/* Axiris IV-3 Arduino Shield as a clock. This program listens to incoming commands on the serial port (9600 baud). A command is processed when a CR (13) or LF (10) character arrives. - Command 'T': Set the date and time by means of a Unix epoch value. The command must be followed by a decimal value. For example: T 1431472660 Sets the date and time to 2015-05-12 23:17:40. See also: http://www.epochconverter.com/ - Command 'S': Set the date and time by specifying year, month, day, hour, minute and second. The values must be separated by one or more spaces. For example: S 2015 07 21 16 35 48 Sets the date and time to 2015-07-21 16:35:48. - Command 'D': Set dimming value for the LEDs. Valid values are 0..8. O means LEDs are off, 8 means LEDs are fully on. For example: D 2 Required library: http://www.pjrc.com/teensy/td_libs_Time.html Notes: * Pins 2..9 are connected to the segments and dots of the tubes. * Pins A0..A3 are connected to the grids of the tubes. * Pin 10 is connected to the LEDs beneath the tubes. * Macros HIGH and LOW are always passed as arguments of type byte (uint8_t). * Developed and tested in Arduino IDE v1.5.8. Tested with: * Arduino 1.5.8 * Arduino 1.6.7 Author: Peter S'heeren, Axiris Date: 2016-01-11 License: public domain */ #include /* pin 2 --- pin 7 | | pin 3 | | pin 8 --- | | pin 4 pin 6 | | --- . pin 9 pin 5 */ static const byte digit_seg_data[11*7] PROGMEM = { /* pin 2 3 4 5 6 7 8 */ HIGH, HIGH, HIGH, HIGH, HIGH, HIGH, LOW, // Digit 0 LOW, HIGH, HIGH, LOW, LOW, LOW, LOW, // Digit 1 HIGH, HIGH, LOW, HIGH, HIGH, LOW, HIGH, // Digit 2 HIGH, HIGH, HIGH, HIGH, LOW, LOW, HIGH, // Digit 3 LOW, HIGH, HIGH, LOW, LOW, HIGH, HIGH, // Digit 4 HIGH, LOW, HIGH, HIGH, LOW, HIGH, HIGH, // Digit 5 HIGH, LOW, HIGH, HIGH, HIGH, HIGH, HIGH, // Digit 6 HIGH, HIGH, HIGH, LOW, LOW, LOW, LOW, // Digit 7 HIGH, HIGH, HIGH, HIGH, HIGH, HIGH, HIGH, // Digit 8 HIGH, HIGH, HIGH, HIGH, LOW, HIGH, HIGH, // Digit 9 LOW, LOW, LOW, LOW, LOW, LOW, HIGH // Hyphen }; typedef struct _TUBE { byte digit; // 0..9 byte dot; // HIGH or LOW } TUBE; // Display state of the tubes (read-write) static TUBE tube_list[4] = { { 10, LOW }, { 10, LOW }, { 10, LOW }, { 10, LOW } }; // Variables accessed at interrupt level static byte cur_tube = 3; // 0..3 static byte tube_toggle = 0; static byte led_pwm_step = 0; // 0..7 static byte led_pwm_off = 2; // 0..7, 8 means always on void isr_tubes () { const byte *digit_seg_p; byte digit; byte pin; // Drive the tubes // Disable all grids and segments, then wait a bit. Doing so prevents the so-called ghosting // visual effect. // Clear pins as fast as possible PORTC &= ~0b00001111; // Clear pin A[0..3] PORTD &= ~0b11111100; // Clear pin 2..7 PORTB &= ~0b00000011; // Clear pin 8..9 // The following function is compiled to one or more nested loops that run for the exact amount // of cycles __builtin_avr_delay_cycles(16*40); // 40 us (at 16 MHz) // Select the next tube cur_tube++; cur_tube %= 4; digit = tube_list[cur_tube].digit; digit_seg_p = digit_seg_data + 7*digit; for (pin = 2; pin < 9; pin++, digit_seg_p++) digitalWrite(pin,pgm_read_byte(digit_seg_p)); digitalWrite(pin,tube_list[cur_tube].dot); // Enable the current tube digitalWrite(A0+cur_tube,HIGH); } void isr_leds () { // Program LED PWM duty cycle if (led_pwm_step == led_pwm_off) digitalWrite(10,LOW); else if (led_pwm_step == 0) digitalWrite(10,HIGH); // PWM step counter: 0->1->2->...->7->0->1->... led_pwm_step++; if (led_pwm_step == 8) led_pwm_step = 0; } // Timer 1 interrupt service routine ISR(TIMER1_COMPA_vect) { // Drive tubes at 250 Hz tube_toggle ^= 1; if (tube_toggle) isr_tubes(); // PWM for LEDs requires 500 Hz isr_leds(); } void setup () { Serial.begin(9600); pinMode(A0,OUTPUT); pinMode(A1,OUTPUT); pinMode(A2,OUTPUT); pinMode(A3,OUTPUT); pinMode(2,OUTPUT); pinMode(3,OUTPUT); pinMode(4,OUTPUT); pinMode(5,OUTPUT); pinMode(6,OUTPUT); pinMode(7,OUTPUT); pinMode(8,OUTPUT); pinMode(9,OUTPUT); pinMode(10,OUTPUT); // TCCR1A - Timer/Counter Control Register A: (default 00000000b) // * Bit 7..6: COM1A[1..0]: Compare Match Output A Mode // * Bit 5..4: COM1B[1..0]: Compare Match Output B Mode // * Bit 3..2: Reserved // * Bit 1..0: WGM1[1..0]: Waveform Generation Mode // // TCCR1B - Timer/Counter Control Register B: (default 00000000b) // * Bit 7: ICNC1: Input Capture Noise Canceler // * Bit 6: ICES1: Input Capture Edge Select // * Bit 5: Reserved // * Bit 4..3: WGM1[3..2]: Waveform Generation Mode // * Bit 2..0: CS1[2..0]: Clock Select // // TCCR1C - Timer/Counter Control Register C: (default 00000000b) // * Bit 7: FOC1A: Force Output Compare for Channel A // * Bit 6: FOC1B: Force Output Compare for Channel B // * Bit 5..0: Reserved // // TCNT1H and TCNT1L - Timer/Counter Register: (default 0000000000000000b) // * Bit 15..0: TCNT1[15..0]: timer/counter value // // OCR1AH and OCR1AL - Output Compare Register A: (default 0000000000000000b) // * Bit 15..0: OCR1A[15..0]: compare value A // // OCR1BH and OCR1BL - Output Compare Register B: (default 0000000000000000b) // * Bit 15..0: OCR1B[15..0]: compare value B // // ICR1H and ICR1L - Input Capture Register: (default 0000000000000000b) // * Bit 15..0: ICR1[15..0]: capture value B // // TIMSK1 - Timer/Counter Interrupt Mask Register: (default 00000000b) // * Bit 7..6: Reserved // * Bit 5: ICIE1: Input Capture Interrupt Enable // * Bit 4..3: Reserved // * Bit 2: OCIE1B: Output Compare B Match Interrupt Enable // * Bit 1: OCIE1A: Output Compare A Match Interrupt Enable // * Bit 0: TOIE1: Overflow Interrupt Enable // // TIFR1 - Timer/Counter Interrupt Flag Register: (default 00000000b) // * Bit 7..6: Reserved // * Bit 5: ICF1: Input Capture Flag // * Bit 4..3: Reserved // * Bit 2: OCF1B: Output Compare B Match Flag // * Bit 1: OCF1A: Output Compare A Match Flag // * Bit 0: TOV1: Overflow Flag // // Settings: // - WGM1[3..0]=0100b: CTC (top value OCR1A, overflow on MAX) // Non-PWM mode: // - COM1A[1..0]=00b: Normal port operation, OC1A disconnected // - COM1B[1..0]=00b: Normal port operation, OC1B disconnected // - CS1[2..0]=100b: clk/256 speed => 62500 Hz // -> a non-zero value also enables the timer/counter // - OCIE1A=1: Generate interrupt on output compare A match cli(); // We've observed on Arduino IDE 1.5.8 that TCCR1A is non-zero at this point. So let's play safe // and write all relevant timer registers. TCCR1A = 0b00000000; OCR1A = 125-1; // 500 Hz (62500/125) TCNT1 = 0; TIMSK1 = 0b00000010; TIFR1 = 0b00000000; TCCR1B = 0b00001100; // Enable timer sei(); } void set_tubes_val (int val) { byte tube; // Loop: tube 3->0 tube = 3; for (;;) { // Least significant decimal digit tube_list[tube].digit = val % 10; // Loop control if (tube == 0) break; tube--; // Shift decimal value one digit to the right val /= 10; } } #define RCV_BUF_LEN 32 static char rcv_buf[RCV_BUF_LEN]; // Receive buffer static byte rcv_si = 0; // Store index static byte rcv_error = false; // Receive error condition static byte rcv_fi = 0; // Fetch index void keep_rcv_char () { rcv_fi--; } char fetch_rcv_char () { if (rcv_fi < rcv_si) { // Fetch the next character return rcv_buf[rcv_fi++]; } else { // Reached the end of the buffer return 0; } } static word parse_u16_res; boolean parse_u16 () { word prev; char c; boolean parsed; parsed = false; parse_u16_res = 0; for (;;) { c = fetch_rcv_char(); if ((c >= '0') && (c <= '9')) { prev = parse_u16_res; parse_u16_res = parse_u16_res * 10 + (c - '0'); // Check for overflow if (parse_u16_res < prev) return false; // At least one digit has been parsed parsed = true; } else { if (c != 0) keep_rcv_char(); return parsed; } } } void parse_spaces () { char c; for (;;) { c = fetch_rcv_char(); if (c != ' ') break; } if (c != 0) keep_rcv_char(); } boolean process_rcv () { char c; c = fetch_rcv_char(); if (c == 0) { // Empty line received return true; } else if (c == 'T') { time_t t; // Parse separator space characters parse_spaces(); // Fetch the decimal value; at least one digit is expected t = 0; for (;;) { c = fetch_rcv_char(); if ((c >= '0') && (c <= '9')) { t = (t * 10) + (c - '0'); } else { if (c != 0) keep_rcv_char(); break; } } // Parse separator space characters parse_spaces(); // End-of-line expected c = fetch_rcv_char(); if (c != 0) return false; setTime(t); return true; } else if (c == 'S') { static tmElements_t elem; word w; time_t t; // Parse separator space characters parse_spaces(); // Parse the year (1970..2225) if (!parse_u16()) return false; w = parse_u16_res - 1970; if (w > 255) return false; elem.Year = (uint8_t)w; // Parse separator space characters parse_spaces(); // Parse the month (1..12) if (!parse_u16()) return false; w = parse_u16_res; if ((w < 1) || (w > 12)) return false; elem.Month = (uint8_t)w; // Parse separator space characters parse_spaces(); // Parse the day (1..31) if (!parse_u16()) return false; w = parse_u16_res; if ((w < 1) || (w > 31)) return false; elem.Day = (uint8_t)w; // Parse separator space characters parse_spaces(); // Parse the hour (0..23) if (!parse_u16()) return false; w = parse_u16_res; if (w > 23) return false; elem.Hour = (uint8_t)w; // Parse separator space characters parse_spaces(); // Parse the minute (0..59) if (!parse_u16()) return false; w = parse_u16_res; if (w > 59) return false; elem.Minute = (uint8_t)w; // Parse separator space characters parse_spaces(); // Parse the second (0..59) if (!parse_u16()) return false; w = parse_u16_res; if (w > 59) return false; elem.Second = (uint8_t)w; // Parse separator space characters parse_spaces(); // End-of-line expected c = fetch_rcv_char(); if (c != 0) return false; t = makeTime(elem); setTime(t); return true; } else if (c == 'D') { byte pwm_off; // Parse separator space characters parse_spaces(); // Parse the PWM duty (0..8) if (!parse_u16()) return false; if (parse_u16_res > 8) return false; pwm_off = (uint8_t)parse_u16_res; // Parse separator space characters parse_spaces(); // End-of-line expected c = fetch_rcv_char(); if (c != 0) return false; cli(); led_pwm_off = pwm_off; sei(); return true; } else { // Unknown command return false; } } // Receive characters from the serial port in non-blocking fashion. void rcv () { char c; while (Serial.available() > 0) { c = Serial.read(); if ((c == 13) || (c == 10)) { if (rcv_error == false) process_rcv(); // Reset the receive buffer rcv_si = 0; rcv_error = false; rcv_fi = 0; } else if ((c < 32) || (c > 126)) { // Invalid character received rcv_error = true; } else if (rcv_si == RCV_BUF_LEN) { // Buffer overflow rcv_error = true; } else { // Store character in receive buffer rcv_buf[rcv_si] = c; rcv_si++; } } } void no_time () { byte tube; cli(); for (tube = 0; tube < 4; tube++) { tube_list[tube].digit = 10; tube_list[tube].dot = LOW; } sei(); } void display_time () { static TimeElements tm; time_t t; unsigned long ms; boolean dot; byte u; ms = millis() % 1000; dot = (ms < 500) ? HIGH : LOW; t = now(); breakTime(t,tm); cli(); u = tm.Second; if ((u >= 50) && (u <= 54)) { u = tm.Day; tube_list[1].digit = (u % 10); tube_list[1].dot = dot; tube_list[0].digit = (u / 10); tube_list[0].dot = dot; u = tm.Month; tube_list[3].digit = (u % 10); tube_list[3].dot = dot; tube_list[2].digit = (u / 10); tube_list[2].dot = dot; } else { u = tm.Hour; tube_list[1].digit = (u % 10); tube_list[1].dot = dot; tube_list[0].digit = (u / 10); tube_list[0].dot = LOW; u = tm.Minute; tube_list[3].digit = (u % 10); tube_list[3].dot = LOW; tube_list[2].digit = (u / 10); tube_list[2].dot = LOW; } sei(); } void loop () { rcv(); if (timeStatus() == timeNotSet) { no_time(); } else { display_time(); } }
