<root>
<document scada='0' schema='103' license='1,FREE_VERSION,DF7JCQ' title='' description='' fcversion='655618' target='PIC.16F.16F18877' >
	<config data='!0,3f8c!10,37fd!20,3f92!30,1fff!40,3fff%0,4%4,0%8,1%b,1%d,1%10,1%11,0%15,1%16,3%19,1%1a,1%1b,0%1c,1%1d,1%20,12%25,0%28,7%2b,7%30,3%3c,1%3d,0%40,1%41,1' clkspd='32000000' simspd='0' usewdt='0' constif='0' Use3V3='0' />
	<plugins />
	<supplement use='0' head='' body='' />
	<debug />
	<traces />
	<ghost >
		<FK2 >
			<data name='FK2D0' port='4294967295' pin='4294967295' />
			<data name='FK2D1' port='4294967295' pin='4294967295' />
			<data name='FK2D2' port='4294967295' pin='4294967295' />
			<data name='FK2D3' port='4294967295' pin='4294967295' />
			<data name='FK2D4' port='4294967295' pin='4294967295' />
			<data name='FK2D5' port='4294967295' pin='4294967295' />
			<data name='FK2D6' port='4294967295' pin='4294967295' />
			<data name='FK2D7' port='4294967295' pin='4294967295' />
			<data name='FK2D8' port='4294967295' pin='4294967295' />
			<data name='FK2D9' port='4294967295' pin='4294967295' />
			<data name='FK2D10' port='4294967295' pin='4294967295' />
			<data name='FK2D11' port='4294967295' pin='4294967295' />
			<data name='FK2D12' port='4294967295' pin='4294967295' />
			<data name='FK2D13' port='4294967295' pin='4294967295' />
			<data name='FK2D14' port='4294967295' pin='4294967295' />
			<data name='FK2D15' port='4294967295' pin='4294967295' />
			<data name='FK2A0' port='4294967295' pin='4294967295' />
			<data name='FK2A1' port='4294967295' pin='4294967295' />
			<data name='FK2A2' port='4294967295' pin='4294967295' />
			<data name='FK2A3' port='4294967295' pin='4294967295' />
			<data name='FK2A4' port='4294967295' pin='4294967295' />
			<data name='FK2A5' port='4294967295' pin='4294967295' />
		</FK2>
		<ICD >
			<data name='AnalogPrescaleValue' value='19' />
			<data name='DigitalSampleRate' value='100000' />
			<data name='BreakpointCount' value='8' />
			<data name='CallStackDepthCount' value='8' />
			<data name='ClockPort' value='1' />
			<data name='ClockPin' value='6' />
			<data name='DataPort' value='1' />
			<data name='DataPin' value='7' />
			<data name='UseDefaultPins' value='1' />
			<data name='WrapEnabled' value='1' />
			<data name='CommsDelayOverridden' value='0' />
			<data name='CommsDelay' value='6' />
			<data name='CalculatedCommsDelay' value='6' />
			<data name='AnalogEB2PrescaleValue' value='2' />
			<data name='DigitalEB2SampleRate' value='100000' />
		</ICD>
		<pins >
			<digital A='0' B='0' C='0' D='0' E='0' F='0' G='0' H='0' I='0' J='0' K='0' L='0' M='0' N='0' O='0' P='0' Q='0' R='0' S='0' T='0' U='0' V='0' W='0' X='0' Y='0' Z='0' />
			<analog A='0' B='0' C='0' D='0' E='0' F='0' G='0' H='0' I='0' J='0' K='0' L='0' M='0' N='0' O='0' P='0' Q='0' R='0' S='0' T='0' U='0' V='0' W='0' X='0' Y='0' Z='0' />
		</pins>
	</ghost>
	<components >
		<settings autoimg='1' center='1' unitscale='0' fixedscale='0' fixedx='1' fixedy='1' fixedz='1' headcode='0' />
		<definition guid='9c9febe3-e17a-4d2b-8546-468abe678c2e' vstate='40' vmin='0' vmaj='1' srcleaf='' visiblename='' description='' category='' category2='' category3='' bIs2dOnly='0' bIs3dOnly='0' catenable='1' author='' manuname='' manucode='' sysinfo='0' keywords='' dynamic='0' scadaCompatible='0' embeddedCompatible='1' showmacros='1' iconpath='' />
		<component class_type='root' codename='panel' panelId='-1' x='0' y='0' z='0' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' scadavisible='1' interactive='1' solid='1' layer='0' poslock='0' comp2dType='0' >
			<resources />
			<properties />
			<values />
			<events />
			<apis />
			<variables >
				<variable public='0' >
					<def class_type='variable' name='Str' type='T8' description='' isconst='0' isHidden='0' isinit='0' usrinit='&quot;&quot;' setinit='' >
						<array size='20' />
					</def>
				</variable>
					<def class_type='variable' name='false' type='b1' description='' isconst='1' isHidden='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='Sense' type='u8' description='' isconst='0' isHidden='0' isinit='0' usrinit='0' setinit='' />
				</variable>
					<def class_type='variable' name='true' type='b1' description='' isconst='1' isHidden='0' isinit='1' usrinit='1' setinit='1' />
				</variable>
			</variables>
			<macros >
				<macro >
					<flowline name='Main' description='' statediag='0' >
						<return name='Return' type='v0' description='' isconst='0' isHidden='0' isinit='0' usrinit='' setinit='' />
						<command class_type='call' title='Call Component Macro' cmdcolor='4487093' cmdcolor_sec='11066367' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='0.64' component='LCD' macro='Start' />
						<command class_type='loop' title='Loop' cmdcolor='4767473' cmdcolor_sec='11337727' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='0.64' type='0' exp='1' >
							<flowline >
								<command class_type='call' title='Call Component Macro' cmdcolor='4487093' cmdcolor_sec='11066367' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='0.64' component='DHT11' macro='SampleSensor' >
									<return exp='Sense' />
								</command>
								<command class_type='call' title='Call Component Macro' cmdcolor='4487093' cmdcolor_sec='11066367' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='0.64' component='LCD' macro='Clear' />
								<command class_type='switch' title='Switch' textarea='36,25,36,25' cmdcolor='4767473' cmdcolor_sec='11337727' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='0.64' exp='Sense' >
									<case >
										<flowline />
									</case>
									<case exp='0' >
										<flowline >
											<command class_type='call' title='Call Component Macro' cmdcolor='4487093' cmdcolor_sec='11066367' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='0.64' component='LCD' macro='PrintString' >
												<argument exp='&quot;Temp: &quot;' />
											</command>
											<command class_type='call' title='Call Component Macro' cmdcolor='4487093' cmdcolor_sec='11066367' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='0.64' component='DHT11' macro='GetTempString' >
												<return exp='Str' />
											</command>
												<argument exp='Str' />
											</command>
											<command class_type='call' title='Call Component Macro' cmdcolor='4487093' cmdcolor_sec='11066367' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='0.64' component='LCD' macro='Cursor' >
												<argument exp='0' />
												<argument exp='1' />
											</command>
												<argument exp='&quot;Humidity: &quot;' />
											</command>
											<command class_type='call' title='Call Component Macro' cmdcolor='4487093' cmdcolor_sec='11066367' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='0.64' component='DHT11' macro='GetHumidityString' >
											</command>
											</command>
										</flowline>
									</case>
									<case exp='1' >
										<flowline >
												<argument exp='&quot;No Reply&quot;' />
											</command>
										</flowline>
									</case>
									<case exp='2' >
										<flowline >
												<argument exp='&quot;CRC Error&quot;' />
											</command>
										</flowline>
									</case>
								</command>
								<command class_type='delay' title='Delay' cmdcolor='4206456' cmdcolor_sec='10785756' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='0.64' exp='2' type='2' />
							</flowline>
						</command>
					</flowline>
				</macro>
			</macros>
			<component class_type='ref' guid='51677753-5eaf-4e3a-a3c8-71c49a142171' vmin='1' vmaj='1' codename='LCD' panelId='0' x='356.267' y='-36.7602' z='0' xsz='25' ysz='25' zsz='25' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' scadavisible='1' interactive='1' solid='1' layer='2' poslock='1' comp2dType='0' >
				<resources />
				<properties />
				<values >
					<value target='LCD::LCD_Mode' data='000' />
					<value target='LCD::Pin_Data_0' data='$PORTB.0' />
					<value target='LCD::Pin_Data_1' data='$PORTB.1' />
					<value target='LCD::Pin_Data_2' data='$PORTB.2' />
					<value target='LCD::Pin_Data_3' data='$PORTB.3' />
					<value target='LCD::Pin_Data_4' data='$PORTB.4' />
					<value target='LCD::Pin_Data_5' data='$PORTB.5' />
					<value target='LCD::Pin_Data_6' data='$PORTB.6' />
					<value target='LCD::Pin_Data_7' data='$PORTB.7' />
					<value target='LCD::LCD_Port' data='$PORTB0' />
					<value target='LCD::Pin_RS' data='$PORTB.4' />
					<value target='LCD::Pin_E' data='$PORTB.5' />
					<value target='LCD::LCD_Use_Write' data='0' />
					<value target='LCD::Pin_RW' data='$PORTB.6' />
					<value target='LCD::Rows' data='002' />
					<value target='LCD::Columns' data='016' />
					<value target='LCD::RemapCharacters' data='0' />
					<value target='LCD::DelayTiming' data='100' />
					<value target='LCD::ctrl_lcd::Base_GLCD1::ComponentLabel' data='000' />
					<value target='LCD::ctrl_lcd::Base_GLCD1::GdiText1::sText' data='LCD' />
					<value target='LCD::ctrl_lcd::Base_GLCD1::GdiText1::dScale' data='1.4' />
					<value target='LCD::ctrl_lcd::TextColour' data='0' />
					<value target='LCD::ctrl_lcd::TextBg' data='14803425' />
					<value target='LCD::ctrl_lcd::DisplayBg' data='16777215' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='ref' guid='40785d28-4fe3-4aec-a5d9-ba30b2d58760' vmin='1' vmaj='1' codename='DHT11' panelId='0' x='146.915' y='-254.96' z='1' xsz='25' ysz='25' zsz='25' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' scadavisible='1' interactive='1' solid='1' layer='2' poslock='1' comp2dType='0' >
				<resources />
				<properties />
				<values >
					<value target='dpin' data='$PORTC.0' />
					<value target='csum' data='1' />
					<value target='ClockAdjust' data='001' />
					<value target='Nop30us' data='224.000000' />
					<value target='DeviceFamily' data='PIC' />
					<value target='InstPerMicro' data='8.000000' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
		</component>
	</components>
	<scadaresourcelookup />
	<keymap />
	<panel2d shadows='1' lighting='0' brightness='0' >
		<background rgb='9737364' img='' style='0' />
		<camera xe='-32.9647' ye='40.8134' ze='378.095' xt='-32.9647' yt='40.8134' zt='0' xquat='0' yquat='0' zquat='0' wquat='1' />
		<viewport dx='585' dy='828' zoom='187.215' fix_topleft='0' />
		<page x='1000' y='1000' show='0' rgb='7360576' />
		<winpos ID='7005' RectRecentFloat='1338,172,1756,1017' RectRecentDocked='0,0,585,851' RecentFrameAlignment='16384' RecentRowIndex='0' IsFloating='0' MRUWidth='32767' PinState='0' IsMaximized='0' IsVisible='0' />
	</panel2d>
	<panel3d shadows='0' lighting='2' brightness='128' perspective='1' >
		<background rgb='65280' img='' style='0' />
		<table rgb='7360576' img='' style='0' size='70' />
		<camera xe='-12.4201' ye='-0.306293' ze='130.844' xt='-12.4201' yt='-0.306293' zt='0' xquat='0' yquat='0' zquat='0' wquat='1' />
		<camerakey0 xe='0' ye='0' ze='300' xt='0' yt='0' zt='0' xquat='0' yquat='0' zquat='0' wquat='1' />
		<camerakey1 xe='-3.67394e-14' ye='0' ze='-300' xt='0' yt='0' zt='0' xquat='0' yquat='1' zquat='0' wquat='6.12323e-17' />
		<camerakey2 xe='0' ye='-300' ze='6.66134e-14' xt='0' yt='0' zt='0' xquat='-0.707107' yquat='0' zquat='0' wquat='0.707107' />
		<camerakey3 xe='-3.67394e-14' ye='300' ze='6.66134e-14' xt='0' yt='0' zt='0' xquat='-4.32978e-17' yquat='0.707107' zquat='0.707107' wquat='4.32978e-17' />
		<camerakey4 xe='-300' ye='-6.66134e-14' ze='6.66134e-14' xt='0' yt='0' zt='0' xquat='-0.5' yquat='0.5' zquat='0.5' wquat='0.5' />
		<camerakey5 xe='300' ye='-6.66134e-14' ze='6.66134e-14' xt='0' yt='0' zt='0' xquat='-0.5' yquat='-0.5' zquat='-0.5' wquat='0.5' />
		<camerakey6 xe='-173.205' ye='-173.205' ze='173.205' xt='0' yt='0' zt='0' xquat='-0.424708' yquat='0.17592' zquat='0.339851' wquat='0.820473' />
		<winpos ID='7004' RectRecentFloat='0,425,654,1002' RectRecentDocked='0,0,275,578' RecentFrameAlignment='16384' RecentRowIndex='0' IsFloating='0' MRUWidth='32767' PinState='0' IsMaximized='0' IsVisible='0' />
	</panel3d>
	<panels2d count='2' >
		<panel2d_0 id='0' name='NewPanel' >
			<winpos ID='1171' RectRecentFloat='9,547,525,1047' RectRecentDocked='1278,141,1920,1021' RecentFrameAlignment='16384' RecentRowIndex='0' IsFloating='1' MRUWidth='32767' PinState='0' IsMaximized='0' IsVisible='1' />
			<background fill='72057594034572492' showgrid='0' gridstyle='1' gridsize='10' gridbrush='71776119075691740' snaptogrid='1' />
		</panel2d_0>
		<panel2d_1 id='1' name='NewPanel_1' >
			<winpos ID='1172' RectRecentFloat='524,288,1174,738' RectRecentDocked='1278,141,1920,1021' RecentFrameAlignment='16384' RecentRowIndex='0' IsFloating='0' MRUWidth='32767' PinState='0' IsMaximized='0' IsVisible='0' />
			<background fill='288230376151053813' showgrid='1' gridstyle='1' gridsize='10' gridbrush='71776119075691740' snaptogrid='1' />
		</panel2d_1>
	</panels2d>
	<layout >
		<view type='0' name='Main' mode='0' placement='LAAAAAAAAAABAAAA---------------------wUAAAAYAAAAmQQAAFkCAAA' zoom='75' scrollx='0' scrolly='216' flags='0' />
	</layout>
</document>
</root>
