" layer="51"/>
<rectangle x1="-6.15" y1="0.53" x2="-5.73" y2="1.03" layer="51"/>
<rectangle x1="-5.71" y1="0.53" x2="-5.29" y2="1.03" layer="51"/>
<rectangle x1="-5.27" y1="0.53" x2="-4.85" y2="1.03" layer="51"/>
<rectangle x1="-4.83" y1="0.53" x2="-4.41" y2="1.03" layer="51"/>
<rectangle x1="-4.39" y1="0.53" x2="-3.97" y2="1.03" layer="51"/>
<rectangle x1="-3.95" y1="0.53" x2="-3.53" y2="1.03" layer="51"/>
<rectangle x1="-3.51" y1="0.53" x2="-3.09" y2="1.03" layer="51"/>
<rectangle x1="-3.07" y1="0.53" x2="-2.65" y2="1.03" layer="51"/>
<rectangle x1="-2.63" y1="0.53" x2="-2.21" y2="1.03" layer="51"/>
<rectangle x1="-2.19" y1="0.53" x2="-1.77" y2="1.03" layer="51"/>
<rectangle x1="-1.75" y1="0.53" x2="-1.33" y2="1.03" layer="51"/>
<rectangle x1="-1.31" y1="0.53" x2="-0.89" y2="1.03" layer="51"/>
<rectangle x1="-0.87" y1="0.53" x2="-0.45" y2="1.03" layer="51"/>
<rectangle x1="-0.43" y1="0.53" x2="-0.01" y2="1.03" layer="51"/>
<rectangle x1="0.01" y1="0.53" x2="0.43" y2="1.03" layer="51"/>
<rectangle x1="0.45" y1="0.53" x2="0.87" y2="1.03" layer="51"/>
<rectangle x1="0.89" y1="0.53" x2="1.31" y2="1.03" layer="51"/>
<rectangle x1="1.33" y1="0.53" x2="1.75" y2="1.03" layer="51"/>
<rectangle x1="1.77" y1="0.53" x2="2.19" y2="1.03" layer="51"/>
<rectangle x1="2.21" y1="0.53" x2="2.63" y2="1.03" layer="51"/>
<rectangle x1="2.65" y1="0.53" x2="3.07" y2="1.03" layer="51"/>
<rectangle x1="3.09" y1="0.53" x2="3.51" y2="1.03" layer="51"/>
<rectangle x1="3.53" y1="0.53" x2="3.95" y2="1.03" layer="51"/>
<rectangle x1="3.97" y1="0.53" x2="4.39" y2="1.03" layer="51"/>
<rectangle x1="4.41" y1="0.53" x2="4.83" y2="1.03" layer="51"/>
<rectangle x1="4.85" y1="0.53" x2="5.27" y2="1.03" layer="51"/>
<rectangle x1="5.29" y1="0.53" x2="5.71" y2="1.03" layer="51"/>
<rectangle x1="5.73" y1="0.53" x2="6.15" y2="1.03" layer="51"/>
<rectangle x1="6.17" y1="0.53" x2="6.59" y2="1.03" layer="51"/>
<rectangle x1="6.61" y1="0.53" x2="7.03" y2="1.03" layer="51"/>
<rectangle x1="7.05" y1="0.53" x2="7.47" y2="1.03" layer="51"/>
<rectangle x1="7.49" y1="0.53" x2="7.91" y2="1.03" layer="51"/>
<rectangle x1="7.93" y1="0.53" x2="8.35" y2="1.03" layer="51"/>
<rectangle x1="8.37" y1="0.53" x2="8.79" y2="1.03" layer="51"/>
<rectangle x1="8.81" y1="0.53" x2="9.23" y2="1.03" layer="51"/>
<rectangle x1="9.25" y1="0.53" x2="9.67" y2="1.03" layer="51"/>
<rectangle x1="9.69" y1="0.53" x2="10.11" y2="1.03" layer="51"/>
<rectangle x1="10.13" y1="0.53" x2="10.55" y2="1.03" layer="51"/>
<rectangle x1="10.57" y1="0.53" x2="10.99" y2="1.03" layer="51"/>
<rectangle x1="11.01" y1="0.53" x2="11.43" y2="1.03" layer="51"/>
<rectangle x1="11.45" y1="0.53" x2="11.87" y2="1.03" layer="51"/>
<rectangle x1="11.89" y1="0.53" x2="12.31" y2="1.03" layer="51"/>
<rectangle x1="12.33" y1="0.53" x2="12.75" y2="1.03" layer="51"/>
<rectangle x1="12.77" y1="0.53" x2="13.19" y2="1.03" layer="51"/>
<rectangle x1="13.21" y1="0.53" x2="13.63" y2="1.03" layer="51"/>
<rectangle x1="13.65" y1="0.53" x2="14.07" y2="1.03" layer="51"/>
<rectangle x1="14.09" y1="0.53" x2="14.51" y2="1.03" layer="51"/>
<rectangle x1="14.53" y1="0.53" x2="14.95" y2="1.03" layer="51"/>
<rectangle x1="14.97" y1="0.53" x2="15.39" y2="1.03" layer="51"/>
<rectangle x1="15.41" y1="0.53" x2="15.83" y2="1.03" layer="51"/>
<rectangle x1="15.85" y1="0.53" x2="16.27" y2="1.03" layer="51"/>
<rectangle x1="16.29" y1="0.53" x2="16.71" y2="1.03" layer="51"/>
<rectangle x1="16.73" y1="0.53" x2="17.15" y2="1.03" layer="51"/>
<rectangle x1="17.17" y1="0.53" x2="17.59" y2="1.03" layer="51"/>
<rectangle x1="17.61" y1="0.53" x2="18.03" y2="1.03" layer="51"/>
<rectangle x1="18.05" y1="0.53" x2="18.47" y2="1.03" layer="51"/>
<rectangle x1="18.49" y1="0.53" x2="18.91" y2="1.03" layer="51"/>
<rectangle x1="18.93" y1="0.53" x2="19.35" y2="1.03" layer="51"/>
<rectangle x1="19.37" y1="0.53" x2="19.79" y2="1.03" layer="51"/>
<rectangle x1="19.81" y1="0.53" x2="20.23" y2="1.03" layer="51"/>
<rectangle x1="20.25" y1="0.53" x2="20.67" y2="1.03" layer="51"/>
<rectangle x1="20.69" y1="0.53" x2="21.11" y2="1.03" layer="51"/>
<rectangle x1="21.13" y1="0.53" x2="21.55" y2="1.03" layer="51"/>
<rectangle x1="21.57" y1="0.53" x2="21.99" y2="1.03" layer="51"/>
<rectangle x1="22.01" y1="0.53" x2="22.43" y2="1.03" layer="51"/>
<rectangle x1="22.45" y1="0.53" x2="22.87" y2="1.03" layer="51"/>
<rectangle x1="22.89" y1="0.53" x2="23.31" y2="1.03" layer="51"/>
<rectangle x1="23.33" y1="0.53" x2="23.75" y2="1.03" layer="51"/>
<rectangle x1="23.77" y1="0.53" x2="24.19" y2="1.03" layer="51"/>
<rectangle x1="24.21" y1="0.53" x2="24.63" y2="1.03" layer="51"/>
<rectangle x1="24.65" y1="0.53" x2="25.07" y2="1.03" layer="51"/>
<rectangle x1="25.09" y1="0.53" x2="25.51" y2="1.03" layer="51"/>
<rectangle x1="25.53" y1="0.53" x2="25.95" y2="1.03" layer="51"/>
<rectangle x1="25.97" y1="0.53" x2="26.39" y2="1.03" layer="51"/>
<rectangle x1="26.41" y1="0.53" x2="26.83" y2="1.03" layer="51"/>
<rectangle x1="26.85" y1="0.53" x2="27.27" y2="1.03" layer="51"/>
<rectangle x1="27.29" y1="0.53" x2="27.71" y2="1.03" layer="51"/>
<rectangle x1="27.73" y1="0.53" x2="28.15" y2="1.03" layer="51"/>
<rectangle x1="-28.15" y1="0.01" x2="-27.73" y2="0.51" layer="51"/>
<rectangle x1="-27.71" y1="0.01" x2="-27.29" y2="0.51" layer="51"/>
<rectangle x1="-27.27" y1="0.01" x2="-26.85" y2="0.51" layer="51"/>
<rectangle x1="-26.83" y1="0.01" x2="-26.41" y2="0.51" layer="51"/>
<rectangle x1="-26.39" y1="0.01" x2="-25.97" y2="0.51" layer="51"/>
<rectangle x1="-25.95" y1="0.01" x2="-25.53" y2="0.51" layer="51"/>
<rectangle x1="-25.51" y1="0.01" x2="-25.09" y2="0.51" layer="51"/>
<rectangle x1="-25.07" y1="0.01" x2="-24.65" y2="0.51" layer="51"/>
<rectangle x1="-24.63" y1="0.01" x2="-24.21" y2="0.51" layer="51"/>
<rectangle x1="-24.19" y1="0.01" x2="-23.77" y2="0.51" layer="51"/>
<rectangle x1="-23.75" y1="0.01" x2="-23.33" y2="0.51" layer="51"/>
<rectangle x1="-23.31" y1="0.01" x2="-22.89" y2="0.51" layer="51"/>
<rectangle x1="-22.87" y1="0.01" x2="-22.45" y2="0.51" layer="51"/>
<rectangle x1="-22.43" y1="0.01" x2="-22.01" y2="0.51" layer="51"/>
<rectangle x1="-21.99" y1="0.01" x2="-21.57" y2="0.51" layer="51"/>
<rectangle x1="-21.55" y1="0.01" x2="-21.13" y2="0.51" layer="51"/>
<rectangle x1="-21.11" y1="0.01" x2="-20.69" y2="0.51" layer="51"/>
<rectangle x1="-20.67" y1="0.01" x2="-20.25" y2="0.51" layer="51"/>
<rectangle x1="-20.23" y1="0.01" x2="-19.81" y2="0.51" layer="51"/>
<rectangle x1="-19.79" y1="0.01" x2="-19.37" y2="0.51" layer="51"/>
<rectangle x1="-19.35" y1="0.01" x2="-18.93" y2="0.51" layer="51"/>
<rectangle x1="-18.91" y1="0.01" x2="-18.49" y2="0.51" layer="51"/>
<rectangle x1="-18.47" y1="0.01" x2="-18.05" y2="0.51" layer="51"/>
<rectangle x1="-18.03" y1="0.01" x2="-17.61" y2="0.51" layer="51"/>
<rectangle x1="-17.59" y1="0.01" x2="-17.17" y2="0.51" layer="51"/>
<rectangle x1="-17.15" y1="0.01" x2="-16.73" y2="0.51" layer="51"/>
<rectangle x1="-16.71" y1="0.01" x2="-16.29" y2="0.51" layer="51"/>
<rectangle x1="-16.27" y1="0.01" x2="-15.85" y2="0.51" layer="51"/>
<rectangle x1="-15.83" y1="0.01" x2="-15.41" y2="0.51" layer="51"/>
<rectangle x1="-15.39" y1="0.01" x2="-14.97" y2="0.51" layer="51"/>
<rectangle x1="-14.95" y1="0.01" x2="-14.53" y2="0.51" layer="51"/>
<rectangle x1="-14.51" y1="0.01" x2="-14.09" y2="0.51" layer="51"/>
<rectangle x1="-14.07" y1="0.01" x2="-13.65" y2="0.51" layer="51"/>
<rectangle x1="-13.63" y1="0.01" x2="-13.21" y2="0.51" layer="51"/>
<rectangle x1="-13.19" y1="0.01" x2="-12.77" y2="0.51" layer="51"/>
<rectangle x1="-12.75" y1="0.01" x2="-12.33" y2="0.51" layer="51"/>
<rectangle x1="-12.31" y1="0.01" x2="-11.89" y2="0.51" layer="51"/>
<rectangle x1="-11.87" y1="0.01" x2="-11.45" y2="0.51" layer="51"/>
<rectangle x1="-11.43" y1="0.01" x2="-11.01" y2="0.51" layer="51"/>
<rectangle x1="-10.99" y1="0.01" x2="-10.57" y2="0.51" layer="51"/>
<rectangle x1="-10.55" y1="0.01" x2="-10.13" y2="0.51" layer="51"/>
<rectangle x1="-10.11" y1="0.01" x2="-9.69" y2="0.51" layer="51"/>
<rectangle x1="-9.67" y1="0.01" x2="-9.25" y2="0.51" layer="51"/>
<rectangle x1="-9.23" y1="0.01" x2="-8.81" y2="0.51" layer="51"/>
<rectangle x1="-8.79" y1="0.01" x2="-8.37" y2="0.51" layer="51"/>
<rectangle x1="-8.35" y1="0.01" x2="-7.93" y2="0.51" layer="51"/>
<rectangle x1="-7.91" y1="0.01" x2="-7.49" y2="0.51" layer="51"/>
<rectangle x1="-7.47" y1="0.01" x2="-7.05" y2="0.51" layer="51"/>
<rectangle x1="-7.03" y1="0.01" x2="-6.61" y2="0.51" layer="51"/>
<rectangle x1="-6.59" y1="0.01" x2="-6.17" y2="0.51" layer="51"/>
<rectangle x1="-6.15" y1="0.01" x2="-5.73" y2="0.51" layer="51"/>
<rectangle x1="-5.71" y1="0.01" x2="-5.29" y2="0.51" layer="51"/>
<rectangle x1="-5.27" y1="0.01" x2="-4.85" y2="0.51" layer="51"/>
<rectangle x1="-4.83" y1="0.01" x2="-4.41" y2="0.51" layer="51"/>
<rectangle x1="-4.39" y1="0.01" x2="-3.97" y2="0.51" layer="51"/>
<rectangle x1="-3.95" y1="0.01" x2="-3.53" y2="0.51" layer="51"/>
<rectangle x1="-3.51" y1="0.01" x2="-3.09" y2="0.51" layer="51"/>
<rectangle x1="-3.07" y1="0.01" x2="-2.65" y2="0.51" layer="51"/>
<rectangle x1="-2.63" y1="0.01" x2="-2.21" y2="0.51" layer="51"/>
<rectangle x1="-2.19" y1="0.01" x2="-1.77" y2="0.51" layer="51"/>
<rectangle x1="-1.75" y1="0.01" x2="-1.33" y2="0.51" layer="51"/>
<rectangle x1="-1.31" y1="0.01" x2="-0.89" y2="0.51" layer="51"/>
<rectangle x1="-0.87" y1="0.01" x2="-0.45" y2="0.51" layer="51"/>
<rectangle x1="-0.43" y1="0.01" x2="-0.01" y2="0.51" layer="51"/>
<rectangle x1="0.01" y1="0.01" x2="0.43" y2="0.51" layer="51"/>
<rectangle x1="0.45" y1="0.01" x2="0.87" y2="0.51" layer="51"/>
<rectangle x1="0.89" y1="0.01" x2="1.31" y2="0.51" layer="51"/>
<rectangle x1="1.33" y1="0.01" x2="1.75" y2="0.51" layer="51"/>
<rectangle x1="1.77" y1="0.01" x2="2.19" y2="0.51" layer="51"/>
<rectangle x1="2.21" y1="0.01" x2="2.63" y2="0.51" layer="51"/>
<rectangle x1="2.65" y1="0.01" x2="3.07" y2="0.51" layer="51"/>
<rectangle x1="3.09" y1="0.01" x2="3.51" y2="0.51" layer="51"/>
<rectangle x1="3.53" y1="0.01" x2="3.95" y2="0.51" layer="51"/>
<rectangle x1="3.97" y1="0.01" x2="4.39" y2="0.51" layer="51"/>
<rectangle x1="4.41" y1="0.01" x2="4.83" y2="0.51" layer="51"/>
<rectangle x1="4.85" y1="0.01" x2="5.27" y2="0.51" layer="51"/>
<rectangle x1="5.29" y1="0.01" x2="5.71" y2="0.51" layer="51"/>
<rectangle x1="5.73" y1="0.01" x2="6.15" y2="0.51" layer="51"/>
<rectangle x1="6.17" y1="0.01" x2="6.59" y2="0.51" layer="51"/>
<rectangle x1="6.61" y1="0.01" x2="7.03" y2="0.51" layer="51"/>
<rectangle x1="7.05" y1="0.01" x2="7.47" y2="0.51" layer="51"/>
<rectangle x1="7.49" y1="0.01" x2="7.91" y2="0.51" layer="51"/>
<rectangle x1="7.93" y1="0.01" x2="8.35" y2="0.51" layer="51"/>
<rectangle x1="8.37" y1="0.01" x2="8.79" y2="0.51" layer="51"/>
<rectangle x1="8.81" y1="0.01" x2="9.23" y2="0.51" layer="51"/>
<rectangle x1="9.25" y1="0.01" x2="9.67" y2="0.51" layer="51"/>
<rectangle x1="9.69" y1="0.01" x2="10.11" y2="0.51" layer="51"/>
<rectangle x1="10.13" y1="0.01" x2="10.55" y2="0.51" layer="51"/>
<rectangle x1="10.57" y1="0.01" x2="10.99" y2="0.51" layer="51"/>
<rectangle x1="11.01" y1="0.01" x2="11.43" y2="0.51" layer="51"/>
<rectangle x1="11.45" y1="0.01" x2="11.87" y2="0.51" layer="51"/>
<rectangle x1="11.89" y1="0.01" x2="12.31" y2="0.51" layer="51"/>
<rectangle x1="12.33" y1="0.01" x2="12.75" y2="0.51" layer="51"/>
<rectangle x1="12.77" y1="0.01" x2="13.19" y2="0.51" layer="51"/>
<rectangle x1="13.21" y1="0.01" x2="13.63" y2="0.51" layer="51"/>
<rectangle x1="13.65" y1="0.01" x2="14.07" y2="0.51" layer="51"/>
<rectangle x1="14.09" y1="0.01" x2="14.51" y2="0.51" layer="51"/>
<rectangle x1="14.53" y1="0.01" x2="14.95" y2="0.51" layer="51"/>
<rectangle x1="14.97" y1="0.01" x2="15.39" y2="0.51" layer="51"/>
<rectangle x1="15.41" y1="0.01" x2="15.83" y2="0.51" layer="51"/>
<rectangle x1="15.85" y1="0.01" x2="16.27" y2="0.51" layer="51"/>
<rectangle x1="16.29" y1="0.01" x2="16.71" y2="0.51" layer="51"/>
<rectangle x1="16.73" y1="0.01" x2="17.15" y2="0.51" layer="51"/>
<rectangle x1="17.17" y1="0.01" x2="17.59" y2="0.51" layer="51"/>
<rectangle x1="17.61" y1="0.01" x2="18.03" y2="0.51" layer="51"/>
<rectangle x1="18.05" y1="0.01" x2="18.47" y2="0.51" layer="51"/>
<rectangle x1="18.49" y1="0.01" x2="18.91" y2="0.51" layer="51"/>
<rectangle x1="18.93" y1="0.01" x2="19.35" y2="0.51" layer="51"/>
<rectangle x1="19.37" y1="0.01" x2="19.79" y2="0.51" layer="51"/>
<rectangle x1="19.81" y1="0.01" x2="20.23" y2="0.51" layer="51"/>
<rectangle x1="20.25" y1="0.01" x2="20.67" y2="0.51" layer="51"/>
<rectangle x1="20.69" y1="0.01" x2="21.11" y2="0.51" layer="51"/>
<rectangle x1="21.13" y1="0.01" x2="21.55" y2="0.51" layer="51"/>
<rectangle x1="21.57" y1="0.01" x2="21.99" y2="0.51" layer="51"/>
<rectangle x1="22.01" y1="0.01" x2="22.43" y2="0.51" layer="51"/>
<rectangle x1="22.45" y1="0.01" x2="22.87" y2="0.51" layer="51"/>
<rectangle x1="22.89" y1="0.01" x2="23.31" y2="0.51" layer="51"/>
<rectangle x1="23.33" y1="0.01" x2="23.75" y2="0.51" layer="51"/>
<rectangle x1="23.77" y1="0.01" x2="24.19" y2="0.51" layer="51"/>
<rectangle x1="24.21" y1="0.01" x2="24.63" y2="0.51" layer="51"/>
<rectangle x1="24.65" y1="0.01" x2="25.07" y2="0.51" layer="51"/>
<rectangle x1="25.09" y1="0.01" x2="25.51" y2="0.51" layer="51"/>
<rectangle x1="25.53" y1="0.01" x2="25.95" y2="0.51" layer="51"/>
<rectangle x1="25.97" y1="0.01" x2="26.39" y2="0.51" layer="51"/>
<rectangle x1="26.41" y1="0.01" x2="26.83" y2="0.51" layer="51"/>
<rectangle x1="26.85" y1="0.01" x2="27.27" y2="0.51" layer="51"/>
<rectangle x1="27.29" y1="0.01" x2="27.71" y2="0.51" layer="51"/>
<rectangle x1="27.73" y1="0.01" x2="28.15" y2="0.51" layer="51"/>
<rectangle x1="-28.15" y1="-0.51" x2="-27.73" y2="-0.01" layer="51"/>
<rectangle x1="-27.71" y1="-0.51" x2="-27.29" y2="-0.01" layer="51"/>
<rectangle x1="-27.27" y1="-0.51" x2="-26.85" y2="-0.01" layer="51"/>
<rectangle x1="-26.83" y1="-0.51" x2="-26.41" y2="-0.01" layer="51"/>
<rectangle x1="-26.39" y1="-0.51" x2="-25.97" y2="-0.01" layer="51"/>
<rectangle x1="-25.95" y1="-0.51" x2="-25.53" y2="-0.01" layer="51"/>
<rectangle x1="-25.51" y1="-0.51" x2="-25.09" y2="-0.01" layer="51"/>
<rectangle x1="-25.07" y1="-0.51" x2="-24.65" y2="-0.01" layer="51"/>
<rectangle x1="-24.63" y1="-0.51" x2="-24.21" y2="-0.01" layer="51"/>
<rectangle x1="-24.19" y1="-0.51" x2="-23.77" y2="-0.01" layer="51"/>
<rectangle x1="-23.75" y1="-0.51" x2="-23.33" y2="-0.01" layer="51"/>
<rectangle x1="-23.31" y1="-0.51" x2="-22.89" y2="-0.01" layer="51"/>
<rectangle x1="-22.87" y1="-0.51" x2="-22.45" y2="-0.01" layer="51"/>
<rectangle x1="-22.43" y1="-0.51" x2="-22.01" y2="-0.01" layer="51"/>
<rectangle x1="-21.99" y1="-0.51" x2="-21.57" y2="-0.01" layer="51"/>
<rectangle x1="-21.55" y1="-0.51" x2="-21.13" y2="-0.01" layer="51"/>
<rectangle x1="-21.11" y1="-0.51" x2="-20.69" y2="-0.01" layer="51"/>
<rectangle x1="-20.67" y1="-0.51" x2="-20.25" y2="-0.01" layer="51"/>
<rectangle x1="-20.23" y1="-0.51" x2="-19.81" y2="-0.01" layer="51"/>
<rectangle x1="-19.79" y1="-0.51" x2="-19.37" y2="-0.01" layer="51"/>
<rectangle x1="-19.35" y1="-0.51" x2="-18.93" y2="-0.01" layer="51"/>
<rectangle x1="-18.91" y1="-0.51" x2="-18.49" y2="-0.01" layer="51"/>
<rectangle x1="-18.47" y1="-0.51" x2="-18.05" y2="-0.01" layer="51"/>
<rectangle x1="-18.03" y1="-0.51" x2="-17.61" y2="-0.01" layer="51"/>
<rectangle x1="-17.59" y1="-0.51" x2="-17.17" y2="-0.01" layer="51"/>
<rectangle x1="-17.15" y1="-0.51" x2="-16.73" y2="-0.01" layer="51"/>
<rectangle x1="-16.71" y1="-0.51" x2="-16.29" y2="-0.01" layer="51"/>
<rectangle x1="-16.27" y1="-0.51" x2="-15.85" y2="-0.01" layer="51"/>
<rectangle x1="-15.83" y1="-0.51" x2="-15.41" y2="-0.01" layer="51"/>
<rectangle x1="-15.39" y1="-0.51" x2="-14.97" y2="-0.01" layer="51"/>
<rectangle x1="-14.95" y1="-0.51" x2="-14.53" y2="-0.01" layer="51"/>
<rectangle x1="-14.51" y1="-0.51" x2="-14.09" y2="-0.01" layer="51"/>
<rectangle x1="-14.07" y1="-0.51" x2="-13.65" y2="-0.01" layer="51"/>
<rectangle x1="-13.63" y1="-0.51" x2="-13.21" y2="-0.01" layer="51"/>
<rectangle x1="-13.19" y1="-0.51" x2="-12.77" y2="-0.01" layer="51"/>
<rectangle x1="-12.75" y1="-0.51" x2="-12.33" y2="-0.01" layer="51"/>
<rectangle x1="-12.31" y1="-0.51" x2="-11.89" y2="-0.01" layer="51"/>
<rectangle x1="-11.87" y1="-0.51" x2="-11.45" y2="-0.01" layer="51"/>
<rectangle x1="-11.43" y1="-0.51" x2="-11.01" y2="-0.01" layer="51"/>
<rectangle x1="-10.99" y1="-0.51" x2="-10.57" y2="-0.01" layer="51"/>
<rectangle x1="-10.55" y1="-0.51" x2="-10.13" y2="-0.01" layer="51"/>
<rectangle x1="-10.11" y1="-0.51" x2="-9.69" y2="-0.01" layer="51"/>
<rectangle x1="-9.67" y1="-0.51" x2="-9.25" y2="-0.01" layer="51"/>
<rectangle x1="-9.23" y1="-0.51" x2="-8.81" y2="-0.01" layer="51"/>
<rectangle x1="-8.79" y1="-0.51" x2="-8.37" y2="-0.01" layer="51"/>
<rectangle x1="-8.35" y1="-0.51" x2="-7.93" y2="-0.01" layer="51"/>
<rectangle x1="-7.91" y1="-0.51" x2="-7.49" y2="-0.01" layer="51"/>
<rectangle x1="-7.47" y1="-0.51" x2="-7.05" y2="-0.01" layer="51"/>
<rectangle x1="-7.03" y1="-0.51" x2="-6.61" y2="-0.01" layer="51"/>
<rectangle x1="-6.59" y1="-0.51" x2="-6.17" y2="-0.01" layer="51"/>
<rectangle x1="-6.15" y1="-0.51" x2="-5.73" y2="-0.01" layer="51"/>
<rectangle x1="-5.71" y1="-0.51" x2="-5.29" y2="-0.01" layer="51"/>
<rectangle x1="-5.27" y1="-0.51" x2="-4.85" y2="-0.01" layer="51"/>
<rectangle x1="-4.83" y1="-0.51" x2="-4.41" y2="-0.01" layer="51"/>
<rectangle x1="-4.39" y1="-0.51" x2="-3.97" y2="-0.01" layer="51"/>
<rectangle x1="-3.95" y1="-0.51" x2="-3.53" y2="-0.01" layer="51"/>
<rectangle x1="-3.51" y1="-0.51" x2="-3.09" y2="-0.01" layer="51"/>
<rectangle x1="-3.07" y1="-0.51" x2="-2.65" y2="-0.01" layer="51"/>
<rectangle x1="-2.63" y1="-0.51" x2="-2.21" y2="-0.01" layer="51"/>
<rectangle x1="-2.19" y1="-0.51" x2="-1.77" y2="-0.01" layer="51"/>
<rectangle x1="-1.75" y1="-0.51" x2="-1.33" y2="-0.01" layer="51"/>
<rectangle x1="-1.31" y1="-0.51" x2="-0.89" y2="-0.01" layer="51"/>
<rectangle x1="-0.87" y1="-0.51" x2="-0.45" y2="-0.01" layer="51"/>
<rectangle x1="-0.43" y1="-0.51" x2="-0.01" y2="-0.01" layer="51"/>
<rectangle x1="0.01" y1="-0.51" x2="0.43" y2="-0.01" layer="51"/>
<rectangle x1="0.45" y1="-0.51" x2="0.87" y2="-0.01" layer="51"/>
<rectangle x1="0.89" y1="-0.51" x2="1.31" y2="-0.01" layer="51"/>
<rectangle x1="1.33" y1="-0.51" x2="1.75" y2="-0.01" layer="51"/>
<rectangle x1="1.77" y1="-0.51" x2="2.19" y2="-0.01" layer="51"/>
<rectangle x1="2.21" y1="-0.51" x2="2.63" y2="-0.01" layer="51"/>
<rectangle x1="2.65" y1="-0.51" x2="3.07" y2="-0.01" layer="51"/>
<rectangle x1="3.09" y1="-0.51" x2="3.51" y2="-0.01" layer="51"/>
<rectangle x1="3.53" y1="-0.51" x2="3.95" y2="-0.01" layer="51"/>
<rectangle x1="3.97" y1="-0.51" x2="4.39" y2="-0.01" layer="51"/>
<rectangle x1="4.41" y1="-0.51" x2="4.83" y2="-0.01" layer="51"/>
<rectangle x1="4.85" y1="-0.51" x2="5.27" y2="-0.01" layer="51"/>
<rectangle x1="5.29" y1="-0.51" x2="5.71" y2="-0.01" layer="51"/>
<rectangle x1="5.73" y1="-0.51" x2="6.15" y2="-0.01" layer="51"/>
<rectangle x1="6.17" y1="-0.51" x2="6.59" y2="-0.01" layer="51"/>
<rectangle x1="6.61" y1="-0.51" x2="7.03" y2="-0.01" layer="51"/>
<rectangle x1="7.05" y1="-0.51" x2="7.47" y2="-0.01" layer="51"/>
<rectangle x1="7.49" y1="-0.51" x2="7.91" y2="-0.01" layer="51"/>
<rectangle x1="7.93" y1="-0.51" x2="8.35" y2="-0.01" layer="51"/>
<rectangle x1="8.37" y1="-0.51" x2="8.79" y2="-0.01" layer="51"/>
<rectangle x1="8.81" y1="-0.51" x2="9.23" y2="-0.01" layer="51"/>
<rectangle x1="9.25" y1="-0.51" x2="9.67" y2="-0.01" layer="51"/>
<rectangle x1="9.69" y1="-0.51" x2="10.11" y2="-0.01" layer="51"/>
<rectangle x1="10.13" y1="-0.51" x2="10.55" y2="-0.01" layer="51"/>
<rectangle x1="10.57" y1="-0.51" x2="10.99" y2="-0.01" layer="51"/>
<rectangle x1="11.01" y1="-0.51" x2="11.43" y2="-0.01" layer="51"/>
<rectangle x1="11.45" y1="-0.51" x2="11.87" y2="-0.01" layer="51"/>
<rectangle x1="11.89" y1="-0.51" x2="12.31" y2="-0.01" layer="51"/>
<rectangle x1="12.33" y1="-0.51" x2="12.75" y2="-0.01" layer="51"/>
<rectangle x1="12.77" y1="-0.51" x2="13.19" y2="-0.01" layer="51"/>
<rectangle x1="13.21" y1="-0.51" x2="13.63" y2="-0.01" layer="51"/>
<rectangle x1="13.65" y1="-0.51" x2="14.07" y2="-0.01" layer="51"/>
<rectangle x1="14.09" y1="-0.51" x2="14.51" y2="-0.01" layer="51"/>
<rectangle x1="14.53" y1="-0.51" x2="14.95" y2="-0.01" layer="51"/>
<rectangle x1="14.97" y1="-0.51" x2="15.39" y2="-0.01" layer="51"/>
<rectangle x1="15.41" y1="-0.51" x2="15.83" y2="-0.01" layer="51"/>
<rectangle x1="15.85" y1="-0.51" x2="16.27" y2="-0.01" layer="51"/>
<rectangle x1="16.29" y1="-0.51" x2="16.71" y2="-0.01" layer="51"/>
<rectangle x1="16.73" y1="-0.51" x2="17.15" y2="-0.01" layer="51"/>
<rectangle x1="17.17" y1="-0.51" x2="17.59" y2="-0.01" layer="51"/>
<rectangle x1="17.61" y1="-0.51" x2="18.03" y2="-0.01" layer="51"/>
<rectangle x1="18.05" y1="-0.51" x2="18.47" y2="-0.01" layer="51"/>
<rectangle x1="18.49" y1="-0.51" x2="18.91" y2="-0.01" layer="51"/>
<rectangle x1="18.93" y1="-0.51" x2="19.35" y2="-0.01" layer="51"/>
<rectangle x1="19.37" y1="-0.51" x2="19.79" y2="-0.01" layer="51"/>
<rectangle x1="19.81" y1="-0.51" x2="20.23" y2="-0.01" layer="51"/>
<rectangle x1="20.25" y1="-0.51" x2="20.67" y2="-0.01" layer="51"/>
<rectangle x1="20.69" y1="-0.51" x2="21.11" y2="-0.01" layer="51"/>
<rectangle x1="21.13" y1="-0.51" x2="21.55" y2="-0.01" layer="51"/>
<rectangle x1="21.57" y1="-0.51" x2="21.99" y2="-0.01" layer="51"/>
<rectangle x1="22.01" y1="-0.51" x2="22.43" y2="-0.01" layer="51"/>
<rectangle x1="22.45" y1="-0.51" x2="22.87" y2="-0.01" layer="51"/>
<rectangle x1="22.89" y1="-0.51" x2="23.31" y2="-0.01" layer="51"/>
<rectangle x1="23.33" y1="-0.51" x2="23.75" y2="-0.01" layer="51"/>
<rectangle x1="23.77" y1="-0.51" x2="24.19" y2="-0.01" layer="51"/>
<rectangle x1="24.21" y1="-0.51" x2="24.63" y2="-0.01" layer="51"/>
<rectangle x1="24.65" y1="-0.51" x2="25.07" y2="-0.01" layer="51"/>
<rectangle x1="25.09" y1="-0.51" x2="25.51" y2="-0.01" layer="51"/>
<rectangle x1="25.53" y1="-0.51" x2="25.95" y2="-0.01" layer="51"/>
<rectangle x1="25.97" y1="-0.51" x2="26.39" y2="-0.01" layer="51"/>
<rectangle x1="26.41" y1="-0.51" x2="26.83" y2="-0.01" layer="51"/>
<rectangle x1="26.85" y1="-0.51" x2="27.27" y2="-0.01" layer="51"/>
<rectangle x1="27.29" y1="-0.51" x2="27.71" y2="-0.01" layer="51"/>
<rectangle x1="27.73" y1="-0.51" x2="28.15" y2="-0.01" layer="51"/>
<rectangle x1="-28.15" y1="-1.03" x2="-27.73" y2="-0.53" layer="51"/>
<rectangle x1="-27.71" y1="-1.03" x2="-27.29" y2="-0.53" layer="51"/>
<rectangle x1="-27.27" y1="-1.03" x2="-26.85" y2="-0.53" layer="51"/>
<rectangle x1="-26.83" y1="-1.03" x2="-26.41" y2="-0.53" layer="51"/>
<rectangle x1="-26.39" y1="-1.03" x2="-25.97" y2="-0.53" layer="51"/>
<rectangle x1="-25.95" y1="-1.03" x2="-25.53" y2="-0.53" layer="51"/>
<rectangle x1="-25.51" y1="-1.03" x2="-25.09" y2="-0.53" layer="51"/>
<rectangle x1="-25.07" y1="-1.03" x2="-24.65" y2="-0.53" layer="51"/>
<rectangle x1="-24.63" y1="-1.03" x2="-24.21" y2="-0.53" layer="51"/>
<rectangle x1="-24.19" y1="-1.03" x2="-23.77" y2="-0.53" layer="51"/>
<rectangle x1="-23.75" y1="-1.03" x2="-23.33" y2="-0.53" layer="51"/>
<rectangle x1="-23.31" y1="-1.03" x2="-22.89" y2="-0.53" layer="51"/>
<rectangle x1="-22.87" y1="-1.03" x2="-22.45" y2="-0.53" layer="51"/>
<rectangle x1="-22.43" y1="-1.03" x2="-22.01" y2="-0.53" layer="51"/>
<rectangle x1="-21.99" y1="-1.03" x2="-21.57" y2="-0.53" layer="51"/>
<rectangle x1="-21.55" y1="-1.03" x2="-21.13" y2="-0.53" layer="51"/>
<rectangle x1="-21.11" y1="-1.03" x2="-20.69" y2="-0.53" layer="51"/>
<rectangle x1="-20.67" y1="-1.03" x2="-20.25" y2="-0.53" layer="51"/>
<rectangle x1="-20.23" y1="-1.03" x2="-19.81" y2="-0.53" layer="51"/>
<rectangle x1="-19.79" y1="-1.03" x2="-19.37" y2="-0.53" layer="51"/>
<rectangle x1="-19.35" y1="-1.03" x2="-18.93" y2="-0.53" layer="51"/>
<rectangle x1="-18.91" y1="-1.03" x2="-18.49" y2="-0.53" layer="51"/>
<rectangle x1="-18.47" y1="-1.03" x2="-18.05" y2="-0.53" layer="51"/>
<rectangle x1="-18.03" y1="-1.03" x2="-17.61" y2="-0.53" layer="51"/>
<rectangle x1="-17.59" y1="-1.03" x2="-17.17" y2="-0.53" layer="51"/>
<rectangle x1="-17.15" y1="-1.03" x2="-16.73" y2="-0.53" layer="51"/>
<rectangle x1="-16.71" y1="-1.03" x2="-16.29" y2="-0.53" layer="51"/>
<rectangle x1="-16.27" y1="-1.03" x2="-15.85" y2="-0.53" layer="51"/>
<rectangle x1="-15.83" y1="-1.03" x2="-15.41" y2="-0.53" layer="51"/>
<rectangle x1="-15.39" y1="-1.03" x2="-14.97" y2="-0.53" layer="51"/>
<rectangle x1="-14.95" y1="-1.03" x2="-14.53" y2="-0.53" layer="51"/>
<rectangle x1="-14.51" y1="-1.03" x2="-14.09" y2="-0.53" layer="51"/>
<rectangle x1="-14.07" y1="-1.03" x2="-13.65" y2="-0.53" layer="51"/>
<rectangle x1="-13.63" y1="-1.03" x2="-13.21" y2="-0.53" layer="51"/>
<rectangle x1="-13.19" y1="-1.03" x2="-12.77" y2="-0.53" layer="51"/>
<rectangle x1="-12.75" y1="-1.03" x2="-12.33" y2="-0.53" layer="51"/>
<rectangle x1="-12.31" y1="-1.03" x2="-11.89" y2="-0.53" layer="51"/>
<rectangle x1="-11.87" y1="-1.03" x2="-11.45" y2="-0.53" layer="51"/>
<rectangle x1="-11.43" y1="-1.03" x2="-11.01" y2="-0.53" layer="51"/>
<rectangle x1="-10.99" y1="-1.03" x2="-10.57" y2="-0.53" layer="51"/>
<rectangle x1="-10.55" y1="-1.03" x2="-10.13" y2="-0.53" layer="51"/>
<rectangle x1="-10.11" y1="-1.03" x2="-9.69" y2="-0.53" layer="51"/>
<rectangle x1="-9.67" y1="-1.03" x2="-9.25" y2="-0.53" layer="51"/>
<rectangle x1="-9.23" y1="-1.03" x2="-8.81" y2="-0.53" layer="51"/>
<rectangle x1="-8.79" y1="-1.03" x2="-8.37" y2="-0.53" layer="51"/>
<rectangle x1="-8.35" y1="-1.03" x2="-7.93" y2="-0.53" layer="51"/>
<rectangle x1="-7.91" y1="-1.03" x2="-7.49" y2="-0.53" layer="51"/>
<rectangle x1="-7.47" y1="-1.03" x2="-7.05" y2="-0.53" layer="51"/>
<rectangle x1="-7.03" y1="-1.03" x2="-6.61" y2="-0.53" layer="51"/>
<rectangle x1="-6.59" y1="-1.03" x2="-6.17" y2="-0.53" layer="51"/>
<rectangle x1="-6.15" y1="-1.03" x2="-5.73" y2="-0.53" layer="51"/>
<rectangle x1="-5.71" y1="-1.03" x2="-5.29" y2="-0.53" layer="51"/>
<rectangle x1="-5.27" y1="-1.03" x2="-4.85" y2="-0.53" layer="51"/>
<rectangle x1="-4.83" y1="-1.03" x2="-4.41" y2="-0.53" layer="51"/>
<rectangle x1="-4.39" y1="-1.03" x2="-3.97" y2="-0.53" layer="51"/>
<rectangle x1="-3.95" y1="-1.03" x2="-3.53" y2="-0.53" layer="51"/>
<rectangle x1="-3.51" y1="-1.03" x2="-3.09" y2="-0.53" layer="51"/>
<rectangle x1="-3.07" y1="-1.03" x2="-2.65" y2="-0.53" layer="51"/>
<rectangle x1="-2.63" y1="-1.03" x2="-2.21" y2="-0.53" layer="51"/>
<rectangle x1="-2.19" y1="-1.03" x2="-1.77" y2="-0.53" layer="51"/>
<rectangle x1="-1.75" y1="-1.03" x2="-1.33" y2="-0.53" layer="51"/>
<rectangle x1="-1.31" y1="-1.03" x2="-0.89" y2="-0.53" layer="51"/>
<rectangle x1="-0.87" y1="-1.03" x2="-0.45" y2="-0.53" layer="51"/>
<rectangle x1="-0.43" y1="-1.03" x2="-0.01" y2="-0.53" layer="51"/>
<rectangle x1="0.01" y1="-1.03" x2="0.43" y2="-0.53" layer="51"/>
<rectangle x1="0.45" y1="-1.03" x2="0.87" y2="-0.53" layer="51"/>
<rectangle x1="0.89" y1="-1.03" x2="1.31" y2="-0.53" layer="51"/>
<rectangle x1="1.33" y1="-1.03" x2="1.75" y2="-0.53" layer="51"/>
<rectangle x1="1.77" y1="-1.03" x2="2.19" y2="-0.53" layer="51"/>
<rectangle x1="2.21" y1="-1.03" x2="2.63" y2="-0.53" layer="51"/>
<rectangle x1="2.65" y1="-1.03" x2="3.07" y2="-0.53" layer="51"/>
<rectangle x1="3.09" y1="-1.03" x2="3.51" y2="-0.53" layer="51"/>
<rectangle x1="3.53" y1="-1.03" x2="3.95" y2="-0.53" layer="51"/>
<rectangle x1="3.97" y1="-1.03" x2="4.39" y2="-0.53" layer="51"/>
<rectangle x1="4.41" y1="-1.03" x2="4.83" y2="-0.53" layer="51"/>
<rectangle x1="4.85" y1="-1.03" x2="5.27" y2="-0.53" layer="51"/>
<rectangle x1="5.29" y1="-1.03" x2="5.71" y2="-0.53" layer="51"/>
<rectangle x1="5.73" y1="-1.03" x2="6.15" y2="-0.53" layer="51"/>
<rectangle x1="6.17" y1="-1.03" x2="6.59" y2="-0.53" layer="51"/>
<rectangle x1="6.61" y1="-1.03" x2="7.03" y2="-0.53" layer="51"/>
<rectangle x1="7.05" y1="-1.03" x2="7.47" y2="-0.53" layer="51"/>
<rectangle x1="7.49" y1="-1.03" x2="7.91" y2="-0.53" layer="51"/>
<rectangle x1="7.93" y1="-1.03" x2="8.35" y2="-0.53" layer="51"/>
<rectangle x1="8.37" y1="-1.03" x2="8.79" y2="-0.53" layer="51"/>
<rectangle x1="8.81" y1="-1.03" x2="9.23" y2="-0.53" layer="51"/>
<rectangle x1="9.25" y1="-1.03" x2="9.67" y2="-0.53" layer="51"/>
<rectangle x1="9.69" y1="-1.03" x2="10.11" y2="-0.53" layer="51"/>
<rectangle x1="10.13" y1="-1.03" x2="10.55" y2="-0.53" layer="51"/>
<rectangle x1="10.57" y1="-1.03" x2="10.99" y2="-0.53" layer="51"/>
<rectangle x1="11.01" y1="-1.03" x2="11.43" y2="-0.53" layer="51"/>
<rectangle x1="11.45" y1="-1.03" x2="11.87" y2="-0.53" layer="51"/>
<rectangle x1="11.89" y1="-1.03" x2="12.31" y2="-0.53" layer="51"/>
<rectangle x1="12.33" y1="-1.03" x2="12.75" y2="-0.53" layer="51"/>
<rectangle x1="12.77" y1="-1.03" x2="13.19" y2="-0.53" layer="51"/>
<rectangle x1="13.21" y1="-1.03" x2="13.63" y2="-0.53" layer="51"/>
<rectangle x1="13.65" y1="-1.03" x2="14.07" y2="-0.53" layer="51"/>
<rectangle x1="14.09" y1="-1.03" x2="14.51" y2="-0.53" layer="51"/>
<rectangle x1="14.53" y1="-1.03" x2="14.95" y2="-0.53" layer="51"/>
<rectangle x1="14.97" y1="-1.03" x2="15.39" y2="-0.53" layer="51"/>
<rectangle x1="15.41" y1="-1.03" x2="15.83" y2="-0.53" layer="51"/>
<rectangle x1="15.85" y1="-1.03" x2="16.27" y2="-0.53" layer="51"/>
<rectangle x1="16.29" y1="-1.03" x2="16.71" y2="-0.53" layer="51"/>
<rectangle x1="16.73" y1="-1.03" x2="17.15" y2="-0.53" layer="51"/>
<rectangle x1="17.17" y1="-1.03" x2="17.59" y2="-0.53" layer="51"/>
<rectangle x1="17.61" y1="-1.03" x2="18.03" y2="-0.53" layer="51"/>
<rectangle x1="18.05" y1="-1.03" x2="18.47" y2="-0.53" layer="51"/>
<rectangle x1="18.49" y1="-1.03" x2="18.91" y2="-0.53" layer="51"/>
<rectangle x1="18.93" y1="-1.03" x2="19.35" y2="-0.53" layer="51"/>
<rectangle x1="19.37" y1="-1.03" x2="19.79" y2="-0.53" layer="51"/>
<rectangle x1="19.81" y1="-1.03" x2="20.23" y2="-0.53" layer="51"/>
<rectangle x1="20.25" y1="-1.03" x2="20.67" y2="-0.53" layer="51"/>
<rectangle x1="20.69" y1="-1.03" x2="21.11" y2="-0.53" layer="51"/>
<rectangle x1="21.13" y1="-1.03" x2="21.55" y2="-0.53" layer="51"/>
<rectangle x1="21.57" y1="-1.03" x2="21.99" y2="-0.53" layer="51"/>
<rectangle x1="22.01" y1="-1.03" x2="22.43" y2="-0.53" layer="51"/>
<rectangle x1="22.45" y1="-1.03" x2="22.87" y2="-0.53" layer="51"/>
<rectangle x1="22.89" y1="-1.03" x2="23.31" y2="-0.53" layer="51"/>
<rectangle x1="23.33" y1="-1.03" x2="23.75" y2="-0.53" layer="51"/>
<rectangle x1="23.77" y1="-1.03" x2="24.19" y2="-0.53" layer="51"/>
<rectangle x1="24.21" y1="-1.03" x2="24.63" y2="-0.53" layer="51"/>
<rectangle x1="24.65" y1="-1.03" x2="25.07" y2="-0.53" layer="51"/>
<rectangle x1="25.09" y1="-1.03" x2="25.51" y2="-0.53" layer="51"/>
<rectangle x1="25.53" y1="-1.03" x2="25.95" y2="-0.53" layer="51"/>
<rectangle x1="25.97" y1="-1.03" x2="26.39" y2="-0.53" layer="51"/>
<rectangle x1="26.41" y1="-1.03" x2="26.83" y2="-0.53" layer="51"/>
<rectangle x1="26.85" y1="-1.03" x2="27.27" y2="-0.53" layer="51"/>
<rectangle x1="27.29" y1="-1.03" x2="27.71" y2="-0.53" layer="51"/>
<rectangle x1="27.73" y1="-1.03" x2="28.15" y2="-0.53" layer="51"/>
<rectangle x1="-28.15" y1="-1.55" x2="-27.73" y2="-1.05" layer="51"/>
<rectangle x1="-27.71" y1="-1.55" x2="-27.29" y2="-1.05" layer="51"/>
<rectangle x1="-27.27" y1="-1.55" x2="-26.85" y2="-1.05" layer="51"/>
<rectangle x1="-26.83" y1="-1.55" x2="-26.41" y2="-1.05" layer="51"/>
<rectangle x1="-26.39" y1="-1.55" x2="-25.97" y2="-1.05" layer="51"/>
<rectangle x1="-25.95" y1="-1.55" x2="-25.53" y2="-1.05" layer="51"/>
<rectangle x1="-25.51" y1="-1.55" x2="-25.09" y2="-1.05" layer="51"/>
<rectangle x1="-25.07" y1="-1.55" x2="-24.65" y2="-1.05" layer="51"/>
<rectangle x1="-24.63" y1="-1.55" x2="-24.21" y2="-1.05" layer="51"/>
<rectangle x1="-24.19" y1="-1.55" x2="-23.77" y2="-1.05" layer="51"/>
<rectangle x1="-23.75" y1="-1.55" x2="-23.33" y2="-1.05" layer="51"/>
<rectangle x1="-23.31" y1="-1.55" x2="-22.89" y2="-1.05" layer="51"/>
<rectangle x1="-22.87" y1="-1.55" x2="-22.45" y2="-1.05" layer="51"/>
<rectangle x1="-22.43" y1="-1.55" x2="-22.01" y2="-1.05" layer="51"/>
<rectangle x1="-21.99" y1="-1.55" x2="-21.57" y2="-1.05" layer="51"/>
<rectangle x1="-21.55" y1="-1.55" x2="-21.13" y2="-1.05" layer="51"/>
<rectangle x1="-21.11" y1="-1.55" x2="-20.69" y2="-1.05" layer="51"/>
<rectangle x1="-20.67" y1="-1.55" x2="-20.25" y2="-1.05" layer="51"/>
<rectangle x1="-20.23" y1="-1.55" x2="-19.81" y2="-1.05" layer="51"/>
<rectangle x1="-19.79" y1="-1.55" x2="-19.37" y2="-1.05" layer="51"/>
<rectangle x1="-19.35" y1="-1.55" x2="-18.93" y2="-1.05" layer="51"/>
<rectangle x1="-18.91" y1="-1.55" x2="-18.49" y2="-1.05" layer="51"/>
<rectangle x1="-18.47" y1="-1.55" x2="-18.05" y2="-1.05" layer="51"/>
<rectangle x1="-18.03" y1="-1.55" x2="-17.61" y2="-1.05" layer="51"/>
<rectangle x1="-17.59" y1="-1.55" x2="-17.17" y2="-1.05" layer="51"/>
<rectangle x1="-17.15" y1="-1.55" x2="-16.73" y2="-1.05" layer="51"/>
<rectangle x1="-16.71" y1="-1.55" x2="-16.29" y2="-1.05" layer="51"/>
<rectangle x1="-16.27" y1="-1.55" x2="-15.85" y2="-1.05" layer="51"/>
<rectangle x1="-15.83" y1="-1.55" x2="-15.41" y2="-1.05" layer="51"/>
<rectangle x1="-15.39" y1="-1.55" x2="-14.97" y2="-1.05" layer="51"/>
<rectangle x1="-14.95" y1="-1.55" x2="-14.53" y2="-1.05" layer="51"/>
<rectangle x1="-14.51" y1="-1.55" x2="-14.09" y2="-1.05" layer="51"/>
<rectangle x1="-14.07" y1="-1.55" x2="-13.65" y2="-1.05" layer="51"/>
<rectangle x1="-13.63" y1="-1.55" x2="-13.21" y2="-1.05" layer="51"/>
<rectangle x1="-13.19" y1="-1.55" x2="-12.77" y2="-1.05" layer="51"/>
<rectangle x1="-12.75" y1="-1.55" x2="-12.33" y2="-1.05" layer="51"/>
<rectangle x1="-12.31" y1="-1.55" x2="-11.89" y2="-1.05" layer="51"/>
<rectangle x1="-11.87" y1="-1.55" x2="-11.45" y2="-1.05" layer="51"/>
<rectangle x1="-11.43" y1="-1.55" x2="-11.01" y2="-1.05" layer="51"/>
<rectangle x1="-10.99" y1="-1.55" x2="-10.57" y2="-1.05" layer="51"/>
<rectangle x1="-10.55" y1="-1.55" x2="-10.13" y2="-1.05" layer="51"/>
<rectangle x1="-10.11" y1="-1.55" x2="-9.69" y2="-1.05" layer="51"/>
<rectangle x1="-9.67" y1="-1.55" x2="-9.25" y2="-1.05" layer="51"/>
<rectangle x1="-9.23" y1="-1.55" x2="-8.81" y2="-1.05" layer="51"/>
<rectangle x1="-8.79" y1="-1.55" x2="-8.37" y2="-1.05" layer="51"/>
<rectangle x1="-8.35" y1="-1.55" x2="-7.93" y2="-1.05" layer="51"/>
<rectangle x1="-7.91" y1="-1.55" x2="-7.49" y2="-1.05" layer="51"/>
<rectangle x1="-7.47" y1="-1.55" x2="-7.05" y2="-1.05" layer="51"/>
<rectangle x1="-7.03" y1="-1.55" x2="-6.61" y2="-1.05" layer="51"/>
<rectangle x1="-6.59" y1="-1.55" x2="-6.17" y2="-1.05" layer="51"/>
<rectangle x1="-6.15" y1="-1.55" x2="-5.73" y2="-1.05" layer="51"/>
<rectangle x1="-5.71" y1="-1.55" x2="-5.29" y2="-1.05" layer="51"/>
<rectangle x1="-5.27" y1="-1.55" x2="-4.85" y2="-1.05" layer="51"/>
<rectangle x1="-4.83" y1="-1.55" x2="-4.41" y2="-1.05" layer="51"/>
<rectangle x1="-4.39" y1="-1.55" x2="-3.97" y2="-1.05" layer="51"/>
<rectangle x1="-3.95" y1="-1.55" x2="-3.53" y2="-1.05" layer="51"/>
<rectangle x1="-3.51" y1="-1.55" x2="-3.09" y2="-1.05" layer="51"/>
<rectangle x1="-3.07" y1="-1.55" x2="-2.65" y2="-1.05" layer="51"/>
<rectangle x1="-2.63" y1="-1.55" x2="-2.21" y2="-1.05" layer="51"/>
<rectangle x1="-2.19" y1="-1.55" x2="-1.77" y2="-1.05" layer="51"/>
<rectangle x1="-1.75" y1="-1.55" x2="-1.33" y2="-1.05" layer="51"/>
<rectangle x1="-1.31" y1="-1.55" x2="-0.89" y2="-1.05" layer="51"/>
<rectangle x1="-0.87" y1="-1.55" x2="-0.45" y2="-1.05" layer="51"/>
<rectangle x1="-0.43" y1="-1.55" x2="-0.01" y2="-1.05" layer="51"/>
<rectangle x1="0.01" y1="-1.55" x2="0.43" y2="-1.05" layer="51"/>
<rectangle x1="0.45" y1="-1.55" x2="0.87" y2="-1.05" layer="51"/>
<rectangle x1="0.89" y1="-1.55" x2="1.31" y2="-1.05" layer="51"/>
<rectangle x1="1.33" y1="-1.55" x2="1.75" y2="-1.05" layer="51"/>
<rectangle x1="1.77" y1="-1.55" x2="2.19" y2="-1.05" layer="51"/>
<rectangle x1="2.21" y1="-1.55" x2="2.63" y2="-1.05" layer="51"/>
<rectangle x1="2.65" y1="-1.55" x2="3.07" y2="-1.05" layer="51"/>
<rectangle x1="3.09" y1="-1.55" x2="3.51" y2="-1.05" layer="51"/>
<rectangle x1="3.53" y1="-1.55" x2="3.95" y2="-1.05" layer="51"/>
<rectangle x1="3.97" y1="-1.55" x2="4.39" y2="-1.05" layer="51"/>
<rectangle x1="4.41" y1="-1.55" x2="4.83" y2="-1.05" layer="51"/>
<rectangle x1="4.85" y1="-1.55" x2="5.27" y2="-1.05" layer="51"/>
<rectangle x1="5.29" y1="-1.55" x2="5.71" y2="-1.05" layer="51"/>
<rectangle x1="5.73" y1="-1.55" x2="6.15" y2="-1.05" layer="51"/>
<rectangle x1="6.17" y1="-1.55" x2="6.59" y2="-1.05" layer="51"/>
<rectangle x1="6.61" y1="-1.55" x2="7.03" y2="-1.05" layer="51"/>
<rectangle x1="7.05" y1="-1.55" x2="7.47" y2="-1.05" layer="51"/>
<rectangle x1="7.49" y1="-1.55" x2="7.91" y2="-1.05" layer="51"/>
<rectangle x1="7.93" y1="-1.55" x2="8.35" y2="-1.05" layer="51"/>
<rectangle x1="8.37" y1="-1.55" x2="8.79" y2="-1.05" layer="51"/>
<rectangle x1="8.81" y1="-1.55" x2="9.23" y2="-1.05" layer="51"/>
<rectangle x1="9.25" y1="-1.55" x2="9.67" y2="-1.05" layer="51"/>
<rectangle x1="9.69" y1="-1.55" x2="10.11" y2="-1.05" layer="51"/>
<rectangle x1="10.13" y1="-1.55" x2="10.55" y2="-1.05" layer="51"/>
<rectangle x1="10.57" y1="-1.55" x2="10.99" y2="-1.05" layer="51"/>
<rectangle x1="11.01" y1="-1.55" x2="11.43" y2="-1.05" layer="51"/>
<rectangle x1="11.45" y1="-1.55" x2="11.87" y2="-1.05" layer="51"/>
<rectangle x1="11.89" y1="-1.55" x2="12.31" y2="-1.05" layer="51"/>
<rectangle x1="12.33" y1="-1.55" x2="12.75" y2="-1.05" layer="51"/>
<rectangle x1="12.77" y1="-1.55" x2="13.19" y2="-1.05" layer="51"/>
<rectangle x1="13.21" y1="-1.55" x2="13.63" y2="-1.05" layer="51"/>
<rectangle x1="13.65" y1="-1.55" x2="14.07" y2="-1.05" layer="51"/>
<rectangle x1="14.09" y1="-1.55" x2="14.51" y2="-1.05" layer="51"/>
<rectangle x1="14.53" y1="-1.55" x2="14.95" y2="-1.05" layer="51"/>
<rectangle x1="14.97" y1="-1.55" x2="15.39" y2="-1.05" layer="51"/>
<rectangle x1="15.41" y1="-1.55" x2="15.83" y2="-1.05" layer="51"/>
<rectangle x1="15.85" y1="-1.55" x2="16.27" y2="-1.05" layer="51"/>
<rectangle x1="16.29" y1="-1.55" x2="16.71" y2="-1.05" layer="51"/>
<rectangle x1="16.73" y1="-1.55" x2="17.15" y2="-1.05" layer="51"/>
<rectangle x1="17.17" y1="-1.55" x2="17.59" y2="-1.05" layer="51"/>
<rectangle x1="17.61" y1="-1.55" x2="18.03" y2="-1.05" layer="51"/>
<rectangle x1="18.05" y1="-1.55" x2="18.47" y2="-1.05" layer="51"/>
<rectangle x1="18.49" y1="-1.55" x2="18.91" y2="-1.05" layer="51"/>
<rectangle x1="18.93" y1="-1.55" x2="19.35" y2="-1.05" layer="51"/>
<rectangle x1="19.37" y1="-1.55" x2="19.79" y2="-1.05" layer="51"/>
<rectangle x1="19.81" y1="-1.55" x2="20.23" y2="-1.05" layer="51"/>
<rectangle x1="20.25" y1="-1.55" x2="20.67" y2="-1.05" layer="51"/>
<rectangle x1="20.69" y1="-1.55" x2="21.11" y2="-1.05" layer="51"/>
<rectangle x1="21.13" y1="-1.55" x2="21.55" y2="-1.05" layer="51"/>
<rectangle x1="21.57" y1="-1.55" x2="21.99" y2="-1.05" layer="51"/>
<rectangle x1="22.01" y1="-1.55" x2="22.43" y2="-1.05" layer="51"/>
<rectangle x1="22.45" y1="-1.55" x2="22.87" y2="-1.05" layer="51"/>
<rectangle x1="22.89" y1="-1.55" x2="23.31" y2="-1.05" layer="51"/>
<rectangle x1="23.33" y1="-1.55" x2="23.75" y2="-1.05" layer="51"/>
<rectangle x1="23.77" y1="-1.55" x2="24.19" y2="-1.05" layer="51"/>
<rectangle x1="24.21" y1="-1.55" x2="24.63" y2="-1.05" layer="51"/>
<rectangle x1="24.65" y1="-1.55" x2="25.07" y2="-1.05" layer="51"/>
<rectangle x1="25.09" y1="-1.55" x2="25.51" y2="-1.05" layer="51"/>
<rectangle x1="25.53" y1="-1.55" x2="25.95" y2="-1.05" layer="51"/>
<rectangle x1="25.97" y1="-1.55" x2="26.39" y2="-1.05" layer="51"/>
<rectangle x1="26.41" y1="-1.55" x2="26.83" y2="-1.05" layer="51"/>
<rectangle x1="26.85" y1="-1.55" x2="27.27" y2="-1.05" layer="51"/>
<rectangle x1="27.29" y1="-1.55" x2="27.71" y2="-1.05" layer="51"/>
<rectangle x1="27.73" y1="-1.55" x2="28.15" y2="-1.05" layer="51"/>
<rectangle x1="-28.15" y1="-2.07" x2="-27.73" y2="-1.57" layer="51"/>
<rectangle x1="-27.71" y1="-2.07" x2="-27.29" y2="-1.57" layer="51"/>
<rectangle x1="-27.27" y1="-2.07" x2="-26.85" y2="-1.57" layer="51"/>
<rectangle x1="-26.83" y1="-2.07" x2="-26.41" y2="-1.57" layer="51"/>
<rectangle x1="-26.39" y1="-2.07" x2="-25.97" y2="-1.57" layer="51"/>
<rectangle x1="-25.95" y1="-2.07" x2="-25.53" y2="-1.57" layer="51"/>
<rectangle x1="-25.51" y1="-2.07" x2="-25.09" y2="-1.57" layer="51"/>
<rectangle x1="-25.07" y1="-2.07" x2="-24.65" y2="-1.57" layer="51"/>
<rectangle x1="-24.63" y1="-2.07" x2="-24.21" y2="-1.57" layer="51"/>
<rectangle x1="-24.19" y1="-2.07" x2="-23.77" y2="-1.57" layer="51"/>
<rectangle x1="-23.75" y1="-2.07" x2="-23.33" y2="-1.57" layer="51"/>
<rectangle x1="-23.31" y1="-2.07" x2="-22.89" y2="-1.57" layer="51"/>
<rectangle x1="-22.87" y1="-2.07" x2="-22.45" y2="-1.57" layer="51"/>
<rectangle x1="-22.43" y1="-2.07" x2="-22.01" y2="-1.57" layer="51"/>
<rectangle x1="-21.99" y1="-2.07" x2="-21.57" y2="-1.57" layer="51"/>
<rectangle x1="-21.55" y1="-2.07" x2="-21.13" y2="-1.57" layer="51"/>
<rectangle x1="-21.11" y1="-2.07" x2="-20.69" y2="-1.57" layer="51"/>
<rectangle x1="-20.67" y1="-2.07" x2="-20.25" y2="-1.57" layer="51"/>
<rectangle x1="-20.23" y1="-2.07" x2="-19.81" y2="-1.57" layer="51"/>
<rectangle x1="-19.79" y1="-2.07" x2="-19.37" y2="-1.57" layer="51"/>
<rectangle x1="-19.35" y1="-2.07" x2="-18.93" y2="-1.57" layer="51"/>
<rectangle x1="-18.91" y1="-2.07" x2="-18.49" y2="-1.57" layer="51"/>
<rectangle x1="-18.47" y1="-2.07" x2="-18.05" y2="-1.57" layer="51"/>
<rectangle x1="-18.03" y1="-2.07" x2="-17.61" y2="-1.57" layer="51"/>
<rectangle x1="-17.59" y1="-2.07" x2="-17.17" y2="-1.57" layer="51"/>
<rectangle x1="-17.15" y1="-2.07" x2="-16.73" y2="-1.57" layer="51"/>
<rectangle x1="-16.71" y1="-2.07" x2="-16.29" y2="-1.57" layer="51"/>
<rectangle x1="-16.27" y1="-2.07" x2="-15.85" y2="-1.57" layer="51"/>
<rectangle x1="-15.83" y1="-2.07" x2="-15.41" y2="-1.57" layer="51"/>
<rectangle x1="-15.39" y1="-2.07" x2="-14.97" y2="-1.57" layer="51"/>
<rectangle x1="-14.95" y1="-2.07" x2="-14.53" y2="-1.57" layer="51"/>
<rectangle x1="-14.51" y1="-2.07" x2="-14.09" y2="-1.57" layer="51"/>
<rectangle x1="-14.07" y1="-2.07" x2="-13.65" y2="-1.57" layer="51"/>
<rectangle x1="-13.63" y1="-2.07" x2="-13.21" y2="-1.57" layer="51"/>
<rectangle x1="-13.19" y1="-2.07" x2="-12.77" y2="-1.57" layer="51"/>
<rectangle x1="-12.75" y1="-2.07" x2="-12.33" y2="-1.57" layer="51"/>
<rectangle x1="-12.31" y1="-2.07" x2="-11.89" y2="-1.57" layer="51"/>
<rectangle x1="-11.87" y1="-2.07" x2="-11.45" y2="-1.57" layer="51"/>
<rectangle x1="-11.43" y1="-2.07" x2="-11.01" y2="-1.57" layer="51"/>
<rectangle x1="-10.99" y1="-2.07" x2="-10.57" y2="-1.57" layer="51"/>
<rectangle x1="-10.55" y1="-2.07" x2="-10.13" y2="-1.57" layer="51"/>
<rectangle x1="-10.11" y1="-2.07" x2="-9.69" y2="-1.57" layer="51"/>
<rectangle x1="-9.67" y1="-2.07" x2="-9.25" y2="-1.57" layer="51"/>
<rectangle x1="-9.23" y1="-2.07" x2="-8.81" y2="-1.57" layer="51"/>
<rectangle x1="-8.79" y1="-2.07" x2="-8.37" y2="-1.57" layer="51"/>
<rectangle x1="-8.35" y1="-2.07" x2="-7.93" y2="-1.57" layer="51"/>
<rectangle x1="-7.91" y1="-2.07" x2="-7.49" y2="-1.57" layer="51"/>
<rectangle x1="-7.47" y1="-2.07" x2="-7.05" y2="-1.57" layer="51"/>
<rectangle x1="-7.03" y1="-2.07" x2="-6.61" y2="-1.57" layer="51"/>
<rectangle x1="-6.59" y1="-2.07" x2="-6.17" y2="-1.57" layer="51"/>
<rectangle x1="-6.15" y1="-2.07" x2="-5.73" y2="-1.57" layer="51"/>
<rectangle x1="-5.71" y1="-2.07" x2="-5.29" y2="-1.57" layer="51"/>
<rectangle x1="-5.27" y1="-2.07" x2="-4.85" y2="-1.57" layer="51"/>
<rectangle x1="-4.83" y1="-2.07" x2="-4.41" y2="-1.57" layer="51"/>
<rectangle x1="-4.39" y1="-2.07" x2="-3.97" y2="-1.57" layer="51"/>
<rectangle x1="-3.95" y1="-2.07" x2="-3.53" y2="-1.57" layer="51"/>
<rectangle x1="-3.51" y1="-2.07" x2="-3.09" y2="-1.57" layer="51"/>
<rectangle x1="-3.07" y1="-2.07" x2="-2.65" y2="-1.57" layer="51"/>
<rectangle x1="-2.63" y1="-2.07" x2="-2.21" y2="-1.57" layer="51"/>
<rectangle x1="-2.19" y1="-2.07" x2="-1.77" y2="-1.57" layer="51"/>
<rectangle x1="-1.75" y1="-2.07" x2="-1.33" y2="-1.57" layer="51"/>
<rectangle x1="-1.31" y1="-2.07" x2="-0.89" y2="-1.57" layer="51"/>
<rectangle x1="-0.87" y1="-2.07" x2="-0.45" y2="-1.57" layer="51"/>
<rectangle x1="-0.43" y1="-2.07" x2="-0.01" y2="-1.57" layer="51"/>
<rectangle x1="0.01" y1="-2.07" x2="0.43" y2="-1.57" layer="51"/>
<rectangle x1="0.45" y1="-2.07" x2="0.87" y2="-1.57" layer="51"/>
<rectangle x1="0.89" y1="-2.07" x2="1.31" y2="-1.57" layer="51"/>
<rectangle x1="1.33" y1="-2.07" x2="1.75" y2="-1.57" layer="51"/>
<rectangle x1="1.77" y1="-2.07" x2="2.19" y2="-1.57" layer="51"/>
<rectangle x1="2.21" y1="-2.07" x2="2.63" y2="-1.57" layer="51"/>
<rectangle x1="2.65" y1="-2.07" x2="3.07" y2="-1.57" layer="51"/>
<rectangle x1="3.09" y1="-2.07" x2="3.51" y2="-1.57" layer="51"/>
<rectangle x1="3.53" y1="-2.07" x2="3.95" y2="-1.57" layer="51"/>
<rectangle x1="3.97" y1="-2.07" x2="4.39" y2="-1.57" layer="51"/>
<rectangle x1="4.41" y1="-2.07" x2="4.83" y2="-1.57" layer="51"/>
<rectangle x1="4.85" y1="-2.07" x2="5.27" y2="-1.57" layer="51"/>
<rectangle x1="5.29" y1="-2.07" x2="5.71" y2="-1.57" layer="51"/>
<rectangle x1="5.73" y1="-2.07" x2="6.15" y2="-1.57" layer="51"/>
<rectangle x1="6.17" y1="-2.07" x2="6.59" y2="-1.57" layer="51"/>
<rectangle x1="6.61" y1="-2.07" x2="7.03" y2="-1.57" layer="51"/>
<rectangle x1="7.05" y1="-2.07" x2="7.47" y2="-1.57" layer="51"/>
<rectangle x1="7.49" y1="-2.07" x2="7.91" y2="-1.57" layer="51"/>
<rectangle x1="7.93" y1="-2.07" x2="8.35" y2="-1.57" layer="51"/>
<rectangle x1="8.37" y1="-2.07" x2="8.79" y2="-1.57" layer="51"/>
<rectangle x1="8.81" y1="-2.07" x2="9.23" y2="-1.57" layer="51"/>
<rectangle x1="9.25" y1="-2.07" x2="9.67" y2="-1.57" layer="51"/>
<rectangle x1="9.69" y1="-2.07" x2="10.11" y2="-1.57" layer="51"/>
<rectangle x1="10.13" y1="-2.07" x2="10.55" y2="-1.57" layer="51"/>
<rectangle x1="10.57" y1="-2.07" x2="10.99" y2="-1.57" layer="51"/>
<rectangle x1="11.01" y1="-2.07" x2="11.43" y2="-1.57" layer="51"/>
<rectangle x1="11.45" y1="-2.07" x2="11.87" y2="-1.57" layer="51"/>
<rectangle x1="11.89" y1="-2.07" x2="12.31" y2="-1.57" layer="51"/>
<rectangle x1="12.33" y1="-2.07" x2="12.75" y2="-1.57" layer="51"/>
<rectangle x1="12.77" y1="-2.07" x2="13.19" y2="-1.57" layer="51"/>
<rectangle x1="13.21" y1="-2.07" x2="13.63" y2="-1.57" layer="51"/>
<rectangle x1="13.65" y1="-2.07" x2="14.07" y2="-1.57" layer="51"/>
<rectangle x1="14.09" y1="-2.07" x2="14.51" y2="-1.57" layer="51"/>
<rectangle x1="14.53" y1="-2.07" x2="14.95" y2="-1.57" layer="51"/>
<rectangle x1="14.97" y1="-2.07" x2="15.39" y2="-1.57" layer="51"/>
<rectangle x1="15.41" y1="-2.07" x2="15.83" y2="-1.57" layer="51"/>
<rectangle x1="15.85" y1="-2.07" x2="16.27" y2="-1.57" layer="51"/>
<rectangle x1="16.29" y1="-2.07" x2="16.71" y2="-1.57" layer="51"/>
<rectangle x1="16.73" y1="-2.07" x2="17.15" y2="-1.57" layer="51"/>
<rectangle x1="17.17" y1="-2.07" x2="17.59" y2="-1.57" layer="51"/>
<rectangle x1="17.61" y1="-2.07" x2="18.03" y2="-1.57" layer="51"/>
<rectangle x1="18.05" y1="-2.07" x2="18.47" y2="-1.57" layer="51"/>
<rectangle x1="18.49" y1="-2.07" x2="18.91" y2="-1.57" layer="51"/>
<rectangle x1="18.93" y1="-2.07" x2="19.35" y2="-1.57" layer="51"/>
<rectangle x1="19.37" y1="-2.07" x2="19.79" y2="-1.57" layer="51"/>
<rectangle x1="19.81" y1="-2.07" x2="20.23" y2="-1.57" layer="51"/>
<rectangle x1="20.25" y1="-2.07" x2="20.67" y2="-1.57" layer="51"/>
<rectangle x1="20.69" y1="-2.07" x2="21.11" y2="-1.57" layer="51"/>
<rectangle x1="21.13" y1="-2.07" x2="21.55" y2="-1.57" layer="51"/>
<rectangle x1="21.57" y1="-2.07" x2="21.99" y2="-1.57" layer="51"/>
<rectangle x1="22.01" y1="-2.07" x2="22.43" y2="-1.57" layer="51"/>
<rectangle x1="22.45" y1="-2.07" x2="22.87" y2="-1.57" layer="51"/>
<rectangle x1="22.89" y1="-2.07" x2="23.31" y2="-1.57" layer="51"/>
<rectangle x1="23.33" y1="-2.07" x2="23.75" y2="-1.57" layer="51"/>
<rectangle x1="23.77" y1="-2.07" x2="24.19" y2="-1.57" layer="51"/>
<rectangle x1="24.21" y1="-2.07" x2="24.63" y2="-1.57" layer="51"/>
<rectangle x1="24.65" y1="-2.07" x2="25.07" y2="-1.57" layer="51"/>
<rectangle x1="25.09" y1="-2.07" x2="25.51" y2="-1.57" layer="51"/>
<rectangle x1="25.53" y1="-2.07" x2="25.95" y2="-1.57" layer="51"/>
<rectangle x1="25.97" y1="-2.07" x2="26.39" y2="-1.57" layer="51"/>
<rectangle x1="26.41" y1="-2.07" x2="26.83" y2="-1.57" layer="51"/>
<rectangle x1="26.85" y1="-2.07" x2="27.27" y2="-1.57" layer="51"/>
<rectangle x1="27.29" y1="-2.07" x2="27.71" y2="-1.57" layer="51"/>
<rectangle x1="27.73" y1="-2.07" x2="28.15" y2="-1.57" layer="51"/>
<rectangle x1="-28.15" y1="-2.59" x2="-27.73" y2="-2.09" layer="51"/>
<rectangle x1="-27.71" y1="-2.59" x2="-27.29" y2="-2.09" layer="51"/>
<rectangle x1="-27.27" y1="-2.59" x2="-26.85" y2="-2.09" layer="51"/>
<rectangle x1="-26.83" y1="-2.59" x2="-26.41" y2="-2.09" layer="51"/>
<rectangle x1="-26.39" y1="-2.59" x2="-25.97" y2="-2.09" layer="51"/>
<rectangle x1="-25.95" y1="-2.59" x2="-25.53" y2="-2.09" layer="51"/>
<rectangle x1="-25.51" y1="-2.59" x2="-25.09" y2="-2.09" layer="51"/>
<rectangle x1="-25.07" y1="-2.59" x2="-24.65" y2="-2.09" layer="51"/>
<rectangle x1="-24.63" y1="-2.59" x2="-24.21" y2="-2.09" layer="51"/>
<rectangle x1="-24.19" y1="-2.59" x2="-23.77" y2="-2.09" layer="51"/>
<rectangle x1="-23.75" y1="-2.59" x2="-23.33" y2="-2.09" layer="51"/>
<rectangle x1="-23.31" y1="-2.59" x2="-22.89" y2="-2.09" layer="51"/>
<rectangle x1="-22.87" y1="-2.59" x2="-22.45" y2="-2.09" layer="51"/>
<rectangle x1="-22.43" y1="-2.59" x2="-22.01" y2="-2.09" layer="51"/>
<rectangle x1="-21.99" y1="-2.59" x2="-21.57" y2="-2.09" layer="51"/>
<rectangle x1="-21.55" y1="-2.59" x2="-21.13" y2="-2.09" layer="51"/>
<rectangle x1="-21.11" y1="-2.59" x2="-20.69" y2="-2.09" layer="51"/>
<rectangle x1="-20.67" y1="-2.59" x2="-20.25" y2="-2.09" layer="51"/>
<rectangle x1="-20.23" y1="-2.59" x2="-19.81" y2="-2.09" layer="51"/>
<rectangle x1="-19.79" y1="-2.59" x2="-19.37" y2="-2.09" layer="51"/>
<rectangle x1="-19.35" y1="-2.59" x2="-18.93" y2="-2.09" layer="51"/>
<rectangle x1="-18.91" y1="-2.59" x2="-18.49" y2="-2.09" layer="51"/>
<rectangle x1="-18.47" y1="-2.59" x2="-18.05" y2="-2.09" layer="51"/>
<rectangle x1="-18.03" y1="-2.59" x2="-17.61" y2="-2.09" layer="51"/>
<rectangle x1="-17.59" y1="-2.59" x2="-17.17" y2="-2.09" layer="51"/>
<rectangle x1="-17.15" y1="-2.59" x2="-16.73" y2="-2.09" layer="51"/>
<rectangle x1="-16.71" y1="-2.59" x2="-16.29" y2="-2.09" layer="51"/>
<rectangle x1="-16.27" y1="-2.59" x2="-15.85" y2="-2.09" layer="51"/>
<rectangle x1="-15.83" y1="-2.59" x2="-15.41" y2="-2.09" layer="51"/>
<rectangle x1="-15.39" y1="-2.59" x2="-14.97" y2="-2.09" layer="51"/>
<rectangle x1="-14.95" y1="-2.59" x2="-14.53" y2="-2.09" layer="51"/>
<rectangle x1="-14.51" y1="-2.59" x2="-14.09" y2="-2.09" layer="51"/>
<rectangle x1="-14.07" y1="-2.59" x2="-13.65" y2="-2.09" layer="51"/>
<rectangle x1="-13.63" y1="-2.59" x2="-13.21" y2="-2.09" layer="51"/>
<rectangle x1="-13.19" y1="-2.59" x2="-12.77" y2="-2.09" layer="51"/>
<rectangle x1="-12.75" y1="-2.59" x2="-12.33" y2="-2.09" layer="51"/>
<rectangle x1="-12.31" y1="-2.59" x2="-11.89" y2="-2.09" layer="51"/>
<rectangle x1="-11.87" y1="-2.59" x2="-11.45" y2="-2.09" layer="51"/>
<rectangle x1="-11.43" y1="-2.59" x2="-11.01" y2="-2.09" layer="51"/>
<rectangle x1="-10.99" y1="-2.59" x2="-10.57" y2="-2.09" layer="51"/>
<rectangle x1="-10.55" y1="-2.59" x2="-10.13" y2="-2.09" layer="51"/>
<rectangle x1="-10.11" y1="-2.59" x2="-9.69" y2="-2.09" layer="51"/>
<rectangle x1="-9.67" y1="-2.59" x2="-9.25" y2="-2.09" layer="51"/>
<rectangle x1="-9.23" y1="-2.59" x2="-8.81" y2="-2.09" layer="51"/>
<rectangle x1="-8.79" y1="-2.59" x2="-8.37" y2="-2.09" layer="51"/>
<rectangle x1="-8.35" y1="-2.59" x2="-7.93" y2="-2.09" layer="51"/>
<rectangle x1="-7.91" y1="-2.59" x2="-7.49" y2="-2.09" layer="51"/>
<rectangle x1="-7.47" y1="-2.59" x2="-7.05" y2="-2.09" layer="51"/>
<rectangle x1="-7.03" y1="-2.59" x2="-6.61" y2="-2.09" layer="51"/>
<rectangle x1="-6.59" y1="-2.59" x2="-6.17" y2="-2.09" layer="51"/>
<rectangle x1="-6.15" y1="-2.59" x2="-5.73" y2="-2.09" layer="51"/>
<rectangle x1="-5.71" y1="-2.59" x2="-5.29" y2="-2.09" layer="51"/>
<rectangle x1="-5.27" y1="-2.59" x2="-4.85" y2="-2.09" layer="51"/>
<rectangle x1="-4.83" y1="-2.59" x2="-4.41" y2="-2.09" layer="51"/>
<rectangle x1="-4.39" y1="-2.59" x2="-3.97" y2="-2.09" layer="51"/>
<rectangle x1="-3.95" y1="-2.59" x2="-3.53" y2="-2.09" layer="51"/>
<rectangle x1="-3.51" y1="-2.59" x2="-3.09" y2="-2.09" layer="51"/>
<rectangle x1="-3.07" y1="-2.59" x2="-2.65" y2="-2.09" layer="51"/>
<rectangle x1="-2.63" y1="-2.59" x2="-2.21" y2="-2.09" layer="51"/>
<rectangle x1="-2.19" y1="-2.59" x2="-1.77" y2="-2.09" layer="51"/>
<rectangle x1="-1.75" y1="-2.59" x2="-1.33" y2="-2.09" layer="51"/>
<rectangle x1="-1.31" y1="-2.59" x2="-0.89" y2="-2.09" layer="51"/>
<rectangle x1="-0.87" y1="-2.59" x2="-0.45" y2="-2.09" layer="51"/>
<rectangle x1="-0.43" y1="-2.59" x2="-0.01" y2="-2.09" layer="51"/>
<rectangle x1="0.01" y1="-2.59" x2="0.43" y2="-2.09" layer="51"/>
<rectangle x1="0.45" y1="-2.59" x2="0.87" y2="-2.09" layer="51"/>
<rectangle x1="0.89" y1="-2.59" x2="1.31" y2="-2.09" layer="51"/>
<rectangle x1="1.33" y1="-2.59" x2="1.75" y2="-2.09" layer="51"/>
<rectangle x1="1.77" y1="-2.59" x2="2.19" y2="-2.09" layer="51"/>
<rectangle x1="2.21" y1="-2.59" x2="2.63" y2="-2.09" layer="51"/>
<rectangle x1="2.65" y1="-2.59" x2="3.07" y2="-2.09" layer="51"/>
<rectangle x1="3.09" y1="-2.59" x2="3.51" y2="-2.09" layer="51"/>
<rectangle x1="3.53" y1="-2.59" x2="3.95" y2="-2.09" layer="51"/>
<rectangle x1="3.97" y1="-2.59" x2="4.39" y2="-2.09" layer="51"/>
<rectangle x1="4.41" y1="-2.59" x2="4.83" y2="-2.09" layer="51"/>
<rectangle x1="4.85" y1="-2.59" x2="5.27" y2="-2.09" layer="51"/>
<rectangle x1="5.29" y1="-2.59" x2="5.71" y2="-2.09" layer="51"/>
<rectangle x1="5.73" y1="-2.59" x2="6.15" y2="-2.09" layer="51"/>
<rectangle x1="6.17" y1="-2.59" x2="6.59" y2="-2.09" layer="51"/>
<rectangle x1="6.61" y1="-2.59" x2="7.03" y2="-2.09" layer="51"/>
<rectangle x1="7.05" y1="-2.59" x2="7.47" y2="-2.09" layer="51"/>
<rectangle x1="7.49" y1="-2.59" x2="7.91" y2="-2.09" layer="51"/>
<rectangle x1="7.93" y1="-2.59" x2="8.35" y2="-2.09" layer="51"/>
<rectangle x1="8.37" y1="-2.59" x2="8.79" y2="-2.09" layer="51"/>
<rectangle x1="8.81" y1="-2.59" x2="9.23" y2="-2.09" layer="51"/>
<rectangle x1="9.25" y1="-2.59" x2="9.67" y2="-2.09" layer="51"/>
<rectangle x1="9.69" y1="-2.59" x2="10.11" y2="-2.09" layer="51"/>
<rectangle x1="10.13" y1="-2.59" x2="10.55" y2="-2.09" layer="51"/>
<rectangle x1="10.57" y1="-2.59" x2="10.99" y2="-2.09" layer="51"/>
<rectangle x1="11.01" y1="-2.59" x2="11.43" y2="-2.09" layer="51"/>
<rectangle x1="11.45" y1="-2.59" x2="11.87" y2="-2.09" layer="51"/>
<rectangle x1="11.89" y1="-2.59" x2="12.31" y2="-2.09" layer="51"/>
<rectangle x1="12.33" y1="-2.59" x2="12.75" y2="-2.09" layer="51"/>
<rectangle x1="12.77" y1="-2.59" x2="13.19" y2="-2.09" layer="51"/>
<rectangle x1="13.21" y1="-2.59" x2="13.63" y2="-2.09" layer="51"/>
<rectangle x1="13.65" y1="-2.59" x2="14.07" y2="-2.09" layer="51"/>
<rectangle x1="14.09" y1="-2.59" x2="14.51" y2="-2.09" layer="51"/>
<rectangle x1="14.53" y1="-2.59" x2="14.95" y2="-2.09" layer="51"/>
<rectangle x1="14.97" y1="-2.59" x2="15.39" y2="-2.09" layer="51"/>
<rectangle x1="15.41" y1="-2.59" x2="15.83" y2="-2.09" layer="51"/>
<rectangle x1="15.85" y1="-2.59" x2="16.27" y2="-2.09" layer="51"/>
<rectangle x1="16.29" y1="-2.59" x2="16.71" y2="-2.09" layer="51"/>
<rectangle x1="16.73" y1="-2.59" x2="17.15" y2="-2.09" layer="51"/>
<rectangle x1="17.17" y1="-2.59" x2="17.59" y2="-2.09" layer="51"/>
<rectangle x1="17.61" y1="-2.59" x2="18.03" y2="-2.09" layer="51"/>
<rectangle x1="18.05" y1="-2.59" x2="18.47" y2="-2.09" layer="51"/>
<rectangle x1="18.49" y1="-2.59" x2="18.91" y2="-2.09" layer="51"/>
<rectangle x1="18.93" y1="-2.59" x2="19.35" y2="-2.09" layer="51"/>
<rectangle x1="19.37" y1="-2.59" x2="19.79" y2="-2.09" layer="51"/>
<rectangle x1="19.81" y1="-2.59" x2="20.23" y2="-2.09" layer="51"/>
<rectangle x1="20.25" y1="-2.59" x2="20.67" y2="-2.09" layer="51"/>
<rectangle x1="20.69" y1="-2.59" x2="21.11" y2="-2.09" layer="51"/>
<rectangle x1="21.13" y1="-2.59" x2="21.55" y2="-2.09" layer="51"/>
<rectangle x1="21.57" y1="-2.59" x2="21.99" y2="-2.09" layer="51"/>
<rectangle x1="22.01" y1="-2.59" x2="22.43" y2="-2.09" layer="51"/>
<rectangle x1="22.45" y1="-2.59" x2="22.87" y2="-2.09" layer="51"/>
<rectangle x1="22.89" y1="-2.59" x2="23.31" y2="-2.09" layer="51"/>
<rectangle x1="23.33" y1="-2.59" x2="23.75" y2="-2.09" layer="51"/>
<rectangle x1="23.77" y1="-2.59" x2="24.19" y2="-2.09" layer="51"/>
<rectangle x1="24.21" y1="-2.59" x2="24.63" y2="-2.09" layer="51"/>
<rectangle x1="24.65" y1="-2.59" x2="25.07" y2="-2.09" layer="51"/>
<rectangle x1="25.09" y1="-2.59" x2="25.51" y2="-2.09" layer="51"/>
<rectangle x1="25.53" y1="-2.59" x2="25.95" y2="-2.09" layer="51"/>
<rectangle x1="25.97" y1="-2.59" x2="26.39" y2="-2.09" layer="51"/>
<rectangle x1="26.41" y1="-2.59" x2="26.83" y2="-2.09" layer="51"/>
<rectangle x1="26.85" y1="-2.59" x2="27.27" y2="-2.09" layer="51"/>
<rectangle x1="27.29" y1="-2.59" x2="27.71" y2="-2.09" layer="51"/>
<rectangle x1="27.73" y1="-2.59" x2="28.15" y2="-2.09" layer="51"/>
<rectangle x1="-28.15" y1="-3.11" x2="-27.73" y2="-2.61" layer="51"/>
<rectangle x1="-27.71" y1="-3.11" x2="-27.29" y2="-2.61" layer="51"/>
<rectangle x1="-27.27" y1="-3.11" x2="-26.85" y2="-2.61" layer="51"/>
<rectangle x1="-26.83" y1="-3.11" x2="-26.41" y2="-2.61" layer="51"/>
<rectangle x1="-26.39" y1="-3.11" x2="-25.97" y2="-2.61" layer="51"/>
<rectangle x1="-25.95" y1="-3.11" x2="-25.53" y2="-2.61" layer="51"/>
<rectangle x1="-25.51" y1="-3.11" x2="-25.09" y2="-2.61" layer="51"/>
<rectangle x1="-25.07" y1="-3.11" x2="-24.65" y2="-2.61" layer="51"/>
<rectangle x1="-24.63" y1="-3.11" x2="-24.21" y2="-2.61" layer="51"/>
<rectangle x1="-24.19" y1="-3.11" x2="-23.77" y2="-2.61" layer="51"/>
<rectangle x1="-23.75" y1="-3.11" x2="-23.33" y2="-2.61" layer="51"/>
<rectangle x1="-23.31" y1="-3.11" x2="-22.89" y2="-2.61" layer="51"/>
<rectangle x1="-22.87" y1="-3.11" x2="-22.45" y2="-2.61" layer="51"/>
<rectangle x1="-22.43" y1="-3.11" x2="-22.01" y2="-2.61" layer="51"/>
<rectangle x1="-21.99" y1="-3.11" x2="-21.57" y2="-2.61" layer="51"/>
<rectangle x1="-21.55" y1="-3.11" x2="-21.13" y2="-2.61" layer="51"/>
<rectangle x1="-21.11" y1="-3.11" x2="-20.69" y2="-2.61" layer="51"/>
<rectangle x1="-20.67" y1="-3.11" x2="-20.25" y2="-2.61" layer="51"/>
<rectangle x1="-20.23" y1="-3.11" x2="-19.81" y2="-2.61" layer="51"/>
<rectangle x1="-19.79" y1="-3.11" x2="-19.37" y2="-2.61" layer="51"/>
<rectangle x1="-19.35" y1="-3.11" x2="-18.93" y2="-2.61" layer="51"/>
<rectangle x1="-18.91" y1="-3.11" x2="-18.49" y2="-2.61" layer="51"/>
<rectangle x1="-18.47" y1="-3.11" x2="-18.05" y2="-2.61" layer="51"/>
<rectangle x1="-18.03" y1="-3.11" x2="-17.61" y2="-2.61" layer="51"/>
<rectangle x1="-17.59" y1="-3.11" x2="-17.17" y2="-2.61" layer="51"/>
<rectangle x1="-17.15" y1="-3.11" x2="-16.73" y2="-2.61" layer="51"/>
<rectangle x1="-16.71" y1="-3.11" x2="-16.29" y2="-2.61" layer="51"/>
<rectangle x1="-16.27" y1="-3.11" x2="-15.85" y2="-2.61" layer="51"/>
<rectangle x1="-15.83" y1="-3.11" x2="-15.41" y2="-2.61" layer="51"/>
<rectangle x1="-15.39" y1="-3.11" x2="-14.97" y2="-2.61" layer="51"/>
<rectangle x1="-14.95" y1="-3.11" x2="-14.53" y2="-2.61" layer="51"/>
<rectangle x1="-14.51" y1="-3.11" x2="-14.09" y2="-2.61" layer="51"/>
<rectangle x1="-14.07" y1="-3.11" x2="-13.65" y2="-2.61" layer="51"/>
<rectangle x1="-13.63" y1="-3.11" x2="-13.21" y2="-2.61" layer="51"/>
<rectangle x1="-13.19" y1="-3.11" x2="-12.77" y2="-2.61" layer="51"/>
<rectangle x1="-12.75" y1="-3.11" x2="-12.33" y2="-2.61" layer="51"/>
<rectangle x1="-12.31" y1="-3.11" x2="-11.89" y2="-2.61" layer="51"/>
<rectangle x1="-11.87" y1="-3.11" x2="-11.45" y2="-2.61" layer="51"/>
<rectangle x1="-11.43" y1="-3.11" x2="-11.01" y2="-2.61" layer="51"/>
<rectangle x1="-10.99" y1="-3.11" x2="-10.57" y2="-2.61" layer="51"/>
<rectangle x1="-10.55" y1="-3.11" x2="-10.13" y2="-2.61" layer="51"/>
<rectangle x1="-10.11" y1="-3.11" x2="-9.69" y2="-2.61" layer="51"/>
<rectangle x1="-9.67" y1="-3.11" x2="-9.25" y2="-2.61" layer="51"/>
<rectangle x1="-9.23" y1="-3.11" x2="-8.81" y2="-2.61" layer="51"/>
<rectangle x1="-8.79" y1="-3.11" x2="-8.37" y2="-2.61" layer="51"/>
<rectangle x1="-8.35" y1="-3.11" x2="-7.93" y2="-2.61" layer="51"/>
<rectangle x1="-7.91" y1="-3.11" x2="-7.49" y2="-2.61" layer="51"/>
<rectangle x1="-7.47" y1="-3.11" x2="-7.05" y2="-2.61" layer="51"/>
<rectangle x1="-7.03" y1="-3.11" x2="-6.61" y2="-2.61" layer="51"/>
<rectangle x1="-6.59" y1="-3.11" x2="-6.17" y2="-2.61" layer="51"/>
<rectangle x1="-6.15" y1="-3.11" x2="-5.73" y2="-2.61" layer="51"/>
<rectangle x1="-5.71" y1="-3.11" x2="-5.29" y2="-2.61" layer="51"/>
<rectangle x1="-5.27" y1="-3.11" x2="-4.85" y2="-2.61" layer="51"/>
<rectangle x1="-4.83" y1="-3.11" x2="-4.41" y2="-2.61" layer="51"/>
<rectangle x1="-4.39" y1="-3.11" x2="-3.97" y2="-2.61" layer="51"/>
<rectangle x1="-3.95" y1="-3.11" x2="-3.53" y2="-2.61" layer="51"/>
<rectangle x1="-3.51" y1="-3.11" x2="-3.09" y2="-2.61" layer="51"/>
<rectangle x1="-3.07" y1="-3.11" x2="-2.65" y2="-2.61" layer="51"/>
<rectangle x1="-2.63" y1="-3.11" x2="-2.21" y2="-2.61" layer="51"/>
<rectangle x1="-2.19" y1="-3.11" x2="-1.77" y2="-2.61" layer="51"/>
<rectangle x1="-1.75" y1="-3.11" x2="-1.33" y2="-2.61" layer="51"/>
<rectangle x1="-1.31" y1="-3.11" x2="-0.89" y2="-2.61" layer="51"/>
<rectangle x1="-0.87" y1="-3.11" x2="-0.45" y2="-2.61" layer="51"/>
<rectangle x1="-0.43" y1="-3.11" x2="-0.01" y2="-2.61" layer="51"/>
<rectangle x1="0.01" y1="-3.11" x2="0.43" y2="-2.61" layer="51"/>
<rectangle x1="0.45" y1="-3.11" x2="0.87" y2="-2.61" layer="51"/>
<rectangle x1="0.89" y1="-3.11" x2="1.31" y2="-2.61" layer="51"/>
<rectangle x1="1.33" y1="-3.11" x2="1.75" y2="-2.61" layer="51"/>
<rectangle x1="1.77" y1="-3.11" x2="2.19" y2="-2.61" layer="51"/>
<rectangle x1="2.21" y1="-3.11" x2="2.63" y2="-2.61" layer="51"/>
<rectangle x1="2.65" y1="-3.11" x2="3.07" y2="-2.61" layer="51"/>
<rectangle x1="3.09" y1="-3.11" x2="3.51" y2="-2.61" layer="51"/>
<rectangle x1="3.53" y1="-3.11" x2="3.95" y2="-2.61" layer="51"/>
<rectangle x1="3.97" y1="-3.11" x2="4.39" y2="-2.61" layer="51"/>
<rectangle x1="4.41" y1="-3.11" x2="4.83" y2="-2.61" layer="51"/>
<rectangle x1="4.85" y1="-3.11" x2="5.27" y2="-2.61" layer="51"/>
<rectangle x1="5.29" y1="-3.11" x2="5.71" y2="-2.61" layer="51"/>
<rectangle x1="5.73" y1="-3.11" x2="6.15" y2="-2.61" layer="51"/>
<rectangle x1="6.17" y1="-3.11" x2="6.59" y2="-2.61" layer="51"/>
<rectangle x1="6.61" y1="-3.11" x2="7.03" y2="-2.61" layer="51"/>
<rectangle x1="7.05" y1="-3.11" x2="7.47" y2="-2.61" layer="51"/>
<rectangle x1="7.49" y1="-3.11" x2="7.91" y2="-2.61" layer="51"/>
<rectangle x1="7.93" y1="-3.11" x2="8.35" y2="-2.61" layer="51"/>
<rectangle x1="8.37" y1="-3.11" x2="8.79" y2="-2.61" layer="51"/>
<rectangle x1="8.81" y1="-3.11" x2="9.23" y2="-2.61" layer="51"/>
<rectangle x1="9.25" y1="-3.11" x2="9.67" y2="-2.61" layer="51"/>
<rectangle x1="9.69" y1="-3.11" x2="10.11" y2="-2.61" layer="51"/>
<rectangle x1="10.13" y1="-3.11" x2="10.55" y2="-2.61" layer="51"/>
<rectangle x1="10.57" y1="-3.11" x2="10.99" y2="-2.61" layer="51"/>
<rectangle x1="11.01" y1="-3.11" x2="11.43" y2="-2.61" layer="51"/>
<rectangle x1="11.45" y1="-3.11" x2="11.87" y2="-2.61" layer="51"/>
<rectangle x1="11.89" y1="-3.11" x2="12.31" y2="-2.61" layer="51"/>
<rectangle x1="12.33" y1="-3.11" x2="12.75" y2="-2.61" layer="51"/>
<rectangle x1="12.77" y1="-3.11" x2="13.19" y2="-2.61" layer="51"/>
<rectangle x1="13.21" y1="-3.11" x2="13.63" y2="-2.61" layer="51"/>
<rectangle x1="13.65" y1="-3.11" x2="14.07" y2="-2.61" layer="51"/>
<rectangle x1="14.09" y1="-3.11" x2="14.51" y2="-2.61" layer="51"/>
<rectangle x1="14.53" y1="-3.11" x2="14.95" y2="-2.61" layer="51"/>
<rectangle x1="14.97" y1="-3.11" x2="15.39" y2="-2.61" layer="51"/>
<rectangle x1="15.41" y1="-3.11" x2="15.83" y2="-2.61" layer="51"/>
<rectangle x1="15.85" y1="-3.11" x2="16.27" y2="-2.61" layer="51"/>
<rectangle x1="16.29" y1="-3.11" x2="16.71" y2="-2.61" layer="51"/>
<rectangle x1="16.73" y1="-3.11" x2="17.15" y2="-2.61" layer="51"/>
<rectangle x1="17.17" y1="-3.11" x2="17.59" y2="-2.61" layer="51"/>
<rectangle x1="17.61" y1="-3.11" x2="18.03" y2="-2.61" layer="51"/>
<rectangle x1="18.05" y1="-3.11" x2="18.47" y2="-2.61" layer="51"/>
<rectangle x1="18.49" y1="-3.11" x2="18.91" y2="-2.61" layer="51"/>
<rectangle x1="18.93" y1="-3.11" x2="19.35" y2="-2.61" layer="51"/>
<rectangle x1="19.37" y1="-3.11" x2="19.79" y2="-2.61" layer="51"/>
<rectangle x1="19.81" y1="-3.11" x2="20.23" y2="-2.61" layer="51"/>
<rectangle x1="20.25" y1="-3.11" x2="20.67" y2="-2.61" layer="51"/>
<rectangle x1="20.69" y1="-3.11" x2="21.11" y2="-2.61" layer="51"/>
<rectangle x1="21.13" y1="-3.11" x2="21.55" y2="-2.61" layer="51"/>
<rectangle x1="21.57" y1="-3.11" x2="21.99" y2="-2.61" layer="51"/>
<rectangle x1="22.01" y1="-3.11" x2="22.43" y2="-2.61" layer="51"/>
<rectangle x1="22.45" y1="-3.11" x2="22.87" y2="-2.61" layer="51"/>
<rectangle x1="22.89" y1="-3.11" x2="23.31" y2="-2.61" layer="51"/>
<rectangle x1="23.33" y1="-3.11" x2="23.75" y2="-2.61" layer="51"/>
<rectangle x1="23.77" y1="-3.11" x2="24.19" y2="-2.61" layer="51"/>
<rectangle x1="24.21" y1="-3.11" x2="24.63" y2="-2.61" layer="51"/>
<rectangle x1="24.65" y1="-3.11" x2="25.07" y2="-2.61" layer="51"/>
<rectangle x1="25.09" y1="-3.11" x2="25.51" y2="-2.61" layer="51"/>
<rectangle x1="25.53" y1="-3.11" x2="25.95" y2="-2.61" layer="51"/>
<rectangle x1="25.97" y1="-3.11" x2="26.39" y2="-2.61" layer="51"/>
<rectangle x1="26.41" y1="-3.11" x2="26.83" y2="-2.61" layer="51"/>
<rectangle x1="26.85" y1="-3.11" x2="27.27" y2="-2.61" layer="51"/>
<rectangle x1="27.29" y1="-3.11" x2="27.71" y2="-2.61" layer="51"/>
<rectangle x1="27.73" y1="-3.11" x2="28.15" y2="-2.61" layer="51"/>
<rectangle x1="-28.15" y1="-3.63" x2="-27.73" y2="-3.13" layer="51"/>
<rectangle x1="-27.71" y1="-3.63" x2="-27.29" y2="-3.13" layer="51"/>
<rectangle x1="-27.27" y1="-3.63" x2="-26.85" y2="-3.13" layer="51"/>
<rectangle x1="-26.83" y1="-3.63" x2="-26.41" y2="-3.13" layer="51"/>
<rectangle x1="-26.39" y1="-3.63" x2="-25.97" y2="-3.13" layer="51"/>
<rectangle x1="-25.95" y1="-3.63" x2="-25.53" y2="-3.13" layer="51"/>
<rectangle x1="-25.51" y1="-3.63" x2="-25.09" y2="-3.13" layer="51"/>
<rectangle x1="-25.07" y1="-3.63" x2="-24.65" y2="-3.13" layer="51"/>
<rectangle x1="-24.63" y1="-3.63" x2="-24.21" y2="-3.13" layer="51"/>
<rectangle x1="-24.19" y1="-3.63" x2="-23.77" y2="-3.13" layer="51"/>
<rectangle x1="-23.75" y1="-3.63" x2="-23.33" y2="-3.13" layer="51"/>
<rectangle x1="-23.31" y1="-3.63" x2="-22.89" y2="-3.13" layer="51"/>
<rectangle x1="-22.87" y1="-3.63" x2="-22.45" y2="-3.13" layer="51"/>
<rectangle x1="-22.43" y1="-3.63" x2="-22.01" y2="-3.13" layer="51"/>
<rectangle x1="-21.99" y1="-3.63" x2="-21.57" y2="-3.13" layer="51"/>
<rectangle x1="-21.55" y1="-3.63" x2="-21.13" y2="-3.13" layer="51"/>
<rectangle x1="-21.11" y1="-3.63" x2="-20.69" y2="-3.13" layer="51"/>
<rectangle x1="-20.67" y1="-3.63" x2="-20.25" y2="-3.13" layer="51"/>
<rectangle x1="-20.23" y1="-3.63" x2="-19.81" y2="-3.13" layer="51"/>
<rectangle x1="-19.79" y1="-3.63" x2="-19.37" y2="-3.13" layer="51"/>
<rectangle x1="-19.35" y1="-3.63" x2="-18.93" y2="-3.13" layer="51"/>
<rectangle x1="-18.91" y1="-3.63" x2="-18.49" y2="-3.13" layer="51"/>
<rectangle x1="-18.47" y1="-3.63" x2="-18.05" y2="-3.13" layer="51"/>
<rectangle x1="-18.03" y1="-3.63" x2="-17.61" y2="-3.13" layer="51"/>
<rectangle x1="-17.59" y1="-3.63" x2="-17.17" y2="-3.13" layer="51"/>
<rectangle x1="-17.15" y1="-3.63" x2="-16.73" y2="-3.13" layer="51"/>
<rectangle x1="-16.71" y1="-3.63" x2="-16.29" y2="-3.13" layer="51"/>
<rectangle x1="-16.27" y1="-3.63" x2="-15.85" y2="-3.13" layer="51"/>
<rectangle x1="-15.83" y1="-3.63" x2="-15.41" y2="-3.13" layer="51"/>
<rectangle x1="-15.39" y1="-3.63" x2="-14.97" y2="-3.13" layer="51"/>
<rectangle x1="-14.95" y1="-3.63" x2="-14.53" y2="-3.13" layer="51"/>
<rectangle x1="-14.51" y1="-3.63" x2="-14.09" y2="-3.13" layer="51"/>
<rectangle x1="-14.07" y1="-3.63" x2="-13.65" y2="-3.13" layer="51"/>
<rectangle x1="-13.63" y1="-3.63" x2="-13.21" y2="-3.13" layer="51"/>
<rectangle x1="-13.19" y1="-3.63" x2="-12.77" y2="-3.13" layer="51"/>
<rectangle x1="-12.75" y1="-3.63" x2="-12.33" y2="-3.13" layer="51"/>
<rectangle x1="-12.31" y1="-3.63" x2="-11.89" y2="-3.13" layer="51"/>
<rectangle x1="-11.87" y1="-3.63" x2="-11.45" y2="-3.13" layer="51"/>
<rectangle x1="-11.43" y1="-3.63" x2="-11.01" y2="-3.13" layer="51"/>
<rectangle x1="-10.99" y1="-3.63" x2="-10.57" y2="-3.13" layer="51"/>
<rectangle x1="-10.55" y1="-3.63" x2="-10.13" y2="-3.13" layer="51"/>
<rectangle x1="-10.11" y1="-3.63" x2="-9.69" y2="-3.13" layer="51"/>
<rectangle x1="-9.67" y1="-3.63" x2="-9.25" y2="-3.13" layer="51"/>
<rectangle x1="-9.23" y1="-3.63" x2="-8.81" y2="-3.13" layer="51"/>
<rectangle x1="-8.79" y1="-3.63" x2="-8.37" y2="-3.13" layer="51"/>
<rectangle x1="-8.35" y1="-3.63" x2="-7.93" y2="-3.13" layer="51"/>
<rectangle x1="-7.91" y1="-3.63" x2="-7.49" y2="-3.13" layer="51"/>
<rectangle x1="-7.47" y1="-3.63" x2="-7.05" y2="-3.13" layer="51"/>
<rectangle x1="-7.03" y1="-3.63" x2="-6.61" y2="-3.13" layer="51"/>
<rectangle x1="-6.59" y1="-3.63" x2="-6.17" y2="-3.13" layer="51"/>
<rectangle x1="-6.15" y1="-3.63" x2="-5.73" y2="-3.13" layer="51"/>
<rectangle x1="-5.71" y1="-3.63" x2="-5.29" y2="-3.13" layer="51"/>
<rectangle x1="-5.27" y1="-3.63" x2="-4.85" y2="-3.13" layer="51"/>
<rectangle x1="-4.83" y1="-3.63" x2="-4.41" y2="-3.13" layer="51"/>
<rectangle x1="-4.39" y1="-3.63" x2="-3.97" y2="-3.13" layer="51"/>
<rectangle x1="-3.95" y1="-3.63" x2="-3.53" y2="-3.13" layer="51"/>
<rectangle x1="-3.51" y1="-3.63" x2="-3.09" y2="-3.13" layer="51"/>
<rectangle x1="-3.07" y1="-3.63" x2="-2.65" y2="-3.13" layer="51"/>
<rectangle x1="-2.63" y1="-3.63" x2="-2.21" y2="-3.13" layer="51"/>
<rectangle x1="-2.19" y1="-3.63" x2="-1.77" y2="-3.13" layer="51"/>
<rectangle x1="-1.75" y1="-3.63" x2="-1.33" y2="-3.13" layer="51"/>
<rectangle x1="-1.31" y1="-3.63" x2="-0.89" y2="-3.13" layer="51"/>
<rectangle x1="-0.87" y1="-3.63" x2="-0.45" y2="-3.13" layer="51"/>
<rectangle x1="-0.43" y1="-3.63" x2="-0.01" y2="-3.13" layer="51"/>
<rectangle x1="0.01" y1="-3.63" x2="0.43" y2="-3.13" layer="51"/>
<rectangle x1="0.45" y1="-3.63" x2="0.87" y2="-3.13" layer="51"/>
<rectangle x1="0.89" y1="-3.63" x2="1.31" y2="-3.13" layer="51"/>
<rectangle x1="1.33" y1="-3.63" x2="1.75" y2="-3.13" layer="51"/>
<rectangle x1="1.77" y1="-3.63" x2="2.19" y2="-3.13" layer="51"/>
<rectangle x1="2.21" y1="-3.63" x2="2.63" y2="-3.13" layer="51"/>
<rectangle x1="2.65" y1="-3.63" x2="3.07" y2="-3.13" layer="51"/>
<rectangle x1="3.09" y1="-3.63" x2="3.51" y2="-3.13" layer="51"/>
<rectangle x1="3.53" y1="-3.63" x2="3.95" y2="-3.13" layer="51"/>
<rectangle x1="3.97" y1="-3.63" x2="4.39" y2="-3.13" layer="51"/>
<rectangle x1="4.41" y1="-3.63" x2="4.83" y2="-3.13" layer="51"/>
<rectangle x1="4.85" y1="-3.63" x2="5.27" y2="-3.13" layer="51"/>
<rectangle x1="5.29" y1="-3.63" x2="5.71" y2="-3.13" layer="51"/>
<rectangle x1="5.73" y1="-3.63" x2="6.15" y2="-3.13" layer="51"/>
<rectangle x1="6.17" y1="-3.63" x2="6.59" y2="-3.13" layer="51"/>
<rectangle x1="6.61" y1="-3.63" x2="7.03" y2="-3.13" layer="51"/>
<rectangle x1="7.05" y1="-3.63" x2="7.47" y2="-3.13" layer="51"/>
<rectangle x1="7.49" y1="-3.63" x2="7.91" y2="-3.13" layer="51"/>
<rectangle x1="7.93" y1="-3.63" x2="8.35" y2="-3.13" layer="51"/>
<rectangle x1="8.37" y1="-3.63" x2="8.79" y2="-3.13" layer="51"/>
<rectangle x1="8.81" y1="-3.63" x2="9.23" y2="-3.13" layer="51"/>
<rectangle x1="9.25" y1="-3.63" x2="9.67" y2="-3.13" layer="51"/>
<rectangle x1="9.69" y1="-3.63" x2="10.11" y2="-3.13" layer="51"/>
<rectangle x1="10.13" y1="-3.63" x2="10.55" y2="-3.13" layer="51"/>
<rectangle x1="10.57" y1="-3.63" x2="10.99" y2="-3.13" layer="51"/>
<rectangle x1="11.01" y1="-3.63" x2="11.43" y2="-3.13" layer="51"/>
<rectangle x1="11.45" y1="-3.63" x2="11.87" y2="-3.13" layer="51"/>
<rectangle x1="11.89" y1="-3.63" x2="12.31" y2="-3.13" layer="51"/>
<rectangle x1="12.33" y1="-3.63" x2="12.75" y2="-3.13" layer="51"/>
<rectangle x1="12.77" y1="-3.63" x2="13.19" y2="-3.13" layer="51"/>
<rectangle x1="13.21" y1="-3.63" x2="13.63" y2="-3.13" layer="51"/>
<rectangle x1="13.65" y1="-3.63" x2="14.07" y2="-3.13" layer="51"/>
<rectangle x1="14.09" y1="-3.63" x2="14.51" y2="-3.13" layer="51"/>
<rectangle x1="14.53" y1="-3.63" x2="14.95" y2="-3.13" layer="51"/>
<rectangle x1="14.97" y1="-3.63" x2="15.39" y2="-3.13" layer="51"/>
<rectangle x1="15.41" y1="-3.63" x2="15.83" y2="-3.13" layer="51"/>
<rectangle x1="15.85" y1="-3.63" x2="16.27" y2="-3.13" layer="51"/>
<rectangle x1="16.29" y1="-3.63" x2="16.71" y2="-3.13" layer="51"/>
<rectangle x1="16.73" y1="-3.63" x2="17.15" y2="-3.13" layer="51"/>
<rectangle x1="17.17" y1="-3.63" x2="17.59" y2="-3.13" layer="51"/>
<rectangle x1="17.61" y1="-3.63" x2="18.03" y2="-3.13" layer="51"/>
<rectangle x1="18.05" y1="-3.63" x2="18.47" y2="-3.13" layer="51"/>
<rectangle x1="18.49" y1="-3.63" x2="18.91" y2="-3.13" layer="51"/>
<rectangle x1="18.93" y1="-3.63" x2="19.35" y2="-3.13" layer="51"/>
<rectangle x1="19.37" y1="-3.63" x2="19.79" y2="-3.13" layer="51"/>
<rectangle x1="19.81" y1="-3.63" x2="20.23" y2="-3.13" layer="51"/>
<rectangle x1="20.25" y1="-3.63" x2="20.67" y2="-3.13" layer="51"/>
<rectangle x1="20.69" y1="-3.63" x2="21.11" y2="-3.13" layer="51"/>
<rectangle x1="21.13" y1="-3.63" x2="21.55" y2="-3.13" layer="51"/>
<rectangle x1="21.57" y1="-3.63" x2="21.99" y2="-3.13" layer="51"/>
<rectangle x1="22.01" y1="-3.63" x2="22.43" y2="-3.13" layer="51"/>
<rectangle x1="22.45" y1="-3.63" x2="22.87" y2="-3.13" layer="51"/>
<rectangle x1="22.89" y1="-3.63" x2="23.31" y2="-3.13" layer="51"/>
<rectangle x1="23.33" y1="-3.63" x2="23.75" y2="-3.13" layer="51"/>
<rectangle x1="23.77" y1="-3.63" x2="24.19" y2="-3.13" layer="51"/>
<rectangle x1="24.21" y1="-3.63" x2="24.63" y2="-3.13" layer="51"/>
<rectangle x1="24.65" y1="-3.63" x2="25.07" y2="-3.13" layer="51"/>
<rectangle x1="25.09" y1="-3.63" x2="25.51" y2="-3.13" layer="51"/>
<rectangle x1="25.53" y1="-3.63" x2="25.95" y2="-3.13" layer="51"/>
<rectangle x1="25.97" y1="-3.63" x2="26.39" y2="-3.13" layer="51"/>
<rectangle x1="26.41" y1="-3.63" x2="26.83" y2="-3.13" layer="51"/>
<rectangle x1="26.85" y1="-3.63" x2="27.27" y2="-3.13" layer="51"/>
<rectangle x1="27.29" y1="-3.63" x2="27.71" y2="-3.13" layer="51"/>
<rectangle x1="27.73" y1="-3.63" x2="28.15" y2="-3.13" layer="51"/>
<rectangle x1="-28.15" y1="-4.15" x2="-27.73" y2="-3.65" layer="51"/>
<rectangle x1="-27.71" y1="-4.15" x2="-27.29" y2="-3.65" layer="51"/>
<rectangle x1="-27.27" y1="-4.15" x2="-26.85" y2="-3.65" layer="51"/>
<rectangle x1="-26.83" y1="-4.15" x2="-26.41" y2="-3.65" layer="51"/>
<rectangle x1="-26.39" y1="-4.15" x2="-25.97" y2="-3.65" layer="51"/>
<rectangle x1="-25.95" y1="-4.15" x2="-25.53" y2="-3.65" layer="51"/>
<rectangle x1="-25.51" y1="-4.15" x2="-25.09" y2="-3.65" layer="51"/>
<rectangle x1="-25.07" y1="-4.15" x2="-24.65" y2="-3.65" layer="51"/>
<rectangle x1="-24.63" y1="-4.15" x2="-24.21" y2="-3.65" layer="51"/>
<rectangle x1="-24.19" y1="-4.15" x2="-23.77" y2="-3.65" layer="51"/>
<rectangle x1="-23.75" y1="-4.15" x2="-23.33" y2="-3.65" layer="51"/>
<rectangle x1="-23.31" y1="-4.15" x2="-22.89" y2="-3.65" layer="51"/>
<rectangle x1="-22.87" y1="-4.15" x2="-22.45" y2="-3.65" layer="51"/>
<rectangle x1="-22.43" y1="-4.15" x2="-22.01" y2="-3.65" layer="51"/>
<rectangle x1="-21.99" y1="-4.15" x2="-21.57" y2="-3.65" layer="51"/>
<rectangle x1="-21.55" y1="-4.15" x2="-21.13" y2="-3.65" layer="51"/>
<rectangle x1="-21.11" y1="-4.15" x2="-20.69" y2="-3.65" layer="51"/>
<rectangle x1="-20.67" y1="-4.15" x2="-20.25" y2="-3.65" layer="51"/>
<rectangle x1="-20.23" y1="-4.15" x2="-19.81" y2="-3.65" layer="51"/>
<rectangle x1="-19.79" y1="-4.15" x2="-19.37" y2="-3.65" layer="51"/>
<rectangle x1="-19.35" y1="-4.15" x2="-18.93" y2="-3.65" layer="51"/>
<rectangle x1="-18.91" y1="-4.15" x2="-18.49" y2="-3.65" layer="51"/>
<rectangle x1="-18.47" y1="-4.15" x2="-18.05" y2="-3.65" layer="51"/>
<rectangle x1="-18.03" y1="-4.15" x2="-17.61" y2="-3.65" layer="51"/>
<rectangle x1="-17.59" y1="-4.15" x2="-17.17" y2="-3.65" layer="51"/>
<rectangle x1="-17.15" y1="-4.15" x2="-16.73" y2="-3.65" layer="51"/>
<rectangle x1="-16.71" y1="-4.15" x2="-16.29" y2="-3.65" layer="51"/>
<rectangle x1="-16.27" y1="-4.15" x2="-15.85" y2="-3.65" layer="51"/>
<rectangle x1="-15.83" y1="-4.15" x2="-15.41" y2="-3.65" layer="51"/>
<rectangle x1="-15.39" y1="-4.15" x2="-14.97" y2="-3.65" layer="51"/>
<rectangle x1="-14.95" y1="-4.15" x2="-14.53" y2="-3.65" layer="51"/>
<rectangle x1="-14.51" y1="-4.15" x2="-14.09" y2="-3.65" layer="51"/>
<rectangle x1="-14.07" y1="-4.15" x2="-13.65" y2="-3.65" layer="51"/>
<rectangle x1="-13.63" y1="-4.15" x2="-13.21" y2="-3.65" layer="51"/>
<rectangle x1="-13.19" y1="-4.15" x2="-12.77" y2="-3.65" layer="51"/>
<rectangle x1="-12.75" y1="-4.15" x2="-12.33" y2="-3.65" layer="51"/>
<rectangle x1="-12.31" y1="-4.15" x2="-11.89" y2="-3.65" layer="51"/>
<rectangle x1="-11.87" y1="-4.15" x2="-11.45" y2="-3.65" layer="51"/>
<rectangle x1="-11.43" y1="-4.15" x2="-11.01" y2="-3.65" layer="51"/>
<rectangle x1="-10.99" y1="-4.15" x2="-10.57" y2="-3.65" layer="51"/>
<rectangle x1="-10.55" y1="-4.15" x2="-10.13" y2="-3.65" layer="51"/>
<rectangle x1="-10.11" y1="-4.15" x2="-9.69" y2="-3.65" layer="51"/>
<rectangle x1="-9.67" y1="-4.15" x2="-9.25" y2="-3.65" layer="51"/>
<rectangle x1="-9.23" y1="-4.15" x2="-8.81" y2="-3.65" layer="51"/>
<rectangle x1="-8.79" y1="-4.15" x2="-8.37" y2="-3.65" layer="51"/>
<rectangle x1="-8.35" y1="-4.15" x2="-7.93" y2="-3.65" layer="51"/>
<rectangle x1="-7.91" y1="-4.15" x2="-7.49" y2="-3.65" layer="51"/>
<rectangle x1="-7.47" y1="-4.15" x2="-7.05" y2="-3.65" layer="51"/>
<rectangle x1="-7.03" y1="-4.15" x2="-6.61" y2="-3.65" layer="51"/>
<rectangle x1="-6.59" y1="-4.15" x2="-6.17" y2="-3.65" layer="51"/>
<rectangle x1="-6.15" y1="-4.15" x2="-5.73" y2="-3.65" layer="51"/>
<rectangle x1="-5.71" y1="-4.15" x2="-5.29" y2="-3.65" layer="51"/>
<rectangle x1="-5.27" y1="-4.15" x2="-4.85" y2="-3.65" layer="51"/>
<rectangle x1="-4.83" y1="-4.15" x2="-4.41" y2="-3.65" layer="51"/>
<rectangle x1="-4.39" y1="-4.15" x2="-3.97" y2="-3.65" layer="51"/>
<rectangle x1="-3.95" y1="-4.15" x2="-3.53" y2="-3.65" layer="51"/>
<rectangle x1="-3.51" y1="-4.15" x2="-3.09" y2="-3.65" layer="51"/>
<rectangle x1="-3.07" y1="-4.15" x2="-2.65" y2="-3.65" layer="51"/>
<rectangle x1="-2.63" y1="-4.15" x2="-2.21" y2="-3.65" layer="51"/>
<rectangle x1="-2.19" y1="-4.15" x2="-1.77" y2="-3.65" layer="51"/>
<rectangle x1="-1.75" y1="-4.15" x2="-1.33" y2="-3.65" layer="51"/>
<rectangle x1="-1.31" y1="-4.15" x2="-0.89" y2="-3.65" layer="51"/>
<rectangle x1="-0.87" y1="-4.15" x2="-0.45" y2="-3.65" layer="51"/>
<rectangle x1="-0.43" y1="-4.15" x2="-0.01" y2="-3.65" layer="51"/>
<rectangle x1="0.01" y1="-4.15" x2="0.43" y2="-3.65" layer="51"/>
<rectangle x1="0.45" y1="-4.15" x2="0.87" y2="-3.65" layer="51"/>
<rectangle x1="0.89" y1="-4.15" x2="1.31" y2="-3.65" layer="51"/>
<rectangle x1="1.33" y1="-4.15" x2="1.75" y2="-3.65" layer="51"/>
<rectangle x1="1.77" y1="-4.15" x2="2.19" y2="-3.65" layer="51"/>
<rectangle x1="2.21" y1="-4.15" x2="2.63" y2="-3.65" layer="51"/>
<rectangle x1="2.65" y1="-4.15" x2="3.07" y2="-3.65" layer="51"/>
<rectangle x1="3.09" y1="-4.15" x2="3.51" y2="-3.65" layer="51"/>
<rectangle x1="3.53" y1="-4.15" x2="3.95" y2="-3.65" layer="51"/>
<rectangle x1="3.97" y1="-4.15" x2="4.39" y2="-3.65" layer="51"/>
<rectangle x1="4.41" y1="-4.15" x2="4.83" y2="-3.65" layer="51"/>
<rectangle x1="4.85" y1="-4.15" x2="5.27" y2="-3.65" layer="51"/>
<rectangle x1="5.29" y1="-4.15" x2="5.71" y2="-3.65" layer="51"/>
<rectangle x1="5.73" y1="-4.15" x2="6.15" y2="-3.65" layer="51"/>
<rectangle x1="6.17" y1="-4.15" x2="6.59" y2="-3.65" layer="51"/>
<rectangle x1="6.61" y1="-4.15" x2="7.03" y2="-3.65" layer="51"/>
<rectangle x1="7.05" y1="-4.15" x2="7.47" y2="-3.65" layer="51"/>
<rectangle x1="7.49" y1="-4.15" x2="7.91" y2="-3.65" layer="51"/>
<rectangle x1="7.93" y1="-4.15" x2="8.35" y2="-3.65" layer="51"/>
<rectangle x1="8.37" y1="-4.15" x2="8.79" y2="-3.65" layer="51"/>
<rectangle x1="8.81" y1="-4.15" x2="9.23" y2="-3.65" layer="51"/>
<rectangle x1="9.25" y1="-4.15" x2="9.67" y2="-3.65" layer="51"/>
<rectangle x1="9.69" y1="-4.15" x2="10.11" y2="-3.65" layer="51"/>
<rectangle x1="10.13" y1="-4.15" x2="10.55" y2="-3.65" layer="51"/>
<rectangle x1="10.57" y1="-4.15" x2="10.99" y2="-3.65" layer="51"/>
<rectangle x1="11.01" y1="-4.15" x2="11.43" y2="-3.65" layer="51"/>
<rectangle x1="11.45" y1="-4.15" x2="11.87" y2="-3.65" layer="51"/>
<rectangle x1="11.89" y1="-4.15" x2="12.31" y2="-3.65" layer="51"/>
<rectangle x1="12.33" y1="-4.15" x2="12.75" y2="-3.65" layer="51"/>
<rectangle x1="12.77" y1="-4.15" x2="13.19" y2="-3.65" layer="51"/>
<rectangle x1="13.21" y1="-4.15" x2="13.63" y2="-3.65" layer="51"/>
<rectangle x1="13.65" y1="-4.15" x2="14.07" y2="-3.65" layer="51"/>
<rectangle x1="14.09" y1="-4.15" x2="14.51" y2="-3.65" layer="51"/>
<rectangle x1="14.53" y1="-4.15" x2="14.95" y2="-3.65" layer="51"/>
<rectangle x1="14.97" y1="-4.15" x2="15.39" y2="-3.65" layer="51"/>
<rectangle x1="15.41" y1="-4.15" x2="15.83" y2="-3.65" layer="51"/>
<rectangle x1="15.85" y1="-4.15" x2="16.27" y2="-3.65" layer="51"/>
<rectangle x1="16.29" y1="-4.15" x2="16.71" y2="-3.65" layer="51"/>
<rectangle x1="16.73" y1="-4.15" x2="17.15" y2="-3.65" layer="51"/>
<rectangle x1="17.17" y1="-4.15" x2="17.59" y2="-3.65" layer="51"/>
<rectangle x1="17.61" y1="-4.15" x2="18.03" y2="-3.65" layer="51"/>
<rectangle x1="18.05" y1="-4.15" x2="18.47" y2="-3.65" layer="51"/>
<rectangle x1="18.49" y1="-4.15" x2="18.91" y2="-3.65" layer="51"/>
<rectangle x1="18.93" y1="-4.15" x2="19.35" y2="-3.65" layer="51"/>
<rectangle x1="19.37" y1="-4.15" x2="19.79" y2="-3.65" layer="51"/>
<rectangle x1="19.81" y1="-4.15" x2="20.23" y2="-3.65" layer="51"/>
<rectangle x1="20.25" y1="-4.15" x2="20.67" y2="-3.65" layer="51"/>
<rectangle x1="20.69" y1="-4.15" x2="21.11" y2="-3.65" layer="51"/>
<rectangle x1="21.13" y1="-4.15" x2="21.55" y2="-3.65" layer="51"/>
<rectangle x1="21.57" y1="-4.15" x2="21.99" y2="-3.65" layer="51"/>
<rectangle x1="22.01" y1="-4.15" x2="22.43" y2="-3.65" layer="51"/>
<rectangle x1="22.45" y1="-4.15" x2="22.87" y2="-3.65" layer="51"/>
<rectangle x1="22.89" y1="-4.15" x2="23.31" y2="-3.65" layer="51"/>
<rectangle x1="23.33" y1="-4.15" x2="23.75" y2="-3.65" layer="51"/>
<rectangle x1="23.77" y1="-4.15" x2="24.19" y2="-3.65" layer="51"/>
<rectangle x1="24.21" y1="-4.15" x2="24.63" y2="-3.65" layer="51"/>
<rectangle x1="24.65" y1="-4.15" x2="25.07" y2="-3.65" layer="51"/>
<rectangle x1="25.09" y1="-4.15" x2="25.51" y2="-3.65" layer="51"/>
<rectangle x1="25.53" y1="-4.15" x2="25.95" y2="-3.65" layer="51"/>
<rectangle x1="25.97" y1="-4.15" x2="26.39" y2="-3.65" layer="51"/>
<rectangle x1="26.41" y1="-4.15" x2="26.83" y2="-3.65" layer="51"/>
<rectangle x1="26.85" y1="-4.15" x2="27.27" y2="-3.65" layer="51"/>
<rectangle x1="27.29" y1="-4.15" x2="27.71" y2="-3.65" layer="51"/>
<rectangle x1="27.73" y1="-4.15" x2="28.15" y2="-3.65" layer="51"/>
<rectangle x1="-28.15" y1="-4.67" x2="-27.73" y2="-4.17" layer="51"/>
<rectangle x1="-27.71" y1="-4.67" x2="-27.29" y2="-4.17" layer="51"/>
<rectangle x1="-27.27" y1="-4.67" x2="-26.85" y2="-4.17" layer="51"/>
<rectangle x1="-26.83" y1="-4.67" x2="-26.41" y2="-4.17" layer="51"/>
<rectangle x1="-26.39" y1="-4.67" x2="-25.97" y2="-4.17" layer="51"/>
<rectangle x1="-25.95" y1="-4.67" x2="-25.53" y2="-4.17" layer="51"/>
<rectangle x1="-25.51" y1="-4.67" x2="-25.09" y2="-4.17" layer="51"/>
<rectangle x1="-25.07" y1="-4.67" x2="-24.65" y2="-4.17" layer="51"/>
<rectangle x1="-24.63" y1="-4.67" x2="-24.21" y2="-4.17" layer="51"/>
<rectangle x1="-24.19" y1="-4.67" x2="-23.77" y2="-4.17" layer="51"/>
<rectangle x1="-23.75" y1="-4.67" x2="-23.33" y2="-4.17" layer="51"/>
<rectangle x1="-23.31" y1="-4.67" x2="-22.89" y2="-4.17" layer="51"/>
<rectangle x1="-22.87" y1="-4.67" x2="-22.45" y2="-4.17" layer="51"/>
<rectangle x1="-22.43" y1="-4.67" x2="-22.01" y2="-4.17" layer="51"/>
<rectangle x1="-21.99" y1="-4.67" x2="-21.57" y2="-4.17" layer="51"/>
<rectangle x1="-21.55" y1="-4.67" x2="-21.13" y2="-4.17" layer="51"/>
<rectangle x1="-21.11" y1="-4.67" x2="-20.69" y2="-4.17" layer="51"/>
<rectangle x1="-20.67" y1="-4.67" x2="-20.25" y2="-4.17" layer="51"/>
<rectangle x1="-20.23" y1="-4.67" x2="-19.81" y2="-4.17" layer="51"/>
<rectangle x1="-19.79" y1="-4.67" x2="-19.37" y2="-4.17" layer="51"/>
<rectangle x1="-19.35" y1="-4.67" x2="-18.93" y2="-4.17" layer="51"/>
<rectangle x1="-18.91" y1="-4.67" x2="-18.49" y2="-4.17" layer="51"/>
<rectangle x1="-18.47" y1="-4.67" x2="-18.05" y2="-4.17" layer="51"/>
<rectangle x1="-18.03" y1="-4.67" x2="-17.61" y2="-4.17" layer="51"/>
<rectangle x1="-17.59" y1="-4.67" x2="-17.17" y2="-4.17" layer="51"/>
<rectangle x1="-17.15" y1="-4.67" x2="-16.73" y2="-4.17" layer="51"/>
<rectangle x1="-16.71" y1="-4.67" x2="-16.29" y2="-4.17" layer="51"/>
<rectangle x1="-16.27" y1="-4.67" x2="-15.85" y2="-4.17" layer="51"/>
<rectangle x1="-15.83" y1="-4.67" x2="-15.41" y2="-4.17" layer="51"/>
<rectangle x1="-15.39" y1="-4.67" x2="-14.97" y2="-4.17" layer="51"/>
<rectangle x1="-14.95" y1="-4.67" x2="-14.53" y2="-4.17" layer="51"/>
<rectangle x1="-14.51" y1="-4.67" x2="-14.09" y2="-4.17" layer="51"/>
<rectangle x1="-14.07" y1="-4.67" x2="-13.65" y2="-4.17" layer="51"/>
<rectangle x1="-13.63" y1="-4.67" x2="-13.21" y2="-4.17" layer="51"/>
<rectangle x1="-13.19" y1="-4.67" x2="-12.77" y2="-4.17" layer="51"/>
<rectangle x1="-12.75" y1="-4.67" x2="-12.33" y2="-4.17" layer="51"/>
<rectangle x1="-12.31" y1="-4.67" x2="-11.89" y2="-4.17" layer="51"/>
<rectangle x1="-11.87" y1="-4.67" x2="-11.45" y2="-4.17" layer="51"/>
<rectangle x1="-11.43" y1="-4.67" x2="-11.01" y2="-4.17" layer="51"/>
<rectangle x1="-10.99" y1="-4.67" x2="-10.57" y2="-4.17" layer="51"/>
<rectangle x1="-10.55" y1="-4.67" x2="-10.13" y2="-4.17" layer="51"/>
<rectangle x1="-10.11" y1="-4.67" x2="-9.69" y2="-4.17" layer="51"/>
<rectangle x1="-9.67" y1="-4.67" x2="-9.25" y2="-4.17" layer="51"/>
<rectangle x1="-9.23" y1="-4.67" x2="-8.81" y2="-4.17" layer="51"/>
<rectangle x1="-8.79" y1="-4.67" x2="-8.37" y2="-4.17" layer="51"/>
<rectangle x1="-8.35" y1="-4.67" x2="-7.93" y2="-4.17" layer="51"/>
<rectangle x1="-7.91" y1="-4.67" x2="-7.49" y2="-4.17" layer="51"/>
<rectangle x1="-7.47" y1="-4.67" x2="-7.05" y2="-4.17" layer="51"/>
<rectangle x1="-7.03" y1="-4.67" x2="-6.61" y2="-4.17" layer="51"/>
<rectangle x1="-6.59" y1="-4.67" x2="-6.17" y2="-4.17" layer="51"/>
<rectangle x1="-6.15" y1="-4.67" x2="-5.73" y2="-4.17" layer="51"/>
<rectangle x1="-5.71" y1="-4.67" x2="-5.29" y2="-4.17" layer="51"/>
<rectangle x1="-5.27" y1="-4.67" x2="-4.85" y2="-4.17" layer="51"/>
<rectangle x1="-4.83" y1="-4.67" x2="-4.41" y2="-4.17" layer="51"/>
<rectangle x1="-4.39" y1="-4.67" x2="-3.97" y2="-4.17" layer="51"/>
<rectangle x1="-3.95" y1="-4.67" x2="-3.53" y2="-4.17" layer="51"/>
<rectangle x1="-3.51" y1="-4.67" x2="-3.09" y2="-4.17" layer="51"/>
<rectangle x1="-3.07" y1="-4.67" x2="-2.65" y2="-4.17" layer="51"/>
<rectangle x1="-2.63" y1="-4.67" x2="-2.21" y2="-4.17" layer="51"/>
<rectangle x1="-2.19" y1="-4.67" x2="-1.77" y2="-4.17" layer="51"/>
<rectangle x1="-1.75" y1="-4.67" x2="-1.33" y2="-4.17" layer="51"/>
<rectangle x1="-1.31" y1="-4.67" x2="-0.89" y2="-4.17" layer="51"/>
<rectangle x1="-0.87" y1="-4.67" x2="-0.45" y2="-4.17" layer="51"/>
<rectangle x1="-0.43" y1="-4.67" x2="-0.01" y2="-4.17" layer="51"/>
<rectangle x1="0.01" y1="-4.67" x2="0.43" y2="-4.17" layer="51"/>
<rectangle x1="0.45" y1="-4.67" x2="0.87" y2="-4.17" layer="51"/>
<rectangle x1="0.89" y1="-4.67" x2="1.31" y2="-4.17" layer="51"/>
<rectangle x1="1.33" y1="-4.67" x2="1.75" y2="-4.17" layer="51"/>
<rectangle x1="1.77" y1="-4.67" x2="2.19" y2="-4.17" layer="51"/>
<rectangle x1="2.21" y1="-4.67" x2="2.63" y2="-4.17" layer="51"/>
<rectangle x1="2.65" y1="-4.67" x2="3.07" y2="-4.17" layer="51"/>
<rectangle x1="3.09" y1="-4.67" x2="3.51" y2="-4.17" layer="51"/>
<rectangle x1="3.53" y1="-4.67" x2="3.95" y2="-4.17" layer="51"/>
<rectangle x1="3.97" y1="-4.67" x2="4.39" y2="-4.17" layer="51"/>
<rectangle x1="4.41" y1="-4.67" x2="4.83" y2="-4.17" layer="51"/>
<rectangle x1="4.85" y1="-4.67" x2="5.27" y2="-4.17" layer="51"/>
<rectangle x1="5.29" y1="-4.67" x2="5.71" y2="-4.17" layer="51"/>
<rectangle x1="5.73" y1="-4.67" x2="6.15" y2="-4.17" layer="51"/>
<rectangle x1="6.17" y1="-4.67" x2="6.59" y2="-4.17" layer="51"/>
<rectangle x1="6.61" y1="-4.67" x2="7.03" y2="-4.17" layer="51"/>
<rectangle x1="7.05" y1="-4.67" x2="7.47" y2="-4.17" layer="51"/>
<rectangle x1="7.49" y1="-4.67" x2="7.91" y2="-4.17" layer="51"/>
<rectangle x1="7.93" y1="-4.67" x2="8.35" y2="-4.17" layer="51"/>
<rectangle x1="8.37" y1="-4.67" x2="8.79" y2="-4.17" layer="51"/>
<rectangle x1="8.81" y1="-4.67" x2="9.23" y2="-4.17" layer="51"/>
<rectangle x1="9.25" y1="-4.67" x2="9.67" y2="-4.17" layer="51"/>
<rectangle x1="9.69" y1="-4.67" x2="10.11" y2="-4.17" layer="51"/>
<rectangle x1="10.13" y1="-4.67" x2="10.55" y2="-4.17" layer="51"/>
<rectangle x1="10.57" y1="-4.67" x2="10.99" y2="-4.17" layer="51"/>
<rectangle x1="11.01" y1="-4.67" x2="11.43" y2="-4.17" layer="51"/>
<rectangle x1="11.45" y1="-4.67" x2="11.87" y2="-4.17" layer="51"/>
<rectangle x1="11.89" y1="-4.67" x2="12.31" y2="-4.17" layer="51"/>
<rectangle x1="12.33" y1="-4.67" x2="12.75" y2="-4.17" layer="51"/>
<rectangle x1="12.77" y1="-4.67" x2="13.19" y2="-4.17" layer="51"/>
<rectangle x1="13.21" y1="-4.67" x2="13.63" y2="-4.17" layer="51"/>
<rectangle x1="13.65" y1="-4.67" x2="14.07" y2="-4.17" layer="51"/>
<rectangle x1="14.09" y1="-4.67" x2="14.51" y2="-4.17" layer="51"/>
<rectangle x1="14.53" y1="-4.67" x2="14.95" y2="-4.17" layer="51"/>
<rectangle x1="14.97" y1="-4.67" x2="15.39" y2="-4.17" layer="51"/>
<rectangle x1="15.41" y1="-4.67" x2="15.83" y2="-4.17" layer="51"/>
<rectangle x1="15.85" y1="-4.67" x2="16.27" y2="-4.17" layer="51"/>
<rectangle x1="16.29" y1="-4.67" x2="16.71" y2="-4.17" layer="51"/>
<rectangle x1="16.73" y1="-4.67" x2="17.15" y2="-4.17" layer="51"/>
<rectangle x1="17.17" y1="-4.67" x2="17.59" y2="-4.17" layer="51"/>
<rectangle x1="17.61" y1="-4.67" x2="18.03" y2="-4.17" layer="51"/>
<rectangle x1="18.05" y1="-4.67" x2="18.47" y2="-4.17" layer="51"/>
<rectangle x1="18.49" y1="-4.67" x2="18.91" y2="-4.17" layer="51"/>
<rectangle x1="18.93" y1="-4.67" x2="19.35" y2="-4.17" layer="51"/>
<rectangle x1="19.37" y1="-4.67" x2="19.79" y2="-4.17" layer="51"/>
<rectangle x1="19.81" y1="-4.67" x2="20.23" y2="-4.17" layer="51"/>
<rectangle x1="20.25" y1="-4.67" x2="20.67" y2="-4.17" layer="51"/>
<rectangle x1="20.69" y1="-4.67" x2="21.11" y2="-4.17" layer="51"/>
<rectangle x1="21.13" y1="-4.67" x2="21.55" y2="-4.17" layer="51"/>
<rectangle x1="21.57" y1="-4.67" x2="21.99" y2="-4.17" layer="51"/>
<rectangle x1="22.01" y1="-4.67" x2="22.43" y2="-4.17" layer="51"/>
<rectangle x1="22.45" y1="-4.67" x2="22.87" y2="-4.17" layer="51"/>
<rectangle x1="22.89" y1="-4.67" x2="23.31" y2="-4.17" layer="51"/>
<rectangle x1="23.33" y1="-4.67" x2="23.75" y2="-4.17" layer="51"/>
<rectangle x1="23.77" y1="-4.67" x2="24.19" y2="-4.17" layer="51"/>
<rectangle x1="24.21" y1="-4.67" x2="24.63" y2="-4.17" layer="51"/>
<rectangle x1="24.65" y1="-4.67" x2="25.07" y2="-4.17" layer="51"/>
<rectangle x1="25.09" y1="-4.67" x2="25.51" y2="-4.17" layer="51"/>
<rectangle x1="25.53" y1="-4.67" x2="25.95" y2="-4.17" layer="51"/>
<rectangle x1="25.97" y1="-4.67" x2="26.39" y2="-4.17" layer="51"/>
<rectangle x1="26.41" y1="-4.67" x2="26.83" y2="-4.17" layer="51"/>
<rectangle x1="26.85" y1="-4.67" x2="27.27" y2="-4.17" layer="51"/>
<rectangle x1="27.29" y1="-4.67" x2="27.71" y2="-4.17" layer="51"/>
<rectangle x1="27.73" y1="-4.67" x2="28.15" y2="-4.17" layer="51"/>
<rectangle x1="-28.15" y1="-5.19" x2="-27.73" y2="-4.69" layer="51"/>
<rectangle x1="-27.71" y1="-5.19" x2="-27.29" y2="-4.69" layer="51"/>
<rectangle x1="-27.27" y1="-5.19" x2="-26.85" y2="-4.69" layer="51"/>
<rectangle x1="-26.83" y1="-5.19" x2="-26.41" y2="-4.69" layer="51"/>
<rectangle x1="-26.39" y1="-5.19" x2="-25.97" y2="-4.69" layer="51"/>
<rectangle x1="-25.95" y1="-5.19" x2="-25.53" y2="-4.69" layer="51"/>
<rectangle x1="-25.51" y1="-5.19" x2="-25.09" y2="-4.69" layer="51"/>
<rectangle x1="-25.07" y1="-5.19" x2="-24.65" y2="-4.69" layer="51"/>
<rectangle x1="-24.63" y1="-5.19" x2="-24.21" y2="-4.69" layer="51"/>
<rectangle x1="-24.19" y1="-5.19" x2="-23.77" y2="-4.69" layer="51"/>
<rectangle x1="-23.75" y1="-5.19" x2="-23.33" y2="-4.69" layer="51"/>
<rectangle x1="-23.31" y1="-5.19" x2="-22.89" y2="-4.69" layer="51"/>
<rectangle x1="-22.87" y1="-5.19" x2="-22.45" y2="-4.69" layer="51"/>
<rectangle x1="-22.43" y1="-5.19" x2="-22.01" y2="-4.69" layer="51"/>
<rectangle x1="-21.99" y1="-5.19" x2="-21.57" y2="-4.69" layer="51"/>
<rectangle x1="-21.55" y1="-5.19" x2="-21.13" y2="-4.69" layer="51"/>
<rectangle x1="-21.11" y1="-5.19" x2="-20.69" y2="-4.69" layer="51"/>
<rectangle x1="-20.67" y1="-5.19" x2="-20.25" y2="-4.69" layer="51"/>
<rectangle x1="-20.23" y1="-5.19" x2="-19.81" y2="-4.69" layer="51"/>
<rectangle x1="-19.79" y1="-5.19" x2="-19.37" y2="-4.69" layer="51"/>
<rectangle x1="-19.35" y1="-5.19" x2="-18.93" y2="-4.69" layer="51"/>
<rectangle x1="-18.91" y1="-5.19" x2="-18.49" y2="-4.69" layer="51"/>
<rectangle x1="-18.47" y1="-5.19" x2="-18.05" y2="-4.69" layer="51"/>
<rectangle x1="-18.03" y1="-5.19" x2="-17.61" y2="-4.69" layer="51"/>
<rectangle x1="-17.59" y1="-5.19" x2="-17.17" y2="-4.69" layer="51"/>
<rectangle x1="-17.15" y1="-5.19" x2="-16.73" y2="-4.69" layer="51"/>
<rectangle x1="-16.71" y1="-5.19" x2="-16.29" y2="-4.69" layer="51"/>
<rectangle x1="-16.27" y1="-5.19" x2="-15.85" y2="-4.69" layer="51"/>
<rectangle x1="-15.83" y1="-5.19" x2="-15.41" y2="-4.69" layer="51"/>
<rectangle x1="-15.39" y1="-5.19" x2="-14.97" y2="-4.69" layer="51"/>
<rectangle x1="-14.95" y1="-5.19" x2="-14.53" y2="-4.69" layer="51"/>
<rectangle x1="-14.51" y1="-5.19" x2="-14.09" y2="-4.69" layer="51"/>
<rectangle x1="-14.07" y1="-5.19" x2="-13.65" y2="-4.69" layer="51"/>
<rectangle x1="-13.63" y1="-5.19" x2="-13.21" y2="-4.69" layer="51"/>
<rectangle x1="-13.19" y1="-5.19" x2="-12.77" y2="-4.69" layer="51"/>
<rectangle x1="-12.75" y1="-5.19" x2="-12.33" y2="-4.69" layer="51"/>
<rectangle x1="-12.31" y1="-5.19" x2="-11.89" y2="-4.69" layer="51"/>
<rectangle x1="-11.87" y1="-5.19" x2="-11.45" y2="-4.69" layer="51"/>
<rectangle x1="-11.43" y1="-5.19" x2="-11.01" y2="-4.69" layer="51"/>
<rectangle x1="-10.99" y1="-5.19" x2="-10.57" y2="-4.69" layer="51"/>
<rectangle x1="-10.55" y1="-5.19" x2="-10.13" y2="-4.69" layer="51"/>
<rectangle x1="-10.11" y1="-5.19" x2="-9.69" y2="-4.69" layer="51"/>
<rectangle x1="-9.67" y1="-5.19" x2="-9.25" y2="-4.69" layer="51"/>
<rectangle x1="-9.23" y1="-5.19" x2="-8.81" y2="-4.69" layer="51"/>
<rectangle x1="-8.79" y1="-5.19" x2="-8.37" y2="-4.69" layer="51"/>
<rectangle x1="-8.35" y1="-5.19" x2="-7.93" y2="-4.69" layer="51"/>
<rectangle x1="-7.91" y1="-5.19" x2="-7.49" y2="-4.69" layer="51"/>
<rectangle x1="-7.47" y1="-5.19" x2="-7.05" y2="-4.69" layer="51"/>
<rectangle x1="-7.03" y1="-5.19" x2="-6.61" y2="-4.69" layer="51"/>
<rectangle x1="-6.59" y1="-5.19" x2="-6.17" y2="-4.69" layer="51"/>
<rectangle x1="-6.15" y1="-5.19" x2="-5.73" y2="-4.69" layer="51"/>
<rectangle x1="-5.71" y1="-5.19" x2="-5.29" y2="-4.69" layer="51"/>
<rectangle x1="-5.27" y1="-5.19" x2="-4.85" y2="-4.69" layer="51"/>
<rectangle x1="-4.83" y1="-5.19" x2="-4.41" y2="-4.69" layer="51"/>
<rectangle x1="-4.39" y1="-5.19" x2="-3.97" y2="-4.69" layer="51"/>
<rectangle x1="-3.95" y1="-5.19" x2="-3.53" y2="-4.69" layer="51"/>
<rectangle x1="-3.51" y1="-5.19" x2="-3.09" y2="-4.69" layer="51"/>
<rectangle x1="-3.07" y1="-5.19" x2="-2.65" y2="-4.69" layer="51"/>
<rectangle x1="-2.63" y1="-5.19" x2="-2.21" y2="-4.69" layer="51"/>
<rectangle x1="-2.19" y1="-5.19" x2="-1.77" y2="-4.69" layer="51"/>
<rectangle x1="-1.75" y1="-5.19" x2="-1.33" y2="-4.69" layer="51"/>
<rectangle x1="-1.31" y1="-5.19" x2="-0.89" y2="-4.69" layer="51"/>
<rectangle x1="-0.87" y1="-5.19" x2="-0.45" y2="-4.69" layer="51"/>
<rectangle x1="-0.43" y1="-5.19" x2="-0.01" y2="-4.69" layer="51"/>
<rectangle x1="0.01" y1="-5.19" x2="0.43" y2="-4.69" layer="51"/>
<rectangle x1="0.45" y1="-5.19" x2="0.87" y2="-4.69" layer="51"/>
<rectangle x1="0.89" y1="-5.19" x2="1.31" y2="-4.69" layer="51"/>
<rectangle x1="1.33" y1="-5.19" x2="1.75" y2="-4.69" layer="51"/>
<rectangle x1="1.77" y1="-5.19" x2="2.19" y2="-4.69" layer="51"/>
<rectangle x1="2.21" y1="-5.19" x2="2.63" y2="-4.69" layer="51"/>
<rectangle x1="2.65" y1="-5.19" x2="3.07" y2="-4.69" layer="51"/>
<rectangle x1="3.09" y1="-5.19" x2="3.51" y2="-4.69" layer="51"/>
<rectangle x1="3.53" y1="-5.19" x2="3.95" y2="-4.69" layer="51"/>
<rectangle x1="3.97" y1="-5.19" x2="4.39" y2="-4.69" layer="51"/>
<rectangle x1="4.41" y1="-5.19" x2="4.83" y2="-4.69" layer="51"/>
<rectangle x1="4.85" y1="-5.19" x2="5.27" y2="-4.69" layer="51"/>
<rectangle x1="5.29" y1="-5.19" x2="5.71" y2="-4.69" layer="51"/>
<rectangle x1="5.73" y1="-5.19" x2="6.15" y2="-4.69" layer="51"/>
<rectangle x1="6.17" y1="-5.19" x2="6.59" y2="-4.69" layer="51"/>
<rectangle x1="6.61" y1="-5.19" x2="7.03" y2="-4.69" layer="51"/>
<rectangle x1="7.05" y1="-5.19" x2="7.47" y2="-4.69" layer="51"/>
<rectangle x1="7.49" y1="-5.19" x2="7.91" y2="-4.69" layer="51"/>
<rectangle x1="7.93" y1="-5.19" x2="8.35" y2="-4.69" layer="51"/>
<rectangle x1="8.37" y1="-5.19" x2="8.79" y2="-4.69" layer="51"/>
<rectangle x1="8.81" y1="-5.19" x2="9.23" y2="-4.69" layer="51"/>
<rectangle x1="9.25" y1="-5.19" x2="9.67" y2="-4.69" layer="51"/>
<rectangle x1="9.69" y1="-5.19" x2="10.11" y2="-4.69" layer="51"/>
<rectangle x1="10.13" y1="-5.19" x2="10.55" y2="-4.69" layer="51"/>
<rectangle x1="10.57" y1="-5.19" x2="10.99" y2="-4.69" layer="51"/>
<rectangle x1="11.01" y1="-5.19" x2="11.43" y2="-4.69" layer="51"/>
<rectangle x1="11.45" y1="-5.19" x2="11.87" y2="-4.69" layer="51"/>
<rectangle x1="11.89" y1="-5.19" x2="12.31" y2="-4.69" layer="51"/>
<rectangle x1="12.33" y1="-5.19" x2="12.75" y2="-4.69" layer="51"/>
<rectangle x1="12.77" y1="-5.19" x2="13.19" y2="-4.69" layer="51"/>
<rectangle x1="13.21" y1="-5.19" x2="13.63" y2="-4.69" layer="51"/>
<rectangle x1="13.65" y1="-5.19" x2="14.07" y2="-4.69" layer="51"/>
<rectangle x1="14.09" y1="-5.19" x2="14.51" y2="-4.69" layer="51"/>
<rectangle x1="14.53" y1="-5.19" x2="14.95" y2="-4.69" layer="51"/>
<rectangle x1="14.97" y1="-5.19" x2="15.39" y2="-4.69" layer="51"/>
<rectangle x1="15.41" y1="-5.19" x2="15.83" y2="-4.69" layer="51"/>
<rectangle x1="15.85" y1="-5.19" x2="16.27" y2="-4.69" layer="51"/>
<rectangle x1="16.29" y1="-5.19" x2="16.71" y2="-4.69" layer="51"/>
<rectangle x1="16.73" y1="-5.19" x2="17.15" y2="-4.69" layer="51"/>
<rectangle x1="17.17" y1="-5.19" x2="17.59" y2="-4.69" layer="51"/>
<rectangle x1="17.61" y1="-5.19" x2="18.03" y2="-4.69" layer="51"/>
<rectangle x1="18.05" y1="-5.19" x2="18.47" y2="-4.69" layer="51"/>
<rectangle x1="18.49" y1="-5.19" x2="18.91" y2="-4.69" layer="51"/>
<rectangle x1="18.93" y1="-5.19" x2="19.35" y2="-4.69" layer="51"/>
<rectangle x1="19.37" y1="-5.19" x2="19.79" y2="-4.69" layer="51"/>
<rectangle x1="19.81" y1="-5.19" x2="20.23" y2="-4.69" layer="51"/>
<rectangle x1="20.25" y1="-5.19" x2="20.67" y2="-4.69" layer="51"/>
<rectangle x1="20.69" y1="-5.19" x2="21.11" y2="-4.69" layer="51"/>
<rectangle x1="21.13" y1="-5.19" x2="21.55" y2="-4.69" layer="51"/>
<rectangle x1="21.57" y1="-5.19" x2="21.99" y2="-4.69" layer="51"/>
<rectangle x1="22.01" y1="-5.19" x2="22.43" y2="-4.69" layer="51"/>
<rectangle x1="22.45" y1="-5.19" x2="22.87" y2="-4.69" layer="51"/>
<rectangle x1="22.89" y1="-5.19" x2="23.31" y2="-4.69" layer="51"/>
<rectangle x1="23.33" y1="-5.19" x2="23.75" y2="-4.69" layer="51"/>
<rectangle x1="23.77" y1="-5.19" x2="24.19" y2="-4.69" layer="51"/>
<rectangle x1="24.21" y1="-5.19" x2="24.63" y2="-4.69" layer="51"/>
<rectangle x1="24.65" y1="-5.19" x2="25.07" y2="-4.69" layer="51"/>
<rectangle x1="25.09" y1="-5.19" x2="25.51" y2="-4.69" layer="51"/>
<rectangle x1="25.53" y1="-5.19" x2="25.95" y2="-4.69" layer="51"/>
<rectangle x1="25.97" y1="-5.19" x2="26.39" y2="-4.69" layer="51"/>
<rectangle x1="26.41" y1="-5.19" x2="26.83" y2="-4.69" layer="51"/>
<rectangle x1="26.85" y1="-5.19" x2="27.27" y2="-4.69" layer="51"/>
<rectangle x1="27.29" y1="-5.19" x2="27.71" y2="-4.69" layer="51"/>
<rectangle x1="27.73" y1="-5.19" x2="28.15" y2="-4.69" layer="51"/>
<rectangle x1="-28.15" y1="-5.71" x2="-27.73" y2="-5.21" layer="51"/>
<rectangle x1="-27.71" y1="-5.71" x2="-27.29" y2="-5.21" layer="51"/>
<rectangle x1="-27.27" y1="-5.71" x2="-26.85" y2="-5.21" layer="51"/>
<rectangle x1="-26.83" y1="-5.71" x2="-26.41" y2="-5.21" layer="51"/>
<rectangle x1="-26.39" y1="-5.71" x2="-25.97" y2="-5.21" layer="51"/>
<rectangle x1="-25.95" y1="-5.71" x2="-25.53" y2="-5.21" layer="51"/>
<rectangle x1="-25.51" y1="-5.71" x2="-25.09" y2="-5.21" layer="51"/>
<rectangle x1="-25.07" y1="-5.71" x2="-24.65" y2="-5.21" layer="51"/>
<rectangle x1="-24.63" y1="-5.71" x2="-24.21" y2="-5.21" layer="51"/>
<rectangle x1="-24.19" y1="-5.71" x2="-23.77" y2="-5.21" layer="51"/>
<rectangle x1="-23.75" y1="-5.71" x2="-23.33" y2="-5.21" layer="51"/>
<rectangle x1="-23.31" y1="-5.71" x2="-22.89" y2="-5.21" layer="51"/>
<rectangle x1="-22.87" y1="-5.71" x2="-22.45" y2="-5.21" layer="51"/>
<rectangle x1="-22.43" y1="-5.71" x2="-22.01" y2="-5.21" layer="51"/>
<rectangle x1="-21.99" y1="-5.71" x2="-21.57" y2="-5.21" layer="51"/>
<rectangle x1="-21.55" y1="-5.71" x2="-21.13" y2="-5.21" layer="51"/>
<rectangle x1="-21.11" y1="-5.71" x2="-20.69" y2="-5.21" layer="51"/>
<rectangle x1="-20.67" y1="-5.71" x2="-20.25" y2="-5.21" layer="51"/>
<rectangle x1="-20.23" y1="-5.71" x2="-19.81" y2="-5.21" layer="51"/>
<rectangle x1="-19.79" y1="-5.71" x2="-19.37" y2="-5.21" layer="51"/>
<rectangle x1="-19.35" y1="-5.71" x2="-18.93" y2="-5.21" layer="51"/>
<rectangle x1="-18.91" y1="-5.71" x2="-18.49" y2="-5.21" layer="51"/>
<rectangle x1="-18.47" y1="-5.71" x2="-18.05" y2="-5.21" layer="51"/>
<rectangle x1="-18.03" y1="-5.71" x2="-17.61" y2="-5.21" layer="51"/>
<rectangle x1="-17.59" y1="-5.71" x2="-17.17" y2="-5.21" layer="51"/>
<rectangle x1="-17.15" y1="-5.71" x2="-16.73" y2="-5.21" layer="51"/>
<rectangle x1="-16.71" y1="-5.71" x2="-16.29" y2="-5.21" layer="51"/>
<rectangle x1="-16.27" y1="-5.71" x2="-15.85" y2="-5.21" layer="51"/>
<rectangle x1="-15.83" y1="-5.71" x2="-15.41" y2="-5.21" layer="51"/>
<rectangle x1="-15.39" y1="-5.71" x2="-14.97" y2="-5.21" layer="51"/>
<rectangle x1="-14.95" y1="-5.71" x2="-14.53" y2="-5.21" layer="51"/>
<rectangle x1="-14.51" y1="-5.71" x2="-14.09" y2="-5.21" layer="51"/>
<rectangle x1="-14.07" y1="-5.71" x2="-13.65" y2="-5.21" layer="51"/>
<rectangle x1="-13.63" y1="-5.71" x2="-13.21" y2="-5.21" layer="51"/>
<rectangle x1="-13.19" y1="-5.71" x2="-12.77" y2="-5.21" layer="51"/>
<rectangle x1="-12.75" y1="-5.71" x2="-12.33" y2="-5.21" layer="51"/>
<rectangle x1="-12.31" y1="-5.71" x2="-11.89" y2="-5.21" layer="51"/>
<rectangle x1="-11.87" y1="-5.71" x2="-11.45" y2="-5.21" layer="51"/>
<rectangle x1="-11.43" y1="-5.71" x2="-11.01" y2="-5.21" layer="51"/>
<rectangle x1="-10.99" y1="-5.71" x2="-10.57" y2="-5.21" layer="51"/>
<rectangle x1="-10.55" y1="-5.71" x2="-10.13" y2="-5.21" layer="51"/>
<rectangle x1="-10.11" y1="-5.71" x2="-9.69" y2="-5.21" layer="51"/>
<rectangle x1="-9.67" y1="-5.71" x2="-9.25" y2="-5.21" layer="51"/>
<rectangle x1="-9.23" y1="-5.71" x2="-8.81" y2="-5.21" layer="51"/>
<rectangle x1="-8.79" y1="-5.71" x2="-8.37" y2="-5.21" layer="51"/>
<rectangle x1="-8.35" y1="-5.71" x2="-7.93" y2="-5.21" layer="51"/>
<rectangle x1="-7.91" y1="-5.71" x2="-7.49" y2="-5.21" layer="51"/>
<rectangle x1="-7.47" y1="-5.71" x2="-7.05" y2="-5.21" layer="51"/>
<rectangle x1="-7.03" y1="-5.71" x2="-6.61" y2="-5.21" layer="51"/>
<rectangle x1="-6.59" y1="-5.71" x2="-6.17" y2="-5.21" layer="51"/>
<rectangle x1="-6.15" y1="-5.71" x2="-5.73" y2="-5.21" layer="51"/>
<rectangle x1="-5.71" y1="-5.71" x2="-5.29" y2="-5.21" layer="51"/>
<rectangle x1="-5.27" y1="-5.71" x2="-4.85" y2="-5.21" layer="51"/>
<rectangle x1="-4.83" y1="-5.71" x2="-4.41" y2="-5.21" layer="51"/>
<rectangle x1="-4.39" y1="-5.71" x2="-3.97" y2="-5.21" layer="51"/>
<rectangle x1="-3.95" y1="-5.71" x2="-3.53" y2="-5.21" layer="51"/>
<rectangle x1="-3.51" y1="-5.71" x2="-3.09" y2="-5.21" layer="51"/>
<rectangle x1="-3.07" y1="-5.71" x2="-2.65" y2="-5.21" layer="51"/>
<rectangle x1="-2.63" y1="-5.71" x2="-2.21" y2="-5.21" layer="51"/>
<rectangle x1="-2.19" y1="-5.71" x2="-1.77" y2="-5.21" layer="51"/>
<rectangle x1="-1.75" y1="-5.71" x2="-1.33" y2="-5.21" layer="51"/>
<rectangle x1="-1.31" y1="-5.71" x2="-0.89" y2="-5.21" layer="51"/>
<rectangle x1="-0.87" y1="-5.71" x2="-0.45" y2="-5.21" layer="51"/>
<rectangle x1="-0.43" y1="-5.71" x2="-0.01" y2="-5.21" layer="51"/>
<rectangle x1="0.01" y1="-5.71" x2="0.43" y2="-5.21" layer="51"/>
<rectangle x1="0.45" y1="-5.71" x2="0.87" y2="-5.21" layer="51"/>
<rectangle x1="0.89" y1="-5.71" x2="1.31" y2="-5.21" layer="51"/>
<rectangle x1="1.33" y1="-5.71" x2="1.75" y2="-5.21" layer="51"/>
<rectangle x1="1.77" y1="-5.71" x2="2.19" y2="-5.21" layer="51"/>
<rectangle x1="2.21" y1="-5.71" x2="2.63" y2="-5.21" layer="51"/>
<rectangle x1="2.65" y1="-5.71" x2="3.07" y2="-5.21" layer="51"/>
<rectangle x1="3.09" y1="-5.71" x2="3.51" y2="-5.21" layer="51"/>
<rectangle x1="3.53" y1="-5.71" x2="3.95" y2="-5.21" layer="51"/>
<rectangle x1="3.97" y1="-5.71" x2="4.39" y2="-5.21" layer="51"/>
<rectangle x1="4.41" y1="-5.71" x2="4.83" y2="-5.21" layer="51"/>
<rectangle x1="4.85" y1="-5.71" x2="5.27" y2="-5.21" layer="51"/>
<rectangle x1="5.29" y1="-5.71" x2="5.71" y2="-5.21" layer="51"/>
<rectangle x1="5.73" y1="-5.71" x2="6.15" y2="-5.21" layer="51"/>
<rectangle x1="6.17" y1="-5.71" x2="6.59" y2="-5.21" layer="51"/>
<rectangle x1="6.61" y1="-5.71" x2="7.03" y2="-5.21" layer="51"/>
<rectangle x1="7.05" y1="-5.71" x2="7.47" y2="-5.21" layer="51"/>
<rectangle x1="7.49" y1="-5.71" x2="7.91" y2="-5.21" layer="51"/>
<rectangle x1="7.93" y1="-5.71" x2="8.35" y2="-5.21" layer="51"/>
<rectangle x1="8.37" y1="-5.71" x2="8.79" y2="-5.21" layer="51"/>
<rectangle x1="8.81" y1="-5.71" x2="9.23" y2="-5.21" layer="51"/>
<rectangle x1="9.25" y1="-5.71" x2="9.67" y2="-5.21" layer="51"/>
<rectangle x1="9.69" y1="-5.71" x2="10.11" y2="-5.21" layer="51"/>
<rectangle x1="10.13" y1="-5.71" x2="10.55" y2="-5.21" layer="51"/>
<rectangle x1="10.57" y1="-5.71" x2="10.99" y2="-5.21" layer="51"/>
<rectangle x1="11.01" y1="-5.71" x2="11.43" y2="-5.21" layer="51"/>
<rectangle x1="11.45" y1="-5.71" x2="11.87" y2="-5.21" layer="51"/>
<rectangle x1="11.89" y1="-5.71" x2="12.31" y2="-5.21" layer="51"/>
<rectangle x1="12.33" y1="-5.71" x2="12.75" y2="-5.21" layer="51"/>
<rectangle x1="12.77" y1="-5.71" x2="13.19" y2="-5.21" layer="51"/>
<rectangle x1="13.21" y1="-5.71" x2="13.63" y2="-5.21" layer="51"/>
<rectangle x1="13.65" y1="-5.71" x2="14.07" y2="-5.21" layer="51"/>
<rectangle x1="14.09" y1="-5.71" x2="14.51" y2="-5.21" layer="51"/>
<rectangle x1="14.53" y1="-5.71" x2="14.95" y2="-5.21" layer="51"/>
<rectangle x1="14.97" y1="-5.71" x2="15.39" y2="-5.21" layer="51"/>
<rectangle x1="15.41" y1="-5.71" x2="15.83" y2="-5.21" layer="51"/>
<rectangle x1="15.85" y1="-5.71" x2="16.27" y2="-5.21" layer="51"/>
<rectangle x1="16.29" y1="-5.71" x2="16.71" y2="-5.21" layer="51"/>
<rectangle x1="16.73" y1="-5.71" x2="17.15" y2="-5.21" layer="51"/>
<rectangle x1="17.17" y1="-5.71" x2="17.59" y2="-5.21" layer="51"/>
<rectangle x1="17.61" y1="-5.71" x2="18.03" y2="-5.21" layer="51"/>
<rectangle x1="18.05" y1="-5.71" x2="18.47" y2="-5.21" layer="51"/>
<rectangle x1="18.49" y1="-5.71" x2="18.91" y2="-5.21" layer="51"/>
<rectangle x1="18.93" y1="-5.71" x2="19.35" y2="-5.21" layer="51"/>
<rectangle x1="19.37" y1="-5.71" x2="19.79" y2="-5.21" layer="51"/>
<rectangle x1="19.81" y1="-5.71" x2="20.23" y2="-5.21" layer="51"/>
<rectangle x1="20.25" y1="-5.71" x2="20.67" y2="-5.21" layer="51"/>
<rectangle x1="20.69" y1="-5.71" x2="21.11" y2="-5.21" layer="51"/>
<rectangle x1="21.13" y1="-5.71" x2="21.55" y2="-5.21" layer="51"/>
<rectangle x1="21.57" y1="-5.71" x2="21.99" y2="-5.21" layer="51"/>
<rectangle x1="22.01" y1="-5.71" x2="22.43" y2="-5.21" layer="51"/>
<rectangle x1="22.45" y1="-5.71" x2="22.87" y2="-5.21" layer="51"/>
<rectangle x1="22.89" y1="-5.71" x2="23.31" y2="-5.21" layer="51"/>
<rectangle x1="23.33" y1="-5.71" x2="23.75" y2="-5.21" layer="51"/>
<rectangle x1="23.77" y1="-5.71" x2="24.19" y2="-5.21" layer="51"/>
<rectangle x1="24.21" y1="-5.71" x2="24.63" y2="-5.21" layer="51"/>
<rectangle x1="24.65" y1="-5.71" x2="25.07" y2="-5.21" layer="51"/>
<rectangle x1="25.09" y1="-5.71" x2="25.51" y2="-5.21" layer="51"/>
<rectangle x1="25.53" y1="-5.71" x2="25.95" y2="-5.21" layer="51"/>
<rectangle x1="25.97" y1="-5.71" x2="26.39" y2="-5.21" layer="51"/>
<rectangle x1="26.41" y1="-5.71" x2="26.83" y2="-5.21" layer="51"/>
<rectangle x1="26.85" y1="-5.71" x2="27.27" y2="-5.21" layer="51"/>
<rectangle x1="27.29" y1="-5.71" x2="27.71" y2="-5.21" layer="51"/>
<rectangle x1="27.73" y1="-5.71" x2="28.15" y2="-5.21" layer="51"/>
<rectangle x1="-28.15" y1="-6.23" x2="-27.73" y2="-5.73" layer="51"/>
<rectangle x1="-27.71" y1="-6.23" x2="-27.29" y2="-5.73" layer="51"/>
<rectangle x1="-27.27" y1="-6.23" x2="-26.85" y2="-5.73" layer="51"/>
<rectangle x1="-26.83" y1="-6.23" x2="-26.41" y2="-5.73" layer="51"/>
<rectangle x1="-26.39" y1="-6.23" x2="-25.97" y2="-5.73" layer="51"/>
<rectangle x1="-25.95" y1="-6.23" x2="-25.53" y2="-5.73" layer="51"/>
<rectangle x1="-25.51" y1="-6.23" x2="-25.09" y2="-5.73" layer="51"/>
<rectangle x1="-25.07" y1="-6.23" x2="-24.65" y2="-5.73" layer="51"/>
<rectangle x1="-24.63" y1="-6.23" x2="-24.21" y2="-5.73" layer="51"/>
<rectangle x1="-24.19" y1="-6.23" x2="-23.77" y2="-5.73" layer="51"/>
<rectangle x1="-23.75" y1="-6.23" x2="-23.33" y2="-5.73" layer="51"/>
<rectangle x1="-23.31" y1="-6.23" x2="-22.89" y2="-5.73" layer="51"/>
<rectangle x1="-22.87" y1="-6.23" x2="-22.45" y2="-5.73" layer="51"/>
<rectangle x1="-22.43" y1="-6.23" x2="-22.01" y2="-5.73" layer="51"/>
<rectangle x1="-21.99" y1="-6.23" x2="-21.57" y2="-5.73" layer="51"/>
<rectangle x1="-21.55" y1="-6.23" x2="-21.13" y2="-5.73" layer="51"/>
<rectangle x1="-21.11" y1="-6.23" x2="-20.69" y2="-5.73" layer="51"/>
<rectangle x1="-20.67" y1="-6.23" x2="-20.25" y2="-5.73" layer="51"/>
<rectangle x1="-20.23" y1="-6.23" x2="-19.81" y2="-5.73" layer="51"/>
<rectangle x1="-19.79" y1="-6.23" x2="-19.37" y2="-5.73" layer="51"/>
<rectangle x1="-19.35" y1="-6.23" x2="-18.93" y2="-5.73" layer="51"/>
<rectangle x1="-18.91" y1="-6.23" x2="-18.49" y2="-5.73" layer="51"/>
<rectangle x1="-18.47" y1="-6.23" x2="-18.05" y2="-5.73" layer="51"/>
<rectangle x1="-18.03" y1="-6.23" x2="-17.61" y2="-5.73" layer="51"/>
<rectangle x1="-17.59" y1="-6.23" x2="-17.17" y2="-5.73" layer="51"/>
<rectangle x1="-17.15" y1="-6.23" x2="-16.73" y2="-5.73" layer="51"/>
<rectangle x1="-16.71" y1="-6.23" x2="-16.29" y2="-5.73" layer="51"/>
<rectangle x1="-16.27" y1="-6.23" x2="-15.85" y2="-5.73" layer="51"/>
<rectangle x1="-15.83" y1="-6.23" x2="-15.41" y2="-5.73" layer="51"/>
<rectangle x1="-15.39" y1="-6.23" x2="-14.97" y2="-5.73" layer="51"/>
<rectangle x1="-14.95" y1="-6.23" x2="-14.53" y2="-5.73" layer="51"/>
<rectangle x1="-14.51" y1="-6.23" x2="-14.09" y2="-5.73" layer="51"/>
<rectangle x1="-14.07" y1="-6.23" x2="-13.65" y2="-5.73" layer="51"/>
<rectangle x1="-13.63" y1="-6.23" x2="-13.21" y2="-5.73" layer="51"/>
<rectangle x1="-13.19" y1="-6.23" x2="-12.77" y2="-5.73" layer="51"/>
<rectangle x1="-12.75" y1="-6.23" x2="-12.33" y2="-5.73" layer="51"/>
<rectangle x1="-12.31" y1="-6.23" x2="-11.89" y2="-5.73" layer="51"/>
<rectangle x1="-11.87" y1="-6.23" x2="-11.45" y2="-5.73" layer="51"/>
<rectangle x1="-11.43" y1="-6.23" x2="-11.01" y2="-5.73" layer="51"/>
<rectangle x1="-10.99" y1="-6.23" x2="-10.57" y2="-5.73" layer="51"/>
<rectangle x1="-10.55" y1="-6.23" x2="-10.13" y2="-5.73" layer="51"/>
<rectangle x1="-10.11" y1="-6.23" x2="-9.69" y2="-5.73" layer="51"/>
<rectangle x1="-9.67" y1="-6.23" x2="-9.25" y2="-5.73" layer="51"/>
<rectangle x1="-9.23" y1="-6.23" x2="-8.81" y2="-5.73" layer="51"/>
<rectangle x1="-8.79" y1="-6.23" x2="-8.37" y2="-5.73" layer="51"/>
<rectangle x1="-8.35" y1="-6.23" x2="-7.93" y2="-5.73" layer="51"/>
<rectangle x1="-7.91" y1="-6.23" x2="-7.49" y2="-5.73" layer="51"/>
<rectangle x1="-7.47" y1="-6.23" x2="-7.05" y2="-5.73" layer="51"/>
<rectangle x1="-7.03" y1="-6.23" x2="-6.61" y2="-5.73" layer="51"/>
<rectangle x1="-6.59" y1="-6.23" x2="-6.17" y2="-5.73" layer="51"/>
<rectangle x1="-6.15" y1="-6.23" x2="-5.73" y2="-5.73" layer="51"/>
<rectangle x1="-5.71" y1="-6.23" x2="-5.29" y2="-5.73" layer="51"/>
<rectangle x1="-5.27" y1="-6.23" x2="-4.85" y2="-5.73" layer="51"/>
<rectangle x1="-4.83" y1="-6.23" x2="-4.41" y2="-5.73" layer="51"/>
<rectangle x1="-4.39" y1="-6.23" x2="-3.97" y2="-5.73" layer="51"/>
<rectangle x1="-3.95" y1="-6.23" x2="-3.53" y2="-5.73" layer="51"/>
<rectangle x1="-3.51" y1="-6.23" x2="-3.09" y2="-5.73" layer="51"/>
<rectangle x1="-3.07" y1="-6.23" x2="-2.65" y2="-5.73" layer="51"/>
<rectangle x1="-2.63" y1="-6.23" x2="-2.21" y2="-5.73" layer="51"/>
<rectangle x1="-2.19" y1="-6.23" x2="-1.77" y2="-5.73" layer="51"/>
<rectangle x1="-1.75" y1="-6.23" x2="-1.33" y2="-5.73" layer="51"/>
<rectangle x1="-1.31" y1="-6.23" x2="-0.89" y2="-5.73" layer="51"/>
<rectangle x1="-0.87" y1="-6.23" x2="-0.45" y2="-5.73" layer="51"/>
<rectangle x1="-0.43" y1="-6.23" x2="-0.01" y2="-5.73" layer="51"/>
<rectangle x1="0.01" y1="-6.23" x2="0.43" y2="-5.73" layer="51"/>
<rectangle x1="0.45" y1="-6.23" x2="0.87" y2="-5.73" layer="51"/>
<rectangle x1="0.89" y1="-6.23" x2="1.31" y2="-5.73" layer="51"/>
<rectangle x1="1.33" y1="-6.23" x2="1.75" y2="-5.73" layer="51"/>
<rectangle x1="1.77" y1="-6.23" x2="2.19" y2="-5.73" layer="51"/>
<rectangle x1="2.21" y1="-6.23" x2="2.63" y2="-5.73" layer="51"/>
<rectangle x1="2.65" y1="-6.23" x2="3.07" y2="-5.73" layer="51"/>
<rectangle x1="3.09" y1="-6.23" x2="3.51" y2="-5.73" layer="51"/>
<rectangle x1="3.53" y1="-6.23" x2="3.95" y2="-5.73" layer="51"/>
<rectangle x1="3.97" y1="-6.23" x2="4.39" y2="-5.73" layer="51"/>
<rectangle x1="4.41" y1="-6.23" x2="4.83" y2="-5.73" layer="51"/>
<rectangle x1="4.85" y1="-6.23" x2="5.27" y2="-5.73" layer="51"/>
<rectangle x1="5.29" y1="-6.23" x2="5.71" y2="-5.73" layer="51"/>
<rectangle x1="5.73" y1="-6.23" x2="6.15" y2="-5.73" layer="51"/>
<rectangle x1="6.17" y1="-6.23" x2="6.59" y2="-5.73" layer="51"/>
<rectangle x1="6.61" y1="-6.23" x2="7.03" y2="-5.73" layer="51"/>
<rectangle x1="7.05" y1="-6.23" x2="7.47" y2="-5.73" layer="51"/>
<rectangle x1="7.49" y1="-6.23" x2="7.91" y2="-5.73" layer="51"/>
<rectangle x1="7.93" y1="-6.23" x2="8.35" y2="-5.73" layer="51"/>
<rectangle x1="8.37" y1="-6.23" x2="8.79" y2="-5.73" layer="51"/>
<rectangle x1="8.81" y1="-6.23" x2="9.23" y2="-5.73" layer="51"/>
<rectangle x1="9.25" y1="-6.23" x2="9.67" y2="-5.73" layer="51"/>
<rectangle x1="9.69" y1="-6.23" x2="10.11" y2="-5.73" layer="51"/>
<rectangle x1="10.13" y1="-6.23" x2="10.55" y2="-5.73" layer="51"/>
<rectangle x1="10.57" y1="-6.23" x2="10.99" y2="-5.73" layer="51"/>
<rectangle x1="11.01" y1="-6.23" x2="11.43" y2="-5.73" layer="51"/>
<rectangle x1="11.45" y1="-6.23" x2="11.87" y2="-5.73" layer="51"/>
<rectangle x1="11.89" y1="-6.23" x2="12.31" y2="-5.73" layer="51"/>
<rectangle x1="12.33" y1="-6.23" x2="12.75" y2="-5.73" layer="51"/>
<rectangle x1="12.77" y1="-6.23" x2="13.19" y2="-5.73" layer="51"/>
<rectangle x1="13.21" y1="-6.23" x2="13.63" y2="-5.73" layer="51"/>
<rectangle x1="13.65" y1="-6.23" x2="14.07" y2="-5.73" layer="51"/>
<rectangle x1="14.09" y1="-6.23" x2="14.51" y2="-5.73" layer="51"/>
<rectangle x1="14.53" y1="-6.23" x2="14.95" y2="-5.73" layer="51"/>
<rectangle x1="14.97" y1="-6.23" x2="15.39" y2="-5.73" layer="51"/>
<rectangle x1="15.41" y1="-6.23" x2="15.83" y2="-5.73" layer="51"/>
<rectangle x1="15.85" y1="-6.23" x2="16.27" y2="-5.73" layer="51"/>
<rectangle x1="16.29" y1="-6.23" x2="16.71" y2="-5.73" layer="51"/>
<rectangle x1="16.73" y1="-6.23" x2="17.15" y2="-5.73" layer="51"/>
<rectangle x1="17.17" y1="-6.23" x2="17.59" y2="-5.73" layer="51"/>
<rectangle x1="17.61" y1="-6.23" x2="18.03" y2="-5.73" layer="51"/>
<rectangle x1="18.05" y1="-6.23" x2="18.47" y2="-5.73" layer="51"/>
<rectangle x1="18.49" y1="-6.23" x2="18.91" y2="-5.73" layer="51"/>
<rectangle x1="18.93" y1="-6.23" x2="19.35" y2="-5.73" layer="51"/>
<rectangle x1="19.37" y1="-6.23" x2="19.79" y2="-5.73" layer="51"/>
<rectangle x1="19.81" y1="-6.23" x2="20.23" y2="-5.73" layer="51"/>
<rectangle x1="20.25" y1="-6.23" x2="20.67" y2="-5.73" layer="51"/>
<rectangle x1="20.69" y1="-6.23" x2="21.11" y2="-5.73" layer="51"/>
<rectangle x1="21.13" y1="-6.23" x2="21.55" y2="-5.73" layer="51"/>
<rectangle x1="21.57" y1="-6.23" x2="21.99" y2="-5.73" layer="51"/>
<rectangle x1="22.01" y1="-6.23" x2="22.43" y2="-5.73" layer="51"/>
<rectangle x1="22.45" y1="-6.23" x2="22.87" y2="-5.73" layer="51"/>
<rectangle x1="22.89" y1="-6.23" x2="23.31" y2="-5.73" layer="51"/>
<rectangle x1="23.33" y1="-6.23" x2="23.75" y2="-5.73" layer="51"/>
<rectangle x1="23.77" y1="-6.23" x2="24.19" y2="-5.73" layer="51"/>
<rectangle x1="24.21" y1="-6.23" x2="24.63" y2="-5.73" layer="51"/>
<rectangle x1="24.65" y1="-6.23" x2="25.07" y2="-5.73" layer="51"/>
<rectangle x1="25.09" y1="-6.23" x2="25.51" y2="-5.73" layer="51"/>
<rectangle x1="25.53" y1="-6.23" x2="25.95" y2="-5.73" layer="51"/>
<rectangle x1="25.97" y1="-6.23" x2="26.39" y2="-5.73" layer="51"/>
<rectangle x1="26.41" y1="-6.23" x2="26.83" y2="-5.73" layer="51"/>
<rectangle x1="26.85" y1="-6.23" x2="27.27" y2="-5.73" layer="51"/>
<rectangle x1="27.29" y1="-6.23" x2="27.71" y2="-5.73" layer="51"/>
<rectangle x1="27.73" y1="-6.23" x2="28.15" y2="-5.73" layer="51"/>
<rectangle x1="-28.15" y1="-6.75" x2="-27.73" y2="-6.25" layer="51"/>
<rectangle x1="-27.71" y1="-6.75" x2="-27.29" y2="-6.25" layer="51"/>
<rectangle x1="-27.27" y1="-6.75" x2="-26.85" y2="-6.25" layer="51"/>
<rectangle x1="-26.83" y1="-6.75" x2="-26.41" y2="-6.25" layer="51"/>
<rectangle x1="-26.39" y1="-6.75" x2="-25.97" y2="-6.25" layer="51"/>
<rectangle x1="-25.95" y1="-6.75" x2="-25.53" y2="-6.25" layer="51"/>
<rectangle x1="-25.51" y1="-6.75" x2="-25.09" y2="-6.25" layer="51"/>
<rectangle x1="-25.07" y1="-6.75" x2="-24.65" y2="-6.25" layer="51"/>
<rectangle x1="-24.63" y1="-6.75" x2="-24.21" y2="-6.25" layer="51"/>
<rectangle x1="-24.19" y1="-6.75" x2="-23.77" y2="-6.25" layer="51"/>
<rectangle x1="-23.75" y1="-6.75" x2="-23.33" y2="-6.25" layer="51"/>
<rectangle x1="-23.31" y1="-6.75" x2="-22.89" y2="-6.25" layer="51"/>
<rectangle x1="-22.87" y1="-6.75" x2="-22.45" y2="-6.25" layer="51"/>
<rectangle x1="-22.43" y1="-6.75" x2="-22.01" y2="-6.25" layer="51"/>
<rectangle x1="-21.99" y1="-6.75" x2="-21.57" y2="-6.25" layer="51"/>
<rectangle x1="-21.55" y1="-6.75" x2="-21.13" y2="-6.25" layer="51"/>
<rectangle x1="-21.11" y1="-6.75" x2="-20.69" y2="-6.25" layer="51"/>
<rectangle x1="-20.67" y1="-6.75" x2="-20.25" y2="-6.25" layer="51"/>
<rectangle x1="-20.23" y1="-6.75" x2="-19.81" y2="-6.25" layer="51"/>
<rectangle x1="-19.79" y1="-6.75" x2="-19.37" y2="-6.25" layer="51"/>
<rectangle x1="-19.35" y1="-6.75" x2="-18.93" y2="-6.25" layer="51"/>
<rectangle x1="-18.91" y1="-6.75" x2="-18.49" y2="-6.25" layer="51"/>
<rectangle x1="-18.47" y1="-6.75" x2="-18.05" y2="-6.25" layer="51"/>
<rectangle x1="-18.03" y1="-6.75" x2="-17.61" y2="-6.25" layer="51"/>
<rectangle x1="-17.59" y1="-6.75" x2="-17.17" y2="-6.25" layer="51"/>
<rectangle x1="-17.15" y1="-6.75" x2="-16.73" y2="-6.25" layer="51"/>
<rectangle x1="-16.71" y1="-6.75" x2="-16.29" y2="-6.25" layer="51"/>
<rectangle x1="-16.27" y1="-6.75" x2="-15.85" y2="-6.25" layer="51"/>
<rectangle x1="-15.83" y1="-6.75" x2="-15.41" y2="-6.25" layer="51"/>
<rectangle x1="-15.39" y1="-6.75" x2="-14.97" y2="-6.25" layer="51"/>
<rectangle x1="-14.95" y1="-6.75" x2="-14.53" y2="-6.25" layer="51"/>
<rectangle x1="-14.51" y1="-6.75" x2="-14.09" y2="-6.25" layer="51"/>
<rectangle x1="-14.07" y1="-6.75" x2="-13.65" y2="-6.25" layer="51"/>
<rectangle x1="-13.63" y1="-6.75" x2="-13.21" y2="-6.25" layer="51"/>
<rectangle x1="-13.19" y1="-6.75" x2="-12.77" y2="-6.25" layer="51"/>
<rectangle x1="-12.75" y1="-6.75" x2="-12.33" y2="-6.25" layer="51"/>
<rectangle x1="-12.31" y1="-6.75" x2="-11.89" y2="-6.25" layer="51"/>
<rectangle x1="-11.87" y1="-6.75" x2="-11.45" y2="-6.25" layer="51"/>
<rectangle x1="-11.43" y1="-6.75" x2="-11.01" y2="-6.25" layer="51"/>
<rectangle x1="-10.99" y1="-6.75" x2="-10.57" y2="-6.25" layer="51"/>
<rectangle x1="-10.55" y1="-6.75" x2="-10.13" y2="-6.25" layer="51"/>
<rectangle x1="-10.11" y1="-6.75" x2="-9.69" y2="-6.25" layer="51"/>
<rectangle x1="-9.67" y1="-6.75" x2="-9.25" y2="-6.25" layer="51"/>
<rectangle x1="-9.23" y1="-6.75" x2="-8.81" y2="-6.25" layer="51"/>
<rectangle x1="-8.79" y1="-6.75" x2="-8.37" y2="-6.25" layer="51"/>
<rectangle x1="-8.35" y1="-6.75" x2="-7.93" y2="-6.25" layer="51"/>
<rectangle x1="-7.91" y1="-6.75" x2="-7.49" y2="-6.25" layer="51"/>
<rectangle x1="-7.47" y1="-6.75" x2="-7.05" y2="-6.25" layer="51"/>
<rectangle x1="-7.03" y1="-6.75" x2="-6.61" y2="-6.25" layer="51"/>
<rectangle x1="-6.59" y1="-6.75" x2="-6.17" y2="-6.25" layer="51"/>
<rectangle x1="-6.15" y1="-6.75" x2="-5.73" y2="-6.25" layer="51"/>
<rectangle x1="-5.71" y1="-6.75" x2="-5.29" y2="-6.25" layer="51"/>
<rectangle x1="-5.27" y1="-6.75" x2="-4.85" y2="-6.25" layer="51"/>
<rectangle x1="-4.83" y1="-6.75" x2="-4.41" y2="-6.25" layer="51"/>
<rectangle x1="-4.39" y1="-6.75" x2="-3.97" y2="-6.25" layer="51"/>
<rectangle x1="-3.95" y1="-6.75" x2="-3.53" y2="-6.25" layer="51"/>
<rectangle x1="-3.51" y1="-6.75" x2="-3.09" y2="-6.25" layer="51"/>
<rectangle x1="-3.07" y1="-6.75" x2="-2.65" y2="-6.25" layer="51"/>
<rectangle x1="-2.63" y1="-6.75" x2="-2.21" y2="-6.25" layer="51"/>
<rectangle x1="-2.19" y1="-6.75" x2="-1.77" y2="-6.25" layer="51"/>
<rectangle x1="-1.75" y1="-6.75" x2="-1.33" y2="-6.25" layer="51"/>
<rectangle x1="-1.31" y1="-6.75" x2="-0.89" y2="-6.25" layer="51"/>
<rectangle x1="-0.87" y1="-6.75" x2="-0.45" y2="-6.25" layer="51"/>
<rectangle x1="-0.43" y1="-6.75" x2="-0.01" y2="-6.25" layer="51"/>
<rectangle x1="0.01" y1="-6.75" x2="0.43" y2="-6.25" layer="51"/>
<rectangle x1="0.45" y1="-6.75" x2="0.87" y2="-6.25" layer="51"/>
<rectangle x1="0.89" y1="-6.75" x2="1.31" y2="-6.25" layer="51"/>
<rectangle x1="1.33" y1="-6.75" x2="1.75" y2="-6.25" layer="51"/>
<rectangle x1="1.77" y1="-6.75" x2="2.19" y2="-6.25" layer="51"/>
<rectangle x1="2.21" y1="-6.75" x2="2.63" y2="-6.25" layer="51"/>
<rectangle x1="2.65" y1="-6.75" x2="3.07" y2="-6.25" layer="51"/>
<rectangle x1="3.09" y1="-6.75" x2="3.51" y2="-6.25" layer="51"/>
<rectangle x1="3.53" y1="-6.75" x2="3.95" y2="-6.25" layer="51"/>
<rectangle x1="3.97" y1="-6.75" x2="4.39" y2="-6.25" layer="51"/>
<rectangle x1="4.41" y1="-6.75" x2="4.83" y2="-6.25" layer="51"/>
<rectangle x1="4.85" y1="-6.75" x2="5.27" y2="-6.25" layer="51"/>
<rectangle x1="5.29" y1="-6.75" x2="5.71" y2="-6.25" layer="51"/>
<rectangle x1="5.73" y1="-6.75" x2="6.15" y2="-6.25" layer="51"/>
<rectangle x1="6.17" y1="-6.75" x2="6.59" y2="-6.25" layer="51"/>
<rectangle x1="6.61" y1="-6.75" x2="7.03" y2="-6.25" layer="51"/>
<rectangle x1="7.05" y1="-6.75" x2="7.47" y2="-6.25" layer="51"/>
<rectangle x1="7.49" y1="-6.75" x2="7.91" y2="-6.25" layer="51"/>
<rectangle x1="7.93" y1="-6.75" x2="8.35" y2="-6.25" layer="51"/>
<rectangle x1="8.37" y1="-6.75" x2="8.79" y2="-6.25" layer="51"/>
<rectangle x1="8.81" y1="-6.75" x2="9.23" y2="-6.25" layer="51"/>
<rectangle x1="9.25" y1="-6.75" x2="9.67" y2="-6.25" layer="51"/>
<rectangle x1="9.69" y1="-6.75" x2="10.11" y2="-6.25" layer="51"/>
<rectangle x1="10.13" y1="-6.75" x2="10.55" y2="-6.25" layer="51"/>
<rectangle x1="10.57" y1="-6.75" x2="10.99" y2="-6.25" layer="51"/>
<rectangle x1="11.01" y1="-6.75" x2="11.43" y2="-6.25" layer="51"/>
<rectangle x1="11.45" y1="-6.75" x2="11.87" y2="-6.25" layer="51"/>
<rectangle x1="11.89" y1="-6.75" x2="12.31" y2="-6.25" layer="51"/>
<rectangle x1="12.33" y1="-6.75" x2="12.75" y2="-6.25" layer="51"/>
<rectangle x1="12.77" y1="-6.75" x2="13.19" y2="-6.25" layer="51"/>
<rectangle x1="13.21" y1="-6.75" x2="13.63" y2="-6.25" layer="51"/>
<rectangle x1="13.65" y1="-6.75" x2="14.07" y2="-6.25" layer="51"/>
<rectangle x1="14.09" y1="-6.75" x2="14.51" y2="-6.25" layer="51"/>
<rectangle x1="14.53" y1="-6.75" x2="14.95" y2="-6.25" layer="51"/>
<rectangle x1="14.97" y1="-6.75" x2="15.39" y2="-6.25" layer="51"/>
<rectangle x1="15.41" y1="-6.75" x2="15.83" y2="-6.25" layer="51"/>
<rectangle x1="15.85" y1="-6.75" x2="16.27" y2="-6.25" layer="51"/>
<rectangle x1="16.29" y1="-6.75" x2="16.71" y2="-6.25" layer="51"/>
<rectangle x1="16.73" y1="-6.75" x2="17.15" y2="-6.25" layer="51"/>
<rectangle x1="17.17" y1="-6.75" x2="17.59" y2="-6.25" layer="51"/>
<rectangle x1="17.61" y1="-6.75" x2="18.03" y2="-6.25" layer="51"/>
<rectangle x1="18.05" y1="-6.75" x2="18.47" y2="-6.25" layer="51"/>
<rectangle x1="18.49" y1="-6.75" x2="18.91" y2="-6.25" layer="51"/>
<rectangle x1="18.93" y1="-6.75" x2="19.35" y2="-6.25" layer="51"/>
<rectangle x1="19.37" y1="-6.75" x2="19.79" y2="-6.25" layer="51"/>
<rectangle x1="19.81" y1="-6.75" x2="20.23" y2="-6.25" layer="51"/>
<rectangle x1="20.25" y1="-6.75" x2="20.67" y2="-6.25" layer="51"/>
<rectangle x1="20.69" y1="-6.75" x2="21.11" y2="-6.25" layer="51"/>
<rectangle x1="21.13" y1="-6.75" x2="21.55" y2="-6.25" layer="51"/>
<rectangle x1="21.57" y1="-6.75" x2="21.99" y2="-6.25" layer="51"/>
<rectangle x1="22.01" y1="-6.75" x2="22.43" y2="-6.25" layer="51"/>
<rectangle x1="22.45" y1="-6.75" x2="22.87" y2="-6.25" layer="51"/>
<rectangle x1="22.89" y1="-6.75" x2="23.31" y2="-6.25" layer="51"/>
<rectangle x1="23.33" y1="-6.75" x2="23.75" y2="-6.25" layer="51"/>
<rectangle x1="23.77" y1="-6.75" x2="24.19" y2="-6.25" layer="51"/>
<rectangle x1="24.21" y1="-6.75" x2="24.63" y2="-6.25" layer="51"/>
<rectangle x1="24.65" y1="-6.75" x2="25.07" y2="-6.25" layer="51"/>
<rectangle x1="25.09" y1="-6.75" x2="25.51" y2="-6.25" layer="51"/>
<rectangle x1="25.53" y1="-6.75" x2="25.95" y2="-6.25" layer="51"/>
<rectangle x1="25.97" y1="-6.75" x2="26.39" y2="-6.25" layer="51"/>
<rectangle x1="26.41" y1="-6.75" x2="26.83" y2="-6.25" layer="51"/>
<rectangle x1="26.85" y1="-6.75" x2="27.27" y2="-6.25" layer="51"/>
<rectangle x1="27.29" y1="-6.75" x2="27.71" y2="-6.25" layer="51"/>
<rectangle x1="27.73" y1="-6.75" x2="28.15" y2="-6.25" layer="51"/>
<rectangle x1="-28.15" y1="-7.27" x2="-27.73" y2="-6.77" layer="51"/>
<rectangle x1="-27.71" y1="-7.27" x2="-27.29" y2="-6.77" layer="51"/>
<rectangle x1="-27.27" y1="-7.27" x2="-26.85" y2="-6.77" layer="51"/>
<rectangle x1="-26.83" y1="-7.27" x2="-26.41" y2="-6.77" layer="51"/>
<rectangle x1="-26.39" y1="-7.27" x2="-25.97" y2="-6.77" layer="51"/>
<rectangle x1="-25.95" y1="-7.27" x2="-25.53" y2="-6.77" layer="51"/>
<rectangle x1="-25.51" y1="-7.27" x2="-25.09" y2="-6.77" layer="51"/>
<rectangle x1="-25.07" y1="-7.27" x2="-24.65" y2="-6.77" layer="51"/>
<rectangle x1="-24.63" y1="-7.27" x2="-24.21" y2="-6.77" layer="51"/>
<rectangle x1="-24.19" y1="-7.27" x2="-23.77" y2="-6.77" layer="51"/>
<rectangle x1="-23.75" y1="-7.27" x2="-23.33" y2="-6.77" layer="51"/>
<rectangle x1="-23.31" y1="-7.27" x2="-22.89" y2="-6.77" layer="51"/>
<rectangle x1="-22.87" y1="-7.27" x2="-22.45" y2="-6.77" layer="51"/>
<rectangle x1="-22.43" y1="-7.27" x2="-22.01" y2="-6.77" layer="51"/>
<rectangle x1="-21.99" y1="-7.27" x2="-21.57" y2="-6.77" layer="51"/>
<rectangle x1="-21.55" y1="-7.27" x2="-21.13" y2="-6.77" layer="51"/>
<rectangle x1="-21.11" y1="-7.27" x2="-20.69" y2="-6.77" layer="51"/>
<rectangle x1="-20.67" y1="-7.27" x2="-20.25" y2="-6.77" layer="51"/>
<rectangle x1="-20.23" y1="-7.27" x2="-19.81" y2="-6.77" layer="51"/>
<rectangle x1="-19.79" y1="-7.27" x2="-19.37" y2="-6.77" layer="51"/>
<rectangle x1="-19.35" y1="-7.27" x2="-18.93" y2="-6.77" layer="51"/>
<rectangle x1="-18.91" y1="-7.27" x2="-18.49" y2="-6.77" layer="51"/>
<rectangle x1="-18.47" y1="-7.27" x2="-18.05" y2="-6.77" layer="51"/>
<rectangle x1="-18.03" y1="-7.27" x2="-17.61" y2="-6.77" layer="51"/>
<rectangle x1="-17.59" y1="-7.27" x2="-17.17" y2="-6.77" layer="51"/>
<rectangle x1="-17.15" y1="-7.27" x2="-16.73" y2="-6.77" layer="51"/>
<rectangle x1="-16.71" y1="-7.27" x2="-16.29" y2="-6.77" layer="51"/>
<rectangle x1="-16.27" y1="-7.27" x2="-15.85" y2="-6.77" layer="51"/>
<rectangle x1="-15.83" y1="-7.27" x2="-15.41" y2="-6.77" layer="51"/>
<rectangle x1="-15.39" y1="-7.27" x2="-14.97" y2="-6.77" layer="51"/>
<rectangle x1="-14.95" y1="-7.27" x2="-14.53" y2="-6.77" layer="51"/>
<rectangle x1="-14.51" y1="-7.27" x2="-14.09" y2="-6.77" layer="51"/>
<rectangle x1="-14.07" y1="-7.27" x2="-13.65" y2="-6.77" layer="51"/>
<rectangle x1="-13.63" y1="-7.27" x2="-13.21" y2="-6.77" layer="51"/>
<rectangle x1="-13.19" y1="-7.27" x2="-12.77" y2="-6.77" layer="51"/>
<rectangle x1="-12.75" y1="-7.27" x2="-12.33" y2="-6.77" layer="51"/>
<rectangle x1="-12.31" y1="-7.27" x2="-11.89" y2="-6.77" layer="51"/>
<rectangle x1="-11.87" y1="-7.27" x2="-11.45" y2="-6.77" layer="51"/>
<rectangle x1="-11.43" y1="-7.27" x2="-11.01" y2="-6.77" layer="51"/>
<rectangle x1="-10.99" y1="-7.27" x2="-10.57" y2="-6.77" layer="51"/>
<rectangle x1="-10.55" y1="-7.27" x2="-10.13" y2="-6.77" layer="51"/>
<rectangle x1="-10.11" y1="-7.27" x2="-9.69" y2="-6.77" layer="51"/>
<rectangle x1="-9.67" y1="-7.27" x2="-9.25" y2="-6.77" layer="51"/>
<rectangle x1="-9.23" y1="-7.27" x2="-8.81" y2="-6.77" layer="51"/>
<rectangle x1="-8.79" y1="-7.27" x2="-8.37" y2="-6.77" layer="51"/>
<rectangle x1="-8.35" y1="-7.27" x2="-7.93" y2="-6.77" layer="51"/>
<rectangle x1="-7.91" y1="-7.27" x2="-7.49" y2="-6.77" layer="51"/>
<rectangle x1="-7.47" y1="-7.27" x2="-7.05" y2="-6.77" layer="51"/>
<rectangle x1="-7.03" y1="-7.27" x2="-6.61" y2="-6.77" layer="51"/>
<rectangle x1="-6.59" y1="-7.27" x2="-6.17" y2="-6.77" layer="51"/>
<rectangle x1="-6.15" y1="-7.27" x2="-5.73" y2="-6.77" layer="51"/>
<rectangle x1="-5.71" y1="-7.27" x2="-5.29" y2="-6.77" layer="51"/>
<rectangle x1="-5.27" y1="-7.27" x2="-4.85" y2="-6.77" layer="51"/>
<rectangle x1="-4.83" y1="-7.27" x2="-4.41" y2="-6.77" layer="51"/>
<rectangle x1="-4.39" y1="-7.27" x2="-3.97" y2="-6.77" layer="51"/>
<rectangle x1="-3.95" y1="-7.27" x2="-3.53" y2="-6.77" layer="51"/>
<rectangle x1="-3.51" y1="-7.27" x2="-3.09" y2="-6.77" layer="51"/>
<rectangle x1="-3.07" y1="-7.27" x2="-2.65" y2="-6.77" layer="51"/>
<rectangle x1="-2.63" y1="-7.27" x2="-2.21" y2="-6.77" layer="51"/>
<rectangle x1="-2.19" y1="-7.27" x2="-1.77" y2="-6.77" layer="51"/>
<rectangle x1="-1.75" y1="-7.27" x2="-1.33" y2="-6.77" layer="51"/>
<rectangle x1="-1.31" y1="-7.27" x2="-0.89" y2="-6.77" layer="51"/>
<rectangle x1="-0.87" y1="-7.27" x2="-0.45" y2="-6.77" layer="51"/>
<rectangle x1="-0.43" y1="-7.27" x2="-0.01" y2="-6.77" layer="51"/>
<rectangle x1="0.01" y1="-7.27" x2="0.43" y2="-6.77" layer="51"/>
<rectangle x1="0.45" y1="-7.27" x2="0.87" y2="-6.77" layer="51"/>
<rectangle x1="0.89" y1="-7.27" x2="1.31" y2="-6.77" layer="51"/>
<rectangle x1="1.33" y1="-7.27" x2="1.75" y2="-6.77" layer="51"/>
<rectangle x1="1.77" y1="-7.27" x2="2.19" y2="-6.77" layer="51"/>
<rectangle x1="2.21" y1="-7.27" x2="2.63" y2="-6.77" layer="51"/>
<rectangle x1="2.65" y1="-7.27" x2="3.07" y2="-6.77" layer="51"/>
<rectangle x1="3.09" y1="-7.27" x2="3.51" y2="-6.77" layer="51"/>
<rectangle x1="3.53" y1="-7.27" x2="3.95" y2="-6.77" layer="51"/>
<rectangle x1="3.97" y1="-7.27" x2="4.39" y2="-6.77" layer="51"/>
<rectangle x1="4.41" y1="-7.27" x2="4.83" y2="-6.77" layer="51"/>
<rectangle x1="4.85" y1="-7.27" x2="5.27" y2="-6.77" layer="51"/>
<rectangle x1="5.29" y1="-7.27" x2="5.71" y2="-6.77" layer="51"/>
<rectangle x1="5.73" y1="-7.27" x2="6.15" y2="-6.77" layer="51"/>
<rectangle x1="6.17" y1="-7.27" x2="6.59" y2="-6.77" layer="51"/>
<rectangle x1="6.61" y1="-7.27" x2="7.03" y2="-6.77" layer="51"/>
<rectangle x1="7.05" y1="-7.27" x2="7.47" y2="-6.77" layer="51"/>
<rectangle x1="7.49" y1="-7.27" x2="7.91" y2="-6.77" layer="51"/>
<rectangle x1="7.93" y1="-7.27" x2="8.35" y2="-6.77" layer="51"/>
<rectangle x1="8.37" y1="-7.27" x2="8.79" y2="-6.77" layer="51"/>
<rectangle x1="8.81" y1="-7.27" x2="9.23" y2="-6.77" layer="51"/>
<rectangle x1="9.25" y1="-7.27" x2="9.67" y2="-6.77" layer="51"/>
<rectangle x1="9.69" y1="-7.27" x2="10.11" y2="-6.77" layer="51"/>
<rectangle x1="10.13" y1="-7.27" x2="10.55" y2="-6.77" layer="51"/>
<rectangle x1="10.57" y1="-7.27" x2="10.99" y2="-6.77" layer="51"/>
<rectangle x1="11.01" y1="-7.27" x2="11.43" y2="-6.77" layer="51"/>
<rectangle x1="11.45" y1="-7.27" x2="11.87" y2="-6.77" layer="51"/>
<rectangle x1="11.89" y1="-7.27" x2="12.31" y2="-6.77" layer="51"/>
<rectangle x1="12.33" y1="-7.27" x2="12.75" y2="-6.77" layer="51"/>
<rectangle x1="12.77" y1="-7.27" x2="13.19" y2="-6.77" layer="51"/>
<rectangle x1="13.21" y1="-7.27" x2="13.63" y2="-6.77" layer="51"/>
<rectangle x1="13.65" y1="-7.27" x2="14.07" y2="-6.77" layer="51"/>
<rectangle x1="14.09" y1="-7.27" x2="14.51" y2="-6.77" layer="51"/>
<rectangle x1="14.53" y1="-7.27" x2="14.95" y2="-6.77" layer="51"/>
<rectangle x1="14.97" y1="-7.27" x2="15.39" y2="-6.77" layer="51"/>
<rectangle x1="15.41" y1="-7.27" x2="15.83" y2="-6.77" layer="51"/>
<rectangle x1="15.85" y1="-7.27" x2="16.27" y2="-6.77" layer="51"/>
<rectangle x1="16.29" y1="-7.27" x2="16.71" y2="-6.77" layer="51"/>
<rectangle x1="16.73" y1="-7.27" x2="17.15" y2="-6.77" layer="51"/>
<rectangle x1="17.17" y1="-7.27" x2="17.59" y2="-6.77" layer="51"/>
<rectangle x1="17.61" y1="-7.27" x2="18.03" y2="-6.77" layer="51"/>
<rectangle x1="18.05" y1="-7.27" x2="18.47" y2="-6.77" layer="51"/>
<rectangle x1="18.49" y1="-7.27" x2="18.91" y2="-6.77" layer="51"/>
<rectangle x1="18.93" y1="-7.27" x2="19.35" y2="-6.77" layer="51"/>
<rectangle x1="19.37" y1="-7.27" x2="19.79" y2="-6.77" layer="51"/>
<rectangle x1="19.81" y1="-7.27" x2="20.23" y2="-6.77" layer="51"/>
<rectangle x1="20.25" y1="-7.27" x2="20.67" y2="-6.77" layer="51"/>
<rectangle x1="20.69" y1="-7.27" x2="21.11" y2="-6.77" layer="51"/>
<rectangle x1="21.13" y1="-7.27" x2="21.55" y2="-6.77" layer="51"/>
<rectangle x1="21.57" y1="-7.27" x2="21.99" y2="-6.77" layer="51"/>
<rectangle x1="22.01" y1="-7.27" x2="22.43" y2="-6.77" layer="51"/>
<rectangle x1="22.45" y1="-7.27" x2="22.87" y2="-6.77" layer="51"/>
<rectangle x1="22.89" y1="-7.27" x2="23.31" y2="-6.77" layer="51"/>
<rectangle x1="23.33" y1="-7.27" x2="23.75" y2="-6.77" layer="51"/>
<rectangle x1="23.77" y1="-7.27" x2="24.19" y2="-6.77" layer="51"/>
<rectangle x1="24.21" y1="-7.27" x2="24.63" y2="-6.77" layer="51"/>
<rectangle x1="24.65" y1="-7.27" x2="25.07" y2="-6.77" layer="51"/>
<rectangle x1="25.09" y1="-7.27" x2="25.51" y2="-6.77" layer="51"/>
<rectangle x1="25.53" y1="-7.27" x2="25.95" y2="-6.77" layer="51"/>
<rectangle x1="25.97" y1="-7.27" x2="26.39" y2="-6.77" layer="51"/>
<rectangle x1="26.41" y1="-7.27" x2="26.83" y2="-6.77" layer="51"/>
<rectangle x1="26.85" y1="-7.27" x2="27.27" y2="-6.77" layer="51"/>
<rectangle x1="27.29" y1="-7.27" x2="27.71" y2="-6.77" layer="51"/>
<rectangle x1="27.73" y1="-7.27" x2="28.15" y2="-6.77" layer="51"/>
<rectangle x1="-28.15" y1="-7.79" x2="-27.73" y2="-7.29" layer="51"/>
<rectangle x1="-27.71" y1="-7.79" x2="-27.29" y2="-7.29" layer="51"/>
<rectangle x1="-27.27" y1="-7.79" x2="-26.85" y2="-7.29" layer="51"/>
<rectangle x1="-26.83" y1="-7.79" x2="-26.41" y2="-7.29" layer="51"/>
<rectangle x1="-26.39" y1="-7.79" x2="-25.97" y2="-7.29" layer="51"/>
<rectangle x1="-25.95" y1="-7.79" x2="-25.53" y2="-7.29" layer="51"/>
<rectangle x1="-25.51" y1="-7.79" x2="-25.09" y2="-7.29" layer="51"/>
<rectangle x1="-25.07" y1="-7.79" x2="-24.65" y2="-7.29" layer="51"/>
<rectangle x1="-24.63" y1="-7.79" x2="-24.21" y2="-7.29" layer="51"/>
<rectangle x1="-24.19" y1="-7.79" x2="-23.77" y2="-7.29" layer="51"/>
<rectangle x1="-23.75" y1="-7.79" x2="-23.33" y2="-7.29" layer="51"/>
<rectangle x1="-23.31" y1="-7.79" x2="-22.89" y2="-7.29" layer="51"/>
<rectangle x1="-22.87" y1="-7.79" x2="-22.45" y2="-7.29" layer="51"/>
<rectangle x1="-22.43" y1="-7.79" x2="-22.01" y2="-7.29" layer="51"/>
<rectangle x1="-21.99" y1="-7.79" x2="-21.57" y2="-7.29" layer="51"/>
<rectangle x1="-21.55" y1="-7.79" x2="-21.13" y2="-7.29" layer="51"/>
<rectangle x1="-21.11" y1="-7.79" x2="-20.69" y2="-7.29" layer="51"/>
<rectangle x1="-20.67" y1="-7.79" x2="-20.25" y2="-7.29" layer="51"/>
<rectangle x1="-20.23" y1="-7.79" x2="-19.81" y2="-7.29" layer="51"/>
<rectangle x1="-19.79" y1="-7.79" x2="-19.37" y2="-7.29" layer="51"/>
<rectangle x1="-19.35" y1="-7.79" x2="-18.93" y2="-7.29" layer="51"/>
<rectangle x1="-18.91" y1="-7.79" x2="-18.49" y2="-7.29" layer="51"/>
<rectangle x1="-18.47" y1="-7.79" x2="-18.05" y2="-7.29" layer="51"/>
<rectangle x1="-18.03" y1="-7.79" x2="-17.61" y2="-7.29" layer="51"/>
<rectangle x1="-17.59" y1="-7.79" x2="-17.17" y2="-7.29" layer="51"/>
<rectangle x1="-17.15" y1="-7.79" x2="-16.73" y2="-7.29" layer="51"/>
<rectangle x1="-16.71" y1="-7.79" x2="-16.29" y2="-7.29" layer="51"/>
<rectangle x1="-16.27" y1="-7.79" x2="-15.85" y2="-7.29" layer="51"/>
<rectangle x1="-15.83" y1="-7.79" x2="-15.41" y2="-7.29" layer="51"/>
<rectangle x1="-15.39" y1="-7.79" x2="-14.97" y2="-7.29" layer="51"/>
<rectangle x1="-14.95" y1="-7.79" x2="-14.53" y2="-7.29" layer="51"/>
<rectangle x1="-14.51" y1="-7.79" x2="-14.09" y2="-7.29" layer="51"/>
<rectangle x1="-14.07" y1="-7.79" x2="-13.65" y2="-7.29" layer="51"/>
<rectangle x1="-13.63" y1="-7.79" x2="-13.21" y2="-7.29" layer="51"/>
<rectangle x1="-13.19" y1="-7.79" x2="-12.77" y2="-7.29" layer="51"/>
<rectangle x1="-12.75" y1="-7.79" x2="-12.33" y2="-7.29" layer="51"/>
<rectangle x1="-12.31" y1="-7.79" x2="-11.89" y2="-7.29" layer="51"/>
<rectangle x1="-11.87" y1="-7.79" x2="-11.45" y2="-7.29" layer="51"/>
<rectangle x1="-11.43" y1="-7.79" x2="-11.01" y2="-7.29" layer="51"/>
<rectangle x1="-10.99" y1="-7.79" x2="-10.57" y2="-7.29" layer="51"/>
<rectangle x1="-10.55" y1="-7.79" x2="-10.13" y2="-7.29" layer="51"/>
<rectangle x1="-10.11" y1="-7.79" x2="-9.69" y2="-7.29" layer="51"/>
<rectangle x1="-9.67" y1="-7.79" x2="-9.25" y2="-7.29" layer="51"/>
<rectangle x1="-9.23" y1="-7.79" x2="-8.81" y2="-7.29" layer="51"/>
<rectangle x1="-8.79" y1="-7.79" x2="-8.37" y2="-7.29" layer="51"/>
<rectangle x1="-8.35" y1="-7.79" x2="-7.93" y2="-7.29" layer="51"/>
<rectangle x1="-7.91" y1="-7.79" x2="-7.49" y2="-7.29" layer="51"/>
<rectangle x1="-7.47" y1="-7.79" x2="-7.05" y2="-7.29" layer="51"/>
<rectangle x1="-7.03" y1="-7.79" x2="-6.61" y2="-7.29" layer="51"/>
<rectangle x1="-6.59" y1="-7.79" x2="-6.17" y2="-7.29" layer="51"/>
<rectangle x1="-6.15" y1="-7.79" x2="-5.73" y2="-7.29" layer="51"/>
<rectangle x1="-5.71" y1="-7.79" x2="-5.29" y2="-7.29" layer="51"/>
<rectangle x1="-5.27" y1="-7.79" x2="-4.85" y2="-7.29" layer="51"/>
<rectangle x1="-4.83" y1="-7.79" x2="-4.41" y2="-7.29" layer="51"/>
<rectangle x1="-4.39" y1="-7.79" x2="-3.97" y2="-7.29" layer="51"/>
<rectangle x1="-3.95" y1="-7.79" x2="-3.53" y2="-7.29" layer="51"/>
<rectangle x1="-3.51" y1="-7.79" x2="-3.09" y2="-7.29" layer="51"/>
<rectangle x1="-3.07" y1="-7.79" x2="-2.65" y2="-7.29" layer="51"/>
<rectangle x1="-2.63" y1="-7.79" x2="-2.21" y2="-7.29" layer="51"/>
<rectangle x1="-2.19" y1="-7.79" x2="-1.77" y2="-7.29" layer="51"/>
<rectangle x1="-1.75" y1="-7.79" x2="-1.33" y2="-7.29" layer="51"/>
<rectangle x1="-1.31" y1="-7.79" x2="-0.89" y2="-7.29" layer="51"/>
<rectangle x1="-0.87" y1="-7.79" x2="-0.45" y2="-7.29" layer="51"/>
<rectangle x1="-0.43" y1="-7.79" x2="-0.01" y2="-7.29" layer="51"/>
<rectangle x1="0.01" y1="-7.79" x2="0.43" y2="-7.29" layer="51"/>
<rectangle x1="0.45" y1="-7.79" x2="0.87" y2="-7.29" layer="51"/>
<rectangle x1="0.89" y1="-7.79" x2="1.31" y2="-7.29" layer="51"/>
<rectangle x1="1.33" y1="-7.79" x2="1.75" y2="-7.29" layer="51"/>
<rectangle x1="1.77" y1="-7.79" x2="2.19" y2="-7.29" layer="51"/>
<rectangle x1="2.21" y1="-7.79" x2="2.63" y2="-7.29" layer="51"/>
<rectangle x1="2.65" y1="-7.79" x2="3.07" y2="-7.29" layer="51"/>
<rectangle x1="3.09" y1="-7.79" x2="3.51" y2="-7.29" layer="51"/>
<rectangle x1="3.53" y1="-7.79" x2="3.95" y2="-7.29" layer="51"/>
<rectangle x1="3.97" y1="-7.79" x2="4.39" y2="-7.29" layer="51"/>
<rectangle x1="4.41" y1="-7.79" x2="4.83" y2="-7.29" layer="51"/>
<rectangle x1="4.85" y1="-7.79" x2="5.27" y2="-7.29" layer="51"/>
<rectangle x1="5.29" y1="-7.79" x2="5.71" y2="-7.29" layer="51"/>
<rectangle x1="5.73" y1="-7.79" x2="6.15" y2="-7.29" layer="51"/>
<rectangle x1="6.17" y1="-7.79" x2="6.59" y2="-7.29" layer="51"/>
<rectangle x1="6.61" y1="-7.79" x2="7.03" y2="-7.29" layer="51"/>
<rectangle x1="7.05" y1="-7.79" x2="7.47" y2="-7.29" layer="51"/>
<rectangle x1="7.49" y1="-7.79" x2="7.91" y2="-7.29" layer="51"/>
<rectangle x1="7.93" y1="-7.79" x2="8.35" y2="-7.29" layer="51"/>
<rectangle x1="8.37" y1="-7.79" x2="8.79" y2="-7.29" layer="51"/>
<rectangle x1="8.81" y1="-7.79" x2="9.23" y2="-7.29" layer="51"/>
<rectangle x1="9.25" y1="-7.79" x2="9.67" y2="-7.29" layer="51"/>
<rectangle x1="9.69" y1="-7.79" x2="10.11" y2="-7.29" layer="51"/>
<rectangle x1="10.13" y1="-7.79" x2="10.55" y2="-7.29" layer="51"/>
<rectangle x1="10.57" y1="-7.79" x2="10.99" y2="-7.29" layer="51"/>
<rectangle x1="11.01" y1="-7.79" x2="11.43" y2="-7.29" layer="51"/>
<rectangle x1="11.45" y1="-7.79" x2="11.87" y2="-7.29" layer="51"/>
<rectangle x1="11.89" y1="-7.79" x2="12.31" y2="-7.29" layer="51"/>
<rectangle x1="12.33" y1="-7.79" x2="12.75" y2="-7.29" layer="51"/>
<rectangle x1="12.77" y1="-7.79" x2="13.19" y2="-7.29" layer="51"/>
<rectangle x1="13.21" y1="-7.79" x2="13.63" y2="-7.29" layer="51"/>
<rectangle x1="13.65" y1="-7.79" x2="14.07" y2="-7.29" layer="51"/>
<rectangle x1="14.09" y1="-7.79" x2="14.51" y2="-7.29" layer="51"/>
<rectangle x1="14.53" y1="-7.79" x2="14.95" y2="-7.29" layer="51"/>
<rectangle x1="14.97" y1="-7.79" x2="15.39" y2="-7.29" layer="51"/>
<rectangle x1="15.41" y1="-7.79" x2="15.83" y2="-7.29" layer="51"/>
<rectangle x1="15.85" y1="-7.79" x2="16.27" y2="-7.29" layer="51"/>
<rectangle x1="16.29" y1="-7.79" x2="16.71" y2="-7.29" layer="51"/>
<rectangle x1="16.73" y1="-7.79" x2="17.15" y2="-7.29" layer="51"/>
<rectangle x1="17.17" y1="-7.79" x2="17.59" y2="-7.29" layer="51"/>
<rectangle x1="17.61" y1="-7.79" x2="18.03" y2="-7.29" layer="51"/>
<rectangle x1="18.05" y1="-7.79" x2="18.47" y2="-7.29" layer="51"/>
<rectangle x1="18.49" y1="-7.79" x2="18.91" y2="-7.29" layer="51"/>
<rectangle x1="18.93" y1="-7.79" x2="19.35" y2="-7.29" layer="51"/>
<rectangle x1="19.37" y1="-7.79" x2="19.79" y2="-7.29" layer="51"/>
<rectangle x1="19.81" y1="-7.79" x2="20.23" y2="-7.29" layer="51"/>
<rectangle x1="20.25" y1="-7.79" x2="20.67" y2="-7.29" layer="51"/>
<rectangle x1="20.69" y1="-7.79" x2="21.11" y2="-7.29" layer="51"/>
<rectangle x1="21.13" y1="-7.79" x2="21.55" y2="-7.29" layer="51"/>
<rectangle x1="21.57" y1="-7.79" x2="21.99" y2="-7.29" layer="51"/>
<rectangle x1="22.01" y1="-7.79" x2="22.43" y2="-7.29" layer="51"/>
<rectangle x1="22.45" y1="-7.79" x2="22.87" y2="-7.29" layer="51"/>
<rectangle x1="22.89" y1="-7.79" x2="23.31" y2="-7.29" layer="51"/>
<rectangle x1="23.33" y1="-7.79" x2="23.75" y2="-7.29" layer="51"/>
<rectangle x1="23.77" y1="-7.79" x2="24.19" y2="-7.29" layer="51"/>
<rectangle x1="24.21" y1="-7.79" x2="24.63" y2="-7.29" layer="51"/>
<rectangle x1="24.65" y1="-7.79" x2="25.07" y2="-7.29" layer="51"/>
<rectangle x1="25.09" y1="-7.79" x2="25.51" y2="-7.29" layer="51"/>
<rectangle x1="25.53" y1="-7.79" x2="25.95" y2="-7.29" layer="51"/>
<rectangle x1="25.97" y1="-7.79" x2="26.39" y2="-7.29" layer="51"/>
<rectangle x1="26.41" y1="-7.79" x2="26.83" y2="-7.29" layer="51"/>
<rectangle x1="26.85" y1="-7.79" x2="27.27" y2="-7.29" layer="51"/>
<rectangle x1="27.29" y1="-7.79" x2="27.71" y2="-7.29" layer="51"/>
<rectangle x1="27.73" y1="-7.79" x2="28.15" y2="-7.29" layer="51"/>
<rectangle x1="-28.15" y1="-8.31" x2="-27.73" y2="-7.81" layer="51"/>
<rectangle x1="-27.71" y1="-8.31" x2="-27.29" y2="-7.81" layer="51"/>
<rectangle x1="-27.27" y1="-8.31" x2="-26.85" y2="-7.81" layer="51"/>
<rectangle x1="-26.83" y1="-8.31" x2="-26.41" y2="-7.81" layer="51"/>
<rectangle x1="-26.39" y1="-8.31" x2="-25.97" y2="-7.81" layer="51"/>
<rectangle x1="-25.95" y1="-8.31" x2="-25.53" y2="-7.81" layer="51"/>
<rectangle x1="-25.51" y1="-8.31" x2="-25.09" y2="-7.81" layer="51"/>
<rectangle x1="-25.07" y1="-8.31" x2="-24.65" y2="-7.81" layer="51"/>
<rectangle x1="-24.63" y1="-8.31" x2="-24.21" y2="-7.81" layer="51"/>
<rectangle x1="-24.19" y1="-8.31" x2="-23.77" y2="-7.81" layer="51"/>
<rectangle x1="-23.75" y1="-8.31" x2="-23.33" y2="-7.81" layer="51"/>
<rectangle x1="-23.31" y1="-8.31" x2="-22.89" y2="-7.81" layer="51"/>
<rectangle x1="-22.87" y1="-8.31" x2="-22.45" y2="-7.81" layer="51"/>
<rectangle x1="-22.43" y1="-8.31" x2="-22.01" y2="-7.81" layer="51"/>
<rectangle x1="-21.99" y1="-8.31" x2="-21.57" y2="-7.81" layer="51"/>
<rectangle x1="-21.55" y1="-8.31" x2="-21.13" y2="-7.81" layer="51"/>
<rectangle x1="-21.11" y1="-8.31" x2="-20.69" y2="-7.81" layer="51"/>
<rectangle x1="-20.67" y1="-8.31" x2="-20.25" y2="-7.81" layer="51"/>
<rectangle x1="-20.23" y1="-8.31" x2="-19.81" y2="-7.81" layer="51"/>
<rectangle x1="-19.79" y1="-8.31" x2="-19.37" y2="-7.81" layer="51"/>
<rectangle x1="-19.35" y1="-8.31" x2="-18.93" y2="-7.81" layer="51"/>
<rectangle x1="-18.91" y1="-8.31" x2="-18.49" y2="-7.81" layer="51"/>
<rectangle x1="-18.47" y1="-8.31" x2="-18.05" y2="-7.81" layer="51"/>
<rectangle x1="-18.03" y1="-8.31" x2="-17.61" y2="-7.81" layer="51"/>
<rectangle x1="-17.59" y1="-8.31" x2="-17.17" y2="-7.81" layer="51"/>
<rectangle x1="-17.15" y1="-8.31" x2="-16.73" y2="-7.81" layer="51"/>
<rectangle x1="-16.71" y1="-8.31" x2="-16.29" y2="-7.81" layer="51"/>
<rectangle x1="-16.27" y1="-8.31" x2="-15.85" y2="-7.81" layer="51"/>
<rectangle x1="-15.83" y1="-8.31" x2="-15.41" y2="-7.81" layer="51"/>
<rectangle x1="-15.39" y1="-8.31" x2="-14.97" y2="-7.81" layer="51"/>
<rectangle x1="-14.95" y1="-8.31" x2="-14.53" y2="-7.81" layer="51"/>
<rectangle x1="-14.51" y1="-8.31" x2="-14.09" y2="-7.81" layer="51"/>
<rectangle x1="-14.07" y1="-8.31" x2="-13.65" y2="-7.81" layer="51"/>
<rectangle x1="-13.63" y1="-8.31" x2="-13.21" y2="-7.81" layer="51"/>
<rectangle x1="-13.19" y1="-8.31" x2="-12.77" y2="-7.81" layer="51"/>
<rectangle x1="-12.75" y1="-8.31" x2="-12.33" y2="-7.81" layer="51"/>
<rectangle x1="-12.31" y1="-8.31" x2="-11.89" y2="-7.81" layer="51"/>
<rectangle x1="-11.87" y1="-8.31" x2="-11.45" y2="-7.81" layer="51"/>
<rectangle x1="-11.43" y1="-8.31" x2="-11.01" y2="-7.81" layer="51"/>
<rectangle x1="-10.99" y1="-8.31" x2="-10.57" y2="-7.81" layer="51"/>
<rectangle x1="-10.55" y1="-8.31" x2="-10.13" y2="-7.81" layer="51"/>
<rectangle x1="-10.11" y1="-8.31" x2="-9.69" y2="-7.81" layer="51"/>
<rectangle x1="-9.67" y1="-8.31" x2="-9.25" y2="-7.81" layer="51"/>
<rectangle x1="-9.23" y1="-8.31" x2="-8.81" y2="-7.81" layer="51"/>
<rectangle x1="-8.79" y1="-8.31" x2="-8.37" y2="-7.81" layer="51"/>
<rectangle x1="-8.35" y1="-8.31" x2="-7.93" y2="-7.81" layer="51"/>
<rectangle x1="-7.91" y1="-8.31" x2="-7.49" y2="-7.81" layer="51"/>
<rectangle x1="-7.47" y1="-8.31" x2="-7.05" y2="-7.81" layer="51"/>
<rectangle x1="-7.03" y1="-8.31" x2="-6.61" y2="-7.81" layer="51"/>
<rectangle x1="-6.59" y1="-8.31" x2="-6.17" y2="-7.81" layer="51"/>
<rectangle x1="-6.15" y1="-8.31" x2="-5.73" y2="-7.81" layer="51"/>
<rectangle x1="-5.71" y1="-8.31" x2="-5.29" y2="-7.81" layer="51"/>
<rectangle x1="-5.27" y1="-8.31" x2="-4.85" y2="-7.81" layer="51"/>
<rectangle x1="-4.83" y1="-8.31" x2="-4.41" y2="-7.81" layer="51"/>
<rectangle x1="-4.39" y1="-8.31" x2="-3.97" y2="-7.81" layer="51"/>
<rectangle x1="-3.95" y1="-8.31" x2="-3.53" y2="-7.81" layer="51"/>
<rectangle x1="-3.51" y1="-8.31" x2="-3.09" y2="-7.81" layer="51"/>
<rectangle x1="-3.07" y1="-8.31" x2="-2.65" y2="-7.81" layer="51"/>
<rectangle x1="-2.63" y1="-8.31" x2="-2.21" y2="-7.81" layer="51"/>
<rectangle x1="-2.19" y1="-8.31" x2="-1.77" y2="-7.81" layer="51"/>
<rectangle x1="-1.75" y1="-8.31" x2="-1.33" y2="-7.81" layer="51"/>
<rectangle x1="-1.31" y1="-8.31" x2="-0.89" y2="-7.81" layer="51"/>
<rectangle x1="-0.87" y1="-8.31" x2="-0.45" y2="-7.81" layer="51"/>
<rectangle x1="-0.43" y1="-8.31" x2="-0.01" y2="-7.81" layer="51"/>
<rectangle x1="0.01" y1="-8.31" x2="0.43" y2="-7.81" layer="51"/>
<rectangle x1="0.45" y1="-8.31" x2="0.87" y2="-7.81" layer="51"/>
<rectangle x1="0.89" y1="-8.31" x2="1.31" y2="-7.81" layer="51"/>
<rectangle x1="1.33" y1="-8.31" x2="1.75" y2="-7.81" layer="51"/>
<rectangle x1="1.77" y1="-8.31" x2="2.19" y2="-7.81" layer="51"/>
<rectangle x1="2.21" y1="-8.31" x2="2.63" y2="-7.81" layer="51"/>
<rectangle x1="2.65" y1="-8.31" x2="3.07" y2="-7.81" layer="51"/>
<rectangle x1="3.09" y1="-8.31" x2="3.51" y2="-7.81" layer="51"/>
<rectangle x1="3.53" y1="-8.31" x2="3.95" y2="-7.81" layer="51"/>
<rectangle x1="3.97" y1="-8.31" x2="4.39" y2="-7.81" layer="51"/>
<rectangle x1="4.41" y1="-8.31" x2="4.83" y2="-7.81" layer="51"/>
<rectangle x1="4.85" y1="-8.31" x2="5.27" y2="-7.81" layer="51"/>
<rectangle x1="5.29" y1="-8.31" x2="5.71" y2="-7.81" layer="51"/>
<rectangle x1="5.73" y1="-8.31" x2="6.15" y2="-7.81" layer="51"/>
<rectangle x1="6.17" y1="-8.31" x2="6.59" y2="-7.81" layer="51"/>
<rectangle x1="6.61" y1="-8.31" x2="7.03" y2="-7.81" layer="51"/>
<rectangle x1="7.05" y1="-8.31" x2="7.47" y2="-7.81" layer="51"/>
<rectangle x1="7.49" y1="-8.31" x2="7.91" y2="-7.81" layer="51"/>
<rectangle x1="7.93" y1="-8.31" x2="8.35" y2="-7.81" layer="51"/>
<rectangle x1="8.37" y1="-8.31" x2="8.79" y2="-7.81" layer="51"/>
<rectangle x1="8.81" y1="-8.31" x2="9.23" y2="-7.81" layer="51"/>
<rectangle x1="9.25" y1="-8.31" x2="9.67" y2="-7.81" layer="51"/>
<rectangle x1="9.69" y1="-8.31" x2="10.11" y2="-7.81" layer="51"/>
<rectangle x1="10.13" y1="-8.31" x2="10.55" y2="-7.81" layer="51"/>
<rectangle x1="10.57" y1="-8.31" x2="10.99" y2="-7.81" layer="51"/>
<rectangle x1="11.01" y1="-8.31" x2="11.43" y2="-7.81" layer="51"/>
<rectangle x1="11.45" y1="-8.31" x2="11.87" y2="-7.81" layer="51"/>
<rectangle x1="11.89" y1="-8.31" x2="12.31" y2="-7.81" layer="51"/>
<rectangle x1="12.33" y1="-8.31" x2="12.75" y2="-7.81" layer="51"/>
<rectangle x1="12.77" y1="-8.31" x2="13.19" y2="-7.81" layer="51"/>
<rectangle x1="13.21" y1="-8.31" x2="13.63" y2="-7.81" layer="51"/>
<rectangle x1="13.65" y1="-8.31" x2="14.07" y2="-7.81" layer="51"/>
<rectangle x1="14.09" y1="-8.31" x2="14.51" y2="-7.81" layer="51"/>
<rectangle x1="14.53" y1="-8.31" x2="14.95" y2="-7.81" layer="51"/>
<rectangle x1="14.97" y1="-8.31" x2="15.39" y2="-7.81" layer="51"/>
<rectangle x1="15.41" y1="-8.31" x2="15.83" y2="-7.81" layer="51"/>
<rectangle x1="15.85" y1="-8.31" x2="16.27" y2="-7.81" layer="51"/>
<rectangle x1="16.29" y1="-8.31" x2="16.71" y2="-7.81" layer="51"/>
<rectangle x1="16.73" y1="-8.31" x2="17.15" y2="-7.81" layer="51"/>
<rectangle x1="17.17" y1="-8.31" x2="17.59" y2="-7.81" layer="51"/>
<rectangle x1="17.61" y1="-8.31" x2="18.03" y2="-7.81" layer="51"/>
<rectangle x1="18.05" y1="-8.31" x2="18.47" y2="-7.81" layer="51"/>
<rectangle x1="18.49" y1="-8.31" x2="18.91" y2="-7.81" layer="51"/>
<rectangle x1="18.93" y1="-8.31" x2="19.35" y2="-7.81" layer="51"/>
<rectangle x1="19.37" y1="-8.31" x2="19.79" y2="-7.81" layer="51"/>
<rectangle x1="19.81" y1="-8.31" x2="20.23" y2="-7.81" layer="51"/>
<rectangle x1="20.25" y1="-8.31" x2="20.67" y2="-7.81" layer="51"/>
<rectangle x1="20.69" y1="-8.31" x2="21.11" y2="-7.81" layer="51"/>
<rectangle x1="21.13" y1="-8.31" x2="21.55" y2="-7.81" layer="51"/>
<rectangle x1="21.57" y1="-8.31" x2="21.99" y2="-7.81" layer="51"/>
<rectangle x1="22.01" y1="-8.31" x2="22.43" y2="-7.81" layer="51"/>
<rectangle x1="22.45" y1="-8.31" x2="22.87" y2="-7.81" layer="51"/>
<rectangle x1="22.89" y1="-8.31" x2="23.31" y2="-7.81" layer="51"/>
<rectangle x1="23.33" y1="-8.31" x2="23.75" y2="-7.81" layer="51"/>
<rectangle x1="23.77" y1="-8.31" x2="24.19" y2="-7.81" layer="51"/>
<rectangle x1="24.21" y1="-8.31" x2="24.63" y2="-7.81" layer="51"/>
<rectangle x1="24.65" y1="-8.31" x2="25.07" y2="-7.81" layer="51"/>
<rectangle x1="25.09" y1="-8.31" x2="25.51" y2="-7.81" layer="51"/>
<rectangle x1="25.53" y1="-8.31" x2="25.95" y2="-7.81" layer="51"/>
<rectangle x1="25.97" y1="-8.31" x2="26.39" y2="-7.81" layer="51"/>
<rectangle x1="26.41" y1="-8.31" x2="26.83" y2="-7.81" layer="51"/>
<rectangle x1="26.85" y1="-8.31" x2="27.27" y2="-7.81" layer="51"/>
<rectangle x1="27.29" y1="-8.31" x2="27.71" y2="-7.81" layer="51"/>
<rectangle x1="27.73" y1="-8.31" x2="28.15" y2="-7.81" layer="51"/>
<rectangle x1="-28.15" y1="-8.83" x2="-27.73" y2="-8.33" layer="51"/>
<rectangle x1="-27.71" y1="-8.83" x2="-27.29" y2="-8.33" layer="51"/>
<rectangle x1="-27.27" y1="-8.83" x2="-26.85" y2="-8.33" layer="51"/>
<rectangle x1="-26.83" y1="-8.83" x2="-26.41" y2="-8.33" layer="51"/>
<rectangle x1="-26.39" y1="-8.83" x2="-25.97" y2="-8.33" layer="51"/>
<rectangle x1="-25.95" y1="-8.83" x2="-25.53" y2="-8.33" layer="51"/>
<rectangle x1="-25.51" y1="-8.83" x2="-25.09" y2="-8.33" layer="51"/>
<rectangle x1="-25.07" y1="-8.83" x2="-24.65" y2="-8.33" layer="51"/>
<rectangle x1="-24.63" y1="-8.83" x2="-24.21" y2="-8.33" layer="51"/>
<rectangle x1="-24.19" y1="-8.83" x2="-23.77" y2="-8.33" layer="51"/>
<rectangle x1="-23.75" y1="-8.83" x2="-23.33" y2="-8.33" layer="51"/>
<rectangle x1="-23.31" y1="-8.83" x2="-22.89" y2="-8.33" layer="51"/>
<rectangle x1="-22.87" y1="-8.83" x2="-22.45" y2="-8.33" layer="51"/>
<rectangle x1="-22.43" y1="-8.83" x2="-22.01" y2="-8.33" layer="51"/>
<rectangle x1="-21.99" y1="-8.83" x2="-21.57" y2="-8.33" layer="51"/>
<rectangle x1="-21.55" y1="-8.83" x2="-21.13" y2="-8.33" layer="51"/>
<rectangle x1="-21.11" y1="-8.83" x2="-20.69" y2="-8.33" layer="51"/>
<rectangle x1="-20.67" y1="-8.83" x2="-20.25" y2="-8.33" layer="51"/>
<rectangle x1="-20.23" y1="-8.83" x2="-19.81" y2="-8.33" layer="51"/>
<rectangle x1="-19.79" y1="-8.83" x2="-19.37" y2="-8.33" layer="51"/>
<rectangle x1="-19.35" y1="-8.83" x2="-18.93" y2="-8.33" layer="51"/>
<rectangle x1="-18.91" y1="-8.83" x2="-18.49" y2="-8.33" layer="51"/>
<rectangle x1="-18.47" y1="-8.83" x2="-18.05" y2="-8.33" layer="51"/>
<rectangle x1="-18.03" y1="-8.83" x2="-17.61" y2="-8.33" layer="51"/>
<rectangle x1="-17.59" y1="-8.83" x2="-17.17" y2="-8.33" layer="51"/>
<rectangle x1="-17.15" y1="-8.83" x2="-16.73" y2="-8.33" layer="51"/>
<rectangle x1="-16.71" y1="-8.83" x2="-16.29" y2="-8.33" layer="51"/>
<rectangle x1="-16.27" y1="-8.83" x2="-15.85" y2="-8.33" layer="51"/>
<rectangle x1="-15.83" y1="-8.83" x2="-15.41" y2="-8.33" layer="51"/>
<rectangle x1="-15.39" y1="-8.83" x2="-14.97" y2="-8.33" layer="51"/>
<rectangle x1="-14.95" y1="-8.83" x2="-14.53" y2="-8.33" layer="51"/>
<rectangle x1="-14.51" y1="-8.83" x2="-14.09" y2="-8.33" layer="51"/>
<rectangle x1="-14.07" y1="-8.83" x2="-13.65" y2="-8.33" layer="51"/>
<rectangle x1="-13.63" y1="-8.83" x2="-13.21" y2="-8.33" layer="51"/>
<rectangle x1="-13.19" y1="-8.83" x2="-12.77" y2="-8.33" layer="51"/>
<rectangle x1="-12.75" y1="-8.83" x2="-12.33" y2="-8.33" layer="51"/>
<rectangle x1="-12.31" y1="-8.83" x2="-11.89" y2="-8.33" layer="51"/>
<rectangle x1="-11.87" y1="-8.83" x2="-11.45" y2="-8.33" layer="51"/>
<rectangle x1="-11.43" y1="-8.83" x2="-11.01" y2="-8.33" layer="51"/>
<rectangle x1="-10.99" y1="-8.83" x2="-10.57" y2="-8.33" layer="51"/>
<rectangle x1="-10.55" y1="-8.83" x2="-10.13" y2="-8.33" layer="51"/>
<rectangle x1="-10.11" y1="-8.83" x2="-9.69" y2="-8.33" layer="51"/>
<rectangle x1="-9.67" y1="-8.83" x2="-9.25" y2="-8.33" layer="51"/>
<rectangle x1="-9.23" y1="-8.83" x2="-8.81" y2="-8.33" layer="51"/>
<rectangle x1="-8.79" y1="-8.83" x2="-8.37" y2="-8.33" layer="51"/>
<rectangle x1="-8.35" y1="-8.83" x2="-7.93" y2="-8.33" layer="51"/>
<rectangle x1="-7.91" y1="-8.83" x2="-7.49" y2="-8.33" layer="51"/>
<rectangle x1="-7.47" y1="-8.83" x2="-7.05" y2="-8.33" layer="51"/>
<rectangle x1="-7.03" y1="-8.83" x2="-6.61" y2="-8.33" layer="51"/>
<rectangle x1="-6.59" y1="-8.83" x2="-6.17" y2="-8.33" layer="51"/>
<rectangle x1="-6.15" y1="-8.83" x2="-5.73" y2="-8.33" layer="51"/>
<rectangle x1="-5.71" y1="-8.83" x2="-5.29" y2="-8.33" layer="51"/>
<rectangle x1="-5.27" y1="-8.83" x2="-4.85" y2="-8.33" layer="51"/>
<rectangle x1="-4.83" y1="-8.83" x2="-4.41" y2="-8.33" layer="51"/>
<rectangle x1="-4.39" y1="-8.83" x2="-3.97" y2="-8.33" layer="51"/>
<rectangle x1="-3.95" y1="-8.83" x2="-3.53" y2="-8.33" layer="51"/>
<rectangle x1="-3.51" y1="-8.83" x2="-3.09" y2="-8.33" layer="51"/>
<rectangle x1="-3.07" y1="-8.83" x2="-2.65" y2="-8.33" layer="51"/>
<rectangle x1="-2.63" y1="-8.83" x2="-2.21" y2="-8.33" layer="51"/>
<rectangle x1="-2.19" y1="-8.83" x2="-1.77" y2="-8.33" layer="51"/>
<rectangle x1="-1.75" y1="-8.83" x2="-1.33" y2="-8.33" layer="51"/>
<rectangle x1="-1.31" y1="-8.83" x2="-0.89" y2="-8.33" layer="51"/>
<rectangle x1="-0.87" y1="-8.83" x2="-0.45" y2="-8.33" layer="51"/>
<rectangle x1="-0.43" y1="-8.83" x2="-0.01" y2="-8.33" layer="51"/>
<rectangle x1="0.01" y1="-8.83" x2="0.43" y2="-8.33" layer="51"/>
<rectangle x1="0.45" y1="-8.83" x2="0.87" y2="-8.33" layer="51"/>
<rectangle x1="0.89" y1="-8.83" x2="1.31" y2="-8.33" layer="51"/>
<rectangle x1="1.33" y1="-8.83" x2="1.75" y2="-8.33" layer="51"/>
<rectangle x1="1.77" y1="-8.83" x2="2.19" y2="-8.33" layer="51"/>
<rectangle x1="2.21" y1="-8.83" x2="2.63" y2="-8.33" layer="51"/>
<rectangle x1="2.65" y1="-8.83" x2="3.07" y2="-8.33" layer="51"/>
<rectangle x1="3.09" y1="-8.83" x2="3.51" y2="-8.33" layer="51"/>
<rectangle x1="3.53" y1="-8.83" x2="3.95" y2="-8.33" layer="51"/>
<rectangle x1="3.97" y1="-8.83" x2="4.39" y2="-8.33" layer="51"/>
<rectangle x1="4.41" y1="-8.83" x2="4.83" y2="-8.33" layer="51"/>
<rectangle x1="4.85" y1="-8.83" x2="5.27" y2="-8.33" layer="51"/>
<rectangle x1="5.29" y1="-8.83" x2="5.71" y2="-8.33" layer="51"/>
<rectangle x1="5.73" y1="-8.83" x2="6.15" y2="-8.33" layer="51"/>
<rectangle x1="6.17" y1="-8.83" x2="6.59" y2="-8.33" layer="51"/>
<rectangle x1="6.61" y1="-8.83" x2="7.03" y2="-8.33" layer="51"/>
<rectangle x1="7.05" y1="-8.83" x2="7.47" y2="-8.33" layer="51"/>
<rectangle x1="7.49" y1="-8.83" x2="7.91" y2="-8.33" layer="51"/>
<rectangle x1="7.93" y1="-8.83" x2="8.35" y2="-8.33" layer="51"/>
<rectangle x1="8.37" y1="-8.83" x2="8.79" y2="-8.33" layer="51"/>
<rectangle x1="8.81" y1="-8.83" x2="9.23" y2="-8.33" layer="51"/>
<rectangle x1="9.25" y1="-8.83" x2="9.67" y2="-8.33" layer="51"/>
<rectangle x1="9.69" y1="-8.83" x2="10.11" y2="-8.33" layer="51"/>
<rectangle x1="10.13" y1="-8.83" x2="10.55" y2="-8.33" layer="51"/>
<rectangle x1="10.57" y1="-8.83" x2="10.99" y2="-8.33" layer="51"/>
<rectangle x1="11.01" y1="-8.83" x2="11.43" y2="-8.33" layer="51"/>
<rectangle x1="11.45" y1="-8.83" x2="11.87" y2="-8.33" layer="51"/>
<rectangle x1="11.89" y1="-8.83" x2="12.31" y2="-8.33" layer="51"/>
<rectangle x1="12.33" y1="-8.83" x2="12.75" y2="-8.33" layer="51"/>
<rectangle x1="12.77" y1="-8.83" x2="13.19" y2="-8.33" layer="51"/>
<rectangle x1="13.21" y1="-8.83" x2="13.63" y2="-8.33" layer="51"/>
<rectangle x1="13.65" y1="-8.83" x2="14.07" y2="-8.33" layer="51"/>
<rectangle x1="14.09" y1="-8.83" x2="14.51" y2="-8.33" layer="51"/>
<rectangle x1="14.53" y1="-8.83" x2="14.95" y2="-8.33" layer="51"/>
<rectangle x1="14.97" y1="-8.83" x2="15.39" y2="-8.33" layer="51"/>
<rectangle x1="15.41" y1="-8.83" x2="15.83" y2="-8.33" layer="51"/>
<rectangle x1="15.85" y1="-8.83" x2="16.27" y2="-8.33" layer="51"/>
<rectangle x1="16.29" y1="-8.83" x2="16.71" y2="-8.33" layer="51"/>
<rectangle x1="16.73" y1="-8.83" x2="17.15" y2="-8.33" layer="51"/>
<rectangle x1="17.17" y1="-8.83" x2="17.59" y2="-8.33" layer="51"/>
<rectangle x1="17.61" y1="-8.83" x2="18.03" y2="-8.33" layer="51"/>
<rectangle x1="18.05" y1="-8.83" x2="18.47" y2="-8.33" layer="51"/>
<rectangle x1="18.49" y1="-8.83" x2="18.91" y2="-8.33" layer="51"/>
<rectangle x1="18.93" y1="-8.83" x2="19.35" y2="-8.33" layer="51"/>
<rectangle x1="19.37" y1="-8.83" x2="19.79" y2="-8.33" layer="51"/>
<rectangle x1="19.81" y1="-8.83" x2="20.23" y2="-8.33" layer="51"/>
<rectangle x1="20.25" y1="-8.83" x2="20.67" y2="-8.33" layer="51"/>
<rectangle x1="20.69" y1="-8.83" x2="21.11" y2="-8.33" layer="51"/>
<rectangle x1="21.13" y1="-8.83" x2="21.55" y2="-8.33" layer="51"/>
<rectangle x1="21.57" y1="-8.83" x2="21.99" y2="-8.33" layer="51"/>
<rectangle x1="22.01" y1="-8.83" x2="22.43" y2="-8.33" layer="51"/>
<rectangle x1="22.45" y1="-8.83" x2="22.87" y2="-8.33" layer="51"/>
<rectangle x1="22.89" y1="-8.83" x2="23.31" y2="-8.33" layer="51"/>
<rectangle x1="23.33" y1="-8.83" x2="23.75" y2="-8.33" layer="51"/>
<rectangle x1="23.77" y1="-8.83" x2="24.19" y2="-8.33" layer="51"/>
<rectangle x1="24.21" y1="-8.83" x2="24.63" y2="-8.33" layer="51"/>
<rectangle x1="24.65" y1="-8.83" x2="25.07" y2="-8.33" layer="51"/>
<rectangle x1="25.09" y1="-8.83" x2="25.51" y2="-8.33" layer="51"/>
<rectangle x1="25.53" y1="-8.83" x2="25.95" y2="-8.33" layer="51"/>
<rectangle x1="25.97" y1="-8.83" x2="26.39" y2="-8.33" layer="51"/>
<rectangle x1="26.41" y1="-8.83" x2="26.83" y2="-8.33" layer="51"/>
<rectangle x1="26.85" y1="-8.83" x2="27.27" y2="-8.33" layer="51"/>
<rectangle x1="27.29" y1="-8.83" x2="27.71" y2="-8.33" layer="51"/>
<rectangle x1="27.73" y1="-8.83" x2="28.15" y2="-8.33" layer="51"/>
<rectangle x1="-28.15" y1="-9.35" x2="-27.73" y2="-8.85" layer="51"/>
<rectangle x1="-27.71" y1="-9.35" x2="-27.29" y2="-8.85" layer="51"/>
<rectangle x1="-27.27" y1="-9.35" x2="-26.85" y2="-8.85" layer="51"/>
<rectangle x1="-26.83" y1="-9.35" x2="-26.41" y2="-8.85" layer="51"/>
<rectangle x1="-26.39" y1="-9.35" x2="-25.97" y2="-8.85" layer="51"/>
<rectangle x1="-25.95" y1="-9.35" x2="-25.53" y2="-8.85" layer="51"/>
<rectangle x1="-25.51" y1="-9.35" x2="-25.09" y2="-8.85" layer="51"/>
<rectangle x1="-25.07" y1="-9.35" x2="-24.65" y2="-8.85" layer="51"/>
<rectangle x1="-24.63" y1="-9.35" x2="-24.21" y2="-8.85" layer="51"/>
<rectangle x1="-24.19" y1="-9.35" x2="-23.77" y2="-8.85" layer="51"/>
<rectangle x1="-23.75" y1="-9.35" x2="-23.33" y2="-8.85" layer="51"/>
<rectangle x1="-23.31" y1="-9.35" x2="-22.89" y2="-8.85" layer="51"/>
<rectangle x1="-22.87" y1="-9.35" x2="-22.45" y2="-8.85" layer="51"/>
<rectangle x1="-22.43" y1="-9.35" x2="-22.01" y2="-8.85" layer="51"/>
<rectangle x1="-21.99" y1="-9.35" x2="-21.57" y2="-8.85" layer="51"/>
<rectangle x1="-21.55" y1="-9.35" x2="-21.13" y2="-8.85" layer="51"/>
<rectangle x1="-21.11" y1="-9.35" x2="-20.69" y2="-8.85" layer="51"/>
<rectangle x1="-20.67" y1="-9.35" x2="-20.25" y2="-8.85" layer="51"/>
<rectangle x1="-20.23" y1="-9.35" x2="-19.81" y2="-8.85" layer="51"/>
<rectangle x1="-19.79" y1="-9.35" x2="-19.37" y2="-8.85" layer="51"/>
<rectangle x1="-19.35" y1="-9.35" x2="-18.93" y2="-8.85" layer="51"/>
<rectangle x1="-18.91" y1="-9.35" x2="-18.49" y2="-8.85" layer="51"/>
<rectangle x1="-18.47" y1="-9.35" x2="-18.05" y2="-8.85" layer="51"/>
<rectangle x1="-18.03" y1="-9.35" x2="-17.61" y2="-8.85" layer="51"/>
<rectangle x1="-17.59" y1="-9.35" x2="-17.17" y2="-8.85" layer="51"/>
<rectangle x1="-17.15" y1="-9.35" x2="-16.73" y2="-8.85" layer="51"/>
<rectangle x1="-16.71" y1="-9.35" x2="-16.29" y2="-8.85" layer="51"/>
<rectangle x1="-16.27" y1="-9.35" x2="-15.85" y2="-8.85" layer="51"/>
<rectangle x1="-15.83" y1="-9.35" x2="-15.41" y2="-8.85" layer="51"/>
<rectangle x1="-15.39" y1="-9.35" x2="-14.97" y2="-8.85" layer="51"/>
<rectangle x1="-14.95" y1="-9.35" x2="-14.53" y2="-8.85" layer="51"/>
<rectangle x1="-14.51" y1="-9.35" x2="-14.09" y2="-8.85" layer="51"/>
<rectangle x1="-14.07" y1="-9.35" x2="-13.65" y2="-8.85" layer="51"/>
<rectangle x1="-13.63" y1="-9.35" x2="-13.21" y2="-8.85" layer="51"/>
<rectangle x1="-13.19" y1="-9.35" x2="-12.77" y2="-8.85" layer="51"/>
<rectangle x1="-12.75" y1="-9.35" x2="-12.33" y2="-8.85" layer="51"/>
<rectangle x1="-12.31" y1="-9.35" x2="-11.89" y2="-8.85" layer="51"/>
<rectangle x1="-11.87" y1="-9.35" x2="-11.45" y2="-8.85" layer="51"/>
<rectangle x1="-11.43" y1="-9.35" x2="-11.01" y2="-8.85" layer="51"/>
<rectangle x1="-10.99" y1="-9.35" x2="-10.57" y2="-8.85" layer="51"/>
<rectangle x1="-10.55" y1="-9.35" x2="-10.13" y2="-8.85" layer="51"/>
<rectangle x1="-10.11" y1="-9.35" x2="-9.69" y2="-8.85" layer="51"/>
<rectangle x1="-9.67" y1="-9.35" x2="-9.25" y2="-8.85" layer="51"/>
<rectangle x1="-9.23" y1="-9.35" x2="-8.81" y2="-8.85" layer="51"/>
<rectangle x1="-8.79" y1="-9.35" x2="-8.37" y2="-8.85" layer="51"/>
<rectangle x1="-8.35" y1="-9.35" x2="-7.93" y2="-8.85" layer="51"/>
<rectangle x1="-7.91" y1="-9.35" x2="-7.49" y2="-8.85" layer="51"/>
<rectangle x1="-7.47" y1="-9.35" x2="-7.05" y2="-8.85" layer="51"/>
<rectangle x1="-7.03" y1="-9.35" x2="-6.61" y2="-8.85" layer="51"/>
<rectangle x1="-6.59" y1="-9.35" x2="-6.17" y2="-8.85" layer="51"/>
<rectangle x1="-6.15" y1="-9.35" x2="-5.73" y2="-8.85" layer="51"/>
<rectangle x1="-5.71" y1="-9.35" x2="-5.29" y2="-8.85" layer="51"/>
<rectangle x1="-5.27" y1="-9.35" x2="-4.85" y2="-8.85" layer="51"/>
<rectangle x1="-4.83" y1="-9.35" x2="-4.41" y2="-8.85" layer="51"/>
<rectangle x1="-4.39" y1="-9.35" x2="-3.97" y2="-8.85" layer="51"/>
<rectangle x1="-3.95" y1="-9.35" x2="-3.53" y2="-8.85" layer="51"/>
<rectangle x1="-3.51" y1="-9.35" x2="-3.09" y2="-8.85" layer="51"/>
<rectangle x1="-3.07" y1="-9.35" x2="-2.65" y2="-8.85" layer="51"/>
<rectangle x1="-2.63" y1="-9.35" x2="-2.21" y2="-8.85" layer="51"/>
<rectangle x1="-2.19" y1="-9.35" x2="-1.77" y2="-8.85" layer="51"/>
<rectangle x1="-1.75" y1="-9.35" x2="-1.33" y2="-8.85" layer="51"/>
<rectangle x1="-1.31" y1="-9.35" x2="-0.89" y2="-8.85" layer="51"/>
<rectangle x1="-0.87" y1="-9.35" x2="-0.45" y2="-8.85" layer="51"/>
<rectangle x1="-0.43" y1="-9.35" x2="-0.01" y2="-8.85" layer="51"/>
<rectangle x1="0.01" y1="-9.35" x2="0.43" y2="-8.85" layer="51"/>
<rectangle x1="0.45" y1="-9.35" x2="0.87" y2="-8.85" layer="51"/>
<rectangle x1="0.89" y1="-9.35" x2="1.31" y2="-8.85" layer="51"/>
<rectangle x1="1.33" y1="-9.35" x2="1.75" y2="-8.85" layer="51"/>
<rectangle x1="1.77" y1="-9.35" x2="2.19" y2="-8.85" layer="51"/>
<rectangle x1="2.21" y1="-9.35" x2="2.63" y2="-8.85" layer="51"/>
<rectangle x1="2.65" y1="-9.35" x2="3.07" y2="-8.85" layer="51"/>
<rectangle x1="3.09" y1="-9.35" x2="3.51" y2="-8.85" layer="51"/>
<rectangle x1="3.53" y1="-9.35" x2="3.95" y2="-8.85" layer="51"/>
<rectangle x1="3.97" y1="-9.35" x2="4.39" y2="-8.85" layer="51"/>
<rectangle x1="4.41" y1="-9.35" x2="4.83" y2="-8.85" layer="51"/>
<rectangle x1="4.85" y1="-9.35" x2="5.27" y2="-8.85" layer="51"/>
<rectangle x1="5.29" y1="-9.35" x2="5.71" y2="-8.85" layer="51"/>
<rectangle x1="5.73" y1="-9.35" x2="6.15" y2="-8.85" layer="51"/>
<rectangle x1="6.17" y1="-9.35" x2="6.59" y2="-8.85" layer="51"/>
<rectangle x1="6.61" y1="-9.35" x2="7.03" y2="-8.85" layer="51"/>
<rectangle x1="7.05" y1="-9.35" x2="7.47" y2="-8.85" layer="51"/>
<rectangle x1="7.49" y1="-9.35" x2="7.91" y2="-8.85" layer="51"/>
<rectangle x1="7.93" y1="-9.35" x2="8.35" y2="-8.85" layer="51"/>
<rectangle x1="8.37" y1="-9.35" x2="8.79" y2="-8.85" layer="51"/>
<rectangle x1="8.81" y1="-9.35" x2="9.23" y2="-8.85" layer="51"/>
<rectangle x1="9.25" y1="-9.35" x2="9.67" y2="-8.85" layer="51"/>
<rectangle x1="9.69" y1="-9.35" x2="10.11" y2="-8.85" layer="51"/>
<rectangle x1="10.13" y1="-9.35" x2="10.55" y2="-8.85" layer="51"/>
<rectangle x1="10.57" y1="-9.35" x2="10.99" y2="-8.85" layer="51"/>
<rectangle x1="11.01" y1="-9.35" x2="11.43" y2="-8.85" layer="51"/>
<rectangle x1="11.45" y1="-9.35" x2="11.87" y2="-8.85" layer="51"/>
<rectangle x1="11.89" y1="-9.35" x2="12.31" y2="-8.85" layer="51"/>
<rectangle x1="12.33" y1="-9.35" x2="12.75" y2="-8.85" layer="51"/>
<rectangle x1="12.77" y1="-9.35" x2="13.19" y2="-8.85" layer="51"/>
<rectangle x1="13.21" y1="-9.35" x2="13.63" y2="-8.85" layer="51"/>
<rectangle x1="13.65" y1="-9.35" x2="14.07" y2="-8.85" layer="51"/>
<rectangle x1="14.09" y1="-9.35" x2="14.51" y2="-8.85" layer="51"/>
<rectangle x1="14.53" y1="-9.35" x2="14.95" y2="-8.85" layer="51"/>
<rectangle x1="14.97" y1="-9.35" x2="15.39" y2="-8.85" layer="51"/>
<rectangle x1="15.41" y1="-9.35" x2="15.83" y2="-8.85" layer="51"/>
<rectangle x1="15.85" y1="-9.35" x2="16.27" y2="-8.85" layer="51"/>
<rectangle x1="16.29" y1="-9.35" x2="16.71" y2="-8.85" layer="51"/>
<rectangle x1="16.73" y1="-9.35" x2="17.15" y2="-8.85" layer="51"/>
<rectangle x1="17.17" y1="-9.35" x2="17.59" y2="-8.85" layer="51"/>
<rectangle x1="17.61" y1="-9.35" x2="18.03" y2="-8.85" layer="51"/>
<rectangle x1="18.05" y1="-9.35" x2="18.47" y2="-8.85" layer="51"/>
<rectangle x1="18.49" y1="-9.35" x2="18.91" y2="-8.85" layer="51"/>
<rectangle x1="18.93" y1="-9.35" x2="19.35" y2="-8.85" layer="51"/>
<rectangle x1="19.37" y1="-9.35" x2="19.79" y2="-8.85" layer="51"/>
<rectangle x1="19.81" y1="-9.35" x2="20.23" y2="-8.85" layer="51"/>
<rectangle x1="20.25" y1="-9.35" x2="20.67" y2="-8.85" layer="51"/>
<rectangle x1="20.69" y1="-9.35" x2="21.11" y2="-8.85" layer="51"/>
<rectangle x1="21.13" y1="-9.35" x2="21.55" y2="-8.85" layer="51"/>
<rectangle x1="21.57" y1="-9.35" x2="21.99" y2="-8.85" layer="51"/>
<rectangle x1="22.01" y1="-9.35" x2="22.43" y2="-8.85" layer="51"/>
<rectangle x1="22.45" y1="-9.35" x2="22.87" y2="-8.85" layer="51"/>
<rectangle x1="22.89" y1="-9.35" x2="23.31" y2="-8.85" layer="51"/>
<rectangle x1="23.33" y1="-9.35" x2="23.75" y2="-8.85" layer="51"/>
<rectangle x1="23.77" y1="-9.35" x2="24.19" y2="-8.85" layer="51"/>
<rectangle x1="24.21" y1="-9.35" x2="24.63" y2="-8.85" layer="51"/>
<rectangle x1="24.65" y1="-9.35" x2="25.07" y2="-8.85" layer="51"/>
<rectangle x1="25.09" y1="-9.35" x2="25.51" y2="-8.85" layer="51"/>
<rectangle x1="25.53" y1="-9.35" x2="25.95" y2="-8.85" layer="51"/>
<rectangle x1="25.97" y1="-9.35" x2="26.39" y2="-8.85" layer="51"/>
<rectangle x1="26.41" y1="-9.35" x2="26.83" y2="-8.85" layer="51"/>
<rectangle x1="26.85" y1="-9.35" x2="27.27" y2="-8.85" layer="51"/>
<rectangle x1="27.29" y1="-9.35" x2="27.71" y2="-8.85" layer="51"/>
<rectangle x1="27.73" y1="-9.35" x2="28.15" y2="-8.85" layer="51"/>
<rectangle x1="-28.15" y1="-9.87" x2="-27.73" y2="-9.37" layer="51"/>
<rectangle x1="-27.71" y1="-9.87" x2="-27.29" y2="-9.37" layer="51"/>
<rectangle x1="-27.27" y1="-9.87" x2="-26.85" y2="-9.37" layer="51"/>
<rectangle x1="-26.83" y1="-9.87" x2="-26.41" y2="-9.37" layer="51"/>
<rectangle x1="-26.39" y1="-9.87" x2="-25.97" y2="-9.37" layer="51"/>
<rectangle x1="-25.95" y1="-9.87" x2="-25.53" y2="-9.37" layer="51"/>
<rectangle x1="-25.51" y1="-9.87" x2="-25.09" y2="-9.37" layer="51"/>
<rectangle x1="-25.07" y1="-9.87" x2="-24.65" y2="-9.37" layer="51"/>
<rectangle x1="-24.63" y1="-9.87" x2="-24.21" y2="-9.37" layer="51"/>
<rectangle x1="-24.19" y1="-9.87" x2="-23.77" y2="-9.37" layer="51"/>
<rectangle x1="-23.75" y1="-9.87" x2="-23.33" y2="-9.37" layer="51"/>
<rectangle x1="-23.31" y1="-9.87" x2="-22.89" y2="-9.37" layer="51"/>
<rectangle x1="-22.87" y1="-9.87" x2="-22.45" y2="-9.37" layer="51"/>
<rectangle x1="-22.43" y1="-9.87" x2="-22.01" y2="-9.37" layer="51"/>
<rectangle x1="-21.99" y1="-9.87" x2="-21.57" y2="-9.37" layer="51"/>
<rectangle x1="-21.55" y1="-9.87" x2="-21.13" y2="-9.37" layer="51"/>
<rectangle x1="-21.11" y1="-9.87" x2="-20.69" y2="-9.37" layer="51"/>
<rectangle x1="-20.67" y1="-9.87" x2="-20.25" y2="-9.37" layer="51"/>
<rectangle x1="-20.23" y1="-9.87" x2="-19.81" y2="-9.37" layer="51"/>
<rectangle x1="-19.79" y1="-9.87" x2="-19.37" y2="-9.37" layer="51"/>
<rectangle x1="-19.35" y1="-9.87" x2="-18.93" y2="-9.37" layer="51"/>
<rectangle x1="-18.91" y1="-9.87" x2="-18.49" y2="-9.37" layer="51"/>
<rectangle x1="-18.47" y1="-9.87" x2="-18.05" y2="-9.37" layer="51"/>
<rectangle x1="-18.03" y1="-9.87" x2="-17.61" y2="-9.37" layer="51"/>
<rectangle x1="-17.59" y1="-9.87" x2="-17.17" y2="-9.37" layer="51"/>
<rectangle x1="-17.15" y1="-9.87" x2="-16.73" y2="-9.37" layer="51"/>
<rectangle x1="-16.71" y1="-9.87" x2="-16.29" y2="-9.37" layer="51"/>
<rectangle x1="-16.27" y1="-9.87" x2="-15.85" y2="-9.37" layer="51"/>
<rectangle x1="-15.83" y1="-9.87" x2="-15.41" y2="-9.37" layer="51"/>
<rectangle x1="-15.39" y1="-9.87" x2="-14.97" y2="-9.37" layer="51"/>
<rectangle x1="-14.95" y1="-9.87" x2="-14.53" y2="-9.37" layer="51"/>
<rectangle x1="-14.51" y1="-9.87" x2="-14.09" y2="-9.37" layer="51"/>
<rectangle x1="-14.07" y1="-9.87" x2="-13.65" y2="-9.37" layer="51"/>
<rectangle x1="-13.63" y1="-9.87" x2="-13.21" y2="-9.37" layer="51"/>
<rectangle x1="-13.19" y1="-9.87" x2="-12.77" y2="-9.37" layer="51"/>
<rectangle x1="-12.75" y1="-9.87" x2="-12.33" y2="-9.37" layer="51"/>
<rectangle x1="-12.31" y1="-9.87" x2="-11.89" y2="-9.37" layer="51"/>
<rectangle x1="-11.87" y1="-9.87" x2="-11.45" y2="-9.37" layer="51"/>
<rectangle x1="-11.43" y1="-9.87" x2="-11.01" y2="-9.37" layer="51"/>
<rectangle x1="-10.99" y1="-9.87" x2="-10.57" y2="-9.37" layer="51"/>
<rectangle x1="-10.55" y1="-9.87" x2="-10.13" y2="-9.37" layer="51"/>
<rectangle x1="-10.11" y1="-9.87" x2="-9.69" y2="-9.37" layer="51"/>
<rectangle x1="-9.67" y1="-9.87" x2="-9.25" y2="-9.37" layer="51"/>
<rectangle x1="-9.23" y1="-9.87" x2="-8.81" y2="-9.37" layer="51"/>
<rectangle x1="-8.79" y1="-9.87" x2="-8.37" y2="-9.37" layer="51"/>
<rectangle x1="-8.35" y1="-9.87" x2="-7.93" y2="-9.37" layer="51"/>
<rectangle x1="-7.91" y1="-9.87" x2="-7.49" y2="-9.37" layer="51"/>
<rectangle x1="-7.47" y1="-9.87" x2="-7.05" y2="-9.37" layer="51"/>
<rectangle x1="-7.03" y1="-9.87" x2="-6.61" y2="-9.37" layer="51"/>
<rectangle x1="-6.59" y1="-9.87" x2="-6.17" y2="-9.37" layer="51"/>
<rectangle x1="-6.15" y1="-9.87" x2="-5.73" y2="-9.37" layer="51"/>
<rectangle x1="-5.71" y1="-9.87" x2="-5.29" y2="-9.37" layer="51"/>
<rectangle x1="-5.27" y1="-9.87" x2="-4.85" y2="-9.37" layer="51"/>
<rectangle x1="-4.83" y1="-9.87" x2="-4.41" y2="-9.37" layer="51"/>
<rectangle x1="-4.39" y1="-9.87" x2="-3.97" y2="-9.37" layer="51"/>
<rectangle x1="-3.95" y1="-9.87" x2="-3.53" y2="-9.37" layer="51"/>
<rectangle x1="-3.51" y1="-9.87" x2="-3.09" y2="-9.37" layer="51"/>
<rectangle x1="-3.07" y1="-9.87" x2="-2.65" y2="-9.37" layer="51"/>
<rectangle x1="-2.63" y1="-9.87" x2="-2.21" y2="-9.37" layer="51"/>
<rectangle x1="-2.19" y1="-9.87" x2="-1.77" y2="-9.37" layer="51"/>
<rectangle x1="-1.75" y1="-9.87" x2="-1.33" y2="-9.37" layer="51"/>
<rectangle x1="-1.31" y1="-9.87" x2="-0.89" y2="-9.37" layer="51"/>
<rectangle x1="-0.87" y1="-9.87" x2="-0.45" y2="-9.37" layer="51"/>
<rectangle x1="-0.43" y1="-9.87" x2="-0.01" y2="-9.37" layer="51"/>
<rectangle x1="0.01" y1="-9.87" x2="0.43" y2="-9.37" layer="51"/>
<rectangle x1="0.45" y1="-9.87" x2="0.87" y2="-9.37" layer="51"/>
<rectangle x1="0.89" y1="-9.87" x2="1.31" y2="-9.37" layer="51"/>
<rectangle x1="1.33" y1="-9.87" x2="1.75" y2="-9.37" layer="51"/>
<rectangle x1="1.77" y1="-9.87" x2="2.19" y2="-9.37" layer="51"/>
<rectangle x1="2.21" y1="-9.87" x2="2.63" y2="-9.37" layer="51"/>
<rectangle x1="2.65" y1="-9.87" x2="3.07" y2="-9.37" layer="51"/>
<rectangle x1="3.09" y1="-9.87" x2="3.51" y2="-9.37" layer="51"/>
<rectangle x1="3.53" y1="-9.87" x2="3.95" y2="-9.37" layer="51"/>
<rectangle x1="3.97" y1="-9.87" x2="4.39" y2="-9.37" layer="51"/>
<rectangle x1="4.41" y1="-9.87" x2="4.83" y2="-9.37" layer="51"/>
<rectangle x1="4.85" y1="-9.87" x2="5.27" y2="-9.37" layer="51"/>
<rectangle x1="5.29" y1="-9.87" x2="5.71" y2="-9.37" layer="51"/>
<rectangle x1="5.73" y1="-9.87" x2="6.15" y2="-9.37" layer="51"/>
<rectangle x1="6.17" y1="-9.87" x2="6.59" y2="-9.37" layer="51"/>
<rectangle x1="6.61" y1="-9.87" x2="7.03" y2="-9.37" layer="51"/>
<rectangle x1="7.05" y1="-9.87" x2="7.47" y2="-9.37" layer="51"/>
<rectangle x1="7.49" y1="-9.87" x2="7.91" y2="-9.37" layer="51"/>
<rectangle x1="7.93" y1="-9.87" x2="8.35" y2="-9.37" layer="51"/>
<rectangle x1="8.37" y1="-9.87" x2="8.79" y2="-9.37" layer="51"/>
<rectangle x1="8.81" y1="-9.87" x2="9.23" y2="-9.37" layer="51"/>
<rectangle x1="9.25" y1="-9.87" x2="9.67" y2="-9.37" layer="51"/>
<rectangle x1="9.69" y1="-9.87" x2="10.11" y2="-9.37" layer="51"/>
<rectangle x1="10.13" y1="-9.87" x2="10.55" y2="-9.37" layer="51"/>
<rectangle x1="10.57" y1="-9.87" x2="10.99" y2="-9.37" layer="51"/>
<rectangle x1="11.01" y1="-9.87" x2="11.43" y2="-9.37" layer="51"/>
<rectangle x1="11.45" y1="-9.87" x2="11.87" y2="-9.37" layer="51"/>
<rectangle x1="11.89" y1="-9.87" x2="12.31" y2="-9.37" layer="51"/>
<rectangle x1="12.33" y1="-9.87" x2="12.75" y2="-9.37" layer="51"/>
<rectangle x1="12.77" y1="-9.87" x2="13.19" y2="-9.37" layer="51"/>
<rectangle x1="13.21" y1="-9.87" x2="13.63" y2="-9.37" layer="51"/>
<rectangle x1="13.65" y1="-9.87" x2="14.07" y2="-9.37" layer="51"/>
<rectangle x1="14.09" y1="-9.87" x2="14.51" y2="-9.37" layer="51"/>
<rectangle x1="14.53" y1="-9.87" x2="14.95" y2="-9.37" layer="51"/>
<rectangle x1="14.97" y1="-9.87" x2="15.39" y2="-9.37" layer="51"/>
<rectangle x1="15.41" y1="-9.87" x2="15.83" y2="-9.37" layer="51"/>
<rectangle x1="15.85" y1="-9.87" x2="16.27" y2="-9.37" layer="51"/>
<rectangle x1="16.29" y1="-9.87" x2="16.71" y2="-9.37" layer="51"/>
<rectangle x1="16.73" y1="-9.87" x2="17.15" y2="-9.37" layer="51"/>
<rectangle x1="17.17" y1="-9.87" x2="17.59" y2="-9.37" layer="51"/>
<rectangle x1="17.61" y1="-9.87" x2="18.03" y2="-9.37" layer="51"/>
<rectangle x1="18.05" y1="-9.87" x2="18.47" y2="-9.37" layer="51"/>
<rectangle x1="18.49" y1="-9.87" x2="18.91" y2="-9.37" layer="51"/>
<rectangle x1="18.93" y1="-9.87" x2="19.35" y2="-9.37" layer="51"/>
<rectangle x1="19.37" y1="-9.87" x2="19.79" y2="-9.37" layer="51"/>
<rectangle x1="19.81" y1="-9.87" x2="20.23" y2="-9.37" layer="51"/>
<rectangle x1="20.25" y1="-9.87" x2="20.67" y2="-9.37" layer="51"/>
<rectangle x1="20.69" y1="-9.87" x2="21.11" y2="-9.37" layer="51"/>
<rectangle x1="21.13" y1="-9.87" x2="21.55" y2="-9.37" layer="51"/>
<rectangle x1="21.57" y1="-9.87" x2="21.99" y2="-9.37" layer="51"/>
<rectangle x1="22.01" y1="-9.87" x2="22.43" y2="-9.37" layer="51"/>
<rectangle x1="22.45" y1="-9.87" x2="22.87" y2="-9.37" layer="51"/>
<rectangle x1="22.89" y1="-9.87" x2="23.31" y2="-9.37" layer="51"/>
<rectangle x1="23.33" y1="-9.87" x2="23.75" y2="-9.37" layer="51"/>
<rectangle x1="23.77" y1="-9.87" x2="24.19" y2="-9.37" layer="51"/>
<rectangle x1="24.21" y1="-9.87" x2="24.63" y2="-9.37" layer="51"/>
<rectangle x1="24.65" y1="-9.87" x2="25.07" y2="-9.37" layer="51"/>
<rectangle x1="25.09" y1="-9.87" x2="25.51" y2="-9.37" layer="51"/>
<rectangle x1="25.53" y1="-9.87" x2="25.95" y2="-9.37" layer="51"/>
<rectangle x1="25.97" y1="-9.87" x2="26.39" y2="-9.37" layer="51"/>
<rectangle x1="26.41" y1="-9.87" x2="26.83" y2="-9.37" layer="51"/>
<rectangle x1="26.85" y1="-9.87" x2="27.27" y2="-9.37" layer="51"/>
<rectangle x1="27.29" y1="-9.87" x2="27.71" y2="-9.37" layer="51"/>
<rectangle x1="27.73" y1="-9.87" x2="28.15" y2="-9.37" layer="51"/>
<rectangle x1="-28.15" y1="-10.39" x2="-27.73" y2="-9.89" layer="51"/>
<rectangle x1="-27.71" y1="-10.39" x2="-27.29" y2="-9.89" layer="51"/>
<rectangle x1="-27.27" y1="-10.39" x2="-26.85" y2="-9.89" layer="51"/>
<rectangle x1="-26.83" y1="-10.39" x2="-26.41" y2="-9.89" layer="51"/>
<rectangle x1="-26.39" y1="-10.39" x2="-25.97" y2="-9.89" layer="51"/>
<rectangle x1="-25.95" y1="-10.39" x2="-25.53" y2="-9.89" layer="51"/>
<rectangle x1="-25.51" y1="-10.39" x2="-25.09" y2="-9.89" layer="51"/>
<rectangle x1="-25.07" y1="-10.39" x2="-24.65" y2="-9.89" layer="51"/>
<rectangle x1="-24.63" y1="-10.39" x2="-24.21" y2="-9.89" layer="51"/>
<rectangle x1="-24.19" y1="-10.39" x2="-23.77" y2="-9.89" layer="51"/>
<rectangle x1="-23.75" y1="-10.39" x2="-23.33" y2="-9.89" layer="51"/>
<rectangle x1="-23.31" y1="-10.39" x2="-22.89" y2="-9.89" layer="51"/>
<rectangle x1="-22.87" y1="-10.39" x2="-22.45" y2="-9.89" layer="51"/>
<rectangle x1="-22.43" y1="-10.39" x2="-22.01" y2="-9.89" layer="51"/>
<rectangle x1="-21.99" y1="-10.39" x2="-21.57" y2="-9.89" layer="51"/>
<rectangle x1="-21.55" y1="-10.39" x2="-21.13" y2="-9.89" layer="51"/>
<rectangle x1="-21.11" y1="-10.39" x2="-20.69" y2="-9.89" layer="51"/>
<rectangle x1="-20.67" y1="-10.39" x2="-20.25" y2="-9.89" layer="51"/>
<rectangle x1="-20.23" y1="-10.39" x2="-19.81" y2="-9.89" layer="51"/>
<rectangle x1="-19.79" y1="-10.39" x2="-19.37" y2="-9.89" layer="51"/>
<rectangle x1="-19.35" y1="-10.39" x2="-18.93" y2="-9.89" layer="51"/>
<rectangle x1="-18.91" y1="-10.39" x2="-18.49" y2="-9.89" layer="51"/>
<rectangle x1="-18.47" y1="-10.39" x2="-18.05" y2="-9.89" layer="51"/>
<rectangle x1="-18.03" y1="-10.39" x2="-17.61" y2="-9.89" layer="51"/>
<rectangle x1="-17.59" y1="-10.39" x2="-17.17" y2="-9.89" layer="51"/>
<rectangle x1="-17.15" y1="-10.39" x2="-16.73" y2="-9.89" layer="51"/>
<rectangle x1="-16.71" y1="-10.39" x2="-16.29" y2="-9.89" layer="51"/>
<rectangle x1="-16.27" y1="-10.39" x2="-15.85" y2="-9.89" layer="51"/>
<rectangle x1="-15.83" y1="-10.39" x2="-15.41" y2="-9.89" layer="51"/>
<rectangle x1="-15.39" y1="-10.39" x2="-14.97" y2="-9.89" layer="51"/>
<rectangle x1="-14.95" y1="-10.39" x2="-14.53" y2="-9.89" layer="51"/>
<rectangle x1="-14.51" y1="-10.39" x2="-14.09" y2="-9.89" layer="51"/>
<rectangle x1="-14.07" y1="-10.39" x2="-13.65" y2="-9.89" layer="51"/>
<rectangle x1="-13.63" y1="-10.39" x2="-13.21" y2="-9.89" layer="51"/>
<rectangle x1="-13.19" y1="-10.39" x2="-12.77" y2="-9.89" layer="51"/>
<rectangle x1="-12.75" y1="-10.39" x2="-12.33" y2="-9.89" layer="51"/>
<rectangle x1="-12.31" y1="-10.39" x2="-11.89" y2="-9.89" layer="51"/>
<rectangle x1="-11.87" y1="-10.39" x2="-11.45" y2="-9.89" layer="51"/>
<rectangle x1="-11.43" y1="-10.39" x2="-11.01" y2="-9.89" layer="51"/>
<rectangle x1="-10.99" y1="-10.39" x2="-10.57" y2="-9.89" layer="51"/>
<rectangle x1="-10.55" y1="-10.39" x2="-10.13" y2="-9.89" layer="51"/>
<rectangle x1="-10.11" y1="-10.39" x2="-9.69" y2="-9.89" layer="51"/>
<rectangle x1="-9.67" y1="-10.39" x2="-9.25" y2="-9.89" layer="51"/>
<rectangle x1="-9.23" y1="-10.39" x2="-8.81" y2="-9.89" layer="51"/>
<rectangle x1="-8.79" y1="-10.39" x2="-8.37" y2="-9.89" layer="51"/>
<rectangle x1="-8.35" y1="-10.39" x2="-7.93" y2="-9.89" layer="51"/>
<rectangle x1="-7.91" y1="-10.39" x2="-7.49" y2="-9.89" layer="51"/>
<rectangle x1="-7.47" y1="-10.39" x2="-7.05" y2="-9.89" layer="51"/>
<rectangle x1="-7.03" y1="-10.39" x2="-6.61" y2="-9.89" layer="51"/>
<rectangle x1="-6.59" y1="-10.39" x2="-6.17" y2="-9.89" layer="51"/>
<rectangle x1="-6.15" y1="-10.39" x2="-5.73" y2="-9.89" layer="51"/>
<rectangle x1="-5.71" y1="-10.39" x2="-5.29" y2="-9.89" layer="51"/>
<rectangle x1="-5.27" y1="-10.39" x2="-4.85" y2="-9.89" layer="51"/>
<rectangle x1="-4.83" y1="-10.39" x2="-4.41" y2="-9.89" layer="51"/>
<rectangle x1="-4.39" y1="-10.39" x2="-3.97" y2="-9.89" layer="51"/>
<rectangle x1="-3.95" y1="-10.39" x2="-3.53" y2="-9.89" layer="51"/>
<rectangle x1="-3.51" y1="-10.39" x2="-3.09" y2="-9.89" layer="51"/>
<rectangle x1="-3.07" y1="-10.39" x2="-2.65" y2="-9.89" layer="51"/>
<rectangle x1="-2.63" y1="-10.39" x2="-2.21" y2="-9.89" layer="51"/>
<rectangle x1="-2.19" y1="-10.39" x2="-1.77" y2="-9.89" layer="51"/>
<rectangle x1="-1.75" y1="-10.39" x2="-1.33" y2="-9.89" layer="51"/>
<rectangle x1="-1.31" y1="-10.39" x2="-0.89" y2="-9.89" layer="51"/>
<rectangle x1="-0.87" y1="-10.39" x2="-0.45" y2="-9.89" layer="51"/>
<rectangle x1="-0.43" y1="-10.39" x2="-0.01" y2="-9.89" layer="51"/>
<rectangle x1="0.01" y1="-10.39" x2="0.43" y2="-9.89" layer="51"/>
<rectangle x1="0.45" y1="-10.39" x2="0.87" y2="-9.89" layer="51"/>
<rectangle x1="0.89" y1="-10.39" x2="1.31" y2="-9.89" layer="51"/>
<rectangle x1="1.33" y1="-10.39" x2="1.75" y2="-9.89" layer="51"/>
<rectangle x1="1.77" y1="-10.39" x2="2.19" y2="-9.89" layer="51"/>
<rectangle x1="2.21" y1="-10.39" x2="2.63" y2="-9.89" layer="51"/>
<rectangle x1="2.65" y1="-10.39" x2="3.07" y2="-9.89" layer="51"/>
<rectangle x1="3.09" y1="-10.39" x2="3.51" y2="-9.89" layer="51"/>
<rectangle x1="3.53" y1="-10.39" x2="3.95" y2="-9.89" layer="51"/>
<rectangle x1="3.97" y1="-10.39" x2="4.39" y2="-9.89" layer="51"/>
<rectangle x1="4.41" y1="-10.39" x2="4.83" y2="-9.89" layer="51"/>
<rectangle x1="4.85" y1="-10.39" x2="5.27" y2="-9.89" layer="51"/>
<rectangle x1="5.29" y1="-10.39" x2="5.71" y2="-9.89" layer="51"/>
<rectangle x1="5.73" y1="-10.39" x2="6.15" y2="-9.89" layer="51"/>
<rectangle x1="6.17" y1="-10.39" x2="6.59" y2="-9.89" layer="51"/>
<rectangle x1="6.61" y1="-10.39" x2="7.03" y2="-9.89" layer="51"/>
<rectangle x1="7.05" y1="-10.39" x2="7.47" y2="-9.89" layer="51"/>
<rectangle x1="7.49" y1="-10.39" x2="7.91" y2="-9.89" layer="51"/>
<rectangle x1="7.93" y1="-10.39" x2="8.35" y2="-9.89" layer="51"/>
<rectangle x1="8.37" y1="-10.39" x2="8.79" y2="-9.89" layer="51"/>
<rectangle x1="8.81" y1="-10.39" x2="9.23" y2="-9.89" layer="51"/>
<rectangle x1="9.25" y1="-10.39" x2="9.67" y2="-9.89" layer="51"/>
<rectangle x1="9.69" y1="-10.39" x2="10.11" y2="-9.89" layer="51"/>
<rectangle x1="10.13" y1="-10.39" x2="10.55" y2="-9.89" layer="51"/>
<rectangle x1="10.57" y1="-10.39" x2="10.99" y2="-9.89" layer="51"/>
<rectangle x1="11.01" y1="-10.39" x2="11.43" y2="-9.89" layer="51"/>
<rectangle x1="11.45" y1="-10.39" x2="11.87" y2="-9.89" layer="51"/>
<rectangle x1="11.89" y1="-10.39" x2="12.31" y2="-9.89" layer="51"/>
<rectangle x1="12.33" y1="-10.39" x2="12.75" y2="-9.89" layer="51"/>
<rectangle x1="12.77" y1="-10.39" x2="13.19" y2="-9.89" layer="51"/>
<rectangle x1="13.21" y1="-10.39" x2="13.63" y2="-9.89" layer="51"/>
<rectangle x1="13.65" y1="-10.39" x2="14.07" y2="-9.89" layer="51"/>
<rectangle x1="14.09" y1="-10.39" x2="14.51" y2="-9.89" layer="51"/>
<rectangle x1="14.53" y1="-10.39" x2="14.95" y2="-9.89" layer="51"/>
<rectangle x1="14.97" y1="-10.39" x2="15.39" y2="-9.89" layer="51"/>
<rectangle x1="15.41" y1="-10.39" x2="15.83" y2="-9.89" layer="51"/>
<rectangle x1="15.85" y1="-10.39" x2="16.27" y2="-9.89" layer="51"/>
<rectangle x1="16.29" y1="-10.39" x2="16.71" y2="-9.89" layer="51"/>
<rectangle x1="16.73" y1="-10.39" x2="17.15" y2="-9.89" layer="51"/>
<rectangle x1="17.17" y1="-10.39" x2="17.59" y2="-9.89" layer="51"/>
<rectangle x1="17.61" y1="-10.39" x2="18.03" y2="-9.89" layer="51"/>
<rectangle x1="18.05" y1="-10.39" x2="18.47" y2="-9.89" layer="51"/>
<rectangle x1="18.49" y1="-10.39" x2="18.91" y2="-9.89" layer="51"/>
<rectangle x1="18.93" y1="-10.39" x2="19.35" y2="-9.89" layer="51"/>
<rectangle x1="19.37" y1="-10.39" x2="19.79" y2="-9.89" layer="51"/>
<rectangle x1="19.81" y1="-10.39" x2="20.23" y2="-9.89" layer="51"/>
<rectangle x1="20.25" y1="-10.39" x2="20.67" y2="-9.89" layer="51"/>
<rectangle x1="20.69" y1="-10.39" x2="21.11" y2="-9.89" layer="51"/>
<rectangle x1="21.13" y1="-10.39" x2="21.55" y2="-9.89" layer="51"/>
<rectangle x1="21.57" y1="-10.39" x2="21.99" y2="-9.89" layer="51"/>
<rectangle x1="22.01" y1="-10.39" x2="22.43" y2="-9.89" layer="51"/>
<rectangle x1="22.45" y1="-10.39" x2="22.87" y2="-9.89" layer="51"/>
<rectangle x1="22.89" y1="-10.39" x2="23.31" y2="-9.89" layer="51"/>
<rectangle x1="23.33" y1="-10.39" x2="23.75" y2="-9.89" layer="51"/>
<rectangle x1="23.77" y1="-10.39" x2="24.19" y2="-9.89" layer="51"/>
<rectangle x1="24.21" y1="-10.39" x2="24.63" y2="-9.89" layer="51"/>
<rectangle x1="24.65" y1="-10.39" x2="25.07" y2="-9.89" layer="51"/>
<rectangle x1="25.09" y1="-10.39" x2="25.51" y2="-9.89" layer="51"/>
<rectangle x1="25.53" y1="-10.39" x2="25.95" y2="-9.89" layer="51"/>
<rectangle x1="25.97" y1="-10.39" x2="26.39" y2="-9.89" layer="51"/>
<rectangle x1="26.41" y1="-10.39" x2="26.83" y2="-9.89" layer="51"/>
<rectangle x1="26.85" y1="-10.39" x2="27.27" y2="-9.89" layer="51"/>
<rectangle x1="27.29" y1="-10.39" x2="27.71" y2="-9.89" layer="51"/>
<rectangle x1="27.73" y1="-10.39" x2="28.15" y2="-9.89" layer="51"/>
<rectangle x1="-28.15" y1="-10.91" x2="-27.73" y2="-10.41" layer="51"/>
<rectangle x1="-27.71" y1="-10.91" x2="-27.29" y2="-10.41" layer="51"/>
<rectangle x1="-27.27" y1="-10.91" x2="-26.85" y2="-10.41" layer="51"/>
<rectangle x1="-26.83" y1="-10.91" x2="-26.41" y2="-10.41" layer="51"/>
<rectangle x1="-26.39" y1="-10.91" x2="-25.97" y2="-10.41" layer="51"/>
<rectangle x1="-25.95" y1="-10.91" x2="-25.53" y2="-10.41" layer="51"/>
<rectangle x1="-25.51" y1="-10.91" x2="-25.09" y2="-10.41" layer="51"/>
<rectangle x1="-25.07" y1="-10.91" x2="-24.65" y2="-10.41" layer="51"/>
<rectangle x1="-24.63" y1="-10.91" x2="-24.21" y2="-10.41" layer="51"/>
<rectangle x1="-24.19" y1="-10.91" x2="-23.77" y2="-10.41" layer="51"/>
<rectangle x1="-23.75" y1="-10.91" x2="-23.33" y2="-10.41" layer="51"/>
<rectangle x1="-23.31" y1="-10.91" x2="-22.89" y2="-10.41" layer="51"/>
<rectangle x1="-22.87" y1="-10.91" x2="-22.45" y2="-10.41" layer="51"/>
<rectangle x1="-22.43" y1="-10.91" x2="-22.01" y2="-10.41" layer="51"/>
<rectangle x1="-21.99" y1="-10.91" x2="-21.57" y2="-10.41" layer="51"/>
<rectangle x1="-21.55" y1="-10.91" x2="-21.13" y2="-10.41" layer="51"/>
<rectangle x1="-21.11" y1="-10.91" x2="-20.69" y2="-10.41" layer="51"/>
<rectangle x1="-20.67" y1="-10.91" x2="-20.25" y2="-10.41" layer="51"/>
<rectangle x1="-20.23" y1="-10.91" x2="-19.81" y2="-10.41" layer="51"/>
<rectangle x1="-19.79" y1="-10.91" x2="-19.37" y2="-10.41" layer="51"/>
<rectangle x1="-19.35" y1="-10.91" x2="-18.93" y2="-10.41" layer="51"/>
<rectangle x1="-18.91" y1="-10.91" x2="-18.49" y2="-10.41" layer="51"/>
<rectangle x1="-18.47" y1="-10.91" x2="-18.05" y2="-10.41" layer="51"/>
<rectangle x1="-18.03" y1="-10.91" x2="-17.61" y2="-10.41" layer="51"/>
<rectangle x1="-17.59" y1="-10.91" x2="-17.17" y2="-10.41" layer="51"/>
<rectangle x1="-17.15" y1="-10.91" x2="-16.73" y2="-10.41" layer="51"/>
<rectangle x1="-16.71" y1="-10.91" x2="-16.29" y2="-10.41" layer="51"/>
<rectangle x1="-16.27" y1="-10.91" x2="-15.85" y2="-10.41" layer="51"/>
<rectangle x1="-15.83" y1="-10.91" x2="-15.41" y2="-10.41" layer="51"/>
<rectangle x1="-15.39" y1="-10.91" x2="-14.97" y2="-10.41" layer="51"/>
<rectangle x1="-14.95" y1="-10.91" x2="-14.53" y2="-10.41" layer="51"/>
<rectangle x1="-14.51" y1="-10.91" x2="-14.09" y2="-10.41" layer="51"/>
<rectangle x1="-14.07" y1="-10.91" x2="-13.65" y2="-10.41" layer="51"/>
<rectangle x1="-13.63" y1="-10.91" x2="-13.21" y2="-10.41" layer="51"/>
<rectangle x1="-13.19" y1="-10.91" x2="-12.77" y2="-10.41" layer="51"/>
<rectangle x1="-12.75" y1="-10.91" x2="-12.33" y2="-10.41" layer="51"/>
<rectangle x1="-12.31" y1="-10.91" x2="-11.89" y2="-10.41" layer="51"/>
<rectangle x1="-11.87" y1="-10.91" x2="-11.45" y2="-10.41" layer="51"/>
<rectangle x1="-11.43" y1="-10.91" x2="-11.01" y2="-10.41" layer="51"/>
<rectangle x1="-10.99" y1="-10.91" x2="-10.57" y2="-10.41" layer="51"/>
<rectangle x1="-10.55" y1="-10.91" x2="-10.13" y2="-10.41" layer="51"/>
<rectangle x1="-10.11" y1="-10.91" x2="-9.69" y2="-10.41" layer="51"/>
<rectangle x1="-9.67" y1="-10.91" x2="-9.25" y2="-10.41" layer="51"/>
<rectangle x1="-9.23" y1="-10.91" x2="-8.81" y2="-10.41" layer="51"/>
<rectangle x1="-8.79" y1="-10.91" x2="-8.37" y2="-10.41" layer="51"/>
<rectangle x1="-8.35" y1="-10.91" x2="-7.93" y2="-10.41" layer="51"/>
<rectangle x1="-7.91" y1="-10.91" x2="-7.49" y2="-10.41" layer="51"/>
<rectangle x1="-7.47" y1="-10.91" x2="-7.05" y2="-10.41" layer="51"/>
<rectangle x1="-7.03" y1="-10.91" x2="-6.61" y2="-10.41" layer="51"/>
<rectangle x1="-6.59" y1="-10.91" x2="-6.17" y2="-10.41" layer="51"/>
<rectangle x1="-6.15" y1="-10.91" x2="-5.73" y2="-10.41" layer="51"/>
<rectangle x1="-5.71" y1="-10.91" x2="-5.29" y2="-10.41" layer="51"/>
<rectangle x1="-5.27" y1="-10.91" x2="-4.85" y2="-10.41" layer="51"/>
<rectangle x1="-4.83" y1="-10.91" x2="-4.41" y2="-10.41" layer="51"/>
<rectangle x1="-4.39" y1="-10.91" x2="-3.97" y2="-10.41" layer="51"/>
<rectangle x1="-3.95" y1="-10.91" x2="-3.53" y2="-10.41" layer="51"/>
<rectangle x1="-3.51" y1="-10.91" x2="-3.09" y2="-10.41" layer="51"/>
<rectangle x1="-3.07" y1="-10.91" x2="-2.65" y2="-10.41" layer="51"/>
<rectangle x1="-2.63" y1="-10.91" x2="-2.21" y2="-10.41" layer="51"/>
<rectangle x1="-2.19" y1="-10.91" x2="-1.77" y2="-10.41" layer="51"/>
<rectangle x1="-1.75" y1="-10.91" x2="-1.33" y2="-10.41" layer="51"/>
<rectangle x1="-1.31" y1="-10.91" x2="-0.89" y2="-10.41" layer="51"/>
<rectangle x1="-0.87" y1="-10.91" x2="-0.45" y2="-10.41" layer="51"/>
<rectangle x1="-0.43" y1="-10.91" x2="-0.01" y2="-10.41" layer="51"/>
<rectangle x1="0.01" y1="-10.91" x2="0.43" y2="-10.41" layer="51"/>
<rectangle x1="0.45" y1="-10.91" x2="0.87" y2="-10.41" layer="51"/>
<rectangle x1="0.89" y1="-10.91" x2="1.31" y2="-10.41" layer="51"/>
<rectangle x1="1.33" y1="-10.91" x2="1.75" y2="-10.41" layer="51"/>
<rectangle x1="1.77" y1="-10.91" x2="2.19" y2="-10.41" layer="51"/>
<rectangle x1="2.21" y1="-10.91" x2="2.63" y2="-10.41" layer="51"/>
<rectangle x1="2.65" y1="-10.91" x2="3.07" y2="-10.41" layer="51"/>
<rectangle x1="3.09" y1="-10.91" x2="3.51" y2="-10.41" layer="51"/>
<rectangle x1="3.53" y1="-10.91" x2="3.95" y2="-10.41" layer="51"/>
<rectangle x1="3.97" y1="-10.91" x2="4.39" y2="-10.41" layer="51"/>
<rectangle x1="4.41" y1="-10.91" x2="4.83" y2="-10.41" layer="51"/>
<rectangle x1="4.85" y1="-10.91" x2="5.27" y2="-10.41" layer="51"/>
<rectangle x1="5.29" y1="-10.91" x2="5.71" y2="-10.41" layer="51"/>
<rectangle x1="5.73" y1="-10.91" x2="6.15" y2="-10.41" layer="51"/>
<rectangle x1="6.17" y1="-10.91" x2="6.59" y2="-10.41" layer="51"/>
<rectangle x1="6.61" y1="-10.91" x2="7.03" y2="-10.41" layer="51"/>
<rectangle x1="7.05" y1="-10.91" x2="7.47" y2="-10.41" layer="51"/>
<rectangle x1="7.49" y1="-10.91" x2="7.91" y2="-10.41" layer="51"/>
<rectangle x1="7.93" y1="-10.91" x2="8.35" y2="-10.41" layer="51"/>
<rectangle x1="8.37" y1="-10.91" x2="8.79" y2="-10.41" layer="51"/>
<rectangle x1="8.81" y1="-10.91" x2="9.23" y2="-10.41" layer="51"/>
<rectangle x1="9.25" y1="-10.91" x2="9.67" y2="-10.41" layer="51"/>
<rectangle x1="9.69" y1="-10.91" x2="10.11" y2="-10.41" layer="51"/>
<rectangle x1="10.13" y1="-10.91" x2="10.55" y2="-10.41" layer="51"/>
<rectangle x1="10.57" y1="-10.91" x2="10.99" y2="-10.41" layer="51"/>
<rectangle x1="11.01" y1="-10.91" x2="11.43" y2="-10.41" layer="51"/>
<rectangle x1="11.45" y1="-10.91" x2="11.87" y2="-10.41" layer="51"/>
<rectangle x1="11.89" y1="-10.91" x2="12.31" y2="-10.41" layer="51"/>
<rectangle x1="12.33" y1="-10.91" x2="12.75" y2="-10.41" layer="51"/>
<rectangle x1="12.77" y1="-10.91" x2="13.19" y2="-10.41" layer="51"/>
<rectangle x1="13.21" y1="-10.91" x2="13.63" y2="-10.41" layer="51"/>
<rectangle x1="13.65" y1="-10.91" x2="14.07" y2="-10.41" layer="51"/>
<rectangle x1="14.09" y1="-10.91" x2="14.51" y2="-10.41" layer="51"/>
<rectangle x1="14.53" y1="-10.91" x2="14.95" y2="-10.41" layer="51"/>
<rectangle x1="14.97" y1="-10.91" x2="15.39" y2="-10.41" layer="51"/>
<rectangle x1="15.41" y1="-10.91" x2="15.83" y2="-10.41" layer="51"/>
<rectangle x1="15.85" y1="-10.91" x2="16.27" y2="-10.41" layer="51"/>
<rectangle x1="16.29" y1="-10.91" x2="16.71" y2="-10.41" layer="51"/>
<rectangle x1="16.73" y1="-10.91" x2="17.15" y2="-10.41" layer="51"/>
<rectangle x1="17.17" y1="-10.91" x2="17.59" y2="-10.41" layer="51"/>
<rectangle x1="17.61" y1="-10.91" x2="18.03" y2="-10.41" layer="51"/>
<rectangle x1="18.05" y1="-10.91" x2="18.47" y2="-10.41" layer="51"/>
<rectangle x1="18.49" y1="-10.91" x2="18.91" y2="-10.41" layer="51"/>
<rectangle x1="18.93" y1="-10.91" x2="19.35" y2="-10.41" layer="51"/>
<rectangle x1="19.37" y1="-10.91" x2="19.79" y2="-10.41" layer="51"/>
<rectangle x1="19.81" y1="-10.91" x2="20.23" y2="-10.41" layer="51"/>
<rectangle x1="20.25" y1="-10.91" x2="20.67" y2="-10.41" layer="51"/>
<rectangle x1="20.69" y1="-10.91" x2="21.11" y2="-10.41" layer="51"/>
<rectangle x1="21.13" y1="-10.91" x2="21.55" y2="-10.41" layer="51"/>
<rectangle x1="21.57" y1="-10.91" x2="21.99" y2="-10.41" layer="51"/>
<rectangle x1="22.01" y1="-10.91" x2="22.43" y2="-10.41" layer="51"/>
<rectangle x1="22.45" y1="-10.91" x2="22.87" y2="-10.41" layer="51"/>
<rectangle x1="22.89" y1="-10.91" x2="23.31" y2="-10.41" layer="51"/>
<rectangle x1="23.33" y1="-10.91" x2="23.75" y2="-10.41" layer="51"/>
<rectangle x1="23.77" y1="-10.91" x2="24.19" y2="-10.41" layer="51"/>
<rectangle x1="24.21" y1="-10.91" x2="24.63" y2="-10.41" layer="51"/>
<rectangle x1="24.65" y1="-10.91" x2="25.07" y2="-10.41" layer="51"/>
<rectangle x1="25.09" y1="-10.91" x2="25.51" y2="-10.41" layer="51"/>
<rectangle x1="25.53" y1="-10.91" x2="25.95" y2="-10.41" layer="51"/>
<rectangle x1="25.97" y1="-10.91" x2="26.39" y2="-10.41" layer="51"/>
<rectangle x1="26.41" y1="-10.91" x2="26.83" y2="-10.41" layer="51"/>
<rectangle x1="26.85" y1="-10.91" x2="27.27" y2="-10.41" layer="51"/>
<rectangle x1="27.29" y1="-10.91" x2="27.71" y2="-10.41" layer="51"/>
<rectangle x1="27.73" y1="-10.91" x2="28.15" y2="-10.41" layer="51"/>
<rectangle x1="-28.15" y1="-11.43" x2="-27.73" y2="-10.93" layer="51"/>
<rectangle x1="-27.71" y1="-11.43" x2="-27.29" y2="-10.93" layer="51"/>
<rectangle x1="-27.27" y1="-11.43" x2="-26.85" y2="-10.93" layer="51"/>
<rectangle x1="-26.83" y1="-11.43" x2="-26.41" y2="-10.93" layer="51"/>
<rectangle x1="-26.39" y1="-11.43" x2="-25.97" y2="-10.93" layer="51"/>
<rectangle x1="-25.95" y1="-11.43" x2="-25.53" y2="-10.93" layer="51"/>
<rectangle x1="-25.51" y1="-11.43" x2="-25.09" y2="-10.93" layer="51"/>
<rectangle x1="-25.07" y1="-11.43" x2="-24.65" y2="-10.93" layer="51"/>
<rectangle x1="-24.63" y1="-11.43" x2="-24.21" y2="-10.93" layer="51"/>
<rectangle x1="-24.19" y1="-11.43" x2="-23.77" y2="-10.93" layer="51"/>
<rectangle x1="-23.75" y1="-11.43" x2="-23.33" y2="-10.93" layer="51"/>
<rectangle x1="-23.31" y1="-11.43" x2="-22.89" y2="-10.93" layer="51"/>
<rectangle x1="-22.87" y1="-11.43" x2="-22.45" y2="-10.93" layer="51"/>
<rectangle x1="-22.43" y1="-11.43" x2="-22.01" y2="-10.93" layer="51"/>
<rectangle x1="-21.99" y1="-11.43" x2="-21.57" y2="-10.93" layer="51"/>
<rectangle x1="-21.55" y1="-11.43" x2="-21.13" y2="-10.93" layer="51"/>
<rectangle x1="-21.11" y1="-11.43" x2="-20.69" y2="-10.93" layer="51"/>
<rectangle x1="-20.67" y1="-11.43" x2="-20.25" y2="-10.93" layer="51"/>
<rectangle x1="-20.23" y1="-11.43" x2="-19.81" y2="-10.93" layer="51"/>
<rectangle x1="-19.79" y1="-11.43" x2="-19.37" y2="-10.93" layer="51"/>
<rectangle x1="-19.35" y1="-11.43" x2="-18.93" y2="-10.93" layer="51"/>
<rectangle x1="-18.91" y1="-11.43" x2="-18.49" y2="-10.93" layer="51"/>
<rectangle x1="-18.47" y1="-11.43" x2="-18.05" y2="-10.93" layer="51"/>
<rectangle x1="-18.03" y1="-11.43" x2="-17.61" y2="-10.93" layer="51"/>
<rectangle x1="-17.59" y1="-11.43" x2="-17.17" y2="-10.93" layer="51"/>
<rectangle x1="-17.15" y1="-11.43" x2="-16.73" y2="-10.93" layer="51"/>
<rectangle x1="-16.71" y1="-11.43" x2="-16.29" y2="-10.93" layer="51"/>
<rectangle x1="-16.27" y1="-11.43" x2="-15.85" y2="-10.93" layer="51"/>
<rectangle x1="-15.83" y1="-11.43" x2="-15.41" y2="-10.93" layer="51"/>
<rectangle x1="-15.39" y1="-11.43" x2="-14.97" y2="-10.93" layer="51"/>
<rectangle x1="-14.95" y1="-11.43" x2="-14.53" y2="-10.93" layer="51"/>
<rectangle x1="-14.51" y1="-11.43" x2="-14.09" y2="-10.93" layer="51"/>
<rectangle x1="-14.07" y1="-11.43" x2="-13.65" y2="-10.93" layer="51"/>
<rectangle x1="-13.63" y1="-11.43" x2="-13.21" y2="-10.93" layer="51"/>
<rectangle x1="-13.19" y1="-11.43" x2="-12.77" y2="-10.93" layer="51"/>
<rectangle x1="-12.75" y1="-11.43" x2="-12.33" y2="-10.93" layer="51"/>
<rectangle x1="-12.31" y1="-11.43" x2="-11.89" y2="-10.93" layer="51"/>
<rectangle x1="-11.87" y1="-11.43" x2="-11.45" y2="-10.93" layer="51"/>
<rectangle x1="-11.43" y1="-11.43" x2="-11.01" y2="-10.93" layer="51"/>
<rectangle x1="-10.99" y1="-11.43" x2="-10.57" y2="-10.93" layer="51"/>
<rectangle x1="-10.55" y1="-11.43" x2="-10.13" y2="-10.93" layer="51"/>
<rectangle x1="-10.11" y1="-11.43" x2="-9.69" y2="-10.93" layer="51"/>
<rectangle x1="-9.67" y1="-11.43" x2="-9.25" y2="-10.93" layer="51"/>
<rectangle x1="-9.23" y1="-11.43" x2="-8.81" y2="-10.93" layer="51"/>
<rectangle x1="-8.79" y1="-11.43" x2="-8.37" y2="-10.93" layer="51"/>
<rectangle x1="-8.35" y1="-11.43" x2="-7.93" y2="-10.93" layer="51"/>
<rectangle x1="-7.91" y1="-11.43" x2="-7.49" y2="-10.93" layer="51"/>
<rectangle x1="-7.47" y1="-11.43" x2="-7.05" y2="-10.93" layer="51"/>
<rectangle x1="-7.03" y1="-11.43" x2="-6.61" y2="-10.93" layer="51"/>
<rectangle x1="-6.59" y1="-11.43" x2="-6.17" y2="-10.93" layer="51"/>
<rectangle x1="-6.15" y1="-11.43" x2="-5.73" y2="-10.93" layer="51"/>
<rectangle x1="-5.71" y1="-11.43" x2="-5.29" y2="-10.93" layer="51"/>
<rectangle x1="-5.27" y1="-11.43" x2="-4.85" y2="-10.93" layer="51"/>
<rectangle x1="-4.83" y1="-11.43" x2="-4.41" y2="-10.93" layer="51"/>
<rectangle x1="-4.39" y1="-11.43" x2="-3.97" y2="-10.93" layer="51"/>
<rectangle x1="-3.95" y1="-11.43" x2="-3.53" y2="-10.93" layer="51"/>
<rectangle x1="-3.51" y1="-11.43" x2="-3.09" y2="-10.93" layer="51"/>
<rectangle x1="-3.07" y1="-11.43" x2="-2.65" y2="-10.93" layer="51"/>
<rectangle x1="-2.63" y1="-11.43" x2="-2.21" y2="-10.93" layer="51"/>
<rectangle x1="-2.19" y1="-11.43" x2="-1.77" y2="-10.93" layer="51"/>
<rectangle x1="-1.75" y1="-11.43" x2="-1.33" y2="-10.93" layer="51"/>
<rectangle x1="-1.31" y1="-11.43" x2="-0.89" y2="-10.93" layer="51"/>
<rectangle x1="-0.87" y1="-11.43" x2="-0.45" y2="-10.93" layer="51"/>
<rectangle x1="-0.43" y1="-11.43" x2="-0.01" y2="-10.93" layer="51"/>
<rectangle x1="0.01" y1="-11.43" x2="0.43" y2="-10.93" layer="51"/>
<rectangle x1="0.45" y1="-11.43" x2="0.87" y2="-10.93" layer="51"/>
<rectangle x1="0.89" y1="-11.43" x2="1.31" y2="-10.93" layer="51"/>
<rectangle x1="1.33" y1="-11.43" x2="1.75" y2="-10.93" layer="51"/>
<rectangle x1="1.77" y1="-11.43" x2="2.19" y2="-10.93" layer="51"/>
<rectangle x1="2.21" y1="-11.43" x2="2.63" y2="-10.93" layer="51"/>
<rectangle x1="2.65" y1="-11.43" x2="3.07" y2="-10.93" layer="51"/>
<rectangle x1="3.09" y1="-11.43" x2="3.51" y2="-10.93" layer="51"/>
<rectangle x1="3.53" y1="-11.43" x2="3.95" y2="-10.93" layer="51"/>
<rectangle x1="3.97" y1="-11.43" x2="4.39" y2="-10.93" layer="51"/>
<rectangle x1="4.41" y1="-11.43" x2="4.83" y2="-10.93" layer="51"/>
<rectangle x1="4.85" y1="-11.43" x2="5.27" y2="-10.93" layer="51"/>
<rectangle x1="5.29" y1="-11.43" x2="5.71" y2="-10.93" layer="51"/>
<rectangle x1="5.73" y1="-11.43" x2="6.15" y2="-10.93" layer="51"/>
<rectangle x1="6.17" y1="-11.43" x2="6.59" y2="-10.93" layer="51"/>
<rectangle x1="6.61" y1="-11.43" x2="7.03" y2="-10.93" layer="51"/>
<rectangle x1="7.05" y1="-11.43" x2="7.47" y2="-10.93" layer="51"/>
<rectangle x1="7.49" y1="-11.43" x2="7.91" y2="-10.93" layer="51"/>
<rectangle x1="7.93" y1="-11.43" x2="8.35" y2="-10.93" layer="51"/>
<rectangle x1="8.37" y1="-11.43" x2="8.79" y2="-10.93" layer="51"/>
<rectangle x1="8.81" y1="-11.43" x2="9.23" y2="-10.93" layer="51"/>
<rectangle x1="9.25" y1="-11.43" x2="9.67" y2="-10.93" layer="51"/>
<rectangle x1="9.69" y1="-11.43" x2="10.11" y2="-10.93" layer="51"/>
<rectangle x1="10.13" y1="-11.43" x2="10.55" y2="-10.93" layer="51"/>
<rectangle x1="10.57" y1="-11.43" x2="10.99" y2="-10.93" layer="51"/>
<rectangle x1="11.01" y1="-11.43" x2="11.43" y2="-10.93" layer="51"/>
<rectangle x1="11.45" y1="-11.43" x2="11.87" y2="-10.93" layer="51"/>
<rectangle x1="11.89" y1="-11.43" x2="12.31" y2="-10.93" layer="51"/>
<rectangle x1="12.33" y1="-11.43" x2="12.75" y2="-10.93" layer="51"/>
<rectangle x1="12.77" y1="-11.43" x2="13.19" y2="-10.93" layer="51"/>
<rectangle x1="13.21" y1="-11.43" x2="13.63" y2="-10.93" layer="51"/>
<rectangle x1="13.65" y1="-11.43" x2="14.07" y2="-10.93" layer="51"/>
<rectangle x1="14.09" y1="-11.43" x2="14.51" y2="-10.93" layer="51"/>
<rectangle x1="14.53" y1="-11.43" x2="14.95" y2="-10.93" layer="51"/>
<rectangle x1="14.97" y1="-11.43" x2="15.39" y2="-10.93" layer="51"/>
<rectangle x1="15.41" y1="-11.43" x2="15.83" y2="-10.93" layer="51"/>
<rectangle x1="15.85" y1="-11.43" x2="16.27" y2="-10.93" layer="51"/>
<rectangle x1="16.29" y1="-11.43" x2="16.71" y2="-10.93" layer="51"/>
<rectangle x1="16.73" y1="-11.43" x2="17.15" y2="-10.93" layer="51"/>
<rectangle x1="17.17" y1="-11.43" x2="17.59" y2="-10.93" layer="51"/>
<rectangle x1="17.61" y1="-11.43" x2="18.03" y2="-10.93" layer="51"/>
<rectangle x1="18.05" y1="-11.43" x2="18.47" y2="-10.93" layer="51"/>
<rectangle x1="18.49" y1="-11.43" x2="18.91" y2="-10.93" layer="51"/>
<rectangle x1="18.93" y1="-11.43" x2="19.35" y2="-10.93" layer="51"/>
<rectangle x1="19.37" y1="-11.43" x2="19.79" y2="-10.93" layer="51"/>
<rectangle x1="19.81" y1="-11.43" x2="20.23" y2="-10.93" layer="51"/>
<rectangle x1="20.25" y1="-11.43" x2="20.67" y2="-10.93" layer="51"/>
<rectangle x1="20.69" y1="-11.43" x2="21.11" y2="-10.93" layer="51"/>
<rectangle x1="21.13" y1="-11.43" x2="21.55" y2="-10.93" layer="51"/>
<rectangle x1="21.57" y1="-11.43" x2="21.99" y2="-10.93" layer="51"/>
<rectangle x1="22.01" y1="-11.43" x2="22.43" y2="-10.93" layer="51"/>
<rectangle x1="22.45" y1="-11.43" x2="22.87" y2="-10.93" layer="51"/>
<rectangle x1="22.89" y1="-11.43" x2="23.31" y2="-10.93" layer="51"/>
<rectangle x1="23.33" y1="-11.43" x2="23.75" y2="-10.93" layer="51"/>
<rectangle x1="23.77" y1="-11.43" x2="24.19" y2="-10.93" layer="51"/>
<rectangle x1="24.21" y1="-11.43" x2="24.63" y2="-10.93" layer="51"/>
<rectangle x1="24.65" y1="-11.43" x2="25.07" y2="-10.93" layer="51"/>
<rectangle x1="25.09" y1="-11.43" x2="25.51" y2="-10.93" layer="51"/>
<rectangle x1="25.53" y1="-11.43" x2="25.95" y2="-10.93" layer="51"/>
<rectangle x1="25.97" y1="-11.43" x2="26.39" y2="-10.93" layer="51"/>
<rectangle x1="26.41" y1="-11.43" x2="26.83" y2="-10.93" layer="51"/>
<rectangle x1="26.85" y1="-11.43" x2="27.27" y2="-10.93" layer="51"/>
<rectangle x1="27.29" y1="-11.43" x2="27.71" y2="-10.93" layer="51"/>
<rectangle x1="27.73" y1="-11.43" x2="28.15" y2="-10.93" layer="51"/>
<rectangle x1="-28.15" y1="-11.95" x2="-27.73" y2="-11.45" layer="51"/>
<rectangle x1="-27.71" y1="-11.95" x2="-27.29" y2="-11.45" layer="51"/>
<rectangle x1="-27.27" y1="-11.95" x2="-26.85" y2="-11.45" layer="51"/>
<rectangle x1="-26.83" y1="-11.95" x2="-26.41" y2="-11.45" layer="51"/>
<rectangle x1="-26.39" y1="-11.95" x2="-25.97" y2="-11.45" layer="51"/>
<rectangle x1="-25.95" y1="-11.95" x2="-25.53" y2="-11.45" layer="51"/>
<rectangle x1="-25.51" y1="-11.95" x2="-25.09" y2="-11.45" layer="51"/>
<rectangle x1="-25.07" y1="-11.95" x2="-24.65" y2="-11.45" layer="51"/>
<rectangle x1="-24.63" y1="-11.95" x2="-24.21" y2="-11.45" layer="51"/>
<rectangle x1="-24.19" y1="-11.95" x2="-23.77" y2="-11.45" layer="51"/>
<rectangle x1="-23.75" y1="-11.95" x2="-23.33" y2="-11.45" layer="51"/>
<rectangle x1="-23.31" y1="-11.95" x2="-22.89" y2="-11.45" layer="51"/>
<rectangle x1="-22.87" y1="-11.95" x2="-22.45" y2="-11.45" layer="51"/>
<rectangle x1="-22.43" y1="-11.95" x2="-22.01" y2="-11.45" layer="51"/>
<rectangle x1="-21.99" y1="-11.95" x2="-21.57" y2="-11.45" layer="51"/>
<rectangle x1="-21.55" y1="-11.95" x2="-21.13" y2="-11.45" layer="51"/>
<rectangle x1="-21.11" y1="-11.95" x2="-20.69" y2="-11.45" layer="51"/>
<rectangle x1="-20.67" y1="-11.95" x2="-20.25" y2="-11.45" layer="51"/>
<rectangle x1="-20.23" y1="-11.95" x2="-19.81" y2="-11.45" layer="51"/>
<rectangle x1="-19.79" y1="-11.95" x2="-19.37" y2="-11.45" layer="51"/>
<rectangle x1="-19.35" y1="-11.95" x2="-18.93" y2="-11.45" layer="51"/>
<rectangle x1="-18.91" y1="-11.95" x2="-18.49" y2="-11.45" layer="51"/>
<rectangle x1="-18.47" y1="-11.95" x2="-18.05" y2="-11.45" layer="51"/>
<rectangle x1="-18.03" y1="-11.95" x2="-17.61" y2="-11.45" layer="51"/>
<rectangle x1="-17.59" y1="-11.95" x2="-17.17" y2="-11.45" layer="51"/>
<rectangle x1="-17.15" y1="-11.95" x2="-16.73" y2="-11.45" layer="51"/>
<rectangle x1="-16.71" y1="-11.95" x2="-16.29" y2="-11.45" layer="51"/>
<rectangle x1="-16.27" y1="-11.95" x2="-15.85" y2="-11.45" layer="51"/>
<rectangle x1="-15.83" y1="-11.95" x2="-15.41" y2="-11.45" layer="51"/>
<rectangle x1="-15.39" y1="-11.95" x2="-14.97" y2="-11.45" layer="51"/>
<rectangle x1="-14.95" y1="-11.95" x2="-14.53" y2="-11.45" layer="51"/>
<rectangle x1="-14.51" y1="-11.95" x2="-14.09" y2="-11.45" layer="51"/>
<rectangle x1="-14.07" y1="-11.95" x2="-13.65" y2="-11.45" layer="51"/>
<rectangle x1="-13.63" y1="-11.95" x2="-13.21" y2="-11.45" layer="51"/>
<rectangle x1="-13.19" y1="-11.95" x2="-12.77" y2="-11.45" layer="51"/>
<rectangle x1="-12.75" y1="-11.95" x2="-12.33" y2="-11.45" layer="51"/>
<rectangle x1="-12.31" y1="-11.95" x2="-11.89" y2="-11.45" layer="51"/>
<rectangle x1="-11.87" y1="-11.95" x2="-11.45" y2="-11.45" layer="51"/>
<rectangle x1="-11.43" y1="-11.95" x2="-11.01" y2="-11.45" layer="51"/>
<rectangle x1="-10.99" y1="-11.95" x2="-10.57" y2="-11.45" layer="51"/>
<rectangle x1="-10.55" y1="-11.95" x2="-10.13" y2="-11.45" layer="51"/>
<rectangle x1="-10.11" y1="-11.95" x2="-9.69" y2="-11.45" layer="51"/>
<rectangle x1="-9.67" y1="-11.95" x2="-9.25" y2="-11.45" layer="51"/>
<rectangle x1="-9.23" y1="-11.95" x2="-8.81" y2="-11.45" layer="51"/>
<rectangle x1="-8.79" y1="-11.95" x2="-8.37" y2="-11.45" layer="51"/>
<rectangle x1="-8.35" y1="-11.95" x2="-7.93" y2="-11.45" layer="51"/>
<rectangle x1="-7.91" y1="-11.95" x2="-7.49" y2="-11.45" layer="51"/>
<rectangle x1="-7.47" y1="-11.95" x2="-7.05" y2="-11.45" layer="51"/>
<rectangle x1="-7.03" y1="-11.95" x2="-6.61" y2="-11.45" layer="51"/>
<rectangle x1="-6.59" y1="-11.95" x2="-6.17" y2="-11.45" layer="51"/>
<rectangle x1="-6.15" y1="-11.95" x2="-5.73" y2="-11.45" layer="51"/>
<rectangle x1="-5.71" y1="-11.95" x2="-5.29" y2="-11.45" layer="51"/>
<rectangle x1="-5.27" y1="-11.95" x2="-4.85" y2="-11.45" layer="51"/>
<rectangle x1="-4.83" y1="-11.95" x2="-4.41" y2="-11.45" layer="51"/>
<rectangle x1="-4.39" y1="-11.95" x2="-3.97" y2="-11.45" layer="51"/>
<rectangle x1="-3.95" y1="-11.95" x2="-3.53" y2="-11.45" layer="51"/>
<rectangle x1="-3.51" y1="-11.95" x2="-3.09" y2="-11.45" layer="51"/>
<rectangle x1="-3.07" y1="-11.95" x2="-2.65" y2="-11.45" layer="51"/>
<rectangle x1="-2.63" y1="-11.95" x2="-2.21" y2="-11.45" layer="51"/>
<rectangle x1="-2.19" y1="-11.95" x2="-1.77" y2="-11.45" layer="51"/>
<rectangle x1="-1.75" y1="-11.95" x2="-1.33" y2="-11.45" layer="51"/>
<rectangle x1="-1.31" y1="-11.95" x2="-0.89" y2="-11.45" layer="51"/>
<rectangle x1="-0.87" y1="-11.95" x2="-0.45" y2="-11.45" layer="51"/>
<rectangle x1="-0.43" y1="-11.95" x2="-0.01" y2="-11.45" layer="51"/>
<rectangle x1="0.01" y1="-11.95" x2="0.43" y2="-11.45" layer="51"/>
<rectangle x1="0.45" y1="-11.95" x2="0.87" y2="-11.45" layer="51"/>
<rectangle x1="0.89" y1="-11.95" x2="1.31" y2="-11.45" layer="51"/>
<rectangle x1="1.33" y1="-11.95" x2="1.75" y2="-11.45" layer="51"/>
<rectangle x1="1.77" y1="-11.95" x2="2.19" y2="-11.45" layer="51"/>
<rectangle x1="2.21" y1="-11.95" x2="2.63" y2="-11.45" layer="51"/>
<rectangle x1="2.65" y1="-11.95" x2="3.07" y2="-11.45" layer="51"/>
<rectangle x1="3.09" y1="-11.95" x2="3.51" y2="-11.45" layer="51"/>
<rectangle x1="3.53" y1="-11.95" x2="3.95" y2="-11.45" layer="51"/>
<rectangle x1="3.97" y1="-11.95" x2="4.39" y2="-11.45" layer="51"/>
<rectangle x1="4.41" y1="-11.95" x2="4.83" y2="-11.45" layer="51"/>
<rectangle x1="4.85" y1="-11.95" x2="5.27" y2="-11.45" layer="51"/>
<rectangle x1="5.29" y1="-11.95" x2="5.71" y2="-11.45" layer="51"/>
<rectangle x1="5.73" y1="-11.95" x2="6.15" y2="-11.45" layer="51"/>
<rectangle x1="6.17" y1="-11.95" x2="6.59" y2="-11.45" layer="51"/>
<rectangle x1="6.61" y1="-11.95" x2="7.03" y2="-11.45" layer="51"/>
<rectangle x1="7.05" y1="-11.95" x2="7.47" y2="-11.45" layer="51"/>
<rectangle x1="7.49" y1="-11.95" x2="7.91" y2="-11.45" layer="51"/>
<rectangle x1="7.93" y1="-11.95" x2="8.35" y2="-11.45" layer="51"/>
<rectangle x1="8.37" y1="-11.95" x2="8.79" y2="-11.45" layer="51"/>
<rectangle x1="8.81" y1="-11.95" x2="9.23" y2="-11.45" layer="51"/>
<rectangle x1="9.25" y1="-11.95" x2="9.67" y2="-11.45" layer="51"/>
<rectangle x1="9.69" y1="-11.95" x2="10.11" y2="-11.45" layer="51"/>
<rectangle x1="10.13" y1="-11.95" x2="10.55" y2="-11.45" layer="51"/>
<rectangle x1="10.57" y1="-11.95" x2="10.99" y2="-11.45" layer="51"/>
<rectangle x1="11.01" y1="-11.95" x2="11.43" y2="-11.45" layer="51"/>
<rectangle x1="11.45" y1="-11.95" x2="11.87" y2="-11.45" layer="51"/>
<rectangle x1="11.89" y1="-11.95" x2="12.31" y2="-11.45" layer="51"/>
<rectangle x1="12.33" y1="-11.95" x2="12.75" y2="-11.45" layer="51"/>
<rectangle x1="12.77" y1="-11.95" x2="13.19" y2="-11.45" layer="51"/>
<rectangle x1="13.21" y1="-11.95" x2="13.63" y2="-11.45" layer="51"/>
<rectangle x1="13.65" y1="-11.95" x2="14.07" y2="-11.45" layer="51"/>
<rectangle x1="14.09" y1="-11.95" x2="14.51" y2="-11.45" layer="51"/>
<rectangle x1="14.53" y1="-11.95" x2="14.95" y2="-11.45" layer="51"/>
<rectangle x1="14.97" y1="-11.95" x2="15.39" y2="-11.45" layer="51"/>
<rectangle x1="15.41" y1="-11.95" x2="15.83" y2="-11.45" layer="51"/>
<rectangle x1="15.85" y1="-11.95" x2="16.27" y2="-11.45" layer="51"/>
<rectangle x1="16.29" y1="-11.95" x2="16.71" y2="-11.45" layer="51"/>
<rectangle x1="16.73" y1="-11.95" x2="17.15" y2="-11.45" layer="51"/>
<rectangle x1="17.17" y1="-11.95" x2="17.59" y2="-11.45" layer="51"/>
<rectangle x1="17.61" y1="-11.95" x2="18.03" y2="-11.45" layer="51"/>
<rectangle x1="18.05" y1="-11.95" x2="18.47" y2="-11.45" layer="51"/>
<rectangle x1="18.49" y1="-11.95" x2="18.91" y2="-11.45" layer="51"/>
<rectangle x1="18.93" y1="-11.95" x2="19.35" y2="-11.45" layer="51"/>
<rectangle x1="19.37" y1="-11.95" x2="19.79" y2="-11.45" layer="51"/>
<rectangle x1="19.81" y1="-11.95" x2="20.23" y2="-11.45" layer="51"/>
<rectangle x1="20.25" y1="-11.95" x2="20.67" y2="-11.45" layer="51"/>
<rectangle x1="20.69" y1="-11.95" x2="21.11" y2="-11.45" layer="51"/>
<rectangle x1="21.13" y1="-11.95" x2="21.55" y2="-11.45" layer="51"/>
<rectangle x1="21.57" y1="-11.95" x2="21.99" y2="-11.45" layer="51"/>
<rectangle x1="22.01" y1="-11.95" x2="22.43" y2="-11.45" layer="51"/>
<rectangle x1="22.45" y1="-11.95" x2="22.87" y2="-11.45" layer="51"/>
<rectangle x1="22.89" y1="-11.95" x2="23.31" y2="-11.45" layer="51"/>
<rectangle x1="23.33" y1="-11.95" x2="23.75" y2="-11.45" layer="51"/>
<rectangle x1="23.77" y1="-11.95" x2="24.19" y2="-11.45" layer="51"/>
<rectangle x1="24.21" y1="-11.95" x2="24.63" y2="-11.45" layer="51"/>
<rectangle x1="24.65" y1="-11.95" x2="25.07" y2="-11.45" layer="51"/>
<rectangle x1="25.09" y1="-11.95" x2="25.51" y2="-11.45" layer="51"/>
<rectangle x1="25.53" y1="-11.95" x2="25.95" y2="-11.45" layer="51"/>
<rectangle x1="25.97" y1="-11.95" x2="26.39" y2="-11.45" layer="51"/>
<rectangle x1="26.41" y1="-11.95" x2="26.83" y2="-11.45" layer="51"/>
<rectangle x1="26.85" y1="-11.95" x2="27.27" y2="-11.45" layer="51"/>
<rectangle x1="27.29" y1="-11.95" x2="27.71" y2="-11.45" layer="51"/>
<rectangle x1="27.73" y1="-11.95" x2="28.15" y2="-11.45" layer="51"/>
<rectangle x1="-28.15" y1="-12.47" x2="-27.73" y2="-11.97" layer="51"/>
<rectangle x1="-27.71" y1="-12.47" x2="-27.29" y2="-11.97" layer="51"/>
<rectangle x1="-27.27" y1="-12.47" x2="-26.85" y2="-11.97" layer="51"/>
<rectangle x1="-26.83" y1="-12.47" x2="-26.41" y2="-11.97" layer="51"/>
<rectangle x1="-26.39" y1="-12.47" x2="-25.97" y2="-11.97" layer="51"/>
<rectangle x1="-25.95" y1="-12.47" x2="-25.53" y2="-11.97" layer="51"/>
<rectangle x1="-25.51" y1="-12.47" x2="-25.09" y2="-11.97" layer="51"/>
<rectangle x1="-25.07" y1="-12.47" x2="-24.65" y2="-11.97" layer="51"/>
<rectangle x1="-24.63" y1="-12.47" x2="-24.21" y2="-11.97" layer="51"/>
<rectangle x1="-24.19" y1="-12.47" x2="-23.77" y2="-11.97" layer="51"/>
<rectangle x1="-23.75" y1="-12.47" x2="-23.33" y2="-11.97" layer="51"/>
<rectangle x1="-23.31" y1="-12.47" x2="-22.89" y2="-11.97" layer="51"/>
<rectangle x1="-22.87" y1="-12.47" x2="-22.45" y2="-11.97" layer="51"/>
<rectangle x1="-22.43" y1="-12.47" x2="-22.01" y2="-11.97" layer="51"/>
<rectangle x1="-21.99" y1="-12.47" x2="-21.57" y2="-11.97" layer="51"/>
<rectangle x1="-21.55" y1="-12.47" x2="-21.13" y2="-11.97" layer="51"/>
<rectangle x1="-21.11" y1="-12.47" x2="-20.69" y2="-11.97" layer="51"/>
<rectangle x1="-20.67" y1="-12.47" x2="-20.25" y2="-11.97" layer="51"/>
<rectangle x1="-20.23" y1="-12.47" x2="-19.81" y2="-11.97" layer="51"/>
<rectangle x1="-19.79" y1="-12.47" x2="-19.37" y2="-11.97" layer="51"/>
<rectangle x1="-19.35" y1="-12.47" x2="-18.93" y2="-11.97" layer="51"/>
<rectangle x1="-18.91" y1="-12.47" x2="-18.49" y2="-11.97" layer="51"/>
<rectangle x1="-18.47" y1="-12.47" x2="-18.05" y2="-11.97" layer="51"/>
<rectangle x1="-18.03" y1="-12.47" x2="-17.61" y2="-11.97" layer="51"/>
<rectangle x1="-17.59" y1="-12.47" x2="-17.17" y2="-11.97" layer="51"/>
<rectangle x1="-17.15" y1="-12.47" x2="-16.73" y2="-11.97" layer="51"/>
<rectangle x1="-16.71" y1="-12.47" x2="-16.29" y2="-11.97" layer="51"/>
<rectangle x1="-16.27" y1="-12.47" x2="-15.85" y2="-11.97" layer="51"/>
<rectangle x1="-15.83" y1="-12.47" x2="-15.41" y2="-11.97" layer="51"/>
<rectangle x1="-15.39" y1="-12.47" x2="-14.97" y2="-11.97" layer="51"/>
<rectangle x1="-14.95" y1="-12.47" x2="-14.53" y2="-11.97" layer="51"/>
<rectangle x1="-14.51" y1="-12.47" x2="-14.09" y2="-11.97" layer="51"/>
<rectangle x1="-14.07" y1="-12.47" x2="-13.65" y2="-11.97" layer="51"/>
<rectangle x1="-13.63" y1="-12.47" x2="-13.21" y2="-11.97" layer="51"/>
<rectangle x1="-13.19" y1="-12.47" x2="-12.77" y2="-11.97" layer="51"/>
<rectangle x1="-12.75" y1="-12.47" x2="-12.33" y2="-11.97" layer="51"/>
<rectangle x1="-12.31" y1="-12.47" x2="-11.89" y2="-11.97" layer="51"/>
<rectangle x1="-11.87" y1="-12.47" x2="-11.45" y2="-11.97" layer="51"/>
<rectangle x1="-11.43" y1="-12.47" x2="-11.01" y2="-11.97" layer="51"/>
<rectangle x1="-10.99" y1="-12.47" x2="-10.57" y2="-11.97" layer="51"/>
<rectangle x1="-10.55" y1="-12.47" x2="-10.13" y2="-11.97" layer="51"/>
<rectangle x1="-10.11" y1="-12.47" x2="-9.69" y2="-11.97" layer="51"/>
<rectangle x1="-9.67" y1="-12.47" x2="-9.25" y2="-11.97" layer="51"/>
<rectangle x1="-9.23" y1="-12.47" x2="-8.81" y2="-11.97" layer="51"/>
<rectangle x1="-8.79" y1="-12.47" x2="-8.37" y2="-11.97" layer="51"/>
<rectangle x1="-8.35" y1="-12.47" x2="-7.93" y2="-11.97" layer="51"/>
<rectangle x1="-7.91" y1="-12.47" x2="-7.49" y2="-11.97" layer="51"/>
<rectangle x1="-7.47" y1="-12.47" x2="-7.05" y2="-11.97" layer="51"/>
<rectangle x1="-7.03" y1="-12.47" x2="-6.61" y2="-11.97" layer="51"/>
<rectangle x1="-6.59" y1="-12.47" x2="-6.17" y2="-11.97" layer="51"/>
<rectangle x1="-6.15" y1="-12.47" x2="-5.73" y2="-11.97" layer="51"/>
<rectangle x1="-5.71" y1="-12.47" x2="-5.29" y2="-11.97" layer="51"/>
<rectangle x1="-5.27" y1="-12.47" x2="-4.85" y2="-11.97" layer="51"/>
<rectangle x1="-4.83" y1="-12.47" x2="-4.41" y2="-11.97" layer="51"/>
<rectangle x1="-4.39" y1="-12.47" x2="-3.97" y2="-11.97" layer="51"/>
<rectangle x1="-3.95" y1="-12.47" x2="-3.53" y2="-11.97" layer="51"/>
<rectangle x1="-3.51" y1="-12.47" x2="-3.09" y2="-11.97" layer="51"/>
<rectangle x1="-3.07" y1="-12.47" x2="-2.65" y2="-11.97" layer="51"/>
<rectangle x1="-2.63" y1="-12.47" x2="-2.21" y2="-11.97" layer="51"/>
<rectangle x1="-2.19" y1="-12.47" x2="-1.77" y2="-11.97" layer="51"/>
<rectangle x1="-1.75" y1="-12.47" x2="-1.33" y2="-11.97" layer="51"/>
<rectangle x1="-1.31" y1="-12.47" x2="-0.89" y2="-11.97" layer="51"/>
<rectangle x1="-0.87" y1="-12.47" x2="-0.45" y2="-11.97" layer="51"/>
<rectangle x1="-0.43" y1="-12.47" x2="-0.01" y2="-11.97" layer="51"/>
<rectangle x1="0.01" y1="-12.47" x2="0.43" y2="-11.97" layer="51"/>
<rectangle x1="0.45" y1="-12.47" x2="0.87" y2="-11.97" layer="51"/>
<rectangle x1="0.89" y1="-12.47" x2="1.31" y2="-11.97" layer="51"/>
<rectangle x1="1.33" y1="-12.47" x2="1.75" y2="-11.97" layer="51"/>
<rectangle x1="1.77" y1="-12.47" x2="2.19" y2="-11.97" layer="51"/>
<rectangle x1="2.21" y1="-12.47" x2="2.63" y2="-11.97" layer="51"/>
<rectangle x1="2.65" y1="-12.47" x2="3.07" y2="-11.97" layer="51"/>
<rectangle x1="3.09" y1="-12.47" x2="3.51" y2="-11.97" layer="51"/>
<rectangle x1="3.53" y1="-12.47" x2="3.95" y2="-11.97" layer="51"/>
<rectangle x1="3.97" y1="-12.47" x2="4.39" y2="-11.97" layer="51"/>
<rectangle x1="4.41" y1="-12.47" x2="4.83" y2="-11.97" layer="51"/>
<rectangle x1="4.85" y1="-12.47" x2="5.27" y2="-11.97" layer="51"/>
<rectangle x1="5.29" y1="-12.47" x2="5.71" y2="-11.97" layer="51"/>
<rectangle x1="5.73" y1="-12.47" x2="6.15" y2="-11.97" layer="51"/>
<rectangle x1="6.17" y1="-12.47" x2="6.59" y2="-11.97" layer="51"/>
<rectangle x1="6.61" y1="-12.47" x2="7.03" y2="-11.97" layer="51"/>
<rectangle x1="7.05" y1="-12.47" x2="7.47" y2="-11.97" layer="51"/>
<rectangle x1="7.49" y1="-12.47" x2="7.91" y2="-11.97" layer="51"/>
<rectangle x1="7.93" y1="-12.47" x2="8.35" y2="-11.97" layer="51"/>
<rectangle x1="8.37" y1="-12.47" x2="8.79" y2="-11.97" layer="51"/>
<rectangle x1="8.81" y1="-12.47" x2="9.23" y2="-11.97" layer="51"/>
<rectangle x1="9.25" y1="-12.47" x2="9.67" y2="-11.97" layer="51"/>
<rectangle x1="9.69" y1="-12.47" x2="10.11" y2="-11.97" layer="51"/>
<rectangle x1="10.13" y1="-12.47" x2="10.55" y2="-11.97" layer="51"/>
<rectangle x1="10.57" y1="-12.47" x2="10.99" y2="-11.97" layer="51"/>
<rectangle x1="11.01" y1="-12.47" x2="11.43" y2="-11.97" layer="51"/>
<rectangle x1="11.45" y1="-12.47" x2="11.87" y2="-11.97" layer="51"/>
<rectangle x1="11.89" y1="-12.47" x2="12.31" y2="-11.97" layer="51"/>
<rectangle x1="12.33" y1="-12.47" x2="12.75" y2="-11.97" layer="51"/>
<rectangle x1="12.77" y1="-12.47" x2="13.19" y2="-11.97" layer="51"/>
<rectangle x1="13.21" y1="-12.47" x2="13.63" y2="-11.97" layer="51"/>
<rectangle x1="13.65" y1="-12.47" x2="14.07" y2="-11.97" layer="51"/>
<rectangle x1="14.09" y1="-12.47" x2="14.51" y2="-11.97" layer="51"/>
<rectangle x1="14.53" y1="-12.47" x2="14.95" y2="-11.97" layer="51"/>
<rectangle x1="14.97" y1="-12.47" x2="15.39" y2="-11.97" layer="51"/>
<rectangle x1="15.41" y1="-12.47" x2="15.83" y2="-11.97" layer="51"/>
<rectangle x1="15.85" y1="-12.47" x2="16.27" y2="-11.97" layer="51"/>
<rectangle x1="16.29" y1="-12.47" x2="16.71" y2="-11.97" layer="51"/>
<rectangle x1="16.73" y1="-12.47" x2="17.15" y2="-11.97" layer="51"/>
<rectangle x1="17.17" y1="-12.47" x2="17.59" y2="-11.97" layer="51"/>
<rectangle x1="17.61" y1="-12.47" x2="18.03" y2="-11.97" layer="51"/>
<rectangle x1="18.05" y1="-12.47" x2="18.47" y2="-11.97" layer="51"/>
<rectangle x1="18.49" y1="-12.47" x2="18.91" y2="-11.97" layer="51"/>
<rectangle x1="18.93" y1="-12.47" x2="19.35" y2="-11.97" layer="51"/>
<rectangle x1="19.37" y1="-12.47" x2="19.79" y2="-11.97" layer="51"/>
<rectangle x1="19.81" y1="-12.47" x2="20.23" y2="-11.97" layer="51"/>
<rectangle x1="20.25" y1="-12.47" x2="20.67" y2="-11.97" layer="51"/>
<rectangle x1="20.69" y1="-12.47" x2="21.11" y2="-11.97" layer="51"/>
<rectangle x1="21.13" y1="-12.47" x2="21.55" y2="-11.97" layer="51"/>
<rectangle x1="21.57" y1="-12.47" x2="21.99" y2="-11.97" layer="51"/>
<rectangle x1="22.01" y1="-12.47" x2="22.43" y2="-11.97" layer="51"/>
<rectangle x1="22.45" y1="-12.47" x2="22.87" y2="-11.97" layer="51"/>
<rectangle x1="22.89" y1="-12.47" x2="23.31" y2="-11.97" layer="51"/>
<rectangle x1="23.33" y1="-12.47" x2="23.75" y2="-11.97" layer="51"/>
<rectangle x1="23.77" y1="-12.47" x2="24.19" y2="-11.97" layer="51"/>
<rectangle x1="24.21" y1="-12.47" x2="24.63" y2="-11.97" layer="51"/>
<rectangle x1="24.65" y1="-12.47" x2="25.07" y2="-11.97" layer="51"/>
<rectangle x1="25.09" y1="-12.47" x2="25.51" y2="-11.97" layer="51"/>
<rectangle x1="25.53" y1="-12.47" x2="25.95" y2="-11.97" layer="51"/>
<rectangle x1="25.97" y1="-12.47" x2="26.39" y2="-11.97" layer="51"/>
<rectangle x1="26.41" y1="-12.47" x2="26.83" y2="-11.97" layer="51"/>
<rectangle x1="26.85" y1="-12.47" x2="27.27" y2="-11.97" layer="51"/>
<rectangle x1="27.29" y1="-12.47" x2="27.71" y2="-11.97" layer="51"/>
<rectangle x1="27.73" y1="-12.47" x2="28.15" y2="-11.97" layer="51"/>
<rectangle x1="-28.15" y1="-12.99" x2="-27.73" y2="-12.49" layer="51"/>
<rectangle x1="-27.71" y1="-12.99" x2="-27.29" y2="-12.49" layer="51"/>
<rectangle x1="-27.27" y1="-12.99" x2="-26.85" y2="-12.49" layer="51"/>
<rectangle x1="-26.83" y1="-12.99" x2="-26.41" y2="-12.49" layer="51"/>
<rectangle x1="-26.39" y1="-12.99" x2="-25.97" y2="-12.49" layer="51"/>
<rectangle x1="-25.95" y1="-12.99" x2="-25.53" y2="-12.49" layer="51"/>
<rectangle x1="-25.51" y1="-12.99" x2="-25.09" y2="-12.49" layer="51"/>
<rectangle x1="-25.07" y1="-12.99" x2="-24.65" y2="-12.49" layer="51"/>
<rectangle x1="-24.63" y1="-12.99" x2="-24.21" y2="-12.49" layer="51"/>
<rectangle x1="-24.19" y1="-12.99" x2="-23.77" y2="-12.49" layer="51"/>
<rectangle x1="-23.75" y1="-12.99" x2="-23.33" y2="-12.49" layer="51"/>
<rectangle x1="-23.31" y1="-12.99" x2="-22.89" y2="-12.49" layer="51"/>
<rectangle x1="-22.87" y1="-12.99" x2="-22.45" y2="-12.49" layer="51"/>
<rectangle x1="-22.43" y1="-12.99" x2="-22.01" y2="-12.49" layer="51"/>
<rectangle x1="-21.99" y1="-12.99" x2="-21.57" y2="-12.49" layer="51"/>
<rectangle x1="-21.55" y1="-12.99" x2="-21.13" y2="-12.49" layer="51"/>
<rectangle x1="-21.11" y1="-12.99" x2="-20.69" y2="-12.49" layer="51"/>
<rectangle x1="-20.67" y1="-12.99" x2="-20.25" y2="-12.49" layer="51"/>
<rectangle x1="-20.23" y1="-12.99" x2="-19.81" y2="-12.49" layer="51"/>
<rectangle x1="-19.79" y1="-12.99" x2="-19.37" y2="-12.49" layer="51"/>
<rectangle x1="-19.35" y1="-12.99" x2="-18.93" y2="-12.49" layer="51"/>
<rectangle x1="-18.91" y1="-12.99" x2="-18.49" y2="-12.49" layer="51"/>
<rectangle x1="-18.47" y1="-12.99" x2="-18.05" y2="-12.49" layer="51"/>
<rectangle x1="-18.03" y1="-12.99" x2="-17.61" y2="-12.49" layer="51"/>
<rectangle x1="-17.59" y1="-12.99" x2="-17.17" y2="-12.49" layer="51"/>
<rectangle x1="-17.15" y1="-12.99" x2="-16.73" y2="-12.49" layer="51"/>
<rectangle x1="-16.71" y1="-12.99" x2="-16.29" y2="-12.49" layer="51"/>
<rectangle x1="-16.27" y1="-12.99" x2="-15.85" y2="-12.49" layer="51"/>
<rectangle x1="-15.83" y1="-12.99" x2="-15.41" y2="-12.49" layer="51"/>
<rectangle x1="-15.39" y1="-12.99" x2="-14.97" y2="-12.49" layer="51"/>
<rectangle x1="-14.95" y1="-12.99" x2="-14.53" y2="-12.49" layer="51"/>
<rectangle x1="-14.51" y1="-12.99" x2="-14.09" y2="-12.49" layer="51"/>
<rectangle x1="-14.07" y1="-12.99" x2="-13.65" y2="-12.49" layer="51"/>
<rectangle x1="-13.63" y1="-12.99" x2="-13.21" y2="-12.49" layer="51"/>
<rectangle x1="-13.19" y1="-12.99" x2="-12.77" y2="-12.49" layer="51"/>
<rectangle x1="-12.75" y1="-12.99" x2="-12.33" y2="-12.49" layer="51"/>
<rectangle x1="-12.31" y1="-12.99" x2="-11.89" y2="-12.49" layer="51"/>
<rectangle x1="-11.87" y1="-12.99" x2="-11.45" y2="-12.49" layer="51"/>
<rectangle x1="-11.43" y1="-12.99" x2="-11.01" y2="-12.49" layer="51"/>
<rectangle x1="-10.99" y1="-12.99" x2="-10.57" y2="-12.49" layer="51"/>
<rectangle x1="-10.55" y1="-12.99" x2="-10.13" y2="-12.49" layer="51"/>
<rectangle x1="-10.11" y1="-12.99" x2="-9.69" y2="-12.49" layer="51"/>
<rectangle x1="-9.67" y1="-12.99" x2="-9.25" y2="-12.49" layer="51"/>
<rectangle x1="-9.23" y1="-12.99" x2="-8.81" y2="-12.49" layer="51"/>
<rectangle x1="-8.79" y1="-12.99" x2="-8.37" y2="-12.49" layer="51"/>
<rectangle x1="-8.35" y1="-12.99" x2="-7.93" y2="-12.49" layer="51"/>
<rectangle x1="-7.91" y1="-12.99" x2="-7.49" y2="-12.49" layer="51"/>
<rectangle x1="-7.47" y1="-12.99" x2="-7.05" y2="-12.49" layer="51"/>
<rectangle x1="-7.03" y1="-12.99" x2="-6.61" y2="-12.49" layer="51"/>
<rectangle x1="-6.59" y1="-12.99" x2="-6.17" y2="-12.49" layer="51"/>
<rectangle x1="-6.15" y1="-12.99" x2="-5.73" y2="-12.49" layer="51"/>
<rectangle x1="-5.71" y1="-12.99" x2="-5.29" y2="-12.49" layer="51"/>
<rectangle x1="-5.27" y1="-12.99" x2="-4.85" y2="-12.49" layer="51"/>
<rectangle x1="-4.83" y1="-12.99" x2="-4.41" y2="-12.49" layer="51"/>
<rectangle x1="-4.39" y1="-12.99" x2="-3.97" y2="-12.49" layer="51"/>
<rectangle x1="-3.95" y1="-12.99" x2="-3.53" y2="-12.49" layer="51"/>
<rectangle x1="-3.51" y1="-12.99" x2="-3.09" y2="-12.49" layer="51"/>
<rectangle x1="-3.07" y1="-12.99" x2="-2.65" y2="-12.49" layer="51"/>
<rectangle x1="-2.63" y1="-12.99" x2="-2.21" y2="-12.49" layer="51"/>
<rectangle x1="-2.19" y1="-12.99" x2="-1.77" y2="-12.49" layer="51"/>
<rectangle x1="-1.75" y1="-12.99" x2="-1.33" y2="-12.49" layer="51"/>
<rectangle x1="-1.31" y1="-12.99" x2="-0.89" y2="-12.49" layer="51"/>
<rectangle x1="-0.87" y1="-12.99" x2="-0.45" y2="-12.49" layer="51"/>
<rectangle x1="-0.43" y1="-12.99" x2="-0.01" y2="-12.49" layer="51"/>
<rectangle x1="0.01" y1="-12.99" x2="0.43" y2="-12.49" layer="51"/>
<rectangle x1="0.45" y1="-12.99" x2="0.87" y2="-12.49" layer="51"/>
<rectangle x1="0.89" y1="-12.99" x2="1.31" y2="-12.49" layer="51"/>
<rectangle x1="1.33" y1="-12.99" x2="1.75" y2="-12.49" layer="51"/>
<rectangle x1="1.77" y1="-12.99" x2="2.19" y2="-12.49" layer="51"/>
<rectangle x1="2.21" y1="-12.99" x2="2.63" y2="-12.49" layer="51"/>
<rectangle x1="2.65" y1="-12.99" x2="3.07" y2="-12.49" layer="51"/>
<rectangle x1="3.09" y1="-12.99" x2="3.51" y2="-12.49" layer="51"/>
<rectangle x1="3.53" y1="-12.99" x2="3.95" y2="-12.49" layer="51"/>
<rectangle x1="3.97" y1="-12.99" x2="4.39" y2="-12.49" layer="51"/>
<rectangle x1="4.41" y1="-12.99" x2="4.83" y2="-12.49" layer="51"/>
<rectangle x1="4.85" y1="-12.99" x2="5.27" y2="-12.49" layer="51"/>
<rectangle x1="5.29" y1="-12.99" x2="5.71" y2="-12.49" layer="51"/>
<rectangle x1="5.73" y1="-12.99" x2="6.15" y2="-12.49" layer="51"/>
<rectangle x1="6.17" y1="-12.99" x2="6.59" y2="-12.49" layer="51"/>
<rectangle x1="6.61" y1="-12.99" x2="7.03" y2="-12.49" layer="51"/>
<rectangle x1="7.05" y1="-12.99" x2="7.47" y2="-12.49" layer="51"/>
<rectangle x1="7.49" y1="-12.99" x2="7.91" y2="-12.49" layer="51"/>
<rectangle x1="7.93" y1="-12.99" x2="8.35" y2="-12.49" layer="51"/>
<rectangle x1="8.37" y1="-12.99" x2="8.79" y2="-12.49" layer="51"/>
<rectangle x1="8.81" y1="-12.99" x2="9.23" y2="-12.49" layer="51"/>
<rectangle x1="9.25" y1="-12.99" x2="9.67" y2="-12.49" layer="51"/>
<rectangle x1="9.69" y1="-12.99" x2="10.11" y2="-12.49" layer="51"/>
<rectangle x1="10.13" y1="-12.99" x2="10.55" y2="-12.49" layer="51"/>
<rectangle x1="10.57" y1="-12.99" x2="10.99" y2="-12.49" layer="51"/>
<rectangle x1="11.01" y1="-12.99" x2="11.43" y2="-12.49" layer="51"/>
<rectangle x1="11.45" y1="-12.99" x2="11.87" y2="-12.49" layer="51"/>
<rectangle x1="11.89" y1="-12.99" x2="12.31" y2="-12.49" layer="51"/>
<rectangle x1="12.33" y1="-12.99" x2="12.75" y2="-12.49" layer="51"/>
<rectangle x1="12.77" y1="-12.99" x2="13.19" y2="-12.49" layer="51"/>
<rectangle x1="13.21" y1="-12.99" x2="13.63" y2="-12.49" layer="51"/>
<rectangle x1="13.65" y1="-12.99" x2="14.07" y2="-12.49" layer="51"/>
<rectangle x1="14.09" y1="-12.99" x2="14.51" y2="-12.49" layer="51"/>
<rectangle x1="14.53" y1="-12.99" x2="14.95" y2="-12.49" layer="51"/>
<rectangle x1="14.97" y1="-12.99" x2="15.39" y2="-12.49" layer="51"/>
<rectangle x1="15.41" y1="-12.99" x2="15.83" y2="-12.49" layer="51"/>
<rectangle x1="15.85" y1="-12.99" x2="16.27" y2="-12.49" layer="51"/>
<rectangle x1="16.29" y1="-12.99" x2="16.71" y2="-12.49" layer="51"/>
<rectangle x1="16.73" y1="-12.99" x2="17.15" y2="-12.49" layer="51"/>
<rectangle x1="17.17" y1="-12.99" x2="17.59" y2="-12.49" layer="51"/>
<rectangle x1="17.61" y1="-12.99" x2="18.03" y2="-12.49" layer="51"/>
<rectangle x1="18.05" y1="-12.99" x2="18.47" y2="-12.49" layer="51"/>
<rectangle x1="18.49" y1="-12.99" x2="18.91" y2="-12.49" layer="51"/>
<rectangle x1="18.93" y1="-12.99" x2="19.35" y2="-12.49" layer="51"/>
<rectangle x1="19.37" y1="-12.99" x2="19.79" y2="-12.49" layer="51"/>
<rectangle x1="19.81" y1="-12.99" x2="20.23" y2="-12.49" layer="51"/>
<rectangle x1="20.25" y1="-12.99" x2="20.67" y2="-12.49" layer="51"/>
<rectangle x1="20.69" y1="-12.99" x2="21.11" y2="-12.49" layer="51"/>
<rectangle x1="21.13" y1="-12.99" x2="21.55" y2="-12.49" layer="51"/>
<rectangle x1="21.57" y1="-12.99" x2="21.99" y2="-12.49" layer="51"/>
<rectangle x1="22.01" y1="-12.99" x2="22.43" y2="-12.49" layer="51"/>
<rectangle x1="22.45" y1="-12.99" x2="22.87" y2="-12.49" layer="51"/>
<rectangle x1="22.89" y1="-12.99" x2="23.31" y2="-12.49" layer="51"/>
<rectangle x1="23.33" y1="-12.99" x2="23.75" y2="-12.49" layer="51"/>
<rectangle x1="23.77" y1="-12.99" x2="24.19" y2="-12.49" layer="51"/>
<rectangle x1="24.21" y1="-12.99" x2="24.63" y2="-12.49" layer="51"/>
<rectangle x1="24.65" y1="-12.99" x2="25.07" y2="-12.49" layer="51"/>
<rectangle x1="25.09" y1="-12.99" x2="25.51" y2="-12.49" layer="51"/>
<rectangle x1="25.53" y1="-12.99" x2="25.95" y2="-12.49" layer="51"/>
<rectangle x1="25.97" y1="-12.99" x2="26.39" y2="-12.49" layer="51"/>
<rectangle x1="26.41" y1="-12.99" x2="26.83" y2="-12.49" layer="51"/>
<rectangle x1="26.85" y1="-12.99" x2="27.27" y2="-12.49" layer="51"/>
<rectangle x1="27.29" y1="-12.99" x2="27.71" y2="-12.49" layer="51"/>
<rectangle x1="27.73" y1="-12.99" x2="28.15" y2="-12.49" layer="51"/>
<rectangle x1="-28.15" y1="-13.51" x2="-27.73" y2="-13.01" layer="51"/>
<rectangle x1="-27.71" y1="-13.51" x2="-27.29" y2="-13.01" layer="51"/>
<rectangle x1="-27.27" y1="-13.51" x2="-26.85" y2="-13.01" layer="51"/>
<rectangle x1="-26.83" y1="-13.51" x2="-26.41" y2="-13.01" layer="51"/>
<rectangle x1="-26.39" y1="-13.51" x2="-25.97" y2="-13.01" layer="51"/>
<rectangle x1="-25.95" y1="-13.51" x2="-25.53" y2="-13.01" layer="51"/>
<rectangle x1="-25.51" y1="-13.51" x2="-25.09" y2="-13.01" layer="51"/>
<rectangle x1="-25.07" y1="-13.51" x2="-24.65" y2="-13.01" layer="51"/>
<rectangle x1="-24.63" y1="-13.51" x2="-24.21" y2="-13.01" layer="51"/>
<rectangle x1="-24.19" y1="-13.51" x2="-23.77" y2="-13.01" layer="51"/>
<rectangle x1="-23.75" y1="-13.51" x2="-23.33" y2="-13.01" layer="51"/>
<rectangle x1="-23.31" y1="-13.51" x2="-22.89" y2="-13.01" layer="51"/>
<rectangle x1="-22.87" y1="-13.51" x2="-22.45" y2="-13.01" layer="51"/>
<rectangle x1="-22.43" y1="-13.51" x2="-22.01" y2="-13.01" layer="51"/>
<rectangle x1="-21.99" y1="-13.51" x2="-21.57" y2="-13.01" layer="51"/>
<rectangle x1="-21.55" y1="-13.51" x2="-21.13" y2="-13.01" layer="51"/>
<rectangle x1="-21.11" y1="-13.51" x2="-20.69" y2="-13.01" layer="51"/>
<rectangle x1="-20.67" y1="-13.51" x2="-20.25" y2="-13.01" layer="51"/>
<rectangle x1="-20.23" y1="-13.51" x2="-19.81" y2="-13.01" layer="51"/>
<rectangle x1="-19.79" y1="-13.51" x2="-19.37" y2="-13.01" layer="51"/>
<rectangle x1="-19.35" y1="-13.51" x2="-18.93" y2="-13.01" layer="51"/>
<rectangle x1="-18.91" y1="-13.51" x2="-18.49" y2="-13.01" layer="51"/>
<rectangle x1="-18.47" y1="-13.51" x2="-18.05" y2="-13.01" layer="51"/>
<rectangle x1="-18.03" y1="-13.51" x2="-17.61" y2="-13.01" layer="51"/>
<rectangle x1="-17.59" y1="-13.51" x2="-17.17" y2="-13.01" layer="51"/>
<rectangle x1="-17.15" y1="-13.51" x2="-16.73" y2="-13.01" layer="51"/>
<rectangle x1="-16.71" y1="-13.51" x2="-16.29" y2="-13.01" layer="51"/>
<rectangle x1="-16.27" y1="-13.51" x2="-15.85" y2="-13.01" layer="51"/>
<rectangle x1="-15.83" y1="-13.51" x2="-15.41" y2="-13.01" layer="51"/>
<rectangle x1="-15.39" y1="-13.51" x2="-14.97" y2="-13.01" layer="51"/>
<rectangle x1="-14.95" y1="-13.51" x2="-14.53" y2="-13.01" layer="51"/>
<rectangle x1="-14.51" y1="-13.51" x2="-14.09" y2="-13.01" layer="51"/>
<rectangle x1="-14.07" y1="-13.51" x2="-13.65" y2="-13.01" layer="51"/>
<rectangle x1="-13.63" y1="-13.51" x2="-13.21" y2="-13.01" layer="51"/>
<rectangle x1="-13.19" y1="-13.51" x2="-12.77" y2="-13.01" layer="51"/>
<rectangle x1="-12.75" y1="-13.51" x2="-12.33" y2="-13.01" layer="51"/>
<rectangle x1="-12.31" y1="-13.51" x2="-11.89" y2="-13.01" layer="51"/>
<rectangle x1="-11.87" y1="-13.51" x2="-11.45" y2="-13.01" layer="51"/>
<rectangle x1="-11.43" y1="-13.51" x2="-11.01" y2="-13.01" layer="51"/>
<rectangle x1="-10.99" y1="-13.51" x2="-10.57" y2="-13.01" layer="51"/>
<rectangle x1="-10.55" y1="-13.51" x2="-10.13" y2="-13.01" layer="51"/>
<rectangle x1="-10.11" y1="-13.51" x2="-9.69" y2="-13.01" layer="51"/>
<rectangle x1="-9.67" y1="-13.51" x2="-9.25" y2="-13.01" layer="51"/>
<rectangle x1="-9.23" y1="-13.51" x2="-8.81" y2="-13.01" layer="51"/>
<rectangle x1="-8.79" y1="-13.51" x2="-8.37" y2="-13.01" layer="51"/>
<rectangle x1="-8.35" y1="-13.51" x2="-7.93" y2="-13.01" layer="51"/>
<rectangle x1="-7.91" y1="-13.51" x2="-7.49" y2="-13.01" layer="51"/>
<rectangle x1="-7.47" y1="-13.51" x2="-7.05" y2="-13.01" layer="51"/>
<rectangle x1="-7.03" y1="-13.51" x2="-6.61" y2="-13.01" layer="51"/>
<rectangle x1="-6.59" y1="-13.51" x2="-6.17" y2="-13.01" layer="51"/>
<rectangle x1="-6.15" y1="-13.51" x2="-5.73" y2="-13.01" layer="51"/>
<rectangle x1="-5.71" y1="-13.51" x2="-5.29" y2="-13.01" layer="51"/>
<rectangle x1="-5.27" y1="-13.51" x2="-4.85" y2="-13.01" layer="51"/>
<rectangle x1="-4.83" y1="-13.51" x2="-4.41" y2="-13.01" layer="51"/>
<rectangle x1="-4.39" y1="-13.51" x2="-3.97" y2="-13.01" layer="51"/>
<rectangle x1="-3.95" y1="-13.51" x2="-3.53" y2="-13.01" layer="51"/>
<rectangle x1="-3.51" y1="-13.51" x2="-3.09" y2="-13.01" layer="51"/>
<rectangle x1="-3.07" y1="-13.51" x2="-2.65" y2="-13.01" layer="51"/>
<rectangle x1="-2.63" y1="-13.51" x2="-2.21" y2="-13.01" layer="51"/>
<rectangle x1="-2.19" y1="-13.51" x2="-1.77" y2="-13.01" layer="51"/>
<rectangle x1="-1.75" y1="-13.51" x2="-1.33" y2="-13.01" layer="51"/>
<rectangle x1="-1.31" y1="-13.51" x2="-0.89" y2="-13.01" layer="51"/>
<rectangle x1="-0.87" y1="-13.51" x2="-0.45" y2="-13.01" layer="51"/>
<rectangle x1="-0.43" y1="-13.51" x2="-0.01" y2="-13.01" layer="51"/>
<rectangle x1="0.01" y1="-13.51" x2="0.43" y2="-13.01" layer="51"/>
<rectangle x1="0.45" y1="-13.51" x2="0.87" y2="-13.01" layer="51"/>
<rectangle x1="0.89" y1="-13.51" x2="1.31" y2="-13.01" layer="51"/>
<rectangle x1="1.33" y1="-13.51" x2="1.75" y2="-13.01" layer="51"/>
<rectangle x1="1.77" y1="-13.51" x2="2.19" y2="-13.01" layer="51"/>
<rectangle x1="2.21" y1="-13.51" x2="2.63" y2="-13.01" layer="51"/>
<rectangle x1="2.65" y1="-13.51" x2="3.07" y2="-13.01" layer="51"/>
<rectangle x1="3.09" y1="-13.51" x2="3.51" y2="-13.01" layer="51"/>
<rectangle x1="3.53" y1="-13.51" x2="3.95" y2="-13.01" layer="51"/>
<rectangle x1="3.97" y1="-13.51" x2="4.39" y2="-13.01" layer="51"/>
<rectangle x1="4.41" y1="-13.51" x2="4.83" y2="-13.01" layer="51"/>
<rectangle x1="4.85" y1="-13.51" x2="5.27" y2="-13.01" layer="51"/>
<rectangle x1="5.29" y1="-13.51" x2="5.71" y2="-13.01" layer="51"/>
<rectangle x1="5.73" y1="-13.51" x2="6.15" y2="-13.01" layer="51"/>
<rectangle x1="6.17" y1="-13.51" x2="6.59" y2="-13.01" layer="51"/>
<rectangle x1="6.61" y1="-13.51" x2="7.03" y2="-13.01" layer="51"/>
<rectangle x1="7.05" y1="-13.51" x2="7.47" y2="-13.01" layer="51"/>
<rectangle x1="7.49" y1="-13.51" x2="7.91" y2="-13.01" layer="51"/>
<rectangle x1="7.93" y1="-13.51" x2="8.35" y2="-13.01" layer="51"/>
<rectangle x1="8.37" y1="-13.51" x2="8.79" y2="-13.01" layer="51"/>
<rectangle x1="8.81" y1="-13.51" x2="9.23" y2="-13.01" layer="51"/>
<rectangle x1="9.25" y1="-13.51" x2="9.67" y2="-13.01" layer="51"/>
<rectangle x1="9.69" y1="-13.51" x2="10.11" y2="-13.01" layer="51"/>
<rectangle x1="10.13" y1="-13.51" x2="10.55" y2="-13.01" layer="51"/>
<rectangle x1="10.57" y1="-13.51" x2="10.99" y2="-13.01" layer="51"/>
<rectangle x1="11.01" y1="-13.51" x2="11.43" y2="-13.01" layer="51"/>
<rectangle x1="11.45" y1="-13.51" x2="11.87" y2="-13.01" layer="51"/>
<rectangle x1="11.89" y1="-13.51" x2="12.31" y2="-13.01" layer="51"/>
<rectangle x1="12.33" y1="-13.51" x2="12.75" y2="-13.01" layer="51"/>
<rectangle x1="12.77" y1="-13.51" x2="13.19" y2="-13.01" layer="51"/>
<rectangle x1="13.21" y1="-13.51" x2="13.63" y2="-13.01" layer="51"/>
<rectangle x1="13.65" y1="-13.51" x2="14.07" y2="-13.01" layer="51"/>
<rectangle x1="14.09" y1="-13.51" x2="14.51" y2="-13.01" layer="51"/>
<rectangle x1="14.53" y1="-13.51" x2="14.95" y2="-13.01" layer="51"/>
<rectangle x1="14.97" y1="-13.51" x2="15.39" y2="-13.01" layer="51"/>
<rectangle x1="15.41" y1="-13.51" x2="15.83" y2="-13.01" layer="51"/>
<rectangle x1="15.85" y1="-13.51" x2="16.27" y2="-13.01" layer="51"/>
<rectangle x1="16.29" y1="-13.51" x2="16.71" y2="-13.01" layer="51"/>
<rectangle x1="16.73" y1="-13.51" x2="17.15" y2="-13.01" layer="51"/>
<rectangle x1="17.17" y1="-13.51" x2="17.59" y2="-13.01" layer="51"/>
<rectangle x1="17.61" y1="-13.51" x2="18.03" y2="-13.01" layer="51"/>
<rectangle x1="18.05" y1="-13.51" x2="18.47" y2="-13.01" layer="51"/>
<rectangle x1="18.49" y1="-13.51" x2="18.91" y2="-13.01" layer="51"/>
<rectangle x1="18.93" y1="-13.51" x2="19.35" y2="-13.01" layer="51"/>
<rectangle x1="19.37" y1="-13.51" x2="19.79" y2="-13.01" layer="51"/>
<rectangle x1="19.81" y1="-13.51" x2="20.23" y2="-13.01" layer="51"/>
<rectangle x1="20.25" y1="-13.51" x2="20.67" y2="-13.01" layer="51"/>
<rectangle x1="20.69" y1="-13.51" x2="21.11" y2="-13.01" layer="51"/>
<rectangle x1="21.13" y1="-13.51" x2="21.55" y2="-13.01" layer="51"/>
<rectangle x1="21.57" y1="-13.51" x2="21.99" y2="-13.01" layer="51"/>
<rectangle x1="22.01" y1="-13.51" x2="22.43" y2="-13.01" layer="51"/>
<rectangle x1="22.45" y1="-13.51" x2="22.87" y2="-13.01" layer="51"/>
<rectangle x1="22.89" y1="-13.51" x2="23.31" y2="-13.01" layer="51"/>
<rectangle x1="23.33" y1="-13.51" x2="23.75" y2="-13.01" layer="51"/>
<rectangle x1="23.77" y1="-13.51" x2="24.19" y2="-13.01" layer="51"/>
<rectangle x1="24.21" y1="-13.51" x2="24.63" y2="-13.01" layer="51"/>
<rectangle x1="24.65" y1="-13.51" x2="25.07" y2="-13.01" layer="51"/>
<rectangle x1="25.09" y1="-13.51" x2="25.51" y2="-13.01" layer="51"/>
<rectangle x1="25.53" y1="-13.51" x2="25.95" y2="-13.01" layer="51"/>
<rectangle x1="25.97" y1="-13.51" x2="26.39" y2="-13.01" layer="51"/>
<rectangle x1="26.41" y1="-13.51" x2="26.83" y2="-13.01" layer="51"/>
<rectangle x1="26.85" y1="-13.51" x2="27.27" y2="-13.01" layer="51"/>
<rectangle x1="27.29" y1="-13.51" x2="27.71" y2="-13.01" layer="51"/>
<rectangle x1="27.73" y1="-13.51" x2="28.15" y2="-13.01" layer="51"/>
<rectangle x1="-28.15" y1="-14.03" x2="-27.73" y2="-13.53" layer="51"/>
<rectangle x1="-27.71" y1="-14.03" x2="-27.29" y2="-13.53" layer="51"/>
<rectangle x1="-27.27" y1="-14.03" x2="-26.85" y2="-13.53" layer="51"/>
<rectangle x1="-26.83" y1="-14.03" x2="-26.41" y2="-13.53" layer="51"/>
<rectangle x1="-26.39" y1="-14.03" x2="-25.97" y2="-13.53" layer="51"/>
<rectangle x1="-25.95" y1="-14.03" x2="-25.53" y2="-13.53" layer="51"/>
<rectangle x1="-25.51" y1="-14.03" x2="-25.09" y2="-13.53" layer="51"/>
<rectangle x1="-25.07" y1="-14.03" x2="-24.65" y2="-13.53" layer="51"/>
<rectangle x1="-24.63" y1="-14.03" x2="-24.21" y2="-13.53" layer="51"/>
<rectangle x1="-24.19" y1="-14.03" x2="-23.77" y2="-13.53" layer="51"/>
<rectangle x1="-23.75" y1="-14.03" x2="-23.33" y2="-13.53" layer="51"/>
<rectangle x1="-23.31" y1="-14.03" x2="-22.89" y2="-13.53" layer="51"/>
<rectangle x1="-22.87" y1="-14.03" x2="-22.45" y2="-13.53" layer="51"/>
<rectangle x1="-22.43" y1="-14.03" x2="-22.01" y2="-13.53" layer="51"/>
<rectangle x1="-21.99" y1="-14.03" x2="-21.57" y2="-13.53" layer="51"/>
<rectangle x1="-21.55" y1="-14.03" x2="-21.13" y2="-13.53" layer="51"/>
<rectangle x1="-21.11" y1="-14.03" x2="-20.69" y2="-13.53" layer="51"/>
<rectangle x1="-20.67" y1="-14.03" x2="-20.25" y2="-13.53" layer="51"/>
<rectangle x1="-20.23" y1="-14.03" x2="-19.81" y2="-13.53" layer="51"/>
<rectangle x1="-19.79" y1="-14.03" x2="-19.37" y2="-13.53" layer="51"/>
<rectangle x1="-19.35" y1="-14.03" x2="-18.93" y2="-13.53" layer="51"/>
<rectangle x1="-18.91" y1="-14.03" x2="-18.49" y2="-13.53" layer="51"/>
<rectangle x1="-18.47" y1="-14.03" x2="-18.05" y2="-13.53" layer="51"/>
<rectangle x1="-18.03" y1="-14.03" x2="-17.61" y2="-13.53" layer="51"/>
<rectangle x1="-17.59" y1="-14.03" x2="-17.17" y2="-13.53" layer="51"/>
<rectangle x1="-17.15" y1="-14.03" x2="-16.73" y2="-13.53" layer="51"/>
<rectangle x1="-16.71" y1="-14.03" x2="-16.29" y2="-13.53" layer="51"/>
<rectangle x1="-16.27" y1="-14.03" x2="-15.85" y2="-13.53" layer="51"/>
<rectangle x1="-15.83" y1="-14.03" x2="-15.41" y2="-13.53" layer="51"/>
<rectangle x1="-15.39" y1="-14.03" x2="-14.97" y2="-13.53" layer="51"/>
<rectangle x1="-14.95" y1="-14.03" x2="-14.53" y2="-13.53" layer="51"/>
<rectangle x1="-14.51" y1="-14.03" x2="-14.09" y2="-13.53" layer="51"/>
<rectangle x1="-14.07" y1="-14.03" x2="-13.65" y2="-13.53" layer="51"/>
<rectangle x1="-13.63" y1="-14.03" x2="-13.21" y2="-13.53" layer="51"/>
<rectangle x1="-13.19" y1="-14.03" x2="-12.77" y2="-13.53" layer="51"/>
<rectangle x1="-12.75" y1="-14.03" x2="-12.33" y2="-13.53" layer="51"/>
<rectangle x1="-12.31" y1="-14.03" x2="-11.89" y2="-13.53" layer="51"/>
<rectangle x1="-11.87" y1="-14.03" x2="-11.45" y2="-13.53" layer="51"/>
<rectangle x1="-11.43" y1="-14.03" x2="-11.01" y2="-13.53" layer="51"/>
<rectangle x1="-10.99" y1="-14.03" x2="-10.57" y2="-13.53" layer="51"/>
<rectangle x1="-10.55" y1="-14.03" x2="-10.13" y2="-13.53" layer="51"/>
<rectangle x1="-10.11" y1="-14.03" x2="-9.69" y2="-13.53" layer="51"/>
<rectangle x1="-9.67" y1="-14.03" x2="-9.25" y2="-13.53" layer="51"/>
<rectangle x1="-9.23" y1="-14.03" x2="-8.81" y2="-13.53" layer="51"/>
<rectangle x1="-8.79" y1="-14.03" x2="-8.37" y2="-13.53" layer="51"/>
<rectangle x1="-8.35" y1="-14.03" x2="-7.93" y2="-13.53" layer="51"/>
<rectangle x1="-7.91" y1="-14.03" x2="-7.49" y2="-13.53" layer="51"/>
<rectangle x1="-7.47" y1="-14.03" x2="-7.05" y2="-13.53" layer="51"/>
<rectangle x1="-7.03" y1="-14.03" x2="-6.61" y2="-13.53" layer="51"/>
<rectangle x1="-6.59" y1="-14.03" x2="-6.17" y2="-13.53" layer="51"/>
<rectangle x1="-6.15" y1="-14.03" x2="-5.73" y2="-13.53" layer="51"/>
<rectangle x1="-5.71" y1="-14.03" x2="-5.29" y2="-13.53" layer="51"/>
<rectangle x1="-5.27" y1="-14.03" x2="-4.85" y2="-13.53" layer="51"/>
<rectangle x1="-4.83" y1="-14.03" x2="-4.41" y2="-13.53" layer="51"/>
<rectangle x1="-4.39" y1="-14.03" x2="-3.97" y2="-13.53" layer="51"/>
<rectangle x1="-3.95" y1="-14.03" x2="-3.53" y2="-13.53" layer="51"/>
<rectangle x1="-3.51" y1="-14.03" x2="-3.09" y2="-13.53" layer="51"/>
<rectangle x1="-3.07" y1="-14.03" x2="-2.65" y2="-13.53" layer="51"/>
<rectangle x1="-2.63" y1="-14.03" x2="-2.21" y2="-13.53" layer="51"/>
<rectangle x1="-2.19" y1="-14.03" x2="-1.77" y2="-13.53" layer="51"/>
<rectangle x1="-1.75" y1="-14.03" x2="-1.33" y2="-13.53" layer="51"/>
<rectangle x1="-1.31" y1="-14.03" x2="-0.89" y2="-13.53" layer="51"/>
<rectangle x1="-0.87" y1="-14.03" x2="-0.45" y2="-13.53" layer="51"/>
<rectangle x1="-0.43" y1="-14.03" x2="-0.01" y2="-13.53" layer="51"/>
<rectangle x1="0.01" y1="-14.03" x2="0.43" y2="-13.53" layer="51"/>
<rectangle x1="0.45" y1="-14.03" x2="0.87" y2="-13.53" layer="51"/>
<rectangle x1="0.89" y1="-14.03" x2="1.31" y2="-13.53" layer="51"/>
<rectangle x1="1.33" y1="-14.03" x2="1.75" y2="-13.53" layer="51"/>
<rectangle x1="1.77" y1="-14.03" x2="2.19" y2="-13.53" layer="51"/>
<rectangle x1="2.21" y1="-14.03" x2="2.63" y2="-13.53" layer="51"/>
<rectangle x1="2.65" y1="-14.03" x2="3.07" y2="-13.53" layer="51"/>
<rectangle x1="3.09" y1="-14.03" x2="3.51" y2="-13.53" layer="51"/>
<rectangle x1="3.53" y1="-14.03" x2="3.95" y2="-13.53" layer="51"/>
<rectangle x1="3.97" y1="-14.03" x2="4.39" y2="-13.53" layer="51"/>
<rectangle x1="4.41" y1="-14.03" x2="4.83" y2="-13.53" layer="51"/>
<rectangle x1="4.85" y1="-14.03" x2="5.27" y2="-13.53" layer="51"/>
<rectangle x1="5.29" y1="-14.03" x2="5.71" y2="-13.53" layer="51"/>
<rectangle x1="5.73" y1="-14.03" x2="6.15" y2="-13.53" layer="51"/>
<rectangle x1="6.17" y1="-14.03" x2="6.59" y2="-13.53" layer="51"/>
<rectangle x1="6.61" y1="-14.03" x2="7.03" y2="-13.53" layer="51"/>
<rectangle x1="7.05" y1="-14.03" x2="7.47" y2="-13.53" layer="51"/>
<rectangle x1="7.49" y1="-14.03" x2="7.91" y2="-13.53" layer="51"/>
<rectangle x1="7.93" y1="-14.03" x2="8.35" y2="-13.53" layer="51"/>
<rectangle x1="8.37" y1="-14.03" x2="8.79" y2="-13.53" layer="51"/>
<rectangle x1="8.81" y1="-14.03" x2="9.23" y2="-13.53" layer="51"/>
<rectangle x1="9.25" y1="-14.03" x2="9.67" y2="-13.53" layer="51"/>
<rectangle x1="9.69" y1="-14.03" x2="10.11" y2="-13.53" layer="51"/>
<rectangle x1="10.13" y1="-14.03" x2="10.55" y2="-13.53" layer="51"/>
<rectangle x1="10.57" y1="-14.03" x2="10.99" y2="-13.53" layer="51"/>
<rectangle x1="11.01" y1="-14.03" x2="11.43" y2="-13.53" layer="51"/>
<rectangle x1="11.45" y1="-14.03" x2="11.87" y2="-13.53" layer="51"/>
<rectangle x1="11.89" y1="-14.03" x2="12.31" y2="-13.53" layer="51"/>
<rectangle x1="12.33" y1="-14.03" x2="12.75" y2="-13.53" layer="51"/>
<rectangle x1="12.77" y1="-14.03" x2="13.19" y2="-13.53" layer="51"/>
<rectangle x1="13.21" y1="-14.03" x2="13.63" y2="-13.53" layer="51"/>
<rectangle x1="13.65" y1="-14.03" x2="14.07" y2="-13.53" layer="51"/>
<rectangle x1="14.09" y1="-14.03" x2="14.51" y2="-13.53" layer="51"/>
<rectangle x1="14.53" y1="-14.03" x2="14.95" y2="-13.53" layer="51"/>
<rectangle x1="14.97" y1="-14.03" x2="15.39" y2="-13.53" layer="51"/>
<rectangle x1="15.41" y1="-14.03" x2="15.83" y2="-13.53" layer="51"/>
<rectangle x1="15.85" y1="-14.03" x2="16.27" y2="-13.53" layer="51"/>
<rectangle x1="16.29" y1="-14.03" x2="16.71" y2="-13.53" layer="51"/>
<rectangle x1="16.73" y1="-14.03" x2="17.15" y2="-13.53" layer="51"/>
<rectangle x1="17.17" y1="-14.03" x2="17.59" y2="-13.53" layer="51"/>
<rectangle x1="17.61" y1="-14.03" x2="18.03" y2="-13.53" layer="51"/>
<rectangle x1="18.05" y1="-14.03" x2="18.47" y2="-13.53" layer="51"/>
<rectangle x1="18.49" y1="-14.03" x2="18.91" y2="-13.53" layer="51"/>
<rectangle x1="18.93" y1="-14.03" x2="19.35" y2="-13.53" layer="51"/>
<rectangle x1="19.37" y1="-14.03" x2="19.79" y2="-13.53" layer="51"/>
<rectangle x1="19.81" y1="-14.03" x2="20.23" y2="-13.53" layer="51"/>
<rectangle x1="20.25" y1="-14.03" x2="20.67" y2="-13.53" layer="51"/>
<rectangle x1="20.69" y1="-14.03" x2="21.11" y2="-13.53" layer="51"/>
<rectangle x1="21.13" y1="-14.03" x2="21.55" y2="-13.53" layer="51"/>
<rectangle x1="21.57" y1="-14.03" x2="21.99" y2="-13.53" layer="51"/>
<rectangle x1="22.01" y1="-14.03" x2="22.43" y2="-13.53" layer="51"/>
<rectangle x1="22.45" y1="-14.03" x2="22.87" y2="-13.53" layer="51"/>
<rectangle x1="22.89" y1="-14.03" x2="23.31" y2="-13.53" layer="51"/>
<rectangle x1="23.33" y1="-14.03" x2="23.75" y2="-13.53" layer="51"/>
<rectangle x1="23.77" y1="-14.03" x2="24.19" y2="-13.53" layer="51"/>
<rectangle x1="24.21" y1="-14.03" x2="24.63" y2="-13.53" layer="51"/>
<rectangle x1="24.65" y1="-14.03" x2="25.07" y2="-13.53" layer="51"/>
<rectangle x1="25.09" y1="-14.03" x2="25.51" y2="-13.53" layer="51"/>
<rectangle x1="25.53" y1="-14.03" x2="25.95" y2="-13.53" layer="51"/>
<rectangle x1="25.97" y1="-14.03" x2="26.39" y2="-13.53" layer="51"/>
<rectangle x1="26.41" y1="-14.03" x2="26.83" y2="-13.53" layer="51"/>
<rectangle x1="26.85" y1="-14.03" x2="27.27" y2="-13.53" layer="51"/>
<rectangle x1="27.29" y1="-14.03" x2="27.71" y2="-13.53" layer="51"/>
<rectangle x1="27.73" y1="-14.03" x2="28.15" y2="-13.53" layer="51"/>
<rectangle x1="-28.15" y1="-14.55" x2="-27.73" y2="-14.05" layer="51"/>
<rectangle x1="-27.71" y1="-14.55" x2="-27.29" y2="-14.05" layer="51"/>
<rectangle x1="-27.27" y1="-14.55" x2="-26.85" y2="-14.05" layer="51"/>
<rectangle x1="-26.83" y1="-14.55" x2="-26.41" y2="-14.05" layer="51"/>
<rectangle x1="-26.39" y1="-14.55" x2="-25.97" y2="-14.05" layer="51"/>
<rectangle x1="-25.95" y1="-14.55" x2="-25.53" y2="-14.05" layer="51"/>
<rectangle x1="-25.51" y1="-14.55" x2="-25.09" y2="-14.05" layer="51"/>
<rectangle x1="-25.07" y1="-14.55" x2="-24.65" y2="-14.05" layer="51"/>
<rectangle x1="-24.63" y1="-14.55" x2="-24.21" y2="-14.05" layer="51"/>
<rectangle x1="-24.19" y1="-14.55" x2="-23.77" y2="-14.05" layer="51"/>
<rectangle x1="-23.75" y1="-14.55" x2="-23.33" y2="-14.05" layer="51"/>
<rectangle x1="-23.31" y1="-14.55" x2="-22.89" y2="-14.05" layer="51"/>
<rectangle x1="-22.87" y1="-14.55" x2="-22.45" y2="-14.05" layer="51"/>
<rectangle x1="-22.43" y1="-14.55" x2="-22.01" y2="-14.05" layer="51"/>
<rectangle x1="-21.99" y1="-14.55" x2="-21.57" y2="-14.05" layer="51"/>
<rectangle x1="-21.55" y1="-14.55" x2="-21.13" y2="-14.05" layer="51"/>
<rectangle x1="-21.11" y1="-14.55" x2="-20.69" y2="-14.05" layer="51"/>
<rectangle x1="-20.67" y1="-14.55" x2="-20.25" y2="-14.05" layer="51"/>
<rectangle x1="-20.23" y1="-14.55" x2="-19.81" y2="-14.05" layer="51"/>
<rectangle x1="-19.79" y1="-14.55" x2="-19.37" y2="-14.05" layer="51"/>
<rectangle x1="-19.35" y1="-14.55" x2="-18.93" y2="-14.05" layer="51"/>
<rectangle x1="-18.91" y1="-14.55" x2="-18.49" y2="-14.05" layer="51"/>
<rectangle x1="-18.47" y1="-14.55" x2="-18.05" y2="-14.05" layer="51"/>
<rectangle x1="-18.03" y1="-14.55" x2="-17.61" y2="-14.05" layer="51"/>
<rectangle x1="-17.59" y1="-14.55" x2="-17.17" y2="-14.05" layer="51"/>
<rectangle x1="-17.15" y1="-14.55" x2="-16.73" y2="-14.05" layer="51"/>
<rectangle x1="-16.71" y1="-14.55" x2="-16.29" y2="-14.05" layer="51"/>
<rectangle x1="-16.27" y1="-14.55" x2="-15.85" y2="-14.05" layer="51"/>
<rectangle x1="-15.83" y1="-14.55" x2="-15.41" y2="-14.05" layer="51"/>
<rectangle x1="-15.39" y1="-14.55" x2="-14.97" y2="-14.05" layer="51"/>
<rectangle x1="-14.95" y1="-14.55" x2="-14.53" y2="-14.05" layer="51"/>
<rectangle x1="-14.51" y1="-14.55" x2="-14.09" y2="-14.05" layer="51"/>
<rectangle x1="-14.07" y1="-14.55" x2="-13.65" y2="-14.05" layer="51"/>
<rectangle x1="-13.63" y1="-14.55" x2="-13.21" y2="-14.05" layer="51"/>
<rectangle x1="-13.19" y1="-14.55" x2="-12.77" y2="-14.05" layer="51"/>
<rectangle x1="-12.75" y1="-14.55" x2="-12.33" y2="-14.05" layer="51"/>
<rectangle x1="-12.31" y1="-14.55" x2="-11.89" y2="-14.05" layer="51"/>
<rectangle x1="-11.87" y1="-14.55" x2="-11.45" y2="-14.05" layer="51"/>
<rectangle x1="-11.43" y1="-14.55" x2="-11.01" y2="-14.05" layer="51"/>
<rectangle x1="-10.99" y1="-14.55" x2="-10.57" y2="-14.05" layer="51"/>
<rectangle x1="-10.55" y1="-14.55" x2="-10.13" y2="-14.05" layer="51"/>
<rectangle x1="-10.11" y1="-14.55" x2="-9.69" y2="-14.05" layer="51"/>
<rectangle x1="-9.67" y1="-14.55" x2="-9.25" y2="-14.05" layer="51"/>
<rectangle x1="-9.23" y1="-14.55" x2="-8.81" y2="-14.05" layer="51"/>
<rectangle x1="-8.79" y1="-14.55" x2="-8.37" y2="-14.05" layer="51"/>
<rectangle x1="-8.35" y1="-14.55" x2="-7.93" y2="-14.05" layer="51"/>
<rectangle x1="-7.91" y1="-14.55" x2="-7.49" y2="-14.05" layer="51"/>
<rectangle x1="-7.47" y1="-14.55" x2="-7.05" y2="-14.05" layer="51"/>
<rectangle x1="-7.03" y1="-14.55" x2="-6.61" y2="-14.05" layer="51"/>
<rectangle x1="-6.59" y1="-14.55" x2="-6.17" y2="-14.05" layer="51"/>
<rectangle x1="-6.15" y1="-14.55" x2="-5.73" y2="-14.05" layer="51"/>
<rectangle x1="-5.71" y1="-14.55" x2="-5.29" y2="-14.05" layer="51"/>
<rectangle x1="-5.27" y1="-14.55" x2="-4.85" y2="-14.05" layer="51"/>
<rectangle x1="-4.83" y1="-14.55" x2="-4.41" y2="-14.05" layer="51"/>
<rectangle x1="-4.39" y1="-14.55" x2="-3.97" y2="-14.05" layer="51"/>
<rectangle x1="-3.95" y1="-14.55" x2="-3.53" y2="-14.05" layer="51"/>
<rectangle x1="-3.51" y1="-14.55" x2="-3.09" y2="-14.05" layer="51"/>
<rectangle x1="-3.07" y1="-14.55" x2="-2.65" y2="-14.05" layer="51"/>
<rectangle x1="-2.63" y1="-14.55" x2="-2.21" y2="-14.05" layer="51"/>
<rectangle x1="-2.19" y1="-14.55" x2="-1.77" y2="-14.05" layer="51"/>
<rectangle x1="-1.75" y1="-14.55" x2="-1.33" y2="-14.05" layer="51"/>
<rectangle x1="-1.31" y1="-14.55" x2="-0.89" y2="-14.05" layer="51"/>
<rectangle x1="-0.87" y1="-14.55" x2="-0.45" y2="-14.05" layer="51"/>
<rectangle x1="-0.43" y1="-14.55" x2="-0.01" y2="-14.05" layer="51"/>
<rectangle x1="0.01" y1="-14.55" x2="0.43" y2="-14.05" layer="51"/>
<rectangle x1="0.45" y1="-14.55" x2="0.87" y2="-14.05" layer="51"/>
<rectangle x1="0.89" y1="-14.55" x2="1.31" y2="-14.05" layer="51"/>
<rectangle x1="1.33" y1="-14.55" x2="1.75" y2="-14.05" layer="51"/>
<rectangle x1="1.77" y1="-14.55" x2="2.19" y2="-14.05" layer="51"/>
<rectangle x1="2.21" y1="-14.55" x2="2.63" y2="-14.05" layer="51"/>
<rectangle x1="2.65" y1="-14.55" x2="3.07" y2="-14.05" layer="51"/>
<rectangle x1="3.09" y1="-14.55" x2="3.51" y2="-14.05" layer="51"/>
<rectangle x1="3.53" y1="-14.55" x2="3.95" y2="-14.05" layer="51"/>
<rectangle x1="3.97" y1="-14.55" x2="4.39" y2="-14.05" layer="51"/>
<rectangle x1="4.41" y1="-14.55" x2="4.83" y2="-14.05" layer="51"/>
<rectangle x1="4.85" y1="-14.55" x2="5.27" y2="-14.05" layer="51"/>
<rectangle x1="5.29" y1="-14.55" x2="5.71" y2="-14.05" layer="51"/>
<rectangle x1="5.73" y1="-14.55" x2="6.15" y2="-14.05" layer="51"/>
<rectangle x1="6.17" y1="-14.55" x2="6.59" y2="-14.05" layer="51"/>
<rectangle x1="6.61" y1="-14.55" x2="7.03" y2="-14.05" layer="51"/>
<rectangle x1="7.05" y1="-14.55" x2="7.47" y2="-14.05" layer="51"/>
<rectangle x1="7.49" y1="-14.55" x2="7.91" y2="-14.05" layer="51"/>
<rectangle x1="7.93" y1="-14.55" x2="8.35" y2="-14.05" layer="51"/>
<rectangle x1="8.37" y1="-14.55" x2="8.79" y2="-14.05" layer="51"/>
<rectangle x1="8.81" y1="-14.55" x2="9.23" y2="-14.05" layer="51"/>
<rectangle x1="9.25" y1="-14.55" x2="9.67" y2="-14.05" layer="51"/>
<rectangle x1="9.69" y1="-14.55" x2="10.11" y2="-14.05" layer="51"/>
<rectangle x1="10.13" y1="-14.55" x2="10.55" y2="-14.05" layer="51"/>
<rectangle x1="10.57" y1="-14.55" x2="10.99" y2="-14.05" layer="51"/>
<rectangle x1="11.01" y1="-14.55" x2="11.43" y2="-14.05" layer="51"/>
<rectangle x1="11.45" y1="-14.55" x2="11.87" y2="-14.05" layer="51"/>
<rectangle x1="11.89" y1="-14.55" x2="12.31" y2="-14.05" layer="51"/>
<rectangle x1="12.33" y1="-14.55" x2="12.75" y2="-14.05" layer="51"/>
<rectangle x1="12.77" y1="-14.55" x2="13.19" y2="-14.05" layer="51"/>
<rectangle x1="13.21" y1="-14.55" x2="13.63" y2="-14.05" layer="51"/>
<rectangle x1="13.65" y1="-14.55" x2="14.07" y2="-14.05" layer="51"/>
<rectangle x1="14.09" y1="-14.55" x2="14.51" y2="-14.05" layer="51"/>
<rectangle x1="14.53" y1="-14.55" x2="14.95" y2="-14.05" layer="51"/>
<rectangle x1="14.97" y1="-14.55" x2="15.39" y2="-14.05" layer="51"/>
<rectangle x1="15.41" y1="-14.55" x2="15.83" y2="-14.05" layer="51"/>
<rectangle x1="15.85" y1="-14.55" x2="16.27" y2="-14.05" layer="51"/>
<rectangle x1="16.29" y1="-14.55" x2="16.71" y2="-14.05" layer="51"/>
<rectangle x1="16.73" y1="-14.55" x2="17.15" y2="-14.05" layer="51"/>
<rectangle x1="17.17" y1="-14.55" x2="17.59" y2="-14.05" layer="51"/>
<rectangle x1="17.61" y1="-14.55" x2="18.03" y2="-14.05" layer="51"/>
<rectangle x1="18.05" y1="-14.55" x2="18.47" y2="-14.05" layer="51"/>
<rectangle x1="18.49" y1="-14.55" x2="18.91" y2="-14.05" layer="51"/>
<rectangle x1="18.93" y1="-14.55" x2="19.35" y2="-14.05" layer="51"/>
<rectangle x1="19.37" y1="-14.55" x2="19.79" y2="-14.05" layer="51"/>
<rectangle x1="19.81" y1="-14.55" x2="20.23" y2="-14.05" layer="51"/>
<rectangle x1="20.25" y1="-14.55" x2="20.67" y2="-14.05" layer="51"/>
<rectangle x1="20.69" y1="-14.55" x2="21.11" y2="-14.05" layer="51"/>
<rectangle x1="21.13" y1="-14.55" x2="21.55" y2="-14.05" layer="51"/>
<rectangle x1="21.57" y1="-14.55" x2="21.99" y2="-14.05" layer="51"/>
<rectangle x1="22.01" y1="-14.55" x2="22.43" y2="-14.05" layer="51"/>
<rectangle x1="22.45" y1="-14.55" x2="22.87" y2="-14.05" layer="51"/>
<rectangle x1="22.89" y1="-14.55" x2="23.31" y2="-14.05" layer="51"/>
<rectangle x1="23.33" y1="-14.55" x2="23.75" y2="-14.05" layer="51"/>
<rectangle x1="23.77" y1="-14.55" x2="24.19" y2="-14.05" layer="51"/>
<rectangle x1="24.21" y1="-14.55" x2="24.63" y2="-14.05" layer="51"/>
<rectangle x1="24.65" y1="-14.55" x2="25.07" y2="-14.05" layer="51"/>
<rectangle x1="25.09" y1="-14.55" x2="25.51" y2="-14.05" layer="51"/>
<rectangle x1="25.53" y1="-14.55" x2="25.95" y2="-14.05" layer="51"/>
<rectangle x1="25.97" y1="-14.55" x2="26.39" y2="-14.05" layer="51"/>
<rectangle x1="26.41" y1="-14.55" x2="26.83" y2="-14.05" layer="51"/>
<rectangle x1="26.85" y1="-14.55" x2="27.27" y2="-14.05" layer="51"/>
<rectangle x1="27.29" y1="-14.55" x2="27.71" y2="-14.05" layer="51"/>
<rectangle x1="27.73" y1="-14.55" x2="28.15" y2="-14.05" layer="51"/>
<rectangle x1="-28.15" y1="-15.07" x2="-27.73" y2="-14.57" layer="51"/>
<rectangle x1="-27.71" y1="-15.07" x2="-27.29" y2="-14.57" layer="51"/>
<rectangle x1="-27.27" y1="-15.07" x2="-26.85" y2="-14.57" layer="51"/>
<rectangle x1="-26.83" y1="-15.07" x2="-26.41" y2="-14.57" layer="51"/>
<rectangle x1="-26.39" y1="-15.07" x2="-25.97" y2="-14.57" layer="51"/>
<rectangle x1="-25.95" y1="-15.07" x2="-25.53" y2="-14.57" layer="51"/>
<rectangle x1="-25.51" y1="-15.07" x2="-25.09" y2="-14.57" layer="51"/>
<rectangle x1="-25.07" y1="-15.07" x2="-24.65" y2="-14.57" layer="51"/>
<rectangle x1="-24.63" y1="-15.07" x2="-24.21" y2="-14.57" layer="51"/>
<rectangle x1="-24.19" y1="-15.07" x2="-23.77" y2="-14.57" layer="51"/>
<rectangle x1="-23.75" y1="-15.07" x2="-23.33" y2="-14.57" layer="51"/>
<rectangle x1="-23.31" y1="-15.07" x2="-22.89" y2="-14.57" layer="51"/>
<rectangle x1="-22.87" y1="-15.07" x2="-22.45" y2="-14.57" layer="51"/>
<rectangle x1="-22.43" y1="-15.07" x2="-22.01" y2="-14.57" layer="51"/>
<rectangle x1="-21.99" y1="-15.07" x2="-21.57" y2="-14.57" layer="51"/>
<rectangle x1="-21.55" y1="-15.07" x2="-21.13" y2="-14.57" layer="51"/>
<rectangle x1="-21.11" y1="-15.07" x2="-20.69" y2="-14.57" layer="51"/>
<rectangle x1="-20.67" y1="-15.07" x2="-20.25" y2="-14.57" layer="51"/>
<rectangle x1="-20.23" y1="-15.07" x2="-19.81" y2="-14.57" layer="51"/>
<rectangle x1="-19.79" y1="-15.07" x2="-19.37" y2="-14.57" layer="51"/>
<rectangle x1="-19.35" y1="-15.07" x2="-18.93" y2="-14.57" layer="51"/>
<rectangle x1="-18.91" y1="-15.07" x2="-18.49" y2="-14.57" layer="51"/>
<rectangle x1="-18.47" y1="-15.07" x2="-18.05" y2="-14.57" layer="51"/>
<rectangle x1="-18.03" y1="-15.07" x2="-17.61" y2="-14.57" layer="51"/>
<rectangle x1="-17.59" y1="-15.07" x2="-17.17" y2="-14.57" layer="51"/>
<rectangle x1="-17.15" y1="-15.07" x2="-16.73" y2="-14.57" layer="51"/>
<rectangle x1="-16.71" y1="-15.07" x2="-16.29" y2="-14.57" layer="51"/>
<rectangle x1="-16.27" y1="-15.07" x2="-15.85" y2="-14.57" layer="51"/>
<rectangle x1="-15.83" y1="-15.07" x2="-15.41" y2="-14.57" layer="51"/>
<rectangle x1="-15.39" y1="-15.07" x2="-14.97" y2="-14.57" layer="51"/>
<rectangle x1="-14.95" y1="-15.07" x2="-14.53" y2="-14.57" layer="51"/>
<rectangle x1="-14.51" y1="-15.07" x2="-14.09" y2="-14.57" layer="51"/>
<rectangle x1="-14.07" y1="-15.07" x2="-13.65" y2="-14.57" layer="51"/>
<rectangle x1="-13.63" y1="-15.07" x2="-13.21" y2="-14.57" layer="51"/>
<rectangle x1="-13.19" y1="-15.07" x2="-12.77" y2="-14.57" layer="51"/>
<rectangle x1="-12.75" y1="-15.07" x2="-12.33" y2="-14.57" layer="51"/>
<rectangle x1="-12.31" y1="-15.07" x2="-11.89" y2="-14.57" layer="51"/>
<rectangle x1="-11.87" y1="-15.07" x2="-11.45" y2="-14.57" layer="51"/>
<rectangle x1="-11.43" y1="-15.07" x2="-11.01" y2="-14.57" layer="51"/>
<rectangle x1="-10.99" y1="-15.07" x2="-10.57" y2="-14.57" layer="51"/>
<rectangle x1="-10.55" y1="-15.07" x2="-10.13" y2="-14.57" layer="51"/>
<rectangle x1="-10.11" y1="-15.07" x2="-9.69" y2="-14.57" layer="51"/>
<rectangle x1="-9.67" y1="-15.07" x2="-9.25" y2="-14.57" layer="51"/>
<rectangle x1="-9.23" y1="-15.07" x2="-8.81" y2="-14.57" layer="51"/>
<rectangle x1="-8.79" y1="-15.07" x2="-8.37" y2="-14.57" layer="51"/>
<rectangle x1="-8.35" y1="-15.07" x2="-7.93" y2="-14.57" layer="51"/>
<rectangle x1="-7.91" y1="-15.07" x2="-7.49" y2="-14.57" layer="51"/>
<rectangle x1="-7.47" y1="-15.07" x2="-7.05" y2="-14.57" layer="51"/>
<rectangle x1="-7.03" y1="-15.07" x2="-6.61" y2="-14.57" layer="51"/>
<rectangle x1="-6.59" y1="-15.07" x2="-6.17" y2="-14.57" layer="51"/>
<rectangle x1="-6.15" y1="-15.07" x2="-5.73" y2="-14.57" layer="51"/>
<rectangle x1="-5.71" y1="-15.07" x2="-5.29" y2="-14.57" layer="51"/>
<rectangle x1="-5.27" y1="-15.07" x2="-4.85" y2="-14.57" layer="51"/>
<rectangle x1="-4.83" y1="-15.07" x2="-4.41" y2="-14.57" layer="51"/>
<rectangle x1="-4.39" y1="-15.07" x2="-3.97" y2="-14.57" layer="51"/>
<rectangle x1="-3.95" y1="-15.07" x2="-3.53" y2="-14.57" layer="51"/>
<rectangle x1="-3.51" y1="-15.07" x2="-3.09" y2="-14.57" layer="51"/>
<rectangle x1="-3.07" y1="-15.07" x2="-2.65" y2="-14.57" layer="51"/>
<rectangle x1="-2.63" y1="-15.07" x2="-2.21" y2="-14.57" layer="51"/>
<rectangle x1="-2.19" y1="-15.07" x2="-1.77" y2="-14.57" layer="51"/>
<rectangle x1="-1.75" y1="-15.07" x2="-1.33" y2="-14.57" layer="51"/>
<rectangle x1="-1.31" y1="-15.07" x2="-0.89" y2="-14.57" layer="51"/>
<rectangle x1="-0.87" y1="-15.07" x2="-0.45" y2="-14.57" layer="51"/>
<rectangle x1="-0.43" y1="-15.07" x2="-0.01" y2="-14.57" layer="51"/>
<rectangle x1="0.01" y1="-15.07" x2="0.43" y2="-14.57" layer="51"/>
<rectangle x1="0.45" y1="-15.07" x2="0.87" y2="-14.57" layer="51"/>
<rectangle x1="0.89" y1="-15.07" x2="1.31" y2="-14.57" layer="51"/>
<rectangle x1="1.33" y1="-15.07" x2="1.75" y2="-14.57" layer="51"/>
<rectangle x1="1.77" y1="-15.07" x2="2.19" y2="-14.57" layer="51"/>
<rectangle x1="2.21" y1="-15.07" x2="2.63" y2="-14.57" layer="51"/>
<rectangle x1="2.65" y1="-15.07" x2="3.07" y2="-14.57" layer="51"/>
<rectangle x1="3.09" y1="-15.07" x2="3.51" y2="-14.57" layer="51"/>
<rectangle x1="3.53" y1="-15.07" x2="3.95" y2="-14.57" layer="51"/>
<rectangle x1="3.97" y1="-15.07" x2="4.39" y2="-14.57" layer="51"/>
<rectangle x1="4.41" y1="-15.07" x2="4.83" y2="-14.57" layer="51"/>
<rectangle x1="4.85" y1="-15.07" x2="5.27" y2="-14.57" layer="51"/>
<rectangle x1="5.29" y1="-15.07" x2="5.71" y2="-14.57" layer="51"/>
<rectangle x1="5.73" y1="-15.07" x2="6.15" y2="-14.57" layer="51"/>
<rectangle x1="6.17" y1="-15.07" x2="6.59" y2="-14.57" layer="51"/>
<rectangle x1="6.61" y1="-15.07" x2="7.03" y2="-14.57" layer="51"/>
<rectangle x1="7.05" y1="-15.07" x2="7.47" y2="-14.57" layer="51"/>
<rectangle x1="7.49" y1="-15.07" x2="7.91" y2="-14.57" layer="51"/>
<rectangle x1="7.93" y1="-15.07" x2="8.35" y2="-14.57" layer="51"/>
<rectangle x1="8.37" y1="-15.07" x2="8.79" y2="-14.57" layer="51"/>
<rectangle x1="8.81" y1="-15.07" x2="9.23" y2="-14.57" layer="51"/>
<rectangle x1="9.25" y1="-15.07" x2="9.67" y2="-14.57" layer="51"/>
<rectangle x1="9.69" y1="-15.07" x2="10.11" y2="-14.57" layer="51"/>
<rectangle x1="10.13" y1="-15.07" x2="10.55" y2="-14.57" layer="51"/>
<rectangle x1="10.57" y1="-15.07" x2="10.99" y2="-14.57" layer="51"/>
<rectangle x1="11.01" y1="-15.07" x2="11.43" y2="-14.57" layer="51"/>
<rectangle x1="11.45" y1="-15.07" x2="11.87" y2="-14.57" layer="51"/>
<rectangle x1="11.89" y1="-15.07" x2="12.31" y2="-14.57" layer="51"/>
<rectangle x1="12.33" y1="-15.07" x2="12.75" y2="-14.57" layer="51"/>
<rectangle x1="12.77" y1="-15.07" x2="13.19" y2="-14.57" layer="51"/>
<rectangle x1="13.21" y1="-15.07" x2="13.63" y2="-14.57" layer="51"/>
<rectangle x1="13.65" y1="-15.07" x2="14.07" y2="-14.57" layer="51"/>
<rectangle x1="14.09" y1="-15.07" x2="14.51" y2="-14.57" layer="51"/>
<rectangle x1="14.53" y1="-15.07" x2="14.95" y2="-14.57" layer="51"/>
<rectangle x1="14.97" y1="-15.07" x2="15.39" y2="-14.57" layer="51"/>
<rectangle x1="15.41" y1="-15.07" x2="15.83" y2="-14.57" layer="51"/>
<rectangle x1="15.85" y1="-15.07" x2="16.27" y2="-14.57" layer="51"/>
<rectangle x1="16.29" y1="-15.07" x2="16.71" y2="-14.57" layer="51"/>
<rectangle x1="16.73" y1="-15.07" x2="17.15" y2="-14.57" layer="51"/>
<rectangle x1="17.17" y1="-15.07" x2="17.59" y2="-14.57" layer="51"/>
<rectangle x1="17.61" y1="-15.07" x2="18.03" y2="-14.57" layer="51"/>
<rectangle x1="18.05" y1="-15.07" x2="18.47" y2="-14.57" layer="51"/>
<rectangle x1="18.49" y1="-15.07" x2="18.91" y2="-14.57" layer="51"/>
<rectangle x1="18.93" y1="-15.07" x2="19.35" y2="-14.57" layer="51"/>
<rectangle x1="19.37" y1="-15.07" x2="19.79" y2="-14.57" layer="51"/>
<rectangle x1="19.81" y1="-15.07" x2="20.23" y2="-14.57" layer="51"/>
<rectangle x1="20.25" y1="-15.07" x2="20.67" y2="-14.57" layer="51"/>
<rectangle x1="20.69" y1="-15.07" x2="21.11" y2="-14.57" layer="51"/>
<rectangle x1="21.13" y1="-15.07" x2="21.55" y2="-14.57" layer="51"/>
<rectangle x1="21.57" y1="-15.07" x2="21.99" y2="-14.57" layer="51"/>
<rectangle x1="22.01" y1="-15.07" x2="22.43" y2="-14.57" layer="51"/>
<rectangle x1="22.45" y1="-15.07" x2="22.87" y2="-14.57" layer="51"/>
<rectangle x1="22.89" y1="-15.07" x2="23.31" y2="-14.57" layer="51"/>
<rectangle x1="23.33" y1="-15.07" x2="23.75" y2="-14.57" layer="51"/>
<rectangle x1="23.77" y1="-15.07" x2="24.19" y2="-14.57" layer="51"/>
<rectangle x1="24.21" y1="-15.07" x2="24.63" y2="-14.57" layer="51"/>
<rectangle x1="24.65" y1="-15.07" x2="25.07" y2="-14.57" layer="51"/>
<rectangle x1="25.09" y1="-15.07" x2="25.51" y2="-14.57" layer="51"/>
<rectangle x1="25.53" y1="-15.07" x2="25.95" y2="-14.57" layer="51"/>
<rectangle x1="25.97" y1="-15.07" x2="26.39" y2="-14.57" layer="51"/>
<rectangle x1="26.41" y1="-15.07" x2="26.83" y2="-14.57" layer="51"/>
<rectangle x1="26.85" y1="-15.07" x2="27.27" y2="-14.57" layer="51"/>
<rectangle x1="27.29" y1="-15.07" x2="27.71" y2="-14.57" layer="51"/>
<rectangle x1="27.73" y1="-15.07" x2="28.15" y2="-14.57" layer="51"/>
<rectangle x1="-28.15" y1="-15.59" x2="-27.73" y2="-15.09" layer="51"/>
<rectangle x1="-27.71" y1="-15.59" x2="-27.29" y2="-15.09" layer="51"/>
<rectangle x1="-27.27" y1="-15.59" x2="-26.85" y2="-15.09" layer="51"/>
<rectangle x1="-26.83" y1="-15.59" x2="-26.41" y2="-15.09" layer="51"/>
<rectangle x1="-26.39" y1="-15.59" x2="-25.97" y2="-15.09" layer="51"/>
<rectangle x1="-25.95" y1="-15.59" x2="-25.53" y2="-15.09" layer="51"/>
<rectangle x1="-25.51" y1="-15.59" x2="-25.09" y2="-15.09" layer="51"/>
<rectangle x1="-25.07" y1="-15.59" x2="-24.65" y2="-15.09" layer="51"/>
<rectangle x1="-24.63" y1="-15.59" x2="-24.21" y2="-15.09" layer="51"/>
<rectangle x1="-24.19" y1="-15.59" x2="-23.77" y2="-15.09" layer="51"/>
<rectangle x1="-23.75" y1="-15.59" x2="-23.33" y2="-15.09" layer="51"/>
<rectangle x1="-23.31" y1="-15.59" x2="-22.89" y2="-15.09" layer="51"/>
<rectangle x1="-22.87" y1="-15.59" x2="-22.45" y2="-15.09" layer="51"/>
<rectangle x1="-22.43" y1="-15.59" x2="-22.01" y2="-15.09" layer="51"/>
<rectangle x1="-21.99" y1="-15.59" x2="-21.57" y2="-15.09" layer="51"/>
<rectangle x1="-21.55" y1="-15.59" x2="-21.13" y2="-15.09" layer="51"/>
<rectangle x1="-21.11" y1="-15.59" x2="-20.69" y2="-15.09" layer="51"/>
<rectangle x1="-20.67" y1="-15.59" x2="-20.25" y2="-15.09" layer="51"/>
<rectangle x1="-20.23" y1="-15.59" x2="-19.81" y2="-15.09" layer="51"/>
<rectangle x1="-19.79" y1="-15.59" x2="-19.37" y2="-15.09" layer="51"/>
<rectangle x1="-19.35" y1="-15.59" x2="-18.93" y2="-15.09" layer="51"/>
<rectangle x1="-18.91" y1="-15.59" x2="-18.49" y2="-15.09" layer="51"/>
<rectangle x1="-18.47" y1="-15.59" x2="-18.05" y2="-15.09" layer="51"/>
<rectangle x1="-18.03" y1="-15.59" x2="-17.61" y2="-15.09" layer="51"/>
<rectangle x1="-17.59" y1="-15.59" x2="-17.17" y2="-15.09" layer="51"/>
<rectangle x1="-17.15" y1="-15.59" x2="-16.73" y2="-15.09" layer="51"/>
<rectangle x1="-16.71" y1="-15.59" x2="-16.29" y2="-15.09" layer="51"/>
<rectangle x1="-16.27" y1="-15.59" x2="-15.85" y2="-15.09" layer="51"/>
<rectangle x1="-15.83" y1="-15.59" x2="-15.41" y2="-15.09" layer="51"/>
<rectangle x1="-15.39" y1="-15.59" x2="-14.97" y2="-15.09" layer="51"/>
<rectangle x1="-14.95" y1="-15.59" x2="-14.53" y2="-15.09" layer="51"/>
<rectangle x1="-14.51" y1="-15.59" x2="-14.09" y2="-15.09" layer="51"/>
<rectangle x1="-14.07" y1="-15.59" x2="-13.65" y2="-15.09" layer="51"/>
<rectangle x1="-13.63" y1="-15.59" x2="-13.21" y2="-15.09" layer="51"/>
<rectangle x1="-13.19" y1="-15.59" x2="-12.77" y2="-15.09" layer="51"/>
<rectangle x1="-12.75" y1="-15.59" x2="-12.33" y2="-15.09" layer="51"/>
<rectangle x1="-12.31" y1="-15.59" x2="-11.89" y2="-15.09" layer="51"/>
<rectangle x1="-11.87" y1="-15.59" x2="-11.45" y2="-15.09" layer="51"/>
<rectangle x1="-11.43" y1="-15.59" x2="-11.01" y2="-15.09" layer="51"/>
<rectangle x1="-10.99" y1="-15.59" x2="-10.57" y2="-15.09" layer="51"/>
<rectangle x1="-10.55" y1="-15.59" x2="-10.13" y2="-15.09" layer="51"/>
<rectangle x1="-10.11" y1="-15.59" x2="-9.69" y2="-15.09" layer="51"/>
<rectangle x1="-9.67" y1="-15.59" x2="-9.25" y2="-15.09" layer="51"/>
<rectangle x1="-9.23" y1="-15.59" x2="-8.81" y2="-15.09" layer="51"/>
<rectangle x1="-8.79" y1="-15.59" x2="-8.37" y2="-15.09" layer="51"/>
<rectangle x1="-8.35" y1="-15.59" x2="-7.93" y2="-15.09" layer="51"/>
<rectangle x1="-7.91" y1="-15.59" x2="-7.49" y2="-15.09" layer="51"/>
<rectangle x1="-7.47" y1="-15.59" x2="-7.05" y2="-15.09" layer="51"/>
<rectangle x1="-7.03" y1="-15.59" x2="-6.61" y2="-15.09" layer="51"/>
<rectangle x1="-6.59" y1="-15.59" x2="-6.17" y2="-15.09" layer="51"/>
<rectangle x1="-6.15" y1="-15.59" x2="-5.73" y2="-15.09" layer="51"/>
<rectangle x1="-5.71" y1="-15.59" x2="-5.29" y2="-15.09" layer="51"/>
<rectangle x1="-5.27" y1="-15.59" x2="-4.85" y2="-15.09" layer="51"/>
<rectangle x1="-4.83" y1="-15.59" x2="-4.41" y2="-15.09" layer="51"/>
<rectangle x1="-4.39" y1="-15.59" x2="-3.97" y2="-15.09" layer="51"/>
<rectangle x1="-3.95" y1="-15.59" x2="-3.53" y2="-15.09" layer="51"/>
<rectangle x1="-3.51" y1="-15.59" x2="-3.09" y2="-15.09" layer="51"/>
<rectangle x1="-3.07" y1="-15.59" x2="-2.65" y2="-15.09" layer="51"/>
<rectangle x1="-2.63" y1="-15.59" x2="-2.21" y2="-15.09" layer="51"/>
<rectangle x1="-2.19" y1="-15.59" x2="-1.77" y2="-15.09" layer="51"/>
<rectangle x1="-1.75" y1="-15.59" x2="-1.33" y2="-15.09" layer="51"/>
<rectangle x1="-1.31" y1="-15.59" x2="-0.89" y2="-15.09" layer="51"/>
<rectangle x1="-0.87" y1="-15.59" x2="-0.45" y2="-15.09" layer="51"/>
<rectangle x1="-0.43" y1="-15.59" x2="-0.01" y2="-15.09" layer="51"/>
<rectangle x1="0.01" y1="-15.59" x2="0.43" y2="-15.09" layer="51"/>
<rectangle x1="0.45" y1="-15.59" x2="0.87" y2="-15.09" layer="51"/>
<rectangle x1="0.89" y1="-15.59" x2="1.31" y2="-15.09" layer="51"/>
<rectangle x1="1.33" y1="-15.59" x2="1.75" y2="-15.09" layer="51"/>
<rectangle x1="1.77" y1="-15.59" x2="2.19" y2="-15.09" layer="51"/>
<rectangle x1="2.21" y1="-15.59" x2="2.63" y2="-15.09" layer="51"/>
<rectangle x1="2.65" y1="-15.59" x2="3.07" y2="-15.09" layer="51"/>
<rectangle x1="3.09" y1="-15.59" x2="3.51" y2="-15.09" layer="51"/>
<rectangle x1="3.53" y1="-15.59" x2="3.95" y2="-15.09" layer="51"/>
<rectangle x1="3.97" y1="-15.59" x2="4.39" y2="-15.09" layer="51"/>
<rectangle x1="4.41" y1="-15.59" x2="4.83" y2="-15.09" layer="51"/>
<rectangle x1="4.85" y1="-15.59" x2="5.27" y2="-15.09" layer="51"/>
<rectangle x1="5.29" y1="-15.59" x2="5.71" y2="-15.09" layer="51"/>
<rectangle x1="5.73" y1="-15.59" x2="6.15" y2="-15.09" layer="51"/>
<rectangle x1="6.17" y1="-15.59" x2="6.59" y2="-15.09" layer="51"/>
<rectangle x1="6.61" y1="-15.59" x2="7.03" y2="-15.09" layer="51"/>
<rectangle x1="7.05" y1="-15.59" x2="7.47" y2="-15.09" layer="51"/>
<rectangle x1="7.49" y1="-15.59" x2="7.91" y2="-15.09" layer="51"/>
<rectangle x1="7.93" y1="-15.59" x2="8.35" y2="-15.09" layer="51"/>
<rectangle x1="8.37" y1="-15.59" x2="8.79" y2="-15.09" layer="51"/>
<rectangle x1="8.81" y1="-15.59" x2="9.23" y2="-15.09" layer="51"/>
<rectangle x1="9.25" y1="-15.59" x2="9.67" y2="-15.09" layer="51"/>
<rectangle x1="9.69" y1="-15.59" x2="10.11" y2="-15.09" layer="51"/>
<rectangle x1="10.13" y1="-15.59" x2="10.55" y2="-15.09" layer="51"/>
<rectangle x1="10.57" y1="-15.59" x2="10.99" y2="-15.09" layer="51"/>
<rectangle x1="11.01" y1="-15.59" x2="11.43" y2="-15.09" layer="51"/>
<rectangle x1="11.45" y1="-15.59" x2="11.87" y2="-15.09" layer="51"/>
<rectangle x1="11.89" y1="-15.59" x2="12.31" y2="-15.09" layer="51"/>
<rectangle x1="12.33" y1="-15.59" x2="12.75" y2="-15.09" layer="51"/>
<rectangle x1="12.77" y1="-15.59" x2="13.19" y2="-15.09" layer="51"/>
<rectangle x1="13.21" y1="-15.59" x2="13.63" y2="-15.09" layer="51"/>
<rectangle x1="13.65" y1="-15.59" x2="14.07" y2="-15.09" layer="51"/>
<rectangle x1="14.09" y1="-15.59" x2="14.51" y2="-15.09" layer="51"/>
<rectangle x1="14.53" y1="-15.59" x2="14.95" y2="-15.09" layer="51"/>
<rectangle x1="14.97" y1="-15.59" x2="15.39" y2="-15.09" layer="51"/>
<rectangle x1="15.41" y1="-15.59" x2="15.83" y2="-15.09" layer="51"/>
<rectangle x1="15.85" y1="-15.59" x2="16.27" y2="-15.09" layer="51"/>
<rectangle x1="16.29" y1="-15.59" x2="16.71" y2="-15.09" layer="51"/>
<rectangle x1="16.73" y1="-15.59" x2="17.15" y2="-15.09" layer="51"/>
<rectangle x1="17.17" y1="-15.59" x2="17.59" y2="-15.09" layer="51"/>
<rectangle x1="17.61" y1="-15.59" x2="18.03" y2="-15.09" layer="51"/>
<rectangle x1="18.05" y1="-15.59" x2="18.47" y2="-15.09" layer="51"/>
<rectangle x1="18.49" y1="-15.59" x2="18.91" y2="-15.09" layer="51"/>
<rectangle x1="18.93" y1="-15.59" x2="19.35" y2="-15.09" layer="51"/>
<rectangle x1="19.37" y1="-15.59" x2="19.79" y2="-15.09" layer="51"/>
<rectangle x1="19.81" y1="-15.59" x2="20.23" y2="-15.09" layer="51"/>
<rectangle x1="20.25" y1="-15.59" x2="20.67" y2="-15.09" layer="51"/>
<rectangle x1="20.69" y1="-15.59" x2="21.11" y2="-15.09" layer="51"/>
<rectangle x1="21.13" y1="-15.59" x2="21.55" y2="-15.09" layer="51"/>
<rectangle x1="21.57" y1="-15.59" x2="21.99" y2="-15.09" layer="51"/>
<rectangle x1="22.01" y1="-15.59" x2="22.43" y2="-15.09" layer="51"/>
<rectangle x1="22.45" y1="-15.59" x2="22.87" y2="-15.09" layer="51"/>
<rectangle x1="22.89" y1="-15.59" x2="23.31" y2="-15.09" layer="51"/>
<rectangle x1="23.33" y1="-15.59" x2="23.75" y2="-15.09" layer="51"/>
<rectangle x1="23.77" y1="-15.59" x2="24.19" y2="-15.09" layer="51"/>
<rectangle x1="24.21" y1="-15.59" x2="24.63" y2="-15.09" layer="51"/>
<rectangle x1="24.65" y1="-15.59" x2="25.07" y2="-15.09" layer="51"/>
<rectangle x1="25.09" y1="-15.59" x2="25.51" y2="-15.09" layer="51"/>
<rectangle x1="25.53" y1="-15.59" x2="25.95" y2="-15.09" layer="51"/>
<rectangle x1="25.97" y1="-15.59" x2="26.39" y2="-15.09" layer="51"/>
<rectangle x1="26.41" y1="-15.59" x2="26.83" y2="-15.09" layer="51"/>
<rectangle x1="26.85" y1="-15.59" x2="27.27" y2="-15.09" layer="51"/>
<rectangle x1="27.29" y1="-15.59" x2="27.71" y2="-15.09" layer="51"/>
<rectangle x1="27.73" y1="-15.59" x2="28.15" y2="-15.09" layer="51"/>
<rectangle x1="-28.15" y1="-16.11" x2="-27.73" y2="-15.61" layer="51"/>
<rectangle x1="-27.71" y1="-16.11" x2="-27.29" y2="-15.61" layer="51"/>
<rectangle x1="-27.27" y1="-16.11" x2="-26.85" y2="-15.61" layer="51"/>
<rectangle x1="-26.83" y1="-16.11" x2="-26.41" y2="-15.61" layer="51"/>
<rectangle x1="-26.39" y1="-16.11" x2="-25.97" y2="-15.61" layer="51"/>
<rectangle x1="-25.95" y1="-16.11" x2="-25.53" y2="-15.61" layer="51"/>
<rectangle x1="-25.51" y1="-16.11" x2="-25.09" y2="-15.61" layer="51"/>
<rectangle x1="-25.07" y1="-16.11" x2="-24.65" y2="-15.61" layer="51"/>
<rectangle x1="-24.63" y1="-16.11" x2="-24.21" y2="-15.61" layer="51"/>
<rectangle x1="-24.19" y1="-16.11" x2="-23.77" y2="-15.61" layer="51"/>
<rectangle x1="-23.75" y1="-16.11" x2="-23.33" y2="-15.61" layer="51"/>
<rectangle x1="-23.31" y1="-16.11" x2="-22.89" y2="-15.61" layer="51"/>
<rectangle x1="-22.87" y1="-16.11" x2="-22.45" y2="-15.61" layer="51"/>
<rectangle x1="-22.43" y1="-16.11" x2="-22.01" y2="-15.61" layer="51"/>
<rectangle x1="-21.99" y1="-16.11" x2="-21.57" y2="-15.61" layer="51"/>
<rectangle x1="-21.55" y1="-16.11" x2="-21.13" y2="-15.61" layer="51"/>
<rectangle x1="-21.11" y1="-16.11" x2="-20.69" y2="-15.61" layer="51"/>
<rectangle x1="-20.67" y1="-16.11" x2="-20.25" y2="-15.61" layer="51"/>
<rectangle x1="-20.23" y1="-16.11" x2="-19.81" y2="-15.61" layer="51"/>
<rectangle x1="-19.79" y1="-16.11" x2="-19.37" y2="-15.61" layer="51"/>
<rectangle x1="-19.35" y1="-16.11" x2="-18.93" y2="-15.61" layer="51"/>
<rectangle x1="-18.91" y1="-16.11" x2="-18.49" y2="-15.61" layer="51"/>
<rectangle x1="-18.47" y1="-16.11" x2="-18.05" y2="-15.61" layer="51"/>
<rectangle x1="-18.03" y1="-16.11" x2="-17.61" y2="-15.61" layer="51"/>
<rectangle x1="-17.59" y1="-16.11" x2="-17.17" y2="-15.61" layer="51"/>
<rectangle x1="-17.15" y1="-16.11" x2="-16.73" y2="-15.61" layer="51"/>
<rectangle x1="-16.71" y1="-16.11" x2="-16.29" y2="-15.61" layer="51"/>
<rectangle x1="-16.27" y1="-16.11" x2="-15.85" y2="-15.61" layer="51"/>
<rectangle x1="-15.83" y1="-16.11" x2="-15.41" y2="-15.61" layer="51"/>
<rectangle x1="-15.39" y1="-16.11" x2="-14.97" y2="-15.61" layer="51"/>
<rectangle x1="-14.95" y1="-16.11" x2="-14.53" y2="-15.61" layer="51"/>
<rectangle x1="-14.51" y1="-16.11" x2="-14.09" y2="-15.61" layer="51"/>
<rectangle x1="-14.07" y1="-16.11" x2="-13.65" y2="-15.61" layer="51"/>
<rectangle x1="-13.63" y1="-16.11" x2="-13.21" y2="-15.61" layer="51"/>
<rectangle x1="-13.19" y1="-16.11" x2="-12.77" y2="-15.61" layer="51"/>
<rectangle x1="-12.75" y1="-16.11" x2="-12.33" y2="-15.61" layer="51"/>
<rectangle x1="-12.31" y1="-16.11" x2="-11.89" y2="-15.61" layer="51"/>
<rectangle x1="-11.87" y1="-16.11" x2="-11.45" y2="-15.61" layer="51"/>
<rectangle x1="-11.43" y1="-16.11" x2="-11.01" y2="-15.61" layer="51"/>
<rectangle x1="-10.99" y1="-16.11" x2="-10.57" y2="-15.61" layer="51"/>
<rectangle x1="-10.55" y1="-16.11" x2="-10.13" y2="-15.61" layer="51"/>
<rectangle x1="-10.11" y1="-16.11" x2="-9.69" y2="-15.61" layer="51"/>
<rectangle x1="-9.67" y1="-16.11" x2="-9.25" y2="-15.61" layer="51"/>
<rectangle x1="-9.23" y1="-16.11" x2="-8.81" y2="-15.61" layer="51"/>
<rectangle x1="-8.79" y1="-16.11" x2="-8.37" y2="-15.61" layer="51"/>
<rectangle x1="-8.35" y1="-16.11" x2="-7.93" y2="-15.61" layer="51"/>
<rectangle x1="-7.91" y1="-16.11" x2="-7.49" y2="-15.61" layer="51"/>
<rectangle x1="-7.47" y1="-16.11" x2="-7.05" y2="-15.61" layer="51"/>
<rectangle x1="-7.03" y1="-16.11" x2="-6.61" y2="-15.61" layer="51"/>
<rectangle x1="-6.59" y1="-16.11" x2="-6.17" y2="-15.61" layer="51"/>
<rectangle x1="-6.15" y1="-16.11" x2="-5.73" y2="-15.61" layer="51"/>
<rectangle x1="-5.71" y1="-16.11" x2="-5.29" y2="-15.61" layer="51"/>
<rectangle x1="-5.27" y1="-16.11" x2="-4.85" y2="-15.61" layer="51"/>
<rectangle x1="-4.83" y1="-16.11" x2="-4.41" y2="-15.61" layer="51"/>
<rectangle x1="-4.39" y1="-16.11" x2="-3.97" y2="-15.61" layer="51"/>
<rectangle x1="-3.95" y1="-16.11" x2="-3.53" y2="-15.61" layer="51"/>
<rectangle x1="-3.51" y1="-16.11" x2="-3.09" y2="-15.61" layer="51"/>
<rectangle x1="-3.07" y1="-16.11" x2="-2.65" y2="-15.61" layer="51"/>
<rectangle x1="-2.63" y1="-16.11" x2="-2.21" y2="-15.61" layer="51"/>
<rectangle x1="-2.19" y1="-16.11" x2="-1.77" y2="-15.61" layer="51"/>
<rectangle x1="-1.75" y1="-16.11" x2="-1.33" y2="-15.61" layer="51"/>
<rectangle x1="-1.31" y1="-16.11" x2="-0.89" y2="-15.61" layer="51"/>
<rectangle x1="-0.87" y1="-16.11" x2="-0.45" y2="-15.61" layer="51"/>
<rectangle x1="-0.43" y1="-16.11" x2="-0.01" y2="-15.61" layer="51"/>
<rectangle x1="0.01" y1="-16.11" x2="0.43" y2="-15.61" layer="51"/>
<rectangle x1="0.45" y1="-16.11" x2="0.87" y2="-15.61" layer="51"/>
<rectangle x1="0.89" y1="-16.11" x2="1.31" y2="-15.61" layer="51"/>
<rectangle x1="1.33" y1="-16.11" x2="1.75" y2="-15.61" layer="51"/>
<rectangle x1="1.77" y1="-16.11" x2="2.19" y2="-15.61" layer="51"/>
<rectangle x1="2.21" y1="-16.11" x2="2.63" y2="-15.61" layer="51"/>
<rectangle x1="2.65" y1="-16.11" x2="3.07" y2="-15.61" layer="51"/>
<rectangle x1="3.09" y1="-16.11" x2="3.51" y2="-15.61" layer="51"/>
<rectangle x1="3.53" y1="-16.11" x2="3.95" y2="-15.61" layer="51"/>
<rectangle x1="3.97" y1="-16.11" x2="4.39" y2="-15.61" layer="51"/>
<rectangle x1="4.41" y1="-16.11" x2="4.83" y2="-15.61" layer="51"/>
<rectangle x1="4.85" y1="-16.11" x2="5.27" y2="-15.61" layer="51"/>
<rectangle x1="5.29" y1="-16.11" x2="5.71" y2="-15.61" layer="51"/>
<rectangle x1="5.73" y1="-16.11" x2="6.15" y2="-15.61" layer="51"/>
<rectangle x1="6.17" y1="-16.11" x2="6.59" y2="-15.61" layer="51"/>
<rectangle x1="6.61" y1="-16.11" x2="7.03" y2="-15.61" layer="51"/>
<rectangle x1="7.05" y1="-16.11" x2="7.47" y2="-15.61" layer="51"/>
<rectangle x1="7.49" y1="-16.11" x2="7.91" y2="-15.61" layer="51"/>
<rectangle x1="7.93" y1="-16.11" x2="8.35" y2="-15.61" layer="51"/>
<rectangle x1="8.37" y1="-16.11" x2="8.79" y2="-15.61" layer="51"/>
<rectangle x1="8.81" y1="-16.11" x2="9.23" y2="-15.61" layer="51"/>
<rectangle x1="9.25" y1="-16.11" x2="9.67" y2="-15.61" layer="51"/>
<rectangle x1="9.69" y1="-16.11" x2="10.11" y2="-15.61" layer="51"/>
<rectangle x1="10.13" y1="-16.11" x2="10.55" y2="-15.61" layer="51"/>
<rectangle x1="10.57" y1="-16.11" x2="10.99" y2="-15.61" layer="51"/>
<rectangle x1="11.01" y1="-16.11" x2="11.43" y2="-15.61" layer="51"/>
<rectangle x1="11.45" y1="-16.11" x2="11.87" y2="-15.61" layer="51"/>
<rectangle x1="11.89" y1="-16.11" x2="12.31" y2="-15.61" layer="51"/>
<rectangle x1="12.33" y1="-16.11" x2="12.75" y2="-15.61" layer="51"/>
<rectangle x1="12.77" y1="-16.11" x2="13.19" y2="-15.61" layer="51"/>
<rectangle x1="13.21" y1="-16.11" x2="13.63" y2="-15.61" layer="51"/>
<rectangle x1="13.65" y1="-16.11" x2="14.07" y2="-15.61" layer="51"/>
<rectangle x1="14.09" y1="-16.11" x2="14.51" y2="-15.61" layer="51"/>
<rectangle x1="14.53" y1="-16.11" x2="14.95" y2="-15.61" layer="51"/>
<rectangle x1="14.97" y1="-16.11" x2="15.39" y2="-15.61" layer="51"/>
<rectangle x1="15.41" y1="-16.11" x2="15.83" y2="-15.61" layer="51"/>
<rectangle x1="15.85" y1="-16.11" x2="16.27" y2="-15.61" layer="51"/>
<rectangle x1="16.29" y1="-16.11" x2="16.71" y2="-15.61" layer="51"/>
<rectangle x1="16.73" y1="-16.11" x2="17.15" y2="-15.61" layer="51"/>
<rectangle x1="17.17" y1="-16.11" x2="17.59" y2="-15.61" layer="51"/>
<rectangle x1="17.61" y1="-16.11" x2="18.03" y2="-15.61" layer="51"/>
<rectangle x1="18.05" y1="-16.11" x2="18.47" y2="-15.61" layer="51"/>
<rectangle x1="18.49" y1="-16.11" x2="18.91" y2="-15.61" layer="51"/>
<rectangle x1="18.93" y1="-16.11" x2="19.35" y2="-15.61" layer="51"/>
<rectangle x1="19.37" y1="-16.11" x2="19.79" y2="-15.61" layer="51"/>
<rectangle x1="19.81" y1="-16.11" x2="20.23" y2="-15.61" layer="51"/>
<rectangle x1="20.25" y1="-16.11" x2="20.67" y2="-15.61" layer="51"/>
<rectangle x1="20.69" y1="-16.11" x2="21.11" y2="-15.61" layer="51"/>
<rectangle x1="21.13" y1="-16.11" x2="21.55" y2="-15.61" layer="51"/>
<rectangle x1="21.57" y1="-16.11" x2="21.99" y2="-15.61" layer="51"/>
<rectangle x1="22.01" y1="-16.11" x2="22.43" y2="-15.61" layer="51"/>
<rectangle x1="22.45" y1="-16.11" x2="22.87" y2="-15.61" layer="51"/>
<rectangle x1="22.89" y1="-16.11" x2="23.31" y2="-15.61" layer="51"/>
<rectangle x1="23.33" y1="-16.11" x2="23.75" y2="-15.61" layer="51"/>
<rectangle x1="23.77" y1="-16.11" x2="24.19" y2="-15.61" layer="51"/>
<rectangle x1="24.21" y1="-16.11" x2="24.63" y2="-15.61" layer="51"/>
<rectangle x1="24.65" y1="-16.11" x2="25.07" y2="-15.61" layer="51"/>
<rectangle x1="25.09" y1="-16.11" x2="25.51" y2="-15.61" layer="51"/>
<rectangle x1="25.53" y1="-16.11" x2="25.95" y2="-15.61" layer="51"/>
<rectangle x1="25.97" y1="-16.11" x2="26.39" y2="-15.61" layer="51"/>
<rectangle x1="26.41" y1="-16.11" x2="26.83" y2="-15.61" layer="51"/>
<rectangle x1="26.85" y1="-16.11" x2="27.27" y2="-15.61" layer="51"/>
<rectangle x1="27.29" y1="-16.11" x2="27.71" y2="-15.61" layer="51"/>
<rectangle x1="27.73" y1="-16.11" x2="28.15" y2="-15.61" layer="51"/>
<rectangle x1="-28.15" y1="-16.63" x2="-27.73" y2="-16.13" layer="51"/>
<rectangle x1="-27.71" y1="-16.63" x2="-27.29" y2="-16.13" layer="51"/>
<rectangle x1="-27.27" y1="-16.63" x2="-26.85" y2="-16.13" layer="51"/>
<rectangle x1="-26.83" y1="-16.63" x2="-26.41" y2="-16.13" layer="51"/>
<rectangle x1="-26.39" y1="-16.63" x2="-25.97" y2="-16.13" layer="51"/>
<rectangle x1="-25.95" y1="-16.63" x2="-25.53" y2="-16.13" layer="51"/>
<rectangle x1="-25.51" y1="-16.63" x2="-25.09" y2="-16.13" layer="51"/>
<rectangle x1="-25.07" y1="-16.63" x2="-24.65" y2="-16.13" layer="51"/>
<rectangle x1="-24.63" y1="-16.63" x2="-24.21" y2="-16.13" layer="51"/>
<rectangle x1="-24.19" y1="-16.63" x2="-23.77" y2="-16.13" layer="51"/>
<rectangle x1="-23.75" y1="-16.63" x2="-23.33" y2="-16.13" layer="51"/>
<rectangle x1="-23.31" y1="-16.63" x2="-22.89" y2="-16.13" layer="51"/>
<rectangle x1="-22.87" y1="-16.63" x2="-22.45" y2="-16.13" layer="51"/>
<rectangle x1="-22.43" y1="-16.63" x2="-22.01" y2="-16.13" layer="51"/>
<rectangle x1="-21.99" y1="-16.63" x2="-21.57" y2="-16.13" layer="51"/>
<rectangle x1="-21.55" y1="-16.63" x2="-21.13" y2="-16.13" layer="51"/>
<rectangle x1="-21.11" y1="-16.63" x2="-20.69" y2="-16.13" layer="51"/>
<rectangle x1="-20.67" y1="-16.63" x2="-20.25" y2="-16.13" layer="51"/>
<rectangle x1="-20.23" y1="-16.63" x2="-19.81" y2="-16.13" layer="51"/>
<rectangle x1="-19.79" y1="-16.63" x2="-19.37" y2="-16.13" layer="51"/>
<rectangle x1="-19.35" y1="-16.63" x2="-18.93" y2="-16.13" layer="51"/>
<rectangle x1="-18.91" y1="-16.63" x2="-18.49" y2="-16.13" layer="51"/>
<rectangle x1="-18.47" y1="-16.63" x2="-18.05" y2="-16.13" layer="51"/>
<rectangle x1="-18.03" y1="-16.63" x2="-17.61" y2="-16.13" layer="51"/>
<rectangle x1="-17.59" y1="-16.63" x2="-17.17" y2="-16.13" layer="51"/>
<rectangle x1="-17.15" y1="-16.63" x2="-16.73" y2="-16.13" layer="51"/>
<rectangle x1="-16.71" y1="-16.63" x2="-16.29" y2="-16.13" layer="51"/>
<rectangle x1="-16.27" y1="-16.63" x2="-15.85" y2="-16.13" layer="51"/>
<rectangle x1="-15.83" y1="-16.63" x2="-15.41" y2="-16.13" layer="51"/>
<rectangle x1="-15.39" y1="-16.63" x2="-14.97" y2="-16.13" layer="51"/>
<rectangle x1="-14.95" y1="-16.63" x2="-14.53" y2="-16.13" layer="51"/>
<rectangle x1="-14.51" y1="-16.63" x2="-14.09" y2="-16.13" layer="51"/>
<rectangle x1="-14.07" y1="-16.63" x2="-13.65" y2="-16.13" layer="51"/>
<rectangle x1="-13.63" y1="-16.63" x2="-13.21" y2="-16.13" layer="51"/>
<rectangle x1="-13.19" y1="-16.63" x2="-12.77" y2="-16.13" layer="51"/>
<rectangle x1="-12.75" y1="-16.63" x2="-12.33" y2="-16.13" layer="51"/>
<rectangle x1="-12.31" y1="-16.63" x2="-11.89" y2="-16.13" layer="51"/>
<rectangle x1="-11.87" y1="-16.63" x2="-11.45" y2="-16.13" layer="51"/>
<rectangle x1="-11.43" y1="-16.63" x2="-11.01" y2="-16.13" layer="51"/>
<rectangle x1="-10.99" y1="-16.63" x2="-10.57" y2="-16.13" layer="51"/>
<rectangle x1="-10.55" y1="-16.63" x2="-10.13" y2="-16.13" layer="51"/>
<rectangle x1="-10.11" y1="-16.63" x2="-9.69" y2="-16.13" layer="51"/>
<rectangle x1="-9.67" y1="-16.63" x2="-9.25" y2="-16.13" layer="51"/>
<rectangle x1="-9.23" y1="-16.63" x2="-8.81" y2="-16.13" layer="51"/>
<rectangle x1="-8.79" y1="-16.63" x2="-8.37" y2="-16.13" layer="51"/>
<rectangle x1="-8.35" y1="-16.63" x2="-7.93" y2="-16.13" layer="51"/>
<rectangle x1="-7.91" y1="-16.63" x2="-7.49" y2="-16.13" layer="51"/>
<rectangle x1="-7.47" y1="-16.63" x2="-7.05" y2="-16.13" layer="51"/>
<rectangle x1="-7.03" y1="-16.63" x2="-6.61" y2="-16.13" layer="51"/>
<rectangle x1="-6.59" y1="-16.63" x2="-6.17" y2="-16.13" layer="51"/>
<rectangle x1="-6.15" y1="-16.63" x2="-5.73" y2="-16.13" layer="51"/>
<rectangle x1="-5.71" y1="-16.63" x2="-5.29" y2="-16.13" layer="51"/>
<rectangle x1="-5.27" y1="-16.63" x2="-4.85" y2="-16.13" layer="51"/>
<rectangle x1="-4.83" y1="-16.63" x2="-4.41" y2="-16.13" layer="51"/>
<rectangle x1="-4.39" y1="-16.63" x2="-3.97" y2="-16.13" layer="51"/>
<rectangle x1="-3.95" y1="-16.63" x2="-3.53" y2="-16.13" layer="51"/>
<rectangle x1="-3.51" y1="-16.63" x2="-3.09" y2="-16.13" layer="51"/>
<rectangle x1="-3.07" y1="-16.63" x2="-2.65" y2="-16.13" layer="51"/>
<rectangle x1="-2.63" y1="-16.63" x2="-2.21" y2="-16.13" layer="51"/>
<rectangle x1="-2.19" y1="-16.63" x2="-1.77" y2="-16.13" layer="51"/>
<rectangle x1="-1.75" y1="-16.63" x2="-1.33" y2="-16.13" layer="51"/>
<rectangle x1="-1.31" y1="-16.63" x2="-0.89" y2="-16.13" layer="51"/>
<rectangle x1="-0.87" y1="-16.63" x2="-0.45" y2="-16.13" layer="51"/>
<rectangle x1="-0.43" y1="-16.63" x2="-0.01" y2="-16.13" layer="51"/>
<rectangle x1="0.01" y1="-16.63" x2="0.43" y2="-16.13" layer="51"/>
<rectangle x1="0.45" y1="-16.63" x2="0.87" y2="-16.13" layer="51"/>
<rectangle x1="0.89" y1="-16.63" x2="1.31" y2="-16.13" layer="51"/>
<rectangle x1="1.33" y1="-16.63" x2="1.75" y2="-16.13" layer="51"/>
<rectangle x1="1.77" y1="-16.63" x2="2.19" y2="-16.13" layer="51"/>
<rectangle x1="2.21" y1="-16.63" x2="2.63" y2="-16.13" layer="51"/>
<rectangle x1="2.65" y1="-16.63" x2="3.07" y2="-16.13" layer="51"/>
<rectangle x1="3.09" y1="-16.63" x2="3.51" y2="-16.13" layer="51"/>
<rectangle x1="3.53" y1="-16.63" x2="3.95" y2="-16.13" layer="51"/>
<rectangle x1="3.97" y1="-16.63" x2="4.39" y2="-16.13" layer="51"/>
<rectangle x1="4.41" y1="-16.63" x2="4.83" y2="-16.13" layer="51"/>
<rectangle x1="4.85" y1="-16.63" x2="5.27" y2="-16.13" layer="51"/>
<rectangle x1="5.29" y1="-16.63" x2="5.71" y2="-16.13" layer="51"/>
<rectangle x1="5.73" y1="-16.63" x2="6.15" y2="-16.13" layer="51"/>
<rectangle x1="6.17" y1="-16.63" x2="6.59" y2="-16.13" layer="51"/>
<rectangle x1="6.61" y1="-16.63" x2="7.03" y2="-16.13" layer="51"/>
<rectangle x1="7.05" y1="-16.63" x2="7.47" y2="-16.13" layer="51"/>
<rectangle x1="7.49" y1="-16.63" x2="7.91" y2="-16.13" layer="51"/>
<rectangle x1="7.93" y1="-16.63" x2="8.35" y2="-16.13" layer="51"/>
<rectangle x1="8.37" y1="-16.63" x2="8.79" y2="-16.13" layer="51"/>
<rectangle x1="8.81" y1="-16.63" x2="9.23" y2="-16.13" layer="51"/>
<rectangle x1="9.25" y1="-16.63" x2="9.67" y2="-16.13" layer="51"/>
<rectangle x1="9.69" y1="-16.63" x2="10.11" y2="-16.13" layer="51"/>
<rectangle x1="10.13" y1="-16.63" x2="10.55" y2="-16.13" layer="51"/>
<rectangle x1="10.57" y1="-16.63" x2="10.99" y2="-16.13" layer="51"/>
<rectangle x1="11.01" y1="-16.63" x2="11.43" y2="-16.13" layer="51"/>
<rectangle x1="11.45" y1="-16.63" x2="11.87" y2="-16.13" layer="51"/>
<rectangle x1="11.89" y1="-16.63" x2="12.31" y2="-16.13" layer="51"/>
<rectangle x1="12.33" y1="-16.63" x2="12.75" y2="-16.13" layer="51"/>
<rectangle x1="12.77" y1="-16.63" x2="13.19" y2="-16.13" layer="51"/>
<rectangle x1="13.21" y1="-16.63" x2="13.63" y2="-16.13" layer="51"/>
<rectangle x1="13.65" y1="-16.63" x2="14.07" y2="-16.13" layer="51"/>
<rectangle x1="14.09" y1="-16.63" x2="14.51" y2="-16.13" layer="51"/>
<rectangle x1="14.53" y1="-16.63" x2="14.95" y2="-16.13" layer="51"/>
<rectangle x1="14.97" y1="-16.63" x2="15.39" y2="-16.13" layer="51"/>
<rectangle x1="15.41" y1="-16.63" x2="15.83" y2="-16.13" layer="51"/>
<rectangle x1="15.85" y1="-16.63" x2="16.27" y2="-16.13" layer="51"/>
<rectangle x1="16.29" y1="-16.63" x2="16.71" y2="-16.13" layer="51"/>
<rectangle x1="16.73" y1="-16.63" x2="17.15" y2="-16.13" layer="51"/>
<rectangle x1="17.17" y1="-16.63" x2="17.59" y2="-16.13" layer="51"/>
<rectangle x1="17.61" y1="-16.63" x2="18.03" y2="-16.13" layer="51"/>
<rectangle x1="18.05" y1="-16.63" x2="18.47" y2="-16.13" layer="51"/>
<rectangle x1="18.49" y1="-16.63" x2="18.91" y2="-16.13" layer="51"/>
<rectangle x1="18.93" y1="-16.63" x2="19.35" y2="-16.13" layer="51"/>
<rectangle x1="19.37" y1="-16.63" x2="19.79" y2="-16.13" layer="51"/>
<rectangle x1="19.81" y1="-16.63" x2="20.23" y2="-16.13" layer="51"/>
<rectangle x1="20.25" y1="-16.63" x2="20.67" y2="-16.13" layer="51"/>
<rectangle x1="20.69" y1="-16.63" x2="21.11" y2="-16.13" layer="51"/>
<rectangle x1="21.13" y1="-16.63" x2="21.55" y2="-16.13" layer="51"/>
<rectangle x1="21.57" y1="-16.63" x2="21.99" y2="-16.13" layer="51"/>
<rectangle x1="22.01" y1="-16.63" x2="22.43" y2="-16.13" layer="51"/>
<rectangle x1="22.45" y1="-16.63" x2="22.87" y2="-16.13" layer="51"/>
<rectangle x1="22.89" y1="-16.63" x2="23.31" y2="-16.13" layer="51"/>
<rectangle x1="23.33" y1="-16.63" x2="23.75" y2="-16.13" layer="51"/>
<rectangle x1="23.77" y1="-16.63" x2="24.19" y2="-16.13" layer="51"/>
<rectangle x1="24.21" y1="-16.63" x2="24.63" y2="-16.13" layer="51"/>
<rectangle x1="24.65" y1="-16.63" x2="25.07" y2="-16.13" layer="51"/>
<rectangle x1="25.09" y1="-16.63" x2="25.51" y2="-16.13" layer="51"/>
<rectangle x1="25.53" y1="-16.63" x2="25.95" y2="-16.13" layer="51"/>
<rectangle x1="25.97" y1="-16.63" x2="26.39" y2="-16.13" layer="51"/>
<rectangle x1="26.41" y1="-16.63" x2="26.83" y2="-16.13" layer="51"/>
<rectangle x1="26.85" y1="-16.63" x2="27.27" y2="-16.13" layer="51"/>
<rectangle x1="27.29" y1="-16.63" x2="27.71" y2="-16.13" layer="51"/>
<rectangle x1="27.73" y1="-16.63" x2="28.15" y2="-16.13" layer="51"/>
</package>
<package name="HDM64GS12_-R">
<description>&lt;b&gt;HDM64GS12_-R&lt;/b&gt; 128 X 64 Dots Graphic&lt;p&gt;
Source: http://www.hantronix.com/down/64gs12-r.pdf</description>
<wire x1="-33.26" y1="16.62" x2="-33.26" y2="-16.62" width="0.04" layer="21"/>
<wire x1="33.26" y1="16.62" x2="33.26" y2="-16.62" width="0.04" layer="21"/>
<wire x1="-46.4" y1="34.9" x2="46.4" y2="34.9" width="0.2032" layer="21"/>
<wire x1="46.4" y1="34.9" x2="46.4" y2="-34.9" width="0.2032" layer="21"/>
<wire x1="46.4" y1="-34.9" x2="-46.4" y2="-34.9" width="0.2032" layer="21"/>
<wire x1="-46.4" y1="-34.9" x2="-46.4" y2="34.9" width="0.2032" layer="21"/>
<wire x1="-33.26" y1="16.62" x2="33.26" y2="16.62" width="0.04" layer="21"/>
<wire x1="33.26" y1="-16.62" x2="-33.26" y2="-16.62" width="0.04" layer="21"/>
<wire x1="-36" y1="20" x2="36" y2="20" width="0.04" layer="21"/>
<wire x1="36" y1="-20" x2="-36" y2="-20" width="0.04" layer="21"/>
<wire x1="-36" y1="20" x2="-36" y2="-20" width="0.04" layer="21"/>
<wire x1="36" y1="-20" x2="36" y2="20" width="0.04" layer="21"/>
<wire x1="-33" y1="0" x2="33" y2="0" width="0.04" layer="51"/>
<wire x1="-33" y1="0.5" x2="33" y2="0.5" width="0.04" layer="51"/>
<wire x1="-33" y1="1" x2="33" y2="1" width="0.04" layer="51"/>
<wire x1="-33" y1="1.5" x2="33" y2="1.5" width="0.04" layer="51"/>
<wire x1="-33" y1="2" x2="33" y2="2" width="0.04" layer="51"/>
<wire x1="-33" y1="2.5" x2="33" y2="2.5" width="0.04" layer="51"/>
<wire x1="-33" y1="3" x2="33" y2="3" width="0.04" layer="51"/>
<wire x1="-33" y1="3.5" x2="33" y2="3.5" width="0.04" layer="51"/>
<wire x1="-33" y1="4" x2="33" y2="4" width="0.04" layer="51"/>
<wire x1="-33" y1="4.5" x2="33" y2="4.5" width="0.04" layer="51"/>
<wire x1="-33" y1="5" x2="33" y2="5" width="0.04" layer="51"/>
<wire x1="-33" y1="5.5" x2="33" y2="5.5" width="0.04" layer="51"/>
<wire x1="-33" y1="6" x2="33" y2="6" width="0.04" layer="51"/>
<wire x1="-33" y1="6.5" x2="33" y2="6.5" width="0.04" layer="51"/>
<wire x1="-33" y1="7" x2="33" y2="7" width="0.04" layer="51"/>
<wire x1="-33" y1="7.5" x2="33" y2="7.5" width="0.04" layer="51"/>
<wire x1="-33" y1="8" x2="33" y2="8" width="0.04" layer="51"/>
<wire x1="-33" y1="8.5" x2="33" y2="8.5" width="0.04" layer="51"/>
<wire x1="-33" y1="9" x2="33" y2="9" width="0.04" layer="51"/>
<wire x1="-33" y1="9.5" x2="33" y2="9.5" width="0.04" layer="51"/>
<wire x1="-33" y1="10" x2="33" y2="10" width="0.04" layer="51"/>
<wire x1="-33" y1="10.5" x2="33" y2="10.5" width="0.04" layer="51"/>
<wire x1="-33" y1="11" x2="33" y2="11" width="0.04" layer="51"/>
<wire x1="-33" y1="11.5" x2="33" y2="11.5" width="0.04" layer="51"/>
<wire x1="-33" y1="12" x2="33" y2="12" width="0.04" layer="51"/>
<wire x1="-33" y1="12.5" x2="33" y2="12.5" width="0.04" layer="51"/>
<wire x1="-33" y1="13" x2="33" y2="13" width="0.04" layer="51"/>
<wire x1="-33" y1="13.5" x2="33" y2="13.5" width="0.04" layer="51"/>
<wire x1="-33" y1="14" x2="33" y2="14" width="0.04" layer="51"/>
<wire x1="-33" y1="14.5" x2="33" y2="14.5" width="0.04" layer="51"/>
<wire x1="-33" y1="15" x2="33" y2="15" width="0.04" layer="51"/>
<wire x1="-33" y1="15.5" x2="33" y2="15.5" width="0.04" layer="51"/>
<wire x1="-33" y1="16" x2="33" y2="16" width="0.04" layer="51"/>
<wire x1="-33" y1="16.5" x2="33" y2="16.5" width="0.04" layer="51"/>
<wire x1="-33" y1="-16.5" x2="33" y2="-16.5" width="0.04" layer="51"/>
<wire x1="-33" y1="-16" x2="33" y2="-16" width="0.04" layer="51"/>
<wire x1="-33" y1="-15.5" x2="33" y2="-15.5" width="0.04" layer="51"/>
<wire x1="-33" y1="-15" x2="33" y2="-15" width="0.04" layer="51"/>
<wire x1="-33" y1="-14.5" x2="33" y2="-14.5" width="0.04" layer="51"/>
<wire x1="-33" y1="-14" x2="33" y2="-14" width="0.04" layer="51"/>
<wire x1="-33" y1="-13.5" x2="33" y2="-13.5" width="0.04" layer="51"/>
<wire x1="-33" y1="-13" x2="33" y2="-13" width="0.04" layer="51"/>
<wire x1="-33" y1="-12.5" x2="33" y2="-12.5" width="0.04" layer="51"/>
<wire x1="-33" y1="-12" x2="33" y2="-12" width="0.04" layer="51"/>
<wire x1="-33" y1="-11.5" x2="33" y2="-11.5" width="0.04" layer="51"/>
<wire x1="-33" y1="-11" x2="33" y2="-11" width="0.04" layer="51"/>
<wire x1="-33" y1="-10.5" x2="33" y2="-10.5" width="0.04" layer="51"/>
<wire x1="-33" y1="-10" x2="33" y2="-10" width="0.04" layer="51"/>
<wire x1="-33" y1="-9.5" x2="33" y2="-9.5" width="0.04" layer="51"/>
<wire x1="-33" y1="-9" x2="33" y2="-9" width="0.04" layer="51"/>
<wire x1="-33" y1="-8.5" x2="33" y2="-8.5" width="0.04" layer="51"/>
<wire x1="-33" y1="-8" x2="33" y2="-8" width="0.04" layer="51"/>
<wire x1="-33" y1="-7.5" x2="33" y2="-7.5" width="0.04" layer="51"/>
<wire x1="-33" y1="-7" x2="33" y2="-7" width="0.04" layer="51"/>
<wire x1="-33" y1="-6.5" x2="33" y2="-6.5" width="0.04" layer="51"/>
<wire x1="-33" y1="-6" x2="33" y2="-6" width="0.04" layer="51"/>
<wire x1="-33" y1="-5.5" x2="33" y2="-5.5" width="0.04" layer="51"/>
<wire x1="-33" y1="-5" x2="33" y2="-5" width="0.04" layer="51"/>
<wire x1="-33" y1="-4.5" x2="33" y2="-4.5" width="0.04" layer="51"/>
<wire x1="-33" y1="-4" x2="33" y2="-4" width="0.04" layer="51"/>
<wire x1="-33" y1="-3.5" x2="33" y2="-3.5" width="0.04" layer="51"/>
<wire x1="-33" y1="-3" x2="33" y2="-3" width="0.04" layer="51"/>
<wire x1="-33" y1="-2.5" x2="33" y2="-2.5" width="0.04" layer="51"/>
<wire x1="-33" y1="-2" x2="33" y2="-2" width="0.04" layer="51"/>
<wire x1="-33" y1="-1.5" x2="33" y2="-1.5" width="0.04" layer="51"/>
<wire x1="-33" y1="-1" x2="33" y2="-1" width="0.04" layer="51"/>
<wire x1="-33" y1="-0.5" x2="33" y2="-0.5" width="0.04" layer="51"/>
<wire x1="0" y1="-16.5" x2="0" y2="16.5" width="0.04" layer="51"/>
<wire x1="-0.5" y1="-16.5" x2="-0.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-1" y1="-16.5" x2="-1" y2="16.5" width="0.04" layer="51"/>
<wire x1="-1.5" y1="-16.5" x2="-1.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-2" y1="-16.5" x2="-2" y2="16.5" width="0.04" layer="51"/>
<wire x1="-2.5" y1="-16.5" x2="-2.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-3" y1="-16.5" x2="-3" y2="16.5" width="0.04" layer="51"/>
<wire x1="-3.5" y1="-16.5" x2="-3.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-4" y1="-16.5" x2="-4" y2="16.5" width="0.04" layer="51"/>
<wire x1="-4.5" y1="-16.5" x2="-4.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-5" y1="-16.5" x2="-5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-5.5" y1="-16.5" x2="-5.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-6" y1="-16.5" x2="-6" y2="16.5" width="0.04" layer="51"/>
<wire x1="-6.5" y1="-16.5" x2="-6.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-7" y1="-16.5" x2="-7" y2="16.5" width="0.04" layer="51"/>
<wire x1="-7.5" y1="-16.5" x2="-7.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-8" y1="-16.5" x2="-8" y2="16.5" width="0.04" layer="51"/>
<wire x1="-8.5" y1="-16.5" x2="-8.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-9" y1="-16.5" x2="-9" y2="16.5" width="0.04" layer="51"/>
<wire x1="-9.5" y1="-16.5" x2="-9.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-10" y1="-16.5" x2="-10" y2="16.5" width="0.04" layer="51"/>
<wire x1="-10.5" y1="-16.5" x2="-10.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-11" y1="-16.5" x2="-11" y2="16.5" width="0.04" layer="51"/>
<wire x1="-11.5" y1="-16.5" x2="-11.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-12" y1="-16.5" x2="-12" y2="16.5" width="0.04" layer="51"/>
<wire x1="-12.5" y1="-16.5" x2="-12.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-13" y1="-16.5" x2="-13" y2="16.5" width="0.04" layer="51"/>
<wire x1="-13.5" y1="-16.5" x2="-13.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-14" y1="-16.5" x2="-14" y2="16.5" width="0.04" layer="51"/>
<wire x1="-14.5" y1="-16.5" x2="-14.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-15" y1="-16.5" x2="-15" y2="16.5" width="0.04" layer="51"/>
<wire x1="-15.5" y1="-16.5" x2="-15.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-16" y1="-16.5" x2="-16" y2="16.5" width="0.04" layer="51"/>
<wire x1="-16.5" y1="-16.5" x2="-16.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-17" y1="-16.5" x2="-17" y2="16.5" width="0.04" layer="51"/>
<wire x1="-17.5" y1="-16.5" x2="-17.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-18" y1="-16.5" x2="-18" y2="16.5" width="0.04" layer="51"/>
<wire x1="-18.5" y1="-16.5" x2="-18.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-19" y1="-16.5" x2="-19" y2="16.5" width="0.04" layer="51"/>
<wire x1="-19.5" y1="-16.5" x2="-19.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-20" y1="-16.5" x2="-20" y2="16.5" width="0.04" layer="51"/>
<wire x1="-20.5" y1="-16.5" x2="-20.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-21" y1="-16.5" x2="-21" y2="16.5" width="0.04" layer="51"/>
<wire x1="-21.5" y1="-16.5" x2="-21.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-22" y1="-16.5" x2="-22" y2="16.5" width="0.04" layer="51"/>
<wire x1="-22.5" y1="-16.5" x2="-22.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-23" y1="-16.5" x2="-23" y2="16.5" width="0.04" layer="51"/>
<wire x1="-23.5" y1="-16.5" x2="-23.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-24" y1="-16.5" x2="-24" y2="16.5" width="0.04" layer="51"/>
<wire x1="-24.5" y1="-16.5" x2="-24.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-25" y1="-16.5" x2="-25" y2="16.5" width="0.04" layer="51"/>
<wire x1="-25.5" y1="-16.5" x2="-25.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-26" y1="-16.5" x2="-26" y2="16.5" width="0.04" layer="51"/>
<wire x1="-26.5" y1="-16.5" x2="-26.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-27" y1="-16.5" x2="-27" y2="16.5" width="0.04" layer="51"/>
<wire x1="-27.5" y1="-16.5" x2="-27.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-28" y1="-16.5" x2="-28" y2="16.5" width="0.04" layer="51"/>
<wire x1="-28.5" y1="-16.5" x2="-28.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-29" y1="-16.5" x2="-29" y2="16.5" width="0.04" layer="51"/>
<wire x1="-29.5" y1="-16.5" x2="-29.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-30" y1="-16.5" x2="-30" y2="16.5" width="0.04" layer="51"/>
<wire x1="-30.5" y1="-16.5" x2="-30.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-31" y1="-16.5" x2="-31" y2="16.5" width="0.04" layer="51"/>
<wire x1="-31.5" y1="-16.5" x2="-31.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-32" y1="-16.5" x2="-32" y2="16.5" width="0.04" layer="51"/>
<wire x1="-32.5" y1="-16.5" x2="-32.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="-33" y1="-16.5" x2="-33" y2="16.5" width="0.04" layer="51"/>
<wire x1="33" y1="-16.5" x2="33" y2="16.5" width="0.04" layer="51"/>
<wire x1="32.5" y1="-16.5" x2="32.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="32" y1="-16.5" x2="32" y2="16.5" width="0.04" layer="51"/>
<wire x1="31.5" y1="-16.5" x2="31.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="31" y1="-16.5" x2="31" y2="16.5" width="0.04" layer="51"/>
<wire x1="30.5" y1="-16.5" x2="30.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="30" y1="-16.5" x2="30" y2="16.5" width="0.04" layer="51"/>
<wire x1="29.5" y1="-16.5" x2="29.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="29" y1="-16.5" x2="29" y2="16.5" width="0.04" layer="51"/>
<wire x1="28.5" y1="-16.5" x2="28.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="28" y1="-16.5" x2="28" y2="16.5" width="0.04" layer="51"/>
<wire x1="27.5" y1="-16.5" x2="27.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="27" y1="-16.5" x2="27" y2="16.5" width="0.04" layer="51"/>
<wire x1="26.5" y1="-16.5" x2="26.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="26" y1="-16.5" x2="26" y2="16.5" width="0.04" layer="51"/>
<wire x1="25.5" y1="-16.5" x2="25.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="25" y1="-16.5" x2="25" y2="16.5" width="0.04" layer="51"/>
<wire x1="24.5" y1="-16.5" x2="24.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="24" y1="-16.5" x2="24" y2="16.5" width="0.04" layer="51"/>
<wire x1="23.5" y1="-16.5" x2="23.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="23" y1="-16.5" x2="23" y2="16.5" width="0.04" layer="51"/>
<wire x1="22.5" y1="-16.5" x2="22.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="22" y1="-16.5" x2="22" y2="16.5" width="0.04" layer="51"/>
<wire x1="21.5" y1="-16.5" x2="21.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="21" y1="-16.5" x2="21" y2="16.5" width="0.04" layer="51"/>
<wire x1="20.5" y1="-16.5" x2="20.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="20" y1="-16.5" x2="20" y2="16.5" width="0.04" layer="51"/>
<wire x1="19.5" y1="-16.5" x2="19.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="19" y1="-16.5" x2="19" y2="16.5" width="0.04" layer="51"/>
<wire x1="18.5" y1="-16.5" x2="18.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="18" y1="-16.5" x2="18" y2="16.5" width="0.04" layer="51"/>
<wire x1="17.5" y1="-16.5" x2="17.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="17" y1="-16.5" x2="17" y2="16.5" width="0.04" layer="51"/>
<wire x1="16.5" y1="-16.5" x2="16.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="16" y1="-16.5" x2="16" y2="16.5" width="0.04" layer="51"/>
<wire x1="15.5" y1="-16.5" x2="15.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="15" y1="-16.5" x2="15" y2="16.5" width="0.04" layer="51"/>
<wire x1="14.5" y1="-16.5" x2="14.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="14" y1="-16.5" x2="14" y2="16.5" width="0.04" layer="51"/>
<wire x1="13.5" y1="-16.5" x2="13.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="13" y1="-16.5" x2="13" y2="16.5" width="0.04" layer="51"/>
<wire x1="12.5" y1="-16.5" x2="12.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="12" y1="-16.5" x2="12" y2="16.5" width="0.04" layer="51"/>
<wire x1="11.5" y1="-16.5" x2="11.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="11" y1="-16.5" x2="11" y2="16.5" width="0.04" layer="51"/>
<wire x1="10.5" y1="-16.5" x2="10.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="10" y1="-16.5" x2="10" y2="16.5" width="0.04" layer="51"/>
<wire x1="9.5" y1="-16.5" x2="9.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="9" y1="-16.5" x2="9" y2="16.5" width="0.04" layer="51"/>
<wire x1="8.5" y1="-16.5" x2="8.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="8" y1="-16.5" x2="8" y2="16.5" width="0.04" layer="51"/>
<wire x1="7.5" y1="-16.5" x2="7.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="7" y1="-16.5" x2="7" y2="16.5" width="0.04" layer="51"/>
<wire x1="6.5" y1="-16.5" x2="6.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="6" y1="-16.5" x2="6" y2="16.5" width="0.04" layer="51"/>
<wire x1="5.5" y1="-16.5" x2="5.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="5" y1="-16.5" x2="5" y2="16.5" width="0.04" layer="51"/>
<wire x1="4.5" y1="-16.5" x2="4.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="4" y1="-16.5" x2="4" y2="16.5" width="0.04" layer="51"/>
<wire x1="3.5" y1="-16.5" x2="3.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="3" y1="-16.5" x2="3" y2="16.5" width="0.04" layer="51"/>
<wire x1="2.5" y1="-16.5" x2="2.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="2" y1="-16.5" x2="2" y2="16.5" width="0.04" layer="51"/>
<wire x1="1.5" y1="-16.5" x2="1.5" y2="16.5" width="0.04" layer="51"/>
<wire x1="1" y1="-16.5" x2="1" y2="16.5" width="0.04" layer="51"/>
<wire x1="0.5" y1="-16.5" x2="0.5" y2="16.5" width="0.04" layer="51"/>
<pad name="1" x="15.76" y="-32.5" drill="1.1" shape="offset" rot="R270"/>
<pad name="2" x="13.22" y="-32.5" drill="1.1" shape="offset" rot="R270"/>
<pad name="3" x="10.68" y="-32.5" drill="1.1" shape="offset" rot="R270"/>
<pad name="4" x="8.14" y="-32.5" drill="1.1" shape="offset" rot="R270"/>
<pad name="5" x="5.6" y="-32.5" drill="1.1" shape="offset" rot="R270"/>
<pad name="6" x="3.06" y="-32.5" drill="1.1" shape="offset" rot="R270"/>
<pad name="7" x="0.52" y="-32.5" drill="1.1" shape="offset" rot="R270"/>
<pad name="8" x="-2.02" y="-32.5" drill="1.1" shape="offset" rot="R270"/>
<pad name="9" x="-4.56" y="-32.5" drill="1.1" shape="offset" rot="R270"/>
<pad name="10" x="-7.1" y="-32.5" drill="1.1" shape="offset" rot="R270"/>
<pad name="11" x="-9.64" y="-32.5" drill="1.1" shape="offset" rot="R270"/>
<pad name="12" x="-12.18" y="-32.5" drill="1.1" shape="offset" rot="R270"/>
<pad name="13" x="-14.72" y="-32.5" drill="1.1" shape="offset" rot="R270"/>
<pad name="14" x="-17.26" y="-32.5" drill="1.1" shape="offset" rot="R270"/>
<pad name="15" x="-19.8" y="-32.5" drill="1.1" shape="offset" rot="R270"/>
<pad name="16" x="-22.34" y="-32.5" drill="1.1" shape="offset" rot="R270"/>
<pad name="17" x="-24.88" y="-32.5" drill="1.1" shape="offset" rot="R270"/>
<pad name="18" x="-27.42" y="-32.5" drill="1.1" shape="offset" rot="R270"/>
<pad name="19" x="-29.96" y="-32.5" drill="1.1" shape="offset" rot="R270"/>
<pad name="20" x="-32.5" y="-32.5" drill="1.1" shape="offset" rot="R270"/>
<text x="-45.72" y="-38.1" size="1.778" layer="25">&gt;NAME</text>
<text x="-34.29" y="-38.1" size="1.778" layer="27">&gt;VALUE</text>
<hole x="-44" y="-32.5" drill="2.5"/>
<hole x="44" y="-32.5" drill="2.5"/>
<hole x="-44" y="32.5" drill="2.5"/>
<hole x="44" y="32.5" drill="2.5"/>
</package>
<package name="SBLCDA4">
<description>&lt;b&gt;LCD Display SBLCDA4&lt;/b&gt;&lt;p&gt;
Source: http://www.softbaugh.com/downloads/SBLCDA4_Specification.pdf</description>
<wire x1="-20.2965" y1="10.163" x2="20.297" y2="10.163" width="0.1016" layer="21"/>
<wire x1="20.297" y1="10.163" x2="20.297" y2="7.6387" width="0.1016" layer="21"/>
<wire x1="20.297" y1="7.6387" x2="20.297" y2="-7.6436" width="0.1016" layer="21"/>
<wire x1="20.297" y1="-7.6436" x2="20.297" y2="-10.1338" width="0.1016" layer="21"/>
<wire x1="20.297" y1="-10.1338" x2="-20.2965" y2="-10.1338" width="0.1016" layer="21"/>
<wire x1="-20.2965" y1="-10.1338" x2="-20.2965" y2="-7.6436" width="0.1016" layer="21"/>
<wire x1="-20.2965" y1="-7.6436" x2="-20.2965" y2="7.6387" width="0.1016" layer="21"/>
<wire x1="-20.2965" y1="7.6387" x2="-20.2965" y2="10.163" width="0.1016" layer="21"/>
<wire x1="-20.2965" y1="7.6387" x2="20.297" y2="7.6387" width="0.1016" layer="21"/>
<wire x1="20.297" y1="-7.6436" x2="-20.2965" y2="-7.6436" width="0.1016" layer="21"/>
<wire x1="-19.0343" y1="6.3765" x2="19.0008" y2="6.3765" width="0.1016" layer="21"/>
<wire x1="19.0008" y1="6.3765" x2="19.0008" y2="-6.3132" width="0.1016" layer="21"/>
<wire x1="19.0008" y1="-6.3132" x2="-19.0343" y2="-6.3132" width="0.1016" layer="21"/>
<wire x1="-19.0343" y1="-6.3132" x2="-19.0343" y2="6.3765" width="0.1016" layer="21"/>
<wire x1="-17.397" y1="5.7284" x2="-13.9857" y2="5.7284" width="0.1016" layer="21"/>
<wire x1="-13.9857" y1="5.7284" x2="-13.9857" y2="3.17" width="0.1016" layer="21"/>
<wire x1="-13.9857" y1="3.17" x2="-17.397" y2="3.17" width="0.1016" layer="21"/>
<wire x1="-17.397" y1="3.17" x2="-17.397" y2="5.7284" width="0.1016" layer="21"/>
<wire x1="-16.9194" y1="5.3531" x2="-14.4633" y2="5.3531" width="0.1016" layer="21"/>
<wire x1="-14.4633" y1="5.3531" x2="-15.4867" y2="4.5686" width="0.1016" layer="21"/>
<wire x1="-15.4867" y1="4.5686" x2="-15.896" y2="4.5686" width="0.1016" layer="21"/>
<wire x1="-15.896" y1="4.5686" x2="-16.9194" y2="5.3531" width="0.1016" layer="21"/>
<wire x1="-17.0558" y1="5.0461" x2="-15.9984" y2="4.2274" width="0.1016" layer="21"/>
<wire x1="-15.9984" y1="4.2274" x2="-15.4185" y2="4.2274" width="0.1016" layer="21"/>
<wire x1="-15.4185" y1="4.2274" x2="-14.3269" y2="5.0461" width="0.1016" layer="21"/>
<wire x1="-14.3269" y1="5.0461" x2="-14.3269" y2="3.5111" width="0.1016" layer="21"/>
<wire x1="-14.3269" y1="3.5111" x2="-17.0558" y2="3.5111" width="0.1016" layer="21"/>
<wire x1="-17.0558" y1="3.5111" x2="-17.0558" y2="5.0461" width="0.1016" layer="21"/>
<wire x1="-12.7236" y1="5.7284" x2="-8.1867" y2="5.7284" width="0.1016" layer="21"/>
<wire x1="-8.1867" y1="5.7284" x2="-8.1867" y2="5.2508" width="0.1016" layer="21"/>
<wire x1="-8.1867" y1="5.2508" x2="-10.2334" y2="3.2041" width="0.1016" layer="21"/>
<wire x1="-10.2334" y1="3.2041" x2="-10.2334" y2="1.1573" width="0.1016" layer="21"/>
<wire x1="-10.2334" y1="1.1573" x2="-10.6769" y2="1.1573" width="0.1016" layer="21"/>
<wire x1="-10.6769" y1="1.1573" x2="-10.6769" y2="3.2041" width="0.1016" layer="21"/>
<wire x1="-10.6769" y1="3.2041" x2="-12.7236" y2="5.2508" width="0.1016" layer="21"/>
<wire x1="-12.7236" y1="5.2508" x2="-12.7236" y2="5.7284" width="0.1016" layer="21"/>
<wire x1="-12.1096" y1="5.2849" x2="-10.6769" y2="5.2849" width="0.1016" layer="21"/>
<wire x1="-10.6769" y1="5.2849" x2="-10.6769" y2="3.8522" width="0.1016" layer="21"/>
<wire x1="-10.6769" y1="3.8522" x2="-12.1096" y2="5.2849" width="0.1016" layer="21"/>
<wire x1="-10.2334" y1="5.2849" x2="-8.8689" y2="5.2849" width="0.1016" layer="21"/>
<wire x1="-8.8689" y1="5.2849" x2="-10.2334" y2="3.8522" width="0.1016" layer="21"/>
<wire x1="-10.2334" y1="3.8522" x2="-10.2334" y2="5.2849" width="0.1016" layer="21"/>
<wire x1="-7.7091" y1="5.7284" x2="-5.9012" y2="5.7284" width="0.1016" layer="21"/>
<wire x1="-5.9012" y1="5.7284" x2="-7.7091" y2="1.1573" width="0.1016" layer="21"/>
<wire x1="-7.7091" y1="1.1573" x2="-7.7091" y2="5.7284" width="0.1016" layer="21"/>
<wire x1="-4.8096" y1="5.319" x2="-4.332" y2="5.319" width="0.1016" layer="21"/>
<wire x1="-4.332" y1="5.319" x2="-3.4451" y2="5.319" width="0.1016" layer="21" curve="-180"/>
<wire x1="-3.4451" y1="5.319" x2="-2.9675" y2="5.319" width="0.1016" layer="21"/>
<wire x1="-2.9675" y1="5.319" x2="-2.9675" y2="1.1573" width="0.1016" layer="21"/>
<wire x1="-2.9675" y1="1.1573" x2="-4.8096" y2="1.1573" width="0.1016" layer="21"/>
<wire x1="-4.8096" y1="1.1573" x2="-4.8096" y2="5.319" width="0.1016" layer="21"/>
<wire x1="-4.7754" y1="5.1144" x2="-3.0357" y2="5.1144" width="0.1016" layer="21"/>
<wire x1="-4.7413" y1="3.3405" x2="-3.0016" y2="3.3405" width="0.1016" layer="21"/>
<wire x1="-4.7413" y1="1.6349" x2="-3.0357" y2="1.6349" width="0.1016" layer="21"/>
<wire x1="-1.8077" y1="3.0335" x2="-0.4091" y2="4.4321" width="0.1016" layer="21"/>
<wire x1="-0.4091" y1="4.4321" x2="-0.4091" y2="3.6134" width="0.1016" layer="21"/>
<wire x1="-0.4091" y1="3.6134" x2="0.5119" y2="3.4429" width="0.1016" layer="21"/>
<wire x1="0.5119" y1="3.4429" x2="0.5119" y2="2.6924" width="0.1016" layer="21"/>
<wire x1="0.5119" y1="2.6924" x2="-0.4091" y2="2.4877" width="0.1016" layer="21"/>
<wire x1="-0.4091" y1="2.4877" x2="-0.4091" y2="1.6349" width="0.1016" layer="21"/>
<wire x1="-0.4091" y1="1.6349" x2="-1.8077" y2="3.0335" width="0.1016" layer="21"/>
<wire x1="1.7741" y1="0.3386" x2="0.3755" y2="1.7372" width="0.1016" layer="21"/>
<wire x1="0.3755" y1="1.7372" x2="1.1942" y2="1.7372" width="0.1016" layer="21"/>
<wire x1="1.1942" y1="1.7372" x2="1.3647" y2="2.6582" width="0.1016" layer="21"/>
<wire x1="1.3647" y1="2.6582" x2="2.1152" y2="2.6582" width="0.1016" layer="21"/>
<wire x1="2.1152" y1="2.6582" x2="2.3199" y2="1.7372" width="0.1016" layer="21"/>
<wire x1="2.3199" y1="1.7372" x2="3.1727" y2="1.7372" width="0.1016" layer="21"/>
<wire x1="3.1727" y1="1.7372" x2="1.7741" y2="0.3386" width="0.1016" layer="21"/>
<wire x1="5.3559" y1="3.0676" x2="3.9573" y2="1.669" width="0.1016" layer="21"/>
<wire x1="3.9573" y1="1.669" x2="3.9573" y2="2.4877" width="0.1016" layer="21"/>
<wire x1="3.9573" y1="2.4877" x2="3.0363" y2="2.6582" width="0.1016" layer="21"/>
<wire x1="3.0363" y1="2.6582" x2="3.0363" y2="3.4087" width="0.1016" layer="21"/>
<wire x1="3.0363" y1="3.4087" x2="3.9573" y2="3.6134" width="0.1016" layer="21"/>
<wire x1="3.9573" y1="3.6134" x2="3.9573" y2="4.4662" width="0.1016" layer="21"/>
<wire x1="3.9573" y1="4.4662" x2="5.3559" y2="3.0676" width="0.1016" layer="21"/>
<wire x1="1.74" y1="5.7625" x2="3.1386" y2="4.3639" width="0.1016" layer="21"/>
<wire x1="3.1386" y1="4.3639" x2="2.3199" y2="4.3639" width="0.1016" layer="21"/>
<wire x1="2.3199" y1="4.3639" x2="2.1494" y2="3.4429" width="0.1016" layer="21"/>
<wire x1="2.1494" y1="3.4429" x2="1.3989" y2="3.4429" width="0.1016" layer="21"/>
<wire x1="1.3989" y1="3.4429" x2="1.1942" y2="4.3639" width="0.1016" layer="21"/>
<wire x1="1.1942" y1="4.3639" x2="0.3414" y2="4.3639" width="0.1016" layer="21"/>
<wire x1="0.3414" y1="4.3639" x2="1.74" y2="5.7625" width="0.1016" layer="21"/>
<wire x1="6.7204" y1="4.4321" x2="6.7204" y2="5.7284" width="0.1016" layer="21"/>
<wire x1="6.7204" y1="5.7284" x2="7.5049" y2="5.7284" width="0.1016" layer="21"/>
<wire x1="7.5049" y1="5.7284" x2="7.5049" y2="5.4896" width="0.1016" layer="21"/>
<wire x1="7.5049" y1="5.4896" x2="7.0615" y2="5.4896" width="0.1016" layer="21"/>
<wire x1="7.0615" y1="5.4896" x2="7.0615" y2="5.2508" width="0.1016" layer="21"/>
<wire x1="7.0615" y1="5.2508" x2="7.4367" y2="5.2508" width="0.1016" layer="21"/>
<wire x1="7.4367" y1="5.2508" x2="7.4367" y2="5.012" width="0.1016" layer="21"/>
<wire x1="7.4367" y1="5.012" x2="7.0615" y2="5.012" width="0.1016" layer="21"/>
<wire x1="7.0615" y1="5.012" x2="7.0615" y2="4.4321" width="0.1016" layer="21"/>
<wire x1="7.0615" y1="4.4321" x2="6.7204" y2="4.4321" width="0.1016" layer="21"/>
<wire x1="7.7096" y1="5.3873" x2="8.0507" y2="5.7284" width="0.1016" layer="21"/>
<wire x1="8.0507" y1="5.7284" x2="8.2554" y2="5.7284" width="0.1016" layer="21"/>
<wire x1="8.2554" y1="5.7284" x2="8.2554" y2="4.4321" width="0.1016" layer="21"/>
<wire x1="8.2554" y1="4.4321" x2="8.0166" y2="4.4321" width="0.1016" layer="21"/>
<wire x1="8.0166" y1="4.4321" x2="8.0166" y2="5.2849" width="0.1016" layer="21"/>
<wire x1="8.0166" y1="5.2849" x2="7.7096" y2="5.0802" width="0.1016" layer="21"/>
<wire x1="7.7096" y1="5.0802" x2="7.7096" y2="5.3873" width="0.1016" layer="21"/>
<wire x1="8.7671" y1="5.7284" x2="9.5176" y2="5.7284" width="0.1016" layer="21"/>
<wire x1="9.5176" y1="5.7284" x2="9.5176" y2="5.4896" width="0.1016" layer="21"/>
<wire x1="9.5176" y1="5.4896" x2="9.0741" y2="5.4896" width="0.1016" layer="21"/>
<wire x1="9.0741" y1="5.4896" x2="9.0741" y2="5.2508" width="0.1016" layer="21"/>
<wire x1="9.0741" y1="5.2508" x2="9.5176" y2="5.2508" width="0.1016" layer="21"/>
<wire x1="9.5176" y1="5.2508" x2="9.5176" y2="5.012" width="0.1016" layer="21"/>
<wire x1="9.5176" y1="5.012" x2="9.0741" y2="5.012" width="0.1016" layer="21"/>
<wire x1="9.0741" y1="5.012" x2="9.0741" y2="4.4321" width="0.1016" layer="21"/>
<wire x1="9.0741" y1="4.4321" x2="8.7671" y2="4.4321" width="0.1016" layer="21"/>
<wire x1="8.7671" y1="4.4321" x2="8.7671" y2="5.7284" width="0.1016" layer="21"/>
<wire x1="10.5409" y1="4.705" x2="10.5409" y2="4.4321" width="0.1016" layer="21"/>
<wire x1="10.5409" y1="4.4321" x2="9.6881" y2="4.4321" width="0.1016" layer="21"/>
<wire x1="9.6881" y1="4.4321" x2="9.6881" y2="4.5003" width="0.1016" layer="21"/>
<wire x1="9.6881" y1="4.5003" x2="9.7563" y2="4.705" width="0.1016" layer="21" curve="-36.8643"/>
<wire x1="9.7563" y1="4.705" x2="10.1657" y2="5.1485" width="0.1016" layer="21" curve="-11.696246"/>
<wire x1="10.1657" y1="5.1485" x2="10.268" y2="5.319" width="0.1016" layer="21" curve="35.199023"/>
<wire x1="10.268" y1="5.319" x2="10.2339" y2="5.4555" width="0.1016" layer="21" curve="54.770713"/>
<wire x1="10.2339" y1="5.4555" x2="10.0292" y2="5.4555" width="0.1016" layer="21" curve="97.158223"/>
<wire x1="10.0292" y1="5.4555" x2="9.9951" y2="5.3531" width="0.1016" layer="21" curve="45.955498"/>
<wire x1="9.9951" y1="5.3531" x2="9.7222" y2="5.3531" width="0.1016" layer="21"/>
<wire x1="9.7222" y1="5.3531" x2="9.7222" y2="5.3873" width="0.1016" layer="21"/>
<wire x1="9.7222" y1="5.3873" x2="9.8928" y2="5.6943" width="0.1016" layer="21" curve="-58.12682"/>
<wire x1="9.8928" y1="5.6943" x2="10.4045" y2="5.6601" width="0.1016" layer="21" curve="-71.408077"/>
<wire x1="10.4045" y1="5.6601" x2="10.5068" y2="5.1826" width="0.1016" layer="21" curve="-76.758822"/>
<wire x1="10.5068" y1="5.1826" x2="10.3363" y2="4.9438" width="0.1016" layer="21" curve="-18.465187"/>
<wire x1="10.3363" y1="4.9438" x2="10.1998" y2="4.8073" width="0.1016" layer="21" curve="-0.478147"/>
<wire x1="10.1998" y1="4.8073" x2="10.1316" y2="4.7391" width="0.1016" layer="21" curve="0.478146"/>
<wire x1="10.1316" y1="4.7391" x2="10.0975" y2="4.705" width="0.1016" layer="21"/>
<wire x1="10.0975" y1="4.705" x2="10.5409" y2="4.705" width="0.1016" layer="21"/>
<wire x1="11.0526" y1="5.7284" x2="11.8031" y2="5.7284" width="0.1016" layer="21"/>
<wire x1="11.8031" y1="5.7284" x2="11.8031" y2="5.4896" width="0.1016" layer="21"/>
<wire x1="11.8031" y1="5.4896" x2="11.3596" y2="5.4896" width="0.1016" layer="21"/>
<wire x1="11.3596" y1="5.4896" x2="11.3596" y2="5.2508" width="0.1016" layer="21"/>
<wire x1="11.3596" y1="5.2508" x2="11.8031" y2="5.2508" width="0.1016" layer="21"/>
<wire x1="11.8031" y1="5.2508" x2="11.8031" y2="5.012" width="0.1016" layer="21"/>
<wire x1="11.8031" y1="5.012" x2="11.3596" y2="5.012" width="0.1016" layer="21"/>
<wire x1="11.3596" y1="5.012" x2="11.3596" y2="4.4321" width="0.1016" layer="21"/>
<wire x1="11.3596" y1="4.4321" x2="11.0526" y2="4.4321" width="0.1016" layer="21"/>
<wire x1="11.0526" y1="4.4321" x2="11.0526" y2="5.7284" width="0.1016" layer="21"/>
<wire x1="13.3381" y1="5.7284" x2="14.0886" y2="5.7284" width="0.1016" layer="21"/>
<wire x1="14.0886" y1="5.7284" x2="14.0886" y2="5.4896" width="0.1016" layer="21"/>
<wire x1="14.0886" y1="5.4896" x2="13.6451" y2="5.4896" width="0.1016" layer="21"/>
<wire x1="13.6451" y1="5.4896" x2="13.6451" y2="5.2508" width="0.1016" layer="21"/>
<wire x1="13.6451" y1="5.2508" x2="14.0886" y2="5.2508" width="0.1016" layer="21"/>
<wire x1="14.0886" y1="5.2508" x2="14.0886" y2="5.012" width="0.1016" layer="21"/>
<wire x1="14.0886" y1="5.012" x2="13.6451" y2="5.012" width="0.1016" layer="21"/>
<wire x1="13.6451" y1="5.012" x2="13.6451" y2="4.4321" width="0.1016" layer="21"/>
<wire x1="13.6451" y1="4.4321" x2="13.3381" y2="4.4321" width="0.1016" layer="21"/>
<wire x1="13.3381" y1="4.4321" x2="13.3381" y2="5.7284" width="0.1016" layer="21"/>
<wire x1="15.5895" y1="5.7284" x2="16.34" y2="5.7284" width="0.1016" layer="21"/>
<wire x1="16.34" y1="5.7284" x2="16.34" y2="5.4896" width="0.1016" layer="21"/>
<wire x1="16.34" y1="5.4896" x2="15.8965" y2="5.4896" width="0.1016" layer="21"/>
<wire x1="15.8965" y1="5.4896" x2="15.8965" y2="5.2508" width="0.1016" layer="21"/>
<wire x1="15.8965" y1="5.2508" x2="16.34" y2="5.2508" width="0.1016" layer="21"/>
<wire x1="16.34" y1="5.2508" x2="16.34" y2="5.012" width="0.1016" layer="21"/>
<wire x1="16.34" y1="5.012" x2="15.8965" y2="5.012" width="0.1016" layer="21"/>
<wire x1="15.8965" y1="5.012" x2="15.8965" y2="4.4321" width="0.1016" layer="21"/>
<wire x1="15.8965" y1="4.4321" x2="15.5895" y2="4.4321" width="0.1016" layer="21"/>
<wire x1="15.5895" y1="4.4321" x2="15.5895" y2="5.7284" width="0.1016" layer="21"/>
<wire x1="12.2465" y1="5.3873" x2="12.0419" y2="5.3873" width="0.1016" layer="21"/>
<wire x1="12.0419" y1="5.3873" x2="12.0419" y2="5.4214" width="0.1016" layer="21"/>
<wire x1="12.0419" y1="5.4214" x2="12.1442" y2="5.6601" width="0.1016" layer="21" curve="-46.431969"/>
<wire x1="12.1442" y1="5.6601" x2="12.6559" y2="5.6601" width="0.1016" layer="21" curve="-87.214692"/>
<wire x1="12.6559" y1="5.6601" x2="12.69" y2="5.1826" width="0.1016" layer="21" curve="-84.607136"/>
<wire x1="12.69" y1="5.1826" x2="12.6559" y2="5.1485" width="0.1016" layer="21"/>
<wire x1="12.6559" y1="5.1485" x2="12.7241" y2="4.5003" width="0.1016" layer="21" curve="-100.82495"/>
<wire x1="12.7241" y1="4.5003" x2="12.1442" y2="4.5003" width="0.1016" layer="21" curve="-75.748903"/>
<wire x1="12.1442" y1="4.5003" x2="12.0078" y2="4.7732" width="0.1016" layer="21" curve="-36.890904"/>
<wire x1="12.0078" y1="4.7732" x2="12.2465" y2="4.7732" width="0.1016" layer="21"/>
<wire x1="12.2465" y1="4.7732" x2="12.383" y2="5.012" width="0.1016" layer="21" curve="259.752596"/>
<wire x1="12.383" y1="5.012" x2="12.3489" y2="5.2167" width="0.1016" layer="21"/>
<wire x1="12.3489" y1="5.2167" x2="12.2465" y2="5.3873" width="0.1016" layer="21" curve="263.175292"/>
<wire x1="14.2933" y1="4.705" x2="14.2933" y2="4.9779" width="0.1016" layer="21"/>
<wire x1="14.2933" y1="4.9779" x2="14.7708" y2="5.7284" width="0.1016" layer="21"/>
<wire x1="14.7708" y1="5.7284" x2="15.0437" y2="5.7284" width="0.1016" layer="21"/>
<wire x1="15.0437" y1="5.7284" x2="15.0437" y2="4.9438" width="0.1016" layer="21"/>
<wire x1="15.0437" y1="4.9438" x2="15.1802" y2="4.9438" width="0.1016" layer="21"/>
<wire x1="15.1802" y1="4.9438" x2="15.1802" y2="4.705" width="0.1016" layer="21"/>
<wire x1="15.1802" y1="4.705" x2="15.0437" y2="4.705" width="0.1016" layer="21"/>
<wire x1="15.0437" y1="4.705" x2="15.0437" y2="4.4321" width="0.1016" layer="21"/>
<wire x1="15.0437" y1="4.4321" x2="14.805" y2="4.4321" width="0.1016" layer="21"/>
<wire x1="14.805" y1="4.4321" x2="14.805" y2="4.705" width="0.1016" layer="21"/>
<wire x1="14.805" y1="4.705" x2="14.2933" y2="4.705" width="0.1016" layer="21"/>
<wire x1="14.5321" y1="4.9438" x2="14.805" y2="4.9438" width="0.1016" layer="21"/>
<wire x1="14.805" y1="4.9438" x2="14.805" y2="5.3531" width="0.1016" layer="21"/>
<wire x1="14.805" y1="5.3531" x2="14.5321" y2="4.9438" width="0.1016" layer="21"/>
<wire x1="17.3293" y1="5.7284" x2="17.3293" y2="5.4896" width="0.1016" layer="21"/>
<wire x1="17.3293" y1="5.4896" x2="16.8517" y2="5.4896" width="0.1016" layer="21"/>
<wire x1="16.8517" y1="5.4896" x2="16.8517" y2="5.2849" width="0.1016" layer="21"/>
<wire x1="16.8517" y1="5.2849" x2="17.3634" y2="5.0461" width="0.1016" layer="21" curve="-90.056013"/>
<wire x1="17.3634" y1="5.0461" x2="17.3634" y2="4.705" width="0.1016" layer="21"/>
<wire x1="17.3634" y1="4.705" x2="16.9881" y2="4.4321" width="0.1016" layer="21" curve="-80.835413"/>
<wire x1="16.9881" y1="4.4321" x2="16.5447" y2="4.7732" width="0.1016" layer="21" curve="-83.716775"/>
<wire x1="16.5447" y1="4.7732" x2="16.8176" y2="4.7732" width="0.1016" layer="21"/>
<wire x1="16.8176" y1="4.7732" x2="16.954" y2="4.6709" width="0.1016" layer="21" curve="59.531148"/>
<wire x1="16.954" y1="4.6709" x2="17.0905" y2="4.7732" width="0.1016" layer="21" curve="73.770028"/>
<wire x1="17.0905" y1="4.7732" x2="17.0905" y2="4.9779" width="0.1016" layer="21"/>
<wire x1="17.0905" y1="4.9779" x2="16.8517" y2="5.012" width="0.1016" layer="21" curve="118.206661"/>
<wire x1="16.8517" y1="5.012" x2="16.8176" y2="5.012" width="0.1016" layer="21"/>
<wire x1="16.8176" y1="5.012" x2="16.5788" y2="5.0461" width="0.1016" layer="21"/>
<wire x1="16.5788" y1="5.0461" x2="16.6811" y2="5.7284" width="0.1016" layer="21"/>
<wire x1="16.6811" y1="5.7284" x2="17.3293" y2="5.7284" width="0.1016" layer="21"/>
<wire x1="16.6811" y1="1.0209" x2="16.6811" y2="1.362" width="0.1016" layer="21"/>
<wire x1="16.6811" y1="1.362" x2="16.9881" y2="1.362" width="0.1016" layer="21"/>
<wire x1="16.9881" y1="1.362" x2="16.9881" y2="3.2382" width="0.1016" layer="21"/>
<wire x1="16.9881" y1="3.2382" x2="16.647" y2="3.2382" width="0.1016" layer="21"/>
<wire x1="16.647" y1="3.2382" x2="16.647" y2="3.5452" width="0.1016" layer="21"/>
<wire x1="16.647" y1="3.5452" x2="17.2951" y2="3.5452" width="0.1016" layer="21"/>
<wire x1="17.2951" y1="3.5452" x2="17.2951" y2="1.0209" width="0.1016" layer="21"/>
<wire x1="17.2951" y1="1.0209" x2="16.6811" y2="1.0209" width="0.1016" layer="21"/>
<wire x1="16.4423" y1="1.0209" x2="16.4423" y2="1.5326" width="0.1016" layer="21"/>
<wire x1="16.4423" y1="1.5326" x2="16.7835" y2="1.5326" width="0.1016" layer="21"/>
<wire x1="16.7835" y1="1.5326" x2="16.7835" y2="3.0676" width="0.1016" layer="21"/>
<wire x1="16.7835" y1="3.0676" x2="16.4423" y2="3.0676" width="0.1016" layer="21"/>
<wire x1="16.4423" y1="3.0676" x2="16.4423" y2="3.5452" width="0.1016" layer="21"/>
<wire x1="16.4423" y1="3.5452" x2="15.3166" y2="3.5452" width="0.1016" layer="21"/>
<wire x1="15.3166" y1="3.5452" x2="15.3166" y2="1.0209" width="0.1016" layer="21"/>
<wire x1="15.3166" y1="1.0209" x2="16.4423" y2="1.0209" width="0.1016" layer="21"/>
<wire x1="15.112" y1="3.5452" x2="13.2017" y2="3.5452" width="0.1016" layer="21"/>
<wire x1="13.2017" y1="3.5452" x2="13.2017" y2="1.0209" width="0.1016" layer="21"/>
<wire x1="13.2017" y1="1.0209" x2="15.112" y2="1.0209" width="0.1016" layer="21"/>
<wire x1="15.112" y1="1.0209" x2="15.112" y2="3.5452" width="0.1016" layer="21"/>
<wire x1="12.997" y1="1.0209" x2="12.997" y2="3.5452" width="0.1016" layer="21"/>
<wire x1="12.997" y1="3.5452" x2="11.0526" y2="3.5452" width="0.1016" layer="21"/>
<wire x1="11.0526" y1="3.5452" x2="11.0526" y2="1.0209" width="0.1016" layer="21"/>
<wire x1="11.0526" y1="1.0209" x2="12.997" y2="1.0209" width="0.1016" layer="21"/>
<wire x1="10.8479" y1="1.0209" x2="10.8479" y2="3.5452" width="0.1016" layer="21"/>
<wire x1="10.8479" y1="3.5452" x2="8.9718" y2="3.5452" width="0.1016" layer="21"/>
<wire x1="8.9718" y1="3.5452" x2="8.9718" y2="1.0209" width="0.1016" layer="21"/>
<wire x1="8.9718" y1="1.0209" x2="10.8479" y2="1.0209" width="0.1016" layer="21"/>
<wire x1="8.733" y1="1.0209" x2="8.733" y2="3.5452" width="0.1016" layer="21"/>
<wire x1="8.733" y1="3.5452" x2="7.6414" y2="3.5452" width="0.1016" layer="21"/>
<wire x1="7.6414" y1="3.5452" x2="7.6414" y2="3.0676" width="0.1016" layer="21"/>
<wire x1="7.6414" y1="3.0676" x2="7.2662" y2="3.0676" width="0.1016" layer="21"/>
<wire x1="7.2662" y1="3.0676" x2="7.2662" y2="1.5326" width="0.1016" layer="21"/>
<wire x1="7.2662" y1="1.5326" x2="7.6414" y2="1.5326" width="0.1016" layer="21"/>
<wire x1="7.6414" y1="1.5326" x2="7.6414" y2="1.0209" width="0.1016" layer="21"/>
<wire x1="7.6414" y1="1.0209" x2="8.733" y2="1.0209" width="0.1016" layer="21"/>
<wire x1="7.4367" y1="1.0209" x2="7.4367" y2="1.362" width="0.1016" layer="21"/>
<wire x1="7.4367" y1="1.362" x2="7.0615" y2="1.362" width="0.1016" layer="21"/>
<wire x1="7.0615" y1="1.362" x2="7.0615" y2="3.2382" width="0.1016" layer="21"/>
<wire x1="7.0615" y1="3.2382" x2="7.4367" y2="3.2382" width="0.1016" layer="21"/>
<wire x1="7.4367" y1="3.2382" x2="7.4367" y2="3.5452" width="0.1016" layer="21"/>
<wire x1="7.4367" y1="3.5452" x2="6.7545" y2="3.5452" width="0.1016" layer="21"/>
<wire x1="6.7545" y1="3.5452" x2="6.7545" y2="1.0209" width="0.1016" layer="21"/>
<wire x1="6.7545" y1="1.0209" x2="7.4367" y2="1.0209" width="0.1016" layer="21"/>
<wire x1="-16.6124" y1="-1.6399" x2="-16.6124" y2="-1.7763" width="0.1016" layer="21"/>
<wire x1="-16.6124" y1="-1.7763" x2="-17.0558" y2="-1.9128" width="0.1016" layer="21" curve="43.617082"/>
<wire x1="-17.0558" y1="-1.9128" x2="-17.1923" y2="-2.9361" width="0.1016" layer="21" curve="77.548521"/>
<wire x1="-17.1923" y1="-2.9361" x2="-16.6124" y2="-3.3114" width="0.1016" layer="21" curve="48.607903"/>
<wire x1="-16.6124" y1="-3.3114" x2="-16.6124" y2="-3.8572" width="0.1016" layer="21"/>
<wire x1="-16.6124" y1="-3.8572" x2="-16.6465" y2="-3.823" width="0.1016" layer="21"/>
<wire x1="-16.6465" y1="-3.823" x2="-16.8171" y2="-3.5501" width="0.1016" layer="21" curve="-46.368962"/>
<wire x1="-16.8171" y1="-3.5501" x2="-17.3629" y2="-3.5843" width="0.1016" layer="21"/>
<wire x1="-17.3629" y1="-3.5843" x2="-17.3287" y2="-3.7889" width="0.1016" layer="21"/>
<wire x1="-17.3287" y1="-3.7889" x2="-16.6124" y2="-4.403" width="0.1016" layer="21" curve="79.799025"/>
<wire x1="-16.6124" y1="-4.403" x2="-16.6124" y2="-4.71" width="0.1016" layer="21"/>
<wire x1="-16.6124" y1="-4.71" x2="-16.4077" y2="-4.71" width="0.1016" layer="21"/>
<wire x1="-16.4077" y1="-4.71" x2="-16.4077" y2="-4.403" width="0.1016" layer="21"/>
<wire x1="-16.4077" y1="-4.403" x2="-16.3736" y2="-4.403" width="0.1016" layer="21"/>
<wire x1="-16.3736" y1="-4.403" x2="-15.7596" y2="-4.0277" width="0.1016" layer="21" curve="62.890978"/>
<wire x1="-15.7596" y1="-4.0277" x2="-16.4077" y2="-2.7656" width="0.1016" layer="21" curve="108.636584"/>
<wire x1="-16.4077" y1="-2.7656" x2="-16.4077" y2="-2.2539" width="0.1016" layer="21"/>
<wire x1="-16.4077" y1="-2.2539" x2="-16.2371" y2="-2.4927" width="0.1016" layer="21" curve="-53.053427"/>
<wire x1="-16.2371" y1="-2.4927" x2="-15.7596" y2="-2.3903" width="0.1016" layer="21"/>
<wire x1="-15.7596" y1="-2.3903" x2="-16.4077" y2="-1.7763" width="0.1016" layer="21" curve="88.353257"/>
<wire x1="-16.4077" y1="-1.7763" x2="-16.4077" y2="-1.6399" width="0.1016" layer="21"/>
<wire x1="-16.4077" y1="-1.6399" x2="-16.6124" y2="-1.6399" width="0.1016" layer="21"/>
<wire x1="-16.6465" y1="-2.6974" x2="-16.6465" y2="-2.2539" width="0.1016" layer="21"/>
<wire x1="-16.6465" y1="-2.2539" x2="-16.6465" y2="-2.6974" width="0.1016" layer="21" curve="133.662081"/>
<wire x1="-16.4077" y1="-3.8572" x2="-16.4077" y2="-3.3796" width="0.1016" layer="21"/>
<wire x1="-16.4077" y1="-3.3796" x2="-16.4077" y2="-3.8572" width="0.1016" layer="21" curve="-154.972872"/>
<wire x1="-14.3269" y1="-2.4927" x2="-14.3269" y2="-0.9917" width="0.1016" layer="21"/>
<wire x1="-14.3269" y1="-0.9917" x2="-13.1329" y2="-0.9917" width="0.1016" layer="21"/>
<wire x1="-13.1329" y1="-0.9917" x2="-13.1329" y2="-1.2646" width="0.1016" layer="21"/>
<wire x1="-13.1329" y1="-1.2646" x2="-13.9516" y2="-1.2646" width="0.1016" layer="21"/>
<wire x1="-13.9516" y1="-1.2646" x2="-13.9516" y2="-1.5716" width="0.1016" layer="21"/>
<wire x1="-13.9516" y1="-1.5716" x2="-13.2012" y2="-1.5716" width="0.1016" layer="21"/>
<wire x1="-13.2012" y1="-1.5716" x2="-13.2012" y2="-1.8104" width="0.1016" layer="21"/>
<wire x1="-13.2012" y1="-1.8104" x2="-13.9516" y2="-1.8104" width="0.1016" layer="21"/>
<wire x1="-13.9516" y1="-1.8104" x2="-13.9516" y2="-2.2198" width="0.1016" layer="21"/>
<wire x1="-13.9516" y1="-2.2198" x2="-13.0988" y2="-2.2198" width="0.1016" layer="21"/>
<wire x1="-13.0988" y1="-2.2198" x2="-13.0988" y2="-2.4927" width="0.1016" layer="21"/>
<wire x1="-13.0988" y1="-2.4927" x2="-14.3269" y2="-2.4927" width="0.1016" layer="21"/>
<wire x1="-14.5657" y1="-2.9702" x2="-12.86" y2="-2.9702" width="0.1016" layer="21"/>
<wire x1="-12.86" y1="-2.9702" x2="-12.86" y2="-3.3796" width="0.1016" layer="21"/>
<wire x1="-12.86" y1="-3.3796" x2="-14.5657" y2="-3.3796" width="0.1016" layer="21"/>
<wire x1="-14.5657" y1="-3.3796" x2="-14.5657" y2="-2.9702" width="0.1016" layer="21"/>
<wire x1="-14.5657" y1="-5.2899" x2="-14.5657" y2="-3.8572" width="0.1016" layer="21"/>
<wire x1="-14.5657" y1="-3.8572" x2="-13.9857" y2="-3.8572" width="0.1016" layer="21"/>
<wire x1="-13.9857" y1="-3.8572" x2="-13.747" y2="-4.7441" width="0.1016" layer="21"/>
<wire x1="-13.747" y1="-4.7441" x2="-13.4741" y2="-3.8572" width="0.1016" layer="21"/>
<wire x1="-13.4741" y1="-3.8572" x2="-12.8942" y2="-3.8572" width="0.1016" layer="21"/>
<wire x1="-12.8942" y1="-3.8572" x2="-12.8942" y2="-5.2899" width="0.1016" layer="21"/>
<wire x1="-12.8942" y1="-5.2899" x2="-13.2012" y2="-5.2899" width="0.1016" layer="21"/>
<wire x1="-13.2012" y1="-5.2899" x2="-13.2012" y2="-4.0959" width="0.1016" layer="21"/>
<wire x1="-13.2012" y1="-4.0959" x2="-13.5764" y2="-5.2899" width="0.1016" layer="21"/>
<wire x1="-13.5764" y1="-5.2899" x2="-13.8834" y2="-5.2899" width="0.1016" layer="21"/>
<wire x1="-13.8834" y1="-5.2899" x2="-14.2245" y2="-4.0959" width="0.1016" layer="21"/>
<wire x1="-14.2245" y1="-4.0959" x2="-14.2245" y2="-5.2899" width="0.1016" layer="21"/>
<wire x1="-14.2245" y1="-5.2899" x2="-14.5657" y2="-5.2899" width="0.1016" layer="21"/>
<wire x1="-11.7343" y1="-4.71" x2="-11.1544" y2="-5.2899" width="0.1016" layer="21"/>
<wire x1="-11.1544" y1="-5.2899" x2="-11.0521" y2="-5.1193" width="0.1016" layer="21"/>
<wire x1="-11.0521" y1="-5.1193" x2="-11.0521" y2="-3.516" width="0.1016" layer="21"/>
<wire x1="-11.0521" y1="-3.516" x2="-11.1885" y2="-3.3455" width="0.1016" layer="21"/>
<wire x1="-11.1885" y1="-3.3455" x2="-11.7343" y2="-3.7207" width="0.1016" layer="21"/>
<wire x1="-11.7343" y1="-3.7207" x2="-11.7343" y2="-4.71" width="0.1016" layer="21"/>
<wire x1="-11.1885" y1="-2.9361" x2="-11.7343" y2="-2.595" width="0.1016" layer="21"/>
<wire x1="-11.7343" y1="-2.595" x2="-11.7343" y2="-1.5375" width="0.1016" layer="21"/>
<wire x1="-11.7343" y1="-1.5375" x2="-11.1885" y2="-0.9917" width="0.1016" layer="21"/>
<wire x1="-11.1885" y1="-0.9917" x2="-11.0521" y2="-1.2305" width="0.1016" layer="21"/>
<wire x1="-11.0521" y1="-1.2305" x2="-11.0521" y2="-2.7315" width="0.1016" layer="21"/>
<wire x1="-11.0521" y1="-2.7315" x2="-11.1885" y2="-2.9361" width="0.1016" layer="21"/>
<wire x1="-9.3465" y1="-0.7871" x2="-9.21" y2="-0.6506" width="0.1016" layer="21"/>
<wire x1="-9.21" y1="-0.6506" x2="-7.5044" y2="-0.6506" width="0.1016" layer="21"/>
<wire x1="-7.5044" y1="-0.6506" x2="-7.368" y2="-0.7871" width="0.1016" layer="21"/>
<wire x1="-7.9479" y1="-1.367" x2="-8.7666" y2="-1.367" width="0.1016" layer="21"/>
<wire x1="-8.7666" y1="-1.367" x2="-9.3465" y2="-0.7871" width="0.1016" layer="21"/>
<wire x1="-9.5512" y1="-1.0258" x2="-9.7217" y2="-1.1282" width="0.1016" layer="21"/>
<wire x1="-9.7217" y1="-1.1282" x2="-9.7217" y2="-2.8338" width="0.1016" layer="21"/>
<wire x1="-9.7217" y1="-2.8338" x2="-9.5512" y2="-2.9361" width="0.1016" layer="21"/>
<wire x1="-8.9712" y1="-2.3563" x2="-8.9713" y2="-1.6058" width="0.1016" layer="21"/>
<wire x1="-8.9713" y1="-1.6058" x2="-9.5512" y2="-1.026" width="0.1016" layer="21"/>
<wire x1="-8.9712" y1="-2.3563" x2="-9.551" y2="-2.9362" width="0.1016" layer="21"/>
<wire x1="-7.368" y1="-0.7871" x2="-7.9479" y2="-1.367" width="0.1016" layer="21"/>
<wire x1="-7.368" y1="-5.5286" x2="-7.5045" y2="-5.6651" width="0.1016" layer="21"/>
<wire x1="-7.5045" y1="-5.6651" x2="-9.2101" y2="-5.6651" width="0.1016" layer="21"/>
<wire x1="-9.2101" y1="-5.6651" x2="-9.3465" y2="-5.5286" width="0.1016" layer="21"/>
<wire x1="-8.7666" y1="-4.9487" x2="-7.9479" y2="-4.9487" width="0.1016" layer="21"/>
<wire x1="-7.9479" y1="-4.9487" x2="-7.368" y2="-5.5286" width="0.1016" layer="21"/>
<wire x1="-7.1633" y1="-5.2899" x2="-6.9928" y2="-5.1875" width="0.1016" layer="21"/>
<wire x1="-6.9928" y1="-5.1875" x2="-6.9928" y2="-3.4819" width="0.1016" layer="21"/>
<wire x1="-6.9928" y1="-3.4819" x2="-7.1633" y2="-3.3796" width="0.1016" layer="21"/>
<wire x1="-7.7433" y1="-3.9594" x2="-7.7432" y2="-4.7099" width="0.1016" layer="21"/>
<wire x1="-7.7432" y1="-4.7099" x2="-7.1633" y2="-5.2897" width="0.1016" layer="21"/>
<wire x1="-7.7433" y1="-3.9594" x2="-7.1635" y2="-3.3795" width="0.1016" layer="21"/>
<wire x1="-9.3465" y1="-5.5286" x2="-8.7666" y2="-4.9487" width="0.1016" layer="21"/>
<wire x1="-9.3465" y1="-3.1408" x2="-8.7325" y2="-2.7996" width="0.1016" layer="21"/>
<wire x1="-8.7325" y1="-2.7996" x2="-8.016" y2="-2.7997" width="0.1016" layer="21"/>
<wire x1="-8.016" y1="-2.7997" x2="-7.4021" y2="-3.1408" width="0.1016" layer="21"/>
<wire x1="-8.016" y1="-3.516" x2="-8.7324" y2="-3.516" width="0.1016" layer="21"/>
<wire x1="-8.7324" y1="-3.516" x2="-9.3466" y2="-3.1408" width="0.1016" layer="21"/>
<wire x1="-9.5512" y1="-3.3454" x2="-9.7217" y2="-3.4478" width="0.1016" layer="21"/>
<wire x1="-9.7217" y1="-3.4478" x2="-9.7217" y2="-5.1534" width="0.1016" layer="21"/>
<wire x1="-9.7217" y1="-5.1534" x2="-9.5512" y2="-5.2557" width="0.1016" layer="21"/>
<wire x1="-8.9712" y1="-4.6759" x2="-8.9713" y2="-3.9254" width="0.1016" layer="21"/>
<wire x1="-8.9713" y1="-3.9254" x2="-9.5512" y2="-3.3456" width="0.1016" layer="21"/>
<wire x1="-8.9712" y1="-4.6759" x2="-9.551" y2="-5.2558" width="0.1016" layer="21"/>
<wire x1="-7.4021" y1="-3.1408" x2="-8.016" y2="-3.516" width="0.1016" layer="21"/>
<wire x1="-9.3466" y1="-3.1408" x2="-9.3465" y2="-3.1408" width="0.1016" layer="21"/>
<wire x1="-7.1633" y1="-2.9362" x2="-6.9928" y2="-2.8338" width="0.1016" layer="21"/>
<wire x1="-6.9928" y1="-2.8338" x2="-6.9928" y2="-1.1282" width="0.1016" layer="21"/>
<wire x1="-6.9928" y1="-1.1282" x2="-7.1633" y2="-1.0259" width="0.1016" layer="21"/>
<wire x1="-7.7433" y1="-1.6057" x2="-7.7432" y2="-2.3562" width="0.1016" layer="21"/>
<wire x1="-7.7432" y1="-2.3562" x2="-7.1633" y2="-2.936" width="0.1016" layer="21"/>
<wire x1="-7.7433" y1="-1.6057" x2="-7.1635" y2="-1.0258" width="0.1016" layer="21"/>
<wire x1="-5.2872" y1="-0.7871" x2="-5.1507" y2="-0.6506" width="0.1016" layer="21"/>
<wire x1="-5.1507" y1="-0.6506" x2="-3.4451" y2="-0.6506" width="0.1016" layer="21"/>
<wire x1="-3.4451" y1="-0.6506" x2="-3.3087" y2="-0.7871" width="0.1016" layer="21"/>
<wire x1="-3.8886" y1="-1.367" x2="-4.7073" y2="-1.367" width="0.1016" layer="21"/>
<wire x1="-4.7073" y1="-1.367" x2="-5.2872" y2="-0.7871" width="0.1016" layer="21"/>
<wire x1="-5.4919" y1="-1.0258" x2="-5.6624" y2="-1.1282" width="0.1016" layer="21"/>
<wire x1="-5.6624" y1="-1.1282" x2="-5.6624" y2="-2.8338" width="0.1016" layer="21"/>
<wire x1="-5.6624" y1="-2.8338" x2="-5.4919" y2="-2.9361" width="0.1016" layer="21"/>
<wire x1="-4.9119" y1="-2.3563" x2="-4.912" y2="-1.6058" width="0.1016" layer="21"/>
<wire x1="-4.912" y1="-1.6058" x2="-5.4919" y2="-1.026" width="0.1016" layer="21"/>
<wire x1="-4.9119" y1="-2.3563" x2="-5.4917" y2="-2.9362" width="0.1016" layer="21"/>
<wire x1="-3.3087" y1="-0.7871" x2="-3.8886" y2="-1.367" width="0.1016" layer="21"/>
<wire x1="-3.3087" y1="-5.5286" x2="-3.4452" y2="-5.6651" width="0.1016" layer="21"/>
<wire x1="-3.4452" y1="-5.6651" x2="-5.1508" y2="-5.6651" width="0.1016" layer="21"/>
<wire x1="-5.1508" y1="-5.6651" x2="-5.2872" y2="-5.5286" width="0.1016" layer="21"/>
<wire x1="-4.7073" y1="-4.9487" x2="-3.8886" y2="-4.9487" width="0.1016" layer="21"/>
<wire x1="-3.8886" y1="-4.9487" x2="-3.3087" y2="-5.5286" width="0.1016" layer="21"/>
<wire x1="-3.104" y1="-5.2899" x2="-2.9335" y2="-5.1875" width="0.1016" layer="21"/>
<wire x1="-2.9335" y1="-5.1875" x2="-2.9335" y2="-3.4819" width="0.1016" layer="21"/>
<wire x1="-2.9335" y1="-3.4819" x2="-3.104" y2="-3.3796" width="0.1016" layer="21"/>
<wire x1="-3.684" y1="-3.9594" x2="-3.6839" y2="-4.7099" width="0.1016" layer="21"/>
<wire x1="-3.6839" y1="-4.7099" x2="-3.104" y2="-5.2897" width="0.1016" layer="21"/>
<wire x1="-3.684" y1="-3.9594" x2="-3.1042" y2="-3.3795" width="0.1016" layer="21"/>
<wire x1="-5.2872" y1="-5.5286" x2="-4.7073" y2="-4.9487" width="0.1016" layer="21"/>
<wire x1="-5.2872" y1="-3.1408" x2="-4.6732" y2="-2.7996" width="0.1016" layer="21"/>
<wire x1="-4.6732" y1="-2.7996" x2="-3.9567" y2="-2.7997" width="0.1016" layer="21"/>
<wire x1="-3.9567" y1="-2.7997" x2="-3.3428" y2="-3.1408" width="0.1016" layer="21"/>
<wire x1="-3.9567" y1="-3.516" x2="-4.6731" y2="-3.516" width="0.1016" layer="21"/>
<wire x1="-4.6731" y1="-3.516" x2="-5.2873" y2="-3.1408" width="0.1016" layer="21"/>
<wire x1="-5.4919" y1="-3.3454" x2="-5.6624" y2="-3.4478" width="0.1016" layer="21"/>
<wire x1="-5.6624" y1="-3.4478" x2="-5.6624" y2="-5.1534" width="0.1016" layer="21"/>
<wire x1="-5.6624" y1="-5.1534" x2="-5.4919" y2="-5.2557" width="0.1016" layer="21"/>
<wire x1="-4.9119" y1="-4.6759" x2="-4.912" y2="-3.9254" width="0.1016" layer="21"/>
<wire x1="-4.912" y1="-3.9254" x2="-5.4919" y2="-3.3456" width="0.1016" layer="21"/>
<wire x1="-4.9119" y1="-4.6759" x2="-5.4917" y2="-5.2558" width="0.1016" layer="21"/>
<wire x1="-3.3428" y1="-3.1408" x2="-3.9567" y2="-3.516" width="0.1016" layer="21"/>
<wire x1="-5.2873" y1="-3.1408" x2="-5.2872" y2="-3.1408" width="0.1016" layer="21"/>
<wire x1="-3.104" y1="-2.9362" x2="-2.9335" y2="-2.8338" width="0.1016" layer="21"/>
<wire x1="-2.9335" y1="-2.8338" x2="-2.9335" y2="-1.1282" width="0.1016" layer="21"/>
<wire x1="-2.9335" y1="-1.1282" x2="-3.104" y2="-1.0259" width="0.1016" layer="21"/>
<wire x1="-3.684" y1="-1.6057" x2="-3.6839" y2="-2.3562" width="0.1016" layer="21"/>
<wire x1="-3.6839" y1="-2.3562" x2="-3.104" y2="-2.936" width="0.1016" layer="21"/>
<wire x1="-3.684" y1="-1.6057" x2="-3.1042" y2="-1.0258" width="0.1016" layer="21"/>
<wire x1="-1.2278" y1="-0.7871" x2="-1.0913" y2="-0.6506" width="0.1016" layer="21"/>
<wire x1="-1.0913" y1="-0.6506" x2="0.6143" y2="-0.6506" width="0.1016" layer="21"/>
<wire x1="0.6143" y1="-0.6506" x2="0.7507" y2="-0.7871" width="0.1016" layer="21"/>
<wire x1="0.1708" y1="-1.367" x2="-0.6479" y2="-1.367" width="0.1016" layer="21"/>
<wire x1="-0.6479" y1="-1.367" x2="-1.2278" y2="-0.7871" width="0.1016" layer="21"/>
<wire x1="-1.4325" y1="-1.0258" x2="-1.603" y2="-1.1282" width="0.1016" layer="21"/>
<wire x1="-1.603" y1="-1.1282" x2="-1.603" y2="-2.8338" width="0.1016" layer="21"/>
<wire x1="-1.603" y1="-2.8338" x2="-1.4325" y2="-2.9361" width="0.1016" layer="21"/>
<wire x1="-0.8525" y1="-2.3563" x2="-0.8526" y2="-1.6058" width="0.1016" layer="21"/>
<wire x1="-0.8526" y1="-1.6058" x2="-1.4325" y2="-1.026" width="0.1016" layer="21"/>
<wire x1="-0.8525" y1="-2.3563" x2="-1.4323" y2="-2.9362" width="0.1016" layer="21"/>
<wire x1="0.7507" y1="-0.7871" x2="0.1708" y2="-1.367" width="0.1016" layer="21"/>
<wire x1="0.7507" y1="-5.5286" x2="0.6142" y2="-5.6651" width="0.1016" layer="21"/>
<wire x1="0.6142" y1="-5.6651" x2="-1.0914" y2="-5.6651" width="0.1016" layer="21"/>
<wire x1="-1.0914" y1="-5.6651" x2="-1.2278" y2="-5.5286" width="0.1016" layer="21"/>
<wire x1="-0.6479" y1="-4.9487" x2="0.1708" y2="-4.9487" width="0.1016" layer="21"/>
<wire x1="0.1708" y1="-4.9487" x2="0.7507" y2="-5.5286" width="0.1016" layer="21"/>
<wire x1="0.9554" y1="-5.2899" x2="1.1259" y2="-5.1875" width="0.1016" layer="21"/>
<wire x1="1.1259" y1="-5.1875" x2="1.1259" y2="-3.4819" width="0.1016" layer="21"/>
<wire x1="1.1259" y1="-3.4819" x2="0.9554" y2="-3.3796" width="0.1016" layer="21"/>
<wire x1="0.3754" y1="-3.9594" x2="0.3755" y2="-4.7099" width="0.1016" layer="21"/>
<wire x1="0.3755" y1="-4.7099" x2="0.9554" y2="-5.2897" width="0.1016" layer="21"/>
<wire x1="0.3754" y1="-3.9594" x2="0.9552" y2="-3.3795" width="0.1016" layer="21"/>
<wire x1="-1.2278" y1="-5.5286" x2="-0.6479" y2="-4.9487" width="0.1016" layer="21"/>
<wire x1="-1.2278" y1="-3.1408" x2="-0.6138" y2="-2.7996" width="0.1016" layer="21"/>
<wire x1="-0.6138" y1="-2.7996" x2="0.1027" y2="-2.7997" width="0.1016" layer="21"/>
<wire x1="0.1027" y1="-2.7997" x2="0.7166" y2="-3.1408" width="0.1016" layer="21"/>
<wire x1="0.1027" y1="-3.516" x2="-0.6137" y2="-3.516" width="0.1016" layer="21"/>
<wire x1="-0.6137" y1="-3.516" x2="-1.2279" y2="-3.1408" width="0.1016" layer="21"/>
<wire x1="-1.4325" y1="-3.3454" x2="-1.603" y2="-3.4478" width="0.1016" layer="21"/>
<wire x1="-1.603" y1="-3.4478" x2="-1.603" y2="-5.1534" width="0.1016" layer="21"/>
<wire x1="-1.603" y1="-5.1534" x2="-1.4325" y2="-5.2557" width="0.1016" layer="21"/>
<wire x1="-0.8525" y1="-4.6759" x2="-0.8526" y2="-3.9254" width="0.1016" layer="21"/>
<wire x1="-0.8526" y1="-3.9254" x2="-1.4325" y2="-3.3456" width="0.1016" layer="21"/>
<wire x1="-0.8525" y1="-4.6759" x2="-1.4323" y2="-5.2558" width="0.1016" layer="21"/>
<wire x1="0.7166" y1="-3.1408" x2="0.1027" y2="-3.516" width="0.1016" layer="21"/>
<wire x1="-1.2279" y1="-3.1408" x2="-1.2278" y2="-3.1408" width="0.1016" layer="21"/>
<wire x1="0.9554" y1="-2.9362" x2="1.1259" y2="-2.8338" width="0.1016" layer="21"/>
<wire x1="1.1259" y1="-2.8338" x2="1.1259" y2="-1.1282" width="0.1016" layer="21"/>
<wire x1="1.1259" y1="-1.1282" x2="0.9554" y2="-1.0259" width="0.1016" layer="21"/>
<wire x1="0.3754" y1="-1.6057" x2="0.3755" y2="-2.3562" width="0.1016" layer="21"/>
<wire x1="0.3755" y1="-2.3562" x2="0.9554" y2="-2.936" width="0.1016" layer="21"/>
<wire x1="0.3754" y1="-1.6057" x2="0.9552" y2="-1.0258" width="0.1016" layer="21"/>
<wire x1="2.8315" y1="-0.7871" x2="2.968" y2="-0.6506" width="0.1016" layer="21"/>
<wire x1="2.968" y1="-0.6506" x2="4.6736" y2="-0.6506" width="0.1016" layer="21"/>
<wire x1="4.6736" y1="-0.6506" x2="4.81" y2="-0.7871" width="0.1016" layer="21"/>
<wire x1="4.2301" y1="-1.367" x2="3.4114" y2="-1.367" width="0.1016" layer="21"/>
<wire x1="3.4114" y1="-1.367" x2="2.8315" y2="-0.7871" width="0.1016" layer="21"/>
<wire x1="2.6268" y1="-1.0258" x2="2.4563" y2="-1.1282" width="0.1016" layer="21"/>
<wire x1="2.4563" y1="-1.1282" x2="2.4563" y2="-2.8338" width="0.1016" layer="21"/>
<wire x1="2.4563" y1="-2.8338" x2="2.6268" y2="-2.9361" width="0.1016" layer="21"/>
<wire x1="3.2068" y1="-2.3563" x2="3.2067" y2="-1.6058" width="0.1016" layer="21"/>
<wire x1="3.2067" y1="-1.6058" x2="2.6268" y2="-1.026" width="0.1016" layer="21"/>
<wire x1="3.2068" y1="-2.3563" x2="2.627" y2="-2.9362" width="0.1016" layer="21"/>
<wire x1="4.81" y1="-0.7871" x2="4.2301" y2="-1.367" width="0.1016" layer="21"/>
<wire x1="4.81" y1="-5.5286" x2="4.6735" y2="-5.6651" width="0.1016" layer="21"/>
<wire x1="4.6735" y1="-5.6651" x2="2.9679" y2="-5.6651" width="0.1016" layer="21"/>
<wire x1="2.9679" y1="-5.6651" x2="2.8315" y2="-5.5286" width="0.1016" layer="21"/>
<wire x1="3.4114" y1="-4.9487" x2="4.2301" y2="-4.9487" width="0.1016" layer="21"/>
<wire x1="4.2301" y1="-4.9487" x2="4.81" y2="-5.5286" width="0.1016" layer="21"/>
<wire x1="5.0147" y1="-5.2899" x2="5.1852" y2="-5.1875" width="0.1016" layer="21"/>
<wire x1="5.1852" y1="-5.1875" x2="5.1852" y2="-3.4819" width="0.1016" layer="21"/>
<wire x1="5.1852" y1="-3.4819" x2="5.0147" y2="-3.3796" width="0.1016" layer="21"/>
<wire x1="4.4347" y1="-3.9594" x2="4.4348" y2="-4.7099" width="0.1016" layer="21"/>
<wire x1="4.4348" y1="-4.7099" x2="5.0147" y2="-5.2897" width="0.1016" layer="21"/>
<wire x1="4.4347" y1="-3.9594" x2="5.0145" y2="-3.3795" width="0.1016" layer="21"/>
<wire x1="2.8315" y1="-5.5286" x2="3.4114" y2="-4.9487" width="0.1016" layer="21"/>
<wire x1="2.8315" y1="-3.1408" x2="3.4455" y2="-2.7996" width="0.1016" layer="21"/>
<wire x1="3.4455" y1="-2.7996" x2="4.162" y2="-2.7997" width="0.1016" layer="21"/>
<wire x1="4.162" y1="-2.7997" x2="4.7759" y2="-3.1408" width="0.1016" layer="21"/>
<wire x1="4.162" y1="-3.516" x2="3.4456" y2="-3.516" width="0.1016" layer="21"/>
<wire x1="3.4456" y1="-3.516" x2="2.8314" y2="-3.1408" width="0.1016" layer="21"/>
<wire x1="2.6268" y1="-3.3454" x2="2.4563" y2="-3.4478" width="0.1016" layer="21"/>
<wire x1="2.4563" y1="-3.4478" x2="2.4563" y2="-5.1534" width="0.1016" layer="21"/>
<wire x1="2.4563" y1="-5.1534" x2="2.6268" y2="-5.2557" width="0.1016" layer="21"/>
<wire x1="3.2068" y1="-4.6759" x2="3.2067" y2="-3.9254" width="0.1016" layer="21"/>
<wire x1="3.2067" y1="-3.9254" x2="2.6268" y2="-3.3456" width="0.1016" layer="21"/>
<wire x1="3.2068" y1="-4.6759" x2="2.627" y2="-5.2558" width="0.1016" layer="21"/>
<wire x1="4.7759" y1="-3.1408" x2="4.162" y2="-3.516" width="0.1016" layer="21"/>
<wire x1="2.8314" y1="-3.1408" x2="2.8315" y2="-3.1408" width="0.1016" layer="21"/>
<wire x1="5.0147" y1="-2.9362" x2="5.1852" y2="-2.8338" width="0.1016" layer="21"/>
<wire x1="5.1852" y1="-2.8338" x2="5.1852" y2="-1.1282" width="0.1016" layer="21"/>
<wire x1="5.1852" y1="-1.1282" x2="5.0147" y2="-1.0259" width="0.1016" layer="21"/>
<wire x1="4.4347" y1="-1.6057" x2="4.4348" y2="-2.3562" width="0.1016" layer="21"/>
<wire x1="4.4348" y1="-2.3562" x2="5.0147" y2="-2.936" width="0.1016" layer="21"/>
<wire x1="4.4347" y1="-1.6057" x2="5.0145" y2="-1.0258" width="0.1016" layer="21"/>
<wire x1="6.8909" y1="-0.7871" x2="7.0274" y2="-0.6506" width="0.1016" layer="21"/>
<wire x1="7.0274" y1="-0.6506" x2="8.733" y2="-0.6506" width="0.1016" layer="21"/>
<wire x1="8.733" y1="-0.6506" x2="8.8694" y2="-0.7871" width="0.1016" layer="21"/>
<wire x1="8.2895" y1="-1.367" x2="7.4708" y2="-1.367" width="0.1016" layer="21"/>
<wire x1="7.4708" y1="-1.367" x2="6.8909" y2="-0.7871" width="0.1016" layer="21"/>
<wire x1="6.6862" y1="-1.0258" x2="6.5157" y2="-1.1282" width="0.1016" layer="21"/>
<wire x1="6.5157" y1="-1.1282" x2="6.5157" y2="-2.8338" width="0.1016" layer="21"/>
<wire x1="6.5157" y1="-2.8338" x2="6.6862" y2="-2.9361" width="0.1016" layer="21"/>
<wire x1="7.2662" y1="-2.3563" x2="7.2661" y2="-1.6058" width="0.1016" layer="21"/>
<wire x1="7.2661" y1="-1.6058" x2="6.6862" y2="-1.026" width="0.1016" layer="21"/>
<wire x1="7.2662" y1="-2.3563" x2="6.6864" y2="-2.9362" width="0.1016" layer="21"/>
<wire x1="8.8694" y1="-0.7871" x2="8.2895" y2="-1.367" width="0.1016" layer="21"/>
<wire x1="8.8694" y1="-5.5286" x2="8.7329" y2="-5.6651" width="0.1016" layer="21"/>
<wire x1="8.7329" y1="-5.6651" x2="7.0273" y2="-5.6651" width="0.1016" layer="21"/>
<wire x1="7.0273" y1="-5.6651" x2="6.8909" y2="-5.5286" width="0.1016" layer="21"/>
<wire x1="7.4708" y1="-4.9487" x2="8.2895" y2="-4.9487" width="0.1016" layer="21"/>
<wire x1="8.2895" y1="-4.9487" x2="8.8694" y2="-5.5286" width="0.1016" layer="21"/>
<wire x1="9.0741" y1="-5.2899" x2="9.2446" y2="-5.1875" width="0.1016" layer="21"/>
<wire x1="9.2446" y1="-5.1875" x2="9.2446" y2="-3.4819" width="0.1016" layer="21"/>
<wire x1="9.2446" y1="-3.4819" x2="9.0741" y2="-3.3796" width="0.1016" layer="21"/>
<wire x1="8.4941" y1="-3.9594" x2="8.4942" y2="-4.7099" width="0.1016" layer="21"/>
<wire x1="8.4942" y1="-4.7099" x2="9.0741" y2="-5.2897" width="0.1016" layer="21"/>
<wire x1="8.4941" y1="-3.9594" x2="9.0739" y2="-3.3795" width="0.1016" layer="21"/>
<wire x1="6.8909" y1="-5.5286" x2="7.4708" y2="-4.9487" width="0.1016" layer="21"/>
<wire x1="6.8909" y1="-3.1408" x2="7.5049" y2="-2.7996" width="0.1016" layer="21"/>
<wire x1="7.5049" y1="-2.7996" x2="8.2214" y2="-2.7997" width="0.1016" layer="21"/>
<wire x1="8.2214" y1="-2.7997" x2="8.8353" y2="-3.1408" width="0.1016" layer="21"/>
<wire x1="8.2214" y1="-3.516" x2="7.505" y2="-3.516" width="0.1016" layer="21"/>
<wire x1="7.505" y1="-3.516" x2="6.8908" y2="-3.1408" width="0.1016" layer="21"/>
<wire x1="6.6862" y1="-3.3454" x2="6.5157" y2="-3.4478" width="0.1016" layer="21"/>
<wire x1="6.5157" y1="-3.4478" x2="6.5157" y2="-5.1534" width="0.1016" layer="21"/>
<wire x1="6.5157" y1="-5.1534" x2="6.6862" y2="-5.2557" width="0.1016" layer="21"/>
<wire x1="7.2662" y1="-4.6759" x2="7.2661" y2="-3.9254" width="0.1016" layer="21"/>
<wire x1="7.2661" y1="-3.9254" x2="6.6862" y2="-3.3456" width="0.1016" layer="21"/>
<wire x1="7.2662" y1="-4.6759" x2="6.6864" y2="-5.2558" width="0.1016" layer="21"/>
<wire x1="8.8353" y1="-3.1408" x2="8.2214" y2="-3.516" width="0.1016" layer="21"/>
<wire x1="6.8908" y1="-3.1408" x2="6.8909" y2="-3.1408" width="0.1016" layer="21"/>
<wire x1="9.0741" y1="-2.9362" x2="9.2446" y2="-2.8338" width="0.1016" layer="21"/>
<wire x1="9.2446" y1="-2.8338" x2="9.2446" y2="-1.1282" width="0.1016" layer="21"/>
<wire x1="9.2446" y1="-1.1282" x2="9.0741" y2="-1.0259" width="0.1016" layer="21"/>
<wire x1="8.4941" y1="-1.6057" x2="8.4942" y2="-2.3562" width="0.1016" layer="21"/>
<wire x1="8.4942" y1="-2.3562" x2="9.0741" y2="-2.936" width="0.1016" layer="21"/>
<wire x1="8.4941" y1="-1.6057" x2="9.0739" y2="-1.0258" width="0.1016" layer="21"/>
<wire x1="10.9502" y1="-0.7871" x2="11.0867" y2="-0.6506" width="0.1016" layer="21"/>
<wire x1="11.0867" y1="-0.6506" x2="12.7923" y2="-0.6506" width="0.1016" layer="21"/>
<wire x1="12.7923" y1="-0.6506" x2="12.9287" y2="-0.7871" width="0.1016" layer="21"/>
<wire x1="12.3488" y1="-1.367" x2="11.5301" y2="-1.367" width="0.1016" layer="21"/>
<wire x1="11.5301" y1="-1.367" x2="10.9502" y2="-0.7871" width="0.1016" layer="21"/>
<wire x1="10.7455" y1="-1.0258" x2="10.575" y2="-1.1282" width="0.1016" layer="21"/>
<wire x1="10.575" y1="-1.1282" x2="10.575" y2="-2.8338" width="0.1016" layer="21"/>
<wire x1="10.575" y1="-2.8338" x2="10.7455" y2="-2.9361" width="0.1016" layer="21"/>
<wire x1="11.3255" y1="-2.3563" x2="11.3254" y2="-1.6058" width="0.1016" layer="21"/>
<wire x1="11.3254" y1="-1.6058" x2="10.7455" y2="-1.026" width="0.1016" layer="21"/>
<wire x1="11.3255" y1="-2.3563" x2="10.7457" y2="-2.9362" width="0.1016" layer="21"/>
<wire x1="12.9287" y1="-0.7871" x2="12.3488" y2="-1.367" width="0.1016" layer="21"/>
<wire x1="12.9287" y1="-5.5286" x2="12.7922" y2="-5.6651" width="0.1016" layer="21"/>
<wire x1="12.7922" y1="-5.6651" x2="11.0866" y2="-5.6651" width="0.1016" layer="21"/>
<wire x1="11.0866" y1="-5.6651" x2="10.9502" y2="-5.5286" width="0.1016" layer="21"/>
<wire x1="11.5301" y1="-4.9487" x2="12.3488" y2="-4.9487" width="0.1016" layer="21"/>
<wire x1="12.3488" y1="-4.9487" x2="12.9287" y2="-5.5286" width="0.1016" layer="21"/>
<wire x1="13.1334" y1="-5.2899" x2="13.3039" y2="-5.1875" width="0.1016" layer="21"/>
<wire x1="13.3039" y1="-5.1875" x2="13.3039" y2="-3.4819" width="0.1016" layer="21"/>
<wire x1="13.3039" y1="-3.4819" x2="13.1334" y2="-3.3796" width="0.1016" layer="21"/>
<wire x1="12.5534" y1="-3.9594" x2="12.5535" y2="-4.7099" width="0.1016" layer="21"/>
<wire x1="12.5535" y1="-4.7099" x2="13.1334" y2="-5.2897" width="0.1016" layer="21"/>
<wire x1="12.5534" y1="-3.9594" x2="13.1332" y2="-3.3795" width="0.1016" layer="21"/>
<wire x1="10.9502" y1="-5.5286" x2="11.5301" y2="-4.9487" width="0.1016" layer="21"/>
<wire x1="10.9502" y1="-3.1408" x2="11.5642" y2="-2.7996" width="0.1016" layer="21"/>
<wire x1="11.5642" y1="-2.7996" x2="12.2807" y2="-2.7997" width="0.1016" layer="21"/>
<wire x1="12.2807" y1="-2.7997" x2="12.8946" y2="-3.1408" width="0.1016" layer="21"/>
<wire x1="12.2807" y1="-3.516" x2="11.5643" y2="-3.516" width="0.1016" layer="21"/>
<wire x1="11.5643" y1="-3.516" x2="10.9501" y2="-3.1408" width="0.1016" layer="21"/>
<wire x1="10.7455" y1="-3.3454" x2="10.575" y2="-3.4478" width="0.1016" layer="21"/>
<wire x1="10.575" y1="-3.4478" x2="10.575" y2="-5.1534" width="0.1016" layer="21"/>
<wire x1="10.575" y1="-5.1534" x2="10.7455" y2="-5.2557" width="0.1016" layer="21"/>
<wire x1="11.3255" y1="-4.6759" x2="11.3254" y2="-3.9254" width="0.1016" layer="21"/>
<wire x1="11.3254" y1="-3.9254" x2="10.7455" y2="-3.3456" width="0.1016" layer="21"/>
<wire x1="11.3255" y1="-4.6759" x2="10.7457" y2="-5.2558" width="0.1016" layer="21"/>
<wire x1="12.8946" y1="-3.1408" x2="12.2807" y2="-3.516" width="0.1016" layer="21"/>
<wire x1="10.9501" y1="-3.1408" x2="10.9502" y2="-3.1408" width="0.1016" layer="21"/>
<wire x1="13.1334" y1="-2.9362" x2="13.3039" y2="-2.8338" width="0.1016" layer="21"/>
<wire x1="13.3039" y1="-2.8338" x2="13.3039" y2="-1.1282" width="0.1016" layer="21"/>
<wire x1="13.3039" y1="-1.1282" x2="13.1334" y2="-1.0259" width="0.1016" layer="21"/>
<wire x1="12.5534" y1="-1.6057" x2="12.5535" y2="-2.3562" width="0.1016" layer="21"/>
<wire x1="12.5535" y1="-2.3562" x2="13.1334" y2="-2.936" width="0.1016" layer="21"/>
<wire x1="12.5534" y1="-1.6057" x2="13.1332" y2="-1.0258" width="0.1016" layer="21"/>
<wire x1="15.0096" y1="-0.7871" x2="15.1461" y2="-0.6506" width="0.1016" layer="21"/>
<wire x1="15.1461" y1="-0.6506" x2="16.8517" y2="-0.6506" width="0.1016" layer="21"/>
<wire x1="16.8517" y1="-0.6506" x2="16.9881" y2="-0.7871" width="0.1016" layer="21"/>
<wire x1="16.4082" y1="-1.367" x2="15.5895" y2="-1.367" width="0.1016" layer="21"/>
<wire x1="15.5895" y1="-1.367" x2="15.0096" y2="-0.7871" width="0.1016" layer="21"/>
<wire x1="14.8049" y1="-1.0258" x2="14.6344" y2="-1.1282" width="0.1016" layer="21"/>
<wire x1="14.6344" y1="-1.1282" x2="14.6344" y2="-2.8338" width="0.1016" layer="21"/>
<wire x1="14.6344" y1="-2.8338" x2="14.8049" y2="-2.9361" width="0.1016" layer="21"/>
<wire x1="15.3849" y1="-2.3563" x2="15.3848" y2="-1.6058" width="0.1016" layer="21"/>
<wire x1="15.3848" y1="-1.6058" x2="14.8049" y2="-1.026" width="0.1016" layer="21"/>
<wire x1="15.3849" y1="-2.3563" x2="14.8051" y2="-2.9362" width="0.1016" layer="21"/>
<wire x1="16.9881" y1="-0.7871" x2="16.4082" y2="-1.367" width="0.1016" layer="21"/>
<wire x1="16.9881" y1="-5.5286" x2="16.8516" y2="-5.6651" width="0.1016" layer="21"/>
<wire x1="16.8516" y1="-5.6651" x2="15.146" y2="-5.6651" width="0.1016" layer="21"/>
<wire x1="15.146" y1="-5.6651" x2="15.0096" y2="-5.5286" width="0.1016" layer="21"/>
<wire x1="15.5895" y1="-4.9487" x2="16.4082" y2="-4.9487" width="0.1016" layer="21"/>
<wire x1="16.4082" y1="-4.9487" x2="16.9881" y2="-5.5286" width="0.1016" layer="21"/>
<wire x1="17.1928" y1="-5.2899" x2="17.3633" y2="-5.1875" width="0.1016" layer="21"/>
<wire x1="17.3633" y1="-5.1875" x2="17.3633" y2="-3.4819" width="0.1016" layer="21"/>
<wire x1="17.3633" y1="-3.4819" x2="17.1928" y2="-3.3796" width="0.1016" layer="21"/>
<wire x1="16.6128" y1="-3.9594" x2="16.6129" y2="-4.7099" width="0.1016" layer="21"/>
<wire x1="16.6129" y1="-4.7099" x2="17.1928" y2="-5.2897" width="0.1016" layer="21"/>
<wire x1="16.6128" y1="-3.9594" x2="17.1926" y2="-3.3795" width="0.1016" layer="21"/>
<wire x1="15.0096" y1="-5.5286" x2="15.5895" y2="-4.9487" width="0.1016" layer="21"/>
<wire x1="15.0096" y1="-3.1408" x2="15.6236" y2="-2.7996" width="0.1016" layer="21"/>
<wire x1="15.6236" y1="-2.7996" x2="16.3401" y2="-2.7997" width="0.1016" layer="21"/>
<wire x1="16.3401" y1="-2.7997" x2="16.954" y2="-3.1408" width="0.1016" layer="21"/>
<wire x1="16.3401" y1="-3.516" x2="15.6237" y2="-3.516" width="0.1016" layer="21"/>
<wire x1="15.6237" y1="-3.516" x2="15.0095" y2="-3.1408" width="0.1016" layer="21"/>
<wire x1="14.8049" y1="-3.3454" x2="14.6344" y2="-3.4478" width="0.1016" layer="21"/>
<wire x1="14.6344" y1="-3.4478" x2="14.6344" y2="-5.1534" width="0.1016" layer="21"/>
<wire x1="14.6344" y1="-5.1534" x2="14.8049" y2="-5.2557" width="0.1016" layer="21"/>
<wire x1="15.3849" y1="-4.6759" x2="15.3848" y2="-3.9254" width="0.1016" layer="21"/>
<wire x1="15.3848" y1="-3.9254" x2="14.8049" y2="-3.3456" width="0.1016" layer="21"/>
<wire x1="15.3849" y1="-4.6759" x2="14.8051" y2="-5.2558" width="0.1016" layer="21"/>
<wire x1="16.954" y1="-3.1408" x2="16.3401" y2="-3.516" width="0.1016" layer="21"/>
<wire x1="15.0095" y1="-3.1408" x2="15.0096" y2="-3.1408" width="0.1016" layer="21"/>
<wire x1="17.1928" y1="-2.9362" x2="17.3633" y2="-2.8338" width="0.1016" layer="21"/>
<wire x1="17.3633" y1="-2.8338" x2="17.3633" y2="-1.1282" width="0.1016" layer="21"/>
<wire x1="17.3633" y1="-1.1282" x2="17.1928" y2="-1.0259" width="0.1016" layer="21"/>
<wire x1="16.6128" y1="-1.6057" x2="16.6129" y2="-2.3562" width="0.1016" layer="21"/>
<wire x1="16.6129" y1="-2.3562" x2="17.1928" y2="-2.936" width="0.1016" layer="21"/>
<wire x1="16.6128" y1="-1.6057" x2="17.1926" y2="-1.0258" width="0.1016" layer="21"/>
<wire x1="5.5264" y1="-3.8913" x2="6.1405" y2="-3.8913" width="0.1016" layer="21"/>
<wire x1="6.1405" y1="-3.8913" x2="6.1405" y2="-4.4712" width="0.1016" layer="21"/>
<wire x1="6.1405" y1="-4.4712" x2="5.5264" y2="-4.4712" width="0.1016" layer="21"/>
<wire x1="5.5264" y1="-4.4712" x2="5.5264" y2="-3.8913" width="0.1016" layer="21"/>
<wire x1="5.5264" y1="-1.8445" x2="6.1405" y2="-1.8445" width="0.1016" layer="21"/>
<wire x1="6.1405" y1="-1.8445" x2="6.1405" y2="-2.4586" width="0.1016" layer="21"/>
<wire x1="6.1405" y1="-2.4586" x2="5.5264" y2="-2.4586" width="0.1016" layer="21"/>
<wire x1="5.5264" y1="-2.4586" x2="5.5264" y2="-1.8445" width="0.1016" layer="21"/>
<wire x1="-2.5923" y1="-3.8913" x2="-1.9782" y2="-3.8913" width="0.1016" layer="21"/>
<wire x1="-1.9782" y1="-3.8913" x2="-1.9782" y2="-4.4712" width="0.1016" layer="21"/>
<wire x1="-1.9782" y1="-4.4712" x2="-2.5923" y2="-4.4712" width="0.1016" layer="21"/>
<wire x1="-2.5923" y1="-4.4712" x2="-2.5923" y2="-3.8913" width="0.1016" layer="21"/>
<wire x1="-2.5923" y1="-1.8445" x2="-1.9782" y2="-1.8445" width="0.1016" layer="21"/>
<wire x1="-1.9782" y1="-1.8445" x2="-1.9782" y2="-2.4586" width="0.1016" layer="21"/>
<wire x1="-1.9782" y1="-2.4586" x2="-2.5923" y2="-2.4586" width="0.1016" layer="21"/>
<wire x1="-2.5923" y1="-2.4586" x2="-2.5923" y2="-1.8445" width="0.1016" layer="21"/>
<wire x1="-7.675" y1="4.4662" x2="-6.4469" y2="4.4662" width="0.1016" layer="21"/>
<wire x1="-7.6409" y1="3.0676" x2="-6.9927" y2="3.0676" width="0.1016" layer="21"/>
<wire x1="-17.3629" y1="1.6008" x2="-16.4418" y2="1.6008" width="0.1016" layer="21"/>
<wire x1="-16.4418" y1="1.6008" x2="-16.4418" y2="1.2938" width="0.1016" layer="21"/>
<wire x1="-16.4418" y1="1.2938" x2="-16.7829" y2="1.2938" width="0.1016" layer="21"/>
<wire x1="-16.7829" y1="1.2938" x2="-16.7829" y2="0.3728" width="0.1016" layer="21"/>
<wire x1="-16.7829" y1="0.3728" x2="-17.0217" y2="0.3728" width="0.1016" layer="21"/>
<wire x1="-17.0217" y1="0.3728" x2="-17.0217" y2="1.2938" width="0.1016" layer="21"/>
<wire x1="-17.0217" y1="1.2938" x2="-17.3629" y2="1.2938" width="0.1016" layer="21"/>
<wire x1="-17.3629" y1="1.2938" x2="-17.3629" y2="1.6008" width="0.1016" layer="21"/>
<wire x1="-14.4974" y1="1.6008" x2="-14.4974" y2="0.3728" width="0.1016" layer="21"/>
<wire x1="-14.4974" y1="0.3728" x2="-14.2245" y2="0.3728" width="0.1016" layer="21"/>
<wire x1="-14.2245" y1="0.3728" x2="-14.2245" y2="0.8503" width="0.1016" layer="21"/>
<wire x1="-14.2245" y1="0.8503" x2="-14.1222" y2="0.8503" width="0.1016" layer="21"/>
<wire x1="-14.1222" y1="0.8503" x2="-13.8834" y2="0.3728" width="0.1016" layer="21"/>
<wire x1="-13.8834" y1="0.3728" x2="-13.5764" y2="0.3728" width="0.1016" layer="21"/>
<wire x1="-13.5764" y1="0.3728" x2="-13.7811" y2="0.8162" width="0.1016" layer="21"/>
<wire x1="-13.7811" y1="0.8162" x2="-13.8493" y2="0.8844" width="0.1016" layer="21"/>
<wire x1="-13.8493" y1="0.8844" x2="-13.8493" y2="0.9527" width="0.1016" layer="21"/>
<wire x1="-13.8493" y1="0.9527" x2="-13.8152" y2="0.9527" width="0.1016" layer="21"/>
<wire x1="-13.8152" y1="0.9527" x2="-13.6105" y2="1.1573" width="0.1016" layer="21" curve="90.084032"/>
<wire x1="-13.6105" y1="1.1573" x2="-13.6105" y2="1.2938" width="0.1016" layer="21" curve="0.056021"/>
<wire x1="-13.6105" y1="1.2938" x2="-13.9175" y2="1.6008" width="0.1016" layer="21" curve="89.925396"/>
<wire x1="-13.9175" y1="1.6008" x2="-14.4974" y2="1.6008" width="0.1016" layer="21" curve="0.074565"/>
<wire x1="-14.1904" y1="1.3279" x2="-14.1904" y2="1.1232" width="0.1016" layer="21"/>
<wire x1="-14.1904" y1="1.1232" x2="-14.054" y2="1.1232" width="0.1016" layer="21"/>
<wire x1="-14.054" y1="1.1232" x2="-14.0199" y2="1.3279" width="0.1016" layer="21" curve="161.193388"/>
<wire x1="-14.0199" y1="1.3279" x2="-14.1904" y2="1.3279" width="0.1016" layer="21"/>
<wire x1="-16.2371" y1="1.1915" x2="-15.9643" y2="0.7821" width="0.1016" layer="21"/>
<wire x1="-15.9643" y1="0.7821" x2="-16.2713" y2="0.3728" width="0.1016" layer="21"/>
<wire x1="-16.2713" y1="0.3728" x2="-15.9984" y2="0.3728" width="0.1016" layer="21"/>
<wire x1="-15.9984" y1="0.3728" x2="-15.8278" y2="0.6115" width="0.1016" layer="21"/>
<wire x1="-15.8278" y1="0.6115" x2="-15.6914" y2="0.3728" width="0.1016" layer="21"/>
<wire x1="-15.6914" y1="0.3728" x2="-15.4185" y2="0.3728" width="0.1016" layer="21"/>
<wire x1="-15.4185" y1="0.3728" x2="-15.6914" y2="0.7821" width="0.1016" layer="21"/>
<wire x1="-15.6914" y1="0.7821" x2="-15.4185" y2="1.1915" width="0.1016" layer="21"/>
<wire x1="-15.4185" y1="1.1915" x2="-15.6572" y2="1.1915" width="0.1016" layer="21"/>
<wire x1="-15.6572" y1="1.1915" x2="-15.8278" y2="0.9527" width="0.1016" layer="21"/>
<wire x1="-15.8278" y1="0.9527" x2="-15.9984" y2="1.1915" width="0.1016" layer="21"/>
<wire x1="-15.9984" y1="1.1915" x2="-16.2371" y2="1.1915" width="0.1016" layer="21"/>
<wire x1="-13.3376" y1="1.1915" x2="-13.0648" y2="0.7821" width="0.1016" layer="21"/>
<wire x1="-13.0648" y1="0.7821" x2="-13.3718" y2="0.3728" width="0.1016" layer="21"/>
<wire x1="-13.3718" y1="0.3728" x2="-13.0989" y2="0.3728" width="0.1016" layer="21"/>
<wire x1="-13.0989" y1="0.3728" x2="-12.9283" y2="0.6115" width="0.1016" layer="21"/>
<wire x1="-12.9283" y1="0.6115" x2="-12.7919" y2="0.3728" width="0.1016" layer="21"/>
<wire x1="-12.7919" y1="0.3728" x2="-12.519" y2="0.3728" width="0.1016" layer="21"/>
<wire x1="-12.519" y1="0.3728" x2="-12.7919" y2="0.7821" width="0.1016" layer="21"/>
<wire x1="-12.7919" y1="0.7821" x2="-12.519" y2="1.1915" width="0.1016" layer="21"/>
<wire x1="-12.519" y1="1.1915" x2="-12.7577" y2="1.1915" width="0.1016" layer="21"/>
<wire x1="-12.7577" y1="1.1915" x2="-12.9283" y2="0.9527" width="0.1016" layer="21"/>
<wire x1="-12.9283" y1="0.9527" x2="-13.0989" y2="1.1915" width="0.1016" layer="21"/>
<wire x1="-13.0989" y1="1.1915" x2="-13.3376" y2="1.1915" width="0.1016" layer="21"/>
<circle x="-10.404" y="-5.3581" radius="0.3144" width="0.1016" layer="21"/>
<circle x="-6.3447" y="-5.3581" radius="0.3144" width="0.1016" layer="21"/>
<circle x="1.774" y="-5.3581" radius="0.3144" width="0.1016" layer="21"/>
<circle x="9.8927" y="-5.3581" radius="0.3144" width="0.1016" layer="21"/>
<circle x="13.9521" y="-5.3581" radius="0.3144" width="0.1016" layer="21"/>
<pad name="1" x="-16.51" y="-11.43" drill="0.9" diameter="1.4224"/>
<pad name="2" x="-13.97" y="-11.43" drill="0.9" diameter="1.4224"/>
<pad name="3" x="-11.43" y="-11.43" drill="0.9" diameter="1.4224"/>
<pad name="4" x="-8.89" y="-11.43" drill="0.9" diameter="1.4224"/>
<pad name="5" x="-6.35" y="-11.43" drill="0.9" diameter="1.4224"/>
<pad name="6" x="-3.81" y="-11.43" drill="0.9" diameter="1.4224"/>
<pad name="7" x="-1.27" y="-11.43" drill="0.9" diameter="1.4224"/>
<pad name="8" x="1.27" y="-11.43" drill="0.9" diameter="1.4224"/>
<pad name="9" x="3.81" y="-11.43" drill="0.9" diameter="1.4224"/>
<pad name="10" x="6.35" y="-11.43" drill="0.9" diameter="1.4224"/>
<pad name="11" x="8.89" y="-11.43" drill="0.9" diameter="1.4224"/>
<pad name="12" x="11.43" y="-11.43" drill="0.9" diameter="1.4224"/>
<pad name="13" x="13.97" y="-11.43" drill="0.9" diameter="1.4224"/>
<pad name="14" x="16.51" y="-11.43" drill="0.9" diameter="1.4224"/>
<pad name="15" x="13.97" y="11.43" drill="0.9" diameter="1.4224"/>
<pad name="16" x="11.43" y="11.43" drill="0.9" diameter="1.4224"/>
<pad name="17" x="8.89" y="11.43" drill="0.9" diameter="1.4224"/>
<pad name="18" x="6.35" y="11.43" drill="0.9" diameter="1.4224"/>
<pad name="19" x="3.81" y="11.43" drill="0.9" diameter="1.4224"/>
<pad name="20" x="1.27" y="11.43" drill="0.9" diameter="1.4224"/>
<pad name="21" x="-1.27" y="11.43" drill="0.9" diameter="1.4224"/>
<pad name="22" x="-3.81" y="11.43" drill="0.9" diameter="1.4224"/>
<pad name="23" x="-6.35" y="11.43" drill="0.9" diameter="1.4224"/>
<pad name="24" x="-8.89" y="11.43" drill="0.9" diameter="1.4224"/>
<pad name="25" x="-11.43" y="11.43" drill="0.9" diameter="1.4224"/>
<pad name="26" x="-13.97" y="11.43" drill="0.9" diameter="1.4224"/>
<text x="-17.145" y="-13.97" size="1.27" layer="25">&gt;NAME</text>
<text x="-8.89" y="-13.97" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-14.5998" y1="7.6387" x2="-13.3035" y2="10.163" layer="21"/>
<rectangle x1="-12.0755" y1="7.6387" x2="-10.7793" y2="10.1629" layer="21"/>
<rectangle x1="-9.5512" y1="7.6387" x2="-8.255" y2="10.1629" layer="21"/>
<rectangle x1="-6.9928" y1="7.6387" x2="-5.6966" y2="10.1629" layer="21"/>
<rectangle x1="-4.4344" y1="7.6387" x2="-3.1382" y2="10.1629" layer="21"/>
<rectangle x1="-1.9101" y1="7.6387" x2="-0.6139" y2="10.1629" layer="21"/>
<rectangle x1="0.6142" y1="7.6387" x2="1.9104" y2="10.1629" layer="21"/>
<rectangle x1="3.1727" y1="7.6387" x2="4.4689" y2="10.1629" layer="21"/>
<rectangle x1="5.697" y1="7.6387" x2="6.9932" y2="10.1629" layer="21"/>
<rectangle x1="8.2213" y1="7.6387" x2="9.5175" y2="10.1629" layer="21"/>
<rectangle x1="10.7798" y1="7.6387" x2="12.076" y2="10.1629" layer="21"/>
<rectangle x1="13.3041" y1="7.6387" x2="14.6003" y2="10.1629" layer="21"/>
<rectangle x1="10.7458" y1="-10.1678" x2="12.042" y2="-7.6436" layer="21" rot="R180"/>
<rectangle x1="8.2215" y1="-10.1678" x2="9.5177" y2="-7.6436" layer="21" rot="R180"/>
<rectangle x1="5.6972" y1="-10.1678" x2="6.9934" y2="-7.6436" layer="21" rot="R180"/>
<rectangle x1="3.1388" y1="-10.1678" x2="4.435" y2="-7.6436" layer="21" rot="R180"/>
<rectangle x1="0.5804" y1="-10.1678" x2="1.8766" y2="-7.6436" layer="21" rot="R180"/>
<rectangle x1="-1.9439" y1="-10.1678" x2="-0.6477" y2="-7.6436" layer="21" rot="R180"/>
<rectangle x1="-4.4682" y1="-10.1678" x2="-3.172" y2="-7.6436" layer="21" rot="R180"/>
<rectangle x1="-7.0267" y1="-10.1678" x2="-5.7305" y2="-7.6436" layer="21" rot="R180"/>
<rectangle x1="-9.551" y1="-10.1678" x2="-8.2548" y2="-7.6436" layer="21" rot="R180"/>
<rectangle x1="-12.0753" y1="-10.1678" x2="-10.7791" y2="-7.6436" layer="21" rot="R180"/>
<rectangle x1="-14.6338" y1="-10.1678" x2="-13.3376" y2="-7.6436" layer="21" rot="R180"/>
<rectangle x1="-17.1581" y1="-10.1678" x2="-15.8619" y2="-7.6436" layer="21" rot="R180"/>
<rectangle x1="13.2858" y1="-10.1678" x2="14.582" y2="-7.6436" layer="21" rot="R180"/>
<rectangle x1="15.8258" y1="-10.1678" x2="17.122" y2="-7.6436" layer="21" rot="R180"/>
</package>
<package name="TUXGR_16X2_R2">
<description>&lt;b&gt;Tuxgraphics LCD display 16x2 characters&lt;/b&gt; reflective, without background light&lt;p&gt;
Source: tuxgr_12x2_r2.pdf</description>
<wire x1="-39.9" y1="17.9" x2="39.9" y2="17.9" width="0.2032" layer="21"/>
<wire x1="39.9" y1="17.9" x2="39.9" y2="-17.9" width="0.2032" layer="21"/>
<wire x1="39.9" y1="-17.9" x2="-39.9" y2="-17.9" width="0.2032" layer="21"/>
<wire x1="-39.9" y1="-17.9" x2="-39.9" y2="17.9" width="0.2032" layer="21"/>
<wire x1="-36.75" y1="12" x2="36.75" y2="12" width="0.2032" layer="21"/>
<wire x1="36.75" y1="12" x2="36.75" y2="-12.6" width="0.2032" layer="21"/>
<wire x1="36.75" y1="-12.6" x2="-36.75" y2="-12.6" width="0.2032" layer="21"/>
<wire x1="-36.75" y1="-12.6" x2="-36.75" y2="12" width="0.2032" layer="21"/>
<wire x1="-32.15" y1="6.5" x2="32.15" y2="6.5" width="0.2032" layer="21"/>
<wire x1="32.15" y1="6.5" x2="32.15" y2="-7.1" width="0.2032" layer="21"/>
<wire x1="32.15" y1="-7.1" x2="-32.15" y2="-7.1" width="0.2032" layer="21"/>
<wire x1="-32.15" y1="-7.1" x2="-32.15" y2="6.5" width="0.2032" layer="21"/>
<pad name="1" x="-32" y="15.5" drill="1" diameter="1.6764"/>
<pad name="2" x="-29.46" y="15.5" drill="1" diameter="1.6764"/>
<pad name="3" x="-26.92" y="15.5" drill="1" diameter="1.6764"/>
<pad name="4" x="-24.38" y="15.5" drill="1" diameter="1.6764"/>
<pad name="5" x="-21.84" y="15.5" drill="1" diameter="1.6764"/>
<pad name="6" x="-19.3" y="15.5" drill="1" diameter="1.6764"/>
<pad name="7" x="-16.76" y="15.5" drill="1" diameter="1.6764"/>
<pad name="8" x="-14.22" y="15.5" drill="1" diameter="1.6764"/>
<pad name="9" x="-11.68" y="15.5" drill="1" diameter="1.6764"/>
<pad name="10" x="-9.14" y="15.5" drill="1" diameter="1.6764"/>
<pad name="11" x="-6.6" y="15.5" drill="1" diameter="1.6764"/>
<pad name="12" x="-4.06" y="15.5" drill="1" diameter="1.6764"/>
<pad name="13" x="-1.52" y="15.5" drill="1" diameter="1.6764"/>
<pad name="14" x="1.02" y="15.5" drill="1" diameter="1.6764"/>
<pad name="15" x="3.56" y="15.5" drill="1" diameter="1.6764"/>
<pad name="16" x="6.1" y="15.5" drill="1" diameter="1.6764"/>
<text x="-38.1" y="18.415" size="1.27" layer="25">&gt;NAME</text>
<text x="0.635" y="18.415" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-28.85" y1="0.1" x2="-25.9" y2="4.45" layer="21"/>
<rectangle x1="-28.85" y1="-5.05" x2="-25.9" y2="-0.7" layer="21"/>
<rectangle x1="-25.2" y1="0.1" x2="-22.25" y2="4.45" layer="21"/>
<rectangle x1="-25.2" y1="-5.05" x2="-22.25" y2="-0.7" layer="21"/>
<rectangle x1="-21.55" y1="0.1" x2="-18.6" y2="4.45" layer="21"/>
<rectangle x1="-21.55" y1="-5.05" x2="-18.6" y2="-0.7" layer="21"/>
<rectangle x1="-17.9" y1="0.1" x2="-14.95" y2="4.45" layer="21"/>
<rectangle x1="-17.9" y1="-5.05" x2="-14.95" y2="-0.7" layer="21"/>
<rectangle x1="-14.25" y1="0.1" x2="-11.3" y2="4.45" layer="21"/>
<rectangle x1="-14.25" y1="-5.05" x2="-11.3" y2="-0.7" layer="21"/>
<rectangle x1="-10.6" y1="0.1" x2="-7.65" y2="4.45" layer="21"/>
<rectangle x1="-10.6" y1="-5.05" x2="-7.65" y2="-0.7" layer="21"/>
<rectangle x1="-6.95" y1="0.1" x2="-4" y2="4.45" layer="21"/>
<rectangle x1="-6.95" y1="-5.05" x2="-4" y2="-0.7" layer="21"/>
<rectangle x1="-3.3" y1="0.1" x2="-0.35" y2="4.45" layer="21"/>
<rectangle x1="-3.3" y1="-5.05" x2="-0.35" y2="-0.7" layer="21"/>
<rectangle x1="0.35" y1="0.1" x2="3.3" y2="4.45" layer="21"/>
<rectangle x1="0.35" y1="-5.05" x2="3.3" y2="-0.7" layer="21"/>
<rectangle x1="4" y1="0.1" x2="6.95" y2="4.45" layer="21"/>
<rectangle x1="4" y1="-5.05" x2="6.95" y2="-0.7" layer="21"/>
<rectangle x1="7.65" y1="0.1" x2="10.6" y2="4.45" layer="21"/>
<rectangle x1="7.65" y1="-5.05" x2="10.6" y2="-0.7" layer="21"/>
<rectangle x1="11.3" y1="0.1" x2="14.25" y2="4.45" layer="21"/>
<rectangle x1="11.3" y1="-5.05" x2="14.25" y2="-0.7" layer="21"/>
<rectangle x1="14.95" y1="0.1" x2="17.9" y2="4.45" layer="21"/>
<rectangle x1="14.95" y1="-5.05" x2="17.9" y2="-0.7" layer="21"/>
<rectangle x1="18.6" y1="0.1" x2="21.55" y2="4.45" layer="21"/>
<rectangle x1="18.6" y1="-5.05" x2="21.55" y2="-0.7" layer="21"/>
<rectangle x1="22.25" y1="0.1" x2="25.2" y2="4.45" layer="21"/>
<rectangle x1="22.25" y1="-5.05" x2="25.2" y2="-0.7" layer="21"/>
<rectangle x1="25.9" y1="0.1" x2="28.85" y2="4.45" layer="21"/>
<rectangle x1="25.9" y1="-5.05" x2="28.85" y2="-0.7" layer="21"/>
<hole x="-37.4" y="-15.5" drill="2.5"/>
<hole x="37.4" y="-15.5" drill="2.5"/>
<hole x="-37.4" y="15.5" drill="2.5"/>
<hole x="37.4" y="15.5" drill="2.5"/>
</package>
<package name="TUXGR_20X2">
<description>&lt;b&gt;Tuxgraphics LCD display 20x2 characters&lt;/b&gt; reflective, without background light&lt;p&gt;
Source: tuxgr_20x2.pdf</description>
<wire x1="-57.9" y1="18.4" x2="57.9" y2="18.4" width="0.2032" layer="21"/>
<wire x1="57.9" y1="18.4" x2="57.9" y2="-18.4" width="0.2032" layer="21"/>
<wire x1="57.9" y1="-18.4" x2="-57.9" y2="-18.4" width="0.2032" layer="21"/>
<wire x1="-57.9" y1="-18.4" x2="-57.9" y2="18.4" width="0.2032" layer="21"/>
<wire x1="-40.4" y1="9.15" x2="42.4" y2="9.15" width="0.2032" layer="21"/>
<wire x1="42.4" y1="9.15" x2="42.4" y2="-9.15" width="0.2032" layer="21"/>
<wire x1="42.4" y1="-9.15" x2="-40.4" y2="-9.15" width="0.2032" layer="21"/>
<wire x1="-40.4" y1="-9.15" x2="-40.4" y2="9.15" width="0.2032" layer="21"/>
<wire x1="-44.5" y1="15.5" x2="46.5" y2="15.5" width="0.2032" layer="21"/>
<wire x1="46.5" y1="15.5" x2="46.5" y2="-15.5" width="0.2032" layer="21"/>
<wire x1="46.5" y1="-15.5" x2="-44.5" y2="-15.5" width="0.2032" layer="21"/>
<wire x1="-44.5" y1="-15.5" x2="-44.5" y2="15.5" width="0.2032" layer="21"/>
<pad name="1" x="-52.73" y="-7.62" drill="1" diameter="1.6764"/>
<pad name="2" x="-55.27" y="-7.62" drill="1" diameter="1.6764"/>
<pad name="3" x="-52.73" y="-5.08" drill="1" diameter="1.6764"/>
<pad name="4" x="-55.27" y="-5.08" drill="1" diameter="1.6764"/>
<pad name="5" x="-52.73" y="-2.54" drill="1" diameter="1.6764"/>
<pad name="6" x="-55.27" y="-2.54" drill="1" diameter="1.6764"/>
<pad name="7" x="-52.73" y="0" drill="1" diameter="1.6764"/>
<pad name="8" x="-55.27" y="0" drill="1" diameter="1.6764"/>
<pad name="9" x="-52.73" y="2.54" drill="1" diameter="1.6764"/>
<pad name="10" x="-55.27" y="2.54" drill="1" diameter="1.6764"/>
<pad name="11" x="-52.73" y="5.08" drill="1" diameter="1.6764"/>
<pad name="12" x="-55.27" y="5.08" drill="1" diameter="1.6764"/>
<pad name="13" x="-52.73" y="7.62" drill="1" diameter="1.6764"/>
<pad name="14" x="-55.27" y="7.62" drill="1" diameter="1.6764"/>
<pad name="15" x="-52.73" y="10.16" drill="1" diameter="1.6764"/>
<pad name="16" x="-55.27" y="10.16" drill="1" diameter="1.6764"/>
<text x="-53.34" y="-20.32" size="1.27" layer="25">&gt;NAME</text>
<text x="-43.18" y="-20.32" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-35.75" y1="0.2" x2="-32.55" y2="5.75" layer="21"/>
<rectangle x1="-35.75" y1="-5.75" x2="-32.55" y2="-0.2" layer="21"/>
<rectangle x1="-32.05" y1="0.2" x2="-28.85" y2="5.75" layer="21"/>
<rectangle x1="-32.05" y1="-5.75" x2="-28.85" y2="-0.2" layer="21"/>
<rectangle x1="-28.35" y1="0.2" x2="-25.15" y2="5.75" layer="21"/>
<rectangle x1="-28.35" y1="-5.75" x2="-25.15" y2="-0.2" layer="21"/>
<rectangle x1="-24.65" y1="0.2" x2="-21.45" y2="5.75" layer="21"/>
<rectangle x1="-24.65" y1="-5.75" x2="-21.45" y2="-0.2" layer="21"/>
<rectangle x1="-20.95" y1="0.2" x2="-17.75" y2="5.75" layer="21"/>
<rectangle x1="-20.95" y1="-5.75" x2="-17.75" y2="-0.2" layer="21"/>
<rectangle x1="-17.25" y1="0.2" x2="-14.05" y2="5.75" layer="21"/>
<rectangle x1="-17.25" y1="-5.75" x2="-14.05" y2="-0.2" layer="21"/>
<rectangle x1="-13.55" y1="0.2" x2="-10.35" y2="5.75" layer="21"/>
<rectangle x1="-13.55" y1="-5.75" x2="-10.35" y2="-0.2" layer="21"/>
<rectangle x1="-9.85" y1="0.2" x2="-6.65" y2="5.75" layer="21"/>
<rectangle x1="-9.85" y1="-5.75" x2="-6.65" y2="-0.2" layer="21"/>
<rectangle x1="-6.15" y1="0.2" x2="-2.95" y2="5.75" layer="21"/>
<rectangle x1="-6.15" y1="-5.75" x2="-2.95" y2="-0.2" layer="21"/>
<rectangle x1="-2.45" y1="0.2" x2="0.75" y2="5.75" layer="21"/>
<rectangle x1="-2.45" y1="-5.75" x2="0.75" y2="-0.2" layer="21"/>
<rectangle x1="1.25" y1="0.2" x2="4.45" y2="5.75" layer="21"/>
<rectangle x1="1.25" y1="-5.75" x2="4.45" y2="-0.2" layer="21"/>
<rectangle x1="4.95" y1="0.2" x2="8.15" y2="5.75" layer="21"/>
<rectangle x1="4.95" y1="-5.75" x2="8.15" y2="-0.2" layer="21"/>
<rectangle x1="8.65" y1="0.2" x2="11.85" y2="5.75" layer="21"/>
<rectangle x1="8.65" y1="-5.75" x2="11.85" y2="-0.2" layer="21"/>
<rectangle x1="12.35" y1="0.2" x2="15.55" y2="5.75" layer="21"/>
<rectangle x1="12.35" y1="-5.75" x2="15.55" y2="-0.2" layer="21"/>
<rectangle x1="16.05" y1="0.2" x2="19.25" y2="5.75" layer="21"/>
<rectangle x1="16.05" y1="-5.75" x2="19.25" y2="-0.2" layer="21"/>
<rectangle x1="19.75" y1="0.2" x2="22.95" y2="5.75" layer="21"/>
<rectangle x1="19.75" y1="-5.75" x2="22.95" y2="-0.2" layer="21"/>
<rectangle x1="23.45" y1="0.2" x2="26.65" y2="5.75" layer="21"/>
<rectangle x1="23.45" y1="-5.75" x2="26.65" y2="-0.2" layer="21"/>
<rectangle x1="27.15" y1="0.2" x2="30.35" y2="5.75" layer="21"/>
<rectangle x1="27.15" y1="-5.75" x2="30.35" y2="-0.2" layer="21"/>
<rectangle x1="30.85" y1="0.2" x2="34.05" y2="5.75" layer="21"/>
<rectangle x1="30.85" y1="-5.75" x2="34.05" y2="-0.2" layer="21"/>
<rectangle x1="34.55" y1="0.2" x2="37.75" y2="5.75" layer="21"/>
<rectangle x1="34.55" y1="-5.75" x2="37.75" y2="-0.2" layer="21"/>
<hole x="-54" y="-14.5" drill="3.5"/>
<hole x="54" y="-14.5" drill="3.5"/>
<hole x="-54" y="14.5" drill="3.5"/>
<hole x="54" y="14.5" drill="3.5"/>
</package>
<package name="MGLS2401280TZ">
<description>&lt;b&gt;LCD Display 240 x 128 Dots&lt;/b&gt;&lt;p&gt;
Source: VARITRONIX LIMITED .. LCD_f1187192714.pdf</description>
<wire x1="-2.9" y1="-3.4" x2="140.9" y2="-3.4" width="0.2032" layer="21"/>
<wire x1="140.9" y1="-3.4" x2="140.9" y2="100.4" width="0.2032" layer="21"/>
<wire x1="140.9" y1="100.4" x2="-2.9" y2="100.4" width="0.2032" layer="21"/>
<wire x1="-2.9" y1="100.4" x2="-2.9" y2="88" width="0.2032" layer="21"/>
<wire x1="-2.9" y1="88" x2="-2" y2="88" width="0.2032" layer="21"/>
<wire x1="-2" y1="88" x2="-2" y2="84" width="0.2032" layer="21"/>
<wire x1="-2" y1="84" x2="-2.9" y2="84" width="0.2032" layer="21"/>
<wire x1="-2.9" y1="84" x2="-2.9" y2="20" width="0.2032" layer="21"/>
<wire x1="-2.9" y1="20" x2="-2" y2="20" width="0.2032" layer="21"/>
<wire x1="-2" y1="20" x2="-2" y2="16" width="0.2032" layer="21"/>
<wire x1="-2" y1="16" x2="-2.9" y2="16" width="0.2032" layer="21"/>
<wire x1="-2.9" y1="16" x2="-2.9" y2="-3.4" width="0.2032" layer="21"/>
<wire x1="14.925" y1="80.375" x2="14.925" y2="22.625" width="0.2032" layer="21"/>
<wire x1="14.925" y1="22.625" x2="123.075" y2="22.625" width="0.2032" layer="21"/>
<wire x1="123.075" y1="22.625" x2="123.075" y2="80.375" width="0.2032" layer="21"/>
<wire x1="123.075" y1="80.375" x2="14.925" y2="80.375" width="0.2032" layer="21"/>
<wire x1="-2.725" y1="86.5" x2="-6.1" y2="86.5" width="0.2032" layer="21"/>
<wire x1="-6.1" y1="86.5" x2="-7.675" y2="83.875" width="0.2032" layer="21" curve="118.072487"/>
<wire x1="-7.675" y1="83.875" x2="-3" y2="75" width="0.2032" layer="21"/>
<wire x1="-2.725" y1="17.4" x2="-6.1" y2="17.4" width="0.2032" layer="21"/>
<wire x1="-6.1" y1="17.4" x2="-7.675" y2="20.025" width="0.2032" layer="21" curve="-118.072487"/>
<wire x1="-7.675" y1="20.025" x2="-3" y2="28.9" width="0.2032" layer="21"/>
<wire x1="15.225" y1="80.025" x2="122.725" y2="80.025" width="0.05" layer="21"/>
<wire x1="15.225" y1="79.575" x2="122.7" y2="79.575" width="0.05" layer="21"/>
<wire x1="15.225" y1="79.125" x2="122.7" y2="79.125" width="0.05" layer="21"/>
<wire x1="15.225" y1="78.675" x2="122.7" y2="78.675" width="0.05" layer="21"/>
<wire x1="15.225" y1="78.225" x2="122.7" y2="78.225" width="0.05" layer="21"/>
<wire x1="15.225" y1="77.775" x2="122.7" y2="77.775" width="0.05" layer="21"/>
<wire x1="15.225" y1="77.325" x2="122.7" y2="77.325" width="0.05" layer="21"/>
<wire x1="15.225" y1="76.875" x2="122.7" y2="76.875" width="0.05" layer="21"/>
<wire x1="15.225" y1="76.425" x2="122.7" y2="76.425" width="0.05" layer="21"/>
<wire x1="15.225" y1="75.975" x2="122.7" y2="75.975" width="0.05" layer="21"/>
<wire x1="15.225" y1="75.525" x2="122.7" y2="75.525" width="0.05" layer="21"/>
<wire x1="15.225" y1="75.075" x2="122.7" y2="75.075" width="0.05" layer="21"/>
<wire x1="15.225" y1="74.625" x2="122.7" y2="74.625" width="0.05" layer="21"/>
<wire x1="15.225" y1="74.175" x2="122.7" y2="74.175" width="0.05" layer="21"/>
<wire x1="15.225" y1="73.725" x2="122.7" y2="73.725" width="0.05" layer="21"/>
<wire x1="15.225" y1="73.275" x2="122.7" y2="73.275" width="0.05" layer="21"/>
<wire x1="15.225" y1="72.825" x2="122.7" y2="72.825" width="0.05" layer="21"/>
<wire x1="15.225" y1="72.375" x2="122.7" y2="72.375" width="0.05" layer="21"/>
<wire x1="15.225" y1="71.925" x2="122.7" y2="71.925" width="0.05" layer="21"/>
<wire x1="15.225" y1="71.475" x2="122.7" y2="71.475" width="0.05" layer="21"/>
<wire x1="15.225" y1="71.025" x2="122.7" y2="71.025" width="0.05" layer="21"/>
<wire x1="15.225" y1="70.575" x2="122.7" y2="70.575" width="0.05" layer="21"/>
<wire x1="15.225" y1="70.125" x2="122.7" y2="70.125" width="0.05" layer="21"/>
<wire x1="15.225" y1="69.675" x2="122.7" y2="69.675" width="0.05" layer="21"/>
<wire x1="15.225" y1="69.225" x2="122.7" y2="69.225" width="0.05" layer="21"/>
<wire x1="15.225" y1="68.775" x2="122.7" y2="68.775" width="0.05" layer="21"/>
<wire x1="15.225" y1="68.325" x2="122.7" y2="68.325" width="0.05" layer="21"/>
<wire x1="15.225" y1="67.875" x2="122.7" y2="67.875" width="0.05" layer="21"/>
<wire x1="15.225" y1="67.425" x2="122.7" y2="67.425" width="0.05" layer="21"/>
<wire x1="15.225" y1="66.975" x2="122.7" y2="66.975" width="0.05" layer="21"/>
<wire x1="15.225" y1="66.525" x2="122.7" y2="66.525" width="0.05" layer="21"/>
<wire x1="15.225" y1="66.075" x2="122.7" y2="66.075" width="0.05" layer="21"/>
<wire x1="15.225" y1="65.625" x2="122.7" y2="65.625" width="0.05" layer="21"/>
<wire x1="15.225" y1="65.175" x2="122.7" y2="65.175" width="0.05" layer="21"/>
<wire x1="15.225" y1="64.725" x2="122.7" y2="64.725" width="0.05" layer="21"/>
<wire x1="15.225" y1="64.275" x2="122.7" y2="64.275" width="0.05" layer="21"/>
<wire x1="15.225" y1="63.825" x2="122.7" y2="63.825" width="0.05" layer="21"/>
<wire x1="15.225" y1="63.375" x2="122.7" y2="63.375" width="0.05" layer="21"/>
<wire x1="15.225" y1="62.925" x2="122.7" y2="62.925" width="0.05" layer="21"/>
<wire x1="15.225" y1="62.475" x2="122.7" y2="62.475" width="0.05" layer="21"/>
<wire x1="15.225" y1="62.025" x2="122.7" y2="62.025" width="0.05" layer="21"/>
<wire x1="15.225" y1="61.125" x2="122.7" y2="61.125" width="0.05" layer="21"/>
<wire x1="15.225" y1="61.575" x2="122.7" y2="61.575" width="0.05" layer="21"/>
<wire x1="15.225" y1="60.675" x2="122.7" y2="60.675" width="0.05" layer="21"/>
<wire x1="15.225" y1="60.225" x2="122.7" y2="60.225" width="0.05" layer="21"/>
<wire x1="15.225" y1="59.775" x2="122.7" y2="59.775" width="0.05" layer="21"/>
<wire x1="15.225" y1="59.325" x2="122.7" y2="59.325" width="0.05" layer="21"/>
<wire x1="15.225" y1="58.875" x2="122.7" y2="58.875" width="0.05" layer="21"/>
<wire x1="15.225" y1="58.425" x2="122.7" y2="58.425" width="0.05" layer="21"/>
<wire x1="15.225" y1="57.975" x2="122.7" y2="57.975" width="0.05" layer="21"/>
<wire x1="15.225" y1="57.525" x2="122.7" y2="57.525" width="0.05" layer="21"/>
<wire x1="15.225" y1="57.075" x2="122.7" y2="57.075" width="0.05" layer="21"/>
<wire x1="15.225" y1="56.625" x2="122.7" y2="56.625" width="0.05" layer="21"/>
<wire x1="15.225" y1="56.175" x2="122.7" y2="56.175" width="0.05" layer="21"/>
<wire x1="15.225" y1="55.725" x2="122.7" y2="55.725" width="0.05" layer="21"/>
<wire x1="15.225" y1="55.275" x2="122.7" y2="55.275" width="0.05" layer="21"/>
<wire x1="15.225" y1="54.825" x2="122.7" y2="54.825" width="0.05" layer="21"/>
<wire x1="15.225" y1="54.375" x2="122.7" y2="54.375" width="0.05" layer="21"/>
<wire x1="15.225" y1="53.925" x2="122.7" y2="53.925" width="0.05" layer="21"/>
<wire x1="15.225" y1="53.475" x2="122.7" y2="53.475" width="0.05" layer="21"/>
<wire x1="15.225" y1="53.025" x2="122.7" y2="53.025" width="0.05" layer="21"/>
<wire x1="15.225" y1="52.575" x2="122.7" y2="52.575" width="0.05" layer="21"/>
<wire x1="15.225" y1="52.125" x2="122.7" y2="52.125" width="0.05" layer="21"/>
<wire x1="15.225" y1="51.675" x2="122.7" y2="51.675" width="0.05" layer="21"/>
<wire x1="15.225" y1="51.225" x2="122.7" y2="51.225" width="0.05" layer="21"/>
<wire x1="15.225" y1="50.775" x2="122.7" y2="50.775" width="0.05" layer="21"/>
<wire x1="15.225" y1="50.325" x2="122.7" y2="50.325" width="0.05" layer="21"/>
<wire x1="15.225" y1="49.875" x2="122.7" y2="49.875" width="0.05" layer="21"/>
<wire x1="15.225" y1="49.425" x2="122.7" y2="49.425" width="0.05" layer="21"/>
<wire x1="15.225" y1="48.975" x2="122.7" y2="48.975" width="0.05" layer="21"/>
<wire x1="15.225" y1="48.525" x2="122.7" y2="48.525" width="0.05" layer="21"/>
<wire x1="15.225" y1="48.075" x2="122.7" y2="48.075" width="0.05" layer="21"/>
<wire x1="15.225" y1="47.625" x2="122.7" y2="47.625" width="0.05" layer="21"/>
<wire x1="15.225" y1="47.175" x2="122.7" y2="47.175" width="0.05" layer="21"/>
<wire x1="15.225" y1="46.725" x2="122.7" y2="46.725" width="0.05" layer="21"/>
<wire x1="15.225" y1="46.275" x2="122.7" y2="46.275" width="0.05" layer="21"/>
<wire x1="15.225" y1="45.825" x2="122.7" y2="45.825" width="0.05" layer="21"/>
<wire x1="15.225" y1="45.375" x2="122.7" y2="45.375" width="0.05" layer="21"/>
<wire x1="15.225" y1="44.925" x2="122.7" y2="44.925" width="0.05" layer="21"/>
<wire x1="15.225" y1="44.475" x2="122.7" y2="44.475" width="0.05" layer="21"/>
<wire x1="15.225" y1="44.025" x2="122.7" y2="44.025" width="0.05" layer="21"/>
<wire x1="15.225" y1="43.575" x2="122.7" y2="43.575" width="0.05" layer="21"/>
<wire x1="15.225" y1="43.125" x2="122.7" y2="43.125" width="0.05" layer="21"/>
<wire x1="15.225" y1="42.675" x2="122.7" y2="42.675" width="0.05" layer="21"/>
<wire x1="15.225" y1="42.225" x2="122.7" y2="42.225" width="0.05" layer="21"/>
<wire x1="15.225" y1="41.775" x2="122.7" y2="41.775" width="0.05" layer="21"/>
<wire x1="15.225" y1="41.325" x2="122.7" y2="41.325" width="0.05" layer="21"/>
<wire x1="15.225" y1="40.875" x2="122.7" y2="40.875" width="0.05" layer="21"/>
<wire x1="15.225" y1="40.425" x2="122.7" y2="40.425" width="0.05" layer="21"/>
<wire x1="15.225" y1="39.975" x2="122.7" y2="39.975" width="0.05" layer="21"/>
<wire x1="15.225" y1="39.525" x2="122.7" y2="39.525" width="0.05" layer="21"/>
<wire x1="15.225" y1="39.075" x2="122.7" y2="39.075" width="0.05" layer="21"/>
<wire x1="15.225" y1="38.625" x2="122.7" y2="38.625" width="0.05" layer="21"/>
<wire x1="15.225" y1="38.175" x2="122.7" y2="38.175" width="0.05" layer="21"/>
<wire x1="15.225" y1="37.725" x2="122.7" y2="37.725" width="0.05" layer="21"/>
<wire x1="15.225" y1="37.275" x2="122.7" y2="37.275" width="0.05" layer="21"/>
<wire x1="15.225" y1="36.825" x2="122.7" y2="36.825" width="0.05" layer="21"/>
<wire x1="15.225" y1="36.375" x2="122.7" y2="36.375" width="0.05" layer="21"/>
<wire x1="15.225" y1="35.925" x2="122.7" y2="35.925" width="0.05" layer="21"/>
<wire x1="15.225" y1="35.475" x2="122.7" y2="35.475" width="0.05" layer="21"/>
<wire x1="15.225" y1="35.025" x2="122.7" y2="35.025" width="0.05" layer="21"/>
<wire x1="15.225" y1="34.575" x2="122.7" y2="34.575" width="0.05" layer="21"/>
<wire x1="15.225" y1="34.125" x2="122.7" y2="34.125" width="0.05" layer="21"/>
<wire x1="15.225" y1="33.675" x2="122.7" y2="33.675" width="0.05" layer="21"/>
<wire x1="15.225" y1="33.225" x2="122.7" y2="33.225" width="0.05" layer="21"/>
<wire x1="15.225" y1="32.775" x2="122.7" y2="32.775" width="0.05" layer="21"/>
<wire x1="15.225" y1="32.325" x2="122.7" y2="32.325" width="0.05" layer="21"/>
<wire x1="15.225" y1="31.875" x2="122.7" y2="31.875" width="0.05" layer="21"/>
<wire x1="15.225" y1="31.425" x2="122.7" y2="31.425" width="0.05" layer="21"/>
<wire x1="15.225" y1="30.975" x2="122.7" y2="30.975" width="0.05" layer="21"/>
<wire x1="15.225" y1="30.525" x2="122.7" y2="30.525" width="0.05" layer="21"/>
<wire x1="15.225" y1="30.075" x2="122.7" y2="30.075" width="0.05" layer="21"/>
<wire x1="15.225" y1="29.625" x2="122.7" y2="29.625" width="0.05" layer="21"/>
<wire x1="15.225" y1="29.175" x2="122.7" y2="29.175" width="0.05" layer="21"/>
<wire x1="15.225" y1="28.725" x2="122.7" y2="28.725" width="0.05" layer="21"/>
<wire x1="15.225" y1="28.275" x2="122.7" y2="28.275" width="0.05" layer="21"/>
<wire x1="15.225" y1="27.825" x2="122.7" y2="27.825" width="0.05" layer="21"/>
<wire x1="15.225" y1="27.375" x2="122.7" y2="27.375" width="0.05" layer="21"/>
<wire x1="15.225" y1="26.925" x2="122.7" y2="26.925" width="0.05" layer="21"/>
<wire x1="15.225" y1="26.475" x2="122.7" y2="26.475" width="0.05" layer="21"/>
<wire x1="15.225" y1="26.025" x2="122.7" y2="26.025" width="0.05" layer="21"/>
<wire x1="15.225" y1="25.575" x2="122.7" y2="25.575" width="0.05" layer="21"/>
<wire x1="15.225" y1="25.125" x2="122.7" y2="25.125" width="0.05" layer="21"/>
<wire x1="15.225" y1="24.675" x2="122.7" y2="24.675" width="0.05" layer="21"/>
<wire x1="15.225" y1="24.225" x2="122.7" y2="24.225" width="0.05" layer="21"/>
<wire x1="15.225" y1="23.775" x2="122.7" y2="23.775" width="0.05" layer="21"/>
<wire x1="15.225" y1="22.875" x2="15.625" y2="22.875" width="0.05" layer="21"/>
<wire x1="15.625" y1="22.875" x2="16.075" y2="22.875" width="0.05" layer="21"/>
<wire x1="16.075" y1="22.875" x2="16.525" y2="22.875" width="0.05" layer="21"/>
<wire x1="16.525" y1="22.875" x2="16.975" y2="22.875" width="0.05" layer="21"/>
<wire x1="16.975" y1="22.875" x2="17.425" y2="22.875" width="0.05" layer="21"/>
<wire x1="17.425" y1="22.875" x2="17.875" y2="22.875" width="0.05" layer="21"/>
<wire x1="17.875" y1="22.875" x2="18.325" y2="22.875" width="0.05" layer="21"/>
<wire x1="18.325" y1="22.875" x2="18.775" y2="22.875" width="0.05" layer="21"/>
<wire x1="18.775" y1="22.875" x2="19.225" y2="22.875" width="0.05" layer="21"/>
<wire x1="19.225" y1="22.875" x2="122.725" y2="22.875" width="0.05" layer="21"/>
<wire x1="15.225" y1="23.325" x2="122.7" y2="23.325" width="0.05" layer="21"/>
<wire x1="15.175" y1="22.875" x2="15.175" y2="80.025" width="0.05" layer="21"/>
<wire x1="15.625" y1="22.875" x2="15.625" y2="80.025" width="0.05" layer="21"/>
<wire x1="16.075" y1="22.875" x2="16.075" y2="80.025" width="0.05" layer="21"/>
<wire x1="16.525" y1="22.875" x2="16.525" y2="80.025" width="0.05" layer="21"/>
<wire x1="16.975" y1="22.875" x2="16.975" y2="80.025" width="0.05" layer="21"/>
<wire x1="17.425" y1="22.875" x2="17.425" y2="80.025" width="0.05" layer="21"/>
<wire x1="17.875" y1="22.875" x2="17.875" y2="80.025" width="0.05" layer="21"/>
<wire x1="18.325" y1="22.875" x2="18.325" y2="80.025" width="0.05" layer="21"/>
<wire x1="18.775" y1="22.875" x2="18.775" y2="80.025" width="0.05" layer="21"/>
<wire x1="19.225" y1="22.875" x2="19.225" y2="80.025" width="0.05" layer="21"/>
<wire x1="19.675" y1="22.875" x2="19.675" y2="80.025" width="0.05" layer="21"/>
<wire x1="20.125" y1="22.875" x2="20.125" y2="80.025" width="0.05" layer="21"/>
<wire x1="20.575" y1="22.875" x2="20.575" y2="80.025" width="0.05" layer="21"/>
<wire x1="21.025" y1="22.875" x2="21.025" y2="80.025" width="0.05" layer="21"/>
<wire x1="21.475" y1="22.875" x2="21.475" y2="80.025" width="0.05" layer="21"/>
<wire x1="21.925" y1="22.875" x2="21.925" y2="80.025" width="0.05" layer="21"/>
<wire x1="22.375" y1="22.875" x2="22.375" y2="80.025" width="0.05" layer="21"/>
<wire x1="22.825" y1="22.875" x2="22.825" y2="80.025" width="0.05" layer="21"/>
<wire x1="23.275" y1="22.875" x2="23.275" y2="80.025" width="0.05" layer="21"/>
<wire x1="23.725" y1="22.875" x2="23.725" y2="80.025" width="0.05" layer="21"/>
<wire x1="24.175" y1="22.875" x2="24.175" y2="80.025" width="0.05" layer="21"/>
<wire x1="24.625" y1="22.875" x2="24.625" y2="80.025" width="0.05" layer="21"/>
<wire x1="25.075" y1="22.875" x2="25.075" y2="80.025" width="0.05" layer="21"/>
<wire x1="25.525" y1="22.875" x2="25.525" y2="80.025" width="0.05" layer="21"/>
<wire x1="25.975" y1="22.875" x2="25.975" y2="80.025" width="0.05" layer="21"/>
<wire x1="26.425" y1="22.875" x2="26.425" y2="80.025" width="0.05" layer="21"/>
<wire x1="26.875" y1="22.875" x2="26.875" y2="80.025" width="0.05" layer="21"/>
<wire x1="27.325" y1="22.875" x2="27.325" y2="80.025" width="0.05" layer="21"/>
<wire x1="27.775" y1="22.875" x2="27.775" y2="80.025" width="0.05" layer="21"/>
<wire x1="28.225" y1="22.875" x2="28.225" y2="80.025" width="0.05" layer="21"/>
<wire x1="28.675" y1="22.875" x2="28.675" y2="80.025" width="0.05" layer="21"/>
<wire x1="29.125" y1="22.875" x2="29.125" y2="80.025" width="0.05" layer="21"/>
<wire x1="29.575" y1="22.875" x2="29.575" y2="80.025" width="0.05" layer="21"/>
<wire x1="30.025" y1="22.875" x2="30.025" y2="80.025" width="0.05" layer="21"/>
<wire x1="30.475" y1="22.875" x2="30.475" y2="80.025" width="0.05" layer="21"/>
<wire x1="30.925" y1="22.875" x2="30.925" y2="80.025" width="0.05" layer="21"/>
<wire x1="31.375" y1="22.875" x2="31.375" y2="80.025" width="0.05" layer="21"/>
<wire x1="31.825" y1="22.875" x2="31.825" y2="80.025" width="0.05" layer="21"/>
<wire x1="32.275" y1="22.875" x2="32.275" y2="80.025" width="0.05" layer="21"/>
<wire x1="32.725" y1="22.875" x2="32.725" y2="80.025" width="0.05" layer="21"/>
<wire x1="33.175" y1="22.875" x2="33.175" y2="80.025" width="0.05" layer="21"/>
<wire x1="33.625" y1="22.875" x2="33.625" y2="80.025" width="0.05" layer="21"/>
<wire x1="34.075" y1="22.875" x2="34.075" y2="80.025" width="0.05" layer="21"/>
<wire x1="34.525" y1="22.875" x2="34.525" y2="80.025" width="0.05" layer="21"/>
<wire x1="34.975" y1="22.875" x2="34.975" y2="80.025" width="0.05" layer="21"/>
<wire x1="35.425" y1="22.875" x2="35.425" y2="80.025" width="0.05" layer="21"/>
<wire x1="35.875" y1="22.875" x2="35.875" y2="80.025" width="0.05" layer="21"/>
<wire x1="36.325" y1="22.875" x2="36.325" y2="80.025" width="0.05" layer="21"/>
<wire x1="36.775" y1="22.875" x2="36.775" y2="80.025" width="0.05" layer="21"/>
<wire x1="37.225" y1="22.875" x2="37.225" y2="80.025" width="0.05" layer="21"/>
<wire x1="37.675" y1="22.875" x2="37.675" y2="80.025" width="0.05" layer="21"/>
<wire x1="38.125" y1="22.875" x2="38.125" y2="80.025" width="0.05" layer="21"/>
<wire x1="38.575" y1="22.875" x2="38.575" y2="80.025" width="0.05" layer="21"/>
<wire x1="39.025" y1="22.875" x2="39.025" y2="80.025" width="0.05" layer="21"/>
<wire x1="39.475" y1="22.875" x2="39.475" y2="80.025" width="0.05" layer="21"/>
<wire x1="39.925" y1="22.875" x2="39.925" y2="80.025" width="0.05" layer="21"/>
<wire x1="40.375" y1="22.875" x2="40.375" y2="80.025" width="0.05" layer="21"/>
<wire x1="40.825" y1="22.875" x2="40.825" y2="80.025" width="0.05" layer="21"/>
<wire x1="41.275" y1="22.875" x2="41.275" y2="80.025" width="0.05" layer="21"/>
<wire x1="41.725" y1="22.875" x2="41.725" y2="80.025" width="0.05" layer="21"/>
<wire x1="42.175" y1="22.875" x2="42.175" y2="80.025" width="0.05" layer="21"/>
<wire x1="42.625" y1="22.875" x2="42.625" y2="80.025" width="0.05" layer="21"/>
<wire x1="43.075" y1="22.875" x2="43.075" y2="80.025" width="0.05" layer="21"/>
<wire x1="43.525" y1="22.875" x2="43.525" y2="80.025" width="0.05" layer="21"/>
<wire x1="43.975" y1="22.875" x2="43.975" y2="80.025" width="0.05" layer="21"/>
<wire x1="44.425" y1="22.875" x2="44.425" y2="80.025" width="0.05" layer="21"/>
<wire x1="44.875" y1="22.875" x2="44.875" y2="80.025" width="0.05" layer="21"/>
<wire x1="45.325" y1="22.875" x2="45.325" y2="80.025" width="0.05" layer="21"/>
<wire x1="45.775" y1="22.875" x2="45.775" y2="80.025" width="0.05" layer="21"/>
<wire x1="46.225" y1="22.875" x2="46.225" y2="80.025" width="0.05" layer="21"/>
<wire x1="46.675" y1="22.875" x2="46.675" y2="80.025" width="0.05" layer="21"/>
<wire x1="47.125" y1="22.875" x2="47.125" y2="80.025" width="0.05" layer="21"/>
<wire x1="47.575" y1="22.875" x2="47.575" y2="80.025" width="0.05" layer="21"/>
<wire x1="48.025" y1="22.875" x2="48.025" y2="80.025" width="0.05" layer="21"/>
<wire x1="48.475" y1="22.875" x2="48.475" y2="80.025" width="0.05" layer="21"/>
<wire x1="48.925" y1="22.875" x2="48.925" y2="80.025" width="0.05" layer="21"/>
<wire x1="49.375" y1="22.875" x2="49.375" y2="80.025" width="0.05" layer="21"/>
<wire x1="49.825" y1="22.875" x2="49.825" y2="80.025" width="0.05" layer="21"/>
<wire x1="50.275" y1="22.875" x2="50.275" y2="80.025" width="0.05" layer="21"/>
<wire x1="50.725" y1="22.875" x2="50.725" y2="80.025" width="0.05" layer="21"/>
<wire x1="51.175" y1="22.875" x2="51.175" y2="80.025" width="0.05" layer="21"/>
<wire x1="51.625" y1="22.875" x2="51.625" y2="80.025" width="0.05" layer="21"/>
<wire x1="52.075" y1="22.875" x2="52.075" y2="80.025" width="0.05" layer="21"/>
<wire x1="52.525" y1="22.875" x2="52.525" y2="80.025" width="0.05" layer="21"/>
<wire x1="52.975" y1="22.875" x2="52.975" y2="80.025" width="0.05" layer="21"/>
<wire x1="53.425" y1="22.875" x2="53.425" y2="80.025" width="0.05" layer="21"/>
<wire x1="53.875" y1="22.875" x2="53.875" y2="80.025" width="0.05" layer="21"/>
<wire x1="54.325" y1="22.875" x2="54.325" y2="80.025" width="0.05" layer="21"/>
<wire x1="54.775" y1="22.875" x2="54.775" y2="80.025" width="0.05" layer="21"/>
<wire x1="55.225" y1="22.875" x2="55.225" y2="80.025" width="0.05" layer="21"/>
<wire x1="55.675" y1="22.875" x2="55.675" y2="80.025" width="0.05" layer="21"/>
<wire x1="56.125" y1="22.875" x2="56.125" y2="80.025" width="0.05" layer="21"/>
<wire x1="56.575" y1="22.875" x2="56.575" y2="80.025" width="0.05" layer="21"/>
<wire x1="57.025" y1="22.875" x2="57.025" y2="80.025" width="0.05" layer="21"/>
<wire x1="57.475" y1="22.875" x2="57.475" y2="80.025" width="0.05" layer="21"/>
<wire x1="57.925" y1="22.875" x2="57.925" y2="80.025" width="0.05" layer="21"/>
<wire x1="58.375" y1="22.875" x2="58.375" y2="80.025" width="0.05" layer="21"/>
<wire x1="58.825" y1="22.875" x2="58.825" y2="80.025" width="0.05" layer="21"/>
<wire x1="59.275" y1="22.875" x2="59.275" y2="80.025" width="0.05" layer="21"/>
<wire x1="59.725" y1="22.875" x2="59.725" y2="80.025" width="0.05" layer="21"/>
<wire x1="60.175" y1="22.875" x2="60.175" y2="80.025" width="0.05" layer="21"/>
<wire x1="60.625" y1="22.875" x2="60.625" y2="80.025" width="0.05" layer="21"/>
<wire x1="61.075" y1="22.875" x2="61.075" y2="80.025" width="0.05" layer="21"/>
<wire x1="61.525" y1="22.875" x2="61.525" y2="80.025" width="0.05" layer="21"/>
<wire x1="61.975" y1="22.875" x2="61.975" y2="80.025" width="0.05" layer="21"/>
<wire x1="62.425" y1="22.875" x2="62.425" y2="80.025" width="0.05" layer="21"/>
<wire x1="62.875" y1="22.875" x2="62.875" y2="80.025" width="0.05" layer="21"/>
<wire x1="63.325" y1="22.875" x2="63.325" y2="80.025" width="0.05" layer="21"/>
<wire x1="63.775" y1="22.875" x2="63.775" y2="80.025" width="0.05" layer="21"/>
<wire x1="64.225" y1="22.875" x2="64.225" y2="80.025" width="0.05" layer="21"/>
<wire x1="64.675" y1="22.875" x2="64.675" y2="80.025" width="0.05" layer="21"/>
<wire x1="65.125" y1="22.875" x2="65.125" y2="80.025" width="0.05" layer="21"/>
<wire x1="65.575" y1="22.875" x2="65.575" y2="80.025" width="0.05" layer="21"/>
<wire x1="66.025" y1="22.875" x2="66.025" y2="80.025" width="0.05" layer="21"/>
<wire x1="66.475" y1="22.875" x2="66.475" y2="80.025" width="0.05" layer="21"/>
<wire x1="66.925" y1="22.875" x2="66.925" y2="80.025" width="0.05" layer="21"/>
<wire x1="67.375" y1="22.875" x2="67.375" y2="80.025" width="0.05" layer="21"/>
<wire x1="67.825" y1="22.875" x2="67.825" y2="80.025" width="0.05" layer="21"/>
<wire x1="68.275" y1="22.875" x2="68.275" y2="80.025" width="0.05" layer="21"/>
<wire x1="68.725" y1="22.875" x2="68.725" y2="80.025" width="0.05" layer="21"/>
<wire x1="69.175" y1="22.875" x2="69.175" y2="80.025" width="0.05" layer="21"/>
<wire x1="69.625" y1="22.875" x2="69.625" y2="80.025" width="0.05" layer="21"/>
<wire x1="70.075" y1="22.875" x2="70.075" y2="80.025" width="0.05" layer="21"/>
<wire x1="70.525" y1="22.875" x2="70.525" y2="80.025" width="0.05" layer="21"/>
<wire x1="70.975" y1="22.875" x2="70.975" y2="80.025" width="0.05" layer="21"/>
<wire x1="71.425" y1="22.875" x2="71.425" y2="80.025" width="0.05" layer="21"/>
<wire x1="71.875" y1="22.875" x2="71.875" y2="80.025" width="0.05" layer="21"/>
<wire x1="72.325" y1="22.875" x2="72.325" y2="80.025" width="0.05" layer="21"/>
<wire x1="72.775" y1="22.875" x2="72.775" y2="80.025" width="0.05" layer="21"/>
<wire x1="73.225" y1="22.875" x2="73.225" y2="80.025" width="0.05" layer="21"/>
<wire x1="73.675" y1="22.875" x2="73.675" y2="80.025" width="0.05" layer="21"/>
<wire x1="74.125" y1="22.875" x2="74.125" y2="80.025" width="0.05" layer="21"/>
<wire x1="74.575" y1="22.875" x2="74.575" y2="80.025" width="0.05" layer="21"/>
<wire x1="75.025" y1="22.875" x2="75.025" y2="80.025" width="0.05" layer="21"/>
<wire x1="75.475" y1="22.875" x2="75.475" y2="80.025" width="0.05" layer="21"/>
<wire x1="75.925" y1="22.875" x2="75.925" y2="80.025" width="0.05" layer="21"/>
<wire x1="76.375" y1="22.875" x2="76.375" y2="80.025" width="0.05" layer="21"/>
<wire x1="76.825" y1="22.875" x2="76.825" y2="80.025" width="0.05" layer="21"/>
<wire x1="77.275" y1="22.875" x2="77.275" y2="80.025" width="0.05" layer="21"/>
<wire x1="77.725" y1="22.875" x2="77.725" y2="80.025" width="0.05" layer="21"/>
<wire x1="78.175" y1="22.875" x2="78.175" y2="80.025" width="0.05" layer="21"/>
<wire x1="78.625" y1="22.875" x2="78.625" y2="80.025" width="0.05" layer="21"/>
<wire x1="79.075" y1="22.875" x2="79.075" y2="80.025" width="0.05" layer="21"/>
<wire x1="79.525" y1="22.875" x2="79.525" y2="80.025" width="0.05" layer="21"/>
<wire x1="79.975" y1="22.875" x2="79.975" y2="80.025" width="0.05" layer="21"/>
<wire x1="80.425" y1="22.875" x2="80.425" y2="80.025" width="0.05" layer="21"/>
<wire x1="80.875" y1="22.875" x2="80.875" y2="80.025" width="0.05" layer="21"/>
<wire x1="81.325" y1="22.875" x2="81.325" y2="80.025" width="0.05" layer="21"/>
<wire x1="81.775" y1="22.875" x2="81.775" y2="80.025" width="0.05" layer="21"/>
<wire x1="82.225" y1="22.875" x2="82.225" y2="80.025" width="0.05" layer="21"/>
<wire x1="82.675" y1="22.875" x2="82.675" y2="80.025" width="0.05" layer="21"/>
<wire x1="83.125" y1="22.875" x2="83.125" y2="80.025" width="0.05" layer="21"/>
<wire x1="83.575" y1="22.875" x2="83.575" y2="80.025" width="0.05" layer="21"/>
<wire x1="84.025" y1="22.875" x2="84.025" y2="80.025" width="0.05" layer="21"/>
<wire x1="84.475" y1="22.875" x2="84.475" y2="80.025" width="0.05" layer="21"/>
<wire x1="84.925" y1="22.875" x2="84.925" y2="80.025" width="0.05" layer="21"/>
<wire x1="85.375" y1="22.875" x2="85.375" y2="80.025" width="0.05" layer="21"/>
<wire x1="85.825" y1="22.875" x2="85.825" y2="80.025" width="0.05" layer="21"/>
<wire x1="86.275" y1="22.875" x2="86.275" y2="80.025" width="0.05" layer="21"/>
<wire x1="86.725" y1="22.875" x2="86.725" y2="80.025" width="0.05" layer="21"/>
<wire x1="87.175" y1="22.875" x2="87.175" y2="80.025" width="0.05" layer="21"/>
<wire x1="87.625" y1="22.875" x2="87.625" y2="80.025" width="0.05" layer="21"/>
<wire x1="88.075" y1="22.875" x2="88.075" y2="80.025" width="0.05" layer="21"/>
<wire x1="88.525" y1="22.875" x2="88.525" y2="80.025" width="0.05" layer="21"/>
<wire x1="88.975" y1="22.875" x2="88.975" y2="80.025" width="0.05" layer="21"/>
<wire x1="89.425" y1="22.875" x2="89.425" y2="80.025" width="0.05" layer="21"/>
<wire x1="89.875" y1="22.875" x2="89.875" y2="80.025" width="0.05" layer="21"/>
<wire x1="90.325" y1="22.875" x2="90.325" y2="80.025" width="0.05" layer="21"/>
<wire x1="90.775" y1="22.875" x2="90.775" y2="80.025" width="0.05" layer="21"/>
<wire x1="91.225" y1="22.875" x2="91.225" y2="80.025" width="0.05" layer="21"/>
<wire x1="91.675" y1="22.875" x2="91.675" y2="80.025" width="0.05" layer="21"/>
<wire x1="92.125" y1="22.875" x2="92.125" y2="80.025" width="0.05" layer="21"/>
<wire x1="92.575" y1="22.875" x2="92.575" y2="80.025" width="0.05" layer="21"/>
<wire x1="93.025" y1="22.875" x2="93.025" y2="80.025" width="0.05" layer="21"/>
<wire x1="93.475" y1="22.875" x2="93.475" y2="80.025" width="0.05" layer="21"/>
<wire x1="93.925" y1="22.875" x2="93.925" y2="80.025" width="0.05" layer="21"/>
<wire x1="94.375" y1="22.875" x2="94.375" y2="80.025" width="0.05" layer="21"/>
<wire x1="94.825" y1="22.875" x2="94.825" y2="80.025" width="0.05" layer="21"/>
<wire x1="95.275" y1="22.875" x2="95.275" y2="80.025" width="0.05" layer="21"/>
<wire x1="95.725" y1="22.875" x2="95.725" y2="80.025" width="0.05" layer="21"/>
<wire x1="96.175" y1="22.875" x2="96.175" y2="80.025" width="0.05" layer="21"/>
<wire x1="96.625" y1="22.875" x2="96.625" y2="80.025" width="0.05" layer="21"/>
<wire x1="97.075" y1="22.875" x2="97.075" y2="80.025" width="0.05" layer="21"/>
<wire x1="97.525" y1="22.875" x2="97.525" y2="80.025" width="0.05" layer="21"/>
<wire x1="97.975" y1="22.875" x2="97.975" y2="80.025" width="0.05" layer="21"/>
<wire x1="98.425" y1="22.875" x2="98.425" y2="80.025" width="0.05" layer="21"/>
<wire x1="98.875" y1="22.875" x2="98.875" y2="80.025" width="0.05" layer="21"/>
<wire x1="99.325" y1="22.875" x2="99.325" y2="80.025" width="0.05" layer="21"/>
<wire x1="99.775" y1="22.875" x2="99.775" y2="80.025" width="0.05" layer="21"/>
<wire x1="100.225" y1="22.875" x2="100.225" y2="80.025" width="0.05" layer="21"/>
<wire x1="100.675" y1="22.875" x2="100.675" y2="80.025" width="0.05" layer="21"/>
<wire x1="101.125" y1="22.875" x2="101.125" y2="80.025" width="0.05" layer="21"/>
<wire x1="101.575" y1="22.875" x2="101.575" y2="80.025" width="0.05" layer="21"/>
<wire x1="102.025" y1="22.875" x2="102.025" y2="80.025" width="0.05" layer="21"/>
<wire x1="102.475" y1="22.875" x2="102.475" y2="80.025" width="0.05" layer="21"/>
<wire x1="102.925" y1="22.875" x2="102.925" y2="80.025" width="0.05" layer="21"/>
<wire x1="103.375" y1="22.875" x2="103.375" y2="80.025" width="0.05" layer="21"/>
<wire x1="103.825" y1="22.875" x2="103.825" y2="80.025" width="0.05" layer="21"/>
<wire x1="104.275" y1="22.875" x2="104.275" y2="80.025" width="0.05" layer="21"/>
<wire x1="104.725" y1="22.875" x2="104.725" y2="80.025" width="0.05" layer="21"/>
<wire x1="105.175" y1="22.875" x2="105.175" y2="80.025" width="0.05" layer="21"/>
<wire x1="105.625" y1="22.875" x2="105.625" y2="80.025" width="0.05" layer="21"/>
<wire x1="106.075" y1="22.875" x2="106.075" y2="80.025" width="0.05" layer="21"/>
<wire x1="106.525" y1="22.875" x2="106.525" y2="80.025" width="0.05" layer="21"/>
<wire x1="106.975" y1="22.875" x2="106.975" y2="80.025" width="0.05" layer="21"/>
<wire x1="107.425" y1="22.875" x2="107.425" y2="80.025" width="0.05" layer="21"/>
<wire x1="107.875" y1="22.875" x2="107.875" y2="80.025" width="0.05" layer="21"/>
<wire x1="108.325" y1="22.875" x2="108.325" y2="80.025" width="0.05" layer="21"/>
<wire x1="108.775" y1="22.875" x2="108.775" y2="80.025" width="0.05" layer="21"/>
<wire x1="109.225" y1="22.875" x2="109.225" y2="80.025" width="0.05" layer="21"/>
<wire x1="109.675" y1="22.875" x2="109.675" y2="80.025" width="0.05" layer="21"/>
<wire x1="110.125" y1="22.875" x2="110.125" y2="80.025" width="0.05" layer="21"/>
<wire x1="110.575" y1="22.875" x2="110.575" y2="80.025" width="0.05" layer="21"/>
<wire x1="111.025" y1="22.875" x2="111.025" y2="80.025" width="0.05" layer="21"/>
<wire x1="111.475" y1="22.875" x2="111.475" y2="80.025" width="0.05" layer="21"/>
<wire x1="111.925" y1="22.875" x2="111.925" y2="80.025" width="0.05" layer="21"/>
<wire x1="112.375" y1="22.875" x2="112.375" y2="80.025" width="0.05" layer="21"/>
<wire x1="112.825" y1="22.875" x2="112.825" y2="80.025" width="0.05" layer="21"/>
<wire x1="113.275" y1="22.875" x2="113.275" y2="80.025" width="0.05" layer="21"/>
<wire x1="113.725" y1="22.875" x2="113.725" y2="80.025" width="0.05" layer="21"/>
<wire x1="114.175" y1="22.875" x2="114.175" y2="80.025" width="0.05" layer="21"/>
<wire x1="114.625" y1="22.875" x2="114.625" y2="80.025" width="0.05" layer="21"/>
<wire x1="115.075" y1="22.875" x2="115.075" y2="80.025" width="0.05" layer="21"/>
<wire x1="115.525" y1="22.875" x2="115.525" y2="80.025" width="0.05" layer="21"/>
<wire x1="115.975" y1="22.875" x2="115.975" y2="80.025" width="0.05" layer="21"/>
<wire x1="116.425" y1="22.875" x2="116.425" y2="80.025" width="0.05" layer="21"/>
<wire x1="116.875" y1="22.875" x2="116.875" y2="80.025" width="0.05" layer="21"/>
<wire x1="117.325" y1="22.875" x2="117.325" y2="80.025" width="0.05" layer="21"/>
<wire x1="117.775" y1="22.875" x2="117.775" y2="80.025" width="0.05" layer="21"/>
<wire x1="118.225" y1="22.875" x2="118.225" y2="80.025" width="0.05" layer="21"/>
<wire x1="118.675" y1="22.875" x2="118.675" y2="80.025" width="0.05" layer="21"/>
<wire x1="119.125" y1="22.875" x2="119.125" y2="80.025" width="0.05" layer="21"/>
<wire x1="119.575" y1="22.875" x2="119.575" y2="80.025" width="0.05" layer="21"/>
<wire x1="120.025" y1="22.875" x2="120.025" y2="80.025" width="0.05" layer="21"/>
<wire x1="120.475" y1="22.875" x2="120.475" y2="80.025" width="0.05" layer="21"/>
<wire x1="120.925" y1="22.875" x2="120.925" y2="80.025" width="0.05" layer="21"/>
<wire x1="121.375" y1="22.875" x2="121.375" y2="80.025" width="0.05" layer="21"/>
<wire x1="121.825" y1="22.875" x2="121.825" y2="80.025" width="0.05" layer="21"/>
<wire x1="122.275" y1="22.875" x2="122.275" y2="80.025" width="0.05" layer="21"/>
<wire x1="122.725" y1="22.875" x2="122.725" y2="80.025" width="0.05" layer="21"/>
<circle x="-1" y="58" radius="0.5" width="0.001" layer="21"/>
<circle x="-1" y="54" radius="0.75" width="0.001" layer="21"/>
<circle x="-1" y="11.6" radius="1" width="0.001" layer="21"/>
<circle x="-1" y="92.65" radius="0.9762" width="0.001" layer="21"/>
<circle x="-1.85" y="86.5" radius="0.875" width="0" layer="21"/>
<circle x="-1.85" y="17.4" radius="0.875" width="0" layer="21"/>
<circle x="-1" y="46" radius="0.75" width="0.001" layer="21"/>
<circle x="-1" y="42" radius="0.5" width="0.001" layer="21"/>
<pad name="1" x="15.8" y="-1" drill="1" diameter="1.6764"/>
<pad name="2" x="18.34" y="-1" drill="1" diameter="1.6764"/>
<pad name="3" x="20.88" y="-1" drill="1" diameter="1.6764"/>
<pad name="4" x="23.42" y="-1" drill="1" diameter="1.6764"/>
<pad name="5" x="25.96" y="-1" drill="1" diameter="1.6764"/>
<pad name="6" x="28.5" y="-1" drill="1" diameter="1.6764"/>
<pad name="7" x="31.04" y="-1" drill="1" diameter="1.6764"/>
<pad name="8" x="33.58" y="-1" drill="1" diameter="1.6764"/>
<pad name="9" x="36.12" y="-1" drill="1" diameter="1.6764"/>
<pad name="10" x="38.66" y="-1" drill="1" diameter="1.6764"/>
<pad name="11" x="41.2" y="-1" drill="1" diameter="1.6764"/>
<pad name="12" x="43.74" y="-1" drill="1" diameter="1.6764"/>
<pad name="13" x="46.28" y="-1" drill="1" diameter="1.6764"/>
<pad name="14" x="48.82" y="-1" drill="1" diameter="1.6764"/>
<pad name="15" x="51.36" y="-1" drill="1" diameter="1.6764"/>
<pad name="16" x="53.9" y="-1" drill="1" diameter="1.6764"/>
<pad name="17" x="56.44" y="-1" drill="1" diameter="1.6764"/>
<pad name="18" x="58.98" y="-1" drill="1" diameter="1.6764"/>
<text x="4.445" y="-5.08" size="1.27" layer="25">&gt;NAME</text>
<text x="67.31" y="3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="2.4" y1="83.5" x2="135.6" y2="91.4" layer="21"/>
<rectangle x1="126" y1="19.5" x2="135.6" y2="83.5" layer="21"/>
<rectangle x1="2.4" y1="11.6" x2="135.6" y2="19.5" layer="21"/>
<rectangle x1="2.4" y1="19.5" x2="12" y2="83.5" layer="21"/>
<hole x="0" y="0" drill="3"/>
<hole x="138" y="0" drill="3"/>
<hole x="0" y="97" drill="3"/>
<hole x="138" y="97" drill="3"/>
</package>
<package name="2X16_FURAT">
<wire x1="-37.36" y1="17.9" x2="42.44" y2="17.9" width="0.2032" layer="21"/>
<wire x1="42.44" y1="17.9" x2="42.44" y2="-17.9" width="0.2032" layer="21"/>
<wire x1="42.44" y1="-17.9" x2="-37.36" y2="-17.9" width="0.2032" layer="21"/>
<wire x1="-37.36" y1="-17.9" x2="-37.36" y2="17.9" width="0.2032" layer="21"/>
<text x="-35.56" y="18.415" size="1.27" layer="25">&gt;NAME</text>
<hole x="-34.86" y="-15.5" drill="2.5"/>
<hole x="39.94" y="-15.5" drill="2.5"/>
<hole x="-34.86" y="15.5" drill="2.5"/>
<hole x="39.94" y="15.5" drill="2.5"/>
<circle x="-34.86" y="15.5" radius="1.469965625" width="0.127" layer="1"/>
<circle x="-34.84" y="15.51" radius="1.0469" width="0.8128" layer="1"/>
<wire x1="-35.89" y1="15.52" x2="-33.8" y2="15.52" width="0.254" layer="1"/>
<wire x1="-34.83" y1="14.44" x2="-34.83" y2="16.53" width="0.254" layer="1"/>
<circle x="-34.84" y="-15.52" radius="1.0469" width="0.8128" layer="1"/>
<wire x1="-34.83" y1="-16.57" x2="-34.83" y2="-14.48" width="0.254" layer="1"/>
<wire x1="-35.84" y1="-15.5" x2="-33.75" y2="-15.5" width="0.254" layer="1"/>
<circle x="39.94" y="15.5" radius="1.0469" width="0.8128" layer="1"/>
<circle x="39.95" y="-15.54" radius="1.0469" width="0.8128" layer="1"/>
<wire x1="39.94" y1="14.43" x2="39.94" y2="16.52" width="0.254" layer="1"/>
<wire x1="39.94" y1="-16.64" x2="39.94" y2="-14.55" width="0.254" layer="1"/>
<wire x1="38.93" y1="15.5" x2="41.02" y2="15.5" width="0.254" layer="1"/>
<wire x1="38.91" y1="-15.52" x2="41" y2="-15.52" width="0.254" layer="1"/>
<circle x="-29.21" y="15.24" radius="0.675425" width="0.3048" layer="21"/>
<circle x="-26.67" y="15.24" radius="0.675425" width="0.3048" layer="21"/>
<circle x="-24.13" y="15.24" radius="0.675425" width="0.3048" layer="21"/>
<circle x="-21.59" y="15.24" radius="0.675425" width="0.3048" layer="21"/>
<circle x="-19.05" y="15.24" radius="0.675425" width="0.3048" layer="21"/>
<circle x="-16.51" y="15.24" radius="0.675425" width="0.3048" layer="21"/>
<circle x="-13.97" y="15.24" radius="0.675425" width="0.3048" layer="21"/>
<circle x="-11.43" y="15.24" radius="0.675425" width="0.3048" layer="21"/>
<circle x="-8.89" y="15.24" radius="0.675425" width="0.3048" layer="21"/>
<circle x="-6.35" y="15.24" radius="0.675425" width="0.3048" layer="21"/>
<circle x="-3.81" y="15.24" radius="0.675425" width="0.3048" layer="21"/>
<circle x="-1.27" y="15.24" radius="0.675425" width="0.3048" layer="21"/>
<circle x="1.27" y="15.24" radius="0.675425" width="0.3048" layer="21"/>
<circle x="3.81" y="15.24" radius="0.675425" width="0.3048" layer="21"/>
<circle x="6.35" y="15.24" radius="0.675425" width="0.3048" layer="21"/>
<circle x="8.89" y="15.24" radius="0.675425" width="0.3048" layer="21"/>
</package>
<package name="LCDTEST">
<circle x="-37.4" y="15.5" radius="1.469965625" width="0.127" layer="1"/>
<circle x="-37.38" y="15.51" radius="1.0469" width="0.8128" layer="1"/>
<wire x1="-38.43" y1="15.52" x2="-36.34" y2="15.52" width="0.254" layer="1"/>
<wire x1="-37.37" y1="14.44" x2="-37.37" y2="16.53" width="0.254" layer="1"/>
<circle x="-37.38" y="-15.52" radius="1.0469" width="0.8128" layer="1"/>
<wire x1="-37.37" y1="-16.57" x2="-37.37" y2="-14.48" width="0.254" layer="1"/>
<wire x1="-38.38" y1="-15.5" x2="-36.29" y2="-15.5" width="0.254" layer="1"/>
<circle x="37.4" y="15.5" radius="1.0469" width="0.8128" layer="1"/>
<circle x="37.41" y="-15.54" radius="1.0469" width="0.8128" layer="1"/>
<wire x1="37.4" y1="14.43" x2="37.4" y2="16.52" width="0.254" layer="1"/>
<wire x1="37.4" y1="-16.64" x2="37.4" y2="-14.55" width="0.254" layer="1"/>
<wire x1="36.39" y1="15.5" x2="38.48" y2="15.5" width="0.254" layer="1"/>
<wire x1="36.37" y1="-15.52" x2="38.46" y2="-15.52" width="0.254" layer="1"/>
<circle x="-31.75" y="15.24" radius="0.675425" width="0.3048" layer="21"/>
<pad name="P$1" x="-31.75" y="16.81" drill="0.6" diameter="2" shape="long" rot="R90"/>
<pad name="P$2" x="-29.21" y="16.81" drill="0.6" diameter="2" shape="long" rot="R90"/>
<pad name="P$3" x="-26.67" y="16.81" drill="0.6" diameter="2" shape="long" rot="R90"/>
<pad name="P$4" x="-24.13" y="16.81" drill="0.6" diameter="2" shape="long" rot="R90"/>
<pad name="P$5" x="-21.59" y="16.81" drill="0.6" diameter="2" shape="long" rot="R90"/>
<pad name="P$6" x="-19.05" y="16.81" drill="0.6" diameter="2" shape="long" rot="R90"/>
<pad name="P$7" x="-16.51" y="16.81" drill="0.6" diameter="2" shape="long" rot="R90"/>
<pad name="P$8" x="-13.97" y="16.81" drill="0.6" diameter="2" shape="long" rot="R90"/>
<pad name="P$9" x="-11.43" y="16.81" drill="0.6" diameter="2" shape="long" rot="R90"/>
<pad name="P$10" x="-8.89" y="16.81" drill="0.6" diameter="2" shape="long" rot="R90"/>
<pad name="P$11" x="-6.35" y="16.81" drill="0.6" diameter="2" shape="long" rot="R90"/>
<pad name="P$12" x="-3.81" y="16.81" drill="0.6" diameter="2" shape="long" rot="R90"/>
<pad name="P$13" x="-1.27" y="16.81" drill="0.6" diameter="2" shape="long" rot="R90"/>
<pad name="P$14" x="1.27" y="16.81" drill="0.6" diameter="2" shape="long" rot="R90"/>
<pad name="P$15" x="3.81" y="16.81" drill="0.6" diameter="2" shape="long" rot="R90"/>
<pad name="P$16" x="6.35" y="16.81" drill="0.6" diameter="2" shape="long" rot="R90"/>
</package>
</packages>
<symbols>
<symbol name="H1333C">
<wire x1="-27.94" y1="-15.24" x2="25.4" y2="-15.24" width="0.4064" layer="94"/>
<wire x1="25.4" y1="15.24" x2="-27.94" y2="15.24" width="0.4064" layer="94"/>
<wire x1="-27.94" y1="15.24" x2="-27.94" y2="-15.24" width="0.4064" layer="94"/>
<wire x1="25.4" y1="-15.24" x2="25.4" y2="15.24" width="0.4064" layer="94"/>
<wire x1="-22.225" y1="8.89" x2="-22.86" y2="8.255" width="0.127" layer="94"/>
<wire x1="-22.86" y1="8.255" x2="-22.86" y2="-8.255" width="0.127" layer="94"/>
<wire x1="-22.86" y1="-8.255" x2="-22.225" y2="-8.89" width="0.127" layer="94"/>
<wire x1="-22.225" y1="-8.89" x2="19.685" y2="-8.89" width="0.127" layer="94"/>
<wire x1="19.685" y1="-8.89" x2="20.32" y2="-8.255" width="0.127" layer="94"/>
<wire x1="20.32" y1="-8.255" x2="20.32" y2="8.255" width="0.127" layer="94"/>
<wire x1="20.32" y1="8.255" x2="19.685" y2="8.89" width="0.127" layer="94"/>
<wire x1="19.685" y1="8.89" x2="-22.225" y2="8.89" width="0.127" layer="94"/>
<wire x1="-19.05" y1="5.715" x2="-19.05" y2="0.762" width="1.27" layer="94"/>
<wire x1="-19.05" y1="-0.762" x2="-19.05" y2="-5.715" width="1.27" layer="94"/>
<wire x1="-17.653" y1="-6.35" x2="-15.367" y2="-6.35" width="1.27" layer="94"/>
<wire x1="-13.97" y1="-5.715" x2="-13.97" y2="-0.762" width="1.27" layer="94"/>
<wire x1="-13.97" y1="0.762" x2="-13.97" y2="5.715" width="1.27" layer="94"/>
<wire x1="-17.653" y1="6.35" x2="-15.367" y2="6.35" width="1.27" layer="94"/>
<wire x1="-17.653" y1="0" x2="-15.367" y2="0" width="1.27" layer="94"/>
<wire x1="11.43" y1="5.715" x2="11.43" y2="0.762" width="1.27" layer="94"/>
<wire x1="11.43" y1="-0.762" x2="11.43" y2="-5.715" width="1.27" layer="94"/>
<wire x1="12.827" y1="-6.35" x2="15.113" y2="-6.35" width="1.27" layer="94"/>
<wire x1="16.51" y1="-5.715" x2="16.51" y2="-0.762" width="1.27" layer="94"/>
<wire x1="16.51" y1="0.762" x2="16.51" y2="5.715" width="1.27" layer="94"/>
<wire x1="12.827" y1="6.35" x2="15.113" y2="6.35" width="1.27" layer="94"/>
<wire x1="12.827" y1="0" x2="15.113" y2="0" width="1.27" layer="94"/>
<wire x1="-8.89" y1="5.715" x2="-8.89" y2="0.762" width="1.27" layer="94"/>
<wire x1="-8.89" y1="-0.762" x2="-8.89" y2="-5.715" width="1.27" layer="94"/>
<wire x1="-7.493" y1="-6.35" x2="-5.207" y2="-6.35" width="1.27" layer="94"/>
<wire x1="-3.81" y1="-5.715" x2="-3.81" y2="-0.762" width="1.27" layer="94"/>
<wire x1="-3.81" y1="0.762" x2="-3.81" y2="5.715" width="1.27" layer="94"/>
<wire x1="-7.493" y1="6.35" x2="-5.207" y2="6.35" width="1.27" layer="94"/>
<wire x1="-7.493" y1="0" x2="-5.207" y2="0" width="1.27" layer="94"/>
<wire x1="1.27" y1="5.715" x2="1.27" y2="0.762" width="1.27" layer="94"/>
<wire x1="1.27" y1="-0.762" x2="1.27" y2="-5.715" width="1.27" layer="94"/>
<wire x1="2.54" y1="-6.35" x2="4.953" y2="-6.35" width="1.27" layer="94"/>
<wire x1="6.35" y1="-5.715" x2="6.35" y2="-0.762" width="1.27" layer="94"/>
<wire x1="6.35" y1="0.762" x2="6.35" y2="5.715" width="1.27" layer="94"/>
<wire x1="2.667" y1="6.35" x2="4.953" y2="6.35" width="1.27" layer="94"/>
<wire x1="2.667" y1="0" x2="4.953" y2="0" width="1.27" layer="94"/>
<text x="-24.511" y="-1.905" size="1.778" layer="94" rot="R90">LCD</text>
<text x="-29.21" y="-15.24" size="1.778" layer="95" rot="R90">&gt;NAME</text>
<text x="-29.337" y="-2.54" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<text x="-1.905" y="3.81" size="1.27" layer="94" ratio="10">L</text>
<text x="11.938" y="7.366" size="1.27" layer="94" ratio="10">a</text>
<text x="17.78" y="2.54" size="1.27" layer="94" ratio="10">b</text>
<text x="17.78" y="-2.54" size="1.27" layer="94" ratio="10">c</text>
<text x="15.24" y="-8.509" size="1.27" layer="94" ratio="10">d</text>
<text x="9.271" y="-2.54" size="1.27" layer="94" ratio="10">e</text>
<text x="9.398" y="2.54" size="1.27" layer="94" ratio="10">f</text>
<text x="13.335" y="1.397" size="1.27" layer="94" ratio="10">g</text>
<text x="8.382" y="-5.334" size="1.27" layer="94" ratio="10">1</text>
<text x="-1.905" y="-5.334" size="1.27" layer="94" ratio="10">2</text>
<text x="-12.065" y="-5.461" size="1.27" layer="94" ratio="10">3</text>
<rectangle x1="-12.065" y1="-6.985" x2="-10.795" y2="-5.715" layer="94"/>
<rectangle x1="-1.905" y1="-6.985" x2="-0.635" y2="-5.715" layer="94"/>
<rectangle x1="-1.905" y1="-3.175" x2="-0.635" y2="-1.905" layer="94"/>
<rectangle x1="-1.905" y1="1.905" x2="-0.635" y2="3.175" layer="94"/>
<rectangle x1="8.255" y1="-6.985" x2="9.525" y2="-5.715" layer="94"/>
<pin name="COM" x="-25.4" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="4E" x="-15.24" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="4D" x="-12.7" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="4C" x="-10.16" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="3DP" x="-7.62" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="3E" x="-5.08" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="3D" x="-2.54" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="3C" x="0" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="2DP" x="2.54" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="2E" x="5.08" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="2D" x="7.62" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="2C" x="10.16" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="1DP" x="12.7" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="1E" x="15.24" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="1D" x="17.78" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="1C" x="20.32" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="1B" x="22.86" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="1A" x="22.86" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="1F" x="20.32" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="1G" x="17.78" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="2B" x="15.24" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="2A" x="12.7" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="2F" x="10.16" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="2G" x="7.62" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="L" x="5.08" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="3B" x="2.54" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="3A" x="0" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="3F" x="-2.54" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="3G" x="-5.08" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="4B" x="-10.16" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="4A" x="-12.7" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="4F" x="-15.24" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="4G" x="-17.78" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="COM1" x="-25.4" y="17.78" length="short" direction="pas" rot="R270"/>
</symbol>
<symbol name="H1331C">
<wire x1="-25.4" y1="-15.24" x2="27.94" y2="-15.24" width="0.4064" layer="94"/>
<wire x1="27.94" y1="15.24" x2="-25.4" y2="15.24" width="0.4064" layer="94"/>
<wire x1="-25.4" y1="15.24" x2="-25.4" y2="-15.24" width="0.4064" layer="94"/>
<wire x1="27.94" y1="-15.24" x2="27.94" y2="15.24" width="0.4064" layer="94"/>
<wire x1="-19.685" y1="8.89" x2="-20.32" y2="8.255" width="0.127" layer="94"/>
<wire x1="-20.32" y1="8.255" x2="-20.32" y2="-8.255" width="0.127" layer="94"/>
<wire x1="-20.32" y1="-8.255" x2="-19.685" y2="-8.89" width="0.127" layer="94"/>
<wire x1="-19.685" y1="-8.89" x2="22.225" y2="-8.89" width="0.127" layer="94"/>
<wire x1="22.225" y1="-8.89" x2="22.86" y2="-8.255" width="0.127" layer="94"/>
<wire x1="22.86" y1="-8.255" x2="22.86" y2="8.255" width="0.127" layer="94"/>
<wire x1="22.86" y1="8.255" x2="22.225" y2="8.89" width="0.127" layer="94"/>
<wire x1="22.225" y1="8.89" x2="-19.685" y2="8.89" width="0.127" layer="94"/>
<wire x1="-11.43" y1="-5.715" x2="-11.43" y2="-0.762" width="1.27" layer="94"/>
<wire x1="-11.43" y1="0.762" x2="-11.43" y2="5.715" width="1.27" layer="94"/>
<wire x1="13.97" y1="5.715" x2="13.97" y2="0.762" width="1.27" layer="94"/>
<wire x1="13.97" y1="-0.762" x2="13.97" y2="-5.715" width="1.27" layer="94"/>
<wire x1="15.367" y1="-6.35" x2="17.653" y2="-6.35" width="1.27" layer="94"/>
<wire x1="19.05" y1="-5.715" x2="19.05" y2="-0.762" width="1.27" layer="94"/>
<wire x1="19.05" y1="0.762" x2="19.05" y2="5.715" width="1.27" layer="94"/>
<wire x1="15.367" y1="6.35" x2="17.653" y2="6.35" width="1.27" layer="94"/>
<wire x1="15.367" y1="0" x2="17.653" y2="0" width="1.27" layer="94"/>
<wire x1="-6.35" y1="5.715" x2="-6.35" y2="0.762" width="1.27" layer="94"/>
<wire x1="-6.35" y1="-0.762" x2="-6.35" y2="-5.715" width="1.27" layer="94"/>
<wire x1="-4.953" y1="-6.35" x2="-2.667" y2="-6.35" width="1.27" layer="94"/>
<wire x1="-1.27" y1="-5.715" x2="-1.27" y2="-0.762" width="1.27" layer="94"/>
<wire x1="-1.27" y1="0.762" x2="-1.27" y2="5.715" width="1.27" layer="94"/>
<wire x1="-4.953" y1="6.35" x2="-2.667" y2="6.35" width="1.27" layer="94"/>
<wire x1="-4.953" y1="0" x2="-2.667" y2="0" width="1.27" layer="94"/>
<wire x1="3.81" y1="5.715" x2="3.81" y2="0.762" width="1.27" layer="94"/>
<wire x1="3.81" y1="-0.762" x2="3.81" y2="-5.715" width="1.27" layer="94"/>
<wire x1="5.207" y1="-6.35" x2="7.493" y2="-6.35" width="1.27" layer="94"/>
<wire x1="8.89" y1="-5.715" x2="8.89" y2="-0.762" width="1.27" layer="94"/>
<wire x1="8.89" y1="0.762" x2="8.89" y2="5.715" width="1.27" layer="94"/>
<wire x1="5.207" y1="6.35" x2="7.493" y2="6.35" width="1.27" layer="94"/>
<wire x1="5.207" y1="0" x2="7.493" y2="0" width="1.27" layer="94"/>
<wire x1="-17.907" y1="5.08" x2="-16.637" y2="6.35" width="0.3048" layer="94"/>
<wire x1="-16.637" y1="6.35" x2="-16.637" y2="3.81" width="0.3048" layer="94"/>
<wire x1="-16.637" y1="3.81" x2="-17.907" y2="5.08" width="0.3048" layer="94"/>
<text x="-21.971" y="-1.905" size="1.778" layer="94" ratio="10" rot="R90">LCD</text>
<text x="-26.67" y="-15.24" size="1.778" layer="95" ratio="10" rot="R90">&gt;NAME</text>
<text x="-26.67" y="-2.54" size="1.778" layer="96" ratio="10" rot="R90">&gt;VALUE</text>
<text x="0.635" y="3.81" size="1.27" layer="94" ratio="10">L</text>
<text x="18.034" y="7.112" size="1.27" layer="94" ratio="10">a</text>
<text x="20.193" y="1.778" size="1.27" layer="94" ratio="10">b</text>
<text x="20.193" y="-3.81" size="1.27" layer="94" ratio="10">c</text>
<text x="13.97" y="-8.509" size="1.27" layer="94" ratio="10">d</text>
<text x="11.684" y="-3.302" size="1.27" layer="94" ratio="10">e</text>
<text x="11.938" y="2.667" size="1.27" layer="94" ratio="10">f</text>
<text x="16.002" y="1.397" size="1.27" layer="94" ratio="10">g</text>
<text x="-17.78" y="-2.54" size="1.27" layer="94" ratio="10">:</text>
<text x="-19.685" y="-0.635" size="1.27" layer="94" ratio="10">-</text>
<text x="10.922" y="-5.334" size="1.27" layer="94" ratio="10">1</text>
<text x="0.762" y="-5.334" size="1.27" layer="94" ratio="10">2</text>
<text x="-9.398" y="-5.334" size="1.27" layer="94" ratio="10">3</text>
<rectangle x1="-18.415" y1="-0.635" x2="-13.335" y2="0.635" layer="94"/>
<rectangle x1="-16.51" y1="1.27" x2="-15.24" y2="2.54" layer="94"/>
<rectangle x1="-16.51" y1="-2.54" x2="-15.24" y2="-1.27" layer="94"/>
<rectangle x1="-9.525" y1="-6.985" x2="-8.255" y2="-5.715" layer="94"/>
<rectangle x1="0.635" y1="-6.985" x2="1.905" y2="-5.715" layer="94"/>
<rectangle x1="0.635" y1="-3.175" x2="1.905" y2="-1.905" layer="94"/>
<rectangle x1="0.635" y1="1.905" x2="1.905" y2="3.175" layer="94"/>
<rectangle x1="10.795" y1="-6.985" x2="12.065" y2="-5.715" layer="94"/>
<rectangle x1="-17.78" y1="4.953" x2="-17.272" y2="5.207" layer="94"/>
<rectangle x1="-17.653" y1="5.207" x2="-17.272" y2="5.334" layer="94"/>
<rectangle x1="-17.526" y1="5.334" x2="-17.272" y2="5.461" layer="94"/>
<rectangle x1="-17.399" y1="5.461" x2="-17.272" y2="5.588" layer="94"/>
<rectangle x1="-17.653" y1="4.826" x2="-17.272" y2="4.953" layer="94"/>
<rectangle x1="-17.526" y1="4.699" x2="-17.272" y2="4.826" layer="94"/>
<rectangle x1="-17.399" y1="4.572" x2="-17.272" y2="4.699" layer="94"/>
<rectangle x1="-17.145" y1="5.715" x2="-16.637" y2="5.969" layer="94"/>
<rectangle x1="-16.891" y1="5.969" x2="-16.637" y2="6.096" layer="94"/>
<rectangle x1="-17.145" y1="4.191" x2="-16.637" y2="4.445" layer="94"/>
<rectangle x1="-16.891" y1="4.064" x2="-16.637" y2="4.191" layer="94"/>
<rectangle x1="-17.272" y1="4.445" x2="-13.462" y2="5.715" layer="94"/>
<pin name="COM" x="-22.86" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="-" x="-20.32" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="BC" x="-17.78" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="3DP" x="-5.08" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="3E" x="-2.54" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="3D" x="0" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="3C" x="2.54" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="2DP" x="5.08" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="2E" x="7.62" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="2D" x="10.16" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="2C" x="12.7" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="1DP" x="15.24" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="1E" x="17.78" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="1D" x="20.32" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="1C" x="22.86" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="1B" x="25.4" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="1A" x="25.4" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="1F" x="22.86" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="1G" x="20.32" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="2B" x="17.78" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="2A" x="15.24" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="2F" x="12.7" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="2G" x="10.16" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="L" x="7.62" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="3B" x="5.08" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="3A" x="2.54" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="3F" x="0" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="3G" x="-2.54" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="&lt;-" x="-17.78" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name=":" x="-20.32" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="COM1" x="-22.86" y="17.78" length="short" direction="pas" rot="R270"/>
</symbol>
<symbol name="H1335C">
<wire x1="-35.56" y1="15.24" x2="-35.56" y2="-15.24" width="0.4064" layer="94"/>
<wire x1="-31.115" y1="8.89" x2="-31.75" y2="8.255" width="0.127" layer="94"/>
<wire x1="-31.75" y1="8.255" x2="-31.75" y2="-8.255" width="0.127" layer="94"/>
<wire x1="-31.75" y1="-8.255" x2="-31.115" y2="-8.89" width="0.127" layer="94"/>
<wire x1="-27.94" y1="5.715" x2="-27.94" y2="0.762" width="1.27" layer="94"/>
<wire x1="-27.94" y1="-0.762" x2="-27.94" y2="-5.715" width="1.27" layer="94"/>
<wire x1="-26.543" y1="-6.35" x2="-24.257" y2="-6.35" width="1.27" layer="94"/>
<wire x1="-22.86" y1="-5.715" x2="-22.86" y2="-0.762" width="1.27" layer="94"/>
<wire x1="-22.86" y1="0.762" x2="-22.86" y2="5.715" width="1.27" layer="94"/>
<wire x1="-26.543" y1="6.35" x2="-24.257" y2="6.35" width="1.27" layer="94"/>
<wire x1="-26.543" y1="0" x2="-24.257" y2="0" width="1.27" layer="94"/>
<wire x1="2.54" y1="5.715" x2="2.54" y2="0.762" width="1.27" layer="94"/>
<wire x1="2.54" y1="-0.762" x2="2.54" y2="-5.715" width="1.27" layer="94"/>
<wire x1="3.937" y1="-6.35" x2="6.223" y2="-6.35" width="1.27" layer="94"/>
<wire x1="7.62" y1="-5.715" x2="7.62" y2="-0.762" width="1.27" layer="94"/>
<wire x1="7.62" y1="0.762" x2="7.62" y2="5.715" width="1.27" layer="94"/>
<wire x1="3.937" y1="6.35" x2="6.223" y2="6.35" width="1.27" layer="94"/>
<wire x1="3.937" y1="0" x2="6.223" y2="0" width="1.27" layer="94"/>
<wire x1="-17.78" y1="5.715" x2="-17.78" y2="0.762" width="1.27" layer="94"/>
<wire x1="-17.78" y1="-0.762" x2="-17.78" y2="-5.715" width="1.27" layer="94"/>
<wire x1="-16.383" y1="-6.35" x2="-14.097" y2="-6.35" width="1.27" layer="94"/>
<wire x1="-12.7" y1="-5.715" x2="-12.7" y2="-0.762" width="1.27" layer="94"/>
<wire x1="-12.7" y1="0.762" x2="-12.7" y2="5.715" width="1.27" layer="94"/>
<wire x1="-16.383" y1="6.35" x2="-14.097" y2="6.35" width="1.27" layer="94"/>
<wire x1="-16.383" y1="0" x2="-14.097" y2="0" width="1.27" layer="94"/>
<wire x1="-7.62" y1="5.715" x2="-7.62" y2="0.762" width="1.27" layer="94"/>
<wire x1="-7.62" y1="-0.762" x2="-7.62" y2="-5.715" width="1.27" layer="94"/>
<wire x1="-6.223" y1="-6.35" x2="-3.937" y2="-6.35" width="1.27" layer="94"/>
<wire x1="-2.54" y1="-5.715" x2="-2.54" y2="-0.762" width="1.27" layer="94"/>
<wire x1="-2.54" y1="0.762" x2="-2.54" y2="5.715" width="1.27" layer="94"/>
<wire x1="-6.223" y1="6.35" x2="-3.937" y2="6.35" width="1.27" layer="94"/>
<wire x1="-6.223" y1="0" x2="-3.937" y2="0" width="1.27" layer="94"/>
<wire x1="-35.56" y1="-15.24" x2="35.56" y2="-15.24" width="0.4064" layer="94"/>
<wire x1="35.56" y1="15.24" x2="-35.56" y2="15.24" width="0.4064" layer="94"/>
<wire x1="35.56" y1="-15.24" x2="35.56" y2="15.24" width="0.4064" layer="94"/>
<wire x1="-31.115" y1="-8.89" x2="31.115" y2="-8.89" width="0.127" layer="94"/>
<wire x1="31.115" y1="-8.89" x2="31.75" y2="-8.255" width="0.127" layer="94"/>
<wire x1="31.75" y1="-8.255" x2="31.75" y2="8.255" width="0.127" layer="94"/>
<wire x1="31.75" y1="8.255" x2="31.115" y2="8.89" width="0.127" layer="94"/>
<wire x1="31.115" y1="8.89" x2="-31.115" y2="8.89" width="0.127" layer="94"/>
<wire x1="22.86" y1="5.715" x2="22.86" y2="0.762" width="1.27" layer="94"/>
<wire x1="22.86" y1="-0.762" x2="22.86" y2="-5.715" width="1.27" layer="94"/>
<wire x1="24.257" y1="-6.35" x2="26.543" y2="-6.35" width="1.27" layer="94"/>
<wire x1="27.94" y1="-5.715" x2="27.94" y2="-0.762" width="1.27" layer="94"/>
<wire x1="27.94" y1="0.762" x2="27.94" y2="5.715" width="1.27" layer="94"/>
<wire x1="24.257" y1="6.35" x2="26.543" y2="6.35" width="1.27" layer="94"/>
<wire x1="24.257" y1="0" x2="26.416" y2="0" width="1.27" layer="94"/>
<wire x1="12.7" y1="5.715" x2="12.7" y2="0.762" width="1.27" layer="94"/>
<wire x1="12.7" y1="-0.762" x2="12.7" y2="-5.715" width="1.27" layer="94"/>
<wire x1="14.097" y1="-6.35" x2="16.383" y2="-6.35" width="1.27" layer="94"/>
<wire x1="17.78" y1="-5.715" x2="17.78" y2="-0.762" width="1.27" layer="94"/>
<wire x1="17.78" y1="0.762" x2="17.78" y2="5.715" width="1.27" layer="94"/>
<wire x1="14.097" y1="6.35" x2="16.383" y2="6.35" width="1.27" layer="94"/>
<wire x1="14.097" y1="0" x2="16.383" y2="0" width="1.27" layer="94"/>
<text x="-32.766" y="-2.54" size="1.778" layer="94" rot="R90">LCD</text>
<text x="-36.83" y="-15.24" size="1.778" layer="95" rot="R90">&gt;NAME</text>
<text x="-36.957" y="-2.54" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<text x="23.368" y="7.366" size="1.27" layer="94" ratio="10">a</text>
<text x="29.21" y="2.54" size="1.27" layer="94" ratio="10">b</text>
<text x="29.21" y="-2.54" size="1.27" layer="94" ratio="10">c</text>
<text x="26.67" y="-8.509" size="1.27" layer="94" ratio="10">d</text>
<text x="20.701" y="-2.54" size="1.27" layer="94" ratio="10">e</text>
<text x="20.828" y="2.54" size="1.27" layer="94" ratio="10">f</text>
<text x="24.765" y="1.397" size="1.27" layer="94" ratio="10">g</text>
<text x="9.525" y="3.81" size="1.27" layer="94" ratio="10">L1</text>
<text x="-10.795" y="3.81" size="1.27" layer="94" ratio="10">L2</text>
<text x="19.812" y="-5.334" size="1.27" layer="94" ratio="10">1</text>
<text x="9.525" y="-5.334" size="1.27" layer="94" ratio="10">2</text>
<text x="-0.508" y="-5.334" size="1.27" layer="94" ratio="10">3</text>
<text x="-10.795" y="-5.334" size="1.27" layer="94" ratio="10">4</text>
<text x="-20.955" y="-5.461" size="1.27" layer="94" ratio="10">5</text>
<rectangle x1="-20.955" y1="-6.985" x2="-19.685" y2="-5.715" layer="94"/>
<rectangle x1="-10.795" y1="-6.985" x2="-9.525" y2="-5.715" layer="94"/>
<rectangle x1="-10.795" y1="-3.175" x2="-9.525" y2="-1.905" layer="94"/>
<rectangle x1="-10.795" y1="1.905" x2="-9.525" y2="3.175" layer="94"/>
<rectangle x1="-0.635" y1="-6.985" x2="0.635" y2="-5.715" layer="94"/>
<rectangle x1="9.525" y1="-6.985" x2="10.795" y2="-5.715" layer="94"/>
<rectangle x1="9.525" y1="-3.175" x2="10.795" y2="-1.905" layer="94"/>
<rectangle x1="9.525" y1="1.905" x2="10.795" y2="3.175" layer="94"/>
<rectangle x1="19.685" y1="-6.985" x2="20.955" y2="-5.715" layer="94"/>
<pin name="COM" x="-30.48" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="5DP" x="-20.32" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="5E" x="-17.78" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="5D" x="-15.24" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="5C" x="-12.7" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="4DP" x="-10.16" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="4E" x="-7.62" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="4D" x="-5.08" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="4C" x="-2.54" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="3DP" x="0" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="3E" x="2.54" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="3D" x="5.08" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="3C" x="7.62" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="2DP" x="10.16" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="2E" x="12.7" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="L1" x="12.7" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="3B" x="10.16" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="3A" x="7.62" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="3F" x="5.08" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="3G" x="2.54" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="4B" x="0" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="4A" x="-2.54" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="4F" x="-5.08" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="4G" x="-7.62" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="L2" x="-10.16" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="5A" x="-15.24" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="5F" x="-17.78" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="5G" x="-20.32" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="6B" x="-22.86" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="6G" x="-30.48" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="2D" x="15.24" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="2C" x="17.78" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="1DP" x="20.32" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="1E" x="22.86" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="1D" x="25.4" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="1C" x="27.94" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="1B" x="30.48" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="1A" x="30.48" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="1F" x="27.94" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="1G" x="25.4" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="2B" x="22.86" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="2A" x="20.32" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="2F" x="17.78" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="2G" x="15.24" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="6F" x="-27.94" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="6A" x="-25.4" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="5B" x="-12.7" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="6C" x="-22.86" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="6D" x="-25.4" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="6E" x="-27.94" y="-17.78" length="short" direction="pas" rot="R90"/>
</symbol>
<symbol name="LS021">
<text x="-21.971" y="-2.54" size="1.778" layer="94" ratio="10" rot="R90">LCD</text>
</symbol>
<symbol name="LS022">
<text x="-24.511" y="-2.54" size="1.778" layer="94" rot="R90">LCD</text>
</symbol>
<symbol name="LS023">
<wire x1="-27.94" y1="-15.24" x2="30.48" y2="-15.24" width="0.4064" layer="94"/>
<wire x1="30.48" y1="15.24" x2="-27.94" y2="15.24" width="0.4064" layer="94"/>
<wire x1="30.48" y1="-15.24" x2="30.48" y2="15.24" width="0.4064" layer="94"/>
<wire x1="-24.765" y1="8.89" x2="-25.4" y2="8.255" width="0.127" layer="94"/>
<wire x1="-25.4" y1="8.255" x2="-25.4" y2="-8.255" width="0.127" layer="94"/>
<wire x1="-25.4" y1="-8.255" x2="-24.765" y2="-8.89" width="0.127" layer="94"/>
<wire x1="-24.765" y1="-8.89" x2="27.305" y2="-8.89" width="0.127" layer="94"/>
<wire x1="27.305" y1="-8.89" x2="27.94" y2="-8.255" width="0.127" layer="94"/>
<wire x1="27.94" y1="-8.255" x2="27.94" y2="8.255" width="0.127" layer="94"/>
<wire x1="27.94" y1="8.255" x2="27.305" y2="8.89" width="0.127" layer="94"/>
<wire x1="27.305" y1="8.89" x2="-24.765" y2="8.89" width="0.127" layer="94"/>
<wire x1="-16.51" y1="-5.715" x2="-16.51" y2="-0.762" width="1.27" layer="94"/>
<wire x1="-16.51" y1="0.762" x2="-16.51" y2="5.715" width="1.27" layer="94"/>
<wire x1="19.05" y1="5.715" x2="19.05" y2="0.762" width="1.27" layer="94"/>
<wire x1="19.05" y1="-0.762" x2="19.05" y2="-5.715" width="1.27" layer="94"/>
<wire x1="20.447" y1="-6.35" x2="22.733" y2="-6.35" width="1.27" layer="94"/>
<wire x1="24.13" y1="-5.715" x2="24.13" y2="-0.762" width="1.27" layer="94"/>
<wire x1="24.13" y1="0.762" x2="24.13" y2="5.715" width="1.27" layer="94"/>
<wire x1="20.447" y1="6.35" x2="22.733" y2="6.35" width="1.27" layer="94"/>
<wire x1="20.447" y1="0" x2="22.733" y2="0" width="1.27" layer="94"/>
<wire x1="-11.43" y1="5.715" x2="-11.43" y2="0.762" width="1.27" layer="94"/>
<wire x1="-11.43" y1="-0.762" x2="-11.43" y2="-5.715" width="1.27" layer="94"/>
<wire x1="-10.033" y1="-6.35" x2="-7.747" y2="-6.35" width="1.27" layer="94"/>
<wire x1="-6.35" y1="-5.715" x2="-6.35" y2="-0.762" width="1.27" layer="94"/>
<wire x1="-6.35" y1="0.762" x2="-6.35" y2="5.715" width="1.27" layer="94"/>
<wire x1="-10.033" y1="6.35" x2="-7.747" y2="6.35" width="1.27" layer="94"/>
<wire x1="-10.033" y1="0" x2="-7.747" y2="0" width="1.27" layer="94"/>
<wire x1="8.89" y1="5.715" x2="8.89" y2="0.762" width="1.27" layer="94"/>
<wire x1="8.89" y1="-0.762" x2="8.89" y2="-5.715" width="1.27" layer="94"/>
<wire x1="10.287" y1="-6.35" x2="12.573" y2="-6.35" width="1.27" layer="94"/>
<wire x1="13.97" y1="-5.715" x2="13.97" y2="-0.762" width="1.27" layer="94"/>
<wire x1="13.97" y1="0.762" x2="13.97" y2="5.715" width="1.27" layer="94"/>
<wire x1="10.287" y1="6.35" x2="12.573" y2="6.35" width="1.27" layer="94"/>
<wire x1="10.287" y1="0" x2="12.573" y2="0" width="1.27" layer="94"/>
<wire x1="-22.987" y1="5.08" x2="-21.717" y2="6.35" width="0.3048" layer="94"/>
<wire x1="-21.717" y1="6.35" x2="-21.717" y2="3.81" width="0.3048" layer="94"/>
<wire x1="-21.717" y1="3.81" x2="-22.987" y2="5.08" width="0.3048" layer="94"/>
<wire x1="-1.27" y1="5.715" x2="-1.27" y2="0.762" width="1.27" layer="94"/>
<wire x1="-1.27" y1="-0.762" x2="-1.27" y2="-5.715" width="1.27" layer="94"/>
<wire x1="0.127" y1="-6.35" x2="2.413" y2="-6.35" width="1.27" layer="94"/>
<wire x1="3.81" y1="-5.715" x2="3.81" y2="-0.762" width="1.27" layer="94"/>
<wire x1="3.81" y1="0.762" x2="3.81" y2="5.715" width="1.27" layer="94"/>
<wire x1="0.127" y1="6.35" x2="2.413" y2="6.35" width="1.27" layer="94"/>
<wire x1="0.127" y1="0" x2="2.413" y2="0" width="1.27" layer="94"/>
<text x="-26.416" y="12.065" size="1.778" layer="94" ratio="10">LCD</text>
<text x="-29.21" y="-15.24" size="1.778" layer="95" ratio="10" rot="R90">&gt;NAME</text>
<text x="-29.21" y="-2.54" size="1.778" layer="96" ratio="10" rot="R90">&gt;VALUE</text>
<text x="5.715" y="3.81" size="1.27" layer="94" ratio="10">L</text>
<text x="23.114" y="7.112" size="1.27" layer="94" ratio="10">a</text>
<text x="25.273" y="1.778" size="1.27" layer="94" ratio="10">b</text>
<text x="25.273" y="-3.81" size="1.27" layer="94" ratio="10">c</text>
<text x="19.05" y="-8.509" size="1.27" layer="94" ratio="10">d</text>
<text x="16.764" y="-3.302" size="1.27" layer="94" ratio="10">e</text>
<text x="17.018" y="2.667" size="1.27" layer="94" ratio="10">f</text>
<text x="21.082" y="1.397" size="1.27" layer="94" ratio="10">g</text>
<text x="-22.86" y="-2.54" size="1.27" layer="94" ratio="10">:</text>
<text x="-24.765" y="-0.635" size="1.27" layer="94" ratio="10">-</text>
<text x="-4.445" y="3.81" size="1.27" layer="94" ratio="10">L</text>
<text x="16.002" y="-5.334" size="1.27" layer="94" ratio="10">1</text>
<text x="5.842" y="-5.334" size="1.27" layer="94" ratio="10">2</text>
<text x="-4.318" y="-5.334" size="1.27" layer="94" ratio="10">3</text>
<text x="-14.478" y="-5.334" size="1.27" layer="94" ratio="10">4</text>
<rectangle x1="-23.495" y1="-0.635" x2="-18.415" y2="0.635" layer="94"/>
<rectangle x1="-21.59" y1="1.27" x2="-20.32" y2="2.54" layer="94"/>
<rectangle x1="-21.59" y1="-2.54" x2="-20.32" y2="-1.27" layer="94"/>
<rectangle x1="-14.605" y1="-6.985" x2="-13.335" y2="-5.715" layer="94"/>
<rectangle x1="5.715" y1="-6.985" x2="6.985" y2="-5.715" layer="94"/>
<rectangle x1="5.715" y1="-3.175" x2="6.985" y2="-1.905" layer="94"/>
<rectangle x1="5.715" y1="1.905" x2="6.985" y2="3.175" layer="94"/>
<rectangle x1="15.875" y1="-6.985" x2="17.145" y2="-5.715" layer="94"/>
<rectangle x1="-22.86" y1="4.953" x2="-22.352" y2="5.207" layer="94"/>
<rectangle x1="-22.733" y1="5.207" x2="-22.352" y2="5.334" layer="94"/>
<rectangle x1="-22.606" y1="5.334" x2="-22.352" y2="5.461" layer="94"/>
<rectangle x1="-22.479" y1="5.461" x2="-22.352" y2="5.588" layer="94"/>
<rectangle x1="-22.733" y1="4.826" x2="-22.352" y2="4.953" layer="94"/>
<rectangle x1="-22.606" y1="4.699" x2="-22.352" y2="4.826" layer="94"/>
<rectangle x1="-22.479" y1="4.572" x2="-22.352" y2="4.699" layer="94"/>
<rectangle x1="-22.225" y1="5.715" x2="-21.717" y2="5.969" layer="94"/>
<rectangle x1="-21.971" y1="5.969" x2="-21.717" y2="6.096" layer="94"/>
<rectangle x1="-22.225" y1="4.191" x2="-21.717" y2="4.445" layer="94"/>
<rectangle x1="-21.971" y1="4.064" x2="-21.717" y2="4.191" layer="94"/>
<rectangle x1="-22.352" y1="4.445" x2="-18.542" y2="5.715" layer="94"/>
<rectangle x1="-4.445" y1="-6.985" x2="-3.175" y2="-5.715" layer="94"/>
<rectangle x1="-4.445" y1="-3.175" x2="-3.175" y2="-1.905" layer="94"/>
<rectangle x1="-4.445" y1="1.905" x2="-3.175" y2="3.175" layer="94"/>
<pin name="L1" x="7.62" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="4DP" x="-15.24" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="4E" x="-12.7" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="4D" x="-10.16" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="4C" x="-7.62" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="L2" x="-5.08" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="4B" x="-7.62" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="4A" x="-10.16" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="4F" x="-12.7" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="4G" x="-15.24" y="17.78" length="short" direction="pas" rot="R270"/>
</symbol>
<symbol name="LS024">
<wire x1="-21.59" y1="5.715" x2="-21.59" y2="0.762" width="1.27" layer="94"/>
<wire x1="-21.59" y1="-0.762" x2="-21.59" y2="-5.715" width="1.27" layer="94"/>
<wire x1="-20.193" y1="-6.35" x2="-17.907" y2="-6.35" width="1.27" layer="94"/>
<wire x1="-20.193" y1="6.35" x2="-17.907" y2="6.35" width="1.27" layer="94"/>
<wire x1="-20.193" y1="0" x2="-17.907" y2="0" width="1.27" layer="94"/>
<text x="-25.146" y="-13.97" size="1.778" layer="94" ratio="10" rot="R90">LCD</text>
<text x="-14.605" y="3.81" size="1.27" layer="94" ratio="10">L</text>
<rectangle x1="-14.605" y1="1.905" x2="-13.335" y2="3.175" layer="94"/>
<rectangle x1="-14.605" y1="-3.175" x2="-13.335" y2="-1.905" layer="94"/>
<pin name="5G" x="-20.32" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="L2" x="-15.24" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="3B" x="7.62" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="3A" x="5.08" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="3F" x="2.54" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="3G" x="0" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="5B" x="-17.78" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="5A" x="-20.32" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="4E" x="-10.16" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="4D" x="-7.62" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="4C" x="-5.08" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="L1" x="-2.54" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="4B" x="-5.08" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="4A" x="-7.62" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="4F" x="-10.16" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="4G" x="-12.7" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="5F" x="-22.86" y="17.78" length="short" direction="pas" rot="R270"/>
</symbol>
<symbol name="LS026">
<wire x1="-43.18" y1="-15.24" x2="45.72" y2="-15.24" width="0.4064" layer="94"/>
<wire x1="45.72" y1="15.24" x2="-43.18" y2="15.24" width="0.4064" layer="94"/>
<wire x1="-43.18" y1="15.24" x2="-43.18" y2="-15.24" width="0.4064" layer="94"/>
<wire x1="45.72" y1="-15.24" x2="45.72" y2="15.24" width="0.4064" layer="94"/>
<wire x1="-38.735" y1="8.89" x2="-39.37" y2="8.255" width="0.127" layer="94"/>
<wire x1="-39.37" y1="8.255" x2="-39.37" y2="-8.255" width="0.127" layer="94"/>
<wire x1="-39.37" y1="-8.255" x2="-38.735" y2="-8.89" width="0.127" layer="94"/>
<wire x1="-38.735" y1="-8.89" x2="41.91" y2="-8.89" width="0.127" layer="94"/>
<wire x1="41.91" y1="-8.89" x2="42.545" y2="-8.255" width="0.127" layer="94"/>
<wire x1="42.545" y1="-8.255" x2="42.545" y2="8.255" width="0.127" layer="94"/>
<wire x1="42.545" y1="8.255" x2="41.91" y2="8.89" width="0.127" layer="94"/>
<wire x1="41.91" y1="8.89" x2="-38.735" y2="8.89" width="0.127" layer="94"/>
<wire x1="-31.75" y1="-5.715" x2="-31.75" y2="-0.762" width="1.27" layer="94"/>
<wire x1="-31.75" y1="0.762" x2="-31.75" y2="5.715" width="1.27" layer="94"/>
<wire x1="34.29" y1="5.715" x2="34.29" y2="0.762" width="1.27" layer="94"/>
<wire x1="34.29" y1="-0.762" x2="34.29" y2="-5.715" width="1.27" layer="94"/>
<wire x1="35.687" y1="-6.35" x2="37.973" y2="-6.35" width="1.27" layer="94"/>
<wire x1="39.37" y1="-5.715" x2="39.37" y2="-0.762" width="1.27" layer="94"/>
<wire x1="39.37" y1="0.762" x2="39.37" y2="5.715" width="1.27" layer="94"/>
<wire x1="35.687" y1="6.35" x2="37.973" y2="6.35" width="1.27" layer="94"/>
<wire x1="35.687" y1="0" x2="37.973" y2="0" width="1.27" layer="94"/>
<wire x1="-26.67" y1="5.715" x2="-26.67" y2="0.762" width="1.27" layer="94"/>
<wire x1="-26.67" y1="-0.762" x2="-26.67" y2="-5.715" width="1.27" layer="94"/>
<wire x1="-25.273" y1="-6.35" x2="-22.987" y2="-6.35" width="1.27" layer="94"/>
<wire x1="-21.59" y1="-5.715" x2="-21.59" y2="-0.762" width="1.27" layer="94"/>
<wire x1="-21.59" y1="0.762" x2="-21.59" y2="5.715" width="1.27" layer="94"/>
<wire x1="-25.273" y1="6.35" x2="-22.987" y2="6.35" width="1.27" layer="94"/>
<wire x1="-25.273" y1="0" x2="-22.987" y2="0" width="1.27" layer="94"/>
<wire x1="24.13" y1="5.715" x2="24.13" y2="0.762" width="1.27" layer="94"/>
<wire x1="24.13" y1="-0.762" x2="24.13" y2="-5.715" width="1.27" layer="94"/>
<wire x1="25.527" y1="-6.35" x2="27.813" y2="-6.35" width="1.27" layer="94"/>
<wire x1="29.21" y1="-5.715" x2="29.21" y2="-0.762" width="1.27" layer="94"/>
<wire x1="29.21" y1="0.762" x2="29.21" y2="5.715" width="1.27" layer="94"/>
<wire x1="25.527" y1="6.35" x2="27.813" y2="6.35" width="1.27" layer="94"/>
<wire x1="25.527" y1="0" x2="27.813" y2="0" width="1.27" layer="94"/>
<wire x1="-16.51" y1="5.715" x2="-16.51" y2="0.762" width="1.27" layer="94"/>
<wire x1="-16.51" y1="-0.762" x2="-16.51" y2="-5.715" width="1.27" layer="94"/>
<wire x1="-15.113" y1="-6.35" x2="-12.827" y2="-6.35" width="1.27" layer="94"/>
<wire x1="-15.113" y1="6.35" x2="-12.827" y2="6.35" width="1.27" layer="94"/>
<wire x1="-15.113" y1="0" x2="-12.827" y2="0" width="1.27" layer="94"/>
<wire x1="-36.83" y1="5.715" x2="-36.83" y2="0.762" width="1.27" layer="94"/>
<wire x1="-36.83" y1="-0.762" x2="-36.83" y2="-5.715" width="1.27" layer="94"/>
<wire x1="-35.433" y1="-6.35" x2="-33.147" y2="-6.35" width="1.27" layer="94"/>
<wire x1="-35.433" y1="6.35" x2="-33.147" y2="6.35" width="1.27" layer="94"/>
<wire x1="-35.433" y1="0" x2="-33.147" y2="0" width="1.27" layer="94"/>
<text x="-40.64" y="-2.54" size="1.778" layer="94" ratio="10" rot="R90">LCD</text>
<text x="-44.45" y="-15.24" size="1.778" layer="95" ratio="10" rot="R90">&gt;NAME</text>
<text x="-44.45" y="-2.54" size="1.778" layer="96" ratio="10" rot="R90">&gt;VALUE</text>
<text x="38.354" y="7.112" size="1.27" layer="94" ratio="10">a</text>
<text x="40.513" y="1.778" size="1.27" layer="94" ratio="10">b</text>
<text x="40.513" y="-3.81" size="1.27" layer="94" ratio="10">c</text>
<text x="34.29" y="-8.509" size="1.27" layer="94" ratio="10">d</text>
<text x="32.004" y="-3.302" size="1.27" layer="94" ratio="10">e</text>
<text x="32.258" y="2.667" size="1.27" layer="94" ratio="10">f</text>
<text x="36.322" y="1.397" size="1.27" layer="94" ratio="10">g</text>
<text x="-19.685" y="3.81" size="1.27" layer="94" ratio="10">L</text>
<text x="20.955" y="3.81" size="1.27" layer="94" ratio="10">L</text>
<text x="10.922" y="-5.334" size="1.27" layer="94" ratio="10">3</text>
<text x="31.242" y="-5.334" size="1.27" layer="94" ratio="10">1</text>
<text x="21.082" y="-5.334" size="1.27" layer="94" ratio="10">2</text>
<text x="0.762" y="-5.334" size="1.27" layer="94" ratio="10">4</text>
<text x="-9.398" y="-5.334" size="1.27" layer="94" ratio="10">5</text>
<text x="-19.558" y="-5.334" size="1.27" layer="94" ratio="10">6</text>
<text x="-29.718" y="-5.334" size="1.27" layer="94" ratio="10">7</text>
<rectangle x1="31.115" y1="-6.985" x2="32.385" y2="-5.715" layer="94"/>
<rectangle x1="-19.685" y1="-3.175" x2="-18.415" y2="-1.905" layer="94"/>
<rectangle x1="-19.685" y1="1.905" x2="-18.415" y2="3.175" layer="94"/>
<rectangle x1="20.955" y1="-3.175" x2="22.225" y2="-1.905" layer="94"/>
<rectangle x1="20.955" y1="1.905" x2="22.225" y2="3.175" layer="94"/>
<rectangle x1="-29.845" y1="-6.985" x2="-28.575" y2="-5.715" layer="94"/>
<rectangle x1="-19.685" y1="-6.985" x2="-18.415" y2="-5.715" layer="94"/>
<rectangle x1="20.955" y1="-6.985" x2="22.225" y2="-5.715" layer="94"/>
<pin name="COM/BP" x="-40.64" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="1DP" x="33.02" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="5E" x="-5.08" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="5C" x="0" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="3E" x="15.24" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="3D" x="17.78" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="3C" x="20.32" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="3DP" x="12.7" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="2E" x="25.4" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="2D" x="27.94" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="2C" x="30.48" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="2DP" x="22.86" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="1E" x="35.56" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="1D" x="38.1" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="1C" x="40.64" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="1B" x="43.18" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="1A" x="43.18" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="1F" x="40.64" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="1G" x="38.1" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="2B" x="35.56" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="2A" x="33.02" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="2F" x="30.48" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="2G" x="27.94" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="L2" x="2.54" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="3B" x="22.86" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="3A" x="20.32" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="3F" x="17.78" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="3G" x="15.24" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="5B" x="0" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="5A" x="-2.54" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="5D" x="-2.54" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="4E" x="5.08" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="4D" x="7.62" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="4C" x="10.16" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="L1" x="25.4" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="4B" x="12.7" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="4A" x="10.16" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="4F" x="7.62" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="4G" x="5.08" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="5F" x="-5.08" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="8E" x="-38.1" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="8D" x="-35.56" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="8C" x="-33.02" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="7DP" x="-30.48" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="7E" x="-27.94" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="7D" x="-25.4" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="7C" x="-22.86" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="6DP" x="-20.32" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="BP" x="-17.78" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="6E" x="-15.24" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="6D" x="-12.7" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="6C" x="-10.16" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="5DP" x="-7.62" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="4DP" x="2.54" y="-17.78" length="short" direction="pas" rot="R90"/>
<pin name="5G" x="-7.62" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="6B" x="-10.16" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="6A" x="-12.7" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="6F" x="-15.24" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="6G" x="-17.78" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="L3" x="-20.32" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="7B" x="-22.86" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="7A" x="-25.4" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="7F" x="-27.94" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="7G" x="-30.48" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="8B" x="-33.02" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="8A" x="-35.56" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="8F" x="-38.1" y="17.78" length="short" direction="pas" rot="R270"/>
<pin name="8G" x="-40.64" y="17.78" length="short" direction="pas" rot="R270"/>
</symbol>
<symbol name="H1332C">
<pin name="BP" x="-22.86" y="17.78" length="short" direction="pas" rot="R270"/>
</symbol>
<symbol name="LCD-DIP128-64">
<wire x1="-25.4" y1="15.24" x2="25.4" y2="15.24" width="0.254" layer="94"/>
<wire x1="25.4" y1="15.24" x2="25.4" y2="-17.78" width="0.254" layer="94"/>
<wire x1="25.4" y1="-17.78" x2="-25.4" y2="-17.78" width="0.254" layer="94"/>
<wire x1="-25.4" y1="-17.78" x2="-25.4" y2="15.24" width="0.254" layer="94"/>
<wire x1="-15.24" y1="10.16" x2="17.78" y2="10.16" width="0" layer="94"/>
<wire x1="17.78" y1="10.16" x2="17.78" y2="9.8028" width="0" layer="94"/>
<wire x1="17.78" y1="9.8028" x2="17.78" y2="9.4456" width="0" layer="94"/>
<wire x1="17.78" y1="9.4456" x2="17.78" y2="9.0884" width="0" layer="94"/>
<wire x1="17.78" y1="9.0884" x2="17.78" y2="8.7312" width="0" layer="94"/>
<wire x1="17.78" y1="8.7312" x2="17.78" y2="8.374" width="0" layer="94"/>
<wire x1="17.78" y1="8.374" x2="17.78" y2="8.0168" width="0" layer="94"/>
<wire x1="17.78" y1="8.0168" x2="17.78" y2="7.6596" width="0" layer="94"/>
<wire x1="17.78" y1="7.6596" x2="17.78" y2="7.3025" width="0" layer="94"/>
<wire x1="17.78" y1="-12.7" x2="-15.24" y2="-12.7" width="0" layer="94"/>
<wire x1="-15.24" y1="9.8028" x2="17.78" y2="9.8028" width="0" layer="94"/>
<wire x1="-15.24" y1="9.4456" x2="17.78" y2="9.4456" width="0" layer="94"/>
<wire x1="-15.24" y1="9.0884" x2="17.78" y2="9.0884" width="0" layer="94"/>
<wire x1="-15.24" y1="8.7312" x2="17.78" y2="8.7312" width="0" layer="94"/>
<wire x1="-15.24" y1="8.374" x2="17.78" y2="8.374" width="0" layer="94"/>
<wire x1="-15.24" y1="8.0168" x2="17.78" y2="8.0168" width="0" layer="94"/>
<wire x1="-15.24" y1="7.6596" x2="17.78" y2="7.6596" width="0" layer="94"/>
<wire x1="-15.24" y1="7.3025" x2="17.78" y2="7.3025" width="0" layer="94"/>
<wire x1="-15.24" y1="6.9453" x2="17.78" y2="6.9453" width="0" layer="94"/>
<wire x1="-15.24" y1="6.5881" x2="17.78" y2="6.5881" width="0" layer="94"/>
<wire x1="-15.24" y1="6.2309" x2="17.78" y2="6.2309" width="0" layer="94"/>
<wire x1="-15.24" y1="5.8737" x2="17.78" y2="5.8737" width="0" layer="94"/>
<wire x1="-15.24" y1="5.5165" x2="17.78" y2="5.5165" width="0" layer="94"/>
<wire x1="-15.24" y1="5.1593" x2="17.78" y2="5.1593" width="0" layer="94"/>
<wire x1="-15.24" y1="4.8021" x2="17.78" y2="4.8021" width="0" layer="94"/>
<wire x1="-15.24" y1="4.4449" x2="17.78" y2="4.4449" width="0" layer="94"/>
<wire x1="-15.24" y1="4.0877" x2="17.78" y2="4.0877" width="0" layer="94"/>
<wire x1="-15.24" y1="3.7306" x2="17.78" y2="3.7306" width="0" layer="94"/>
<wire x1="-15.24" y1="3.3734" x2="17.78" y2="3.3734" width="0" layer="94"/>
<wire x1="-15.24" y1="3.0162" x2="17.78" y2="3.0162" width="0" layer="94"/>
<wire x1="-15.24" y1="2.659" x2="17.78" y2="2.659" width="0" layer="94"/>
<wire x1="-15.24" y1="2.3018" x2="17.78" y2="2.3018" width="0" layer="94"/>
<wire x1="-15.24" y1="1.9446" x2="17.78" y2="1.9446" width="0" layer="94"/>
<wire x1="-15.24" y1="1.5874" x2="17.78" y2="1.5874" width="0" layer="94"/>
<wire x1="-15.24" y1="1.2302" x2="17.78" y2="1.2302" width="0" layer="94"/>
<wire x1="-15.24" y1="0.873" x2="17.78" y2="0.873" width="0" layer="94"/>
<wire x1="-15.24" y1="0.5158" x2="17.78" y2="0.5158" width="0" layer="94"/>
<wire x1="-15.24" y1="0.1587" x2="17.78" y2="0.1587" width="0" layer="94"/>
<wire x1="-15.24" y1="-0.1985" x2="17.78" y2="-0.1985" width="0" layer="94"/>
<wire x1="-15.24" y1="-0.5557" x2="17.78" y2="-0.5557" width="0" layer="94"/>
<wire x1="-15.24" y1="-0.9128" x2="17.78" y2="-0.9128" width="0" layer="94"/>
<wire x1="-15.24" y1="-1.27" x2="17.78" y2="-1.27" width="0" layer="94"/>
<wire x1="-15.24" y1="-1.6272" x2="17.78" y2="-1.6272" width="0" layer="94"/>
<wire x1="-15.24" y1="-1.9844" x2="17.78" y2="-1.9844" width="0" layer="94"/>
<wire x1="-15.24" y1="-2.3416" x2="17.78" y2="-2.3416" width="0" layer="94"/>
<wire x1="-15.24" y1="-2.6988" x2="17.78" y2="-2.6988" width="0" layer="94"/>
<wire x1="-15.24" y1="-3.056" x2="17.78" y2="-3.056" width="0" layer="94"/>
<wire x1="-15.24" y1="-3.4131" x2="17.78" y2="-3.4131" width="0" layer="94"/>
<wire x1="-15.24" y1="-3.7703" x2="17.78" y2="-3.7703" width="0" layer="94"/>
<wire x1="-15.24" y1="-4.1275" x2="17.78" y2="-4.1275" width="0" layer="94"/>
<wire x1="-15.24" y1="-4.4847" x2="17.78" y2="-4.4847" width="0" layer="94"/>
<wire x1="-15.24" y1="-4.8419" x2="17.78" y2="-4.8419" width="0" layer="94"/>
<wire x1="-15.24" y1="-5.1991" x2="17.78" y2="-5.1991" width="0" layer="94"/>
<wire x1="-15.24" y1="-5.5563" x2="17.78" y2="-5.5563" width="0" layer="94"/>
<wire x1="-15.24" y1="-5.9135" x2="17.78" y2="-5.9135" width="0" layer="94"/>
<wire x1="-15.24" y1="-6.2707" x2="17.78" y2="-6.2707" width="0" layer="94"/>
<wire x1="-15.24" y1="-6.6279" x2="17.78" y2="-6.6279" width="0" layer="94"/>
<wire x1="-15.24" y1="-6.985" x2="17.78" y2="-6.985" width="0" layer="94"/>
<wire x1="-15.24" y1="-7.3422" x2="17.78" y2="-7.3422" width="0" layer="94"/>
<wire x1="-15.24" y1="-7.6994" x2="17.78" y2="-7.6994" width="0" layer="94"/>
<wire x1="-15.24" y1="-8.0566" x2="17.78" y2="-8.0566" width="0" layer="94"/>
<wire x1="-15.24" y1="-8.4138" x2="17.78" y2="-8.4138" width="0" layer="94"/>
<wire x1="-15.24" y1="-8.771" x2="17.78" y2="-8.771" width="0" layer="94"/>
<wire x1="-15.24" y1="-9.1282" x2="17.78" y2="-9.1282" width="0" layer="94"/>
<wire x1="-15.24" y1="-9.4854" x2="17.78" y2="-9.4854" width="0" layer="94"/>
<wire x1="-15.24" y1="-9.8426" x2="17.78" y2="-9.8426" width="0" layer="94"/>
<wire x1="-15.24" y1="-10.1998" x2="17.78" y2="-10.1998" width="0" layer="94"/>
<wire x1="-15.24" y1="-10.5569" x2="17.78" y2="-10.5569" width="0" layer="94"/>
<wire x1="-15.24" y1="-10.9141" x2="17.78" y2="-10.9141" width="0" layer="94"/>
<wire x1="-15.24" y1="-11.2713" x2="17.78" y2="-11.2713" width="0" layer="94"/>
<wire x1="-15.24" y1="-11.6285" x2="17.78" y2="-11.6285" width="0" layer="94"/>
<wire x1="-15.24" y1="-11.9857" x2="17.78" y2="-11.9857" width="0" layer="94"/>
<wire x1="-15.24" y1="-12.3429" x2="17.78" y2="-12.3429" width="0" layer="94"/>
<wire x1="-15.24" y1="-12.7001" x2="-15.24" y2="-12.7" width="0" layer="94"/>
<wire x1="17.78" y1="7.3025" x2="17.78" y2="-12.7" width="0" layer="94"/>
<wire x1="-15.24" y1="10.16" x2="-15.24" y2="-12.7" width="0" layer="94"/>
<wire x1="-14.982" y1="10.16" x2="-14.982" y2="-12.7" width="0" layer="94"/>
<wire x1="-14.724" y1="10.16" x2="-14.724" y2="-12.7" width="0" layer="94"/>
<wire x1="-14.4661" y1="10.16" x2="-14.4661" y2="-12.7" width="0" layer="94"/>
<wire x1="-14.2081" y1="10.16" x2="-14.2081" y2="-12.7" width="0" layer="94"/>
<wire x1="-13.9501" y1="10.16" x2="-13.9501" y2="-12.7" width="0" layer="94"/>
<wire x1="-13.6921" y1="10.16" x2="-13.6921" y2="-12.7" width="0" layer="94"/>
<wire x1="-13.4341" y1="10.16" x2="-13.4341" y2="-12.7" width="0" layer="94"/>
<wire x1="-13.1762" y1="10.16" x2="-13.1762" y2="-12.7" width="0" layer="94"/>
<wire x1="-12.9182" y1="10.16" x2="-12.9182" y2="-12.7" width="0" layer="94"/>
<wire x1="-12.6603" y1="10.16" x2="-12.6603" y2="-12.7" width="0" layer="94"/>
<wire x1="-12.4023" y1="10.16" x2="-12.4023" y2="-12.7" width="0" layer="94"/>
<wire x1="-12.1443" y1="10.16" x2="-12.1443" y2="-12.7" width="0" layer="94"/>
<wire x1="-11.8864" y1="10.16" x2="-11.8864" y2="-12.7" width="0" layer="94"/>
<wire x1="-11.6284" y1="10.16" x2="-11.6284" y2="-12.7" width="0" layer="94"/>
<wire x1="-11.3704" y1="10.16" x2="-11.3704" y2="-12.7" width="0" layer="94"/>
<wire x1="-11.1124" y1="10.16" x2="-11.1124" y2="-12.7" width="0" layer="94"/>
<wire x1="-10.8544" y1="10.16" x2="-10.8544" y2="-12.7" width="0" layer="94"/>
<wire x1="-10.5965" y1="10.16" x2="-10.5965" y2="-12.7" width="0" layer="94"/>
<wire x1="-10.3385" y1="10.16" x2="-10.3385" y2="-12.7" width="0" layer="94"/>
<wire x1="-10.0806" y1="10.16" x2="-10.0806" y2="-12.7" width="0" layer="94"/>
<wire x1="-9.8226" y1="10.16" x2="-9.8226" y2="-12.7" width="0" layer="94"/>
<wire x1="-9.5646" y1="10.16" x2="-9.5646" y2="-12.7" width="0" layer="94"/>
<wire x1="-9.3067" y1="10.16" x2="-9.3067" y2="-12.7" width="0" layer="94"/>
<wire x1="-9.0487" y1="10.16" x2="-9.0487" y2="-12.7" width="0" layer="94"/>
<wire x1="-8.7907" y1="10.16" x2="-8.7907" y2="-12.7" width="0" layer="94"/>
<wire x1="-8.5327" y1="10.16" x2="-8.5327" y2="-12.7" width="0" layer="94"/>
<wire x1="-8.2747" y1="10.16" x2="-8.2747" y2="-12.7" width="0" layer="94"/>
<wire x1="-8.0168" y1="10.16" x2="-8.0168" y2="-12.7" width="0" layer="94"/>
<wire x1="-7.7588" y1="10.16" x2="-7.7588" y2="-12.7" width="0" layer="94"/>
<wire x1="-7.5009" y1="10.16" x2="-7.5009" y2="-12.7" width="0" layer="94"/>
<wire x1="-7.2429" y1="10.16" x2="-7.2429" y2="-12.7" width="0" layer="94"/>
<wire x1="-6.9849" y1="10.16" x2="-6.9849" y2="-12.7" width="0" layer="94"/>
<wire x1="-6.727" y1="10.16" x2="-6.727" y2="-12.7" width="0" layer="94"/>
<wire x1="-6.469" y1="10.16" x2="-6.469" y2="-12.7" width="0" layer="94"/>
<wire x1="-6.211" y1="10.16" x2="-6.211" y2="-12.7" width="0" layer="94"/>
<wire x1="-5.953" y1="10.16" x2="-5.953" y2="-12.7" width="0" layer="94"/>
<wire x1="-5.695" y1="10.16" x2="-5.695" y2="-12.7" width="0" layer="94"/>
<wire x1="-5.4371" y1="10.16" x2="-5.4371" y2="-12.7" width="0" layer="94"/>
<wire x1="-5.1791" y1="10.16" x2="-5.1791" y2="-12.7" width="0" layer="94"/>
<wire x1="-4.9212" y1="10.16" x2="-4.9212" y2="-12.7" width="0" layer="94"/>
<wire x1="-4.6632" y1="10.16" x2="-4.6632" y2="-12.7" width="0" layer="94"/>
<wire x1="-4.4052" y1="10.16" x2="-4.4052" y2="-12.7" width="0" layer="94"/>
<wire x1="-4.1473" y1="10.16" x2="-4.1473" y2="-12.7" width="0" layer="94"/>
<wire x1="-3.8893" y1="10.16" x2="-3.8893" y2="-12.7" width="0" layer="94"/>
<wire x1="-3.6313" y1="10.16" x2="-3.6313" y2="-12.7" width="0" layer="94"/>
<wire x1="-3.3733" y1="10.16" x2="-3.3733" y2="-12.7" width="0" layer="94"/>
<wire x1="-3.1153" y1="10.16" x2="-3.1153" y2="-12.7" width="0" layer="94"/>
<wire x1="-2.8574" y1="10.16" x2="-2.8574" y2="-12.7" width="0" layer="94"/>
<wire x1="-2.5994" y1="10.16" x2="-2.5994" y2="-12.7" width="0" layer="94"/>
<wire x1="-2.3415" y1="10.16" x2="-2.3415" y2="-12.7" width="0" layer="94"/>
<wire x1="-2.0835" y1="10.16" x2="-2.0835" y2="-12.7" width="0" layer="94"/>
<wire x1="-1.8255" y1="10.16" x2="-1.8255" y2="-12.7" width="0" layer="94"/>
<wire x1="-1.5676" y1="10.16" x2="-1.5676" y2="-12.7" width="0" layer="94"/>
<wire x1="-1.3096" y1="10.16" x2="-1.3096" y2="-12.7" width="0" layer="94"/>
<wire x1="-1.0516" y1="10.16" x2="-1.0516" y2="-12.7" width="0" layer="94"/>
<wire x1="-0.7936" y1="10.16" x2="-0.7936" y2="-12.7" width="0" layer="94"/>
<wire x1="-0.5356" y1="10.16" x2="-0.5356" y2="-12.7" width="0" layer="94"/>
<wire x1="-0.2777" y1="10.16" x2="-0.2777" y2="-12.7" width="0" layer="94"/>
<wire x1="-0.0197" y1="10.16" x2="-0.0197" y2="-12.7" width="0" layer="94"/>
<wire x1="0.2382" y1="10.16" x2="0.2382" y2="-12.7" width="0" layer="94"/>
<wire x1="0.4962" y1="10.16" x2="0.4962" y2="-12.7" width="0" layer="94"/>
<wire x1="0.7542" y1="10.16" x2="0.7542" y2="-12.7" width="0" layer="94"/>
<wire x1="1.0121" y1="10.16" x2="1.0121" y2="-12.7" width="0" layer="94"/>
<wire x1="1.2701" y1="10.16" x2="1.2701" y2="-12.7" width="0" layer="94"/>
<wire x1="1.5281" y1="10.16" x2="1.5281" y2="-12.7" width="0" layer="94"/>
<wire x1="1.7861" y1="10.16" x2="1.7861" y2="-12.7" width="0" layer="94"/>
<wire x1="2.0441" y1="10.16" x2="2.0441" y2="-12.7" width="0" layer="94"/>
<wire x1="2.302" y1="10.16" x2="2.302" y2="-12.7" width="0" layer="94"/>
<wire x1="2.56" y1="10.16" x2="2.56" y2="-12.7" width="0" layer="94"/>
<wire x1="2.8179" y1="10.16" x2="2.8179" y2="-12.7" width="0" layer="94"/>
<wire x1="3.0759" y1="10.16" x2="3.0759" y2="-12.7" width="0" layer="94"/>
<wire x1="3.3339" y1="10.16" x2="3.3339" y2="-12.7" width="0" layer="94"/>
<wire x1="3.5918" y1="10.16" x2="3.5918" y2="-12.7" width="0" layer="94"/>
<wire x1="3.8498" y1="10.16" x2="3.8498" y2="-12.7" width="0" layer="94"/>
<wire x1="4.1078" y1="10.16" x2="4.1078" y2="-12.7" width="0" layer="94"/>
<wire x1="4.3658" y1="10.16" x2="4.3658" y2="-12.7" width="0" layer="94"/>
<wire x1="4.6238" y1="10.16" x2="4.6238" y2="-12.7" width="0" layer="94"/>
<wire x1="4.8817" y1="10.16" x2="4.8817" y2="-12.7" width="0" layer="94"/>
<wire x1="5.1397" y1="10.16" x2="5.1397" y2="-12.7" width="0" layer="94"/>
<wire x1="5.3977" y1="10.16" x2="5.3977" y2="-12.7" width="0" layer="94"/>
<wire x1="5.6557" y1="10.16" x2="5.6557" y2="-12.7" width="0" layer="94"/>
<wire x1="5.9137" y1="10.16" x2="5.9137" y2="-12.7" width="0" layer="94"/>
<wire x1="6.1716" y1="10.16" x2="6.1716" y2="-12.7" width="0" layer="94"/>
<wire x1="6.4296" y1="10.16" x2="6.4296" y2="-12.7" width="0" layer="94"/>
<wire x1="6.6876" y1="10.16" x2="6.6876" y2="-12.7" width="0" layer="94"/>
<wire x1="6.9456" y1="10.16" x2="6.9456" y2="-12.7" width="0" layer="94"/>
<wire x1="7.2036" y1="10.16" x2="7.2036" y2="-12.7" width="0" layer="94"/>
<wire x1="7.4615" y1="10.16" x2="7.4615" y2="-12.7" width="0" layer="94"/>
<wire x1="7.7195" y1="10.16" x2="7.7195" y2="-12.7" width="0" layer="94"/>
<wire x1="7.9774" y1="10.16" x2="7.9774" y2="-12.7" width="0" layer="94"/>
<wire x1="8.2354" y1="10.16" x2="8.2354" y2="-12.7" width="0" layer="94"/>
<wire x1="8.4934" y1="10.16" x2="8.4934" y2="-12.7" width="0" layer="94"/>
<wire x1="8.7513" y1="10.16" x2="8.7513" y2="-12.7" width="0" layer="94"/>
<wire x1="9.0093" y1="10.16" x2="9.0093" y2="-12.7" width="0" layer="94"/>
<wire x1="9.2673" y1="10.16" x2="9.2673" y2="-12.7" width="0" layer="94"/>
<wire x1="9.5253" y1="10.16" x2="9.5253" y2="-12.7" width="0" layer="94"/>
<wire x1="9.7833" y1="10.16" x2="9.7833" y2="-12.7" width="0" layer="94"/>
<wire x1="10.0412" y1="10.16" x2="10.0412" y2="-12.7" width="0" layer="94"/>
<wire x1="10.2992" y1="10.16" x2="10.2992" y2="-12.7" width="0" layer="94"/>
<wire x1="10.5571" y1="10.16" x2="10.5571" y2="-12.7" width="0" layer="94"/>
<wire x1="10.8151" y1="10.16" x2="10.8151" y2="-12.7" width="0" layer="94"/>
<wire x1="11.0731" y1="10.16" x2="11.0731" y2="-12.7" width="0" layer="94"/>
<wire x1="11.331" y1="10.16" x2="11.331" y2="-12.7" width="0" layer="94"/>
<wire x1="11.589" y1="10.16" x2="11.589" y2="-12.7" width="0" layer="94"/>
<wire x1="11.847" y1="10.16" x2="11.847" y2="-12.7" width="0" layer="94"/>
<wire x1="12.105" y1="10.16" x2="12.105" y2="-12.7" width="0" layer="94"/>
<wire x1="12.363" y1="10.16" x2="12.363" y2="-12.7" width="0" layer="94"/>
<wire x1="12.6209" y1="10.16" x2="12.6209" y2="-12.7" width="0" layer="94"/>
<wire x1="12.8789" y1="10.16" x2="12.8789" y2="-12.7" width="0" layer="94"/>
<wire x1="13.1368" y1="10.16" x2="13.1368" y2="-12.7" width="0" layer="94"/>
<wire x1="13.3948" y1="10.16" x2="13.3948" y2="-12.7" width="0" layer="94"/>
<wire x1="13.6528" y1="10.16" x2="13.6528" y2="-12.7" width="0" layer="94"/>
<wire x1="13.9107" y1="10.16" x2="13.9107" y2="-12.7" width="0" layer="94"/>
<wire x1="14.1687" y1="10.16" x2="14.1687" y2="-12.7" width="0" layer="94"/>
<wire x1="14.4267" y1="10.16" x2="14.4267" y2="-12.7" width="0" layer="94"/>
<wire x1="14.6847" y1="10.16" x2="14.6847" y2="-12.7" width="0" layer="94"/>
<wire x1="14.9427" y1="10.16" x2="14.9427" y2="-12.7" width="0" layer="94"/>
<wire x1="15.2006" y1="10.16" x2="15.2006" y2="-12.7" width="0" layer="94"/>
<wire x1="15.4586" y1="10.16" x2="15.4586" y2="-12.7" width="0" layer="94"/>
<wire x1="15.7165" y1="10.16" x2="15.7165" y2="-12.7" width="0" layer="94"/>
<wire x1="15.9745" y1="10.16" x2="15.9745" y2="-12.7" width="0" layer="94"/>
<wire x1="16.2325" y1="10.16" x2="16.2325" y2="-12.7" width="0" layer="94"/>
<wire x1="16.4904" y1="10.16" x2="16.4904" y2="-12.7" width="0" layer="94"/>
<wire x1="16.7484" y1="10.16" x2="16.7484" y2="-12.7" width="0" layer="94"/>
<wire x1="17.0064" y1="10.16" x2="17.0064" y2="-12.7" width="0" layer="94"/>
<wire x1="17.2644" y1="10.16" x2="17.2644" y2="-12.7" width="0" layer="94"/>
<wire x1="17.5224" y1="10.16" x2="17.5224" y2="-12.7" width="0" layer="94"/>
<wire x1="17.7803" y1="10.16" x2="17.7803" y2="-12.7" width="0" layer="94"/>
<text x="-25.4" y="16.51" size="1.778" layer="95">&gt;NAME</text>
<text x="-25.4" y="-20.32" size="1.778" layer="96">&gt;VALUE</text>
<pin name="VSS" x="-27.94" y="12.7" length="short" direction="pwr"/>
<pin name="VDD" x="-27.94" y="10.16" length="short" direction="pwr"/>
<pin name="ADJ" x="-27.94" y="7.62" length="short" direction="in"/>
<pin name="RES" x="-27.94" y="5.08" length="short" direction="in"/>
<pin name="D/I" x="-27.94" y="2.54" length="short" direction="in"/>
<pin name="R/!W" x="-27.94" y="0" length="short" direction="in"/>
<pin name="E1" x="-27.94" y="-2.54" length="short" direction="in"/>
<pin name="E2" x="-27.94" y="-5.08" length="short" direction="in"/>
<pin name="CS1L" x="-27.94" y="-7.62" length="short" direction="in"/>
<pin name="CS1H" x="-27.94" y="-10.16" length="short" direction="in"/>
<pin name="CS2L" x="-27.94" y="-12.7" length="short" direction="in"/>
<pin name="CS2H" x="-27.94" y="-15.24" length="short" direction="in"/>
<pin name="VNEG" x="27.94" y="12.7" length="short" direction="pas" rot="R180"/>
<pin name="NC" x="27.94" y="10.16" length="short" direction="nc" rot="R180"/>
<pin name="D0" x="27.94" y="7.62" length="short" rot="R180"/>
<pin name="D1" x="27.94" y="5.08" length="short" rot="R180"/>
<pin name="D2" x="27.94" y="2.54" length="short" rot="R180"/>
<pin name="D3" x="27.94" y="0" length="short" rot="R180"/>
<pin name="D4" x="27.94" y="-2.54" length="short" rot="R180"/>
<pin name="D5" x="27.94" y="-5.08" length="short" rot="R180"/>
<pin name="D6" x="27.94" y="-7.62" length="short" rot="R180"/>
<pin name="D7" x="27.94" y="-10.16" length="short" rot="R180"/>
<pin name="A" x="27.94" y="-12.7" length="short" direction="pas" rot="R180"/>
<pin name="C" x="27.94" y="-15.24" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="HDM64GS12">
<wire x1="-25.4" y1="15.24" x2="27.94" y2="15.24" width="0.254" layer="94"/>
<wire x1="27.94" y1="15.24" x2="27.94" y2="-20.32" width="0.254" layer="94"/>
<wire x1="27.94" y1="-20.32" x2="-25.4" y2="-20.32" width="0.254" layer="94"/>
<wire x1="-25.4" y1="-20.32" x2="-25.4" y2="15.24" width="0.254" layer="94"/>
<text x="-10.16" y="16.51" size="1.778" layer="96">&gt;VALUE</text>
<pin name="VSS" x="25.4" y="-22.86" length="short" direction="pwr" rot="R90"/>
<pin name="VDD" x="22.86" y="-22.86" length="short" direction="pwr" rot="R90"/>
<pin name="RES" x="-15.24" y="-22.86" length="short" direction="in" rot="R90"/>
<pin name="D/I" x="17.78" y="-22.86" length="short" direction="in" rot="R90"/>
<pin name="R/!W" x="15.24" y="-22.86" length="short" direction="in" rot="R90"/>
<pin name="E" x="12.7" y="-22.86" length="short" direction="in" rot="R90"/>
<pin name="CS1" x="-10.16" y="-22.86" length="short" direction="in" rot="R90"/>
<pin name="VEE" x="-17.78" y="-22.86" length="short" direction="out" rot="R90"/>
<pin name="CS2" x="-12.7" y="-22.86" length="short" direction="in" rot="R90"/>
<pin name="VL" x="20.32" y="-22.86" length="short" direction="pas" rot="R90"/>
<pin name="D0" x="10.16" y="-22.86" length="short" rot="R90"/>
<pin name="D1" x="7.62" y="-22.86" length="short" rot="R90"/>
<pin name="D2" x="5.08" y="-22.86" length="short" rot="R90"/>
<pin name="D3" x="2.54" y="-22.86" length="short" rot="R90"/>
<pin name="D4" x="0" y="-22.86" length="short" rot="R90"/>
<pin name="D5" x="-2.54" y="-22.86" length="short" rot="R90"/>
<pin name="D6" x="-5.08" y="-22.86" length="short" rot="R90"/>
<pin name="D7" x="-7.62" y="-22.86" length="short" rot="R90"/>
<pin name="A" x="-20.32" y="-22.86" length="short" direction="pas" rot="R90"/>
<pin name="K" x="-22.86" y="-22.86" length="short" direction="pas" rot="R90"/>
</symbol>
<symbol name="SBLCDA4">
<wire x1="-17.7643" y1="7.6465" x2="20.2708" y2="7.6465" width="0.254" layer="94"/>
<wire x1="20.2708" y1="7.6465" x2="20.2708" y2="-5.0432" width="0.254" layer="94"/>
<wire x1="20.2708" y1="-5.0432" x2="-17.7643" y2="-5.0432" width="0.254" layer="94"/>
<wire x1="-17.7643" y1="-5.0432" x2="-17.7643" y2="7.6465" width="0.254" layer="94"/>
<wire x1="-16.127" y1="6.9984" x2="-12.7157" y2="6.9984" width="0.1016" layer="94"/>
<wire x1="-12.7157" y1="6.9984" x2="-12.7157" y2="4.44" width="0.1016" layer="94"/>
<wire x1="-12.7157" y1="4.44" x2="-16.127" y2="4.44" width="0.1016" layer="94"/>
<wire x1="-16.127" y1="4.44" x2="-16.127" y2="6.9984" width="0.1016" layer="94"/>
<wire x1="-15.6494" y1="6.6231" x2="-13.1933" y2="6.6231" width="0.1016" layer="94"/>
<wire x1="-13.1933" y1="6.6231" x2="-14.2167" y2="5.8386" width="0.1016" layer="94"/>
<wire x1="-14.2167" y1="5.8386" x2="-14.626" y2="5.8386" width="0.1016" layer="94"/>
<wire x1="-14.626" y1="5.8386" x2="-15.6494" y2="6.6231" width="0.1016" layer="94"/>
<wire x1="-15.7858" y1="6.3161" x2="-14.7284" y2="5.4974" width="0.1016" layer="94"/>
<wire x1="-14.7284" y1="5.4974" x2="-14.1485" y2="5.4974" width="0.1016" layer="94"/>
<wire x1="-14.1485" y1="5.4974" x2="-13.0569" y2="6.3161" width="0.1016" layer="94"/>
<wire x1="-13.0569" y1="6.3161" x2="-13.0569" y2="4.7811" width="0.1016" layer="94"/>
<wire x1="-13.0569" y1="4.7811" x2="-15.7858" y2="4.7811" width="0.1016" layer="94"/>
<wire x1="-15.7858" y1="4.7811" x2="-15.7858" y2="6.3161" width="0.1016" layer="94"/>
<wire x1="-11.4536" y1="6.9984" x2="-6.9167" y2="6.9984" width="0.1016" layer="94"/>
<wire x1="-6.9167" y1="6.9984" x2="-6.9167" y2="6.5208" width="0.1016" layer="94"/>
<wire x1="-6.9167" y1="6.5208" x2="-8.9634" y2="4.4741" width="0.1016" layer="94"/>
<wire x1="-8.9634" y1="4.4741" x2="-8.9634" y2="2.4273" width="0.1016" layer="94"/>
<wire x1="-8.9634" y1="2.4273" x2="-9.4069" y2="2.4273" width="0.1016" layer="94"/>
<wire x1="-9.4069" y1="2.4273" x2="-9.4069" y2="4.4741" width="0.1016" layer="94"/>
<wire x1="-9.4069" y1="4.4741" x2="-11.4536" y2="6.5208" width="0.1016" layer="94"/>
<wire x1="-11.4536" y1="6.5208" x2="-11.4536" y2="6.9984" width="0.1016" layer="94"/>
<wire x1="-10.8396" y1="6.5549" x2="-9.4069" y2="6.5549" width="0.1016" layer="94"/>
<wire x1="-9.4069" y1="6.5549" x2="-9.4069" y2="5.1222" width="0.1016" layer="94"/>
<wire x1="-9.4069" y1="5.1222" x2="-10.8396" y2="6.5549" width="0.1016" layer="94"/>
<wire x1="-8.9634" y1="6.5549" x2="-7.5989" y2="6.5549" width="0.1016" layer="94"/>
<wire x1="-7.5989" y1="6.5549" x2="-8.9634" y2="5.1222" width="0.1016" layer="94"/>
<wire x1="-8.9634" y1="5.1222" x2="-8.9634" y2="6.5549" width="0.1016" layer="94"/>
<wire x1="-6.4391" y1="6.9984" x2="-4.6312" y2="6.9984" width="0.1016" layer="94"/>
<wire x1="-4.6312" y1="6.9984" x2="-6.4391" y2="2.4273" width="0.1016" layer="94"/>
<wire x1="-6.4391" y1="2.4273" x2="-6.4391" y2="6.9984" width="0.1016" layer="94"/>
<wire x1="-3.5396" y1="6.589" x2="-3.062" y2="6.589" width="0.1016" layer="94"/>
<wire x1="-3.062" y1="6.589" x2="-2.1751" y2="6.589" width="0.1016" layer="94" curve="-180"/>
<wire x1="-2.1751" y1="6.589" x2="-1.6975" y2="6.589" width="0.1016" layer="94"/>
<wire x1="-1.6975" y1="6.589" x2="-1.6975" y2="2.4273" width="0.1016" layer="94"/>
<wire x1="-1.6975" y1="2.4273" x2="-3.5396" y2="2.4273" width="0.1016" layer="94"/>
<wire x1="-3.5396" y1="2.4273" x2="-3.5396" y2="6.589" width="0.1016" layer="94"/>
<wire x1="-3.5054" y1="6.3844" x2="-1.7657" y2="6.3844" width="0.1016" layer="94"/>
<wire x1="-3.4713" y1="4.6105" x2="-1.7316" y2="4.6105" width="0.1016" layer="94"/>
<wire x1="-3.4713" y1="2.9049" x2="-1.7657" y2="2.9049" width="0.1016" layer="94"/>
<wire x1="-0.5377" y1="4.3035" x2="0.8609" y2="5.7021" width="0.1016" layer="94"/>
<wire x1="0.8609" y1="5.7021" x2="0.8609" y2="4.8834" width="0.1016" layer="94"/>
<wire x1="0.8609" y1="4.8834" x2="1.7819" y2="4.7129" width="0.1016" layer="94"/>
<wire x1="1.7819" y1="4.7129" x2="1.7819" y2="3.9624" width="0.1016" layer="94"/>
<wire x1="1.7819" y1="3.9624" x2="0.8609" y2="3.7577" width="0.1016" layer="94"/>
<wire x1="0.8609" y1="3.7577" x2="0.8609" y2="2.9049" width="0.1016" layer="94"/>
<wire x1="0.8609" y1="2.9049" x2="-0.5377" y2="4.3035" width="0.1016" layer="94"/>
<wire x1="3.0441" y1="1.6086" x2="1.6455" y2="3.0072" width="0.1016" layer="94"/>
<wire x1="1.6455" y1="3.0072" x2="2.4642" y2="3.0072" width="0.1016" layer="94"/>
<wire x1="2.4642" y1="3.0072" x2="2.6347" y2="3.9282" width="0.1016" layer="94"/>
<wire x1="2.6347" y1="3.9282" x2="3.3852" y2="3.9282" width="0.1016" layer="94"/>
<wire x1="3.3852" y1="3.9282" x2="3.5899" y2="3.0072" width="0.1016" layer="94"/>
<wire x1="3.5899" y1="3.0072" x2="4.4427" y2="3.0072" width="0.1016" layer="94"/>
<wire x1="4.4427" y1="3.0072" x2="3.0441" y2="1.6086" width="0.1016" layer="94"/>
<wire x1="6.6259" y1="4.3376" x2="5.2273" y2="2.939" width="0.1016" layer="94"/>
<wire x1="5.2273" y1="2.939" x2="5.2273" y2="3.7577" width="0.1016" layer="94"/>
<wire x1="5.2273" y1="3.7577" x2="4.3063" y2="3.9282" width="0.1016" layer="94"/>
<wire x1="4.3063" y1="3.9282" x2="4.3063" y2="4.6787" width="0.1016" layer="94"/>
<wire x1="4.3063" y1="4.6787" x2="5.2273" y2="4.8834" width="0.1016" layer="94"/>
<wire x1="5.2273" y1="4.8834" x2="5.2273" y2="5.7362" width="0.1016" layer="94"/>
<wire x1="5.2273" y1="5.7362" x2="6.6259" y2="4.3376" width="0.1016" layer="94"/>
<wire x1="3.01" y1="7.0325" x2="4.4086" y2="5.6339" width="0.1016" layer="94"/>
<wire x1="4.4086" y1="5.6339" x2="3.5899" y2="5.6339" width="0.1016" layer="94"/>
<wire x1="3.5899" y1="5.6339" x2="3.4194" y2="4.7129" width="0.1016" layer="94"/>
<wire x1="3.4194" y1="4.7129" x2="2.6689" y2="4.7129" width="0.1016" layer="94"/>
<wire x1="2.6689" y1="4.7129" x2="2.4642" y2="5.6339" width="0.1016" layer="94"/>
<wire x1="2.4642" y1="5.6339" x2="1.6114" y2="5.6339" width="0.1016" layer="94"/>
<wire x1="1.6114" y1="5.6339" x2="3.01" y2="7.0325" width="0.1016" layer="94"/>
<wire x1="7.9904" y1="5.7021" x2="7.9904" y2="6.9984" width="0.1016" layer="94"/>
<wire x1="7.9904" y1="6.9984" x2="8.7749" y2="6.9984" width="0.1016" layer="94"/>
<wire x1="8.7749" y1="6.9984" x2="8.7749" y2="6.7596" width="0.1016" layer="94"/>
<wire x1="8.7749" y1="6.7596" x2="8.3315" y2="6.7596" width="0.1016" layer="94"/>
<wire x1="8.3315" y1="6.7596" x2="8.3315" y2="6.5208" width="0.1016" layer="94"/>
<wire x1="8.3315" y1="6.5208" x2="8.7067" y2="6.5208" width="0.1016" layer="94"/>
<wire x1="8.7067" y1="6.5208" x2="8.7067" y2="6.282" width="0.1016" layer="94"/>
<wire x1="8.7067" y1="6.282" x2="8.3315" y2="6.282" width="0.1016" layer="94"/>
<wire x1="8.3315" y1="6.282" x2="8.3315" y2="5.7021" width="0.1016" layer="94"/>
<wire x1="8.3315" y1="5.7021" x2="7.9904" y2="5.7021" width="0.1016" layer="94"/>
<wire x1="8.9796" y1="6.6573" x2="9.3207" y2="6.9984" width="0.1016" layer="94"/>
<wire x1="9.3207" y1="6.9984" x2="9.5254" y2="6.9984" width="0.1016" layer="94"/>
<wire x1="9.5254" y1="6.9984" x2="9.5254" y2="5.7021" width="0.1016" layer="94"/>
<wire x1="9.5254" y1="5.7021" x2="9.2866" y2="5.7021" width="0.1016" layer="94"/>
<wire x1="9.2866" y1="5.7021" x2="9.2866" y2="6.5549" width="0.1016" layer="94"/>
<wire x1="9.2866" y1="6.5549" x2="8.9796" y2="6.3502" width="0.1016" layer="94"/>
<wire x1="8.9796" y1="6.3502" x2="8.9796" y2="6.6573" width="0.1016" layer="94"/>
<wire x1="10.0371" y1="6.9984" x2="10.7876" y2="6.9984" width="0.1016" layer="94"/>
<wire x1="10.7876" y1="6.9984" x2="10.7876" y2="6.7596" width="0.1016" layer="94"/>
<wire x1="10.7876" y1="6.7596" x2="10.3441" y2="6.7596" width="0.1016" layer="94"/>
<wire x1="10.3441" y1="6.7596" x2="10.3441" y2="6.5208" width="0.1016" layer="94"/>
<wire x1="10.3441" y1="6.5208" x2="10.7876" y2="6.5208" width="0.1016" layer="94"/>
<wire x1="10.7876" y1="6.5208" x2="10.7876" y2="6.282" width="0.1016" layer="94"/>
<wire x1="10.7876" y1="6.282" x2="10.3441" y2="6.282" width="0.1016" layer="94"/>
<wire x1="10.3441" y1="6.282" x2="10.3441" y2="5.7021" width="0.1016" layer="94"/>
<wire x1="10.3441" y1="5.7021" x2="10.0371" y2="5.7021" width="0.1016" layer="94"/>
<wire x1="10.0371" y1="5.7021" x2="10.0371" y2="6.9984" width="0.1016" layer="94"/>
<wire x1="11.8109" y1="5.975" x2="11.8109" y2="5.7021" width="0.1016" layer="94"/>
<wire x1="11.8109" y1="5.7021" x2="10.9581" y2="5.7021" width="0.1016" layer="94"/>
<wire x1="10.9581" y1="5.7021" x2="10.9581" y2="5.7703" width="0.1016" layer="94"/>
<wire x1="10.9581" y1="5.7703" x2="11.0263" y2="5.975" width="0.1016" layer="94" curve="-36.8643"/>
<wire x1="11.0263" y1="5.975" x2="11.4357" y2="6.4185" width="0.1016" layer="94" curve="-11.696246"/>
<wire x1="11.4357" y1="6.4185" x2="11.538" y2="6.589" width="0.1016" layer="94" curve="35.199023"/>
<wire x1="11.538" y1="6.589" x2="11.5039" y2="6.7255" width="0.1016" layer="94" curve="54.770713"/>
<wire x1="11.5039" y1="6.7255" x2="11.2992" y2="6.7255" width="0.1016" layer="94" curve="97.158223"/>
<wire x1="11.2992" y1="6.7255" x2="11.2651" y2="6.6231" width="0.1016" layer="94" curve="45.955498"/>
<wire x1="11.2651" y1="6.6231" x2="10.9922" y2="6.6231" width="0.1016" layer="94"/>
<wire x1="10.9922" y1="6.6231" x2="10.9922" y2="6.6573" width="0.1016" layer="94"/>
<wire x1="10.9922" y1="6.6573" x2="11.1628" y2="6.9643" width="0.1016" layer="94" curve="-58.12682"/>
<wire x1="11.1628" y1="6.9643" x2="11.6745" y2="6.9301" width="0.1016" layer="94" curve="-71.408077"/>
<wire x1="11.6745" y1="6.9301" x2="11.7768" y2="6.4526" width="0.1016" layer="94" curve="-76.758822"/>
<wire x1="11.7768" y1="6.4526" x2="11.6063" y2="6.2138" width="0.1016" layer="94" curve="-18.465187"/>
<wire x1="11.6063" y1="6.2138" x2="11.4698" y2="6.0773" width="0.1016" layer="94" curve="-0.478147"/>
<wire x1="11.4698" y1="6.0773" x2="11.4016" y2="6.0091" width="0.1016" layer="94" curve="0.478146"/>
<wire x1="11.4016" y1="6.0091" x2="11.3675" y2="5.975" width="0.1016" layer="94"/>
<wire x1="11.3675" y1="5.975" x2="11.8109" y2="5.975" width="0.1016" layer="94"/>
<wire x1="12.3226" y1="6.9984" x2="13.0731" y2="6.9984" width="0.1016" layer="94"/>
<wire x1="13.0731" y1="6.9984" x2="13.0731" y2="6.7596" width="0.1016" layer="94"/>
<wire x1="13.0731" y1="6.7596" x2="12.6296" y2="6.7596" width="0.1016" layer="94"/>
<wire x1="12.6296" y1="6.7596" x2="12.6296" y2="6.5208" width="0.1016" layer="94"/>
<wire x1="12.6296" y1="6.5208" x2="13.0731" y2="6.5208" width="0.1016" layer="94"/>
<wire x1="13.0731" y1="6.5208" x2="13.0731" y2="6.282" width="0.1016" layer="94"/>
<wire x1="13.0731" y1="6.282" x2="12.6296" y2="6.282" width="0.1016" layer="94"/>
<wire x1="12.6296" y1="6.282" x2="12.6296" y2="5.7021" width="0.1016" layer="94"/>
<wire x1="12.6296" y1="5.7021" x2="12.3226" y2="5.7021" width="0.1016" layer="94"/>
<wire x1="12.3226" y1="5.7021" x2="12.3226" y2="6.9984" width="0.1016" layer="94"/>
<wire x1="14.6081" y1="6.9984" x2="15.3586" y2="6.9984" width="0.1016" layer="94"/>
<wire x1="15.3586" y1="6.9984" x2="15.3586" y2="6.7596" width="0.1016" layer="94"/>
<wire x1="15.3586" y1="6.7596" x2="14.9151" y2="6.7596" width="0.1016" layer="94"/>
<wire x1="14.9151" y1="6.7596" x2="14.9151" y2="6.5208" width="0.1016" layer="94"/>
<wire x1="14.9151" y1="6.5208" x2="15.3586" y2="6.5208" width="0.1016" layer="94"/>
<wire x1="15.3586" y1="6.5208" x2="15.3586" y2="6.282" width="0.1016" layer="94"/>
<wire x1="15.3586" y1="6.282" x2="14.9151" y2="6.282" width="0.1016" layer="94"/>
<wire x1="14.9151" y1="6.282" x2="14.9151" y2="5.7021" width="0.1016" layer="94"/>
<wire x1="14.9151" y1="5.7021" x2="14.6081" y2="5.7021" width="0.1016" layer="94"/>
<wire x1="14.6081" y1="5.7021" x2="14.6081" y2="6.9984" width="0.1016" layer="94"/>
<wire x1="16.8595" y1="6.9984" x2="17.61" y2="6.9984" width="0.1016" layer="94"/>
<wire x1="17.61" y1="6.9984" x2="17.61" y2="6.7596" width="0.1016" layer="94"/>
<wire x1="17.61" y1="6.7596" x2="17.1665" y2="6.7596" width="0.1016" layer="94"/>
<wire x1="17.1665" y1="6.7596" x2="17.1665" y2="6.5208" width="0.1016" layer="94"/>
<wire x1="17.1665" y1="6.5208" x2="17.61" y2="6.5208" width="0.1016" layer="94"/>
<wire x1="17.61" y1="6.5208" x2="17.61" y2="6.282" width="0.1016" layer="94"/>
<wire x1="17.61" y1="6.282" x2="17.1665" y2="6.282" width="0.1016" layer="94"/>
<wire x1="17.1665" y1="6.282" x2="17.1665" y2="5.7021" width="0.1016" layer="94"/>
<wire x1="17.1665" y1="5.7021" x2="16.8595" y2="5.7021" width="0.1016" layer="94"/>
<wire x1="16.8595" y1="5.7021" x2="16.8595" y2="6.9984" width="0.1016" layer="94"/>
<wire x1="13.5165" y1="6.6573" x2="13.3119" y2="6.6573" width="0.1016" layer="94"/>
<wire x1="13.3119" y1="6.6573" x2="13.3119" y2="6.6914" width="0.1016" layer="94"/>
<wire x1="13.3119" y1="6.6914" x2="13.4142" y2="6.9301" width="0.1016" layer="94" curve="-46.431969"/>
<wire x1="13.4142" y1="6.9301" x2="13.9259" y2="6.9301" width="0.1016" layer="94" curve="-87.214692"/>
<wire x1="13.9259" y1="6.9301" x2="13.96" y2="6.4526" width="0.1016" layer="94" curve="-84.607136"/>
<wire x1="13.96" y1="6.4526" x2="13.9259" y2="6.4185" width="0.1016" layer="94"/>
<wire x1="13.9259" y1="6.4185" x2="13.9941" y2="5.7703" width="0.1016" layer="94" curve="-100.82495"/>
<wire x1="13.9941" y1="5.7703" x2="13.4142" y2="5.7703" width="0.1016" layer="94" curve="-75.748903"/>
<wire x1="13.4142" y1="5.7703" x2="13.2778" y2="6.0432" width="0.1016" layer="94" curve="-36.890904"/>
<wire x1="13.2778" y1="6.0432" x2="13.5165" y2="6.0432" width="0.1016" layer="94"/>
<wire x1="13.5165" y1="6.0432" x2="13.653" y2="6.282" width="0.1016" layer="94" curve="259.752596"/>
<wire x1="13.653" y1="6.282" x2="13.6189" y2="6.4867" width="0.1016" layer="94"/>
<wire x1="13.6189" y1="6.4867" x2="13.5165" y2="6.6573" width="0.1016" layer="94" curve="263.175292"/>
<wire x1="15.5633" y1="5.975" x2="15.5633" y2="6.2479" width="0.1016" layer="94"/>
<wire x1="15.5633" y1="6.2479" x2="16.0408" y2="6.9984" width="0.1016" layer="94"/>
<wire x1="16.0408" y1="6.9984" x2="16.3137" y2="6.9984" width="0.1016" layer="94"/>
<wire x1="16.3137" y1="6.9984" x2="16.3137" y2="6.2138" width="0.1016" layer="94"/>
<wire x1="16.3137" y1="6.2138" x2="16.4502" y2="6.2138" width="0.1016" layer="94"/>
<wire x1="16.4502" y1="6.2138" x2="16.4502" y2="5.975" width="0.1016" layer="94"/>
<wire x1="16.4502" y1="5.975" x2="16.3137" y2="5.975" width="0.1016" layer="94"/>
<wire x1="16.3137" y1="5.975" x2="16.3137" y2="5.7021" width="0.1016" layer="94"/>
<wire x1="16.3137" y1="5.7021" x2="16.075" y2="5.7021" width="0.1016" layer="94"/>
<wire x1="16.075" y1="5.7021" x2="16.075" y2="5.975" width="0.1016" layer="94"/>
<wire x1="16.075" y1="5.975" x2="15.5633" y2="5.975" width="0.1016" layer="94"/>
<wire x1="15.8021" y1="6.2138" x2="16.075" y2="6.2138" width="0.1016" layer="94"/>
<wire x1="16.075" y1="6.2138" x2="16.075" y2="6.6231" width="0.1016" layer="94"/>
<wire x1="16.075" y1="6.6231" x2="15.8021" y2="6.2138" width="0.1016" layer="94"/>
<wire x1="18.5993" y1="6.9984" x2="18.5993" y2="6.7596" width="0.1016" layer="94"/>
<wire x1="18.5993" y1="6.7596" x2="18.1217" y2="6.7596" width="0.1016" layer="94"/>
<wire x1="18.1217" y1="6.7596" x2="18.1217" y2="6.5549" width="0.1016" layer="94"/>
<wire x1="18.1217" y1="6.5549" x2="18.6334" y2="6.3161" width="0.1016" layer="94" curve="-90.056013"/>
<wire x1="18.6334" y1="6.3161" x2="18.6334" y2="5.975" width="0.1016" layer="94"/>
<wire x1="18.6334" y1="5.975" x2="18.2581" y2="5.7021" width="0.1016" layer="94" curve="-80.835413"/>
<wire x1="18.2581" y1="5.7021" x2="17.8147" y2="6.0432" width="0.1016" layer="94" curve="-83.716775"/>
<wire x1="17.8147" y1="6.0432" x2="18.0876" y2="6.0432" width="0.1016" layer="94"/>
<wire x1="18.0876" y1="6.0432" x2="18.224" y2="5.9409" width="0.1016" layer="94" curve="59.531148"/>
<wire x1="18.224" y1="5.9409" x2="18.3605" y2="6.0432" width="0.1016" layer="94" curve="73.770028"/>
<wire x1="18.3605" y1="6.0432" x2="18.3605" y2="6.2479" width="0.1016" layer="94"/>
<wire x1="18.3605" y1="6.2479" x2="18.1217" y2="6.282" width="0.1016" layer="94" curve="118.206661"/>
<wire x1="18.1217" y1="6.282" x2="18.0876" y2="6.282" width="0.1016" layer="94"/>
<wire x1="18.0876" y1="6.282" x2="17.8488" y2="6.3161" width="0.1016" layer="94"/>
<wire x1="17.8488" y1="6.3161" x2="17.9511" y2="6.9984" width="0.1016" layer="94"/>
<wire x1="17.9511" y1="6.9984" x2="18.5993" y2="6.9984" width="0.1016" layer="94"/>
<wire x1="17.9511" y1="2.2909" x2="17.9511" y2="2.632" width="0.1016" layer="94"/>
<wire x1="17.9511" y1="2.632" x2="18.2581" y2="2.632" width="0.1016" layer="94"/>
<wire x1="18.2581" y1="2.632" x2="18.2581" y2="4.5082" width="0.1016" layer="94"/>
<wire x1="18.2581" y1="4.5082" x2="17.917" y2="4.5082" width="0.1016" layer="94"/>
<wire x1="17.917" y1="4.5082" x2="17.917" y2="4.8152" width="0.1016" layer="94"/>
<wire x1="17.917" y1="4.8152" x2="18.5651" y2="4.8152" width="0.1016" layer="94"/>
<wire x1="18.5651" y1="4.8152" x2="18.5651" y2="2.2909" width="0.1016" layer="94"/>
<wire x1="18.5651" y1="2.2909" x2="17.9511" y2="2.2909" width="0.1016" layer="94"/>
<wire x1="17.7123" y1="2.2909" x2="17.7123" y2="2.8026" width="0.1016" layer="94"/>
<wire x1="17.7123" y1="2.8026" x2="18.0535" y2="2.8026" width="0.1016" layer="94"/>
<wire x1="18.0535" y1="2.8026" x2="18.0535" y2="4.3376" width="0.1016" layer="94"/>
<wire x1="18.0535" y1="4.3376" x2="17.7123" y2="4.3376" width="0.1016" layer="94"/>
<wire x1="17.7123" y1="4.3376" x2="17.7123" y2="4.8152" width="0.1016" layer="94"/>
<wire x1="17.7123" y1="4.8152" x2="16.5866" y2="4.8152" width="0.1016" layer="94"/>
<wire x1="16.5866" y1="4.8152" x2="16.5866" y2="2.2909" width="0.1016" layer="94"/>
<wire x1="16.5866" y1="2.2909" x2="17.7123" y2="2.2909" width="0.1016" layer="94"/>
<wire x1="16.382" y1="4.8152" x2="14.4717" y2="4.8152" width="0.1016" layer="94"/>
<wire x1="14.4717" y1="4.8152" x2="14.4717" y2="2.2909" width="0.1016" layer="94"/>
<wire x1="14.4717" y1="2.2909" x2="16.382" y2="2.2909" width="0.1016" layer="94"/>
<wire x1="16.382" y1="2.2909" x2="16.382" y2="4.8152" width="0.1016" layer="94"/>
<wire x1="14.267" y1="2.2909" x2="14.267" y2="4.8152" width="0.1016" layer="94"/>
<wire x1="14.267" y1="4.8152" x2="12.3226" y2="4.8152" width="0.1016" layer="94"/>
<wire x1="12.3226" y1="4.8152" x2="12.3226" y2="2.2909" width="0.1016" layer="94"/>
<wire x1="12.3226" y1="2.2909" x2="14.267" y2="2.2909" width="0.1016" layer="94"/>
<wire x1="12.1179" y1="2.2909" x2="12.1179" y2="4.8152" width="0.1016" layer="94"/>
<wire x1="12.1179" y1="4.8152" x2="10.2418" y2="4.8152" width="0.1016" layer="94"/>
<wire x1="10.2418" y1="4.8152" x2="10.2418" y2="2.2909" width="0.1016" layer="94"/>
<wire x1="10.2418" y1="2.2909" x2="12.1179" y2="2.2909" width="0.1016" layer="94"/>
<wire x1="10.003" y1="2.2909" x2="10.003" y2="4.8152" width="0.1016" layer="94"/>
<wire x1="10.003" y1="4.8152" x2="8.9114" y2="4.8152" width="0.1016" layer="94"/>
<wire x1="8.9114" y1="4.8152" x2="8.9114" y2="4.3376" width="0.1016" layer="94"/>
<wire x1="8.9114" y1="4.3376" x2="8.5362" y2="4.3376" width="0.1016" layer="94"/>
<wire x1="8.5362" y1="4.3376" x2="8.5362" y2="2.8026" width="0.1016" layer="94"/>
<wire x1="8.5362" y1="2.8026" x2="8.9114" y2="2.8026" width="0.1016" layer="94"/>
<wire x1="8.9114" y1="2.8026" x2="8.9114" y2="2.2909" width="0.1016" layer="94"/>
<wire x1="8.9114" y1="2.2909" x2="10.003" y2="2.2909" width="0.1016" layer="94"/>
<wire x1="8.7067" y1="2.2909" x2="8.7067" y2="2.632" width="0.1016" layer="94"/>
<wire x1="8.7067" y1="2.632" x2="8.3315" y2="2.632" width="0.1016" layer="94"/>
<wire x1="8.3315" y1="2.632" x2="8.3315" y2="4.5082" width="0.1016" layer="94"/>
<wire x1="8.3315" y1="4.5082" x2="8.7067" y2="4.5082" width="0.1016" layer="94"/>
<wire x1="8.7067" y1="4.5082" x2="8.7067" y2="4.8152" width="0.1016" layer="94"/>
<wire x1="8.7067" y1="4.8152" x2="8.0245" y2="4.8152" width="0.1016" layer="94"/>
<wire x1="8.0245" y1="4.8152" x2="8.0245" y2="2.2909" width="0.1016" layer="94"/>
<wire x1="8.0245" y1="2.2909" x2="8.7067" y2="2.2909" width="0.1016" layer="94"/>
<wire x1="-15.3424" y1="-0.3699" x2="-15.3424" y2="-0.5063" width="0.1016" layer="94"/>
<wire x1="-15.3424" y1="-0.5063" x2="-15.7858" y2="-0.6428" width="0.1016" layer="94" curve="43.617082"/>
<wire x1="-15.7858" y1="-0.6428" x2="-15.9223" y2="-1.6661" width="0.1016" layer="94" curve="77.548521"/>
<wire x1="-15.9223" y1="-1.6661" x2="-15.3424" y2="-2.0414" width="0.1016" layer="94" curve="48.607903"/>
<wire x1="-15.3424" y1="-2.0414" x2="-15.3424" y2="-2.5872" width="0.1016" layer="94"/>
<wire x1="-15.3424" y1="-2.5872" x2="-15.3765" y2="-2.553" width="0.1016" layer="94"/>
<wire x1="-15.3765" y1="-2.553" x2="-15.5471" y2="-2.2801" width="0.1016" layer="94" curve="-46.368962"/>
<wire x1="-15.5471" y1="-2.2801" x2="-16.0929" y2="-2.3143" width="0.1016" layer="94"/>
<wire x1="-16.0929" y1="-2.3143" x2="-16.0587" y2="-2.5189" width="0.1016" layer="94"/>
<wire x1="-16.0587" y1="-2.5189" x2="-15.3424" y2="-3.133" width="0.1016" layer="94" curve="79.799025"/>
<wire x1="-15.3424" y1="-3.133" x2="-15.3424" y2="-3.44" width="0.1016" layer="94"/>
<wire x1="-15.3424" y1="-3.44" x2="-15.1377" y2="-3.44" width="0.1016" layer="94"/>
<wire x1="-15.1377" y1="-3.44" x2="-15.1377" y2="-3.133" width="0.1016" layer="94"/>
<wire x1="-15.1377" y1="-3.133" x2="-15.1036" y2="-3.133" width="0.1016" layer="94"/>
<wire x1="-15.1036" y1="-3.133" x2="-14.4896" y2="-2.7577" width="0.1016" layer="94" curve="62.890978"/>
<wire x1="-14.4896" y1="-2.7577" x2="-15.1377" y2="-1.4956" width="0.1016" layer="94" curve="108.636584"/>
<wire x1="-15.1377" y1="-1.4956" x2="-15.1377" y2="-0.9839" width="0.1016" layer="94"/>
<wire x1="-15.1377" y1="-0.9839" x2="-14.9671" y2="-1.2227" width="0.1016" layer="94" curve="-53.053427"/>
<wire x1="-14.9671" y1="-1.2227" x2="-14.4896" y2="-1.1203" width="0.1016" layer="94"/>
<wire x1="-14.4896" y1="-1.1203" x2="-15.1377" y2="-0.5063" width="0.1016" layer="94" curve="88.353257"/>
<wire x1="-15.1377" y1="-0.5063" x2="-15.1377" y2="-0.3699" width="0.1016" layer="94"/>
<wire x1="-15.1377" y1="-0.3699" x2="-15.3424" y2="-0.3699" width="0.1016" layer="94"/>
<wire x1="-15.3765" y1="-1.4274" x2="-15.3765" y2="-0.9839" width="0.1016" layer="94"/>
<wire x1="-15.3765" y1="-0.9839" x2="-15.3765" y2="-1.4274" width="0.1016" layer="94" curve="133.662081"/>
<wire x1="-15.1377" y1="-2.5872" x2="-15.1377" y2="-2.1096" width="0.1016" layer="94"/>
<wire x1="-15.1377" y1="-2.1096" x2="-15.1377" y2="-2.5872" width="0.1016" layer="94" curve="-154.972872"/>
<wire x1="-13.0569" y1="-1.2227" x2="-13.0569" y2="0.2783" width="0.1016" layer="94"/>
<wire x1="-13.0569" y1="0.2783" x2="-11.8629" y2="0.2783" width="0.1016" layer="94"/>
<wire x1="-11.8629" y1="0.2783" x2="-11.8629" y2="0.0054" width="0.1016" layer="94"/>
<wire x1="-11.8629" y1="0.0054" x2="-12.6816" y2="0.0054" width="0.1016" layer="94"/>
<wire x1="-12.6816" y1="0.0054" x2="-12.6816" y2="-0.3016" width="0.1016" layer="94"/>
<wire x1="-12.6816" y1="-0.3016" x2="-11.9312" y2="-0.3016" width="0.1016" layer="94"/>
<wire x1="-11.9312" y1="-0.3016" x2="-11.9312" y2="-0.5404" width="0.1016" layer="94"/>
<wire x1="-11.9312" y1="-0.5404" x2="-12.6816" y2="-0.5404" width="0.1016" layer="94"/>
<wire x1="-12.6816" y1="-0.5404" x2="-12.6816" y2="-0.9498" width="0.1016" layer="94"/>
<wire x1="-12.6816" y1="-0.9498" x2="-11.8288" y2="-0.9498" width="0.1016" layer="94"/>
<wire x1="-11.8288" y1="-0.9498" x2="-11.8288" y2="-1.2227" width="0.1016" layer="94"/>
<wire x1="-11.8288" y1="-1.2227" x2="-13.0569" y2="-1.2227" width="0.1016" layer="94"/>
<wire x1="-13.2957" y1="-1.7002" x2="-11.59" y2="-1.7002" width="0.1016" layer="94"/>
<wire x1="-11.59" y1="-1.7002" x2="-11.59" y2="-2.1096" width="0.1016" layer="94"/>
<wire x1="-11.59" y1="-2.1096" x2="-13.2957" y2="-2.1096" width="0.1016" layer="94"/>
<wire x1="-13.2957" y1="-2.1096" x2="-13.2957" y2="-1.7002" width="0.1016" layer="94"/>
<wire x1="-13.2957" y1="-4.0199" x2="-13.2957" y2="-2.5872" width="0.1016" layer="94"/>
<wire x1="-13.2957" y1="-2.5872" x2="-12.7157" y2="-2.5872" width="0.1016" layer="94"/>
<wire x1="-12.7157" y1="-2.5872" x2="-12.477" y2="-3.4741" width="0.1016" layer="94"/>
<wire x1="-12.477" y1="-3.4741" x2="-12.2041" y2="-2.5872" width="0.1016" layer="94"/>
<wire x1="-12.2041" y1="-2.5872" x2="-11.6242" y2="-2.5872" width="0.1016" layer="94"/>
<wire x1="-11.6242" y1="-2.5872" x2="-11.6242" y2="-4.0199" width="0.1016" layer="94"/>
<wire x1="-11.6242" y1="-4.0199" x2="-11.9312" y2="-4.0199" width="0.1016" layer="94"/>
<wire x1="-11.9312" y1="-4.0199" x2="-11.9312" y2="-2.8259" width="0.1016" layer="94"/>
<wire x1="-11.9312" y1="-2.8259" x2="-12.3064" y2="-4.0199" width="0.1016" layer="94"/>
<wire x1="-12.3064" y1="-4.0199" x2="-12.6134" y2="-4.0199" width="0.1016" layer="94"/>
<wire x1="-12.6134" y1="-4.0199" x2="-12.9545" y2="-2.8259" width="0.1016" layer="94"/>
<wire x1="-12.9545" y1="-2.8259" x2="-12.9545" y2="-4.0199" width="0.1016" layer="94"/>
<wire x1="-12.9545" y1="-4.0199" x2="-13.2957" y2="-4.0199" width="0.1016" layer="94"/>
<wire x1="-10.4643" y1="-3.44" x2="-9.8844" y2="-4.0199" width="0.1016" layer="94"/>
<wire x1="-9.8844" y1="-4.0199" x2="-9.7821" y2="-3.8493" width="0.1016" layer="94"/>
<wire x1="-9.7821" y1="-3.8493" x2="-9.7821" y2="-2.246" width="0.1016" layer="94"/>
<wire x1="-9.7821" y1="-2.246" x2="-9.9185" y2="-2.0755" width="0.1016" layer="94"/>
<wire x1="-9.9185" y1="-2.0755" x2="-10.4643" y2="-2.4507" width="0.1016" layer="94"/>
<wire x1="-10.4643" y1="-2.4507" x2="-10.4643" y2="-3.44" width="0.1016" layer="94"/>
<wire x1="-9.9185" y1="-1.6661" x2="-10.4643" y2="-1.325" width="0.1016" layer="94"/>
<wire x1="-10.4643" y1="-1.325" x2="-10.4643" y2="-0.2675" width="0.1016" layer="94"/>
<wire x1="-10.4643" y1="-0.2675" x2="-9.9185" y2="0.2783" width="0.1016" layer="94"/>
<wire x1="-9.9185" y1="0.2783" x2="-9.7821" y2="0.0395" width="0.1016" layer="94"/>
<wire x1="-9.7821" y1="0.0395" x2="-9.7821" y2="-1.4615" width="0.1016" layer="94"/>
<wire x1="-9.7821" y1="-1.4615" x2="-9.9185" y2="-1.6661" width="0.1016" layer="94"/>
<wire x1="-8.0765" y1="0.4829" x2="-7.94" y2="0.6194" width="0.1016" layer="94"/>
<wire x1="-7.94" y1="0.6194" x2="-6.2344" y2="0.6194" width="0.1016" layer="94"/>
<wire x1="-6.2344" y1="0.6194" x2="-6.098" y2="0.4829" width="0.1016" layer="94"/>
<wire x1="-6.6779" y1="-0.097" x2="-7.4966" y2="-0.097" width="0.1016" layer="94"/>
<wire x1="-7.4966" y1="-0.097" x2="-8.0765" y2="0.4829" width="0.1016" layer="94"/>
<wire x1="-8.2812" y1="0.2442" x2="-8.4517" y2="0.1418" width="0.1016" layer="94"/>
<wire x1="-8.4517" y1="0.1418" x2="-8.4517" y2="-1.5638" width="0.1016" layer="94"/>
<wire x1="-8.4517" y1="-1.5638" x2="-8.2812" y2="-1.6661" width="0.1016" layer="94"/>
<wire x1="-7.7012" y1="-1.0863" x2="-7.7013" y2="-0.3358" width="0.1016" layer="94"/>
<wire x1="-7.7013" y1="-0.3358" x2="-8.2812" y2="0.244" width="0.1016" layer="94"/>
<wire x1="-7.7012" y1="-1.0863" x2="-8.281" y2="-1.6662" width="0.1016" layer="94"/>
<wire x1="-6.098" y1="0.4829" x2="-6.6779" y2="-0.097" width="0.1016" layer="94"/>
<wire x1="-6.098" y1="-4.2586" x2="-6.2345" y2="-4.3951" width="0.1016" layer="94"/>
<wire x1="-6.2345" y1="-4.3951" x2="-7.9401" y2="-4.3951" width="0.1016" layer="94"/>
<wire x1="-7.9401" y1="-4.3951" x2="-8.0765" y2="-4.2586" width="0.1016" layer="94"/>
<wire x1="-7.4966" y1="-3.6787" x2="-6.6779" y2="-3.6787" width="0.1016" layer="94"/>
<wire x1="-6.6779" y1="-3.6787" x2="-6.098" y2="-4.2586" width="0.1016" layer="94"/>
<wire x1="-5.8933" y1="-4.0199" x2="-5.7228" y2="-3.9175" width="0.1016" layer="94"/>
<wire x1="-5.7228" y1="-3.9175" x2="-5.7228" y2="-2.2119" width="0.1016" layer="94"/>
<wire x1="-5.7228" y1="-2.2119" x2="-5.8933" y2="-2.1096" width="0.1016" layer="94"/>
<wire x1="-6.4733" y1="-2.6894" x2="-6.4732" y2="-3.4399" width="0.1016" layer="94"/>
<wire x1="-6.4732" y1="-3.4399" x2="-5.8933" y2="-4.0197" width="0.1016" layer="94"/>
<wire x1="-6.4733" y1="-2.6894" x2="-5.8935" y2="-2.1095" width="0.1016" layer="94"/>
<wire x1="-8.0765" y1="-4.2586" x2="-7.4966" y2="-3.6787" width="0.1016" layer="94"/>
<wire x1="-8.0765" y1="-1.8708" x2="-7.4625" y2="-1.5296" width="0.1016" layer="94"/>
<wire x1="-7.4625" y1="-1.5296" x2="-6.746" y2="-1.5297" width="0.1016" layer="94"/>
<wire x1="-6.746" y1="-1.5297" x2="-6.1321" y2="-1.8708" width="0.1016" layer="94"/>
<wire x1="-6.746" y1="-2.246" x2="-7.4624" y2="-2.246" width="0.1016" layer="94"/>
<wire x1="-7.4624" y1="-2.246" x2="-8.0766" y2="-1.8708" width="0.1016" layer="94"/>
<wire x1="-8.2812" y1="-2.0754" x2="-8.4517" y2="-2.1778" width="0.1016" layer="94"/>
<wire x1="-8.4517" y1="-2.1778" x2="-8.4517" y2="-3.8834" width="0.1016" layer="94"/>
<wire x1="-8.4517" y1="-3.8834" x2="-8.2812" y2="-3.9857" width="0.1016" layer="94"/>
<wire x1="-7.7012" y1="-3.4059" x2="-7.7013" y2="-2.6554" width="0.1016" layer="94"/>
<wire x1="-7.7013" y1="-2.6554" x2="-8.2812" y2="-2.0756" width="0.1016" layer="94"/>
<wire x1="-7.7012" y1="-3.4059" x2="-8.281" y2="-3.9858" width="0.1016" layer="94"/>
<wire x1="-6.1321" y1="-1.8708" x2="-6.746" y2="-2.246" width="0.1016" layer="94"/>
<wire x1="-8.0766" y1="-1.8708" x2="-8.0765" y2="-1.8708" width="0.1016" layer="94"/>
<wire x1="-5.8933" y1="-1.6662" x2="-5.7228" y2="-1.5638" width="0.1016" layer="94"/>
<wire x1="-5.7228" y1="-1.5638" x2="-5.7228" y2="0.1418" width="0.1016" layer="94"/>
<wire x1="-5.7228" y1="0.1418" x2="-5.8933" y2="0.2441" width="0.1016" layer="94"/>
<wire x1="-6.4733" y1="-0.3357" x2="-6.4732" y2="-1.0862" width="0.1016" layer="94"/>
<wire x1="-6.4732" y1="-1.0862" x2="-5.8933" y2="-1.666" width="0.1016" layer="94"/>
<wire x1="-6.4733" y1="-0.3357" x2="-5.8935" y2="0.2442" width="0.1016" layer="94"/>
<wire x1="-4.0172" y1="0.4829" x2="-3.8807" y2="0.6194" width="0.1016" layer="94"/>
<wire x1="-3.8807" y1="0.6194" x2="-2.1751" y2="0.6194" width="0.1016" layer="94"/>
<wire x1="-2.1751" y1="0.6194" x2="-2.0387" y2="0.4829" width="0.1016" layer="94"/>
<wire x1="-2.6186" y1="-0.097" x2="-3.4373" y2="-0.097" width="0.1016" layer="94"/>
<wire x1="-3.4373" y1="-0.097" x2="-4.0172" y2="0.4829" width="0.1016" layer="94"/>
<wire x1="-4.2219" y1="0.2442" x2="-4.3924" y2="0.1418" width="0.1016" layer="94"/>
<wire x1="-4.3924" y1="0.1418" x2="-4.3924" y2="-1.5638" width="0.1016" layer="94"/>
<wire x1="-4.3924" y1="-1.5638" x2="-4.2219" y2="-1.6661" width="0.1016" layer="94"/>
<wire x1="-3.6419" y1="-1.0863" x2="-3.642" y2="-0.3358" width="0.1016" layer="94"/>
<wire x1="-3.642" y1="-0.3358" x2="-4.2219" y2="0.244" width="0.1016" layer="94"/>
<wire x1="-3.6419" y1="-1.0863" x2="-4.2217" y2="-1.6662" width="0.1016" layer="94"/>
<wire x1="-2.0387" y1="0.4829" x2="-2.6186" y2="-0.097" width="0.1016" layer="94"/>
<wire x1="-2.0387" y1="-4.2586" x2="-2.1752" y2="-4.3951" width="0.1016" layer="94"/>
<wire x1="-2.1752" y1="-4.3951" x2="-3.8808" y2="-4.3951" width="0.1016" layer="94"/>
<wire x1="-3.8808" y1="-4.3951" x2="-4.0172" y2="-4.2586" width="0.1016" layer="94"/>
<wire x1="-3.4373" y1="-3.6787" x2="-2.6186" y2="-3.6787" width="0.1016" layer="94"/>
<wire x1="-2.6186" y1="-3.6787" x2="-2.0387" y2="-4.2586" width="0.1016" layer="94"/>
<wire x1="-1.834" y1="-4.0199" x2="-1.6635" y2="-3.9175" width="0.1016" layer="94"/>
<wire x1="-1.6635" y1="-3.9175" x2="-1.6635" y2="-2.2119" width="0.1016" layer="94"/>
<wire x1="-1.6635" y1="-2.2119" x2="-1.834" y2="-2.1096" width="0.1016" layer="94"/>
<wire x1="-2.414" y1="-2.6894" x2="-2.4139" y2="-3.4399" width="0.1016" layer="94"/>
<wire x1="-2.4139" y1="-3.4399" x2="-1.834" y2="-4.0197" width="0.1016" layer="94"/>
<wire x1="-2.414" y1="-2.6894" x2="-1.8342" y2="-2.1095" width="0.1016" layer="94"/>
<wire x1="-4.0172" y1="-4.2586" x2="-3.4373" y2="-3.6787" width="0.1016" layer="94"/>
<wire x1="-4.0172" y1="-1.8708" x2="-3.4032" y2="-1.5296" width="0.1016" layer="94"/>
<wire x1="-3.4032" y1="-1.5296" x2="-2.6867" y2="-1.5297" width="0.1016" layer="94"/>
<wire x1="-2.6867" y1="-1.5297" x2="-2.0728" y2="-1.8708" width="0.1016" layer="94"/>
<wire x1="-2.6867" y1="-2.246" x2="-3.4031" y2="-2.246" width="0.1016" layer="94"/>
<wire x1="-3.4031" y1="-2.246" x2="-4.0173" y2="-1.8708" width="0.1016" layer="94"/>
<wire x1="-4.2219" y1="-2.0754" x2="-4.3924" y2="-2.1778" width="0.1016" layer="94"/>
<wire x1="-4.3924" y1="-2.1778" x2="-4.3924" y2="-3.8834" width="0.1016" layer="94"/>
<wire x1="-4.3924" y1="-3.8834" x2="-4.2219" y2="-3.9857" width="0.1016" layer="94"/>
<wire x1="-3.6419" y1="-3.4059" x2="-3.642" y2="-2.6554" width="0.1016" layer="94"/>
<wire x1="-3.642" y1="-2.6554" x2="-4.2219" y2="-2.0756" width="0.1016" layer="94"/>
<wire x1="-3.6419" y1="-3.4059" x2="-4.2217" y2="-3.9858" width="0.1016" layer="94"/>
<wire x1="-2.0728" y1="-1.8708" x2="-2.6867" y2="-2.246" width="0.1016" layer="94"/>
<wire x1="-4.0173" y1="-1.8708" x2="-4.0172" y2="-1.8708" width="0.1016" layer="94"/>
<wire x1="-1.834" y1="-1.6662" x2="-1.6635" y2="-1.5638" width="0.1016" layer="94"/>
<wire x1="-1.6635" y1="-1.5638" x2="-1.6635" y2="0.1418" width="0.1016" layer="94"/>
<wire x1="-1.6635" y1="0.1418" x2="-1.834" y2="0.2441" width="0.1016" layer="94"/>
<wire x1="-2.414" y1="-0.3357" x2="-2.4139" y2="-1.0862" width="0.1016" layer="94"/>
<wire x1="-2.4139" y1="-1.0862" x2="-1.834" y2="-1.666" width="0.1016" layer="94"/>
<wire x1="-2.414" y1="-0.3357" x2="-1.8342" y2="0.2442" width="0.1016" layer="94"/>
<wire x1="0.0422" y1="0.4829" x2="0.1787" y2="0.6194" width="0.1016" layer="94"/>
<wire x1="0.1787" y1="0.6194" x2="1.8843" y2="0.6194" width="0.1016" layer="94"/>
<wire x1="1.8843" y1="0.6194" x2="2.0207" y2="0.4829" width="0.1016" layer="94"/>
<wire x1="1.4408" y1="-0.097" x2="0.6221" y2="-0.097" width="0.1016" layer="94"/>
<wire x1="0.6221" y1="-0.097" x2="0.0422" y2="0.4829" width="0.1016" layer="94"/>
<wire x1="-0.1625" y1="0.2442" x2="-0.333" y2="0.1418" width="0.1016" layer="94"/>
<wire x1="-0.333" y1="0.1418" x2="-0.333" y2="-1.5638" width="0.1016" layer="94"/>
<wire x1="-0.333" y1="-1.5638" x2="-0.1625" y2="-1.6661" width="0.1016" layer="94"/>
<wire x1="0.4175" y1="-1.0863" x2="0.4174" y2="-0.3358" width="0.1016" layer="94"/>
<wire x1="0.4174" y1="-0.3358" x2="-0.1625" y2="0.244" width="0.1016" layer="94"/>
<wire x1="0.4175" y1="-1.0863" x2="-0.1623" y2="-1.6662" width="0.1016" layer="94"/>
<wire x1="2.0207" y1="0.4829" x2="1.4408" y2="-0.097" width="0.1016" layer="94"/>
<wire x1="2.0207" y1="-4.2586" x2="1.8842" y2="-4.3951" width="0.1016" layer="94"/>
<wire x1="1.8842" y1="-4.3951" x2="0.1786" y2="-4.3951" width="0.1016" layer="94"/>
<wire x1="0.1786" y1="-4.3951" x2="0.0422" y2="-4.2586" width="0.1016" layer="94"/>
<wire x1="0.6221" y1="-3.6787" x2="1.4408" y2="-3.6787" width="0.1016" layer="94"/>
<wire x1="1.4408" y1="-3.6787" x2="2.0207" y2="-4.2586" width="0.1016" layer="94"/>
<wire x1="2.2254" y1="-4.0199" x2="2.3959" y2="-3.9175" width="0.1016" layer="94"/>
<wire x1="2.3959" y1="-3.9175" x2="2.3959" y2="-2.2119" width="0.1016" layer="94"/>
<wire x1="2.3959" y1="-2.2119" x2="2.2254" y2="-2.1096" width="0.1016" layer="94"/>
<wire x1="1.6454" y1="-2.6894" x2="1.6455" y2="-3.4399" width="0.1016" layer="94"/>
<wire x1="1.6455" y1="-3.4399" x2="2.2254" y2="-4.0197" width="0.1016" layer="94"/>
<wire x1="1.6454" y1="-2.6894" x2="2.2252" y2="-2.1095" width="0.1016" layer="94"/>
<wire x1="0.0422" y1="-4.2586" x2="0.6221" y2="-3.6787" width="0.1016" layer="94"/>
<wire x1="0.0422" y1="-1.8708" x2="0.6562" y2="-1.5296" width="0.1016" layer="94"/>
<wire x1="0.6562" y1="-1.5296" x2="1.3727" y2="-1.5297" width="0.1016" layer="94"/>
<wire x1="1.3727" y1="-1.5297" x2="1.9866" y2="-1.8708" width="0.1016" layer="94"/>
<wire x1="1.3727" y1="-2.246" x2="0.6563" y2="-2.246" width="0.1016" layer="94"/>
<wire x1="0.6563" y1="-2.246" x2="0.0421" y2="-1.8708" width="0.1016" layer="94"/>
<wire x1="-0.1625" y1="-2.0754" x2="-0.333" y2="-2.1778" width="0.1016" layer="94"/>
<wire x1="-0.333" y1="-2.1778" x2="-0.333" y2="-3.8834" width="0.1016" layer="94"/>
<wire x1="-0.333" y1="-3.8834" x2="-0.1625" y2="-3.9857" width="0.1016" layer="94"/>
<wire x1="0.4175" y1="-3.4059" x2="0.4174" y2="-2.6554" width="0.1016" layer="94"/>
<wire x1="0.4174" y1="-2.6554" x2="-0.1625" y2="-2.0756" width="0.1016" layer="94"/>
<wire x1="0.4175" y1="-3.4059" x2="-0.1623" y2="-3.9858" width="0.1016" layer="94"/>
<wire x1="1.9866" y1="-1.8708" x2="1.3727" y2="-2.246" width="0.1016" layer="94"/>
<wire x1="0.0421" y1="-1.8708" x2="0.0422" y2="-1.8708" width="0.1016" layer="94"/>
<wire x1="2.2254" y1="-1.6662" x2="2.3959" y2="-1.5638" width="0.1016" layer="94"/>
<wire x1="2.3959" y1="-1.5638" x2="2.3959" y2="0.1418" width="0.1016" layer="94"/>
<wire x1="2.3959" y1="0.1418" x2="2.2254" y2="0.2441" width="0.1016" layer="94"/>
<wire x1="1.6454" y1="-0.3357" x2="1.6455" y2="-1.0862" width="0.1016" layer="94"/>
<wire x1="1.6455" y1="-1.0862" x2="2.2254" y2="-1.666" width="0.1016" layer="94"/>
<wire x1="1.6454" y1="-0.3357" x2="2.2252" y2="0.2442" width="0.1016" layer="94"/>
<wire x1="4.1015" y1="0.4829" x2="4.238" y2="0.6194" width="0.1016" layer="94"/>
<wire x1="4.238" y1="0.6194" x2="5.9436" y2="0.6194" width="0.1016" layer="94"/>
<wire x1="5.9436" y1="0.6194" x2="6.08" y2="0.4829" width="0.1016" layer="94"/>
<wire x1="5.5001" y1="-0.097" x2="4.6814" y2="-0.097" width="0.1016" layer="94"/>
<wire x1="4.6814" y1="-0.097" x2="4.1015" y2="0.4829" width="0.1016" layer="94"/>
<wire x1="3.8968" y1="0.2442" x2="3.7263" y2="0.1418" width="0.1016" layer="94"/>
<wire x1="3.7263" y1="0.1418" x2="3.7263" y2="-1.5638" width="0.1016" layer="94"/>
<wire x1="3.7263" y1="-1.5638" x2="3.8968" y2="-1.6661" width="0.1016" layer="94"/>
<wire x1="4.4768" y1="-1.0863" x2="4.4767" y2="-0.3358" width="0.1016" layer="94"/>
<wire x1="4.4767" y1="-0.3358" x2="3.8968" y2="0.244" width="0.1016" layer="94"/>
<wire x1="4.4768" y1="-1.0863" x2="3.897" y2="-1.6662" width="0.1016" layer="94"/>
<wire x1="6.08" y1="0.4829" x2="5.5001" y2="-0.097" width="0.1016" layer="94"/>
<wire x1="6.08" y1="-4.2586" x2="5.9435" y2="-4.3951" width="0.1016" layer="94"/>
<wire x1="5.9435" y1="-4.3951" x2="4.2379" y2="-4.3951" width="0.1016" layer="94"/>
<wire x1="4.2379" y1="-4.3951" x2="4.1015" y2="-4.2586" width="0.1016" layer="94"/>
<wire x1="4.6814" y1="-3.6787" x2="5.5001" y2="-3.6787" width="0.1016" layer="94"/>
<wire x1="5.5001" y1="-3.6787" x2="6.08" y2="-4.2586" width="0.1016" layer="94"/>
<wire x1="6.2847" y1="-4.0199" x2="6.4552" y2="-3.9175" width="0.1016" layer="94"/>
<wire x1="6.4552" y1="-3.9175" x2="6.4552" y2="-2.2119" width="0.1016" layer="94"/>
<wire x1="6.4552" y1="-2.2119" x2="6.2847" y2="-2.1096" width="0.1016" layer="94"/>
<wire x1="5.7047" y1="-2.6894" x2="5.7048" y2="-3.4399" width="0.1016" layer="94"/>
<wire x1="5.7048" y1="-3.4399" x2="6.2847" y2="-4.0197" width="0.1016" layer="94"/>
<wire x1="5.7047" y1="-2.6894" x2="6.2845" y2="-2.1095" width="0.1016" layer="94"/>
<wire x1="4.1015" y1="-4.2586" x2="4.6814" y2="-3.6787" width="0.1016" layer="94"/>
<wire x1="4.1015" y1="-1.8708" x2="4.7155" y2="-1.5296" width="0.1016" layer="94"/>
<wire x1="4.7155" y1="-1.5296" x2="5.432" y2="-1.5297" width="0.1016" layer="94"/>
<wire x1="5.432" y1="-1.5297" x2="6.0459" y2="-1.8708" width="0.1016" layer="94"/>
<wire x1="5.432" y1="-2.246" x2="4.7156" y2="-2.246" width="0.1016" layer="94"/>
<wire x1="4.7156" y1="-2.246" x2="4.1014" y2="-1.8708" width="0.1016" layer="94"/>
<wire x1="3.8968" y1="-2.0754" x2="3.7263" y2="-2.1778" width="0.1016" layer="94"/>
<wire x1="3.7263" y1="-2.1778" x2="3.7263" y2="-3.8834" width="0.1016" layer="94"/>
<wire x1="3.7263" y1="-3.8834" x2="3.8968" y2="-3.9857" width="0.1016" layer="94"/>
<wire x1="4.4768" y1="-3.4059" x2="4.4767" y2="-2.6554" width="0.1016" layer="94"/>
<wire x1="4.4767" y1="-2.6554" x2="3.8968" y2="-2.0756" width="0.1016" layer="94"/>
<wire x1="4.4768" y1="-3.4059" x2="3.897" y2="-3.9858" width="0.1016" layer="94"/>
<wire x1="6.0459" y1="-1.8708" x2="5.432" y2="-2.246" width="0.1016" layer="94"/>
<wire x1="4.1014" y1="-1.8708" x2="4.1015" y2="-1.8708" width="0.1016" layer="94"/>
<wire x1="6.2847" y1="-1.6662" x2="6.4552" y2="-1.5638" width="0.1016" layer="94"/>
<wire x1="6.4552" y1="-1.5638" x2="6.4552" y2="0.1418" width="0.1016" layer="94"/>
<wire x1="6.4552" y1="0.1418" x2="6.2847" y2="0.2441" width="0.1016" layer="94"/>
<wire x1="5.7047" y1="-0.3357" x2="5.7048" y2="-1.0862" width="0.1016" layer="94"/>
<wire x1="5.7048" y1="-1.0862" x2="6.2847" y2="-1.666" width="0.1016" layer="94"/>
<wire x1="5.7047" y1="-0.3357" x2="6.2845" y2="0.2442" width="0.1016" layer="94"/>
<wire x1="8.1609" y1="0.4829" x2="8.2974" y2="0.6194" width="0.1016" layer="94"/>
<wire x1="8.2974" y1="0.6194" x2="10.003" y2="0.6194" width="0.1016" layer="94"/>
<wire x1="10.003" y1="0.6194" x2="10.1394" y2="0.4829" width="0.1016" layer="94"/>
<wire x1="9.5595" y1="-0.097" x2="8.7408" y2="-0.097" width="0.1016" layer="94"/>
<wire x1="8.7408" y1="-0.097" x2="8.1609" y2="0.4829" width="0.1016" layer="94"/>
<wire x1="7.9562" y1="0.2442" x2="7.7857" y2="0.1418" width="0.1016" layer="94"/>
<wire x1="7.7857" y1="0.1418" x2="7.7857" y2="-1.5638" width="0.1016" layer="94"/>
<wire x1="7.7857" y1="-1.5638" x2="7.9562" y2="-1.6661" width="0.1016" layer="94"/>
<wire x1="8.5362" y1="-1.0863" x2="8.5361" y2="-0.3358" width="0.1016" layer="94"/>
<wire x1="8.5361" y1="-0.3358" x2="7.9562" y2="0.244" width="0.1016" layer="94"/>
<wire x1="8.5362" y1="-1.0863" x2="7.9564" y2="-1.6662" width="0.1016" layer="94"/>
<wire x1="10.1394" y1="0.4829" x2="9.5595" y2="-0.097" width="0.1016" layer="94"/>
<wire x1="10.1394" y1="-4.2586" x2="10.0029" y2="-4.3951" width="0.1016" layer="94"/>
<wire x1="10.0029" y1="-4.3951" x2="8.2973" y2="-4.3951" width="0.1016" layer="94"/>
<wire x1="8.2973" y1="-4.3951" x2="8.1609" y2="-4.2586" width="0.1016" layer="94"/>
<wire x1="8.7408" y1="-3.6787" x2="9.5595" y2="-3.6787" width="0.1016" layer="94"/>
<wire x1="9.5595" y1="-3.6787" x2="10.1394" y2="-4.2586" width="0.1016" layer="94"/>
<wire x1="10.3441" y1="-4.0199" x2="10.5146" y2="-3.9175" width="0.1016" layer="94"/>
<wire x1="10.5146" y1="-3.9175" x2="10.5146" y2="-2.2119" width="0.1016" layer="94"/>
<wire x1="10.5146" y1="-2.2119" x2="10.3441" y2="-2.1096" width="0.1016" layer="94"/>
<wire x1="9.7641" y1="-2.6894" x2="9.7642" y2="-3.4399" width="0.1016" layer="94"/>
<wire x1="9.7642" y1="-3.4399" x2="10.3441" y2="-4.0197" width="0.1016" layer="94"/>
<wire x1="9.7641" y1="-2.6894" x2="10.3439" y2="-2.1095" width="0.1016" layer="94"/>
<wire x1="8.1609" y1="-4.2586" x2="8.7408" y2="-3.6787" width="0.1016" layer="94"/>
<wire x1="8.1609" y1="-1.8708" x2="8.7749" y2="-1.5296" width="0.1016" layer="94"/>
<wire x1="8.7749" y1="-1.5296" x2="9.4914" y2="-1.5297" width="0.1016" layer="94"/>
<wire x1="9.4914" y1="-1.5297" x2="10.1053" y2="-1.8708" width="0.1016" layer="94"/>
<wire x1="9.4914" y1="-2.246" x2="8.775" y2="-2.246" width="0.1016" layer="94"/>
<wire x1="8.775" y1="-2.246" x2="8.1608" y2="-1.8708" width="0.1016" layer="94"/>
<wire x1="7.9562" y1="-2.0754" x2="7.7857" y2="-2.1778" width="0.1016" layer="94"/>
<wire x1="7.7857" y1="-2.1778" x2="7.7857" y2="-3.8834" width="0.1016" layer="94"/>
<wire x1="7.7857" y1="-3.8834" x2="7.9562" y2="-3.9857" width="0.1016" layer="94"/>
<wire x1="8.5362" y1="-3.4059" x2="8.5361" y2="-2.6554" width="0.1016" layer="94"/>
<wire x1="8.5361" y1="-2.6554" x2="7.9562" y2="-2.0756" width="0.1016" layer="94"/>
<wire x1="8.5362" y1="-3.4059" x2="7.9564" y2="-3.9858" width="0.1016" layer="94"/>
<wire x1="10.1053" y1="-1.8708" x2="9.4914" y2="-2.246" width="0.1016" layer="94"/>
<wire x1="8.1608" y1="-1.8708" x2="8.1609" y2="-1.8708" width="0.1016" layer="94"/>
<wire x1="10.3441" y1="-1.6662" x2="10.5146" y2="-1.5638" width="0.1016" layer="94"/>
<wire x1="10.5146" y1="-1.5638" x2="10.5146" y2="0.1418" width="0.1016" layer="94"/>
<wire x1="10.5146" y1="0.1418" x2="10.3441" y2="0.2441" width="0.1016" layer="94"/>
<wire x1="9.7641" y1="-0.3357" x2="9.7642" y2="-1.0862" width="0.1016" layer="94"/>
<wire x1="9.7642" y1="-1.0862" x2="10.3441" y2="-1.666" width="0.1016" layer="94"/>
<wire x1="9.7641" y1="-0.3357" x2="10.3439" y2="0.2442" width="0.1016" layer="94"/>
<wire x1="12.2202" y1="0.4829" x2="12.3567" y2="0.6194" width="0.1016" layer="94"/>
<wire x1="12.3567" y1="0.6194" x2="14.0623" y2="0.6194" width="0.1016" layer="94"/>
<wire x1="14.0623" y1="0.6194" x2="14.1987" y2="0.4829" width="0.1016" layer="94"/>
<wire x1="13.6188" y1="-0.097" x2="12.8001" y2="-0.097" width="0.1016" layer="94"/>
<wire x1="12.8001" y1="-0.097" x2="12.2202" y2="0.4829" width="0.1016" layer="94"/>
<wire x1="12.0155" y1="0.2442" x2="11.845" y2="0.1418" width="0.1016" layer="94"/>
<wire x1="11.845" y1="0.1418" x2="11.845" y2="-1.5638" width="0.1016" layer="94"/>
<wire x1="11.845" y1="-1.5638" x2="12.0155" y2="-1.6661" width="0.1016" layer="94"/>
<wire x1="12.5955" y1="-1.0863" x2="12.5954" y2="-0.3358" width="0.1016" layer="94"/>
<wire x1="12.5954" y1="-0.3358" x2="12.0155" y2="0.244" width="0.1016" layer="94"/>
<wire x1="12.5955" y1="-1.0863" x2="12.0157" y2="-1.6662" width="0.1016" layer="94"/>
<wire x1="14.1987" y1="0.4829" x2="13.6188" y2="-0.097" width="0.1016" layer="94"/>
<wire x1="14.1987" y1="-4.2586" x2="14.0622" y2="-4.3951" width="0.1016" layer="94"/>
<wire x1="14.0622" y1="-4.3951" x2="12.3566" y2="-4.3951" width="0.1016" layer="94"/>
<wire x1="12.3566" y1="-4.3951" x2="12.2202" y2="-4.2586" width="0.1016" layer="94"/>
<wire x1="12.8001" y1="-3.6787" x2="13.6188" y2="-3.6787" width="0.1016" layer="94"/>
<wire x1="13.6188" y1="-3.6787" x2="14.1987" y2="-4.2586" width="0.1016" layer="94"/>
<wire x1="14.4034" y1="-4.0199" x2="14.5739" y2="-3.9175" width="0.1016" layer="94"/>
<wire x1="14.5739" y1="-3.9175" x2="14.5739" y2="-2.2119" width="0.1016" layer="94"/>
<wire x1="14.5739" y1="-2.2119" x2="14.4034" y2="-2.1096" width="0.1016" layer="94"/>
<wire x1="13.8234" y1="-2.6894" x2="13.8235" y2="-3.4399" width="0.1016" layer="94"/>
<wire x1="13.8235" y1="-3.4399" x2="14.4034" y2="-4.0197" width="0.1016" layer="94"/>
<wire x1="13.8234" y1="-2.6894" x2="14.4032" y2="-2.1095" width="0.1016" layer="94"/>
<wire x1="12.2202" y1="-4.2586" x2="12.8001" y2="-3.6787" width="0.1016" layer="94"/>
<wire x1="12.2202" y1="-1.8708" x2="12.8342" y2="-1.5296" width="0.1016" layer="94"/>
<wire x1="12.8342" y1="-1.5296" x2="13.5507" y2="-1.5297" width="0.1016" layer="94"/>
<wire x1="13.5507" y1="-1.5297" x2="14.1646" y2="-1.8708" width="0.1016" layer="94"/>
<wire x1="13.5507" y1="-2.246" x2="12.8343" y2="-2.246" width="0.1016" layer="94"/>
<wire x1="12.8343" y1="-2.246" x2="12.2201" y2="-1.8708" width="0.1016" layer="94"/>
<wire x1="12.0155" y1="-2.0754" x2="11.845" y2="-2.1778" width="0.1016" layer="94"/>
<wire x1="11.845" y1="-2.1778" x2="11.845" y2="-3.8834" width="0.1016" layer="94"/>
<wire x1="11.845" y1="-3.8834" x2="12.0155" y2="-3.9857" width="0.1016" layer="94"/>
<wire x1="12.5955" y1="-3.4059" x2="12.5954" y2="-2.6554" width="0.1016" layer="94"/>
<wire x1="12.5954" y1="-2.6554" x2="12.0155" y2="-2.0756" width="0.1016" layer="94"/>
<wire x1="12.5955" y1="-3.4059" x2="12.0157" y2="-3.9858" width="0.1016" layer="94"/>
<wire x1="14.1646" y1="-1.8708" x2="13.5507" y2="-2.246" width="0.1016" layer="94"/>
<wire x1="12.2201" y1="-1.8708" x2="12.2202" y2="-1.8708" width="0.1016" layer="94"/>
<wire x1="14.4034" y1="-1.6662" x2="14.5739" y2="-1.5638" width="0.1016" layer="94"/>
<wire x1="14.5739" y1="-1.5638" x2="14.5739" y2="0.1418" width="0.1016" layer="94"/>
<wire x1="14.5739" y1="0.1418" x2="14.4034" y2="0.2441" width="0.1016" layer="94"/>
<wire x1="13.8234" y1="-0.3357" x2="13.8235" y2="-1.0862" width="0.1016" layer="94"/>
<wire x1="13.8235" y1="-1.0862" x2="14.4034" y2="-1.666" width="0.1016" layer="94"/>
<wire x1="13.8234" y1="-0.3357" x2="14.4032" y2="0.2442" width="0.1016" layer="94"/>
<wire x1="16.2796" y1="0.4829" x2="16.4161" y2="0.6194" width="0.1016" layer="94"/>
<wire x1="16.4161" y1="0.6194" x2="18.1217" y2="0.6194" width="0.1016" layer="94"/>
<wire x1="18.1217" y1="0.6194" x2="18.2581" y2="0.4829" width="0.1016" layer="94"/>
<wire x1="17.6782" y1="-0.097" x2="16.8595" y2="-0.097" width="0.1016" layer="94"/>
<wire x1="16.8595" y1="-0.097" x2="16.2796" y2="0.4829" width="0.1016" layer="94"/>
<wire x1="16.0749" y1="0.2442" x2="15.9044" y2="0.1418" width="0.1016" layer="94"/>
<wire x1="15.9044" y1="0.1418" x2="15.9044" y2="-1.5638" width="0.1016" layer="94"/>
<wire x1="15.9044" y1="-1.5638" x2="16.0749" y2="-1.6661" width="0.1016" layer="94"/>
<wire x1="16.6549" y1="-1.0863" x2="16.6548" y2="-0.3358" width="0.1016" layer="94"/>
<wire x1="16.6548" y1="-0.3358" x2="16.0749" y2="0.244" width="0.1016" layer="94"/>
<wire x1="16.6549" y1="-1.0863" x2="16.0751" y2="-1.6662" width="0.1016" layer="94"/>
<wire x1="18.2581" y1="0.4829" x2="17.6782" y2="-0.097" width="0.1016" layer="94"/>
<wire x1="18.2581" y1="-4.2586" x2="18.1216" y2="-4.3951" width="0.1016" layer="94"/>
<wire x1="18.1216" y1="-4.3951" x2="16.416" y2="-4.3951" width="0.1016" layer="94"/>
<wire x1="16.416" y1="-4.3951" x2="16.2796" y2="-4.2586" width="0.1016" layer="94"/>
<wire x1="16.8595" y1="-3.6787" x2="17.6782" y2="-3.6787" width="0.1016" layer="94"/>
<wire x1="17.6782" y1="-3.6787" x2="18.2581" y2="-4.2586" width="0.1016" layer="94"/>
<wire x1="18.4628" y1="-4.0199" x2="18.6333" y2="-3.9175" width="0.1016" layer="94"/>
<wire x1="18.6333" y1="-3.9175" x2="18.6333" y2="-2.2119" width="0.1016" layer="94"/>
<wire x1="18.6333" y1="-2.2119" x2="18.4628" y2="-2.1096" width="0.1016" layer="94"/>
<wire x1="17.8828" y1="-2.6894" x2="17.8829" y2="-3.4399" width="0.1016" layer="94"/>
<wire x1="17.8829" y1="-3.4399" x2="18.4628" y2="-4.0197" width="0.1016" layer="94"/>
<wire x1="17.8828" y1="-2.6894" x2="18.4626" y2="-2.1095" width="0.1016" layer="94"/>
<wire x1="16.2796" y1="-4.2586" x2="16.8595" y2="-3.6787" width="0.1016" layer="94"/>
<wire x1="16.2796" y1="-1.8708" x2="16.8936" y2="-1.5296" width="0.1016" layer="94"/>
<wire x1="16.8936" y1="-1.5296" x2="17.6101" y2="-1.5297" width="0.1016" layer="94"/>
<wire x1="17.6101" y1="-1.5297" x2="18.224" y2="-1.8708" width="0.1016" layer="94"/>
<wire x1="17.6101" y1="-2.246" x2="16.8937" y2="-2.246" width="0.1016" layer="94"/>
<wire x1="16.8937" y1="-2.246" x2="16.2795" y2="-1.8708" width="0.1016" layer="94"/>
<wire x1="16.0749" y1="-2.0754" x2="15.9044" y2="-2.1778" width="0.1016" layer="94"/>
<wire x1="15.9044" y1="-2.1778" x2="15.9044" y2="-3.8834" width="0.1016" layer="94"/>
<wire x1="15.9044" y1="-3.8834" x2="16.0749" y2="-3.9857" width="0.1016" layer="94"/>
<wire x1="16.6549" y1="-3.4059" x2="16.6548" y2="-2.6554" width="0.1016" layer="94"/>
<wire x1="16.6548" y1="-2.6554" x2="16.0749" y2="-2.0756" width="0.1016" layer="94"/>
<wire x1="16.6549" y1="-3.4059" x2="16.0751" y2="-3.9858" width="0.1016" layer="94"/>
<wire x1="18.224" y1="-1.8708" x2="17.6101" y2="-2.246" width="0.1016" layer="94"/>
<wire x1="16.2795" y1="-1.8708" x2="16.2796" y2="-1.8708" width="0.1016" layer="94"/>
<wire x1="18.4628" y1="-1.6662" x2="18.6333" y2="-1.5638" width="0.1016" layer="94"/>
<wire x1="18.6333" y1="-1.5638" x2="18.6333" y2="0.1418" width="0.1016" layer="94"/>
<wire x1="18.6333" y1="0.1418" x2="18.4628" y2="0.2441" width="0.1016" layer="94"/>
<wire x1="17.8828" y1="-0.3357" x2="17.8829" y2="-1.0862" width="0.1016" layer="94"/>
<wire x1="17.8829" y1="-1.0862" x2="18.4628" y2="-1.666" width="0.1016" layer="94"/>
<wire x1="17.8828" y1="-0.3357" x2="18.4626" y2="0.2442" width="0.1016" layer="94"/>
<wire x1="6.7964" y1="-2.6213" x2="7.4105" y2="-2.6213" width="0.1016" layer="94"/>
<wire x1="7.4105" y1="-2.6213" x2="7.4105" y2="-3.2012" width="0.1016" layer="94"/>
<wire x1="7.4105" y1="-3.2012" x2="6.7964" y2="-3.2012" width="0.1016" layer="94"/>
<wire x1="6.7964" y1="-3.2012" x2="6.7964" y2="-2.6213" width="0.1016" layer="94"/>
<wire x1="6.7964" y1="-0.5745" x2="7.4105" y2="-0.5745" width="0.1016" layer="94"/>
<wire x1="7.4105" y1="-0.5745" x2="7.4105" y2="-1.1886" width="0.1016" layer="94"/>
<wire x1="7.4105" y1="-1.1886" x2="6.7964" y2="-1.1886" width="0.1016" layer="94"/>
<wire x1="6.7964" y1="-1.1886" x2="6.7964" y2="-0.5745" width="0.1016" layer="94"/>
<wire x1="-1.3223" y1="-2.6213" x2="-0.7082" y2="-2.6213" width="0.1016" layer="94"/>
<wire x1="-0.7082" y1="-2.6213" x2="-0.7082" y2="-3.2012" width="0.1016" layer="94"/>
<wire x1="-0.7082" y1="-3.2012" x2="-1.3223" y2="-3.2012" width="0.1016" layer="94"/>
<wire x1="-1.3223" y1="-3.2012" x2="-1.3223" y2="-2.6213" width="0.1016" layer="94"/>
<wire x1="-1.3223" y1="-0.5745" x2="-0.7082" y2="-0.5745" width="0.1016" layer="94"/>
<wire x1="-0.7082" y1="-0.5745" x2="-0.7082" y2="-1.1886" width="0.1016" layer="94"/>
<wire x1="-0.7082" y1="-1.1886" x2="-1.3223" y2="-1.1886" width="0.1016" layer="94"/>
<wire x1="-1.3223" y1="-1.1886" x2="-1.3223" y2="-0.5745" width="0.1016" layer="94"/>
<wire x1="-6.405" y1="5.7362" x2="-5.1769" y2="5.7362" width="0.1016" layer="94"/>
<wire x1="-6.3709" y1="4.3376" x2="-5.7227" y2="4.3376" width="0.1016" layer="94"/>
<wire x1="-16.0929" y1="2.8708" x2="-15.1718" y2="2.8708" width="0.1016" layer="94"/>
<wire x1="-15.1718" y1="2.8708" x2="-15.1718" y2="2.5638" width="0.1016" layer="94"/>
<wire x1="-15.1718" y1="2.5638" x2="-15.5129" y2="2.5638" width="0.1016" layer="94"/>
<wire x1="-15.5129" y1="2.5638" x2="-15.5129" y2="1.6428" width="0.1016" layer="94"/>
<wire x1="-15.5129" y1="1.6428" x2="-15.7517" y2="1.6428" width="0.1016" layer="94"/>
<wire x1="-15.7517" y1="1.6428" x2="-15.7517" y2="2.5638" width="0.1016" layer="94"/>
<wire x1="-15.7517" y1="2.5638" x2="-16.0929" y2="2.5638" width="0.1016" layer="94"/>
<wire x1="-16.0929" y1="2.5638" x2="-16.0929" y2="2.8708" width="0.1016" layer="94"/>
<wire x1="-13.2274" y1="2.8708" x2="-13.2274" y2="1.6428" width="0.1016" layer="94"/>
<wire x1="-13.2274" y1="1.6428" x2="-12.9545" y2="1.6428" width="0.1016" layer="94"/>
<wire x1="-12.9545" y1="1.6428" x2="-12.9545" y2="2.1203" width="0.1016" layer="94"/>
<wire x1="-12.9545" y1="2.1203" x2="-12.8522" y2="2.1203" width="0.1016" layer="94"/>
<wire x1="-12.8522" y1="2.1203" x2="-12.6134" y2="1.6428" width="0.1016" layer="94"/>
<wire x1="-12.6134" y1="1.6428" x2="-12.3064" y2="1.6428" width="0.1016" layer="94"/>
<wire x1="-12.3064" y1="1.6428" x2="-12.5111" y2="2.0862" width="0.1016" layer="94"/>
<wire x1="-12.5111" y1="2.0862" x2="-12.5793" y2="2.1544" width="0.1016" layer="94"/>
<wire x1="-12.5793" y1="2.1544" x2="-12.5793" y2="2.2227" width="0.1016" layer="94"/>
<wire x1="-12.5793" y1="2.2227" x2="-12.5452" y2="2.2227" width="0.1016" layer="94"/>
<wire x1="-12.5452" y1="2.2227" x2="-12.3405" y2="2.4273" width="0.1016" layer="94" curve="90.084032"/>
<wire x1="-12.3405" y1="2.4273" x2="-12.3405" y2="2.5638" width="0.1016" layer="94" curve="0.056021"/>
<wire x1="-12.3405" y1="2.5638" x2="-12.6475" y2="2.8708" width="0.1016" layer="94" curve="89.925396"/>
<wire x1="-12.6475" y1="2.8708" x2="-13.2274" y2="2.8708" width="0.1016" layer="94" curve="0.074565"/>
<wire x1="-12.9204" y1="2.5979" x2="-12.9204" y2="2.3932" width="0.1016" layer="94"/>
<wire x1="-12.9204" y1="2.3932" x2="-12.784" y2="2.3932" width="0.1016" layer="94"/>
<wire x1="-12.784" y1="2.3932" x2="-12.7499" y2="2.5979" width="0.1016" layer="94" curve="161.193388"/>
<wire x1="-12.7499" y1="2.5979" x2="-12.9204" y2="2.5979" width="0.1016" layer="94"/>
<wire x1="-14.9671" y1="2.4615" x2="-14.6943" y2="2.0521" width="0.1016" layer="94"/>
<wire x1="-14.6943" y1="2.0521" x2="-15.0013" y2="1.6428" width="0.1016" layer="94"/>
<wire x1="-15.0013" y1="1.6428" x2="-14.7284" y2="1.6428" width="0.1016" layer="94"/>
<wire x1="-14.7284" y1="1.6428" x2="-14.5578" y2="1.8815" width="0.1016" layer="94"/>
<wire x1="-14.5578" y1="1.8815" x2="-14.4214" y2="1.6428" width="0.1016" layer="94"/>
<wire x1="-14.4214" y1="1.6428" x2="-14.1485" y2="1.6428" width="0.1016" layer="94"/>
<wire x1="-14.1485" y1="1.6428" x2="-14.4214" y2="2.0521" width="0.1016" layer="94"/>
<wire x1="-14.4214" y1="2.0521" x2="-14.1485" y2="2.4615" width="0.1016" layer="94"/>
<wire x1="-14.1485" y1="2.4615" x2="-14.3872" y2="2.4615" width="0.1016" layer="94"/>
<wire x1="-14.3872" y1="2.4615" x2="-14.5578" y2="2.2227" width="0.1016" layer="94"/>
<wire x1="-14.5578" y1="2.2227" x2="-14.7284" y2="2.4615" width="0.1016" layer="94"/>
<wire x1="-14.7284" y1="2.4615" x2="-14.9671" y2="2.4615" width="0.1016" layer="94"/>
<wire x1="-12.0676" y1="2.4615" x2="-11.7948" y2="2.0521" width="0.1016" layer="94"/>
<wire x1="-11.7948" y1="2.0521" x2="-12.1018" y2="1.6428" width="0.1016" layer="94"/>
<wire x1="-12.1018" y1="1.6428" x2="-11.8289" y2="1.6428" width="0.1016" layer="94"/>
<wire x1="-11.8289" y1="1.6428" x2="-11.6583" y2="1.8815" width="0.1016" layer="94"/>
<wire x1="-11.6583" y1="1.8815" x2="-11.5219" y2="1.6428" width="0.1016" layer="94"/>
<wire x1="-11.5219" y1="1.6428" x2="-11.249" y2="1.6428" width="0.1016" layer="94"/>
<wire x1="-11.249" y1="1.6428" x2="-11.5219" y2="2.0521" width="0.1016" layer="94"/>
<wire x1="-11.5219" y1="2.0521" x2="-11.249" y2="2.4615" width="0.1016" layer="94"/>
<wire x1="-11.249" y1="2.4615" x2="-11.4877" y2="2.4615" width="0.1016" layer="94"/>
<wire x1="-11.4877" y1="2.4615" x2="-11.6583" y2="2.2227" width="0.1016" layer="94"/>
<wire x1="-11.6583" y1="2.2227" x2="-11.8289" y2="2.4615" width="0.1016" layer="94"/>
<wire x1="-11.8289" y1="2.4615" x2="-12.0676" y2="2.4615" width="0.1016" layer="94"/>
<circle x="-9.134" y="-4.0881" radius="0.3144" width="0.1016" layer="94"/>
<circle x="-5.0747" y="-4.0881" radius="0.3144" width="0.1016" layer="94"/>
<circle x="3.044" y="-4.0881" radius="0.3144" width="0.1016" layer="94"/>
<circle x="11.1627" y="-4.0881" radius="0.3144" width="0.1016" layer="94"/>
<circle x="15.2221" y="-4.0881" radius="0.3144" width="0.1016" layer="94"/>
<text x="-19.05" y="-5.08" size="1.778" layer="95" rot="R90">&gt;NAME</text>
<text x="22.86" y="-5.08" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<pin name="1" x="-15.24" y="-7.62" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="2" x="-12.7" y="-7.62" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="3" x="-10.16" y="-7.62" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="4" x="-7.62" y="-7.62" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="5" x="-5.08" y="-7.62" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="6" x="-2.54" y="-7.62" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="7" x="0" y="-7.62" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="8" x="2.54" y="-7.62" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="9" x="5.08" y="-7.62" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="10" x="7.62" y="-7.62" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="11" x="10.16" y="-7.62" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="12" x="12.7" y="-7.62" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="13" x="15.24" y="-7.62" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="14" x="17.78" y="-7.62" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="15" x="15.24" y="10.16" visible="pad" length="short" direction="pas" rot="R270"/>
<pin name="16" x="12.7" y="10.16" visible="pad" length="short" direction="pas" rot="R270"/>
<pin name="17" x="10.16" y="10.16" visible="pad" length="short" direction="pas" rot="R270"/>
<pin name="18" x="7.62" y="10.16" visible="pad" length="short" direction="pas" rot="R270"/>
<pin name="19" x="5.08" y="10.16" visible="pad" length="short" direction="pas" rot="R270"/>
<pin name="20" x="2.54" y="10.16" visible="pad" length="short" direction="pas" rot="R270"/>
<pin name="21" x="0" y="10.16" visible="pad" length="short" direction="pas" rot="R270"/>
<pin name="22" x="-2.54" y="10.16" visible="pad" length="short" direction="pas" rot="R270"/>
<pin name="23" x="-5.08" y="10.16" visible="pad" length="short" direction="pas" rot="R270"/>
<pin name="24" x="-7.62" y="10.16" visible="pad" length="short" direction="pas" rot="R270"/>
<pin name="25" x="-10.16" y="10.16" visible="pad" length="short" direction="pas" rot="R270"/>
<pin name="26" x="-12.7" y="10.16" visible="pad" length="short" direction="pas" rot="R270"/>
</symbol>
<symbol name="TUXGR_16X2_R2">
<wire x1="-20.32" y1="-7.62" x2="22.86" y2="-7.62" width="0.2032" layer="94"/>
<wire x1="22.86" y1="-7.62" x2="22.86" y2="12.7" width="0.2032" layer="94"/>
<wire x1="22.86" y1="12.7" x2="-20.32" y2="12.7" width="0.2032" layer="94"/>
<wire x1="-20.32" y1="12.7" x2="-20.32" y2="-7.62" width="0.2032" layer="94"/>
<text x="-10.16" y="10.668" size="1.524" layer="94">LCD DISPLAY 16x2</text>
<text x="-20.32" y="13.97" size="1.778" layer="95">&gt;NAME</text>
<text x="-1.27" y="13.97" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="-19.05" y1="6.604" x2="-16.764" y2="10.16" layer="94"/>
<rectangle x1="-19.05" y1="2.54" x2="-16.764" y2="6.096" layer="94"/>
<rectangle x1="-16.51" y1="6.604" x2="-14.224" y2="10.16" layer="94"/>
<rectangle x1="-16.51" y1="2.54" x2="-14.224" y2="6.096" layer="94"/>
<rectangle x1="-13.97" y1="6.604" x2="-11.684" y2="10.16" layer="94"/>
<rectangle x1="-13.97" y1="2.54" x2="-11.684" y2="6.096" layer="94"/>
<rectangle x1="-11.43" y1="6.604" x2="-9.144" y2="10.16" layer="94"/>
<rectangle x1="-11.43" y1="2.54" x2="-9.144" y2="6.096" layer="94"/>
<rectangle x1="-8.89" y1="6.604" x2="-6.604" y2="10.16" layer="94"/>
<rectangle x1="-8.89" y1="2.54" x2="-6.604" y2="6.096" layer="94"/>
<rectangle x1="-6.35" y1="6.604" x2="-4.064" y2="10.16" layer="94"/>
<rectangle x1="-6.35" y1="2.54" x2="-4.064" y2="6.096" layer="94"/>
<rectangle x1="-3.81" y1="6.604" x2="-1.524" y2="10.16" layer="94"/>
<rectangle x1="-3.81" y1="2.54" x2="-1.524" y2="6.096" layer="94"/>
<rectangle x1="-1.27" y1="6.604" x2="1.016" y2="10.16" layer="94"/>
<rectangle x1="-1.27" y1="2.54" x2="1.016" y2="6.096" layer="94"/>
<rectangle x1="1.27" y1="6.604" x2="3.556" y2="10.16" layer="94"/>
<rectangle x1="1.27" y1="2.54" x2="3.556" y2="6.096" layer="94"/>
<rectangle x1="3.81" y1="6.604" x2="6.096" y2="10.16" layer="94"/>
<rectangle x1="3.81" y1="2.54" x2="6.096" y2="6.096" layer="94"/>
<rectangle x1="6.35" y1="6.604" x2="8.636" y2="10.16" layer="94"/>
<rectangle x1="6.35" y1="2.54" x2="8.636" y2="6.096" layer="94"/>
<rectangle x1="8.89" y1="6.604" x2="11.176" y2="10.16" layer="94"/>
<rectangle x1="8.89" y1="2.54" x2="11.176" y2="6.096" layer="94"/>
<rectangle x1="11.43" y1="6.604" x2="13.716" y2="10.16" layer="94"/>
<rectangle x1="11.43" y1="2.54" x2="13.716" y2="6.096" layer="94"/>
<rectangle x1="13.97" y1="6.604" x2="16.256" y2="10.16" layer="94"/>
<rectangle x1="13.97" y1="2.54" x2="16.256" y2="6.096" layer="94"/>
<rectangle x1="16.51" y1="6.604" x2="18.796" y2="10.16" layer="94"/>
<rectangle x1="16.51" y1="2.54" x2="18.796" y2="6.096" layer="94"/>
<rectangle x1="19.05" y1="6.604" x2="21.336" y2="10.16" layer="94"/>
<rectangle x1="19.05" y1="2.54" x2="21.336" y2="6.096" layer="94"/>
<pin name="GND" x="-17.78" y="-10.16" length="short" direction="pwr" rot="R90"/>
<pin name="VCC" x="-15.24" y="-10.16" length="short" direction="pwr" rot="R90"/>
<pin name="CONTR" x="-12.7" y="-10.16" length="short" direction="in" rot="R90"/>
<pin name="RS" x="-10.16" y="-10.16" length="short" direction="in" rot="R90"/>
<pin name="R/W" x="-7.62" y="-10.16" length="short" direction="in" rot="R90"/>
<pin name="E" x="-5.08" y="-10.16" length="short" direction="in" rot="R90"/>
<pin name="D0" x="-2.54" y="-10.16" length="short" direction="in" rot="R90"/>
<pin name="D1" x="0" y="-10.16" length="short" direction="in" rot="R90"/>
<pin name="D2" x="2.54" y="-10.16" length="short" direction="in" rot="R90"/>
<pin name="D3" x="5.08" y="-10.16" length="short" direction="in" rot="R90"/>
<pin name="D4" x="7.62" y="-10.16" length="short" direction="in" rot="R90"/>
<pin name="D5" x="10.16" y="-10.16" length="short" direction="in" rot="R90"/>
<pin name="D6" x="12.7" y="-10.16" length="short" direction="in" rot="R90"/>
<pin name="D7" x="15.24" y="-10.16" length="short" direction="in" rot="R90"/>
<pin name="NC@1" x="17.78" y="-10.16" length="short" direction="nc" rot="R90"/>
<pin name="NC@2" x="20.32" y="-10.16" length="short" direction="nc" rot="R90"/>
</symbol>
<symbol name="TUXGR_20X2">
<wire x1="-26.67" y1="-7.62" x2="26.67" y2="-7.62" width="0.2032" layer="94"/>
<wire x1="26.67" y1="-7.62" x2="26.67" y2="12.7" width="0.2032" layer="94"/>
<wire x1="26.67" y1="12.7" x2="-26.67" y2="12.7" width="0.2032" layer="94"/>
<wire x1="-26.67" y1="12.7" x2="-26.67" y2="-7.62" width="0.2032" layer="94"/>
<text x="-17.78" y="10.668" size="1.524" layer="94">LCD DISPLAY 20x2</text>
<text x="-25.4" y="13.97" size="1.778" layer="95">&gt;NAME</text>
<text x="-10.16" y="13.97" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="-25.4" y1="6.604" x2="-23.114" y2="10.16" layer="94"/>
<rectangle x1="-25.4" y1="2.54" x2="-23.114" y2="6.096" layer="94"/>
<rectangle x1="-22.86" y1="6.604" x2="-20.574" y2="10.16" layer="94"/>
<rectangle x1="-22.86" y1="2.54" x2="-20.574" y2="6.096" layer="94"/>
<rectangle x1="-20.32" y1="6.604" x2="-18.034" y2="10.16" layer="94"/>
<rectangle x1="-20.32" y1="2.54" x2="-18.034" y2="6.096" layer="94"/>
<rectangle x1="-17.78" y1="6.604" x2="-15.494" y2="10.16" layer="94"/>
<rectangle x1="-17.78" y1="2.54" x2="-15.494" y2="6.096" layer="94"/>
<rectangle x1="-15.24" y1="6.604" x2="-12.954" y2="10.16" layer="94"/>
<rectangle x1="-15.24" y1="2.54" x2="-12.954" y2="6.096" layer="94"/>
<rectangle x1="-12.7" y1="6.604" x2="-10.414" y2="10.16" layer="94"/>
<rectangle x1="-12.7" y1="2.54" x2="-10.414" y2="6.096" layer="94"/>
<rectangle x1="-10.16" y1="6.604" x2="-7.874" y2="10.16" layer="94"/>
<rectangle x1="-10.16" y1="2.54" x2="-7.874" y2="6.096" layer="94"/>
<rectangle x1="-7.62" y1="6.604" x2="-5.334" y2="10.16" layer="94"/>
<rectangle x1="-7.62" y1="2.54" x2="-5.334" y2="6.096" layer="94"/>
<rectangle x1="-5.08" y1="6.604" x2="-2.794" y2="10.16" layer="94"/>
<rectangle x1="-5.08" y1="2.54" x2="-2.794" y2="6.096" layer="94"/>
<rectangle x1="-2.54" y1="6.604" x2="-0.254" y2="10.16" layer="94"/>
<rectangle x1="-2.54" y1="2.54" x2="-0.254" y2="6.096" layer="94"/>
<rectangle x1="0" y1="6.604" x2="2.286" y2="10.16" layer="94"/>
<rectangle x1="0" y1="2.54" x2="2.286" y2="6.096" layer="94"/>
<rectangle x1="2.54" y1="6.604" x2="4.826" y2="10.16" layer="94"/>
<rectangle x1="2.54" y1="2.54" x2="4.826" y2="6.096" layer="94"/>
<rectangle x1="5.08" y1="6.604" x2="7.366" y2="10.16" layer="94"/>
<rectangle x1="5.08" y1="2.54" x2="7.366" y2="6.096" layer="94"/>
<rectangle x1="7.62" y1="6.604" x2="9.906" y2="10.16" layer="94"/>
<rectangle x1="7.62" y1="2.54" x2="9.906" y2="6.096" layer="94"/>
<rectangle x1="10.16" y1="6.604" x2="12.446" y2="10.16" layer="94"/>
<rectangle x1="10.16" y1="2.54" x2="12.446" y2="6.096" layer="94"/>
<rectangle x1="12.7" y1="6.604" x2="14.986" y2="10.16" layer="94"/>
<rectangle x1="12.7" y1="2.54" x2="14.986" y2="6.096" layer="94"/>
<rectangle x1="15.24" y1="6.604" x2="17.526" y2="10.16" layer="94"/>
<rectangle x1="15.24" y1="2.54" x2="17.526" y2="6.096" layer="94"/>
<rectangle x1="17.78" y1="6.604" x2="20.066" y2="10.16" layer="94"/>
<rectangle x1="17.78" y1="2.54" x2="20.066" y2="6.096" layer="94"/>
<rectangle x1="20.32" y1="6.604" x2="22.606" y2="10.16" layer="94"/>
<rectangle x1="20.32" y1="2.54" x2="22.606" y2="6.096" layer="94"/>
<rectangle x1="22.86" y1="6.604" x2="25.146" y2="10.16" layer="94"/>
<rectangle x1="22.86" y1="2.54" x2="25.146" y2="6.096" layer="94"/>
<pin name="GND" x="-22.86" y="-10.16" length="short" direction="pwr" rot="R90"/>
<pin name="VCC" x="-20.32" y="-10.16" length="short" direction="pwr" rot="R90"/>
<pin name="CONTR" x="-17.78" y="-10.16" length="short" direction="in" rot="R90"/>
<pin name="RS" x="-15.24" y="-10.16" length="short" direction="in" rot="R90"/>
<pin name="R/W" x="-12.7" y="-10.16" length="short" direction="in" rot="R90"/>
<pin name="E" x="-10.16" y="-10.16" length="short" direction="in" rot="R90"/>
<pin name="D0" x="-7.62" y="-10.16" length="short" direction="in" rot="R90"/>
<pin name="D1" x="-5.08" y="-10.16" length="short" direction="in" rot="R90"/>
<pin name="D2" x="-2.54" y="-10.16" length="short" direction="in" rot="R90"/>
<pin name="D3" x="0" y="-10.16" length="short" direction="in" rot="R90"/>
<pin name="D4" x="2.54" y="-10.16" length="short" direction="in" rot="R90"/>
<pin name="D5" x="5.08" y="-10.16" length="short" direction="in" rot="R90"/>
<pin name="D6" x="7.62" y="-10.16" length="short" direction="in" rot="R90"/>
<pin name="D7" x="10.16" y="-10.16" length="short" direction="in" rot="R90"/>
<pin name="NC@1" x="12.7" y="-10.16" length="short" direction="nc" rot="R90"/>
<pin name="NC@2" x="15.24" y="-10.16" length="short" direction="nc" rot="R90"/>
</symbol>
<symbol name="MGLS2401280TZ">
<wire x1="-5.08" y1="30.48" x2="40.64" y2="30.48" width="0.254" layer="94"/>
<wire x1="40.64" y1="30.48" x2="40.64" y2="-25.4" width="0.254" layer="94"/>
<wire x1="40.64" y1="-25.4" x2="-5.08" y2="-25.4" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-25.4" x2="-5.08" y2="30.48" width="0.254" layer="94"/>
<wire x1="5.08" y1="25.4" x2="38.1" y2="25.4" width="0.254" layer="94"/>
<wire x1="38.1" y1="25.4" x2="38.1" y2="-20.32" width="0.254" layer="94"/>
<wire x1="38.1" y1="-20.32" x2="5.08" y2="-20.32" width="0.254" layer="94"/>
<wire x1="5.08" y1="-20.32" x2="5.08" y2="25.4" width="0.254" layer="94"/>
<text x="10.16" y="7.62" size="1.778" layer="94">LCD: VGLS-240128</text>
<text x="10.16" y="2.54" size="1.778" layer="94">240 x 128 DOTS</text>
<text x="-5.08" y="31.75" size="1.778" layer="95">&gt;NAME</text>
<text x="-5.08" y="-27.94" size="1.778" layer="96">&gt;VALUE</text>
<pin name="FS" x="-7.62" y="17.78" length="short" direction="in"/>
<pin name="!WR" x="-7.62" y="15.24" length="short" direction="in"/>
<pin name="!RD" x="-7.62" y="12.7" length="short" direction="in"/>
<pin name="!CE" x="-7.62" y="10.16" length="short" direction="in"/>
<pin name="C/!D" x="-7.62" y="7.62" length="short" direction="in"/>
<pin name="DB0" x="-7.62" y="2.54" length="short"/>
<pin name="DB1" x="-7.62" y="0" length="short"/>
<pin name="DB2" x="-7.62" y="-2.54" length="short"/>
<pin name="DB3" x="-7.62" y="-5.08" length="short"/>
<pin name="DB4" x="-7.62" y="-7.62" length="short"/>
<pin name="DB5" x="-7.62" y="-10.16" length="short"/>
<pin name="DB6" x="-7.62" y="-12.7" length="short"/>
<pin name="DB7" x="-7.62" y="-15.24" length="short"/>
<pin name="FG" x="-7.62" y="-20.32" length="short" direction="in"/>
<pin name="VSS" x="-7.62" y="-22.86" length="short" direction="in"/>
<pin name="VDD" x="-7.62" y="27.94" length="short" direction="in"/>
<pin name="V0" x="-7.62" y="25.4" length="short" direction="in"/>
<pin name="!RST" x="-7.62" y="20.32" length="short" direction="in"/>
</symbol>
<symbol name="2X16_FURAT">
<text x="0" y="0" size="1.778" layer="94">2x16_furat</text>
</symbol>
<symbol name="LCDTEST">
<pin name="P$1" x="-20.32" y="-7.62" visible="off" length="middle" rot="R90"/>
<pin name="P$2" x="-17.78" y="-7.62" visible="off" length="middle" rot="R90"/>
<pin name="P$3" x="-15.24" y="-7.62" visible="off" length="middle" rot="R90"/>
<pin name="P$4" x="-12.7" y="-7.62" visible="off" length="middle" rot="R90"/>
<pin name="P$5" x="-10.16" y="-7.62" visible="off" length="middle" rot="R90"/>
<pin name="P$6" x="-7.62" y="-7.62" visible="off" length="middle" rot="R90"/>
<pin name="P$7" x="-5.08" y="-7.62" visible="off" length="middle" rot="R90"/>
<pin name="P$8" x="-2.54" y="-7.62" visible="off" length="middle" rot="R90"/>
<pin name="P$9" x="0" y="-7.62" visible="off" length="middle" rot="R90"/>
<pin name="P$10" x="2.54" y="-7.62" visible="off" length="middle" rot="R90"/>
<pin name="P$11" x="5.08" y="-7.62" visible="off" length="middle" rot="R90"/>
<pin name="P$12" x="7.62" y="-7.62" visible="off" length="middle" rot="R90"/>
<pin name="P$13" x="10.16" y="-7.62" visible="off" length="middle" rot="R90"/>
<pin name="P$14" x="12.7" y="-7.62" visible="off" length="middle" rot="R90"/>
<pin name="P$15" x="15.24" y="-7.62" visible="off" length="middle" rot="R90"/>
<pin name="P$16" x="17.78" y="-7.62" visible="off" length="middle" rot="R90"/>
<wire x1="-22.86" y1="-2.54" x2="20.32" y2="-2.54" width="0.254" layer="94"/>
<wire x1="20.32" y1="-2.54" x2="20.32" y2="0" width="0.254" layer="94"/>
<wire x1="20.32" y1="0" x2="-22.86" y2="0" width="0.254" layer="94"/>
<wire x1="-22.86" y1="0" x2="-22.86" y2="-2.54" width="0.254" layer="94"/>
<text x="-21.082" y="-1.778" size="0.6096" layer="94">VSS</text>
<text x="-18.542" y="-1.778" size="0.6096" layer="94">VDD</text>
<text x="-15.748" y="-1.778" size="0.6096" layer="94">Ctr</text>
<text x="-13.208" y="-1.778" size="0.6096" layer="94">RS</text>
<text x="-11.176" y="-1.778" size="0.6096" layer="94">R/W</text>
<text x="-7.874" y="-1.778" size="0.6096" layer="94">E</text>
<text x="17.018" y="-1.778" size="0.6096" layer="94">LED -</text>
<text x="14.224" y="-1.778" size="0.6096" layer="94">LED +</text>
<text x="12.192" y="-1.778" size="0.6096" layer="94">D7</text>
<text x="9.652" y="-1.778" size="0.6096" layer="94">D6</text>
<text x="7.112" y="-1.778" size="0.6096" layer="94">D5</text>
<text x="4.572" y="-1.778" size="0.6096" layer="94">D4</text>
</symbol>
</symbols>
<devicesets>
<deviceset name="H1331C" prefix="DIS">
<description>&lt;b&gt;LCD DISPLAY&lt;/b&gt;&lt;p&gt;
3 1/2 character 7 segment</description>
<gates>
<gate name="G$1" symbol="H1331C" x="0" y="0"/>
</gates>
<devices>
<device name="" package="H1331C">
<connects>
<connect gate="G$1" pin="-" pad="2"/>
<connect gate="G$1" pin="1A" pad="21"/>
<connect gate="G$1" pin="1B" pad="20"/>
<connect gate="G$1" pin="1C" pad="19"/>
<connect gate="G$1" pin="1D" pad="18"/>
<connect gate="G$1" pin="1DP" pad="16"/>
<connect gate="G$1" pin="1E" pad="17"/>
<connect gate="G$1" pin="1F" pad="22"/>
<connect gate="G$1" pin="1G" pad="23"/>
<connect gate="G$1" pin="2A" pad="25"/>
<connect gate="G$1" pin="2B" pad="24"/>
<connect gate="G$1" pin="2C" pad="15"/>
<connect gate="G$1" pin="2D" pad="14"/>
<connect gate="G$1" pin="2DP" pad="12"/>
<connect gate="G$1" pin="2E" pad="13"/>
<connect gate="G$1" pin="2F" pad="26"/>
<connect gate="G$1" pin="2G" pad="27"/>
<connect gate="G$1" pin="3A" pad="30"/>
<connect gate="G$1" pin="3B" pad="29"/>
<connect gate="G$1" pin="3C" pad="11"/>
<connect gate="G$1" pin="3D" pad="10"/>
<connect gate="G$1" pin="3DP" pad="8"/>
<connect gate="G$1" pin="3E" pad="9"/>
<connect gate="G$1" pin="3F" pad="31"/>
<connect gate="G$1" pin="3G" pad="32"/>
<connect gate="G$1" pin=":" pad="39"/>
<connect gate="G$1" pin="&lt;-" pad="38"/>
<connect gate="G$1" pin="BC" pad="3"/>
<connect gate="G$1" pin="COM" pad="1"/>
<connect gate="G$1" pin="COM1" pad="40"/>
<connect gate="G$1" pin="L" pad="28"/>
</connects>
<technologies>
<technology name="">
<attribute name="MF" value="" constant="no"/>
<attribute name="MPN" value="" constant="no"/>
<attribute name="OC_FARNELL" value="unknown" constant="no"/>
<attribute name="OC_NEWARK" value="unknown" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="H1333C" prefix="DIS">
4-character 7 segment</description>
<gates>
<gate name="G$1" symbol="H1333C" x="0" y="0"/>
</gates>
<devices>
<device name="" package="H1333C">
<connects>
<connect gate="G$1" pin="4A" pad="35"/>
<connect gate="G$1" pin="4B" pad="34"/>
<connect gate="G$1" pin="4C" pad="7"/>
<connect gate="G$1" pin="4D" pad="6"/>
<connect gate="G$1" pin="4E" pad="5"/>
<connect gate="G$1" pin="4F" pad="36"/>
<connect gate="G$1" pin="4G" pad="37"/>
</connects>
<technologies>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="H1335C" prefix="DIS">
6-character 7 segment</description>
<gates>
<gate name="1" symbol="H1335C" x="0" y="0"/>
</gates>
<devices>
<device name="" package="H1335C">
<connects>
<connect gate="1" pin="1A" pad="26"/>
<connect gate="1" pin="1B" pad="25"/>
<connect gate="1" pin="1C" pad="24"/>
<connect gate="1" pin="1D" pad="23"/>
<connect gate="1" pin="1DP" pad="21"/>
<connect gate="1" pin="1E" pad="22"/>
<connect gate="1" pin="1F" pad="27"/>
<connect gate="1" pin="1G" pad="28"/>
<connect gate="1" pin="2A" pad="30"/>
<connect gate="1" pin="2B" pad="29"/>
<connect gate="1" pin="2C" pad="20"/>
<connect gate="1" pin="2D" pad="19"/>
<connect gate="1" pin="2DP" pad="17"/>
<connect gate="1" pin="2E" pad="18"/>
<connect gate="1" pin="2F" pad="31"/>
<connect gate="1" pin="2G" pad="32"/>
<connect gate="1" pin="3A" pad="35"/>
<connect gate="1" pin="3B" pad="34"/>
<connect gate="1" pin="3C" pad="16"/>
<connect gate="1" pin="3D" pad="15"/>
<connect gate="1" pin="3DP" pad="13"/>
<connect gate="1" pin="3E" pad="14"/>
<connect gate="1" pin="3F" pad="36"/>
<connect gate="1" pin="3G" pad="37"/>
<connect gate="1" pin="4A" pad="39"/>
<connect gate="1" pin="4B" pad="38"/>
<connect gate="1" pin="4C" pad="12"/>
<connect gate="1" pin="4D" pad="11"/>
<connect gate="1" pin="4DP" pad="9"/>
<connect gate="1" pin="4E" pad="10"/>
<connect gate="1" pin="4F" pad="40"/>
<connect gate="1" pin="4G" pad="41"/>
<connect gate="1" pin="5A" pad="44"/>
<connect gate="1" pin="5B" pad="43"/>
<connect gate="1" pin="5C" pad="8"/>
<connect gate="1" pin="5D" pad="7"/>
<connect gate="1" pin="5DP" pad="5"/>
<connect gate="1" pin="5E" pad="6"/>
<connect gate="1" pin="5F" pad="45"/>
<connect gate="1" pin="5G" pad="46"/>
<connect gate="1" pin="6A" pad="48"/>
<connect gate="1" pin="6B" pad="47"/>
<connect gate="1" pin="6C" pad="4"/>
<connect gate="1" pin="6D" pad="3"/>
<connect gate="1" pin="6E" pad="2"/>
<connect gate="1" pin="6F" pad="49"/>
<connect gate="1" pin="6G" pad="50"/>
<connect gate="1" pin="COM" pad="1"/>
<connect gate="1" pin="L1" pad="33"/>
<connect gate="1" pin="L2" pad="42"/>
</connects>
<technologies>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="LS021C" prefix="DIS">
3 1/2-character 7 segment</description>
<gates>
<gate name="G$1" symbol="LS021" x="0" y="0"/>
</gates>
<devices>
<device name="" package="LS021C">
<connects>
</connects>
<technologies>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="LS022C" prefix="DIS">
<gates>
<gate name="G$1" symbol="LS022" x="0" y="0"/>
</gates>
<devices>
<device name="" package="LS022C">
<connects>
</connects>
<technologies>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="LS023C" prefix="DIS">
4 1/2-character 7 segment</description>
<gates>
<gate name="A" symbol="LS023" x="0" y="0"/>
</gates>
<devices>
<device name="" package="LS023C">
<connects>
<connect gate="A" pin="-" pad="2"/>
<connect gate="A" pin="1A" pad="21"/>
<connect gate="A" pin="1B" pad="20"/>
<connect gate="A" pin="1C" pad="19"/>
<connect gate="A" pin="1D" pad="18"/>
<connect gate="A" pin="1DP" pad="16"/>
<connect gate="A" pin="1E" pad="17"/>
<connect gate="A" pin="1F" pad="22"/>
<connect gate="A" pin="1G" pad="23"/>
<connect gate="A" pin="2A" pad="25"/>
<connect gate="A" pin="2B" pad="24"/>
<connect gate="A" pin="2C" pad="15"/>
<connect gate="A" pin="2D" pad="14"/>
<connect gate="A" pin="2DP" pad="12"/>
<connect gate="A" pin="2E" pad="13"/>
<connect gate="A" pin="2F" pad="26"/>
<connect gate="A" pin="2G" pad="27"/>
<connect gate="A" pin="3A" pad="30"/>
<connect gate="A" pin="3B" pad="29"/>
<connect gate="A" pin="3C" pad="11"/>
<connect gate="A" pin="3D" pad="10"/>
<connect gate="A" pin="3DP" pad="8"/>
<connect gate="A" pin="3E" pad="9"/>
<connect gate="A" pin="3F" pad="31"/>
<connect gate="A" pin="3G" pad="32"/>
<connect gate="A" pin="4A" pad="35"/>
<connect gate="A" pin="4B" pad="34"/>
<connect gate="A" pin="4C" pad="7"/>
<connect gate="A" pin="4D" pad="6"/>
<connect gate="A" pin="4DP" pad="4"/>
<connect gate="A" pin="4E" pad="5"/>
<connect gate="A" pin="4F" pad="36"/>
<connect gate="A" pin="4G" pad="37"/>
<connect gate="A" pin=":" pad="39"/>
<connect gate="A" pin="&lt;-" pad="38"/>
<connect gate="A" pin="BC" pad="3"/>
<connect gate="A" pin="COM" pad="1"/>
<connect gate="A" pin="L1" pad="28"/>
<connect gate="A" pin="L2" pad="33"/>
</connects>
<technologies>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="H1332C" prefix="DIS">
<gates>
<gate name="A" symbol="H1332C" x="0" y="0"/>
</gates>
<devices>
<device name="" package="H1332C">
<connects>
<connect gate="A" pin="BP" pad="40"/>
</connects>
<technologies>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="LS024C" prefix="DIS">
5-character 7 segment</description>
<gates>
<gate name="A" symbol="LS024" x="0" y="0"/>
</gates>
<devices>
<device name="" package="LS024C">
<connects>
<connect gate="A" pin="3A" pad="29"/>
<connect gate="A" pin="3B" pad="28"/>
<connect gate="A" pin="3F" pad="30"/>
<connect gate="A" pin="3G" pad="31"/>
<connect gate="A" pin="4A" pad="34"/>
<connect gate="A" pin="4B" pad="33"/>
<connect gate="A" pin="4C" pad="8"/>
<connect gate="A" pin="4D" pad="7"/>
<connect gate="A" pin="4E" pad="6"/>
<connect gate="A" pin="4F" pad="35"/>
<connect gate="A" pin="4G" pad="36"/>
<connect gate="A" pin="5A" pad="39"/>
<connect gate="A" pin="5B" pad="38"/>
<connect gate="A" pin="5C" pad="5"/>
<connect gate="A" pin="5D" pad="4"/>
<connect gate="A" pin="5E" pad="3"/>
<connect gate="A" pin="5F" pad="40"/>
<connect gate="A" pin="5G" pad="2"/>
<connect gate="A" pin="L1" pad="32"/>
<connect gate="A" pin="L2" pad="37"/>
</connects>
<technologies>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="LS026C" prefix="DIS">
8-character 7 segment</description>
<gates>
<gate name="A" symbol="LS026" x="0" y="0"/>
</gates>
<devices>
<device name="" package="LS026C">
<connects>
<connect gate="A" pin="1A" pad="35"/>
<connect gate="A" pin="1B" pad="34"/>
<connect gate="A" pin="1C" pad="33"/>
<connect gate="A" pin="1D" pad="32"/>
<connect gate="A" pin="1DP" pad="30"/>
<connect gate="A" pin="1E" pad="31"/>
<connect gate="A" pin="1F" pad="36"/>
<connect gate="A" pin="1G" pad="37"/>
<connect gate="A" pin="2A" pad="39"/>
<connect gate="A" pin="2B" pad="38"/>
<connect gate="A" pin="2C" pad="29"/>
<connect gate="A" pin="2D" pad="28"/>
<connect gate="A" pin="2DP" pad="26"/>
<connect gate="A" pin="2E" pad="27"/>
<connect gate="A" pin="2F" pad="40"/>
<connect gate="A" pin="2G" pad="41"/>
<connect gate="A" pin="3A" pad="44"/>
<connect gate="A" pin="3B" pad="43"/>
<connect gate="A" pin="3C" pad="25"/>
<connect gate="A" pin="3D" pad="24"/>
<connect gate="A" pin="3DP" pad="22"/>
<connect gate="A" pin="3E" pad="23"/>
<connect gate="A" pin="3F" pad="45"/>
<connect gate="A" pin="3G" pad="46"/>
<connect gate="A" pin="4A" pad="48"/>
<connect gate="A" pin="4B" pad="47"/>
<connect gate="A" pin="4C" pad="21"/>
<connect gate="A" pin="4D" pad="20"/>
<connect gate="A" pin="4DP" pad="18"/>
<connect gate="A" pin="4E" pad="19"/>
<connect gate="A" pin="4F" pad="49"/>
<connect gate="A" pin="4G" pad="50"/>
<connect gate="A" pin="5A" pad="53"/>
<connect gate="A" pin="5B" pad="52"/>
<connect gate="A" pin="5C" pad="17"/>
<connect gate="A" pin="5D" pad="16"/>
<connect gate="A" pin="5DP" pad="14"/>
<connect gate="A" pin="5E" pad="15"/>
<connect gate="A" pin="5F" pad="54"/>
<connect gate="A" pin="5G" pad="55"/>
<connect gate="A" pin="6A" pad="57"/>
<connect gate="A" pin="6B" pad="56"/>
<connect gate="A" pin="6C" pad="13"/>
<connect gate="A" pin="6D" pad="12"/>
<connect gate="A" pin="6DP" pad="9"/>
<connect gate="A" pin="6E" pad="11"/>
<connect gate="A" pin="6F" pad="58"/>
<connect gate="A" pin="6G" pad="59"/>
<connect gate="A" pin="7A" pad="62"/>
<connect gate="A" pin="7B" pad="61"/>
<connect gate="A" pin="7C" pad="8"/>
<connect gate="A" pin="7D" pad="7"/>
<connect gate="A" pin="7DP" pad="5"/>
<connect gate="A" pin="7E" pad="6"/>
<connect gate="A" pin="7F" pad="63"/>
<connect gate="A" pin="7G" pad="64"/>
<connect gate="A" pin="8A" pad="66"/>
<connect gate="A" pin="8B" pad="65"/>
<connect gate="A" pin="8C" pad="4"/>
<connect gate="A" pin="8D" pad="3"/>
<connect gate="A" pin="8E" pad="2"/>
<connect gate="A" pin="8F" pad="67"/>
<connect gate="A" pin="8G" pad="68"/>
<connect gate="A" pin="BP" pad="10"/>
<connect gate="A" pin="COM/BP" pad="1"/>
<connect gate="A" pin="L1" pad="42"/>
<connect gate="A" pin="L2" pad="51"/>
<connect gate="A" pin="L3" pad="60"/>
</connects>
<technologies>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="EADIP128*-6N5LW" prefix="DIS">
<description>&lt;b&gt;LCD-GRAFIK MODUL 128x64 PIXEL&lt;/b&gt;&lt;p&gt;
EA DIP128-6N5LW BLAU-WEISS&lt;br&gt;
EA DIP128J-6N5LW SCHWARZ-WEISS&lt;br&gt;
&lt;br&gt;
ELECTRONIC ASSEMBLY GMBH&lt;br&gt;
LOCHHAMER SCHLAG 17&lt;br&gt;
D-82166 GRÄFELFING&lt;br&gt;
Source: www.lcd-module.de .. dip128-6.pdf</description>
<gates>
<gate name="G$1" symbol="LCD-DIP128-64" x="0" y="0"/>
</gates>
<devices>
<device name="" package="LCD-DIP128-64">
<connects>
<connect gate="G$1" pin="A" pad="23"/>
<connect gate="G$1" pin="ADJ" pad="3"/>
<connect gate="G$1" pin="C" pad="24"/>
<connect gate="G$1" pin="CS1H" pad="10"/>
<connect gate="G$1" pin="CS1L" pad="9"/>
<connect gate="G$1" pin="CS2H" pad="12"/>
<connect gate="G$1" pin="CS2L" pad="11"/>
<connect gate="G$1" pin="D/I" pad="5"/>
<connect gate="G$1" pin="D0" pad="15"/>
<connect gate="G$1" pin="D1" pad="16"/>
<connect gate="G$1" pin="D2" pad="17"/>
<connect gate="G$1" pin="D3" pad="18"/>
<connect gate="G$1" pin="D4" pad="19"/>
<connect gate="G$1" pin="D5" pad="20"/>
<connect gate="G$1" pin="D6" pad="21"/>
<connect gate="G$1" pin="D7" pad="22"/>
<connect gate="G$1" pin="E1" pad="7"/>
<connect gate="G$1" pin="E2" pad="8"/>
<connect gate="G$1" pin="NC" pad="14"/>
<connect gate="G$1" pin="R/!W" pad="6"/>
<connect gate="G$1" pin="RES" pad="4"/>
<connect gate="G$1" pin="VDD" pad="2"/>
<connect gate="G$1" pin="VNEG" pad="13"/>
<connect gate="G$1" pin="VSS" pad="1"/>
</connects>
<technologies>
</technology>
<technology name="J">
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="HDM64GS12_-R" prefix="DIS">
<description>&lt;b&gt;HDM64GS12_-R&lt;/b&gt; 128 X 64 Dots Graphic&lt;p&gt;
Source: http://www.hantronix.com/down/64gs12-r.pdf</description>
<gates>
<gate name="G$1" symbol="HDM64GS12" x="0" y="0"/>
</gates>
<devices>
<device name="" package="HDM64GS12_-R">
<connects>
<connect gate="G$1" pin="A" pad="19"/>
<connect gate="G$1" pin="CS1" pad="15"/>
<connect gate="G$1" pin="CS2" pad="16"/>
<connect gate="G$1" pin="D/I" pad="4"/>
<connect gate="G$1" pin="D0" pad="7"/>
<connect gate="G$1" pin="D1" pad="8"/>
<connect gate="G$1" pin="D2" pad="9"/>
<connect gate="G$1" pin="D3" pad="10"/>
<connect gate="G$1" pin="D4" pad="11"/>
<connect gate="G$1" pin="D5" pad="12"/>
<connect gate="G$1" pin="D6" pad="13"/>
<connect gate="G$1" pin="D7" pad="14"/>
<connect gate="G$1" pin="E" pad="6"/>
<connect gate="G$1" pin="K" pad="20"/>
<connect gate="G$1" pin="R/!W" pad="5"/>
<connect gate="G$1" pin="RES" pad="17"/>
<connect gate="G$1" pin="VEE" pad="18"/>
<connect gate="G$1" pin="VL" pad="3"/>
</connects>
<technologies>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="SBLCDA4" prefix="DIS">
<description>&lt;b&gt;LCD Display SBLCDA4&lt;/b&gt;&lt;p&gt;
Source: http://www.softbaugh.com/downloads/SBLCDA4_Specification.pdf</description>
<gates>
<gate name="G$1" symbol="SBLCDA4" x="0" y="0"/>
</gates>
<devices>
<device name="" package="SBLCDA4">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="10" pad="10"/>
<connect gate="G$1" pin="11" pad="11"/>
<connect gate="G$1" pin="12" pad="12"/>
<connect gate="G$1" pin="13" pad="13"/>
<connect gate="G$1" pin="14" pad="14"/>
<connect gate="G$1" pin="15" pad="15"/>
<connect gate="G$1" pin="16" pad="16"/>
<connect gate="G$1" pin="17" pad="17"/>
<connect gate="G$1" pin="18" pad="18"/>
<connect gate="G$1" pin="19" pad="19"/>
<connect gate="G$1" pin="2" pad="2"/>
<connect gate="G$1" pin="20" pad="20"/>
<connect gate="G$1" pin="21" pad="21"/>
<connect gate="G$1" pin="22" pad="22"/>
<connect gate="G$1" pin="23" pad="23"/>
<connect gate="G$1" pin="24" pad="24"/>
<connect gate="G$1" pin="25" pad="25"/>
<connect gate="G$1" pin="26" pad="26"/>
<connect gate="G$1" pin="3" pad="3"/>
<connect gate="G$1" pin="4" pad="4"/>
<connect gate="G$1" pin="5" pad="5"/>
<connect gate="G$1" pin="6" pad="6"/>
<connect gate="G$1" pin="7" pad="7"/>
<connect gate="G$1" pin="8" pad="8"/>
<connect gate="G$1" pin="9" pad="9"/>
</connects>
<technologies>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="TUXGR_16X2_R2" prefix="DIS">
<description>&lt;b&gt;Tuxgraphics LCD display 16x2 characters&lt;/b&gt; reflective, without background light&lt;p&gt;
Source: tuxgr_12x2_r2.pdf</description>
<gates>
<gate name="G$1" symbol="TUXGR_16X2_R2" x="0" y="0"/>
</gates>
<devices>
<device name="" package="TUXGR_16X2_R2">
<connects>
<connect gate="G$1" pin="CONTR" pad="3"/>
<connect gate="G$1" pin="GND" pad="1"/>
<connect gate="G$1" pin="NC@1" pad="15"/>
<connect gate="G$1" pin="NC@2" pad="16"/>
<connect gate="G$1" pin="R/W" pad="5"/>
<connect gate="G$1" pin="RS" pad="4"/>
<connect gate="G$1" pin="VCC" pad="2"/>
</connects>
<technologies>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="TUXGR_20X2" prefix="DIS">
<description>&lt;b&gt;Tuxgraphics LCD display 20x2 characters&lt;/b&gt; reflective, without background light&lt;p&gt;
Source: tuxgr_20x2.pdf</description>
<gates>
<gate name="G$1" symbol="TUXGR_20X2" x="0" y="0"/>
</gates>
<devices>
<device name="" package="TUXGR_20X2">
<connects>
</connects>
<technologies>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="MGLS2401280TZ" prefix="DIS">
<description>&lt;b&gt;LCD Display 240 x 128 Dots&lt;/b&gt;&lt;p&gt;
Source: VARITRONIX LIMITED .. LCD_f1187192714.pdf</description>
<gates>
<gate name="G$1" symbol="MGLS2401280TZ" x="0" y="0"/>
</gates>
<devices>
<device name="" package="MGLS2401280TZ">
<connects>
<connect gate="G$1" pin="!CE" pad="7"/>
<connect gate="G$1" pin="!RD" pad="6"/>
<connect gate="G$1" pin="!RST" pad="9"/>
<connect gate="G$1" pin="!WR" pad="5"/>
<connect gate="G$1" pin="C/!D" pad="8"/>
<connect gate="G$1" pin="DB0" pad="10"/>
<connect gate="G$1" pin="DB1" pad="11"/>
<connect gate="G$1" pin="DB2" pad="12"/>
<connect gate="G$1" pin="DB3" pad="13"/>
<connect gate="G$1" pin="DB4" pad="14"/>
<connect gate="G$1" pin="DB5" pad="15"/>
<connect gate="G$1" pin="DB6" pad="16"/>
<connect gate="G$1" pin="DB7" pad="17"/>
<connect gate="G$1" pin="FG" pad="1"/>
<connect gate="G$1" pin="FS" pad="18"/>
<connect gate="G$1" pin="V0" pad="4"/>
<connect gate="G$1" pin="VDD" pad="3"/>
<connect gate="G$1" pin="VSS" pad="2"/>
</connects>
<technologies>
<attribute name="OC_FARNELL" value="1183196" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="2X16_FURAT">
<gates>
<gate name="G$1" symbol="2X16_FURAT" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2X16_FURAT">
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="LCDTEST">
<gates>
<gate name="G$1" symbol="LCDTEST" x="2.54" y="2.54"/>
</gates>
<devices>
<device name="" package="LCDTEST">
<connects>
<connect gate="G$1" pin="P$1" pad="P$1"/>
<connect gate="G$1" pin="P$10" pad="P$10"/>
<connect gate="G$1" pin="P$11" pad="P$11"/>
<connect gate="G$1" pin="P$12" pad="P$12"/>
<connect gate="G$1" pin="P$13" pad="P$13"/>
<connect gate="G$1" pin="P$14" pad="P$14"/>
<connect gate="G$1" pin="P$15" pad="P$15"/>
<connect gate="G$1" pin="P$16" pad="P$16"/>
<connect gate="G$1" pin="P$2" pad="P$2"/>
<connect gate="G$1" pin="P$3" pad="P$3"/>
<connect gate="G$1" pin="P$4" pad="P$4"/>
<connect gate="G$1" pin="P$5" pad="P$5"/>
<connect gate="G$1" pin="P$6" pad="P$6"/>
<connect gate="G$1" pin="P$7" pad="P$7"/>
<connect gate="G$1" pin="P$8" pad="P$8"/>
<connect gate="G$1" pin="P$9" pad="P$9"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
