[21/12/2023 14:37:41]
Modbus Response (COM8)
Address: 76
Function: 124 (0x7c)
Exception Code: 0
Checksum: 0x3800 - BAD (should be 0xc570)
Address: 10
Function: 0 (0x00)
Exception Code: 255
Checksum: 0x0ffe - BAD (should be 0x6437)
Address: 31
Function: 2 (0x02) - Read Discrete Inputs
Byte Count: 30
Values: fc 0a 08 4e e0 1a 30 10 e0 0a f0 08 70 02 79 00 06 00 00 f0 00 00 ff 42 00 18 e7
Coils 0-7: 00111111
Coils 8-15: 01010000
Coils 16-23: 00010000
Coils 24-31: 01110010
Coils 32-39: 00000111
Coils 40-47: 01011000
Coils 48-55: 00001100
Coils 56-63: 00001000
Coils 64-71: 00000111
Coils 72-79: 01010000
Coils 80-87: 00001111
Coils 88-95: 00010000
Coils 96-103: 00001110
Coils 104-111: 01000000
Coils 112-119: 10011110
Coils 120-127: 00000000
Coils 128-135: 01100000
Coils 136-143: 00000000
Coils 144-151: 00000000
Coils 152-159: 00001111
Coils 160-167: 00000000
Coils 168-175: 00000000
Coils 176-183: 11111111
Coils 184-191: 01000010
Coils 192-199: 00000000
Coils 200-207: 00011000
Coils 208-215: 11100111
Checksum: 0x3800 - BAD (should be 0x86ca)
[21/12/2023 14:37:42]
Address: 220
Function: 127 (0x7f)
Exception Code: 14
Checksum: 0x3002 - BAD (should be 0x352c)
Address: 241
Function: 4 (0x04) - Read Input Registers
Byte Count: 224
Values: 00 80 f0 ff 08 fc 00 00 f0 ff 20 00 f8 30 00 fc fe 3e 00 fc ff f8 00 e8 ff e0 00
Register0: 128
Register1: 61695
Register2: 2300
Register3: 0
Register4: 61695
Register5: 8192
Register6: 63536
Register7: 252
Register8: 65086
Register9: 252
Register10: 65528
Register11: 232
Register12: 65504
Checksum: 0xe0f2 - BAD (should be 0xa315)
Address: 0
Function: 15 (0x0f) - Write Multiple Coils
Starting Address: 64815
Quantity: 63488
Checksum: 0xff00 - BAD (should be 0x5143)
Address: 1
Function: 1 (0x01) - Read Coils
Byte Count: 48
Values: 00 e0 ff 00 ff 00 1c ff 5c fc 00 ff fc ff 04 e0 e8 00 1f fc 0f fc 00 0e 04 0c f8
Coils 0-7: 00000000
Coils 8-15: 00000111
Coils 16-23: 11111111
Coils 24-31: 00000000
Coils 32-39: 11111111
Coils 40-47: 00000000
Coils 48-55: 00111000
Coils 56-63: 11111111
Coils 64-71: 00111010
Coils 72-79: 00111111
Coils 80-87: 00000000
Coils 88-95: 11111111
Coils 96-103: 00111111
Coils 104-111: 11111111
Coils 112-119: 00100000
Coils 120-127: 00000111
Coils 128-135: 00010111
Coils 144-151: 11111000
Coils 152-159: 00111111
Coils 160-167: 11110000
Coils 168-175: 00111111
Coils 176-183: 00000000
Coils 184-191: 01110000
Coils 192-199: 00100000
Coils 200-207: 00110000
Coils 208-215: 00011111
Checksum: 0x00d0 - BAD (should be 0xa62d)
Address: 2
Function: 16 (0x10) - Write Multiple Registers
Starting Address: 1600
Quantity: 240
Checksum: 0x002c - BAD (should be 0x9f25)
Address: 254
Function: 56 (0x38)
Checksum: 0xf800 - BAD (should be 0xcb76)
Address: 225
Function: 0 (0x00)
Checksum: 0x00f4 - BAD (should be 0x784b)
[21/12/2023 14:37:43]
Address: 36
Function: 30 (0x1e)
Checksum: 0x0001 - BAD (should be 0x9461)
Address: 252
Exception Code: 0
Checksum: 0xaffe - BAD (should be 0xd734)
Address: 20
Function: 33 (0x21)
Checksum: 0xfe00 - BAD (should be 0xbff4)
Address: 255
Function: 126 (0x7e)
Exception Code: 54
Checksum: 0x84f0 - BAD (should be 0x846c)
Address: 255
Byte Count: 0
Values:
Checksum: 0xf80a - BAD (should be 0xaaeb)
Address: 56
Function: 8 (0x08) - Diagnostic
Sub-function: 49153
Data: 38 08 f0 02 00 06 e0 ff 02 ff 00 06 b8 ff 41 00 f0 00 00 7c fe 5c 01 ff fc 4c
Checksum: 0xfc00 - BAD (should be 0x32f7)
Address: 252
Sub-function: 59423
Data: 02 1e fc 1d 00 1a f1 38 e0 00 47 10 08 fc 00 02 60 00 e0 00 04 70 05 b8 00 00
Checksum: 0xa0ff - BAD (should be 0xb0b1)
[21/12/2023 14:37:44]
Address: 1
Exception Code: 0
Checksum: 0x1b10 - BAD (should be 0x0dba)
Address: 240
Function: 27 (0x1b)
Checksum: 0xd701 - BAD (should be 0x169d)
Address: 250
Function: 62 (0x3e)
Exception Code: 12
Checksum: 0x0aa0 - BAD (should be 0x9707)
Address: 0
Exception Code: 0
Checksum: 0x041f - BAD (should be 0xc82e)
Address: 241
Byte Count: 48
Values: 14 f8 02 00 08 70 10 e2 00 08 e0 ff 00 f0 00 00 6e 02 fc 00 10 30 00 30 ff 3c 00
Register0: 5368
Register1: 512
Register2: 2160
Register3: 4322
Register4: 8
Register5: 57599
Register6: 240
Register7: 0
Register8: 28162
Register9: 64512
Register10: 4144
Register11: 48
Register12: 65340
Checksum: 0xfcfe - BAD (should be 0xcc41)
Address: 159
Function: 120 (0x78)
Exception Code: 0
Checksum: 0x00f0 - BAD (should be 0xc679)
Address: 255
Function: 0 (0x00)
Checksum: 0x1dfe - BAD (should be 0x80c9)
[21/12/2023 14:37:45]
Address: 15
Exception Code: 0
Checksum: 0x00b8 - BAD (should be 0x6bb0)
Address: 255
Function: 28 (0x1c)
Checksum: 0x7000 - BAD (should be 0xf288)
Address: 112
Byte Count: 240
Values: ff 02 f8 00 00 00 fe 00 00 08 7f 60 ff 00 f8 00 1c 00 de fe cb fc 00 70 fc cf fc
Coils 0-7: 11111111
Coils 8-15: 01000000
Coils 16-23: 00011111
Coils 32-39: 00000000
Coils 48-55: 01111111
Coils 56-63: 00000000
Coils 64-71: 00000000
Coils 72-79: 00010000
Coils 80-87: 11111110
Coils 88-95: 00000110
Coils 96-103: 11111111
Coils 104-111: 00000000
Coils 112-119: 00011111
Coils 128-135: 00111000
Coils 144-151: 01111011
Coils 152-159: 01111111
Coils 160-167: 11010011
Coils 184-191: 00001110
Coils 192-199: 00111111
Coils 200-207: 11110011
Coils 208-215: 00111111
Checksum: 0x00f8 - BAD (should be 0x4295)
Address: 48
Function: 46 (0x2e)
Checksum: 0x1000 - BAD (should be 0x35de)
Address: 8
Exception Code: 56
Checksum: 0x6001 - BAD (should be 0xb35e)
Address: 224
Byte Count: 112
Values: 00 06 f0 00 06 f8 00 00 f8 00 20 ff 08 ff 00 f0 00 18 fe 10 fe be fc 00 fc ef fe
Coils 0-7: 00000000
Coils 8-15: 01100000
Coils 16-23: 00001111
Coils 32-39: 01100000
Coils 40-47: 00011111
Coils 48-55: 00000000
Coils 64-71: 00011111
Coils 72-79: 00000000
Coils 80-87: 00000100
Coils 96-103: 00010000
Coils 112-119: 00000000
Coils 120-127: 00001111
Coils 128-135: 00000000
Coils 136-143: 00011000
Coils 144-151: 01111111
Coils 152-159: 00001000
Coils 160-167: 01111111
Coils 168-175: 01111101
Coils 176-183: 00111111
Coils 184-191: 00000000
Coils 200-207: 11110111
Coils 208-215: 01111111
Checksum: 0x00e0 - BAD (should be 0x398d)
Address: 36
Function: 100 (0x64)
Exception Code: 137
Checksum: 0x0030 - BAD (should be 0x9ca5)
[21/12/2023 14:37:46]
Address: 0
Function: 113 (0x71)
Checksum: 0x0002 - BAD (should be 0x37be)
Address: 222
Function: 0 (0x00)
Checksum: 0x00ef - BAD (should be 0x9085)
Address: 248
Function: 112 (0x70)
Exception Code: 0
Checksum: 0x01ff - BAD (should be 0xff49)
Address: 0
Function: 0 (0x00)
Checksum: 0xf000 - BAD (should be 0xea99)
Address: 0
Function: 96 (0x60)
Exception Code: 0
Checksum: 0xfaf8 - BAD (should be 0x3f8b)
Address: 0
Function: 119 (0x77)
Exception Code: 248
Checksum: 0xff00 - BAD (should be 0xfe0f)
[21/12/2023 14:37:47]
Address: 0
Exception Code: 33
Checksum: 0xf80c - BAD (should be 0x393d)
Address: 32
Byte Count: 252
Values: 0c f0 00 00 f0 06 b8 00 04 70 86 f0 00 00 71 ff 45 7a 08 fc 00 20 ff 00 08 ff 78
Coils 0-7: 00110000
Coils 8-15: 00001111
Coils 16-23: 00000000
Coils 32-39: 00001111
Coils 40-47: 01100000
Coils 48-55: 00011101
Coils 64-71: 00100000
Coils 72-79: 00001110
Coils 80-87: 01100001
Coils 88-95: 00001111
Coils 96-103: 00000000
Coils 112-119: 10001110
Coils 120-127: 11111111
Coils 128-135: 10100010
Coils 136-143: 01011110
Coils 144-151: 00010000
Coils 168-175: 00000100
Coils 192-199: 00010000
Coils 200-207: 11111111
Coils 208-215: 00011110
Checksum: 0x00ae - BAD (should be 0x3eb9)
Address: 252
Function: 46 (0x2e)
Exception Code: 252
Checksum: 0x0100 - BAD (should be 0xcd96)
Address: 224
Function: 0 (0x00)
Checksum: 0x0ef8 - BAD (should be 0x23c7)
Address: 22
Exception Code: 0
Checksum: 0x58fe - BAD (should be 0x892e)
Address: 0
Exception Code: 254
Checksum: 0x12e2 - BAD (should be 0xe3a3)
Address: 255
Byte Count: 240
Values: ff 00 12 f0 00 ff 00 10 ff 48 00 70 ff 28 00 1c fe be fc 00 f8 db fc 00 00 00 1f
Coils 0-7: 11111111
Coils 8-15: 00000000
Coils 16-23: 01001000
Coils 24-31: 00001111
Coils 40-47: 11111111
Coils 64-71: 11111111
Coils 72-79: 00010010
Coils 88-95: 00001110
Coils 104-111: 00010100
Coils 120-127: 00111000
Coils 128-135: 01111111
Coils 136-143: 01111101
Coils 144-151: 00111111
Coils 152-159: 00000000
Coils 160-167: 00011111
Coils 168-175: 11011011
Coils 200-207: 00000000
Coils 208-215: 11111000
Checksum: 0xfc1e - BAD (should be 0xe50c)
[21/12/2023 14:37:48]
Address: 240
Function: 0 (0x00)
Checksum: 0xffc0 - BAD (should be 0xcf69)
Address: 0
Function: 96 (0x60)
Exception Code: 255
Checksum: 0xe000 - BAD (should be 0x39b8)
Address: 4
Exception Code: 8
Checksum: 0xf000 - BAD (should be 0x8131)
Address: 31
Exception Code: 30
Checksum: 0xff00 - BAD (should be 0x3432)
Address: 32
Function: 40 (0x28)
Checksum: 0xe200 - BAD (should be 0xdc1a)
Address: 112
Function: 0 (0x00)
Checksum: 0xfc1c - BAD (should be 0xeeaf)
Address: 248
Function: 0 (0x00)
Checksum: 0xfeff - BAD (should be 0x2d2b)
[21/12/2023 14:37:49]
Address: 0
Starting Address: 65472
Quantity: 65280
Checksum: 0xae00 - BAD (should be 0x6367)
Address: 2
Function: 96 (0x60)
Exception Code: 0
Checksum: 0xfc00 - BAD (should be 0x88e8)
Address: 239
Exception Code: 223
Checksum: 0x04f0 - BAD (should be 0xcc96)
Address: 0
Byte Count: 240
Values: 00 40 fc 10 ff 00 60 ff 78 00 58 fe 6c fc 00 ff fc ef fc 00 fe f8 00 df c0 1f fc
Coils 0-7: 00000000
Coils 8-15: 00000010
Coils 16-23: 00111111
Coils 24-31: 00001000
Coils 48-55: 00000110
Coils 64-71: 00011110
Coils 80-87: 00011010
Coils 88-95: 01111111
Coils 96-103: 00110110
Coils 104-111: 00111111
Coils 128-135: 00111111
Coils 136-143: 11110111
Coils 168-175: 00011111
Coils 184-191: 11111011
Coils 192-199: 00000011
Coils 200-207: 11111000
Checksum: 0x000a - BAD (should be 0xa846)
Address: 248
Function: 122 (0x7a)
Checksum: 0x1001 - BAD (should be 0xd9f5)
Address: 16
Function: 0 (0x00)
Checksum: 0x00e0 - BAD (should be 0x9d31)
Address: 0
Function: 3 (0x03) - Read Holding Registers
Byte Count: 0
Values:
Checksum: 0x07fe - BAD (should be 0x59eb)
[21/12/2023 14:37:50]
Address: 14
Exception Code: 0
Checksum: 0x001c - BAD (should be 0x9de3)
Address: 255
Function: 60 (0x3c)
Checksum: 0x7002 - BAD (should be 0x67af)
Address: 224
Byte Count: 248
Values: 00 20 e0 ff 00 00 e0 ff 00 00 18 ff 78 00 78 fe 5d 02 ff fc bb 00 f8 ff 00 c0 3e
Coils 0-7: 00000000
Coils 8-15: 00000100
Coils 16-23: 00000111
Coils 24-31: 11111111
Coils 48-55: 00000111
Coils 80-87: 00011000
Coils 96-103: 00011110
Coils 112-119: 00011110
Coils 120-127: 01111111
Coils 128-135: 10111010
Coils 136-143: 01000000
Coils 144-151: 11111111
Coils 160-167: 11011101
Coils 176-183: 00011111
Coils 184-191: 11111111
Coils 200-207: 00000011
Coils 208-215: 01111100
Checksum: 0xf800 - BAD (should be 0xad35)
Address: 47
Exception Code: 63
Checksum: 0xdcfe - BAD (should be 0x6c3d)
Address: 116
Exception Code: 0
Checksum: 0x82f0 - BAD (should be 0x11af)
Address: 3
Exception Code: 64
Checksum: 0xfe00 - BAD (should be 0x50c0)
Address: 38
Exception Code: 14
Checksum: 0x0018 - BAD (should be 0x50bc)
[21/12/2023 14:37:51]
Address: 255
Starting Address: 24
Quantity: 65296
Checksum: 0x0008 - BAD (should be 0x1f69)
Address: 224
Sub-function: 28680
Data: e0 00 e0 00 00 c0 00 28 00 00 e0 ff 00 00 00 ff 62 00 10 8f 2f 86 fe 28 04 f8
Checksum: 0x0cfa - BAD (should be 0xe2df)
Address: 240
Function: 0 (0x00)
Checksum: 0x6200 - BAD (should be 0xe1bb)
Address: 138
Exception Code: 24
Checksum: 0xe00e - BAD (should be 0xeaf5)
Address: 48
Sub-function: 57350
Data: 70 00 01 f0 00 e1 ff 00 08 f0 02 ff 00 82 ff 00 ff 00 60 ff 1c ff 00 fc fe 5c
Checksum: 0x00fe - BAD (should be 0xe212)
Address: 254
Exception Code: 4
Checksum: 0xf000 - BAD (should be 0xd3d4)
[21/12/2023 14:37:52]
Address: 0
Function: 0 (0x00)
Checksum: 0x8700 - BAD (should be 0xa44e)
Address: 25
Exception Code: 3
Checksum: 0x10fe - BAD (should be 0x2046)
Address: 20
Function: 0 (0x00)
Checksum: 0x0478 - BAD (should be 0xfa1a)
Address: 2
Function: 96 (0x60)
Exception Code: 255
Checksum: 0x1f01 - BAD (should be 0x2b09)
Address: 64
Function: 0 (0x00)
Exception Code: 15
Checksum: 0x0060 - BAD (should be 0x976c)
Address: 0
Function: 64 (0x40)
Exception Code: 0
Checksum: 0x6115 - BAD (should be 0x05a2)
Address: 240
Sub-function: 24582
Data: b8 06 e1 00 89 c0 ff 00 f8 00 00 f8 02 70 ff 00 00 72 00 78 ff 20 ff 00 fc fe
Checksum: 0x18fc - BAD (should be 0x5944)
[21/12/2023 14:37:53]
Address: 0
Exception Code: 252
Checksum: 0x7000 - BAD (should be 0x0d95)
Address: 64
Byte Count: 0
Values:
Checksum: 0x0047 - BAD (should be 0x6328)
Address: 252
Function: 9 (0x09)
Checksum: 0xff28 - BAD (should be 0x34ba)
Address: 0
Function: 56 (0x38)
Exception Code: 0
Checksum: 0x0bb8 - BAD (should be 0x47aa)
Address: 6
Function: 98 (0x62)
Exception Code: 0
Checksum: 0xf000 - BAD (should be 0xfae8)
Address: 240
Exception Code: 0
Checksum: 0xff00 - BAD (should be 0x99bb)
Address: 32
Function: 0 (0x00)
Checksum: 0x005f - BAD (should be 0x2fa0)
[21/12/2023 14:37:54]
Address: 194
Sub-function: 57346
Data: 70 08 c1 00 00 e0 02 00 00 70 ff 82 fc 00 08 ff 01 00 30 ff 39 fe 00 f8 fe 94
Checksum: 0xfc00 - BAD (should be 0x7352)
Address: 222
Exception Code: 190
Checksum: 0x0000 - BAD (should be 0x9fc7)
Address: 0
Checksum: 0x1ef8 - BAD (should be 0x328d)
Address: 0
Function: 63 (0x3f)
Checksum: 0xff0c - BAD (should be 0x6257)
Address: 0
Function: 12 (0x0c) - Get Com Event Log
Byte Count: 159
Status: 15360
Event Count: 61436
Message Count: 61436
Events: 00 08 04 e8 50 87 fe 0e 00 1e f0 01 22 29 f0 46 e0 00 a0 04 41
Checksum: 0x12f8 - BAD (should be 0xc8f0)
Address: 4
Function: 96 (0x60)
Exception Code: 0
Checksum: 0x00ff - BAD (should be 0xd8ba)
[21/12/2023 14:37:55]
Address: 218
Function: 31 (0x1f)
Checksum: 0xff00 - BAD (should be 0x1f22)
Address: 8
Function: 0 (0x00)
Checksum: 0x82e0 - BAD (should be 0xa3e1)
Address: 0
Starting Address: 57345
Quantity: 28672
Checksum: 0x5cfc - BAD (should be 0x002c)
Address: 0
Function: 95 (0x5f)
Exception Code: 252
Checksum: 0x11c0 - BAD (should be 0x67b3)
Address: 0
Sub-function: 57599
Data: 00 f8 fe 00 00 ec 80 00 08 ff 18 ff 00 28 fe 2c 00 ff fc da 08 f8 ff c4 00 e4
Checksum: 0x0f00 - BAD (should be 0x3fdf)
Address: 127
Function: 31 (0x1f)
Checksum: 0x71df - BAD (should be 0x7e2c)
Address: 120
Exception Code: 0
Checksum: 0x0960 - BAD (should be 0x75a2)
[21/12/2023 14:37:56]
Address: 1
Function: 96 (0x60)
Exception Code: 8
Checksum: 0xc000 - BAD (should be 0x24df)
Address: 31
Exception Code: 14
Checksum: 0xff24 - BAD (should be 0x8594)
Address: 0
Function: 0 (0x00)
Checksum: 0xf802 - BAD (should be 0xe7b6)
Address: 48
Function: 14 (0x0e)
Exception Code: 0
Checksum: 0xaefe - BAD (should be 0xa017)
Address: 0
Exception Code: 4
Checksum: 0x7000 - BAD (should be 0x59a3)
Address: 8
Checksum: 0x1ffc - BAD (should be 0xe0cf)
Address: 30
Exception Code: 0
Checksum: 0x30df - BAD (should be 0x3a1d)
[21/12/2023 14:37:57]
Address: 124
Exception Code: 0
Checksum: 0xf002 - BAD (should be 0x1981)
Address: 112
Function: 6 (0x06) - Write Single Register
Address: 57599
Value: 481
Checksum: 0xf300 - BAD (should be 0x6ded)
Address: 244
Exception Code: 0
Checksum: 0xe000 - BAD (should be 0x7211)
Address: 2
Exception Code: 255
Checksum: 0xf81f - BAD (should be 0x07ab)
Address: 240
Function: 0 (0x00)
Checksum: 0x08ff - BAD (should be 0x2b5c)
Address: 0
Function: 24 (0x18) - Read FIFO queue
Byte Count: 40788
FIFO Count: 254
FIFO Value Register: fc ff fc 00 ff f0 19 ff e8 3f 06 8f ff 0f 04 7e 84 1e 10 00 1a f0 10 f0
Register0: 64767
Register1: 64512
Register2: 65520
Register3: 6655
Register4: 59455
Register5: 1679
Register6: 65295
Register7: 1150
Register8: 33822
Register9: 4096
Register10: 6896
Register11: 4336
Checksum: 0x0000 - BAD (should be 0x4c54)
Address: 112
Function: 0 (0x00)
Checksum: 0x00f8 - BAD (should be 0x5d1b)
[21/12/2023 14:37:58]
Address: 244
Function: 0 (0x00)
Checksum: 0xa0ff - BAD (should be 0x2039)
Address: 0
Exception Code: 0
Checksum: 0x000c - BAD (should be 0xd287)
Address: 248
Byte Count: 224
Values: 00 1d e0 08 18 00 e2 0a f0 00 08 70 ff 20 e0 00 00 fb 22 fc ff 00 04 ff 0c ff 00
Coils 0-7: 00000000
Coils 8-15: 10111000
Coils 24-31: 00010000
Coils 32-39: 00011000
Coils 48-55: 01000111
Coils 56-63: 01010000
Coils 64-71: 00001111
Coils 80-87: 00010000
Coils 104-111: 00000100
Coils 112-119: 00000111
Coils 136-143: 11011111
Coils 144-151: 01000100
Coils 160-167: 11111111
Coils 176-183: 00100000
Coils 192-199: 00110000
Coils 208-215: 00000000
Checksum: 0x0c00 - BAD (should be 0xcef3)
Address: 48
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xf9e3)
Address: 112
Byte Count: 240
Values: 00 00 e1 ff 82 f0 ff 00 00 30 ff 00 20 5c ff 20 00 38 fe 28 00 e1 fe 9e 08 e8 18
Coils 0-7: 00000000
Coils 16-23: 10000111
Coils 32-39: 01000001
Coils 40-47: 00001111
Coils 48-55: 11111111
Coils 72-79: 00001100
Coils 80-87: 11111111
Coils 88-95: 00000000
Coils 96-103: 00000100
Coils 104-111: 00111010
Coils 112-119: 11111111
Coils 120-127: 00000100
Coils 136-143: 00011100
Coils 152-159: 00010100
Coils 168-175: 10000111
Coils 176-183: 01111111
Coils 184-191: 01111001
Coils 200-207: 00010111
Coils 208-215: 00011000
Checksum: 0xfc20 - BAD (should be 0x7af0)
Address: 31
Exception Code: 14
Checksum: 0x0070 - BAD (should be 0xe041)
Address: 255
Function: 48 (0x30)
Checksum: 0x3000 - BAD (should be 0xd48f)
[21/12/2023 14:37:59]
Address: 240
Sub-function: 49444
Data: c0 ff 81 00 00 01 f0 ff 00 00 00 fc ff 00 00 10 ff 10 00 b0 ff 34 00 1c fc ff
Checksum: 0xfc00 - BAD (should be 0x51b6)
Address: 248
Byte Count: 248
Status: 4094
Event Count: 12
Message Count: 3087
Events: f8 00 0c f8 06 10 08 04 30 01 60 02 e1 00 86 08 09 70 00 01 e0
Checksum: 0x0100 - BAD (should be 0x2b26)
Address: 0
Function: 32 (0x20)
Checksum: 0x0007 - BAD (should be 0xf936)
Address: 62
Function: 0 (0x00)
Checksum: 0xff60 - BAD (should be 0x2406)
Address: 255
Function: 0 (0x00)
Checksum: 0xe000 - BAD (should be 0xc22b)
Address: 96
Function: 0 (0x00)
Checksum: 0x00fe - BAD (should be 0x4088)
Address: 239
Exception Code: 0
Checksum: 0xff00 - BAD (should be 0xca79)
[21/12/2023 14:38:00]
Address: 240
Function: 0 (0x00)
Checksum: 0x0ffc - BAD (should be 0x9932)
Address: 14
Exception Code: 0
Checksum: 0xff39 - BAD (should be 0x77af)
Address: 254
Function: 0 (0x00)
Checksum: 0x0538 - BAD (should be 0x41ed)
Address: 4
Exception Code: 4
Checksum: 0x04f0 - BAD (should be 0x58f3)
Address: 32
Exception Code: 196
Checksum: 0x02ff - BAD (should be 0xe73d)
Address: 0
Function: 64 (0x40)
Checksum: 0x0000 - BAD (should be 0x848d)
[21/12/2023 14:38:01]
Address: 224
Byte Count: 40
Values: 08 60 00 71 08 e0 fe 00 00 00 f4 01 ee 00 20 08 00 31 ff 18 fe 00 fc df 02 fc bf
Coils 0-7: 00010000
Coils 8-15: 00000110
Coils 24-31: 10001110
Coils 32-39: 00010000
Coils 40-47: 00000111
Coils 80-87: 00101111
Coils 88-95: 10000000
Coils 96-103: 01110111
Coils 112-119: 00000100
Coils 120-127: 00010000
Coils 136-143: 10001100
Coils 152-159: 00011000
Coils 192-199: 01000000
Coils 200-207: 00111111
Coils 208-215: 11111101
Checksum: 0xf800 - BAD (should be 0x509d)
Address: 232
Function: 40 (0x28)
Checksum: 0x0020 - BAD (should be 0xfa57)
Address: 255
Byte Count: 65280
FIFO Count: 3072
Checksum: 0xe006 - BAD (should be 0x420c)
Address: 224
Function: 0 (0x00)
Checksum: 0xf8d7 - BAD (should be 0x902f)
Address: 2
Exception Code: 246
Checksum: 0x01f8 - BAD (should be 0x7fd6)
Address: 0
Checksum: 0x0ef8 - BAD (should be 0x7bf6)
Address: 0
Function: 28 (0x1c)
Checksum: 0xff70 - BAD (should be 0xb4a7)
[21/12/2023 14:38:02]
Address: 247
Exception Code: 0
Checksum: 0x00a3 - BAD (should be 0xba91)
Address: 240
Function: 0 (0x00)
Checksum: 0x281e - BAD (should be 0xc01e)
Address: 1
Function: 31 (0x1f)
Checksum: 0xff82 - BAD (should be 0x9153)
Address: 255
Function: 0 (0x00)
Checksum: 0x00a0 - BAD (should be 0x9ae3)
Address: 0
Function: 79 (0x4f)
Exception Code: 16
Checksum: 0xff16 - BAD (should be 0xe25e)
Address: 0
Exception Code: 254
Checksum: 0x01e0 - BAD (should be 0xdf2a)
Address: 255
Function: 0 (0x00)
Checksum: 0xf287 - BAD (should be 0x1db7)
[21/12/2023 14:38:03]
Address: 2
Function: 7 (0x07) - Read Exception status
Output Data: 0c
Coils 0-7: 00110000
Checksum: 0x40ff - BAD (should be 0x60a5)
Address: 48
Exception Code: 0
Checksum: 0xe000 - BAD (should be 0x381a)
Address: 131
Exception Code: 3
Checksum: 0x9efc - BAD (should be 0xb28e)
Address: 0
Function: 125 (0x7d)
Exception Code: 0
Checksum: 0xc0ff - BAD (should be 0x53d1)
Address: 137
Function: 30 (0x1e)
Exception Code: 0
Checksum: 0xf800 - BAD (should be 0xb533)
Address: 132
Function: 13 (0x0d)
Checksum: 0xff60 - BAD (should be 0xe394)
Address: 255
Function: 0 (0x00)
Checksum: 0xf009 - BAD (should be 0x5f3d)
[21/12/2023 14:38:04]
Address: 184
Function: 0 (0x00)
Checksum: 0xf000 - BAD (should be 0x646d)
Address: 248
Starting Address: 57376
Quantity: 24568
Checksum: 0x0000 - BAD (should be 0xcfe7)
Address: 255
Byte Count: 1
FIFO Count: 28672
Checksum: 0x0402 - BAD (should be 0xc2c6)
Address: 48
Function: 5 (0x05) - Write Single Coil
Address: 61442
Value: 57344
Checksum: 0x00de - BAD (should be 0x34b7)
Address: 248
Function: 69 (0x45)
Exception Code: 252
Checksum: 0x087c - BAD (should be 0x7822)
Address: 0
Function: 96 (0x60)
Exception Code: 255
Checksum: 0xf80c - BAD (should be 0xacc2)
[21/12/2023 14:38:05]
Address: 248
Function: 0 (0x00)
Checksum: 0x0030 - BAD (should be 0x00b7)
Address: 255
Function: 28 (0x1c)
Checksum: 0x06e0 - BAD (should be 0xc9d4)
Address: 8
Function: 48 (0x30)
Checksum: 0xfcd8 - BAD (should be 0x6649)
Address: 0
Exception Code: 252
Checksum: 0x5982 - BAD (should be 0xe539)
Address: 255
Function: 64 (0x40)
Checksum: 0x07fe - BAD (should be 0xf18b)
Address: 0
Starting Address: 2048
Quantity: 6152
Checksum: 0xff00 - BAD (should be 0x0c09)
Address: 32
Exception Code: 24
Checksum: 0xf600 - BAD (should be 0xd0f1)
[21/12/2023 14:38:06]
Address: 132
Function: 9 (0x09)
Exception Code: 240
Checksum: 0xf8f0 - BAD (should be 0x4f9f)
Address: 0
Exception Code: 224
Checksum: 0x09d0 - BAD (should be 0xc269)
Address: 0
Function: 98 (0x62)
Checksum: 0x1000 - BAD (should be 0x7242)
Address: 29
Function: 0 (0x00)
Checksum: 0x18fe - BAD (should be 0xc5c5)
Address: 84
Exception Code: 0
Checksum: 0x0003 - BAD (should be 0xf0eb)
Address: 112
Function: 0 (0x00)
Checksum: 0x8000 - BAD (should be 0x9aad)
Address: 127
Exception Code: 13
Checksum: 0x60ff - BAD (should be 0x861b)
[21/12/2023 14:38:07]
Address: 0
Function: 49 (0x31)
Checksum: 0x000f - BAD (should be 0xd02d)
Address: 8
Byte Count: 0
Values:
Checksum: 0xcffc - BAD (should be 0x528f)
Address: 0
Function: 95 (0x5f)
Exception Code: 248
Checksum: 0xf8ff - BAD (should be 0xc348)
Address: 0
Function: 65 (0x41)
Exception Code: 255
Checksum: 0x1ff8 - BAD (should be 0xa858)
Address: 29
Address: 49944
Value: 176
Checksum: 0x809f - BAD (should be 0xd3b8)
Address: 253
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x7f98)
Address: 240
Exception Code: 0
Checksum: 0x0e08 - BAD (should be 0xd6a5)
[21/12/2023 14:38:08]
Address: 14
Exception Code: 29
Checksum: 0x00fc - BAD (should be 0x442f)
Address: 252
Function: 95 (0x5f)
Exception Code: 252
Checksum: 0xfc00 - BAD (should be 0x4753)
Address: 0
Function: 0 (0x00)
Checksum: 0x0004 - BAD (should be 0x0245)
Address: 0
Function: 82 (0x52)
Checksum: 0x1800 - BAD (should be 0x5395)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xfa33)
[21/12/2023 14:38:09]
Address: 254
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xeafc)
Address: 132
Exception Code: 0
Checksum: 0xff00 - BAD (should be 0xa0a3)
Address: 0
Function: 0 (0x00)
Checksum: 0xfc00 - BAD (should be 0x28ac)
Address: 254
Function: 0 (0x00)
Checksum: 0x0020 - BAD (should be 0x8313)
Address: 16
Function: 0 (0x00)
Exception Code: 0
Checksum: 0x0000 - BAD (should be 0xdee8)
Address: 0
Function: 0 (0x00)
Checksum: 0xd8fc - BAD (should be 0xb6cf)
[21/12/2023 14:38:10]
Address: 0
Function: 0 (0x00)
Checksum: 0x2000 - BAD (should be 0xaea4)
Address: 6
Byte Count: 0
Status: 383
Event Count: 0
Message Count: 7744
Events: fe 00 00 fc 00 00 00 00 00 00 f0 e0 00 f6 00 f0 f0 00 00 00 00
Checksum: 0x0000 - BAD (should be 0xa961)
Address: 0
Function: 0 (0x00)
Checksum: 0x00fe - BAD (should be 0xd3e9)
Address: 255
Byte Count: 0
Values:
Checksum: 0x0097 - BAD (should be 0x3218)
Address: 0
Function: 0 (0x00)
Checksum: 0xfe00 - BAD (should be 0xc068)
[21/12/2023 14:38:11]
Address: 0
Function: 0 (0x00)
Checksum: 0x0002 - BAD (should be 0x6933)
Address: 0
Address: 61440
Value: 252
Checksum: 0x0000 - BAD (should be 0x620a)
Address: 128
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xdeb1)
Address: 0
Exception Code: 0
Checksum: 0x00f8 - BAD (should be 0xb941)
Address: 0
Exception Code: 253
Checksum: 0xfa02 - BAD (should be 0x09ce)
Address: 0
Exception Code: 8
Checksum: 0x0000 - BAD (should be 0xa359)
[21/12/2023 14:38:12]
Address: 252
Starting Address: 32
Quantity: 65032
Checksum: 0x0000 - BAD (should be 0x8ef1)
Address: 0
Starting Address: 0
Quantity: 0
Checksum: 0x00ff - BAD (should be 0x7955)
Address: 134
Function: 0 (0x00)
Checksum: 0xe080 - BAD (should be 0x3c32)
Address: 0
Byte Count: 254
Values: 00 ff f8 00 00 c0 82 01 10 3f e0 00 10 00 00 00 00 00 f0 00 00 03 fc 81 0a 00 00
Coils 0-7: 00000000
Coils 8-15: 11111111
Coils 40-47: 00000011
Coils 48-55: 01000001
Coils 56-63: 10000000
Coils 64-71: 00001000
Coils 72-79: 11111100
Coils 80-87: 00000111
Coils 96-103: 00001000
Coils 144-151: 00001111
Coils 168-175: 11000000
Coils 184-191: 10000001
Coils 192-199: 01010000
Checksum: 0x8000 - BAD (should be 0xaede)
Address: 0
Exception Code: 0
Checksum: 0x8004 - BAD (should be 0x4636)
Address: 16
Function: 0 (0x00)
Checksum: 0x8000 - BAD (should be 0x79f3)
Address: 224
Starting Address: 1024
Quantity: 64512
Checksum: 0xff00 - BAD (should be 0x21cf)
[21/12/2023 14:38:13]
Address: 0
Exception Code: 248
Checksum: 0xee00 - BAD (should be 0x6cb6)
Address: 255
Function: 0 (0x00)
Exception Code: 0
Checksum: 0x00ff - BAD (should be 0x4d09)
Address: 254
Function: 0 (0x00)
Checksum: 0x00ff - BAD (should be 0xcfe5)
Address: 255
Function: 0 (0x00)
Checksum: 0x00ff - BAD (should be 0xfbee)
Address: 0
Function: 0 (0x00)
Checksum: 0x8000 - BAD (should be 0x0290)
Address: 0
Function: 0 (0x00)
Checksum: 0xe600 - BAD (should be 0x84f0)
Address: 0
Function: 0 (0x00)
Checksum: 0x1000 - BAD (should be 0x8fc0)
[21/12/2023 14:38:14]
Address: 128
Function: 0 (0x00)
Exception Code: 0
Checksum: 0xe000 - BAD (should be 0x238b)
Address: 0
Function: 0 (0x00)
Checksum: 0x00ff - BAD (should be 0x5e24)
Address: 0
Exception Code: 0
Checksum: 0x0000 - BAD (should be 0x3a17)
Address: 0
Function: 0 (0x00)
Exception Code: 0
Checksum: 0xff00 - BAD (should be 0xde44)
Address: 252
Function: 0 (0x00)
Checksum: 0x00ff - BAD (should be 0xb5a7)
Address: 0
Exception Code: 0
Checksum: 0xff00 - BAD (should be 0x8730)
Address: 254
Function: 0 (0x00)
Checksum: 0xf000 - BAD (should be 0xf4d2)
Address: 240
Function: 0 (0x00)
Checksum: 0x0080 - BAD (should be 0xc863)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x7a07)
[21/12/2023 14:38:15]
Address: 0
Function: 0 (0x00)
Checksum: 0xf000 - BAD (should be 0x9533)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x8111)
Address: 255
Function: 0 (0x00)
Checksum: 0xff00 - BAD (should be 0x270c)
Address: 252
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x9322)
Address: 248
Function: 0 (0x00)
Checksum: 0xe000 - BAD (should be 0xa597)
Address: 0
Function: 64 (0x40)
Exception Code: 0
Checksum: 0x8000 - BAD (should be 0x72b4)
Address: 0
Function: 64 (0x40)
Exception Code: 0
Checksum: 0x8000 - BAD (should be 0x1936)
[21/12/2023 14:38:16]
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x298b)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xafb9)
Address: 0
Function: 0 (0x00)
Checksum: 0x0200 - BAD (should be 0xf0bb)
Address: 0
Exception Code: 128
Checksum: 0x0080 - BAD (should be 0x88e6)
Address: 0
Function: 0 (0x00)
Checksum: 0xc002 - BAD (should be 0x37c6)
Address: 192
Function: 0 (0x00)
Checksum: 0xe000 - BAD (should be 0xbb2a)
Address: 0
Function: 96 (0x60)
Exception Code: 0
Checksum: 0x0200 - BAD (should be 0x5a74)
Address: 2
Function: 0 (0x00)
Checksum: 0xfc80 - BAD (should be 0x98b0)
[21/12/2023 14:38:17]
Address: 0
Exception Code: 0
Checksum: 0x00f8 - BAD (should be 0x63a1)
Address: 0
Exception Code: 0
Checksum: 0xe000 - BAD (should be 0x8f86)
Address: 0
Function: 96 (0x60)
Exception Code: 0
Checksum: 0x0001 - BAD (should be 0xba49)
Address: 0
Function: 31 (0x1f)
Exception Code: 128
Checksum: 0x0000 - BAD (should be 0x1586)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xe939)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x3d75)
Address: 0
Byte Count: 128
Values: 00 00 00 00 80 01 00 02 c0 00 00 c0 00 00 c0 00 00 00 ff e0 01 00 00 e0 00 00 e0
Coils 0-7: 00000000
Coils 32-39: 00000001
Coils 40-47: 10000000
Coils 56-63: 01000000
Coils 64-71: 00000011
Coils 88-95: 00000011
Coils 112-119: 00000011
Coils 152-159: 00000111
Coils 160-167: 10000000
Coils 184-191: 00000111
Coils 208-215: 00000111
Checksum: 0x0100 - BAD (should be 0xc031)
Address: 224
Function: 0 (0x00)
Checksum: 0xfffc - BAD (should be 0x9874)
[21/12/2023 14:38:18]
Address: 0
Function: 0 (0x00)
Checksum: 0x0002 - BAD (should be 0x73a6)
Address: 252
Exception Code: 255
Checksum: 0xffc0 - BAD (should be 0x5fb3)
Address: 226
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x75c2)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x787e)
Address: 0
Function: 0 (0x00)
Checksum: 0xc000 - BAD (should be 0xcd3c)
Address: 0
Byte Count: 192
Values: 00 00 c0 02 e0 00 00 e0 02 e0 00 00 e0 00 f0 00 00 f0 00 f8 00 00 f8 00 ff f8 00
Coils 0-7: 00000000
Coils 16-23: 00000011
Coils 24-31: 01000000
Coils 56-63: 00000111
Coils 64-71: 01000000
Coils 72-79: 00000111
Coils 96-103: 00000111
Coils 112-119: 00001111
Coils 136-143: 00001111
Coils 152-159: 00011111
Coils 192-199: 11111111
Coils 200-207: 00011111
Checksum: 0x00f8 - BAD (should be 0x9810)
Address: 1
Exception Code: 0
Checksum: 0xff00 - BAD (should be 0x0d3a)
Address: 252
Function: 0 (0x00)
Checksum: 0xe000 - BAD (should be 0xfcaf)
[21/12/2023 14:38:19]
Address: 0
Function: 0 (0x00)
Checksum: 0x0080 - BAD (should be 0xa9ec)
Address: 7
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xa0c7)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x4c1c)
Address: 224
Function: 0 (0x00)
Checksum: 0xfe00 - BAD (should be 0x0b01)
Address: 0
Exception Code: 2
Checksum: 0x02f0 - BAD (should be 0x41fd)
Address: 0
Function: 0 (0x00)
Checksum: 0x0082 - BAD (should be 0xf504)
Address: 254
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x07d4)
Address: 1
Function: 0 (0x00)
Checksum: 0xe000 - BAD (should be 0xbdd1)
[21/12/2023 14:38:20]
Address: 255
Function: 96 (0x60)
Exception Code: 0
Checksum: 0x0001 - BAD (should be 0x6cc2)
Address: 254
Function: 0 (0x00)
Checksum: 0x00f0 - BAD (should be 0x0b1a)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x5d2d)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x9c7f)
Address: 0
Function: 0 (0x00)
Exception Code: 0
Checksum: 0x0000 - BAD (should be 0xe6e9)
Address: 255
Exception Code: 1
Checksum: 0xff00 - BAD (should be 0x00c1)
Address: 248
Function: 0 (0x00)
Checksum: 0x0080 - BAD (should be 0x2805)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xa251)
[21/12/2023 14:38:21]
Address: 0
Function: 0 (0x00)
Checksum: 0xc000 - BAD (should be 0x5afc)
Address: 0
Function: 96 (0x60)
Exception Code: 0
Checksum: 0x0000 - BAD (should be 0x1d78)
Address: 252
Function: 0 (0x00)
Checksum: 0xfc00 - BAD (should be 0xc069)
Address: 240
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x8517)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xf181)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xdc1d)
Address: 0
Exception Code: 0
Checksum: 0x0000 - BAD (should be 0x9082)
Address: 2
Function: 0 (0x00)
Checksum: 0xff00 - BAD (should be 0x7241)
[21/12/2023 14:38:22]
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xfe4f)
Address: 0
Function: 0 (0x00)
Checksum: 0xe000 - BAD (should be 0xcdb8)
Address: 0
Function: 64 (0x40)
Exception Code: 0
Checksum: 0x01fe - BAD (should be 0xf8fb)
Address: 0
Function: 0 (0x00)
Checksum: 0x00e0 - BAD (should be 0xf5e9)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x0086)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x8144)
Address: 192
Function: 0 (0x00)
Checksum: 0x00ff - BAD (should be 0x9e72)
Address: 0
Exception Code: 0
Checksum: 0x0000 - BAD (should be 0x6fc5)
[21/12/2023 14:38:23]
Address: 224
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xd882)
Address: 0
Function: 0 (0x00)
Checksum: 0x02c0 - BAD (should be 0x480c)
Address: 0
Function: 0 (0x00)
Checksum: 0xfe00 - BAD (should be 0x85e5)
Address: 0
Exception Code: 0
Checksum: 0x00c0 - BAD (should be 0x0a56)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xbce6)
Address: 0
Function: 0 (0x00)
Checksum: 0x00f0 - BAD (should be 0xa9c9)
Address: 0
Function: 0 (0x00)
Checksum: 0x00fc - BAD (should be 0x6cec)
Address: 0
Function: 0 (0x00)
Checksum: 0x8000 - BAD (should be 0x0b02)
[21/12/2023 14:38:24]
Address: 128
Function: 0 (0x00)
Checksum: 0x0100 - BAD (should be 0xf78a)
Address: 0
Function: 0 (0x00)
Exception Code: 0
Checksum: 0x00fc - BAD (should be 0x0023)
Address: 0
Function: 0 (0x00)
Checksum: 0xff02 - BAD (should be 0x956d)
Address: 240
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x05b9)
Address: 0
Function: 0 (0x00)
Checksum: 0xc002 - BAD (should be 0x0758)
Address: 192
Byte Count: 0
Values:
Checksum: 0x00ff - BAD (should be 0x8205)
Address: 255
Function: 0 (0x00)
Checksum: 0xff00 - BAD (should be 0xd5df)
Address: 128
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x5a55)
[21/12/2023 14:38:25]
Address: 0
Function: 0 (0x00)
Checksum: 0x00f0 - BAD (should be 0xb070)
Address: 0
Exception Code: 0
Checksum: 0xfc00 - BAD (should be 0x4abe)
Address: 248
Function: 0 (0x00)
Checksum: 0x0002 - BAD (should be 0x28df)
Address: 0
Function: 0 (0x00)
Checksum: 0xc000 - BAD (should be 0x9803)
Address: 0
Function: 64 (0x40)
Exception Code: 0
Checksum: 0x00ff - BAD (should be 0xd6d9)
Address: 2
Exception Code: 255
Checksum: 0x0001 - BAD (should be 0x32e4)
Address: 0
Function: 0 (0x00)
Exception Code: 0
Checksum: 0x0280 - BAD (should be 0xfeb7)
Address: 0
Function: 0 (0x00)
Checksum: 0xfe00 - BAD (should be 0x2f93)
[21/12/2023 14:38:26]
Address: 255
Function: 0 (0x00)
Checksum: 0xc000 - BAD (should be 0xba67)
Address: 0
Function: 96 (0x60)
Exception Code: 0
Checksum: 0x0000 - BAD (should be 0x675e)
Address: 0
Function: 0 (0x00)
Checksum: 0xfc00 - BAD (should be 0xddbf)
Address: 0
Exception Code: 0
Checksum: 0x0000 - BAD (should be 0x2ae0)
Address: 192
Function: 0 (0x00)
Checksum: 0xff00 - BAD (should be 0xc8b2)
Address: 2
Function: 0 (0x00)
Checksum: 0x00f0 - BAD (should be 0x4188)
Address: 0
Exception Code: 0
Checksum: 0x00f8 - BAD (should be 0xd25d)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xa47e)
[21/12/2023 14:38:27]
Address: 0
Byte Count: 0
Values:
Checksum: 0xf000 - BAD (should be 0x6774)
Address: 0
Exception Code: 0
Checksum: 0xf800 - BAD (should be 0xce51)
Address: 240
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xd8e4)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x8cde)
Address: 0
Function: 0 (0x00)
Checksum: 0xfc00 - BAD (should be 0x8bf1)
Address: 248
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x8f3e)
Address: 0
Function: 0 (0x00)
Checksum: 0xffe0 - BAD (should be 0x90de)
Address: 0
Function: 0 (0x00)
Checksum: 0x00fc - BAD (should be 0x7e97)
[21/12/2023 14:38:28]
Address: 0
Exception Code: 0
Checksum: 0x0080 - BAD (should be 0xa54b)
Address: 0
Function: 0 (0x00)
Checksum: 0xf000 - BAD (should be 0x336a)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x9796)
Address: 0
Exception Code: 0
Checksum: 0x0003 - BAD (should be 0xa47a)
Address: 2
Function: 0 (0x00)
Checksum: 0xf000 - BAD (should be 0x1b0b)
Address: 0
Exception Code: 2
Checksum: 0x0000 - BAD (should be 0x882b)
Address: 0
Exception Code: 0
Checksum: 0x0000 - BAD (should be 0x7022)
Address: 0
Function: 0 (0x00)
Checksum: 0xf802 - BAD (should be 0x2ff0)
[21/12/2023 14:38:29]
Address: 0
Exception Code: 0
Checksum: 0xf000 - BAD (should be 0x54c5)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x242e)
Address: 0
Function: 0 (0x00)
Checksum: 0xf802 - BAD (should be 0x2e2f)
Address: 252
Function: 0 (0x00)
Checksum: 0xe000 - BAD (should be 0x7778)
Address: 0
Function: 63 (0x3f)
Checksum: 0x0001 - BAD (should be 0x3b7f)
Address: 0
Function: 0 (0x00)
Checksum: 0x00ff - BAD (should be 0xcae5)
Address: 0
Exception Code: 0
Checksum: 0xf000 - BAD (should be 0xb7e1)
[21/12/2023 14:38:30]
Address: 0
Function: 0 (0x00)
Checksum: 0x0200 - BAD (should be 0x54da)
Address: 255
Function: 0 (0x00)
Checksum: 0x00ff - BAD (should be 0x9d56)
Address: 0
Exception Code: 0
Checksum: 0x00c0 - BAD (should be 0x38ed)
Address: 0
Function: 0 (0x00)
Checksum: 0x00ff - BAD (should be 0x6ab7)
Address: 128
Function: 0 (0x00)
Checksum: 0xffff - BAD (should be 0x9def)
Address: 0
Exception Code: 0
Checksum: 0x0000 - BAD (should be 0xde4b)
Address: 0
Byte Count: 0
Values:
Checksum: 0x00c0 - BAD (should be 0x290c)
Address: 0
Function: 96 (0x60)
Exception Code: 2
Checksum: 0x00f8 - BAD (should be 0x091f)
[21/12/2023 14:38:31]
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xcfd2)
Address: 0
Function: 0 (0x00)
Checksum: 0x00f8 - BAD (should be 0xaf9d)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x5b8c)
Address: 2
Function: 64 (0x40)
Exception Code: 0
Checksum: 0x8000 - BAD (should be 0x5384)
Address: 0
Function: 64 (0x40)
Exception Code: 0
Checksum: 0x00fe - BAD (should be 0xc38d)
Address: 0
Function: 0 (0x00)
Checksum: 0x00ff - BAD (should be 0x5c19)
Address: 0
Exception Code: 0
Checksum: 0xdce0 - BAD (should be 0xce12)
Address: 0
Function: 0 (0x00)
Checksum: 0x00fe - BAD (should be 0x3b5d)
[21/12/2023 14:38:32]
Address: 128
Function: 0 (0x00)
Checksum: 0x0080 - BAD (should be 0x0aca)
Address: 224
Function: 0 (0x00)
Checksum: 0x00e0 - BAD (should be 0x4d4f)
Address: 0
Exception Code: 1
Checksum: 0xfe00 - BAD (should be 0xf222)
Address: 255
Function: 0 (0x00)
Exception Code: 8
Checksum: 0x0000 - BAD (should be 0xa5ca)
Address: 128
Function: 0 (0x00)
Checksum: 0x0200 - BAD (should be 0x64cc)
Address: 255
Function: 0 (0x00)
Checksum: 0xe0fc - BAD (should be 0x6381)
Address: 0
Function: 0 (0x00)
Checksum: 0x8000 - BAD (should be 0x4d6d)
[21/12/2023 14:38:33]
Address: 0
Function: 0 (0x00)
Checksum: 0x0700 - BAD (should be 0x8217)
Address: 0
Exception Code: 0
Checksum: 0x1000 - BAD (should be 0xfb8b)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x46a9)
Address: 4
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x8eaf)
Address: 0
Function: 0 (0x00)
Checksum: 0x0080 - BAD (should be 0x746c)
Address: 0
Sub-function: 0 (Return Query Data)
Data: 01 04 00 11 00 10 00 00 00 10 00 00 00 00 00 00 00 02 00 00 03 00 ff 00 34 f0
Checksum: 0x00ff - BAD (should be 0x739c)
[21/12/2023 14:38:34]
Address: 0
Function: 0 (0x00)
Checksum: 0xff00 - BAD (should be 0x3af0)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x9d61)
Address: 0
Byte Count: 0
Status: 0
Event Count: 41212
Message Count: 0
Events: 00 00 fe 00 00 00 00 10 00 00 80 00 08 00 40 00 00 80 00 01 fe
Checksum: 0x0040 - BAD (should be 0x4004)
Address: 0
Function: 0 (0x00)
Exception Code: 255
Checksum: 0x0000 - BAD (should be 0x8827)
Address: 16
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x71fe)
Address: 0
Function: 0 (0x00)
Checksum: 0x00ff - BAD (should be 0xc853)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x0146)
[21/12/2023 14:38:35]
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x410f)
Address: 254
Exception Code: 1
Checksum: 0x0000 - BAD (should be 0x3355)
Address: 128
Function: 0 (0x00)
Checksum: 0x0080 - BAD (should be 0xa4ba)
Address: 0
Function: 0 (0x00)
Checksum: 0xc000 - BAD (should be 0x1460)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xc0e1)
Address: 0
Function: 0 (0x00)
Checksum: 0xa500 - BAD (should be 0x1e8f)
[21/12/2023 14:38:36]
Address: 0
Function: 0 (0x00)
Checksum: 0xfe00 - BAD (should be 0xecad)
Address: 136
Function: 0 (0x00)
Checksum: 0x7a03 - BAD (should be 0x6420)
Address: 0
Exception Code: 255
Checksum: 0x0000 - BAD (should be 0x8038)
Address: 255
Function: 0 (0x00)
Checksum: 0x0080 - BAD (should be 0x4cfd)
Address: 0
Function: 17 (0x11) - Report Slave ID
Exception Code: 254
Checksum: 0x8500 - BAD (should be 0x8b16)
[21/12/2023 14:38:37]
Address: 245
Function: 97 (0x61)
Exception Code: 8
Checksum: 0x53fe - BAD (should be 0xdc0d)
Address: 0
Function: 62 (0x3e)
Checksum: 0x0790 - BAD (should be 0x950c)
Address: 0
Function: 98 (0x62)
Exception Code: 192
Checksum: 0x77dc - BAD (should be 0x1e2a)
Address: 196
Function: 0 (0x00)
Checksum: 0x4b00 - BAD (should be 0x36dd)
Address: 128
Byte Count: 226
Values: 00 9f dc 44 00 a0 d5 00 ef 00 7d f0 00 e8 7e 00 3e ff 02 0f 00 2f 00 68 53 00 09
Coils 0-7: 00000000
Coils 8-15: 11111001
Coils 16-23: 00111011
Coils 24-31: 00100010
Coils 40-47: 00000101
Coils 48-55: 10101011
Coils 64-71: 11110111
Coils 80-87: 10111110
Coils 104-111: 00010111
Coils 112-119: 01111110
Coils 128-135: 01111100
Coils 136-143: 11111111
Coils 144-151: 01000000
Coils 152-159: 11110000
Coils 168-175: 11110100
Coils 184-191: 00010110
Coils 192-199: 11001010
Coils 208-215: 10010000
Checksum: 0x00ce - BAD (should be 0xa93b)
Address: 144
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x145d)
[21/12/2023 14:38:38]
Address: 175
Function: 84 (0x54)
Exception Code: 160
Checksum: 0x6dfc - BAD (should be 0x79f1)
Address: 27
Exception Code: 0
Checksum: 0x00e0 - BAD (should be 0x06aa)
Address: 0
Function: 65 (0x41)
Checksum: 0x0040 - BAD (should be 0xa2b5)
Address: 247
Function: 66 (0x42)
Exception Code: 0
Checksum: 0x0091 - BAD (should be 0x4f0d)
Address: 244
Function: 61 (0x3d)
Exception Code: 0
Checksum: 0xfa05 - BAD (should be 0x80d7)
Address: 4
Checksum: 0xd100 - BAD (should be 0x6d54)
[21/12/2023 14:38:39]
Address: 64
Function: 21 (0x15) - Write File record
Request data length: 0
Checksum: 0x8f05 - BAD (should be 0x18ce)
Address: 63
Function: 41 (0x29)
Checksum: 0x6e00 - BAD (should be 0x7483)
Address: 128
Function: 0 (0x00)
Checksum: 0xdb00 - BAD (should be 0x4deb)
Address: 30
Byte Count: 253
Values: 00 a0 fc f0 fc 00 3d ff 7a f8 00 ef c0 00 00 64 e5 a0 00 47 00 a4 00 05 02 29 04
Coils 0-7: 00000000
Coils 8-15: 00000101
Coils 32-39: 00111111
Coils 48-55: 10111100
Coils 64-71: 01011110
Coils 72-79: 00011111
Coils 88-95: 11110111
Coils 96-103: 00000011
Coils 120-127: 00100110
Coils 128-135: 10100111
Coils 136-143: 00000101
Coils 152-159: 11100010
Coils 168-175: 00100101
Coils 184-191: 10100000
Coils 200-207: 10010100
Coils 208-215: 00100000
Checksum: 0xf8b8 - BAD (should be 0x27e4)
Address: 0
Exception Code: 0
Checksum: 0x001a - BAD (should be 0x52b2)
Address: 218
Byte Count: 243
Values: 00 a2 ff fc 00 10 03 00 eb ff 1f 00 22 12 00 05 00 97 f3 00 4b ff a9 00 71 00 9d
Register0: 162
Register1: 65532
Register2: 16
Register3: 768
Register4: 60415
Register5: 7936
Register6: 8722
Register7: 5
Register8: 151
Register9: 62208
Register10: 19455
Register11: 43264
Register12: 28928
Checksum: 0xf900 - BAD (should be 0x1a63)
[21/12/2023 14:38:40]
Address: 119
Exception Code: 0
Checksum: 0x01b0 - BAD (should be 0xbcdc)
Address: 255
Function: 0 (0x00)
Checksum: 0xcbff - BAD (should be 0xfbc4)
Address: 18
Function: 116 (0x74)
Exception Code: 0
Checksum: 0x013f - BAD (should be 0xbebc)
Address: 253
Function: 0 (0x00)
Checksum: 0x27e8 - BAD (should be 0x3552)
Address: 234
Function: 0 (0x00)
Checksum: 0xffbf - BAD (should be 0x7b59)
Address: 107
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xe04e)
[21/12/2023 14:38:41]
Address: 128
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x7bcc)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x053f)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x3ec1)
Address: 0
Function: 0 (0x00)
Checksum: 0xfe00 - BAD (should be 0xb8ea)
Address: 255
Function: 0 (0x00)
Checksum: 0x0400 - BAD (should be 0x7b8c)
[21/12/2023 14:38:42]
Address: 0
Function: 0 (0x00)
Checksum: 0xff00 - BAD (should be 0x6d99)
Address: 0
Exception Code: 0
Checksum: 0x0010 - BAD (should be 0x7b89)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x755f)
Address: 0
Exception Code: 0
Checksum: 0x0008 - BAD (should be 0x89ed)
[21/12/2023 14:38:43]
Address: 0
Function: 0 (0x00)
Checksum: 0x00ff - BAD (should be 0x04d9)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x5a10)
Address: 0
Exception Code: 0
Checksum: 0x00fe - BAD (should be 0xa174)
Address: 0
Exception Code: 0
Checksum: 0x0000 - BAD (should be 0x5d29)
Address: 255
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x7362)
[21/12/2023 14:38:44]
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xe3e0)
Address: 255
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xc27e)
Address: 0
Byte Count: 0
Values:
Checksum: 0x0000 - BAD (should be 0xb6d2)
Address: 0
Function: 0 (0x00)
Checksum: 0xfe00 - BAD (should be 0xb48a)
Address: 255
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xfef8)
[21/12/2023 14:38:45]
Address: 0
Exception Code: 0
Checksum: 0x2200 - BAD (should be 0x4da8)
Address: 254
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xb427)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x2220)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x520b)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xbeca)
[21/12/2023 14:38:46]
Address: 0
Function: 0 (0x00)
Checksum: 0x80ff - BAD (should be 0x38dd)
Address: 0
Function: 0 (0x00)
Checksum: 0x0020 - BAD (should be 0xbcd0)
Address: 0
Function: 0 (0x00)
Checksum: 0x1000 - BAD (should be 0x7f80)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x2a0a)
Address: 0
Exception Code: 0
Checksum: 0x0041 - BAD (should be 0x0c1a)
[21/12/2023 14:38:47]
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xc68e)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xe459)
Address: 0
Function: 0 (0x00)
Checksum: 0x9000 - BAD (should be 0xe78a)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x8822)
[21/12/2023 14:38:48]
Address: 0
Function: 0 (0x00)
Checksum: 0x00ff - BAD (should be 0x0655)
Address: 0
Function: 0 (0x00)
Checksum: 0x0010 - BAD (should be 0xe25d)
Address: 252
Starting Address: 0
Quantity: 0
Checksum: 0x0000 - BAD (should be 0xb1e4)
Address: 255
Byte Count: 0
Values:
Checksum: 0x0001 - BAD (should be 0xe533)
Address: 255
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x30f9)
Address: 0
Function: 0 (0x00)
Checksum: 0x0040 - BAD (should be 0x8e37)
[21/12/2023 14:38:49]
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xd3ef)
Address: 248
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xb412)
Address: 1
Starting Address: 0
Quantity: 39
Checksum: 0x0000 - BAD (should be 0xf025)
Address: 31
Function: 0 (0x00)
Checksum: 0x0002 - BAD (should be 0x2fa2)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xfb70)
[21/12/2023 14:38:50]
Address: 254
Function: 64 (0x40)
Checksum: 0x88f8 - BAD (should be 0x0167)
Address: 48
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x5fb2)
Address: 255
Function: 31 (0x1f)
Checksum: 0xfe00 - BAD (should be 0x32af)
Address: 1
Function: 0 (0x00)
Checksum: 0x4b62 - BAD (should be 0x0a24)
Address: 0
Exception Code: 192
Checksum: 0x000a - BAD (should be 0x4350)
[21/12/2023 14:38:51]
Address: 180
Function: 51 (0x33)
Checksum: 0x01ce - BAD (should be 0x58e0)
Address: 224
Function: 0 (0x00)
Checksum: 0xff00 - BAD (should be 0xe612)
Address: 48
Exception Code: 64
Checksum: 0x8400 - BAD (should be 0x8202)
Address: 15
Function: 96 (0x60)
Exception Code: 0
Checksum: 0x0001 - BAD (should be 0x12bc)
Address: 4
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x68fb)
Address: 0
Function: 19 (0x13)
Checksum: 0x80ff - BAD (should be 0x3552)
[21/12/2023 14:38:52]
Address: 4
Function: 0 (0x00)
Checksum: 0x80fe - BAD (should be 0xa3f2)
Address: 126
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x4dfa)
Address: 200
Exception Code: 128
Checksum: 0x00f0 - BAD (should be 0x332d)
Address: 0
Function: 63 (0x3f)
Checksum: 0xfe00 - BAD (should be 0x50c7)
Address: 0
Exception Code: 2
Checksum: 0xc680 - BAD (should be 0x1af4)
Address: 134
Function: 0 (0x00)
Checksum: 0x0ff0 - BAD (should be 0x29f3)
[21/12/2023 14:38:53]
Address: 1
Function: 25 (0x19)
Checksum: 0x8200 - BAD (should be 0x25e3)
Address: 0
Starting Address: 57599
Quantity: 7376
Checksum: 0x82fe - BAD (should be 0x3e46)
Address: 0
Byte Count: 0
Values:
Checksum: 0x0000 - BAD (should be 0x14f3)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xb5cc)
Address: 128
Function: 0 (0x00)
Exception Code: 0
Checksum: 0x012f - BAD (should be 0x8625)
Address: 65
Function: 0 (0x00)
Checksum: 0xfe00 - BAD (should be 0xdb71)
Address: 28
Function: 96 (0x60)
Checksum: 0x0000 - BAD (should be 0xd806)
[21/12/2023 14:38:54]
Address: 17
Function: 0 (0x00)
Checksum: 0x00f7 - BAD (should be 0x6388)
Address: 128
Function: 0 (0x00)
Checksum: 0x00fe - BAD (should be 0xf5a4)
Address: 0
Starting Address: 35
Quantity: 65024
Checksum: 0x0004 - BAD (should be 0xc442)
Address: 248
Function: 0 (0x00)
Exception Code: 0
Checksum: 0xe000 - BAD (should be 0x0747)
Address: 255
Function: 33 (0x21)
Checksum: 0x1f02 - BAD (should be 0x65f9)
Address: 0
Exception Code: 192
Checksum: 0xff00 - BAD (should be 0xe58c)
Address: 255
Function: 0 (0x00)
Checksum: 0xff7f - BAD (should be 0x7b4e)
Address: 0
Function: 0 (0x00)
Checksum: 0x8000 - BAD (should be 0x3862)
[21/12/2023 14:38:55]
Address: 255
Function: 64 (0x40)
Exception Code: 4
Checksum: 0x000c - BAD (should be 0xb707)
Address: 0
Byte Count: 207
Values: 00 80 fe 00 00 fe c0 de 04 00 f0 f0 00 08 00 f8 3f 00 00 fe 80 00 fe 00 cb 80 00
Coils 0-7: 00000000
Coils 8-15: 00000001
Coils 16-23: 01111111
Coils 40-47: 01111111
Coils 48-55: 00000011
Coils 56-63: 01111011
Coils 104-111: 00010000
Coils 120-127: 00011111
Coils 128-135: 11111100
Coils 160-167: 00000001
Coils 192-199: 11010011
Coils 200-207: 00000001
Checksum: 0x00fc - BAD (should be 0x0425)
Address: 6
Function: 0 (0x00)
Checksum: 0x3fff - BAD (should be 0xf84e)
Address: 128
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xfc4b)
Address: 128
Function: 9 (0x09)
Checksum: 0xf600 - BAD (should be 0x4040)
Address: 0
Exception Code: 255
Checksum: 0x00f8 - BAD (should be 0x882a)
[21/12/2023 14:38:56]
Address: 10
Function: 0 (0x00)
Checksum: 0xa000 - BAD (should be 0x479c)
Address: 1
Exception Code: 0
Checksum: 0x0020 - BAD (should be 0x9579)
Address: 192
Function: 96 (0x60)
Exception Code: 4
Checksum: 0x00b8 - BAD (should be 0xc2fa)
Address: 0
Function: 0 (0x00)
Checksum: 0x00fe - BAD (should be 0xb783)
Address: 0
Function: 48 (0x30)
Checksum: 0x00e0 - BAD (should be 0x274b)
Address: 255
Function: 0 (0x00)
Checksum: 0xe000 - BAD (should be 0x8ce4)
Address: 64
Function: 0 (0x00)
Checksum: 0x0080 - BAD (should be 0xd52b)
[21/12/2023 14:38:57]
Address: 0
Function: 0 (0x00)
Exception Code: 0
Checksum: 0xf000 - BAD (should be 0x75e9)
Address: 0
Function: 0 (0x00)
Checksum: 0x0100 - BAD (should be 0x9266)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x8da3)
Address: 240
Function: 0 (0x00)
Checksum: 0xfe00 - BAD (should be 0xf943)
Address: 0
Function: 0 (0x00)
Checksum: 0xfe00 - BAD (should be 0xe0c3)
Address: 0
Function: 0 (0x00)
Checksum: 0x0001 - BAD (should be 0x6d11)
[21/12/2023 14:38:58]
Address: 240
Function: 0 (0x00)
Checksum: 0xe000 - BAD (should be 0x05a5)
Address: 0
Function: 0 (0x00)
Checksum: 0xfc00 - BAD (should be 0x164d)
Address: 0
Function: 96 (0x60)
Exception Code: 248
Checksum: 0x0100 - BAD (should be 0x89cc)
Address: 128
Function: 0 (0x00)
Exception Code: 0
Checksum: 0x0000 - BAD (should be 0x8a73)
Address: 128
Function: 96 (0x60)
Exception Code: 0
Checksum: 0x0000 - BAD (should be 0x3cb0)
Address: 0
Exception Code: 128
Checksum: 0x0000 - BAD (should be 0xe98a)
Address: 0
Byte Count: 255
Values: 00 00 00 10 00 00 00 00 fc 00 00 00 fc 00 00 00 f0 00 00 00 fe 01 f0 00 00 01 80
Coils 0-7: 00000000
Coils 64-71: 00111111
Coils 128-135: 00001111
Coils 168-175: 10000000
Coils 176-183: 00001111
Coils 200-207: 10000000
Coils 208-215: 00000001
Checksum: 0x0000 - BAD (should be 0x99e7)
[21/12/2023 14:38:59]
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x9b2c)
Address: 128
Exception Code: 0
Checksum: 0x0000 - BAD (should be 0x3135)
Address: 0
Exception Code: 0
Checksum: 0x00ff - BAD (should be 0x12d2)
Address: 128
Exception Code: 0
Checksum: 0x0080 - BAD (should be 0x7d8b)
Address: 255
Function: 0 (0x00)
Checksum: 0x8100 - BAD (should be 0x55ca)
Address: 0
Function: 96 (0x60)
Exception Code: 0
Checksum: 0x00f8 - BAD (should be 0xafa8)
Address: 0
Function: 64 (0x40)
Exception Code: 0
Checksum: 0xbff0 - BAD (should be 0xf171)
[21/12/2023 14:39:00]
Address: 0
Function: 0 (0x00)
Checksum: 0x0005 - BAD (should be 0xc2a1)
Address: 193
Function: 0 (0x00)
Checksum: 0x00e0 - BAD (should be 0xed7e)
Address: 1
Function: 96 (0x60)
Exception Code: 0
Checksum: 0x8000 - BAD (should be 0x2c92)
Address: 240
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x15c8)
Address: 255
Exception Code: 0
Checksum: 0x0000 - BAD (should be 0xfa61)
Address: 128
Function: 0 (0x00)
Checksum: 0x0080 - BAD (should be 0xedf0)
Address: 255
Exception Code: 0
Checksum: 0x0000 - BAD (should be 0x7910)
Address: 0
Exception Code: 0
Checksum: 0xfe08 - BAD (should be 0xf128)
[21/12/2023 14:39:01]
Address: 0
Function: 9 (0x09)
Exception Code: 248
Checksum: 0x0080 - BAD (should be 0x4098)
Address: 248
Function: 0 (0x00)
Checksum: 0x00fe - BAD (should be 0xedb1)
Address: 0
Function: 0 (0x00)
Checksum: 0xff00 - BAD (should be 0x913a)
Address: 128
Exception Code: 1
Checksum: 0x0000 - BAD (should be 0x7b5d)
Address: 192
Function: 0 (0x00)
Checksum: 0x0108 - BAD (should be 0xa9ee)
Address: 0
Function: 0 (0x00)
Exception Code: 136
Checksum: 0x8000 - BAD (should be 0xb0f3)
Address: 0
Sub-function: 33800
Data: 00 09 ff 08 00 01 c0 00 00 00 80 00 fe 80 00 8c e0 80 c0 f8 00 f0 80 00 00 00
Checksum: 0x0004 - BAD (should be 0x1212)
[21/12/2023 14:39:02]
Address: 0
Exception Code: 0
Checksum: 0x00f8 - BAD (should be 0xe27c)
Address: 0
Exception Code: 0
Checksum: 0xc400 - BAD (should be 0x60cb)
Address: 0
Exception Code: 4
Checksum: 0x08f8 - BAD (should be 0x91eb)
Address: 0
Function: 47 (0x2f)
Checksum: 0x0000 - BAD (should be 0xde92)
Address: 254
Sub-function: 57344
Data: 03 80 c0 00 00 80 ff 80 00 88 c0 08 00 00 08 ff 08 00 00 e0 08 00 00 f8 81 00
Checksum: 0xfc80 - BAD (should be 0x7487)
Address: 0
Exception Code: 248
Checksum: 0x88fc - BAD (should be 0xc88a)
Address: 0
Function: 63 (0x3f)
Checksum: 0x84ff - BAD (should be 0xafb2)
[21/12/2023 14:39:03]
Address: 128
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xa6e2)
Address: 8
Function: 0 (0x00)
Checksum: 0x88fc - BAD (should be 0xaa16)
Address: 0
Function: 63 (0x3f)
Checksum: 0x8800 - BAD (should be 0xe304)
Address: 9
Exception Code: 0
Checksum: 0x0008 - BAD (should be 0x3eed)
Address: 254
Function: 64 (0x40)
Exception Code: 224
Checksum: 0xc0fe - BAD (should be 0x8403)
Address: 0
Function: 0 (0x00)
Exception Code: 0
Checksum: 0x8000 - BAD (should be 0xfe2b)
Address: 0
Function: 66 (0x42)
Checksum: 0x8100 - BAD (should be 0x31a4)
Address: 0
Function: 0 (0x00)
Exception Code: 224
Checksum: 0x0408 - BAD (should be 0xe974)
[21/12/2023 14:39:04]
Address: 0
Sub-function: 64512
Data: 00 00 f8 00 01 80 f0 88 ff 00 04 00 88 00 00 80 e0 80 00 80 00 88 00 00 80 00
Checksum: 0x8000 - BAD (should be 0x23d9)
Address: 128
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x8aae)
Address: 4
Exception Code: 255
Checksum: 0xfc80 - BAD (should be 0x37a3)
Address: 255
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x9e7b)
Address: 8
Function: 0 (0x00)
Exception Code: 254
Checksum: 0x0008 - BAD (should be 0xb586)
Address: 224
Function: 0 (0x00)
Exception Code: 0
Checksum: 0xf800 - BAD (should be 0xd2c9)
Address: 252
Function: 0 (0x00)
Checksum: 0x0008 - BAD (should be 0x3279)
[21/12/2023 14:39:05]
Address: 9
Function: 0 (0x00)
Checksum: 0x0080 - BAD (should be 0x7ab1)
Address: 254
Function: 0 (0x00)
Checksum: 0x0008 - BAD (should be 0x8bb7)
Address: 240
Function: 0 (0x00)
Checksum: 0x01c0 - BAD (should be 0x8ad3)
Address: 0
Function: 0 (0x00)
Checksum: 0x00fe - BAD (should be 0xf89d)
Address: 128
Function: 0 (0x00)
Checksum: 0xf900 - BAD (should be 0x1b17)
Address: 8
Function: 0 (0x00)
Exception Code: 240
Checksum: 0x00c0 - BAD (should be 0xfcbc)
Address: 0
Function: 0 (0x00)
Checksum: 0x0088 - BAD (should be 0xad83)
[21/12/2023 14:39:06]
Address: 0
Function: 64 (0x40)
Exception Code: 128
Checksum: 0x8000 - BAD (should be 0xcb48)
Address: 1
Function: 0 (0x00)
Checksum: 0x00c0 - BAD (should be 0x2562)
Address: 5
Function: 9 (0x09)
Checksum: 0xe000 - BAD (should be 0xafc0)
Address: 0
Function: 64 (0x40)
Checksum: 0x0800 - BAD (should be 0xca42)
Address: 128
Function: 0 (0x00)
Exception Code: 0
Checksum: 0x0f04 - BAD (should be 0xb966)
Address: 251
Function: 0 (0x00)
Checksum: 0x00ff - BAD (should be 0x6927)
Address: 0
Function: 0 (0x00)
Exception Code: 254
Checksum: 0x0000 - BAD (should be 0x4dd5)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x2f47)
[21/12/2023 14:39:07]
Address: 192
Function: 0 (0x00)
Checksum: 0x00ff - BAD (should be 0x286e)
Address: 0
Function: 96 (0x60)
Exception Code: 0
Checksum: 0x0000 - BAD (should be 0xadac)
Address: 248
Function: 0 (0x00)
Checksum: 0xfffe - BAD (should be 0xec90)
Address: 0
Exception Code: 0
Checksum: 0xffff - BAD (should be 0x122e)
Address: 0
Exception Code: 0
Checksum: 0x00ff - BAD (should be 0x41d0)
Address: 0
Exception Code: 2
Checksum: 0x00fc - BAD (should be 0xf11c)
Address: 0
Exception Code: 0
Checksum: 0x0000 - BAD (should be 0x3e75)
Address: 248
Function: 0 (0x00)
Checksum: 0xe000 - BAD (should be 0xe3a2)
[21/12/2023 14:39:08]
Address: 0
Function: 96 (0x60)
Exception Code: 0
Checksum: 0xc000 - BAD (should be 0x06d6)
Address: 128
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x8395)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x3f4f)
Address: 0
Function: 0 (0x00)
Checksum: 0xc000 - BAD (should be 0x7ed7)
Address: 0
Function: 0 (0x00)
Exception Code: 0
Checksum: 0x0000 - BAD (should be 0x3b78)
Address: 240
Function: 0 (0x00)
Checksum: 0x00fe - BAD (should be 0xb617)
Address: 254
Byte Count: 255
Values: 00 fe 00 fe ff 00 fe 00 00 fe ff ff 00 00 ff 00 fe 00 fc 00 ff 00 fc 00 00 00 fc
Coils 0-7: 00000000
Coils 8-15: 01111111
Coils 24-31: 01111111
Coils 72-79: 01111111
Checksum: 0x0000 - BAD (should be 0xd642)
Address: 0
Byte Count: 0
Values:
Checksum: 0x00e0 - BAD (should be 0x4014)
[21/12/2023 14:39:09]
Address: 0
Function: 64 (0x40)
Exception Code: 0
Checksum: 0x0000 - BAD (should be 0xf1c7)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x54d2)
Address: 0
Exception Code: 0
Checksum: 0xe000 - BAD (should be 0x2fc5)
Address: 0
Function: 0 (0x00)
Checksum: 0x00fc - BAD (should be 0x76f1)
Address: 0
Function: 0 (0x00)
Checksum: 0x00ff - BAD (should be 0xa717)
Address: 0
Exception Code: 0
Checksum: 0x00e0 - BAD (should be 0xfcc9)
Address: 0
Function: 96 (0x60)
Exception Code: 0
Checksum: 0x0000 - BAD (should be 0xf814)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xf1ff)
Address: 0
Function: 0 (0x00)
Checksum: 0xff00 - BAD (should be 0x17f8)
[21/12/2023 14:39:10]
Address: 0
Exception Code: 0
Checksum: 0xfe00 - BAD (should be 0x6915)
Address: 0
Exception Code: 0
Checksum: 0x0000 - BAD (should be 0xf223)
Address: 224
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xf7b9)
Address: 0
Function: 0 (0x00)
Checksum: 0x0080 - BAD (should be 0xd9a9)
Address: 255
Function: 0 (0x00)
Exception Code: 0
Checksum: 0xf800 - BAD (should be 0x64a8)
Address: 0
Exception Code: 0
Checksum: 0x0000 - BAD (should be 0x79d8)
Modbus Response (COM8)
Address: 252
Function: 0 (0x00)
Checksum: 0xc000 - BAD (should be 0x92d1)
Address: 0
Function: 64 (0x40)
Exception Code: 0
Checksum: 0x0000 - BAD (should be 0x9d48)
[21/12/2023 14:39:11]
Address: 0
Function: 0 (0x00)
Checksum: 0xc000 - BAD (should be 0x9833)
Address: 240
Function: 0 (0x00)
Checksum: 0x00fe - BAD (should be 0x7c6f)
Address: 0
Byte Count: 254
Values: 00 fe 00 fe 00 00 ff 00 fe 00 00 fe 00 fc 00 80 fc 00 fc 00 80 fc 01 00 00 f8 00
Coils 0-7: 00000000
Coils 64-71: 01111111
Coils 120-127: 00000001
Coils 176-183: 10000000
Checksum: 0x0800 - BAD (should be 0x9d5d)
Address: 240
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x6021)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xbeae)
Address: 0
Function: 0 (0x00)
Exception Code: 0
Checksum: 0x0000 - BAD (should be 0xb50d)
Address: 0
Function: 0 (0x00)
Checksum: 0x00fe - BAD (should be 0xf39e)
Address: 0
Exception Code: 0
Checksum: 0xc000 - BAD (should be 0xd986)
[21/12/2023 14:39:12]
Address: 31
Function: 64 (0x40)
Exception Code: 0
Checksum: 0x0000 - BAD (should be 0x270f)
Address: 0
Function: 0 (0x00)
Checksum: 0x00f0 - BAD (should be 0x67ea)
Address: 0
Function: 0 (0x00)
Checksum: 0xfe01 - BAD (should be 0xd709)
Address: 0
Function: 127 (0x7f)
Exception Code: 0
Checksum: 0x0000 - BAD (should be 0xdb43)
Address: 0
Function: 0 (0x00)
Exception Code: 0
Checksum: 0x0002 - BAD (should be 0x9f49)
Address: 0
Function: 0 (0x00)
Checksum: 0xf800 - BAD (should be 0x8b30)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x67a7)
Address: 224
Function: 0 (0x00)
Checksum: 0x00ff - BAD (should be 0x4944)
[21/12/2023 14:39:13]
Address: 120
Function: 68 (0x44)
Exception Code: 0
Checksum: 0x0000 - BAD (should be 0x1dcb)
Address: 0
Function: 0 (0x00)
Exception Code: 0
Checksum: 0x0000 - BAD (should be 0x86eb)
Address: 0
Function: 0 (0x00)
Exception Code: 0
Checksum: 0x0600 - BAD (should be 0xe388)
Address: 252
Exception Code: 254
Checksum: 0x0000 - BAD (should be 0xef38)
Address: 240
Function: 0 (0x00)
Checksum: 0x80e0 - BAD (should be 0x8047)
Address: 0
Function: 0 (0x00)
Checksum: 0x8000 - BAD (should be 0x0a20)
Address: 0
Function: 0 (0x00)
Checksum: 0x00e0 - BAD (should be 0x585c)
[21/12/2023 14:39:14]
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x080d)
Address: 0
Function: 1 (0x01) - Read Coils
Byte Count: 0
Values:
Checksum: 0x0000 - BAD (should be 0xc72e)
Address: 0
Function: 0 (0x00)
Checksum: 0x00cf - BAD (should be 0x9ec7)
Address: 0
Data: 00 00 00 00 00 80 00 00 40 00 00 00 ff 00 81 04 00 00 00 02 ff 00 00 fc fc 00
Checksum: 0x0000 - BAD (should be 0xd7d0)
Address: 16
Function: 124 (0x7c)
Exception Code: 0
Checksum: 0x1002 - BAD (should be 0xca15)
Address: 254
Function: 0 (0x00)
Checksum: 0x00fc - BAD (should be 0xfe83)
Address: 232
Function: 96 (0x60)
Exception Code: 248
Checksum: 0x0f13 - BAD (should be 0x8731)
Address: 4
Exception Code: 208
Checksum: 0x00f8 - BAD (should be 0x3537)
Address: 16
Exception Code: 255
Checksum: 0x000a - BAD (should be 0x36d4)
[21/12/2023 14:39:15]
Address: 0
Function: 64 (0x40)
Exception Code: 192
Checksum: 0x4300 - BAD (should be 0x05f4)
Address: 0
Function: 0 (0x00)
Checksum: 0x1300 - BAD (should be 0xa36b)
Address: 128
Function: 0 (0x00)
Checksum: 0x8100 - BAD (should be 0xd9a7)
Address: 1
Function: 0 (0x00)
Checksum: 0x0022 - BAD (should be 0xf3ce)
Address: 0
Function: 48 (0x30)
Checksum: 0x1afb - BAD (should be 0x1976)
Address: 0
Function: 32 (0x20)
Checksum: 0x0401 - BAD (should be 0x2c9f)
Address: 8
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x4477)
Address: 5
Function: 0 (0x00)
Checksum: 0xfec0 - BAD (should be 0x65e5)
Address: 0
Function: 66 (0x42)
Exception Code: 2
Checksum: 0x3ee1 - BAD (should be 0x1b0e)
Address: 24
Function: 8 (0x08) - Diagnostic
Sub-function: 64512
Data: 04 00 02 ff fc 00 44 f0 00 00 3e f8 f6 00 f8 00 c0 00 00 05 c1 00 00 f5 00 00
Checksum: 0x3ae9 - BAD (should be 0xc4a0)
[21/12/2023 14:39:16]
Address: 0
Function: 16 (0x10) - Write Multiple Registers
Starting Address: 35327
Quantity: 216
Checksum: 0xff00 - BAD (should be 0x5234)
Address: 220
Function: 41 (0x29)
Checksum: 0x0019 - BAD (should be 0x9d8c)
Address: 240
Function: 120 (0x78)
Exception Code: 248
Checksum: 0x00c0 - BAD (should be 0x2427)
Address: 50
Function: 65 (0x41)
Exception Code: 0
Checksum: 0x10fc - BAD (should be 0x3798)
Address: 0
Function: 15 (0x0f) - Write Multiple Coils
Starting Address: 7680
Quantity: 18685
Checksum: 0x0701 - BAD (should be 0x1cb0)
Address: 253
Function: 0 (0x00)
Checksum: 0x0003 - BAD (should be 0xb730)
Address: 2
Exception Code: 0
Checksum: 0x7e2e - BAD (should be 0x4e7c)
Address: 56
Function: 0 (0x00)
Checksum: 0x0062 - BAD (should be 0x855d)
Address: 255
Function: 0 (0x00)
Checksum: 0x4c70 - BAD (should be 0xd0ea)
Address: 0
Function: 0 (0x00)
Exception Code: 216
Checksum: 0x0000 - BAD (should be 0x34fb)
[21/12/2023 14:39:17]
Address: 1
Byte Count: 0
Values:
Checksum: 0x0002 - BAD (should be 0x11d0)
Address: 255
Function: 0 (0x00)
Checksum: 0x5084 - BAD (should be 0x0efa)
Address: 255
Function: 95 (0x5f)
Exception Code: 0
Checksum: 0xf08c - BAD (should be 0x9e48)
Address: 0
Exception Code: 64
Checksum: 0x0000 - BAD (should be 0x60ae)
Address: 7
Sub-function: 4608
Data: 68 00 00 00 e8 ff 00 f0 80 00 00 00 00 00 00 ff 00 45 00 00 00 00 00 00 00 00
Checksum: 0x0000 - BAD (should be 0x7e16)
Address: 254
Function: 0 (0x00)
Checksum: 0x0050 - BAD (should be 0xb6f1)
Address: 4
Sub-function: 21759
Data: 00 00 00 00 00 81 00 00 00 00 fd 00 80 f1 00 00 ff 00 80 00 14 00 84 c8 00 00
Checksum: 0x0002 - BAD (should be 0x3b5b)
Address: 177
Function: 0 (0x00)
Checksum: 0xfe00 - BAD (should be 0x98e9)
Address: 16
Function: 0 (0x00)
Checksum: 0xff08 - BAD (should be 0x7a6c)
[21/12/2023 14:39:18]
Address: 1
Function: 4 (0x04) - Read Input Registers
Byte Count: 64
Values: 83 00 00 00 00 00 80 82 80 00 00 00 00 ff 00 fe f2 fc ff 00 63 02 00 00 f8 fe 00
Register0: 33536
Register1: 0
Register2: 0
Register3: 32898
Register4: 32768
Register5: 0
Register6: 255
Register7: 254
Register8: 62204
Register9: 65280
Register10: 25346
Register11: 0
Register12: 63742
Checksum: 0x2c11 - BAD (should be 0x22e5)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x2751)
Address: 0
Function: 0 (0x00)
Checksum: 0x0100 - BAD (should be 0x8fa6)
Address: 0
Address: 1820
Value: 1024
Checksum: 0x0400 - BAD (should be 0x9ba7)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x0cb8)
Address: 41
Function: 112 (0x70)
Exception Code: 2
Checksum: 0x00f7 - BAD (should be 0x220f)
Address: 246
Function: 0 (0x00)
Checksum: 0x0040 - BAD (should be 0x69c2)
Address: 125
Function: 25 (0x19)
Exception Code: 180
Checksum: 0xff00 - BAD (should be 0x37f1)
Address: 48
Function: 63 (0x3f)
Checksum: 0x0000 - BAD (should be 0x6781)
[21/12/2023 14:39:19]
Address: 0
Function: 0 (0x00)
Checksum: 0x8040 - BAD (should be 0x057d)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xf34e)
Address: 255
Function: 0 (0x00)
Checksum: 0x0080 - BAD (should be 0x2072)
Address: 0
Function: 0 (0x00)
Checksum: 0x0100 - BAD (should be 0xec5d)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xe2ea)
[21/12/2023 14:39:20]
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x4f83)
Address: 0
Function: 0 (0x00)
Checksum: 0x00ff - BAD (should be 0x5c1c)
Address: 0
Function: 0 (0x00)
Exception Code: 0
Checksum: 0x0200 - BAD (should be 0xb0b1)
Address: 0
Function: 0 (0x00)
Checksum: 0x0020 - BAD (should be 0xfb19)
[21/12/2023 14:39:21]
Address: 255
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x0af2)
Address: 0
Function: 0 (0x00)
Checksum: 0x00ff - BAD (should be 0x4eb1)
Address: 0
Exception Code: 0
Checksum: 0x0040 - BAD (should be 0xd5f4)
Address: 255
Function: 0 (0x00)
Checksum: 0x0020 - BAD (should be 0x3175)
Address: 128
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xbb28)
[21/12/2023 14:39:22]
Address: 0
Function: 0 (0x00)
Address: 2
Starting Address: 0
Quantity: 0
Checksum: 0xff00 - BAD (should be 0x8870)
Address: 255
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xefb5)
Address: 132
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x4fea)
Address: 0
Function: 0 (0x00)
Checksum: 0x8000 - BAD (should be 0x19a0)
[21/12/2023 14:39:23]
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x57e3)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x299b)
Address: 0
Function: 0 (0x00)
Checksum: 0x0004 - BAD (should be 0x8de4)
Address: 0
Function: 0 (0x00)
Exception Code: 0
Checksum: 0x0000 - BAD (should be 0x014c)
Address: 16
Function: 0 (0x00)
Checksum: 0xff00 - BAD (should be 0x310d)
[21/12/2023 14:39:24]
Address: 0
Byte Count: 0
Values:
Checksum: 0x0001 - BAD (should be 0x64eb)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x282b)
Address: 8
Byte Count: 0
Values:
Checksum: 0x0000 - BAD (should be 0x56d9)
Address: 0
Exception Code: 0
Checksum: 0x0000 - BAD (should be 0x9fa1)
[21/12/2023 14:39:25]
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x6713)
Address: 0
Function: 0 (0x00)
Checksum: 0xff00 - BAD (should be 0xfcde)
Address: 0
Function: 0 (0x00)
Exception Code: 0
Checksum: 0x0000 - BAD (should be 0xd878)
Address: 0
Function: 0 (0x00)
Checksum: 0xff00 - BAD (should be 0xdb7f)
Address: 0
Data: 04 00 00 00 00 00 00 00 00 00 20 00 00 ff 00 00 08 00 00 ff 00 00 80 00 00 00
Checksum: 0x0000 - BAD (should be 0xf17d)
[21/12/2023 14:39:26]
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xcaed)
Address: 64
Exception Code: 0
Checksum: 0x0000 - BAD (should be 0xa8e6)
Address: 255
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x09de)
Address: 0
Function: 0 (0x00)
Checksum: 0xfe00 - BAD (should be 0x8a20)
Address: 255
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x03ea)
[21/12/2023 14:39:27]
Address: 0
Function: 32 (0x20)
Checksum: 0x00ff - BAD (should be 0xebf1)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x98a1)
Address: 0
Function: 0 (0x00)
Checksum: 0x00fe - BAD (should be 0xc35a)
Address: 0
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0x246a)
[21/12/2023 14:39:28]
Address: 255
Function: 0 (0x00)
Checksum: 0x0000 - BAD (should be 0xbac1)
