Lead Acid Battery Charger
by Tony van Roon
Parts List:
R1 = 120 Ohm C1 = 100uF/63V Q1 = NTE374/BD140
R2 = 82 Ohm C2 = 10uF/35V Q2 = NTE123AP/BC547
R3 = 10K D1 = 1N5401/NTE5801 U1 = LM350 (On large coolrib!)
R4 = 33K D2 = LED (Red, 5mm)
R5 = 22K
P1 = 2K2
How it works:
Except for use as a normal
Batter Charger, this circuit is perfect to 'constant-charge' a 12-Volt Lead-Acid
Battery, like the one in your flight box, and keep it
in optimum charged condition. This circuit is not
recommended for GELL-TYPE batteries since it draws to much
current.
The above circuit is a precision voltage source, and contains a
temperature sensor with a negative temperature coëficient. Meaning, whenever the
surrounding or battery temperature increases the voltage will automatically
decrease. Temperature coëficient for this circuit is -8mV per °Celcius. A normal
transistor (Q1) is used as a temperature sensor.
This Battery Charger is
centered around the LM350 integrated,
3-amp, adjustable stabiliser IC. Output voltage can be adjusted with P1 between
13.5 and 14.5 volt. T2 was added to prevent battery discharge via R1 if no power
present. P1 can adjust the output voltage between 13.5 and 14.5 volts. R4's
value can be adjusted to accommodate a bit larger or smaller window. D1 is a
large power-diode, 100V PRV @ 3 amp. Bigger is best but I don't recommend going
smaller.
The LM350's 'adjust' pin will try to keep the voltage drop
between its pin and the output pin at a constant value of 1.25V. So there is a
constant current flow through R1. Q1 act here as a temperature sensor with the
help of components P1/R3/R4 who more or less control the base of Q1. Since the
emitter/base connection of Q1, just like any other semiconductor, contains a
temperature coëficient of -2mV/°C, the output voltage will also show a negative
temperature coëficient. That one is only a factor of 4 larger, because of the
variation of the emitter/basis of Q1 multiplied by the division factor of
P1/R3/R4. Which results in approximately -8mV/°C. To prevent that sensor Q1 is
warmed up by its own current draw, I recommend adding a cooling rib of
sorts.
(If you wish to compensate for the battery-temperature itself, then
Q1 should be mounted as close on the battery as possible)
The red led
(D2) indicates the presence of input power.
Depending on what type of
transistor you use for Q1, the pads on the circuit board may no fit exactly (in
case of the BD140).
Caution: Adjust the voltage of capacitor C1
according to the input voltage. Example, if your input voltage will be 24 volt,
your C1 should be able to carry at least 50V.
Back to Gadgets
Menu page
Copyright © Tony van Roon
