<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="7.1.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="1.27" unitdist="mm" unit="mm" style="lines" multiple="1" display="yes" altdistance="0.127" altunitdist="mm" altunit="mm"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="yes" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="90" name="Modules" color="5" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
</layers>
<library>
<description>&lt;TEXAS INSTRUMENTS - LM723CH/NOPB - V REG ADJ +2/37V, TO-100-10, 723&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by SamacSys&lt;/author&gt;</description>
<packages>
<package name="LME(O-MBCY-W10)">
<description>&lt;b&gt;LME(O-MBCY-W10)&lt;/b&gt;&lt;br&gt;
</description>
<pad name="1" x="-0.55766875" y="1.71633125" drill="0.73" diameter="1.23"/>
<pad name="10" x="0" y="0" drill="0.73" diameter="1.23"/>
<pad name="9" x="1.46" y="-1.06075" drill="0.73" diameter="1.23"/>
<pad name="8" x="3.264659375" y="-1.06075" drill="0.73" diameter="1.23"/>
<pad name="7" x="4.724659375" y="0" drill="0.73" diameter="1.23"/>
<pad name="6" x="5.28233125" y="1.71633125" drill="0.73" diameter="1.23"/>
<pad name="5" x="4.724659375" y="3.43266875" drill="0.73" diameter="1.23"/>
<pad name="4" x="3.264659375" y="4.49341875" drill="0.73" diameter="1.23"/>
<pad name="3" x="1.46" y="4.49341875" drill="0.73" diameter="1.23"/>
<pad name="2" x="0" y="3.43266875" drill="0.73" diameter="1.23"/>
<text x="2.13" y="7.71" size="1.27" layer="25" align="center">&gt;NAME</text>
<text x="2.13" y="-4.99" size="1.27" layer="27" align="center">&gt;VALUE</text>
<wire x1="-1.871734375" y1="-1.45918125" x2="-2.284028125" y2="-0.52195" width="0.254" layer="21" curve="-151.927513"/>
<wire x1="-2.284028125" y1="-0.52195" x2="-1.725709375" y2="-0.069834375" width="0.254" layer="21"/>
<wire x1="-1.871734375" y1="-1.45918125" x2="-1.0740875" y2="-1.15991875" width="0.254" layer="21"/>
<wire x1="-1.725709375" y1="-0.069834375" x2="-1.0740875" y2="-1.15991875" width="0.254" layer="21" curve="-343.739795"/>
</package>
</packages>
<symbols>
<symbol name="LM723CH_NOPB">
<wire x1="5.08" y1="2.54" x2="66.04" y2="2.54" width="0.254" layer="94"/>
<wire x1="66.04" y1="-12.7" x2="66.04" y2="2.54" width="0.254" layer="94"/>
<wire x1="66.04" y1="-12.7" x2="5.08" y2="-12.7" width="0.254" layer="94"/>
<wire x1="5.08" y1="2.54" x2="5.08" y2="-12.7" width="0.254" layer="94"/>
<text x="67.31" y="7.62" size="1.778" layer="95" align="center-left">&gt;NAME</text>
<text x="67.31" y="5.08" size="1.778" layer="96" align="center-left">&gt;VALUE</text>
<pin name="CURRENT_SENSE" x="0" y="0" length="middle"/>
<pin name="INVERTING_INPUT" x="0" y="-2.54" length="middle"/>
<pin name="NON-INVERTING_INPUT" x="0" y="-5.08" length="middle"/>
<pin name="VREF" x="0" y="-7.62" length="middle"/>
<pin name="V-" x="0" y="-10.16" length="middle"/>
<pin name="VOUT" x="71.12" y="0" length="middle" rot="R180"/>
<pin name="VC" x="71.12" y="-2.54" length="middle" rot="R180"/>
<pin name="V+" x="71.12" y="-5.08" length="middle" rot="R180"/>
<pin name="FREQUENCY_COMPENSATION" x="71.12" y="-7.62" length="middle" rot="R180"/>
<pin name="CURRENT_LIMIT" x="71.12" y="-10.16" length="middle" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="LM723CH_NOPB" prefix="IC">
<gates>
<gate name="G$1" symbol="LM723CH_NOPB" x="0" y="0"/>
</gates>
<devices>
<device name="" package="LME(O-MBCY-W10)">
<connects>
<connect gate="G$1" pin="CURRENT_LIMIT" pad="10"/>
<connect gate="G$1" pin="CURRENT_SENSE" pad="1"/>
<connect gate="G$1" pin="FREQUENCY_COMPENSATION" pad="9"/>
<connect gate="G$1" pin="INVERTING_INPUT" pad="2"/>
<connect gate="G$1" pin="NON-INVERTING_INPUT" pad="3"/>
<connect gate="G$1" pin="V+" pad="8"/>
<connect gate="G$1" pin="V-" pad="5"/>
<connect gate="G$1" pin="VC" pad="7"/>
<connect gate="G$1" pin="VOUT" pad="6"/>
<connect gate="G$1" pin="VREF" pad="4"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
