#include <p16F690.inc>          ; remove this if not necessary
#define PRECISION 2             ; byte size for registers
M_STOR_STATUS macro WHERE
    movf    STATUS,w
    movwf   WHERE
    endm
M_RETR_STATUS macro WHERE
    movf    WHERE,w
    movwf   STATUS
    endm
    cblock 0x20
    REG_X:PRECISION
    REG_Y:PRECISION
    REG_Z:PRECISION
    REG_COUNTER
    REG_STATUS
    REG_T1
    REG_T2
    REG_ROT_COUNTER
    endc
    org 0x00
    goto    M_TEST
    org 0x04
    goto    M_TEST
    org 0x0c
M_TEST                          ; Test subroutine
    movlw   REG_X
    call    M_CLR               ; clear register X
    movlw   REG_Y
    call    M_CLR               ; clear register Y
    movlw   REG_Z
    call    M_CLR               ; clear register Z
    movlw   0x8A
    movwf   REG_X               ; set register X (lowest byte)
    movlw   0xFC
    movwf   REG_Z               ; set register Z (lowest byte)
    call    M_ADD               ; adds X and Z, result in Z
    movlw   0x05                ; set register X (lowest byte)
    movwf   REG_X
    call    M_DIV               ; divide Z by X, result in Y, remainder in Z
    movlw   0x05                ; multiply Y by X -> Z
    movwf   REG_X
    call    M_MUL
    movlw   0xFC                ; subtract X from Z -> Z
    movwf   REG_X
    call    M_SUB
    sleep                       ; end of test
M_CLR                           ; clear a register
    movwf   FSR
    movlw   PRECISION
    movwf   REG_COUNTER
M_CLR_loop
    clrf    INDF
    incf    FSR,f
    decf    REG_COUNTER,f
    btfss   STATUS,Z
    goto    M_CLR_loop
    return
M_INC                           ; increment a register
    movwf   FSR
    movlw   PRECISION
    movwf   REG_COUNTER
M_INC_loop
    incf    INDF,f
    btfss   STATUS,Z
    return
    incf    FSR,f
    decf    REG_COUNTER,f
    btfss   STATUS,Z
    goto    M_INC_loop
    return
M_DEC                           ; decrement a register
    movwf   FSR
    movlw   PRECISION
    movwf   REG_COUNTER
M_DEC_loop
    decf    INDF,f
    movlw   0xFF
    subwf   INDF,w
    btfss   STATUS,Z
    return
    incf    FSR,f
    decf    REG_COUNTER,f
    btfss   STATUS,Z
    goto    M_DEC_loop
    return
M_ROL                           ; rotate a register to the left
    movwf   FSR
    M_STOR_STATUS REG_STATUS
    clrf    REG_COUNTER
M_ROL_loop
    M_RETR_STATUS REG_STATUS
    rlf     INDF,f
    incf    FSR,f
    incf    REG_COUNTER,f
    movlw   PRECISION
    subwf   REG_COUNTER,w
    btfss   STATUS,Z
    goto    M_ROL_loop
    return
M_ROR                           ; rotates a register to the right
    movwf   FSR
    movlw   PRECISION-1
    addwf   FSR,f
    clrf    REG_COUNTER
M_ROR_loop
    rrf     INDF,f
    decf    FSR,f
    incf    REG_COUNTER,f
    movlw   PRECISION
    subwf   REG_COUNTER,w
    btfss   STATUS,Z
    goto    M_ROR_loop
    return
M_CMP                           ; Z <=> X -> STATUS(C,Z)
                                ; STATUS,C set if Z => X;
                                ; STATUS,Z set if Z == X
    clrf    REG_COUNTER
M_CMP_loop
    movf    REG_COUNTER,w
    sublw   REG_Z+PRECISION-1
    movwf   FSR
    movf    INDF,w
    movwf   REG_T1
    movf    REG_COUNTER,w
    sublw   REG_X+PRECISION-1
    movwf   FSR
    movf    INDF,w
    subwf   REG_T1,f
    btfss   STATUS,Z
    return
    incf    REG_COUNTER,f
    movlw   PRECISION
    subwf   REG_COUNTER,w
    btfss   STATUS,Z
    goto    M_CMP_loop
    return
M_ADD                           ; Z + X -> Z
    bcf     STATUS,C
    clrf    REG_STATUS
    clrf    REG_COUNTER
M_ADD_loop
    clrf    REG_T1
    btfsc   REG_STATUS,C
    incf    REG_T1,f
    clrf    REG_STATUS
    movlw   REG_X
    addwf   REG_COUNTER,w
    movwf   FSR
    movf    INDF,w
    addwf   REG_T1,f
    btfsc   STATUS,C
    bsf     REG_STATUS,C
    movlw   REG_Z
    addwf   REG_COUNTER,w
    movwf   FSR
    movf    INDF,w
    addwf   REG_T1,f
    btfsc   STATUS,C
    bsf     REG_STATUS,C
    movf    REG_T1,w
    movwf   INDF
    incf    REG_COUNTER,f
    movlw   PRECISION
    subwf   REG_COUNTER,w
    btfss   STATUS,Z
    goto    M_ADD_loop
    return
M_SUB                           ; Z - X -> Z
    clrf    REG_COUNTER
    bsf     REG_STATUS,C
M_SUB_loop
    bsf     REG_T2,C
    movlw   REG_Z
    addwf   REG_COUNTER,w
    movwf   FSR
    movf    INDF,w
    movwf   REG_T1
    movlw   REG_X
    addwf   REG_COUNTER,w
    movwf   FSR
    movf    INDF,w
    subwf   REG_T1,f
    btfss   STATUS,C
    bcf     REG_T2,C
    btfsc   REG_STATUS,C
    goto    M_SUB_no_carry
    movlw   0x01
    subwf   REG_T1,f
    btfss   STATUS,C
    bcf     REG_T2,C
M_SUB_no_carry
    movlw   REG_Z
    addwf   REG_COUNTER,w
    movwf   FSR
    movf    REG_T1,w
    movwf   INDF
    bsf     REG_STATUS,C
    btfss   REG_T2,C
    bcf     REG_STATUS,C
    incf    REG_COUNTER,f
    movlw   PRECISION
    subwf   REG_COUNTER,w
    btfss   STATUS,Z
    goto    M_SUB_loop
    btfss   REG_STATUS,C
    bcf     STATUS,C
    return
M_MUL                           ; X * Y -> Z
    movlw   REG_Z
    call    M_CLR
    movlw   PRECISION*8+1
    movwf   REG_ROT_COUNTER
M_MUL_loop
    decf    REG_ROT_COUNTER,f
    btfsc   STATUS,Z
    return
    btfsc   REG_Y,0
    call    M_ADD
    bcf     STATUS,C
    movlw   REG_Y
    call    M_ROR
    bcf     STATUS,C
    movlw   REG_X
    call    M_ROL
    goto    M_MUL_loop
M_DIV                           ; Z / X -> Y;  remainder -> Z
    movlw   REG_Y
    call    M_CLR
    movlw   PRECISION*8
M_DIV_rot_loop
    btfsc   REG_X+PRECISION-1,7
    goto    M_DIV_loop
    movlw   REG_X
    bcf     STATUS,C
    call    M_ROL
    btfss   STATUS,Z
    goto    M_DIV_rot_loop
    bsf     STATUS,Z
    return
M_DIV_loop
    call    M_CMP
    M_STOR_STATUS REG_T2
    movlw   REG_Y
    call    M_ROL
    M_RETR_STATUS REG_T2
    btfsc   STATUS,C
    call    M_SUB
    bcf     STATUS,Z
    bcf     STATUS,C
    movlw   REG_X
    call    M_ROR
    incf    REG_ROT_COUNTER,f
    movlw   PRECISION*8+1
    subwf   REG_ROT_COUNTER,w
    btfss   STATUS,Z
    goto    M_DIV_loop
    return    
    END
