  wiring_pulse.c - pulseIn() function
  Part of Arduino - http://www.arduino.cc/
  Copyright (c) 2005-2006 David A. Mellis
  This library is free software; you can redistribute it and/or
  modify it under the terms of the GNU Lesser General Public
  License as published by the Free Software Foundation; either
  version 2.1 of the License, or (at your option) any later version.
  This library is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
  Lesser General Public License for more details.
  You should have received a copy of the GNU Lesser General
  Public License along with this library; if not, write to the
  Free Software Foundation, Inc., 59 Temple Place, Suite 330,
  Boston, MA  02111-1307  USA
#include "wiring_private.h"
#include "pins_arduino.h"
/* Measures the length (in microseconds) of a pulse on the pin; state is HIGH
 * or LOW, the type of pulse to measure.  Works on pulses from 2-3 microseconds
 * to 3 minutes in length, but must be called at least a few dozen microseconds
 * before the start of the pulse.
 * This function performs better with short pulses in noInterrupt() context
unsigned long pulseIn(uint8_t pin, uint8_t state, unsigned long timeout)
	// cache the port and bit of the pin in order to speed up the
	// pulse width measuring loop and achieve finer resolution.  calling
	// digitalRead() instead yields much coarser resolution.
	uint8_t bit = digitalPinToBitMask(pin);
	uint8_t port = digitalPinToPort(pin);
	uint8_t stateMask = (state ? bit : 0);
	// convert the timeout from microseconds to a number of times through
	// the initial loop; it takes approximately 16 clock cycles per iteration
	unsigned long maxloops = microsecondsToClockCycles(timeout)/16;
	unsigned long width = countPulseASM(portInputRegister(port), bit, stateMask, maxloops);
	// prevent clockCyclesToMicroseconds to return bogus values if countPulseASM timed out
	if (width)
		return clockCyclesToMicroseconds(width * 16 + 16);
	else
		return 0;
 * ATTENTION:
 * this function relies on micros() so cannot be used in noInterrupt() context
unsigned long pulseInLong(uint8_t pin, uint8_t state, unsigned long timeout)
	unsigned long startMicros = micros();
	// wait for any previous pulse to end
	while ((*portInputRegister(port) & bit) == stateMask) {
		if (micros() - startMicros > timeout)
			return 0;
	// wait for the pulse to start
	while ((*portInputRegister(port) & bit) != stateMask) {
			return 0;
	unsigned long start = micros();
	// wait for the pulse to stop
			return 0;
	return micros() - start;
