; Ver 2.0 alpha modified to be function only decoder GP3/comparator input
; Ver 2.01 beta 1 with further development (see below for enhancement/fixes)
; Ver 2.02 addressing inverted functioning of F0 forwards and changed CV8 to 13
; Ver 2.03 Beta 2 F0 reverse invertion now fixed as well.
; Ver 2.04 F5-F8 and F9-F12 now not transposed.
; Ver 2.05 Added output inversion in CV99.
; Ver 2.06 Added decoder lock.
; Ver 2.07 and 2.08 only apply to 12F683 and 16F684
; Ver 2.09 DC Analogue mode improvements using CV14
; Ver 2.10 Improved DC brake
; Ver 2.11 Implemented CV21 and CV22 for F0-F12 operated by consist address
; Ver 2.12 Added support for LokMaus2 programming
; Ver 2.13 Changed CV29 default to 6 as per NMRA
; Ver 2.14 Fixed ignoring short address 112-127
; Ver 2.15 Tidied up redundant code and registers.
; Ver 2.16 Added flicker for PORTC outputs C,E,F,G and H
; Ver 2.17 Protected unsupported bits in CV29 so they cannot be set
; Ver 2.18 Corrected ACK pulse to 6mS
; This is a basic DCC mobile function decoder using the 12F629/675 (3 or 5 function)
; or 16F630/676 (8 function)
; It uses the internal 4MHz osc. Execution cycle is 1us.
; It incorporates ideas from D.Probst DCC decoder project
; and Heiko Schroeter's 12F629 mobile 'Z' gauge decoders
; Parts copyright (C) Dean Probst and (C) Heiko Schroeter but released
; under the GNU General Public License
; This version is by Paul Harman mailto:diydecoder@hotmail.co.uk and is not fully functional.
; It will be superceded by a working version but is sufficiently functional to test the 
; hardware platform.
;    This program is free software; you can redistribute it and/or modify
;    it under the terms of the GNU General Public License as published by
;    the Free Software Foundation; either version 2 of the License, or
;    (at your option) any later version.
;    This program is distributed in the hope that it will be useful,
;    but WITHOUT ANY WARRANTY; without even the implied warranty of
;    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
;    GNU General Public License for more details.
;    You should have received a copy of the GNU General Public License
;    along with this program; if not, write to the Free Software
;    Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
; BUGFIXES and ENHANCEMENTS
; 1. Programming on the programming track (service mode) now fully implemented.
; 2. Function 0 is now direction dependent for 14,27,28 and 126 speed steps
; 3. Functions 5-12 now implemented.
; 3A. Functions 13-28 now implemented
; 6. Changed manufacturer ID temporarily to 13 (DIY and development)
; B. Brake on DC should work as well as analogue DC.
; C. Support now present for a CV (CV13) to hold function definitions for use in DC mode.
; F. CV47 moved to CV13.
; i. Resolved inverse functioning of F0
; 3B. Resolved transposition of function group two blocks F5-F8 and F9-F12.
; A1. Added function output inversion.
; G. Decoder lock as per TCS and Digitrax (CV15 and CV16) RP
; 4. DC Analogue now works and uses CV14 as well as CV13
; 4A. Brake on DC should now return to DCC without requiring power off
; 7. Implemented CV21 and CV22 for proper functioning in consist
; 5. Fixed state machine timing variability by removing redundant code
; J. Added LokMaus2 programming support using CV7
; H. Added flicker for oil lamp or firebox on port C outputs using CV100.
; 11. Fixed ACK pulse to 6mS
; KNOWN BUGS:-
; 4. Brake on DC not tested (may actually work!).
; 6. Incorrect manufacturer ID (need an allocation of ID and ver No for production)
; 8. CV17 write does not wait for CV18 write before committing.
; 9. Function status not retained during power outage.
; 10. Flicker not very good on Lenz.
; PLANNED CHANGES
; A. Implementation of programmable special effects such as dim on outputs similar to Lenz Gold.
; D. Proper CV definitions for functions 13-28.
; E. Possible support for asymetric braking (in 12F675 or 16F676) if anyone can think of an application!
; H. Implementation of 'exotic' UK lighting effects such as oil lamp, flashing tail lamp.
; I. Perhaps a servo drive option for fitting to live steam/internal combustion locos.
 #define ManId .13	; This should be the NMRA assigned ID in CV8, but anything other than 8 or 255
 #define VerNo .2	; The version release number to identify the decoder in CV7
 ifdef __12F629
	LIST	p=12F629	; target processor, also should work in 12F675, 16F630 and 16F676
	#include <p12f629.inc>		  ; processor specific variable definitions
	__CONFIG  _BODEN_ON & _CP_OFF & _WDT_OFF & _MCLRE_OFF & _INTRC_OSC_NOCLKOUT & _PWRTE_ON
 endif
 ifdef __16F648A
	LIST	p=16F648a	; target processor, also should work in 16F648A
	#include <p16f648A.inc>		  ; processor specific variable definitions
	__CONFIG  _CP_OFF & _LVP_OFF & _BOREN_ON & _MCLRE_OFF & _WDT_OFF  & _INTRC_OSC_NOCLKOUT & _PWRTE_ON
 endif
	__idlocs  0xB218
;***************** User definable variables in this block ***********************************
#define cv19default 0			; no consist as default
#define cv29default B'00000110'	; CV29 bit 0 =0 normal dir
								; CV29 bit 1 =1 28/126 speed steps rather than 14/27
								; CV29 bit 2 =1 DC analogue rather than DC brake
#define Acksecs  .6		; Acknowledge time in mS
AckTime set (Acksecs * D'14') / D'10'	; 1.4 times round the loop approx 1mS @4MHz
;--------------- Do not change anything below this line ----------------------------------------
; CONSTANTS
#define	F0_base		.33	; Function 0 uses CV 33 and 34
#define	F0_revoffset .1	; CV34 is next to CV33
#define	F1_base		.35	; Function 1-4 uses CV 35-38
#define	F5_base		.39	; Function 5-8 uses CV 39-42
#define	F9_base		.43	; Function 9-12 uses CV 43-46
#define	F13_base	.83	; Function 13-16 uses CV 83-86 *TemP*
#define	F17_base	.87	; Function 17-20 uses CV 87-90 *TemP*
#define	F21_base	.91	; Function 21-24 uses CV 91-94 *TemP*
#define	F25_base	.95	; Function 25-28 uses CV 95-98 *TemP*
#define Invert		.99	; Output invertion CV99
#define LokMaus2	.71 ; EEPROM location for LokMaus hundreds
#define Flicker		.100; CV100 used for flicker map, 0=flicker
; VARIABLES
#define nopreamb	D'19'	; No. of preamble half bits = 20
#define	Seed		.29		; Seed for random number generator
;Bit positions
#define norm_rev	.0		; CV29 Bit0 normal or reverse operation
#define fl_control	.1		; CV29 Bit1 FL control = 0 FL in speed14,=1 speed28 FL in function one
#define DCmode		.2		; CV29 bit2 Analogue DC mode enable (disable brake on DC support)
#define long_adr	.5
#define cv21_bit	.6		; CV21 if 1 than consist adr controls Functions
; Pin connection of 12F629/630 Function decoder
; gp0 = Function output F (or track input comparator mode)
; gp1 = Function output E (or track input comparator mode)
; gp2 = Function output D
; gp3 = Track input (non comparator mode)
; gp4 = Function output B
; gp5 = Function output A
; Extra definitions for 14 pin chips
; PC0 = Function output H
; PC1 = Function output G
; PC2 = Function output F
; PC3 = Function output E
; PC4 = Function output D (again)
; PC5 = Function output C
#define gp0	0		; Function F (or Track with comparator)
#define gp1	1		; Function E (or Track with comparator)
#define gp2	2		; Function D
#define gp3	3		; Track (non comparator)
#define gp4	4		; Function B
#define gp5	5		; Function A
; Bit Positions in CONFIG0, status flags
#define bitrec		0	; What value has just rec. bit
#define CVaccessBit	1	; Two consecutive packets to be send
#define rev_bit		2	; watch CV3/4 when changing direction set by new speed packet
#define cst_rev		3	; Consist Reverse Mode
#define cst_mode	4	; consist mode
#define cst_adr		5	; valid consist adr
#define resetflag	6	; Signal reset for service mode
#define smflag		7	; Service Mode Flag
; Bit positions in FLAG
#define FourByte	0	; 1 indicates Direct CV mode in service mode
#define	rev_mode	1	; 1 indicates that controller is set to reverse
#define	brake		2	; Stores current polarity of track
; RAM locations. EEPROM routine uses 0x1A  to 0x1F ! <- is this 12C509?
		cblock	0x20
CONFIG0				; Contains various bits to test
ENDVAL				; Offset to byte check routines
PRECOUNT			; Preamble counter
STATE				; Where are we in the DCC package
DATA1				; First transm. byte
DATA2				; Second trans. byte
DATA3				; Third transm. byte
DATA4				; Fourth transm. byte
DATA5				; Fifth transm. byte
DATA6				; Sixth transm. byte
SAMPLES				; How many samples taken for one or zero
TEMP				; Temporary scratch reg
TEMP1				; ditto
TEMP2				; ditto
TEMP3				; ditto
COUNTER    			; 
CVACCESSRATE
TIMEOUTCOUNT
CV14
CV19
CV21				; F1-F8 consist active status
CV22				; F9-F12 and F0, "  but shifted up 2-bits
CV29
MYEEDATA
FnSTATE
FnMASK
FLAG				; bit 0=1 four or more bytes to decode, bit 1=1 reverse direction called
TestByte
INVERTMAP			; Holds contents of invertmap CV to save on EEPROM reads
OUTPUT				; Values to be applied to output function pins
FlickMASK			; Copy of flicker CV
RANDOM				; Random number updated by flicker routine
		endc
;************* Here we start ! ******************************************************************************
	org	0
START:
;	bsf	STATUS,RP0
;	call	0x3FF
;	movwf	OSCCAL		;put calibration value into OSCCAL
;	bcf	STATUS,RP0
	goto	dccsetup
	org	0x5
;************* setup sets all what is ness. *****************************************************************
dccsetup:
; Temporarily removed RAM clearance to save space
	movlw	0x20		; bottom of RAM
	movwf	FSR
Next1:
	clrf	INDF
	incf	FSR,F
  ifdef __16F648A
	btfss	FSR,7
  else
	movlw	0x60		; end of ram +1
	subwf	FSR,W
	btfss	STATUS,C
  endif
	goto	Next1
	movlw	Seed		; Get seed for random number generator
	movwf	RANDOM
	movlw	nopreamb	; Preamble = 20 half bits
	movwf	PRECOUNT
; call master init and read contents of EEPROM into RAM mirrors
	call	ChkPowerUp	; Check EEPROM for consistancy and refresh if required
	call	ReadNMRA	; Load CVs into RAM image buffer for quick access
; Switch off all outputs by loading invert mask into output buffer
	movf	INVERTMAP,W		; Get invertmap	
	movwf	FnSTATE			; Save mask in output buffer
	call	Function_activate	; Activate the outputs
	btfsc	CV29,DCmode		; Check for DC mode
 ifdef __16F648A
	movlw	0x7			; set GP2:0 to digital I/O and disable comparator
	movwf	CMCON
	clrf	PORTB
 endif
	bsf	STATUS,RP0
;	movlw	B'00001000'	; gp0,1,2,4,5 are outputs ...
;	movwf	TRISIO		; ... gp3 dcc data in if comparator not used
	movlw	B'11000000'	; 
 ifdef __16F648A
    clrf	TRISB
 else
	clrf	TRISC		; Set PC5:0 output on 14 pin devices (16F630/676)
 endif
;	bcf	STATUS,RP0
;*** Removed support for GP3 input to save code space ***
; Need to test here for GP2 connected to GP3 and set up input for comparator
; GP2 is pulsed with a very short pulse which is not part of the DCC signal
;	clrf	GPIO		; Set GP2 low
;	btfsc	GPIO,GP3	; Test that GP3 is also low
;	goto	starthi		; not low so pins not linked, GP3 is the input
;	bsf		GPIO,GP2	; Set GP2 high
;	btfss	GPIO,GP3	; Test that GP3 is also high
;	goto	starthi		; not high so pins not linked, GP3 is the input
;	clrf	GPIO		; Set GP2 low again
;	btfsc	GPIO,GP3	; Test that GP3 has returned low
; Set up for comparator as input rather than GP3
;	bsf		STATUS,RP0
  ifndef __16F648A
	movlw	B'00001011'	; gp2:5 are outputs, GP3 and GP0:1 inputs
	movwf	TRISIO		; 
  endif
	bcf		STATUS,RP0
	movlw	0x2			; Leave GP2 as IO and set GP1:0 to comparator in
	movwf	CMCON
; Set bit somewhere to flag to use CMCON,COUT instead of GP3 possibly
; Drop through to starthiC
; High Bit Level Section with comparator
starthiC:
	call	Value		;4,5
conthiC:
	btfss	CMCON,C2OUT	;1	HighLevel ?
	goto	startloC		;2,3	No
	call	Speed_Sub	;3,4
	goto	conthiC		;21,22
; Low Level Bit Section with comparator
startloC:
	call	Value		;4,5
contloC:
	btfsc	CMCON,C2OUT	;1
	goto	starthiC		;2,3
	call	Speed_Sub	;3,4
	goto	contloC		;21,22
; High Bit Level Section with GP3
;starthi:
;	call	Value		;4,5
;conthi:
;	btfss	GPIO,gp3	;1	HighLevel ?
;	goto	startlo		;2,3	No
;	call	Speed_Sub	;3,4
;	goto	conthi		;22,23
; Low Level Bit Section with GP3
;startlo:
;	call	Value		;4,5
;contlo:
;	btfsc;	GPIO,gp3	;1
;	goto	starthi		;2,3
;	goto	contlo		;22,23
				;Value checks for correct bit and jumps to where we are in DCC package
				;Computed goto has to reside wholy within page 0, so make sure not too
				;much code is added in front.
Value:
	clrf	SAMPLES		; 6
	movf	STATE,W		; 7
	addwf	PCL,F		; 8,9
				;Jump table to routines from where we do a RETURN !
				;cycl. to here ->  cycl for rout.
	goto	waitn		; 10,11
	goto	waitlo
	goto	testlo
; First byte
	goto	bitset		; Half bit
	goto	lastv		; Bit 0
	goto	lastv		; Bit 1
	goto	lastv		; Bit 2
	goto	lastv		; Bit 3
	goto	lastv		; Bit 4
	goto	lastv		; Bit 5
	goto	lastv		; Bit 6
	goto	lastx		; Bit 7 so Byte received
; Seperator bits
	goto	end11		; Check first half bit of byte 1-2 seperator
	goto	end12		; Check second half bit of byte 1-2 seperator
	goto	end11		; Check first half bit of byte 2-3 seperator
	goto	end22		; Check second half bit of byte 2-3 seperator
	goto	end31		; Check first half bit of byte 3-4 seperator
	goto	end32		; Check second half bit of byte 3-4 seperator
	goto	end31		; Check first half bit of byte 4-5 seperator
	goto	end42		; Check second half bit of byte 4-5 seperator
	goto	end31		; Check first half bit of byte 5-6 seperator
	goto	end52		; Check second half bit of byte 5-6 seperator
	goto	end61		; Check first half bit of byte 6 terminator
	goto	end62		; Check second half bit of byte 6 terminator
; Decoding will occur after six bytes. If another byte is signalled there will be a frame error
; I guess that nothing should ever get here, but if it does it will check CV8 and return
ChkPowerUp:
; New, more compact set to factory defaults procedure
; Set the page register to 1 at power on. Page mode will not power cycle between
; setting the page register and programming the CV. A power cycle reset will ensure
; that register and address only modes will always program CV1-4.
; Computed goto so must remain wholy within page 0
	movlw	.1			; Page register default is 1
	movwf	MYEEDATA
	movlw	.0			; Page register uses EEPROM location 0
	call	EEPROM_WRITE
; Check that CV8 has not been changed to force a factory reset
	movlw	0x8		 ; CV8 will contain the manufacturer ID if all is sound
	call	EEPROM_READ
	xorlw	ManId
	btfsc	STATUS,Z
	return			 ; CV 8 is set correctly so return without setting factory defaults
; Set CVs to default values
	movlw	.255		; CV8=255 while resetting to factory default
	movwf	MYEEDATA
	movlw	.8
	call	EEPROM_WRITE
	clrf	TEMP			; TEMP is used as a counter for the table
Next_default:
	Call	GetCVDefault	; Get CV number
	movwF	TEMP1
	incf	TEMP,F
	Call	GetCVDefault	; Get CV contents
	movwf	MYEEDATA
	movf	TEMP1,W
	call	EEPROM_WRITE	; Write CV
	incf	TEMP,F
	movlw	.8
	xorwf	TEMP1,W
	btfsc	STATUS,Z		; Check for CV8, always last
	return					; Done if CV8 done
	goto	Next_default	; Do next CV
GetCVDefault:
	movf	TEMP,W	;
	addwf	PCL,F	;
; Table format is:- 	retlw CV_Number
;						retlw CV_value
	retlw	.1
	retlw	.3		; CV1=3
	retlw	.7
	retlw	VerNo	; CV7 = version number
	retlw	.13
	retlw	b'11111111'	; CV13 = F1-8 active in DC analogue mode
	retlw	.14
	retlw	b'00111111'	; CV14 = F0,9-12 active in DC analogue mode
	retlw	.15
	retlw	.0		; CV15=0 decoder lock default
	retlw	.16
	retlw	.0		; CV16=0 decoder lock default
	retlw	.17
	retlw	.0		; CV17=0 and CV18=0 long address 0000
	retlw	.18
	retlw	.0
	retlw	.19
	retlw	.0		; CV19=0
	retlw	.21
	retlw	b'11111111'	; CV21 = F1-8 active in consist mode
	retlw	.22
	retlw	b'00111111'	; CV22 = F0 and F9-12 active in consist mode
	retlw	.29
	retlw	.6		; CV29=6
; CV 33-46 are function to output mappings similar to the NMRA method. Bit positions are
; the same as in port C register where possible to keep life simple rather than NMRA method
; Output A = GP5/PA5 = value of 128
; Output B = GP4/PA4 = value of 64
; Output C = PC5 = value of 32
; Output D = GP2/(PC4) = value of 16
; Output E = (GP1)/PC3 = value of 8
; Output F = (GP0)/PC2 = value of 4
; Output G = PC1 = value of 2
; Output H = PC0 = value of 1
	retlw	F0_base
	retlw	b'10000000'	; CV33 = F0 forward -> Output A
	retlw	F0_base + 1
	retlw	b'01000000'	; CV34 = F0 reverse -> Output B
	retlw	F1_base
	retlw	b'00100000'	; CV35 = F1 -> Output C
	retlw	F1_base + 1
	retlw	b'00010000'	; CV36 = F2 -> Output D
	retlw	F1_base + 2
	retlw	b'00001000'	; CV37 = F3 -> Output E
	retlw	F1_base + 3
	retlw	b'00000100'	; CV38 = F4 -> Output F
	retlw	F5_base
	retlw	b'00000010'	; CV39 = F5 -> Output G
	retlw	F5_base + 1
	retlw	b'00000001'	; CV40 = F6 -> Output H
	retlw	F5_base + 2
	retlw	b'00000000'	; CV41 = F7 -> No Output
	retlw	F5_base + 3
	retlw	b'00000000'	; CV42 = F8 -> No Output
	retlw	F9_base
	retlw	b'00000000'	; CV43 = F9 -> No Output
	retlw	F9_base + 1
	retlw	b'00000000'	; CV44 = F10 -> No Output
	retlw	F9_base + 2
	retlw	b'00000000'	; CV45 = F11 -> No Output
	retlw	F9_base + 3
	retlw	b'00000000'	; CV46 = F12 -> No Output
	retlw	F13_base
	retlw	b'00000000'	; CV83 = F13 -> No Output
	retlw	F13_base + 1
	retlw	b'00000000'	; CV84 = F14 -> No Output
	retlw	F13_base + 2
	retlw	b'00000000'	; CV85 = F15 -> No Output
	retlw	F13_base + 3
	retlw	b'00000000'	; CV86 = F16 -> No Output
	retlw	F17_base
	retlw	b'00000000'	; CV87 = F17 -> No Output
	retlw	F17_base + 1
	retlw	b'00000000'	; CV88 = F18 -> No Output
	retlw	F17_base + 2
	retlw	b'00000000'	; CV89 = F19 -> No Output
	retlw	F17_base + 3
	retlw	b'00000000'	; CV90 = F20 -> No Output
	retlw	F21_base
	retlw	b'00000000'	; CV91 = F21 -> No Output
	retlw	F21_base + 1
	retlw	b'00000000'	; CV92 = F22 -> No Output
	retlw	F21_base + 2
	retlw	b'00000000'	; CV93 = F23 -> No Output
	retlw	F21_base + 3
	retlw	b'00000000'	; CV94 = F24 -> No Output
	retlw	F25_base
	retlw	b'00000000'	; CV95 = F25 -> No Output
	retlw	F25_base + 1
	retlw	b'00000000'	; CV96 = F26 -> No Output
	retlw	F25_base + 2
	retlw	b'00000000'	; CV97 = F27 -> No Output
	retlw	F25_base + 3
	retlw	b'00000000'	; CV98 = F28 -> No Output
	retlw	Invert
	retlw	b'00000000'	; CV99  No inversions
	retlw	Flicker
	retlw	b'11111111'	; CV99  No flickering
; CV8 must always be last. CV8=255 while setting to defaults is in progress
	retlw	.8		 ; stamp power up by rewriting manufacturer ID to CV8
	retlw	ManId
; Each of the following state routines enters on step 12 and exits with step 22
				; waitn waits for 20 half bits of the preamble
waitn:	
	clrf	TIMEOUTCOUNT	;12 clear DC timeout when preamble is received
	nop						;13
	btfss	CONFIG0,bitrec	;14   there are only ones in preamble
	goto	waitn1			;15,16
	decfsz	PRECOUNT,F		;16
	goto	ret4			;17,18
	movlw	nopreamb		;18
	movwf	PRECOUNT		;19
	incf	STATE,F			;20
	return					;21,22
waitn1:
	movlw	nopreamb		;17
	movwf	PRECOUNT		;18
ret4:
	nop						;19
	nop						;20
	return					;21,22
				; waitlo waits for low half bit after preamble
waitlo:	
	clrf	TIMEOUTCOUNT	;12 clear DC timeout when half bit received
	nop						;13
	nop						;14
	nop						;15
	nop						;16
	nop						;17
	btfsc	CONFIG0,bitrec	;18	must be a zero
	goto	ret5			;19,20	might be long preamble so go round again
	incf	STATE,F			;20
ret5:
	return					;21,22
				; testlo test second half bit of start bit
testlo:	
	nop						;13
	nop						;14
	nop						;15
	nop						;16
	nop						;17
	goto	frameerr		;19 incomplete zero bit so no good
	incf	STATE,F			;20
	return					;21,22
				; bitset takes first half bit of a bit in the byte
bitset:	
	incf	STATE,F			;12
	bcf	STATUS,C			;13
	btfsc	CONFIG0,bitrec	;14
	bsf	STATUS,C			;15
	rlf	DATA6,F				;16
	nop						;17
	nop						;18
	nop						;19
	nop						;20
	return					;21,22
				; lastv checks that first half bit = second half bit
lastv:	
	nop						;13
	nop						;14
	incf	STATE,F			;15
	btfss	CONFIG0,bitrec	;16
	goto	lastv1			;17,18
	btfss	DATA6,0			;18
	goto	frameerr		;19,20 error if half bits not equal
	nop						;20
	return					;21,22
lastv1:
	btfsc	DATA6,0			;19
	goto	frameerr		;20,21	error if half bits not equal
	return					;21,22
				; lastx checks that first half bit = second half bit
				; and sets offset to byte check routine
lastx:	
	incf	ENDVAL,F		;13
	movf	ENDVAL,W		;14
	addwf	STATE,F			;15
	goto	lastx1			;17,18
	btfss	DATA6,0			;18
	goto	frameerr		;19	error if half bits not equal
	nop						;20
	return					;21,22
lastx1:
	btfsc	DATA6,0			;19
	goto	frameerr		;20	error if half bits not equal
	return					;21,22
				; end11 end of first byte there must be zero
				; end11 first half bit. end12 second half bit
end11:
	btfsc	CONFIG0,bitrec	;13
	goto	frameerr		;14,15 first half bit is not zero
	incf	STATE,F			;15
	incf	ENDVAL,F		;16
	nop						;17
	nop						;18
	nop						;19
	nop						;20
	return					;21,22
end12:	
	btfsc	CONFIG0,bitrec	;12
	goto	frameerr		;13,14 second half bit is not zero
	movf	DATA6,W			;14
	movwf	DATA1			;15
	movlw	0x03			;16	point STATE to beginning of jump table
	movwf	STATE			;17
	bcf	FLAG,FourByte		;18
	nop						;19
	nop						;20
	return					;21,22
				; end21 end of second byte there must be zero
				; end21 first half bit. end22 second half bit
; end21: is the same as end11:, so use end11:
end22:	
	goto	frameerr		;14,15 second half bit is not zero
	movf	DATA6,W			;15
	movwf	DATA2			;16
	movlw	0x03			;17	point STATE to beginning of jump table
	movwf	STATE			;18
	nop						;19
	nop						;20
	return					;21,22
				; end31 end of third byte there must be a one if last byte, or 0 if more
				; end31 first half bit. end32 second half bit
				; there does not appear to be any testing of the first half bit.
				; Use spare cycles to flag only three bytes.
end31:	
	incf	STATE,F			;13
	incf	ENDVAL,F		;14
	nop						;15
	nop						;16
	nop						;17
	nop						;18
	nop						;19
	nop						;20
	return					;21,22
end32:	
	movf	DATA6,W			;13
	movwf	DATA3			;14
	btfsc	CONFIG0,bitrec	;15	if 0 other bytes will follow
	goto	end32x			;16,17 not zero so prepare to decode
	movwf	STATE			;18
	nop						;19
	nop						;20
	return					;21,22
end32x: 
	clrf	STATE			;18	reset STATE for next preamble
	clrf	ENDVAL			;19
	clrf	DATA4			;20
	clrf	DATA5			;21
	clrf	DATA6			;22
	goto	decode			;23,24	no need here for precise cycle counting, because we decode now
				; end41 end of forth byte there must be a one if last byte, or 0 if more
				; end41 first half bit. end42 second half bit
; end41: is the same as end31:, so use end31:
end42:	
	movf	DATA6,W			;12
	movwf	DATA4			;13
	btfsc	CONFIG0,bitrec	;14	if 0 other bytes will follow
	goto	end42x			;15,16 not zero so prepare to decode
	movwf	STATE			;17
	bsf	FLAG,FourByte		;18	Indicate that four or more bytes have been decoded
	nop						;19
	nop						;20
	return					;21,22
end42x: 
	clrf	STATE			;17	reset STATE for next preamble
	clrf	ENDVAL			;18
	clrf	DATA5			;19
	clrf	DATA6			;20
	bsf	FLAG,FourByte		;21	Indicate that four bytes have been decoded
	goto	decode			;22,23	no need to count, because we decode now
				; end51 end of fifth byte there must be a one if last byte, or 0 if more
				; end51 first half bit. end52 second half bit
; end51: is the same as end31:, so use end31:
end52:	
	movf	DATA6,W			;13
	movwf	DATA5			;14
	goto	end52x			;16,17 not zero so prepare to decode
	movwf	STATE			;18
	nop						;19
	nop						;20
	return					;21,22
end52x: 
	clrf	ENDVAL			;19
	clrf	DATA6			;20
				; end61 end of sixth byte there must be a one since last byte
				; end61 first half bit. end62 second half bit
end61:	
	btfss	CONFIG0,bitrec	;13
	goto	frameerr		;14,15 first half bit is not one
	incf	STATE,F			;15
	incf	ENDVAL,F		;16
	nop						;17
	nop						;18
	nop						;19
	nop						;20
	return					;21,22
end62:
	btfss	CONFIG0,bitrec	;13	test correct ending
	goto	frameerr		;14,15 second half bit is not one
	clrf	STATE			;15	reset STATE for next preamble
	clrf	ENDVAL			;16
	goto	decode			;17,18	no need to count, because we decode now
				; Frame error in packet
frameerr:
	movlw	nopreamb
	movwf	PRECOUNT
	clrf	STATE
	clrf	ENDVAL
	clrf	DATA1
	clrf	DATA2
	clrf	DATA3
	clrf	DATA4
	clrf	DATA5
	clrf	DATA6
	clrf	SAMPLES
; clear packet status bits in CONFIG0 Byte
	bcf	CONFIG0,bitrec
	bcf	CONFIG0,CVaccessBit
	bcf	CONFIG0,rev_bit
;	movlw	b'11111000'		; Old code here
;	andwf	CONFIG0,F
	return
;************* DECODING *******************************
decode:
	movf	DATA1,W		; Exclusive or check
	xorwf	DATA2,W
	xorwf	DATA3,W
	xorwf	DATA4,W
	xorwf	DATA5,W
	xorwf	DATA6,W
	btfss	STATUS,Z
	goto	exit_bank1	; error in packet
chkconsist:
	bcf	CONFIG0,cst_mode
	movlw	.19			; Read CV19
	call	EEPROM_READ
	movwf	TEMP
	andlw	B'01111111'
;	iorlw	0			<- implied!
	btfsc	STATUS,Z
	goto	chkadr		; no consist address set in CV19
	bsf	CONFIG0,cst_mode; Consist address is active in CV19
	bsf	CONFIG0,cst_rev
	btfss	TEMP,7		; reverse mode?
	bcf	CONFIG0,cst_rev
	xorwf	DATA1,W
	btfss	STATUS,Z
	goto	chkadr		; Not consist, so check as baseline
	bsf	CONFIG0,cst_adr	; valid consist address
	goto	decode_1	; Decode packet as consist
chkadr:
	movlw	.112
	subwf	DATA1,W
	btfss	STATUS,C	; Less than 112 is a normal short address
	goto	chknormal
	movlw	.128
	subwf	DATA1,W
	btfss	STATUS,C	; Greater than 127 is a long address or accessory
	goto	check_sm	; 112-127 is short address but could be service mode
	movlw	B'11000000'
	andwf	DATA1,W
	xorlw	B'11000000'
	btfsc	STATUS,Z
	goto	chk_longadr	; 192 or Greater is long address
	goto	exit_bank1	; 128-191 is accessory decoder
chknormal:
	movf	DATA1,W		; Set ZERO Flag if a broadcast address
	btfsc	STATUS,Z
	goto	decode_1	; zero is valid Broadcast address
baseline:
	movlw	.1
	call	EEPROM_READ
	xorwf	DATA1,W
	btfss	STATUS,Z
	goto	exit_bank1
	bcf		CONFIG0,cst_adr	; baseline address
	btfsc	CV29,long_adr	; Is decoder using a long address?
	goto	exit_bank1		; Yes - ignore short address.
	goto	decode_1		; No - decode packet.
chk_longadr:
	btfss	CV29,long_adr	; Is decoder using a long address?
	goto	exit_bank1		; No
	btfsc	DATA1,3		; 128-191
	goto	exit_bank1
	movlw	.17			; CV17
	call	EEPROM_READ	; Get long address to compare
	xorwf	DATA1,W
	btfss	STATUS,Z
	goto	exit_bank1
	movlw	.18			; CV18
	call	EEPROM_READ
	xorwf	DATA2,W
	btfss	STATUS,Z
	goto	exit_bank1
; Shift data bytes down to take account of longer address. Decoding assumes short address
	movf	DATA3,W
	movwf	DATA2
	movf	DATA4,W
	movwf	DATA3
	movf	DATA5,W
	movwf	DATA4
; Next two probably not required because DATA6 will only contain the checksum
;	movf	DATA6,W
;	movwf	DATA5
; Decoder information originaly in DATA1, DATA2 and DATA5 no longer valid
; Command is now in DATA2, Primary data in DATA3 and extended data in DATA4 
;----- Command Decode -------------
decode_1:
	movf	DATA2,W		; Command decoding jump table
	andlw	0xE0		; Isolate command
decode1:
	xorlw	.0			; Consist (000.....)
	btfsc	STATUS,Z
	goto	ConsistGroup
	bcf	CONFIG0,resetflag
	bcf	CONFIG0,smflag
	xorlw	.64			; Speed reverse (010.....) 14/28 speedsteps
	btfsc	STATUS,Z
	goto	Speed_rev
	xorlw	.32			; Speed forward (011.....) 14/28 speedsteps
	btfsc	STATUS,Z
	goto	Speed_for
	xorlw	.224		; Function group one (100.....)
	btfsc	STATUS,Z
	goto	Function_one
	xorlw	.96			; CV access (111.....)
	btfsc	STATUS,Z
	goto	CVaccess
	xorlw	.192		; Advanced (001.....) 126 speedsteps
	btfsc	STATUS,Z
	goto	Speed_126	; Convert to 28 step command
	xorlw	.128		; Function group two (101.....)
	btfsc	STATUS,Z
	goto	Function_two
	; here by default
	goto	Function_three	; Future expansion command (110.....), F13-F28 only
EEPROM_WRITE:
; Address in W, DATA in MYEEDATA
	bsf		STATUS,RP0
;	movwf	EEADR		<- superfluous if reading first
	call	EEPROM_READ	; get previously stored value
	bcf		STATUS,RP0
	xorwf	MYEEDATA,W	; Compare with new value
	btfsc	STATUS,Z	; If zero no need to write
	return				; No need to write so return
	movf	MYEEDATA,W	; Load value to be written
	bsf		STATUS,RP0
	movwf	EEDATA
	bsf		EECON1,WREN
	movlw	0x55
	movwf	EECON2
	movlw	0xAA
	movwf	EECON2
	bsf		EECON1,WR		; Instigate write sequence
wait_ee_write:
	btfsc	EECON1,WR	; Wait for write to complete
	goto	wait_ee_write
	bcf		STATUS,RP0
	return
EEPROM_READ:
; Address in W
; return data in W
	bsf		STATUS,RP0
	movwf	EEADR
	bsf		EECON1,RD
	movf	EEDATA,W
	bcf		STATUS,RP0
	return
ReadNMRA:
	movlw	.19			; CV19 = Consist address
	call	EEPROM_READ
	movwf	CV19
	movlw	.21			; CV21 = Consist F1-F8 mapping
	call	EEPROM_READ
	movwf	CV21
	movlw	.22			; CV22 = Consist F0 and F9-F12 mapping
	call	EEPROM_READ
	movwf	CV22
	rlf		CV22,F		; Shift up a couple of bits to make it easy later
	rlf		CV22,F		; 
	movlw	.29			; CV29 = Configuration bits
	call	EEPROM_READ
	movwf	CV29
	movlw	Invert		; CV99 = output invert map
	call	EEPROM_READ
	movwf	INVERTMAP
	movlw	Flicker		; CV100 = flicker map
	call	EEPROM_READ
	movwf	FlickMASK
	goto	exit_bank1	; start sampling
;************* SERVICE MODE *******************************************
; Direct CV (4 byte):-		DATA1      DATA2      DATA3      DATA4
;							1110CCAA 0 AAAAAAAA 0 DDDDDDDD 0 EEEEEEEE 1
; Legacy modes (3 byte):-	DATA1      DATA2      DATA3     
;							1110CAAA 0 DDDDDDDD 0 EEEEEEEE 1
check_sm:
; Might need to check here for short address 112-127 and go to chk_normal
	btfss	CONFIG0,resetflag; check for SM, reset packet has to come first
	goto	chknormal
	btfss	CONFIG0,smflag	; Second SM packet
	goto	set_sm_flag
; Direct mode is four bytes, but other modes are only three (inc check byte)
; Use FLAG,FourByte=1 to indicate Direct CV mode
	btfss	FLAG,FourByte	; Direct CV Mode if set, else not enough bytes so legacy
	goto	ad_mode_write	; Go to legacy address only/register/paged mode
; Direct CV mode. This bit manipulates the data to be the same as POM (short address).
dm_mode_write:			; Drop through to Direct CV mode
	movf	DATA3,W		; Data in Byte 3
	movwf	DATA4		; now CV contents in DATA 4
	movf	DATA2,W		; CV number in Byte 2, 0=CV1
	movwf	DATA3		; Now most of CV number (all the useful bit) in DATA3
	movf	DATA1,W		; Command in Byte 1
	movwf	DATA2		; Command now in DATA2
	goto	DoCV		; Carry on as if POM
; Address only/register/paged mode. This part manipulates the data to be the same as POM.
; Losing support for modes other than Direct CV will save about 50 program words! 
ad_mode_write:
	movf	DATA2,W		; Data in byte 2
	movwf	DATA4		; Now CV contents in DATA4
	movlw	B'00001100'	; Write command for POM/Direct CV ready 
	btfss	DATA1,3		; Test that write mode is what is required
	movlw	B'00000100'	; Verify command for POM/Direct CV if not write mode
	movwf	DATA2		; Command Verify or Write now in DATA2
	movf	DATA1,W		; Get register address from command byte 
	andlw	b'00000111'	; Mask off CV address (lower 3 bits)
	movwf	DATA3		; Put CV address in DATA3 (0=CV1)
	btfsc	DATA3,2		; Test for CV1-4 or CV5-8
	goto	Not_page	; Not in the paged bank, so sort out CV29 and page register
; This bit adds on the page offset
	movlw	.0			; Lets see what is in the page register, EEPROM location 0
	call	EEPROM_READ	; Read the page register
	movwf	TEMP
	decf	TEMP,F		; Take off one from page register to get multiplier
	movlw	b'11100000'	; Check for out of range page register
	andwf	TEMP,W		; Zero result for valid page value
	btfss	STATUS,Z	; Carry on if page in range
	goto	sm_error	; Out of range so reset and don't program
	bcf		STATUS,C	; Clear carry ready for multiply
	rlf		TEMP,F		; times 2
	rlf		TEMP,W		; Times 2 again (2x2=4). Page multiplier now in top 6 bits of W
	iorwf	DATA3,F		; Data 3 should now be 0PPPPPAA, or CV address, 0=CV1
Not_page:	; W contains CV address 100-111, CV29,page register,CV7 and CV8
	btfsc	DATA3,1		; Test for CV29/page register or CV7-8
	goto	DoCV		; 11X, CV7 or 8, Carry on as if POM
	btfsc	DATA3,0		; Test for CV29 or page register
	goto	Set_page	; 101, set page register
	movlw	.28			; CV29 POM address = 28
	movwf	DATA3		
Set_page
; Bit of a fudge here, set page register manually then refresh CV127 as a dummy.
; Write of CV127 will generate all the acknowledgement and stuff
	movf	DATA4,W		; Get value that needs to go into the page register
	movwf	MYEEDATA	; Load EEPROM with page value
	movlw	0			; EEPROM 0 is page register
	call	EEPROM_WRITE	; write page register
	movlw	.126
	movlw	DATA3		; Set DATA3 to CV127 address
	movlw	.127
	call	EEPROM_READ	; Read CV127 so it can be rewritten!
	movwf	DATA4		; Put CV127 contents into DATA4
	goto	DoCV		; Carry on and write CV127 as if POM. Page register already written!
;******************CV Access group*******************************
; Routine for 'Operations mode' or 'Programming on the main' and 'Direct CV' modes
; all modes converted to be compatible with short address POM for DoCV routine
;POM (short address) :-	DATA1      DATA2      DATA3      DATA4      DATA5
;						0aaaaaaa 0 1110CCAA 0 AAAAAAAA 0 DDDDDDDD 0 EEEEEEEE 1
;POM (long address) :-	DATA1      DATA2      DATA3      DATA4      DATA5      DATA6
;						11aaaaaa 0 aaaaaaaa 0 1110CCAA 0 AAAAAAAA 0 DDDDDDDD 0 EEEEEEEE 1
; The CV address is 1 less than the CV number so address 00 00000000 = CV1
; CC Field, 11=Write, 01=Verify, 10=Bit manipulation (not yet tested)
; a=decoder address, A=CV address, D=CV contents, E=checksum
; For bit manipulation the DDDDDDDD field is broken up into 111KDBBB where D is the
; bit value, BBB is the bit position within the CV, K=1 means write, K=0 means verify
CVaccess:
	btfss	CONFIG0,cst_mode	; chk if baseline address ok
	goto	CVaccess1
	btfsc	CONFIG0,cst_adr		; if consist adr then no POM CVaccess
	goto	exit_bank1
CVaccess1:
	btfsc	CONFIG0,CVaccessBit	; second packet received ?
	goto	DoCV
	bsf	CONFIG0,CVaccessBit
	goto	exit_bank1	
DoCV:
Test_CV:
; LokMaus2 support mode here getting value from 71 that was written to CV7
; Process is to write hundreds columns to CV7 then use tens and units to write CV
;            CV7 = Hh                   <- First write
;       CV No = HTU    htu = CV value
;        CV No = TU     tu = Value      <- Second write
; This will result in value htu being put in CV HTU
; Bit values in EEPROM 71 (hex 47) indicate the following:-
;	0 (1) = 1,  Add 100 to CV contents
;	1 (2) = 1,  Add 200 to CV contents if bit 3 = 0 (02 or 22 programmed to CV7)
;	2 (4) = 1,  Add 200 to CV contents if bit 3 = 1 (12 programmed to CV7)
;	3 (8) = 1,  Add 100 to CV number
;	4 (16) = 1, Add 200 to CV number
; Subtracting 2 from EEPROM 71 if bit 3 = 1 simplifies things as follows:-
;	2 (4) = 1,  ignore
; Get CV7 value from EEPROM 71, and subtract 2 if required
	movlw	LokMaus2		; Read CV7 saved value
	call	EEPROM_READ		; Get current contents
	movwf	TEMP			; Save CV7 contents into TEMP
	movlw	.2				; Get 2 ready in case it neads to be subtracted
	btfsc	TEMP,3			; Test for 1x
	subwf	TEMP,F			; Take away 2 to leave bit 1 free of tens column
; Add digits from CV 7 to CV number and value
	movf	DATA4,W			; Get CV value
	btfsc	TEMP,0			; Test for x1
	addlw	.100			; Add 100 to CV value
	btfsc	TEMP,1			; Test for x2
	addlw	.200			; Add 200 to CV value
	movwf	DATA4			; Save modified value
	movf	DATA3,W			; Get CV number
	addlw	.100			; Add 100 to CV number
; Only CV1-127 currently supported, so 2xx will be out of range.
;	btfsc	TEMP,4			; Test for 2x
;	addlw	.200			; Add 200 to CV number
	movwf	DATA3			; Save modified CV number
	clrf	MYEEDATA		; Clear location 'CV7'
	movlw	LokMaus2		; EEPROM CV7 saved location
	call	EEPROM_WRITE	; Write location 'CV7'
	movf	DATA2,W			; Load top two bits
	andlw	B'00000011'		; Mask off from instruction
	btfss	STATUS,Z		; check that they are both zero
	goto	exit_bank1		; CV is above CV256 if non zero
	movf	DATA3,W			; load lowest 8 bits of CV address
	movwf	TEMP
	incfsz	TEMP,F			; Address 0 is CV1 so increase to get CV and EEPROM number
	btfsc	TEMP,7			; Valid CV for this decoder is CV1-127
	goto	exit_bank1		; CV is above 127
	movf	DATA2,W
	andlw	B'00001100'
	xorlw	B'00001100'		; CC=11=Write 
	btfsc	STATUS,Z
	goto	Legacy_chk
	xorlw	B'00001000'		; CC=01=Verify 
	btfsc	STATUS,Z
	goto	cv_verify
	xorlw	B'00001100'		; CC=10=Bit manipulation 
	btfss	STATUS,Z
	goto	exit_bank1		; CC=00=no valid CV command
; Convert bit manipulation into standard write/verify commands
	btfss	DATA4,4		; Test that write mode is what is required
	movlw	B'00000100'	; Verify command if not
; Convert bit manipulation data field into standard CV write/verify format
	movf	DATA4,W		; Get the bit position number from the data
	andlw	b'00000111'	; Mask off all but the bit position
	movwf	TEMP1		; Store in counter
	movf	TEMP,W		; Get CV number
	call	EEPROM_READ	; Get current contents of CV
	movwf	TEMP3		; Put the current contents into TEMP3
	clrf	TEMP2
	bsf		STATUS,C	; Set a bit in the carry ready to rotate
	incf	TEMP1,F		; Zero is one bit, not zero bits!!!
Multiply:
	rlf		TEMP2,F		; Shift a bit up
	decfsz	TEMP1,F		; Is that enough shifting?
	goto	Multiply	; No
	movf	TEMP2,W		; TEMP2 now contains one bit in the correct position
	iorwf	TEMP3,F		; Set the bit in TEMP3
	xorlw	b'11111111'	; Complement the bit position (a zero now in the bit position)
	btfss	DATA4,3		; Test the bit
	andwf	TEMP3,F		; Clear the bit if it should be zero
	movf	TEMP3,W		; Get the manipulated data field
	movwf	DATA4		; And put it in DATA4 to be processed as a normal 8 bit CV value
Legacy_chk:
; Check for write to CV 1 and reset consist details in CV19 and long address in CV29 if so
	decf	TEMP,W			; Temp contains CV number. CV1-1=0
	btfss	STATUS,Z		; If zero skip to check for four bytes
	goto 	cv_prog			; Not CV1 so program
; Not sure if we should be checking for POM/Direct mode, and just resetting consist anyway
;	btfsc	FLAG,FourByte	; Check for four bytes (CV direct or POM)
;	goto 	cv_prog			; Four bytes so just program
; Need to put this in a subroutine as part of Consist group
	clrf	MYEEDATA		; Put zero in consist address
	movlw	.19				; CV19 = consist address
	call	EEPROM_WRITE	; write CV19
	movlw	.29				; Need to reset consist active bit in CV29
	call	EEPROM_READ		; Get current contents of CV29
	movwf	MYEEDATA		;
	bcf		MYEEDATA,5		; Clear long address enable bit
	movlw	.29				; CV29 = configuration CV
	call	EEPROM_WRITE	; write CV29
cv_prog:
; Check decoder lock here before writing
; CV number in TEMP, CV value in DATA4
	movlw	.1				; Check for CV1
	xorwf	TEMP,W			; Compare CV number with 1
	btfsc	STATUS,Z		; Not CV1 so check next
	goto	Write_OK		; CV1 so write even if locked
	movlw	.15				; Check for CV15
	xorwf	TEMP,W			; Compare CV number with 15
	btfsc	STATUS,Z		; Not CV15 so check next
	goto	Write_OK		; CV15 so write even if locked
	movlw	.15				; Get CV15 for comparison
	call	EEPROM_READ		; CV15 now in W
	movwf	TEMP2			; Store contents of CV15
	xorlw	.255			; Check for 'broadcast' value
	btfsc	STATUS,Z		; CV15 not 255 so check next
	goto	Write_OK		; CV15 255 so write even if locked
	movlw	.16				; Get CV16 to compare
	call	EEPROM_READ		; CV16 now in W
	xorwf	TEMP2, W		; Compare CV15 and CV16 contents
	btfss	STATUS,Z		; CV15 and CV16 are equal, so write
	goto	exit_bank1		; Not equal so exit without writing
Write_OK:
	movf	DATA4,W			; value in DATA4
	movwf	MYEEDATA
	movf	TEMP,W			; CV number held in TEMP
; Check for CV7 write for LokMaus2 mode
	xorlw	.7
	movlw	LokMaus2		; Get CV7 save location ready
	btfsc	STATUS,Z		; If CV7, use CV7 save location
	movwf	TEMP			; =7 so store 'CV7' value instead
; Check for CV29 write, must not allow illegal bits to be set
;	movf	TEMP,W			; CV number held in TEMP
	xorlw	.29
	movlw	b'00000111'		; Get mask ready 
	btfsc	STATUS,Z		; Is it CV 29?
	andwf	MYEEDATA,F		; Yes, so clear unsuppored bits.
;	goto	acknowledge		; Why not load CV number, drop through and auto verify?
cv_verify:
	call	EEPROM_READ
	xorwf	DATA4,W
	btfss	STATUS,Z		; equal then ACK
	goto	exit_bank1		; not equal exit
; Need to add pin 6/11(/5 on 8-pin) acknowledgement only pin here.
acknowledge:
	movlw	0xFF
  ifndef __16F648A
	movwf	GPIO	; Turn outputs A,B and D on at least
	movwf	PORTC	; Turn on the rest as well
  else
	movwf	PORTB
  endif
	clrf	TEMP1
	movlw	AckTime		; acktime in ms can be set in *.h file
	movwf	TEMP
loop_ack1:
	decfsz	TEMP1,F
	goto	loop_ack1
	decfsz	TEMP,F
	goto	loop_ack1
  ifndef __16F648A
	clrf	GPIO	; turn off
	clrf	PORTC
  else
	clrf	PORTB
  endif
exit_cv:
	bcf	CONFIG0,smflag	; clear SM mode in case
	goto	ReadNMRA
set_sm_flag:
	bsf		CONFIG0,smflag
	goto	exit_bank1
sm_error:
	bcf		CONFIG0,smflag
	goto	exit_bank1
;*********************** SPEED COMMAND GROUP *********************************************
; 126 step :-		DATA1      DATA2      DATA3      DATA4
; (short address)	0aaaaaaa 0 00111111 0 DSSSSSSS 0 EEEEEEEE 1
; 126 step :-		DATA1      DATA2      DATA3      DATA4      DATA5
; (long address) 	11aaaaaa 0 aaaaaaaa 0 00111111 0 DSSSSSSS 0 EEEEEEEE 1
; 28 step :-		DATA1      DATA2      DATA3
; (short address)	0aaaaaaa 0 01DSSSSS 0 EEEEEEEE 1
; 28 step :-		DATA1      DATA2      DATA3      DATA4
; (long address) 	11aaaaaa 0 aaaaaaaa 0 01DSSSSS 0 EEEEEEEE 1
; 14 step :-		DATA1      DATA2      DATA3
; (short address)	0aaaaaaa 0 01DLSSSS 0 EEEEEEEE 1
; 14 step :-		DATA1      DATA2      DATA3      DATA4 
; (long address) 	11aaaaaa 0 aaaaaaaa 0 01DLSSSS 0 EEEEEEEE 1
; Where a=loco address, D=direction, S=speed information, L=Function 0
; Bit order for 28 step mode SSSSS = 04321, for 14 step SSSS = 3210
Speed_126:
; This bit converts a 126 step speed command to be the same as a 28 step command
	movf	DATA2,W		; Get command
	xorlw	b'00111111'	; Check for 128 speedstep command
	btfss	STATUS,Z	; Is it a 128 speedstep command?
	goto	exit_bank1	; No, it is not. No other commands in this group supported.
	rlf		DATA3,W		; Shift direction bit into C, without shifting DATA3
	rrf		DATA3,F		; Shift speed bits down and shift direction into MSb
	bsf		STATUS,C	; Set middle instruction bit
	rrf		DATA3,F		; Shift it in
	bcf		STATUS,C	; Clear left instruction bit
	rrf		DATA3,F		; Shift it in, and shift LSb into C
	bsf		DATA3,4		; Set LSb in 28 speedstep instruction
	btfss	STATUS,C	; Check LSb in C, is it set?
	bcf		DATA3,4		; No, clear LSb in 28 speedstep instruction
	movf	DATA3,W		; Move newly constructed instruction from DATA3	
	movwf	DATA2		; To DATA2.
	btfsc	DATA2,5		; Check direction, is it forward?
	goto	Speed_for	; Yes, do 28 step forward	
;	goto	Speed_rev	; No, do 28 step reverse.  <- implied goto
; This bit works out from the supplied direction command and configuration bits
; which direction the loco should currently be going physicaly. Result is stored
; in FLAG:1, 1=reverse, 0=forwards
; Important to ignore commands to baseline address when consist is active for
; this group. Test is CONFIG0,cst_adr=0 and CONFIG0,cst_mode=1
Speed_rev:			; Controller says go in reverse
; Only need to accept commands from baseline address if consist mode not set
	btfss	CONFIG0,cst_mode	; Is a consist address set?
	goto	Speed_rev_chk		; No, address must be baseline OK
								; Yes so test for consist address
	btfss	CONFIG0,cst_adr		; Is the address baseline?
	goto	exit_bank1			; Yes, address was baseline so ignore
								; No, address was consist OK
Speed_rev_chk:
	btfsc	CONFIG0,cst_rev
	goto	Speed_for_cst
Speed_rev_cst:
	bcf	CONFIG0,rev_bit
	btfsc	CV29,norm_rev		; Normal or reverse operation ?
	goto	Sp_for1
Sp_rev1:
	bsf		FLAG,rev_mode		; Set flag for reverse mode
	goto	Check14
Speed_for:			; Controller says go forwards
	goto	Speed_for_chk		; No, address must be baseline OK
Speed_for_chk:
	goto	Speed_rev_cst
Speed_for_cst:
	bcf	CONFIG0,rev_bit
	goto	Sp_rev1
Sp_for1:
	bcf		FLAG,rev_mode		; Clear flag, forward mode
;	goto	Check14				; <- implied
Check14:
; routine if 14 step mode active.
	btfss	CV29,fl_control	; Check CV29 bit 1. 28/128 ?
	call	Function_zero	; No, Function 0 controlled by speed group
	goto	Function_activate
Function_one:			; Function group one (F0-F4)
	movfw	CV21			; Get function consist status
	andlw	b'00001111'		; Mask off leaving consist mask for just F1-F4
	btfss	CONFIG0,cst_adr	; Check for using consist address, skip if consist
	xorlw	b'00001111'		; Invert mask to get non consist mask
	movwf	FnMASK			; Save mask for F1 to F4
	btfss	CONFIG0,cst_mode	; check if consist is currently active
	clrf	FnMASK			; consist not active so do all functions anyway
	movlw	F1_base				; Set CV base, F1=CV35,F2=CV36,F3=CV37,F4=CV38
	call	Function_block
; Function 0 is a special case that cannot be handled by the subroutine
	btfsc	CV29,fl_control	; Check CV29 bit 1. 28/128 ?
	call	Function_zero	; Yes, Function 0 controlled by function group 1
	goto	exit_bank1
Function_two:		; Function group two (F5-F12)
	btfss	DATA2,4			; Test for 5-8 or 9-12
	goto	Function_nine	; Bit is not set so do 9-12
							; Bit is set so drop through to 5-8
; Function 5-8
	swapf	CV21,W			; Get F5-F8 consist status into lower 4 bits
	andlw	b'00001111'		; Mask off leaving consist mask for just F5-F8
	movwf	FnMASK			; Save mask for F5-F8
	movlw	F5_base				; Set CV base, F5=CV39,F6=CV40,F7=CV41,F8=CV42
	call	Function_block
	goto	exit_bank1
; Function 9-12
Function_nine:
	swapf	CV22,W			; Get F9-F12 consist status in lower 4 bits
	andlw	b'00001111'		; Mask off leaving consist mask for just F9-F12
	movwf	FnMASK			; Save mask for F9 to F12
	movlw	F9_base				; Set CV base, F9=CV43,F10=CV44,F11=CV45,F12=CV46
	call	Function_block
	goto	exit_bank1
; Function group three (F13-F28)
; Command is in the form of:-
;			DATA2      DATA3
;			1101111A 0 FFFFFFFF
; Where A is 0 for F13-20 and 1 for F21-28, F is a function state bit
Function_three:
	clrf	FnMASK			; assume not consist address so do all functions
	btfsc	CONFIG0,cst_adr	; check if consist address
	decf	FnMASK,F		; consist so set to all 1 to disable all functions 
	movf	DATA2,W		; Get instruction
	andlw	b'11111110'	; mask off valid bits
	xorlw	b'11011110'	; Zero if a valid F13-F28 instruction
	btfss	STATUS,Z	; Is it F13-F28?
	goto	exit_bank1	; No, it is a currently unsupported bit command then
	btfsc	DATA2,0		; Is it F21-F28?
	goto	Function_21	; Yes, do F21-F28
						; No, do F13-F20
	movf	DATA3,W		; Need to move function bits into DATA2
	movwf	DATA2
	movlw	F13_base	; Get base CV for F13-F16
	call	Function_block
	swapf	DATA2,F		; Move the other four functions into the lower four bits
	movlw	F17_base	; Get base CV for F17-F20
	call	Function_block
	goto	exit_bank1
Function_21:
	movwf	DATA2
	movlw	F21_base	; Get base CV for F21-F24
	call	Function_block
	movlw	F25_base	; Get base CV for F25-F28
	call	Function_block	; 
	goto	exit_bank1
; Function block subroutine. This is used for each block of four functions 1-4, 5-8 and 9-12.
; Input is just the CV base in W. The function control, is in the lower four bits of DATA2
;		DATA2
;		xxxxFFFF
; Where F is a function control bit. The lowest numbered function has the lowest bit value
; For functions 13-28 the data will have to be put into the same format as above in blocks
; of four functions from the format below and processed four bits at a time by swapping nibbles.
;		DATA3
;		FFFFFFFF
Function_block:
	movwf	TEMP		; Store CV base in TEMP
Do_Function:
	bcf	CONFIG0,CVaccessBit	; clear CVaccess flag
; Function 1,5,9,13,17,21,25
	btfsc	FnMASK,0	; Check that we should be doing this function
	goto	End_Fn1		; Set so skip
	movf	TEMP,W		; Get CV number ready to read
	call	EEPROM_READ	; Read map for Function 1
	iorwf	FnSTATE, F	; Set mapped output on
	btfsc	DATA2,0		; Jump to end and leave F1 set if function active
	goto	End_Fn1
	xorlw	0xFF		; Invert map
	andwf	FnSTATE, F	; Leave non mapped outputs and clear mapped
End_Fn1
; Function 2,6,10,14,18,22,26
	incf	TEMP,F		; Move on to next CV
	btfsc	FnMASK,1	; Check that we should be doing this function
	goto	End_Fn2
	call	EEPROM_READ	; Read map for Function 2
	btfsc	DATA2,1		; Jump to end and leave F2 set if function active
	goto	End_Fn2
End_Fn2
; Function 3,7,11,15,19,23,27
	btfsc	FnMASK,2	; Check that we should be doing this function
	goto	End_Fn3
	call	EEPROM_READ	; Read map for Function 3
	btfsc	DATA2,2		; Jump to end and leave F3 set if function active
	goto	End_Fn3
End_Fn3
; Function 4,8,12,16,20,24,28
	incf	TEMP,W		; Move on to next CV and get CV number ready to read
	btfsc	FnMASK,3	; Check that we should be doing this function
	goto	End_Fn4
	btfsc	DATA2,3		; Jump to end and leave F4 set if function active
	goto	End_Fn4
End_Fn4
	return				; Job done
; DATA2 bit 4 contains the state of function 0, either from speed command (14 bit)
; or function command (28/128 bit)
; FLAG,rev_mode contains the direction data, 1=reverse
; In practice Function 0 is two seperate functions, one forward and one reverse.
Function_zero:
;Set up activation mask
	movf	CV22,W			; Get F0 consist status in bits 2 and 3
	andlw	b'00001100'		; Mask off leaving consist mask for just F0
	xorlw	b'00001100'		; Invert mask to get non consist mask
	movwf	FnMASK			; Save mask for F0
; Function 0 forwards
	goto	End_fwd		; Set so don't do
	movlw	F0_base		; Function 0 Forwards mapping CV
	call	EEPROM_READ	; Read map for Function 0 forwards
	btfsc	DATA2,4		; Jump to end if F0 inactive, leave function off
	btfsc	FLAG,rev_mode	; Jump to end if reverse selected , leave function off
	goto	End_fwd
	xorlw	0xFF		; Invert map again
End_fwd:
; Function 0 reverse
	goto	End_rev
	movlw	(F0_base + F0_revoffset)	; Function 0 Backwards mapping
	call	EEPROM_READ	; Read map for Function 0 backwards
	btfss	FLAG,rev_mode	; Jump to end if forward selected , leave function off
	goto	End_rev
End_rev:
	return				; Done
Function_activate:
; FnSTATE now contains the the active state of outputs A to H.
; Invert according to CV
	movf	INVERTMAP,W	; Get invert map
	xorwf	FnSTATE, W	; Invert required bits of function state and leave in W
  ifdef __16F648A
	movwf	PORTB
  else
	movwf	PORTC		; Put outputs C-H on Port C, C=PC5,D=PC4,E=PC3,F=PC2,G=PC1,H=PC0
	movwf	TEMP		; Store state ready for shifting
	rrf		TEMP, F		; Shift outputs A-H down one (H into carry)
	rrf		TEMP, W		; Shift outputs A-H down another one (G into carry)
	movwf	GPIO		; stick outputs A-F on GPIO, A=GP5,B=GP4,C=GP2,E=GP1,F=GP0
  endif
	return
				; Consist Group
; Decoder reset apears as a consist group instruction to the broadcast address
; I think that this bit may contain errors!
ConsistGroup:
	movf	DATA2,W
	xorlw	.0			; Service mode decoder reset instruction 00000000 
	btfsc	STATUS,Z
	goto	soft_reset	;
	xorlw	.1			; service mode hard reset instruction 00000001
	btfsc	STATUS,Z
	goto	hard_reset	; Set CV29 to default and clear CV19.
; Check here for setting/reseting of CV29 bit 5 using SM inst. 0000101x
	andlw	B'11111110'
	xorlw	B'00001010'	; Service mode set advanced addressing instruction 0000101x
	btfsc	STATUS,Z
	goto	long_adr_set
; Start checking for consist instructions.
; 0001001x where x is the direction of travel relative to the consist (CV19 bit 7)
	movf	DATA2,W
	andlw	B'11111110'
	xorlw	B'00010010'
	btfsc	STATUS,Z
	goto	cst_ctrl_set
	goto	exit_bank1
hard_reset:
; Perform NMRA service mode Hard Reset
	clrf	MYEEDATA	; no consist
	movlw	.19			; get EEPROM location of CV19
	call	EEPROM_WRITE
	movlw	cv29default	; CV29	
	movwf	MYEEDATA
	movlw	.29		; get EEPROM location of CV29
	call	EEPROM_WRITE
; reset CV31 and CV32 here as well if implemented.
soft_reset:
; Service mode reset packet received, so prepare for service mode
	bsf	CONFIG0,resetflag	; set resetflag for SM mode detection
; Decoder will now respond to address 112-127 as service mode packets
; Make sure that all function outputs are inactive
	clrf	FnSTATE			; Turn all functions off
	goto	ReadNMRA
; Set consist address and direction in CV19
cst_ctrl_set:
	bsf		DATA3,7
	btfss	DATA2,0
	bcf		DATA3,7
	movf	DATA3,W
	movwf	MYEEDATA
	movlw	.19
	call	EEPROM_WRITE
	goto	exit_bank1
; Set/reset bit in CV29 for long addressing 
long_adr_set:
	movlw	.29
	call	EEPROM_READ	; Get CV29 contents
	movwf	MYEEDATA	; Put in buffer
	bsf		MYEEDATA,5	; Set bit
	btfss	DATA2,0		; Check bit
	bcf		MYEEDATA,5	; Clear bit if it should not be set
	movlw	.29
	call	EEPROM_WRITE; Rewrite CV29
;	goto	exit_bank1	<- implied goto
exit_bank1:
	clrf	TIMEOUTCOUNT	; ANALOG watchdog
	clrf	TEMP
	clrf	DATA1
	clrf	DATA2
	clrf	DATA3
	clrf	DATA4
	clrf	DATA5
	clrf	DATA6
	clrf	ENDVAL
	return
; Speed subroutine replaces speed macros to save space
; Need to replace this with routine to manage exotic function output.
; Timing is critical, enters on step 5 and should exit with last step of return step 20
; which makes only 7 instructions per pass for correct timing. Stretching to 9 will match
; current routine which appears to work.
Speed_Sub
	incf	SAMPLES,F	;5
	bcf	CONFIG0,bitrec	;6
	movlw	0xFD		;7
	addwf	SAMPLES,W	;8
	btfss	STATUS,C	;9
	bsf	CONFIG0,bitrec	;10
	decfsz	COUNTER,F	;11
	Goto	Do_Flicker	;12,13 Update random number generator
	movf	FnSTATE,W	;13	Get function state
	btfss	RANDOM,7	;14	Test random bit
	andwf	FlickMASK,W	;15	Bit clear, so switch off flicker outputs
	xorwf	INVERTMAP,W	;16 Invert required bits of function state and leave in W
  ifdef __16F648A
	movwf	PORTB
  else
	movwf	PORTC		;17 Put outputs C-H on Port C, C=PC5,(D=PC4),E=PC3,F=PC2,G=PC1,H=PC0
  endif
	decfsz	TIMEOUTCOUNT,F	;18	For ANALOG mode. Timeoutcount is cleared in state machine.
	return				;19,20 timeout not expired, so carry on receiving bits
	goto	ANALOG		;20,21 Timeout expired so do analogue timing not critical <= implied goto
Do_Flicker:
; Randomisation routine
	movlw	01DH		;14 Load prime number
	clrc				;15 Clear carry ready for shift
	rlf		RANDOM,F	;16
	btfsc	STATUS,C	;17
	xorwf	RANDOM,F	;18
; Random bit supplied in RANDOM,7 
	return				;19,20
; Analogue routine here. Came here because no valid DCC signal detected
; Need to look at DC behaviour from CV. Normal to support Brake On DC
; or analogue operation but not both
ANALOG:
	btfss	CV29,DCmode	; DC analogue or brake on DC supported?
	return				; Clear, so carry on as normal and wait for a valid packet
						; Set, analogue enabled so must be running on a DC layout.
; Need to turn Functions 1-12 on according to CV13/CV14 values
; and operate F0 according to DC polarity if true analogue mode.
	movlw	.13		; CV13 will contain analogue group 1 active functions 1-8
	call	EEPROM_READ
	movwf	DATA2		; Hold analogue function status in DATA2
	movlw	F1_base		; Start with CV35 for F1 mapping
	call	Function_block
	movlw	F5_base 	; Get base CV for F5-8
	call	Function_block
	movlw	.14	; CV14 will contain analogue group 2 active functions 9-12 and F0
	call	EEPROM_READ
	movwf	CV14		; Store CV14 for later
	movwf	DATA2		; Put analogue function status in DATA2
	rrf		DATA2,W		; Shift F9-F12 into lower four bits
	rrf		DATA2,W		; 
	movlw	F9_base		; Get base CV for F9-12
	call	Function_block
; Do F0 here according to track polarity. Track polarity can only be accuratly
; measured in comparator mode so no Function 0 support for PA3 mode.
Alog_Chg:
	bsf		FLAG,rev_mode	; Set forwards
	btfss	CMCON,C2OUT	; Are we going forwards on DC?
	bcf		FLAG,rev_mode	; No, set reverse
	bcf		DATA2,4			; Set function 0 off
	btfsc	FLAG,rev_mode	; Going forwards?
	goto 	Alog_Rev		; No, so do reverse
	btfsc	CV14,0			; F0 forwards enabled on DC?
	bsf		DATA2,4			; Yes, set function 0 on
	goto	Alog_Act
Alog_Rev:
	btfsc	CV14,1			; F0 reverse enabled on DC?
Alog_Act:
	call	Function_zero	; Do F0 forwards and F0 backwards
DC_Analogue:
; Put support for exotic functions on analogue in here
	clrw					; Set zero flag
	btfsc	CMCON,C2OUT	; Test the comparator output
	xorlw	0xff			; Clear zero flag
	btfsc	FLAG,rev_mode	; Are we going in reverse?
	xorlw	0xff			; Toggle zero flag
	btfsc	STATUS,Z		; Test for 0 (0=same)
	goto 	DC_Analogue		; Same so test again
	goto 	Alog_Chg		; Different so change direction
	org	0x2108	; Make sure that CV8=255 to force load of EEPROM to defaults on first boot
	DW	.255	; CV8=255
	END
