Parts: R1 = 0.1 ohm P1 = 2K
R2 = 3.3 ohm P2 = 1K
R3 = 220 ohm C1 = 100uF/40V (Electrolytic)
R4 = 2K7 C2 = 100pF (0.1nF)
R5 = 1K U1 = LM350
R6 = 1K5 U2 = LM334
R7 = 4K7 U3 = LM301A
R8 = 1K8 Q1 = 2N3906
R9 = 4K7 D1 = 1N4002
R10 = 1K5 Led1 = Red, 5mm
R11 = 33 ohm Led2 = Green, 5mm
R12 = 100 ohm S1 = Switch, ON-ON
R13 = 1K8
Notes:
The circuit
furnishes an initial charge voltage of 2.5 Volt-per-cell at 25°C to rapidly
charge a Lead-Acid battery.
The charging current decreases as the battery
charges, and when the current drops to about 180mA, the charging circuit reduces
the output voltage to 2.35 Volt-per-cell, floating the battery in a fully
charged state. This lower voltage prevents the battery from overcharging, which
would shorten its life. The LM301A (U3) compares the voltage drop across R1 with
an 18-mV reference set by R2. The comparator's output controls the voltage
regulator, forcing it to produce the lower float voltage when the
battey-charging current passing trhought R1 drops below 180mA. The 150mV
difference between the charge and float voltages is set by the ratio of R10 and
R12. The red and green Led's show this state of the circuit.
At points A and
B you would see approximately 18mV depending on the types of components used. At
point C there is a current flow of approximately 2.3 milli-amps, again,
depending on your choice of components and ofcourse the input voltage at 'Vin'
of the LM350 regulator.
Led1 is a red led, and for Led2 you can also use a
yellow or red one. Make sure that C1 is at least twice the input voltage. C2 is
a small ceramic type. Vin is at least 18-20volt max about 30V. Switch S1 is a
toggle or slide (ON-ON) switch of your choice. The regular on-off type will not
work.
This circuit is not recommended for GEL-TYPE
batteries since it draws to much current.
Below are the
layout and pcb for this project, with thanks to Chaisaeng
Euesakulkieat:
Back to Gadgets
Menu page
Copyright © 1998 - Tony van Roon
