Partlist exported from C:/Users/Bence/Dropbox/eagle/projektek/dallammodul/dallammodul_smd.sch at 2022.06.11. 18:36
Part   Value           Device                  Package     Description
C1     10nF            C-EUC0805               C0805       CAPACITOR, European symbol
C2     10nF            C-EUC0805               C0805       CAPACITOR, European symbol
C3     10nF            C-EUC0805               C0805       CAPACITOR, European symbol
C4     10nF            C-EUC0805               C0805       CAPACITOR, European symbol
C5     10nF            C-EUC0805               C0805       CAPACITOR, European symbol
C6     20pF            C-EUC0805               C0805       CAPACITOR, European symbol
C7     20pF            C-EUC0805               C0805       CAPACITOR, European symbol
C8     10uF            CPOL-EU153CLV-0505      153CLV-0505 POLARIZED CAPACITOR, European symbol
C9     1uF             CPOL-EU153CLV-0405      153CLV-0405 POLARIZED CAPACITOR, European symbol
C10    10nF            C-EUC0805               C0805       CAPACITOR, European symbol
C11    1.5nF           C-EUC0805               C0805       CAPACITOR, European symbol
D1     GS3MB           DIODE-DO214AA           DO214AA     DIODE
D2     1N4148SOD123-FL 1N4148SOD123-FL         SOD123FL    DIODE
D3     1N4148SOD123-FL 1N4148SOD123-FL         SOD123FL    DIODE
D4     1N4148SOD123-FL 1N4148SOD123-FL         SOD123FL    DIODE
D5     1N4148SOD123-FL 1N4148SOD123-FL         SOD123FL    DIODE
D6     1N4148SOD123-FL 1N4148SOD123-FL         SOD123FL    DIODE
D7     1N4148SOD123-FL 1N4148SOD123-FL         SOD123FL    DIODE
DOBOZ1 DOBOZG1812      DOBOZG1812              G1812       Ha eleve dobozba tervezném az áramkört, akkor miért ne legyen meg alkatrészként?
F1     3A              BIZTOSITEK              OMNIBLOK
H+     LSP10           LSP10                   LSP10       SOLDER PAD drill 1.0 mm, distributor Buerklin, 12H555
H-     LSP10           LSP10                   LSP10       SOLDER PAD drill 1.0 mm, distributor Buerklin, 12H555
IC1    PIC16F627SO     PIC16F627SO             SO-18W      FLASH-Based 8-Bit CMOS Microcontroller
IC2    NE555D          NE555D                  SO08        TIMER
IC3    L78M05C         L78MXXCDPAK             TO252
ICSP                   PINHD-1X6               1X06        PIN HEADER
JP1                    PINHD-2X3               2X03        PIN HEADER
JP2                    PINHD-1X2               1X02        PIN HEADER
Q1     4MHz            CRYSTALHC49UP           HC49UP      CRYSTAL
R1     1k              R-EU_R0805              R0805       RESISTOR, European symbol
R2     1k              R-EU_R0805              R0805       RESISTOR, European symbol
R3     1k              R-EU_R0805              R0805       RESISTOR, European symbol
R4     1k              R-EU_R0805              R0805       RESISTOR, European symbol
R5     2.2k            R-EU_R0805              R0805       RESISTOR, European symbol
R6     2.2k            R-EU_R0805              R0805       RESISTOR, European symbol
R7     410k            R-EU_R0805              R0805       RESISTOR, European symbol
R8     3.3k            R-EU_R0805              R0805       RESISTOR, European symbol
R9     3.3k            R-EU_R0805              R0805       RESISTOR, European symbol
R10    3.3k            R-EU_R0805              R0805       RESISTOR, European symbol
R11    3.3k            R-EU_R0805              R0805       RESISTOR, European symbol
R12    2.2M            R-EU_R0805              R0805       RESISTOR, European symbol
R13    2.2M            R-EU_R0805              R0805       RESISTOR, European symbol
R14    220             R-EU_R0805              R0805       RESISTOR, European symbol
R15    220             R-EU_R0805              R0805       RESISTOR, European symbol
R16    1k              R-EU_R0805              R0805       RESISTOR, European symbol
R17    1k              R-EU_R0805              R0805       RESISTOR, European symbol
R18    220             R-EU_R0805              R0805       RESISTOR, European symbol
R19    5k              R-TRIMM64W              RTRIM64W    Trimm resistor
START  LSP10           LSP10                   LSP10       SOLDER PAD drill 1.0 mm, distributor Buerklin, 12H555
STOP   LSP10           LSP10                   LSP10       SOLDER PAD drill 1.0 mm, distributor Buerklin, 12H555
T1     MJD41C          TRANSISTOR-NPNDPAK      TO252
T2     MJD41C          TRANSISTOR-NPNDPAK      TO252
T3     MJD42C          TRANSISTOR-PNPDPAK      TO252
T4     MJD42C          TRANSISTOR-PNPDPAK      TO252
T5     BC807           TRANSISTOR-PNPSOT23-BEC SOT23
T6     BC818           TRANSISTOR-NPNSOT23-BEC SOT23
T7     BC818           TRANSISTOR-NPNSOT23-BEC SOT23
T8                     NPN-FETDPAK             TO252       NPN FET
U$1    VONALZO         VONALZO                 VONALZO     vonalzó
X2                     AK300/2                 AK300/2     CONNECTOR
ZB1    ZB              ZB                      ZB          Zahalka Bence monogram
