#include <U8glib-HAL.h>
#include <U8glibPrint.h>
#include <U8glibPrintable.h>
#include <U8glib.h>
   Marlin 3D Printer Firmware
   Copyright (c) 2021 MarlinFirmware [https://github.com/MarlinFirmware/Marlin]
   Based on Sprinter and grbl.
   Copyright (c) 2011 Camiel Gubbels / Erik van der Zalm
   This program is free software: you can redistribute it and/or modify
   it under the terms of the GNU General Public License as published by
   the Free Software Foundation, either version 3 of the License, or
   (at your option) any later version.
   This program is distributed in the hope that it will be useful,
   but WITHOUT ANY WARRANTY; without even the implied warranty of
   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
   GNU General Public License for more details.
   You should have received a copy of the GNU General Public License
   along with this program.  If not, see <https://www.gnu.org/licenses/>.
#pragma once
#define CONFIG_EXAMPLES_DIR "config/examples/Prusa/MK3"
   Configuration.h
   Basic settings such as:
   - Type of electronics
   - Type of temperature sensor
   - Printer geometry
   - Endstop configuration
   - LCD controller
   - Extra features
   Advanced settings can be found in Configuration_adv.h
#define CONFIGURATION_H_VERSION 02010201
//============================= Getting Started =============================
   Here are some useful links to help get your machine configured and calibrated:
   Example Configs:     https://github.com/MarlinFirmware/Configurations/branches/all
   Průša Calculator:    https://blog.prusaprinters.org/calculator_3416/
   Calibration Guides:  https://reprap.org/wiki/Calibration
                        https://reprap.org/wiki/Triffid_Hunter%27s_Calibration_Guide
                        https://sites.google.com/site/repraplogphase/calibration-of-your-reprap
                        https://youtu.be/wAL9d7FgInk
   Calibration Objects: https://www.thingiverse.com/thing:5573
                        https://www.thingiverse.com/thing:1278865
// @section info
// Author info of this build printed to the host during boot and M115
#define STRING_CONFIG_H_AUTHOR "(Prussia3D, Paul_GD MK3S)" // Who made the changes.
//#define CUSTOM_VERSION_FILE Version.h // Path from the root directory (no quotes)
// Disable this for FAN_PIN 8 and FAN1_PIN 6
#define MK3_FAN_PINS
// Is printer equipped with a 3.5:1 gearbox on the extruder?
//#define GEARBOX_BEAR
// Printer needs lower baudrate?
//#define LOWBAUD
// Tall Bear (320mm)?
//#define TALLBEAR
// SuperPINDA present?
//#define SUPERPINDA
 * *** VENDORS PLEASE READ ***
   Marlin allows you to add a custom boot image for Graphical LCDs.
   With this option Marlin will first show your custom screen followed
   by the standard Marlin logo with version number and web URL.
   We encourage you to take advantage of this new feature and we also
   respectfully request that you retain the unmodified Marlin boot screen.
// Show the Marlin bootscreen on startup. ** ENABLE FOR PRODUCTION **
#define SHOW_BOOTSCREEN
// Show the bitmap in Marlin/_Bootscreen.h on startup.
//#define SHOW_CUSTOM_BOOTSCREEN
// Show the bitmap in Marlin/_Statusscreen.h on the status screen.
//#define CUSTOM_STATUS_SCREEN_IMAGE
// @section machine
// Choose the name from boards.h that matches your setup
#ifndef MOTHERBOARD
#define MOTHERBOARD 46
#endif
   Select the serial port on the board to use for communication with the host.
   This allows the connection of wireless adapters (for instance) to non-default port pins.
   Serial port -1 is the USB emulated serial port, if available.
   Note: The first serial port (-1 or 0) will always be used by the Arduino bootloader.
   :[-1, 0, 1, 2, 3, 4, 5, 6, 7]
#define SERIAL_PORT 0
   Serial Port Baud Rate
   This is the default communication speed for all serial ports.
   Set the baud rate defaults for additional serial ports below.
   250000 works in most cases, but you might try a lower speed if
   you commonly experience drop-outs during host printing.
   You may try up to 1000000 to speed up SD file transfer.
   :[2400, 9600, 19200, 38400, 57600, 115200, 250000, 500000, 1000000]
#if ENABLED(LOWBAUD)
#define BAUDRATE 115200
#else
#define BAUDRATE 250000
#endif
//#define BAUD_RATE_GCODE     // Enable G-code M575 to set the baud rate
   Select a secondary serial port on the board to use for communication with the host.
   Currently Ethernet (-2) is only supported on Teensy 4.1 boards.
   :[-2, -1, 0, 1, 2, 3, 4, 5, 6, 7]
//#define SERIAL_PORT_2 -1
//#define BAUDRATE_2 250000   // :[2400, 9600, 19200, 38400, 57600, 115200, 250000, 500000, 1000000] Enable to override BAUDRATE
   Select a third serial port on the board to use for communication with the host.
   Currently only supported for AVR, DUE, LPC1768/9 and STM32/STM32F1
//#define SERIAL_PORT_3 1
//#define BAUDRATE_3 250000   // :[2400, 9600, 19200, 38400, 57600, 115200, 250000, 500000, 1000000] Enable to override BAUDRATE
// Enable the Bluetooth serial interface on AT90USB devices
//#define BLUETOOTH
// Name displayed in the LCD "Ready" message and Info menu
#define CUSTOM_MACHINE_NAME "Dara1"
// Printer's unique ID, used by some programs to differentiate between machines.
// Choose your own or use a service like https://www.uuidgenerator.net/version4
//#define MACHINE_UUID "00000000-0000-0000-0000-000000000000"
// @section stepper drivers
   Stepper Drivers
   These settings allow Marlin to tune stepper driver timing and enable advanced options for
   stepper drivers that support them. You may also override timing options in Configuration_adv.h.
   Use TMC2208/TMC2208_STANDALONE for TMC2225 drivers and TMC2209/TMC2209_STANDALONE for TMC2226 drivers.
   Options: A4988, A5984, DRV8825, LV8729, TB6560, TB6600, TMC2100,
            TMC2130, TMC2130_STANDALONE, TMC2160, TMC2160_STANDALONE,
            TMC2208, TMC2208_STANDALONE, TMC2209, TMC2209_STANDALONE,
            TMC26X,  TMC26X_STANDALONE,  TMC2660, TMC2660_STANDALONE,
            TMC5130, TMC5130_STANDALONE, TMC5160, TMC5160_STANDALONE
   :['A4988', 'A5984', 'DRV8825', 'LV8729', 'TB6560', 'TB6600', 'TMC2100', 'TMC2130', 'TMC2130_STANDALONE', 'TMC2160', 'TMC2160_STANDALONE', 'TMC2208', 'TMC2208_STANDALONE', 'TMC2209', 'TMC2209_STANDALONE', 'TMC26X', 'TMC26X_STANDALONE', 'TMC2660', 'TMC2660_STANDALONE', 'TMC5130', 'TMC5130_STANDALONE', 'TMC5160', 'TMC5160_STANDALONE']
#define X_DRIVER_TYPE  TMC2130
#define Y_DRIVER_TYPE  TMC2130
#define Z_DRIVER_TYPE  TMC2130
//#define X2_DRIVER_TYPE A4988
//#define Y2_DRIVER_TYPE A4988
//#define Z2_DRIVER_TYPE A4988
//#define Z3_DRIVER_TYPE A4988
//#define Z4_DRIVER_TYPE A4988
//#define I_DRIVER_TYPE  A4988
//#define J_DRIVER_TYPE  A4988
//#define K_DRIVER_TYPE  A4988
//#define U_DRIVER_TYPE  A4988
//#define V_DRIVER_TYPE  A4988
//#define W_DRIVER_TYPE  A4988
#define E0_DRIVER_TYPE TMC2130
//#define E1_DRIVER_TYPE A4988
//#define E2_DRIVER_TYPE A4988
//#define E3_DRIVER_TYPE A4988
//#define E4_DRIVER_TYPE A4988
//#define E5_DRIVER_TYPE A4988
//#define E6_DRIVER_TYPE A4988
//#define E7_DRIVER_TYPE A4988
   Additional Axis Settings
   Define AXISn_ROTATES for all axes that rotate or pivot.
   Rotational axis coordinates are expressed in degrees.
   AXISn_NAME defines the letter used to refer to the axis in (most) G-code commands.
   By convention the names and roles are typically:
     'A' : Rotational axis parallel to X
     'B' : Rotational axis parallel to Y
     'C' : Rotational axis parallel to Z
     'U' : Secondary linear axis parallel to X
     'V' : Secondary linear axis parallel to Y
     'W' : Secondary linear axis parallel to Z
   Regardless of these settings the axes are internally named I, J, K, U, V, W.
#ifdef I_DRIVER_TYPE
#define AXIS4_NAME 'A' // :['A', 'B', 'C', 'U', 'V', 'W']
#define AXIS4_ROTATES
#endif
#ifdef J_DRIVER_TYPE
#define AXIS5_NAME 'B' // :['B', 'C', 'U', 'V', 'W']
#define AXIS5_ROTATES
#endif
#ifdef K_DRIVER_TYPE
#define AXIS6_NAME 'C' // :['C', 'U', 'V', 'W']
#define AXIS6_ROTATES
#endif
#ifdef U_DRIVER_TYPE
#define AXIS7_NAME 'U' // :['U', 'V', 'W']
//#define AXIS7_ROTATES
#endif
#ifdef V_DRIVER_TYPE
#define AXIS8_NAME 'V' // :['V', 'W']
//#define AXIS8_ROTATES
#endif
#ifdef W_DRIVER_TYPE
#define AXIS9_NAME 'W' // :['W']
//#define AXIS9_ROTATES
#endif
// @section extruder
// This defines the number of extruders
// :[0, 1, 2, 3, 4, 5, 6, 7, 8]
#define EXTRUDERS 1
// Generally expected filament diameter (1.75, 2.85, 3.0, ...). Used for Volumetric, Filament Width Sensor, etc.
#define DEFAULT_NOMINAL_FILAMENT_DIA 1.75
// For Cyclops or any "multi-extruder" that shares a single nozzle.
//#define SINGLENOZZLE
// Save and restore temperature and fan speed on tool-change.
// Set standby for the unselected tool with M104/106/109 T...
#if ENABLED(SINGLENOZZLE)
//#define SINGLENOZZLE_STANDBY_TEMP
//#define SINGLENOZZLE_STANDBY_FAN
#endif
// A dual extruder that uses a single stepper motor
//#define SWITCHING_EXTRUDER
#if ENABLED(SWITCHING_EXTRUDER)
#define SWITCHING_EXTRUDER_SERVO_NR 0
#define SWITCHING_EXTRUDER_SERVO_ANGLES { 0, 90 } // Angles for E0, E1[, E2, E3]
#if EXTRUDERS > 3
#define SWITCHING_EXTRUDER_E23_SERVO_NR 1
#endif
#endif
// A dual-nozzle that uses a servomotor to raise/lower one (or both) of the nozzles
//#define SWITCHING_NOZZLE
#if ENABLED(SWITCHING_NOZZLE)
#define SWITCHING_NOZZLE_SERVO_NR 0
//#define SWITCHING_NOZZLE_E1_SERVO_NR 1          // If two servos are used, the index of the second
#define SWITCHING_NOZZLE_SERVO_ANGLES { 0, 90 }   // Angles for E0, E1 (single servo) or lowered/raised (dual servo)
#define SWITCHING_NOZZLE_SERVO_DWELL 2500         // Dwell time to wait for servo to make physical move
#endif
   Two separate X-carriages with extruders that connect to a moving part
   via a solenoid docking mechanism. Requires SOL1_PIN and SOL2_PIN.
//#define PARKING_EXTRUDER
   via a magnetic docking mechanism using movements and no solenoid
   project   : https://www.thingiverse.com/thing:3080893
   movements : https://youtu.be/0xCEiG9VS3k
               https://youtu.be/Bqbcs0CU2FE
//#define MAGNETIC_PARKING_EXTRUDER
#if EITHER(PARKING_EXTRUDER, MAGNETIC_PARKING_EXTRUDER)
#define PARKING_EXTRUDER_PARKING_X { -78, 184 }     // X positions for parking the extruders
#define PARKING_EXTRUDER_GRAB_DISTANCE 1            // (mm) Distance to move beyond the parking point to grab the extruder
#if ENABLED(PARKING_EXTRUDER)
#define PARKING_EXTRUDER_SOLENOIDS_INVERT           // If enabled, the solenoid is NOT magnetized with applied voltage
#define PARKING_EXTRUDER_SOLENOIDS_PINS_ACTIVE LOW  // LOW or HIGH pin signal energizes the coil
#define PARKING_EXTRUDER_SOLENOIDS_DELAY 250        // (ms) Delay for magnetic field. No delay if 0 or not defined.
//#define MANUAL_SOLENOID_CONTROL                   // Manual control of docking solenoids with M380 S / M381
#elif ENABLED(MAGNETIC_PARKING_EXTRUDER)
#define MPE_FAST_SPEED      9000      // (mm/min) Speed for travel before last distance point
#define MPE_SLOW_SPEED      4500      // (mm/min) Speed for last distance travel to park and couple
#define MPE_TRAVEL_DISTANCE   10      // (mm) Last distance point
#define MPE_COMPENSATION       0      // Offset Compensation -1 , 0 , 1 (multiplier) only for coupling
#endif
#endif
   Switching Toolhead
   Support for swappable and dockable toolheads, such as
   the E3D Tool Changer. Toolheads are locked with a servo.
//#define SWITCHING_TOOLHEAD
   Magnetic Switching Toolhead
   Support swappable and dockable toolheads with a magnetic
   docking mechanism using movement and no servo.
//#define MAGNETIC_SWITCHING_TOOLHEAD
   Electromagnetic Switching Toolhead
   Parking for CoreXY / HBot kinematics.
   Toolheads are parked at one edge and held with an electromagnet.
   Supports more than 2 Toolheads. See https://youtu.be/JolbsAKTKf4
//#define ELECTROMAGNETIC_SWITCHING_TOOLHEAD
#if ANY(SWITCHING_TOOLHEAD, MAGNETIC_SWITCHING_TOOLHEAD, ELECTROMAGNETIC_SWITCHING_TOOLHEAD)
#define SWITCHING_TOOLHEAD_Y_POS          235         // (mm) Y position of the toolhead dock
#define SWITCHING_TOOLHEAD_Y_SECURITY      10         // (mm) Security distance Y axis
#define SWITCHING_TOOLHEAD_Y_CLEAR         60         // (mm) Minimum distance from dock for unobstructed X axis
#define SWITCHING_TOOLHEAD_X_POS          { 215, 0 }  // (mm) X positions for parking the extruders
#if ENABLED(SWITCHING_TOOLHEAD)
#define SWITCHING_TOOLHEAD_SERVO_NR       2         // Index of the servo connector
#define SWITCHING_TOOLHEAD_SERVO_ANGLES { 0, 180 }  // (degrees) Angles for Lock, Unlock
#elif ENABLED(MAGNETIC_SWITCHING_TOOLHEAD)
#define SWITCHING_TOOLHEAD_Y_RELEASE      5         // (mm) Security distance Y axis
#define SWITCHING_TOOLHEAD_X_SECURITY   { 90, 150 } // (mm) Security distance X axis (T0,T1)
//#define PRIME_BEFORE_REMOVE                       // Prime the nozzle before release from the dock
#if ENABLED(PRIME_BEFORE_REMOVE)
#define SWITCHING_TOOLHEAD_PRIME_MM           20  // (mm)   Extruder prime length
#define SWITCHING_TOOLHEAD_RETRACT_MM         10  // (mm)   Retract after priming length
#define SWITCHING_TOOLHEAD_PRIME_FEEDRATE    300  // (mm/min) Extruder prime feedrate
#define SWITCHING_TOOLHEAD_RETRACT_FEEDRATE 2400  // (mm/min) Extruder retract feedrate
#endif
#elif ENABLED(ELECTROMAGNETIC_SWITCHING_TOOLHEAD)
#define SWITCHING_TOOLHEAD_Z_HOP          2         // (mm) Z raise for switching
#endif
#endif
   "Mixing Extruder"
     - Adds G-codes M163 and M164 to set and "commit" the current mix factors.
     - Extends the stepping routines to move multiple steppers in proportion to the mix.
     - Optional support for Repetier Firmware's 'M164 S<index>' supporting virtual tools.
     - This implementation supports up to two mixing extruders.
     - Enable DIRECT_MIXING_IN_G1 for M165 and mixing in G1 (from Pia Taubert's reference implementation).
//#define MIXING_EXTRUDER
#if ENABLED(MIXING_EXTRUDER)
#define MIXING_STEPPERS 2        // Number of steppers in your mixing extruder
#define MIXING_VIRTUAL_TOOLS 16  // Use the Virtual Tool method with M163 and M164
//#define DIRECT_MIXING_IN_G1    // Allow ABCDHI mix factors in G1 movement commands
//#define GRADIENT_MIX           // Support for gradient mixing with M166 and LCD
//#define MIXING_PRESETS         // Assign 8 default V-tool presets for 2 or 3 MIXING_STEPPERS
#if ENABLED(GRADIENT_MIX)
//#define GRADIENT_VTOOL       // Add M166 T to use a V-tool index as a Gradient alias
#endif
#endif
// Offset of the extruders (uncomment if using more than one and relying on firmware to position when changing).
// The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder).
// For the other hotends it is their distance from the extruder 0 hotend.
//#define HOTEND_OFFSET_X { 0.0, 20.00 } // (mm) relative X-offset for each nozzle
//#define HOTEND_OFFSET_Y { 0.0, 5.00 }  // (mm) relative Y-offset for each nozzle
//#define HOTEND_OFFSET_Z { 0.0, 0.00 }  // (mm) relative Z-offset for each nozzle
// @section multi-material
   Multi-Material Unit
   Set to one of these predefined models:
     PRUSA_MMU1           : Průša MMU1 (The "multiplexer" version)
     PRUSA_MMU2           : Průša MMU2
     PRUSA_MMU2S          : Průša MMU2S (Requires MK3S extruder with motion sensor, EXTRUDERS = 5)
     EXTENDABLE_EMU_MMU2  : MMU with configurable number of filaments (ERCF, SMuFF or similar with Průša MMU2 compatible firmware)
     EXTENDABLE_EMU_MMU2S : MMUS with configurable number of filaments (ERCF, SMuFF or similar with Průša MMU2 compatible firmware)
   Requires NOZZLE_PARK_FEATURE to park print head in case MMU unit fails.
   See additional options in Configuration_adv.h.
   :["PRUSA_MMU1", "PRUSA_MMU2", "PRUSA_MMU2S", "EXTENDABLE_EMU_MMU2", "EXTENDABLE_EMU_MMU2S"]
//#define MMU_MODEL PRUSA_MMU2
// @section psu control
   Power Supply Control
   Enable and connect the power supply to the PS_ON_PIN.
   Specify whether the power supply is active HIGH or active LOW.
//#define PSU_CONTROL
//#define PSU_NAME "Power Supply"
#if ENABLED(PSU_CONTROL)
//#define MKS_PWC                 // Using the MKS PWC add-on
//#define PS_OFF_CONFIRM          // Confirm dialog when power off
//#define PS_OFF_SOUND            // Beep 1s when power off
#define PSU_ACTIVE_STATE LOW      // Set 'LOW' for ATX, 'HIGH' for X-Box
//#define PSU_DEFAULT_OFF               // Keep power off until enabled directly with M80
//#define PSU_POWERUP_DELAY      250    // (ms) Delay for the PSU to warm up to full power
//#define LED_POWEROFF_TIMEOUT 10000    // (ms) Turn off LEDs after power-off, with this amount of delay
//#define POWER_OFF_TIMER               // Enable M81 D<seconds> to power off after a delay
//#define POWER_OFF_WAIT_FOR_COOLDOWN   // Enable M81 S to power off only after cooldown
//#define PSU_POWERUP_GCODE  "M355 S1"  // G-code to run after power-on (e.g., case light on)
//#define PSU_POWEROFF_GCODE "M355 S0"  // G-code to run before power-off (e.g., case light off)
//#define AUTO_POWER_CONTROL      // Enable automatic control of the PS_ON pin
#if ENABLED(AUTO_POWER_CONTROL)
#define AUTO_POWER_FANS         // Turn on PSU if fans need power
#define AUTO_POWER_E_FANS
#define AUTO_POWER_CONTROLLERFAN
#define AUTO_POWER_CHAMBER_FAN
#define AUTO_POWER_COOLER_FAN
#define POWER_TIMEOUT              30 // (s) Turn off power if the machine is idle for this duration
//#define POWER_OFF_DELAY          60 // (s) Delay of poweroff after M81 command. Useful to let fans run for extra time.
#endif
#if EITHER(AUTO_POWER_CONTROL, POWER_OFF_WAIT_FOR_COOLDOWN)
//#define AUTO_POWER_E_TEMP        50 // (°C) PSU on if any extruder is over this temperature
//#define AUTO_POWER_CHAMBER_TEMP  30 // (°C) PSU on if the chamber is over this temperature
//#define AUTO_POWER_COOLER_TEMP   26 // (°C) PSU on if the cooler is over this temperature
#endif
#endif
//============================= Thermal Settings ============================
// @section temperature
   --NORMAL IS 4.7kΩ PULLUP!-- 1kΩ pullup can be used on hotend sensor, using correct resistor and table
   Temperature sensors available:
    SPI RTD/Thermocouple Boards - IMPORTANT: Read the NOTE below!
      -5 : MAX31865 with Pt100/Pt1000, 2, 3, or 4-wire  (only for sensors 0-1)
                    NOTE: You must uncomment/set the MAX31865_*_OHMS_n defines below.
      -3 : MAX31855 with Thermocouple, -200°C to +700°C (only for sensors 0-1)
      -2 : MAX6675  with Thermocouple, 0°C to +700°C    (only for sensors 0-1)
    NOTE: Ensure TEMP_n_CS_PIN is set in your pins file for each TEMP_SENSOR_n using an SPI Thermocouple. By default,
          Hardware SPI on the default serial bus is used. If you have also set TEMP_n_SCK_PIN and TEMP_n_MISO_PIN,
          Software SPI will be used on those ports instead. You can force Hardware SPI on the default bus in the
          Configuration_adv.h file. At this time, separate Hardware SPI buses for sensors are not supported.
    Analog Themocouple Boards
      -4 : AD8495 with Thermocouple
      -1 : AD595  with Thermocouple
    Analog Thermistors - 4.7kΩ pullup - Normal
       1 : 100kΩ  EPCOS - Best choice for EPCOS thermistors
     331 : 100kΩ  Same as #1, but 3.3V scaled for MEGA
     332 : 100kΩ  Same as #1, but 3.3V scaled for DUE
       2 : 200kΩ  ATC Semitec 204GT-2
     202 : 200kΩ  Copymaster 3D
       3 : ???Ω   Mendel-parts thermistor
       4 : 10kΩ   Generic Thermistor !! DO NOT use for a hotend - it gives bad resolution at high temp. !!
       5 : 100kΩ  ATC Semitec 104GT-2/104NT-4-R025H42G - Used in ParCan, J-Head, and E3D, SliceEngineering 300°C
     501 : 100kΩ  Zonestar - Tronxy X3A
     502 : 100kΩ  Zonestar - used by hot bed in Zonestar Průša P802M
     503 : 100kΩ  Zonestar (Z8XM2) Heated Bed thermistor
     504 : 100kΩ  Zonestar P802QR2 (Part# QWG-104F-B3950) Hotend Thermistor
     505 : 100kΩ  Zonestar P802QR2 (Part# QWG-104F-3950) Bed Thermistor
     512 : 100kΩ  RPW-Ultra hotend
       6 : 100kΩ  EPCOS - Not as accurate as table #1 (created using a fluke thermocouple)
       7 : 100kΩ  Honeywell 135-104LAG-J01
      71 : 100kΩ  Honeywell 135-104LAF-J01
       8 : 100kΩ  Vishay 0603 SMD NTCS0603E3104FXT
       9 : 100kΩ  GE Sensing AL03006-58.2K-97-G1
      10 : 100kΩ  RS PRO 198-961
      11 : 100kΩ  Keenovo AC silicone mats, most Wanhao i3 machines - beta 3950, 1%
      12 : 100kΩ  Vishay 0603 SMD NTCS0603E3104FXT (#8) - calibrated for Makibox hot bed
      13 : 100kΩ  Hisens up to 300°C - for "Simple ONE" & "All In ONE" hotend - beta 3950, 1%
      15 : 100kΩ  Calibrated for JGAurora A5 hotend
      18 : 200kΩ  ATC Semitec 204GT-2 Dagoma.Fr - MKS_Base_DKU001327
      22 : 100kΩ  GTM32 Pro vB - hotend - 4.7kΩ pullup to 3.3V and 220Ω to analog input
      23 : 100kΩ  GTM32 Pro vB - bed - 4.7kΩ pullup to 3.3v and 220Ω to analog input
      30 : 100kΩ  Kis3d Silicone heating mat 200W/300W with 6mm precision cast plate (EN AW 5083) NTC100K - beta 3950
      60 : 100kΩ  Maker's Tool Works Kapton Bed Thermistor - beta 3950
      61 : 100kΩ  Formbot/Vivedino 350°C Thermistor - beta 3950
      66 : 4.7MΩ  Dyze Design / Trianglelab T-D500 500°C High Temperature Thermistor
      67 : 500kΩ  SliceEngineering 450°C Thermistor
      68 : PT100 amplifier board from Dyze Design
      70 : 100kΩ  bq Hephestos 2
      75 : 100kΩ  Generic Silicon Heat Pad with NTC100K MGB18-104F39050L32
    2000 : 100kΩ  Ultimachine Rambo TDK NTCG104LH104KT1 NTC100K motherboard Thermistor
    Analog Thermistors - 1kΩ pullup - Atypical, and requires changing out the 4.7kΩ pullup for 1kΩ.
    -------                           (but gives greater accuracy and more stable PID)
      51 : 100kΩ  EPCOS (1kΩ pullup)
      52 : 200kΩ  ATC Semitec 204GT-2 (1kΩ pullup)
      55 : 100kΩ  ATC Semitec 104GT-2 - Used in ParCan & J-Head (1kΩ pullup)
    Analog Thermistors - 10kΩ pullup - Atypical
      99 : 100kΩ  Found on some Wanhao i3 machines with a 10kΩ pull-up resistor
    Analog RTDs (Pt100/Pt1000)
     110 : Pt100  with 1kΩ pullup (atypical)
     147 : Pt100  with 4.7kΩ pullup
    1010 : Pt1000 with 1kΩ pullup (atypical)
    1022 : Pt1000 with 2.2kΩ pullup
    1047 : Pt1000 with 4.7kΩ pullup (E3D)
      20 : Pt100  with circuit in the Ultimainboard V2.x with mainboard ADC reference voltage = INA826 amplifier-board supply voltage.
                  NOTE: (1) Must use an ADC input with no pullup. (2) Some INA826 amplifiers are unreliable at 3.3V so consider using sensor 147, 110, or 21.
      21 : Pt100  with circuit in the Ultimainboard V2.x with 3.3v ADC reference voltage (STM32, LPC176x....) and 5V INA826 amplifier board supply.
                  NOTE: ADC pins are not 5V tolerant. Not recommended because it's possible to damage the CPU by going over 500°C.
     201 : Pt100  with circuit in Overlord, similar to Ultimainboard V2.x
    Custom/Dummy/Other Thermal Sensors
       0 : not used
    1000 : Custom - Specify parameters in Configuration_adv.h
     !!! Use these for Testing or Development purposes. NEVER for production machine. !!!
     998 : Dummy Table that ALWAYS reads 25°C or the temperature defined below.
     999 : Dummy Table that ALWAYS reads 100°C or the temperature defined below.
#define TEMP_SENSOR_0 1
#define TEMP_SENSOR_1 0
#define TEMP_SENSOR_2 0
#define TEMP_SENSOR_3 0
#define TEMP_SENSOR_4 0
#define TEMP_SENSOR_5 0
#define TEMP_SENSOR_6 0
#define TEMP_SENSOR_7 0
#define TEMP_SENSOR_BED 1
#if ENABLED(SUPERPINDA)
#define TEMP_SENSOR_PROBE 0
#else
#define TEMP_SENSOR_PROBE 1
#endif
#define TEMP_SENSOR_CHAMBER 0
#define TEMP_SENSOR_COOLER 0
#define TEMP_SENSOR_BOARD 0
#define TEMP_SENSOR_REDUNDANT 0
// Dummy thermistor constant temperature readings, for use with 998 and 999
#define DUMMY_THERMISTOR_998_VALUE  25
#define DUMMY_THERMISTOR_999_VALUE 100
// Resistor values when using MAX31865 sensors (-5) on TEMP_SENSOR_0 / 1
#if TEMP_SENSOR_IS_MAX_TC(0)
#define MAX31865_SENSOR_OHMS_0      100 // (Ω) Typically 100 or 1000 (PT100 or PT1000)
#define MAX31865_CALIBRATION_OHMS_0 430 // (Ω) Typically 430 for Adafruit PT100; 4300 for Adafruit PT1000
#endif
#if TEMP_SENSOR_IS_MAX_TC(1)
#define MAX31865_SENSOR_OHMS_1      100
#define MAX31865_CALIBRATION_OHMS_1 430
#endif
#if TEMP_SENSOR_IS_MAX_TC(2)
#define MAX31865_SENSOR_OHMS_2      100
#define MAX31865_CALIBRATION_OHMS_2 430
#endif
#if HAS_E_TEMP_SENSOR
#define TEMP_RESIDENCY_TIME         10  // (seconds) Time to wait for hotend to "settle" in M109
#define TEMP_WINDOW                  1  // (°C) Temperature proximity for the "temperature reached" timer
#define TEMP_HYSTERESIS              3  // (°C) Temperature proximity considered "close enough" to the target
#endif
#if TEMP_SENSOR_BED
#define TEMP_BED_RESIDENCY_TIME     10  // (seconds) Time to wait for bed to "settle" in M190
#define TEMP_BED_WINDOW              1  // (°C) Temperature proximity for the "temperature reached" timer
#define TEMP_BED_HYSTERESIS          3  // (°C) Temperature proximity considered "close enough" to the target
#endif
#if TEMP_SENSOR_CHAMBER
#define TEMP_CHAMBER_RESIDENCY_TIME 10  // (seconds) Time to wait for chamber to "settle" in M191
#define TEMP_CHAMBER_WINDOW          1  // (°C) Temperature proximity for the "temperature reached" timer
#define TEMP_CHAMBER_HYSTERESIS      3  // (°C) Temperature proximity considered "close enough" to the target
#endif
   Redundant Temperature Sensor (TEMP_SENSOR_REDUNDANT)
   Use a temp sensor as a redundant sensor for another reading. Select an unused temperature sensor, and another
   sensor you'd like it to be redundant for. If the two thermistors differ by TEMP_SENSOR_REDUNDANT_MAX_DIFF (°C),
   the print will be aborted. Whichever sensor is selected will have its normal functions disabled; i.e. selecting
   the Bed sensor (-1) will disable bed heating/monitoring.
   For selecting source/target use: COOLER, PROBE, BOARD, CHAMBER, BED, E0, E1, E2, E3, E4, E5, E6, E7
#if TEMP_SENSOR_REDUNDANT
#define TEMP_SENSOR_REDUNDANT_SOURCE    E1  // The sensor that will provide the redundant reading.
#define TEMP_SENSOR_REDUNDANT_TARGET    E0  // The sensor that we are providing a redundant reading for.
#define TEMP_SENSOR_REDUNDANT_MAX_DIFF  10  // (°C) Temperature difference that will trigger a print abort.
#endif
// Below this temperature the heater will be switched off
// because it probably indicates a broken thermistor wire.
#define HEATER_0_MINTEMP  10
#define HEATER_1_MINTEMP   5
#define HEATER_2_MINTEMP   5
#define HEATER_3_MINTEMP   5
#define HEATER_4_MINTEMP   5
#define HEATER_5_MINTEMP   5
#define HEATER_6_MINTEMP   5
#define HEATER_7_MINTEMP   5
#define BED_MINTEMP       10
#define CHAMBER_MINTEMP    5
// Above this temperature the heater will be switched off.
// This can protect components from overheating, but NOT from shorts and failures.
// (Use MINTEMP for thermistor short/failure protection.)
#define HEATER_0_MAXTEMP 280
#define HEATER_1_MAXTEMP 275
#define HEATER_2_MAXTEMP 275
#define HEATER_3_MAXTEMP 275
#define HEATER_4_MAXTEMP 275
#define HEATER_5_MAXTEMP 275
#define HEATER_6_MAXTEMP 275
#define HEATER_7_MAXTEMP 275
#define BED_MAXTEMP      125
#define CHAMBER_MAXTEMP  60
   Thermal Overshoot
   During heatup (and printing) the temperature can often "overshoot" the target by many degrees
   (especially before PID tuning). Setting the target temperature too close to MAXTEMP guarantees
   a MAXTEMP shutdown! Use these values to forbid temperatures being set too close to MAXTEMP.
#define HOTEND_OVERSHOOT 15   // (°C) Forbid temperatures over MAXTEMP - OVERSHOOT
#define BED_OVERSHOOT    10   // (°C) Forbid temperatures over MAXTEMP - OVERSHOOT
#define COOLER_OVERSHOOT  2   // (°C) Forbid temperatures closer than OVERSHOOT
//============================= PID Settings ================================
// @section hotend temp
// Enable PIDTEMP for PID control or MPCTEMP for Predictive Model.
// temperature control. Disable both for bang-bang heating.
#define PIDTEMP          // See the PID Tuning Guide at https://reprap.org/wiki/PID_Tuning
//#define MPCTEMP        // ** EXPERIMENTAL **
#define BANG_MAX 255     // Limits current to nozzle while in bang-bang mode; 255=full current
#define PID_MAX BANG_MAX // Limits current to nozzle while PID is active (see PID_FUNCTIONAL_RANGE below); 255=full current
#define PID_K1 0.95      // Smoothing factor within any PID loop
#if ENABLED(PIDTEMP)
//#define PID_DEBUG             // Print PID debug data to the serial port. Use 'M303 D' to toggle activation.
//#define PID_PARAMS_PER_HOTEND // Use separate PID parameters for each extruder (useful for mismatched extruders)
// Set/get with G-code: M301 E[extruder number, 0-2]
#if ENABLED(PID_PARAMS_PER_HOTEND)
// Specify up to one value per hotend here, according to your setup.
// If there are fewer values, the last one applies to the remaining hotends.
#define DEFAULT_Kp_LIST {  22.20,  22.20 }
#define DEFAULT_Ki_LIST {   1.08,   1.08 }
#define DEFAULT_Kd_LIST { 114.00, 114.00 }
#else
// Original Prusa i3 MK3/S
#define DEFAULT_Kp  16.13
#define DEFAULT_Ki   1.1625
#define DEFAULT_Kd  56.23
#endif
#endif
   Model Predictive Control for hotend
   Use a physical model of the hotend to control temperature. When configured correctly
   this gives better responsiveness and stability than PID and it also removes the need
   for PID_EXTRUSION_SCALING and PID_FAN_SCALING. Use M306 T to autotune the model.
   @section mpctemp
#if ENABLED(MPCTEMP)
//#define MPC_EDIT_MENU                             // Add MPC editing to the "Advanced Settings" menu. (~1300 bytes of flash)
//#define MPC_AUTOTUNE_MENU                         // Add MPC auto-tuning to the "Advanced Settings" menu. (~350 bytes of flash)
#define MPC_MAX BANG_MAX                            // (0..255) Current to nozzle while MPC is active.
#define MPC_HEATER_POWER { 40.0f }                  // (W) Heat cartridge powers.
#define MPC_INCLUDE_FAN                             // Model the fan speed?
// Measured physical constants from M306
#define MPC_BLOCK_HEAT_CAPACITY { 16.7f }           // (J/K) Heat block heat capacities.
#define MPC_SENSOR_RESPONSIVENESS { 0.22f }         // (K/s per ∆K) Rate of change of sensor temperature from heat block.
#define MPC_AMBIENT_XFER_COEFF { 0.068f }           // (W/K) Heat transfer coefficients from heat block to room air with fan off.
#if ENABLED(MPC_INCLUDE_FAN)
#define MPC_AMBIENT_XFER_COEFF_FAN255 { 0.097f }  // (W/K) Heat transfer coefficients from heat block to room air with fan on full.
#endif
// For one fan and multiple hotends MPC needs to know how to apply the fan cooling effect.
//#define MPC_FAN_0_ALL_HOTENDS
//#define MPC_FAN_0_ACTIVE_HOTEND
#endif
#define FILAMENT_HEAT_CAPACITY_PERMM { 5.6e-3f }    // 0.0056 J/K/mm for 1.75mm PLA (0.0149 J/K/mm for 2.85mm PLA).
//#define FILAMENT_HEAT_CAPACITY_PERMM { 3.6e-3f }  // 0.0036 J/K/mm for 1.75mm PETG (0.0094 J/K/mm for 2.85mm PETG).
// Advanced options
#define MPC_SMOOTHING_FACTOR 0.5f                   // (0.0...1.0) Noisy temperature sensors may need a lower value for stabilization.
#define MPC_MIN_AMBIENT_CHANGE 1.0f                 // (K/s) Modeled ambient temperature rate of change, when correcting model inaccuracies.
#define MPC_STEADYSTATE 0.5f                        // (K/s) Temperature change rate for steady state logic to be enforced.
#define MPC_TUNING_POS { X_CENTER, Y_CENTER, 1.0f } // (mm) M306 Autotuning position, ideally bed center at first layer height.
#define MPC_TUNING_END_Z 10.0f                      // (mm) M306 Autotuning final Z position.
#endif
//====================== PID > Bed Temperature Control ======================
   PID Bed Heating
   If this option is enabled set PID constants below.
   If this option is disabled, bang-bang will be used and BED_LIMIT_SWITCHING will enable hysteresis.
   The PID frequency will be the same as the extruder PWM.
   If PID_dT is the default, and correct for the hardware/configuration, that means 7.689Hz,
   which is fine for driving a square wave into a resistive load and does not significantly
   impact FET heating. This also works fine on a Fotek SSR-10DA Solid State Relay into a 250W
   heater. If your configuration is significantly different than this and you don't understand
   the issues involved, don't use bed PID until someone else verifies that your hardware works.
   @section bed temp
#define PIDTEMPBED
//#define BED_LIMIT_SWITCHING
   Max Bed Power
   Applies to all forms of bed control (PID, bang-bang, and bang-bang with hysteresis).
   When set to any value below 255, enables a form of PWM to the bed that acts like a divider
   so don't use it unless you are OK with PWM on your bed. (See the comment on enabling PIDTEMPBED)
#define MAX_BED_POWER 255 // limits duty cycle to bed; 255=full current
#if ENABLED(PIDTEMPBED)
//#define MIN_BED_POWER 0
//#define PID_BED_DEBUG // Print Bed PID debug data to the serial port.
// 120V 250W silicone heater into 4mm borosilicate (MendelMax 1.5+)
// from FOPDT model - kp=.39 Tp=405 Tdead=66, Tc set to 79.2, aggressive factor of .15 (vs .1, 1, 10)
#define DEFAULT_bedKp 126.13
#define DEFAULT_bedKi 4.30
#define DEFAULT_bedKd 924.76
// FIND YOUR OWN: "M303 E-1 C8 S90" to run autotune on the bed at 90 degreesC for 8 cycles.
#endif // PIDTEMPBED
//==================== PID > Chamber Temperature Control ====================
   PID Chamber Heating
   If this option is disabled, bang-bang will be used and CHAMBER_LIMIT_SWITCHING will enable
   hysteresis.
   impact FET heating. This also works fine on a Fotek SSR-10DA Solid State Relay into a 200W
   the issues involved, don't use chamber PID until someone else verifies that your hardware works.
   @section chamber temp
//#define PIDTEMPCHAMBER
//#define CHAMBER_LIMIT_SWITCHING
   Max Chamber Power
   Applies to all forms of chamber control (PID, bang-bang, and bang-bang with hysteresis).
   When set to any value below 255, enables a form of PWM to the chamber heater that acts like a divider
   so don't use it unless you are OK with PWM on your heater. (See the comment on enabling PIDTEMPCHAMBER)
#define MAX_CHAMBER_POWER 255 // limits duty cycle to chamber heater; 255=full current
#if ENABLED(PIDTEMPCHAMBER)
#define MIN_CHAMBER_POWER 0
//#define PID_CHAMBER_DEBUG // Print Chamber PID debug data to the serial port.
// Lasko "MyHeat Personal Heater" (200w) modified with a Fotek SSR-10DA to control only the heating element
// and placed inside the small Creality printer enclosure tent.
#define DEFAULT_chamberKp 37.04
#define DEFAULT_chamberKi 1.40
#define DEFAULT_chamberKd 655.17
// M309 P37.04 I1.04 D655.17
// FIND YOUR OWN: "M303 E-2 C8 S50" to run autotune on the chamber at 50 degreesC for 8 cycles.
#endif // PIDTEMPCHAMBER
#if ANY(PIDTEMP, PIDTEMPBED, PIDTEMPCHAMBER)
//#define PID_OPENLOOP          // Puts PID in open loop. M104/M140 sets the output power from 0 to PID_MAX
//#define SLOW_PWM_HEATERS      // PWM with very low frequency (roughly 0.125Hz=8s) and minimum state time of approximately 1s useful for heaters driven by a relay
#define PID_FUNCTIONAL_RANGE 10 // If the temperature difference between the target temperature and the actual temperature
// is more than PID_FUNCTIONAL_RANGE then the PID will be shut off and the heater will be set to min/max.
#define PID_EDIT_MENU           // Add PID editing to the "Advanced Settings" menu. (~700 bytes of flash)
#define PID_AUTOTUNE_MENU       // Add PID auto-tuning to the "Advanced Settings" menu. (~250 bytes of flash)
#endif
// @section safety
   Prevent extrusion if the temperature is below EXTRUDE_MINTEMP.
   Add M302 to set the minimum extrusion temperature and/or turn
   cold extrusion prevention on and off.
 * *** IT IS HIGHLY RECOMMENDED TO LEAVE THIS OPTION ENABLED! ***
#define PREVENT_COLD_EXTRUSION
#define EXTRUDE_MINTEMP 175
   Prevent a single extrusion longer than EXTRUDE_MAXLENGTH.
   Note: For Bowden Extruders make this large enough to allow load/unload.
#define PREVENT_LENGTHY_EXTRUDE
#define EXTRUDE_MAXLENGTH 200
//======================== Thermal Runaway Protection =======================
   Thermal Protection provides additional protection to your printer from damage
   and fire. Marlin always includes safe min and max temperature ranges which
   protect against a broken or disconnected thermistor wire.
   The issue: If a thermistor falls out, it will report the much lower
   temperature of the air in the room, and the the firmware will keep
   the heater on.
   If you get "Thermal Runaway" or "Heating failed" errors the
   details can be tuned in Configuration_adv.h
#define THERMAL_PROTECTION_HOTENDS // Enable thermal protection for all extruders
#define THERMAL_PROTECTION_BED     // Enable thermal protection for the heated bed
#define THERMAL_PROTECTION_CHAMBER // Enable thermal protection for the heated chamber
#define THERMAL_PROTECTION_COOLER  // Enable thermal protection for the laser cooling
//============================= Mechanical Settings =========================
// @section machine
// Enable one of the options below for CoreXY, CoreXZ, or CoreYZ kinematics,
// either in the usual order or reversed
//#define COREXY
//#define COREXZ
//#define COREYZ
//#define COREYX
//#define COREZX
//#define COREZY
//#define MARKFORGED_XY  // MarkForged. See https://reprap.org/forum/read.php?152,504042
//#define MARKFORGED_YX
// Enable for a belt style printer with endless "Z" motion
//#define BELTPRINTER
// Enable for Polargraph Kinematics
//#define POLARGRAPH
#if ENABLED(POLARGRAPH)
#define POLARGRAPH_MAX_BELT_LEN 1035.0
#define DEFAULT_SEGMENTS_PER_SECOND 5
#endif
// @section delta
// Enable for DELTA kinematics and configure below
//#define DELTA
#if ENABLED(DELTA)
// Make delta curves from many straight lines (linear interpolation).
// This is a trade-off between visible corners (not enough segments)
// and processor overload (too many expensive sqrt calls).
#define DEFAULT_SEGMENTS_PER_SECOND 200
// After homing move down to a height where XY movement is unconstrained
//#define DELTA_HOME_TO_SAFE_ZONE
// Delta calibration menu
// Add three-point calibration to the MarlinUI menu.
// See http://minow.blogspot.com/index.html#4918805519571907051
//#define DELTA_CALIBRATION_MENU
// G33 Delta Auto-Calibration. Enable EEPROM_SETTINGS to store results.
//#define DELTA_AUTO_CALIBRATION
#if ENABLED(DELTA_AUTO_CALIBRATION)
// Default number of probe points : n*n (1 -> 7)
#define DELTA_CALIBRATION_DEFAULT_POINTS 4
#endif
#if EITHER(DELTA_AUTO_CALIBRATION, DELTA_CALIBRATION_MENU)
// Step size for paper-test probing
#define PROBE_MANUALLY_STEP 0.05      // (mm)
#endif
// Print surface diameter/2 minus unreachable space (avoid collisions with vertical towers).
#define DELTA_PRINTABLE_RADIUS 140.0    // (mm)
// Maximum reachable area
#define DELTA_MAX_RADIUS       140.0    // (mm)
// Center-to-center distance of the holes in the diagonal push rods.
#define DELTA_DIAGONAL_ROD 250.0        // (mm)
// Distance between bed and nozzle Z home position
#define DELTA_HEIGHT 250.00             // (mm) Get this value from G33 auto calibrate
#define DELTA_ENDSTOP_ADJ { 0.0, 0.0, 0.0 } // Get these values from G33 auto calibrate
// Horizontal distance bridged by diagonal push rods when effector is centered.
#define DELTA_RADIUS 124.0              // (mm) Get this value from G33 auto calibrate
// Trim adjustments for individual towers
// tower angle corrections for X and Y tower / rotate XYZ so Z tower angle = 0
// measured in degrees anticlockwise looking from above the printer
#define DELTA_TOWER_ANGLE_TRIM { 0.0, 0.0, 0.0 } // Get these values from G33 auto calibrate
// Delta radius and diagonal rod adjustments (mm)
//#define DELTA_RADIUS_TRIM_TOWER { 0.0, 0.0, 0.0 }
//#define DELTA_DIAGONAL_ROD_TRIM_TOWER { 0.0, 0.0, 0.0 }
#endif
// @section scara
   MORGAN_SCARA was developed by QHARLEY in South Africa in 2012-2013.
   Implemented and slightly reworked by JCERNY in June, 2014.
   Mostly Printed SCARA is an open source design by Tyler Williams. See:
     https://www.thingiverse.com/thing:2487048
     https://www.thingiverse.com/thing:1241491
//#define MORGAN_SCARA
//#define MP_SCARA
#if EITHER(MORGAN_SCARA, MP_SCARA)
// If movement is choppy try lowering this value
// Length of inner and outer support arms. Measure arm lengths precisely.
#define SCARA_LINKAGE_1 150       // (mm)
#define SCARA_LINKAGE_2 150       // (mm)
// SCARA tower offset (position of Tower relative to bed zero position)
// This needs to be reasonably accurate as it defines the printbed position in the SCARA space.
#define SCARA_OFFSET_X  100       // (mm)
#define SCARA_OFFSET_Y  -56       // (mm)
#if ENABLED(MORGAN_SCARA)
//#define DEBUG_SCARA_KINEMATICS
#define SCARA_FEEDRATE_SCALING  // Convert XY feedrate from mm/s to degrees/s on the fly
// Radius around the center where the arm cannot reach
#define MIDDLE_DEAD_ZONE_R   0  // (mm)
#define THETA_HOMING_OFFSET  0  // Calculated from Calibration Guide and M360 / M114. See http://reprap.harleystudio.co.za/?page_id=1073
#define PSI_HOMING_OFFSET    0  // Calculated from Calibration Guide and M364 / M114. See http://reprap.harleystudio.co.za/?page_id=1073
#elif ENABLED(MP_SCARA)
#define SCARA_OFFSET_THETA1  12 // degrees
#define SCARA_OFFSET_THETA2 131 // degrees
#endif
#endif
// @section tpara
// Enable for TPARA kinematics and configure below
//#define AXEL_TPARA
#if ENABLED(AXEL_TPARA)
#define DEBUG_TPARA_KINEMATICS
#define TPARA_LINKAGE_1 120       // (mm)
#define TPARA_LINKAGE_2 120       // (mm)
#define TPARA_OFFSET_X    0       // (mm)
#define TPARA_OFFSET_Y    0       // (mm)
#define TPARA_OFFSET_Z    0       // (mm)
#endif
// @section machine
// Articulated robot (arm). Joints are directly mapped to axes with no kinematics.
//#define ARTICULATED_ROBOT_ARM
// For a hot wire cutter with parallel horizontal axes (X, I) where the heights of the two wire
// ends are controlled by parallel axes (Y, J). Joints are directly mapped to axes (no kinematics).
//#define FOAMCUTTER_XYUV
//============================== Endstop Settings ===========================
// @section endstops
// Specify here all the endstop connectors that are connected to any endstop or probe.
// Almost all printers will be using one per axis. Probes will use one or more of the
// extra connectors. Leave undefined any used for non-endstop and non-probe purposes.
#define USE_XMIN_PLUG
#define USE_YMIN_PLUG
#define USE_ZMIN_PLUG
//#define USE_IMIN_PLUG
//#define USE_JMIN_PLUG
//#define USE_KMIN_PLUG
//#define USE_UMIN_PLUG
//#define USE_VMIN_PLUG
//#define USE_WMIN_PLUG
//#define USE_XMAX_PLUG
//#define USE_YMAX_PLUG
//#define USE_ZMAX_PLUG
//#define USE_IMAX_PLUG
//#define USE_JMAX_PLUG
//#define USE_KMAX_PLUG
//#define USE_UMAX_PLUG
//#define USE_VMAX_PLUG
//#define USE_WMAX_PLUG
// Enable pullup for all endstops to prevent a floating state
#define ENDSTOPPULLUPS
#if DISABLED(ENDSTOPPULLUPS)
// Disable ENDSTOPPULLUPS to set pullups individually
//#define ENDSTOPPULLUP_XMIN
//#define ENDSTOPPULLUP_YMIN
//#define ENDSTOPPULLUP_ZMIN
//#define ENDSTOPPULLUP_IMIN
//#define ENDSTOPPULLUP_JMIN
//#define ENDSTOPPULLUP_KMIN
//#define ENDSTOPPULLUP_UMIN
//#define ENDSTOPPULLUP_VMIN
//#define ENDSTOPPULLUP_WMIN
//#define ENDSTOPPULLUP_XMAX
//#define ENDSTOPPULLUP_YMAX
//#define ENDSTOPPULLUP_ZMAX
//#define ENDSTOPPULLUP_IMAX
//#define ENDSTOPPULLUP_JMAX
//#define ENDSTOPPULLUP_KMAX
//#define ENDSTOPPULLUP_UMAX
//#define ENDSTOPPULLUP_VMAX
//#define ENDSTOPPULLUP_WMAX
//#define ENDSTOPPULLUP_ZMIN_PROBE
#endif
// Enable pulldown for all endstops to prevent a floating state
//#define ENDSTOPPULLDOWNS
#if DISABLED(ENDSTOPPULLDOWNS)
// Disable ENDSTOPPULLDOWNS to set pulldowns individually
//#define ENDSTOPPULLDOWN_XMIN
//#define ENDSTOPPULLDOWN_YMIN
//#define ENDSTOPPULLDOWN_ZMIN
//#define ENDSTOPPULLDOWN_IMIN
//#define ENDSTOPPULLDOWN_JMIN
//#define ENDSTOPPULLDOWN_KMIN
//#define ENDSTOPPULLDOWN_UMIN
//#define ENDSTOPPULLDOWN_VMIN
//#define ENDSTOPPULLDOWN_WMIN
//#define ENDSTOPPULLDOWN_XMAX
//#define ENDSTOPPULLDOWN_YMAX
//#define ENDSTOPPULLDOWN_ZMAX
//#define ENDSTOPPULLDOWN_IMAX
//#define ENDSTOPPULLDOWN_JMAX
//#define ENDSTOPPULLDOWN_KMAX
//#define ENDSTOPPULLDOWN_UMAX
//#define ENDSTOPPULLDOWN_VMAX
//#define ENDSTOPPULLDOWN_WMAX
//#define ENDSTOPPULLDOWN_ZMIN_PROBE
#endif
// Mechanical endstop with COM to ground and NC to Signal uses "false" here (most common setup).
#define X_MIN_ENDSTOP_INVERTING true  // Set to true to invert the logic of the endstop.
#define Y_MIN_ENDSTOP_INVERTING true  // Set to true to invert the logic of the endstop.
#define Z_MIN_ENDSTOP_INVERTING true // Set to true to invert the logic of the endstop.
#define I_MIN_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop.
#define J_MIN_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop.
#define K_MIN_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop.
#define U_MIN_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop.
#define V_MIN_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop.
#define W_MIN_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop.
#define X_MAX_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop.
#define Y_MAX_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop.
#define Z_MAX_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop.
#define I_MAX_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop.
#define J_MAX_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop.
#define K_MAX_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop.
#define U_MAX_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop.
#define V_MAX_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop.
#define W_MAX_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop.
#define Z_MIN_PROBE_ENDSTOP_INVERTING false // Set to true to invert the logic of the probe.
// Enable this feature if all enabled endstop pins are interrupt-capable.
// This will remove the need to poll the interrupt pins, saving many CPU cycles.
//#define ENDSTOP_INTERRUPTS_FEATURE
   Endstop Noise Threshold
   Enable if your probe or endstops falsely trigger due to noise.
   - Higher values may affect repeatability or accuracy of some bed probes.
   - To fix noise install a 100nF ceramic capacitor in parallel with the switch.
   - This feature is not required for common micro-switches mounted on PCBs
     based on the Makerbot design, which already have the 100nF capacitor.
   :[2,3,4,5,6,7]
//#define ENDSTOP_NOISE_THRESHOLD 2
// Check for stuck or disconnected endstops during homing moves.
//#define DETECT_BROKEN_ENDSTOP
//============================== Movement Settings ============================
// @section motion
   Default Settings
   These settings can be reset by M502
   Note that if EEPROM is enabled, saved values will override these.
   With this option each E stepper can have its own factors for the
   following movement settings. If fewer factors are given than the
   total number of extruders, the last value applies to the rest.
//#define DISTINCT_E_FACTORS
   Default Axis Steps Per Unit (linear=steps/mm, rotational=steps/°)
   Override with M92
                                        X, Y, Z [, I [, J [, K...]]], E0 [, E1[, E2...]]
#if ENABLED(GEARBOX_BEAR)
#define DEFAULT_AXIS_STEPS_PER_UNIT { 80,80, 400, 106 }
#else
#define DEFAULT_AXIS_STEPS_PER_UNIT { 80, 80, 400, 106 }
#endif
   Default Max Feed Rate (linear=mm/s, rotational=°/s)
   Override with M203
#define DEFAULT_MAX_FEEDRATE          { 200, 200, 25, 70 }
//#define LIMITED_MAX_FR_EDITING        // Limit edit via M203 or LCD to DEFAULT_MAX_FEEDRATE * 2
#if ENABLED(LIMITED_MAX_FR_EDITING)
#define MAX_FEEDRATE_EDIT_VALUES    { 200, 200, 25, 70 } // ...or, set your own edit limits
#endif
   Default Max Acceleration (speed change with time) (linear=mm/(s^2), rotational=°/(s^2))
   (Maximum start speed for accelerated moves)
   Override with M201
#define DEFAULT_MAX_ACCELERATION      { 960, 960, 200, 5000 }
//#define LIMITED_MAX_ACCEL_EDITING     // Limit edit via M201 or LCD to DEFAULT_MAX_ACCELERATION * 2
#if ENABLED(LIMITED_MAX_ACCEL_EDITING)
#define MAX_ACCEL_EDIT_VALUES       { 2000, 2000, 200, 10000 } // ...or, set your own edit limits
#endif
   Default Acceleration (speed change with time) (linear=mm/(s^2), rotational=°/(s^2))
   Override with M204
     M204 P    Acceleration
     M204 R    Retract Acceleration
     M204 T    Travel Acceleration
#define DEFAULT_ACCELERATION          1000    // X, Y, Z and E acceleration for printing moves
#define DEFAULT_RETRACT_ACCELERATION  4000    // E acceleration for retracts
#define DEFAULT_TRAVEL_ACCELERATION   1000    // X, Y, Z acceleration for travel (non printing) moves
   Default Jerk limits (mm/s)
   Override with M205 X Y Z . . . E
   "Jerk" specifies the minimum speed change that requires acceleration.
   When changing speed and direction, if the difference is less than the
   value set here, it may happen instantaneously.
#define CLASSIC_JERK
#if ENABLED(CLASSIC_JERK)
#define DEFAULT_XJERK  8.0
#define DEFAULT_YJERK  8.0
#define DEFAULT_ZJERK  0.4
//#define DEFAULT_IJERK  0.3
//#define DEFAULT_JJERK  0.3
//#define DEFAULT_KJERK  0.3
//#define DEFAULT_UJERK  0.3
//#define DEFAULT_VJERK  0.3
//#define DEFAULT_WJERK  0.3
//#define TRAVEL_EXTRA_XYJERK 0.0     // Additional jerk allowance for all travel moves
//#define LIMITED_JERK_EDITING        // Limit edit via M205 or LCD to DEFAULT_aJERK * 2
#if ENABLED(LIMITED_JERK_EDITING)
#define MAX_JERK_EDIT_VALUES { 20, 20, 0.6, 10 } // ...or, set your own edit limits
#endif
#endif
#define DEFAULT_EJERK    5.0  // May be used by Linear Advance
   Junction Deviation Factor
   See:
     https://reprap.org/forum/read.php?1,739819
     https://blog.kyneticcnc.com/2018/10/computing-junction-deviation-for-marlin.html
#if DISABLED(CLASSIC_JERK)
#define JUNCTION_DEVIATION_MM 0.02  // (mm) Distance from real junction edge
#define JD_HANDLE_SMALL_SEGMENTS    // Use curvature estimation instead of just the junction angle
// for small segments (< 1mm) with large junction angles (> 135°).
#endif
   S-Curve Acceleration
   This option eliminates vibration during printing by fitting a Bézier
   curve to move acceleration, producing much smoother direction changes.
   See https://github.com/synthetos/TinyG/wiki/Jerk-Controlled-Motion-Explained
#define S_CURVE_ACCELERATION
//============================= Z Probe Options =============================
// @section probes
// See https://marlinfw.org/docs/configuration/probes.html
   Enable this option for a probe connected to the Z-MIN pin.
   The probe replaces the Z-MIN endstop and is used for Z homing.
   (Automatically enables USE_PROBE_FOR_Z_HOMING.)
#define Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN
// Force the use of the probe for Z-axis homing
#define USE_PROBE_FOR_Z_HOMING
   Z_MIN_PROBE_PIN
   Define this pin if the probe is not connected to Z_MIN_PIN.
   If not defined the default pin for the selected MOTHERBOARD
   will be used. Most of the time the default is what you want.
    - The simplest option is to use a free endstop connector.
    - Use 5V for powered (usually inductive) sensors.
    - RAMPS 1.3/1.4 boards may use the 5V, GND, and Aux4->D32 pin:
      - For simple switches connect...
        - normally-closed switches to GND and D32.
        - normally-open switches to 5V and D32.
//#define Z_MIN_PROBE_PIN 32 // Pin 32 is the RAMPS default
   Probe Type
   Allen Key Probes, Servo Probes, Z-Sled Probes, FIX_MOUNTED_PROBE, etc.
   Activate one of these to use Auto Bed Leveling below.
   The "Manual Probe" provides a means to do "Auto" Bed Leveling without a probe.
   Use G29 repeatedly, adjusting the Z height at each point with movement commands
   or (with LCD_BED_LEVELING) the LCD controller.
//#define PROBE_MANUALLY
   A Fix-Mounted Probe either doesn't deploy or needs manual deployment.
     (e.g., an inductive probe or a nozzle-based probe-switch.)
#define FIX_MOUNTED_PROBE
   Use the nozzle as the probe, as with a conductive
   nozzle system or a piezo-electric smart effector.
//#define NOZZLE_AS_PROBE
   Z Servo Probe, such as an endstop switch on a rotating arm.
//#define Z_PROBE_SERVO_NR 0       // Defaults to SERVO 0 connector.
//#define Z_SERVO_ANGLES { 70, 0 } // Z Servo Deploy and Stow angles
   The BLTouch probe uses a Hall effect sensor and emulates a servo.
//#define BLTOUCH
   MagLev V4 probe by MDD
   This probe is deployed and activated by powering a built-in electromagnet.
//#define MAGLEV4
#if ENABLED(MAGLEV4)
//#define MAGLEV_TRIGGER_PIN 11     // Set to the connected digital output
#define MAGLEV_TRIGGER_DELAY 15     // Changing this risks overheating the coil
#endif
   Touch-MI Probe by hotends.fr
   This probe is deployed and activated by moving the X-axis to a magnet at the edge of the bed.
   By default, the magnet is assumed to be on the left and activated by a home. If the magnet is
   on the right, enable and set TOUCH_MI_DEPLOY_XPOS to the deploy position.
   Also requires: BABYSTEPPING, BABYSTEP_ZPROBE_OFFSET, Z_SAFE_HOMING,
                  and a minimum Z_HOMING_HEIGHT of 10.
//#define TOUCH_MI_PROBE
#if ENABLED(TOUCH_MI_PROBE)
#define TOUCH_MI_RETRACT_Z 0.5                  // Height at which the probe retracts
//#define TOUCH_MI_DEPLOY_XPOS (X_MAX_BED + 2)  // For a magnet on the right side of the bed
//#define TOUCH_MI_MANUAL_DEPLOY                // For manual deploy (LCD menu)
#endif
// A probe that is deployed and stowed with a solenoid pin (SOL1_PIN)
//#define SOLENOID_PROBE
// A sled-mounted probe like those designed by Charles Bell.
//#define Z_PROBE_SLED
//#define SLED_DOCKING_OFFSET 5  // The extra distance the X axis must travel to pickup the sled. 0 should be fine but you can push it further if you'd like.
// A probe deployed by moving the x-axis, such as the Wilson II's rack-and-pinion probe designed by Marty Rice.
//#define RACK_AND_PINION_PROBE
#if ENABLED(RACK_AND_PINION_PROBE)
#define Z_PROBE_DEPLOY_X  X_MIN_POS
#define Z_PROBE_RETRACT_X X_MAX_POS
#endif
   Magnetically Mounted Probe
   For probes such as Euclid, Klicky, Klackender, etc.
//#define MAG_MOUNTED_PROBE
#if ENABLED(MAG_MOUNTED_PROBE)
#define PROBE_DEPLOY_FEEDRATE (133*60)  // (mm/min) Probe deploy speed
#define PROBE_STOW_FEEDRATE   (133*60)  // (mm/min) Probe stow speed
#define MAG_MOUNTED_DEPLOY_1 { PROBE_DEPLOY_FEEDRATE, { 245, 114, 30 } }  // Move to side Dock & Attach probe
#define MAG_MOUNTED_DEPLOY_2 { PROBE_DEPLOY_FEEDRATE, { 210, 114, 30 } }  // Move probe off dock
#define MAG_MOUNTED_DEPLOY_3 { PROBE_DEPLOY_FEEDRATE, {   0,   0,  0 } }  // Extra move if needed
#define MAG_MOUNTED_DEPLOY_4 { PROBE_DEPLOY_FEEDRATE, {   0,   0,  0 } }  // Extra move if needed
#define MAG_MOUNTED_DEPLOY_5 { PROBE_DEPLOY_FEEDRATE, {   0,   0,  0 } }  // Extra move if needed
#define MAG_MOUNTED_STOW_1   { PROBE_STOW_FEEDRATE,   { 245, 114, 20 } }  // Move to dock
#define MAG_MOUNTED_STOW_2   { PROBE_STOW_FEEDRATE,   { 245, 114,  0 } }  // Place probe beside remover
#define MAG_MOUNTED_STOW_3   { PROBE_STOW_FEEDRATE,   { 230, 114,  0 } }  // Side move to remove probe
#define MAG_MOUNTED_STOW_4   { PROBE_STOW_FEEDRATE,   { 210, 114, 20 } }  // Side move to remove probe
#define MAG_MOUNTED_STOW_5   { PROBE_STOW_FEEDRATE,   {   0,   0,  0 } }  // Extra move if needed
#endif
// Duet Smart Effector (for delta printers) - https://bit.ly/2ul5U7J
// When the pin is defined you can use M672 to set/reset the probe sensitivity.
//#define DUET_SMART_EFFECTOR
#if ENABLED(DUET_SMART_EFFECTOR)
#define SMART_EFFECTOR_MOD_PIN  -1  // Connect a GPIO pin to the Smart Effector MOD pin
#endif
   Use StallGuard2 to probe the bed with the nozzle.
   Requires stallGuard-capable Trinamic stepper drivers.
   CAUTION: This can damage machines with Z lead screws.
            Take extreme care when setting up this feature.
//#define SENSORLESS_PROBING
   Allen key retractable z-probe as seen on many Kossel delta printers - https://reprap.org/wiki/Kossel#Automatic_bed_leveling_probe
   Deploys by touching z-axis belt. Retracts by pushing the probe down.
//#define Z_PROBE_ALLEN_KEY
#if ENABLED(Z_PROBE_ALLEN_KEY)
// 2 or 3 sets of coordinates for deploying and retracting the spring loaded touch probe on G29,
// if servo actuated touch probe is not defined. Uncomment as appropriate for your printer/probe.
#define Z_PROBE_ALLEN_KEY_DEPLOY_1 { 30.0, DELTA_PRINTABLE_RADIUS, 100.0 }
#define Z_PROBE_ALLEN_KEY_DEPLOY_1_FEEDRATE XY_PROBE_FEEDRATE
#define Z_PROBE_ALLEN_KEY_DEPLOY_2 { 0.0, DELTA_PRINTABLE_RADIUS, 100.0 }
#define Z_PROBE_ALLEN_KEY_DEPLOY_2_FEEDRATE (XY_PROBE_FEEDRATE)/10
#define Z_PROBE_ALLEN_KEY_DEPLOY_3 { 0.0, (DELTA_PRINTABLE_RADIUS) * 0.75, 100.0 }
#define Z_PROBE_ALLEN_KEY_DEPLOY_3_FEEDRATE XY_PROBE_FEEDRATE
#define Z_PROBE_ALLEN_KEY_STOW_1 { -64.0, 56.0, 23.0 } // Move the probe into position
#define Z_PROBE_ALLEN_KEY_STOW_1_FEEDRATE XY_PROBE_FEEDRATE
#define Z_PROBE_ALLEN_KEY_STOW_2 { -64.0, 56.0, 3.0 } // Push it down
#define Z_PROBE_ALLEN_KEY_STOW_2_FEEDRATE (XY_PROBE_FEEDRATE)/10
#define Z_PROBE_ALLEN_KEY_STOW_3 { -64.0, 56.0, 50.0 } // Move it up to clear
#define Z_PROBE_ALLEN_KEY_STOW_3_FEEDRATE XY_PROBE_FEEDRATE
#define Z_PROBE_ALLEN_KEY_STOW_4 { 0.0, 0.0, 50.0 }
#define Z_PROBE_ALLEN_KEY_STOW_4_FEEDRATE XY_PROBE_FEEDRATE
#endif // Z_PROBE_ALLEN_KEY
   Nozzle-to-Probe offsets { X, Y, Z }
   X and Y offset
     Use a caliper or ruler to measure the distance from the tip of
     the Nozzle to the center-point of the Probe in the X and Y axes.
   Z offset
   - For the Z offset use your best known value and adjust at runtime.
   - Common probes trigger below the nozzle and have negative values for Z offset.
   - Probes triggering above the nozzle height are uncommon but do exist. When using
     probes such as this, carefully set Z_CLEARANCE_DEPLOY_PROBE and Z_CLEARANCE_BETWEEN_PROBES
     to avoid collisions during probing.
   Tune and Adjust
   -  Probe Offsets can be tuned at runtime with 'M851', LCD menus, babystepping, etc.
   -  PROBE_OFFSET_WIZARD (configuration_adv.h) can be used for setting the Z offset.
   Assuming the typical work area orientation:
    - Probe to RIGHT of the Nozzle has a Positive X offset
    - Probe to LEFT  of the Nozzle has a Negative X offset
    - Probe in BACK  of the Nozzle has a Positive Y offset
    - Probe in FRONT of the Nozzle has a Negative Y offset
   Some examples:
     #define NOZZLE_TO_PROBE_OFFSET { 10, 10, -1 }   // Example "1"
     #define NOZZLE_TO_PROBE_OFFSET {-10,  5, -1 }   // Example "2"
     #define NOZZLE_TO_PROBE_OFFSET {  5, -5, -1 }   // Example "3"
     #define NOZZLE_TO_PROBE_OFFSET {-15,-10, -1 }   // Example "4"
       +-- BACK ---+
     L |        1  | R <-- Example "1" (right+,  back+)
     E |  2        | I <-- Example "2" ( left-,  back+)
     F |[-]  N  [+]| G <-- Nozzle
     T |       3   | H <-- Example "3" (right+, front-)
       | 4         | T <-- Example "4" ( left-, front-)
       O-- FRONT --+
#define NOZZLE_TO_PROBE_OFFSET { 23, 5, -0.5 }
// Most probes should stay away from the edges of the bed, but
// with NOZZLE_AS_PROBE this can be negative for a wider probing area.
#define PROBING_MARGIN 0
// X and Y axis travel speed (mm/min) between probes
#define XY_PROBE_FEEDRATE (86*60)
// Feedrate (mm/min) for the first approach when double-probing (MULTIPLE_PROBING == 2)
#define Z_PROBE_FEEDRATE_FAST (4*60)
// Feedrate (mm/min) for the "accurate" probe of each point
#define Z_PROBE_FEEDRATE_SLOW (Z_PROBE_FEEDRATE_FAST / 2)
   Probe Activation Switch
   A switch indicating proper deployment, or an optical
   switch triggered when the carriage is near the bed.
//#define PROBE_ACTIVATION_SWITCH
#if ENABLED(PROBE_ACTIVATION_SWITCH)
#define PROBE_ACTIVATION_SWITCH_STATE LOW // State indicating probe is active
//#define PROBE_ACTIVATION_SWITCH_PIN PC6 // Override default pin
#endif
   Tare Probe (determine zero-point) prior to each probe.
   Useful for a strain gauge or piezo sensor that needs to factor out
   elements such as cables pulling on the carriage.
//#define PROBE_TARE
#if ENABLED(PROBE_TARE)
#define PROBE_TARE_TIME  200    // (ms) Time to hold tare pin
#define PROBE_TARE_DELAY 200    // (ms) Delay after tare before
#define PROBE_TARE_STATE HIGH   // State to write pin for tare
//#define PROBE_TARE_PIN PA5    // Override default pin
//#define PROBE_TARE_ONLY_WHILE_INACTIVE  // Fail to tare/probe if PROBE_ACTIVATION_SWITCH is active
#endif
#endif
   Probe Enable / Disable
   The probe only provides a triggered signal when enabled.
//#define PROBE_ENABLE_DISABLE
#if ENABLED(PROBE_ENABLE_DISABLE)
//#define PROBE_ENABLE_PIN -1   // Override the default pin here
#endif
   Multiple Probing
   You may get improved results by probing 2 or more times.
   With EXTRA_PROBING the more atypical reading(s) will be disregarded.
   A total of 2 does fast/slow probes with a weighted average.
   A total of 3 or more adds more slow probes, taking the average.
#define MULTIPLE_PROBING 2
#define EXTRA_PROBING    1
   Z probes require clearance when deploying, stowing, and moving between
   probe points to avoid hitting the bed and other hardware.
   Servo-mounted probes require extra space for the arm to rotate.
   Inductive probes need space to keep from triggering early.
   Use these settings to specify the distance (mm) to raise the probe (or
   lower the bed). The values set here apply over and above any (negative)
   probe Z Offset set with NOZZLE_TO_PROBE_OFFSET, M851, or the LCD.
   Only integer values >= 1 are valid here.
   Example: `M851 Z-5` with a CLEARANCE of 4  =>  9mm from bed to nozzle.
       But: `M851 Z+1` with a CLEARANCE of 2  =>  2mm from bed to nozzle.
#define Z_CLEARANCE_DEPLOY_PROBE    2 // Z Clearance for Deploy/Stow
#define Z_CLEARANCE_BETWEEN_PROBES  2 // Z Clearance between probe points
#define Z_CLEARANCE_MULTI_PROBE     1 // Z Clearance between multiple probes
//#define Z_AFTER_PROBING           5 // Z position after probing is done
#define Z_PROBE_LOW_POINT          -1 // Farthest distance below the trigger-point to go before stopping
// For M851 give a range for adjusting the Z probe offset
#define Z_PROBE_OFFSET_RANGE_MIN -3
#define Z_PROBE_OFFSET_RANGE_MAX  0
// Enable the M48 repeatability test to test probe accuracy
#define Z_MIN_PROBE_REPEATABILITY_TEST
// Before deploy/stow pause for user confirmation
//#define PAUSE_BEFORE_DEPLOY_STOW
#if ENABLED(PAUSE_BEFORE_DEPLOY_STOW)
//#define PAUSE_PROBE_DEPLOY_WHEN_TRIGGERED // For Manual Deploy Allenkey Probe
#endif
   Enable one or more of the following if probing seems unreliable.
   Heaters and/or fans can be disabled during probing to minimize electrical
   noise. A delay can also be added to allow noise and vibration to settle.
   These options are most useful for the BLTouch probe, but may also improve
   readings with inductive probes and piezo sensors.
#define PROBING_HEATERS_OFF         // Turn heaters off when probing
#if ENABLED(PROBING_HEATERS_OFF)
//#define WAIT_FOR_BED_HEATER     // Wait for bed to heat back up between probes (to improve accuracy)
//#define WAIT_FOR_HOTEND         // Wait for hotend to heat back up between probes (to improve accuracy & prevent cold extrude)
#endif
//#define PROBING_FANS_OFF          // Turn fans off when probing
//#define PROBING_ESTEPPERS_OFF     // Turn all extruder steppers off when probing
//#define PROBING_STEPPERS_OFF      // Turn all steppers off (unless needed to hold position) when probing (including extruders)
//#define DELAY_BEFORE_PROBING 200  // (ms) To prevent vibrations from triggering piezo sensors
// Require minimum nozzle and/or bed temperature for probing
//#define PREHEAT_BEFORE_PROBING
#if ENABLED(PREHEAT_BEFORE_PROBING)
#define PROBING_NOZZLE_TEMP 120   // (°C) Only applies to E0 at this time
#define PROBING_BED_TEMP     50
#endif
// For Inverting Stepper Enable Pins (Active Low) use 0, Non Inverting (Active High) use 1
// :{ 0:'Low', 1:'High' }
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define E_ENABLE_ON 0 // For all extruders
//#define I_ENABLE_ON 0
//#define J_ENABLE_ON 0
//#define K_ENABLE_ON 0
//#define U_ENABLE_ON 0
//#define V_ENABLE_ON 0
//#define W_ENABLE_ON 0
// Disable axis steppers immediately when they're not being stepped.
// WARNING: When motors turn off there is a chance of losing position accuracy!
#define DISABLE_X false
#define DISABLE_Y false
#define DISABLE_Z false
//#define DISABLE_I false
//#define DISABLE_J false
//#define DISABLE_K false
//#define DISABLE_U false
//#define DISABLE_V false
//#define DISABLE_W false
// Turn off the display blinking that warns about possible accuracy reduction
//#define DISABLE_REDUCED_ACCURACY_WARNING
#define DISABLE_E false             // Disable the extruder when not stepping
#define DISABLE_INACTIVE_EXTRUDER   // Keep only the active extruder enabled
// @section motion
// Invert the stepper direction. Change (or reverse the motor connector) if an axis goes the wrong way.
#define INVERT_X_DIR false
#define INVERT_Y_DIR false
#define INVERT_Z_DIR false
//#define INVERT_I_DIR false
//#define INVERT_J_DIR false
//#define INVERT_K_DIR false
//#define INVERT_U_DIR false
//#define INVERT_V_DIR false
//#define INVERT_W_DIR false
// For direct drive extruder v9 set to true, for geared extruder set to false.
#define INVERT_E0_DIR false
#define INVERT_E1_DIR false
#define INVERT_E2_DIR false
#define INVERT_E3_DIR false
#define INVERT_E4_DIR false
#define INVERT_E5_DIR false
#define INVERT_E6_DIR false
#define INVERT_E7_DIR false
// @section homing
//#define NO_MOTION_BEFORE_HOMING // Inhibit movement until all axes have been homed. Also enable HOME_AFTER_DEACTIVATE for extra safety.
#define HOME_AFTER_DEACTIVATE     // Require rehoming after steppers are deactivated. Also enable NO_MOTION_BEFORE_HOMING for extra safety.
   Set Z_IDLE_HEIGHT if the Z-Axis moves on its own when steppers are disabled.
    - Use a low value (i.e., Z_MIN_POS) if the nozzle falls down to the bed.
    - Use a large value (i.e., Z_MAX_POS) if the bed falls down, away from the nozzle.
//#define Z_IDLE_HEIGHT Z_HOME_POS
//#define Z_HOMING_HEIGHT  4      // (mm) Minimal Z height before homing (G28) for Z clearance above the bed, clamps, ...
// Be sure to have this much clearance over your Z_MAX_POS to prevent grinding.
//#define Z_AFTER_HOMING  10      // (mm) Height to move to after homing Z
// Direction of endstops when homing; 1=MAX, -1=MIN
// :[-1,1]
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
//#define I_HOME_DIR -1
//#define J_HOME_DIR -1
//#define K_HOME_DIR -1
//#define U_HOME_DIR -1
//#define V_HOME_DIR -1
//#define W_HOME_DIR -1
// @section geometry
// The size of the printable area
#define X_BED_SIZE 250
#define Y_BED_SIZE 250
// Travel limits (linear=mm, rotational=°) after homing, corresponding to endstop positions.
#define X_MIN_POS 0
#define Y_MIN_POS -4
#define Z_MIN_POS 0.15
#define X_MAX_POS 255
#define Y_MAX_POS 255
#if ENABLED(TALLBEAR)
#define Z_MAX_POS 320
#else
#define Z_MAX_POS 300
#endif
//#define I_MIN_POS 0
//#define I_MAX_POS 50
//#define J_MIN_POS 0
//#define J_MAX_POS 50
//#define K_MIN_POS 0
//#define K_MAX_POS 50
//#define U_MIN_POS 0
//#define U_MAX_POS 50
//#define V_MIN_POS 0
//#define V_MAX_POS 50
//#define W_MIN_POS 0
//#define W_MAX_POS 50
   Software Endstops
   - Prevent moves outside the set machine bounds.
   - Individual axes can be disabled, if desired.
   - X and Y only apply to Cartesian robots.
   - Use 'M211' to set software endstops on/off or report current state
// Min software endstops constrain movement within minimum coordinate bounds
#define MIN_SOFTWARE_ENDSTOPS
#if ENABLED(MIN_SOFTWARE_ENDSTOPS)
#define MIN_SOFTWARE_ENDSTOP_X
#define MIN_SOFTWARE_ENDSTOP_Y
#define MIN_SOFTWARE_ENDSTOP_Z
#define MIN_SOFTWARE_ENDSTOP_I
#define MIN_SOFTWARE_ENDSTOP_J
#define MIN_SOFTWARE_ENDSTOP_K
#define MIN_SOFTWARE_ENDSTOP_U
#define MIN_SOFTWARE_ENDSTOP_V
#define MIN_SOFTWARE_ENDSTOP_W
#endif
// Max software endstops constrain movement within maximum coordinate bounds
#define MAX_SOFTWARE_ENDSTOPS
#if ENABLED(MAX_SOFTWARE_ENDSTOPS)
#define MAX_SOFTWARE_ENDSTOP_X
#define MAX_SOFTWARE_ENDSTOP_Y
#define MAX_SOFTWARE_ENDSTOP_Z
#define MAX_SOFTWARE_ENDSTOP_I
#define MAX_SOFTWARE_ENDSTOP_J
#define MAX_SOFTWARE_ENDSTOP_K
#define MAX_SOFTWARE_ENDSTOP_U
#define MAX_SOFTWARE_ENDSTOP_V
#define MAX_SOFTWARE_ENDSTOP_W
#endif
#if EITHER(MIN_SOFTWARE_ENDSTOPS, MAX_SOFTWARE_ENDSTOPS)
#define SOFT_ENDSTOPS_MENU_ITEM  // Enable/Disable software endstops from the LCD
#endif
   Filament Runout Sensors
   Mechanical or opto endstops are used to check for the presence of filament.
   IMPORTANT: Runout will only trigger if Marlin is aware that a print job is running.
   Marlin knows a print job is running when:
    1. Running a print job from media started with M24.
    2. The Print Job Timer has been started with M75.
    3. The heaters were turned on and PRINTJOB_TIMER_AUTOSTART is enabled.
   RAMPS-based boards use SERVO3_PIN for the first runout sensor.
   For other boards you may need to define FIL_RUNOUT_PIN, FIL_RUNOUT2_PIN, etc.
#define FILAMENT_RUNOUT_SENSOR
#if ENABLED(FILAMENT_RUNOUT_SENSOR)
#define FIL_RUNOUT_ENABLED_DEFAULT true // Enable the sensor on startup. Override with M412 followed by M500.
#define NUM_RUNOUT_SENSORS   1          // Number of sensors, up to one per extruder. Define a FIL_RUNOUT#_PIN for each.
#define FIL_RUNOUT_STATE     HIGH       // Pin state indicating that filament is NOT present.
#define FIL_RUNOUT_PULLUP               // Use internal pullup for filament runout pins.
//#define FIL_RUNOUT_PULLDOWN           // Use internal pulldown for filament runout pins.
//#define WATCH_ALL_RUNOUT_SENSORS      // Execute runout script on any triggering sensor, not only for the active extruder.
// This is automatically enabled for MIXING_EXTRUDERs.
// Override individually if the runout sensors vary
//#define FIL_RUNOUT1_STATE LOW
//#define FIL_RUNOUT1_PULLUP
//#define FIL_RUNOUT1_PULLDOWN
//#define FIL_RUNOUT2_STATE LOW
//#define FIL_RUNOUT2_PULLUP
//#define FIL_RUNOUT2_PULLDOWN
//#define FIL_RUNOUT3_STATE LOW
//#define FIL_RUNOUT3_PULLUP
//#define FIL_RUNOUT3_PULLDOWN
//#define FIL_RUNOUT4_STATE LOW
//#define FIL_RUNOUT4_PULLUP
//#define FIL_RUNOUT4_PULLDOWN
//#define FIL_RUNOUT5_STATE LOW
//#define FIL_RUNOUT5_PULLUP
//#define FIL_RUNOUT5_PULLDOWN
//#define FIL_RUNOUT6_STATE LOW
//#define FIL_RUNOUT6_PULLUP
//#define FIL_RUNOUT6_PULLDOWN
//#define FIL_RUNOUT7_STATE LOW
//#define FIL_RUNOUT7_PULLUP
//#define FIL_RUNOUT7_PULLDOWN
//#define FIL_RUNOUT8_STATE LOW
//#define FIL_RUNOUT8_PULLUP
//#define FIL_RUNOUT8_PULLDOWN
// Commands to execute on filament runout.
// With multiple runout sensors use the %c placeholder for the current tool in commands (e.g., "M600 T%c")
// NOTE: After 'M412 H1' the host handles filament runout and this script does not apply.
#define FILAMENT_RUNOUT_SCRIPT "M600"
// After a runout is detected, continue printing this length of filament
// before executing the runout script. Useful for a sensor at the end of
// a feed tube. Requires 4 bytes SRAM per sensor, plus 4 bytes overhead.
//#define FILAMENT_RUNOUT_DISTANCE_MM 25
#ifdef FILAMENT_RUNOUT_DISTANCE_MM
// Enable this option to use an encoder disc that toggles the runout pin
// as the filament moves. (Be sure to set FILAMENT_RUNOUT_DISTANCE_MM
// large enough to avoid false positives.)
//#define FILAMENT_MOTION_SENSOR
#endif
#endif
//=============================== Bed Leveling ==============================
// @section calibrate
   Choose one of the options below to enable G29 Bed Leveling. The parameters
   and behavior of G29 will change depending on your selection.
    If using a Probe for Z Homing, enable Z_SAFE_HOMING also!
   - AUTO_BED_LEVELING_3POINT
     Probe 3 arbitrary points on the bed (that aren't collinear)
     You specify the XY coordinates of all 3 points.
     The result is a single tilted plane. Best for a flat bed.
   - AUTO_BED_LEVELING_LINEAR
     Probe several points in a grid.
     You specify the rectangle and the density of sample points.
   - AUTO_BED_LEVELING_BILINEAR
     The result is a mesh, best for large or uneven beds.
   - AUTO_BED_LEVELING_UBL (Unified Bed Leveling)
     A comprehensive bed leveling system combining the features and benefits
     of other systems. UBL also includes integrated Mesh Generation, Mesh
     Validation and Mesh Editing systems.
   - MESH_BED_LEVELING
     Probe a grid manually
     The result is a mesh, suitable for large or uneven beds. (See BILINEAR.)
     For machines without a probe, Mesh Bed Leveling provides a method to perform
     leveling in steps so you can manually adjust the Z height at each grid-point.
     With an LCD controller the process is guided step-by-step.
//#define AUTO_BED_LEVELING_3POINT
//#define AUTO_BED_LEVELING_LINEAR
#define AUTO_BED_LEVELING_BILINEAR
//#define AUTO_BED_LEVELING_UBL
//#define MESH_BED_LEVELING
   Normally G28 leaves leveling disabled on completion. Enable one of
   these options to restore the prior leveling state or to always enable
   leveling immediately after G28.
//#define RESTORE_LEVELING_AFTER_G28
//#define ENABLE_LEVELING_AFTER_G28
   Auto-leveling needs preheating
//#define PREHEAT_BEFORE_LEVELING
#if ENABLED(PREHEAT_BEFORE_LEVELING)
#define LEVELING_NOZZLE_TEMP 120   // (°C) Only applies to E0 at this time
#define LEVELING_BED_TEMP     50
#endif
   Bed Distance Sensor
   Measures the distance from bed to nozzle with accuracy of 0.01mm.
   For information about this sensor https://github.com/markniu/Bed_Distance_sensor
   Uses I2C port, so it requires I2C library markyue/Panda_SoftMasterI2C.
//#define BD_SENSOR
   Enable detailed logging of G28, G29, M48, etc.
   Turn on with the command 'M111 S32'.
   NOTE: Requires a lot of PROGMEM!
//#define DEBUG_LEVELING_FEATURE
#if ANY(MESH_BED_LEVELING, AUTO_BED_LEVELING_UBL, PROBE_MANUALLY)
// Set a height for the start of manual adjustment
#define MANUAL_PROBE_START_Z 0.2  // (mm) Comment out to use the last-measured height
#endif
#if ANY(MESH_BED_LEVELING, AUTO_BED_LEVELING_BILINEAR, AUTO_BED_LEVELING_UBL)
   Gradually reduce leveling correction until a set height is reached,
   at which point movement will be level to the machine's XY plane.
   The height can be set with M420 Z<height>
#define ENABLE_LEVELING_FADE_HEIGHT
#if ENABLED(ENABLE_LEVELING_FADE_HEIGHT)
#define DEFAULT_LEVELING_FADE_HEIGHT 10.0 // (mm) Default fade height.
#endif
   For Cartesian machines, instead of dividing moves on mesh boundaries,
   split up moves into short segments like a Delta. This follows the
   contours of the bed more closely than edge-to-edge straight moves.
#define SEGMENT_LEVELED_MOVES
#define LEVELED_SEGMENT_LENGTH 5.0 // (mm) Length of all segments (except the last one)
   Enable the G26 Mesh Validation Pattern tool.
//#define G26_MESH_VALIDATION
#if ENABLED(G26_MESH_VALIDATION)
#define MESH_TEST_NOZZLE_SIZE    0.4  // (mm) Diameter of primary nozzle.
#define MESH_TEST_LAYER_HEIGHT   0.2  // (mm) Default layer height for G26.
#define MESH_TEST_HOTEND_TEMP  215    // (°C) Default nozzle temperature for G26.
#define MESH_TEST_BED_TEMP      70    // (°C) Default bed temperature for G26.
#define G26_XY_FEEDRATE         20    // (mm/s) Feedrate for G26 XY moves.
#define G26_XY_FEEDRATE_TRAVEL 100    // (mm/s) Feedrate for G26 XY travel moves.
#define G26_RETRACT_MULTIPLIER   1.0  // G26 Q (retraction) used by default between mesh test elements.
#endif
#endif
#if EITHER(AUTO_BED_LEVELING_LINEAR, AUTO_BED_LEVELING_BILINEAR)
// Set the number of grid points per dimension.
#define GRID_MAX_POINTS_X 4
#define GRID_MAX_POINTS_Y 6
// Probe along the Y axis, advancing X after each column
//#define PROBE_Y_FIRST
#if ENABLED(AUTO_BED_LEVELING_BILINEAR)
// Beyond the probed grid, continue the implied tilt?
// Default is to maintain the height of the nearest edge.
//#define EXTRAPOLATE_BEYOND_GRID
// Experimental Subdivision of the grid by Catmull-Rom method.
// Synthesizes intermediate points to produce a more detailed mesh.
#define ABL_BILINEAR_SUBDIVISION
#if ENABLED(ABL_BILINEAR_SUBDIVISION)
// Number of subdivisions between probe points
#define BILINEAR_SUBDIVISIONS 3
#endif
#endif
#elif ENABLED(AUTO_BED_LEVELING_UBL)
//========================= Unified Bed Leveling ============================
//#define MESH_EDIT_GFX_OVERLAY   // Display a graphics overlay while editing the mesh
#define MESH_INSET 0              // Set Mesh bounds as an inset region of the bed
#define GRID_MAX_POINTS_X 4       // Don't use more than 15 points per axis, implementation limited.
//#define UBL_HILBERT_CURVE       // Use Hilbert distribution for less travel when probing multiple points
#define UBL_MESH_EDIT_MOVES_Z     // Sophisticated users prefer no movement of nozzle
#define UBL_SAVE_ACTIVE_ON_M500   // Save the currently active mesh in the current slot on M500
//#define UBL_Z_RAISE_WHEN_OFF_MESH 2.5 // When the nozzle is off the mesh, this value is used
// as the Z-Height correction value.
//#define UBL_MESH_WIZARD         // Run several commands in a row to get a complete mesh
#elif ENABLED(MESH_BED_LEVELING)
//=================================== Mesh ==================================
#define MESH_INSET 10          // Set Mesh bounds as an inset region of the bed
#define GRID_MAX_POINTS_X 3    // Don't use more than 7 points per axis, implementation limited.
#define GRID_MAX_POINTS_Y GRID_MAX_POINTS_X
//#define MESH_G28_REST_ORIGIN // After homing all axes ('G28' or 'G28 XYZ') rest Z at Z_MIN_POS
#endif // BED_LEVELING
   Add a bed leveling sub-menu for ABL or MBL.
   Include a guided procedure if manual probing is enabled.
//#define LCD_BED_LEVELING
#if ENABLED(LCD_BED_LEVELING)
#define MESH_EDIT_Z_STEP  0.025 // (mm) Step size while manually probing Z axis.
#define LCD_PROBE_Z_RANGE 4     // (mm) Z Range centered on Z_MIN_POS for LCD Z adjustment
//#define MESH_EDIT_MENU        // Add a menu to edit mesh points
#endif
// Add a menu item to move between bed corners for manual bed adjustment
//#define LCD_BED_TRAMMING
#if ENABLED(LCD_BED_TRAMMING)
#define BED_TRAMMING_INSET_LFRB { 30, 30, 30, 30 } // (mm) Left, Front, Right, Back insets
#define BED_TRAMMING_HEIGHT      0.0        // (mm) Z height of nozzle at leveling points
#define BED_TRAMMING_Z_HOP       4.0        // (mm) Z height of nozzle between leveling points
//#define BED_TRAMMING_INCLUDE_CENTER       // Move to the center after the last corner
//#define BED_TRAMMING_USE_PROBE
#if ENABLED(BED_TRAMMING_USE_PROBE)
#define BED_TRAMMING_PROBE_TOLERANCE 0.1  // (mm)
#define BED_TRAMMING_VERIFY_RAISED        // After adjustment triggers the probe, re-probe to verify
//#define BED_TRAMMING_AUDIO_FEEDBACK
#endif
   Corner Leveling Order
   Set 2 or 4 points. When 2 points are given, the 3rd is the center of the opposite edge.
    LF  Left-Front    RF  Right-Front
    LB  Left-Back     RB  Right-Back
   Examples:
        Default        {LF,RB,LB,RF}         {LF,RF}           {LB,LF}
    LB --------- RB   LB --------- RB    LB --------- RB   LB --------- RB
    |  4       3  |   | 3         2 |    |     <3>     |   | 1           |
    |             |   |             |    |             |   |          <3>|
    |  1       2  |   | 1         4 |    | 1         2 |   | 2           |
    LF --------- RF   LF --------- RF    LF --------- RF   LF --------- RF
#define BED_TRAMMING_LEVELING_ORDER { LF, RF, RB, LB }
#endif
   Commands to execute at the end of G29 probing.
   Useful to retract or move the Z probe out of the way.
#define Z_PROBE_END_SCRIPT "G1 X12 Y6 F7200\nG1 Z0 F8000"
// @section homing
// The center of the bed is at (X=0, Y=0)
//#define BED_CENTER_AT_0_0
// Manually set the home position. Leave these undefined for automatic settings.
// For DELTA this is the top-center of the Cartesian print volume.
//#define MANUAL_X_HOME_POS 0
//#define MANUAL_Y_HOME_POS 0
//#define MANUAL_Z_HOME_POS 0
//#define MANUAL_I_HOME_POS 0
//#define MANUAL_J_HOME_POS 0
//#define MANUAL_K_HOME_POS 0
//#define MANUAL_U_HOME_POS 0
//#define MANUAL_V_HOME_POS 0
//#define MANUAL_W_HOME_POS 0
   Use "Z Safe Homing" to avoid homing with a Z probe outside the bed area.
   - Moves the Z probe (or nozzle) to a defined XY point before Z homing.
   - Allows Z homing only when XY positions are known and trusted.
   - If stepper drivers sleep, XY homing may be required again before Z homing.
#define Z_SAFE_HOMING
#if ENABLED(Z_SAFE_HOMING)
#define Z_SAFE_HOMING_X_POINT 35  // X point for Z homing
#define Z_SAFE_HOMING_Y_POINT 11  // Y point for Z homing
#endif
// Homing speeds (linear=mm/min, rotational=°/min)
#define HOMING_FEEDRATE_MM_M { (50*60), (50*60), (13*60) }
// Validate that endstops are triggered on homing moves
#define VALIDATE_HOMING_ENDSTOPS
   Bed Skew Compensation
   This feature corrects for misalignment in the XYZ axes.
   Take the following steps to get the bed skew in the XY plane:
    1. Print a test square (e.g., https://www.thingiverse.com/thing:2563185)
    2. For XY_DIAG_AC measure the diagonal A to C
    3. For XY_DIAG_BD measure the diagonal B to D
    4. For XY_SIDE_AD measure the edge A to D
   Marlin automatically computes skew factors from these measurements.
   Skew factors may also be computed and set manually:
    - Compute AB     : SQRT(2*AC*AC+2*BD*BD-4*AD*AD)/2
    - XY_SKEW_FACTOR : TAN(PI/2-ACOS((AC*AC-AB*AB-AD*AD)/(2*AB*AD)))
   If desired, follow the same procedure for XZ and YZ.
   Use these diagrams for reference:
      Y                     Z                     Z
      ^     B-------C       ^     B-------C       ^     B-------C
      |  A-------D          |  A-------D          |  A-------D
      +-------------->X     +-------------->X     +-------------->Y
       XY_SKEW_FACTOR        XZ_SKEW_FACTOR        YZ_SKEW_FACTOR
#define SKEW_CORRECTION
#if ENABLED(SKEW_CORRECTION)
// Input all length measurements here:
#define XY_DIAG_AC 282.8427124746
#define XY_DIAG_BD 282.8427124746
#define XY_SIDE_AD 200
// Or, set the XY skew factor directly:
//#define XY_SKEW_FACTOR 0.0
#define SKEW_CORRECTION_FOR_Z
#if ENABLED(SKEW_CORRECTION_FOR_Z)
#define XZ_DIAG_AC 282.8427124746
#define XZ_DIAG_BD 282.8427124746
#define YZ_DIAG_AC 282.8427124746
#define YZ_DIAG_BD 282.8427124746
#define YZ_SIDE_AD 200
// Or, set the Z skew factors directly:
//#define XZ_SKEW_FACTOR 0.0
//#define YZ_SKEW_FACTOR 0.0
#endif
// Enable this option for M852 to set skew at runtime
#define SKEW_CORRECTION_GCODE
#endif
//============================= Additional Features ===========================
// @section eeprom
   EEPROM
   Persistent storage to preserve configurable settings across reboots.
     M500 - Store settings to EEPROM.
     M501 - Read settings from EEPROM. (i.e., Throw away unsaved changes)
     M502 - Revert settings to "factory" defaults. (Follow with M500 to init the EEPROM.)
#define EEPROM_SETTINGS       // Persistent storage with M500 and M501
//#define DISABLE_M503        // Saves ~2700 bytes of flash. Disable for release!
#define EEPROM_CHITCHAT       // Give feedback on EEPROM commands. Disable to save PROGMEM.
#define EEPROM_BOOT_SILENT    // Keep M503 quiet and only give errors during first load
#if ENABLED(EEPROM_SETTINGS)
//#define EEPROM_AUTO_INIT  // Init EEPROM automatically on any errors.
//#define EEPROM_INIT_NOW   // Init EEPROM on first boot after a new build.
#endif
// @section host
// Host Keepalive
// When enabled Marlin will send a busy status message to the host
// every couple of seconds when it can't accept commands.
#define HOST_KEEPALIVE_FEATURE        // Disable this if your host doesn't like keepalive messages
#define DEFAULT_KEEPALIVE_INTERVAL 2  // Number of seconds between "busy" messages. Set with M113.
#define BUSY_WHILE_HEATING            // Some hosts require "busy" messages even during heating
// @section units
// G20/G21 Inch mode support
//#define INCH_MODE_SUPPORT
// M149 Set temperature units support
//#define TEMPERATURE_UNITS_SUPPORT
// @section temperature
// Preheat Constants - Up to 10 are supported without changes
#define PREHEAT_1_LABEL       "PLA"
#define PREHEAT_1_TEMP_HOTEND 200
#define PREHEAT_1_TEMP_BED     50
#define PREHEAT_1_TEMP_CHAMBER 35
#define PREHEAT_1_FAN_SPEED     0 // Value from 0 to 255
#define PREHEAT_2_LABEL      "PETG"
#define PREHEAT_2_TEMP_HOTEND 240
#define PREHEAT_2_TEMP_BED     80
#define PREHEAT_2_TEMP_CHAMBER 35
#define PREHEAT_2_FAN_SPEED     0 // Value from 0 to 255
#define PREHEAT_3_LABEL       "ASA"
#define PREHEAT_3_TEMP_HOTEND 260
#define PREHEAT_3_TEMP_BED    105
#define PREHEAT_3_TEMP_CHAMBER 35
#define PREHEAT_3_FAN_SPEED     0
#define PREHEAT_4_LABEL       "TPU"
#define PREHEAT_4_TEMP_HOTEND 230
#define PREHEAT_4_TEMP_BED     50
#define PREHEAT_4_TEMP_CHAMBER 35
#define PREHEAT_4_FAN_SPEED     0
#define PREHEAT_5_LABEL       "GTP" // Extrudr GreenTEC Pro
#define PREHEAT_5_TEMP_HOTEND 225
#define PREHEAT_5_TEMP_BED     50
#define PREHEAT_5_TEMP_CHAMBER 35
#define PREHEAT_5_FAN_SPEED     0
#define PREHEAT_6_LABEL        "PC"
#define PREHEAT_6_TEMP_HOTEND 265
#define PREHEAT_6_TEMP_BED    110
#define PREHEAT_6_TEMP_CHAMBER 35
#define PREHEAT_6_FAN_SPEED     0
// @section motion
   Nozzle Park
   Park the nozzle at the given XYZ position on idle or G27.
   The "P" parameter controls the action applied to the Z axis:
      P0  (Default) If Z is below park Z raise the nozzle.
      P1  Raise the nozzle always to Z-park height.
      P2  Raise the nozzle by Z-park amount, limited to Z_MAX_POS.
#define NOZZLE_PARK_FEATURE
#if ENABLED(NOZZLE_PARK_FEATURE)
// Specify a park position as { X, Y, Z_raise }
#define NOZZLE_PARK_POINT { (X_MIN_POS + 10), (Y_MAX_POS - 10), 20 }
#define NOZZLE_PARK_MOVE          0   // Park motion: 0 = XY Move, 1 = X Only, 2 = Y Only, 3 = X before Y, 4 = Y before X
#define NOZZLE_PARK_Z_RAISE_MIN   2   // (mm) Always raise Z by at least this distance
#define NOZZLE_PARK_XY_FEEDRATE 100   // (mm/s) X and Y axes feedrate (also used for delta Z axis)
#define NOZZLE_PARK_Z_FEEDRATE    5   // (mm/s) Z axis feedrate (not used for delta printers)
#endif
   Clean Nozzle Feature -- EXPERIMENTAL
   Adds the G12 command to perform a nozzle cleaning process.
   Parameters:
     P  Pattern
     S  Strokes / Repetitions
     T  Triangles (P1 only)
   Patterns:
     P0  Straight line (default). This process requires a sponge type material
         at a fixed bed location. "S" specifies strokes (i.e. back-forth motions)
         between the start / end points.
     P1  Zig-zag pattern between (X0, Y0) and (X1, Y1), "T" specifies the
         number of zig-zag triangles to do. "S" defines the number of strokes.
         Zig-zags are done in whichever is the narrower dimension.
         For example, "G12 P1 S1 T3" will execute:
           |  (X0, Y1) |     /\        /\        /\     | (X1, Y1)
         A |           |   /    \    /    \    /    \   |
           |  (X0, Y0) | /        \/        \/        \ | (X1, Y0)
                         |________|_________|_________|
                             T1        T2        T3
     P2  Circular pattern with middle at NOZZLE_CLEAN_CIRCLE_MIDDLE.
         "R" specifies the radius. "S" specifies the stroke count.
         Before starting, the nozzle moves to NOZZLE_CLEAN_START_POINT.
     Caveats: The ending Z should be the same as starting Z.
   Attention: EXPERIMENTAL. G-code arguments may change.
//#define NOZZLE_CLEAN_FEATURE
#if ENABLED(NOZZLE_CLEAN_FEATURE)
// Default number of pattern repetitions
#define NOZZLE_CLEAN_STROKES  12
// Default number of triangles
#define NOZZLE_CLEAN_TRIANGLES  3
// Specify positions for each tool as { { X, Y, Z }, { X, Y, Z } }
// Dual hotend system may use { {  -20, (Y_BED_SIZE / 2), (Z_MIN_POS + 1) },  {  420, (Y_BED_SIZE / 2), (Z_MIN_POS + 1) }}
#define NOZZLE_CLEAN_START_POINT { {  30, 30, (Z_MIN_POS + 1) } }
#define NOZZLE_CLEAN_END_POINT   { { 100, 60, (Z_MIN_POS + 1) } }
// Circular pattern radius
#define NOZZLE_CLEAN_CIRCLE_RADIUS 6.5
// Circular pattern circle fragments number
#define NOZZLE_CLEAN_CIRCLE_FN 10
// Middle point of circle
#define NOZZLE_CLEAN_CIRCLE_MIDDLE NOZZLE_CLEAN_START_POINT
// Move the nozzle to the initial position after cleaning
#define NOZZLE_CLEAN_GOBACK
// For a purge/clean station that's always at the gantry height (thus no Z move)
//#define NOZZLE_CLEAN_NO_Z
// For a purge/clean station mounted on the X axis
//#define NOZZLE_CLEAN_NO_Y
// Require a minimum hotend temperature for cleaning
#define NOZZLE_CLEAN_MIN_TEMP 170
//#define NOZZLE_CLEAN_HEATUP       // Heat up the nozzle instead of skipping wipe
// Explicit wipe G-code script applies to a G12 with no arguments.
//#define WIPE_SEQUENCE_COMMANDS "G1 X-17 Y25 Z10 F4000\nG1 Z1\nM114\nG1 X-17 Y25\nG1 X-17 Y95\nG1 X-17 Y25\nG1 X-17 Y95\nG1 X-17 Y25\nG1 X-17 Y95\nG1 X-17 Y25\nG1 X-17 Y95\nG1 X-17 Y25\nG1 X-17 Y95\nG1 X-17 Y25\nG1 X-17 Y95\nG1 Z15\nM400\nG0 X-10.0 Y-9.0"
#endif
// @section host
   Print Job Timer
   Automatically start and stop the print job timer on M104/M109/M140/M190/M141/M191.
   The print job timer will only be stopped if the bed/chamber target temp is
   below BED_MINTEMP/CHAMBER_MINTEMP.
     M104 (hotend, no wait)  - high temp = none,        low temp = stop timer
     M109 (hotend, wait)     - high temp = start timer, low temp = stop timer
     M140 (bed, no wait)     - high temp = none,        low temp = stop timer
     M190 (bed, wait)        - high temp = start timer, low temp = none
     M141 (chamber, no wait) - high temp = none,        low temp = stop timer
     M191 (chamber, wait)    - high temp = start timer, low temp = none
   For M104/M109, high temp is anything over EXTRUDE_MINTEMP / 2.
   For M140/M190, high temp is anything over BED_MINTEMP.
   For M141/M191, high temp is anything over CHAMBER_MINTEMP.
   The timer can also be controlled with the following commands:
     M75 - Start the print job timer
     M76 - Pause the print job timer
     M77 - Stop the print job timer
#define PRINTJOB_TIMER_AUTOSTART
// @section stats
   Print Counter
   Track statistical data such as:
    - Total print jobs
    - Total successful print jobs
    - Total failed print jobs
    - Total time printing
   View the current statistics with M78.
#define PRINTCOUNTER
#if ENABLED(PRINTCOUNTER)
#define PRINTCOUNTER_SAVE_INTERVAL 60 // (minutes) EEPROM save interval during print. A value of 0 will save stats at end of print.
#endif
// @section security
   Password
   Set a numerical password for the printer which can be requested:
    - When the printer boots up
    - Upon opening the 'Print from Media' Menu
    - When SD printing is completed or aborted
   The following G-codes can be used:
    M510 - Lock Printer. Blocks all commands except M511.
    M511 - Unlock Printer.
    M512 - Set, Change and Remove Password.
   If you forget the password and get locked out you'll need to re-flash
   the firmware with the feature disabled, reset EEPROM, and (optionally)
   re-flash the firmware again with this feature enabled.
//#define PASSWORD_FEATURE
#if ENABLED(PASSWORD_FEATURE)
//#define PASSWORD_LENGTH 4                 // (#) Number of digits (1-9). 3 or 4 is recommended
//#define PASSWORD_ON_STARTUP
//#define PASSWORD_UNLOCK_GCODE             // Unlock with the M511 P<password> command. Disable to prevent brute-force attack.
//#define PASSWORD_CHANGE_GCODE             // Change the password with M512 P<old> S<new>.
//#define PASSWORD_ON_SD_PRINT_MENU       // This does not prevent gcodes from running
//#define PASSWORD_AFTER_SD_PRINT_END
//#define PASSWORD_AFTER_SD_PRINT_ABORT
//#include "Configuration_Secure.h"       // External file with PASSWORD_DEFAULT_VALUE
#endif
//============================= LCD and SD support ============================
// @section interface
   LCD LANGUAGE
   Select the language to display on the LCD. These languages are available:
     en, an, bg, ca, cz, da, de, el, el_CY, es, eu, fi, fr, gl, hr, hu, it,
     jp_kana, ko_KR, nl, pl, pt, pt_br, ro, ru, sk, sv, tr, uk, vi, zh_CN, zh_TW
   :{ 'en':'English', 'an':'Aragonese', 'bg':'Bulgarian', 'ca':'Catalan', 'cz':'Czech', 'da':'Danish', 'de':'German', 'el':'Greek (Greece)', 'el_CY':'Greek (Cyprus)', 'es':'Spanish', 'eu':'Basque-Euskera', 'fi':'Finnish', 'fr':'French', 'gl':'Galician', 'hr':'Croatian', 'hu':'Hungarian', 'it':'Italian', 'jp_kana':'Japanese', 'ko_KR':'Korean (South Korea)', 'nl':'Dutch', 'pl':'Polish', 'pt':'Portuguese', 'pt_br':'Portuguese (Brazilian)', 'ro':'Romanian', 'ru':'Russian', 'sk':'Slovak', 'sv':'Swedish', 'tr':'Turkish', 'uk':'Ukrainian', 'vi':'Vietnamese', 'zh_CN':'Chinese (Simplified)', 'zh_TW':'Chinese (Traditional)' }
#define LCD_LANGUAGE en
   LCD Character Set
   Note: This option is NOT applicable to Graphical Displays.
   All character-based LCDs provide ASCII plus one of these
   language extensions:
    - JAPANESE ... the most common
    - WESTERN  ... with more accented characters
    - CYRILLIC ... for the Russian language
   To determine the language extension installed on your controller:
    - Compile and upload with LCD_LANGUAGE set to 'test'
    - Click the controller to view the LCD menu
    - The LCD will display Japanese, Western, or Cyrillic text
   See https://marlinfw.org/docs/development/lcd_language.html
   :['JAPANESE', 'WESTERN', 'CYRILLIC']
//#define DISPLAY_CHARSET_HD44780 JAPANESE
   Info Screen Style (0:Classic, 1:Průša)
   :[0:'Classic', 1:'Průša']
#define LCD_INFO_SCREEN_STYLE 1
   SD CARD
   SD Card support is disabled by default. If your controller has an SD slot,
   you must uncomment the following option or it won't work.
#define SDSUPPORT
   SD CARD: ENABLE CRC
   Use CRC checks and retries on the SD communication.
#define SD_CHECK_AND_RETRY
   LCD Menu Items
   Disable all menus and only display the Status Screen, or
   just remove some extraneous menu items to recover space.
//#define NO_LCD_MENUS
//#define SLIM_LCD_MENUS
// ENCODER SETTINGS
// This option overrides the default number of encoder pulses needed to
// produce one step. Should be increased for high-resolution encoders.
#define ENCODER_PULSES_PER_STEP 4
// Use this option to override the number of step signals required to
// move between next/prev menu items.
#define ENCODER_STEPS_PER_MENU_ITEM 1
   Encoder Direction Options
   Test your encoder's behavior first with both options disabled.
    Reversed Value Edit and Menu Nav? Enable REVERSE_ENCODER_DIRECTION.
    Reversed Menu Navigation only?    Enable REVERSE_MENU_DIRECTION.
    Reversed Value Editing only?      Enable BOTH options.
// This option reverses the encoder direction everywhere.
//  Set this option if CLOCKWISE causes values to DECREASE
#define REVERSE_ENCODER_DIRECTION
// This option reverses the encoder direction for navigating LCD menus.
//  If CLOCKWISE normally moves DOWN this makes it go UP.
//  If CLOCKWISE normally moves UP this makes it go DOWN.
//#define REVERSE_MENU_DIRECTION
// This option reverses the encoder direction for Select Screen.
//  If CLOCKWISE normally moves LEFT this makes it go RIGHT.
//  If CLOCKWISE normally moves RIGHT this makes it go LEFT.
//#define REVERSE_SELECT_DIRECTION
// Encoder EMI Noise Filter
// This option increases encoder samples to filter out phantom encoder clicks caused by EMI noise.
//#define ENCODER_NOISE_FILTER
#if ENABLED(ENCODER_NOISE_FILTER)
#define ENCODER_SAMPLES 10
#endif
// Individual Axis Homing
// Add individual axis homing items (Home X, Home Y, and Home Z) to the LCD menu.
#define INDIVIDUAL_AXIS_HOMING_MENU
//#define INDIVIDUAL_AXIS_HOMING_SUBMENU
// SPEAKER/BUZZER
// If you have a speaker that can produce tones, enable it here.
// By default Marlin assumes you have a buzzer with a fixed frequency.
#define SPEAKER
// The duration and frequency for the UI feedback sound.
// Set these to 0 to disable audio feedback in the LCD menus.
// Note: Test audio output with the G-Code:
//  M300 S<frequency Hz> P<duration ms>
//#define LCD_FEEDBACK_FREQUENCY_DURATION_MS 2
//#define LCD_FEEDBACK_FREQUENCY_HZ 5000
//======================== LCD / Controller Selection =========================
//========================   (Character-based LCDs)   =========================
// @section lcd
// RepRapDiscount Smart Controller.
// https://reprap.org/wiki/RepRapDiscount_Smart_Controller
// Note: Usually sold with a white PCB.
//#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
// GT2560 (YHCB2004) LCD Display
// Requires Testato, Koepel softwarewire library and
// Andriy Golovnya's LiquidCrystal_AIP31068 library.
//#define YHCB2004
// Original RADDS LCD Display+Encoder+SDCardReader
// http://doku.radds.org/dokumentation/lcd-display/
//#define RADDS_DISPLAY
// ULTIMAKER Controller.
//#define ULTIMAKERCONTROLLER
// ULTIPANEL as seen on Thingiverse.
//#define ULTIPANEL
// PanelOne from T3P3 (via RAMPS 1.4 AUX2/AUX3)
// https://reprap.org/wiki/PanelOne
//#define PANEL_ONE
// GADGETS3D G3D LCD/SD Controller
// https://reprap.org/wiki/RAMPS_1.3/1.4_GADGETS3D_Shield_with_Panel
// Note: Usually sold with a blue PCB.
//#define G3D_PANEL
// RigidBot Panel V1.0
// http://www.inventapart.com/
//#define RIGIDBOT_PANEL
// Makeboard 3D Printer Parts 3D Printer Mini Display 1602 Mini Controller
// https://www.aliexpress.com/item/32765887917.html
//#define MAKEBOARD_MINI_2_LINE_DISPLAY_1602
// ANET and Tronxy 20x4 Controller
//#define ZONESTAR_LCD            // Requires ADC_KEYPAD_PIN to be assigned to an analog pin.
// This LCD is known to be susceptible to electrical interference
// which scrambles the display.  Pressing any button clears it up.
// This is a LCD2004 display with 5 analog buttons.
// Generic 16x2, 16x4, 20x2, or 20x4 character-based LCD.
//#define ULTRA_LCD
//=====================   (I2C and Shift-Register LCDs)   =====================
// CONTROLLER TYPE: I2C
// Note: These controllers require the installation of Arduino's LiquidCrystal_I2C
// library. For more info: https://github.com/kiyoshigawa/LiquidCrystal_I2C
// Elefu RA Board Control Panel
// https://web.archive.org/web/20140823033947/http://www.elefu.com/index.php?route=product/product&product_id=53
//#define RA_CONTROL_PANEL
// Sainsmart (YwRobot) LCD Displays
// These require F.Malpartida's LiquidCrystal_I2C library
// https://bitbucket.org/fmalpartida/new-liquidcrystal/wiki/Home
//#define LCD_SAINSMART_I2C_1602
//#define LCD_SAINSMART_I2C_2004
// Generic LCM1602 LCD adapter
//#define LCM1602
// PANELOLU2 LCD with status LEDs,
// separate encoder and click inputs.
// Note: This controller requires Arduino's LiquidTWI2 library v1.2.3 or later.
// For more info: https://github.com/lincomatic/LiquidTWI2
// Note: The PANELOLU2 encoder click input can either be directly connected to
// a pin (if BTN_ENC defined to != -1) or read through I2C (when BTN_ENC == -1).
//#define LCD_I2C_PANELOLU2
// Panucatt VIKI LCD with status LEDs,
// integrated click & L/R/U/D buttons, separate encoder inputs.
//#define LCD_I2C_VIKI
// CONTROLLER TYPE: Shift register panels
// 2-wire Non-latching LCD SR from https://goo.gl/aJJ4sH
// LCD configuration: https://reprap.org/wiki/SAV_3D_LCD
//#define SAV_3DLCD
// 3-wire SR LCD with strobe using 74HC4094
// https://github.com/mikeshub/SailfishLCD
// Uses the code directly from Sailfish
//#define FF_INTERFACEBOARD
// TFT GLCD Panel with Marlin UI
// Panel connected to main board by SPI or I2C interface.
// See https://github.com/Serhiy-K/TFTGLCDAdapter
//#define TFTGLCD_PANEL_SPI
//#define TFTGLCD_PANEL_I2C
//=======================   LCD / Controller Selection  =======================
//=========================      (Graphical LCDs)      ========================
// CONTROLLER TYPE: Graphical 128x64 (DOGM)
// IMPORTANT: The U8glib library is required for Graphical Display!
//            https://github.com/olikraus/U8glib_Arduino
// NOTE: If the LCD is unresponsive you may need to reverse the plugs.
// RepRapDiscount FULL GRAPHIC Smart Controller
// https://reprap.org/wiki/RepRapDiscount_Full_Graphic_Smart_Controller
// K.3D Full Graphic Smart Controller
//#define K3D_FULL_GRAPHIC_SMART_CONTROLLER
// ReprapWorld Graphical LCD
// https://reprapworld.com/electronics/3d-printer-modules/autonomous-printing/graphical-lcd-screen-v1-0/
//#define REPRAPWORLD_GRAPHICAL_LCD
// Activate one of these if you have a Panucatt Devices
// Viki 2.0 or mini Viki with Graphic LCD
// https://www.panucatt.com
//#define VIKI2
//#define miniVIKI
// Alfawise Ex8 printer LCD marked as WYH L12864 COG
//#define WYH_L12864
// MakerLab Mini Panel with graphic
// controller and SD support - https://reprap.org/wiki/Mini_panel
//#define MINIPANEL
// MaKr3d Makr-Panel with graphic controller and SD support.
// https://reprap.org/wiki/MaKr3d_MaKrPanel
//#define MAKRPANEL
// Adafruit ST7565 Full Graphic Controller.
// https://github.com/eboston/Adafruit-ST7565-Full-Graphic-Controller/
//#define ELB_FULL_GRAPHIC_CONTROLLER
// BQ LCD Smart Controller shipped by
// default with the BQ Hephestos 2 and Witbox 2.
//#define BQ_LCD_SMART_CONTROLLER
// Cartesio UI
// http://mauk.cc/webshop/cartesio-shop/electronics/user-interface
//#define CARTESIO_UI
// LCD for Melzi Card with Graphical LCD
//#define LCD_FOR_MELZI
// Original Ulticontroller from Ultimaker 2 printer with SSD1309 I2C display and encoder
// https://github.com/Ultimaker/Ultimaker2/tree/master/1249_Ulticontroller_Board_(x1)
//#define ULTI_CONTROLLER
// MKS MINI12864 with graphic controller and SD support
// https://reprap.org/wiki/MKS_MINI_12864
//#define MKS_MINI_12864
// MKS MINI12864 V3 is an alias for FYSETC_MINI_12864_2_1. Type A/B. NeoPixel RGB Backlight.
//#define MKS_MINI_12864_V3
// MKS LCD12864A/B with graphic controller and SD support. Follows MKS_MINI_12864 pinout.
// https://www.aliexpress.com/item/33018110072.html
//#define MKS_LCD12864A
//#define MKS_LCD12864B
// FYSETC variant of the MINI12864 graphic controller with SD support
// https://wiki.fysetc.com/Mini12864_Panel/
//#define FYSETC_MINI_12864_X_X    // Type C/D/E/F. No tunable RGB Backlight by default
//#define FYSETC_MINI_12864_1_2    // Type C/D/E/F. Simple RGB Backlight (always on)
//#define FYSETC_MINI_12864_2_0    // Type A/B. Discreet RGB Backlight
//#define FYSETC_MINI_12864_2_1    // Type A/B. NeoPixel RGB Backlight
//#define FYSETC_GENERIC_12864_1_1 // Larger display with basic ON/OFF backlight.
// BigTreeTech Mini 12864 V1.0 is an alias for FYSETC_MINI_12864_2_1. Type A/B. NeoPixel RGB Backlight.
//#define BTT_MINI_12864_V1
// Factory display for Creality CR-10
// https://www.aliexpress.com/item/32833148327.html
// This is RAMPS-compatible using a single 10-pin connector.
// (For CR-10 owners who want to replace the Melzi Creality board but retain the display)
//#define CR10_STOCKDISPLAY
// Ender-2 OEM display, a variant of the MKS_MINI_12864
//#define ENDER2_STOCKDISPLAY
// ANET and Tronxy Graphical Controller
// Anet 128x64 full graphics lcd with rotary encoder as used on Anet A6
// A clone of the RepRapDiscount full graphics display but with
// different pins/wiring (see pins_ANET_10.h). Enable one of these.
//#define ANET_FULL_GRAPHICS_LCD
//#define ANET_FULL_GRAPHICS_LCD_ALT_WIRING
// AZSMZ 12864 LCD with SD
// https://www.aliexpress.com/item/32837222770.html
//#define AZSMZ_12864
// Silvergate GLCD controller
// https://github.com/android444/Silvergate
//#define SILVER_GATE_GLCD_CONTROLLER
// eMotion Tech LCD with SD
// https://www.reprap-france.com/produit/1234568748-ecran-graphique-128-x-64-points-2-1
//#define EMOTION_TECH_LCD
//==============================  OLED Displays  ==============================
// SSD1306 OLED full graphics generic display
//#define U8GLIB_SSD1306
// SAV OLEd LCD module support using either SSD1306 or SH1106 based LCD modules
//#define SAV_3DGLCD
//#if ENABLED(SAV_3DGLCD)
//#define U8GLIB_SH1106
//#endif
// TinyBoy2 128x64 OLED / Encoder Panel
//#define OLED_PANEL_TINYBOY2
// MKS OLED 1.3" 128×64 Full Graphics Controller
// https://reprap.org/wiki/MKS_12864OLED
// Tiny, but very sharp OLED display
//#define MKS_12864OLED          // Uses the SH1106 controller (default)
//#define MKS_12864OLED_SSD1306  // Uses the SSD1306 controller
// Zonestar OLED 128×64 Full Graphics Controller
//#define ZONESTAR_12864LCD           // Graphical (DOGM) with ST7920 controller
//#define ZONESTAR_12864OLED          // 1.3" OLED with SH1106 controller (default)
//#define ZONESTAR_12864OLED_SSD1306  // 0.96" OLED with SSD1306 controller
// Einstart S OLED SSD1306
//#define U8GLIB_SH1106_EINSTART
// Overlord OLED display/controller with i2c buzzer and LEDs
//#define OVERLORD_OLED
// FYSETC OLED 2.42" 128×64 Full Graphics Controller with WS2812 RGB
// Where to find : https://www.aliexpress.com/item/4000345255731.html
//#define FYSETC_242_OLED_12864   // Uses the SSD1309 controller
// K.3D SSD1309 OLED 2.42" 128×64 Full Graphics Controller
//#define K3D_242_OLED_CONTROLLER   // Software SPI
//========================== Extensible UI Displays ===========================
   DGUS Touch Display with DWIN OS. (Choose one.)
   ORIGIN : https://www.aliexpress.com/item/32993409517.html
   FYSETC : https://www.aliexpress.com/item/32961471929.html
   MKS    : https://www.aliexpress.com/item/1005002008179262.html
   Flash display with DGUS Displays for Marlin:
    - Format the SD card to FAT32 with an allocation size of 4kb.
    - Download files as specified for your type of display.
    - Plug the microSD card into the back of the display.
    - Boot the display and wait for the update to complete.
   ORIGIN (Marlin DWIN_SET)
    - Download https://github.com/coldtobi/Marlin_DGUS_Resources
    - Copy the downloaded DWIN_SET folder to the SD card.
   FYSETC (Supplier default)
    - Download https://github.com/FYSETC/FYSTLCD-2.0
    - Copy the downloaded SCREEN folder to the SD card.
   HIPRECY (Supplier default)
    - Download https://github.com/HiPrecy/Touch-Lcd-LEO
   MKS (MKS-H43) (Supplier default)
    - Download https://github.com/makerbase-mks/MKS-H43
   RELOADED (T5UID1)
    - Download https://github.com/Desuuuu/DGUS-reloaded/releases
//#define DGUS_LCD_UI_ORIGIN
//#define DGUS_LCD_UI_FYSETC
//#define DGUS_LCD_UI_HIPRECY
//#define DGUS_LCD_UI_MKS
//#define DGUS_LCD_UI_RELOADED
//#if ENABLED(DGUS_LCD_UI_MKS)
//#define USE_MKS_GREEN_UI
//#endif
// Touch-screen LCD for Malyan M200/M300 printers
//#define MALYAN_LCD
// Touch UI for FTDI EVE (FT800/FT810) displays
// See Configuration_adv.h for all configuration options.
//#define TOUCH_UI_FTDI_EVE
// Touch-screen LCD for Anycubic printers
//#define ANYCUBIC_LCD_I3MEGA
//#define ANYCUBIC_LCD_CHIRON
//#if EITHER(ANYCUBIC_LCD_I3MEGA, ANYCUBIC_LCD_CHIRON)
//#define ANYCUBIC_LCD_DEBUG
//#define ANYCUBIC_LCD_GCODE_EXT  // Add ".gcode" to menu entries for DGUS clone compatibility
//#endif
// 320x240 Nextion 2.8" serial TFT Resistive Touch Screen NX3224T028
//#define NEXTION_TFT
// Third-party or vendor-customized controller interfaces.
// Sources should be installed in 'src/lcd/extui'.
//#define EXTENSIBLE_UI
//#if ENABLED(EXTENSIBLE_UI)
//#define EXTUI_LOCAL_BEEPER // Enables use of local Beeper pin with external display
//#endif
//=============================== Graphical TFTs ==============================
   Specific TFT Model Presets. Enable one of the following options
   or enable TFT_GENERIC and set sub-options.
// 480x320, 3.5", SPI Display with Rotary Encoder from MKS
// Usually paired with MKS Robin Nano V2 & V3
//#define MKS_TS35_V2_0
// 320x240, 2.4", FSMC Display From MKS
// Usually paired with MKS Robin Nano V1.2
//#define MKS_ROBIN_TFT24
// 320x240, 2.8", FSMC Display From MKS
//#define MKS_ROBIN_TFT28
// 320x240, 3.2", FSMC Display From MKS
//#define MKS_ROBIN_TFT32
// 480x320, 3.5", FSMC Display From MKS
//#define MKS_ROBIN_TFT35
// 480x272, 4.3", FSMC Display From MKS
//#define MKS_ROBIN_TFT43
//#define MKS_ROBIN_TFT_V1_1R
// 480x320, 3.5", FSMC Stock Display from Tronxy
//#define TFT_TRONXY_X5SA
// 480x320, 3.5", FSMC Stock Display from AnyCubic
//#define ANYCUBIC_TFT35
// 320x240, 2.8", FSMC Stock Display from Longer/Alfawise
//#define LONGER_LK_TFT28
// 320x240, 2.8", FSMC Stock Display from ET4
//#define ANET_ET4_TFT28
// 480x320, 3.5", FSMC Stock Display from ET5
//#define ANET_ET5_TFT35
// 1024x600, 7", RGB Stock Display with Rotary Encoder from BIQU-BX
//#define BIQU_BX_TFT70
// 480x320, 3.5", SPI Stock Display with Rotary Encoder from BIQU B1 SE Series
//#define BTT_TFT35_SPI_V1_0
// Generic TFT with detailed options
//#define TFT_GENERIC
//#if ENABLED(TFT_GENERIC)
// :[ 'AUTO', 'ST7735', 'ST7789', 'ST7796', 'R61505', 'ILI9328', 'ILI9341', 'ILI9488' ]
//#define TFT_DRIVER AUTO
// Interface. Enable one of the following options:
//#define TFT_INTERFACE_FSMC
//#define TFT_INTERFACE_SPI
// TFT Resolution. Enable one of the following options:
//#define TFT_RES_320x240
//#define TFT_RES_480x272
//#define TFT_RES_480x320
//#define TFT_RES_1024x600
//#endif
   TFT UI - User Interface Selection. Enable one of the following options:
     TFT_CLASSIC_UI - Emulated DOGM - 128x64 Upscaled
     TFT_COLOR_UI   - Marlin Default Menus, Touch Friendly, using full TFT capabilities
     TFT_LVGL_UI    - A Modern UI using LVGL
     For LVGL_UI also copy the 'assets' folder from the build directory to the
     root of your SD card, together with the compiled firmware.
//#define TFT_CLASSIC_UI
//#define TFT_COLOR_UI
//#define TFT_LVGL_UI
//#if ENABLED(TFT_COLOR_UI)
//#define TFT_SHARED_SPI   // SPI is shared between TFT display and other devices. Disable async data transfer
//#endif
//#if ENABLED(TFT_LVGL_UI)
//#define MKS_WIFI_MODULE  // MKS WiFi module
//#endif
   TFT Rotation. Set to one of the following values:
     TFT_ROTATE_90,  TFT_ROTATE_90_MIRROR_X,  TFT_ROTATE_90_MIRROR_Y,
     TFT_ROTATE_180, TFT_ROTATE_180_MIRROR_X, TFT_ROTATE_180_MIRROR_Y,
     TFT_ROTATE_270, TFT_ROTATE_270_MIRROR_X, TFT_ROTATE_270_MIRROR_Y,
     TFT_MIRROR_X, TFT_MIRROR_Y, TFT_NO_ROTATION
//#define TFT_ROTATION TFT_NO_ROTATION
//============================  Other Controllers  ============================
// Ender-3 v2 OEM display. A DWIN display with Rotary Encoder.
//#define DWIN_CREALITY_LCD           // Creality UI
//#define DWIN_LCD_PROUI              // Pro UI by MRiscoC
//#define DWIN_CREALITY_LCD_JYERSUI   // Jyers UI by Jacob Myers
//#define DWIN_MARLINUI_PORTRAIT      // MarlinUI (portrait orientation)
//#define DWIN_MARLINUI_LANDSCAPE     // MarlinUI (landscape orientation)
// Touch Screen Settings
//#define TOUCH_SCREEN
//#if ENABLED(TOUCH_SCREEN)
//#define BUTTON_DELAY_EDIT      50 // (ms) Button repeat delay for edit screens
//#define BUTTON_DELAY_MENU     250 // (ms) Button repeat delay for menus
//#define DISABLE_ENCODER         // Disable the click encoder, if any
//#define TOUCH_IDLE_SLEEP_MINS 5 // (minutes) Display Sleep after a period of inactivity. Set with M255 S.
//#define TOUCH_SCREEN_CALIBRATION
//#define TOUCH_CALIBRATION_X 12316
//#define TOUCH_CALIBRATION_Y -8981
//#define TOUCH_OFFSET_X        -43
//#define TOUCH_OFFSET_Y        257
//#define TOUCH_ORIENTATION TOUCH_LANDSCAPE
//#if BOTH(TOUCH_SCREEN_CALIBRATION, EEPROM_SETTINGS)
//#define TOUCH_CALIBRATION_AUTO_SAVE // Auto save successful calibration values to EEPROM
//#endif
//#define SINGLE_TOUCH_NAVIGATION
//#endif
//#endif
// RepRapWorld REPRAPWORLD_KEYPAD v1.1
// https://reprapworld.com/products/electronics/ramps/keypad_v1_0_fully_assembled/
//#define REPRAPWORLD_KEYPAD
//#define REPRAPWORLD_KEYPAD_MOVE_STEP 10.0 // (mm) Distance to move per key-press
// EasyThreeD ET-4000+ with button input and status LED
//#define EASYTHREED_UI
//=============================== Extra Features ==============================
// @section fans
// Set number of user-controlled fans. Disable to use all board-defined fans.
// :[1,2,3,4,5,6,7,8]
//#define NUM_M106_FANS 1
// Use software PWM to drive the fan, as for the heaters. This uses a very low frequency
// which is not as annoying as with the hardware PWM. On the other hand, if this frequency
// is too low, you should also increment SOFT_PWM_SCALE.
//#define FAN_SOFT_PWM
// Incrementing this by 1 will double the software PWM frequency,
// affecting heaters, and the fan if FAN_SOFT_PWM is enabled.
// However, control resolution will be halved for each increment;
// at zero value, there are 128 effective control positions.
// :[0,1,2,3,4,5,6,7]
#define SOFT_PWM_SCALE 0
// If SOFT_PWM_SCALE is set to a value higher than 0, dithering can
// be used to mitigate the associated resolution loss. If enabled,
// some of the PWM cycles are stretched so on average the desired
// duty cycle is attained.
//#define SOFT_PWM_DITHER
// @section extras
// Support for the BariCUDA Paste Extruder
//#define BARICUDA
// @section lights
// Temperature status LEDs that display the hotend and bed temperature.
// If all hotends, bed temperature, and target temperature are under 54C
// then the BLUE led is on. Otherwise the RED led is on. (1C hysteresis)
//#define TEMP_STAT_LEDS
// Support for BlinkM/CyzRgb
//#define BLINKM
// Support for PCA9632 PWM LED driver
//#define PCA9632
// Support for PCA9533 PWM LED driver
//#define PCA9533
   RGB LED / LED Strip Control
   Enable support for an RGB LED connected to 5V digital pins, or
   an RGB Strip connected to MOSFETs controlled by digital pins.
   Adds the M150 command to set the LED (or LED strip) color.
   If pins are PWM capable (e.g., 4, 5, 6, 11) then a range of
   luminance values can be set from 0 to 255.
   For NeoPixel LED an overall brightness parameter is also available.
    === CAUTION ===
    LED Strips require a MOSFET Chip between PWM lines and LEDs,
    as the Arduino cannot handle the current the LEDs will require.
    Failure to follow this precaution can destroy your Arduino!
    NOTE: A separate 5V power supply is required! The NeoPixel LED needs
    more current than the Arduino 5V linear regulator can produce.
    Requires PWM frequency between 50 <> 100Hz (Check HAL or variant)
    Use FAST_PWM_FAN, if possible, to reduce fan noise.
// LED Type. Enable only one of the following two options:
//#define RGB_LED
//#define RGBW_LED
#if EITHER(RGB_LED, RGBW_LED)
//#define RGB_LED_R_PIN 34
//#define RGB_LED_G_PIN 43
//#define RGB_LED_B_PIN 35
//#define RGB_LED_W_PIN -1
//#define RGB_STARTUP_TEST              // For PWM pins, fade between all colors
#if ENABLED(RGB_STARTUP_TEST)
#define RGB_STARTUP_TEST_INNER_MS 10  // (ms) Reduce or increase fading speed
#endif
#endif
// Support for Adafruit NeoPixel LED driver
//#define NEOPIXEL_LED
#if ENABLED(NEOPIXEL_LED)
#define NEOPIXEL_TYPE          NEO_GRBW // NEO_GRBW, NEO_RGBW, NEO_GRB, NEO_RBG, etc.
// See https://github.com/adafruit/Adafruit_NeoPixel/blob/master/Adafruit_NeoPixel.h
//#define NEOPIXEL_PIN                4 // LED driving pin
//#define NEOPIXEL2_TYPE  NEOPIXEL_TYPE
//#define NEOPIXEL2_PIN               5
#define NEOPIXEL_PIXELS              30 // Number of LEDs in the strip. (Longest strip when NEOPIXEL2_SEPARATE is disabled.)
#define NEOPIXEL_IS_SEQUENTIAL          // Sequential display for temperature change - LED by LED. Disable to change all LEDs at once.
#define NEOPIXEL_BRIGHTNESS         127 // Initial brightness (0-255)
//#define NEOPIXEL_STARTUP_TEST         // Cycle through colors at startup
// Support for second Adafruit NeoPixel LED driver controlled with M150 S1 ...
//#define NEOPIXEL2_SEPARATE
#if ENABLED(NEOPIXEL2_SEPARATE)
#define NEOPIXEL2_PIXELS           15 // Number of LEDs in the second strip
#define NEOPIXEL2_BRIGHTNESS      127 // Initial brightness (0-255)
#define NEOPIXEL2_STARTUP_TEST        // Cycle through colors at startup
#define NEOPIXEL_M150_DEFAULT      -1 // Default strip for M150 without 'S'. Use -1 to set all by default.
#else
//#define NEOPIXEL2_INSERIES          // Default behavior is NeoPixel 2 in parallel
#endif
// Use some of the NeoPixel LEDs for static (background) lighting
//#define NEOPIXEL_BKGD_INDEX_FIRST   0 // Index of the first background LED
//#define NEOPIXEL_BKGD_INDEX_LAST    5 // Index of the last background LED
//#define NEOPIXEL_BKGD_COLOR { 255, 255, 255, 0 }  // R, G, B, W
//#define NEOPIXEL_BKGD_ALWAYS_ON       // Keep the backlight on when other NeoPixels are off
#endif
   Printer Event LEDs
   During printing, the LEDs will reflect the printer status:
    - Gradually change from blue to violet as the heated bed gets to target temp
    - Gradually change from violet to red as the hotend gets to temperature
    - Change to white to illuminate work surface
    - Change to green once print has finished
    - Turn off after the print has finished and the user has pushed a button
#if ANY(BLINKM, RGB_LED, RGBW_LED, PCA9632, PCA9533, NEOPIXEL_LED)
#define PRINTER_EVENT_LEDS
#endif
// @section servos
   Number of servos
   For some servo-related options NUM_SERVOS will be set automatically.
   Set this manually if there are extra servos needing manual control.
   Set to 0 to turn off servo support.
//#define NUM_SERVOS 3 // Note: Servo index starts with 0 for M280-M282 commands
// (ms) Delay before the next move will start, to give the servo time to reach its target angle.
// 300ms is a good value but you can try less delay.
// If the servo can't reach the requested position, increase it.
#define SERVO_DELAY { 300 }
// Only power servos during movement, otherwise leave off to prevent jitter
//#define DEACTIVATE_SERVOS_AFTER_MOVE
// Edit servo angles with M281 and save to EEPROM with M500
//#define EDITABLE_SERVO_ANGLES
// Disable servo with M282 to reduce power consumption, noise, and heat when not in use
//#define SERVO_DETACH_GCODE
