<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="9.5.1">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="50" unitdist="mil" unit="mil" style="lines" multiple="1" display="yes" altdistance="5" altunitdist="mil" altunit="mil"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="16" fill="1" visible="no" active="yes"/>
<layer number="3" name="Route3" color="17" fill="1" visible="no" active="yes"/>
<layer number="4" name="Route4" color="18" fill="1" visible="no" active="yes"/>
<layer number="5" name="Route5" color="19" fill="1" visible="no" active="yes"/>
<layer number="6" name="Route6" color="25" fill="1" visible="no" active="yes"/>
<layer number="7" name="Route7" color="26" fill="1" visible="no" active="yes"/>
<layer number="8" name="Route8" color="27" fill="1" visible="no" active="yes"/>
<layer number="9" name="Route9" color="28" fill="1" visible="no" active="yes"/>
<layer number="10" name="Route10" color="29" fill="1" visible="no" active="yes"/>
<layer number="11" name="Route11" color="30" fill="1" visible="no" active="yes"/>
<layer number="12" name="Route12" color="20" fill="1" visible="no" active="yes"/>
<layer number="13" name="Route13" color="21" fill="1" visible="no" active="yes"/>
<layer number="14" name="Route14" color="22" fill="1" visible="no" active="yes"/>
<layer number="15" name="Route15" color="23" fill="1" visible="no" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="24" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="88" name="SimResults" color="9" fill="1" visible="yes" active="yes"/>
<layer number="89" name="SimProbes" color="9" fill="1" visible="yes" active="yes"/>
<layer number="90" name="Modules" color="5" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="yes" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
</layers>
<library>
<packages>
<package name="OSK4039A-IG">
<description>4x7 led disp</description>
<smd name="E" x="-6.35" y="-7.62" dx="2.54" dy="2" layer="1" rot="R90"/>
<smd name="D" x="-3.81" y="-7.62" dx="2.54" dy="2" layer="1" rot="R90"/>
<smd name="DP" x="-1.27" y="-7.62" dx="2.54" dy="2" layer="1" rot="R90"/>
<smd name="C" x="1.27" y="-7.62" dx="2.54" dy="2" layer="1" rot="R90"/>
<smd name="G" x="3.81" y="-7.62" dx="2.54" dy="2" layer="1" rot="R90"/>
<smd name="G4" x="6.35" y="-7.62" dx="2.54" dy="2" layer="1" rot="R90"/>
<smd name="B" x="6.35" y="7.62" dx="2.54" dy="2" layer="1" rot="R90"/>
<smd name="G3" x="3.81" y="7.62" dx="2.54" dy="2" layer="1" rot="R90"/>
<smd name="G2" x="1.27" y="7.62" dx="2.54" dy="2" layer="1" rot="R90"/>
<smd name="F" x="-1.27" y="7.62" dx="2.54" dy="2" layer="1" rot="R90"/>
<smd name="A" x="-3.81" y="7.62" dx="2.54" dy="2" layer="1" rot="R90"/>
<smd name="G1" x="-6.35" y="7.62" dx="2.54" dy="2" layer="1" rot="R90"/>
<wire x1="20.32" y1="6.35" x2="-20.32" y2="6.35" width="0.127" layer="21"/>
<wire x1="-20.32" y1="6.35" x2="-20.32" y2="-6.35" width="0.127" layer="21"/>
<wire x1="-20.32" y1="-6.35" x2="20.32" y2="-6.35" width="0.127" layer="21"/>
<wire x1="20.32" y1="-6.35" x2="20.32" y2="6.35" width="0.127" layer="21"/>
<wire x1="2.3114" y1="0.1016" x2="2.9464" y2="3.9116" width="1.016" layer="21"/>
<wire x1="2.9464" y1="3.9116" x2="8.0264" y2="3.9116" width="1.016" layer="21"/>
<wire x1="8.0264" y1="3.9116" x2="7.3914" y2="0.1016" width="1.016" layer="21"/>
<wire x1="7.3914" y1="0.1016" x2="2.3114" y2="0.1016" width="1.016" layer="21"/>
<wire x1="2.3114" y1="0.1016" x2="1.6764" y2="-3.7084" width="1.016" layer="21"/>
<wire x1="1.6764" y1="-3.7084" x2="6.7564" y2="-3.7084" width="1.016" layer="21"/>
<wire x1="6.7564" y1="-3.7084" x2="7.3914" y2="0.1016" width="1.016" layer="21"/>
<wire x1="8.5344" y1="-4.4704" x2="8.6614" y2="-4.4704" width="1.27" layer="21"/>
<wire x1="11.2014" y1="0.1016" x2="11.8364" y2="3.9116" width="1.016" layer="21"/>
<wire x1="11.8364" y1="3.9116" x2="16.9164" y2="3.9116" width="1.016" layer="21"/>
<wire x1="16.9164" y1="3.9116" x2="16.2814" y2="0.1016" width="1.016" layer="21"/>
<wire x1="16.2814" y1="0.1016" x2="11.2014" y2="0.1016" width="1.016" layer="21"/>
<wire x1="11.2014" y1="0.1016" x2="10.5664" y2="-3.7084" width="1.016" layer="21"/>
<wire x1="10.5664" y1="-3.7084" x2="15.6464" y2="-3.7084" width="1.016" layer="21"/>
<wire x1="15.6464" y1="-3.7084" x2="16.2814" y2="0.1016" width="1.016" layer="21"/>
<wire x1="17.4244" y1="-4.4704" x2="17.5514" y2="-4.4704" width="1.27" layer="21"/>
<wire x1="-16.1036" y1="0.1016" x2="-15.4686" y2="3.9116" width="1.016" layer="21"/>
<wire x1="-15.4686" y1="3.9116" x2="-10.3886" y2="3.9116" width="1.016" layer="21"/>
<wire x1="-10.3886" y1="3.9116" x2="-11.0236" y2="0.1016" width="1.016" layer="21"/>
<wire x1="-11.0236" y1="0.1016" x2="-16.1036" y2="0.1016" width="1.016" layer="21"/>
<wire x1="-16.1036" y1="0.1016" x2="-16.7386" y2="-3.7084" width="1.016" layer="21"/>
<wire x1="-16.7386" y1="-3.7084" x2="-11.6586" y2="-3.7084" width="1.016" layer="21"/>
<wire x1="-11.6586" y1="-3.7084" x2="-11.0236" y2="0.1016" width="1.016" layer="21"/>
<wire x1="-9.8806" y1="-4.4704" x2="-9.7536" y2="-4.4704" width="1.27" layer="21"/>
<wire x1="-7.2136" y1="0.1016" x2="-6.5786" y2="3.9116" width="1.016" layer="21"/>
<wire x1="-6.5786" y1="3.9116" x2="-1.4986" y2="3.9116" width="1.016" layer="21"/>
<wire x1="-1.4986" y1="3.9116" x2="-2.1336" y2="0.1016" width="1.016" layer="21"/>
<wire x1="-2.1336" y1="0.1016" x2="-7.2136" y2="0.1016" width="1.016" layer="21"/>
<wire x1="-7.2136" y1="0.1016" x2="-7.8486" y2="-3.7084" width="1.016" layer="21"/>
<wire x1="-7.8486" y1="-3.7084" x2="-2.7686" y2="-3.7084" width="1.016" layer="21"/>
<wire x1="-2.7686" y1="-3.7084" x2="-2.1336" y2="0.1016" width="1.016" layer="21"/>
<wire x1="-0.9906" y1="-4.4704" x2="-0.8636" y2="-4.4704" width="1.27" layer="21"/>
</package>
</packages>
<symbols>
<symbol name="OSK4039A-IG">
<description>OSK4039A-IG 4x7 led kijelző</description>
<pin name="E" x="-6.35" y="-10.16" length="short" rot="R90"/>
<pin name="D" x="-3.81" y="-10.16" length="short" rot="R90"/>
<pin name="DP" x="-1.27" y="-10.16" length="short" rot="R90"/>
<pin name="C" x="1.27" y="-10.16" length="short" rot="R90"/>
<pin name="G" x="3.81" y="-10.16" length="short" rot="R90"/>
<pin name="DIG4" x="6.35" y="-10.16" length="short" rot="R90"/>
<pin name="B" x="6.35" y="10.16" length="short" rot="R270"/>
<pin name="DIG3" x="3.81" y="10.16" length="short" rot="R270"/>
<pin name="DIG2" x="1.27" y="10.16" length="short" rot="R270"/>
<pin name="F" x="-1.27" y="10.16" length="short" rot="R270"/>
<pin name="A" x="-3.81" y="10.16" length="short" rot="R270"/>
<pin name="DIG1" x="-6.35" y="10.16" length="short" rot="R270"/>
<wire x1="15.24" y1="-7.62" x2="15.24" y2="7.62" width="0.254" layer="94"/>
<wire x1="15.24" y1="7.62" x2="-15.24" y2="7.62" width="0.254" layer="94"/>
<wire x1="-15.24" y1="7.62" x2="-15.24" y2="-7.62" width="0.254" layer="94"/>
<wire x1="-15.24" y1="-7.62" x2="15.24" y2="-7.62" width="0.254" layer="94"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="OSK4039A-IG">
<gates>
<gate name="G$1" symbol="OSK4039A-IG" x="0" y="0"/>
</gates>
<devices>
<device name="" package="OSK4039A-IG">
<connects>
<connect gate="G$1" pin="A" pad="A"/>
<connect gate="G$1" pin="B" pad="B"/>
<connect gate="G$1" pin="C" pad="C"/>
<connect gate="G$1" pin="D" pad="D"/>
<connect gate="G$1" pin="DIG1" pad="G1"/>
<connect gate="G$1" pin="DIG2" pad="G2"/>
<connect gate="G$1" pin="DIG3" pad="G3"/>
<connect gate="G$1" pin="DIG4" pad="G4"/>
<connect gate="G$1" pin="DP" pad="DP"/>
<connect gate="G$1" pin="E" pad="E"/>
<connect gate="G$1" pin="F" pad="F"/>
<connect gate="G$1" pin="G" pad="G"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="4X7LEDDISP">
<gates>
</gates>
<devices>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
