 *   ATmega 328 specific global configuration, setup and settings
 *   (c) 2012-2022 by Markus Reschke
 *   based on code from Markus Frejek and Karl-Heinz Kübbeler
/* source management */
#define CONFIG_328_H
 *   display module
 *  display module / controller
 *  Please uncomment the package matching your LCD/OLED module and adjust
 *  settings. And comment out the default package if not used.
 *  To uncomment, remove the enclosing "#if 0" and "#endif" or put
 *  a "//" in front of both. To comment out, remove the "//" in front
 *  of the "#if 0" and "#endif".
 *  Individual settings can be enabled by removing the leading "//", or
 *  disabled by placing a "//" in front of the setting.
 *  HD44780
 *  - 4 bit parallel interface
 *  - if you change LCD_DB4/5/6/7 comment out LCD_DB_STD!
#if 0
#define LCD_HD44780                     /* display controller HD44780 */
#define LCD_TEXT                        /* character display */
#define LCD_PAR_4                       /* 4 bit parallel interface */
/* control and data lines */
#define LCD_PORT         PORTD          /* port data register */
#define LCD_DDR          DDRD           /* port data direction register */
#define LCD_DB_STD                      /* use standard pins 0-3 for DB4-7 */
#define LCD_DB4          PD0            /* port pin used for DB4 */
#define LCD_DB5          PD1            /* port pin used for DB5 */
#define LCD_DB6          PD2            /* port pin used for DB6 */
#define LCD_DB7          PD3            /* port pin used for DB7 */
#define LCD_RS           PD4            /* port pin used for RS */
#define LCD_EN1          PD5            /* port pin used for E */
/* display settings */
#define LCD_CHAR_X       16             /* characters per line */
#define LCD_CHAR_Y       2              /* number of lines */
/* HD44780 has an internal 5x7 font */
#define FONT_HD44780_INT                /* International font (English) */
//#define FONT_HD44780_WIN1251            /* Cyrillic font (European) */
#endif
 *  HD44780 plus PCF8574 based backpack
 *  - I2C interface using bit-bang I2C
 *  - PCF8574T is 0x27, PCF8574AT is 0x3f
#if 0
#define LCD_PCF8574                     /* PCF8574 backpack */
#define LCD_I2C_ADDR     0x3f           /* PCF8574's I2C address */
#define LCD_DB_STD                      /* use standard pins 4-7 for DB4-7 */
#define LCD_DB4          PCF8574_P4     /* port pin used for DB4 */
#define LCD_DB5          PCF8574_P5     /* port pin used for DB5 */
#define LCD_DB6          PCF8574_P6     /* port pin used for DB6 */
#define LCD_DB7          PCF8574_P7     /* port pin used for DB7 */
#define LCD_RS           PCF8574_P0     /* port pin used for RS */
#define LCD_RW           PCF8574_P1     /* port pin used for RW */
#define LCD_EN1          PCF8574_P2     /* port pin used for E */
#define LCD_LED          PCF8574_P3     /* port pin used for backlight */
//#define LCD_BACKLIGHT_LOW               /* backlight is low active */
/* I2C bus */
#define I2C_BITBANG                     /* bit-bang I2C */
#define I2C_STANDARD_MODE               /* 100kHz bus speed */
#define I2C_PORT         PORTD          /* I2C port data register */
#define I2C_DDR          DDRD           /* I2C port data direction register */
#define I2C_PIN          PIND           /* I2C port input pins register */
#define I2C_SDA          PD0            /* port pin used for SDA */
#define I2C_SCL          PD1            /* port pin used for SCL */
#endif
 *  ILI9163
 *  - 4 wire SPI interface using bit-bang SPI
#if 0
#define LCD_ILI9163                     /* display controller ILI9163 */
#define LCD_GRAPHIC                     /* graphic display */
#define LCD_COLOR                       /* color display */
#define LCD_SPI                         /* SPI interface */
#define LCD_RES          PD4            /* port pin used for /RESX (optional) */
#define LCD_CS           PD5            /* port pin used for /CSX (optional) */
#define LCD_DC           PD3            /* port pin used for D/CX */
#define LCD_SCL          PD2            /* port pin used for SCL */
#define LCD_SDA          PD1            /* port pin used for SDA/SDIO */
#define LCD_DOTS_X       128            /* number of horizontal dots */
#define LCD_DOTS_Y       128            /* number of vertical dots */
#define LCD_OFFSET_X      32            /* x offset of 32 dots (160-128) */
//#define LCD_FLIP_X                      /* enable horizontal flip */
#define LCD_FLIP_Y                      /* enable vertical flip */
#define LCD_ROTATE                      /* switch X and Y (rotate by 90°) */
#define LCD_BGR                         /* reverse red and blue color channels */
//#define LCD_LATE_ON                     /* turn on LCD after clearing it */
/* font and symbols: horizonally aligned & flipped */
#define FONT_8X8_HF                     /* 8x8 font */
//#define FONT_10X16_HF                   /* 10x16 font */
//#define FONT_8X8_ISO8859_2_HF           /* 8x8 Central European font */
//#define FONT_8X12T_ISO8859_2_HF         /* thin 8x12 Central European font */
//#define FONT_8X16_ISO8859_2_HF          /* 8x16 Central European font */
//#define FONT_10X16_ISO8859_2_HF         /* 10x16 Central European font */
//#define FONT_8X16_WIN1251_HF            /* 8x16 cyrillic font */
//#define FONT_8X16ALT_WIN1251_HF         /* 8x16 alternative cyrillic font */
#define SYMBOLS_30X32_HF                /* 30x32 symbols */
//#define SYMBOLS_30X32_ALT1_HF           /* 30x32 alternative symbols #1 */
//#define SYMBOLS_30X32_ALT2_HF           /* 30x32 alternative symbols #2 */
//#define SYMBOLS_32X32_HF                /* 32x32 symbols */
//#define SYMBOLS_32X32_ALT1_HF           /* 32x32 alternative symbols #1 */
//#define SYMBOLS_32X32_ALT2_HF           /* 32x32 alternative symbols #2 */
/* SPI bus */
#define SPI_BITBANG                     /* bit-bang SPI */
#define SPI_PORT         LCD_PORT       /* SPI port data register */
#define SPI_DDR          LCD_DDR        /* SPI port data direction register */
#define SPI_SCK          LCD_SCL        /* port pin used for SCK */
#define SPI_MOSI         LCD_SDA        /* port pin used for MOSI */
#endif
 *  ILI9342
 *  - SPI interface using bit-bang SPI
#if 0
#define LCD_ILI9341                     /* display controller ILI9341/ILI9342 */
#define LCD_RES          PD4            /* port pin used for /RES (optional) */
#define LCD_CS           PD5            /* port pin used for /CS (optional) */
#define LCD_DC           PD3            /* port pin used for D/C */
#define LCD_SCK          PD2            /* port pin used for SCK */
#define LCD_SDI          PD1            /* port pin used for SDI (data input) */
//#define LCD_SDO          PD0            /* port pin used for SDO (data output) */
#define LCD_DOTS_X       320            /* number of horizontal dots */
#define LCD_DOTS_Y       240            /* number of vertical dots */
//#define LCD_FLIP_Y                      /* enable vertical flip */
//#define LCD_ROTATE                      /* switch X and Y (rotate by 90°) */
//#define LCD_BGR                         /* reverse red and blue color channels */
//#define LCD_EXT_CMD_OFF                 /* extended commands disabled */
/* font and symbols: horizontally aligned & flipped */
#define FONT_16X26_HF                   /* 16x26 font */
//#define FONT_16X26_ISO8859_2_HF         /* 16x26 Central European font */
//#define FONT_16X26_WIN1251_HF           /* 16x26 cyrillic font */
#define SYMBOLS_32X39_HF                /* 32x39 symbols */
/* SPI bus */
#define SPI_SCK          LCD_SCK        /* port pin used for SCK */
#define SPI_MOSI         LCD_SDI        /* port pin used for MOSI */
#endif
 *  PCD8544
 *  - for a 180° rotated display (LCD_ROT180)
 *    - comment out "_VF" font and "_VFP" symbols
 *    - uncomment "_V_F" font and "_VP_F" symbols
#if 0
#define LCD_PCD8544                     /* display controller PCD8544 */
#define LCD_SCE          PD5            /* port pin used for /SCE (optional) */
#define LCD_SCLK         PD2            /* port pin used for SCLK */
#define LCD_SDIN         PD1            /* port pin used for SDIN (data input) */
#define LCD_DOTS_X       84             /* number of horizontal dots */
#define LCD_DOTS_Y       48             /* number of vertical dots */
#define LCD_CONTRAST     66             /* default contrast (1-127) */
/* font and symbols: vertically aligned & flipped */
#define FONT_6X8_VF                     /* 6x8 font */
//#define FONT_6X8_ISO8859_2_VF         /* 6x8 Central Euopean font */
#define SYMBOLS_24X24_VFP               /* 24x24 symbols */
//#define SYMBOLS_24X24_ALT1_VFP          /* 24x24 alternative symbols #1 */
//#define SYMBOLS_24X24_ALT2_VFP          /* 24x24 alternative symbols #2 */
//#define LCD_ROT180                      /* rotate output by 180° (not supported yet) */
/* font and symbols: vertically aligned, bank-wise grouping, hor. flipped */
//#define FONT_6X8_V_F                    /* 6x8 font */
//#define FONT_6X8_ISO8859_2_V_F          /* 6x8 Central Euopean font */
//#define SYMBOLS_24X24_VP_F              /* 24x24 symbols */
//#define SYMBOLS_24X24_ALT1_VP_F         /* 24x24 alternative symbols #1 */
//#define SYMBOLS_24X24_ALT2_VP_F         /* 24x24 alternative symbols #2 */
/* SPI bus */
#define SPI_SCK          LCD_SCLK       /* port pin used for SCK */
#define SPI_MOSI         LCD_SDIN       /* port pin used for MOSI */
#endif
 *  PCF8814
 *  - 3 wire SPI interface using bit-bang SPI
#if 0
#define LCD_PCF8814                     /* display controller PCF8814 */
#define LCD_RESET        PD4            /* port pin used for /RES */
#define LCD_DOTS_X       96             /* number of horizontal dots */
#define LCD_DOTS_Y       65             /* number of vertical dots */
#define LCD_CONTRAST     5              /* default contrast (0-255) */
/* font and symbols: vertically aligned & flipped, page-wise grouping */
//#define FONT_6X8_ISO8859_2_VF             /* 6x8 Central European font */
/* SPI bus */
#define SPI_9                           /* support 9 bit frames */
#endif
 *  SH1106
 *  - untested
#if 0
#define LCD_SH1106                      /* display controller SH1106 */
#define LCD_RESET        PD4            /* port pin used for /RES (optional) */
#define LCD_A0           PD3            /* port pin used for A0 */
#define LCD_SI           PD1            /* port pin used for SI (data input) */
#define LCD_DOTS_Y       64             /* number of vertical dots */
#define LCD_OFFSET_X     2              /* enable x offset of 2 or 4 dots */
#define LCD_CONTRAST     127            /* default contrast (0-255) */
/* font and symbols: vertically aligned & flipped, bank-wise grouping */
//#define FONT_6X8_VF                      /* 6x8 font */
#define FONT_8X8_VF                     /* 8x8 font */
//#define FONT_8X16_VFP                   /* 8x16 font */
//#define FONT_8X8_ISO8859_2_VF           /* 8x8 Central European font */
//#define FONT_8X12T_ISO8859_2_VFP        /* thin 8x12 Central European font */
//#define FONT_8X16_ISO8859_2_VFP         /* 8x16 Central European font */
//#define FONT_8X8_WIN1251_VF             /* 8x8 cyrillic font */
//#define FONT_8X8ALT_WIN1251_VF          /* 8x8 alternative cyrillic font */
//#define FONT_8X8T_WIN1251_VF            /* thin 8x8 cyrillic font */
//#define FONT_8X12T_WIN1251_VFP          /* thin 8x12 cyrillic font */
//#define FONT_8X16_WIN1251_VFP           /* 8x16 cyrillic font */
/* SPI bus */
#define SPI_MOSI         LCD_SI         /* port pin used for MOSI */
#endif
 *  SH1106
 *  - untested
#if 0
/* SPI bus */
#endif
 *  SH1106
#if 0
#define LCD_I2C                         /* I2C interface */
#define LCD_I2C_ADDR     0x3c           /* SH1106's I2C address */
/* control lines */
//#define LCD_RESET        PD4            /* port pin used for /RES (optional) */
/* I2C bus */
#define I2C_FAST_MODE                   /* 400kHz bus speed */
#endif
 *  SSD1306
#if 0
#define LCD_SSD1306                     /* display controller SSD1306 */
/* SPI bus */
#endif
 *  SSD1306
#if 0
/* SPI bus */
#endif
 *  SSD1306
#if 0
#define LCD_I2C_ADDR     0x3c           /* SSD1306's I2C address */
/* control lines */
/* I2C bus */
#endif
 *  ST7036
 *  - enable LCD_DB_STD when using port pins 0-3 for LCD_DB4/5/6/7
 *  - untested!!!
#if 0
#define LCD_ST7036                      /* display controller ST7036 */
//#define LCD_DB_STD                      /* use standard pins 0-3 for DB4-7 */
#define LCD_EN           PD5            /* port pin used for E */
//#define LCD_RW           ???            /* port pin used for R/W (optional) */
//#define LCD_RESET        ???            /* port pin used for XRESET (optional) */
#define LCD_CHAR_Y       3              /* number of lines */
#define LCD_EXTENDED_CMD                /* extended instruction set (EXT pin high) */
#define LCD_CONTRAST     32             /* default contrast (0-63) */
/* ST7036 has internal 5x8 font */
#define FONT_ST7036                     /* 5x8 font */
#endif
 *  ST7036
 *  - untested!!!
#if 0
#define LCD_RESET        PD4            /* port pin used for XRESET (optional) */
#define LCD_CS           PD5            /* port pin used for CSB (optional) */
#define LCD_RS           PD3            /* port pin used for RS */
/* SPI bus */
#endif
 *  ST7565R
 *  - settings for Electronic Assembly EA DOGM/DOGL128-6
 *  - uses LCD_CS to support rotary encoder in parallel at PD2/3
#if 0
#define LCD_ST7565R                     /* display controller ST7565R */
#define LCD_RESET        PD0            /* port pin used for /RES (optional) */
#define LCD_CS           PD5            /* port pin used for /CS1 (optional) */
#define LCD_A0           PD1            /* port pin used for A0 */
#define LCD_SI           PD3            /* port pin used for SI (data input) */
#define LCD_OFFSET_X                    /* enable x offset of 4 dots */
#define LCD_START_Y      0              /* start line (0-63) */
#define LCD_CONTRAST     22             /* default contrast (0-63) */
/* SPI bus */
#endif
 *  ST7735
//#if 0
#define LCD_ST7735                      /* display controller ST7735 */
#define LCD_RES          PD0            /* port pin used for /RESX (optional) */
#define LCD_DC           PD1            /* port pin used for D/CX */
#define LCD_SDA          PD3            /* port pin used for SDA */
#define LCD_DOTS_Y       160            /* number of vertical dots */
//#define LCD_OFFSET_X     4               /* enable x offset of 2 or 4 dots */
//#define LCD_OFFSET_Y     2               /* enable y offset of 1 or 2 dots */
//#define FONT_6X8_ISO8859_2_HF           /* 6x8 Central European font */
//#define SYMBOLS_30X32_HF                /* 30x32 symbols */
/* SPI bus */
//#endif
//For the ST7735 semi-compatible display use:
#if 0
#define LCD_SEMI_ST7735
#define LCD_RES          PD0            /* port pin used for /RESX */
#define LCD_DOTS_X       160            /* number of horizontal dots */
#endif
 *  ST7920
 *    - comment out "_H" font and symbols
 *    - uncomment "_HF" font and symbols
#if 0
#define LCD_ST7920                      /* display controller ST7920 */
#define LCD_RESET        PD4            /* port pin used for /RESET (optional) */
#define LCD_CS           PD5            /* port pin used for CS (optional) */
#define LCD_SID          PD1            /* port pin used for SID (data input) */
/* font and symbols: horizonally aligned */
#define FONT_8X8_H                      /* 8x8 font  */
//#define FONT_8X8_ISO8859_2_H            /* 8x8 Central European font */
#define SYMBOLS_24X24_H                 /* 24x24 symbols */
//#define SYMBOLS_24X24_ALT1_H            /* alternative 24x24 symbols #1 */
//#define SYMBOLS_24X24_ALT2_H            /* alternative 24x24 symbols #2 */
//#define LCD_ROT180                      /* rotate output by 180° */
//#define FONT_8X8_HF                     /* 8x8 font */
//#define SYMBOLS_24X24_HF                /* 24x24 symbols */
//#define SYMBOLS_24X24_ALT1_HF           /* alternative 24x24 symbols #1 */
//#define SYMBOLS_24X24_ALT2_HF           /* alternative 24x24 symbols #2 */
/* SPI bus */
#define SPI_MOSI         LCD_SID        /* port pin used for MOSI */
#endif
 *  ST7920
#if 0
//#define LCD_RW           PD?            /* port pin used for RW (optional) */
//#define LCD_RESET        PD?            /* port pin used for /RESET (optional) */
#endif
 *  STE2007
#if 0
#define LCD_STE2007                     /* display controller STE2007 */
#define LCD_DOTS_Y       68             /* number of vertical dots */
#define LCD_CONTRAST     16             /* default contrast (0-31) */
/* SPI bus */
#endif
 *  VT100 serial terminal, TTL serial
#if 0
#define LCD_VT100                       /* pseudo display VT100 */
#define LCD_CHAR_X       40             /* characters per line */
#define LCD_CHAR_Y       24             /* number of lines */
#define SERIAL_BITBANG                  /* bit-bang serial */
//#define SERIAL_HARDWARE                 /* hardware serial */
#endif
 *  check if a LCD module is specified
#if !defined(LCD_TEXT) && !defined(LCD_GRAPHIC)
  #error <<< No LCD module specified! >>>
#endif
 *   port and pin assignments
 *  test pins / probes:
 *  - Must be an ADC port
 *  - Lower 3 pins of the port must be used for probes.
 *  - Please don't change the definitions of TP1, TP2 and TP3!
 *  - Don't share this port with POWER_CTRL or TEST_BUTTON!
#define ADC_PORT         PORTC     /* port data register */
#define ADC_DDR          DDRC      /* port data direction register */
#define ADC_PIN          PINC      /* port input pins register */
#define TP1              PC0       /* test pin / probe #1 */
#define TP2              PC1       /* test pin / probe #2 */
#define TP3              PC2       /* test pin / probe #3 */
#define TP_ZENER         PC3       /* test pin for for Zener check (10:1 voltage divider) */
#define TP_REF           PC4       /* test pin for 2.5V reference and relay */
#define TP_BAT           PC5       /* test pin for battery (4:1 voltage divider) */
#define TP_LOGIC         PC3       /* test pin for Logic Probe (4:1 voltage divider) */
 *  probe resistors
 *  - For PWM/squarewave output via probe #2 R_RL_2 has to be PB2/OC1B.
#define R_PORT           PORTB     /* port data register */
#define R_DDR            DDRB      /* port data direction register */
#define R_RL_1           PB0       /* Rl (680R) for test pin #1 */
#define R_RH_1           PB1       /* Rh (470k) for test pin #1 */
#define R_RL_2           PB2       /* Rl (680R) for test pin #2 */
#define R_RH_2           PB3       /* Rh (470k) for test pin #2 */
#define R_RL_3           PB4       /* Rl (680R) for test pin #3 */
#define R_RH_3           PB5       /* Rh (470k) for test pin #3 */
 *  dedicated signal output via OC1B
 *  - don't change this!
#define SIGNAL_PORT      PORTB     /* port data register */
#define SIGNAL_DDR       DDRB      /* port data direction register */
#define SIGNAL_OUT       PB2       /* MCU's OC1B pin */
 *  power control
 *  - can't be same port as ADC_PORT or R_PORT
#define POWER_PORT       PORTD     /* port data register */
#define POWER_DDR        DDRD      /* port data direction register */
#define POWER_CTRL       PD6       /* control pin (1: on / 0: off) */
 *  test push button
#define BUTTON_PORT      PORTD     /* port data register */
#define BUTTON_DDR       DDRD      /* port data direction register */
#define BUTTON_PIN       PIND      /* port input pins register */
#define TEST_BUTTON      PD7       /* test/start push button (low active) */
 *  rotary encoder
#define ENCODER_PORT     PORTD     /* port data register */
#define ENCODER_DDR      DDRD      /* port data direction register */
#define ENCODER_PIN      PIND      /* port input pins register */
#define ENCODER_A        PD3       /* rotary encoder A signal */
#define ENCODER_B        PD1       /* rotary encoder B signal */
 *  increase/decrease push buttons
#define KEY_PORT         PORTD     /* port data register */
#define KEY_DDR          DDRD      /* port data direction register */
#define KEY_PIN          PIND      /* port input pins register */
#define KEY_INC          PD2       /* increase push button (low active) */
#define KEY_DEC          PD3       /* decrease push button (low active) */
 *  frequency counter
 *  - input must be pin PD4/T0
#define COUNTER_PORT     PORTD     /* port data register */
#define COUNTER_DDR      DDRD      /* port data direction register */
#define COUNTER_IN       PD4       /* signal input T0 */
 *  ring tester
 *  - counter input must be pin PD4/T0 (uses COUNTER_IN)
#define RINGTESTER_PORT  PORTD     /* port data register */
#define RINGTESTER_DDR   DDRD      /* port data direction register */
#define RINGTESTER_OUT   PD5       /* pulse output */
 *  IR detector/decoder
 *  - fixed module connected to dedicated I/O pin
#define IR_PORT          PORTD     /* port data register */
#define IR_DDR           DDRD      /* port data direction register */
#define IR_PIN           PIND      /* port input pins register */
#define IR_DATA          PD5       /* data signal */
 *  SPI
 *  - hardware SPI uses
 *    SCK PB5, MOSI PB3, MISO PB4 and /SS PB2
 *  - could be already set in display section
 *  - unused signals can be ignored
 *  - /SS is set to output mode for hardware SPI but not used
/* for bit-bang and hardware SPI */
#ifndef SPI_PORT
#define SPI_PORT         PORTB     /* port data register */
#define SPI_DDR          DDRB      /* port data direction register */
#define SPI_PIN          PINB      /* port input pins register */
#define SPI_SCK          PB5       /* pin for SCK */
#define SPI_MOSI         PB3       /* pin for MOSI */
#define SPI_MISO         PB4       /* pin for MISO */
#define SPI_SS           PB2       /* pin for /SS */
#endif
 *  I2C
 *  - hardware I2C (TWI) uses
 *    SDA PC4 and SCL PC5
/* for bit-bang I2C */
#ifndef I2C_PORT
#define I2C_PORT         PORTC     /* port data register */
#define I2C_DDR          DDRC      /* port data direction register */
#define I2C_PIN          PINC      /* port input pins register */
#define I2C_SDA          PC4       /* pin for SDA */
#define I2C_SCL          PC5       /* pin for SCL */
#endif
 *  TTL serial interface
 *  - hardware USART uses
 *    USART0: Rx PD0 and Tx PD1
/* for hardware RS232 */
#define SERIAL_USART     0         /* use USART0 */
/* for bit-bang RS232 */
#define SERIAL_PORT      PORTD     /* port data register */
#define SERIAL_DDR       DDRD      /* port data direction register */
#define SERIAL_PIN       PIND      /* port input pins register */
#define SERIAL_TX        PD1       /* pin for Tx (transmit) */
#define SERIAL_RX        PD0       /* pin for Rx (receive) */
#define SERIAL_PCINT     16        /* PCINT# for Rx pin */
 *  OneWire
 *  - dedicated I/O pin
#define ONEWIRE_PORT     PORTD     /* port data register */
#define ONEWIRE_DDR      DDRD      /* port data direction register */
#define ONEWIRE_PIN      PIND      /* port input pins register */
#define ONEWIRE_DQ       PD5       /* DQ (data line) */
 *  buzzer
#define BUZZER_PORT      PORTD     /* port data register */
#define BUZZER_DDR       DDRD      /* port data direction register */
#define BUZZER_CTRL      PD5       /* control pin (low: off / high: on) */
 *  MAX6675
#define MAX6675_PORT     PORTD     /* port data register */
#define MAX6675_DDR      DDRD      /* port data direction register */
#define MAX6675_CS       PD5       /* port pin used for /CS */
 *  MAX31855
#define MAX31855_PORT    PORTD     /* port data register */
#define MAX31855_DDR     DDRD      /* port data direction register */
#define MAX31855_CS      PD5       /* port pin used for /CS */
 *   internal stuff
/* ADC reference selection: AVcc */
#define ADC_REF_VCC           (1 << REFS0)
/* ADC reference selection: internal 1.1V bandgap */
#define ADC_REF_BANDGAP       ((1 << REFS1) | (1 << REFS0))
/* ADC reference selection: filter mask for register bits */
#define ADC_REF_MASK          ((1 << REFS1) | (1 << REFS0))
/* ADC MUX channel: internal 1.1V bandgap reference */
#define ADC_CHAN_BANDGAP      0x0e      /* 1110 */
/* ADC MUX channel: filter mask for register bits */
#define ADC_CHAN_MASK         0b00001111     /* MUX0-3 */
 *   MCU specific setup to support different AVRs
 *  ATmega 328/328P
#if defined(__AVR_ATmega328__)
  /* estimated internal resistance of port to GND (in 0.1 Ohms) */
  #define R_MCU_LOW           200
  /* estimated internal resistance of port to VCC (in 0.1 Ohms) */
  #define R_MCU_HIGH          220
  /* voltage offset of MCU's analog comparator (in mV): -50 up to 50 */
  #define COMPARATOR_OFFSET   0
  /* this MCU has 32kB Flash, 1kB EEPROM and 2kB RAM (enable extra features) */
  #define RES_FLASH           32
  #define RES_EEPROM          1
  #define RES_RAM             2
 *  missing or unsupported MCU
#else
  #error <<< No or wrong MCU type selected! >>>
#endif
 *   EOF
