; Source created with Parsic Version 3.x
; at              : 2008.11.14. 8:38:18
; Project File    : C:\Pic programok\knight ryder-.pic
; Project Version : 1.0.9
; Created         : 2008.05.11. 9:16:00
; Last change     : 2008.11.14. 8:38:07
	PROCESSOR 16F628
	INCLUDE P16F628.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_ON & _WDT_OFF & _BODEN_ON & _INTRC_OSC_NOCLKOUT & _LVP_OFF & _MCLRE_OFF
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
S1	= 32	; located in Bank 0
OS1_FD	= 33	; located in Bank 0
ZV1	= 34	; located in Bank 0
ZV1_FD	= 35	; located in Bank 0
S2	= 36	; located in Bank 0
TR1	= 37	; located in Bank 0
TR1_HI	= 38	; located in Bank 0
S3	= 39	; located in Bank 0
S4	= 40	; located in Bank 0
ZV2	= 41	; located in Bank 0
ZV2_FD	= 42	; located in Bank 0
S0	= 43	; located in Bank 0
RAM	= 44	; located in Bank 0
SYS_WSAV	= 112	; located in Bank 0, 1, 2, 3
SYS_SSAV	= 113	; located in Bank 0, 1, 2, 3
SYS_TMP1	= 114	; located in Bank 0, 1, 2, 3
SYS_TMP2	= 115	; located in Bank 0, 1, 2, 3
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	CLRF STATUS	; switch to RAM-Bank 0
	GOTO SYS_INIT
	NOP
	NOP
;Interrupt-Adress
	MOVWF SYS_WSAV	; save register
	SWAPF STATUS,W
	CLRF STATUS	; bank 0
	MOVWF SYS_SSAV
	BCF INTCON,T0IF	; Interrupt quitieren
	BCF STATUS,RP0	; Bank 0
	BCF STATUS,RP1	; Bank 0
	INCFSZ TR1,F
	GOTO SYS_INT_LABEL_0
	BSF STATUS,RP0	; Bank 1
	INCF TR1_HI,F
SYS_INT_LABEL_0
EXITINT
	SWAPF SYS_SSAV,W	; Register zurück
	MOVWF STATUS
	SWAPF SYS_WSAV,F
	SWAPF SYS_WSAV,W
	RETURN
; Subroutines
; Direct jump into a table
SYSTABJMP
	BCF INTCON,GIE
	BTFSC INTCON,GIE
	GOTO SYSTABJMP
	MOVFW SYS_TMP2
	MOVWF PCLATH
	MOVFW SYS_TMP1
	MOVWF PCL
;Initialisierung
SYS_INIT
	MOVLW B'00100000'
	MOVWF INTCON
; Set output before direction
	MOVLW B'00000000'
	MOVWF PORTA
	MOVLW B'00000000'
	MOVWF PORTB
	MOVLW 143
	MOVWF OPTION_REG
; Richtung setzen
	MOVLW B'00110000'
	MOVWF TRISA
	MOVLW B'00000100'
	MOVWF TRISB
	MOVLW 7	; Comparators off
	MOVWF CMCON
; init vars
; Clear RAM
	BCF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	BTFSS FSR,7
	GOTO CR1
	BSF FSR,5
CR2
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR2
	BSF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR3
	CLRF INDF
	INCF FSR,F
	MOVLW H'50'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR3
	MOVLW B'00001000'
	MOVWF S4
	CLRF TMR0
	BCF INTCON,T0IF
	BSF INTCON,GIE	; Interrupt freigeben
;******* Haupt-Programm ***********
MAIN
; One Shot -> OS1
	BTFSC S1,0
	GOTO LABEL_OS1_1
	BTFSC OS1_FD,0
	GOTO LABEL_OS1_1
	BSF OS1_FD,0
	BSF S1,1
	GOTO LABEL_OS1_2
LABEL_OS1_1
	BCF S1,1
	BTFSS S1,0
	GOTO LABEL_OS1_2
	BCF OS1_FD,0
LABEL_OS1_2
; Zähler -> ZV1
	BTFSS S1,2	; Reset ?
	GOTO LABEL_ZV1_COUNT
	CLRF ZV1
	GOTO LABEL_ZV1_SETOUT
LABEL_ZV1_COUNT
; Test auf positive Flanke
	BTFSS S1,1
	GOTO LABEL_ZV1_SETFD
	BTFSC ZV1_FD,0
	BSF ZV1_FD,0
	BTFSC S1,3	; Vorwärts oder Rückwärts ?
	GOTO LABEL_ZV1_BACKWARD
	INCF ZV1,F
LABEL_ZV1_BACKWARD
	DECF ZV1,F
LABEL_ZV1_SETOUT
LABEL_ZV1_SETFD
; Test auf negative Flanke
	BTFSC S1,1
	GOTO LABEL_ZV1_EXIT
	BCF ZV1_FD,0
LABEL_ZV1_EXIT
; Schmitt-Trigger 8-Bit -> ST1
	BTFSC S1,2	; Ausgang gesetzt ?
	GOTO LABEL_ST1_MH	; dann mit Hysterese ?
	MOVLW 7
	GOTO LABEL_ST1_TEST
LABEL_ST1_MH
	MOVLW 7
LABEL_ST1_TEST
	SUBWF ZV1,W
	BTFSS STATUS,CARRY
	GOTO LABEL_ST1_RESET
	BSF S1,2	; if greater or equal
	GOTO LABEL_ST1_ENDE
LABEL_ST1_RESET
	BCF S1,2	; if less
LABEL_ST1_ENDE
; Verteiler -> BV1
	BTFSC S0,0
	GOTO LABEL_BV1_0
	BCF S1,4
	GOTO LABEL_BV1_0_END
LABEL_BV1_0
	BSF S1,4
LABEL_BV1_0_END
	BTFSC S0,1
	GOTO LABEL_BV1_1
	BCF S1,5
	GOTO LABEL_BV1_1_END
LABEL_BV1_1
	BSF S1,5
LABEL_BV1_1_END
	BTFSC S0,2
	GOTO LABEL_BV1_2
	BCF S1,6
	GOTO LABEL_BV1_2_END
LABEL_BV1_2
	BSF S1,6
LABEL_BV1_2_END
	BTFSC S0,3
	GOTO LABEL_BV1_3
	BCF S1,7
	GOTO LABEL_BV1_3_END
LABEL_BV1_3
	BSF S1,7
LABEL_BV1_3_END
	BTFSC S0,4
	GOTO LABEL_BV1_4
	BCF S2,0
	GOTO LABEL_BV1_4_END
LABEL_BV1_4
	BSF S2,0
LABEL_BV1_4_END
	BTFSC S0,5
	GOTO LABEL_BV1_5
	BCF S2,1
	GOTO LABEL_BV1_5_END
LABEL_BV1_5
	BSF S2,1
LABEL_BV1_5_END
	BTFSC S0,6
	GOTO LABEL_BV1_6
	BCF S2,2
	GOTO LABEL_BV1_6_END
LABEL_BV1_6
	BSF S2,2
LABEL_BV1_6_END
; GND
	BCF S1,3	; immer Low
; Timer -> TR1
	MOVLW 0	; Test auf >=
	SUBWF TR1_HI,W	;F-W -> W
	BTFSS STATUS,ZERO
	GOTO LABEL_TR1_CHECK
	MOVLW 195
	SUBWF TR1,W	;F-W -> W
LABEL_TR1_CHECK
	BTFSS STATUS,CARRY
	GOTO LABEL_TR1_ENDE
LABEL_TR1_RESET
	SUBWF TR1_HI,F	;F-W -> F
	MOVLW 195
	SUBWF TR1,F	;F-W -> F
	BTFSS STATUS,CARRY
	DECF TR1_HI,F
LABEL_TR1_SET	; toggel output
	BTFSC S2,3
	GOTO LABEL_TR1_CLR
	BSF S2,3
	GOTO LABEL_TR1_ENDE
LABEL_TR1_CLR
	BCF S2,3
LABEL_TR1_ENDE
; UND - Gatter -> LG1
LABEL_LG1_1
	BTFSS S1,4
	GOTO LABEL_LG1_FALSE
LABEL_LG1_2
	BTFSS S4,4
LABEL_LG1_TRUE
	BSF S2,5
	GOTO LABEL_LG1_ENDE
LABEL_LG1_FALSE
	BCF S2,5
LABEL_LG1_ENDE
; UND - Gatter -> LG2
LABEL_LG2_1
	BTFSS S1,5
	GOTO LABEL_LG2_FALSE
LABEL_LG2_2
	BTFSS S4,4
LABEL_LG2_TRUE
	BSF S2,7
	GOTO LABEL_LG2_ENDE
LABEL_LG2_FALSE
	BCF S2,7
LABEL_LG2_ENDE
; UND - Gatter -> LG3
LABEL_LG3_1
	BTFSS S1,6
	GOTO LABEL_LG3_FALSE
LABEL_LG3_2
	BTFSS S4,4
LABEL_LG3_TRUE
	BSF STATUS,RP1	; Bank 2
	BSF S3,0
	GOTO LABEL_LG3_ENDE
LABEL_LG3_FALSE
	BCF S3,0
LABEL_LG3_ENDE
; UND - Gatter -> LG4
LABEL_LG4_1
	BTFSS S1,7
	GOTO LABEL_LG4_FALSE
LABEL_LG4_2
	BTFSS S4,4
LABEL_LG4_TRUE
	BSF S3,1
	GOTO LABEL_LG4_ENDE
LABEL_LG4_FALSE
	BCF S3,1
LABEL_LG4_ENDE
; UND - Gatter -> LG5
LABEL_LG5_1
	BTFSS S2,0
	GOTO LABEL_LG5_FALSE
LABEL_LG5_2
	BTFSS S4,4
LABEL_LG5_TRUE
	BSF S3,2
	GOTO LABEL_LG5_ENDE
LABEL_LG5_FALSE
	BCF S3,2
LABEL_LG5_ENDE
; UND - Gatter -> LG6
LABEL_LG6_1
	BTFSS S2,1
	GOTO LABEL_LG6_FALSE
LABEL_LG6_2
	BTFSS S4,4
LABEL_LG6_TRUE
	BSF S3,3
	GOTO LABEL_LG6_ENDE
LABEL_LG6_FALSE
	BCF S3,3
LABEL_LG6_ENDE
; UND - Gatter -> LG7
LABEL_LG7_1
	BTFSS S2,2
	GOTO LABEL_LG7_FALSE
LABEL_LG7_2
	BTFSS S4,4
LABEL_LG7_TRUE
	BSF S3,4
	GOTO LABEL_LG7_ENDE
LABEL_LG7_FALSE
	BCF S3,4
LABEL_LG7_ENDE
; UND - Gatter -> LG8
LABEL_LG8_1
	BTFSS S1,4
	GOTO LABEL_LG8_FALSE
LABEL_LG8_2
	BTFSS S4,3
LABEL_LG8_TRUE
	BSF S3,5
	GOTO LABEL_LG8_ENDE
LABEL_LG8_FALSE
	BCF S3,5
LABEL_LG8_ENDE
; UND - Gatter -> LG9
LABEL_LG9_1
	BTFSS S1,5
	GOTO LABEL_LG9_FALSE
LABEL_LG9_2
	BTFSS S4,3
LABEL_LG9_TRUE
	BSF S3,6
	GOTO LABEL_LG9_ENDE
LABEL_LG9_FALSE
	BCF S3,6
LABEL_LG9_ENDE
; UND - Gatter -> LG10
LABEL_LG10_1
	BTFSS S1,6
	GOTO LABEL_LG10_FALSE
LABEL_LG10_2
	BTFSS S4,3
LABEL_LG10_TRUE
	BSF S3,7
	GOTO LABEL_LG10_ENDE
LABEL_LG10_FALSE
	BCF S3,7
LABEL_LG10_ENDE
; UND - Gatter -> LG11
LABEL_LG11_1
	BTFSS S1,7
	GOTO LABEL_LG11_FALSE
LABEL_LG11_2
	BTFSS S4,3
LABEL_LG11_TRUE
	BSF S4,0
	GOTO LABEL_LG11_ENDE
LABEL_LG11_FALSE
	BCF S4,0
LABEL_LG11_ENDE
; UND - Gatter -> LG12
LABEL_LG12_1
	BTFSS S2,0
	GOTO LABEL_LG12_FALSE
LABEL_LG12_2
	BTFSS S4,3
LABEL_LG12_TRUE
	BSF S4,1
	GOTO LABEL_LG12_ENDE
LABEL_LG12_FALSE
	BCF S4,1
LABEL_LG12_ENDE
; UND - Gatter -> LG13
LABEL_LG13_1
	BTFSS S2,1
	GOTO LABEL_LG13_FALSE
LABEL_LG13_2
	BTFSS S4,3
LABEL_LG13_TRUE
	BSF S4,2
	GOTO LABEL_LG13_ENDE
LABEL_LG13_FALSE
	BCF S4,2
LABEL_LG13_ENDE
; UND - Gatter -> LG14
LABEL_LG14_1
	BTFSS S2,2
	GOTO LABEL_LG14_FALSE
LABEL_LG14_2
	BTFSS S4,3
LABEL_LG14_TRUE
	BSF S2,6
	GOTO LABEL_LG14_ENDE
LABEL_LG14_FALSE
	BCF S2,6
LABEL_LG14_ENDE
; ODER - Gatter -> LG15
LABEL_LG15_1
	BTFSC S2,5
	GOTO LABEL_LG15_TRUE
LABEL_LG15_2
	BTFSC S2,6
LABEL_LG15_FALSE
	BCF PORTB,0
	GOTO LABEL_LG15_ENDE
LABEL_LG15_TRUE
	BSF PORTB,0
LABEL_LG15_ENDE
; ODER - Gatter -> LG16
LABEL_LG16_1
	BTFSC S2,7
	GOTO LABEL_LG16_TRUE
LABEL_LG16_2
	BTFSC S4,2
	BCF STATUS,RP1	; Bank 1
LABEL_LG16_FALSE
	BCF PORTB,1
	GOTO LABEL_LG16_ENDE
LABEL_LG16_TRUE
	BSF PORTB,1
LABEL_LG16_ENDE
; ODER - Gatter -> LG17
LABEL_LG17_1
	BTFSC S3,0
	GOTO LABEL_LG17_TRUE
LABEL_LG17_2
	BTFSC S4,1
LABEL_LG17_FALSE
	BCF S2,4
	GOTO LABEL_LG17_ENDE
LABEL_LG17_TRUE
	BSF S2,4
LABEL_LG17_ENDE
; ODER - Gatter -> LG18
LABEL_LG18_1
	BTFSC S3,1
	GOTO LABEL_LG18_TRUE
LABEL_LG18_2
	BTFSC S4,0
LABEL_LG18_FALSE
	BCF PORTB,3
	GOTO LABEL_LG18_ENDE
LABEL_LG18_TRUE
	BSF PORTB,3
LABEL_LG18_ENDE
; ODER - Gatter -> LG19
LABEL_LG19_1
	BTFSC S3,2
	GOTO LABEL_LG19_TRUE
LABEL_LG19_2
	BTFSC S3,7
LABEL_LG19_FALSE
	BCF PORTB,4
	GOTO LABEL_LG19_ENDE
LABEL_LG19_TRUE
	BSF PORTB,4
LABEL_LG19_ENDE
; ODER - Gatter -> LG20
LABEL_LG20_1
	BTFSC S3,3
	GOTO LABEL_LG20_TRUE
LABEL_LG20_2
	BTFSC S3,6
LABEL_LG20_FALSE
	BCF PORTB,5
	GOTO LABEL_LG20_ENDE
LABEL_LG20_TRUE
	BSF PORTB,5
LABEL_LG20_ENDE
; ODER - Gatter -> LG21
LABEL_LG21_1
	BTFSC S3,4
	GOTO LABEL_LG21_TRUE
LABEL_LG21_2
	BTFSC S3,5
LABEL_LG21_FALSE
	BCF PORTB,6
	GOTO LABEL_LG21_ENDE
LABEL_LG21_TRUE
	BSF PORTB,6
LABEL_LG21_ENDE
; UND - Gatter -> LG22
LABEL_LG22_1
	BTFSS S4,4
	GOTO LABEL_LG22_FALSE
LABEL_LG22_TRUE
	BCF S4,3
	GOTO LABEL_LG22_ENDE
LABEL_LG22_FALSE
	BSF S4,3
LABEL_LG22_ENDE
; Zähler -> ZV2
	BTFSS S4,5	; Reset ?
	GOTO LABEL_ZV2_COUNT
	CLRF ZV2
	GOTO LABEL_ZV2_SETOUT
LABEL_ZV2_COUNT
	BTFSS S1,2
	GOTO LABEL_ZV2_SETFD
	BTFSC ZV2_FD,0
	BSF ZV2_FD,0
	GOTO LABEL_ZV2_BACKWARD
	INCF ZV2,F
LABEL_ZV2_BACKWARD
	DECF ZV2,F
LABEL_ZV2_SETOUT
; Output Q0
	BTFSS ZV2,0
	GOTO LABEL_ZV2_SETOUT0
	BSF S4,4
	GOTO LABEL_ZV2_SETOUT0_END
LABEL_ZV2_SETOUT0
	BCF S4,4
LABEL_ZV2_SETFD
	BTFSC S1,2
	GOTO LABEL_ZV2_EXIT
	BCF ZV2_FD,0
LABEL_ZV2_EXIT
; Schmitt-Trigger 8-Bit -> ST2
	BTFSC S4,5	; Ausgang gesetzt ?
	GOTO LABEL_ST2_MH	; dann mit Hysterese ?
	MOVLW 2
	GOTO LABEL_ST2_TEST
LABEL_ST2_MH
	MOVLW 2
LABEL_ST2_TEST
	SUBWF ZV2,W
	BTFSS STATUS,CARRY
	GOTO LABEL_ST2_RESET
	BSF S4,5	; if greater or equal
	GOTO LABEL_ST2_ENDE
LABEL_ST2_RESET
	BCF S4,5	; if less
LABEL_ST2_ENDE
; Call subroutine TAB
	MOVLW LOW TAB
	MOVWF SYS_TMP1
	MOVLW HIGH TAB
	MOVWF SYS_TMP2
	MOVFW ZV1
	ADDWF SYS_TMP1,F
	BTFSC STATUS,CARRY
	INCF SYS_TMP2,F
	CALL SYSTABJMP
	MOVWF S0
	BSF INTCON,GIE
; ODER - Gatter -> LG23
LABEL_LG23_1
	BTFSC S3,5
	GOTO LABEL_LG23_TRUE
LABEL_LG23_2
	BTFSC S3,4
LABEL_LG23_FALSE
	BCF PORTB,7
	GOTO LABEL_LG23_ENDE
LABEL_LG23_TRUE
	BSF PORTB,7
LABEL_LG23_ENDE
; ODER - Gatter -> LG24
LABEL_LG24_1
	BTFSC S3,6
	GOTO LABEL_LG24_TRUE
LABEL_LG24_2
	BTFSC S3,3
LABEL_LG24_FALSE
	BCF PORTA,6
	GOTO LABEL_LG24_ENDE
LABEL_LG24_TRUE
	BSF PORTA,6
LABEL_LG24_ENDE
; ODER - Gatter -> LG25
LABEL_LG25_1
	BTFSC S3,2
	GOTO LABEL_LG25_TRUE
LABEL_LG25_2
	BTFSC S3,7
LABEL_LG25_FALSE
	BCF PORTA,7
	GOTO LABEL_LG25_ENDE
LABEL_LG25_TRUE
	BSF PORTA,7
LABEL_LG25_ENDE
; ODER - Gatter -> LG26
LABEL_LG26_1
	BTFSC S3,1
	GOTO LABEL_LG26_TRUE
LABEL_LG26_2
	BTFSC S4,0
LABEL_LG26_FALSE
	BCF PORTA,0
	GOTO LABEL_LG26_ENDE
LABEL_LG26_TRUE
	BSF PORTA,0
LABEL_LG26_ENDE
; ODER - Gatter -> LG27
LABEL_LG27_1
	BTFSC S4,1
	GOTO LABEL_LG27_TRUE
LABEL_LG27_2
	BTFSC S3,0
LABEL_LG27_FALSE
	BCF PORTA,1
	GOTO LABEL_LG27_ENDE
LABEL_LG27_TRUE
	BSF PORTA,1
LABEL_LG27_ENDE
; ODER - Gatter -> LG28
LABEL_LG28_1
	BTFSC S4,2
	GOTO LABEL_LG28_TRUE
LABEL_LG28_2
	BTFSC S2,7
LABEL_LG28_FALSE
	BCF PORTA,2
	GOTO LABEL_LG28_ENDE
LABEL_LG28_TRUE
	BSF PORTA,2
LABEL_LG28_ENDE
; ODER - Gatter -> LG29
LABEL_LG29_1
	BTFSC S2,6
	GOTO LABEL_LG29_TRUE
LABEL_LG29_2
	BTFSC S2,5
LABEL_LG29_FALSE
	BCF PORTA,3
	GOTO LABEL_LG29_ENDE
LABEL_LG29_TRUE
	BSF PORTA,3
LABEL_LG29_ENDE
; UND - Gatter -> LG30
LABEL_LG30_1
	BTFSS PORTA,2
	GOTO LABEL_LG30_FALSE
LABEL_LG30_2
	BTFSS S2,3
LABEL_LG30_TRUE
	BSF S1,0
	GOTO LABEL_LG30_ENDE
LABEL_LG30_FALSE
	BCF S1,0
LABEL_LG30_ENDE
	GOTO MAIN
; Table -> TAB
TAB
	RETLW 1	; // INDEX 0
	RETLW 0	; // INDEX 0
	RETLW 2	; // INDEX 1
	RETLW 0	; // INDEX 1
	RETLW 4	; // INDEX 2
	RETLW 0	; // INDEX 2
	RETLW 8	; // INDEX 3
	RETLW 0	; // INDEX 3
	RETLW 16	; // INDEX 4
	RETLW 0	; // INDEX 4
	RETLW 32	; // INDEX 5
	RETLW 0	; // INDEX 5
	RETLW 64	; // INDEX 6
	RETLW 0	; // INDEX 6
	RETLW 128	; // INDEX 7
	RETLW 0	; // INDEX 7
	RETLW 0	; // INDEX 8
	RETLW 1	; // INDEX 8
	RETLW 0	; // INDEX 9
	RETLW 2	; // INDEX 9
	RETLW 0	; // INDEX 10
	RETLW 4	; // INDEX 10
	RETLW 0	; // INDEX 11
	RETLW 8	; // INDEX 11
	RETLW 12	; // INDEX 12
	RETLW 0	; // INDEX 12
	RETLW 13	; // INDEX 13
	RETLW 0	; // INDEX 13
	RETLW 14	; // INDEX 14
	RETLW 0	; // INDEX 14
	RETLW 15	; // INDEX 15
	RETLW 0	; // INDEX 15
	END
