/* Tiny TFT Graphics Library v4 - see http://www.technoblogy.com/show?3WAI
   David Johnson-Davies - www.technoblogy.com - 11th July 2022
   CC BY 4.0
   Licensed under a Creative Commons Attribution 4.0 International license: 
   http://creativecommons.org/licenses/by/4.0/
#if defined(MEGATINYCORE)
// ATtiny402/412 PORTA positions. Change these for the chip you're using
int const dc = 7;
int const mosi = 1;
int const sck = 3;
int const cs = 6;
// ATtiny 0-, 1-, and 2-series port manipulations - assumes all pins in same port
#define PORT_TOGGLE(x)  PORTA.OUTTGL = (x)
#define PORT_LOW(x)     PORTA.OUTCLR = (x)
#define PORT_HIGH(x)    PORTA.OUTSET = (x)
#define PORT_OUTPUT(x)  PORTA.DIRSET = (x)
#else
// ATtiny45/85 PORTB positions. Change these for the chip you're using
int const dc = 0;
int const mosi = 1;
int const sck = 2;
int const cs = 3;
// Classic ATtiny port manipulations - assumes all pins in same port
#define PORT_TOGGLE(x)  PINB = (x)
#define PORT_LOW(x)     PORTB = PORTB & ~((x));
#define PORT_HIGH(x)    PORTB = PORTB | ((x))
#define PORT_OUTPUT(x)  DDRB = (x)
#endif
// Display parameters - uncomment the line for the one you want to use
// Adafruit 1.44" 128x128 display
int const xsize = 128, ysize = 128, xoff = 2, yoff = 1, invert = 0, rotate = 3, bgr = 1;
// AliExpress 1.44" 128x128 display
// int const xsize = 128, ysize = 128, xoff = 2, yoff = 1, invert = 0, rotate = 3, bgr = 1;
// Adafruit 0.96" 160x80 display
// int const xsize = 160, ysize = 80, xoff = 0, yoff = 24, invert = 0, rotate = 6, bgr = 0;
// AliExpress 0.96" 160x80 display
// int const xsize = 160, ysize = 80, xoff = 1, yoff = 26, invert = 1, rotate = 0, bgr = 1;
// Adafruit 1.8" 160x128 display
// int const xsize = 160, ysize = 128, xoff = 0, yoff = 0, invert = 0, rotate = 0, bgr = 1;
// AliExpress 1.8" 160x128 display (red PCB)
// AliExpress 1.8" 160x128 display (blue PCB)
// int const xsize = 160, ysize = 128, xoff = 0, yoff = 0, invert = 0, rotate = 6, bgr = 0;
// Adafruit 1.14" 240x135 display
// int const xsize = 240, ysize = 135, xoff = 40, yoff = 53, invert = 1, rotate = 6, bgr = 0;
// AliExpress 1.14" 240x135 display
// int const xsize = 240, ysize = 135, xoff = 40, yoff = 52, invert = 1, rotate = 0, bgr = 0;
// Adafruit 1.3" 240x240 display
// int const xsize = 240, ysize = 240, xoff = 0, yoff = 80, invert = 1, rotate = 5, bgr = 0;
// Adafruit 1.54" 240x240 display
// AliExpress 1.54" 240x240 display
// Adafruit 1.9" 320x170 display
// int const xsize = 320, ysize = 170, xoff = 0, yoff = 35, invert = 1, rotate = 0, bgr = 0;
// Adafruit 2.0" 320x240 display
// int const xsize = 320, ysize = 240, xoff = 0, yoff = 0, invert = 1, rotate = 6, bgr = 0;
// AliExpress 2.0" 320x240 display
// int const xsize = 320, ysize = 240, xoff = 0, yoff = 0, invert = 1, rotate = 0, bgr = 0;
// Adafruit 2.2" 320x240 display
// int const xsize = 320, ysize = 240, xoff = 0, yoff = 0, invert = 0, rotate = 4, bgr = 1;
// AliExpress 2.4" 320x240 display
// int const xsize = 320, ysize = 240, xoff = 0, yoff = 0, invert = 0, rotate = 2, bgr = 1;
// Character set for text - stored in program memory
const uint8_t CharMap[96][6] PROGMEM = {
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 }, 
{ 0x00, 0x00, 0x5F, 0x00, 0x00, 0x00 }, 
{ 0x00, 0x07, 0x00, 0x07, 0x00, 0x00 }, 
{ 0x14, 0x7F, 0x14, 0x7F, 0x14, 0x00 }, 
{ 0x24, 0x2A, 0x7F, 0x2A, 0x12, 0x00 }, 
{ 0x23, 0x13, 0x08, 0x64, 0x62, 0x00 }, 
{ 0x36, 0x49, 0x56, 0x20, 0x50, 0x00 }, 
{ 0x00, 0x08, 0x07, 0x03, 0x00, 0x00 }, 
{ 0x00, 0x1C, 0x22, 0x41, 0x00, 0x00 }, 
{ 0x00, 0x41, 0x22, 0x1C, 0x00, 0x00 }, 
{ 0x2A, 0x1C, 0x7F, 0x1C, 0x2A, 0x00 }, 
{ 0x08, 0x08, 0x3E, 0x08, 0x08, 0x00 }, 
{ 0x00, 0x80, 0x70, 0x30, 0x00, 0x00 }, 
{ 0x08, 0x08, 0x08, 0x08, 0x08, 0x00 }, 
{ 0x00, 0x00, 0x60, 0x60, 0x00, 0x00 }, 
{ 0x20, 0x10, 0x08, 0x04, 0x02, 0x00 }, 
{ 0x3E, 0x51, 0x49, 0x45, 0x3E, 0x00 }, 
{ 0x00, 0x42, 0x7F, 0x40, 0x00, 0x00 }, 
{ 0x72, 0x49, 0x49, 0x49, 0x46, 0x00 }, 
{ 0x21, 0x41, 0x49, 0x4D, 0x33, 0x00 }, 
{ 0x18, 0x14, 0x12, 0x7F, 0x10, 0x00 }, 
{ 0x27, 0x45, 0x45, 0x45, 0x39, 0x00 }, 
{ 0x3C, 0x4A, 0x49, 0x49, 0x31, 0x00 }, 
{ 0x41, 0x21, 0x11, 0x09, 0x07, 0x00 }, 
{ 0x36, 0x49, 0x49, 0x49, 0x36, 0x00 }, 
{ 0x46, 0x49, 0x49, 0x29, 0x1E, 0x00 }, 
{ 0x00, 0x00, 0x14, 0x00, 0x00, 0x00 }, 
{ 0x00, 0x40, 0x34, 0x00, 0x00, 0x00 }, 
{ 0x00, 0x08, 0x14, 0x22, 0x41, 0x00 }, 
{ 0x14, 0x14, 0x14, 0x14, 0x14, 0x00 }, 
{ 0x00, 0x41, 0x22, 0x14, 0x08, 0x00 }, 
{ 0x02, 0x01, 0x59, 0x09, 0x06, 0x00 }, 
{ 0x3E, 0x41, 0x5D, 0x59, 0x4E, 0x00 }, 
{ 0x7C, 0x12, 0x11, 0x12, 0x7C, 0x00 }, 
{ 0x7F, 0x49, 0x49, 0x49, 0x36, 0x00 }, 
{ 0x3E, 0x41, 0x41, 0x41, 0x22, 0x00 }, 
{ 0x7F, 0x41, 0x41, 0x41, 0x3E, 0x00 }, 
{ 0x7F, 0x49, 0x49, 0x49, 0x41, 0x00 }, 
{ 0x7F, 0x09, 0x09, 0x09, 0x01, 0x00 }, 
{ 0x3E, 0x41, 0x41, 0x51, 0x73, 0x00 }, 
{ 0x7F, 0x08, 0x08, 0x08, 0x7F, 0x00 }, 
{ 0x00, 0x41, 0x7F, 0x41, 0x00, 0x00 }, 
{ 0x20, 0x40, 0x41, 0x3F, 0x01, 0x00 }, 
{ 0x7F, 0x08, 0x14, 0x22, 0x41, 0x00 }, 
{ 0x7F, 0x40, 0x40, 0x40, 0x40, 0x00 }, 
{ 0x7F, 0x02, 0x1C, 0x02, 0x7F, 0x00 }, 
{ 0x7F, 0x04, 0x08, 0x10, 0x7F, 0x00 }, 
{ 0x3E, 0x41, 0x41, 0x41, 0x3E, 0x00 }, 
{ 0x7F, 0x09, 0x09, 0x09, 0x06, 0x00 }, 
{ 0x3E, 0x41, 0x51, 0x21, 0x5E, 0x00 }, 
{ 0x7F, 0x09, 0x19, 0x29, 0x46, 0x00 }, 
{ 0x26, 0x49, 0x49, 0x49, 0x32, 0x00 }, 
{ 0x03, 0x01, 0x7F, 0x01, 0x03, 0x00 }, 
{ 0x3F, 0x40, 0x40, 0x40, 0x3F, 0x00 }, 
{ 0x1F, 0x20, 0x40, 0x20, 0x1F, 0x00 }, 
{ 0x3F, 0x40, 0x38, 0x40, 0x3F, 0x00 }, 
{ 0x63, 0x14, 0x08, 0x14, 0x63, 0x00 }, 
{ 0x03, 0x04, 0x78, 0x04, 0x03, 0x00 }, 
{ 0x61, 0x59, 0x49, 0x4D, 0x43, 0x00 }, 
{ 0x00, 0x7F, 0x41, 0x41, 0x41, 0x00 }, 
{ 0x02, 0x04, 0x08, 0x10, 0x20, 0x00 }, 
{ 0x00, 0x41, 0x41, 0x41, 0x7F, 0x00 }, 
{ 0x04, 0x02, 0x01, 0x02, 0x04, 0x00 }, 
{ 0x40, 0x40, 0x40, 0x40, 0x40, 0x00 }, 
{ 0x00, 0x03, 0x07, 0x08, 0x00, 0x00 }, 
{ 0x20, 0x54, 0x54, 0x78, 0x40, 0x00 }, 
{ 0x7F, 0x28, 0x44, 0x44, 0x38, 0x00 }, 
{ 0x38, 0x44, 0x44, 0x44, 0x28, 0x00 }, 
{ 0x38, 0x44, 0x44, 0x28, 0x7F, 0x00 }, 
{ 0x38, 0x54, 0x54, 0x54, 0x18, 0x00 }, 
{ 0x00, 0x08, 0x7E, 0x09, 0x02, 0x00 }, 
{ 0x18, 0xA4, 0xA4, 0x9C, 0x78, 0x00 }, 
{ 0x7F, 0x08, 0x04, 0x04, 0x78, 0x00 }, 
{ 0x00, 0x44, 0x7D, 0x40, 0x00, 0x00 }, 
{ 0x20, 0x40, 0x40, 0x3D, 0x00, 0x00 }, 
{ 0x7F, 0x10, 0x28, 0x44, 0x00, 0x00 }, 
{ 0x00, 0x41, 0x7F, 0x40, 0x00, 0x00 }, 
{ 0x7C, 0x04, 0x78, 0x04, 0x78, 0x00 }, 
{ 0x7C, 0x08, 0x04, 0x04, 0x78, 0x00 }, 
{ 0x38, 0x44, 0x44, 0x44, 0x38, 0x00 }, 
{ 0xFC, 0x18, 0x24, 0x24, 0x18, 0x00 }, 
{ 0x18, 0x24, 0x24, 0x18, 0xFC, 0x00 }, 
{ 0x7C, 0x08, 0x04, 0x04, 0x08, 0x00 }, 
{ 0x48, 0x54, 0x54, 0x54, 0x24, 0x00 }, 
{ 0x04, 0x04, 0x3F, 0x44, 0x24, 0x00 }, 
{ 0x3C, 0x40, 0x40, 0x20, 0x7C, 0x00 }, 
{ 0x1C, 0x20, 0x40, 0x20, 0x1C, 0x00 }, 
{ 0x3C, 0x40, 0x30, 0x40, 0x3C, 0x00 }, 
{ 0x44, 0x28, 0x10, 0x28, 0x44, 0x00 }, 
{ 0x4C, 0x90, 0x90, 0x90, 0x7C, 0x00 }, 
{ 0x44, 0x64, 0x54, 0x4C, 0x44, 0x00 }, 
{ 0x00, 0x08, 0x36, 0x41, 0x00, 0x00 }, 
{ 0x00, 0x00, 0x77, 0x00, 0x00, 0x00 }, 
{ 0x00, 0x41, 0x36, 0x08, 0x00, 0x00 }, 
{ 0x00, 0x06, 0x09, 0x06, 0x00, 0x00 },  // degree symbol = '~'
{ 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x00 }
// TFT colour display **********************************************
int const CASET = 0x2A; // Define column address
int const RASET = 0x2B; // Define row address
int const RAMWR = 0x2C; // Write to display RAM
int const White = 0xFFFF;
int const Black = 0;
// Current plot position and colours
int xpos, ypos;
int fore = White;
int back = Black;
int scale = 1;     // Text scale
// Send a byte to the display
void Data (uint8_t d) {
  for (uint8_t bit = 0x80; bit; bit >>= 1) {
    PORT_TOGGLE(1<<sck);
    if (d & bit) PORT_HIGH(1<<mosi); else PORT_LOW(1<<mosi);
// Send a command to the display
void Command (uint8_t c) {
  PORT_TOGGLE(1<<dc);
  Data(c);
  PORT_TOGGLE(1<<dc);
// Send a command followed by two data words
void Command2 (uint8_t c, uint16_t d1, uint16_t d2) {
  PORT_TOGGLE(1<<dc);
  Data(c);
  PORT_TOGGLE(1<<dc);
  Data(d1>>8); Data(d1); Data(d2>>8); Data(d2);
void InitDisplay () {
  PORT_OUTPUT(1<<dc | 1<<cs | 1<<mosi | 1<<sck); // All outputs
  PORT_HIGH(1<<dc | 1<<cs | 1<<sck);       // Outputs high
  PORT_TOGGLE(1<<cs);
  Command(0x01);                           // Software reset
  delay(250);                              // delay 250 ms
  Command(0x36); Data(rotate<<5 | bgr<<3); // Set orientation and rgb/bgr
  Command(0x3A); Data(0x55);               // Set color mode - 16-bit color
  Command(0x20+invert);                    // Invert
  Command(0x11);                           // Out of sleep mode
  delay(150);
  PORT_TOGGLE(1<<cs);
void DisplayOn () {
  PORT_TOGGLE(1<<cs);
  Command(0x29);                           // Display on
  delay(150);
  PORT_TOGGLE(1<<cs);
void ClearDisplay () {
  PORT_TOGGLE(1<<cs);
  Command2(CASET, yoff, yoff + ysize - 1);
  Command2(RASET, xoff, xoff + xsize - 1);
  Command(0x3A); Data(0x03);               // 12-bit colour
  Command(RAMWR);                          // Leaves mosi low
  for (int i=0; i<xsize*4; i++) {
    for (int j=0; j<ysize*3; j++) {
  Command(0x3A); Data(0x05);               // Back to 16-bit colour
  PORT_TOGGLE(1<<cs);
unsigned int Colour (int r, int g, int b) {
  return (r & 0xf8)<<8 | (g & 0xfc)<<3 | b>>3;
// Move current plot position to x,y
void MoveTo (int x, int y) {
  xpos = x; ypos = y;
// Plot point at x,y
void PlotPoint (int x, int y) {
  PORT_TOGGLE(1<<cs);
  Command2(CASET, yoff+y, yoff+y);
  Command2(RASET, xoff+x, xoff+x);
  Command(RAMWR); Data(fore>>8); Data(fore & 0xff);
  PORT_TOGGLE(1<<cs);
// Draw a line to x,y
void DrawTo (int x, int y) {
  int sx, sy, e2, err;
  int dx = abs(x - xpos);
  int dy = abs(y - ypos);
  if (xpos < x) sx = 1; else sx = -1;
  if (ypos < y) sy = 1; else sy = -1;
  err = dx - dy;
  for (;;) {
    PlotPoint(xpos, ypos);
    if (xpos==x && ypos==y) return;
    e2 = err<<1;
    if (e2 > -dy) { err = err - dy; xpos = xpos + sx; }
    if (e2 < dx) { err = err + dx; ypos = ypos + sy; }
void FillRect (int w, int h) {
  PORT_TOGGLE(1<<cs);
  Command2(CASET, ypos+yoff, ypos+yoff+h-1);
  Command2(RASET, xpos+xoff, xpos+xoff+w-1);
  Command(RAMWR);
  uint8_t hi = fore>>8;
  uint8_t lo = fore & 0xff;
  for (int i=0; i<w; i++) {
    for (int j=0; j<h; j++) {
      Data(hi); Data(lo);
  PORT_TOGGLE(1<<cs);
void DrawRect (int w, int h) {
  int x1 = xpos, y1 = ypos;
  FillRect(w-1, 1); MoveTo(x1, y1+1);
  FillRect(1, h-1); MoveTo(x1+1, y1+h-1);
  FillRect(w-1, 1); MoveTo(x1+w-1, y1);
  FillRect(1, h-1);
  xpos = x1; ypos = y1;
void FillCircle (int radius) {
  int x1 = xpos, y1 = ypos, dx = 1, dy = 1;
  int x = radius - 1, y = 0;
  int err = dx - (radius<<1);
  while (x >= y) {
    MoveTo(x1-x, y1+y); FillRect(x<<1, 1);
    MoveTo(x1-y, y1+x); FillRect(y<<1, 1);
    MoveTo(x1-y, y1-x); FillRect(y<<1, 1);
    MoveTo(x1-x, y1-y); FillRect(x<<1, 1);
    if (err > 0) {
      x = x - 1; dx = dx + 2;
      err = err - (radius<<1) + dx;
    } else {
      y = y + 1; err = err + dy;
      dy = dy + 2;
void DrawCircle (int radius) {
  while (x >= y) {
    PlotPoint(x1-x, y1+y); PlotPoint(x1+x, y1+y);
    PlotPoint(x1-y, y1+x); PlotPoint(x1+y, y1+x);
    PlotPoint(x1-y, y1-x); PlotPoint(x1+y, y1-x);
    PlotPoint(x1-x, y1-y); PlotPoint(x1+x, y1-y);
    if (err > 0) {
    } else {
      dy = dy + 2;
// Plot an ASCII character with bottom left corner at x,y
void PlotChar (char c) {
  int colour;
  PORT_TOGGLE(1<<cs);
  Command2(CASET, yoff+ypos, yoff+ypos+8*scale-1);
  Command2(RASET, xoff+xpos, xoff+xpos+6*scale-1);
  Command(RAMWR);
  for (int xx=0; xx<6; xx++) {
    int bits = pgm_read_byte(&CharMap[c-32][xx]);
    for (int xr=0; xr<scale; xr++) {
      for (int yy=0; yy<8; yy++) {
        if (bits>>(7-yy) & 1) colour = fore; else colour = back;
        for (int yr=0; yr<scale; yr++) {
          Data(colour>>8); Data(colour & 0xFF);
  PORT_TOGGLE(1<<cs);
  xpos = xpos + 6*scale;
// Plot text starting at the current plot position
void PlotText(PGM_P p) {
  while (1) {
    char c = pgm_read_byte(p++);
    if (c == 0) return;
    PlotChar(c);
void PlotInt(int n) {
  bool lead = false;
  for (int d=10000; d>0; d = d/10) {
    char j = (n/d) % 10;
    if (j!=0 || lead || d==1) { PlotChar(j + '0'); lead = true; }
void TestChart () {
  DrawRect(xsize, ysize);
  scale = 8;
  fore = Colour(255, 0, 0);
  MoveTo((xsize-40)/2, (ysize-64)/2); PlotChar('F');
  scale = 1;
// Demos **********************************************
void BarChart () {
  int x0 = 0, y0 = 0, w = xsize, h = ysize, x1 = 15, y1 = 11;
  MoveTo(x0+(w-x1-90)/2+x1, y0+h-8); PlotText(PSTR("Sensor Readings"));
  // Horizontal axis
  int xinc = (w-x1)/20;
  MoveTo(x0+x1, y0+y1); DrawTo(x0+w-1, y0+y1);
  for (int i=0; i<=20; i=i+4) {
    int mark = x1+i*xinc;
    MoveTo(x0+mark, y0+y1); DrawTo(x0+mark, y0+y1-2);
    // Draw histogram
    if (i != 20) {
      int bar = xinc*4/3;
      for (int b=2; b>=0; b--) {
        fore = Colour(255, 127*b, 0); // Red, Orange, Yellow 
        MoveTo(x0+mark+bar*b-b+1, y0+y1+1); FillRect(bar, 5+random(h-y1-20));
      fore = White;
    if (i > 9) MoveTo(x0+mark-7, y0+y1-11); else MoveTo(x0+mark-3, y0+y1-11);
    PlotInt(i);
  // Vertical axis
  int yinc = (h-y1)/20;
  MoveTo(x0+x1, y0+y1); DrawTo(x0+x1, y0+h-1);
  for (int i=0; i<=20; i=i+5) {
    int mark = y1+i*yinc;
    MoveTo(x0+x1, y0+mark); DrawTo(x0+x1-2, y0+mark);
    if (i > 9) MoveTo(x0+x1-15, y0+mark-4); else MoveTo(x0+x1-9, y0+mark-4);
    PlotInt(i);
void Waterfall () {
  int factor = 5160/h*10;
  MoveTo(x0+(w-x1-60)/2+x1, y0+h-8); PlotText(PSTR("Luminance"));
  // Horizontal axis
  int xinc = (w-x1-15)/30;
  MoveTo(x0+x1, y0+y1); DrawTo(x0+x1+xinc*20, y0+y1);
    PlotInt(i);
  // Vertical axis
    PlotInt(i);
  // Diagonal axis
  yinc = xinc/2;
  // MoveTo(x0+x1, y0+y1); DrawTo(x0+x1+10*xinc, y0+y1+10*xinc);
  MoveTo(x0+x1+20*xinc, y0+y1); DrawTo(x0+x1+30*xinc, y0+y1+10*xinc);
    MoveTo(x0+x1+20*xinc+i*xinc/2, y0+y1+i*xinc/2);
    DrawTo(x0+x1+20*xinc+i*xinc/2+3, y0+y1+i*xinc/2);
    MoveTo(x0+x1+20*xinc+i*xinc/2+6, y0+y1+i*xinc/2-4); PlotInt(i);
  // Plot data
  for (int y=20; y>=0; y--) {
    for (int i=0; i<=20; i++) {
      int fn0 = 180-(i-10)*(i-10)-(y-10)*(y-10);
      int fn1 = 180-(i+1-10)*(i+1-10)-(y-10)*(y-10);
      fore = Colour(255, 255, 0);
      MoveTo(x0+x1+y*yinc+i*xinc, y0+y1+y*yinc+fn0*fn0/factor);
      DrawTo(x0+x1+y*yinc+(i+1)*xinc, y0+y1+y*yinc+fn1*fn1/factor);
      fore = White;
void setup() {
  InitDisplay();
  ClearDisplay();
  DisplayOn();
  MoveTo(0,0);
void loop () {
  BarChart();
  // Waterfall();
  for (;;);
