cmake_minimum_required(VERSION 3.12)
include(pico_sdk_import.cmake)
set(CMAKE_C_STANDARD 11)
add_compile_options(-Wall -Werror -fdata-sections -ffunction-sections)
add_compile_options($<$<COMPILE_LANGUAGE:CXX>:-fno-rtti>)
add_compile_options($<$<COMPILE_LANGUAGE:CXX>:-fno-exceptions>)
project(picorx)
pico_sdk_init()
file(GLOB U8G2_SRCS
     "external/u8g2/csrc/*.c"
include_directories(include external/u8g2/csrc/)
add_library(
    u8g2
    ${U8G2_SRCS}
target_compile_options(u8g2 PRIVATE -Wno-unused-function -Wno-unused-variable)
if(PICO_BOARD STREQUAL "pico")
  #main application
  add_executable(picorx
      ssd1306.c
      picorx.cpp
      nco.cpp
      rx.cpp
      rx_dsp.cpp
      fft.cpp
      fft_filter.cpp
      cic_corrections.cpp
      ui.cpp
      utils.cpp
      ili934x.cpp
      waterfall.cpp
      button.cpp
      cat.cpp
      usb_descriptors.c
      usb_audio_device.c
      ring_buffer_lib.c
  pico_generate_pio_header(picorx ${CMAKE_CURRENT_LIST_DIR}/nco.pio)
  pico_generate_pio_header(picorx ${CMAKE_CURRENT_LIST_DIR}/quadrature_encoder.pio)
  pico_add_extra_outputs(picorx)
  # enable usb output, disable uart output
  pico_enable_stdio_usb(picorx 1)
  pico_enable_stdio_uart(picorx 0)
  target_include_directories(picorx PRIVATE ${CMAKE_CURRENT_LIST_DIR})
  target_link_libraries(picorx PRIVATE pico_stdlib
                                       pico_multicore
                                       hardware_clocks
                                       hardware_flash
                                       hardware_pio
                                       hardware_adc
                                       hardware_pwm
                                       hardware_dma
                                       hardware_i2c
                                       hardware_spi
                                       tinyusb_device
                                       tinyusb_board
                                       u8g2)
  target_compile_definitions(picorx PUBLIC PICO_XOSC_STARTUP_DELAY_MULTIPLIER=128)
  #battery check utility
  project(battery_check)
  add_executable(battery_check
      battery_check.cpp
  pico_add_extra_outputs(battery_check)
  pico_enable_stdio_usb(battery_check 1)
  pico_enable_stdio_uart(battery_check 0)
  target_link_libraries(battery_check pico_stdlib hardware_adc)
elseif(PICO_BOARD STREQUAL "pico2")
  if(PICO_PLATFORM STREQUAL "rp2350-riscv")
    #main application
    add_executable(pico2rx-riscv
      ssd1306.c
      picorx.cpp
      nco.cpp
      rx.cpp
      rx_dsp.cpp
      fft.cpp
      fft_filter.cpp
      cic_corrections.cpp
      ui.cpp
      utils.cpp
      ili934x.cpp
      waterfall.cpp
      button.cpp
      cat.cpp
      usb_descriptors.c
      usb_audio_device.c
      ring_buffer_lib.c
    pico_generate_pio_header(pico2rx-riscv ${CMAKE_CURRENT_LIST_DIR}/nco.pio)
    pico_generate_pio_header(pico2rx-riscv ${CMAKE_CURRENT_LIST_DIR}/quadrature_encoder.pio)
    pico_add_extra_outputs(pico2rx-riscv)
    pico_enable_stdio_usb(pico2rx-riscv 1)
    pico_enable_stdio_uart(pico2rx-riscv 0)
    target_include_directories(pico2rx-riscv PRIVATE ${CMAKE_CURRENT_LIST_DIR})
    target_link_libraries(pico2rx-riscv PRIVATE pico_stdlib
                                         pico_multicore
                                         hardware_clocks
                                         hardware_flash
                                         hardware_pio
                                         hardware_adc
                                         hardware_pwm
                                         hardware_dma
                                         hardware_i2c
                                         hardware_spi
                                         tinyusb_device
                                         tinyusb_board
                                         u8g2)
    target_compile_definitions(pico2rx-riscv PUBLIC PICO_XOSC_STARTUP_DELAY_MULTIPLIER=128)
    project(battery_check_pico2-riscv)
    add_executable(battery_check_pico2-riscv
        battery_check.cpp
    pico_add_extra_outputs(battery_check_pico2-riscv)
    pico_enable_stdio_usb(battery_check_pico2-riscv 1)
    pico_enable_stdio_uart(battery_check_pico2-riscv 0)
    target_link_libraries(battery_check_pico2-riscv pico_stdlib hardware_adc)
  else()
    #main application
      ssd1306.c
      picorx.cpp
      nco.cpp
      rx.cpp
      rx_dsp.cpp
      fft.cpp
      fft_filter.cpp
      cic_corrections.cpp
      ui.cpp
      utils.cpp
      ili934x.cpp
      waterfall.cpp
      button.cpp
      cat.cpp
      usb_descriptors.c
      usb_audio_device.c
      ring_buffer_lib.c
    pico_generate_pio_header(pico2rx ${CMAKE_CURRENT_LIST_DIR}/nco.pio)
    pico_generate_pio_header(pico2rx ${CMAKE_CURRENT_LIST_DIR}/quadrature_encoder.pio)
    pico_add_extra_outputs(pico2rx)
    pico_enable_stdio_usb(pico2rx 1)
    pico_enable_stdio_uart(pico2rx 0)
    target_include_directories(pico2rx PRIVATE ${CMAKE_CURRENT_LIST_DIR})
    target_link_libraries(pico2rx PRIVATE pico_stdlib
                                         pico_multicore
                                         hardware_clocks
                                         hardware_flash
                                         hardware_pio
                                         hardware_adc
                                         hardware_pwm
                                         hardware_dma
                                         hardware_i2c
                                         hardware_spi
                                         tinyusb_device
                                         tinyusb_board
                                         u8g2)
    target_compile_definitions(pico2rx PUBLIC PICO_XOSC_STARTUP_DELAY_MULTIPLIER=128)
    project(battery_check_pico2)
        battery_check.cpp
    pico_add_extra_outputs(battery_check_pico2)
    pico_enable_stdio_usb(battery_check_pico2 1)
    pico_enable_stdio_uart(battery_check_pico2 0)
    target_link_libraries(battery_check_pico2 pico_stdlib hardware_adc)
  endif()
endif()
