<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="9.5.2">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting keepoldvectorfont="yes"/>
<setting verticaltext="up"/>
</settings>
<grid distance="12.5" unitdist="mil" unit="mil" style="dots" multiple="8" display="no" altdistance="0.025" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="no" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="50" name="dxf" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="53" name="tPadExt" color="7" fill="1" visible="no" active="no"/>
<layer number="54" name="bPadExt" color="1" fill="1" visible="no" active="no"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
<layer number="101" name="Hidden" color="15" fill="1" visible="yes" active="yes"/>
<layer number="102" name="Changes" color="12" fill="1" visible="yes" active="yes"/>
<layer number="200" name="200bmp" color="1" fill="10" visible="no" active="yes"/>
<layer number="211" name="tLogo" color="7" fill="1" visible="yes" active="yes"/>
<layer number="212" name="bLogo" color="7" fill="1" visible="yes" active="yes"/>
<layer number="250" name="Descript" color="3" fill="1" visible="no" active="no"/>
<layer number="251" name="SMDround" color="12" fill="11" visible="no" active="no"/>
</layers>
<board>
<plain>
<wire x1="-111.125" y1="50.165" x2="12.3825" y2="50.165" width="0.254" layer="20"/>
<wire x1="12.3825" y1="50.165" x2="12.3825" y2="95.885" width="0.254" layer="20"/>
<wire x1="12.3825" y1="95.885" x2="-111.125" y2="95.885" width="0.254" layer="20"/>
<wire x1="-111.125" y1="95.885" x2="-111.125" y2="50.165" width="0.254" layer="20"/>
<text x="-9.2075" y="75.565" size="2.1844" layer="16" ratio="10" rot="MR0">+</text>
<text x="0.635" y="75.8825" size="2.1844" layer="16" ratio="10" rot="MR0">-</text>
<text x="-66.9925" y="89.535" size="1.778" layer="16" ratio="10" rot="MR0">GND</text>
<text x="-71.12" y="80.3275" size="1.778" layer="16" ratio="10" rot="MR0">C</text>
<text x="-68.8975" y="76.835" size="1.778" layer="16" ratio="10" rot="MR0">ELKO</text>
<text x="-29.845" y="93.0275" size="1.778" layer="16" ratio="10" rot="MR0">L/C</text>
<text x="-106.3625" y="70.8025" size="1.778" layer="21" rot="R90">PROG</text>
<text x="-20.0025" y="53.34" size="1.778" layer="21">LCM-3 Skori-mod</text>
</plain>
<libraries>
<library name="01_LCM3">
<packages>
<package name="MTB-086">
<description>&lt;b&gt;LCD kijelzö (DEM16217)&lt;/b&gt;
&lt;p&gt;2x16-os
&lt;p&gt;Adatlap: http://www.maplin.co.uk/media/pdfs/N27AZ.pdf
&lt;p&gt;&lt;i&gt;http://www.pa-elektronika.fw.hu&lt;/i&gt;</description>
<wire x1="0" y1="0" x2="122" y2="0" width="0.127" layer="21"/>
<wire x1="122" y1="0" x2="122" y2="16" width="0.127" layer="21"/>
<wire x1="122" y1="16" x2="122" y2="44" width="0.127" layer="21"/>
<wire x1="122" y1="44" x2="12" y2="44" width="0.127" layer="21"/>
<wire x1="12" y1="44" x2="0" y2="44" width="0.127" layer="21"/>
<wire x1="0" y1="44" x2="0" y2="0" width="0.127" layer="21"/>
<wire x1="8" y1="41.5" x2="8" y2="6" width="0.127" layer="21"/>
<wire x1="114" y1="41.5" x2="114" y2="6" width="0.127" layer="21"/>
<wire x1="8" y1="41.5" x2="114" y2="41.5" width="0.127" layer="21"/>
<wire x1="8" y1="6" x2="114" y2="6" width="0.127" layer="21"/>
<wire x1="11" y1="35.5" x2="11" y2="12" width="0.127" layer="21"/>
<wire x1="111" y1="35.5" x2="111" y2="12" width="0.127" layer="21"/>
<wire x1="11" y1="35.5" x2="111" y2="35.5" width="0.127" layer="21"/>
<wire x1="11" y1="12" x2="111" y2="12" width="0.127" layer="21"/>
<pad name="14" x="10.922" y="2.54" drill="0.9" diameter="1.9304" shape="square"/>
<pad name="13" x="13.462" y="2.54" drill="0.9" diameter="1.9304" shape="square"/>
<pad name="12" x="16.002" y="2.54" drill="0.9" diameter="1.9304" shape="square"/>
<pad name="11" x="18.542" y="2.54" drill="0.9" diameter="1.9304" shape="square"/>
<pad name="10" x="21.082" y="2.54" drill="0.9" diameter="1.9304" shape="square"/>
<pad name="9" x="23.622" y="2.54" drill="0.9" diameter="1.9304" shape="square"/>
<pad name="8" x="26.162" y="2.54" drill="0.9" diameter="1.9304" shape="square"/>
<pad name="7" x="28.702" y="2.54" drill="0.9" diameter="1.9304" shape="square"/>
<pad name="6" x="31.242" y="2.54" drill="0.9" diameter="1.9304" shape="square"/>
<pad name="5" x="33.782" y="2.54" drill="0.9" diameter="1.9304" shape="square"/>
<pad name="4" x="36.322" y="2.54" drill="0.9" diameter="1.9304" shape="square"/>
<pad name="3" x="38.862" y="2.54" drill="0.9" diameter="1.9304" shape="square"/>
<pad name="2" x="41.402" y="2.54" drill="0.9" diameter="1.9304" shape="square"/>
<pad name="1" x="43.942" y="2.54" drill="0.9" diameter="1.9304" shape="square"/>
<pad name="15" x="46.482" y="2.54" drill="0.9" diameter="1.9304" shape="square"/>
<pad name="16" x="49.022" y="2.54" drill="0.9" diameter="1.9304" shape="square"/>
<text x="43.652" y="4.13" size="1.27" layer="21" ratio="0">1</text>
<text x="12.386" y="33.054" size="1.27" layer="25">&gt;Name</text>
<text x="12.386" y="31.014" size="1.27" layer="27">&gt;Value</text>
<text x="45.902" y="4.13" size="1.27" layer="21">L-</text>
<text x="48.402" y="4.13" size="1.27" layer="21">L+</text>
<text x="10.152" y="4.13" size="1.27" layer="21">14</text>
<hole x="3.5" y="3.5" drill="3.2"/>
<hole x="3.5" y="40.5" drill="3.2"/>
<hole x="118.5" y="40.5" drill="3.2"/>
<hole x="118.5" y="3.5" drill="3.2"/>
</package>
<package name="M9040P2B">
<description>&lt;b&gt;TOGGLE SWITCH&lt;/b&gt;&lt;p&gt;
Marquardt</description>
<wire x1="-5.6642" y1="6.6802" x2="-6.2992" y2="6.0452" width="0.1524" layer="21"/>
<wire x1="-5.6642" y1="6.6802" x2="5.6642" y2="6.6802" width="0.1524" layer="21"/>
<wire x1="6.2992" y1="6.0452" x2="5.6642" y2="6.6802" width="0.1524" layer="21"/>
<wire x1="5.6642" y1="-6.6802" x2="6.2992" y2="-6.0452" width="0.1524" layer="21"/>
<wire x1="5.6642" y1="-6.6802" x2="-5.6642" y2="-6.6802" width="0.1524" layer="21"/>
<wire x1="-6.2992" y1="-6.0452" x2="-5.6642" y2="-6.6802" width="0.1524" layer="21"/>
<wire x1="6.2992" y1="6.0452" x2="6.2992" y2="-6.0452" width="0.1524" layer="21"/>
<wire x1="-6.2992" y1="-6.0452" x2="-6.2992" y2="6.0452" width="0.1524" layer="21"/>
<wire x1="4.318" y1="2.286" x2="4.318" y2="-2.286" width="0.1524" layer="51"/>
<wire x1="-4.318" y1="2.286" x2="-4.318" y2="-2.286" width="0.1524" layer="51"/>
<wire x1="4.318" y1="2.286" x2="0" y2="5.08" width="0.1524" layer="51"/>
<wire x1="0" y1="5.08" x2="-4.318" y2="2.286" width="0.1524" layer="51"/>
<wire x1="-4.318" y1="-2.286" x2="0" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="0" y1="-5.08" x2="4.318" y2="-2.286" width="0.1524" layer="51"/>
<wire x1="1.905" y1="-1.27" x2="2.54" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="1.905" y1="-3.175" x2="2.54" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="1.905" y1="-3.175" x2="-1.905" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-2.54" x2="-1.905" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-2.54" x2="-2.54" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="-1.905" y1="-1.27" x2="-2.54" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="-1.905" y1="-1.27" x2="1.905" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="1.6002" y1="1.27" x2="2.54" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="-1.6002" y1="1.27" x2="-2.54" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-2.54" x2="2.54" y2="-2.54" width="0.1524" layer="51" curve="-270"/>
<wire x1="-2.54" y1="-1.27" x2="2.54" y2="-1.27" width="0.1524" layer="51" curve="-233.130102"/>
<wire x1="-1.6002" y1="1.27" x2="1.6002" y2="1.27" width="0.1524" layer="51"/>
<pad name="3" x="-2.413" y="-4.699" drill="1.8034" diameter="3.048" shape="offset" rot="R180"/>
<pad name="2" x="-2.413" y="0" drill="1.8034" diameter="3.048" shape="offset" rot="R180"/>
<pad name="1" x="-2.413" y="4.699" drill="1.8034" diameter="3.048" shape="offset" rot="R180"/>
<pad name="4" x="2.413" y="4.699" drill="1.8034" diameter="3.048" shape="offset"/>
<pad name="5" x="2.413" y="0" drill="1.8034" diameter="3.048" shape="offset"/>
<pad name="6" x="2.413" y="-4.699" drill="1.8034" diameter="3.048" shape="offset"/>
<text x="-5.08" y="7.62" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-9.525" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="pic16f690">
<packages>
<package name="DIL20">
<wire x1="12.7" y1="2.921" x2="-12.7" y2="2.921" width="0.127" layer="21"/>
<wire x1="-12.7" y1="-2.921" x2="12.7" y2="-2.921" width="0.127" layer="21"/>
<wire x1="12.7" y1="2.921" x2="12.7" y2="-2.921" width="0.127" layer="21"/>
<wire x1="-12.7" y1="2.921" x2="-12.7" y2="1.016" width="0.127" layer="21"/>
<wire x1="-12.7" y1="-2.921" x2="-12.7" y2="-1.016" width="0.127" layer="21"/>
<wire x1="-12.7" y1="1.016" x2="-12.7" y2="-1.016" width="0.127" layer="21" curve="-180"/>
<pad name="1" x="-11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="-6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="-8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="-11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-5.08" y="0.635" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.08" y="-1.905" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="pot">
<packages>
<package name="CA9V">
<description>&lt;b&gt;POTENTIOMETER&lt;/b&gt;&lt;p&gt;
distributor Schukat</description>
<wire x1="-0.381" y1="0.381" x2="-0.381" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="1.651" x2="0.381" y2="1.651" width="0.1524" layer="21"/>
<wire x1="0.381" y1="1.651" x2="0.381" y2="0.381" width="0.1524" layer="21"/>
<wire x1="0.381" y1="0.381" x2="1.016" y2="-0.127" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.127" x2="1.016" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.381" x2="0.381" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-0.381" x2="0.381" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-1.651" x2="-0.381" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-1.651" x2="-0.381" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-0.381" x2="-1.016" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-0.381" x2="-1.016" y2="-0.127" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-0.127" x2="-0.381" y2="0.381" width="0.1524" layer="21"/>
<wire x1="1.524" y1="5.08" x2="-1.524" y2="5.08" width="0.1524" layer="51"/>
<wire x1="4.572" y1="5.08" x2="1.524" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-1.524" x2="-2.032" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-1.524" x2="2.032" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="0" x2="-2.413" y2="0" width="0.1524" layer="21"/>
<wire x1="2.413" y1="0" x2="2.921" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.778" x2="-2.032" y2="2.032" width="0.1524" layer="21"/>
<wire x1="1.778" y1="1.778" x2="2.032" y2="2.032" width="0.1524" layer="21"/>
<wire x1="0" y1="2.413" x2="0" y2="2.921" width="0.1524" layer="21"/>
<wire x1="3.937" y1="-5.08" x2="1.143" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-5.08" x2="-1.143" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="-5.08" x2="-3.937" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="-3.937" y1="-5.08" x2="-4.572" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="4.572" y1="-5.08" x2="4.953" y2="-4.699" width="0.1524" layer="21" curve="90"/>
<wire x1="4.572" y1="5.08" x2="4.953" y2="4.699" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.953" y1="4.699" x2="-4.572" y2="5.08" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.953" y1="-4.699" x2="-4.572" y2="-5.08" width="0.1524" layer="21" curve="90"/>
<wire x1="4.572" y1="-5.08" x2="3.937" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="4.953" y1="4.699" x2="4.953" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="5.08" x2="-1.524" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-4.699" x2="-4.953" y2="4.699" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.032" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.921" width="0.1524" layer="21"/>
<pad name="S" x="0" y="5.08" drill="1.3208" diameter="2.54" shape="octagon"/>
<pad name="A" x="-2.54" y="-5.08" drill="1.3208" diameter="2.54" shape="octagon" rot="R90"/>
<pad name="E" x="2.54" y="-5.08" drill="1.3208" diameter="2.54" shape="octagon" rot="R90"/>
<text x="-5.461" y="-5.08" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="6.731" y="-5.08" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.508" y1="5.08" x2="0.508" y2="5.461" layer="51"/>
<rectangle x1="2.032" y1="-5.461" x2="3.048" y2="-3.683" layer="51"/>
<rectangle x1="1.397" y1="-3.683" x2="4.572" y2="-2.667" layer="21"/>
<rectangle x1="3.048" y1="-2.667" x2="4.572" y2="0" layer="21"/>
<rectangle x1="-4.572" y1="-2.667" x2="-3.048" y2="0" layer="21"/>
<rectangle x1="-4.572" y1="-3.683" x2="-1.397" y2="-2.667" layer="21"/>
<rectangle x1="-3.048" y1="-5.461" x2="-2.032" y2="-3.683" layer="51"/>
</package>
</packages>
</library>
<library name="rcl">
<packages>
<package name="C1206K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 1206 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 3216</description>
<wire x1="-1.525" y1="0.75" x2="1.525" y2="0.75" width="0.1016" layer="51"/>
<wire x1="1.525" y1="-0.75" x2="-1.525" y2="-0.75" width="0.1016" layer="51"/>
<smd name="1" x="-1.5" y="0" dx="1.5" dy="2" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.5" dy="2" layer="1"/>
<text x="-1.6" y="1.1" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.6" y="-2.1" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-0.8" x2="-1.1" y2="0.8" layer="51"/>
<rectangle x1="1.1" y1="-0.8" x2="1.6" y2="0.8" layer="51"/>
</package>
<package name="085CS_1AR">
<description>&lt;b&gt;Aluminum electrolytic capacitors&lt;/b&gt; reflow soldering&lt;p&gt;
SMD (Chip) Standard 085 CS&lt;p&gt;
http://www.bccomponents.com/</description>
<wire x1="4.2" y1="-0.95" x2="4.45" y2="-0.7" width="0.1016" layer="51"/>
<wire x1="4.45" y1="-0.7" x2="4.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="4.45" y1="0.7" x2="4.2" y2="0.95" width="0.1016" layer="51"/>
<wire x1="4.2" y1="0.95" x2="4.2" y2="-0.95" width="0.1016" layer="51"/>
<wire x1="4.3" y1="-0.75" x2="4.3" y2="0.75" width="0.2032" layer="51"/>
<wire x1="-4.2" y1="0.95" x2="-4.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-4.45" y1="0.7" x2="-4.45" y2="-0.7" width="0.1016" layer="51"/>
<wire x1="-4.45" y1="-0.7" x2="-4.2" y2="-0.95" width="0.1016" layer="51"/>
<wire x1="-4.2" y1="-0.95" x2="-4.2" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-4.3" y1="0.75" x2="-4.3" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="3.65" y1="-1.85" x2="3.65" y2="1.85" width="0.2032" layer="51"/>
<wire x1="3.65" y1="1.85" x2="-3.65" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-3.65" y1="1.85" x2="-3.65" y2="-1.85" width="0.2032" layer="51"/>
<wire x1="-3.65" y1="-1.85" x2="3.65" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="3.6" y1="-1.35" x2="1.8" y2="-1.35" width="0.2032" layer="51"/>
<wire x1="1.8" y1="-1.35" x2="1.7" y2="-1.75" width="0.2032" layer="21"/>
<wire x1="3.55" y1="1.35" x2="1.8" y2="1.35" width="0.2032" layer="51"/>
<wire x1="1.8" y1="1.35" x2="1.7" y2="1.75" width="0.2032" layer="21"/>
<wire x1="-5.5" y1="2.2" x2="-5.5" y2="-2.2" width="0.2032" layer="39"/>
<wire x1="5.5" y1="2.2" x2="5.5" y2="-2.2" width="0.2032" layer="39"/>
<wire x1="-5.5" y1="2.2" x2="5.5" y2="2.2" width="0.2032" layer="39"/>
<wire x1="-5.5" y1="-2.2" x2="5.5" y2="-2.2" width="0.2032" layer="39"/>
<smd name="+" x="3.25" y="0" dx="2.9" dy="2.5" layer="1"/>
<smd name="-" x="-3.25" y="0" dx="2.9" dy="2.5" layer="1"/>
<text x="-3.81" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.81" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="1.8" y1="-1" x2="4.15" y2="1" layer="51"/>
<rectangle x1="-4.15" y1="-1" x2="-1.8" y2="1" layer="51"/>
</package>
<package name="R1206">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;</description>
<wire x1="0.9525" y1="-0.8128" x2="-0.9652" y2="-0.8128" width="0.1524" layer="51"/>
<wire x1="0.9525" y1="0.8128" x2="-0.9652" y2="0.8128" width="0.1524" layer="51"/>
<wire x1="-2.473" y1="0.983" x2="2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="0.983" x2="2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-0.983" x2="-2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-0.983" x2="-2.473" y2="0.983" width="0.0508" layer="39"/>
<smd name="2" x="1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<smd name="1" x="-1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6891" y1="-0.8763" x2="-0.9525" y2="0.8763" layer="51"/>
<rectangle x1="0.9525" y1="-0.8763" x2="1.6891" y2="0.8763" layer="51"/>
<rectangle x1="-0.3" y1="-0.7" x2="0.3" y2="0.7" layer="35"/>
</package>
<package name="R2512">
<wire x1="-2.362" y1="1.473" x2="2.387" y2="1.473" width="0.1524" layer="51"/>
<wire x1="-2.362" y1="-1.473" x2="2.387" y2="-1.473" width="0.1524" layer="51"/>
<wire x1="-3.973" y1="1.983" x2="3.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="3.973" y1="1.983" x2="3.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="3.973" y1="-1.983" x2="-3.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-3.973" y1="-1.983" x2="-3.973" y2="1.983" width="0.0508" layer="39"/>
<smd name="1" x="-2.8" y="0" dx="1.8" dy="3.2" layer="1"/>
<smd name="2" x="2.8" y="0" dx="1.8" dy="3.2" layer="1"/>
<text x="-2.54" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3.2004" y1="-1.5494" x2="-2.3505" y2="1.5507" layer="51"/>
<rectangle x1="2.3622" y1="-1.5494" x2="3.2121" y2="1.5507" layer="51"/>
<rectangle x1="-0.5001" y1="-1" x2="0.5001" y2="1" layer="35"/>
</package>
<package name="TJ3-U2">
<description>&lt;b&gt;Inductor&lt;/b&gt;&lt;p&gt;
Source: TJ-Serie Vishay.pdf</description>
<circle x="0" y="0" radius="8.3" width="0.2032" layer="21"/>
<pad name="1" x="-7.35" y="0" drill="0.9" diameter="2.1844"/>
<pad name="2" x="7.35" y="0" drill="0.9" diameter="2.1844"/>
</package>
<package name="C102-064X133">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 10.2 mm, outline 6.4 x 13.3 mm</description>
<wire x1="-3.175" y1="1.27" x2="-3.175" y2="0" width="0.4064" layer="21"/>
<wire x1="-2.286" y1="1.27" x2="-2.286" y2="0" width="0.4064" layer="21"/>
<wire x1="3.81" y1="0" x2="-2.286" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0" x2="-2.286" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-3.81" y1="0" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="0" x2="-3.175" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-6.096" y1="3.048" x2="6.096" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.604" y1="2.54" x2="6.604" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-3.048" x2="-6.096" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.54" x2="-6.604" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.096" y1="3.048" x2="6.604" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="-3.048" x2="6.604" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="-2.54" x2="-6.096" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="2.54" x2="-6.096" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-5.08" y="0" drill="1.016" diameter="1.778" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="1.016" diameter="1.778" shape="octagon"/>
<text x="-6.096" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-2.032" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="crystal">
<packages>
<package name="HC49U70">
<description>&lt;b&gt;CRYSTAL&lt;/b&gt;</description>
<wire x1="-3.048" y1="-2.54" x2="3.048" y2="-2.54" width="0.4064" layer="21"/>
<wire x1="-3.048" y1="2.54" x2="3.048" y2="2.54" width="0.4064" layer="21"/>
<wire x1="-3.048" y1="-2.032" x2="3.048" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-0.3302" y1="1.016" x2="-0.3302" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-0.3302" y1="-1.016" x2="0.3048" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="0.3048" y1="-1.016" x2="0.3048" y2="1.016" width="0.1524" layer="21"/>
<wire x1="0.3048" y1="1.016" x2="-0.3302" y2="1.016" width="0.1524" layer="21"/>
<wire x1="0.6858" y1="1.016" x2="0.6858" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.6858" y1="1.016" x2="-0.6858" y2="0" width="0.1524" layer="21"/>
<wire x1="0.6858" y1="0" x2="1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="0.6858" y1="0" x2="0.6858" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-0.6858" y1="0" x2="-1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.6858" y1="0" x2="-0.6858" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="2.54" x2="-3.048" y2="-2.54" width="0.4064" layer="21" curve="180"/>
<wire x1="3.048" y1="2.54" x2="3.048" y2="-2.54" width="0.4064" layer="21" curve="-180"/>
<wire x1="-3.048" y1="-2.032" x2="-3.048" y2="2.032" width="0.1524" layer="21" curve="-180"/>
<wire x1="3.048" y1="2.032" x2="3.048" y2="-2.032" width="0.1524" layer="21" curve="-180"/>
<wire x1="3.048" y1="2.032" x2="-3.048" y2="2.032" width="0.1524" layer="21"/>
<pad name="1" x="-2.413" y="0" drill="0.8128" diameter="1.6764"/>
<pad name="2" x="2.413" y="0" drill="0.8128" diameter="1.6764"/>
<text x="-5.08" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-4.445" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-4.572" y1="-2.794" x2="-4.064" y2="2.794" layer="43"/>
<rectangle x1="-5.08" y1="-2.54" x2="-4.572" y2="2.54" layer="43"/>
<rectangle x1="-5.588" y1="-2.032" x2="-5.08" y2="2.032" layer="43"/>
<rectangle x1="-5.842" y1="-1.27" x2="-5.588" y2="1.27" layer="43"/>
<rectangle x1="-4.064" y1="-3.048" x2="4.064" y2="3.048" layer="43"/>
<rectangle x1="4.064" y1="-2.794" x2="4.572" y2="2.794" layer="43"/>
<rectangle x1="4.572" y1="-2.54" x2="5.08" y2="2.54" layer="43"/>
<rectangle x1="5.08" y1="-2.032" x2="5.588" y2="2.032" layer="43"/>
<rectangle x1="5.588" y1="-1.27" x2="5.842" y2="1.27" layer="43"/>
</package>
</packages>
</library>
<library name="switch">
<packages>
<package name="M9040P">
<wire x1="-3.3528" y1="6.6802" x2="-3.9878" y2="6.0452" width="0.1524" layer="21"/>
<wire x1="-3.3528" y1="6.6802" x2="3.3528" y2="6.6802" width="0.1524" layer="21"/>
<wire x1="3.9878" y1="6.0452" x2="3.3528" y2="6.6802" width="0.1524" layer="21"/>
<wire x1="3.3782" y1="-6.6802" x2="4.0132" y2="-6.0452" width="0.1524" layer="21"/>
<wire x1="3.3782" y1="-6.6802" x2="-3.3782" y2="-6.6802" width="0.1524" layer="21"/>
<wire x1="-4.0132" y1="-6.0452" x2="-3.3782" y2="-6.6802" width="0.1524" layer="21"/>
<wire x1="4.318" y1="2.286" x2="4.318" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="2.286" x2="-4.318" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="4.318" y1="2.286" x2="3.9878" y2="2.5146" width="0.1524" layer="21"/>
<wire x1="0" y1="5.08" x2="-3.9878" y2="2.4892" width="0.1524" layer="51"/>
<wire x1="-4.318" y1="-2.286" x2="-4.0132" y2="-2.4892" width="0.1524" layer="21"/>
<wire x1="0" y1="-5.08" x2="4.0132" y2="-2.4892" width="0.1524" layer="51"/>
<wire x1="4.0132" y1="-6.0452" x2="4.0132" y2="-2.4892" width="0.1524" layer="21"/>
<wire x1="3.9878" y1="6.0452" x2="3.9878" y2="2.5146" width="0.1524" layer="21"/>
<wire x1="-3.9878" y1="2.4892" x2="-3.9878" y2="6.0452" width="0.1524" layer="21"/>
<wire x1="-4.0132" y1="-6.0452" x2="-4.0132" y2="-2.4892" width="0.1524" layer="21"/>
<wire x1="3.9878" y1="2.5146" x2="0" y2="5.08" width="0.1524" layer="51"/>
<wire x1="4.0132" y1="-2.4892" x2="4.318" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.0132" y1="-2.4892" x2="0" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="-3.9878" y1="2.4892" x2="-4.318" y2="2.286" width="0.1524" layer="21"/>
<pad name="3" x="0" y="-4.699" drill="1.8034" diameter="2.794" shape="long"/>
<pad name="2" x="0" y="0" drill="1.8034" diameter="2.794" shape="long"/>
<pad name="1" x="0" y="4.699" drill="1.8034" diameter="2.794" shape="long"/>
<text x="-3.81" y="7.62" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-9.525" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="01skori-hp">
<packages>
<package name="PIN-4">
<description>&lt;b&gt;Forr. pont&lt;/b&gt;
&lt;br&gt;kör alakú
&lt;br&gt;furat 1,3mm
&lt;br&gt;szélesség 120 mil (kb. 3mm)</description>
<circle x="0" y="0.0254" radius="1.778" width="0.1524" layer="51"/>
<pad name="1" x="0" y="0.0254" drill="1.3" diameter="3.048" rot="R180"/>
<text x="-3.81" y="3.175" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="0.889" size="1.778" layer="27" ratio="10" rot="R180">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="linear">
<packages>
<package name="TO92-T">
<wire x1="-2.0946" y1="-1.651" x2="-0.7863" y2="2.5485" width="0.1524" layer="21" curve="-111.098957" cap="flat"/>
<wire x1="0.7868" y1="2.5484" x2="2.095" y2="-1.651" width="0.1524" layer="21" curve="-111.09954" cap="flat"/>
<wire x1="-2.095" y1="-1.651" x2="2.095" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-2.655" y1="-0.254" x2="-2.254" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-2.191" y1="-0.254" x2="2.655" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-0.7863" y1="2.5485" x2="0.7863" y2="2.5485" width="0.1524" layer="51" curve="-34.293591" cap="flat"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="0" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<text x="3.175" y="0.635" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-1.27" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="transistor-small-signal">
<packages>
<package name="SOT23">
<description>&lt;b&gt;SOT-23&lt;/b&gt;</description>
<wire x1="1.4224" y1="0.6604" x2="1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="1.4224" y1="-0.6604" x2="-1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="-0.6604" x2="-1.4224" y2="0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="0.6604" x2="1.4224" y2="0.6604" width="0.1524" layer="51"/>
<smd name="3" x="0" y="1.1" dx="1" dy="1.4" layer="1"/>
<smd name="2" x="0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<smd name="1" x="-0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.2286" y1="0.7112" x2="0.2286" y2="1.2954" layer="51"/>
<rectangle x1="0.7112" y1="-1.2954" x2="1.1684" y2="-0.7112" layer="51"/>
<rectangle x1="-1.1684" y1="-1.2954" x2="-0.7112" y2="-0.7112" layer="51"/>
</package>
</packages>
</library>
<library name="con-lstb">
<packages>
<package name="MA06-1">
<description>&lt;b&gt;PIN HEADER&lt;/b&gt;</description>
<wire x1="-6.985" y1="1.27" x2="-5.715" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="1.27" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="-5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.635" x2="-4.445" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.27" x2="-3.175" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.27" x2="-2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.635" x2="-3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.27" x2="-4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-1.27" x2="-5.08" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="0.635" x2="-7.62" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="1.27" x2="-7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-0.635" x2="-6.985" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-1.27" x2="-6.985" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.27" x2="-0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="-0.635" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.27" x2="-2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.635" y1="1.27" x2="1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="1.27" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.635" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.635" x2="3.175" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="1.27" x2="4.445" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="1.27" x2="5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-0.635" x2="4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-1.27" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.27" x2="2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.635" y1="1.27" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="-0.635" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.635" x2="5.715" y2="1.27" width="0.1524" layer="21"/>
<wire x1="5.715" y1="1.27" x2="6.985" y2="1.27" width="0.1524" layer="21"/>
<wire x1="6.985" y1="1.27" x2="7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-0.635" x2="6.985" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-1.27" x2="5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-1.27" x2="5.08" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="7.62" y1="0.635" x2="7.62" y2="-0.635" width="0.1524" layer="21"/>
<pad name="1" x="-6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-7.62" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.985" y="-2.921" size="1.27" layer="21" ratio="10">1</text>
<text x="5.715" y="1.651" size="1.27" layer="21" ratio="10">6</text>
<text x="-2.54" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-4.064" y1="-0.254" x2="-3.556" y2="0.254" layer="51"/>
<rectangle x1="-6.604" y1="-0.254" x2="-6.096" y2="0.254" layer="51"/>
<rectangle x1="-1.524" y1="-0.254" x2="-1.016" y2="0.254" layer="51"/>
<rectangle x1="3.556" y1="-0.254" x2="4.064" y2="0.254" layer="51"/>
<rectangle x1="1.016" y1="-0.254" x2="1.524" y2="0.254" layer="51"/>
<rectangle x1="6.096" y1="-0.254" x2="6.604" y2="0.254" layer="51"/>
</package>
</packages>
</library>
<library name="transistor-npn">
<packages>
<package name="SOT23-BEC">
<description>TO-236 ITT Intermetall</description>
<wire x1="1.4224" y1="0.6604" x2="1.4224" y2="-0.6604" width="0.127" layer="51"/>
<wire x1="1.4224" y1="-0.6604" x2="-1.4224" y2="-0.6604" width="0.127" layer="51"/>
<wire x1="-1.4224" y1="-0.6604" x2="-1.4224" y2="0.6604" width="0.127" layer="51"/>
<wire x1="-1.4224" y1="0.6604" x2="1.4224" y2="0.6604" width="0.127" layer="51"/>
<smd name="C" x="0" y="1.1" dx="1" dy="1.4" layer="1"/>
<smd name="E" x="0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<smd name="B" x="-0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules name="default">
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="checkStop" value="0"/>
<param name="checkValues" value="0"/>
<param name="checkNames" value="1"/>
<param name="checkWireStubs" value="1"/>
<param name="checkPolygonWidth" value="0"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="AutoGrid" value="1"/>
<param name="Efforts" value="0"/>
<param name="TopRouterVariant" value="1"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="|"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="-"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="LCD1" library="01_LCM3" package="MTB-086" value="LCD-2X16" x="-110.49" y="51.1175" smashed="yes">
<attribute name="NAME" x="-98.104" y="84.1715" size="1.27" layer="25"/>
<attribute name="VALUE" x="-98.104" y="82.1315" size="1.27" layer="27"/>
</element>
<element name="U1" library="pic16f690" package="DIL20" value="16F690" x="-86.0425" y="70.485" smashed="yes">
<attribute name="NAME" x="-91.1225" y="71.12" size="1.27" layer="25"/>
<attribute name="VALUE" x="-91.1225" y="68.58" size="1.27" layer="27"/>
</element>
<element name="P1" library="pot" package="CA9V" value="10k" x="-66.3575" y="61.2775" smashed="yes" rot="R90">
<attribute name="NAME" x="-61.2775" y="55.8165" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="-61.2775" y="68.0085" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C1" library="rcl" package="C1206K" value="22p" x="-92.3925" y="70.485" smashed="yes" rot="MR90">
<attribute name="NAME" x="-91.2925" y="68.885" size="1.016" layer="26" rot="MR90"/>
<attribute name="VALUE" x="-94.4925" y="68.885" size="1.016" layer="28" rot="MR90"/>
</element>
<element name="C2" library="rcl" package="C1206K" value="22p" x="-94.9325" y="70.485" smashed="yes" rot="MR90">
<attribute name="NAME" x="-93.8325" y="68.885" size="1.016" layer="26" rot="MR90"/>
<attribute name="VALUE" x="-97.0325" y="68.885" size="1.016" layer="28" rot="MR90"/>
</element>
<element name="Q1" library="crystal" package="HC49U70" value="20MHz" x="-95.5675" y="62.23" smashed="yes">
<attribute name="NAME" x="-100.6475" y="65.405" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="-100.6475" y="57.785" size="1.27" layer="27" ratio="10"/>
</element>
<element name="C6" library="rcl" package="C1206K" value="100n" x="-97.4725" y="70.485" smashed="yes" rot="MR270">
<attribute name="NAME" x="-98.5725" y="72.085" size="1.016" layer="26" rot="MR270"/>
<attribute name="VALUE" x="-95.3725" y="72.085" size="1.016" layer="28" rot="MR270"/>
</element>
<element name="C11" library="rcl" package="C1206K" value="100n" x="-67.6275" y="56.515" smashed="yes" rot="MR180">
<attribute name="NAME" x="-69.2275" y="55.415" size="1.016" layer="26" rot="MR180"/>
<attribute name="VALUE" x="-69.2275" y="58.615" size="1.016" layer="28" rot="MR180"/>
</element>
<element name="R4" library="rcl" package="R1206" value="47k" x="-84.7725" y="70.485" smashed="yes" rot="MR90">
<attribute name="NAME" x="-83.5025" y="69.215" size="1.27" layer="26" rot="MR90"/>
<attribute name="VALUE" x="-87.3125" y="69.215" size="1.27" layer="28" rot="MR90"/>
</element>
<element name="C44" library="rcl" package="C1206K" value="4,7uF Ker" x="-84.7725" y="86.6775" smashed="yes" rot="MR270">
<attribute name="NAME" x="-85.8725" y="88.2775" size="1.016" layer="26" rot="MR270"/>
<attribute name="VALUE" x="-82.6725" y="88.2775" size="1.016" layer="28" rot="MR270"/>
</element>
<element name="R3" library="rcl" package="R1206" value="100k" x="-88.5824" y="71.755" smashed="yes" rot="MR180">
<attribute name="NAME" x="-89.8524" y="70.485" size="1.27" layer="26" rot="MR180"/>
<attribute name="VALUE" x="-89.8524" y="74.295" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="R2" library="rcl" package="R1206" value="100k" x="-87.3125" y="83.5025" smashed="yes" rot="MR270">
<attribute name="NAME" x="-88.5825" y="84.7725" size="1.27" layer="26" rot="MR270"/>
<attribute name="VALUE" x="-84.7725" y="84.7725" size="1.27" layer="28" rot="MR270"/>
</element>
<element name="R1" library="rcl" package="R1206" value="100k" x="-97.155" y="83.185" smashed="yes" rot="MR270">
<attribute name="NAME" x="-98.425" y="84.455" size="1.27" layer="26" rot="MR270"/>
<attribute name="VALUE" x="-94.615" y="84.455" size="1.27" layer="28" rot="MR270"/>
</element>
<element name="C55" library="rcl" package="C1206K" value="4,7uF Ker" x="-94.615" y="83.185" smashed="yes" rot="MR90">
<attribute name="NAME" x="-93.515" y="81.585" size="1.016" layer="26" rot="MR90"/>
<attribute name="VALUE" x="-96.715" y="81.585" size="1.016" layer="28" rot="MR90"/>
</element>
<element name="CMEAS" library="rcl" package="C102-064X133" value="1n" x="-53.975" y="86.6775" smashed="yes" rot="R90">
<attribute name="NAME" x="-52.2923" y="83.3755" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="-51.943" y="83.2485" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="C-REF" library="rcl" package="C102-064X133" value="1n" x="-47.625" y="86.6775" smashed="yes" rot="R90">
<attribute name="NAME" x="-45.6247" y="82.7405" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="-45.593" y="83.2485" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="C8" library="rcl" package="C102-064X133" value="33n" x="-82.55" y="86.6775" smashed="yes" rot="R270">
<attribute name="NAME" x="-82.0103" y="86.0107" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="-84.582" y="90.1065" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R6" library="rcl" package="R1206" value="220" x="-82.2325" y="77.7875" smashed="yes" rot="MR90">
<attribute name="NAME" x="-80.9625" y="76.5175" size="1.27" layer="26" rot="MR90"/>
<attribute name="VALUE" x="-84.7725" y="76.5175" size="1.27" layer="28" rot="MR90"/>
</element>
<element name="R7" library="rcl" package="R1206" value="180" x="-79.6925" y="77.7875" smashed="yes" rot="MR90">
<attribute name="NAME" x="-78.4225" y="76.5175" size="1.27" layer="26" rot="MR90"/>
<attribute name="VALUE" x="-82.2325" y="76.5175" size="1.27" layer="28" rot="MR90"/>
</element>
<element name="S3" library="01_LCM3" package="M9040P2B" value="C/L" x="-18.415" y="83.82" smashed="yes" rot="R270">
<attribute name="NAME" x="-10.795" y="88.9" size="1.778" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="-27.94" y="88.9" size="1.778" layer="27" ratio="10" rot="R270"/>
</element>
<element name="S5" library="switch" package="M9040P" value="CAL" x="-64.77" y="83.82" smashed="yes" rot="R90">
<attribute name="NAME" x="-72.39" y="80.01" size="1.778" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="-55.245" y="80.01" size="1.778" layer="27" ratio="10" rot="R90"/>
</element>
<element name="R8" library="rcl" package="R1206" value="1k" x="-100.0125" y="83.185" smashed="yes" rot="MR90">
<attribute name="NAME" x="-98.7425" y="81.915" size="1.27" layer="26" rot="MR90"/>
<attribute name="VALUE" x="-102.5525" y="81.915" size="1.27" layer="28" rot="MR90"/>
</element>
<element name="R12" library="rcl" package="R2512" value="47" x="-61.9125" y="89.535" smashed="yes" rot="MR0">
<attribute name="NAME" x="-59.3725" y="91.44" size="1.27" layer="26" rot="MR0"/>
<attribute name="VALUE" x="-59.3725" y="86.36" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="R9" library="rcl" package="R1206" value="1k" x="-90.9637" y="77.1525" smashed="yes" rot="MR180">
<attribute name="NAME" x="-92.2337" y="75.8825" size="1.27" layer="26" rot="MR180"/>
<attribute name="VALUE" x="-92.2337" y="79.6925" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="L1" library="rcl" package="TJ3-U2" value="100uH" x="-35.8775" y="84.455" smashed="yes" rot="R90">
<attribute name="NAME" x="-36.5125" y="79.375" size="1.27" layer="25" rot="R90"/>
<attribute name="VALUE" x="-33.9725" y="79.375" size="1.27" layer="27" rot="R90"/>
</element>
<element name="R5" library="rcl" package="R1206" value="10k" x="-106.9975" y="67.945" smashed="yes" rot="MR270">
<attribute name="NAME" x="-108.2675" y="69.215" size="1.27" layer="26" rot="MR270"/>
<attribute name="VALUE" x="-104.4575" y="69.215" size="1.27" layer="28" rot="MR270"/>
</element>
<element name="C4" library="rcl" package="085CS_1AR" value="10uF Ta" x="-78.74" y="86.6775" smashed="yes" rot="MR270">
<attribute name="NAME" x="-81.28" y="90.4875" size="1.27" layer="26" rot="MR270"/>
<attribute name="VALUE" x="-74.93" y="90.4875" size="1.27" layer="28" rot="MR270"/>
</element>
<element name="C5" library="rcl" package="085CS_1AR" value="10uF Ta" x="-91.1225" y="85.725" smashed="yes" rot="MR270">
<attribute name="NAME" x="-93.6625" y="89.535" size="1.27" layer="26" rot="MR270"/>
<attribute name="VALUE" x="-87.3125" y="89.535" size="1.27" layer="28" rot="MR270"/>
</element>
<element name="X1" library="01skori-hp" package="PIN-4" value="Cx Lx" x="-27.94" y="92.075" smashed="yes" rot="R90">
<attribute name="NAME" x="-31.115" y="88.265" size="1.778" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="-28.829" y="88.265" size="1.778" layer="27" ratio="10" rot="R270"/>
</element>
<element name="X2" library="01skori-hp" package="PIN-4" value="ELKO" x="-74.295" y="83.5025" smashed="yes">
<attribute name="NAME" x="-78.105" y="86.6775" size="1.778" layer="25" ratio="10"/>
<attribute name="VALUE" x="-78.105" y="84.3915" size="1.778" layer="27" ratio="10" rot="R180"/>
</element>
<element name="X3" library="01skori-hp" package="PIN-4" value="GND" x="-74.295" y="91.7575" smashed="yes" rot="R180">
<attribute name="NAME" x="-70.485" y="88.5825" size="1.778" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="-70.485" y="90.8685" size="1.778" layer="27" ratio="10"/>
</element>
<element name="IC1" library="linear" package="TO92-T" value="LP2950T" x="-49.8475" y="61.2775" smashed="yes" rot="R270">
<attribute name="NAME" x="-49.2125" y="58.1025" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="-51.1175" y="58.1025" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="Q2" library="transistor-small-signal" package="SOT23" value="BSS123" x="-46.355" y="62.23" smashed="yes" rot="MR0">
<attribute name="NAME" x="-44.45" y="64.135" size="1.27" layer="26" rot="MR0"/>
<attribute name="VALUE" x="-44.45" y="59.055" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="Q3" library="transistor-small-signal" package="SOT23" value="SI2307 (Lomex: 86-03-40)" x="-40.9575" y="62.865" smashed="yes" rot="MR180">
<attribute name="NAME" x="-42.8625" y="60.96" size="1.27" layer="26" rot="MR180"/>
<attribute name="VALUE" x="-42.8625" y="66.04" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="R20" library="rcl" package="R1206" value="10M" x="-43.4975" y="55.5625" smashed="yes" rot="MR0">
<attribute name="NAME" x="-42.2275" y="56.8325" size="1.27" layer="26" rot="MR0"/>
<attribute name="VALUE" x="-42.2275" y="53.0225" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="R22" library="rcl" package="R1206" value="1k" x="-46.355" y="66.9925" smashed="yes" rot="MR90">
<attribute name="NAME" x="-45.085" y="65.7225" size="1.27" layer="26" rot="MR90"/>
<attribute name="VALUE" x="-48.895" y="65.7225" size="1.27" layer="28" rot="MR90"/>
</element>
<element name="R21" library="rcl" package="R1206" value="1M" x="-41.5925" y="68.58" smashed="yes" rot="MR180">
<attribute name="NAME" x="-42.8625" y="67.31" size="1.27" layer="26" rot="MR180"/>
<attribute name="VALUE" x="-42.8625" y="71.12" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="C21" library="rcl" package="C1206K" value="10uF" x="-41.5925" y="66.04" smashed="yes" rot="MR180">
<attribute name="NAME" x="-43.1925" y="64.94" size="1.016" layer="26" rot="MR180"/>
<attribute name="VALUE" x="-43.1925" y="68.14" size="1.016" layer="28" rot="MR180"/>
</element>
<element name="C22" library="rcl" package="C1206K" value="100n" x="-37.465" y="66.9925" smashed="yes" rot="MR90">
<attribute name="NAME" x="-36.365" y="65.3925" size="1.016" layer="26" rot="MR90"/>
<attribute name="VALUE" x="-39.565" y="65.3925" size="1.016" layer="28" rot="MR90"/>
</element>
<element name="S1" library="switch" package="M9040P" value="ON" x="-2.2225" y="83.82" smashed="yes" rot="R90">
<attribute name="NAME" x="-9.8425" y="80.01" size="1.778" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="7.3025" y="80.01" size="1.778" layer="27" ratio="10" rot="R90"/>
</element>
<element name="R24" library="rcl" package="R1206" value="100k" x="6.35" y="82.2325" smashed="yes" rot="MR270">
<attribute name="NAME" x="5.08" y="83.5025" size="1.27" layer="26" rot="MR270"/>
<attribute name="VALUE" x="8.89" y="83.5025" size="1.27" layer="28" rot="MR270"/>
</element>
<element name="X4" library="01skori-hp" package="PIN-4" value="+" x="-6.985" y="76.835" smashed="yes" rot="R180">
<attribute name="NAME" x="-3.175" y="73.66" size="1.778" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="-3.175" y="75.946" size="1.778" layer="27" ratio="10"/>
</element>
<element name="X5" library="01skori-hp" package="PIN-4" value="-" x="2.8575" y="76.835" smashed="yes" rot="R180">
<attribute name="NAME" x="6.6675" y="73.66" size="1.778" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="6.6675" y="75.946" size="1.778" layer="27" ratio="10"/>
</element>
<element name="ICSP" library="con-lstb" package="MA06-1" value="Prog" x="-103.8225" y="73.025" smashed="yes" rot="R90">
<attribute name="NAME" x="-105.4735" y="65.405" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="-100.9015" y="70.485" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="C3" library="rcl" package="C1206K" value="10uF" x="-53.0225" y="57.4675" smashed="yes" rot="MR90">
<attribute name="NAME" x="-51.9225" y="55.8675" size="1.016" layer="26" rot="MR90"/>
<attribute name="VALUE" x="-55.1225" y="55.8675" size="1.016" layer="28" rot="MR90"/>
</element>
<element name="C7" library="rcl" package="C1206K" value="10uF" x="-53.0225" y="62.23" smashed="yes" rot="MR270">
<attribute name="NAME" x="-54.1225" y="63.83" size="1.016" layer="26" rot="MR270"/>
<attribute name="VALUE" x="-50.9225" y="63.83" size="1.016" layer="28" rot="MR270"/>
</element>
<element name="R25" library="rcl" package="R1206" value="100k" x="-76.835" y="57.4675" smashed="yes" rot="MR90">
<attribute name="NAME" x="-75.565" y="56.1975" size="1.27" layer="26" rot="MR90"/>
<attribute name="VALUE" x="-79.375" y="56.1975" size="1.27" layer="28" rot="MR90"/>
</element>
<element name="R10" library="rcl" package="R1206" value="1k" x="-54.2925" y="74.93" smashed="yes" rot="MR0">
<attribute name="NAME" x="-53.0225" y="76.2" size="1.27" layer="26" rot="MR0"/>
<attribute name="VALUE" x="-53.0225" y="72.39" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="Q4" library="transistor-npn" package="SOT23-BEC" value="BC817-40LT1SMD" x="-48.895" y="75.8825" smashed="yes" rot="MR90">
<attribute name="NAME" x="-46.99" y="73.9775" size="1.27" layer="26" rot="MR90"/>
<attribute name="VALUE" x="-52.07" y="73.9775" size="1.27" layer="28" rot="MR90"/>
</element>
<element name="R13" library="rcl" package="R1206" value="10M" x="-45.4025" y="74.295" smashed="yes" rot="MR90">
<attribute name="NAME" x="-44.1325" y="73.025" size="1.27" layer="26" rot="MR90"/>
<attribute name="VALUE" x="-47.9425" y="73.025" size="1.27" layer="28" rot="MR90"/>
</element>
</elements>
<signals>
<signal name="A">
<contactref element="LCD1" pad="16"/>
</signal>
<signal name="K">
<contactref element="LCD1" pad="15"/>
</signal>
<signal name="N$1">
<contactref element="U1" pad="5"/>
<contactref element="LCD1" pad="14"/>
<wire x1="-99.3775" y1="53.848" x2="-99.568" y2="53.6575" width="0.6096" layer="16"/>
<wire x1="-92.075" y1="59.055" x2="-94.615" y2="59.055" width="0.6096" layer="16"/>
<wire x1="-94.615" y1="59.055" x2="-99.3775" y2="54.2925" width="0.6096" layer="16"/>
<wire x1="-99.3775" y1="54.2925" x2="-99.3775" y2="53.848" width="0.6096" layer="16"/>
<wire x1="-87.3125" y1="63.8175" x2="-87.3125" y2="62.23" width="0.6096" layer="16"/>
<wire x1="-87.3125" y1="62.23" x2="-89.2175" y2="60.6425" width="0.6096" layer="16"/>
<wire x1="-89.2175" y1="60.6425" x2="-90.4875" y2="60.6425" width="0.6096" layer="16"/>
<wire x1="-90.4875" y1="60.6425" x2="-92.075" y2="59.055" width="0.6096" layer="16"/>
<wire x1="-87.3125" y1="66.675" x2="-87.3125" y2="63.8175" width="0.6096" layer="16"/>
</signal>
<signal name="N$2">
<contactref element="U1" pad="7"/>
<contactref element="LCD1" pad="13"/>
<wire x1="-96.8375" y1="53.848" x2="-97.028" y2="53.6575" width="0.6096" layer="16"/>
<wire x1="-92.075" y1="57.785" x2="-93.2175" y2="57.785" width="0.6096" layer="16"/>
<wire x1="-93.2175" y1="57.785" x2="-96.8375" y2="54.165" width="0.6096" layer="16"/>
<wire x1="-96.8375" y1="54.165" x2="-96.8375" y2="53.848" width="0.6096" layer="16"/>
<wire x1="-82.2325" y1="66.675" x2="-82.2325" y2="65.405" width="0.6096" layer="16"/>
<wire x1="-91.7575" y1="57.785" x2="-92.075" y2="57.785" width="0.6096" layer="16"/>
<wire x1="-82.2325" y1="64.77" x2="-83.82" y2="63.1825" width="0.6096" layer="16"/>
<wire x1="-82.2325" y1="65.405" x2="-82.2325" y2="64.77" width="0.6096" layer="16"/>
<wire x1="-83.82" y1="63.1825" x2="-84.7725" y2="62.23" width="0.6096" layer="16"/>
<wire x1="-87.9475" y1="59.055" x2="-90.4875" y2="59.055" width="0.6096" layer="16"/>
<wire x1="-90.4875" y1="59.055" x2="-91.7575" y2="57.785" width="0.6096" layer="16"/>
<wire x1="-84.7725" y1="62.23" x2="-87.9475" y2="59.055" width="0.6096" layer="16"/>
</signal>
<signal name="N$4">
<contactref element="U1" pad="9"/>
<contactref element="LCD1" pad="11"/>
<wire x1="-90.17" y1="55.88" x2="-91.44" y2="54.61" width="0.6096" layer="16"/>
<wire x1="-77.1525" y1="64.4525" x2="-81.5975" y2="60.0075" width="0.6096" layer="16"/>
<wire x1="-77.1525" y1="66.675" x2="-77.1525" y2="64.4525" width="0.6096" layer="16"/>
<wire x1="-91.44" y1="54.61" x2="-91.948" y2="54.102" width="0.6096" layer="16"/>
<wire x1="-91.948" y1="54.102" x2="-91.948" y2="53.6575" width="0.6096" layer="16"/>
<wire x1="-85.725" y1="55.88" x2="-90.17" y2="55.88" width="0.6096" layer="16"/>
<wire x1="-81.5975" y1="60.0075" x2="-85.725" y2="55.88" width="0.6096" layer="16"/>
</signal>
<signal name="+5V">
<contactref element="LCD1" pad="2"/>
<contactref element="P1" pad="E"/>
<contactref element="C11" pad="1"/>
<contactref element="R1" pad="1"/>
<contactref element="R5" pad="1"/>
<contactref element="IC1" pad="1"/>
<contactref element="ICSP" pad="2"/>
<contactref element="C7" pad="1"/>
<contactref element="C6" pad="2"/>
<contactref element="U1" pad="1"/>
<wire x1="-71.12" y1="69.215" x2="-100.965" y2="69.215" width="0.254" layer="1"/>
<wire x1="-108.9025" y1="69.85" x2="-108.9025" y2="82.8675" width="0.8128" layer="16"/>
<wire x1="-108.9025" y1="82.8675" x2="-100.33" y2="91.44" width="0.8128" layer="16"/>
<wire x1="-100.33" y1="91.44" x2="-98.2997" y2="91.44" width="0.8128" layer="16"/>
<wire x1="-98.2997" y1="91.44" x2="-97.155" y2="90.2953" width="0.8128" layer="16"/>
<wire x1="-97.155" y1="90.2953" x2="-97.155" y2="84.607" width="0.8128" layer="16"/>
<wire x1="-103.8225" y1="69.215" x2="-107.315" y2="69.215" width="0.8128" layer="16"/>
<wire x1="-107.315" y1="69.215" x2="-106.9975" y2="69.367" width="0.8128" layer="16"/>
<wire x1="-108.2675" y1="69.215" x2="-108.9025" y2="69.85" width="0.8128" layer="16"/>
<wire x1="-107.467" y1="69.215" x2="-108.2675" y2="69.215" width="0.8128" layer="16"/>
<wire x1="-106.9975" y1="69.367" x2="-107.467" y2="69.215" width="0.8128" layer="16"/>
<wire x1="-100.965" y1="69.215" x2="-103.8225" y2="69.215" width="0.8128" layer="16"/>
<wire x1="-97.4725" y1="68.985" x2="-97.4725" y2="66.675" width="0.8128" layer="16"/>
<wire x1="-100.965" y1="68.985" x2="-97.4725" y2="68.985" width="0.8128" layer="16"/>
<wire x1="-100.965" y1="69.215" x2="-100.965" y2="68.985" width="0.8128" layer="16"/>
<wire x1="-69.1275" y1="56.515" x2="-69.088" y2="56.5545" width="0.6096" layer="16"/>
<wire x1="-69.088" y1="56.5545" x2="-69.088" y2="57.15" width="0.6096" layer="16"/>
<wire x1="-69.215" y1="69.215" x2="-49.8475" y2="69.215" width="0.254" layer="1"/>
<wire x1="-49.8475" y1="69.215" x2="-49.8475" y2="63.8175" width="0.6096" layer="16"/>
<wire x1="-49.8475" y1="63.8175" x2="-49.935" y2="63.73" width="0.6096" layer="16"/>
<wire x1="-49.935" y1="63.73" x2="-53.0225" y2="63.73" width="0.6096" layer="16"/>
<wire x1="-69.1275" y1="69.215" x2="-69.1275" y2="64.77" width="0.8128" layer="16"/>
<wire x1="-69.1275" y1="64.77" x2="-69.1275" y2="56.515" width="0.8128" layer="16"/>
<wire x1="-69.215" y1="69.215" x2="-71.12" y2="69.215" width="0.8128" layer="16"/>
<wire x1="-69.215" y1="69.215" x2="-69.1275" y2="69.215" width="0.8128" layer="16"/>
<wire x1="-62.23" y1="64.77" x2="-61.2775" y2="63.8175" width="0.8128" layer="16"/>
<wire x1="-69.1275" y1="64.77" x2="-62.23" y2="64.77" width="0.8128" layer="16"/>
<wire x1="-69.088" y1="57.15" x2="-69.088" y2="53.6575" width="0.8128" layer="16"/>
<via x="-100.965" y="69.215" extent="1-16" drill="0.8" diameter="1.6764" shape="square"/>
<via x="-71.12" y="69.215" extent="1-16" drill="0.8" diameter="1.6764" shape="square"/>
<via x="-69.215" y="69.215" extent="1-16" drill="0.8" diameter="1.6764" shape="square"/>
<via x="-49.8475" y="69.215" extent="1-16" drill="0.8" diameter="1.6764" shape="square"/>
<contactref element="R13" pad="1"/>
<wire x1="-49.8475" y1="69.215" x2="-46.1895" y2="72.873" width="0.6096" layer="16"/>
<wire x1="-46.1895" y1="72.873" x2="-45.4025" y2="72.873" width="0.6096" layer="16"/>
</signal>
<signal name="GND">
<contactref element="LCD1" pad="1"/>
<contactref element="P1" pad="A"/>
<contactref element="C11" pad="2"/>
<contactref element="LCD1" pad="5"/>
<contactref element="U1" pad="20"/>
<contactref element="C6" pad="1"/>
<contactref element="C2" pad="2"/>
<contactref element="C1" pad="2"/>
<contactref element="C44" pad="1"/>
<contactref element="R2" pad="1"/>
<contactref element="CMEAS" pad="1"/>
<contactref element="R12" pad="1"/>
<contactref element="C4" pad="-"/>
<contactref element="X3" pad="1"/>
<contactref element="Q2" pad="2"/>
<contactref element="IC1" pad="2"/>
<contactref element="R24" pad="2"/>
<contactref element="X5" pad="1"/>
<contactref element="ICSP" pad="3"/>
<contactref element="C3" pad="2"/>
<contactref element="C7" pad="2"/>
<contactref element="R25" pad="1"/>
<contactref element="LCD1" pad="10"/>
<contactref element="LCD1" pad="9"/>
<contactref element="LCD1" pad="8"/>
<contactref element="LCD1" pad="7"/>
<contactref element="S3" pad="5"/>
<contactref element="Q4" pad="E"/>
<wire x1="-81.788" y1="53.6575" x2="-84.328" y2="53.6575" width="1.016" layer="16"/>
<wire x1="-84.328" y1="53.6575" x2="-86.868" y2="53.6575" width="1.016" layer="16"/>
<wire x1="-86.868" y1="53.6575" x2="-89.408" y2="53.6575" width="1.016" layer="16"/>
<wire x1="-97.4725" y1="71.985" x2="-97.4725" y2="74.295" width="1.016" layer="16"/>
<wire x1="-100.965" y1="71.755" x2="-103.8225" y2="71.755" width="1.016" layer="16"/>
<wire x1="-67.31" y1="71.755" x2="-100.965" y2="71.755" width="0.254" layer="1"/>
<wire x1="-87.3125" y1="84.9245" x2="-87.3125" y2="84.7725" width="1.016" layer="16"/>
<wire x1="-87.3125" y1="86.36" x2="-87.3125" y2="84.9245" width="1.016" layer="16"/>
<wire x1="-86.995" y1="86.6775" x2="-87.3125" y2="86.36" width="1.016" layer="16"/>
<wire x1="-85.8125" y1="88.1775" x2="-84.7725" y2="88.1775" width="1.016" layer="16"/>
<wire x1="-86.995" y1="86.6775" x2="-85.8125" y2="88.1775" width="1.016" layer="16"/>
<wire x1="-84.7725" y1="88.1775" x2="-82.32" y2="88.1775" width="1.016" layer="16"/>
<wire x1="-80.57" y1="89.9275" x2="-78.74" y2="89.9275" width="1.016" layer="16"/>
<wire x1="-82.32" y1="88.1775" x2="-80.57" y2="89.9275" width="1.016" layer="16"/>
<wire x1="-78.74" y1="89.9275" x2="-78.665" y2="89.9275" width="0.8128" layer="16"/>
<wire x1="-94.9325" y1="71.985" x2="-92.3925" y2="71.985" width="0.8128" layer="16"/>
<wire x1="-97.4725" y1="71.985" x2="-94.9325" y2="71.985" width="0.8128" layer="16"/>
<wire x1="-100.965" y1="71.985" x2="-97.4725" y2="71.985" width="0.8128" layer="16"/>
<wire x1="-100.965" y1="71.755" x2="-100.965" y2="71.985" width="0.8128" layer="16"/>
<wire x1="-66.1275" y1="56.515" x2="-66.548" y2="56.0945" width="0.6096" layer="16"/>
<wire x1="-74.9554" y1="92.075" x2="-74.295" y2="91.7321" width="1.016" layer="16"/>
<wire x1="-78.74" y1="92.075" x2="-74.9554" y2="92.075" width="1.016" layer="16"/>
<wire x1="-74.9554" y1="92.075" x2="-59.1125" y2="92.075" width="1.016" layer="16"/>
<wire x1="-78.74" y1="89.9275" x2="-78.74" y2="92.075" width="1.016" layer="16"/>
<wire x1="-53.975" y1="86.995" x2="-53.975" y2="81.5975" width="1.016" layer="16"/>
<wire x1="-81.788" y1="52.578" x2="-81.788" y2="53.6575" width="1.016" layer="16"/>
<wire x1="-80.645" y1="51.435" x2="-81.788" y2="52.578" width="1.016" layer="16"/>
<wire x1="-58.42" y1="51.435" x2="-76.835" y2="51.435" width="1.016" layer="16"/>
<wire x1="-76.835" y1="51.435" x2="-80.645" y2="51.435" width="1.016" layer="16"/>
<wire x1="-57.4675" y1="52.3875" x2="-58.42" y2="51.435" width="1.016" layer="16"/>
<wire x1="-57.4675" y1="60.6425" x2="-57.4675" y2="70.1675" width="1.016" layer="16"/>
<wire x1="-57.4675" y1="58.7375" x2="-57.4675" y2="60.6425" width="1.016" layer="16"/>
<wire x1="-57.4675" y1="58.7375" x2="-57.4675" y2="52.3875" width="1.016" layer="16"/>
<wire x1="-61.2775" y1="58.7375" x2="-57.4675" y2="58.7375" width="1.016" layer="16"/>
<wire x1="-76.835" y1="53.5305" x2="-76.708" y2="53.6575" width="0.8128" layer="16"/>
<wire x1="-76.835" y1="51.435" x2="-76.835" y2="53.5305" width="1.016" layer="16"/>
<wire x1="-57.4675" y1="52.3875" x2="-56.8325" y2="51.7525" width="1.016" layer="16"/>
<wire x1="-56.8325" y1="51.7525" x2="-37.7825" y2="51.7525" width="1.016" layer="16"/>
<wire x1="-53.0225" y1="60.6425" x2="-53.0225" y2="60.73" width="0.6096" layer="16"/>
<wire x1="-53.0225" y1="60.6425" x2="-53.0225" y2="58.9675" width="0.6096" layer="16"/>
<wire x1="-50.395" y1="60.73" x2="-49.8475" y2="61.2775" width="1.016" layer="16"/>
<wire x1="-53.0225" y1="60.73" x2="-50.395" y2="60.73" width="1.016" layer="16"/>
<wire x1="-57.4675" y1="60.6425" x2="-53.0225" y2="60.6425" width="1.016" layer="16"/>
<wire x1="-76.835" y1="53.6575" x2="-76.835" y2="56.0455" width="0.6096" layer="16"/>
<wire x1="-76.708" y1="53.6575" x2="-76.835" y2="53.6575" width="0.6096" layer="16"/>
<wire x1="-37.7825" y1="51.7525" x2="-37.635" y2="51.7525" width="0.6096" layer="16"/>
<wire x1="-37.7825" y1="51.7525" x2="-20.32" y2="51.7525" width="1.016" layer="16"/>
<wire x1="-47.4525" y1="61.2775" x2="-47.305" y2="61.13" width="0.6096" layer="16"/>
<wire x1="-49.8475" y1="61.2775" x2="-47.4525" y2="61.2775" width="0.6096" layer="16"/>
<wire x1="-61.2775" y1="58.7375" x2="-63.5" y2="56.515" width="0.8128" layer="16"/>
<wire x1="-63.5" y1="56.515" x2="-66.1275" y2="56.515" width="0.8128" layer="16"/>
<wire x1="-66.1275" y1="53.6575" x2="-66.548" y2="53.6575" width="0.8128" layer="16"/>
<wire x1="-66.1275" y1="56.515" x2="-66.1275" y2="53.6575" width="0.8128" layer="16"/>
<wire x1="-59.1125" y1="92.075" x2="-59.1125" y2="89.535" width="1.016" layer="16"/>
<wire x1="-56.515" y1="89.535" x2="-53.975" y2="86.995" width="1.016" layer="16"/>
<wire x1="-59.1125" y1="89.535" x2="-56.515" y2="89.535" width="1.016" layer="16"/>
<wire x1="-18.415" y1="78.105" x2="-18.415" y2="81.407" width="1.016" layer="16"/>
<wire x1="-22.225" y1="74.295" x2="-18.415" y2="78.105" width="1.016" layer="16"/>
<wire x1="-40.3225" y1="74.295" x2="-22.225" y2="74.295" width="1.016" layer="16"/>
<wire x1="-42.8625" y1="76.835" x2="-40.3225" y2="74.295" width="1.016" layer="16"/>
<wire x1="-53.975" y1="86.995" x2="-47.4415" y2="86.995" width="1.016" layer="16"/>
<wire x1="-47.4415" y1="86.995" x2="-42.8625" y2="82.416" width="1.016" layer="16"/>
<wire x1="-42.8625" y1="82.416" x2="-42.8625" y2="76.835" width="1.016" layer="16"/>
<wire x1="-20.32" y1="51.7525" x2="2.8575" y2="74.295" width="1.016" layer="16"/>
<wire x1="2.8575" y1="74.295" x2="2.8575" y2="76.8096" width="1.016" layer="16"/>
<wire x1="2.8575" y1="76.8096" x2="2.8829" y2="76.835" width="1.016" layer="16"/>
<wire x1="2.8829" y1="76.835" x2="4.1275" y2="76.835" width="1.016" layer="16"/>
<wire x1="4.1275" y1="76.835" x2="6.35" y2="79.0575" width="1.016" layer="16"/>
<wire x1="6.35" y1="79.0575" x2="6.35" y2="80.8105" width="1.016" layer="16"/>
<via x="-100.965" y="71.755" extent="1-16" drill="0.8" diameter="1.6764" shape="square"/>
<via x="-67.31" y="71.755" extent="1-16" drill="0.8" diameter="1.6764" shape="square"/>
<polygon width="0.254" layer="16" isolate="1.016" thermals="no">
<vertex x="-110.1725" y="94.615"/>
<vertex x="11.1125" y="94.615"/>
<vertex x="11.1125" y="50.8"/>
<vertex x="-110.1725" y="50.8"/>
</polygon>
</signal>
<signal name="N$5">
<contactref element="P1" pad="S"/>
<contactref element="LCD1" pad="3"/>
<wire x1="-71.4375" y1="61.2775" x2="-71.628" y2="61.087" width="0.6096" layer="16"/>
<wire x1="-71.628" y1="61.087" x2="-71.628" y2="53.6575" width="0.6096" layer="16"/>
</signal>
<signal name="N$6">
<contactref element="LCD1" pad="4"/>
<contactref element="R20" pad="2"/>
<contactref element="U1" pad="11"/>
<contactref element="R25" pad="2"/>
<wire x1="-74.6125" y1="74.295" x2="-72.7075" y2="72.39" width="0.6096" layer="16"/>
<wire x1="-72.7075" y1="72.39" x2="-72.7075" y2="71.755" width="0.6096" layer="16"/>
<wire x1="-72.7075" y1="71.755" x2="-72.7075" y2="63.8175" width="0.6096" layer="16"/>
<wire x1="-72.7075" y1="63.8175" x2="-74.168" y2="62.357" width="0.6096" layer="16"/>
<wire x1="-74.168" y1="62.357" x2="-74.168" y2="59.055" width="0.6096" layer="16"/>
<wire x1="-74.168" y1="59.055" x2="-74.168" y2="55.7568" width="0.6096" layer="16"/>
<wire x1="-74.168" y1="55.7568" x2="-74.168" y2="53.6575" width="0.6096" layer="16"/>
<wire x1="-74.168" y1="55.7568" x2="-73.9737" y2="55.5625" width="0.6096" layer="1"/>
<wire x1="-73.9737" y1="55.5625" x2="-47.625" y2="55.5625" width="0.254" layer="1"/>
<wire x1="-76.835" y1="59.055" x2="-76.835" y2="58.8895" width="0.6096" layer="16"/>
<wire x1="-74.168" y1="59.055" x2="-76.835" y2="59.055" width="0.6096" layer="16"/>
<wire x1="-47.625" y1="55.5625" x2="-44.9195" y2="55.5625" width="0.6096" layer="16"/>
<via x="-74.168" y="55.7568" extent="1-16" drill="0.8" diameter="1.6764" shape="square"/>
<via x="-47.625" y="55.5625" extent="1-16" drill="0.8" diameter="1.6764" shape="square"/>
</signal>
<signal name="N$7">
<contactref element="U1" pad="10"/>
<contactref element="LCD1" pad="6"/>
<wire x1="-79.0575" y1="53.848" x2="-79.248" y2="53.6575" width="0.6096" layer="16"/>
<wire x1="-79.0575" y1="60.0075" x2="-79.0575" y2="53.848" width="0.6096" layer="16"/>
<wire x1="-74.6125" y1="64.4525" x2="-79.0575" y2="60.0075" width="0.6096" layer="16"/>
<wire x1="-74.6125" y1="66.675" x2="-74.6125" y2="64.4525" width="0.6096" layer="16"/>
</signal>
<signal name="N$8">
<contactref element="U1" pad="3"/>
<contactref element="C1" pad="1"/>
<contactref element="Q1" pad="2"/>
<wire x1="-92.3925" y1="68.985" x2="-92.3925" y2="66.675" width="0.8128" layer="16"/>
<wire x1="-92.3925" y1="62.992" x2="-93.1545" y2="62.23" width="0.6096" layer="16"/>
<wire x1="-92.3925" y1="66.675" x2="-92.3925" y2="62.992" width="0.6096" layer="16"/>
</signal>
<signal name="N$9">
<contactref element="U1" pad="2"/>
<contactref element="C2" pad="1"/>
<contactref element="Q1" pad="1"/>
<wire x1="-94.9325" y1="68.985" x2="-94.9325" y2="66.675" width="0.8128" layer="16"/>
<wire x1="-94.9325" y1="65.278" x2="-97.9805" y2="62.23" width="0.6096" layer="16"/>
<wire x1="-94.9325" y1="66.675" x2="-94.9325" y2="65.278" width="0.6096" layer="16"/>
</signal>
<signal name="N$12">
<contactref element="C44" pad="2"/>
<contactref element="U1" pad="15"/>
<contactref element="R4" pad="2"/>
<contactref element="C4" pad="+"/>
<wire x1="-84.7725" y1="74.295" x2="-84.7725" y2="72.39" width="1.016" layer="16"/>
<wire x1="-84.7725" y1="72.39" x2="-84.7725" y2="71.907" width="1.016" layer="16"/>
<wire x1="-84.7725" y1="85.1775" x2="-84.7725" y2="74.295" width="1.016" layer="16"/>
<wire x1="-84.7725" y1="85.1775" x2="-82.32" y2="85.1775" width="1.016" layer="16"/>
<wire x1="-82.32" y1="85.1775" x2="-80.9625" y2="83.82" width="1.016" layer="16"/>
<wire x1="-80.57" y1="83.4275" x2="-78.74" y2="83.4275" width="1.016" layer="16"/>
<wire x1="-80.9625" y1="83.82" x2="-80.57" y2="83.4275" width="1.016" layer="16"/>
</signal>
<signal name="N$11">
<contactref element="R4" pad="1"/>
<contactref element="R3" pad="1"/>
<contactref element="U1" pad="17"/>
<contactref element="U1" pad="6"/>
<wire x1="-84.7725" y1="69.063" x2="-84.7725" y2="67.945" width="1.016" layer="16"/>
<wire x1="-84.7725" y1="67.945" x2="-84.7725" y2="66.675" width="1.016" layer="16"/>
<wire x1="-89.8525" y1="74.295" x2="-90.0044" y2="74.1431" width="0.8128" layer="16"/>
<wire x1="-90.0044" y1="74.1431" x2="-90.0044" y2="71.755" width="0.8128" layer="16"/>
<wire x1="-84.9245" y1="69.215" x2="-84.7725" y2="69.063" width="0.8128" layer="16"/>
<wire x1="-88.1063" y1="69.215" x2="-84.9245" y2="69.215" width="0.8128" layer="16"/>
<wire x1="-88.5825" y1="69.215" x2="-88.1063" y2="69.215" width="0.8128" layer="16"/>
<wire x1="-90.0044" y1="70.6369" x2="-88.5825" y2="69.215" width="0.8128" layer="16"/>
<wire x1="-90.0044" y1="71.755" x2="-90.0044" y2="70.6369" width="0.8128" layer="16"/>
</signal>
<signal name="N$13">
<contactref element="C55" pad="2"/>
<contactref element="C-REF" pad="2"/>
<contactref element="C8" pad="1"/>
<contactref element="L1" pad="2"/>
<contactref element="C5" pad="-"/>
<contactref element="CMEAS" pad="2"/>
<contactref element="S3" pad="3"/>
<wire x1="-53.975" y1="91.7575" x2="-47.625" y2="91.7575" width="1.016" layer="16"/>
<wire x1="-82.55" y1="91.7575" x2="-82.55" y2="93.268" width="1.016" layer="16"/>
<wire x1="-82.55" y1="93.268" x2="-81.203" y2="94.615" width="1.016" layer="16"/>
<wire x1="-81.203" y1="94.615" x2="-55.322" y2="94.615" width="1.016" layer="16"/>
<wire x1="-55.322" y1="94.615" x2="-53.975" y2="93.268" width="1.016" layer="16"/>
<wire x1="-53.975" y1="93.268" x2="-53.975" y2="92.075" width="1.016" layer="16"/>
<wire x1="-53.975" y1="92.075" x2="-53.975" y2="91.7575" width="0.8128" layer="16"/>
<wire x1="-91.1225" y1="88.975" x2="-93.905" y2="88.975" width="0.8128" layer="16"/>
<wire x1="-93.905" y1="88.975" x2="-94.615" y2="88.265" width="0.8128" layer="16"/>
<wire x1="-94.615" y1="88.265" x2="-94.615" y2="84.685" width="0.8128" layer="16"/>
<wire x1="-90.4875" y1="91.7575" x2="-82.55" y2="91.7575" width="1.016" layer="16"/>
<wire x1="-91.1225" y1="91.1225" x2="-90.4875" y2="91.7575" width="1.016" layer="16"/>
<wire x1="-91.1225" y1="88.975" x2="-91.1225" y2="91.1225" width="1.016" layer="16"/>
<wire x1="-47.625" y1="91.7575" x2="-35.8775" y2="91.805" width="1.016" layer="16"/>
<wire x1="-30.9405" y1="86.233" x2="-23.114" y2="86.233" width="1.016" layer="16"/>
<wire x1="-35.8775" y1="91.805" x2="-30.9405" y2="86.233" width="1.016" layer="16"/>
</signal>
<signal name="N$15">
<contactref element="U1" pad="12"/>
<contactref element="R10" pad="2"/>
<wire x1="-77.1525" y1="77.1525" x2="-77.1525" y2="74.295" width="1.016" layer="16"/>
<wire x1="-77.1525" y1="77.1525" x2="-55.88" y2="77.47" width="0.254" layer="1"/>
<wire x1="-55.88" y1="77.47" x2="-55.88" y2="75.0955" width="0.8128" layer="16"/>
<wire x1="-55.88" y1="75.0955" x2="-55.7145" y2="74.93" width="0.8128" layer="16"/>
<via x="-77.1525" y="77.1525" extent="1-16" drill="0.8" diameter="1.6764" shape="square"/>
<via x="-55.88" y="77.47" extent="1-16" drill="0.7" diameter="1.6764" shape="square"/>
</signal>
<signal name="N$17">
<contactref element="C-REF" pad="1"/>
<contactref element="Q4" pad="C"/>
<wire x1="-47.795" y1="75.8825" x2="-47.625" y2="75.8825" width="0.8128" layer="16"/>
<wire x1="-47.625" y1="75.8825" x2="-47.625" y2="81.5975" width="0.8128" layer="16"/>
<contactref element="R13" pad="2"/>
<wire x1="-47.625" y1="75.8825" x2="-45.568" y2="75.8825" width="0.6096" layer="16"/>
<wire x1="-45.568" y1="75.8825" x2="-45.4025" y2="75.717" width="0.6096" layer="16" curve="-90"/>
</signal>
<signal name="N$14">
<contactref element="R6" pad="2"/>
<contactref element="R7" pad="2"/>
<contactref element="S5" pad="3"/>
<contactref element="X2" pad="1"/>
<contactref element="C8" pad="2"/>
<wire x1="-82.2325" y1="79.2095" x2="-79.6925" y2="79.2095" width="1.016" layer="16"/>
<wire x1="-82.2325" y1="79.6925" x2="-82.2325" y2="79.2095" width="0.8128" layer="16"/>
<wire x1="-82.55" y1="80.01" x2="-82.2325" y2="79.6925" width="0.8128" layer="16"/>
<wire x1="-82.55" y1="81.5975" x2="-82.55" y2="80.01" width="1.016" layer="16"/>
<wire x1="-79.6925" y1="79.2095" x2="-77.953" y2="79.2095" width="1.016" layer="16"/>
<wire x1="-74.295" y1="80.645" x2="-74.295" y2="83.5279" width="1.016" layer="16"/>
<wire x1="-60.071" y1="81.3588" x2="-60.071" y2="83.82" width="1.016" layer="16"/>
<wire x1="-77.953" y1="79.2095" x2="-74.295" y2="79.2095" width="1.016" layer="16"/>
<wire x1="-74.295" y1="79.2095" x2="-74.295" y2="80.645" width="1.016" layer="16"/>
<wire x1="-62.2203" y1="79.2095" x2="-60.071" y2="81.3588" width="1.016" layer="16"/>
<wire x1="-74.295" y1="79.2095" x2="-62.2203" y2="79.2095" width="1.016" layer="16"/>
</signal>
<signal name="N$16">
<contactref element="R6" pad="1"/>
<contactref element="U1" pad="14"/>
<wire x1="-82.2325" y1="76.3655" x2="-82.2325" y2="74.295" width="1.016" layer="16"/>
</signal>
<signal name="N$18">
<contactref element="U1" pad="13"/>
<contactref element="R7" pad="1"/>
<wire x1="-79.6925" y1="76.3655" x2="-79.6925" y2="74.295" width="1.016" layer="16"/>
</signal>
<signal name="N$19">
<contactref element="U1" pad="19"/>
<contactref element="R8" pad="1"/>
<contactref element="ICSP" pad="4"/>
<wire x1="-94.9325" y1="75.565" x2="-94.9325" y2="74.295" width="0.8128" layer="16"/>
<wire x1="-95.885" y1="76.5175" x2="-94.9325" y2="75.565" width="0.8128" layer="16"/>
<wire x1="-99.06" y1="76.5175" x2="-95.885" y2="76.5175" width="0.8128" layer="16"/>
<wire x1="-101.2825" y1="74.295" x2="-99.06" y2="76.5175" width="0.8128" layer="16"/>
<wire x1="-103.8225" y1="74.295" x2="-101.2825" y2="74.295" width="0.8128" layer="16"/>
<wire x1="-106.3625" y1="74.295" x2="-103.8225" y2="74.295" width="0.8128" layer="16"/>
<wire x1="-106.9975" y1="74.93" x2="-106.3625" y2="74.295" width="0.8128" layer="16"/>
<wire x1="-106.9975" y1="76.835" x2="-106.9975" y2="74.93" width="0.8128" layer="16"/>
<wire x1="-106.9975" y1="80.645" x2="-106.9975" y2="76.835" width="0.8128" layer="16"/>
<wire x1="-105.8795" y1="81.763" x2="-106.9975" y2="80.645" width="0.8128" layer="16"/>
<wire x1="-100.0125" y1="81.763" x2="-105.8795" y2="81.763" width="0.8128" layer="16"/>
</signal>
<signal name="N$20">
<contactref element="R8" pad="2"/>
<contactref element="S5" pad="1"/>
<wire x1="-74.295" y1="87.9475" x2="-71.4375" y2="87.9475" width="1.016" layer="16"/>
<wire x1="-71.4375" y1="87.9475" x2="-69.5325" y2="86.0425" width="1.016" layer="16"/>
<wire x1="-69.5325" y1="86.0425" x2="-69.469" y2="83.82" width="1.016" layer="16"/>
<wire x1="-100.0125" y1="87.9475" x2="-100.0125" y2="84.607" width="0.8128" layer="16"/>
<wire x1="-74.295" y1="87.9475" x2="-100.0125" y2="87.9475" width="0.254" layer="1"/>
<via x="-100.0125" y="87.9475" extent="1-16" drill="0.8" diameter="1.6764" shape="square"/>
<via x="-74.295" y="87.9475" extent="1-16" drill="0.8" diameter="1.6764" shape="square"/>
</signal>
<signal name="N$21">
<contactref element="S5" pad="2"/>
<contactref element="R12" pad="2"/>
<wire x1="-64.77" y1="87.63" x2="-64.7125" y2="89.535" width="1.016" layer="16"/>
<wire x1="-64.77" y1="83.82" x2="-64.77" y2="87.63" width="1.016" layer="16"/>
</signal>
<signal name="N$22">
<contactref element="U1" pad="18"/>
<contactref element="R9" pad="1"/>
<contactref element="ICSP" pad="5"/>
<wire x1="-92.3925" y1="77.1525" x2="-92.3925" y2="74.295" width="0.8128" layer="16"/>
<wire x1="-92.3857" y1="77.1525" x2="-92.3925" y2="77.1525" width="0.8128" layer="16"/>
<wire x1="-102.3938" y1="76.835" x2="-103.8225" y2="76.835" width="0.8128" layer="16"/>
<wire x1="-100.965" y1="78.2638" x2="-102.3938" y2="76.835" width="0.8128" layer="16"/>
<wire x1="-96.3613" y1="78.2638" x2="-100.965" y2="78.2638" width="0.8128" layer="16"/>
<wire x1="-95.25" y1="78.2638" x2="-96.3613" y2="78.2638" width="0.8128" layer="16"/>
<wire x1="-94.1387" y1="77.1525" x2="-95.25" y2="78.2638" width="0.8128" layer="16"/>
<wire x1="-92.3857" y1="77.1525" x2="-94.1387" y2="77.1525" width="0.8128" layer="16"/>
</signal>
<signal name="N$23">
<contactref element="R9" pad="2"/>
<contactref element="S3" pad="4"/>
<wire x1="-89.535" y1="78.7467" x2="-89.5417" y2="77.1525" width="0.8128" layer="16"/>
<wire x1="-89.535" y1="79.2163" x2="-89.535" y2="78.7467" width="0.8128" layer="16"/>
<wire x1="-89.535" y1="79.2163" x2="-14.7638" y2="79.2163" width="0.254" layer="1"/>
<wire x1="-14.7638" y1="79.1845" x2="-13.716" y2="81.407" width="1.016" layer="16"/>
<wire x1="-14.7638" y1="79.2163" x2="-14.7638" y2="79.1845" width="1.016" layer="16"/>
<via x="-89.535" y="79.2163" extent="1-16" drill="0.7" diameter="1.6764" shape="square"/>
<via x="-14.7638" y="79.2163" extent="1-16" drill="0.7" diameter="1.4224" shape="square"/>
</signal>
<signal name="N$24">
<contactref element="L1" pad="1"/>
<contactref element="S3" pad="6"/>
<contactref element="S3" pad="1"/>
<wire x1="-16.129" y1="83.82" x2="-13.716" y2="86.233" width="0.8128" layer="16"/>
<wire x1="-18.415" y1="83.82" x2="-16.129" y2="83.82" width="0.8128" layer="16"/>
<wire x1="-23.114" y1="81.407" x2="-20.701" y2="83.82" width="0.8128" layer="16"/>
<wire x1="-20.701" y1="83.82" x2="-18.415" y2="83.82" width="0.8128" layer="16"/>
<wire x1="-23.368" y1="81.407" x2="-23.114" y2="81.407" width="1.016" layer="16"/>
<wire x1="-31.258" y1="81.407" x2="-23.368" y2="81.407" width="1.016" layer="16"/>
<wire x1="-35.8775" y1="77.105" x2="-31.258" y2="81.407" width="1.016" layer="16"/>
</signal>
<signal name="N$26">
<contactref element="X1" pad="1"/>
<contactref element="S3" pad="2"/>
<wire x1="-27.9654" y1="92.075" x2="-27.9654" y2="92.0496" width="1.016" layer="16"/>
<wire x1="-27.9654" y1="92.0496" x2="-27.94" y2="92.075" width="1.016" layer="16"/>
<wire x1="-27.94" y1="92.075" x2="-21.2725" y2="92.075" width="1.016" layer="16"/>
<wire x1="-21.2725" y1="92.075" x2="-20.6375" y2="92.075" width="1.016" layer="16"/>
<wire x1="-20.6375" y1="92.075" x2="-18.415" y2="89.8525" width="1.016" layer="16"/>
<wire x1="-18.415" y1="89.8525" x2="-18.415" y2="86.233" width="1.016" layer="16"/>
</signal>
<signal name="N$27">
<contactref element="U1" pad="4"/>
<contactref element="R5" pad="2"/>
<contactref element="ICSP" pad="1"/>
<wire x1="-107.163" y1="66.675" x2="-106.9975" y2="66.523" width="0.8128" layer="16" curve="90.03463"/>
<wire x1="-103.8225" y1="66.675" x2="-107.163" y2="66.675" width="0.8128" layer="16"/>
<wire x1="-89.8525" y1="66.675" x2="-89.8525" y2="64.135" width="0.6096" layer="16"/>
<wire x1="-89.8525" y1="64.135" x2="-89.8525" y2="62.865" width="0.6096" layer="16"/>
<wire x1="-89.8525" y1="62.865" x2="-92.075" y2="60.6425" width="0.6096" layer="16"/>
<wire x1="-92.075" y1="60.6425" x2="-99.695" y2="60.6425" width="0.6096" layer="16"/>
<wire x1="-99.695" y1="60.6425" x2="-103.8225" y2="64.77" width="0.6096" layer="16"/>
<wire x1="-103.8225" y1="64.77" x2="-103.8225" y2="66.675" width="0.6096" layer="16"/>
</signal>
<signal name="N$25">
<contactref element="C55" pad="1"/>
<contactref element="R3" pad="2"/>
<contactref element="R1" pad="2"/>
<contactref element="U1" pad="16"/>
<contactref element="R2" pad="2"/>
<contactref element="C5" pad="+"/>
<wire x1="-97.3945" y1="81.685" x2="-97.155" y2="81.763" width="0.8128" layer="16"/>
<wire x1="-94.615" y1="81.685" x2="-97.3945" y2="81.685" width="0.8128" layer="16"/>
<wire x1="-91.1225" y1="81.685" x2="-94.615" y2="81.685" width="0.8128" layer="16"/>
<wire x1="-91.1225" y1="81.915" x2="-91.1225" y2="82.475" width="0.8128" layer="16"/>
<wire x1="-91.1225" y1="81.915" x2="-91.1225" y2="81.685" width="0.8128" layer="16"/>
<wire x1="-87.3125" y1="82.0805" x2="-87.63" y2="81.915" width="0.8128" layer="16"/>
<wire x1="-87.63" y1="81.915" x2="-91.1225" y2="81.915" width="0.8128" layer="16"/>
<wire x1="-87.3125" y1="82.0805" x2="-87.3125" y2="74.295" width="1.016" layer="16"/>
<wire x1="-87.3125" y1="74.295" x2="-87.1604" y2="74.1429" width="0.8128" layer="16"/>
<wire x1="-87.1604" y1="74.1429" x2="-87.1604" y2="71.755" width="0.8128" layer="16"/>
</signal>
<signal name="N$29">
<contactref element="IC1" pad="3"/>
<contactref element="Q3" pad="3"/>
<contactref element="C3" pad="1"/>
<wire x1="-53.0225" y1="55.9675" x2="-51.5827" y2="55.9675" width="0.6096" layer="16"/>
<wire x1="-51.5827" y1="55.9675" x2="-49.8475" y2="57.7027" width="0.6096" layer="16"/>
<wire x1="-49.8475" y1="57.7027" x2="-49.8475" y2="58.7375" width="0.6096" layer="16"/>
<wire x1="-49.8475" y1="58.7375" x2="-42.545" y2="58.7375" width="1.016" layer="16"/>
<wire x1="-42.545" y1="58.7375" x2="-41.5925" y2="59.69" width="1.016" layer="16"/>
<wire x1="-41.5925" y1="59.69" x2="-40.9575" y2="60.325" width="0.6096" layer="16"/>
<wire x1="-40.9575" y1="60.325" x2="-40.9575" y2="61.765" width="0.6096" layer="16"/>
</signal>
<signal name="N$30">
<contactref element="Q2" pad="3"/>
<contactref element="R22" pad="1"/>
<wire x1="-45.72" y1="65.8745" x2="-46.355" y2="65.5705" width="0.6096" layer="16"/>
<wire x1="-46.355" y1="65.7225" x2="-45.72" y2="65.8745" width="0.6096" layer="16"/>
<wire x1="-46.355" y1="65.405" x2="-46.355" y2="65.7225" width="0.6096" layer="16"/>
<wire x1="-46.355" y1="63.33" x2="-46.355" y2="65.405" width="0.6096" layer="16"/>
</signal>
<signal name="N$31">
<contactref element="R22" pad="2"/>
<contactref element="R21" pad="1"/>
<contactref element="Q3" pad="1"/>
<contactref element="C21" pad="1"/>
<wire x1="-42.6925" y1="63.965" x2="-41.9075" y2="63.965" width="0.6096" layer="16"/>
<wire x1="-43.18" y1="64.4525" x2="-42.6925" y2="63.965" width="0.6096" layer="16"/>
<wire x1="-43.18" y1="66.04" x2="-43.18" y2="64.4525" width="0.6096" layer="16"/>
<wire x1="-43.0925" y1="66.04" x2="-43.18" y2="66.04" width="0.6096" layer="16"/>
<wire x1="-46.355" y1="68.4145" x2="-46.355" y2="68.58" width="0.6096" layer="16"/>
<wire x1="-43.0145" y1="66.04" x2="-43.0925" y2="66.04" width="0.8128" layer="16"/>
<wire x1="-43.0145" y1="68.58" x2="-43.0145" y2="66.04" width="0.8128" layer="16"/>
<wire x1="-46.355" y1="68.58" x2="-43.0145" y2="68.58" width="0.8128" layer="16"/>
<wire x1="-46.355" y1="68.4145" x2="-46.355" y2="68.58" width="0.8128" layer="16"/>
</signal>
<signal name="N$32">
<contactref element="R21" pad="2"/>
<contactref element="Q3" pad="2"/>
<contactref element="C21" pad="2"/>
<contactref element="C22" pad="2"/>
<contactref element="S1" pad="2"/>
<wire x1="-40.005" y1="66.04" x2="-40.0925" y2="66.04" width="0.6096" layer="16"/>
<wire x1="-40.1705" y1="68.58" x2="-40.083" y2="68.4925" width="1.016" layer="16"/>
<wire x1="-40.083" y1="68.4925" x2="-37.465" y2="68.4925" width="1.016" layer="16"/>
<wire x1="-37.465" y1="68.4925" x2="-32.0675" y2="68.4925" width="1.016" layer="16"/>
<wire x1="-40.0925" y1="68.58" x2="-40.1705" y2="68.58" width="1.016" layer="16"/>
<wire x1="-40.0075" y1="66.04" x2="-40.005" y2="66.04" width="0.8128" layer="16"/>
<wire x1="-40.0075" y1="63.965" x2="-40.0075" y2="66.04" width="0.8128" layer="16"/>
<wire x1="-40.0925" y1="66.04" x2="-40.0925" y2="68.58" width="0.8128" layer="16"/>
<wire x1="-32.0675" y1="68.4925" x2="-8.025" y2="68.4925" width="1.016" layer="16"/>
<wire x1="-8.025" y1="68.4925" x2="-4.445" y2="71.755" width="1.016" layer="16"/>
<wire x1="-4.445" y1="71.755" x2="-2.2225" y2="73.9775" width="1.016" layer="16"/>
<wire x1="-2.2225" y1="73.9775" x2="-2.2225" y2="83.82" width="1.016" layer="16"/>
</signal>
<signal name="N$10">
<contactref element="R24" pad="1"/>
<contactref element="S1" pad="3"/>
<wire x1="6.1845" y1="83.82" x2="6.35" y2="83.6545" width="1.016" layer="16"/>
<wire x1="2.4765" y1="83.82" x2="6.1845" y2="83.82" width="1.016" layer="16"/>
</signal>
<signal name="N$28">
<contactref element="S1" pad="1"/>
<contactref element="X4" pad="1"/>
<wire x1="-6.985" y1="76.8096" x2="-6.9215" y2="76.8731" width="1.016" layer="16"/>
<wire x1="-6.9215" y1="76.8731" x2="-6.9215" y2="83.82" width="1.016" layer="16"/>
</signal>
<signal name="N$34">
<contactref element="C22" pad="1"/>
<contactref element="Q2" pad="1"/>
<contactref element="R20" pad="1"/>
<wire x1="-37.465" y1="58.42" x2="-37.465" y2="65.4925" width="0.6096" layer="16"/>
<wire x1="-40.3225" y1="55.5625" x2="-37.465" y2="58.42" width="0.6096" layer="16"/>
<wire x1="-42.0755" y1="55.5625" x2="-40.3225" y2="55.5625" width="0.6096" layer="16"/>
<wire x1="-37.465" y1="65.4925" x2="-37.465" y2="60.96" width="0.6096" layer="16"/>
<wire x1="-37.465" y1="60.96" x2="-43.4975" y2="60.96" width="0.254" layer="1"/>
<wire x1="-43.4975" y1="60.96" x2="-43.645" y2="61.1075" width="0.6096" layer="16"/>
<wire x1="-43.645" y1="61.1075" x2="-45.405" y2="61.13" width="0.6096" layer="16"/>
<via x="-37.465" y="60.96" extent="1-16" drill="0.7" diameter="1.6764" shape="square"/>
<via x="-43.4975" y="60.96" extent="1-16" drill="0.7" diameter="1.6764" shape="square"/>
</signal>
<signal name="N$3">
<contactref element="LCD1" pad="12"/>
<contactref element="U1" pad="8"/>
<wire x1="-94.2975" y1="53.848" x2="-94.488" y2="53.6575" width="0.6096" layer="16"/>
<wire x1="-92.3925" y1="56.1975" x2="-92.5821" y2="56.1975" width="0.6096" layer="16"/>
<wire x1="-92.5821" y1="56.1975" x2="-94.2975" y2="54.4821" width="0.6096" layer="16"/>
<wire x1="-94.2975" y1="54.4821" x2="-94.2975" y2="53.848" width="0.6096" layer="16"/>
<wire x1="-91.7575" y1="56.1975" x2="-92.3925" y2="56.1975" width="0.6096" layer="16"/>
<wire x1="-79.6925" y1="64.77" x2="-82.8675" y2="61.595" width="0.6096" layer="16"/>
<wire x1="-79.6925" y1="66.675" x2="-79.6925" y2="64.77" width="0.6096" layer="16"/>
<wire x1="-82.8675" y1="61.595" x2="-83.185" y2="61.2775" width="0.6096" layer="16"/>
<wire x1="-86.995" y1="57.4675" x2="-89.2175" y2="57.4675" width="0.6096" layer="16"/>
<wire x1="-89.2175" y1="57.4675" x2="-90.4875" y2="57.4675" width="0.6096" layer="16"/>
<wire x1="-90.4875" y1="57.4675" x2="-91.7575" y2="56.1975" width="0.6096" layer="16"/>
<wire x1="-83.185" y1="61.2775" x2="-86.995" y2="57.4675" width="0.6096" layer="16"/>
</signal>
<signal name="N$33">
<via x="-35.8775" y="84.455" extent="1-16" drill="0.7" shape="square"/>
</signal>
<signal name="N$35">
<via x="-66.3575" y="61.2775" extent="1-16" drill="0.8" shape="square"/>
</signal>
<signal name="N$36">
<polygon width="0.254" layer="16" isolate="1.016">
<vertex x="-109.855" y="94.9325"/>
<vertex x="-88.265" y="94.9325"/>
<vertex x="-88.265" y="81.5975"/>
<vertex x="-110.49" y="81.5975"/>
<vertex x="-110.49" y="94.9325"/>
</polygon>
</signal>
<signal name="N$37">
<contactref element="R10" pad="1"/>
<contactref element="Q4" pad="B"/>
<wire x1="-49.995" y1="74.9325" x2="-51.265" y2="74.948" width="0.8128" layer="16"/>
<wire x1="-51.265" y1="74.948" x2="-52.8705" y2="74.93" width="0.8128" layer="16"/>
</signal>
</signals>
<mfgpreviewcolors>
<mfgpreviewcolor name="soldermaskcolor" color="0xC8008000"/>
<mfgpreviewcolor name="silkscreencolor" color="0xFFFEFEFE"/>
<mfgpreviewcolor name="backgroundcolor" color="0xFF282828"/>
<mfgpreviewcolor name="coppercolor" color="0xFFFFBF00"/>
<mfgpreviewcolor name="substratecolor" color="0xFF786E46"/>
</mfgpreviewcolors>
</board>
</drawing>
</eagle>
