; Source created with Parsic Version 3.x
; at              : 2008.12.02. 22:44:24
; Project File    : C:\PROGRA~1\Parsic\Examples\HE\EE02.PIC
; Project Version : 1.0.2
; Created         : 2008.12.02. 22:28:26
; Last change     : 2008.12.02. 22:44:23
	PROCESSOR 16F876
	INCLUDE P16F876.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_ON & _WDT_OFF & _BODEN_ON & _XT_OSC & _LVP_OFF & _CPD_OFF & _DEBUG_OFF
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
ZV2	= 32	; located in Bank 0
ZV2_HI	= 33	; located in Bank 0
EE1_FD	= 34	; located in Bank 0
ZV1	= 35	; located in Bank 0
ZV1_HI	= 36	; located in Bank 0
ZV1_FD	= 37	; located in Bank 0
S1	= 38	; located in Bank 0
LT1_FD	= 39	; located in Bank 0
TR1	= 40	; located in Bank 0
TR1_HI	= 41	; located in Bank 0
ZV2_FD	= 42	; located in Bank 0
OS1_FD	= 43	; located in Bank 0
ADC0	= 44	; located in Bank 0
ADC0_HI	= 45	; located in Bank 0
S0	= 46	; located in Bank 0
OS2_FD	= 47	; located in Bank 0
LT2_FD	= 48	; located in Bank 0
RAM	= 49	; located in Bank 0
SYS_TMP1	= 114	; located in Bank 0, 1, 2, 3
SYS_TMP2	= 115	; located in Bank 0, 1, 2, 3
SYS_TMP3	= 116	; located in Bank 0, 1, 2, 3
SYS_TMP4	= 117	; located in Bank 0, 1, 2, 3
SYS_TMP5	= 118	; located in Bank 0, 1, 2, 3
SYS_TMP6	= 119	; located in Bank 0, 1, 2, 3
SYS_TMP9	= 120	; located in Bank 0, 1, 2, 3
SYS_TMP10	= 121	; located in Bank 0, 1, 2, 3
SYS_WSAV	= 122	; located in Bank 0, 1, 2, 3
SYS_SSAV	= 123	; located in Bank 0, 1, 2, 3
SYS_PSAV	= 124	; located in Bank 0, 1, 2, 3
SYS_FSAV	= 125	; located in Bank 0, 1, 2, 3
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	CLRF STATUS	; switch to RAM-Bank 0
	MOVLW HIGH SYS_INIT	; set page
	MOVWF PCLATH
	GOTO SYS_INIT
;Interrupt-Adress
	MOVWF SYS_WSAV	; save register
	SWAPF STATUS,W
	CLRF STATUS	; bank 0
	MOVWF SYS_SSAV
	MOVFW FSR
	MOVWF SYS_FSAV
	MOVFW PCLATH
	MOVWF SYS_PSAV
	CLRF PCLATH
	BTFSS INTCON,T0IF	; TMR0 ?
	GOTO NOTMR0INT
	BCF INTCON,T0IF	; Interrupt quitieren
	BCF STATUS,RP0	; Bank 0
	BCF STATUS,RP1	; Bank 0
	INCFSZ TR1,F
	GOTO SYS_INT_LABEL_0
	INCF TR1_HI,F
SYS_INT_LABEL_0
NOTMR0INT
EXITINT
	MOVFW SYS_PSAV
	MOVWF PCLATH
	MOVFW SYS_FSAV
	MOVWF FSR
	SWAPF SYS_SSAV,W	; Register zurück
	MOVWF STATUS
	SWAPF SYS_WSAV,F
	SWAPF SYS_WSAV,W
	RETFIE
; Subroutines
; Read  -> AN0
READ_AN0
	MOVLW B'100'
	BSF STATUS,RP0	; Bank 1
	BCF STATUS,RP1	; Bank 1
	MOVWF ADCON1
	BSF TRISA,0
	BSF ADCON1,ADFM	; Right-Justified
	MOVLW B'11000001'	; CH0
	MOVWF ADCON0
	MOVLW 5
	MOVWF SYS_TMP1
SYS_ADC_LABEL_0
	DECFSZ SYS_TMP1,F
	GOTO SYS_ADC_LABEL_0
	BSF ADCON0,GO	; Start convert
SYS_ADC_LABEL_1
	BTFSC ADCON0,GO	; ready ?
	GOTO SYS_ADC_LABEL_1	; no
	MOVFW ADRESL
	MOVWF ADC0
	MOVFW ADRESH
	MOVWF ADC0_HI
	MOVLW 6
	MOVWF ADCON1
	MOVLW B'11111111'
	MOVWF TRISA
	RETURN
; Subroutines for LB1
LCD_LB1_INIT
	BCF PORTB,4	; ir-register
LCD_LB1_L1
	CALL LCD_LB1_OUT4
	DECFSZ SYS_TMP1,F
	GOTO LCD_LB1_L1
	MOVFW PORTB
	ANDLW H'F0'
	IORLW B'0011'	; Function Set
	MOVWF PORTB
	BSF PORTB,5	; write
	GOTO $+1
	BCF PORTB,5
	BSF SYS_TMP1,5	; wait
LCD_LB1_L2
	CALL LCD_LB1_OUT4
	DECFSZ SYS_TMP1,F
	GOTO LCD_LB1_L2
	BSF PORTB,5	; write
	GOTO $+1
	BCF PORTB,5
	CALL LCD_LB1_OUT4
	BSF PORTB,5	; write
	GOTO $+1
	BCF PORTB,5
	CALL LCD_LB1_OUT4
	BCF PORTB,0	; 4-Bit Interface
	BSF PORTB,5	; write
	GOTO $+1
	BCF PORTB,5
	CALL LCD_LB1_OUT4
	MOVLW B'00101000'	; Function Set 4-Bit,2-Lines
	CALL LCD_LB1_OUT
	MOVLW B'00001100'	; Display on, Cursor off, Blink off
	CALL LCD_LB1_OUT
	MOVLW B'00000110'	; Entrymode set
	CALL LCD_LB1_OUT
LCD_LB1_CLR
	MOVLW B'00000001'	; Display clear
	CALL LCD_LB1_OUT
LCD_LB1_L3
	CALL LCD_LB1_OUT4
	DECFSZ SYS_TMP1,F
	GOTO LCD_LB1_L3
	GOTO LCD_LB1_OUT4
LCD_LB1_GOTOXY
	MOVLW H'40'
	BTFSC SYS_TMP2,0	; Ypos
	ADDWF SYS_TMP1,F
	MOVLW D'20'
	BTFSC SYS_TMP2,1	; Ypos
	ADDWF SYS_TMP1,F
	BSF SYS_TMP1,7	; select dd-ram
	GOTO LCD_LB1_OUT1
LCD_LB1_WRITESTR
	BSF PORTB,4	; dd-ram
LCD_LB1_WRITESTR1
	CALL LCD_LB1_CHAROUT
	BSF INTCON,GIE
	ANDLW H'FF'	; last is zero
	BTFSC STATUS,ZERO
	RETURN
	MOVWF SYS_TMP1
	MOVLW HIGH LCD_LB1_OUT1	; set page
	MOVWF PCLATH
	CALL LCD_LB1_OUT1
	INCFSZ SYS_TMP4,F	; next char
	GOTO LCD_LB1_WRITESTR1
	INCF SYS_TMP5,F	; next page
LCD_LB1_CHAROUT
	BCF INTCON,GIE
	MOVFW SYS_TMP5
	MOVWF PCLATH
	MOVFW SYS_TMP4
	MOVWF PCL
LCD_LB1_DEZO10000
	MOVLW LOW 10000
	MOVWF SYS_TMP1
	MOVLW HIGH 10000
	MOVWF SYS_TMP2
	CALL LCD_LB1_CONVERTDEZ
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
	GOTO LCD_LB1_DEZO1000
	CALL LCD_LB1_CHECKNULL
LCD_LB1_DEZO1000
	MOVLW LOW 1000
	MOVWF SYS_TMP1
	MOVLW HIGH 1000
	MOVWF SYS_TMP2
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
LCD_LB1_DEZO100
	MOVLW LOW 100
	MOVWF SYS_TMP1
	CLRF SYS_TMP2
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
	GOTO LCD_LB1_DEZO10
LCD_LB1_DEZO10
	MOVLW LOW 10
	MOVWF SYS_TMP1
	CLRF SYS_TMP2
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
	GOTO LCD_LB1_DEZO1
LCD_LB1_DEZO1
	MOVLW 48
	ADDWF SYS_TMP4,W
	GOTO LCD_LB1_WRITECHAR
LCD_LB1_CONVERTDEZ
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
	DECF SYS_TMP9,F
	CLRF SYS_TMP6
LCD_LB1_CONVERTDEZ2
	INCF SYS_TMP6,F
	MOVFW SYS_TMP1
	SUBWF SYS_TMP4,F
	MOVFW SYS_TMP2
	BTFSS STATUS,CARRY
	INCFSZ SYS_TMP2,W
	SUBWF SYS_TMP5,F
	BTFSC STATUS,CARRY
	GOTO LCD_LB1_CONVERTDEZ2
	MOVFW SYS_TMP2
	ADDWF SYS_TMP5,F
	MOVFW SYS_TMP1
	ADDWF SYS_TMP4,F
	BTFSC STATUS,CARRY
	INCF SYS_TMP5,F
	DECF SYS_TMP6,W
	BTFSS STATUS,ZERO
	BSF SYS_TMP10,0
	RETURN
LCD_LB1_CONVERTHEX
	ANDLW 15
	MOVWF SYS_TMP1
	MOVLW 48
	ADDWF SYS_TMP1,F
	MOVLW 58
	SUBWF SYS_TMP1,W
	BTFSS STATUS,CARRY
	GOTO $+3
	MOVLW 7
	ADDWF SYS_TMP1,F
	MOVFW SYS_TMP1
LCD_LB1_WRITECHAR
LCD_LB1_OUT
	MOVWF SYS_TMP1	; store
LCD_LB1_OUT1
	CLRF SYS_TMP3	; LCDWriteStr (first nibble)
LCD_LB1_OUT2
	SWAPF SYS_TMP1,W	;high nibble
LCD_LB1_OUT3
	ANDLW H'0F'	; mask
	MOVWF SYS_TMP2	; store
	MOVFW PORTB	; load port
	ANDLW H'F0'	; mask
	IORWF SYS_TMP2,W	; add cmd
	MOVWF PORTB	; out
	BSF PORTB,5	; E high
	GOTO $+1
	BCF PORTB,5	; E low
	BTFSC SYS_TMP3,3	; ready ?
	GOTO LCD_LB1_OUT4	; yes
	BSF SYS_TMP3,3	; second nibble
	MOVFW SYS_TMP1
	GOTO LCD_LB1_OUT3	; next nibble
LCD_LB1_OUT4
LCD_LB1_OUTV
	DECFSZ SYS_TMP3,F
	GOTO LCD_LB1_OUTV
	RETURN
LCD_LB1_CHECKNULL
	BTFSS STATUS,ZERO
	DECF SYS_TMP9,F
	MOVWF SYS_TMP1
	BTFSS STATUS,ZERO
	BSF SYS_TMP10,0
	MOVLW 48
	BTFSC SYS_TMP10,0
	ADDWF SYS_TMP1,f
	MOVLW 32
	BTFSS SYS_TMP10,0
	ADDWF SYS_TMP1,F
	MOVFW SYS_TMP1
; 00F5
EEINT_WRITE
	MOVFW INDF
EEINT_WRITE_0
	BCF STATUS,RP0	; Bank 2
	BSF STATUS,RP1	; Bank 2
	MOVWF EEDATA
	BSF STATUS,RP0	; Bank 3
	BSF EECON1,WREN
EEINT_DISINT
	BCF INTCON,GIE
	BTFSC INTCON,GIE
	GOTO EEINT_DISINT
	MOVLW H'55'
	MOVWF EECON2
	MOVLW H'AA'
	MOVWF EECON2
	BSF EECON1,WR	; start write
	BSF INTCON,GIE
EEINT_WRITE_1
	BTFSC EECON1,WR	; ready ?
	GOTO EEINT_WRITE_1	; no
	BCF EECON1,WREN
	INCF EEADR,F
	INCF FSR,F
	DECFSZ SYS_TMP1,F
	GOTO EEINT_WRITE
	RETURN
EEINT_READ
	BSF STATUS,RP1	; Bank 3
	BSF EECON1,RD
	MOVFW EEDATA
	MOVWF INDF
	INCF EEADR,F
	INCF FSR,F
	DECFSZ SYS_TMP1,F
	GOTO EEINT_READ
	RETURN
; EE-Modul -> EE1
WRITE_EE1
	BCF EECON1,EEPGD
	CLRF EEADRH
	MOVLW 0
	MOVWF EEADR
	BCF STATUS,IRP	; vars - located in Bank 0
	MOVLW 2
	MOVWF SYS_TMP1
	MOVLW LOW ZV2
	MOVWF FSR
	CALL EEINT_WRITE
	RETURN
; EE-Modul -> EE1
READ_EE1
	MOVLW 0
	MOVWF EEADR
	CLRF EEADRH
	BCF EECON1,EEPGD
	MOVLW 2
	MOVWF SYS_TMP1
	MOVLW LOW ZV2
	MOVWF FSR
	CALL EEINT_READ
	RETURN
;Initialisierung
SYS_INIT
	MOVLW B'00100000'
	MOVWF INTCON
; Set output before direction
	MOVLW B'00000000'
	MOVWF PORTA
	MOVLW B'00000000'
	MOVWF PORTB
	MOVLW B'00000000'
	MOVWF PORTC
	MOVLW 15
	MOVWF OPTION_REG
	MOVLW 6	; all Digital
	MOVWF ADCON1
; Richtung setzen
	MOVLW B'11111111'
	MOVWF TRISA
	MOVLW B'11000000'
	MOVWF TRISB
	MOVLW B'11111111'
	MOVWF TRISC
; init vars
; Clear RAM
	BCF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	BTFSS FSR,7
	GOTO CR1
	BSF FSR,5
CR2
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR2
	BSF STATUS,IRP
	MOVLW 16
	MOVWF FSR
CR3
	CLRF INDF
	INCF FSR,F
	MOVLW H'70'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR3
	MOVLW 144
	MOVWF FSR
CR4
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR4
; Init LCD -> LB1
	CALL LCD_LB1_INIT
	CALL READ_EE1	; read vars from internal EE
	CLRF TMR0
	BCF INTCON,T0IF
	BSF INTCON,GIE	; Interrupt freigeben
;******* Haupt-Programm ***********
MAIN
	CALL READ_AN0
; Zähler -> ZV1
	BTFSS S1,1	; Reset ?
	GOTO LABEL_ZV1_COUNT
	CLRF ZV1
	CLRF ZV1_HI
	GOTO LABEL_ZV1_SETOUT
LABEL_ZV1_COUNT
; Test auf positive Flanke
	BTFSS S1,0
	GOTO LABEL_ZV1_SETFD
	BTFSC ZV1_FD,0
	BSF ZV1_FD,0
	BTFSC S1,2	; Vorwärts oder Rückwärts ?
	GOTO LABEL_ZV1_BACKWARD
	INCFSZ ZV1,F
	INCF ZV1_HI,F
LABEL_ZV1_BACKWARD
	DECF ZV1,F
	INCFSZ ZV1,W
	DECF ZV1_HI,F
LABEL_ZV1_SETOUT
LABEL_ZV1_SETFD
; Test auf negative Flanke
	BTFSC S1,0
	GOTO LABEL_ZV1_EXIT
	BCF ZV1_FD,0
LABEL_ZV1_EXIT
; Schmitt-Trigger 16-Bit -> ST1
	MOVLW LOW 1000
	MOVWF SYS_TMP1
	MOVLW HIGH 1000
	MOVWF SYS_TMP2
	BTFSS S1,1	; Ausgang gesetzt ?
	GOTO LABEL_ST1_TEST	; without Hysterese
	MOVLW HIGH 0
	SUBWF SYS_TMP2,F
	MOVLW LOW 0
	SUBWF SYS_TMP1,F
	BTFSS STATUS,CARRY
	DECF SYS_TMP2,F
LABEL_ST1_TEST
	MOVFW SYS_TMP2
	SUBWF ZV1_HI,W
	BTFSS STATUS,ZERO
	GOTO LABEL_ST1_TEST2
	MOVFW SYS_TMP1
	SUBWF ZV1,W
LABEL_ST1_TEST2
	BTFSS STATUS,CARRY
	GOTO LABEL_ST1_RESET
LABEL_ST1_SET
	BSF S1,1	; if greater or equal
	GOTO LABEL_ST1_ENDE
LABEL_ST1_RESET
	BCF S1,1	; if less
LABEL_ST1_ENDE
; GND
	BCF S1,2	; immer Low
; LCD -> LT1
; test of positiv edge
	BTFSC LT1_FD,0
	GOTO LABEL_LT1_SETFD
	BTFSS S1,3
	MOVLW 3
	MOVWF SYS_TMP1
	MOVLW 1
	MOVWF SYS_TMP2
	MOVLW HIGH LCD_LB1_GOTOXY	; set page
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVFW ZV1
	MOVWF SYS_TMP4
	MOVFW ZV1_HI
	MOVWF SYS_TMP5
	BCF SYS_TMP10,0
	CLRF SYS_TMP9
	MOVLW HIGH LCD_LB1_DEZO10000	; set page
	MOVWF PCLATH
	CALL LCD_LB1_DEZO10000
	BCF PCLATH,3	; Page 0
	BCF PCLATH,4	; Page 0
LABEL_LT1_SETFD
	BTFSS S1,3
	GOTO LABEL_LT1_SETFD2
	BSF LT1_FD,0
	GOTO LABEL_LT1_END
LABEL_LT1_SETFD2
	BCF LT1_FD,0
LABEL_LT1_END
; Timer -> TR1
	MOVLW 0	; Test auf >=
	SUBWF TR1_HI,W	;F-W -> W
	BTFSS STATUS,ZERO
	GOTO LABEL_TR1_CHECK
	MOVLW 59
	SUBWF TR1,W	;F-W -> W
LABEL_TR1_CHECK
	BTFSS STATUS,CARRY
	GOTO LABEL_TR1_ENDE
LABEL_TR1_RESET
	SUBWF TR1_HI,F	;F-W -> F
	MOVLW 59
	SUBWF TR1,F	;F-W -> F
	BTFSS STATUS,CARRY
	DECF TR1_HI,F
LABEL_TR1_SET	; toggel output
	BTFSC S1,3
	GOTO LABEL_TR1_CLR
	BSF S1,3
	GOTO LABEL_TR1_ENDE
LABEL_TR1_CLR
	BCF S1,3
LABEL_TR1_ENDE
; EE-Modul -> EE1
; Test of falling edge
	BTFSC S1,4
	GOTO LABEL_EE1_SETFD
	BTFSS EE1_FD,0
	BCF EE1_FD,0
	MOVLW HIGH WRITE_EE1
	MOVWF PCLATH
	CALL WRITE_EE1
	MOVLW HIGH LABEL_EE1_SETFD
	MOVWF PCLATH
LABEL_EE1_SETFD
; test input
	BTFSS S1,4
	GOTO LABEL_EE1_EXIT
	BSF EE1_FD,0
LABEL_EE1_EXIT
; Zähler -> ZV2
	BTFSS S1,2	; Reset ?
	GOTO LABEL_ZV2_COUNT
	CLRF ZV2
	CLRF ZV2_HI
	GOTO LABEL_ZV2_SETOUT
LABEL_ZV2_COUNT
	BTFSS S1,4
	GOTO LABEL_ZV2_SETFD
	BTFSC ZV2_FD,0
	BSF ZV2_FD,0
	GOTO LABEL_ZV2_BACKWARD
	INCFSZ ZV2,F
	INCF ZV2_HI,F
LABEL_ZV2_BACKWARD
	DECF ZV2,F
	INCFSZ ZV2,W
	DECF ZV2_HI,F
LABEL_ZV2_SETOUT
LABEL_ZV2_SETFD
	BTFSC S1,4
	GOTO LABEL_ZV2_EXIT
	BCF ZV2_FD,0
LABEL_ZV2_EXIT
; Multiplexer -> MX1
	CLRF SYS_TMP1
	MOVFW S0
	BTFSS STATUS,ZERO
	GOTO LABEL_MX1_CHECKCONTROL1
	MOVFW ZV2
	MOVWF ZV2
	MOVFW ZV2_HI
	MOVWF ZV2_HI
	GOTO LABEL_MX1_END
	INCF SYS_TMP1,F
	MOVFW S0
	SUBWF SYS_TMP1,W
	BTFSS STATUS,ZERO
	GOTO LABEL_MX1_CHECKCONTROL2
	MOVFW ZV1
	MOVWF ZV2
	MOVFW ZV1_HI
	MOVWF ZV2_HI
	GOTO LABEL_MX1_END
LABEL_MX1_END
; One Shot -> OS1
	BTFSS S1,5
	GOTO LABEL_OS1_1
	BTFSC OS1_FD,0
	GOTO LABEL_OS1_1
	BSF OS1_FD,0
	BSF S1,6
	GOTO LABEL_OS1_2
LABEL_OS1_1
	BCF S1,6
	BTFSC S1,5
	GOTO LABEL_OS1_2
	BCF OS1_FD,0
LABEL_OS1_2
; Vergleich -> IF1
	MOVLW HIGH 600
	SUBWF ADC0_HI,W	; F - W -> W
	BTFSS STATUS,ZERO	; Wenn ZERO gesetzt LOW-Byte testen
	GOTO LABEL_IF1_CHECK
	MOVLW LOW 600
	SUBWF ADC0,W	; F - W -> W
LABEL_IF1_CHECK
	BTFSC STATUS,CARRY	; Test auf -> <
	GOTO LABEL_IF1_FALSE
LABEL_IF1_TRUE
	BSF S1,5
	GOTO LABEL_IF1_EXIT
LABEL_IF1_FALSE
	BCF S1,5
LABEL_IF1_EXIT
; Verteiler -> BV1
	MOVLW 0 
	BTFSC S1,6	; IN0
	IORLW 1
	MOVWF S0	; OUT
; One Shot -> OS2
	BTFSC PORTC,0
	GOTO LABEL_OS2_1
	BTFSC OS2_FD,0
	GOTO LABEL_OS2_1
	BSF OS2_FD,0
	BSF S1,0
	GOTO LABEL_OS2_2
LABEL_OS2_1
	BCF S1,0
	BTFSS PORTC,0
	GOTO LABEL_OS2_2
	BCF OS2_FD,0
LABEL_OS2_2
; LCD -> LT2
	BTFSC LT2_FD,0
	GOTO LABEL_LT2_SETFD
	BTFSS S1,3
	MOVLW 3
	MOVWF SYS_TMP1
	MOVLW 3
	MOVWF SYS_TMP2
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVFW ZV2
	MOVWF SYS_TMP4
	MOVFW ZV2_HI
	MOVWF SYS_TMP5
	BCF SYS_TMP10,0
	CLRF SYS_TMP9
	MOVWF PCLATH
LABEL_LT2_SETFD
	BTFSS S1,3
	GOTO LABEL_LT2_SETFD2
	BSF LT2_FD,0
	GOTO LABEL_LT2_END
LABEL_LT2_SETFD2
	BCF LT2_FD,0
LABEL_LT2_END
	GOTO MAIN
	ORG H'2100'
	DE 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	END
