/* FreqMeasure Library, for measuring relatively low frequencies
 * http://www.pjrc.com/teensy/td_libs_FreqMeasure.html
 * Copyright (c) 2011 PJRC.COM, LLC - Paul Stoffregen <paul@pjrc.com>
 * Permission is hereby granted, free of charge, to any person obtaining a copy
 * of this software and associated documentation files (the "Software"), to deal
 * in the Software without restriction, including without limitation the rights
 * to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
 * copies of the Software, and to permit persons to whom the Software is
 * furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in
 * all copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
 * AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
 * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
 * THE SOFTWARE.
#ifndef FreqMeasure_capture_h_
#define FreqMeasure_capture_h_
// Arduino Uno, Duemilanove, LilyPad, Mini, Fio, etc
#if defined(__AVR_ATmega328P__) || defined(__AVR_ATmega168__)
  #define CAPTURE_USE_TIMER1       // ICP1 is pin 8
// Teensy 3.1
#elif defined(__MK20DX256__)
  #define CAPTURE_USE_FTM1_CH0 3    // FTM1 CH0 is pin 3
  //#define CAPTURE_USE_FTM1_CH1 4  // FTM1 CH1 is pin 4
  //#define CAPTURE_USE_FTM2_CH0 32 // FTM2 CH0 is pin 32
  //#define CAPTURE_USE_FTM2_CH1 25 // FTM2 CH1 is pin 25
// Teensy 3.0
#elif defined(__MK20DX128__)
// Teensy-LC
#elif defined(__MKL26Z64__)
  #define CAPTURE_USE_FTM1_CH0 16   // FTM1 CH0 is pin 16
  //#define CAPTURE_USE_FTM1_CH1 17 // FTM1 CH1 is pin 17
  //#define CAPTURE_USE_FTM2_CH0 3  // FTM2 CH0 is pin 3
  //#define CAPTURE_USE_FTM2_CH1 4  // FTM2 CH1 is pin 4
// Teensy 2.0
#elif defined(__AVR_ATmega32U4__)
  // #define CAPTURE_USE_TIMER1    // ICP1 is pin 22
  #define CAPTURE_USE_TIMER3       // ICP3 is pin 10
// Teensy++ 1.0 & 2.0
#elif defined(__AVR_AT90USB646__) || defined(__AVR_AT90USB1286__)
  // #define CAPTURE_USE_TIMER1    // ICP1 is pin 4
  #define CAPTURE_USE_TIMER3       // ICP3 is pin 17
// Teensy 1.0
#elif defined(__AVR_AT90USB162__)
  #define CAPTURE_USE_TIMER1       // ICP1 is pin 16
// Sanguino
#elif defined(__AVR_ATmega644P__) || defined(__AVR_ATmega644__)
  #define CAPTURE_USE_TIMER1       // ICP1 is pin 14
// Arduino Mega
#elif defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
  // #define CAPTURE_USE_TIMER1    // ICP1 is not connected
  // #define CAPTURE_USE_TIMER3    // ICP3 is not connected
  #define CAPTURE_USE_TIMER4       // ICP4 is pin 49
  // #define CAPTURE_USE_TIMER5    // ICP5 is pin 48
#else
  #error "Unknown chip, please edit me with timer+counter definitions"
#endif
#if defined(CAPTURE_USE_FTM1_CH0)
#define FTM_SC_VALUE (FTM_SC_TOIE | FTM_SC_CLKS(1) | FTM_SC_PS(0))
#define FTM_ISR_NAME ftm1_isr
static inline void capture_init(void)
	if (FTM1_MOD != 0xFFFF || (FTM1_SC & 0x7F) != FTM_SC_VALUE) {
		FTM1_SC = 0;
		FTM1_CNT = 0;
		FTM1_MOD = 0xFFFF;
		FTM1_SC = FTM_SC_VALUE;
		#ifdef KINETISK
		FTM1_MODE = 0;
		#endif
	NVIC_SET_PRIORITY(IRQ_FTM1, 48);
static inline void capture_start(void)
	#if defined(KINETISL)
	FTM1_C0SC = 0;
	delayMicroseconds(1);
	#endif
	FTM1_C0SC = 0b01000100;
	*portConfigRegister(CAPTURE_USE_FTM1_CH0) = PORT_PCR_MUX(3);
	NVIC_ENABLE_IRQ(IRQ_FTM1);
static inline uint16_t capture_event(void)
	return (FTM1_C0SC & 0x80) ? 1 : 0;
static inline uint32_t capture_read(void)
	uint32_t val = FTM1_C0V;
	#if defined(KINETISK)
	#elif defined(KINETISL)
	FTM1_C0SC = 0b01000100 | FTM_CSC_CHF;
	#endif
	return val;
static inline uint8_t capture_overflow(void)
	return (FTM1_SC & FTM_SC_TOF) ? 1 : 0;
static inline void capture_overflow_reset(void)
	FTM1_SC = FTM_SC_VALUE | FTM_SC_TOF;
	#endif
static inline void capture_shutdown(void)
	FTM1_C0SC = 0;
	*portConfigRegister(CAPTURE_USE_FTM1_CH0) = 0;
	NVIC_DISABLE_IRQ(IRQ_FTM1);
#elif defined(CAPTURE_USE_FTM1_CH1)
		FTM1_SC = 0;
		FTM1_CNT = 0;
		FTM1_MOD = 0xFFFF;
		#ifdef KINETISK
		FTM1_MODE = 0;
		#endif
	FTM1_C1SC = 0;
	#endif
	FTM1_C1SC = 0b01000100;
	*portConfigRegister(CAPTURE_USE_FTM1_CH1) = PORT_PCR_MUX(3);
	return (FTM1_C1SC & 0x80) ? 1 : 0;
	uint32_t val = FTM1_C1V;
	FTM1_C1SC = 0b01000100 | FTM_CSC_CHF;
	#endif
	return val;
	#endif
	FTM1_C1SC = 0;
	*portConfigRegister(CAPTURE_USE_FTM1_CH1) = 0;
#elif defined(CAPTURE_USE_FTM2_CH0)
#define FTM_ISR_NAME ftm2_isr
	if (FTM2_MOD != 0xFFFF || (FTM2_SC & 0x7F) != FTM_SC_VALUE) {
		FTM2_SC = 0;
		FTM2_CNT = 0;
		FTM2_MOD = 0xFFFF;
		FTM2_SC = FTM_SC_VALUE;
		#ifdef KINETISK
		FTM2_MODE = 0;
		#endif
	NVIC_SET_PRIORITY(IRQ_FTM2, 48);
	FTM2_C0SC = 0;
	#endif
	FTM2_C0SC = 0b01000100;
	*portConfigRegister(CAPTURE_USE_FTM2_CH0) = PORT_PCR_MUX(3);
	NVIC_ENABLE_IRQ(IRQ_FTM2);
	return (FTM2_C0SC & 0x80) ? 1 : 0;
	uint32_t val = FTM2_C0V;
	FTM2_C0SC = 0b01000100 | FTM_CSC_CHF;
	#endif
	return val;
	return (FTM2_SC & FTM_SC_TOF) ? 1 : 0;
	FTM2_SC = FTM_SC_VALUE | FTM_SC_TOF;
	#endif
	FTM2_C0SC = 0;
	*portConfigRegister(CAPTURE_USE_FTM2_CH0) = 0;
	NVIC_DISABLE_IRQ(IRQ_FTM2);
#elif defined(CAPTURE_USE_FTM2_CH1)
		FTM2_SC = 0;
		FTM2_CNT = 0;
		FTM2_MOD = 0xFFFF;
		#ifdef KINETISK
		FTM2_MODE = 0;
		#endif
	FTM2_C1SC = 0;
	#endif
	FTM2_C1SC = 0b01000100;
	*portConfigRegister(CAPTURE_USE_FTM2_CH1) = PORT_PCR_MUX(3);
	return (FTM2_C1SC & 0x80) ? 1 : 0;
	uint32_t val = FTM2_C1V;
	FTM2_C1SC = 0b01000100 | FTM_CSC_CHF;
	#endif
	return val;
	#endif
	FTM2_C1SC = 0;
	*portConfigRegister(CAPTURE_USE_FTM2_CH1) = 0;
#elif defined(CAPTURE_USE_TIMER1)
static uint8_t saveTCCR1A, saveTCCR1B;
	saveTCCR1A = TCCR1A;
	saveTCCR1B = TCCR1B;
	TCCR1B = 0;
	TCCR1A = 0;
	TCNT1 = 0;
	TIFR1 = (1<<ICF1) | (1<<TOV1);
	TIMSK1 = (1<<ICIE1) | (1<<TOIE1);
	TCCR1B = (1<<ICNC1) | (1<<ICES1) | (1<<CS10);
static inline uint16_t capture_read(void)
	return ICR1;
	return TIFR1 & (1<<TOV1);
	TIFR1 = (1<<TOV1);
	TCCR1B = 0;
	TIMSK1 = 0;
	TCCR1A = saveTCCR1A;
	TCCR1B = saveTCCR1B;
#define TIMER_OVERFLOW_VECTOR  TIMER1_OVF_vect
#define TIMER_CAPTURE_VECTOR   TIMER1_CAPT_vect
#elif defined(CAPTURE_USE_TIMER3)
static uint8_t saveTCCR3A, saveTCCR3B;
	saveTCCR3A = TCCR3A;
	saveTCCR3B = TCCR3B;
	TCCR3B = 0;
	TCCR3A = 0;
	TCNT3 = 0;
	TIFR3 = (1<<ICF3) | (1<<TOV3);
	TIMSK3 = (1<<ICIE3) | (1<<TOIE3);
	TCCR3B = (1<<ICNC3) | (1<<ICES3) | (1<<CS30);
	return ICR3;
	return TIFR3 & (1<<TOV3);
	TIFR3 = (1<<TOV3);
	TCCR3B = 0;
	TIMSK3 = 0;
	TCCR3A = saveTCCR3A;
	TCCR3B = saveTCCR3B;
#define TIMER_OVERFLOW_VECTOR  TIMER3_OVF_vect
#define TIMER_CAPTURE_VECTOR   TIMER3_CAPT_vect
#elif defined(CAPTURE_USE_TIMER4)
static uint8_t saveTCCR4A, saveTCCR4B;
	saveTCCR4A = TCCR4A;
	saveTCCR4B = TCCR4B;
	TCCR4B = 0;
	TCCR4A = 0;
	TCNT4 = 0;
	TIFR4 = (1<<ICF4) | (1<<TOV4);
	TIMSK4 = (1<<ICIE4) | (1<<TOIE4);
	TCCR4B = (1<<ICNC4) | (1<<ICES4) | (1<<CS40);
	return ICR4;
	return TIFR4 & (1<<TOV4);
	TIFR4 = (1<<TOV4);
	TCCR4B = 0;
	TIMSK4 = 0;
	TCCR4A = saveTCCR4A;
	TCCR4B = saveTCCR4B;
#define TIMER_OVERFLOW_VECTOR  TIMER4_OVF_vect
#define TIMER_CAPTURE_VECTOR   TIMER4_CAPT_vect
#elif defined(CAPTURE_USE_TIMER5)
static uint8_t saveTCCR5A, saveTCCR5B;
	saveTCCR5A = TCCR5A;
	saveTCCR5B = TCCR5B;
	TCCR5B = 0;
	TCCR5A = 0;
	TCNT5 = 0;
	TIFR5 = (1<<ICF5) | (1<<TOV5);
	TIMSK5 = (1<<ICIE5) | (1<<TOIE5);
	TCCR5B = (1<<ICNC5) | (1<<ICES5) | (1<<CS50);
	return ICR5;
	return TIFR5 & (1<<TOV5);
	TIFR5 = (1<<TOV5);
	TCCR5B = 0;
	TIMSK5 = 0;
	TCCR5A = saveTCCR5A;
	TCCR5B = saveTCCR5B;
#define TIMER_OVERFLOW_VECTOR  TIMER5_OVF_vect
#define TIMER_CAPTURE_VECTOR   TIMER5_CAPT_vect
#endif // CAPTURE_USE_***
#endif
