;   This file is a basic code template for object module code         *
;   generation on the PIC16F690. This file contains the               *
;   basic code building blocks to build upon.  As a project minimum   *
;   the 16F690.lkr file will also be required for this file to        *
;   correctly build. The .lkr files are located in the MPLAB          *
;   directory.                                                        *
;   If interrupts are not used all code presented between the         *
;   code section "INT_VECTOR and code section "MAIN" can be removed.  *
;   In addition the variable assignments for 'w_temp' and             *
;   'status_temp' can be removed.                                     *
;   If interrupts are used, as in this template file, the 16F690.lkr  *
;   file will need to be modified as follows: Remove the lines        *
;     CODEPAGE   NAME=vectors  START=0x0      END=0x4      PROTECTED  *
;   and                                                               *
;     SECTION    NAME=STARTUP  ROM=vectors                            *
;   and change the start address of the page0 section from 0x5 to 0x0 *
;   Refer to the MPASM User's Guide for additional information on     *
;   features of the assembler and linker (Document DS33014).          *
;   Refer to the respective PIC data sheet for additional            *
;   information on the instruction set.                               *
;    Filename:	    xxx.asm                                           *
;    Date:                                                            *
;    File Version:                                                    *
;    Author:                                                          *
;    Company:                                                         *
;    Files required:                                                  *
;                    16F690.lkr                                       *
;    Notes:                                                           *
	list      p=16F690           ; list directive to define processor
	#include <p16F690.inc>        ; processor specific variable definitions
	errorlevel  -302              ; suppress message 302 from list file 
 __CONFIG _CP_OFF & _CPD_OFF & _BOR_OFF & _MCLRE_ON & _WDT_OFF & _PWRTE_ON & _INTRC_OSC_NOCLKOUT & _FCMEN_OFF & _IESO_OFF
#define PRECISION 2             ; byte size for registers
M_STOR_STATUS macro WHERE
    movf    STATUS,w
    movwf   WHERE
    endm
M_RETR_STATUS macro WHERE
    movf    WHERE,w
    movwf   STATUS
    endm
    cblock 0x20
    REG_X:PRECISION
    REG_Y:PRECISION
    REG_Z:PRECISION
    REG_COUNTER
    REG_STATUS
    REG_T1
    REG_T2
    REG_ROT_COUNTER
    endc
    org 0x00
    goto    M_TEST
    org 0x04
    goto    M_TEST
    org 0x0c
M_TEST                          ; Test subroutine
    movlw   REG_X
    call    M_CLR               ; clear register X
    movlw   REG_Y
    call    M_CLR               ; clear register Y
    movlw   REG_Z
    call    M_CLR               ; clear register Z
    movlw   0x00		; set register X (lowest byte)
    movwf   REG_X               
	movlw   0x04		; set register X (highest byte)
    movwf   REG_X+1  
	movlw   0x03		; set register Y (lowest byte)
    movwf   REG_Y               
	call	 M_MUL		;X * Y -> Z
	movwf	REG_X
	movwf	REG_X+1	
	call	M_SUB		; Z - X -> Z
	movlw	0x19		; set register Y (lowest byte)
	movwf	REG_Y
	movf REG_Z,w		; set Z lowest to X lowest
	movwf REG_X
	movf REG_Z+1,w		; set Z highest to X highest
	movwf REG_X+1
	movwf	REG_X
	movlw	0x02		; set register X (highest byte)
	movwf	REG_X+1
	call M_DIV		; Z * X -> Y
M_CLR                           ; clear a register
    movwf   FSR
    movlw   PRECISION
    movwf   REG_COUNTER
M_CLR_loop
    clrf    INDF
    incf    FSR,f
    decf    REG_COUNTER,f
    btfss   STATUS,Z
    goto    M_CLR_loop
    return
M_INC                           ; increment a register
    movwf   FSR
    movlw   PRECISION
    movwf   REG_COUNTER
M_INC_loop
    incf    INDF,f
    btfss   STATUS,Z
    return
    incf    FSR,f
    decf    REG_COUNTER,f
    btfss   STATUS,Z
    goto    M_INC_loop
    return
M_DEC                           ; decrement a register
    movwf   FSR
    movlw   PRECISION
    movwf   REG_COUNTER
M_DEC_loop
    decf    INDF,f
    movlw   0xFF
    subwf   INDF,w
    btfss   STATUS,Z
    return
    incf    FSR,f
    decf    REG_COUNTER,f
    btfss   STATUS,Z
    goto    M_DEC_loop
    return
M_ROL                           ; rotate a register to the left
    movwf   FSR
    M_STOR_STATUS REG_STATUS
    clrf    REG_COUNTER
M_ROL_loop
    M_RETR_STATUS REG_STATUS
    rlf     INDF,f
    incf    FSR,f
    incf    REG_COUNTER,f
    movlw   PRECISION
    subwf   REG_COUNTER,w
    btfss   STATUS,Z
    goto    M_ROL_loop
    return
M_ROR                           ; rotates a register to the right
    movwf   FSR
    movlw   PRECISION-1
    addwf   FSR,f
    clrf    REG_COUNTER
M_ROR_loop
    rrf     INDF,f
    decf    FSR,f
    incf    REG_COUNTER,f
    movlw   PRECISION
    subwf   REG_COUNTER,w
    btfss   STATUS,Z
    goto    M_ROR_loop
    return
M_CMP                           ; Z <=> X -> STATUS(C,Z)
                                ; STATUS,C set if Z => X;
                                ; STATUS,Z set if Z == X
    clrf    REG_COUNTER
M_CMP_loop
    movf    REG_COUNTER,w
    sublw   REG_Z+PRECISION-1
    movwf   FSR
    movf    INDF,w
    movwf   REG_T1
    movf    REG_COUNTER,w
    sublw   REG_X+PRECISION-1
    movwf   FSR
    movf    INDF,w
    subwf   REG_T1,f
    btfss   STATUS,Z
    return
    incf    REG_COUNTER,f
    movlw   PRECISION
    subwf   REG_COUNTER,w
    btfss   STATUS,Z
    goto    M_CMP_loop
    return
M_ADD                           ; Z + X -> Z
    bcf     STATUS,C
    clrf    REG_STATUS
    clrf    REG_COUNTER
M_ADD_loop
    clrf    REG_T1
    btfsc   REG_STATUS,C
    incf    REG_T1,f
    clrf    REG_STATUS
    movlw   REG_X
    addwf   REG_COUNTER,w
    movwf   FSR
    movf    INDF,w
    addwf   REG_T1,f
    btfsc   STATUS,C
    bsf     REG_STATUS,C
    movlw   REG_Z
    addwf   REG_COUNTER,w
    movwf   FSR
    movf    INDF,w
    addwf   REG_T1,f
    btfsc   STATUS,C
    bsf     REG_STATUS,C
    movf    REG_T1,w
    movwf   INDF
    incf    REG_COUNTER,f
    movlw   PRECISION
    subwf   REG_COUNTER,w
    btfss   STATUS,Z
    goto    M_ADD_loop
    return
M_SUB                           ; Z - X -> Z
    clrf    REG_COUNTER
    bsf     REG_STATUS,C
M_SUB_loop
    bsf     REG_T2,C
    movlw   REG_Z
    addwf   REG_COUNTER,w
    movwf   FSR
    movf    INDF,w
    movwf   REG_T1
    movlw   REG_X
    addwf   REG_COUNTER,w
    movwf   FSR
    movf    INDF,w
    subwf   REG_T1,f
    btfss   STATUS,C
    bcf     REG_T2,C
    btfsc   REG_STATUS,C
    goto    M_SUB_no_carry
    movlw   0x01
    subwf   REG_T1,f
    btfss   STATUS,C
    bcf     REG_T2,C
M_SUB_no_carry
    movlw   REG_Z
    addwf   REG_COUNTER,w
    movwf   FSR
    movf    REG_T1,w
    movwf   INDF
    bsf     REG_STATUS,C
    btfss   REG_T2,C
    bcf     REG_STATUS,C
    incf    REG_COUNTER,f
    movlw   PRECISION
    subwf   REG_COUNTER,w
    btfss   STATUS,Z
    goto    M_SUB_loop
    btfss   REG_STATUS,C
    bcf     STATUS,C
    return
M_MUL                           ; X * Y -> Z
    movlw   REG_Z
    call    M_CLR
    movlw   PRECISION*8+1
    movwf   REG_ROT_COUNTER
M_MUL_loop
    decf    REG_ROT_COUNTER,f
    btfsc   STATUS,Z
    return
    btfsc   REG_Y,0
    call    M_ADD
    bcf     STATUS,C
    movlw   REG_Y
    call    M_ROR
    bcf     STATUS,C
    movlw   REG_X
    call    M_ROL
    goto    M_MUL_loop
	return
M_DIV                           ; Z / X -> Y;  remainder -> Z
    movlw   REG_Y
    call    M_CLR
    movlw   PRECISION*8
M_DIV_rot_loop
    btfsc   REG_X+PRECISION-1,7
    goto    M_DIV_loop
    movlw   REG_X
    bcf     STATUS,C
    call    M_ROL
    btfss   STATUS,Z
    goto    M_DIV_rot_loop
    bsf     STATUS,Z
    return
M_DIV_loop
    call    M_CMP
    M_STOR_STATUS REG_T2
    movlw   REG_Y
    call    M_ROL
    M_RETR_STATUS REG_T2
    btfsc   STATUS,C
    call    M_SUB
    bcf     STATUS,Z
    bcf     STATUS,C
    movlw   REG_X
    call    M_ROR
    incf    REG_ROT_COUNTER,f
    movlw   PRECISION*8+1
    subwf   REG_ROT_COUNTER,w
    btfss   STATUS,Z
    goto    M_DIV_loop
    return    
    END
