#MicroXplorer Configuration settings - do not modify ADC1.Channel-2\#ChannelRegularConversion=ADC_CHANNEL_1 ADC1.IPParameters=Rank-2\#ChannelRegularConversion,Channel-2\#ChannelRegularConversion,SamplingTime-2\#ChannelRegularConversion,NbrOfConversionFlag,master ADC1.NbrOfConversionFlag=1 ADC1.Rank-2\#ChannelRegularConversion=1 ADC1.SamplingTime-2\#ChannelRegularConversion=ADC_SAMPLETIME_1CYCLE_5 ADC1.master=1 CAD.formats= CAD.pinconfig= CAD.provider= Dma.I2C1_RX.0.Direction=DMA_PERIPH_TO_MEMORY Dma.I2C1_RX.0.Instance=DMA1_Channel7 Dma.I2C1_RX.0.MemDataAlignment=DMA_MDATAALIGN_BYTE Dma.I2C1_RX.0.MemInc=DMA_MINC_ENABLE Dma.I2C1_RX.0.Mode=DMA_NORMAL Dma.I2C1_RX.0.PeriphDataAlignment=DMA_PDATAALIGN_BYTE Dma.I2C1_RX.0.PeriphInc=DMA_PINC_DISABLE Dma.I2C1_RX.0.Priority=DMA_PRIORITY_LOW Dma.I2C1_RX.0.RequestParameters=Instance,Direction,PeriphInc,MemInc,PeriphDataAlignment,MemDataAlignment,Mode,Priority Dma.I2C1_TX.1.Direction=DMA_MEMORY_TO_PERIPH Dma.I2C1_TX.1.Instance=DMA1_Channel6 Dma.I2C1_TX.1.MemDataAlignment=DMA_MDATAALIGN_BYTE Dma.I2C1_TX.1.MemInc=DMA_MINC_ENABLE Dma.I2C1_TX.1.Mode=DMA_NORMAL Dma.I2C1_TX.1.PeriphDataAlignment=DMA_PDATAALIGN_BYTE Dma.I2C1_TX.1.PeriphInc=DMA_PINC_DISABLE Dma.I2C1_TX.1.Priority=DMA_PRIORITY_LOW Dma.I2C1_TX.1.RequestParameters=Instance,Direction,PeriphInc,MemInc,PeriphDataAlignment,MemDataAlignment,Mode,Priority Dma.Request0=I2C1_RX Dma.Request1=I2C1_TX Dma.RequestsNb=2 File.Version=6 GPIO.groupedBy=Group By Peripherals I2C1.ClockSpeed=10000 I2C1.IPParameters=ClockSpeed KeepUserPlacement=false Mcu.CPN=STM32F103C8T6 Mcu.Family=STM32F1 Mcu.IP0=ADC1 Mcu.IP1=DMA Mcu.IP2=I2C1 Mcu.IP3=NVIC Mcu.IP4=RCC Mcu.IP5=RTC Mcu.IP6=SYS Mcu.IP7=TIM2 Mcu.IP8=USART1 Mcu.IPNb=9 Mcu.Name=STM32F103C(8-B)Tx Mcu.Package=LQFP48 Mcu.Pin0=PC13-TAMPER-RTC Mcu.Pin1=PC14-OSC32_IN Mcu.Pin10=PA13 Mcu.Pin11=PA14 Mcu.Pin12=PB6 Mcu.Pin13=PB7 Mcu.Pin14=VP_ADC1_TempSens_Input Mcu.Pin15=VP_RTC_VS_RTC_Activate Mcu.Pin16=VP_RTC_VS_RTC_Calendar Mcu.Pin17=VP_SYS_VS_Systick Mcu.Pin18=VP_TIM2_VS_ClockSourceINT Mcu.Pin19=VP_TIM2_VS_no_output1 Mcu.Pin2=PC15-OSC32_OUT Mcu.Pin20=VP_TIM2_VS_no_output2 Mcu.Pin21=VP_TIM2_VS_no_output3 Mcu.Pin22=VP_TIM2_VS_no_output4 Mcu.Pin3=PD0-OSC_IN Mcu.Pin4=PD1-OSC_OUT Mcu.Pin5=PA1 Mcu.Pin6=PB11 Mcu.Pin7=PA8 Mcu.Pin8=PA9 Mcu.Pin9=PA10 Mcu.PinsNb=23 Mcu.ThirdPartyNb=0 Mcu.UserConstants= Mcu.UserName=STM32F103C8Tx MxCube.Version=6.8.0 MxDb.Version=DB.6.0.80 NVIC.BusFault_IRQn=true\:0\:0\:false\:false\:true\:false\:false\:false NVIC.DMA1_Channel6_IRQn=true\:0\:0\:false\:false\:true\:false\:true\:true NVIC.DMA1_Channel7_IRQn=true\:0\:0\:false\:false\:true\:false\:true\:true NVIC.DebugMonitor_IRQn=true\:0\:0\:false\:false\:true\:false\:false\:false NVIC.ForceEnableDMAVector=true NVIC.HardFault_IRQn=true\:0\:0\:false\:false\:true\:false\:false\:false NVIC.MemoryManagement_IRQn=true\:0\:0\:false\:false\:true\:false\:false\:false NVIC.NonMaskableInt_IRQn=true\:0\:0\:false\:false\:true\:false\:false\:false NVIC.PendSV_IRQn=true\:0\:0\:false\:false\:true\:false\:false\:false NVIC.PriorityGroup=NVIC_PRIORITYGROUP_4 NVIC.SVCall_IRQn=true\:0\:0\:false\:false\:true\:false\:false\:false NVIC.SysTick_IRQn=true\:15\:0\:false\:false\:true\:false\:true\:false NVIC.TIM2_IRQn=true\:0\:0\:false\:false\:true\:true\:true\:true NVIC.USART1_IRQn=true\:0\:0\:false\:false\:true\:true\:true\:true NVIC.UsageFault_IRQn=true\:0\:0\:false\:false\:true\:false\:false\:false PA1.GPIOParameters=GPIO_Label PA1.GPIO_Label=AdCh_Utap PA1.Locked=true PA1.Signal=ADCx_IN1 PA10.GPIOParameters=GPIO_PuPd,GPIO_Label PA10.GPIO_Label=PcCom_Rx PA10.GPIO_PuPd=GPIO_PULLUP PA10.Mode=Asynchronous PA10.Signal=USART1_RX PA13.Mode=Serial_Wire PA13.Signal=SYS_JTMS-SWDIO PA14.Mode=Serial_Wire PA14.Signal=SYS_JTCK-SWCLK PA8.GPIOParameters=GPIO_Label PA8.GPIO_Label=PcCom_TxEn PA8.Locked=true PA8.Signal=GPIO_Output PA9.GPIOParameters=GPIO_Label PA9.GPIO_Label=PcCom_Tx PA9.Mode=Asynchronous PA9.Signal=USART1_TX PB11.GPIOParameters=GPIO_Label PB11.GPIO_Label=TestOscOut PB11.Locked=true PB11.Signal=GPIO_Output PB6.GPIOParameters=GPIO_Label PB6.GPIO_Label=i2c_Clk PB6.Mode=I2C PB6.Signal=I2C1_SCL PB7.GPIOParameters=GPIO_Label PB7.GPIO_Label=i2c_Data PB7.Mode=I2C PB7.Signal=I2C1_SDA PC13-TAMPER-RTC.GPIOParameters=GPIO_Label PC13-TAMPER-RTC.GPIO_Label=PanelLed PC13-TAMPER-RTC.Locked=true PC13-TAMPER-RTC.Signal=GPIO_Output PC14-OSC32_IN.Mode=LSE-External-Oscillator PC14-OSC32_IN.Signal=RCC_OSC32_IN PC15-OSC32_OUT.Mode=LSE-External-Oscillator PC15-OSC32_OUT.Signal=RCC_OSC32_OUT PD0-OSC_IN.Mode=HSE-External-Oscillator PD0-OSC_IN.Signal=RCC_OSC_IN PD1-OSC_OUT.Mode=HSE-External-Oscillator PD1-OSC_OUT.Signal=RCC_OSC_OUT PinOutPanel.RotationAngle=0 ProjectManager.AskForMigrate=true ProjectManager.BackupPrevious=false ProjectManager.CompilerOptimize=6 ProjectManager.ComputerToolchain=false ProjectManager.CoupleFile=false ProjectManager.CustomerFirmwarePackage= ProjectManager.DefaultFWLocation=true ProjectManager.DeletePrevious=true ProjectManager.DeviceId=STM32F103C8Tx ProjectManager.FirmwarePackage=STM32Cube FW_F1 V1.8.4 ProjectManager.FreePins=false ProjectManager.HalAssertFull=false ProjectManager.HeapSize=0x200 ProjectManager.KeepUserCode=true ProjectManager.LastFirmware=true ProjectManager.LibraryCopy=1 ProjectManager.MainLocation=Core/Src ProjectManager.NoMain=false ProjectManager.PreviousToolchain=STM32CubeIDE ProjectManager.ProjectBuild=false ProjectManager.ProjectFileName=redony_i2c.ioc ProjectManager.ProjectName=redony_i2c ProjectManager.ProjectStructure= ProjectManager.RegisterCallBack= ProjectManager.StackSize=0x400 ProjectManager.TargetToolchain=STM32CubeIDE ProjectManager.ToolChainLocation= ProjectManager.UnderRoot=true ProjectManager.functionlistsort=1-SystemClock_Config-RCC-false-HAL-false,2-MX_GPIO_Init-GPIO-false-HAL-true,3-MX_DMA_Init-DMA-false-HAL-true,4-MX_I2C1_Init-I2C1-false-HAL-true,5-MX_USART1_UART_Init-USART1-false-HAL-true,6-MX_ADC1_Init-ADC1-false-HAL-true,7-MX_TIM2_Init-TIM2-false-HAL-true RCC.ADCFreqValue=8000000 RCC.ADCPresc=RCC_ADCPCLK2_DIV8 RCC.AHBFreq_Value=64000000 RCC.APB1CLKDivider=RCC_HCLK_DIV2 RCC.APB1Freq_Value=32000000 RCC.APB1TimFreq_Value=64000000 RCC.APB2Freq_Value=64000000 RCC.APB2TimFreq_Value=64000000 RCC.FCLKCortexFreq_Value=64000000 RCC.FamilyName=M RCC.HCLKFreq_Value=64000000 RCC.IPParameters=ADCFreqValue,ADCPresc,AHBFreq_Value,APB1CLKDivider,APB1Freq_Value,APB1TimFreq_Value,APB2Freq_Value,APB2TimFreq_Value,FCLKCortexFreq_Value,FamilyName,HCLKFreq_Value,MCOFreq_Value,PLLCLKFreq_Value,PLLMCOFreq_Value,PLLMUL,RTCClockSelection,RTCFreq_Value,SYSCLKFreq_VALUE,SYSCLKSource,TimSysFreq_Value,USBFreq_Value RCC.MCOFreq_Value=64000000 RCC.PLLCLKFreq_Value=64000000 RCC.PLLMCOFreq_Value=32000000 RCC.PLLMUL=RCC_PLL_MUL16 RCC.RTCClockSelection=RCC_RTCCLKSOURCE_LSE RCC.RTCFreq_Value=32768 RCC.SYSCLKFreq_VALUE=64000000 RCC.SYSCLKSource=RCC_SYSCLKSOURCE_PLLCLK RCC.TimSysFreq_Value=64000000 RCC.USBFreq_Value=64000000 RTC.Date=7 RTC.Hours=15 RTC.IPParameters=Hours,Minutes,Month,Date,WeekDay RTC.Minutes=30 RTC.Month=RTC_MONTH_APRIL RTC.WeekDay=RTC_WEEKDAY_FRIDAY SH.ADCx_IN1.0=ADC1_IN1,IN1 SH.ADCx_IN1.ConfNb=1 TIM2.Channel-Output\ Compare1\ No\ Output=TIM_CHANNEL_1 TIM2.Channel-Output\ Compare2\ No\ Output=TIM_CHANNEL_2 TIM2.Channel-Output\ Compare3\ No\ Output=TIM_CHANNEL_3 TIM2.Channel-Output\ Compare4\ No\ Output=TIM_CHANNEL_4 TIM2.IPParameters=Prescaler,Period,Channel-Output Compare1 No Output,Channel-Output Compare2 No Output,Channel-Output Compare3 No Output,Channel-Output Compare4 No Output,Pulse-Output Compare1 No Output,Pulse-Output Compare2 No Output,Pulse-Output Compare3 No Output,Pulse-Output Compare4 No Output TIM2.Period=1000 TIM2.Prescaler=63999 TIM2.Pulse-Output\ Compare1\ No\ Output=10 TIM2.Pulse-Output\ Compare2\ No\ Output=100 TIM2.Pulse-Output\ Compare3\ No\ Output=200 TIM2.Pulse-Output\ Compare4\ No\ Output=500 USART1.BaudRate=19200 USART1.IPParameters=VirtualMode,BaudRate,StopBits USART1.StopBits=STOPBITS_2 USART1.VirtualMode=VM_ASYNC VP_ADC1_TempSens_Input.Mode=IN-TempSens VP_ADC1_TempSens_Input.Signal=ADC1_TempSens_Input VP_RTC_VS_RTC_Activate.Mode=RTC_Enabled VP_RTC_VS_RTC_Activate.Signal=RTC_VS_RTC_Activate VP_RTC_VS_RTC_Calendar.Mode=RTC_Calendar VP_RTC_VS_RTC_Calendar.Signal=RTC_VS_RTC_Calendar VP_SYS_VS_Systick.Mode=SysTick VP_SYS_VS_Systick.Signal=SYS_VS_Systick VP_TIM2_VS_ClockSourceINT.Mode=Internal VP_TIM2_VS_ClockSourceINT.Signal=TIM2_VS_ClockSourceINT VP_TIM2_VS_no_output1.Mode=Output Compare1 No Output VP_TIM2_VS_no_output1.Signal=TIM2_VS_no_output1 VP_TIM2_VS_no_output2.Mode=Output Compare2 No Output VP_TIM2_VS_no_output2.Signal=TIM2_VS_no_output2 VP_TIM2_VS_no_output3.Mode=Output Compare3 No Output VP_TIM2_VS_no_output3.Signal=TIM2_VS_no_output3 VP_TIM2_VS_no_output4.Mode=Output Compare4 No Output VP_TIM2_VS_no_output4.Signal=TIM2_VS_no_output4 board=custom isbadioc=false
