<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="9.5.2">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting keepoldvectorfont="yes"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="yes"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="yes"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="yes"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="yes"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="yes"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="yes"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="yes"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="yes"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="yes"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="yes"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="yes"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="yes"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="yes"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="88" name="SimResults" color="9" fill="1" visible="yes" active="yes"/>
<layer number="89" name="SimProbes" color="9" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="yes" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
</layers>
<library>
<description>Tubes devices</description>
<packages>
<package name="MSF9">
<wire x1="-12.827" y1="-3.048" x2="-12.827" y2="3.048" width="0.127" layer="21"/>
<wire x1="-11.811" y1="-3.048" x2="-12.827" y2="-3.048" width="0.127" layer="21"/>
<wire x1="-11.811" y1="-3.048" x2="-11.811" y2="-3.302" width="0.127" layer="21"/>
<wire x1="-11.811" y1="-4.064" x2="-13.335" y2="-4.064" width="0.127" layer="21"/>
<wire x1="12.8524" y1="-3.048" x2="11.8364" y2="-3.048" width="0.127" layer="21"/>
<wire x1="11.8364" y1="-4.064" x2="11.8364" y2="-3.302" width="0.127" layer="21"/>
<wire x1="12.8524" y1="3.048" x2="12.8524" y2="-3.048" width="0.127" layer="21"/>
<wire x1="-11.811" y1="-3.048" x2="-11.811" y2="-2.032" width="0.127" layer="21"/>
<wire x1="11.8364" y1="-3.048" x2="11.8364" y2="-2.032" width="0.127" layer="21"/>
<wire x1="11.8364" y1="-2.032" x2="-11.811" y2="-2.032" width="0.127" layer="21"/>
<wire x1="-4.191" y1="4.064" x2="-4.191" y2="3.048" width="0.127" layer="21"/>
<wire x1="-4.191" y1="3.048" x2="-3.683" y2="3.048" width="0.127" layer="21"/>
<wire x1="-4.191" y1="4.064" x2="-3.683" y2="4.064" width="0.127" layer="21"/>
<wire x1="-3.683" y1="4.064" x2="3.5814" y2="4.064" width="0.127" layer="21"/>
<wire x1="3.5814" y1="4.064" x2="3.5814" y2="3.302" width="0.127" layer="21"/>
<wire x1="3.5814" y1="4.064" x2="4.0894" y2="4.064" width="0.127" layer="21"/>
<wire x1="3.5814" y1="3.048" x2="4.0894" y2="3.048" width="0.127" layer="21"/>
<wire x1="4.0894" y1="4.064" x2="4.0894" y2="3.048" width="0.127" layer="21"/>
<wire x1="4.0894" y1="4.064" x2="5.1054" y2="4.064" width="0.127" layer="21"/>
<wire x1="5.1054" y1="4.064" x2="5.1054" y2="3.302" width="0.127" layer="21"/>
<wire x1="5.1054" y1="4.064" x2="13.3604" y2="4.064" width="0.127" layer="21"/>
<wire x1="4.0894" y1="3.048" x2="5.1054" y2="3.048" width="0.127" layer="21"/>
<wire x1="5.1054" y1="3.048" x2="12.8524" y2="3.048" width="0.127" layer="21"/>
<wire x1="-5.08" y1="4.064" x2="-5.08" y2="3.302" width="0.127" layer="21"/>
<wire x1="-5.08" y1="4.064" x2="-4.191" y2="4.064" width="0.127" layer="21"/>
<wire x1="-12.827" y1="3.048" x2="-5.08" y2="3.048" width="0.127" layer="21"/>
<wire x1="-5.08" y1="3.048" x2="-4.191" y2="3.048" width="0.127" layer="21"/>
<wire x1="-13.843" y1="-3.556" x2="-13.843" y2="3.556" width="0.127" layer="21"/>
<wire x1="-13.843" y1="-3.556" x2="-13.335" y2="-4.064" width="0.127" layer="21" curve="90"/>
<wire x1="-11.811" y1="-3.302" x2="-13.081" y2="-3.302" width="0" layer="21"/>
<wire x1="-11.811" y1="-3.302" x2="-11.811" y2="-4.064" width="0.127" layer="21"/>
<wire x1="-13.081" y1="-3.302" x2="-13.081" y2="3.302" width="0" layer="21"/>
<wire x1="13.1064" y1="-3.302" x2="11.8364" y2="-3.302" width="0" layer="21"/>
<wire x1="11.8364" y1="-3.302" x2="11.8364" y2="-3.048" width="0.127" layer="21"/>
<wire x1="13.1064" y1="3.302" x2="13.1064" y2="-3.302" width="0" layer="21"/>
<wire x1="13.3604" y1="-4.064" x2="11.8364" y2="-4.064" width="0.127" layer="21"/>
<wire x1="13.3604" y1="-4.064" x2="13.8684" y2="-3.556" width="0.127" layer="21" curve="90"/>
<wire x1="13.8684" y1="3.556" x2="13.8684" y2="-3.556" width="0.127" layer="21"/>
<wire x1="13.3604" y1="4.064" x2="13.8684" y2="3.556" width="0.127" layer="21" curve="-90"/>
<wire x1="-13.335" y1="4.064" x2="-5.08" y2="4.064" width="0.127" layer="21"/>
<wire x1="-13.843" y1="3.556" x2="-13.335" y2="4.064" width="0.127" layer="21" curve="-90"/>
<wire x1="-3.683" y1="4.064" x2="-3.683" y2="3.302" width="0.127" layer="21"/>
<wire x1="-3.683" y1="3.302" x2="3.5814" y2="3.302" width="0.127" layer="21"/>
<wire x1="-3.683" y1="3.302" x2="-3.683" y2="3.048" width="0.127" layer="21"/>
<wire x1="3.5814" y1="3.302" x2="3.5814" y2="3.048" width="0.127" layer="21"/>
<wire x1="-3.683" y1="3.048" x2="3.5814" y2="3.048" width="0.127" layer="21"/>
<wire x1="-13.081" y1="3.302" x2="-5.08" y2="3.302" width="0" layer="21"/>
<wire x1="-5.08" y1="3.302" x2="-5.08" y2="3.048" width="0.127" layer="21"/>
<wire x1="5.1054" y1="3.302" x2="13.1064" y2="3.302" width="0" layer="21"/>
<wire x1="5.1054" y1="3.302" x2="5.1054" y2="3.048" width="0.127" layer="21"/>
<wire x1="-5.3848" y1="-0.381" x2="-4.6228" y2="-0.381" width="0.127" layer="51"/>
<wire x1="-4.6228" y1="-0.381" x2="-4.6228" y2="0.381" width="0.127" layer="51"/>
<wire x1="-4.6228" y1="0.381" x2="-5.3848" y2="0.381" width="0.127" layer="51"/>
<wire x1="-5.3848" y1="0.381" x2="-5.3848" y2="-0.381" width="0.127" layer="51"/>
<wire x1="-5.3848" y1="0.381" x2="-4.6228" y2="-0.381" width="0.127" layer="51"/>
<wire x1="-4.6228" y1="0.381" x2="-5.3848" y2="-0.381" width="0.127" layer="51"/>
<wire x1="-2.8702" y1="-0.381" x2="-2.1082" y2="-0.381" width="0.127" layer="51"/>
<wire x1="-2.1082" y1="-0.381" x2="-2.1082" y2="0.381" width="0.127" layer="51"/>
<wire x1="-2.1082" y1="0.381" x2="-2.8702" y2="0.381" width="0.127" layer="51"/>
<wire x1="-2.8702" y1="0.381" x2="-2.8702" y2="-0.381" width="0.127" layer="51"/>
<wire x1="-2.8702" y1="0.381" x2="-2.1082" y2="-0.381" width="0.127" layer="51"/>
<wire x1="-2.1082" y1="0.381" x2="-2.8702" y2="-0.381" width="0.127" layer="51"/>
<wire x1="7.112" y1="-0.381" x2="7.874" y2="-0.381" width="0.127" layer="51"/>
<wire x1="7.874" y1="-0.381" x2="7.874" y2="0.381" width="0.127" layer="51"/>
<wire x1="7.874" y1="0.381" x2="7.112" y2="0.381" width="0.127" layer="51"/>
<wire x1="7.112" y1="0.381" x2="7.112" y2="-0.381" width="0.127" layer="51"/>
<wire x1="7.112" y1="0.381" x2="7.874" y2="-0.381" width="0.127" layer="51"/>
<wire x1="7.874" y1="0.381" x2="7.112" y2="-0.381" width="0.127" layer="51"/>
<wire x1="0.381" y1="-0.381" x2="0.381" y2="0.381" width="0.127" layer="51"/>
<wire x1="0.381" y1="0.381" x2="-0.381" y2="-0.381" width="0.127" layer="51"/>
<wire x1="-0.381" y1="0.381" x2="0.381" y2="-0.381" width="0.127" layer="51"/>
<wire x1="-0.381" y1="0.381" x2="-0.381" y2="-0.381" width="0.127" layer="51"/>
<wire x1="0.381" y1="0.381" x2="-0.381" y2="0.381" width="0.127" layer="51"/>
<wire x1="-0.381" y1="-0.381" x2="0.381" y2="-0.381" width="0.127" layer="51"/>
<wire x1="2.8702" y1="-0.381" x2="2.8702" y2="0.381" width="0.127" layer="51"/>
<wire x1="2.1082" y1="0.381" x2="2.8702" y2="-0.381" width="0.127" layer="51"/>
<wire x1="2.8702" y1="0.381" x2="2.1082" y2="-0.381" width="0.127" layer="51"/>
<wire x1="2.1082" y1="-0.381" x2="2.8702" y2="-0.381" width="0.127" layer="51"/>
<wire x1="2.8702" y1="0.381" x2="2.1082" y2="0.381" width="0.127" layer="51"/>
<wire x1="2.1082" y1="0.381" x2="2.1082" y2="-0.381" width="0.127" layer="51"/>
<wire x1="5.3848" y1="-0.381" x2="5.3848" y2="0.381" width="0.127" layer="51"/>
<wire x1="5.3848" y1="0.381" x2="4.6228" y2="0.381" width="0.127" layer="51"/>
<wire x1="4.6228" y1="0.381" x2="4.6228" y2="-0.381" width="0.127" layer="51"/>
<wire x1="4.6228" y1="-0.381" x2="5.3848" y2="-0.381" width="0.127" layer="51"/>
<wire x1="5.3848" y1="0.381" x2="4.6228" y2="-0.381" width="0.127" layer="51"/>
<wire x1="4.6228" y1="0.381" x2="5.3848" y2="-0.381" width="0.127" layer="51"/>
<wire x1="-10.3886" y1="-0.381" x2="-9.6266" y2="-0.381" width="0.127" layer="51"/>
<wire x1="-7.874" y1="0.381" x2="-7.874" y2="-0.381" width="0.127" layer="51"/>
<wire x1="-10.3886" y1="0.381" x2="-10.3886" y2="-0.381" width="0.127" layer="51"/>
<wire x1="-7.112" y1="0.381" x2="-7.874" y2="0.381" width="0.127" layer="51"/>
<wire x1="-9.6266" y1="0.381" x2="-10.3886" y2="0.381" width="0.127" layer="51"/>
<wire x1="-7.112" y1="-0.381" x2="-7.112" y2="0.381" width="0.127" layer="51"/>
<wire x1="-9.6266" y1="-0.381" x2="-9.6266" y2="0.381" width="0.127" layer="51"/>
<wire x1="-7.112" y1="0.381" x2="-7.874" y2="-0.381" width="0.127" layer="51"/>
<wire x1="-7.874" y1="-0.381" x2="-7.112" y2="-0.381" width="0.127" layer="51"/>
<wire x1="-9.6266" y1="0.381" x2="-10.3886" y2="-0.381" width="0.127" layer="51"/>
<wire x1="-7.874" y1="0.381" x2="-7.112" y2="-0.381" width="0.127" layer="51"/>
<wire x1="-10.3886" y1="0.381" x2="-9.6266" y2="-0.381" width="0.127" layer="51"/>
<wire x1="9.6266" y1="0.381" x2="9.6266" y2="-0.381" width="0.127" layer="51"/>
<wire x1="10.3886" y1="0.381" x2="9.6266" y2="0.381" width="0.127" layer="51"/>
<wire x1="10.3886" y1="-0.381" x2="10.3886" y2="0.381" width="0.127" layer="51"/>
<wire x1="9.6266" y1="0.381" x2="10.3886" y2="-0.381" width="0.127" layer="51"/>
<wire x1="10.3886" y1="0.381" x2="9.6266" y2="-0.381" width="0.127" layer="51"/>
<wire x1="9.6266" y1="-0.381" x2="10.3886" y2="-0.381" width="0.127" layer="51"/>
<pad name="7" x="-5.0038" y="0" drill="1.016" diameter="1.778" shape="octagon"/>
<pad name="6" x="-2.4892" y="0" drill="1.016" diameter="1.778" shape="octagon"/>
<pad name="2" x="7.493" y="0" drill="1.016" diameter="1.778" shape="octagon"/>
<pad name="5" x="0" y="0" drill="1.016" diameter="1.778" shape="octagon"/>
<pad name="4" x="2.4892" y="0" drill="1.016" diameter="1.778" shape="octagon"/>
<pad name="3" x="5.0038" y="0" drill="1.016" diameter="1.778" shape="octagon"/>
<pad name="1" x="10.0076" y="0" drill="1.016" diameter="1.778" shape="octagon"/>
<pad name="8" x="-7.493" y="0" drill="1.016" diameter="1.778" shape="octagon"/>
<pad name="9" x="-10.0076" y="0" drill="1.016" diameter="1.778" shape="octagon"/>
<text x="-13.843" y="6.731" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-13.843" y="4.572" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="11.557" y="-1.651" size="1.27" layer="21" ratio="10">1</text>
<text x="-12.446" y="-1.651" size="1.27" layer="21" ratio="10">9</text>
<rectangle x1="-3.6068" y1="3.302" x2="3.5052" y2="4.064" layer="21"/>
</package>
<package name="MSF8">
<wire x1="-11.5824" y1="-3.048" x2="-11.5824" y2="3.048" width="0.127" layer="21"/>
<wire x1="-10.5664" y1="-3.048" x2="-11.5824" y2="-3.048" width="0.127" layer="21"/>
<wire x1="-10.5664" y1="-3.048" x2="-10.5664" y2="-3.302" width="0.127" layer="21"/>
<wire x1="-10.5664" y1="-4.064" x2="-12.0904" y2="-4.064" width="0.127" layer="21"/>
<wire x1="11.6078" y1="-3.048" x2="10.5918" y2="-3.048" width="0.127" layer="21"/>
<wire x1="10.5918" y1="-4.064" x2="10.5918" y2="-3.302" width="0.127" layer="21"/>
<wire x1="11.6078" y1="3.048" x2="11.6078" y2="-3.048" width="0.127" layer="21"/>
<wire x1="-10.5664" y1="-3.048" x2="-10.5664" y2="-2.032" width="0.127" layer="21"/>
<wire x1="10.5918" y1="-3.048" x2="10.5918" y2="-2.032" width="0.127" layer="21"/>
<wire x1="10.5918" y1="-2.032" x2="-10.5664" y2="-2.032" width="0.127" layer="21"/>
<wire x1="5.1054" y1="4.064" x2="12.1158" y2="4.064" width="0.127" layer="21"/>
<wire x1="5.1054" y1="3.048" x2="11.6078" y2="3.048" width="0.127" layer="21"/>
<wire x1="-11.5824" y1="3.048" x2="-5.08" y2="3.048" width="0.127" layer="21"/>
<wire x1="-12.5984" y1="-3.556" x2="-12.5984" y2="3.556" width="0.127" layer="21"/>
<wire x1="-12.5984" y1="-3.556" x2="-12.0904" y2="-4.064" width="0.127" layer="21" curve="90"/>
<wire x1="-10.5664" y1="-3.302" x2="-11.8364" y2="-3.302" width="0" layer="21"/>
<wire x1="-10.5664" y1="-3.302" x2="-10.5664" y2="-4.064" width="0.127" layer="21"/>
<wire x1="-11.8364" y1="-3.302" x2="-11.8364" y2="3.302" width="0" layer="21"/>
<wire x1="11.8618" y1="-3.302" x2="10.5918" y2="-3.302" width="0" layer="21"/>
<wire x1="10.5918" y1="-3.302" x2="10.5918" y2="-3.048" width="0.127" layer="21"/>
<wire x1="11.8618" y1="3.302" x2="11.8618" y2="-3.302" width="0" layer="21"/>
<wire x1="12.1158" y1="-4.064" x2="10.5918" y2="-4.064" width="0.127" layer="21"/>
<wire x1="12.1158" y1="-4.064" x2="12.6238" y2="-3.556" width="0.127" layer="21" curve="90"/>
<wire x1="12.6238" y1="3.556" x2="12.6238" y2="-3.556" width="0.127" layer="21"/>
<wire x1="12.1158" y1="4.064" x2="12.6238" y2="3.556" width="0.127" layer="21" curve="-90"/>
<wire x1="-12.0904" y1="4.064" x2="-5.08" y2="4.064" width="0.127" layer="21"/>
<wire x1="-12.5984" y1="3.556" x2="-12.0904" y2="4.064" width="0.127" layer="21" curve="-90"/>
<wire x1="-11.8364" y1="3.302" x2="-5.08" y2="3.302" width="0" layer="21"/>
<wire x1="5.1054" y1="3.302" x2="11.8618" y2="3.302" width="0" layer="21"/>
<wire x1="-4.1402" y1="-0.381" x2="-3.3782" y2="-0.381" width="0.127" layer="51"/>
<wire x1="-3.3782" y1="-0.381" x2="-3.3782" y2="0.381" width="0.127" layer="51"/>
<wire x1="-3.3782" y1="0.381" x2="-4.1402" y2="0.381" width="0.127" layer="51"/>
<wire x1="-4.1402" y1="0.381" x2="-4.1402" y2="-0.381" width="0.127" layer="51"/>
<wire x1="-4.1402" y1="0.381" x2="-3.3782" y2="-0.381" width="0.127" layer="51"/>
<wire x1="-3.3782" y1="0.381" x2="-4.1402" y2="-0.381" width="0.127" layer="51"/>
<wire x1="-1.6256" y1="-0.381" x2="-0.8636" y2="-0.381" width="0.127" layer="51"/>
<wire x1="-0.8636" y1="-0.381" x2="-0.8636" y2="0.381" width="0.127" layer="51"/>
<wire x1="-0.8636" y1="0.381" x2="-1.6256" y2="0.381" width="0.127" layer="51"/>
<wire x1="-1.6256" y1="0.381" x2="-1.6256" y2="-0.381" width="0.127" layer="51"/>
<wire x1="-1.6256" y1="0.381" x2="-0.8636" y2="-0.381" width="0.127" layer="51"/>
<wire x1="-0.8636" y1="0.381" x2="-1.6256" y2="-0.381" width="0.127" layer="51"/>
<wire x1="8.382" y1="-0.381" x2="9.144" y2="-0.381" width="0.127" layer="51"/>
<wire x1="9.144" y1="-0.381" x2="9.144" y2="0.381" width="0.127" layer="51"/>
<wire x1="9.144" y1="0.381" x2="8.382" y2="0.381" width="0.127" layer="51"/>
<wire x1="8.382" y1="0.381" x2="8.382" y2="-0.381" width="0.127" layer="51"/>
<wire x1="8.382" y1="0.381" x2="9.144" y2="-0.381" width="0.127" layer="51"/>
<wire x1="9.144" y1="0.381" x2="8.382" y2="-0.381" width="0.127" layer="51"/>
<wire x1="1.6256" y1="-0.381" x2="1.6256" y2="0.381" width="0.127" layer="51"/>
<wire x1="1.6256" y1="0.381" x2="0.8636" y2="-0.381" width="0.127" layer="51"/>
<wire x1="0.8636" y1="0.381" x2="1.6256" y2="-0.381" width="0.127" layer="51"/>
<wire x1="0.8636" y1="0.381" x2="0.8636" y2="-0.381" width="0.127" layer="51"/>
<wire x1="1.6256" y1="0.381" x2="0.8636" y2="0.381" width="0.127" layer="51"/>
<wire x1="0.8636" y1="-0.381" x2="1.6256" y2="-0.381" width="0.127" layer="51"/>
<wire x1="4.1402" y1="-0.381" x2="4.1402" y2="0.381" width="0.127" layer="51"/>
<wire x1="3.3782" y1="0.381" x2="4.1402" y2="-0.381" width="0.127" layer="51"/>
<wire x1="4.1402" y1="0.381" x2="3.3782" y2="-0.381" width="0.127" layer="51"/>
<wire x1="3.3782" y1="-0.381" x2="4.1402" y2="-0.381" width="0.127" layer="51"/>
<wire x1="4.1402" y1="0.381" x2="3.3782" y2="0.381" width="0.127" layer="51"/>
<wire x1="3.3782" y1="0.381" x2="3.3782" y2="-0.381" width="0.127" layer="51"/>
<wire x1="6.6294" y1="-0.381" x2="6.6294" y2="0.381" width="0.127" layer="51"/>
<wire x1="6.6294" y1="0.381" x2="5.8674" y2="0.381" width="0.127" layer="51"/>
<wire x1="5.8674" y1="0.381" x2="5.8674" y2="-0.381" width="0.127" layer="51"/>
<wire x1="5.8674" y1="-0.381" x2="6.6294" y2="-0.381" width="0.127" layer="51"/>
<wire x1="6.6294" y1="0.381" x2="5.8674" y2="-0.381" width="0.127" layer="51"/>
<wire x1="5.8674" y1="0.381" x2="6.6294" y2="-0.381" width="0.127" layer="51"/>
<wire x1="-9.144" y1="-0.381" x2="-8.382" y2="-0.381" width="0.127" layer="51"/>
<wire x1="-6.6294" y1="0.381" x2="-6.6294" y2="-0.381" width="0.127" layer="51"/>
<wire x1="-9.144" y1="0.381" x2="-9.144" y2="-0.381" width="0.127" layer="51"/>
<wire x1="-5.8674" y1="0.381" x2="-6.6294" y2="0.381" width="0.127" layer="51"/>
<wire x1="-8.382" y1="0.381" x2="-9.144" y2="0.381" width="0.127" layer="51"/>
<wire x1="-5.8674" y1="-0.381" x2="-5.8674" y2="0.381" width="0.127" layer="51"/>
<wire x1="-8.382" y1="-0.381" x2="-8.382" y2="0.381" width="0.127" layer="51"/>
<wire x1="-5.8674" y1="0.381" x2="-6.6294" y2="-0.381" width="0.127" layer="51"/>
<wire x1="-6.6294" y1="-0.381" x2="-5.8674" y2="-0.381" width="0.127" layer="51"/>
<wire x1="-8.382" y1="0.381" x2="-9.144" y2="-0.381" width="0.127" layer="51"/>
<wire x1="-6.6294" y1="0.381" x2="-5.8674" y2="-0.381" width="0.127" layer="51"/>
<wire x1="-9.144" y1="0.381" x2="-8.382" y2="-0.381" width="0.127" layer="51"/>
<pad name="6" x="-3.7592" y="0" drill="1.016" diameter="1.778" shape="octagon"/>
<pad name="5" x="-1.2446" y="0" drill="1.016" diameter="1.778" shape="octagon"/>
<pad name="1" x="8.763" y="0" drill="1.016" diameter="1.778" shape="octagon"/>
<pad name="4" x="1.2446" y="0" drill="1.016" diameter="1.778" shape="octagon"/>
<pad name="3" x="3.7592" y="0" drill="1.016" diameter="1.778" shape="octagon"/>
<pad name="2" x="6.2484" y="0" drill="1.016" diameter="1.778" shape="octagon"/>
<pad name="7" x="-6.2484" y="0" drill="1.016" diameter="1.778" shape="octagon"/>
<pad name="8" x="-8.763" y="0" drill="1.016" diameter="1.778" shape="octagon"/>
<text x="-12.5984" y="6.604" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-12.5984" y="4.445" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="10.287" y="-1.651" size="1.27" layer="21" ratio="10">1</text>
<text x="-11.303" y="-1.651" size="1.27" layer="21" ratio="10">8</text>
</package>
<package name="OKTAL">
<wire x1="-1.27" y1="-3.81" x2="1.27" y2="-3.81" width="0.127" layer="21" curve="180" cap="flat"/>
<wire x1="-1.27" y1="-3.81" x2="1.27" y2="-3.81" width="0.127" layer="21" curve="-323.130102" cap="flat"/>
<wire x1="-11.43" y1="0" x2="-6.35" y2="0" width="0.6096" layer="21"/>
<wire x1="0" y1="11.684" x2="0" y2="6.604" width="0.6096" layer="21"/>
<wire x1="6.604" y1="0" x2="11.43" y2="0" width="0.6096" layer="21"/>
<wire x1="0" y1="-6.096" x2="0" y2="-11.176" width="0.6096" layer="21"/>
<wire x1="4.572" y1="-4.572" x2="7.874" y2="-7.874" width="0.6096" layer="21"/>
<wire x1="4.572" y1="4.572" x2="8.128" y2="8.128" width="0.6096" layer="21"/>
<wire x1="-4.572" y1="4.572" x2="-8.128" y2="8.128" width="0.6096" layer="21"/>
<wire x1="-4.318" y1="-4.318" x2="-7.874" y2="-7.874" width="0.6096" layer="21"/>
<wire x1="-1.524" y1="-4.064" x2="1.524" y2="-4.064" width="0.127" layer="21" curve="-318.88791" cap="flat"/>
<circle x="-8.89" y="-3.81" radius="1.5875" width="0.127" layer="27"/>
<circle x="-8.89" y="3.81" radius="1.5875" width="0.127" layer="27"/>
<circle x="-3.81" y="8.89" radius="1.5875" width="0.127" layer="27"/>
<circle x="3.81" y="8.89" radius="1.5875" width="0.127" layer="27"/>
<circle x="8.89" y="3.81" radius="1.5875" width="0.127" layer="27"/>
<circle x="8.89" y="-3.81" radius="1.5875" width="0.127" layer="27"/>
<circle x="3.81" y="-8.89" radius="1.5875" width="0.127" layer="27"/>
<circle x="-3.81" y="-8.89" radius="1.5875" width="0.127" layer="27"/>
<circle x="0" y="0" radius="13.5479" width="0.254" layer="21"/>
<circle x="-8.89" y="-3.81" radius="2.615" width="0.4064" layer="21"/>
<circle x="-3.81" y="-8.89" radius="2.5526" width="0.4064" layer="21"/>
<circle x="3.81" y="-8.89" radius="2.5526" width="0.4064" layer="21"/>
<circle x="8.89" y="-3.81" radius="2.5016" width="0.4064" layer="21"/>
<circle x="8.89" y="3.81" radius="2.5903" width="0.4064" layer="21"/>
<circle x="3.81" y="8.89" radius="2.5903" width="0.4064" layer="21"/>
<circle x="-3.81" y="8.89" radius="2.615" width="0.4064" layer="21"/>
<circle x="-8.89" y="3.81" radius="2.615" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="14.199" width="0.6096" layer="21"/>
<pad name="1" x="3.81" y="-8.89" drill="1.27" diameter="2.54"/>
<pad name="7" x="-8.89" y="-3.81" drill="1.27" diameter="2.54"/>
<pad name="5" x="-3.81" y="8.89" drill="1.27" diameter="2.54"/>
<pad name="4" x="3.81" y="8.89" drill="1.27" diameter="2.54"/>
<pad name="3" x="8.89" y="3.81" drill="1.27" diameter="2.54"/>
<pad name="2" x="8.89" y="-3.81" drill="1.27" diameter="2.54"/>
<pad name="8" x="-3.81" y="-8.89" drill="1.27" diameter="2.54"/>
<pad name="6" x="-8.89" y="3.81" drill="1.27" diameter="2.54"/>
<text x="-4.699" y="-16.637" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.699" y="-18.796" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-2.794" y="-6.35" size="1.27" layer="21">8</text>
<text x="-5.842" y="-3.048" size="1.27" layer="21">7</text>
<text x="-6.096" y="1.778" size="1.27" layer="21">6</text>
<text x="-2.794" y="4.826" size="1.27" layer="21">5</text>
<text x="1.778" y="4.826" size="1.27" layer="21">4</text>
<text x="5.08" y="1.778" size="1.27" layer="21">3</text>
<text x="5.08" y="-3.048" size="1.27" layer="21">2</text>
<text x="1.778" y="-6.35" size="1.27" layer="21">1</text>
</package>
<package name="NOVAL">
<circle x="0" y="0" radius="3" width="0.254" layer="21"/>
<circle x="-6.5" y="-2" radius="1.5" width="0.3048" layer="21"/>
<circle x="-4" y="-5.5" radius="1.5" width="0.3048" layer="21"/>
<circle x="4" y="-5.5" radius="1.5" width="0.3048" layer="21"/>
<circle x="6.5" y="-2" radius="1.5811" width="0.3048" layer="21"/>
<circle x="-6.5" y="2.25" radius="1.5206" width="0.3048" layer="21"/>
<circle x="-4" y="5.5" radius="1.4577" width="0.3048" layer="21"/>
<circle x="0" y="6.75" radius="1.5" width="0.3048" layer="21"/>
<circle x="4" y="5.5" radius="1.6007" width="0.3048" layer="21"/>
<circle x="6.5" y="2.25" radius="1.5811" width="0.3048" layer="21"/>
<circle x="-4.0132" y="5.4864" radius="0.9725" width="0.127" layer="21"/>
<circle x="0" y="6.7564" radius="0.9725" width="0.127" layer="21"/>
<circle x="4.0386" y="5.4864" radius="0.9725" width="0.127" layer="21"/>
<circle x="6.5532" y="2.2352" radius="0.9725" width="0.127" layer="21"/>
<circle x="6.5532" y="-2.0066" radius="0.9725" width="0.127" layer="21"/>
<circle x="4.0132" y="-5.5372" radius="0.9725" width="0.127" layer="21"/>
<circle x="-4.0132" y="-5.5372" radius="0.9725" width="0.127" layer="21"/>
<circle x="-6.5278" y="-2.0066" radius="0.9725" width="0.127" layer="21"/>
<circle x="-6.5024" y="2.2606" radius="0.9725" width="0.127" layer="21"/>
<circle x="0" y="0" radius="12.5" width="0.6096" layer="21"/>
<circle x="0" y="0" radius="2.54" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="10" width="0.4064" layer="21"/>
<pad name="9" x="-5.826" y="-7.985" drill="1.6002" diameter="3.81"/>
<pad name="1" x="6.207" y="-7.858" drill="1.6002" diameter="3.81"/>
<pad name="8" x="-9.524" y="-2.992" drill="1.6002" diameter="3.81"/>
<pad name="7" x="-9.401" y="3.655" drill="1.6002" diameter="3.81"/>
<pad name="6" x="-5.893" y="8.167" drill="1.6002" diameter="3.81"/>
<pad name="5" x="0" y="10.048" drill="1.6002" diameter="3.81"/>
<pad name="4" x="6.274" y="7.786" drill="1.6002" diameter="3.81"/>
<pad name="2" x="9.254" y="-3.484" drill="1.6002" diameter="3.81"/>
<pad name="3" x="9.528" y="3.147" drill="1.6002" diameter="3.81"/>
<text x="-4.064" y="-14.732" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.064" y="-17.018" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-2.794" y="-4.2164" size="1.27" layer="21">9</text>
<text x="-4.5974" y="-1.7526" size="1.27" layer="21">8</text>
<text x="-4.5466" y="0.7112" size="1.27" layer="21">7</text>
<text x="-2.9718" y="2.8702" size="1.27" layer="21">6</text>
<text x="-0.4318" y="3.5814" size="1.27" layer="21">5</text>
<text x="1.8288" y="2.921" size="1.27" layer="21">4</text>
<text x="3.6068" y="0.7366" size="1.27" layer="21">3</text>
<text x="3.429" y="-1.778" size="1.27" layer="21">2</text>
<text x="1.9304" y="-4.2418" size="1.27" layer="21">1</text>
</package>
<package name="ZM1000">
<wire x1="-8" y1="0" x2="-4" y2="-7" width="0.127" layer="21" curve="-299.487126" cap="flat"/>
<circle x="0" y="0" radius="9" width="0.6096" layer="21"/>
<circle x="-1.27" y="5.08" radius="0.898" width="0.127" layer="21"/>
<circle x="1.27" y="5.08" radius="0.898" width="0.127" layer="21"/>
<circle x="3.81" y="2.54" radius="0.898" width="0.127" layer="21"/>
<circle x="1.27" y="2.54" radius="0.898" width="0.127" layer="21"/>
<circle x="-1.27" y="2.54" radius="0.898" width="0.127" layer="21"/>
<circle x="-3.81" y="2.54" radius="0.898" width="0.127" layer="21"/>
<circle x="-3.81" y="0" radius="0.898" width="0.127" layer="21"/>
<circle x="-3.81" y="-2.54" radius="0.898" width="0.127" layer="21"/>
<circle x="-1.27" y="0" radius="0.898" width="0.127" layer="21"/>
<circle x="1.27" y="0" radius="0.898" width="0.127" layer="21"/>
<circle x="3.81" y="0" radius="0.898" width="0.127" layer="21"/>
<circle x="1.27" y="-2.54" radius="0.898" width="0.127" layer="21"/>
<circle x="-1.27" y="-2.54" radius="0.898" width="0.127" layer="21"/>
<circle x="-1.27" y="-5.08" radius="0.898" width="0.127" layer="21"/>
<circle x="1.27" y="-5.08" radius="0.898" width="0.127" layer="21"/>
<circle x="3.81" y="-2.54" radius="0.898" width="0.127" layer="21"/>
<circle x="0" y="0" radius="8.4433" width="0.127" layer="21"/>
<pad name="K8" x="-1.27" y="5.08" drill="0.8128" diameter="1.397" shape="octagon"/>
<pad name="K1" x="1.27" y="5.08" drill="0.8128" diameter="1.397" shape="octagon"/>
<pad name="K9" x="-1.27" y="2.54" drill="0.8128" diameter="1.397" shape="octagon"/>
<pad name="K0" x="-1.27" y="0" drill="0.8128" diameter="1.397" shape="octagon"/>
<pad name="K7" x="-1.27" y="-2.54" drill="0.8128" diameter="1.397" shape="octagon"/>
<pad name="K6" x="-1.27" y="-5.08" drill="0.8128" diameter="1.397" shape="octagon"/>
<pad name="K2" x="1.27" y="2.54" drill="0.8128" diameter="1.397" shape="octagon"/>
<pad name="K3" x="1.27" y="0" drill="0.8128" diameter="1.397" shape="octagon"/>
<pad name="K4" x="1.27" y="-2.54" drill="0.8128" diameter="1.397" shape="octagon"/>
<pad name="K5" x="1.27" y="-5.08" drill="0.8128" diameter="1.397" shape="octagon"/>
<pad name="&quot;IV&quot;" x="3.81" y="2.54" drill="0.8128" diameter="1.397" shape="octagon"/>
<pad name="V" x="3.81" y="0" drill="0.8128" diameter="1.397" shape="octagon"/>
<pad name="A2" x="3.81" y="-2.54" drill="0.8128" diameter="1.397" shape="octagon"/>
<pad name="IV" x="-3.81" y="2.54" drill="0.8128" diameter="1.397" shape="octagon"/>
<pad name="KDP" x="-3.81" y="0" drill="0.8128" diameter="1.397" shape="octagon"/>
<pad name="A1" x="-3.81" y="-2.54" drill="0.8128" diameter="1.397" shape="octagon"/>
<text x="-4.016" y="-11.971" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.016" y="-14.175" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-1.524" y="6.096" size="0.6096" layer="21">8</text>
<text x="1.143" y="6.096" size="0.6096" layer="21">1</text>
<text x="-1.524" y="3.556" size="0.6096" layer="21">9</text>
<text x="1.016" y="3.556" size="0.6096" layer="21">2</text>
<text x="-4.318" y="1.016" size="0.6096" layer="21">DP</text>
<text x="-1.524" y="1.016" size="0.6096" layer="21">0</text>
<text x="1.016" y="1.016" size="0.6096" layer="21">3</text>
<text x="3.556" y="1.016" size="0.6096" layer="21">V</text>
<text x="-4.318" y="-1.524" size="0.6096" layer="21">A1</text>
<text x="-1.524" y="-1.524" size="0.6096" layer="21">7</text>
<text x="1.016" y="-1.524" size="0.6096" layer="21">4</text>
<text x="3.302" y="-1.524" size="0.6096" layer="21">A2</text>
<text x="-1.524" y="-4.064" size="0.6096" layer="21">6</text>
<text x="1.016" y="-4.064" size="0.6096" layer="21">5</text>
<text x="-4.318" y="3.556" size="0.6096" layer="21">NC</text>
<text x="3.302" y="3.556" size="0.6096" layer="21">NC</text>
</package>
<package name="MSTBV9">
<wire x1="-20.955" y1="0.635" x2="-20.955" y2="-0.635" width="0.127" layer="51"/>
<wire x1="-20.955" y1="-0.635" x2="-19.685" y2="-0.635" width="0.127" layer="51"/>
<wire x1="-19.685" y1="-0.635" x2="-19.685" y2="0.635" width="0.127" layer="51"/>
<wire x1="-19.685" y1="0.635" x2="-20.955" y2="0.635" width="0.127" layer="51"/>
<wire x1="-20.955" y1="0.635" x2="-19.685" y2="-0.635" width="0.127" layer="51"/>
<wire x1="-20.955" y1="-0.635" x2="-19.685" y2="0.635" width="0.127" layer="51"/>
<wire x1="-23.495" y1="4.572" x2="-23.495" y2="4.064" width="0.127" layer="21"/>
<wire x1="-23.495" y1="4.064" x2="-23.495" y2="-3.81" width="0.127" layer="21"/>
<wire x1="-22.86" y1="-2.54" x2="-22.86" y2="2.794" width="0.127" layer="21"/>
<wire x1="-22.86" y1="2.794" x2="-22.86" y2="3.048" width="0.127" layer="21"/>
<wire x1="-10.795" y1="0.635" x2="-10.795" y2="-0.635" width="0.127" layer="51"/>
<wire x1="-10.795" y1="-0.635" x2="-9.525" y2="-0.635" width="0.127" layer="51"/>
<wire x1="-9.525" y1="-0.635" x2="-9.525" y2="0.635" width="0.127" layer="51"/>
<wire x1="-9.525" y1="0.635" x2="-10.795" y2="0.635" width="0.127" layer="51"/>
<wire x1="-10.795" y1="0.635" x2="-9.525" y2="-0.635" width="0.127" layer="51"/>
<wire x1="-10.795" y1="-0.635" x2="-9.525" y2="0.635" width="0.127" layer="51"/>
<wire x1="-22.4536" y1="-2.4892" x2="-20.32" y2="-3.556" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="-20.32" y1="-3.556" x2="-18.1864" y2="-2.4892" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="-18.161" y1="-2.54" x2="-17.399" y2="-2.54" width="0.127" layer="21"/>
<wire x1="-22.86" y1="-2.54" x2="-22.4282" y2="-2.54" width="0.127" layer="21"/>
<wire x1="-12.2936" y1="-2.4892" x2="-10.16" y2="-3.556" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="-5.08" y1="-3.556" x2="-2.9464" y2="-2.4892" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="-22.86" y1="2.794" x2="-20.828" y2="2.794" width="0.127" layer="21"/>
<wire x1="-20.828" y1="2.794" x2="-19.812" y2="2.794" width="0.127" layer="21"/>
<wire x1="-19.812" y1="2.794" x2="-15.748" y2="2.794" width="0.127" layer="21"/>
<wire x1="-15.748" y1="2.794" x2="-14.732" y2="2.794" width="0.127" layer="21"/>
<wire x1="-14.732" y1="2.794" x2="-10.668" y2="2.794" width="0.127" layer="21"/>
<wire x1="-10.668" y1="2.794" x2="-9.652" y2="2.794" width="0.127" layer="21"/>
<wire x1="-9.652" y1="2.794" x2="-5.588" y2="2.794" width="0.127" layer="21"/>
<wire x1="-5.588" y1="2.794" x2="-4.572" y2="2.794" width="0.127" layer="21"/>
<wire x1="-23.495" y1="4.572" x2="-20.828" y2="4.572" width="0.127" layer="21"/>
<wire x1="-20.828" y1="4.572" x2="-19.812" y2="4.572" width="0.127" layer="21"/>
<wire x1="-19.812" y1="4.572" x2="-15.748" y2="4.572" width="0.127" layer="21"/>
<wire x1="-15.748" y1="4.572" x2="-14.732" y2="4.572" width="0.127" layer="21"/>
<wire x1="-14.732" y1="4.572" x2="-10.668" y2="4.572" width="0.127" layer="21"/>
<wire x1="-10.668" y1="4.572" x2="-9.652" y2="4.572" width="0.127" layer="21"/>
<wire x1="-9.652" y1="4.572" x2="-5.588" y2="4.572" width="0.127" layer="21"/>
<wire x1="-5.588" y1="4.572" x2="-4.572" y2="4.572" width="0.127" layer="21"/>
<wire x1="-10.668" y1="2.794" x2="-10.668" y2="4.572" width="0.127" layer="21"/>
<wire x1="-9.652" y1="2.794" x2="-9.652" y2="4.572" width="0.127" layer="21"/>
<wire x1="-23.495" y1="4.064" x2="-21.082" y2="4.064" width="0.127" layer="21"/>
<wire x1="-19.558" y1="4.064" x2="-16.002" y2="4.064" width="0.127" layer="21"/>
<wire x1="-14.478" y1="4.064" x2="-10.922" y2="4.064" width="0.127" layer="21"/>
<wire x1="-10.922" y1="4.064" x2="-10.668" y2="4.572" width="0.127" layer="21"/>
<wire x1="-10.922" y1="4.064" x2="-10.922" y2="3.048" width="0.127" layer="21"/>
<wire x1="-10.922" y1="3.048" x2="-10.668" y2="2.794" width="0.127" layer="21"/>
<wire x1="-10.922" y1="3.048" x2="-14.478" y2="3.048" width="0.127" layer="21"/>
<wire x1="-16.002" y1="3.048" x2="-19.558" y2="3.048" width="0.127" layer="21"/>
<wire x1="-21.082" y1="3.048" x2="-22.86" y2="3.048" width="0.127" layer="21"/>
<wire x1="-9.652" y1="4.572" x2="-9.398" y2="4.064" width="0.127" layer="21"/>
<wire x1="-9.398" y1="4.064" x2="-5.842" y2="4.064" width="0.127" layer="21"/>
<wire x1="-9.398" y1="4.064" x2="-9.398" y2="3.048" width="0.127" layer="21"/>
<wire x1="-9.398" y1="3.048" x2="-9.652" y2="2.794" width="0.127" layer="21"/>
<wire x1="-9.398" y1="3.048" x2="-5.842" y2="3.048" width="0.127" layer="21"/>
<wire x1="-19.812" y1="2.794" x2="-19.812" y2="4.572" width="0.127" layer="21"/>
<wire x1="-20.828" y1="2.794" x2="-20.828" y2="4.572" width="0.127" layer="21"/>
<wire x1="-21.082" y1="4.064" x2="-21.082" y2="3.048" width="0.127" layer="21"/>
<wire x1="-19.558" y1="4.064" x2="-19.558" y2="3.048" width="0.127" layer="21"/>
<wire x1="-19.812" y1="4.572" x2="-19.558" y2="4.064" width="0.127" layer="21"/>
<wire x1="-21.082" y1="4.064" x2="-20.828" y2="4.572" width="0.127" layer="21"/>
<wire x1="-21.082" y1="3.048" x2="-20.828" y2="2.794" width="0.127" layer="21"/>
<wire x1="-19.558" y1="3.048" x2="-19.812" y2="2.794" width="0.127" layer="21"/>
<wire x1="-17.3736" y1="-2.4892" x2="-15.24" y2="-3.556" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="-15.24" y1="-3.556" x2="-13.1064" y2="-2.4892" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="-13.081" y1="-2.54" x2="-12.319" y2="-2.54" width="0.127" layer="21"/>
<wire x1="-15.875" y1="-0.635" x2="-14.605" y2="-0.635" width="0.127" layer="51"/>
<wire x1="-15.875" y1="0.635" x2="-15.875" y2="-0.635" width="0.127" layer="51"/>
<wire x1="-14.605" y1="0.635" x2="-15.875" y2="0.635" width="0.127" layer="51"/>
<wire x1="-14.605" y1="-0.635" x2="-14.605" y2="0.635" width="0.127" layer="51"/>
<wire x1="-15.875" y1="-0.635" x2="-14.605" y2="0.635" width="0.127" layer="51"/>
<wire x1="-15.875" y1="0.635" x2="-14.605" y2="-0.635" width="0.127" layer="51"/>
<wire x1="-15.748" y1="2.794" x2="-15.748" y2="4.572" width="0.127" layer="21"/>
<wire x1="-14.732" y1="2.794" x2="-14.732" y2="4.572" width="0.127" layer="21"/>
<wire x1="-14.478" y1="4.064" x2="-14.478" y2="3.048" width="0.127" layer="21"/>
<wire x1="-14.732" y1="4.572" x2="-14.478" y2="4.064" width="0.127" layer="21"/>
<wire x1="-14.478" y1="3.048" x2="-14.732" y2="2.794" width="0.127" layer="21"/>
<wire x1="-16.002" y1="4.064" x2="-15.748" y2="4.572" width="0.127" layer="21"/>
<wire x1="-16.002" y1="4.064" x2="-16.002" y2="3.048" width="0.127" layer="21"/>
<wire x1="-16.002" y1="3.048" x2="-15.748" y2="2.794" width="0.127" layer="21"/>
<wire x1="-4.445" y1="-0.635" x2="-4.445" y2="0.635" width="0.127" layer="51"/>
<wire x1="-4.445" y1="0.635" x2="-5.715" y2="0.635" width="0.127" layer="51"/>
<wire x1="-5.715" y1="0.635" x2="-5.715" y2="-0.635" width="0.127" layer="51"/>
<wire x1="-5.715" y1="0.635" x2="-4.445" y2="-0.635" width="0.127" layer="51"/>
<wire x1="-5.715" y1="-0.635" x2="-4.445" y2="0.635" width="0.127" layer="51"/>
<wire x1="-5.715" y1="-0.635" x2="-4.445" y2="-0.635" width="0.127" layer="51"/>
<wire x1="-7.2136" y1="-2.4892" x2="-5.08" y2="-3.556" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="-10.16" y1="-3.556" x2="-8.0264" y2="-2.4892" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="-8.001" y1="-2.54" x2="-7.239" y2="-2.54" width="0.127" layer="21"/>
<wire x1="-4.572" y1="2.794" x2="-4.572" y2="4.572" width="0.127" layer="21"/>
<wire x1="-4.318" y1="4.064" x2="-4.318" y2="3.048" width="0.127" layer="21"/>
<wire x1="-4.572" y1="4.572" x2="-4.318" y2="4.064" width="0.127" layer="21"/>
<wire x1="-4.318" y1="3.048" x2="-4.572" y2="2.794" width="0.127" layer="21"/>
<wire x1="-5.588" y1="2.794" x2="-5.588" y2="4.572" width="0.127" layer="21"/>
<wire x1="-5.842" y1="4.064" x2="-5.842" y2="3.048" width="0.127" layer="21"/>
<wire x1="-5.842" y1="4.064" x2="-5.588" y2="4.572" width="0.127" layer="21"/>
<wire x1="-5.842" y1="3.048" x2="-5.588" y2="2.794" width="0.127" layer="21"/>
<wire x1="-0.635" y1="0.635" x2="-0.635" y2="-0.635" width="0.127" layer="51"/>
<wire x1="-0.635" y1="-0.635" x2="0.635" y2="-0.635" width="0.127" layer="51"/>
<wire x1="0.635" y1="-0.635" x2="0.635" y2="0.635" width="0.127" layer="51"/>
<wire x1="0.635" y1="0.635" x2="-0.635" y2="0.635" width="0.127" layer="51"/>
<wire x1="-0.635" y1="0.635" x2="0.635" y2="-0.635" width="0.127" layer="51"/>
<wire x1="-0.635" y1="-0.635" x2="0.635" y2="0.635" width="0.127" layer="51"/>
<wire x1="-23.495" y1="-3.81" x2="23.495" y2="-3.81" width="0.127" layer="21"/>
<wire x1="23.495" y1="-3.81" x2="23.495" y2="4.064" width="0.127" layer="21"/>
<wire x1="23.495" y1="4.064" x2="23.495" y2="4.572" width="0.127" layer="21"/>
<wire x1="22.86" y1="3.048" x2="22.86" y2="2.794" width="0.127" layer="21"/>
<wire x1="22.86" y1="2.794" x2="22.86" y2="-2.54" width="0.127" layer="21"/>
<wire x1="9.525" y1="0.635" x2="9.525" y2="-0.635" width="0.127" layer="51"/>
<wire x1="9.525" y1="-0.635" x2="10.795" y2="-0.635" width="0.127" layer="51"/>
<wire x1="10.795" y1="-0.635" x2="10.795" y2="0.635" width="0.127" layer="51"/>
<wire x1="10.795" y1="0.635" x2="9.525" y2="0.635" width="0.127" layer="51"/>
<wire x1="9.525" y1="0.635" x2="10.795" y2="-0.635" width="0.127" layer="51"/>
<wire x1="9.525" y1="-0.635" x2="10.795" y2="0.635" width="0.127" layer="51"/>
<wire x1="-2.1336" y1="-2.4892" x2="0" y2="-3.556" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="0" y1="-3.556" x2="2.1336" y2="-2.4892" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="2.159" y1="-2.54" x2="2.921" y2="-2.54" width="0.127" layer="21"/>
<wire x1="-2.9718" y1="-2.54" x2="-2.1082" y2="-2.54" width="0.127" layer="21"/>
<wire x1="8.0264" y1="-2.4892" x2="10.16" y2="-3.556" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="20.32" y1="-3.556" x2="22.4536" y2="-2.4892" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="22.4282" y1="-2.54" x2="22.86" y2="-2.54" width="0.127" layer="21"/>
<wire x1="-4.572" y1="2.794" x2="-0.508" y2="2.794" width="0.127" layer="21"/>
<wire x1="-0.508" y1="2.794" x2="0.508" y2="2.794" width="0.127" layer="21"/>
<wire x1="0.508" y1="2.794" x2="4.572" y2="2.794" width="0.127" layer="21"/>
<wire x1="4.572" y1="2.794" x2="5.588" y2="2.794" width="0.127" layer="21"/>
<wire x1="5.588" y1="2.794" x2="9.652" y2="2.794" width="0.127" layer="21"/>
<wire x1="9.652" y1="2.794" x2="10.668" y2="2.794" width="0.127" layer="21"/>
<wire x1="10.668" y1="2.794" x2="14.732" y2="2.794" width="0.127" layer="21"/>
<wire x1="14.732" y1="2.794" x2="15.748" y2="2.794" width="0.127" layer="21"/>
<wire x1="15.748" y1="2.794" x2="19.812" y2="2.794" width="0.127" layer="21"/>
<wire x1="19.812" y1="2.794" x2="20.828" y2="2.794" width="0.127" layer="21"/>
<wire x1="20.828" y1="2.794" x2="22.86" y2="2.794" width="0.127" layer="21"/>
<wire x1="-4.572" y1="4.572" x2="-0.508" y2="4.572" width="0.127" layer="21"/>
<wire x1="-0.508" y1="4.572" x2="0.508" y2="4.572" width="0.127" layer="21"/>
<wire x1="0.508" y1="4.572" x2="4.572" y2="4.572" width="0.127" layer="21"/>
<wire x1="4.572" y1="4.572" x2="5.588" y2="4.572" width="0.127" layer="21"/>
<wire x1="5.588" y1="4.572" x2="9.652" y2="4.572" width="0.127" layer="21"/>
<wire x1="9.652" y1="4.572" x2="10.668" y2="4.572" width="0.127" layer="21"/>
<wire x1="10.668" y1="4.572" x2="14.732" y2="4.572" width="0.127" layer="21"/>
<wire x1="14.732" y1="4.572" x2="15.748" y2="4.572" width="0.127" layer="21"/>
<wire x1="15.748" y1="4.572" x2="19.812" y2="4.572" width="0.127" layer="21"/>
<wire x1="19.812" y1="4.572" x2="20.828" y2="4.572" width="0.127" layer="21"/>
<wire x1="20.828" y1="4.572" x2="23.495" y2="4.572" width="0.127" layer="21"/>
<wire x1="9.652" y1="2.794" x2="9.652" y2="4.572" width="0.127" layer="21"/>
<wire x1="10.668" y1="2.794" x2="10.668" y2="4.572" width="0.127" layer="21"/>
<wire x1="-4.318" y1="4.064" x2="-0.762" y2="4.064" width="0.127" layer="21"/>
<wire x1="0.762" y1="4.064" x2="4.318" y2="4.064" width="0.127" layer="21"/>
<wire x1="5.842" y1="4.064" x2="9.398" y2="4.064" width="0.127" layer="21"/>
<wire x1="9.398" y1="4.064" x2="9.652" y2="4.572" width="0.127" layer="21"/>
<wire x1="9.398" y1="4.064" x2="9.398" y2="3.048" width="0.127" layer="21"/>
<wire x1="9.398" y1="3.048" x2="9.652" y2="2.794" width="0.127" layer="21"/>
<wire x1="9.398" y1="3.048" x2="5.842" y2="3.048" width="0.127" layer="21"/>
<wire x1="4.318" y1="3.048" x2="0.762" y2="3.048" width="0.127" layer="21"/>
<wire x1="-0.762" y1="3.048" x2="-4.318" y2="3.048" width="0.127" layer="21"/>
<wire x1="10.668" y1="4.572" x2="10.922" y2="4.064" width="0.127" layer="21"/>
<wire x1="10.922" y1="4.064" x2="14.478" y2="4.064" width="0.127" layer="21"/>
<wire x1="16.002" y1="4.064" x2="19.558" y2="4.064" width="0.127" layer="21"/>
<wire x1="21.082" y1="4.064" x2="23.495" y2="4.064" width="0.127" layer="21"/>
<wire x1="10.922" y1="4.064" x2="10.922" y2="3.048" width="0.127" layer="21"/>
<wire x1="10.922" y1="3.048" x2="10.668" y2="2.794" width="0.127" layer="21"/>
<wire x1="10.922" y1="3.048" x2="14.478" y2="3.048" width="0.127" layer="21"/>
<wire x1="16.002" y1="3.048" x2="19.558" y2="3.048" width="0.127" layer="21"/>
<wire x1="21.082" y1="3.048" x2="22.86" y2="3.048" width="0.127" layer="21"/>
<wire x1="0.508" y1="2.794" x2="0.508" y2="4.572" width="0.127" layer="21"/>
<wire x1="-0.508" y1="2.794" x2="-0.508" y2="4.572" width="0.127" layer="21"/>
<wire x1="-0.762" y1="4.064" x2="-0.762" y2="3.048" width="0.127" layer="21"/>
<wire x1="0.762" y1="4.064" x2="0.762" y2="3.048" width="0.127" layer="21"/>
<wire x1="0.508" y1="4.572" x2="0.762" y2="4.064" width="0.127" layer="21"/>
<wire x1="-0.762" y1="4.064" x2="-0.508" y2="4.572" width="0.127" layer="21"/>
<wire x1="-0.762" y1="3.048" x2="-0.508" y2="2.794" width="0.127" layer="21"/>
<wire x1="0.762" y1="3.048" x2="0.508" y2="2.794" width="0.127" layer="21"/>
<wire x1="2.9464" y1="-2.4892" x2="5.08" y2="-3.556" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="5.08" y1="-3.556" x2="7.2136" y2="-2.4892" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="7.239" y1="-2.54" x2="8.001" y2="-2.54" width="0.127" layer="21"/>
<wire x1="4.445" y1="-0.635" x2="5.715" y2="-0.635" width="0.127" layer="51"/>
<wire x1="4.445" y1="0.635" x2="4.445" y2="-0.635" width="0.127" layer="51"/>
<wire x1="5.715" y1="0.635" x2="4.445" y2="0.635" width="0.127" layer="51"/>
<wire x1="5.715" y1="-0.635" x2="5.715" y2="0.635" width="0.127" layer="51"/>
<wire x1="4.445" y1="-0.635" x2="5.715" y2="0.635" width="0.127" layer="51"/>
<wire x1="4.445" y1="0.635" x2="5.715" y2="-0.635" width="0.127" layer="51"/>
<wire x1="4.572" y1="2.794" x2="4.572" y2="4.572" width="0.127" layer="21"/>
<wire x1="5.588" y1="2.794" x2="5.588" y2="4.572" width="0.127" layer="21"/>
<wire x1="5.842" y1="4.064" x2="5.842" y2="3.048" width="0.127" layer="21"/>
<wire x1="5.588" y1="4.572" x2="5.842" y2="4.064" width="0.127" layer="21"/>
<wire x1="5.842" y1="3.048" x2="5.588" y2="2.794" width="0.127" layer="21"/>
<wire x1="4.318" y1="4.064" x2="4.572" y2="4.572" width="0.127" layer="21"/>
<wire x1="4.318" y1="4.064" x2="4.318" y2="3.048" width="0.127" layer="21"/>
<wire x1="4.318" y1="3.048" x2="4.572" y2="2.794" width="0.127" layer="21"/>
<wire x1="15.875" y1="-0.635" x2="15.875" y2="0.635" width="0.127" layer="51"/>
<wire x1="15.875" y1="0.635" x2="14.605" y2="0.635" width="0.127" layer="51"/>
<wire x1="14.605" y1="0.635" x2="14.605" y2="-0.635" width="0.127" layer="51"/>
<wire x1="14.605" y1="0.635" x2="15.875" y2="-0.635" width="0.127" layer="51"/>
<wire x1="14.605" y1="-0.635" x2="15.875" y2="0.635" width="0.127" layer="51"/>
<wire x1="14.605" y1="-0.635" x2="15.875" y2="-0.635" width="0.127" layer="51"/>
<wire x1="13.1064" y1="-2.4892" x2="15.24" y2="-3.556" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="10.16" y1="-3.556" x2="12.2936" y2="-2.4892" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="12.319" y1="-2.54" x2="13.081" y2="-2.54" width="0.127" layer="21"/>
<wire x1="15.748" y1="2.794" x2="15.748" y2="4.572" width="0.127" layer="21"/>
<wire x1="16.002" y1="4.064" x2="16.002" y2="3.048" width="0.127" layer="21"/>
<wire x1="15.748" y1="4.572" x2="16.002" y2="4.064" width="0.127" layer="21"/>
<wire x1="16.002" y1="3.048" x2="15.748" y2="2.794" width="0.127" layer="21"/>
<wire x1="14.732" y1="2.794" x2="14.732" y2="4.572" width="0.127" layer="21"/>
<wire x1="14.478" y1="4.064" x2="14.478" y2="3.048" width="0.127" layer="21"/>
<wire x1="14.478" y1="4.064" x2="14.732" y2="4.572" width="0.127" layer="21"/>
<wire x1="14.478" y1="3.048" x2="14.732" y2="2.794" width="0.127" layer="21"/>
<wire x1="18.1864" y1="-2.4892" x2="20.32" y2="-3.556" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="15.24" y1="-3.556" x2="17.3736" y2="-2.4892" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="17.399" y1="-2.54" x2="18.161" y2="-2.54" width="0.127" layer="21"/>
<wire x1="20.828" y1="2.794" x2="20.828" y2="4.572" width="0.127" layer="21"/>
<wire x1="21.082" y1="4.064" x2="21.082" y2="3.048" width="0.127" layer="21"/>
<wire x1="20.828" y1="4.572" x2="21.082" y2="4.064" width="0.127" layer="21"/>
<wire x1="21.082" y1="3.048" x2="20.828" y2="2.794" width="0.127" layer="21"/>
<wire x1="19.812" y1="2.794" x2="19.812" y2="4.572" width="0.127" layer="21"/>
<wire x1="19.558" y1="4.064" x2="19.812" y2="4.572" width="0.127" layer="21"/>
<wire x1="19.558" y1="4.064" x2="19.558" y2="3.048" width="0.127" layer="21"/>
<wire x1="19.558" y1="3.048" x2="19.812" y2="2.794" width="0.127" layer="21"/>
<wire x1="20.955" y1="0.635" x2="19.685" y2="0.635" width="0.127" layer="51"/>
<wire x1="20.955" y1="-0.635" x2="20.955" y2="0.635" width="0.127" layer="51"/>
<wire x1="19.685" y1="0.635" x2="19.685" y2="-0.635" width="0.127" layer="51"/>
<wire x1="19.685" y1="-0.635" x2="20.955" y2="-0.635" width="0.127" layer="51"/>
<wire x1="19.685" y1="0.635" x2="20.955" y2="-0.635" width="0.127" layer="51"/>
<wire x1="19.685" y1="-0.635" x2="20.955" y2="0.635" width="0.127" layer="51"/>
<pad name="1" x="-20.32" y="0" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="2" x="-15.24" y="0" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="3" x="-10.16" y="0" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="4" x="-5.08" y="0" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="5" x="0" y="0" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="6" x="5.08" y="0" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="7" x="10.16" y="0" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="8" x="15.24" y="0" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="9" x="20.32" y="0" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<text x="-22.479" y="-2.159" size="1.27" layer="21" ratio="10">1</text>
<text x="-23.622" y="7.747" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-23.622" y="5.334" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-17.78" y="-2.159" size="1.27" layer="21" ratio="10">2</text>
<text x="-12.7" y="-2.159" size="1.27" layer="21" ratio="10">3</text>
<text x="-7.62" y="-2.159" size="1.27" layer="21" ratio="10">4</text>
<text x="-2.159" y="-2.159" size="1.27" layer="21" ratio="10">5</text>
<text x="2.54" y="-2.159" size="1.27" layer="21" ratio="10">6</text>
<text x="7.62" y="-2.159" size="1.27" layer="21" ratio="10">7</text>
<text x="12.7" y="-2.159" size="1.27" layer="21" ratio="10">8</text>
<text x="17.78" y="-2.159" size="1.27" layer="21" ratio="10">9</text>
</package>
<package name="MSTBV8">
<wire x1="-18.415" y1="0.635" x2="-18.415" y2="-0.635" width="0.127" layer="51"/>
<wire x1="-18.415" y1="-0.635" x2="-17.145" y2="-0.635" width="0.127" layer="51"/>
<wire x1="-17.145" y1="-0.635" x2="-17.145" y2="0.635" width="0.127" layer="51"/>
<wire x1="-17.145" y1="0.635" x2="-18.415" y2="0.635" width="0.127" layer="51"/>
<wire x1="-18.415" y1="0.635" x2="-17.145" y2="-0.635" width="0.127" layer="51"/>
<wire x1="-18.415" y1="-0.635" x2="-17.145" y2="0.635" width="0.127" layer="51"/>
<wire x1="-20.955" y1="4.572" x2="-20.955" y2="4.064" width="0.127" layer="21"/>
<wire x1="-20.955" y1="4.064" x2="-20.955" y2="-3.81" width="0.127" layer="21"/>
<wire x1="-20.32" y1="-2.54" x2="-20.32" y2="2.794" width="0.127" layer="21"/>
<wire x1="-20.32" y1="2.794" x2="-20.32" y2="3.048" width="0.127" layer="21"/>
<wire x1="-8.255" y1="0.635" x2="-8.255" y2="-0.635" width="0.127" layer="51"/>
<wire x1="-8.255" y1="-0.635" x2="-6.985" y2="-0.635" width="0.127" layer="51"/>
<wire x1="-6.985" y1="-0.635" x2="-6.985" y2="0.635" width="0.127" layer="51"/>
<wire x1="-6.985" y1="0.635" x2="-8.255" y2="0.635" width="0.127" layer="51"/>
<wire x1="-8.255" y1="0.635" x2="-6.985" y2="-0.635" width="0.127" layer="51"/>
<wire x1="-8.255" y1="-0.635" x2="-6.985" y2="0.635" width="0.127" layer="51"/>
<wire x1="-19.9136" y1="-2.4892" x2="-17.78" y2="-3.556" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="-17.78" y1="-3.556" x2="-15.6464" y2="-2.4892" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="-15.621" y1="-2.54" x2="-14.859" y2="-2.54" width="0.127" layer="21"/>
<wire x1="-20.32" y1="-2.54" x2="-19.8882" y2="-2.54" width="0.127" layer="21"/>
<wire x1="-9.7536" y1="-2.4892" x2="-7.62" y2="-3.556" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="-2.54" y1="-3.556" x2="-0.4064" y2="-2.4892" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="-20.32" y1="2.794" x2="-18.288" y2="2.794" width="0.127" layer="21"/>
<wire x1="-18.288" y1="2.794" x2="-17.272" y2="2.794" width="0.127" layer="21"/>
<wire x1="-17.272" y1="2.794" x2="-13.208" y2="2.794" width="0.127" layer="21"/>
<wire x1="-13.208" y1="2.794" x2="-12.192" y2="2.794" width="0.127" layer="21"/>
<wire x1="-12.192" y1="2.794" x2="-8.128" y2="2.794" width="0.127" layer="21"/>
<wire x1="-8.128" y1="2.794" x2="-7.112" y2="2.794" width="0.127" layer="21"/>
<wire x1="-7.112" y1="2.794" x2="-3.048" y2="2.794" width="0.127" layer="21"/>
<wire x1="-3.048" y1="2.794" x2="-2.032" y2="2.794" width="0.127" layer="21"/>
<wire x1="-20.955" y1="4.572" x2="-18.288" y2="4.572" width="0.127" layer="21"/>
<wire x1="-18.288" y1="4.572" x2="-17.272" y2="4.572" width="0.127" layer="21"/>
<wire x1="-17.272" y1="4.572" x2="-13.208" y2="4.572" width="0.127" layer="21"/>
<wire x1="-13.208" y1="4.572" x2="-12.192" y2="4.572" width="0.127" layer="21"/>
<wire x1="-12.192" y1="4.572" x2="-8.128" y2="4.572" width="0.127" layer="21"/>
<wire x1="-8.128" y1="4.572" x2="-7.112" y2="4.572" width="0.127" layer="21"/>
<wire x1="-7.112" y1="4.572" x2="-3.048" y2="4.572" width="0.127" layer="21"/>
<wire x1="-3.048" y1="4.572" x2="-2.032" y2="4.572" width="0.127" layer="21"/>
<wire x1="-8.128" y1="2.794" x2="-8.128" y2="4.572" width="0.127" layer="21"/>
<wire x1="-7.112" y1="2.794" x2="-7.112" y2="4.572" width="0.127" layer="21"/>
<wire x1="-20.955" y1="4.064" x2="-18.542" y2="4.064" width="0.127" layer="21"/>
<wire x1="-17.018" y1="4.064" x2="-13.462" y2="4.064" width="0.127" layer="21"/>
<wire x1="-11.938" y1="4.064" x2="-8.382" y2="4.064" width="0.127" layer="21"/>
<wire x1="-8.382" y1="4.064" x2="-8.128" y2="4.572" width="0.127" layer="21"/>
<wire x1="-8.382" y1="4.064" x2="-8.382" y2="3.048" width="0.127" layer="21"/>
<wire x1="-8.382" y1="3.048" x2="-8.128" y2="2.794" width="0.127" layer="21"/>
<wire x1="-8.382" y1="3.048" x2="-11.938" y2="3.048" width="0.127" layer="21"/>
<wire x1="-13.462" y1="3.048" x2="-17.018" y2="3.048" width="0.127" layer="21"/>
<wire x1="-18.542" y1="3.048" x2="-20.32" y2="3.048" width="0.127" layer="21"/>
<wire x1="-7.112" y1="4.572" x2="-6.858" y2="4.064" width="0.127" layer="21"/>
<wire x1="-6.858" y1="4.064" x2="-3.302" y2="4.064" width="0.127" layer="21"/>
<wire x1="-6.858" y1="4.064" x2="-6.858" y2="3.048" width="0.127" layer="21"/>
<wire x1="-6.858" y1="3.048" x2="-7.112" y2="2.794" width="0.127" layer="21"/>
<wire x1="-6.858" y1="3.048" x2="-3.302" y2="3.048" width="0.127" layer="21"/>
<wire x1="-17.272" y1="2.794" x2="-17.272" y2="4.572" width="0.127" layer="21"/>
<wire x1="-18.288" y1="2.794" x2="-18.288" y2="4.572" width="0.127" layer="21"/>
<wire x1="-18.542" y1="4.064" x2="-18.542" y2="3.048" width="0.127" layer="21"/>
<wire x1="-17.018" y1="4.064" x2="-17.018" y2="3.048" width="0.127" layer="21"/>
<wire x1="-17.272" y1="4.572" x2="-17.018" y2="4.064" width="0.127" layer="21"/>
<wire x1="-18.542" y1="4.064" x2="-18.288" y2="4.572" width="0.127" layer="21"/>
<wire x1="-18.542" y1="3.048" x2="-18.288" y2="2.794" width="0.127" layer="21"/>
<wire x1="-17.018" y1="3.048" x2="-17.272" y2="2.794" width="0.127" layer="21"/>
<wire x1="-14.8336" y1="-2.4892" x2="-12.7" y2="-3.556" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="-12.7" y1="-3.556" x2="-10.5664" y2="-2.4892" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="-10.541" y1="-2.54" x2="-9.779" y2="-2.54" width="0.127" layer="21"/>
<wire x1="-13.335" y1="-0.635" x2="-12.065" y2="-0.635" width="0.127" layer="51"/>
<wire x1="-13.335" y1="0.635" x2="-13.335" y2="-0.635" width="0.127" layer="51"/>
<wire x1="-12.065" y1="0.635" x2="-13.335" y2="0.635" width="0.127" layer="51"/>
<wire x1="-12.065" y1="-0.635" x2="-12.065" y2="0.635" width="0.127" layer="51"/>
<wire x1="-13.335" y1="-0.635" x2="-12.065" y2="0.635" width="0.127" layer="51"/>
<wire x1="-13.335" y1="0.635" x2="-12.065" y2="-0.635" width="0.127" layer="51"/>
<wire x1="-13.208" y1="2.794" x2="-13.208" y2="4.572" width="0.127" layer="21"/>
<wire x1="-12.192" y1="2.794" x2="-12.192" y2="4.572" width="0.127" layer="21"/>
<wire x1="-11.938" y1="4.064" x2="-11.938" y2="3.048" width="0.127" layer="21"/>
<wire x1="-12.192" y1="4.572" x2="-11.938" y2="4.064" width="0.127" layer="21"/>
<wire x1="-11.938" y1="3.048" x2="-12.192" y2="2.794" width="0.127" layer="21"/>
<wire x1="-13.462" y1="4.064" x2="-13.208" y2="4.572" width="0.127" layer="21"/>
<wire x1="-13.462" y1="4.064" x2="-13.462" y2="3.048" width="0.127" layer="21"/>
<wire x1="-13.462" y1="3.048" x2="-13.208" y2="2.794" width="0.127" layer="21"/>
<wire x1="-1.905" y1="-0.635" x2="-1.905" y2="0.635" width="0.127" layer="51"/>
<wire x1="-1.905" y1="0.635" x2="-3.175" y2="0.635" width="0.127" layer="51"/>
<wire x1="-3.175" y1="0.635" x2="-3.175" y2="-0.635" width="0.127" layer="51"/>
<wire x1="-3.175" y1="0.635" x2="-1.905" y2="-0.635" width="0.127" layer="51"/>
<wire x1="-3.175" y1="-0.635" x2="-1.905" y2="0.635" width="0.127" layer="51"/>
<wire x1="-3.175" y1="-0.635" x2="-1.905" y2="-0.635" width="0.127" layer="51"/>
<wire x1="-4.6736" y1="-2.4892" x2="-2.54" y2="-3.556" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="-7.62" y1="-3.556" x2="-5.4864" y2="-2.4892" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="-5.461" y1="-2.54" x2="-4.699" y2="-2.54" width="0.127" layer="21"/>
<wire x1="-2.032" y1="2.794" x2="-2.032" y2="4.572" width="0.127" layer="21"/>
<wire x1="-1.778" y1="4.064" x2="-1.778" y2="3.048" width="0.127" layer="21"/>
<wire x1="-2.032" y1="4.572" x2="-1.778" y2="4.064" width="0.127" layer="21"/>
<wire x1="-1.778" y1="3.048" x2="-2.032" y2="2.794" width="0.127" layer="21"/>
<wire x1="-3.048" y1="2.794" x2="-3.048" y2="4.572" width="0.127" layer="21"/>
<wire x1="-3.302" y1="4.064" x2="-3.302" y2="3.048" width="0.127" layer="21"/>
<wire x1="-3.302" y1="4.064" x2="-3.048" y2="4.572" width="0.127" layer="21"/>
<wire x1="-3.302" y1="3.048" x2="-3.048" y2="2.794" width="0.127" layer="21"/>
<wire x1="1.905" y1="0.635" x2="1.905" y2="-0.635" width="0.127" layer="51"/>
<wire x1="1.905" y1="-0.635" x2="3.175" y2="-0.635" width="0.127" layer="51"/>
<wire x1="3.175" y1="-0.635" x2="3.175" y2="0.635" width="0.127" layer="51"/>
<wire x1="3.175" y1="0.635" x2="1.905" y2="0.635" width="0.127" layer="51"/>
<wire x1="1.905" y1="0.635" x2="3.175" y2="-0.635" width="0.127" layer="51"/>
<wire x1="1.905" y1="-0.635" x2="3.175" y2="0.635" width="0.127" layer="51"/>
<wire x1="-20.955" y1="-3.81" x2="20.955" y2="-3.81" width="0.127" layer="21"/>
<wire x1="20.955" y1="-3.81" x2="20.955" y2="4.064" width="0.127" layer="21"/>
<wire x1="20.955" y1="4.064" x2="20.955" y2="4.572" width="0.127" layer="21"/>
<wire x1="20.32" y1="3.048" x2="20.32" y2="2.794" width="0.127" layer="21"/>
<wire x1="20.32" y1="2.794" x2="20.32" y2="-2.54" width="0.127" layer="21"/>
<wire x1="12.065" y1="0.635" x2="12.065" y2="-0.635" width="0.127" layer="51"/>
<wire x1="12.065" y1="-0.635" x2="13.335" y2="-0.635" width="0.127" layer="51"/>
<wire x1="13.335" y1="-0.635" x2="13.335" y2="0.635" width="0.127" layer="51"/>
<wire x1="13.335" y1="0.635" x2="12.065" y2="0.635" width="0.127" layer="51"/>
<wire x1="12.065" y1="0.635" x2="13.335" y2="-0.635" width="0.127" layer="51"/>
<wire x1="12.065" y1="-0.635" x2="13.335" y2="0.635" width="0.127" layer="51"/>
<wire x1="0.4064" y1="-2.4892" x2="2.54" y2="-3.556" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="2.54" y1="-3.556" x2="4.6736" y2="-2.4892" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="4.699" y1="-2.54" x2="5.461" y2="-2.54" width="0.127" layer="21"/>
<wire x1="-0.4318" y1="-2.54" x2="0.4318" y2="-2.54" width="0.127" layer="21"/>
<wire x1="10.5664" y1="-2.4892" x2="12.7" y2="-3.556" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="17.78" y1="-3.556" x2="19.9136" y2="-2.4892" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="19.8882" y1="-2.54" x2="20.32" y2="-2.54" width="0.127" layer="21"/>
<wire x1="-2.032" y1="2.794" x2="2.032" y2="2.794" width="0.127" layer="21"/>
<wire x1="2.032" y1="2.794" x2="3.048" y2="2.794" width="0.127" layer="21"/>
<wire x1="3.048" y1="2.794" x2="7.112" y2="2.794" width="0.127" layer="21"/>
<wire x1="7.112" y1="2.794" x2="8.128" y2="2.794" width="0.127" layer="21"/>
<wire x1="8.128" y1="2.794" x2="12.192" y2="2.794" width="0.127" layer="21"/>
<wire x1="12.192" y1="2.794" x2="13.208" y2="2.794" width="0.127" layer="21"/>
<wire x1="13.208" y1="2.794" x2="17.272" y2="2.794" width="0.127" layer="21"/>
<wire x1="17.272" y1="2.794" x2="18.288" y2="2.794" width="0.127" layer="21"/>
<wire x1="18.288" y1="2.794" x2="20.32" y2="2.794" width="0.127" layer="21"/>
<wire x1="-2.032" y1="4.572" x2="2.032" y2="4.572" width="0.127" layer="21"/>
<wire x1="2.032" y1="4.572" x2="3.048" y2="4.572" width="0.127" layer="21"/>
<wire x1="3.048" y1="4.572" x2="7.112" y2="4.572" width="0.127" layer="21"/>
<wire x1="7.112" y1="4.572" x2="8.128" y2="4.572" width="0.127" layer="21"/>
<wire x1="8.128" y1="4.572" x2="12.192" y2="4.572" width="0.127" layer="21"/>
<wire x1="12.192" y1="4.572" x2="13.208" y2="4.572" width="0.127" layer="21"/>
<wire x1="13.208" y1="4.572" x2="17.272" y2="4.572" width="0.127" layer="21"/>
<wire x1="17.272" y1="4.572" x2="18.288" y2="4.572" width="0.127" layer="21"/>
<wire x1="18.288" y1="4.572" x2="20.955" y2="4.572" width="0.127" layer="21"/>
<wire x1="12.192" y1="2.794" x2="12.192" y2="4.572" width="0.127" layer="21"/>
<wire x1="13.208" y1="2.794" x2="13.208" y2="4.572" width="0.127" layer="21"/>
<wire x1="-1.778" y1="4.064" x2="1.778" y2="4.064" width="0.127" layer="21"/>
<wire x1="3.302" y1="4.064" x2="6.858" y2="4.064" width="0.127" layer="21"/>
<wire x1="8.382" y1="4.064" x2="11.938" y2="4.064" width="0.127" layer="21"/>
<wire x1="11.938" y1="4.064" x2="12.192" y2="4.572" width="0.127" layer="21"/>
<wire x1="11.938" y1="4.064" x2="11.938" y2="3.048" width="0.127" layer="21"/>
<wire x1="11.938" y1="3.048" x2="12.192" y2="2.794" width="0.127" layer="21"/>
<wire x1="11.938" y1="3.048" x2="8.382" y2="3.048" width="0.127" layer="21"/>
<wire x1="6.858" y1="3.048" x2="3.302" y2="3.048" width="0.127" layer="21"/>
<wire x1="1.778" y1="3.048" x2="-1.778" y2="3.048" width="0.127" layer="21"/>
<wire x1="13.208" y1="4.572" x2="13.462" y2="4.064" width="0.127" layer="21"/>
<wire x1="13.462" y1="4.064" x2="17.018" y2="4.064" width="0.127" layer="21"/>
<wire x1="18.542" y1="4.064" x2="20.955" y2="4.064" width="0.127" layer="21"/>
<wire x1="13.462" y1="4.064" x2="13.462" y2="3.048" width="0.127" layer="21"/>
<wire x1="13.462" y1="3.048" x2="13.208" y2="2.794" width="0.127" layer="21"/>
<wire x1="13.462" y1="3.048" x2="17.018" y2="3.048" width="0.127" layer="21"/>
<wire x1="18.542" y1="3.048" x2="20.32" y2="3.048" width="0.127" layer="21"/>
<wire x1="3.048" y1="2.794" x2="3.048" y2="4.572" width="0.127" layer="21"/>
<wire x1="2.032" y1="2.794" x2="2.032" y2="4.572" width="0.127" layer="21"/>
<wire x1="1.778" y1="4.064" x2="1.778" y2="3.048" width="0.127" layer="21"/>
<wire x1="3.302" y1="4.064" x2="3.302" y2="3.048" width="0.127" layer="21"/>
<wire x1="3.048" y1="4.572" x2="3.302" y2="4.064" width="0.127" layer="21"/>
<wire x1="1.778" y1="4.064" x2="2.032" y2="4.572" width="0.127" layer="21"/>
<wire x1="1.778" y1="3.048" x2="2.032" y2="2.794" width="0.127" layer="21"/>
<wire x1="3.302" y1="3.048" x2="3.048" y2="2.794" width="0.127" layer="21"/>
<wire x1="5.4864" y1="-2.4892" x2="7.62" y2="-3.556" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="7.62" y1="-3.556" x2="9.7536" y2="-2.4892" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="9.779" y1="-2.54" x2="10.541" y2="-2.54" width="0.127" layer="21"/>
<wire x1="6.985" y1="-0.635" x2="8.255" y2="-0.635" width="0.127" layer="51"/>
<wire x1="6.985" y1="0.635" x2="6.985" y2="-0.635" width="0.127" layer="51"/>
<wire x1="8.255" y1="0.635" x2="6.985" y2="0.635" width="0.127" layer="51"/>
<wire x1="8.255" y1="-0.635" x2="8.255" y2="0.635" width="0.127" layer="51"/>
<wire x1="6.985" y1="-0.635" x2="8.255" y2="0.635" width="0.127" layer="51"/>
<wire x1="6.985" y1="0.635" x2="8.255" y2="-0.635" width="0.127" layer="51"/>
<wire x1="7.112" y1="2.794" x2="7.112" y2="4.572" width="0.127" layer="21"/>
<wire x1="8.128" y1="2.794" x2="8.128" y2="4.572" width="0.127" layer="21"/>
<wire x1="8.382" y1="4.064" x2="8.382" y2="3.048" width="0.127" layer="21"/>
<wire x1="8.128" y1="4.572" x2="8.382" y2="4.064" width="0.127" layer="21"/>
<wire x1="8.382" y1="3.048" x2="8.128" y2="2.794" width="0.127" layer="21"/>
<wire x1="6.858" y1="4.064" x2="7.112" y2="4.572" width="0.127" layer="21"/>
<wire x1="6.858" y1="4.064" x2="6.858" y2="3.048" width="0.127" layer="21"/>
<wire x1="6.858" y1="3.048" x2="7.112" y2="2.794" width="0.127" layer="21"/>
<wire x1="18.415" y1="-0.635" x2="18.415" y2="0.635" width="0.127" layer="51"/>
<wire x1="18.415" y1="0.635" x2="17.145" y2="0.635" width="0.127" layer="51"/>
<wire x1="17.145" y1="0.635" x2="17.145" y2="-0.635" width="0.127" layer="51"/>
<wire x1="17.145" y1="0.635" x2="18.415" y2="-0.635" width="0.127" layer="51"/>
<wire x1="17.145" y1="-0.635" x2="18.415" y2="0.635" width="0.127" layer="51"/>
<wire x1="17.145" y1="-0.635" x2="18.415" y2="-0.635" width="0.127" layer="51"/>
<wire x1="15.6464" y1="-2.4892" x2="17.78" y2="-3.556" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="12.7" y1="-3.556" x2="14.8336" y2="-2.4892" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="14.859" y1="-2.54" x2="15.621" y2="-2.54" width="0.127" layer="21"/>
<wire x1="18.288" y1="2.794" x2="18.288" y2="4.572" width="0.127" layer="21"/>
<wire x1="18.542" y1="4.064" x2="18.542" y2="3.048" width="0.127" layer="21"/>
<wire x1="18.288" y1="4.572" x2="18.542" y2="4.064" width="0.127" layer="21"/>
<wire x1="18.542" y1="3.048" x2="18.288" y2="2.794" width="0.127" layer="21"/>
<wire x1="17.272" y1="2.794" x2="17.272" y2="4.572" width="0.127" layer="21"/>
<wire x1="17.018" y1="4.064" x2="17.018" y2="3.048" width="0.127" layer="21"/>
<wire x1="17.018" y1="4.064" x2="17.272" y2="4.572" width="0.127" layer="21"/>
<wire x1="17.018" y1="3.048" x2="17.272" y2="2.794" width="0.127" layer="21"/>
<pad name="1" x="-17.78" y="0" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="2" x="-12.7" y="0" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="3" x="-7.62" y="0" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="4" x="-2.54" y="0" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="5" x="2.54" y="0" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="6" x="7.62" y="0" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="7" x="12.7" y="0" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="8" x="17.78" y="0" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<text x="-19.939" y="-2.159" size="1.27" layer="21" ratio="10">1</text>
<text x="-21.082" y="7.62" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-21.082" y="5.334" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-15.24" y="-2.159" size="1.27" layer="21" ratio="10">2</text>
<text x="-10.16" y="-2.159" size="1.27" layer="21" ratio="10">3</text>
<text x="-5.08" y="-2.159" size="1.27" layer="21" ratio="10">4</text>
<text x="0.381" y="-2.159" size="1.27" layer="21" ratio="10">5</text>
<text x="5.08" y="-2.159" size="1.27" layer="21" ratio="10">6</text>
<text x="10.16" y="-2.159" size="1.27" layer="21" ratio="10">7</text>
<text x="15.24" y="-2.159" size="1.27" layer="21" ratio="10">8</text>
</package>
<package name="MSTBA8">
<wire x1="-21.336" y1="4.572" x2="-21.336" y2="-4.445" width="0.127" layer="21"/>
<wire x1="-21.336" y1="4.572" x2="-18.415" y2="4.572" width="0.127" layer="21"/>
<wire x1="-18.415" y1="4.572" x2="-17.145" y2="4.572" width="0.127" layer="51"/>
<wire x1="-17.145" y1="4.572" x2="-13.335" y2="4.572" width="0.127" layer="21"/>
<wire x1="-13.335" y1="4.572" x2="-12.065" y2="4.572" width="0.127" layer="51"/>
<wire x1="18.415" y1="4.572" x2="21.336" y2="4.572" width="0.127" layer="21"/>
<wire x1="-21.336" y1="-4.445" x2="21.336" y2="-4.445" width="0.127" layer="21"/>
<wire x1="21.336" y1="4.572" x2="21.336" y2="-4.445" width="0.127" layer="21"/>
<wire x1="-21.336" y1="-7.493" x2="-18.669" y2="-7.493" width="0.127" layer="21"/>
<wire x1="-21.336" y1="-4.445" x2="-21.336" y2="-7.493" width="0.127" layer="21"/>
<wire x1="21.336" y1="-4.445" x2="21.336" y2="-7.493" width="0.127" layer="21"/>
<wire x1="-16.891" y1="-7.493" x2="-17.272" y2="-6.223" width="0.127" layer="21"/>
<wire x1="-16.891" y1="-7.493" x2="-13.589" y2="-7.493" width="0.127" layer="21"/>
<wire x1="-17.272" y1="-6.223" x2="-18.288" y2="-6.223" width="0.127" layer="21"/>
<wire x1="-18.669" y1="-7.493" x2="-18.288" y2="-6.223" width="0.127" layer="21"/>
<wire x1="-18.669" y1="-7.493" x2="-16.891" y2="-7.493" width="0.127" layer="21"/>
<wire x1="-11.811" y1="-7.493" x2="-12.192" y2="-6.223" width="0.127" layer="21"/>
<wire x1="-11.811" y1="-7.493" x2="-8.509" y2="-7.493" width="0.127" layer="21"/>
<wire x1="-8.509" y1="-7.493" x2="-6.731" y2="-7.493" width="0.127" layer="21"/>
<wire x1="-6.731" y1="-7.493" x2="-3.429" y2="-7.493" width="0.127" layer="21"/>
<wire x1="-3.429" y1="-7.493" x2="-1.651" y2="-7.493" width="0.127" layer="21"/>
<wire x1="-1.651" y1="-7.493" x2="1.651" y2="-7.493" width="0.127" layer="21"/>
<wire x1="1.651" y1="-7.493" x2="3.429" y2="-7.493" width="0.127" layer="21"/>
<wire x1="3.429" y1="-7.493" x2="6.731" y2="-7.493" width="0.127" layer="21"/>
<wire x1="6.731" y1="-7.493" x2="8.509" y2="-7.493" width="0.127" layer="21"/>
<wire x1="8.509" y1="-7.493" x2="11.811" y2="-7.493" width="0.127" layer="21"/>
<wire x1="11.811" y1="-7.493" x2="13.589" y2="-7.493" width="0.127" layer="21"/>
<wire x1="13.589" y1="-7.493" x2="16.891" y2="-7.493" width="0.127" layer="21"/>
<wire x1="16.891" y1="-7.493" x2="18.669" y2="-7.493" width="0.127" layer="21"/>
<wire x1="18.669" y1="-7.493" x2="21.336" y2="-7.493" width="0.127" layer="21"/>
<wire x1="-13.589" y1="-7.493" x2="-13.208" y2="-6.223" width="0.127" layer="21"/>
<wire x1="-13.589" y1="-7.493" x2="-11.811" y2="-7.493" width="0.127" layer="21"/>
<wire x1="-13.208" y1="-6.223" x2="-12.192" y2="-6.223" width="0.127" layer="21"/>
<wire x1="-8.128" y1="-6.223" x2="-7.112" y2="-6.223" width="0.127" layer="21"/>
<wire x1="-6.731" y1="-7.493" x2="-7.112" y2="-6.223" width="0.127" layer="21"/>
<wire x1="-8.509" y1="-7.493" x2="-8.128" y2="-6.223" width="0.127" layer="21"/>
<wire x1="-8.255" y1="4.572" x2="-6.985" y2="4.572" width="0.127" layer="51"/>
<wire x1="-12.065" y1="4.572" x2="-8.255" y2="4.572" width="0.127" layer="21"/>
<wire x1="-3.175" y1="4.572" x2="-1.905" y2="4.572" width="0.127" layer="51"/>
<wire x1="-6.985" y1="4.572" x2="-3.175" y2="4.572" width="0.127" layer="21"/>
<wire x1="-3.048" y1="-6.223" x2="-2.032" y2="-6.223" width="0.127" layer="21"/>
<wire x1="-1.651" y1="-7.493" x2="-2.032" y2="-6.223" width="0.127" layer="21"/>
<wire x1="-3.429" y1="-7.493" x2="-3.048" y2="-6.223" width="0.127" layer="21"/>
<wire x1="1.905" y1="4.572" x2="3.175" y2="4.572" width="0.127" layer="51"/>
<wire x1="-1.905" y1="4.572" x2="1.905" y2="4.572" width="0.127" layer="21"/>
<wire x1="2.032" y1="-6.223" x2="3.048" y2="-6.223" width="0.127" layer="21"/>
<wire x1="3.429" y1="-7.493" x2="3.048" y2="-6.223" width="0.127" layer="21"/>
<wire x1="1.651" y1="-7.493" x2="2.032" y2="-6.223" width="0.127" layer="21"/>
<wire x1="7.112" y1="-6.223" x2="8.128" y2="-6.223" width="0.127" layer="21"/>
<wire x1="6.731" y1="-7.493" x2="7.112" y2="-6.223" width="0.127" layer="21"/>
<wire x1="8.509" y1="-7.493" x2="8.128" y2="-6.223" width="0.127" layer="21"/>
<wire x1="6.985" y1="4.572" x2="8.255" y2="4.572" width="0.127" layer="51"/>
<wire x1="3.175" y1="4.572" x2="6.985" y2="4.572" width="0.127" layer="21"/>
<wire x1="12.192" y1="-6.223" x2="13.208" y2="-6.223" width="0.127" layer="21"/>
<wire x1="13.589" y1="-7.493" x2="13.208" y2="-6.223" width="0.127" layer="21"/>
<wire x1="11.811" y1="-7.493" x2="12.192" y2="-6.223" width="0.127" layer="21"/>
<wire x1="8.255" y1="4.572" x2="12.065" y2="4.572" width="0.127" layer="21"/>
<wire x1="12.065" y1="4.572" x2="13.335" y2="4.572" width="0.127" layer="51"/>
<wire x1="17.272" y1="-6.223" x2="18.288" y2="-6.223" width="0.127" layer="21"/>
<wire x1="18.669" y1="-7.493" x2="18.288" y2="-6.223" width="0.127" layer="21"/>
<wire x1="16.891" y1="-7.493" x2="17.272" y2="-6.223" width="0.127" layer="21"/>
<wire x1="13.335" y1="4.572" x2="17.145" y2="4.572" width="0.127" layer="21"/>
<wire x1="17.145" y1="4.572" x2="18.415" y2="4.572" width="0.127" layer="51"/>
<pad name="1" x="-17.78" y="2.54" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="2" x="-12.7" y="2.54" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="8" x="17.78" y="2.54" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="3" x="-7.62" y="2.54" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="4" x="-2.54" y="2.54" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="7" x="12.7" y="2.54" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="5" x="2.54" y="2.54" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="6" x="7.62" y="2.54" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<text x="-21.336" y="7.62" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-21.336" y="5.334" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-19.812" y="1.905" size="1.27" layer="21" ratio="10">1</text>
<text x="-14.986" y="1.905" size="1.27" layer="21" ratio="10">2</text>
<text x="-9.906" y="1.905" size="1.27" layer="21" ratio="10">3</text>
<text x="-4.826" y="1.905" size="1.27" layer="21" ratio="10">4</text>
<text x="0.254" y="1.905" size="1.27" layer="21" ratio="10">5</text>
<text x="5.334" y="1.905" size="1.27" layer="21" ratio="10">6</text>
<text x="10.414" y="1.905" size="1.27" layer="21" ratio="10">7</text>
<text x="15.494" y="1.905" size="1.27" layer="21" ratio="10">8</text>
</package>
<package name="MSTBA9">
<wire x1="-23.876" y1="4.572" x2="-23.876" y2="-4.445" width="0.127" layer="21"/>
<wire x1="-23.876" y1="4.572" x2="-20.955" y2="4.572" width="0.127" layer="21"/>
<wire x1="-20.955" y1="4.572" x2="-19.685" y2="4.572" width="0.127" layer="51"/>
<wire x1="-19.685" y1="4.572" x2="-15.875" y2="4.572" width="0.127" layer="21"/>
<wire x1="-15.875" y1="4.572" x2="-14.605" y2="4.572" width="0.127" layer="51"/>
<wire x1="20.955" y1="4.572" x2="23.876" y2="4.572" width="0.127" layer="21"/>
<wire x1="-23.876" y1="-4.445" x2="23.876" y2="-4.445" width="0.127" layer="21"/>
<wire x1="23.876" y1="4.572" x2="23.876" y2="-4.445" width="0.127" layer="21"/>
<wire x1="-23.876" y1="-7.493" x2="-21.209" y2="-7.493" width="0.127" layer="21"/>
<wire x1="-23.876" y1="-4.445" x2="-23.876" y2="-7.493" width="0.127" layer="21"/>
<wire x1="23.876" y1="-4.445" x2="23.876" y2="-7.493" width="0.127" layer="21"/>
<wire x1="-19.431" y1="-7.493" x2="-19.812" y2="-6.223" width="0.127" layer="21"/>
<wire x1="-19.431" y1="-7.493" x2="-16.129" y2="-7.493" width="0.127" layer="21"/>
<wire x1="-19.812" y1="-6.223" x2="-20.828" y2="-6.223" width="0.127" layer="21"/>
<wire x1="-21.209" y1="-7.493" x2="-20.828" y2="-6.223" width="0.127" layer="21"/>
<wire x1="-21.209" y1="-7.493" x2="-19.431" y2="-7.493" width="0.127" layer="21"/>
<wire x1="-14.351" y1="-7.493" x2="-14.732" y2="-6.223" width="0.127" layer="21"/>
<wire x1="-14.351" y1="-7.493" x2="-11.049" y2="-7.493" width="0.127" layer="21"/>
<wire x1="-11.049" y1="-7.493" x2="-9.271" y2="-7.493" width="0.127" layer="21"/>
<wire x1="-9.271" y1="-7.493" x2="-5.969" y2="-7.493" width="0.127" layer="21"/>
<wire x1="-5.969" y1="-7.493" x2="-4.191" y2="-7.493" width="0.127" layer="21"/>
<wire x1="-4.191" y1="-7.493" x2="-0.889" y2="-7.493" width="0.127" layer="21"/>
<wire x1="-0.889" y1="-7.493" x2="0.889" y2="-7.493" width="0.127" layer="21"/>
<wire x1="0.889" y1="-7.493" x2="4.191" y2="-7.493" width="0.127" layer="21"/>
<wire x1="4.191" y1="-7.493" x2="5.969" y2="-7.493" width="0.127" layer="21"/>
<wire x1="5.969" y1="-7.493" x2="9.271" y2="-7.493" width="0.127" layer="21"/>
<wire x1="9.271" y1="-7.493" x2="11.049" y2="-7.493" width="0.127" layer="21"/>
<wire x1="11.049" y1="-7.493" x2="14.351" y2="-7.493" width="0.127" layer="21"/>
<wire x1="14.351" y1="-7.493" x2="16.129" y2="-7.493" width="0.127" layer="21"/>
<wire x1="16.129" y1="-7.493" x2="19.431" y2="-7.493" width="0.127" layer="21"/>
<wire x1="19.431" y1="-7.493" x2="21.209" y2="-7.493" width="0.127" layer="21"/>
<wire x1="21.209" y1="-7.493" x2="23.876" y2="-7.493" width="0.127" layer="21"/>
<wire x1="-16.129" y1="-7.493" x2="-15.748" y2="-6.223" width="0.127" layer="21"/>
<wire x1="-16.129" y1="-7.493" x2="-14.351" y2="-7.493" width="0.127" layer="21"/>
<wire x1="-15.748" y1="-6.223" x2="-14.732" y2="-6.223" width="0.127" layer="21"/>
<wire x1="-10.668" y1="-6.223" x2="-9.652" y2="-6.223" width="0.127" layer="21"/>
<wire x1="-9.271" y1="-7.493" x2="-9.652" y2="-6.223" width="0.127" layer="21"/>
<wire x1="-11.049" y1="-7.493" x2="-10.668" y2="-6.223" width="0.127" layer="21"/>
<wire x1="-10.795" y1="4.572" x2="-9.525" y2="4.572" width="0.127" layer="51"/>
<wire x1="-14.605" y1="4.572" x2="-10.795" y2="4.572" width="0.127" layer="21"/>
<wire x1="-5.715" y1="4.572" x2="-4.445" y2="4.572" width="0.127" layer="51"/>
<wire x1="-9.525" y1="4.572" x2="-5.715" y2="4.572" width="0.127" layer="21"/>
<wire x1="-5.588" y1="-6.223" x2="-4.572" y2="-6.223" width="0.127" layer="21"/>
<wire x1="-4.191" y1="-7.493" x2="-4.572" y2="-6.223" width="0.127" layer="21"/>
<wire x1="-5.969" y1="-7.493" x2="-5.588" y2="-6.223" width="0.127" layer="21"/>
<wire x1="-0.635" y1="4.572" x2="0.635" y2="4.572" width="0.127" layer="51"/>
<wire x1="-4.445" y1="4.572" x2="-0.635" y2="4.572" width="0.127" layer="21"/>
<wire x1="-0.508" y1="-6.223" x2="0.508" y2="-6.223" width="0.127" layer="21"/>
<wire x1="0.889" y1="-7.493" x2="0.508" y2="-6.223" width="0.127" layer="21"/>
<wire x1="-0.889" y1="-7.493" x2="-0.508" y2="-6.223" width="0.127" layer="21"/>
<wire x1="4.572" y1="-6.223" x2="5.588" y2="-6.223" width="0.127" layer="21"/>
<wire x1="4.191" y1="-7.493" x2="4.572" y2="-6.223" width="0.127" layer="21"/>
<wire x1="5.969" y1="-7.493" x2="5.588" y2="-6.223" width="0.127" layer="21"/>
<wire x1="4.445" y1="4.572" x2="5.715" y2="4.572" width="0.127" layer="51"/>
<wire x1="0.635" y1="4.572" x2="4.445" y2="4.572" width="0.127" layer="21"/>
<wire x1="9.652" y1="-6.223" x2="10.668" y2="-6.223" width="0.127" layer="21"/>
<wire x1="11.049" y1="-7.493" x2="10.668" y2="-6.223" width="0.127" layer="21"/>
<wire x1="9.271" y1="-7.493" x2="9.652" y2="-6.223" width="0.127" layer="21"/>
<wire x1="5.715" y1="4.572" x2="9.525" y2="4.572" width="0.127" layer="21"/>
<wire x1="9.525" y1="4.572" x2="10.795" y2="4.572" width="0.127" layer="51"/>
<wire x1="14.732" y1="-6.223" x2="15.748" y2="-6.223" width="0.127" layer="21"/>
<wire x1="16.129" y1="-7.493" x2="15.748" y2="-6.223" width="0.127" layer="21"/>
<wire x1="14.351" y1="-7.493" x2="14.732" y2="-6.223" width="0.127" layer="21"/>
<wire x1="10.795" y1="4.572" x2="14.605" y2="4.572" width="0.127" layer="21"/>
<wire x1="14.605" y1="4.572" x2="15.875" y2="4.572" width="0.127" layer="51"/>
<wire x1="19.812" y1="-6.223" x2="20.828" y2="-6.223" width="0.127" layer="21"/>
<wire x1="21.209" y1="-7.493" x2="20.828" y2="-6.223" width="0.127" layer="21"/>
<wire x1="19.431" y1="-7.493" x2="19.812" y2="-6.223" width="0.127" layer="21"/>
<wire x1="15.875" y1="4.572" x2="19.685" y2="4.572" width="0.127" layer="21"/>
<wire x1="19.685" y1="4.572" x2="20.955" y2="4.572" width="0.127" layer="51"/>
<pad name="1" x="-20.32" y="2.54" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="2" x="-15.24" y="2.54" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="9" x="20.32" y="2.54" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="3" x="-10.16" y="2.54" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="4" x="-5.08" y="2.54" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="8" x="15.24" y="2.54" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="5" x="0" y="2.54" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="6" x="5.08" y="2.54" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="7" x="10.16" y="2.54" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<text x="-23.876" y="7.747" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-23.876" y="5.334" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-22.352" y="1.905" size="1.27" layer="21" ratio="10">1</text>
<text x="-17.526" y="1.905" size="1.27" layer="21" ratio="10">2</text>
<text x="-12.446" y="1.905" size="1.27" layer="21" ratio="10">3</text>
<text x="-7.366" y="1.905" size="1.27" layer="21" ratio="10">4</text>
<text x="-2.286" y="1.905" size="1.27" layer="21" ratio="10">5</text>
<text x="2.794" y="1.905" size="1.27" layer="21" ratio="10">6</text>
<text x="7.874" y="1.905" size="1.27" layer="21" ratio="10">7</text>
<text x="12.954" y="1.905" size="1.27" layer="21" ratio="10">8</text>
<text x="18.034" y="1.905" size="1.27" layer="21" ratio="10">9</text>
</package>
<package name="NOVAL1">
<wire x1="0" y1="0" x2="-0.1" y2="0" width="0" layer="21"/>
<circle x="0" y="0" radius="11.0707" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="2.5" width="0.4064" layer="21"/>
<circle x="-5.13" y="3.811" radius="1.5" width="0.254" layer="21"/>
<circle x="-6.326" y="0.123" radius="1.5" width="0.254" layer="21"/>
<circle x="-5.357" y="-3.688" radius="1.5" width="0.254" layer="21"/>
<circle x="2.096" y="-6.026" radius="1.5" width="0.254" layer="21"/>
<circle x="5.18" y="-3.811" radius="1.5" width="0.254" layer="21"/>
<circle x="6.426" y="-0.254" radius="1.5" width="0.254" layer="21"/>
<circle x="5.357" y="3.557" radius="1.5" width="0.254" layer="21"/>
<circle x="2.215" y="5.876" radius="1.5" width="0.254" layer="21"/>
<circle x="-1.869" y="6.153" radius="1.5" width="0.254" layer="21"/>
<circle x="-6.326" y="0.123" radius="1.1045" width="0.127" layer="21"/>
<circle x="-5.13" y="3.811" radius="1.1045" width="0.127" layer="21"/>
<circle x="-1.869" y="6.153" radius="1.1045" width="0.127" layer="21"/>
<circle x="2.215" y="5.876" radius="1.1045" width="0.127" layer="21"/>
<circle x="5.357" y="3.557" radius="1.1045" width="0.127" layer="21"/>
<circle x="6.426" y="-0.254" radius="1.1045" width="0.127" layer="21"/>
<circle x="5.18" y="-3.811" radius="1.1045" width="0.127" layer="21"/>
<circle x="2.096" y="-6.026" radius="1.1045" width="0.127" layer="21"/>
<circle x="-5.357" y="-3.688" radius="1.1045" width="0.127" layer="21"/>
<circle x="0" y="0" radius="10.5004" width="0.127" layer="21"/>
<circle x="0" y="0" radius="2.0591" width="0.127" layer="21"/>
<pad name="1" x="2.75" y="-8.85" drill="1.016" diameter="2.54"/>
<pad name="M" x="2.75" y="-1.75" drill="1.016" diameter="2.54" shape="octagon"/>
<pad name="2" x="7.5" y="-5.5" drill="1.016" diameter="2.54"/>
<pad name="3" x="9.25" y="0" drill="1.016" diameter="2.54"/>
<pad name="5" x="3.25" y="8.65" drill="1.016" diameter="2.54"/>
<pad name="4" x="7.5" y="5.5" drill="1.016" diameter="2.54"/>
<pad name="6" x="-2.75" y="8.85" drill="1.016" diameter="2.54"/>
<pad name="7" x="-7.5" y="5.5" drill="1.016" diameter="2.54"/>
<pad name="8" x="-9.25" y="0.25" drill="1.016" diameter="2.54"/>
<pad name="9" x="-7.65" y="-5.25" drill="1.016" diameter="2.54"/>
<text x="1.905" y="-6.604" size="1.27" layer="21">1</text>
<text x="4.699" y="-4.445" size="1.27" layer="21">2</text>
<text x="5.969" y="-0.889" size="1.27" layer="21">3</text>
<text x="4.826" y="2.921" size="1.27" layer="21">4</text>
<text x="1.778" y="5.207" size="1.27" layer="21">5</text>
<text x="-2.413" y="5.588" size="1.27" layer="21">6</text>
<text x="-5.461" y="3.175" size="1.27" layer="21">7</text>
<text x="-6.731" y="-0.508" size="1.27" layer="21">8</text>
<text x="-5.842" y="-4.318" size="1.27" layer="21">9</text>
<text x="0.889" y="-3.683" size="1.27" layer="21">m</text>
<text x="-3.81" y="-13.97" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-16.51" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="OKTAL1">
<wire x1="-5" y1="2" x2="-10.5" y2="4.5" width="0.6096" layer="21"/>
<wire x1="-2" y1="5" x2="-4.5" y2="10.5" width="0.6096" layer="21"/>
<wire x1="2" y1="5" x2="4" y2="10" width="0.6096" layer="21"/>
<wire x1="5" y1="2" x2="10.5" y2="4" width="0.6096" layer="21"/>
<wire x1="5" y1="-2" x2="10.5" y2="-4.5" width="0.6096" layer="21"/>
<wire x1="2" y1="-5" x2="4.5" y2="-10.5" width="0.6096" layer="21"/>
<wire x1="-2" y1="-5" x2="-4.5" y2="-10.5" width="0.6096" layer="21"/>
<wire x1="-5" y1="-2" x2="-10.5" y2="-4" width="0.6096" layer="21"/>
<wire x1="0" y1="-4" x2="2.5" y2="-3" width="0.254" layer="21" curve="-320.692352" cap="flat"/>
<wire x1="0" y1="-4" x2="2.5" y2="-3" width="0.254" layer="21" curve="180" cap="flat"/>
<circle x="0" y="0" radius="15.0332" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="14.0356" width="0.254" layer="21"/>
<circle x="-9" y="0" radius="2" width="0.254" layer="21"/>
<circle x="9" y="0" radius="2" width="0.254" layer="21"/>
<circle x="0" y="-9" radius="2" width="0.254" layer="21"/>
<circle x="0" y="9" radius="2" width="0.254" layer="21"/>
<circle x="-6" y="-6" radius="2" width="0.254" layer="21"/>
<circle x="-6" y="6" radius="2" width="0.254" layer="21"/>
<circle x="6" y="6" radius="2" width="0.254" layer="21"/>
<circle x="6" y="-6" radius="2" width="0.254" layer="21"/>
<circle x="-6" y="6" radius="1.5811" width="0.127" layer="21"/>
<circle x="0" y="9" radius="1.5811" width="0.127" layer="21"/>
<circle x="6" y="6" radius="1.5811" width="0.127" layer="21"/>
<circle x="9" y="0" radius="1.5811" width="0.127" layer="21"/>
<circle x="6" y="-6" radius="1.5811" width="0.127" layer="21"/>
<circle x="0" y="-9" radius="1.5811" width="0.127" layer="21"/>
<circle x="-6" y="-6" radius="1.5811" width="0.127" layer="21"/>
<circle x="-9" y="0" radius="1.5811" width="0.127" layer="21"/>
<pad name="8" x="0" y="-13" drill="1.27" diameter="2.54"/>
<pad name="4" x="0" y="13" drill="1.27" diameter="2.54"/>
<pad name="2" x="13" y="0" drill="1.27" diameter="2.54"/>
<pad name="6" x="-13" y="0" drill="1.27" diameter="2.54"/>
<pad name="5" x="-9" y="9" drill="1.27" diameter="2.54"/>
<pad name="7" x="-9" y="-9" drill="1.27" diameter="2.54"/>
<pad name="1" x="9" y="-9" drill="1.27" diameter="2.54"/>
<pad name="3" x="9" y="9" drill="1.27" diameter="2.54"/>
<text x="-5.08" y="-18.415" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-20.955" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="5.842" y="-6.858" size="1.778" layer="21">1</text>
<text x="8.382" y="-0.762" size="1.778" layer="21">2</text>
<text x="5.334" y="5.08" size="1.778" layer="21">3</text>
<text x="-0.762" y="8.128" size="1.778" layer="21">4</text>
<text x="-6.604" y="5.08" size="1.778" layer="21">5</text>
<text x="-9.652" y="-0.762" size="1.778" layer="21">6</text>
<text x="-6.604" y="-6.858" size="1.778" layer="21">7</text>
<text x="-0.508" y="-9.906" size="1.778" layer="21">8</text>
</package>
<package name="MSTBA4">
<wire x1="-11.176" y1="4.572" x2="-11.176" y2="-4.445" width="0.127" layer="21"/>
<wire x1="-11.176" y1="4.572" x2="-8.255" y2="4.572" width="0.127" layer="21"/>
<wire x1="8.255" y1="4.572" x2="11.176" y2="4.572" width="0.127" layer="21"/>
<wire x1="-11.176" y1="-4.445" x2="11.176" y2="-4.445" width="0.127" layer="21"/>
<wire x1="11.176" y1="4.572" x2="11.176" y2="-4.445" width="0.127" layer="21"/>
<wire x1="-11.176" y1="-7.493" x2="-8.509" y2="-7.493" width="0.127" layer="21"/>
<wire x1="-11.176" y1="-4.445" x2="-11.176" y2="-7.493" width="0.127" layer="21"/>
<wire x1="11.176" y1="-4.445" x2="11.176" y2="-7.493" width="0.127" layer="21"/>
<wire x1="-7.112" y1="-6.223" x2="-8.128" y2="-6.223" width="0.127" layer="21"/>
<wire x1="8.509" y1="-7.493" x2="11.176" y2="-7.493" width="0.127" layer="21"/>
<pad name="1" x="-7.62" y="2.54" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="2" x="-2.54" y="2.54" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="4" x="7.62" y="2.54" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="2.54" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<text x="-11.176" y="7.62" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-11.176" y="5.334" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-9.652" y="1.905" size="1.27" layer="21" ratio="10">1</text>
<text x="-4.826" y="1.905" size="1.27" layer="21" ratio="10">2</text>
<text x="0.254" y="1.905" size="1.27" layer="21" ratio="10">3</text>
<text x="5.334" y="1.905" size="1.27" layer="21" ratio="10">4</text>
</package>
<package name="MSTBV4">
<wire x1="-10.795" y1="-3.81" x2="10.795" y2="-3.81" width="0.127" layer="21"/>
<wire x1="10.795" y1="-3.81" x2="10.795" y2="4.064" width="0.127" layer="21"/>
<wire x1="10.795" y1="4.064" x2="10.795" y2="4.572" width="0.127" layer="21"/>
<wire x1="-10.795" y1="4.572" x2="-10.795" y2="4.064" width="0.127" layer="21"/>
<wire x1="-10.795" y1="4.064" x2="-10.795" y2="-3.81" width="0.127" layer="21"/>
<wire x1="-10.16" y1="-2.54" x2="-10.16" y2="2.794" width="0.127" layer="21"/>
<wire x1="-10.16" y1="2.794" x2="-10.16" y2="3.048" width="0.127" layer="21"/>
<wire x1="10.16" y1="3.048" x2="10.16" y2="2.794" width="0.127" layer="21"/>
<wire x1="10.16" y1="2.794" x2="10.16" y2="-2.54" width="0.127" layer="21"/>
<wire x1="-10.16" y1="-2.54" x2="-9.7282" y2="-2.54" width="0.127" layer="21"/>
<wire x1="9.7282" y1="-2.54" x2="10.16" y2="-2.54" width="0.127" layer="21"/>
<wire x1="-10.16" y1="2.794" x2="-8.128" y2="2.794" width="0.127" layer="21"/>
<wire x1="8.128" y1="2.794" x2="10.16" y2="2.794" width="0.127" layer="21"/>
<wire x1="-10.795" y1="4.572" x2="-8.128" y2="4.572" width="0.127" layer="21"/>
<wire x1="8.128" y1="4.572" x2="10.795" y2="4.572" width="0.127" layer="21"/>
<wire x1="-10.795" y1="4.064" x2="-8.382" y2="4.064" width="0.127" layer="21"/>
<wire x1="-3.302" y1="3.048" x2="-6.858" y2="3.048" width="0.127" layer="21"/>
<wire x1="-8.382" y1="3.048" x2="-10.16" y2="3.048" width="0.127" layer="21"/>
<wire x1="8.382" y1="4.064" x2="10.795" y2="4.064" width="0.127" layer="21"/>
<wire x1="3.302" y1="3.048" x2="6.858" y2="3.048" width="0.127" layer="21"/>
<wire x1="8.382" y1="3.048" x2="10.16" y2="3.048" width="0.127" layer="21"/>
<wire x1="-0.381" y1="-2.54" x2="0.381" y2="-2.54" width="0.127" layer="21"/>
<pad name="1" x="-7.62" y="0" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="2" x="-2.54" y="0" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="0" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="4" x="7.62" y="0" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<text x="-9.779" y="-2.159" size="1.27" layer="21" ratio="10">1</text>
<text x="-10.795" y="7.874" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-10.922" y="5.334" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-5.08" y="-2.159" size="1.27" layer="21" ratio="10">2</text>
<text x="0" y="-2.159" size="1.27" layer="21" ratio="10">3</text>
<text x="5.08" y="-2.159" size="1.27" layer="21" ratio="10">4</text>
</package>
<package name="MSTBA7">
<wire x1="-18.796" y1="4.572" x2="-18.796" y2="-4.445" width="0.127" layer="21"/>
<wire x1="-18.796" y1="4.572" x2="-15.875" y2="4.572" width="0.127" layer="21"/>
<wire x1="15.875" y1="4.572" x2="18.796" y2="4.572" width="0.127" layer="21"/>
<wire x1="-18.796" y1="-4.445" x2="18.796" y2="-4.445" width="0.127" layer="21"/>
<wire x1="18.796" y1="4.572" x2="18.796" y2="-4.445" width="0.127" layer="21"/>
<wire x1="-18.796" y1="-7.493" x2="-16.129" y2="-7.493" width="0.127" layer="21"/>
<wire x1="-18.796" y1="-4.445" x2="-18.796" y2="-7.493" width="0.127" layer="21"/>
<wire x1="18.796" y1="-4.445" x2="18.796" y2="-7.493" width="0.127" layer="21"/>
<wire x1="-14.732" y1="-6.223" x2="-15.748" y2="-6.223" width="0.127" layer="21"/>
<wire x1="16.129" y1="-7.493" x2="18.796" y2="-7.493" width="0.127" layer="21"/>
<pad name="1" x="-15.24" y="2.54" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="2" x="-10.16" y="2.54" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="7" x="15.24" y="2.54" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="3" x="-5.08" y="2.54" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="4" x="0" y="2.54" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="6" x="10.16" y="2.54" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="5" x="5.08" y="2.54" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<text x="-18.796" y="8.128" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-18.796" y="5.588" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-17.272" y="1.905" size="1.27" layer="21" ratio="10">1</text>
<text x="-12.446" y="1.905" size="1.27" layer="21" ratio="10">2</text>
<text x="-7.366" y="1.905" size="1.27" layer="21" ratio="10">3</text>
<text x="-2.286" y="1.905" size="1.27" layer="21" ratio="10">4</text>
<text x="2.794" y="1.905" size="1.27" layer="21" ratio="10">5</text>
<text x="7.874" y="1.905" size="1.27" layer="21" ratio="10">6</text>
<text x="12.954" y="1.905" size="1.27" layer="21" ratio="10">7</text>
</package>
<package name="MSTBV7">
<wire x1="-18.415" y1="-3.81" x2="18.415" y2="-3.81" width="0.127" layer="21"/>
<wire x1="18.415" y1="-3.81" x2="18.415" y2="4.064" width="0.127" layer="21"/>
<wire x1="18.415" y1="4.064" x2="18.415" y2="4.572" width="0.127" layer="21"/>
<wire x1="-18.415" y1="4.572" x2="-18.415" y2="4.064" width="0.127" layer="21"/>
<wire x1="-18.415" y1="4.064" x2="-18.415" y2="-3.81" width="0.127" layer="21"/>
<wire x1="-17.78" y1="-2.54" x2="-17.78" y2="2.794" width="0.127" layer="21"/>
<wire x1="-17.78" y1="2.794" x2="-17.78" y2="3.048" width="0.127" layer="21"/>
<wire x1="17.78" y1="3.048" x2="17.78" y2="2.794" width="0.127" layer="21"/>
<wire x1="17.78" y1="2.794" x2="17.78" y2="-2.54" width="0.127" layer="21"/>
<wire x1="-17.78" y1="-2.54" x2="-17.3482" y2="-2.54" width="0.127" layer="21"/>
<wire x1="17.3482" y1="-2.54" x2="17.78" y2="-2.54" width="0.127" layer="21"/>
<wire x1="-17.78" y1="2.794" x2="-15.748" y2="2.794" width="0.127" layer="21"/>
<wire x1="-15.748" y1="2.794" x2="-14.732" y2="2.794" width="0.127" layer="21"/>
<wire x1="-14.732" y1="2.794" x2="-10.668" y2="2.794" width="0.127" layer="21"/>
<wire x1="-10.668" y1="2.794" x2="-9.652" y2="2.794" width="0.127" layer="21"/>
<wire x1="-9.652" y1="2.794" x2="-5.588" y2="2.794" width="0.127" layer="21"/>
<wire x1="-5.588" y1="2.794" x2="-4.572" y2="2.794" width="0.127" layer="21"/>
<wire x1="15.748" y1="2.794" x2="17.78" y2="2.794" width="0.127" layer="21"/>
<wire x1="-18.415" y1="4.572" x2="-15.748" y2="4.572" width="0.127" layer="21"/>
<wire x1="-15.748" y1="4.572" x2="-14.732" y2="4.572" width="0.127" layer="21"/>
<wire x1="-14.732" y1="4.572" x2="-10.668" y2="4.572" width="0.127" layer="21"/>
<wire x1="-10.668" y1="4.572" x2="-9.652" y2="4.572" width="0.127" layer="21"/>
<wire x1="-9.652" y1="4.572" x2="-5.588" y2="4.572" width="0.127" layer="21"/>
<wire x1="-5.588" y1="4.572" x2="-4.572" y2="4.572" width="0.127" layer="21"/>
<wire x1="15.748" y1="4.572" x2="18.415" y2="4.572" width="0.127" layer="21"/>
<wire x1="-18.415" y1="4.064" x2="-16.002" y2="4.064" width="0.127" layer="21"/>
<wire x1="-14.478" y1="4.064" x2="-10.922" y2="4.064" width="0.127" layer="21"/>
<wire x1="-9.398" y1="4.064" x2="-5.842" y2="4.064" width="0.127" layer="21"/>
<wire x1="-5.842" y1="3.048" x2="-9.398" y2="3.048" width="0.127" layer="21"/>
<wire x1="-10.922" y1="3.048" x2="-14.478" y2="3.048" width="0.127" layer="21"/>
<wire x1="-16.002" y1="3.048" x2="-17.78" y2="3.048" width="0.127" layer="21"/>
<wire x1="16.002" y1="4.064" x2="18.415" y2="4.064" width="0.127" layer="21"/>
<wire x1="-4.318" y1="3.048" x2="-0.762" y2="3.048" width="0.127" layer="21"/>
<wire x1="0.762" y1="3.048" x2="4.318" y2="3.048" width="0.127" layer="21"/>
<wire x1="5.842" y1="3.048" x2="9.398" y2="3.048" width="0.127" layer="21"/>
<wire x1="16.002" y1="3.048" x2="17.78" y2="3.048" width="0.127" layer="21"/>
<wire x1="-14.732" y1="2.794" x2="-14.732" y2="4.572" width="0.127" layer="21"/>
<wire x1="-15.748" y1="2.794" x2="-15.748" y2="4.572" width="0.127" layer="21"/>
<wire x1="-16.002" y1="4.064" x2="-16.002" y2="3.048" width="0.127" layer="21"/>
<wire x1="-14.478" y1="4.064" x2="-14.478" y2="3.048" width="0.127" layer="21"/>
<wire x1="-14.732" y1="4.572" x2="-14.478" y2="4.064" width="0.127" layer="21"/>
<wire x1="-16.002" y1="4.064" x2="-15.748" y2="4.572" width="0.127" layer="21"/>
<wire x1="-16.002" y1="3.048" x2="-15.748" y2="2.794" width="0.127" layer="21"/>
<wire x1="-14.478" y1="3.048" x2="-14.732" y2="2.794" width="0.127" layer="21"/>
<wire x1="-12.2936" y1="-2.4892" x2="-10.16" y2="-3.556" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="-10.795" y1="-0.635" x2="-9.525" y2="-0.635" width="0.127" layer="51"/>
<wire x1="-10.795" y1="0.635" x2="-10.795" y2="-0.635" width="0.127" layer="51"/>
<wire x1="-9.525" y1="0.635" x2="-10.795" y2="0.635" width="0.127" layer="51"/>
<wire x1="-9.525" y1="-0.635" x2="-9.525" y2="0.635" width="0.127" layer="51"/>
<wire x1="-10.795" y1="-0.635" x2="-9.525" y2="0.635" width="0.127" layer="51"/>
<wire x1="-10.795" y1="0.635" x2="-9.525" y2="-0.635" width="0.127" layer="51"/>
<wire x1="-10.668" y1="2.794" x2="-10.668" y2="4.572" width="0.127" layer="21"/>
<wire x1="-9.652" y1="2.794" x2="-9.652" y2="4.572" width="0.127" layer="21"/>
<wire x1="-9.398" y1="4.064" x2="-9.398" y2="3.048" width="0.127" layer="21"/>
<wire x1="-9.652" y1="4.572" x2="-9.398" y2="4.064" width="0.127" layer="21"/>
<wire x1="-9.398" y1="3.048" x2="-9.652" y2="2.794" width="0.127" layer="21"/>
<wire x1="-10.922" y1="4.064" x2="-10.668" y2="4.572" width="0.127" layer="21"/>
<wire x1="-10.922" y1="4.064" x2="-10.922" y2="3.048" width="0.127" layer="21"/>
<wire x1="-10.922" y1="3.048" x2="-10.668" y2="2.794" width="0.127" layer="21"/>
<wire x1="0.635" y1="-0.635" x2="0.635" y2="0.635" width="0.127" layer="51"/>
<wire x1="0.635" y1="0.635" x2="-0.635" y2="0.635" width="0.127" layer="51"/>
<wire x1="-0.635" y1="0.635" x2="-0.635" y2="-0.635" width="0.127" layer="51"/>
<wire x1="-0.635" y1="0.635" x2="0.635" y2="-0.635" width="0.127" layer="51"/>
<wire x1="-0.635" y1="-0.635" x2="0.635" y2="0.635" width="0.127" layer="51"/>
<wire x1="-0.635" y1="-0.635" x2="0.635" y2="-0.635" width="0.127" layer="51"/>
<wire x1="-5.08" y1="-3.556" x2="-2.9464" y2="-2.4892" width="0.127" layer="21" curve="53.130102" cap="flat"/>
<wire x1="-2.921" y1="-2.54" x2="-2.159" y2="-2.54" width="0.127" layer="21"/>
<wire x1="9.525" y1="0.635" x2="9.525" y2="-0.635" width="0.127" layer="51"/>
<wire x1="9.525" y1="-0.635" x2="10.795" y2="-0.635" width="0.127" layer="51"/>
<pad name="1" x="-15.24" y="0" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="2" x="-10.16" y="0" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="3" x="-5.08" y="0" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="4" x="0" y="0" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="5" x="5.08" y="0" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="6" x="10.16" y="0" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<pad name="7" x="15.24" y="0" drill="1.397" diameter="1.905" shape="long" rot="R90"/>
<text x="-17.399" y="-2.159" size="1.27" layer="21" ratio="10">1</text>
<text x="-18.415" y="8.382" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-18.542" y="5.842" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-12.7" y="-2.159" size="1.27" layer="21" ratio="10">2</text>
<text x="-7.62" y="-2.159" size="1.27" layer="21" ratio="10">3</text>
<text x="-2.54" y="-2.159" size="1.27" layer="21" ratio="10">4</text>
<text x="2.54" y="-2.159" size="1.27" layer="21" ratio="10">5</text>
<text x="7.62" y="-2.159" size="1.27" layer="21" ratio="10">6</text>
<text x="12.7" y="-2.159" size="1.27" layer="21" ratio="10">7</text>
</package>
</packages>
<symbols>
<symbol name="HEATER_2">
<wire x1="0" y1="2.54" x2="0" y2="7.62" width="0.4064" layer="94" curve="180" cap="flat"/>
<wire x1="0" y1="-2.54" x2="0" y2="-7.62" width="0.4064" layer="94" curve="-180" cap="flat"/>
<wire x1="0" y1="2.54" x2="0" y2="-2.54" width="0.254" layer="94" locked="yes"/>
<text x="3.048" y="-2.54" size="1.778" layer="96">&gt;VALUE</text>
<text x="3.048" y="0" size="1.778" layer="95">&gt;NAME</text>
<pin name="H1" x="0" y="10.16" visible="pad" length="short" direction="pas" rot="R270"/>
<pin name="H2" x="-2.54" y="0" visible="pad" length="short" direction="pas"/>
<pin name="H3" x="0" y="-10.16" visible="pad" length="short" direction="pas" rot="R90"/>
</symbol>
<symbol name="TRIODE">
<wire x1="-3.302" y1="0" x2="-2.032" y2="0" width="0.4064" layer="94"/>
<wire x1="-0.635" y1="0" x2="0.635" y2="0" width="0.4064" layer="94"/>
<wire x1="2.032" y1="0" x2="3.302" y2="0" width="0.4064" layer="94"/>
<wire x1="-1.27" y1="2.54" x2="0" y2="2.54" width="0.8128" layer="94"/>
<wire x1="0" y1="2.54" x2="1.27" y2="2.54" width="0.8128" layer="94"/>
<wire x1="0" y1="5.08" x2="0" y2="2.54" width="0.1524" layer="94"/>
<wire x1="-5.08" y1="0" x2="-3.302" y2="0" width="0.1524" layer="94"/>
<wire x1="0" y1="-2.54" x2="0" y2="-5.08" width="0.1524" layer="94"/>
<circle x="0" y="-2.667" radius="0.254" width="0.8128" layer="94"/>
<circle x="0" y="0" radius="5.08" width="0.4064" layer="94"/>
<text x="2.54" y="7.62" size="1.778" layer="95">&gt;NAME</text>
<text x="2.54" y="5.08" size="1.778" layer="96">&gt;VALUE</text>
<pin name="TA" x="0" y="10.16" visible="pad" length="middle" direction="pas" rot="R270"/>
<pin name="TG" x="-10.16" y="0" visible="pad" length="middle" direction="pas"/>
<pin name="TK" x="0" y="-10.16" visible="pad" length="middle" direction="pas" rot="R90"/>
<wire x1="-1.27" y1="3.81" x2="-3.81" y2="1.27" width="0.254" layer="94" style="shortdash" curve="90"/>
<pin name="P$1" x="-8.89" y="2.54" visible="off" length="middle"/>
</symbol>
<symbol name="PENTODE">
<wire x1="-1.27" y1="5.08" x2="1.27" y2="5.08" width="0.8128" layer="94"/>
<wire x1="-0.635" y1="-2.54" x2="0.635" y2="-2.54" width="0.4064" layer="94"/>
<wire x1="2.032" y1="-2.54" x2="3.302" y2="-2.54" width="0.4064" layer="94"/>
<wire x1="-3.302" y1="-2.54" x2="-2.032" y2="-2.54" width="0.4064" layer="94"/>
<wire x1="2.032" y1="0" x2="2.667" y2="0" width="0.4064" layer="94"/>
<wire x1="2.667" y1="0" x2="3.302" y2="0.635" width="0.4064" layer="94"/>
<wire x1="-2.032" y1="0" x2="-2.667" y2="0" width="0.4064" layer="94"/>
<wire x1="-2.667" y1="0" x2="-3.302" y2="0.635" width="0.4064" layer="94"/>
<wire x1="-0.635" y1="2.54" x2="0.635" y2="2.54" width="0.4064" layer="94"/>
<wire x1="2.032" y1="2.54" x2="3.302" y2="2.54" width="0.4064" layer="94"/>
<wire x1="3.302" y1="2.54" x2="3.302" y2="3.175" width="0.4064" layer="94"/>
<wire x1="-2.032" y1="2.54" x2="-3.302" y2="2.54" width="0.4064" layer="94"/>
<wire x1="-3.302" y1="2.54" x2="-3.302" y2="3.175" width="0.4064" layer="94"/>
<wire x1="3.175" y1="-4.826" x2="-2.54" y2="-4.826" width="0.4064" layer="94"/>
<wire x1="-2.54" y1="-4.826" x2="-3.175" y2="-5.461" width="0.4064" layer="94"/>
<wire x1="-5.08" y1="3.556" x2="5.08" y2="3.556" width="0.4064" layer="94" curve="-180"/>
<wire x1="-5.08" y1="-3.429" x2="5.08" y2="-3.429" width="0.4064" layer="94" curve="180"/>
<wire x1="-5.08" y1="3.556" x2="-5.08" y2="-3.429" width="0.4064" layer="94"/>
<wire x1="5.08" y1="4.064" x2="5.08" y2="-3.429" width="0.4064" layer="94"/>
<wire x1="3.2512" y1="-4.8006" x2="5.08" y2="-6.604" width="0.1524" layer="94"/>
<wire x1="5.08" y1="-6.604" x2="5.08" y2="-7.62" width="0.1524" layer="94"/>
<wire x1="3.302" y1="2.54" x2="3.937" y2="1.905" width="0.1524" layer="94"/>
<wire x1="3.937" y1="1.905" x2="3.937" y2="-4.191" width="0.1524" layer="94"/>
<wire x1="3.937" y1="-4.191" x2="3.2512" y2="-4.8006" width="0.1524" layer="94"/>
<text x="2.54" y="12.7" size="1.778" layer="95">&gt;NAME</text>
<text x="2.54" y="10.16" size="1.778" layer="96">&gt;VALUE</text>
<pin name="PSG" x="7.62" y="0" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="PG" x="-7.62" y="-2.54" visible="pad" length="middle" direction="pas"/>
<pin name="PA" x="0" y="10.16" visible="pad" length="middle" direction="pas" rot="R270"/>
<pin name="PK" x="5.08" y="-10.16" visible="pad" length="short" direction="pas" rot="R90"/>
</symbol>
<symbol name="PENTODE/">
<wire x1="-1.27" y1="7.62" x2="1.27" y2="7.62" width="0.8128" layer="94"/>
<wire x1="2.032" y1="2.54" x2="2.667" y2="2.54" width="0.4064" layer="94"/>
<wire x1="2.667" y1="2.54" x2="3.302" y2="3.175" width="0.4064" layer="94"/>
<wire x1="-2.032" y1="2.54" x2="-2.667" y2="2.54" width="0.4064" layer="94"/>
<wire x1="-2.667" y1="2.54" x2="-3.302" y2="3.175" width="0.4064" layer="94"/>
<wire x1="-0.635" y1="5.08" x2="0.635" y2="5.08" width="0.4064" layer="94"/>
<wire x1="2.032" y1="5.08" x2="3.302" y2="5.08" width="0.4064" layer="94"/>
<wire x1="3.302" y1="5.08" x2="3.302" y2="5.715" width="0.4064" layer="94"/>
<wire x1="-2.032" y1="5.08" x2="-3.302" y2="5.08" width="0.4064" layer="94"/>
<wire x1="-3.302" y1="5.08" x2="-3.302" y2="5.715" width="0.4064" layer="94"/>
<wire x1="-5.08" y1="6.096" x2="5.08" y2="6.096" width="0.4064" layer="94" curve="-180"/>
<wire x1="-5.08" y1="-0.889" x2="5.08" y2="-0.889" width="0.4064" layer="94" curve="180"/>
<wire x1="-5.08" y1="6.096" x2="-5.08" y2="-0.889" width="0.4064" layer="94"/>
<wire x1="5.08" y1="6.35" x2="5.08" y2="-0.889" width="0.4064" layer="94"/>
<text x="2.54" y="15.24" size="1.778" layer="95">&gt;NAME</text>
<text x="2.54" y="12.7" size="1.778" layer="96">&gt;VALUE</text>
<pin name="PSG" x="7.62" y="2.54" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="PG" x="-7.582478125" y="-0.0296" visible="pad" length="middle" direction="pas"/>
<pin name="PA" x="0" y="12.7" visible="pad" length="middle" direction="pas" rot="R270"/>
<pin name="PK" x="0" y="-7.59709375" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="PBG" x="7.62" y="5.08" visible="pad" length="middle" direction="pas" rot="R180"/>
<circle x="0" y="-2.54" radius="0.635" width="1.016" layer="94"/>
<pin name="P$1" x="-7.580271875" y="-2.53889375" visible="pad" length="short"/>
<wire x1="-3.81" y1="-2.54" x2="-0.635" y2="-4.445" width="0.1524" layer="94" style="shortdash" curve="36.869898"/>
<wire x1="-5.08" y1="-2.54" x2="-3.81" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="0" y1="-5.08" x2="0" y2="-2.54" width="0.1524" layer="94"/>
</symbol>
<symbol name="HEATER_1">
<wire x1="0" y1="7.62" x2="0" y2="2.54" width="0.4064" layer="94" curve="-180" cap="flat"/>
<text x="3.302" y="2.54" size="1.778" layer="96">&gt;VALUE</text>
<text x="3.302" y="5.08" size="1.778" layer="95">&gt;NAME</text>
<pin name="H2" x="0" y="0" visible="pad" length="short" direction="pas" rot="R90"/>
</symbol>
<symbol name="ABSTIMM">
<wire x1="2.54" y1="12.7" x2="7.62" y2="7.62" width="0.4064" layer="94" curve="-90"/>
<wire x1="-7.62" y1="7.62" x2="-2.54" y2="12.7" width="0.4064" layer="94" curve="-90"/>
<wire x1="-7.62" y1="0" x2="-2.54" y2="-5.08" width="0.4064" layer="94" curve="90"/>
<wire x1="2.54" y1="-5.08" x2="7.62" y2="0" width="0.4064" layer="94" curve="90"/>
<wire x1="-2.54" y1="12.7" x2="2.54" y2="12.7" width="0.4064" layer="94"/>
<wire x1="7.62" y1="7.62" x2="7.62" y2="-0.508" width="0.4064" layer="94"/>
<wire x1="2.54" y1="-5.08" x2="-2.54" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="0" x2="-7.62" y2="2.54" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="2.54" x2="-7.62" y2="7.62" width="0.4064" layer="94"/>
<wire x1="1.651" y1="2.54" x2="0.889" y2="2.54" width="0.4064" layer="94"/>
<wire x1="4.445" y1="2.54" x2="5.461" y2="2.54" width="0.4064" layer="94"/>
<wire x1="3.429" y1="2.54" x2="2.667" y2="2.54" width="0.4064" layer="94"/>
<wire x1="1.27" y1="5.842" x2="3.81" y2="5.842" width="0.3048" layer="94"/>
<wire x1="3.81" y1="9.525" x2="2.54" y2="10.16" width="0.4064" layer="94"/>
<wire x1="2.54" y1="10.16" x2="1.27" y2="10.795" width="0.4064" layer="94"/>
<wire x1="1.27" y1="10.16" x2="1.27" y2="10.795" width="0.4064" layer="94"/>
<wire x1="1.27" y1="10.795" x2="1.27" y2="11.43" width="0.4064" layer="94"/>
<wire x1="3.81" y1="8.89" x2="3.81" y2="10.16" width="0.4064" layer="94"/>
<wire x1="-3.683" y1="2.54" x2="-2.921" y2="2.54" width="0.4064" layer="94"/>
<wire x1="-4.699" y1="2.54" x2="-5.334" y2="2.54" width="0.4064" layer="94"/>
<wire x1="-5.334" y1="2.54" x2="-5.461" y2="2.54" width="0.4064" layer="94"/>
<wire x1="4.953" y1="-1.905" x2="-3.81" y2="-1.905" width="0.4064" layer="94"/>
<wire x1="-3.81" y1="-1.905" x2="-4.445" y2="-2.54" width="0.4064" layer="94"/>
<wire x1="-1.27" y1="10.16" x2="-2.54" y2="10.16" width="0.8128" layer="94"/>
<wire x1="-2.54" y1="10.16" x2="-3.81" y2="10.16" width="0.8128" layer="94"/>
<wire x1="4.953" y1="-1.905" x2="5.08" y2="-1.778" width="0.1524" layer="94"/>
<wire x1="5.08" y1="-1.778" x2="5.842" y2="-0.762" width="0.1524" layer="94"/>
<wire x1="5.842" y1="-0.762" x2="5.842" y2="2.159" width="0.1524" layer="94"/>
<wire x1="5.842" y1="2.159" x2="5.461" y2="2.54" width="0.1524" layer="94"/>
<wire x1="-1.143" y1="2.54" x2="-1.905" y2="2.54" width="0.4064" layer="94"/>
<wire x1="-2.54" y1="12.7" x2="-2.54" y2="10.16" width="0.1524" layer="94"/>
<wire x1="2.54" y1="12.7" x2="2.54" y2="10.16" width="0.1524" layer="94"/>
<wire x1="-7.62" y1="2.54" x2="-5.334" y2="2.54" width="0.1524" layer="94"/>
<wire x1="6.096" y1="7.62" x2="7.62" y2="7.62" width="0.1524" layer="94"/>
<wire x1="6.096" y1="7.62" x2="4.826" y2="6.35" width="0.1524" layer="94"/>
<wire x1="5.08" y1="-5.08" x2="5.08" y2="-1.778" width="0.1524" layer="94"/>
<circle x="4.445" y="5.842" radius="0.635" width="0.254" layer="94"/>
<circle x="0.635" y="5.842" radius="0.635" width="0.254" layer="94"/>
<text x="5.08" y="15.24" size="1.778" layer="95">&gt;NAME</text>
<text x="5.08" y="12.7" size="1.778" layer="96">&gt;VALUE</text>
<pin name="A" x="-2.54" y="17.78" visible="pad" length="middle" direction="pas" rot="R270"/>
<pin name="GT" x="-12.7" y="2.54" visible="pad" length="middle" direction="pas"/>
<pin name="L" x="2.54" y="17.78" visible="pad" length="middle" direction="pas" rot="R270"/>
<pin name="ST" x="12.7" y="7.62" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="K_G1" x="5.08" y="-10.16" visible="pad" length="middle" direction="pas" rot="R90"/>
</symbol>
<symbol name="ZM1000">
<wire x1="-12.7" y1="2.54" x2="-12.7" y2="-5.08" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="10.16" y1="-5.08" x2="10.16" y2="2.54" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="-12.7" y1="0" x2="10.16" y2="0" width="0.8128" layer="94"/>
<wire x1="-12.7" y1="2.54" x2="10.16" y2="2.54" width="0.254" layer="94"/>
<wire x1="-12.7" y1="-5.08" x2="10.16" y2="-5.08" width="0.1524" layer="94"/>
<wire x1="-17.78" y1="-2.54" x2="-17.78" y2="-1.27" width="0.1524" layer="94"/>
<wire x1="-17.78" y1="-1.27" x2="-15.24" y2="-1.27" width="0.1524" layer="94"/>
<circle x="-12.7" y="-2.54" radius="0.254" width="0.254" layer="94"/>
<circle x="-7.62" y="-2.54" radius="0.254" width="0.254" layer="94"/>
<circle x="-5.08" y="-2.54" radius="0.254" width="0.254" layer="94"/>
<circle x="-2.54" y="-2.54" radius="0.254" width="0.254" layer="94"/>
<circle x="0" y="-2.54" radius="0.254" width="0.254" layer="94"/>
<circle x="2.54" y="-2.54" radius="0.254" width="0.254" layer="94"/>
<circle x="5.08" y="-2.54" radius="0.254" width="0.254" layer="94"/>
<circle x="7.62" y="-2.54" radius="0.254" width="0.254" layer="94"/>
<circle x="10.16" y="-2.54" radius="0.254" width="0.254" layer="94"/>
<circle x="-10.16" y="-2.54" radius="0.254" width="0.254" layer="94"/>
<circle x="-15.24" y="-1.27" radius="0.254" width="0.254" layer="94"/>
<circle x="-12.7" y="-2.54" radius="0.508" width="0.254" layer="94"/>
<circle x="-10.16" y="-2.54" radius="0.508" width="0.254" layer="94"/>
<circle x="-7.62" y="-2.54" radius="0.508" width="0.254" layer="94"/>
<circle x="-5.08" y="-2.54" radius="0.508" width="0.254" layer="94"/>
<circle x="-2.54" y="-2.54" radius="0.508" width="0.254" layer="94"/>
<circle x="0" y="-2.54" radius="0.508" width="0.254" layer="94"/>
<circle x="2.54" y="-2.54" radius="0.508" width="0.254" layer="94"/>
<circle x="5.08" y="-2.54" radius="0.508" width="0.254" layer="94"/>
<circle x="7.62" y="-2.54" radius="0.508" width="0.254" layer="94"/>
<circle x="10.16" y="-2.54" radius="0.508" width="0.254" layer="94"/>
<circle x="-15.24" y="-1.27" radius="0.508" width="0.254" layer="94"/>
<text x="2.54" y="5.588" size="1.778" layer="95">&gt;NAME</text>
<text x="2.54" y="3.302" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-10.16" y="-10.16" visible="pad" direction="pas" rot="R90"/>
<pin name="2" x="-7.62" y="-10.16" visible="pad" direction="pas" rot="R90"/>
<pin name="4" x="-2.54" y="-10.16" visible="pad" direction="pas" rot="R90"/>
<pin name="3" x="-5.08" y="-10.16" visible="pad" direction="pas" rot="R90"/>
<pin name="5" x="0" y="-10.16" visible="pad" direction="pas" rot="R90"/>
<pin name="6" x="2.54" y="-10.16" visible="pad" direction="pas" rot="R90"/>
<pin name="7" x="5.08" y="-10.16" visible="pad" direction="pas" rot="R90"/>
<pin name="8" x="7.62" y="-10.16" visible="pad" direction="pas" rot="R90"/>
<pin name="9" x="10.16" y="-10.16" visible="pad" direction="pas" rot="R90"/>
<pin name="0" x="-12.7" y="-10.16" visible="pad" direction="pas" rot="R90"/>
<pin name="DPL" x="-17.78" y="-10.16" visible="pad" direction="pas" rot="R90"/>
<pin name="A1" x="-2.54" y="7.62" visible="pad" direction="pas" rot="R270"/>
<pin name="A2" x="0" y="7.62" visible="pad" direction="pas" rot="R270"/>
</symbol>
<symbol name="DIODE">
<wire x1="-2.54" y1="-4.572" x2="2.54" y2="-4.572" width="0.254" layer="94" curve="-180" cap="flat"/>
<wire x1="-3.302" y1="1.778" x2="-1.524" y2="3.556" width="0.6096" layer="94"/>
<wire x1="1.524" y1="3.556" x2="3.302" y2="1.778" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="5.08" x2="-2.54" y2="2.794" width="0.1524" layer="94"/>
<wire x1="2.54" y1="5.08" x2="2.54" y2="2.794" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="-5.08" x2="-2.54" y2="-4.318" width="0.1524" layer="94"/>
<wire x1="2.54" y1="-5.08" x2="2.54" y2="-4.318" width="0.1524" layer="94"/>
<wire x1="-1.016" y1="-2.286" x2="1.016" y2="-2.286" width="0.6096" layer="94" curve="-59.489763" cap="flat"/>
<text x="5.08" y="5.08" size="1.778" layer="95">&gt;NAME</text>
<text x="5.08" y="2.54" size="1.778" layer="96">&gt;VALUE</text>
<pin name="H2" x="2.54" y="-10.16" visible="pad" length="middle" direction="pas" rot="R90"/>
<pin name="A2" x="2.54" y="10.16" visible="pad" length="middle" direction="pas" rot="R270"/>
<pin name="A1" x="-2.54" y="10.16" visible="pad" length="middle" direction="pas" rot="R270"/>
<pin name="H1" x="-2.54" y="-10.16" visible="pad" length="middle" direction="pas" rot="R90"/>
</symbol>
<symbol name="REGULAR">
<pin name="A" x="0" y="10.16" visible="pad" length="middle" direction="pas" rot="R270"/>
<pin name="K" x="0" y="-10.16" visible="pad" length="middle" direction="pas" rot="R90"/>
</symbol>
<symbol name="DIODE/">
<wire x1="-1.27" y1="-1.27" x2="1.27" y2="-1.27" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-1.27" x2="2.286" y2="-1.27" width="0.1524" layer="94"/>
<wire x1="7.62" y1="-6.604" x2="7.62" y2="-7.62" width="0.1524" layer="94"/>
<wire x1="2.286" y1="-1.27" x2="7.62" y2="-6.604" width="0.1524" layer="94"/>
<pin name="K" x="7.62" y="-10.16" visible="pad" length="short" direction="pas" rot="R90"/>
</symbol>
<symbol name="TRIODE/">
<wire x1="-3.302" y1="0" x2="-2.54" y2="0" width="0.4064" layer="94"/>
<wire x1="-2.54" y1="0" x2="-2.032" y2="0" width="0.4064" layer="94"/>
<wire x1="-1.016" y1="-2.286" x2="1.016" y2="-2.286" width="0.6096" layer="94" curve="-72.054747" cap="flat"/>
<wire x1="-5.08" y1="0" x2="-2.54" y2="0" width="0.1524" layer="94"/>
<pin name="K/H1" x="-2.54" y="-10.16" visible="pad" length="middle" direction="pas" rot="R90"/>
<pin name="K/H2" x="2.54" y="-10.16" visible="pad" length="middle" direction="pas" rot="R90"/>
</symbol>
<symbol name="TETRODE">
<wire x1="-1.27" y1="5.08" x2="0" y2="5.08" width="0.8128" layer="94"/>
<wire x1="0" y1="5.08" x2="1.27" y2="5.08" width="0.8128" layer="94"/>
<wire x1="-5.08" y1="3.556" x2="-5.08" y2="-2.54" width="0.4064" layer="94"/>
<wire x1="-5.08" y1="-2.54" x2="-5.08" y2="-3.429" width="0.4064" layer="94"/>
<wire x1="5.08" y1="3.81" x2="5.08" y2="2.54" width="0.4064" layer="94"/>
<wire x1="5.08" y1="2.54" x2="5.08" y2="0" width="0.4064" layer="94"/>
<wire x1="5.08" y1="0" x2="5.08" y2="-3.429" width="0.4064" layer="94"/>
<wire x1="0" y1="10.16" x2="0" y2="5.08" width="0.1524" layer="94"/>
<wire x1="3.2766" y1="-4.826" x2="5.08" y2="-6.604" width="0.1524" layer="94"/>
<wire x1="5.08" y1="-6.604" x2="5.08" y2="-10.16" width="0.1524" layer="94"/>
<wire x1="-5.08" y1="-2.54" x2="-2.032" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="2.032" y1="0" x2="5.08" y2="0" width="0.1524" layer="94"/>
<pin name="PSG" x="10.16" y="0" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="PG" x="-10.16" y="-2.54" visible="pad" length="middle" direction="pas"/>
<pin name="PA" x="0" y="15.24" visible="pad" length="middle" direction="pas" rot="R270"/>
<pin name="PK" x="5.08" y="-12.7" visible="pad" length="short" direction="pas" rot="R90"/>
</symbol>
<symbol name="PENT/">
<wire x1="5.08" y1="4.064" x2="5.08" y2="0" width="0.4064" layer="94"/>
<wire x1="0" y1="5.08" x2="0" y2="15.24" width="0.1524" layer="94"/>
<wire x1="-5.08" y1="-2.54" x2="-10.16" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="5.08" y1="0" x2="10.16" y2="0" width="0.1524" layer="94"/>
<wire x1="5.08" y1="-6.604" x2="5.08" y2="-12.7" width="0.1524" layer="94"/>
<text x="-2.794" y="9.652" size="1.27" layer="94">PA</text>
<text x="-8.382" y="-2.032" size="1.27" layer="94">G1</text>
<text x="6.35" y="0.508" size="1.27" layer="94">G2</text>
<text x="-1.016" y="-10.668" size="1.27" layer="94">PK/G3</text>
</symbol>
<symbol name="PENT//">
<wire x1="3.302" y1="2.54" x2="5.08" y2="2.54" width="0.1524" layer="94"/>
<wire x1="5.08" y1="2.54" x2="10.16" y2="2.54" width="0.1524" layer="94"/>
<text x="-8.128" y="-2.032" size="1.27" layer="94">G1</text>
<text x="6.35" y="3.048" size="1.27" layer="94">G3</text>
<text x="-2.794" y="10.16" size="1.27" layer="94">PA</text>
<text x="2.54" y="-10.16" size="1.27" layer="94">PK</text>
</symbol>
<symbol name="TRIO/">
<wire x1="0" y1="2.54" x2="0" y2="10.16" width="0.1524" layer="94"/>
<wire x1="-3.302" y1="0" x2="-10.16" y2="0" width="0.1524" layer="94"/>
<wire x1="0" y1="-2.54" x2="0" y2="-10.16" width="0.1524" layer="94"/>
<text x="-2.54" y="-7.62" size="1.27" layer="94">TK</text>
<text x="-8.382" y="0.508" size="1.27" layer="94">TG</text>
<text x="-2.794" y="6.096" size="1.27" layer="94">TA</text>
</symbol>
<symbol name="DIO/">
<wire x1="-2.54" y1="2.794" x2="-2.54" y2="10.16" width="0.1524" layer="94"/>
<wire x1="2.54" y1="2.794" x2="2.54" y2="10.16" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="-4.318" x2="-2.54" y2="-10.16" width="0.1524" layer="94"/>
<wire x1="2.54" y1="-4.318" x2="2.54" y2="-10.16" width="0.1524" layer="94"/>
<text x="-4.572" y="5.842" size="1.27" layer="94">A1</text>
<text x="0" y="5.842" size="1.27" layer="94">A2</text>
<text x="-4.572" y="-7.366" size="1.27" layer="94">H1</text>
<text x="0" y="-7.366" size="1.27" layer="94">H2</text>
</symbol>
<symbol name="DIO//">
<wire x1="7.62" y1="-6.604" x2="7.62" y2="-10.16" width="0.1524" layer="94"/>
<text x="4.318" y="-7.366" size="1.27" layer="94">DK</text>
</symbol>
<symbol name="HEAT/1">
<wire x1="-2.54" y1="2.54" x2="-2.54" y2="-2.54" width="0.4064" layer="94" curve="-180" cap="flat"/>
<wire x1="-2.54" y1="2.54" x2="-2.54" y2="5.08" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="-2.54" x2="-2.54" y2="-5.08" width="0.1524" layer="94"/>
<text x="0.762" y="-2.54" size="1.778" layer="96">&gt;VALUE</text>
<text x="0.762" y="0" size="1.778" layer="95">&gt;NAME</text>
<text x="-4.572" y="3.302" size="1.27" layer="94">H1</text>
<text x="-5.08" y="-4.318" size="1.27" layer="94">H2</text>
</symbol>
<symbol name="HEAT/2">
<wire x1="0" y1="2.54" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="0" y2="-2.54" width="0.254" layer="94"/>
<wire x1="0" y1="7.62" x2="0" y2="10.16" width="0.1524" layer="94"/>
<wire x1="0" y1="-7.62" x2="0" y2="-10.16" width="0.1524" layer="94"/>
<wire x1="0" y1="0" x2="-2.54" y2="0" width="0.1524" layer="94"/>
<text x="-2.032" y="8.382" size="1.27" layer="94">H1</text>
<text x="-2.54" y="-9.652" size="1.27" layer="94">H2</text>
<text x="-2.794" y="0.508" size="1.27" layer="94">H3</text>
</symbol>
<symbol name="TETRO/">
<wire x1="5.08" y1="3.81" x2="5.08" y2="0" width="0.4064" layer="94"/>
<text x="-2.54" y="10.16" size="1.27" layer="94">PA</text>
<text x="-7.874" y="-2.032" size="1.27" layer="94">G1</text>
<text x="6.096" y="0.508" size="1.27" layer="94">G2</text>
<text x="2.286" y="-10.414" size="1.27" layer="94">PK</text>
</symbol>
<symbol name="REGU/">
<text x="-1.524" y="6.604" size="1.27" layer="94">A</text>
<text x="-1.524" y="-7.62" size="1.27" layer="94">K</text>
</symbol>
<symbol name="ABST/">
<wire x1="2.54" y1="10.16" x2="7.62" y2="5.08" width="0.4064" layer="94" curve="-90"/>
<wire x1="-7.62" y1="5.08" x2="-2.54" y2="10.16" width="0.4064" layer="94" curve="-90"/>
<wire x1="-7.62" y1="-2.54" x2="-2.54" y2="-7.62" width="0.4064" layer="94" curve="90"/>
<wire x1="2.54" y1="-7.62" x2="7.62" y2="-2.54" width="0.4064" layer="94" curve="90"/>
<wire x1="-2.54" y1="10.16" x2="2.54" y2="10.16" width="0.4064" layer="94"/>
<wire x1="7.62" y1="5.08" x2="7.62" y2="-3.048" width="0.4064" layer="94"/>
<wire x1="2.54" y1="-7.62" x2="-2.54" y2="-7.62" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="-2.54" x2="-7.62" y2="0" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="0" x2="-7.62" y2="5.08" width="0.4064" layer="94"/>
<wire x1="1.651" y1="0" x2="0.889" y2="0" width="0.4064" layer="94"/>
<wire x1="4.445" y1="0" x2="5.461" y2="0" width="0.4064" layer="94"/>
<wire x1="3.429" y1="0" x2="2.667" y2="0" width="0.4064" layer="94"/>
<wire x1="1.27" y1="3.302" x2="3.81" y2="3.302" width="0.3048" layer="94"/>
<wire x1="3.81" y1="6.985" x2="2.54" y2="7.62" width="0.4064" layer="94"/>
<wire x1="2.54" y1="7.62" x2="1.27" y2="8.255" width="0.4064" layer="94"/>
<wire x1="1.27" y1="7.62" x2="1.27" y2="8.255" width="0.4064" layer="94"/>
<wire x1="1.27" y1="8.255" x2="1.27" y2="8.89" width="0.4064" layer="94"/>
<wire x1="3.81" y1="6.35" x2="3.81" y2="7.62" width="0.4064" layer="94"/>
<wire x1="-3.683" y1="0" x2="-2.921" y2="0" width="0.4064" layer="94"/>
<wire x1="-4.699" y1="0" x2="-5.334" y2="0" width="0.4064" layer="94"/>
<wire x1="-5.334" y1="0" x2="-5.461" y2="0" width="0.4064" layer="94"/>
<wire x1="4.953" y1="-4.445" x2="-3.81" y2="-4.445" width="0.4064" layer="94"/>
<wire x1="-3.81" y1="-4.445" x2="-4.445" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="-1.27" y1="7.62" x2="-2.54" y2="7.62" width="0.8128" layer="94"/>
<wire x1="-2.54" y1="7.62" x2="-3.81" y2="7.62" width="0.8128" layer="94"/>
<wire x1="4.953" y1="-4.445" x2="5.08" y2="-4.318" width="0.1524" layer="94"/>
<wire x1="5.08" y1="-4.318" x2="5.842" y2="-3.302" width="0.1524" layer="94"/>
<wire x1="5.842" y1="-3.302" x2="5.842" y2="-0.381" width="0.1524" layer="94"/>
<wire x1="5.842" y1="-0.381" x2="5.461" y2="0" width="0.1524" layer="94"/>
<wire x1="-1.143" y1="0" x2="-1.905" y2="0" width="0.4064" layer="94"/>
<wire x1="-2.54" y1="10.16" x2="-2.54" y2="7.62" width="0.1524" layer="94"/>
<wire x1="2.54" y1="10.16" x2="2.54" y2="7.62" width="0.1524" layer="94"/>
<wire x1="-7.62" y1="0" x2="-5.334" y2="0" width="0.1524" layer="94"/>
<wire x1="6.096" y1="5.08" x2="7.62" y2="5.08" width="0.1524" layer="94"/>
<wire x1="6.096" y1="5.08" x2="4.826" y2="3.81" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="10.16" x2="-2.54" y2="15.24" width="0.1524" layer="94"/>
<wire x1="2.54" y1="10.16" x2="2.54" y2="15.24" width="0.1524" layer="94"/>
<wire x1="7.62" y1="5.08" x2="12.7" y2="5.08" width="0.1524" layer="94"/>
<wire x1="5.08" y1="-4.318" x2="5.08" y2="-12.7" width="0.1524" layer="94"/>
<wire x1="-7.62" y1="0" x2="-12.7" y2="0" width="0.1524" layer="94"/>
<circle x="4.445" y="3.302" radius="0.635" width="0.254" layer="94"/>
<circle x="0.635" y="3.302" radius="0.635" width="0.254" layer="94"/>
<text x="5.08" y="12.7" size="1.778" layer="95">&gt;NAME</text>
<text x="5.08" y="10.16" size="1.778" layer="96">&gt;VALUE</text>
<text x="-5.08" y="11.176" size="1.27" layer="94">AT</text>
<text x="-10.922" y="0.508" size="1.27" layer="94">GT</text>
<text x="0.508" y="-10.668" size="1.27" layer="94">K/G1</text>
<text x="8.636" y="5.588" size="1.27" layer="94">ST</text>
<text x="1.016" y="11.176" size="1.27" layer="94">L</text>
</symbol>
<symbol name="TRIO//">
<wire x1="-2.54" y1="0" x2="-10.16" y2="0" width="0.1524" layer="94"/>
<text x="-2.54" y="7.112" size="1.27" layer="94">TA</text>
<text x="-6.858" y="-7.62" size="1.27" layer="94">K/H1</text>
<text x="-2.032" y="-7.62" size="1.27" layer="94">K/H2</text>
</symbol>
<symbol name="DUOTRIODE">
<wire x1="-3.10680625" y1="0" x2="-1.83680625" y2="0" width="0.4064" layer="94"/>
<wire x1="1.88560625" y1="0" x2="3.15560625" y2="0" width="0.4064" layer="94"/>
<text x="15.24" y="7.62" size="1.778" layer="95">&gt;NAME</text>
<text x="15.24" y="5.08" size="1.778" layer="96">&gt;VALUE</text>
<wire x1="4.470025" y1="0" x2="5.740025" y2="0" width="0.4064" layer="94"/>
<wire x1="6.96623125" y1="0" x2="8.23623125" y2="0" width="0.4064" layer="94"/>
<wire x1="9.53063125" y1="0.04880625" x2="10.80063125" y2="0.04880625" width="0.4064" layer="94"/>
<wire x1="6.399425" y1="2.5156" x2="8.939425" y2="2.5156" width="0.8128" layer="94"/>
<circle x="7.6215" y="-2.569390625" radius="0.254" width="0.8128" layer="94"/>
<wire x1="-3.81" y1="3.81" x2="-3.81" y2="-3.81" width="0.254" layer="94"/>
<wire x1="-1.93325625" y1="5.080778125" x2="9.515365625" y2="5.080778125" width="0.254" layer="94"/>
<wire x1="11.4544625" y1="2.438046875" x2="11.420821875" y2="-2.5687125" width="0.254" layer="94"/>
<pin name="AA" x="0" y="6.28635" visible="pad" length="short" rot="R270"/>
<pin name="BA" x="7.620625" y="6.301459375" visible="pad" length="short" rot="R270"/>
<pin name="AK" x="0" y="-6.293675" visible="pad" length="short" rot="R90"/>
<pin name="BK" x="7.621" y="-6.27334375" visible="pad" length="short" rot="R90"/>
<pin name="AG" x="-5.048196875" y="0.002071875" visible="pad" length="short"/>
<pin name="BG" x="12.676853125" y="0.024403125" visible="pad" length="short" rot="R180"/>
<pin name="S" x="3.81233125" y="-6.292740625" visible="pad" length="short" rot="R90"/>
<wire x1="-3.835153125" y1="2.633796875" x2="-3.835153125" y2="2.495703125" width="0.254" layer="94"/>
<wire x1="10.16" y1="5.08" x2="11.43" y2="3.81" width="0.254" layer="94" curve="-90"/>
<wire x1="11.43" y1="3.81" x2="11.43" y2="2.54" width="0.254" layer="94"/>
<wire x1="11.43" y1="-2.54" x2="11.43" y2="-3.81" width="0.254" layer="94"/>
<wire x1="11.43" y1="-3.81" x2="10.16" y2="-5.08" width="0.254" layer="94" curve="-90"/>
<wire x1="10.16" y1="-5.08" x2="-2.54" y2="-5.08" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-5.08" x2="-3.81" y2="-3.81" width="0.254" layer="94" curve="-90"/>
<wire x1="8.89" y1="5.08" x2="10.16" y2="5.08" width="0.254" layer="94"/>
<wire x1="-2.54" y1="5.08" x2="-3.81" y2="3.81" width="0.254" layer="94" curve="90"/>
<wire x1="-2.54" y1="5.08" x2="-1.27" y2="5.08" width="0.254" layer="94"/>
<wire x1="0" y1="3.81" x2="0" y2="2.54" width="0.1524" layer="94"/>
<wire x1="7.62" y1="3.81" x2="7.62" y2="2.54" width="0.1524" layer="94"/>
<wire x1="0" y1="-3.81" x2="0" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="7.62" y1="-3.81" x2="7.62" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="3.81" y1="3.81" x2="3.81" y2="-3.81" width="0.1524" layer="94" style="shortdash"/>
</symbol>
<symbol name="PENTODE_1">
<pin name="PG" x="-7.62" y="0" visible="pad" length="middle"/>
<pin name="PK" x="0" y="-7.62" visible="pad" length="middle" rot="R90"/>
<pin name="PS" x="-7.62" y="-2.54" visible="pad" length="short"/>
<wire x1="-3.81" y1="-2.54" x2="-5.08" y2="-2.54" width="0.1524" layer="94"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="EM84-P" prefix="V" uservalue="yes">
<gates>
<gate name="G$1" symbol="ABSTIMM" x="-15.24" y="0" swaplevel="1"/>
<gate name="&quot;" symbol="HEATER_1" x="10.16" y="-17.78" addlevel="request" swaplevel="1"/>
</gates>
<devices>
<device name="" package="NOVAL">
<connects>
<connect gate="&quot;" pin="H1" pad="4"/>
<connect gate="&quot;" pin="H2" pad="5"/>
<connect gate="G$1" pin="A" pad="9"/>
<connect gate="G$1" pin="GT" pad="1"/>
<connect gate="G$1" pin="K_G1" pad="3"/>
<connect gate="G$1" pin="L" pad="6"/>
<connect gate="G$1" pin="ST" pad="7"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="EM87-P" prefix="V" uservalue="yes">
<gates>
<gate name="G$1" symbol="ABSTIMM" x="-15.24" y="0"/>
<gate name="&quot;" symbol="HEATER_1" x="10.16" y="-17.78" addlevel="request"/>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6550A-P" prefix="V" uservalue="yes">
<gates>
<gate name="G$1" symbol="PENTODE" x="0" y="0"/>
<gate name="&quot;" symbol="HEATER_1" x="20.32" y="-12.7" addlevel="request"/>
</gates>
<devices>
<device name="" package="OKTAL">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ECL86-P" prefix="V" uservalue="yes">
<gates>
<gate name="A" symbol="PENTODE" x="-20.32" y="2.54"/>
<gate name="B" symbol="TRIODE" x="10.16" y="0"/>
<gate name="&quot;" symbol="HEATER_1" x="27.94" y="-10.16" addlevel="request"/>
</gates>
<devices>
<connects>
<connect gate="A" pin="PA" pad="6"/>
<connect gate="A" pin="PG" pad="8"/>
<connect gate="A" pin="PK" pad="7"/>
<connect gate="A" pin="PSG" pad="3"/>
<connect gate="B" pin="TA" pad="9"/>
<connect gate="B" pin="TG" pad="1"/>
<connect gate="B" pin="TK" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="EL34-P" prefix="V" uservalue="yes">
<gates>
<gate name="G$1" symbol="PENTODE/" x="0" y="-2.54"/>
</gates>
<devices>
<connects>
<connect gate="&quot;" pin="H1" pad="2"/>
<connect gate="&quot;" pin="H2" pad="7"/>
<connect gate="G$1" pin="PA" pad="3"/>
<connect gate="G$1" pin="PBG" pad="1"/>
<connect gate="G$1" pin="PG" pad="5"/>
<connect gate="G$1" pin="PK" pad="8"/>
<connect gate="G$1" pin="PSG" pad="4"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="EL84-P" prefix="V">
<gates>
</gates>
<devices>
<connects>
<connect gate="G$1" pin="PA" pad="7"/>
<connect gate="G$1" pin="PG" pad="2"/>
<connect gate="G$1" pin="PK" pad="3"/>
<connect gate="G$1" pin="PSG" pad="9"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="EF86-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
<connect gate="&quot;" pin="H1" pad="5"/>
<connect gate="&quot;" pin="H2" pad="4"/>
<connect gate="G$1" pin="P$1" pad="2 7"/>
<connect gate="G$1" pin="PA" pad="6"/>
<connect gate="G$1" pin="PBG" pad="8"/>
<connect gate="G$1" pin="PG" pad="9"/>
<connect gate="G$1" pin="PSG" pad="1"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ECL82-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
<connect gate="A" pin="PG" pad="3"/>
<connect gate="A" pin="PK" pad="2"/>
<connect gate="A" pin="PSG" pad="7"/>
<connect gate="B" pin="TK" pad="8"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ECC82-P" prefix="V" uservalue="yes">
<gates>
<gate name="A" symbol="TRIODE" x="-12.7" y="0"/>
<gate name="&quot;" symbol="HEATER_2" x="27.94" y="0" addlevel="request"/>
</gates>
<devices>
<connects>
<connect gate="&quot;" pin="H2" pad="9"/>
<connect gate="&quot;" pin="H3" pad="5"/>
<connect gate="A" pin="TA" pad="1"/>
<connect gate="A" pin="TG" pad="2"/>
<connect gate="A" pin="TK" pad="3"/>
<connect gate="B" pin="TA" pad="6"/>
<connect gate="B" pin="TG" pad="7"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ECC81-P" prefix="V" uservalue="yes">
<gates>
<gate name="&quot;" symbol="HEATER_2" x="30.48" y="0" addlevel="request"/>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="KT77-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="KT66-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PCL805-P" prefix="V" uservalue="yes">
<gates>
<gate name="A" symbol="PENTODE" x="-15.24" y="0"/>
<gate name="B" symbol="TRIODE" x="15.24" y="-2.54"/>
<gate name="&quot;" symbol="HEATER_1" x="33.02" y="-12.7" addlevel="request"/>
</gates>
<devices>
<connects>
<connect gate="&quot;" pin="H1" pad="6"/>
<connect gate="A" pin="PA" pad="4"/>
<connect gate="A" pin="PG" pad="1"/>
<connect gate="B" pin="TG" pad="8"/>
<connect gate="B" pin="TK" pad="7"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ECC83-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="KT88-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
<connect gate="&quot;" pin="H1" pad="7"/>
<connect gate="&quot;" pin="H2" pad="2"/>
<connect gate="G$1" pin="PG" pad="4"/>
<connect gate="G$1" pin="PK" pad="1"/>
<connect gate="G$1" pin="PSG" pad="5"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ZM1000" prefix="AN" uservalue="yes">
<gates>
<gate name="G$1" symbol="ZM1000" x="0" y="0"/>
</gates>
<devices>
<device name="" package="ZM1000">
<connects>
<connect gate="G$1" pin="0" pad="K0"/>
<connect gate="G$1" pin="1" pad="K1"/>
<connect gate="G$1" pin="2" pad="K2"/>
<connect gate="G$1" pin="3" pad="K3"/>
<connect gate="G$1" pin="4" pad="K4"/>
<connect gate="G$1" pin="5" pad="K5"/>
<connect gate="G$1" pin="6" pad="K6"/>
<connect gate="G$1" pin="7" pad="K7"/>
<connect gate="G$1" pin="8" pad="K8"/>
<connect gate="G$1" pin="9" pad="K9"/>
<connect gate="G$1" pin="A1" pad="A1"/>
<connect gate="G$1" pin="A2" pad="A2"/>
<connect gate="G$1" pin="DPL" pad="KDP"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6SN7GT-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
<connect gate="&quot;" pin="H2" pad="8"/>
<connect gate="A" pin="TA" pad="2"/>
<connect gate="A" pin="TG" pad="1"/>
<connect gate="B" pin="TA" pad="5"/>
<connect gate="B" pin="TG" pad="4"/>
<connect gate="B" pin="TK" pad="6"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6BL7GT-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6AS7G-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6DJ8-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6N1P-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5R4GY" prefix="V" uservalue="yes">
<gates>
<gate name="G$1" symbol="DIODE" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="G$1" pin="A1" pad="4"/>
<connect gate="G$1" pin="A2" pad="6"/>
<connect gate="G$1" pin="H1" pad="2"/>
<connect gate="G$1" pin="H2" pad="8"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5U4GB" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5V4G" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="EZ80" prefix="V" uservalue="yes">
<gates>
<gate name="G$1" symbol="DIODE/" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="G$1" pin="A1" pad="7"/>
<connect gate="G$1" pin="A2" pad="1"/>
<connect gate="G$1" pin="H1" pad="4"/>
<connect gate="G$1" pin="H2" pad="5"/>
<connect gate="G$1" pin="K" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="EZ81" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="GZ32" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="GZ34" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="GZ37" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="OD3A" prefix="V" uservalue="yes">
<gates>
<gate name="G$1" symbol="REGULAR" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="G$1" pin="A" pad="5"/>
<connect gate="G$1" pin="K" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5Y3GT" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12BH7-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12DW7-P" prefix="V" uservalue="yes">
<gates>
<gate name="&quot;" symbol="HEATER_2" x="25.4" y="0" addlevel="request"/>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="7247-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5879-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
<connect gate="G$1" pin="PA" pad="8"/>
<connect gate="G$1" pin="PBG" pad="9"/>
<connect gate="G$1" pin="PG" pad="1"/>
<connect gate="G$1" pin="PSG" pad="7"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5881-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6AN8-P" prefix="V" uservalue="yes">
<gates>
<gate name="A" symbol="TRIODE" x="-15.24" y="0"/>
<gate name="B" symbol="PENTODE" x="10.16" y="2.54"/>
<gate name="&quot;" symbol="HEATER_1" x="30.48" y="-10.16" addlevel="request"/>
</gates>
<devices>
<connects>
<connect gate="B" pin="PA" pad="6"/>
<connect gate="B" pin="PG" pad="8"/>
<connect gate="B" pin="PK" pad="9"/>
<connect gate="B" pin="PSG" pad="7"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6C5GT-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6CG7-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6FQ7-P" prefix="V" uservalue="yes">
<gates>
<gate name="&quot;" symbol="HEATER_2" x="27.94" y="-2.54" addlevel="request"/>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6EU7-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
<connect gate="&quot;" pin="H1" pad="1"/>
<connect gate="A" pin="TA" pad="6"/>
<connect gate="A" pin="TG" pad="5"/>
<connect gate="A" pin="TK" pad="4"/>
<connect gate="B" pin="TA" pad="7"/>
<connect gate="B" pin="TK" pad="9"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6F6GT-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6J5-P" prefix="V" uservalue="yes">
<gates>
<gate name="G$1" symbol="TRIODE" x="-12.7" y="0"/>
<gate name="&quot;" symbol="HEATER_1" x="7.62" y="-10.16" addlevel="request"/>
</gates>
<devices>
<connects>
<connect gate="G$1" pin="TA" pad="3"/>
<connect gate="G$1" pin="TG" pad="5"/>
<connect gate="G$1" pin="TK" pad="8"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6K6GT-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6L6GC-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6SJ7-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
<connect gate="G$1" pin="PBG" pad="3"/>
<connect gate="G$1" pin="PK" pad="5"/>
<connect gate="G$1" pin="PSG" pad="6"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6SL7GT-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6113-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6U8-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
<connect gate="A" pin="TG" pad="9"/>
<connect gate="A" pin="TK" pad="8"/>
<connect gate="B" pin="PG" pad="2"/>
<connect gate="B" pin="PK" pad="7"/>
<connect gate="B" pin="PSG" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ECF82-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6V6GT-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="7184-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="7027-P" prefix="V" uservalue="yes">
<gates>
<gate name="G$2" symbol="HEATER_1" x="20.32" y="-12.7" addlevel="request"/>
</gates>
<devices>
<connects>
<connect gate="G$2" pin="H1" pad="2"/>
<connect gate="G$2" pin="H2" pad="7"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="7199-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
<connect gate="B" pin="PA" pad="2"/>
<connect gate="B" pin="PG" pad="7"/>
<connect gate="B" pin="PK" pad="6"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="7868-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
<connect gate="G$1" pin="PA" pad="9"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ECC86-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ECC40-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
<connect gate="A" pin="TG" pad="3"/>
<connect gate="B" pin="TG" pad="6"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12AT7-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12AU7-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12AX7-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ECC84-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6CW7-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ECC88-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6BM8-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
<connect gate="A" pin="TA" pad="9"/>
<connect gate="B" pin="PG" pad="3"/>
<connect gate="B" pin="PK" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6GW8-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
<connect gate="A" pin="TK" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="EF40-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6BK8-P" prefix="V" uservalue="yes">
<gates>
<gate name="G$1" symbol="PENTODE/" x="-10.16" y="-2.54"/>
<gate name="&quot;" symbol="HEATER_1" x="10.16" y="-12.7" addlevel="request"/>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6CA7-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="EL41-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
<connect gate="G$1" pin="PA" pad="2"/>
<connect gate="G$1" pin="PG" pad="6"/>
<connect gate="G$1" pin="PK" pad="7"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6CK5-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="EL42-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6BQ5-P" prefix="V" uservalue="yes">
<gates>
<gate name="G$1" symbol="PENTODE" x="-10.16" y="0"/>
<gate name="&quot;" symbol="HEATER_1" x="7.62" y="-12.7" addlevel="request"/>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="EL86-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6CW5-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="7025-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12DM7-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6680-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6681-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6679-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6201-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6267-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6KX8-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
<connect gate="&quot;" pin="H2" pad="6"/>
<connect gate="A" pin="TA" pad="3"/>
<connect gate="B" pin="TG" pad="9"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6V4" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6CA4" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5931" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6CL6-P" prefix="V" uservalue="yes">
<gates>
<gate name="&quot;" symbol="HEATER_1" x="22.86" y="-12.7" addlevel="request"/>
</gates>
<devices>
<connects>
<connect gate="G$1" pin="PSG" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6922-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5687-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12B4-P" prefix="V" uservalue="yes">
<gates>
<gate name="G$1" symbol="TRIODE" x="-10.16" y="0"/>
<gate name="&quot;" symbol="HEATER_2" x="12.7" y="0" addlevel="request"/>
</gates>
<devices>
<connects>
<connect gate="&quot;" pin="H2" pad="3"/>
<connect gate="G$1" pin="TA" pad="9"/>
<connect gate="G$1" pin="TG" pad="7"/>
<connect gate="G$1" pin="TK" pad="1"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6080-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5691-P" prefix="V" uservalue="yes">
<gates>
<gate name="&quot;" symbol="HEATER_1" x="25.4" y="-10.16" addlevel="request"/>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5692-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ECC34-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ECC35-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6BX7-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="7119-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="E182CC-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="E88CC-P" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIODE1" prefix="V" uservalue="yes">
<gates>
<gate name="G$1" symbol="DIO/" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIODE2" prefix="V" uservalue="yes">
<gates>
<gate name="G$1" symbol="DIO//" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="TRIODE1" prefix="V" uservalue="yes">
<gates>
<gate name="G$1" symbol="TRIO/" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="TETRODE1" prefix="V" uservalue="yes">
<gates>
<gate name="G$1" symbol="TETRO/" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="HEATER1" prefix="V" uservalue="yes">
<gates>
<gate name="G$1" symbol="HEAT/1" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="HEATER2" prefix="V" uservalue="yes">
<gates>
<gate name="G$1" symbol="HEAT/2" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PENTODE1" prefix="V" uservalue="yes">
<gates>
<gate name="G$1" symbol="PENT/" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PENTODE2" prefix="V" uservalue="yes">
<gates>
<gate name="G$1" symbol="PENT//" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="REGULAR1" prefix="V" uservalue="yes">
<gates>
<gate name="G$1" symbol="REGU/" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ABSTIMM1" prefix="V" uservalue="yes">
<gates>
<gate name="G$1" symbol="ABST/" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6C33C-B" prefix="V" uservalue="yes">
<gates>
<gate name="A" symbol="HEATER_1" x="5.08" y="-10.16" addlevel="request"/>
<gate name="B" symbol="HEATER_1" x="20.32" y="-10.16" addlevel="request"/>
</gates>
<devices>
<device name="" package="MSTBV7">
<connects>
<connect gate="A" pin="H1" pad="1"/>
<connect gate="A" pin="H2" pad="2"/>
<connect gate="B" pin="H1" pad="6"/>
<connect gate="B" pin="H2" pad="7"/>
<connect gate="G$1" pin="TA" pad="4"/>
<connect gate="G$1" pin="TK" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="211" prefix="V" uservalue="yes">
<gates>
<gate name="G$1" symbol="TRIODE/" x="0" y="0"/>
</gates>
<devices>
<device name="" package="MSTBV4">
<connects>
<connect gate="G$1" pin="K/H1" pad="2"/>
<connect gate="G$1" pin="K/H2" pad="4"/>
<connect gate="G$1" pin="TG" pad="1"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="VT4" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="845" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="WE300" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
<connect gate="G$1" pin="K/H1" pad="1"/>
<connect gate="G$1" pin="TA" pad="2"/>
<connect gate="G$1" pin="TG" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="TRIODE2" prefix="V" uservalue="yes">
<gates>
<gate name="G$1" symbol="TRIO//" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="2A3" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ECC85" prefix="V">
<gates>
<gate name="G$3" symbol="HEATER_1" x="38.1" y="-5.08"/>
<gate name="G$1" symbol="DUOTRIODE" x="5.08" y="0"/>
</gates>
<devices>
<connects>
<connect gate="G$1" pin="AA" pad="1"/>
<connect gate="G$1" pin="AG" pad="2"/>
<connect gate="G$1" pin="AK" pad="3"/>
<connect gate="G$1" pin="BA" pad="6"/>
<connect gate="G$1" pin="BG" pad="7"/>
<connect gate="G$1" pin="BK" pad="8"/>
<connect gate="G$1" pin="S" pad="9"/>
<connect gate="G$3" pin="H1" pad="4"/>
<connect gate="G$3" pin="H2" pad="5"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DUOTRIODE">
<gates>
<gate name="G$1" symbol="DUOTRIODE" x="-2.54" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="EF183" prefix="V">
<gates>
<gate name="G$3" symbol="HEATER_1" x="27.94" y="10.16"/>
<gate name="&gt;NAME" symbol="PENTODE_1" x="15.24" y="12.7"/>
</gates>
<devices>
<connects>
<connect gate="&gt;NAME" pin="PA" pad="7"/>
<connect gate="&gt;NAME" pin="PBG" pad="9"/>
<connect gate="&gt;NAME" pin="PG" pad="2"/>
<connect gate="&gt;NAME" pin="PK" pad="1 3"/>
<connect gate="&gt;NAME" pin="PS" pad="6"/>
<connect gate="&gt;NAME" pin="PSG" pad="8"/>
<connect gate="G$3" pin="H1" pad="5"/>
<connect gate="G$3" pin="H2" pad="4"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
<compatibility>
<note version="8.5" severity="warning">
Since Version 8.5, EAGLE supports locking for holes, vias, wires and polygons.
The locking property on all objects of these types will not be understood in this version.
</note>
</compatibility>
</eagle>
