	       Analog Devices Inc. SoundMAX(R) Readme
INSTALLATION AND REMOVAL INSTRUCTIONS:
Installation or Update of Analog Devices SoundMAX
  NOTE: Remove any previously installed driver using the instructions
        in the next section.
1.  From the task bar, click on Start -> Run.
2.  In the Run dialog box, type X:\path\setup, where X:\path is the
    full path to the root of the installation media.
3.  When upgrading or reinstalling, a dialog will appear. Select
    Reinstall and press Next.
4.  Click on the OK button or press the ENTER key.
5.  Click on the Next and OK prompts as they appear.
6.  Reboot the system to complete the installation.
Removal of Analog Devices SoundMAX
1.  From the task bar, click on Start -> Settings -> Control Panel,
    or for Windows XP, click on Start -> Control Panel.
2.  Double-click on the Add/Remove programs icon.
3.  Double-click on SoundMAX Install.
4.  If the installation media is present, a dialog will appear.
    Select Remove and press Next.
5.  Reboot the system to fully uninstall the drivers.
NOTES:
* Microsoft(R) DirectX 9.0 or later is required.
UNATTENDED (SILENT) INSTALLATION INSTRUCTIONS
Unattended installations use an Install Shield Silent Response
File (setup.iss) to provide user input.
Running an Unattended (Silent) Installation
Run SETUP.EXE as described in the installation section above, but with
the -s parameter to use the .iss file that is provided with the driver.
To use a different setup.iss file, use the -f1 parameter to provide the
full path to the file.
  NOTE: When running an installation in silent mode, no messages
        are displayed. Instead, a log file named Setup.log captures
        installation information, including whether the installation
        was successful. The -f2 parameter can be used to control
        where the log file is created.
Running an Unattended (Silent) Uninstallation
2.  In the Run dialog box, type X:\path\setup -s REMOVE,
    where X:\path is the full path to the root of the
    installation media.
3.  Reboot the system to fully uninstall the drivers.
This driver is built for the Microsoft(R) Windows Operating Systems.
Copyright 2005 Analog Devices, Inc. All names mentioned herein
are a registered trademark or a trademark of Analog Devices or its
respective owners. All rights reserved.
			Version 5.0.0.4
