<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="9.6.2">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting keepoldvectorfont="yes"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="mm" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="mm"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="no" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="yes"/>
<layer number="51" name="tDocu" color="6" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="88" name="SimResults" color="9" fill="1" visible="yes" active="yes"/>
<layer number="89" name="SimProbes" color="9" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="yes" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
</layers>
<library>
<description>&lt;b&gt;Molex Connectors&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="DVI-I-R">
<description>&lt;b&gt;CONNECTOR&lt;/b&gt;&lt;p&gt;
MiroCross(TM)-DVI i/0 plug and receptacle connector system (scart)</description>
<wire x1="-18.288" y1="-2.0574" x2="18.288" y2="-2.0574" width="0.0508" layer="21"/>
<wire x1="-18.288" y1="8.128" x2="-17.653" y2="8.763" width="0.254" layer="21" curve="-90"/>
<wire x1="-18.288" y1="8.128" x2="-18.288" y2="-2.0574" width="0.254" layer="21"/>
<wire x1="-18.288" y1="-2.0574" x2="-18.288" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-18.288" y1="-2.54" x2="18.288" y2="-2.54" width="0.254" layer="21"/>
<wire x1="18.288" y1="-2.54" x2="18.288" y2="-2.0574" width="0.254" layer="21"/>
<wire x1="18.288" y1="-2.0574" x2="18.288" y2="8.128" width="0.254" layer="21"/>
<wire x1="17.653" y1="8.763" x2="18.288" y2="8.128" width="0.254" layer="21" curve="-90"/>
<wire x1="17.653" y1="8.763" x2="-17.653" y2="8.763" width="0.254" layer="21"/>
<wire x1="-10.414" y1="-2.667" x2="-10.414" y2="-9.017" width="0.254" layer="21"/>
<wire x1="-9.779" y1="-9.652" x2="9.779" y2="-9.652" width="0.254" layer="21"/>
<wire x1="10.414" y1="-9.017" x2="10.414" y2="-2.667" width="0.254" layer="21"/>
<wire x1="-10.414" y1="-9.017" x2="-9.779" y2="-9.652" width="0.254" layer="21" curve="90"/>
<wire x1="9.779" y1="-9.652" x2="10.414" y2="-9.017" width="0.254" layer="21" curve="90"/>
<pad name="1" x="-9.525" y="6.985" drill="0.8636" diameter="1.397"/>
<pad name="2" x="-7.62" y="6.985" drill="0.8636" diameter="1.397"/>
<pad name="3" x="-5.715" y="6.985" drill="0.8636" diameter="1.397"/>
<pad name="4" x="-3.81" y="6.985" drill="0.8636" diameter="1.397"/>
<pad name="5" x="-1.905" y="6.985" drill="0.8636" diameter="1.397"/>
<pad name="6" x="0" y="6.985" drill="0.8636" diameter="1.397"/>
<pad name="7" x="1.905" y="6.985" drill="0.8636" diameter="1.397"/>
<pad name="8" x="3.81" y="6.985" drill="0.8636" diameter="1.397"/>
<pad name="9" x="-9.525" y="5.08" drill="0.8636" diameter="1.397"/>
<pad name="10" x="-7.62" y="5.08" drill="0.8636" diameter="1.397"/>
<pad name="11" x="-5.715" y="5.08" drill="0.8636" diameter="1.397"/>
<pad name="12" x="-3.81" y="5.08" drill="0.8636" diameter="1.397"/>
<pad name="13" x="-1.905" y="5.08" drill="0.8636" diameter="1.397"/>
<pad name="14" x="0" y="5.08" drill="0.8636" diameter="1.397"/>
<pad name="15" x="1.905" y="5.08" drill="0.8636" diameter="1.397"/>
<pad name="16" x="3.81" y="5.08" drill="0.8636" diameter="1.397"/>
<pad name="17" x="-9.525" y="3.175" drill="0.8636" diameter="1.397"/>
<pad name="18" x="-7.62" y="3.175" drill="0.8636" diameter="1.397"/>
<pad name="19" x="-5.715" y="3.175" drill="0.8636" diameter="1.397"/>
<pad name="20" x="-3.81" y="3.175" drill="0.8636" diameter="1.397"/>
<pad name="21" x="-1.905" y="3.175" drill="0.8636" diameter="1.397"/>
<pad name="22" x="0" y="3.175" drill="0.8636" diameter="1.397"/>
<pad name="23" x="1.905" y="3.175" drill="0.8636" diameter="1.397"/>
<pad name="24" x="3.81" y="3.175" drill="0.8636" diameter="1.397"/>
<pad name="C1" x="6.985" y="6.35" drill="0.6604" diameter="1.27"/>
<pad name="C2" x="9.525" y="6.35" drill="0.6604" diameter="1.27"/>
<pad name="C3" x="6.985" y="3.81" drill="0.6604" diameter="1.27"/>
<pad name="C4" x="9.525" y="3.81" drill="0.6604" diameter="1.27"/>
<pad name="C5" x="8.255" y="2.54" drill="0.6604" diameter="1.27"/>
<pad name="C6" x="8.255" y="7.62" drill="0.6604" diameter="1.27"/>
<text x="-7.62" y="0.635" size="1.27" layer="25">&gt;NAME</text>
<text x="-7.62" y="-1.27" size="1.27" layer="27">&gt;VALUE</text>
<hole x="-15.367" y="3.175" drill="1.9304"/>
<hole x="15.367" y="3.175" drill="1.9304"/>
<hole x="-9.525" y="-0.127" drill="1.9304"/>
<hole x="9.525" y="-0.127" drill="1.9304"/>
</package>
<package name="DVI-I-V">
<wire x1="-18.288" y1="-4.953" x2="-18.288" y2="3.81" width="0.254" layer="21"/>
<wire x1="-17.653" y1="-5.588" x2="-14.351" y2="-5.588" width="0.254" layer="21"/>
<wire x1="-13.716" y1="-4.953" x2="13.462" y2="-4.953" width="0.254" layer="21"/>
<wire x1="18.034" y1="-4.953" x2="18.034" y2="3.81" width="0.254" layer="21"/>
<wire x1="17.399" y1="4.445" x2="-17.653" y2="4.445" width="0.254" layer="21"/>
<wire x1="-18.288" y1="3.81" x2="-17.653" y2="4.445" width="0.254" layer="21" curve="-90"/>
<wire x1="-18.288" y1="-4.953" x2="-17.653" y2="-5.588" width="0.254" layer="21" curve="90"/>
<wire x1="17.399" y1="4.445" x2="18.034" y2="3.81" width="0.254" layer="21" curve="-90"/>
<wire x1="17.399" y1="-5.588" x2="18.034" y2="-4.953" width="0.254" layer="21" curve="90"/>
<wire x1="-14.351" y1="-5.588" x2="-13.716" y2="-4.953" width="0.254" layer="21" curve="90"/>
<wire x1="14.097" y1="-5.588" x2="17.399" y2="-5.588" width="0.254" layer="21"/>
<wire x1="13.462" y1="-4.953" x2="14.097" y2="-5.588" width="0.254" layer="21" curve="90"/>
<wire x1="-10.16" y1="1.905" x2="-10.16" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-10.16" y1="0.635" x2="-8.89" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-8.89" y1="0.635" x2="-8.89" y2="1.905" width="0.1524" layer="51"/>
<wire x1="-8.89" y1="1.905" x2="-10.16" y2="1.905" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="1.905" x2="-8.255" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="0.635" x2="-6.985" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-6.985" y1="0.635" x2="-6.985" y2="1.905" width="0.1524" layer="51"/>
<wire x1="-6.985" y1="1.905" x2="-8.255" y2="1.905" width="0.1524" layer="51"/>
<wire x1="-6.35" y1="1.905" x2="-6.35" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-6.35" y1="0.635" x2="-5.08" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-5.08" y1="0.635" x2="-5.08" y2="1.905" width="0.1524" layer="51"/>
<wire x1="-5.08" y1="1.905" x2="-6.35" y2="1.905" width="0.1524" layer="51"/>
<wire x1="-4.445" y1="1.905" x2="-4.445" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-4.445" y1="0.635" x2="-3.175" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-3.175" y1="0.635" x2="-3.175" y2="1.905" width="0.1524" layer="51"/>
<wire x1="-3.175" y1="1.905" x2="-4.445" y2="1.905" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="1.905" x2="-2.54" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="0.635" x2="-1.27" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="0.635" x2="-1.27" y2="1.905" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="1.905" x2="-2.54" y2="1.905" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="1.905" x2="-0.635" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="0.635" x2="0.635" y2="0.635" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0.635" x2="0.635" y2="1.905" width="0.1524" layer="51"/>
<wire x1="0.635" y1="1.905" x2="-0.635" y2="1.905" width="0.1524" layer="51"/>
<wire x1="1.27" y1="1.905" x2="1.27" y2="0.635" width="0.1524" layer="51"/>
<wire x1="1.27" y1="0.635" x2="2.54" y2="0.635" width="0.1524" layer="51"/>
<wire x1="2.54" y1="0.635" x2="2.54" y2="1.905" width="0.1524" layer="51"/>
<wire x1="2.54" y1="1.905" x2="1.27" y2="1.905" width="0.1524" layer="51"/>
<wire x1="3.175" y1="1.905" x2="3.175" y2="0.635" width="0.1524" layer="51"/>
<wire x1="3.175" y1="0.635" x2="4.445" y2="0.635" width="0.1524" layer="51"/>
<wire x1="4.445" y1="0.635" x2="4.445" y2="1.905" width="0.1524" layer="51"/>
<wire x1="4.445" y1="1.905" x2="3.175" y2="1.905" width="0.1524" layer="51"/>
<wire x1="-10.16" y1="0" x2="-10.16" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-10.16" y1="-1.27" x2="-8.89" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-8.89" y1="-1.27" x2="-8.89" y2="0" width="0.1524" layer="51"/>
<wire x1="-8.89" y1="0" x2="-10.16" y2="0" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="0" x2="-8.255" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-1.27" x2="-6.985" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-6.985" y1="-1.27" x2="-6.985" y2="0" width="0.1524" layer="51"/>
<wire x1="-6.985" y1="0" x2="-8.255" y2="0" width="0.1524" layer="51"/>
<wire x1="-6.35" y1="0" x2="-6.35" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-6.35" y1="-1.27" x2="-5.08" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-5.08" y1="-1.27" x2="-5.08" y2="0" width="0.1524" layer="51"/>
<wire x1="-5.08" y1="0" x2="-6.35" y2="0" width="0.1524" layer="51"/>
<wire x1="-4.445" y1="0" x2="-4.445" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-4.445" y1="-1.27" x2="-3.175" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-3.175" y1="-1.27" x2="-3.175" y2="0" width="0.1524" layer="51"/>
<wire x1="-3.175" y1="0" x2="-4.445" y2="0" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="0" x2="-2.54" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-1.27" x2="-1.27" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="-1.27" x2="-1.27" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="0" x2="-2.54" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="0" x2="-0.635" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-1.27" x2="0.635" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="0.635" y1="-1.27" x2="0.635" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="-0.635" y2="0" width="0.1524" layer="51"/>
<wire x1="1.27" y1="0" x2="1.27" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="1.27" y1="-1.27" x2="2.54" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="2.54" y1="-1.27" x2="2.54" y2="0" width="0.1524" layer="51"/>
<wire x1="2.54" y1="0" x2="1.27" y2="0" width="0.1524" layer="51"/>
<wire x1="3.175" y1="0" x2="3.175" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="3.175" y1="-1.27" x2="4.445" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="4.445" y1="-1.27" x2="4.445" y2="0" width="0.1524" layer="51"/>
<wire x1="4.445" y1="0" x2="3.175" y2="0" width="0.1524" layer="51"/>
<wire x1="-10.16" y1="-1.905" x2="-10.16" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="-10.16" y1="-3.175" x2="-8.89" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="-8.89" y1="-3.175" x2="-8.89" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="-8.89" y1="-1.905" x2="-10.16" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-1.905" x2="-8.255" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-3.175" x2="-6.985" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="-6.985" y1="-3.175" x2="-6.985" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="-6.985" y1="-1.905" x2="-8.255" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="-6.35" y1="-1.905" x2="-6.35" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="-6.35" y1="-3.175" x2="-5.08" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="-5.08" y1="-3.175" x2="-5.08" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="-5.08" y1="-1.905" x2="-6.35" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="-4.445" y1="-1.905" x2="-4.445" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="-4.445" y1="-3.175" x2="-3.175" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="-3.175" y1="-3.175" x2="-3.175" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="-3.175" y1="-1.905" x2="-4.445" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-1.905" x2="-2.54" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-3.175" x2="-1.27" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="-3.175" x2="-1.27" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="-1.905" x2="-2.54" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-1.905" x2="-0.635" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-3.175" x2="0.635" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="0.635" y1="-3.175" x2="0.635" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="0.635" y1="-1.905" x2="-0.635" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="1.27" y1="-1.905" x2="1.27" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="1.27" y1="-3.175" x2="2.54" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="2.54" y1="-3.175" x2="2.54" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="2.54" y1="-1.905" x2="1.27" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="3.175" y1="-1.905" x2="3.175" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="3.175" y1="-3.175" x2="4.445" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="4.445" y1="-3.175" x2="4.445" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="4.445" y1="-1.905" x2="3.175" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="6.35" y1="1.27" x2="6.35" y2="0" width="0.1524" layer="51"/>
<wire x1="6.35" y1="0" x2="7.62" y2="0" width="0.1524" layer="51"/>
<wire x1="7.62" y1="0" x2="7.62" y2="1.27" width="0.1524" layer="51"/>
<wire x1="7.62" y1="1.27" x2="6.35" y2="1.27" width="0.1524" layer="51"/>
<wire x1="8.89" y1="1.27" x2="8.89" y2="0" width="0.1524" layer="51"/>
<wire x1="8.89" y1="0" x2="10.16" y2="0" width="0.1524" layer="51"/>
<wire x1="10.16" y1="0" x2="10.16" y2="1.27" width="0.1524" layer="51"/>
<wire x1="10.16" y1="1.27" x2="8.89" y2="1.27" width="0.1524" layer="51"/>
<wire x1="6.35" y1="-1.27" x2="6.35" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="6.35" y1="-2.54" x2="7.62" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="7.62" y1="-2.54" x2="7.62" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="7.62" y1="-1.27" x2="6.35" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="8.89" y1="-1.27" x2="8.89" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="8.89" y1="-2.54" x2="10.16" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="10.16" y1="-2.54" x2="10.16" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="10.16" y1="-1.27" x2="8.89" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="5.08" y1="1.905" x2="5.715" y2="1.905" width="0.1524" layer="51"/>
<wire x1="5.715" y1="1.905" x2="5.715" y2="0" width="0.1524" layer="51"/>
<wire x1="5.715" y1="0" x2="5.08" y2="0" width="0.1524" layer="51"/>
<wire x1="5.08" y1="0" x2="5.08" y2="1.905" width="0.1524" layer="51"/>
<wire x1="5.08" y1="-1.27" x2="5.715" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="5.715" y1="-1.27" x2="5.715" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="5.715" y1="-3.175" x2="5.08" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="5.08" y1="-3.175" x2="5.08" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="6.223" y1="-0.508" x2="10.287" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="10.287" y1="-0.508" x2="10.287" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="10.287" y1="-0.762" x2="6.223" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="6.223" y1="-0.762" x2="6.223" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-11.43" y1="1.905" x2="-10.795" y2="2.54" width="0.1524" layer="51" curve="-90"/>
<wire x1="10.795" y1="2.54" x2="11.43" y2="1.905" width="0.1524" layer="51" curve="-90"/>
<wire x1="-10.795" y1="2.54" x2="10.795" y2="2.54" width="0.1524" layer="51"/>
<wire x1="-11.43" y1="1.905" x2="-11.43" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="11.43" y1="-1.905" x2="10.668" y2="-3.556" width="0.1524" layer="51"/>
<wire x1="10.16" y1="-3.81" x2="10.668" y2="-3.556" width="0.1524" layer="51" curve="53.130102"/>
<wire x1="11.43" y1="1.905" x2="11.43" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="-10.16" y1="-3.81" x2="10.16" y2="-3.81" width="0.1524" layer="51"/>
<wire x1="-11.43" y1="-1.905" x2="-10.668" y2="-3.556" width="0.1524" layer="51"/>
<wire x1="-10.668" y1="-3.556" x2="-10.16" y2="-3.81" width="0.1524" layer="51" curve="53.130102"/>
<pad name="1" x="-9.525" y="1.27" drill="0.8636" diameter="1.397"/>
<pad name="2" x="-7.62" y="1.27" drill="0.8636" diameter="1.397"/>
<pad name="3" x="-5.715" y="1.27" drill="0.8636" diameter="1.397"/>
<pad name="4" x="-3.81" y="1.27" drill="0.8636" diameter="1.397"/>
<pad name="5" x="-1.905" y="1.27" drill="0.8636" diameter="1.397"/>
<pad name="6" x="0" y="1.27" drill="0.8636" diameter="1.397"/>
<pad name="7" x="1.905" y="1.27" drill="0.8636" diameter="1.397"/>
<pad name="8" x="3.81" y="1.27" drill="0.8636" diameter="1.397"/>
<pad name="9" x="-9.525" y="-0.635" drill="0.8636" diameter="1.397"/>
<pad name="10" x="-7.62" y="-0.635" drill="0.8636" diameter="1.397"/>
<pad name="11" x="-5.715" y="-0.635" drill="0.8636" diameter="1.397"/>
<pad name="12" x="-3.81" y="-0.635" drill="0.8636" diameter="1.397"/>
<pad name="13" x="-1.905" y="-0.635" drill="0.8636" diameter="1.397"/>
<pad name="14" x="0" y="-0.635" drill="0.8636" diameter="1.397"/>
<pad name="15" x="1.905" y="-0.635" drill="0.8636" diameter="1.397"/>
<pad name="16" x="3.81" y="-0.635" drill="0.8636" diameter="1.397"/>
<pad name="17" x="-9.525" y="-2.54" drill="0.8636" diameter="1.397"/>
<pad name="18" x="-7.62" y="-2.54" drill="0.8636" diameter="1.397"/>
<pad name="19" x="-5.715" y="-2.54" drill="0.8636" diameter="1.397"/>
<pad name="20" x="-3.81" y="-2.54" drill="0.8636" diameter="1.397"/>
<pad name="21" x="-1.905" y="-2.54" drill="0.8636" diameter="1.397"/>
<pad name="22" x="0" y="-2.54" drill="0.8636" diameter="1.397"/>
<pad name="23" x="1.905" y="-2.54" drill="0.8636" diameter="1.397"/>
<pad name="24" x="3.81" y="-2.54" drill="0.8636" diameter="1.397"/>
<pad name="C1" x="6.985" y="0.635" drill="0.6604" diameter="1.27"/>
<pad name="C2" x="9.525" y="0.635" drill="0.6604" diameter="1.27"/>
<pad name="C3" x="6.985" y="-1.905" drill="0.6604" diameter="1.27"/>
<pad name="C4" x="9.525" y="-1.905" drill="0.6604" diameter="1.27"/>
<pad name="C5" x="8.255" y="-3.175" drill="0.6604" diameter="1.27"/>
<pad name="C6" x="8.255" y="1.905" drill="0.6604" diameter="1.27"/>
<text x="-10.16" y="2.921" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="2.921" size="1.27" layer="27">&gt;VALUE</text>
<hole x="-12.065" y="2.794" drill="1.9304"/>
<hole x="12.065" y="2.794" drill="1.9304"/>
<hole x="-15.748" y="-4.6482" drill="1.9304"/>
<hole x="15.748" y="-4.6482" drill="1.9304"/>
</package>
<package name="DVI-D-R">
</package>
<package name="DVI-D-V">
</package>
<package name="53047-15">
wire to board 1.25 mm (.049 inch) pitch header&lt;p&gt;
straight&lt;br&gt;
Sourcxe: http://www.molex.com/pdm_docs/sd/530470210_sd.pdf</description>
<wire x1="-10.15" y1="-1.5" x2="10.15" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="10.15" y1="-1.5" x2="10.15" y2="1.5" width="0.2032" layer="21"/>
<wire x1="10.15" y1="1.5" x2="-10.15" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-10.15" y1="1.5" x2="-10.15" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="-10.125" y1="-0.25" x2="-9.75" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="-9.75" y1="-0.25" x2="-9.75" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="9.75" y1="-0.25" x2="10.125" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="9.75" y1="-0.25" x2="9.75" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="-10.125" y1="0.375" x2="-9.75" y2="0.375" width="0.0508" layer="21"/>
<wire x1="9.75" y1="0.375" x2="10.125" y2="0.375" width="0.0508" layer="21"/>
<wire x1="-9.75" y1="0.375" x2="-9.75" y2="1.125" width="0.0508" layer="21"/>
<wire x1="-9.75" y1="1.125" x2="9.75" y2="1.125" width="0.0508" layer="21"/>
<wire x1="9.75" y1="1.125" x2="9.75" y2="0.375" width="0.0508" layer="21"/>
<wire x1="9.75" y1="1.125" x2="10" y2="1.375" width="0.0508" layer="21"/>
<wire x1="-9.75" y1="1.125" x2="-10" y2="1.375" width="0.0508" layer="21"/>
<pad name="1" x="8.75" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="2" x="7.5" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="3" x="6.25" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="4" x="5" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="5" x="3.75" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="6" x="2.5" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="7" x="1.25" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="8" x="0" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="9" x="-1.25" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="10" x="-2.5" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="11" x="-3.75" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="12" x="-5" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="13" x="-6.25" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="14" x="-7.5" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="15" x="-8.75" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<text x="-10" y="1.75" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.25" y="1.75" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-10.125" y1="-1.5" x2="10.125" y2="-1.125" layer="21"/>
</package>
<package name="53047-14">
straight&lt;br&gt;
<wire x1="-9.525" y1="-1.5" x2="9.525" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="9.525" y1="-1.5" x2="9.525" y2="1.5" width="0.2032" layer="21"/>
<wire x1="9.525" y1="1.5" x2="-9.525" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-9.525" y1="1.5" x2="-9.525" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="-9.5" y1="-0.25" x2="-9.125" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="-9.125" y1="-0.25" x2="-9.125" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="9.125" y1="-0.25" x2="9.5" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="9.125" y1="-0.25" x2="9.125" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="-9.5" y1="0.375" x2="-9.125" y2="0.375" width="0.0508" layer="21"/>
<wire x1="9.125" y1="0.375" x2="9.5" y2="0.375" width="0.0508" layer="21"/>
<wire x1="-9.125" y1="0.375" x2="-9.125" y2="1.125" width="0.0508" layer="21"/>
<wire x1="-9.125" y1="1.125" x2="9.125" y2="1.125" width="0.0508" layer="21"/>
<wire x1="9.125" y1="1.125" x2="9.125" y2="0.375" width="0.0508" layer="21"/>
<wire x1="9.125" y1="1.125" x2="9.375" y2="1.375" width="0.0508" layer="21"/>
<wire x1="-9.125" y1="1.125" x2="-9.375" y2="1.375" width="0.0508" layer="21"/>
<pad name="1" x="8.125" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="2" x="6.875" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="3" x="5.625" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="4" x="4.375" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="5" x="3.125" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="6" x="1.875" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="7" x="0.625" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="8" x="-0.625" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="9" x="-1.875" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="10" x="-3.125" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="11" x="-4.375" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="12" x="-5.625" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="13" x="-6.875" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="14" x="-8.125" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<text x="-9.375" y="1.75" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.625" y="1.75" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-9.5" y1="-1.5" x2="9.5" y2="-1.125" layer="21"/>
</package>
<package name="53047-13">
straight&lt;br&gt;
<wire x1="-8.9" y1="-1.5" x2="8.9" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="8.9" y1="-1.5" x2="8.9" y2="1.5" width="0.2032" layer="21"/>
<wire x1="8.9" y1="1.5" x2="-8.9" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-8.9" y1="1.5" x2="-8.9" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="-8.875" y1="-0.25" x2="-8.5" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="-8.5" y1="-0.25" x2="-8.5" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="8.5" y1="-0.25" x2="8.875" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="8.5" y1="-0.25" x2="8.5" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="-8.875" y1="0.375" x2="-8.5" y2="0.375" width="0.0508" layer="21"/>
<wire x1="8.5" y1="0.375" x2="8.875" y2="0.375" width="0.0508" layer="21"/>
<wire x1="-8.5" y1="0.375" x2="-8.5" y2="1.125" width="0.0508" layer="21"/>
<wire x1="-8.5" y1="1.125" x2="8.5" y2="1.125" width="0.0508" layer="21"/>
<wire x1="8.5" y1="1.125" x2="8.5" y2="0.375" width="0.0508" layer="21"/>
<wire x1="8.5" y1="1.125" x2="8.75" y2="1.375" width="0.0508" layer="21"/>
<wire x1="-8.5" y1="1.125" x2="-8.75" y2="1.375" width="0.0508" layer="21"/>
<pad name="1" x="7.5" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="2" x="6.25" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="3" x="5" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="4" x="3.75" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="5" x="2.5" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="6" x="1.25" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="7" x="0" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="8" x="-1.25" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="9" x="-2.5" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="10" x="-3.75" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="11" x="-5" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="12" x="-6.25" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="13" x="-7.5" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<text x="-8.75" y="1.75" size="1.27" layer="25">&gt;NAME</text>
<text x="-2" y="1.75" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-8.875" y1="-1.5" x2="8.875" y2="-1.125" layer="21"/>
</package>
<package name="53047-12">
straight&lt;br&gt;
<wire x1="-8.275" y1="-1.5" x2="8.275" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="8.275" y1="-1.5" x2="8.275" y2="1.5" width="0.2032" layer="21"/>
<wire x1="8.275" y1="1.5" x2="-8.275" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-8.275" y1="1.5" x2="-8.275" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="-8.25" y1="-0.25" x2="-7.875" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="-7.875" y1="-0.25" x2="-7.875" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="7.875" y1="-0.25" x2="8.25" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="7.875" y1="-0.25" x2="7.875" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="-8.25" y1="0.375" x2="-7.875" y2="0.375" width="0.0508" layer="21"/>
<wire x1="7.875" y1="0.375" x2="8.25" y2="0.375" width="0.0508" layer="21"/>
<wire x1="-7.875" y1="0.375" x2="-7.875" y2="1.125" width="0.0508" layer="21"/>
<wire x1="-7.875" y1="1.125" x2="7.875" y2="1.125" width="0.0508" layer="21"/>
<wire x1="7.875" y1="1.125" x2="7.875" y2="0.375" width="0.0508" layer="21"/>
<wire x1="7.875" y1="1.125" x2="8.125" y2="1.375" width="0.0508" layer="21"/>
<wire x1="-7.875" y1="1.125" x2="-8.125" y2="1.375" width="0.0508" layer="21"/>
<pad name="1" x="6.875" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="2" x="5.625" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="3" x="4.375" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="4" x="3.125" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="5" x="1.875" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="6" x="0.625" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="7" x="-0.625" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="8" x="-1.875" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="9" x="-3.125" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="10" x="-4.375" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="11" x="-5.625" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="12" x="-6.875" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<text x="-8.125" y="1.75" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.375" y="1.75" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-8.25" y1="-1.5" x2="8.25" y2="-1.125" layer="21"/>
</package>
<package name="53047-11">
straight&lt;br&gt;
<wire x1="-7.65" y1="-1.5" x2="7.65" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="7.65" y1="-1.5" x2="7.65" y2="1.5" width="0.2032" layer="21"/>
<wire x1="7.65" y1="1.5" x2="-7.65" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-7.65" y1="1.5" x2="-7.65" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="-7.625" y1="-0.25" x2="-7.25" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="-7.25" y1="-0.25" x2="-7.25" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="7.25" y1="-0.25" x2="7.625" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="7.25" y1="-0.25" x2="7.25" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="-7.625" y1="0.375" x2="-7.25" y2="0.375" width="0.0508" layer="21"/>
<wire x1="7.25" y1="0.375" x2="7.625" y2="0.375" width="0.0508" layer="21"/>
<wire x1="-7.25" y1="0.375" x2="-7.25" y2="1.125" width="0.0508" layer="21"/>
<wire x1="-7.25" y1="1.125" x2="7.25" y2="1.125" width="0.0508" layer="21"/>
<wire x1="7.25" y1="1.125" x2="7.25" y2="0.375" width="0.0508" layer="21"/>
<wire x1="7.25" y1="1.125" x2="7.5" y2="1.375" width="0.0508" layer="21"/>
<wire x1="-7.25" y1="1.125" x2="-7.5" y2="1.375" width="0.0508" layer="21"/>
<pad name="1" x="6.25" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="2" x="5" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="3" x="3.75" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="4" x="2.5" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="5" x="1.25" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="6" x="0" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="7" x="-1.25" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="8" x="-2.5" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="9" x="-3.75" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="10" x="-5" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="11" x="-6.25" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<text x="-7.5" y="1.75" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.75" y="1.75" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-7.625" y1="-1.5" x2="7.625" y2="-1.125" layer="21"/>
</package>
<package name="53047-10">
straight&lt;br&gt;
<wire x1="-7.025" y1="-1.5" x2="7.025" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="7.025" y1="-1.5" x2="7.025" y2="1.5" width="0.2032" layer="21"/>
<wire x1="7.025" y1="1.5" x2="-7.025" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-7.025" y1="1.5" x2="-7.025" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="-7" y1="-0.25" x2="-6.625" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="-6.625" y1="-0.25" x2="-6.625" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="6.625" y1="-0.25" x2="7" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="6.625" y1="-0.25" x2="6.625" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="-7" y1="0.375" x2="-6.625" y2="0.375" width="0.0508" layer="21"/>
<wire x1="6.625" y1="0.375" x2="7" y2="0.375" width="0.0508" layer="21"/>
<wire x1="-6.625" y1="0.375" x2="-6.625" y2="1.125" width="0.0508" layer="21"/>
<wire x1="-6.625" y1="1.125" x2="6.625" y2="1.125" width="0.0508" layer="21"/>
<wire x1="6.625" y1="1.125" x2="6.625" y2="0.375" width="0.0508" layer="21"/>
<wire x1="6.625" y1="1.125" x2="6.875" y2="1.375" width="0.0508" layer="21"/>
<wire x1="-6.625" y1="1.125" x2="-6.875" y2="1.375" width="0.0508" layer="21"/>
<pad name="1" x="5.625" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="2" x="4.375" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="3" x="3.125" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="4" x="1.875" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="5" x="0.625" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="6" x="-0.625" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="7" x="-1.875" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="8" x="-3.125" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="9" x="-4.375" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="10" x="-5.625" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<text x="-6.875" y="1.75" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.125" y="1.75" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-7" y1="-1.5" x2="7" y2="-1.125" layer="21"/>
</package>
<package name="53047-09">
straight&lt;br&gt;
<wire x1="-6.4" y1="-1.5" x2="6.4" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="6.4" y1="-1.5" x2="6.4" y2="1.5" width="0.2032" layer="21"/>
<wire x1="6.4" y1="1.5" x2="-6.4" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="1.5" x2="-6.4" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="-6.375" y1="-0.25" x2="-6" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="-6" y1="-0.25" x2="-6" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="6" y1="-0.25" x2="6.375" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="6" y1="-0.25" x2="6" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="-6.375" y1="0.375" x2="-6" y2="0.375" width="0.0508" layer="21"/>
<wire x1="6" y1="0.375" x2="6.375" y2="0.375" width="0.0508" layer="21"/>
<wire x1="-6" y1="0.375" x2="-6" y2="1.125" width="0.0508" layer="21"/>
<wire x1="-6" y1="1.125" x2="6" y2="1.125" width="0.0508" layer="21"/>
<wire x1="6" y1="1.125" x2="6" y2="0.375" width="0.0508" layer="21"/>
<wire x1="6" y1="1.125" x2="6.25" y2="1.375" width="0.0508" layer="21"/>
<wire x1="-6" y1="1.125" x2="-6.25" y2="1.375" width="0.0508" layer="21"/>
<pad name="1" x="5" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="2" x="3.75" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="3" x="2.5" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="4" x="1.25" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="5" x="0" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="6" x="-1.25" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="7" x="-2.5" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="8" x="-3.75" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="9" x="-5" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<text x="-6.25" y="1.75" size="1.27" layer="25">&gt;NAME</text>
<text x="0.5" y="1.75" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-6.375" y1="-1.5" x2="6.375" y2="-1.125" layer="21"/>
</package>
<package name="53047-08">
straight&lt;br&gt;
<wire x1="-5.775" y1="-1.5" x2="5.775" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="5.775" y1="-1.5" x2="5.775" y2="1.5" width="0.2032" layer="21"/>
<wire x1="5.775" y1="1.5" x2="-5.775" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-5.775" y1="1.5" x2="-5.775" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="-5.75" y1="-0.25" x2="-5.375" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="-5.375" y1="-0.25" x2="-5.375" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="5.375" y1="-0.25" x2="5.75" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="5.375" y1="-0.25" x2="5.375" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="-5.75" y1="0.375" x2="-5.375" y2="0.375" width="0.0508" layer="21"/>
<wire x1="5.375" y1="0.375" x2="5.75" y2="0.375" width="0.0508" layer="21"/>
<wire x1="-5.375" y1="0.375" x2="-5.375" y2="1.125" width="0.0508" layer="21"/>
<wire x1="-5.375" y1="1.125" x2="5.375" y2="1.125" width="0.0508" layer="21"/>
<wire x1="5.375" y1="1.125" x2="5.375" y2="0.375" width="0.0508" layer="21"/>
<wire x1="5.375" y1="1.125" x2="5.625" y2="1.375" width="0.0508" layer="21"/>
<wire x1="-5.375" y1="1.125" x2="-5.625" y2="1.375" width="0.0508" layer="21"/>
<pad name="1" x="4.375" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="2" x="3.125" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="3" x="1.875" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="4" x="0.625" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="5" x="-0.625" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="6" x="-1.875" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="7" x="-3.125" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="8" x="-4.375" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<text x="-5.625" y="1.75" size="1.27" layer="25">&gt;NAME</text>
<text x="1.125" y="1.75" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-5.75" y1="-1.5" x2="5.75" y2="-1.125" layer="21"/>
</package>
<package name="53047-07">
straight&lt;br&gt;
<wire x1="-5.15" y1="-1.5" x2="5.15" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="5.15" y1="-1.5" x2="5.15" y2="1.5" width="0.2032" layer="21"/>
<wire x1="5.15" y1="1.5" x2="-5.15" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-5.15" y1="1.5" x2="-5.15" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="-5.125" y1="-0.25" x2="-4.75" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="-4.75" y1="-0.25" x2="-4.75" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="4.75" y1="-0.25" x2="5.125" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="4.75" y1="-0.25" x2="4.75" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="-5.125" y1="0.375" x2="-4.75" y2="0.375" width="0.0508" layer="21"/>
<wire x1="4.75" y1="0.375" x2="5.125" y2="0.375" width="0.0508" layer="21"/>
<wire x1="-4.75" y1="0.375" x2="-4.75" y2="1.125" width="0.0508" layer="21"/>
<wire x1="-4.75" y1="1.125" x2="4.75" y2="1.125" width="0.0508" layer="21"/>
<wire x1="4.75" y1="1.125" x2="4.75" y2="0.375" width="0.0508" layer="21"/>
<wire x1="4.75" y1="1.125" x2="5" y2="1.375" width="0.0508" layer="21"/>
<wire x1="-4.75" y1="1.125" x2="-5" y2="1.375" width="0.0508" layer="21"/>
<pad name="1" x="3.75" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R270"/>
<pad name="2" x="2.5" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R270"/>
<pad name="3" x="1.25" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R270"/>
<pad name="4" x="0" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R270"/>
<pad name="5" x="-1.25" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R270"/>
<pad name="6" x="-2.5" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R270"/>
<pad name="7" x="-3.75" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R270"/>
<text x="-5" y="1.75" size="1.27" layer="25">&gt;NAME</text>
<text x="-4.5" y="-3.25" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-5.125" y1="-1.5" x2="5.125" y2="-1.125" layer="21"/>
</package>
<package name="53047-06">
straight&lt;br&gt;
<wire x1="-4.525" y1="-1.5" x2="4.525" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="4.525" y1="-1.5" x2="4.525" y2="1.5" width="0.2032" layer="21"/>
<wire x1="4.525" y1="1.5" x2="-4.525" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-4.525" y1="1.5" x2="-4.525" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="-4.5" y1="-0.25" x2="-4.125" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="-4.125" y1="-0.25" x2="-4.125" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="4.125" y1="-0.25" x2="4.5" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="4.125" y1="-0.25" x2="4.125" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="-4.5" y1="0.375" x2="-4.125" y2="0.375" width="0.0508" layer="21"/>
<wire x1="4.125" y1="0.375" x2="4.5" y2="0.375" width="0.0508" layer="21"/>
<wire x1="-4.125" y1="0.375" x2="-4.125" y2="1.125" width="0.0508" layer="21"/>
<wire x1="-4.125" y1="1.125" x2="4.125" y2="1.125" width="0.0508" layer="21"/>
<wire x1="4.125" y1="1.125" x2="4.125" y2="0.375" width="0.0508" layer="21"/>
<wire x1="4.125" y1="1.125" x2="4.375" y2="1.375" width="0.0508" layer="21"/>
<wire x1="-4.125" y1="1.125" x2="-4.375" y2="1.375" width="0.0508" layer="21"/>
<pad name="1" x="3.125" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="2" x="1.875" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="3" x="0.625" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="4" x="-0.625" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="5" x="-1.875" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="6" x="-3.125" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<text x="-4.375" y="1.75" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.875" y="-3.25" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-4.5" y1="-1.5" x2="4.5" y2="-1.125" layer="21"/>
</package>
<package name="53047-05">
straight&lt;br&gt;
<wire x1="-3.9" y1="-1.5" x2="3.9" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="3.9" y1="-1.5" x2="3.9" y2="1.5" width="0.2032" layer="21"/>
<wire x1="3.9" y1="1.5" x2="-3.9" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-3.9" y1="1.5" x2="-3.9" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="-3.875" y1="-0.25" x2="-3.5" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="-3.5" y1="-0.25" x2="-3.5" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="3.5" y1="-0.25" x2="3.875" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="3.5" y1="-0.25" x2="3.5" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="-3.875" y1="0.375" x2="-3.5" y2="0.375" width="0.0508" layer="21"/>
<wire x1="3.5" y1="0.375" x2="3.875" y2="0.375" width="0.0508" layer="21"/>
<wire x1="-3.5" y1="0.375" x2="-3.5" y2="1.125" width="0.0508" layer="21"/>
<wire x1="-3.5" y1="1.125" x2="3.5" y2="1.125" width="0.0508" layer="21"/>
<wire x1="3.5" y1="1.125" x2="3.5" y2="0.375" width="0.0508" layer="21"/>
<wire x1="3.5" y1="1.125" x2="3.75" y2="1.375" width="0.0508" layer="21"/>
<wire x1="-3.5" y1="1.125" x2="-3.75" y2="1.375" width="0.0508" layer="21"/>
<pad name="1" x="2.5" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="2" x="1.25" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="3" x="0" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="4" x="-1.25" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="5" x="-2.5" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<text x="-3.75" y="1.75" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.25" y="-3.25" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3.875" y1="-1.5" x2="3.875" y2="-1.125" layer="21"/>
</package>
<package name="53047-04">
straight&lt;br&gt;
<wire x1="-3.275" y1="-1.5" x2="3.275" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="3.275" y1="-1.5" x2="3.275" y2="1.5" width="0.2032" layer="21"/>
<wire x1="3.275" y1="1.5" x2="-3.275" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-3.275" y1="1.5" x2="-3.275" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="-3.25" y1="-0.25" x2="-2.875" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="-2.875" y1="-0.25" x2="-2.875" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="2.875" y1="-0.25" x2="3.25" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="2.875" y1="-0.25" x2="2.875" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="-3.25" y1="0.375" x2="-2.875" y2="0.375" width="0.0508" layer="21"/>
<wire x1="2.875" y1="0.375" x2="3.25" y2="0.375" width="0.0508" layer="21"/>
<wire x1="-2.875" y1="0.375" x2="-2.875" y2="1.125" width="0.0508" layer="21"/>
<wire x1="-2.875" y1="1.125" x2="2.875" y2="1.125" width="0.0508" layer="21"/>
<wire x1="2.875" y1="1.125" x2="2.875" y2="0.375" width="0.0508" layer="21"/>
<wire x1="2.875" y1="1.125" x2="3.125" y2="1.375" width="0.0508" layer="21"/>
<wire x1="-2.875" y1="1.125" x2="-3.125" y2="1.375" width="0.0508" layer="21"/>
<pad name="1" x="1.875" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="2" x="0.625" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="3" x="-0.625" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="4" x="-1.875" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<text x="-3.125" y="1.75" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.625" y="-3.25" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3.25" y1="-1.5" x2="3.25" y2="-1.125" layer="21"/>
</package>
<package name="53047-03">
straight&lt;br&gt;
<wire x1="-2.65" y1="-1.5" x2="2.65" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="2.65" y1="-1.5" x2="2.65" y2="1.5" width="0.2032" layer="21"/>
<wire x1="2.65" y1="1.5" x2="-2.65" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-2.65" y1="1.5" x2="-2.65" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="-2.625" y1="-0.25" x2="-2.25" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="-2.25" y1="-0.25" x2="-2.25" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="2.25" y1="-0.25" x2="2.625" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="2.25" y1="-0.25" x2="2.25" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="-2.625" y1="0.375" x2="-2.25" y2="0.375" width="0.0508" layer="21"/>
<wire x1="2.25" y1="0.375" x2="2.625" y2="0.375" width="0.0508" layer="21"/>
<wire x1="-2.25" y1="0.375" x2="-2.25" y2="1.125" width="0.0508" layer="21"/>
<wire x1="-2.25" y1="1.125" x2="2.25" y2="1.125" width="0.0508" layer="21"/>
<wire x1="2.25" y1="1.125" x2="2.25" y2="0.375" width="0.0508" layer="21"/>
<wire x1="2.25" y1="1.125" x2="2.5" y2="1.375" width="0.0508" layer="21"/>
<wire x1="-2.25" y1="1.125" x2="-2.5" y2="1.375" width="0.0508" layer="21"/>
<pad name="1" x="1.25" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="2" x="0" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="3" x="-1.25" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<text x="-2.5" y="1.75" size="1.27" layer="25">&gt;NAME</text>
<text x="-2" y="-3.25" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.625" y1="-1.5" x2="2.625" y2="-1.125" layer="21"/>
</package>
<package name="53047-02">
straight&lt;br&gt;
<wire x1="-2.025" y1="-1.5" x2="2.025" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="2.025" y1="-1.5" x2="2.025" y2="1.5" width="0.2032" layer="21"/>
<wire x1="2.025" y1="1.5" x2="-2.025" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-2.025" y1="1.5" x2="-2.025" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="-2" y1="-0.25" x2="-1.625" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="-1.625" y1="-0.25" x2="-1.625" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="1.625" y1="-0.25" x2="2" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="1.625" y1="-0.25" x2="1.625" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="-2" y1="0.375" x2="-1.625" y2="0.375" width="0.0508" layer="21"/>
<wire x1="1.625" y1="0.375" x2="2" y2="0.375" width="0.0508" layer="21"/>
<wire x1="-1.625" y1="0.375" x2="-1.625" y2="1.125" width="0.0508" layer="21"/>
<wire x1="-1.625" y1="1.125" x2="1.625" y2="1.125" width="0.0508" layer="21"/>
<wire x1="1.625" y1="1.125" x2="1.625" y2="0.375" width="0.0508" layer="21"/>
<wire x1="1.625" y1="1.125" x2="1.875" y2="1.375" width="0.0508" layer="21"/>
<wire x1="-1.625" y1="1.125" x2="-1.875" y2="1.375" width="0.0508" layer="21"/>
<pad name="1" x="0.625" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="2" x="-0.625" y="0.45" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<text x="-1.875" y="1.75" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.375" y="-3.25" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2" y1="-1.5" x2="2" y2="-1.125" layer="21"/>
</package>
<package name="53048-15">
right angle</description>
<wire x1="-10.15" y1="-2.25" x2="-9.625" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="9.625" y1="-2.25" x2="10.15" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="10.15" y1="-2.25" x2="10.15" y2="3.125" width="0.2032" layer="21"/>
<wire x1="10.15" y1="3.125" x2="10" y2="3.125" width="0.2032" layer="21"/>
<wire x1="10" y1="3.125" x2="-10" y2="3.125" width="0.2032" layer="21"/>
<wire x1="-10" y1="3.125" x2="-10.15" y2="3.125" width="0.2032" layer="21"/>
<wire x1="-10.15" y1="3.125" x2="-10.15" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="-10.125" y1="1.5" x2="-9.625" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-9.625" y1="1.5" x2="-9.375" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-9.375" y1="1.5" x2="-9.375" y2="0.625" width="0.0508" layer="21"/>
<wire x1="-9.375" y1="0.625" x2="9.375" y2="0.625" width="0.0508" layer="21"/>
<wire x1="9.375" y1="1.5" x2="9.625" y2="1.5" width="0.0508" layer="21"/>
<wire x1="9.625" y1="1.5" x2="10.125" y2="1.5" width="0.0508" layer="21"/>
<wire x1="9.375" y1="1.5" x2="9.375" y2="0.625" width="0.0508" layer="21"/>
<wire x1="-9.625" y1="-1" x2="9.625" y2="-1" width="0.2032" layer="51"/>
<wire x1="-9" y1="-1.5" x2="-9.125" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-7.75" y1="-1.5" x2="-7.875" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-7.875" y1="-1.625" x2="-8.375" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-8.5" y1="-1.5" x2="-8.375" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-6.5" y1="-1.5" x2="-6.625" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-6.625" y1="-1.625" x2="-7.125" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-7.25" y1="-1.5" x2="-7.125" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-5.25" y1="-1.5" x2="-5.375" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-5.375" y1="-1.625" x2="-5.875" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-6" y1="-1.5" x2="-5.875" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-4" y1="-1.5" x2="-4.125" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-4.125" y1="-1.625" x2="-4.625" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-4.75" y1="-1.5" x2="-4.625" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-2.75" y1="-1.5" x2="-2.875" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-2.875" y1="-1.625" x2="-3.375" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-3.5" y1="-1.5" x2="-3.375" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-1.5" y1="-1.5" x2="-1.625" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-1.625" y1="-1.625" x2="-2.125" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-2.25" y1="-1.5" x2="-2.125" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-0.25" y1="-1.5" x2="-0.375" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-0.375" y1="-1.625" x2="-0.875" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-1" y1="-1.5" x2="-0.875" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="1" y1="-1.5" x2="0.875" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="0.875" y1="-1.625" x2="0.375" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="0.25" y1="-1.5" x2="0.375" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="2.25" y1="-1.5" x2="2.125" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="2.125" y1="-1.625" x2="1.625" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="1.5" y1="-1.5" x2="1.625" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="3.5" y1="-1.5" x2="3.375" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="3.375" y1="-1.625" x2="2.875" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="2.75" y1="-1.5" x2="2.875" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="4.75" y1="-1.5" x2="4.625" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="4.625" y1="-1.625" x2="4.125" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="4" y1="-1.5" x2="4.125" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="6" y1="-1.5" x2="5.875" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="5.875" y1="-1.625" x2="5.375" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="5.25" y1="-1.5" x2="5.375" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="7.25" y1="-1.5" x2="7.125" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="7.125" y1="-1.625" x2="6.625" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="6.5" y1="-1.5" x2="6.625" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="8.5" y1="-1.5" x2="8.375" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="8.375" y1="-1.625" x2="7.875" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="7.75" y1="-1.5" x2="7.875" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="9.625" y1="-1.625" x2="9.125" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="9" y1="-1.5" x2="9.125" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-9.125" y1="-1.625" x2="-9.625" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-10.125" y1="-1" x2="-9.625" y2="-1" width="0.2032" layer="21"/>
<wire x1="-9.625" y1="-1" x2="-9.625" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="9.625" y1="-1" x2="10.125" y2="-1" width="0.2032" layer="21"/>
<wire x1="9.625" y1="-1" x2="9.625" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="-9.625" y1="1.5" x2="-9.625" y2="2.75" width="0.0508" layer="21"/>
<wire x1="-9.625" y1="2.75" x2="9.625" y2="2.75" width="0.0508" layer="21"/>
<wire x1="9.625" y1="2.75" x2="9.625" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-9.625" y1="2.75" x2="-10" y2="3.125" width="0.0508" layer="21"/>
<wire x1="9.625" y1="2.75" x2="10" y2="3.125" width="0.0508" layer="21"/>
<wire x1="-8.875" y1="1.5" x2="-8.75" y2="2" width="0.2032" layer="21"/>
<wire x1="-8.75" y1="2" x2="-8.625" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-7.625" y1="1.5" x2="-7.5" y2="2" width="0.2032" layer="21"/>
<wire x1="-7.5" y1="2" x2="-7.375" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-6.375" y1="1.5" x2="-6.25" y2="2" width="0.2032" layer="21"/>
<wire x1="-6.25" y1="2" x2="-6.125" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-5.125" y1="1.5" x2="-5" y2="2" width="0.2032" layer="21"/>
<wire x1="-5" y1="2" x2="-4.875" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-3.875" y1="1.5" x2="-3.75" y2="2" width="0.2032" layer="21"/>
<wire x1="-3.75" y1="2" x2="-3.625" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-2.625" y1="1.5" x2="-2.5" y2="2" width="0.2032" layer="21"/>
<wire x1="-2.5" y1="2" x2="-2.375" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-1.375" y1="1.5" x2="-1.25" y2="2" width="0.2032" layer="21"/>
<wire x1="-1.25" y1="2" x2="-1.125" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-0.125" y1="1.5" x2="0" y2="2" width="0.2032" layer="21"/>
<wire x1="0" y1="2" x2="0.125" y2="1.5" width="0.2032" layer="21"/>
<wire x1="1.125" y1="1.5" x2="1.25" y2="2" width="0.2032" layer="21"/>
<wire x1="1.25" y1="2" x2="1.375" y2="1.5" width="0.2032" layer="21"/>
<wire x1="2.375" y1="1.5" x2="2.5" y2="2" width="0.2032" layer="21"/>
<wire x1="2.5" y1="2" x2="2.625" y2="1.5" width="0.2032" layer="21"/>
<wire x1="3.625" y1="1.5" x2="3.75" y2="2" width="0.2032" layer="21"/>
<wire x1="3.75" y1="2" x2="3.875" y2="1.5" width="0.2032" layer="21"/>
<wire x1="4.875" y1="1.5" x2="5" y2="2" width="0.2032" layer="21"/>
<wire x1="5" y1="2" x2="5.125" y2="1.5" width="0.2032" layer="21"/>
<wire x1="6.125" y1="1.5" x2="6.25" y2="2" width="0.2032" layer="21"/>
<wire x1="6.25" y1="2" x2="6.375" y2="1.5" width="0.2032" layer="21"/>
<wire x1="7.375" y1="1.5" x2="7.5" y2="2" width="0.2032" layer="21"/>
<wire x1="7.5" y1="2" x2="7.625" y2="1.5" width="0.2032" layer="21"/>
<wire x1="8.625" y1="1.5" x2="8.75" y2="2" width="0.2032" layer="21"/>
<wire x1="8.75" y1="2" x2="8.875" y2="1.5" width="0.2032" layer="21"/>
<pad name="1" x="8.75" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="2" x="7.5" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="3" x="6.25" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="4" x="5" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="5" x="3.75" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="6" x="2.5" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="7" x="1.25" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="8" x="0" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="9" x="-1.25" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="10" x="-2.5" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="11" x="-3.75" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="12" x="-5" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="13" x="-6.25" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="14" x="-7.5" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="15" x="-8.75" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<text x="-8.75" y="3.375" size="1.27" layer="25">&gt;NAME</text>
<text x="-9.375" y="-3.625" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-9" y1="-1.5" x2="-8.5" y2="-1" layer="51"/>
<rectangle x1="-9" y1="0.625" x2="-8.5" y2="1.5" layer="21"/>
<rectangle x1="-7.75" y1="-1.5" x2="-7.25" y2="-1" layer="51"/>
<rectangle x1="-6.5" y1="-1.5" x2="-6" y2="-1" layer="51"/>
<rectangle x1="-5.25" y1="-1.5" x2="-4.75" y2="-1" layer="51"/>
<rectangle x1="-4" y1="-1.5" x2="-3.5" y2="-1" layer="51"/>
<rectangle x1="-2.75" y1="-1.5" x2="-2.25" y2="-1" layer="51"/>
<rectangle x1="-1.5" y1="-1.5" x2="-1" y2="-1" layer="51"/>
<rectangle x1="-0.25" y1="-1.5" x2="0.25" y2="-1" layer="51"/>
<rectangle x1="1" y1="-1.5" x2="1.5" y2="-1" layer="51"/>
<rectangle x1="2.25" y1="-1.5" x2="2.75" y2="-1" layer="51"/>
<rectangle x1="3.5" y1="-1.5" x2="4" y2="-1" layer="51"/>
<rectangle x1="4.75" y1="-1.5" x2="5.25" y2="-1" layer="51"/>
<rectangle x1="6" y1="-1.5" x2="6.5" y2="-1" layer="51"/>
<rectangle x1="7.25" y1="-1.5" x2="7.75" y2="-1" layer="51"/>
<rectangle x1="8.5" y1="-1.5" x2="9" y2="-1" layer="51"/>
<rectangle x1="-7.75" y1="0.625" x2="-7.25" y2="1.5" layer="21"/>
<rectangle x1="-6.5" y1="0.625" x2="-6" y2="1.5" layer="21"/>
<rectangle x1="-5.25" y1="0.625" x2="-4.75" y2="1.5" layer="21"/>
<rectangle x1="-4" y1="0.625" x2="-3.5" y2="1.5" layer="21"/>
<rectangle x1="-2.75" y1="0.625" x2="-2.25" y2="1.5" layer="21"/>
<rectangle x1="-1.5" y1="0.625" x2="-1" y2="1.5" layer="21"/>
<rectangle x1="-0.25" y1="0.625" x2="0.25" y2="1.5" layer="21"/>
<rectangle x1="1" y1="0.625" x2="1.5" y2="1.5" layer="21"/>
<rectangle x1="2.25" y1="0.625" x2="2.75" y2="1.5" layer="21"/>
<rectangle x1="3.5" y1="0.625" x2="4" y2="1.5" layer="21"/>
<rectangle x1="4.75" y1="0.625" x2="5.25" y2="1.5" layer="21"/>
<rectangle x1="6" y1="0.625" x2="6.5" y2="1.5" layer="21"/>
<rectangle x1="7.25" y1="0.625" x2="7.75" y2="1.5" layer="21"/>
<rectangle x1="8.5" y1="0.625" x2="9" y2="1.5" layer="21"/>
</package>
<package name="53261-15">
SMT&lt;p&gt;
<wire x1="-10.15" y1="-1.375" x2="-9.625" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-9.625" y1="-1.375" x2="9.625" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="9.625" y1="-1.375" x2="10.15" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="10.15" y1="-1.375" x2="10.15" y2="2.625" width="0.2032" layer="21"/>
<wire x1="10.15" y1="2.625" x2="10" y2="2.625" width="0.2032" layer="21"/>
<wire x1="10" y1="2.625" x2="-10" y2="2.625" width="0.2032" layer="21"/>
<wire x1="-10" y1="2.625" x2="-10.15" y2="2.625" width="0.2032" layer="21"/>
<wire x1="-10.15" y1="2.625" x2="-10.15" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-10.125" y1="1.625" x2="-9.625" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-9.625" y1="1.625" x2="-9.375" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-9.375" y1="1.625" x2="-9.375" y2="1" width="0.0508" layer="21"/>
<wire x1="-9.375" y1="1" x2="9.375" y2="1" width="0.0508" layer="21"/>
<wire x1="9.375" y1="1.625" x2="9.625" y2="1.625" width="0.0508" layer="21"/>
<wire x1="9.625" y1="1.625" x2="10.125" y2="1.625" width="0.0508" layer="21"/>
<wire x1="9.375" y1="1.625" x2="9.375" y2="1" width="0.0508" layer="21"/>
<wire x1="-10.125" y1="-0.75" x2="-9.625" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-9.625" y1="-0.75" x2="-9.625" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="9.625" y1="-0.75" x2="10.125" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="9.625" y1="-0.75" x2="9.625" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="-9.625" y1="1.625" x2="-9.625" y2="2.25" width="0.0508" layer="21"/>
<wire x1="-9.625" y1="2.25" x2="9.625" y2="2.25" width="0.0508" layer="21"/>
<wire x1="9.625" y1="2.25" x2="9.625" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-9.625" y1="2.25" x2="-10" y2="2.625" width="0.0508" layer="21"/>
<wire x1="9.625" y1="2.25" x2="10" y2="2.625" width="0.0508" layer="21"/>
<wire x1="-9" y1="-1.25" x2="-9" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-9" y1="-0.75" x2="-8.5" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-8.5" y1="-0.75" x2="-8.5" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="-7.75" y1="-1.25" x2="-7.75" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-7.75" y1="-0.75" x2="-7.25" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-7.25" y1="-0.75" x2="-7.25" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="-6.5" y1="-1.25" x2="-6.5" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-6.5" y1="-0.75" x2="-6" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-6" y1="-0.75" x2="-6" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="-5.25" y1="-1.25" x2="-5.25" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-5.25" y1="-0.75" x2="-4.75" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-4.75" y1="-0.75" x2="-4.75" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="-4" y1="-1.25" x2="-4" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-4" y1="-0.75" x2="-3.5" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-3.5" y1="-0.75" x2="-3.5" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="-2.75" y1="-1.25" x2="-2.75" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-2.75" y1="-0.75" x2="-2.25" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-2.25" y1="-0.75" x2="-2.25" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="-1.5" y1="-1.25" x2="-1.5" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-1.5" y1="-0.75" x2="-1" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-1" y1="-0.75" x2="-1" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="-0.25" y1="-1.25" x2="-0.25" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-0.25" y1="-0.75" x2="0.25" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="0.25" y1="-0.75" x2="0.25" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="1" y1="-1.25" x2="1" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="1" y1="-0.75" x2="1.5" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="1.5" y1="-0.75" x2="1.5" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="2.25" y1="-1.25" x2="2.25" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="2.25" y1="-0.75" x2="2.75" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="2.75" y1="-0.75" x2="2.75" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="3.5" y1="-1.25" x2="3.5" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="3.5" y1="-0.75" x2="4" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="4" y1="-0.75" x2="4" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="4.75" y1="-1.25" x2="4.75" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="4.75" y1="-0.75" x2="5.25" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="5.25" y1="-0.75" x2="5.25" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="6" y1="-1.25" x2="6" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="6" y1="-0.75" x2="6.5" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="6.5" y1="-0.75" x2="6.5" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="7.25" y1="-1.25" x2="7.25" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="7.25" y1="-0.75" x2="7.75" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="7.75" y1="-0.75" x2="7.75" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="8.5" y1="-1.25" x2="8.5" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="8.5" y1="-0.75" x2="9" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="9" y1="-0.75" x2="9" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="-10.25" y1="2.25" x2="-12.125" y2="2.25" width="0.2032" layer="51"/>
<wire x1="-12.125" y1="2.25" x2="-12.125" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="-12.125" y1="-0.75" x2="-10.25" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="10.25" y1="-0.75" x2="12.125" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="12.125" y1="-0.75" x2="12.125" y2="2.25" width="0.2032" layer="51"/>
<wire x1="12.125" y1="2.25" x2="10.25" y2="2.25" width="0.2032" layer="51"/>
<smd name="1" x="8.75" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="2" x="7.5" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="3" x="6.25" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="4" x="5" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="5" x="3.75" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="6" x="2.5" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="7" x="1.25" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="8" x="0" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="9" x="-1.25" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="10" x="-2.5" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="11" x="-3.75" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="12" x="-5" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="13" x="-6.25" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="14" x="-7.5" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="15" x="-8.75" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="S1" x="11.25" y="0.625" dx="2.1" dy="3" layer="1"/>
<smd name="S2" x="-11.25" y="0.625" dx="2.1" dy="3" layer="1"/>
<text x="-8.75" y="2.875" size="1.27" layer="25">&gt;NAME</text>
<text x="-8.875" y="-0.5" size="1.27" layer="27">&gt;VALUE</text>
<text x="10.75" y="-0.25" size="1.9304" layer="51">1</text>
<rectangle x1="-9" y1="1" x2="-8.5" y2="1.875" layer="21"/>
<rectangle x1="-7.75" y1="1" x2="-7.25" y2="1.875" layer="21"/>
<rectangle x1="-6.5" y1="1" x2="-6" y2="1.875" layer="21"/>
<rectangle x1="-5.25" y1="1" x2="-4.75" y2="1.875" layer="21"/>
<rectangle x1="-4" y1="1" x2="-3.5" y2="1.875" layer="21"/>
<rectangle x1="-2.75" y1="1" x2="-2.25" y2="1.875" layer="21"/>
<rectangle x1="-1.5" y1="1" x2="-1" y2="1.875" layer="21"/>
<rectangle x1="-0.25" y1="1" x2="0.25" y2="1.875" layer="21"/>
<rectangle x1="1" y1="1" x2="1.5" y2="1.875" layer="21"/>
<rectangle x1="2.25" y1="1" x2="2.75" y2="1.875" layer="21"/>
<rectangle x1="3.5" y1="1" x2="4" y2="1.875" layer="21"/>
<rectangle x1="4.75" y1="1" x2="5.25" y2="1.875" layer="21"/>
<rectangle x1="6" y1="1" x2="6.5" y2="1.875" layer="21"/>
<rectangle x1="7.25" y1="1" x2="7.75" y2="1.875" layer="21"/>
<rectangle x1="8.5" y1="1" x2="9" y2="1.875" layer="21"/>
</package>
<package name="53261-14">
<description>&lt;b&gt;CONNECTOR&lt;/b&gt;&lt;p&gt;
SMT&lt;p&gt;
<wire x1="-9.525" y1="-1.375" x2="-9" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-9" y1="-1.375" x2="9" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="9" y1="-1.375" x2="9.525" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="9.525" y1="-1.375" x2="9.525" y2="2.625" width="0.2032" layer="21"/>
<wire x1="9.525" y1="2.625" x2="9.375" y2="2.625" width="0.2032" layer="21"/>
<wire x1="9.375" y1="2.625" x2="-9.375" y2="2.625" width="0.2032" layer="21"/>
<wire x1="-9.375" y1="2.625" x2="-9.525" y2="2.625" width="0.2032" layer="21"/>
<wire x1="-9.525" y1="2.625" x2="-9.525" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-9.5" y1="1.625" x2="-9" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-9" y1="1.625" x2="-8.75" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-8.75" y1="1.625" x2="-8.75" y2="1" width="0.0508" layer="21"/>
<wire x1="-8.75" y1="1" x2="8.75" y2="1" width="0.0508" layer="21"/>
<wire x1="8.75" y1="1.625" x2="9" y2="1.625" width="0.0508" layer="21"/>
<wire x1="9" y1="1.625" x2="9.5" y2="1.625" width="0.0508" layer="21"/>
<wire x1="8.75" y1="1.625" x2="8.75" y2="1" width="0.0508" layer="21"/>
<wire x1="-9.5" y1="-0.75" x2="-9" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-9" y1="-0.75" x2="-9" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="9" y1="-0.75" x2="9.5" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="9" y1="-0.75" x2="9" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="-9" y1="1.625" x2="-9" y2="2.25" width="0.0508" layer="21"/>
<wire x1="-9" y1="2.25" x2="9" y2="2.25" width="0.0508" layer="21"/>
<wire x1="9" y1="2.25" x2="9" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-9" y1="2.25" x2="-9.375" y2="2.625" width="0.0508" layer="21"/>
<wire x1="9" y1="2.25" x2="9.375" y2="2.625" width="0.0508" layer="21"/>
<wire x1="-8.375" y1="-1.25" x2="-8.375" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-8.375" y1="-0.75" x2="-7.875" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-7.875" y1="-0.75" x2="-7.875" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="-7.125" y1="-1.25" x2="-7.125" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-7.125" y1="-0.75" x2="-6.625" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-6.625" y1="-0.75" x2="-6.625" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="-5.875" y1="-1.25" x2="-5.875" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-5.875" y1="-0.75" x2="-5.375" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-5.375" y1="-0.75" x2="-5.375" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="-4.625" y1="-1.25" x2="-4.625" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-4.625" y1="-0.75" x2="-4.125" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-4.125" y1="-0.75" x2="-4.125" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="-3.375" y1="-1.25" x2="-3.375" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-3.375" y1="-0.75" x2="-2.875" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-2.875" y1="-0.75" x2="-2.875" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="-2.125" y1="-1.25" x2="-2.125" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-2.125" y1="-0.75" x2="-1.625" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-1.625" y1="-0.75" x2="-1.625" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="-0.875" y1="-1.25" x2="-0.875" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-0.875" y1="-0.75" x2="-0.375" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-0.375" y1="-0.75" x2="-0.375" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="0.375" y1="-1.25" x2="0.375" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="0.375" y1="-0.75" x2="0.875" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="0.875" y1="-0.75" x2="0.875" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="1.625" y1="-1.25" x2="1.625" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="1.625" y1="-0.75" x2="2.125" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="2.125" y1="-0.75" x2="2.125" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="2.875" y1="-1.25" x2="2.875" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="2.875" y1="-0.75" x2="3.375" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="3.375" y1="-0.75" x2="3.375" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="4.125" y1="-1.25" x2="4.125" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="4.125" y1="-0.75" x2="4.625" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="4.625" y1="-0.75" x2="4.625" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="5.375" y1="-1.25" x2="5.375" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="5.375" y1="-0.75" x2="5.875" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="5.875" y1="-0.75" x2="5.875" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="6.625" y1="-1.25" x2="6.625" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="6.625" y1="-0.75" x2="7.125" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="7.125" y1="-0.75" x2="7.125" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="7.875" y1="-1.25" x2="7.875" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="7.875" y1="-0.75" x2="8.375" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="8.375" y1="-0.75" x2="8.375" y2="-1.25" width="0.0508" layer="21"/>
<wire x1="-9.625" y1="2.25" x2="-11.5" y2="2.25" width="0.2032" layer="51"/>
<wire x1="-11.5" y1="2.25" x2="-11.5" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="-11.5" y1="-0.75" x2="-9.625" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="9.625" y1="-0.75" x2="11.5" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="11.5" y1="-0.75" x2="11.5" y2="2.25" width="0.2032" layer="51"/>
<wire x1="11.5" y1="2.25" x2="9.625" y2="2.25" width="0.2032" layer="51"/>
<smd name="1" x="8.125" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="2" x="6.875" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="3" x="5.625" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="4" x="4.375" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="5" x="3.125" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="6" x="1.875" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="7" x="0.625" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="8" x="-0.625" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="9" x="-1.875" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="10" x="-3.125" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="11" x="-4.375" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="12" x="-5.625" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="13" x="-6.875" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="14" x="-8.125" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="S1" x="10.625" y="0.625" dx="2.1" dy="3" layer="1"/>
<smd name="S2" x="-10.625" y="0.625" dx="2.1" dy="3" layer="1"/>
<text x="-8.125" y="2.875" size="1.27" layer="25">&gt;NAME</text>
<text x="-8.25" y="-0.5" size="1.27" layer="27">&gt;VALUE</text>
<text x="10" y="-0.25" size="1.9304" layer="51">1</text>
<rectangle x1="-8.375" y1="1" x2="-7.875" y2="1.875" layer="21"/>
<rectangle x1="-7.125" y1="1" x2="-6.625" y2="1.875" layer="21"/>
<rectangle x1="-5.875" y1="1" x2="-5.375" y2="1.875" layer="21"/>
<rectangle x1="-4.625" y1="1" x2="-4.125" y2="1.875" layer="21"/>
<rectangle x1="-3.375" y1="1" x2="-2.875" y2="1.875" layer="21"/>
<rectangle x1="-2.125" y1="1" x2="-1.625" y2="1.875" layer="21"/>
<rectangle x1="-0.875" y1="1" x2="-0.375" y2="1.875" layer="21"/>
<rectangle x1="0.375" y1="1" x2="0.875" y2="1.875" layer="21"/>
<rectangle x1="1.625" y1="1" x2="2.125" y2="1.875" layer="21"/>
<rectangle x1="2.875" y1="1" x2="3.375" y2="1.875" layer="21"/>
<rectangle x1="4.125" y1="1" x2="4.625" y2="1.875" layer="21"/>
<rectangle x1="5.375" y1="1" x2="5.875" y2="1.875" layer="21"/>
<rectangle x1="6.625" y1="1" x2="7.125" y2="1.875" layer="21"/>
<rectangle x1="7.875" y1="1" x2="8.375" y2="1.875" layer="21"/>
</package>
<package name="53261-13">
SMT&lt;p&gt;
<wire x1="-8.9" y1="-1.375" x2="-8.375" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-8.375" y1="-1.375" x2="8.375" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="8.375" y1="-1.375" x2="8.9" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="8.9" y1="-1.375" x2="8.9" y2="2.625" width="0.2032" layer="21"/>
<wire x1="8.9" y1="2.625" x2="8.75" y2="2.625" width="0.2032" layer="21"/>
<wire x1="8.75" y1="2.625" x2="-8.75" y2="2.625" width="0.2032" layer="21"/>
<wire x1="-8.75" y1="2.625" x2="-8.9" y2="2.625" width="0.2032" layer="21"/>
<wire x1="-8.9" y1="2.625" x2="-8.9" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-8.875" y1="1.625" x2="-8.375" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-8.375" y1="1.625" x2="-8.125" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-8.125" y1="1.625" x2="-8.125" y2="1" width="0.0508" layer="21"/>
<wire x1="-8.125" y1="1" x2="8.125" y2="1" width="0.0508" layer="21"/>
<wire x1="8.125" y1="1.625" x2="8.375" y2="1.625" width="0.0508" layer="21"/>
<wire x1="8.375" y1="1.625" x2="8.875" y2="1.625" width="0.0508" layer="21"/>
<wire x1="8.125" y1="1.625" x2="8.125" y2="1" width="0.0508" layer="21"/>
<wire x1="-8.875" y1="-0.75" x2="-8.375" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-8.375" y1="-0.75" x2="-8.375" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="8.375" y1="-0.75" x2="8.875" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="8.375" y1="-0.75" x2="8.375" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="-8.375" y1="1.625" x2="-8.375" y2="2.25" width="0.0508" layer="21"/>
<wire x1="-8.375" y1="2.25" x2="8.375" y2="2.25" width="0.0508" layer="21"/>
<wire x1="8.375" y1="2.25" x2="8.375" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-8.375" y1="2.25" x2="-8.75" y2="2.625" width="0.0508" layer="21"/>
<wire x1="8.375" y1="2.25" x2="8.75" y2="2.625" width="0.0508" layer="21"/>
<wire x1="-9" y1="2.25" x2="-10.875" y2="2.25" width="0.2032" layer="51"/>
<wire x1="-10.875" y1="2.25" x2="-10.875" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="-10.875" y1="-0.75" x2="-9" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="9" y1="-0.75" x2="10.875" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="10.875" y1="-0.75" x2="10.875" y2="2.25" width="0.2032" layer="51"/>
<wire x1="10.875" y1="2.25" x2="9" y2="2.25" width="0.2032" layer="51"/>
<smd name="1" x="7.5" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="2" x="6.25" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="3" x="5" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="4" x="3.75" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="5" x="2.5" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="6" x="1.25" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="7" x="0" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="8" x="-1.25" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="9" x="-2.5" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="10" x="-3.75" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="11" x="-5" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="12" x="-6.25" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="13" x="-7.5" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="S1" x="10" y="0.625" dx="2.1" dy="3" layer="1"/>
<smd name="S2" x="-10" y="0.625" dx="2.1" dy="3" layer="1"/>
<text x="-7.5" y="2.875" size="1.27" layer="25">&gt;NAME</text>
<text x="-6.375" y="-0.5" size="1.27" layer="27">&gt;VALUE</text>
<text x="9.5" y="-0.25" size="1.9304" layer="51">1</text>
</package>
<package name="53261-12">
wire to board 1.25 mm (.049 inch) pitch header&lt;p&gt;
SMT&lt;p&gt;
<wire x1="-8.275" y1="-1.375" x2="-7.75" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-7.75" y1="-1.375" x2="7.75" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="7.75" y1="-1.375" x2="8.275" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="8.275" y1="-1.375" x2="8.275" y2="2.625" width="0.2032" layer="21"/>
<wire x1="8.275" y1="2.625" x2="8.125" y2="2.625" width="0.2032" layer="21"/>
<wire x1="8.125" y1="2.625" x2="-8.125" y2="2.625" width="0.2032" layer="21"/>
<wire x1="-8.125" y1="2.625" x2="-8.275" y2="2.625" width="0.2032" layer="21"/>
<wire x1="-8.275" y1="2.625" x2="-8.275" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-8.25" y1="1.625" x2="-7.75" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-7.75" y1="1.625" x2="-7.5" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-7.5" y1="1.625" x2="-7.5" y2="1" width="0.0508" layer="21"/>
<wire x1="-7.5" y1="1" x2="7.5" y2="1" width="0.0508" layer="21"/>
<wire x1="7.5" y1="1.625" x2="7.75" y2="1.625" width="0.0508" layer="21"/>
<wire x1="7.75" y1="1.625" x2="8.25" y2="1.625" width="0.0508" layer="21"/>
<wire x1="7.5" y1="1.625" x2="7.5" y2="1" width="0.0508" layer="21"/>
<wire x1="-8.25" y1="-0.75" x2="-7.75" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-7.75" y1="-0.75" x2="-7.75" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="7.75" y1="-0.75" x2="8.25" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="7.75" y1="-0.75" x2="7.75" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="-7.75" y1="1.625" x2="-7.75" y2="2.25" width="0.0508" layer="21"/>
<wire x1="-7.75" y1="2.25" x2="7.75" y2="2.25" width="0.0508" layer="21"/>
<wire x1="7.75" y1="2.25" x2="7.75" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-7.75" y1="2.25" x2="-8.125" y2="2.625" width="0.0508" layer="21"/>
<wire x1="7.75" y1="2.25" x2="8.125" y2="2.625" width="0.0508" layer="21"/>
<wire x1="-8.375" y1="2.25" x2="-10.25" y2="2.25" width="0.2032" layer="51"/>
<wire x1="-10.25" y1="2.25" x2="-10.25" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="-10.25" y1="-0.75" x2="-8.375" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="8.375" y1="-0.75" x2="10.25" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="10.25" y1="-0.75" x2="10.25" y2="2.25" width="0.2032" layer="51"/>
<wire x1="10.25" y1="2.25" x2="8.375" y2="2.25" width="0.2032" layer="51"/>
<smd name="1" x="6.875" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="2" x="5.625" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="3" x="4.375" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="4" x="3.125" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="5" x="1.875" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="6" x="0.625" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="7" x="-0.625" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="8" x="-1.875" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="9" x="-3.125" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="10" x="-4.375" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="11" x="-5.625" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="12" x="-6.875" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="S1" x="9.375" y="0.625" dx="2.1" dy="3" layer="1"/>
<smd name="S2" x="-9.375" y="0.625" dx="2.1" dy="3" layer="1"/>
<text x="-6.875" y="2.875" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.75" y="-0.5" size="1.27" layer="27">&gt;VALUE</text>
<text x="8.75" y="-0.25" size="1.9304" layer="51">1</text>
</package>
<package name="53261-11">
SMT&lt;p&gt;
<wire x1="-7.65" y1="-1.375" x2="-7.125" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-7.125" y1="-1.375" x2="7.125" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="7.125" y1="-1.375" x2="7.65" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="7.65" y1="-1.375" x2="7.65" y2="2.625" width="0.2032" layer="21"/>
<wire x1="7.65" y1="2.625" x2="7.5" y2="2.625" width="0.2032" layer="21"/>
<wire x1="7.5" y1="2.625" x2="-7.5" y2="2.625" width="0.2032" layer="21"/>
<wire x1="-7.5" y1="2.625" x2="-7.65" y2="2.625" width="0.2032" layer="21"/>
<wire x1="-7.65" y1="2.625" x2="-7.65" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-7.625" y1="1.625" x2="-7.125" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-7.125" y1="1.625" x2="-6.875" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-6.875" y1="1.625" x2="-6.875" y2="1" width="0.0508" layer="21"/>
<wire x1="-6.875" y1="1" x2="6.875" y2="1" width="0.0508" layer="21"/>
<wire x1="6.875" y1="1.625" x2="7.125" y2="1.625" width="0.0508" layer="21"/>
<wire x1="7.125" y1="1.625" x2="7.625" y2="1.625" width="0.0508" layer="21"/>
<wire x1="6.875" y1="1.625" x2="6.875" y2="1" width="0.0508" layer="21"/>
<wire x1="-7.625" y1="-0.75" x2="-7.125" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-7.125" y1="-0.75" x2="-7.125" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="7.125" y1="-0.75" x2="7.625" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="7.125" y1="-0.75" x2="7.125" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="-7.125" y1="1.625" x2="-7.125" y2="2.25" width="0.0508" layer="21"/>
<wire x1="-7.125" y1="2.25" x2="7.125" y2="2.25" width="0.0508" layer="21"/>
<wire x1="7.125" y1="2.25" x2="7.125" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-7.125" y1="2.25" x2="-7.5" y2="2.625" width="0.0508" layer="21"/>
<wire x1="7.125" y1="2.25" x2="7.5" y2="2.625" width="0.0508" layer="21"/>
<wire x1="-7.75" y1="2.25" x2="-9.625" y2="2.25" width="0.2032" layer="51"/>
<wire x1="-9.625" y1="2.25" x2="-9.625" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="-9.625" y1="-0.75" x2="-7.75" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="7.75" y1="-0.75" x2="9.625" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="9.625" y1="-0.75" x2="9.625" y2="2.25" width="0.2032" layer="51"/>
<wire x1="9.625" y1="2.25" x2="7.75" y2="2.25" width="0.2032" layer="51"/>
<smd name="1" x="6.25" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="2" x="5" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="3" x="3.75" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="4" x="2.5" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="5" x="1.25" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="6" x="0" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="7" x="-1.25" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="8" x="-2.5" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="9" x="-3.75" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="10" x="-5" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="11" x="-6.25" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="S1" x="8.75" y="0.625" dx="2.1" dy="3" layer="1"/>
<smd name="S2" x="-8.75" y="0.625" dx="2.1" dy="3" layer="1"/>
<text x="-6.25" y="2.875" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.125" y="-0.5" size="1.27" layer="27">&gt;VALUE</text>
<text x="8.25" y="-0.25" size="1.9304" layer="51">1</text>
</package>
<package name="53261-10">
SMT&lt;p&gt;
<wire x1="-7.025" y1="-1.375" x2="-6.5" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-6.5" y1="-1.375" x2="6.5" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="6.5" y1="-1.375" x2="7.025" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="7.025" y1="-1.375" x2="7.025" y2="2.625" width="0.2032" layer="21"/>
<wire x1="7.025" y1="2.625" x2="6.875" y2="2.625" width="0.2032" layer="21"/>
<wire x1="6.875" y1="2.625" x2="-6.875" y2="2.625" width="0.2032" layer="21"/>
<wire x1="-6.875" y1="2.625" x2="-7.025" y2="2.625" width="0.2032" layer="21"/>
<wire x1="-7.025" y1="2.625" x2="-7.025" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-7" y1="1.625" x2="-6.5" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-6.5" y1="1.625" x2="-6.25" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-6.25" y1="1.625" x2="-6.25" y2="1" width="0.0508" layer="21"/>
<wire x1="-6.25" y1="1" x2="6.25" y2="1" width="0.0508" layer="21"/>
<wire x1="6.25" y1="1.625" x2="6.5" y2="1.625" width="0.0508" layer="21"/>
<wire x1="6.5" y1="1.625" x2="7" y2="1.625" width="0.0508" layer="21"/>
<wire x1="6.25" y1="1.625" x2="6.25" y2="1" width="0.0508" layer="21"/>
<wire x1="-7" y1="-0.75" x2="-6.5" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-6.5" y1="-0.75" x2="-6.5" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="6.5" y1="-0.75" x2="7" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="6.5" y1="-0.75" x2="6.5" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="-6.5" y1="1.625" x2="-6.5" y2="2.25" width="0.0508" layer="21"/>
<wire x1="-6.5" y1="2.25" x2="6.5" y2="2.25" width="0.0508" layer="21"/>
<wire x1="6.5" y1="2.25" x2="6.5" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-6.5" y1="2.25" x2="-6.875" y2="2.625" width="0.0508" layer="21"/>
<wire x1="6.5" y1="2.25" x2="6.875" y2="2.625" width="0.0508" layer="21"/>
<wire x1="-7.125" y1="2.25" x2="-9" y2="2.25" width="0.2032" layer="51"/>
<wire x1="-9" y1="2.25" x2="-9" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="-9" y1="-0.75" x2="-7.125" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="7.125" y1="-0.75" x2="9" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="9" y1="-0.75" x2="9" y2="2.25" width="0.2032" layer="51"/>
<wire x1="9" y1="2.25" x2="7.125" y2="2.25" width="0.2032" layer="51"/>
<smd name="1" x="5.625" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="2" x="4.375" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="3" x="3.125" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="4" x="1.875" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="5" x="0.625" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="6" x="-0.625" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="7" x="-1.875" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="8" x="-3.125" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="9" x="-4.375" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="10" x="-5.625" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="S1" x="8.125" y="0.625" dx="2.1" dy="3" layer="1"/>
<smd name="S2" x="-8.125" y="0.625" dx="2.1" dy="3" layer="1"/>
<text x="-5.625" y="2.875" size="1.27" layer="25">&gt;NAME</text>
<text x="-4.5" y="-0.5" size="1.27" layer="27">&gt;VALUE</text>
<text x="7.5" y="-0.25" size="1.9304" layer="51">1</text>
</package>
<package name="53261-09">
SMT&lt;p&gt;
<wire x1="-6.4" y1="-1.375" x2="-5.875" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-5.875" y1="-1.375" x2="5.875" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="5.875" y1="-1.375" x2="6.4" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="6.4" y1="-1.375" x2="6.4" y2="2.625" width="0.2032" layer="21"/>
<wire x1="6.4" y1="2.625" x2="6.25" y2="2.625" width="0.2032" layer="21"/>
<wire x1="6.25" y1="2.625" x2="-6.25" y2="2.625" width="0.2032" layer="21"/>
<wire x1="-6.25" y1="2.625" x2="-6.4" y2="2.625" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="2.625" x2="-6.4" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-6.375" y1="1.625" x2="-5.875" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-5.875" y1="1.625" x2="-5.625" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-5.625" y1="1.625" x2="-5.625" y2="1" width="0.0508" layer="21"/>
<wire x1="-5.625" y1="1" x2="5.625" y2="1" width="0.0508" layer="21"/>
<wire x1="5.625" y1="1.625" x2="5.875" y2="1.625" width="0.0508" layer="21"/>
<wire x1="5.875" y1="1.625" x2="6.375" y2="1.625" width="0.0508" layer="21"/>
<wire x1="5.625" y1="1.625" x2="5.625" y2="1" width="0.0508" layer="21"/>
<wire x1="-6.375" y1="-0.75" x2="-5.875" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-5.875" y1="-0.75" x2="-5.875" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="5.875" y1="-0.75" x2="6.375" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="5.875" y1="-0.75" x2="5.875" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="-5.875" y1="1.625" x2="-5.875" y2="2.25" width="0.0508" layer="21"/>
<wire x1="-5.875" y1="2.25" x2="5.875" y2="2.25" width="0.0508" layer="21"/>
<wire x1="5.875" y1="2.25" x2="5.875" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-5.875" y1="2.25" x2="-6.25" y2="2.625" width="0.0508" layer="21"/>
<wire x1="5.875" y1="2.25" x2="6.25" y2="2.625" width="0.0508" layer="21"/>
<wire x1="-6.5" y1="2.25" x2="-8.375" y2="2.25" width="0.2032" layer="51"/>
<wire x1="-8.375" y1="2.25" x2="-8.375" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="-8.375" y1="-0.75" x2="-6.5" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="6.5" y1="-0.75" x2="8.375" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="8.375" y1="-0.75" x2="8.375" y2="2.25" width="0.2032" layer="51"/>
<wire x1="8.375" y1="2.25" x2="6.5" y2="2.25" width="0.2032" layer="51"/>
<smd name="1" x="5" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="2" x="3.75" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="3" x="2.5" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="4" x="1.25" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="5" x="0" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="6" x="-1.25" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="7" x="-2.5" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="8" x="-3.75" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="9" x="-5" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="S1" x="7.5" y="0.625" dx="2.1" dy="3" layer="1"/>
<smd name="S2" x="-7.5" y="0.625" dx="2.1" dy="3" layer="1"/>
<text x="-5" y="2.875" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.875" y="-0.5" size="1.27" layer="27">&gt;VALUE</text>
<text x="6.875" y="-0.25" size="1.9304" layer="51">1</text>
</package>
<package name="53261-08">
SMT&lt;p&gt;
<wire x1="-5.775" y1="-1.375" x2="-5.25" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-5.25" y1="-1.375" x2="5.25" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="5.25" y1="-1.375" x2="5.775" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="5.775" y1="-1.375" x2="5.775" y2="2.625" width="0.2032" layer="21"/>
<wire x1="5.775" y1="2.625" x2="5.625" y2="2.625" width="0.2032" layer="21"/>
<wire x1="5.625" y1="2.625" x2="-5.625" y2="2.625" width="0.2032" layer="21"/>
<wire x1="-5.625" y1="2.625" x2="-5.775" y2="2.625" width="0.2032" layer="21"/>
<wire x1="-5.775" y1="2.625" x2="-5.775" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-5.75" y1="1.625" x2="-5.25" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-5.25" y1="1.625" x2="-5" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-5" y1="1.625" x2="-5" y2="1" width="0.0508" layer="21"/>
<wire x1="-5" y1="1" x2="5" y2="1" width="0.0508" layer="21"/>
<wire x1="5" y1="1.625" x2="5.25" y2="1.625" width="0.0508" layer="21"/>
<wire x1="5.25" y1="1.625" x2="5.75" y2="1.625" width="0.0508" layer="21"/>
<wire x1="5" y1="1.625" x2="5" y2="1" width="0.0508" layer="21"/>
<wire x1="-5.75" y1="-0.75" x2="-5.25" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-5.25" y1="-0.75" x2="-5.25" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="5.25" y1="-0.75" x2="5.75" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="5.25" y1="-0.75" x2="5.25" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="-5.25" y1="1.625" x2="-5.25" y2="2.25" width="0.0508" layer="21"/>
<wire x1="-5.25" y1="2.25" x2="5.25" y2="2.25" width="0.0508" layer="21"/>
<wire x1="5.25" y1="2.25" x2="5.25" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-5.25" y1="2.25" x2="-5.625" y2="2.625" width="0.0508" layer="21"/>
<wire x1="5.25" y1="2.25" x2="5.625" y2="2.625" width="0.0508" layer="21"/>
<wire x1="-5.875" y1="2.25" x2="-7.75" y2="2.25" width="0.2032" layer="51"/>
<wire x1="-7.75" y1="2.25" x2="-7.75" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="-7.75" y1="-0.75" x2="-5.875" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="5.875" y1="-0.75" x2="7.75" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="7.75" y1="-0.75" x2="7.75" y2="2.25" width="0.2032" layer="51"/>
<wire x1="7.75" y1="2.25" x2="5.875" y2="2.25" width="0.2032" layer="51"/>
<smd name="1" x="4.375" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="2" x="3.125" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="3" x="1.875" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="4" x="0.625" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="5" x="-0.625" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="6" x="-1.875" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="7" x="-3.125" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="8" x="-4.375" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="S1" x="6.875" y="0.625" dx="2.1" dy="3" layer="1"/>
<smd name="S2" x="-6.875" y="0.625" dx="2.1" dy="3" layer="1"/>
<text x="-3.25" y="-0.5" size="1.27" layer="27">&gt;VALUE</text>
<text x="6.25" y="-0.25" size="1.9304" layer="51">1</text>
</package>
<package name="53261-07">
SMT&lt;p&gt;
<wire x1="-5.15" y1="-1.375" x2="-4.625" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-4.625" y1="-1.375" x2="4.625" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="4.625" y1="-1.375" x2="5.15" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="5.15" y1="-1.375" x2="5.15" y2="2.625" width="0.2032" layer="21"/>
<wire x1="5.15" y1="2.625" x2="5" y2="2.625" width="0.2032" layer="21"/>
<wire x1="5" y1="2.625" x2="-5" y2="2.625" width="0.2032" layer="21"/>
<wire x1="-5" y1="2.625" x2="-5.15" y2="2.625" width="0.2032" layer="21"/>
<wire x1="-5.15" y1="2.625" x2="-5.15" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-5.125" y1="1.625" x2="-4.625" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-4.625" y1="1.625" x2="-4.375" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-4.375" y1="1.625" x2="-4.375" y2="1" width="0.0508" layer="21"/>
<wire x1="-4.375" y1="1" x2="4.375" y2="1" width="0.0508" layer="21"/>
<wire x1="4.375" y1="1.625" x2="4.625" y2="1.625" width="0.0508" layer="21"/>
<wire x1="4.625" y1="1.625" x2="5.125" y2="1.625" width="0.0508" layer="21"/>
<wire x1="4.375" y1="1.625" x2="4.375" y2="1" width="0.0508" layer="21"/>
<wire x1="-5.125" y1="-0.75" x2="-4.625" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-4.625" y1="-0.75" x2="-4.625" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="4.625" y1="-0.75" x2="5.125" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="4.625" y1="-0.75" x2="4.625" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="-4.625" y1="1.625" x2="-4.625" y2="2.25" width="0.0508" layer="21"/>
<wire x1="-4.625" y1="2.25" x2="4.625" y2="2.25" width="0.0508" layer="21"/>
<wire x1="4.625" y1="2.25" x2="4.625" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-4.625" y1="2.25" x2="-5" y2="2.625" width="0.0508" layer="21"/>
<wire x1="4.625" y1="2.25" x2="5" y2="2.625" width="0.0508" layer="21"/>
<wire x1="-5.25" y1="2.25" x2="-7.125" y2="2.25" width="0.2032" layer="51"/>
<wire x1="-7.125" y1="2.25" x2="-7.125" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="-7.125" y1="-0.75" x2="-5.25" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="5.25" y1="-0.75" x2="7.125" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="7.125" y1="-0.75" x2="7.125" y2="2.25" width="0.2032" layer="51"/>
<wire x1="7.125" y1="2.25" x2="5.25" y2="2.25" width="0.2032" layer="51"/>
<smd name="1" x="3.75" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="2" x="2.5" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="3" x="1.25" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="4" x="0" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="5" x="-1.25" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="6" x="-2.5" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="7" x="-3.75" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="S1" x="6.25" y="0.625" dx="2.1" dy="3" layer="1"/>
<smd name="S2" x="-6.25" y="0.625" dx="2.1" dy="3" layer="1"/>
<text x="-2.625" y="-0.5" size="1.27" layer="27">&gt;VALUE</text>
<text x="5.75" y="-0.25" size="1.9304" layer="51">1</text>
</package>
<package name="53261-06">
SMT&lt;p&gt;
<wire x1="-4.525" y1="-1.375" x2="-4" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-4" y1="-1.375" x2="4" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="4" y1="-1.375" x2="4.525" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="4.525" y1="-1.375" x2="4.525" y2="2.625" width="0.2032" layer="21"/>
<wire x1="4.525" y1="2.625" x2="4.375" y2="2.625" width="0.2032" layer="21"/>
<wire x1="4.375" y1="2.625" x2="-4.375" y2="2.625" width="0.2032" layer="21"/>
<wire x1="-4.375" y1="2.625" x2="-4.525" y2="2.625" width="0.2032" layer="21"/>
<wire x1="-4.525" y1="2.625" x2="-4.525" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-4.5" y1="1.625" x2="-4" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-4" y1="1.625" x2="-3.75" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-3.75" y1="1.625" x2="-3.75" y2="1" width="0.0508" layer="21"/>
<wire x1="-3.75" y1="1" x2="3.75" y2="1" width="0.0508" layer="21"/>
<wire x1="3.75" y1="1.625" x2="4" y2="1.625" width="0.0508" layer="21"/>
<wire x1="4" y1="1.625" x2="4.5" y2="1.625" width="0.0508" layer="21"/>
<wire x1="3.75" y1="1.625" x2="3.75" y2="1" width="0.0508" layer="21"/>
<wire x1="-4.5" y1="-0.75" x2="-4" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-4" y1="-0.75" x2="-4" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="4" y1="-0.75" x2="4.5" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="4" y1="-0.75" x2="4" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="-4" y1="1.625" x2="-4" y2="2.25" width="0.0508" layer="21"/>
<wire x1="-4" y1="2.25" x2="4" y2="2.25" width="0.0508" layer="21"/>
<wire x1="4" y1="2.25" x2="4" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-4" y1="2.25" x2="-4.375" y2="2.625" width="0.0508" layer="21"/>
<wire x1="4" y1="2.25" x2="4.375" y2="2.625" width="0.0508" layer="21"/>
<wire x1="-4.625" y1="2.25" x2="-6.5" y2="2.25" width="0.2032" layer="51"/>
<wire x1="-6.5" y1="2.25" x2="-6.5" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="-6.5" y1="-0.75" x2="-4.625" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="4.625" y1="-0.75" x2="6.5" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="6.5" y1="-0.75" x2="6.5" y2="2.25" width="0.2032" layer="51"/>
<wire x1="6.5" y1="2.25" x2="4.625" y2="2.25" width="0.2032" layer="51"/>
<smd name="1" x="3.125" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="2" x="1.875" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="3" x="0.625" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="4" x="-0.625" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="5" x="-1.875" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="6" x="-3.125" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="S1" x="5.625" y="0.625" dx="2.1" dy="3" layer="1"/>
<smd name="S2" x="-5.625" y="0.625" dx="2.1" dy="3" layer="1"/>
<text x="-4.375" y="2.875" size="1.27" layer="25">&gt;NAME</text>
<text x="5" y="-0.25" size="1.9304" layer="51">1</text>
</package>
<package name="53261-05">
SMT&lt;p&gt;
<wire x1="-3.9" y1="-1.375" x2="-3.375" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-3.375" y1="-1.375" x2="3.375" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="3.375" y1="-1.375" x2="3.9" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="3.9" y1="-1.375" x2="3.9" y2="2.625" width="0.2032" layer="21"/>
<wire x1="3.9" y1="2.625" x2="3.75" y2="2.625" width="0.2032" layer="21"/>
<wire x1="3.75" y1="2.625" x2="-3.75" y2="2.625" width="0.2032" layer="21"/>
<wire x1="-3.75" y1="2.625" x2="-3.9" y2="2.625" width="0.2032" layer="21"/>
<wire x1="-3.9" y1="2.625" x2="-3.9" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-3.875" y1="1.625" x2="-3.375" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-3.375" y1="1.625" x2="-3.125" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-3.125" y1="1.625" x2="-3.125" y2="1" width="0.0508" layer="21"/>
<wire x1="-3.125" y1="1" x2="3.125" y2="1" width="0.0508" layer="21"/>
<wire x1="3.125" y1="1.625" x2="3.375" y2="1.625" width="0.0508" layer="21"/>
<wire x1="3.375" y1="1.625" x2="3.875" y2="1.625" width="0.0508" layer="21"/>
<wire x1="3.125" y1="1.625" x2="3.125" y2="1" width="0.0508" layer="21"/>
<wire x1="-3.875" y1="-0.75" x2="-3.375" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-3.375" y1="-0.75" x2="-3.375" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="3.375" y1="-0.75" x2="3.875" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="3.375" y1="-0.75" x2="3.375" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="-3.375" y1="1.625" x2="-3.375" y2="2.25" width="0.0508" layer="21"/>
<wire x1="-3.375" y1="2.25" x2="3.375" y2="2.25" width="0.0508" layer="21"/>
<wire x1="3.375" y1="2.25" x2="3.375" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-3.375" y1="2.25" x2="-3.75" y2="2.625" width="0.0508" layer="21"/>
<wire x1="3.375" y1="2.25" x2="3.75" y2="2.625" width="0.0508" layer="21"/>
<wire x1="-4" y1="2.25" x2="-5.875" y2="2.25" width="0.2032" layer="51"/>
<wire x1="-5.875" y1="2.25" x2="-5.875" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="-5.875" y1="-0.75" x2="-4" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="4" y1="-0.75" x2="5.875" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="5.875" y1="-0.75" x2="5.875" y2="2.25" width="0.2032" layer="51"/>
<wire x1="5.875" y1="2.25" x2="4" y2="2.25" width="0.2032" layer="51"/>
<smd name="1" x="2.5" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="2" x="1.25" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="3" x="0" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="4" x="-1.25" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="5" x="-2.5" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="S1" x="5" y="0.625" dx="2.1" dy="3" layer="1"/>
<smd name="S2" x="-5" y="0.625" dx="2.1" dy="3" layer="1"/>
<text x="-3.75" y="2.875" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.375" y="-0.5" size="1.27" layer="27">&gt;VALUE</text>
<text x="4.375" y="-0.25" size="1.9304" layer="51">1</text>
</package>
<package name="53261-04">
SMT&lt;p&gt;
<wire x1="-3.275" y1="-1.375" x2="-2.75" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-2.75" y1="-1.375" x2="2.75" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="2.75" y1="-1.375" x2="3.275" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="3.275" y1="-1.375" x2="3.275" y2="2.625" width="0.2032" layer="21"/>
<wire x1="3.275" y1="2.625" x2="3.125" y2="2.625" width="0.2032" layer="21"/>
<wire x1="3.125" y1="2.625" x2="-3.125" y2="2.625" width="0.2032" layer="21"/>
<wire x1="-3.125" y1="2.625" x2="-3.275" y2="2.625" width="0.2032" layer="21"/>
<wire x1="-3.275" y1="2.625" x2="-3.275" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-3.25" y1="1.625" x2="-2.75" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-2.75" y1="1.625" x2="-2.5" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-2.5" y1="1.625" x2="-2.5" y2="1" width="0.0508" layer="21"/>
<wire x1="-2.5" y1="1" x2="2.5" y2="1" width="0.0508" layer="21"/>
<wire x1="2.5" y1="1.625" x2="2.75" y2="1.625" width="0.0508" layer="21"/>
<wire x1="2.75" y1="1.625" x2="3.25" y2="1.625" width="0.0508" layer="21"/>
<wire x1="2.5" y1="1.625" x2="2.5" y2="1" width="0.0508" layer="21"/>
<wire x1="-3.25" y1="-0.75" x2="-2.75" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-2.75" y1="-0.75" x2="-2.75" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="2.75" y1="-0.75" x2="3.25" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="2.75" y1="-0.75" x2="2.75" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="-2.75" y1="1.625" x2="-2.75" y2="2.25" width="0.0508" layer="21"/>
<wire x1="-2.75" y1="2.25" x2="2.75" y2="2.25" width="0.0508" layer="21"/>
<wire x1="2.75" y1="2.25" x2="2.75" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-2.75" y1="2.25" x2="-3.125" y2="2.625" width="0.0508" layer="21"/>
<wire x1="2.75" y1="2.25" x2="3.125" y2="2.625" width="0.0508" layer="21"/>
<wire x1="-3.375" y1="2.25" x2="-5.25" y2="2.25" width="0.2032" layer="51"/>
<wire x1="-5.25" y1="2.25" x2="-5.25" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="-5.25" y1="-0.75" x2="-3.375" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="3.375" y1="-0.75" x2="5.25" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="5.25" y1="-0.75" x2="5.25" y2="2.25" width="0.2032" layer="51"/>
<wire x1="5.25" y1="2.25" x2="3.375" y2="2.25" width="0.2032" layer="51"/>
<smd name="1" x="1.875" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="2" x="0.625" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="3" x="-0.625" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="4" x="-1.875" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="S1" x="4.375" y="0.625" dx="2.1" dy="3" layer="1"/>
<smd name="S2" x="-4.375" y="0.625" dx="2.1" dy="3" layer="1"/>
<text x="-3.125" y="2.875" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.75" y="-0.5" size="1.27" layer="27">&gt;VALUE</text>
<text x="3.75" y="-0.25" size="1.9304" layer="51">1</text>
</package>
<package name="53261-03">
SMT&lt;p&gt;
<wire x1="-2.65" y1="-1.375" x2="-2.125" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-2.125" y1="-1.375" x2="2.125" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="2.125" y1="-1.375" x2="2.65" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="2.65" y1="-1.375" x2="2.65" y2="2.625" width="0.2032" layer="21"/>
<wire x1="2.65" y1="2.625" x2="2.5" y2="2.625" width="0.2032" layer="21"/>
<wire x1="2.5" y1="2.625" x2="-2.5" y2="2.625" width="0.2032" layer="21"/>
<wire x1="-2.5" y1="2.625" x2="-2.65" y2="2.625" width="0.2032" layer="21"/>
<wire x1="-2.65" y1="2.625" x2="-2.65" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-2.625" y1="1.625" x2="-2.125" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-2.125" y1="1.625" x2="-1.875" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-1.875" y1="1.625" x2="-1.875" y2="1" width="0.0508" layer="21"/>
<wire x1="-1.875" y1="1" x2="1.875" y2="1" width="0.0508" layer="21"/>
<wire x1="1.875" y1="1.625" x2="2.125" y2="1.625" width="0.0508" layer="21"/>
<wire x1="2.125" y1="1.625" x2="2.625" y2="1.625" width="0.0508" layer="21"/>
<wire x1="1.875" y1="1.625" x2="1.875" y2="1" width="0.0508" layer="21"/>
<wire x1="-2.625" y1="-0.75" x2="-2.125" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-2.125" y1="-0.75" x2="-2.125" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="2.125" y1="-0.75" x2="2.625" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="2.125" y1="-0.75" x2="2.125" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="-2.125" y1="1.625" x2="-2.125" y2="2.25" width="0.0508" layer="21"/>
<wire x1="-2.125" y1="2.25" x2="2.125" y2="2.25" width="0.0508" layer="21"/>
<wire x1="2.125" y1="2.25" x2="2.125" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-2.125" y1="2.25" x2="-2.5" y2="2.625" width="0.0508" layer="21"/>
<wire x1="2.125" y1="2.25" x2="2.5" y2="2.625" width="0.0508" layer="21"/>
<wire x1="-2.75" y1="2.25" x2="-4.625" y2="2.25" width="0.2032" layer="51"/>
<wire x1="-4.625" y1="2.25" x2="-4.625" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="-4.625" y1="-0.75" x2="-2.75" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="2.75" y1="-0.75" x2="4.625" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="4.625" y1="-0.75" x2="4.625" y2="2.25" width="0.2032" layer="51"/>
<wire x1="4.625" y1="2.25" x2="2.75" y2="2.25" width="0.2032" layer="51"/>
<smd name="1" x="1.25" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="2" x="0" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="3" x="-1.25" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="S1" x="3.75" y="0.625" dx="2.1" dy="3" layer="1"/>
<smd name="S2" x="-3.75" y="0.625" dx="2.1" dy="3" layer="1"/>
<text x="-2.5" y="2.875" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.25" y="-3" size="1.27" layer="27">&gt;VALUE</text>
<text x="3.125" y="-0.25" size="1.9304" layer="51">1</text>
</package>
<package name="53261-02">
SMT&lt;p&gt;
right angle</description>
<wire x1="-2.025" y1="-1.375" x2="-1.5" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-1.5" y1="-1.375" x2="1.5" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="1.5" y1="-1.375" x2="2.025" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="2.025" y1="-1.375" x2="2.025" y2="2.625" width="0.2032" layer="21"/>
<wire x1="2.025" y1="2.625" x2="1.875" y2="2.625" width="0.2032" layer="21"/>
<wire x1="1.875" y1="2.625" x2="-1.875" y2="2.625" width="0.2032" layer="21"/>
<wire x1="-1.875" y1="2.625" x2="-2.025" y2="2.625" width="0.2032" layer="21"/>
<wire x1="-2.025" y1="2.625" x2="-2.025" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-2" y1="1.625" x2="-1.5" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-1.5" y1="1.625" x2="-1.25" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-1.25" y1="1.625" x2="-1.25" y2="1" width="0.0508" layer="21"/>
<wire x1="-1.25" y1="1" x2="1.25" y2="1" width="0.0508" layer="21"/>
<wire x1="1.25" y1="1.625" x2="1.5" y2="1.625" width="0.0508" layer="21"/>
<wire x1="1.5" y1="1.625" x2="2" y2="1.625" width="0.0508" layer="21"/>
<wire x1="1.25" y1="1.625" x2="1.25" y2="1" width="0.0508" layer="21"/>
<wire x1="-2" y1="-0.75" x2="-1.5" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="-1.5" y1="-0.75" x2="-1.5" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="1.5" y1="-0.75" x2="2" y2="-0.75" width="0.0508" layer="21"/>
<wire x1="1.5" y1="-0.75" x2="1.5" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="-1.5" y1="1.625" x2="-1.5" y2="2.25" width="0.0508" layer="21"/>
<wire x1="-1.5" y1="2.25" x2="1.5" y2="2.25" width="0.0508" layer="21"/>
<wire x1="1.5" y1="2.25" x2="1.5" y2="1.625" width="0.0508" layer="21"/>
<wire x1="-1.5" y1="2.25" x2="-1.875" y2="2.625" width="0.0508" layer="21"/>
<wire x1="1.5" y1="2.25" x2="1.875" y2="2.625" width="0.0508" layer="21"/>
<wire x1="-2.125" y1="2.25" x2="-4" y2="2.25" width="0.2032" layer="51"/>
<wire x1="-4" y1="2.25" x2="-4" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="-4" y1="-0.75" x2="-2.125" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="2.125" y1="-0.75" x2="4" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="4" y1="-0.75" x2="4" y2="2.25" width="0.2032" layer="51"/>
<wire x1="4" y1="2.25" x2="2.125" y2="2.25" width="0.2032" layer="51"/>
<smd name="1" x="0.625" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="2" x="-0.625" y="-2.5" dx="0.8" dy="2" layer="1"/>
<smd name="S1" x="3.125" y="0.625" dx="2.1" dy="3" layer="1"/>
<smd name="S2" x="-3.125" y="0.625" dx="2.1" dy="3" layer="1"/>
<text x="-1.875" y="2.875" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.625" y="-3" size="1.27" layer="27">&gt;VALUE</text>
<text x="2.5" y="-0.25" size="1.9304" layer="51">1</text>
</package>
<package name="53398-15">
SMT&lt;p&gt;
straight</description>
<wire x1="-9.625" y1="-1.375" x2="-9.375" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-9.375" y1="-1.375" x2="9.375" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="9.375" y1="-1.375" x2="9.625" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="10.15" y1="-1.375" x2="10.15" y2="2.125" width="0.2032" layer="21"/>
<wire x1="10.15" y1="2.125" x2="10" y2="2.125" width="0.2032" layer="21"/>
<wire x1="10" y1="2.125" x2="-10" y2="2.125" width="0.2032" layer="21"/>
<wire x1="-10" y1="2.125" x2="-10.15" y2="2.125" width="0.2032" layer="21"/>
<wire x1="-10.15" y1="2.125" x2="-10.15" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-10.125" y1="1" x2="-9.625" y2="1" width="0.0508" layer="21"/>
<wire x1="9.625" y1="1" x2="10.125" y2="1" width="0.0508" layer="21"/>
<wire x1="-10.125" y1="-0.25" x2="-9.625" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="-9.625" y1="-0.25" x2="-9.625" y2="-1" width="0.0508" layer="21"/>
<wire x1="9.625" y1="-0.25" x2="10.125" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="9.625" y1="-0.25" x2="9.625" y2="-1" width="0.0508" layer="21"/>
<wire x1="-9.625" y1="1" x2="-9.625" y2="1.75" width="0.0508" layer="21"/>
<wire x1="-9.625" y1="1.75" x2="9.625" y2="1.75" width="0.0508" layer="21"/>
<wire x1="9.625" y1="1.75" x2="9.625" y2="1" width="0.0508" layer="21"/>
<wire x1="-9.625" y1="1.75" x2="-10" y2="2.125" width="0.0508" layer="21"/>
<wire x1="9.625" y1="1.75" x2="10" y2="2.125" width="0.0508" layer="21"/>
<wire x1="-10.25" y1="2.125" x2="-12.125" y2="2.125" width="0.2032" layer="51"/>
<wire x1="-12.125" y1="2.125" x2="-12.125" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="12.125" y1="-0.75" x2="12.125" y2="2.125" width="0.2032" layer="51"/>
<wire x1="12.125" y1="2.125" x2="10.25" y2="2.125" width="0.2032" layer="51"/>
<wire x1="-10.125" y1="-1" x2="-9.625" y2="-1" width="0.0508" layer="21"/>
<wire x1="-9.625" y1="-1" x2="-9.375" y2="-1" width="0.0508" layer="21"/>
<wire x1="-9.375" y1="-1" x2="-9.375" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="9.625" y1="-1" x2="10.125" y2="-1" width="0.0508" layer="21"/>
<wire x1="9.375" y1="-1" x2="9.625" y2="-1" width="0.0508" layer="21"/>
<wire x1="9.375" y1="-1" x2="9.375" y2="-1.375" width="0.0508" layer="21"/>
<smd name="1" x="8.75" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="2" x="7.5" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="3" x="6.25" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="4" x="5" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="5" x="3.75" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="6" x="2.5" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="7" x="1.25" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="8" x="0" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="9" x="-1.25" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="10" x="-2.5" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="11" x="-3.75" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="12" x="-5" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="13" x="-6.25" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="14" x="-7.5" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="15" x="-8.75" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<text x="-9.875" y="2.375" size="1.27" layer="25">&gt;NAME</text>
<text x="-9.375" y="-1" size="1.27" layer="27">&gt;VALUE</text>
<text x="10.625" y="-0.25" size="1.9304" layer="51">1</text>
<rectangle x1="-9" y1="0.375" x2="-8.5" y2="1" layer="21"/>
<rectangle x1="-7.75" y1="0.375" x2="-7.25" y2="1" layer="21"/>
<rectangle x1="-6.5" y1="0.375" x2="-6" y2="1" layer="21"/>
<rectangle x1="-5.25" y1="0.375" x2="-4.75" y2="1" layer="21"/>
<rectangle x1="-4" y1="0.375" x2="-3.5" y2="1" layer="21"/>
<rectangle x1="-2.75" y1="0.375" x2="-2.25" y2="1" layer="21"/>
<rectangle x1="-1.5" y1="0.375" x2="-1" y2="1" layer="21"/>
<rectangle x1="-0.25" y1="0.375" x2="0.25" y2="1" layer="21"/>
<rectangle x1="1" y1="0.375" x2="1.5" y2="1" layer="21"/>
<rectangle x1="2.25" y1="0.375" x2="2.75" y2="1" layer="21"/>
<rectangle x1="3.5" y1="0.375" x2="4" y2="1" layer="21"/>
<rectangle x1="4.75" y1="0.375" x2="5.25" y2="1" layer="21"/>
<rectangle x1="6" y1="0.375" x2="6.5" y2="1" layer="21"/>
<rectangle x1="7.25" y1="0.375" x2="7.75" y2="1" layer="21"/>
<rectangle x1="8.5" y1="0.375" x2="9" y2="1" layer="21"/>
</package>
<package name="53398-14">
SMT&lt;p&gt;
<wire x1="-9.525" y1="-1.375" x2="-8.75" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-8.75" y1="-1.375" x2="8.75" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="8.75" y1="-1.375" x2="9.525" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="9.525" y1="-1.375" x2="9.525" y2="2.125" width="0.2032" layer="21"/>
<wire x1="9.525" y1="2.125" x2="9.375" y2="2.125" width="0.2032" layer="21"/>
<wire x1="9.375" y1="2.125" x2="-9.375" y2="2.125" width="0.2032" layer="21"/>
<wire x1="-9.375" y1="2.125" x2="-9.525" y2="2.125" width="0.2032" layer="21"/>
<wire x1="-9.525" y1="2.125" x2="-9.525" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-9.5" y1="1" x2="-9" y2="1" width="0.0508" layer="21"/>
<wire x1="9" y1="1" x2="9.5" y2="1" width="0.0508" layer="21"/>
<wire x1="-9.5" y1="-0.25" x2="-9" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="-9" y1="-0.25" x2="-9" y2="-1" width="0.0508" layer="21"/>
<wire x1="9" y1="-0.25" x2="9.5" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="9" y1="-0.25" x2="9" y2="-1" width="0.0508" layer="21"/>
<wire x1="-9" y1="1" x2="-9" y2="1.75" width="0.0508" layer="21"/>
<wire x1="-9" y1="1.75" x2="9" y2="1.75" width="0.0508" layer="21"/>
<wire x1="9" y1="1.75" x2="9" y2="1" width="0.0508" layer="21"/>
<wire x1="-9" y1="1.75" x2="-9.375" y2="2.125" width="0.0508" layer="21"/>
<wire x1="9" y1="1.75" x2="9.375" y2="2.125" width="0.0508" layer="21"/>
<wire x1="-9.625" y1="2.125" x2="-11.5" y2="2.125" width="0.2032" layer="51"/>
<wire x1="-11.5" y1="2.125" x2="-11.5" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="11.5" y1="-0.75" x2="11.5" y2="2.125" width="0.2032" layer="51"/>
<wire x1="11.5" y1="2.125" x2="9.625" y2="2.125" width="0.2032" layer="51"/>
<wire x1="-9.5" y1="-1" x2="-9" y2="-1" width="0.0508" layer="21"/>
<wire x1="-9" y1="-1" x2="-8.75" y2="-1" width="0.0508" layer="21"/>
<wire x1="-8.75" y1="-1" x2="-8.75" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="9" y1="-1" x2="9.5" y2="-1" width="0.0508" layer="21"/>
<wire x1="8.75" y1="-1" x2="9" y2="-1" width="0.0508" layer="21"/>
<wire x1="8.75" y1="-1" x2="8.75" y2="-1.375" width="0.0508" layer="21"/>
<smd name="1" x="8.125" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="2" x="6.875" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="3" x="5.625" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="4" x="4.375" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="5" x="3.125" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="6" x="1.875" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="7" x="0.625" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="8" x="-0.625" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="9" x="-1.875" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="10" x="-3.125" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="11" x="-4.375" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="12" x="-5.625" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="13" x="-6.875" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="14" x="-8.125" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<text x="-9.25" y="2.375" size="1.27" layer="25">&gt;NAME</text>
<text x="-8.75" y="-1" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-8.375" y1="0.375" x2="-7.875" y2="1" layer="21"/>
<rectangle x1="-7.125" y1="0.375" x2="-6.625" y2="1" layer="21"/>
<rectangle x1="-5.875" y1="0.375" x2="-5.375" y2="1" layer="21"/>
<rectangle x1="-4.625" y1="0.375" x2="-4.125" y2="1" layer="21"/>
<rectangle x1="-3.375" y1="0.375" x2="-2.875" y2="1" layer="21"/>
<rectangle x1="-2.125" y1="0.375" x2="-1.625" y2="1" layer="21"/>
<rectangle x1="-0.875" y1="0.375" x2="-0.375" y2="1" layer="21"/>
<rectangle x1="0.375" y1="0.375" x2="0.875" y2="1" layer="21"/>
<rectangle x1="1.625" y1="0.375" x2="2.125" y2="1" layer="21"/>
<rectangle x1="2.875" y1="0.375" x2="3.375" y2="1" layer="21"/>
<rectangle x1="4.125" y1="0.375" x2="4.625" y2="1" layer="21"/>
<rectangle x1="5.375" y1="0.375" x2="5.875" y2="1" layer="21"/>
<rectangle x1="6.625" y1="0.375" x2="7.125" y2="1" layer="21"/>
<rectangle x1="7.875" y1="0.375" x2="8.375" y2="1" layer="21"/>
</package>
<package name="53398-13">
SMT&lt;p&gt;
<wire x1="-8.9" y1="-1.375" x2="-8.125" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-8.125" y1="-1.375" x2="8.125" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="8.125" y1="-1.375" x2="8.9" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="8.9" y1="-1.375" x2="8.9" y2="2.125" width="0.2032" layer="21"/>
<wire x1="8.9" y1="2.125" x2="8.75" y2="2.125" width="0.2032" layer="21"/>
<wire x1="8.75" y1="2.125" x2="-8.75" y2="2.125" width="0.2032" layer="21"/>
<wire x1="-8.75" y1="2.125" x2="-8.9" y2="2.125" width="0.2032" layer="21"/>
<wire x1="-8.9" y1="2.125" x2="-8.9" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-8.875" y1="1" x2="-8.375" y2="1" width="0.0508" layer="21"/>
<wire x1="8.375" y1="1" x2="8.875" y2="1" width="0.0508" layer="21"/>
<wire x1="-8.875" y1="-0.25" x2="-8.375" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="-8.375" y1="-0.25" x2="-8.375" y2="-1" width="0.0508" layer="21"/>
<wire x1="8.375" y1="-0.25" x2="8.875" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="8.375" y1="-0.25" x2="8.375" y2="-1" width="0.0508" layer="21"/>
<wire x1="-8.375" y1="1" x2="-8.375" y2="1.75" width="0.0508" layer="21"/>
<wire x1="-8.375" y1="1.75" x2="8.375" y2="1.75" width="0.0508" layer="21"/>
<wire x1="8.375" y1="1.75" x2="8.375" y2="1" width="0.0508" layer="21"/>
<wire x1="-8.375" y1="1.75" x2="-8.75" y2="2.125" width="0.0508" layer="21"/>
<wire x1="8.375" y1="1.75" x2="8.75" y2="2.125" width="0.0508" layer="21"/>
<wire x1="-9" y1="2.125" x2="-10.875" y2="2.125" width="0.2032" layer="51"/>
<wire x1="-10.875" y1="2.125" x2="-10.875" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="10.875" y1="-0.75" x2="10.875" y2="2.125" width="0.2032" layer="51"/>
<wire x1="10.875" y1="2.125" x2="9" y2="2.125" width="0.2032" layer="51"/>
<wire x1="-8.875" y1="-1" x2="-8.375" y2="-1" width="0.0508" layer="21"/>
<wire x1="-8.375" y1="-1" x2="-8.125" y2="-1" width="0.0508" layer="21"/>
<wire x1="-8.125" y1="-1" x2="-8.125" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="8.375" y1="-1" x2="8.875" y2="-1" width="0.0508" layer="21"/>
<wire x1="8.125" y1="-1" x2="8.375" y2="-1" width="0.0508" layer="21"/>
<wire x1="8.125" y1="-1" x2="8.125" y2="-1.375" width="0.0508" layer="21"/>
<smd name="1" x="7.5" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="2" x="6.25" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="3" x="5" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="4" x="3.75" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="5" x="2.5" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="6" x="1.25" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="7" x="0" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="8" x="-1.25" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="9" x="-2.5" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="10" x="-3.75" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="11" x="-5" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="12" x="-6.25" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="13" x="-7.5" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<text x="-8.625" y="2.375" size="1.27" layer="25">&gt;NAME</text>
<text x="-8.125" y="-1" size="1.27" layer="27">&gt;VALUE</text>
<text x="9.375" y="-0.25" size="1.9304" layer="51">1</text>
</package>
<package name="53398-12">
SMT&lt;p&gt;
<wire x1="-8.275" y1="-1.375" x2="-7.5" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-7.5" y1="-1.375" x2="7.5" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="7.5" y1="-1.375" x2="8.275" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="8.275" y1="-1.375" x2="8.275" y2="2.125" width="0.2032" layer="21"/>
<wire x1="8.275" y1="2.125" x2="8.125" y2="2.125" width="0.2032" layer="21"/>
<wire x1="8.125" y1="2.125" x2="-8.125" y2="2.125" width="0.2032" layer="21"/>
<wire x1="-8.125" y1="2.125" x2="-8.275" y2="2.125" width="0.2032" layer="21"/>
<wire x1="-8.275" y1="2.125" x2="-8.275" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-8.25" y1="1" x2="-7.75" y2="1" width="0.0508" layer="21"/>
<wire x1="7.75" y1="1" x2="8.25" y2="1" width="0.0508" layer="21"/>
<wire x1="-8.25" y1="-0.25" x2="-7.75" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="-7.75" y1="-0.25" x2="-7.75" y2="-1" width="0.0508" layer="21"/>
<wire x1="7.75" y1="-0.25" x2="8.25" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="7.75" y1="-0.25" x2="7.75" y2="-1" width="0.0508" layer="21"/>
<wire x1="-7.75" y1="1" x2="-7.75" y2="1.75" width="0.0508" layer="21"/>
<wire x1="-7.75" y1="1.75" x2="7.75" y2="1.75" width="0.0508" layer="21"/>
<wire x1="7.75" y1="1.75" x2="7.75" y2="1" width="0.0508" layer="21"/>
<wire x1="-7.75" y1="1.75" x2="-8.125" y2="2.125" width="0.0508" layer="21"/>
<wire x1="7.75" y1="1.75" x2="8.125" y2="2.125" width="0.0508" layer="21"/>
<wire x1="-8.375" y1="2.125" x2="-10.25" y2="2.125" width="0.2032" layer="51"/>
<wire x1="-10.25" y1="2.125" x2="-10.25" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="10.25" y1="-0.75" x2="10.25" y2="2.125" width="0.2032" layer="51"/>
<wire x1="10.25" y1="2.125" x2="8.375" y2="2.125" width="0.2032" layer="51"/>
<wire x1="-8.25" y1="-1" x2="-7.75" y2="-1" width="0.0508" layer="21"/>
<wire x1="-7.75" y1="-1" x2="-7.5" y2="-1" width="0.0508" layer="21"/>
<wire x1="-7.5" y1="-1" x2="-7.5" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="7.75" y1="-1" x2="8.25" y2="-1" width="0.0508" layer="21"/>
<wire x1="7.5" y1="-1" x2="7.75" y2="-1" width="0.0508" layer="21"/>
<wire x1="7.5" y1="-1" x2="7.5" y2="-1.375" width="0.0508" layer="21"/>
<smd name="1" x="6.875" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="2" x="5.625" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="3" x="4.375" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="4" x="3.125" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="5" x="1.875" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="6" x="0.625" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="7" x="-0.625" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="8" x="-1.875" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="9" x="-3.125" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="10" x="-4.375" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="11" x="-5.625" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="12" x="-6.875" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<text x="-8" y="2.375" size="1.27" layer="25">&gt;NAME</text>
<text x="-7.5" y="-1" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="53398-11">
SMT&lt;p&gt;
<wire x1="-7.65" y1="-1.375" x2="-6.875" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-6.875" y1="-1.375" x2="6.875" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="6.875" y1="-1.375" x2="7.65" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="7.65" y1="-1.375" x2="7.65" y2="2.125" width="0.2032" layer="21"/>
<wire x1="7.65" y1="2.125" x2="7.5" y2="2.125" width="0.2032" layer="21"/>
<wire x1="7.5" y1="2.125" x2="-7.5" y2="2.125" width="0.2032" layer="21"/>
<wire x1="-7.5" y1="2.125" x2="-7.65" y2="2.125" width="0.2032" layer="21"/>
<wire x1="-7.65" y1="2.125" x2="-7.65" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-7.625" y1="1" x2="-7.125" y2="1" width="0.0508" layer="21"/>
<wire x1="7.125" y1="1" x2="7.625" y2="1" width="0.0508" layer="21"/>
<wire x1="-7.625" y1="-0.25" x2="-7.125" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="-7.125" y1="-0.25" x2="-7.125" y2="-1" width="0.0508" layer="21"/>
<wire x1="7.125" y1="-0.25" x2="7.625" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="7.125" y1="-0.25" x2="7.125" y2="-1" width="0.0508" layer="21"/>
<wire x1="-7.125" y1="1" x2="-7.125" y2="1.75" width="0.0508" layer="21"/>
<wire x1="-7.125" y1="1.75" x2="7.125" y2="1.75" width="0.0508" layer="21"/>
<wire x1="7.125" y1="1.75" x2="7.125" y2="1" width="0.0508" layer="21"/>
<wire x1="-7.125" y1="1.75" x2="-7.5" y2="2.125" width="0.0508" layer="21"/>
<wire x1="7.125" y1="1.75" x2="7.5" y2="2.125" width="0.0508" layer="21"/>
<wire x1="-7.75" y1="2.125" x2="-9.625" y2="2.125" width="0.2032" layer="51"/>
<wire x1="-9.625" y1="2.125" x2="-9.625" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="9.625" y1="-0.75" x2="9.625" y2="2.125" width="0.2032" layer="51"/>
<wire x1="9.625" y1="2.125" x2="7.75" y2="2.125" width="0.2032" layer="51"/>
<wire x1="-7.625" y1="-1" x2="-7.125" y2="-1" width="0.0508" layer="21"/>
<wire x1="-7.125" y1="-1" x2="-6.875" y2="-1" width="0.0508" layer="21"/>
<wire x1="-6.875" y1="-1" x2="-6.875" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="7.125" y1="-1" x2="7.625" y2="-1" width="0.0508" layer="21"/>
<wire x1="6.875" y1="-1" x2="7.125" y2="-1" width="0.0508" layer="21"/>
<wire x1="6.875" y1="-1" x2="6.875" y2="-1.375" width="0.0508" layer="21"/>
<smd name="1" x="6.25" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="2" x="5" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="3" x="3.75" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="4" x="2.5" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="5" x="1.25" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="6" x="0" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="7" x="-1.25" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="8" x="-2.5" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="9" x="-3.75" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="10" x="-5" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="11" x="-6.25" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<text x="-7.375" y="2.375" size="1.27" layer="25">&gt;NAME</text>
<text x="-6.875" y="-1" size="1.27" layer="27">&gt;VALUE</text>
<text x="8.125" y="-0.25" size="1.9304" layer="51">1</text>
</package>
<package name="53398-10">
<description>&lt;b&gt;CONNECTOR&lt;/b&gt;&lt;p&gt;
SMT&lt;p&gt;
<wire x1="-7.025" y1="-1.375" x2="-6.25" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-6.25" y1="-1.375" x2="6.25" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="6.25" y1="-1.375" x2="7.025" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="7.025" y1="-1.375" x2="7.025" y2="2.125" width="0.2032" layer="21"/>
<wire x1="7.025" y1="2.125" x2="6.875" y2="2.125" width="0.2032" layer="21"/>
<wire x1="6.875" y1="2.125" x2="-6.875" y2="2.125" width="0.2032" layer="21"/>
<wire x1="-6.875" y1="2.125" x2="-7.025" y2="2.125" width="0.2032" layer="21"/>
<wire x1="-7.025" y1="2.125" x2="-7.025" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-7" y1="1" x2="-6.5" y2="1" width="0.0508" layer="21"/>
<wire x1="6.5" y1="1" x2="7" y2="1" width="0.0508" layer="21"/>
<wire x1="-7" y1="-0.25" x2="-6.5" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="-6.5" y1="-0.25" x2="-6.5" y2="-1" width="0.0508" layer="21"/>
<wire x1="6.5" y1="-0.25" x2="7" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="6.5" y1="-0.25" x2="6.5" y2="-1" width="0.0508" layer="21"/>
<wire x1="-6.5" y1="1" x2="-6.5" y2="1.75" width="0.0508" layer="21"/>
<wire x1="-6.5" y1="1.75" x2="6.5" y2="1.75" width="0.0508" layer="21"/>
<wire x1="6.5" y1="1.75" x2="6.5" y2="1" width="0.0508" layer="21"/>
<wire x1="-6.5" y1="1.75" x2="-6.875" y2="2.125" width="0.0508" layer="21"/>
<wire x1="6.5" y1="1.75" x2="6.875" y2="2.125" width="0.0508" layer="21"/>
<wire x1="-7.125" y1="2.125" x2="-9" y2="2.125" width="0.2032" layer="51"/>
<wire x1="-9" y1="2.125" x2="-9" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="9" y1="-0.75" x2="9" y2="2.125" width="0.2032" layer="51"/>
<wire x1="9" y1="2.125" x2="7.125" y2="2.125" width="0.2032" layer="51"/>
<wire x1="-7" y1="-1" x2="-6.5" y2="-1" width="0.0508" layer="21"/>
<wire x1="-6.5" y1="-1" x2="-6.25" y2="-1" width="0.0508" layer="21"/>
<wire x1="-6.25" y1="-1" x2="-6.25" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="6.5" y1="-1" x2="7" y2="-1" width="0.0508" layer="21"/>
<wire x1="6.25" y1="-1" x2="6.5" y2="-1" width="0.0508" layer="21"/>
<wire x1="6.25" y1="-1" x2="6.25" y2="-1.375" width="0.0508" layer="21"/>
<smd name="1" x="5.625" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="2" x="4.375" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="3" x="3.125" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="4" x="1.875" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="5" x="0.625" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="6" x="-0.625" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="7" x="-1.875" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="8" x="-3.125" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="9" x="-4.375" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="10" x="-5.625" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<text x="-6.75" y="2.375" size="1.27" layer="25">&gt;NAME</text>
<text x="-6.25" y="-1" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="53398-09">
SMT&lt;p&gt;
<wire x1="-6.4" y1="-1.375" x2="-5.625" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-5.625" y1="-1.375" x2="5.625" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="5.625" y1="-1.375" x2="6.4" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="6.4" y1="-1.375" x2="6.4" y2="2.125" width="0.2032" layer="21"/>
<wire x1="6.4" y1="2.125" x2="6.25" y2="2.125" width="0.2032" layer="21"/>
<wire x1="6.25" y1="2.125" x2="-6.25" y2="2.125" width="0.2032" layer="21"/>
<wire x1="-6.25" y1="2.125" x2="-6.4" y2="2.125" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="2.125" x2="-6.4" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-6.375" y1="1" x2="-5.875" y2="1" width="0.0508" layer="21"/>
<wire x1="5.875" y1="1" x2="6.375" y2="1" width="0.0508" layer="21"/>
<wire x1="-6.375" y1="-0.25" x2="-5.875" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="-5.875" y1="-0.25" x2="-5.875" y2="-1" width="0.0508" layer="21"/>
<wire x1="5.875" y1="-0.25" x2="6.375" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="5.875" y1="-0.25" x2="5.875" y2="-1" width="0.0508" layer="21"/>
<wire x1="-5.875" y1="1" x2="-5.875" y2="1.75" width="0.0508" layer="21"/>
<wire x1="-5.875" y1="1.75" x2="5.875" y2="1.75" width="0.0508" layer="21"/>
<wire x1="5.875" y1="1.75" x2="5.875" y2="1" width="0.0508" layer="21"/>
<wire x1="-5.875" y1="1.75" x2="-6.25" y2="2.125" width="0.0508" layer="21"/>
<wire x1="5.875" y1="1.75" x2="6.25" y2="2.125" width="0.0508" layer="21"/>
<wire x1="-6.5" y1="2.125" x2="-8.375" y2="2.125" width="0.2032" layer="51"/>
<wire x1="-8.375" y1="2.125" x2="-8.375" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="8.375" y1="-0.75" x2="8.375" y2="2.125" width="0.2032" layer="51"/>
<wire x1="8.375" y1="2.125" x2="6.5" y2="2.125" width="0.2032" layer="51"/>
<wire x1="-6.375" y1="-1" x2="-5.875" y2="-1" width="0.0508" layer="21"/>
<wire x1="-5.875" y1="-1" x2="-5.625" y2="-1" width="0.0508" layer="21"/>
<wire x1="-5.625" y1="-1" x2="-5.625" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="5.875" y1="-1" x2="6.375" y2="-1" width="0.0508" layer="21"/>
<wire x1="5.625" y1="-1" x2="5.875" y2="-1" width="0.0508" layer="21"/>
<wire x1="5.625" y1="-1" x2="5.625" y2="-1.375" width="0.0508" layer="21"/>
<smd name="1" x="5" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="2" x="3.75" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="3" x="2.5" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="4" x="1.25" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="5" x="0" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="6" x="-1.25" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="7" x="-2.5" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="8" x="-3.75" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="9" x="-5" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<text x="-6.125" y="2.375" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.625" y="-1" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="53398-08">
SMT&lt;p&gt;
<wire x1="-5.775" y1="-1.375" x2="-5" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-5" y1="-1.375" x2="5" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="5" y1="-1.375" x2="5.775" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="5.775" y1="-1.375" x2="5.775" y2="2.125" width="0.2032" layer="21"/>
<wire x1="5.775" y1="2.125" x2="5.625" y2="2.125" width="0.2032" layer="21"/>
<wire x1="5.625" y1="2.125" x2="-5.625" y2="2.125" width="0.2032" layer="21"/>
<wire x1="-5.625" y1="2.125" x2="-5.775" y2="2.125" width="0.2032" layer="21"/>
<wire x1="-5.775" y1="2.125" x2="-5.775" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-5.75" y1="1" x2="-5.25" y2="1" width="0.0508" layer="21"/>
<wire x1="5.25" y1="1" x2="5.75" y2="1" width="0.0508" layer="21"/>
<wire x1="-5.75" y1="-0.25" x2="-5.25" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="-5.25" y1="-0.25" x2="-5.25" y2="-1" width="0.0508" layer="21"/>
<wire x1="5.25" y1="-0.25" x2="5.75" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="5.25" y1="-0.25" x2="5.25" y2="-1" width="0.0508" layer="21"/>
<wire x1="-5.25" y1="1" x2="-5.25" y2="1.75" width="0.0508" layer="21"/>
<wire x1="-5.25" y1="1.75" x2="5.25" y2="1.75" width="0.0508" layer="21"/>
<wire x1="5.25" y1="1.75" x2="5.25" y2="1" width="0.0508" layer="21"/>
<wire x1="-5.25" y1="1.75" x2="-5.625" y2="2.125" width="0.0508" layer="21"/>
<wire x1="5.25" y1="1.75" x2="5.625" y2="2.125" width="0.0508" layer="21"/>
<wire x1="-5.875" y1="2.125" x2="-7.75" y2="2.125" width="0.2032" layer="51"/>
<wire x1="-7.75" y1="2.125" x2="-7.75" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="7.75" y1="-0.75" x2="7.75" y2="2.125" width="0.2032" layer="51"/>
<wire x1="7.75" y1="2.125" x2="5.875" y2="2.125" width="0.2032" layer="51"/>
<wire x1="-5.75" y1="-1" x2="-5.25" y2="-1" width="0.0508" layer="21"/>
<wire x1="-5.25" y1="-1" x2="-5" y2="-1" width="0.0508" layer="21"/>
<wire x1="-5" y1="-1" x2="-5" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="5.25" y1="-1" x2="5.75" y2="-1" width="0.0508" layer="21"/>
<wire x1="5" y1="-1" x2="5.25" y2="-1" width="0.0508" layer="21"/>
<wire x1="5" y1="-1" x2="5" y2="-1.375" width="0.0508" layer="21"/>
<smd name="1" x="4.375" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="2" x="3.125" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="3" x="1.875" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="4" x="0.625" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="5" x="-0.625" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="6" x="-1.875" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="7" x="-3.125" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="8" x="-4.375" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<text x="-5.5" y="2.375" size="1.27" layer="25">&gt;NAME</text>
<text x="-5" y="-1" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="53398-07">
wire to board 1.25 mm (.049 inch) pitch header&lt;p&gt;
SMT&lt;p&gt;
<wire x1="-5.15" y1="-1.375" x2="-4.375" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-4.375" y1="-1.375" x2="4.375" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="4.375" y1="-1.375" x2="5.15" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="5.15" y1="-1.375" x2="5.15" y2="2.125" width="0.2032" layer="21"/>
<wire x1="5.15" y1="2.125" x2="5" y2="2.125" width="0.2032" layer="21"/>
<wire x1="5" y1="2.125" x2="-5" y2="2.125" width="0.2032" layer="21"/>
<wire x1="-5" y1="2.125" x2="-5.15" y2="2.125" width="0.2032" layer="21"/>
<wire x1="-5.15" y1="2.125" x2="-5.15" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-5.125" y1="1" x2="-4.625" y2="1" width="0.0508" layer="21"/>
<wire x1="4.625" y1="1" x2="5.125" y2="1" width="0.0508" layer="21"/>
<wire x1="-5.125" y1="-0.25" x2="-4.625" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="-4.625" y1="-0.25" x2="-4.625" y2="-1" width="0.0508" layer="21"/>
<wire x1="4.625" y1="-0.25" x2="5.125" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="4.625" y1="-0.25" x2="4.625" y2="-1" width="0.0508" layer="21"/>
<wire x1="-4.625" y1="1" x2="-4.625" y2="1.75" width="0.0508" layer="21"/>
<wire x1="-4.625" y1="1.75" x2="4.625" y2="1.75" width="0.0508" layer="21"/>
<wire x1="4.625" y1="1.75" x2="4.625" y2="1" width="0.0508" layer="21"/>
<wire x1="-4.625" y1="1.75" x2="-5" y2="2.125" width="0.0508" layer="21"/>
<wire x1="4.625" y1="1.75" x2="5" y2="2.125" width="0.0508" layer="21"/>
<wire x1="-5.25" y1="2.125" x2="-7.125" y2="2.125" width="0.2032" layer="51"/>
<wire x1="-7.125" y1="2.125" x2="-7.125" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="7.125" y1="-0.75" x2="7.125" y2="2.125" width="0.2032" layer="51"/>
<wire x1="7.125" y1="2.125" x2="5.25" y2="2.125" width="0.2032" layer="51"/>
<wire x1="-5.125" y1="-1" x2="-4.625" y2="-1" width="0.0508" layer="21"/>
<wire x1="-4.625" y1="-1" x2="-4.375" y2="-1" width="0.0508" layer="21"/>
<wire x1="-4.375" y1="-1" x2="-4.375" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="4.625" y1="-1" x2="5.125" y2="-1" width="0.0508" layer="21"/>
<wire x1="4.375" y1="-1" x2="4.625" y2="-1" width="0.0508" layer="21"/>
<wire x1="4.375" y1="-1" x2="4.375" y2="-1.375" width="0.0508" layer="21"/>
<smd name="1" x="3.75" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="2" x="2.5" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="3" x="1.25" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="4" x="0" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="5" x="-1.25" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="6" x="-2.5" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="7" x="-3.75" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<text x="-4.875" y="2.375" size="1.27" layer="25">&gt;NAME</text>
<text x="-4.375" y="-1" size="1.27" layer="27">&gt;VALUE</text>
<text x="5.625" y="-0.25" size="1.9304" layer="51">1</text>
</package>
<package name="53398-06">
SMT&lt;p&gt;
<wire x1="-4.525" y1="-1.375" x2="-3.75" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-3.75" y1="-1.375" x2="3.75" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="3.75" y1="-1.375" x2="4.525" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="4.525" y1="-1.375" x2="4.525" y2="2.125" width="0.2032" layer="21"/>
<wire x1="4.525" y1="2.125" x2="4.375" y2="2.125" width="0.2032" layer="21"/>
<wire x1="4.375" y1="2.125" x2="-4.375" y2="2.125" width="0.2032" layer="21"/>
<wire x1="-4.375" y1="2.125" x2="-4.525" y2="2.125" width="0.2032" layer="21"/>
<wire x1="-4.525" y1="2.125" x2="-4.525" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-4.5" y1="1" x2="-4" y2="1" width="0.0508" layer="21"/>
<wire x1="4" y1="1" x2="4.5" y2="1" width="0.0508" layer="21"/>
<wire x1="-4.5" y1="-0.25" x2="-4" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="-4" y1="-0.25" x2="-4" y2="-1" width="0.0508" layer="21"/>
<wire x1="4" y1="-0.25" x2="4.5" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="4" y1="-0.25" x2="4" y2="-1" width="0.0508" layer="21"/>
<wire x1="-4" y1="1" x2="-4" y2="1.75" width="0.0508" layer="21"/>
<wire x1="-4" y1="1.75" x2="4" y2="1.75" width="0.0508" layer="21"/>
<wire x1="4" y1="1.75" x2="4" y2="1" width="0.0508" layer="21"/>
<wire x1="-4" y1="1.75" x2="-4.375" y2="2.125" width="0.0508" layer="21"/>
<wire x1="4" y1="1.75" x2="4.375" y2="2.125" width="0.0508" layer="21"/>
<wire x1="-4.625" y1="2.125" x2="-6.5" y2="2.125" width="0.2032" layer="51"/>
<wire x1="-6.5" y1="2.125" x2="-6.5" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="6.5" y1="-0.75" x2="6.5" y2="2.125" width="0.2032" layer="51"/>
<wire x1="6.5" y1="2.125" x2="4.625" y2="2.125" width="0.2032" layer="51"/>
<wire x1="-4.5" y1="-1" x2="-4" y2="-1" width="0.0508" layer="21"/>
<wire x1="-4" y1="-1" x2="-3.75" y2="-1" width="0.0508" layer="21"/>
<wire x1="-3.75" y1="-1" x2="-3.75" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="4" y1="-1" x2="4.5" y2="-1" width="0.0508" layer="21"/>
<wire x1="3.75" y1="-1" x2="4" y2="-1" width="0.0508" layer="21"/>
<wire x1="3.75" y1="-1" x2="3.75" y2="-1.375" width="0.0508" layer="21"/>
<smd name="1" x="3.125" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="2" x="1.875" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="3" x="0.625" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="4" x="-0.625" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="5" x="-1.875" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="6" x="-3.125" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<text x="-4.25" y="2.375" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.75" y="-1" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="53398-05">
SMT&lt;p&gt;
<wire x1="-3.9" y1="-1.375" x2="-3.125" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-3.125" y1="-1.375" x2="3.125" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="3.125" y1="-1.375" x2="3.9" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="3.9" y1="-1.375" x2="3.9" y2="2.125" width="0.2032" layer="21"/>
<wire x1="3.9" y1="2.125" x2="3.75" y2="2.125" width="0.2032" layer="21"/>
<wire x1="3.75" y1="2.125" x2="-3.75" y2="2.125" width="0.2032" layer="21"/>
<wire x1="-3.75" y1="2.125" x2="-3.9" y2="2.125" width="0.2032" layer="21"/>
<wire x1="-3.9" y1="2.125" x2="-3.9" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-3.875" y1="1" x2="-3.375" y2="1" width="0.0508" layer="21"/>
<wire x1="3.375" y1="1" x2="3.875" y2="1" width="0.0508" layer="21"/>
<wire x1="-3.875" y1="-0.25" x2="-3.375" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="-3.375" y1="-0.25" x2="-3.375" y2="-1" width="0.0508" layer="21"/>
<wire x1="3.375" y1="-0.25" x2="3.875" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="3.375" y1="-0.25" x2="3.375" y2="-1" width="0.0508" layer="21"/>
<wire x1="-3.375" y1="1" x2="-3.375" y2="1.75" width="0.0508" layer="21"/>
<wire x1="-3.375" y1="1.75" x2="3.375" y2="1.75" width="0.0508" layer="21"/>
<wire x1="3.375" y1="1.75" x2="3.375" y2="1" width="0.0508" layer="21"/>
<wire x1="-3.375" y1="1.75" x2="-3.75" y2="2.125" width="0.0508" layer="21"/>
<wire x1="3.375" y1="1.75" x2="3.75" y2="2.125" width="0.0508" layer="21"/>
<wire x1="-4" y1="2.125" x2="-5.875" y2="2.125" width="0.2032" layer="51"/>
<wire x1="-5.875" y1="2.125" x2="-5.875" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="5.875" y1="-0.75" x2="5.875" y2="2.125" width="0.2032" layer="51"/>
<wire x1="5.875" y1="2.125" x2="4" y2="2.125" width="0.2032" layer="51"/>
<wire x1="-3.875" y1="-1" x2="-3.375" y2="-1" width="0.0508" layer="21"/>
<wire x1="-3.375" y1="-1" x2="-3.125" y2="-1" width="0.0508" layer="21"/>
<wire x1="-3.125" y1="-1" x2="-3.125" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="3.375" y1="-1" x2="3.875" y2="-1" width="0.0508" layer="21"/>
<wire x1="3.125" y1="-1" x2="3.375" y2="-1" width="0.0508" layer="21"/>
<wire x1="3.125" y1="-1" x2="3.125" y2="-1.375" width="0.0508" layer="21"/>
<smd name="1" x="2.5" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="2" x="1.25" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="3" x="0" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="4" x="-1.25" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="5" x="-2.5" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<text x="-3.625" y="2.375" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.125" y="-1" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="53398-04">
SMT&lt;p&gt;
<wire x1="-3.275" y1="-1.375" x2="-2.5" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-2.5" y1="-1.375" x2="2.5" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="2.5" y1="-1.375" x2="3.275" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="3.275" y1="-1.375" x2="3.275" y2="2.125" width="0.2032" layer="21"/>
<wire x1="3.275" y1="2.125" x2="3.125" y2="2.125" width="0.2032" layer="21"/>
<wire x1="3.125" y1="2.125" x2="-3.125" y2="2.125" width="0.2032" layer="21"/>
<wire x1="-3.125" y1="2.125" x2="-3.275" y2="2.125" width="0.2032" layer="21"/>
<wire x1="-3.275" y1="2.125" x2="-3.275" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-3.25" y1="1" x2="-2.75" y2="1" width="0.0508" layer="21"/>
<wire x1="2.75" y1="1" x2="3.25" y2="1" width="0.0508" layer="21"/>
<wire x1="-3.25" y1="-0.25" x2="-2.75" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="-2.75" y1="-0.25" x2="-2.75" y2="-1" width="0.0508" layer="21"/>
<wire x1="2.75" y1="-0.25" x2="3.25" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="2.75" y1="-0.25" x2="2.75" y2="-1" width="0.0508" layer="21"/>
<wire x1="-2.75" y1="1" x2="-2.75" y2="1.75" width="0.0508" layer="21"/>
<wire x1="-2.75" y1="1.75" x2="2.75" y2="1.75" width="0.0508" layer="21"/>
<wire x1="2.75" y1="1.75" x2="2.75" y2="1" width="0.0508" layer="21"/>
<wire x1="-2.75" y1="1.75" x2="-3.125" y2="2.125" width="0.0508" layer="21"/>
<wire x1="2.75" y1="1.75" x2="3.125" y2="2.125" width="0.0508" layer="21"/>
<wire x1="-3.375" y1="2.125" x2="-5.25" y2="2.125" width="0.2032" layer="51"/>
<wire x1="-5.25" y1="2.125" x2="-5.25" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="5.25" y1="-0.75" x2="5.25" y2="2.125" width="0.2032" layer="51"/>
<wire x1="5.25" y1="2.125" x2="3.375" y2="2.125" width="0.2032" layer="51"/>
<wire x1="-3.25" y1="-1" x2="-2.75" y2="-1" width="0.0508" layer="21"/>
<wire x1="-2.75" y1="-1" x2="-2.5" y2="-1" width="0.0508" layer="21"/>
<wire x1="-2.5" y1="-1" x2="-2.5" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="2.75" y1="-1" x2="3.25" y2="-1" width="0.0508" layer="21"/>
<wire x1="2.5" y1="-1" x2="2.75" y2="-1" width="0.0508" layer="21"/>
<wire x1="2.5" y1="-1" x2="2.5" y2="-1.375" width="0.0508" layer="21"/>
<smd name="1" x="1.875" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="2" x="0.625" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="3" x="-0.625" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="4" x="-1.875" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<text x="-3" y="2.375" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.75" y="-3.5" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="53398-03">
SMT&lt;p&gt;
<wire x1="-2.65" y1="-1.375" x2="-1.875" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-1.875" y1="-1.375" x2="1.875" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="1.875" y1="-1.375" x2="2.65" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="2.65" y1="-1.375" x2="2.65" y2="2.125" width="0.2032" layer="21"/>
<wire x1="2.65" y1="2.125" x2="2.5" y2="2.125" width="0.2032" layer="21"/>
<wire x1="2.5" y1="2.125" x2="-2.5" y2="2.125" width="0.2032" layer="21"/>
<wire x1="-2.5" y1="2.125" x2="-2.65" y2="2.125" width="0.2032" layer="21"/>
<wire x1="-2.65" y1="2.125" x2="-2.65" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-2.625" y1="1" x2="-2.125" y2="1" width="0.0508" layer="21"/>
<wire x1="2.125" y1="1" x2="2.625" y2="1" width="0.0508" layer="21"/>
<wire x1="-2.625" y1="-0.25" x2="-2.125" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="-2.125" y1="-0.25" x2="-2.125" y2="-1" width="0.0508" layer="21"/>
<wire x1="2.125" y1="-0.25" x2="2.625" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="2.125" y1="-0.25" x2="2.125" y2="-1" width="0.0508" layer="21"/>
<wire x1="-2.125" y1="1" x2="-2.125" y2="1.75" width="0.0508" layer="21"/>
<wire x1="-2.125" y1="1.75" x2="2.125" y2="1.75" width="0.0508" layer="21"/>
<wire x1="2.125" y1="1.75" x2="2.125" y2="1" width="0.0508" layer="21"/>
<wire x1="-2.125" y1="1.75" x2="-2.5" y2="2.125" width="0.0508" layer="21"/>
<wire x1="2.125" y1="1.75" x2="2.5" y2="2.125" width="0.0508" layer="21"/>
<wire x1="-2.75" y1="2.125" x2="-4.625" y2="2.125" width="0.2032" layer="51"/>
<wire x1="-4.625" y1="2.125" x2="-4.625" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="4.625" y1="-0.75" x2="4.625" y2="2.125" width="0.2032" layer="51"/>
<wire x1="4.625" y1="2.125" x2="2.75" y2="2.125" width="0.2032" layer="51"/>
<wire x1="-2.625" y1="-1" x2="-2.125" y2="-1" width="0.0508" layer="21"/>
<wire x1="-2.125" y1="-1" x2="-1.875" y2="-1" width="0.0508" layer="21"/>
<wire x1="-1.875" y1="-1" x2="-1.875" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="2.125" y1="-1" x2="2.625" y2="-1" width="0.0508" layer="21"/>
<wire x1="1.875" y1="-1" x2="2.125" y2="-1" width="0.0508" layer="21"/>
<wire x1="1.875" y1="-1" x2="1.875" y2="-1.375" width="0.0508" layer="21"/>
<smd name="1" x="1.25" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="2" x="0" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="3" x="-1.25" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<text x="-2.375" y="2.375" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.125" y="-3.5" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="53398-02">
SMT&lt;p&gt;
<wire x1="-2.025" y1="-1.375" x2="-1.25" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-1.25" y1="-1.375" x2="1.25" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="1.25" y1="-1.375" x2="2.025" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="2.025" y1="-1.375" x2="2.025" y2="2.125" width="0.2032" layer="21"/>
<wire x1="2.025" y1="2.125" x2="1.875" y2="2.125" width="0.2032" layer="21"/>
<wire x1="1.875" y1="2.125" x2="-1.875" y2="2.125" width="0.2032" layer="21"/>
<wire x1="-1.875" y1="2.125" x2="-2.025" y2="2.125" width="0.2032" layer="21"/>
<wire x1="-2.025" y1="2.125" x2="-2.025" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="-2" y1="1" x2="-1.5" y2="1" width="0.0508" layer="21"/>
<wire x1="1.5" y1="1" x2="2" y2="1" width="0.0508" layer="21"/>
<wire x1="-2" y1="-0.25" x2="-1.5" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="-1.5" y1="-0.25" x2="-1.5" y2="-1" width="0.0508" layer="21"/>
<wire x1="1.5" y1="-0.25" x2="2" y2="-0.25" width="0.0508" layer="21"/>
<wire x1="1.5" y1="-0.25" x2="1.5" y2="-1" width="0.0508" layer="21"/>
<wire x1="-1.5" y1="1" x2="-1.5" y2="1.75" width="0.0508" layer="21"/>
<wire x1="-1.5" y1="1.75" x2="1.5" y2="1.75" width="0.0508" layer="21"/>
<wire x1="1.5" y1="1.75" x2="1.5" y2="1" width="0.0508" layer="21"/>
<wire x1="-1.5" y1="1.75" x2="-1.875" y2="2.125" width="0.0508" layer="21"/>
<wire x1="1.5" y1="1.75" x2="1.875" y2="2.125" width="0.0508" layer="21"/>
<wire x1="-2.125" y1="2.125" x2="-4" y2="2.125" width="0.2032" layer="51"/>
<wire x1="-4" y1="2.125" x2="-4" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="4" y1="-0.75" x2="4" y2="2.125" width="0.2032" layer="51"/>
<wire x1="4" y1="2.125" x2="2.125" y2="2.125" width="0.2032" layer="51"/>
<wire x1="-2" y1="-1" x2="-1.5" y2="-1" width="0.0508" layer="21"/>
<wire x1="-1.5" y1="-1" x2="-1.25" y2="-1" width="0.0508" layer="21"/>
<wire x1="-1.25" y1="-1" x2="-1.25" y2="-1.375" width="0.0508" layer="21"/>
<wire x1="1.5" y1="-1" x2="2" y2="-1" width="0.0508" layer="21"/>
<wire x1="1.25" y1="-1" x2="1.5" y2="-1" width="0.0508" layer="21"/>
<wire x1="1.25" y1="-1" x2="1.25" y2="-1.375" width="0.0508" layer="21"/>
<smd name="1" x="0.625" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<smd name="2" x="-0.625" y="-2.5" dx="0.8" dy="1.8" layer="1"/>
<text x="-2.5" y="-3.5" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="53048-14">
<wire x1="-9.525" y1="-2.25" x2="-9" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="9" y1="-2.25" x2="9.525" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="9.525" y1="-2.25" x2="9.525" y2="3.125" width="0.2032" layer="21"/>
<wire x1="9.525" y1="3.125" x2="9.375" y2="3.125" width="0.2032" layer="21"/>
<wire x1="9.375" y1="3.125" x2="-9.375" y2="3.125" width="0.2032" layer="21"/>
<wire x1="-9.375" y1="3.125" x2="-9.525" y2="3.125" width="0.2032" layer="21"/>
<wire x1="-9.525" y1="3.125" x2="-9.525" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="-9.5" y1="1.5" x2="-9" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-9" y1="1.5" x2="-8.75" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-8.75" y1="1.5" x2="-8.75" y2="0.625" width="0.0508" layer="21"/>
<wire x1="-8.75" y1="0.625" x2="8.75" y2="0.625" width="0.0508" layer="21"/>
<wire x1="8.75" y1="1.5" x2="9" y2="1.5" width="0.0508" layer="21"/>
<wire x1="9" y1="1.5" x2="9.5" y2="1.5" width="0.0508" layer="21"/>
<wire x1="8.75" y1="1.5" x2="8.75" y2="0.625" width="0.0508" layer="21"/>
<wire x1="-9" y1="-1" x2="9" y2="-1" width="0.2032" layer="51"/>
<wire x1="-8.375" y1="-1.5" x2="-8.5" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-7.125" y1="-1.5" x2="-7.25" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-7.25" y1="-1.625" x2="-7.75" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-7.875" y1="-1.5" x2="-7.75" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-5.875" y1="-1.5" x2="-6" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-6" y1="-1.625" x2="-6.5" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-6.625" y1="-1.5" x2="-6.5" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-4.625" y1="-1.5" x2="-4.75" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-4.75" y1="-1.625" x2="-5.25" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-5.375" y1="-1.5" x2="-5.25" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-3.375" y1="-1.5" x2="-3.5" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-3.5" y1="-1.625" x2="-4" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-4.125" y1="-1.5" x2="-4" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-2.125" y1="-1.5" x2="-2.25" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-2.25" y1="-1.625" x2="-2.75" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-2.875" y1="-1.5" x2="-2.75" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-0.875" y1="-1.5" x2="-1" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-1" y1="-1.625" x2="-1.5" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-1.625" y1="-1.5" x2="-1.5" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="0.375" y1="-1.5" x2="0.25" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="0.25" y1="-1.625" x2="-0.25" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-0.375" y1="-1.5" x2="-0.25" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="1.625" y1="-1.5" x2="1.5" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="1.5" y1="-1.625" x2="1" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="0.875" y1="-1.5" x2="1" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="2.875" y1="-1.5" x2="2.75" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="2.75" y1="-1.625" x2="2.25" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="2.125" y1="-1.5" x2="2.25" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="4.125" y1="-1.5" x2="4" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="4" y1="-1.625" x2="3.5" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="3.375" y1="-1.5" x2="3.5" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="5.375" y1="-1.5" x2="5.25" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="5.25" y1="-1.625" x2="4.75" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="4.625" y1="-1.5" x2="4.75" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="6.625" y1="-1.5" x2="6.5" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="6.5" y1="-1.625" x2="6" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="5.875" y1="-1.5" x2="6" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="7.875" y1="-1.5" x2="7.75" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="7.75" y1="-1.625" x2="7.25" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="7.125" y1="-1.5" x2="7.25" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="9" y1="-1.625" x2="8.5" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="8.375" y1="-1.5" x2="8.5" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-8.5" y1="-1.625" x2="-9" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-9.5" y1="-1" x2="-9" y2="-1" width="0.2032" layer="21"/>
<wire x1="-9" y1="-1" x2="-9" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="9" y1="-1" x2="9.5" y2="-1" width="0.2032" layer="21"/>
<wire x1="9" y1="-1" x2="9" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="-9" y1="1.5" x2="-9" y2="2.75" width="0.0508" layer="21"/>
<wire x1="-9" y1="2.75" x2="9" y2="2.75" width="0.0508" layer="21"/>
<wire x1="9" y1="2.75" x2="9" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-9" y1="2.75" x2="-9.375" y2="3.125" width="0.0508" layer="21"/>
<wire x1="9" y1="2.75" x2="9.375" y2="3.125" width="0.0508" layer="21"/>
<wire x1="-8.25" y1="1.5" x2="-8.125" y2="2" width="0.2032" layer="21"/>
<wire x1="-8.125" y1="2" x2="-8" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-7" y1="1.5" x2="-6.875" y2="2" width="0.2032" layer="21"/>
<wire x1="-6.875" y1="2" x2="-6.75" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-5.75" y1="1.5" x2="-5.625" y2="2" width="0.2032" layer="21"/>
<wire x1="-5.625" y1="2" x2="-5.5" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-4.5" y1="1.5" x2="-4.375" y2="2" width="0.2032" layer="21"/>
<wire x1="-4.375" y1="2" x2="-4.25" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-3.25" y1="1.5" x2="-3.125" y2="2" width="0.2032" layer="21"/>
<wire x1="-3.125" y1="2" x2="-3" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-2" y1="1.5" x2="-1.875" y2="2" width="0.2032" layer="21"/>
<wire x1="-1.875" y1="2" x2="-1.75" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-0.75" y1="1.5" x2="-0.625" y2="2" width="0.2032" layer="21"/>
<wire x1="-0.625" y1="2" x2="-0.5" y2="1.5" width="0.2032" layer="21"/>
<wire x1="0.5" y1="1.5" x2="0.625" y2="2" width="0.2032" layer="21"/>
<wire x1="0.625" y1="2" x2="0.75" y2="1.5" width="0.2032" layer="21"/>
<wire x1="1.75" y1="1.5" x2="1.875" y2="2" width="0.2032" layer="21"/>
<wire x1="1.875" y1="2" x2="2" y2="1.5" width="0.2032" layer="21"/>
<wire x1="3" y1="1.5" x2="3.125" y2="2" width="0.2032" layer="21"/>
<wire x1="3.125" y1="2" x2="3.25" y2="1.5" width="0.2032" layer="21"/>
<wire x1="4.25" y1="1.5" x2="4.375" y2="2" width="0.2032" layer="21"/>
<wire x1="4.375" y1="2" x2="4.5" y2="1.5" width="0.2032" layer="21"/>
<wire x1="5.5" y1="1.5" x2="5.625" y2="2" width="0.2032" layer="21"/>
<wire x1="5.625" y1="2" x2="5.75" y2="1.5" width="0.2032" layer="21"/>
<wire x1="6.75" y1="1.5" x2="6.875" y2="2" width="0.2032" layer="21"/>
<wire x1="6.875" y1="2" x2="7" y2="1.5" width="0.2032" layer="21"/>
<wire x1="8" y1="1.5" x2="8.125" y2="2" width="0.2032" layer="21"/>
<wire x1="8.125" y1="2" x2="8.25" y2="1.5" width="0.2032" layer="21"/>
<pad name="1" x="8.125" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="2" x="6.875" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="3" x="5.625" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="4" x="4.375" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="5" x="3.125" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="6" x="1.875" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="7" x="0.625" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="8" x="-0.625" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="9" x="-1.875" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="10" x="-3.125" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="11" x="-4.375" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="12" x="-5.625" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="13" x="-6.875" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="14" x="-8.125" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<text x="-8.125" y="3.375" size="1.27" layer="25">&gt;NAME</text>
<text x="-8.75" y="-3.625" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-8.375" y1="-1.5" x2="-7.875" y2="-1" layer="51"/>
<rectangle x1="-7.125" y1="-1.5" x2="-6.625" y2="-1" layer="51"/>
<rectangle x1="-5.875" y1="-1.5" x2="-5.375" y2="-1" layer="51"/>
<rectangle x1="-4.625" y1="-1.5" x2="-4.125" y2="-1" layer="51"/>
<rectangle x1="-3.375" y1="-1.5" x2="-2.875" y2="-1" layer="51"/>
<rectangle x1="-2.125" y1="-1.5" x2="-1.625" y2="-1" layer="51"/>
<rectangle x1="-0.875" y1="-1.5" x2="-0.375" y2="-1" layer="51"/>
<rectangle x1="0.375" y1="-1.5" x2="0.875" y2="-1" layer="51"/>
<rectangle x1="1.625" y1="-1.5" x2="2.125" y2="-1" layer="51"/>
<rectangle x1="2.875" y1="-1.5" x2="3.375" y2="-1" layer="51"/>
<rectangle x1="4.125" y1="-1.5" x2="4.625" y2="-1" layer="51"/>
<rectangle x1="5.375" y1="-1.5" x2="5.875" y2="-1" layer="51"/>
<rectangle x1="6.625" y1="-1.5" x2="7.125" y2="-1" layer="51"/>
<rectangle x1="7.875" y1="-1.5" x2="8.375" y2="-1" layer="51"/>
<rectangle x1="-8.375" y1="0.625" x2="-7.875" y2="1.5" layer="21"/>
<rectangle x1="-7.125" y1="0.625" x2="-6.625" y2="1.5" layer="21"/>
<rectangle x1="-5.875" y1="0.625" x2="-5.375" y2="1.5" layer="21"/>
<rectangle x1="-4.625" y1="0.625" x2="-4.125" y2="1.5" layer="21"/>
<rectangle x1="-3.375" y1="0.625" x2="-2.875" y2="1.5" layer="21"/>
<rectangle x1="-2.125" y1="0.625" x2="-1.625" y2="1.5" layer="21"/>
<rectangle x1="-0.875" y1="0.625" x2="-0.375" y2="1.5" layer="21"/>
<rectangle x1="0.375" y1="0.625" x2="0.875" y2="1.5" layer="21"/>
<rectangle x1="1.625" y1="0.625" x2="2.125" y2="1.5" layer="21"/>
<rectangle x1="2.875" y1="0.625" x2="3.375" y2="1.5" layer="21"/>
<rectangle x1="4.125" y1="0.625" x2="4.625" y2="1.5" layer="21"/>
<rectangle x1="5.375" y1="0.625" x2="5.875" y2="1.5" layer="21"/>
<rectangle x1="6.625" y1="0.625" x2="7.125" y2="1.5" layer="21"/>
<rectangle x1="7.875" y1="0.625" x2="8.375" y2="1.5" layer="21"/>
</package>
<package name="53048-13">
<wire x1="-8.9" y1="-2.25" x2="-8.375" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="8.375" y1="-2.25" x2="8.9" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="8.9" y1="-2.25" x2="8.9" y2="3.125" width="0.2032" layer="21"/>
<wire x1="8.9" y1="3.125" x2="8.75" y2="3.125" width="0.2032" layer="21"/>
<wire x1="8.75" y1="3.125" x2="-8.75" y2="3.125" width="0.2032" layer="21"/>
<wire x1="-8.75" y1="3.125" x2="-8.9" y2="3.125" width="0.2032" layer="21"/>
<wire x1="-8.9" y1="3.125" x2="-8.9" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="-8.875" y1="1.5" x2="-8.375" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-8.375" y1="1.5" x2="-8.125" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-8.125" y1="1.5" x2="-8.125" y2="0.625" width="0.0508" layer="21"/>
<wire x1="-8.125" y1="0.625" x2="8.125" y2="0.625" width="0.0508" layer="21"/>
<wire x1="8.125" y1="1.5" x2="8.375" y2="1.5" width="0.0508" layer="21"/>
<wire x1="8.375" y1="1.5" x2="8.875" y2="1.5" width="0.0508" layer="21"/>
<wire x1="8.125" y1="1.5" x2="8.125" y2="0.625" width="0.0508" layer="21"/>
<wire x1="-8.375" y1="-1" x2="8.375" y2="-1" width="0.2032" layer="51"/>
<wire x1="-7.75" y1="-1.5" x2="-7.875" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-6.5" y1="-1.5" x2="-6.625" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-6.625" y1="-1.625" x2="-7.125" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-7.25" y1="-1.5" x2="-7.125" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-5.25" y1="-1.5" x2="-5.375" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-5.375" y1="-1.625" x2="-5.875" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-6" y1="-1.5" x2="-5.875" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-4" y1="-1.5" x2="-4.125" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-4.125" y1="-1.625" x2="-4.625" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-4.75" y1="-1.5" x2="-4.625" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-2.75" y1="-1.5" x2="-2.875" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-2.875" y1="-1.625" x2="-3.375" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-3.5" y1="-1.5" x2="-3.375" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-1.5" y1="-1.5" x2="-1.625" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-1.625" y1="-1.625" x2="-2.125" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-2.25" y1="-1.5" x2="-2.125" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-0.25" y1="-1.5" x2="-0.375" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-0.375" y1="-1.625" x2="-0.875" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-1" y1="-1.5" x2="-0.875" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="1" y1="-1.5" x2="0.875" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="0.875" y1="-1.625" x2="0.375" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="0.25" y1="-1.5" x2="0.375" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="2.25" y1="-1.5" x2="2.125" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="2.125" y1="-1.625" x2="1.625" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="1.5" y1="-1.5" x2="1.625" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="3.5" y1="-1.5" x2="3.375" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="3.375" y1="-1.625" x2="2.875" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="2.75" y1="-1.5" x2="2.875" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="4.75" y1="-1.5" x2="4.625" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="4.625" y1="-1.625" x2="4.125" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="4" y1="-1.5" x2="4.125" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="6" y1="-1.5" x2="5.875" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="5.875" y1="-1.625" x2="5.375" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="5.25" y1="-1.5" x2="5.375" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="7.25" y1="-1.5" x2="7.125" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="7.125" y1="-1.625" x2="6.625" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="6.5" y1="-1.5" x2="6.625" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="8.375" y1="-1.625" x2="7.875" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="7.75" y1="-1.5" x2="7.875" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-7.875" y1="-1.625" x2="-8.375" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="-8.875" y1="-1" x2="-8.375" y2="-1" width="0.2032" layer="21"/>
<wire x1="-8.375" y1="-1" x2="-8.375" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="8.375" y1="-1" x2="8.875" y2="-1" width="0.2032" layer="21"/>
<wire x1="8.375" y1="-1" x2="8.375" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="-8.375" y1="1.5" x2="-8.375" y2="2.75" width="0.0508" layer="21"/>
<wire x1="-8.375" y1="2.75" x2="8.375" y2="2.75" width="0.0508" layer="21"/>
<wire x1="8.375" y1="2.75" x2="8.375" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-8.375" y1="2.75" x2="-8.75" y2="3.125" width="0.0508" layer="21"/>
<wire x1="8.375" y1="2.75" x2="8.75" y2="3.125" width="0.0508" layer="21"/>
<wire x1="-7.625" y1="1.5" x2="-7.5" y2="2" width="0.2032" layer="21"/>
<wire x1="-7.5" y1="2" x2="-7.375" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-6.375" y1="1.5" x2="-6.25" y2="2" width="0.2032" layer="21"/>
<wire x1="-6.25" y1="2" x2="-6.125" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-5.125" y1="1.5" x2="-5" y2="2" width="0.2032" layer="21"/>
<wire x1="-5" y1="2" x2="-4.875" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-3.875" y1="1.5" x2="-3.75" y2="2" width="0.2032" layer="21"/>
<wire x1="-3.75" y1="2" x2="-3.625" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-2.625" y1="1.5" x2="-2.5" y2="2" width="0.2032" layer="21"/>
<wire x1="-2.5" y1="2" x2="-2.375" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-1.375" y1="1.5" x2="-1.25" y2="2" width="0.2032" layer="21"/>
<wire x1="-1.25" y1="2" x2="-1.125" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-0.125" y1="1.5" x2="0" y2="2" width="0.2032" layer="21"/>
<wire x1="0" y1="2" x2="0.125" y2="1.5" width="0.2032" layer="21"/>
<wire x1="1.125" y1="1.5" x2="1.25" y2="2" width="0.2032" layer="21"/>
<wire x1="1.25" y1="2" x2="1.375" y2="1.5" width="0.2032" layer="21"/>
<wire x1="2.375" y1="1.5" x2="2.5" y2="2" width="0.2032" layer="21"/>
<wire x1="2.5" y1="2" x2="2.625" y2="1.5" width="0.2032" layer="21"/>
<wire x1="3.625" y1="1.5" x2="3.75" y2="2" width="0.2032" layer="21"/>
<wire x1="3.75" y1="2" x2="3.875" y2="1.5" width="0.2032" layer="21"/>
<wire x1="4.875" y1="1.5" x2="5" y2="2" width="0.2032" layer="21"/>
<wire x1="5" y1="2" x2="5.125" y2="1.5" width="0.2032" layer="21"/>
<wire x1="6.125" y1="1.5" x2="6.25" y2="2" width="0.2032" layer="21"/>
<wire x1="6.25" y1="2" x2="6.375" y2="1.5" width="0.2032" layer="21"/>
<wire x1="7.375" y1="1.5" x2="7.5" y2="2" width="0.2032" layer="21"/>
<wire x1="7.5" y1="2" x2="7.625" y2="1.5" width="0.2032" layer="21"/>
<pad name="1" x="7.5" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="2" x="6.25" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="3" x="5" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="4" x="3.75" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="5" x="2.5" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="6" x="1.25" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="7" x="0" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="8" x="-1.25" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="9" x="-2.5" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="10" x="-3.75" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="11" x="-5" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="12" x="-6.25" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="13" x="-7.5" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<text x="-7.5" y="3.375" size="1.27" layer="25">&gt;NAME</text>
<text x="-8.125" y="-3.625" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-7.75" y1="-1.5" x2="-7.25" y2="-1" layer="51"/>
<rectangle x1="-6.5" y1="-1.5" x2="-6" y2="-1" layer="51"/>
<rectangle x1="-5.25" y1="-1.5" x2="-4.75" y2="-1" layer="51"/>
<rectangle x1="-4" y1="-1.5" x2="-3.5" y2="-1" layer="51"/>
<rectangle x1="-2.75" y1="-1.5" x2="-2.25" y2="-1" layer="51"/>
<rectangle x1="-1.5" y1="-1.5" x2="-1" y2="-1" layer="51"/>
<rectangle x1="-0.25" y1="-1.5" x2="0.25" y2="-1" layer="51"/>
<rectangle x1="1" y1="-1.5" x2="1.5" y2="-1" layer="51"/>
<rectangle x1="2.25" y1="-1.5" x2="2.75" y2="-1" layer="51"/>
<rectangle x1="3.5" y1="-1.5" x2="4" y2="-1" layer="51"/>
<rectangle x1="4.75" y1="-1.5" x2="5.25" y2="-1" layer="51"/>
<rectangle x1="6" y1="-1.5" x2="6.5" y2="-1" layer="51"/>
<rectangle x1="7.25" y1="-1.5" x2="7.75" y2="-1" layer="51"/>
<rectangle x1="-7.75" y1="0.625" x2="-7.25" y2="1.5" layer="21"/>
<rectangle x1="-6.5" y1="0.625" x2="-6" y2="1.5" layer="21"/>
<rectangle x1="-5.25" y1="0.625" x2="-4.75" y2="1.5" layer="21"/>
<rectangle x1="-4" y1="0.625" x2="-3.5" y2="1.5" layer="21"/>
<rectangle x1="-2.75" y1="0.625" x2="-2.25" y2="1.5" layer="21"/>
<rectangle x1="-1.5" y1="0.625" x2="-1" y2="1.5" layer="21"/>
<rectangle x1="-0.25" y1="0.625" x2="0.25" y2="1.5" layer="21"/>
<rectangle x1="1" y1="0.625" x2="1.5" y2="1.5" layer="21"/>
<rectangle x1="2.25" y1="0.625" x2="2.75" y2="1.5" layer="21"/>
<rectangle x1="3.5" y1="0.625" x2="4" y2="1.5" layer="21"/>
<rectangle x1="4.75" y1="0.625" x2="5.25" y2="1.5" layer="21"/>
<rectangle x1="6" y1="0.625" x2="6.5" y2="1.5" layer="21"/>
<rectangle x1="7.25" y1="0.625" x2="7.75" y2="1.5" layer="21"/>
</package>
<package name="53048-12">
right angle</description>
<wire x1="-8.275" y1="-2.25" x2="-7.75" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="7.75" y1="-2.25" x2="8.275" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="8.275" y1="-2.25" x2="8.275" y2="3.125" width="0.2032" layer="21"/>
<wire x1="8.275" y1="3.125" x2="8.125" y2="3.125" width="0.2032" layer="21"/>
<wire x1="8.125" y1="3.125" x2="-8.125" y2="3.125" width="0.2032" layer="21"/>
<wire x1="-8.125" y1="3.125" x2="-8.275" y2="3.125" width="0.2032" layer="21"/>
<wire x1="-8.275" y1="3.125" x2="-8.275" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="-8.25" y1="1.5" x2="-7.75" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-7.75" y1="1.5" x2="-7.5" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-7.5" y1="1.5" x2="-7.5" y2="0.625" width="0.0508" layer="21"/>
<wire x1="-7.5" y1="0.625" x2="7.5" y2="0.625" width="0.0508" layer="21"/>
<wire x1="7.5" y1="1.5" x2="7.75" y2="1.5" width="0.0508" layer="21"/>
<wire x1="7.75" y1="1.5" x2="8.25" y2="1.5" width="0.0508" layer="21"/>
<wire x1="7.5" y1="1.5" x2="7.5" y2="0.625" width="0.0508" layer="21"/>
<wire x1="-7.75" y1="-1" x2="7.75" y2="-1" width="0.2032" layer="51"/>
<wire x1="-8.25" y1="-1" x2="-7.75" y2="-1" width="0.2032" layer="21"/>
<wire x1="-7.75" y1="-1" x2="-7.75" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="7.75" y1="-1" x2="8.25" y2="-1" width="0.2032" layer="21"/>
<wire x1="7.75" y1="-1" x2="7.75" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="-7.75" y1="1.5" x2="-7.75" y2="2.75" width="0.0508" layer="21"/>
<wire x1="-7.75" y1="2.75" x2="7.75" y2="2.75" width="0.0508" layer="21"/>
<wire x1="7.75" y1="2.75" x2="7.75" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-7.75" y1="2.75" x2="-8.125" y2="3.125" width="0.0508" layer="21"/>
<wire x1="7.75" y1="2.75" x2="8.125" y2="3.125" width="0.0508" layer="21"/>
<pad name="1" x="6.875" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="2" x="5.625" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="3" x="4.375" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="4" x="3.125" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="5" x="1.875" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="6" x="0.625" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="7" x="-0.625" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="8" x="-1.875" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="9" x="-3.125" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="10" x="-4.375" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="11" x="-5.625" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="12" x="-6.875" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<text x="-6.875" y="3.375" size="1.27" layer="25">&gt;NAME</text>
<text x="-7.5" y="-3.75" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="53048-11">
<wire x1="-7.65" y1="-2.25" x2="-7.125" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="7.125" y1="-2.25" x2="7.65" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="7.65" y1="-2.25" x2="7.65" y2="3.125" width="0.2032" layer="21"/>
<wire x1="7.65" y1="3.125" x2="7.5" y2="3.125" width="0.2032" layer="21"/>
<wire x1="7.5" y1="3.125" x2="-7.5" y2="3.125" width="0.2032" layer="21"/>
<wire x1="-7.5" y1="3.125" x2="-7.65" y2="3.125" width="0.2032" layer="21"/>
<wire x1="-7.65" y1="3.125" x2="-7.65" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="-7.625" y1="1.5" x2="-7.125" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-7.125" y1="1.5" x2="-6.875" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-6.875" y1="1.5" x2="-6.875" y2="0.625" width="0.0508" layer="21"/>
<wire x1="-6.875" y1="0.625" x2="6.875" y2="0.625" width="0.0508" layer="21"/>
<wire x1="6.875" y1="1.5" x2="7.125" y2="1.5" width="0.0508" layer="21"/>
<wire x1="7.125" y1="1.5" x2="7.625" y2="1.5" width="0.0508" layer="21"/>
<wire x1="6.875" y1="1.5" x2="6.875" y2="0.625" width="0.0508" layer="21"/>
<wire x1="-7.125" y1="-1" x2="7.125" y2="-1" width="0.2032" layer="51"/>
<wire x1="-7.625" y1="-1" x2="-7.125" y2="-1" width="0.2032" layer="21"/>
<wire x1="-7.125" y1="-1" x2="-7.125" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="7.125" y1="-1" x2="7.625" y2="-1" width="0.2032" layer="21"/>
<wire x1="7.125" y1="-1" x2="7.125" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="-7.125" y1="1.5" x2="-7.125" y2="2.75" width="0.0508" layer="21"/>
<wire x1="-7.125" y1="2.75" x2="7.125" y2="2.75" width="0.0508" layer="21"/>
<wire x1="7.125" y1="2.75" x2="7.125" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-7.125" y1="2.75" x2="-7.5" y2="3.125" width="0.0508" layer="21"/>
<wire x1="7.125" y1="2.75" x2="7.5" y2="3.125" width="0.0508" layer="21"/>
<pad name="1" x="6.25" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="2" x="5" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="3" x="3.75" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="4" x="2.5" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="5" x="1.25" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="6" x="0" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="7" x="-1.25" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="8" x="-2.5" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="9" x="-3.75" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="10" x="-5" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="11" x="-6.25" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<text x="-6.25" y="3.375" size="1.27" layer="25">&gt;NAME</text>
<text x="-7.125" y="-3.75" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="53048-10">
<wire x1="-7.025" y1="-2.25" x2="-6.5" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="6.5" y1="-2.25" x2="7.025" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="7.025" y1="-2.25" x2="7.025" y2="3.125" width="0.2032" layer="21"/>
<wire x1="7.025" y1="3.125" x2="6.875" y2="3.125" width="0.2032" layer="21"/>
<wire x1="6.875" y1="3.125" x2="-6.875" y2="3.125" width="0.2032" layer="21"/>
<wire x1="-6.875" y1="3.125" x2="-7.025" y2="3.125" width="0.2032" layer="21"/>
<wire x1="-7.025" y1="3.125" x2="-7.025" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="-7" y1="1.5" x2="-6.5" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-6.5" y1="1.5" x2="-6.25" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-6.25" y1="1.5" x2="-6.25" y2="0.625" width="0.0508" layer="21"/>
<wire x1="-6.25" y1="0.625" x2="6.25" y2="0.625" width="0.0508" layer="21"/>
<wire x1="6.25" y1="1.5" x2="6.5" y2="1.5" width="0.0508" layer="21"/>
<wire x1="6.5" y1="1.5" x2="7" y2="1.5" width="0.0508" layer="21"/>
<wire x1="6.25" y1="1.5" x2="6.25" y2="0.625" width="0.0508" layer="21"/>
<wire x1="-6.5" y1="-1" x2="6.5" y2="-1" width="0.2032" layer="51"/>
<wire x1="-7" y1="-1" x2="-6.5" y2="-1" width="0.2032" layer="21"/>
<wire x1="-6.5" y1="-1" x2="-6.5" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="6.5" y1="-1" x2="7" y2="-1" width="0.2032" layer="21"/>
<wire x1="6.5" y1="-1" x2="6.5" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="-6.5" y1="1.5" x2="-6.5" y2="2.75" width="0.0508" layer="21"/>
<wire x1="-6.5" y1="2.75" x2="6.5" y2="2.75" width="0.0508" layer="21"/>
<wire x1="6.5" y1="2.75" x2="6.5" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-6.5" y1="2.75" x2="-6.875" y2="3.125" width="0.0508" layer="21"/>
<wire x1="6.5" y1="2.75" x2="6.875" y2="3.125" width="0.0508" layer="21"/>
<pad name="1" x="5.625" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="2" x="4.375" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="3" x="3.125" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="4" x="1.875" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="5" x="0.625" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="6" x="-0.625" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="7" x="-1.875" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="8" x="-3.125" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="9" x="-4.375" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="10" x="-5.625" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<text x="-5.625" y="3.375" size="1.27" layer="25">&gt;NAME</text>
<text x="-6.5" y="-3.875" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="53048-09">
<wire x1="-6.4" y1="-2.25" x2="-5.875" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="5.875" y1="-2.25" x2="6.4" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="6.4" y1="-2.25" x2="6.4" y2="3.125" width="0.2032" layer="21"/>
<wire x1="6.4" y1="3.125" x2="6.25" y2="3.125" width="0.2032" layer="21"/>
<wire x1="6.25" y1="3.125" x2="-6.25" y2="3.125" width="0.2032" layer="21"/>
<wire x1="-6.25" y1="3.125" x2="-6.4" y2="3.125" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="3.125" x2="-6.4" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="-6.375" y1="1.5" x2="-5.875" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-5.875" y1="1.5" x2="-5.625" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-5.625" y1="1.5" x2="-5.625" y2="0.625" width="0.0508" layer="21"/>
<wire x1="-5.625" y1="0.625" x2="5.625" y2="0.625" width="0.0508" layer="21"/>
<wire x1="5.625" y1="1.5" x2="5.875" y2="1.5" width="0.0508" layer="21"/>
<wire x1="5.875" y1="1.5" x2="6.375" y2="1.5" width="0.0508" layer="21"/>
<wire x1="5.625" y1="1.5" x2="5.625" y2="0.625" width="0.0508" layer="21"/>
<wire x1="-5.875" y1="-1" x2="5.875" y2="-1" width="0.2032" layer="51"/>
<wire x1="-6.375" y1="-1" x2="-5.875" y2="-1" width="0.2032" layer="21"/>
<wire x1="-5.875" y1="-1" x2="-5.875" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="5.875" y1="-1" x2="6.375" y2="-1" width="0.2032" layer="21"/>
<wire x1="5.875" y1="-1" x2="5.875" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="-5.875" y1="1.5" x2="-5.875" y2="2.75" width="0.0508" layer="21"/>
<wire x1="-5.875" y1="2.75" x2="5.875" y2="2.75" width="0.0508" layer="21"/>
<wire x1="5.875" y1="2.75" x2="5.875" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-5.875" y1="2.75" x2="-6.25" y2="3.125" width="0.0508" layer="21"/>
<wire x1="5.875" y1="2.75" x2="6.25" y2="3.125" width="0.0508" layer="21"/>
<pad name="1" x="5" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="2" x="3.75" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="3" x="2.5" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="4" x="1.25" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="5" x="0" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="6" x="-1.25" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="7" x="-2.5" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="8" x="-3.75" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="9" x="-5" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<text x="-5" y="3.375" size="1.27" layer="25">&gt;NAME</text>
<text x="-6" y="-3.75" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="53048-08">
<wire x1="-5.775" y1="-2.25" x2="-5.25" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="5.25" y1="-2.25" x2="5.775" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="5.775" y1="-2.25" x2="5.775" y2="3.125" width="0.2032" layer="21"/>
<wire x1="5.775" y1="3.125" x2="5.625" y2="3.125" width="0.2032" layer="21"/>
<wire x1="5.625" y1="3.125" x2="-5.625" y2="3.125" width="0.2032" layer="21"/>
<wire x1="-5.625" y1="3.125" x2="-5.775" y2="3.125" width="0.2032" layer="21"/>
<wire x1="-5.775" y1="3.125" x2="-5.775" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="-5.75" y1="1.5" x2="-5.25" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-5.25" y1="1.5" x2="-5" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-5" y1="1.5" x2="-5" y2="0.625" width="0.0508" layer="21"/>
<wire x1="-5" y1="0.625" x2="5" y2="0.625" width="0.0508" layer="21"/>
<wire x1="5" y1="1.5" x2="5.25" y2="1.5" width="0.0508" layer="21"/>
<wire x1="5.25" y1="1.5" x2="5.75" y2="1.5" width="0.0508" layer="21"/>
<wire x1="5" y1="1.5" x2="5" y2="0.625" width="0.0508" layer="21"/>
<wire x1="-5.25" y1="-1" x2="5.25" y2="-1" width="0.2032" layer="51"/>
<wire x1="-5.75" y1="-1" x2="-5.25" y2="-1" width="0.2032" layer="21"/>
<wire x1="-5.25" y1="-1" x2="-5.25" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="5.25" y1="-1" x2="5.75" y2="-1" width="0.2032" layer="21"/>
<wire x1="5.25" y1="-1" x2="5.25" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="-5.25" y1="1.5" x2="-5.25" y2="2.75" width="0.0508" layer="21"/>
<wire x1="-5.25" y1="2.75" x2="5.25" y2="2.75" width="0.0508" layer="21"/>
<wire x1="5.25" y1="2.75" x2="5.25" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-5.25" y1="2.75" x2="-5.625" y2="3.125" width="0.0508" layer="21"/>
<wire x1="5.25" y1="2.75" x2="5.625" y2="3.125" width="0.0508" layer="21"/>
<pad name="1" x="4.375" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="2" x="3.125" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="3" x="1.875" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="4" x="0.625" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="5" x="-0.625" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="6" x="-1.875" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="7" x="-3.125" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="8" x="-4.375" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<text x="-4.375" y="3.375" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.375" y="-3.75" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="53048-07">
<wire x1="-5.15" y1="-2.25" x2="-4.625" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="4.625" y1="-2.25" x2="5.15" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="5.15" y1="-2.25" x2="5.15" y2="3.125" width="0.2032" layer="21"/>
<wire x1="5.15" y1="3.125" x2="5" y2="3.125" width="0.2032" layer="21"/>
<wire x1="5" y1="3.125" x2="-5" y2="3.125" width="0.2032" layer="21"/>
<wire x1="-5" y1="3.125" x2="-5.15" y2="3.125" width="0.2032" layer="21"/>
<wire x1="-5.15" y1="3.125" x2="-5.15" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="-5.125" y1="1.5" x2="-4.625" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-4.625" y1="1.5" x2="-4.375" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-4.375" y1="1.5" x2="-4.375" y2="0.625" width="0.0508" layer="21"/>
<wire x1="-4.375" y1="0.625" x2="4.375" y2="0.625" width="0.0508" layer="21"/>
<wire x1="4.375" y1="1.5" x2="4.625" y2="1.5" width="0.0508" layer="21"/>
<wire x1="4.625" y1="1.5" x2="5.125" y2="1.5" width="0.0508" layer="21"/>
<wire x1="4.375" y1="1.5" x2="4.375" y2="0.625" width="0.0508" layer="21"/>
<wire x1="-4.625" y1="-1" x2="4.625" y2="-1" width="0.2032" layer="51"/>
<wire x1="-5.125" y1="-1" x2="-4.625" y2="-1" width="0.2032" layer="21"/>
<wire x1="-4.625" y1="-1" x2="-4.625" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="4.625" y1="-1" x2="5.125" y2="-1" width="0.2032" layer="21"/>
<wire x1="4.625" y1="-1" x2="4.625" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="-4.625" y1="1.5" x2="-4.625" y2="2.75" width="0.0508" layer="21"/>
<wire x1="-4.625" y1="2.75" x2="4.625" y2="2.75" width="0.0508" layer="21"/>
<wire x1="4.625" y1="2.75" x2="4.625" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-4.625" y1="2.75" x2="-5" y2="3.125" width="0.0508" layer="21"/>
<wire x1="4.625" y1="2.75" x2="5" y2="3.125" width="0.0508" layer="21"/>
<pad name="1" x="3.75" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="2" x="2.5" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="3" x="1.25" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="4" x="0" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="5" x="-1.25" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="6" x="-2.5" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="7" x="-3.75" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<text x="-3.75" y="3.375" size="1.27" layer="25">&gt;NAME</text>
<text x="-4.75" y="-3.75" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="53048-06">
<description>&lt;b&gt;CONNECTOR&lt;/b&gt;&lt;p&gt;
<wire x1="-4.525" y1="-2.25" x2="-4" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="4" y1="-2.25" x2="4.525" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="4.525" y1="-2.25" x2="4.525" y2="3.125" width="0.2032" layer="21"/>
<wire x1="4.525" y1="3.125" x2="4.375" y2="3.125" width="0.2032" layer="21"/>
<wire x1="4.375" y1="3.125" x2="-4.375" y2="3.125" width="0.2032" layer="21"/>
<wire x1="-4.375" y1="3.125" x2="-4.525" y2="3.125" width="0.2032" layer="21"/>
<wire x1="-4.525" y1="3.125" x2="-4.525" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="-4.5" y1="1.5" x2="-4" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-4" y1="1.5" x2="-3.75" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-3.75" y1="1.5" x2="-3.75" y2="0.625" width="0.0508" layer="21"/>
<wire x1="-3.75" y1="0.625" x2="3.75" y2="0.625" width="0.0508" layer="21"/>
<wire x1="3.75" y1="1.5" x2="4" y2="1.5" width="0.0508" layer="21"/>
<wire x1="4" y1="1.5" x2="4.5" y2="1.5" width="0.0508" layer="21"/>
<wire x1="3.75" y1="1.5" x2="3.75" y2="0.625" width="0.0508" layer="21"/>
<wire x1="-4" y1="-1" x2="4" y2="-1" width="0.2032" layer="51"/>
<wire x1="-4.5" y1="-1" x2="-4" y2="-1" width="0.2032" layer="21"/>
<wire x1="-4" y1="-1" x2="-4" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="4" y1="-1" x2="4.5" y2="-1" width="0.2032" layer="21"/>
<wire x1="4" y1="-1" x2="4" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="-4" y1="1.5" x2="-4" y2="2.75" width="0.0508" layer="21"/>
<wire x1="-4" y1="2.75" x2="4" y2="2.75" width="0.0508" layer="21"/>
<wire x1="4" y1="2.75" x2="4" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-4" y1="2.75" x2="-4.375" y2="3.125" width="0.0508" layer="21"/>
<wire x1="4" y1="2.75" x2="4.375" y2="3.125" width="0.0508" layer="21"/>
<pad name="1" x="3.125" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="2" x="1.875" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="3" x="0.625" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="4" x="-0.625" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="5" x="-1.875" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="6" x="-3.125" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<text x="-3.125" y="3.375" size="1.27" layer="25">&gt;NAME</text>
<text x="-4.375" y="-3.75" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="53048-05">
<wire x1="-3.9" y1="-2.25" x2="-3.375" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="3.375" y1="-2.25" x2="3.9" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="3.9" y1="-2.25" x2="3.9" y2="3.125" width="0.2032" layer="21"/>
<wire x1="3.9" y1="3.125" x2="3.75" y2="3.125" width="0.2032" layer="21"/>
<wire x1="3.75" y1="3.125" x2="-3.75" y2="3.125" width="0.2032" layer="21"/>
<wire x1="-3.75" y1="3.125" x2="-3.9" y2="3.125" width="0.2032" layer="21"/>
<wire x1="-3.9" y1="3.125" x2="-3.9" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="-3.875" y1="1.5" x2="-3.375" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-3.375" y1="1.5" x2="-3.125" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-3.125" y1="1.5" x2="-3.125" y2="0.625" width="0.0508" layer="21"/>
<wire x1="-3.125" y1="0.625" x2="3.125" y2="0.625" width="0.0508" layer="21"/>
<wire x1="3.125" y1="1.5" x2="3.375" y2="1.5" width="0.0508" layer="21"/>
<wire x1="3.375" y1="1.5" x2="3.875" y2="1.5" width="0.0508" layer="21"/>
<wire x1="3.125" y1="1.5" x2="3.125" y2="0.625" width="0.0508" layer="21"/>
<wire x1="-3.375" y1="-1" x2="3.375" y2="-1" width="0.2032" layer="51"/>
<wire x1="-3.875" y1="-1" x2="-3.375" y2="-1" width="0.2032" layer="21"/>
<wire x1="-3.375" y1="-1" x2="-3.375" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="3.375" y1="-1" x2="3.875" y2="-1" width="0.2032" layer="21"/>
<wire x1="3.375" y1="-1" x2="3.375" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="-3.375" y1="1.5" x2="-3.375" y2="2.75" width="0.0508" layer="21"/>
<wire x1="-3.375" y1="2.75" x2="3.375" y2="2.75" width="0.0508" layer="21"/>
<wire x1="3.375" y1="2.75" x2="3.375" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-3.375" y1="2.75" x2="-3.75" y2="3.125" width="0.0508" layer="21"/>
<wire x1="3.375" y1="2.75" x2="3.75" y2="3.125" width="0.0508" layer="21"/>
<pad name="1" x="2.5" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="2" x="1.25" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="3" x="0" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="4" x="-1.25" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="5" x="-2.5" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<text x="-2.5" y="3.375" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.625" y="-3.75" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="53048-04">
<wire x1="-3.275" y1="-2.25" x2="-2.75" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="2.75" y1="-2.25" x2="3.275" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="3.275" y1="-2.25" x2="3.275" y2="3.125" width="0.2032" layer="21"/>
<wire x1="3.275" y1="3.125" x2="3.125" y2="3.125" width="0.2032" layer="21"/>
<wire x1="3.125" y1="3.125" x2="-3.125" y2="3.125" width="0.2032" layer="21"/>
<wire x1="-3.125" y1="3.125" x2="-3.275" y2="3.125" width="0.2032" layer="21"/>
<wire x1="-3.275" y1="3.125" x2="-3.275" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="-3.25" y1="1.5" x2="-2.75" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-2.75" y1="1.5" x2="-2.5" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-2.5" y1="1.5" x2="-2.5" y2="0.625" width="0.0508" layer="21"/>
<wire x1="-2.5" y1="0.625" x2="2.5" y2="0.625" width="0.0508" layer="21"/>
<wire x1="2.5" y1="1.5" x2="2.75" y2="1.5" width="0.0508" layer="21"/>
<wire x1="2.75" y1="1.5" x2="3.25" y2="1.5" width="0.0508" layer="21"/>
<wire x1="2.5" y1="1.5" x2="2.5" y2="0.625" width="0.0508" layer="21"/>
<wire x1="-2.75" y1="-1" x2="2.75" y2="-1" width="0.2032" layer="51"/>
<wire x1="-3.25" y1="-1" x2="-2.75" y2="-1" width="0.2032" layer="21"/>
<wire x1="-2.75" y1="-1" x2="-2.75" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="2.75" y1="-1" x2="3.25" y2="-1" width="0.2032" layer="21"/>
<wire x1="2.75" y1="-1" x2="2.75" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="-2.75" y1="1.5" x2="-2.75" y2="2.75" width="0.0508" layer="21"/>
<wire x1="-2.75" y1="2.75" x2="2.75" y2="2.75" width="0.0508" layer="21"/>
<wire x1="2.75" y1="2.75" x2="2.75" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-2.75" y1="2.75" x2="-3.125" y2="3.125" width="0.0508" layer="21"/>
<wire x1="2.75" y1="2.75" x2="3.125" y2="3.125" width="0.0508" layer="21"/>
<pad name="1" x="1.875" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="2" x="0.625" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="3" x="-0.625" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="4" x="-1.875" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<text x="-1.875" y="3.375" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.25" y="-3.75" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="53048-03">
wire to board 1.25 mm (.049 inch) pitch header&lt;p&gt;
<wire x1="-2.65" y1="-2.25" x2="-2.125" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="2.125" y1="-2.25" x2="2.65" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="2.65" y1="-2.25" x2="2.65" y2="3.125" width="0.2032" layer="21"/>
<wire x1="2.65" y1="3.125" x2="2.5" y2="3.125" width="0.2032" layer="21"/>
<wire x1="2.5" y1="3.125" x2="-2.5" y2="3.125" width="0.2032" layer="21"/>
<wire x1="-2.5" y1="3.125" x2="-2.65" y2="3.125" width="0.2032" layer="21"/>
<wire x1="-2.65" y1="3.125" x2="-2.65" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="-2.625" y1="1.5" x2="-2.125" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-2.125" y1="1.5" x2="-1.875" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-1.875" y1="1.5" x2="-1.875" y2="0.625" width="0.0508" layer="21"/>
<wire x1="-1.875" y1="0.625" x2="1.875" y2="0.625" width="0.0508" layer="21"/>
<wire x1="1.875" y1="1.5" x2="2.125" y2="1.5" width="0.0508" layer="21"/>
<wire x1="2.125" y1="1.5" x2="2.625" y2="1.5" width="0.0508" layer="21"/>
<wire x1="1.875" y1="1.5" x2="1.875" y2="0.625" width="0.0508" layer="21"/>
<wire x1="-2.125" y1="-1" x2="2.125" y2="-1" width="0.2032" layer="51"/>
<wire x1="-2.625" y1="-1" x2="-2.125" y2="-1" width="0.2032" layer="21"/>
<wire x1="-2.125" y1="-1" x2="-2.125" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="2.125" y1="-1" x2="2.625" y2="-1" width="0.2032" layer="21"/>
<wire x1="2.125" y1="-1" x2="2.125" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="-2.125" y1="1.5" x2="-2.125" y2="2.75" width="0.0508" layer="21"/>
<wire x1="-2.125" y1="2.75" x2="2.125" y2="2.75" width="0.0508" layer="21"/>
<wire x1="2.125" y1="2.75" x2="2.125" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-2.125" y1="2.75" x2="-2.5" y2="3.125" width="0.0508" layer="21"/>
<wire x1="2.125" y1="2.75" x2="2.5" y2="3.125" width="0.0508" layer="21"/>
<pad name="1" x="1.25" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="2" x="0" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="3" x="-1.25" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<text x="-2.625" y="-3.875" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="53048-02">
<wire x1="-2.025" y1="-2.25" x2="-1.5" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="1.5" y1="-2.25" x2="2.025" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="2.025" y1="-2.25" x2="2.025" y2="3.125" width="0.2032" layer="21"/>
<wire x1="2.025" y1="3.125" x2="1.875" y2="3.125" width="0.2032" layer="21"/>
<wire x1="1.875" y1="3.125" x2="-1.875" y2="3.125" width="0.2032" layer="21"/>
<wire x1="-1.875" y1="3.125" x2="-2.025" y2="3.125" width="0.2032" layer="21"/>
<wire x1="-2.025" y1="3.125" x2="-2.025" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="-2" y1="1.5" x2="-1.5" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-1.5" y1="1.5" x2="-1.25" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-1.25" y1="1.5" x2="-1.25" y2="0.625" width="0.0508" layer="21"/>
<wire x1="-1.25" y1="0.625" x2="1.25" y2="0.625" width="0.0508" layer="21"/>
<wire x1="1.25" y1="1.5" x2="1.5" y2="1.5" width="0.0508" layer="21"/>
<wire x1="1.5" y1="1.5" x2="2" y2="1.5" width="0.0508" layer="21"/>
<wire x1="1.25" y1="1.5" x2="1.25" y2="0.625" width="0.0508" layer="21"/>
<wire x1="-1.5" y1="-1" x2="1.5" y2="-1" width="0.2032" layer="51"/>
<wire x1="-2" y1="-1" x2="-1.5" y2="-1" width="0.2032" layer="21"/>
<wire x1="-1.5" y1="-1" x2="-1.5" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="1.5" y1="-1" x2="2" y2="-1" width="0.2032" layer="21"/>
<wire x1="1.5" y1="-1" x2="1.5" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="-1.5" y1="1.5" x2="-1.5" y2="2.75" width="0.0508" layer="21"/>
<wire x1="-1.5" y1="2.75" x2="1.5" y2="2.75" width="0.0508" layer="21"/>
<wire x1="1.5" y1="2.75" x2="1.5" y2="1.5" width="0.0508" layer="21"/>
<wire x1="-1.5" y1="2.75" x2="-1.875" y2="3.125" width="0.0508" layer="21"/>
<wire x1="1.5" y1="2.75" x2="1.875" y2="3.125" width="0.0508" layer="21"/>
<pad name="1" x="0.625" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<pad name="2" x="-0.625" y="-1.25" drill="0.5" diameter="0.6984" shape="long" rot="R90"/>
<text x="-2" y="-3.875" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="71061-0001">
50-pin 1.27mm (.050 inch) pitch SCSI+ unshielded receptacle, right angle, all plastic&lt;br&gt;
Source: http://www.molex.com/product/io/71061.html</description>
<wire x1="-17.235" y1="9.365" x2="17.235" y2="9.365" width="0.2032" layer="21"/>
<wire x1="17.235" y1="9.365" x2="17.235" y2="4.365" width="0.2032" layer="21"/>
<wire x1="17.235" y1="4.365" x2="20.735" y2="4.365" width="0.2032" layer="21"/>
<wire x1="20.735" y1="4.365" x2="20.735" y2="-6.885" width="0.2032" layer="21"/>
<wire x1="20.735" y1="-6.885" x2="-20.785" y2="-6.885" width="0.2032" layer="21"/>
<wire x1="-20.785" y1="-6.885" x2="-20.785" y2="4.365" width="0.2032" layer="21"/>
<wire x1="-20.785" y1="4.365" x2="-17.235" y2="4.365" width="0.2032" layer="21"/>
<wire x1="-17.235" y1="4.365" x2="-17.235" y2="9.365" width="0.2032" layer="21"/>
<wire x1="17.235" y1="4.365" x2="-17.235" y2="4.365" width="0.2032" layer="21"/>
<pad name="1" x="-15.24" y="-5.73" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="2" x="-13.97" y="-3.82" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="3" x="-12.7" y="-5.73" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="4" x="-11.43" y="-3.82" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="5" x="-10.16" y="-5.73" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="6" x="-8.89" y="-3.82" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="7" x="-7.62" y="-5.73" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="8" x="-6.35" y="-3.82" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="9" x="-5.08" y="-5.73" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="10" x="-3.81" y="-3.82" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="11" x="-2.54" y="-5.73" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="12" x="-1.27" y="-3.82" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="13" x="0" y="-5.73" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="14" x="1.27" y="-3.82" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="15" x="2.54" y="-5.73" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="16" x="3.81" y="-3.82" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="17" x="5.08" y="-5.73" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="18" x="6.35" y="-3.82" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="19" x="7.62" y="-5.73" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="20" x="8.89" y="-3.82" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="21" x="10.16" y="-5.73" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="22" x="11.43" y="-3.82" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="23" x="12.7" y="-5.73" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="24" x="13.97" y="-3.82" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="25" x="15.24" y="-5.73" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="26" x="-15.24" y="-1.91" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="27" x="-13.97" y="0" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="28" x="-12.7" y="-1.91" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="29" x="-11.43" y="0" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="30" x="-10.16" y="-1.91" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="31" x="-8.89" y="0" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="32" x="-7.62" y="-1.91" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="33" x="-6.35" y="0" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="34" x="-5.08" y="-1.91" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="35" x="-3.81" y="0" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="36" x="-2.54" y="-1.91" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="37" x="-1.27" y="0" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="38" x="0" y="-1.91" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="39" x="1.27" y="0" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="40" x="2.54" y="-1.91" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="41" x="3.81" y="0" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="42" x="5.08" y="-1.91" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="43" x="6.35" y="0" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="44" x="7.62" y="-1.91" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="45" x="8.89" y="0" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="46" x="10.16" y="-1.91" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="47" x="11.43" y="0" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="48" x="12.7" y="-1.91" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="49" x="13.97" y="0" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="50" x="15.24" y="-1.91" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<text x="-17.78" y="-9.525" size="1.778" layer="25">&gt;NAME</text>
<text x="-15.24" y="1.905" size="1.778" layer="27">&gt;VALUE</text>
</package>
<package name="71061-0003">
68-pin 1.27mm (.050 inch) pitch SCSI+ unshielded receptacle, right angle, all plastic&lt;br&gt;
Source: http://www.molex.com/product/io/71061.html&lt;br&gt;
http://www.molex.com .. 710610003_sd.pdf</description>
<wire x1="-22.95" y1="9.365" x2="22.95" y2="9.365" width="0.2032" layer="21"/>
<wire x1="22.95" y1="9.365" x2="22.95" y2="4.365" width="0.2032" layer="21"/>
<wire x1="22.95" y1="4.365" x2="26.45" y2="4.365" width="0.2032" layer="21"/>
<wire x1="26.45" y1="4.365" x2="26.45" y2="-6.885" width="0.2032" layer="21"/>
<wire x1="26.45" y1="-6.885" x2="-26.5" y2="-6.885" width="0.2032" layer="21"/>
<wire x1="-26.5" y1="-6.885" x2="-26.5" y2="4.365" width="0.2032" layer="21"/>
<wire x1="-26.5" y1="4.365" x2="-22.95" y2="4.365" width="0.2032" layer="21"/>
<wire x1="-22.95" y1="4.365" x2="-22.95" y2="9.365" width="0.2032" layer="21"/>
<wire x1="22.95" y1="4.365" x2="-22.95" y2="4.365" width="0.2032" layer="21"/>
<pad name="1" x="-20.955" y="-5.73" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="2" x="-19.685" y="-3.82" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="3" x="-18.415" y="-5.73" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="4" x="-17.145" y="-3.82" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="5" x="-15.875" y="-5.73" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="6" x="-14.605" y="-3.82" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="7" x="-13.335" y="-5.73" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="8" x="-12.065" y="-3.82" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="9" x="-10.795" y="-5.73" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="10" x="-9.525" y="-3.82" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="11" x="-8.255" y="-5.73" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="12" x="-6.985" y="-3.82" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="13" x="-5.715" y="-5.73" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="14" x="-4.445" y="-3.82" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="15" x="-3.175" y="-5.73" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="16" x="-1.905" y="-3.82" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="17" x="-0.635" y="-5.73" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="18" x="0.635" y="-3.82" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="19" x="1.905" y="-5.73" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="20" x="3.175" y="-3.82" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="21" x="4.445" y="-5.73" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="22" x="5.715" y="-3.82" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="23" x="6.985" y="-5.73" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="24" x="8.255" y="-3.82" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="25" x="9.525" y="-5.73" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="26" x="10.795" y="-3.82" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="27" x="12.065" y="-5.73" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="28" x="13.335" y="-3.82" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="29" x="14.605" y="-5.73" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="30" x="15.875" y="-3.82" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="31" x="17.145" y="-5.73" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="32" x="18.415" y="-3.82" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="33" x="19.685" y="-5.73" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="34" x="20.955" y="-3.82" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="35" x="-20.955" y="-1.91" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="36" x="-19.685" y="0" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="37" x="-18.415" y="-1.91" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="38" x="-17.145" y="0" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="39" x="-15.875" y="-1.91" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="40" x="-14.605" y="0" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="41" x="-13.335" y="-1.91" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="42" x="-12.065" y="0" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="43" x="-10.795" y="-1.91" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="44" x="-9.525" y="0" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="45" x="-8.255" y="-1.91" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="46" x="-6.985" y="0" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="47" x="-5.715" y="-1.91" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="48" x="-4.445" y="0" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="49" x="-3.175" y="-1.91" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="50" x="-1.905" y="0" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="51" x="-0.635" y="-1.91" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="52" x="0.635" y="0" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="53" x="1.905" y="-1.91" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="54" x="3.175" y="0" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="55" x="4.445" y="-1.91" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="56" x="5.715" y="0" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="57" x="6.985" y="-1.91" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="58" x="8.255" y="0" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="59" x="9.525" y="-1.91" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="60" x="10.795" y="0" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="61" x="12.065" y="-1.91" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="62" x="13.335" y="0" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="63" x="14.605" y="-1.91" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="64" x="15.875" y="0" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="65" x="17.145" y="-1.91" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="66" x="18.415" y="0" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="67" x="19.685" y="-1.91" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<pad name="68" x="20.955" y="0" drill="0.8128" diameter="1.397" shape="octagon" rot="R180"/>
<text x="-23.495" y="-9.525" size="1.778" layer="25">&gt;NAME</text>
<text x="-20.955" y="1.905" size="1.778" layer="27">&gt;VALUE</text>
</package>
<package name="87360-SCSI">
input/output 3 in 1 combo connector&lt;p&gt;
wide SCSI, 2.00 mm, power, right angle</description>
<wire x1="-47.124" y1="-3.27" x2="47.404" y2="-3.27" width="0" layer="20"/>
<wire x1="-44.6" y1="-12.3" x2="-44.6" y2="-7.3" width="0.2032" layer="21"/>
<wire x1="-44.6" y1="-7.3" x2="-47.1" y2="-7.3" width="0.2032" layer="21"/>
<wire x1="-42" y1="-2.8" x2="-42" y2="0.5" width="0.2032" layer="51"/>
<wire x1="-42" y1="0.5" x2="-40.8" y2="0.5" width="0.2032" layer="51"/>
<wire x1="-40.8" y1="0.5" x2="-40.8" y2="-2.8" width="0.2032" layer="51"/>
<wire x1="-39.9" y1="-2.8" x2="-39.9" y2="0.5" width="0.2032" layer="51"/>
<wire x1="-39.9" y1="0.5" x2="-35.7" y2="0.5" width="0.2032" layer="51"/>
<wire x1="-35.7" y1="0.5" x2="-35.7" y2="-2.8" width="0.2032" layer="51"/>
<wire x1="-34.9" y1="-2.8" x2="-34.9" y2="0.5" width="0.2032" layer="51"/>
<wire x1="-34.9" y1="0.5" x2="-30.6" y2="0.5" width="0.2032" layer="51"/>
<wire x1="-30.6" y1="0.5" x2="-30.6" y2="-2.8" width="0.2032" layer="51"/>
<wire x1="-29.8" y1="-2.8" x2="-29.8" y2="0.5" width="0.2032" layer="51"/>
<wire x1="-29.8" y1="0.5" x2="-25.6" y2="0.5" width="0.2032" layer="51"/>
<wire x1="-25.6" y1="0.5" x2="-25.6" y2="-2.8" width="0.2032" layer="51"/>
<wire x1="-24.7" y1="-2.8" x2="-24.7" y2="0.5" width="0.2032" layer="51"/>
<wire x1="-41" y1="0.6" x2="-41" y2="0.8" width="0.2032" layer="51"/>
<wire x1="-41" y1="0.8" x2="-39.7" y2="0.8" width="0.2032" layer="51"/>
<wire x1="-39.7" y1="0.8" x2="-39.7" y2="0.6" width="0.2032" layer="51"/>
<wire x1="-35.9" y1="0.6" x2="-35.9" y2="0.8" width="0.2032" layer="51"/>
<wire x1="-35.9" y1="0.8" x2="-34.7" y2="0.8" width="0.2032" layer="51"/>
<wire x1="-34.7" y1="0.8" x2="-34.7" y2="0.6" width="0.2032" layer="51"/>
<wire x1="-30.8" y1="0.6" x2="-30.8" y2="0.8" width="0.2032" layer="51"/>
<wire x1="-30.8" y1="0.8" x2="-29.7" y2="0.8" width="0.2032" layer="51"/>
<wire x1="-29.7" y1="0.8" x2="-29.7" y2="0.6" width="0.2032" layer="51"/>
<wire x1="-46.091" y1="5.1" x2="-46.0914" y2="0.9301" width="0.2032" layer="51"/>
<wire x1="-44.491" y1="5.1" x2="-44.491" y2="0.93" width="0.2032" layer="51"/>
<wire x1="44.796" y1="0.93" x2="44.796" y2="5.1" width="0.2032" layer="51"/>
<wire x1="46.396" y1="0.93" x2="46.396" y2="5.1" width="0.2032" layer="51"/>
<wire x1="-25.8" y1="0.6" x2="-25.8" y2="0.8" width="0.2032" layer="51"/>
<wire x1="-25.8" y1="0.8" x2="-24.5" y2="0.8" width="0.2032" layer="51"/>
<wire x1="-24.5" y1="0.8" x2="-24.5" y2="0.6" width="0.2032" layer="51"/>
<wire x1="-24.7" y1="0.5" x2="-23.5" y2="0.5" width="0.2032" layer="51"/>
<wire x1="-18.55" y1="-2.7" x2="-18.55" y2="1.2" width="0.2032" layer="51"/>
<wire x1="-18.55" y1="1.2" x2="-18.05" y2="1.2" width="0.2032" layer="51"/>
<wire x1="-18.05" y1="1.2" x2="-18.05" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="-0.2" y1="-2.7" x2="-0.2" y2="1.438" width="0.2032" layer="51"/>
<wire x1="-0.2" y1="1.438" x2="0.2" y2="1.438" width="0.2032" layer="51"/>
<wire x1="0.2" y1="1.438" x2="0.2" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="47.4" y1="-7.3" x2="44.6" y2="-7.3" width="0.2032" layer="21"/>
<wire x1="44.6" y1="-7.3" x2="44.6" y2="-12" width="0.2032" layer="21"/>
<wire x1="44.6" y1="-12" x2="44.3" y2="-12.3" width="0.2032" layer="21"/>
<wire x1="44.6" y1="-7.3" x2="-1.4" y2="-7.3" width="0.2032" layer="21"/>
<wire x1="-1.4" y1="-7.3" x2="-5.4" y2="-7.3" width="0.2032" layer="21"/>
<wire x1="-5.4" y1="-7.3" x2="-5.4" y2="-12.3" width="0.2032" layer="21"/>
<wire x1="-5.4" y1="-12.3" x2="-6.7" y2="-12.3" width="0.2032" layer="21"/>
<wire x1="-1.4" y1="-7.3" x2="-1.4" y2="-11.9" width="0.2032" layer="21"/>
<wire x1="-1.4" y1="-11.9" x2="-1" y2="-12.3" width="0.2032" layer="21"/>
<wire x1="-1" y1="-12.3" x2="44.3" y2="-12.3" width="0.2032" layer="21"/>
<wire x1="47.4" y1="-7.3" x2="47.4" y2="-3.317" width="0.2032" layer="21"/>
<wire x1="-19.3" y1="-12.3" x2="-44.6" y2="-12.3" width="0.2032" layer="21"/>
<wire x1="-4.496" y1="0.93" x2="-4.496" y2="5.1" width="0.2032" layer="51"/>
<wire x1="-2.896" y1="0.93" x2="-2.896" y2="5.1" width="0.2032" layer="51"/>
<wire x1="-16.55" y1="-2.7" x2="-16.55" y2="1.2" width="0.2032" layer="51"/>
<wire x1="-16.55" y1="1.2" x2="-16.05" y2="1.2" width="0.2032" layer="51"/>
<wire x1="-16.05" y1="1.2" x2="-16.05" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="-14.55" y1="-2.7" x2="-14.55" y2="1.2" width="0.2032" layer="51"/>
<wire x1="-14.55" y1="1.2" x2="-14.05" y2="1.2" width="0.2032" layer="51"/>
<wire x1="-14.05" y1="1.2" x2="-14.05" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="-12.55" y1="-2.7" x2="-12.55" y2="1.2" width="0.2032" layer="51"/>
<wire x1="-12.55" y1="1.2" x2="-12.05" y2="1.2" width="0.2032" layer="51"/>
<wire x1="-12.05" y1="1.2" x2="-12.05" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="-10.55" y1="-2.7" x2="-10.55" y2="1.2" width="0.2032" layer="51"/>
<wire x1="-10.55" y1="1.2" x2="-10.05" y2="1.2" width="0.2032" layer="51"/>
<wire x1="-10.05" y1="1.2" x2="-10.05" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="-8.55" y1="-2.7" x2="-8.55" y2="1.2" width="0.2032" layer="51"/>
<wire x1="-8.55" y1="1.2" x2="-8.05" y2="1.2" width="0.2032" layer="51"/>
<wire x1="-8.05" y1="1.2" x2="-8.05" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="1.07" y1="-2.7" x2="1.07" y2="1.438" width="0.2032" layer="51"/>
<wire x1="1.07" y1="1.438" x2="1.47" y2="1.438" width="0.2032" layer="51"/>
<wire x1="1.47" y1="1.438" x2="1.47" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="2.34" y1="-2.7" x2="2.34" y2="1.438" width="0.2032" layer="51"/>
<wire x1="2.34" y1="1.438" x2="2.74" y2="1.438" width="0.2032" layer="51"/>
<wire x1="2.74" y1="1.438" x2="2.74" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="3.61" y1="-2.7" x2="3.61" y2="1.438" width="0.2032" layer="51"/>
<wire x1="3.61" y1="1.438" x2="4.01" y2="1.438" width="0.2032" layer="51"/>
<wire x1="4.01" y1="1.438" x2="4.01" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="4.88" y1="-2.7" x2="4.88" y2="1.438" width="0.2032" layer="51"/>
<wire x1="4.88" y1="1.438" x2="5.28" y2="1.438" width="0.2032" layer="51"/>
<wire x1="5.28" y1="1.438" x2="5.28" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="6.15" y1="-2.7" x2="6.15" y2="1.438" width="0.2032" layer="51"/>
<wire x1="6.15" y1="1.438" x2="6.55" y2="1.438" width="0.2032" layer="51"/>
<wire x1="6.55" y1="1.438" x2="6.55" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="7.42" y1="-2.7" x2="7.42" y2="1.438" width="0.2032" layer="51"/>
<wire x1="7.42" y1="1.438" x2="7.82" y2="1.438" width="0.2032" layer="51"/>
<wire x1="7.82" y1="1.438" x2="7.82" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="8.69" y1="-2.7" x2="8.69" y2="1.438" width="0.2032" layer="51"/>
<wire x1="8.69" y1="1.438" x2="9.09" y2="1.438" width="0.2032" layer="51"/>
<wire x1="9.09" y1="1.438" x2="9.09" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="9.96" y1="-2.7" x2="9.96" y2="1.438" width="0.2032" layer="51"/>
<wire x1="9.96" y1="1.438" x2="10.36" y2="1.438" width="0.2032" layer="51"/>
<wire x1="10.36" y1="1.438" x2="10.36" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="11.23" y1="-2.7" x2="11.23" y2="1.438" width="0.2032" layer="51"/>
<wire x1="11.23" y1="1.438" x2="11.63" y2="1.438" width="0.2032" layer="51"/>
<wire x1="11.63" y1="1.438" x2="11.63" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="12.5" y1="-2.7" x2="12.5" y2="1.438" width="0.2032" layer="51"/>
<wire x1="12.5" y1="1.438" x2="12.9" y2="1.438" width="0.2032" layer="51"/>
<wire x1="12.9" y1="1.438" x2="12.9" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="13.77" y1="-2.7" x2="13.77" y2="1.438" width="0.2032" layer="51"/>
<wire x1="13.77" y1="1.438" x2="14.17" y2="1.438" width="0.2032" layer="51"/>
<wire x1="14.17" y1="1.438" x2="14.17" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="15.04" y1="-2.7" x2="15.04" y2="1.438" width="0.2032" layer="51"/>
<wire x1="15.04" y1="1.438" x2="15.44" y2="1.438" width="0.2032" layer="51"/>
<wire x1="15.44" y1="1.438" x2="15.44" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="16.31" y1="-2.7" x2="16.31" y2="1.438" width="0.2032" layer="51"/>
<wire x1="16.31" y1="1.438" x2="16.71" y2="1.438" width="0.2032" layer="51"/>
<wire x1="16.71" y1="1.438" x2="16.71" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="17.58" y1="-2.7" x2="17.58" y2="1.438" width="0.2032" layer="51"/>
<wire x1="17.58" y1="1.438" x2="17.98" y2="1.438" width="0.2032" layer="51"/>
<wire x1="17.98" y1="1.438" x2="17.98" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="18.85" y1="-2.7" x2="18.85" y2="1.438" width="0.2032" layer="51"/>
<wire x1="18.85" y1="1.438" x2="19.25" y2="1.438" width="0.2032" layer="51"/>
<wire x1="19.25" y1="1.438" x2="19.25" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="20.12" y1="-2.7" x2="20.12" y2="1.438" width="0.2032" layer="51"/>
<wire x1="20.12" y1="1.438" x2="20.52" y2="1.438" width="0.2032" layer="51"/>
<wire x1="20.52" y1="1.438" x2="20.52" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="21.39" y1="-2.7" x2="21.39" y2="1.438" width="0.2032" layer="51"/>
<wire x1="21.39" y1="1.438" x2="21.79" y2="1.438" width="0.2032" layer="51"/>
<wire x1="21.79" y1="1.438" x2="21.79" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="22.66" y1="-2.7" x2="22.66" y2="1.438" width="0.2032" layer="51"/>
<wire x1="22.66" y1="1.438" x2="23.06" y2="1.438" width="0.2032" layer="51"/>
<wire x1="23.06" y1="1.438" x2="23.06" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="23.93" y1="-2.7" x2="23.93" y2="1.438" width="0.2032" layer="51"/>
<wire x1="23.93" y1="1.438" x2="24.33" y2="1.438" width="0.2032" layer="51"/>
<wire x1="24.33" y1="1.438" x2="24.33" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="25.2" y1="-2.7" x2="25.2" y2="1.438" width="0.2032" layer="51"/>
<wire x1="25.2" y1="1.438" x2="25.6" y2="1.438" width="0.2032" layer="51"/>
<wire x1="25.6" y1="1.438" x2="25.6" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="26.47" y1="-2.7" x2="26.47" y2="1.438" width="0.2032" layer="51"/>
<wire x1="26.47" y1="1.438" x2="26.87" y2="1.438" width="0.2032" layer="51"/>
<wire x1="26.87" y1="1.438" x2="26.87" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="27.74" y1="-2.7" x2="27.74" y2="1.438" width="0.2032" layer="51"/>
<wire x1="27.74" y1="1.438" x2="28.14" y2="1.438" width="0.2032" layer="51"/>
<wire x1="28.14" y1="1.438" x2="28.14" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="29.01" y1="-2.7" x2="29.01" y2="1.438" width="0.2032" layer="51"/>
<wire x1="29.01" y1="1.438" x2="29.41" y2="1.438" width="0.2032" layer="51"/>
<wire x1="29.41" y1="1.438" x2="29.41" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="30.28" y1="-2.7" x2="30.28" y2="1.438" width="0.2032" layer="51"/>
<wire x1="30.28" y1="1.438" x2="30.68" y2="1.438" width="0.2032" layer="51"/>
<wire x1="30.68" y1="1.438" x2="30.68" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="31.55" y1="-2.7" x2="31.55" y2="1.438" width="0.2032" layer="51"/>
<wire x1="31.55" y1="1.438" x2="31.95" y2="1.438" width="0.2032" layer="51"/>
<wire x1="31.95" y1="1.438" x2="31.95" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="32.82" y1="-2.7" x2="32.82" y2="1.438" width="0.2032" layer="51"/>
<wire x1="32.82" y1="1.438" x2="33.22" y2="1.438" width="0.2032" layer="51"/>
<wire x1="33.22" y1="1.438" x2="33.22" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="34.09" y1="-2.7" x2="34.09" y2="1.438" width="0.2032" layer="51"/>
<wire x1="34.09" y1="1.438" x2="34.49" y2="1.438" width="0.2032" layer="51"/>
<wire x1="34.49" y1="1.438" x2="34.49" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="35.36" y1="-2.7" x2="35.36" y2="1.438" width="0.2032" layer="51"/>
<wire x1="35.36" y1="1.438" x2="35.76" y2="1.438" width="0.2032" layer="51"/>
<wire x1="35.76" y1="1.438" x2="35.76" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="36.63" y1="-2.7" x2="36.63" y2="1.438" width="0.2032" layer="51"/>
<wire x1="36.63" y1="1.438" x2="37.03" y2="1.438" width="0.2032" layer="51"/>
<wire x1="37.03" y1="1.438" x2="37.03" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="37.9" y1="-2.7" x2="37.9" y2="1.438" width="0.2032" layer="51"/>
<wire x1="37.9" y1="1.438" x2="38.3" y2="1.438" width="0.2032" layer="51"/>
<wire x1="38.3" y1="1.438" x2="38.3" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="39.17" y1="-2.7" x2="39.17" y2="1.438" width="0.2032" layer="51"/>
<wire x1="39.17" y1="1.438" x2="39.57" y2="1.438" width="0.2032" layer="51"/>
<wire x1="39.57" y1="1.438" x2="39.57" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="40.44" y1="-2.7" x2="40.44" y2="1.438" width="0.2032" layer="51"/>
<wire x1="40.44" y1="1.438" x2="40.84" y2="1.438" width="0.2032" layer="51"/>
<wire x1="40.84" y1="1.438" x2="40.84" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="41.71" y1="-2.7" x2="41.71" y2="1.438" width="0.2032" layer="51"/>
<wire x1="41.71" y1="1.438" x2="42.11" y2="1.438" width="0.2032" layer="51"/>
<wire x1="42.11" y1="1.438" x2="42.11" y2="-2.7" width="0.2032" layer="51"/>
<wire x1="-33.782" y1="-8.23" x2="-33.782" y2="-6.795" width="0.2032" layer="21"/>
<wire x1="-33.782" y1="-6.795" x2="-34.356" y2="-6.795" width="0.2032" layer="21"/>
<wire x1="-34.356" y1="-6.795" x2="-34.356" y2="-8.039" width="0.2032" layer="21"/>
<wire x1="-34.356" y1="-8.039" x2="-34.165" y2="-8.23" width="0.2032" layer="21"/>
<wire x1="-34.165" y1="-8.23" x2="-33.782" y2="-8.23" width="0.2032" layer="21"/>
<wire x1="-34.452" y1="-7.943" x2="-34.739" y2="-7.943" width="0.2032" layer="21"/>
<wire x1="-34.739" y1="-7.943" x2="-34.835" y2="-7.847" width="0.2032" layer="21"/>
<wire x1="-34.835" y1="-7.847" x2="-34.835" y2="-6.795" width="0.2032" layer="21"/>
<wire x1="-34.835" y1="-6.795" x2="-35.409" y2="-6.795" width="0.2032" layer="21"/>
<wire x1="-35.409" y1="-6.795" x2="-35.409" y2="-7.943" width="0.2032" layer="21"/>
<wire x1="-35.409" y1="-7.943" x2="-35.026" y2="-8.326" width="0.2032" layer="21"/>
<wire x1="-35.026" y1="-8.326" x2="-34.548" y2="-8.326" width="0.2032" layer="21"/>
<wire x1="-34.548" y1="-8.326" x2="-34.356" y2="-8.135" width="0.2032" layer="21"/>
<wire x1="-35.505" y1="-7.943" x2="-35.792" y2="-7.943" width="0.2032" layer="21"/>
<wire x1="-35.792" y1="-7.943" x2="-35.888" y2="-7.847" width="0.2032" layer="21"/>
<wire x1="-35.888" y1="-7.847" x2="-35.888" y2="-6.795" width="0.2032" layer="21"/>
<wire x1="-35.888" y1="-6.795" x2="-36.462" y2="-6.795" width="0.2032" layer="21"/>
<wire x1="-36.462" y1="-6.795" x2="-36.462" y2="-7.943" width="0.2032" layer="21"/>
<wire x1="-36.462" y1="-7.943" x2="-36.079" y2="-8.326" width="0.2032" layer="21"/>
<wire x1="-36.079" y1="-8.326" x2="-35.696" y2="-8.326" width="0.2032" layer="21"/>
<wire x1="-35.696" y1="-8.326" x2="-35.409" y2="-8.039" width="0.2032" layer="21"/>
<wire x1="-39.237" y1="-6.795" x2="-39.237" y2="-8.9" width="0.2032" layer="21"/>
<wire x1="-39.237" y1="-8.9" x2="-38.759" y2="-8.9" width="0.2032" layer="21"/>
<wire x1="-38.759" y1="-8.9" x2="-38.759" y2="-6.795" width="0.2032" layer="21"/>
<wire x1="-38.759" y1="-6.795" x2="-39.237" y2="-6.795" width="0.2032" layer="21"/>
<wire x1="-40.003" y1="-8.326" x2="-39.62" y2="-8.039" width="0.2032" layer="21"/>
<wire x1="-39.62" y1="-8.039" x2="-39.524" y2="-7.752" width="0.2032" layer="21"/>
<wire x1="-39.524" y1="-7.752" x2="-39.524" y2="-7.178" width="0.2032" layer="21"/>
<wire x1="-39.524" y1="-7.178" x2="-39.907" y2="-6.795" width="0.2032" layer="21"/>
<wire x1="-39.907" y1="-6.795" x2="-40.673" y2="-6.795" width="0.2032" layer="21"/>
<wire x1="-40.673" y1="-6.795" x2="-41.151" y2="-7.273" width="0.2032" layer="21"/>
<wire x1="-41.151" y1="-7.273" x2="-41.151" y2="-7.656" width="0.2032" layer="21"/>
<wire x1="-41.151" y1="-7.656" x2="-41.055" y2="-7.943" width="0.2032" layer="21"/>
<wire x1="-41.055" y1="-7.943" x2="-40.577" y2="-8.326" width="0.2032" layer="21"/>
<wire x1="-40.577" y1="-8.326" x2="-40.003" y2="-8.326" width="0.2032" layer="21"/>
<wire x1="-40.194" y1="-8.039" x2="-39.907" y2="-7.752" width="0.2032" layer="21"/>
<wire x1="-39.907" y1="-7.465" x2="-39.907" y2="-7.273" width="0.2032" layer="21"/>
<wire x1="-39.907" y1="-7.273" x2="-40.003" y2="-7.178" width="0.2032" layer="21"/>
<wire x1="-40.003" y1="-7.178" x2="-40.481" y2="-7.178" width="0.2032" layer="21"/>
<wire x1="-40.481" y1="-7.178" x2="-40.673" y2="-7.369" width="0.2032" layer="21"/>
<wire x1="-42.969" y1="-6.795" x2="-42.395" y2="-6.795" width="0.2032" layer="21"/>
<wire x1="-42.395" y1="-6.795" x2="-42.012" y2="-7.178" width="0.2032" layer="21"/>
<wire x1="-42.012" y1="-7.178" x2="-41.63" y2="-6.795" width="0.2032" layer="21"/>
<wire x1="-41.63" y1="-6.795" x2="-41.055" y2="-6.795" width="0.2032" layer="21"/>
<wire x1="-41.055" y1="-6.795" x2="-41.725" y2="-7.465" width="0.2032" layer="21"/>
<wire x1="-41.725" y1="-7.465" x2="-41.725" y2="-7.656" width="0.2032" layer="21"/>
<wire x1="-41.725" y1="-7.656" x2="-41.151" y2="-8.23" width="0.2032" layer="21"/>
<wire x1="-41.151" y1="-8.23" x2="-41.725" y2="-8.23" width="0.2032" layer="21"/>
<wire x1="-41.725" y1="-8.23" x2="-42.012" y2="-7.943" width="0.2032" layer="21"/>
<wire x1="-42.012" y1="-7.943" x2="-42.299" y2="-8.23" width="0.2032" layer="21"/>
<wire x1="-42.299" y1="-8.23" x2="-42.874" y2="-8.23" width="0.2032" layer="21"/>
<wire x1="-42.874" y1="-8.23" x2="-42.299" y2="-7.656" width="0.2032" layer="21"/>
<wire x1="-42.299" y1="-7.656" x2="-42.299" y2="-7.465" width="0.2032" layer="21"/>
<wire x1="-42.299" y1="-7.465" x2="-42.969" y2="-6.795" width="0.2032" layer="21"/>
<wire x1="-39.907" y1="-7.465" x2="-41.055" y2="-7.465" width="0.2032" layer="21"/>
<wire x1="-39.907" y1="-7.752" x2="-40.673" y2="-7.752" width="0.2032" layer="21"/>
<wire x1="-40.673" y1="-7.752" x2="-40.385" y2="-8.039" width="0.2032" layer="21"/>
<wire x1="-40.385" y1="-8.039" x2="-40.194" y2="-8.039" width="0.2032" layer="21"/>
<wire x1="-41.6295" y1="-6.6033" x2="-35.1219" y2="-6.6033" width="0.2032" layer="21" curve="-150.34704" cap="flat"/>
<wire x1="-41.534" y1="-8.613" x2="-35.2178" y2="-8.613" width="0.2032" layer="21" curve="140.033787" cap="flat"/>
<wire x1="-41.917" y1="-8.613" x2="-34.8352" y2="-8.7087" width="0.2032" layer="21" curve="142.666171" cap="flat"/>
<wire x1="-42.012" y1="-6.508" x2="-34.7388" y2="-6.4123" width="0.2032" layer="21" curve="-149.107367" cap="flat"/>
<wire x1="-35.218" y1="-8.709" x2="-34.835" y2="-8.709" width="0.2032" layer="21"/>
<wire x1="-41.534" y1="-8.613" x2="-41.917" y2="-8.613" width="0.2032" layer="21"/>
<wire x1="-41.63" y1="-6.508" x2="-42.012" y2="-6.508" width="0.2032" layer="21"/>
<wire x1="-35.122" y1="-6.508" x2="-34.739" y2="-6.508" width="0.2032" layer="21"/>
<wire x1="-47.1" y1="-7.3" x2="-47.1" y2="5.2" width="0.2032" layer="21"/>
<wire x1="-47.1" y1="5.2" x2="-43.2" y2="5.2" width="0.2032" layer="21"/>
<wire x1="-43.2" y1="5.2" x2="-43.2" y2="-2.8" width="0.2032" layer="21"/>
<wire x1="-47" y1="-2.8" x2="-43.4" y2="-2.8" width="0.2032" layer="21"/>
<wire x1="-46.1" y1="-2.7" x2="-46.1" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="-46.1" y1="-1.1" x2="-44.2" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="-44.2" y1="-1.1" x2="-44.2" y2="-2.7" width="0.2032" layer="21"/>
<wire x1="-5.6" y1="-2.8" x2="-43.2" y2="-2.8" width="0.2032" layer="21"/>
<wire x1="47.4" y1="5" x2="47.4" y2="5.2" width="0.2032" layer="21"/>
<wire x1="47.4" y1="5.2" x2="43.6" y2="5.2" width="0.2032" layer="21"/>
<wire x1="43.6" y1="5.2" x2="43.6" y2="-2.8" width="0.2032" layer="21"/>
<wire x1="43.6" y1="-2.8" x2="-1.7" y2="-2.8" width="0.2032" layer="21"/>
<wire x1="-1.7" y1="-2.8" x2="-2.6" y2="-2.8" width="0.2032" layer="21"/>
<wire x1="-4.6" y1="-2.8" x2="-5.6" y2="-2.8" width="0.2032" layer="21"/>
<wire x1="-4.5" y1="-1.1" x2="-2.7" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="-2.7" y1="-1.1" x2="-2.7" y2="-2.8" width="0.2032" layer="21"/>
<wire x1="-2.7" y1="-2.8" x2="-4.5" y2="-2.8" width="0.2032" layer="21"/>
<wire x1="-4.5" y1="-2.8" x2="-4.5" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="44.6" y1="-1.1" x2="46.4" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="46.4" y1="-1.1" x2="46.4" y2="-2.8" width="0.2032" layer="21"/>
<wire x1="46.4" y1="-2.8" x2="44.6" y2="-2.8" width="0.2032" layer="21"/>
<wire x1="44.6" y1="-2.8" x2="44.6" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="-6.7" y1="-12.3" x2="-7.2" y2="-11.8" width="0.2032" layer="21"/>
<wire x1="-7.2" y1="-11.8" x2="-7.2" y2="-8.3" width="0.2032" layer="21"/>
<wire x1="-10.588" y1="-12.3" x2="-5.4" y2="-12.3" width="0.2032" layer="21"/>
<wire x1="47.4" y1="-7.3" x2="47.4" y2="5.2" width="0.2032" layer="21"/>
<wire x1="-7.2" y1="-8.3" x2="-11.1" y2="-8.3" width="0.2032" layer="21"/>
<wire x1="-11.1" y1="-8.3" x2="-11.1" y2="-11.8" width="0.2032" layer="21"/>
<wire x1="-11.1" y1="-11.8" x2="-11.6" y2="-12.3" width="0.2032" layer="21"/>
<wire x1="-11.1" y1="-11.8" x2="-10.6" y2="-12.3" width="0.2032" layer="21"/>
<wire x1="-11.557" y1="-12.3" x2="-14.5" y2="-12.3" width="0.2032" layer="21"/>
<wire x1="-14.5" y1="-12.3" x2="-15" y2="-11.8" width="0.2032" layer="21"/>
<wire x1="-15" y1="-11.8" x2="-15" y2="-8.3" width="0.2032" layer="21"/>
<wire x1="-15" y1="-11.8" x2="-15.5" y2="-12.3" width="0.2032" layer="21"/>
<wire x1="-15.5" y1="-12.3" x2="-15.472" y2="-12.3" width="0.2032" layer="21"/>
<wire x1="-15" y1="-8.3" x2="-19" y2="-8.3" width="0.2032" layer="21"/>
<wire x1="-19" y1="-8.3" x2="-19" y2="-12" width="0.2032" layer="21"/>
<wire x1="-19" y1="-12" x2="-19.3" y2="-12.3" width="0.2032" layer="21"/>
<wire x1="-15.5" y1="-12.3" x2="-44.6" y2="-12.3" width="0.2032" layer="21"/>
<wire x1="-5.6" y1="-2.8" x2="-5.6" y2="5.2" width="0.2032" layer="21"/>
<wire x1="-5.6" y1="5.2" x2="-1.7" y2="5.2" width="0.2032" layer="21"/>
<wire x1="-1.7" y1="5.2" x2="-1.7" y2="-2.8" width="0.2032" layer="21"/>
<wire x1="-11.172" y1="-8.3" x2="-14.951" y2="-8.3" width="0.2032" layer="21"/>
<wire x1="-47.1" y1="-7.3" x2="-47.1" y2="-3.317" width="0.2032" layer="21"/>
<wire x1="47.332" y1="-2.8" x2="43.662" y2="-2.8" width="0.2032" layer="21"/>
<wire x1="-23.447" y1="0.479" x2="-23.447" y2="-2.775" width="0.2032" layer="51"/>
<circle x="-45.291" y="0.93" radius="0.8" width="0.2032" layer="51"/>
<circle x="-3.6957" y="0.9301" radius="0.8" width="0.2032" layer="51"/>
<circle x="45.5957" y="0.9301" radius="0.8" width="0.2032" layer="51"/>
<circle x="-37.5144" y="-7.5603" radius="0.8613" width="0.2032" layer="21"/>
<circle x="-37.5144" y="-7.5603" radius="0.4785" width="0.2032" layer="21"/>
<pad name="1" x="0" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="2" x="1.27" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="3" x="2.54" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="4" x="3.81" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="5" x="5.08" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="6" x="6.35" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="7" x="7.62" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="8" x="8.89" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="9" x="10.16" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="10" x="11.43" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="11" x="12.7" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="12" x="13.97" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="13" x="15.24" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="14" x="16.51" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="15" x="17.78" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="16" x="19.05" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="17" x="20.32" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="18" x="21.59" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="19" x="22.86" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="20" x="24.13" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="21" x="25.4" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="22" x="26.67" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="23" x="27.94" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="24" x="29.21" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="25" x="30.48" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="26" x="31.75" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="27" x="33.02" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="28" x="34.29" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="29" x="35.56" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="30" x="36.83" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="31" x="38.1" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="32" x="39.37" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="33" x="40.64" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="34" x="41.91" y="1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="35" x="0" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="36" x="1.27" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="37" x="2.54" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="38" x="3.81" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="39" x="5.08" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="40" x="6.35" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="41" x="7.62" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="42" x="8.89" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="43" x="10.16" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="44" x="11.43" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="45" x="12.7" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="46" x="13.97" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="47" x="15.24" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="48" x="16.51" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="49" x="17.78" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="50" x="19.05" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="51" x="20.32" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="52" x="21.59" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="53" x="22.86" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="54" x="24.13" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="55" x="25.4" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="56" x="26.67" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="57" x="27.94" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="58" x="29.21" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="59" x="30.48" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="60" x="31.75" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="61" x="33.02" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="62" x="34.29" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="63" x="35.56" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="64" x="36.83" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="65" x="38.1" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="66" x="39.37" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="67" x="40.64" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="68" x="41.91" y="-1.27" drill="0.7" diameter="1.016" shape="octagon"/>
<pad name="J1" x="-18.28" y="1" drill="0.9" shape="octagon"/>
<pad name="J2" x="-18.28" y="-1" drill="0.9" shape="octagon"/>
<pad name="J3" x="-16.28" y="1" drill="0.9" shape="octagon"/>
<pad name="J4" x="-16.28" y="-1" drill="0.9" shape="octagon"/>
<pad name="J5" x="-14.28" y="1" drill="0.9" shape="octagon"/>
<pad name="J6" x="-14.28" y="-1" drill="0.9" shape="octagon"/>
<pad name="J7" x="-12.28" y="1" drill="0.9" shape="octagon"/>
<pad name="J8" x="-12.28" y="-1" drill="0.9" shape="octagon"/>
<pad name="J9" x="-10.28" y="1" drill="0.9" shape="octagon"/>
<pad name="J10" x="-10.28" y="-1" drill="0.9" shape="octagon"/>
<pad name="J11" x="-8.28" y="1" drill="0.9" shape="octagon"/>
<pad name="J12" x="-8.28" y="-1" drill="0.9" shape="octagon"/>
<pad name="P1" x="-40.38" y="0" drill="1" diameter="2.54" shape="octagon"/>
<pad name="P2" x="-35.3" y="0" drill="1" diameter="2.54" shape="octagon"/>
<pad name="P3" x="-30.22" y="0" drill="1" diameter="2.54" shape="octagon"/>
<pad name="P4" x="-25.14" y="0" drill="1" diameter="2.54" shape="octagon"/>
<text x="-41" y="3.6" size="1.27" layer="25" font="vector">&gt;NAME</text>
<text x="-0.2" y="3.6" size="1.27" layer="27" font="vector">&gt;VALUE</text>
<rectangle x1="-46.31" y1="-0.675" x2="-44.285" y2="2.525" layer="1"/>
<rectangle x1="-4.685" y1="-0.675" x2="-2.685" y2="2.525" layer="1"/>
<rectangle x1="44.59" y1="-0.675" x2="46.59" y2="2.525" layer="1"/>
<rectangle x1="-46.31" y1="-0.675" x2="-44.285" y2="2.525" layer="16"/>
<rectangle x1="-4.685" y1="-0.675" x2="-2.685" y2="2.525" layer="16"/>
<rectangle x1="44.59" y1="-0.675" x2="46.59" y2="2.525" layer="16"/>
<hole x="-3.685" y="0.92" drill="1.14"/>
<hole x="45.595" y="0.92" drill="1.14"/>
<hole x="-45.295" y="0.92" drill="1.14"/>
</package>
<package name="5566-20">
<description>&lt;b&gt;Mini FIT connector 20 pol&lt;/b&gt;&lt;p&gt;
ATX PC-Motherboard Power connector&lt;br&gt;
Source: http://www.molex.com</description>
<wire x1="-21.5" y1="4.5" x2="21.5" y2="4.5" width="0.254" layer="21"/>
<wire x1="21.5" y1="4.5" x2="21.5" y2="-2.2" width="0.254" layer="21"/>
<wire x1="21.5" y1="-3.3" x2="21.5" y2="-4.9" width="0.254" layer="21"/>
<wire x1="21.5" y1="-4.9" x2="-21.5" y2="-4.9" width="0.254" layer="21"/>
<wire x1="-21.5" y1="-4.9" x2="-21.5" y2="4.5" width="0.254" layer="21"/>
<wire x1="-25" y1="3.2" x2="-22.2" y2="3.2" width="0.254" layer="21" curve="-114.529547" cap="flat"/>
<wire x1="-25" y1="1.4" x2="-22.2" y2="1.4" width="0.254" layer="21" curve="114.529547" cap="flat"/>
<wire x1="-25" y1="3.2" x2="-25" y2="1.4" width="0.254" layer="21"/>
<wire x1="-22.3" y1="3.3" x2="-21.6" y2="3.3" width="0.254" layer="21"/>
<wire x1="-22.3" y1="1.3" x2="-21.6" y2="1.3" width="0.254" layer="21"/>
<wire x1="22.2" y1="1.4" x2="25" y2="1.4" width="0.254" layer="21" curve="114.529547" cap="flat"/>
<wire x1="22.2" y1="3.2" x2="25" y2="3.2" width="0.254" layer="21" curve="-114.529547" cap="flat"/>
<wire x1="25" y1="1.4" x2="25" y2="3.2" width="0.254" layer="21"/>
<wire x1="22.3" y1="1.3" x2="21.6" y2="1.3" width="0.254" layer="21"/>
<wire x1="22.3" y1="3.3" x2="21.6" y2="3.3" width="0.254" layer="21"/>
<wire x1="21.5" y1="-2.2" x2="21.5" y2="-3.3" width="0.254" layer="21" curve="-180"/>
<wire x1="-2.1" y1="6.3" x2="2.1" y2="6.3" width="0.254" layer="27"/>
<wire x1="-2.1" y1="6.3" x2="-2.1" y2="4.6" width="0.254" layer="27"/>
<wire x1="2.1" y1="6.3" x2="2.1" y2="4.6" width="0.254" layer="27"/>
<pad name="1" x="18.9" y="-2.75" drill="1.4" shape="square"/>
<pad name="2" x="14.7" y="-2.75" drill="1.4" shape="square"/>
<pad name="3" x="10.5" y="-2.75" drill="1.4" shape="square"/>
<pad name="4" x="6.3" y="-2.75" drill="1.4" shape="square"/>
<pad name="5" x="2.1" y="-2.75" drill="1.4" shape="square"/>
<pad name="6" x="-2.1" y="-2.75" drill="1.4" shape="square"/>
<pad name="7" x="-6.3" y="-2.75" drill="1.4" shape="square"/>
<pad name="8" x="-10.5" y="-2.75" drill="1.4" shape="square"/>
<pad name="9" x="-14.7" y="-2.75" drill="1.4" shape="square"/>
<pad name="10" x="-18.9" y="-2.75" drill="1.4" shape="square"/>
<pad name="11" x="18.9" y="2.75" drill="1.4" shape="square"/>
<pad name="12" x="14.7" y="2.75" drill="1.4" shape="square"/>
<pad name="13" x="10.5" y="2.75" drill="1.4" shape="square"/>
<pad name="14" x="6.3" y="2.75" drill="1.4" shape="square"/>
<pad name="15" x="2.1" y="2.75" drill="1.4" shape="square"/>
<pad name="16" x="-2.1" y="2.75" drill="1.4" shape="square"/>
<pad name="17" x="-6.3" y="2.75" drill="1.4" shape="square"/>
<pad name="18" x="-10.5" y="2.75" drill="1.4" shape="square"/>
<pad name="19" x="-14.7" y="2.75" drill="1.4" shape="square"/>
<pad name="20" x="-18.9" y="2.75" drill="1.4" shape="square"/>
<text x="16.51" y="-6.985" size="1.27" layer="25">&gt;NAME</text>
<text x="-20.32" y="-6.985" size="1.27" layer="27">&gt;VALUE</text>
<hole x="23.6" y="2.29" drill="3"/>
<hole x="-23.6" y="2.29" drill="3"/>
</package>
<package name="5566-22">
<description>&lt;b&gt;Mini FIT connector 22 pol&lt;/b&gt;&lt;p&gt;
<wire x1="-23.6" y1="4.5" x2="23.6" y2="4.5" width="0.254" layer="21"/>
<wire x1="23.6" y1="4.5" x2="23.6" y2="-2.2" width="0.254" layer="21"/>
<wire x1="23.6" y1="-3.3" x2="23.6" y2="-4.9" width="0.254" layer="21"/>
<wire x1="23.6" y1="-4.9" x2="-23.6" y2="-4.9" width="0.254" layer="21"/>
<wire x1="-23.6" y1="-4.9" x2="-23.6" y2="4.5" width="0.254" layer="21"/>
<wire x1="-27.1" y1="3.2" x2="-24.3" y2="3.2" width="0.254" layer="21" curve="-114.529547" cap="flat"/>
<wire x1="-27.1" y1="1.4" x2="-24.3" y2="1.4" width="0.254" layer="21" curve="114.529547" cap="flat"/>
<wire x1="-27.1" y1="3.2" x2="-27.1" y2="1.4" width="0.254" layer="21"/>
<wire x1="-24.4" y1="3.3" x2="-23.7" y2="3.3" width="0.254" layer="21"/>
<wire x1="-24.4" y1="1.3" x2="-23.7" y2="1.3" width="0.254" layer="21"/>
<wire x1="24.3" y1="1.4" x2="27.1" y2="1.4" width="0.254" layer="21" curve="114.529547" cap="flat"/>
<wire x1="24.3" y1="3.2" x2="27.1" y2="3.2" width="0.254" layer="21" curve="-114.529547" cap="flat"/>
<wire x1="27.1" y1="1.4" x2="27.1" y2="3.2" width="0.254" layer="21"/>
<wire x1="24.4" y1="1.3" x2="23.7" y2="1.3" width="0.254" layer="21"/>
<wire x1="24.4" y1="3.3" x2="23.7" y2="3.3" width="0.254" layer="21"/>
<wire x1="23.6" y1="-2.2" x2="23.6" y2="-3.3" width="0.254" layer="21" curve="-180"/>
<pad name="1" x="21" y="-2.75" drill="1.4" shape="square"/>
<pad name="2" x="16.8" y="-2.75" drill="1.4" shape="square"/>
<pad name="3" x="12.6" y="-2.75" drill="1.4" shape="square"/>
<pad name="4" x="8.4" y="-2.75" drill="1.4" shape="square"/>
<pad name="5" x="4.2" y="-2.75" drill="1.4" shape="square"/>
<pad name="6" x="0" y="-2.75" drill="1.4" shape="square"/>
<pad name="7" x="-4.2" y="-2.75" drill="1.4" shape="square"/>
<pad name="8" x="-8.4" y="-2.75" drill="1.4" shape="square"/>
<pad name="9" x="-12.6" y="-2.75" drill="1.4" shape="square"/>
<pad name="10" x="-16.8" y="-2.75" drill="1.4" shape="square"/>
<pad name="12" x="21" y="2.75" drill="1.4" shape="square"/>
<pad name="11" x="-21" y="-2.75" drill="1.4" shape="square"/>
<pad name="13" x="16.8" y="2.75" drill="1.4" shape="square"/>
<pad name="14" x="12.6" y="2.75" drill="1.4" shape="square"/>
<pad name="15" x="8.4" y="2.75" drill="1.4" shape="square"/>
<pad name="16" x="4.2" y="2.75" drill="1.4" shape="square"/>
<pad name="17" x="0" y="2.75" drill="1.4" shape="square"/>
<pad name="18" x="-4.2" y="2.75" drill="1.4" shape="square"/>
<pad name="19" x="-8.4" y="2.75" drill="1.4" shape="square"/>
<pad name="20" x="-12.6" y="2.75" drill="1.4" shape="square"/>
<pad name="21" x="-16.8" y="2.75" drill="1.4" shape="square"/>
<pad name="22" x="-21" y="2.75" drill="1.4" shape="square"/>
<text x="18.415" y="-6.985" size="1.27" layer="25">&gt;NAME</text>
<text x="-22.225" y="-6.985" size="1.27" layer="27">&gt;VALUE</text>
<hole x="25.7" y="2.29" drill="3"/>
<hole x="-25.7" y="2.29" drill="3"/>
</package>
<package name="5566-24">
<description>&lt;b&gt;Mini FIT connector 24 pol&lt;/b&gt;&lt;p&gt;
<wire x1="-25.7" y1="4.5" x2="25.7" y2="4.5" width="0.254" layer="21"/>
<wire x1="25.7" y1="4.5" x2="25.7" y2="-2.2" width="0.254" layer="21"/>
<wire x1="25.7" y1="-3.3" x2="25.7" y2="-4.9" width="0.254" layer="21"/>
<wire x1="25.7" y1="-4.9" x2="-25.7" y2="-4.9" width="0.254" layer="21"/>
<wire x1="-25.7" y1="-4.9" x2="-25.7" y2="4.5" width="0.254" layer="21"/>
<wire x1="-29.2" y1="3.2" x2="-26.4" y2="3.2" width="0.254" layer="21" curve="-114.529547" cap="flat"/>
<wire x1="-29.2" y1="1.4" x2="-26.4" y2="1.4" width="0.254" layer="21" curve="114.529547" cap="flat"/>
<wire x1="-29.2" y1="3.2" x2="-29.2" y2="1.4" width="0.254" layer="21"/>
<wire x1="-26.5" y1="3.3" x2="-25.8" y2="3.3" width="0.254" layer="21"/>
<wire x1="-26.5" y1="1.3" x2="-25.8" y2="1.3" width="0.254" layer="21"/>
<wire x1="26.4" y1="1.4" x2="29.2" y2="1.4" width="0.254" layer="21" curve="114.529547" cap="flat"/>
<wire x1="26.4" y1="3.2" x2="29.2" y2="3.2" width="0.254" layer="21" curve="-114.529547" cap="flat"/>
<wire x1="29.2" y1="1.4" x2="29.2" y2="3.2" width="0.254" layer="21"/>
<wire x1="26.5" y1="1.3" x2="25.8" y2="1.3" width="0.254" layer="21"/>
<wire x1="26.5" y1="3.3" x2="25.8" y2="3.3" width="0.254" layer="21"/>
<wire x1="25.7" y1="-2.2" x2="25.7" y2="-3.3" width="0.254" layer="21" curve="-180"/>
<pad name="1" x="23.1" y="-2.75" drill="1.4" shape="square"/>
<pad name="2" x="18.9" y="-2.75" drill="1.4" shape="square"/>
<pad name="3" x="14.7" y="-2.75" drill="1.4" shape="square"/>
<pad name="4" x="10.5" y="-2.75" drill="1.4" shape="square"/>
<pad name="5" x="6.3" y="-2.75" drill="1.4" shape="square"/>
<pad name="6" x="2.1" y="-2.75" drill="1.4" shape="square"/>
<pad name="7" x="-2.1" y="-2.75" drill="1.4" shape="square"/>
<pad name="8" x="-6.3" y="-2.75" drill="1.4" shape="square"/>
<pad name="9" x="-10.5" y="-2.75" drill="1.4" shape="square"/>
<pad name="10" x="-14.7" y="-2.75" drill="1.4" shape="square"/>
<pad name="11" x="-18.9" y="-2.75" drill="1.4" shape="square"/>
<pad name="13" x="23.1" y="2.75" drill="1.4" shape="square"/>
<pad name="14" x="18.9" y="2.75" drill="1.4" shape="square"/>
<pad name="15" x="14.7" y="2.75" drill="1.4" shape="square"/>
<pad name="16" x="10.5" y="2.75" drill="1.4" shape="square"/>
<pad name="17" x="6.3" y="2.75" drill="1.4" shape="square"/>
<pad name="18" x="2.1" y="2.75" drill="1.4" shape="square"/>
<pad name="19" x="-2.1" y="2.75" drill="1.4" shape="square"/>
<pad name="20" x="-6.3" y="2.75" drill="1.4" shape="square"/>
<pad name="21" x="-10.5" y="2.75" drill="1.4" shape="square"/>
<pad name="22" x="-14.7" y="2.75" drill="1.4" shape="square"/>
<pad name="12" x="-23.1" y="-2.75" drill="1.4" shape="square"/>
<pad name="23" x="-18.9" y="2.75" drill="1.4" shape="square"/>
<pad name="24" x="-23.1" y="2.75" drill="1.4" shape="square"/>
<text x="20.32" y="-6.985" size="1.27" layer="25">&gt;NAME</text>
<text x="-24.765" y="-6.985" size="1.27" layer="27">&gt;VALUE</text>
<hole x="27.8" y="2.29" drill="3"/>
<hole x="-27.8" y="2.29" drill="3"/>
</package>
<package name="5566-18">
<description>&lt;b&gt;Mini FIT connector 18 pol&lt;/b&gt;&lt;p&gt;
<wire x1="-19.4" y1="4.5" x2="19.4" y2="4.5" width="0.254" layer="21"/>
<wire x1="19.4" y1="4.5" x2="19.4" y2="-2.2" width="0.254" layer="21"/>
<wire x1="19.4" y1="-3.3" x2="19.4" y2="-4.9" width="0.254" layer="21"/>
<wire x1="19.4" y1="-4.9" x2="-19.4" y2="-4.9" width="0.254" layer="21"/>
<wire x1="-19.4" y1="-4.9" x2="-19.4" y2="4.5" width="0.254" layer="21"/>
<wire x1="-22.9" y1="3.2" x2="-20.1" y2="3.2" width="0.254" layer="21" curve="-114.529547" cap="flat"/>
<wire x1="-22.9" y1="1.4" x2="-20.1" y2="1.4" width="0.254" layer="21" curve="114.529547" cap="flat"/>
<wire x1="-22.9" y1="3.2" x2="-22.9" y2="1.4" width="0.254" layer="21"/>
<wire x1="-20.2" y1="3.3" x2="-19.5" y2="3.3" width="0.254" layer="21"/>
<wire x1="-20.2" y1="1.3" x2="-19.5" y2="1.3" width="0.254" layer="21"/>
<wire x1="20.1" y1="1.4" x2="22.9" y2="1.4" width="0.254" layer="21" curve="114.529547" cap="flat"/>
<wire x1="20.1" y1="3.2" x2="22.9" y2="3.2" width="0.254" layer="21" curve="-114.529547" cap="flat"/>
<wire x1="22.9" y1="1.4" x2="22.9" y2="3.2" width="0.254" layer="21"/>
<wire x1="20.2" y1="1.3" x2="19.5" y2="1.3" width="0.254" layer="21"/>
<wire x1="20.2" y1="3.3" x2="19.5" y2="3.3" width="0.254" layer="21"/>
<wire x1="19.4" y1="-2.2" x2="19.4" y2="-3.3" width="0.254" layer="21" curve="-180"/>
<pad name="1" x="16.8" y="-2.75" drill="1.4" shape="square"/>
<pad name="2" x="12.6" y="-2.75" drill="1.4" shape="square"/>
<pad name="3" x="8.4" y="-2.75" drill="1.4" shape="square"/>
<pad name="4" x="4.2" y="-2.75" drill="1.4" shape="square"/>
<pad name="5" x="0" y="-2.75" drill="1.4" shape="square"/>
<pad name="6" x="-4.2" y="-2.75" drill="1.4" shape="square"/>
<pad name="7" x="-8.4" y="-2.75" drill="1.4" shape="square"/>
<pad name="8" x="-12.6" y="-2.75" drill="1.4" shape="square"/>
<pad name="9" x="-16.8" y="-2.75" drill="1.4" shape="square"/>
<pad name="11" x="12.6" y="2.75" drill="1.4" shape="square"/>
<pad name="12" x="8.4" y="2.75" drill="1.4" shape="square"/>
<pad name="13" x="4.2" y="2.75" drill="1.4" shape="square"/>
<pad name="14" x="0" y="2.75" drill="1.4" shape="square"/>
<pad name="15" x="-4.2" y="2.75" drill="1.4" shape="square"/>
<pad name="16" x="-8.4" y="2.75" drill="1.4" shape="square"/>
<pad name="17" x="-12.6" y="2.75" drill="1.4" shape="square"/>
<pad name="18" x="-16.8" y="2.75" drill="1.4" shape="square"/>
<pad name="10" x="16.8" y="2.75" drill="1.4" shape="square"/>
<text x="13.97" y="-6.985" size="1.27" layer="25">&gt;NAME</text>
<text x="-18.415" y="-6.985" size="1.27" layer="27">&gt;VALUE</text>
<hole x="21.5" y="2.29" drill="3"/>
<hole x="-21.5" y="2.29" drill="3"/>
</package>
<package name="5566-16">
<description>&lt;b&gt;Mini FIT connector 16 pol&lt;/b&gt;&lt;p&gt;
<wire x1="-17.3" y1="4.5" x2="17.3" y2="4.5" width="0.254" layer="21"/>
<wire x1="17.3" y1="4.5" x2="17.3" y2="-2.2" width="0.254" layer="21"/>
<wire x1="17.3" y1="-3.3" x2="17.3" y2="-4.9" width="0.254" layer="21"/>
<wire x1="17.3" y1="-4.9" x2="-17.3" y2="-4.9" width="0.254" layer="21"/>
<wire x1="-17.3" y1="-4.9" x2="-17.3" y2="4.5" width="0.254" layer="21"/>
<wire x1="-20.8" y1="3.2" x2="-18" y2="3.2" width="0.254" layer="21" curve="-114.529547" cap="flat"/>
<wire x1="-20.8" y1="1.4" x2="-18" y2="1.4" width="0.254" layer="21" curve="114.529547" cap="flat"/>
<wire x1="-20.8" y1="3.2" x2="-20.8" y2="1.4" width="0.254" layer="21"/>
<wire x1="-18.1" y1="3.3" x2="-17.4" y2="3.3" width="0.254" layer="21"/>
<wire x1="-18.1" y1="1.3" x2="-17.4" y2="1.3" width="0.254" layer="21"/>
<wire x1="18" y1="1.4" x2="20.8" y2="1.4" width="0.254" layer="21" curve="114.529547" cap="flat"/>
<wire x1="18" y1="3.2" x2="20.8" y2="3.2" width="0.254" layer="21" curve="-114.529547" cap="flat"/>
<wire x1="20.8" y1="1.4" x2="20.8" y2="3.2" width="0.254" layer="21"/>
<wire x1="18.1" y1="1.3" x2="17.4" y2="1.3" width="0.254" layer="21"/>
<wire x1="18.1" y1="3.3" x2="17.4" y2="3.3" width="0.254" layer="21"/>
<wire x1="17.3" y1="-2.2" x2="17.3" y2="-3.3" width="0.254" layer="21" curve="-180"/>
<pad name="1" x="14.7" y="-2.75" drill="1.4" shape="square"/>
<pad name="2" x="10.5" y="-2.75" drill="1.4" shape="square"/>
<pad name="3" x="6.3" y="-2.75" drill="1.4" shape="square"/>
<pad name="4" x="2.1" y="-2.75" drill="1.4" shape="square"/>
<pad name="5" x="-2.1" y="-2.75" drill="1.4" shape="square"/>
<pad name="6" x="-6.3" y="-2.75" drill="1.4" shape="square"/>
<pad name="7" x="-10.5" y="-2.75" drill="1.4" shape="square"/>
<pad name="8" x="-14.7" y="-2.75" drill="1.4" shape="square"/>
<pad name="12" x="2.1" y="2.75" drill="1.4" shape="square"/>
<pad name="13" x="-2.1" y="2.75" drill="1.4" shape="square"/>
<pad name="14" x="-6.3" y="2.75" drill="1.4" shape="square"/>
<pad name="15" x="-10.5" y="2.75" drill="1.4" shape="square"/>
<pad name="16" x="-14.7" y="2.75" drill="1.4" shape="square"/>
<pad name="9" x="14.7" y="2.75" drill="1.4" shape="square"/>
<pad name="10" x="10.5" y="2.75" drill="1.4" shape="square"/>
<pad name="11" x="6.3" y="2.75" drill="1.4" shape="square"/>
<text x="12.065" y="-6.985" size="1.27" layer="25">&gt;NAME</text>
<text x="-15.875" y="-6.985" size="1.27" layer="27">&gt;VALUE</text>
<hole x="19.4" y="2.29" drill="3"/>
<hole x="-19.4" y="2.29" drill="3"/>
</package>
<package name="5566-14">
<description>&lt;b&gt;Mini FIT connector 14 pol&lt;/b&gt;&lt;p&gt;
<wire x1="-15.2" y1="4.5" x2="15.2" y2="4.5" width="0.254" layer="21"/>
<wire x1="15.2" y1="4.5" x2="15.2" y2="-2.2" width="0.254" layer="21"/>
<wire x1="15.2" y1="-3.3" x2="15.2" y2="-4.9" width="0.254" layer="21"/>
<wire x1="15.2" y1="-4.9" x2="-15.2" y2="-4.9" width="0.254" layer="21"/>
<wire x1="-15.2" y1="-4.9" x2="-15.2" y2="4.5" width="0.254" layer="21"/>
<wire x1="-18.7" y1="3.2" x2="-15.9" y2="3.2" width="0.254" layer="21" curve="-114.529547" cap="flat"/>
<wire x1="-18.7" y1="1.4" x2="-15.9" y2="1.4" width="0.254" layer="21" curve="114.529547" cap="flat"/>
<wire x1="-18.7" y1="3.2" x2="-18.7" y2="1.4" width="0.254" layer="21"/>
<wire x1="-16" y1="3.3" x2="-15.3" y2="3.3" width="0.254" layer="21"/>
<wire x1="-16" y1="1.3" x2="-15.3" y2="1.3" width="0.254" layer="21"/>
<wire x1="15.9" y1="1.4" x2="18.7" y2="1.4" width="0.254" layer="21" curve="114.529547" cap="flat"/>
<wire x1="15.9" y1="3.2" x2="18.7" y2="3.2" width="0.254" layer="21" curve="-114.529547" cap="flat"/>
<wire x1="18.7" y1="1.4" x2="18.7" y2="3.2" width="0.254" layer="21"/>
<wire x1="16" y1="1.3" x2="15.3" y2="1.3" width="0.254" layer="21"/>
<wire x1="16" y1="3.3" x2="15.3" y2="3.3" width="0.254" layer="21"/>
<wire x1="15.2" y1="-2.2" x2="15.2" y2="-3.3" width="0.254" layer="21" curve="-180"/>
<pad name="1" x="12.6" y="-2.75" drill="1.4" shape="square"/>
<pad name="2" x="8.4" y="-2.75" drill="1.4" shape="square"/>
<pad name="3" x="4.2" y="-2.75" drill="1.4" shape="square"/>
<pad name="4" x="0" y="-2.75" drill="1.4" shape="square"/>
<pad name="5" x="-4.2" y="-2.75" drill="1.4" shape="square"/>
<pad name="6" x="-8.4" y="-2.75" drill="1.4" shape="square"/>
<pad name="7" x="-12.6" y="-2.75" drill="1.4" shape="square"/>
<pad name="12" x="-4.2" y="2.75" drill="1.4" shape="square"/>
<pad name="13" x="-8.4" y="2.75" drill="1.4" shape="square"/>
<pad name="14" x="-12.6" y="2.75" drill="1.4" shape="square"/>
<pad name="9" x="8.4" y="2.75" drill="1.4" shape="square"/>
<pad name="10" x="4.2" y="2.75" drill="1.4" shape="square"/>
<pad name="11" x="0" y="2.75" drill="1.4" shape="square"/>
<pad name="8" x="12.6" y="2.75" drill="1.4" shape="square"/>
<text x="10.16" y="-6.985" size="1.27" layer="25">&gt;NAME</text>
<text x="-13.97" y="-6.985" size="1.27" layer="27">&gt;VALUE</text>
<hole x="17.3" y="2.29" drill="3"/>
<hole x="-17.3" y="2.29" drill="3"/>
</package>
<package name="5566-12">
<description>&lt;b&gt;Mini FIT connector 12 pol&lt;/b&gt;&lt;p&gt;
<wire x1="-13.1" y1="4.5" x2="13.1" y2="4.5" width="0.254" layer="21"/>
<wire x1="13.1" y1="4.5" x2="13.1" y2="-2.2" width="0.254" layer="21"/>
<wire x1="13.1" y1="-3.3" x2="13.1" y2="-4.9" width="0.254" layer="21"/>
<wire x1="13.1" y1="-4.9" x2="-13.1" y2="-4.9" width="0.254" layer="21"/>
<wire x1="-13.1" y1="-4.9" x2="-13.1" y2="4.5" width="0.254" layer="21"/>
<wire x1="-16.6" y1="3.2" x2="-13.8" y2="3.2" width="0.254" layer="21" curve="-114.529547" cap="flat"/>
<wire x1="-16.6" y1="1.4" x2="-13.8" y2="1.4" width="0.254" layer="21" curve="114.529547" cap="flat"/>
<wire x1="-16.6" y1="3.2" x2="-16.6" y2="1.4" width="0.254" layer="21"/>
<wire x1="-13.9" y1="3.3" x2="-13.2" y2="3.3" width="0.254" layer="21"/>
<wire x1="-13.9" y1="1.3" x2="-13.2" y2="1.3" width="0.254" layer="21"/>
<wire x1="13.8" y1="1.4" x2="16.6" y2="1.4" width="0.254" layer="21" curve="114.529547" cap="flat"/>
<wire x1="13.8" y1="3.2" x2="16.6" y2="3.2" width="0.254" layer="21" curve="-114.529547" cap="flat"/>
<wire x1="16.6" y1="1.4" x2="16.6" y2="3.2" width="0.254" layer="21"/>
<wire x1="13.9" y1="1.3" x2="13.2" y2="1.3" width="0.254" layer="21"/>
<wire x1="13.9" y1="3.3" x2="13.2" y2="3.3" width="0.254" layer="21"/>
<wire x1="13.1" y1="-2.2" x2="13.1" y2="-3.3" width="0.254" layer="21" curve="-180"/>
<pad name="1" x="10.5" y="-2.75" drill="1.4" shape="square"/>
<pad name="2" x="6.3" y="-2.75" drill="1.4" shape="square"/>
<pad name="3" x="2.1" y="-2.75" drill="1.4" shape="square"/>
<pad name="4" x="-2.1" y="-2.75" drill="1.4" shape="square"/>
<pad name="5" x="-6.3" y="-2.75" drill="1.4" shape="square"/>
<pad name="6" x="-10.5" y="-2.75" drill="1.4" shape="square"/>
<pad name="12" x="-10.5" y="2.75" drill="1.4" shape="square"/>
<pad name="9" x="2.1" y="2.75" drill="1.4" shape="square"/>
<pad name="10" x="-2.1" y="2.75" drill="1.4" shape="square"/>
<pad name="11" x="-6.3" y="2.75" drill="1.4" shape="square"/>
<pad name="8" x="6.3" y="2.75" drill="1.4" shape="square"/>
<pad name="7" x="10.5" y="2.75" drill="1.4" shape="square"/>
<text x="7.62" y="-6.985" size="1.27" layer="25">&gt;NAME</text>
<text x="-11.43" y="-6.985" size="1.27" layer="27">&gt;VALUE</text>
<hole x="15.2" y="2.29" drill="3"/>
<hole x="-15.2" y="2.29" drill="3"/>
</package>
<package name="5566-10">
<description>&lt;b&gt;Mini FIT connector 10 pol&lt;/b&gt;&lt;p&gt;
<wire x1="-11" y1="4.5" x2="11" y2="4.5" width="0.254" layer="21"/>
<wire x1="11" y1="4.5" x2="11" y2="-2.2" width="0.254" layer="21"/>
<wire x1="11" y1="-3.3" x2="11" y2="-4.9" width="0.254" layer="21"/>
<wire x1="11" y1="-4.9" x2="-11" y2="-4.9" width="0.254" layer="21"/>
<wire x1="-11" y1="-4.9" x2="-11" y2="4.5" width="0.254" layer="21"/>
<wire x1="-14.5" y1="3.2" x2="-11.7" y2="3.2" width="0.254" layer="21" curve="-114.529547" cap="flat"/>
<wire x1="-14.5" y1="1.4" x2="-11.7" y2="1.4" width="0.254" layer="21" curve="114.529547" cap="flat"/>
<wire x1="-14.5" y1="3.2" x2="-14.5" y2="1.4" width="0.254" layer="21"/>
<wire x1="-11.8" y1="3.3" x2="-11.1" y2="3.3" width="0.254" layer="21"/>
<wire x1="-11.8" y1="1.3" x2="-11.1" y2="1.3" width="0.254" layer="21"/>
<wire x1="11.7" y1="1.4" x2="14.5" y2="1.4" width="0.254" layer="21" curve="114.529547" cap="flat"/>
<wire x1="11.7" y1="3.2" x2="14.5" y2="3.2" width="0.254" layer="21" curve="-114.529547" cap="flat"/>
<wire x1="14.5" y1="1.4" x2="14.5" y2="3.2" width="0.254" layer="21"/>
<wire x1="11.8" y1="1.3" x2="11.1" y2="1.3" width="0.254" layer="21"/>
<wire x1="11.8" y1="3.3" x2="11.1" y2="3.3" width="0.254" layer="21"/>
<wire x1="11" y1="-2.2" x2="11" y2="-3.3" width="0.254" layer="21" curve="-180"/>
<pad name="1" x="8.4" y="-2.75" drill="1.4" shape="square"/>
<pad name="2" x="4.2" y="-2.75" drill="1.4" shape="square"/>
<pad name="3" x="0" y="-2.75" drill="1.4" shape="square"/>
<pad name="4" x="-4.2" y="-2.75" drill="1.4" shape="square"/>
<pad name="5" x="-8.4" y="-2.75" drill="1.4" shape="square"/>
<pad name="9" x="-4.2" y="2.75" drill="1.4" shape="square"/>
<pad name="10" x="-8.4" y="2.75" drill="1.4" shape="square"/>
<pad name="8" x="0" y="2.75" drill="1.4" shape="square"/>
<pad name="7" x="4.2" y="2.75" drill="1.4" shape="square"/>
<pad name="6" x="8.4" y="2.75" drill="1.4" shape="square"/>
<text x="5.715" y="-6.985" size="1.27" layer="25">&gt;NAME</text>
<text x="-10.16" y="-6.985" size="1.27" layer="27">&gt;VALUE</text>
<hole x="13.1" y="2.29" drill="3"/>
<hole x="-13.1" y="2.29" drill="3"/>
</package>
<package name="5566-8">
<description>&lt;b&gt;Mini FIT connector 8 pol&lt;/b&gt;&lt;p&gt;
<wire x1="-8.9" y1="4.5" x2="8.9" y2="4.5" width="0.254" layer="21"/>
<wire x1="8.9" y1="4.5" x2="8.9" y2="-2.2" width="0.254" layer="21"/>
<wire x1="8.9" y1="-3.3" x2="8.9" y2="-4.9" width="0.254" layer="21"/>
<wire x1="8.9" y1="-4.9" x2="-8.9" y2="-4.9" width="0.254" layer="21"/>
<wire x1="-8.9" y1="-4.9" x2="-8.9" y2="4.5" width="0.254" layer="21"/>
<wire x1="-12.4" y1="3.2" x2="-9.6" y2="3.2" width="0.254" layer="21" curve="-114.529547" cap="flat"/>
<wire x1="-12.4" y1="1.4" x2="-9.6" y2="1.4" width="0.254" layer="21" curve="114.529547" cap="flat"/>
<wire x1="-12.4" y1="3.2" x2="-12.4" y2="1.4" width="0.254" layer="21"/>
<wire x1="-9.7" y1="3.3" x2="-9" y2="3.3" width="0.254" layer="21"/>
<wire x1="-9.7" y1="1.3" x2="-9" y2="1.3" width="0.254" layer="21"/>
<wire x1="9.6" y1="1.4" x2="12.4" y2="1.4" width="0.254" layer="21" curve="114.529547" cap="flat"/>
<wire x1="9.6" y1="3.2" x2="12.4" y2="3.2" width="0.254" layer="21" curve="-114.529547" cap="flat"/>
<wire x1="12.4" y1="1.4" x2="12.4" y2="3.2" width="0.254" layer="21"/>
<wire x1="9.7" y1="1.3" x2="9" y2="1.3" width="0.254" layer="21"/>
<wire x1="9.7" y1="3.3" x2="9" y2="3.3" width="0.254" layer="21"/>
<wire x1="8.9" y1="-2.2" x2="8.9" y2="-3.3" width="0.254" layer="21" curve="-180"/>
<pad name="1" x="6.3" y="-2.75" drill="1.4" shape="square"/>
<pad name="2" x="2.1" y="-2.75" drill="1.4" shape="square"/>
<pad name="3" x="-2.1" y="-2.75" drill="1.4" shape="square"/>
<pad name="4" x="-6.3" y="-2.75" drill="1.4" shape="square"/>
<pad name="8" x="-6.3" y="2.75" drill="1.4" shape="square"/>
<pad name="7" x="-2.1" y="2.75" drill="1.4" shape="square"/>
<pad name="6" x="2.1" y="2.75" drill="1.4" shape="square"/>
<pad name="5" x="6.3" y="2.75" drill="1.4" shape="square"/>
<text x="2.54" y="-6.985" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="6.985" size="1.27" layer="27">&gt;VALUE</text>
<hole x="11" y="2.29" drill="3"/>
<hole x="-11" y="2.29" drill="3"/>
</package>
<package name="5566-6">
<description>&lt;b&gt;Mini FIT connector 6 pol&lt;/b&gt;&lt;p&gt;
<wire x1="-6.8" y1="4.5" x2="6.8" y2="4.5" width="0.254" layer="21"/>
<wire x1="6.8" y1="4.5" x2="6.8" y2="-2.2" width="0.254" layer="21"/>
<wire x1="6.8" y1="-3.3" x2="6.8" y2="-4.9" width="0.254" layer="21"/>
<wire x1="6.8" y1="-4.9" x2="-6.8" y2="-4.9" width="0.254" layer="21"/>
<wire x1="-6.8" y1="-4.9" x2="-6.8" y2="4.5" width="0.254" layer="21"/>
<wire x1="-10.3" y1="3.2" x2="-7.5" y2="3.2" width="0.254" layer="21" curve="-114.529547" cap="flat"/>
<wire x1="-10.3" y1="1.4" x2="-7.5" y2="1.4" width="0.254" layer="21" curve="114.529547" cap="flat"/>
<wire x1="-10.3" y1="3.2" x2="-10.3" y2="1.4" width="0.254" layer="21"/>
<wire x1="-7.6" y1="3.3" x2="-6.9" y2="3.3" width="0.254" layer="21"/>
<wire x1="-7.6" y1="1.3" x2="-6.9" y2="1.3" width="0.254" layer="21"/>
<wire x1="7.5" y1="1.4" x2="10.3" y2="1.4" width="0.254" layer="21" curve="114.529547" cap="flat"/>
<wire x1="7.5" y1="3.2" x2="10.3" y2="3.2" width="0.254" layer="21" curve="-114.529547" cap="flat"/>
<wire x1="10.3" y1="1.4" x2="10.3" y2="3.2" width="0.254" layer="21"/>
<wire x1="7.6" y1="1.3" x2="6.9" y2="1.3" width="0.254" layer="21"/>
<wire x1="7.6" y1="3.3" x2="6.9" y2="3.3" width="0.254" layer="21"/>
<wire x1="6.8" y1="-2.2" x2="6.8" y2="-3.3" width="0.254" layer="21" curve="-180"/>
<pad name="1" x="4.2" y="-2.75" drill="1.4" shape="square"/>
<pad name="2" x="0" y="-2.75" drill="1.4" shape="square"/>
<pad name="3" x="-4.2" y="-2.75" drill="1.4" shape="square"/>
<pad name="6" x="-4.2" y="2.75" drill="1.4" shape="square"/>
<pad name="5" x="0" y="2.75" drill="1.4" shape="square"/>
<pad name="4" x="4.2" y="2.75" drill="1.4" shape="square"/>
<text x="-1.27" y="-6.985" size="1.27" layer="25">&gt;NAME</text>
<hole x="8.9" y="2.29" drill="3"/>
<hole x="-8.9" y="2.29" drill="3"/>
</package>
<package name="5566-4">
<description>&lt;b&gt;Mini FIT connector 4 pol&lt;/b&gt;&lt;p&gt;
<wire x1="-4.7" y1="4.5" x2="4.7" y2="4.5" width="0.254" layer="21"/>
<wire x1="4.7" y1="4.5" x2="4.7" y2="-2.2" width="0.254" layer="21"/>
<wire x1="4.7" y1="-3.3" x2="4.7" y2="-4.9" width="0.254" layer="21"/>
<wire x1="4.7" y1="-4.9" x2="-4.7" y2="-4.9" width="0.254" layer="21"/>
<wire x1="-4.7" y1="-4.9" x2="-4.7" y2="4.5" width="0.254" layer="21"/>
<wire x1="-8.2" y1="3.2" x2="-5.4" y2="3.2" width="0.254" layer="21" curve="-114.529547" cap="flat"/>
<wire x1="-8.2" y1="1.4" x2="-5.4" y2="1.4" width="0.254" layer="21" curve="114.529547" cap="flat"/>
<wire x1="-8.2" y1="3.2" x2="-8.2" y2="1.4" width="0.254" layer="21"/>
<wire x1="-5.5" y1="3.3" x2="-4.8" y2="3.3" width="0.254" layer="21"/>
<wire x1="-5.5" y1="1.3" x2="-4.8" y2="1.3" width="0.254" layer="21"/>
<wire x1="5.4" y1="1.4" x2="8.2" y2="1.4" width="0.254" layer="21" curve="114.529547" cap="flat"/>
<wire x1="5.4" y1="3.2" x2="8.2" y2="3.2" width="0.254" layer="21" curve="-114.529547" cap="flat"/>
<wire x1="8.2" y1="1.4" x2="8.2" y2="3.2" width="0.254" layer="21"/>
<wire x1="5.5" y1="1.3" x2="4.8" y2="1.3" width="0.254" layer="21"/>
<wire x1="5.5" y1="3.3" x2="4.8" y2="3.3" width="0.254" layer="21"/>
<wire x1="4.7" y1="-2.2" x2="4.7" y2="-3.3" width="0.254" layer="21" curve="-180"/>
<pad name="1" x="2.1" y="-2.75" drill="1.4" shape="square"/>
<pad name="2" x="-2.1" y="-2.75" drill="1.4" shape="square"/>
<pad name="4" x="-2.1" y="2.75" drill="1.4" shape="square"/>
<pad name="3" x="2.1" y="2.75" drill="1.4" shape="square"/>
<text x="-3.81" y="6.985" size="1.27" layer="27">&gt;VALUE</text>
<hole x="6.8" y="2.29" drill="3"/>
<hole x="-6.8" y="2.29" drill="3"/>
</package>
<package name="5566-2">
<description>&lt;b&gt;Mini FIT connector 2 pol&lt;/b&gt;&lt;p&gt;
<wire x1="-2.6" y1="4.5" x2="2.6" y2="4.5" width="0.254" layer="21"/>
<wire x1="2.6" y1="4.5" x2="2.6" y2="-2.2" width="0.254" layer="21"/>
<wire x1="2.6" y1="-3.3" x2="2.6" y2="-4.9" width="0.254" layer="21"/>
<wire x1="2.6" y1="-4.9" x2="-2.6" y2="-4.9" width="0.254" layer="21"/>
<wire x1="-2.6" y1="-4.9" x2="-2.6" y2="4.5" width="0.254" layer="21"/>
<wire x1="-6.1" y1="3.2" x2="-3.3" y2="3.2" width="0.254" layer="21" curve="-114.529547" cap="flat"/>
<wire x1="-6.1" y1="1.4" x2="-3.3" y2="1.4" width="0.254" layer="21" curve="114.529547" cap="flat"/>
<wire x1="-6.1" y1="3.2" x2="-6.1" y2="1.4" width="0.254" layer="21"/>
<wire x1="-3.4" y1="3.3" x2="-2.7" y2="3.3" width="0.254" layer="21"/>
<wire x1="-3.4" y1="1.3" x2="-2.7" y2="1.3" width="0.254" layer="21"/>
<wire x1="3.3" y1="1.4" x2="6.1" y2="1.4" width="0.254" layer="21" curve="114.529547" cap="flat"/>
<wire x1="3.3" y1="3.2" x2="6.1" y2="3.2" width="0.254" layer="21" curve="-114.529547" cap="flat"/>
<wire x1="6.1" y1="1.4" x2="6.1" y2="3.2" width="0.254" layer="21"/>
<wire x1="3.4" y1="1.3" x2="2.7" y2="1.3" width="0.254" layer="21"/>
<wire x1="3.4" y1="3.3" x2="2.7" y2="3.3" width="0.254" layer="21"/>
<wire x1="2.6" y1="-2.2" x2="2.6" y2="-3.3" width="0.254" layer="21" curve="-180"/>
<pad name="1" x="0" y="-2.75" drill="1.4" shape="square"/>
<pad name="2" x="0" y="2.75" drill="1.4" shape="square"/>
<text x="-1.27" y="5.08" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-6.35" size="1.27" layer="27">&gt;VALUE</text>
<hole x="4.7" y="2.29" drill="3"/>
<hole x="-4.7" y="2.29" drill="3"/>
</package>
<package name="52745-0490">
<description>&lt;b&gt;FFC/FPC&lt;/b&gt;-to-Board  0.50mm (.020") SMT Top Contact&lt;p&gt;
Right Angle, ZIF, Style Receptacle 52745 / 52435&lt;br&gt;
Source: http://www.molex.com/product/ffc/52745.html</description>
<wire x1="-3.95" y1="-3" x2="-3.95" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="-3.95" y1="-3.5" x2="-3.85" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="-3.85" y1="-3.6" x2="3.85" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="3.85" y1="-3.6" x2="3.95" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="3.95" y1="-3.5" x2="3.95" y2="-3" width="0.2032" layer="21"/>
<wire x1="3.95" y1="-3" x2="-3.95" y2="-3" width="0.2032" layer="21"/>
<wire x1="-3.05" y1="1.9" x2="3.05" y2="1.9" width="0.2032" layer="51"/>
<wire x1="3.05" y1="1.9" x2="3.05" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="3.05" y1="-1.4" x2="-3.05" y2="-1.4" width="0.2032" layer="21"/>
<wire x1="-3.05" y1="-1.4" x2="-3.05" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-2.5" y1="-1.5" x2="-2.5" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="2.5" y1="-1.5" x2="2.5" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="-1.05" y1="-3.1" x2="-1.05" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="-1.05" y1="-3.5" x2="-0.8" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-0.8" y1="-3.25" x2="-0.8" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="0.8" y1="-3.1" x2="0.8" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="0.8" y1="-3.25" x2="1.05" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="1.05" y1="-3.5" x2="1.05" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="3.2" y1="1.95" x2="3.35" y2="1.95" width="0.1016" layer="51"/>
<wire x1="3.35" y1="1.95" x2="3.35" y2="1.65" width="0.1016" layer="51"/>
<wire x1="3.35" y1="1.65" x2="3.95" y2="1.65" width="0.1016" layer="51"/>
<wire x1="3.95" y1="1.65" x2="3.95" y2="1.45" width="0.1016" layer="51"/>
<wire x1="3.95" y1="1.45" x2="3.35" y2="1.45" width="0.1016" layer="51"/>
<wire x1="3.35" y1="1.45" x2="3.35" y2="0.95" width="0.1016" layer="51"/>
<wire x1="3.35" y1="0.95" x2="3.4" y2="0.9" width="0.1016" layer="51"/>
<wire x1="3.4" y1="0.9" x2="3.95" y2="0.9" width="0.1016" layer="51"/>
<wire x1="3.95" y1="0.9" x2="3.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="3.95" y1="0.7" x2="3.2" y2="0.7" width="0.1016" layer="51"/>
<wire x1="3.2" y1="0.7" x2="3.2" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-3.2" y1="1.95" x2="-3.35" y2="1.95" width="0.1016" layer="51"/>
<wire x1="-3.35" y1="1.95" x2="-3.35" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-3.35" y1="1.65" x2="-3.95" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-3.95" y1="1.65" x2="-3.95" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-3.95" y1="1.45" x2="-3.35" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-3.35" y1="1.45" x2="-3.35" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-3.35" y1="0.95" x2="-3.4" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-3.4" y1="0.9" x2="-3.95" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-3.95" y1="0.9" x2="-3.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-3.95" y1="0.7" x2="-3.2" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-3.2" y1="0.7" x2="-3.2" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-1.65" y1="-1.25" x2="-1.65" y2="1" width="0.2032" layer="21"/>
<wire x1="-1.65" y1="1" x2="-1.5" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="-1.5" y1="1" x2="-1.5" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="1.5" y1="-1.25" x2="1.5" y2="1" width="0.2032" layer="21"/>
<wire x1="1.5" y1="1" x2="1.65" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="1.65" y1="1" x2="1.65" y2="-1.25" width="0.2032" layer="21"/>
<smd name="1" x="-0.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="2" x="-0.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="3" x="0.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="4" x="0.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<text x="-4.08" y="3.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-4.08" y="-5.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="3.25" y1="-0.2" x2="4.4" y2="2" layer="29" rot="R180"/>
<rectangle x1="2" y1="-1.05" x2="3.3" y2="2" layer="29" rot="R180"/>
<rectangle x1="2.2" y1="-0.05" x2="4.2" y2="1.85" layer="31" rot="R180"/>
<rectangle x1="-4.4" y1="-0.2" x2="-3.25" y2="2" layer="29"/>
<rectangle x1="-3.3" y1="-1.05" x2="-2" y2="2" layer="29"/>
<rectangle x1="-4.2" y1="-0.05" x2="-2.2" y2="1.85" layer="31"/>
<rectangle x1="-0.85" y1="2" x2="-0.65" y2="2.7" layer="51"/>
<rectangle x1="-0.35" y1="2" x2="-0.15" y2="2.7" layer="51"/>
<rectangle x1="0.15" y1="2" x2="0.35" y2="2.7" layer="51"/>
<rectangle x1="0.65" y1="2" x2="0.85" y2="2.7" layer="51"/>
<rectangle x1="-4.4" y1="-0.2" x2="-2" y2="2" layer="1"/>
<rectangle x1="-3.3" y1="-1.05" x2="-2" y2="-0.2" layer="1"/>
<rectangle x1="2" y1="-1.05" x2="3.3" y2="-0.2" layer="1"/>
<rectangle x1="2" y1="-0.2" x2="4.4" y2="2" layer="1"/>
<polygon width="0.1016" layer="21">
<vertex x="-1.25" y="-1.25"/>
<vertex x="-1.25" y="-1.2"/>
<vertex x="-1" y="-0.85"/>
<vertex x="-0.75" y="-1.2"/>
<vertex x="-0.75" y="-1.25"/>
</polygon>
</package>
<package name="52559-0692">
<description>&lt;b&gt;FFC/FPC&lt;/b&gt;-to-Board  0.50mm (.020") SMT, Vertical, ZIF Receptacle&lt;p&gt;
Source: http://www.molex.com/product/ffc/52559.html</description>
<wire x1="-4.25" y1="-1" x2="-4.25" y2="1" width="0.2032" layer="21"/>
<wire x1="-4.25" y1="1" x2="-1.75" y2="1.75" width="0.2032" layer="51"/>
<wire x1="-1.75" y1="1.75" x2="1.75" y2="1.75" width="0.2032" layer="51"/>
<wire x1="1.75" y1="1.75" x2="4.25" y2="1" width="0.2032" layer="51"/>
<wire x1="4.25" y1="1" x2="4.25" y2="-1" width="0.2032" layer="21"/>
<wire x1="2.95" y1="-1" x2="-2.95" y2="-1" width="0.2032" layer="51"/>
<wire x1="-2.95" y1="-1" x2="-4.25" y2="-1" width="0.2032" layer="21"/>
<wire x1="-1.7" y1="-1" x2="-1.7" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="-1.7" y1="-0.25" x2="1.7" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="1.7" y1="-0.25" x2="1.7" y2="-1" width="0.2032" layer="21"/>
<wire x1="4.25" y1="-1" x2="2.95" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-1.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="3" x="-0.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="5" x="0.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="M1" x="-2.25" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="M2" x="2.25" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="6" x="1.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="4" x="0.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="2" x="-0.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="M3" x="2.25" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="M4" x="-2.25" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<text x="-2.54" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.5" y1="-1.55" x2="-2" y2="-1.1" layer="51"/>
<rectangle x1="-1.4" y1="-1.55" x2="-1.1" y2="-1.1" layer="51"/>
<rectangle x1="-0.4" y1="-1.55" x2="-0.1" y2="-1.1" layer="51"/>
<rectangle x1="0.6" y1="-1.55" x2="0.9" y2="-1.1" layer="51"/>
<rectangle x1="2" y1="-1.55" x2="2.5" y2="-1.1" layer="51"/>
<vertex x="-3.1" y="-0.95"/>
<vertex x="-3.1" y="-0.85"/>
<vertex x="-3.3" y="-0.55"/>
<vertex x="-3.5" y="-0.85"/>
<vertex x="-3.5" y="-0.95"/>
</polygon>
</package>
<package name="52559-0890">
<wire x1="-4.75" y1="-1" x2="-4.75" y2="1" width="0.2032" layer="21"/>
<wire x1="-4.75" y1="1" x2="-2.25" y2="1.75" width="0.2032" layer="51"/>
<wire x1="-2.25" y1="1.75" x2="2.25" y2="1.75" width="0.2032" layer="51"/>
<wire x1="2.25" y1="1.75" x2="4.75" y2="1" width="0.2032" layer="51"/>
<wire x1="4.75" y1="1" x2="4.75" y2="-1" width="0.2032" layer="21"/>
<wire x1="3.45" y1="-1" x2="-3.45" y2="-1" width="0.2032" layer="51"/>
<wire x1="-3.45" y1="-1" x2="-4.75" y2="-1" width="0.2032" layer="21"/>
<wire x1="-2.2" y1="-1" x2="-2.2" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="-2.2" y1="-0.25" x2="2.2" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="2.2" y1="-0.25" x2="2.2" y2="-1" width="0.2032" layer="21"/>
<wire x1="4.75" y1="-1" x2="3.45" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-1.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="3" x="-0.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="5" x="0.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="M1" x="-2.75" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="M2" x="2.75" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="6" x="0.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="4" x="-0.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="2" x="-1.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="M3" x="2.75" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="M4" x="-2.75" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="7" x="1.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="8" x="1.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<text x="-3.81" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.81" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3" y1="-1.55" x2="-2.5" y2="-1.1" layer="51"/>
<rectangle x1="-1.9" y1="-1.55" x2="-1.6" y2="-1.1" layer="51"/>
<rectangle x1="-0.9" y1="-1.55" x2="-0.6" y2="-1.1" layer="51"/>
<rectangle x1="0.1" y1="-1.55" x2="0.4" y2="-1.1" layer="51"/>
<rectangle x1="2.5" y1="-1.55" x2="3" y2="-1.1" layer="51"/>
<rectangle x1="1.1" y1="-1.55" x2="1.4" y2="-1.1" layer="51"/>
<vertex x="-3.6" y="-0.95"/>
<vertex x="-3.6" y="-0.85"/>
<vertex x="-3.8" y="-0.55"/>
<vertex x="-4" y="-0.85"/>
<vertex x="-4" y="-0.95"/>
</polygon>
</package>
<package name="52559-0992">
<wire x1="-5" y1="-1" x2="-5" y2="1" width="0.2032" layer="21"/>
<wire x1="-5" y1="1" x2="-2.5" y2="1.75" width="0.2032" layer="51"/>
<wire x1="-2.5" y1="1.75" x2="2.5" y2="1.75" width="0.2032" layer="51"/>
<wire x1="2.5" y1="1.75" x2="5" y2="1" width="0.2032" layer="51"/>
<wire x1="5" y1="1" x2="5" y2="-1" width="0.2032" layer="21"/>
<wire x1="3.7" y1="-1" x2="-3.7" y2="-1" width="0.2032" layer="51"/>
<wire x1="-3.7" y1="-1" x2="-5" y2="-1" width="0.2032" layer="21"/>
<wire x1="-2.45" y1="-1" x2="-2.45" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="-2.45" y1="-0.25" x2="2.45" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="2.45" y1="-0.25" x2="2.45" y2="-1" width="0.2032" layer="21"/>
<wire x1="5" y1="-1" x2="3.7" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-2" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="3" x="-1" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="5" x="0" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="M1" x="-3" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="M2" x="3" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="6" x="0.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="4" x="-0.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="2" x="-1.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="M3" x="3" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="M4" x="-3" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="7" x="1" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="8" x="1.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="9" x="2" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<rectangle x1="-3.25" y1="-1.55" x2="-2.75" y2="-1.1" layer="51"/>
<rectangle x1="-2.15" y1="-1.55" x2="-1.85" y2="-1.1" layer="51"/>
<rectangle x1="-1.15" y1="-1.55" x2="-0.85" y2="-1.1" layer="51"/>
<rectangle x1="-0.15" y1="-1.55" x2="0.15" y2="-1.1" layer="51"/>
<rectangle x1="2.75" y1="-1.55" x2="3.25" y2="-1.1" layer="51"/>
<rectangle x1="0.85" y1="-1.55" x2="1.15" y2="-1.1" layer="51"/>
<rectangle x1="1.85" y1="-1.55" x2="2.15" y2="-1.1" layer="51"/>
<vertex x="-3.85" y="-0.95"/>
<vertex x="-3.85" y="-0.85"/>
<vertex x="-4.05" y="-0.55"/>
<vertex x="-4.25" y="-0.85"/>
<vertex x="-4.25" y="-0.95"/>
</polygon>
</package>
<package name="52559-1092">
<wire x1="-5.25" y1="-1" x2="-5.25" y2="1" width="0.2032" layer="21"/>
<wire x1="-5.25" y1="1" x2="-2.75" y2="1.75" width="0.2032" layer="51"/>
<wire x1="-2.75" y1="1.75" x2="2.75" y2="1.75" width="0.2032" layer="51"/>
<wire x1="2.75" y1="1.75" x2="5.25" y2="1" width="0.2032" layer="51"/>
<wire x1="5.25" y1="1" x2="5.25" y2="-1" width="0.2032" layer="21"/>
<wire x1="3.95" y1="-1" x2="-3.95" y2="-1" width="0.2032" layer="51"/>
<wire x1="-3.95" y1="-1" x2="-5.25" y2="-1" width="0.2032" layer="21"/>
<wire x1="-2.7" y1="-1" x2="-2.7" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="-2.7" y1="-0.25" x2="2.7" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="2.7" y1="-0.25" x2="2.7" y2="-1" width="0.2032" layer="21"/>
<wire x1="5.25" y1="-1" x2="3.95" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-2.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="3" x="-1.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="5" x="-0.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="M1" x="-3.25" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="M2" x="3.25" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="6" x="0.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="4" x="-0.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="2" x="-1.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="M3" x="3.25" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="M4" x="-3.25" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="7" x="0.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="8" x="1.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="9" x="1.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="10" x="2.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<rectangle x1="-3.5" y1="-1.55" x2="-3" y2="-1.1" layer="51"/>
<rectangle x1="-2.4" y1="-1.55" x2="-2.1" y2="-1.1" layer="51"/>
<rectangle x1="3" y1="-1.55" x2="3.5" y2="-1.1" layer="51"/>
<rectangle x1="1.6" y1="-1.55" x2="1.9" y2="-1.1" layer="51"/>
<vertex x="-4.1" y="-0.95"/>
<vertex x="-4.1" y="-0.85"/>
<vertex x="-4.3" y="-0.55"/>
<vertex x="-4.5" y="-0.85"/>
<vertex x="-4.5" y="-0.95"/>
</polygon>
</package>
<package name="52559-1292">
<wire x1="-5.75" y1="-1" x2="-5.75" y2="1" width="0.2032" layer="21"/>
<wire x1="-5.75" y1="1" x2="-3.25" y2="1.75" width="0.2032" layer="51"/>
<wire x1="-3.25" y1="1.75" x2="3.25" y2="1.75" width="0.2032" layer="51"/>
<wire x1="3.25" y1="1.75" x2="5.75" y2="1" width="0.2032" layer="51"/>
<wire x1="5.75" y1="1" x2="5.75" y2="-1" width="0.2032" layer="21"/>
<wire x1="4.45" y1="-1" x2="-4.45" y2="-1" width="0.2032" layer="51"/>
<wire x1="-4.45" y1="-1" x2="-5.75" y2="-1" width="0.2032" layer="21"/>
<wire x1="-3.2" y1="-1" x2="-3.2" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="-3.2" y1="-0.25" x2="3.2" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="3.2" y1="-0.25" x2="3.2" y2="-1" width="0.2032" layer="21"/>
<wire x1="5.75" y1="-1" x2="4.45" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-2.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="3" x="-1.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="5" x="-0.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="M1" x="-3.75" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="M2" x="3.75" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="6" x="-0.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="4" x="-1.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="2" x="-2.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="M3" x="3.75" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="M4" x="-3.75" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="7" x="0.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="8" x="0.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="9" x="1.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="10" x="1.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="11" x="2.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="12" x="2.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<rectangle x1="-4" y1="-1.55" x2="-3.5" y2="-1.1" layer="51"/>
<rectangle x1="-2.9" y1="-1.55" x2="-2.6" y2="-1.1" layer="51"/>
<rectangle x1="3.5" y1="-1.55" x2="4" y2="-1.1" layer="51"/>
<rectangle x1="2.1" y1="-1.55" x2="2.4" y2="-1.1" layer="51"/>
<vertex x="-4.6" y="-0.95"/>
<vertex x="-4.6" y="-0.85"/>
<vertex x="-4.8" y="-0.55"/>
<vertex x="-5" y="-0.85"/>
<vertex x="-5" y="-0.95"/>
</polygon>
</package>
<package name="52559-1390">
<wire x1="-6" y1="-1" x2="-6" y2="1" width="0.2032" layer="21"/>
<wire x1="-6" y1="1" x2="-3.5" y2="1.75" width="0.2032" layer="51"/>
<wire x1="-3.5" y1="1.75" x2="3.5" y2="1.75" width="0.2032" layer="51"/>
<wire x1="3.5" y1="1.75" x2="6" y2="1" width="0.2032" layer="51"/>
<wire x1="6" y1="1" x2="6" y2="-1" width="0.2032" layer="21"/>
<wire x1="4.7" y1="-1" x2="-4.7" y2="-1" width="0.2032" layer="51"/>
<wire x1="-4.7" y1="-1" x2="-6" y2="-1" width="0.2032" layer="21"/>
<wire x1="-3.45" y1="-1" x2="-3.45" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="-3.45" y1="-0.25" x2="3.45" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="3.45" y1="-0.25" x2="3.45" y2="-1" width="0.2032" layer="21"/>
<wire x1="6" y1="-1" x2="4.7" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-3" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="3" x="-2" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="5" x="-1" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="M1" x="-4" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="M2" x="4" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="6" x="-0.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="4" x="-1.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="2" x="-2.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="M3" x="4" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="M4" x="-4" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="7" x="0" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="8" x="0.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="9" x="1" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="10" x="1.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="11" x="2" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="12" x="2.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="13" x="3" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<rectangle x1="-4.25" y1="-1.55" x2="-3.75" y2="-1.1" layer="51"/>
<rectangle x1="-3.15" y1="-1.55" x2="-2.85" y2="-1.1" layer="51"/>
<rectangle x1="3.75" y1="-1.55" x2="4.25" y2="-1.1" layer="51"/>
<rectangle x1="2.85" y1="-1.55" x2="3.15" y2="-1.1" layer="51"/>
<vertex x="-4.85" y="-0.95"/>
<vertex x="-4.85" y="-0.85"/>
<vertex x="-5.05" y="-0.55"/>
<vertex x="-5.25" y="-0.85"/>
<vertex x="-5.25" y="-0.95"/>
</polygon>
</package>
<package name="52559-1492">
<wire x1="-6.25" y1="-1" x2="-6.25" y2="1" width="0.2032" layer="21"/>
<wire x1="-6.25" y1="1" x2="-3.75" y2="1.75" width="0.2032" layer="51"/>
<wire x1="-3.75" y1="1.75" x2="3.75" y2="1.75" width="0.2032" layer="51"/>
<wire x1="3.75" y1="1.75" x2="6.25" y2="1" width="0.2032" layer="51"/>
<wire x1="6.25" y1="1" x2="6.25" y2="-1" width="0.2032" layer="21"/>
<wire x1="4.95" y1="-1" x2="-4.95" y2="-1" width="0.2032" layer="51"/>
<wire x1="-4.95" y1="-1" x2="-6.25" y2="-1" width="0.2032" layer="21"/>
<wire x1="-3.7" y1="-1" x2="-3.7" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="-3.7" y1="-0.25" x2="3.7" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="3.7" y1="-0.25" x2="3.7" y2="-1" width="0.2032" layer="21"/>
<wire x1="6.25" y1="-1" x2="4.95" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-3.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="3" x="-2.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="5" x="-1.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="M1" x="-4.25" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="M2" x="4.25" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="6" x="-0.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="4" x="-1.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="2" x="-2.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="M3" x="4.25" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="M4" x="-4.25" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="7" x="-0.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="8" x="0.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="9" x="0.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="10" x="1.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="11" x="1.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="12" x="2.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="13" x="2.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="14" x="3.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<text x="-5.08" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.08" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-4.5" y1="-1.55" x2="-4" y2="-1.1" layer="51"/>
<rectangle x1="-3.4" y1="-1.55" x2="-3.1" y2="-1.1" layer="51"/>
<rectangle x1="4" y1="-1.55" x2="4.5" y2="-1.1" layer="51"/>
<rectangle x1="2.6" y1="-1.55" x2="2.9" y2="-1.1" layer="51"/>
<vertex x="-5.1" y="-0.95"/>
<vertex x="-5.1" y="-0.85"/>
<vertex x="-5.3" y="-0.55"/>
<vertex x="-5.5" y="-0.85"/>
<vertex x="-5.5" y="-0.95"/>
</polygon>
</package>
<package name="52559-1692">
<wire x1="-6.75" y1="-1" x2="-6.75" y2="1" width="0.2032" layer="21"/>
<wire x1="-6.75" y1="1" x2="-4.25" y2="1.75" width="0.2032" layer="51"/>
<wire x1="-4.25" y1="1.75" x2="4.25" y2="1.75" width="0.2032" layer="51"/>
<wire x1="4.25" y1="1.75" x2="6.75" y2="1" width="0.2032" layer="51"/>
<wire x1="6.75" y1="1" x2="6.75" y2="-1" width="0.2032" layer="21"/>
<wire x1="5.45" y1="-1" x2="-5.45" y2="-1" width="0.2032" layer="51"/>
<wire x1="-5.45" y1="-1" x2="-6.75" y2="-1" width="0.2032" layer="21"/>
<wire x1="-4.2" y1="-1" x2="-4.2" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="-4.2" y1="-0.25" x2="4.2" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="4.2" y1="-0.25" x2="4.2" y2="-1" width="0.2032" layer="21"/>
<wire x1="6.75" y1="-1" x2="5.45" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-3.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="3" x="-2.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="5" x="-1.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="M1" x="-4.75" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="M2" x="4.75" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="6" x="-1.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="4" x="-2.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="2" x="-3.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="M3" x="4.75" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="M4" x="-4.75" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="7" x="-0.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="8" x="-0.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="9" x="0.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="10" x="0.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="11" x="1.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="12" x="1.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="13" x="2.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="14" x="2.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="15" x="3.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="16" x="3.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<rectangle x1="-5" y1="-1.55" x2="-4.5" y2="-1.1" layer="51"/>
<rectangle x1="-3.9" y1="-1.55" x2="-3.6" y2="-1.1" layer="51"/>
<rectangle x1="4.5" y1="-1.55" x2="5" y2="-1.1" layer="51"/>
<rectangle x1="3.1" y1="-1.55" x2="3.4" y2="-1.1" layer="51"/>
<vertex x="-5.6" y="-0.95"/>
<vertex x="-5.6" y="-0.85"/>
<vertex x="-5.8" y="-0.55"/>
<vertex x="-6" y="-0.85"/>
<vertex x="-6" y="-0.95"/>
</polygon>
</package>
<package name="52559-1592">
<wire x1="-6.5" y1="-1" x2="-6.5" y2="1" width="0.2032" layer="21"/>
<wire x1="-6.5" y1="1" x2="-4" y2="1.75" width="0.2032" layer="51"/>
<wire x1="-4" y1="1.75" x2="4" y2="1.75" width="0.2032" layer="51"/>
<wire x1="4" y1="1.75" x2="6.5" y2="1" width="0.2032" layer="51"/>
<wire x1="6.5" y1="1" x2="6.5" y2="-1" width="0.2032" layer="21"/>
<wire x1="5.2" y1="-1" x2="-5.2" y2="-1" width="0.2032" layer="51"/>
<wire x1="-5.2" y1="-1" x2="-6.5" y2="-1" width="0.2032" layer="21"/>
<wire x1="-3.95" y1="-1" x2="-3.95" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="-3.95" y1="-0.25" x2="3.95" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="3.95" y1="-0.25" x2="3.95" y2="-1" width="0.2032" layer="21"/>
<wire x1="6.5" y1="-1" x2="5.2" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-3.5" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="3" x="-2.5" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="5" x="-1.5" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="M1" x="-4.5" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="M2" x="4.5" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="6" x="-1" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="4" x="-2" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="2" x="-3" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="M3" x="4.5" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="M4" x="-4.5" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="7" x="-0.5" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="8" x="0" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="9" x="0.5" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="10" x="1" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="11" x="1.5" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="12" x="2" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="13" x="2.5" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="14" x="3" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="15" x="3.5" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<rectangle x1="-4.75" y1="-1.55" x2="-4.25" y2="-1.1" layer="51"/>
<rectangle x1="-3.65" y1="-1.55" x2="-3.35" y2="-1.1" layer="51"/>
<rectangle x1="-2.65" y1="-1.55" x2="-2.35" y2="-1.1" layer="51"/>
<rectangle x1="-1.65" y1="-1.55" x2="-1.35" y2="-1.1" layer="51"/>
<rectangle x1="4.25" y1="-1.55" x2="4.75" y2="-1.1" layer="51"/>
<rectangle x1="-0.65" y1="-1.55" x2="-0.35" y2="-1.1" layer="51"/>
<rectangle x1="0.35" y1="-1.55" x2="0.65" y2="-1.1" layer="51"/>
<rectangle x1="1.35" y1="-1.55" x2="1.65" y2="-1.1" layer="51"/>
<rectangle x1="2.35" y1="-1.55" x2="2.65" y2="-1.1" layer="51"/>
<rectangle x1="3.35" y1="-1.55" x2="3.65" y2="-1.1" layer="51"/>
<vertex x="-5.35" y="-0.95"/>
<vertex x="-5.35" y="-0.85"/>
<vertex x="-5.55" y="-0.55"/>
<vertex x="-5.75" y="-0.85"/>
<vertex x="-5.75" y="-0.95"/>
</polygon>
</package>
<package name="52559-1792">
<wire x1="-7" y1="-1" x2="-7" y2="1" width="0.2032" layer="21"/>
<wire x1="-7" y1="1" x2="-4.5" y2="1.75" width="0.2032" layer="51"/>
<wire x1="-4.5" y1="1.75" x2="4.5" y2="1.75" width="0.2032" layer="51"/>
<wire x1="4.5" y1="1.75" x2="7" y2="1" width="0.2032" layer="51"/>
<wire x1="7" y1="1" x2="7" y2="-1" width="0.2032" layer="21"/>
<wire x1="5.7" y1="-1" x2="-5.7" y2="-1" width="0.2032" layer="51"/>
<wire x1="-5.7" y1="-1" x2="-7" y2="-1" width="0.2032" layer="21"/>
<wire x1="-4.45" y1="-1" x2="-4.45" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="-4.45" y1="-0.25" x2="4.45" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="4.45" y1="-0.25" x2="4.45" y2="-1" width="0.2032" layer="21"/>
<wire x1="7" y1="-1" x2="5.7" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-4" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="3" x="-3" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="5" x="-2" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="M1" x="-5" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="M2" x="5" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="6" x="-1.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="4" x="-2.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="2" x="-3.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="M3" x="5" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="M4" x="-5" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="7" x="-1" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="8" x="-0.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="9" x="0" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="10" x="0.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="11" x="1" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="12" x="1.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="13" x="2" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="14" x="2.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="15" x="3" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="16" x="3.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="17" x="4" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<rectangle x1="-5.25" y1="-1.55" x2="-4.75" y2="-1.1" layer="51"/>
<rectangle x1="-4.15" y1="-1.55" x2="-3.85" y2="-1.1" layer="51"/>
<rectangle x1="4.75" y1="-1.55" x2="5.25" y2="-1.1" layer="51"/>
<rectangle x1="3.85" y1="-1.55" x2="4.15" y2="-1.1" layer="51"/>
<vertex x="-5.85" y="-0.95"/>
<vertex x="-5.85" y="-0.85"/>
<vertex x="-6.05" y="-0.55"/>
<vertex x="-6.25" y="-0.85"/>
<vertex x="-6.25" y="-0.95"/>
</polygon>
</package>
<package name="52559-1890">
<wire x1="-7.25" y1="-1" x2="-7.25" y2="1" width="0.2032" layer="21"/>
<wire x1="-7.25" y1="1" x2="-4.75" y2="1.75" width="0.2032" layer="51"/>
<wire x1="-4.75" y1="1.75" x2="4.75" y2="1.75" width="0.2032" layer="51"/>
<wire x1="4.75" y1="1.75" x2="7.25" y2="1" width="0.2032" layer="51"/>
<wire x1="7.25" y1="1" x2="7.25" y2="-1" width="0.2032" layer="21"/>
<wire x1="5.95" y1="-1" x2="-5.95" y2="-1" width="0.2032" layer="51"/>
<wire x1="-5.95" y1="-1" x2="-7.25" y2="-1" width="0.2032" layer="21"/>
<wire x1="-4.7" y1="-1" x2="-4.7" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="-4.7" y1="-0.25" x2="4.7" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="4.7" y1="-0.25" x2="4.7" y2="-1" width="0.2032" layer="21"/>
<wire x1="7.25" y1="-1" x2="5.95" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-4.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="3" x="-3.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="5" x="-2.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="M1" x="-5.25" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="M2" x="5.25" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="6" x="-1.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="4" x="-2.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="2" x="-3.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="M3" x="5.25" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="M4" x="-5.25" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="7" x="-1.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="8" x="-0.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="9" x="-0.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="10" x="0.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="11" x="0.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="12" x="1.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="13" x="1.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="14" x="2.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="15" x="2.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="16" x="3.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="17" x="3.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="18" x="4.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<rectangle x1="-5.5" y1="-1.55" x2="-5" y2="-1.1" layer="51"/>
<rectangle x1="-4.4" y1="-1.55" x2="-4.1" y2="-1.1" layer="51"/>
<rectangle x1="5" y1="-1.55" x2="5.5" y2="-1.1" layer="51"/>
<rectangle x1="3.6" y1="-1.55" x2="3.9" y2="-1.1" layer="51"/>
<vertex x="-6.1" y="-0.95"/>
<vertex x="-6.1" y="-0.85"/>
<vertex x="-6.3" y="-0.55"/>
<vertex x="-6.5" y="-0.85"/>
<vertex x="-6.5" y="-0.95"/>
</polygon>
</package>
<package name="52559-2092">
<wire x1="-7.75" y1="-1" x2="-7.75" y2="1" width="0.2032" layer="21"/>
<wire x1="-7.75" y1="1" x2="-5.25" y2="1.75" width="0.2032" layer="51"/>
<wire x1="-5.25" y1="1.75" x2="5.25" y2="1.75" width="0.2032" layer="51"/>
<wire x1="5.25" y1="1.75" x2="7.75" y2="1" width="0.2032" layer="51"/>
<wire x1="7.75" y1="1" x2="7.75" y2="-1" width="0.2032" layer="21"/>
<wire x1="6.45" y1="-1" x2="-6.45" y2="-1" width="0.2032" layer="51"/>
<wire x1="-6.45" y1="-1" x2="-7.75" y2="-1" width="0.2032" layer="21"/>
<wire x1="-5.2" y1="-1" x2="-5.2" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="-5.2" y1="-0.25" x2="5.2" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="5.2" y1="-0.25" x2="5.2" y2="-1" width="0.2032" layer="21"/>
<wire x1="7.75" y1="-1" x2="6.45" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-4.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="3" x="-3.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="5" x="-2.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="M1" x="-5.75" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="M2" x="5.75" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="6" x="-2.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="4" x="-3.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="2" x="-4.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="M3" x="5.75" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="M4" x="-5.75" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="7" x="-1.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="8" x="-1.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="9" x="-0.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="10" x="-0.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="11" x="0.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="12" x="0.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="13" x="1.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="14" x="1.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="15" x="2.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="16" x="2.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="17" x="3.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="18" x="3.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="19" x="4.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="20" x="4.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<text x="-6.35" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-6.35" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-6" y1="-1.55" x2="-5.5" y2="-1.1" layer="51"/>
<rectangle x1="-4.9" y1="-1.55" x2="-4.6" y2="-1.1" layer="51"/>
<rectangle x1="5.5" y1="-1.55" x2="6" y2="-1.1" layer="51"/>
<rectangle x1="4.1" y1="-1.55" x2="4.4" y2="-1.1" layer="51"/>
<vertex x="-6.6" y="-0.95"/>
<vertex x="-6.6" y="-0.85"/>
<vertex x="-6.8" y="-0.55"/>
<vertex x="-7" y="-0.85"/>
<vertex x="-7" y="-0.95"/>
</polygon>
</package>
<package name="52559-2290">
<wire x1="-8.25" y1="-1" x2="-8.25" y2="1" width="0.2032" layer="21"/>
<wire x1="-8.25" y1="1" x2="-5.75" y2="1.75" width="0.2032" layer="51"/>
<wire x1="-5.75" y1="1.75" x2="5.75" y2="1.75" width="0.2032" layer="51"/>
<wire x1="5.75" y1="1.75" x2="8.25" y2="1" width="0.2032" layer="51"/>
<wire x1="8.25" y1="1" x2="8.25" y2="-1" width="0.2032" layer="21"/>
<wire x1="6.95" y1="-1" x2="-6.95" y2="-1" width="0.2032" layer="51"/>
<wire x1="-6.95" y1="-1" x2="-8.25" y2="-1" width="0.2032" layer="21"/>
<wire x1="-5.7" y1="-1" x2="-5.7" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="-5.7" y1="-0.25" x2="5.7" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="5.7" y1="-0.25" x2="5.7" y2="-1" width="0.2032" layer="21"/>
<wire x1="8.25" y1="-1" x2="6.95" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-5.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="3" x="-4.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="5" x="-3.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="M1" x="-6.25" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="M2" x="6.25" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="6" x="-2.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="4" x="-3.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="2" x="-4.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="M3" x="6.25" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="M4" x="-6.25" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="7" x="-2.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="8" x="-1.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="9" x="-1.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="10" x="-0.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="11" x="-0.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="12" x="0.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="13" x="0.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="14" x="1.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="15" x="1.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="16" x="2.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="17" x="2.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="18" x="3.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="19" x="3.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="20" x="4.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="21" x="4.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="22" x="5.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<rectangle x1="-6.5" y1="-1.55" x2="-6" y2="-1.1" layer="51"/>
<rectangle x1="-5.4" y1="-1.55" x2="-5.1" y2="-1.1" layer="51"/>
<rectangle x1="6" y1="-1.55" x2="6.5" y2="-1.1" layer="51"/>
<rectangle x1="4.6" y1="-1.55" x2="4.9" y2="-1.1" layer="51"/>
<vertex x="-7.1" y="-0.95"/>
<vertex x="-7.1" y="-0.85"/>
<vertex x="-7.3" y="-0.55"/>
<vertex x="-7.5" y="-0.85"/>
<vertex x="-7.5" y="-0.95"/>
</polygon>
</package>
<package name="52559-2192">
<wire x1="-8" y1="-1" x2="-8" y2="1" width="0.2032" layer="21"/>
<wire x1="-8" y1="1" x2="-5.5" y2="1.75" width="0.2032" layer="51"/>
<wire x1="-5.5" y1="1.75" x2="5.5" y2="1.75" width="0.2032" layer="51"/>
<wire x1="5.5" y1="1.75" x2="8" y2="1" width="0.2032" layer="51"/>
<wire x1="8" y1="1" x2="8" y2="-1" width="0.2032" layer="21"/>
<wire x1="6.7" y1="-1" x2="-6.7" y2="-1" width="0.2032" layer="51"/>
<wire x1="-6.7" y1="-1" x2="-8" y2="-1" width="0.2032" layer="21"/>
<wire x1="-5.45" y1="-1" x2="-5.45" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="-5.45" y1="-0.25" x2="5.45" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="5.45" y1="-0.25" x2="5.45" y2="-1" width="0.2032" layer="21"/>
<wire x1="8" y1="-1" x2="6.7" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-5" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="3" x="-4" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="5" x="-3" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="M1" x="-6" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="M2" x="6" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="6" x="-2.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="4" x="-3.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="2" x="-4.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="M3" x="6" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="M4" x="-6" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="7" x="-2" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="8" x="-1.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="9" x="-1" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="10" x="-0.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="11" x="0" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="12" x="0.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="13" x="1" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="14" x="1.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="15" x="2" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="16" x="2.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="17" x="3" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="18" x="3.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="19" x="4" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="20" x="4.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="21" x="5" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<rectangle x1="-6.25" y1="-1.55" x2="-5.75" y2="-1.1" layer="51"/>
<rectangle x1="-5.15" y1="-1.55" x2="-4.85" y2="-1.1" layer="51"/>
<rectangle x1="5.75" y1="-1.55" x2="6.25" y2="-1.1" layer="51"/>
<rectangle x1="4.85" y1="-1.55" x2="5.15" y2="-1.1" layer="51"/>
<vertex x="-6.85" y="-0.95"/>
<vertex x="-6.85" y="-0.85"/>
<vertex x="-7.05" y="-0.55"/>
<vertex x="-7.25" y="-0.85"/>
<vertex x="-7.25" y="-0.95"/>
</polygon>
</package>
<package name="52559-2492">
<wire x1="-8.75" y1="-1" x2="-8.75" y2="1" width="0.2032" layer="21"/>
<wire x1="-8.75" y1="1" x2="-6.25" y2="1.75" width="0.2032" layer="51"/>
<wire x1="-6.25" y1="1.75" x2="6.25" y2="1.75" width="0.2032" layer="51"/>
<wire x1="6.25" y1="1.75" x2="8.75" y2="1" width="0.2032" layer="51"/>
<wire x1="8.75" y1="1" x2="8.75" y2="-1" width="0.2032" layer="21"/>
<wire x1="7.45" y1="-1" x2="-7.45" y2="-1" width="0.2032" layer="51"/>
<wire x1="-7.45" y1="-1" x2="-8.75" y2="-1" width="0.2032" layer="21"/>
<wire x1="-6.2" y1="-1" x2="-6.2" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="-6.2" y1="-0.25" x2="6.2" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="6.2" y1="-0.25" x2="6.2" y2="-1" width="0.2032" layer="21"/>
<wire x1="8.75" y1="-1" x2="7.45" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-5.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="3" x="-4.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="5" x="-3.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="M1" x="-6.75" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="M2" x="6.75" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="6" x="-3.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="4" x="-4.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="2" x="-5.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="M3" x="6.75" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="M4" x="-6.75" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="7" x="-2.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="8" x="-2.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="9" x="-1.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="10" x="-1.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="11" x="-0.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="12" x="-0.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="13" x="0.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="14" x="0.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="15" x="1.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="16" x="1.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="17" x="2.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="18" x="2.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="19" x="3.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="20" x="3.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="21" x="4.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="22" x="4.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="23" x="5.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="24" x="5.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<rectangle x1="-7" y1="-1.55" x2="-6.5" y2="-1.1" layer="51"/>
<rectangle x1="-5.9" y1="-1.55" x2="-5.6" y2="-1.1" layer="51"/>
<rectangle x1="6.5" y1="-1.55" x2="7" y2="-1.1" layer="51"/>
<rectangle x1="5.1" y1="-1.55" x2="5.4" y2="-1.1" layer="51"/>
<vertex x="-7.6" y="-0.95"/>
<vertex x="-7.6" y="-0.85"/>
<vertex x="-7.8" y="-0.55"/>
<vertex x="-8" y="-0.85"/>
<vertex x="-8" y="-0.95"/>
</polygon>
</package>
<package name="52559-2590">
<wire x1="-9" y1="-1" x2="-9" y2="1" width="0.2032" layer="21"/>
<wire x1="-9" y1="1" x2="-6.5" y2="1.75" width="0.2032" layer="51"/>
<wire x1="-6.5" y1="1.75" x2="6.5" y2="1.75" width="0.2032" layer="51"/>
<wire x1="6.5" y1="1.75" x2="9" y2="1" width="0.2032" layer="51"/>
<wire x1="9" y1="1" x2="9" y2="-1" width="0.2032" layer="21"/>
<wire x1="7.7" y1="-1" x2="-7.7" y2="-1" width="0.2032" layer="51"/>
<wire x1="-7.7" y1="-1" x2="-9" y2="-1" width="0.2032" layer="21"/>
<wire x1="-6.45" y1="-1" x2="-6.45" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="-6.45" y1="-0.25" x2="6.45" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="6.45" y1="-0.25" x2="6.45" y2="-1" width="0.2032" layer="21"/>
<wire x1="9" y1="-1" x2="7.7" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-6" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="3" x="-5" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="5" x="-4" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="M1" x="-7" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="M2" x="7" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="6" x="-3.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="4" x="-4.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="2" x="-5.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="M3" x="7" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="M4" x="-7" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="7" x="-3" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="8" x="-2.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="9" x="-2" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="10" x="-1.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="11" x="-1" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="12" x="-0.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="13" x="0" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="14" x="0.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="15" x="1" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="16" x="1.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="17" x="2" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="18" x="2.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="19" x="3" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="20" x="3.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="21" x="4" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="22" x="4.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="23" x="5" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="24" x="5.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="25" x="6" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<text x="-7.62" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-7.62" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-7.25" y1="-1.55" x2="-6.75" y2="-1.1" layer="51"/>
<rectangle x1="-6.15" y1="-1.55" x2="-5.85" y2="-1.1" layer="51"/>
<rectangle x1="6.75" y1="-1.55" x2="7.25" y2="-1.1" layer="51"/>
<rectangle x1="5.85" y1="-1.55" x2="6.15" y2="-1.1" layer="51"/>
<vertex x="-7.85" y="-0.95"/>
<vertex x="-7.85" y="-0.85"/>
<vertex x="-8.05" y="-0.55"/>
<vertex x="-8.25" y="-0.85"/>
<vertex x="-8.25" y="-0.95"/>
</polygon>
</package>
<package name="52559-2692">
<wire x1="-9.25" y1="-1" x2="-9.25" y2="1" width="0.2032" layer="21"/>
<wire x1="-9.25" y1="1" x2="-6.75" y2="1.75" width="0.2032" layer="51"/>
<wire x1="-6.75" y1="1.75" x2="6.75" y2="1.75" width="0.2032" layer="51"/>
<wire x1="6.75" y1="1.75" x2="9.25" y2="1" width="0.2032" layer="51"/>
<wire x1="9.25" y1="1" x2="9.25" y2="-1" width="0.2032" layer="21"/>
<wire x1="7.95" y1="-1" x2="-7.95" y2="-1" width="0.2032" layer="51"/>
<wire x1="-7.95" y1="-1" x2="-9.25" y2="-1" width="0.2032" layer="21"/>
<wire x1="-6.7" y1="-1" x2="-6.7" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="-6.7" y1="-0.25" x2="6.7" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="6.7" y1="-0.25" x2="6.7" y2="-1" width="0.2032" layer="21"/>
<wire x1="9.25" y1="-1" x2="7.95" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-6.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="3" x="-5.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="5" x="-4.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="M1" x="-7.25" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="M2" x="7.25" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="6" x="-3.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="4" x="-4.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="2" x="-5.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="M3" x="7.25" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="M4" x="-7.25" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="7" x="-3.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="8" x="-2.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="9" x="-2.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="10" x="-1.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="11" x="-1.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="12" x="-0.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="13" x="-0.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="14" x="0.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="15" x="0.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="16" x="1.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="17" x="1.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="18" x="2.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="19" x="2.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="20" x="3.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="21" x="3.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="22" x="4.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="23" x="4.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="24" x="5.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="25" x="5.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="26" x="6.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<rectangle x1="-7.5" y1="-1.55" x2="-7" y2="-1.1" layer="51"/>
<rectangle x1="-6.4" y1="-1.55" x2="-6.1" y2="-1.1" layer="51"/>
<rectangle x1="7" y1="-1.55" x2="7.5" y2="-1.1" layer="51"/>
<rectangle x1="5.6" y1="-1.55" x2="5.9" y2="-1.1" layer="51"/>
<vertex x="-8.1" y="-0.95"/>
<vertex x="-8.1" y="-0.85"/>
<vertex x="-8.3" y="-0.55"/>
<vertex x="-8.5" y="-0.85"/>
<vertex x="-8.5" y="-0.95"/>
</polygon>
</package>
<package name="52559-2892">
<wire x1="-9.75" y1="-1" x2="-9.75" y2="1" width="0.2032" layer="21"/>
<wire x1="-9.75" y1="1" x2="-7.25" y2="1.75" width="0.2032" layer="51"/>
<wire x1="-7.25" y1="1.75" x2="7.25" y2="1.75" width="0.2032" layer="51"/>
<wire x1="7.25" y1="1.75" x2="9.75" y2="1" width="0.2032" layer="51"/>
<wire x1="9.75" y1="1" x2="9.75" y2="-1" width="0.2032" layer="21"/>
<wire x1="8.45" y1="-1" x2="-8.45" y2="-1" width="0.2032" layer="51"/>
<wire x1="-8.45" y1="-1" x2="-9.75" y2="-1" width="0.2032" layer="21"/>
<wire x1="-7.2" y1="-1" x2="-7.2" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="-7.2" y1="-0.25" x2="7.2" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="7.2" y1="-0.25" x2="7.2" y2="-1" width="0.2032" layer="21"/>
<wire x1="9.75" y1="-1" x2="8.45" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-6.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="3" x="-5.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="5" x="-4.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="M1" x="-7.75" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="M2" x="7.75" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="6" x="-4.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="4" x="-5.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="2" x="-6.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="M3" x="7.75" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="M4" x="-7.75" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="7" x="-3.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="8" x="-3.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="9" x="-2.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="10" x="-2.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="11" x="-1.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="12" x="-1.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="13" x="-0.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="14" x="-0.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="15" x="0.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="16" x="0.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="17" x="1.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="18" x="1.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="19" x="2.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="20" x="2.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="21" x="3.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="22" x="3.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="23" x="4.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="24" x="4.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="25" x="5.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="26" x="5.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="27" x="6.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="28" x="6.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<rectangle x1="-8" y1="-1.55" x2="-7.5" y2="-1.1" layer="51"/>
<rectangle x1="-6.9" y1="-1.55" x2="-6.6" y2="-1.1" layer="51"/>
<rectangle x1="7.5" y1="-1.55" x2="8" y2="-1.1" layer="51"/>
<rectangle x1="6.1" y1="-1.55" x2="6.4" y2="-1.1" layer="51"/>
<vertex x="-8.6" y="-0.95"/>
<vertex x="-8.6" y="-0.85"/>
<vertex x="-8.8" y="-0.55"/>
<vertex x="-9" y="-0.85"/>
<vertex x="-9" y="-0.95"/>
</polygon>
</package>
<package name="52559-3092">
<wire x1="-10.25" y1="-1" x2="-10.25" y2="1" width="0.2032" layer="21"/>
<wire x1="-10.25" y1="1" x2="-7.75" y2="1.75" width="0.2032" layer="51"/>
<wire x1="-7.75" y1="1.75" x2="7.75" y2="1.75" width="0.2032" layer="51"/>
<wire x1="7.75" y1="1.75" x2="10.25" y2="1" width="0.2032" layer="51"/>
<wire x1="10.25" y1="1" x2="10.25" y2="-1" width="0.2032" layer="21"/>
<wire x1="8.95" y1="-1" x2="-8.95" y2="-1" width="0.2032" layer="51"/>
<wire x1="-8.95" y1="-1" x2="-10.25" y2="-1" width="0.2032" layer="21"/>
<wire x1="-7.7" y1="-1" x2="-7.7" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="-7.7" y1="-0.25" x2="7.7" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="7.7" y1="-0.25" x2="7.7" y2="-1" width="0.2032" layer="21"/>
<wire x1="10.25" y1="-1" x2="8.95" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-7.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="3" x="-6.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="5" x="-5.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="M1" x="-8.25" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="M2" x="8.25" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="6" x="-4.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="4" x="-5.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="2" x="-6.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="M3" x="8.25" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="M4" x="-8.25" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="7" x="-4.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="8" x="-3.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="9" x="-3.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="10" x="-2.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="11" x="-2.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="12" x="-1.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="13" x="-1.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="14" x="-0.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="15" x="-0.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="16" x="0.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="17" x="0.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="18" x="1.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="19" x="1.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="20" x="2.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="21" x="2.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="22" x="3.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="23" x="3.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="24" x="4.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="25" x="4.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="26" x="5.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="27" x="5.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="28" x="6.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="29" x="6.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="30" x="7.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<text x="-8.89" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-8.89" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-8.5" y1="-1.55" x2="-8" y2="-1.1" layer="51"/>
<rectangle x1="-7.4" y1="-1.55" x2="-7.1" y2="-1.1" layer="51"/>
<rectangle x1="8" y1="-1.55" x2="8.5" y2="-1.1" layer="51"/>
<rectangle x1="6.6" y1="-1.55" x2="6.9" y2="-1.1" layer="51"/>
<vertex x="-9.1" y="-0.95"/>
<vertex x="-9.1" y="-0.85"/>
<vertex x="-9.3" y="-0.55"/>
<vertex x="-9.5" y="-0.85"/>
<vertex x="-9.5" y="-0.95"/>
</polygon>
</package>
<package name="52559-3292">
<wire x1="-10.75" y1="-1" x2="-10.75" y2="1" width="0.2032" layer="21"/>
<wire x1="-10.75" y1="1" x2="-8.25" y2="1.75" width="0.2032" layer="51"/>
<wire x1="-8.25" y1="1.75" x2="8.25" y2="1.75" width="0.2032" layer="51"/>
<wire x1="8.25" y1="1.75" x2="10.75" y2="1" width="0.2032" layer="51"/>
<wire x1="10.75" y1="1" x2="10.75" y2="-1" width="0.2032" layer="21"/>
<wire x1="9.45" y1="-1" x2="-9.45" y2="-1" width="0.2032" layer="51"/>
<wire x1="-9.45" y1="-1" x2="-10.75" y2="-1" width="0.2032" layer="21"/>
<wire x1="-8.2" y1="-1" x2="-8.2" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="-8.2" y1="-0.25" x2="8.2" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="8.2" y1="-0.25" x2="8.2" y2="-1" width="0.2032" layer="21"/>
<wire x1="10.75" y1="-1" x2="9.45" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-7.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="3" x="-6.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="5" x="-5.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="M1" x="-8.75" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="M2" x="8.75" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="6" x="-5.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="4" x="-6.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="2" x="-7.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="M3" x="8.75" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="M4" x="-8.75" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="7" x="-4.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="8" x="-4.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="9" x="-3.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="10" x="-3.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="11" x="-2.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="12" x="-2.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="13" x="-1.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="14" x="-1.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="15" x="-0.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="16" x="-0.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="17" x="0.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="18" x="0.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="19" x="1.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="20" x="1.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="21" x="2.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="22" x="2.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="23" x="3.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="24" x="3.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="25" x="4.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="26" x="4.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="27" x="5.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="28" x="5.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="29" x="6.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="30" x="6.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="31" x="7.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="32" x="7.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<rectangle x1="-9" y1="-1.55" x2="-8.5" y2="-1.1" layer="51"/>
<rectangle x1="-7.9" y1="-1.55" x2="-7.6" y2="-1.1" layer="51"/>
<rectangle x1="8.5" y1="-1.55" x2="9" y2="-1.1" layer="51"/>
<rectangle x1="7.1" y1="-1.55" x2="7.4" y2="-1.1" layer="51"/>
<vertex x="-9.6" y="-0.95"/>
<vertex x="-9.6" y="-0.85"/>
<vertex x="-9.8" y="-0.55"/>
<vertex x="-10" y="-0.85"/>
<vertex x="-10" y="-0.95"/>
</polygon>
</package>
<package name="52559-3390">
<wire x1="-11" y1="-1" x2="-11" y2="1" width="0.2032" layer="21"/>
<wire x1="-11" y1="1" x2="-8.5" y2="1.75" width="0.2032" layer="51"/>
<wire x1="-8.5" y1="1.75" x2="8.75" y2="1.75" width="0.2032" layer="51"/>
<wire x1="8.75" y1="1.75" x2="11.25" y2="1" width="0.2032" layer="51"/>
<wire x1="11.25" y1="1" x2="11.25" y2="-1" width="0.2032" layer="21"/>
<wire x1="9.95" y1="-1" x2="-9.7" y2="-1" width="0.2032" layer="51"/>
<wire x1="-9.7" y1="-1" x2="-11" y2="-1" width="0.2032" layer="21"/>
<wire x1="-8.45" y1="-1" x2="-8.45" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="-8.45" y1="-0.25" x2="8.7" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="8.7" y1="-0.25" x2="8.7" y2="-1" width="0.2032" layer="21"/>
<wire x1="11.25" y1="-1" x2="9.95" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-8" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="3" x="-7" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="5" x="-6" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="M1" x="-9" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="M2" x="9.25" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="6" x="-5.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="4" x="-6.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="2" x="-7.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="M3" x="9.25" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="M4" x="-9" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="7" x="-5" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="8" x="-4.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="9" x="-4" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="10" x="-3.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="11" x="-3" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="12" x="-2.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="13" x="-2" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="14" x="-1.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="15" x="-1" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="16" x="-0.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="17" x="0" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="18" x="0.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="19" x="1" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="20" x="1.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="21" x="2" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="22" x="2.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="23" x="3" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="24" x="3.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="25" x="4" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="26" x="4.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="27" x="5" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="28" x="5.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="29" x="6" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="30" x="6.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="31" x="7" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="32" x="7.5" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="33" x="8" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<rectangle x1="-9.25" y1="-1.55" x2="-8.75" y2="-1.1" layer="51"/>
<rectangle x1="-8.15" y1="-1.55" x2="-7.85" y2="-1.1" layer="51"/>
<rectangle x1="-7.15" y1="-1.55" x2="-6.85" y2="-1.1" layer="51"/>
<rectangle x1="9" y1="-1.55" x2="9.5" y2="-1.1" layer="51"/>
<rectangle x1="6.85" y1="-1.55" x2="7.15" y2="-1.1" layer="51"/>
<rectangle x1="7.85" y1="-1.55" x2="8.15" y2="-1.1" layer="51"/>
<polygon width="0.1016" layer="21">
<vertex x="-9.85" y="-0.95"/>
<vertex x="-9.85" y="-0.85"/>
<vertex x="-10.05" y="-0.55"/>
<vertex x="-10.25" y="-0.85"/>
<vertex x="-10.25" y="-0.95"/>
</polygon>
</package>
<package name="52559-3692">
<description>&lt;b&gt;FFC/FPC&lt;/b&gt;-to-Board  0.50mm (.020") SMT, Vertical, ZIF Receptacle&lt;p&gt;
Source: http://www.molex.com/product/ffc/52559.html</description>
<wire x1="-11.75" y1="-1" x2="-11.75" y2="1" width="0.2032" layer="21"/>
<wire x1="-11.75" y1="1" x2="-9.25" y2="1.75" width="0.2032" layer="51"/>
<wire x1="-9.25" y1="1.75" x2="9.25" y2="1.75" width="0.2032" layer="51"/>
<wire x1="9.25" y1="1.75" x2="11.75" y2="1" width="0.2032" layer="51"/>
<wire x1="11.75" y1="1" x2="11.75" y2="-1" width="0.2032" layer="21"/>
<wire x1="10.45" y1="-1" x2="-10.45" y2="-1" width="0.2032" layer="51"/>
<wire x1="-10.45" y1="-1" x2="-11.75" y2="-1" width="0.2032" layer="21"/>
<wire x1="-9.2" y1="-1" x2="-9.2" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="-9.2" y1="-0.25" x2="9.2" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="9.2" y1="-0.25" x2="9.2" y2="-1" width="0.2032" layer="21"/>
<wire x1="11.75" y1="-1" x2="10.45" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-8.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="3" x="-7.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="5" x="-6.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="M1" x="-9.75" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="M2" x="9.75" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="6" x="-6.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="4" x="-7.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="2" x="-8.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="M3" x="9.75" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="M4" x="-9.75" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="7" x="-5.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="8" x="-5.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="9" x="-4.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="10" x="-4.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="11" x="-3.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="12" x="-3.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="13" x="-2.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="14" x="-2.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="15" x="-1.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="16" x="-1.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="17" x="-0.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="18" x="-0.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="19" x="0.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="20" x="0.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="21" x="1.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="22" x="1.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="23" x="2.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="24" x="2.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="25" x="3.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="26" x="3.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="27" x="4.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="28" x="4.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="29" x="5.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="30" x="5.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="31" x="6.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="32" x="6.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="33" x="7.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="34" x="7.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="35" x="8.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="36" x="8.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<text x="-10.16" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-10.16" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-10" y1="-1.55" x2="-9.5" y2="-1.1" layer="51"/>
<rectangle x1="-8.9" y1="-1.55" x2="-8.6" y2="-1.1" layer="51"/>
<rectangle x1="9.5" y1="-1.55" x2="10" y2="-1.1" layer="51"/>
<rectangle x1="-1.9" y1="-1.55" x2="-1.6" y2="-1.1" layer="51"/>
<rectangle x1="-0.9" y1="-1.55" x2="-0.6" y2="-1.1" layer="51"/>
<rectangle x1="0.1" y1="-1.55" x2="0.4" y2="-1.1" layer="51"/>
<rectangle x1="1.1" y1="-1.55" x2="1.4" y2="-1.1" layer="51"/>
<rectangle x1="8.1" y1="-1.55" x2="8.4" y2="-1.1" layer="51"/>
<vertex x="-10.6" y="-0.95"/>
<vertex x="-10.6" y="-0.85"/>
<vertex x="-10.8" y="-0.55"/>
<vertex x="-11" y="-0.85"/>
<vertex x="-11" y="-0.95"/>
</polygon>
</package>
<package name="52559-4092">
<wire x1="-12.75" y1="-1" x2="-12.75" y2="1" width="0.2032" layer="21"/>
<wire x1="-12.75" y1="1" x2="-10.25" y2="1.75" width="0.2032" layer="51"/>
<wire x1="-10.25" y1="1.75" x2="10.25" y2="1.75" width="0.2032" layer="51"/>
<wire x1="10.25" y1="1.75" x2="12.75" y2="1" width="0.2032" layer="51"/>
<wire x1="12.75" y1="1" x2="12.75" y2="-1" width="0.2032" layer="21"/>
<wire x1="11.45" y1="-1" x2="-11.45" y2="-1" width="0.2032" layer="51"/>
<wire x1="-11.45" y1="-1" x2="-12.75" y2="-1" width="0.2032" layer="21"/>
<wire x1="-10.2" y1="-1" x2="-10.2" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="-10.2" y1="-0.25" x2="10.2" y2="-0.25" width="0.2032" layer="21"/>
<wire x1="10.2" y1="-0.25" x2="10.2" y2="-1" width="0.2032" layer="21"/>
<wire x1="12.75" y1="-1" x2="11.45" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-9.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="3" x="-8.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="5" x="-7.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="M1" x="-10.75" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="M2" x="10.75" y="-1.4" dx="0.8" dy="1.5" layer="1"/>
<smd name="6" x="-7.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="4" x="-8.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="2" x="-9.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="M3" x="10.75" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="M4" x="-10.75" y="1.4" dx="0.8" dy="1.5" layer="1" rot="R180"/>
<smd name="7" x="-6.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="8" x="-6.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="9" x="-5.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="10" x="-5.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="11" x="-4.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="12" x="-4.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="13" x="-3.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="14" x="-3.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="15" x="-2.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="16" x="-2.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="17" x="-1.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="18" x="-1.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="19" x="-0.75" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="20" x="-0.25" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="21" x="0.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="22" x="0.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="23" x="1.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="24" x="1.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="25" x="2.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="26" x="2.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="27" x="3.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="28" x="3.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="29" x="4.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="30" x="4.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="31" x="5.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="32" x="5.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="33" x="6.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="34" x="6.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="35" x="7.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="36" x="7.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="37" x="8.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="38" x="8.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<smd name="39" x="9.25" y="-1.4" dx="0.6" dy="1.5" layer="1"/>
<smd name="40" x="9.75" y="1.4" dx="0.6" dy="1.5" layer="1" rot="R180"/>
<rectangle x1="-11" y1="-1.55" x2="-10.5" y2="-1.1" layer="51"/>
<rectangle x1="-9.9" y1="-1.55" x2="-9.6" y2="-1.1" layer="51"/>
<rectangle x1="10.5" y1="-1.55" x2="11" y2="-1.1" layer="51"/>
<rectangle x1="9.1" y1="-1.55" x2="9.4" y2="-1.1" layer="51"/>
<vertex x="-11.6" y="-0.95"/>
<vertex x="-11.6" y="-0.85"/>
<vertex x="-11.8" y="-0.55"/>
<vertex x="-12" y="-0.85"/>
<vertex x="-12" y="-0.95"/>
</polygon>
</package>
<package name="52745-0690">
<description>&lt;b&gt;FFC/FPC&lt;/b&gt;-to-Board  0.50mm (.020") SMT Top Contact&lt;p&gt;
Right Angle, ZIF, Style Receptacle 52745 / 52435&lt;br&gt;
Source: http://www.molex.com/product/ffc/52745.html</description>
<wire x1="-4.45" y1="-3" x2="-4.45" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="-4.45" y1="-3.5" x2="-4.35" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="-4.35" y1="-3.6" x2="4.35" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="4.35" y1="-3.6" x2="4.45" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="4.45" y1="-3.5" x2="4.45" y2="-3" width="0.2032" layer="21"/>
<wire x1="4.45" y1="-3" x2="-4.45" y2="-3" width="0.2032" layer="21"/>
<wire x1="-3.55" y1="1.9" x2="3.55" y2="1.9" width="0.2032" layer="51"/>
<wire x1="3.55" y1="1.9" x2="3.55" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="3.55" y1="-1.4" x2="-3.55" y2="-1.4" width="0.2032" layer="21"/>
<wire x1="-3.55" y1="-1.4" x2="-3.55" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-3" y1="-1.5" x2="-3" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="3" y1="-1.5" x2="3" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="-1.55" y1="-3.1" x2="-1.55" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="-1.55" y1="-3.5" x2="-1.3" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-1.3" y1="-3.25" x2="-1.3" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="1.3" y1="-3.1" x2="1.3" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="1.3" y1="-3.25" x2="1.55" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="1.55" y1="-3.5" x2="1.55" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="3.7" y1="1.95" x2="3.85" y2="1.95" width="0.1016" layer="51"/>
<wire x1="3.85" y1="1.95" x2="3.85" y2="1.65" width="0.1016" layer="51"/>
<wire x1="3.85" y1="1.65" x2="4.45" y2="1.65" width="0.1016" layer="51"/>
<wire x1="4.45" y1="1.65" x2="4.45" y2="1.45" width="0.1016" layer="51"/>
<wire x1="4.45" y1="1.45" x2="3.85" y2="1.45" width="0.1016" layer="51"/>
<wire x1="3.85" y1="1.45" x2="3.85" y2="0.95" width="0.1016" layer="51"/>
<wire x1="3.85" y1="0.95" x2="3.9" y2="0.9" width="0.1016" layer="51"/>
<wire x1="3.9" y1="0.9" x2="4.45" y2="0.9" width="0.1016" layer="51"/>
<wire x1="4.45" y1="0.9" x2="4.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="4.45" y1="0.7" x2="3.7" y2="0.7" width="0.1016" layer="51"/>
<wire x1="3.7" y1="0.7" x2="3.7" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-3.7" y1="1.95" x2="-3.85" y2="1.95" width="0.1016" layer="51"/>
<wire x1="-3.85" y1="1.95" x2="-3.85" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-3.85" y1="1.65" x2="-4.45" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-4.45" y1="1.65" x2="-4.45" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-4.45" y1="1.45" x2="-3.85" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-3.85" y1="1.45" x2="-3.85" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-3.85" y1="0.95" x2="-3.9" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-3.9" y1="0.9" x2="-4.45" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-4.45" y1="0.9" x2="-4.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-4.45" y1="0.7" x2="-3.7" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-3.7" y1="0.7" x2="-3.7" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-2.15" y1="-1.25" x2="-2.15" y2="1" width="0.2032" layer="21"/>
<wire x1="-2.15" y1="1" x2="-2" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="-2" y1="1" x2="-2" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="2" y1="-1.25" x2="2" y2="1" width="0.2032" layer="21"/>
<wire x1="2" y1="1" x2="2.15" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="2.15" y1="1" x2="2.15" y2="-1.25" width="0.2032" layer="21"/>
<smd name="1" x="-1.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="2" x="-0.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="3" x="-0.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="4" x="0.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="5" x="0.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="6" x="1.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<text x="-4.58" y="3.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-4.58" y="-5.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="3.75" y1="-0.2" x2="4.9" y2="2" layer="29" rot="R180"/>
<rectangle x1="2.5" y1="-1.05" x2="3.8" y2="2" layer="29" rot="R180"/>
<rectangle x1="2.7" y1="-0.05" x2="4.7" y2="1.85" layer="31" rot="R180"/>
<rectangle x1="-4.9" y1="-0.2" x2="-3.75" y2="2" layer="29"/>
<rectangle x1="-3.8" y1="-1.05" x2="-2.5" y2="2" layer="29"/>
<rectangle x1="-4.7" y1="-0.05" x2="-2.7" y2="1.85" layer="31"/>
<rectangle x1="-1.35" y1="2" x2="-1.15" y2="2.7" layer="51"/>
<rectangle x1="-0.85" y1="2" x2="-0.65" y2="2.7" layer="51"/>
<rectangle x1="-0.35" y1="2" x2="-0.15" y2="2.7" layer="51"/>
<rectangle x1="0.15" y1="2" x2="0.35" y2="2.7" layer="51"/>
<rectangle x1="0.65" y1="2" x2="0.85" y2="2.7" layer="51"/>
<rectangle x1="1.15" y1="2" x2="1.35" y2="2.7" layer="51"/>
<rectangle x1="-4.9" y1="-0.2" x2="-2.5" y2="2" layer="1"/>
<rectangle x1="-3.8" y1="-1.05" x2="-2.5" y2="-0.2" layer="1"/>
<rectangle x1="2.5" y1="-1.05" x2="3.8" y2="-0.2" layer="1"/>
<rectangle x1="2.5" y1="-0.2" x2="4.9" y2="2" layer="1"/>
<vertex x="-1.75" y="-1.25"/>
<vertex x="-1.75" y="-1.2"/>
<vertex x="-1.5" y="-0.85"/>
<vertex x="-1.25" y="-1.2"/>
<vertex x="-1.25" y="-1.25"/>
</polygon>
</package>
<package name="52745-0790">
<wire x1="-4.7" y1="-3" x2="-4.7" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="-4.7" y1="-3.5" x2="-4.6" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="-4.6" y1="-3.6" x2="4.6" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="4.6" y1="-3.6" x2="4.7" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="4.7" y1="-3.5" x2="4.7" y2="-3" width="0.2032" layer="21"/>
<wire x1="4.7" y1="-3" x2="-4.7" y2="-3" width="0.2032" layer="21"/>
<wire x1="-3.8" y1="1.9" x2="3.8" y2="1.9" width="0.2032" layer="51"/>
<wire x1="3.8" y1="1.9" x2="3.8" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="3.8" y1="-1.4" x2="-3.8" y2="-1.4" width="0.2032" layer="21"/>
<wire x1="-3.8" y1="-1.4" x2="-3.8" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-3.25" y1="-1.5" x2="-3.25" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="3.25" y1="-1.5" x2="3.25" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="-1.8" y1="-3.1" x2="-1.8" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="-1.8" y1="-3.5" x2="-1.55" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-1.55" y1="-3.25" x2="-1.55" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="1.55" y1="-3.1" x2="1.55" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="1.55" y1="-3.25" x2="1.8" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="1.8" y1="-3.5" x2="1.8" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="3.95" y1="1.95" x2="4.1" y2="1.95" width="0.1016" layer="51"/>
<wire x1="4.1" y1="1.95" x2="4.1" y2="1.65" width="0.1016" layer="51"/>
<wire x1="4.1" y1="1.65" x2="4.7" y2="1.65" width="0.1016" layer="51"/>
<wire x1="4.7" y1="1.65" x2="4.7" y2="1.45" width="0.1016" layer="51"/>
<wire x1="4.7" y1="1.45" x2="4.1" y2="1.45" width="0.1016" layer="51"/>
<wire x1="4.1" y1="1.45" x2="4.1" y2="0.95" width="0.1016" layer="51"/>
<wire x1="4.1" y1="0.95" x2="4.15" y2="0.9" width="0.1016" layer="51"/>
<wire x1="4.15" y1="0.9" x2="4.7" y2="0.9" width="0.1016" layer="51"/>
<wire x1="4.7" y1="0.9" x2="4.7" y2="0.7" width="0.1016" layer="51"/>
<wire x1="4.7" y1="0.7" x2="3.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="3.95" y1="0.7" x2="3.95" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-3.95" y1="1.95" x2="-4.1" y2="1.95" width="0.1016" layer="51"/>
<wire x1="-4.1" y1="1.95" x2="-4.1" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-4.1" y1="1.65" x2="-4.7" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-4.7" y1="1.65" x2="-4.7" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-4.7" y1="1.45" x2="-4.1" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-4.1" y1="1.45" x2="-4.1" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-4.1" y1="0.95" x2="-4.15" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-4.15" y1="0.9" x2="-4.7" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-4.7" y1="0.9" x2="-4.7" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-4.7" y1="0.7" x2="-3.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-3.95" y1="0.7" x2="-3.95" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-2.4" y1="-1.25" x2="-2.4" y2="1" width="0.2032" layer="21"/>
<wire x1="-2.4" y1="1" x2="-2.25" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="-2.25" y1="1" x2="-2.25" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="2.25" y1="-1.25" x2="2.25" y2="1" width="0.2032" layer="21"/>
<wire x1="2.25" y1="1" x2="2.4" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="2.4" y1="1" x2="2.4" y2="-1.25" width="0.2032" layer="21"/>
<smd name="1" x="-1.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="2" x="-1" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="3" x="-0.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="4" x="0" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="5" x="0.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="6" x="1" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="7" x="1.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<text x="-4.83" y="3.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-4.83" y="-5.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="4" y1="-0.2" x2="5.15" y2="2" layer="29" rot="R180"/>
<rectangle x1="2.75" y1="-1.05" x2="4.05" y2="2" layer="29" rot="R180"/>
<rectangle x1="2.95" y1="-0.05" x2="4.95" y2="1.85" layer="31" rot="R180"/>
<rectangle x1="-5.15" y1="-0.2" x2="-4" y2="2" layer="29"/>
<rectangle x1="-4.05" y1="-1.05" x2="-2.75" y2="2" layer="29"/>
<rectangle x1="-4.95" y1="-0.05" x2="-2.95" y2="1.85" layer="31"/>
<rectangle x1="-1.6" y1="2" x2="-1.4" y2="2.7" layer="51"/>
<rectangle x1="-1.1" y1="2" x2="-0.9" y2="2.7" layer="51"/>
<rectangle x1="-0.6" y1="2" x2="-0.4" y2="2.7" layer="51"/>
<rectangle x1="-0.1" y1="2" x2="0.1" y2="2.7" layer="51"/>
<rectangle x1="0.4" y1="2" x2="0.6" y2="2.7" layer="51"/>
<rectangle x1="0.9" y1="2" x2="1.1" y2="2.7" layer="51"/>
<rectangle x1="1.4" y1="2" x2="1.6" y2="2.7" layer="51"/>
<rectangle x1="-5.15" y1="-0.2" x2="-2.75" y2="2" layer="1"/>
<rectangle x1="-4.05" y1="-1.05" x2="-2.75" y2="-0.2" layer="1"/>
<rectangle x1="2.75" y1="-1.05" x2="4.05" y2="-0.2" layer="1"/>
<rectangle x1="2.75" y1="-0.2" x2="5.15" y2="2" layer="1"/>
<vertex x="-2" y="-1.25"/>
<vertex x="-2" y="-1.2"/>
<vertex x="-1.75" y="-0.85"/>
<vertex x="-1.5" y="-1.2"/>
<vertex x="-1.5" y="-1.25"/>
</polygon>
</package>
<package name="52745-0890">
<wire x1="-4.95" y1="-3" x2="-4.95" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="-4.95" y1="-3.5" x2="-4.85" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="-4.85" y1="-3.6" x2="4.85" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="4.85" y1="-3.6" x2="4.95" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="4.95" y1="-3.5" x2="4.95" y2="-3" width="0.2032" layer="21"/>
<wire x1="4.95" y1="-3" x2="-4.95" y2="-3" width="0.2032" layer="21"/>
<wire x1="-4.05" y1="1.9" x2="4.05" y2="1.9" width="0.2032" layer="51"/>
<wire x1="4.05" y1="1.9" x2="4.05" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="4.05" y1="-1.4" x2="-4.05" y2="-1.4" width="0.2032" layer="21"/>
<wire x1="-4.05" y1="-1.4" x2="-4.05" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-3.5" y1="-1.5" x2="-3.5" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="3.5" y1="-1.5" x2="3.5" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="-2.05" y1="-3.1" x2="-2.05" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="-2.05" y1="-3.5" x2="-1.8" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-1.8" y1="-3.25" x2="-1.8" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="1.8" y1="-3.1" x2="1.8" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="1.8" y1="-3.25" x2="2.05" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="2.05" y1="-3.5" x2="2.05" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="4.2" y1="1.95" x2="4.35" y2="1.95" width="0.1016" layer="51"/>
<wire x1="4.35" y1="1.95" x2="4.35" y2="1.65" width="0.1016" layer="51"/>
<wire x1="4.35" y1="1.65" x2="4.95" y2="1.65" width="0.1016" layer="51"/>
<wire x1="4.95" y1="1.65" x2="4.95" y2="1.45" width="0.1016" layer="51"/>
<wire x1="4.95" y1="1.45" x2="4.35" y2="1.45" width="0.1016" layer="51"/>
<wire x1="4.35" y1="1.45" x2="4.35" y2="0.95" width="0.1016" layer="51"/>
<wire x1="4.35" y1="0.95" x2="4.4" y2="0.9" width="0.1016" layer="51"/>
<wire x1="4.4" y1="0.9" x2="4.95" y2="0.9" width="0.1016" layer="51"/>
<wire x1="4.95" y1="0.9" x2="4.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="4.95" y1="0.7" x2="4.2" y2="0.7" width="0.1016" layer="51"/>
<wire x1="4.2" y1="0.7" x2="4.2" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-4.2" y1="1.95" x2="-4.35" y2="1.95" width="0.1016" layer="51"/>
<wire x1="-4.35" y1="1.95" x2="-4.35" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-4.35" y1="1.65" x2="-4.95" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-4.95" y1="1.65" x2="-4.95" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-4.95" y1="1.45" x2="-4.35" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-4.35" y1="1.45" x2="-4.35" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-4.35" y1="0.95" x2="-4.4" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-4.4" y1="0.9" x2="-4.95" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-4.95" y1="0.9" x2="-4.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-4.95" y1="0.7" x2="-4.2" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-4.2" y1="0.7" x2="-4.2" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-2.65" y1="-1.25" x2="-2.65" y2="1" width="0.2032" layer="21"/>
<wire x1="-2.65" y1="1" x2="-2.5" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="-2.5" y1="1" x2="-2.5" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="2.5" y1="-1.25" x2="2.5" y2="1" width="0.2032" layer="21"/>
<wire x1="2.5" y1="1" x2="2.65" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="2.65" y1="1" x2="2.65" y2="-1.25" width="0.2032" layer="21"/>
<smd name="1" x="-1.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="2" x="-1.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="3" x="-0.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="4" x="-0.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="5" x="0.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="6" x="0.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="7" x="1.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="8" x="1.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<text x="-5.08" y="3.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.08" y="-5.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="4.25" y1="-0.2" x2="5.4" y2="2" layer="29" rot="R180"/>
<rectangle x1="3" y1="-1.05" x2="4.3" y2="2" layer="29" rot="R180"/>
<rectangle x1="3.2" y1="-0.05" x2="5.2" y2="1.85" layer="31" rot="R180"/>
<rectangle x1="-5.4" y1="-0.2" x2="-4.25" y2="2" layer="29"/>
<rectangle x1="-4.3" y1="-1.05" x2="-3" y2="2" layer="29"/>
<rectangle x1="-5.2" y1="-0.05" x2="-3.2" y2="1.85" layer="31"/>
<rectangle x1="-1.85" y1="2" x2="-1.65" y2="2.7" layer="51"/>
<rectangle x1="1.65" y1="2" x2="1.85" y2="2.7" layer="51"/>
<rectangle x1="-5.4" y1="-0.2" x2="-3" y2="2" layer="1"/>
<rectangle x1="-4.3" y1="-1.05" x2="-3" y2="-0.2" layer="1"/>
<rectangle x1="3" y1="-1.05" x2="4.3" y2="-0.2" layer="1"/>
<rectangle x1="3" y1="-0.2" x2="5.4" y2="2" layer="1"/>
<vertex x="-2.25" y="-1.25"/>
<vertex x="-2.25" y="-1.2"/>
<vertex x="-2" y="-0.85"/>
</polygon>
</package>
<package name="52745-0990">
<wire x1="-5.2" y1="-3" x2="-5.2" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="-5.2" y1="-3.5" x2="-5.1" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="-5.1" y1="-3.6" x2="5.1" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="5.1" y1="-3.6" x2="5.2" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="5.2" y1="-3.5" x2="5.2" y2="-3" width="0.2032" layer="21"/>
<wire x1="5.2" y1="-3" x2="-5.2" y2="-3" width="0.2032" layer="21"/>
<wire x1="-4.3" y1="1.9" x2="4.3" y2="1.9" width="0.2032" layer="51"/>
<wire x1="4.3" y1="1.9" x2="4.3" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="4.3" y1="-1.4" x2="-4.3" y2="-1.4" width="0.2032" layer="21"/>
<wire x1="-4.3" y1="-1.4" x2="-4.3" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-3.75" y1="-1.5" x2="-3.75" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="3.75" y1="-1.5" x2="3.75" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="-2.3" y1="-3.1" x2="-2.3" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="-2.3" y1="-3.5" x2="-2.05" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-2.05" y1="-3.25" x2="-2.05" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="2.05" y1="-3.1" x2="2.05" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="2.05" y1="-3.25" x2="2.3" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="2.3" y1="-3.5" x2="2.3" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="4.45" y1="1.95" x2="4.6" y2="1.95" width="0.1016" layer="51"/>
<wire x1="4.6" y1="1.95" x2="4.6" y2="1.65" width="0.1016" layer="51"/>
<wire x1="4.6" y1="1.65" x2="5.2" y2="1.65" width="0.1016" layer="51"/>
<wire x1="5.2" y1="1.65" x2="5.2" y2="1.45" width="0.1016" layer="51"/>
<wire x1="5.2" y1="1.45" x2="4.6" y2="1.45" width="0.1016" layer="51"/>
<wire x1="4.6" y1="1.45" x2="4.6" y2="0.95" width="0.1016" layer="51"/>
<wire x1="4.6" y1="0.95" x2="4.65" y2="0.9" width="0.1016" layer="51"/>
<wire x1="4.65" y1="0.9" x2="5.2" y2="0.9" width="0.1016" layer="51"/>
<wire x1="5.2" y1="0.9" x2="5.2" y2="0.7" width="0.1016" layer="51"/>
<wire x1="5.2" y1="0.7" x2="4.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="4.45" y1="0.7" x2="4.45" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-4.45" y1="1.95" x2="-4.6" y2="1.95" width="0.1016" layer="51"/>
<wire x1="-4.6" y1="1.95" x2="-4.6" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-4.6" y1="1.65" x2="-5.2" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-5.2" y1="1.65" x2="-5.2" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-5.2" y1="1.45" x2="-4.6" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-4.6" y1="1.45" x2="-4.6" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-4.6" y1="0.95" x2="-4.65" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-4.65" y1="0.9" x2="-5.2" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-5.2" y1="0.9" x2="-5.2" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-5.2" y1="0.7" x2="-4.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-4.45" y1="0.7" x2="-4.45" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-2.9" y1="-1.25" x2="-2.9" y2="1" width="0.2032" layer="21"/>
<wire x1="-2.9" y1="1" x2="-2.75" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="-2.75" y1="1" x2="-2.75" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="2.75" y1="-1.25" x2="2.75" y2="1" width="0.2032" layer="21"/>
<wire x1="2.75" y1="1" x2="2.9" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="2.9" y1="1" x2="2.9" y2="-1.25" width="0.2032" layer="21"/>
<smd name="1" x="-2" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="2" x="-1.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="3" x="-1" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="4" x="-0.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="5" x="0" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="6" x="0.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="7" x="1" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="8" x="1.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="9" x="2" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<text x="-5.33" y="3.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.33" y="-5.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="4.5" y1="-0.2" x2="5.65" y2="2" layer="29" rot="R180"/>
<rectangle x1="3.25" y1="-1.05" x2="4.55" y2="2" layer="29" rot="R180"/>
<rectangle x1="3.45" y1="-0.05" x2="5.45" y2="1.85" layer="31" rot="R180"/>
<rectangle x1="-5.65" y1="-0.2" x2="-4.5" y2="2" layer="29"/>
<rectangle x1="-4.55" y1="-1.05" x2="-3.25" y2="2" layer="29"/>
<rectangle x1="-5.45" y1="-0.05" x2="-3.45" y2="1.85" layer="31"/>
<rectangle x1="-2.1" y1="2" x2="-1.9" y2="2.7" layer="51"/>
<rectangle x1="1.9" y1="2" x2="2.1" y2="2.7" layer="51"/>
<rectangle x1="-5.65" y1="-0.2" x2="-3.25" y2="2" layer="1"/>
<rectangle x1="-4.55" y1="-1.05" x2="-3.25" y2="-0.2" layer="1"/>
<rectangle x1="3.25" y1="-1.05" x2="4.55" y2="-0.2" layer="1"/>
<rectangle x1="3.25" y1="-0.2" x2="5.65" y2="2" layer="1"/>
<vertex x="-2.5" y="-1.25"/>
<vertex x="-2.5" y="-1.2"/>
<vertex x="-2.25" y="-0.85"/>
</polygon>
</package>
<package name="52745-1090">
<wire x1="-5.45" y1="-3" x2="-5.45" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="-5.45" y1="-3.5" x2="-5.35" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="-5.35" y1="-3.6" x2="5.35" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="5.35" y1="-3.6" x2="5.45" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="5.45" y1="-3.5" x2="5.45" y2="-3" width="0.2032" layer="21"/>
<wire x1="5.45" y1="-3" x2="-5.45" y2="-3" width="0.2032" layer="21"/>
<wire x1="-4.55" y1="1.9" x2="4.55" y2="1.9" width="0.2032" layer="51"/>
<wire x1="4.55" y1="1.9" x2="4.55" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="4.55" y1="-1.4" x2="-4.55" y2="-1.4" width="0.2032" layer="21"/>
<wire x1="-4.55" y1="-1.4" x2="-4.55" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-4" y1="-1.5" x2="-4" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="4" y1="-1.5" x2="4" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="-2.55" y1="-3.1" x2="-2.55" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="-2.55" y1="-3.5" x2="-2.3" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-2.3" y1="-3.25" x2="-2.3" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="2.3" y1="-3.1" x2="2.3" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="2.3" y1="-3.25" x2="2.55" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="2.55" y1="-3.5" x2="2.55" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="4.7" y1="1.95" x2="4.85" y2="1.95" width="0.1016" layer="51"/>
<wire x1="4.85" y1="1.95" x2="4.85" y2="1.65" width="0.1016" layer="51"/>
<wire x1="4.85" y1="1.65" x2="5.45" y2="1.65" width="0.1016" layer="51"/>
<wire x1="5.45" y1="1.65" x2="5.45" y2="1.45" width="0.1016" layer="51"/>
<wire x1="5.45" y1="1.45" x2="4.85" y2="1.45" width="0.1016" layer="51"/>
<wire x1="4.85" y1="1.45" x2="4.85" y2="0.95" width="0.1016" layer="51"/>
<wire x1="4.85" y1="0.95" x2="4.9" y2="0.9" width="0.1016" layer="51"/>
<wire x1="4.9" y1="0.9" x2="5.45" y2="0.9" width="0.1016" layer="51"/>
<wire x1="5.45" y1="0.9" x2="5.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="5.45" y1="0.7" x2="4.7" y2="0.7" width="0.1016" layer="51"/>
<wire x1="4.7" y1="0.7" x2="4.7" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-4.7" y1="1.95" x2="-4.85" y2="1.95" width="0.1016" layer="51"/>
<wire x1="-4.85" y1="1.95" x2="-4.85" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-4.85" y1="1.65" x2="-5.45" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-5.45" y1="1.65" x2="-5.45" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-5.45" y1="1.45" x2="-4.85" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-4.85" y1="1.45" x2="-4.85" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-4.85" y1="0.95" x2="-4.9" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-4.9" y1="0.9" x2="-5.45" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-5.45" y1="0.9" x2="-5.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-5.45" y1="0.7" x2="-4.7" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-4.7" y1="0.7" x2="-4.7" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-3.15" y1="-1.25" x2="-3.15" y2="1" width="0.2032" layer="21"/>
<wire x1="-3.15" y1="1" x2="-3" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="-3" y1="1" x2="-3" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="3" y1="-1.25" x2="3" y2="1" width="0.2032" layer="21"/>
<wire x1="3" y1="1" x2="3.15" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="3.15" y1="1" x2="3.15" y2="-1.25" width="0.2032" layer="21"/>
<smd name="1" x="-2.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="2" x="-1.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="3" x="-1.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="4" x="-0.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="5" x="-0.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="6" x="0.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="7" x="0.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="8" x="1.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="9" x="1.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="10" x="2.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<text x="-5.58" y="3.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.58" y="-5.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="4.75" y1="-0.2" x2="5.9" y2="2" layer="29" rot="R180"/>
<rectangle x1="3.5" y1="-1.05" x2="4.8" y2="2" layer="29" rot="R180"/>
<rectangle x1="3.7" y1="-0.05" x2="5.7" y2="1.85" layer="31" rot="R180"/>
<rectangle x1="-5.9" y1="-0.2" x2="-4.75" y2="2" layer="29"/>
<rectangle x1="-4.8" y1="-1.05" x2="-3.5" y2="2" layer="29"/>
<rectangle x1="-5.7" y1="-0.05" x2="-3.7" y2="1.85" layer="31"/>
<rectangle x1="-2.35" y1="2" x2="-2.15" y2="2.7" layer="51"/>
<rectangle x1="2.15" y1="2" x2="2.35" y2="2.7" layer="51"/>
<rectangle x1="-5.9" y1="-0.2" x2="-3.5" y2="2" layer="1"/>
<rectangle x1="-4.8" y1="-1.05" x2="-3.5" y2="-0.2" layer="1"/>
<rectangle x1="3.5" y1="-1.05" x2="4.8" y2="-0.2" layer="1"/>
<rectangle x1="3.5" y1="-0.2" x2="5.9" y2="2" layer="1"/>
<vertex x="-2.75" y="-1.25"/>
<vertex x="-2.75" y="-1.2"/>
<vertex x="-2.5" y="-0.85"/>
</polygon>
</package>
<package name="52745-1190">
<wire x1="-5.7" y1="-3" x2="-5.7" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="-5.7" y1="-3.5" x2="-5.6" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="-5.6" y1="-3.6" x2="5.6" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="5.6" y1="-3.6" x2="5.7" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="5.7" y1="-3.5" x2="5.7" y2="-3" width="0.2032" layer="21"/>
<wire x1="5.7" y1="-3" x2="-5.7" y2="-3" width="0.2032" layer="21"/>
<wire x1="-4.8" y1="1.9" x2="4.8" y2="1.9" width="0.2032" layer="51"/>
<wire x1="4.8" y1="1.9" x2="4.8" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="4.8" y1="-1.4" x2="-4.8" y2="-1.4" width="0.2032" layer="21"/>
<wire x1="-4.8" y1="-1.4" x2="-4.8" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-4.25" y1="-1.5" x2="-4.25" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="4.25" y1="-1.5" x2="4.25" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="-2.8" y1="-3.1" x2="-2.8" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="-2.8" y1="-3.5" x2="-2.55" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-2.55" y1="-3.25" x2="-2.55" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="2.55" y1="-3.1" x2="2.55" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="2.55" y1="-3.25" x2="2.8" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="2.8" y1="-3.5" x2="2.8" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="4.95" y1="1.95" x2="5.1" y2="1.95" width="0.1016" layer="51"/>
<wire x1="5.1" y1="1.95" x2="5.1" y2="1.65" width="0.1016" layer="51"/>
<wire x1="5.1" y1="1.65" x2="5.7" y2="1.65" width="0.1016" layer="51"/>
<wire x1="5.7" y1="1.65" x2="5.7" y2="1.45" width="0.1016" layer="51"/>
<wire x1="5.7" y1="1.45" x2="5.1" y2="1.45" width="0.1016" layer="51"/>
<wire x1="5.1" y1="1.45" x2="5.1" y2="0.95" width="0.1016" layer="51"/>
<wire x1="5.1" y1="0.95" x2="5.15" y2="0.9" width="0.1016" layer="51"/>
<wire x1="5.15" y1="0.9" x2="5.7" y2="0.9" width="0.1016" layer="51"/>
<wire x1="5.7" y1="0.9" x2="5.7" y2="0.7" width="0.1016" layer="51"/>
<wire x1="5.7" y1="0.7" x2="4.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="4.95" y1="0.7" x2="4.95" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-4.95" y1="1.95" x2="-5.1" y2="1.95" width="0.1016" layer="51"/>
<wire x1="-5.1" y1="1.95" x2="-5.1" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-5.1" y1="1.65" x2="-5.7" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-5.7" y1="1.65" x2="-5.7" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-5.7" y1="1.45" x2="-5.1" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-5.1" y1="1.45" x2="-5.1" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-5.1" y1="0.95" x2="-5.15" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-5.15" y1="0.9" x2="-5.7" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-5.7" y1="0.9" x2="-5.7" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-5.7" y1="0.7" x2="-4.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-4.95" y1="0.7" x2="-4.95" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-3.4" y1="-1.25" x2="-3.4" y2="1" width="0.2032" layer="21"/>
<wire x1="-3.4" y1="1" x2="-3.25" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="-3.25" y1="1" x2="-3.25" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="3.25" y1="-1.25" x2="3.25" y2="1" width="0.2032" layer="21"/>
<wire x1="3.25" y1="1" x2="3.4" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="3.4" y1="1" x2="3.4" y2="-1.25" width="0.2032" layer="21"/>
<smd name="1" x="-2.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="2" x="-2" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="3" x="-1.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="4" x="-1" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="5" x="-0.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="6" x="0" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="7" x="0.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="8" x="1" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="9" x="1.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="10" x="2" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="11" x="2.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<text x="-5.83" y="3.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.83" y="-5.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="5" y1="-0.2" x2="6.15" y2="2" layer="29" rot="R180"/>
<rectangle x1="3.75" y1="-1.05" x2="5.05" y2="2" layer="29" rot="R180"/>
<rectangle x1="3.95" y1="-0.05" x2="5.95" y2="1.85" layer="31" rot="R180"/>
<rectangle x1="-6.15" y1="-0.2" x2="-5" y2="2" layer="29"/>
<rectangle x1="-5.05" y1="-1.05" x2="-3.75" y2="2" layer="29"/>
<rectangle x1="-5.95" y1="-0.05" x2="-3.95" y2="1.85" layer="31"/>
<rectangle x1="-2.6" y1="2" x2="-2.4" y2="2.7" layer="51"/>
<rectangle x1="2.4" y1="2" x2="2.6" y2="2.7" layer="51"/>
<rectangle x1="-6.15" y1="-0.2" x2="-3.75" y2="2" layer="1"/>
<rectangle x1="-5.05" y1="-1.05" x2="-3.75" y2="-0.2" layer="1"/>
<rectangle x1="3.75" y1="-1.05" x2="5.05" y2="-0.2" layer="1"/>
<rectangle x1="3.75" y1="-0.2" x2="6.15" y2="2" layer="1"/>
<vertex x="-3" y="-1.25"/>
<vertex x="-3" y="-1.2"/>
<vertex x="-2.75" y="-0.85"/>
</polygon>
</package>
<package name="52745-1290">
<wire x1="-5.95" y1="-3" x2="-5.95" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="-5.95" y1="-3.5" x2="-5.85" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="-5.85" y1="-3.6" x2="5.85" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="5.85" y1="-3.6" x2="5.95" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="5.95" y1="-3.5" x2="5.95" y2="-3" width="0.2032" layer="21"/>
<wire x1="5.95" y1="-3" x2="-5.95" y2="-3" width="0.2032" layer="21"/>
<wire x1="-5.05" y1="1.9" x2="5.05" y2="1.9" width="0.2032" layer="51"/>
<wire x1="5.05" y1="1.9" x2="5.05" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="5.05" y1="-1.4" x2="-5.05" y2="-1.4" width="0.2032" layer="21"/>
<wire x1="-5.05" y1="-1.4" x2="-5.05" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-4.5" y1="-1.5" x2="-4.5" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="4.5" y1="-1.5" x2="4.5" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="-3.05" y1="-3.1" x2="-3.05" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="-3.05" y1="-3.5" x2="-2.8" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-2.8" y1="-3.25" x2="-2.8" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="2.8" y1="-3.1" x2="2.8" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="2.8" y1="-3.25" x2="3.05" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="3.05" y1="-3.5" x2="3.05" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="5.2" y1="1.95" x2="5.35" y2="1.95" width="0.1016" layer="51"/>
<wire x1="5.35" y1="1.95" x2="5.35" y2="1.65" width="0.1016" layer="51"/>
<wire x1="5.35" y1="1.65" x2="5.95" y2="1.65" width="0.1016" layer="51"/>
<wire x1="5.95" y1="1.65" x2="5.95" y2="1.45" width="0.1016" layer="51"/>
<wire x1="5.95" y1="1.45" x2="5.35" y2="1.45" width="0.1016" layer="51"/>
<wire x1="5.35" y1="1.45" x2="5.35" y2="0.95" width="0.1016" layer="51"/>
<wire x1="5.35" y1="0.95" x2="5.4" y2="0.9" width="0.1016" layer="51"/>
<wire x1="5.4" y1="0.9" x2="5.95" y2="0.9" width="0.1016" layer="51"/>
<wire x1="5.95" y1="0.9" x2="5.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="5.95" y1="0.7" x2="5.2" y2="0.7" width="0.1016" layer="51"/>
<wire x1="5.2" y1="0.7" x2="5.2" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-5.2" y1="1.95" x2="-5.35" y2="1.95" width="0.1016" layer="51"/>
<wire x1="-5.35" y1="1.95" x2="-5.35" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-5.35" y1="1.65" x2="-5.95" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-5.95" y1="1.65" x2="-5.95" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-5.95" y1="1.45" x2="-5.35" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-5.35" y1="1.45" x2="-5.35" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-5.35" y1="0.95" x2="-5.4" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-5.4" y1="0.9" x2="-5.95" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-5.95" y1="0.9" x2="-5.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-5.95" y1="0.7" x2="-5.2" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-5.2" y1="0.7" x2="-5.2" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-3.65" y1="-1.25" x2="-3.65" y2="1" width="0.2032" layer="21"/>
<wire x1="-3.65" y1="1" x2="-3.5" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="-3.5" y1="1" x2="-3.5" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="3.5" y1="-1.25" x2="3.5" y2="1" width="0.2032" layer="21"/>
<wire x1="3.5" y1="1" x2="3.65" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="3.65" y1="1" x2="3.65" y2="-1.25" width="0.2032" layer="21"/>
<smd name="1" x="-2.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="2" x="-2.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="3" x="-1.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="4" x="-1.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="5" x="-0.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="6" x="-0.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="7" x="0.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="8" x="0.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="9" x="1.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="10" x="1.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="11" x="2.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="12" x="2.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<text x="-6.08" y="3.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-6.08" y="-5.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="5.25" y1="-0.2" x2="6.4" y2="2" layer="29" rot="R180"/>
<rectangle x1="4" y1="-1.05" x2="5.3" y2="2" layer="29" rot="R180"/>
<rectangle x1="4.2" y1="-0.05" x2="6.2" y2="1.85" layer="31" rot="R180"/>
<rectangle x1="-6.4" y1="-0.2" x2="-5.25" y2="2" layer="29"/>
<rectangle x1="-5.3" y1="-1.05" x2="-4" y2="2" layer="29"/>
<rectangle x1="-6.2" y1="-0.05" x2="-4.2" y2="1.85" layer="31"/>
<rectangle x1="-2.85" y1="2" x2="-2.65" y2="2.7" layer="51"/>
<rectangle x1="2.65" y1="2" x2="2.85" y2="2.7" layer="51"/>
<rectangle x1="-6.4" y1="-0.2" x2="-4" y2="2" layer="1"/>
<rectangle x1="-5.3" y1="-1.05" x2="-4" y2="-0.2" layer="1"/>
<rectangle x1="4" y1="-0.2" x2="6.4" y2="2" layer="1"/>
<rectangle x1="4" y1="-1.05" x2="5.3" y2="-0.2" layer="1"/>
<vertex x="-3.25" y="-1.25"/>
<vertex x="-3.25" y="-1.2"/>
<vertex x="-3" y="-0.85"/>
</polygon>
</package>
<package name="52745-1390">
<wire x1="-6.2" y1="-3" x2="-6.2" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="-6.2" y1="-3.5" x2="-6.1" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="-6.1" y1="-3.6" x2="6.1" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="6.1" y1="-3.6" x2="6.2" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="6.2" y1="-3.5" x2="6.2" y2="-3" width="0.2032" layer="21"/>
<wire x1="6.2" y1="-3" x2="-6.2" y2="-3" width="0.2032" layer="21"/>
<wire x1="-5.3" y1="1.9" x2="5.3" y2="1.9" width="0.2032" layer="51"/>
<wire x1="5.3" y1="1.9" x2="5.3" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="5.3" y1="-1.4" x2="-5.3" y2="-1.4" width="0.2032" layer="21"/>
<wire x1="-5.3" y1="-1.4" x2="-5.3" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-4.75" y1="-1.5" x2="-4.75" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="4.75" y1="-1.5" x2="4.75" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-3.1" x2="-3.3" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="-3.3" y1="-3.5" x2="-3.05" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-3.05" y1="-3.25" x2="-3.05" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="3.05" y1="-3.1" x2="3.05" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="3.05" y1="-3.25" x2="3.3" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="3.3" y1="-3.5" x2="3.3" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="5.45" y1="1.95" x2="5.6" y2="1.95" width="0.1016" layer="51"/>
<wire x1="5.6" y1="1.95" x2="5.6" y2="1.65" width="0.1016" layer="51"/>
<wire x1="5.6" y1="1.65" x2="6.2" y2="1.65" width="0.1016" layer="51"/>
<wire x1="6.2" y1="1.65" x2="6.2" y2="1.45" width="0.1016" layer="51"/>
<wire x1="6.2" y1="1.45" x2="5.6" y2="1.45" width="0.1016" layer="51"/>
<wire x1="5.6" y1="1.45" x2="5.6" y2="0.95" width="0.1016" layer="51"/>
<wire x1="5.6" y1="0.95" x2="5.65" y2="0.9" width="0.1016" layer="51"/>
<wire x1="5.65" y1="0.9" x2="6.2" y2="0.9" width="0.1016" layer="51"/>
<wire x1="6.2" y1="0.9" x2="6.2" y2="0.7" width="0.1016" layer="51"/>
<wire x1="6.2" y1="0.7" x2="5.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="5.45" y1="0.7" x2="5.45" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-5.45" y1="1.95" x2="-5.6" y2="1.95" width="0.1016" layer="51"/>
<wire x1="-5.6" y1="1.95" x2="-5.6" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-5.6" y1="1.65" x2="-6.2" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-6.2" y1="1.65" x2="-6.2" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-6.2" y1="1.45" x2="-5.6" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-5.6" y1="1.45" x2="-5.6" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-5.6" y1="0.95" x2="-5.65" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-5.65" y1="0.9" x2="-6.2" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-6.2" y1="0.9" x2="-6.2" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-6.2" y1="0.7" x2="-5.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-5.45" y1="0.7" x2="-5.45" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-3.9" y1="-1.25" x2="-3.9" y2="1" width="0.2032" layer="21"/>
<wire x1="-3.9" y1="1" x2="-3.75" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="-3.75" y1="1" x2="-3.75" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="3.75" y1="-1.25" x2="3.75" y2="1" width="0.2032" layer="21"/>
<wire x1="3.75" y1="1" x2="3.9" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="3.9" y1="1" x2="3.9" y2="-1.25" width="0.2032" layer="21"/>
<smd name="1" x="-3" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="2" x="-2.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="3" x="-2" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="4" x="-1.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="5" x="-1" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="6" x="-0.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="7" x="0" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="8" x="0.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="9" x="1" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="10" x="1.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="11" x="2" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="12" x="2.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="13" x="3" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<text x="-6.33" y="3.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-6.33" y="-5.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="5.5" y1="-0.2" x2="6.65" y2="2" layer="29" rot="R180"/>
<rectangle x1="4.25" y1="-1.05" x2="5.55" y2="2" layer="29" rot="R180"/>
<rectangle x1="4.45" y1="-0.05" x2="6.45" y2="1.85" layer="31" rot="R180"/>
<rectangle x1="-6.65" y1="-0.2" x2="-5.5" y2="2" layer="29"/>
<rectangle x1="-5.55" y1="-1.05" x2="-4.25" y2="2" layer="29"/>
<rectangle x1="-6.45" y1="-0.05" x2="-4.45" y2="1.85" layer="31"/>
<rectangle x1="-3.1" y1="2" x2="-2.9" y2="2.7" layer="51"/>
<rectangle x1="2.9" y1="2" x2="3.1" y2="2.7" layer="51"/>
<rectangle x1="-6.65" y1="-0.2" x2="-4.25" y2="2" layer="1"/>
<rectangle x1="-5.55" y1="-1.05" x2="-4.25" y2="-0.2" layer="1"/>
<rectangle x1="4.25" y1="-0.2" x2="6.65" y2="2" layer="1"/>
<rectangle x1="4.25" y1="-1.05" x2="5.55" y2="-0.2" layer="1"/>
<vertex x="-3.5" y="-1.25"/>
<vertex x="-3.5" y="-1.2"/>
<vertex x="-3.25" y="-0.85"/>
</polygon>
</package>
<package name="52745-1490">
<wire x1="-6.45" y1="-3" x2="-6.45" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="-6.45" y1="-3.5" x2="-6.35" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="-6.35" y1="-3.6" x2="6.35" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-3.6" x2="6.45" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="6.45" y1="-3.5" x2="6.45" y2="-3" width="0.2032" layer="21"/>
<wire x1="6.45" y1="-3" x2="-6.45" y2="-3" width="0.2032" layer="21"/>
<wire x1="-5.55" y1="1.9" x2="5.55" y2="1.9" width="0.2032" layer="51"/>
<wire x1="5.55" y1="1.9" x2="5.55" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="5.55" y1="-1.4" x2="-5.55" y2="-1.4" width="0.2032" layer="21"/>
<wire x1="-5.55" y1="-1.4" x2="-5.55" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-5" y1="-1.5" x2="-5" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="5" y1="-1.5" x2="5" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="-3.55" y1="-3.1" x2="-3.55" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="-3.55" y1="-3.5" x2="-3.3" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-3.3" y1="-3.25" x2="-3.3" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="3.3" y1="-3.1" x2="3.3" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="3.3" y1="-3.25" x2="3.55" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="3.55" y1="-3.5" x2="3.55" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="5.7" y1="1.95" x2="5.85" y2="1.95" width="0.1016" layer="51"/>
<wire x1="5.85" y1="1.95" x2="5.85" y2="1.65" width="0.1016" layer="51"/>
<wire x1="5.85" y1="1.65" x2="6.45" y2="1.65" width="0.1016" layer="51"/>
<wire x1="6.45" y1="1.65" x2="6.45" y2="1.45" width="0.1016" layer="51"/>
<wire x1="6.45" y1="1.45" x2="5.85" y2="1.45" width="0.1016" layer="51"/>
<wire x1="5.85" y1="1.45" x2="5.85" y2="0.95" width="0.1016" layer="51"/>
<wire x1="5.85" y1="0.95" x2="5.9" y2="0.9" width="0.1016" layer="51"/>
<wire x1="5.9" y1="0.9" x2="6.45" y2="0.9" width="0.1016" layer="51"/>
<wire x1="6.45" y1="0.9" x2="6.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="6.45" y1="0.7" x2="5.7" y2="0.7" width="0.1016" layer="51"/>
<wire x1="5.7" y1="0.7" x2="5.7" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-5.7" y1="1.95" x2="-5.85" y2="1.95" width="0.1016" layer="51"/>
<wire x1="-5.85" y1="1.95" x2="-5.85" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-5.85" y1="1.65" x2="-6.45" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-6.45" y1="1.65" x2="-6.45" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-6.45" y1="1.45" x2="-5.85" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-5.85" y1="1.45" x2="-5.85" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-5.85" y1="0.95" x2="-5.9" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-5.9" y1="0.9" x2="-6.45" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-6.45" y1="0.9" x2="-6.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-6.45" y1="0.7" x2="-5.7" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-5.7" y1="0.7" x2="-5.7" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-4.15" y1="-1.25" x2="-4.15" y2="1" width="0.2032" layer="21"/>
<wire x1="-4.15" y1="1" x2="-4" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="-4" y1="1" x2="-4" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="4" y1="-1.25" x2="4" y2="1" width="0.2032" layer="21"/>
<wire x1="4" y1="1" x2="4.15" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="4.15" y1="1" x2="4.15" y2="-1.25" width="0.2032" layer="21"/>
<smd name="1" x="-3.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="2" x="-2.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="3" x="-2.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="4" x="-1.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="5" x="-1.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="6" x="-0.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="7" x="-0.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="8" x="0.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="9" x="0.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="10" x="1.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="11" x="1.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="12" x="2.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="13" x="2.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="14" x="3.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<text x="-6.58" y="3.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-6.58" y="-5.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="5.75" y1="-0.2" x2="6.9" y2="2" layer="29" rot="R180"/>
<rectangle x1="4.5" y1="-1.05" x2="5.8" y2="2" layer="29" rot="R180"/>
<rectangle x1="4.7" y1="-0.05" x2="6.7" y2="1.85" layer="31" rot="R180"/>
<rectangle x1="-6.9" y1="-0.2" x2="-5.75" y2="2" layer="29"/>
<rectangle x1="-5.8" y1="-1.05" x2="-4.5" y2="2" layer="29"/>
<rectangle x1="-6.7" y1="-0.05" x2="-4.7" y2="1.85" layer="31"/>
<rectangle x1="-3.35" y1="2" x2="-3.15" y2="2.7" layer="51"/>
<rectangle x1="3.15" y1="2" x2="3.35" y2="2.7" layer="51"/>
<rectangle x1="-6.9" y1="-0.2" x2="-4.5" y2="2" layer="1"/>
<rectangle x1="-5.8" y1="-1.05" x2="-4.5" y2="-0.2" layer="1"/>
<rectangle x1="4.5" y1="-0.2" x2="6.9" y2="2" layer="1"/>
<rectangle x1="4.5" y1="-1.05" x2="5.8" y2="-0.2" layer="1"/>
<vertex x="-3.75" y="-1.25"/>
<vertex x="-3.75" y="-1.2"/>
<vertex x="-3.5" y="-0.85"/>
</polygon>
</package>
<package name="52745-1590">
<wire x1="-6.7" y1="-3" x2="-6.7" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="-6.7" y1="-3.5" x2="-6.6" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="-6.6" y1="-3.6" x2="6.6" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="6.6" y1="-3.6" x2="6.7" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="6.7" y1="-3.5" x2="6.7" y2="-3" width="0.2032" layer="21"/>
<wire x1="6.7" y1="-3" x2="-6.7" y2="-3" width="0.2032" layer="21"/>
<wire x1="-5.8" y1="1.9" x2="5.8" y2="1.9" width="0.2032" layer="51"/>
<wire x1="5.8" y1="1.9" x2="5.8" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="5.8" y1="-1.4" x2="-5.8" y2="-1.4" width="0.2032" layer="21"/>
<wire x1="-5.8" y1="-1.4" x2="-5.8" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-5.25" y1="-1.5" x2="-5.25" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="5.25" y1="-1.5" x2="5.25" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="-3.8" y1="-3.1" x2="-3.8" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="-3.8" y1="-3.5" x2="-3.55" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-3.55" y1="-3.25" x2="-3.55" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="3.55" y1="-3.1" x2="3.55" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="3.55" y1="-3.25" x2="3.8" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="3.8" y1="-3.5" x2="3.8" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="5.95" y1="1.95" x2="6.1" y2="1.95" width="0.1016" layer="51"/>
<wire x1="6.1" y1="1.95" x2="6.1" y2="1.65" width="0.1016" layer="51"/>
<wire x1="6.1" y1="1.65" x2="6.7" y2="1.65" width="0.1016" layer="51"/>
<wire x1="6.7" y1="1.65" x2="6.7" y2="1.45" width="0.1016" layer="51"/>
<wire x1="6.7" y1="1.45" x2="6.1" y2="1.45" width="0.1016" layer="51"/>
<wire x1="6.1" y1="1.45" x2="6.1" y2="0.95" width="0.1016" layer="51"/>
<wire x1="6.1" y1="0.95" x2="6.15" y2="0.9" width="0.1016" layer="51"/>
<wire x1="6.15" y1="0.9" x2="6.7" y2="0.9" width="0.1016" layer="51"/>
<wire x1="6.7" y1="0.9" x2="6.7" y2="0.7" width="0.1016" layer="51"/>
<wire x1="6.7" y1="0.7" x2="5.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="5.95" y1="0.7" x2="5.95" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-5.95" y1="1.95" x2="-6.1" y2="1.95" width="0.1016" layer="51"/>
<wire x1="-6.1" y1="1.95" x2="-6.1" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-6.1" y1="1.65" x2="-6.7" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-6.7" y1="1.65" x2="-6.7" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-6.7" y1="1.45" x2="-6.1" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-6.1" y1="1.45" x2="-6.1" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-6.1" y1="0.95" x2="-6.15" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-6.15" y1="0.9" x2="-6.7" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-6.7" y1="0.9" x2="-6.7" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-6.7" y1="0.7" x2="-5.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-5.95" y1="0.7" x2="-5.95" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-4.4" y1="-1.25" x2="-4.4" y2="1" width="0.2032" layer="21"/>
<wire x1="-4.4" y1="1" x2="-4.25" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="-4.25" y1="1" x2="-4.25" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="4.25" y1="-1.25" x2="4.25" y2="1" width="0.2032" layer="21"/>
<wire x1="4.25" y1="1" x2="4.4" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="4.4" y1="1" x2="4.4" y2="-1.25" width="0.2032" layer="21"/>
<smd name="1" x="-3.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="2" x="-3" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="3" x="-2.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="4" x="-2" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="5" x="-1.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="6" x="-1" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="7" x="-0.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="8" x="0" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="9" x="0.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="10" x="1" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="11" x="1.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="12" x="2" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="13" x="2.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="14" x="3" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="15" x="3.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<text x="-6.83" y="3.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-6.83" y="-5.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="6" y1="-0.2" x2="7.15" y2="2" layer="29" rot="R180"/>
<rectangle x1="4.75" y1="-1.05" x2="6.05" y2="2" layer="29" rot="R180"/>
<rectangle x1="4.95" y1="-0.05" x2="6.95" y2="1.85" layer="31" rot="R180"/>
<rectangle x1="-7.15" y1="-0.2" x2="-6" y2="2" layer="29"/>
<rectangle x1="-6.05" y1="-1.05" x2="-4.75" y2="2" layer="29"/>
<rectangle x1="-6.95" y1="-0.05" x2="-4.95" y2="1.85" layer="31"/>
<rectangle x1="-3.6" y1="2" x2="-3.4" y2="2.7" layer="51"/>
<rectangle x1="3.4" y1="2" x2="3.6" y2="2.7" layer="51"/>
<rectangle x1="-7.15" y1="-0.2" x2="-4.75" y2="2" layer="1"/>
<rectangle x1="-6.05" y1="-1.05" x2="-4.75" y2="-0.2" layer="1"/>
<rectangle x1="4.75" y1="-0.2" x2="7.15" y2="2" layer="1"/>
<rectangle x1="4.75" y1="-1.05" x2="6.05" y2="-0.2" layer="1"/>
<polygon width="0.1016" layer="21">
<vertex x="-4" y="-1.25"/>
<vertex x="-4" y="-1.2"/>
<vertex x="-3.75" y="-0.85"/>
</polygon>
</package>
<package name="52745-1690">
<wire x1="-6.95" y1="-3" x2="-6.95" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="-6.95" y1="-3.5" x2="-6.85" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="-6.85" y1="-3.6" x2="6.85" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="6.85" y1="-3.6" x2="6.95" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="6.95" y1="-3.5" x2="6.95" y2="-3" width="0.2032" layer="21"/>
<wire x1="6.95" y1="-3" x2="-6.95" y2="-3" width="0.2032" layer="21"/>
<wire x1="-6.05" y1="1.9" x2="6.05" y2="1.9" width="0.2032" layer="51"/>
<wire x1="6.05" y1="1.9" x2="6.05" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="6.05" y1="-1.4" x2="-6.05" y2="-1.4" width="0.2032" layer="21"/>
<wire x1="-6.05" y1="-1.4" x2="-6.05" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-5.5" y1="-1.5" x2="-5.5" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="5.5" y1="-1.5" x2="5.5" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="-4.05" y1="-3.1" x2="-4.05" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="-4.05" y1="-3.5" x2="-3.8" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-3.8" y1="-3.25" x2="-3.8" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="3.8" y1="-3.1" x2="3.8" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="3.8" y1="-3.25" x2="4.05" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="4.05" y1="-3.5" x2="4.05" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="6.2" y1="1.95" x2="6.35" y2="1.95" width="0.1016" layer="51"/>
<wire x1="6.35" y1="1.95" x2="6.35" y2="1.65" width="0.1016" layer="51"/>
<wire x1="6.35" y1="1.65" x2="6.95" y2="1.65" width="0.1016" layer="51"/>
<wire x1="6.95" y1="1.65" x2="6.95" y2="1.45" width="0.1016" layer="51"/>
<wire x1="6.95" y1="1.45" x2="6.35" y2="1.45" width="0.1016" layer="51"/>
<wire x1="6.35" y1="1.45" x2="6.35" y2="0.95" width="0.1016" layer="51"/>
<wire x1="6.35" y1="0.95" x2="6.4" y2="0.9" width="0.1016" layer="51"/>
<wire x1="6.4" y1="0.9" x2="6.95" y2="0.9" width="0.1016" layer="51"/>
<wire x1="6.95" y1="0.9" x2="6.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="6.95" y1="0.7" x2="6.2" y2="0.7" width="0.1016" layer="51"/>
<wire x1="6.2" y1="0.7" x2="6.2" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-6.2" y1="1.95" x2="-6.35" y2="1.95" width="0.1016" layer="51"/>
<wire x1="-6.35" y1="1.95" x2="-6.35" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-6.35" y1="1.65" x2="-6.95" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-6.95" y1="1.65" x2="-6.95" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-6.95" y1="1.45" x2="-6.35" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-6.35" y1="1.45" x2="-6.35" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-6.35" y1="0.95" x2="-6.4" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-6.4" y1="0.9" x2="-6.95" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-6.95" y1="0.9" x2="-6.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-6.95" y1="0.7" x2="-6.2" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-6.2" y1="0.7" x2="-6.2" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-4.65" y1="-1.25" x2="-4.65" y2="1" width="0.2032" layer="21"/>
<wire x1="-4.65" y1="1" x2="-4.5" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="-4.5" y1="1" x2="-4.5" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="4.5" y1="-1.25" x2="4.5" y2="1" width="0.2032" layer="21"/>
<wire x1="4.5" y1="1" x2="4.65" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="4.65" y1="1" x2="4.65" y2="-1.25" width="0.2032" layer="21"/>
<smd name="1" x="-3.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="2" x="-3.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="3" x="-2.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="4" x="-2.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="5" x="-1.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="6" x="-1.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="7" x="-0.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="8" x="-0.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="9" x="0.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="10" x="0.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="11" x="1.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="12" x="1.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="13" x="2.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="14" x="2.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="15" x="3.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="16" x="3.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<text x="-7.08" y="3.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-7.08" y="-5.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="6.25" y1="-0.2" x2="7.4" y2="2" layer="29" rot="R180"/>
<rectangle x1="5" y1="-1.05" x2="6.3" y2="2" layer="29" rot="R180"/>
<rectangle x1="5.2" y1="-0.05" x2="7.2" y2="1.85" layer="31" rot="R180"/>
<rectangle x1="-7.4" y1="-0.2" x2="-6.25" y2="2" layer="29"/>
<rectangle x1="-6.3" y1="-1.05" x2="-5" y2="2" layer="29"/>
<rectangle x1="-7.2" y1="-0.05" x2="-5.2" y2="1.85" layer="31"/>
<rectangle x1="-3.85" y1="2" x2="-3.65" y2="2.7" layer="51"/>
<rectangle x1="3.65" y1="2" x2="3.85" y2="2.7" layer="51"/>
<rectangle x1="-7.4" y1="-0.2" x2="-5" y2="2" layer="1"/>
<rectangle x1="-6.3" y1="-1.05" x2="-5" y2="-0.2" layer="1"/>
<rectangle x1="5" y1="-0.2" x2="7.4" y2="2" layer="1"/>
<rectangle x1="5" y1="-1.05" x2="6.3" y2="-0.2" layer="1"/>
<vertex x="-4.25" y="-1.25"/>
<vertex x="-4.25" y="-1.2"/>
<vertex x="-4" y="-0.85"/>
</polygon>
</package>
<package name="52745-1790">
<wire x1="-7.2" y1="-3" x2="-7.2" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="-7.2" y1="-3.5" x2="-7.1" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="-7.1" y1="-3.6" x2="7.1" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="7.1" y1="-3.6" x2="7.2" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="7.2" y1="-3.5" x2="7.2" y2="-3" width="0.2032" layer="21"/>
<wire x1="7.2" y1="-3" x2="-7.2" y2="-3" width="0.2032" layer="21"/>
<wire x1="-6.3" y1="1.9" x2="6.3" y2="1.9" width="0.2032" layer="51"/>
<wire x1="6.3" y1="1.9" x2="6.3" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="6.3" y1="-1.4" x2="-6.3" y2="-1.4" width="0.2032" layer="21"/>
<wire x1="-6.3" y1="-1.4" x2="-6.3" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-5.75" y1="-1.5" x2="-5.75" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="5.75" y1="-1.5" x2="5.75" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="-4.3" y1="-3.1" x2="-4.3" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="-4.3" y1="-3.5" x2="-4.05" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-4.05" y1="-3.25" x2="-4.05" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="4.05" y1="-3.1" x2="4.05" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="4.05" y1="-3.25" x2="4.3" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="4.3" y1="-3.5" x2="4.3" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="6.45" y1="1.95" x2="6.6" y2="1.95" width="0.1016" layer="51"/>
<wire x1="6.6" y1="1.95" x2="6.6" y2="1.65" width="0.1016" layer="51"/>
<wire x1="6.6" y1="1.65" x2="7.2" y2="1.65" width="0.1016" layer="51"/>
<wire x1="7.2" y1="1.65" x2="7.2" y2="1.45" width="0.1016" layer="51"/>
<wire x1="7.2" y1="1.45" x2="6.6" y2="1.45" width="0.1016" layer="51"/>
<wire x1="6.6" y1="1.45" x2="6.6" y2="0.95" width="0.1016" layer="51"/>
<wire x1="6.6" y1="0.95" x2="6.65" y2="0.9" width="0.1016" layer="51"/>
<wire x1="6.65" y1="0.9" x2="7.2" y2="0.9" width="0.1016" layer="51"/>
<wire x1="7.2" y1="0.9" x2="7.2" y2="0.7" width="0.1016" layer="51"/>
<wire x1="7.2" y1="0.7" x2="6.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="6.45" y1="0.7" x2="6.45" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-6.45" y1="1.95" x2="-6.6" y2="1.95" width="0.1016" layer="51"/>
<wire x1="-6.6" y1="1.95" x2="-6.6" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-6.6" y1="1.65" x2="-7.2" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-7.2" y1="1.65" x2="-7.2" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-7.2" y1="1.45" x2="-6.6" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-6.6" y1="1.45" x2="-6.6" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-6.6" y1="0.95" x2="-6.65" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-6.65" y1="0.9" x2="-7.2" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-7.2" y1="0.9" x2="-7.2" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-7.2" y1="0.7" x2="-6.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-6.45" y1="0.7" x2="-6.45" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-4.9" y1="-1.25" x2="-4.9" y2="1" width="0.2032" layer="21"/>
<wire x1="-4.9" y1="1" x2="-4.75" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="-4.75" y1="1" x2="-4.75" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="4.75" y1="-1.25" x2="4.75" y2="1" width="0.2032" layer="21"/>
<wire x1="4.75" y1="1" x2="4.9" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="4.9" y1="1" x2="4.9" y2="-1.25" width="0.2032" layer="21"/>
<smd name="1" x="-4" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="2" x="-3.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="3" x="-3" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="4" x="-2.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="5" x="-2" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="6" x="-1.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="7" x="-1" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="8" x="-0.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="9" x="0" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="10" x="0.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="11" x="1" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="12" x="1.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="13" x="2" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="14" x="2.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="15" x="3" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="16" x="3.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="17" x="4" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<text x="-7.33" y="3.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-7.33" y="-5.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="6.5" y1="-0.2" x2="7.65" y2="2" layer="29" rot="R180"/>
<rectangle x1="5.25" y1="-1.05" x2="6.55" y2="2" layer="29" rot="R180"/>
<rectangle x1="5.45" y1="-0.05" x2="7.45" y2="1.85" layer="31" rot="R180"/>
<rectangle x1="-7.65" y1="-0.2" x2="-6.5" y2="2" layer="29"/>
<rectangle x1="-6.55" y1="-1.05" x2="-5.25" y2="2" layer="29"/>
<rectangle x1="-7.45" y1="-0.05" x2="-5.45" y2="1.85" layer="31"/>
<rectangle x1="-4.1" y1="2" x2="-3.9" y2="2.7" layer="51"/>
<rectangle x1="3.9" y1="2" x2="4.1" y2="2.7" layer="51"/>
<rectangle x1="-7.65" y1="-0.2" x2="-5.25" y2="2" layer="1"/>
<rectangle x1="-6.55" y1="-1.05" x2="-5.25" y2="-0.175" layer="1"/>
<rectangle x1="5.25" y1="-1.05" x2="6.55" y2="-0.175" layer="1"/>
<rectangle x1="5.25" y1="-0.2" x2="7.65" y2="2" layer="1"/>
<vertex x="-4.5" y="-1.25"/>
<vertex x="-4.5" y="-1.2"/>
<vertex x="-4.25" y="-0.85"/>
</polygon>
</package>
<package name="52745-1890">
<description>&lt;b&gt;FFC/FPC&lt;/b&gt;-to-Board  0.50mm (.020") SMT Top Contact&lt;p&gt;
Right Angle, ZIF, Style Receptacle 52745 / 52435&lt;br&gt;
Source: http://www.molex.com/product/ffc/52745.html</description>
<wire x1="-7.45" y1="-3" x2="-7.45" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="-7.45" y1="-3.5" x2="-7.35" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="-7.35" y1="-3.6" x2="7.35" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="7.35" y1="-3.6" x2="7.45" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="7.45" y1="-3.5" x2="7.45" y2="-3" width="0.2032" layer="21"/>
<wire x1="7.45" y1="-3" x2="-7.45" y2="-3" width="0.2032" layer="21"/>
<wire x1="-6.55" y1="1.9" x2="6.55" y2="1.9" width="0.2032" layer="51"/>
<wire x1="6.55" y1="1.9" x2="6.55" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="6.55" y1="-1.4" x2="-6.55" y2="-1.4" width="0.2032" layer="21"/>
<wire x1="-6.55" y1="-1.4" x2="-6.55" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-6" y1="-1.5" x2="-6" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="6" y1="-1.5" x2="6" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="-4.55" y1="-3.1" x2="-4.55" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="-4.55" y1="-3.5" x2="-4.3" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-4.3" y1="-3.25" x2="-4.3" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="4.3" y1="-3.1" x2="4.3" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="4.3" y1="-3.25" x2="4.55" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="4.55" y1="-3.5" x2="4.55" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="6.7" y1="1.95" x2="6.85" y2="1.95" width="0.1016" layer="51"/>
<wire x1="6.85" y1="1.95" x2="6.85" y2="1.65" width="0.1016" layer="51"/>
<wire x1="6.85" y1="1.65" x2="7.45" y2="1.65" width="0.1016" layer="51"/>
<wire x1="7.45" y1="1.65" x2="7.45" y2="1.45" width="0.1016" layer="51"/>
<wire x1="7.45" y1="1.45" x2="6.85" y2="1.45" width="0.1016" layer="51"/>
<wire x1="6.85" y1="1.45" x2="6.85" y2="0.95" width="0.1016" layer="51"/>
<wire x1="6.85" y1="0.95" x2="6.9" y2="0.9" width="0.1016" layer="51"/>
<wire x1="6.9" y1="0.9" x2="7.45" y2="0.9" width="0.1016" layer="51"/>
<wire x1="7.45" y1="0.9" x2="7.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="7.45" y1="0.7" x2="6.7" y2="0.7" width="0.1016" layer="51"/>
<wire x1="6.7" y1="0.7" x2="6.7" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-6.7" y1="1.95" x2="-6.85" y2="1.95" width="0.1016" layer="51"/>
<wire x1="-6.85" y1="1.95" x2="-6.85" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-6.85" y1="1.65" x2="-7.45" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-7.45" y1="1.65" x2="-7.45" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-7.45" y1="1.45" x2="-6.85" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-6.85" y1="1.45" x2="-6.85" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-6.85" y1="0.95" x2="-6.9" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-6.9" y1="0.9" x2="-7.45" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-7.45" y1="0.9" x2="-7.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-7.45" y1="0.7" x2="-6.7" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-6.7" y1="0.7" x2="-6.7" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-5.15" y1="-1.25" x2="-5.15" y2="1" width="0.2032" layer="21"/>
<wire x1="-5.15" y1="1" x2="-5" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="-5" y1="1" x2="-5" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="5" y1="-1.25" x2="5" y2="1" width="0.2032" layer="21"/>
<wire x1="5" y1="1" x2="5.15" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="5.15" y1="1" x2="5.15" y2="-1.25" width="0.2032" layer="21"/>
<smd name="1" x="-4.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="2" x="-3.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="3" x="-3.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="4" x="-2.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="5" x="-2.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="6" x="-1.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="7" x="-1.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="8" x="-0.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="9" x="-0.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="10" x="0.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="11" x="0.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="12" x="1.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="13" x="1.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="14" x="2.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="15" x="2.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="16" x="3.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="17" x="3.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="18" x="4.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<text x="-7.58" y="3.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-7.58" y="-5.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="6.75" y1="-0.2" x2="7.9" y2="2" layer="29" rot="R180"/>
<rectangle x1="5.5" y1="-1.05" x2="6.8" y2="2" layer="29" rot="R180"/>
<rectangle x1="5.7" y1="-0.05" x2="7.7" y2="1.85" layer="31" rot="R180"/>
<rectangle x1="-7.9" y1="-0.2" x2="-6.75" y2="2" layer="29"/>
<rectangle x1="-6.8" y1="-1.05" x2="-5.5" y2="2" layer="29"/>
<rectangle x1="-7.7" y1="-0.05" x2="-5.7" y2="1.85" layer="31"/>
<rectangle x1="-4.35" y1="2" x2="-4.15" y2="2.7" layer="51"/>
<rectangle x1="-1.35" y1="2" x2="-1.15" y2="2.7" layer="51"/>
<rectangle x1="-0.85" y1="2" x2="-0.65" y2="2.7" layer="51"/>
<rectangle x1="-0.35" y1="2" x2="-0.15" y2="2.7" layer="51"/>
<rectangle x1="0.15" y1="2" x2="0.35" y2="2.7" layer="51"/>
<rectangle x1="0.65" y1="2" x2="0.85" y2="2.7" layer="51"/>
<rectangle x1="1.15" y1="2" x2="1.35" y2="2.7" layer="51"/>
<rectangle x1="4.15" y1="2" x2="4.35" y2="2.7" layer="51"/>
<rectangle x1="-7.9" y1="-0.2" x2="-5.5" y2="2" layer="1"/>
<rectangle x1="-6.8" y1="-1.05" x2="-5.5" y2="-0.2" layer="1"/>
<rectangle x1="5.5" y1="-1.05" x2="6.8" y2="-0.2" layer="1"/>
<rectangle x1="5.5" y1="-0.2" x2="7.9" y2="2" layer="1"/>
<vertex x="-4.75" y="-1.25"/>
<vertex x="-4.75" y="-1.2"/>
<vertex x="-4.5" y="-0.85"/>
</polygon>
</package>
<package name="52745-1990">
<wire x1="-7.7" y1="-3" x2="-7.7" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="-7.7" y1="-3.5" x2="-7.6" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="-7.6" y1="-3.6" x2="7.6" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="7.6" y1="-3.6" x2="7.7" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="7.7" y1="-3.5" x2="7.7" y2="-3" width="0.2032" layer="21"/>
<wire x1="7.7" y1="-3" x2="-7.7" y2="-3" width="0.2032" layer="21"/>
<wire x1="-6.8" y1="1.9" x2="6.8" y2="1.9" width="0.2032" layer="51"/>
<wire x1="6.8" y1="1.9" x2="6.8" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="6.8" y1="-1.4" x2="-6.8" y2="-1.4" width="0.2032" layer="21"/>
<wire x1="-6.8" y1="-1.4" x2="-6.8" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-6.25" y1="-1.5" x2="-6.25" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="6.25" y1="-1.5" x2="6.25" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="-4.8" y1="-3.1" x2="-4.8" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="-4.8" y1="-3.5" x2="-4.55" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-4.55" y1="-3.25" x2="-4.55" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="4.55" y1="-3.1" x2="4.55" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="4.55" y1="-3.25" x2="4.8" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="4.8" y1="-3.5" x2="4.8" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="6.95" y1="1.95" x2="7.1" y2="1.95" width="0.1016" layer="51"/>
<wire x1="7.1" y1="1.95" x2="7.1" y2="1.65" width="0.1016" layer="51"/>
<wire x1="7.1" y1="1.65" x2="7.7" y2="1.65" width="0.1016" layer="51"/>
<wire x1="7.7" y1="1.65" x2="7.7" y2="1.45" width="0.1016" layer="51"/>
<wire x1="7.7" y1="1.45" x2="7.1" y2="1.45" width="0.1016" layer="51"/>
<wire x1="7.1" y1="1.45" x2="7.1" y2="0.95" width="0.1016" layer="51"/>
<wire x1="7.1" y1="0.95" x2="7.15" y2="0.9" width="0.1016" layer="51"/>
<wire x1="7.15" y1="0.9" x2="7.7" y2="0.9" width="0.1016" layer="51"/>
<wire x1="7.7" y1="0.9" x2="7.7" y2="0.7" width="0.1016" layer="51"/>
<wire x1="7.7" y1="0.7" x2="6.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="6.95" y1="0.7" x2="6.95" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-6.95" y1="1.95" x2="-7.1" y2="1.95" width="0.1016" layer="51"/>
<wire x1="-7.1" y1="1.95" x2="-7.1" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-7.1" y1="1.65" x2="-7.7" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-7.7" y1="1.65" x2="-7.7" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-7.7" y1="1.45" x2="-7.1" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-7.1" y1="1.45" x2="-7.1" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-7.1" y1="0.95" x2="-7.15" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-7.15" y1="0.9" x2="-7.7" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-7.7" y1="0.9" x2="-7.7" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-7.7" y1="0.7" x2="-6.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-6.95" y1="0.7" x2="-6.95" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-5.4" y1="-1.25" x2="-5.4" y2="1" width="0.2032" layer="21"/>
<wire x1="-5.4" y1="1" x2="-5.25" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="-5.25" y1="1" x2="-5.25" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="5.25" y1="-1.25" x2="5.25" y2="1" width="0.2032" layer="21"/>
<wire x1="5.25" y1="1" x2="5.4" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="5.4" y1="1" x2="5.4" y2="-1.25" width="0.2032" layer="21"/>
<smd name="1" x="-4.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="2" x="-4" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="3" x="-3.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="4" x="-3" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="5" x="-2.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="6" x="-2" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="7" x="-1.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="8" x="-1" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="9" x="-0.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="10" x="0" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="11" x="0.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="12" x="1" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="13" x="1.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="14" x="2" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="15" x="2.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="16" x="3" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="17" x="3.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="18" x="4" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="19" x="4.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<text x="-7.83" y="3.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-7.83" y="-5.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="7" y1="-0.2" x2="8.15" y2="2" layer="29" rot="R180"/>
<rectangle x1="5.75" y1="-1.05" x2="7.05" y2="2" layer="29" rot="R180"/>
<rectangle x1="5.95" y1="-0.05" x2="7.95" y2="1.85" layer="31" rot="R180"/>
<rectangle x1="-8.15" y1="-0.2" x2="-7" y2="2" layer="29"/>
<rectangle x1="-7.05" y1="-1.05" x2="-5.75" y2="2" layer="29"/>
<rectangle x1="-7.95" y1="-0.05" x2="-5.95" y2="1.85" layer="31"/>
<rectangle x1="-4.6" y1="2" x2="-4.4" y2="2.7" layer="51"/>
<rectangle x1="-1.6" y1="2" x2="-1.4" y2="2.7" layer="51"/>
<rectangle x1="-1.1" y1="2" x2="-0.9" y2="2.7" layer="51"/>
<rectangle x1="-0.6" y1="2" x2="-0.4" y2="2.7" layer="51"/>
<rectangle x1="-0.1" y1="2" x2="0.1" y2="2.7" layer="51"/>
<rectangle x1="0.4" y1="2" x2="0.6" y2="2.7" layer="51"/>
<rectangle x1="0.9" y1="2" x2="1.1" y2="2.7" layer="51"/>
<rectangle x1="1.4" y1="2" x2="1.6" y2="2.7" layer="51"/>
<rectangle x1="4.4" y1="2" x2="4.6" y2="2.7" layer="51"/>
<rectangle x1="-8.15" y1="-0.2" x2="-5.75" y2="2" layer="1"/>
<rectangle x1="-7.05" y1="-1.05" x2="-5.75" y2="-0.2" layer="1"/>
<rectangle x1="5.75" y1="-1.05" x2="7.05" y2="-0.2" layer="1"/>
<rectangle x1="5.75" y1="-0.2" x2="8.15" y2="2" layer="1"/>
<vertex x="-5" y="-1.25"/>
<vertex x="-5" y="-1.2"/>
<vertex x="-4.75" y="-0.85"/>
</polygon>
</package>
<package name="52745-2090">
<wire x1="-7.95" y1="-3" x2="-7.95" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="-7.95" y1="-3.5" x2="-7.85" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="-7.85" y1="-3.6" x2="7.85" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="7.85" y1="-3.6" x2="7.95" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="7.95" y1="-3.5" x2="7.95" y2="-3" width="0.2032" layer="21"/>
<wire x1="7.95" y1="-3" x2="-7.95" y2="-3" width="0.2032" layer="21"/>
<wire x1="-7.05" y1="1.9" x2="7.05" y2="1.9" width="0.2032" layer="51"/>
<wire x1="7.05" y1="1.9" x2="7.05" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="7.05" y1="-1.4" x2="-7.05" y2="-1.4" width="0.2032" layer="21"/>
<wire x1="-7.05" y1="-1.4" x2="-7.05" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-6.5" y1="-1.5" x2="-6.5" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="6.5" y1="-1.5" x2="6.5" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="-5.05" y1="-3.1" x2="-5.05" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="-5.05" y1="-3.5" x2="-4.8" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-4.8" y1="-3.25" x2="-4.8" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="4.8" y1="-3.1" x2="4.8" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="4.8" y1="-3.25" x2="5.05" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="5.05" y1="-3.5" x2="5.05" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="7.2" y1="1.95" x2="7.35" y2="1.95" width="0.1016" layer="51"/>
<wire x1="7.35" y1="1.95" x2="7.35" y2="1.65" width="0.1016" layer="51"/>
<wire x1="7.35" y1="1.65" x2="7.95" y2="1.65" width="0.1016" layer="51"/>
<wire x1="7.95" y1="1.65" x2="7.95" y2="1.45" width="0.1016" layer="51"/>
<wire x1="7.95" y1="1.45" x2="7.35" y2="1.45" width="0.1016" layer="51"/>
<wire x1="7.35" y1="1.45" x2="7.35" y2="0.95" width="0.1016" layer="51"/>
<wire x1="7.35" y1="0.95" x2="7.4" y2="0.9" width="0.1016" layer="51"/>
<wire x1="7.4" y1="0.9" x2="7.95" y2="0.9" width="0.1016" layer="51"/>
<wire x1="7.95" y1="0.9" x2="7.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="7.95" y1="0.7" x2="7.2" y2="0.7" width="0.1016" layer="51"/>
<wire x1="7.2" y1="0.7" x2="7.2" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-7.2" y1="1.95" x2="-7.35" y2="1.95" width="0.1016" layer="51"/>
<wire x1="-7.35" y1="1.95" x2="-7.35" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-7.35" y1="1.65" x2="-7.95" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-7.95" y1="1.65" x2="-7.95" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-7.95" y1="1.45" x2="-7.35" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-7.35" y1="1.45" x2="-7.35" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-7.35" y1="0.95" x2="-7.4" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-7.4" y1="0.9" x2="-7.95" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-7.95" y1="0.9" x2="-7.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-7.95" y1="0.7" x2="-7.2" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-7.2" y1="0.7" x2="-7.2" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-5.65" y1="-1.25" x2="-5.65" y2="1" width="0.2032" layer="21"/>
<wire x1="-5.65" y1="1" x2="-5.5" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="-5.5" y1="1" x2="-5.5" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="5.5" y1="-1.25" x2="5.5" y2="1" width="0.2032" layer="21"/>
<wire x1="5.5" y1="1" x2="5.65" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="5.65" y1="1" x2="5.65" y2="-1.25" width="0.2032" layer="21"/>
<smd name="1" x="-4.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="2" x="-4.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="3" x="-3.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="4" x="-3.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="5" x="-2.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="6" x="-2.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="7" x="-1.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="8" x="-1.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="9" x="-0.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="10" x="-0.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="11" x="0.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="12" x="0.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="13" x="1.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="14" x="1.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="15" x="2.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="16" x="2.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="17" x="3.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="18" x="3.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="19" x="4.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="20" x="4.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<text x="-8.08" y="3.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-8.08" y="-5.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="7.25" y1="-0.2" x2="8.4" y2="2" layer="29" rot="R180"/>
<rectangle x1="6" y1="-1.05" x2="7.3" y2="2" layer="29" rot="R180"/>
<rectangle x1="6.2" y1="-0.05" x2="8.2" y2="1.85" layer="31" rot="R180"/>
<rectangle x1="-8.4" y1="-0.2" x2="-7.25" y2="2" layer="29"/>
<rectangle x1="-7.3" y1="-1.05" x2="-6" y2="2" layer="29"/>
<rectangle x1="-8.2" y1="-0.05" x2="-6.2" y2="1.85" layer="31"/>
<rectangle x1="-4.85" y1="2" x2="-4.65" y2="2.7" layer="51"/>
<rectangle x1="-1.85" y1="2" x2="-1.65" y2="2.7" layer="51"/>
<rectangle x1="1.65" y1="2" x2="1.85" y2="2.7" layer="51"/>
<rectangle x1="4.65" y1="2" x2="4.85" y2="2.7" layer="51"/>
<rectangle x1="-8.4" y1="-0.2" x2="-6" y2="2" layer="1"/>
<rectangle x1="-7.3" y1="-1.05" x2="-6" y2="-0.2" layer="1"/>
<rectangle x1="6" y1="-1.05" x2="7.3" y2="-0.2" layer="1"/>
<rectangle x1="6" y1="-0.2" x2="8.4" y2="2" layer="1"/>
<vertex x="-5.25" y="-1.25"/>
<vertex x="-5.25" y="-1.2"/>
<vertex x="-5" y="-0.85"/>
</polygon>
</package>
<package name="52745-2190">
<wire x1="-8.2" y1="-3" x2="-8.2" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="-8.2" y1="-3.5" x2="-8.1" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="-8.1" y1="-3.6" x2="8.1" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="8.1" y1="-3.6" x2="8.2" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="8.2" y1="-3.5" x2="8.2" y2="-3" width="0.2032" layer="21"/>
<wire x1="8.2" y1="-3" x2="-8.2" y2="-3" width="0.2032" layer="21"/>
<wire x1="-7.3" y1="1.9" x2="7.3" y2="1.9" width="0.2032" layer="51"/>
<wire x1="7.3" y1="1.9" x2="7.3" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="7.3" y1="-1.4" x2="-7.3" y2="-1.4" width="0.2032" layer="21"/>
<wire x1="-7.3" y1="-1.4" x2="-7.3" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-6.75" y1="-1.5" x2="-6.75" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="6.75" y1="-1.5" x2="6.75" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="-5.3" y1="-3.1" x2="-5.3" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="-5.3" y1="-3.5" x2="-5.05" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-5.05" y1="-3.25" x2="-5.05" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="5.05" y1="-3.1" x2="5.05" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="5.05" y1="-3.25" x2="5.3" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="5.3" y1="-3.5" x2="5.3" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="7.45" y1="1.95" x2="7.6" y2="1.95" width="0.1016" layer="51"/>
<wire x1="7.6" y1="1.95" x2="7.6" y2="1.65" width="0.1016" layer="51"/>
<wire x1="7.6" y1="1.65" x2="8.2" y2="1.65" width="0.1016" layer="51"/>
<wire x1="8.2" y1="1.65" x2="8.2" y2="1.45" width="0.1016" layer="51"/>
<wire x1="8.2" y1="1.45" x2="7.6" y2="1.45" width="0.1016" layer="51"/>
<wire x1="7.6" y1="1.45" x2="7.6" y2="0.95" width="0.1016" layer="51"/>
<wire x1="7.6" y1="0.95" x2="7.65" y2="0.9" width="0.1016" layer="51"/>
<wire x1="7.65" y1="0.9" x2="8.2" y2="0.9" width="0.1016" layer="51"/>
<wire x1="8.2" y1="0.9" x2="8.2" y2="0.7" width="0.1016" layer="51"/>
<wire x1="8.2" y1="0.7" x2="7.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="7.45" y1="0.7" x2="7.45" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-7.45" y1="1.95" x2="-7.6" y2="1.95" width="0.1016" layer="51"/>
<wire x1="-7.6" y1="1.95" x2="-7.6" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-7.6" y1="1.65" x2="-8.2" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-8.2" y1="1.65" x2="-8.2" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-8.2" y1="1.45" x2="-7.6" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-7.6" y1="1.45" x2="-7.6" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-7.6" y1="0.95" x2="-7.65" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-7.65" y1="0.9" x2="-8.2" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-8.2" y1="0.9" x2="-8.2" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-8.2" y1="0.7" x2="-7.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-7.45" y1="0.7" x2="-7.45" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-5.9" y1="-1.25" x2="-5.9" y2="1" width="0.2032" layer="21"/>
<wire x1="-5.9" y1="1" x2="-5.75" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="-5.75" y1="1" x2="-5.75" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="5.75" y1="-1.25" x2="5.75" y2="1" width="0.2032" layer="21"/>
<wire x1="5.75" y1="1" x2="5.9" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="5.9" y1="1" x2="5.9" y2="-1.25" width="0.2032" layer="21"/>
<smd name="1" x="-5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="2" x="-4.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="3" x="-4" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="4" x="-3.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="5" x="-3" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="6" x="-2.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="7" x="-2" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="8" x="-1.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="9" x="-1" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="10" x="-0.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="11" x="0" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="12" x="0.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="13" x="1" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="14" x="1.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="15" x="2" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="16" x="2.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="17" x="3" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="18" x="3.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="19" x="4" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="20" x="4.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="21" x="5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<text x="-8.33" y="3.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-8.33" y="-5.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="7.5" y1="-0.2" x2="8.65" y2="2" layer="29" rot="R180"/>
<rectangle x1="6.25" y1="-1.05" x2="7.55" y2="2" layer="29" rot="R180"/>
<rectangle x1="6.45" y1="-0.05" x2="8.45" y2="1.85" layer="31" rot="R180"/>
<rectangle x1="-8.65" y1="-0.2" x2="-7.5" y2="2" layer="29"/>
<rectangle x1="-7.55" y1="-1.05" x2="-6.25" y2="2" layer="29"/>
<rectangle x1="-8.45" y1="-0.05" x2="-6.45" y2="1.85" layer="31"/>
<rectangle x1="-5.1" y1="2" x2="-4.9" y2="2.7" layer="51"/>
<rectangle x1="-2.1" y1="2" x2="-1.9" y2="2.7" layer="51"/>
<rectangle x1="1.9" y1="2" x2="2.1" y2="2.7" layer="51"/>
<rectangle x1="4.9" y1="2" x2="5.1" y2="2.7" layer="51"/>
<rectangle x1="-8.65" y1="-0.2" x2="-6.25" y2="2" layer="1"/>
<rectangle x1="-7.55" y1="-1.05" x2="-6.25" y2="-0.2" layer="1"/>
<rectangle x1="6.25" y1="-1.05" x2="7.55" y2="-0.2" layer="1"/>
<rectangle x1="6.25" y1="-0.2" x2="8.65" y2="2" layer="1"/>
<vertex x="-5.5" y="-1.25"/>
<vertex x="-5.5" y="-1.2"/>
<vertex x="-5.25" y="-0.85"/>
</polygon>
</package>
<package name="52745-2290">
<wire x1="-8.45" y1="-3" x2="-8.45" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="-8.45" y1="-3.5" x2="-8.35" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="-8.35" y1="-3.6" x2="8.35" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="8.35" y1="-3.6" x2="8.45" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="8.45" y1="-3.5" x2="8.45" y2="-3" width="0.2032" layer="21"/>
<wire x1="8.45" y1="-3" x2="-8.45" y2="-3" width="0.2032" layer="21"/>
<wire x1="-7.55" y1="1.9" x2="7.55" y2="1.9" width="0.2032" layer="51"/>
<wire x1="7.55" y1="1.9" x2="7.55" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="7.55" y1="-1.4" x2="-7.55" y2="-1.4" width="0.2032" layer="21"/>
<wire x1="-7.55" y1="-1.4" x2="-7.55" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-7" y1="-1.5" x2="-7" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="7" y1="-1.5" x2="7" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="-5.55" y1="-3.1" x2="-5.55" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="-5.55" y1="-3.5" x2="-5.3" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-5.3" y1="-3.25" x2="-5.3" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="5.3" y1="-3.1" x2="5.3" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="5.3" y1="-3.25" x2="5.55" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="5.55" y1="-3.5" x2="5.55" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="7.7" y1="1.95" x2="7.85" y2="1.95" width="0.1016" layer="51"/>
<wire x1="7.85" y1="1.95" x2="7.85" y2="1.65" width="0.1016" layer="51"/>
<wire x1="7.85" y1="1.65" x2="8.45" y2="1.65" width="0.1016" layer="51"/>
<wire x1="8.45" y1="1.65" x2="8.45" y2="1.45" width="0.1016" layer="51"/>
<wire x1="8.45" y1="1.45" x2="7.85" y2="1.45" width="0.1016" layer="51"/>
<wire x1="7.85" y1="1.45" x2="7.85" y2="0.95" width="0.1016" layer="51"/>
<wire x1="7.85" y1="0.95" x2="7.9" y2="0.9" width="0.1016" layer="51"/>
<wire x1="7.9" y1="0.9" x2="8.45" y2="0.9" width="0.1016" layer="51"/>
<wire x1="8.45" y1="0.9" x2="8.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="8.45" y1="0.7" x2="7.7" y2="0.7" width="0.1016" layer="51"/>
<wire x1="7.7" y1="0.7" x2="7.7" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-7.7" y1="1.95" x2="-7.85" y2="1.95" width="0.1016" layer="51"/>
<wire x1="-7.85" y1="1.95" x2="-7.85" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-7.85" y1="1.65" x2="-8.45" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-8.45" y1="1.65" x2="-8.45" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-8.45" y1="1.45" x2="-7.85" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-7.85" y1="1.45" x2="-7.85" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-7.85" y1="0.95" x2="-7.9" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-7.9" y1="0.9" x2="-8.45" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-8.45" y1="0.9" x2="-8.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-8.45" y1="0.7" x2="-7.7" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-7.7" y1="0.7" x2="-7.7" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-6.15" y1="-1.25" x2="-6.15" y2="1" width="0.2032" layer="21"/>
<wire x1="-6.15" y1="1" x2="-6" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="-6" y1="1" x2="-6" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="6" y1="-1.25" x2="6" y2="1" width="0.2032" layer="21"/>
<wire x1="6" y1="1" x2="6.15" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="6.15" y1="1" x2="6.15" y2="-1.25" width="0.2032" layer="21"/>
<smd name="1" x="-5.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="2" x="-4.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="3" x="-4.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="4" x="-3.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="5" x="-3.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="6" x="-2.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="7" x="-2.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="8" x="-1.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="9" x="-1.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="10" x="-0.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="11" x="-0.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="12" x="0.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="13" x="0.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="14" x="1.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="15" x="1.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="16" x="2.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="17" x="2.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="18" x="3.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="19" x="3.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="20" x="4.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="21" x="4.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="22" x="5.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<text x="-8.58" y="3.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-8.58" y="-5.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="7.75" y1="-0.2" x2="8.9" y2="2" layer="29" rot="R180"/>
<rectangle x1="6.5" y1="-1.05" x2="7.8" y2="2" layer="29" rot="R180"/>
<rectangle x1="6.7" y1="-0.05" x2="8.7" y2="1.85" layer="31" rot="R180"/>
<rectangle x1="-8.9" y1="-0.2" x2="-7.75" y2="2" layer="29"/>
<rectangle x1="-7.8" y1="-1.05" x2="-6.5" y2="2" layer="29"/>
<rectangle x1="-8.7" y1="-0.05" x2="-6.7" y2="1.85" layer="31"/>
<rectangle x1="-5.35" y1="2" x2="-5.15" y2="2.7" layer="51"/>
<rectangle x1="-2.35" y1="2" x2="-2.15" y2="2.7" layer="51"/>
<rectangle x1="2.15" y1="2" x2="2.35" y2="2.7" layer="51"/>
<rectangle x1="5.15" y1="2" x2="5.35" y2="2.7" layer="51"/>
<rectangle x1="-8.9" y1="-0.2" x2="-6.5" y2="2" layer="1"/>
<rectangle x1="-7.8" y1="-1.05" x2="-6.5" y2="-0.2" layer="1"/>
<rectangle x1="6.5" y1="-1.05" x2="7.8" y2="-0.2" layer="1"/>
<rectangle x1="6.5" y1="-0.2" x2="8.9" y2="2" layer="1"/>
<vertex x="-5.75" y="-1.25"/>
<vertex x="-5.75" y="-1.2"/>
<vertex x="-5.5" y="-0.85"/>
</polygon>
</package>
<package name="52745-2390">
<wire x1="-8.7" y1="-3" x2="-8.7" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="-8.7" y1="-3.5" x2="-8.6" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="-8.6" y1="-3.6" x2="8.6" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="8.6" y1="-3.6" x2="8.7" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="8.7" y1="-3.5" x2="8.7" y2="-3" width="0.2032" layer="21"/>
<wire x1="8.7" y1="-3" x2="-8.7" y2="-3" width="0.2032" layer="21"/>
<wire x1="-7.8" y1="1.9" x2="7.8" y2="1.9" width="0.2032" layer="51"/>
<wire x1="7.8" y1="1.9" x2="7.8" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="7.8" y1="-1.4" x2="-7.8" y2="-1.4" width="0.2032" layer="21"/>
<wire x1="-7.8" y1="-1.4" x2="-7.8" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-7.25" y1="-1.5" x2="-7.25" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="7.25" y1="-1.5" x2="7.25" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="-5.8" y1="-3.1" x2="-5.8" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="-5.8" y1="-3.5" x2="-5.55" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-5.55" y1="-3.25" x2="-5.55" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="5.55" y1="-3.1" x2="5.55" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="5.55" y1="-3.25" x2="5.8" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="5.8" y1="-3.5" x2="5.8" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="7.95" y1="1.95" x2="8.1" y2="1.95" width="0.1016" layer="51"/>
<wire x1="8.1" y1="1.95" x2="8.1" y2="1.65" width="0.1016" layer="51"/>
<wire x1="8.1" y1="1.65" x2="8.7" y2="1.65" width="0.1016" layer="51"/>
<wire x1="8.7" y1="1.65" x2="8.7" y2="1.45" width="0.1016" layer="51"/>
<wire x1="8.7" y1="1.45" x2="8.1" y2="1.45" width="0.1016" layer="51"/>
<wire x1="8.1" y1="1.45" x2="8.1" y2="0.95" width="0.1016" layer="51"/>
<wire x1="8.1" y1="0.95" x2="8.15" y2="0.9" width="0.1016" layer="51"/>
<wire x1="8.15" y1="0.9" x2="8.7" y2="0.9" width="0.1016" layer="51"/>
<wire x1="8.7" y1="0.9" x2="8.7" y2="0.7" width="0.1016" layer="51"/>
<wire x1="8.7" y1="0.7" x2="7.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="7.95" y1="0.7" x2="7.95" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-7.95" y1="1.95" x2="-8.1" y2="1.95" width="0.1016" layer="51"/>
<wire x1="-8.1" y1="1.95" x2="-8.1" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-8.1" y1="1.65" x2="-8.7" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-8.7" y1="1.65" x2="-8.7" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-8.7" y1="1.45" x2="-8.1" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-8.1" y1="1.45" x2="-8.1" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-8.1" y1="0.95" x2="-8.15" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-8.15" y1="0.9" x2="-8.7" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-8.7" y1="0.9" x2="-8.7" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-8.7" y1="0.7" x2="-7.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-7.95" y1="0.7" x2="-7.95" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-6.4" y1="-1.25" x2="-6.4" y2="1" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="1" x2="-6.25" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="-6.25" y1="1" x2="-6.25" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="6.25" y1="-1.25" x2="6.25" y2="1" width="0.2032" layer="21"/>
<wire x1="6.25" y1="1" x2="6.4" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="6.4" y1="1" x2="6.4" y2="-1.25" width="0.2032" layer="21"/>
<smd name="1" x="-5.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="2" x="-5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="3" x="-4.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="4" x="-4" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="5" x="-3.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="6" x="-3" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="7" x="-2.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="8" x="-2" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="9" x="-1.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="10" x="-1" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="11" x="-0.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="12" x="0" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="13" x="0.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="14" x="1" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="15" x="1.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="16" x="2" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="17" x="2.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="18" x="3" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="19" x="3.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="20" x="4" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="21" x="4.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="22" x="5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="23" x="5.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<text x="-8.83" y="3.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-8.83" y="-5.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="8" y1="-0.2" x2="9.15" y2="2" layer="29" rot="R180"/>
<rectangle x1="6.75" y1="-1.05" x2="8.05" y2="2" layer="29" rot="R180"/>
<rectangle x1="6.95" y1="-0.05" x2="8.95" y2="1.85" layer="31" rot="R180"/>
<rectangle x1="-9.15" y1="-0.2" x2="-8" y2="2" layer="29"/>
<rectangle x1="-8.05" y1="-1.05" x2="-6.75" y2="2" layer="29"/>
<rectangle x1="-8.95" y1="-0.05" x2="-6.95" y2="1.85" layer="31"/>
<rectangle x1="-5.6" y1="2" x2="-5.4" y2="2.7" layer="51"/>
<rectangle x1="-2.6" y1="2" x2="-2.4" y2="2.7" layer="51"/>
<rectangle x1="2.4" y1="2" x2="2.6" y2="2.7" layer="51"/>
<rectangle x1="5.4" y1="2" x2="5.6" y2="2.7" layer="51"/>
<rectangle x1="-9.15" y1="-0.2" x2="-6.75" y2="2" layer="1"/>
<rectangle x1="-8.05" y1="-1.05" x2="-6.75" y2="-0.2" layer="1"/>
<rectangle x1="6.75" y1="-1.05" x2="8.05" y2="-0.2" layer="1"/>
<rectangle x1="6.75" y1="-0.2" x2="9.15" y2="2" layer="1"/>
<vertex x="-6" y="-1.25"/>
<vertex x="-6" y="-1.2"/>
<vertex x="-5.75" y="-0.85"/>
</polygon>
</package>
<package name="52745-2490">
<wire x1="-8.95" y1="-3" x2="-8.95" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="-8.95" y1="-3.5" x2="-8.85" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="-8.85" y1="-3.6" x2="8.85" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="8.85" y1="-3.6" x2="8.95" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="8.95" y1="-3.5" x2="8.95" y2="-3" width="0.2032" layer="21"/>
<wire x1="8.95" y1="-3" x2="-8.95" y2="-3" width="0.2032" layer="21"/>
<wire x1="-8.05" y1="1.9" x2="8.05" y2="1.9" width="0.2032" layer="51"/>
<wire x1="8.05" y1="1.9" x2="8.05" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="8.05" y1="-1.4" x2="-8.05" y2="-1.4" width="0.2032" layer="21"/>
<wire x1="-8.05" y1="-1.4" x2="-8.05" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-7.5" y1="-1.5" x2="-7.5" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="7.5" y1="-1.5" x2="7.5" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="-6.05" y1="-3.1" x2="-6.05" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="-6.05" y1="-3.5" x2="-5.8" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-5.8" y1="-3.25" x2="-5.8" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="5.8" y1="-3.1" x2="5.8" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="5.8" y1="-3.25" x2="6.05" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="6.05" y1="-3.5" x2="6.05" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="8.2" y1="1.95" x2="8.35" y2="1.95" width="0.1016" layer="51"/>
<wire x1="8.35" y1="1.95" x2="8.35" y2="1.65" width="0.1016" layer="51"/>
<wire x1="8.35" y1="1.65" x2="8.95" y2="1.65" width="0.1016" layer="51"/>
<wire x1="8.95" y1="1.65" x2="8.95" y2="1.45" width="0.1016" layer="51"/>
<wire x1="8.95" y1="1.45" x2="8.35" y2="1.45" width="0.1016" layer="51"/>
<wire x1="8.35" y1="1.45" x2="8.35" y2="0.95" width="0.1016" layer="51"/>
<wire x1="8.35" y1="0.95" x2="8.4" y2="0.9" width="0.1016" layer="51"/>
<wire x1="8.4" y1="0.9" x2="8.95" y2="0.9" width="0.1016" layer="51"/>
<wire x1="8.95" y1="0.9" x2="8.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="8.95" y1="0.7" x2="8.2" y2="0.7" width="0.1016" layer="51"/>
<wire x1="8.2" y1="0.7" x2="8.2" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-8.2" y1="1.95" x2="-8.35" y2="1.95" width="0.1016" layer="51"/>
<wire x1="-8.35" y1="1.95" x2="-8.35" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-8.35" y1="1.65" x2="-8.95" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-8.95" y1="1.65" x2="-8.95" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-8.95" y1="1.45" x2="-8.35" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-8.35" y1="1.45" x2="-8.35" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-8.35" y1="0.95" x2="-8.4" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-8.4" y1="0.9" x2="-8.95" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-8.95" y1="0.9" x2="-8.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-8.95" y1="0.7" x2="-8.2" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-8.2" y1="0.7" x2="-8.2" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-6.65" y1="-1.25" x2="-6.65" y2="1" width="0.2032" layer="21"/>
<wire x1="-6.65" y1="1" x2="-6.5" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="-6.5" y1="1" x2="-6.5" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="6.5" y1="-1.25" x2="6.5" y2="1" width="0.2032" layer="21"/>
<wire x1="6.5" y1="1" x2="6.65" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="6.65" y1="1" x2="6.65" y2="-1.25" width="0.2032" layer="21"/>
<smd name="1" x="-5.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="2" x="-5.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="3" x="-4.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="4" x="-4.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="5" x="-3.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="6" x="-3.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="7" x="-2.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="8" x="-2.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="9" x="-1.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="10" x="-1.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="11" x="-0.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="12" x="-0.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="13" x="0.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="14" x="0.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="15" x="1.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="16" x="1.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="17" x="2.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="18" x="2.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="19" x="3.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="20" x="3.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="21" x="4.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="22" x="4.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="23" x="5.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="24" x="5.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<text x="-9.08" y="3.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-9.08" y="-5.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="8.25" y1="-0.2" x2="9.4" y2="2" layer="29" rot="R180"/>
<rectangle x1="7" y1="-1.05" x2="8.3" y2="2" layer="29" rot="R180"/>
<rectangle x1="7.2" y1="-0.05" x2="9.2" y2="1.85" layer="31" rot="R180"/>
<rectangle x1="-9.4" y1="-0.2" x2="-8.25" y2="2" layer="29"/>
<rectangle x1="-8.3" y1="-1.05" x2="-7" y2="2" layer="29"/>
<rectangle x1="-9.2" y1="-0.05" x2="-7.2" y2="1.85" layer="31"/>
<rectangle x1="-5.85" y1="2" x2="-5.65" y2="2.7" layer="51"/>
<rectangle x1="-2.85" y1="2" x2="-2.65" y2="2.7" layer="51"/>
<rectangle x1="2.65" y1="2" x2="2.85" y2="2.7" layer="51"/>
<rectangle x1="5.65" y1="2" x2="5.85" y2="2.7" layer="51"/>
<rectangle x1="-9.4" y1="-0.2" x2="-7" y2="2" layer="1"/>
<rectangle x1="-8.3" y1="-1.05" x2="-7" y2="-0.2" layer="1"/>
<rectangle x1="7" y1="-1.05" x2="8.3" y2="-0.2" layer="1"/>
<rectangle x1="7" y1="-0.2" x2="9.4" y2="2" layer="1"/>
<vertex x="-6.25" y="-1.25"/>
<vertex x="-6.25" y="-1.2"/>
<vertex x="-6" y="-0.85"/>
</polygon>
</package>
<package name="52745-2590">
<wire x1="-9.2" y1="-3" x2="-9.2" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="-9.2" y1="-3.5" x2="-9.1" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="-9.1" y1="-3.6" x2="9.1" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="9.1" y1="-3.6" x2="9.2" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="9.2" y1="-3.5" x2="9.2" y2="-3" width="0.2032" layer="21"/>
<wire x1="9.2" y1="-3" x2="-9.2" y2="-3" width="0.2032" layer="21"/>
<wire x1="-8.3" y1="1.9" x2="8.3" y2="1.9" width="0.2032" layer="51"/>
<wire x1="8.3" y1="1.9" x2="8.3" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="8.3" y1="-1.4" x2="-8.3" y2="-1.4" width="0.2032" layer="21"/>
<wire x1="-8.3" y1="-1.4" x2="-8.3" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-7.75" y1="-1.5" x2="-7.75" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="7.75" y1="-1.5" x2="7.75" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="-6.3" y1="-3.1" x2="-6.3" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="-6.3" y1="-3.5" x2="-6.05" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-6.05" y1="-3.25" x2="-6.05" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="6.05" y1="-3.1" x2="6.05" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="6.05" y1="-3.25" x2="6.3" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="6.3" y1="-3.5" x2="6.3" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="8.45" y1="1.95" x2="8.6" y2="1.95" width="0.1016" layer="51"/>
<wire x1="8.6" y1="1.95" x2="8.6" y2="1.65" width="0.1016" layer="51"/>
<wire x1="8.6" y1="1.65" x2="9.2" y2="1.65" width="0.1016" layer="51"/>
<wire x1="9.2" y1="1.65" x2="9.2" y2="1.45" width="0.1016" layer="51"/>
<wire x1="9.2" y1="1.45" x2="8.6" y2="1.45" width="0.1016" layer="51"/>
<wire x1="8.6" y1="1.45" x2="8.6" y2="0.95" width="0.1016" layer="51"/>
<wire x1="8.6" y1="0.95" x2="8.65" y2="0.9" width="0.1016" layer="51"/>
<wire x1="8.65" y1="0.9" x2="9.2" y2="0.9" width="0.1016" layer="51"/>
<wire x1="9.2" y1="0.9" x2="9.2" y2="0.7" width="0.1016" layer="51"/>
<wire x1="9.2" y1="0.7" x2="8.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="8.45" y1="0.7" x2="8.45" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-8.45" y1="1.95" x2="-8.6" y2="1.95" width="0.1016" layer="51"/>
<wire x1="-8.6" y1="1.95" x2="-8.6" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-8.6" y1="1.65" x2="-9.2" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-9.2" y1="1.65" x2="-9.2" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-9.2" y1="1.45" x2="-8.6" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-8.6" y1="1.45" x2="-8.6" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-8.6" y1="0.95" x2="-8.65" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-8.65" y1="0.9" x2="-9.2" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-9.2" y1="0.9" x2="-9.2" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-9.2" y1="0.7" x2="-8.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-8.45" y1="0.7" x2="-8.45" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-6.9" y1="-1.25" x2="-6.9" y2="1" width="0.2032" layer="21"/>
<wire x1="-6.9" y1="1" x2="-6.75" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="-6.75" y1="1" x2="-6.75" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="6.75" y1="-1.25" x2="6.75" y2="1" width="0.2032" layer="21"/>
<wire x1="6.75" y1="1" x2="6.9" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="6.9" y1="1" x2="6.9" y2="-1.25" width="0.2032" layer="21"/>
<smd name="1" x="-6" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="2" x="-5.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="3" x="-5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="4" x="-4.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="5" x="-4" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="6" x="-3.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="7" x="-3" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="8" x="-2.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="9" x="-2" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="10" x="-1.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="11" x="-1" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="12" x="-0.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="13" x="0" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="14" x="0.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="15" x="1" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="16" x="1.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="17" x="2" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="18" x="2.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="19" x="3" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="20" x="3.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="21" x="4" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="22" x="4.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="23" x="5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="24" x="5.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="25" x="6" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<text x="-9.33" y="3.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-9.33" y="-5.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="8.5" y1="-0.2" x2="9.65" y2="2" layer="29" rot="R180"/>
<rectangle x1="7.25" y1="-1.05" x2="8.55" y2="2" layer="29" rot="R180"/>
<rectangle x1="7.45" y1="-0.05" x2="9.45" y2="1.85" layer="31" rot="R180"/>
<rectangle x1="-9.65" y1="-0.2" x2="-8.5" y2="2" layer="29"/>
<rectangle x1="-8.55" y1="-1.05" x2="-7.25" y2="2" layer="29"/>
<rectangle x1="-9.45" y1="-0.05" x2="-7.45" y2="1.85" layer="31"/>
<rectangle x1="-6.1" y1="2" x2="-5.9" y2="2.7" layer="51"/>
<rectangle x1="-3.1" y1="2" x2="-2.9" y2="2.7" layer="51"/>
<rectangle x1="2.9" y1="2" x2="3.1" y2="2.7" layer="51"/>
<rectangle x1="5.9" y1="2" x2="6.1" y2="2.7" layer="51"/>
<rectangle x1="-9.65" y1="-0.2" x2="-7.25" y2="2" layer="1"/>
<rectangle x1="-8.55" y1="-1.05" x2="-7.25" y2="-0.2" layer="1"/>
<rectangle x1="7.25" y1="-1.05" x2="8.55" y2="-0.2" layer="1"/>
<rectangle x1="7.25" y1="-0.2" x2="9.65" y2="2" layer="1"/>
<vertex x="-6.5" y="-1.25"/>
<vertex x="-6.5" y="-1.2"/>
<vertex x="-6.25" y="-0.85"/>
</polygon>
</package>
<package name="52745-2690">
<wire x1="-9.45" y1="-3" x2="-9.45" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="-9.45" y1="-3.5" x2="-9.35" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="-9.35" y1="-3.6" x2="9.35" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="9.35" y1="-3.6" x2="9.45" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="9.45" y1="-3.5" x2="9.45" y2="-3" width="0.2032" layer="21"/>
<wire x1="9.45" y1="-3" x2="-9.45" y2="-3" width="0.2032" layer="21"/>
<wire x1="-8.55" y1="1.9" x2="8.55" y2="1.9" width="0.2032" layer="51"/>
<wire x1="8.55" y1="1.9" x2="8.55" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="8.55" y1="-1.4" x2="-8.55" y2="-1.4" width="0.2032" layer="21"/>
<wire x1="-8.55" y1="-1.4" x2="-8.55" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-8" y1="-1.5" x2="-8" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="8" y1="-1.5" x2="8" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="-6.55" y1="-3.1" x2="-6.55" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="-6.55" y1="-3.5" x2="-6.3" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-6.3" y1="-3.25" x2="-6.3" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="6.3" y1="-3.1" x2="6.3" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="6.3" y1="-3.25" x2="6.55" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="6.55" y1="-3.5" x2="6.55" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="8.7" y1="1.95" x2="8.85" y2="1.95" width="0.1016" layer="51"/>
<wire x1="8.85" y1="1.95" x2="8.85" y2="1.65" width="0.1016" layer="51"/>
<wire x1="8.85" y1="1.65" x2="9.45" y2="1.65" width="0.1016" layer="51"/>
<wire x1="9.45" y1="1.65" x2="9.45" y2="1.45" width="0.1016" layer="51"/>
<wire x1="9.45" y1="1.45" x2="8.85" y2="1.45" width="0.1016" layer="51"/>
<wire x1="8.85" y1="1.45" x2="8.85" y2="0.95" width="0.1016" layer="51"/>
<wire x1="8.85" y1="0.95" x2="8.9" y2="0.9" width="0.1016" layer="51"/>
<wire x1="8.9" y1="0.9" x2="9.45" y2="0.9" width="0.1016" layer="51"/>
<wire x1="9.45" y1="0.9" x2="9.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="9.45" y1="0.7" x2="8.7" y2="0.7" width="0.1016" layer="51"/>
<wire x1="8.7" y1="0.7" x2="8.7" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-8.7" y1="1.95" x2="-8.85" y2="1.95" width="0.1016" layer="51"/>
<wire x1="-8.85" y1="1.95" x2="-8.85" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-8.85" y1="1.65" x2="-9.45" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-9.45" y1="1.65" x2="-9.45" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-9.45" y1="1.45" x2="-8.85" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-8.85" y1="1.45" x2="-8.85" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-8.85" y1="0.95" x2="-8.9" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-8.9" y1="0.9" x2="-9.45" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-9.45" y1="0.9" x2="-9.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-9.45" y1="0.7" x2="-8.7" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-8.7" y1="0.7" x2="-8.7" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-7.15" y1="-1.25" x2="-7.15" y2="1" width="0.2032" layer="21"/>
<wire x1="-7.15" y1="1" x2="-7" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="-7" y1="1" x2="-7" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="7" y1="-1.25" x2="7" y2="1" width="0.2032" layer="21"/>
<wire x1="7" y1="1" x2="7.15" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="7.15" y1="1" x2="7.15" y2="-1.25" width="0.2032" layer="21"/>
<smd name="1" x="-6.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="2" x="-5.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="3" x="-5.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="4" x="-4.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="5" x="-4.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="6" x="-3.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="7" x="-3.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="8" x="-2.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="9" x="-2.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="10" x="-1.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="11" x="-1.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="12" x="-0.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="13" x="-0.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="14" x="0.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="15" x="0.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="16" x="1.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="17" x="1.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="18" x="2.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="19" x="2.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="20" x="3.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="21" x="3.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="22" x="4.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="23" x="4.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="24" x="5.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="25" x="5.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="26" x="6.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<text x="-9.58" y="3.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-9.58" y="-5.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="8.75" y1="-0.2" x2="9.9" y2="2" layer="29" rot="R180"/>
<rectangle x1="7.5" y1="-1.05" x2="8.8" y2="2" layer="29" rot="R180"/>
<rectangle x1="7.7" y1="-0.05" x2="9.7" y2="1.85" layer="31" rot="R180"/>
<rectangle x1="-9.9" y1="-0.2" x2="-8.75" y2="2" layer="29"/>
<rectangle x1="-8.8" y1="-1.05" x2="-7.5" y2="2" layer="29"/>
<rectangle x1="-9.7" y1="-0.05" x2="-7.7" y2="1.85" layer="31"/>
<rectangle x1="-6.35" y1="2" x2="-6.15" y2="2.7" layer="51"/>
<rectangle x1="-3.35" y1="2" x2="-3.15" y2="2.7" layer="51"/>
<rectangle x1="3.15" y1="2" x2="3.35" y2="2.7" layer="51"/>
<rectangle x1="6.15" y1="2" x2="6.35" y2="2.7" layer="51"/>
<rectangle x1="-9.9" y1="-0.2" x2="-7.5" y2="2" layer="1"/>
<rectangle x1="-8.8" y1="-1.05" x2="-7.5" y2="-0.2" layer="1"/>
<rectangle x1="7.5" y1="-1.05" x2="8.8" y2="-0.2" layer="1"/>
<rectangle x1="7.5" y1="-0.2" x2="9.9" y2="2" layer="1"/>
<polygon width="0.1016" layer="21">
<vertex x="-6.75" y="-1.25"/>
<vertex x="-6.75" y="-1.2"/>
<vertex x="-6.5" y="-0.85"/>
</polygon>
</package>
<package name="52745-2790">
<wire x1="-9.7" y1="-3" x2="-9.7" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="-9.7" y1="-3.5" x2="-9.6" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="-9.6" y1="-3.6" x2="9.6" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="9.6" y1="-3.6" x2="9.7" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="9.7" y1="-3.5" x2="9.7" y2="-3" width="0.2032" layer="21"/>
<wire x1="9.7" y1="-3" x2="-9.7" y2="-3" width="0.2032" layer="21"/>
<wire x1="-8.8" y1="1.9" x2="8.8" y2="1.9" width="0.2032" layer="51"/>
<wire x1="8.8" y1="1.9" x2="8.8" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="8.8" y1="-1.4" x2="-8.8" y2="-1.4" width="0.2032" layer="21"/>
<wire x1="-8.8" y1="-1.4" x2="-8.8" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-8.25" y1="-1.5" x2="-8.25" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="8.25" y1="-1.5" x2="8.25" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="-6.8" y1="-3.1" x2="-6.8" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="-6.8" y1="-3.5" x2="-6.55" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-6.55" y1="-3.25" x2="-6.55" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="6.55" y1="-3.1" x2="6.55" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="6.55" y1="-3.25" x2="6.8" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="6.8" y1="-3.5" x2="6.8" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="8.95" y1="1.95" x2="9.1" y2="1.95" width="0.1016" layer="51"/>
<wire x1="9.1" y1="1.95" x2="9.1" y2="1.65" width="0.1016" layer="51"/>
<wire x1="9.1" y1="1.65" x2="9.7" y2="1.65" width="0.1016" layer="51"/>
<wire x1="9.7" y1="1.65" x2="9.7" y2="1.45" width="0.1016" layer="51"/>
<wire x1="9.7" y1="1.45" x2="9.1" y2="1.45" width="0.1016" layer="51"/>
<wire x1="9.1" y1="1.45" x2="9.1" y2="0.95" width="0.1016" layer="51"/>
<wire x1="9.1" y1="0.95" x2="9.15" y2="0.9" width="0.1016" layer="51"/>
<wire x1="9.15" y1="0.9" x2="9.7" y2="0.9" width="0.1016" layer="51"/>
<wire x1="9.7" y1="0.9" x2="9.7" y2="0.7" width="0.1016" layer="51"/>
<wire x1="9.7" y1="0.7" x2="8.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="8.95" y1="0.7" x2="8.95" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-8.95" y1="1.95" x2="-9.1" y2="1.95" width="0.1016" layer="51"/>
<wire x1="-9.1" y1="1.95" x2="-9.1" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-9.1" y1="1.65" x2="-9.7" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-9.7" y1="1.65" x2="-9.7" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-9.7" y1="1.45" x2="-9.1" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-9.1" y1="1.45" x2="-9.1" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-9.1" y1="0.95" x2="-9.15" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-9.15" y1="0.9" x2="-9.7" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-9.7" y1="0.9" x2="-9.7" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-9.7" y1="0.7" x2="-8.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-8.95" y1="0.7" x2="-8.95" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-7.4" y1="-1.25" x2="-7.4" y2="1" width="0.2032" layer="21"/>
<wire x1="-7.4" y1="1" x2="-7.25" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="-7.25" y1="1" x2="-7.25" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="7.25" y1="-1.25" x2="7.25" y2="1" width="0.2032" layer="21"/>
<wire x1="7.25" y1="1" x2="7.4" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="7.4" y1="1" x2="7.4" y2="-1.25" width="0.2032" layer="21"/>
<smd name="1" x="-6.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="2" x="-6" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="3" x="-5.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="4" x="-5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="5" x="-4.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="6" x="-4" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="7" x="-3.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="8" x="-3" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="9" x="-2.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="10" x="-2" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="11" x="-1.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="12" x="-1" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="13" x="-0.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="14" x="0" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="15" x="0.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="16" x="1" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="17" x="1.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="18" x="2" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="19" x="2.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="20" x="3" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="21" x="3.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="22" x="4" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="23" x="4.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="24" x="5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="25" x="5.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="26" x="6" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="27" x="6.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<text x="-9.83" y="3.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-9.83" y="-5.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="9" y1="-0.2" x2="10.15" y2="2" layer="29" rot="R180"/>
<rectangle x1="7.75" y1="-1.05" x2="9.05" y2="2" layer="29" rot="R180"/>
<rectangle x1="7.95" y1="-0.05" x2="9.95" y2="1.85" layer="31" rot="R180"/>
<rectangle x1="-10.15" y1="-0.2" x2="-9" y2="2" layer="29"/>
<rectangle x1="-9.05" y1="-1.05" x2="-7.75" y2="2" layer="29"/>
<rectangle x1="-9.95" y1="-0.05" x2="-7.95" y2="1.85" layer="31"/>
<rectangle x1="-6.6" y1="2" x2="-6.4" y2="2.7" layer="51"/>
<rectangle x1="-3.6" y1="2" x2="-3.4" y2="2.7" layer="51"/>
<rectangle x1="3.4" y1="2" x2="3.6" y2="2.7" layer="51"/>
<rectangle x1="6.4" y1="2" x2="6.6" y2="2.7" layer="51"/>
<rectangle x1="-10.15" y1="-0.2" x2="-7.75" y2="2" layer="1"/>
<rectangle x1="-9.05" y1="-1.05" x2="-7.75" y2="-0.2" layer="1"/>
<rectangle x1="7.75" y1="-1.05" x2="9.05" y2="-0.2" layer="1"/>
<rectangle x1="7.75" y1="-0.2" x2="10.15" y2="2" layer="1"/>
<vertex x="-7" y="-1.25"/>
<vertex x="-7" y="-1.2"/>
<vertex x="-6.75" y="-0.85"/>
</polygon>
</package>
<package name="52745-2890">
<wire x1="-9.95" y1="-3" x2="-9.95" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="-9.95" y1="-3.5" x2="-9.85" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="-9.85" y1="-3.6" x2="9.85" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="9.85" y1="-3.6" x2="9.95" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="9.95" y1="-3.5" x2="9.95" y2="-3" width="0.2032" layer="21"/>
<wire x1="9.95" y1="-3" x2="-9.95" y2="-3" width="0.2032" layer="21"/>
<wire x1="-9.05" y1="1.9" x2="9.05" y2="1.9" width="0.2032" layer="51"/>
<wire x1="9.05" y1="1.9" x2="9.05" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="9.05" y1="-1.4" x2="-9.05" y2="-1.4" width="0.2032" layer="21"/>
<wire x1="-9.05" y1="-1.4" x2="-9.05" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-8.5" y1="-1.5" x2="-8.5" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="8.5" y1="-1.5" x2="8.5" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="-7.05" y1="-3.1" x2="-7.05" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="-7.05" y1="-3.5" x2="-6.8" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-6.8" y1="-3.25" x2="-6.8" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="6.8" y1="-3.1" x2="6.8" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="6.8" y1="-3.25" x2="7.05" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="7.05" y1="-3.5" x2="7.05" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="9.2" y1="1.95" x2="9.35" y2="1.95" width="0.1016" layer="51"/>
<wire x1="9.35" y1="1.95" x2="9.35" y2="1.65" width="0.1016" layer="51"/>
<wire x1="9.35" y1="1.65" x2="9.95" y2="1.65" width="0.1016" layer="51"/>
<wire x1="9.95" y1="1.65" x2="9.95" y2="1.45" width="0.1016" layer="51"/>
<wire x1="9.95" y1="1.45" x2="9.35" y2="1.45" width="0.1016" layer="51"/>
<wire x1="9.35" y1="1.45" x2="9.35" y2="0.95" width="0.1016" layer="51"/>
<wire x1="9.35" y1="0.95" x2="9.4" y2="0.9" width="0.1016" layer="51"/>
<wire x1="9.4" y1="0.9" x2="9.95" y2="0.9" width="0.1016" layer="51"/>
<wire x1="9.95" y1="0.9" x2="9.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="9.95" y1="0.7" x2="9.2" y2="0.7" width="0.1016" layer="51"/>
<wire x1="9.2" y1="0.7" x2="9.2" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-9.2" y1="1.95" x2="-9.35" y2="1.95" width="0.1016" layer="51"/>
<wire x1="-9.35" y1="1.95" x2="-9.35" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-9.35" y1="1.65" x2="-9.95" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-9.95" y1="1.65" x2="-9.95" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-9.95" y1="1.45" x2="-9.35" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-9.35" y1="1.45" x2="-9.35" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-9.35" y1="0.95" x2="-9.4" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-9.4" y1="0.9" x2="-9.95" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-9.95" y1="0.9" x2="-9.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-9.95" y1="0.7" x2="-9.2" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-9.2" y1="0.7" x2="-9.2" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-7.65" y1="-1.25" x2="-7.65" y2="1" width="0.2032" layer="21"/>
<wire x1="-7.65" y1="1" x2="-7.5" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="-7.5" y1="1" x2="-7.5" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="7.5" y1="-1.25" x2="7.5" y2="1" width="0.2032" layer="21"/>
<wire x1="7.5" y1="1" x2="7.65" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="7.65" y1="1" x2="7.65" y2="-1.25" width="0.2032" layer="21"/>
<smd name="1" x="-6.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="2" x="-6.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="3" x="-5.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="4" x="-5.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="5" x="-4.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="6" x="-4.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="7" x="-3.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="8" x="-3.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="9" x="-2.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="10" x="-2.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="11" x="-1.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="12" x="-1.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="13" x="-0.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="14" x="-0.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="15" x="0.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="16" x="0.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="17" x="1.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="18" x="1.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="19" x="2.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="20" x="2.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="21" x="3.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="22" x="3.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="23" x="4.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="24" x="4.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="25" x="5.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="26" x="5.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="27" x="6.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="28" x="6.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<text x="-10.08" y="3.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-10.08" y="-5.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="9.25" y1="-0.2" x2="10.4" y2="2" layer="29" rot="R180"/>
<rectangle x1="8" y1="-1.05" x2="9.3" y2="2" layer="29" rot="R180"/>
<rectangle x1="8.2" y1="-0.05" x2="10.2" y2="1.85" layer="31" rot="R180"/>
<rectangle x1="-10.4" y1="-0.2" x2="-9.25" y2="2" layer="29"/>
<rectangle x1="-9.3" y1="-1.05" x2="-8" y2="2" layer="29"/>
<rectangle x1="-10.2" y1="-0.05" x2="-8.2" y2="1.85" layer="31"/>
<rectangle x1="-6.85" y1="2" x2="-6.65" y2="2.7" layer="51"/>
<rectangle x1="-4.35" y1="2" x2="-4.15" y2="2.7" layer="51"/>
<rectangle x1="-3.85" y1="2" x2="-3.65" y2="2.7" layer="51"/>
<rectangle x1="-1.35" y1="2" x2="-1.15" y2="2.7" layer="51"/>
<rectangle x1="-0.85" y1="2" x2="-0.65" y2="2.7" layer="51"/>
<rectangle x1="-0.35" y1="2" x2="-0.15" y2="2.7" layer="51"/>
<rectangle x1="0.15" y1="2" x2="0.35" y2="2.7" layer="51"/>
<rectangle x1="0.65" y1="2" x2="0.85" y2="2.7" layer="51"/>
<rectangle x1="1.15" y1="2" x2="1.35" y2="2.7" layer="51"/>
<rectangle x1="3.65" y1="2" x2="3.85" y2="2.7" layer="51"/>
<rectangle x1="4.15" y1="2" x2="4.35" y2="2.7" layer="51"/>
<rectangle x1="6.65" y1="2" x2="6.85" y2="2.7" layer="51"/>
<rectangle x1="-10.4" y1="-0.2" x2="-8" y2="2" layer="1"/>
<rectangle x1="-9.3" y1="-1.05" x2="-8" y2="-0.2" layer="1"/>
<rectangle x1="8" y1="-1.05" x2="9.3" y2="-0.2" layer="1"/>
<rectangle x1="8" y1="-0.2" x2="10.4" y2="2" layer="1"/>
<vertex x="-7.25" y="-1.25"/>
<vertex x="-7.25" y="-1.2"/>
<vertex x="-7" y="-0.85"/>
</polygon>
</package>
<package name="52745-2990">
<description>&lt;b&gt;FFC/FPC&lt;/b&gt;-to-Board  0.50mm (.020") SMT Top Contact&lt;p&gt;
Right Angle, ZIF, Style Receptacle 52745 / 52435&lt;br&gt;
Source: http://www.molex.com/product/ffc/52745.html</description>
<wire x1="-10.2" y1="-3" x2="-10.2" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="-10.2" y1="-3.5" x2="-10.1" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="-10.1" y1="-3.6" x2="10.1" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="10.1" y1="-3.6" x2="10.2" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="10.2" y1="-3.5" x2="10.2" y2="-3" width="0.2032" layer="21"/>
<wire x1="10.2" y1="-3" x2="-10.2" y2="-3" width="0.2032" layer="21"/>
<wire x1="-9.3" y1="1.9" x2="9.3" y2="1.9" width="0.2032" layer="51"/>
<wire x1="9.3" y1="1.9" x2="9.3" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="9.3" y1="-1.4" x2="-9.3" y2="-1.4" width="0.2032" layer="21"/>
<wire x1="-9.3" y1="-1.4" x2="-9.3" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-8.75" y1="-1.5" x2="-8.75" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="8.75" y1="-1.5" x2="8.75" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="-7.3" y1="-3.1" x2="-7.3" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="-7.3" y1="-3.5" x2="-7.05" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-7.05" y1="-3.25" x2="-7.05" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="7.05" y1="-3.1" x2="7.05" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="7.05" y1="-3.25" x2="7.3" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="7.3" y1="-3.5" x2="7.3" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="9.45" y1="1.95" x2="9.6" y2="1.95" width="0.1016" layer="51"/>
<wire x1="9.6" y1="1.95" x2="9.6" y2="1.65" width="0.1016" layer="51"/>
<wire x1="9.6" y1="1.65" x2="10.2" y2="1.65" width="0.1016" layer="51"/>
<wire x1="10.2" y1="1.65" x2="10.2" y2="1.45" width="0.1016" layer="51"/>
<wire x1="10.2" y1="1.45" x2="9.6" y2="1.45" width="0.1016" layer="51"/>
<wire x1="9.6" y1="1.45" x2="9.6" y2="0.95" width="0.1016" layer="51"/>
<wire x1="9.6" y1="0.95" x2="9.65" y2="0.9" width="0.1016" layer="51"/>
<wire x1="9.65" y1="0.9" x2="10.2" y2="0.9" width="0.1016" layer="51"/>
<wire x1="10.2" y1="0.9" x2="10.2" y2="0.7" width="0.1016" layer="51"/>
<wire x1="10.2" y1="0.7" x2="9.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="9.45" y1="0.7" x2="9.45" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-9.45" y1="1.95" x2="-9.6" y2="1.95" width="0.1016" layer="51"/>
<wire x1="-9.6" y1="1.95" x2="-9.6" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-9.6" y1="1.65" x2="-10.2" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-10.2" y1="1.65" x2="-10.2" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-10.2" y1="1.45" x2="-9.6" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-9.6" y1="1.45" x2="-9.6" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-9.6" y1="0.95" x2="-9.65" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-9.65" y1="0.9" x2="-10.2" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-10.2" y1="0.9" x2="-10.2" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-10.2" y1="0.7" x2="-9.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-9.45" y1="0.7" x2="-9.45" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-7.9" y1="-1.25" x2="-7.9" y2="1" width="0.2032" layer="21"/>
<wire x1="-7.9" y1="1" x2="-7.75" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="-7.75" y1="1" x2="-7.75" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="7.75" y1="-1.25" x2="7.75" y2="1" width="0.2032" layer="21"/>
<wire x1="7.75" y1="1" x2="7.9" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="7.9" y1="1" x2="7.9" y2="-1.25" width="0.2032" layer="21"/>
<smd name="1" x="-7" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="2" x="-6.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="3" x="-6" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="4" x="-5.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="5" x="-5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="6" x="-4.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="7" x="-4" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="8" x="-3.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="9" x="-3" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="10" x="-2.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="11" x="-2" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="12" x="-1.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="13" x="-1" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="14" x="-0.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="15" x="0" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="16" x="0.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="17" x="1" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="18" x="1.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="19" x="2" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="20" x="2.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="21" x="3" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="22" x="3.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="23" x="4" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="24" x="4.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="25" x="5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="26" x="5.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="27" x="6" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="28" x="6.5" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="29" x="7" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<text x="-10.33" y="3.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-10.33" y="-5.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="9.5" y1="-0.2" x2="10.65" y2="2" layer="29" rot="R180"/>
<rectangle x1="8.25" y1="-1.05" x2="9.55" y2="2" layer="29" rot="R180"/>
<rectangle x1="8.45" y1="-0.05" x2="10.45" y2="1.85" layer="31" rot="R180"/>
<rectangle x1="-10.65" y1="-0.2" x2="-9.5" y2="2" layer="29"/>
<rectangle x1="-9.55" y1="-1.05" x2="-8.25" y2="2" layer="29"/>
<rectangle x1="-10.45" y1="-0.05" x2="-8.45" y2="1.85" layer="31"/>
<rectangle x1="-7.1" y1="2" x2="-6.9" y2="2.7" layer="51"/>
<rectangle x1="-4.6" y1="2" x2="-4.4" y2="2.7" layer="51"/>
<rectangle x1="-4.1" y1="2" x2="-3.9" y2="2.7" layer="51"/>
<rectangle x1="-1.6" y1="2" x2="-1.4" y2="2.7" layer="51"/>
<rectangle x1="-1.1" y1="2" x2="-0.9" y2="2.7" layer="51"/>
<rectangle x1="-0.6" y1="2" x2="-0.4" y2="2.7" layer="51"/>
<rectangle x1="-0.1" y1="2" x2="0.1" y2="2.7" layer="51"/>
<rectangle x1="0.4" y1="2" x2="0.6" y2="2.7" layer="51"/>
<rectangle x1="0.9" y1="2" x2="1.1" y2="2.7" layer="51"/>
<rectangle x1="1.4" y1="2" x2="1.6" y2="2.7" layer="51"/>
<rectangle x1="3.9" y1="2" x2="4.1" y2="2.7" layer="51"/>
<rectangle x1="4.4" y1="2" x2="4.6" y2="2.7" layer="51"/>
<rectangle x1="6.9" y1="2" x2="7.1" y2="2.7" layer="51"/>
<rectangle x1="-10.65" y1="-0.2" x2="-8.25" y2="2" layer="1"/>
<rectangle x1="-9.55" y1="-1.05" x2="-8.25" y2="-0.2" layer="1"/>
<rectangle x1="8.25" y1="-1.05" x2="9.55" y2="-0.2" layer="1"/>
<rectangle x1="8.25" y1="-0.2" x2="10.65" y2="2" layer="1"/>
<vertex x="-7.5" y="-1.25"/>
<vertex x="-7.5" y="-1.2"/>
<vertex x="-7.25" y="-0.85"/>
</polygon>
</package>
<package name="52745-3090">
<wire x1="-10.45" y1="-3" x2="-10.45" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="-10.45" y1="-3.5" x2="-10.35" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="-10.35" y1="-3.6" x2="10.35" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="10.35" y1="-3.6" x2="10.45" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="10.45" y1="-3.5" x2="10.45" y2="-3" width="0.2032" layer="21"/>
<wire x1="10.45" y1="-3" x2="-10.45" y2="-3" width="0.2032" layer="21"/>
<wire x1="-9.55" y1="1.9" x2="9.55" y2="1.9" width="0.2032" layer="51"/>
<wire x1="9.55" y1="1.9" x2="9.55" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="9.55" y1="-1.4" x2="-9.55" y2="-1.4" width="0.2032" layer="21"/>
<wire x1="-9.55" y1="-1.4" x2="-9.55" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-9" y1="-1.5" x2="-9" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="9" y1="-1.5" x2="9" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="-7.55" y1="-3.1" x2="-7.55" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="-7.55" y1="-3.5" x2="-7.3" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-7.3" y1="-3.25" x2="-7.3" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="7.3" y1="-3.1" x2="7.3" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="7.3" y1="-3.25" x2="7.55" y2="-3.5" width="0.1016" layer="21"/>
<wire x1="7.55" y1="-3.5" x2="7.55" y2="-3.1" width="0.1016" layer="21"/>
<wire x1="9.7" y1="1.95" x2="9.85" y2="1.95" width="0.1016" layer="51"/>
<wire x1="9.85" y1="1.95" x2="9.85" y2="1.65" width="0.1016" layer="51"/>
<wire x1="9.85" y1="1.65" x2="10.45" y2="1.65" width="0.1016" layer="51"/>
<wire x1="10.45" y1="1.65" x2="10.45" y2="1.45" width="0.1016" layer="51"/>
<wire x1="10.45" y1="1.45" x2="9.85" y2="1.45" width="0.1016" layer="51"/>
<wire x1="9.85" y1="1.45" x2="9.85" y2="0.95" width="0.1016" layer="51"/>
<wire x1="9.85" y1="0.95" x2="9.9" y2="0.9" width="0.1016" layer="51"/>
<wire x1="9.9" y1="0.9" x2="10.45" y2="0.9" width="0.1016" layer="51"/>
<wire x1="10.45" y1="0.9" x2="10.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="10.45" y1="0.7" x2="9.7" y2="0.7" width="0.1016" layer="51"/>
<wire x1="9.7" y1="0.7" x2="9.7" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-9.7" y1="1.95" x2="-9.85" y2="1.95" width="0.1016" layer="51"/>
<wire x1="-9.85" y1="1.95" x2="-9.85" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-9.85" y1="1.65" x2="-10.45" y2="1.65" width="0.1016" layer="51"/>
<wire x1="-10.45" y1="1.65" x2="-10.45" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-10.45" y1="1.45" x2="-9.85" y2="1.45" width="0.1016" layer="51"/>
<wire x1="-9.85" y1="1.45" x2="-9.85" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-9.85" y1="0.95" x2="-9.9" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-9.9" y1="0.9" x2="-10.45" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-10.45" y1="0.9" x2="-10.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-10.45" y1="0.7" x2="-9.7" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-9.7" y1="0.7" x2="-9.7" y2="1.9" width="0.1016" layer="51"/>
<wire x1="-8.15" y1="-1.25" x2="-8.15" y2="1" width="0.2032" layer="21"/>
<wire x1="-8.15" y1="1" x2="-8" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="-8" y1="1" x2="-8" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="8" y1="-1.25" x2="8" y2="1" width="0.2032" layer="21"/>
<wire x1="8" y1="1" x2="8.15" y2="1" width="0.2032" layer="21" curve="-180"/>
<wire x1="8.15" y1="1" x2="8.15" y2="-1.25" width="0.2032" layer="21"/>
<smd name="1" x="-7.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="2" x="-6.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="3" x="-6.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="4" x="-5.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="5" x="-5.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="6" x="-4.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="7" x="-4.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="8" x="-3.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="9" x="-3.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="10" x="-2.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="11" x="-2.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="12" x="-1.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="13" x="-1.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="14" x="-0.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="15" x="-0.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="16" x="0.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="17" x="0.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="18" x="1.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="19" x="1.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="20" x="2.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="21" x="2.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="22" x="3.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="23" x="3.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="24" x="4.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="25" x="4.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="26" x="5.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="27" x="5.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="28" x="6.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="29" x="6.75" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<smd name="30" x="7.25" y="2.5" dx="0.3" dy="0.8" layer="1"/>
<text x="-10.58" y="3.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-10.58" y="-5.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="9.75" y1="-0.2" x2="10.9" y2="2" layer="29" rot="R180"/>
<rectangle x1="8.5" y1="-1.05" x2="9.8" y2="2" layer="29" rot="R180"/>
<rectangle x1="8.7" y1="-0.05" x2="10.7" y2="1.85" layer="31" rot="R180"/>
<rectangle x1="-10.9" y1="-0.2" x2="-9.75" y2="2" layer="29"/>
<rectangle x1="-9.8" y1="-1.05" x2="-8.5" y2="2" layer="29"/>
<rectangle x1="-10.7" y1="-0.05" x2="-8.7" y2="1.85" layer="31"/>
<rectangle x1="-7.35" y1="2" x2="-7.15" y2="2.7" layer="51"/>
<rectangle x1="-4.85" y1="2" x2="-4.65" y2="2.7" layer="51"/>
<rectangle x1="-1.85" y1="2" x2="-1.65" y2="2.7" layer="51"/>
<rectangle x1="1.65" y1="2" x2="1.85" y2="2.7" layer="51"/>
<rectangle x1="4.65" y1="2" x2="4.85" y2="2.7" layer="51"/>
<rectangle x1="7.15" y1="2" x2="7.35" y2="2.7" layer="51"/>
<rectangle x1="-10.9" y1="-0.2" x2="-8.5" y2="2" layer="1"/>
<rectangle x1="-9.8" y1="-1.05" x2="-8.5" y2="-0.2" layer="1"/>
<rectangle x1="8.5" y1="-1.05" x2="9.8" y2="-0.2" layer="1"/>
<rectangle x1="8.5" y1="-0.2" x2="10.9" y2="2" layer="1"/>
<vertex x="-7.75" y="-1.25"/>
<vertex x="-7.75" y="-1.2"/>
<vertex x="-7.5" y="-0.85"/>
</polygon>
</package>
<package name="22-23-2021">
<description>.100" (2.54mm) Center Headers - 2 Pin</description>
<wire x1="-2.54" y1="3.175" x2="2.54" y2="3.175" width="0.254" layer="21"/>
<wire x1="2.54" y1="3.175" x2="2.54" y2="1.27" width="0.254" layer="21"/>
<wire x1="2.54" y1="1.27" x2="2.54" y2="-3.175" width="0.254" layer="21"/>
<wire x1="2.54" y1="-3.175" x2="-2.54" y2="-3.175" width="0.254" layer="21"/>
<wire x1="-2.54" y1="-3.175" x2="-2.54" y2="1.27" width="0.254" layer="21"/>
<wire x1="-2.54" y1="1.27" x2="-2.54" y2="3.175" width="0.254" layer="21"/>
<wire x1="-2.54" y1="1.27" x2="2.54" y2="1.27" width="0.254" layer="21"/>
<pad name="1" x="-1.27" y="0" drill="1" shape="long" rot="R90"/>
<pad name="2" x="1.27" y="0" drill="1" shape="long" rot="R90"/>
<text x="-2.54" y="3.81" size="1.016" layer="25" ratio="14">&gt;NAME</text>
<text x="-2.54" y="-5.08" size="1.016" layer="27" ratio="14">&gt;VALUE</text>
</package>
<package name="22-23-2031">
<description>.100" (2.54mm) Center Header - 3 Pin</description>
<wire x1="-3.81" y1="3.175" x2="3.81" y2="3.175" width="0.254" layer="21"/>
<wire x1="3.81" y1="3.175" x2="3.81" y2="1.27" width="0.254" layer="21"/>
<wire x1="3.81" y1="1.27" x2="3.81" y2="-3.175" width="0.254" layer="21"/>
<wire x1="3.81" y1="-3.175" x2="-3.81" y2="-3.175" width="0.254" layer="21"/>
<wire x1="-3.81" y1="-3.175" x2="-3.81" y2="1.27" width="0.254" layer="21"/>
<wire x1="-3.81" y1="1.27" x2="-3.81" y2="3.175" width="0.254" layer="21"/>
<wire x1="-3.81" y1="1.27" x2="3.81" y2="1.27" width="0.254" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="1" shape="long" rot="R90"/>
<pad name="2" x="0" y="0" drill="1" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="0" drill="1" shape="long" rot="R90"/>
<text x="-3.81" y="3.81" size="1.016" layer="25" ratio="14">&gt;NAME</text>
<text x="-3.81" y="-5.08" size="1.016" layer="27" ratio="14">&gt;VALUE</text>
</package>
<package name="22-23-2041">
<description>.100" (2.54mm) Center Header - 4 Pin</description>
<wire x1="-5.08" y1="3.175" x2="5.08" y2="3.175" width="0.254" layer="21"/>
<wire x1="5.08" y1="3.175" x2="5.08" y2="1.27" width="0.254" layer="21"/>
<wire x1="5.08" y1="1.27" x2="5.08" y2="-3.175" width="0.254" layer="21"/>
<wire x1="5.08" y1="-3.175" x2="-5.08" y2="-3.175" width="0.254" layer="21"/>
<wire x1="-5.08" y1="-3.175" x2="-5.08" y2="1.27" width="0.254" layer="21"/>
<wire x1="-5.08" y1="1.27" x2="-5.08" y2="3.175" width="0.254" layer="21"/>
<wire x1="-5.08" y1="1.27" x2="5.08" y2="1.27" width="0.254" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="1" shape="long" rot="R90"/>
<pad name="2" x="-1.27" y="0" drill="1" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="0" drill="1" shape="long" rot="R90"/>
<pad name="4" x="3.81" y="0" drill="1" shape="long" rot="R90"/>
<text x="-5.08" y="3.81" size="1.016" layer="25" ratio="14">&gt;NAME</text>
<text x="-5.08" y="-5.08" size="1.016" layer="27" ratio="14">&gt;VALUE</text>
</package>
<package name="22-23-2051">
<description>.100" (2.54mm) Center Header - 5 Pin</description>
<wire x1="-6.35" y1="3.175" x2="6.35" y2="3.175" width="0.254" layer="21"/>
<wire x1="6.35" y1="3.175" x2="6.35" y2="1.27" width="0.254" layer="21"/>
<wire x1="6.35" y1="1.27" x2="6.35" y2="-3.175" width="0.254" layer="21"/>
<wire x1="6.35" y1="-3.175" x2="-6.35" y2="-3.175" width="0.254" layer="21"/>
<wire x1="-6.35" y1="-3.175" x2="-6.35" y2="1.27" width="0.254" layer="21"/>
<wire x1="-6.35" y1="1.27" x2="-6.35" y2="3.175" width="0.254" layer="21"/>
<wire x1="-6.35" y1="1.27" x2="6.35" y2="1.27" width="0.254" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="1" shape="long" rot="R90"/>
<pad name="2" x="-2.54" y="0" drill="1" shape="long" rot="R90"/>
<pad name="3" x="0" y="0" drill="1" shape="long" rot="R90"/>
<pad name="4" x="2.54" y="0" drill="1" shape="long" rot="R90"/>
<pad name="5" x="5.08" y="0" drill="1" shape="long" rot="R90"/>
<text x="-6.35" y="3.81" size="1.016" layer="25" ratio="14">&gt;NAME</text>
<text x="-6.35" y="-5.08" size="1.016" layer="27" ratio="14">&gt;VALUE</text>
</package>
<package name="22-23-2061">
<description>.100" (2.54mm) Center Header - 6 Pin</description>
<wire x1="-7.62" y1="3.175" x2="7.62" y2="3.175" width="0.254" layer="21"/>
<wire x1="7.62" y1="3.175" x2="7.62" y2="1.27" width="0.254" layer="21"/>
<wire x1="7.62" y1="1.27" x2="7.62" y2="-3.175" width="0.254" layer="21"/>
<wire x1="7.62" y1="-3.175" x2="-7.62" y2="-3.175" width="0.254" layer="21"/>
<wire x1="-7.62" y1="-3.175" x2="-7.62" y2="1.27" width="0.254" layer="21"/>
<wire x1="-7.62" y1="1.27" x2="-7.62" y2="3.175" width="0.254" layer="21"/>
<wire x1="-7.62" y1="1.27" x2="7.62" y2="1.27" width="0.254" layer="21"/>
<pad name="1" x="-6.35" y="0" drill="1" shape="long" rot="R90"/>
<pad name="2" x="-3.81" y="0" drill="1" shape="long" rot="R90"/>
<pad name="3" x="-1.27" y="0" drill="1" shape="long" rot="R90"/>
<pad name="4" x="1.27" y="0" drill="1" shape="long" rot="R90"/>
<pad name="5" x="3.81" y="0" drill="1" shape="long" rot="R90"/>
<pad name="6" x="6.35" y="0" drill="1" shape="long" rot="R90"/>
<text x="-7.62" y="3.81" size="1.016" layer="25" ratio="14">&gt;NAME</text>
<text x="-7.62" y="-5.08" size="1.016" layer="27" ratio="14">&gt;VALUE</text>
</package>
<package name="22-23-2071">
<description>.100" (2.54mm) Center Header - 7 Pin</description>
<wire x1="-8.89" y1="3.175" x2="8.89" y2="3.175" width="0.254" layer="21"/>
<wire x1="8.89" y1="3.175" x2="8.89" y2="1.27" width="0.254" layer="21"/>
<wire x1="8.89" y1="1.27" x2="8.89" y2="-3.175" width="0.254" layer="21"/>
<wire x1="8.89" y1="-3.175" x2="-8.89" y2="-3.175" width="0.254" layer="21"/>
<wire x1="-8.89" y1="-3.175" x2="-8.89" y2="1.27" width="0.254" layer="21"/>
<wire x1="-8.89" y1="1.27" x2="-8.89" y2="3.175" width="0.254" layer="21"/>
<wire x1="-8.89" y1="1.27" x2="8.89" y2="1.27" width="0.254" layer="21"/>
<pad name="1" x="-7.62" y="0" drill="1" shape="long" rot="R90"/>
<pad name="2" x="-5.08" y="0" drill="1" shape="long" rot="R90"/>
<pad name="3" x="-2.54" y="0" drill="1" shape="long" rot="R90"/>
<pad name="4" x="0" y="0" drill="1" shape="long" rot="R90"/>
<pad name="5" x="2.54" y="0" drill="1" shape="long" rot="R90"/>
<pad name="6" x="5.08" y="0" drill="1" shape="long" rot="R90"/>
<pad name="7" x="7.62" y="0" drill="1" shape="long" rot="R90"/>
<text x="-8.89" y="3.81" size="1.016" layer="25" ratio="14">&gt;NAME</text>
<text x="-8.89" y="-5.08" size="1.016" layer="27" ratio="14">&gt;VALUE</text>
</package>
<package name="22-23-2081">
<description>.100" (2.54mm) Center Header - 8 Pin</description>
<wire x1="-10.16" y1="3.175" x2="10.16" y2="3.175" width="0.254" layer="21"/>
<wire x1="10.16" y1="3.175" x2="10.16" y2="1.27" width="0.254" layer="21"/>
<wire x1="10.16" y1="1.27" x2="10.16" y2="-3.175" width="0.254" layer="21"/>
<wire x1="10.16" y1="-3.175" x2="-10.16" y2="-3.175" width="0.254" layer="21"/>
<wire x1="-10.16" y1="-3.175" x2="-10.16" y2="1.27" width="0.254" layer="21"/>
<wire x1="-10.16" y1="1.27" x2="-10.16" y2="3.175" width="0.254" layer="21"/>
<wire x1="-10.16" y1="1.27" x2="10.16" y2="1.27" width="0.254" layer="21"/>
<pad name="1" x="-8.89" y="0" drill="1" shape="long" rot="R90"/>
<pad name="2" x="-6.35" y="0" drill="1" shape="long" rot="R90"/>
<pad name="3" x="-3.81" y="0" drill="1" shape="long" rot="R90"/>
<pad name="4" x="-1.27" y="0" drill="1" shape="long" rot="R90"/>
<pad name="5" x="1.27" y="0" drill="1" shape="long" rot="R90"/>
<pad name="6" x="3.81" y="0" drill="1" shape="long" rot="R90"/>
<pad name="7" x="6.35" y="0" drill="1" shape="long" rot="R90"/>
<pad name="8" x="8.89" y="0" drill="1" shape="long" rot="R90"/>
<text x="-10.16" y="3.81" size="1.016" layer="25" ratio="14">&gt;NAME</text>
<text x="-10.16" y="-5.08" size="1.016" layer="27" ratio="14">&gt;VALUE</text>
</package>
<package name="22-23-2091">
<description>.100" (2.54mm) Center Header - 9 Pin</description>
<wire x1="-11.43" y1="3.175" x2="11.43" y2="3.175" width="0.254" layer="21"/>
<wire x1="11.43" y1="3.175" x2="11.43" y2="1.27" width="0.254" layer="21"/>
<wire x1="11.43" y1="1.27" x2="11.43" y2="-3.175" width="0.254" layer="21"/>
<wire x1="11.43" y1="-3.175" x2="-11.43" y2="-3.175" width="0.254" layer="21"/>
<wire x1="-11.43" y1="-3.175" x2="-11.43" y2="1.27" width="0.254" layer="21"/>
<wire x1="-11.43" y1="1.27" x2="-11.43" y2="3.175" width="0.254" layer="21"/>
<wire x1="-11.43" y1="1.27" x2="11.43" y2="1.27" width="0.254" layer="21"/>
<pad name="1" x="-10.16" y="0" drill="1" shape="long" rot="R90"/>
<pad name="2" x="-7.62" y="0" drill="1" shape="long" rot="R90"/>
<pad name="3" x="-5.08" y="0" drill="1" shape="long" rot="R90"/>
<pad name="4" x="-2.54" y="0" drill="1" shape="long" rot="R90"/>
<pad name="5" x="0" y="0" drill="1" shape="long" rot="R90"/>
<pad name="6" x="2.54" y="0" drill="1" shape="long" rot="R90"/>
<pad name="7" x="5.08" y="0" drill="1" shape="long" rot="R90"/>
<pad name="8" x="7.62" y="0" drill="1" shape="long" rot="R90"/>
<pad name="9" x="10.16" y="0" drill="1" shape="long" rot="R90"/>
<text x="-11.43" y="3.81" size="1.016" layer="25" ratio="14">&gt;NAME</text>
<text x="-11.43" y="-5.08" size="1.016" layer="27" ratio="14">&gt;VALUE</text>
</package>
<package name="22-23-2101">
<description>.100" (2.54mm) Center Header - 10 Pin</description>
<wire x1="-12.7" y1="3.175" x2="12.7" y2="3.175" width="0.254" layer="21"/>
<wire x1="12.7" y1="3.175" x2="12.7" y2="1.27" width="0.254" layer="21"/>
<wire x1="12.7" y1="1.27" x2="12.7" y2="-3.175" width="0.254" layer="21"/>
<wire x1="12.7" y1="-3.175" x2="-12.7" y2="-3.175" width="0.254" layer="21"/>
<wire x1="-12.7" y1="-3.175" x2="-12.7" y2="1.27" width="0.254" layer="21"/>
<wire x1="-12.7" y1="1.27" x2="-12.7" y2="3.175" width="0.254" layer="21"/>
<wire x1="-12.7" y1="1.27" x2="12.7" y2="1.27" width="0.254" layer="21"/>
<pad name="1" x="-11.43" y="0" drill="1" shape="long" rot="R90"/>
<pad name="2" x="-8.89" y="0" drill="1" shape="long" rot="R90"/>
<pad name="3" x="-6.35" y="0" drill="1" shape="long" rot="R90"/>
<pad name="4" x="-3.81" y="0" drill="1" shape="long" rot="R90"/>
<pad name="5" x="-1.27" y="0" drill="1" shape="long" rot="R90"/>
<pad name="6" x="1.27" y="0" drill="1" shape="long" rot="R90"/>
<pad name="7" x="3.81" y="0" drill="1" shape="long" rot="R90"/>
<pad name="8" x="6.35" y="0" drill="1" shape="long" rot="R90"/>
<pad name="9" x="8.89" y="0" drill="1" shape="long" rot="R90"/>
<pad name="10" x="11.43" y="0" drill="1" shape="long" rot="R90"/>
<text x="-12.7" y="3.81" size="1.016" layer="25" ratio="14">&gt;NAME</text>
<text x="-12.7" y="-5.08" size="1.016" layer="27" ratio="14">&gt;VALUE</text>
</package>
<package name="22-23-2111">
<description>.100" (2.54mm) Center Header - 11 Pin</description>
<wire x1="-13.97" y1="3.175" x2="13.97" y2="3.175" width="0.254" layer="21"/>
<wire x1="13.97" y1="3.175" x2="13.97" y2="1.27" width="0.254" layer="21"/>
<wire x1="13.97" y1="1.27" x2="13.97" y2="-3.175" width="0.254" layer="21"/>
<wire x1="13.97" y1="-3.175" x2="-13.97" y2="-3.175" width="0.254" layer="21"/>
<wire x1="-13.97" y1="-3.175" x2="-13.97" y2="1.27" width="0.254" layer="21"/>
<wire x1="-13.97" y1="1.27" x2="-13.97" y2="3.175" width="0.254" layer="21"/>
<wire x1="-13.97" y1="1.27" x2="13.97" y2="1.27" width="0.254" layer="21"/>
<pad name="1" x="-12.7" y="0" drill="1" shape="long" rot="R90"/>
<pad name="2" x="-10.16" y="0" drill="1" shape="long" rot="R90"/>
<pad name="3" x="-7.62" y="0" drill="1" shape="long" rot="R90"/>
<pad name="4" x="-5.08" y="0" drill="1" shape="long" rot="R90"/>
<pad name="5" x="-2.54" y="0" drill="1" shape="long" rot="R90"/>
<pad name="6" x="0" y="0" drill="1" shape="long" rot="R90"/>
<pad name="7" x="2.54" y="0" drill="1" shape="long" rot="R90"/>
<pad name="8" x="5.08" y="0" drill="1" shape="long" rot="R90"/>
<pad name="9" x="7.62" y="0" drill="1" shape="long" rot="R90"/>
<pad name="10" x="10.16" y="0" drill="1" shape="long" rot="R90"/>
<pad name="11" x="12.7" y="0" drill="1" shape="long" rot="R90"/>
<text x="-13.97" y="3.81" size="1.016" layer="25" ratio="14">&gt;NAME</text>
<text x="-13.97" y="-5.08" size="1.016" layer="27" ratio="14">&gt;VALUE</text>
</package>
<package name="22-23-2121">
<description>.100" (2.54mm) Center Header - 12 Pin</description>
<wire x1="-15.24" y1="3.175" x2="15.24" y2="3.175" width="0.254" layer="21"/>
<wire x1="15.24" y1="3.175" x2="15.24" y2="1.27" width="0.254" layer="21"/>
<wire x1="15.24" y1="1.27" x2="15.24" y2="-3.175" width="0.254" layer="21"/>
<wire x1="15.24" y1="-3.175" x2="-15.24" y2="-3.175" width="0.254" layer="21"/>
<wire x1="-15.24" y1="-3.175" x2="-15.24" y2="1.27" width="0.254" layer="21"/>
<wire x1="-15.24" y1="1.27" x2="-15.24" y2="3.175" width="0.254" layer="21"/>
<wire x1="-15.24" y1="1.27" x2="15.24" y2="1.27" width="0.254" layer="21"/>
<pad name="1" x="-13.97" y="0" drill="1" shape="long" rot="R90"/>
<pad name="2" x="-11.43" y="0" drill="1" shape="long" rot="R90"/>
<pad name="3" x="-8.89" y="0" drill="1" shape="long" rot="R90"/>
<pad name="4" x="-6.35" y="0" drill="1" shape="long" rot="R90"/>
<pad name="5" x="-3.81" y="0" drill="1" shape="long" rot="R90"/>
<pad name="6" x="-1.27" y="0" drill="1" shape="long" rot="R90"/>
<pad name="7" x="1.27" y="0" drill="1" shape="long" rot="R90"/>
<pad name="8" x="3.81" y="0" drill="1" shape="long" rot="R90"/>
<pad name="9" x="6.35" y="0" drill="1" shape="long" rot="R90"/>
<pad name="10" x="8.89" y="0" drill="1" shape="long" rot="R90"/>
<pad name="11" x="11.43" y="0" drill="1" shape="long" rot="R90"/>
<pad name="12" x="13.97" y="0" drill="1" shape="long" rot="R90"/>
<text x="-15.24" y="3.81" size="1.016" layer="25" ratio="14">&gt;NAME</text>
<text x="-15.24" y="-5.08" size="1.016" layer="27" ratio="14">&gt;VALUE</text>
</package>
<package name="7395-02">
<description>&lt;b&gt;MOLEX 2.54mm KK RA CONNECTOR&lt;/b&gt;
&lt;br&gt;Fixed Orientation</description>
<wire x1="2.54" y1="-5.08" x2="2.54" y2="-1.905" width="0.254" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="1.905" y2="-1.905" width="0.254" layer="21"/>
<wire x1="1.905" y1="-1.905" x2="1.905" y2="-2.54" width="0.254" layer="21"/>
<wire x1="1.905" y1="-2.54" x2="0.635" y2="-2.54" width="0.254" layer="21"/>
<wire x1="0.635" y1="-2.54" x2="0.635" y2="-1.905" width="0.254" layer="21"/>
<wire x1="0.635" y1="-1.905" x2="-0.635" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-1.905" x2="-0.635" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-2.54" x2="-1.905" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-2.54" x2="-1.905" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-1.905" x2="-2.54" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-2.54" y1="-1.905" x2="-2.54" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-2.54" y1="-5.08" x2="-1.651" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-1.651" y1="-5.08" x2="1.27" y2="-5.08" width="0.254" layer="21"/>
<wire x1="1.27" y1="-5.08" x2="2.54" y2="-5.08" width="0.254" layer="21"/>
<wire x1="1.27" y1="-5.08" x2="1.27" y2="-13.081" width="0.254" layer="21"/>
<wire x1="1.27" y1="-13.081" x2="1.016" y2="-13.589" width="0.254" layer="21"/>
<wire x1="1.016" y1="-13.589" x2="-0.0508" y2="-13.589" width="0.254" layer="21"/>
<wire x1="-1.27" y1="-5.08" x2="-1.27" y2="-13.081" width="0.254" layer="21"/>
<wire x1="-1.27" y1="-13.081" x2="-1.016" y2="-13.589" width="0.254" layer="21"/>
<wire x1="-1.016" y1="-13.589" x2="-0.0508" y2="-13.589" width="0.254" layer="21"/>
<wire x1="-0.0508" y1="-13.589" x2="0.0508" y2="-13.589" width="0.254" layer="21"/>
<wire x1="1.27" y1="-5.08" x2="0.889" y2="-5.08" width="0.254" layer="51"/>
<wire x1="-1.651" y1="-5.08" x2="-1.651" y2="-11.303" width="0.254" layer="21"/>
<wire x1="-1.651" y1="-11.303" x2="-1.3208" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="1.651" y1="-5.08" x2="1.651" y2="-11.303" width="0.254" layer="21"/>
<wire x1="1.651" y1="-11.303" x2="1.3208" y2="-11.6586" width="0.254" layer="21"/>
<pad name="1" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="2.6401" y="2.9479" size="1.016" layer="25" ratio="14" rot="R180">&gt;NAME</text>
<text x="0.7859" y="-3.4021" size="1.27" layer="21" ratio="14" rot="R270">1</text>
<text x="-1.7033" y="-3.2751" size="1.27" layer="21" ratio="14" rot="R270">2</text>
<text x="3.4021" y="-2.4399" size="0.8128" layer="27" ratio="10" rot="R270">&gt;VALUE</text>
<rectangle x1="1.016" y1="-0.254" x2="1.524" y2="0.254" layer="51"/>
<rectangle x1="-1.524" y1="-0.254" x2="-1.016" y2="0.254" layer="51"/>
<rectangle x1="1.016" y1="-2.5146" x2="1.524" y2="-0.2794" layer="51"/>
<rectangle x1="-1.524" y1="-2.5146" x2="-1.016" y2="-0.2794" layer="51"/>
</package>
<package name="6410-02">
<description>&lt;b&gt;MOLEX 2.54mm KK  CONNECTOR&lt;/b&gt;</description>
<wire x1="-1.27" y1="2.54" x2="-1.27" y2="2.921" width="0.127" layer="21"/>
<wire x1="-2.54" y1="0" x2="-2.54" y2="2.921" width="0.254" layer="21"/>
<wire x1="-2.54" y1="2.921" x2="-1.27" y2="2.921" width="0.254" layer="21"/>
<wire x1="-1.016" y1="2.921" x2="-1.27" y2="2.921" width="0.127" layer="21"/>
<wire x1="-1.27" y1="2.921" x2="0" y2="2.921" width="0.254" layer="21"/>
<wire x1="2.54" y1="0" x2="2.54" y2="2.921" width="0.254" layer="21"/>
<wire x1="2.54" y1="2.921" x2="0" y2="2.921" width="0.127" layer="21"/>
<wire x1="-2.54" y1="0" x2="-2.54" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-2.54" y1="-2.921" x2="0" y2="-2.921" width="0.254" layer="21"/>
<wire x1="2.54" y1="0" x2="2.54" y2="-2.921" width="0.254" layer="21"/>
<wire x1="2.54" y1="-2.921" x2="1.905" y2="-2.921" width="0.127" layer="21"/>
<wire x1="1.905" y1="-2.921" x2="0.635" y2="-2.921" width="0.254" layer="21"/>
<wire x1="0.635" y1="-2.921" x2="0" y2="-2.921" width="0.127" layer="21"/>
<wire x1="-2.286" y1="-2.921" x2="-1.905" y2="-2.921" width="0.127" layer="21"/>
<wire x1="-2.54" y1="-2.921" x2="-1.905" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-2.921" x2="-1.905" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-2.286" x2="-0.635" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-2.286" x2="-0.635" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-2.921" x2="0.635" y2="-2.921" width="0.254" layer="21"/>
<wire x1="0.635" y1="-2.921" x2="0.635" y2="-2.286" width="0.254" layer="21"/>
<wire x1="0.635" y1="-2.286" x2="1.905" y2="-2.286" width="0.254" layer="21"/>
<wire x1="1.905" y1="-2.286" x2="1.905" y2="-2.921" width="0.254" layer="21"/>
<wire x1="1.905" y1="-2.921" x2="2.54" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-1.27" y1="1.905" x2="-1.27" y2="2.921" width="0.254" layer="21"/>
<wire x1="-1.27" y1="1.905" x2="-1.016" y2="1.905" width="0.254" layer="21"/>
<wire x1="-1.016" y1="1.905" x2="1.016" y2="1.905" width="0.254" layer="21"/>
<wire x1="1.016" y1="1.905" x2="1.27" y2="1.905" width="0.254" layer="21"/>
<wire x1="1.27" y1="1.905" x2="1.27" y2="2.921" width="0.254" layer="21"/>
<wire x1="-1.27" y1="1.905" x2="-1.016" y2="1.397" width="0.254" layer="21"/>
<wire x1="-1.016" y1="2.921" x2="-1.016" y2="1.905" width="0.254" layer="21"/>
<wire x1="-1.016" y1="1.397" x2="1.016" y2="1.397" width="0.254" layer="21"/>
<wire x1="1.016" y1="1.397" x2="1.27" y2="1.905" width="0.254" layer="21"/>
<wire x1="1.016" y1="2.921" x2="1.016" y2="1.905" width="0.254" layer="21"/>
<text x="-2.5131" y="3.2751" size="1.016" layer="25" ratio="14">&gt;NAME</text>
<text x="3.2751" y="-0.6111" size="1.27" layer="21" ratio="14">1</text>
<text x="-3.7099" y="-0.6873" size="1.27" layer="21" ratio="14">2</text>
<text x="-2.5131" y="-4.5989" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="7395-03">
<wire x1="3.81" y1="-5.08" x2="3.81" y2="-1.905" width="0.254" layer="21"/>
<wire x1="3.81" y1="-1.905" x2="3.175" y2="-1.905" width="0.254" layer="21"/>
<wire x1="3.175" y1="-1.905" x2="3.175" y2="-2.54" width="0.254" layer="21"/>
<wire x1="3.175" y1="-2.54" x2="1.905" y2="-2.54" width="0.254" layer="21"/>
<wire x1="1.905" y1="-2.54" x2="1.905" y2="-1.905" width="0.254" layer="21"/>
<wire x1="1.905" y1="-1.905" x2="0.635" y2="-1.905" width="0.254" layer="21"/>
<wire x1="0.635" y1="-1.905" x2="0.635" y2="-2.54" width="0.254" layer="21"/>
<wire x1="0.635" y1="-2.54" x2="-0.635" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-2.54" x2="-0.635" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-1.905" x2="-1.905" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-1.905" x2="-1.905" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-2.54" x2="-3.175" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-3.175" y1="-2.54" x2="-3.175" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-3.175" y1="-1.905" x2="-3.81" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-3.81" y1="-1.905" x2="-3.81" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-3.81" y1="-5.08" x2="-2.921" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-2.921" y1="-5.08" x2="2.54" y2="-5.08" width="0.127" layer="21"/>
<wire x1="2.54" y1="-5.08" x2="3.81" y2="-5.08" width="0.254" layer="21"/>
<wire x1="2.54" y1="-5.08" x2="2.54" y2="-13.081" width="0.254" layer="21"/>
<wire x1="2.54" y1="-13.081" x2="2.286" y2="-13.589" width="0.254" layer="21"/>
<wire x1="2.286" y1="-13.589" x2="-1.3208" y2="-13.589" width="0.254" layer="21"/>
<wire x1="-2.54" y1="-5.08" x2="-2.54" y2="-13.081" width="0.254" layer="21"/>
<wire x1="-2.54" y1="-13.081" x2="-2.286" y2="-13.589" width="0.254" layer="21"/>
<wire x1="-2.286" y1="-13.589" x2="-1.2192" y2="-13.589" width="0.254" layer="21"/>
<wire x1="0" y1="-5.08" x2="-0.381" y2="-5.08" width="0.254" layer="51"/>
<wire x1="-2.921" y1="-5.08" x2="-2.921" y2="-11.303" width="0.254" layer="21"/>
<wire x1="-2.921" y1="-11.303" x2="-2.5908" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="2.921" y1="-5.08" x2="2.921" y2="-11.303" width="0.254" layer="21"/>
<wire x1="2.921" y1="-11.303" x2="2.5908" y2="-11.6586" width="0.254" layer="21"/>
<pad name="1" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="3.9101" y="2.9479" size="1.016" layer="25" ratio="14" rot="R180">&gt;NAME</text>
<text x="2.0559" y="-3.4021" size="1.27" layer="21" ratio="14" rot="R270">1</text>
<text x="-2.9733" y="-3.2751" size="1.27" layer="21" ratio="14" rot="R270">3</text>
<text x="4.6721" y="-2.4399" size="0.8128" layer="27" ratio="10" rot="R270">&gt;VALUE</text>
<rectangle x1="2.286" y1="-0.254" x2="2.794" y2="0.254" layer="51"/>
<rectangle x1="-0.254" y1="-0.254" x2="0.254" y2="0.254" layer="51"/>
<rectangle x1="-2.794" y1="-0.254" x2="-2.286" y2="0.254" layer="51"/>
<rectangle x1="2.286" y1="-2.5146" x2="2.794" y2="-0.2794" layer="51"/>
<rectangle x1="-0.254" y1="-2.5146" x2="0.254" y2="-0.2794" layer="51"/>
<rectangle x1="-2.794" y1="-2.5146" x2="-2.286" y2="-0.2794" layer="51"/>
</package>
<package name="6410-03">
<wire x1="-2.54" y1="2.54" x2="-2.54" y2="2.921" width="0.127" layer="21"/>
<wire x1="-3.81" y1="0" x2="-3.81" y2="2.921" width="0.254" layer="21"/>
<wire x1="-3.81" y1="2.921" x2="-2.54" y2="2.921" width="0.254" layer="21"/>
<wire x1="-2.286" y1="2.921" x2="-2.54" y2="2.921" width="0.127" layer="21"/>
<wire x1="3.81" y1="0" x2="3.81" y2="2.921" width="0.254" layer="21"/>
<wire x1="3.81" y1="2.921" x2="-1.27" y2="2.921" width="0.254" layer="21"/>
<wire x1="-3.81" y1="0" x2="-3.81" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-3.81" y1="-2.921" x2="-1.27" y2="-2.921" width="0.127" layer="21"/>
<wire x1="3.81" y1="0" x2="3.81" y2="-2.921" width="0.254" layer="21"/>
<wire x1="3.175" y1="-2.921" x2="1.905" y2="-2.921" width="0.254" layer="21"/>
<wire x1="0.635" y1="-2.921" x2="-0.635" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-2.921" x2="-1.27" y2="-2.921" width="0.127" layer="21"/>
<wire x1="-3.556" y1="-2.921" x2="-3.175" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-3.175" y1="-2.921" x2="-3.175" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-3.175" y1="-2.286" x2="-1.905" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-2.286" x2="-1.905" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-2.921" x2="-3.175" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-2.921" x2="-0.635" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-2.921" x2="-0.635" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-2.286" x2="0.635" y2="-2.286" width="0.254" layer="21"/>
<wire x1="0.635" y1="-2.286" x2="0.635" y2="-2.921" width="0.254" layer="21"/>
<wire x1="0.635" y1="-2.921" x2="1.905" y2="-2.921" width="0.254" layer="21"/>
<wire x1="1.905" y1="-2.921" x2="1.905" y2="-2.286" width="0.254" layer="21"/>
<wire x1="1.905" y1="-2.286" x2="3.175" y2="-2.286" width="0.254" layer="21"/>
<wire x1="3.175" y1="-2.286" x2="3.175" y2="-2.921" width="0.254" layer="21"/>
<wire x1="3.175" y1="-2.921" x2="3.81" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-2.54" y2="2.921" width="0.254" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-2.286" y2="1.905" width="0.254" layer="21"/>
<wire x1="-2.286" y1="1.905" x2="2.286" y2="1.905" width="0.254" layer="21"/>
<wire x1="2.286" y1="1.905" x2="2.54" y2="1.905" width="0.254" layer="21"/>
<wire x1="2.54" y1="1.905" x2="2.54" y2="2.921" width="0.254" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-2.286" y2="1.397" width="0.254" layer="21"/>
<wire x1="-2.286" y1="2.921" x2="-2.286" y2="1.905" width="0.254" layer="21"/>
<wire x1="-2.286" y1="1.397" x2="2.286" y2="1.397" width="0.254" layer="21"/>
<wire x1="2.286" y1="1.397" x2="2.54" y2="1.905" width="0.254" layer="21"/>
<wire x1="2.286" y1="2.921" x2="2.286" y2="1.905" width="0.254" layer="21"/>
<text x="-3.7831" y="3.2751" size="1.016" layer="25" ratio="14">&gt;NAME</text>
<text x="4.4181" y="-0.7381" size="1.27" layer="21" ratio="14">1</text>
<text x="-4.9799" y="-0.6873" size="1.27" layer="21" ratio="14">3</text>
<text x="-3.7831" y="-4.5989" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="7395-04">
<wire x1="5.08" y1="-5.08" x2="5.08" y2="-1.905" width="0.254" layer="21"/>
<wire x1="5.08" y1="-1.905" x2="4.445" y2="-1.905" width="0.254" layer="21"/>
<wire x1="4.445" y1="-1.905" x2="4.445" y2="-2.54" width="0.254" layer="21"/>
<wire x1="4.445" y1="-2.54" x2="3.175" y2="-2.54" width="0.254" layer="21"/>
<wire x1="3.175" y1="-2.54" x2="3.175" y2="-1.905" width="0.254" layer="21"/>
<wire x1="3.175" y1="-1.905" x2="1.905" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-1.905" x2="-3.175" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-3.175" y1="-1.905" x2="-3.175" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-3.175" y1="-2.54" x2="-4.445" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-4.445" y1="-2.54" x2="-4.445" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-4.445" y1="-1.905" x2="-5.08" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-5.08" y1="-1.905" x2="-5.08" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-5.08" y1="-5.08" x2="-4.191" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-4.191" y1="-5.08" x2="3.81" y2="-5.08" width="0.254" layer="21"/>
<wire x1="3.81" y1="-5.08" x2="5.08" y2="-5.08" width="0.254" layer="21"/>
<wire x1="3.81" y1="-5.08" x2="3.81" y2="-13.081" width="0.254" layer="21"/>
<wire x1="3.81" y1="-13.081" x2="3.556" y2="-13.589" width="0.254" layer="21"/>
<wire x1="3.556" y1="-13.589" x2="-0.0508" y2="-13.589" width="0.254" layer="21"/>
<wire x1="-3.81" y1="-5.08" x2="-3.81" y2="-13.081" width="0.254" layer="21"/>
<wire x1="-3.81" y1="-13.081" x2="-3.556" y2="-13.589" width="0.254" layer="21"/>
<wire x1="-3.556" y1="-13.589" x2="0.0508" y2="-13.589" width="0.254" layer="21"/>
<wire x1="-4.191" y1="-5.08" x2="-4.191" y2="-11.303" width="0.254" layer="21"/>
<wire x1="-4.191" y1="-11.303" x2="-3.8608" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="4.191" y1="-5.08" x2="4.191" y2="-11.303" width="0.254" layer="21"/>
<wire x1="4.191" y1="-11.303" x2="3.8608" y2="-11.6586" width="0.254" layer="21"/>
<pad name="1" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="5.1801" y="2.9479" size="1.016" layer="25" ratio="14" rot="R180">&gt;NAME</text>
<text x="3.3259" y="-3.4021" size="1.27" layer="21" ratio="14" rot="R270">1</text>
<text x="-4.2433" y="-3.2751" size="1.27" layer="21" ratio="14" rot="R270">4</text>
<text x="5.9421" y="-2.4399" size="0.8128" layer="27" ratio="10" rot="R270">&gt;VALUE</text>
<rectangle x1="3.556" y1="-0.254" x2="4.064" y2="0.254" layer="51"/>
<rectangle x1="-4.064" y1="-0.254" x2="-3.556" y2="0.254" layer="51"/>
<rectangle x1="3.556" y1="-2.5146" x2="4.064" y2="-0.2794" layer="51"/>
<rectangle x1="-4.064" y1="-2.5146" x2="-3.556" y2="-0.2794" layer="51"/>
</package>
<package name="6410-04">
<wire x1="-3.81" y1="2.54" x2="-3.81" y2="2.921" width="0.127" layer="21"/>
<wire x1="-5.08" y1="0" x2="-5.08" y2="2.921" width="0.254" layer="21"/>
<wire x1="-5.08" y1="2.921" x2="-3.81" y2="2.921" width="0.254" layer="21"/>
<wire x1="-3.556" y1="2.921" x2="-3.81" y2="2.921" width="0.127" layer="21"/>
<wire x1="5.08" y1="0" x2="5.08" y2="2.921" width="0.254" layer="21"/>
<wire x1="5.08" y1="2.921" x2="-2.54" y2="2.921" width="0.254" layer="21"/>
<wire x1="-5.08" y1="0" x2="-5.08" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="-2.667" y2="-2.921" width="0.127" layer="21"/>
<wire x1="5.08" y1="0" x2="5.08" y2="-2.921" width="0.254" layer="21"/>
<wire x1="5.08" y1="-2.921" x2="-2.667" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-4.826" y1="-2.921" x2="-4.445" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-4.445" y1="-2.921" x2="-4.445" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-4.445" y1="-2.286" x2="-3.175" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-3.175" y1="-2.286" x2="-3.175" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-2.921" x2="-4.445" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-3.175" y1="-2.921" x2="-1.905" y2="-2.921" width="0.254" layer="21"/>
<wire x1="1.905" y1="-2.921" x2="3.175" y2="-2.921" width="0.254" layer="21"/>
<wire x1="3.175" y1="-2.921" x2="3.175" y2="-2.286" width="0.254" layer="21"/>
<wire x1="3.175" y1="-2.286" x2="4.445" y2="-2.286" width="0.254" layer="21"/>
<wire x1="4.445" y1="-2.286" x2="4.445" y2="-2.921" width="0.254" layer="21"/>
<wire x1="4.445" y1="-2.921" x2="5.08" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-3.81" y1="1.905" x2="-3.81" y2="2.921" width="0.254" layer="21"/>
<wire x1="-3.81" y1="1.905" x2="-3.556" y2="1.905" width="0.254" layer="21"/>
<wire x1="-3.556" y1="1.905" x2="3.556" y2="1.905" width="0.254" layer="21"/>
<wire x1="3.556" y1="1.905" x2="3.81" y2="1.905" width="0.254" layer="21"/>
<wire x1="3.81" y1="1.905" x2="3.81" y2="2.921" width="0.254" layer="21"/>
<wire x1="-3.81" y1="1.905" x2="-3.556" y2="1.397" width="0.254" layer="21"/>
<wire x1="-3.556" y1="2.921" x2="-3.556" y2="1.905" width="0.254" layer="21"/>
<wire x1="-3.556" y1="1.397" x2="3.556" y2="1.397" width="0.254" layer="21"/>
<wire x1="3.556" y1="1.397" x2="3.81" y2="1.905" width="0.254" layer="21"/>
<wire x1="3.556" y1="2.921" x2="3.556" y2="1.905" width="0.254" layer="21"/>
<text x="-5.0531" y="3.2751" size="1.016" layer="25" ratio="14">&gt;NAME</text>
<text x="5.6881" y="-0.7381" size="1.27" layer="21" ratio="14">1</text>
<text x="-6.2499" y="-0.6873" size="1.27" layer="21" ratio="14">4</text>
<text x="-5.0531" y="-4.5989" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="7395-05">
<wire x1="6.35" y1="-5.08" x2="6.35" y2="-1.905" width="0.254" layer="21"/>
<wire x1="6.35" y1="-1.905" x2="5.715" y2="-1.905" width="0.254" layer="21"/>
<wire x1="5.715" y1="-1.905" x2="5.715" y2="-2.54" width="0.254" layer="21"/>
<wire x1="5.715" y1="-2.54" x2="4.445" y2="-2.54" width="0.254" layer="21"/>
<wire x1="4.445" y1="-2.54" x2="4.445" y2="-1.905" width="0.254" layer="21"/>
<wire x1="4.445" y1="-1.905" x2="3.175" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-3.175" y1="-1.905" x2="-4.445" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-4.445" y1="-1.905" x2="-4.445" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-4.445" y1="-2.54" x2="-5.715" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-5.715" y1="-2.54" x2="-5.715" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-5.715" y1="-1.905" x2="-6.35" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-6.35" y1="-1.905" x2="-6.35" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-6.35" y1="-5.08" x2="-5.461" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-5.461" y1="-5.08" x2="5.08" y2="-5.08" width="0.127" layer="21"/>
<wire x1="5.08" y1="-5.08" x2="6.35" y2="-5.08" width="0.254" layer="21"/>
<wire x1="5.08" y1="-5.08" x2="5.08" y2="-13.081" width="0.254" layer="21"/>
<wire x1="5.08" y1="-13.081" x2="4.826" y2="-13.589" width="0.254" layer="21"/>
<wire x1="4.826" y1="-13.589" x2="-0.0508" y2="-13.589" width="0.254" layer="21"/>
<wire x1="-5.08" y1="-5.08" x2="-5.08" y2="-13.081" width="0.254" layer="21"/>
<wire x1="-5.08" y1="-13.081" x2="-4.826" y2="-13.589" width="0.254" layer="21"/>
<wire x1="-4.826" y1="-13.589" x2="0.0508" y2="-13.589" width="0.254" layer="21"/>
<wire x1="-5.461" y1="-5.08" x2="-5.461" y2="-11.303" width="0.254" layer="21"/>
<wire x1="-5.461" y1="-11.303" x2="-5.1308" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="5.461" y1="-5.08" x2="5.461" y2="-11.303" width="0.254" layer="21"/>
<wire x1="5.461" y1="-11.303" x2="5.1308" y2="-11.6586" width="0.254" layer="21"/>
<pad name="1" x="5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="6.4501" y="2.9479" size="1.016" layer="25" ratio="14" rot="R180">&gt;NAME</text>
<text x="4.5959" y="-3.4021" size="1.27" layer="21" ratio="14" rot="R270">1</text>
<text x="-5.5133" y="-3.2751" size="1.27" layer="21" ratio="14" rot="R270">5</text>
<text x="7.2121" y="-2.4399" size="0.8128" layer="27" ratio="10" rot="R270">&gt;VALUE</text>
<rectangle x1="4.826" y1="-0.254" x2="5.334" y2="0.254" layer="51"/>
<rectangle x1="-5.334" y1="-0.254" x2="-4.826" y2="0.254" layer="51"/>
<rectangle x1="4.826" y1="-2.5146" x2="5.334" y2="-0.2794" layer="51"/>
<rectangle x1="-5.334" y1="-2.5146" x2="-4.826" y2="-0.2794" layer="51"/>
</package>
<package name="6410-05">
<wire x1="-5.08" y1="2.54" x2="-5.08" y2="2.921" width="0.127" layer="21"/>
<wire x1="-6.35" y1="0" x2="-6.35" y2="2.921" width="0.254" layer="21"/>
<wire x1="-6.35" y1="2.921" x2="-5.08" y2="2.921" width="0.254" layer="21"/>
<wire x1="-5.08" y1="2.921" x2="-4.826" y2="2.921" width="0.254" layer="21"/>
<wire x1="-4.826" y1="2.921" x2="1.27" y2="2.921" width="0.254" layer="21"/>
<wire x1="6.35" y1="0" x2="6.35" y2="2.921" width="0.254" layer="21"/>
<wire x1="6.35" y1="2.921" x2="1.27" y2="2.921" width="0.254" layer="21"/>
<wire x1="-6.35" y1="0" x2="-6.35" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-6.35" y1="-2.921" x2="1.27" y2="-2.921" width="0.254" layer="21"/>
<wire x1="6.35" y1="0" x2="6.35" y2="-2.921" width="0.254" layer="21"/>
<wire x1="5.715" y1="-2.921" x2="4.445" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-6.096" y1="-2.921" x2="-5.715" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-5.715" y1="-2.921" x2="-5.715" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-5.715" y1="-2.286" x2="-4.445" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-4.445" y1="-2.286" x2="-4.445" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-4.445" y1="-2.921" x2="-3.175" y2="-2.921" width="0.254" layer="21"/>
<wire x1="3.175" y1="-2.921" x2="4.445" y2="-2.921" width="0.254" layer="21"/>
<wire x1="5.715" y1="-2.921" x2="6.35" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-5.08" y1="1.905" x2="-5.08" y2="2.921" width="0.254" layer="21"/>
<wire x1="-5.08" y1="1.905" x2="-4.826" y2="1.905" width="0.254" layer="21"/>
<wire x1="-4.826" y1="1.905" x2="4.826" y2="1.905" width="0.254" layer="21"/>
<wire x1="4.826" y1="1.905" x2="5.08" y2="1.905" width="0.254" layer="21"/>
<wire x1="5.08" y1="1.905" x2="5.08" y2="2.921" width="0.254" layer="21"/>
<wire x1="-5.08" y1="1.905" x2="-4.826" y2="1.397" width="0.254" layer="21"/>
<wire x1="-4.826" y1="2.921" x2="-4.826" y2="1.905" width="0.254" layer="21"/>
<wire x1="-4.826" y1="1.397" x2="4.826" y2="1.397" width="0.254" layer="21"/>
<wire x1="4.826" y1="1.397" x2="5.08" y2="1.905" width="0.254" layer="21"/>
<wire x1="4.826" y1="2.921" x2="4.826" y2="1.905" width="0.254" layer="21"/>
<wire x1="4.445" y1="-2.921" x2="4.445" y2="-2.286" width="0.254" layer="21"/>
<wire x1="4.445" y1="-2.286" x2="5.715" y2="-2.286" width="0.254" layer="21"/>
<wire x1="5.715" y1="-2.286" x2="5.715" y2="-2.921" width="0.254" layer="21"/>
<text x="-6.1961" y="3.2751" size="1.016" layer="25" ratio="14">&gt;NAME</text>
<text x="6.7041" y="-0.4841" size="1.27" layer="21" ratio="14">1</text>
<text x="-7.5199" y="-0.4333" size="1.27" layer="21" ratio="14">5</text>
<text x="-6.3231" y="-4.5989" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="7395-06">
<wire x1="7.62" y1="-5.08" x2="7.62" y2="-1.905" width="0.254" layer="21"/>
<wire x1="7.62" y1="-1.905" x2="6.985" y2="-1.905" width="0.254" layer="21"/>
<wire x1="6.985" y1="-1.905" x2="6.985" y2="-2.54" width="0.254" layer="21"/>
<wire x1="6.985" y1="-2.54" x2="5.715" y2="-2.54" width="0.254" layer="21"/>
<wire x1="5.715" y1="-2.54" x2="5.715" y2="-1.905" width="0.254" layer="21"/>
<wire x1="5.715" y1="-1.905" x2="4.445" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-4.445" y1="-1.905" x2="-5.715" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-5.715" y1="-1.905" x2="-5.715" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-5.715" y1="-2.54" x2="-6.985" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-6.985" y1="-2.54" x2="-6.985" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-6.985" y1="-1.905" x2="-7.62" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-7.62" y1="-1.905" x2="-7.62" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-7.62" y1="-5.08" x2="-6.731" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-6.731" y1="-5.08" x2="0.889" y2="-5.08" width="0.254" layer="21"/>
<wire x1="0.889" y1="-5.08" x2="1.2192" y2="-5.08" width="0.127" layer="21"/>
<wire x1="1.2192" y1="-5.08" x2="6.35" y2="-5.08" width="0.254" layer="21"/>
<wire x1="6.35" y1="-5.08" x2="7.62" y2="-5.08" width="0.254" layer="21"/>
<wire x1="6.35" y1="-5.08" x2="6.35" y2="-13.081" width="0.254" layer="21"/>
<wire x1="6.35" y1="-13.081" x2="6.096" y2="-13.589" width="0.254" layer="21"/>
<wire x1="6.096" y1="-13.589" x2="1.2192" y2="-13.589" width="0.254" layer="21"/>
<wire x1="1.2192" y1="-13.589" x2="1.2192" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="1.2192" y1="-11.6586" x2="1.2192" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-6.35" y1="-5.08" x2="-6.35" y2="-13.081" width="0.254" layer="21"/>
<wire x1="-6.35" y1="-13.081" x2="-6.096" y2="-13.589" width="0.254" layer="21"/>
<wire x1="-6.096" y1="-13.589" x2="-1.2192" y2="-13.589" width="0.254" layer="21"/>
<wire x1="-1.2192" y1="-13.589" x2="-1.2192" y2="-5.08" width="0.254" layer="21"/>
<wire x1="0.889" y1="-5.08" x2="0.889" y2="-11.303" width="0.254" layer="21"/>
<wire x1="0.889" y1="-11.303" x2="1.2192" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="-6.731" y1="-5.08" x2="-6.731" y2="-11.303" width="0.254" layer="21"/>
<wire x1="-6.731" y1="-11.303" x2="-6.4008" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="6.731" y1="-5.08" x2="6.731" y2="-11.303" width="0.254" layer="21"/>
<wire x1="6.731" y1="-11.303" x2="6.4008" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="-0.889" y1="-5.08" x2="-0.889" y2="-11.303" width="0.254" layer="21"/>
<wire x1="-0.889" y1="-11.303" x2="-1.2192" y2="-11.6586" width="0.254" layer="21"/>
<pad name="1" x="6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="7.7201" y="2.9479" size="1.016" layer="25" ratio="14" rot="R180">&gt;NAME</text>
<text x="5.8659" y="-3.4021" size="1.27" layer="21" ratio="14" rot="R270">1</text>
<text x="-6.7833" y="-3.2751" size="1.27" layer="21" ratio="14" rot="R270">6</text>
<text x="-2.4399" y="2.9479" size="0.8128" layer="27" ratio="10" rot="R180">&gt;VALUE</text>
<rectangle x1="6.096" y1="-0.254" x2="6.604" y2="0.254" layer="51"/>
<rectangle x1="-6.604" y1="-0.254" x2="-6.096" y2="0.254" layer="51"/>
<rectangle x1="6.096" y1="-2.5146" x2="6.604" y2="-0.2794" layer="51"/>
<rectangle x1="-6.604" y1="-2.5146" x2="-6.096" y2="-0.2794" layer="51"/>
</package>
<package name="6410-06">
<wire x1="-6.35" y1="2.54" x2="-6.35" y2="2.921" width="0.127" layer="21"/>
<wire x1="-7.62" y1="0" x2="-7.62" y2="2.921" width="0.254" layer="21"/>
<wire x1="-7.62" y1="2.921" x2="-6.35" y2="2.921" width="0.254" layer="21"/>
<wire x1="-6.35" y1="2.921" x2="-6.096" y2="2.921" width="0.254" layer="21"/>
<wire x1="-6.096" y1="2.921" x2="0" y2="2.921" width="0.254" layer="21"/>
<wire x1="7.62" y1="0" x2="7.62" y2="2.921" width="0.254" layer="21"/>
<wire x1="7.62" y1="2.921" x2="0" y2="2.921" width="0.254" layer="21"/>
<wire x1="-7.62" y1="0" x2="-7.62" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-7.62" y1="-2.921" x2="-0.127" y2="-2.921" width="0.254" layer="21"/>
<wire x1="7.62" y1="0" x2="7.62" y2="-2.921" width="0.254" layer="21"/>
<wire x1="7.62" y1="-2.921" x2="-0.127" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-7.366" y1="-2.921" x2="-6.985" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-6.985" y1="-2.921" x2="-6.985" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-6.985" y1="-2.286" x2="-5.715" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-5.715" y1="-2.286" x2="-5.715" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-5.715" y1="-2.921" x2="-4.445" y2="-2.921" width="0.254" layer="21"/>
<wire x1="4.445" y1="-2.921" x2="5.715" y2="-2.921" width="0.254" layer="21"/>
<wire x1="5.715" y1="-2.921" x2="5.715" y2="-2.286" width="0.254" layer="21"/>
<wire x1="5.715" y1="-2.286" x2="6.985" y2="-2.286" width="0.254" layer="21"/>
<wire x1="6.985" y1="-2.286" x2="6.985" y2="-2.921" width="0.254" layer="21"/>
<wire x1="6.985" y1="-2.921" x2="7.62" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-6.35" y1="1.905" x2="-6.35" y2="2.921" width="0.254" layer="21"/>
<wire x1="-6.35" y1="1.905" x2="-6.096" y2="1.905" width="0.254" layer="21"/>
<wire x1="-6.096" y1="1.905" x2="6.096" y2="1.905" width="0.254" layer="21"/>
<wire x1="6.096" y1="1.905" x2="6.35" y2="1.905" width="0.254" layer="21"/>
<wire x1="6.35" y1="1.905" x2="6.35" y2="2.921" width="0.254" layer="21"/>
<wire x1="-6.35" y1="1.905" x2="-6.096" y2="1.397" width="0.254" layer="21"/>
<wire x1="-6.096" y1="2.921" x2="-6.096" y2="1.905" width="0.254" layer="21"/>
<wire x1="-6.096" y1="1.397" x2="6.096" y2="1.397" width="0.254" layer="21"/>
<wire x1="6.096" y1="1.397" x2="6.35" y2="1.905" width="0.254" layer="21"/>
<wire x1="6.096" y1="2.921" x2="6.096" y2="1.905" width="0.254" layer="21"/>
<text x="-7.5931" y="-4.7259" size="1.016" layer="25" ratio="14">&gt;NAME</text>
<text x="7.9741" y="-0.3571" size="1.27" layer="21" ratio="14">1</text>
<text x="-8.7899" y="-0.4333" size="1.27" layer="21" ratio="14">6</text>
<text x="0.9159" y="-4.7259" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="7395-07">
<wire x1="8.89" y1="-5.08" x2="8.89" y2="-1.905" width="0.254" layer="21"/>
<wire x1="8.89" y1="-1.905" x2="8.255" y2="-1.905" width="0.254" layer="21"/>
<wire x1="8.255" y1="-1.905" x2="8.255" y2="-2.54" width="0.254" layer="21"/>
<wire x1="8.255" y1="-2.54" x2="6.985" y2="-2.54" width="0.254" layer="21"/>
<wire x1="6.985" y1="-2.54" x2="6.985" y2="-1.905" width="0.254" layer="21"/>
<wire x1="6.985" y1="-1.905" x2="5.715" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-5.715" y1="-1.905" x2="-6.985" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-6.985" y1="-1.905" x2="-6.985" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-6.985" y1="-2.54" x2="-8.255" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-8.255" y1="-2.54" x2="-8.255" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-8.255" y1="-1.905" x2="-8.89" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-8.89" y1="-1.905" x2="-8.89" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-8.89" y1="-5.08" x2="-8.001" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-8.001" y1="-5.08" x2="-0.381" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-0.381" y1="-5.08" x2="2.159" y2="-5.08" width="0.254" layer="21"/>
<wire x1="2.159" y1="-5.08" x2="2.4892" y2="-5.08" width="0.127" layer="21"/>
<wire x1="2.4892" y1="-5.08" x2="7.62" y2="-5.08" width="0.254" layer="21"/>
<wire x1="7.62" y1="-5.08" x2="8.89" y2="-5.08" width="0.254" layer="21"/>
<wire x1="7.62" y1="-5.08" x2="7.62" y2="-13.081" width="0.254" layer="21"/>
<wire x1="7.62" y1="-13.081" x2="7.366" y2="-13.589" width="0.254" layer="21"/>
<wire x1="7.366" y1="-13.589" x2="2.4892" y2="-13.589" width="0.254" layer="21"/>
<wire x1="2.4892" y1="-13.589" x2="2.4892" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="2.4892" y1="-11.6586" x2="2.4892" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-7.62" y1="-5.08" x2="-7.62" y2="-13.081" width="0.254" layer="21"/>
<wire x1="-7.62" y1="-13.081" x2="-7.366" y2="-13.589" width="0.254" layer="21"/>
<wire x1="-7.366" y1="-13.589" x2="-2.4892" y2="-13.589" width="0.254" layer="21"/>
<wire x1="-2.4892" y1="-13.589" x2="-2.4892" y2="-5.08" width="0.254" layer="21"/>
<wire x1="2.54" y1="-5.08" x2="2.159" y2="-5.08" width="0.254" layer="51"/>
<wire x1="2.159" y1="-5.08" x2="2.159" y2="-11.303" width="0.254" layer="21"/>
<wire x1="2.159" y1="-11.303" x2="2.4892" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="-8.001" y1="-5.08" x2="-8.001" y2="-11.303" width="0.254" layer="21"/>
<wire x1="-8.001" y1="-11.303" x2="-7.6708" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="8.001" y1="-5.08" x2="8.001" y2="-11.303" width="0.254" layer="21"/>
<wire x1="8.001" y1="-11.303" x2="7.6708" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="-2.159" y1="-5.08" x2="-2.159" y2="-11.303" width="0.254" layer="21"/>
<wire x1="-2.159" y1="-11.303" x2="-2.4892" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="0.381" y1="-5.08" x2="0.381" y2="-11.303" width="0.254" layer="21"/>
<wire x1="0.381" y1="-11.303" x2="0.0508" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="-0.381" y1="-5.08" x2="-0.381" y2="-11.303" width="0.254" layer="21"/>
<wire x1="-0.381" y1="-11.303" x2="-0.0508" y2="-11.6586" width="0.254" layer="21"/>
<pad name="1" x="7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="8.9901" y="2.9479" size="1.016" layer="25" ratio="14" rot="R180">&gt;NAME</text>
<text x="7.1359" y="-3.4021" size="1.27" layer="21" ratio="14" rot="R270">1</text>
<text x="-8.0533" y="-3.2751" size="1.27" layer="21" ratio="14" rot="R270">7</text>
<text x="-3.7099" y="2.9479" size="0.8128" layer="27" ratio="10" rot="R180">&gt;VALUE</text>
<rectangle x1="7.366" y1="-0.254" x2="7.874" y2="0.254" layer="51"/>
<rectangle x1="-7.874" y1="-0.254" x2="-7.366" y2="0.254" layer="51"/>
<rectangle x1="7.366" y1="-2.5146" x2="7.874" y2="-0.2794" layer="51"/>
<rectangle x1="-7.874" y1="-2.5146" x2="-7.366" y2="-0.2794" layer="51"/>
</package>
<package name="6410-07">
<wire x1="-7.62" y1="2.54" x2="-7.62" y2="2.921" width="0.127" layer="21"/>
<wire x1="-8.89" y1="0" x2="-8.89" y2="2.921" width="0.254" layer="21"/>
<wire x1="-8.89" y1="2.921" x2="-7.62" y2="2.921" width="0.254" layer="21"/>
<wire x1="-7.62" y1="2.921" x2="-7.366" y2="2.921" width="0.254" layer="21"/>
<wire x1="-7.366" y1="2.921" x2="-2.54" y2="2.921" width="0.254" layer="21"/>
<wire x1="8.89" y1="0" x2="8.89" y2="2.921" width="0.254" layer="21"/>
<wire x1="8.89" y1="2.921" x2="-1.27" y2="2.921" width="0.254" layer="21"/>
<wire x1="-8.89" y1="0" x2="-8.89" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-8.89" y1="-2.921" x2="-1.397" y2="-2.921" width="0.254" layer="21"/>
<wire x1="8.89" y1="0" x2="8.89" y2="-2.921" width="0.254" layer="21"/>
<wire x1="8.89" y1="-2.921" x2="-1.397" y2="-2.921" width="0.127" layer="21"/>
<wire x1="-8.636" y1="-2.921" x2="-8.255" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-8.255" y1="-2.921" x2="-8.255" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-8.255" y1="-2.286" x2="-6.985" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-6.985" y1="-2.286" x2="-6.985" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-6.985" y1="-2.921" x2="-5.715" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-2.921" x2="1.905" y2="-2.921" width="0.254" layer="21"/>
<wire x1="5.715" y1="-2.921" x2="6.985" y2="-2.921" width="0.254" layer="21"/>
<wire x1="6.985" y1="-2.921" x2="6.985" y2="-2.286" width="0.254" layer="21"/>
<wire x1="6.985" y1="-2.286" x2="8.255" y2="-2.286" width="0.254" layer="21"/>
<wire x1="8.255" y1="-2.286" x2="8.255" y2="-2.921" width="0.254" layer="21"/>
<wire x1="8.255" y1="-2.921" x2="8.89" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-7.62" y1="1.905" x2="-7.62" y2="2.921" width="0.254" layer="21"/>
<wire x1="-7.62" y1="1.905" x2="-7.366" y2="1.905" width="0.254" layer="21"/>
<wire x1="-7.366" y1="1.905" x2="-2.54" y2="1.905" width="0.254" layer="21"/>
<wire x1="2.54" y1="1.905" x2="7.366" y2="1.905" width="0.254" layer="21"/>
<wire x1="7.366" y1="1.905" x2="7.62" y2="1.905" width="0.254" layer="21"/>
<wire x1="7.62" y1="1.905" x2="7.62" y2="2.921" width="0.254" layer="21"/>
<wire x1="-7.62" y1="1.905" x2="-7.366" y2="1.397" width="0.254" layer="21"/>
<wire x1="-7.366" y1="1.397" x2="-2.794" y2="1.397" width="0.254" layer="21"/>
<wire x1="-2.794" y1="1.397" x2="-2.54" y2="1.905" width="0.254" layer="21"/>
<wire x1="-7.366" y1="2.921" x2="-7.366" y2="1.905" width="0.254" layer="21"/>
<wire x1="2.54" y1="1.905" x2="2.794" y2="1.397" width="0.254" layer="21"/>
<wire x1="2.794" y1="1.397" x2="7.366" y2="1.397" width="0.254" layer="21"/>
<wire x1="7.366" y1="1.397" x2="7.62" y2="1.905" width="0.254" layer="21"/>
<wire x1="7.366" y1="2.921" x2="7.366" y2="1.905" width="0.254" layer="21"/>
<text x="-8.8631" y="-4.5989" size="1.016" layer="25" ratio="14">&gt;NAME</text>
<text x="9.3711" y="-0.4841" size="1.27" layer="21" ratio="14">1</text>
<text x="-10.0599" y="-0.5603" size="1.27" layer="21" ratio="14">7</text>
<text x="2.1859" y="-4.5989" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="7395-08">
<wire x1="10.16" y1="-5.08" x2="10.16" y2="-1.905" width="0.254" layer="21"/>
<wire x1="10.16" y1="-1.905" x2="9.525" y2="-1.905" width="0.254" layer="21"/>
<wire x1="9.525" y1="-1.905" x2="9.525" y2="-2.54" width="0.254" layer="21"/>
<wire x1="9.525" y1="-2.54" x2="8.255" y2="-2.54" width="0.254" layer="21"/>
<wire x1="8.255" y1="-2.54" x2="8.255" y2="-1.905" width="0.254" layer="21"/>
<wire x1="8.255" y1="-1.905" x2="6.985" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-6.985" y1="-1.905" x2="-8.255" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-8.255" y1="-1.905" x2="-8.255" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-8.255" y1="-2.54" x2="-9.525" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-9.525" y1="-2.54" x2="-9.525" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-9.525" y1="-1.905" x2="-10.16" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-10.16" y1="-1.905" x2="-10.16" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-10.16" y1="-5.08" x2="-9.271" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-9.271" y1="-5.08" x2="-1.651" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-1.651" y1="-5.08" x2="0.889" y2="-5.08" width="0.254" layer="21"/>
<wire x1="0.889" y1="-5.08" x2="3.429" y2="-5.08" width="0.254" layer="21"/>
<wire x1="3.429" y1="-5.08" x2="3.7592" y2="-5.08" width="0.127" layer="21"/>
<wire x1="3.7592" y1="-5.08" x2="8.89" y2="-5.08" width="0.254" layer="21"/>
<wire x1="8.89" y1="-5.08" x2="10.16" y2="-5.08" width="0.254" layer="21"/>
<wire x1="8.89" y1="-5.08" x2="8.89" y2="-13.081" width="0.254" layer="21"/>
<wire x1="8.89" y1="-13.081" x2="8.636" y2="-13.589" width="0.254" layer="21"/>
<wire x1="8.636" y1="-13.589" x2="3.7592" y2="-13.589" width="0.254" layer="21"/>
<wire x1="3.7592" y1="-13.589" x2="3.7592" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="3.7592" y1="-11.6586" x2="3.7592" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-8.89" y1="-5.08" x2="-8.89" y2="-13.081" width="0.254" layer="21"/>
<wire x1="-8.89" y1="-13.081" x2="-8.636" y2="-13.589" width="0.254" layer="21"/>
<wire x1="-8.636" y1="-13.589" x2="-3.7592" y2="-13.589" width="0.254" layer="21"/>
<wire x1="-3.7592" y1="-13.589" x2="-3.7592" y2="-5.08" width="0.254" layer="21"/>
<wire x1="3.81" y1="-5.08" x2="3.429" y2="-5.08" width="0.254" layer="51"/>
<wire x1="3.429" y1="-5.08" x2="3.429" y2="-11.303" width="0.254" layer="21"/>
<wire x1="3.429" y1="-11.303" x2="3.7592" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="-9.271" y1="-5.08" x2="-9.271" y2="-11.303" width="0.254" layer="21"/>
<wire x1="-9.271" y1="-11.303" x2="-8.9408" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="9.271" y1="-5.08" x2="9.271" y2="-11.303" width="0.254" layer="21"/>
<wire x1="9.271" y1="-11.303" x2="8.9408" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="-3.429" y1="-5.08" x2="-3.429" y2="-11.303" width="0.254" layer="21"/>
<wire x1="-3.429" y1="-11.303" x2="-3.7592" y2="-11.6586" width="0.254" layer="21"/>
<pad name="1" x="8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="-8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="10.2601" y="2.9479" size="1.016" layer="25" ratio="14" rot="R180">&gt;NAME</text>
<text x="8.4059" y="-3.4021" size="1.27" layer="21" ratio="14" rot="R270">1</text>
<text x="-9.3233" y="-3.2751" size="1.27" layer="21" ratio="14" rot="R270">8</text>
<text x="-4.9799" y="2.9479" size="0.8128" layer="27" ratio="10" rot="R180">&gt;VALUE</text>
<rectangle x1="8.636" y1="-0.254" x2="9.144" y2="0.254" layer="51"/>
<rectangle x1="-9.144" y1="-0.254" x2="-8.636" y2="0.254" layer="51"/>
<rectangle x1="8.636" y1="-2.5146" x2="9.144" y2="-0.2794" layer="51"/>
<rectangle x1="-9.144" y1="-2.5146" x2="-8.636" y2="-0.2794" layer="51"/>
</package>
<package name="6410-08">
<wire x1="-8.89" y1="2.54" x2="-8.89" y2="2.921" width="0.127" layer="21"/>
<wire x1="-10.16" y1="0" x2="-10.16" y2="2.921" width="0.254" layer="21"/>
<wire x1="-10.16" y1="2.921" x2="-8.89" y2="2.921" width="0.254" layer="21"/>
<wire x1="-8.89" y1="2.921" x2="-8.636" y2="2.921" width="0.254" layer="21"/>
<wire x1="-8.636" y1="2.921" x2="-3.81" y2="2.921" width="0.254" layer="21"/>
<wire x1="10.16" y1="0" x2="10.16" y2="2.921" width="0.254" layer="21"/>
<wire x1="10.16" y1="2.921" x2="-2.54" y2="2.921" width="0.127" layer="21"/>
<wire x1="-10.16" y1="0" x2="-10.16" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-10.16" y1="-2.921" x2="-2.667" y2="-2.921" width="0.254" layer="21"/>
<wire x1="10.16" y1="0" x2="10.16" y2="-2.921" width="0.254" layer="21"/>
<wire x1="10.16" y1="-2.921" x2="-2.667" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-9.906" y1="-2.921" x2="-9.525" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-9.525" y1="-2.921" x2="-9.525" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-9.525" y1="-2.286" x2="-8.255" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-8.255" y1="-2.286" x2="-8.255" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-8.255" y1="-2.921" x2="-6.985" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-3.175" y1="-2.921" x2="3.175" y2="-2.921" width="0.254" layer="21"/>
<wire x1="6.985" y1="-2.921" x2="8.255" y2="-2.921" width="0.254" layer="21"/>
<wire x1="8.255" y1="-2.921" x2="8.255" y2="-2.286" width="0.254" layer="21"/>
<wire x1="8.255" y1="-2.286" x2="9.525" y2="-2.286" width="0.254" layer="21"/>
<wire x1="9.525" y1="-2.286" x2="9.525" y2="-2.921" width="0.254" layer="21"/>
<wire x1="9.525" y1="-2.921" x2="10.16" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-8.89" y1="1.905" x2="-8.89" y2="2.921" width="0.254" layer="21"/>
<wire x1="-8.89" y1="1.905" x2="-8.636" y2="1.905" width="0.254" layer="21"/>
<wire x1="-8.636" y1="1.905" x2="-3.81" y2="1.905" width="0.254" layer="21"/>
<wire x1="3.81" y1="1.905" x2="8.636" y2="1.905" width="0.254" layer="21"/>
<wire x1="8.636" y1="1.905" x2="8.89" y2="1.905" width="0.254" layer="21"/>
<wire x1="8.89" y1="1.905" x2="8.89" y2="2.921" width="0.254" layer="21"/>
<wire x1="-8.89" y1="1.905" x2="-8.636" y2="1.397" width="0.254" layer="21"/>
<wire x1="-8.636" y1="1.397" x2="-4.064" y2="1.397" width="0.254" layer="21"/>
<wire x1="-4.064" y1="1.397" x2="-3.81" y2="1.905" width="0.254" layer="21"/>
<wire x1="-8.636" y1="2.921" x2="-8.636" y2="1.905" width="0.254" layer="21"/>
<wire x1="3.81" y1="1.905" x2="4.064" y2="1.397" width="0.254" layer="21"/>
<wire x1="4.064" y1="1.397" x2="8.636" y2="1.397" width="0.254" layer="21"/>
<wire x1="8.636" y1="1.397" x2="8.89" y2="1.905" width="0.254" layer="21"/>
<wire x1="8.636" y1="2.921" x2="8.636" y2="1.905" width="0.254" layer="21"/>
<text x="-10.0061" y="-4.7259" size="1.016" layer="25" ratio="14">&gt;NAME</text>
<text x="10.5141" y="-0.4841" size="1.27" layer="21" ratio="14">1</text>
<text x="-11.3299" y="-0.5603" size="1.27" layer="21" ratio="14">8</text>
<text x="3.3289" y="-4.7259" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="7395-09">
<wire x1="11.43" y1="-5.08" x2="11.43" y2="-1.905" width="0.254" layer="21"/>
<wire x1="11.43" y1="-1.905" x2="10.795" y2="-1.905" width="0.254" layer="21"/>
<wire x1="10.795" y1="-1.905" x2="10.795" y2="-2.54" width="0.254" layer="21"/>
<wire x1="10.795" y1="-2.54" x2="9.525" y2="-2.54" width="0.254" layer="21"/>
<wire x1="9.525" y1="-2.54" x2="9.525" y2="-1.905" width="0.254" layer="21"/>
<wire x1="9.525" y1="-1.905" x2="8.255" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-8.255" y1="-1.905" x2="-9.525" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-9.525" y1="-1.905" x2="-9.525" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-9.525" y1="-2.54" x2="-10.795" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-10.795" y1="-2.54" x2="-10.795" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-10.795" y1="-1.905" x2="-11.43" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-11.43" y1="-1.905" x2="-11.43" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-11.43" y1="-5.08" x2="-10.541" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-10.541" y1="-5.08" x2="-2.921" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-2.921" y1="-5.08" x2="-0.381" y2="-5.08" width="0.254" layer="21"/>
<wire x1="2.159" y1="-5.08" x2="4.699" y2="-5.08" width="0.254" layer="21"/>
<wire x1="4.699" y1="-5.08" x2="5.0292" y2="-5.08" width="0.127" layer="21"/>
<wire x1="5.0292" y1="-5.08" x2="10.16" y2="-5.08" width="0.254" layer="21"/>
<wire x1="10.16" y1="-5.08" x2="11.43" y2="-5.08" width="0.254" layer="21"/>
<wire x1="10.16" y1="-5.08" x2="10.16" y2="-13.081" width="0.254" layer="21"/>
<wire x1="10.16" y1="-13.081" x2="9.906" y2="-13.589" width="0.254" layer="21"/>
<wire x1="9.906" y1="-13.589" x2="5.0292" y2="-13.589" width="0.254" layer="21"/>
<wire x1="5.0292" y1="-13.589" x2="5.0292" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="5.0292" y1="-11.6586" x2="5.0292" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-10.16" y1="-5.08" x2="-10.16" y2="-13.081" width="0.254" layer="21"/>
<wire x1="-10.16" y1="-13.081" x2="-9.906" y2="-13.589" width="0.254" layer="21"/>
<wire x1="-9.906" y1="-13.589" x2="-5.0292" y2="-13.589" width="0.254" layer="21"/>
<wire x1="-5.0292" y1="-13.589" x2="-5.0292" y2="-5.08" width="0.254" layer="21"/>
<wire x1="5.08" y1="-5.08" x2="4.699" y2="-5.08" width="0.254" layer="51"/>
<wire x1="4.699" y1="-5.08" x2="4.699" y2="-11.303" width="0.254" layer="21"/>
<wire x1="4.699" y1="-11.303" x2="5.0292" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="-10.541" y1="-5.08" x2="-10.541" y2="-11.303" width="0.254" layer="21"/>
<wire x1="-10.541" y1="-11.303" x2="-10.2108" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="10.541" y1="-5.08" x2="10.541" y2="-11.303" width="0.254" layer="21"/>
<wire x1="10.541" y1="-11.303" x2="10.2108" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="-4.699" y1="-5.08" x2="-4.699" y2="-11.303" width="0.254" layer="21"/>
<wire x1="-4.699" y1="-11.303" x2="-5.0292" y2="-11.6586" width="0.254" layer="21"/>
<pad name="1" x="10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="-7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="-10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="11.5301" y="2.9479" size="1.016" layer="25" ratio="14" rot="R180">&gt;NAME</text>
<text x="9.6759" y="-3.4021" size="1.27" layer="21" ratio="14" rot="R270">1</text>
<text x="-10.5933" y="-3.2751" size="1.27" layer="21" ratio="14" rot="R270">9</text>
<text x="-6.2499" y="2.9479" size="0.8128" layer="27" ratio="10" rot="R180">&gt;VALUE</text>
<rectangle x1="9.906" y1="-0.254" x2="10.414" y2="0.254" layer="51"/>
<rectangle x1="-10.414" y1="-0.254" x2="-9.906" y2="0.254" layer="51"/>
<rectangle x1="9.906" y1="-2.5146" x2="10.414" y2="-0.2794" layer="51"/>
<rectangle x1="-10.414" y1="-2.5146" x2="-9.906" y2="-0.2794" layer="51"/>
</package>
<package name="6410-09">
<wire x1="-10.16" y1="2.54" x2="-10.16" y2="2.921" width="0.127" layer="21"/>
<wire x1="-11.43" y1="0" x2="-11.43" y2="2.921" width="0.254" layer="21"/>
<wire x1="-11.43" y1="2.921" x2="-10.16" y2="2.921" width="0.254" layer="21"/>
<wire x1="-10.16" y1="2.921" x2="-9.906" y2="2.921" width="0.254" layer="21"/>
<wire x1="-9.906" y1="2.921" x2="-5.08" y2="2.921" width="0.254" layer="21"/>
<wire x1="11.43" y1="0" x2="11.43" y2="2.921" width="0.254" layer="21"/>
<wire x1="11.43" y1="2.921" x2="-3.81" y2="2.921" width="0.254" layer="21"/>
<wire x1="-11.43" y1="0" x2="-11.43" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-11.43" y1="-2.921" x2="-3.937" y2="-2.921" width="0.254" layer="21"/>
<wire x1="11.43" y1="0" x2="11.43" y2="-2.921" width="0.254" layer="21"/>
<wire x1="11.43" y1="-2.921" x2="-3.937" y2="-2.921" width="0.127" layer="21"/>
<wire x1="-11.176" y1="-2.921" x2="-10.795" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-10.795" y1="-2.921" x2="-10.795" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-10.795" y1="-2.286" x2="-9.525" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-9.525" y1="-2.286" x2="-9.525" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-9.525" y1="-2.921" x2="-8.255" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-4.445" y1="-2.921" x2="4.445" y2="-2.921" width="0.254" layer="21"/>
<wire x1="8.255" y1="-2.921" x2="9.525" y2="-2.921" width="0.254" layer="21"/>
<wire x1="9.525" y1="-2.921" x2="9.525" y2="-2.286" width="0.254" layer="21"/>
<wire x1="9.525" y1="-2.286" x2="10.795" y2="-2.286" width="0.254" layer="21"/>
<wire x1="10.795" y1="-2.286" x2="10.795" y2="-2.921" width="0.254" layer="21"/>
<wire x1="10.795" y1="-2.921" x2="11.43" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-10.16" y1="1.905" x2="-10.16" y2="2.921" width="0.254" layer="21"/>
<wire x1="-10.16" y1="1.905" x2="-9.906" y2="1.905" width="0.254" layer="21"/>
<wire x1="-9.906" y1="1.905" x2="-5.08" y2="1.905" width="0.254" layer="21"/>
<wire x1="5.08" y1="1.905" x2="9.906" y2="1.905" width="0.254" layer="21"/>
<wire x1="9.906" y1="1.905" x2="10.16" y2="1.905" width="0.254" layer="21"/>
<wire x1="10.16" y1="1.905" x2="10.16" y2="2.921" width="0.254" layer="21"/>
<wire x1="-10.16" y1="1.905" x2="-9.906" y2="1.397" width="0.254" layer="21"/>
<wire x1="-9.906" y1="1.397" x2="-5.334" y2="1.397" width="0.254" layer="21"/>
<wire x1="-5.334" y1="1.397" x2="-5.08" y2="1.905" width="0.254" layer="21"/>
<wire x1="-9.906" y1="2.921" x2="-9.906" y2="1.905" width="0.254" layer="21"/>
<wire x1="5.08" y1="1.905" x2="5.334" y2="1.397" width="0.254" layer="21"/>
<wire x1="5.334" y1="1.397" x2="9.906" y2="1.397" width="0.254" layer="21"/>
<wire x1="9.906" y1="1.397" x2="10.16" y2="1.905" width="0.254" layer="21"/>
<wire x1="9.906" y1="2.921" x2="9.906" y2="1.905" width="0.254" layer="21"/>
<text x="-11.4031" y="-4.7259" size="1.016" layer="25" ratio="14">&gt;NAME</text>
<text x="11.7841" y="-0.4841" size="1.27" layer="21" ratio="14">1</text>
<text x="-12.5999" y="-0.5603" size="1.27" layer="21" ratio="14">9</text>
<text x="4.5989" y="-4.7259" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="7395-10">
<wire x1="12.7" y1="-5.08" x2="12.7" y2="-1.905" width="0.254" layer="21"/>
<wire x1="12.7" y1="-1.905" x2="12.065" y2="-1.905" width="0.254" layer="21"/>
<wire x1="12.065" y1="-1.905" x2="12.065" y2="-2.54" width="0.254" layer="21"/>
<wire x1="12.065" y1="-2.54" x2="10.795" y2="-2.54" width="0.254" layer="21"/>
<wire x1="10.795" y1="-2.54" x2="10.795" y2="-1.905" width="0.254" layer="21"/>
<wire x1="10.795" y1="-1.905" x2="9.525" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-9.525" y1="-1.905" x2="-10.795" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-10.795" y1="-1.905" x2="-10.795" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-10.795" y1="-2.54" x2="-12.065" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-12.065" y1="-2.54" x2="-12.065" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-12.065" y1="-1.905" x2="-12.7" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-12.7" y1="-1.905" x2="-12.7" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-12.7" y1="-5.08" x2="-11.811" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-11.811" y1="-5.08" x2="-4.191" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-4.191" y1="-5.08" x2="-1.651" y2="-5.08" width="0.254" layer="21"/>
<wire x1="3.429" y1="-5.08" x2="5.969" y2="-5.08" width="0.254" layer="21"/>
<wire x1="5.969" y1="-5.08" x2="6.2992" y2="-5.08" width="0.127" layer="21"/>
<wire x1="6.2992" y1="-5.08" x2="11.43" y2="-5.08" width="0.254" layer="21"/>
<wire x1="11.43" y1="-5.08" x2="12.7" y2="-5.08" width="0.254" layer="21"/>
<wire x1="11.43" y1="-5.08" x2="11.43" y2="-13.081" width="0.254" layer="21"/>
<wire x1="11.43" y1="-13.081" x2="11.176" y2="-13.589" width="0.254" layer="21"/>
<wire x1="11.176" y1="-13.589" x2="6.2992" y2="-13.589" width="0.254" layer="21"/>
<wire x1="6.2992" y1="-13.589" x2="6.2992" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="6.2992" y1="-11.6586" x2="6.2992" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-11.43" y1="-5.08" x2="-11.43" y2="-13.081" width="0.254" layer="21"/>
<wire x1="-11.43" y1="-13.081" x2="-11.176" y2="-13.589" width="0.254" layer="21"/>
<wire x1="-11.176" y1="-13.589" x2="-6.2992" y2="-13.589" width="0.254" layer="21"/>
<wire x1="-6.2992" y1="-13.589" x2="-6.2992" y2="-5.08" width="0.254" layer="21"/>
<wire x1="6.35" y1="-5.08" x2="5.969" y2="-5.08" width="0.254" layer="51"/>
<wire x1="5.969" y1="-5.08" x2="5.969" y2="-11.303" width="0.254" layer="21"/>
<wire x1="5.969" y1="-11.303" x2="6.2992" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="-11.811" y1="-5.08" x2="-11.811" y2="-11.303" width="0.254" layer="21"/>
<wire x1="-11.811" y1="-11.303" x2="-11.4808" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="11.811" y1="-5.08" x2="11.811" y2="-11.303" width="0.254" layer="21"/>
<wire x1="11.811" y1="-11.303" x2="11.4808" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="-5.969" y1="-5.08" x2="-5.969" y2="-11.303" width="0.254" layer="21"/>
<wire x1="-5.969" y1="-11.303" x2="-6.2992" y2="-11.6586" width="0.254" layer="21"/>
<pad name="1" x="11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="-6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="-8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="-11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="12.8001" y="2.9479" size="1.016" layer="25" ratio="14" rot="R180">&gt;NAME</text>
<text x="10.9459" y="-3.4021" size="1.27" layer="21" ratio="14" rot="R270">1</text>
<text x="-12.1173" y="-2.5131" size="1.27" layer="21" ratio="14" rot="R270">10</text>
<text x="-7.5199" y="2.9479" size="0.8128" layer="27" ratio="10" rot="R180">&gt;VALUE</text>
<rectangle x1="11.176" y1="-0.254" x2="11.684" y2="0.254" layer="51"/>
<rectangle x1="-11.684" y1="-0.254" x2="-11.176" y2="0.254" layer="51"/>
<rectangle x1="11.176" y1="-2.5146" x2="11.684" y2="-0.2794" layer="51"/>
<rectangle x1="-11.684" y1="-2.5146" x2="-11.176" y2="-0.2794" layer="51"/>
</package>
<package name="6410-10">
<wire x1="-11.43" y1="2.54" x2="-11.43" y2="2.921" width="0.127" layer="21"/>
<wire x1="-12.7" y1="0" x2="-12.7" y2="2.921" width="0.254" layer="21"/>
<wire x1="-12.7" y1="2.921" x2="-11.43" y2="2.921" width="0.254" layer="21"/>
<wire x1="-11.43" y1="2.921" x2="-11.176" y2="2.921" width="0.254" layer="21"/>
<wire x1="-11.176" y1="2.921" x2="-6.35" y2="2.921" width="0.254" layer="21"/>
<wire x1="12.7" y1="0" x2="12.7" y2="2.921" width="0.254" layer="21"/>
<wire x1="12.7" y1="2.921" x2="-5.08" y2="2.921" width="0.254" layer="21"/>
<wire x1="-12.7" y1="0" x2="-12.7" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-12.7" y1="-2.921" x2="-5.207" y2="-2.921" width="0.254" layer="21"/>
<wire x1="12.7" y1="0" x2="12.7" y2="-2.921" width="0.254" layer="21"/>
<wire x1="12.7" y1="-2.921" x2="-5.207" y2="-2.921" width="0.127" layer="21"/>
<wire x1="-12.446" y1="-2.921" x2="-12.065" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-12.065" y1="-2.921" x2="-12.065" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-12.065" y1="-2.286" x2="-10.795" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-10.795" y1="-2.286" x2="-10.795" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-10.795" y1="-2.921" x2="-9.525" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-5.715" y1="-2.921" x2="5.715" y2="-2.921" width="0.254" layer="21"/>
<wire x1="9.525" y1="-2.921" x2="10.795" y2="-2.921" width="0.254" layer="21"/>
<wire x1="10.795" y1="-2.921" x2="10.795" y2="-2.286" width="0.254" layer="21"/>
<wire x1="10.795" y1="-2.286" x2="12.065" y2="-2.286" width="0.254" layer="21"/>
<wire x1="12.065" y1="-2.286" x2="12.065" y2="-2.921" width="0.254" layer="21"/>
<wire x1="12.065" y1="-2.921" x2="12.7" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-11.43" y1="1.905" x2="-11.43" y2="2.921" width="0.254" layer="21"/>
<wire x1="-11.43" y1="1.905" x2="-11.176" y2="1.905" width="0.254" layer="21"/>
<wire x1="-11.176" y1="1.905" x2="-6.35" y2="1.905" width="0.254" layer="21"/>
<wire x1="6.35" y1="1.905" x2="11.176" y2="1.905" width="0.254" layer="21"/>
<wire x1="11.176" y1="1.905" x2="11.43" y2="1.905" width="0.254" layer="21"/>
<wire x1="11.43" y1="1.905" x2="11.43" y2="2.921" width="0.254" layer="21"/>
<wire x1="-11.43" y1="1.905" x2="-11.176" y2="1.397" width="0.254" layer="21"/>
<wire x1="-11.176" y1="1.397" x2="-6.604" y2="1.397" width="0.254" layer="21"/>
<wire x1="-6.604" y1="1.397" x2="-6.35" y2="1.905" width="0.254" layer="21"/>
<wire x1="-11.176" y1="2.921" x2="-11.176" y2="1.905" width="0.254" layer="21"/>
<wire x1="6.35" y1="1.905" x2="6.604" y2="1.397" width="0.254" layer="21"/>
<wire x1="6.604" y1="1.397" x2="11.176" y2="1.397" width="0.254" layer="21"/>
<wire x1="11.176" y1="1.397" x2="11.43" y2="1.905" width="0.254" layer="21"/>
<wire x1="11.176" y1="2.921" x2="11.176" y2="1.905" width="0.254" layer="21"/>
<text x="-12.6731" y="-4.5989" size="1.016" layer="25" ratio="14">&gt;NAME</text>
<text x="13.1811" y="-0.4841" size="1.27" layer="21" ratio="14">1</text>
<text x="-14.8859" y="-0.5603" size="1.27" layer="21" ratio="14">10</text>
<text x="5.8689" y="-4.5989" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="7395-11">
<description>&lt;b&gt;MOLEX 2.54mm KK RA CONNECTOR&lt;/b&gt;
&lt;br&gt;Fixed Orientation</description>
<wire x1="13.97" y1="-5.08" x2="13.97" y2="-1.905" width="0.254" layer="21"/>
<wire x1="13.97" y1="-1.905" x2="13.335" y2="-1.905" width="0.254" layer="21"/>
<wire x1="13.335" y1="-1.905" x2="13.335" y2="-2.54" width="0.254" layer="21"/>
<wire x1="13.335" y1="-2.54" x2="12.065" y2="-2.54" width="0.254" layer="21"/>
<wire x1="12.065" y1="-2.54" x2="12.065" y2="-1.905" width="0.254" layer="21"/>
<wire x1="12.065" y1="-1.905" x2="10.795" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-10.795" y1="-1.905" x2="-12.065" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-12.065" y1="-1.905" x2="-12.065" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-12.065" y1="-2.54" x2="-13.335" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-13.335" y1="-2.54" x2="-13.335" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-13.335" y1="-1.905" x2="-13.97" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-13.97" y1="-1.905" x2="-13.97" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-13.97" y1="-5.08" x2="-13.081" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-13.081" y1="-5.08" x2="-5.461" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-5.461" y1="-5.08" x2="-2.921" y2="-5.08" width="0.254" layer="21"/>
<wire x1="4.699" y1="-5.08" x2="7.239" y2="-5.08" width="0.254" layer="21"/>
<wire x1="7.239" y1="-5.08" x2="7.5692" y2="-5.08" width="0.127" layer="21"/>
<wire x1="7.5692" y1="-5.08" x2="12.7" y2="-5.08" width="0.254" layer="21"/>
<wire x1="12.7" y1="-5.08" x2="13.97" y2="-5.08" width="0.254" layer="21"/>
<wire x1="12.7" y1="-5.08" x2="12.7" y2="-13.081" width="0.254" layer="21"/>
<wire x1="12.7" y1="-13.081" x2="12.446" y2="-13.589" width="0.254" layer="21"/>
<wire x1="12.446" y1="-13.589" x2="7.5692" y2="-13.589" width="0.254" layer="21"/>
<wire x1="7.5692" y1="-13.589" x2="7.5692" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="7.5692" y1="-11.6586" x2="7.5692" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-12.7" y1="-5.08" x2="-12.7" y2="-13.081" width="0.254" layer="21"/>
<wire x1="-12.7" y1="-13.081" x2="-12.446" y2="-13.589" width="0.254" layer="21"/>
<wire x1="-12.446" y1="-13.589" x2="-7.5692" y2="-13.589" width="0.254" layer="21"/>
<wire x1="-7.5692" y1="-13.589" x2="-7.5692" y2="-5.08" width="0.254" layer="21"/>
<wire x1="7.62" y1="-5.08" x2="7.239" y2="-5.08" width="0.254" layer="51"/>
<wire x1="7.239" y1="-5.08" x2="7.239" y2="-11.303" width="0.254" layer="21"/>
<wire x1="7.239" y1="-11.303" x2="7.5692" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="-13.081" y1="-5.08" x2="-13.081" y2="-11.303" width="0.254" layer="21"/>
<wire x1="-13.081" y1="-11.303" x2="-12.7508" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="13.081" y1="-5.08" x2="13.081" y2="-11.303" width="0.254" layer="21"/>
<wire x1="13.081" y1="-11.303" x2="12.7508" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="-7.239" y1="-5.08" x2="-7.239" y2="-11.303" width="0.254" layer="21"/>
<wire x1="-7.239" y1="-11.303" x2="-7.5692" y2="-11.6586" width="0.254" layer="21"/>
<pad name="1" x="12.7" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="-7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="-10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="-12.7" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="-5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="14.0701" y="2.9479" size="1.016" layer="25" ratio="14" rot="R180">&gt;NAME</text>
<text x="12.4699" y="-3.1481" size="1.27" layer="21" ratio="14" rot="R270">1</text>
<text x="-13.3873" y="-2.5131" size="1.27" layer="21" ratio="14" rot="R270">11</text>
<text x="-8.7899" y="2.9479" size="0.8128" layer="27" ratio="10" rot="R180">&gt;VALUE</text>
<rectangle x1="12.446" y1="-0.254" x2="12.954" y2="0.254" layer="51"/>
<rectangle x1="-12.954" y1="-0.254" x2="-12.446" y2="0.254" layer="51"/>
<rectangle x1="12.446" y1="-2.5146" x2="12.954" y2="-0.2794" layer="51"/>
<rectangle x1="-12.954" y1="-2.5146" x2="-12.446" y2="-0.2794" layer="51"/>
</package>
<package name="6410-11">
<description>&lt;b&gt;MOLEX 2.54mm KK  CONNECTOR&lt;/b&gt;</description>
<wire x1="-12.7" y1="2.54" x2="-12.7" y2="2.921" width="0.127" layer="21"/>
<wire x1="-13.97" y1="0" x2="-13.97" y2="2.921" width="0.254" layer="21"/>
<wire x1="-13.97" y1="2.921" x2="-12.7" y2="2.921" width="0.254" layer="21"/>
<wire x1="-12.7" y1="2.921" x2="-12.446" y2="2.921" width="0.254" layer="21"/>
<wire x1="-12.446" y1="2.921" x2="-7.62" y2="2.921" width="0.254" layer="21"/>
<wire x1="13.97" y1="0" x2="13.97" y2="2.921" width="0.254" layer="21"/>
<wire x1="13.97" y1="2.921" x2="-6.35" y2="2.921" width="0.254" layer="21"/>
<wire x1="-13.97" y1="0" x2="-13.97" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-13.97" y1="-2.921" x2="-9.017" y2="-2.921" width="0.127" layer="21"/>
<wire x1="13.97" y1="0" x2="13.97" y2="-2.921" width="0.254" layer="21"/>
<wire x1="13.97" y1="-2.921" x2="-9.017" y2="-2.921" width="0.127" layer="21"/>
<wire x1="-13.716" y1="-2.921" x2="-13.335" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-12.065" y1="-2.921" x2="-13.335" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-13.335" y1="-2.921" x2="-13.335" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-13.335" y1="-2.286" x2="-12.065" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-12.065" y1="-2.286" x2="-12.065" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-12.065" y1="-2.921" x2="-10.795" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-9.525" y1="-2.921" x2="6.985" y2="-2.921" width="0.254" layer="21"/>
<wire x1="10.795" y1="-2.921" x2="12.065" y2="-2.921" width="0.254" layer="21"/>
<wire x1="12.065" y1="-2.921" x2="12.065" y2="-2.286" width="0.254" layer="21"/>
<wire x1="12.065" y1="-2.286" x2="13.335" y2="-2.286" width="0.254" layer="21"/>
<wire x1="13.335" y1="-2.286" x2="13.335" y2="-2.921" width="0.254" layer="21"/>
<wire x1="13.335" y1="-2.921" x2="13.97" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-12.7" y1="1.905" x2="-12.7" y2="2.921" width="0.254" layer="21"/>
<wire x1="-12.7" y1="1.905" x2="-12.446" y2="1.905" width="0.254" layer="21"/>
<wire x1="-12.446" y1="1.905" x2="-7.62" y2="1.905" width="0.254" layer="21"/>
<wire x1="7.62" y1="1.905" x2="12.446" y2="1.905" width="0.254" layer="21"/>
<wire x1="12.446" y1="1.905" x2="12.7" y2="1.905" width="0.254" layer="21"/>
<wire x1="12.7" y1="1.905" x2="12.7" y2="2.921" width="0.254" layer="21"/>
<wire x1="-12.7" y1="1.905" x2="-12.446" y2="1.397" width="0.254" layer="21"/>
<wire x1="-12.446" y1="1.397" x2="-7.874" y2="1.397" width="0.254" layer="21"/>
<wire x1="-7.874" y1="1.397" x2="-7.62" y2="1.905" width="0.254" layer="21"/>
<wire x1="-12.446" y1="2.921" x2="-12.446" y2="1.905" width="0.254" layer="21"/>
<wire x1="7.62" y1="1.905" x2="7.874" y2="1.397" width="0.254" layer="21"/>
<wire x1="7.874" y1="1.397" x2="12.446" y2="1.397" width="0.254" layer="21"/>
<wire x1="12.446" y1="1.397" x2="12.7" y2="1.905" width="0.254" layer="21"/>
<wire x1="12.446" y1="2.921" x2="12.446" y2="1.905" width="0.254" layer="21"/>
<text x="-13.9431" y="-4.7259" size="1.016" layer="25" ratio="14">&gt;NAME</text>
<text x="14.4511" y="-0.4841" size="1.27" layer="21" ratio="14">1</text>
<text x="-15.7749" y="-0.6873" size="1.27" layer="21" ratio="14">11</text>
<text x="7.0119" y="-4.7259" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="7395-12">
<wire x1="15.24" y1="-5.08" x2="15.24" y2="-1.905" width="0.254" layer="21"/>
<wire x1="15.24" y1="-1.905" x2="14.605" y2="-1.905" width="0.254" layer="21"/>
<wire x1="14.605" y1="-1.905" x2="14.605" y2="-2.54" width="0.254" layer="21"/>
<wire x1="14.605" y1="-2.54" x2="13.335" y2="-2.54" width="0.254" layer="21"/>
<wire x1="13.335" y1="-2.54" x2="13.335" y2="-1.905" width="0.254" layer="21"/>
<wire x1="13.335" y1="-1.905" x2="12.065" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-12.065" y1="-1.905" x2="-13.335" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-13.335" y1="-1.905" x2="-13.335" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-13.335" y1="-2.54" x2="-14.605" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-14.605" y1="-2.54" x2="-14.605" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-14.605" y1="-1.905" x2="-15.24" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-15.24" y1="-1.905" x2="-15.24" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-15.24" y1="-5.08" x2="-14.351" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-14.351" y1="-5.08" x2="-6.731" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-6.731" y1="-5.08" x2="-4.191" y2="-5.08" width="0.254" layer="21"/>
<wire x1="5.969" y1="-5.08" x2="8.509" y2="-5.08" width="0.254" layer="21"/>
<wire x1="8.509" y1="-5.08" x2="8.8392" y2="-5.08" width="0.127" layer="21"/>
<wire x1="8.8392" y1="-5.08" x2="13.97" y2="-5.08" width="0.254" layer="21"/>
<wire x1="13.97" y1="-5.08" x2="15.24" y2="-5.08" width="0.254" layer="21"/>
<wire x1="13.97" y1="-5.08" x2="13.97" y2="-13.081" width="0.254" layer="21"/>
<wire x1="13.97" y1="-13.081" x2="13.716" y2="-13.589" width="0.254" layer="21"/>
<wire x1="13.716" y1="-13.589" x2="8.8392" y2="-13.589" width="0.254" layer="21"/>
<wire x1="8.8392" y1="-13.589" x2="8.8392" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="8.8392" y1="-11.6586" x2="8.8392" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-13.97" y1="-5.08" x2="-13.97" y2="-13.081" width="0.254" layer="21"/>
<wire x1="-13.97" y1="-13.081" x2="-13.716" y2="-13.589" width="0.254" layer="21"/>
<wire x1="-13.716" y1="-13.589" x2="-8.8392" y2="-13.589" width="0.254" layer="21"/>
<wire x1="-8.8392" y1="-13.589" x2="-8.8392" y2="-5.08" width="0.254" layer="21"/>
<wire x1="8.89" y1="-5.08" x2="8.509" y2="-5.08" width="0.254" layer="51"/>
<wire x1="8.509" y1="-5.08" x2="8.509" y2="-11.303" width="0.254" layer="21"/>
<wire x1="8.509" y1="-11.303" x2="8.8392" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="-14.351" y1="-5.08" x2="-14.351" y2="-11.303" width="0.254" layer="21"/>
<wire x1="-14.351" y1="-11.303" x2="-14.0208" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="14.351" y1="-5.08" x2="14.351" y2="-11.303" width="0.254" layer="21"/>
<wire x1="14.351" y1="-11.303" x2="14.0208" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="-8.509" y1="-5.08" x2="-8.509" y2="-11.303" width="0.254" layer="21"/>
<wire x1="-8.509" y1="-11.303" x2="-8.8392" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="1.905" y1="-1.905" x2="1.905" y2="-2.54" width="0.254" layer="21"/>
<wire x1="1.905" y1="-2.54" x2="0.635" y2="-2.54" width="0.254" layer="21"/>
<wire x1="0.635" y1="-2.54" x2="0.635" y2="-1.905" width="0.254" layer="21"/>
<wire x1="1.651" y1="-5.08" x2="1.651" y2="-11.303" width="0.254" layer="21"/>
<wire x1="1.651" y1="-11.303" x2="1.3208" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="0.635" y1="-1.905" x2="-0.635" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-1.905" x2="-0.635" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-2.54" x2="-1.905" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-2.54" x2="-1.905" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-1.651" y1="-5.08" x2="-1.651" y2="-11.303" width="0.254" layer="21"/>
<wire x1="-1.651" y1="-11.303" x2="-1.3208" y2="-11.6586" width="0.254" layer="21"/>
<pad name="1" x="13.97" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="-8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="-11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="-13.97" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="-6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="15.3401" y="2.9479" size="1.016" layer="25" ratio="14" rot="R180">&gt;NAME</text>
<text x="13.4859" y="-3.4021" size="1.27" layer="21" ratio="14" rot="R270">1</text>
<text x="-14.4033" y="-2.5131" size="1.27" layer="21" ratio="14" rot="R270">12</text>
<text x="-10.0599" y="2.9479" size="0.8128" layer="27" ratio="10" rot="R180">&gt;VALUE</text>
<rectangle x1="13.716" y1="-0.254" x2="14.224" y2="0.254" layer="51"/>
<rectangle x1="-14.224" y1="-0.254" x2="-13.716" y2="0.254" layer="51"/>
<rectangle x1="13.716" y1="-2.5146" x2="14.224" y2="-0.2794" layer="51"/>
<rectangle x1="-14.224" y1="-2.5146" x2="-13.716" y2="-0.2794" layer="51"/>
<rectangle x1="1.016" y1="-2.5146" x2="1.524" y2="-0.2794" layer="51"/>
<rectangle x1="1.016" y1="-0.254" x2="1.524" y2="0.254" layer="51"/>
<rectangle x1="-1.524" y1="-2.5146" x2="-1.016" y2="-0.2794" layer="51"/>
<rectangle x1="-1.524" y1="-0.254" x2="-1.016" y2="0.254" layer="51"/>
</package>
<package name="6410-12">
<wire x1="-13.97" y1="2.54" x2="-13.97" y2="2.921" width="0.127" layer="21"/>
<wire x1="-15.24" y1="0" x2="-15.24" y2="2.921" width="0.254" layer="21"/>
<wire x1="-15.24" y1="2.921" x2="-13.97" y2="2.921" width="0.254" layer="21"/>
<wire x1="-13.97" y1="2.921" x2="-13.716" y2="2.921" width="0.254" layer="21"/>
<wire x1="-13.716" y1="2.921" x2="-8.89" y2="2.921" width="0.254" layer="21"/>
<wire x1="15.24" y1="0" x2="15.24" y2="2.921" width="0.254" layer="21"/>
<wire x1="15.24" y1="2.921" x2="-7.62" y2="2.921" width="0.254" layer="21"/>
<wire x1="-15.24" y1="0" x2="-15.24" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-15.24" y1="-2.921" x2="-7.747" y2="-2.921" width="0.254" layer="21"/>
<wire x1="15.24" y1="0" x2="15.24" y2="-2.921" width="0.254" layer="21"/>
<wire x1="15.24" y1="-2.921" x2="-7.747" y2="-2.921" width="0.127" layer="21"/>
<wire x1="-14.986" y1="-2.921" x2="-14.605" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-14.605" y1="-2.921" x2="-14.605" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-14.605" y1="-2.286" x2="-13.335" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-13.335" y1="-2.286" x2="-13.335" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-13.335" y1="-2.921" x2="-12.065" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-8.255" y1="-2.921" x2="8.255" y2="-2.921" width="0.254" layer="21"/>
<wire x1="12.065" y1="-2.921" x2="13.335" y2="-2.921" width="0.254" layer="21"/>
<wire x1="13.335" y1="-2.921" x2="13.335" y2="-2.286" width="0.254" layer="21"/>
<wire x1="13.335" y1="-2.286" x2="14.605" y2="-2.286" width="0.254" layer="21"/>
<wire x1="14.605" y1="-2.286" x2="14.605" y2="-2.921" width="0.254" layer="21"/>
<wire x1="14.605" y1="-2.921" x2="15.24" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-13.97" y1="1.905" x2="-13.97" y2="2.921" width="0.254" layer="21"/>
<wire x1="-13.97" y1="1.905" x2="-13.716" y2="1.905" width="0.254" layer="21"/>
<wire x1="-13.716" y1="1.905" x2="-8.89" y2="1.905" width="0.254" layer="21"/>
<wire x1="8.89" y1="1.905" x2="13.716" y2="1.905" width="0.254" layer="21"/>
<wire x1="13.716" y1="1.905" x2="13.97" y2="1.905" width="0.254" layer="21"/>
<wire x1="13.97" y1="1.905" x2="13.97" y2="2.921" width="0.254" layer="21"/>
<wire x1="-13.97" y1="1.905" x2="-13.716" y2="1.397" width="0.254" layer="21"/>
<wire x1="-13.716" y1="1.397" x2="-9.144" y2="1.397" width="0.254" layer="21"/>
<wire x1="-9.144" y1="1.397" x2="-8.89" y2="1.905" width="0.254" layer="21"/>
<wire x1="-13.716" y1="2.921" x2="-13.716" y2="1.905" width="0.254" layer="21"/>
<wire x1="8.89" y1="1.905" x2="9.144" y2="1.397" width="0.254" layer="21"/>
<wire x1="9.144" y1="1.397" x2="13.716" y2="1.397" width="0.254" layer="21"/>
<wire x1="13.716" y1="1.397" x2="13.97" y2="1.905" width="0.254" layer="21"/>
<wire x1="13.716" y1="2.921" x2="13.716" y2="1.905" width="0.254" layer="21"/>
<wire x1="-4.445" y1="-2.921" x2="-4.445" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-4.445" y1="-2.286" x2="-3.175" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-3.175" y1="-2.286" x2="-3.175" y2="-2.921" width="0.254" layer="21"/>
<wire x1="3.175" y1="-2.921" x2="3.175" y2="-2.286" width="0.254" layer="21"/>
<wire x1="3.175" y1="-2.286" x2="4.445" y2="-2.286" width="0.254" layer="21"/>
<wire x1="4.445" y1="-2.286" x2="4.445" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-2.921" x2="-1.905" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-2.286" x2="-0.635" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-2.286" x2="-0.635" y2="-2.921" width="0.254" layer="21"/>
<wire x1="0.635" y1="-2.921" x2="0.635" y2="-2.286" width="0.254" layer="21"/>
<wire x1="0.635" y1="-2.286" x2="1.905" y2="-2.286" width="0.254" layer="21"/>
<wire x1="1.905" y1="-2.286" x2="1.905" y2="-2.921" width="0.254" layer="21"/>
<text x="-15.2131" y="-4.5989" size="1.016" layer="25" ratio="14">&gt;NAME</text>
<text x="15.7211" y="-0.4841" size="1.27" layer="21" ratio="14">1</text>
<text x="-17.5529" y="-0.6873" size="1.27" layer="21" ratio="14">12</text>
<text x="8.4089" y="-4.7259" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.556" y1="-0.254" x2="4.064" y2="0.254" layer="51"/>
<rectangle x1="-4.064" y1="-0.254" x2="-3.556" y2="0.254" layer="51"/>
</package>
<package name="87832-04">
<description>&lt;b&gt;PCB Headers&lt;/b&gt;&lt;p&gt;
2.00mm (.079") Pitch Milli-Grid Header, Vertical, Shrouded</description>
<wire x1="3.4" y1="3.75" x2="3.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="3.4" y1="-3.75" x2="-3.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="-3.4" y1="-3.75" x2="-3.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="-3.4" y1="3.75" x2="3.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="1" y1="-3.75" x2="1" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="1" y1="-3.25" x2="1" y2="-3" width="0.0508" layer="51"/>
<wire x1="1" y1="-3" x2="2.5" y2="-3" width="0.0508" layer="51"/>
<wire x1="2.5" y1="-3" x2="2.5" y2="1" width="0.0508" layer="51"/>
<wire x1="2.5" y1="1" x2="2.5" y2="1.75" width="0.0508" layer="51"/>
<wire x1="2.5" y1="1.75" x2="2.5" y2="3" width="0.0508" layer="51"/>
<wire x1="2.5" y1="3" x2="1.25" y2="3" width="0.0508" layer="51"/>
<wire x1="1.25" y1="3" x2="1.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="1.25" y1="2.75" x2="0.75" y2="2.75" width="0.0508" layer="51"/>
<wire x1="0.75" y1="2.75" x2="0.75" y2="3" width="0.0508" layer="51"/>
<wire x1="0.75" y1="3" x2="-0.75" y2="3" width="0.0508" layer="51"/>
<wire x1="-0.75" y1="3" x2="-0.75" y2="2.75" width="0.0508" layer="51"/>
<wire x1="-0.75" y1="2.75" x2="-1.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="-1.25" y1="2.75" x2="-1.25" y2="3" width="0.0508" layer="51"/>
<wire x1="-1.25" y1="3" x2="-2.5" y2="3" width="0.0508" layer="51"/>
<wire x1="-2.5" y1="3" x2="-2.5" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-2.5" y1="-0.75" x2="-2.5" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="-2.5" y1="-1.75" x2="-2.5" y2="-3" width="0.0508" layer="51"/>
<wire x1="-2.5" y1="-3" x2="-2.25" y2="-3" width="0.0508" layer="51"/>
<wire x1="-2.25" y1="-3" x2="-2.25" y2="-2.75" width="0.0508" layer="51"/>
<wire x1="-2.25" y1="-2.75" x2="-1.75" y2="-2.75" width="0.0508" layer="51"/>
<wire x1="-1.75" y1="-2.75" x2="-1.75" y2="-3" width="0.0508" layer="51"/>
<wire x1="-1.75" y1="-3" x2="-1" y2="-3" width="0.0508" layer="51"/>
<wire x1="-1" y1="-3" x2="-1" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="-1" y1="-3.25" x2="-1" y2="-3.75" width="0.0508" layer="51"/>
<wire x1="-2.5" y1="-0.75" x2="-3" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-3" y1="-0.75" x2="-3.25" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-2.5" y1="-1.75" x2="-3" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="-3" y1="-1.75" x2="-3.25" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="2.5" y1="1.75" x2="3" y2="1.75" width="0.0508" layer="51"/>
<wire x1="3" y1="1.75" x2="3.25" y2="1.75" width="0.0508" layer="51"/>
<wire x1="2.5" y1="1" x2="3" y2="1" width="0.0508" layer="51"/>
<wire x1="3" y1="1" x2="3.25" y2="1" width="0.0508" layer="51"/>
<wire x1="-3" y1="-0.75" x2="-3" y2="3.25" width="0.0508" layer="51"/>
<wire x1="-3" y1="3.25" x2="3" y2="3.25" width="0.0508" layer="51"/>
<wire x1="3" y1="3.25" x2="3" y2="1.75" width="0.0508" layer="51"/>
<wire x1="3" y1="1" x2="3" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="3" y1="-3.25" x2="1" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="-1" y1="-3.25" x2="-3" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="-3" y1="-3.25" x2="-3" y2="-1.75" width="0.0508" layer="51"/>
<smd name="2" x="-1" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="4" x="1" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="1" x="-1" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="3" x="1" y="-2.15" dx="1" dy="2.75" layer="1"/>
<text x="-4.0325" y="-3.4925" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="4.985" y="-3.4925" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="-2.25" y="-2.5" size="0.6096" layer="51" ratio="10">1</text>
<rectangle x1="-1.5" y1="0.5" x2="-0.5" y2="1.5" layer="51"/>
<rectangle x1="0.5" y1="0.5" x2="1.5" y2="1.5" layer="51"/>
<rectangle x1="-1.5" y1="-1.5" x2="-0.5" y2="-0.5" layer="51"/>
<rectangle x1="0.5" y1="-1.5" x2="1.5" y2="-0.5" layer="51"/>
</package>
<package name="87832-06">
<wire x1="4.4" y1="3.75" x2="4.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="4.4" y1="-3.75" x2="-4.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="-4.4" y1="-3.75" x2="-4.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="-4.4" y1="3.75" x2="4.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="1" y1="-3" x2="1.75" y2="-3" width="0.0508" layer="51"/>
<wire x1="1.75" y1="-3" x2="1.75" y2="-2.75" width="0.0508" layer="51"/>
<wire x1="1.75" y1="-2.75" x2="2.25" y2="-2.75" width="0.0508" layer="51"/>
<wire x1="2.25" y1="-2.75" x2="2.25" y2="-3" width="0.0508" layer="51"/>
<wire x1="2.25" y1="-3" x2="3.5" y2="-3" width="0.0508" layer="51"/>
<wire x1="3.5" y1="-3" x2="3.5" y2="1" width="0.0508" layer="51"/>
<wire x1="3.5" y1="1" x2="3.5" y2="1.75" width="0.0508" layer="51"/>
<wire x1="3.5" y1="1.75" x2="3.5" y2="3" width="0.0508" layer="51"/>
<wire x1="3.5" y1="3" x2="2.25" y2="3" width="0.0508" layer="51"/>
<wire x1="2.25" y1="3" x2="2.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="2.25" y1="2.75" x2="1.75" y2="2.75" width="0.0508" layer="51"/>
<wire x1="1.75" y1="2.75" x2="1.75" y2="3" width="0.0508" layer="51"/>
<wire x1="1.75" y1="3" x2="0.25" y2="3" width="0.0508" layer="51"/>
<wire x1="0.25" y1="3" x2="0.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="0.25" y1="2.75" x2="-0.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="-0.25" y1="2.75" x2="-0.25" y2="3" width="0.0508" layer="51"/>
<wire x1="-0.25" y1="3" x2="-1.75" y2="3" width="0.0508" layer="51"/>
<wire x1="-1.75" y1="3" x2="-1.75" y2="2.75" width="0.0508" layer="51"/>
<wire x1="-1.75" y1="2.75" x2="-2.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="-2.25" y1="2.75" x2="-2.25" y2="3" width="0.0508" layer="51"/>
<wire x1="-2.25" y1="3" x2="-3.5" y2="3" width="0.0508" layer="51"/>
<wire x1="-3.5" y1="3" x2="-3.5" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-3.5" y1="-0.75" x2="-3.5" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="-3.5" y1="-1.75" x2="-3.5" y2="-3" width="0.0508" layer="51"/>
<wire x1="-3.5" y1="-3" x2="-2.25" y2="-3" width="0.0508" layer="51"/>
<wire x1="-3.5" y1="-0.75" x2="-4" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-4" y1="-0.75" x2="-4.25" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-3.5" y1="-1.75" x2="-4" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="-4" y1="-1.75" x2="-4.25" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="3.5" y1="1.75" x2="4" y2="1.75" width="0.0508" layer="51"/>
<wire x1="4" y1="1.75" x2="4.25" y2="1.75" width="0.0508" layer="51"/>
<wire x1="3.5" y1="1" x2="4" y2="1" width="0.0508" layer="51"/>
<wire x1="4" y1="1" x2="4.25" y2="1" width="0.0508" layer="51"/>
<wire x1="-4" y1="-0.75" x2="-4" y2="3.25" width="0.0508" layer="51"/>
<wire x1="-4" y1="3.25" x2="4" y2="3.25" width="0.0508" layer="51"/>
<wire x1="4" y1="3.25" x2="4" y2="1.75" width="0.0508" layer="51"/>
<wire x1="4" y1="1" x2="4" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="4" y1="-3.25" x2="1" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="-1" y1="-3.25" x2="-4" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="-4" y1="-3.25" x2="-4" y2="-1.75" width="0.0508" layer="51"/>
<smd name="2" x="-2" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="4" x="0" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="1" x="-2" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="3" x="0" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="5" x="2" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="6" x="2" y="2.15" dx="1" dy="2.75" layer="1"/>
<text x="-5.0325" y="-3.4925" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="5.985" y="-3.4925" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="-3.25" y="-2.75" size="0.6096" layer="51" ratio="10">1</text>
<rectangle x1="-2.5" y1="0.5" x2="-1.5" y2="1.5" layer="51"/>
<rectangle x1="-0.5" y1="0.5" x2="0.5" y2="1.5" layer="51"/>
<rectangle x1="1.5" y1="0.5" x2="2.5" y2="1.5" layer="51"/>
<rectangle x1="-2.5" y1="-1.5" x2="-1.5" y2="-0.5" layer="51"/>
<rectangle x1="-0.5" y1="-1.5" x2="0.5" y2="-0.5" layer="51"/>
<rectangle x1="1.5" y1="-1.5" x2="2.5" y2="-0.5" layer="51"/>
<hole x="-1" y="0" drill="1"/>
<hole x="1" y="0" drill="1"/>
</package>
<package name="87832-08">
<wire x1="5.4" y1="3.75" x2="5.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="5.4" y1="-3.75" x2="-5.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="-5.4" y1="-3.75" x2="-5.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="-5.4" y1="3.75" x2="5.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="1" y1="-3" x2="2.75" y2="-3" width="0.0508" layer="51"/>
<wire x1="2.75" y1="-3" x2="2.75" y2="-2.75" width="0.0508" layer="51"/>
<wire x1="2.75" y1="-2.75" x2="3.25" y2="-2.75" width="0.0508" layer="51"/>
<wire x1="3.25" y1="-2.75" x2="3.25" y2="-3" width="0.0508" layer="51"/>
<wire x1="3.25" y1="-3" x2="4.5" y2="-3" width="0.0508" layer="51"/>
<wire x1="4.5" y1="-3" x2="4.5" y2="1" width="0.0508" layer="51"/>
<wire x1="4.5" y1="1" x2="4.5" y2="1.75" width="0.0508" layer="51"/>
<wire x1="4.5" y1="1.75" x2="4.5" y2="3" width="0.0508" layer="51"/>
<wire x1="4.5" y1="3" x2="3.25" y2="3" width="0.0508" layer="51"/>
<wire x1="3.25" y1="3" x2="3.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="3.25" y1="2.75" x2="2.75" y2="2.75" width="0.0508" layer="51"/>
<wire x1="2.75" y1="2.75" x2="2.75" y2="3" width="0.0508" layer="51"/>
<wire x1="2.75" y1="3" x2="1.25" y2="3" width="0.0508" layer="51"/>
<wire x1="-1.25" y1="3" x2="-2.75" y2="3" width="0.0508" layer="51"/>
<wire x1="-2.75" y1="3" x2="-2.75" y2="2.75" width="0.0508" layer="51"/>
<wire x1="-2.75" y1="2.75" x2="-3.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="-3.25" y1="2.75" x2="-3.25" y2="3" width="0.0508" layer="51"/>
<wire x1="-3.25" y1="3" x2="-4.5" y2="3" width="0.0508" layer="51"/>
<wire x1="-4.5" y1="3" x2="-4.5" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-4.5" y1="-0.75" x2="-4.5" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="-4.5" y1="-1.75" x2="-4.5" y2="-3" width="0.0508" layer="51"/>
<wire x1="-4.5" y1="-3" x2="-3.25" y2="-3" width="0.0508" layer="51"/>
<wire x1="-3.25" y1="-3" x2="-3.25" y2="-2.75" width="0.0508" layer="51"/>
<wire x1="-3.25" y1="-2.75" x2="-2.75" y2="-2.75" width="0.0508" layer="51"/>
<wire x1="-2.75" y1="-2.75" x2="-2.75" y2="-3" width="0.0508" layer="51"/>
<wire x1="-2.75" y1="-3" x2="-1" y2="-3" width="0.0508" layer="51"/>
<wire x1="-4.5" y1="-0.75" x2="-5" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-5" y1="-0.75" x2="-5.25" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-4.5" y1="-1.75" x2="-5" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="-5" y1="-1.75" x2="-5.25" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="4.5" y1="1.75" x2="5" y2="1.75" width="0.0508" layer="51"/>
<wire x1="5" y1="1.75" x2="5.25" y2="1.75" width="0.0508" layer="51"/>
<wire x1="4.5" y1="1" x2="5" y2="1" width="0.0508" layer="51"/>
<wire x1="5" y1="1" x2="5.25" y2="1" width="0.0508" layer="51"/>
<wire x1="-5" y1="-0.75" x2="-5" y2="3.25" width="0.0508" layer="51"/>
<wire x1="-5" y1="3.25" x2="5" y2="3.25" width="0.0508" layer="51"/>
<wire x1="5" y1="3.25" x2="5" y2="1.75" width="0.0508" layer="51"/>
<wire x1="5" y1="1" x2="5" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="5" y1="-3.25" x2="1" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="-1" y1="-3.25" x2="-5" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="-5" y1="-3.25" x2="-5" y2="-1.75" width="0.0508" layer="51"/>
<smd name="2" x="-3" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="4" x="-1" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="1" x="-3" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="3" x="-1" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="5" x="1" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="6" x="1" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="7" x="3" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="8" x="3" y="2.15" dx="1" dy="2.75" layer="1"/>
<text x="-6.0325" y="-3.4925" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="6.985" y="-3.4925" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="-4.25" y="-2.75" size="0.6096" layer="51" ratio="10">1</text>
<rectangle x1="-3.5" y1="0.5" x2="-2.5" y2="1.5" layer="51"/>
<rectangle x1="2.5" y1="0.5" x2="3.5" y2="1.5" layer="51"/>
<rectangle x1="-3.5" y1="-1.5" x2="-2.5" y2="-0.5" layer="51"/>
<rectangle x1="2.5" y1="-1.5" x2="3.5" y2="-0.5" layer="51"/>
<hole x="-2" y="0" drill="1"/>
<hole x="2" y="0" drill="1"/>
</package>
<package name="87832-10">
<wire x1="6.4" y1="3.75" x2="6.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="6.4" y1="-3.75" x2="-6.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="-3.75" x2="-6.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="3.75" x2="6.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="3.25" y1="-3" x2="5.5" y2="-3" width="0.0508" layer="51"/>
<wire x1="5.5" y1="-3" x2="5.5" y2="1" width="0.0508" layer="51"/>
<wire x1="5.5" y1="1" x2="5.5" y2="1.75" width="0.0508" layer="51"/>
<wire x1="5.5" y1="1.75" x2="5.5" y2="3" width="0.0508" layer="51"/>
<wire x1="5.5" y1="3" x2="4.25" y2="3" width="0.0508" layer="51"/>
<wire x1="4.25" y1="3" x2="4.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="4.25" y1="2.75" x2="3.75" y2="2.75" width="0.0508" layer="51"/>
<wire x1="3.75" y1="2.75" x2="3.75" y2="3" width="0.0508" layer="51"/>
<wire x1="3.75" y1="3" x2="2.25" y2="3" width="0.0508" layer="51"/>
<wire x1="-2.25" y1="3" x2="-3.75" y2="3" width="0.0508" layer="51"/>
<wire x1="-3.75" y1="3" x2="-3.75" y2="2.75" width="0.0508" layer="51"/>
<wire x1="-3.75" y1="2.75" x2="-4.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="-4.25" y1="2.75" x2="-4.25" y2="3" width="0.0508" layer="51"/>
<wire x1="-4.25" y1="3" x2="-5.5" y2="3" width="0.0508" layer="51"/>
<wire x1="-5.5" y1="3" x2="-5.5" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-5.5" y1="-0.75" x2="-5.5" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="-5.5" y1="-1.75" x2="-5.5" y2="-3" width="0.0508" layer="51"/>
<wire x1="-5.5" y1="-3" x2="-3.25" y2="-3" width="0.0508" layer="51"/>
<wire x1="-5.5" y1="-0.75" x2="-6" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-6" y1="-0.75" x2="-6.25" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-5.5" y1="-1.75" x2="-6" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="-6" y1="-1.75" x2="-6.25" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="5.5" y1="1.75" x2="6" y2="1.75" width="0.0508" layer="51"/>
<wire x1="6" y1="1.75" x2="6.25" y2="1.75" width="0.0508" layer="51"/>
<wire x1="5.5" y1="1" x2="6" y2="1" width="0.0508" layer="51"/>
<wire x1="6" y1="1" x2="6.25" y2="1" width="0.0508" layer="51"/>
<wire x1="-6" y1="-0.75" x2="-6" y2="3.25" width="0.0508" layer="51"/>
<wire x1="-6" y1="3.25" x2="6" y2="3.25" width="0.0508" layer="51"/>
<wire x1="6" y1="3.25" x2="6" y2="1.75" width="0.0508" layer="51"/>
<wire x1="6" y1="1" x2="6" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="6" y1="-3.25" x2="1" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="-1" y1="-3.25" x2="-6" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="-6" y1="-3.25" x2="-6" y2="-1.75" width="0.0508" layer="51"/>
<smd name="2" x="-4" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="4" x="-2" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="1" x="-4" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="3" x="-2" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="5" x="0" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="6" x="0" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="7" x="2" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="8" x="2" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="9" x="4" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="10" x="4" y="2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<text x="-7.0325" y="-3.4925" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="7.985" y="-3.4925" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="-5.25" y="-2.75" size="0.6096" layer="51" ratio="10">1</text>
<rectangle x1="-4.5" y1="0.5" x2="-3.5" y2="1.5" layer="51"/>
<rectangle x1="-4.5" y1="-1.5" x2="-3.5" y2="-0.5" layer="51"/>
<rectangle x1="3.5" y1="0.5" x2="4.5" y2="1.5" layer="51"/>
<rectangle x1="3.5" y1="-1.5" x2="4.5" y2="-0.5" layer="51"/>
<hole x="-3" y="0" drill="1"/>
<hole x="3" y="0" drill="1"/>
</package>
<package name="87832-12">
<wire x1="7.4" y1="3.75" x2="7.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="7.4" y1="-3.75" x2="-7.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="-7.4" y1="-3.75" x2="-7.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="-7.4" y1="3.75" x2="7.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="3.25" y1="-3" x2="6.5" y2="-3" width="0.0508" layer="51"/>
<wire x1="6.5" y1="-3" x2="6.5" y2="1" width="0.0508" layer="51"/>
<wire x1="6.5" y1="1" x2="6.5" y2="1.75" width="0.0508" layer="51"/>
<wire x1="6.5" y1="1.75" x2="6.5" y2="3" width="0.0508" layer="51"/>
<wire x1="6.5" y1="3" x2="5.25" y2="3" width="0.0508" layer="51"/>
<wire x1="5.25" y1="3" x2="5.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="5.25" y1="2.75" x2="4.75" y2="2.75" width="0.0508" layer="51"/>
<wire x1="4.75" y1="2.75" x2="4.75" y2="3" width="0.0508" layer="51"/>
<wire x1="4.75" y1="3" x2="3.25" y2="3" width="0.0508" layer="51"/>
<wire x1="-3.25" y1="3" x2="-4.75" y2="3" width="0.0508" layer="51"/>
<wire x1="-4.75" y1="3" x2="-4.75" y2="2.75" width="0.0508" layer="51"/>
<wire x1="-4.75" y1="2.75" x2="-5.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="-5.25" y1="2.75" x2="-5.25" y2="3" width="0.0508" layer="51"/>
<wire x1="-5.25" y1="3" x2="-6.5" y2="3" width="0.0508" layer="51"/>
<wire x1="-6.5" y1="3" x2="-6.5" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-6.5" y1="-0.75" x2="-6.5" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="-6.5" y1="-1.75" x2="-6.5" y2="-3" width="0.0508" layer="51"/>
<wire x1="-6.5" y1="-3" x2="-3.25" y2="-3" width="0.0508" layer="51"/>
<wire x1="-6.5" y1="-0.75" x2="-7" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-7" y1="-0.75" x2="-7.25" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-6.5" y1="-1.75" x2="-7" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="-7" y1="-1.75" x2="-7.25" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="6.5" y1="1.75" x2="7" y2="1.75" width="0.0508" layer="51"/>
<wire x1="7" y1="1.75" x2="7.25" y2="1.75" width="0.0508" layer="51"/>
<wire x1="6.5" y1="1" x2="7" y2="1" width="0.0508" layer="51"/>
<wire x1="7" y1="1" x2="7.25" y2="1" width="0.0508" layer="51"/>
<wire x1="-7" y1="-0.75" x2="-7" y2="3.25" width="0.0508" layer="51"/>
<wire x1="-7" y1="3.25" x2="7" y2="3.25" width="0.0508" layer="51"/>
<wire x1="7" y1="3.25" x2="7" y2="1.75" width="0.0508" layer="51"/>
<wire x1="7" y1="1" x2="7" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="7" y1="-3.25" x2="1" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="-1" y1="-3.25" x2="-7" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="-7" y1="-3.25" x2="-7" y2="-1.75" width="0.0508" layer="51"/>
<smd name="2" x="-5" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="4" x="-3" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="1" x="-5" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="3" x="-3" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="5" x="-1" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="6" x="-1" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="7" x="1" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="8" x="1" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="9" x="3" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="10" x="3" y="2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="11" x="5" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="12" x="5" y="2.15" dx="1" dy="2.75" layer="1"/>
<text x="-8.0325" y="-3.4925" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="8.985" y="-3.4925" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="-6.25" y="-2.75" size="0.6096" layer="51" ratio="10">1</text>
<rectangle x1="-5.5" y1="0.5" x2="-4.5" y2="1.5" layer="51"/>
<rectangle x1="-5.5" y1="-1.5" x2="-4.5" y2="-0.5" layer="51"/>
<rectangle x1="4.5" y1="0.5" x2="5.5" y2="1.5" layer="51"/>
<rectangle x1="4.5" y1="-1.5" x2="5.5" y2="-0.5" layer="51"/>
<hole x="-4" y="0" drill="1"/>
<hole x="4" y="0" drill="1"/>
</package>
<package name="87832-14">
<wire x1="8.4" y1="3.75" x2="8.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="8.4" y1="-3.75" x2="-8.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="-8.4" y1="-3.75" x2="-8.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="-8.4" y1="3.75" x2="8.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="3.25" y1="-3" x2="7.5" y2="-3" width="0.0508" layer="51"/>
<wire x1="7.5" y1="-3" x2="7.5" y2="1" width="0.0508" layer="51"/>
<wire x1="7.5" y1="1" x2="7.5" y2="1.75" width="0.0508" layer="51"/>
<wire x1="7.5" y1="1.75" x2="7.5" y2="3" width="0.0508" layer="51"/>
<wire x1="7.5" y1="3" x2="6.25" y2="3" width="0.0508" layer="51"/>
<wire x1="6.25" y1="3" x2="6.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="6.25" y1="2.75" x2="5.75" y2="2.75" width="0.0508" layer="51"/>
<wire x1="5.75" y1="2.75" x2="5.75" y2="3" width="0.0508" layer="51"/>
<wire x1="5.75" y1="3" x2="4.25" y2="3" width="0.0508" layer="51"/>
<wire x1="-4.25" y1="3" x2="-5.75" y2="3" width="0.0508" layer="51"/>
<wire x1="-5.75" y1="3" x2="-5.75" y2="2.75" width="0.0508" layer="51"/>
<wire x1="-5.75" y1="2.75" x2="-6.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="-6.25" y1="2.75" x2="-6.25" y2="3" width="0.0508" layer="51"/>
<wire x1="-6.25" y1="3" x2="-7.5" y2="3" width="0.0508" layer="51"/>
<wire x1="-7.5" y1="3" x2="-7.5" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-7.5" y1="-0.75" x2="-7.5" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="-7.5" y1="-1.75" x2="-7.5" y2="-3" width="0.0508" layer="51"/>
<wire x1="-7.5" y1="-3" x2="-3.25" y2="-3" width="0.0508" layer="51"/>
<wire x1="-7.5" y1="-0.75" x2="-8" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-8" y1="-0.75" x2="-8.25" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-7.5" y1="-1.75" x2="-8" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="-8" y1="-1.75" x2="-8.25" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="7.5" y1="1.75" x2="8" y2="1.75" width="0.0508" layer="51"/>
<wire x1="8" y1="1.75" x2="8.25" y2="1.75" width="0.0508" layer="51"/>
<wire x1="7.5" y1="1" x2="8" y2="1" width="0.0508" layer="51"/>
<wire x1="8" y1="1" x2="8.25" y2="1" width="0.0508" layer="51"/>
<wire x1="-8" y1="-0.75" x2="-8" y2="3.25" width="0.0508" layer="51"/>
<wire x1="-8" y1="3.25" x2="8" y2="3.25" width="0.0508" layer="51"/>
<wire x1="8" y1="3.25" x2="8" y2="1.75" width="0.0508" layer="51"/>
<wire x1="8" y1="1" x2="8" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="8" y1="-3.25" x2="1" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="-1" y1="-3.25" x2="-8" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="-8" y1="-3.25" x2="-8" y2="-1.75" width="0.0508" layer="51"/>
<smd name="2" x="-6" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="4" x="-4" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="1" x="-6" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="3" x="-4" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="5" x="-2" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="6" x="-2" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="7" x="0" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="8" x="0" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="9" x="2" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="10" x="2" y="2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="11" x="4" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="12" x="4" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="13" x="6" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="14" x="6" y="2.15" dx="1" dy="2.75" layer="1"/>
<text x="-9.0325" y="-3.4925" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="9.985" y="-3.4925" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="-7.25" y="-2.75" size="0.6096" layer="51" ratio="10">1</text>
<rectangle x1="-6.5" y1="0.5" x2="-5.5" y2="1.5" layer="51"/>
<rectangle x1="-6.5" y1="-1.5" x2="-5.5" y2="-0.5" layer="51"/>
<rectangle x1="5.5" y1="0.5" x2="6.5" y2="1.5" layer="51"/>
<rectangle x1="5.5" y1="-1.5" x2="6.5" y2="-0.5" layer="51"/>
<hole x="-5" y="0" drill="1"/>
<hole x="5" y="0" drill="1"/>
</package>
<package name="87832-16">
<wire x1="9.4" y1="3.75" x2="9.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="9.4" y1="-3.75" x2="-9.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="-9.4" y1="-3.75" x2="-9.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="-9.4" y1="3.75" x2="9.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="3.25" y1="-3" x2="8.5" y2="-3" width="0.0508" layer="51"/>
<wire x1="8.5" y1="-3" x2="8.5" y2="1" width="0.0508" layer="51"/>
<wire x1="8.5" y1="1" x2="8.5" y2="1.75" width="0.0508" layer="51"/>
<wire x1="8.5" y1="1.75" x2="8.5" y2="3" width="0.0508" layer="51"/>
<wire x1="8.5" y1="3" x2="7.25" y2="3" width="0.0508" layer="51"/>
<wire x1="7.25" y1="3" x2="7.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="7.25" y1="2.75" x2="6.75" y2="2.75" width="0.0508" layer="51"/>
<wire x1="6.75" y1="2.75" x2="6.75" y2="3" width="0.0508" layer="51"/>
<wire x1="6.75" y1="3" x2="5.25" y2="3" width="0.0508" layer="51"/>
<wire x1="-5.25" y1="3" x2="-6.75" y2="3" width="0.0508" layer="51"/>
<wire x1="-6.75" y1="3" x2="-6.75" y2="2.75" width="0.0508" layer="51"/>
<wire x1="-6.75" y1="2.75" x2="-7.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="-7.25" y1="2.75" x2="-7.25" y2="3" width="0.0508" layer="51"/>
<wire x1="-7.25" y1="3" x2="-8.5" y2="3" width="0.0508" layer="51"/>
<wire x1="-8.5" y1="3" x2="-8.5" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-8.5" y1="-0.75" x2="-8.5" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="-8.5" y1="-1.75" x2="-8.5" y2="-3" width="0.0508" layer="51"/>
<wire x1="-8.5" y1="-3" x2="-3.25" y2="-3" width="0.0508" layer="51"/>
<wire x1="-8.5" y1="-0.75" x2="-9" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-9" y1="-0.75" x2="-9.25" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-8.5" y1="-1.75" x2="-9" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="-9" y1="-1.75" x2="-9.25" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="8.5" y1="1.75" x2="9" y2="1.75" width="0.0508" layer="51"/>
<wire x1="9" y1="1.75" x2="9.25" y2="1.75" width="0.0508" layer="51"/>
<wire x1="8.5" y1="1" x2="9" y2="1" width="0.0508" layer="51"/>
<wire x1="9" y1="1" x2="9.25" y2="1" width="0.0508" layer="51"/>
<wire x1="-9" y1="-0.75" x2="-9" y2="3.25" width="0.0508" layer="51"/>
<wire x1="-9" y1="3.25" x2="9" y2="3.25" width="0.0508" layer="51"/>
<wire x1="9" y1="3.25" x2="9" y2="1.75" width="0.0508" layer="51"/>
<wire x1="9" y1="1" x2="9" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="9" y1="-3.25" x2="1" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="-1" y1="-3.25" x2="-9" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="-9" y1="-3.25" x2="-9" y2="-1.75" width="0.0508" layer="51"/>
<smd name="2" x="-7" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="4" x="-5" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="1" x="-7" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="3" x="-5" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="5" x="-3" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="6" x="-3" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="7" x="-1" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="8" x="-1" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="9" x="1" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="10" x="1" y="2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="11" x="3" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="12" x="3" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="13" x="5" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="14" x="5" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="15" x="7" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="16" x="7" y="2.15" dx="1" dy="2.75" layer="1"/>
<text x="-10.0325" y="-3.4925" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="10.985" y="-3.4925" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="-8.25" y="-2.75" size="0.6096" layer="51" ratio="10">1</text>
<rectangle x1="-7.5" y1="0.5" x2="-6.5" y2="1.5" layer="51"/>
<rectangle x1="-7.5" y1="-1.5" x2="-6.5" y2="-0.5" layer="51"/>
<rectangle x1="6.5" y1="0.5" x2="7.5" y2="1.5" layer="51"/>
<rectangle x1="6.5" y1="-1.5" x2="7.5" y2="-0.5" layer="51"/>
<hole x="-6" y="0" drill="1"/>
<hole x="6" y="0" drill="1"/>
</package>
<package name="87832-18">
<wire x1="10.4" y1="3.75" x2="10.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="10.4" y1="-3.75" x2="-10.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="-10.4" y1="-3.75" x2="-10.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="-10.4" y1="3.75" x2="10.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="3.25" y1="-3" x2="9.5" y2="-3" width="0.0508" layer="51"/>
<wire x1="9.5" y1="-3" x2="9.5" y2="1" width="0.0508" layer="51"/>
<wire x1="9.5" y1="1" x2="9.5" y2="1.75" width="0.0508" layer="51"/>
<wire x1="9.5" y1="1.75" x2="9.5" y2="3" width="0.0508" layer="51"/>
<wire x1="9.5" y1="3" x2="8.25" y2="3" width="0.0508" layer="51"/>
<wire x1="8.25" y1="3" x2="8.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="8.25" y1="2.75" x2="7.75" y2="2.75" width="0.0508" layer="51"/>
<wire x1="7.75" y1="2.75" x2="7.75" y2="3" width="0.0508" layer="51"/>
<wire x1="7.75" y1="3" x2="6.25" y2="3" width="0.0508" layer="51"/>
<wire x1="-6.25" y1="3" x2="-7.75" y2="3" width="0.0508" layer="51"/>
<wire x1="-7.75" y1="3" x2="-7.75" y2="2.75" width="0.0508" layer="51"/>
<wire x1="-7.75" y1="2.75" x2="-8.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="-8.25" y1="2.75" x2="-8.25" y2="3" width="0.0508" layer="51"/>
<wire x1="-8.25" y1="3" x2="-9.5" y2="3" width="0.0508" layer="51"/>
<wire x1="-9.5" y1="3" x2="-9.5" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-9.5" y1="-0.75" x2="-9.5" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="-9.5" y1="-1.75" x2="-9.5" y2="-3" width="0.0508" layer="51"/>
<wire x1="-9.5" y1="-3" x2="-3.25" y2="-3" width="0.0508" layer="51"/>
<wire x1="-9.5" y1="-0.75" x2="-10" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-10" y1="-0.75" x2="-10.25" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-9.5" y1="-1.75" x2="-10" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="-10" y1="-1.75" x2="-10.25" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="9.5" y1="1.75" x2="10" y2="1.75" width="0.0508" layer="51"/>
<wire x1="10" y1="1.75" x2="10.25" y2="1.75" width="0.0508" layer="51"/>
<wire x1="9.5" y1="1" x2="10" y2="1" width="0.0508" layer="51"/>
<wire x1="10" y1="1" x2="10.25" y2="1" width="0.0508" layer="51"/>
<wire x1="-10" y1="-0.75" x2="-10" y2="3.25" width="0.0508" layer="51"/>
<wire x1="-10" y1="3.25" x2="10" y2="3.25" width="0.0508" layer="51"/>
<wire x1="10" y1="3.25" x2="10" y2="1.75" width="0.0508" layer="51"/>
<wire x1="10" y1="1" x2="10" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="10" y1="-3.25" x2="1" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="-1" y1="-3.25" x2="-10" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="-10" y1="-3.25" x2="-10" y2="-1.75" width="0.0508" layer="51"/>
<smd name="2" x="-8" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="4" x="-6" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="1" x="-8" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="3" x="-6" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="5" x="-4" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="6" x="-4" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="7" x="-2" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="8" x="-2" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="9" x="0" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="10" x="0" y="2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="11" x="2" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="12" x="2" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="13" x="4" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="14" x="4" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="15" x="6" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="16" x="6" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="17" x="8" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="18" x="8" y="2.15" dx="1" dy="2.75" layer="1"/>
<text x="-11.0325" y="-3.4925" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="11.985" y="-3.4925" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="-9.25" y="-2.75" size="0.6096" layer="51" ratio="10">1</text>
<rectangle x1="-8.5" y1="0.5" x2="-7.5" y2="1.5" layer="51"/>
<rectangle x1="-8.5" y1="-1.5" x2="-7.5" y2="-0.5" layer="51"/>
<rectangle x1="7.5" y1="0.5" x2="8.5" y2="1.5" layer="51"/>
<rectangle x1="7.5" y1="-1.5" x2="8.5" y2="-0.5" layer="51"/>
<hole x="-7" y="0" drill="1"/>
<hole x="7" y="0" drill="1"/>
</package>
<package name="87832-20">
<wire x1="11.4" y1="3.75" x2="11.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="11.4" y1="-3.75" x2="-11.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="-11.4" y1="-3.75" x2="-11.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="-11.4" y1="3.75" x2="11.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="3.25" y1="-3" x2="10.5" y2="-3" width="0.0508" layer="51"/>
<wire x1="10.5" y1="-3" x2="10.5" y2="1" width="0.0508" layer="51"/>
<wire x1="10.5" y1="1" x2="10.5" y2="1.75" width="0.0508" layer="51"/>
<wire x1="10.5" y1="1.75" x2="10.5" y2="3" width="0.0508" layer="51"/>
<wire x1="10.5" y1="3" x2="9.25" y2="3" width="0.0508" layer="51"/>
<wire x1="9.25" y1="3" x2="9.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="9.25" y1="2.75" x2="8.75" y2="2.75" width="0.0508" layer="51"/>
<wire x1="8.75" y1="2.75" x2="8.75" y2="3" width="0.0508" layer="51"/>
<wire x1="8.75" y1="3" x2="7.25" y2="3" width="0.0508" layer="51"/>
<wire x1="-7.25" y1="3" x2="-8.75" y2="3" width="0.0508" layer="51"/>
<wire x1="-8.75" y1="3" x2="-8.75" y2="2.75" width="0.0508" layer="51"/>
<wire x1="-8.75" y1="2.75" x2="-9.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="-9.25" y1="2.75" x2="-9.25" y2="3" width="0.0508" layer="51"/>
<wire x1="-9.25" y1="3" x2="-10.5" y2="3" width="0.0508" layer="51"/>
<wire x1="-10.5" y1="3" x2="-10.5" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-10.5" y1="-0.75" x2="-10.5" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="-10.5" y1="-1.75" x2="-10.5" y2="-3" width="0.0508" layer="51"/>
<wire x1="-10.5" y1="-3" x2="-3.25" y2="-3" width="0.0508" layer="51"/>
<wire x1="-10.5" y1="-0.75" x2="-11" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-11" y1="-0.75" x2="-11.25" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-10.5" y1="-1.75" x2="-11" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="-11" y1="-1.75" x2="-11.25" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="10.5" y1="1.75" x2="11" y2="1.75" width="0.0508" layer="51"/>
<wire x1="11" y1="1.75" x2="11.25" y2="1.75" width="0.0508" layer="51"/>
<wire x1="10.5" y1="1" x2="11" y2="1" width="0.0508" layer="51"/>
<wire x1="11" y1="1" x2="11.25" y2="1" width="0.0508" layer="51"/>
<wire x1="-11" y1="-0.75" x2="-11" y2="3.25" width="0.0508" layer="51"/>
<wire x1="-11" y1="3.25" x2="11" y2="3.25" width="0.0508" layer="51"/>
<wire x1="11" y1="3.25" x2="11" y2="1.75" width="0.0508" layer="51"/>
<wire x1="11" y1="1" x2="11" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="11" y1="-3.25" x2="1" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="-1" y1="-3.25" x2="-11" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="-11" y1="-3.25" x2="-11" y2="-1.75" width="0.0508" layer="51"/>
<smd name="2" x="-9" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="4" x="-7" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="1" x="-9" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="3" x="-7" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="5" x="-5" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="6" x="-5" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="7" x="-3" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="8" x="-3" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="9" x="-1" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="10" x="-1" y="2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="11" x="1" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="12" x="1" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="13" x="3" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="14" x="3" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="15" x="5" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="16" x="5" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="17" x="7" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="18" x="7" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="19" x="9" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="20" x="9" y="2.15" dx="1" dy="2.75" layer="1"/>
<text x="-12.0325" y="-3.4925" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="12.985" y="-3.4925" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="-10.25" y="-2.75" size="0.6096" layer="51" ratio="10">1</text>
<rectangle x1="-9.5" y1="0.5" x2="-8.5" y2="1.5" layer="51"/>
<rectangle x1="-9.5" y1="-1.5" x2="-8.5" y2="-0.5" layer="51"/>
<rectangle x1="8.5" y1="0.5" x2="9.5" y2="1.5" layer="51"/>
<rectangle x1="8.5" y1="-1.5" x2="9.5" y2="-0.5" layer="51"/>
<hole x="-8" y="0" drill="1"/>
<hole x="8" y="0" drill="1"/>
</package>
<package name="87832-22">
<wire x1="12.4" y1="3.75" x2="12.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="12.4" y1="-3.75" x2="-12.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="-12.4" y1="-3.75" x2="-12.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="-12.4" y1="3.75" x2="12.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="3.25" y1="-3" x2="11.5" y2="-3" width="0.0508" layer="51"/>
<wire x1="11.5" y1="-3" x2="11.5" y2="1" width="0.0508" layer="51"/>
<wire x1="11.5" y1="1" x2="11.5" y2="1.75" width="0.0508" layer="51"/>
<wire x1="11.5" y1="1.75" x2="11.5" y2="3" width="0.0508" layer="51"/>
<wire x1="11.5" y1="3" x2="10.25" y2="3" width="0.0508" layer="51"/>
<wire x1="10.25" y1="3" x2="10.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="10.25" y1="2.75" x2="9.75" y2="2.75" width="0.0508" layer="51"/>
<wire x1="9.75" y1="2.75" x2="9.75" y2="3" width="0.0508" layer="51"/>
<wire x1="9.75" y1="3" x2="8.25" y2="3" width="0.0508" layer="51"/>
<wire x1="-8.25" y1="3" x2="-9.75" y2="3" width="0.0508" layer="51"/>
<wire x1="-9.75" y1="3" x2="-9.75" y2="2.75" width="0.0508" layer="51"/>
<wire x1="-9.75" y1="2.75" x2="-10.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="-10.25" y1="2.75" x2="-10.25" y2="3" width="0.0508" layer="51"/>
<wire x1="-10.25" y1="3" x2="-11.5" y2="3" width="0.0508" layer="51"/>
<wire x1="-11.5" y1="3" x2="-11.5" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-11.5" y1="-0.75" x2="-11.5" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="-11.5" y1="-1.75" x2="-11.5" y2="-3" width="0.0508" layer="51"/>
<wire x1="-11.5" y1="-3" x2="-3.25" y2="-3" width="0.0508" layer="51"/>
<wire x1="-11.5" y1="-0.75" x2="-12" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-12" y1="-0.75" x2="-12.25" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-11.5" y1="-1.75" x2="-12" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="-12" y1="-1.75" x2="-12.25" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="11.5" y1="1.75" x2="12" y2="1.75" width="0.0508" layer="51"/>
<wire x1="12" y1="1.75" x2="12.25" y2="1.75" width="0.0508" layer="51"/>
<wire x1="11.5" y1="1" x2="12" y2="1" width="0.0508" layer="51"/>
<wire x1="12" y1="1" x2="12.25" y2="1" width="0.0508" layer="51"/>
<wire x1="-12" y1="-0.75" x2="-12" y2="3.25" width="0.0508" layer="51"/>
<wire x1="-12" y1="3.25" x2="12" y2="3.25" width="0.0508" layer="51"/>
<wire x1="12" y1="3.25" x2="12" y2="1.75" width="0.0508" layer="51"/>
<wire x1="12" y1="1" x2="12" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="12" y1="-3.25" x2="1" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="-1" y1="-3.25" x2="-12" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="-12" y1="-3.25" x2="-12" y2="-1.75" width="0.0508" layer="51"/>
<smd name="2" x="-10" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="4" x="-8" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="1" x="-10" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="3" x="-8" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="5" x="-6" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="6" x="-6" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="7" x="-4" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="8" x="-4" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="9" x="-2" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="10" x="-2" y="2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="11" x="0" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="12" x="0" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="13" x="2" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="14" x="2" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="15" x="4" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="16" x="4" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="17" x="6" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="18" x="6" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="19" x="8" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="20" x="8" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="21" x="10" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="22" x="10" y="2.15" dx="1" dy="2.75" layer="1"/>
<text x="-13.0325" y="-3.4925" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="13.985" y="-3.4925" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="-11.25" y="-2.75" size="0.6096" layer="51" ratio="10">1</text>
<rectangle x1="-10.5" y1="0.5" x2="-9.5" y2="1.5" layer="51"/>
<rectangle x1="-10.5" y1="-1.5" x2="-9.5" y2="-0.5" layer="51"/>
<rectangle x1="9.5" y1="0.5" x2="10.5" y2="1.5" layer="51"/>
<rectangle x1="9.5" y1="-1.5" x2="10.5" y2="-0.5" layer="51"/>
<hole x="-9" y="0" drill="1"/>
<hole x="9" y="0" drill="1"/>
</package>
<package name="87832-24">
<wire x1="13.4" y1="3.75" x2="13.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="13.4" y1="-3.75" x2="-13.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="-13.4" y1="-3.75" x2="-13.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="-13.4" y1="3.75" x2="13.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="3.25" y1="-3" x2="12.5" y2="-3" width="0.0508" layer="51"/>
<wire x1="12.5" y1="-3" x2="12.5" y2="1" width="0.0508" layer="51"/>
<wire x1="12.5" y1="1" x2="12.5" y2="1.75" width="0.0508" layer="51"/>
<wire x1="12.5" y1="1.75" x2="12.5" y2="3" width="0.0508" layer="51"/>
<wire x1="12.5" y1="3" x2="11.25" y2="3" width="0.0508" layer="51"/>
<wire x1="11.25" y1="3" x2="11.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="11.25" y1="2.75" x2="10.75" y2="2.75" width="0.0508" layer="51"/>
<wire x1="10.75" y1="2.75" x2="10.75" y2="3" width="0.0508" layer="51"/>
<wire x1="10.75" y1="3" x2="9.25" y2="3" width="0.0508" layer="51"/>
<wire x1="-9.25" y1="3" x2="-10.75" y2="3" width="0.0508" layer="51"/>
<wire x1="-10.75" y1="3" x2="-10.75" y2="2.75" width="0.0508" layer="51"/>
<wire x1="-10.75" y1="2.75" x2="-11.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="-11.25" y1="2.75" x2="-11.25" y2="3" width="0.0508" layer="51"/>
<wire x1="-11.25" y1="3" x2="-12.5" y2="3" width="0.0508" layer="51"/>
<wire x1="-12.5" y1="3" x2="-12.5" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-12.5" y1="-0.75" x2="-12.5" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="-12.5" y1="-1.75" x2="-12.5" y2="-3" width="0.0508" layer="51"/>
<wire x1="-12.5" y1="-3" x2="-3.25" y2="-3" width="0.0508" layer="51"/>
<wire x1="-12.5" y1="-0.75" x2="-13" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-13" y1="-0.75" x2="-13.25" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-12.5" y1="-1.75" x2="-13" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="-13" y1="-1.75" x2="-13.25" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="12.5" y1="1.75" x2="13" y2="1.75" width="0.0508" layer="51"/>
<wire x1="13" y1="1.75" x2="13.25" y2="1.75" width="0.0508" layer="51"/>
<wire x1="12.5" y1="1" x2="13" y2="1" width="0.0508" layer="51"/>
<wire x1="13" y1="1" x2="13.25" y2="1" width="0.0508" layer="51"/>
<wire x1="-13" y1="-0.75" x2="-13" y2="3.25" width="0.0508" layer="51"/>
<wire x1="-13" y1="3.25" x2="13" y2="3.25" width="0.0508" layer="51"/>
<wire x1="13" y1="3.25" x2="13" y2="1.75" width="0.0508" layer="51"/>
<wire x1="13" y1="1" x2="13" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="13" y1="-3.25" x2="1" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="-1" y1="-3.25" x2="-13" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="-13" y1="-3.25" x2="-13" y2="-1.75" width="0.0508" layer="51"/>
<smd name="2" x="-11" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="4" x="-9" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="1" x="-11" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="3" x="-9" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="5" x="-7" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="6" x="-7" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="7" x="-5" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="8" x="-5" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="9" x="-3" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="10" x="-3" y="2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="11" x="-1" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="12" x="-1" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="13" x="1" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="14" x="1" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="15" x="3" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="16" x="3" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="17" x="5" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="18" x="5" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="19" x="7" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="20" x="7" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="21" x="9" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="22" x="9" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="23" x="11" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="24" x="11" y="2.15" dx="1" dy="2.75" layer="1"/>
<text x="-14.0325" y="-3.4925" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="14.985" y="-3.4925" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="-12.25" y="-2.75" size="0.6096" layer="51" ratio="10">1</text>
<rectangle x1="-11.5" y1="0.5" x2="-10.5" y2="1.5" layer="51"/>
<rectangle x1="-11.5" y1="-1.5" x2="-10.5" y2="-0.5" layer="51"/>
<rectangle x1="10.5" y1="0.5" x2="11.5" y2="1.5" layer="51"/>
<rectangle x1="10.5" y1="-1.5" x2="11.5" y2="-0.5" layer="51"/>
<hole x="-10" y="0" drill="1"/>
<hole x="10" y="0" drill="1"/>
</package>
<package name="87832-26">
<wire x1="14.4" y1="3.75" x2="14.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="14.4" y1="-3.75" x2="-14.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="-14.4" y1="-3.75" x2="-14.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="-14.4" y1="3.75" x2="14.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="3.25" y1="-3" x2="13.5" y2="-3" width="0.0508" layer="51"/>
<wire x1="13.5" y1="-3" x2="13.5" y2="1" width="0.0508" layer="51"/>
<wire x1="13.5" y1="1" x2="13.5" y2="1.75" width="0.0508" layer="51"/>
<wire x1="13.5" y1="1.75" x2="13.5" y2="3" width="0.0508" layer="51"/>
<wire x1="13.5" y1="3" x2="12.25" y2="3" width="0.0508" layer="51"/>
<wire x1="12.25" y1="3" x2="12.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="12.25" y1="2.75" x2="11.75" y2="2.75" width="0.0508" layer="51"/>
<wire x1="11.75" y1="2.75" x2="11.75" y2="3" width="0.0508" layer="51"/>
<wire x1="11.75" y1="3" x2="10.25" y2="3" width="0.0508" layer="51"/>
<wire x1="-10.25" y1="3" x2="-11.75" y2="3" width="0.0508" layer="51"/>
<wire x1="-11.75" y1="3" x2="-11.75" y2="2.75" width="0.0508" layer="51"/>
<wire x1="-11.75" y1="2.75" x2="-12.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="-12.25" y1="2.75" x2="-12.25" y2="3" width="0.0508" layer="51"/>
<wire x1="-12.25" y1="3" x2="-13.5" y2="3" width="0.0508" layer="51"/>
<wire x1="-13.5" y1="3" x2="-13.5" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-13.5" y1="-0.75" x2="-13.5" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="-13.5" y1="-1.75" x2="-13.5" y2="-3" width="0.0508" layer="51"/>
<wire x1="-13.5" y1="-3" x2="-3.25" y2="-3" width="0.0508" layer="51"/>
<wire x1="-13.5" y1="-0.75" x2="-14" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-14" y1="-0.75" x2="-14.25" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-13.5" y1="-1.75" x2="-14" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="-14" y1="-1.75" x2="-14.25" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="13.5" y1="1.75" x2="14" y2="1.75" width="0.0508" layer="51"/>
<wire x1="14" y1="1.75" x2="14.25" y2="1.75" width="0.0508" layer="51"/>
<wire x1="13.5" y1="1" x2="14" y2="1" width="0.0508" layer="51"/>
<wire x1="14" y1="1" x2="14.25" y2="1" width="0.0508" layer="51"/>
<wire x1="-14" y1="-0.75" x2="-14" y2="3.25" width="0.0508" layer="51"/>
<wire x1="-14" y1="3.25" x2="14" y2="3.25" width="0.0508" layer="51"/>
<wire x1="14" y1="3.25" x2="14" y2="1.75" width="0.0508" layer="51"/>
<wire x1="14" y1="1" x2="14" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="14" y1="-3.25" x2="1" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="-1" y1="-3.25" x2="-14" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="-14" y1="-3.25" x2="-14" y2="-1.75" width="0.0508" layer="51"/>
<smd name="2" x="-12" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="4" x="-10" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="1" x="-12" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="3" x="-10" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="5" x="-8" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="6" x="-8" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="7" x="-6" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="8" x="-6" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="9" x="-4" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="10" x="-4" y="2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="11" x="-2" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="12" x="-2" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="13" x="0" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="14" x="0" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="15" x="2" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="16" x="2" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="17" x="4" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="18" x="4" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="19" x="6" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="20" x="6" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="21" x="8" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="22" x="8" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="23" x="10" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="24" x="10" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="25" x="12" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="26" x="12" y="2.15" dx="1" dy="2.75" layer="1"/>
<text x="-15.0325" y="-3.4925" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="15.985" y="-3.4925" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="-13.25" y="-2.75" size="0.6096" layer="51" ratio="10">1</text>
<rectangle x1="-12.5" y1="0.5" x2="-11.5" y2="1.5" layer="51"/>
<rectangle x1="-12.5" y1="-1.5" x2="-11.5" y2="-0.5" layer="51"/>
<rectangle x1="11.5" y1="0.5" x2="12.5" y2="1.5" layer="51"/>
<rectangle x1="11.5" y1="-1.5" x2="12.5" y2="-0.5" layer="51"/>
<hole x="-11" y="0" drill="1"/>
<hole x="11" y="0" drill="1"/>
</package>
<package name="87832-28">
<wire x1="15.4" y1="3.75" x2="15.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="15.4" y1="-3.75" x2="-15.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="-15.4" y1="-3.75" x2="-15.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="-15.4" y1="3.75" x2="15.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="3.25" y1="-3" x2="14.5" y2="-3" width="0.0508" layer="51"/>
<wire x1="14.5" y1="-3" x2="14.5" y2="1" width="0.0508" layer="51"/>
<wire x1="14.5" y1="1" x2="14.5" y2="1.75" width="0.0508" layer="51"/>
<wire x1="14.5" y1="1.75" x2="14.5" y2="3" width="0.0508" layer="51"/>
<wire x1="14.5" y1="3" x2="13.25" y2="3" width="0.0508" layer="51"/>
<wire x1="13.25" y1="3" x2="13.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="13.25" y1="2.75" x2="12.75" y2="2.75" width="0.0508" layer="51"/>
<wire x1="12.75" y1="2.75" x2="12.75" y2="3" width="0.0508" layer="51"/>
<wire x1="12.75" y1="3" x2="11.25" y2="3" width="0.0508" layer="51"/>
<wire x1="-11.25" y1="3" x2="-12.75" y2="3" width="0.0508" layer="51"/>
<wire x1="-12.75" y1="3" x2="-12.75" y2="2.75" width="0.0508" layer="51"/>
<wire x1="-12.75" y1="2.75" x2="-13.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="-13.25" y1="2.75" x2="-13.25" y2="3" width="0.0508" layer="51"/>
<wire x1="-13.25" y1="3" x2="-14.5" y2="3" width="0.0508" layer="51"/>
<wire x1="-14.5" y1="3" x2="-14.5" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-14.5" y1="-0.75" x2="-14.5" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="-14.5" y1="-1.75" x2="-14.5" y2="-3" width="0.0508" layer="51"/>
<wire x1="-14.5" y1="-3" x2="-3.25" y2="-3" width="0.0508" layer="51"/>
<wire x1="-14.5" y1="-0.75" x2="-15" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-15" y1="-0.75" x2="-15.25" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-14.5" y1="-1.75" x2="-15" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="-15" y1="-1.75" x2="-15.25" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="14.5" y1="1.75" x2="15" y2="1.75" width="0.0508" layer="51"/>
<wire x1="15" y1="1.75" x2="15.25" y2="1.75" width="0.0508" layer="51"/>
<wire x1="14.5" y1="1" x2="15" y2="1" width="0.0508" layer="51"/>
<wire x1="15" y1="1" x2="15.25" y2="1" width="0.0508" layer="51"/>
<wire x1="-15" y1="-0.75" x2="-15" y2="3.25" width="0.0508" layer="51"/>
<wire x1="-15" y1="3.25" x2="15" y2="3.25" width="0.0508" layer="51"/>
<wire x1="15" y1="3.25" x2="15" y2="1.75" width="0.0508" layer="51"/>
<wire x1="15" y1="1" x2="15" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="15" y1="-3.25" x2="1" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="-1" y1="-3.25" x2="-15" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="-15" y1="-3.25" x2="-15" y2="-1.75" width="0.0508" layer="51"/>
<smd name="2" x="-13" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="4" x="-11" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="1" x="-13" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="3" x="-11" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="5" x="-9" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="6" x="-9" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="7" x="-7" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="8" x="-7" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="9" x="-5" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="10" x="-5" y="2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="11" x="-3" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="12" x="-3" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="13" x="-1" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="14" x="-1" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="15" x="1" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="16" x="1" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="17" x="3" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="18" x="3" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="19" x="5" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="20" x="5" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="21" x="7" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="22" x="7" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="23" x="9" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="24" x="9" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="25" x="11" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="26" x="11" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="27" x="13" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="28" x="13" y="2.15" dx="1" dy="2.75" layer="1"/>
<text x="-16.0325" y="-3.4925" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="16.985" y="-3.4925" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="-14.25" y="-2.75" size="0.6096" layer="51" ratio="10">1</text>
<rectangle x1="-13.5" y1="0.5" x2="-12.5" y2="1.5" layer="51"/>
<rectangle x1="-13.5" y1="-1.5" x2="-12.5" y2="-0.5" layer="51"/>
<rectangle x1="12.5" y1="0.5" x2="13.5" y2="1.5" layer="51"/>
<rectangle x1="12.5" y1="-1.5" x2="13.5" y2="-0.5" layer="51"/>
<hole x="-12" y="0" drill="1"/>
<hole x="12" y="0" drill="1"/>
</package>
<package name="87832-30">
<wire x1="16.4" y1="3.75" x2="16.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="16.4" y1="-3.75" x2="-16.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="-16.4" y1="-3.75" x2="-16.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="-16.4" y1="3.75" x2="16.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="3.25" y1="-3" x2="15.5" y2="-3" width="0.0508" layer="51"/>
<wire x1="15.5" y1="-3" x2="15.5" y2="1" width="0.0508" layer="51"/>
<wire x1="15.5" y1="1" x2="15.5" y2="1.75" width="0.0508" layer="51"/>
<wire x1="15.5" y1="1.75" x2="15.5" y2="3" width="0.0508" layer="51"/>
<wire x1="15.5" y1="3" x2="14.25" y2="3" width="0.0508" layer="51"/>
<wire x1="14.25" y1="3" x2="14.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="14.25" y1="2.75" x2="13.75" y2="2.75" width="0.0508" layer="51"/>
<wire x1="13.75" y1="2.75" x2="13.75" y2="3" width="0.0508" layer="51"/>
<wire x1="13.75" y1="3" x2="12.25" y2="3" width="0.0508" layer="51"/>
<wire x1="-12.25" y1="3" x2="-13.75" y2="3" width="0.0508" layer="51"/>
<wire x1="-13.75" y1="3" x2="-13.75" y2="2.75" width="0.0508" layer="51"/>
<wire x1="-13.75" y1="2.75" x2="-14.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="-14.25" y1="2.75" x2="-14.25" y2="3" width="0.0508" layer="51"/>
<wire x1="-14.25" y1="3" x2="-15.5" y2="3" width="0.0508" layer="51"/>
<wire x1="-15.5" y1="3" x2="-15.5" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-15.5" y1="-0.75" x2="-15.5" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="-15.5" y1="-1.75" x2="-15.5" y2="-3" width="0.0508" layer="51"/>
<wire x1="-15.5" y1="-3" x2="-3.25" y2="-3" width="0.0508" layer="51"/>
<wire x1="-15.5" y1="-0.75" x2="-16" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-16" y1="-0.75" x2="-16.25" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-15.5" y1="-1.75" x2="-16" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="-16" y1="-1.75" x2="-16.25" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="15.5" y1="1.75" x2="16" y2="1.75" width="0.0508" layer="51"/>
<wire x1="16" y1="1.75" x2="16.25" y2="1.75" width="0.0508" layer="51"/>
<wire x1="15.5" y1="1" x2="16" y2="1" width="0.0508" layer="51"/>
<wire x1="16" y1="1" x2="16.25" y2="1" width="0.0508" layer="51"/>
<wire x1="-16" y1="-0.75" x2="-16" y2="3.25" width="0.0508" layer="51"/>
<wire x1="-16" y1="3.25" x2="16" y2="3.25" width="0.0508" layer="51"/>
<wire x1="16" y1="3.25" x2="16" y2="1.75" width="0.0508" layer="51"/>
<wire x1="16" y1="1" x2="16" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="16" y1="-3.25" x2="1" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="-1" y1="-3.25" x2="-16" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="-16" y1="-3.25" x2="-16" y2="-1.75" width="0.0508" layer="51"/>
<smd name="2" x="-14" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="4" x="-12" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="1" x="-14" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="3" x="-12" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="5" x="-10" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="6" x="-10" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="7" x="-8" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="8" x="-8" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="9" x="-6" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="10" x="-6" y="2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="11" x="-4" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="12" x="-4" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="13" x="-2" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="14" x="-2" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="15" x="0" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="16" x="0" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="17" x="2" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="18" x="2" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="19" x="4" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="20" x="4" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="21" x="6" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="22" x="6" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="23" x="8" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="24" x="8" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="25" x="10" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="26" x="10" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="27" x="12" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="28" x="12" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="29" x="14" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="30" x="14" y="2.15" dx="1" dy="2.75" layer="1"/>
<text x="-17.0325" y="-3.4925" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="17.985" y="-3.4925" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="-15.25" y="-2.75" size="0.6096" layer="51" ratio="10">1</text>
<rectangle x1="-14.5" y1="0.5" x2="-13.5" y2="1.5" layer="51"/>
<rectangle x1="-14.5" y1="-1.5" x2="-13.5" y2="-0.5" layer="51"/>
<rectangle x1="13.5" y1="0.5" x2="14.5" y2="1.5" layer="51"/>
<rectangle x1="13.5" y1="-1.5" x2="14.5" y2="-0.5" layer="51"/>
<hole x="-13" y="0" drill="1"/>
<hole x="13" y="0" drill="1"/>
</package>
<package name="87832-32">
<description>&lt;b&gt;PCB Headers&lt;/b&gt;&lt;p&gt;
2.00mm (.079") Pitch Milli-Grid Header, Vertical, Shrouded</description>
<wire x1="17.4" y1="3.75" x2="17.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="17.4" y1="-3.75" x2="-17.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="-17.4" y1="-3.75" x2="-17.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="-17.4" y1="3.75" x2="17.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="1" y1="-3.75" x2="1" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="1" y1="-3.25" x2="1" y2="-3" width="0.0508" layer="51"/>
<wire x1="3.25" y1="-3" x2="16.5" y2="-3" width="0.0508" layer="51"/>
<wire x1="16.5" y1="-3" x2="16.5" y2="1" width="0.0508" layer="51"/>
<wire x1="16.5" y1="1" x2="16.5" y2="1.75" width="0.0508" layer="51"/>
<wire x1="16.5" y1="1.75" x2="16.5" y2="3" width="0.0508" layer="51"/>
<wire x1="16.5" y1="3" x2="15.25" y2="3" width="0.0508" layer="51"/>
<wire x1="15.25" y1="3" x2="15.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="15.25" y1="2.75" x2="14.75" y2="2.75" width="0.0508" layer="51"/>
<wire x1="14.75" y1="2.75" x2="14.75" y2="3" width="0.0508" layer="51"/>
<wire x1="14.75" y1="3" x2="13.25" y2="3" width="0.0508" layer="51"/>
<wire x1="1.25" y1="3" x2="1.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="1.25" y1="2.75" x2="0.75" y2="2.75" width="0.0508" layer="51"/>
<wire x1="0.75" y1="2.75" x2="0.75" y2="3" width="0.0508" layer="51"/>
<wire x1="0.75" y1="3" x2="-0.75" y2="3" width="0.0508" layer="51"/>
<wire x1="-0.75" y1="3" x2="-0.75" y2="2.75" width="0.0508" layer="51"/>
<wire x1="-0.75" y1="2.75" x2="-1.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="-1.25" y1="2.75" x2="-1.25" y2="3" width="0.0508" layer="51"/>
<wire x1="-13.25" y1="3" x2="-14.75" y2="3" width="0.0508" layer="51"/>
<wire x1="-14.75" y1="3" x2="-14.75" y2="2.75" width="0.0508" layer="51"/>
<wire x1="-14.75" y1="2.75" x2="-15.25" y2="2.75" width="0.0508" layer="51"/>
<wire x1="-15.25" y1="2.75" x2="-15.25" y2="3" width="0.0508" layer="51"/>
<wire x1="-15.25" y1="3" x2="-16.5" y2="3" width="0.0508" layer="51"/>
<wire x1="-16.5" y1="3" x2="-16.5" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-16.5" y1="-0.75" x2="-16.5" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="-16.5" y1="-1.75" x2="-16.5" y2="-3" width="0.0508" layer="51"/>
<wire x1="-16.5" y1="-3" x2="-3.25" y2="-3" width="0.0508" layer="51"/>
<wire x1="-1" y1="-3" x2="-1" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="-1" y1="-3.25" x2="-1" y2="-3.75" width="0.0508" layer="51"/>
<wire x1="-16.5" y1="-0.75" x2="-17" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-17" y1="-0.75" x2="-17.25" y2="-0.75" width="0.0508" layer="51"/>
<wire x1="-16.5" y1="-1.75" x2="-17" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="-17" y1="-1.75" x2="-17.25" y2="-1.75" width="0.0508" layer="51"/>
<wire x1="16.5" y1="1.75" x2="17" y2="1.75" width="0.0508" layer="51"/>
<wire x1="17" y1="1.75" x2="17.25" y2="1.75" width="0.0508" layer="51"/>
<wire x1="16.5" y1="1" x2="17" y2="1" width="0.0508" layer="51"/>
<wire x1="17" y1="1" x2="17.25" y2="1" width="0.0508" layer="51"/>
<wire x1="-17" y1="-0.75" x2="-17" y2="3.25" width="0.0508" layer="51"/>
<wire x1="-17" y1="3.25" x2="17" y2="3.25" width="0.0508" layer="51"/>
<wire x1="17" y1="3.25" x2="17" y2="1.75" width="0.0508" layer="51"/>
<wire x1="17" y1="1" x2="17" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="17" y1="-3.25" x2="1" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="-1" y1="-3.25" x2="-17" y2="-3.25" width="0.0508" layer="51"/>
<wire x1="-17" y1="-3.25" x2="-17" y2="-1.75" width="0.0508" layer="51"/>
<smd name="2" x="-15" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="4" x="-13" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="1" x="-15" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="3" x="-13" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="5" x="-11" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="6" x="-11" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="7" x="-9" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="8" x="-9" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="9" x="-7" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="10" x="-7" y="2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="11" x="-5" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="12" x="-5" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="13" x="-3" y="-2.15" dx="1" dy="2.75" layer="1"/>
<smd name="14" x="-3" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="15" x="-1" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="16" x="-1" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="17" x="1" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="18" x="1" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="19" x="3" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="20" x="3" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="21" x="5" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="22" x="5" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="23" x="7" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="24" x="7" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="25" x="9" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="26" x="9" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="27" x="11" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="28" x="11" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="29" x="13" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="30" x="13" y="2.15" dx="1" dy="2.75" layer="1"/>
<smd name="31" x="15" y="-2.15" dx="1" dy="2.75" layer="1" rot="R180"/>
<smd name="32" x="15" y="2.15" dx="1" dy="2.75" layer="1"/>
<text x="-18.0325" y="-3.4925" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="18.985" y="-3.4925" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="-16.25" y="-2.75" size="0.6096" layer="51" ratio="10">1</text>
<rectangle x1="-15.5" y1="0.5" x2="-14.5" y2="1.5" layer="51"/>
<rectangle x1="-15.5" y1="-1.5" x2="-14.5" y2="-0.5" layer="51"/>
<rectangle x1="-1.5" y1="0.5" x2="-0.5" y2="1.5" layer="51"/>
<rectangle x1="-1.5" y1="-1.5" x2="-0.5" y2="-0.5" layer="51"/>
<rectangle x1="0.5" y1="0.5" x2="1.5" y2="1.5" layer="51"/>
<rectangle x1="0.5" y1="-1.5" x2="1.5" y2="-0.5" layer="51"/>
<rectangle x1="14.5" y1="0.5" x2="15.5" y2="1.5" layer="51"/>
<rectangle x1="14.5" y1="-1.5" x2="15.5" y2="-0.5" layer="51"/>
<hole x="-14" y="0" drill="1"/>
<hole x="14" y="0" drill="1"/>
</package>
<package name="70543-02">
<description>&lt;b&gt;C-Grid SL Connector&lt;/b&gt;&lt;p&gt;
 vertical, 2 pin</description>
<wire x1="3.81" y1="-2.8575" x2="3.81" y2="2.8575" width="0.254" layer="21"/>
<wire x1="3.81" y1="2.8575" x2="-3.81" y2="2.8575" width="0.254" layer="21"/>
<wire x1="-3.81" y1="2.8575" x2="-3.81" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-3.81" y1="-2.8575" x2="-3.4925" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-3.4925" y1="-2.8575" x2="-3.4925" y2="-3.81" width="0.254" layer="21"/>
<wire x1="-3.4925" y1="-3.81" x2="3.4925" y2="-3.81" width="0.254" layer="21"/>
<wire x1="3.4925" y1="-3.81" x2="3.4925" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="3.4925" y1="-2.8575" x2="3.81" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-3.175" y1="2.2225" x2="-3.175" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="3.175" y1="2.2225" x2="3.175" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="-3.175" y1="2.2225" x2="3.175" y2="2.2225" width="0.0508" layer="51"/>
<wire x1="-3.175" y1="-2.2225" x2="-2.8575" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="-2.8575" y1="-2.2225" x2="2.8575" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-2.2225" x2="3.175" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-3.175" x2="-2.8575" y2="-3.175" width="0.0508" layer="51"/>
<wire x1="-2.8575" y1="-2.2225" x2="-2.8575" y2="-3.175" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-2.2225" x2="2.8575" y2="-3.175" width="0.0508" layer="51"/>
<pad name="2" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-4.445" y="-2.54" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="-3.4925" y="3.4925" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-2.8575" y="-1.5875" size="1.016" layer="51" ratio="10">1</text>
<rectangle x1="1.0319" y1="-0.2381" x2="1.5081" y2="0.2381" layer="51"/>
<rectangle x1="-1.5081" y1="-0.2381" x2="-1.0319" y2="0.2381" layer="51"/>
</package>
<package name="70553-02">
 right angle, 2 pin</description>
<wire x1="3.9688" y1="5.8738" x2="-3.9688" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-1.27" y1="2.54" x2="-1.27" y2="-3.175" width="0.254" layer="21"/>
<wire x1="-1.27" y1="-3.175" x2="1.27" y2="-3.175" width="0.254" layer="21"/>
<wire x1="1.27" y1="-3.175" x2="1.27" y2="2.54" width="0.254" layer="21"/>
<wire x1="-3.9688" y1="5.8738" x2="-3.9688" y2="2.54" width="0.254" layer="21"/>
<wire x1="-3.9688" y1="2.54" x2="-3.175" y2="2.54" width="0.254" layer="21"/>
<wire x1="-3.175" y1="2.54" x2="-1.27" y2="2.54" width="0.254" layer="21"/>
<wire x1="1.27" y1="2.54" x2="3.175" y2="2.54" width="0.254" layer="21"/>
<wire x1="3.175" y1="2.54" x2="3.9688" y2="2.54" width="0.254" layer="21"/>
<wire x1="3.9688" y1="2.54" x2="3.9688" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-3.175" y1="2.54" x2="-3.175" y2="3.175" width="0.254" layer="21"/>
<wire x1="-3.175" y1="3.175" x2="-1.905" y2="4.445" width="0.254" layer="21" curve="-90"/>
<wire x1="-1.905" y1="4.445" x2="1.905" y2="4.445" width="0.254" layer="21"/>
<wire x1="1.905" y1="4.445" x2="3.175" y2="3.175" width="0.254" layer="21" curve="-90"/>
<wire x1="3.175" y1="3.175" x2="3.175" y2="2.54" width="0.254" layer="21"/>
<wire x1="-3.9688" y1="2.54" x2="-3.9688" y2="-5.715" width="0.254" layer="21"/>
<wire x1="-3.9688" y1="-5.715" x2="3.9688" y2="-5.715" width="0.254" layer="21"/>
<wire x1="3.9688" y1="-5.715" x2="3.9688" y2="2.54" width="0.254" layer="21"/>
<wire x1="-2.8575" y1="-5.715" x2="-2.8575" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-2.8575" y1="-6.35" x2="-2.8575" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="2.8575" y1="-7.9375" x2="2.8575" y2="-6.35" width="0.254" layer="51"/>
<wire x1="2.8575" y1="-6.35" x2="2.8575" y2="-5.715" width="0.254" layer="51"/>
<wire x1="-2.8575" y1="-6.35" x2="-1.905" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-1.905" y1="-6.35" x2="-0.635" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-0.635" y1="-6.35" x2="0.635" y2="-6.35" width="0.254" layer="51"/>
<wire x1="0.635" y1="-6.35" x2="1.905" y2="-6.35" width="0.127" layer="51"/>
<wire x1="1.905" y1="-6.35" x2="2.8575" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-1.905" y1="-6.35" x2="-1.905" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-1.905" y1="-7.6835" x2="-2.159" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-2.159" y1="-7.9375" x2="-2.8575" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-0.635" y1="-6.35" x2="-0.635" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-0.635" y1="-7.6835" x2="-0.381" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="0.635" y1="-6.35" x2="0.635" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="0.635" y1="-7.6835" x2="0.381" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="0.381" y1="-7.9375" x2="-0.381" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="1.905" y1="-6.35" x2="1.905" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="1.905" y1="-7.6835" x2="2.159" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="2.159" y1="-7.9375" x2="2.8575" y2="-7.9375" width="0.254" layer="51"/>
<pad name="2" x="1.27" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="1" x="-1.27" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<text x="-4.445" y="-5.715" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="5.715" y="-5.715" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-1.5875" y1="-7.62" x2="-0.9525" y2="-6.35" layer="51"/>
<rectangle x1="0.9525" y1="-7.62" x2="1.5875" y2="-6.35" layer="51"/>
<polygon width="0.0508" layer="21">
<vertex x="-3.81" y="5.8738"/>
<vertex x="-3.3338" y="3.9689"/>
<vertex x="-2.8575" y="5.8738"/>
</polygon>
</package>
<package name="15-91-02">
 right angle SMD, 2 pin</description>
<wire x1="3.9688" y1="5.08" x2="-3.9688" y2="5.08" width="0.254" layer="21"/>
<wire x1="-1.27" y1="1.905" x2="-1.27" y2="-3.81" width="0.254" layer="51"/>
<wire x1="-1.27" y1="-3.81" x2="1.27" y2="-3.81" width="0.254" layer="51"/>
<wire x1="1.27" y1="-3.81" x2="1.27" y2="1.905" width="0.254" layer="51"/>
<wire x1="-3.9688" y1="5.08" x2="-3.9688" y2="2.2225" width="0.254" layer="21"/>
<wire x1="-3.9688" y1="2.2225" x2="-3.9688" y2="1.905" width="0.254" layer="51"/>
<wire x1="-3.9688" y1="1.905" x2="-3.175" y2="1.905" width="0.254" layer="51"/>
<wire x1="-3.175" y1="1.905" x2="-1.27" y2="1.905" width="0.254" layer="51"/>
<wire x1="1.27" y1="1.905" x2="3.175" y2="1.905" width="0.254" layer="51"/>
<wire x1="3.175" y1="1.905" x2="3.9688" y2="1.905" width="0.254" layer="51"/>
<wire x1="3.9688" y1="1.905" x2="3.9688" y2="2.2225" width="0.254" layer="51"/>
<wire x1="3.9688" y1="2.2225" x2="3.9688" y2="5.08" width="0.254" layer="21"/>
<wire x1="-3.175" y1="1.905" x2="-3.175" y2="2.54" width="0.254" layer="51"/>
<wire x1="-3.175" y1="2.54" x2="-1.905" y2="3.81" width="0.254" layer="51" curve="-90"/>
<wire x1="-1.905" y1="3.81" x2="1.905" y2="3.81" width="0.254" layer="51"/>
<wire x1="1.905" y1="3.81" x2="3.175" y2="2.54" width="0.254" layer="51" curve="-90"/>
<wire x1="3.175" y1="2.54" x2="3.175" y2="1.905" width="0.254" layer="51"/>
<wire x1="-3.9688" y1="-0.635" x2="-3.9688" y2="-6.35" width="0.254" layer="21"/>
<wire x1="-3.9688" y1="-6.35" x2="3.9688" y2="-6.35" width="0.254" layer="21"/>
<wire x1="3.9688" y1="-6.35" x2="3.9688" y2="-0.635" width="0.254" layer="21"/>
<wire x1="-2.54" y1="-6.35" x2="-2.54" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="2.54" y1="-8.5725" x2="2.54" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-2.54" y1="-6.985" x2="-1.905" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-0.635" y1="-6.985" x2="0.635" y2="-6.985" width="0.254" layer="51"/>
<wire x1="1.905" y1="-6.985" x2="2.54" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-1.905" y1="-6.985" x2="-1.905" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="-1.905" y1="-8.3185" x2="-2.159" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-2.159" y1="-8.5725" x2="-2.54" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="0.635" y1="-6.985" x2="0.635" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="0.635" y1="-8.3185" x2="0.381" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="0.381" y1="-8.5725" x2="-0.381" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-0.381" y1="-8.5725" x2="-0.635" y2="-8.3185" width="0.254" layer="51" curve="-90"/>
<wire x1="-0.635" y1="-8.3185" x2="-0.635" y2="-6.985" width="0.254" layer="51"/>
<wire x1="1.905" y1="-6.985" x2="1.905" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="1.905" y1="-8.3185" x2="2.159" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="2.159" y1="-8.5725" x2="2.54" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-3.9688" y1="-0.635" x2="-3.9688" y2="1.905" width="0.254" layer="51"/>
<wire x1="3.9688" y1="-0.635" x2="3.9688" y2="1.905" width="0.254" layer="51"/>
<wire x1="-1.905" y1="-6.985" x2="-0.635" y2="-6.985" width="0.254" layer="51"/>
<wire x1="0.635" y1="-6.985" x2="1.905" y2="-6.985" width="0.254" layer="51"/>
<smd name="1" x="-1.27" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="2" x="1.27" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<text x="-4.445" y="-6.35" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="5.715" y="-6.35" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-1.5875" y1="-10.795" x2="-0.9525" y2="-6.985" layer="51"/>
<rectangle x1="0.9525" y1="-10.795" x2="1.5875" y2="-6.985" layer="51"/>
<hole x="-2.667" y="0.8382" drill="3.4036"/>
<hole x="2.667" y="0.8382" drill="3.4036"/>
<polygon width="0.2032" layer="21">
<vertex x="-3.81" y="5.08"/>
<vertex x="-3.3337" y="3.4926"/>
<vertex x="-2.8575" y="5.08"/>
</polygon>
</package>
<package name="70543-03">
 vertical, 3 pin</description>
<wire x1="5.08" y1="-2.8575" x2="5.08" y2="2.8575" width="0.254" layer="21"/>
<wire x1="5.08" y1="2.8575" x2="-5.08" y2="2.8575" width="0.254" layer="21"/>
<wire x1="-5.08" y1="2.8575" x2="-5.08" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-5.08" y1="-2.8575" x2="-3.4925" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="3.4925" y1="-2.8575" x2="5.08" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-4.445" y1="2.2225" x2="-4.445" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="4.445" y1="2.2225" x2="4.445" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="-4.445" y1="2.2225" x2="4.445" y2="2.2225" width="0.0508" layer="51"/>
<wire x1="-4.445" y1="-2.2225" x2="-2.8575" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-2.2225" x2="4.445" y2="-2.2225" width="0.0508" layer="51"/>
<pad name="3" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-5.715" y="-2.54" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="-4.7625" y="3.4925" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.1275" y="-1.5875" size="1.016" layer="51" ratio="10">1</text>
<rectangle x1="-0.2381" y1="-0.2381" x2="0.2381" y2="0.2381" layer="51"/>
<rectangle x1="-2.7781" y1="-0.2381" x2="-2.3019" y2="0.2381" layer="51"/>
<rectangle x1="2.3019" y1="-0.2381" x2="2.7781" y2="0.2381" layer="51"/>
</package>
<package name="70553-03">
 right angle, 3 pin</description>
<wire x1="5.2388" y1="5.8738" x2="4.1275" y2="5.8738" width="0.254" layer="21"/>
<wire x1="4.1275" y1="5.8738" x2="-5.2387" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-5.2387" y1="5.8738" x2="-5.2388" y2="-5.715" width="0.254" layer="21"/>
<wire x1="-4.1275" y1="5.8737" x2="-4.1275" y2="2.54" width="0.254" layer="21"/>
<wire x1="-4.1275" y1="2.54" x2="-3.175" y2="2.54" width="0.254" layer="21"/>
<wire x1="3.175" y1="2.54" x2="4.1275" y2="2.54" width="0.254" layer="21"/>
<wire x1="4.1275" y1="2.54" x2="4.1275" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-5.2388" y1="-5.715" x2="5.2388" y2="-5.715" width="0.254" layer="21"/>
<wire x1="5.2388" y1="-5.715" x2="5.2388" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-4.1275" y1="-5.715" x2="-4.1275" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-4.1275" y1="-6.35" x2="-4.1275" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-4.1275" y1="-6.35" x2="-3.175" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-3.175" y1="-6.35" x2="-1.905" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-1.905" y1="-6.35" x2="-0.635" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-0.635" y1="-6.35" x2="0.635" y2="-6.35" width="0.127" layer="51"/>
<wire x1="0.635" y1="-6.35" x2="1.5875" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-3.175" y1="-6.35" x2="-3.175" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-3.175" y1="-7.6835" x2="-3.429" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-3.429" y1="-7.9375" x2="-4.1275" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-1.905" y1="-7.6835" x2="-1.651" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-0.635" y1="-7.6835" x2="-0.889" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-0.889" y1="-7.9375" x2="-1.651" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="0.635" y1="-7.6835" x2="0.889" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="0.889" y1="-7.9375" x2="1.3335" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="1.3335" y1="-7.9375" x2="1.5875" y2="-7.6835" width="0.254" layer="51" curve="90"/>
<wire x1="1.5875" y1="-7.6835" x2="1.5875" y2="-6.35" width="0.254" layer="51"/>
<wire x1="4.1275" y1="-7.9375" x2="4.1275" y2="-6.35" width="0.254" layer="51"/>
<wire x1="4.1275" y1="-6.35" x2="4.1275" y2="-5.715" width="0.254" layer="51"/>
<wire x1="1.5875" y1="-6.35" x2="3.175" y2="-6.35" width="0.127" layer="51"/>
<wire x1="3.175" y1="-6.35" x2="4.1275" y2="-6.35" width="0.254" layer="51"/>
<wire x1="3.175" y1="-6.35" x2="3.175" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="3.175" y1="-7.6835" x2="3.429" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="3.429" y1="-7.9375" x2="4.1275" y2="-7.9375" width="0.254" layer="51"/>
<pad name="2" x="0" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="1" x="-2.54" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<text x="-5.715" y="-5.715" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="6.985" y="-5.715" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.8575" y1="-7.62" x2="-2.2225" y2="-6.35" layer="51"/>
<rectangle x1="-0.3175" y1="-7.62" x2="0.3175" y2="-6.35" layer="51"/>
<rectangle x1="2.2225" y1="-7.62" x2="2.8575" y2="-6.35" layer="51"/>
<vertex x="-3.9688" y="5.8738"/>
<vertex x="-3.4924" y="3.9689"/>
<vertex x="-3.0163" y="5.8738"/>
</polygon>
</package>
<package name="74099-03">
 vertical SMD, 3 pin</description>
<smd name="3" x="2.54" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="2" x="0" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="1" x="-2.54" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<text x="-4.1275" y="0.635" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.1275" y="-1.905" size="1.016" layer="51" ratio="10">1</text>
</package>
<package name="15-91-03">
 right angle SMD, 3 pin</description>
<wire x1="5.2388" y1="5.08" x2="-5.2387" y2="5.08" width="0.254" layer="21"/>
<wire x1="-5.2387" y1="5.08" x2="-5.2387" y2="2.2225" width="0.254" layer="21"/>
<wire x1="-5.2388" y1="-0.635" x2="-5.2388" y2="-6.35" width="0.254" layer="21"/>
<wire x1="-4.1275" y1="5.0799" x2="-4.1275" y2="1.905" width="0.254" layer="51"/>
<wire x1="-4.1275" y1="1.905" x2="-3.175" y2="1.905" width="0.254" layer="51"/>
<wire x1="3.175" y1="1.905" x2="4.1275" y2="1.905" width="0.254" layer="51"/>
<wire x1="4.1275" y1="1.905" x2="4.1275" y2="5.08" width="0.254" layer="51"/>
<wire x1="-5.2388" y1="-6.35" x2="5.2388" y2="-6.35" width="0.254" layer="21"/>
<wire x1="5.2388" y1="-6.35" x2="5.2388" y2="-0.635" width="0.254" layer="21"/>
<wire x1="5.2388" y1="2.2225" x2="5.2388" y2="5.08" width="0.254" layer="21"/>
<wire x1="-3.81" y1="-6.35" x2="-3.81" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-3.81" y1="-6.985" x2="-3.175" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-3.175" y1="-6.985" x2="-3.175" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="-3.175" y1="-8.3185" x2="-3.429" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-3.429" y1="-8.5725" x2="-3.81" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-1.905" y1="-8.3185" x2="-1.651" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="-0.635" y1="-6.985" x2="-0.635" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="-0.635" y1="-8.3185" x2="-0.889" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-0.889" y1="-8.5725" x2="-1.651" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="3.81" y1="-8.5725" x2="3.81" y2="-6.35" width="0.254" layer="51"/>
<wire x1="3.175" y1="-6.985" x2="3.81" y2="-6.985" width="0.254" layer="51"/>
<wire x1="0.635" y1="-8.3185" x2="0.889" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="1.905" y1="-8.3185" x2="1.651" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="1.651" y1="-8.5725" x2="0.889" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="3.175" y1="-6.985" x2="3.175" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="3.175" y1="-8.3185" x2="3.429" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="3.429" y1="-8.5725" x2="3.81" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-5.2388" y1="2.2225" x2="-5.2388" y2="-0.635" width="0.254" layer="51"/>
<wire x1="5.2388" y1="2.2225" x2="5.2388" y2="-0.635" width="0.254" layer="51"/>
<wire x1="-3.175" y1="-6.985" x2="-1.905" y2="-6.985" width="0.254" layer="51"/>
<wire x1="1.905" y1="-6.985" x2="3.175" y2="-6.985" width="0.254" layer="51"/>
<smd name="1" x="-2.54" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="2" x="0" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="3" x="2.54" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<text x="-5.715" y="-6.35" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="6.985" y="-6.35" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.8575" y1="-10.795" x2="-2.2225" y2="-6.985" layer="51"/>
<rectangle x1="-0.3175" y1="-10.795" x2="0.3175" y2="-6.985" layer="51"/>
<rectangle x1="2.2225" y1="-10.795" x2="2.8575" y2="-6.985" layer="51"/>
<hole x="-3.937" y="0.8382" drill="3.4036"/>
<hole x="3.937" y="0.8382" drill="3.4036"/>
</polygon>
</package>
<package name="70543-04">
 vertical, 4 pin</description>
<wire x1="6.35" y1="-2.8575" x2="6.35" y2="2.8575" width="0.254" layer="21"/>
<wire x1="6.35" y1="2.8575" x2="-6.35" y2="2.8575" width="0.254" layer="21"/>
<wire x1="-6.35" y1="2.8575" x2="-6.35" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-6.35" y1="-2.8575" x2="-3.4925" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="3.4925" y1="-2.8575" x2="6.35" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-5.715" y1="2.2225" x2="-5.715" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="5.715" y1="2.2225" x2="5.715" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="-5.715" y1="2.2225" x2="5.715" y2="2.2225" width="0.0508" layer="51"/>
<wire x1="-5.715" y1="-2.2225" x2="-2.8575" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-2.2225" x2="5.715" y2="-2.2225" width="0.0508" layer="51"/>
<pad name="3" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-6.985" y="-2.54" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="-6.0325" y="3.4925" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-5.3975" y="-1.5875" size="1.016" layer="51" ratio="10">1</text>
<rectangle x1="-4.0481" y1="-0.2381" x2="-3.5719" y2="0.2381" layer="51"/>
<rectangle x1="3.5719" y1="-0.2381" x2="4.0481" y2="0.2381" layer="51"/>
</package>
<package name="70553-04">
 right angle, 4 pin</description>
<wire x1="6.1913" y1="5.8738" x2="4.1275" y2="5.8738" width="0.254" layer="21"/>
<wire x1="4.1275" y1="5.8738" x2="-6.1913" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-6.1913" y1="5.8738" x2="-6.1913" y2="-5.715" width="0.254" layer="21"/>
<wire x1="-6.1913" y1="-5.715" x2="6.1913" y2="-5.715" width="0.254" layer="21"/>
<wire x1="6.1913" y1="-5.715" x2="6.1913" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-5.3975" y1="-6.35" x2="-3.175" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-3.175" y1="-6.35" x2="-1.905" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-3.175" y1="-7.6835" x2="-2.921" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-2.159" y1="-7.9375" x2="-2.921" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="1.905" y1="-6.35" x2="3.175" y2="-6.35" width="0.254" layer="51"/>
<wire x1="3.175" y1="-7.6835" x2="2.921" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="2.921" y1="-7.9375" x2="2.159" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="3.175" y1="-6.35" x2="4.445" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-5.3975" y1="-5.715" x2="-5.3975" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-5.3975" y1="-6.35" x2="-5.3975" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-4.445" y1="-6.35" x2="-4.445" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-4.445" y1="-7.6835" x2="-4.699" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-4.699" y1="-7.9375" x2="-5.3975" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="4.445" y1="-6.35" x2="4.445" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="4.445" y1="-7.6835" x2="4.699" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="4.699" y1="-7.9375" x2="5.3975" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="5.3975" y1="-7.9375" x2="5.3975" y2="-6.35" width="0.254" layer="51"/>
<wire x1="5.3975" y1="-6.35" x2="5.3975" y2="-5.715" width="0.254" layer="51"/>
<wire x1="4.445" y1="-6.35" x2="5.3975" y2="-6.35" width="0.254" layer="51"/>
<pad name="2" x="-1.27" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="1" x="-3.81" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="4" x="3.81" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<text x="-6.6675" y="-5.715" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="7.9375" y="-5.715" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-4.1275" y1="-7.62" x2="-3.4925" y2="-6.35" layer="51"/>
<rectangle x1="3.4925" y1="-7.62" x2="4.1275" y2="-6.35" layer="51"/>
<vertex x="-5.715" y="5.8737"/>
<vertex x="-5.2387" y="3.9688"/>
<vertex x="-4.7625" y="5.8737"/>
</polygon>
</package>
<package name="74099-04">
 vertical SMD, 4 pin</description>
<smd name="4" x="3.81" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="3" x="1.27" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="2" x="-1.27" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="1" x="-3.81" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<text x="-5.3975" y="0.635" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-5.3975" y="-1.905" size="1.016" layer="51" ratio="10">1</text>
</package>
<package name="15-91-04">
 right angle SMD, 4 pin</description>
<wire x1="6.1913" y1="5.08" x2="-6.1913" y2="5.08" width="0.254" layer="21"/>
<wire x1="-6.1913" y1="5.08" x2="-6.1913" y2="2.54" width="0.254" layer="21"/>
<wire x1="-6.1913" y1="-0.9525" x2="-6.1913" y2="-6.35" width="0.254" layer="21"/>
<wire x1="-6.1913" y1="-6.35" x2="6.1913" y2="-6.35" width="0.254" layer="21"/>
<wire x1="6.1913" y1="-6.35" x2="6.1913" y2="-0.9525" width="0.254" layer="21"/>
<wire x1="6.1913" y1="2.54" x2="6.1913" y2="5.08" width="0.254" layer="21"/>
<wire x1="-5.08" y1="-6.35" x2="-5.08" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-5.08" y1="-6.985" x2="-4.445" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-4.445" y1="-6.985" x2="-4.445" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="-4.445" y1="-8.3185" x2="-4.699" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-4.699" y1="-8.5725" x2="-5.08" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-3.175" y1="-8.3185" x2="-2.921" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="-2.159" y1="-8.5725" x2="-2.921" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-0.635" y1="-8.3185" x2="-0.381" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="5.08" y1="-8.5725" x2="5.08" y2="-6.35" width="0.254" layer="51"/>
<wire x1="4.445" y1="-6.985" x2="5.08" y2="-6.985" width="0.254" layer="51"/>
<wire x1="3.175" y1="-8.3185" x2="2.921" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="2.921" y1="-8.5725" x2="2.159" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="4.445" y1="-6.985" x2="4.445" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="4.445" y1="-8.3185" x2="4.699" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="4.699" y1="-8.5725" x2="5.08" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-6.1913" y1="2.54" x2="-6.1913" y2="-0.9525" width="0.254" layer="51"/>
<wire x1="6.1913" y1="2.54" x2="6.1913" y2="-0.9525" width="0.254" layer="51"/>
<wire x1="-4.445" y1="-6.985" x2="-3.175" y2="-6.985" width="0.254" layer="51"/>
<wire x1="3.175" y1="-6.985" x2="4.445" y2="-6.985" width="0.254" layer="51"/>
<smd name="1" x="-3.81" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="2" x="-1.27" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="3" x="1.27" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="4" x="3.81" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<text x="-6.6675" y="-6.35" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="7.9375" y="-6.35" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-4.1275" y1="-10.795" x2="-3.4925" y2="-6.985" layer="51"/>
<rectangle x1="3.4925" y1="-10.795" x2="4.1275" y2="-6.985" layer="51"/>
<hole x="-5.207" y="0.8382" drill="3.4036"/>
<hole x="5.207" y="0.8382" drill="3.4036"/>
<vertex x="-5.715" y="5.08"/>
<vertex x="-5.2387" y="3.1751"/>
<vertex x="-4.7625" y="5.08"/>
</polygon>
</package>
<package name="70543-05">
 vertical, 5 pin</description>
<wire x1="7.62" y1="-2.8575" x2="7.62" y2="2.8575" width="0.254" layer="21"/>
<wire x1="7.62" y1="2.8575" x2="-7.62" y2="2.8575" width="0.254" layer="21"/>
<wire x1="-7.62" y1="2.8575" x2="-7.62" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-7.62" y1="-2.8575" x2="-3.4925" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="3.4925" y1="-2.8575" x2="7.62" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-6.985" y1="2.2225" x2="-6.985" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="6.985" y1="2.2225" x2="6.985" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="-6.985" y1="2.2225" x2="6.985" y2="2.2225" width="0.0508" layer="51"/>
<wire x1="-6.985" y1="-2.2225" x2="-2.8575" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-2.2225" x2="6.985" y2="-2.2225" width="0.0508" layer="51"/>
<pad name="3" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="-5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-8.255" y="-2.54" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="-7.3025" y="3.4925" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.6675" y="-1.5875" size="1.016" layer="51" ratio="10">1</text>
<rectangle x1="-5.3181" y1="-0.2381" x2="-4.8419" y2="0.2381" layer="51"/>
<rectangle x1="4.8419" y1="-0.2381" x2="5.3181" y2="0.2381" layer="51"/>
</package>
<package name="70553-05">
 right angle, 5 pin</description>
<wire x1="7.4613" y1="5.8738" x2="4.1275" y2="5.8738" width="0.254" layer="21"/>
<wire x1="4.1275" y1="5.8738" x2="-7.4613" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-7.4613" y1="5.8738" x2="-7.4613" y2="-5.715" width="0.254" layer="21"/>
<wire x1="-7.4613" y1="-5.715" x2="7.4613" y2="-5.715" width="0.254" layer="21"/>
<wire x1="7.4613" y1="-5.715" x2="7.4613" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-5.715" y1="-6.35" x2="-4.445" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-4.445" y1="-6.35" x2="-3.175" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-4.445" y1="-7.6835" x2="-4.191" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-3.429" y1="-7.9375" x2="-4.191" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="0.635" y1="-6.35" x2="1.905" y2="-6.35" width="0.254" layer="51"/>
<wire x1="1.905" y1="-7.6835" x2="1.651" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="1.651" y1="-7.9375" x2="0.889" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="1.905" y1="-6.35" x2="3.175" y2="-6.35" width="0.127" layer="51"/>
<wire x1="3.175" y1="-6.35" x2="4.445" y2="-6.35" width="0.254" layer="51"/>
<wire x1="4.445" y1="-7.6835" x2="4.191" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="4.191" y1="-7.9375" x2="3.429" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="4.445" y1="-6.35" x2="5.715" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-6.6675" y1="-5.715" x2="-6.6675" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-5.715" y1="-6.35" x2="-5.715" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-5.715" y1="-7.6835" x2="-5.969" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-5.969" y1="-7.9375" x2="-6.6675" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="5.715" y1="-6.35" x2="5.715" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="5.715" y1="-7.6835" x2="5.969" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="5.969" y1="-7.9375" x2="6.6675" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="6.6675" y1="-7.9375" x2="6.6675" y2="-6.35" width="0.254" layer="51"/>
<wire x1="6.6675" y1="-6.35" x2="6.6675" y2="-5.715" width="0.254" layer="51"/>
<wire x1="5.715" y1="-6.35" x2="6.6675" y2="-6.35" width="0.254" layer="51"/>
<pad name="2" x="-2.54" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="1" x="-5.08" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="3" x="0" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="4" x="2.54" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="5" x="5.08" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<text x="-7.9375" y="-5.715" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="9.2075" y="-5.715" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-5.3975" y1="-7.62" x2="-4.7625" y2="-6.35" layer="51"/>
<rectangle x1="4.7625" y1="-7.62" x2="5.3975" y2="-6.35" layer="51"/>
<vertex x="-6.985" y="5.8737"/>
<vertex x="-6.5087" y="3.9688"/>
<vertex x="-6.0325" y="5.8737"/>
</polygon>
</package>
<package name="74099-05">
 vertical SMD, 5 pin</description>
<smd name="5" x="5.08" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="4" x="2.54" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="3" x="0" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="2" x="-2.54" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="1" x="-5.08" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<text x="-6.6675" y="0.635" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.6675" y="-1.905" size="1.016" layer="51" ratio="10">1</text>
</package>
<package name="15-91-05">
 right angle SMD, 5 pin</description>
<wire x1="7.4613" y1="5.0801" x2="-7.4613" y2="5.0801" width="0.254" layer="21"/>
<wire x1="-7.4613" y1="5.0801" x2="-7.4613" y2="2.54" width="0.254" layer="21"/>
<wire x1="-7.4613" y1="-0.9525" x2="-7.4613" y2="-6.35" width="0.254" layer="21"/>
<wire x1="-7.4613" y1="-6.35" x2="7.4613" y2="-6.35" width="0.254" layer="21"/>
<wire x1="7.4613" y1="-6.35" x2="7.4613" y2="-0.9525" width="0.254" layer="21"/>
<wire x1="7.4613" y1="2.54" x2="7.4613" y2="5.0801" width="0.254" layer="21"/>
<wire x1="-4.1275" y1="5.08" x2="-4.1275" y2="1.905" width="0.254" layer="51"/>
<wire x1="4.1275" y1="1.905" x2="4.1275" y2="5.0801" width="0.254" layer="51"/>
<wire x1="-6.35" y1="-6.35" x2="-6.35" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-6.35" y1="-6.985" x2="-5.715" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-5.715" y1="-6.985" x2="-5.715" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="-5.715" y1="-8.3185" x2="-5.969" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-5.969" y1="-8.5725" x2="-6.35" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-4.445" y1="-8.3185" x2="-4.191" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="-3.429" y1="-8.5725" x2="-4.191" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="6.35" y1="-8.5725" x2="6.35" y2="-6.35" width="0.254" layer="51"/>
<wire x1="5.715" y1="-6.985" x2="6.35" y2="-6.985" width="0.254" layer="51"/>
<wire x1="4.445" y1="-8.3185" x2="4.191" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="4.191" y1="-8.5725" x2="3.429" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="5.715" y1="-6.985" x2="5.715" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="5.715" y1="-8.3185" x2="5.969" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="5.969" y1="-8.5725" x2="6.35" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-7.4613" y1="2.54" x2="-7.4613" y2="-0.9525" width="0.254" layer="51"/>
<wire x1="7.4613" y1="2.54" x2="7.4613" y2="-0.9525" width="0.254" layer="51"/>
<wire x1="-5.715" y1="-6.985" x2="-4.445" y2="-6.985" width="0.254" layer="51"/>
<wire x1="4.445" y1="-6.985" x2="5.715" y2="-6.985" width="0.254" layer="51"/>
<smd name="1" x="-5.08" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="2" x="-2.54" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="3" x="0" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="4" x="2.54" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="5" x="5.08" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<text x="-7.9375" y="-6.35" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="9.2075" y="-6.35" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-5.3975" y1="-10.795" x2="-4.7625" y2="-6.985" layer="51"/>
<rectangle x1="4.7625" y1="-10.795" x2="5.3975" y2="-6.985" layer="51"/>
<hole x="-6.477" y="0.8382" drill="3.4036"/>
<hole x="6.477" y="0.8382" drill="3.4036"/>
<vertex x="-6.985" y="5.08"/>
<vertex x="-6.5087" y="3.1751"/>
<vertex x="-6.0325" y="5.08"/>
</polygon>
</package>
<package name="70543-06">
 vertical, 6 pin</description>
<wire x1="8.89" y1="-2.8575" x2="8.89" y2="2.8575" width="0.254" layer="21"/>
<wire x1="8.89" y1="2.8575" x2="-8.89" y2="2.8575" width="0.254" layer="21"/>
<wire x1="-8.89" y1="2.8575" x2="-8.89" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-8.89" y1="-2.8575" x2="-3.4925" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="3.4925" y1="-2.8575" x2="8.89" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-8.255" y1="2.2225" x2="-8.255" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="8.255" y1="2.2225" x2="8.255" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="-8.255" y1="2.2225" x2="8.255" y2="2.2225" width="0.0508" layer="51"/>
<wire x1="-8.255" y1="-2.2225" x2="-2.8575" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-2.2225" x2="8.255" y2="-2.2225" width="0.0508" layer="51"/>
<pad name="3" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="-6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-9.525" y="-2.54" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="-8.5725" y="3.4925" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-7.9375" y="-1.5875" size="1.016" layer="51" ratio="10">1</text>
<rectangle x1="-6.5881" y1="-0.2381" x2="-6.1119" y2="0.2381" layer="51"/>
<rectangle x1="6.1119" y1="-0.2381" x2="6.5881" y2="0.2381" layer="51"/>
</package>
<package name="70553-06">
 right angle, 6 pin</description>
<wire x1="8.7313" y1="5.8738" x2="4.1275" y2="5.8738" width="0.254" layer="21"/>
<wire x1="4.1275" y1="5.8738" x2="-8.7313" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-8.7313" y1="5.8738" x2="-8.7313" y2="-5.715" width="0.254" layer="21"/>
<wire x1="-8.7313" y1="-5.715" x2="8.7313" y2="-5.715" width="0.254" layer="21"/>
<wire x1="8.7313" y1="-5.715" x2="8.7313" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-6.985" y1="-6.35" x2="-5.715" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-5.715" y1="-6.35" x2="-4.445" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-5.715" y1="-7.6835" x2="-5.461" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-4.699" y1="-7.9375" x2="-5.461" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-4.445" y1="-6.35" x2="-3.175" y2="-6.35" width="0.127" layer="51"/>
<wire x1="4.445" y1="-6.35" x2="5.715" y2="-6.35" width="0.254" layer="51"/>
<wire x1="5.715" y1="-7.6835" x2="5.461" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="5.461" y1="-7.9375" x2="4.699" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="5.715" y1="-6.35" x2="6.985" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-7.9375" y1="-5.715" x2="-7.9375" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-6.985" y1="-6.35" x2="-6.985" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-6.985" y1="-7.6835" x2="-7.239" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-7.239" y1="-7.9375" x2="-7.9375" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="6.985" y1="-6.35" x2="6.985" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="6.985" y1="-7.6835" x2="7.239" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="7.239" y1="-7.9375" x2="7.9375" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="7.9375" y1="-7.9375" x2="7.9375" y2="-6.35" width="0.254" layer="51"/>
<wire x1="7.9375" y1="-6.35" x2="7.9375" y2="-5.715" width="0.254" layer="51"/>
<wire x1="6.985" y1="-6.35" x2="7.9375" y2="-6.35" width="0.254" layer="51"/>
<pad name="2" x="-3.81" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="1" x="-6.35" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="3" x="-1.27" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="4" x="1.27" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="5" x="3.81" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="6" x="6.35" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<text x="-9.2075" y="-5.715" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="10.4775" y="-5.715" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-6.6675" y1="-7.62" x2="-6.0325" y2="-6.35" layer="51"/>
<rectangle x1="6.0325" y1="-7.62" x2="6.6675" y2="-6.35" layer="51"/>
<vertex x="-8.255" y="5.8737"/>
<vertex x="-7.7787" y="3.9688"/>
<vertex x="-7.3025" y="5.8737"/>
</polygon>
</package>
<package name="74099-06">
 vertical SMD, 6 pin</description>
<smd name="5" x="3.81" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="4" x="1.27" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="3" x="-1.27" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="2" x="-3.81" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="1" x="-6.35" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="6" x="6.35" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<text x="-7.9375" y="0.635" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-7.9375" y="-1.905" size="1.016" layer="51" ratio="10">1</text>
</package>
<package name="15-91-06">
 right angle SMD, 6 pin</description>
<wire x1="8.7313" y1="5.08" x2="-8.7313" y2="5.08" width="0.254" layer="21"/>
<wire x1="-8.7313" y1="5.08" x2="-8.7313" y2="2.54" width="0.254" layer="21"/>
<wire x1="-8.7313" y1="-0.9525" x2="-8.7313" y2="-6.35" width="0.254" layer="21"/>
<wire x1="-8.7313" y1="-6.35" x2="8.7313" y2="-6.35" width="0.254" layer="21"/>
<wire x1="8.7313" y1="-6.35" x2="8.7313" y2="-0.9525" width="0.254" layer="21"/>
<wire x1="8.7313" y1="2.54" x2="8.7313" y2="5.08" width="0.254" layer="21"/>
<wire x1="-7.62" y1="-6.35" x2="-7.62" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-7.62" y1="-6.985" x2="-6.985" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-6.985" y1="-6.985" x2="-6.985" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="-6.985" y1="-8.3185" x2="-7.239" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-7.239" y1="-8.5725" x2="-7.62" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-5.715" y1="-8.3185" x2="-5.461" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="-4.699" y1="-8.5725" x2="-5.461" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="7.62" y1="-8.5725" x2="7.62" y2="-6.35" width="0.254" layer="51"/>
<wire x1="6.985" y1="-6.985" x2="7.62" y2="-6.985" width="0.254" layer="51"/>
<wire x1="5.715" y1="-8.3185" x2="5.461" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="5.461" y1="-8.5725" x2="4.699" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="6.985" y1="-6.985" x2="6.985" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="6.985" y1="-8.3185" x2="7.239" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="7.239" y1="-8.5725" x2="7.62" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-8.7313" y1="2.54" x2="-8.7313" y2="-0.9525" width="0.254" layer="51"/>
<wire x1="8.7313" y1="2.54" x2="8.7313" y2="-0.9525" width="0.254" layer="51"/>
<wire x1="-6.985" y1="-6.985" x2="-5.715" y2="-6.985" width="0.254" layer="51"/>
<wire x1="5.715" y1="-6.985" x2="6.985" y2="-6.985" width="0.254" layer="51"/>
<smd name="1" x="-6.35" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="2" x="-3.81" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="3" x="-1.27" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="4" x="1.27" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="5" x="3.81" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="6" x="6.35" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<text x="-9.2075" y="-6.35" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="10.4775" y="-6.35" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-6.6675" y1="-10.795" x2="-6.0325" y2="-6.985" layer="51"/>
<rectangle x1="6.0325" y1="-10.795" x2="6.6675" y2="-6.985" layer="51"/>
<hole x="-7.747" y="0.8382" drill="3.4036"/>
<hole x="7.747" y="0.8382" drill="3.4036"/>
<vertex x="-8.255" y="5.08"/>
<vertex x="-7.7787" y="3.1751"/>
<vertex x="-7.3025" y="5.08"/>
</polygon>
</package>
<package name="70543-07">
 vertical, 7 pin</description>
<wire x1="10.16" y1="-2.8575" x2="10.16" y2="2.8575" width="0.254" layer="21"/>
<wire x1="10.16" y1="2.8575" x2="-10.16" y2="2.8575" width="0.254" layer="21"/>
<wire x1="-10.16" y1="2.8575" x2="-10.16" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-10.16" y1="-2.8575" x2="-3.4925" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="3.4925" y1="-2.8575" x2="10.16" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-9.525" y1="2.2225" x2="-9.525" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="9.525" y1="2.2225" x2="9.525" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="-9.525" y1="2.2225" x2="9.525" y2="2.2225" width="0.0508" layer="51"/>
<wire x1="-9.525" y1="-2.2225" x2="-2.8575" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-2.2225" x2="9.525" y2="-2.2225" width="0.0508" layer="51"/>
<pad name="3" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="-7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-10.795" y="-2.54" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="-9.8425" y="3.4925" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-9.2075" y="-1.5875" size="1.016" layer="51" ratio="10">1</text>
<rectangle x1="-7.8581" y1="-0.2381" x2="-7.3819" y2="0.2381" layer="51"/>
<rectangle x1="7.3819" y1="-0.2381" x2="7.8581" y2="0.2381" layer="51"/>
</package>
<package name="70553-07">
 right angle, 7 pin</description>
<wire x1="10.0013" y1="5.8738" x2="4.1275" y2="5.8738" width="0.254" layer="21"/>
<wire x1="4.1275" y1="5.8738" x2="-10.0013" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-10.0013" y1="5.8738" x2="-10.0013" y2="-5.715" width="0.254" layer="21"/>
<wire x1="-10.0013" y1="-5.715" x2="10.0013" y2="-5.715" width="0.254" layer="21"/>
<wire x1="10.0013" y1="-5.715" x2="10.0013" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-8.255" y1="-6.35" x2="-6.985" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-6.985" y1="-6.35" x2="-5.715" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-6.985" y1="-7.6835" x2="-6.731" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-5.969" y1="-7.9375" x2="-6.731" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="5.715" y1="-6.35" x2="6.985" y2="-6.35" width="0.254" layer="51"/>
<wire x1="6.985" y1="-7.6835" x2="6.731" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="6.731" y1="-7.9375" x2="5.969" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="6.985" y1="-6.35" x2="8.255" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-9.2075" y1="-5.715" x2="-9.2075" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-8.255" y1="-6.35" x2="-8.255" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-8.255" y1="-7.6835" x2="-8.509" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-8.509" y1="-7.9375" x2="-9.2075" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="8.255" y1="-6.35" x2="8.255" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="8.255" y1="-7.6835" x2="8.509" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="8.509" y1="-7.9375" x2="9.2075" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="9.2075" y1="-7.9375" x2="9.2075" y2="-6.35" width="0.254" layer="51"/>
<wire x1="9.2075" y1="-6.35" x2="9.2075" y2="-5.715" width="0.254" layer="51"/>
<wire x1="8.255" y1="-6.35" x2="9.2075" y2="-6.35" width="0.254" layer="51"/>
<pad name="2" x="-5.08" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="1" x="-7.62" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="3" x="-2.54" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="4" x="0" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="5" x="2.54" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="6" x="5.08" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="7" x="7.62" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<text x="-10.4775" y="-5.715" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="11.7475" y="-5.715" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-7.9375" y1="-7.62" x2="-7.3025" y2="-6.35" layer="51"/>
<rectangle x1="7.3025" y1="-7.62" x2="7.9375" y2="-6.35" layer="51"/>
<vertex x="-9.525" y="5.8738"/>
<vertex x="-9.0487" y="3.9689"/>
<vertex x="-8.5725" y="5.8738"/>
</polygon>
</package>
<package name="74099-07">
 vertical SMD, 7 pin</description>
<smd name="5" x="2.54" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="4" x="0" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="3" x="-2.54" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="2" x="-5.08" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="1" x="-7.62" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="6" x="5.08" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="7" x="7.62" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<text x="-9.2075" y="0.635" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-9.2075" y="-1.905" size="1.016" layer="51" ratio="10">1</text>
</package>
<package name="15-91-07">
 right angle SMD, 7 pin</description>
<wire x1="10.0013" y1="5.0801" x2="-10.0013" y2="5.0801" width="0.254" layer="21"/>
<wire x1="-10.0013" y1="5.0801" x2="-10.0013" y2="2.54" width="0.254" layer="21"/>
<wire x1="-10.0013" y1="-0.9525" x2="-10.0013" y2="-6.35" width="0.254" layer="21"/>
<wire x1="-10.0013" y1="-6.35" x2="10.0013" y2="-6.35" width="0.254" layer="21"/>
<wire x1="10.0013" y1="-6.35" x2="10.0013" y2="-0.9525" width="0.254" layer="21"/>
<wire x1="10.0013" y1="2.54" x2="10.0013" y2="5.0801" width="0.254" layer="21"/>
<wire x1="-8.89" y1="-6.35" x2="-8.89" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-8.89" y1="-6.985" x2="-8.255" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-8.255" y1="-6.985" x2="-8.255" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="-8.255" y1="-8.3185" x2="-8.509" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-8.509" y1="-8.5725" x2="-8.89" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-6.985" y1="-8.3185" x2="-6.731" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="-5.969" y1="-8.5725" x2="-6.731" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="8.89" y1="-8.5725" x2="8.89" y2="-6.985" width="0.254" layer="51"/>
<wire x1="8.89" y1="-6.985" x2="8.89" y2="-6.35" width="0.254" layer="51"/>
<wire x1="8.255" y1="-6.985" x2="8.89" y2="-6.985" width="0.254" layer="51"/>
<wire x1="6.985" y1="-8.3185" x2="6.731" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="6.731" y1="-8.5725" x2="5.969" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="8.255" y1="-6.985" x2="8.255" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="8.255" y1="-8.3185" x2="8.509" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="8.509" y1="-8.5725" x2="8.89" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="0.635" y1="-8.3185" x2="0.889" y2="-8.5725" width="0.254" layer="51" curve="90.090301"/>
<wire x1="-10.0013" y1="2.54" x2="-10.0013" y2="-0.9525" width="0.254" layer="51"/>
<wire x1="10.0013" y1="2.54" x2="10.0013" y2="-0.9525" width="0.254" layer="51"/>
<wire x1="-8.255" y1="-6.985" x2="-6.985" y2="-6.985" width="0.254" layer="51"/>
<wire x1="6.985" y1="-6.985" x2="8.255" y2="-6.985" width="0.254" layer="51"/>
<smd name="1" x="-7.62" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="2" x="-5.08" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="3" x="-2.54" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="4" x="0" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="5" x="2.54" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="6" x="5.08" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="7" x="7.62" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<text x="-10.4775" y="-6.35" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="11.7475" y="-6.35" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-7.9375" y1="-10.795" x2="-7.3025" y2="-6.985" layer="51"/>
<rectangle x1="7.3025" y1="-10.795" x2="7.9375" y2="-6.985" layer="51"/>
<hole x="-9.017" y="0.8382" drill="3.4036"/>
<hole x="9.017" y="0.8382" drill="3.4036"/>
<vertex x="-9.525" y="5.08"/>
<vertex x="-9.0487" y="3.3338"/>
<vertex x="-8.5725" y="5.08"/>
</polygon>
</package>
<package name="70543-08">
 vertical, 8 pin</description>
<wire x1="11.43" y1="-2.8575" x2="11.43" y2="2.8575" width="0.254" layer="21"/>
<wire x1="11.43" y1="2.8575" x2="-11.43" y2="2.8575" width="0.254" layer="21"/>
<wire x1="-11.43" y1="2.8575" x2="-11.43" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-11.43" y1="-2.8575" x2="-3.4925" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="3.4925" y1="-2.8575" x2="11.43" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-10.795" y1="2.2225" x2="-10.795" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="10.795" y1="2.2225" x2="10.795" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="-10.795" y1="2.2225" x2="10.795" y2="2.2225" width="0.0508" layer="51"/>
<wire x1="-10.795" y1="-2.2225" x2="-2.8575" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-2.2225" x2="10.795" y2="-2.2225" width="0.0508" layer="51"/>
<pad name="3" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="-8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-12.065" y="-2.54" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="-11.1125" y="3.4925" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-10.4775" y="-1.5875" size="1.016" layer="51" ratio="10">1</text>
<rectangle x1="-9.1281" y1="-0.2381" x2="-8.6519" y2="0.2381" layer="51"/>
<rectangle x1="8.6519" y1="-0.2381" x2="9.1281" y2="0.2381" layer="51"/>
</package>
<package name="70553-08">
 right angle, 8 pin</description>
<wire x1="11.2713" y1="5.8738" x2="4.1275" y2="5.8738" width="0.254" layer="21"/>
<wire x1="4.1275" y1="5.8738" x2="-11.2713" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-11.2713" y1="5.8738" x2="-11.2713" y2="-5.715" width="0.254" layer="21"/>
<wire x1="-11.2713" y1="-5.715" x2="11.2713" y2="-5.715" width="0.254" layer="21"/>
<wire x1="11.2713" y1="-5.715" x2="11.2713" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-9.525" y1="-6.35" x2="-8.255" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-8.255" y1="-6.35" x2="-6.985" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-8.255" y1="-7.6835" x2="-8.001" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-7.239" y1="-7.9375" x2="-8.001" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="6.985" y1="-6.35" x2="8.255" y2="-6.35" width="0.254" layer="51"/>
<wire x1="8.255" y1="-7.6835" x2="8.001" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="8.001" y1="-7.9375" x2="7.239" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="8.255" y1="-6.35" x2="9.525" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-10.4775" y1="-5.715" x2="-10.4775" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-9.525" y1="-6.35" x2="-9.525" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-9.525" y1="-7.6835" x2="-9.779" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-9.779" y1="-7.9375" x2="-10.4775" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="9.525" y1="-6.35" x2="9.525" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="9.525" y1="-7.6835" x2="9.779" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="9.779" y1="-7.9375" x2="10.4775" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="10.4775" y1="-7.9375" x2="10.4775" y2="-6.35" width="0.254" layer="51"/>
<wire x1="10.4775" y1="-6.35" x2="10.4775" y2="-5.715" width="0.254" layer="51"/>
<wire x1="9.525" y1="-6.35" x2="10.4775" y2="-6.35" width="0.254" layer="51"/>
<pad name="2" x="-6.35" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="1" x="-8.89" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="3" x="-3.81" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="4" x="-1.27" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="5" x="1.27" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="6" x="3.81" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="7" x="6.35" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="8" x="8.89" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<text x="-11.7475" y="-5.715" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="13.0175" y="-5.715" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-9.2075" y1="-7.62" x2="-8.5725" y2="-6.35" layer="51"/>
<rectangle x1="8.5725" y1="-7.62" x2="9.2075" y2="-6.35" layer="51"/>
<vertex x="-10.795" y="5.8737"/>
<vertex x="-10.3187" y="3.9688"/>
<vertex x="-9.8425" y="5.8737"/>
</polygon>
</package>
<package name="74099-08">
 vertical SMD, 8 pin</description>
<smd name="5" x="1.27" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="4" x="-1.27" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="3" x="-3.81" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="2" x="-6.35" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="1" x="-8.89" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="6" x="3.81" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="7" x="6.35" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="8" x="8.89" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<text x="-10.4775" y="0.635" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-10.4775" y="-1.905" size="1.016" layer="51" ratio="10">1</text>
</package>
<package name="15-91-08">
 right angle SMD, 8 pin</description>
<wire x1="11.2713" y1="5.08" x2="-11.2713" y2="5.08" width="0.254" layer="21"/>
<wire x1="-11.2713" y1="5.08" x2="-11.2713" y2="2.54" width="0.254" layer="21"/>
<wire x1="-11.2713" y1="-0.9525" x2="-11.2713" y2="-6.35" width="0.254" layer="21"/>
<wire x1="-11.2713" y1="-6.35" x2="11.2713" y2="-6.35" width="0.254" layer="21"/>
<wire x1="11.2713" y1="-6.35" x2="11.2713" y2="-0.9525" width="0.254" layer="21"/>
<wire x1="11.2713" y1="2.54" x2="11.2713" y2="5.08" width="0.254" layer="21"/>
<wire x1="-10.16" y1="-6.35" x2="-10.16" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-10.16" y1="-6.985" x2="-9.525" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-9.525" y1="-6.985" x2="-9.525" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="-9.525" y1="-8.3185" x2="-9.779" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-9.779" y1="-8.5725" x2="-10.16" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-8.255" y1="-8.3185" x2="-8.001" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="-7.239" y1="-8.5725" x2="-8.001" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="10.16" y1="-8.5725" x2="10.16" y2="-6.35" width="0.254" layer="51"/>
<wire x1="9.525" y1="-6.985" x2="10.16" y2="-6.985" width="0.254" layer="51"/>
<wire x1="8.255" y1="-8.3185" x2="8.001" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="8.001" y1="-8.5725" x2="7.239" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="9.525" y1="-6.985" x2="9.525" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="9.525" y1="-8.3185" x2="9.779" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="9.779" y1="-8.5725" x2="10.16" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-11.2713" y1="2.54" x2="-11.2713" y2="-0.9525" width="0.254" layer="51"/>
<wire x1="11.2713" y1="2.54" x2="11.2713" y2="-0.9525" width="0.254" layer="51"/>
<wire x1="-9.525" y1="-6.985" x2="-8.255" y2="-6.985" width="0.254" layer="51"/>
<wire x1="8.255" y1="-6.985" x2="9.525" y2="-6.985" width="0.254" layer="51"/>
<smd name="1" x="-8.89" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="2" x="-6.35" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="3" x="-3.81" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="4" x="-1.27" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="5" x="1.27" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="6" x="3.81" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="7" x="6.35" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="8" x="8.89" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<text x="-11.7475" y="-6.35" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="13.0175" y="-6.35" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-9.2075" y1="-10.795" x2="-8.5725" y2="-6.985" layer="51"/>
<rectangle x1="8.5725" y1="-10.795" x2="9.2075" y2="-6.985" layer="51"/>
<hole x="-10.287" y="0.8382" drill="3.4036"/>
<hole x="10.287" y="0.8382" drill="3.4036"/>
<vertex x="-10.795" y="5.08"/>
<vertex x="-10.3187" y="3.3339"/>
<vertex x="-9.8425" y="5.08"/>
</polygon>
</package>
<package name="70543-09">
<description>&lt;b&gt;C-Grid SL Connector&lt;/b&gt;&lt;p&gt;
 vertical, 9 pin</description>
<wire x1="12.7" y1="-2.8575" x2="12.7" y2="2.8575" width="0.254" layer="21"/>
<wire x1="12.7" y1="2.8575" x2="-12.7" y2="2.8575" width="0.254" layer="21"/>
<wire x1="-12.7" y1="2.8575" x2="-12.7" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-12.7" y1="-2.8575" x2="-3.4925" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-3.4925" y1="-2.8575" x2="-3.4925" y2="-3.81" width="0.254" layer="21"/>
<wire x1="-3.4925" y1="-3.81" x2="3.4925" y2="-3.81" width="0.254" layer="21"/>
<wire x1="3.4925" y1="-3.81" x2="3.4925" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="3.4925" y1="-2.8575" x2="12.7" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-12.065" y1="2.2225" x2="-12.065" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="12.065" y1="2.2225" x2="12.065" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="-12.065" y1="2.2225" x2="12.065" y2="2.2225" width="0.0508" layer="51"/>
<wire x1="-12.065" y1="-2.2225" x2="-2.8575" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="-2.8575" y1="-2.2225" x2="2.8575" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-2.2225" x2="12.065" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-3.175" x2="-2.8575" y2="-3.175" width="0.0508" layer="51"/>
<wire x1="-2.8575" y1="-2.2225" x2="-2.8575" y2="-3.175" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-2.2225" x2="2.8575" y2="-3.175" width="0.0508" layer="51"/>
<pad name="3" x="-5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="-10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-13.335" y="-2.54" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="-12.3825" y="3.4925" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-11.7475" y="-1.5875" size="1.016" layer="51" ratio="10">1</text>
<rectangle x1="-10.3981" y1="-0.2381" x2="-9.9219" y2="0.2381" layer="51"/>
<rectangle x1="9.9219" y1="-0.2381" x2="10.3981" y2="0.2381" layer="51"/>
</package>
<package name="70553-09">
 right angle, 9 pin</description>
<wire x1="12.5413" y1="5.8738" x2="4.1275" y2="5.8738" width="0.254" layer="21"/>
<wire x1="4.1275" y1="5.8738" x2="-12.5413" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-12.5413" y1="5.8738" x2="-12.5413" y2="-5.715" width="0.254" layer="21"/>
<wire x1="-12.5413" y1="-5.715" x2="12.5413" y2="-5.715" width="0.254" layer="21"/>
<wire x1="12.5413" y1="-5.715" x2="12.5413" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-1.27" y1="2.54" x2="-1.27" y2="-3.175" width="0.254" layer="21"/>
<wire x1="-1.27" y1="-3.175" x2="1.27" y2="-3.175" width="0.254" layer="21"/>
<wire x1="1.27" y1="-3.175" x2="1.27" y2="2.54" width="0.254" layer="21"/>
<wire x1="-3.175" y1="2.54" x2="-1.27" y2="2.54" width="0.254" layer="21"/>
<wire x1="1.27" y1="2.54" x2="3.175" y2="2.54" width="0.254" layer="21"/>
<wire x1="-3.175" y1="2.54" x2="-3.175" y2="3.175" width="0.254" layer="21"/>
<wire x1="-3.175" y1="3.175" x2="-1.905" y2="4.445" width="0.254" layer="21" curve="-90"/>
<wire x1="-1.905" y1="4.445" x2="1.905" y2="4.445" width="0.254" layer="21"/>
<wire x1="1.905" y1="4.445" x2="3.175" y2="3.175" width="0.254" layer="21" curve="-90"/>
<wire x1="3.175" y1="3.175" x2="3.175" y2="2.54" width="0.254" layer="21"/>
<wire x1="-10.795" y1="-6.35" x2="-9.525" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-9.525" y1="-6.35" x2="-8.255" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-9.525" y1="-7.6835" x2="-9.271" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-8.509" y1="-7.9375" x2="-9.271" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-1.905" y1="-6.35" x2="-1.905" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-0.635" y1="-6.35" x2="-0.635" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="0.635" y1="-6.35" x2="0.635" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="1.905" y1="-6.35" x2="1.905" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="8.255" y1="-6.35" x2="9.525" y2="-6.35" width="0.254" layer="51"/>
<wire x1="9.525" y1="-7.6835" x2="9.271" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="9.271" y1="-7.9375" x2="8.509" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="9.525" y1="-6.35" x2="10.795" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-11.7475" y1="-5.715" x2="-11.7475" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-10.795" y1="-6.35" x2="-10.795" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-10.795" y1="-7.6835" x2="-11.049" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-11.049" y1="-7.9375" x2="-11.7475" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="10.795" y1="-6.35" x2="10.795" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="10.795" y1="-7.6835" x2="11.049" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="11.049" y1="-7.9375" x2="11.7475" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="11.7475" y1="-7.9375" x2="11.7475" y2="-6.35" width="0.254" layer="51"/>
<wire x1="11.7475" y1="-6.35" x2="11.7475" y2="-5.715" width="0.254" layer="51"/>
<wire x1="10.795" y1="-6.35" x2="11.7475" y2="-6.35" width="0.254" layer="51"/>
<pad name="2" x="-7.62" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="1" x="-10.16" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="3" x="-5.08" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="4" x="-2.54" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="5" x="0" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="6" x="2.54" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="7" x="5.08" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="8" x="7.62" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="9" x="10.16" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<text x="-13.0175" y="-5.715" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="14.2875" y="-5.715" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-10.4775" y1="-7.62" x2="-9.8425" y2="-6.35" layer="51"/>
<rectangle x1="9.8425" y1="-7.62" x2="10.4775" y2="-6.35" layer="51"/>
<polygon width="0.0508" layer="21">
<vertex x="-12.065" y="5.8737"/>
<vertex x="-11.5887" y="3.9688"/>
<vertex x="-11.1125" y="5.8737"/>
</polygon>
</package>
<package name="74099-09">
 vertical SMD, 9 pin</description>
<smd name="5" x="0" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="4" x="-2.54" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="3" x="-5.08" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="2" x="-7.62" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="1" x="-10.16" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="6" x="2.54" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="7" x="5.08" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="8" x="7.62" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="9" x="10.16" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<text x="-11.7475" y="0.635" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-11.7475" y="-1.905" size="1.016" layer="51" ratio="10">1</text>
</package>
<package name="15-91-09">
 right angle SMD, 9 pin</description>
<wire x1="12.5413" y1="5.0801" x2="-12.5413" y2="5.0801" width="0.254" layer="21"/>
<wire x1="-12.5413" y1="5.0801" x2="-12.5413" y2="2.54" width="0.254" layer="21"/>
<wire x1="-12.5413" y1="-0.9525" x2="-12.5413" y2="-6.35" width="0.254" layer="21"/>
<wire x1="-12.5413" y1="-6.35" x2="12.5413" y2="-6.35" width="0.254" layer="21"/>
<wire x1="12.5413" y1="-6.35" x2="12.5413" y2="-0.9525" width="0.254" layer="21"/>
<wire x1="12.5413" y1="2.54" x2="12.5413" y2="5.0801" width="0.254" layer="21"/>
<wire x1="-1.27" y1="1.905" x2="-1.27" y2="-3.81" width="0.254" layer="51"/>
<wire x1="-1.27" y1="-3.81" x2="1.27" y2="-3.81" width="0.254" layer="51"/>
<wire x1="1.27" y1="-3.81" x2="1.27" y2="1.905" width="0.254" layer="51"/>
<wire x1="-3.175" y1="1.905" x2="-1.27" y2="1.905" width="0.254" layer="51"/>
<wire x1="1.27" y1="1.905" x2="3.175" y2="1.905" width="0.254" layer="51"/>
<wire x1="-3.175" y1="1.905" x2="-3.175" y2="2.54" width="0.254" layer="51"/>
<wire x1="-3.175" y1="2.54" x2="-1.905" y2="3.81" width="0.254" layer="51" curve="-90"/>
<wire x1="-1.905" y1="3.81" x2="1.905" y2="3.81" width="0.254" layer="51"/>
<wire x1="1.905" y1="3.81" x2="3.175" y2="2.54" width="0.254" layer="51" curve="-90"/>
<wire x1="3.175" y1="2.54" x2="3.175" y2="1.905" width="0.254" layer="51"/>
<wire x1="-11.43" y1="-6.35" x2="-11.43" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-11.43" y1="-6.985" x2="-10.795" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-10.795" y1="-6.985" x2="-10.795" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="-10.795" y1="-8.3185" x2="-11.049" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-11.049" y1="-8.5725" x2="-11.43" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-9.525" y1="-8.3185" x2="-9.271" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="-8.509" y1="-8.5725" x2="-9.271" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-1.905" y1="-6.985" x2="-0.635" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-1.905" y1="-6.985" x2="-1.905" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="0.635" y1="-6.985" x2="1.905" y2="-6.985" width="0.254" layer="51"/>
<wire x1="0.635" y1="-6.985" x2="0.635" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="1.905" y1="-6.985" x2="1.905" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="11.43" y1="-8.5725" x2="11.43" y2="-6.35" width="0.254" layer="51"/>
<wire x1="10.795" y1="-6.985" x2="11.43" y2="-6.985" width="0.254" layer="51"/>
<wire x1="9.525" y1="-8.3185" x2="9.271" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="9.271" y1="-8.5725" x2="8.509" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="10.795" y1="-6.985" x2="10.795" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="10.795" y1="-8.3185" x2="11.049" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="11.049" y1="-8.5725" x2="11.43" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-12.5413" y1="2.54" x2="-12.5413" y2="-0.9525" width="0.254" layer="51"/>
<wire x1="12.5413" y1="2.54" x2="12.5413" y2="-0.9525" width="0.254" layer="51"/>
<wire x1="-10.795" y1="-6.985" x2="-9.525" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-0.635" y1="-6.985" x2="0.635" y2="-6.985" width="0.254" layer="51"/>
<wire x1="9.525" y1="-6.985" x2="10.795" y2="-6.985" width="0.254" layer="51"/>
<smd name="1" x="-10.16" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="2" x="-7.62" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="3" x="-5.08" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="4" x="-2.54" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="5" x="0" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="6" x="2.54" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="7" x="5.08" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="8" x="7.62" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="9" x="10.16" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<text x="-13.0175" y="-6.35" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="14.2875" y="-6.35" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-10.4775" y1="-10.795" x2="-9.8425" y2="-6.985" layer="51"/>
<rectangle x1="9.8425" y1="-10.795" x2="10.4775" y2="-6.985" layer="51"/>
<hole x="-11.557" y="0.8382" drill="3.4036"/>
<hole x="11.557" y="0.8382" drill="3.4036"/>
<polygon width="0.2032" layer="21">
<vertex x="-12.065" y="5.08"/>
<vertex x="-11.5887" y="3.1751"/>
<vertex x="-11.1125" y="5.08"/>
</polygon>
</package>
<package name="70543-10">
 vertical, 10 pin</description>
<wire x1="13.97" y1="-2.8575" x2="13.97" y2="2.8575" width="0.254" layer="21"/>
<wire x1="13.97" y1="2.8575" x2="-13.97" y2="2.8575" width="0.254" layer="21"/>
<wire x1="-13.97" y1="2.8575" x2="-13.97" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-13.97" y1="-2.8575" x2="-3.4925" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="3.4925" y1="-2.8575" x2="13.97" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-13.335" y1="2.2225" x2="-13.335" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="13.335" y1="2.2225" x2="13.335" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="-13.335" y1="2.2225" x2="13.335" y2="2.2225" width="0.0508" layer="51"/>
<wire x1="-13.335" y1="-2.2225" x2="-2.8575" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-2.2225" x2="13.335" y2="-2.2225" width="0.0508" layer="51"/>
<pad name="3" x="-6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="-11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-14.605" y="-2.54" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="-13.6525" y="3.4925" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-13.0175" y="-1.5875" size="1.016" layer="51" ratio="10">1</text>
<rectangle x1="-11.6681" y1="-0.2381" x2="-11.1919" y2="0.2381" layer="51"/>
<rectangle x1="1.0319" y1="-0.2381" x2="1.5081" y2="0.2381" layer="51"/>
<rectangle x1="-1.5081" y1="-0.2381" x2="-1.0319" y2="0.2381" layer="51"/>
<rectangle x1="11.1919" y1="-0.2381" x2="11.6681" y2="0.2381" layer="51"/>
</package>
<package name="70553-10">
 right angle, 10 pin</description>
<wire x1="13.8113" y1="5.8738" x2="4.1275" y2="5.8738" width="0.254" layer="21"/>
<wire x1="4.1275" y1="5.8738" x2="-13.8113" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-13.8113" y1="5.8738" x2="-13.8113" y2="-5.715" width="0.254" layer="21"/>
<wire x1="-13.8113" y1="-5.715" x2="13.8113" y2="-5.715" width="0.254" layer="21"/>
<wire x1="13.8113" y1="-5.715" x2="13.8113" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-4.1275" y1="5.8737" x2="-4.1275" y2="2.54" width="0.254" layer="21"/>
<wire x1="-4.1275" y1="2.54" x2="-3.175" y2="2.54" width="0.254" layer="21"/>
<wire x1="3.175" y1="2.54" x2="4.1275" y2="2.54" width="0.254" layer="21"/>
<wire x1="4.1275" y1="2.54" x2="4.1275" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-12.065" y1="-6.35" x2="-10.795" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-10.795" y1="-6.35" x2="-9.525" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-10.795" y1="-7.6835" x2="-10.541" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-9.779" y1="-7.9375" x2="-10.541" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-3.175" y1="-6.35" x2="-3.175" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-1.905" y1="-7.6835" x2="-2.159" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-1.905" y1="-6.35" x2="-0.635" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-0.635" y1="-6.35" x2="0.635" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-0.635" y1="-7.6835" x2="-0.381" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="0.635" y1="-7.6835" x2="0.381" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="0.381" y1="-7.9375" x2="-0.381" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="0.635" y1="-6.35" x2="1.905" y2="-6.35" width="0.127" layer="51"/>
<wire x1="1.905" y1="-7.6835" x2="2.159" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="3.175" y1="-6.35" x2="3.175" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="9.525" y1="-6.35" x2="10.795" y2="-6.35" width="0.254" layer="51"/>
<wire x1="10.795" y1="-7.6835" x2="10.541" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="10.541" y1="-7.9375" x2="9.779" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="10.795" y1="-6.35" x2="12.065" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-13.0175" y1="-5.715" x2="-13.0175" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-12.065" y1="-6.35" x2="-12.065" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-12.065" y1="-7.6835" x2="-12.319" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-12.319" y1="-7.9375" x2="-13.0175" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="12.065" y1="-6.35" x2="12.065" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="12.065" y1="-7.6835" x2="12.319" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="12.319" y1="-7.9375" x2="13.0175" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="13.0175" y1="-7.9375" x2="13.0175" y2="-6.35" width="0.254" layer="51"/>
<wire x1="13.0175" y1="-6.35" x2="13.0175" y2="-5.715" width="0.254" layer="51"/>
<wire x1="12.065" y1="-6.35" x2="13.0175" y2="-6.35" width="0.254" layer="51"/>
<pad name="2" x="-8.89" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="1" x="-11.43" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="3" x="-6.35" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="4" x="-3.81" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="5" x="-1.27" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="6" x="1.27" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="7" x="3.81" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="8" x="6.35" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="9" x="8.89" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="10" x="11.43" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<text x="-14.2875" y="-5.715" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="15.5575" y="-5.715" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-11.7475" y1="-7.62" x2="-11.1125" y2="-6.35" layer="51"/>
<rectangle x1="-1.5875" y1="-7.62" x2="-0.9525" y2="-6.35" layer="51"/>
<rectangle x1="0.9525" y1="-7.62" x2="1.5875" y2="-6.35" layer="51"/>
<rectangle x1="11.1125" y1="-7.62" x2="11.7475" y2="-6.35" layer="51"/>
<vertex x="-13.3351" y="5.8738"/>
<vertex x="-12.8588" y="3.9689"/>
<vertex x="-12.3826" y="5.8738"/>
</polygon>
</package>
<package name="74099-10">
 vertical SMD, 10 pin</description>
<smd name="5" x="-1.27" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="4" x="-3.81" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="3" x="-6.35" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="2" x="-8.89" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="1" x="-11.43" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="6" x="1.27" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="7" x="3.81" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="8" x="6.35" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="9" x="8.89" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="10" x="11.43" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<text x="-13.0175" y="0.635" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-13.0175" y="-1.905" size="1.016" layer="51" ratio="10">1</text>
<rectangle x1="-4.0481" y1="-0.2381" x2="-3.5719" y2="0.2381" layer="51"/>
<rectangle x1="3.5719" y1="-0.2381" x2="4.0481" y2="0.2381" layer="51"/>
</package>
<package name="15-91-10">
 right angle SMD, 10 pin</description>
<wire x1="13.8113" y1="5.0801" x2="-13.8113" y2="5.0801" width="0.254" layer="21"/>
<wire x1="-13.8113" y1="5.0801" x2="-13.8113" y2="2.54" width="0.254" layer="21"/>
<wire x1="-13.8113" y1="-0.9525" x2="-13.8113" y2="-6.35" width="0.254" layer="21"/>
<wire x1="-13.8113" y1="-6.35" x2="13.8113" y2="-6.35" width="0.254" layer="21"/>
<wire x1="13.8113" y1="-6.35" x2="13.8113" y2="-0.9525" width="0.254" layer="21"/>
<wire x1="13.8113" y1="2.54" x2="13.8113" y2="5.0801" width="0.254" layer="21"/>
<wire x1="-4.1275" y1="1.905" x2="-3.175" y2="1.905" width="0.254" layer="51"/>
<wire x1="3.175" y1="1.905" x2="4.1275" y2="1.905" width="0.254" layer="51"/>
<wire x1="-12.7" y1="-6.35" x2="-12.7" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-12.7" y1="-6.985" x2="-12.065" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-12.065" y1="-6.985" x2="-12.065" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="-12.065" y1="-8.3185" x2="-12.319" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-12.319" y1="-8.5725" x2="-12.7" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-10.795" y1="-8.3185" x2="-10.541" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="-9.779" y1="-8.5725" x2="-10.541" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-3.175" y1="-6.985" x2="-3.175" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="-3.175" y1="-6.985" x2="-1.905" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-1.905" y1="-8.3185" x2="-2.159" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-0.635" y1="-6.985" x2="-0.635" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="0.635" y1="-8.3185" x2="0.381" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="0.381" y1="-8.5725" x2="-0.381" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="1.905" y1="-8.3185" x2="2.159" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="1.905" y1="-6.985" x2="3.175" y2="-6.985" width="0.254" layer="51"/>
<wire x1="3.175" y1="-6.985" x2="3.175" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="12.7" y1="-8.5725" x2="12.7" y2="-6.35" width="0.254" layer="51"/>
<wire x1="12.065" y1="-6.985" x2="12.7" y2="-6.985" width="0.254" layer="51"/>
<wire x1="10.795" y1="-8.3185" x2="10.541" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="10.541" y1="-8.5725" x2="9.779" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="12.065" y1="-6.985" x2="12.065" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="12.065" y1="-8.3185" x2="12.319" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="12.319" y1="-8.5725" x2="12.7" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-13.8113" y1="2.54" x2="-13.8113" y2="-0.9525" width="0.254" layer="51"/>
<wire x1="13.8113" y1="2.54" x2="13.8113" y2="-0.9525" width="0.254" layer="51"/>
<wire x1="-12.065" y1="-6.985" x2="-10.795" y2="-6.985" width="0.254" layer="51"/>
<wire x1="10.795" y1="-6.985" x2="12.065" y2="-6.985" width="0.254" layer="51"/>
<smd name="1" x="-11.43" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="2" x="-8.89" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="3" x="-6.35" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="4" x="-3.81" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="5" x="-1.27" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="6" x="1.27" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="7" x="3.81" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="8" x="6.35" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="9" x="8.89" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="10" x="11.43" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<text x="-14.2875" y="-6.35" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="15.5575" y="-6.35" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-11.7475" y1="-10.795" x2="-11.1125" y2="-6.985" layer="51"/>
<rectangle x1="-1.5875" y1="-10.795" x2="-0.9525" y2="-6.985" layer="51"/>
<rectangle x1="0.9525" y1="-10.795" x2="1.5875" y2="-6.985" layer="51"/>
<rectangle x1="11.1125" y1="-10.795" x2="11.7475" y2="-6.985" layer="51"/>
<hole x="-12.827" y="0.8382" drill="3.4036"/>
<hole x="12.827" y="0.8382" drill="3.4036"/>
<vertex x="-13.335" y="5.08"/>
<vertex x="-12.8587" y="3.1751"/>
<vertex x="-12.3825" y="5.08"/>
</polygon>
</package>
<package name="70543-11">
 vertical, 11 pin</description>
<wire x1="15.24" y1="-2.8575" x2="15.24" y2="2.8575" width="0.254" layer="21"/>
<wire x1="15.24" y1="2.8575" x2="-15.24" y2="2.8575" width="0.254" layer="21"/>
<wire x1="-15.24" y1="2.8575" x2="-15.24" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-15.24" y1="-2.8575" x2="-3.4925" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="3.4925" y1="-2.8575" x2="15.24" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-14.605" y1="2.2225" x2="-14.605" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="14.605" y1="2.2225" x2="14.605" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="-14.605" y1="2.2225" x2="14.605" y2="2.2225" width="0.0508" layer="51"/>
<wire x1="-14.605" y1="-2.2225" x2="-2.8575" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-2.2225" x2="14.605" y2="-2.2225" width="0.0508" layer="51"/>
<pad name="3" x="-7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="-12.7" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="12.7" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-15.875" y="-2.54" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="-14.9225" y="3.4925" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-14.2875" y="-1.5875" size="1.016" layer="51" ratio="10">1</text>
<rectangle x1="-12.9381" y1="-0.2381" x2="-12.4619" y2="0.2381" layer="51"/>
<rectangle x1="-0.2381" y1="-0.2381" x2="0.2381" y2="0.2381" layer="51"/>
<rectangle x1="-2.7781" y1="-0.2381" x2="-2.3019" y2="0.2381" layer="51"/>
<rectangle x1="2.3019" y1="-0.2381" x2="2.7781" y2="0.2381" layer="51"/>
<rectangle x1="12.4619" y1="-0.2381" x2="12.9381" y2="0.2381" layer="51"/>
</package>
<package name="70553-11">
 right angle, 11 pin</description>
<wire x1="15.0813" y1="5.8738" x2="4.1275" y2="5.8738" width="0.254" layer="21"/>
<wire x1="4.1275" y1="5.8738" x2="-15.0813" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-15.0813" y1="5.8738" x2="-15.0813" y2="-5.715" width="0.254" layer="21"/>
<wire x1="-15.0813" y1="-5.715" x2="15.0813" y2="-5.715" width="0.254" layer="21"/>
<wire x1="15.0813" y1="-5.715" x2="15.0813" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-13.335" y1="-6.35" x2="-12.065" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-12.065" y1="-6.35" x2="-10.795" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-12.065" y1="-7.6835" x2="-11.811" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-11.049" y1="-7.9375" x2="-11.811" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-5.715" y1="-6.35" x2="-4.445" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-4.445" y1="-6.35" x2="-3.175" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-4.445" y1="-6.35" x2="-4.445" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-4.445" y1="-7.6835" x2="-4.191" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-3.175" y1="-7.6835" x2="-3.429" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-3.429" y1="-7.9375" x2="-4.191" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-3.175" y1="-6.35" x2="-1.905" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-1.905" y1="-6.35" x2="-0.635" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-1.905" y1="-7.6835" x2="-1.651" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-0.635" y1="-7.6835" x2="-0.889" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-0.889" y1="-7.9375" x2="-1.651" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-0.635" y1="-6.35" x2="0.635" y2="-6.35" width="0.127" layer="51"/>
<wire x1="0.635" y1="-6.35" x2="1.905" y2="-6.35" width="0.254" layer="51"/>
<wire x1="0.635" y1="-7.6835" x2="0.889" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="1.905" y1="-7.6835" x2="1.651" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="1.651" y1="-7.9375" x2="0.889" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="1.905" y1="-6.35" x2="3.175" y2="-6.35" width="0.127" layer="51"/>
<wire x1="3.175" y1="-6.35" x2="4.445" y2="-6.35" width="0.254" layer="51"/>
<wire x1="3.175" y1="-7.6835" x2="3.429" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="4.445" y1="-6.35" x2="4.445" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="4.445" y1="-7.6835" x2="4.191" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="4.191" y1="-7.9375" x2="3.429" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="4.445" y1="-6.35" x2="5.715" y2="-6.35" width="0.127" layer="51"/>
<wire x1="5.715" y1="-6.35" x2="5.715" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="5.715" y1="-7.6835" x2="5.969" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="10.795" y1="-6.35" x2="12.065" y2="-6.35" width="0.254" layer="51"/>
<wire x1="12.065" y1="-7.6835" x2="11.811" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="11.811" y1="-7.9375" x2="11.049" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="12.065" y1="-6.35" x2="13.335" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-14.2875" y1="-5.715" x2="-14.2875" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-13.335" y1="-6.35" x2="-13.335" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-13.335" y1="-7.6835" x2="-13.589" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-13.589" y1="-7.9375" x2="-14.2875" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="13.335" y1="-6.35" x2="13.335" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="13.335" y1="-7.6835" x2="13.589" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="13.589" y1="-7.9375" x2="14.2875" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="14.2875" y1="-7.9375" x2="14.2875" y2="-6.35" width="0.254" layer="51"/>
<wire x1="14.2875" y1="-6.35" x2="14.2875" y2="-5.715" width="0.254" layer="51"/>
<wire x1="13.335" y1="-6.35" x2="14.2875" y2="-6.35" width="0.254" layer="51"/>
<pad name="2" x="-10.16" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="1" x="-12.7" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="3" x="-7.62" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="4" x="-5.08" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="5" x="-2.54" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="6" x="0" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="7" x="2.54" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="8" x="5.08" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="9" x="7.62" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="10" x="10.16" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="11" x="12.7" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<text x="-15.5575" y="-5.715" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="16.8275" y="-5.715" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-13.0175" y1="-7.62" x2="-12.3825" y2="-6.35" layer="51"/>
<rectangle x1="-5.3975" y1="-7.62" x2="-4.7625" y2="-6.35" layer="51"/>
<rectangle x1="-2.8575" y1="-7.62" x2="-2.2225" y2="-6.35" layer="51"/>
<rectangle x1="-0.3175" y1="-7.62" x2="0.3175" y2="-6.35" layer="51"/>
<rectangle x1="2.2225" y1="-7.62" x2="2.8575" y2="-6.35" layer="51"/>
<rectangle x1="4.7625" y1="-7.62" x2="5.3975" y2="-6.35" layer="51"/>
<rectangle x1="12.3825" y1="-7.62" x2="13.0175" y2="-6.35" layer="51"/>
<vertex x="-14.605" y="5.8737"/>
<vertex x="-14.1287" y="3.9688"/>
<vertex x="-13.6525" y="5.8737"/>
</polygon>
</package>
<package name="74099-11">
 vertical SMD, 11 pin</description>
<smd name="5" x="-2.54" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="4" x="-5.08" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="3" x="-7.62" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="2" x="-10.16" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="1" x="-12.7" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="6" x="0" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="7" x="2.54" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="8" x="5.08" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="9" x="7.62" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="10" x="10.16" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="11" x="12.7" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<text x="-14.2875" y="0.635" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-14.2875" y="-1.905" size="1.016" layer="51" ratio="10">1</text>
<rectangle x1="-5.3181" y1="-0.2381" x2="-4.8419" y2="0.2381" layer="51"/>
<rectangle x1="4.8419" y1="-0.2381" x2="5.3181" y2="0.2381" layer="51"/>
</package>
<package name="15-91-11">
 right angle SMD, 11 pin</description>
<wire x1="15.0813" y1="5.08" x2="-15.0813" y2="5.08" width="0.254" layer="21"/>
<wire x1="-15.0813" y1="5.08" x2="-15.0813" y2="2.54" width="0.254" layer="21"/>
<wire x1="-15.0813" y1="-0.9525" x2="-15.0813" y2="-6.35" width="0.254" layer="21"/>
<wire x1="-15.0813" y1="-6.35" x2="15.0813" y2="-6.35" width="0.254" layer="21"/>
<wire x1="15.0813" y1="-6.35" x2="15.0813" y2="-0.9525" width="0.254" layer="21"/>
<wire x1="15.0813" y1="2.54" x2="15.0813" y2="5.08" width="0.254" layer="21"/>
<wire x1="-4.1275" y1="5.0799" x2="-4.1275" y2="1.905" width="0.254" layer="51"/>
<wire x1="4.1275" y1="1.905" x2="4.1275" y2="5.08" width="0.254" layer="51"/>
<wire x1="-13.97" y1="-6.35" x2="-13.97" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-13.97" y1="-6.985" x2="-13.335" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-13.335" y1="-6.985" x2="-13.335" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="-13.335" y1="-8.3185" x2="-13.589" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-13.589" y1="-8.5725" x2="-13.97" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-12.065" y1="-8.3185" x2="-11.811" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="-11.049" y1="-8.5725" x2="-11.811" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="13.97" y1="-8.5725" x2="13.97" y2="-6.35" width="0.254" layer="51"/>
<wire x1="13.335" y1="-6.985" x2="13.97" y2="-6.985" width="0.254" layer="51"/>
<wire x1="12.065" y1="-8.3185" x2="11.811" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="11.811" y1="-8.5725" x2="11.049" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="13.335" y1="-6.985" x2="13.335" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="13.335" y1="-8.3185" x2="13.589" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="13.589" y1="-8.5725" x2="13.97" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-4.445" y1="-6.985" x2="-3.175" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-5.715" y1="-6.985" x2="-5.715" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="-5.715" y1="-8.3185" x2="-5.969" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-4.445" y1="-6.985" x2="-4.445" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="-4.445" y1="-8.3185" x2="-4.191" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="-3.175" y1="-8.3185" x2="-3.429" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-3.429" y1="-8.5725" x2="-4.191" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-1.905" y1="-8.3185" x2="-1.651" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="-0.635" y1="-8.3185" x2="-0.889" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-0.889" y1="-8.5725" x2="-1.651" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="0.635" y1="-8.3185" x2="0.889" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="1.905" y1="-8.3185" x2="1.651" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="1.651" y1="-8.5725" x2="0.889" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="3.175" y1="-8.3185" x2="3.429" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="3.175" y1="-6.985" x2="4.445" y2="-6.985" width="0.254" layer="51"/>
<wire x1="4.445" y1="-6.985" x2="4.445" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="4.445" y1="-8.3185" x2="4.191" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="4.191" y1="-8.5725" x2="3.429" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="5.715" y1="-6.985" x2="5.715" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="5.715" y1="-8.3185" x2="5.969" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="-15.0813" y1="2.54" x2="-15.0813" y2="-0.9525" width="0.254" layer="51"/>
<wire x1="15.0813" y1="2.54" x2="15.0813" y2="-0.9525" width="0.254" layer="51"/>
<wire x1="-13.335" y1="-6.985" x2="-12.065" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-5.715" y1="-6.985" x2="-4.445" y2="-6.985" width="0.254" layer="51"/>
<wire x1="4.445" y1="-6.985" x2="5.715" y2="-6.985" width="0.254" layer="51"/>
<wire x1="12.065" y1="-6.985" x2="13.335" y2="-6.985" width="0.254" layer="51"/>
<smd name="1" x="-12.7" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="2" x="-10.16" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="3" x="-7.62" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="4" x="-5.08" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="5" x="-2.54" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="6" x="0" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="7" x="2.54" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="8" x="5.08" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="9" x="7.62" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="10" x="10.16" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="11" x="12.7" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<text x="-15.5575" y="-6.35" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="16.8275" y="-6.35" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-13.0175" y1="-10.795" x2="-12.3825" y2="-6.985" layer="51"/>
<rectangle x1="12.3825" y1="-10.795" x2="13.0175" y2="-6.985" layer="51"/>
<rectangle x1="-5.3975" y1="-10.795" x2="-4.7625" y2="-6.985" layer="51"/>
<rectangle x1="-2.8575" y1="-10.795" x2="-2.2225" y2="-6.985" layer="51"/>
<rectangle x1="-0.3175" y1="-10.795" x2="0.3175" y2="-6.985" layer="51"/>
<rectangle x1="2.2225" y1="-10.795" x2="2.8575" y2="-6.985" layer="51"/>
<rectangle x1="4.7625" y1="-10.795" x2="5.3975" y2="-6.985" layer="51"/>
<hole x="-14.097" y="0.8382" drill="3.4036"/>
<hole x="14.097" y="0.8382" drill="3.4036"/>
<vertex x="-14.605" y="5.08"/>
<vertex x="-14.1287" y="3.1751"/>
<vertex x="-13.6525" y="5.08"/>
</polygon>
</package>
<package name="70543-12">
 vertical, 12 pin</description>
<wire x1="16.51" y1="-2.8575" x2="16.51" y2="2.8575" width="0.254" layer="21"/>
<wire x1="16.51" y1="2.8575" x2="-16.51" y2="2.8575" width="0.254" layer="21"/>
<wire x1="-16.51" y1="2.8575" x2="-16.51" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-16.51" y1="-2.8575" x2="-3.4925" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="3.4925" y1="-2.8575" x2="16.51" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-15.875" y1="2.2225" x2="-15.875" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="15.875" y1="2.2225" x2="15.875" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="-15.875" y1="2.2225" x2="15.875" y2="2.2225" width="0.0508" layer="51"/>
<wire x1="-15.875" y1="-2.2225" x2="-2.8575" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-2.2225" x2="15.875" y2="-2.2225" width="0.0508" layer="51"/>
<pad name="3" x="-8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="-13.97" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="13.97" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-17.145" y="-2.54" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="-16.1925" y="3.4925" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-15.5575" y="-1.5875" size="1.016" layer="51" ratio="10">1</text>
<rectangle x1="-14.2081" y1="-0.2381" x2="-13.7319" y2="0.2381" layer="51"/>
<rectangle x1="-6.5881" y1="-0.2381" x2="-6.1119" y2="0.2381" layer="51"/>
<rectangle x1="6.1119" y1="-0.2381" x2="6.5881" y2="0.2381" layer="51"/>
<rectangle x1="13.7319" y1="-0.2381" x2="14.2081" y2="0.2381" layer="51"/>
</package>
<package name="70553-12">
 right angle, 12 pin</description>
<wire x1="16.3513" y1="5.8738" x2="4.1275" y2="5.8738" width="0.254" layer="21"/>
<wire x1="4.1275" y1="5.8738" x2="-16.3513" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-16.3513" y1="5.8738" x2="-16.3513" y2="-5.715" width="0.254" layer="21"/>
<wire x1="-16.3513" y1="-5.715" x2="16.3513" y2="-5.715" width="0.254" layer="21"/>
<wire x1="16.3513" y1="-5.715" x2="16.3513" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-14.605" y1="-6.35" x2="-13.335" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-13.335" y1="-6.35" x2="-12.065" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-13.335" y1="-7.6835" x2="-13.081" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-12.319" y1="-7.9375" x2="-13.081" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-6.985" y1="-6.35" x2="-6.985" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-6.985" y1="-7.6835" x2="-7.239" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-6.985" y1="-6.35" x2="-5.715" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-5.715" y1="-6.35" x2="-4.445" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-5.715" y1="-6.35" x2="-5.715" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-5.715" y1="-7.6835" x2="-5.461" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-4.445" y1="-7.6835" x2="-4.699" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-4.699" y1="-7.9375" x2="-5.461" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-4.445" y1="-6.35" x2="-3.175" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-3.175" y1="-6.35" x2="-1.905" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-3.175" y1="-7.6835" x2="-2.921" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-2.159" y1="-7.9375" x2="-2.921" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="1.905" y1="-6.35" x2="3.175" y2="-6.35" width="0.254" layer="51"/>
<wire x1="3.175" y1="-7.6835" x2="2.921" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="2.921" y1="-7.9375" x2="2.159" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="3.175" y1="-6.35" x2="4.445" y2="-6.35" width="0.127" layer="51"/>
<wire x1="4.445" y1="-6.35" x2="5.715" y2="-6.35" width="0.254" layer="51"/>
<wire x1="4.445" y1="-7.6835" x2="4.699" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="5.715" y1="-7.6835" x2="5.461" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="5.461" y1="-7.9375" x2="4.699" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="5.715" y1="-6.35" x2="6.985" y2="-6.35" width="0.127" layer="51"/>
<wire x1="6.985" y1="-6.35" x2="6.985" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="6.985" y1="-7.6835" x2="7.239" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="12.065" y1="-6.35" x2="13.335" y2="-6.35" width="0.254" layer="51"/>
<wire x1="13.335" y1="-7.6835" x2="13.081" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="13.081" y1="-7.9375" x2="12.319" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="13.335" y1="-6.35" x2="14.605" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-15.5575" y1="-5.715" x2="-15.5575" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-14.605" y1="-6.35" x2="-14.605" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-14.605" y1="-7.6835" x2="-14.859" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-14.859" y1="-7.9375" x2="-15.5575" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="14.605" y1="-6.35" x2="14.605" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="14.605" y1="-7.6835" x2="14.859" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="14.859" y1="-7.9375" x2="15.5575" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="15.5575" y1="-7.9375" x2="15.5575" y2="-6.35" width="0.254" layer="51"/>
<wire x1="15.5575" y1="-6.35" x2="15.5575" y2="-5.715" width="0.254" layer="51"/>
<wire x1="14.605" y1="-6.35" x2="15.5575" y2="-6.35" width="0.254" layer="51"/>
<pad name="2" x="-11.43" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="1" x="-13.97" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="3" x="-8.89" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="4" x="-6.35" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="5" x="-3.81" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="6" x="-1.27" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="7" x="1.27" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="8" x="3.81" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="9" x="6.35" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="10" x="8.89" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="11" x="11.43" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="12" x="13.97" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<text x="-16.8275" y="-5.715" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="18.0975" y="-5.715" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-14.2875" y1="-7.62" x2="-13.6525" y2="-6.35" layer="51"/>
<rectangle x1="-6.6675" y1="-7.62" x2="-6.0325" y2="-6.35" layer="51"/>
<rectangle x1="-4.1275" y1="-7.62" x2="-3.4925" y2="-6.35" layer="51"/>
<rectangle x1="3.4925" y1="-7.62" x2="4.1275" y2="-6.35" layer="51"/>
<rectangle x1="6.0325" y1="-7.62" x2="6.6675" y2="-6.35" layer="51"/>
<rectangle x1="13.6525" y1="-7.62" x2="14.2875" y2="-6.35" layer="51"/>
<vertex x="-15.875" y="5.8737"/>
<vertex x="-15.3987" y="3.9688"/>
<vertex x="-14.9225" y="5.8737"/>
</polygon>
</package>
<package name="74099-12">
 vertical SMD, 12 pin</description>
<smd name="5" x="-3.81" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="4" x="-6.35" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="3" x="-8.89" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="2" x="-11.43" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="1" x="-13.97" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="6" x="-1.27" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="7" x="1.27" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="8" x="3.81" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="9" x="6.35" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="10" x="8.89" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="11" x="11.43" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="12" x="13.97" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<text x="-15.5575" y="0.635" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-15.5575" y="-1.905" size="1.016" layer="51" ratio="10">1</text>
</package>
<package name="15-91-12">
 right angle SMD, 12 pin</description>
<wire x1="16.3513" y1="5.0801" x2="-16.3513" y2="5.0801" width="0.254" layer="21"/>
<wire x1="-16.3513" y1="5.0801" x2="-16.3513" y2="2.54" width="0.254" layer="21"/>
<wire x1="-16.3513" y1="-0.9525" x2="-16.3513" y2="-6.35" width="0.254" layer="21"/>
<wire x1="-16.3513" y1="-6.35" x2="16.3513" y2="-6.35" width="0.254" layer="21"/>
<wire x1="16.3513" y1="-6.35" x2="16.3513" y2="-0.9525" width="0.254" layer="21"/>
<wire x1="16.3513" y1="2.54" x2="16.3513" y2="5.0801" width="0.254" layer="21"/>
<wire x1="-4.1275" y1="5.08" x2="-4.1275" y2="1.905" width="0.254" layer="51"/>
<wire x1="4.1275" y1="1.905" x2="4.1275" y2="5.0801" width="0.254" layer="51"/>
<wire x1="-15.24" y1="-6.35" x2="-15.24" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-15.24" y1="-6.985" x2="-14.605" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-14.605" y1="-6.985" x2="-14.605" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="-14.605" y1="-8.3185" x2="-14.859" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-14.859" y1="-8.5725" x2="-15.24" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-13.335" y1="-8.3185" x2="-13.081" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="-12.319" y1="-8.5725" x2="-13.081" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-8.255" y1="-6.985" x2="-6.985" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-8.255" y1="-6.985" x2="-8.255" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="-6.985" y1="-6.985" x2="-6.985" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="-6.985" y1="-8.3185" x2="-7.239" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-5.715" y1="-8.3185" x2="-5.461" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="-4.445" y1="-8.3185" x2="-4.699" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-4.699" y1="-8.5725" x2="-5.461" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-3.175" y1="-8.3185" x2="-2.921" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="-2.159" y1="-8.5725" x2="-2.921" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-0.635" y1="-8.3185" x2="-0.381" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="3.175" y1="-8.3185" x2="2.921" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="2.921" y1="-8.5725" x2="2.159" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="4.445" y1="-8.3185" x2="4.699" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="6.985" y1="-6.985" x2="8.255" y2="-6.985" width="0.254" layer="51"/>
<wire x1="5.715" y1="-8.3185" x2="5.461" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="5.461" y1="-8.5725" x2="4.699" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="6.985" y1="-6.985" x2="6.985" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="6.985" y1="-8.3185" x2="7.239" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="8.255" y1="-6.985" x2="8.255" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="15.24" y1="-8.5725" x2="15.24" y2="-6.35" width="0.254" layer="51"/>
<wire x1="14.605" y1="-6.985" x2="15.24" y2="-6.985" width="0.254" layer="51"/>
<wire x1="13.335" y1="-8.3185" x2="13.081" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="13.081" y1="-8.5725" x2="12.319" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="14.605" y1="-6.985" x2="14.605" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="14.605" y1="-8.3185" x2="14.859" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="14.859" y1="-8.5725" x2="15.24" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-16.3513" y1="2.54" x2="-16.3513" y2="-0.9525" width="0.254" layer="51"/>
<wire x1="16.3513" y1="2.54" x2="16.3513" y2="-0.9525" width="0.254" layer="51"/>
<wire x1="-14.605" y1="-6.985" x2="-13.335" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-6.985" y1="-6.985" x2="-5.715" y2="-6.985" width="0.254" layer="51"/>
<wire x1="5.715" y1="-6.985" x2="6.985" y2="-6.985" width="0.254" layer="51"/>
<wire x1="13.335" y1="-6.985" x2="14.605" y2="-6.985" width="0.254" layer="51"/>
<smd name="1" x="-13.97" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="2" x="-11.43" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="3" x="-8.89" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="4" x="-6.35" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="5" x="-3.81" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="6" x="-1.27" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="7" x="1.27" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="8" x="3.81" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="9" x="6.35" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="10" x="8.89" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="11" x="11.43" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="12" x="13.97" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<text x="-16.8275" y="-6.35" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="18.0975" y="-6.35" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-14.2875" y1="-10.795" x2="-13.6525" y2="-6.985" layer="51"/>
<rectangle x1="-6.6675" y1="-10.795" x2="-6.0325" y2="-6.985" layer="51"/>
<rectangle x1="-4.1275" y1="-10.795" x2="-3.4925" y2="-6.985" layer="51"/>
<rectangle x1="3.4925" y1="-10.795" x2="4.1275" y2="-6.985" layer="51"/>
<rectangle x1="6.0325" y1="-10.795" x2="6.6675" y2="-6.985" layer="51"/>
<rectangle x1="13.6525" y1="-10.795" x2="14.2875" y2="-6.985" layer="51"/>
<hole x="-15.367" y="0.8382" drill="3.4036"/>
<hole x="15.367" y="0.8382" drill="3.4036"/>
<vertex x="-15.875" y="5.08"/>
<vertex x="-15.3987" y="3.1751"/>
<vertex x="-14.9225" y="5.08"/>
</polygon>
</package>
<package name="70543-13">
 vertical, 13 pin</description>
<wire x1="17.78" y1="-2.8575" x2="17.78" y2="2.8575" width="0.254" layer="21"/>
<wire x1="17.78" y1="2.8575" x2="-17.78" y2="2.8575" width="0.254" layer="21"/>
<wire x1="-17.78" y1="2.8575" x2="-17.78" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-17.78" y1="-2.8575" x2="-3.4925" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="3.4925" y1="-2.8575" x2="17.78" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-17.145" y1="2.2225" x2="-17.145" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="17.145" y1="2.2225" x2="17.145" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="-17.145" y1="2.2225" x2="17.145" y2="2.2225" width="0.0508" layer="51"/>
<wire x1="-17.145" y1="-2.2225" x2="-2.8575" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-2.2225" x2="17.145" y2="-2.2225" width="0.0508" layer="51"/>
<pad name="3" x="-10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-12.7" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="-15.24" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="12.7" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="15.24" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-18.415" y="-2.54" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="-17.4625" y="3.4925" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-16.8275" y="-1.5875" size="1.016" layer="51" ratio="10">1</text>
<rectangle x1="-15.4781" y1="-0.2381" x2="-15.0019" y2="0.2381" layer="51"/>
<rectangle x1="-7.8581" y1="-0.2381" x2="-7.3819" y2="0.2381" layer="51"/>
<rectangle x1="7.3819" y1="-0.2381" x2="7.8581" y2="0.2381" layer="51"/>
<rectangle x1="15.0019" y1="-0.2381" x2="15.4781" y2="0.2381" layer="51"/>
</package>
<package name="70553-13">
 right angle, 13 pin</description>
<wire x1="17.6213" y1="5.8738" x2="4.1275" y2="5.8738" width="0.254" layer="21"/>
<wire x1="4.1275" y1="5.8738" x2="-17.6213" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-17.6213" y1="5.8738" x2="-17.6213" y2="-5.715" width="0.254" layer="21"/>
<wire x1="-17.6213" y1="-5.715" x2="17.6213" y2="-5.715" width="0.254" layer="21"/>
<wire x1="17.6213" y1="-5.715" x2="17.6213" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-15.875" y1="-6.35" x2="-14.605" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-14.605" y1="-6.35" x2="-13.335" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-14.605" y1="-7.6835" x2="-14.351" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-13.589" y1="-7.9375" x2="-14.351" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-9.525" y1="-6.35" x2="-9.525" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-8.255" y1="-6.35" x2="-8.255" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-8.255" y1="-7.6835" x2="-8.509" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-8.255" y1="-6.35" x2="-6.985" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-6.985" y1="-6.35" x2="-5.715" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-6.985" y1="-7.6835" x2="-6.731" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-5.715" y1="-7.6835" x2="-5.969" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-5.969" y1="-7.9375" x2="-6.731" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="5.715" y1="-6.35" x2="6.985" y2="-6.35" width="0.254" layer="51"/>
<wire x1="6.985" y1="-7.6835" x2="6.731" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="6.731" y1="-7.9375" x2="5.969" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="6.985" y1="-6.35" x2="8.255" y2="-6.35" width="0.127" layer="51"/>
<wire x1="8.255" y1="-6.35" x2="8.255" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="8.255" y1="-7.6835" x2="8.509" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="9.525" y1="-6.35" x2="9.525" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="14.605" y1="-6.35" x2="15.875" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-16.8275" y1="-5.715" x2="-16.8275" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-15.875" y1="-6.35" x2="-15.875" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-15.875" y1="-7.6835" x2="-16.129" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-16.129" y1="-7.9375" x2="-16.8275" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="15.875" y1="-6.35" x2="15.875" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="15.875" y1="-7.6835" x2="16.129" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="16.129" y1="-7.9375" x2="16.8275" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="16.8275" y1="-7.9375" x2="16.8275" y2="-6.35" width="0.254" layer="51"/>
<wire x1="16.8275" y1="-6.35" x2="16.8275" y2="-5.715" width="0.254" layer="51"/>
<wire x1="15.875" y1="-6.35" x2="16.8275" y2="-6.35" width="0.254" layer="51"/>
<wire x1="13.335" y1="-6.35" x2="14.605" y2="-6.35" width="0.254" layer="51"/>
<wire x1="14.605" y1="-7.6835" x2="14.351" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="14.351" y1="-7.9375" x2="13.589" y2="-7.9375" width="0.254" layer="51"/>
<pad name="2" x="-12.7" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="1" x="-15.24" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="3" x="-10.16" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="4" x="-7.62" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="5" x="-5.08" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="6" x="-2.54" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="7" x="0" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="8" x="2.54" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="9" x="5.08" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="10" x="7.62" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="11" x="10.16" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="12" x="12.7" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="13" x="15.24" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<text x="-18.0975" y="-5.715" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="19.3675" y="-5.715" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-15.5575" y1="-7.62" x2="-14.9225" y2="-6.35" layer="51"/>
<rectangle x1="-7.9375" y1="-7.62" x2="-7.3025" y2="-6.35" layer="51"/>
<rectangle x1="7.3025" y1="-7.62" x2="7.9375" y2="-6.35" layer="51"/>
<rectangle x1="14.9225" y1="-7.62" x2="15.5575" y2="-6.35" layer="51"/>
<vertex x="-17.145" y="5.8737"/>
<vertex x="-16.6687" y="3.9688"/>
<vertex x="-16.1925" y="5.8737"/>
</polygon>
</package>
<package name="74099-13">
<description>&lt;b&gt;C-Grid SL Connector&lt;/b&gt;&lt;p&gt;
 vertical SMD, 13 pin</description>
<wire x1="-3.4925" y1="-2.8575" x2="-3.4925" y2="-3.81" width="0.254" layer="21"/>
<wire x1="-3.4925" y1="-3.81" x2="3.4925" y2="-3.81" width="0.254" layer="21"/>
<wire x1="3.4925" y1="-3.81" x2="3.4925" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-2.8575" y1="-2.2225" x2="2.8575" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-3.175" x2="-2.8575" y2="-3.175" width="0.0508" layer="51"/>
<wire x1="-2.8575" y1="-2.2225" x2="-2.8575" y2="-3.175" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-2.2225" x2="2.8575" y2="-3.175" width="0.0508" layer="51"/>
<smd name="5" x="-5.08" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="4" x="-7.62" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="3" x="-10.16" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="2" x="-12.7" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="1" x="-15.24" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="6" x="-2.54" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="7" x="0" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="8" x="2.54" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="9" x="5.08" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="10" x="7.62" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="11" x="10.16" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="12" x="12.7" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="13" x="15.24" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<text x="-16.8275" y="0.635" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-16.8275" y="-1.905" size="1.016" layer="51" ratio="10">1</text>
<rectangle x1="-10.3981" y1="-0.2381" x2="-9.9219" y2="0.2381" layer="51"/>
<rectangle x1="9.9219" y1="-0.2381" x2="10.3981" y2="0.2381" layer="51"/>
</package>
<package name="15-91-13">
 right angle SMD, 13 pin</description>
<wire x1="17.6213" y1="5.0801" x2="-17.6213" y2="5.0801" width="0.254" layer="21"/>
<wire x1="-17.6213" y1="-6.35" x2="17.6213" y2="-6.35" width="0.254" layer="21"/>
<wire x1="-16.51" y1="-6.35" x2="-16.51" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-16.51" y1="-6.985" x2="-15.875" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-15.875" y1="-6.985" x2="-15.875" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="-15.875" y1="-8.3185" x2="-16.129" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-16.129" y1="-8.5725" x2="-16.51" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-14.605" y1="-8.3185" x2="-14.351" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="-13.589" y1="-8.5725" x2="-14.351" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-9.525" y1="-6.985" x2="-8.255" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-9.525" y1="-6.985" x2="-9.525" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="-8.255" y1="-8.3185" x2="-8.509" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-6.985" y1="-8.3185" x2="-6.731" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="-5.969" y1="-8.5725" x2="-6.731" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="6.985" y1="-8.3185" x2="6.731" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="6.731" y1="-8.5725" x2="5.969" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="8.255" y1="-8.3185" x2="8.509" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="16.51" y1="-8.5725" x2="16.51" y2="-6.35" width="0.254" layer="51"/>
<wire x1="8.255" y1="-6.985" x2="9.525" y2="-6.985" width="0.254" layer="51"/>
<wire x1="15.875" y1="-6.985" x2="16.51" y2="-6.985" width="0.254" layer="51"/>
<wire x1="9.525" y1="-6.985" x2="9.525" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="15.875" y1="-6.985" x2="15.875" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="15.875" y1="-8.3185" x2="16.129" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="16.129" y1="-8.5725" x2="16.51" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-15.875" y1="-6.985" x2="-14.605" y2="-6.985" width="0.254" layer="51"/>
<wire x1="14.605" y1="-6.985" x2="15.875" y2="-6.985" width="0.2032" layer="51"/>
<wire x1="11.049" y1="-8.5725" x2="11.811" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="11.811" y1="-8.5725" x2="12.065" y2="-8.3185" width="0.254" layer="51" curve="90"/>
<wire x1="12.065" y1="-8.3185" x2="12.065" y2="-6.985" width="0.254" layer="51"/>
<wire x1="13.589" y1="-8.5725" x2="14.351" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="14.351" y1="-8.5725" x2="14.605" y2="-8.3185" width="0.254" layer="51" curve="90"/>
<wire x1="14.605" y1="-8.3185" x2="14.605" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-17.6213" y1="5.0801" x2="-17.6213" y2="2.54" width="0.254" layer="21"/>
<wire x1="-17.6213" y1="-0.9525" x2="-17.6213" y2="-6.35" width="0.254" layer="21"/>
<wire x1="17.6213" y1="-6.35" x2="17.6213" y2="-0.9525" width="0.254" layer="21"/>
<wire x1="17.6213" y1="2.54" x2="17.6213" y2="5.0801" width="0.254" layer="21"/>
<wire x1="-17.6213" y1="2.54" x2="-17.6213" y2="-0.9525" width="0.254" layer="51"/>
<wire x1="17.6213" y1="2.54" x2="17.6213" y2="-0.9525" width="0.254" layer="51"/>
<smd name="1" x="-15.24" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="2" x="-12.7" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="3" x="-10.16" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="4" x="-7.62" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="5" x="-5.08" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="6" x="-2.54" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="7" x="0" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="8" x="2.54" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="9" x="5.08" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="10" x="7.62" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="11" x="10.16" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="12" x="12.7" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="13" x="15.24" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<text x="-18.0975" y="-6.35" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="19.3675" y="-6.35" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-15.5575" y1="-10.795" x2="-14.9225" y2="-6.985" layer="51"/>
<rectangle x1="-7.9375" y1="-10.795" x2="-7.3025" y2="-6.985" layer="51"/>
<rectangle x1="7.3025" y1="-10.795" x2="7.9375" y2="-6.985" layer="51"/>
<rectangle x1="14.9225" y1="-10.795" x2="15.5575" y2="-6.985" layer="51"/>
<hole x="-16.637" y="0.8382" drill="3.4036"/>
<hole x="16.637" y="0.8382" drill="3.4036"/>
<vertex x="-17.145" y="5.08"/>
<vertex x="-16.6687" y="3.1751"/>
<vertex x="-16.1925" y="5.08"/>
</polygon>
</package>
<package name="70543-14">
 vertical, 14 pin</description>
<wire x1="19.05" y1="-2.8575" x2="19.05" y2="2.8575" width="0.254" layer="21"/>
<wire x1="19.05" y1="2.8575" x2="-19.05" y2="2.8575" width="0.254" layer="21"/>
<wire x1="-19.05" y1="2.8575" x2="-19.05" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-19.05" y1="-2.8575" x2="-3.4925" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="3.4925" y1="-2.8575" x2="19.05" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-18.415" y1="2.2225" x2="-18.415" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="18.415" y1="2.2225" x2="18.415" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="-18.415" y1="2.2225" x2="18.415" y2="2.2225" width="0.0508" layer="51"/>
<wire x1="-18.415" y1="-2.2225" x2="-2.8575" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-2.2225" x2="18.415" y2="-2.2225" width="0.0508" layer="51"/>
<pad name="3" x="-11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-13.97" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="-16.51" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="13.97" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="16.51" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-19.685" y="-2.54" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="-18.7325" y="3.4925" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-18.0975" y="-1.5875" size="1.016" layer="51" ratio="10">1</text>
<rectangle x1="-16.7481" y1="-0.2381" x2="-16.2719" y2="0.2381" layer="51"/>
<rectangle x1="-9.1281" y1="-0.2381" x2="-8.6519" y2="0.2381" layer="51"/>
<rectangle x1="8.6519" y1="-0.2381" x2="9.1281" y2="0.2381" layer="51"/>
<rectangle x1="16.2719" y1="-0.2381" x2="16.7481" y2="0.2381" layer="51"/>
</package>
<package name="70553-14">
 right angle, 14 pin</description>
<wire x1="18.8913" y1="5.8738" x2="4.1275" y2="5.8738" width="0.254" layer="21"/>
<wire x1="4.1275" y1="5.8738" x2="-18.8913" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-18.8913" y1="5.8738" x2="-18.8913" y2="-5.715" width="0.254" layer="21"/>
<wire x1="-18.8913" y1="-5.715" x2="18.8913" y2="-5.715" width="0.254" layer="21"/>
<wire x1="18.8913" y1="-5.715" x2="18.8913" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-1.27" y1="2.54" x2="-1.27" y2="-3.175" width="0.254" layer="21"/>
<wire x1="-1.27" y1="-3.175" x2="1.27" y2="-3.175" width="0.254" layer="21"/>
<wire x1="1.27" y1="-3.175" x2="1.27" y2="2.54" width="0.254" layer="21"/>
<wire x1="-3.175" y1="2.54" x2="-1.27" y2="2.54" width="0.254" layer="21"/>
<wire x1="1.27" y1="2.54" x2="3.175" y2="2.54" width="0.254" layer="21"/>
<wire x1="-3.175" y1="2.54" x2="-3.175" y2="3.175" width="0.254" layer="21"/>
<wire x1="-3.175" y1="3.175" x2="-1.905" y2="4.445" width="0.254" layer="21" curve="-90"/>
<wire x1="-1.905" y1="4.445" x2="1.905" y2="4.445" width="0.254" layer="21"/>
<wire x1="1.905" y1="4.445" x2="3.175" y2="3.175" width="0.254" layer="21" curve="-90"/>
<wire x1="3.175" y1="3.175" x2="3.175" y2="2.54" width="0.254" layer="21"/>
<wire x1="-17.145" y1="-6.35" x2="-15.875" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-15.875" y1="-6.35" x2="-14.605" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-15.875" y1="-7.6835" x2="-15.621" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-14.859" y1="-7.9375" x2="-15.621" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-10.795" y1="-6.35" x2="-10.795" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-9.525" y1="-7.6835" x2="-9.779" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-9.525" y1="-6.35" x2="-8.255" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-8.255" y1="-6.35" x2="-6.985" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-8.255" y1="-7.6835" x2="-8.001" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-7.239" y1="-7.9375" x2="-8.001" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-1.905" y1="-6.35" x2="-1.905" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-0.635" y1="-6.35" x2="-0.635" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="0.635" y1="-6.35" x2="0.635" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="1.905" y1="-6.35" x2="1.905" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="6.985" y1="-6.35" x2="8.255" y2="-6.35" width="0.254" layer="51"/>
<wire x1="8.255" y1="-7.6835" x2="8.001" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="8.001" y1="-7.9375" x2="7.239" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="15.875" y1="-6.35" x2="17.145" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-18.0975" y1="-5.715" x2="-18.0975" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-17.145" y1="-6.35" x2="-17.145" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-17.145" y1="-7.6835" x2="-17.399" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-17.399" y1="-7.9375" x2="-18.0975" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="17.145" y1="-6.35" x2="17.145" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="17.145" y1="-7.6835" x2="17.399" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="17.399" y1="-7.9375" x2="18.0975" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="18.0975" y1="-7.9375" x2="18.0975" y2="-6.35" width="0.254" layer="51"/>
<wire x1="18.0975" y1="-6.35" x2="18.0975" y2="-5.715" width="0.254" layer="51"/>
<wire x1="17.145" y1="-6.35" x2="18.0975" y2="-6.35" width="0.254" layer="51"/>
<wire x1="8.255" y1="-6.35" x2="9.525" y2="-6.35" width="0.127" layer="51"/>
<wire x1="9.525" y1="-7.6835" x2="9.779" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="10.795" y1="-6.35" x2="10.795" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="14.605" y1="-6.35" x2="15.875" y2="-6.35" width="0.254" layer="51"/>
<wire x1="15.875" y1="-7.6835" x2="15.621" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="15.621" y1="-7.9375" x2="14.859" y2="-7.9375" width="0.254" layer="51"/>
<pad name="2" x="-13.97" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="1" x="-16.51" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="3" x="-11.43" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="4" x="-8.89" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="5" x="-6.35" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="6" x="-3.81" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="8" x="1.27" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="9" x="3.81" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="10" x="6.35" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="11" x="8.89" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="12" x="11.43" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="13" x="13.97" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="14" x="16.51" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<text x="-19.3675" y="-5.715" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="20.6375" y="-5.715" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-16.8275" y1="-7.62" x2="-16.1925" y2="-6.35" layer="51"/>
<rectangle x1="-9.2075" y1="-7.62" x2="-8.5725" y2="-6.35" layer="51"/>
<rectangle x1="16.1925" y1="-7.62" x2="16.8275" y2="-6.35" layer="51"/>
<rectangle x1="8.5725" y1="-7.62" x2="9.2075" y2="-6.35" layer="51"/>
<polygon width="0.0508" layer="21">
<vertex x="-18.415" y="5.8737"/>
<vertex x="-17.9387" y="3.9688"/>
<vertex x="-17.4625" y="5.8737"/>
</polygon>
</package>
<package name="74099-14">
 vertical SMD, 14 pin</description>
<smd name="5" x="-6.35" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="4" x="-8.89" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="3" x="-11.43" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="2" x="-13.97" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="1" x="-16.51" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="6" x="-3.81" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="7" x="-1.27" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="8" x="1.27" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="9" x="3.81" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="10" x="6.35" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="11" x="8.89" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="12" x="11.43" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="13" x="13.97" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="14" x="16.51" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<text x="-18.0975" y="0.635" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-18.0975" y="-1.905" size="1.016" layer="51" ratio="10">1</text>
<rectangle x1="-11.6681" y1="-0.2381" x2="-11.1919" y2="0.2381" layer="51"/>
<rectangle x1="-1.5081" y1="-0.2381" x2="-1.0319" y2="0.2381" layer="51"/>
<rectangle x1="1.0319" y1="-0.2381" x2="1.5081" y2="0.2381" layer="51"/>
<rectangle x1="11.1919" y1="-0.2381" x2="11.6681" y2="0.2381" layer="51"/>
</package>
<package name="15-91-14">
 right angle SMD, 14 pin</description>
<wire x1="18.8913" y1="5.0801" x2="-18.8913" y2="5.0801" width="0.254" layer="21"/>
<wire x1="-18.8913" y1="-6.35" x2="18.8913" y2="-6.35" width="0.254" layer="21"/>
<wire x1="-1.27" y1="1.905" x2="-1.27" y2="-3.81" width="0.254" layer="51"/>
<wire x1="-1.27" y1="-3.81" x2="1.27" y2="-3.81" width="0.254" layer="51"/>
<wire x1="1.27" y1="-3.81" x2="1.27" y2="1.905" width="0.254" layer="51"/>
<wire x1="-3.175" y1="1.905" x2="-1.27" y2="1.905" width="0.254" layer="51"/>
<wire x1="1.27" y1="1.905" x2="3.175" y2="1.905" width="0.254" layer="51"/>
<wire x1="-3.175" y1="1.905" x2="-3.175" y2="2.54" width="0.254" layer="51"/>
<wire x1="-3.175" y1="2.54" x2="-1.905" y2="3.81" width="0.254" layer="51" curve="-90"/>
<wire x1="-1.905" y1="3.81" x2="1.905" y2="3.81" width="0.254" layer="51"/>
<wire x1="1.905" y1="3.81" x2="3.175" y2="2.54" width="0.254" layer="51" curve="-90"/>
<wire x1="3.175" y1="2.54" x2="3.175" y2="1.905" width="0.254" layer="51"/>
<wire x1="-17.78" y1="-6.35" x2="-17.78" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-17.78" y1="-6.985" x2="-17.145" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-17.145" y1="-6.985" x2="-17.145" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="-17.145" y1="-8.3185" x2="-17.399" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-17.399" y1="-8.5725" x2="-17.78" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-15.875" y1="-8.3185" x2="-15.621" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="-14.859" y1="-8.5725" x2="-15.621" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-10.795" y1="-6.985" x2="-9.525" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-10.795" y1="-6.985" x2="-10.795" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="-9.525" y1="-8.3185" x2="-9.779" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-8.255" y1="-8.3185" x2="-8.001" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="-7.239" y1="-8.5725" x2="-8.001" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-0.635" y1="-6.985" x2="0.635" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-1.905" y1="-6.985" x2="-1.905" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="0.635" y1="-6.985" x2="0.635" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="1.905" y1="-6.985" x2="1.905" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="17.78" y1="-8.5725" x2="17.78" y2="-6.35" width="0.254" layer="51"/>
<wire x1="9.525" y1="-6.985" x2="10.795" y2="-6.985" width="0.254" layer="51"/>
<wire x1="17.145" y1="-6.985" x2="17.78" y2="-6.985" width="0.254" layer="51"/>
<wire x1="8.255" y1="-8.3185" x2="8.001" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="8.001" y1="-8.5725" x2="7.239" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="17.145" y1="-6.985" x2="17.145" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="17.145" y1="-8.3185" x2="17.399" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="17.399" y1="-8.5725" x2="17.78" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-17.145" y1="-6.985" x2="-15.875" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-1.905" y1="-6.985" x2="-0.635" y2="-6.985" width="0.254" layer="51"/>
<wire x1="0.635" y1="-6.985" x2="1.905" y2="-6.985" width="0.254" layer="51"/>
<wire x1="13.335" y1="-6.985" x2="14.605" y2="-6.985" width="0.2032" layer="51"/>
<wire x1="14.605" y1="-6.985" x2="15.875" y2="-6.985" width="0.254" layer="51"/>
<wire x1="15.875" y1="-6.985" x2="17.145" y2="-6.985" width="0.2032" layer="51"/>
<wire x1="9.525" y1="-8.3185" x2="9.779" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="9.779" y1="-8.5725" x2="10.541" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="10.541" y1="-8.5725" x2="10.795" y2="-8.3185" width="0.254" layer="51" curve="90"/>
<wire x1="10.795" y1="-8.3185" x2="10.795" y2="-6.985" width="0.254" layer="51"/>
<wire x1="12.065" y1="-6.985" x2="12.065" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="12.065" y1="-8.3185" x2="12.319" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="12.319" y1="-8.5725" x2="13.081" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="13.081" y1="-8.5725" x2="13.335" y2="-8.3185" width="0.254" layer="51" curve="90"/>
<wire x1="13.335" y1="-8.3185" x2="13.335" y2="-6.985" width="0.254" layer="51"/>
<wire x1="14.859" y1="-8.5725" x2="15.621" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="15.621" y1="-8.5725" x2="15.875" y2="-8.3185" width="0.254" layer="51" curve="90"/>
<wire x1="15.875" y1="-8.3185" x2="15.875" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-18.8913" y1="5.0801" x2="-18.8913" y2="2.54" width="0.254" layer="21"/>
<wire x1="-18.8913" y1="-0.9525" x2="-18.8913" y2="-6.35" width="0.254" layer="21"/>
<wire x1="18.8913" y1="-6.35" x2="18.8913" y2="-0.9525" width="0.254" layer="21"/>
<wire x1="18.8913" y1="2.54" x2="18.8913" y2="5.0801" width="0.254" layer="21"/>
<wire x1="-18.8913" y1="2.54" x2="-18.8913" y2="-0.9525" width="0.254" layer="51"/>
<wire x1="18.8913" y1="2.54" x2="18.8913" y2="-0.9525" width="0.254" layer="51"/>
<smd name="1" x="-16.51" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="2" x="-13.97" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="3" x="-11.43" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="4" x="-8.89" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="5" x="-6.35" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="6" x="-3.81" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="7" x="-1.27" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="8" x="1.27" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="9" x="3.81" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="10" x="6.35" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="11" x="8.89" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="12" x="11.43" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="13" x="13.97" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="14" x="16.51" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<text x="-19.3675" y="-6.35" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="20.6375" y="-6.35" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-16.8275" y1="-10.795" x2="-16.1925" y2="-6.985" layer="51"/>
<rectangle x1="-11.7475" y1="-10.795" x2="-11.1125" y2="-6.985" layer="51"/>
<rectangle x1="-9.2075" y1="-10.795" x2="-8.5725" y2="-6.985" layer="51"/>
<rectangle x1="-1.5875" y1="-10.795" x2="-0.9525" y2="-6.985" layer="51"/>
<rectangle x1="0.9525" y1="-10.795" x2="1.5875" y2="-6.985" layer="51"/>
<rectangle x1="8.5725" y1="-10.795" x2="9.2075" y2="-6.985" layer="51"/>
<rectangle x1="11.1125" y1="-10.795" x2="11.7475" y2="-6.985" layer="51"/>
<rectangle x1="16.1925" y1="-10.795" x2="16.8275" y2="-6.985" layer="51"/>
<hole x="-17.907" y="0.8382" drill="3.4036"/>
<hole x="17.907" y="0.8382" drill="3.4036"/>
<polygon width="0.2032" layer="21">
<vertex x="-18.415" y="5.08"/>
<vertex x="-17.9387" y="3.1751"/>
<vertex x="-17.4625" y="5.08"/>
</polygon>
</package>
<package name="70543-15">
 vertical, 15 pin</description>
<wire x1="20.32" y1="-2.8575" x2="20.32" y2="2.8575" width="0.254" layer="21"/>
<wire x1="20.32" y1="2.8575" x2="-20.32" y2="2.8575" width="0.254" layer="21"/>
<wire x1="-20.32" y1="2.8575" x2="-20.32" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-20.32" y1="-2.8575" x2="-3.4925" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="3.4925" y1="-2.8575" x2="20.32" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-19.685" y1="2.2225" x2="-19.685" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="19.685" y1="2.2225" x2="19.685" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="-19.685" y1="2.2225" x2="19.685" y2="2.2225" width="0.0508" layer="51"/>
<wire x1="-19.685" y1="-2.2225" x2="-2.8575" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-2.2225" x2="19.685" y2="-2.2225" width="0.0508" layer="51"/>
<pad name="3" x="-12.7" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-15.24" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="-17.78" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="12.7" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="15.24" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="15" x="17.78" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-20.955" y="-2.54" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="-20.0025" y="3.4925" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-19.3675" y="-1.5875" size="1.016" layer="51" ratio="10">1</text>
<rectangle x1="-18.0181" y1="-0.2381" x2="-17.5419" y2="0.2381" layer="51"/>
<rectangle x1="-12.9381" y1="-0.2381" x2="-12.4619" y2="0.2381" layer="51"/>
<rectangle x1="-0.2381" y1="-0.2381" x2="0.2381" y2="0.2381" layer="51"/>
<rectangle x1="-2.7781" y1="-0.2381" x2="-2.3019" y2="0.2381" layer="51"/>
<rectangle x1="2.3019" y1="-0.2381" x2="2.7781" y2="0.2381" layer="51"/>
<rectangle x1="12.4619" y1="-0.2381" x2="12.9381" y2="0.2381" layer="51"/>
<rectangle x1="17.5419" y1="-0.2381" x2="18.0181" y2="0.2381" layer="51"/>
</package>
<package name="70553-15">
 right angle, 15 pin</description>
<wire x1="20.1613" y1="5.8738" x2="4.1275" y2="5.8738" width="0.254" layer="21"/>
<wire x1="4.1275" y1="5.8738" x2="-20.1613" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-20.1613" y1="5.8738" x2="-20.1613" y2="-5.715" width="0.254" layer="21"/>
<wire x1="-20.1613" y1="-5.715" x2="20.1613" y2="-5.715" width="0.254" layer="21"/>
<wire x1="20.1613" y1="-5.715" x2="20.1613" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-4.1275" y1="5.8737" x2="-4.1275" y2="2.54" width="0.254" layer="21"/>
<wire x1="-4.1275" y1="2.54" x2="-3.175" y2="2.54" width="0.254" layer="21"/>
<wire x1="3.175" y1="2.54" x2="4.1275" y2="2.54" width="0.254" layer="21"/>
<wire x1="4.1275" y1="2.54" x2="4.1275" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-18.415" y1="-6.35" x2="-17.145" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-17.145" y1="-6.35" x2="-15.875" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-17.145" y1="-7.6835" x2="-16.891" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-16.129" y1="-7.9375" x2="-16.891" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-13.335" y1="-6.35" x2="-12.065" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-12.065" y1="-6.35" x2="-10.795" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-12.065" y1="-6.35" x2="-12.065" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-12.065" y1="-7.6835" x2="-11.811" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-10.795" y1="-7.6835" x2="-11.049" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-11.049" y1="-7.9375" x2="-11.811" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-10.795" y1="-6.35" x2="-9.525" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-9.525" y1="-6.35" x2="-8.255" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-9.525" y1="-7.6835" x2="-9.271" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-8.509" y1="-7.9375" x2="-9.271" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-5.715" y1="-6.35" x2="-4.445" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-4.445" y1="-6.35" x2="-3.175" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-4.445" y1="-6.35" x2="-4.445" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-4.445" y1="-7.6835" x2="-4.191" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-3.175" y1="-6.35" x2="-3.175" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-3.175" y1="-7.6835" x2="-3.429" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-3.429" y1="-7.9375" x2="-4.191" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-3.175" y1="-6.35" x2="-1.905" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-1.905" y1="-6.35" x2="-0.635" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-1.905" y1="-7.6835" x2="-1.651" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-0.635" y1="-7.6835" x2="-0.889" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-0.889" y1="-7.9375" x2="-1.651" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-0.635" y1="-6.35" x2="0.635" y2="-6.35" width="0.127" layer="51"/>
<wire x1="0.635" y1="-6.35" x2="1.905" y2="-6.35" width="0.254" layer="51"/>
<wire x1="0.635" y1="-7.6835" x2="0.889" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="1.905" y1="-7.6835" x2="1.651" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="1.651" y1="-7.9375" x2="0.889" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="1.905" y1="-6.35" x2="3.175" y2="-6.35" width="0.127" layer="51"/>
<wire x1="3.175" y1="-6.35" x2="4.445" y2="-6.35" width="0.254" layer="51"/>
<wire x1="3.175" y1="-6.35" x2="3.175" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="3.175" y1="-7.6835" x2="3.429" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="4.445" y1="-6.35" x2="4.445" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="4.445" y1="-7.6835" x2="4.191" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="4.191" y1="-7.9375" x2="3.429" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="4.445" y1="-6.35" x2="5.715" y2="-6.35" width="0.127" layer="51"/>
<wire x1="5.715" y1="-6.35" x2="5.715" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="5.715" y1="-7.6835" x2="5.969" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="14.605" y1="-6.35" x2="18.415" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-19.3675" y1="-5.715" x2="-19.3675" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-18.415" y1="-6.35" x2="-18.415" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-18.415" y1="-7.6835" x2="-18.669" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-18.669" y1="-7.9375" x2="-19.3675" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="18.415" y1="-6.35" x2="18.415" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="18.415" y1="-7.6835" x2="18.669" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="18.669" y1="-7.9375" x2="19.3675" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="19.3675" y1="-7.9375" x2="19.3675" y2="-6.35" width="0.254" layer="51"/>
<wire x1="19.3675" y1="-6.35" x2="19.3675" y2="-5.715" width="0.254" layer="51"/>
<wire x1="18.415" y1="-6.35" x2="19.3675" y2="-6.35" width="0.254" layer="51"/>
<wire x1="8.255" y1="-6.35" x2="9.525" y2="-6.35" width="0.254" layer="51"/>
<wire x1="9.525" y1="-7.6835" x2="9.271" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="9.271" y1="-7.9375" x2="8.509" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="12.065" y1="-6.35" x2="13.335" y2="-6.35" width="0.127" layer="51"/>
<wire x1="13.335" y1="-6.35" x2="13.335" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="13.335" y1="-7.6835" x2="13.589" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="9.525" y1="-6.35" x2="10.795" y2="-6.35" width="0.254" layer="51"/>
<wire x1="10.795" y1="-6.35" x2="12.065" y2="-6.35" width="0.254" layer="51"/>
<wire x1="10.795" y1="-7.6835" x2="11.049" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="12.065" y1="-6.35" x2="12.065" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="12.065" y1="-7.6835" x2="11.811" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="11.811" y1="-7.9375" x2="11.049" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="17.145" y1="-7.6835" x2="16.891" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="16.891" y1="-7.9375" x2="16.129" y2="-7.9375" width="0.254" layer="51"/>
<pad name="2" x="-15.24" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="1" x="-17.78" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="3" x="-12.7" y="-7.62" drill="1.0922" shape="long" rot="R270"/>
<pad name="4" x="-10.16" y="-7.62" drill="1.0922" shape="long" rot="R270"/>
<pad name="5" x="-7.62" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="6" x="-5.08" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="7" x="-2.54" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="8" x="0" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="9" x="2.54" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="10" x="5.08" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="11" x="7.62" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="12" x="10.16" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="13" x="12.7" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="14" x="15.24" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="15" x="17.78" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<text x="-20.6375" y="-5.715" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="21.9075" y="-5.715" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-18.0975" y1="-7.62" x2="-17.4625" y2="-6.35" layer="51"/>
<rectangle x1="-13.0175" y1="-7.62" x2="-12.3825" y2="-6.35" layer="51"/>
<rectangle x1="-10.4775" y1="-7.62" x2="-9.8425" y2="-6.35" layer="51"/>
<rectangle x1="-5.3975" y1="-7.62" x2="-4.7625" y2="-6.35" layer="51"/>
<rectangle x1="-2.8575" y1="-7.62" x2="-2.2225" y2="-6.35" layer="51"/>
<rectangle x1="-0.3175" y1="-7.62" x2="0.3175" y2="-6.35" layer="51"/>
<rectangle x1="2.2225" y1="-7.62" x2="2.8575" y2="-6.35" layer="51"/>
<rectangle x1="4.7625" y1="-7.62" x2="5.3975" y2="-6.35" layer="51"/>
<rectangle x1="17.4625" y1="-7.62" x2="18.0975" y2="-6.35" layer="51"/>
<rectangle x1="9.8425" y1="-7.62" x2="10.4775" y2="-6.35" layer="51"/>
<rectangle x1="12.3825" y1="-7.62" x2="13.0175" y2="-6.35" layer="51"/>
<vertex x="-19.685" y="5.8737"/>
<vertex x="-19.2087" y="3.9688"/>
<vertex x="-18.7325" y="5.8737"/>
</polygon>
</package>
<package name="74099-15">
 vertical SMD, 15 pin</description>
<smd name="5" x="-7.62" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="4" x="-10.16" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="3" x="-12.7" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="2" x="-15.24" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="1" x="-17.78" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="6" x="-5.08" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="7" x="-2.54" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="8" x="0" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="9" x="2.54" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="10" x="5.08" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="11" x="7.62" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="12" x="10.16" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="13" x="12.7" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="14" x="15.24" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="15" x="17.78" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<text x="-19.3675" y="0.635" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-19.3675" y="-1.905" size="1.016" layer="51" ratio="10">1</text>
<rectangle x1="-5.3181" y1="-0.2381" x2="-4.8419" y2="0.2381" layer="51"/>
<rectangle x1="4.8419" y1="-0.2381" x2="5.3181" y2="0.2381" layer="51"/>
</package>
<package name="15-91-15">
 right angle SMD, 15 pin</description>
<wire x1="20.1613" y1="5.0801" x2="-20.1613" y2="5.0801" width="0.254" layer="21"/>
<wire x1="-20.1613" y1="-6.35" x2="20.1613" y2="-6.35" width="0.254" layer="21"/>
<wire x1="-4.1275" y1="1.905" x2="-3.175" y2="1.905" width="0.254" layer="51"/>
<wire x1="3.175" y1="1.905" x2="4.1275" y2="1.905" width="0.254" layer="51"/>
<wire x1="-19.05" y1="-6.35" x2="-19.05" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-19.05" y1="-6.985" x2="-18.415" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-18.415" y1="-6.985" x2="-18.415" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="-18.415" y1="-8.3185" x2="-18.669" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-18.669" y1="-8.5725" x2="-19.05" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-17.145" y1="-8.3185" x2="-16.891" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="-16.129" y1="-8.5725" x2="-16.891" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-12.065" y1="-6.985" x2="-10.795" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-13.335" y1="-6.985" x2="-13.335" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="-13.335" y1="-8.3185" x2="-13.589" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-12.065" y1="-6.985" x2="-12.065" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="-12.065" y1="-8.3185" x2="-11.811" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="-10.795" y1="-8.3185" x2="-11.049" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-11.049" y1="-8.5725" x2="-11.811" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-9.525" y1="-8.3185" x2="-9.271" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="-8.509" y1="-8.5725" x2="-9.271" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-5.715" y1="-6.985" x2="-5.715" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="-5.715" y1="-8.3185" x2="-5.969" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-4.445" y1="-6.985" x2="-4.445" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="-4.445" y1="-8.3185" x2="-4.191" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="-4.445" y1="-6.985" x2="-3.175" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-3.175" y1="-6.985" x2="-3.175" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="-3.175" y1="-8.3185" x2="-3.429" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-3.429" y1="-8.5725" x2="-4.191" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-1.905" y1="-8.3185" x2="-1.651" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="-0.635" y1="-6.985" x2="-0.635" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="-0.635" y1="-8.3185" x2="-0.889" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-0.889" y1="-8.5725" x2="-1.651" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="0.635" y1="-8.3185" x2="0.889" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="3.175" y1="-6.985" x2="4.445" y2="-6.985" width="0.254" layer="51"/>
<wire x1="1.905" y1="-8.3185" x2="1.651" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="1.651" y1="-8.5725" x2="0.889" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="3.175" y1="-6.985" x2="3.175" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="3.175" y1="-8.3185" x2="3.429" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="4.445" y1="-6.985" x2="4.445" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="4.445" y1="-8.3185" x2="4.191" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="4.191" y1="-8.5725" x2="3.429" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="5.715" y1="-6.985" x2="5.715" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="5.715" y1="-8.3185" x2="5.969" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="19.05" y1="-8.5725" x2="19.05" y2="-6.35" width="0.254" layer="51"/>
<wire x1="18.415" y1="-6.985" x2="19.05" y2="-6.985" width="0.254" layer="51"/>
<wire x1="18.415" y1="-6.985" x2="18.415" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="18.415" y1="-8.3185" x2="18.669" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="18.669" y1="-8.5725" x2="19.05" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-18.415" y1="-6.985" x2="-17.145" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-13.335" y1="-6.985" x2="-12.065" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-5.715" y1="-6.985" x2="-4.445" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-3.175" y1="-6.985" x2="-1.905" y2="-6.985" width="0.254" layer="51"/>
<wire x1="1.905" y1="-6.985" x2="3.175" y2="-6.985" width="0.254" layer="51"/>
<wire x1="4.445" y1="-6.985" x2="5.715" y2="-6.985" width="0.254" layer="51"/>
<wire x1="10.795" y1="-6.985" x2="12.065" y2="-6.985" width="0.254" layer="51"/>
<wire x1="12.065" y1="-6.985" x2="13.335" y2="-6.985" width="0.2032" layer="51"/>
<wire x1="15.875" y1="-6.985" x2="17.145" y2="-6.985" width="0.254" layer="51"/>
<wire x1="17.145" y1="-6.985" x2="18.415" y2="-6.985" width="0.2032" layer="51"/>
<wire x1="8.509" y1="-8.5725" x2="9.271" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="9.271" y1="-8.5725" x2="9.525" y2="-8.3185" width="0.254" layer="51" curve="90"/>
<wire x1="9.525" y1="-8.3185" x2="9.525" y2="-6.985" width="0.254" layer="51"/>
<wire x1="10.795" y1="-6.985" x2="10.795" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="10.795" y1="-8.3185" x2="11.049" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="16.129" y1="-8.5725" x2="16.891" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="16.891" y1="-8.5725" x2="17.145" y2="-8.3185" width="0.254" layer="51" curve="90"/>
<wire x1="17.145" y1="-8.3185" x2="17.145" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-20.1613" y1="5.0801" x2="-20.1613" y2="2.54" width="0.254" layer="21"/>
<wire x1="-20.1613" y1="-0.9525" x2="-20.1613" y2="-6.35" width="0.254" layer="21"/>
<wire x1="20.1613" y1="-6.35" x2="20.1613" y2="-0.9525" width="0.254" layer="21"/>
<wire x1="20.1613" y1="2.54" x2="20.1613" y2="5.0801" width="0.254" layer="21"/>
<wire x1="-20.1613" y1="2.54" x2="-20.1613" y2="-0.9525" width="0.254" layer="51"/>
<wire x1="20.1613" y1="2.54" x2="20.1613" y2="-0.9525" width="0.254" layer="51"/>
<wire x1="13.335" y1="-6.985" x2="13.335" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="13.335" y1="-8.3185" x2="13.589" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<smd name="1" x="-17.78" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="2" x="-15.24" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="3" x="-12.7" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="4" x="-10.16" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="5" x="-7.62" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="6" x="-5.08" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="7" x="-2.54" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="8" x="0" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="9" x="2.54" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="10" x="5.08" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="11" x="7.62" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="12" x="10.16" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="13" x="12.7" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="14" x="15.24" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="15" x="17.78" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<text x="-20.6375" y="-6.35" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="21.9075" y="-6.35" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-18.0975" y1="-10.795" x2="-17.4625" y2="-6.985" layer="51"/>
<rectangle x1="-13.0175" y1="-10.795" x2="-12.3825" y2="-6.985" layer="51"/>
<rectangle x1="-10.4775" y1="-10.795" x2="-9.8425" y2="-6.985" layer="51"/>
<rectangle x1="-5.3975" y1="-10.795" x2="-4.7625" y2="-6.985" layer="51"/>
<rectangle x1="-2.8575" y1="-10.795" x2="-2.2225" y2="-6.985" layer="51"/>
<rectangle x1="-0.3175" y1="-10.795" x2="0.3175" y2="-6.985" layer="51"/>
<rectangle x1="2.2225" y1="-10.795" x2="2.8575" y2="-6.985" layer="51"/>
<rectangle x1="4.7625" y1="-10.795" x2="5.3975" y2="-6.985" layer="51"/>
<rectangle x1="9.8425" y1="-10.795" x2="10.4775" y2="-6.985" layer="51"/>
<rectangle x1="12.3825" y1="-10.795" x2="13.0175" y2="-6.985" layer="51"/>
<rectangle x1="17.4625" y1="-10.795" x2="18.0975" y2="-6.985" layer="51"/>
<hole x="-19.177" y="0.8382" drill="3.4036"/>
<hole x="19.177" y="0.8382" drill="3.4036"/>
<vertex x="-19.685" y="5.08"/>
<vertex x="-19.2087" y="3.1751"/>
<vertex x="-18.7325" y="5.08"/>
</polygon>
</package>
<package name="70543-16">
 vertical, 16 pin</description>
<wire x1="21.59" y1="-2.8575" x2="21.59" y2="2.8575" width="0.254" layer="21"/>
<wire x1="21.59" y1="2.8575" x2="-21.59" y2="2.8575" width="0.254" layer="21"/>
<wire x1="-21.59" y1="2.8575" x2="-21.59" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-21.59" y1="-2.8575" x2="-3.4925" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="3.4925" y1="-2.8575" x2="21.59" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-20.955" y1="2.2225" x2="-20.955" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="20.955" y1="2.2225" x2="20.955" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="-20.955" y1="2.2225" x2="20.955" y2="2.2225" width="0.0508" layer="51"/>
<wire x1="-20.955" y1="-2.2225" x2="-2.8575" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-2.2225" x2="20.955" y2="-2.2225" width="0.0508" layer="51"/>
<pad name="3" x="-13.97" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-16.51" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="-19.05" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="13.97" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="15" x="16.51" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="16" x="19.05" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-22.225" y="-2.54" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="-21.2725" y="3.4925" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-20.6375" y="-1.5875" size="1.016" layer="51" ratio="10">1</text>
<rectangle x1="-19.2881" y1="-0.2381" x2="-18.8119" y2="0.2381" layer="51"/>
<rectangle x1="-14.2081" y1="-0.2381" x2="-13.7319" y2="0.2381" layer="51"/>
<rectangle x1="-6.5881" y1="-0.2381" x2="-6.1119" y2="0.2381" layer="51"/>
<rectangle x1="-4.0481" y1="-0.2381" x2="-3.5719" y2="0.2381" layer="51"/>
<rectangle x1="3.5719" y1="-0.2381" x2="4.0481" y2="0.2381" layer="51"/>
<rectangle x1="6.1119" y1="-0.2381" x2="6.5881" y2="0.2381" layer="51"/>
<rectangle x1="13.7319" y1="-0.2381" x2="14.2081" y2="0.2381" layer="51"/>
<rectangle x1="18.8119" y1="-0.2381" x2="19.2881" y2="0.2381" layer="51"/>
</package>
<package name="70553-16">
 right angle, 16 pin</description>
<wire x1="21.4313" y1="5.8738" x2="4.1275" y2="5.8738" width="0.254" layer="21"/>
<wire x1="4.1275" y1="5.8738" x2="-21.4313" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-21.4313" y1="5.8738" x2="-21.4313" y2="-5.715" width="0.254" layer="21"/>
<wire x1="-21.4313" y1="-5.715" x2="21.4313" y2="-5.715" width="0.254" layer="21"/>
<wire x1="21.4313" y1="-5.715" x2="21.4313" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-19.685" y1="-6.35" x2="-18.415" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-18.415" y1="-6.35" x2="-17.145" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-18.415" y1="-7.6835" x2="-18.161" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-17.399" y1="-7.9375" x2="-18.161" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-14.605" y1="-6.35" x2="-14.605" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-14.605" y1="-7.6835" x2="-14.859" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-14.605" y1="-6.35" x2="-13.335" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-13.335" y1="-6.35" x2="-12.065" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-13.335" y1="-6.35" x2="-13.335" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-13.335" y1="-7.6835" x2="-13.081" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-12.065" y1="-7.6835" x2="-12.319" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-12.319" y1="-7.9375" x2="-13.081" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-12.065" y1="-6.35" x2="-10.795" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-10.795" y1="-6.35" x2="-9.525" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-10.795" y1="-7.6835" x2="-10.541" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-9.779" y1="-7.9375" x2="-10.541" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-6.985" y1="-6.35" x2="-6.985" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-6.985" y1="-7.6835" x2="-7.239" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-6.985" y1="-6.35" x2="-5.715" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-5.715" y1="-6.35" x2="-4.445" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-5.715" y1="-6.35" x2="-5.715" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-5.715" y1="-7.6835" x2="-5.461" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-4.445" y1="-7.6835" x2="-4.699" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-4.699" y1="-7.9375" x2="-5.461" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-4.445" y1="-6.35" x2="-3.175" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-3.175" y1="-6.35" x2="-1.905" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-3.175" y1="-7.6835" x2="-2.921" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-1.905" y1="-7.6835" x2="-2.159" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-2.159" y1="-7.9375" x2="-2.921" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-1.905" y1="-6.35" x2="-0.635" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-0.635" y1="-6.35" x2="0.635" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-0.635" y1="-7.6835" x2="-0.381" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="0.635" y1="-7.6835" x2="0.381" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="0.381" y1="-7.9375" x2="-0.381" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="0.635" y1="-6.35" x2="1.905" y2="-6.35" width="0.127" layer="51"/>
<wire x1="1.905" y1="-6.35" x2="3.175" y2="-6.35" width="0.254" layer="51"/>
<wire x1="1.905" y1="-7.6835" x2="2.159" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="3.175" y1="-7.6835" x2="2.921" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="2.921" y1="-7.9375" x2="2.159" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="3.175" y1="-6.35" x2="4.445" y2="-6.35" width="0.127" layer="51"/>
<wire x1="4.445" y1="-6.35" x2="5.715" y2="-6.35" width="0.254" layer="51"/>
<wire x1="4.445" y1="-7.6835" x2="4.699" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="5.715" y1="-7.6835" x2="5.461" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="5.461" y1="-7.9375" x2="4.699" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="13.335" y1="-6.35" x2="17.145" y2="-6.35" width="0.254" layer="51"/>
<wire x1="17.145" y1="-6.35" x2="18.415" y2="-6.35" width="0.254" layer="51"/>
<wire x1="18.415" y1="-6.35" x2="19.685" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-20.6375" y1="-5.715" x2="-20.6375" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-19.685" y1="-6.35" x2="-19.685" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-19.685" y1="-7.6835" x2="-19.939" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-19.939" y1="-7.9375" x2="-20.6375" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="19.685" y1="-6.35" x2="19.685" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="19.685" y1="-7.6835" x2="19.939" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="19.939" y1="-7.9375" x2="20.6375" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="20.6375" y1="-7.9375" x2="20.6375" y2="-6.35" width="0.254" layer="51"/>
<wire x1="20.6375" y1="-6.35" x2="20.6375" y2="-5.715" width="0.254" layer="51"/>
<wire x1="19.685" y1="-6.35" x2="20.6375" y2="-6.35" width="0.254" layer="51"/>
<wire x1="5.715" y1="-6.35" x2="6.985" y2="-6.35" width="0.127" layer="51"/>
<wire x1="6.985" y1="-6.35" x2="6.985" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="6.985" y1="-7.6835" x2="7.239" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="10.795" y1="-6.35" x2="12.065" y2="-6.35" width="0.127" layer="51"/>
<wire x1="12.065" y1="-6.35" x2="13.335" y2="-6.35" width="0.254" layer="51"/>
<wire x1="12.065" y1="-7.6835" x2="12.319" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="13.335" y1="-7.6835" x2="13.081" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="13.081" y1="-7.9375" x2="12.319" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="10.795" y1="-7.6835" x2="10.541" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="10.541" y1="-7.9375" x2="9.779" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="14.605" y1="-6.35" x2="14.605" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="14.605" y1="-7.6835" x2="14.859" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="17.399" y1="-7.9375" x2="18.161" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="18.161" y1="-7.9375" x2="18.415" y2="-7.6835" width="0.254" layer="51" curve="90"/>
<wire x1="18.415" y1="-7.6835" x2="18.415" y2="-6.35" width="0.254" layer="51"/>
<pad name="2" x="-16.51" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="1" x="-19.05" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="3" x="-13.97" y="-7.62" drill="1.0922" shape="long" rot="R270"/>
<pad name="4" x="-11.43" y="-7.62" drill="1.0922" shape="long" rot="R270"/>
<pad name="5" x="-8.89" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="6" x="-6.35" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="7" x="-3.81" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="8" x="-1.27" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="9" x="1.27" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="10" x="3.81" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="11" x="6.35" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="12" x="8.89" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="13" x="11.43" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="14" x="13.97" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="15" x="16.51" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="16" x="19.05" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<text x="-21.9075" y="-5.715" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="23.1775" y="-5.715" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-19.3675" y1="-7.62" x2="-18.7325" y2="-6.35" layer="51"/>
<rectangle x1="-14.2875" y1="-7.62" x2="-13.6525" y2="-6.35" layer="51"/>
<rectangle x1="-11.7475" y1="-7.62" x2="-11.1125" y2="-6.35" layer="51"/>
<rectangle x1="-6.6675" y1="-7.62" x2="-6.0325" y2="-6.35" layer="51"/>
<rectangle x1="-4.1275" y1="-7.62" x2="-3.4925" y2="-6.35" layer="51"/>
<rectangle x1="-1.5875" y1="-7.62" x2="-0.9525" y2="-6.35" layer="51"/>
<rectangle x1="0.9525" y1="-7.62" x2="1.5875" y2="-6.35" layer="51"/>
<rectangle x1="3.4925" y1="-7.62" x2="4.1275" y2="-6.35" layer="51"/>
<rectangle x1="18.7325" y1="-7.62" x2="19.3675" y2="-6.35" layer="51"/>
<rectangle x1="6.0325" y1="-7.62" x2="6.6675" y2="-6.35" layer="51"/>
<rectangle x1="11.1125" y1="-7.62" x2="11.7475" y2="-6.35" layer="51"/>
<rectangle x1="13.6525" y1="-7.62" x2="14.2875" y2="-6.35" layer="51"/>
<vertex x="-20.955" y="5.8737"/>
<vertex x="-20.4787" y="3.9688"/>
<vertex x="-20.0025" y="5.8737"/>
</polygon>
</package>
<package name="74099-16">
 vertical SMD, 16 pin</description>
<smd name="5" x="-8.89" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="4" x="-11.43" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="3" x="-13.97" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="2" x="-16.51" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="1" x="-19.05" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="6" x="-6.35" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="7" x="-3.81" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="8" x="-1.27" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="9" x="1.27" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="10" x="3.81" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="11" x="6.35" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="12" x="8.89" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="13" x="11.43" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="14" x="13.97" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="15" x="16.51" y="-2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<smd name="16" x="19.05" y="2.2225" dx="3.175" dy="1.27" layer="1" rot="R270"/>
<text x="-20.6375" y="0.635" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-20.6375" y="-1.905" size="1.016" layer="51" ratio="10">1</text>
</package>
<package name="15-91-16">
 right angle SMD, 16 pin</description>
<wire x1="21.4313" y1="5.0801" x2="-21.4313" y2="5.0801" width="0.254" layer="21"/>
<wire x1="-21.4313" y1="-6.35" x2="21.4313" y2="-6.35" width="0.254" layer="21"/>
<wire x1="-4.1275" y1="5.08" x2="-4.1275" y2="1.905" width="0.254" layer="51"/>
<wire x1="4.1275" y1="1.905" x2="4.1275" y2="5.0801" width="0.254" layer="51"/>
<wire x1="-20.32" y1="-6.35" x2="-20.32" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-20.32" y1="-6.985" x2="-19.685" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-19.685" y1="-6.985" x2="-19.685" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="-19.685" y1="-8.3185" x2="-19.939" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-19.939" y1="-8.5725" x2="-20.32" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-18.415" y1="-8.3185" x2="-18.161" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="-17.399" y1="-8.5725" x2="-18.161" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-14.605" y1="-6.985" x2="-14.605" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="-14.605" y1="-8.3185" x2="-14.859" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-13.335" y1="-8.3185" x2="-13.081" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="-12.065" y1="-8.3185" x2="-12.319" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-12.319" y1="-8.5725" x2="-13.081" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-10.795" y1="-8.3185" x2="-10.541" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="-8.255" y1="-6.985" x2="-6.985" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-9.779" y1="-8.5725" x2="-10.541" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-8.255" y1="-6.985" x2="-8.255" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="-6.985" y1="-6.985" x2="-6.985" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="-6.985" y1="-8.3185" x2="-7.239" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-5.715" y1="-8.3185" x2="-5.461" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="-4.445" y1="-8.3185" x2="-4.699" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-4.699" y1="-8.5725" x2="-5.461" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-3.175" y1="-8.3185" x2="-2.921" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="-1.905" y1="-8.3185" x2="-2.159" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="-2.159" y1="-8.5725" x2="-2.921" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-0.635" y1="-8.3185" x2="-0.381" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="0.635" y1="-8.3185" x2="0.381" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="0.381" y1="-8.5725" x2="-0.381" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="1.905" y1="-8.3185" x2="2.159" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="3.175" y1="-8.3185" x2="2.921" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="2.921" y1="-8.5725" x2="2.159" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="4.445" y1="-8.3185" x2="4.699" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="20.32" y1="-8.5725" x2="20.32" y2="-6.35" width="0.254" layer="51"/>
<wire x1="6.985" y1="-6.985" x2="8.255" y2="-6.985" width="0.254" layer="51"/>
<wire x1="19.685" y1="-6.985" x2="20.32" y2="-6.985" width="0.254" layer="51"/>
<wire x1="5.715" y1="-8.3185" x2="5.461" y2="-8.5725" width="0.254" layer="51" curve="-90"/>
<wire x1="5.461" y1="-8.5725" x2="4.699" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="19.685" y1="-6.985" x2="19.685" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="19.685" y1="-8.3185" x2="19.939" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="19.939" y1="-8.5725" x2="20.32" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="-19.685" y1="-6.985" x2="-18.415" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-14.605" y1="-6.985" x2="-13.335" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-9.525" y1="-6.985" x2="-8.255" y2="-6.985" width="0.254" layer="51"/>
<wire x1="-6.985" y1="-6.985" x2="-5.715" y2="-6.985" width="0.254" layer="51"/>
<wire x1="5.715" y1="-6.985" x2="6.985" y2="-6.985" width="0.254" layer="51"/>
<wire x1="10.795" y1="-6.985" x2="12.065" y2="-6.985" width="0.2032" layer="51"/>
<wire x1="12.065" y1="-6.985" x2="13.335" y2="-6.985" width="0.254" layer="51"/>
<wire x1="17.145" y1="-6.985" x2="18.415" y2="-6.985" width="0.254" layer="51"/>
<wire x1="18.415" y1="-6.985" x2="19.685" y2="-6.985" width="0.2032" layer="51"/>
<wire x1="6.985" y1="-6.985" x2="6.985" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="6.985" y1="-8.3185" x2="7.239" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="7.239" y1="-8.5725" x2="8.001" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="8.001" y1="-8.5725" x2="8.255" y2="-8.3185" width="0.254" layer="51" curve="90"/>
<wire x1="8.255" y1="-8.3185" x2="8.255" y2="-6.985" width="0.254" layer="51"/>
<wire x1="9.525" y1="-6.985" x2="9.525" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="14.605" y1="-6.985" x2="14.605" y2="-8.3185" width="0.254" layer="51"/>
<wire x1="14.605" y1="-8.3185" x2="14.859" y2="-8.5725" width="0.254" layer="51" curve="90"/>
<wire x1="-21.4313" y1="5.0801" x2="-21.4313" y2="2.54" width="0.254" layer="21"/>
<wire x1="-21.4313" y1="-0.9525" x2="-21.4313" y2="-6.35" width="0.254" layer="21"/>
<wire x1="21.4313" y1="-6.35" x2="21.4313" y2="-0.9525" width="0.254" layer="21"/>
<wire x1="21.4313" y1="2.54" x2="21.4313" y2="5.0801" width="0.254" layer="21"/>
<wire x1="-21.4313" y1="2.54" x2="-21.4313" y2="-0.9525" width="0.254" layer="51"/>
<wire x1="21.4313" y1="2.54" x2="21.4313" y2="-0.9525" width="0.254" layer="51"/>
<wire x1="17.399" y1="-8.5725" x2="18.161" y2="-8.5725" width="0.254" layer="51"/>
<wire x1="18.161" y1="-8.5725" x2="18.415" y2="-8.3185" width="0.254" layer="51" curve="90"/>
<wire x1="18.415" y1="-8.3185" x2="18.415" y2="-6.985" width="0.254" layer="51"/>
<smd name="1" x="-19.05" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="2" x="-16.51" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="3" x="-13.97" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="4" x="-11.43" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="5" x="-8.89" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="6" x="-6.35" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="7" x="-3.81" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="8" x="-1.27" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="9" x="1.27" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="10" x="3.81" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="11" x="6.35" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="12" x="8.89" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="13" x="11.43" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="14" x="13.97" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="15" x="16.51" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<smd name="16" x="19.05" y="-10.795" dx="5.334" dy="1.651" layer="1" rot="R90"/>
<text x="-21.9075" y="-6.35" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="23.1775" y="-6.35" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-19.3675" y1="-10.795" x2="-18.7325" y2="-6.985" layer="51"/>
<rectangle x1="-14.2875" y1="-10.795" x2="-13.6525" y2="-6.985" layer="51"/>
<rectangle x1="-6.6675" y1="-10.795" x2="-6.0325" y2="-6.985" layer="51"/>
<rectangle x1="-4.1275" y1="-10.795" x2="-3.4925" y2="-6.985" layer="51"/>
<rectangle x1="3.4925" y1="-10.795" x2="4.1275" y2="-6.985" layer="51"/>
<rectangle x1="6.0325" y1="-10.795" x2="6.6675" y2="-6.985" layer="51"/>
<rectangle x1="18.7325" y1="-10.795" x2="19.3675" y2="-6.985" layer="51"/>
<rectangle x1="13.6525" y1="-10.795" x2="14.2875" y2="-6.985" layer="51"/>
<hole x="-20.447" y="0.8382" drill="3.4036"/>
<hole x="20.447" y="0.8382" drill="3.4036"/>
<vertex x="-20.955" y="5.08"/>
<vertex x="-20.4787" y="3.1751"/>
<vertex x="-20.0025" y="5.08"/>
</polygon>
</package>
<package name="70543-17">
<description>&lt;b&gt;C-Grid SL Connector&lt;/b&gt;&lt;p&gt;
 vertical, 17 pin</description>
<wire x1="22.86" y1="-2.8575" x2="22.86" y2="2.8575" width="0.254" layer="21"/>
<wire x1="22.86" y1="2.8575" x2="-22.86" y2="2.8575" width="0.254" layer="21"/>
<wire x1="-22.86" y1="2.8575" x2="-22.86" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-22.86" y1="-2.8575" x2="-3.4925" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-3.4925" y1="-2.8575" x2="-3.4925" y2="-3.81" width="0.254" layer="21"/>
<wire x1="-3.4925" y1="-3.81" x2="3.4925" y2="-3.81" width="0.254" layer="21"/>
<wire x1="3.4925" y1="-3.81" x2="3.4925" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="3.4925" y1="-2.8575" x2="22.86" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-22.225" y1="2.2225" x2="-22.225" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="22.225" y1="2.2225" x2="22.225" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="-22.225" y1="2.2225" x2="22.225" y2="2.2225" width="0.0508" layer="51"/>
<wire x1="-22.225" y1="-2.2225" x2="-2.8575" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="-2.8575" y1="-2.2225" x2="2.8575" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-2.2225" x2="22.225" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-3.175" x2="-2.8575" y2="-3.175" width="0.0508" layer="51"/>
<wire x1="-2.8575" y1="-2.2225" x2="-2.8575" y2="-3.175" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-2.2225" x2="2.8575" y2="-3.175" width="0.0508" layer="51"/>
<pad name="3" x="-15.24" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-17.78" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="-20.32" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-12.7" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="12.7" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="15" x="15.24" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="16" x="17.78" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="17" x="20.32" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-23.495" y="-2.54" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="-22.5425" y="3.4925" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-21.9075" y="-1.5875" size="1.016" layer="51" ratio="10">1</text>
<rectangle x1="-20.5581" y1="-0.2381" x2="-20.0819" y2="0.2381" layer="51"/>
<rectangle x1="-15.4781" y1="-0.2381" x2="-15.0019" y2="0.2381" layer="51"/>
<rectangle x1="-7.8581" y1="-0.2381" x2="-7.3819" y2="0.2381" layer="51"/>
<rectangle x1="-10.3981" y1="-0.2381" x2="-9.9219" y2="0.2381" layer="51"/>
<rectangle x1="7.3819" y1="-0.2381" x2="7.8581" y2="0.2381" layer="51"/>
<rectangle x1="9.9219" y1="-0.2381" x2="10.3981" y2="0.2381" layer="51"/>
<rectangle x1="15.0019" y1="-0.2381" x2="15.4781" y2="0.2381" layer="51"/>
<rectangle x1="20.0819" y1="-0.2381" x2="20.5581" y2="0.2381" layer="51"/>
</package>
<package name="70553-17">
 right angle, 17 pin</description>
<wire x1="22.7013" y1="5.8738" x2="4.1275" y2="5.8738" width="0.254" layer="21"/>
<wire x1="4.1275" y1="5.8738" x2="-22.7013" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-22.7013" y1="5.8738" x2="-22.7013" y2="-5.715" width="0.254" layer="21"/>
<wire x1="-22.7013" y1="-5.715" x2="22.7013" y2="-5.715" width="0.254" layer="21"/>
<wire x1="22.7013" y1="-5.715" x2="22.7013" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-1.27" y1="2.54" x2="-1.27" y2="-3.175" width="0.254" layer="21"/>
<wire x1="-1.27" y1="-3.175" x2="1.27" y2="-3.175" width="0.254" layer="21"/>
<wire x1="1.27" y1="-3.175" x2="1.27" y2="2.54" width="0.254" layer="21"/>
<wire x1="-3.175" y1="2.54" x2="-1.27" y2="2.54" width="0.254" layer="21"/>
<wire x1="1.27" y1="2.54" x2="3.175" y2="2.54" width="0.254" layer="21"/>
<wire x1="-3.175" y1="2.54" x2="-3.175" y2="3.175" width="0.254" layer="21"/>
<wire x1="-3.175" y1="3.175" x2="-1.905" y2="4.445" width="0.254" layer="21" curve="-90"/>
<wire x1="-1.905" y1="4.445" x2="1.905" y2="4.445" width="0.254" layer="21"/>
<wire x1="1.905" y1="4.445" x2="3.175" y2="3.175" width="0.254" layer="21" curve="-90"/>
<wire x1="3.175" y1="3.175" x2="3.175" y2="2.54" width="0.254" layer="21"/>
<wire x1="-20.955" y1="-6.35" x2="-19.685" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-19.685" y1="-6.35" x2="-18.415" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-19.685" y1="-7.6835" x2="-19.431" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-18.669" y1="-7.9375" x2="-19.431" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-17.145" y1="-6.35" x2="-17.145" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-15.875" y1="-6.35" x2="-15.875" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-15.875" y1="-7.6835" x2="-16.129" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-15.875" y1="-6.35" x2="-14.605" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-14.605" y1="-6.35" x2="-13.335" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-14.605" y1="-7.6835" x2="-14.351" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-13.335" y1="-7.6835" x2="-13.589" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-13.589" y1="-7.9375" x2="-14.351" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-10.795" y1="-6.35" x2="-10.795" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-9.525" y1="-6.35" x2="-9.525" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-8.255" y1="-6.35" x2="-8.255" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-8.255" y1="-7.6835" x2="-8.509" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-8.255" y1="-6.35" x2="-6.985" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-6.985" y1="-6.35" x2="-5.715" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-6.985" y1="-7.6835" x2="-6.731" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-5.715" y1="-7.6835" x2="-5.969" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-5.969" y1="-7.9375" x2="-6.731" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-1.905" y1="-6.35" x2="-1.905" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-0.635" y1="-6.35" x2="-0.635" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="0.635" y1="-6.35" x2="0.635" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="1.905" y1="-6.35" x2="1.905" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="12.065" y1="-6.35" x2="15.875" y2="-6.35" width="0.254" layer="51"/>
<wire x1="15.875" y1="-6.35" x2="17.145" y2="-6.35" width="0.254" layer="51"/>
<wire x1="17.145" y1="-6.35" x2="18.415" y2="-6.35" width="0.127" layer="51"/>
<wire x1="18.415" y1="-6.35" x2="19.685" y2="-6.35" width="0.254" layer="51"/>
<wire x1="19.685" y1="-6.35" x2="20.955" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-21.9075" y1="-5.715" x2="-21.9075" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-20.955" y1="-6.35" x2="-20.955" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-20.955" y1="-7.6835" x2="-21.209" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-21.209" y1="-7.9375" x2="-21.9075" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="20.955" y1="-6.35" x2="20.955" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="20.955" y1="-7.6835" x2="21.209" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="21.209" y1="-7.9375" x2="21.9075" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="21.9075" y1="-7.9375" x2="21.9075" y2="-6.35" width="0.254" layer="51"/>
<wire x1="21.9075" y1="-6.35" x2="21.9075" y2="-5.715" width="0.254" layer="51"/>
<wire x1="20.955" y1="-6.35" x2="21.9075" y2="-6.35" width="0.254" layer="51"/>
<wire x1="5.715" y1="-6.35" x2="6.985" y2="-6.35" width="0.254" layer="51"/>
<wire x1="6.985" y1="-7.6835" x2="6.731" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="6.731" y1="-7.9375" x2="5.969" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="9.525" y1="-6.35" x2="10.795" y2="-6.35" width="0.127" layer="51"/>
<wire x1="10.795" y1="-6.35" x2="10.795" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="6.985" y1="-6.35" x2="8.255" y2="-6.35" width="0.254" layer="51"/>
<wire x1="8.255" y1="-6.35" x2="8.255" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="8.255" y1="-7.6835" x2="8.509" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="9.525" y1="-6.35" x2="9.525" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="14.605" y1="-7.6835" x2="14.351" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="14.351" y1="-7.9375" x2="13.589" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="15.875" y1="-6.35" x2="15.875" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="15.875" y1="-7.6835" x2="16.129" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="16.129" y1="-7.9375" x2="16.891" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="16.891" y1="-7.9375" x2="17.145" y2="-7.6835" width="0.254" layer="51" curve="90"/>
<wire x1="17.145" y1="-7.6835" x2="17.145" y2="-6.35" width="0.254" layer="51"/>
<wire x1="18.669" y1="-7.9375" x2="19.431" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="19.431" y1="-7.9375" x2="19.685" y2="-7.6835" width="0.254" layer="51" curve="90"/>
<wire x1="19.685" y1="-7.6835" x2="19.685" y2="-6.35" width="0.254" layer="51"/>
<pad name="2" x="-17.78" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="1" x="-20.32" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="3" x="-15.24" y="-7.62" drill="1.0922" shape="long" rot="R270"/>
<pad name="4" x="-12.7" y="-7.62" drill="1.0922" shape="long" rot="R270"/>
<pad name="5" x="-10.16" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="6" x="-7.62" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="7" x="-5.08" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="8" x="-2.54" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="9" x="0" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="10" x="2.54" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="11" x="5.08" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="12" x="7.62" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="13" x="10.16" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="14" x="12.7" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="15" x="15.24" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="16" x="17.78" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="17" x="20.32" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<text x="-23.1775" y="-5.715" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="24.4475" y="-5.715" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-20.6375" y1="-7.62" x2="-20.0025" y2="-6.35" layer="51"/>
<rectangle x1="-15.5575" y1="-7.62" x2="-14.9225" y2="-6.35" layer="51"/>
<rectangle x1="-7.9375" y1="-7.62" x2="-7.3025" y2="-6.35" layer="51"/>
<rectangle x1="20.0025" y1="-7.62" x2="20.6375" y2="-6.35" layer="51"/>
<rectangle x1="7.3025" y1="-7.62" x2="7.9375" y2="-6.35" layer="51"/>
<rectangle x1="14.9225" y1="-7.62" x2="15.5575" y2="-6.35" layer="51"/>
<polygon width="0.0508" layer="21">
<vertex x="-22.225" y="5.8737"/>
<vertex x="-21.7487" y="3.9688"/>
<vertex x="-21.2725" y="5.8737"/>
</polygon>
</package>
<package name="70543-18">
 vertical, 18 pin</description>
<wire x1="24.13" y1="-2.8575" x2="24.13" y2="2.8575" width="0.254" layer="21"/>
<wire x1="24.13" y1="2.8575" x2="-24.13" y2="2.8575" width="0.254" layer="21"/>
<wire x1="-24.13" y1="2.8575" x2="-24.13" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-24.13" y1="-2.8575" x2="-3.4925" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="3.4925" y1="-2.8575" x2="24.13" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-23.495" y1="2.2225" x2="-23.495" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="23.495" y1="2.2225" x2="23.495" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="-23.495" y1="2.2225" x2="23.495" y2="2.2225" width="0.0508" layer="51"/>
<wire x1="-23.495" y1="-2.2225" x2="-2.8575" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-2.2225" x2="23.495" y2="-2.2225" width="0.0508" layer="51"/>
<pad name="3" x="-16.51" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-19.05" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="-21.59" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-13.97" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="15" x="13.97" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="16" x="16.51" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="17" x="19.05" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="18" x="21.59" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-24.765" y="-2.54" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="-23.8125" y="3.4925" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-23.1775" y="-1.5875" size="1.016" layer="51" ratio="10">1</text>
<rectangle x1="-21.8281" y1="-0.2381" x2="-21.3519" y2="0.2381" layer="51"/>
<rectangle x1="-16.7481" y1="-0.2381" x2="-16.2719" y2="0.2381" layer="51"/>
<rectangle x1="-9.1281" y1="-0.2381" x2="-8.6519" y2="0.2381" layer="51"/>
<rectangle x1="-11.6681" y1="-0.2381" x2="-11.1919" y2="0.2381" layer="51"/>
<rectangle x1="1.0319" y1="-0.2381" x2="1.5081" y2="0.2381" layer="51"/>
<rectangle x1="-1.5081" y1="-0.2381" x2="-1.0319" y2="0.2381" layer="51"/>
<rectangle x1="8.6519" y1="-0.2381" x2="9.1281" y2="0.2381" layer="51"/>
<rectangle x1="11.1919" y1="-0.2381" x2="11.6681" y2="0.2381" layer="51"/>
<rectangle x1="16.2719" y1="-0.2381" x2="16.7481" y2="0.2381" layer="51"/>
<rectangle x1="21.3519" y1="-0.2381" x2="21.8281" y2="0.2381" layer="51"/>
</package>
<package name="70553-18">
 right angle, 18 pin</description>
<wire x1="23.9713" y1="5.8738" x2="4.1275" y2="5.8738" width="0.254" layer="21"/>
<wire x1="4.1275" y1="5.8738" x2="-23.9713" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-23.9713" y1="5.8738" x2="-23.9713" y2="-5.715" width="0.254" layer="21"/>
<wire x1="-23.9713" y1="-5.715" x2="23.9713" y2="-5.715" width="0.254" layer="21"/>
<wire x1="23.9713" y1="-5.715" x2="23.9713" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-22.225" y1="-6.35" x2="-20.955" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-20.955" y1="-6.35" x2="-19.685" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-20.955" y1="-7.6835" x2="-20.701" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-19.939" y1="-7.9375" x2="-20.701" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-17.145" y1="-7.6835" x2="-17.399" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-17.145" y1="-6.35" x2="-15.875" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-15.875" y1="-6.35" x2="-14.605" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-15.875" y1="-7.6835" x2="-15.621" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-14.859" y1="-7.9375" x2="-15.621" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-9.525" y1="-7.6835" x2="-9.779" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-9.525" y1="-6.35" x2="-8.255" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-8.255" y1="-6.35" x2="-6.985" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-8.255" y1="-7.6835" x2="-8.001" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-7.239" y1="-7.9375" x2="-8.001" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="10.795" y1="-6.35" x2="14.605" y2="-6.35" width="0.254" layer="51"/>
<wire x1="14.605" y1="-6.35" x2="15.875" y2="-6.35" width="0.254" layer="51"/>
<wire x1="15.875" y1="-6.35" x2="17.145" y2="-6.35" width="0.127" layer="51"/>
<wire x1="19.685" y1="-6.35" x2="20.955" y2="-6.35" width="0.254" layer="51"/>
<wire x1="20.955" y1="-6.35" x2="22.225" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-23.1775" y1="-5.715" x2="-23.1775" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-22.225" y1="-6.35" x2="-22.225" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-22.225" y1="-7.6835" x2="-22.479" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-22.479" y1="-7.9375" x2="-23.1775" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="22.225" y1="-6.35" x2="22.225" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="22.225" y1="-7.6835" x2="22.479" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="22.479" y1="-7.9375" x2="23.1775" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="23.1775" y1="-7.9375" x2="23.1775" y2="-6.35" width="0.254" layer="51"/>
<wire x1="23.1775" y1="-6.35" x2="23.1775" y2="-5.715" width="0.254" layer="51"/>
<wire x1="22.225" y1="-6.35" x2="23.1775" y2="-6.35" width="0.254" layer="51"/>
<wire x1="8.255" y1="-6.35" x2="9.525" y2="-6.35" width="0.127" layer="51"/>
<wire x1="9.525" y1="-7.6835" x2="9.779" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="8.255" y1="-7.6835" x2="8.001" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="8.001" y1="-7.9375" x2="7.239" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="14.859" y1="-7.9375" x2="15.621" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="15.621" y1="-7.9375" x2="15.875" y2="-7.6835" width="0.254" layer="51" curve="90"/>
<wire x1="15.875" y1="-7.6835" x2="15.875" y2="-6.35" width="0.254" layer="51"/>
<wire x1="19.939" y1="-7.9375" x2="20.701" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="20.701" y1="-7.9375" x2="20.955" y2="-7.6835" width="0.254" layer="51" curve="90"/>
<wire x1="20.955" y1="-7.6835" x2="20.955" y2="-6.35" width="0.254" layer="51"/>
<wire x1="17.145" y1="-6.35" x2="17.145" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="17.145" y1="-7.6835" x2="17.399" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<pad name="2" x="-19.05" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="1" x="-21.59" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="3" x="-16.51" y="-7.62" drill="1.0922" shape="long" rot="R270"/>
<pad name="4" x="-13.97" y="-7.62" drill="1.0922" shape="long" rot="R270"/>
<pad name="5" x="-11.43" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="6" x="-8.89" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="7" x="-6.35" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="8" x="-3.81" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="9" x="-1.27" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="10" x="1.27" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="11" x="3.81" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="12" x="6.35" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="13" x="8.89" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="14" x="11.43" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="15" x="13.97" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="16" x="16.51" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="17" x="19.05" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="18" x="21.59" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<text x="-24.4475" y="-5.715" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="25.7175" y="-5.715" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-21.9075" y1="-7.62" x2="-21.2725" y2="-6.35" layer="51"/>
<rectangle x1="-16.8275" y1="-7.62" x2="-16.1925" y2="-6.35" layer="51"/>
<rectangle x1="-9.2075" y1="-7.62" x2="-8.5725" y2="-6.35" layer="51"/>
<rectangle x1="21.2725" y1="-7.62" x2="21.9075" y2="-6.35" layer="51"/>
<rectangle x1="8.5725" y1="-7.62" x2="9.2075" y2="-6.35" layer="51"/>
<rectangle x1="16.1925" y1="-7.62" x2="16.8275" y2="-6.35" layer="51"/>
<vertex x="-23.495" y="5.8737"/>
<vertex x="-23.0187" y="3.9688"/>
<vertex x="-22.5425" y="5.8737"/>
</polygon>
</package>
<package name="70543-19">
 vertical, 19 pin</description>
<wire x1="25.4" y1="-2.8575" x2="25.4" y2="2.8575" width="0.254" layer="21"/>
<wire x1="25.4" y1="2.8575" x2="-25.4" y2="2.8575" width="0.254" layer="21"/>
<wire x1="-25.4" y1="2.8575" x2="-25.4" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-25.4" y1="-2.8575" x2="-3.4925" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="3.4925" y1="-2.8575" x2="25.4" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-24.765" y1="2.2225" x2="-24.765" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="24.765" y1="2.2225" x2="24.765" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="-24.765" y1="2.2225" x2="24.765" y2="2.2225" width="0.0508" layer="51"/>
<wire x1="-24.765" y1="-2.2225" x2="-2.8575" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-2.2225" x2="24.765" y2="-2.2225" width="0.0508" layer="51"/>
<pad name="3" x="-17.78" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-20.32" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="-22.86" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-15.24" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-12.7" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="-5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="15" x="12.7" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="16" x="15.24" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="17" x="17.78" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="18" x="20.32" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="19" x="22.86" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-26.035" y="-2.54" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="-25.0825" y="3.4925" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-24.4475" y="-1.5875" size="1.016" layer="51" ratio="10">1</text>
<rectangle x1="-23.0981" y1="-0.2381" x2="-22.6219" y2="0.2381" layer="51"/>
<rectangle x1="-18.0181" y1="-0.2381" x2="-17.5419" y2="0.2381" layer="51"/>
<rectangle x1="-12.9381" y1="-0.2381" x2="-12.4619" y2="0.2381" layer="51"/>
<rectangle x1="-0.2381" y1="-0.2381" x2="0.2381" y2="0.2381" layer="51"/>
<rectangle x1="-2.7781" y1="-0.2381" x2="-2.3019" y2="0.2381" layer="51"/>
<rectangle x1="2.3019" y1="-0.2381" x2="2.7781" y2="0.2381" layer="51"/>
<rectangle x1="12.4619" y1="-0.2381" x2="12.9381" y2="0.2381" layer="51"/>
<rectangle x1="17.5419" y1="-0.2381" x2="18.0181" y2="0.2381" layer="51"/>
<rectangle x1="22.6219" y1="-0.2381" x2="23.0981" y2="0.2381" layer="51"/>
</package>
<package name="70553-19">
 right angle, 19 pin</description>
<wire x1="25.2413" y1="5.8738" x2="4.1275" y2="5.8738" width="0.254" layer="21"/>
<wire x1="4.1275" y1="5.8738" x2="-25.2413" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-25.2413" y1="5.8738" x2="-25.2413" y2="-5.715" width="0.254" layer="21"/>
<wire x1="-25.2413" y1="-5.715" x2="25.2413" y2="-5.715" width="0.254" layer="21"/>
<wire x1="25.2413" y1="-5.715" x2="25.2413" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-4.1275" y1="5.8737" x2="-4.1275" y2="2.54" width="0.254" layer="21"/>
<wire x1="-4.1275" y1="2.54" x2="-3.175" y2="2.54" width="0.254" layer="21"/>
<wire x1="3.175" y1="2.54" x2="4.1275" y2="2.54" width="0.254" layer="21"/>
<wire x1="4.1275" y1="2.54" x2="4.1275" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-23.495" y1="-6.35" x2="-22.225" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-22.225" y1="-6.35" x2="-20.955" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-22.225" y1="-7.6835" x2="-21.971" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-21.209" y1="-7.9375" x2="-21.971" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-18.415" y1="-6.35" x2="-18.415" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-18.415" y1="-7.6835" x2="-18.669" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-18.415" y1="-6.35" x2="-17.145" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-17.145" y1="-6.35" x2="-15.875" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-17.145" y1="-7.6835" x2="-16.891" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-16.129" y1="-7.9375" x2="-16.891" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-13.335" y1="-6.35" x2="-12.065" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-12.065" y1="-6.35" x2="-10.795" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-12.065" y1="-6.35" x2="-12.065" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-12.065" y1="-7.6835" x2="-11.811" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-10.795" y1="-7.6835" x2="-11.049" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-11.049" y1="-7.9375" x2="-11.811" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-10.795" y1="-6.35" x2="-9.525" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-9.525" y1="-6.35" x2="-8.255" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-9.525" y1="-7.6835" x2="-9.271" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-8.509" y1="-7.9375" x2="-9.271" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-5.715" y1="-6.35" x2="-4.445" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-4.445" y1="-6.35" x2="-3.175" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-4.445" y1="-6.35" x2="-4.445" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-4.445" y1="-7.6835" x2="-4.191" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-3.175" y1="-6.35" x2="-3.175" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-3.175" y1="-7.6835" x2="-3.429" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-3.429" y1="-7.9375" x2="-4.191" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-3.175" y1="-6.35" x2="-1.905" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-1.905" y1="-6.35" x2="-0.635" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-1.905" y1="-7.6835" x2="-1.651" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-0.635" y1="-7.6835" x2="-0.889" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-0.889" y1="-7.9375" x2="-1.651" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-0.635" y1="-6.35" x2="0.635" y2="-6.35" width="0.127" layer="51"/>
<wire x1="0.635" y1="-6.35" x2="1.905" y2="-6.35" width="0.254" layer="51"/>
<wire x1="0.635" y1="-7.6835" x2="0.889" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="1.905" y1="-7.6835" x2="1.651" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="1.651" y1="-7.9375" x2="0.889" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="9.525" y1="-6.35" x2="13.335" y2="-6.35" width="0.254" layer="51"/>
<wire x1="13.335" y1="-6.35" x2="14.605" y2="-6.35" width="0.254" layer="51"/>
<wire x1="14.605" y1="-6.35" x2="15.875" y2="-6.35" width="0.127" layer="51"/>
<wire x1="20.955" y1="-6.35" x2="22.225" y2="-6.35" width="0.254" layer="51"/>
<wire x1="22.225" y1="-6.35" x2="23.495" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-24.4475" y1="-5.715" x2="-24.4475" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-23.495" y1="-6.35" x2="-23.495" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-23.495" y1="-7.6835" x2="-23.749" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-23.749" y1="-7.9375" x2="-24.4475" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="23.495" y1="-6.35" x2="23.495" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="23.495" y1="-7.6835" x2="23.749" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="23.749" y1="-7.9375" x2="24.4475" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="24.4475" y1="-7.9375" x2="24.4475" y2="-6.35" width="0.254" layer="51"/>
<wire x1="24.4475" y1="-6.35" x2="24.4475" y2="-5.715" width="0.254" layer="51"/>
<wire x1="23.495" y1="-6.35" x2="24.4475" y2="-6.35" width="0.254" layer="51"/>
<wire x1="1.905" y1="-6.35" x2="3.175" y2="-6.35" width="0.127" layer="51"/>
<wire x1="3.175" y1="-6.35" x2="4.445" y2="-6.35" width="0.254" layer="51"/>
<wire x1="3.175" y1="-6.35" x2="3.175" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="3.175" y1="-7.6835" x2="3.429" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="4.445" y1="-6.35" x2="4.445" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="4.445" y1="-7.6835" x2="4.191" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="4.191" y1="-7.9375" x2="3.429" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="6.985" y1="-6.35" x2="8.255" y2="-6.35" width="0.127" layer="51"/>
<wire x1="8.255" y1="-6.35" x2="9.525" y2="-6.35" width="0.254" layer="51"/>
<wire x1="9.525" y1="-7.6835" x2="9.271" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="9.271" y1="-7.9375" x2="8.509" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="5.715" y1="-6.35" x2="5.715" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="5.715" y1="-7.6835" x2="5.969" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="10.795" y1="-7.6835" x2="11.049" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="12.065" y1="-6.35" x2="12.065" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="12.065" y1="-7.6835" x2="11.811" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="11.811" y1="-7.9375" x2="11.049" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="13.335" y1="-6.35" x2="13.335" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="13.335" y1="-7.6835" x2="13.589" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="13.589" y1="-7.9375" x2="14.351" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="14.351" y1="-7.9375" x2="14.605" y2="-7.6835" width="0.254" layer="51" curve="90"/>
<wire x1="14.605" y1="-7.6835" x2="14.605" y2="-6.35" width="0.254" layer="51"/>
<wire x1="21.209" y1="-7.9375" x2="21.971" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="21.971" y1="-7.9375" x2="22.225" y2="-7.6835" width="0.254" layer="51" curve="90"/>
<wire x1="22.225" y1="-7.6835" x2="22.225" y2="-6.35" width="0.254" layer="51"/>
<wire x1="18.415" y1="-6.35" x2="18.415" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="18.415" y1="-7.6835" x2="18.669" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<pad name="2" x="-20.32" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="1" x="-22.86" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="3" x="-17.78" y="-7.62" drill="1.0922" shape="long" rot="R270"/>
<pad name="4" x="-15.24" y="-7.62" drill="1.0922" shape="long" rot="R270"/>
<pad name="5" x="-12.7" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="6" x="-10.16" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="7" x="-7.62" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="8" x="-5.08" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="9" x="-2.54" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="10" x="0" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="11" x="2.54" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="12" x="5.08" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="13" x="7.62" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="14" x="10.16" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="15" x="12.7" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="16" x="15.24" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="17" x="17.78" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="18" x="20.32" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="19" x="22.86" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<text x="-25.7175" y="-5.715" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="26.9875" y="-5.715" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-23.1775" y1="-7.62" x2="-22.5425" y2="-6.35" layer="51"/>
<rectangle x1="-18.0975" y1="-7.62" x2="-17.4625" y2="-6.35" layer="51"/>
<rectangle x1="-13.0175" y1="-7.62" x2="-12.3825" y2="-6.35" layer="51"/>
<rectangle x1="-10.4775" y1="-7.62" x2="-9.8425" y2="-6.35" layer="51"/>
<rectangle x1="-5.3975" y1="-7.62" x2="-4.7625" y2="-6.35" layer="51"/>
<rectangle x1="-2.8575" y1="-7.62" x2="-2.2225" y2="-6.35" layer="51"/>
<rectangle x1="-0.3175" y1="-7.62" x2="0.3175" y2="-6.35" layer="51"/>
<rectangle x1="22.5425" y1="-7.62" x2="23.1775" y2="-6.35" layer="51"/>
<rectangle x1="2.2225" y1="-7.62" x2="2.8575" y2="-6.35" layer="51"/>
<rectangle x1="4.7625" y1="-7.62" x2="5.3975" y2="-6.35" layer="51"/>
<rectangle x1="9.8425" y1="-7.62" x2="10.4775" y2="-6.35" layer="51"/>
<rectangle x1="12.3825" y1="-7.62" x2="13.0175" y2="-6.35" layer="51"/>
<rectangle x1="17.4625" y1="-7.62" x2="18.0975" y2="-6.35" layer="51"/>
<vertex x="-24.765" y="5.8737"/>
<vertex x="-24.2887" y="3.9688"/>
<vertex x="-23.8125" y="5.8737"/>
</polygon>
</package>
<package name="70543-20">
 vertical, 20 pin</description>
<wire x1="26.67" y1="-2.8575" x2="26.67" y2="2.8575" width="0.254" layer="21"/>
<wire x1="26.67" y1="2.8575" x2="-26.67" y2="2.8575" width="0.254" layer="21"/>
<wire x1="-26.67" y1="2.8575" x2="-26.67" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-26.67" y1="-2.8575" x2="-3.4925" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="3.4925" y1="-2.8575" x2="26.67" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-26.035" y1="2.2225" x2="-26.035" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="26.035" y1="2.2225" x2="26.035" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="-26.035" y1="2.2225" x2="26.035" y2="2.2225" width="0.0508" layer="51"/>
<wire x1="-26.035" y1="-2.2225" x2="-2.8575" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-2.2225" x2="26.035" y2="-2.2225" width="0.0508" layer="51"/>
<pad name="3" x="-19.05" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-21.59" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="-24.13" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-16.51" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-13.97" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="-6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="15" x="11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="16" x="13.97" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="17" x="16.51" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="18" x="19.05" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="19" x="21.59" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="20" x="24.13" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-27.305" y="-2.54" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="-26.3525" y="3.4925" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-25.7175" y="-1.5875" size="1.016" layer="51" ratio="10">1</text>
<rectangle x1="-24.3681" y1="-0.2381" x2="-23.8919" y2="0.2381" layer="51"/>
<rectangle x1="23.8919" y1="-0.2381" x2="24.3681" y2="0.2381" layer="51"/>
</package>
<package name="70553-20">
 right angle, 20 pin</description>
<wire x1="26.5113" y1="5.8738" x2="4.1275" y2="5.8738" width="0.254" layer="21"/>
<wire x1="4.1275" y1="5.8738" x2="-26.5113" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-26.5113" y1="5.8738" x2="-26.5113" y2="-5.715" width="0.254" layer="21"/>
<wire x1="-26.5113" y1="-5.715" x2="26.5113" y2="-5.715" width="0.254" layer="21"/>
<wire x1="26.5113" y1="-5.715" x2="26.5113" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-24.765" y1="-6.35" x2="-23.495" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-23.495" y1="-6.35" x2="-22.225" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-23.495" y1="-7.6835" x2="-23.241" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-22.479" y1="-7.9375" x2="-23.241" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="8.255" y1="-6.35" x2="12.065" y2="-6.35" width="0.254" layer="51"/>
<wire x1="13.335" y1="-6.35" x2="14.605" y2="-6.35" width="0.127" layer="51"/>
<wire x1="22.225" y1="-6.35" x2="23.495" y2="-6.35" width="0.254" layer="51"/>
<wire x1="23.495" y1="-6.35" x2="24.765" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-25.7175" y1="-5.715" x2="-25.7175" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-24.765" y1="-6.35" x2="-24.765" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-24.765" y1="-7.6835" x2="-25.019" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-25.019" y1="-7.9375" x2="-25.7175" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="24.765" y1="-6.35" x2="24.765" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="24.765" y1="-7.6835" x2="25.019" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="25.019" y1="-7.9375" x2="25.7175" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="25.7175" y1="-7.9375" x2="25.7175" y2="-6.35" width="0.254" layer="51"/>
<wire x1="25.7175" y1="-6.35" x2="25.7175" y2="-5.715" width="0.254" layer="51"/>
<wire x1="24.765" y1="-6.35" x2="25.7175" y2="-6.35" width="0.254" layer="51"/>
<wire x1="12.319" y1="-7.9375" x2="13.081" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="13.081" y1="-7.9375" x2="13.335" y2="-7.6835" width="0.254" layer="51" curve="90"/>
<wire x1="13.335" y1="-7.6835" x2="13.335" y2="-6.35" width="0.254" layer="51"/>
<wire x1="22.479" y1="-7.9375" x2="23.241" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="23.241" y1="-7.9375" x2="23.495" y2="-7.6835" width="0.254" layer="51" curve="90"/>
<wire x1="23.495" y1="-7.6835" x2="23.495" y2="-6.35" width="0.254" layer="51"/>
<pad name="2" x="-21.59" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="1" x="-24.13" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="3" x="-19.05" y="-7.62" drill="1.0922" shape="long" rot="R270"/>
<pad name="4" x="-16.51" y="-7.62" drill="1.0922" shape="long" rot="R270"/>
<pad name="5" x="-13.97" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="6" x="-11.43" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="7" x="-8.89" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="8" x="-6.35" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="9" x="-3.81" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="10" x="-1.27" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="11" x="1.27" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="12" x="3.81" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="13" x="6.35" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="14" x="8.89" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="15" x="11.43" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="16" x="13.97" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="17" x="16.51" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="18" x="19.05" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="19" x="21.59" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="20" x="24.13" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<text x="-26.9875" y="-5.715" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="28.2575" y="-5.715" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-24.4475" y1="-7.62" x2="-23.8125" y2="-6.35" layer="51"/>
<rectangle x1="23.8125" y1="-7.62" x2="24.4475" y2="-6.35" layer="51"/>
<vertex x="-26.035" y="5.8737"/>
<vertex x="-25.5587" y="3.9688"/>
<vertex x="-25.0825" y="5.8737"/>
</polygon>
</package>
<package name="70543-21">
 vertical, 21 pin</description>
<wire x1="27.94" y1="-2.8575" x2="27.94" y2="2.8575" width="0.254" layer="21"/>
<wire x1="27.94" y1="2.8575" x2="-27.94" y2="2.8575" width="0.254" layer="21"/>
<wire x1="-27.94" y1="2.8575" x2="-27.94" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-27.94" y1="-2.8575" x2="-3.4925" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="3.4925" y1="-2.8575" x2="27.94" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-27.305" y1="2.2225" x2="-27.305" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="27.305" y1="2.2225" x2="27.305" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="-27.305" y1="2.2225" x2="27.305" y2="2.2225" width="0.0508" layer="51"/>
<wire x1="-27.305" y1="-2.2225" x2="-2.8575" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-2.2225" x2="27.305" y2="-2.2225" width="0.0508" layer="51"/>
<pad name="3" x="-20.32" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-22.86" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="-25.4" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-17.78" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-15.24" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-12.7" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="-7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="-5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="15" x="10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="16" x="12.7" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="17" x="15.24" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="18" x="17.78" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="19" x="20.32" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="20" x="22.86" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="21" x="25.4" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-28.575" y="-2.54" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="-27.6225" y="3.4925" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-26.9875" y="-1.5875" size="1.016" layer="51" ratio="10">1</text>
<rectangle x1="-25.6381" y1="-0.2381" x2="-25.1619" y2="0.2381" layer="51"/>
<rectangle x1="-5.3181" y1="-0.2381" x2="-4.8419" y2="0.2381" layer="51"/>
<rectangle x1="4.8419" y1="-0.2381" x2="5.3181" y2="0.2381" layer="51"/>
<rectangle x1="25.1619" y1="-0.2381" x2="25.6381" y2="0.2381" layer="51"/>
</package>
<package name="70553-21">
 right angle, 21 pin</description>
<wire x1="27.7813" y1="5.8738" x2="4.1275" y2="5.8738" width="0.254" layer="21"/>
<wire x1="4.1275" y1="5.8738" x2="-27.7813" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-27.7813" y1="5.8738" x2="-27.7813" y2="-5.715" width="0.254" layer="21"/>
<wire x1="-27.7813" y1="-5.715" x2="27.7813" y2="-5.715" width="0.254" layer="21"/>
<wire x1="27.7813" y1="-5.715" x2="27.7813" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-26.035" y1="-6.35" x2="-24.765" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-24.765" y1="-6.35" x2="-23.495" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-24.765" y1="-7.6835" x2="-24.511" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-23.749" y1="-7.9375" x2="-24.511" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-14.605" y1="-6.35" x2="-14.605" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-13.335" y1="-6.35" x2="-13.335" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-6.985" y1="-6.35" x2="-6.985" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-5.715" y1="-6.35" x2="-5.715" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="6.985" y1="-6.35" x2="10.795" y2="-6.35" width="0.254" layer="51"/>
<wire x1="10.795" y1="-6.35" x2="12.065" y2="-6.35" width="0.254" layer="51"/>
<wire x1="12.065" y1="-6.35" x2="13.335" y2="-6.35" width="0.127" layer="51"/>
<wire x1="23.495" y1="-6.35" x2="24.765" y2="-6.35" width="0.254" layer="51"/>
<wire x1="24.765" y1="-6.35" x2="26.035" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-26.9875" y1="-5.715" x2="-26.9875" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-26.035" y1="-6.35" x2="-26.035" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-26.035" y1="-7.6835" x2="-26.289" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-26.289" y1="-7.9375" x2="-26.9875" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="26.035" y1="-6.35" x2="26.035" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="26.035" y1="-7.6835" x2="26.289" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="26.289" y1="-7.9375" x2="26.9875" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="26.9875" y1="-7.9375" x2="26.9875" y2="-6.35" width="0.254" layer="51"/>
<wire x1="26.9875" y1="-6.35" x2="26.9875" y2="-5.715" width="0.254" layer="51"/>
<wire x1="26.035" y1="-6.35" x2="26.9875" y2="-6.35" width="0.254" layer="51"/>
<wire x1="4.445" y1="-6.35" x2="5.715" y2="-6.35" width="0.127" layer="51"/>
<wire x1="6.985" y1="-6.35" x2="6.985" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="1.905" y1="-6.35" x2="3.175" y2="-6.35" width="0.254" layer="51"/>
<wire x1="11.049" y1="-7.9375" x2="11.811" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="11.811" y1="-7.9375" x2="12.065" y2="-7.6835" width="0.254" layer="51" curve="90"/>
<wire x1="12.065" y1="-7.6835" x2="12.065" y2="-6.35" width="0.254" layer="51"/>
<wire x1="23.749" y1="-7.9375" x2="24.511" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="24.511" y1="-7.9375" x2="24.765" y2="-7.6835" width="0.254" layer="51" curve="90"/>
<wire x1="24.765" y1="-7.6835" x2="24.765" y2="-6.35" width="0.254" layer="51"/>
<pad name="2" x="-22.86" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="1" x="-25.4" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="3" x="-20.32" y="-7.62" drill="1.0922" shape="long" rot="R270"/>
<pad name="4" x="-17.78" y="-7.62" drill="1.0922" shape="long" rot="R270"/>
<pad name="5" x="-15.24" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="6" x="-12.7" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="7" x="-10.16" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="8" x="-7.62" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="9" x="-5.08" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="10" x="-2.54" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="11" x="0" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="12" x="2.54" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="13" x="5.08" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="14" x="7.62" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="15" x="10.16" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="16" x="12.7" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="17" x="15.24" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="18" x="17.78" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="19" x="20.32" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="20" x="22.86" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="21" x="25.4" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<text x="-28.2575" y="-5.715" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="29.5275" y="-5.715" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-25.7175" y1="-7.62" x2="-25.0825" y2="-6.35" layer="51"/>
<rectangle x1="25.0825" y1="-7.62" x2="25.7175" y2="-6.35" layer="51"/>
<vertex x="-27.305" y="5.8737"/>
<vertex x="-26.8287" y="3.9688"/>
<vertex x="-26.3525" y="5.8737"/>
</polygon>
</package>
<package name="70543-22">
 vertical, 22 pin</description>
<wire x1="29.21" y1="-2.8575" x2="29.21" y2="2.8575" width="0.254" layer="21"/>
<wire x1="29.21" y1="2.8575" x2="-29.21" y2="2.8575" width="0.254" layer="21"/>
<wire x1="-29.21" y1="2.8575" x2="-29.21" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-29.21" y1="-2.8575" x2="-3.4925" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="3.4925" y1="-2.8575" x2="29.21" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-28.575" y1="2.2225" x2="-28.575" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="28.575" y1="2.2225" x2="28.575" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="-28.575" y1="2.2225" x2="28.575" y2="2.2225" width="0.0508" layer="51"/>
<wire x1="-28.575" y1="-2.2225" x2="-2.8575" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-2.2225" x2="28.575" y2="-2.2225" width="0.0508" layer="51"/>
<pad name="3" x="-21.59" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-24.13" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="-26.67" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-19.05" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-16.51" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-13.97" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="-8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="-6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="15" x="8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="16" x="11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="17" x="13.97" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="18" x="16.51" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="19" x="19.05" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="20" x="21.59" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="21" x="24.13" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="22" x="26.67" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-29.845" y="-2.54" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="-28.8925" y="3.4925" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-28.2575" y="-1.5875" size="1.016" layer="51" ratio="10">1</text>
<rectangle x1="-26.9081" y1="-0.2381" x2="-26.4319" y2="0.2381" layer="51"/>
<rectangle x1="-19.2881" y1="-0.2381" x2="-18.8119" y2="0.2381" layer="51"/>
<rectangle x1="-14.2081" y1="-0.2381" x2="-13.7319" y2="0.2381" layer="51"/>
<rectangle x1="-4.0481" y1="-0.2381" x2="-3.5719" y2="0.2381" layer="51"/>
<rectangle x1="-6.5881" y1="-0.2381" x2="-6.1119" y2="0.2381" layer="51"/>
<rectangle x1="3.5719" y1="-0.2381" x2="4.0481" y2="0.2381" layer="51"/>
<rectangle x1="6.1119" y1="-0.2381" x2="6.5881" y2="0.2381" layer="51"/>
<rectangle x1="13.7319" y1="-0.2381" x2="14.2081" y2="0.2381" layer="51"/>
<rectangle x1="18.8119" y1="-0.2381" x2="19.2881" y2="0.2381" layer="51"/>
<rectangle x1="26.4319" y1="-0.2381" x2="26.9081" y2="0.2381" layer="51"/>
</package>
<package name="70553-22">
 right angle, 22 pin</description>
<wire x1="29.0513" y1="5.8738" x2="4.1275" y2="5.8738" width="0.254" layer="21"/>
<wire x1="4.1275" y1="5.8738" x2="-29.0513" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-29.0513" y1="5.8738" x2="-29.0513" y2="-5.715" width="0.254" layer="21"/>
<wire x1="-29.0513" y1="-5.715" x2="29.0513" y2="-5.715" width="0.254" layer="21"/>
<wire x1="29.0513" y1="-5.715" x2="29.0513" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-27.305" y1="-6.35" x2="-26.035" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-26.035" y1="-6.35" x2="-24.765" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-26.035" y1="-7.6835" x2="-25.781" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-25.019" y1="-7.9375" x2="-25.781" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-19.685" y1="-6.35" x2="-19.685" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-19.685" y1="-7.6835" x2="-19.939" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-19.685" y1="-6.35" x2="-18.415" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-18.415" y1="-6.35" x2="-17.145" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-18.415" y1="-7.6835" x2="-18.161" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-17.399" y1="-7.9375" x2="-18.161" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-14.605" y1="-7.6835" x2="-14.859" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-14.605" y1="-6.35" x2="-13.335" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-13.335" y1="-6.35" x2="-12.065" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-13.335" y1="-7.6835" x2="-13.081" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-12.065" y1="-7.6835" x2="-12.319" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-12.319" y1="-7.9375" x2="-13.081" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-12.065" y1="-6.35" x2="-10.795" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-10.795" y1="-6.35" x2="-9.525" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-10.795" y1="-7.6835" x2="-10.541" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-9.779" y1="-7.9375" x2="-10.541" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-6.985" y1="-7.6835" x2="-7.239" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-6.985" y1="-6.35" x2="-5.715" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-5.715" y1="-6.35" x2="-4.445" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-5.715" y1="-7.6835" x2="-5.461" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-4.445" y1="-7.6835" x2="-4.699" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-4.699" y1="-7.9375" x2="-5.461" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-4.445" y1="-6.35" x2="-3.175" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-3.175" y1="-6.35" x2="-1.905" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-3.175" y1="-7.6835" x2="-2.921" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-1.905" y1="-7.6835" x2="-2.159" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-2.159" y1="-7.9375" x2="-2.921" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="5.715" y1="-6.35" x2="9.525" y2="-6.35" width="0.254" layer="51"/>
<wire x1="9.525" y1="-6.35" x2="10.795" y2="-6.35" width="0.254" layer="51"/>
<wire x1="10.795" y1="-6.35" x2="12.065" y2="-6.35" width="0.127" layer="51"/>
<wire x1="12.065" y1="-6.35" x2="13.335" y2="-6.35" width="0.254" layer="51"/>
<wire x1="17.145" y1="-6.35" x2="18.415" y2="-6.35" width="0.254" layer="51"/>
<wire x1="18.415" y1="-6.35" x2="19.685" y2="-6.35" width="0.127" layer="51"/>
<wire x1="24.765" y1="-6.35" x2="26.035" y2="-6.35" width="0.254" layer="51"/>
<wire x1="26.035" y1="-6.35" x2="27.305" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-28.2575" y1="-5.715" x2="-28.2575" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-27.305" y1="-6.35" x2="-27.305" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-27.305" y1="-7.6835" x2="-27.559" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-27.559" y1="-7.9375" x2="-28.2575" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="27.305" y1="-6.35" x2="27.305" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="27.305" y1="-7.6835" x2="27.559" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="27.559" y1="-7.9375" x2="28.2575" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="28.2575" y1="-7.9375" x2="28.2575" y2="-6.35" width="0.254" layer="51"/>
<wire x1="28.2575" y1="-6.35" x2="28.2575" y2="-5.715" width="0.254" layer="51"/>
<wire x1="27.305" y1="-6.35" x2="28.2575" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-1.905" y1="-6.35" x2="-0.635" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-0.635" y1="-6.35" x2="0.635" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-0.635" y1="-7.6835" x2="-0.381" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="0.635" y1="-7.6835" x2="0.381" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="0.381" y1="-7.9375" x2="-0.381" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="3.175" y1="-6.35" x2="4.445" y2="-6.35" width="0.127" layer="51"/>
<wire x1="4.445" y1="-6.35" x2="5.715" y2="-6.35" width="0.254" layer="51"/>
<wire x1="4.445" y1="-7.6835" x2="4.699" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="5.715" y1="-7.6835" x2="5.461" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="5.461" y1="-7.9375" x2="4.699" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="1.905" y1="-7.6835" x2="2.159" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="3.175" y1="-7.6835" x2="2.921" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="2.921" y1="-7.9375" x2="2.159" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="6.985" y1="-7.6835" x2="7.239" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="9.779" y1="-7.9375" x2="10.541" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="10.541" y1="-7.9375" x2="10.795" y2="-7.6835" width="0.254" layer="51" curve="90"/>
<wire x1="10.795" y1="-7.6835" x2="10.795" y2="-6.35" width="0.254" layer="51"/>
<wire x1="17.399" y1="-7.9375" x2="18.161" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="18.161" y1="-7.9375" x2="18.415" y2="-7.6835" width="0.254" layer="51" curve="90"/>
<wire x1="18.415" y1="-7.6835" x2="18.415" y2="-6.35" width="0.254" layer="51"/>
<wire x1="12.065" y1="-7.6835" x2="12.319" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="14.605" y1="-6.35" x2="14.605" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="14.605" y1="-7.6835" x2="14.859" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="25.019" y1="-7.9375" x2="25.781" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="25.781" y1="-7.9375" x2="26.035" y2="-7.6835" width="0.254" layer="51" curve="90"/>
<wire x1="26.035" y1="-7.6835" x2="26.035" y2="-6.35" width="0.254" layer="51"/>
<wire x1="19.685" y1="-6.35" x2="19.685" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="19.685" y1="-7.6835" x2="19.939" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<pad name="2" x="-24.13" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="1" x="-26.67" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="3" x="-21.59" y="-7.62" drill="1.0922" shape="long" rot="R270"/>
<pad name="4" x="-19.05" y="-7.62" drill="1.0922" shape="long" rot="R270"/>
<pad name="5" x="-16.51" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="6" x="-13.97" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="7" x="-11.43" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="8" x="-8.89" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="9" x="-6.35" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="10" x="-3.81" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="11" x="-1.27" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="12" x="1.27" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="13" x="3.81" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="14" x="6.35" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="15" x="8.89" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="16" x="11.43" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="17" x="13.97" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="18" x="16.51" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="19" x="19.05" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="20" x="21.59" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="21" x="24.13" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="22" x="26.67" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<text x="-29.5275" y="-5.715" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="30.7975" y="-5.715" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-26.9875" y1="-7.62" x2="-26.3525" y2="-6.35" layer="51"/>
<rectangle x1="-19.3675" y1="-7.62" x2="-18.7325" y2="-6.35" layer="51"/>
<rectangle x1="-14.2875" y1="-7.62" x2="-13.6525" y2="-6.35" layer="51"/>
<rectangle x1="-11.7475" y1="-7.62" x2="-11.1125" y2="-6.35" layer="51"/>
<rectangle x1="-6.6675" y1="-7.62" x2="-6.0325" y2="-6.35" layer="51"/>
<rectangle x1="-4.1275" y1="-7.62" x2="-3.4925" y2="-6.35" layer="51"/>
<rectangle x1="26.3525" y1="-7.62" x2="26.9875" y2="-6.35" layer="51"/>
<rectangle x1="-1.5875" y1="-7.62" x2="-0.9525" y2="-6.35" layer="51"/>
<rectangle x1="0.9525" y1="-7.62" x2="1.5875" y2="-6.35" layer="51"/>
<rectangle x1="3.4925" y1="-7.62" x2="4.1275" y2="-6.35" layer="51"/>
<rectangle x1="6.0325" y1="-7.62" x2="6.6675" y2="-6.35" layer="51"/>
<rectangle x1="11.1125" y1="-7.62" x2="11.7475" y2="-6.35" layer="51"/>
<rectangle x1="13.6525" y1="-7.62" x2="14.2875" y2="-6.35" layer="51"/>
<rectangle x1="18.7325" y1="-7.62" x2="19.3675" y2="-6.35" layer="51"/>
<vertex x="-28.575" y="5.8737"/>
<vertex x="-28.0987" y="3.9688"/>
<vertex x="-27.6225" y="5.8737"/>
</polygon>
</package>
<package name="70543-23">
<description>&lt;b&gt;C-Grid SL Connector&lt;/b&gt;&lt;p&gt;
 vertical, 23 pin</description>
<wire x1="30.48" y1="-2.8575" x2="30.48" y2="2.8575" width="0.254" layer="21"/>
<wire x1="30.48" y1="2.8575" x2="-30.48" y2="2.8575" width="0.254" layer="21"/>
<wire x1="-30.48" y1="2.8575" x2="-30.48" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-30.48" y1="-2.8575" x2="-3.4925" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-3.4925" y1="-2.8575" x2="-3.4925" y2="-3.81" width="0.254" layer="21"/>
<wire x1="-3.4925" y1="-3.81" x2="3.4925" y2="-3.81" width="0.254" layer="21"/>
<wire x1="3.4925" y1="-3.81" x2="3.4925" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="3.4925" y1="-2.8575" x2="30.48" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-29.845" y1="2.2225" x2="-29.845" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="29.845" y1="2.2225" x2="29.845" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="-29.845" y1="2.2225" x2="29.845" y2="2.2225" width="0.0508" layer="51"/>
<wire x1="-29.845" y1="-2.2225" x2="-2.8575" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="-2.8575" y1="-2.2225" x2="2.8575" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-2.2225" x2="29.845" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-3.175" x2="-2.8575" y2="-3.175" width="0.0508" layer="51"/>
<wire x1="-2.8575" y1="-2.2225" x2="-2.8575" y2="-3.175" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-2.2225" x2="2.8575" y2="-3.175" width="0.0508" layer="51"/>
<pad name="3" x="-22.86" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-25.4" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="-27.94" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-20.32" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-17.78" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-15.24" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-12.7" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="-10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="-7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="-5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="15" x="7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="16" x="10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="17" x="12.7" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="18" x="15.24" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="19" x="17.78" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="20" x="20.32" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="21" x="22.86" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="22" x="25.4" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="23" x="27.94" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-31.115" y="-2.54" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="-30.1625" y="3.4925" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-29.5275" y="-1.5875" size="1.016" layer="51" ratio="10">1</text>
<rectangle x1="-28.1781" y1="-0.2381" x2="-27.7019" y2="0.2381" layer="51"/>
<rectangle x1="-20.5581" y1="-0.2381" x2="-20.0819" y2="0.2381" layer="51"/>
<rectangle x1="-15.4781" y1="-0.2381" x2="-15.0019" y2="0.2381" layer="51"/>
<rectangle x1="-10.3981" y1="-0.2381" x2="-9.9219" y2="0.2381" layer="51"/>
<rectangle x1="-7.8581" y1="-0.2381" x2="-7.3819" y2="0.2381" layer="51"/>
<rectangle x1="7.3819" y1="-0.2381" x2="7.8581" y2="0.2381" layer="51"/>
<rectangle x1="9.9219" y1="-0.2381" x2="10.3981" y2="0.2381" layer="51"/>
<rectangle x1="15.0019" y1="-0.2381" x2="15.4781" y2="0.2381" layer="51"/>
<rectangle x1="20.0819" y1="-0.2381" x2="20.5581" y2="0.2381" layer="51"/>
<rectangle x1="27.7019" y1="-0.2381" x2="28.1781" y2="0.2381" layer="51"/>
</package>
<package name="70553-23">
 right angle, 23 pin</description>
<wire x1="30.3213" y1="5.8738" x2="4.1275" y2="5.8738" width="0.254" layer="21"/>
<wire x1="4.1275" y1="5.8738" x2="-30.3213" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-30.3213" y1="5.8738" x2="-30.3213" y2="-5.715" width="0.254" layer="21"/>
<wire x1="-30.3213" y1="-5.715" x2="30.3213" y2="-5.715" width="0.254" layer="21"/>
<wire x1="30.3213" y1="-5.715" x2="30.3213" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-1.27" y1="2.54" x2="-1.27" y2="-3.175" width="0.254" layer="21"/>
<wire x1="-1.27" y1="-3.175" x2="1.27" y2="-3.175" width="0.254" layer="21"/>
<wire x1="1.27" y1="-3.175" x2="1.27" y2="2.54" width="0.254" layer="21"/>
<wire x1="-3.175" y1="2.54" x2="-1.27" y2="2.54" width="0.254" layer="21"/>
<wire x1="1.27" y1="2.54" x2="3.175" y2="2.54" width="0.254" layer="21"/>
<wire x1="-3.175" y1="2.54" x2="-3.175" y2="3.175" width="0.254" layer="21"/>
<wire x1="-3.175" y1="3.175" x2="-1.905" y2="4.445" width="0.254" layer="21" curve="-90"/>
<wire x1="-1.905" y1="4.445" x2="1.905" y2="4.445" width="0.254" layer="21"/>
<wire x1="1.905" y1="4.445" x2="3.175" y2="3.175" width="0.254" layer="21" curve="-90"/>
<wire x1="3.175" y1="3.175" x2="3.175" y2="2.54" width="0.254" layer="21"/>
<wire x1="-28.575" y1="-6.35" x2="-27.305" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-27.305" y1="-6.35" x2="-26.035" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-27.305" y1="-7.6835" x2="-27.051" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-26.289" y1="-7.9375" x2="-27.051" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-20.955" y1="-6.35" x2="-20.955" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-20.955" y1="-7.6835" x2="-21.209" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-20.955" y1="-6.35" x2="-19.685" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-19.685" y1="-6.35" x2="-18.415" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-19.685" y1="-7.6835" x2="-19.431" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-18.669" y1="-7.9375" x2="-19.431" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-17.145" y1="-6.35" x2="-17.145" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-15.875" y1="-6.35" x2="-15.875" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-15.875" y1="-7.6835" x2="-16.129" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-15.875" y1="-6.35" x2="-14.605" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-14.605" y1="-6.35" x2="-13.335" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-14.605" y1="-7.6835" x2="-14.351" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-13.335" y1="-7.6835" x2="-13.589" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-13.589" y1="-7.9375" x2="-14.351" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-10.795" y1="-6.35" x2="-10.795" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-9.525" y1="-6.35" x2="-9.525" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-8.255" y1="-6.35" x2="-8.255" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-8.255" y1="-7.6835" x2="-8.509" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-8.255" y1="-6.35" x2="-6.985" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-6.985" y1="-6.35" x2="-5.715" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-6.985" y1="-7.6835" x2="-6.731" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-5.715" y1="-7.6835" x2="-5.969" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-5.969" y1="-7.9375" x2="-6.731" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="4.445" y1="-6.35" x2="8.255" y2="-6.35" width="0.254" layer="51"/>
<wire x1="9.525" y1="-6.35" x2="10.795" y2="-6.35" width="0.127" layer="51"/>
<wire x1="15.875" y1="-6.35" x2="17.145" y2="-6.35" width="0.254" layer="51"/>
<wire x1="17.145" y1="-6.35" x2="18.415" y2="-6.35" width="0.127" layer="51"/>
<wire x1="18.415" y1="-6.35" x2="19.685" y2="-6.35" width="0.254" layer="51"/>
<wire x1="19.685" y1="-6.35" x2="20.955" y2="-6.35" width="0.127" layer="51"/>
<wire x1="26.035" y1="-6.35" x2="27.305" y2="-6.35" width="0.254" layer="51"/>
<wire x1="27.305" y1="-6.35" x2="28.575" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-29.5275" y1="-5.715" x2="-29.5275" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-28.575" y1="-6.35" x2="-28.575" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-28.575" y1="-7.6835" x2="-28.829" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-28.829" y1="-7.9375" x2="-29.5275" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="28.575" y1="-6.35" x2="28.575" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="28.575" y1="-7.6835" x2="28.829" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="28.829" y1="-7.9375" x2="29.5275" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="29.5275" y1="-7.9375" x2="29.5275" y2="-6.35" width="0.254" layer="51"/>
<wire x1="29.5275" y1="-6.35" x2="29.5275" y2="-5.715" width="0.254" layer="51"/>
<wire x1="28.575" y1="-6.35" x2="29.5275" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-1.905" y1="-6.35" x2="-1.905" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-0.635" y1="-6.35" x2="-0.635" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="0.635" y1="-6.35" x2="0.635" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="1.905" y1="-6.35" x2="1.905" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="6.985" y1="-7.6835" x2="6.731" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="6.731" y1="-7.9375" x2="5.969" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="8.255" y1="-6.35" x2="8.255" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="8.255" y1="-7.6835" x2="8.509" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="8.509" y1="-7.9375" x2="9.271" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="9.271" y1="-7.9375" x2="9.525" y2="-7.6835" width="0.254" layer="51" curve="90"/>
<wire x1="9.525" y1="-7.6835" x2="9.525" y2="-6.35" width="0.254" layer="51"/>
<wire x1="15.875" y1="-6.35" x2="15.875" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="15.875" y1="-7.6835" x2="16.129" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="16.129" y1="-7.9375" x2="16.891" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="16.891" y1="-7.9375" x2="17.145" y2="-7.6835" width="0.254" layer="51" curve="90"/>
<wire x1="17.145" y1="-7.6835" x2="17.145" y2="-6.35" width="0.254" layer="51"/>
<wire x1="10.795" y1="-6.35" x2="10.795" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="18.669" y1="-7.9375" x2="19.431" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="19.431" y1="-7.9375" x2="19.685" y2="-7.6835" width="0.254" layer="51" curve="90"/>
<wire x1="19.685" y1="-7.6835" x2="19.685" y2="-6.35" width="0.254" layer="51"/>
<wire x1="20.955" y1="-6.35" x2="20.955" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="20.955" y1="-7.6835" x2="21.209" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="26.289" y1="-7.9375" x2="27.051" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="27.051" y1="-7.9375" x2="27.305" y2="-7.6835" width="0.254" layer="51" curve="90"/>
<wire x1="27.305" y1="-7.6835" x2="27.305" y2="-6.35" width="0.254" layer="51"/>
<pad name="2" x="-25.4" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="1" x="-27.94" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="3" x="-22.86" y="-7.62" drill="1.0922" shape="long" rot="R270"/>
<pad name="4" x="-20.32" y="-7.62" drill="1.0922" shape="long" rot="R270"/>
<pad name="5" x="-17.78" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="6" x="-15.24" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="7" x="-12.7" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="8" x="-10.16" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="9" x="-7.62" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="10" x="-5.08" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="11" x="-2.54" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="12" x="0" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="13" x="2.54" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="14" x="5.08" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="15" x="7.62" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="16" x="10.16" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="17" x="12.7" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="18" x="15.24" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="19" x="17.78" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="20" x="20.32" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="21" x="22.86" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="22" x="25.4" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="23" x="27.94" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<text x="-30.7975" y="-5.715" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="32.0675" y="-5.715" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-28.2575" y1="-7.62" x2="-27.6225" y2="-6.35" layer="51"/>
<rectangle x1="-20.6375" y1="-7.62" x2="-20.0025" y2="-6.35" layer="51"/>
<rectangle x1="-15.5575" y1="-7.62" x2="-14.9225" y2="-6.35" layer="51"/>
<rectangle x1="-7.9375" y1="-7.62" x2="-7.3025" y2="-6.35" layer="51"/>
<rectangle x1="27.6225" y1="-7.62" x2="28.2575" y2="-6.35" layer="51"/>
<rectangle x1="7.3025" y1="-7.62" x2="7.9375" y2="-6.35" layer="51"/>
<rectangle x1="14.9225" y1="-7.62" x2="15.5575" y2="-6.35" layer="51"/>
<rectangle x1="20.0025" y1="-7.62" x2="20.6375" y2="-6.35" layer="51"/>
<polygon width="0.0508" layer="21">
<vertex x="-29.845" y="5.8737"/>
<vertex x="-29.3687" y="3.9688"/>
<vertex x="-28.8925" y="5.8737"/>
</polygon>
</package>
<package name="70543-24">
 vertical, 24 pin</description>
<wire x1="31.75" y1="-2.8575" x2="31.75" y2="2.8575" width="0.254" layer="21"/>
<wire x1="31.75" y1="2.8575" x2="-31.75" y2="2.8575" width="0.254" layer="21"/>
<wire x1="-31.75" y1="2.8575" x2="-31.75" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-31.75" y1="-2.8575" x2="-3.4925" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="3.4925" y1="-2.8575" x2="31.75" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-31.115" y1="2.2225" x2="-31.115" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="31.115" y1="2.2225" x2="31.115" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="-31.115" y1="2.2225" x2="31.115" y2="2.2225" width="0.0508" layer="51"/>
<wire x1="-31.115" y1="-2.2225" x2="-2.8575" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-2.2225" x2="31.115" y2="-2.2225" width="0.0508" layer="51"/>
<pad name="3" x="-24.13" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-26.67" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="-29.21" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-21.59" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-19.05" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-16.51" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-13.97" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="-11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="-8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="-6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="15" x="6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="16" x="8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="17" x="11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="18" x="13.97" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="19" x="16.51" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="20" x="19.05" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="21" x="21.59" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="22" x="24.13" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="23" x="26.67" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="24" x="29.21" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-32.385" y="-2.54" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="-31.4325" y="3.4925" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-30.7975" y="-1.5875" size="1.016" layer="51" ratio="10">1</text>
<rectangle x1="-29.4481" y1="-0.2381" x2="-28.9719" y2="0.2381" layer="51"/>
<rectangle x1="-21.8281" y1="-0.2381" x2="-21.3519" y2="0.2381" layer="51"/>
<rectangle x1="-16.7481" y1="-0.2381" x2="-16.2719" y2="0.2381" layer="51"/>
<rectangle x1="-11.6681" y1="-0.2381" x2="-11.1919" y2="0.2381" layer="51"/>
<rectangle x1="-9.1281" y1="-0.2381" x2="-8.6519" y2="0.2381" layer="51"/>
<rectangle x1="-1.5081" y1="-0.2381" x2="-1.0319" y2="0.2381" layer="51"/>
<rectangle x1="1.0319" y1="-0.2381" x2="1.5081" y2="0.2381" layer="51"/>
<rectangle x1="8.6519" y1="-0.2381" x2="9.1281" y2="0.2381" layer="51"/>
<rectangle x1="11.1919" y1="-0.2381" x2="11.6681" y2="0.2381" layer="51"/>
<rectangle x1="16.2719" y1="-0.2381" x2="16.7481" y2="0.2381" layer="51"/>
<rectangle x1="21.3519" y1="-0.2381" x2="21.8281" y2="0.2381" layer="51"/>
<rectangle x1="28.9719" y1="-0.2381" x2="29.4481" y2="0.2381" layer="51"/>
</package>
<package name="70553-24">
 right angle, 24 pin</description>
<wire x1="31.5913" y1="5.8738" x2="4.1275" y2="5.8738" width="0.254" layer="21"/>
<wire x1="4.1275" y1="5.8738" x2="-31.5913" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-31.5913" y1="5.8738" x2="-31.5913" y2="-5.715" width="0.254" layer="21"/>
<wire x1="-31.5913" y1="-5.715" x2="31.5913" y2="-5.715" width="0.254" layer="21"/>
<wire x1="31.5913" y1="-5.715" x2="31.5913" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-29.845" y1="-6.35" x2="-28.575" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-28.575" y1="-6.35" x2="-27.305" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-28.575" y1="-7.6835" x2="-28.321" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-27.559" y1="-7.9375" x2="-28.321" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-22.225" y1="-6.35" x2="-22.225" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-22.225" y1="-7.6835" x2="-22.479" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-22.225" y1="-6.35" x2="-20.955" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-20.955" y1="-6.35" x2="-19.685" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-20.955" y1="-7.6835" x2="-20.701" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-19.939" y1="-7.9375" x2="-20.701" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-17.145" y1="-7.6835" x2="-17.399" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-17.145" y1="-6.35" x2="-15.875" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-15.875" y1="-6.35" x2="-14.605" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-15.875" y1="-7.6835" x2="-15.621" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-14.859" y1="-7.9375" x2="-15.621" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-9.525" y1="-7.6835" x2="-9.779" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-9.525" y1="-6.35" x2="-8.255" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-8.255" y1="-6.35" x2="-6.985" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-8.255" y1="-7.6835" x2="-8.001" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-7.239" y1="-7.9375" x2="-8.001" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="3.175" y1="-6.35" x2="6.985" y2="-6.35" width="0.254" layer="51"/>
<wire x1="6.985" y1="-6.35" x2="8.255" y2="-6.35" width="0.254" layer="51"/>
<wire x1="8.255" y1="-6.35" x2="9.525" y2="-6.35" width="0.127" layer="51"/>
<wire x1="14.605" y1="-6.35" x2="15.875" y2="-6.35" width="0.254" layer="51"/>
<wire x1="15.875" y1="-6.35" x2="17.145" y2="-6.35" width="0.127" layer="51"/>
<wire x1="19.685" y1="-6.35" x2="20.955" y2="-6.35" width="0.254" layer="51"/>
<wire x1="20.955" y1="-6.35" x2="22.225" y2="-6.35" width="0.127" layer="51"/>
<wire x1="27.305" y1="-6.35" x2="28.575" y2="-6.35" width="0.254" layer="51"/>
<wire x1="28.575" y1="-6.35" x2="29.845" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-30.7975" y1="-5.715" x2="-30.7975" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-29.845" y1="-6.35" x2="-29.845" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-29.845" y1="-7.6835" x2="-30.099" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-30.099" y1="-7.9375" x2="-30.7975" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="29.845" y1="-6.35" x2="29.845" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="29.845" y1="-7.6835" x2="30.099" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="30.099" y1="-7.9375" x2="30.7975" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="30.7975" y1="-7.9375" x2="30.7975" y2="-6.35" width="0.254" layer="51"/>
<wire x1="30.7975" y1="-6.35" x2="30.7975" y2="-5.715" width="0.254" layer="51"/>
<wire x1="29.845" y1="-6.35" x2="30.7975" y2="-6.35" width="0.254" layer="51"/>
<wire x1="0.635" y1="-6.35" x2="1.905" y2="-6.35" width="0.127" layer="51"/>
<wire x1="7.239" y1="-7.9375" x2="8.001" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="8.001" y1="-7.9375" x2="8.255" y2="-7.6835" width="0.254" layer="51" curve="90"/>
<wire x1="8.255" y1="-7.6835" x2="8.255" y2="-6.35" width="0.254" layer="51"/>
<wire x1="14.859" y1="-7.9375" x2="15.621" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="15.621" y1="-7.9375" x2="15.875" y2="-7.6835" width="0.254" layer="51" curve="90"/>
<wire x1="15.875" y1="-7.6835" x2="15.875" y2="-6.35" width="0.254" layer="51"/>
<wire x1="9.525" y1="-6.35" x2="9.525" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="9.525" y1="-7.6835" x2="9.779" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="22.225" y1="-6.35" x2="22.225" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="22.225" y1="-7.6835" x2="22.479" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="17.145" y1="-6.35" x2="17.145" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="17.145" y1="-7.6835" x2="17.399" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="19.939" y1="-7.9375" x2="20.701" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="20.701" y1="-7.9375" x2="20.955" y2="-7.6835" width="0.254" layer="51" curve="90"/>
<wire x1="20.955" y1="-7.6835" x2="20.955" y2="-6.35" width="0.254" layer="51"/>
<wire x1="27.559" y1="-7.9375" x2="28.321" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="28.321" y1="-7.9375" x2="28.575" y2="-7.6835" width="0.254" layer="51" curve="90"/>
<wire x1="28.575" y1="-7.6835" x2="28.575" y2="-6.35" width="0.254" layer="51"/>
<pad name="2" x="-26.67" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="1" x="-29.21" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="3" x="-24.13" y="-7.62" drill="1.0922" shape="long" rot="R270"/>
<pad name="4" x="-21.59" y="-7.62" drill="1.0922" shape="long" rot="R270"/>
<pad name="5" x="-19.05" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="6" x="-16.51" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="7" x="-13.97" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="8" x="-11.43" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="9" x="-8.89" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="10" x="-6.35" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="11" x="-3.81" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="12" x="-1.27" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="13" x="1.27" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="14" x="3.81" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="15" x="6.35" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="16" x="8.89" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="17" x="11.43" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="18" x="13.97" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="19" x="16.51" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="20" x="19.05" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="21" x="21.59" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="22" x="24.13" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="23" x="26.67" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="24" x="29.21" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<text x="-32.0675" y="-5.715" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="33.3375" y="-5.715" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-29.5275" y1="-7.62" x2="-28.8925" y2="-6.35" layer="51"/>
<rectangle x1="-21.9075" y1="-7.62" x2="-21.2725" y2="-6.35" layer="51"/>
<rectangle x1="-16.8275" y1="-7.62" x2="-16.1925" y2="-6.35" layer="51"/>
<rectangle x1="-9.2075" y1="-7.62" x2="-8.5725" y2="-6.35" layer="51"/>
<rectangle x1="28.8925" y1="-7.62" x2="29.5275" y2="-6.35" layer="51"/>
<rectangle x1="8.5725" y1="-7.62" x2="9.2075" y2="-6.35" layer="51"/>
<rectangle x1="16.1925" y1="-7.62" x2="16.8275" y2="-6.35" layer="51"/>
<rectangle x1="21.2725" y1="-7.62" x2="21.9075" y2="-6.35" layer="51"/>
<vertex x="-31.115" y="5.8737"/>
<vertex x="-30.6387" y="3.9688"/>
<vertex x="-30.1625" y="5.8737"/>
</polygon>
</package>
<package name="70543-25">
 vertical, 25 pin</description>
<wire x1="33.02" y1="-2.8575" x2="33.02" y2="2.8575" width="0.254" layer="21"/>
<wire x1="33.02" y1="2.8575" x2="-33.02" y2="2.8575" width="0.254" layer="21"/>
<wire x1="-33.02" y1="2.8575" x2="-33.02" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-33.02" y1="-2.8575" x2="-3.4925" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="3.4925" y1="-2.8575" x2="33.02" y2="-2.8575" width="0.254" layer="21"/>
<wire x1="-32.385" y1="2.2225" x2="-32.385" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="32.385" y1="2.2225" x2="32.385" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="-32.385" y1="2.2225" x2="32.385" y2="2.2225" width="0.0508" layer="51"/>
<wire x1="-32.385" y1="-2.2225" x2="-2.8575" y2="-2.2225" width="0.0508" layer="51"/>
<wire x1="2.8575" y1="-2.2225" x2="32.385" y2="-2.2225" width="0.0508" layer="51"/>
<pad name="3" x="-25.4" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-27.94" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="-30.48" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-22.86" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-20.32" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-17.78" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-15.24" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="-12.7" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="-10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="-7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="-5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="15" x="5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="16" x="7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="17" x="10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="18" x="12.7" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="19" x="15.24" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="20" x="17.78" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="21" x="20.32" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="22" x="22.86" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="23" x="25.4" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="24" x="27.94" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="25" x="30.48" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-33.655" y="-2.54" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="-32.7025" y="3.4925" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-32.0675" y="-1.5875" size="1.016" layer="51" ratio="10">1</text>
<rectangle x1="-30.7181" y1="-0.2381" x2="-30.2419" y2="0.2381" layer="51"/>
<rectangle x1="-23.0981" y1="-0.2381" x2="-22.6219" y2="0.2381" layer="51"/>
<rectangle x1="-18.0181" y1="-0.2381" x2="-17.5419" y2="0.2381" layer="51"/>
<rectangle x1="-12.9381" y1="-0.2381" x2="-12.4619" y2="0.2381" layer="51"/>
<rectangle x1="-2.7781" y1="-0.2381" x2="-2.3019" y2="0.2381" layer="51"/>
<rectangle x1="-0.2381" y1="-0.2381" x2="0.2381" y2="0.2381" layer="51"/>
<rectangle x1="2.3019" y1="-0.2381" x2="2.7781" y2="0.2381" layer="51"/>
<rectangle x1="12.4619" y1="-0.2381" x2="12.9381" y2="0.2381" layer="51"/>
<rectangle x1="17.5419" y1="-0.2381" x2="18.0181" y2="0.2381" layer="51"/>
<rectangle x1="22.6219" y1="-0.2381" x2="23.0981" y2="0.2381" layer="51"/>
<rectangle x1="30.2419" y1="-0.2381" x2="30.7181" y2="0.2381" layer="51"/>
</package>
<package name="70553-25">
 right angle, 25 pin</description>
<wire x1="32.8613" y1="5.8738" x2="4.1275" y2="5.8738" width="0.254" layer="21"/>
<wire x1="4.1275" y1="5.8738" x2="-32.8613" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-32.8613" y1="5.8738" x2="-32.8613" y2="-5.715" width="0.254" layer="21"/>
<wire x1="-32.8613" y1="-5.715" x2="32.8613" y2="-5.715" width="0.254" layer="21"/>
<wire x1="32.8613" y1="-5.715" x2="32.8613" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-4.1275" y1="5.8737" x2="-4.1275" y2="2.54" width="0.254" layer="21"/>
<wire x1="-4.1275" y1="2.54" x2="-3.175" y2="2.54" width="0.254" layer="21"/>
<wire x1="3.175" y1="2.54" x2="4.1275" y2="2.54" width="0.254" layer="21"/>
<wire x1="4.1275" y1="2.54" x2="4.1275" y2="5.8738" width="0.254" layer="21"/>
<wire x1="-31.115" y1="-6.35" x2="-29.845" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-29.845" y1="-6.35" x2="-28.575" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-29.845" y1="-7.6835" x2="-29.591" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-28.829" y1="-7.9375" x2="-29.591" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-23.495" y1="-6.35" x2="-23.495" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-23.495" y1="-7.6835" x2="-23.749" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-23.495" y1="-6.35" x2="-22.225" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-22.225" y1="-6.35" x2="-20.955" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-22.225" y1="-7.6835" x2="-21.971" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-21.209" y1="-7.9375" x2="-21.971" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-18.415" y1="-6.35" x2="-18.415" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-18.415" y1="-7.6835" x2="-18.669" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-18.415" y1="-6.35" x2="-17.145" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-17.145" y1="-6.35" x2="-15.875" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-17.145" y1="-7.6835" x2="-16.891" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-16.129" y1="-7.9375" x2="-16.891" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-13.335" y1="-6.35" x2="-12.065" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-12.065" y1="-6.35" x2="-10.795" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-12.065" y1="-6.35" x2="-12.065" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-12.065" y1="-7.6835" x2="-11.811" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-10.795" y1="-7.6835" x2="-11.049" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-11.049" y1="-7.9375" x2="-11.811" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-10.795" y1="-6.35" x2="-9.525" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-9.525" y1="-6.35" x2="-8.255" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-9.525" y1="-7.6835" x2="-9.271" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-8.509" y1="-7.9375" x2="-9.271" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="1.905" y1="-6.35" x2="5.715" y2="-6.35" width="0.254" layer="51"/>
<wire x1="5.715" y1="-6.35" x2="6.985" y2="-6.35" width="0.254" layer="51"/>
<wire x1="6.985" y1="-6.35" x2="8.255" y2="-6.35" width="0.127" layer="51"/>
<wire x1="8.255" y1="-6.35" x2="9.525" y2="-6.35" width="0.254" layer="51"/>
<wire x1="13.335" y1="-6.35" x2="14.605" y2="-6.35" width="0.254" layer="51"/>
<wire x1="14.605" y1="-6.35" x2="15.875" y2="-6.35" width="0.127" layer="51"/>
<wire x1="20.955" y1="-6.35" x2="22.225" y2="-6.35" width="0.254" layer="51"/>
<wire x1="22.225" y1="-6.35" x2="23.495" y2="-6.35" width="0.127" layer="51"/>
<wire x1="28.575" y1="-6.35" x2="29.845" y2="-6.35" width="0.254" layer="51"/>
<wire x1="29.845" y1="-6.35" x2="31.115" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-32.0675" y1="-5.715" x2="-32.0675" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-31.115" y1="-6.35" x2="-31.115" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-31.115" y1="-7.6835" x2="-31.369" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-31.369" y1="-7.9375" x2="-32.0675" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="31.115" y1="-6.35" x2="31.115" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="31.115" y1="-7.6835" x2="31.369" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="31.369" y1="-7.9375" x2="32.0675" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="32.0675" y1="-7.9375" x2="32.0675" y2="-6.35" width="0.254" layer="51"/>
<wire x1="32.0675" y1="-6.35" x2="32.0675" y2="-5.715" width="0.254" layer="51"/>
<wire x1="31.115" y1="-6.35" x2="32.0675" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-5.715" y1="-6.35" x2="-4.445" y2="-6.35" width="0.127" layer="51"/>
<wire x1="-4.445" y1="-6.35" x2="-3.175" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-4.445" y1="-6.35" x2="-4.445" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-4.445" y1="-7.6835" x2="-4.191" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-3.175" y1="-6.35" x2="-3.175" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="-3.175" y1="-7.6835" x2="-3.429" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-3.429" y1="-7.9375" x2="-4.191" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-0.635" y1="-6.35" x2="0.635" y2="-6.35" width="0.127" layer="51"/>
<wire x1="0.635" y1="-6.35" x2="1.905" y2="-6.35" width="0.254" layer="51"/>
<wire x1="0.635" y1="-7.6835" x2="0.889" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="1.905" y1="-7.6835" x2="1.651" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="1.651" y1="-7.9375" x2="0.889" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="-1.905" y1="-6.35" x2="-0.635" y2="-6.35" width="0.254" layer="51"/>
<wire x1="-1.905" y1="-7.6835" x2="-1.651" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="-0.635" y1="-7.6835" x2="-0.889" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="-0.889" y1="-7.9375" x2="-1.651" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="3.175" y1="-6.35" x2="3.175" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="3.175" y1="-7.6835" x2="3.429" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="4.445" y1="-6.35" x2="4.445" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="4.445" y1="-7.6835" x2="4.191" y2="-7.9375" width="0.254" layer="51" curve="-90"/>
<wire x1="4.191" y1="-7.9375" x2="3.429" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="5.715" y1="-6.35" x2="5.715" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="5.715" y1="-7.6835" x2="5.969" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="5.969" y1="-7.9375" x2="6.731" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="6.731" y1="-7.9375" x2="6.985" y2="-7.6835" width="0.254" layer="51" curve="90"/>
<wire x1="6.985" y1="-7.6835" x2="6.985" y2="-6.35" width="0.254" layer="51"/>
<wire x1="13.335" y1="-6.35" x2="13.335" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="13.335" y1="-7.6835" x2="13.589" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="13.589" y1="-7.9375" x2="14.351" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="14.351" y1="-7.9375" x2="14.605" y2="-7.6835" width="0.254" layer="51" curve="90"/>
<wire x1="14.605" y1="-7.6835" x2="14.605" y2="-6.35" width="0.254" layer="51"/>
<wire x1="10.795" y1="-7.6835" x2="11.049" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="21.209" y1="-7.9375" x2="21.971" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="21.971" y1="-7.9375" x2="22.225" y2="-7.6835" width="0.254" layer="51" curve="90"/>
<wire x1="22.225" y1="-7.6835" x2="22.225" y2="-6.35" width="0.254" layer="51"/>
<wire x1="18.415" y1="-6.35" x2="18.415" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="18.415" y1="-7.6835" x2="18.669" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<wire x1="28.829" y1="-7.9375" x2="29.591" y2="-7.9375" width="0.254" layer="51"/>
<wire x1="29.591" y1="-7.9375" x2="29.845" y2="-7.6835" width="0.254" layer="51" curve="90"/>
<wire x1="29.845" y1="-7.6835" x2="29.845" y2="-6.35" width="0.254" layer="51"/>
<wire x1="23.495" y1="-6.35" x2="23.495" y2="-7.6835" width="0.254" layer="51"/>
<wire x1="23.495" y1="-7.6835" x2="23.749" y2="-7.9375" width="0.254" layer="51" curve="90"/>
<pad name="2" x="-27.94" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="1" x="-30.48" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="3" x="-25.4" y="-7.62" drill="1.0922" shape="long" rot="R270"/>
<pad name="4" x="-22.86" y="-7.62" drill="1.0922" shape="long" rot="R270"/>
<pad name="5" x="-20.32" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="6" x="-17.78" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="7" x="-15.24" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="8" x="-12.7" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="9" x="-10.16" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="10" x="-7.62" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="11" x="-5.08" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="12" x="-2.54" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="13" x="0" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="14" x="2.54" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="15" x="5.08" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="16" x="7.62" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="17" x="10.16" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="18" x="12.7" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="19" x="15.24" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="20" x="17.78" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="21" x="20.32" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="22" x="22.86" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="23" x="25.4" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="24" x="27.94" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<pad name="25" x="30.48" y="-7.62" drill="1.0922" shape="long" rot="R90"/>
<text x="-33.3375" y="-5.715" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="34.6075" y="-5.715" size="0.8128" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-30.7975" y1="-7.62" x2="-30.1625" y2="-6.35" layer="51"/>
<rectangle x1="-23.1775" y1="-7.62" x2="-22.5425" y2="-6.35" layer="51"/>
<rectangle x1="-18.0975" y1="-7.62" x2="-17.4625" y2="-6.35" layer="51"/>
<rectangle x1="-13.0175" y1="-7.62" x2="-12.3825" y2="-6.35" layer="51"/>
<rectangle x1="-10.4775" y1="-7.62" x2="-9.8425" y2="-6.35" layer="51"/>
<rectangle x1="30.1625" y1="-7.62" x2="30.7975" y2="-6.35" layer="51"/>
<rectangle x1="-5.3975" y1="-7.62" x2="-4.7625" y2="-6.35" layer="51"/>
<rectangle x1="-2.8575" y1="-7.62" x2="-2.2225" y2="-6.35" layer="51"/>
<rectangle x1="-0.3175" y1="-7.62" x2="0.3175" y2="-6.35" layer="51"/>
<rectangle x1="2.2225" y1="-7.62" x2="2.8575" y2="-6.35" layer="51"/>
<rectangle x1="4.7625" y1="-7.62" x2="5.3975" y2="-6.35" layer="51"/>
<rectangle x1="9.8425" y1="-7.62" x2="10.4775" y2="-6.35" layer="51"/>
<rectangle x1="12.3825" y1="-7.62" x2="13.0175" y2="-6.35" layer="51"/>
<rectangle x1="17.4625" y1="-7.62" x2="18.0975" y2="-6.35" layer="51"/>
<rectangle x1="22.5425" y1="-7.62" x2="23.1775" y2="-6.35" layer="51"/>
<vertex x="-32.385" y="5.8737"/>
<vertex x="-31.9087" y="3.9688"/>
<vertex x="-31.4325" y="5.8737"/>
</polygon>
</package>
<package name="52746-20">
<description>&lt;b&gt;FPC Connector ZIF for SMT 0.5mm&lt;/b&gt;&lt;p&gt;
Source: http://www.farnell.com/datasheets/73044.pdf [DWG. NO. (Sheet 1 OF 2) SD-52746-**17]&lt;br&gt;
Distributor: Farnell 9786350</description>
<wire x1="-7.05" y1="0.6" x2="-5.25" y2="0.6" width="0.2032" layer="21"/>
<wire x1="-5.25" y1="0.6" x2="5.25" y2="0.6" width="0.2032" layer="51"/>
<wire x1="5.25" y1="0.6" x2="7.05" y2="0.6" width="0.2032" layer="21"/>
<wire x1="7.05" y1="0.6" x2="7.05" y2="-4" width="0.2032" layer="51"/>
<wire x1="7.05" y1="-4" x2="6.35" y2="-4" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-4" x2="6.35" y2="-5" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-5" x2="7.95" y2="-5" width="0.2032" layer="21"/>
<wire x1="7.95" y1="-5" x2="7.95" y2="-5.2" width="0.2032" layer="21"/>
<wire x1="7.95" y1="-5.2" x2="7.55" y2="-5.6" width="0.2032" layer="21" curve="-90"/>
<wire x1="7.55" y1="-5.6" x2="-7.55" y2="-5.6" width="0.2032" layer="21"/>
<wire x1="-7.55" y1="-5.6" x2="-7.95" y2="-5.2" width="0.2032" layer="21" curve="-90"/>
<wire x1="-7.95" y1="-5.2" x2="-7.95" y2="-5" width="0.2032" layer="21"/>
<wire x1="-7.95" y1="-5" x2="-6.35" y2="-5" width="0.2032" layer="21"/>
<wire x1="-6.35" y1="-5" x2="-6.35" y2="-4" width="0.2032" layer="21"/>
<wire x1="-6.35" y1="-4" x2="-7.05" y2="-4" width="0.2032" layer="21"/>
<wire x1="-7.05" y1="-4" x2="-7.05" y2="0.6" width="0.2032" layer="51"/>
<wire x1="-8" y1="-0.25" x2="-7.2" y2="-0.25" width="0.5" layer="51"/>
<wire x1="-7.2" y1="-0.25" x2="-7.2" y2="-1.4" width="0.5" layer="51"/>
<wire x1="-7.2" y1="-1.4" x2="-8" y2="-1.4" width="0.5" layer="51"/>
<wire x1="8" y1="-1.4" x2="7.2" y2="-1.4" width="0.5" layer="51"/>
<wire x1="7.2" y1="-1.4" x2="7.2" y2="-0.25" width="0.5" layer="51"/>
<wire x1="7.2" y1="-0.25" x2="8" y2="-0.25" width="0.5" layer="51"/>
<smd name="1" x="-4.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="2" x="-4.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="3" x="-3.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="4" x="-3.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="5" x="-2.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="6" x="-2.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="7" x="-1.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="8" x="-1.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="9" x="-0.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="10" x="-0.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="11" x="0.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="12" x="0.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="13" x="1.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="14" x="1.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="15" x="2.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="16" x="2.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="17" x="3.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="18" x="3.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="19" x="4.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="20" x="4.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<text x="-5.715" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-6.985" y="-7.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-8.4" y1="-2" x2="-6" y2="0.2" layer="1"/>
<rectangle x1="-7.3" y1="-2.85" x2="-6" y2="-2" layer="1"/>
<rectangle x1="6" y1="-2" x2="8.4" y2="0.2" layer="1"/>
<rectangle x1="6" y1="-2.85" x2="7.3" y2="-2" layer="1"/>
<rectangle x1="-8.4" y1="-2" x2="-6" y2="0.2" layer="29"/>
<rectangle x1="-7.3" y1="-2.85" x2="-6" y2="-2" layer="29"/>
<rectangle x1="6" y1="-2" x2="8.4" y2="0.2" layer="29"/>
<rectangle x1="6" y1="-2.85" x2="7.3" y2="-2" layer="29"/>
<rectangle x1="-4.925" y1="0.175" x2="-4.575" y2="1.025" layer="29"/>
<rectangle x1="-4.425" y1="0.175" x2="-4.075" y2="1.025" layer="29"/>
<rectangle x1="-3.925" y1="0.175" x2="-3.575" y2="1.025" layer="29"/>
<rectangle x1="-3.425" y1="0.175" x2="-3.075" y2="1.025" layer="29"/>
<rectangle x1="-2.925" y1="0.175" x2="-2.575" y2="1.025" layer="29"/>
<rectangle x1="-2.425" y1="0.175" x2="-2.075" y2="1.025" layer="29"/>
<rectangle x1="-1.925" y1="0.175" x2="-1.575" y2="1.025" layer="29"/>
<rectangle x1="-1.425" y1="0.175" x2="-1.075" y2="1.025" layer="29"/>
<rectangle x1="-0.925" y1="0.175" x2="-0.575" y2="1.025" layer="29"/>
<rectangle x1="-0.425" y1="0.175" x2="-0.075" y2="1.025" layer="29"/>
<rectangle x1="0.075" y1="0.175" x2="0.425" y2="1.025" layer="29"/>
<rectangle x1="0.575" y1="0.175" x2="0.925" y2="1.025" layer="29"/>
<rectangle x1="1.075" y1="0.175" x2="1.425" y2="1.025" layer="29"/>
<rectangle x1="1.575" y1="0.175" x2="1.925" y2="1.025" layer="29"/>
<rectangle x1="2.075" y1="0.175" x2="2.425" y2="1.025" layer="29"/>
<rectangle x1="2.575" y1="0.175" x2="2.925" y2="1.025" layer="29"/>
<rectangle x1="3.075" y1="0.175" x2="3.425" y2="1.025" layer="29"/>
<rectangle x1="3.575" y1="0.175" x2="3.925" y2="1.025" layer="29"/>
<rectangle x1="4.075" y1="0.175" x2="4.425" y2="1.025" layer="29"/>
<rectangle x1="4.575" y1="0.175" x2="4.925" y2="1.025" layer="29"/>
<rectangle x1="-8.275" y1="-1.9" x2="-6.1" y2="0.075" layer="31"/>
<rectangle x1="-7.2" y1="-2.75" x2="-6.1" y2="-1.9" layer="31"/>
<rectangle x1="6.1" y1="-1.9" x2="8.275" y2="0.075" layer="31"/>
<rectangle x1="6.1" y1="-2.75" x2="7.2" y2="-1.9" layer="31"/>
</package>
<package name="52746-19">
Source: http://www.farnell.com/datasheets/73044.pdf [DWG. NO. (Sheet 1 OF 2) SD-52746-**17]</description>
<wire x1="-6.8" y1="0.6" x2="-5" y2="0.6" width="0.2032" layer="21"/>
<wire x1="-5" y1="0.6" x2="5" y2="0.6" width="0.2032" layer="51"/>
<wire x1="5" y1="0.6" x2="6.8" y2="0.6" width="0.2032" layer="21"/>
<wire x1="6.8" y1="0.6" x2="6.8" y2="-4" width="0.2032" layer="51"/>
<wire x1="6.8" y1="-4" x2="6.1" y2="-4" width="0.2032" layer="21"/>
<wire x1="6.1" y1="-4" x2="6.1" y2="-5" width="0.2032" layer="21"/>
<wire x1="6.1" y1="-5" x2="7.7" y2="-5" width="0.2032" layer="21"/>
<wire x1="7.7" y1="-5" x2="7.7" y2="-5.2" width="0.2032" layer="21"/>
<wire x1="7.7" y1="-5.2" x2="7.3" y2="-5.6" width="0.2032" layer="21" curve="-90"/>
<wire x1="7.3" y1="-5.6" x2="-7.3" y2="-5.6" width="0.2032" layer="21"/>
<wire x1="-7.3" y1="-5.6" x2="-7.7" y2="-5.2" width="0.2032" layer="21" curve="-90"/>
<wire x1="-7.7" y1="-5.2" x2="-7.7" y2="-5" width="0.2032" layer="21"/>
<wire x1="-7.7" y1="-5" x2="-6.1" y2="-5" width="0.2032" layer="21"/>
<wire x1="-6.1" y1="-5" x2="-6.1" y2="-4" width="0.2032" layer="21"/>
<wire x1="-6.1" y1="-4" x2="-6.8" y2="-4" width="0.2032" layer="21"/>
<wire x1="-6.8" y1="-4" x2="-6.8" y2="0.6" width="0.2032" layer="51"/>
<wire x1="-7.75" y1="-0.25" x2="-6.95" y2="-0.25" width="0.5" layer="51"/>
<wire x1="-6.95" y1="-0.25" x2="-6.95" y2="-1.4" width="0.5" layer="51"/>
<wire x1="-6.95" y1="-1.4" x2="-7.75" y2="-1.4" width="0.5" layer="51"/>
<wire x1="7.75" y1="-1.4" x2="6.95" y2="-1.4" width="0.5" layer="51"/>
<wire x1="6.95" y1="-1.4" x2="6.95" y2="-0.25" width="0.5" layer="51"/>
<wire x1="6.95" y1="-0.25" x2="7.75" y2="-0.25" width="0.5" layer="51"/>
<smd name="1" x="-4.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="2" x="-4" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="3" x="-3.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="4" x="-3" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="5" x="-2.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="6" x="-2" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="7" x="-1.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="8" x="-1" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="9" x="-0.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="10" x="0" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="11" x="0.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="12" x="1" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="13" x="1.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="14" x="2" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="15" x="2.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="16" x="3" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="17" x="3.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="18" x="4" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="19" x="4.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<text x="-5.465" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-6.735" y="-7.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-8.15" y1="-2" x2="-5.75" y2="0.2" layer="1"/>
<rectangle x1="-7.05" y1="-2.85" x2="-5.75" y2="-2" layer="1"/>
<rectangle x1="5.75" y1="-2" x2="8.15" y2="0.2" layer="1"/>
<rectangle x1="5.75" y1="-2.85" x2="7.05" y2="-2" layer="1"/>
<rectangle x1="-8.15" y1="-2" x2="-5.75" y2="0.2" layer="29"/>
<rectangle x1="-7.05" y1="-2.85" x2="-5.75" y2="-2" layer="29"/>
<rectangle x1="5.75" y1="-2" x2="8.15" y2="0.2" layer="29"/>
<rectangle x1="5.75" y1="-2.85" x2="7.05" y2="-2" layer="29"/>
<rectangle x1="-4.675" y1="0.175" x2="-4.325" y2="1.025" layer="29"/>
<rectangle x1="-4.175" y1="0.175" x2="-3.825" y2="1.025" layer="29"/>
<rectangle x1="-3.675" y1="0.175" x2="-3.325" y2="1.025" layer="29"/>
<rectangle x1="-3.175" y1="0.175" x2="-2.825" y2="1.025" layer="29"/>
<rectangle x1="-2.675" y1="0.175" x2="-2.325" y2="1.025" layer="29"/>
<rectangle x1="-2.175" y1="0.175" x2="-1.825" y2="1.025" layer="29"/>
<rectangle x1="-1.675" y1="0.175" x2="-1.325" y2="1.025" layer="29"/>
<rectangle x1="-1.175" y1="0.175" x2="-0.825" y2="1.025" layer="29"/>
<rectangle x1="-0.675" y1="0.175" x2="-0.325" y2="1.025" layer="29"/>
<rectangle x1="-0.175" y1="0.175" x2="0.175" y2="1.025" layer="29"/>
<rectangle x1="0.325" y1="0.175" x2="0.675" y2="1.025" layer="29"/>
<rectangle x1="0.825" y1="0.175" x2="1.175" y2="1.025" layer="29"/>
<rectangle x1="1.325" y1="0.175" x2="1.675" y2="1.025" layer="29"/>
<rectangle x1="1.825" y1="0.175" x2="2.175" y2="1.025" layer="29"/>
<rectangle x1="2.325" y1="0.175" x2="2.675" y2="1.025" layer="29"/>
<rectangle x1="2.825" y1="0.175" x2="3.175" y2="1.025" layer="29"/>
<rectangle x1="3.325" y1="0.175" x2="3.675" y2="1.025" layer="29"/>
<rectangle x1="3.825" y1="0.175" x2="4.175" y2="1.025" layer="29"/>
<rectangle x1="4.325" y1="0.175" x2="4.675" y2="1.025" layer="29"/>
<rectangle x1="-8.025" y1="-1.9" x2="-5.85" y2="0.075" layer="31"/>
<rectangle x1="-6.95" y1="-2.75" x2="-5.85" y2="-1.9" layer="31"/>
<rectangle x1="5.85" y1="-1.9" x2="8.025" y2="0.075" layer="31"/>
<rectangle x1="5.85" y1="-2.75" x2="6.95" y2="-1.9" layer="31"/>
</package>
<package name="52746-18">
<wire x1="-6.55" y1="0.6" x2="-4.75" y2="0.6" width="0.2032" layer="21"/>
<wire x1="-4.75" y1="0.6" x2="4.75" y2="0.6" width="0.2032" layer="51"/>
<wire x1="4.75" y1="0.6" x2="6.55" y2="0.6" width="0.2032" layer="21"/>
<wire x1="6.55" y1="0.6" x2="6.55" y2="-4" width="0.2032" layer="51"/>
<wire x1="6.55" y1="-4" x2="5.85" y2="-4" width="0.2032" layer="21"/>
<wire x1="5.85" y1="-4" x2="5.85" y2="-5" width="0.2032" layer="21"/>
<wire x1="5.85" y1="-5" x2="7.45" y2="-5" width="0.2032" layer="21"/>
<wire x1="7.45" y1="-5" x2="7.45" y2="-5.2" width="0.2032" layer="21"/>
<wire x1="7.45" y1="-5.2" x2="7.05" y2="-5.6" width="0.2032" layer="21" curve="-90"/>
<wire x1="7.05" y1="-5.6" x2="-7.05" y2="-5.6" width="0.2032" layer="21"/>
<wire x1="-7.05" y1="-5.6" x2="-7.45" y2="-5.2" width="0.2032" layer="21" curve="-90"/>
<wire x1="-7.45" y1="-5.2" x2="-7.45" y2="-5" width="0.2032" layer="21"/>
<wire x1="-7.45" y1="-5" x2="-5.85" y2="-5" width="0.2032" layer="21"/>
<wire x1="-5.85" y1="-5" x2="-5.85" y2="-4" width="0.2032" layer="21"/>
<wire x1="-5.85" y1="-4" x2="-6.55" y2="-4" width="0.2032" layer="21"/>
<wire x1="-6.55" y1="-4" x2="-6.55" y2="0.6" width="0.2032" layer="51"/>
<wire x1="-7.5" y1="-0.25" x2="-6.7" y2="-0.25" width="0.5" layer="51"/>
<wire x1="-6.7" y1="-0.25" x2="-6.7" y2="-1.4" width="0.5" layer="51"/>
<wire x1="-6.7" y1="-1.4" x2="-7.5" y2="-1.4" width="0.5" layer="51"/>
<wire x1="7.5" y1="-1.4" x2="6.7" y2="-1.4" width="0.5" layer="51"/>
<wire x1="6.7" y1="-1.4" x2="6.7" y2="-0.25" width="0.5" layer="51"/>
<wire x1="6.7" y1="-0.25" x2="7.5" y2="-0.25" width="0.5" layer="51"/>
<smd name="1" x="-4.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="2" x="-3.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="3" x="-3.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="4" x="-2.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="5" x="-2.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="6" x="-1.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="7" x="-1.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="8" x="-0.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="9" x="-0.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="10" x="0.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="11" x="0.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="12" x="1.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="13" x="1.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="14" x="2.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="15" x="2.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="16" x="3.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="17" x="3.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="18" x="4.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<text x="-5.215" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-6.485" y="-7.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-7.9" y1="-2" x2="-5.5" y2="0.2" layer="1"/>
<rectangle x1="-6.8" y1="-2.85" x2="-5.5" y2="-2" layer="1"/>
<rectangle x1="5.5" y1="-2" x2="7.9" y2="0.2" layer="1"/>
<rectangle x1="5.5" y1="-2.85" x2="6.8" y2="-2" layer="1"/>
<rectangle x1="-7.9" y1="-2" x2="-5.5" y2="0.2" layer="29"/>
<rectangle x1="-6.8" y1="-2.85" x2="-5.5" y2="-2" layer="29"/>
<rectangle x1="5.5" y1="-2" x2="7.9" y2="0.2" layer="29"/>
<rectangle x1="5.5" y1="-2.85" x2="6.8" y2="-2" layer="29"/>
<rectangle x1="-7.775" y1="-1.9" x2="-5.6" y2="0.075" layer="31"/>
<rectangle x1="-6.7" y1="-2.75" x2="-5.6" y2="-1.9" layer="31"/>
<rectangle x1="5.6" y1="-1.9" x2="7.775" y2="0.075" layer="31"/>
<rectangle x1="5.6" y1="-2.75" x2="6.7" y2="-1.9" layer="31"/>
</package>
<package name="52746-17">
<wire x1="-6.3" y1="0.6" x2="-4.5" y2="0.6" width="0.2032" layer="21"/>
<wire x1="-4.5" y1="0.6" x2="4.5" y2="0.6" width="0.2032" layer="51"/>
<wire x1="4.5" y1="0.6" x2="6.3" y2="0.6" width="0.2032" layer="21"/>
<wire x1="6.3" y1="0.6" x2="6.3" y2="-4" width="0.2032" layer="51"/>
<wire x1="6.3" y1="-4" x2="5.6" y2="-4" width="0.2032" layer="21"/>
<wire x1="5.6" y1="-4" x2="5.6" y2="-5" width="0.2032" layer="21"/>
<wire x1="5.6" y1="-5" x2="7.2" y2="-5" width="0.2032" layer="21"/>
<wire x1="7.2" y1="-5" x2="7.2" y2="-5.2" width="0.2032" layer="21"/>
<wire x1="7.2" y1="-5.2" x2="6.8" y2="-5.6" width="0.2032" layer="21" curve="-90"/>
<wire x1="6.8" y1="-5.6" x2="-6.8" y2="-5.6" width="0.2032" layer="21"/>
<wire x1="-6.8" y1="-5.6" x2="-7.2" y2="-5.2" width="0.2032" layer="21" curve="-90"/>
<wire x1="-7.2" y1="-5.2" x2="-7.2" y2="-5" width="0.2032" layer="21"/>
<wire x1="-7.2" y1="-5" x2="-5.6" y2="-5" width="0.2032" layer="21"/>
<wire x1="-5.6" y1="-5" x2="-5.6" y2="-4" width="0.2032" layer="21"/>
<wire x1="-5.6" y1="-4" x2="-6.3" y2="-4" width="0.2032" layer="21"/>
<wire x1="-6.3" y1="-4" x2="-6.3" y2="0.6" width="0.2032" layer="51"/>
<wire x1="-7.25" y1="-0.25" x2="-6.45" y2="-0.25" width="0.5" layer="51"/>
<wire x1="-6.45" y1="-0.25" x2="-6.45" y2="-1.4" width="0.5" layer="51"/>
<wire x1="-6.45" y1="-1.4" x2="-7.25" y2="-1.4" width="0.5" layer="51"/>
<wire x1="7.25" y1="-1.4" x2="6.45" y2="-1.4" width="0.5" layer="51"/>
<wire x1="6.45" y1="-1.4" x2="6.45" y2="-0.25" width="0.5" layer="51"/>
<wire x1="6.45" y1="-0.25" x2="7.25" y2="-0.25" width="0.5" layer="51"/>
<smd name="1" x="-4" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="2" x="-3.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="3" x="-3" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="4" x="-2.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="5" x="-2" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="6" x="-1.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="7" x="-1" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="8" x="-0.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="9" x="0" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="10" x="0.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="11" x="1" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="12" x="1.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="13" x="2" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="14" x="2.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="15" x="3" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="16" x="3.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="17" x="4" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<text x="-4.965" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-6.235" y="-7.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-7.65" y1="-2" x2="-5.25" y2="0.2" layer="1"/>
<rectangle x1="-6.55" y1="-2.85" x2="-5.25" y2="-2" layer="1"/>
<rectangle x1="5.25" y1="-2" x2="7.65" y2="0.2" layer="1"/>
<rectangle x1="5.25" y1="-2.85" x2="6.55" y2="-2" layer="1"/>
<rectangle x1="-7.65" y1="-2" x2="-5.25" y2="0.2" layer="29"/>
<rectangle x1="-6.55" y1="-2.85" x2="-5.25" y2="-2" layer="29"/>
<rectangle x1="5.25" y1="-2" x2="7.65" y2="0.2" layer="29"/>
<rectangle x1="5.25" y1="-2.85" x2="6.55" y2="-2" layer="29"/>
<rectangle x1="-7.525" y1="-1.9" x2="-5.35" y2="0.075" layer="31"/>
<rectangle x1="-6.45" y1="-2.75" x2="-5.35" y2="-1.9" layer="31"/>
<rectangle x1="5.35" y1="-1.9" x2="7.525" y2="0.075" layer="31"/>
<rectangle x1="5.35" y1="-2.75" x2="6.45" y2="-1.9" layer="31"/>
</package>
<package name="52746-16">
<wire x1="-6.05" y1="0.6" x2="-4.25" y2="0.6" width="0.2032" layer="21"/>
<wire x1="-4.25" y1="0.6" x2="4.25" y2="0.6" width="0.2032" layer="51"/>
<wire x1="4.25" y1="0.6" x2="6.05" y2="0.6" width="0.2032" layer="21"/>
<wire x1="6.05" y1="0.6" x2="6.05" y2="-4" width="0.2032" layer="51"/>
<wire x1="6.05" y1="-4" x2="5.35" y2="-4" width="0.2032" layer="21"/>
<wire x1="5.35" y1="-4" x2="5.35" y2="-5" width="0.2032" layer="21"/>
<wire x1="5.35" y1="-5" x2="6.95" y2="-5" width="0.2032" layer="21"/>
<wire x1="6.95" y1="-5" x2="6.95" y2="-5.2" width="0.2032" layer="21"/>
<wire x1="6.95" y1="-5.2" x2="6.55" y2="-5.6" width="0.2032" layer="21" curve="-90"/>
<wire x1="6.55" y1="-5.6" x2="-6.55" y2="-5.6" width="0.2032" layer="21"/>
<wire x1="-6.55" y1="-5.6" x2="-6.95" y2="-5.2" width="0.2032" layer="21" curve="-90"/>
<wire x1="-6.95" y1="-5.2" x2="-6.95" y2="-5" width="0.2032" layer="21"/>
<wire x1="-6.95" y1="-5" x2="-5.35" y2="-5" width="0.2032" layer="21"/>
<wire x1="-5.35" y1="-5" x2="-5.35" y2="-4" width="0.2032" layer="21"/>
<wire x1="-5.35" y1="-4" x2="-6.05" y2="-4" width="0.2032" layer="21"/>
<wire x1="-6.05" y1="-4" x2="-6.05" y2="0.6" width="0.2032" layer="51"/>
<wire x1="-7" y1="-0.25" x2="-6.2" y2="-0.25" width="0.5" layer="51"/>
<wire x1="-6.2" y1="-0.25" x2="-6.2" y2="-1.4" width="0.5" layer="51"/>
<wire x1="-6.2" y1="-1.4" x2="-7" y2="-1.4" width="0.5" layer="51"/>
<wire x1="7" y1="-1.4" x2="6.2" y2="-1.4" width="0.5" layer="51"/>
<wire x1="6.2" y1="-1.4" x2="6.2" y2="-0.25" width="0.5" layer="51"/>
<wire x1="6.2" y1="-0.25" x2="7" y2="-0.25" width="0.5" layer="51"/>
<smd name="1" x="-3.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="2" x="-3.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="3" x="-2.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="4" x="-2.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="5" x="-1.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="6" x="-1.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="7" x="-0.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="8" x="-0.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="9" x="0.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="10" x="0.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="11" x="1.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="12" x="1.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="13" x="2.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="14" x="2.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="15" x="3.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="16" x="3.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<text x="-4.715" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.985" y="-7.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-7.4" y1="-2" x2="-5" y2="0.2" layer="1"/>
<rectangle x1="-6.3" y1="-2.85" x2="-5" y2="-2" layer="1"/>
<rectangle x1="5" y1="-2" x2="7.4" y2="0.2" layer="1"/>
<rectangle x1="5" y1="-2.85" x2="6.3" y2="-2" layer="1"/>
<rectangle x1="-7.4" y1="-2" x2="-5" y2="0.2" layer="29"/>
<rectangle x1="-6.3" y1="-2.85" x2="-5" y2="-2" layer="29"/>
<rectangle x1="5" y1="-2" x2="7.4" y2="0.2" layer="29"/>
<rectangle x1="5" y1="-2.85" x2="6.3" y2="-2" layer="29"/>
<rectangle x1="-7.275" y1="-1.9" x2="-5.1" y2="0.075" layer="31"/>
<rectangle x1="-6.2" y1="-2.75" x2="-5.1" y2="-1.9" layer="31"/>
<rectangle x1="5.1" y1="-1.9" x2="7.275" y2="0.075" layer="31"/>
<rectangle x1="5.1" y1="-2.75" x2="6.2" y2="-1.9" layer="31"/>
</package>
<package name="52746-15">
<wire x1="-5.8" y1="0.6" x2="-4" y2="0.6" width="0.2032" layer="21"/>
<wire x1="-4" y1="0.6" x2="4" y2="0.6" width="0.2032" layer="51"/>
<wire x1="4" y1="0.6" x2="5.8" y2="0.6" width="0.2032" layer="21"/>
<wire x1="5.8" y1="0.6" x2="5.8" y2="-4" width="0.2032" layer="51"/>
<wire x1="5.8" y1="-4" x2="5.1" y2="-4" width="0.2032" layer="21"/>
<wire x1="5.1" y1="-4" x2="5.1" y2="-5" width="0.2032" layer="21"/>
<wire x1="5.1" y1="-5" x2="6.7" y2="-5" width="0.2032" layer="21"/>
<wire x1="6.7" y1="-5" x2="6.7" y2="-5.2" width="0.2032" layer="21"/>
<wire x1="6.7" y1="-5.2" x2="6.3" y2="-5.6" width="0.2032" layer="21" curve="-90"/>
<wire x1="6.3" y1="-5.6" x2="-6.3" y2="-5.6" width="0.2032" layer="21"/>
<wire x1="-6.3" y1="-5.6" x2="-6.7" y2="-5.2" width="0.2032" layer="21" curve="-90"/>
<wire x1="-6.7" y1="-5.2" x2="-6.7" y2="-5" width="0.2032" layer="21"/>
<wire x1="-6.7" y1="-5" x2="-5.1" y2="-5" width="0.2032" layer="21"/>
<wire x1="-5.1" y1="-5" x2="-5.1" y2="-4" width="0.2032" layer="21"/>
<wire x1="-5.1" y1="-4" x2="-5.8" y2="-4" width="0.2032" layer="21"/>
<wire x1="-5.8" y1="-4" x2="-5.8" y2="0.6" width="0.2032" layer="51"/>
<wire x1="-6.75" y1="-0.25" x2="-5.95" y2="-0.25" width="0.5" layer="51"/>
<wire x1="-5.95" y1="-0.25" x2="-5.95" y2="-1.4" width="0.5" layer="51"/>
<wire x1="-5.95" y1="-1.4" x2="-6.75" y2="-1.4" width="0.5" layer="51"/>
<wire x1="6.75" y1="-1.4" x2="5.95" y2="-1.4" width="0.5" layer="51"/>
<wire x1="5.95" y1="-1.4" x2="5.95" y2="-0.25" width="0.5" layer="51"/>
<wire x1="5.95" y1="-0.25" x2="6.75" y2="-0.25" width="0.5" layer="51"/>
<smd name="1" x="-3.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="2" x="-3" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="3" x="-2.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="4" x="-2" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="5" x="-1.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="6" x="-1" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="7" x="-0.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="8" x="0" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="9" x="0.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="10" x="1" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="11" x="1.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="12" x="2" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="13" x="2.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="14" x="3" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="15" x="3.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<text x="-4.465" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.735" y="-7.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-7.15" y1="-2" x2="-4.75" y2="0.2" layer="1"/>
<rectangle x1="-6.05" y1="-2.85" x2="-4.75" y2="-2" layer="1"/>
<rectangle x1="4.75" y1="-2" x2="7.15" y2="0.2" layer="1"/>
<rectangle x1="4.75" y1="-2.85" x2="6.05" y2="-2" layer="1"/>
<rectangle x1="-7.15" y1="-2" x2="-4.75" y2="0.2" layer="29"/>
<rectangle x1="-6.05" y1="-2.85" x2="-4.75" y2="-2" layer="29"/>
<rectangle x1="4.75" y1="-2" x2="7.15" y2="0.2" layer="29"/>
<rectangle x1="4.75" y1="-2.85" x2="6.05" y2="-2" layer="29"/>
<rectangle x1="-7.025" y1="-1.9" x2="-4.85" y2="0.075" layer="31"/>
<rectangle x1="-5.95" y1="-2.75" x2="-4.85" y2="-1.9" layer="31"/>
<rectangle x1="4.85" y1="-1.9" x2="7.025" y2="0.075" layer="31"/>
<rectangle x1="4.85" y1="-2.75" x2="5.95" y2="-1.9" layer="31"/>
</package>
<package name="52746-14">
<wire x1="-5.55" y1="0.6" x2="-3.75" y2="0.6" width="0.2032" layer="21"/>
<wire x1="-3.75" y1="0.6" x2="3.75" y2="0.6" width="0.2032" layer="51"/>
<wire x1="3.75" y1="0.6" x2="5.55" y2="0.6" width="0.2032" layer="21"/>
<wire x1="5.55" y1="0.6" x2="5.55" y2="-4" width="0.2032" layer="51"/>
<wire x1="5.55" y1="-4" x2="4.85" y2="-4" width="0.2032" layer="21"/>
<wire x1="4.85" y1="-4" x2="4.85" y2="-5" width="0.2032" layer="21"/>
<wire x1="4.85" y1="-5" x2="6.45" y2="-5" width="0.2032" layer="21"/>
<wire x1="6.45" y1="-5" x2="6.45" y2="-5.2" width="0.2032" layer="21"/>
<wire x1="6.45" y1="-5.2" x2="6.05" y2="-5.6" width="0.2032" layer="21" curve="-90"/>
<wire x1="6.05" y1="-5.6" x2="-6.05" y2="-5.6" width="0.2032" layer="21"/>
<wire x1="-6.05" y1="-5.6" x2="-6.45" y2="-5.2" width="0.2032" layer="21" curve="-90"/>
<wire x1="-6.45" y1="-5.2" x2="-6.45" y2="-5" width="0.2032" layer="21"/>
<wire x1="-6.45" y1="-5" x2="-4.85" y2="-5" width="0.2032" layer="21"/>
<wire x1="-4.85" y1="-5" x2="-4.85" y2="-4" width="0.2032" layer="21"/>
<wire x1="-4.85" y1="-4" x2="-5.55" y2="-4" width="0.2032" layer="21"/>
<wire x1="-5.55" y1="-4" x2="-5.55" y2="0.6" width="0.2032" layer="51"/>
<wire x1="-6.5" y1="-0.25" x2="-5.7" y2="-0.25" width="0.5" layer="51"/>
<wire x1="-5.7" y1="-0.25" x2="-5.7" y2="-1.4" width="0.5" layer="51"/>
<wire x1="-5.7" y1="-1.4" x2="-6.5" y2="-1.4" width="0.5" layer="51"/>
<wire x1="6.5" y1="-1.4" x2="5.7" y2="-1.4" width="0.5" layer="51"/>
<wire x1="5.7" y1="-1.4" x2="5.7" y2="-0.25" width="0.5" layer="51"/>
<wire x1="5.7" y1="-0.25" x2="6.5" y2="-0.25" width="0.5" layer="51"/>
<smd name="1" x="-3.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="2" x="-2.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="3" x="-2.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="4" x="-1.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="5" x="-1.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="6" x="-0.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="7" x="-0.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="8" x="0.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="9" x="0.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="10" x="1.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="11" x="1.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="12" x="2.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="13" x="2.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="14" x="3.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<text x="-4.215" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.485" y="-7.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-6.9" y1="-2" x2="-4.5" y2="0.2" layer="1"/>
<rectangle x1="-5.8" y1="-2.85" x2="-4.5" y2="-2" layer="1"/>
<rectangle x1="4.5" y1="-2" x2="6.9" y2="0.2" layer="1"/>
<rectangle x1="4.5" y1="-2.85" x2="5.8" y2="-2" layer="1"/>
<rectangle x1="-6.9" y1="-2" x2="-4.5" y2="0.2" layer="29"/>
<rectangle x1="-5.8" y1="-2.85" x2="-4.5" y2="-2" layer="29"/>
<rectangle x1="4.5" y1="-2" x2="6.9" y2="0.2" layer="29"/>
<rectangle x1="4.5" y1="-2.85" x2="5.8" y2="-2" layer="29"/>
<rectangle x1="-6.775" y1="-1.9" x2="-4.6" y2="0.075" layer="31"/>
<rectangle x1="-5.7" y1="-2.75" x2="-4.6" y2="-1.9" layer="31"/>
<rectangle x1="4.6" y1="-1.9" x2="6.775" y2="0.075" layer="31"/>
<rectangle x1="4.6" y1="-2.75" x2="5.7" y2="-1.9" layer="31"/>
</package>
<package name="52746-13">
<wire x1="-5.3" y1="0.6" x2="-3.5" y2="0.6" width="0.2032" layer="21"/>
<wire x1="-3.5" y1="0.6" x2="3.5" y2="0.6" width="0.2032" layer="51"/>
<wire x1="3.5" y1="0.6" x2="5.3" y2="0.6" width="0.2032" layer="21"/>
<wire x1="5.3" y1="0.6" x2="5.3" y2="-4" width="0.2032" layer="51"/>
<wire x1="5.3" y1="-4" x2="4.6" y2="-4" width="0.2032" layer="21"/>
<wire x1="4.6" y1="-4" x2="4.6" y2="-5" width="0.2032" layer="21"/>
<wire x1="4.6" y1="-5" x2="6.2" y2="-5" width="0.2032" layer="21"/>
<wire x1="6.2" y1="-5" x2="6.2" y2="-5.2" width="0.2032" layer="21"/>
<wire x1="6.2" y1="-5.2" x2="5.8" y2="-5.6" width="0.2032" layer="21" curve="-90"/>
<wire x1="5.8" y1="-5.6" x2="-5.8" y2="-5.6" width="0.2032" layer="21"/>
<wire x1="-5.8" y1="-5.6" x2="-6.2" y2="-5.2" width="0.2032" layer="21" curve="-90"/>
<wire x1="-6.2" y1="-5.2" x2="-6.2" y2="-5" width="0.2032" layer="21"/>
<wire x1="-6.2" y1="-5" x2="-4.6" y2="-5" width="0.2032" layer="21"/>
<wire x1="-4.6" y1="-5" x2="-4.6" y2="-4" width="0.2032" layer="21"/>
<wire x1="-4.6" y1="-4" x2="-5.3" y2="-4" width="0.2032" layer="21"/>
<wire x1="-5.3" y1="-4" x2="-5.3" y2="0.6" width="0.2032" layer="51"/>
<wire x1="-6.25" y1="-0.25" x2="-5.45" y2="-0.25" width="0.5" layer="51"/>
<wire x1="-5.45" y1="-0.25" x2="-5.45" y2="-1.4" width="0.5" layer="51"/>
<wire x1="-5.45" y1="-1.4" x2="-6.25" y2="-1.4" width="0.5" layer="51"/>
<wire x1="6.25" y1="-1.4" x2="5.45" y2="-1.4" width="0.5" layer="51"/>
<wire x1="5.45" y1="-1.4" x2="5.45" y2="-0.25" width="0.5" layer="51"/>
<wire x1="5.45" y1="-0.25" x2="6.25" y2="-0.25" width="0.5" layer="51"/>
<smd name="1" x="-3" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="2" x="-2.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="3" x="-2" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="4" x="-1.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="5" x="-1" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="6" x="-0.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="7" x="0" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="8" x="0.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="9" x="1" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="10" x="1.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="11" x="2" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="12" x="2.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="13" x="3" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<text x="-3.965" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.235" y="-7.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-6.65" y1="-2" x2="-4.25" y2="0.2" layer="1"/>
<rectangle x1="-5.55" y1="-2.85" x2="-4.25" y2="-2" layer="1"/>
<rectangle x1="4.25" y1="-2" x2="6.65" y2="0.2" layer="1"/>
<rectangle x1="4.25" y1="-2.85" x2="5.55" y2="-2" layer="1"/>
<rectangle x1="-6.65" y1="-2" x2="-4.25" y2="0.2" layer="29"/>
<rectangle x1="-5.55" y1="-2.85" x2="-4.25" y2="-2" layer="29"/>
<rectangle x1="4.25" y1="-2" x2="6.65" y2="0.2" layer="29"/>
<rectangle x1="4.25" y1="-2.85" x2="5.55" y2="-2" layer="29"/>
<rectangle x1="-6.525" y1="-1.9" x2="-4.35" y2="0.075" layer="31"/>
<rectangle x1="-5.45" y1="-2.75" x2="-4.35" y2="-1.9" layer="31"/>
<rectangle x1="4.35" y1="-1.9" x2="6.525" y2="0.075" layer="31"/>
<rectangle x1="4.35" y1="-2.75" x2="5.45" y2="-1.9" layer="31"/>
</package>
<package name="52746-12">
<wire x1="-5.05" y1="0.6" x2="-3.25" y2="0.6" width="0.2032" layer="21"/>
<wire x1="-3.25" y1="0.6" x2="3.25" y2="0.6" width="0.2032" layer="51"/>
<wire x1="3.25" y1="0.6" x2="5.05" y2="0.6" width="0.2032" layer="21"/>
<wire x1="5.05" y1="0.6" x2="5.05" y2="-4" width="0.2032" layer="51"/>
<wire x1="5.05" y1="-4" x2="4.35" y2="-4" width="0.2032" layer="21"/>
<wire x1="4.35" y1="-4" x2="4.35" y2="-5" width="0.2032" layer="21"/>
<wire x1="4.35" y1="-5" x2="5.95" y2="-5" width="0.2032" layer="21"/>
<wire x1="5.95" y1="-5" x2="5.95" y2="-5.2" width="0.2032" layer="21"/>
<wire x1="5.95" y1="-5.2" x2="5.55" y2="-5.6" width="0.2032" layer="21" curve="-90"/>
<wire x1="5.55" y1="-5.6" x2="-5.55" y2="-5.6" width="0.2032" layer="21"/>
<wire x1="-5.55" y1="-5.6" x2="-5.95" y2="-5.2" width="0.2032" layer="21" curve="-90"/>
<wire x1="-5.95" y1="-5.2" x2="-5.95" y2="-5" width="0.2032" layer="21"/>
<wire x1="-5.95" y1="-5" x2="-4.35" y2="-5" width="0.2032" layer="21"/>
<wire x1="-4.35" y1="-5" x2="-4.35" y2="-4" width="0.2032" layer="21"/>
<wire x1="-4.35" y1="-4" x2="-5.05" y2="-4" width="0.2032" layer="21"/>
<wire x1="-5.05" y1="-4" x2="-5.05" y2="0.6" width="0.2032" layer="51"/>
<wire x1="-6" y1="-0.25" x2="-5.2" y2="-0.25" width="0.5" layer="51"/>
<wire x1="-5.2" y1="-0.25" x2="-5.2" y2="-1.4" width="0.5" layer="51"/>
<wire x1="-5.2" y1="-1.4" x2="-6" y2="-1.4" width="0.5" layer="51"/>
<wire x1="6" y1="-1.4" x2="5.2" y2="-1.4" width="0.5" layer="51"/>
<wire x1="5.2" y1="-1.4" x2="5.2" y2="-0.25" width="0.5" layer="51"/>
<wire x1="5.2" y1="-0.25" x2="6" y2="-0.25" width="0.5" layer="51"/>
<smd name="1" x="-2.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="2" x="-2.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="3" x="-1.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="4" x="-1.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="5" x="-0.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="6" x="-0.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="7" x="0.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="8" x="0.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="9" x="1.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="10" x="1.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="11" x="2.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="12" x="2.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<text x="-3.715" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-4.985" y="-7.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-6.4" y1="-2" x2="-4" y2="0.2" layer="1"/>
<rectangle x1="-5.3" y1="-2.85" x2="-4" y2="-2" layer="1"/>
<rectangle x1="4" y1="-2" x2="6.4" y2="0.2" layer="1"/>
<rectangle x1="4" y1="-2.85" x2="5.3" y2="-2" layer="1"/>
<rectangle x1="-6.4" y1="-2" x2="-4" y2="0.2" layer="29"/>
<rectangle x1="-5.3" y1="-2.85" x2="-4" y2="-2" layer="29"/>
<rectangle x1="4" y1="-2" x2="6.4" y2="0.2" layer="29"/>
<rectangle x1="4" y1="-2.85" x2="5.3" y2="-2" layer="29"/>
<rectangle x1="-6.275" y1="-1.9" x2="-4.1" y2="0.075" layer="31"/>
<rectangle x1="-5.2" y1="-2.75" x2="-4.1" y2="-1.9" layer="31"/>
<rectangle x1="4.1" y1="-1.9" x2="6.275" y2="0.075" layer="31"/>
<rectangle x1="4.1" y1="-2.75" x2="5.2" y2="-1.9" layer="31"/>
</package>
<package name="52746-11">
<wire x1="-4.8" y1="0.6" x2="-3" y2="0.6" width="0.2032" layer="21"/>
<wire x1="-3" y1="0.6" x2="3" y2="0.6" width="0.2032" layer="51"/>
<wire x1="3" y1="0.6" x2="4.8" y2="0.6" width="0.2032" layer="21"/>
<wire x1="4.8" y1="0.6" x2="4.8" y2="-4" width="0.2032" layer="51"/>
<wire x1="4.8" y1="-4" x2="4.1" y2="-4" width="0.2032" layer="21"/>
<wire x1="4.1" y1="-4" x2="4.1" y2="-5" width="0.2032" layer="21"/>
<wire x1="4.1" y1="-5" x2="5.7" y2="-5" width="0.2032" layer="21"/>
<wire x1="5.7" y1="-5" x2="5.7" y2="-5.2" width="0.2032" layer="21"/>
<wire x1="5.7" y1="-5.2" x2="5.3" y2="-5.6" width="0.2032" layer="21" curve="-90"/>
<wire x1="5.3" y1="-5.6" x2="-5.3" y2="-5.6" width="0.2032" layer="21"/>
<wire x1="-5.3" y1="-5.6" x2="-5.7" y2="-5.2" width="0.2032" layer="21" curve="-90"/>
<wire x1="-5.7" y1="-5.2" x2="-5.7" y2="-5" width="0.2032" layer="21"/>
<wire x1="-5.7" y1="-5" x2="-4.1" y2="-5" width="0.2032" layer="21"/>
<wire x1="-4.1" y1="-5" x2="-4.1" y2="-4" width="0.2032" layer="21"/>
<wire x1="-4.1" y1="-4" x2="-4.8" y2="-4" width="0.2032" layer="21"/>
<wire x1="-4.8" y1="-4" x2="-4.8" y2="0.6" width="0.2032" layer="51"/>
<wire x1="-5.75" y1="-0.25" x2="-4.95" y2="-0.25" width="0.5" layer="51"/>
<wire x1="-4.95" y1="-0.25" x2="-4.95" y2="-1.4" width="0.5" layer="51"/>
<wire x1="-4.95" y1="-1.4" x2="-5.75" y2="-1.4" width="0.5" layer="51"/>
<wire x1="5.75" y1="-1.4" x2="4.95" y2="-1.4" width="0.5" layer="51"/>
<wire x1="4.95" y1="-1.4" x2="4.95" y2="-0.25" width="0.5" layer="51"/>
<wire x1="4.95" y1="-0.25" x2="5.75" y2="-0.25" width="0.5" layer="51"/>
<smd name="1" x="-2.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="2" x="-2" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="3" x="-1.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="4" x="-1" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="5" x="-0.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="6" x="0" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="7" x="0.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="8" x="1" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="9" x="1.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="10" x="2" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="11" x="2.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<text x="-3.465" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-4.735" y="-7.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-6.15" y1="-2" x2="-3.75" y2="0.2" layer="1"/>
<rectangle x1="-5.05" y1="-2.85" x2="-3.75" y2="-2" layer="1"/>
<rectangle x1="3.75" y1="-2" x2="6.15" y2="0.2" layer="1"/>
<rectangle x1="3.75" y1="-2.85" x2="5.05" y2="-2" layer="1"/>
<rectangle x1="-6.15" y1="-2" x2="-3.75" y2="0.2" layer="29"/>
<rectangle x1="-5.05" y1="-2.85" x2="-3.75" y2="-2" layer="29"/>
<rectangle x1="3.75" y1="-2" x2="6.15" y2="0.2" layer="29"/>
<rectangle x1="3.75" y1="-2.85" x2="5.05" y2="-2" layer="29"/>
<rectangle x1="-6.025" y1="-1.9" x2="-3.85" y2="0.075" layer="31"/>
<rectangle x1="-4.95" y1="-2.75" x2="-3.85" y2="-1.9" layer="31"/>
<rectangle x1="3.85" y1="-1.9" x2="6.025" y2="0.075" layer="31"/>
<rectangle x1="3.85" y1="-2.75" x2="4.95" y2="-1.9" layer="31"/>
</package>
<package name="52746-10">
<wire x1="-4.55" y1="0.6" x2="-2.75" y2="0.6" width="0.2032" layer="21"/>
<wire x1="-2.75" y1="0.6" x2="2.75" y2="0.6" width="0.2032" layer="51"/>
<wire x1="2.75" y1="0.6" x2="4.55" y2="0.6" width="0.2032" layer="21"/>
<wire x1="4.55" y1="0.6" x2="4.55" y2="-4" width="0.2032" layer="51"/>
<wire x1="4.55" y1="-4" x2="3.85" y2="-4" width="0.2032" layer="21"/>
<wire x1="3.85" y1="-4" x2="3.85" y2="-5" width="0.2032" layer="21"/>
<wire x1="3.85" y1="-5" x2="5.45" y2="-5" width="0.2032" layer="21"/>
<wire x1="5.45" y1="-5" x2="5.45" y2="-5.2" width="0.2032" layer="21"/>
<wire x1="5.45" y1="-5.2" x2="5.05" y2="-5.6" width="0.2032" layer="21" curve="-90"/>
<wire x1="5.05" y1="-5.6" x2="-5.05" y2="-5.6" width="0.2032" layer="21"/>
<wire x1="-5.05" y1="-5.6" x2="-5.45" y2="-5.2" width="0.2032" layer="21" curve="-90"/>
<wire x1="-5.45" y1="-5.2" x2="-5.45" y2="-5" width="0.2032" layer="21"/>
<wire x1="-5.45" y1="-5" x2="-3.85" y2="-5" width="0.2032" layer="21"/>
<wire x1="-3.85" y1="-5" x2="-3.85" y2="-4" width="0.2032" layer="21"/>
<wire x1="-3.85" y1="-4" x2="-4.55" y2="-4" width="0.2032" layer="21"/>
<wire x1="-4.55" y1="-4" x2="-4.55" y2="0.6" width="0.2032" layer="51"/>
<wire x1="-5.5" y1="-0.25" x2="-4.7" y2="-0.25" width="0.5" layer="51"/>
<wire x1="-4.7" y1="-0.25" x2="-4.7" y2="-1.4" width="0.5" layer="51"/>
<wire x1="-4.7" y1="-1.4" x2="-5.5" y2="-1.4" width="0.5" layer="51"/>
<wire x1="5.5" y1="-1.4" x2="4.7" y2="-1.4" width="0.5" layer="51"/>
<wire x1="4.7" y1="-1.4" x2="4.7" y2="-0.25" width="0.5" layer="51"/>
<wire x1="4.7" y1="-0.25" x2="5.5" y2="-0.25" width="0.5" layer="51"/>
<smd name="1" x="-2.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="2" x="-1.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="3" x="-1.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="4" x="-0.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="5" x="-0.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="6" x="0.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="7" x="0.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="8" x="1.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="9" x="1.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="10" x="2.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<text x="-3.215" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-4.485" y="-7.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-5.9" y1="-2" x2="-3.5" y2="0.2" layer="1"/>
<rectangle x1="-4.8" y1="-2.85" x2="-3.5" y2="-2" layer="1"/>
<rectangle x1="3.5" y1="-2" x2="5.9" y2="0.2" layer="1"/>
<rectangle x1="3.5" y1="-2.85" x2="4.8" y2="-2" layer="1"/>
<rectangle x1="-5.9" y1="-2" x2="-3.5" y2="0.2" layer="29"/>
<rectangle x1="-4.8" y1="-2.85" x2="-3.5" y2="-2" layer="29"/>
<rectangle x1="3.5" y1="-2" x2="5.9" y2="0.2" layer="29"/>
<rectangle x1="3.5" y1="-2.85" x2="4.8" y2="-2" layer="29"/>
<rectangle x1="-5.775" y1="-1.9" x2="-3.6" y2="0.075" layer="31"/>
<rectangle x1="-4.7" y1="-2.75" x2="-3.6" y2="-1.9" layer="31"/>
<rectangle x1="3.6" y1="-1.9" x2="5.775" y2="0.075" layer="31"/>
<rectangle x1="3.6" y1="-2.75" x2="4.7" y2="-1.9" layer="31"/>
</package>
<package name="52746-9">
<wire x1="-4.3" y1="0.6" x2="-2.5" y2="0.6" width="0.2032" layer="21"/>
<wire x1="-2.5" y1="0.6" x2="2.5" y2="0.6" width="0.2032" layer="51"/>
<wire x1="2.5" y1="0.6" x2="4.3" y2="0.6" width="0.2032" layer="21"/>
<wire x1="4.3" y1="0.6" x2="4.3" y2="-4" width="0.2032" layer="51"/>
<wire x1="4.3" y1="-4" x2="3.6" y2="-4" width="0.2032" layer="21"/>
<wire x1="3.6" y1="-4" x2="3.6" y2="-5" width="0.2032" layer="21"/>
<wire x1="3.6" y1="-5" x2="5.2" y2="-5" width="0.2032" layer="21"/>
<wire x1="5.2" y1="-5" x2="5.2" y2="-5.2" width="0.2032" layer="21"/>
<wire x1="5.2" y1="-5.2" x2="4.8" y2="-5.6" width="0.2032" layer="21" curve="-90"/>
<wire x1="4.8" y1="-5.6" x2="-4.8" y2="-5.6" width="0.2032" layer="21"/>
<wire x1="-4.8" y1="-5.6" x2="-5.2" y2="-5.2" width="0.2032" layer="21" curve="-90"/>
<wire x1="-5.2" y1="-5.2" x2="-5.2" y2="-5" width="0.2032" layer="21"/>
<wire x1="-5.2" y1="-5" x2="-3.6" y2="-5" width="0.2032" layer="21"/>
<wire x1="-3.6" y1="-5" x2="-3.6" y2="-4" width="0.2032" layer="21"/>
<wire x1="-3.6" y1="-4" x2="-4.3" y2="-4" width="0.2032" layer="21"/>
<wire x1="-4.3" y1="-4" x2="-4.3" y2="0.6" width="0.2032" layer="51"/>
<wire x1="-5.25" y1="-0.25" x2="-4.45" y2="-0.25" width="0.5" layer="51"/>
<wire x1="-4.45" y1="-0.25" x2="-4.45" y2="-1.4" width="0.5" layer="51"/>
<wire x1="-4.45" y1="-1.4" x2="-5.25" y2="-1.4" width="0.5" layer="51"/>
<wire x1="5.25" y1="-1.4" x2="4.45" y2="-1.4" width="0.5" layer="51"/>
<wire x1="4.45" y1="-1.4" x2="4.45" y2="-0.25" width="0.5" layer="51"/>
<wire x1="4.45" y1="-0.25" x2="5.25" y2="-0.25" width="0.5" layer="51"/>
<smd name="1" x="-2" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="2" x="-1.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="3" x="-1" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="4" x="-0.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="5" x="0" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="6" x="0.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="7" x="1" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="8" x="1.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="9" x="2" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<text x="-2.965" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-4.235" y="-7.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-5.65" y1="-2" x2="-3.25" y2="0.2" layer="1"/>
<rectangle x1="-4.55" y1="-2.85" x2="-3.25" y2="-2" layer="1"/>
<rectangle x1="3.25" y1="-2" x2="5.65" y2="0.2" layer="1"/>
<rectangle x1="3.25" y1="-2.85" x2="4.55" y2="-2" layer="1"/>
<rectangle x1="-5.65" y1="-2" x2="-3.25" y2="0.2" layer="29"/>
<rectangle x1="-4.55" y1="-2.85" x2="-3.25" y2="-2" layer="29"/>
<rectangle x1="3.25" y1="-2" x2="5.65" y2="0.2" layer="29"/>
<rectangle x1="3.25" y1="-2.85" x2="4.55" y2="-2" layer="29"/>
<rectangle x1="-5.525" y1="-1.9" x2="-3.35" y2="0.075" layer="31"/>
<rectangle x1="-4.45" y1="-2.75" x2="-3.35" y2="-1.9" layer="31"/>
<rectangle x1="3.35" y1="-1.9" x2="5.525" y2="0.075" layer="31"/>
<rectangle x1="3.35" y1="-2.75" x2="4.45" y2="-1.9" layer="31"/>
</package>
<package name="52746-8">
<wire x1="-4.05" y1="0.6" x2="-2.25" y2="0.6" width="0.2032" layer="21"/>
<wire x1="-2.25" y1="0.6" x2="2.25" y2="0.6" width="0.2032" layer="51"/>
<wire x1="2.25" y1="0.6" x2="4.05" y2="0.6" width="0.2032" layer="21"/>
<wire x1="4.05" y1="0.6" x2="4.05" y2="-4" width="0.2032" layer="51"/>
<wire x1="4.05" y1="-4" x2="3.35" y2="-4" width="0.2032" layer="21"/>
<wire x1="3.35" y1="-4" x2="3.35" y2="-5" width="0.2032" layer="21"/>
<wire x1="3.35" y1="-5" x2="4.95" y2="-5" width="0.2032" layer="21"/>
<wire x1="4.95" y1="-5" x2="4.95" y2="-5.2" width="0.2032" layer="21"/>
<wire x1="4.95" y1="-5.2" x2="4.55" y2="-5.6" width="0.2032" layer="21" curve="-90"/>
<wire x1="4.55" y1="-5.6" x2="-4.55" y2="-5.6" width="0.2032" layer="21"/>
<wire x1="-4.55" y1="-5.6" x2="-4.95" y2="-5.2" width="0.2032" layer="21" curve="-90"/>
<wire x1="-4.95" y1="-5.2" x2="-4.95" y2="-5" width="0.2032" layer="21"/>
<wire x1="-4.95" y1="-5" x2="-3.35" y2="-5" width="0.2032" layer="21"/>
<wire x1="-3.35" y1="-5" x2="-3.35" y2="-4" width="0.2032" layer="21"/>
<wire x1="-3.35" y1="-4" x2="-4.05" y2="-4" width="0.2032" layer="21"/>
<wire x1="-4.05" y1="-4" x2="-4.05" y2="0.6" width="0.2032" layer="51"/>
<wire x1="-5" y1="-0.25" x2="-4.2" y2="-0.25" width="0.5" layer="51"/>
<wire x1="-4.2" y1="-0.25" x2="-4.2" y2="-1.4" width="0.5" layer="51"/>
<wire x1="-4.2" y1="-1.4" x2="-5" y2="-1.4" width="0.5" layer="51"/>
<wire x1="5" y1="-1.4" x2="4.2" y2="-1.4" width="0.5" layer="51"/>
<wire x1="4.2" y1="-1.4" x2="4.2" y2="-0.25" width="0.5" layer="51"/>
<wire x1="4.2" y1="-0.25" x2="5" y2="-0.25" width="0.5" layer="51"/>
<smd name="1" x="-1.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="2" x="-1.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="3" x="-0.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="4" x="-0.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="5" x="0.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="6" x="0.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="7" x="1.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="8" x="1.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<text x="-2.715" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.985" y="-7.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-5.4" y1="-2" x2="-3" y2="0.2" layer="1"/>
<rectangle x1="-4.3" y1="-2.85" x2="-3" y2="-2" layer="1"/>
<rectangle x1="3" y1="-2" x2="5.4" y2="0.2" layer="1"/>
<rectangle x1="3" y1="-2.85" x2="4.3" y2="-2" layer="1"/>
<rectangle x1="-5.4" y1="-2" x2="-3" y2="0.2" layer="29"/>
<rectangle x1="-4.3" y1="-2.85" x2="-3" y2="-2" layer="29"/>
<rectangle x1="3" y1="-2" x2="5.4" y2="0.2" layer="29"/>
<rectangle x1="3" y1="-2.85" x2="4.3" y2="-2" layer="29"/>
<rectangle x1="-5.275" y1="-1.9" x2="-3.1" y2="0.075" layer="31"/>
<rectangle x1="-4.2" y1="-2.75" x2="-3.1" y2="-1.9" layer="31"/>
<rectangle x1="3.1" y1="-1.9" x2="5.275" y2="0.075" layer="31"/>
<rectangle x1="3.1" y1="-2.75" x2="4.2" y2="-1.9" layer="31"/>
</package>
<package name="52746-7">
<wire x1="-3.8" y1="0.6" x2="-2" y2="0.6" width="0.2032" layer="21"/>
<wire x1="-2" y1="0.6" x2="2" y2="0.6" width="0.2032" layer="51"/>
<wire x1="2" y1="0.6" x2="3.8" y2="0.6" width="0.2032" layer="21"/>
<wire x1="3.8" y1="0.6" x2="3.8" y2="-4" width="0.2032" layer="51"/>
<wire x1="3.8" y1="-4" x2="3.1" y2="-4" width="0.2032" layer="21"/>
<wire x1="3.1" y1="-4" x2="3.1" y2="-5" width="0.2032" layer="21"/>
<wire x1="3.1" y1="-5" x2="4.7" y2="-5" width="0.2032" layer="21"/>
<wire x1="4.7" y1="-5" x2="4.7" y2="-5.2" width="0.2032" layer="21"/>
<wire x1="4.7" y1="-5.2" x2="4.3" y2="-5.6" width="0.2032" layer="21" curve="-90"/>
<wire x1="4.3" y1="-5.6" x2="-4.3" y2="-5.6" width="0.2032" layer="21"/>
<wire x1="-4.3" y1="-5.6" x2="-4.7" y2="-5.2" width="0.2032" layer="21" curve="-90"/>
<wire x1="-4.7" y1="-5.2" x2="-4.7" y2="-5" width="0.2032" layer="21"/>
<wire x1="-4.7" y1="-5" x2="-3.1" y2="-5" width="0.2032" layer="21"/>
<wire x1="-3.1" y1="-5" x2="-3.1" y2="-4" width="0.2032" layer="21"/>
<wire x1="-3.1" y1="-4" x2="-3.8" y2="-4" width="0.2032" layer="21"/>
<wire x1="-3.8" y1="-4" x2="-3.8" y2="0.6" width="0.2032" layer="51"/>
<wire x1="-4.75" y1="-0.25" x2="-3.95" y2="-0.25" width="0.5" layer="51"/>
<wire x1="-3.95" y1="-0.25" x2="-3.95" y2="-1.4" width="0.5" layer="51"/>
<wire x1="-3.95" y1="-1.4" x2="-4.75" y2="-1.4" width="0.5" layer="51"/>
<wire x1="4.75" y1="-1.4" x2="3.95" y2="-1.4" width="0.5" layer="51"/>
<wire x1="3.95" y1="-1.4" x2="3.95" y2="-0.25" width="0.5" layer="51"/>
<wire x1="3.95" y1="-0.25" x2="4.75" y2="-0.25" width="0.5" layer="51"/>
<smd name="1" x="-1.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="2" x="-1" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="3" x="-0.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="4" x="0" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="5" x="0.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="6" x="1" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="7" x="1.5" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<text x="-2.465" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.735" y="-7.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-5.15" y1="-2" x2="-2.75" y2="0.2" layer="1"/>
<rectangle x1="-4.05" y1="-2.85" x2="-2.75" y2="-2" layer="1"/>
<rectangle x1="2.75" y1="-2" x2="5.15" y2="0.2" layer="1"/>
<rectangle x1="2.75" y1="-2.85" x2="4.05" y2="-2" layer="1"/>
<rectangle x1="-5.15" y1="-2" x2="-2.75" y2="0.2" layer="29"/>
<rectangle x1="-4.05" y1="-2.85" x2="-2.75" y2="-2" layer="29"/>
<rectangle x1="2.75" y1="-2" x2="5.15" y2="0.2" layer="29"/>
<rectangle x1="2.75" y1="-2.85" x2="4.05" y2="-2" layer="29"/>
<rectangle x1="-5.025" y1="-1.9" x2="-2.85" y2="0.075" layer="31"/>
<rectangle x1="-3.95" y1="-2.75" x2="-2.85" y2="-1.9" layer="31"/>
<rectangle x1="2.85" y1="-1.9" x2="5.025" y2="0.075" layer="31"/>
<rectangle x1="2.85" y1="-2.75" x2="3.95" y2="-1.9" layer="31"/>
</package>
<package name="52746-6">
<wire x1="-3.55" y1="0.6" x2="-1.75" y2="0.6" width="0.2032" layer="21"/>
<wire x1="-1.75" y1="0.6" x2="1.75" y2="0.6" width="0.2032" layer="51"/>
<wire x1="1.75" y1="0.6" x2="3.55" y2="0.6" width="0.2032" layer="21"/>
<wire x1="3.55" y1="0.6" x2="3.55" y2="-4" width="0.2032" layer="51"/>
<wire x1="3.55" y1="-4" x2="2.85" y2="-4" width="0.2032" layer="21"/>
<wire x1="2.85" y1="-4" x2="2.85" y2="-5" width="0.2032" layer="21"/>
<wire x1="2.85" y1="-5" x2="4.45" y2="-5" width="0.2032" layer="21"/>
<wire x1="4.45" y1="-5" x2="4.45" y2="-5.2" width="0.2032" layer="21"/>
<wire x1="4.45" y1="-5.2" x2="4.05" y2="-5.6" width="0.2032" layer="21" curve="-90"/>
<wire x1="4.05" y1="-5.6" x2="-4.05" y2="-5.6" width="0.2032" layer="21"/>
<wire x1="-4.05" y1="-5.6" x2="-4.45" y2="-5.2" width="0.2032" layer="21" curve="-90"/>
<wire x1="-4.45" y1="-5.2" x2="-4.45" y2="-5" width="0.2032" layer="21"/>
<wire x1="-4.45" y1="-5" x2="-2.85" y2="-5" width="0.2032" layer="21"/>
<wire x1="-2.85" y1="-5" x2="-2.85" y2="-4" width="0.2032" layer="21"/>
<wire x1="-2.85" y1="-4" x2="-3.55" y2="-4" width="0.2032" layer="21"/>
<wire x1="-3.55" y1="-4" x2="-3.55" y2="0.6" width="0.2032" layer="51"/>
<wire x1="-4.5" y1="-0.25" x2="-3.7" y2="-0.25" width="0.5" layer="51"/>
<wire x1="-3.7" y1="-0.25" x2="-3.7" y2="-1.4" width="0.5" layer="51"/>
<wire x1="-3.7" y1="-1.4" x2="-4.5" y2="-1.4" width="0.5" layer="51"/>
<wire x1="4.5" y1="-1.4" x2="3.7" y2="-1.4" width="0.5" layer="51"/>
<wire x1="3.7" y1="-1.4" x2="3.7" y2="-0.25" width="0.5" layer="51"/>
<wire x1="3.7" y1="-0.25" x2="4.5" y2="-0.25" width="0.5" layer="51"/>
<smd name="1" x="-1.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="2" x="-0.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="3" x="-0.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="4" x="0.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="5" x="0.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="6" x="1.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<text x="-2.215" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.485" y="-7.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-4.9" y1="-2" x2="-2.5" y2="0.2" layer="1"/>
<rectangle x1="-3.8" y1="-2.85" x2="-2.5" y2="-2" layer="1"/>
<rectangle x1="2.5" y1="-2" x2="4.9" y2="0.2" layer="1"/>
<rectangle x1="2.5" y1="-2.85" x2="3.8" y2="-2" layer="1"/>
<rectangle x1="-4.9" y1="-2" x2="-2.5" y2="0.2" layer="29"/>
<rectangle x1="-3.8" y1="-2.85" x2="-2.5" y2="-2" layer="29"/>
<rectangle x1="2.5" y1="-2" x2="4.9" y2="0.2" layer="29"/>
<rectangle x1="2.5" y1="-2.85" x2="3.8" y2="-2" layer="29"/>
<rectangle x1="-4.775" y1="-1.9" x2="-2.6" y2="0.075" layer="31"/>
<rectangle x1="-3.7" y1="-2.75" x2="-2.6" y2="-1.9" layer="31"/>
<rectangle x1="2.6" y1="-1.9" x2="4.775" y2="0.075" layer="31"/>
<rectangle x1="2.6" y1="-2.75" x2="3.7" y2="-1.9" layer="31"/>
</package>
<package name="52746-4">
<wire x1="-3.05" y1="0.6" x2="-1.25" y2="0.6" width="0.2032" layer="21"/>
<wire x1="-1.25" y1="0.6" x2="1.25" y2="0.6" width="0.2032" layer="51"/>
<wire x1="1.25" y1="0.6" x2="3.05" y2="0.6" width="0.2032" layer="21"/>
<wire x1="3.05" y1="0.6" x2="3.05" y2="-4" width="0.2032" layer="51"/>
<wire x1="3.05" y1="-4" x2="2.35" y2="-4" width="0.2032" layer="21"/>
<wire x1="2.35" y1="-4" x2="2.35" y2="-5" width="0.2032" layer="21"/>
<wire x1="2.35" y1="-5" x2="3.95" y2="-5" width="0.2032" layer="21"/>
<wire x1="3.95" y1="-5" x2="3.95" y2="-5.2" width="0.2032" layer="21"/>
<wire x1="3.95" y1="-5.2" x2="3.55" y2="-5.6" width="0.2032" layer="21" curve="-90"/>
<wire x1="3.55" y1="-5.6" x2="-3.55" y2="-5.6" width="0.2032" layer="21"/>
<wire x1="-3.55" y1="-5.6" x2="-3.95" y2="-5.2" width="0.2032" layer="21" curve="-90"/>
<wire x1="-3.95" y1="-5.2" x2="-3.95" y2="-5" width="0.2032" layer="21"/>
<wire x1="-3.95" y1="-5" x2="-2.35" y2="-5" width="0.2032" layer="21"/>
<wire x1="-2.35" y1="-5" x2="-2.35" y2="-4" width="0.2032" layer="21"/>
<wire x1="-2.35" y1="-4" x2="-3.05" y2="-4" width="0.2032" layer="21"/>
<wire x1="-3.05" y1="-4" x2="-3.05" y2="0.6" width="0.2032" layer="51"/>
<wire x1="-4" y1="-0.25" x2="-3.2" y2="-0.25" width="0.5" layer="51"/>
<wire x1="-3.2" y1="-0.25" x2="-3.2" y2="-1.4" width="0.5" layer="51"/>
<wire x1="-3.2" y1="-1.4" x2="-4" y2="-1.4" width="0.5" layer="51"/>
<wire x1="4" y1="-1.4" x2="3.2" y2="-1.4" width="0.5" layer="51"/>
<wire x1="3.2" y1="-1.4" x2="3.2" y2="-0.25" width="0.5" layer="51"/>
<wire x1="3.2" y1="-0.25" x2="4" y2="-0.25" width="0.5" layer="51"/>
<smd name="1" x="-0.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="2" x="-0.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="3" x="0.25" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<smd name="4" x="0.75" y="0.6" dx="0.3" dy="0.8" layer="1" stop="no"/>
<text x="-1.715" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.985" y="-7.62" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-4.4" y1="-2" x2="-2" y2="0.2" layer="1"/>
<rectangle x1="-3.3" y1="-2.85" x2="-2" y2="-2" layer="1"/>
<rectangle x1="2" y1="-2" x2="4.4" y2="0.2" layer="1"/>
<rectangle x1="2" y1="-2.85" x2="3.3" y2="-2" layer="1"/>
<rectangle x1="-4.4" y1="-2" x2="-2" y2="0.2" layer="29"/>
<rectangle x1="-3.3" y1="-2.85" x2="-2" y2="-2" layer="29"/>
<rectangle x1="2" y1="-2" x2="4.4" y2="0.2" layer="29"/>
<rectangle x1="2" y1="-2.85" x2="3.3" y2="-2" layer="29"/>
<rectangle x1="-4.275" y1="-1.9" x2="-2.1" y2="0.075" layer="31"/>
<rectangle x1="-3.2" y1="-2.75" x2="-2.1" y2="-1.9" layer="31"/>
<rectangle x1="2.1" y1="-1.9" x2="4.275" y2="0.075" layer="31"/>
<rectangle x1="2.1" y1="-2.75" x2="3.2" y2="-1.9" layer="31"/>
</package>
<package name="534620621_SD">
<description>&lt;b&gt;IEEE 1394 2.0 I/O Conn.&lt;/b&gt; Socket Right-Angle Flat with Kink&lt;p&gt;
Source: http://www.molex.com/pdm_docs/sd/534620621_sd.pdf</description>
<wire x1="3.4" y1="5.85" x2="3.9" y2="6.35" width="0" layer="46" curve="-90"/>
<wire x1="3.9" y1="6.35" x2="5.4" y2="6.35" width="0" layer="46"/>
<wire x1="5.4" y1="6.35" x2="5.9" y2="5.85" width="0" layer="46" curve="-90"/>
<wire x1="5.9" y1="5.85" x2="5.4" y2="5.35" width="0" layer="46" curve="-90"/>
<wire x1="5.4" y1="5.35" x2="3.9" y2="5.35" width="0" layer="46"/>
<wire x1="3.9" y1="5.35" x2="3.4" y2="5.85" width="0" layer="46" curve="-90"/>
<wire x1="3.4" y1="-5.85" x2="3.9" y2="-5.35" width="0" layer="46" curve="-90"/>
<wire x1="3.9" y1="-5.35" x2="5.4" y2="-5.35" width="0" layer="46"/>
<wire x1="5.4" y1="-5.35" x2="5.9" y2="-5.85" width="0" layer="46" curve="-90"/>
<wire x1="5.9" y1="-5.85" x2="5.4" y2="-6.35" width="0" layer="46" curve="-90"/>
<wire x1="5.4" y1="-6.35" x2="3.9" y2="-6.35" width="0" layer="46"/>
<wire x1="3.9" y1="-6.35" x2="3.4" y2="-5.85" width="0" layer="46" curve="-90"/>
<wire x1="-6.821" y1="6.7145" x2="-6.5013" y2="6.7145" width="0.1016" layer="21"/>
<wire x1="-6.5013" y1="6.7145" x2="-6.5013" y2="6.1816" width="0.1016" layer="21"/>
<wire x1="-6.5013" y1="6.1816" x2="2.8777" y2="6.1816" width="0.1016" layer="21"/>
<wire x1="2.8777" y1="6.1816" x2="6.9276" y2="6.1816" width="0.1016" layer="51"/>
<wire x1="6.9276" y1="6.1816" x2="7.1408" y2="5.9684" width="0.1016" layer="51" curve="-90"/>
<wire x1="7.1408" y1="5.9684" x2="7.1408" y2="-5.8619" width="0.1016" layer="51"/>
<wire x1="7.1408" y1="-5.8619" x2="6.8211" y2="-6.1816" width="0.1016" layer="51" curve="-89.964168"/>
<wire x1="6.8211" y1="-6.1816" x2="2.8777" y2="-6.1816" width="0.1016" layer="51"/>
<wire x1="2.8777" y1="-6.1816" x2="-6.5013" y2="-6.1816" width="0.1016" layer="21"/>
<wire x1="-6.5013" y1="-6.1816" x2="-6.5013" y2="-6.7145" width="0.1016" layer="21"/>
<wire x1="-6.5013" y1="-6.7145" x2="-6.821" y2="-6.7145" width="0.1016" layer="21"/>
<wire x1="-6.821" y1="-6.7145" x2="-6.821" y2="-5.9684" width="0.1016" layer="21"/>
<wire x1="-6.821" y1="-5.9684" x2="-6.5013" y2="-5.6487" width="0.1016" layer="21" curve="-90.071732"/>
<wire x1="-6.5013" y1="-5.6487" x2="-6.1815" y2="-5.6487" width="0.1016" layer="21"/>
<wire x1="-6.1815" y1="-5.6487" x2="-6.1815" y2="-3.9434" width="0.1016" layer="21"/>
<wire x1="-6.1815" y1="-3.9434" x2="-6.821" y2="-3.9434" width="0.1016" layer="21"/>
<wire x1="-6.821" y1="-3.9434" x2="-6.821" y2="5.1158" width="0.1016" layer="21"/>
<wire x1="-6.821" y1="5.1158" x2="-6.1815" y2="5.1158" width="0.1016" layer="21"/>
<wire x1="-6.1815" y1="5.1158" x2="-6.1815" y2="5.6487" width="0.1016" layer="21"/>
<wire x1="-6.1815" y1="5.6487" x2="-6.5013" y2="5.6487" width="0.1016" layer="21"/>
<wire x1="-6.5013" y1="5.6487" x2="-6.821" y2="5.9684" width="0.1016" layer="21" curve="-90"/>
<wire x1="-6.821" y1="5.9684" x2="-6.821" y2="6.7145" width="0.1016" layer="21"/>
<wire x1="2.8777" y1="6.1816" x2="2.8777" y2="6.5013" width="0.1016" layer="21"/>
<wire x1="2.8777" y1="6.5013" x2="7.0343" y2="6.5013" width="0.1016" layer="51"/>
<wire x1="7.0343" y1="6.5013" x2="7.5672" y2="5.9684" width="0.1016" layer="21" curve="-90"/>
<wire x1="7.5672" y1="5.9684" x2="7.5672" y2="-5.8618" width="0.1016" layer="51"/>
<wire x1="7.5672" y1="-5.8618" x2="6.9277" y2="-6.5013" width="0.1016" layer="21" curve="-89.982084"/>
<wire x1="6.9277" y1="-6.5013" x2="2.8777" y2="-6.5013" width="0.1016" layer="51"/>
<wire x1="2.8777" y1="-6.5013" x2="2.8777" y2="-6.1816" width="0.1016" layer="21"/>
<wire x1="7.5672" y1="-5.8619" x2="8.8461" y2="-5.8619" width="0.1016" layer="21"/>
<wire x1="8.8461" y1="-5.8619" x2="9.2724" y2="-5.4356" width="0.1016" layer="21" curve="90"/>
<wire x1="9.2724" y1="-5.4356" x2="9.2724" y2="-3.9434" width="0.1016" layer="21"/>
<wire x1="9.2724" y1="-3.9434" x2="8.8461" y2="-3.5171" width="0.1016" layer="21" curve="90.026887"/>
<wire x1="8.8461" y1="-3.5171" x2="7.6737" y2="-3.5171" width="0.1016" layer="21"/>
<wire x1="7.6737" y1="5.8618" x2="8.8461" y2="5.8618" width="0.1016" layer="21"/>
<wire x1="8.8461" y1="5.8618" x2="9.2724" y2="5.4355" width="0.1016" layer="21" curve="-90"/>
<wire x1="9.2724" y1="5.4355" x2="9.2724" y2="3.9434" width="0.1016" layer="21"/>
<wire x1="9.2724" y1="3.9434" x2="8.8461" y2="3.5171" width="0.1016" layer="21" curve="-90.026887"/>
<wire x1="8.8461" y1="3.5171" x2="7.6737" y2="3.5171" width="0.1016" layer="21"/>
<wire x1="-4.9026" y1="4.1566" x2="0.9591" y2="4.1566" width="0.1016" layer="21"/>
<wire x1="0.9591" y1="4.1566" x2="1.5987" y2="3.5171" width="0.1016" layer="21" curve="-90.008959"/>
<wire x1="1.5987" y1="3.5171" x2="1.5987" y2="2.025" width="0.1016" layer="21"/>
<wire x1="1.5987" y1="2.025" x2="0.9593" y2="1.3855" width="0.1016" layer="21" curve="-89.991041"/>
<wire x1="0.9593" y1="1.3855" x2="-4.9026" y2="1.3855" width="0.1016" layer="21"/>
<wire x1="-4.9026" y1="1.3855" x2="-4.9026" y2="1.9184" width="0.1016" layer="21" curve="-180"/>
<wire x1="-4.9026" y1="1.9184" x2="-1.7052" y2="2.1316" width="0.1016" layer="21" curve="7.629577"/>
<wire x1="-4.9026" y1="4.1566" x2="-4.9026" y2="3.6237" width="0.1016" layer="21" curve="180"/>
<wire x1="-4.9026" y1="3.6237" x2="-1.7052" y2="3.4105" width="0.1016" layer="21" curve="-7.629577"/>
<wire x1="-1.7052" y1="3.4105" x2="-1.3855" y2="3.6237" width="0.1016" layer="21"/>
<wire x1="-1.7052" y1="2.1316" x2="-1.3855" y2="1.9184" width="0.1016" layer="21"/>
<wire x1="-1.3855" y1="1.9184" x2="0.7461" y2="1.9184" width="0.1016" layer="21"/>
<wire x1="0.7461" y1="1.9184" x2="1.0658" y2="2.2381" width="0.1016" layer="21" curve="90"/>
<wire x1="1.0658" y1="2.2381" x2="1.0658" y2="3.3039" width="0.1016" layer="21"/>
<wire x1="1.0658" y1="3.3039" x2="0.746" y2="3.6237" width="0.1016" layer="21" curve="90"/>
<wire x1="0.746" y1="3.6237" x2="-1.3855" y2="3.6237" width="0.1016" layer="21"/>
<wire x1="-4.9026" y1="-1.3855" x2="0.9591" y2="-1.3855" width="0.1016" layer="21"/>
<wire x1="0.9591" y1="-1.3855" x2="1.5987" y2="-2.025" width="0.1016" layer="21" curve="-90.02688"/>
<wire x1="1.5987" y1="-2.025" x2="1.5987" y2="-3.5171" width="0.1016" layer="21"/>
<wire x1="1.5987" y1="-3.5171" x2="0.9593" y2="-4.1566" width="0.1016" layer="21" curve="-89.991041"/>
<wire x1="0.9593" y1="-4.1566" x2="-4.9026" y2="-4.1566" width="0.1016" layer="21"/>
<wire x1="-4.9026" y1="-4.1566" x2="-4.9026" y2="-3.6237" width="0.1016" layer="21" curve="-180"/>
<wire x1="-4.9026" y1="-3.6237" x2="-1.7052" y2="-3.4105" width="0.1016" layer="21" curve="7.629577"/>
<wire x1="-4.9026" y1="-1.3855" x2="-4.9026" y2="-1.9184" width="0.1016" layer="21" curve="180"/>
<wire x1="-4.9026" y1="-1.9184" x2="-1.7052" y2="-2.1316" width="0.1016" layer="21" curve="-7.629577"/>
<wire x1="-1.7052" y1="-2.1316" x2="-1.3855" y2="-1.9184" width="0.1016" layer="21"/>
<wire x1="-1.7052" y1="-3.4105" x2="-1.3855" y2="-3.6237" width="0.1016" layer="21"/>
<wire x1="-1.3855" y1="-3.6237" x2="0.7461" y2="-3.6237" width="0.1016" layer="21"/>
<wire x1="0.7461" y1="-3.6237" x2="1.0658" y2="-3.304" width="0.1016" layer="21" curve="90"/>
<wire x1="1.0658" y1="-3.304" x2="1.0658" y2="-2.2382" width="0.1016" layer="21"/>
<wire x1="1.0658" y1="-2.2382" x2="0.746" y2="-1.9184" width="0.1016" layer="21" curve="90"/>
<wire x1="0.746" y1="-1.9184" x2="-1.3855" y2="-1.9184" width="0.1016" layer="21"/>
<wire x1="-6.3947" y1="5.0092" x2="-6.3947" y2="-3.8369" width="0.1016" layer="21"/>
<wire x1="7.5672" y1="5.9684" x2="7.5672" y2="3.1382" width="0.1016" layer="21"/>
<wire x1="7.1408" y1="-3.0316" x2="7.1408" y2="-4.8619" width="0.1016" layer="21"/>
<wire x1="7.1408" y1="4.9684" x2="7.1408" y2="3.1381" width="0.1016" layer="21"/>
<wire x1="7.5672" y1="-3.0316" x2="7.5672" y2="-5.8618" width="0.1016" layer="21"/>
<wire x1="2.8777" y1="6.5013" x2="3.5343" y2="6.5013" width="0.1016" layer="21"/>
<wire x1="3.4277" y1="-6.5013" x2="2.8777" y2="-6.5013" width="0.1016" layer="21"/>
<pad name="M1" x="3.9" y="5.85" drill="1" diameter="1.27" shape="offset"/>
<pad name="M3" x="3.9" y="-5.85" drill="1" diameter="1.27" shape="offset"/>
<pad name="M2" x="5.4" y="5.85" drill="1" diameter="1.27" shape="offset"/>
<pad name="M4" x="5.4" y="-5.85" drill="1" diameter="1.27" shape="offset"/>
<smd name="1" x="8.25" y="2.5" dx="2.2" dy="0.7" layer="1"/>
<smd name="2" x="8.25" y="1.5" dx="2.2" dy="0.7" layer="1"/>
<smd name="3" x="8.25" y="0.5" dx="2.2" dy="0.7" layer="1"/>
<smd name="4" x="8.25" y="-0.5" dx="2.2" dy="0.7" layer="1"/>
<smd name="5" x="8.25" y="-1.5" dx="2.2" dy="0.7" layer="1"/>
<smd name="6" x="8.25" y="-2.5" dx="2.2" dy="0.7" layer="1"/>
<text x="1" y="7" size="1.27" layer="25">&gt;NAME</text>
<text x="1" y="-8" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="7.15" y1="2.25" x2="9.05" y2="2.75" layer="51"/>
<rectangle x1="7.15" y1="1.25" x2="9.05" y2="1.75" layer="51"/>
<rectangle x1="7.15" y1="0.25" x2="9.05" y2="0.75" layer="51"/>
<rectangle x1="7.15" y1="-0.75" x2="9.05" y2="-0.25" layer="51"/>
<rectangle x1="7.15" y1="-1.75" x2="9.05" y2="-1.25" layer="51"/>
<rectangle x1="7.15" y1="-2.75" x2="9.05" y2="-2.25" layer="51"/>
<hole x="8.45" y="5" drill="1.6"/>
<hole x="8.45" y="-5" drill="1.6"/>
</package>
<package name=",156_12">
<pad name="3" x="-7.94" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-11.88" y="0.01" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="-15.848" y="-0.02" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-3.97" y="-0.01" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="3.94" y="-0.01" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="7.92" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="11.89" y="-0.01" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="15.84" y="-0.01" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="19.8" y="-0.01" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="23.75" y="-0.01" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="27.71" y="-0.01" drill="1.016" shape="long" rot="R90"/>
<text x="-18.235" y="-5.11" size="1.016" layer="25" ratio="14" rot="R90">&gt;NAME</text>
<text x="-17.3725" y="5.2325" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<text x="-16.1955" y="-2.9675" size="1.016" layer="51" ratio="10">1</text>
<rectangle x1="-12.1181" y1="-0.2281" x2="-11.6419" y2="0.2481" layer="51"/>
<rectangle x1="-16.0861" y1="-0.2581" x2="-15.6099" y2="0.2181" layer="51"/>
<rectangle x1="-4.2081" y1="-0.2481" x2="-3.7319" y2="0.2281" layer="51"/>
<rectangle x1="-8.1781" y1="-0.2381" x2="-7.7019" y2="0.2381" layer="51"/>
<rectangle x1="3.7019" y1="-0.2481" x2="4.1781" y2="0.2281" layer="51"/>
<rectangle x1="-0.2381" y1="-0.2381" x2="0.2381" y2="0.2381" layer="51"/>
<rectangle x1="11.6519" y1="-0.2481" x2="12.1281" y2="0.2281" layer="51"/>
<rectangle x1="7.6819" y1="-0.2381" x2="8.1581" y2="0.2381" layer="51"/>
<rectangle x1="19.5619" y1="-0.2481" x2="20.0381" y2="0.2281" layer="51"/>
<rectangle x1="15.6019" y1="-0.2481" x2="16.0781" y2="0.2281" layer="51"/>
<rectangle x1="27.4719" y1="-0.2481" x2="27.9481" y2="0.2281" layer="51"/>
<rectangle x1="23.5119" y1="-0.2481" x2="23.9881" y2="0.2281" layer="51"/>
<wire x1="-17.39" y1="-5.57" x2="29.31" y2="-5.57" width="0.1524" layer="21"/>
<wire x1="29.31" y1="-5.57" x2="29.31" y2="-5.59" width="0.1524" layer="21"/>
<wire x1="29.31" y1="-5.57" x2="29.31" y2="4.64" width="0.1524" layer="21"/>
<wire x1="29.31" y1="4.64" x2="-17.42" y2="4.64" width="0.1524" layer="21"/>
<wire x1="-17.42" y1="4.64" x2="-17.42" y2="-5.59" width="0.1524" layer="21"/>
<rectangle x1="-16.6" y1="2.76" x2="-15.13" y2="4.37" layer="21"/>
<rectangle x1="-12.64" y1="2.76" x2="-11.17" y2="4.37" layer="21"/>
<rectangle x1="-8.68" y1="2.76" x2="-7.21" y2="4.37" layer="21"/>
<rectangle x1="-4.72" y1="2.76" x2="-3.25" y2="4.37" layer="21"/>
<rectangle x1="-0.76" y1="2.76" x2="0.71" y2="4.37" layer="21"/>
<rectangle x1="3.2" y1="2.76" x2="4.67" y2="4.37" layer="21"/>
<rectangle x1="7.16" y1="2.76" x2="8.63" y2="4.37" layer="21"/>
<rectangle x1="11.12" y1="2.76" x2="12.59" y2="4.37" layer="21"/>
<rectangle x1="15.08" y1="2.76" x2="16.55" y2="4.37" layer="21"/>
<rectangle x1="19.04" y1="2.76" x2="20.51" y2="4.37" layer="21"/>
<rectangle x1="23" y1="2.76" x2="24.47" y2="4.37" layer="21"/>
<rectangle x1="26.96" y1="2.76" x2="28.43" y2="4.37" layer="21"/>
</package>
<package name=",156_9">
<wire x1="-17.39" y1="-5.57" x2="17.88" y2="-5.57" width="0.1524" layer="21"/>
<wire x1="17.88" y1="-5.57" x2="17.88" y2="-5.59" width="0.1524" layer="21"/>
<wire x1="17.88" y1="-5.57" x2="17.88" y2="4.64" width="0.1524" layer="21"/>
<wire x1="17.88" y1="4.64" x2="-17.42" y2="4.64" width="0.1524" layer="21"/>
</package>
</packages>
<symbols>
<symbol name="DVI-I">
<wire x1="-10.16" y1="35.56" x2="-10.16" y2="-27.94" width="0.254" layer="94"/>
<wire x1="-10.16" y1="-27.94" x2="-10.16" y2="-43.18" width="0.254" layer="94"/>
<wire x1="-10.16" y1="-43.18" x2="7.62" y2="-43.18" width="0.254" layer="94"/>
<wire x1="7.62" y1="-43.18" x2="7.62" y2="-27.94" width="0.254" layer="94"/>
<wire x1="7.62" y1="-27.94" x2="7.62" y2="35.56" width="0.254" layer="94"/>
<wire x1="7.62" y1="35.56" x2="-10.16" y2="35.56" width="0.254" layer="94"/>
<wire x1="-10.16" y1="-27.94" x2="7.62" y2="-27.94" width="0.254" layer="94"/>
<text x="-10.16" y="36.83" size="1.778" layer="95">&gt;NAME</text>
<text x="-10.16" y="-45.72" size="1.778" layer="96">&gt;VALUE</text>
<pin name="DATA2-" x="-12.7" y="33.02" length="short" direction="pas"/>
<pin name="DATA2+" x="-12.7" y="30.48" length="short" direction="pas"/>
<pin name="DATA2/4S" x="-12.7" y="27.94" length="short" direction="pas"/>
<pin name="DATA4-" x="-12.7" y="25.4" length="short" direction="pas"/>
<pin name="DATA4+" x="-12.7" y="22.86" length="short" direction="pas"/>
<pin name="DDCCLOCK" x="-12.7" y="20.32" length="short" direction="pas"/>
<pin name="DDCDATA" x="-12.7" y="17.78" length="short" direction="pas"/>
<pin name="AV-SYNC" x="-12.7" y="15.24" length="short" direction="pas"/>
<pin name="DATA1-" x="-12.7" y="12.7" length="short" direction="pas"/>
<pin name="DATA1+" x="-12.7" y="10.16" length="short" direction="pas"/>
<pin name="DATA1/3S" x="-12.7" y="7.62" length="short" direction="pas"/>
<pin name="DATA3-" x="-12.7" y="5.08" length="short" direction="pas"/>
<pin name="DATA3+" x="-12.7" y="2.54" length="short" direction="pas"/>
<pin name="+5V" x="-12.7" y="0" length="short" direction="pwr"/>
<pin name="GND" x="-12.7" y="-2.54" length="short" direction="pwr"/>
<pin name="HOT-PLUG" x="-12.7" y="-5.08" length="short" direction="pas"/>
<pin name="DATA0-" x="-12.7" y="-7.62" length="short" direction="pas"/>
<pin name="DATA0+" x="-12.7" y="-10.16" length="short" direction="pas"/>
<pin name="DATA0/5S" x="-12.7" y="-12.7" length="short" direction="pas"/>
<pin name="DATA5-" x="-12.7" y="-15.24" length="short" direction="pas"/>
<pin name="DATA5+" x="-12.7" y="-17.78" length="short" direction="pas"/>
<pin name="CLOCKS" x="-12.7" y="-20.32" length="short" direction="pas"/>
<pin name="CLOCK+" x="-12.7" y="-22.86" length="short" direction="pas"/>
<pin name="CLOCK-" x="-12.7" y="-25.4" length="short" direction="pas"/>
<pin name="RED" x="-12.7" y="-30.48" length="short" direction="pas"/>
<pin name="GREEN" x="-12.7" y="-33.02" length="short" direction="pas"/>
<pin name="BLUE" x="-12.7" y="-35.56" length="short" direction="pas"/>
<pin name="H-SYNC" x="-12.7" y="-38.1" length="short" direction="pas"/>
<pin name="A-GND" x="-12.7" y="-40.64" length="short" direction="pwr"/>
</symbol>
<symbol name="AGND">
<text x="-2.54" y="2.54" size="1.778" layer="95">&gt;NAME</text>
<pin name="A-GND@1" x="-2.54" y="0" length="short" direction="pwr"/>
</symbol>
<symbol name="DVI-D">
<wire x1="-10.16" y1="30.48" x2="-10.16" y2="-33.02" width="0.254" layer="94"/>
<wire x1="7.62" y1="-33.02" x2="7.62" y2="30.48" width="0.254" layer="94"/>
<wire x1="7.62" y1="30.48" x2="-10.16" y2="30.48" width="0.254" layer="94"/>
<wire x1="-10.16" y1="-33.02" x2="7.62" y2="-33.02" width="0.254" layer="94"/>
<text x="-10.16" y="31.75" size="1.778" layer="95">&gt;NAME</text>
<text x="-10.16" y="-35.56" size="1.778" layer="96">&gt;VALUE</text>
<pin name="DATA2-" x="-12.7" y="27.94" length="short" direction="pas"/>
<pin name="DATA2+" x="-12.7" y="25.4" length="short" direction="pas"/>
<pin name="DATA2/4S" x="-12.7" y="22.86" length="short" direction="pas"/>
<pin name="DATA4-" x="-12.7" y="20.32" length="short" direction="pas"/>
<pin name="DATA4+" x="-12.7" y="17.78" length="short" direction="pas"/>
<pin name="DDCCLOCK" x="-12.7" y="15.24" length="short" direction="pas"/>
<pin name="DDCDATA" x="-12.7" y="12.7" length="short" direction="pas"/>
<pin name="NC" x="-12.7" y="10.16" length="short" direction="pas"/>
<pin name="DATA1-" x="-12.7" y="7.62" length="short" direction="pas"/>
<pin name="DATA1+" x="-12.7" y="5.08" length="short" direction="pas"/>
<pin name="DATA1/3S" x="-12.7" y="2.54" length="short" direction="pas"/>
<pin name="DATA3-" x="-12.7" y="0" length="short" direction="pas"/>
<pin name="DATA3+" x="-12.7" y="-2.54" length="short" direction="pas"/>
<pin name="+5V" x="-12.7" y="-5.08" length="short" direction="pwr"/>
<pin name="GND" x="-12.7" y="-7.62" length="short" direction="pwr"/>
<pin name="HOT-PLUG" x="-12.7" y="-10.16" length="short" direction="pas"/>
<pin name="DATA0-" x="-12.7" y="-12.7" length="short" direction="pas"/>
<pin name="DATA0+" x="-12.7" y="-15.24" length="short" direction="pas"/>
<pin name="DATA0/5S" x="-12.7" y="-17.78" length="short" direction="pas"/>
<pin name="DATA5-" x="-12.7" y="-20.32" length="short" direction="pas"/>
<pin name="DATA5+" x="-12.7" y="-22.86" length="short" direction="pas"/>
<pin name="CLOCKS" x="-12.7" y="-25.4" length="short" direction="pas"/>
<pin name="CLOCK+" x="-12.7" y="-27.94" length="short" direction="pas"/>
<pin name="CLOCK-" x="-12.7" y="-30.48" length="short" direction="pas"/>
</symbol>
<symbol name="MV">
<wire x1="1.27" y1="0" x2="0" y2="0" width="0.6096" layer="94"/>
<text x="2.54" y="-0.762" size="1.524" layer="95">&gt;NAME</text>
<text x="-0.762" y="1.397" size="1.778" layer="96">&gt;VALUE</text>
<pin name="S" x="-2.54" y="0" visible="off" length="short" direction="pas"/>
</symbol>
<symbol name="M">
</symbol>
<symbol name="87360-SCSI">
<wire x1="-7.62" y1="43.18" x2="-5.08" y2="43.18" width="0.254" layer="94"/>
<wire x1="-5.08" y1="43.18" x2="-5.08" y2="44.958" width="0.254" layer="94"/>
<wire x1="-5.08" y1="44.958" x2="2.54" y2="44.958" width="0.254" layer="94"/>
<wire x1="2.54" y1="44.958" x2="2.54" y2="43.18" width="0.254" layer="94"/>
<wire x1="2.54" y1="43.18" x2="5.08" y2="43.18" width="0.254" layer="94"/>
<wire x1="-7.62" y1="25.4" x2="-5.08" y2="25.4" width="0.254" layer="94"/>
<wire x1="-5.08" y1="25.4" x2="-5.08" y2="23.622" width="0.254" layer="94"/>
<wire x1="-5.08" y1="23.622" x2="2.54" y2="23.622" width="0.254" layer="94"/>
<wire x1="2.54" y1="23.622" x2="2.54" y2="25.4" width="0.254" layer="94"/>
<wire x1="2.54" y1="25.4" x2="5.08" y2="25.4" width="0.254" layer="94"/>
<wire x1="5.08" y1="69.85" x2="-7.62" y2="69.85" width="0.254" layer="94"/>
<wire x1="-7.62" y1="69.85" x2="-10.16" y2="67.31" width="0.254" layer="94"/>
<wire x1="5.08" y1="46.99" x2="-7.62" y2="46.99" width="0.254" layer="94"/>
<wire x1="-7.62" y1="46.99" x2="-10.16" y2="49.53" width="0.254" layer="94"/>
<wire x1="2.54" y1="18.034" x2="3.556" y2="16.51" width="0.254" layer="94" curve="-73.739795"/>
<wire x1="-3.302" y1="20.574" x2="2.54" y2="18.034" width="0.254" layer="94"/>
<wire x1="-6.096" y1="18.288" x2="-3.302" y2="20.574" width="0.254" layer="94" curve="-115.057615"/>
<wire x1="2.54" y1="-71.374" x2="3.556" y2="-69.85" width="0.254" layer="94" curve="73.739795"/>
<wire x1="-3.302" y1="-73.914" x2="2.54" y2="-71.374" width="0.254" layer="94"/>
<wire x1="-6.096" y1="-71.628" x2="-3.302" y2="-73.914" width="0.254" layer="94" curve="115.057615"/>
<wire x1="-6.096" y1="18.288" x2="-6.096" y2="16.002" width="0.254" layer="94"/>
<wire x1="-6.096" y1="-69.342" x2="-6.096" y2="-71.628" width="0.254" layer="94"/>
<wire x1="-6.096" y1="-67.818" x2="-6.096" y2="-66.802" width="0.254" layer="94"/>
<wire x1="-6.096" y1="-65.278" x2="-6.096" y2="-64.262" width="0.254" layer="94"/>
<wire x1="-6.096" y1="-62.738" x2="-6.096" y2="-61.722" width="0.254" layer="94"/>
<wire x1="3.556" y1="-69.342" x2="3.556" y2="-69.85" width="0.254" layer="94"/>
<wire x1="-6.096" y1="-60.198" x2="-6.096" y2="-59.182" width="0.254" layer="94"/>
<wire x1="-6.096" y1="-57.658" x2="-6.096" y2="-56.642" width="0.254" layer="94"/>
<wire x1="-6.096" y1="-55.118" x2="-6.096" y2="-54.102" width="0.254" layer="94"/>
<wire x1="-6.096" y1="-52.578" x2="-6.096" y2="-51.562" width="0.254" layer="94"/>
<wire x1="-6.096" y1="-50.038" x2="-6.096" y2="-49.022" width="0.254" layer="94"/>
<wire x1="-6.096" y1="-47.498" x2="-6.096" y2="-46.482" width="0.254" layer="94"/>
<wire x1="-6.096" y1="-44.958" x2="-6.096" y2="-43.942" width="0.254" layer="94"/>
<wire x1="-6.096" y1="-42.418" x2="-6.096" y2="-41.402" width="0.254" layer="94"/>
<wire x1="-6.096" y1="-39.878" x2="-6.096" y2="-38.862" width="0.254" layer="94"/>
<wire x1="-6.096" y1="-37.338" x2="-6.096" y2="-36.322" width="0.254" layer="94"/>
<wire x1="-6.096" y1="-34.798" x2="-6.096" y2="-33.782" width="0.254" layer="94"/>
<wire x1="-6.096" y1="-32.258" x2="-6.096" y2="-31.242" width="0.254" layer="94"/>
<wire x1="-6.096" y1="-29.718" x2="-6.096" y2="-28.702" width="0.254" layer="94"/>
<wire x1="-6.096" y1="-27.178" x2="-6.096" y2="-26.162" width="0.254" layer="94"/>
<wire x1="-6.096" y1="-24.638" x2="-6.096" y2="-23.622" width="0.254" layer="94"/>
<wire x1="-6.096" y1="-22.098" x2="-6.096" y2="-21.082" width="0.254" layer="94"/>
<wire x1="-6.096" y1="-19.558" x2="-6.096" y2="-18.542" width="0.254" layer="94"/>
<wire x1="-6.096" y1="-17.018" x2="-6.096" y2="-16.002" width="0.254" layer="94"/>
<wire x1="-6.096" y1="-14.478" x2="-6.096" y2="-13.462" width="0.254" layer="94"/>
<wire x1="-6.096" y1="-11.938" x2="-6.096" y2="-10.922" width="0.254" layer="94"/>
<wire x1="-6.096" y1="-9.398" x2="-6.096" y2="-8.382" width="0.254" layer="94"/>
<wire x1="-6.096" y1="-6.858" x2="-6.096" y2="-5.842" width="0.254" layer="94"/>
<wire x1="-6.096" y1="-4.318" x2="-6.096" y2="-3.302" width="0.254" layer="94"/>
<wire x1="-6.096" y1="-1.778" x2="-6.096" y2="-0.762" width="0.254" layer="94"/>
<wire x1="-6.096" y1="0.762" x2="-6.096" y2="1.778" width="0.254" layer="94"/>
<wire x1="-6.096" y1="3.302" x2="-6.096" y2="4.318" width="0.254" layer="94"/>
<wire x1="-6.096" y1="5.842" x2="-6.096" y2="6.858" width="0.254" layer="94"/>
<wire x1="-6.096" y1="8.382" x2="-6.096" y2="9.398" width="0.254" layer="94"/>
<wire x1="-6.096" y1="10.922" x2="-6.096" y2="11.938" width="0.254" layer="94"/>
<wire x1="-6.096" y1="13.462" x2="-6.096" y2="14.478" width="0.254" layer="94"/>
<wire x1="3.556" y1="14.478" x2="3.556" y2="13.462" width="0.254" layer="94"/>
<wire x1="3.556" y1="11.938" x2="3.556" y2="10.922" width="0.254" layer="94"/>
<wire x1="3.556" y1="9.398" x2="3.556" y2="8.382" width="0.254" layer="94"/>
<wire x1="3.556" y1="6.858" x2="3.556" y2="5.842" width="0.254" layer="94"/>
<wire x1="3.556" y1="4.318" x2="3.556" y2="3.302" width="0.254" layer="94"/>
<wire x1="3.556" y1="1.778" x2="3.556" y2="0.762" width="0.254" layer="94"/>
<wire x1="3.556" y1="-0.762" x2="3.556" y2="-1.778" width="0.254" layer="94"/>
<wire x1="3.556" y1="-3.302" x2="3.556" y2="-4.318" width="0.254" layer="94"/>
<wire x1="3.556" y1="-5.842" x2="3.556" y2="-6.858" width="0.254" layer="94"/>
<wire x1="3.556" y1="-8.382" x2="3.556" y2="-9.398" width="0.254" layer="94"/>
<wire x1="3.556" y1="-10.922" x2="3.556" y2="-11.938" width="0.254" layer="94"/>
<wire x1="3.556" y1="-13.462" x2="3.556" y2="-14.478" width="0.254" layer="94"/>
<wire x1="3.556" y1="-16.002" x2="3.556" y2="-17.018" width="0.254" layer="94"/>
<wire x1="3.556" y1="-18.542" x2="3.556" y2="-19.558" width="0.254" layer="94"/>
<wire x1="3.556" y1="-21.082" x2="3.556" y2="-22.098" width="0.254" layer="94"/>
<wire x1="3.556" y1="-23.622" x2="3.556" y2="-24.638" width="0.254" layer="94"/>
<wire x1="3.556" y1="-26.162" x2="3.556" y2="-27.178" width="0.254" layer="94"/>
<wire x1="3.556" y1="-28.702" x2="3.556" y2="-29.718" width="0.254" layer="94"/>
<wire x1="3.556" y1="-31.242" x2="3.556" y2="-32.258" width="0.254" layer="94"/>
<wire x1="3.556" y1="-33.782" x2="3.556" y2="-34.798" width="0.254" layer="94"/>
<wire x1="3.556" y1="-36.322" x2="3.556" y2="-37.338" width="0.254" layer="94"/>
<wire x1="3.556" y1="-38.862" x2="3.556" y2="-39.878" width="0.254" layer="94"/>
<wire x1="3.556" y1="-41.402" x2="3.556" y2="-42.418" width="0.254" layer="94"/>
<wire x1="3.556" y1="-43.942" x2="3.556" y2="-44.958" width="0.254" layer="94"/>
<wire x1="3.556" y1="-46.482" x2="3.556" y2="-47.498" width="0.254" layer="94"/>
<wire x1="3.556" y1="-49.022" x2="3.556" y2="-50.038" width="0.254" layer="94"/>
<wire x1="3.556" y1="-51.562" x2="3.556" y2="-52.578" width="0.254" layer="94"/>
<wire x1="3.556" y1="-54.102" x2="3.556" y2="-55.118" width="0.254" layer="94"/>
<wire x1="3.556" y1="-56.642" x2="3.556" y2="-57.658" width="0.254" layer="94"/>
<wire x1="3.556" y1="-59.182" x2="3.556" y2="-60.198" width="0.254" layer="94"/>
<wire x1="3.556" y1="-61.722" x2="3.556" y2="-62.738" width="0.254" layer="94"/>
<wire x1="3.556" y1="-64.262" x2="3.556" y2="-65.278" width="0.254" layer="94"/>
<wire x1="3.556" y1="-66.802" x2="3.556" y2="-67.818" width="0.254" layer="94"/>
<wire x1="3.556" y1="16.51" x2="3.556" y2="16.002" width="0.254" layer="94"/>
<circle x="-1.524" y="66.04" radius="1.016" width="0.254" layer="94"/>
<circle x="-1.524" y="60.96" radius="1.016" width="0.254" layer="94"/>
<circle x="-1.524" y="55.88" radius="1.016" width="0.254" layer="94"/>
<circle x="-1.524" y="50.8" radius="1.016" width="0.254" layer="94"/>
<text x="-10.16" y="71.12" size="1.778" layer="95" font="vector">&gt;NAME</text>
<text x="-10.16" y="-76.2" size="1.778" layer="96" font="vector">&gt;VALUE</text>
<text x="-5.08" y="16.002" size="1.6764" layer="94">1</text>
<text x="-5.334" y="-70.866" size="1.6764" layer="94">34</text>
<text x="-0.254" y="16.002" size="1.6764" layer="94">35</text>
<text x="0" y="-70.866" size="1.6764" layer="94">68</text>
<text x="-4.318" y="41.656" size="1.6764" layer="94">1</text>
<text x="0.508" y="41.656" size="1.6764" layer="94">2</text>
<text x="-4.572" y="25.4" size="1.6764" layer="94">11</text>
<text x="-0.508" y="25.4" size="1.6764" layer="94">12</text>
<rectangle x1="2.032" y1="14.986" x2="2.54" y2="15.494" layer="94"/>
<rectangle x1="2.032" y1="12.446" x2="2.54" y2="12.954" layer="94"/>
<rectangle x1="2.032" y1="9.906" x2="2.54" y2="10.414" layer="94"/>
<rectangle x1="2.032" y1="7.366" x2="2.54" y2="7.874" layer="94"/>
<rectangle x1="2.032" y1="4.826" x2="2.54" y2="5.334" layer="94"/>
<rectangle x1="2.032" y1="2.286" x2="2.54" y2="2.794" layer="94"/>
<rectangle x1="2.032" y1="-0.254" x2="2.54" y2="0.254" layer="94"/>
<rectangle x1="2.032" y1="-2.794" x2="2.54" y2="-2.286" layer="94"/>
<rectangle x1="2.032" y1="-5.334" x2="2.54" y2="-4.826" layer="94"/>
<rectangle x1="2.032" y1="-7.874" x2="2.54" y2="-7.366" layer="94"/>
<rectangle x1="2.032" y1="-10.414" x2="2.54" y2="-9.906" layer="94"/>
<rectangle x1="2.032" y1="-12.954" x2="2.54" y2="-12.446" layer="94"/>
<rectangle x1="2.032" y1="-15.494" x2="2.54" y2="-14.986" layer="94"/>
<rectangle x1="2.032" y1="-18.034" x2="2.54" y2="-17.526" layer="94"/>
<rectangle x1="2.032" y1="-20.574" x2="2.54" y2="-20.066" layer="94"/>
<rectangle x1="2.032" y1="-23.114" x2="2.54" y2="-22.606" layer="94"/>
<rectangle x1="2.032" y1="-25.654" x2="2.54" y2="-25.146" layer="94"/>
<rectangle x1="2.032" y1="-28.194" x2="2.54" y2="-27.686" layer="94"/>
<rectangle x1="2.032" y1="-30.734" x2="2.54" y2="-30.226" layer="94"/>
<rectangle x1="2.032" y1="-33.274" x2="2.54" y2="-32.766" layer="94"/>
<rectangle x1="2.032" y1="-35.814" x2="2.54" y2="-35.306" layer="94"/>
<rectangle x1="2.032" y1="-38.354" x2="2.54" y2="-37.846" layer="94"/>
<rectangle x1="2.032" y1="-40.894" x2="2.54" y2="-40.386" layer="94"/>
<rectangle x1="2.032" y1="-43.434" x2="2.54" y2="-42.926" layer="94"/>
<rectangle x1="2.032" y1="-45.974" x2="2.54" y2="-45.466" layer="94"/>
<rectangle x1="2.032" y1="-48.514" x2="2.54" y2="-48.006" layer="94"/>
<rectangle x1="2.032" y1="-51.054" x2="2.54" y2="-50.546" layer="94"/>
<rectangle x1="2.032" y1="-53.594" x2="2.54" y2="-53.086" layer="94"/>
<rectangle x1="2.032" y1="-56.134" x2="2.54" y2="-55.626" layer="94"/>
<rectangle x1="2.032" y1="-58.674" x2="2.54" y2="-58.166" layer="94"/>
<rectangle x1="2.032" y1="-61.214" x2="2.54" y2="-60.706" layer="94"/>
<rectangle x1="2.032" y1="-63.754" x2="2.54" y2="-63.246" layer="94"/>
<rectangle x1="2.032" y1="-66.294" x2="2.54" y2="-65.786" layer="94"/>
<rectangle x1="2.032" y1="-68.834" x2="2.54" y2="-68.326" layer="94"/>
<rectangle x1="-5.08" y1="-18.034" x2="-4.572" y2="-17.526" layer="94"/>
<rectangle x1="-5.08" y1="-15.494" x2="-4.572" y2="-14.986" layer="94"/>
<rectangle x1="-5.08" y1="-12.954" x2="-4.572" y2="-12.446" layer="94"/>
<rectangle x1="-5.08" y1="-10.414" x2="-4.572" y2="-9.906" layer="94"/>
<rectangle x1="-5.08" y1="-7.874" x2="-4.572" y2="-7.366" layer="94"/>
<rectangle x1="-5.08" y1="-5.334" x2="-4.572" y2="-4.826" layer="94"/>
<rectangle x1="-5.08" y1="-2.794" x2="-4.572" y2="-2.286" layer="94"/>
<rectangle x1="-5.08" y1="-0.254" x2="-4.572" y2="0.254" layer="94"/>
<rectangle x1="-5.08" y1="2.286" x2="-4.572" y2="2.794" layer="94"/>
<rectangle x1="-5.08" y1="4.826" x2="-4.572" y2="5.334" layer="94"/>
<rectangle x1="-5.08" y1="7.366" x2="-4.572" y2="7.874" layer="94"/>
<rectangle x1="-5.08" y1="9.906" x2="-4.572" y2="10.414" layer="94"/>
<rectangle x1="-5.08" y1="12.446" x2="-4.572" y2="12.954" layer="94"/>
<rectangle x1="-5.08" y1="14.986" x2="-4.572" y2="15.494" layer="94"/>
<rectangle x1="-5.08" y1="-53.594" x2="-4.572" y2="-53.086" layer="94"/>
<rectangle x1="-5.08" y1="-51.054" x2="-4.572" y2="-50.546" layer="94"/>
<rectangle x1="-5.08" y1="-48.514" x2="-4.572" y2="-48.006" layer="94"/>
<rectangle x1="-5.08" y1="-45.974" x2="-4.572" y2="-45.466" layer="94"/>
<rectangle x1="-5.08" y1="-43.434" x2="-4.572" y2="-42.926" layer="94"/>
<rectangle x1="-5.08" y1="-40.894" x2="-4.572" y2="-40.386" layer="94"/>
<rectangle x1="-5.08" y1="-38.354" x2="-4.572" y2="-37.846" layer="94"/>
<rectangle x1="-5.08" y1="-35.814" x2="-4.572" y2="-35.306" layer="94"/>
<rectangle x1="-5.08" y1="-33.274" x2="-4.572" y2="-32.766" layer="94"/>
<rectangle x1="-5.08" y1="-30.734" x2="-4.572" y2="-30.226" layer="94"/>
<rectangle x1="-5.08" y1="-28.194" x2="-4.572" y2="-27.686" layer="94"/>
<rectangle x1="-5.08" y1="-25.654" x2="-4.572" y2="-25.146" layer="94"/>
<rectangle x1="-5.08" y1="-23.114" x2="-4.572" y2="-22.606" layer="94"/>
<rectangle x1="-5.08" y1="-20.574" x2="-4.572" y2="-20.066" layer="94"/>
<rectangle x1="-5.08" y1="-68.834" x2="-4.572" y2="-68.326" layer="94"/>
<rectangle x1="-5.08" y1="-66.294" x2="-4.572" y2="-65.786" layer="94"/>
<rectangle x1="-5.08" y1="-63.754" x2="-4.572" y2="-63.246" layer="94"/>
<rectangle x1="-5.08" y1="-61.214" x2="-4.572" y2="-60.706" layer="94"/>
<rectangle x1="-5.08" y1="-58.674" x2="-4.572" y2="-58.166" layer="94"/>
<rectangle x1="-5.08" y1="-56.134" x2="-4.572" y2="-55.626" layer="94"/>
<rectangle x1="1.524" y1="40.132" x2="2.54" y2="41.148" layer="94"/>
<rectangle x1="1.524" y1="37.592" x2="2.54" y2="38.608" layer="94"/>
<rectangle x1="1.524" y1="35.052" x2="2.54" y2="36.068" layer="94"/>
<rectangle x1="1.524" y1="32.512" x2="2.54" y2="33.528" layer="94"/>
<rectangle x1="1.524" y1="29.972" x2="2.54" y2="30.988" layer="94"/>
<rectangle x1="1.524" y1="27.432" x2="2.54" y2="28.448" layer="94"/>
<rectangle x1="-5.08" y1="27.432" x2="-4.064" y2="28.448" layer="94"/>
<rectangle x1="-5.08" y1="29.972" x2="-4.064" y2="30.988" layer="94"/>
<rectangle x1="-5.08" y1="32.512" x2="-4.064" y2="33.528" layer="94"/>
<rectangle x1="-5.08" y1="35.052" x2="-4.064" y2="36.068" layer="94"/>
<rectangle x1="-5.08" y1="37.592" x2="-4.064" y2="38.608" layer="94"/>
<rectangle x1="-5.08" y1="40.132" x2="-4.064" y2="41.148" layer="94"/>
<pin name="P1" x="-5.08" y="66.04" length="short" direction="pas"/>
<pin name="P2" x="-5.08" y="60.96" length="short" direction="pas"/>
<pin name="P3" x="-5.08" y="55.88" length="short" direction="pas"/>
<pin name="P4" x="-5.08" y="50.8" length="short" direction="pas"/>
<pin name="J1" x="-7.62" y="40.64" visible="off" length="short" direction="pas"/>
<pin name="J2" x="5.08" y="40.64" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="J3" x="-7.62" y="38.1" visible="off" length="short" direction="pas"/>
<pin name="J4" x="5.08" y="38.1" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="J5" x="-7.62" y="35.56" visible="off" length="short" direction="pas"/>
<pin name="J6" x="5.08" y="35.56" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="J7" x="-7.62" y="33.02" visible="off" length="short" direction="pas"/>
<pin name="J8" x="5.08" y="33.02" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="J9" x="-7.62" y="30.48" visible="off" length="short" direction="pas"/>
<pin name="J10" x="5.08" y="30.48" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="J11" x="-7.62" y="27.94" visible="off" length="short" direction="pas"/>
<pin name="J12" x="5.08" y="27.94" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="1" x="-7.62" y="15.24" visible="off" length="short" direction="pas"/>
<pin name="2" x="-7.62" y="12.7" visible="off" length="short" direction="pas"/>
<pin name="3" x="-7.62" y="10.16" visible="off" length="short" direction="pas"/>
<pin name="4" x="-7.62" y="7.62" visible="off" length="short" direction="pas"/>
<pin name="5" x="-7.62" y="5.08" visible="off" length="short" direction="pas"/>
<pin name="6" x="-7.62" y="2.54" visible="off" length="short" direction="pas"/>
<pin name="7" x="-7.62" y="0" visible="off" length="short" direction="pas"/>
<pin name="8" x="-7.62" y="-2.54" visible="off" length="short" direction="pas"/>
<pin name="9" x="-7.62" y="-5.08" visible="off" length="short" direction="pas"/>
<pin name="10" x="-7.62" y="-7.62" visible="off" length="short" direction="pas"/>
<pin name="11" x="-7.62" y="-10.16" visible="off" length="short" direction="pas"/>
<pin name="12" x="-7.62" y="-12.7" visible="off" length="short" direction="pas"/>
<pin name="13" x="-7.62" y="-15.24" visible="off" length="short" direction="pas"/>
<pin name="14" x="-7.62" y="-17.78" visible="off" length="short" direction="pas"/>
<pin name="15" x="-7.62" y="-20.32" visible="off" length="short" direction="pas"/>
<pin name="16" x="-7.62" y="-22.86" visible="off" length="short" direction="pas"/>
<pin name="17" x="-7.62" y="-25.4" visible="off" length="short" direction="pas"/>
<pin name="18" x="-7.62" y="-27.94" visible="off" length="short" direction="pas"/>
<pin name="19" x="-7.62" y="-30.48" visible="off" length="short" direction="pas"/>
<pin name="20" x="-7.62" y="-33.02" visible="off" length="short" direction="pas"/>
<pin name="21" x="-7.62" y="-35.56" visible="off" length="short" direction="pas"/>
<pin name="22" x="-7.62" y="-38.1" visible="off" length="short" direction="pas"/>
<pin name="23" x="-7.62" y="-40.64" visible="off" length="short" direction="pas"/>
<pin name="24" x="-7.62" y="-43.18" visible="off" length="short" direction="pas"/>
<pin name="25" x="-7.62" y="-45.72" visible="off" length="short" direction="pas"/>
<pin name="26" x="-7.62" y="-48.26" visible="off" length="short" direction="pas"/>
<pin name="27" x="-7.62" y="-50.8" visible="off" length="short" direction="pas"/>
<pin name="28" x="-7.62" y="-53.34" visible="off" length="short" direction="pas"/>
<pin name="29" x="-7.62" y="-55.88" visible="off" length="short" direction="pas"/>
<pin name="30" x="-7.62" y="-58.42" visible="off" length="short" direction="pas"/>
<pin name="31" x="-7.62" y="-60.96" visible="off" length="short" direction="pas"/>
<pin name="32" x="-7.62" y="-63.5" visible="off" length="short" direction="pas"/>
<pin name="33" x="-7.62" y="-66.04" visible="off" length="short" direction="pas"/>
<pin name="34" x="-7.62" y="-68.58" visible="off" length="short" direction="pas"/>
<pin name="35" x="5.08" y="15.24" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="36" x="5.08" y="12.7" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="37" x="5.08" y="10.16" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="38" x="5.08" y="7.62" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="39" x="5.08" y="5.08" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="40" x="5.08" y="2.54" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="41" x="5.08" y="0" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="42" x="5.08" y="-2.54" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="43" x="5.08" y="-5.08" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="44" x="5.08" y="-7.62" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="45" x="5.08" y="-10.16" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="46" x="5.08" y="-12.7" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="47" x="5.08" y="-15.24" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="48" x="5.08" y="-17.78" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="49" x="5.08" y="-20.32" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="50" x="5.08" y="-22.86" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="51" x="5.08" y="-25.4" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="52" x="5.08" y="-27.94" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="53" x="5.08" y="-30.48" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="54" x="5.08" y="-33.02" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="55" x="5.08" y="-35.56" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="56" x="5.08" y="-38.1" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="57" x="5.08" y="-40.64" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="58" x="5.08" y="-43.18" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="59" x="5.08" y="-45.72" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="60" x="5.08" y="-48.26" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="61" x="5.08" y="-50.8" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="62" x="5.08" y="-53.34" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="63" x="5.08" y="-55.88" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="64" x="5.08" y="-58.42" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="65" x="5.08" y="-60.96" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="66" x="5.08" y="-63.5" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="67" x="5.08" y="-66.04" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="68" x="5.08" y="-68.58" visible="off" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="CON-2X02">
<wire x1="4.445" y1="1.27" x2="-1.905" y2="1.27" width="0.254" layer="94"/>
<wire x1="-1.905" y1="-3.81" x2="-1.905" y2="1.27" width="0.254" layer="94"/>
<wire x1="-1.905" y1="-3.81" x2="4.445" y2="-3.81" width="0.254" layer="94"/>
<wire x1="4.445" y1="1.27" x2="4.445" y2="-3.81" width="0.254" layer="94"/>
<wire x1="-2.54" y1="0" x2="-0.635" y2="0" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="-2.54" x2="-0.635" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="5.08" y1="0" x2="3.175" y2="0" width="0.1524" layer="94"/>
<wire x1="5.08" y1="-2.54" x2="3.175" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="-0.635" y1="0" x2="0.635" y2="0" width="0.4064" layer="94"/>
<wire x1="-0.635" y1="-2.54" x2="0.635" y2="-2.54" width="0.4064" layer="94"/>
<wire x1="1.905" y1="0" x2="3.175" y2="0" width="0.4064" layer="94"/>
<wire x1="1.905" y1="-2.54" x2="3.175" y2="-2.54" width="0.4064" layer="94"/>
<text x="-1.905" y="2.54" size="1.778" layer="95">&gt;NAME</text>
<text x="-1.905" y="-6.6675" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-5.08" y="0" visible="pad" length="short" direction="pas"/>
<pin name="2" x="7.62" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="3" x="-5.08" y="-2.54" visible="pad" length="short" direction="pas"/>
<pin name="4" x="7.62" y="-2.54" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="CON-2X03">
<wire x1="4.445" y1="3.81" x2="-1.905" y2="3.81" width="0.254" layer="94"/>
<wire x1="-1.905" y1="-3.81" x2="-1.905" y2="3.81" width="0.254" layer="94"/>
<wire x1="4.445" y1="3.81" x2="4.445" y2="-3.81" width="0.254" layer="94"/>
<wire x1="-2.54" y1="2.54" x2="-0.635" y2="2.54" width="0.1524" layer="94"/>
<wire x1="5.08" y1="2.54" x2="3.175" y2="2.54" width="0.1524" layer="94"/>
<wire x1="-0.635" y1="2.54" x2="0.635" y2="2.54" width="0.4064" layer="94"/>
<wire x1="1.905" y1="2.54" x2="3.175" y2="2.54" width="0.4064" layer="94"/>
<text x="-1.905" y="5.08" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="-5.08" y="2.54" visible="pad" length="short" direction="pas"/>
<pin name="2" x="7.62" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="3" x="-5.08" y="0" visible="pad" length="short" direction="pas"/>
<pin name="4" x="7.62" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="5" x="-5.08" y="-2.54" visible="pad" length="short" direction="pas"/>
<pin name="6" x="7.62" y="-2.54" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="CON-2X04">
<wire x1="-1.905" y1="-6.35" x2="-1.905" y2="3.81" width="0.254" layer="94"/>
<wire x1="-1.905" y1="-6.35" x2="4.445" y2="-6.35" width="0.254" layer="94"/>
<wire x1="4.445" y1="3.81" x2="4.445" y2="-6.35" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-5.08" x2="-0.635" y2="-5.08" width="0.1524" layer="94"/>
<wire x1="5.08" y1="-5.08" x2="3.175" y2="-5.08" width="0.1524" layer="94"/>
<wire x1="-0.635" y1="-5.08" x2="0.635" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="1.905" y1="-5.08" x2="3.175" y2="-5.08" width="0.4064" layer="94"/>
<text x="-1.905" y="-9.2075" size="1.778" layer="96">&gt;VALUE</text>
<pin name="7" x="-5.08" y="-5.08" visible="pad" length="short" direction="pas"/>
<pin name="8" x="7.62" y="-5.08" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="CON-2X05">
<wire x1="4.445" y1="6.35" x2="-1.905" y2="6.35" width="0.254" layer="94"/>
<wire x1="-1.905" y1="-6.35" x2="-1.905" y2="6.35" width="0.254" layer="94"/>
<wire x1="4.445" y1="6.35" x2="4.445" y2="-6.35" width="0.254" layer="94"/>
<wire x1="-2.54" y1="5.08" x2="-0.635" y2="5.08" width="0.1524" layer="94"/>
<wire x1="5.08" y1="5.08" x2="3.175" y2="5.08" width="0.1524" layer="94"/>
<wire x1="-0.635" y1="5.08" x2="0.635" y2="5.08" width="0.4064" layer="94"/>
<wire x1="1.905" y1="5.08" x2="3.175" y2="5.08" width="0.4064" layer="94"/>
<text x="-1.905" y="7.62" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="-5.08" y="5.08" visible="pad" length="short" direction="pas"/>
<pin name="2" x="7.62" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="3" x="-5.08" y="2.54" visible="pad" length="short" direction="pas"/>
<pin name="4" x="7.62" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="5" x="-5.08" y="0" visible="pad" length="short" direction="pas"/>
<pin name="6" x="7.62" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="7" x="-5.08" y="-2.54" visible="pad" length="short" direction="pas"/>
<pin name="8" x="7.62" y="-2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="9" x="-5.08" y="-5.08" visible="pad" length="short" direction="pas"/>
<pin name="10" x="7.62" y="-5.08" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="CON-2X06">
<wire x1="-1.905" y1="-8.89" x2="-1.905" y2="6.35" width="0.254" layer="94"/>
<wire x1="-1.905" y1="-8.89" x2="4.445" y2="-8.89" width="0.254" layer="94"/>
<wire x1="4.445" y1="6.35" x2="4.445" y2="-8.89" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-7.62" x2="-0.635" y2="-7.62" width="0.1524" layer="94"/>
<wire x1="5.08" y1="-7.62" x2="3.175" y2="-7.62" width="0.1524" layer="94"/>
<wire x1="-0.635" y1="-7.62" x2="0.635" y2="-7.62" width="0.4064" layer="94"/>
<wire x1="1.905" y1="-7.62" x2="3.175" y2="-7.62" width="0.4064" layer="94"/>
<text x="-1.905" y="-11.7475" size="1.778" layer="96">&gt;VALUE</text>
<pin name="11" x="-5.08" y="-7.62" visible="pad" length="short" direction="pas"/>
<pin name="12" x="7.62" y="-7.62" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="CON-2X07">
<wire x1="4.445" y1="8.89" x2="-1.905" y2="8.89" width="0.254" layer="94"/>
<wire x1="-1.905" y1="-8.89" x2="-1.905" y2="8.89" width="0.254" layer="94"/>
<wire x1="4.445" y1="8.89" x2="4.445" y2="-8.89" width="0.254" layer="94"/>
<wire x1="-2.54" y1="7.62" x2="-0.635" y2="7.62" width="0.1524" layer="94"/>
<wire x1="5.08" y1="7.62" x2="3.175" y2="7.62" width="0.1524" layer="94"/>
<wire x1="-0.635" y1="7.62" x2="0.635" y2="7.62" width="0.4064" layer="94"/>
<wire x1="1.905" y1="7.62" x2="3.175" y2="7.62" width="0.4064" layer="94"/>
<text x="-1.905" y="10.16" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="-5.08" y="7.62" visible="pad" length="short" direction="pas"/>
<pin name="2" x="7.62" y="7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="3" x="-5.08" y="5.08" visible="pad" length="short" direction="pas"/>
<pin name="4" x="7.62" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="5" x="-5.08" y="2.54" visible="pad" length="short" direction="pas"/>
<pin name="6" x="7.62" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="7" x="-5.08" y="0" visible="pad" length="short" direction="pas"/>
<pin name="8" x="7.62" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="9" x="-5.08" y="-2.54" visible="pad" length="short" direction="pas"/>
<pin name="10" x="7.62" y="-2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="11" x="-5.08" y="-5.08" visible="pad" length="short" direction="pas"/>
<pin name="12" x="7.62" y="-5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="13" x="-5.08" y="-7.62" visible="pad" length="short" direction="pas"/>
<pin name="14" x="7.62" y="-7.62" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="CON-2X08">
<wire x1="-1.905" y1="-11.43" x2="-1.905" y2="8.89" width="0.254" layer="94"/>
<wire x1="-1.905" y1="-11.43" x2="4.445" y2="-11.43" width="0.254" layer="94"/>
<wire x1="4.445" y1="8.89" x2="4.445" y2="-11.43" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-10.16" x2="-0.635" y2="-10.16" width="0.1524" layer="94"/>
<wire x1="5.08" y1="-10.16" x2="3.175" y2="-10.16" width="0.1524" layer="94"/>
<wire x1="-0.635" y1="-10.16" x2="0.635" y2="-10.16" width="0.4064" layer="94"/>
<wire x1="1.905" y1="-10.16" x2="3.175" y2="-10.16" width="0.4064" layer="94"/>
<text x="-1.905" y="-14.2875" size="1.778" layer="96">&gt;VALUE</text>
<pin name="15" x="-5.08" y="-10.16" visible="pad" length="short" direction="pas"/>
<pin name="16" x="7.62" y="-10.16" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="CON-2X09">
<wire x1="4.445" y1="11.43" x2="-1.905" y2="11.43" width="0.254" layer="94"/>
<wire x1="-1.905" y1="-11.43" x2="-1.905" y2="11.43" width="0.254" layer="94"/>
<wire x1="4.445" y1="11.43" x2="4.445" y2="-11.43" width="0.254" layer="94"/>
<wire x1="-2.54" y1="10.16" x2="-0.635" y2="10.16" width="0.1524" layer="94"/>
<wire x1="5.08" y1="10.16" x2="3.175" y2="10.16" width="0.1524" layer="94"/>
<wire x1="-0.635" y1="10.16" x2="0.635" y2="10.16" width="0.4064" layer="94"/>
<wire x1="1.905" y1="10.16" x2="3.175" y2="10.16" width="0.4064" layer="94"/>
<text x="-1.905" y="12.7" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="-5.08" y="10.16" visible="pad" length="short" direction="pas"/>
<pin name="2" x="7.62" y="10.16" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="3" x="-5.08" y="7.62" visible="pad" length="short" direction="pas"/>
<pin name="4" x="7.62" y="7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="5" x="-5.08" y="5.08" visible="pad" length="short" direction="pas"/>
<pin name="6" x="7.62" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="7" x="-5.08" y="2.54" visible="pad" length="short" direction="pas"/>
<pin name="8" x="7.62" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="9" x="-5.08" y="0" visible="pad" length="short" direction="pas"/>
<pin name="10" x="7.62" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="11" x="-5.08" y="-2.54" visible="pad" length="short" direction="pas"/>
<pin name="12" x="7.62" y="-2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="13" x="-5.08" y="-5.08" visible="pad" length="short" direction="pas"/>
<pin name="14" x="7.62" y="-5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="15" x="-5.08" y="-7.62" visible="pad" length="short" direction="pas"/>
<pin name="16" x="7.62" y="-7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="17" x="-5.08" y="-10.16" visible="pad" length="short" direction="pas"/>
<pin name="18" x="7.62" y="-10.16" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="CON-2X10">
<wire x1="-1.905" y1="-13.97" x2="-1.905" y2="11.43" width="0.254" layer="94"/>
<wire x1="-1.905" y1="-13.97" x2="4.445" y2="-13.97" width="0.254" layer="94"/>
<wire x1="4.445" y1="11.43" x2="4.445" y2="-13.97" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-12.7" x2="-0.635" y2="-12.7" width="0.1524" layer="94"/>
<wire x1="5.08" y1="-12.7" x2="3.175" y2="-12.7" width="0.1524" layer="94"/>
<wire x1="-0.635" y1="-12.7" x2="0.635" y2="-12.7" width="0.4064" layer="94"/>
<wire x1="1.905" y1="-12.7" x2="3.175" y2="-12.7" width="0.4064" layer="94"/>
<text x="-1.905" y="-16.8275" size="1.778" layer="96">&gt;VALUE</text>
<pin name="19" x="-5.08" y="-12.7" visible="pad" length="short" direction="pas"/>
<pin name="20" x="7.62" y="-12.7" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="CON-2X11">
<wire x1="4.445" y1="13.97" x2="-1.905" y2="13.97" width="0.254" layer="94"/>
<wire x1="-1.905" y1="-13.97" x2="-1.905" y2="13.97" width="0.254" layer="94"/>
<wire x1="4.445" y1="13.97" x2="4.445" y2="-13.97" width="0.254" layer="94"/>
<wire x1="-2.54" y1="12.7" x2="-0.635" y2="12.7" width="0.1524" layer="94"/>
<wire x1="5.08" y1="12.7" x2="3.175" y2="12.7" width="0.1524" layer="94"/>
<wire x1="-0.635" y1="12.7" x2="0.635" y2="12.7" width="0.4064" layer="94"/>
<wire x1="1.905" y1="12.7" x2="3.175" y2="12.7" width="0.4064" layer="94"/>
<text x="-1.905" y="15.24" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="-5.08" y="12.7" visible="pad" length="short" direction="pas"/>
<pin name="2" x="7.62" y="12.7" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="3" x="-5.08" y="10.16" visible="pad" length="short" direction="pas"/>
<pin name="4" x="7.62" y="10.16" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="5" x="-5.08" y="7.62" visible="pad" length="short" direction="pas"/>
<pin name="6" x="7.62" y="7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="7" x="-5.08" y="5.08" visible="pad" length="short" direction="pas"/>
<pin name="8" x="7.62" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="9" x="-5.08" y="2.54" visible="pad" length="short" direction="pas"/>
<pin name="10" x="7.62" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="11" x="-5.08" y="0" visible="pad" length="short" direction="pas"/>
<pin name="12" x="7.62" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="13" x="-5.08" y="-2.54" visible="pad" length="short" direction="pas"/>
<pin name="14" x="7.62" y="-2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="15" x="-5.08" y="-5.08" visible="pad" length="short" direction="pas"/>
<pin name="16" x="7.62" y="-5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="17" x="-5.08" y="-7.62" visible="pad" length="short" direction="pas"/>
<pin name="18" x="7.62" y="-7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="19" x="-5.08" y="-10.16" visible="pad" length="short" direction="pas"/>
<pin name="20" x="7.62" y="-10.16" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="21" x="-5.08" y="-12.7" visible="pad" length="short" direction="pas"/>
<pin name="22" x="7.62" y="-12.7" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="CON-2X12">
<wire x1="-1.905" y1="-16.51" x2="-1.905" y2="13.97" width="0.254" layer="94"/>
<wire x1="-1.905" y1="-16.51" x2="4.445" y2="-16.51" width="0.254" layer="94"/>
<wire x1="4.445" y1="13.97" x2="4.445" y2="-16.51" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-15.24" x2="-0.635" y2="-15.24" width="0.1524" layer="94"/>
<wire x1="5.08" y1="-15.24" x2="3.175" y2="-15.24" width="0.1524" layer="94"/>
<wire x1="-0.635" y1="-15.24" x2="0.635" y2="-15.24" width="0.4064" layer="94"/>
<wire x1="1.905" y1="-15.24" x2="3.175" y2="-15.24" width="0.4064" layer="94"/>
<text x="-1.905" y="-19.3675" size="1.778" layer="96">&gt;VALUE</text>
<pin name="23" x="-5.08" y="-15.24" visible="pad" length="short" direction="pas"/>
<pin name="24" x="7.62" y="-15.24" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="CON-2X13">
<wire x1="4.445" y1="16.51" x2="-1.905" y2="16.51" width="0.254" layer="94"/>
<wire x1="-1.905" y1="-16.51" x2="-1.905" y2="16.51" width="0.254" layer="94"/>
<wire x1="4.445" y1="16.51" x2="4.445" y2="-16.51" width="0.254" layer="94"/>
<wire x1="-2.54" y1="15.24" x2="-0.635" y2="15.24" width="0.1524" layer="94"/>
<wire x1="5.08" y1="15.24" x2="3.175" y2="15.24" width="0.1524" layer="94"/>
<wire x1="-0.635" y1="15.24" x2="0.635" y2="15.24" width="0.4064" layer="94"/>
<wire x1="1.905" y1="15.24" x2="3.175" y2="15.24" width="0.4064" layer="94"/>
<text x="-1.905" y="17.78" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="-5.08" y="15.24" visible="pad" length="short" direction="pas"/>
<pin name="2" x="7.62" y="15.24" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="3" x="-5.08" y="12.7" visible="pad" length="short" direction="pas"/>
<pin name="4" x="7.62" y="12.7" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="5" x="-5.08" y="10.16" visible="pad" length="short" direction="pas"/>
<pin name="6" x="7.62" y="10.16" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="7" x="-5.08" y="7.62" visible="pad" length="short" direction="pas"/>
<pin name="8" x="7.62" y="7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="9" x="-5.08" y="5.08" visible="pad" length="short" direction="pas"/>
<pin name="10" x="7.62" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="11" x="-5.08" y="2.54" visible="pad" length="short" direction="pas"/>
<pin name="12" x="7.62" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="13" x="-5.08" y="0" visible="pad" length="short" direction="pas"/>
<pin name="14" x="7.62" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="15" x="-5.08" y="-2.54" visible="pad" length="short" direction="pas"/>
<pin name="16" x="7.62" y="-2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="17" x="-5.08" y="-5.08" visible="pad" length="short" direction="pas"/>
<pin name="18" x="7.62" y="-5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="19" x="-5.08" y="-7.62" visible="pad" length="short" direction="pas"/>
<pin name="20" x="7.62" y="-7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="21" x="-5.08" y="-10.16" visible="pad" length="short" direction="pas"/>
<pin name="22" x="7.62" y="-10.16" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="23" x="-5.08" y="-12.7" visible="pad" length="short" direction="pas"/>
<pin name="24" x="7.62" y="-12.7" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="25" x="-5.08" y="-15.24" visible="pad" length="short" direction="pas"/>
<pin name="26" x="7.62" y="-15.24" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="CON-2X14">
<wire x1="-1.905" y1="-19.05" x2="-1.905" y2="16.51" width="0.254" layer="94"/>
<wire x1="-1.905" y1="-19.05" x2="4.445" y2="-19.05" width="0.254" layer="94"/>
<wire x1="4.445" y1="16.51" x2="4.445" y2="-19.05" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-17.78" x2="-0.635" y2="-17.78" width="0.1524" layer="94"/>
<wire x1="5.08" y1="-17.78" x2="3.175" y2="-17.78" width="0.1524" layer="94"/>
<wire x1="-0.635" y1="-17.78" x2="0.635" y2="-17.78" width="0.4064" layer="94"/>
<wire x1="1.905" y1="-17.78" x2="3.175" y2="-17.78" width="0.4064" layer="94"/>
<text x="-1.905" y="-21.9075" size="1.778" layer="96">&gt;VALUE</text>
<pin name="27" x="-5.08" y="-17.78" visible="pad" length="short" direction="pas"/>
<pin name="28" x="7.62" y="-17.78" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="CON-2X15">
<wire x1="-1.905" y1="-21.59" x2="-1.905" y2="16.51" width="0.254" layer="94"/>
<wire x1="-1.905" y1="-21.59" x2="4.445" y2="-21.59" width="0.254" layer="94"/>
<wire x1="4.445" y1="16.51" x2="4.445" y2="-21.59" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-20.32" x2="-0.635" y2="-20.32" width="0.1524" layer="94"/>
<wire x1="5.08" y1="-20.32" x2="3.175" y2="-20.32" width="0.1524" layer="94"/>
<wire x1="-0.635" y1="-20.32" x2="0.635" y2="-20.32" width="0.4064" layer="94"/>
<wire x1="1.905" y1="-20.32" x2="3.175" y2="-20.32" width="0.4064" layer="94"/>
<text x="-1.905" y="-24.4475" size="1.778" layer="96">&gt;VALUE</text>
<pin name="29" x="-5.08" y="-20.32" visible="pad" length="short" direction="pas"/>
<pin name="30" x="7.62" y="-20.32" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="CON-2X16">
<wire x1="4.445" y1="19.05" x2="-1.905" y2="19.05" width="0.254" layer="94"/>
<wire x1="-1.905" y1="-21.59" x2="-1.905" y2="19.05" width="0.254" layer="94"/>
<wire x1="4.445" y1="19.05" x2="4.445" y2="-21.59" width="0.254" layer="94"/>
<wire x1="-2.54" y1="17.78" x2="-0.635" y2="17.78" width="0.1524" layer="94"/>
<wire x1="5.08" y1="17.78" x2="3.175" y2="17.78" width="0.1524" layer="94"/>
<wire x1="-0.635" y1="17.78" x2="0.635" y2="17.78" width="0.4064" layer="94"/>
<wire x1="1.905" y1="17.78" x2="3.175" y2="17.78" width="0.4064" layer="94"/>
<text x="-1.905" y="20.32" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="-5.08" y="17.78" visible="pad" length="short" direction="pas"/>
<pin name="2" x="7.62" y="17.78" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="3" x="-5.08" y="15.24" visible="pad" length="short" direction="pas"/>
<pin name="4" x="7.62" y="15.24" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="5" x="-5.08" y="12.7" visible="pad" length="short" direction="pas"/>
<pin name="6" x="7.62" y="12.7" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="7" x="-5.08" y="10.16" visible="pad" length="short" direction="pas"/>
<pin name="8" x="7.62" y="10.16" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="9" x="-5.08" y="7.62" visible="pad" length="short" direction="pas"/>
<pin name="10" x="7.62" y="7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="11" x="-5.08" y="5.08" visible="pad" length="short" direction="pas"/>
<pin name="12" x="7.62" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="13" x="-5.08" y="2.54" visible="pad" length="short" direction="pas"/>
<pin name="14" x="7.62" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="15" x="-5.08" y="0" visible="pad" length="short" direction="pas"/>
<pin name="16" x="7.62" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="17" x="-5.08" y="-2.54" visible="pad" length="short" direction="pas"/>
<pin name="18" x="7.62" y="-2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="19" x="-5.08" y="-5.08" visible="pad" length="short" direction="pas"/>
<pin name="20" x="7.62" y="-5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="21" x="-5.08" y="-7.62" visible="pad" length="short" direction="pas"/>
<pin name="22" x="7.62" y="-7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="23" x="-5.08" y="-10.16" visible="pad" length="short" direction="pas"/>
<pin name="24" x="7.62" y="-10.16" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="25" x="-5.08" y="-12.7" visible="pad" length="short" direction="pas"/>
<pin name="26" x="7.62" y="-12.7" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="27" x="-5.08" y="-15.24" visible="pad" length="short" direction="pas"/>
<pin name="28" x="7.62" y="-15.24" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="29" x="-5.08" y="-17.78" visible="pad" length="short" direction="pas"/>
<pin name="30" x="7.62" y="-17.78" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="31" x="-5.08" y="-20.32" visible="pad" length="short" direction="pas"/>
<pin name="32" x="7.62" y="-20.32" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="IEEE1394P6">
<wire x1="5.08" y1="5.588" x2="-2.54" y2="5.588" width="0.254" layer="94"/>
<wire x1="-2.54" y1="5.588" x2="-2.54" y2="-7.874" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-7.874" x2="0" y2="-10.414" width="0.254" layer="94"/>
<wire x1="0" y1="-10.414" x2="2.54" y2="-10.414" width="0.254" layer="94"/>
<wire x1="2.54" y1="-10.414" x2="5.08" y2="-7.874" width="0.254" layer="94"/>
<wire x1="5.08" y1="-7.874" x2="5.08" y2="5.588" width="0.254" layer="94"/>
<text x="-2.54" y="6.35" size="1.778" layer="95" font="vector">&gt;NAME</text>
<text x="-2.54" y="-12.7" size="1.778" layer="96" font="vector">&gt;VALUE</text>
<text x="-0.508" y="2.794" size="1.27" layer="94" font="vector">1</text>
<text x="2.032" y="2.794" size="1.27" layer="94" font="vector">2</text>
<text x="-0.508" y="-6.604" size="1.27" layer="94" font="vector">5</text>
<text x="2.286" y="-6.604" size="1.27" layer="94" font="vector">6</text>
<rectangle x1="0" y1="1.016" x2="0.762" y2="2.54" layer="94"/>
<rectangle x1="0" y1="-2.032" x2="0.762" y2="-0.508" layer="94"/>
<rectangle x1="0" y1="-5.08" x2="0.762" y2="-3.556" layer="94"/>
<rectangle x1="1.778" y1="1.016" x2="2.54" y2="2.54" layer="94"/>
<rectangle x1="1.778" y1="-2.032" x2="2.54" y2="-0.508" layer="94"/>
<rectangle x1="1.778" y1="-5.08" x2="2.54" y2="-3.556" layer="94"/>
<pin name="2" x="-5.08" y="2.54" visible="pad" length="short" direction="pas"/>
<pin name="4" x="-5.08" y="-2.54" visible="pad" length="short" direction="pas"/>
<pin name="5" x="-5.08" y="-5.08" visible="pad" length="short" direction="pas"/>
<pin name="6" x="-5.08" y="-7.62" visible="pad" length="short" direction="pas"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="DVI-I-R" prefix="X">
<description>&lt;b&gt;CONNECTOR&lt;/b&gt;&lt;p&gt;
MiroCross(TM)-DVI i/0 plug and receptacle connector system (scart)</description>
<gates>
<gate name="G$1" symbol="DVI-I" x="0" y="0"/>
<gate name="G" symbol="AGND" x="25.4" y="10.16" addlevel="request"/>
</gates>
<devices>
<device name="" package="DVI-I-R">
<connects>
<connect gate="G" pin="A-GND@1" pad="C6"/>
<connect gate="G$1" pin="+5V" pad="14"/>
<connect gate="G$1" pin="A-GND" pad="C5"/>
<connect gate="G$1" pin="AV-SYNC" pad="8"/>
<connect gate="G$1" pin="BLUE" pad="C3"/>
<connect gate="G$1" pin="CLOCK+" pad="23"/>
<connect gate="G$1" pin="CLOCK-" pad="24"/>
<connect gate="G$1" pin="CLOCKS" pad="22"/>
<connect gate="G$1" pin="DATA0+" pad="18"/>
<connect gate="G$1" pin="DATA0-" pad="17"/>
<connect gate="G$1" pin="DATA0/5S" pad="19"/>
<connect gate="G$1" pin="DATA1+" pad="10"/>
<connect gate="G$1" pin="DATA1-" pad="9"/>
<connect gate="G$1" pin="DATA1/3S" pad="11"/>
<connect gate="G$1" pin="DATA2+" pad="2"/>
<connect gate="G$1" pin="DATA2-" pad="1"/>
<connect gate="G$1" pin="DATA2/4S" pad="3"/>
<connect gate="G$1" pin="DATA3+" pad="13"/>
<connect gate="G$1" pin="DATA3-" pad="12"/>
<connect gate="G$1" pin="DATA4+" pad="5"/>
<connect gate="G$1" pin="DATA4-" pad="4"/>
<connect gate="G$1" pin="DATA5+" pad="21"/>
<connect gate="G$1" pin="DATA5-" pad="20"/>
<connect gate="G$1" pin="DDCCLOCK" pad="6"/>
<connect gate="G$1" pin="DDCDATA" pad="7"/>
<connect gate="G$1" pin="GND" pad="15"/>
<connect gate="G$1" pin="GREEN" pad="C2"/>
<connect gate="G$1" pin="H-SYNC" pad="C4"/>
<connect gate="G$1" pin="HOT-PLUG" pad="16"/>
<connect gate="G$1" pin="RED" pad="C1"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DVI-I-V" prefix="X">
<gates>
<gate name="G" symbol="AGND" x="17.78" y="0" addlevel="request"/>
</gates>
<devices>
<device name="" package="DVI-I-V">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DVI-D-R" prefix="X">
<gates>
<gate name="G$1" symbol="DVI-D" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DVI-D-R">
<connects>
<connect gate="G$1" pin="NC" pad="8"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DVI-D-V" prefix="X">
<gates>
</gates>
<devices>
<device name="" package="DVI-D-V">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="53?-15" prefix="X">
wire to board 1.25 mm (.049 inch) pitch header</description>
<gates>
<gate name="-1" symbol="MV" x="0" y="15.24" addlevel="always" swaplevel="1"/>
<gate name="-2" symbol="M" x="0" y="12.7" addlevel="always" swaplevel="1"/>
<gate name="-3" symbol="M" x="0" y="10.16" addlevel="always" swaplevel="1"/>
<gate name="-4" symbol="M" x="0" y="7.62" addlevel="always" swaplevel="1"/>
<gate name="-5" symbol="M" x="0" y="5.08" addlevel="always" swaplevel="1"/>
<gate name="-6" symbol="M" x="0" y="2.54" addlevel="always" swaplevel="1"/>
<gate name="-7" symbol="M" x="0" y="0" addlevel="always" swaplevel="1"/>
<gate name="-8" symbol="M" x="0" y="-2.54" addlevel="always" swaplevel="1"/>
<gate name="-9" symbol="M" x="0" y="-5.08" addlevel="always" swaplevel="1"/>
<gate name="-10" symbol="M" x="0" y="-7.62" addlevel="always" swaplevel="1"/>
<gate name="-11" symbol="M" x="0" y="-10.16" addlevel="always" swaplevel="1"/>
<gate name="-12" symbol="M" x="0" y="-12.7" addlevel="always" swaplevel="1"/>
<gate name="-13" symbol="M" x="0" y="-15.24" addlevel="always" swaplevel="1"/>
<gate name="-14" symbol="M" x="0" y="-17.78" addlevel="always" swaplevel="1"/>
<gate name="-15" symbol="M" x="0" y="-20.32" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="047" package="53047-15">
<connects>
<connect gate="-1" pin="S" pad="1"/>
<connect gate="-10" pin="S" pad="10"/>
<connect gate="-11" pin="S" pad="11"/>
<connect gate="-12" pin="S" pad="12"/>
<connect gate="-13" pin="S" pad="13"/>
<connect gate="-14" pin="S" pad="14"/>
<connect gate="-15" pin="S" pad="15"/>
<connect gate="-2" pin="S" pad="2"/>
<connect gate="-3" pin="S" pad="3"/>
<connect gate="-4" pin="S" pad="4"/>
<connect gate="-5" pin="S" pad="5"/>
<connect gate="-6" pin="S" pad="6"/>
<connect gate="-7" pin="S" pad="7"/>
<connect gate="-8" pin="S" pad="8"/>
<connect gate="-9" pin="S" pad="9"/>
</connects>
<technologies>
</technologies>
</device>
<device name="048" package="53048-15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="261" package="53261-15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="398" package="53398-15">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="53?-14" prefix="X">
<gates>
</gates>
<devices>
<device name="047" package="53047-14">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="048" package="53048-14">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="261" package="53261-14">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="398" package="53398-14">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="53?-13" prefix="X">
<gates>
</gates>
<devices>
<device name="047" package="53047-13">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="048" package="53048-13">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="261" package="53261-13">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="398" package="53398-13">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="53?-12" prefix="X">
<gates>
<gate name="-1" symbol="MV" x="0" y="12.7" addlevel="always" swaplevel="1"/>
<gate name="-2" symbol="M" x="0" y="10.16" addlevel="always" swaplevel="1"/>
<gate name="-3" symbol="M" x="0" y="7.62" addlevel="always" swaplevel="1"/>
<gate name="-4" symbol="M" x="0" y="5.08" addlevel="always" swaplevel="1"/>
<gate name="-5" symbol="M" x="0" y="2.54" addlevel="always" swaplevel="1"/>
<gate name="-6" symbol="M" x="0" y="0" addlevel="always" swaplevel="1"/>
<gate name="-7" symbol="M" x="0" y="-2.54" addlevel="always" swaplevel="1"/>
<gate name="-8" symbol="M" x="0" y="-5.08" addlevel="always" swaplevel="1"/>
<gate name="-9" symbol="M" x="0" y="-7.62" addlevel="always" swaplevel="1"/>
<gate name="-10" symbol="M" x="0" y="-10.16" addlevel="always" swaplevel="1"/>
<gate name="-11" symbol="M" x="0" y="-12.7" addlevel="always" swaplevel="1"/>
<gate name="-12" symbol="M" x="0" y="-15.24" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="047" package="53047-12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="048" package="53048-12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="261" package="53261-12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="398" package="53398-12">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="53?-11" prefix="X">
<gates>
</gates>
<devices>
<device name="047" package="53047-11">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="048" package="53048-11">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="261" package="53261-11">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="398" package="53398-11">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="53?-10" prefix="X">
<gates>
<gate name="-1" symbol="MV" x="0" y="10.16" addlevel="always" swaplevel="1"/>
<gate name="-2" symbol="M" x="0" y="7.62" addlevel="always" swaplevel="1"/>
<gate name="-3" symbol="M" x="0" y="5.08" addlevel="always" swaplevel="1"/>
<gate name="-4" symbol="M" x="0" y="2.54" addlevel="always" swaplevel="1"/>
<gate name="-5" symbol="M" x="0" y="0" addlevel="always" swaplevel="1"/>
<gate name="-6" symbol="M" x="0" y="-2.54" addlevel="always" swaplevel="1"/>
<gate name="-7" symbol="M" x="0" y="-5.08" addlevel="always" swaplevel="1"/>
<gate name="-8" symbol="M" x="0" y="-7.62" addlevel="always" swaplevel="1"/>
<gate name="-9" symbol="M" x="0" y="-10.16" addlevel="always" swaplevel="1"/>
<gate name="-10" symbol="M" x="0" y="-12.7" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="047" package="53047-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="048" package="53048-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="261" package="53261-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="398" package="53398-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="53?-09" prefix="X">
<gates>
</gates>
<devices>
<device name="047" package="53047-09">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="048" package="53048-09">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="261" package="53261-09">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="398" package="53398-09">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="53?-08" prefix="X">
<gates>
<gate name="-1" symbol="MV" x="0" y="7.62" addlevel="always" swaplevel="1"/>
<gate name="-2" symbol="M" x="0" y="5.08" addlevel="always" swaplevel="1"/>
<gate name="-3" symbol="M" x="0" y="2.54" addlevel="always" swaplevel="1"/>
<gate name="-4" symbol="M" x="0" y="0" addlevel="always" swaplevel="1"/>
<gate name="-5" symbol="M" x="0" y="-2.54" addlevel="always" swaplevel="1"/>
<gate name="-6" symbol="M" x="0" y="-5.08" addlevel="always" swaplevel="1"/>
<gate name="-7" symbol="M" x="0" y="-7.62" addlevel="always" swaplevel="1"/>
<gate name="-8" symbol="M" x="0" y="-10.16" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="047" package="53047-08">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="048" package="53048-08">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="261" package="53261-08">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="398" package="53398-08">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="53?-07" prefix="X">
<gates>
</gates>
<devices>
<device name="047" package="53047-07">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="048" package="53048-07">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="261" package="53261-07">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="398" package="53398-07">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="53?-06" prefix="X">
<gates>
<gate name="-1" symbol="MV" x="0" y="5.08" addlevel="always" swaplevel="1"/>
<gate name="-2" symbol="M" x="0" y="2.54" addlevel="always" swaplevel="1"/>
<gate name="-3" symbol="M" x="0" y="0" addlevel="always" swaplevel="1"/>
<gate name="-4" symbol="M" x="0" y="-2.54" addlevel="always" swaplevel="1"/>
<gate name="-5" symbol="M" x="0" y="-5.08" addlevel="always" swaplevel="1"/>
<gate name="-6" symbol="M" x="0" y="-7.62" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="047" package="53047-06">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="048" package="53048-06">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="261" package="53261-06">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="398" package="53398-06">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="53?-05" prefix="X">
<gates>
</gates>
<devices>
<device name="047" package="53047-05">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="048" package="53048-05">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="261" package="53261-05">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="398" package="53398-05">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="53?-04" prefix="X">
<gates>
<gate name="-1" symbol="MV" x="0" y="2.54" addlevel="always" swaplevel="1"/>
<gate name="-2" symbol="M" x="0" y="0" addlevel="always" swaplevel="1"/>
<gate name="-3" symbol="M" x="0" y="-2.54" addlevel="always" swaplevel="1"/>
<gate name="-4" symbol="M" x="0" y="-5.08" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="047" package="53047-04">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="048" package="53048-04">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="261" package="53261-04">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="398" package="53398-04">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="53?-03" prefix="X">
<gates>
</gates>
<devices>
<device name="047" package="53047-03">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="048" package="53048-03">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="261" package="53261-03">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="398" package="53398-03">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="53?-02" prefix="X">
<gates>
<gate name="-1" symbol="MV" x="0" y="0" addlevel="always" swaplevel="1"/>
<gate name="-2" symbol="M" x="0" y="-2.54" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="047" package="53047-02">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="048" package="53048-02">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="261" package="53261-02">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="398" package="53398-02">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="71061-003" prefix="X">
68-pin 1.27mm (.050 inch) pitch SCSI+ unshielded receptacle&lt;p&gt;
right angle&lt;p&gt;
all plastic</description>
<gates>
<gate name="-1" symbol="MV" x="-10.16" y="40.64" addlevel="always" swaplevel="1"/>
<gate name="-2" symbol="M" x="-10.16" y="38.1" addlevel="always" swaplevel="1"/>
<gate name="-3" symbol="M" x="-10.16" y="35.56" addlevel="always" swaplevel="1"/>
<gate name="-4" symbol="M" x="-10.16" y="33.02" addlevel="always" swaplevel="1"/>
<gate name="-5" symbol="M" x="-10.16" y="30.48" addlevel="always" swaplevel="1"/>
<gate name="-6" symbol="M" x="-10.16" y="27.94" addlevel="always" swaplevel="1"/>
<gate name="-7" symbol="M" x="-10.16" y="25.4" addlevel="always" swaplevel="1"/>
<gate name="-8" symbol="M" x="-10.16" y="22.86" addlevel="always" swaplevel="1"/>
<gate name="-9" symbol="M" x="-10.16" y="20.32" addlevel="always" swaplevel="1"/>
<gate name="-10" symbol="M" x="-10.16" y="17.78" addlevel="always" swaplevel="1"/>
<gate name="-11" symbol="M" x="-10.16" y="15.24" addlevel="always" swaplevel="1"/>
<gate name="-12" symbol="M" x="-10.16" y="12.7" addlevel="always" swaplevel="1"/>
<gate name="-13" symbol="M" x="-10.16" y="10.16" addlevel="always" swaplevel="1"/>
<gate name="-14" symbol="M" x="-10.16" y="7.62" addlevel="always" swaplevel="1"/>
<gate name="-15" symbol="M" x="-10.16" y="5.08" addlevel="always" swaplevel="1"/>
<gate name="-16" symbol="M" x="-10.16" y="2.54" addlevel="always" swaplevel="1"/>
<gate name="-17" symbol="M" x="-10.16" y="0" addlevel="always" swaplevel="1"/>
<gate name="-18" symbol="M" x="-10.16" y="-2.54" addlevel="always" swaplevel="1"/>
<gate name="-19" symbol="M" x="-10.16" y="-5.08" addlevel="always" swaplevel="1"/>
<gate name="-20" symbol="M" x="-10.16" y="-7.62" addlevel="always" swaplevel="1"/>
<gate name="-21" symbol="M" x="-10.16" y="-10.16" addlevel="always" swaplevel="1"/>
<gate name="-22" symbol="M" x="-10.16" y="-12.7" addlevel="always" swaplevel="1"/>
<gate name="-23" symbol="M" x="-10.16" y="-15.24" addlevel="always" swaplevel="1"/>
<gate name="-24" symbol="M" x="-10.16" y="-17.78" addlevel="always" swaplevel="1"/>
<gate name="-25" symbol="M" x="-10.16" y="-20.32" addlevel="always" swaplevel="1"/>
<gate name="-26" symbol="M" x="-10.16" y="-22.86" addlevel="always" swaplevel="1"/>
<gate name="-27" symbol="M" x="-10.16" y="-25.4" addlevel="always" swaplevel="1"/>
<gate name="-28" symbol="M" x="-10.16" y="-27.94" addlevel="always" swaplevel="1"/>
<gate name="-29" symbol="M" x="-10.16" y="-30.48" addlevel="always" swaplevel="1"/>
<gate name="-30" symbol="M" x="-10.16" y="-33.02" addlevel="always" swaplevel="1"/>
<gate name="-31" symbol="M" x="-10.16" y="-35.56" addlevel="always" swaplevel="1"/>
<gate name="-32" symbol="M" x="-10.16" y="-38.1" addlevel="always" swaplevel="1"/>
<gate name="-33" symbol="M" x="-10.16" y="-40.64" addlevel="always" swaplevel="1"/>
<gate name="-34" symbol="M" x="-10.16" y="-43.18" addlevel="always" swaplevel="1"/>
<gate name="-35" symbol="M" x="10.16" y="40.64" addlevel="always" swaplevel="1"/>
<gate name="-36" symbol="M" x="10.16" y="38.1" addlevel="always" swaplevel="1"/>
<gate name="-37" symbol="M" x="10.16" y="35.56" addlevel="always" swaplevel="1"/>
<gate name="-38" symbol="M" x="10.16" y="33.02" addlevel="always" swaplevel="1"/>
<gate name="-39" symbol="M" x="10.16" y="30.48" addlevel="always" swaplevel="1"/>
<gate name="-40" symbol="M" x="10.16" y="27.94" addlevel="always" swaplevel="1"/>
<gate name="-41" symbol="M" x="10.16" y="25.4" addlevel="always" swaplevel="1"/>
<gate name="-42" symbol="M" x="10.16" y="22.86" addlevel="always" swaplevel="1"/>
<gate name="-43" symbol="M" x="10.16" y="20.32" addlevel="always" swaplevel="1"/>
<gate name="-44" symbol="M" x="10.16" y="17.78" addlevel="always" swaplevel="1"/>
<gate name="-45" symbol="M" x="10.16" y="15.24" addlevel="always" swaplevel="1"/>
<gate name="-46" symbol="M" x="10.16" y="12.7" addlevel="always" swaplevel="1"/>
<gate name="-47" symbol="M" x="10.16" y="10.16" addlevel="always" swaplevel="1"/>
<gate name="-48" symbol="M" x="10.16" y="7.62" addlevel="always" swaplevel="1"/>
<gate name="-49" symbol="M" x="10.16" y="5.08" addlevel="always" swaplevel="1"/>
<gate name="-50" symbol="M" x="10.16" y="2.54" addlevel="always" swaplevel="1"/>
<gate name="-51" symbol="M" x="10.16" y="0" addlevel="always" swaplevel="1"/>
<gate name="-52" symbol="M" x="10.16" y="-2.54" addlevel="always" swaplevel="1"/>
<gate name="-53" symbol="M" x="10.16" y="-5.08" addlevel="always" swaplevel="1"/>
<gate name="-54" symbol="M" x="10.16" y="-7.62" addlevel="always" swaplevel="1"/>
<gate name="-55" symbol="M" x="10.16" y="-10.16" addlevel="always" swaplevel="1"/>
<gate name="-56" symbol="M" x="10.16" y="-12.7" addlevel="always" swaplevel="1"/>
<gate name="-57" symbol="M" x="10.16" y="-15.24" addlevel="always" swaplevel="1"/>
<gate name="-58" symbol="M" x="10.16" y="-17.78" addlevel="always" swaplevel="1"/>
<gate name="-59" symbol="M" x="10.16" y="-20.32" addlevel="always" swaplevel="1"/>
<gate name="-60" symbol="M" x="10.16" y="-22.86" addlevel="always" swaplevel="1"/>
<gate name="-61" symbol="M" x="10.16" y="-25.4" addlevel="always" swaplevel="1"/>
<gate name="-62" symbol="M" x="10.16" y="-27.94" addlevel="always" swaplevel="1"/>
<gate name="-63" symbol="M" x="10.16" y="-30.48" addlevel="always" swaplevel="1"/>
<gate name="-64" symbol="M" x="10.16" y="-33.02" addlevel="always" swaplevel="1"/>
<gate name="-65" symbol="M" x="10.16" y="-35.56" addlevel="always" swaplevel="1"/>
<gate name="-66" symbol="M" x="10.16" y="-38.1" addlevel="always" swaplevel="1"/>
<gate name="-67" symbol="M" x="10.16" y="-40.64" addlevel="always" swaplevel="1"/>
<gate name="-68" symbol="M" x="10.16" y="-43.18" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="" package="71061-0003">
<connects>
<connect gate="-16" pin="S" pad="16"/>
<connect gate="-17" pin="S" pad="17"/>
<connect gate="-18" pin="S" pad="18"/>
<connect gate="-19" pin="S" pad="19"/>
<connect gate="-20" pin="S" pad="20"/>
<connect gate="-21" pin="S" pad="21"/>
<connect gate="-22" pin="S" pad="22"/>
<connect gate="-23" pin="S" pad="23"/>
<connect gate="-24" pin="S" pad="24"/>
<connect gate="-25" pin="S" pad="25"/>
<connect gate="-26" pin="S" pad="26"/>
<connect gate="-27" pin="S" pad="27"/>
<connect gate="-28" pin="S" pad="28"/>
<connect gate="-29" pin="S" pad="29"/>
<connect gate="-30" pin="S" pad="30"/>
<connect gate="-31" pin="S" pad="31"/>
<connect gate="-32" pin="S" pad="32"/>
<connect gate="-33" pin="S" pad="33"/>
<connect gate="-34" pin="S" pad="34"/>
<connect gate="-35" pin="S" pad="35"/>
<connect gate="-36" pin="S" pad="36"/>
<connect gate="-37" pin="S" pad="37"/>
<connect gate="-38" pin="S" pad="38"/>
<connect gate="-39" pin="S" pad="39"/>
<connect gate="-40" pin="S" pad="40"/>
<connect gate="-41" pin="S" pad="41"/>
<connect gate="-42" pin="S" pad="42"/>
<connect gate="-43" pin="S" pad="43"/>
<connect gate="-44" pin="S" pad="44"/>
<connect gate="-45" pin="S" pad="45"/>
<connect gate="-46" pin="S" pad="46"/>
<connect gate="-47" pin="S" pad="47"/>
<connect gate="-48" pin="S" pad="48"/>
<connect gate="-49" pin="S" pad="49"/>
<connect gate="-50" pin="S" pad="50"/>
<connect gate="-51" pin="S" pad="51"/>
<connect gate="-52" pin="S" pad="52"/>
<connect gate="-53" pin="S" pad="53"/>
<connect gate="-54" pin="S" pad="54"/>
<connect gate="-55" pin="S" pad="55"/>
<connect gate="-56" pin="S" pad="56"/>
<connect gate="-57" pin="S" pad="57"/>
<connect gate="-58" pin="S" pad="58"/>
<connect gate="-59" pin="S" pad="59"/>
<connect gate="-60" pin="S" pad="60"/>
<connect gate="-61" pin="S" pad="61"/>
<connect gate="-62" pin="S" pad="62"/>
<connect gate="-63" pin="S" pad="63"/>
<connect gate="-64" pin="S" pad="64"/>
<connect gate="-65" pin="S" pad="65"/>
<connect gate="-66" pin="S" pad="66"/>
<connect gate="-67" pin="S" pad="67"/>
<connect gate="-68" pin="S" pad="68"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="71061-001" prefix="X">
50-pin 1.27mm (.050 inch) pitch SCSI+ unshielded receptacle&lt;p&gt;
<gates>
<gate name="-1" symbol="MV" x="-10.16" y="25.4" addlevel="always" swaplevel="1"/>
<gate name="-2" symbol="M" x="-10.16" y="22.86" addlevel="always" swaplevel="1"/>
<gate name="-3" symbol="M" x="-10.16" y="20.32" addlevel="always" swaplevel="1"/>
<gate name="-4" symbol="M" x="-10.16" y="17.78" addlevel="always" swaplevel="1"/>
<gate name="-5" symbol="M" x="-10.16" y="15.24" addlevel="always" swaplevel="1"/>
<gate name="-6" symbol="M" x="-10.16" y="12.7" addlevel="always" swaplevel="1"/>
<gate name="-7" symbol="M" x="-10.16" y="10.16" addlevel="always" swaplevel="1"/>
<gate name="-8" symbol="M" x="-10.16" y="7.62" addlevel="always" swaplevel="1"/>
<gate name="-9" symbol="M" x="-10.16" y="5.08" addlevel="always" swaplevel="1"/>
<gate name="-10" symbol="M" x="-10.16" y="2.54" addlevel="always" swaplevel="1"/>
<gate name="-11" symbol="M" x="-10.16" y="0" addlevel="always" swaplevel="1"/>
<gate name="-12" symbol="M" x="-10.16" y="-2.54" addlevel="always" swaplevel="1"/>
<gate name="-13" symbol="M" x="-10.16" y="-5.08" addlevel="always" swaplevel="1"/>
<gate name="-14" symbol="M" x="-10.16" y="-7.62" addlevel="always" swaplevel="1"/>
<gate name="-15" symbol="M" x="-10.16" y="-10.16" addlevel="always" swaplevel="1"/>
<gate name="-16" symbol="M" x="-10.16" y="-12.7" addlevel="always" swaplevel="1"/>
<gate name="-17" symbol="M" x="-10.16" y="-15.24" addlevel="always" swaplevel="1"/>
<gate name="-18" symbol="M" x="-10.16" y="-17.78" addlevel="always" swaplevel="1"/>
<gate name="-19" symbol="M" x="-10.16" y="-20.32" addlevel="always" swaplevel="1"/>
<gate name="-20" symbol="M" x="-10.16" y="-22.86" addlevel="always" swaplevel="1"/>
<gate name="-21" symbol="M" x="-10.16" y="-25.4" addlevel="always" swaplevel="1"/>
<gate name="-22" symbol="M" x="-10.16" y="-27.94" addlevel="always" swaplevel="1"/>
<gate name="-23" symbol="M" x="-10.16" y="-30.48" addlevel="always" swaplevel="1"/>
<gate name="-24" symbol="M" x="-10.16" y="-33.02" addlevel="always" swaplevel="1"/>
<gate name="-25" symbol="M" x="-10.16" y="-35.56" addlevel="always" swaplevel="1"/>
<gate name="-26" symbol="M" x="7.62" y="25.4" addlevel="always" swaplevel="1"/>
<gate name="-27" symbol="M" x="7.62" y="22.86" addlevel="always" swaplevel="1"/>
<gate name="-28" symbol="M" x="7.62" y="20.32" addlevel="always" swaplevel="1"/>
<gate name="-29" symbol="M" x="7.62" y="17.78" addlevel="always" swaplevel="1"/>
<gate name="-30" symbol="M" x="7.62" y="15.24" addlevel="always" swaplevel="1"/>
<gate name="-31" symbol="M" x="7.62" y="12.7" addlevel="always" swaplevel="1"/>
<gate name="-32" symbol="M" x="7.62" y="10.16" addlevel="always" swaplevel="1"/>
<gate name="-33" symbol="M" x="7.62" y="7.62" addlevel="always" swaplevel="1"/>
<gate name="-34" symbol="M" x="7.62" y="5.08" addlevel="always" swaplevel="1"/>
<gate name="-35" symbol="M" x="7.62" y="2.54" addlevel="always" swaplevel="1"/>
<gate name="-36" symbol="M" x="7.62" y="0" addlevel="always" swaplevel="1"/>
<gate name="-37" symbol="M" x="7.62" y="-2.54" addlevel="always" swaplevel="1"/>
<gate name="-38" symbol="M" x="7.62" y="-5.08" addlevel="always" swaplevel="1"/>
<gate name="-39" symbol="M" x="7.62" y="-7.62" addlevel="always" swaplevel="1"/>
<gate name="-40" symbol="M" x="7.62" y="-10.16" addlevel="always" swaplevel="1"/>
<gate name="-41" symbol="M" x="7.62" y="-12.7" addlevel="always" swaplevel="1"/>
<gate name="-42" symbol="M" x="7.62" y="-15.24" addlevel="always" swaplevel="1"/>
<gate name="-43" symbol="M" x="7.62" y="-17.78" addlevel="always" swaplevel="1"/>
<gate name="-44" symbol="M" x="7.62" y="-20.32" addlevel="always" swaplevel="1"/>
<gate name="-45" symbol="M" x="7.62" y="-22.86" addlevel="always" swaplevel="1"/>
<gate name="-46" symbol="M" x="7.62" y="-25.4" addlevel="always" swaplevel="1"/>
<gate name="-47" symbol="M" x="7.62" y="-27.94" addlevel="always" swaplevel="1"/>
<gate name="-48" symbol="M" x="7.62" y="-30.48" addlevel="always" swaplevel="1"/>
<gate name="-49" symbol="M" x="7.62" y="-33.02" addlevel="always" swaplevel="1"/>
<gate name="-50" symbol="M" x="7.62" y="-35.56" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="" package="71061-0001">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="87360-SCSI" prefix="X">
input/output 3 in 1 combo connector&lt;p&gt;
wide SCSI, 2.00 mm, power, right angle</description>
<gates>
<gate name="G$1" symbol="87360-SCSI" x="0" y="0"/>
</gates>
<devices>
<device name="" package="87360-SCSI">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="10" pad="10"/>
<connect gate="G$1" pin="11" pad="11"/>
<connect gate="G$1" pin="12" pad="12"/>
<connect gate="G$1" pin="13" pad="13"/>
<connect gate="G$1" pin="14" pad="14"/>
<connect gate="G$1" pin="15" pad="15"/>
<connect gate="G$1" pin="16" pad="16"/>
<connect gate="G$1" pin="17" pad="17"/>
<connect gate="G$1" pin="18" pad="18"/>
<connect gate="G$1" pin="19" pad="19"/>
<connect gate="G$1" pin="2" pad="2"/>
<connect gate="G$1" pin="20" pad="20"/>
<connect gate="G$1" pin="21" pad="21"/>
<connect gate="G$1" pin="22" pad="22"/>
<connect gate="G$1" pin="23" pad="23"/>
<connect gate="G$1" pin="24" pad="24"/>
<connect gate="G$1" pin="25" pad="25"/>
<connect gate="G$1" pin="26" pad="26"/>
<connect gate="G$1" pin="27" pad="27"/>
<connect gate="G$1" pin="28" pad="28"/>
<connect gate="G$1" pin="29" pad="29"/>
<connect gate="G$1" pin="3" pad="3"/>
<connect gate="G$1" pin="30" pad="30"/>
<connect gate="G$1" pin="31" pad="31"/>
<connect gate="G$1" pin="32" pad="32"/>
<connect gate="G$1" pin="33" pad="33"/>
<connect gate="G$1" pin="34" pad="34"/>
<connect gate="G$1" pin="35" pad="35"/>
<connect gate="G$1" pin="36" pad="36"/>
<connect gate="G$1" pin="37" pad="37"/>
<connect gate="G$1" pin="38" pad="38"/>
<connect gate="G$1" pin="39" pad="39"/>
<connect gate="G$1" pin="4" pad="4"/>
<connect gate="G$1" pin="40" pad="40"/>
<connect gate="G$1" pin="41" pad="41"/>
<connect gate="G$1" pin="42" pad="42"/>
<connect gate="G$1" pin="43" pad="43"/>
<connect gate="G$1" pin="44" pad="44"/>
<connect gate="G$1" pin="45" pad="45"/>
<connect gate="G$1" pin="46" pad="46"/>
<connect gate="G$1" pin="47" pad="47"/>
<connect gate="G$1" pin="48" pad="48"/>
<connect gate="G$1" pin="49" pad="49"/>
<connect gate="G$1" pin="5" pad="5"/>
<connect gate="G$1" pin="50" pad="50"/>
<connect gate="G$1" pin="51" pad="51"/>
<connect gate="G$1" pin="52" pad="52"/>
<connect gate="G$1" pin="53" pad="53"/>
<connect gate="G$1" pin="54" pad="54"/>
<connect gate="G$1" pin="55" pad="55"/>
<connect gate="G$1" pin="56" pad="56"/>
<connect gate="G$1" pin="57" pad="57"/>
<connect gate="G$1" pin="58" pad="58"/>
<connect gate="G$1" pin="59" pad="59"/>
<connect gate="G$1" pin="6" pad="6"/>
<connect gate="G$1" pin="60" pad="60"/>
<connect gate="G$1" pin="61" pad="61"/>
<connect gate="G$1" pin="62" pad="62"/>
<connect gate="G$1" pin="63" pad="63"/>
<connect gate="G$1" pin="64" pad="64"/>
<connect gate="G$1" pin="65" pad="65"/>
<connect gate="G$1" pin="66" pad="66"/>
<connect gate="G$1" pin="67" pad="67"/>
<connect gate="G$1" pin="68" pad="68"/>
<connect gate="G$1" pin="7" pad="7"/>
<connect gate="G$1" pin="8" pad="8"/>
<connect gate="G$1" pin="9" pad="9"/>
<connect gate="G$1" pin="J1" pad="J1"/>
<connect gate="G$1" pin="J10" pad="J10"/>
<connect gate="G$1" pin="J11" pad="J11"/>
<connect gate="G$1" pin="J12" pad="J12"/>
<connect gate="G$1" pin="J2" pad="J2"/>
<connect gate="G$1" pin="J3" pad="J3"/>
<connect gate="G$1" pin="J4" pad="J4"/>
<connect gate="G$1" pin="J5" pad="J5"/>
<connect gate="G$1" pin="J6" pad="J6"/>
<connect gate="G$1" pin="J7" pad="J7"/>
<connect gate="G$1" pin="J8" pad="J8"/>
<connect gate="G$1" pin="J9" pad="J9"/>
<connect gate="G$1" pin="P1" pad="P1"/>
<connect gate="G$1" pin="P2" pad="P2"/>
<connect gate="G$1" pin="P3" pad="P3"/>
<connect gate="G$1" pin="P4" pad="P4"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="22-23-2021" prefix="X">
<description>.100" (2.54mm) Center Header - 2 Pin</description>
<gates>
</gates>
<devices>
<device name="" package="22-23-2021">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="22-23-2031" prefix="X">
<description>.100" (2.54mm) Center Header - 3 Pin</description>
<gates>
</gates>
<devices>
<device name="" package="22-23-2031">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="22-23-2041" prefix="X">
<description>.100" (2.54mm) Center Header - 4 Pin</description>
<gates>
</gates>
<devices>
<device name="" package="22-23-2041">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="22-23-2051" prefix="X">
<description>.100" (2.54mm) Center Header - 5 Pin</description>
<gates>
</gates>
<devices>
<device name="" package="22-23-2051">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="22-23-2061" prefix="X" uservalue="yes">
<description>.100" (2.54mm) Center Header - 6 Pin</description>
<gates>
</gates>
<devices>
<device name="" package="22-23-2061">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="22-23-2071" prefix="X">
<description>.100" (2.54mm) Center Header - 7 Pin</description>
<gates>
</gates>
<devices>
<device name="" package="22-23-2071">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="22-23-2081" prefix="X">
<description>.100" (2.54mm) Center Header - 8 Pin</description>
<gates>
</gates>
<devices>
<device name="" package="22-23-2081">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="22-23-2091" prefix="X">
<description>.100" (2.54mm) Center Header - 9 Pin</description>
<gates>
</gates>
<devices>
<device name="" package="22-23-2091">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="22-23-2101" prefix="X">
<description>.100" (2.54mm) Center Header - 10 Pin</description>
<gates>
</gates>
<devices>
<device name="" package="22-23-2101">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="22-23-2111" prefix="X">
<description>.100" (2.54mm) Center Header - 11 Pin</description>
<gates>
</gates>
<devices>
<device name="" package="22-23-2111">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="22-23-2121" prefix="X">
<description>.100" (2.54mm) Center Header - 12 Pin</description>
<gates>
</gates>
<devices>
<device name="" package="22-23-2121">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="22-?-02" prefix="J">
wire to board 2.54 mm (.1 inch) pitch header</description>
<gates>
<gate name="-2" symbol="M" x="0" y="-5.08" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="05-7028" package="7395-02">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="27-2021" package="6410-02">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="22-?-03" prefix="J">
<gates>
<gate name="-3" symbol="M" x="0" y="-5.08" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="05-7038" package="7395-03">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="27-2031" package="6410-03">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="22-?-04" prefix="J">
<gates>
<gate name="-4" symbol="M" x="0" y="-10.16" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="05-7048" package="7395-04">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="27-2041" package="6410-04">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="22-?-05" prefix="J">
<gates>
<gate name="-5" symbol="M" x="0" y="-10.16" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="05-7058" package="7395-05">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="27-2051" package="6410-05">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="22-?-06" prefix="J">
<gates>
<gate name="-6" symbol="M" x="0" y="-15.24" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="05-7068" package="7395-06">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="27-2061" package="6410-06">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="22-?-07" prefix="J">
<gates>
<gate name="-6" symbol="M" x="0" y="-10.16" addlevel="always" swaplevel="1"/>
<gate name="-7" symbol="M" x="0" y="-15.24" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="05-7078" package="7395-07">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="27-2071" package="6410-07">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="22-?-08" prefix="J">
<gates>
<gate name="-8" symbol="M" x="0" y="-20.32" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="05-7088" package="7395-08">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="27-2081" package="6410-08">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="22-?-09" prefix="J">
<gates>
<gate name="-1" symbol="MV" x="0" y="20.32" addlevel="always" swaplevel="1"/>
<gate name="-2" symbol="M" x="0" y="15.24" addlevel="always" swaplevel="1"/>
<gate name="-7" symbol="M" x="0" y="-10.16" addlevel="always" swaplevel="1"/>
<gate name="-8" symbol="M" x="0" y="-15.24" addlevel="always" swaplevel="1"/>
<gate name="-9" symbol="M" x="0" y="-20.32" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="05-7098" package="7395-09">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="27-2091" package="6410-09">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="22-?-10" prefix="J">
<gates>
<gate name="-10" symbol="M" x="0" y="-25.4" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="05-7108" package="7395-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="27-2101" package="6410-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="22-?-11" prefix="J">
<gates>
<gate name="-1" symbol="MV" x="0" y="25.4" addlevel="always" swaplevel="1"/>
<gate name="-2" symbol="M" x="0" y="20.32" addlevel="always" swaplevel="1"/>
<gate name="-3" symbol="M" x="0" y="15.24" addlevel="always" swaplevel="1"/>
<gate name="-4" symbol="M" x="0" y="10.16" addlevel="always" swaplevel="1"/>
<gate name="-9" symbol="M" x="0" y="-15.24" addlevel="always" swaplevel="1"/>
<gate name="-10" symbol="M" x="0" y="-20.32" addlevel="always" swaplevel="1"/>
<gate name="-11" symbol="M" x="0" y="-25.4" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="05-7118" package="7395-11">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="27-2111" package="6410-11">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="22-?-12" prefix="J">
<gates>
<gate name="-12" symbol="M" x="0" y="-30.48" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="05-7128" package="7395-12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="27-2121" package="6410-12">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="87832-04" prefix="X">
<description>&lt;b&gt;Milli-Grid Header&lt;/b&gt;&lt;p&gt;
2.00mm (.079") Pitch</description>
<gates>
<gate name="G$1" symbol="CON-2X02" x="0" y="0"/>
</gates>
<devices>
<device name="" package="87832-04">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="87832-06" prefix="X">
<gates>
<gate name="G$1" symbol="CON-2X03" x="0" y="-2.54"/>
</gates>
<devices>
<device name="" package="87832-06">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="87832-08" prefix="X">
<gates>
<gate name="G$1" symbol="CON-2X04" x="0" y="-2.54"/>
</gates>
<devices>
<device name="" package="87832-08">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="87832-10" prefix="X">
<gates>
<gate name="G$1" symbol="CON-2X05" x="0" y="-5.08"/>
</gates>
<devices>
<device name="" package="87832-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="87832-12" prefix="X">
<gates>
<gate name="G$1" symbol="CON-2X06" x="0" y="-5.08"/>
</gates>
<devices>
<device name="" package="87832-12">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="87832-14" prefix="X">
<gates>
<gate name="G$1" symbol="CON-2X07" x="0" y="-7.62"/>
</gates>
<devices>
<device name="" package="87832-14">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="87832-16" prefix="X">
<gates>
<gate name="G$1" symbol="CON-2X08" x="0" y="-7.62"/>
</gates>
<devices>
<device name="" package="87832-16">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="87832-18" prefix="X">
<gates>
<gate name="G$1" symbol="CON-2X09" x="0" y="-10.16"/>
</gates>
<devices>
<device name="" package="87832-18">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="87832-20" prefix="X">
<gates>
<gate name="G$1" symbol="CON-2X10" x="0" y="-10.16"/>
</gates>
<devices>
<device name="" package="87832-20">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="87832-22" prefix="X">
<gates>
<gate name="G$1" symbol="CON-2X11" x="0" y="-12.7"/>
</gates>
<devices>
<device name="" package="87832-22">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="87832-24" prefix="X">
<gates>
<gate name="G$1" symbol="CON-2X12" x="0" y="-12.7"/>
</gates>
<devices>
<device name="" package="87832-24">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="87832-26" prefix="X">
<gates>
<gate name="G$1" symbol="CON-2X13" x="0" y="-15.24"/>
</gates>
<devices>
<device name="" package="87832-26">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="87832-28" prefix="X">
<gates>
<gate name="G$1" symbol="CON-2X14" x="0" y="-15.24"/>
</gates>
<devices>
<device name="" package="87832-28">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="87832-30" prefix="X">
<gates>
<gate name="G$1" symbol="CON-2X15" x="0" y="-15.24"/>
</gates>
<devices>
<device name="" package="87832-30">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="87832-32" prefix="X">
<gates>
<gate name="G$1" symbol="CON-2X16" x="0" y="-17.78"/>
</gates>
<devices>
<device name="" package="87832-32">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="C-GRID-02" prefix="X">
wire to board 2.54 mm (0.100") pitch header</description>
<gates>
<gate name="-2" symbol="M" x="2.54" y="15.24" addlevel="always" swaplevel="1"/>
<gate name="-1" symbol="MV" x="2.54" y="17.78" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="-70543" package="70543-02">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-70553" package="70553-02">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-15-19" package="15-91-02">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="C-GRID-03" prefix="X">
<gates>
<gate name="-1" symbol="MV" x="2.54" y="7.62" addlevel="always" swaplevel="1"/>
<gate name="-2" symbol="M" x="2.54" y="5.08" addlevel="always" swaplevel="1"/>
<gate name="-3" symbol="M" x="2.54" y="2.54" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="-70543" package="70543-03">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-70553" package="70553-03">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-74099" package="74099-03">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-15-91" package="15-91-03">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="C-GRID-04" prefix="X">
<gates>
<gate name="-1" symbol="MV" x="2.54" y="0" addlevel="always" swaplevel="1"/>
<gate name="-2" symbol="M" x="2.54" y="-2.54" addlevel="always" swaplevel="1"/>
<gate name="-3" symbol="M" x="2.54" y="-5.08" addlevel="always" swaplevel="1"/>
<gate name="-4" symbol="M" x="2.54" y="-7.62" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="-70543" package="70543-04">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-70553" package="70553-04">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-74099" package="74099-04">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-15-91" package="15-91-04">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="C-GRID-05" prefix="X">
<gates>
<gate name="-5" symbol="M" x="2.54" y="-10.16" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="-70543" package="70543-05">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-70553" package="70553-05">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-74099" package="74099-05">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-15-91" package="15-91-05">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="C-GRID-06" prefix="X">
<gates>
<gate name="-6" symbol="M" x="2.54" y="-12.7" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="-70543" package="70543-06">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-70553" package="70553-06">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-74099" package="74099-06">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-15-91" package="15-91-06">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="C-GRID-07" prefix="X">
<gates>
<gate name="-7" symbol="M" x="2.54" y="-15.24" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="-70543" package="70543-07">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-70553" package="70553-07">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-74099" package="74099-07">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-15-91" package="15-91-07">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="C-GRID-08" prefix="X">
<gates>
<gate name="-8" symbol="M" x="2.54" y="-17.78" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="-70543" package="70543-08">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-70553" package="70553-08">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-74099" package="74099-08">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-15-91" package="15-91-08">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="C-GRID-09" prefix="X">
<gates>
<gate name="-1" symbol="MV" x="2.54" y="0" swaplevel="1"/>
<gate name="-2" symbol="M" x="2.54" y="-2.54" swaplevel="1"/>
<gate name="-3" symbol="M" x="2.54" y="-5.08" swaplevel="1"/>
<gate name="-4" symbol="M" x="2.54" y="-7.62" swaplevel="1"/>
<gate name="-5" symbol="M" x="2.54" y="-10.16" swaplevel="1"/>
<gate name="-6" symbol="M" x="2.54" y="-12.7" swaplevel="1"/>
<gate name="-7" symbol="M" x="2.54" y="-15.24" swaplevel="1"/>
<gate name="-8" symbol="M" x="2.54" y="-17.78" swaplevel="1"/>
<gate name="-9" symbol="M" x="2.54" y="-20.32" swaplevel="1"/>
</gates>
<devices>
<device name="-70543" package="70543-09">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-70553" package="70553-09">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-74099" package="74099-09">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-15-91" package="15-91-09">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="" package=",156_9">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="C-GRID-10" prefix="X">
<gates>
<gate name="-9" symbol="M" x="2.54" y="-20.32" addlevel="always" swaplevel="1"/>
<gate name="-10" symbol="M" x="2.54" y="-22.86" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="-70543" package="70543-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-70553" package="70553-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-74099" package="74099-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-15-91" package="15-91-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="C-GRID-11" prefix="X">
<gates>
<gate name="-11" symbol="M" x="2.54" y="-25.4" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="-70543" package="70543-11">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-70553" package="70553-11">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-74099" package="74099-11">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-15-91" package="15-91-11">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="C-GRID-12" prefix="X">
<gates>
<gate name="-12" symbol="M" x="2.54" y="-27.94" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="-70543" package="70543-12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-70553" package="70553-12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-74099" package="74099-12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-15-91" package="15-91-12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="" package=",156_12">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="C-GRID-13" prefix="X">
<gates>
<gate name="-13" symbol="M" x="2.54" y="-30.48" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="-70543" package="70543-13">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-70553" package="70553-13">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-74099" package="74099-13">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-15-91" package="15-91-13">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="C-GRID-14" prefix="X">
<gates>
<gate name="-14" symbol="M" x="2.54" y="-33.02" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="-70543" package="70543-14">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-70553" package="70553-14">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-74099" package="74099-14">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-15-91" package="15-91-14">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="C-GRID-15" prefix="X">
<gates>
<gate name="-15" symbol="M" x="2.54" y="-35.56" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="-70543" package="70543-15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-70553" package="70553-15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-74099" package="74099-15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-15-91" package="15-91-15">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="C-GRID-16" prefix="X">
<gates>
<gate name="-1" symbol="MV" x="-15.24" y="35.56" addlevel="always" swaplevel="1"/>
<gate name="-2" symbol="M" x="-15.24" y="33.02" addlevel="always" swaplevel="1"/>
<gate name="-3" symbol="M" x="-15.24" y="30.48" addlevel="always" swaplevel="1"/>
<gate name="-4" symbol="M" x="-15.24" y="27.94" addlevel="always" swaplevel="1"/>
<gate name="-5" symbol="M" x="-15.24" y="25.4" addlevel="always" swaplevel="1"/>
<gate name="-6" symbol="M" x="-15.24" y="22.86" addlevel="always" swaplevel="1"/>
<gate name="-7" symbol="M" x="-15.24" y="20.32" addlevel="always" swaplevel="1"/>
<gate name="-8" symbol="M" x="-15.24" y="17.78" addlevel="always" swaplevel="1"/>
<gate name="-9" symbol="M" x="-15.24" y="15.24" addlevel="always" swaplevel="1"/>
<gate name="-10" symbol="M" x="-15.24" y="12.7" addlevel="always" swaplevel="1"/>
<gate name="-11" symbol="M" x="-15.24" y="10.16" addlevel="always" swaplevel="1"/>
<gate name="-12" symbol="M" x="-15.24" y="7.62" addlevel="always" swaplevel="1"/>
<gate name="-13" symbol="M" x="-15.24" y="5.08" addlevel="always" swaplevel="1"/>
<gate name="-14" symbol="M" x="-15.24" y="2.54" addlevel="always" swaplevel="1"/>
<gate name="-15" symbol="M" x="-15.24" y="0" addlevel="always" swaplevel="1"/>
<gate name="-16" symbol="M" x="-15.24" y="-2.54" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="-70543" package="70543-16">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-70553" package="70553-16">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-74099" package="74099-16">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-15-91" package="15-91-16">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="C-GRID-17" prefix="X">
<gates>
<gate name="-16" symbol="M" x="2.54" y="-38.1" addlevel="always" swaplevel="1"/>
<gate name="-17" symbol="M" x="2.54" y="-40.64" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="-70543" package="70543-17">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-70553" package="70553-17">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="C-GRID-18" prefix="X">
<gates>
<gate name="-18" symbol="M" x="2.54" y="-43.18" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="-70543" package="70543-18">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-70553" package="70553-18">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="C-GRID-19" prefix="X">
<gates>
<gate name="-19" symbol="M" x="2.54" y="-45.72" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="-70543" package="70543-19">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-70553" package="70553-19">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="C-GRID-20" prefix="X">
<gates>
<gate name="-20" symbol="M" x="2.54" y="-48.26" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="-70543" package="70543-20">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-70553" package="70553-20">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="C-GRID-21" prefix="X">
<gates>
<gate name="-21" symbol="M" x="2.54" y="-50.8" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="-70543" package="70543-21">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-70553" package="70553-21">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="C-GRID-22" prefix="X">
<gates>
<gate name="-22" symbol="M" x="2.54" y="-53.34" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="-70543" package="70543-22">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-70553" package="70553-22">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="C-GRID-23" prefix="X">
<gates>
<gate name="-23" symbol="M" x="2.54" y="-55.88" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="-70543" package="70543-23">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-70553" package="70553-23">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="C-GRID-24" prefix="X">
<gates>
<gate name="-24" symbol="M" x="2.54" y="-58.42" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="-70543" package="70543-24">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-70553" package="70553-24">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="C-GRID-25" prefix="X">
<gates>
<gate name="-25" symbol="M" x="2.54" y="-60.96" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="-70543" package="70543-25">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-70553" package="70553-25">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52559-0692" prefix="X">
<description>&lt;b&gt;FFC/FPC&lt;/b&gt;-to-Board  0.50mm (.020") SMT, Vertical, ZIF Receptacle&lt;p&gt;
Source: http://www.molex.com/product/ffc/52559.html</description>
<gates>
<gate name="-1" symbol="MV" x="0" y="7.62" addlevel="always"/>
<gate name="-2" symbol="M" x="0" y="5.08" addlevel="always"/>
<gate name="-3" symbol="M" x="0" y="2.54" addlevel="always"/>
<gate name="-4" symbol="M" x="0" y="0" addlevel="always"/>
<gate name="-5" symbol="M" x="0" y="-2.54" addlevel="always"/>
<gate name="-6" symbol="M" x="0" y="-5.08" addlevel="always"/>
</gates>
<devices>
<device name="" package="52559-0692">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52559-0890" prefix="X">
<gates>
<gate name="-1" symbol="MV" x="2.54" y="10.16" addlevel="always"/>
<gate name="-2" symbol="M" x="2.54" y="7.62" addlevel="always"/>
<gate name="-3" symbol="M" x="2.54" y="5.08" addlevel="always"/>
<gate name="-4" symbol="M" x="2.54" y="2.54" addlevel="always"/>
<gate name="-5" symbol="M" x="2.54" y="0" addlevel="always"/>
<gate name="-6" symbol="M" x="2.54" y="-2.54" addlevel="always"/>
<gate name="-7" symbol="M" x="2.54" y="-5.08" addlevel="always"/>
<gate name="-8" symbol="M" x="2.54" y="-7.62" addlevel="always"/>
</gates>
<devices>
<device name="" package="52559-0890">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52559-0992" prefix="X">
<gates>
<gate name="-1" symbol="MV" x="0" y="12.7" addlevel="always"/>
<gate name="-2" symbol="M" x="0" y="10.16" addlevel="always"/>
<gate name="-3" symbol="M" x="0" y="7.62" addlevel="always"/>
<gate name="-4" symbol="M" x="0" y="5.08" addlevel="always"/>
<gate name="-5" symbol="M" x="0" y="2.54" addlevel="always"/>
<gate name="-6" symbol="M" x="0" y="0" addlevel="always"/>
<gate name="-7" symbol="M" x="0" y="-2.54" addlevel="always"/>
<gate name="-8" symbol="M" x="0" y="-5.08" addlevel="always"/>
<gate name="-9" symbol="M" x="0" y="-7.62" addlevel="always"/>
</gates>
<devices>
<device name="" package="52559-0992">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52559-1092" prefix="X">
<gates>
<gate name="-7" symbol="M" x="0" y="-7.62" addlevel="always"/>
<gate name="-8" symbol="M" x="0" y="-10.16" addlevel="always"/>
<gate name="-9" symbol="M" x="0" y="-12.7" addlevel="always"/>
<gate name="-10" symbol="M" x="0" y="-15.24" addlevel="always"/>
</gates>
<devices>
<device name="" package="52559-1092">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52559-1292" prefix="X">
<gates>
<gate name="-10" symbol="M" x="0" y="-10.16" addlevel="always"/>
<gate name="-11" symbol="M" x="0" y="-12.7" addlevel="always"/>
<gate name="-12" symbol="M" x="0" y="-15.24" addlevel="always"/>
</gates>
<devices>
<device name="" package="52559-1292">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52559-1390" prefix="X">
<gates>
<gate name="-1" symbol="MV" x="0" y="17.78" addlevel="always"/>
<gate name="-2" symbol="M" x="0" y="15.24" addlevel="always"/>
<gate name="-3" symbol="M" x="0" y="12.7" addlevel="always"/>
<gate name="-4" symbol="M" x="0" y="10.16" addlevel="always"/>
<gate name="-5" symbol="M" x="0" y="7.62" addlevel="always"/>
<gate name="-6" symbol="M" x="0" y="5.08" addlevel="always"/>
<gate name="-7" symbol="M" x="0" y="2.54" addlevel="always"/>
<gate name="-8" symbol="M" x="0" y="0" addlevel="always"/>
<gate name="-9" symbol="M" x="0" y="-2.54" addlevel="always"/>
<gate name="-10" symbol="M" x="0" y="-5.08" addlevel="always"/>
<gate name="-11" symbol="M" x="0" y="-7.62" addlevel="always"/>
<gate name="-12" symbol="M" x="0" y="-7.62" addlevel="always"/>
<gate name="-13" symbol="M" x="0" y="-10.16" addlevel="always"/>
</gates>
<devices>
<device name="" package="52559-1390">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52559-1492" prefix="X">
<gates>
<gate name="-1" symbol="MV" x="0" y="15.24" addlevel="always"/>
<gate name="-2" symbol="M" x="0" y="12.7" addlevel="always"/>
<gate name="-3" symbol="M" x="0" y="10.16" addlevel="always"/>
<gate name="-4" symbol="M" x="0" y="7.62" addlevel="always"/>
<gate name="-5" symbol="M" x="0" y="5.08" addlevel="always"/>
<gate name="-6" symbol="M" x="0" y="2.54" addlevel="always"/>
<gate name="-7" symbol="M" x="0" y="0" addlevel="always"/>
<gate name="-8" symbol="M" x="0" y="-2.54" addlevel="always"/>
<gate name="-9" symbol="M" x="0" y="-5.08" addlevel="always"/>
<gate name="-10" symbol="M" x="0" y="-7.62" addlevel="always"/>
<gate name="-11" symbol="M" x="0" y="-10.16" addlevel="always"/>
<gate name="-12" symbol="M" x="0" y="-12.7" addlevel="always"/>
<gate name="-13" symbol="M" x="0" y="-15.24" addlevel="always"/>
<gate name="-14" symbol="M" x="0" y="-17.78" addlevel="always"/>
</gates>
<devices>
<device name="" package="52559-1492">
<connects>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52559-1592" prefix="X">
<gates>
<gate name="-12" symbol="M" x="0" y="-10.16" addlevel="always"/>
<gate name="-13" symbol="M" x="0" y="-12.7" addlevel="always"/>
<gate name="-14" symbol="M" x="0" y="-15.24" addlevel="always"/>
<gate name="-15" symbol="M" x="0" y="-17.78" addlevel="always"/>
</gates>
<devices>
<device name="" package="52559-1592">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52559-1692" prefix="X">
<gates>
<gate name="-16" symbol="M" x="0" y="-20.32" addlevel="always"/>
</gates>
<devices>
<device name="" package="52559-1692">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52559-1792" prefix="X">
<gates>
<gate name="-1" symbol="MV" x="0" y="20.32" addlevel="always"/>
<gate name="-2" symbol="M" x="0" y="17.78" addlevel="always"/>
<gate name="-3" symbol="M" x="0" y="15.24" addlevel="always"/>
<gate name="-4" symbol="M" x="0" y="12.7" addlevel="always"/>
<gate name="-5" symbol="M" x="0" y="10.16" addlevel="always"/>
<gate name="-6" symbol="M" x="0" y="7.62" addlevel="always"/>
<gate name="-7" symbol="M" x="0" y="5.08" addlevel="always"/>
<gate name="-8" symbol="M" x="0" y="2.54" addlevel="always"/>
<gate name="-9" symbol="M" x="0" y="0" addlevel="always"/>
<gate name="-10" symbol="M" x="0" y="-2.54" addlevel="always"/>
<gate name="-11" symbol="M" x="0" y="-5.08" addlevel="always"/>
<gate name="-14" symbol="M" x="0" y="-12.7" addlevel="always"/>
<gate name="-15" symbol="M" x="0" y="-15.24" addlevel="always"/>
<gate name="-16" symbol="M" x="0" y="-17.78" addlevel="always"/>
<gate name="-17" symbol="M" x="0" y="-20.32" addlevel="always"/>
</gates>
<devices>
<device name="" package="52559-1792">
<connects>
<connect gate="-1" pin="S" pad="1"/>
<connect gate="-10" pin="S" pad="10"/>
<connect gate="-11" pin="S" pad="11"/>
<connect gate="-12" pin="S" pad="12"/>
<connect gate="-13" pin="S" pad="13"/>
<connect gate="-14" pin="S" pad="14"/>
<connect gate="-15" pin="S" pad="15"/>
<connect gate="-2" pin="S" pad="2"/>
<connect gate="-3" pin="S" pad="3"/>
<connect gate="-4" pin="S" pad="4"/>
<connect gate="-5" pin="S" pad="5"/>
<connect gate="-6" pin="S" pad="6"/>
<connect gate="-7" pin="S" pad="7"/>
<connect gate="-8" pin="S" pad="8"/>
<connect gate="-9" pin="S" pad="9"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52559-1890" prefix="X">
<gates>
<gate name="-1" symbol="MV" x="0" y="22.86" addlevel="always"/>
<gate name="-2" symbol="M" x="0" y="20.32" addlevel="always"/>
<gate name="-3" symbol="M" x="0" y="17.78" addlevel="always"/>
<gate name="-4" symbol="M" x="0" y="15.24" addlevel="always"/>
<gate name="-5" symbol="M" x="0" y="12.7" addlevel="always"/>
<gate name="-6" symbol="M" x="0" y="10.16" addlevel="always"/>
<gate name="-7" symbol="M" x="0" y="7.62" addlevel="always"/>
<gate name="-8" symbol="M" x="0" y="5.08" addlevel="always"/>
<gate name="-9" symbol="M" x="0" y="2.54" addlevel="always"/>
<gate name="-10" symbol="M" x="0" y="0" addlevel="always"/>
<gate name="-11" symbol="M" x="0" y="-2.54" addlevel="always"/>
<gate name="-12" symbol="M" x="0" y="-5.08" addlevel="always"/>
<gate name="-13" symbol="M" x="0" y="-7.62" addlevel="always"/>
<gate name="-14" symbol="M" x="0" y="-10.16" addlevel="always"/>
<gate name="-15" symbol="M" x="0" y="-12.7" addlevel="always"/>
<gate name="-16" symbol="M" x="0" y="-15.24" addlevel="always"/>
<gate name="-17" symbol="M" x="0" y="-17.78" addlevel="always"/>
<gate name="-18" symbol="M" x="0" y="-20.32" addlevel="always"/>
</gates>
<devices>
<device name="" package="52559-1890">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52559-2092" prefix="X">
<gates>
<gate name="-19" symbol="M" x="0" y="-22.86" addlevel="always"/>
<gate name="-20" symbol="M" x="0" y="-25.4" addlevel="always"/>
</gates>
<devices>
<device name="" package="52559-2092">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52559-2192" prefix="X">
<gates>
<gate name="-18" symbol="M" x="0" y="-22.86" addlevel="always"/>
<gate name="-19" symbol="M" x="0" y="-25.4" addlevel="always"/>
<gate name="-20" symbol="M" x="0" y="-27.94" addlevel="always"/>
<gate name="-21" symbol="M" x="0" y="-30.48" addlevel="always"/>
</gates>
<devices>
<device name="" package="52559-2192">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52559-2290" prefix="X">
<gates>
<gate name="-1" symbol="MV" x="0" y="25.4" addlevel="always"/>
<gate name="-2" symbol="M" x="0" y="22.86" addlevel="always"/>
<gate name="-3" symbol="M" x="0" y="20.32" addlevel="always"/>
<gate name="-4" symbol="M" x="0" y="17.78" addlevel="always"/>
<gate name="-5" symbol="M" x="0" y="15.24" addlevel="always"/>
<gate name="-6" symbol="M" x="0" y="12.7" addlevel="always"/>
<gate name="-7" symbol="M" x="0" y="10.16" addlevel="always"/>
<gate name="-8" symbol="M" x="0" y="7.62" addlevel="always"/>
<gate name="-9" symbol="M" x="0" y="5.08" addlevel="always"/>
<gate name="-10" symbol="M" x="0" y="2.54" addlevel="always"/>
<gate name="-11" symbol="M" x="0" y="0" addlevel="always"/>
<gate name="-12" symbol="M" x="0" y="-2.54" addlevel="always"/>
<gate name="-13" symbol="M" x="0" y="-5.08" addlevel="always"/>
<gate name="-14" symbol="M" x="0" y="-7.62" addlevel="always"/>
<gate name="-15" symbol="M" x="0" y="-10.16" addlevel="always"/>
<gate name="-16" symbol="M" x="0" y="-12.7" addlevel="always"/>
<gate name="-17" symbol="M" x="0" y="-15.24" addlevel="always"/>
<gate name="-18" symbol="M" x="0" y="-17.78" addlevel="always"/>
<gate name="-19" symbol="M" x="0" y="-20.32" addlevel="always"/>
<gate name="-20" symbol="M" x="0" y="-22.86" addlevel="always"/>
<gate name="-21" symbol="M" x="0" y="-25.4" addlevel="always"/>
<gate name="-22" symbol="M" x="0" y="-27.94" addlevel="always"/>
</gates>
<devices>
<device name="" package="52559-2290">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52559-2492" prefix="X">
<gates>
<gate name="-1" symbol="MV" x="0" y="30.48" addlevel="always"/>
<gate name="-2" symbol="M" x="0" y="27.94" addlevel="always"/>
<gate name="-3" symbol="M" x="0" y="25.4" addlevel="always"/>
<gate name="-4" symbol="M" x="0" y="22.86" addlevel="always"/>
<gate name="-5" symbol="M" x="0" y="20.32" addlevel="always"/>
<gate name="-6" symbol="M" x="0" y="17.78" addlevel="always"/>
<gate name="-7" symbol="M" x="0" y="15.24" addlevel="always"/>
<gate name="-8" symbol="M" x="0" y="12.7" addlevel="always"/>
<gate name="-9" symbol="M" x="0" y="10.16" addlevel="always"/>
<gate name="-10" symbol="M" x="0" y="7.62" addlevel="always"/>
<gate name="-11" symbol="M" x="0" y="5.08" addlevel="always"/>
<gate name="-12" symbol="M" x="0" y="2.54" addlevel="always"/>
<gate name="-13" symbol="M" x="0" y="0" addlevel="always"/>
<gate name="-14" symbol="M" x="0" y="-2.54" addlevel="always"/>
<gate name="-15" symbol="M" x="0" y="-5.08" addlevel="always"/>
<gate name="-16" symbol="M" x="0" y="-7.62" addlevel="always"/>
<gate name="-17" symbol="M" x="0" y="-10.16" addlevel="always"/>
<gate name="-18" symbol="M" x="0" y="-12.7" addlevel="always"/>
<gate name="-19" symbol="M" x="0" y="-15.24" addlevel="always"/>
<gate name="-20" symbol="M" x="0" y="-17.78" addlevel="always"/>
<gate name="-21" symbol="M" x="0" y="-20.32" addlevel="always"/>
<gate name="-22" symbol="M" x="0" y="-22.86" addlevel="always"/>
<gate name="-23" symbol="M" x="0" y="-25.4" addlevel="always"/>
<gate name="-24" symbol="M" x="0" y="-27.94" addlevel="always"/>
</gates>
<devices>
<device name="" package="52559-2492">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52559-2590" prefix="X">
<gates>
<gate name="-25" symbol="M" x="0" y="-30.48" addlevel="always"/>
</gates>
<devices>
<device name="" package="52559-2590">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52559-2692" prefix="X">
<gates>
<gate name="-26" symbol="M" x="0" y="-33.02" addlevel="always"/>
</gates>
<devices>
<device name="" package="52559-2692">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52559-2892" prefix="X">
<gates>
<gate name="-27" symbol="M" x="0" y="-35.56" addlevel="always"/>
<gate name="-28" symbol="M" x="0" y="-38.1" addlevel="always"/>
</gates>
<devices>
<device name="" package="52559-2892">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52559-3092" prefix="X">
<gates>
<gate name="-1" symbol="MV" x="0" y="43.18" addlevel="always"/>
<gate name="-2" symbol="M" x="0" y="40.64" addlevel="always"/>
<gate name="-3" symbol="M" x="0" y="38.1" addlevel="always"/>
<gate name="-4" symbol="M" x="0" y="35.56" addlevel="always"/>
<gate name="-5" symbol="M" x="0" y="33.02" addlevel="always"/>
<gate name="-6" symbol="M" x="0" y="30.48" addlevel="always"/>
<gate name="-7" symbol="M" x="0" y="27.94" addlevel="always"/>
<gate name="-8" symbol="M" x="0" y="25.4" addlevel="always"/>
<gate name="-9" symbol="M" x="0" y="22.86" addlevel="always"/>
<gate name="-10" symbol="M" x="0" y="20.32" addlevel="always"/>
<gate name="-11" symbol="M" x="0" y="17.78" addlevel="always"/>
<gate name="-12" symbol="M" x="0" y="15.24" addlevel="always"/>
<gate name="-13" symbol="M" x="0" y="12.7" addlevel="always"/>
<gate name="-14" symbol="M" x="0" y="10.16" addlevel="always"/>
<gate name="-15" symbol="M" x="0" y="7.62" addlevel="always"/>
<gate name="-16" symbol="M" x="0" y="5.08" addlevel="always"/>
<gate name="-17" symbol="M" x="0" y="2.54" addlevel="always"/>
<gate name="-18" symbol="M" x="0" y="0" addlevel="always"/>
<gate name="-19" symbol="M" x="0" y="-2.54" addlevel="always"/>
<gate name="-20" symbol="M" x="0" y="-5.08" addlevel="always"/>
<gate name="-21" symbol="M" x="0" y="-7.62" addlevel="always"/>
<gate name="-22" symbol="M" x="0" y="-10.16" addlevel="always"/>
<gate name="-23" symbol="M" x="0" y="-12.7" addlevel="always"/>
<gate name="-24" symbol="M" x="0" y="-15.24" addlevel="always"/>
<gate name="-25" symbol="M" x="0" y="-17.78" addlevel="always"/>
<gate name="-26" symbol="M" x="0" y="-20.32" addlevel="always"/>
<gate name="-27" symbol="M" x="0" y="-22.86" addlevel="always"/>
<gate name="-28" symbol="M" x="0" y="-25.4" addlevel="always"/>
<gate name="-29" symbol="M" x="0" y="-27.94" addlevel="always"/>
<gate name="-30" symbol="M" x="0" y="-30.48" addlevel="always"/>
</gates>
<devices>
<device name="" package="52559-3092">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52559-3292" prefix="X">
<gates>
<gate name="-1" symbol="MV" x="0" y="48.26" addlevel="always"/>
<gate name="-2" symbol="M" x="0" y="45.72" addlevel="always"/>
<gate name="-3" symbol="M" x="0" y="43.18" addlevel="always"/>
<gate name="-4" symbol="M" x="0" y="40.64" addlevel="always"/>
<gate name="-5" symbol="M" x="0" y="38.1" addlevel="always"/>
<gate name="-6" symbol="M" x="0" y="35.56" addlevel="always"/>
<gate name="-7" symbol="M" x="0" y="33.02" addlevel="always"/>
<gate name="-8" symbol="M" x="0" y="30.48" addlevel="always"/>
<gate name="-9" symbol="M" x="0" y="27.94" addlevel="always"/>
<gate name="-10" symbol="M" x="0" y="25.4" addlevel="always"/>
<gate name="-11" symbol="M" x="0" y="22.86" addlevel="always"/>
<gate name="-12" symbol="M" x="0" y="20.32" addlevel="always"/>
<gate name="-13" symbol="M" x="0" y="17.78" addlevel="always"/>
<gate name="-14" symbol="M" x="0" y="15.24" addlevel="always"/>
<gate name="-15" symbol="M" x="0" y="12.7" addlevel="always"/>
<gate name="-16" symbol="M" x="0" y="10.16" addlevel="always"/>
<gate name="-17" symbol="M" x="0" y="7.62" addlevel="always"/>
<gate name="-18" symbol="M" x="0" y="5.08" addlevel="always"/>
<gate name="-19" symbol="M" x="0" y="2.54" addlevel="always"/>
<gate name="-20" symbol="M" x="0" y="0" addlevel="always"/>
<gate name="-21" symbol="M" x="0" y="-2.54" addlevel="always"/>
<gate name="-22" symbol="M" x="0" y="-5.08" addlevel="always"/>
<gate name="-23" symbol="M" x="0" y="-7.62" addlevel="always"/>
<gate name="-24" symbol="M" x="0" y="-10.16" addlevel="always"/>
<gate name="-25" symbol="M" x="0" y="-12.7" addlevel="always"/>
<gate name="-26" symbol="M" x="0" y="-15.24" addlevel="always"/>
<gate name="-27" symbol="M" x="0" y="-17.78" addlevel="always"/>
<gate name="-28" symbol="M" x="0" y="-20.32" addlevel="always"/>
<gate name="-29" symbol="M" x="0" y="-22.86" addlevel="always"/>
<gate name="-30" symbol="M" x="0" y="-25.4" addlevel="always"/>
<gate name="-31" symbol="M" x="0" y="-27.94" addlevel="always"/>
<gate name="-32" symbol="M" x="0" y="-30.48" addlevel="always"/>
</gates>
<devices>
<device name="" package="52559-3292">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52559-3390" prefix="X">
<gates>
<gate name="-1" symbol="MV" x="0" y="40.64" addlevel="always"/>
<gate name="-2" symbol="M" x="0" y="38.1" addlevel="always"/>
<gate name="-3" symbol="M" x="0" y="35.56" addlevel="always"/>
<gate name="-4" symbol="M" x="0" y="33.02" addlevel="always"/>
<gate name="-5" symbol="M" x="0" y="30.48" addlevel="always"/>
<gate name="-6" symbol="M" x="0" y="27.94" addlevel="always"/>
<gate name="-7" symbol="M" x="0" y="25.4" addlevel="always"/>
<gate name="-8" symbol="M" x="0" y="22.86" addlevel="always"/>
<gate name="-9" symbol="M" x="0" y="20.32" addlevel="always"/>
<gate name="-10" symbol="M" x="0" y="17.78" addlevel="always"/>
<gate name="-11" symbol="M" x="0" y="15.24" addlevel="always"/>
<gate name="-12" symbol="M" x="0" y="12.7" addlevel="always"/>
<gate name="-13" symbol="M" x="0" y="10.16" addlevel="always"/>
<gate name="-14" symbol="M" x="0" y="7.62" addlevel="always"/>
<gate name="-15" symbol="M" x="0" y="5.08" addlevel="always"/>
<gate name="-16" symbol="M" x="0" y="2.54" addlevel="always"/>
<gate name="-17" symbol="M" x="0" y="0" addlevel="always"/>
<gate name="-18" symbol="M" x="0" y="-2.54" addlevel="always"/>
<gate name="-19" symbol="M" x="0" y="-5.08" addlevel="always"/>
<gate name="-20" symbol="M" x="0" y="-7.62" addlevel="always"/>
<gate name="-21" symbol="M" x="0" y="-10.16" addlevel="always"/>
<gate name="-22" symbol="M" x="0" y="-12.7" addlevel="always"/>
<gate name="-23" symbol="M" x="0" y="-15.24" addlevel="always"/>
<gate name="-24" symbol="M" x="0" y="-17.78" addlevel="always"/>
<gate name="-25" symbol="M" x="0" y="-20.32" addlevel="always"/>
<gate name="-26" symbol="M" x="0" y="-22.86" addlevel="always"/>
<gate name="-27" symbol="M" x="0" y="-25.4" addlevel="always"/>
<gate name="-28" symbol="M" x="0" y="-27.94" addlevel="always"/>
<gate name="-29" symbol="M" x="0" y="-30.48" addlevel="always"/>
<gate name="-30" symbol="M" x="0" y="-33.02" addlevel="always"/>
<gate name="-31" symbol="M" x="0" y="-35.56" addlevel="always"/>
<gate name="-32" symbol="M" x="0" y="-38.1" addlevel="always"/>
<gate name="-33" symbol="M" x="0" y="-40.64" addlevel="always"/>
</gates>
<devices>
<device name="" package="52559-3390">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52559-3692" prefix="X">
<gates>
<gate name="-1" symbol="MV" x="0" y="45.72" addlevel="always"/>
<gate name="-2" symbol="M" x="0" y="43.18" addlevel="always"/>
<gate name="-3" symbol="M" x="0" y="40.64" addlevel="always"/>
<gate name="-4" symbol="M" x="0" y="38.1" addlevel="always"/>
<gate name="-5" symbol="M" x="0" y="35.56" addlevel="always"/>
<gate name="-6" symbol="M" x="0" y="33.02" addlevel="always"/>
<gate name="-7" symbol="M" x="0" y="30.48" addlevel="always"/>
<gate name="-8" symbol="M" x="0" y="27.94" addlevel="always"/>
<gate name="-9" symbol="M" x="0" y="25.4" addlevel="always"/>
<gate name="-10" symbol="M" x="0" y="22.86" addlevel="always"/>
<gate name="-11" symbol="M" x="0" y="20.32" addlevel="always"/>
<gate name="-12" symbol="M" x="0" y="17.78" addlevel="always"/>
<gate name="-13" symbol="M" x="0" y="15.24" addlevel="always"/>
<gate name="-14" symbol="M" x="0" y="12.7" addlevel="always"/>
<gate name="-15" symbol="M" x="0" y="10.16" addlevel="always"/>
<gate name="-16" symbol="M" x="0" y="7.62" addlevel="always"/>
<gate name="-17" symbol="M" x="0" y="5.08" addlevel="always"/>
<gate name="-18" symbol="M" x="0" y="2.54" addlevel="always"/>
<gate name="-19" symbol="M" x="0" y="0" addlevel="always"/>
<gate name="-20" symbol="M" x="0" y="-2.54" addlevel="always"/>
<gate name="-21" symbol="M" x="0" y="-5.08" addlevel="always"/>
<gate name="-22" symbol="M" x="0" y="-7.62" addlevel="always"/>
<gate name="-23" symbol="M" x="0" y="-10.16" addlevel="always"/>
<gate name="-24" symbol="M" x="0" y="-12.7" addlevel="always"/>
<gate name="-25" symbol="M" x="0" y="-15.24" addlevel="always"/>
<gate name="-26" symbol="M" x="0" y="-17.78" addlevel="always"/>
<gate name="-27" symbol="M" x="0" y="-20.32" addlevel="always"/>
<gate name="-28" symbol="M" x="0" y="-22.86" addlevel="always"/>
<gate name="-29" symbol="M" x="0" y="-25.4" addlevel="always"/>
<gate name="-30" symbol="M" x="0" y="-27.94" addlevel="always"/>
<gate name="-31" symbol="M" x="0" y="-30.48" addlevel="always"/>
<gate name="-32" symbol="M" x="0" y="-33.02" addlevel="always"/>
<gate name="-33" symbol="M" x="0" y="-35.56" addlevel="always"/>
<gate name="-34" symbol="M" x="0" y="-38.1" addlevel="always"/>
<gate name="-35" symbol="M" x="0" y="-40.64" addlevel="always"/>
<gate name="-36" symbol="M" x="0" y="-43.18" addlevel="always"/>
</gates>
<devices>
<device name="" package="52559-3692">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52559-4092" prefix="X">
<gates>
<gate name="-37" symbol="M" x="0" y="-45.72" addlevel="always"/>
<gate name="-38" symbol="M" x="0" y="-48.26" addlevel="always"/>
<gate name="-39" symbol="M" x="0" y="-50.8" addlevel="always"/>
<gate name="-40" symbol="M" x="0" y="-53.34" addlevel="always"/>
</gates>
<devices>
<device name="" package="52559-4092">
<connects>
<connect gate="-16" pin="S" pad="16"/>
<connect gate="-17" pin="S" pad="17"/>
<connect gate="-18" pin="S" pad="18"/>
<connect gate="-19" pin="S" pad="19"/>
<connect gate="-20" pin="S" pad="20"/>
<connect gate="-21" pin="S" pad="21"/>
<connect gate="-22" pin="S" pad="22"/>
<connect gate="-23" pin="S" pad="23"/>
<connect gate="-24" pin="S" pad="24"/>
<connect gate="-25" pin="S" pad="25"/>
<connect gate="-26" pin="S" pad="26"/>
<connect gate="-27" pin="S" pad="27"/>
<connect gate="-28" pin="S" pad="28"/>
<connect gate="-29" pin="S" pad="29"/>
<connect gate="-30" pin="S" pad="30"/>
<connect gate="-31" pin="S" pad="31"/>
<connect gate="-32" pin="S" pad="32"/>
<connect gate="-33" pin="S" pad="33"/>
<connect gate="-34" pin="S" pad="34"/>
<connect gate="-35" pin="S" pad="35"/>
<connect gate="-36" pin="S" pad="36"/>
<connect gate="-37" pin="S" pad="37"/>
<connect gate="-38" pin="S" pad="38"/>
<connect gate="-39" pin="S" pad="39"/>
<connect gate="-40" pin="S" pad="40"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52745-0490" prefix="X">
<description>&lt;b&gt;FFC/FPC&lt;/b&gt;-to-Board  0.50mm (.020") SMT Top Contact&lt;p&gt;
Right Angle, ZIF, Style Receptacle 52745 / 52435&lt;br&gt;
Source: http://www.molex.com/product/ffc/52745.html</description>
<gates>
<gate name="-1" symbol="MV" x="0" y="2.54" addlevel="always"/>
<gate name="-2" symbol="M" x="0" y="0" addlevel="always"/>
<gate name="-3" symbol="M" x="0" y="-2.54" addlevel="always"/>
<gate name="-4" symbol="M" x="0" y="-5.08" addlevel="always"/>
</gates>
<devices>
<device name="" package="52745-0490">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52745-0690" prefix="X">
<gates>
<gate name="-1" symbol="MV" x="0" y="5.08" addlevel="always"/>
<gate name="-2" symbol="M" x="0" y="2.54" addlevel="always"/>
<gate name="-3" symbol="M" x="0" y="0" addlevel="always"/>
<gate name="-4" symbol="M" x="0" y="-2.54" addlevel="always"/>
<gate name="-5" symbol="M" x="0" y="-5.08" addlevel="always"/>
<gate name="-6" symbol="M" x="0" y="-7.62" addlevel="always"/>
</gates>
<devices>
<device name="" package="52745-0690">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52745-0790" prefix="X">
<gates>
</gates>
<devices>
<device name="" package="52745-0790">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52745-0890" prefix="X">
<gates>
</gates>
<devices>
<device name="" package="52745-0890">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52745-0990" prefix="X">
<gates>
</gates>
<devices>
<device name="" package="52745-0990">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52745-1090" prefix="X">
<gates>
<gate name="-1" symbol="MV" x="0" y="10.16" addlevel="always"/>
<gate name="-2" symbol="M" x="0" y="7.62" addlevel="always"/>
<gate name="-3" symbol="M" x="0" y="5.08" addlevel="always"/>
<gate name="-4" symbol="M" x="0" y="2.54" addlevel="always"/>
<gate name="-5" symbol="M" x="0" y="0" addlevel="always"/>
<gate name="-6" symbol="M" x="0" y="-2.54" addlevel="always"/>
<gate name="-7" symbol="M" x="0" y="-5.08" addlevel="always"/>
<gate name="-8" symbol="M" x="0" y="-7.62" addlevel="always"/>
<gate name="-9" symbol="M" x="0" y="-10.16" addlevel="always"/>
<gate name="-10" symbol="M" x="0" y="-12.7" addlevel="always"/>
</gates>
<devices>
<device name="" package="52745-1090">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52745-1190" prefix="X">
<gates>
<gate name="-11" symbol="M" x="0" y="-15.24" addlevel="always"/>
</gates>
<devices>
<device name="" package="52745-1190">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52745-1290" prefix="X">
<gates>
</gates>
<devices>
<device name="" package="52745-1290">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52745-1390" prefix="X">
<gates>
</gates>
<devices>
<device name="" package="52745-1390">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52745-1490" prefix="X">
<gates>
</gates>
<devices>
<device name="" package="52745-1490">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52745-1590" prefix="X">
<gates>
</gates>
<devices>
<device name="" package="52745-1590">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52745-1690" prefix="X">
<gates>
</gates>
<devices>
<device name="" package="52745-1690">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52745-1790" prefix="X">
<gates>
<gate name="-17" symbol="M" x="0" y="-22.86" addlevel="always"/>
</gates>
<devices>
<device name="" package="52745-1790">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52745-1890" prefix="X">
<gates>
<gate name="-18" symbol="M" x="0" y="-25.4" addlevel="always"/>
</gates>
<devices>
<device name="" package="52745-1890">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52745-1990" prefix="X">
<gates>
</gates>
<devices>
<device name="" package="52745-1990">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52745-2090" prefix="X">
<gates>
</gates>
<devices>
<device name="" package="52745-2090">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52745-2190" prefix="X">
<gates>
</gates>
<devices>
<device name="" package="52745-2190">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52745-2290" prefix="X">
<gates>
<gate name="-1" symbol="MV" x="0" y="27.94" addlevel="always"/>
<gate name="-2" symbol="M" x="0" y="25.4" addlevel="always"/>
<gate name="-3" symbol="M" x="0" y="22.86" addlevel="always"/>
<gate name="-4" symbol="M" x="0" y="20.32" addlevel="always"/>
<gate name="-5" symbol="M" x="0" y="17.78" addlevel="always"/>
<gate name="-6" symbol="M" x="0" y="15.24" addlevel="always"/>
<gate name="-7" symbol="M" x="0" y="12.7" addlevel="always"/>
<gate name="-8" symbol="M" x="0" y="10.16" addlevel="always"/>
<gate name="-9" symbol="M" x="0" y="7.62" addlevel="always"/>
<gate name="-10" symbol="M" x="0" y="5.08" addlevel="always"/>
<gate name="-11" symbol="M" x="0" y="2.54" addlevel="always"/>
<gate name="-12" symbol="M" x="0" y="0" addlevel="always"/>
<gate name="-13" symbol="M" x="0" y="-2.54" addlevel="always"/>
<gate name="-14" symbol="M" x="0" y="-5.08" addlevel="always"/>
<gate name="-15" symbol="M" x="0" y="-7.62" addlevel="always"/>
<gate name="-16" symbol="M" x="0" y="-10.16" addlevel="always"/>
<gate name="-17" symbol="M" x="0" y="-12.7" addlevel="always"/>
<gate name="-18" symbol="M" x="0" y="-15.24" addlevel="always"/>
<gate name="-19" symbol="M" x="0" y="-17.78" addlevel="always"/>
<gate name="-20" symbol="M" x="0" y="-20.32" addlevel="always"/>
<gate name="-21" symbol="M" x="0" y="-22.86" addlevel="always"/>
<gate name="-22" symbol="M" x="0" y="-25.4" addlevel="always"/>
</gates>
<devices>
<device name="" package="52745-2290">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52745-2390" prefix="X">
<gates>
<gate name="-23" symbol="M" x="0" y="-30.48" addlevel="always"/>
</gates>
<devices>
<device name="" package="52745-2390">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52745-2490" prefix="X">
<gates>
<gate name="-23" symbol="M" x="0" y="-27.94" addlevel="always"/>
<gate name="-24" symbol="M" x="0" y="-30.48" addlevel="always"/>
</gates>
<devices>
<device name="" package="52745-2490">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52745-2590" prefix="X">
<gates>
<gate name="-25" symbol="M" x="0" y="-33.02" addlevel="always"/>
</gates>
<devices>
<device name="" package="52745-2590">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52745-2690" prefix="X">
<gates>
</gates>
<devices>
<device name="" package="52745-2690">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52745-2790" prefix="X">
<gates>
<gate name="-1" symbol="MV" x="0" y="33.02" addlevel="always"/>
<gate name="-2" symbol="M" x="0" y="30.48" addlevel="always"/>
<gate name="-3" symbol="M" x="0" y="27.94" addlevel="always"/>
<gate name="-4" symbol="M" x="0" y="25.4" addlevel="always"/>
<gate name="-5" symbol="M" x="0" y="22.86" addlevel="always"/>
<gate name="-6" symbol="M" x="0" y="20.32" addlevel="always"/>
<gate name="-7" symbol="M" x="0" y="17.78" addlevel="always"/>
<gate name="-8" symbol="M" x="0" y="15.24" addlevel="always"/>
<gate name="-9" symbol="M" x="0" y="12.7" addlevel="always"/>
<gate name="-10" symbol="M" x="0" y="10.16" addlevel="always"/>
<gate name="-11" symbol="M" x="0" y="7.62" addlevel="always"/>
<gate name="-12" symbol="M" x="0" y="5.08" addlevel="always"/>
<gate name="-13" symbol="M" x="0" y="2.54" addlevel="always"/>
<gate name="-14" symbol="M" x="0" y="0" addlevel="always"/>
<gate name="-15" symbol="M" x="0" y="-2.54" addlevel="always"/>
<gate name="-16" symbol="M" x="0" y="-5.08" addlevel="always"/>
<gate name="-17" symbol="M" x="0" y="-7.62" addlevel="always"/>
<gate name="-18" symbol="M" x="0" y="-10.16" addlevel="always"/>
<gate name="-19" symbol="M" x="0" y="-12.7" addlevel="always"/>
<gate name="-20" symbol="M" x="0" y="-15.24" addlevel="always"/>
<gate name="-21" symbol="M" x="0" y="-17.78" addlevel="always"/>
<gate name="-22" symbol="M" x="0" y="-20.32" addlevel="always"/>
<gate name="-23" symbol="M" x="0" y="-22.86" addlevel="always"/>
<gate name="-24" symbol="M" x="0" y="-25.4" addlevel="always"/>
<gate name="-25" symbol="M" x="0" y="-27.94" addlevel="always"/>
<gate name="-26" symbol="M" x="0" y="-30.48" addlevel="always"/>
<gate name="-27" symbol="M" x="0" y="-33.02" addlevel="always"/>
</gates>
<devices>
<device name="" package="52745-2790">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52745-2890" prefix="X">
<gates>
<gate name="-1" symbol="MV" x="0" y="35.56" addlevel="always"/>
<gate name="-2" symbol="M" x="0" y="33.02" addlevel="always"/>
<gate name="-3" symbol="M" x="0" y="30.48" addlevel="always"/>
<gate name="-4" symbol="M" x="0" y="27.94" addlevel="always"/>
<gate name="-5" symbol="M" x="0" y="25.4" addlevel="always"/>
<gate name="-6" symbol="M" x="0" y="22.86" addlevel="always"/>
<gate name="-7" symbol="M" x="0" y="20.32" addlevel="always"/>
<gate name="-8" symbol="M" x="0" y="17.78" addlevel="always"/>
<gate name="-9" symbol="M" x="0" y="15.24" addlevel="always"/>
<gate name="-10" symbol="M" x="0" y="12.7" addlevel="always"/>
<gate name="-11" symbol="M" x="0" y="10.16" addlevel="always"/>
<gate name="-12" symbol="M" x="0" y="7.62" addlevel="always"/>
<gate name="-13" symbol="M" x="0" y="5.08" addlevel="always"/>
<gate name="-14" symbol="M" x="0" y="2.54" addlevel="always"/>
<gate name="-15" symbol="M" x="0" y="0" addlevel="always"/>
<gate name="-16" symbol="M" x="0" y="-2.54" addlevel="always"/>
<gate name="-17" symbol="M" x="0" y="-5.08" addlevel="always"/>
<gate name="-18" symbol="M" x="0" y="-7.62" addlevel="always"/>
<gate name="-19" symbol="M" x="0" y="-10.16" addlevel="always"/>
<gate name="-20" symbol="M" x="0" y="-12.7" addlevel="always"/>
<gate name="-21" symbol="M" x="0" y="-15.24" addlevel="always"/>
<gate name="-22" symbol="M" x="0" y="-17.78" addlevel="always"/>
<gate name="-23" symbol="M" x="0" y="-20.32" addlevel="always"/>
<gate name="-24" symbol="M" x="0" y="-22.86" addlevel="always"/>
<gate name="-25" symbol="M" x="0" y="-25.4" addlevel="always"/>
<gate name="-26" symbol="M" x="0" y="-27.94" addlevel="always"/>
<gate name="-27" symbol="M" x="0" y="-30.48" addlevel="always"/>
<gate name="-28" symbol="M" x="0" y="-33.02" addlevel="always"/>
</gates>
<devices>
<device name="" package="52745-2890">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52745-2990" prefix="X">
<gates>
<gate name="-29" symbol="M" x="0" y="-35.56" addlevel="always"/>
</gates>
<devices>
<device name="" package="52745-2990">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52745-3090" prefix="X">
<gates>
<gate name="-1" symbol="MV" x="0" y="38.1" addlevel="always"/>
<gate name="-2" symbol="M" x="0" y="35.56" addlevel="always"/>
<gate name="-3" symbol="M" x="0" y="33.02" addlevel="always"/>
<gate name="-4" symbol="M" x="0" y="30.48" addlevel="always"/>
<gate name="-5" symbol="M" x="0" y="27.94" addlevel="always"/>
<gate name="-6" symbol="M" x="0" y="25.4" addlevel="always"/>
<gate name="-7" symbol="M" x="0" y="22.86" addlevel="always"/>
<gate name="-8" symbol="M" x="0" y="20.32" addlevel="always"/>
<gate name="-9" symbol="M" x="0" y="17.78" addlevel="always"/>
<gate name="-10" symbol="M" x="0" y="15.24" addlevel="always"/>
<gate name="-11" symbol="M" x="0" y="12.7" addlevel="always"/>
<gate name="-12" symbol="M" x="0" y="10.16" addlevel="always"/>
<gate name="-13" symbol="M" x="0" y="7.62" addlevel="always"/>
<gate name="-14" symbol="M" x="0" y="5.08" addlevel="always"/>
<gate name="-15" symbol="M" x="0" y="2.54" addlevel="always"/>
<gate name="-16" symbol="M" x="0" y="0" addlevel="always"/>
<gate name="-17" symbol="M" x="0" y="-2.54" addlevel="always"/>
<gate name="-18" symbol="M" x="0" y="-5.08" addlevel="always"/>
<gate name="-19" symbol="M" x="0" y="-7.62" addlevel="always"/>
<gate name="-20" symbol="M" x="0" y="-10.16" addlevel="always"/>
<gate name="-21" symbol="M" x="0" y="-12.7" addlevel="always"/>
<gate name="-22" symbol="M" x="0" y="-15.24" addlevel="always"/>
<gate name="-23" symbol="M" x="0" y="-17.78" addlevel="always"/>
<gate name="-24" symbol="M" x="0" y="-20.32" addlevel="always"/>
<gate name="-25" symbol="M" x="0" y="-22.86" addlevel="always"/>
<gate name="-26" symbol="M" x="0" y="-25.4" addlevel="always"/>
<gate name="-27" symbol="M" x="0" y="-27.94" addlevel="always"/>
<gate name="-28" symbol="M" x="0" y="-30.48" addlevel="always"/>
<gate name="-29" symbol="M" x="0" y="-33.02" addlevel="always"/>
<gate name="-30" symbol="M" x="0" y="-35.56" addlevel="always"/>
</gates>
<devices>
<device name="" package="52745-3090">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5566-2" prefix="X">
<description>&lt;b&gt;Mini FIT connector 2 pol&lt;/b&gt;&lt;p&gt;
Source: http://www.molex.com</description>
<gates>
<gate name="-2" symbol="MV" x="0" y="-2.54" addlevel="always"/>
</gates>
<devices>
<device name="" package="5566-2">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5566-4" prefix="X">
<description>&lt;b&gt;Mini FIT connector 4 pol&lt;/b&gt;&lt;p&gt;
<gates>
</gates>
<devices>
<device name="" package="5566-4">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5566-6" prefix="X">
<description>&lt;b&gt;Mini FIT connector 6 pol&lt;/b&gt;&lt;p&gt;
<gates>
</gates>
<devices>
<device name="" package="5566-6">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5566-8" prefix="X">
<description>&lt;b&gt;Mini FIT connector 8 pol&lt;/b&gt;&lt;p&gt;
<gates>
</gates>
<devices>
<device name="" package="5566-8">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5566-10" prefix="X">
<description>&lt;b&gt;Mini FIT connector 10 pol&lt;/b&gt;&lt;p&gt;
<gates>
</gates>
<devices>
<device name="" package="5566-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5566-12" prefix="X">
<description>&lt;b&gt;Mini FIT connector 12 pol&lt;/b&gt;&lt;p&gt;
<gates>
</gates>
<devices>
<device name="" package="5566-12">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5566-14" prefix="X">
<description>&lt;b&gt;Mini FIT connector 14 pol&lt;/b&gt;&lt;p&gt;
<gates>
</gates>
<devices>
<device name="" package="5566-14">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5566-16" prefix="X">
<description>&lt;b&gt;Mini FIT connector 16 pol&lt;/b&gt;&lt;p&gt;
<gates>
</gates>
<devices>
<device name="" package="5566-16">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5566-18" prefix="X">
<description>&lt;b&gt;Mini FIT connector 18 pol&lt;/b&gt;&lt;p&gt;
<gates>
</gates>
<devices>
<device name="" package="5566-18">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5566-20" prefix="X">
<description>&lt;b&gt;Mini FIT connector 20 pol&lt;/b&gt;&lt;p&gt;
ATX PC-Motherboard Power connector&lt;br&gt;
<gates>
</gates>
<devices>
<device name="" package="5566-20">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5566-22" prefix="X">
<description>&lt;b&gt;Mini FIT connector 22 pol&lt;/b&gt;&lt;p&gt;
<gates>
</gates>
<devices>
<device name="" package="5566-22">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5566-24" prefix="X">
<description>&lt;b&gt;Mini FIT connector 24 pol&lt;/b&gt;&lt;p&gt;
<gates>
</gates>
<devices>
<device name="" package="5566-24">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52746-4" prefix="X">
<description>&lt;b&gt;FPC Connector ZIF for SMT 0.5mm&lt;/b&gt;&lt;p&gt;
Source: http://www.farnell.com/datasheets/73044.pdf [DWG. NO. (Sheet 1 OF 2) SD-52746-**17]</description>
<gates>
<gate name="-1" symbol="MV" x="0" y="2.54" addlevel="always" swaplevel="1"/>
<gate name="-2" symbol="M" x="0" y="0" addlevel="always" swaplevel="1"/>
<gate name="-3" symbol="M" x="0" y="-2.54" addlevel="always" swaplevel="1"/>
<gate name="-4" symbol="M" x="0" y="-5.08" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="" package="52746-4">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52746-20" prefix="X">
Source: http://www.farnell.com/datasheets/73044.pdf [DWG. NO. (Sheet 1 OF 2) SD-52746-**17]&lt;br&gt;
Distributor: Farnell 9786350</description>
<gates>
<gate name="-1" symbol="MV" x="-2.54" y="25.4" addlevel="always" swaplevel="1"/>
<gate name="-2" symbol="M" x="-2.54" y="22.86" addlevel="always" swaplevel="1"/>
<gate name="-3" symbol="M" x="-2.54" y="20.32" addlevel="always" swaplevel="1"/>
<gate name="-4" symbol="M" x="-2.54" y="17.78" addlevel="always" swaplevel="1"/>
<gate name="-5" symbol="M" x="-2.54" y="15.24" addlevel="always" swaplevel="1"/>
<gate name="-6" symbol="M" x="-2.54" y="12.7" addlevel="always" swaplevel="1"/>
<gate name="-7" symbol="M" x="-2.54" y="10.16" addlevel="always" swaplevel="1"/>
<gate name="-8" symbol="M" x="-2.54" y="7.62" addlevel="always" swaplevel="1"/>
<gate name="-9" symbol="M" x="-2.54" y="5.08" addlevel="always" swaplevel="1"/>
<gate name="-10" symbol="M" x="-2.54" y="2.54" addlevel="always" swaplevel="1"/>
<gate name="-11" symbol="M" x="-2.54" y="0" addlevel="always" swaplevel="1"/>
<gate name="-12" symbol="M" x="-2.54" y="-2.54" addlevel="always" swaplevel="1"/>
<gate name="-13" symbol="M" x="-2.54" y="-5.08" addlevel="always" swaplevel="1"/>
<gate name="-14" symbol="M" x="-2.54" y="-7.62" addlevel="always" swaplevel="1"/>
<gate name="-15" symbol="M" x="-2.54" y="-10.16" addlevel="always" swaplevel="1"/>
<gate name="-16" symbol="M" x="-2.54" y="-12.7" addlevel="always" swaplevel="1"/>
<gate name="-17" symbol="M" x="-2.54" y="-15.24" addlevel="always" swaplevel="1"/>
<gate name="-18" symbol="M" x="-2.54" y="-17.78" addlevel="always" swaplevel="1"/>
<gate name="-19" symbol="M" x="-2.54" y="-20.32" addlevel="always" swaplevel="1"/>
<gate name="-20" symbol="M" x="-2.54" y="-22.86" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="" package="52746-20">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52746-19" prefix="X">
<gates>
</gates>
<devices>
<device name="" package="52746-19">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52746-18" prefix="X">
<gates>
<gate name="-1" symbol="MV" x="-2.54" y="20.32" addlevel="always" swaplevel="1"/>
<gate name="-2" symbol="M" x="-2.54" y="17.78" addlevel="always" swaplevel="1"/>
<gate name="-3" symbol="M" x="-2.54" y="15.24" addlevel="always" swaplevel="1"/>
<gate name="-4" symbol="M" x="-2.54" y="12.7" addlevel="always" swaplevel="1"/>
<gate name="-5" symbol="M" x="-2.54" y="10.16" addlevel="always" swaplevel="1"/>
<gate name="-6" symbol="M" x="-2.54" y="7.62" addlevel="always" swaplevel="1"/>
<gate name="-7" symbol="M" x="-2.54" y="5.08" addlevel="always" swaplevel="1"/>
<gate name="-8" symbol="M" x="-2.54" y="2.54" addlevel="always" swaplevel="1"/>
<gate name="-9" symbol="M" x="-2.54" y="0" addlevel="always" swaplevel="1"/>
<gate name="-10" symbol="M" x="-2.54" y="-2.54" addlevel="always" swaplevel="1"/>
<gate name="-11" symbol="M" x="-2.54" y="-5.08" addlevel="always" swaplevel="1"/>
<gate name="-12" symbol="M" x="-2.54" y="-7.62" addlevel="always" swaplevel="1"/>
<gate name="-13" symbol="M" x="-2.54" y="-10.16" addlevel="always" swaplevel="1"/>
<gate name="-14" symbol="M" x="-2.54" y="-12.7" addlevel="always" swaplevel="1"/>
<gate name="-15" symbol="M" x="-2.54" y="-15.24" addlevel="always" swaplevel="1"/>
<gate name="-16" symbol="M" x="-2.54" y="-17.78" addlevel="always" swaplevel="1"/>
<gate name="-17" symbol="M" x="-2.54" y="-20.32" addlevel="always" swaplevel="1"/>
<gate name="-18" symbol="M" x="-2.54" y="-22.86" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="" package="52746-18">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="52746-17" prefix="X">
<gates>
