__Lib_TFT_Defs_TFT_Write_Strobe:
;__Lib_TFT_Defs.mbas,97 :: 		sub procedure TFT_Write_Strobe()
;__Lib_TFT_Defs.mbas,98 :: 		TFT_WR = 0
_LX	
INS	R2, R0, BitPos(TFT_WR+0), 1
_SX	
;__Lib_TFT_Defs.mbas,99 :: 		asm nop end asm
NOP	
;__Lib_TFT_Defs.mbas,100 :: 		TFT_WR = 1
_LX	
ORI	R2, R2, BitMask(TFT_WR+0)
_SX	
;__Lib_TFT_Defs.mbas,101 :: 		end sub
L_end_TFT_Write_Strobe:
JR	RA
NOP	
; end of __Lib_TFT_Defs_TFT_Write_Strobe
__Lib_TFT_Defs_TFT_Read_Strobe:
;__Lib_TFT_Defs.mbas,103 :: 		sub procedure TFT_Read_Strobe()
;__Lib_TFT_Defs.mbas,104 :: 		TFT_RD = 0
_LX	
INS	R2, R0, BitPos(TFT_RD+0), 1
_SX	
;__Lib_TFT_Defs.mbas,105 :: 		asm nop end asm
NOP	
;__Lib_TFT_Defs.mbas,106 :: 		asm nop end asm
NOP	
;__Lib_TFT_Defs.mbas,107 :: 		asm nop end asm
NOP	
;__Lib_TFT_Defs.mbas,108 :: 		asm nop end asm
NOP	
;__Lib_TFT_Defs.mbas,109 :: 		asm nop end asm
NOP	
;__Lib_TFT_Defs.mbas,110 :: 		TFT_RD = 1
_LX	
ORI	R2, R2, BitMask(TFT_RD+0)
_SX	
;__Lib_TFT_Defs.mbas,111 :: 		end sub
L_end_TFT_Read_Strobe:
JR	RA
NOP	
; end of __Lib_TFT_Defs_TFT_Read_Strobe
__Lib_TFT_Defs_Read_From_Port:
;__Lib_TFT_Defs.mbas,115 :: 		dim turnOn as byte
ADDIU	SP, SP, -4
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,116 :: 		turnOn = 0
; turnOn start address is: 12 (R3)
MOVZ	R3, R0, R0
;__Lib_TFT_Defs.mbas,117 :: 		if (PMCON.ON_) then
LBU	R2, Offset(PMCON+1)(GP)
EXT	R2, R2, 7, 1
BNE	R2, R0, L___Lib_TFT_Defs_Read_From_Port462
NOP	
J	L___Lib_TFT_Defs_Read_From_Port454
NOP	
L___Lib_TFT_Defs_Read_From_Port462:
; turnOn end address is: 12 (R3)
;__Lib_TFT_Defs.mbas,118 :: 		PMCON.ON_ = 0         ' MikroE HW (mikromedia for PIC32 with ST7789V controler) will not work if PMP
ORI	R2, R0, 32768
SW	R2, Offset(PMCON+4)(GP)
;__Lib_TFT_Defs.mbas,119 :: 		turnOn = 1            ' is turnd on. We must turn it off when calling TFT_Read_Strobe function
ORI	R3, R0, 1
NOP	
L___Lib_TFT_Defs_Read_From_Port454:
L___Lib_TFT_Defs_Read_From_Port4:
;__Lib_TFT_Defs.mbas,122 :: 		PMCON.ON_ = 0
ORI	R2, R0, 32768
;__Lib_TFT_Defs.mbas,123 :: 		dataPort = ^word(@TFT_DataPort - 0x10)
LUI	R2, hi_addr(TFT_DataPort+0)
ORI	R2, R2, lo_addr(TFT_DataPort+0)
ADDIU	R2, R2, -16
; dataPort start address is: 16 (R4)
MOVZ	R4, R2, R0
;__Lib_TFT_Defs.mbas,124 :: 		TFT_RS = 1
_LX	
ORI	R2, R2, BitMask(TFT_RS+0)
_SX	
;__Lib_TFT_Defs.mbas,125 :: 		TFT_Read_Strobe()
JAL	__Lib_TFT_Defs_TFT_Read_Strobe+0
NOP	
;__Lib_TFT_Defs.mbas,126 :: 		Result = dataPort^
LHU	R2, 0(R4)
; dataPort end address is: 16 (R4)
; Result start address is: 16 (R4)
ANDI	R4, R2, 65535
;__Lib_TFT_Defs.mbas,128 :: 		if (turnOn) then
BNE	R3, R0, L___Lib_TFT_Defs_Read_From_Port464
NOP	
J	L___Lib_TFT_Defs_Read_From_Port7
NOP	
L___Lib_TFT_Defs_Read_From_Port464:
;__Lib_TFT_Defs.mbas,129 :: 		PMCON.ON_ = 1
ORI	R2, R0, 32768
SW	R2, Offset(PMCON+8)(GP)
L___Lib_TFT_Defs_Read_From_Port7:
;__Lib_TFT_Defs.mbas,131 :: 		end sub
ANDI	R2, R4, 65535
; Result end address is: 16 (R4)
L_end_Read_From_Port:
LW	RA, 0(SP)
ADDIU	SP, SP, 4
JR	RA
NOP	
; end of __Lib_TFT_Defs_Read_From_Port
__Lib_TFT_Defs_TFT_Set_DataPort_Direction:
;__Lib_TFT_Defs.mbas,137 :: 		sub procedure TFT_Set_DataPort_Direction()
;__Lib_TFT_Defs.mbas,140 :: 		TFT_DataPort_Direction = TFT_DataPort_Direction and not(longword(__controller))
LHU	R2, Offset(__Lib_TFT_Defs___controller+0)(GP)
NOR	R3, R2, R0
LBU	R2, Offset(TFT_DataPort_Direction+0)(GP)
AND	R2, R2, R3
SB	R2, Offset(TFT_DataPort_Direction+0)(GP)
;__Lib_TFT_Defs.mbas,141 :: 		end sub
L_end_TFT_Set_DataPort_Direction:
JR	RA
NOP	
; end of __Lib_TFT_Defs_TFT_Set_DataPort_Direction
__Lib_TFT_Defs_TFT_Set_DataPort_Direction_Input:
;__Lib_TFT_Defs.mbas,147 :: 		sub procedure TFT_Set_DataPort_Direction_Input()
;__Lib_TFT_Defs.mbas,150 :: 		TFT_DataPort_Direction = TFT_DataPort_Direction or (longword(__controller))
LHU	R3, Offset(__Lib_TFT_Defs___controller+0)(GP)
OR	R2, R2, R3
;__Lib_TFT_Defs.mbas,151 :: 		end sub
L_end_TFT_Set_DataPort_Direction_Input:
JR	RA
NOP	
; end of __Lib_TFT_Defs_TFT_Set_DataPort_Direction_Input
_TFT_Set_Index:
;__Lib_TFT_Defs.mbas,157 :: 		sub procedure TFT_Set_Index(dim index as byte)
ADDIU	SP, SP, -4
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,158 :: 		TFT_RS = 0
_LX	
INS	R2, R0, BitPos(TFT_RS+0), 1
_SX	
;__Lib_TFT_Defs.mbas,159 :: 		TFT_DataPort = index
SB	R25, Offset(TFT_DataPort+0)(GP)
;__Lib_TFT_Defs.mbas,160 :: 		TFT_Write_Strobe()
JAL	__Lib_TFT_Defs_TFT_Write_Strobe+0
NOP	
;__Lib_TFT_Defs.mbas,161 :: 		end sub
L_end_TFT_Set_Index:
LW	RA, 0(SP)
ADDIU	SP, SP, 4
JR	RA
NOP	
; end of _TFT_Set_Index
_TFT_Write_Command:
;__Lib_TFT_Defs.mbas,167 :: 		sub procedure TFT_Write_Command(dim cmd as byte)
ADDIU	SP, SP, -4
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,168 :: 		TFT_RS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,169 :: 		TFT_DataPort = cmd
;__Lib_TFT_Defs.mbas,170 :: 		TFT_Write_Strobe()
NOP	
;__Lib_TFT_Defs.mbas,171 :: 		end sub
L_end_TFT_Write_Command:
LW	RA, 0(SP)
ADDIU	SP, SP, 4
JR	RA
NOP	
; end of _TFT_Write_Command
_TFT_Set_Reg:
;__Lib_TFT_Defs.mbas,178 :: 		sub procedure TFT_Set_Reg(dim index, value as byte)
ADDIU	SP, SP, -12
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,179 :: 		TFT_CS = 0
SW	R25, 4(SP)
_LX	
INS	R2, R0, BitPos(TFT_CS+0), 1
_SX	
;__Lib_TFT_Defs.mbas,180 :: 		TFT_Set_Index_Ptr(index)
SB	R26, 8(SP)
LW	R30, Offset(_TFT_Set_Index_Ptr+0)(GP)
JALR	RA, R30
NOP	
LBU	R26, 8(SP)
;__Lib_TFT_Defs.mbas,181 :: 		TFT_Write_Command_Ptr(value)
ANDI	R25, R26, 255
LW	R30, Offset(_TFT_Write_Command_Ptr+0)(GP)
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,182 :: 		TFT_CS = 1
_LX	
ORI	R2, R2, BitMask(TFT_CS+0)
_SX	
;__Lib_TFT_Defs.mbas,183 :: 		end sub
L_end_TFT_Set_Reg:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 12
JR	RA
NOP	
; end of _TFT_Set_Reg
_TFT_Reset_Device:
;__Lib_TFT_Defs.mbas,189 :: 		sub procedure TFT_Reset_Device()
ADDIU	SP, SP, -12
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,191 :: 		TFT_RST = 0
SW	R25, 4(SP)
SW	R26, 8(SP)
_LX	
INS	R2, R0, BitPos(TFT_RST+0), 1
_SX	
;__Lib_TFT_Defs.mbas,193 :: 		TFT_RST_Direction = 0
_LX	
INS	R2, R0, BitPos(TFT_RST_Direction+0), 1
_SX	
;__Lib_TFT_Defs.mbas,196 :: 		TFT_RS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,198 :: 		TFT_RS_Direction = 0
_LX	
INS	R2, R0, BitPos(TFT_RS_Direction+0), 1
_SX	
;__Lib_TFT_Defs.mbas,201 :: 		TFT_CS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,203 :: 		TFT_CS_Direction = 0
_LX	
INS	R2, R0, BitPos(TFT_CS_Direction+0), 1
_SX	
;__Lib_TFT_Defs.mbas,205 :: 		TFT_RD_Direction = 0
_LX	
INS	R2, R0, BitPos(TFT_RD_Direction+0), 1
_SX	
;__Lib_TFT_Defs.mbas,206 :: 		TFT_WR_Direction = 0
_LX	
INS	R2, R0, BitPos(TFT_WR_Direction+0), 1
_SX	
;__Lib_TFT_Defs.mbas,207 :: 		TFT_RD = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,208 :: 		TFT_WR = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,211 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,212 :: 		TFT_RST = 1
_LX	
ORI	R2, R2, BitMask(TFT_RST+0)
_SX	
;__Lib_TFT_Defs.mbas,213 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,214 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,217 :: 		TFT_Set_Reg(0xEA, 0x00) ' PTBA[15:8]
MOVZ	R26, R0, R0
ORI	R25, R0, 234
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,218 :: 		TFT_Set_Reg(0xEB, 0x20) ' PTBA[7:0]
ORI	R26, R0, 32
ORI	R25, R0, 235
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,219 :: 		TFT_Set_Reg(0xEC, 0x0C) ' STBA[15:8]
ORI	R26, R0, 12
ORI	R25, R0, 236
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,220 :: 		TFT_Set_Reg(0xED, 0xC4) ' STBA[7:0]
ORI	R26, R0, 196
ORI	R25, R0, 237
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,221 :: 		TFT_Set_Reg(0xE8, 0x40) ' OPON[7:0]
ORI	R26, R0, 64
ORI	R25, R0, 232
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,222 :: 		TFT_Set_Reg(0xE9, 0x38) ' OPON1[7:0]
ORI	R26, R0, 56
ORI	R25, R0, 233
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,223 :: 		TFT_Set_Reg(0xF1, 0x01) ' OTPS1B
ORI	R26, R0, 1
ORI	R25, R0, 241
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,224 :: 		TFT_Set_Reg(0xF2, 0x10) ' GEN
ORI	R26, R0, 16
ORI	R25, R0, 242
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,225 :: 		TFT_Set_Reg(0x27, 0xA3)
ORI	R26, R0, 163
ORI	R25, R0, 39
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,228 :: 		TFT_Set_Reg(0x40, 0x00) '
MOVZ	R26, R0, R0
ORI	R25, R0, 64
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,229 :: 		TFT_Set_Reg(0x41, 0x00) '
MOVZ	R26, R0, R0
ORI	R25, R0, 65
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,230 :: 		TFT_Set_Reg(0x42, 0x01) '
ORI	R26, R0, 1
ORI	R25, R0, 66
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,231 :: 		TFT_Set_Reg(0x43, 0x13) '
ORI	R26, R0, 19
ORI	R25, R0, 67
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,232 :: 		TFT_Set_Reg(0x44, 0x10) '
ORI	R26, R0, 16
ORI	R25, R0, 68
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,233 :: 		TFT_Set_Reg(0x45, 0x26) '
ORI	R26, R0, 38
ORI	R25, R0, 69
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,234 :: 		TFT_Set_Reg(0x46, 0x08) '
ORI	R26, R0, 8
ORI	R25, R0, 70
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,235 :: 		TFT_Set_Reg(0x47, 0x51) '
ORI	R26, R0, 81
ORI	R25, R0, 71
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,236 :: 		TFT_Set_Reg(0x48, 0x02) '
ORI	R26, R0, 2
ORI	R25, R0, 72
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,237 :: 		TFT_Set_Reg(0x49, 0x12) '
ORI	R26, R0, 18
ORI	R25, R0, 73
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,238 :: 		TFT_Set_Reg(0x4A, 0x18) '
ORI	R26, R0, 24
ORI	R25, R0, 74
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,239 :: 		TFT_Set_Reg(0x4B, 0x19) '
ORI	R26, R0, 25
ORI	R25, R0, 75
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,240 :: 		TFT_Set_Reg(0x4C, 0x14) '
ORI	R26, R0, 20
ORI	R25, R0, 76
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,242 :: 		TFT_Set_Reg(0x50, 0x19) '
ORI	R26, R0, 25
ORI	R25, R0, 80
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,243 :: 		TFT_Set_Reg(0x51, 0x2F) '
ORI	R26, R0, 47
ORI	R25, R0, 81
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,244 :: 		TFT_Set_Reg(0x52, 0x2C) '
ORI	R26, R0, 44
ORI	R25, R0, 82
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,245 :: 		TFT_Set_Reg(0x53, 0x3E) '
ORI	R26, R0, 62
ORI	R25, R0, 83
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,246 :: 		TFT_Set_Reg(0x54, 0x3F) '
ORI	R26, R0, 63
ORI	R25, R0, 84
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,247 :: 		TFT_Set_Reg(0x55, 0x3F) '
ORI	R26, R0, 63
ORI	R25, R0, 85
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,248 :: 		TFT_Set_Reg(0x56, 0x2E) '
ORI	R26, R0, 46
ORI	R25, R0, 86
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,249 :: 		TFT_Set_Reg(0x57, 0x77) '
ORI	R26, R0, 119
ORI	R25, R0, 87
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,250 :: 		TFT_Set_Reg(0x58, 0x0B) '
ORI	R26, R0, 11
ORI	R25, R0, 88
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,251 :: 		TFT_Set_Reg(0x59, 0x06) '
ORI	R26, R0, 6
ORI	R25, R0, 89
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,252 :: 		TFT_Set_Reg(0x5A, 0x07) '
ORI	R26, R0, 7
ORI	R25, R0, 90
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,253 :: 		TFT_Set_Reg(0x5B, 0x0D) '
ORI	R26, R0, 13
ORI	R25, R0, 91
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,254 :: 		TFT_Set_Reg(0x5C, 0x1D) '
ORI	R26, R0, 29
ORI	R25, R0, 92
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,255 :: 		TFT_Set_Reg(0x5D, 0xCC) '
ORI	R26, R0, 204
ORI	R25, R0, 93
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,258 :: 		if (TFT_Disp_Rotation = 90) then
LBU	R3, Offset(__Lib_TFT_Defs_TFT_Disp_Rotation+0)(GP)
ORI	R2, R0, 90
BEQ	R3, R2, L__TFT_Reset_Device471
NOP	
J	L__TFT_Reset_Device16
NOP	
L__TFT_Reset_Device471:
;__Lib_TFT_Defs.mbas,259 :: 		TFT_Set_Reg(0x04, 0x00)
MOVZ	R26, R0, R0
ORI	R25, R0, 4
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,260 :: 		TFT_Set_Reg(0x05, 0xEF)
ORI	R26, R0, 239
ORI	R25, R0, 5
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,261 :: 		TFT_Set_Reg(0x08, 0x01)
ORI	R26, R0, 1
ORI	R25, R0, 8
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,262 :: 		TFT_Set_Reg(0x09, 0x3F)
ORI	R26, R0, 63
ORI	R25, R0, 9
JAL	_TFT_Set_Reg+0
NOP	
J	L__TFT_Reset_Device17
NOP	
;__Lib_TFT_Defs.mbas,263 :: 		else
L__TFT_Reset_Device16:
;__Lib_TFT_Defs.mbas,264 :: 		TFT_Set_Reg(0x04, 0x01)
ORI	R26, R0, 1
ORI	R25, R0, 4
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,265 :: 		TFT_Set_Reg(0x05, 0x3F)
ORI	R26, R0, 63
ORI	R25, R0, 5
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,266 :: 		TFT_Set_Reg(0x08, 0x00)
MOVZ	R26, R0, R0
ORI	R25, R0, 8
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,267 :: 		TFT_Set_Reg(0x09, 0xEF)
ORI	R26, R0, 239
ORI	R25, R0, 9
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,268 :: 		end if
L__TFT_Reset_Device17:
;__Lib_TFT_Defs.mbas,270 :: 		if (TFT_Disp_Rotation = 90) then
ORI	R2, R0, 90
BEQ	R3, R2, L__TFT_Reset_Device472
NOP	
J	L__TFT_Reset_Device19
NOP	
L__TFT_Reset_Device472:
;__Lib_TFT_Defs.mbas,271 :: 		if (Is_TFT_Rotated_180() = 1) then
JAL	_Is_TFT_Rotated_180+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BEQ	R3, R2, L__TFT_Reset_Device473
NOP	
J	L__TFT_Reset_Device22
NOP	
L__TFT_Reset_Device473:
;__Lib_TFT_Defs.mbas,272 :: 		TFT_Set_Reg(0x16, 0xC8) ' MY=1, MX=1, MV=0, BGR=1
ORI	R26, R0, 200
ORI	R25, R0, 22
JAL	_TFT_Set_Reg+0
NOP	
J	L__TFT_Reset_Device23
NOP	
;__Lib_TFT_Defs.mbas,273 :: 		else
L__TFT_Reset_Device22:
;__Lib_TFT_Defs.mbas,274 :: 		TFT_Set_Reg(0x16, 0x08) ' MY=0, MX=0, MV=0, BGR=1
ORI	R26, R0, 8
ORI	R25, R0, 22
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,275 :: 		end if
L__TFT_Reset_Device23:
J	L__TFT_Reset_Device20
NOP	
;__Lib_TFT_Defs.mbas,276 :: 		else
L__TFT_Reset_Device19:
;__Lib_TFT_Defs.mbas,277 :: 		if (Is_TFT_Rotated_180() = 1) then
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BEQ	R3, R2, L__TFT_Reset_Device474
NOP	
J	L__TFT_Reset_Device25
NOP	
L__TFT_Reset_Device474:
;__Lib_TFT_Defs.mbas,278 :: 		TFT_Set_Reg(0x16, 0xA8) ' MY=0, MX=1, MV=1, BGR=1
ORI	R26, R0, 168
ORI	R25, R0, 22
JAL	_TFT_Set_Reg+0
NOP	
J	L__TFT_Reset_Device26
NOP	
;__Lib_TFT_Defs.mbas,279 :: 		else
L__TFT_Reset_Device25:
;__Lib_TFT_Defs.mbas,280 :: 		TFT_Set_Reg(0x16, 0x68) ' MY=1, MX=0, MV=1, BGR=1
ORI	R26, R0, 104
ORI	R25, R0, 22
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,281 :: 		end if
L__TFT_Reset_Device26:
;__Lib_TFT_Defs.mbas,282 :: 		end if
L__TFT_Reset_Device20:
;__Lib_TFT_Defs.mbas,285 :: 		TFT_Set_Reg(0x1B, 0x1B) ' VRH = 4.65
ORI	R26, R0, 27
ORI	R25, R0, 27
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,286 :: 		TFT_Set_Reg(0x1A, 0x01) ' BT
ORI	R26, R0, 1
ORI	R25, R0, 26
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,287 :: 		TFT_Set_Reg(0x24, 0x2F) ' VMH
ORI	R26, R0, 47
ORI	R25, R0, 36
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,288 :: 		TFT_Set_Reg(0x25, 0x57) ' VML
ORI	R26, R0, 87
ORI	R25, R0, 37
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,291 :: 		TFT_Set_Reg(0x23, 0x8D) ' FLICKER ADJUST
ORI	R26, R0, 141
ORI	R25, R0, 35
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,294 :: 		TFT_Set_Reg(0x18, 0x36) '
ORI	R26, R0, 54
ORI	R25, R0, 24
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,295 :: 		TFT_Set_Reg(0x19, 0x01) '
ORI	R26, R0, 1
ORI	R25, R0, 25
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,296 :: 		TFT_Set_Reg(0x01, 0x00) '
MOVZ	R26, R0, R0
ORI	R25, R0, 1
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,297 :: 		TFT_Set_Reg(0x1F, 0x88) '
ORI	R26, R0, 136
ORI	R25, R0, 31
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,298 :: 		Delay_5ms()
JAL	_Delay_5ms+0
NOP	
;__Lib_TFT_Defs.mbas,299 :: 		TFT_Set_Reg(0x1F, 0x80) '
ORI	R26, R0, 128
ORI	R25, R0, 31
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,300 :: 		Delay_5ms()
JAL	_Delay_5ms+0
NOP	
;__Lib_TFT_Defs.mbas,301 :: 		TFT_Set_Reg(0x1F, 0x90) '
ORI	R26, R0, 144
ORI	R25, R0, 31
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,302 :: 		Delay_5ms()
JAL	_Delay_5ms+0
NOP	
;__Lib_TFT_Defs.mbas,303 :: 		TFT_Set_Reg(0x1F, 0xD0) '
ORI	R26, R0, 208
ORI	R25, R0, 31
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,304 :: 		Delay_5ms()
JAL	_Delay_5ms+0
NOP	
;__Lib_TFT_Defs.mbas,307 :: 		TFT_Set_Reg(0x17, 0x05) '
ORI	R26, R0, 5
ORI	R25, R0, 23
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,310 :: 		TFT_Set_Reg(0x36, 0x00) ' Panel characteristic control register
MOVZ	R26, R0, R0
ORI	R25, R0, 54
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,313 :: 		TFT_Set_Reg(0x28, 0x38) '
ORI	R26, R0, 56
ORI	R25, R0, 40
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,314 :: 		Delay_10ms()Delay_10ms()Delay_10ms()Delay_10ms()
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
;__Lib_TFT_Defs.mbas,315 :: 		TFT_Set_Reg(0x28, 0x3C) '
ORI	R26, R0, 60
ORI	R25, R0, 40
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,316 :: 		end sub
L_end_TFT_Reset_Device:
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 12
JR	RA
NOP	
; end of _TFT_Reset_Device
_TFT_Set_Address:
;__Lib_TFT_Defs.mbas,323 :: 		sub procedure TFT_Set_Address(dim x, y as word)
ADDIU	SP, SP, -12
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,324 :: 		TFT_Set_Index_Ptr(0x02)
SW	R25, 4(SP)
SH	R26, 8(SP)
SH	R25, 10(SP)
ORI	R25, R0, 2
JALR	RA, R30
NOP	
LHU	R25, 10(SP)
;__Lib_TFT_Defs.mbas,325 :: 		TFT_Write_Command_Ptr(Hi(x))
SH	R25, 10(SP)
EXT	R25, R25, 8, 8
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,326 :: 		TFT_Set_Index_Ptr(0x03)
ORI	R25, R0, 3
JALR	RA, R30
NOP	
LHU	R25, 10(SP)
;__Lib_TFT_Defs.mbas,327 :: 		TFT_Write_Command_Ptr(Lo(x))
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,328 :: 		TFT_Set_Index_Ptr(0x06)
ORI	R25, R0, 6
JALR	RA, R30
NOP	
LHU	R26, 8(SP)
;__Lib_TFT_Defs.mbas,329 :: 		TFT_Write_Command_Ptr(Hi(y))
SH	R26, 8(SP)
EXT	R25, R26, 8, 8
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,330 :: 		TFT_Set_Index_Ptr(0x07)
ORI	R25, R0, 7
JALR	RA, R30
NOP	
LHU	R26, 8(SP)
;__Lib_TFT_Defs.mbas,331 :: 		TFT_Write_Command_Ptr(Lo(y))
ANDI	R25, R26, 255
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,332 :: 		TFT_Set_Index_Ptr(0x22)
ORI	R25, R0, 34
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,333 :: 		end sub
L_end_TFT_Set_Address:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 12
JR	RA
NOP	
; end of _TFT_Set_Address
_TFT_Write_Data:
;__Lib_TFT_Defs.mbas,341 :: 		sub procedure TFT_Write_Data(dim _data as word)
ADDIU	SP, SP, -4
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,342 :: 		TFT_RS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,343 :: 		TFT_DataPort = Hi(_data)
EXT	R2, R25, 8, 8
SB	R2, Offset(TFT_DataPort+0)(GP)
;__Lib_TFT_Defs.mbas,344 :: 		TFT_Write_Strobe()
NOP	
;__Lib_TFT_Defs.mbas,345 :: 		TFT_DataPort = Lo(_data)
;__Lib_TFT_Defs.mbas,346 :: 		TFT_Write_Strobe()
NOP	
;__Lib_TFT_Defs.mbas,347 :: 		end sub
L_end_TFT_Write_Data:
LW	RA, 0(SP)
ADDIU	SP, SP, 4
JR	RA
NOP	
; end of _TFT_Write_Data
_TFT_16bit_Write_Data:
;__Lib_TFT_Defs.mbas,356 :: 		dim temp as ^word
ADDIU	SP, SP, -4
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,357 :: 		TFT_RS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,358 :: 		temp = @TFT_DataPort
; temp start address is: 8 (R2)
;__Lib_TFT_Defs.mbas,359 :: 		temp^ = _data
SH	R25, 0(R2)
; temp end address is: 8 (R2)
;__Lib_TFT_Defs.mbas,360 :: 		TFT_Write_Strobe()
NOP	
;__Lib_TFT_Defs.mbas,361 :: 		end sub
L_end_TFT_16bit_Write_Data:
LW	RA, 0(SP)
ADDIU	SP, SP, 4
JR	RA
NOP	
; end of _TFT_16bit_Write_Data
_TFT_Init:
;__Lib_TFT_Defs.mbas,368 :: 		sub procedure TFT_Init(dim display_width, display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,369 :: 		__controller = _8BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 255
SH	R2, Offset(__Lib_TFT_Defs___controller+0)(GP)
;__Lib_TFT_Defs.mbas,370 :: 		if (Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init480
NOP	
J	L__TFT_Init32
NOP	
L__TFT_Init480:
;__Lib_TFT_Defs.mbas,371 :: 		TFT_Set_Index_Ptr     = @TFT_Set_Index
LUI	R2, hi_addr(_TFT_Set_Index+0)
ORI	R2, R2, lo_addr(_TFT_Set_Index+0)
SW	R2, Offset(_TFT_Set_Index_Ptr+0)(GP)
;__Lib_TFT_Defs.mbas,372 :: 		TFT_Write_Command_Ptr = @TFT_Write_Command
LUI	R2, hi_addr(_TFT_Write_Command+0)
ORI	R2, R2, lo_addr(_TFT_Write_Command+0)
SW	R2, Offset(_TFT_Write_Command_Ptr+0)(GP)
;__Lib_TFT_Defs.mbas,373 :: 		TFT_Write_Data_Ptr    = @TFT_Write_Data
LUI	R2, hi_addr(_TFT_Write_Data+0)
ORI	R2, R2, lo_addr(_TFT_Write_Data+0)
SW	R2, Offset(_TFT_Write_Data_Ptr+0)(GP)
L__TFT_Init32:
;__Lib_TFT_Defs.mbas,376 :: 		TFT_DISP_WIDTH = display_width
SH	R25, Offset(_TFT_DISP_WIDTH+0)(GP)
;__Lib_TFT_Defs.mbas,377 :: 		TFT_DISP_HEIGHT = display_height
SH	R26, Offset(_TFT_DISP_HEIGHT+0)(GP)
;__Lib_TFT_Defs.mbas,378 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init481
NOP	
J	L__TFT_Init35
NOP	
L__TFT_Init481:
;__Lib_TFT_Defs.mbas,379 :: 		TFT_Disp_Rotation = 0
SB	R0, Offset(__Lib_TFT_Defs_TFT_Disp_Rotation+0)(GP)
J	L__TFT_Init36
NOP	
;__Lib_TFT_Defs.mbas,380 :: 		else
L__TFT_Init35:
;__Lib_TFT_Defs.mbas,381 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
SB	R2, Offset(__Lib_TFT_Defs_TFT_Disp_Rotation+0)(GP)
;__Lib_TFT_Defs.mbas,382 :: 		end if
L__TFT_Init36:
;__Lib_TFT_Defs.mbas,384 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,385 :: 		TFT_Clear_Fonts()
JAL	_TFT_Clear_Fonts+0
NOP	
;__Lib_TFT_Defs.mbas,386 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
JAL	_TFT_Set_Brush+0
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,388 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
JAL	_TFT_Move_Cursor+0
NOP	
;__Lib_TFT_Defs.mbas,389 :: 		TFT_Set_DataPort_Direction()
JAL	__Lib_TFT_Defs_TFT_Set_DataPort_Direction+0
NOP	
;__Lib_TFT_Defs.mbas,391 :: 		TFT_Reset_Device()
JAL	_TFT_Reset_Device+0
NOP	
;__Lib_TFT_Defs.mbas,392 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address
LUI	R2, hi_addr(_TFT_Set_Address+0)
ORI	R2, R2, lo_addr(_TFT_Set_Address+0)
SW	R2, Offset(_TFT_Set_Address_Ptr+0)(GP)
;__Lib_TFT_Defs.mbas,393 :: 		end sub
L_end_TFT_Init:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
; end of _TFT_Init
_TFT_Init_Custom:
;__Lib_TFT_Defs.mbas,403 :: 		sub procedure TFT_Init_Custom(dim display_width, display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,404 :: 		__controller = _8BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 255
;__Lib_TFT_Defs.mbas,405 :: 		if (Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init_Custom484
NOP	
J	L__TFT_Init_Custom39
NOP	
L__TFT_Init_Custom484:
;__Lib_TFT_Defs.mbas,406 :: 		TFT_Set_Index_Ptr     = @TFT_Set_Index
;__Lib_TFT_Defs.mbas,407 :: 		TFT_Write_Command_Ptr = @TFT_Write_Command
;__Lib_TFT_Defs.mbas,408 :: 		TFT_Write_Data_Ptr    = @TFT_Write_Data
L__TFT_Init_Custom39:
;__Lib_TFT_Defs.mbas,411 :: 		TFT_DISP_WIDTH = display_width
;__Lib_TFT_Defs.mbas,412 :: 		TFT_DISP_HEIGHT = display_height
;__Lib_TFT_Defs.mbas,413 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init_Custom485
NOP	
J	L__TFT_Init_Custom42
NOP	
L__TFT_Init_Custom485:
;__Lib_TFT_Defs.mbas,414 :: 		TFT_Disp_Rotation = 0
J	L__TFT_Init_Custom43
NOP	
;__Lib_TFT_Defs.mbas,415 :: 		else
L__TFT_Init_Custom42:
;__Lib_TFT_Defs.mbas,416 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
;__Lib_TFT_Defs.mbas,417 :: 		end if
L__TFT_Init_Custom43:
;__Lib_TFT_Defs.mbas,419 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,420 :: 		TFT_Clear_Fonts()
NOP	
;__Lib_TFT_Defs.mbas,421 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,423 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,425 :: 		TFT_Reset_Device() 'return
NOP	
;__Lib_TFT_Defs.mbas,426 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address
;__Lib_TFT_Defs.mbas,427 :: 		end sub
L_end_TFT_Init_Custom:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
; end of _TFT_Init_Custom
_TFT_Set_Address_R61526:
;__Lib_TFT_Defs.mbas,435 :: 		sub procedure TFT_Set_Address_R61526(dim x as word y as word)
ADDIU	SP, SP, -12
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,436 :: 		TFT_Set_Index_Ptr(0x2A)
SW	R25, 4(SP)
SH	R26, 8(SP)
SH	R25, 10(SP)
ORI	R25, R0, 42
JALR	RA, R30
NOP	
LHU	R25, 10(SP)
;__Lib_TFT_Defs.mbas,437 :: 		TFT_Write_Command_Ptr(Hi(x))
SH	R25, 10(SP)
EXT	R25, R25, 8, 8
JALR	RA, R30
NOP	
LHU	R25, 10(SP)
;__Lib_TFT_Defs.mbas,438 :: 		TFT_Write_Command_Ptr(x)
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,439 :: 		TFT_Set_Index_Ptr(0x2B)
ORI	R25, R0, 43
JALR	RA, R30
NOP	
LHU	R26, 8(SP)
;__Lib_TFT_Defs.mbas,440 :: 		TFT_Write_Command_Ptr(Hi(y))
SH	R26, 8(SP)
EXT	R25, R26, 8, 8
JALR	RA, R30
NOP	
LHU	R26, 8(SP)
;__Lib_TFT_Defs.mbas,441 :: 		TFT_Write_Command_Ptr(y)
ANDI	R25, R26, 65535
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,442 :: 		TFT_Set_Index_Ptr(0x2C)
ORI	R25, R0, 44
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,443 :: 		end sub
L_end_TFT_Set_Address_R61526:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 12
JR	RA
NOP	
; end of _TFT_Set_Address_R61526
__Lib_TFT_Defs_TFT_Reset_R61526:
;__Lib_TFT_Defs.mbas,449 :: 		sub procedure TFT_Reset_R61526()
ADDIU	SP, SP, -8
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,451 :: 		TFT_RST = 0
SW	R25, 4(SP)
_LX	
_SX	
;__Lib_TFT_Defs.mbas,453 :: 		TFT_RST_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,456 :: 		TFT_RS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,458 :: 		TFT_RS_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,461 :: 		TFT_CS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,463 :: 		TFT_CS_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,465 :: 		TFT_RD_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,466 :: 		TFT_WR_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,467 :: 		TFT_RD = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,468 :: 		TFT_WR = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,471 :: 		Delay_1ms()
JAL	_Delay_1ms+0
NOP	
;__Lib_TFT_Defs.mbas,472 :: 		TFT_RST = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,473 :: 		Delay_10ms()
JAL	_Delay_10ms+0
NOP	
;__Lib_TFT_Defs.mbas,474 :: 		TFT_RST = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,475 :: 		Delay_100ms() Delay_10ms() Delay_10ms()  Delay_10ms()
JAL	_Delay_100ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
;__Lib_TFT_Defs.mbas,477 :: 		TFT_CS = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,479 :: 		TFT_Set_Index_Ptr(0xB0)'Manufacturer Command Access Protect
ORI	R25, R0, 176
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,480 :: 		TFT_Write_Command_Ptr(0x3F)
ORI	R25, R0, 63
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,481 :: 		TFT_Write_Command_Ptr(0x3F)
ORI	R25, R0, 63
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,482 :: 		Delay_100ms() Delay_100ms() Delay_10ms() Delay_10ms()
JAL	_Delay_100ms+0
NOP	
JAL	_Delay_100ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
;__Lib_TFT_Defs.mbas,483 :: 		Delay_10ms() Delay_10ms() Delay_10ms() Delay_10ms()
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
;__Lib_TFT_Defs.mbas,485 :: 		TFT_Set_Index_Ptr(0xFE)
ORI	R25, R0, 254
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,486 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,487 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,488 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,489 :: 		TFT_Write_Command_Ptr(0x21)
ORI	R25, R0, 33
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,490 :: 		TFT_Write_Command_Ptr(0xB4)
ORI	R25, R0, 180
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,492 :: 		TFT_Set_Index_Ptr(0xB3)'Frame Memory Access and Interface Setting
ORI	R25, R0, 179
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,493 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,494 :: 		TFT_Write_Command_Ptr(0x10)
ORI	R25, R0, 16
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,496 :: 		TFT_Set_Index_Ptr(0xE0)'NVM Access Control
ORI	R25, R0, 224
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,497 :: 		TFT_Write_Command_Ptr(0x00)'NVAE: NVM access enable register. NVM access is enabled when NVAE=1.
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,498 :: 		TFT_Write_Command_Ptr(0x40)'FTT: NVM control bit.
ORI	R25, R0, 64
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,499 :: 		Delay_100ms() Delay_100ms()
JAL	_Delay_100ms+0
NOP	
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,501 :: 		TFT_Set_Index_Ptr(0xB3)
ORI	R25, R0, 179
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,502 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,503 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,505 :: 		TFT_Set_Index_Ptr(0xFE)
ORI	R25, R0, 254
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,506 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,507 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,508 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,509 :: 		TFT_Write_Command_Ptr(0x21)
ORI	R25, R0, 33
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,510 :: 		TFT_Write_Command_Ptr(0x30)
ORI	R25, R0, 48
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,512 :: 		TFT_Set_Index_Ptr(0xB0)
ORI	R25, R0, 176
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,513 :: 		TFT_Write_Command_Ptr(0x3F)
ORI	R25, R0, 63
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,514 :: 		TFT_Write_Command_Ptr(0x3F)
ORI	R25, R0, 63
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,516 :: 		TFT_Set_Index_Ptr(0xB3)
ORI	R25, R0, 179
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,517 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,518 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,519 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,520 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,522 :: 		TFT_Set_Index_Ptr(0xB4)
ORI	R25, R0, 180
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,523 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,525 :: 		TFT_Set_Index_Ptr(0xC0)
ORI	R25, R0, 192
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,526 :: 		TFT_Write_Command_Ptr(0x03)'GIP REV  SM GS BGR SS
ORI	R25, R0, 3
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,527 :: 		TFT_Write_Command_Ptr(0x4F)
ORI	R25, R0, 79
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,528 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,529 :: 		TFT_Write_Command_Ptr(0x10)
ORI	R25, R0, 16
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,530 :: 		TFT_Write_Command_Ptr(0xA0)'BLV=0 LINE
ORI	R25, R0, 160
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,531 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,532 :: 		TFT_Write_Command_Ptr(0x01)
ORI	R25, R0, 1
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,533 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,535 :: 		TFT_Set_Index_Ptr(0xC1)
ORI	R25, R0, 193
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,536 :: 		TFT_Write_Command_Ptr(0x01)'BC0   Frame inversion(0)/Line inversion(1)
ORI	R25, R0, 1
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,537 :: 		TFT_Write_Command_Ptr(0x02)'DIV0[1:0]  800kHz
ORI	R25, R0, 2
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,538 :: 		TFT_Write_Command_Ptr(0x20)'RTN0[5:0]   clocks    21
ORI	R25, R0, 32
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,539 :: 		TFT_Write_Command_Ptr(0x06)'BP0[7:0]   6 lines
ORI	R25, R0, 6
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,540 :: 		TFT_Write_Command_Ptr(0x06)'FP0[7:0]   6 lines
ORI	R25, R0, 6
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,541 :: 		Delay_100ms() Delay_100ms()
JAL	_Delay_100ms+0
NOP	
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,543 :: 		TFT_Set_Index_Ptr(0xC3)  'PRTIAL MODE
ORI	R25, R0, 195
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,544 :: 		TFT_Write_Command_Ptr(0x01)'BC2
ORI	R25, R0, 1
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,545 :: 		TFT_Write_Command_Ptr(0x00)'DIV2[1:0]
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,546 :: 		TFT_Write_Command_Ptr(0x21)'RTN2[5:0]
ORI	R25, R0, 33
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,547 :: 		TFT_Write_Command_Ptr(0x08)'BP2[7:0]
ORI	R25, R0, 8
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,548 :: 		TFT_Write_Command_Ptr(0x08)'FP2[7:0]
ORI	R25, R0, 8
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,549 :: 		Delay_100ms() Delay_100ms()
JAL	_Delay_100ms+0
NOP	
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,551 :: 		TFT_Set_Index_Ptr(0xC4)
ORI	R25, R0, 196
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,552 :: 		TFT_Write_Command_Ptr(0x11)
ORI	R25, R0, 17
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,553 :: 		TFT_Write_Command_Ptr(0x01)
ORI	R25, R0, 1
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,554 :: 		TFT_Write_Command_Ptr(0x43)
ORI	R25, R0, 67
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,555 :: 		TFT_Write_Command_Ptr(0x04)
ORI	R25, R0, 4
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,557 :: 		TFT_Set_Index_Ptr(0x0c8)
ORI	R25, R0, 200
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,558 :: 		TFT_Write_Command_Ptr(0x0A)
ORI	R25, R0, 10
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,559 :: 		TFT_Write_Command_Ptr(0x0D)
ORI	R25, R0, 13
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,560 :: 		TFT_Write_Command_Ptr(0x0A)
ORI	R25, R0, 10
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,561 :: 		TFT_Write_Command_Ptr(0x13)
ORI	R25, R0, 19
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,562 :: 		TFT_Write_Command_Ptr(0x16)
ORI	R25, R0, 22
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,563 :: 		TFT_Write_Command_Ptr(0x13)
ORI	R25, R0, 19
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,564 :: 		TFT_Write_Command_Ptr(0x08)
ORI	R25, R0, 8
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,565 :: 		TFT_Write_Command_Ptr(0x0A)
ORI	R25, R0, 10
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,566 :: 		TFT_Write_Command_Ptr(0x03)
ORI	R25, R0, 3
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,567 :: 		TFT_Write_Command_Ptr(0x06)
ORI	R25, R0, 6
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,568 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,569 :: 		TFT_Write_Command_Ptr(0x07)
ORI	R25, R0, 7
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,570 :: 		TFT_Write_Command_Ptr(0x09)
ORI	R25, R0, 9
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,571 :: 		TFT_Write_Command_Ptr(0x09)
ORI	R25, R0, 9
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,572 :: 		TFT_Write_Command_Ptr(0x0E)
ORI	R25, R0, 14
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,573 :: 		TFT_Write_Command_Ptr(0x12)
ORI	R25, R0, 18
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,574 :: 		TFT_Write_Command_Ptr(0x12)
ORI	R25, R0, 18
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,575 :: 		TFT_Write_Command_Ptr(0x0A)
ORI	R25, R0, 10
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,576 :: 		TFT_Write_Command_Ptr(0x10)
ORI	R25, R0, 16
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,577 :: 		TFT_Write_Command_Ptr(0x04)
ORI	R25, R0, 4
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,578 :: 		TFT_Write_Command_Ptr(0x0D)
ORI	R25, R0, 13
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,579 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,581 :: 		TFT_Set_Index_Ptr(0x0c9)
ORI	R25, R0, 201
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,582 :: 		TFT_Write_Command_Ptr(0x0A)
ORI	R25, R0, 10
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,583 :: 		TFT_Write_Command_Ptr(0x0D)
ORI	R25, R0, 13
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,584 :: 		TFT_Write_Command_Ptr(0x0A)
ORI	R25, R0, 10
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,585 :: 		TFT_Write_Command_Ptr(0x13)
ORI	R25, R0, 19
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,586 :: 		TFT_Write_Command_Ptr(0x16)
ORI	R25, R0, 22
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,587 :: 		TFT_Write_Command_Ptr(0x13)
ORI	R25, R0, 19
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,588 :: 		TFT_Write_Command_Ptr(0x08)
ORI	R25, R0, 8
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,589 :: 		TFT_Write_Command_Ptr(0x0A)
ORI	R25, R0, 10
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,590 :: 		TFT_Write_Command_Ptr(0x03)
ORI	R25, R0, 3
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,591 :: 		TFT_Write_Command_Ptr(0x06)
ORI	R25, R0, 6
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,592 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,593 :: 		TFT_Write_Command_Ptr(0x07)
ORI	R25, R0, 7
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,594 :: 		TFT_Write_Command_Ptr(0x09)
ORI	R25, R0, 9
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,595 :: 		TFT_Write_Command_Ptr(0x09)
ORI	R25, R0, 9
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,596 :: 		TFT_Write_Command_Ptr(0x0E)
ORI	R25, R0, 14
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,597 :: 		TFT_Write_Command_Ptr(0x12)
ORI	R25, R0, 18
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,598 :: 		TFT_Write_Command_Ptr(0x12)
ORI	R25, R0, 18
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,599 :: 		TFT_Write_Command_Ptr(0x0A)
ORI	R25, R0, 10
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,600 :: 		TFT_Write_Command_Ptr(0x10)
ORI	R25, R0, 16
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,601 :: 		TFT_Write_Command_Ptr(0x04)
ORI	R25, R0, 4
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,602 :: 		TFT_Write_Command_Ptr(0x0D)
ORI	R25, R0, 13
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,603 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,605 :: 		TFT_Set_Index_Ptr(0x0ca)
ORI	R25, R0, 202
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,606 :: 		TFT_Write_Command_Ptr(0x0A)
ORI	R25, R0, 10
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,607 :: 		TFT_Write_Command_Ptr(0x0D)
ORI	R25, R0, 13
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,608 :: 		TFT_Write_Command_Ptr(0x0A)
ORI	R25, R0, 10
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,609 :: 		TFT_Write_Command_Ptr(0x13)
ORI	R25, R0, 19
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,610 :: 		TFT_Write_Command_Ptr(0x16)
ORI	R25, R0, 22
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,611 :: 		TFT_Write_Command_Ptr(0x13)
ORI	R25, R0, 19
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,612 :: 		TFT_Write_Command_Ptr(0x08)
ORI	R25, R0, 8
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,613 :: 		TFT_Write_Command_Ptr(0x0A)
ORI	R25, R0, 10
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,614 :: 		TFT_Write_Command_Ptr(0x03)
ORI	R25, R0, 3
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,615 :: 		TFT_Write_Command_Ptr(0x06)
ORI	R25, R0, 6
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,616 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,617 :: 		TFT_Write_Command_Ptr(0x07)
ORI	R25, R0, 7
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,618 :: 		TFT_Write_Command_Ptr(0x09)
ORI	R25, R0, 9
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,619 :: 		TFT_Write_Command_Ptr(0x09)
ORI	R25, R0, 9
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,620 :: 		TFT_Write_Command_Ptr(0x0E)
ORI	R25, R0, 14
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,621 :: 		TFT_Write_Command_Ptr(0x12)
ORI	R25, R0, 18
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,622 :: 		TFT_Write_Command_Ptr(0x12)
ORI	R25, R0, 18
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,623 :: 		TFT_Write_Command_Ptr(0x0A)
ORI	R25, R0, 10
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,624 :: 		TFT_Write_Command_Ptr(0x10)
ORI	R25, R0, 16
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,625 :: 		TFT_Write_Command_Ptr(0x04)
ORI	R25, R0, 4
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,626 :: 		TFT_Write_Command_Ptr(0x0D)
ORI	R25, R0, 13
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,627 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,629 :: 		TFT_Set_Index_Ptr(0x0cB)
ORI	R25, R0, 203
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,630 :: 		TFT_Write_Command_Ptr(0x0A)
ORI	R25, R0, 10
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,631 :: 		TFT_Write_Command_Ptr(0x0D)
ORI	R25, R0, 13
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,632 :: 		TFT_Write_Command_Ptr(0x0A)
ORI	R25, R0, 10
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,633 :: 		TFT_Write_Command_Ptr(0x13)
ORI	R25, R0, 19
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,634 :: 		TFT_Write_Command_Ptr(0x16)
ORI	R25, R0, 22
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,635 :: 		TFT_Write_Command_Ptr(0x13)
ORI	R25, R0, 19
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,636 :: 		TFT_Write_Command_Ptr(0x08)
ORI	R25, R0, 8
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,637 :: 		TFT_Write_Command_Ptr(0x0A)
ORI	R25, R0, 10
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,638 :: 		TFT_Write_Command_Ptr(0x03)
ORI	R25, R0, 3
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,639 :: 		TFT_Write_Command_Ptr(0x06)
ORI	R25, R0, 6
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,640 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,641 :: 		TFT_Write_Command_Ptr(0x07)
ORI	R25, R0, 7
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,642 :: 		TFT_Write_Command_Ptr(0x09)
ORI	R25, R0, 9
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,643 :: 		TFT_Write_Command_Ptr(0x09)
ORI	R25, R0, 9
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,644 :: 		TFT_Write_Command_Ptr(0x0E)
ORI	R25, R0, 14
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,645 :: 		TFT_Write_Command_Ptr(0x12)
ORI	R25, R0, 18
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,646 :: 		TFT_Write_Command_Ptr(0x12)
ORI	R25, R0, 18
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,647 :: 		TFT_Write_Command_Ptr(0x0A)
ORI	R25, R0, 10
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,648 :: 		TFT_Write_Command_Ptr(0x10)
ORI	R25, R0, 16
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,649 :: 		TFT_Write_Command_Ptr(0x04)
ORI	R25, R0, 4
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,650 :: 		TFT_Write_Command_Ptr(0x0D)
ORI	R25, R0, 13
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,651 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,653 :: 		TFT_Set_Index_Ptr(0xD0)
ORI	R25, R0, 208
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,654 :: 		TFT_Write_Command_Ptr(0x63)
ORI	R25, R0, 99
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,655 :: 		TFT_Write_Command_Ptr(0x53)
ORI	R25, R0, 83
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,656 :: 		TFT_Write_Command_Ptr(0x82)'VC2[2:0]=010,VCI2=5V
ORI	R25, R0, 130
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,657 :: 		TFT_Write_Command_Ptr(0x33)'33,VREG=4.7V
ORI	R25, R0, 51
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,659 :: 		TFT_Set_Index_Ptr(0xD1)
ORI	R25, R0, 209
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,660 :: 		TFT_Write_Command_Ptr(0x60)'VCOMH=VREG x 0.876      69
ORI	R25, R0, 96
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,661 :: 		TFT_Write_Command_Ptr(0x69)'VDV=VREG x 1.064
ORI	R25, R0, 105
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,663 :: 		TFT_Set_Index_Ptr(0xD2)'DC10[2:0], DC12[2:0]
ORI	R25, R0, 210
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,664 :: 		TFT_Write_Command_Ptr(0x03)
ORI	R25, R0, 3
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,665 :: 		TFT_Write_Command_Ptr(0x24)
ORI	R25, R0, 36
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,667 :: 		TFT_Set_Index_Ptr(0xD4)
ORI	R25, R0, 212
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,668 :: 		TFT_Write_Command_Ptr(0x03)
ORI	R25, R0, 3
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,669 :: 		TFT_Write_Command_Ptr(0x24)
ORI	R25, R0, 36
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,671 :: 		TFT_Set_Index_Ptr(0xE2)'NVM Load Control
ORI	R25, R0, 226
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,672 :: 		TFT_Write_Command_Ptr(0x3F)
ORI	R25, R0, 63
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,674 :: 		TFT_Set_Index_Ptr(0x35)'set_tear_on
ORI	R25, R0, 53
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,675 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,677 :: 		TFT_Set_Index_Ptr(0x36)
ORI	R25, R0, 54
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,678 :: 		if (TFT_Disp_Rotation = 90) then
ORI	R2, R0, 90
BEQ	R3, R2, L___Lib_TFT_Defs_TFT_Reset_R61526488
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_R6152647
NOP	
L___Lib_TFT_Defs_TFT_Reset_R61526488:
;__Lib_TFT_Defs.mbas,679 :: 		if (Is_TFT_Rotated_180() = 1) then
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BEQ	R3, R2, L___Lib_TFT_Defs_TFT_Reset_R61526489
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_R6152650
NOP	
L___Lib_TFT_Defs_TFT_Reset_R61526489:
;__Lib_TFT_Defs.mbas,680 :: 		TFT_Write_Command_Ptr(0xC0)
ORI	R25, R0, 192
JALR	RA, R30
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_R6152651
NOP	
;__Lib_TFT_Defs.mbas,681 :: 		else
L___Lib_TFT_Defs_TFT_Reset_R6152650:
;__Lib_TFT_Defs.mbas,682 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,683 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_R6152651:
J	L___Lib_TFT_Defs_TFT_Reset_R6152648
NOP	
;__Lib_TFT_Defs.mbas,684 :: 		else
L___Lib_TFT_Defs_TFT_Reset_R6152647:
;__Lib_TFT_Defs.mbas,685 :: 		if (Is_TFT_Rotated_180() = 1) then
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BEQ	R3, R2, L___Lib_TFT_Defs_TFT_Reset_R61526490
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_R6152653
NOP	
L___Lib_TFT_Defs_TFT_Reset_R61526490:
;__Lib_TFT_Defs.mbas,686 :: 		TFT_Write_Command_Ptr(0x70)
ORI	R25, R0, 112
JALR	RA, R30
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_R6152654
NOP	
;__Lib_TFT_Defs.mbas,687 :: 		else
L___Lib_TFT_Defs_TFT_Reset_R6152653:
;__Lib_TFT_Defs.mbas,688 :: 		TFT_Write_Command_Ptr(0x21)
ORI	R25, R0, 33
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,689 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_R6152654:
;__Lib_TFT_Defs.mbas,690 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_R6152648:
;__Lib_TFT_Defs.mbas,692 :: 		TFT_Set_Index_Ptr(0x3A)          'set_pixel_format
ORI	R25, R0, 58
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,693 :: 		TFT_Write_Command_Ptr(0x55)
ORI	R25, R0, 85
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,695 :: 		TFT_Set_Index_Ptr(0x2A)          'set_column_address
ORI	R25, R0, 42
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,696 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,697 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,698 :: 		TFT_Write_Command_Ptr((TFT_DISP_WIDTH-1) >> 8)
LHU	R2, Offset(_TFT_DISP_WIDTH+0)(GP)
ADDIU	R2, R2, -1
ANDI	R2, R2, 65535
SRL	R2, R2, 8
ANDI	R25, R2, 65535
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,699 :: 		TFT_Write_Command_Ptr(TFT_DISP_WIDTH-1)
ADDIU	R2, R2, -1
ANDI	R25, R2, 255
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,701 :: 		TFT_Set_Index_Ptr(0x2B)          'set_page_address:
ORI	R25, R0, 43
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,702 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,703 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,704 :: 		TFT_Write_Command_Ptr((TFT_DISP_HEIGHT-1) >> 8)
LHU	R2, Offset(_TFT_DISP_HEIGHT+0)(GP)
ADDIU	R2, R2, -1
ANDI	R2, R2, 65535
SRL	R2, R2, 8
ANDI	R25, R2, 65535
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,705 :: 		TFT_Write_Command_Ptr(TFT_DISP_HEIGHT-1)
ADDIU	R2, R2, -1
ANDI	R25, R2, 255
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,707 :: 		TFT_Set_Index_Ptr(0x2C)          'write_memory_start:
ORI	R25, R0, 44
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,708 :: 		TFT_Set_Index_Ptr(0x11)          'exit_sleep_mode
ORI	R25, R0, 17
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,709 :: 		Delay_100ms() Delay_100ms()
JAL	_Delay_100ms+0
NOP	
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,710 :: 		TFT_Set_Index_Ptr(0x29)          'set_display_on
ORI	R25, R0, 41
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,711 :: 		Delay_100ms() Delay_100ms()
JAL	_Delay_100ms+0
NOP	
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,713 :: 		TFT_CS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,714 :: 		end sub
L_end_TFT_Reset_R61526:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 8
JR	RA
NOP	
; end of __Lib_TFT_Defs_TFT_Reset_R61526
_TFT_Init_R61526:
;__Lib_TFT_Defs.mbas,721 :: 		sub procedure TFT_Init_R61526(dim display_width as word display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,722 :: 		__controller = _8BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 255
;__Lib_TFT_Defs.mbas,723 :: 		if (Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init_R61526493
NOP	
J	L__TFT_Init_R6152657
NOP	
L__TFT_Init_R61526493:
;__Lib_TFT_Defs.mbas,724 :: 		TFT_Set_Index_Ptr     = @TFT_Set_Index
;__Lib_TFT_Defs.mbas,725 :: 		TFT_Write_Command_Ptr = @TFT_Write_Command
;__Lib_TFT_Defs.mbas,726 :: 		TFT_Write_Data_Ptr    = @TFT_Write_Data
L__TFT_Init_R6152657:
;__Lib_TFT_Defs.mbas,729 :: 		TFT_DISP_WIDTH = display_width
;__Lib_TFT_Defs.mbas,730 :: 		TFT_DISP_HEIGHT = display_height
;__Lib_TFT_Defs.mbas,731 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init_R61526494
NOP	
J	L__TFT_Init_R6152660
NOP	
L__TFT_Init_R61526494:
;__Lib_TFT_Defs.mbas,732 :: 		TFT_Disp_Rotation = 0
J	L__TFT_Init_R6152661
NOP	
;__Lib_TFT_Defs.mbas,733 :: 		else
L__TFT_Init_R6152660:
;__Lib_TFT_Defs.mbas,734 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
;__Lib_TFT_Defs.mbas,735 :: 		end if
L__TFT_Init_R6152661:
;__Lib_TFT_Defs.mbas,737 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,738 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,740 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,741 :: 		TFT_Clear_Fonts()
NOP	
;__Lib_TFT_Defs.mbas,742 :: 		TFT_Set_DataPort_Direction()
NOP	
;__Lib_TFT_Defs.mbas,744 :: 		TFT_Reset_R61526()
JAL	__Lib_TFT_Defs_TFT_Reset_R61526+0
NOP	
;__Lib_TFT_Defs.mbas,745 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address_R61526
LUI	R2, hi_addr(_TFT_Set_Address_R61526+0)
ORI	R2, R2, lo_addr(_TFT_Set_Address_R61526+0)
;__Lib_TFT_Defs.mbas,746 :: 		end sub
L_end_TFT_Init_R61526:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
; end of _TFT_Init_R61526
_TFT_Init_R61526_Custom:
;__Lib_TFT_Defs.mbas,756 :: 		sub procedure TFT_Init_R61526_Custom(dim display_width as word display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,757 :: 		__controller = _8BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 255
;__Lib_TFT_Defs.mbas,758 :: 		if (Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init_R61526_Custom497
NOP	
J	L__TFT_Init_R61526_Custom64
NOP	
L__TFT_Init_R61526_Custom497:
;__Lib_TFT_Defs.mbas,759 :: 		TFT_Set_Index_Ptr     = @TFT_Set_Index
;__Lib_TFT_Defs.mbas,760 :: 		TFT_Write_Command_Ptr = @TFT_Write_Command
;__Lib_TFT_Defs.mbas,761 :: 		TFT_Write_Data_Ptr    = @TFT_Write_Data
L__TFT_Init_R61526_Custom64:
;__Lib_TFT_Defs.mbas,764 :: 		TFT_DISP_WIDTH = display_width
;__Lib_TFT_Defs.mbas,765 :: 		TFT_DISP_HEIGHT = display_height
;__Lib_TFT_Defs.mbas,766 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init_R61526_Custom498
NOP	
J	L__TFT_Init_R61526_Custom67
NOP	
L__TFT_Init_R61526_Custom498:
;__Lib_TFT_Defs.mbas,767 :: 		TFT_Disp_Rotation = 0
J	L__TFT_Init_R61526_Custom68
NOP	
;__Lib_TFT_Defs.mbas,768 :: 		else
L__TFT_Init_R61526_Custom67:
;__Lib_TFT_Defs.mbas,769 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
;__Lib_TFT_Defs.mbas,770 :: 		end if
L__TFT_Init_R61526_Custom68:
;__Lib_TFT_Defs.mbas,772 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,773 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,775 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,776 :: 		TFT_Clear_Fonts()
NOP	
;__Lib_TFT_Defs.mbas,778 :: 		TFT_Reset_R61526()
NOP	
;__Lib_TFT_Defs.mbas,779 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address_R61526
;__Lib_TFT_Defs.mbas,780 :: 		end sub
L_end_TFT_Init_R61526_Custom:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
; end of _TFT_Init_R61526_Custom
_TFT_Set_Address_SST7715R:
;__Lib_TFT_Defs.mbas,789 :: 		sub procedure TFT_Set_Address_SST7715R(dim x as word y as word)
ADDIU	SP, SP, -12
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,790 :: 		TFT_Set_Index_Ptr(0x2A)
SW	R25, 4(SP)
SH	R26, 8(SP)
SH	R25, 10(SP)
ORI	R25, R0, 42
JALR	RA, R30
NOP	
LHU	R25, 10(SP)
;__Lib_TFT_Defs.mbas,791 :: 		TFT_Write_Command_Ptr(x >> 8)
ANDI	R2, R25, 65535
SRL	R2, R2, 8
SH	R25, 10(SP)
ANDI	R25, R2, 65535
JALR	RA, R30
NOP	
LHU	R25, 10(SP)
;__Lib_TFT_Defs.mbas,792 :: 		TFT_Write_Command_Ptr(x)
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,793 :: 		TFT_Set_Index_Ptr(0x2B)
ORI	R25, R0, 43
JALR	RA, R30
NOP	
LHU	R26, 8(SP)
;__Lib_TFT_Defs.mbas,794 :: 		TFT_Write_Command_Ptr(y >> 8)
ANDI	R2, R26, 65535
SRL	R2, R2, 8
SH	R26, 8(SP)
ANDI	R25, R2, 65535
JALR	RA, R30
NOP	
LHU	R26, 8(SP)
;__Lib_TFT_Defs.mbas,795 :: 		TFT_Write_Command_Ptr(y)
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,796 :: 		TFT_Set_Index_Ptr(0x2C)
ORI	R25, R0, 44
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,797 :: 		end sub
L_end_TFT_Set_Address_SST7715R:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 12
JR	RA
NOP	
; end of _TFT_Set_Address_SST7715R
__Lib_TFT_Defs_TFT_Reset_SST7715R:
;__Lib_TFT_Defs.mbas,803 :: 		sub procedure TFT_Reset_SST7715R()
ADDIU	SP, SP, -8
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,805 :: 		TFT_RST = 0
SW	R25, 4(SP)
_LX	
_SX	
;__Lib_TFT_Defs.mbas,807 :: 		TFT_RST_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,810 :: 		TFT_RS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,812 :: 		TFT_RS_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,815 :: 		TFT_CS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,817 :: 		TFT_CS_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,819 :: 		TFT_RD_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,820 :: 		TFT_WR_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,821 :: 		TFT_RD = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,822 :: 		TFT_WR = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,825 :: 		TFT_RST = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,826 :: 		Delay_1ms()
JAL	_Delay_1ms+0
NOP	
;__Lib_TFT_Defs.mbas,827 :: 		TFT_RST = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,828 :: 		Delay_10ms()
JAL	_Delay_10ms+0
NOP	
;__Lib_TFT_Defs.mbas,829 :: 		TFT_RST = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,830 :: 		Delay_100ms() Delay_10ms() Delay_10ms()
JAL	_Delay_100ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
;__Lib_TFT_Defs.mbas,832 :: 		TFT_CS = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,834 :: 		TFT_Set_Index_Ptr(0x11) 'Exit Sleep
ORI	R25, R0, 17
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,835 :: 		Delay_100ms() Delay_10ms() Delay_10ms() Delay_10ms()
JAL	_Delay_100ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
;__Lib_TFT_Defs.mbas,837 :: 		TFT_Set_Index_Ptr(0xB1)
ORI	R25, R0, 177
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,838 :: 		TFT_Write_Command_Ptr(0x02)
ORI	R25, R0, 2
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,839 :: 		TFT_Write_Command_Ptr(0x23)
ORI	R25, R0, 35
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,840 :: 		TFT_Write_Command_Ptr(0x22)
ORI	R25, R0, 34
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,842 :: 		TFT_Set_Index_Ptr(0xB2)
ORI	R25, R0, 178
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,843 :: 		TFT_Write_Command_Ptr(0x02)
ORI	R25, R0, 2
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,844 :: 		TFT_Write_Command_Ptr(0x23)
ORI	R25, R0, 35
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,845 :: 		TFT_Write_Command_Ptr(0x22)
ORI	R25, R0, 34
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,847 :: 		TFT_Set_Index_Ptr(0xB3)
ORI	R25, R0, 179
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,848 :: 		TFT_Write_Command_Ptr(0x02)
ORI	R25, R0, 2
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,849 :: 		TFT_Write_Command_Ptr(0x23)
ORI	R25, R0, 35
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,850 :: 		TFT_Write_Command_Ptr(0x22)
ORI	R25, R0, 34
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,851 :: 		TFT_Write_Command_Ptr(0x02)
ORI	R25, R0, 2
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,852 :: 		TFT_Write_Command_Ptr(0x23)
ORI	R25, R0, 35
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,853 :: 		TFT_Write_Command_Ptr(0x22)
ORI	R25, R0, 34
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,855 :: 		TFT_Set_Index_Ptr(0xB4)
ORI	R25, R0, 180
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,856 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,858 :: 		TFT_Set_Index_Ptr(0xC0)
ORI	R25, R0, 192
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,859 :: 		TFT_Write_Command_Ptr(0xA3)
ORI	R25, R0, 163
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,860 :: 		TFT_Write_Command_Ptr(0x02)
ORI	R25, R0, 2
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,861 :: 		TFT_Write_Command_Ptr(0x84)
ORI	R25, R0, 132
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,863 :: 		TFT_Set_Index_Ptr(0xC1)
ORI	R25, R0, 193
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,864 :: 		TFT_Write_Command_Ptr(0xC5)
ORI	R25, R0, 197
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,866 :: 		TFT_Set_Index_Ptr(0xC2)
ORI	R25, R0, 194
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,867 :: 		TFT_Write_Command_Ptr(0x0A)
ORI	R25, R0, 10
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,868 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,870 :: 		TFT_Set_Index_Ptr(0xC3)
ORI	R25, R0, 195
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,871 :: 		TFT_Write_Command_Ptr(0x8A)
ORI	R25, R0, 138
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,872 :: 		TFT_Write_Command_Ptr(0x2A)
ORI	R25, R0, 42
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,874 :: 		TFT_Set_Index_Ptr(0xC4)
ORI	R25, R0, 196
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,875 :: 		TFT_Write_Command_Ptr(0x8A)
ORI	R25, R0, 138
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,876 :: 		TFT_Write_Command_Ptr(0xEE)
ORI	R25, R0, 238
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,878 :: 		TFT_Set_Index_Ptr(0xC5)
ORI	R25, R0, 197
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,879 :: 		TFT_Write_Command_Ptr(0x07)
ORI	R25, R0, 7
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,881 :: 		TFT_Set_Index_Ptr(0x36)
ORI	R25, R0, 54
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,882 :: 		if (TFT_Disp_Rotation = 90) then
ORI	R2, R0, 90
BEQ	R3, R2, L___Lib_TFT_Defs_TFT_Reset_SST7715R501
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_SST7715R72
NOP	
L___Lib_TFT_Defs_TFT_Reset_SST7715R501:
;__Lib_TFT_Defs.mbas,883 :: 		if (Is_TFT_Rotated_180() = 1) then
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BEQ	R3, R2, L___Lib_TFT_Defs_TFT_Reset_SST7715R502
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_SST7715R75
NOP	
L___Lib_TFT_Defs_TFT_Reset_SST7715R502:
;__Lib_TFT_Defs.mbas,884 :: 		TFT_Write_Command_Ptr(0xA0)
ORI	R25, R0, 160
JALR	RA, R30
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_SST7715R76
NOP	
;__Lib_TFT_Defs.mbas,885 :: 		else
L___Lib_TFT_Defs_TFT_Reset_SST7715R75:
;__Lib_TFT_Defs.mbas,886 :: 		TFT_Write_Command_Ptr(0x60)
ORI	R25, R0, 96
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,887 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_SST7715R76:
J	L___Lib_TFT_Defs_TFT_Reset_SST7715R73
NOP	
;__Lib_TFT_Defs.mbas,888 :: 		else
L___Lib_TFT_Defs_TFT_Reset_SST7715R72:
;__Lib_TFT_Defs.mbas,889 :: 		if (Is_TFT_Rotated_180() = 1) then
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BEQ	R3, R2, L___Lib_TFT_Defs_TFT_Reset_SST7715R503
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_SST7715R78
NOP	
L___Lib_TFT_Defs_TFT_Reset_SST7715R503:
;__Lib_TFT_Defs.mbas,890 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_SST7715R79
NOP	
;__Lib_TFT_Defs.mbas,891 :: 		else
L___Lib_TFT_Defs_TFT_Reset_SST7715R78:
;__Lib_TFT_Defs.mbas,892 :: 		TFT_Write_Command_Ptr(0xC0)
ORI	R25, R0, 192
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,893 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_SST7715R79:
;__Lib_TFT_Defs.mbas,894 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_SST7715R73:
;__Lib_TFT_Defs.mbas,896 :: 		TFT_Set_Index_Ptr(0x3A)
ORI	R25, R0, 58
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,897 :: 		TFT_Write_Command_Ptr(0x55)  ' RGB 565
ORI	R25, R0, 85
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,899 :: 		TFT_Set_Index_Ptr(0xF0)
ORI	R25, R0, 240
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,900 :: 		TFT_Write_Command_Ptr(0x01)
ORI	R25, R0, 1
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,902 :: 		TFT_Set_Index_Ptr(0xF6)
ORI	R25, R0, 246
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,903 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,905 :: 		TFT_Set_Index_Ptr(0xE0)
ORI	R25, R0, 224
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,906 :: 		TFT_Write_Command_Ptr(0x03)'p1
ORI	R25, R0, 3
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,907 :: 		TFT_Write_Command_Ptr(0x1B)'p2
ORI	R25, R0, 27
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,908 :: 		TFT_Write_Command_Ptr(0x09)'p3
ORI	R25, R0, 9
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,909 :: 		TFT_Write_Command_Ptr(0x0E)'p4
ORI	R25, R0, 14
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,910 :: 		TFT_Write_Command_Ptr(0x32)'p5
ORI	R25, R0, 50
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,911 :: 		TFT_Write_Command_Ptr(0x2D)'p6
ORI	R25, R0, 45
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,912 :: 		TFT_Write_Command_Ptr(0x28)'p7
ORI	R25, R0, 40
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,913 :: 		TFT_Write_Command_Ptr(0x2C)'p8
ORI	R25, R0, 44
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,914 :: 		TFT_Write_Command_Ptr(0x2B)'p9
ORI	R25, R0, 43
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,915 :: 		TFT_Write_Command_Ptr(0x29)'p10
ORI	R25, R0, 41
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,916 :: 		TFT_Write_Command_Ptr(0x30)'p11
ORI	R25, R0, 48
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,917 :: 		TFT_Write_Command_Ptr(0x3B)'p12
ORI	R25, R0, 59
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,918 :: 		TFT_Write_Command_Ptr(0x00)'p13
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,919 :: 		TFT_Write_Command_Ptr(0x01)'p14
ORI	R25, R0, 1
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,920 :: 		TFT_Write_Command_Ptr(0x02)'p15
ORI	R25, R0, 2
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,921 :: 		TFT_Write_Command_Ptr(0x10)'p16
ORI	R25, R0, 16
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,923 :: 		TFT_Set_Index_Ptr(0xE1)
ORI	R25, R0, 225
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,924 :: 		TFT_Write_Command_Ptr(0x03)'p1
ORI	R25, R0, 3
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,925 :: 		TFT_Write_Command_Ptr(0x1B)'p2
ORI	R25, R0, 27
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,926 :: 		TFT_Write_Command_Ptr(0x09)'p3
ORI	R25, R0, 9
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,927 :: 		TFT_Write_Command_Ptr(0x0E)'p4
ORI	R25, R0, 14
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,928 :: 		TFT_Write_Command_Ptr(0x32)'p5
ORI	R25, R0, 50
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,929 :: 		TFT_Write_Command_Ptr(0x2E)'p6
ORI	R25, R0, 46
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,930 :: 		TFT_Write_Command_Ptr(0x28)'p7
ORI	R25, R0, 40
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,931 :: 		TFT_Write_Command_Ptr(0x2C)'p8
ORI	R25, R0, 44
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,932 :: 		TFT_Write_Command_Ptr(0x2B)'p9
ORI	R25, R0, 43
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,933 :: 		TFT_Write_Command_Ptr(0x28)'p10
ORI	R25, R0, 40
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,934 :: 		TFT_Write_Command_Ptr(0x31)'p11
ORI	R25, R0, 49
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,935 :: 		TFT_Write_Command_Ptr(0x3C)'p12
ORI	R25, R0, 60
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,936 :: 		TFT_Write_Command_Ptr(0x00)'p13
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,937 :: 		TFT_Write_Command_Ptr(0x00)'p14
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,938 :: 		TFT_Write_Command_Ptr(0x02)'p15
ORI	R25, R0, 2
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,939 :: 		TFT_Write_Command_Ptr(0x10)'p15
ORI	R25, R0, 16
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,941 :: 		TFT_Set_Index_Ptr(0x13) ' Normal Display Mode On
ORI	R25, R0, 19
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,942 :: 		TFT_Set_Index_Ptr(0x20) ' Display inversion OFF
ORI	R25, R0, 32
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,943 :: 		TFT_Set_Index_Ptr(0x29) ' Display ON
ORI	R25, R0, 41
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,944 :: 		TFT_Set_Index_Ptr(0x38) ' Idle Mode Off
ORI	R25, R0, 56
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,945 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,947 :: 		TFT_Set_Index_Ptr(0x2A)      'set_column_address
ORI	R25, R0, 42
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,948 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,949 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,950 :: 		TFT_Write_Command_Ptr(Hi(TFT_DISP_WIDTH-1))
ADDIU	R2, R2, -1
EXT	R25, R2, 8, 8
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,951 :: 		TFT_Write_Command_Ptr(TFT_DISP_WIDTH-1)
ADDIU	R2, R2, -1
ANDI	R25, R2, 255
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,953 :: 		TFT_Set_Index_Ptr(0x2B)      ' set_page_address:
ORI	R25, R0, 43
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,954 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,955 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,956 :: 		TFT_Write_Command_Ptr(Hi(TFT_DISP_HEIGHT-1))
ADDIU	R2, R2, -1
EXT	R25, R2, 8, 8
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,957 :: 		TFT_Write_Command_Ptr(TFT_DISP_HEIGHT-1)
ADDIU	R2, R2, -1
ANDI	R25, R2, 255
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,959 :: 		TFT_Set_Index_Ptr(0x2C)
ORI	R25, R0, 44
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,960 :: 		Delay_10ms()
JAL	_Delay_10ms+0
NOP	
;__Lib_TFT_Defs.mbas,962 :: 		TFT_CS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,963 :: 		end sub
L_end_TFT_Reset_SST7715R:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 8
JR	RA
NOP	
; end of __Lib_TFT_Defs_TFT_Reset_SST7715R
_TFT_Init_SST7715R:
;__Lib_TFT_Defs.mbas,970 :: 		sub procedure TFT_Init_SST7715R(dim display_width as word display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,971 :: 		__controller = _8BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 255
;__Lib_TFT_Defs.mbas,972 :: 		if (Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init_SST7715R506
NOP	
J	L__TFT_Init_SST7715R82
NOP	
L__TFT_Init_SST7715R506:
;__Lib_TFT_Defs.mbas,973 :: 		TFT_Set_Index_Ptr     = @TFT_Set_Index
;__Lib_TFT_Defs.mbas,974 :: 		TFT_Write_Command_Ptr = @TFT_Write_Command
;__Lib_TFT_Defs.mbas,975 :: 		TFT_Write_Data_Ptr    = @TFT_Write_Data
L__TFT_Init_SST7715R82:
;__Lib_TFT_Defs.mbas,978 :: 		TFT_DISP_WIDTH = display_width
;__Lib_TFT_Defs.mbas,979 :: 		TFT_DISP_HEIGHT = display_height
;__Lib_TFT_Defs.mbas,980 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init_SST7715R507
NOP	
J	L__TFT_Init_SST7715R85
NOP	
L__TFT_Init_SST7715R507:
;__Lib_TFT_Defs.mbas,981 :: 		TFT_Disp_Rotation = 0
J	L__TFT_Init_SST7715R86
NOP	
;__Lib_TFT_Defs.mbas,982 :: 		else
L__TFT_Init_SST7715R85:
;__Lib_TFT_Defs.mbas,983 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
;__Lib_TFT_Defs.mbas,984 :: 		end if
L__TFT_Init_SST7715R86:
;__Lib_TFT_Defs.mbas,986 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,987 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,989 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,990 :: 		TFT_Clear_Fonts()
NOP	
;__Lib_TFT_Defs.mbas,991 :: 		TFT_Set_DataPort_Direction()
NOP	
;__Lib_TFT_Defs.mbas,993 :: 		TFT_Reset_SST7715R()
JAL	__Lib_TFT_Defs_TFT_Reset_SST7715R+0
NOP	
;__Lib_TFT_Defs.mbas,994 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address_SST7715R
LUI	R2, hi_addr(_TFT_Set_Address_SST7715R+0)
ORI	R2, R2, lo_addr(_TFT_Set_Address_SST7715R+0)
;__Lib_TFT_Defs.mbas,995 :: 		end sub
L_end_TFT_Init_SST7715R:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
; end of _TFT_Init_SST7715R
_TFT_Init_SST7715R_Custom:
;__Lib_TFT_Defs.mbas,1005 :: 		sub procedure TFT_Init_SST7715R_Custom(dim display_width as word display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,1006 :: 		__controller = _8BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 255
;__Lib_TFT_Defs.mbas,1007 :: 		if (Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init_SST7715R_Custom510
NOP	
J	L__TFT_Init_SST7715R_Custom89
NOP	
L__TFT_Init_SST7715R_Custom510:
;__Lib_TFT_Defs.mbas,1008 :: 		TFT_Set_Index_Ptr     = @TFT_Set_Index
;__Lib_TFT_Defs.mbas,1009 :: 		TFT_Write_Command_Ptr = @TFT_Write_Command
;__Lib_TFT_Defs.mbas,1010 :: 		TFT_Write_Data_Ptr    = @TFT_Write_Data
L__TFT_Init_SST7715R_Custom89:
;__Lib_TFT_Defs.mbas,1013 :: 		TFT_DISP_WIDTH = display_width
;__Lib_TFT_Defs.mbas,1014 :: 		TFT_DISP_HEIGHT = display_height
;__Lib_TFT_Defs.mbas,1015 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init_SST7715R_Custom511
NOP	
J	L__TFT_Init_SST7715R_Custom92
NOP	
L__TFT_Init_SST7715R_Custom511:
;__Lib_TFT_Defs.mbas,1016 :: 		TFT_Disp_Rotation = 0
J	L__TFT_Init_SST7715R_Custom93
NOP	
;__Lib_TFT_Defs.mbas,1017 :: 		else
L__TFT_Init_SST7715R_Custom92:
;__Lib_TFT_Defs.mbas,1018 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
;__Lib_TFT_Defs.mbas,1019 :: 		end if
L__TFT_Init_SST7715R_Custom93:
;__Lib_TFT_Defs.mbas,1021 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,1022 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,1024 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,1025 :: 		TFT_Clear_Fonts()
NOP	
;__Lib_TFT_Defs.mbas,1027 :: 		TFT_Reset_SST7715R()
NOP	
;__Lib_TFT_Defs.mbas,1028 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address_SST7715R
;__Lib_TFT_Defs.mbas,1029 :: 		end sub
L_end_TFT_Init_SST7715R_Custom:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
; end of _TFT_Init_SST7715R_Custom
__Lib_TFT_Defs_TFT_Reset_HX8347G:
;__Lib_TFT_Defs.mbas,1037 :: 		sub procedure TFT_Reset_HX8347G()
ADDIU	SP, SP, -12
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,1039 :: 		TFT_RST = 0
SW	R25, 4(SP)
SW	R26, 8(SP)
_LX	
INS	R2, R0, BitPos(TFT_RST+0), 1
_SX	
;__Lib_TFT_Defs.mbas,1041 :: 		TFT_RST_Direction = 0
_LX	
INS	R2, R0, BitPos(TFT_RST_Direction+0), 1
_SX	
;__Lib_TFT_Defs.mbas,1044 :: 		TFT_RS = 1
_LX	
ORI	R2, R2, BitMask(TFT_RS+0)
_SX	
;__Lib_TFT_Defs.mbas,1046 :: 		TFT_RS_Direction = 0
_LX	
INS	R2, R0, BitPos(TFT_RS_Direction+0), 1
_SX	
;__Lib_TFT_Defs.mbas,1049 :: 		TFT_CS = 1
_LX	
ORI	R2, R2, BitMask(TFT_CS+0)
_SX	
;__Lib_TFT_Defs.mbas,1051 :: 		TFT_CS_Direction = 0
_LX	
INS	R2, R0, BitPos(TFT_CS_Direction+0), 1
_SX	
;__Lib_TFT_Defs.mbas,1053 :: 		TFT_RD_Direction = 0
_LX	
INS	R2, R0, BitPos(TFT_RD_Direction+0), 1
_SX	
;__Lib_TFT_Defs.mbas,1054 :: 		TFT_WR_Direction = 0
_LX	
INS	R2, R0, BitPos(TFT_WR_Direction+0), 1
_SX	
;__Lib_TFT_Defs.mbas,1055 :: 		TFT_RD = 1
_LX	
ORI	R2, R2, BitMask(TFT_RD+0)
_SX	
;__Lib_TFT_Defs.mbas,1056 :: 		TFT_WR = 1
_LX	
ORI	R2, R2, BitMask(TFT_WR+0)
_SX	
;__Lib_TFT_Defs.mbas,1059 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,1060 :: 		TFT_RST = 1
_LX	
ORI	R2, R2, BitMask(TFT_RST+0)
_SX	
;__Lib_TFT_Defs.mbas,1061 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,1062 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,1064 :: 		TFT_Set_Reg(0xEA, 0x00) ' PTBA[15:8]
MOVZ	R26, R0, R0
ORI	R25, R0, 234
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1065 :: 		TFT_Set_Reg(0xEB, 0x20) ' PTBA[7:0]
ORI	R26, R0, 32
ORI	R25, R0, 235
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1066 :: 		TFT_Set_Reg(0xEC, 0x0C) ' STBA[15:8]
ORI	R26, R0, 12
ORI	R25, R0, 236
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1067 :: 		TFT_Set_Reg(0xED, 0xC4) ' STBA[7:0]
ORI	R26, R0, 196
ORI	R25, R0, 237
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1068 :: 		TFT_Set_Reg(0xE8, 0x40) ' OPON[7:0]
ORI	R26, R0, 64
ORI	R25, R0, 232
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1069 :: 		TFT_Set_Reg(0xE9, 0x38) ' OPON1[7:0]
ORI	R26, R0, 56
ORI	R25, R0, 233
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1070 :: 		TFT_Set_Reg(0xF1, 0x01) ' OTPS1B
ORI	R26, R0, 1
ORI	R25, R0, 241
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1071 :: 		TFT_Set_Reg(0xF2, 0x10) ' GEN
ORI	R26, R0, 16
ORI	R25, R0, 242
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1072 :: 		TFT_Set_Reg(0x27, 0xA3)
ORI	R26, R0, 163
ORI	R25, R0, 39
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1075 :: 		TFT_Set_Reg(0x40, 0x00) '
MOVZ	R26, R0, R0
ORI	R25, R0, 64
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1076 :: 		TFT_Set_Reg(0x41, 0x00) '
MOVZ	R26, R0, R0
ORI	R25, R0, 65
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1077 :: 		TFT_Set_Reg(0x42, 0x01) '
ORI	R26, R0, 1
ORI	R25, R0, 66
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1078 :: 		TFT_Set_Reg(0x43, 0x13) '
ORI	R26, R0, 19
ORI	R25, R0, 67
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1079 :: 		TFT_Set_Reg(0x44, 0x10) '
ORI	R26, R0, 16
ORI	R25, R0, 68
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1080 :: 		TFT_Set_Reg(0x45, 0x26) '
ORI	R26, R0, 38
ORI	R25, R0, 69
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1081 :: 		TFT_Set_Reg(0x46, 0x08) '
ORI	R26, R0, 8
ORI	R25, R0, 70
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1082 :: 		TFT_Set_Reg(0x47, 0x51) '
ORI	R26, R0, 81
ORI	R25, R0, 71
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1083 :: 		TFT_Set_Reg(0x48, 0x02) '
ORI	R26, R0, 2
ORI	R25, R0, 72
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1084 :: 		TFT_Set_Reg(0x49, 0x12) '
ORI	R26, R0, 18
ORI	R25, R0, 73
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1085 :: 		TFT_Set_Reg(0x4A, 0x18) '
ORI	R26, R0, 24
ORI	R25, R0, 74
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1086 :: 		TFT_Set_Reg(0x4B, 0x19) '
ORI	R26, R0, 25
ORI	R25, R0, 75
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1087 :: 		TFT_Set_Reg(0x4C, 0x14) '
ORI	R26, R0, 20
ORI	R25, R0, 76
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1089 :: 		TFT_Set_Reg(0x50, 0x19) '
ORI	R26, R0, 25
ORI	R25, R0, 80
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1090 :: 		TFT_Set_Reg(0x51, 0x2F) '
ORI	R26, R0, 47
ORI	R25, R0, 81
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1091 :: 		TFT_Set_Reg(0x52, 0x2C) '
ORI	R26, R0, 44
ORI	R25, R0, 82
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1092 :: 		TFT_Set_Reg(0x53, 0x3E) '
ORI	R26, R0, 62
ORI	R25, R0, 83
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1093 :: 		TFT_Set_Reg(0x54, 0x3F) '
ORI	R26, R0, 63
ORI	R25, R0, 84
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1094 :: 		TFT_Set_Reg(0x55, 0x3F) '
ORI	R26, R0, 63
ORI	R25, R0, 85
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1095 :: 		TFT_Set_Reg(0x56, 0x2E) '
ORI	R26, R0, 46
ORI	R25, R0, 86
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1096 :: 		TFT_Set_Reg(0x57, 0x77) '
ORI	R26, R0, 119
ORI	R25, R0, 87
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1097 :: 		TFT_Set_Reg(0x58, 0x0B) '
ORI	R26, R0, 11
ORI	R25, R0, 88
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1098 :: 		TFT_Set_Reg(0x59, 0x06) '
ORI	R26, R0, 6
ORI	R25, R0, 89
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1099 :: 		TFT_Set_Reg(0x5A, 0x07) '
ORI	R26, R0, 7
ORI	R25, R0, 90
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1100 :: 		TFT_Set_Reg(0x5B, 0x0D) '
ORI	R26, R0, 13
ORI	R25, R0, 91
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1101 :: 		TFT_Set_Reg(0x5C, 0x1D) '
ORI	R26, R0, 29
ORI	R25, R0, 92
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1102 :: 		TFT_Set_Reg(0x5D, 0xCC) '
ORI	R26, R0, 204
ORI	R25, R0, 93
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1105 :: 		TFT_Set_Reg(0x04, (TFT_DISP_WIDTH-1) >> 8)
ADDIU	R2, R2, -1
ANDI	R2, R2, 65535
SRL	R2, R2, 8
ANDI	R26, R2, 65535
ORI	R25, R0, 4
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1106 :: 		TFT_Set_Reg(0x05, TFT_DISP_WIDTH-1)
ADDIU	R2, R2, -1
ANDI	R26, R2, 255
ORI	R25, R0, 5
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1107 :: 		TFT_Set_Reg(0x08, (TFT_DISP_HEIGHT-1) >> 8)
ADDIU	R2, R2, -1
ANDI	R2, R2, 65535
SRL	R2, R2, 8
ANDI	R26, R2, 65535
ORI	R25, R0, 8
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1108 :: 		TFT_Set_Reg(0x09, TFT_DISP_HEIGHT-1)
ADDIU	R2, R2, -1
ANDI	R26, R2, 255
ORI	R25, R0, 9
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1110 :: 		if (TFT_Disp_Rotation = 90) then
LBU	R3, Offset(__Lib_TFT_Defs_TFT_Disp_Rotation+0)(GP)
ORI	R2, R0, 90
BEQ	R3, R2, L___Lib_TFT_Defs_TFT_Reset_HX8347G513
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_HX8347G96
NOP	
L___Lib_TFT_Defs_TFT_Reset_HX8347G513:
;__Lib_TFT_Defs.mbas,1111 :: 		if (Is_TFT_Rotated_180() = 1) then
JAL	_Is_TFT_Rotated_180+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BEQ	R3, R2, L___Lib_TFT_Defs_TFT_Reset_HX8347G514
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_HX8347G99
NOP	
L___Lib_TFT_Defs_TFT_Reset_HX8347G514:
;__Lib_TFT_Defs.mbas,1112 :: 		TFT_Set_Reg(0x16, 0x88)  ' MY=1, MX=0, MV=0, BGR=1
ORI	R26, R0, 136
ORI	R25, R0, 22
JAL	_TFT_Set_Reg+0
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_HX8347G100
NOP	
;__Lib_TFT_Defs.mbas,1113 :: 		else
L___Lib_TFT_Defs_TFT_Reset_HX8347G99:
;__Lib_TFT_Defs.mbas,1114 :: 		TFT_Set_Reg(0x16, 0x48) ' MY=0, MX=1, MV=0, BGR=1
ORI	R26, R0, 72
ORI	R25, R0, 22
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1115 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_HX8347G100:
J	L___Lib_TFT_Defs_TFT_Reset_HX8347G97
NOP	
;__Lib_TFT_Defs.mbas,1116 :: 		else
L___Lib_TFT_Defs_TFT_Reset_HX8347G96:
;__Lib_TFT_Defs.mbas,1117 :: 		if (Is_TFT_Rotated_180() = 1) then
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BEQ	R3, R2, L___Lib_TFT_Defs_TFT_Reset_HX8347G515
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_HX8347G102
NOP	
L___Lib_TFT_Defs_TFT_Reset_HX8347G515:
;__Lib_TFT_Defs.mbas,1118 :: 		TFT_Set_Reg(0x16, 0xE8)  ' MY=1, MX=1, MV=1, BGR=1
ORI	R26, R0, 232
ORI	R25, R0, 22
JAL	_TFT_Set_Reg+0
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_HX8347G103
NOP	
;__Lib_TFT_Defs.mbas,1119 :: 		else
L___Lib_TFT_Defs_TFT_Reset_HX8347G102:
;__Lib_TFT_Defs.mbas,1120 :: 		TFT_Set_Reg(0x16, 0x28) ' MY=0, MX=0, MV=1, BGR=1
ORI	R26, R0, 40
ORI	R25, R0, 22
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1121 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_HX8347G103:
;__Lib_TFT_Defs.mbas,1122 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_HX8347G97:
;__Lib_TFT_Defs.mbas,1125 :: 		TFT_Set_Reg(0x1B, 0x1B) ' VRH = 4.65
ORI	R26, R0, 27
ORI	R25, R0, 27
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1126 :: 		TFT_Set_Reg(0x1A, 0x01) ' BT
ORI	R26, R0, 1
ORI	R25, R0, 26
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1127 :: 		TFT_Set_Reg(0x24, 0x2F) ' VMH
ORI	R26, R0, 47
ORI	R25, R0, 36
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1128 :: 		TFT_Set_Reg(0x25, 0x57) ' VML
ORI	R26, R0, 87
ORI	R25, R0, 37
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1131 :: 		TFT_Set_Reg(0x23, 0x8D) ' FLICKER ADJUST
ORI	R26, R0, 141
ORI	R25, R0, 35
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1134 :: 		TFT_Set_Reg(0x18, 0x36) '
ORI	R26, R0, 54
ORI	R25, R0, 24
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1135 :: 		TFT_Set_Reg(0x19, 0x01) '
ORI	R26, R0, 1
ORI	R25, R0, 25
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1136 :: 		TFT_Set_Reg(0x01, 0x00) '
MOVZ	R26, R0, R0
ORI	R25, R0, 1
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1137 :: 		TFT_Set_Reg(0x1F, 0x88) '
ORI	R26, R0, 136
ORI	R25, R0, 31
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1138 :: 		Delay_5ms()
JAL	_Delay_5ms+0
NOP	
;__Lib_TFT_Defs.mbas,1139 :: 		TFT_Set_Reg(0x1F, 0x80) '
ORI	R26, R0, 128
ORI	R25, R0, 31
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1140 :: 		Delay_5ms()
JAL	_Delay_5ms+0
NOP	
;__Lib_TFT_Defs.mbas,1141 :: 		TFT_Set_Reg(0x1F, 0x90) '
ORI	R26, R0, 144
ORI	R25, R0, 31
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1142 :: 		Delay_5ms()
JAL	_Delay_5ms+0
NOP	
;__Lib_TFT_Defs.mbas,1143 :: 		TFT_Set_Reg(0x1F, 0xD0) '
ORI	R26, R0, 208
ORI	R25, R0, 31
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1144 :: 		Delay_5ms()
JAL	_Delay_5ms+0
NOP	
;__Lib_TFT_Defs.mbas,1147 :: 		TFT_Set_Reg(0x17, 0x05) '
ORI	R26, R0, 5
ORI	R25, R0, 23
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1150 :: 		TFT_Set_Reg(0x36, 0x00) ' Panel characteristic control register
MOVZ	R26, R0, R0
ORI	R25, R0, 54
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1153 :: 		TFT_Set_Reg(0x28, 0x38) '
ORI	R26, R0, 56
ORI	R25, R0, 40
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1154 :: 		Delay_10ms()
JAL	_Delay_10ms+0
NOP	
;__Lib_TFT_Defs.mbas,1155 :: 		Delay_10ms()
JAL	_Delay_10ms+0
NOP	
;__Lib_TFT_Defs.mbas,1156 :: 		Delay_10ms()
JAL	_Delay_10ms+0
NOP	
;__Lib_TFT_Defs.mbas,1157 :: 		Delay_10ms()
JAL	_Delay_10ms+0
NOP	
;__Lib_TFT_Defs.mbas,1158 :: 		TFT_Set_Reg(0x28, 0x3C) '
ORI	R26, R0, 60
ORI	R25, R0, 40
JAL	_TFT_Set_Reg+0
NOP	
;__Lib_TFT_Defs.mbas,1159 :: 		end sub
L_end_TFT_Reset_HX8347G:
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 12
JR	RA
NOP	
; end of __Lib_TFT_Defs_TFT_Reset_HX8347G
_TFT_Init_HX8347G:
;__Lib_TFT_Defs.mbas,1166 :: 		sub procedure TFT_Init_HX8347G(dim display_width as word display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,1167 :: 		__controller = _8BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 255
;__Lib_TFT_Defs.mbas,1168 :: 		if (Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init_HX8347G518
NOP	
J	L__TFT_Init_HX8347G106
NOP	
L__TFT_Init_HX8347G518:
;__Lib_TFT_Defs.mbas,1169 :: 		TFT_Set_Index_Ptr = @TFT_Set_Index
;__Lib_TFT_Defs.mbas,1170 :: 		TFT_Write_Command_Ptr = @TFT_Write_Command
;__Lib_TFT_Defs.mbas,1171 :: 		TFT_Write_Data_Ptr = @TFT_Write_Data
L__TFT_Init_HX8347G106:
;__Lib_TFT_Defs.mbas,1174 :: 		TFT_DISP_WIDTH = display_width
;__Lib_TFT_Defs.mbas,1175 :: 		TFT_DISP_HEIGHT = display_height
;__Lib_TFT_Defs.mbas,1176 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init_HX8347G519
NOP	
J	L__TFT_Init_HX8347G109
NOP	
L__TFT_Init_HX8347G519:
;__Lib_TFT_Defs.mbas,1177 :: 		TFT_Disp_Rotation = 0
J	L__TFT_Init_HX8347G110
NOP	
;__Lib_TFT_Defs.mbas,1178 :: 		else
L__TFT_Init_HX8347G109:
;__Lib_TFT_Defs.mbas,1179 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
;__Lib_TFT_Defs.mbas,1180 :: 		end if
L__TFT_Init_HX8347G110:
;__Lib_TFT_Defs.mbas,1182 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,1183 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,1185 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,1186 :: 		TFT_Clear_Fonts()
NOP	
;__Lib_TFT_Defs.mbas,1187 :: 		TFT_Set_DataPort_Direction()
NOP	
;__Lib_TFT_Defs.mbas,1189 :: 		TFT_Reset_HX8347G()
JAL	__Lib_TFT_Defs_TFT_Reset_HX8347G+0
NOP	
;__Lib_TFT_Defs.mbas,1190 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address
;__Lib_TFT_Defs.mbas,1191 :: 		end sub
L_end_TFT_Init_HX8347G:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
; end of _TFT_Init_HX8347G
_TFT_Init_HX8347G_Custom:
;__Lib_TFT_Defs.mbas,1201 :: 		sub procedure TFT_Init_HX8347G_Custom(dim display_width as word display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,1202 :: 		__controller = _8BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 255
SH	R2, Offset(__Lib_TFT_Defs___controller+0)(GP)
;__Lib_TFT_Defs.mbas,1203 :: 		if (Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init_HX8347G_Custom522
NOP	
J	L__TFT_Init_HX8347G_Custom113
NOP	
L__TFT_Init_HX8347G_Custom522:
;__Lib_TFT_Defs.mbas,1204 :: 		TFT_Set_Index_Ptr = @TFT_Set_Index
LUI	R2, hi_addr(_TFT_Set_Index+0)
ORI	R2, R2, lo_addr(_TFT_Set_Index+0)
SW	R2, Offset(_TFT_Set_Index_Ptr+0)(GP)
;__Lib_TFT_Defs.mbas,1205 :: 		TFT_Write_Command_Ptr = @TFT_Write_Command
LUI	R2, hi_addr(_TFT_Write_Command+0)
ORI	R2, R2, lo_addr(_TFT_Write_Command+0)
SW	R2, Offset(_TFT_Write_Command_Ptr+0)(GP)
;__Lib_TFT_Defs.mbas,1206 :: 		TFT_Write_Data_Ptr = @TFT_Write_Data
LUI	R2, hi_addr(_TFT_Write_Data+0)
ORI	R2, R2, lo_addr(_TFT_Write_Data+0)
SW	R2, Offset(_TFT_Write_Data_Ptr+0)(GP)
L__TFT_Init_HX8347G_Custom113:
;__Lib_TFT_Defs.mbas,1209 :: 		TFT_DISP_WIDTH = display_width
SH	R25, Offset(_TFT_DISP_WIDTH+0)(GP)
;__Lib_TFT_Defs.mbas,1210 :: 		TFT_DISP_HEIGHT = display_height
SH	R26, Offset(_TFT_DISP_HEIGHT+0)(GP)
;__Lib_TFT_Defs.mbas,1211 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init_HX8347G_Custom523
NOP	
J	L__TFT_Init_HX8347G_Custom116
NOP	
L__TFT_Init_HX8347G_Custom523:
;__Lib_TFT_Defs.mbas,1212 :: 		TFT_Disp_Rotation = 0
SB	R0, Offset(__Lib_TFT_Defs_TFT_Disp_Rotation+0)(GP)
J	L__TFT_Init_HX8347G_Custom117
NOP	
;__Lib_TFT_Defs.mbas,1213 :: 		else
L__TFT_Init_HX8347G_Custom116:
;__Lib_TFT_Defs.mbas,1214 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
SB	R2, Offset(__Lib_TFT_Defs_TFT_Disp_Rotation+0)(GP)
;__Lib_TFT_Defs.mbas,1215 :: 		end if
L__TFT_Init_HX8347G_Custom117:
;__Lib_TFT_Defs.mbas,1217 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,1218 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
JAL	_TFT_Set_Brush+0
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,1220 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
JAL	_TFT_Move_Cursor+0
NOP	
;__Lib_TFT_Defs.mbas,1221 :: 		TFT_Clear_Fonts()
JAL	_TFT_Clear_Fonts+0
NOP	
;__Lib_TFT_Defs.mbas,1223 :: 		TFT_Reset_HX8347G()
NOP	
;__Lib_TFT_Defs.mbas,1224 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address
LUI	R2, hi_addr(_TFT_Set_Address+0)
ORI	R2, R2, lo_addr(_TFT_Set_Address+0)
SW	R2, Offset(_TFT_Set_Address_Ptr+0)(GP)
;__Lib_TFT_Defs.mbas,1225 :: 		end sub
L_end_TFT_Init_HX8347G_Custom:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
; end of _TFT_Init_HX8347G_Custom
_TFT_Set_Address_HX8352A:
;__Lib_TFT_Defs.mbas,1234 :: 		sub procedure TFT_Set_Address_HX8352A(dim x as word y as word)
ADDIU	SP, SP, -12
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,1235 :: 		if (TFT_Disp_Rotation = 90) then
SW	R25, 4(SP)
ORI	R2, R0, 90
BEQ	R3, R2, L__TFT_Set_Address_HX8352A525
NOP	
J	L__TFT_Set_Address_HX8352A120
NOP	
L__TFT_Set_Address_HX8352A525:
;__Lib_TFT_Defs.mbas,1236 :: 		TFT_Set_Index_Ptr(0x02)
SH	R26, 8(SP)
SH	R25, 10(SP)
ORI	R25, R0, 2
LW	R30, Offset(_TFT_Set_Index_Ptr+0)(GP)
JALR	RA, R30
NOP	
LHU	R25, 10(SP)
;__Lib_TFT_Defs.mbas,1237 :: 		TFT_Write_Command_Ptr(x >> 8)
ANDI	R2, R25, 65535
SRL	R2, R2, 8
SH	R25, 10(SP)
ANDI	R25, R2, 65535
LW	R30, Offset(_TFT_Write_Command_Ptr+0)(GP)
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1238 :: 		TFT_Set_Index_Ptr(0x03)
ORI	R25, R0, 3
JALR	RA, R30
NOP	
LHU	R25, 10(SP)
;__Lib_TFT_Defs.mbas,1239 :: 		TFT_Write_Command_Ptr(x)
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1240 :: 		TFT_Set_Index_Ptr(0x06)
ORI	R25, R0, 6
JALR	RA, R30
NOP	
LHU	R26, 8(SP)
;__Lib_TFT_Defs.mbas,1241 :: 		TFT_Write_Command_Ptr(y >> 8)
ANDI	R2, R26, 65535
SRL	R2, R2, 8
SH	R26, 8(SP)
ANDI	R25, R2, 65535
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1242 :: 		TFT_Set_Index_Ptr(0x07)
ORI	R25, R0, 7
JALR	RA, R30
NOP	
LHU	R26, 8(SP)
;__Lib_TFT_Defs.mbas,1243 :: 		TFT_Write_Command_Ptr(y)
JALR	RA, R30
NOP	
J	L__TFT_Set_Address_HX8352A121
NOP	
;__Lib_TFT_Defs.mbas,1244 :: 		else
L__TFT_Set_Address_HX8352A120:
;__Lib_TFT_Defs.mbas,1245 :: 		TFT_Set_Index_Ptr(0x02)
SH	R26, 8(SP)
SH	R25, 10(SP)
ORI	R25, R0, 2
JALR	RA, R30
NOP	
LHU	R25, 10(SP)
LHU	R26, 8(SP)
;__Lib_TFT_Defs.mbas,1246 :: 		TFT_Write_Command_Ptr(y >> 8)
ANDI	R2, R26, 65535
SRL	R2, R2, 8
SH	R26, 8(SP)
SH	R25, 10(SP)
ANDI	R25, R2, 65535
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1247 :: 		TFT_Set_Index_Ptr(0x03)
ORI	R25, R0, 3
JALR	RA, R30
NOP	
LHU	R25, 10(SP)
LHU	R26, 8(SP)
;__Lib_TFT_Defs.mbas,1248 :: 		TFT_Write_Command_Ptr(y)
SH	R25, 8(SP)
ANDI	R25, R26, 65535
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1249 :: 		TFT_Set_Index_Ptr(0x06)
ORI	R25, R0, 6
JALR	RA, R30
NOP	
LHU	R25, 8(SP)
;__Lib_TFT_Defs.mbas,1250 :: 		TFT_Write_Command_Ptr(x >> 8)
ANDI	R2, R25, 65535
SRL	R2, R2, 8
SH	R25, 8(SP)
ANDI	R25, R2, 65535
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1251 :: 		TFT_Set_Index_Ptr(0x07)
ORI	R25, R0, 7
JALR	RA, R30
NOP	
LHU	R25, 8(SP)
;__Lib_TFT_Defs.mbas,1252 :: 		TFT_Write_Command_Ptr(x)
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1253 :: 		end if
L__TFT_Set_Address_HX8352A121:
;__Lib_TFT_Defs.mbas,1254 :: 		TFT_Set_Index_Ptr(0x22)
ORI	R25, R0, 34
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1255 :: 		end sub
L_end_TFT_Set_Address_HX8352A:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 12
JR	RA
NOP	
; end of _TFT_Set_Address_HX8352A
__Lib_TFT_Defs_TFT_Reset_HX8352A:
;__Lib_TFT_Defs.mbas,1262 :: 		dim _counter as byte
ADDIU	SP, SP, -12
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,1264 :: 		TFT_RST = 0
SW	R25, 4(SP)
_LX	
_SX	
;__Lib_TFT_Defs.mbas,1266 :: 		TFT_RST_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,1269 :: 		TFT_RS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,1271 :: 		TFT_RS_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,1274 :: 		TFT_CS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,1276 :: 		TFT_CS_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,1278 :: 		TFT_RD_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,1279 :: 		TFT_WR_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,1280 :: 		TFT_RD = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,1281 :: 		TFT_WR = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,1284 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,1285 :: 		TFT_RST = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,1286 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,1287 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,1289 :: 		TFT_CS = 0
_LX	
INS	R2, R0, BitPos(TFT_CS+0), 1
_SX	
;__Lib_TFT_Defs.mbas,1291 :: 		TFT_Set_Index_Ptr(0x83) TFT_Write_Command_Ptr(0x02)
ORI	R25, R0, 131
JALR	RA, R30
NOP	
ORI	R25, R0, 2
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1292 :: 		TFT_Set_Index_Ptr(0x85) TFT_Write_Command_Ptr(0x03)
ORI	R25, R0, 133
JALR	RA, R30
NOP	
ORI	R25, R0, 3
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1293 :: 		TFT_Set_Index_Ptr(0x8B) TFT_Write_Command_Ptr(0x00)
ORI	R25, R0, 139
JALR	RA, R30
NOP	
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1294 :: 		TFT_Set_Index_Ptr(0x8C) TFT_Write_Command_Ptr(0x13)
ORI	R25, R0, 140
JALR	RA, R30
NOP	
ORI	R25, R0, 19
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1295 :: 		TFT_Set_Index_Ptr(0x91) TFT_Write_Command_Ptr(0x01)
ORI	R25, R0, 145
JALR	RA, R30
NOP	
ORI	R25, R0, 1
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1296 :: 		TFT_Set_Index_Ptr(0x83) TFT_Write_Command_Ptr(0x00)
ORI	R25, R0, 131
JALR	RA, R30
NOP	
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1297 :: 		Delay_10ms()
JAL	_Delay_10ms+0
NOP	
;__Lib_TFT_Defs.mbas,1300 :: 		TFT_Set_Index_Ptr(0x3E) TFT_Write_Command_Ptr(0xC4)
ORI	R25, R0, 62
JALR	RA, R30
NOP	
ORI	R25, R0, 196
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1301 :: 		TFT_Set_Index_Ptr(0x3F) TFT_Write_Command_Ptr(0x44)
ORI	R25, R0, 63
JALR	RA, R30
NOP	
ORI	R25, R0, 68
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1302 :: 		TFT_Set_Index_Ptr(0x40) TFT_Write_Command_Ptr(0x22)
ORI	R25, R0, 64
JALR	RA, R30
NOP	
ORI	R25, R0, 34
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1303 :: 		TFT_Set_Index_Ptr(0x41) TFT_Write_Command_Ptr(0x57)
ORI	R25, R0, 65
JALR	RA, R30
NOP	
ORI	R25, R0, 87
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1304 :: 		TFT_Set_Index_Ptr(0x42) TFT_Write_Command_Ptr(0x03)
ORI	R25, R0, 66
JALR	RA, R30
NOP	
ORI	R25, R0, 3
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1305 :: 		TFT_Set_Index_Ptr(0x43) TFT_Write_Command_Ptr(0x47)
ORI	R25, R0, 67
JALR	RA, R30
NOP	
ORI	R25, R0, 71
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1306 :: 		TFT_Set_Index_Ptr(0x44) TFT_Write_Command_Ptr(0x02)
ORI	R25, R0, 68
JALR	RA, R30
NOP	
ORI	R25, R0, 2
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1307 :: 		TFT_Set_Index_Ptr(0x45) TFT_Write_Command_Ptr(0x55)
ORI	R25, R0, 69
JALR	RA, R30
NOP	
ORI	R25, R0, 85
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1308 :: 		TFT_Set_Index_Ptr(0x46) TFT_Write_Command_Ptr(0x06)
ORI	R25, R0, 70
JALR	RA, R30
NOP	
ORI	R25, R0, 6
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1309 :: 		TFT_Set_Index_Ptr(0x47) TFT_Write_Command_Ptr(0x4C)
ORI	R25, R0, 71
JALR	RA, R30
NOP	
ORI	R25, R0, 76
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1310 :: 		TFT_Set_Index_Ptr(0x48) TFT_Write_Command_Ptr(0x06)
ORI	R25, R0, 72
JALR	RA, R30
NOP	
ORI	R25, R0, 6
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1311 :: 		TFT_Set_Index_Ptr(0x49) TFT_Write_Command_Ptr(0x8C)
ORI	R25, R0, 73
JALR	RA, R30
NOP	
ORI	R25, R0, 140
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1313 :: 		TFT_Set_Index_Ptr(0x17) TFT_Write_Command_Ptr(0x91)
ORI	R25, R0, 23
JALR	RA, R30
NOP	
ORI	R25, R0, 145
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1314 :: 		TFT_Set_Index_Ptr(0x23) TFT_Write_Command_Ptr(0x01)
ORI	R25, R0, 35
JALR	RA, R30
NOP	
ORI	R25, R0, 1
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1315 :: 		TFT_Set_Index_Ptr(0x2B) TFT_Write_Command_Ptr(0xF9)
ORI	R25, R0, 43
JALR	RA, R30
NOP	
ORI	R25, R0, 249
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1316 :: 		Delay_10ms() Delay_10ms()
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
;__Lib_TFT_Defs.mbas,1317 :: 		TFT_Set_Index_Ptr(0x18) TFT_Write_Command_Ptr(0x3A)
ORI	R25, R0, 24
JALR	RA, R30
NOP	
ORI	R25, R0, 58
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1318 :: 		TFT_Set_Index_Ptr(0x1B) TFT_Write_Command_Ptr(0x11)
ORI	R25, R0, 27
JALR	RA, R30
NOP	
ORI	R25, R0, 17
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1320 :: 		TFT_Set_Index_Ptr(0x83) TFT_Write_Command_Ptr(0x02)
ORI	R25, R0, 131
JALR	RA, R30
NOP	
ORI	R25, R0, 2
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1321 :: 		TFT_Set_Index_Ptr(0x8A) TFT_Write_Command_Ptr(0x06)
ORI	R25, R0, 138
JALR	RA, R30
NOP	
ORI	R25, R0, 6
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1322 :: 		TFT_Set_Index_Ptr(0x83) TFT_Write_Command_Ptr(0x00)
ORI	R25, R0, 131
JALR	RA, R30
NOP	
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1323 :: 		TFT_Set_Index_Ptr(0x1A) TFT_Write_Command_Ptr(0x11)
ORI	R25, R0, 26
JALR	RA, R30
NOP	
ORI	R25, R0, 17
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1324 :: 		TFT_Set_Index_Ptr(0x1C) TFT_Write_Command_Ptr(0x0A)
ORI	R25, R0, 28
JALR	RA, R30
NOP	
ORI	R25, R0, 10
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1325 :: 		TFT_Set_Index_Ptr(0x1F) TFT_Write_Command_Ptr(0x58)
ORI	R25, R0, 31
JALR	RA, R30
NOP	
ORI	R25, R0, 88
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1326 :: 		Delay_10ms() Delay_10ms() Delay_10ms()
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
;__Lib_TFT_Defs.mbas,1327 :: 		TFT_Set_Index_Ptr(0x19) TFT_Write_Command_Ptr(0x0A)
ORI	R25, R0, 25
JALR	RA, R30
NOP	
ORI	R25, R0, 10
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1328 :: 		TFT_Set_Index_Ptr(0x19) TFT_Write_Command_Ptr(0x1A)
ORI	R25, R0, 25
JALR	RA, R30
NOP	
ORI	R25, R0, 26
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1329 :: 		Delay_10ms() Delay_10ms() Delay_10ms() Delay_10ms() Delay_10ms()
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
;__Lib_TFT_Defs.mbas,1330 :: 		TFT_Set_Index_Ptr(0x19) TFT_Write_Command_Ptr(0x12)
ORI	R25, R0, 25
JALR	RA, R30
NOP	
ORI	R25, R0, 18
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1331 :: 		Delay_10ms() Delay_10ms() Delay_10ms() Delay_10ms() Delay_10ms()
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
;__Lib_TFT_Defs.mbas,1332 :: 		TFT_Set_Index_Ptr(0x1E) TFT_Write_Command_Ptr(0x2E)
ORI	R25, R0, 30
JALR	RA, R30
NOP	
ORI	R25, R0, 46
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1333 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,1335 :: 		TFT_Set_Index_Ptr(0x5A) TFT_Write_Command_Ptr(0x01)
ORI	R25, R0, 90
JALR	RA, R30
NOP	
ORI	R25, R0, 1
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1337 :: 		TFT_Set_Index_Ptr(0x5C)
ORI	R25, R0, 92
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1338 :: 		for _counter = 0 to 3
SB	R0, 8(SP)
L___Lib_TFT_Defs_TFT_Reset_HX8352A124:
;__Lib_TFT_Defs.mbas,1339 :: 		TFT_Write_Command_Ptr(0x00)'---------0
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1340 :: 		TFT_Write_Command_Ptr(0x03)
ORI	R25, R0, 3
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1341 :: 		TFT_Write_Command_Ptr(0x0A)
ORI	R25, R0, 10
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1342 :: 		TFT_Write_Command_Ptr(0x0F)
ORI	R25, R0, 15
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1343 :: 		TFT_Write_Command_Ptr(0x13)
ORI	R25, R0, 19
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1344 :: 		TFT_Write_Command_Ptr(0x16)'---------5
ORI	R25, R0, 22
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1345 :: 		TFT_Write_Command_Ptr(0x19)
ORI	R25, R0, 25
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1346 :: 		TFT_Write_Command_Ptr(0x1C)
ORI	R25, R0, 28
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1347 :: 		TFT_Write_Command_Ptr(0x1E)
ORI	R25, R0, 30
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1348 :: 		TFT_Write_Command_Ptr(0x1F)
ORI	R25, R0, 31
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1349 :: 		TFT_Write_Command_Ptr(0x25)'---------10
ORI	R25, R0, 37
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1350 :: 		TFT_Write_Command_Ptr(0x2A)
ORI	R25, R0, 42
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1351 :: 		TFT_Write_Command_Ptr(0x30)
ORI	R25, R0, 48
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1352 :: 		TFT_Write_Command_Ptr(0x35)
ORI	R25, R0, 53
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1353 :: 		TFT_Write_Command_Ptr(0x39)
ORI	R25, R0, 57
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1354 :: 		TFT_Write_Command_Ptr(0x3D)'---------15
ORI	R25, R0, 61
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1355 :: 		TFT_Write_Command_Ptr(0x41)
ORI	R25, R0, 65
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1356 :: 		TFT_Write_Command_Ptr(0x45)
ORI	R25, R0, 69
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1357 :: 		TFT_Write_Command_Ptr(0x48)
ORI	R25, R0, 72
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1358 :: 		TFT_Write_Command_Ptr(0x4C)
ORI	R25, R0, 76
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1359 :: 		TFT_Write_Command_Ptr(0x4F)'---------20
ORI	R25, R0, 79
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1360 :: 		TFT_Write_Command_Ptr(0x53)
ORI	R25, R0, 83
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1361 :: 		TFT_Write_Command_Ptr(0x58)
ORI	R25, R0, 88
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1362 :: 		TFT_Write_Command_Ptr(0x5D)
ORI	R25, R0, 93
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1363 :: 		TFT_Write_Command_Ptr(0x61)
ORI	R25, R0, 97
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1364 :: 		TFT_Write_Command_Ptr(0x66)'---------25
ORI	R25, R0, 102
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1365 :: 		TFT_Write_Command_Ptr(0x6A)
ORI	R25, R0, 106
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1366 :: 		TFT_Write_Command_Ptr(0x6E)
ORI	R25, R0, 110
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1367 :: 		TFT_Write_Command_Ptr(0x72)
ORI	R25, R0, 114
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1368 :: 		TFT_Write_Command_Ptr(0x76)
ORI	R25, R0, 118
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1370 :: 		TFT_Write_Command_Ptr(0x7A)'---------30
ORI	R25, R0, 122
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1371 :: 		TFT_Write_Command_Ptr(0x7E)
ORI	R25, R0, 126
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1372 :: 		TFT_Write_Command_Ptr(0x82)
ORI	R25, R0, 130
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1373 :: 		TFT_Write_Command_Ptr(0x85)
ORI	R25, R0, 133
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1374 :: 		TFT_Write_Command_Ptr(0x89)
ORI	R25, R0, 137
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1375 :: 		TFT_Write_Command_Ptr(0x8D)'---------35
ORI	R25, R0, 141
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1376 :: 		TFT_Write_Command_Ptr(0x90)
ORI	R25, R0, 144
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1377 :: 		TFT_Write_Command_Ptr(0x94)
ORI	R25, R0, 148
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1378 :: 		TFT_Write_Command_Ptr(0x96)
ORI	R25, R0, 150
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1379 :: 		TFT_Write_Command_Ptr(0x9A)
ORI	R25, R0, 154
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1380 :: 		TFT_Write_Command_Ptr(0x9D)'---------40
ORI	R25, R0, 157
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1381 :: 		TFT_Write_Command_Ptr(0xA1)
ORI	R25, R0, 161
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1382 :: 		TFT_Write_Command_Ptr(0xA4)
ORI	R25, R0, 164
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1383 :: 		TFT_Write_Command_Ptr(0xA8)
ORI	R25, R0, 168
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1384 :: 		TFT_Write_Command_Ptr(0xAB)
ORI	R25, R0, 171
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1385 :: 		TFT_Write_Command_Ptr(0xAF)'---------45
ORI	R25, R0, 175
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1386 :: 		TFT_Write_Command_Ptr(0xB3)
ORI	R25, R0, 179
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1387 :: 		TFT_Write_Command_Ptr(0xB7)
ORI	R25, R0, 183
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1388 :: 		TFT_Write_Command_Ptr(0xBB)
ORI	R25, R0, 187
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1389 :: 		TFT_Write_Command_Ptr(0xBF)
ORI	R25, R0, 191
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1390 :: 		TFT_Write_Command_Ptr(0xC3)'---------50
ORI	R25, R0, 195
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1391 :: 		TFT_Write_Command_Ptr(0xC8)
ORI	R25, R0, 200
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1392 :: 		TFT_Write_Command_Ptr(0xCC)
ORI	R25, R0, 204
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1393 :: 		TFT_Write_Command_Ptr(0xD1)
ORI	R25, R0, 209
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1394 :: 		TFT_Write_Command_Ptr(0xD6)
ORI	R25, R0, 214
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1395 :: 		TFT_Write_Command_Ptr(0xDB)'---------55
ORI	R25, R0, 219
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1396 :: 		TFT_Write_Command_Ptr(0xDE)
ORI	R25, R0, 222
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1397 :: 		TFT_Write_Command_Ptr(0xE1)
ORI	R25, R0, 225
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1398 :: 		TFT_Write_Command_Ptr(0xE5)
ORI	R25, R0, 229
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1399 :: 		TFT_Write_Command_Ptr(0xE7)
ORI	R25, R0, 231
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1400 :: 		TFT_Write_Command_Ptr(0xEC)'---------60
ORI	R25, R0, 236
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1401 :: 		TFT_Write_Command_Ptr(0xEF)
ORI	R25, R0, 239
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1402 :: 		TFT_Write_Command_Ptr(0xF4)
ORI	R25, R0, 244
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1403 :: 		TFT_Write_Command_Ptr(0xFF)'---------63
ORI	R25, R0, 255
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1404 :: 		next _counter
LBU	R3, 8(SP)
ORI	R2, R0, 3
BNE	R3, R2, L___Lib_TFT_Defs_TFT_Reset_HX8352A528
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_HX8352A127
NOP	
L___Lib_TFT_Defs_TFT_Reset_HX8352A528:
LBU	R2, 8(SP)
ADDIU	R2, R2, 1
SB	R2, 8(SP)
J	L___Lib_TFT_Defs_TFT_Reset_HX8352A124
NOP	
L___Lib_TFT_Defs_TFT_Reset_HX8352A127:
;__Lib_TFT_Defs.mbas,1406 :: 		TFT_Set_Index_Ptr(0x3C) TFT_Write_Command_Ptr(0xC0)
ORI	R25, R0, 60
JALR	RA, R30
NOP	
ORI	R25, R0, 192
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1407 :: 		TFT_Set_Index_Ptr(0x3D) TFT_Write_Command_Ptr(0x1C)
ORI	R25, R0, 61
JALR	RA, R30
NOP	
ORI	R25, R0, 28
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1408 :: 		TFT_Set_Index_Ptr(0x34) TFT_Write_Command_Ptr(0x38)
ORI	R25, R0, 52
JALR	RA, R30
NOP	
ORI	R25, R0, 56
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1409 :: 		TFT_Set_Index_Ptr(0x35) TFT_Write_Command_Ptr(0x38)
ORI	R25, R0, 53
JALR	RA, R30
NOP	
ORI	R25, R0, 56
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1410 :: 		TFT_Set_Index_Ptr(0x24) TFT_Write_Command_Ptr(0x38)
ORI	R25, R0, 36
JALR	RA, R30
NOP	
ORI	R25, R0, 56
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1411 :: 		Delay_10ms() Delay_10ms() Delay_10ms() Delay_10ms() Delay_10ms()
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
;__Lib_TFT_Defs.mbas,1412 :: 		TFT_Set_Index_Ptr(0x24) TFT_Write_Command_Ptr(0x3C)
ORI	R25, R0, 36
JALR	RA, R30
NOP	
ORI	R25, R0, 60
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1414 :: 		TFT_Set_Index_Ptr(0x16)
ORI	R25, R0, 22
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1415 :: 		if (TFT_Disp_Rotation = 90) then
ORI	R2, R0, 90
BEQ	R3, R2, L___Lib_TFT_Defs_TFT_Reset_HX8352A529
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_HX8352A129
NOP	
L___Lib_TFT_Defs_TFT_Reset_HX8352A529:
;__Lib_TFT_Defs.mbas,1416 :: 		if (Is_TFT_Rotated_180() = 1) then
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BEQ	R3, R2, L___Lib_TFT_Defs_TFT_Reset_HX8352A530
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_HX8352A132
NOP	
L___Lib_TFT_Defs_TFT_Reset_HX8352A530:
;__Lib_TFT_Defs.mbas,1417 :: 		TFT_Write_Command_Ptr(0x08)
ORI	R25, R0, 8
JALR	RA, R30
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_HX8352A133
NOP	
;__Lib_TFT_Defs.mbas,1418 :: 		else
L___Lib_TFT_Defs_TFT_Reset_HX8352A132:
;__Lib_TFT_Defs.mbas,1419 :: 		TFT_Write_Command_Ptr(0xC8)
ORI	R25, R0, 200
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1420 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_HX8352A133:
J	L___Lib_TFT_Defs_TFT_Reset_HX8352A130
NOP	
;__Lib_TFT_Defs.mbas,1421 :: 		else
L___Lib_TFT_Defs_TFT_Reset_HX8352A129:
;__Lib_TFT_Defs.mbas,1422 :: 		if (Is_TFT_Rotated_180() = 1) then
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BEQ	R3, R2, L___Lib_TFT_Defs_TFT_Reset_HX8352A531
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_HX8352A135
NOP	
L___Lib_TFT_Defs_TFT_Reset_HX8352A531:
;__Lib_TFT_Defs.mbas,1423 :: 		TFT_Write_Command_Ptr(0xD8)
ORI	R25, R0, 216
JALR	RA, R30
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_HX8352A136
NOP	
;__Lib_TFT_Defs.mbas,1424 :: 		else
L___Lib_TFT_Defs_TFT_Reset_HX8352A135:
;__Lib_TFT_Defs.mbas,1425 :: 		TFT_Write_Command_Ptr(0x18)
ORI	R25, R0, 24
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1426 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_HX8352A136:
;__Lib_TFT_Defs.mbas,1427 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_HX8352A130:
;__Lib_TFT_Defs.mbas,1429 :: 		TFT_Set_Index_Ptr(0x01) TFT_Write_Command_Ptr(0x06)
ORI	R25, R0, 1
JALR	RA, R30
NOP	
ORI	R25, R0, 6
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1430 :: 		TFT_Set_Index_Ptr(0x55) TFT_Write_Command_Ptr(0x00)
ORI	R25, R0, 85
JALR	RA, R30
NOP	
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1434 :: 		TFT_Set_Index_Ptr(0x02) TFT_Write_Command_Ptr(0x00)
ORI	R25, R0, 2
JALR	RA, R30
NOP	
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1435 :: 		TFT_Set_Index_Ptr(0x03) TFT_Write_Command_Ptr(0x00)
ORI	R25, R0, 3
JALR	RA, R30
NOP	
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1436 :: 		TFT_Set_Index_Ptr(0x04) TFT_Write_Command_Ptr((240-1) >> 8)                   ' TFT_DISP_WIDTH
ORI	R25, R0, 4
JALR	RA, R30
NOP	
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1437 :: 		TFT_Set_Index_Ptr(0x05) TFT_Write_Command_Ptr(240-1)                          ' TFT_DISP_WIDTH
ORI	R25, R0, 5
JALR	RA, R30
NOP	
ORI	R25, R0, 239
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1438 :: 		TFT_Set_Index_Ptr(0x06) TFT_Write_Command_Ptr(0x00)
ORI	R25, R0, 6
JALR	RA, R30
NOP	
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1439 :: 		TFT_Set_Index_Ptr(0x07) TFT_Write_Command_Ptr(0x00)
ORI	R25, R0, 7
JALR	RA, R30
NOP	
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1440 :: 		TFT_Set_Index_Ptr(0x08) TFT_Write_Command_Ptr((400-1) >> 8)                   ' TFT_DISP_HEIGHT
ORI	R25, R0, 8
JALR	RA, R30
NOP	
ORI	R25, R0, 1
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1441 :: 		TFT_Set_Index_Ptr(0x09) TFT_Write_Command_Ptr(byte(400-1))                    ' TFT_DISP_HEIGHT
ORI	R25, R0, 9
JALR	RA, R30
NOP	
ORI	R25, R0, 143
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1443 :: 		TFT_Set_Index_Ptr(0x22)
ORI	R25, R0, 34
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1444 :: 		Delay_10ms()
JAL	_Delay_10ms+0
NOP	
;__Lib_TFT_Defs.mbas,1445 :: 		TFT_CS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,1446 :: 		end sub
L_end_TFT_Reset_HX8352A:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 12
JR	RA
NOP	
; end of __Lib_TFT_Defs_TFT_Reset_HX8352A
_TFT_Init_HX8352A:
;__Lib_TFT_Defs.mbas,1453 :: 		sub procedure TFT_Init_HX8352A(dim display_width as word display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,1454 :: 		__controller = _16BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 65535
;__Lib_TFT_Defs.mbas,1455 :: 		TFT_Set_HX8352A()
JAL	_TFT_Set_HX8352A+0
NOP	
;__Lib_TFT_Defs.mbas,1456 :: 		if (Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init_HX8352A534
NOP	
J	L__TFT_Init_HX8352A139
NOP	
L__TFT_Init_HX8352A534:
;__Lib_TFT_Defs.mbas,1457 :: 		TFT_Set_Index_Ptr = @TFT_Set_Index
;__Lib_TFT_Defs.mbas,1458 :: 		TFT_Write_Command_Ptr = @TFT_Write_Command
;__Lib_TFT_Defs.mbas,1459 :: 		TFT_Write_Data_Ptr = @TFT_16bit_Write_Data
LUI	R2, hi_addr(_TFT_16bit_Write_Data+0)
ORI	R2, R2, lo_addr(_TFT_16bit_Write_Data+0)
L__TFT_Init_HX8352A139:
;__Lib_TFT_Defs.mbas,1462 :: 		TFT_DISP_WIDTH = display_width
;__Lib_TFT_Defs.mbas,1463 :: 		TFT_DISP_HEIGHT = display_height
;__Lib_TFT_Defs.mbas,1464 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init_HX8352A535
NOP	
J	L__TFT_Init_HX8352A142
NOP	
L__TFT_Init_HX8352A535:
;__Lib_TFT_Defs.mbas,1465 :: 		TFT_Disp_Rotation = 0
J	L__TFT_Init_HX8352A143
NOP	
;__Lib_TFT_Defs.mbas,1466 :: 		else
L__TFT_Init_HX8352A142:
;__Lib_TFT_Defs.mbas,1467 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
;__Lib_TFT_Defs.mbas,1468 :: 		end if
L__TFT_Init_HX8352A143:
;__Lib_TFT_Defs.mbas,1470 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,1471 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,1473 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,1474 :: 		TFT_Clear_Fonts()
NOP	
;__Lib_TFT_Defs.mbas,1475 :: 		TFT_Set_DataPort_Direction()
JAL	__Lib_TFT_Defs_TFT_Set_DataPort_Direction+0
NOP	
;__Lib_TFT_Defs.mbas,1477 :: 		TFT_Reset_HX8352A()
JAL	__Lib_TFT_Defs_TFT_Reset_HX8352A+0
NOP	
;__Lib_TFT_Defs.mbas,1478 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address_HX8352A
LUI	R2, hi_addr(_TFT_Set_Address_HX8352A+0)
ORI	R2, R2, lo_addr(_TFT_Set_Address_HX8352A+0)
;__Lib_TFT_Defs.mbas,1479 :: 		end sub
L_end_TFT_Init_HX8352A:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
; end of _TFT_Init_HX8352A
_TFT_Init_HX8352A_Custom:
;__Lib_TFT_Defs.mbas,1489 :: 		sub procedure TFT_Init_HX8352A_Custom(dim display_width as word display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,1490 :: 		__controller = _16BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 65535
;__Lib_TFT_Defs.mbas,1491 :: 		TFT_Set_HX8352A()
NOP	
;__Lib_TFT_Defs.mbas,1492 :: 		if (Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init_HX8352A_Custom538
NOP	
J	L__TFT_Init_HX8352A_Custom146
NOP	
L__TFT_Init_HX8352A_Custom538:
;__Lib_TFT_Defs.mbas,1493 :: 		TFT_Set_Index_Ptr = @TFT_Set_Index
;__Lib_TFT_Defs.mbas,1494 :: 		TFT_Write_Command_Ptr = @TFT_Write_Command
;__Lib_TFT_Defs.mbas,1495 :: 		TFT_Write_Data_Ptr = @TFT_16bit_Write_Data
L__TFT_Init_HX8352A_Custom146:
;__Lib_TFT_Defs.mbas,1498 :: 		TFT_DISP_WIDTH = display_width
;__Lib_TFT_Defs.mbas,1499 :: 		TFT_DISP_HEIGHT = display_height
;__Lib_TFT_Defs.mbas,1500 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init_HX8352A_Custom539
NOP	
J	L__TFT_Init_HX8352A_Custom149
NOP	
L__TFT_Init_HX8352A_Custom539:
;__Lib_TFT_Defs.mbas,1501 :: 		TFT_Disp_Rotation = 0
J	L__TFT_Init_HX8352A_Custom150
NOP	
;__Lib_TFT_Defs.mbas,1502 :: 		else
L__TFT_Init_HX8352A_Custom149:
;__Lib_TFT_Defs.mbas,1503 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
;__Lib_TFT_Defs.mbas,1504 :: 		end if
L__TFT_Init_HX8352A_Custom150:
;__Lib_TFT_Defs.mbas,1506 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,1507 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,1509 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,1510 :: 		TFT_Clear_Fonts()
NOP	
;__Lib_TFT_Defs.mbas,1512 :: 		TFT_Reset_HX8352A()
NOP	
;__Lib_TFT_Defs.mbas,1513 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address_HX8352A
;__Lib_TFT_Defs.mbas,1514 :: 		end sub
L_end_TFT_Init_HX8352A_Custom:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
; end of _TFT_Init_HX8352A_Custom
_TFT_Set_Address_ILI9340:
;__Lib_TFT_Defs.mbas,1523 :: 		sub procedure TFT_Set_Address_ILI9340(dim x as word y as word)
ADDIU	SP, SP, -12
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,1524 :: 		TFT_Set_Index_Ptr(0x2A)
SW	R25, 4(SP)
SH	R26, 8(SP)
SH	R25, 10(SP)
ORI	R25, R0, 42
JALR	RA, R30
NOP	
LHU	R25, 10(SP)
;__Lib_TFT_Defs.mbas,1525 :: 		TFT_Write_Command_Ptr(x >> 8)
ANDI	R2, R25, 65535
SRL	R2, R2, 8
SH	R25, 10(SP)
ANDI	R25, R2, 65535
JALR	RA, R30
NOP	
LHU	R25, 10(SP)
;__Lib_TFT_Defs.mbas,1526 :: 		TFT_Write_Command_Ptr(x)
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1527 :: 		TFT_Set_Index_Ptr(0x2B)
ORI	R25, R0, 43
JALR	RA, R30
NOP	
LHU	R26, 8(SP)
;__Lib_TFT_Defs.mbas,1528 :: 		TFT_Write_Command_Ptr(y >> 8)
ANDI	R2, R26, 65535
SRL	R2, R2, 8
SH	R26, 8(SP)
ANDI	R25, R2, 65535
JALR	RA, R30
NOP	
LHU	R26, 8(SP)
;__Lib_TFT_Defs.mbas,1529 :: 		TFT_Write_Command_Ptr(y)
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1530 :: 		TFT_Set_Index_Ptr(0x2C)
ORI	R25, R0, 44
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1531 :: 		end sub
L_end_TFT_Set_Address_ILI9340:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 12
JR	RA
NOP	
; end of _TFT_Set_Address_ILI9340
__Lib_TFT_Defs_TFT_Reset_ILI9340:
;__Lib_TFT_Defs.mbas,1537 :: 		sub procedure TFT_Reset_ILI9340()
ADDIU	SP, SP, -8
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,1539 :: 		TFT_RST = 0
SW	R25, 4(SP)
_LX	
_SX	
;__Lib_TFT_Defs.mbas,1541 :: 		TFT_RST_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,1544 :: 		TFT_RS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,1546 :: 		TFT_RS_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,1549 :: 		TFT_CS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,1551 :: 		TFT_CS_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,1553 :: 		TFT_RD_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,1554 :: 		TFT_WR_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,1555 :: 		TFT_RD = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,1556 :: 		TFT_WR = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,1558 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,1559 :: 		TFT_RST = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,1560 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,1561 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,1563 :: 		TFT_CS = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,1565 :: 		TFT_Set_Index_Ptr(0x11)'Exit Sleep
ORI	R25, R0, 17
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1566 :: 		Delay_10ms() Delay_10ms() Delay_10ms()
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
;__Lib_TFT_Defs.mbas,1567 :: 		Delay_10ms() Delay_10ms() Delay_10ms()
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
;__Lib_TFT_Defs.mbas,1569 :: 		TFT_Set_Index_Ptr(0xCB)TFT_Write_Command_Ptr(0x01)'AP[2:0]
ORI	R25, R0, 203
JALR	RA, R30
NOP	
ORI	R25, R0, 1
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1571 :: 		TFT_Set_Index_Ptr(0xC0)TFT_Write_Command_Ptr(0x26) 'VRH[5:0]
ORI	R25, R0, 192
JALR	RA, R30
NOP	
ORI	R25, R0, 38
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1572 :: 		TFT_Write_Command_Ptr(0x04)'VC[2:0]
ORI	R25, R0, 4
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1574 :: 		TFT_Set_Index_Ptr(0xC1)TFT_Write_Command_Ptr(0x04) 'SAP[2:0]BT[3:0]
ORI	R25, R0, 193
JALR	RA, R30
NOP	
ORI	R25, R0, 4
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1577 :: 		TFT_Set_Index_Ptr(0xC5)TFT_Write_Command_Ptr(0x34) 'VCM control
ORI	R25, R0, 197
JALR	RA, R30
NOP	
ORI	R25, R0, 52
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1578 :: 		TFT_Write_Command_Ptr(0x40)
ORI	R25, R0, 64
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1579 :: 		TFT_Set_Index_Ptr(0x36)     ' memory access control
ORI	R25, R0, 54
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1580 :: 		if (TFT_Disp_Rotation = 90) then
ORI	R2, R0, 90
BEQ	R3, R2, L___Lib_TFT_Defs_TFT_Reset_ILI9340542
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_ILI9340154
NOP	
L___Lib_TFT_Defs_TFT_Reset_ILI9340542:
;__Lib_TFT_Defs.mbas,1581 :: 		if (Is_TFT_Rotated_180() = 1) then
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BEQ	R3, R2, L___Lib_TFT_Defs_TFT_Reset_ILI9340543
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_ILI9340157
NOP	
L___Lib_TFT_Defs_TFT_Reset_ILI9340543:
;__Lib_TFT_Defs.mbas,1582 :: 		TFT_Write_Command_Ptr (0xC8)
ORI	R25, R0, 200
JALR	RA, R30
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_ILI9340158
NOP	
;__Lib_TFT_Defs.mbas,1583 :: 		else
L___Lib_TFT_Defs_TFT_Reset_ILI9340157:
;__Lib_TFT_Defs.mbas,1584 :: 		TFT_Write_Command_Ptr (0x08)
ORI	R25, R0, 8
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1585 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_ILI9340158:
J	L___Lib_TFT_Defs_TFT_Reset_ILI9340155
NOP	
;__Lib_TFT_Defs.mbas,1586 :: 		else
L___Lib_TFT_Defs_TFT_Reset_ILI9340154:
;__Lib_TFT_Defs.mbas,1587 :: 		if (Is_TFT_Rotated_180() = 1) then
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BEQ	R3, R2, L___Lib_TFT_Defs_TFT_Reset_ILI9340544
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_ILI9340160
NOP	
L___Lib_TFT_Defs_TFT_Reset_ILI9340544:
;__Lib_TFT_Defs.mbas,1588 :: 		TFT_Write_Command_Ptr (0xA8)
ORI	R25, R0, 168
JALR	RA, R30
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_ILI9340161
NOP	
;__Lib_TFT_Defs.mbas,1589 :: 		else
L___Lib_TFT_Defs_TFT_Reset_ILI9340160:
;__Lib_TFT_Defs.mbas,1590 :: 		TFT_Write_Command_Ptr (0x68)
ORI	R25, R0, 104
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1591 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_ILI9340161:
;__Lib_TFT_Defs.mbas,1592 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_ILI9340155:
;__Lib_TFT_Defs.mbas,1594 :: 		TFT_Set_Index_Ptr(0xB1)TFT_Write_Command_Ptr(0x00) ' Frame Rate Control
ORI	R25, R0, 177
JALR	RA, R30
NOP	
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1595 :: 		TFT_Write_Command_Ptr(0x18)
ORI	R25, R0, 24
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1597 :: 		TFT_Set_Index_Ptr(0xB6)TFT_Write_Command_Ptr(0x0A) ' Display Function Control
ORI	R25, R0, 182
JALR	RA, R30
NOP	
ORI	R25, R0, 10
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1598 :: 		TFT_Write_Command_Ptr(0xA2)
ORI	R25, R0, 162
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1600 :: 		TFT_Set_Index_Ptr(0xC7)TFT_Write_Command_Ptr(0xCD) 'VCOM Control , VMF[6:0]
ORI	R25, R0, 199
JALR	RA, R30
NOP	
ORI	R25, R0, 205
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1602 :: 		TFT_Set_Index_Ptr(0xE8)
ORI	R25, R0, 232
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1603 :: 		TFT_Write_Command_Ptr(0x89)
ORI	R25, R0, 137
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1604 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1605 :: 		TFT_Write_Command_Ptr(0x79)
ORI	R25, R0, 121
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1607 :: 		TFT_Set_Index_Ptr(0xF2)TFT_Write_Command_Ptr(0x00) ' 3Gamma Function Disable
ORI	R25, R0, 242
JALR	RA, R30
NOP	
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1609 :: 		TFT_Set_Index_Ptr(0xE0)TFT_Write_Command_Ptr(0x0F)
ORI	R25, R0, 224
JALR	RA, R30
NOP	
ORI	R25, R0, 15
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1610 :: 		TFT_Write_Command_Ptr(0x1D)
ORI	R25, R0, 29
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1611 :: 		TFT_Write_Command_Ptr(0x1A)
ORI	R25, R0, 26
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1612 :: 		TFT_Write_Command_Ptr(0x0B)
ORI	R25, R0, 11
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1613 :: 		TFT_Write_Command_Ptr(0x0F)
ORI	R25, R0, 15
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1614 :: 		TFT_Write_Command_Ptr(0x09)
ORI	R25, R0, 9
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1615 :: 		TFT_Write_Command_Ptr(0x47)
ORI	R25, R0, 71
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1616 :: 		TFT_Write_Command_Ptr(0xD6)
ORI	R25, R0, 214
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1617 :: 		TFT_Write_Command_Ptr(0x37)
ORI	R25, R0, 55
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1618 :: 		TFT_Write_Command_Ptr(0x0A)
ORI	R25, R0, 10
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1619 :: 		TFT_Write_Command_Ptr(0x0C)
ORI	R25, R0, 12
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1620 :: 		TFT_Write_Command_Ptr(0x07)
ORI	R25, R0, 7
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1621 :: 		TFT_Write_Command_Ptr(0x07)
ORI	R25, R0, 7
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1622 :: 		TFT_Write_Command_Ptr(0x05)
ORI	R25, R0, 5
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1623 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1625 :: 		TFT_Set_Index_Ptr(0xE1)TFT_Write_Command_Ptr(0x00)
ORI	R25, R0, 225
JALR	RA, R30
NOP	
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1626 :: 		TFT_Write_Command_Ptr(0x22)
ORI	R25, R0, 34
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1627 :: 		TFT_Write_Command_Ptr(0x25)
ORI	R25, R0, 37
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1628 :: 		TFT_Write_Command_Ptr(0x04)
ORI	R25, R0, 4
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1629 :: 		TFT_Write_Command_Ptr(0x10)
ORI	R25, R0, 16
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1630 :: 		TFT_Write_Command_Ptr(0x06)
ORI	R25, R0, 6
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1631 :: 		TFT_Write_Command_Ptr(0x38)
ORI	R25, R0, 56
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1632 :: 		TFT_Write_Command_Ptr(0x7F)
ORI	R25, R0, 127
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1633 :: 		TFT_Write_Command_Ptr(0x48)
ORI	R25, R0, 72
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1634 :: 		TFT_Write_Command_Ptr(0x05)
ORI	R25, R0, 5
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1635 :: 		TFT_Write_Command_Ptr(0x13)
ORI	R25, R0, 19
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1636 :: 		TFT_Write_Command_Ptr(0x38)
ORI	R25, R0, 56
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1637 :: 		TFT_Write_Command_Ptr(0x38)
ORI	R25, R0, 56
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1638 :: 		TFT_Write_Command_Ptr(0x3A)
ORI	R25, R0, 58
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1639 :: 		TFT_Write_Command_Ptr(0x0F)
ORI	R25, R0, 15
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1641 :: 		TFT_Set_Index_Ptr(0x29)
ORI	R25, R0, 41
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1642 :: 		TFT_Set_Index_Ptr(0x3A)
ORI	R25, R0, 58
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1643 :: 		TFT_Write_Command_Ptr(0x05)
ORI	R25, R0, 5
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1647 :: 		TFT_Set_Index_Ptr(0x2A)
ORI	R25, R0, 42
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1648 :: 		TFT_Write_Command_Ptr(0)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1649 :: 		TFT_Write_Command_Ptr(0)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1650 :: 		TFT_Write_Command_Ptr((TFT_DISP_WIDTH-1) >> 8)
LHU	R2, Offset(_TFT_DISP_WIDTH+0)(GP)
ADDIU	R2, R2, -1
ANDI	R2, R2, 65535
SRL	R2, R2, 8
ANDI	R25, R2, 65535
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1651 :: 		TFT_Write_Command_Ptr(TFT_DISP_WIDTH-1)
ADDIU	R2, R2, -1
ANDI	R25, R2, 255
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1652 :: 		TFT_Set_Index_Ptr(0x2B)
ORI	R25, R0, 43
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1653 :: 		TFT_Write_Command_Ptr(0)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1654 :: 		TFT_Write_Command_Ptr(0)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1655 :: 		TFT_Write_Command_Ptr((TFT_DISP_HEIGHT-1) >> 8)
LHU	R2, Offset(_TFT_DISP_HEIGHT+0)(GP)
ADDIU	R2, R2, -1
ANDI	R2, R2, 65535
SRL	R2, R2, 8
ANDI	R25, R2, 65535
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1656 :: 		TFT_Write_Command_Ptr(TFT_DISP_HEIGHT-1)
ADDIU	R2, R2, -1
ANDI	R25, R2, 255
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1658 :: 		Delay_10ms()
JAL	_Delay_10ms+0
NOP	
;__Lib_TFT_Defs.mbas,1659 :: 		TFT_CS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,1660 :: 		end sub
L_end_TFT_Reset_ILI9340:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 8
JR	RA
NOP	
; end of __Lib_TFT_Defs_TFT_Reset_ILI9340
_TFT_Init_ILI9340:
;__Lib_TFT_Defs.mbas,1667 :: 		sub procedure TFT_Init_ILI9340(dim display_width as word display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,1668 :: 		__controller = _16BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 65535
;__Lib_TFT_Defs.mbas,1669 :: 		if (Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init_ILI9340547
NOP	
J	L__TFT_Init_ILI9340164
NOP	
L__TFT_Init_ILI9340547:
;__Lib_TFT_Defs.mbas,1670 :: 		TFT_Set_Index_Ptr = @TFT_Set_Index
;__Lib_TFT_Defs.mbas,1671 :: 		TFT_Write_Command_Ptr = @TFT_Write_Command
;__Lib_TFT_Defs.mbas,1672 :: 		TFT_Write_Data_Ptr = @TFT_16bit_Write_Data
L__TFT_Init_ILI9340164:
;__Lib_TFT_Defs.mbas,1675 :: 		TFT_DISP_WIDTH = display_width
;__Lib_TFT_Defs.mbas,1676 :: 		TFT_DISP_HEIGHT = display_height
;__Lib_TFT_Defs.mbas,1677 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init_ILI9340548
NOP	
J	L__TFT_Init_ILI9340167
NOP	
L__TFT_Init_ILI9340548:
;__Lib_TFT_Defs.mbas,1678 :: 		TFT_Disp_Rotation = 0
J	L__TFT_Init_ILI9340168
NOP	
;__Lib_TFT_Defs.mbas,1679 :: 		else
L__TFT_Init_ILI9340167:
;__Lib_TFT_Defs.mbas,1680 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
;__Lib_TFT_Defs.mbas,1681 :: 		end if
L__TFT_Init_ILI9340168:
;__Lib_TFT_Defs.mbas,1683 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,1684 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,1686 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,1687 :: 		TFT_Clear_Fonts()
NOP	
;__Lib_TFT_Defs.mbas,1688 :: 		TFT_Set_DataPort_Direction()
NOP	
;__Lib_TFT_Defs.mbas,1690 :: 		TFT_Reset_ILI9340()
JAL	__Lib_TFT_Defs_TFT_Reset_ILI9340+0
NOP	
;__Lib_TFT_Defs.mbas,1691 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address_ILI9340
LUI	R2, hi_addr(_TFT_Set_Address_ILI9340+0)
ORI	R2, R2, lo_addr(_TFT_Set_Address_ILI9340+0)
;__Lib_TFT_Defs.mbas,1692 :: 		end sub
L_end_TFT_Init_ILI9340:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
; end of _TFT_Init_ILI9340
_TFT_Init_ILI9340_Custom:
;__Lib_TFT_Defs.mbas,1702 :: 		sub procedure TFT_Init_ILI9340_Custom(dim display_width as word display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,1703 :: 		__controller = _16BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 65535
;__Lib_TFT_Defs.mbas,1704 :: 		if (Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init_ILI9340_Custom551
NOP	
J	L__TFT_Init_ILI9340_Custom171
NOP	
L__TFT_Init_ILI9340_Custom551:
;__Lib_TFT_Defs.mbas,1705 :: 		TFT_Set_Index_Ptr = @TFT_Set_Index
;__Lib_TFT_Defs.mbas,1706 :: 		TFT_Write_Command_Ptr = @TFT_Write_Command
;__Lib_TFT_Defs.mbas,1707 :: 		TFT_Write_Data_Ptr = @TFT_16bit_Write_Data
L__TFT_Init_ILI9340_Custom171:
;__Lib_TFT_Defs.mbas,1710 :: 		TFT_DISP_WIDTH = display_width
;__Lib_TFT_Defs.mbas,1711 :: 		TFT_DISP_HEIGHT = display_height
;__Lib_TFT_Defs.mbas,1712 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init_ILI9340_Custom552
NOP	
J	L__TFT_Init_ILI9340_Custom174
NOP	
L__TFT_Init_ILI9340_Custom552:
;__Lib_TFT_Defs.mbas,1713 :: 		TFT_Disp_Rotation = 0
J	L__TFT_Init_ILI9340_Custom175
NOP	
;__Lib_TFT_Defs.mbas,1714 :: 		else
L__TFT_Init_ILI9340_Custom174:
;__Lib_TFT_Defs.mbas,1715 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
;__Lib_TFT_Defs.mbas,1716 :: 		end if
L__TFT_Init_ILI9340_Custom175:
;__Lib_TFT_Defs.mbas,1718 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,1719 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,1721 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,1722 :: 		TFT_Clear_Fonts()
NOP	
;__Lib_TFT_Defs.mbas,1724 :: 		TFT_Reset_ILI9340()
NOP	
;__Lib_TFT_Defs.mbas,1725 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address_ILI9340
;__Lib_TFT_Defs.mbas,1726 :: 		end sub
L_end_TFT_Init_ILI9340_Custom:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
; end of _TFT_Init_ILI9340_Custom
_TFT_Init_ILI9340_8bit:
;__Lib_TFT_Defs.mbas,1735 :: 		sub procedure TFT_Init_ILI9340_8bit(dim display_width as word display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,1736 :: 		__controller = _8BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 255
;__Lib_TFT_Defs.mbas,1737 :: 		if (Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init_ILI9340_8bit555
NOP	
J	L__TFT_Init_ILI9340_8bit178
NOP	
L__TFT_Init_ILI9340_8bit555:
;__Lib_TFT_Defs.mbas,1738 :: 		TFT_Set_Index_Ptr = @TFT_Set_Index
;__Lib_TFT_Defs.mbas,1739 :: 		TFT_Write_Command_Ptr = @TFT_Write_Command
;__Lib_TFT_Defs.mbas,1740 :: 		TFT_Write_Data_Ptr = @TFT_Write_Data
L__TFT_Init_ILI9340_8bit178:
;__Lib_TFT_Defs.mbas,1743 :: 		TFT_DISP_WIDTH = display_width
;__Lib_TFT_Defs.mbas,1744 :: 		TFT_DISP_HEIGHT = display_height
;__Lib_TFT_Defs.mbas,1745 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init_ILI9340_8bit556
NOP	
J	L__TFT_Init_ILI9340_8bit181
NOP	
L__TFT_Init_ILI9340_8bit556:
;__Lib_TFT_Defs.mbas,1746 :: 		TFT_Disp_Rotation = 0
J	L__TFT_Init_ILI9340_8bit182
NOP	
;__Lib_TFT_Defs.mbas,1747 :: 		else
L__TFT_Init_ILI9340_8bit181:
;__Lib_TFT_Defs.mbas,1748 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
;__Lib_TFT_Defs.mbas,1749 :: 		end if
L__TFT_Init_ILI9340_8bit182:
;__Lib_TFT_Defs.mbas,1751 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,1752 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,1754 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,1755 :: 		TFT_Clear_Fonts()
NOP	
;__Lib_TFT_Defs.mbas,1756 :: 		TFT_Set_DataPort_Direction()
NOP	
;__Lib_TFT_Defs.mbas,1758 :: 		TFT_Reset_ILI9340()
NOP	
;__Lib_TFT_Defs.mbas,1759 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address_ILI9340
;__Lib_TFT_Defs.mbas,1760 :: 		end sub
L_end_TFT_Init_ILI9340_8bit:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
; end of _TFT_Init_ILI9340_8bit
_TFT_Init_ILI9340_8bit_Custom:
;__Lib_TFT_Defs.mbas,1770 :: 		sub procedure TFT_Init_ILI9340_8bit_Custom(dim display_width as word display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,1771 :: 		__controller = _8BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 255
;__Lib_TFT_Defs.mbas,1772 :: 		if (Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init_ILI9340_8bit_Custom559
NOP	
J	L__TFT_Init_ILI9340_8bit_Custom185
NOP	
L__TFT_Init_ILI9340_8bit_Custom559:
;__Lib_TFT_Defs.mbas,1773 :: 		TFT_Set_Index_Ptr = @TFT_Set_Index
;__Lib_TFT_Defs.mbas,1774 :: 		TFT_Write_Command_Ptr = @TFT_Write_Command
;__Lib_TFT_Defs.mbas,1775 :: 		TFT_Write_Data_Ptr = @TFT_Write_Data
L__TFT_Init_ILI9340_8bit_Custom185:
;__Lib_TFT_Defs.mbas,1778 :: 		TFT_DISP_WIDTH = display_width
;__Lib_TFT_Defs.mbas,1779 :: 		TFT_DISP_HEIGHT = display_height
;__Lib_TFT_Defs.mbas,1780 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init_ILI9340_8bit_Custom560
NOP	
J	L__TFT_Init_ILI9340_8bit_Custom188
NOP	
L__TFT_Init_ILI9340_8bit_Custom560:
;__Lib_TFT_Defs.mbas,1781 :: 		TFT_Disp_Rotation = 0
J	L__TFT_Init_ILI9340_8bit_Custom189
NOP	
;__Lib_TFT_Defs.mbas,1782 :: 		else
L__TFT_Init_ILI9340_8bit_Custom188:
;__Lib_TFT_Defs.mbas,1783 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
;__Lib_TFT_Defs.mbas,1784 :: 		end if
L__TFT_Init_ILI9340_8bit_Custom189:
;__Lib_TFT_Defs.mbas,1786 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,1787 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,1789 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,1790 :: 		TFT_Clear_Fonts()
NOP	
;__Lib_TFT_Defs.mbas,1792 :: 		TFT_Reset_ILI9340()
NOP	
;__Lib_TFT_Defs.mbas,1793 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address_ILI9340
;__Lib_TFT_Defs.mbas,1794 :: 		end sub
L_end_TFT_Init_ILI9340_8bit_Custom:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
; end of _TFT_Init_ILI9340_8bit_Custom
__Lib_TFT_Defs_TFT_Reset_ST7789V:
;__Lib_TFT_Defs.mbas,1802 :: 		sub procedure TFT_Reset_ST7789V()
ADDIU	SP, SP, -8
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,1804 :: 		TFT_RST = 0
SW	R25, 4(SP)
_LX	
INS	R2, R0, BitPos(TFT_RST+0), 1
_SX	
;__Lib_TFT_Defs.mbas,1806 :: 		TFT_RST_Direction = 0
_LX	
INS	R2, R0, BitPos(TFT_RST_Direction+0), 1
_SX	
;__Lib_TFT_Defs.mbas,1809 :: 		TFT_RS = 1
_LX	
ORI	R2, R2, BitMask(TFT_RS+0)
_SX	
;__Lib_TFT_Defs.mbas,1811 :: 		TFT_RS_Direction = 0
_LX	
INS	R2, R0, BitPos(TFT_RS_Direction+0), 1
_SX	
;__Lib_TFT_Defs.mbas,1814 :: 		TFT_CS = 1
_LX	
ORI	R2, R2, BitMask(TFT_CS+0)
_SX	
;__Lib_TFT_Defs.mbas,1816 :: 		TFT_CS_Direction = 0
_LX	
INS	R2, R0, BitPos(TFT_CS_Direction+0), 1
_SX	
;__Lib_TFT_Defs.mbas,1818 :: 		TFT_RD_Direction = 0
_LX	
INS	R2, R0, BitPos(TFT_RD_Direction+0), 1
_SX	
;__Lib_TFT_Defs.mbas,1819 :: 		TFT_WR_Direction = 0
_LX	
INS	R2, R0, BitPos(TFT_WR_Direction+0), 1
_SX	
;__Lib_TFT_Defs.mbas,1820 :: 		TFT_RD = 1
_LX	
ORI	R2, R2, BitMask(TFT_RD+0)
_SX	
;__Lib_TFT_Defs.mbas,1821 :: 		TFT_WR = 1
_LX	
ORI	R2, R2, BitMask(TFT_WR+0)
_SX	
;__Lib_TFT_Defs.mbas,1823 :: 		TFT_RST = 1
_LX	
ORI	R2, R2, BitMask(TFT_RST+0)
_SX	
;__Lib_TFT_Defs.mbas,1824 :: 		Delay_10ms()
JAL	_Delay_10ms+0
NOP	
;__Lib_TFT_Defs.mbas,1825 :: 		TFT_RST = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,1826 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,1827 :: 		TFT_RST = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,1828 :: 		Delay_100ms() Delay_10ms() Delay_10ms()
JAL	_Delay_100ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
;__Lib_TFT_Defs.mbas,1829 :: 		TFT_CS = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,1831 :: 		TFT_Set_Index_Ptr(0x11)
ORI	R25, R0, 17
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1832 :: 		Delay_100ms()      'Delay 120ms
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,1833 :: 		Delay_10ms() Delay_10ms()
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
;__Lib_TFT_Defs.mbas,1835 :: 		TFT_Set_Index_Ptr(0x36)
ORI	R25, R0, 54
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1836 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1838 :: 		TFT_Set_Index_Ptr(0x3a)
ORI	R25, R0, 58
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1839 :: 		TFT_Write_Command_Ptr(0x05)  '65k
ORI	R25, R0, 5
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1841 :: 		TFT_Set_Index_Ptr(0xb2)
ORI	R25, R0, 178
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1842 :: 		TFT_Write_Command_Ptr(0x0c)
ORI	R25, R0, 12
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1843 :: 		TFT_Write_Command_Ptr(0x0c)
ORI	R25, R0, 12
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1844 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1845 :: 		TFT_Write_Command_Ptr(0x33)
ORI	R25, R0, 51
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1846 :: 		TFT_Write_Command_Ptr(0x33)
ORI	R25, R0, 51
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1848 :: 		TFT_Set_Index_Ptr(0xb7)
ORI	R25, R0, 183
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1849 :: 		TFT_Write_Command_Ptr(0x70)
ORI	R25, R0, 112
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1852 :: 		TFT_Set_Index_Ptr(0xbb)
ORI	R25, R0, 187
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1853 :: 		TFT_Write_Command_Ptr(0x1B)'VCOM
ORI	R25, R0, 27
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1855 :: 		TFT_Set_Index_Ptr(0xc0)
ORI	R25, R0, 192
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1856 :: 		TFT_Write_Command_Ptr(0x2c)
ORI	R25, R0, 44
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1858 :: 		TFT_Set_Index_Ptr(0xc2)
ORI	R25, R0, 194
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1859 :: 		TFT_Write_Command_Ptr(0x01)
ORI	R25, R0, 1
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1861 :: 		TFT_Set_Index_Ptr(0xc3)
ORI	R25, R0, 195
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1862 :: 		TFT_Write_Command_Ptr(0x0B)
ORI	R25, R0, 11
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1864 :: 		TFT_Set_Index_Ptr(0xc4)
ORI	R25, R0, 196
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1865 :: 		TFT_Write_Command_Ptr(0x27)
ORI	R25, R0, 39
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1867 :: 		TFT_Set_Index_Ptr(0xc6)
ORI	R25, R0, 198
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1868 :: 		TFT_Write_Command_Ptr(0x0f)
ORI	R25, R0, 15
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1870 :: 		TFT_Set_Index_Ptr(0xd0)
ORI	R25, R0, 208
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1871 :: 		TFT_Write_Command_Ptr(0xa4)
ORI	R25, R0, 164
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1872 :: 		TFT_Write_Command_Ptr(0xA1)
ORI	R25, R0, 161
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1874 :: 		TFT_Set_Index_Ptr(0xe0)
ORI	R25, R0, 224
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1875 :: 		TFT_Write_Command_Ptr(0xD0)
ORI	R25, R0, 208
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1876 :: 		TFT_Write_Command_Ptr(0x06)
ORI	R25, R0, 6
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1877 :: 		TFT_Write_Command_Ptr(0x0B)
ORI	R25, R0, 11
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1878 :: 		TFT_Write_Command_Ptr(0x09)
ORI	R25, R0, 9
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1879 :: 		TFT_Write_Command_Ptr(0x08)
ORI	R25, R0, 8
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1880 :: 		TFT_Write_Command_Ptr(0x30)
ORI	R25, R0, 48
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1881 :: 		TFT_Write_Command_Ptr(0x30)
ORI	R25, R0, 48
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1882 :: 		TFT_Write_Command_Ptr(0x5B)
ORI	R25, R0, 91
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1883 :: 		TFT_Write_Command_Ptr(0x4B)
ORI	R25, R0, 75
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1884 :: 		TFT_Write_Command_Ptr(0x18)
ORI	R25, R0, 24
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1885 :: 		TFT_Write_Command_Ptr(0x14)
ORI	R25, R0, 20
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1886 :: 		TFT_Write_Command_Ptr(0x14)
ORI	R25, R0, 20
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1887 :: 		TFT_Write_Command_Ptr(0x2C)
ORI	R25, R0, 44
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1888 :: 		TFT_Write_Command_Ptr(0x32)
ORI	R25, R0, 50
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1890 :: 		TFT_Set_Index_Ptr(0xe1)
ORI	R25, R0, 225
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1891 :: 		TFT_Write_Command_Ptr(0xD0)
ORI	R25, R0, 208
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1892 :: 		TFT_Write_Command_Ptr(0x05)
ORI	R25, R0, 5
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1893 :: 		TFT_Write_Command_Ptr(0x0A)
ORI	R25, R0, 10
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1894 :: 		TFT_Write_Command_Ptr(0x0A)
ORI	R25, R0, 10
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1895 :: 		TFT_Write_Command_Ptr(0x07)
ORI	R25, R0, 7
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1896 :: 		TFT_Write_Command_Ptr(0x28)
ORI	R25, R0, 40
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1897 :: 		TFT_Write_Command_Ptr(0x32)
ORI	R25, R0, 50
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1898 :: 		TFT_Write_Command_Ptr(0x2C)
ORI	R25, R0, 44
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1899 :: 		TFT_Write_Command_Ptr(0x49)
ORI	R25, R0, 73
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1900 :: 		TFT_Write_Command_Ptr(0x18)
ORI	R25, R0, 24
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1901 :: 		TFT_Write_Command_Ptr(0x13)
ORI	R25, R0, 19
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1902 :: 		TFT_Write_Command_Ptr(0x13)
ORI	R25, R0, 19
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1903 :: 		TFT_Write_Command_Ptr(0x2C)
ORI	R25, R0, 44
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1904 :: 		TFT_Write_Command_Ptr(0x33)
ORI	R25, R0, 51
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1906 :: 		TFT_Set_Index_Ptr(0x21) '·´ÏÔ
ORI	R25, R0, 33
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1908 :: 		TFT_Set_Index_Ptr(0x2A) ' Column Address Set
ORI	R25, R0, 42
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1909 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1910 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1911 :: 		TFT_Write_Command_Ptr(TFT_DISP_WIDTH >> 8)
SRL	R2, R2, 8
ANDI	R25, R2, 65535
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1912 :: 		TFT_Write_Command_Ptr(TFT_DISP_WIDTH)
LHU	R25, Offset(_TFT_DISP_WIDTH+0)(GP)
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1913 :: 		TFT_Set_Index_Ptr(0x2B) 'Row Address Set
ORI	R25, R0, 43
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1914 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1915 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1916 :: 		TFT_Write_Command_Ptr(TFT_DISP_HEIGHT >> 8)
SRL	R2, R2, 8
ANDI	R25, R2, 65535
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1917 :: 		TFT_Write_Command_Ptr(TFT_DISP_HEIGHT)
LHU	R25, Offset(_TFT_DISP_HEIGHT+0)(GP)
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1919 :: 		TFT_Set_Index_Ptr(0x36)     ' memory access control
ORI	R25, R0, 54
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1920 :: 		if (TFT_Disp_Rotation = 90) then
LBU	R3, Offset(__Lib_TFT_Defs_TFT_Disp_Rotation+0)(GP)
ORI	R2, R0, 90
BEQ	R3, R2, L___Lib_TFT_Defs_TFT_Reset_ST7789V562
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_ST7789V192
NOP	
L___Lib_TFT_Defs_TFT_Reset_ST7789V562:
;__Lib_TFT_Defs.mbas,1921 :: 		if (Is_TFT_Rotated_180()) then
JAL	_Is_TFT_Rotated_180+0
NOP	
BNE	R2, R0, L___Lib_TFT_Defs_TFT_Reset_ST7789V564
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_ST7789V195
NOP	
L___Lib_TFT_Defs_TFT_Reset_ST7789V564:
;__Lib_TFT_Defs.mbas,1922 :: 		TFT_Write_Command_Ptr (0xC0)
ORI	R25, R0, 192
JALR	RA, R30
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_ST7789V196
NOP	
;__Lib_TFT_Defs.mbas,1923 :: 		else
L___Lib_TFT_Defs_TFT_Reset_ST7789V195:
;__Lib_TFT_Defs.mbas,1924 :: 		TFT_Write_Command_Ptr (0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1925 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_ST7789V196:
J	L___Lib_TFT_Defs_TFT_Reset_ST7789V193
NOP	
;__Lib_TFT_Defs.mbas,1926 :: 		else
L___Lib_TFT_Defs_TFT_Reset_ST7789V192:
;__Lib_TFT_Defs.mbas,1927 :: 		if (Is_TFT_Rotated_180()) then
NOP	
BNE	R2, R0, L___Lib_TFT_Defs_TFT_Reset_ST7789V566
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_ST7789V198
NOP	
L___Lib_TFT_Defs_TFT_Reset_ST7789V566:
;__Lib_TFT_Defs.mbas,1928 :: 		TFT_Write_Command_Ptr (0xA0)
ORI	R25, R0, 160
JALR	RA, R30
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_ST7789V199
NOP	
;__Lib_TFT_Defs.mbas,1929 :: 		else
L___Lib_TFT_Defs_TFT_Reset_ST7789V198:
;__Lib_TFT_Defs.mbas,1930 :: 		TFT_Write_Command_Ptr (0x60)
ORI	R25, R0, 96
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1931 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_ST7789V199:
;__Lib_TFT_Defs.mbas,1932 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_ST7789V193:
;__Lib_TFT_Defs.mbas,1934 :: 		TFT_Set_Index_Ptr(0x29) 'display on
ORI	R25, R0, 41
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1935 :: 		TFT_Set_Index_Ptr(0x2c)
ORI	R25, R0, 44
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,1936 :: 		TFT_CS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,1937 :: 		end sub
L_end_TFT_Reset_ST7789V:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 8
JR	RA
NOP	
; end of __Lib_TFT_Defs_TFT_Reset_ST7789V
_TFT_Init_ST7789V_8bit_Custom:
;__Lib_TFT_Defs.mbas,1944 :: 		sub procedure TFT_Init_ST7789V_8bit_Custom(dim display_width as word display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,1945 :: 		__controller = _8BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 255
;__Lib_TFT_Defs.mbas,1946 :: 		if (Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init_ST7789V_8bit_Custom569
NOP	
J	L__TFT_Init_ST7789V_8bit_Custom202
NOP	
L__TFT_Init_ST7789V_8bit_Custom569:
;__Lib_TFT_Defs.mbas,1947 :: 		TFT_Set_Index_Ptr = @TFT_Set_Index
;__Lib_TFT_Defs.mbas,1948 :: 		TFT_Write_Command_Ptr = @TFT_Write_Command
;__Lib_TFT_Defs.mbas,1949 :: 		TFT_Write_Data_Ptr = @TFT_Write_Data
L__TFT_Init_ST7789V_8bit_Custom202:
;__Lib_TFT_Defs.mbas,1952 :: 		TFT_DISP_WIDTH = display_width
;__Lib_TFT_Defs.mbas,1953 :: 		TFT_DISP_HEIGHT = display_height
;__Lib_TFT_Defs.mbas,1954 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init_ST7789V_8bit_Custom570
NOP	
J	L__TFT_Init_ST7789V_8bit_Custom205
NOP	
L__TFT_Init_ST7789V_8bit_Custom570:
;__Lib_TFT_Defs.mbas,1955 :: 		TFT_Disp_Rotation = 0
J	L__TFT_Init_ST7789V_8bit_Custom206
NOP	
;__Lib_TFT_Defs.mbas,1956 :: 		else
L__TFT_Init_ST7789V_8bit_Custom205:
;__Lib_TFT_Defs.mbas,1957 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
;__Lib_TFT_Defs.mbas,1958 :: 		end if
L__TFT_Init_ST7789V_8bit_Custom206:
;__Lib_TFT_Defs.mbas,1960 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,1961 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,1963 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,1964 :: 		TFT_Clear_Fonts()
NOP	
;__Lib_TFT_Defs.mbas,1966 :: 		TFT_Reset_ST7789V()
JAL	__Lib_TFT_Defs_TFT_Reset_ST7789V+0
NOP	
;__Lib_TFT_Defs.mbas,1967 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address_SST7715R
LUI	R2, hi_addr(_TFT_Set_Address_SST7715R+0)
ORI	R2, R2, lo_addr(_TFT_Set_Address_SST7715R+0)
;__Lib_TFT_Defs.mbas,1968 :: 		end sub
L_end_TFT_Init_ST7789V_8bit_Custom:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
; end of _TFT_Init_ST7789V_8bit_Custom
_TFT_Init_ST7789V_8bit:
;__Lib_TFT_Defs.mbas,1975 :: 		sub procedure TFT_Init_ST7789V_8bit(dim display_width as word display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,1976 :: 		__controller = _8BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 255
SH	R2, Offset(__Lib_TFT_Defs___controller+0)(GP)
;__Lib_TFT_Defs.mbas,1977 :: 		if (Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init_ST7789V_8bit573
NOP	
J	L__TFT_Init_ST7789V_8bit209
NOP	
L__TFT_Init_ST7789V_8bit573:
;__Lib_TFT_Defs.mbas,1978 :: 		TFT_Set_Index_Ptr = @TFT_Set_Index
LUI	R2, hi_addr(_TFT_Set_Index+0)
ORI	R2, R2, lo_addr(_TFT_Set_Index+0)
SW	R2, Offset(_TFT_Set_Index_Ptr+0)(GP)
;__Lib_TFT_Defs.mbas,1979 :: 		TFT_Write_Command_Ptr = @TFT_Write_Command
LUI	R2, hi_addr(_TFT_Write_Command+0)
ORI	R2, R2, lo_addr(_TFT_Write_Command+0)
SW	R2, Offset(_TFT_Write_Command_Ptr+0)(GP)
;__Lib_TFT_Defs.mbas,1980 :: 		TFT_Write_Data_Ptr = @TFT_Write_Data
LUI	R2, hi_addr(_TFT_Write_Data+0)
ORI	R2, R2, lo_addr(_TFT_Write_Data+0)
SW	R2, Offset(_TFT_Write_Data_Ptr+0)(GP)
L__TFT_Init_ST7789V_8bit209:
;__Lib_TFT_Defs.mbas,1983 :: 		TFT_DISP_WIDTH = display_width
SH	R25, Offset(_TFT_DISP_WIDTH+0)(GP)
;__Lib_TFT_Defs.mbas,1984 :: 		TFT_DISP_HEIGHT = display_height
SH	R26, Offset(_TFT_DISP_HEIGHT+0)(GP)
;__Lib_TFT_Defs.mbas,1985 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init_ST7789V_8bit574
NOP	
J	L__TFT_Init_ST7789V_8bit212
NOP	
L__TFT_Init_ST7789V_8bit574:
;__Lib_TFT_Defs.mbas,1986 :: 		TFT_Disp_Rotation = 0
SB	R0, Offset(__Lib_TFT_Defs_TFT_Disp_Rotation+0)(GP)
J	L__TFT_Init_ST7789V_8bit213
NOP	
;__Lib_TFT_Defs.mbas,1987 :: 		else
L__TFT_Init_ST7789V_8bit212:
;__Lib_TFT_Defs.mbas,1988 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
SB	R2, Offset(__Lib_TFT_Defs_TFT_Disp_Rotation+0)(GP)
;__Lib_TFT_Defs.mbas,1989 :: 		end if
L__TFT_Init_ST7789V_8bit213:
;__Lib_TFT_Defs.mbas,1991 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,1992 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
JAL	_TFT_Set_Brush+0
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,1994 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
JAL	_TFT_Move_Cursor+0
NOP	
;__Lib_TFT_Defs.mbas,1995 :: 		TFT_Clear_Fonts()
JAL	_TFT_Clear_Fonts+0
NOP	
;__Lib_TFT_Defs.mbas,1996 :: 		TFT_Set_DataPort_Direction()
NOP	
;__Lib_TFT_Defs.mbas,1998 :: 		TFT_Reset_ST7789V()
NOP	
;__Lib_TFT_Defs.mbas,1999 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address_SST7715R
SW	R2, Offset(_TFT_Set_Address_Ptr+0)(GP)
;__Lib_TFT_Defs.mbas,2000 :: 		end sub
L_end_TFT_Init_ST7789V_8bit:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
_TFT_Init_ST7789V_16bit_Custom:
;__Lib_TFT_Defs.mbas,2007 :: 		sub procedure TFT_Init_ST7789V_16bit_Custom(dim display_width as word display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,2008 :: 		__controller = _16BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 65535
;__Lib_TFT_Defs.mbas,2009 :: 		if (Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init_ST7789V_16bit_Custom577
NOP	
J	L__TFT_Init_ST7789V_16bit_Custom216
NOP	
L__TFT_Init_ST7789V_16bit_Custom577:
;__Lib_TFT_Defs.mbas,2010 :: 		TFT_Set_Index_Ptr = @TFT_Set_Index
;__Lib_TFT_Defs.mbas,2011 :: 		TFT_Write_Command_Ptr = @TFT_Write_Command
;__Lib_TFT_Defs.mbas,2012 :: 		TFT_Write_Data_Ptr = @TFT_16bit_Write_Data
L__TFT_Init_ST7789V_16bit_Custom216:
;__Lib_TFT_Defs.mbas,2015 :: 		TFT_DISP_WIDTH = display_width
;__Lib_TFT_Defs.mbas,2016 :: 		TFT_DISP_HEIGHT = display_height
;__Lib_TFT_Defs.mbas,2017 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init_ST7789V_16bit_Custom578
NOP	
J	L__TFT_Init_ST7789V_16bit_Custom219
NOP	
L__TFT_Init_ST7789V_16bit_Custom578:
;__Lib_TFT_Defs.mbas,2018 :: 		TFT_Disp_Rotation = 0
J	L__TFT_Init_ST7789V_16bit_Custom220
NOP	
;__Lib_TFT_Defs.mbas,2019 :: 		else
L__TFT_Init_ST7789V_16bit_Custom219:
;__Lib_TFT_Defs.mbas,2020 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
;__Lib_TFT_Defs.mbas,2021 :: 		end if
L__TFT_Init_ST7789V_16bit_Custom220:
;__Lib_TFT_Defs.mbas,2023 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,2024 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,2026 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,2027 :: 		TFT_Clear_Fonts()
NOP	
;__Lib_TFT_Defs.mbas,2029 :: 		TFT_Reset_ST7789V()
NOP	
;__Lib_TFT_Defs.mbas,2030 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address_SST7715R
;__Lib_TFT_Defs.mbas,2031 :: 		end sub
L_end_TFT_Init_ST7789V_16bit_Custom:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
; end of _TFT_Init_ST7789V_16bit_Custom
_TFT_Init_ST7789V_16bit:
;__Lib_TFT_Defs.mbas,2038 :: 		sub procedure TFT_Init_ST7789V_16bit(dim display_width as word display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,2039 :: 		__controller = _16BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 65535
;__Lib_TFT_Defs.mbas,2040 :: 		if (Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init_ST7789V_16bit581
NOP	
J	L__TFT_Init_ST7789V_16bit223
NOP	
L__TFT_Init_ST7789V_16bit581:
;__Lib_TFT_Defs.mbas,2041 :: 		TFT_Set_Index_Ptr = @TFT_Set_Index
;__Lib_TFT_Defs.mbas,2042 :: 		TFT_Write_Command_Ptr = @TFT_Write_Command
;__Lib_TFT_Defs.mbas,2043 :: 		TFT_Write_Data_Ptr = @TFT_16bit_Write_Data
L__TFT_Init_ST7789V_16bit223:
;__Lib_TFT_Defs.mbas,2046 :: 		TFT_DISP_WIDTH = display_width
;__Lib_TFT_Defs.mbas,2047 :: 		TFT_DISP_HEIGHT = display_height
;__Lib_TFT_Defs.mbas,2048 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init_ST7789V_16bit582
NOP	
J	L__TFT_Init_ST7789V_16bit226
NOP	
L__TFT_Init_ST7789V_16bit582:
;__Lib_TFT_Defs.mbas,2049 :: 		TFT_Disp_Rotation = 0
J	L__TFT_Init_ST7789V_16bit227
NOP	
;__Lib_TFT_Defs.mbas,2050 :: 		else
L__TFT_Init_ST7789V_16bit226:
;__Lib_TFT_Defs.mbas,2051 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
;__Lib_TFT_Defs.mbas,2052 :: 		end if
L__TFT_Init_ST7789V_16bit227:
;__Lib_TFT_Defs.mbas,2054 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,2055 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,2057 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,2058 :: 		TFT_Clear_Fonts()
NOP	
;__Lib_TFT_Defs.mbas,2059 :: 		TFT_Set_DataPort_Direction()
NOP	
;__Lib_TFT_Defs.mbas,2061 :: 		TFT_Reset_ST7789V()
NOP	
;__Lib_TFT_Defs.mbas,2062 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address_SST7715R
;__Lib_TFT_Defs.mbas,2063 :: 		end sub
L_end_TFT_Init_ST7789V_16bit:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
__Lib_TFT_Defs_TFT_ReadId_ST7789V_or_ILI9341:
;__Lib_TFT_Defs.mbas,2067 :: 		dim id as longword
ADDIU	SP, SP, -12
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,2068 :: 		id = 0
SW	R25, 4(SP)
SW	R0, 8(SP)
;__Lib_TFT_Defs.mbas,2071 :: 		TFT_RST = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2073 :: 		TFT_RST_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2076 :: 		TFT_RS = 0
_LX	
INS	R2, R0, BitPos(TFT_RS+0), 1
_SX	
;__Lib_TFT_Defs.mbas,2078 :: 		TFT_RS_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2081 :: 		TFT_CS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2083 :: 		TFT_CS_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2085 :: 		TFT_RD_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2086 :: 		TFT_WR_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2087 :: 		TFT_RD = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2088 :: 		TFT_WR = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2090 :: 		TFT_RST = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2091 :: 		Delay_ms(100)
LUI	R24, 20
ORI	R24, R24, 22612
L___Lib_TFT_Defs_TFT_ReadId_ST7789V_or_ILI9341229:
ADDIU	R24, R24, -1
BNE	R24, R0, L___Lib_TFT_Defs_TFT_ReadId_ST7789V_or_ILI9341229
NOP	
NOP	
NOP	
;__Lib_TFT_Defs.mbas,2093 :: 		TFT_CS = 0
_LX	
INS	R2, R0, BitPos(TFT_CS+0), 1
_SX	
;__Lib_TFT_Defs.mbas,2095 :: 		TFT_Set_Index_Ptr(0x04)
ORI	R25, R0, 4
LW	R30, Offset(_TFT_Set_Index_Ptr+0)(GP)
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2098 :: 		TFT_Set_DataPort_Direction_Input()
JAL	__Lib_TFT_Defs_TFT_Set_DataPort_Direction_Input+0
NOP	
;__Lib_TFT_Defs.mbas,2099 :: 		Read_From_Port() ' don't care
JAL	__Lib_TFT_Defs_Read_From_Port+0
NOP	
;__Lib_TFT_Defs.mbas,2100 :: 		id = id or longword(Read_From_Port() and 0x00FF) << 8
NOP	
ANDI	R2, R2, 255
ANDI	R2, R2, 65535
SLL	R3, R2, 8
LW	R2, 8(SP)
OR	R2, R2, R3
SW	R2, 8(SP)
;__Lib_TFT_Defs.mbas,2101 :: 		id = id or longword(Read_From_Port() and 0x00FF) << 16
NOP	
ANDI	R2, R2, 255
ANDI	R2, R2, 65535
SLL	R3, R2, 16
LW	R2, 8(SP)
OR	R2, R2, R3
SW	R2, 8(SP)
;__Lib_TFT_Defs.mbas,2102 :: 		id = id or longword(Read_From_Port() and 0x00FF) << 24
NOP	
ANDI	R2, R2, 255
ANDI	R2, R2, 65535
SLL	R3, R2, 24
LW	R2, 8(SP)
OR	R2, R2, R3
SW	R2, 8(SP)
;__Lib_TFT_Defs.mbas,2103 :: 		TFT_CS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2105 :: 		TFT_Set_DataPort_Direction()
NOP	
;__Lib_TFT_Defs.mbas,2107 :: 		Result = id
; Result start address is: 8 (R2)
LW	R2, 8(SP)
;__Lib_TFT_Defs.mbas,2108 :: 		end sub
; Result end address is: 8 (R2)
L_end_TFT_ReadId_ST7789V_or_ILI9341:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 12
JR	RA
NOP	
; end of __Lib_TFT_Defs_TFT_ReadId_ST7789V_or_ILI9341
__Lib_TFT_Defs_TFT_Reset_ILI9341:
;__Lib_TFT_Defs.mbas,2118 :: 		sub procedure TFT_Reset_ILI9341()
ADDIU	SP, SP, -8
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,2120 :: 		TFT_RST = 0
SW	R25, 4(SP)
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2122 :: 		TFT_RST_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2125 :: 		TFT_RS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2127 :: 		TFT_RS_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2130 :: 		TFT_CS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2132 :: 		TFT_CS_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2134 :: 		TFT_RD_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2135 :: 		TFT_WR_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2136 :: 		TFT_RD = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2137 :: 		TFT_WR = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2139 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,2140 :: 		TFT_RST = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2141 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,2142 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,2144 :: 		TFT_CS = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2145 :: 		TFT_Set_Index_Ptr(0x01)   ' software reset
ORI	R25, R0, 1
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2146 :: 		Delay_5ms()
JAL	_Delay_5ms+0
NOP	
;__Lib_TFT_Defs.mbas,2147 :: 		TFT_Set_Index_Ptr(0x28)   ' display off
ORI	R25, R0, 40
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2149 :: 		TFT_Set_Index_Ptr(0xcf)
ORI	R25, R0, 207
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2150 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
LW	R30, Offset(_TFT_Write_Command_Ptr+0)(GP)
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2151 :: 		TFT_Write_Command_Ptr(0x83)
ORI	R25, R0, 131
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2152 :: 		TFT_Write_Command_Ptr(0x30)
ORI	R25, R0, 48
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2154 :: 		TFT_Set_Index_Ptr(0xed)
ORI	R25, R0, 237
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2155 :: 		TFT_Write_Command_Ptr(0x64)
ORI	R25, R0, 100
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2156 :: 		TFT_Write_Command_Ptr(0x03)
ORI	R25, R0, 3
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2157 :: 		TFT_Write_Command_Ptr(0x12)
ORI	R25, R0, 18
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2158 :: 		TFT_Write_Command_Ptr(0x81)
ORI	R25, R0, 129
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2160 :: 		TFT_Set_Index_Ptr(0xe8)
ORI	R25, R0, 232
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2161 :: 		TFT_Write_Command_Ptr(0x85)
ORI	R25, R0, 133
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2162 :: 		TFT_Write_Command_Ptr(0x01)
ORI	R25, R0, 1
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2163 :: 		TFT_Write_Command_Ptr(0x79)
ORI	R25, R0, 121
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2165 :: 		TFT_Set_Index_Ptr(0xcb)
ORI	R25, R0, 203
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2166 :: 		TFT_Write_Command_Ptr(0x39)
ORI	R25, R0, 57
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2167 :: 		TFT_Write_Command_Ptr(0x2c)
ORI	R25, R0, 44
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2168 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2169 :: 		TFT_Write_Command_Ptr(0x34)
ORI	R25, R0, 52
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2170 :: 		TFT_Write_Command_Ptr(0x02)
ORI	R25, R0, 2
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2172 :: 		TFT_Set_Index_Ptr(0xf7)
ORI	R25, R0, 247
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2173 :: 		TFT_Write_Command_Ptr(0x20)
ORI	R25, R0, 32
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2175 :: 		TFT_Set_Index_Ptr(0xea)
ORI	R25, R0, 234
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2176 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2177 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2179 :: 		TFT_Set_Index_Ptr(0xc0)     ' power control
ORI	R25, R0, 192
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2180 :: 		TFT_Write_Command_Ptr(0x26)
ORI	R25, R0, 38
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2182 :: 		TFT_Set_Index_Ptr(0xc1)     ' power control
ORI	R25, R0, 193
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2183 :: 		TFT_Write_Command_Ptr(0x11)
ORI	R25, R0, 17
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2185 :: 		TFT_Set_Index_Ptr(0xc5)     ' vcom control
ORI	R25, R0, 197
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2186 :: 		TFT_Write_Command_Ptr(0x35)
ORI	R25, R0, 53
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2187 :: 		TFT_Write_Command_Ptr(0x3e)
ORI	R25, R0, 62
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2189 :: 		TFT_Set_Index_Ptr(0xc7)     ' vcom control
ORI	R25, R0, 199
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2190 :: 		TFT_Write_Command_Ptr(0xbe)
ORI	R25, R0, 190
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2192 :: 		TFT_Set_Index_Ptr(0x36)     ' memory access control
ORI	R25, R0, 54
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2193 :: 		if (TFT_DISP_ROTATION = 90) then
ORI	R2, R0, 90
BEQ	R3, R2, L___Lib_TFT_Defs_TFT_Reset_ILI9341585
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_ILI9341233
NOP	
L___Lib_TFT_Defs_TFT_Reset_ILI9341585:
;__Lib_TFT_Defs.mbas,2194 :: 		if (Is_TFT_Rotated_180() = 1) then
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BEQ	R3, R2, L___Lib_TFT_Defs_TFT_Reset_ILI9341586
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_ILI9341236
NOP	
L___Lib_TFT_Defs_TFT_Reset_ILI9341586:
;__Lib_TFT_Defs.mbas,2195 :: 		TFT_Write_Command_Ptr (0x88)
ORI	R25, R0, 136
JALR	RA, R30
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_ILI9341237
NOP	
;__Lib_TFT_Defs.mbas,2196 :: 		else
L___Lib_TFT_Defs_TFT_Reset_ILI9341236:
;__Lib_TFT_Defs.mbas,2197 :: 		TFT_Write_Command_Ptr (0x48)
ORI	R25, R0, 72
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2198 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_ILI9341237:
J	L___Lib_TFT_Defs_TFT_Reset_ILI9341234
NOP	
;__Lib_TFT_Defs.mbas,2199 :: 		else
L___Lib_TFT_Defs_TFT_Reset_ILI9341233:
;__Lib_TFT_Defs.mbas,2200 :: 		if (Is_TFT_Rotated_180() = 1) then
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BEQ	R3, R2, L___Lib_TFT_Defs_TFT_Reset_ILI9341587
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_ILI9341239
NOP	
L___Lib_TFT_Defs_TFT_Reset_ILI9341587:
;__Lib_TFT_Defs.mbas,2201 :: 		TFT_Write_Command_Ptr (0xE8)
ORI	R25, R0, 232
JALR	RA, R30
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_ILI9341240
NOP	
;__Lib_TFT_Defs.mbas,2202 :: 		else
L___Lib_TFT_Defs_TFT_Reset_ILI9341239:
;__Lib_TFT_Defs.mbas,2203 :: 		TFT_Write_Command_Ptr (0x28)
ORI	R25, R0, 40
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2204 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_ILI9341240:
;__Lib_TFT_Defs.mbas,2205 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_ILI9341234:
;__Lib_TFT_Defs.mbas,2207 :: 		TFT_Set_Index_Ptr(0x3A)     ' pixel format set
ORI	R25, R0, 58
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2208 :: 		TFT_Write_Command_Ptr(0x55) ' 16bit/pixel
ORI	R25, R0, 85
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2210 :: 		TFT_Set_Index_Ptr(0xB1)     ' frame rate
ORI	R25, R0, 177
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2211 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2212 :: 		TFT_Write_Command_Ptr(0x1B) ' 70
ORI	R25, R0, 27
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2215 :: 		TFT_Set_Index_Ptr(0xf2)     ' 3Gamma Function Disable
ORI	R25, R0, 242
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2216 :: 		TFT_Write_Command_Ptr(0x08)
ORI	R25, R0, 8
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2218 :: 		TFT_Set_Index_Ptr(0x26)
ORI	R25, R0, 38
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2219 :: 		TFT_Write_Command_Ptr(0x01) ' gamma set 4 gamma curve 01/02/04/08
ORI	R25, R0, 1
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2221 :: 		TFT_Set_Index_Ptr(0xE0)     ' positive gamma correction
ORI	R25, R0, 224
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2222 :: 		TFT_Write_Command_Ptr(0x1f)
ORI	R25, R0, 31
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2223 :: 		TFT_Write_Command_Ptr(0x1a)
ORI	R25, R0, 26
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2224 :: 		TFT_Write_Command_Ptr(0x18)
ORI	R25, R0, 24
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2225 :: 		TFT_Write_Command_Ptr(0x0a)
ORI	R25, R0, 10
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2226 :: 		TFT_Write_Command_Ptr(0x0f)
ORI	R25, R0, 15
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2227 :: 		TFT_Write_Command_Ptr(0x06)
ORI	R25, R0, 6
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2228 :: 		TFT_Write_Command_Ptr(0x45)
ORI	R25, R0, 69
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2229 :: 		TFT_Write_Command_Ptr(0x87)
ORI	R25, R0, 135
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2230 :: 		TFT_Write_Command_Ptr(0x32)
ORI	R25, R0, 50
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2231 :: 		TFT_Write_Command_Ptr(0x0a)
ORI	R25, R0, 10
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2232 :: 		TFT_Write_Command_Ptr(0x07)
ORI	R25, R0, 7
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2233 :: 		TFT_Write_Command_Ptr(0x02)
ORI	R25, R0, 2
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2234 :: 		TFT_Write_Command_Ptr(0x07)
ORI	R25, R0, 7
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2235 :: 		TFT_Write_Command_Ptr(0x05)
ORI	R25, R0, 5
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2236 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2238 :: 		TFT_Set_Index_Ptr(0xE1)     ' negamma correction
ORI	R25, R0, 225
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2239 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2240 :: 		TFT_Write_Command_Ptr(0x25)
ORI	R25, R0, 37
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2241 :: 		TFT_Write_Command_Ptr(0x27)
ORI	R25, R0, 39
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2242 :: 		TFT_Write_Command_Ptr(0x05)
ORI	R25, R0, 5
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2243 :: 		TFT_Write_Command_Ptr(0x10)
ORI	R25, R0, 16
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2244 :: 		TFT_Write_Command_Ptr(0x09)
ORI	R25, R0, 9
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2245 :: 		TFT_Write_Command_Ptr(0x3a)
ORI	R25, R0, 58
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2246 :: 		TFT_Write_Command_Ptr(0x78)
ORI	R25, R0, 120
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2247 :: 		TFT_Write_Command_Ptr(0x4d)
ORI	R25, R0, 77
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2248 :: 		TFT_Write_Command_Ptr(0x05)
ORI	R25, R0, 5
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2249 :: 		TFT_Write_Command_Ptr(0x18)
ORI	R25, R0, 24
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2250 :: 		TFT_Write_Command_Ptr(0x0d)
ORI	R25, R0, 13
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2251 :: 		TFT_Write_Command_Ptr(0x38)
ORI	R25, R0, 56
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2252 :: 		TFT_Write_Command_Ptr(0x3a)
ORI	R25, R0, 58
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2253 :: 		TFT_Write_Command_Ptr(0x1f)
ORI	R25, R0, 31
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2257 :: 		TFT_Set_Index_Ptr(0x2A)
ORI	R25, R0, 42
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2258 :: 		TFT_Write_Command_Ptr(0)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2259 :: 		TFT_Write_Command_Ptr(0)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2260 :: 		TFT_Write_Command_Ptr((TFT_DISP_WIDTH - 1) >> 8)
ADDIU	R2, R2, -1
ANDI	R2, R2, 65535
SRL	R2, R2, 8
ANDI	R25, R2, 65535
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2261 :: 		TFT_Write_Command_Ptr(TFT_DISP_WIDTH-1)
ADDIU	R2, R2, -1
ANDI	R25, R2, 255
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2263 :: 		TFT_Set_Index_Ptr(0x2B)
ORI	R25, R0, 43
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2264 :: 		TFT_Write_Command_Ptr(0)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2265 :: 		TFT_Write_Command_Ptr(0)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2266 :: 		TFT_Write_Command_Ptr((TFT_DISP_HEIGHT - 1) >> 8)
ADDIU	R2, R2, -1
ANDI	R2, R2, 65535
SRL	R2, R2, 8
ANDI	R25, R2, 65535
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2267 :: 		TFT_Write_Command_Ptr(TFT_DISP_HEIGHT-1)
ADDIU	R2, R2, -1
ANDI	R25, R2, 255
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2269 :: 		TFT_Set_Index_Ptr(0xb7)     ' entry mode set
ORI	R25, R0, 183
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2270 :: 		TFT_Write_Command_Ptr(0x07)
ORI	R25, R0, 7
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2272 :: 		TFT_Set_Index_Ptr(0xb6)     ' display function control
ORI	R25, R0, 182
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2273 :: 		TFT_Write_Command_Ptr(0x0a)
ORI	R25, R0, 10
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2274 :: 		TFT_Write_Command_Ptr(0x82)
ORI	R25, R0, 130
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2275 :: 		TFT_Write_Command_Ptr(0x27)
ORI	R25, R0, 39
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2276 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2278 :: 		TFT_Set_Index_Ptr(0x11)     ' sleep out
ORI	R25, R0, 17
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2279 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,2280 :: 		TFT_Set_Index_Ptr(0x29)     ' display on
ORI	R25, R0, 41
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2281 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,2282 :: 		TFT_Set_Index_Ptr(0x2c)     ' memory write
ORI	R25, R0, 44
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2283 :: 		TFT_CS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2284 :: 		end sub
L_end_TFT_Reset_ILI9341:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 8
JR	RA
NOP	
; end of __Lib_TFT_Defs_TFT_Reset_ILI9341
_TFT_Init_ILI9341_16bit:
;__Lib_TFT_Defs.mbas,2291 :: 		sub procedure TFT_Init_ILI9341_16bit(dim display_width as word display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,2292 :: 		__controller = _16BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 65535
;__Lib_TFT_Defs.mbas,2293 :: 		if(Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init_ILI9341_16bit590
NOP	
J	L__TFT_Init_ILI9341_16bit243
NOP	
L__TFT_Init_ILI9341_16bit590:
;__Lib_TFT_Defs.mbas,2294 :: 		TFT_Set_Index_Ptr = @TFT_Set_Index
;__Lib_TFT_Defs.mbas,2295 :: 		TFT_Write_Command_Ptr = @TFT_Write_Command
;__Lib_TFT_Defs.mbas,2296 :: 		TFT_Write_Data_Ptr = @TFT_16bit_Write_Data
L__TFT_Init_ILI9341_16bit243:
;__Lib_TFT_Defs.mbas,2299 :: 		TFT_DISP_WIDTH = display_width
;__Lib_TFT_Defs.mbas,2300 :: 		TFT_DISP_HEIGHT = display_height
;__Lib_TFT_Defs.mbas,2301 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init_ILI9341_16bit591
NOP	
J	L__TFT_Init_ILI9341_16bit246
NOP	
L__TFT_Init_ILI9341_16bit591:
;__Lib_TFT_Defs.mbas,2302 :: 		TFT_Disp_Rotation = 0
J	L__TFT_Init_ILI9341_16bit247
NOP	
;__Lib_TFT_Defs.mbas,2303 :: 		else
L__TFT_Init_ILI9341_16bit246:
;__Lib_TFT_Defs.mbas,2304 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
;__Lib_TFT_Defs.mbas,2305 :: 		end if
L__TFT_Init_ILI9341_16bit247:
;__Lib_TFT_Defs.mbas,2307 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,2308 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,2310 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,2311 :: 		TFT_Clear_Fonts()
NOP	
;__Lib_TFT_Defs.mbas,2312 :: 		TFT_Set_DataPort_Direction()
NOP	
;__Lib_TFT_Defs.mbas,2314 :: 		if (TFT_ReadId_ST7789V_or_ILI9341() = TFT_ST7789_HW_ID) then
JAL	__Lib_TFT_Defs_TFT_ReadId_ST7789V_or_ILI9341+0
NOP	
LUI	R3, 21125
ORI	R3, R3, 34048
BEQ	R2, R3, L__TFT_Init_ILI9341_16bit592
NOP	
J	L__TFT_Init_ILI9341_16bit249
NOP	
L__TFT_Init_ILI9341_16bit592:
;__Lib_TFT_Defs.mbas,2316 :: 		TFT_Reset_ST7789V()
NOP	
;__Lib_TFT_Defs.mbas,2317 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address_SST7715R
J	L__TFT_Init_ILI9341_16bit250
NOP	
;__Lib_TFT_Defs.mbas,2318 :: 		else
L__TFT_Init_ILI9341_16bit249:
;__Lib_TFT_Defs.mbas,2320 :: 		TFT_Reset_ILI9341()
JAL	__Lib_TFT_Defs_TFT_Reset_ILI9341+0
NOP	
;__Lib_TFT_Defs.mbas,2321 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address_ILI9340
;__Lib_TFT_Defs.mbas,2322 :: 		end if
L__TFT_Init_ILI9341_16bit250:
;__Lib_TFT_Defs.mbas,2328 :: 		end sub
L_end_TFT_Init_ILI9341_16bit:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
; end of _TFT_Init_ILI9341_16bit
_TFT_Init_ILI9341_16bit_Custom:
;__Lib_TFT_Defs.mbas,2338 :: 		sub procedure TFT_Init_ILI9341_16bit_Custom(dim display_width as word display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,2339 :: 		__controller = _16BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 65535
;__Lib_TFT_Defs.mbas,2340 :: 		if(Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init_ILI9341_16bit_Custom595
NOP	
J	L__TFT_Init_ILI9341_16bit_Custom253
NOP	
L__TFT_Init_ILI9341_16bit_Custom595:
;__Lib_TFT_Defs.mbas,2341 :: 		TFT_Set_Index_Ptr = @TFT_Set_Index
;__Lib_TFT_Defs.mbas,2342 :: 		TFT_Write_Command_Ptr = @TFT_Write_Command
;__Lib_TFT_Defs.mbas,2343 :: 		TFT_Write_Data_Ptr = @TFT_16bit_Write_Data
LUI	R2, hi_addr(_TFT_16bit_Write_Data+0)
ORI	R2, R2, lo_addr(_TFT_16bit_Write_Data+0)
L__TFT_Init_ILI9341_16bit_Custom253:
;__Lib_TFT_Defs.mbas,2346 :: 		TFT_DISP_WIDTH = display_width
;__Lib_TFT_Defs.mbas,2347 :: 		TFT_DISP_HEIGHT = display_height
;__Lib_TFT_Defs.mbas,2348 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init_ILI9341_16bit_Custom596
NOP	
J	L__TFT_Init_ILI9341_16bit_Custom256
NOP	
L__TFT_Init_ILI9341_16bit_Custom596:
;__Lib_TFT_Defs.mbas,2349 :: 		TFT_Disp_Rotation = 0
J	L__TFT_Init_ILI9341_16bit_Custom257
NOP	
;__Lib_TFT_Defs.mbas,2350 :: 		else
L__TFT_Init_ILI9341_16bit_Custom256:
;__Lib_TFT_Defs.mbas,2351 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
;__Lib_TFT_Defs.mbas,2352 :: 		end if
L__TFT_Init_ILI9341_16bit_Custom257:
;__Lib_TFT_Defs.mbas,2354 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,2355 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,2357 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,2358 :: 		TFT_Clear_Fonts()
NOP	
;__Lib_TFT_Defs.mbas,2360 :: 		if (TFT_ReadId_ST7789V_or_ILI9341() = TFT_ST7789_HW_ID) then
NOP	
LUI	R3, 21125
ORI	R3, R3, 34048
BEQ	R2, R3, L__TFT_Init_ILI9341_16bit_Custom597
NOP	
J	L__TFT_Init_ILI9341_16bit_Custom259
NOP	
L__TFT_Init_ILI9341_16bit_Custom597:
;__Lib_TFT_Defs.mbas,2362 :: 		TFT_Reset_ST7789V()
NOP	
;__Lib_TFT_Defs.mbas,2363 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address_SST7715R
J	L__TFT_Init_ILI9341_16bit_Custom260
NOP	
;__Lib_TFT_Defs.mbas,2364 :: 		else
L__TFT_Init_ILI9341_16bit_Custom259:
;__Lib_TFT_Defs.mbas,2366 :: 		TFT_Reset_ILI9341()
NOP	
;__Lib_TFT_Defs.mbas,2367 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address_ILI9340
;__Lib_TFT_Defs.mbas,2368 :: 		end if
L__TFT_Init_ILI9341_16bit_Custom260:
;__Lib_TFT_Defs.mbas,2374 :: 		end sub
L_end_TFT_Init_ILI9341_16bit_Custom:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
; end of _TFT_Init_ILI9341_16bit_Custom
_TFT_Init_ILI9341_8bit:
;__Lib_TFT_Defs.mbas,2383 :: 		sub procedure TFT_Init_ILI9341_8bit(dim display_width as word display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,2384 :: 		__controller = _8BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 255
;__Lib_TFT_Defs.mbas,2385 :: 		if (Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init_ILI9341_8bit600
NOP	
J	L__TFT_Init_ILI9341_8bit263
NOP	
L__TFT_Init_ILI9341_8bit600:
;__Lib_TFT_Defs.mbas,2386 :: 		TFT_Set_Index_Ptr = @TFT_Set_Index
;__Lib_TFT_Defs.mbas,2387 :: 		TFT_Write_Command_Ptr = @TFT_Write_Command
;__Lib_TFT_Defs.mbas,2388 :: 		TFT_Write_Data_Ptr = @TFT_Write_Data
L__TFT_Init_ILI9341_8bit263:
;__Lib_TFT_Defs.mbas,2391 :: 		TFT_DISP_WIDTH = display_width
;__Lib_TFT_Defs.mbas,2392 :: 		TFT_DISP_HEIGHT = display_height
;__Lib_TFT_Defs.mbas,2393 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init_ILI9341_8bit601
NOP	
J	L__TFT_Init_ILI9341_8bit266
NOP	
L__TFT_Init_ILI9341_8bit601:
;__Lib_TFT_Defs.mbas,2394 :: 		TFT_Disp_Rotation = 0
J	L__TFT_Init_ILI9341_8bit267
NOP	
;__Lib_TFT_Defs.mbas,2395 :: 		else
L__TFT_Init_ILI9341_8bit266:
;__Lib_TFT_Defs.mbas,2396 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
;__Lib_TFT_Defs.mbas,2397 :: 		end if
L__TFT_Init_ILI9341_8bit267:
;__Lib_TFT_Defs.mbas,2399 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,2400 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,2402 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,2403 :: 		TFT_Clear_Fonts()
NOP	
;__Lib_TFT_Defs.mbas,2404 :: 		TFT_Set_DataPort_Direction()
JAL	__Lib_TFT_Defs_TFT_Set_DataPort_Direction+0
NOP	
;__Lib_TFT_Defs.mbas,2406 :: 		if (TFT_ReadId_ST7789V_or_ILI9341() = TFT_ST7789_HW_ID) then
NOP	
LUI	R3, 21125
ORI	R3, R3, 34048
BEQ	R2, R3, L__TFT_Init_ILI9341_8bit602
NOP	
J	L__TFT_Init_ILI9341_8bit269
NOP	
L__TFT_Init_ILI9341_8bit602:
;__Lib_TFT_Defs.mbas,2408 :: 		TFT_Reset_ST7789V()
NOP	
;__Lib_TFT_Defs.mbas,2409 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address_SST7715R
J	L__TFT_Init_ILI9341_8bit270
NOP	
;__Lib_TFT_Defs.mbas,2410 :: 		else
L__TFT_Init_ILI9341_8bit269:
;__Lib_TFT_Defs.mbas,2412 :: 		TFT_Reset_ILI9341()
NOP	
;__Lib_TFT_Defs.mbas,2413 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address_ILI9340
;__Lib_TFT_Defs.mbas,2414 :: 		end if
L__TFT_Init_ILI9341_8bit270:
;__Lib_TFT_Defs.mbas,2420 :: 		end sub
L_end_TFT_Init_ILI9341_8bit:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
; end of _TFT_Init_ILI9341_8bit
_TFT_Init_ILI9341_8bit_Custom:
;__Lib_TFT_Defs.mbas,2430 :: 		sub procedure TFT_Init_ILI9341_8bit_Custom(dim display_width as word display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,2431 :: 		__controller = _8BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 255
;__Lib_TFT_Defs.mbas,2432 :: 		if (Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init_ILI9341_8bit_Custom605
NOP	
J	L__TFT_Init_ILI9341_8bit_Custom273
NOP	
L__TFT_Init_ILI9341_8bit_Custom605:
;__Lib_TFT_Defs.mbas,2433 :: 		TFT_Set_Index_Ptr = @TFT_Set_Index
;__Lib_TFT_Defs.mbas,2434 :: 		TFT_Write_Command_Ptr = @TFT_Write_Command
;__Lib_TFT_Defs.mbas,2435 :: 		TFT_Write_Data_Ptr = @TFT_Write_Data
L__TFT_Init_ILI9341_8bit_Custom273:
;__Lib_TFT_Defs.mbas,2438 :: 		TFT_DISP_WIDTH = display_width
;__Lib_TFT_Defs.mbas,2439 :: 		TFT_DISP_HEIGHT = display_height
;__Lib_TFT_Defs.mbas,2440 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init_ILI9341_8bit_Custom606
NOP	
J	L__TFT_Init_ILI9341_8bit_Custom276
NOP	
L__TFT_Init_ILI9341_8bit_Custom606:
;__Lib_TFT_Defs.mbas,2441 :: 		TFT_Disp_Rotation = 0
J	L__TFT_Init_ILI9341_8bit_Custom277
NOP	
;__Lib_TFT_Defs.mbas,2442 :: 		else
L__TFT_Init_ILI9341_8bit_Custom276:
;__Lib_TFT_Defs.mbas,2443 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
;__Lib_TFT_Defs.mbas,2444 :: 		end if
L__TFT_Init_ILI9341_8bit_Custom277:
;__Lib_TFT_Defs.mbas,2446 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,2447 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,2449 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,2450 :: 		TFT_Clear_Fonts()
NOP	
;__Lib_TFT_Defs.mbas,2452 :: 		if (TFT_ReadId_ST7789V_or_ILI9341() = TFT_ST7789_HW_ID) then
NOP	
LUI	R3, 21125
ORI	R3, R3, 34048
BEQ	R2, R3, L__TFT_Init_ILI9341_8bit_Custom607
NOP	
J	L__TFT_Init_ILI9341_8bit_Custom279
NOP	
L__TFT_Init_ILI9341_8bit_Custom607:
;__Lib_TFT_Defs.mbas,2454 :: 		TFT_Reset_ST7789V()
NOP	
;__Lib_TFT_Defs.mbas,2455 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address_SST7715R
J	L__TFT_Init_ILI9341_8bit_Custom280
NOP	
;__Lib_TFT_Defs.mbas,2456 :: 		else
L__TFT_Init_ILI9341_8bit_Custom279:
;__Lib_TFT_Defs.mbas,2458 :: 		TFT_Reset_ILI9341()
NOP	
;__Lib_TFT_Defs.mbas,2459 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address_ILI9340
;__Lib_TFT_Defs.mbas,2460 :: 		end if
L__TFT_Init_ILI9341_8bit_Custom280:
;__Lib_TFT_Defs.mbas,2466 :: 		end sub
L_end_TFT_Init_ILI9341_8bit_Custom:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
; end of _TFT_Init_ILI9341_8bit_Custom
_TFT_Set_Address_ILI9342:
;__Lib_TFT_Defs.mbas,2476 :: 		sub procedure TFT_Set_Address_ILI9342(dim x as word y as word)
ADDIU	SP, SP, -12
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,2477 :: 		TFT_Set_Index_Ptr(0x2A)
SW	R25, 4(SP)
SH	R26, 8(SP)
SH	R25, 10(SP)
ORI	R25, R0, 42
JALR	RA, R30
NOP	
LHU	R25, 10(SP)
;__Lib_TFT_Defs.mbas,2478 :: 		TFT_Write_Command_Ptr(x >> 8)
ANDI	R2, R25, 65535
SRL	R2, R2, 8
SH	R25, 10(SP)
ANDI	R25, R2, 65535
JALR	RA, R30
NOP	
LHU	R25, 10(SP)
;__Lib_TFT_Defs.mbas,2479 :: 		TFT_Write_Command_Ptr(x)
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2480 :: 		TFT_Set_Index_Ptr(0x2B)
ORI	R25, R0, 43
JALR	RA, R30
NOP	
LHU	R26, 8(SP)
;__Lib_TFT_Defs.mbas,2481 :: 		TFT_Write_Command_Ptr(y >> 8)
ANDI	R2, R26, 65535
SRL	R2, R2, 8
SH	R26, 8(SP)
ANDI	R25, R2, 65535
JALR	RA, R30
NOP	
LHU	R26, 8(SP)
;__Lib_TFT_Defs.mbas,2482 :: 		TFT_Write_Command_Ptr(y)
ANDI	R25, R26, 65535
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2483 :: 		TFT_Set_Index_Ptr(0x2C)
ORI	R25, R0, 44
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2484 :: 		end sub
L_end_TFT_Set_Address_ILI9342:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 12
JR	RA
NOP	
; end of _TFT_Set_Address_ILI9342
__Lib_TFT_Defs_TFT_Reset_ILI9342:
;__Lib_TFT_Defs.mbas,2490 :: 		sub procedure TFT_Reset_ILI9342()
ADDIU	SP, SP, -8
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,2492 :: 		TFT_RST = 0
SW	R25, 4(SP)
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2494 :: 		TFT_RST_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2497 :: 		TFT_RS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2499 :: 		TFT_RS_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2502 :: 		TFT_CS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2504 :: 		TFT_CS_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2506 :: 		TFT_RD_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2507 :: 		TFT_WR_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2508 :: 		TFT_RD = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2509 :: 		TFT_WR = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2511 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,2512 :: 		TFT_RST = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2513 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,2514 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,2516 :: 		TFT_CS = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2517 :: 		TFT_Set_Index_Ptr(0xB9)      ' Set EXTC
ORI	R25, R0, 185
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2518 :: 		TFT_Write_Command_Ptr(0xFF)
ORI	R25, R0, 255
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2519 :: 		TFT_Write_Command_Ptr(0x93)
ORI	R25, R0, 147
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2520 :: 		TFT_Write_Command_Ptr(0x42)
ORI	R25, R0, 66
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2522 :: 		TFT_Set_Index_Ptr(0x36)     ' memory access control
ORI	R25, R0, 54
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2523 :: 		if (TFT_Disp_Rotation = 90) then
ORI	R2, R0, 90
BEQ	R3, R2, L___Lib_TFT_Defs_TFT_Reset_ILI9342610
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_ILI9342284
NOP	
L___Lib_TFT_Defs_TFT_Reset_ILI9342610:
;__Lib_TFT_Defs.mbas,2524 :: 		if (Is_TFT_Rotated_180() = 1) then
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BEQ	R3, R2, L___Lib_TFT_Defs_TFT_Reset_ILI9342611
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_ILI9342287
NOP	
L___Lib_TFT_Defs_TFT_Reset_ILI9342611:
;__Lib_TFT_Defs.mbas,2525 :: 		TFT_Write_Command_Ptr (0x60)
ORI	R25, R0, 96
JALR	RA, R30
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_ILI9342288
NOP	
;__Lib_TFT_Defs.mbas,2526 :: 		else
L___Lib_TFT_Defs_TFT_Reset_ILI9342287:
;__Lib_TFT_Defs.mbas,2527 :: 		TFT_Write_Command_Ptr (0xA0)
ORI	R25, R0, 160
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2528 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_ILI9342288:
J	L___Lib_TFT_Defs_TFT_Reset_ILI9342285
NOP	
;__Lib_TFT_Defs.mbas,2529 :: 		else
L___Lib_TFT_Defs_TFT_Reset_ILI9342284:
;__Lib_TFT_Defs.mbas,2530 :: 		if (Is_TFT_Rotated_180() = 1) then
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BEQ	R3, R2, L___Lib_TFT_Defs_TFT_Reset_ILI9342612
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_ILI9342290
NOP	
L___Lib_TFT_Defs_TFT_Reset_ILI9342612:
;__Lib_TFT_Defs.mbas,2531 :: 		TFT_Write_Command_Ptr (0xC0)
ORI	R25, R0, 192
JALR	RA, R30
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_ILI9342291
NOP	
;__Lib_TFT_Defs.mbas,2532 :: 		else
L___Lib_TFT_Defs_TFT_Reset_ILI9342290:
;__Lib_TFT_Defs.mbas,2533 :: 		TFT_Write_Command_Ptr (0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2534 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_ILI9342291:
;__Lib_TFT_Defs.mbas,2535 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_ILI9342285:
;__Lib_TFT_Defs.mbas,2538 :: 		TFT_Set_Index_Ptr(0x2A)
ORI	R25, R0, 42
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2539 :: 		TFT_Write_Command_Ptr(0)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2540 :: 		TFT_Write_Command_Ptr(0)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2541 :: 		TFT_Write_Command_Ptr(Hi(TFT_DISP_WIDTH))
LBU	R25, Offset(_TFT_DISP_WIDTH+1)(GP)
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2542 :: 		TFT_Write_Command_Ptr(TFT_DISP_WIDTH)
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2544 :: 		TFT_Set_Index_Ptr(0x2B)
ORI	R25, R0, 43
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2545 :: 		TFT_Write_Command_Ptr(0)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2546 :: 		TFT_Write_Command_Ptr(0)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2547 :: 		TFT_Write_Command_Ptr(Hi(TFT_DISP_HEIGHT))
LBU	R25, Offset(_TFT_DISP_HEIGHT+1)(GP)
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2548 :: 		TFT_Write_Command_Ptr(TFT_DISP_HEIGHT)
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2550 :: 		TFT_Set_Index_Ptr(0x3A)     ' pixel format set
ORI	R25, R0, 58
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2551 :: 		TFT_Write_Command_Ptr (0x55)
ORI	R25, R0, 85
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2553 :: 		TFT_Set_Index_Ptr(0xB1)     ' Display Waveform Cycle 1
ORI	R25, R0, 177
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2554 :: 		TFT_Write_Command_Ptr (0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2555 :: 		TFT_Write_Command_Ptr (0x10)
ORI	R25, R0, 16
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2557 :: 		TFT_Set_Index_Ptr(0xB6)     ' Display Function Control
ORI	R25, R0, 182
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2558 :: 		TFT_Write_Command_Ptr (0x0A)
ORI	R25, R0, 10
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2559 :: 		TFT_Write_Command_Ptr (0xE2)
ORI	R25, R0, 226
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2560 :: 		TFT_Write_Command_Ptr (0x1D)
ORI	R25, R0, 29
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2562 :: 		TFT_Set_Index_Ptr(0xC0)     ' Power Control 1
ORI	R25, R0, 192
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2563 :: 		TFT_Write_Command_Ptr (0x35)
ORI	R25, R0, 53
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2564 :: 		TFT_Write_Command_Ptr (0x0e)
ORI	R25, R0, 14
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2566 :: 		TFT_Set_Index_Ptr(0xC1)     ' Power Control 2
ORI	R25, R0, 193
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2567 :: 		TFT_Write_Command_Ptr (0x02)
ORI	R25, R0, 2
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2569 :: 		TFT_Set_Index_Ptr(0xC5)     ' VCOM Control 1
ORI	R25, R0, 197
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2570 :: 		TFT_Write_Command_Ptr (0x31)
ORI	R25, R0, 49
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2571 :: 		TFT_Write_Command_Ptr (0x3C)
ORI	R25, R0, 60
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2573 :: 		TFT_Set_Index_Ptr(0xB8)    ' Oscillator Control
ORI	R25, R0, 184
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2574 :: 		TFT_Write_Command_Ptr (0x0A)
ORI	R25, R0, 10
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2576 :: 		TFT_Set_Index_Ptr(0x26)    ' Gamma Set
ORI	R25, R0, 38
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2577 :: 		TFT_Write_Command_Ptr (0x01)
ORI	R25, R0, 1
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2579 :: 		TFT_Set_Index_Ptr(0xC7)    ' VCOM Control 2
ORI	R25, R0, 199
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2580 :: 		TFT_Write_Command_Ptr (0xBF)
ORI	R25, R0, 191
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2582 :: 		TFT_Set_Index_Ptr(0xE0)   ' Positive Gamma Correction
ORI	R25, R0, 224
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2583 :: 		TFT_Write_Command_Ptr (0x08)
ORI	R25, R0, 8
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2584 :: 		TFT_Write_Command_Ptr (0x1C)
ORI	R25, R0, 28
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2585 :: 		TFT_Write_Command_Ptr (0x1B)
ORI	R25, R0, 27
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2586 :: 		TFT_Write_Command_Ptr (0x09)
ORI	R25, R0, 9
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2587 :: 		TFT_Write_Command_Ptr (0x0D)
ORI	R25, R0, 13
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2588 :: 		TFT_Write_Command_Ptr (0x08)
ORI	R25, R0, 8
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2589 :: 		TFT_Write_Command_Ptr (0x4B)
ORI	R25, R0, 75
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2590 :: 		TFT_Write_Command_Ptr (0xB8)
ORI	R25, R0, 184
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2591 :: 		TFT_Write_Command_Ptr (0x3B)
ORI	R25, R0, 59
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2592 :: 		TFT_Write_Command_Ptr (0x08)
ORI	R25, R0, 8
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2593 :: 		TFT_Write_Command_Ptr (0x10)
ORI	R25, R0, 16
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2594 :: 		TFT_Write_Command_Ptr (0x08)
ORI	R25, R0, 8
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2595 :: 		TFT_Write_Command_Ptr (0x20)
ORI	R25, R0, 32
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2596 :: 		TFT_Write_Command_Ptr (0x20)
ORI	R25, R0, 32
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2597 :: 		TFT_Write_Command_Ptr (0x08)
ORI	R25, R0, 8
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2599 :: 		TFT_Set_Index_Ptr(0xE1)  ' Negative Gamma Correction
ORI	R25, R0, 225
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2600 :: 		TFT_Write_Command_Ptr (0x07)
ORI	R25, R0, 7
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2601 :: 		TFT_Write_Command_Ptr (0x23)
ORI	R25, R0, 35
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2602 :: 		TFT_Write_Command_Ptr (0x24)
ORI	R25, R0, 36
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2603 :: 		TFT_Write_Command_Ptr (0x06)
ORI	R25, R0, 6
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2604 :: 		TFT_Write_Command_Ptr (0x12)
ORI	R25, R0, 18
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2605 :: 		TFT_Write_Command_Ptr (0x07)
ORI	R25, R0, 7
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2606 :: 		TFT_Write_Command_Ptr (0x34)
ORI	R25, R0, 52
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2607 :: 		TFT_Write_Command_Ptr (0x47)
ORI	R25, R0, 71
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2608 :: 		TFT_Write_Command_Ptr (0x44)
ORI	R25, R0, 68
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2609 :: 		TFT_Write_Command_Ptr (0x07)
ORI	R25, R0, 7
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2610 :: 		TFT_Write_Command_Ptr (0x0F)
ORI	R25, R0, 15
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2611 :: 		TFT_Write_Command_Ptr (0x07)
ORI	R25, R0, 7
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2612 :: 		TFT_Write_Command_Ptr (0x1F)
ORI	R25, R0, 31
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2613 :: 		TFT_Write_Command_Ptr (0x1F)
ORI	R25, R0, 31
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2614 :: 		TFT_Write_Command_Ptr (0x07)
ORI	R25, R0, 7
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2616 :: 		TFT_Set_Index_Ptr(0x13) ' Set Normal Mode
ORI	R25, R0, 19
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2618 :: 		TFT_Set_Index_Ptr(0x11) 'Exit Sleep
ORI	R25, R0, 17
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2619 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,2620 :: 		TFT_Set_Index_Ptr(0x11) 'Exit Sleep
ORI	R25, R0, 17
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2621 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,2622 :: 		TFT_Set_Index_Ptr(0x29)
ORI	R25, R0, 41
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2623 :: 		TFT_CS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2624 :: 		end sub
L_end_TFT_Reset_ILI9342:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 8
JR	RA
NOP	
; end of __Lib_TFT_Defs_TFT_Reset_ILI9342
_TFT_Init_ILI9342:
;__Lib_TFT_Defs.mbas,2631 :: 		sub procedure TFT_Init_ILI9342(dim display_width as word display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,2632 :: 		__controller = _16BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 65535
;__Lib_TFT_Defs.mbas,2633 :: 		if (Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init_ILI9342615
NOP	
J	L__TFT_Init_ILI9342294
NOP	
L__TFT_Init_ILI9342615:
;__Lib_TFT_Defs.mbas,2634 :: 		TFT_Set_Index_Ptr = @TFT_Set_Index
;__Lib_TFT_Defs.mbas,2635 :: 		TFT_Write_Command_Ptr = @TFT_Write_Command
;__Lib_TFT_Defs.mbas,2636 :: 		TFT_Write_Data_Ptr = @TFT_16bit_Write_Data
L__TFT_Init_ILI9342294:
;__Lib_TFT_Defs.mbas,2639 :: 		TFT_DISP_WIDTH = display_width
;__Lib_TFT_Defs.mbas,2640 :: 		TFT_DISP_HEIGHT = display_height
;__Lib_TFT_Defs.mbas,2641 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init_ILI9342616
NOP	
J	L__TFT_Init_ILI9342297
NOP	
L__TFT_Init_ILI9342616:
;__Lib_TFT_Defs.mbas,2642 :: 		TFT_Disp_Rotation = 0
J	L__TFT_Init_ILI9342298
NOP	
;__Lib_TFT_Defs.mbas,2643 :: 		else
L__TFT_Init_ILI9342297:
;__Lib_TFT_Defs.mbas,2644 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
;__Lib_TFT_Defs.mbas,2645 :: 		end if
L__TFT_Init_ILI9342298:
;__Lib_TFT_Defs.mbas,2647 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,2648 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,2650 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,2651 :: 		TFT_Clear_Fonts()
NOP	
;__Lib_TFT_Defs.mbas,2652 :: 		TFT_Set_DataPort_Direction()
NOP	
;__Lib_TFT_Defs.mbas,2654 :: 		TFT_Reset_ILI9342()
JAL	__Lib_TFT_Defs_TFT_Reset_ILI9342+0
NOP	
;__Lib_TFT_Defs.mbas,2655 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address_ILI9342
LUI	R2, hi_addr(_TFT_Set_Address_ILI9342+0)
ORI	R2, R2, lo_addr(_TFT_Set_Address_ILI9342+0)
;__Lib_TFT_Defs.mbas,2656 :: 		end sub
L_end_TFT_Init_ILI9342:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
; end of _TFT_Init_ILI9342
_TFT_Init_ILI9342_Custom:
;__Lib_TFT_Defs.mbas,2666 :: 		sub procedure TFT_Init_ILI9342_Custom(dim display_width as word display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,2667 :: 		__controller = _16BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 65535
;__Lib_TFT_Defs.mbas,2668 :: 		if (Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init_ILI9342_Custom619
NOP	
J	L__TFT_Init_ILI9342_Custom301
NOP	
L__TFT_Init_ILI9342_Custom619:
;__Lib_TFT_Defs.mbas,2669 :: 		TFT_Set_Index_Ptr = @TFT_Set_Index
;__Lib_TFT_Defs.mbas,2670 :: 		TFT_Write_Command_Ptr = @TFT_Write_Command
;__Lib_TFT_Defs.mbas,2671 :: 		TFT_Write_Data_Ptr = @TFT_16bit_Write_Data
L__TFT_Init_ILI9342_Custom301:
;__Lib_TFT_Defs.mbas,2674 :: 		TFT_DISP_WIDTH = display_width
;__Lib_TFT_Defs.mbas,2675 :: 		TFT_DISP_HEIGHT = display_height
;__Lib_TFT_Defs.mbas,2676 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init_ILI9342_Custom620
NOP	
J	L__TFT_Init_ILI9342_Custom304
NOP	
L__TFT_Init_ILI9342_Custom620:
;__Lib_TFT_Defs.mbas,2677 :: 		TFT_Disp_Rotation = 0
J	L__TFT_Init_ILI9342_Custom305
NOP	
;__Lib_TFT_Defs.mbas,2678 :: 		else
L__TFT_Init_ILI9342_Custom304:
;__Lib_TFT_Defs.mbas,2679 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
;__Lib_TFT_Defs.mbas,2680 :: 		end if
L__TFT_Init_ILI9342_Custom305:
;__Lib_TFT_Defs.mbas,2682 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,2683 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,2685 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,2686 :: 		TFT_Clear_Fonts()
NOP	
;__Lib_TFT_Defs.mbas,2688 :: 		TFT_Reset_ILI9342()
NOP	
;__Lib_TFT_Defs.mbas,2689 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address_ILI9342
;__Lib_TFT_Defs.mbas,2690 :: 		end sub
L_end_TFT_Init_ILI9342_Custom:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
; end of _TFT_Init_ILI9342_Custom
_TFT_Set_Address_ILI9481:
;__Lib_TFT_Defs.mbas,2699 :: 		sub procedure TFT_Set_Address_ILI9481(dim x as word y as word)
ADDIU	SP, SP, -12
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,2700 :: 		TFT_Set_Index_Ptr(0x2A)
SW	R25, 4(SP)
SH	R26, 8(SP)
SH	R25, 10(SP)
ORI	R25, R0, 42
JALR	RA, R30
NOP	
LHU	R25, 10(SP)
;__Lib_TFT_Defs.mbas,2701 :: 		TFT_Write_Command_Ptr(x >> 8)
ANDI	R2, R25, 65535
SRL	R2, R2, 8
SH	R25, 10(SP)
ANDI	R25, R2, 65535
JALR	RA, R30
NOP	
LHU	R25, 10(SP)
;__Lib_TFT_Defs.mbas,2702 :: 		TFT_Write_Command_Ptr(x)
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2703 :: 		TFT_Set_Index_Ptr(0x2B)
ORI	R25, R0, 43
JALR	RA, R30
NOP	
LHU	R26, 8(SP)
;__Lib_TFT_Defs.mbas,2704 :: 		TFT_Write_Command_Ptr(y >> 8)
ANDI	R2, R26, 65535
SRL	R2, R2, 8
SH	R26, 8(SP)
ANDI	R25, R2, 65535
JALR	RA, R30
NOP	
LHU	R26, 8(SP)
;__Lib_TFT_Defs.mbas,2705 :: 		TFT_Write_Command_Ptr(y)
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2706 :: 		TFT_Set_Index_Ptr(0x2C)
ORI	R25, R0, 44
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2707 :: 		end sub
L_end_TFT_Set_Address_ILI9481:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 12
JR	RA
NOP	
; end of _TFT_Set_Address_ILI9481
__Lib_TFT_Defs_TFT_Reset_ILI9481:
;__Lib_TFT_Defs.mbas,2713 :: 		sub procedure TFT_Reset_ILI9481()
ADDIU	SP, SP, -8
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,2715 :: 		TFT_RST = 0
SW	R25, 4(SP)
_LX	
INS	R2, R0, BitPos(TFT_RST+0), 1
_SX	
;__Lib_TFT_Defs.mbas,2717 :: 		TFT_RST_Direction = 0
_LX	
INS	R2, R0, BitPos(TFT_RST_Direction+0), 1
_SX	
;__Lib_TFT_Defs.mbas,2720 :: 		TFT_RS = 1
_LX	
ORI	R2, R2, BitMask(TFT_RS+0)
_SX	
;__Lib_TFT_Defs.mbas,2722 :: 		TFT_RS_Direction = 0
_LX	
INS	R2, R0, BitPos(TFT_RS_Direction+0), 1
_SX	
;__Lib_TFT_Defs.mbas,2725 :: 		TFT_CS = 1
_LX	
ORI	R2, R2, BitMask(TFT_CS+0)
_SX	
;__Lib_TFT_Defs.mbas,2727 :: 		TFT_CS_Direction = 0
_LX	
INS	R2, R0, BitPos(TFT_CS_Direction+0), 1
_SX	
;__Lib_TFT_Defs.mbas,2729 :: 		TFT_RD_Direction = 0
_LX	
INS	R2, R0, BitPos(TFT_RD_Direction+0), 1
_SX	
;__Lib_TFT_Defs.mbas,2730 :: 		TFT_WR_Direction = 0
_LX	
INS	R2, R0, BitPos(TFT_WR_Direction+0), 1
_SX	
;__Lib_TFT_Defs.mbas,2731 :: 		TFT_RD = 1
_LX	
ORI	R2, R2, BitMask(TFT_RD+0)
_SX	
;__Lib_TFT_Defs.mbas,2732 :: 		TFT_WR = 1
_LX	
ORI	R2, R2, BitMask(TFT_WR+0)
_SX	
;__Lib_TFT_Defs.mbas,2734 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,2735 :: 		TFT_RST = 1
_LX	
ORI	R2, R2, BitMask(TFT_RST+0)
_SX	
;__Lib_TFT_Defs.mbas,2736 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,2737 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,2739 :: 		TFT_CS = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2741 :: 		TFT_Set_Index_Ptr(0x11)
ORI	R25, R0, 17
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2742 :: 		Delay_10ms() Delay_10ms()
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
;__Lib_TFT_Defs.mbas,2743 :: 		TFT_Set_Index_Ptr(0xD0)
ORI	R25, R0, 208
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2744 :: 		TFT_Write_Command_Ptr(0x07)
ORI	R25, R0, 7
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2745 :: 		TFT_Write_Command_Ptr(0x41)
ORI	R25, R0, 65
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2746 :: 		TFT_Write_Command_Ptr(0x1D)
ORI	R25, R0, 29
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2748 :: 		TFT_Set_Index_Ptr(0xD1)
ORI	R25, R0, 209
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2749 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2750 :: 		TFT_Write_Command_Ptr(0x2F)
ORI	R25, R0, 47
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2751 :: 		TFT_Write_Command_Ptr(0x1C)
ORI	R25, R0, 28
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2753 :: 		TFT_Set_Index_Ptr(0xD2)
ORI	R25, R0, 210
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2754 :: 		TFT_Write_Command_Ptr(0x01)
ORI	R25, R0, 1
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2755 :: 		TFT_Write_Command_Ptr(0x11)
ORI	R25, R0, 17
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2757 :: 		TFT_Set_Index_Ptr(0xC0)
ORI	R25, R0, 192
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2758 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2759 :: 		TFT_Write_Command_Ptr(0x3B)
ORI	R25, R0, 59
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2760 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2761 :: 		TFT_Write_Command_Ptr(0x02)
ORI	R25, R0, 2
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2762 :: 		TFT_Write_Command_Ptr(0x11)
ORI	R25, R0, 17
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2764 :: 		TFT_Set_Index_Ptr(0xC5)      ' Frame rate
ORI	R25, R0, 197
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2765 :: 		TFT_Write_Command_Ptr(0x03)
ORI	R25, R0, 3
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2767 :: 		TFT_Set_Index_Ptr(0xC8)      ' Gamma Setting
ORI	R25, R0, 200
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2768 :: 		TFT_Write_Command_Ptr(0x01)
ORI	R25, R0, 1
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2769 :: 		TFT_Write_Command_Ptr(0x47)
ORI	R25, R0, 71
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2770 :: 		TFT_Write_Command_Ptr(0x33)
ORI	R25, R0, 51
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2771 :: 		TFT_Write_Command_Ptr(0x23)
ORI	R25, R0, 35
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2772 :: 		TFT_Write_Command_Ptr(0x04)
ORI	R25, R0, 4
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2773 :: 		TFT_Write_Command_Ptr(0x0C)
ORI	R25, R0, 12
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2774 :: 		TFT_Write_Command_Ptr(0x44)
ORI	R25, R0, 68
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2775 :: 		TFT_Write_Command_Ptr(0x03)
ORI	R25, R0, 3
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2776 :: 		TFT_Write_Command_Ptr(0x67)
ORI	R25, R0, 103
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2777 :: 		TFT_Write_Command_Ptr(0x32)
ORI	R25, R0, 50
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2778 :: 		TFT_Write_Command_Ptr(0x0A)
ORI	R25, R0, 10
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2779 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2781 :: 		TFT_Set_Index_Ptr(0xE4)
ORI	R25, R0, 228
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2782 :: 		TFT_Write_Command_Ptr(0xA0)
ORI	R25, R0, 160
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2784 :: 		TFT_Set_Index_Ptr(0xF0)
ORI	R25, R0, 240
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2785 :: 		TFT_Write_Command_Ptr(0x08)
ORI	R25, R0, 8
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2787 :: 		TFT_Set_Index_Ptr(0xF3)
ORI	R25, R0, 243
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2788 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2789 :: 		TFT_Write_Command_Ptr(0x1A)
ORI	R25, R0, 26
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2791 :: 		TFT_Set_Index_Ptr(0xF7)
ORI	R25, R0, 247
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2792 :: 		TFT_Write_Command_Ptr(0x80)
ORI	R25, R0, 128
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2794 :: 		TFT_Set_Index_Ptr(0x13) ' Set Normal Mode
ORI	R25, R0, 19
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2796 :: 		TFT_Set_Index_Ptr(0x38) ' Exit Idle Mode
ORI	R25, R0, 56
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2798 :: 		TFT_Set_Index_Ptr(0x36)     ' memory access control
ORI	R25, R0, 54
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2799 :: 		if (TFT_Disp_Rotation = 90) then
LBU	R3, Offset(__Lib_TFT_Defs_TFT_Disp_Rotation+0)(GP)
ORI	R2, R0, 90
BEQ	R3, R2, L___Lib_TFT_Defs_TFT_Reset_ILI9481623
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_ILI9481309
NOP	
L___Lib_TFT_Defs_TFT_Reset_ILI9481623:
;__Lib_TFT_Defs.mbas,2800 :: 		if (Is_TFT_Rotated_180() = 1) then
JAL	_Is_TFT_Rotated_180+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BEQ	R3, R2, L___Lib_TFT_Defs_TFT_Reset_ILI9481624
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_ILI9481312
NOP	
L___Lib_TFT_Defs_TFT_Reset_ILI9481624:
;__Lib_TFT_Defs.mbas,2801 :: 		TFT_Write_Command_Ptr (0x09)
ORI	R25, R0, 9
JALR	RA, R30
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_ILI9481313
NOP	
;__Lib_TFT_Defs.mbas,2802 :: 		else
L___Lib_TFT_Defs_TFT_Reset_ILI9481312:
;__Lib_TFT_Defs.mbas,2803 :: 		TFT_Write_Command_Ptr (0x0A)
ORI	R25, R0, 10
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2804 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_ILI9481313:
J	L___Lib_TFT_Defs_TFT_Reset_ILI9481310
NOP	
;__Lib_TFT_Defs.mbas,2805 :: 		else
L___Lib_TFT_Defs_TFT_Reset_ILI9481309:
;__Lib_TFT_Defs.mbas,2806 :: 		if (Is_TFT_Rotated_180() = 1) then
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BEQ	R3, R2, L___Lib_TFT_Defs_TFT_Reset_ILI9481625
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_ILI9481315
NOP	
L___Lib_TFT_Defs_TFT_Reset_ILI9481625:
;__Lib_TFT_Defs.mbas,2807 :: 		TFT_Write_Command_Ptr (0x2B)
ORI	R25, R0, 43
JALR	RA, R30
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_ILI9481316
NOP	
;__Lib_TFT_Defs.mbas,2808 :: 		else
L___Lib_TFT_Defs_TFT_Reset_ILI9481315:
;__Lib_TFT_Defs.mbas,2809 :: 		TFT_Write_Command_Ptr (0x28)
ORI	R25, R0, 40
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2810 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_ILI9481316:
;__Lib_TFT_Defs.mbas,2811 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_ILI9481310:
;__Lib_TFT_Defs.mbas,2813 :: 		Delay_100ms() Delay_10ms() Delay_10ms()
JAL	_Delay_100ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
;__Lib_TFT_Defs.mbas,2815 :: 		TFT_Set_Index_Ptr(0x29)
ORI	R25, R0, 41
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2818 :: 		TFT_Set_Index_Ptr(0x2A)
ORI	R25, R0, 42
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2819 :: 		TFT_Write_Command_Ptr(0)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2820 :: 		TFT_Write_Command_Ptr(0)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2821 :: 		TFT_Write_Command_Ptr((TFT_DISP_WIDTH-1) >> 8)
LHU	R2, Offset(_TFT_DISP_WIDTH+0)(GP)
ADDIU	R2, R2, -1
ANDI	R2, R2, 65535
SRL	R2, R2, 8
ANDI	R25, R2, 65535
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2822 :: 		TFT_Write_Command_Ptr(TFT_DISP_WIDTH-1)
ADDIU	R2, R2, -1
ANDI	R25, R2, 255
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2824 :: 		TFT_Set_Index_Ptr(0x2B)
ORI	R25, R0, 43
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2825 :: 		TFT_Write_Command_Ptr(0)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2826 :: 		TFT_Write_Command_Ptr(0)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2827 :: 		TFT_Write_Command_Ptr((TFT_DISP_HEIGHT-1) >> 8)
LHU	R2, Offset(_TFT_DISP_HEIGHT+0)(GP)
ADDIU	R2, R2, -1
ANDI	R2, R2, 65535
SRL	R2, R2, 8
ANDI	R25, R2, 65535
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2828 :: 		TFT_Write_Command_Ptr(TFT_DISP_HEIGHT-1)
ADDIU	R2, R2, -1
ANDI	R25, R2, 255
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2830 :: 		TFT_Set_Index_Ptr(0x3A)  ' pixel format set
ORI	R25, R0, 58
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2831 :: 		TFT_Write_Command_Ptr (0x55)
ORI	R25, R0, 85
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2832 :: 		TFT_Set_Index_Ptr(0x11)    ' Set_address_mode
ORI	R25, R0, 17
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2833 :: 		Delay_100ms() Delay_10ms() Delay_10ms()
JAL	_Delay_100ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
;__Lib_TFT_Defs.mbas,2834 :: 		Delay_10ms() Delay_10ms() Delay_10ms()
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
JAL	_Delay_10ms+0
NOP	
;__Lib_TFT_Defs.mbas,2835 :: 		TFT_Set_Index_Ptr(0x2C)
ORI	R25, R0, 44
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,2836 :: 		TFT_CS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,2837 :: 		end sub
L_end_TFT_Reset_ILI9481:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 8
JR	RA
NOP	
; end of __Lib_TFT_Defs_TFT_Reset_ILI9481
_TFT_Init_ILI9481:
;__Lib_TFT_Defs.mbas,2844 :: 		sub procedure TFT_Init_ILI9481(dim display_width as word display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,2845 :: 		__controller = _16BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 65535
;__Lib_TFT_Defs.mbas,2846 :: 		if (Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init_ILI9481628
NOP	
J	L__TFT_Init_ILI9481319
NOP	
L__TFT_Init_ILI9481628:
;__Lib_TFT_Defs.mbas,2847 :: 		TFT_Set_Index_Ptr = @TFT_Set_Index
;__Lib_TFT_Defs.mbas,2848 :: 		TFT_Write_Command_Ptr = @TFT_Write_Command
;__Lib_TFT_Defs.mbas,2849 :: 		TFT_Write_Data_Ptr = @TFT_16bit_Write_Data
L__TFT_Init_ILI9481319:
;__Lib_TFT_Defs.mbas,2852 :: 		TFT_DISP_WIDTH = display_width
;__Lib_TFT_Defs.mbas,2853 :: 		TFT_DISP_HEIGHT = display_height
;__Lib_TFT_Defs.mbas,2854 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init_ILI9481629
NOP	
J	L__TFT_Init_ILI9481322
NOP	
L__TFT_Init_ILI9481629:
;__Lib_TFT_Defs.mbas,2855 :: 		TFT_Disp_Rotation = 0
J	L__TFT_Init_ILI9481323
NOP	
;__Lib_TFT_Defs.mbas,2856 :: 		else
L__TFT_Init_ILI9481322:
;__Lib_TFT_Defs.mbas,2857 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
;__Lib_TFT_Defs.mbas,2858 :: 		end if
L__TFT_Init_ILI9481323:
;__Lib_TFT_Defs.mbas,2860 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,2861 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,2863 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,2864 :: 		TFT_Clear_Fonts()
NOP	
;__Lib_TFT_Defs.mbas,2865 :: 		TFT_Set_DataPort_Direction()
NOP	
;__Lib_TFT_Defs.mbas,2867 :: 		TFT_Reset_ILI9481()
JAL	__Lib_TFT_Defs_TFT_Reset_ILI9481+0
NOP	
;__Lib_TFT_Defs.mbas,2868 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address_ILI9481
LUI	R2, hi_addr(_TFT_Set_Address_ILI9481+0)
ORI	R2, R2, lo_addr(_TFT_Set_Address_ILI9481+0)
;__Lib_TFT_Defs.mbas,2869 :: 		end sub
L_end_TFT_Init_ILI9481:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
; end of _TFT_Init_ILI9481
_TFT_Init_ILI9481_Custom:
;__Lib_TFT_Defs.mbas,2879 :: 		sub procedure TFT_Init_ILI9481_Custom(dim display_width as word display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,2880 :: 		__controller = _16BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 65535
SH	R2, Offset(__Lib_TFT_Defs___controller+0)(GP)
;__Lib_TFT_Defs.mbas,2881 :: 		if (Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init_ILI9481_Custom632
NOP	
J	L__TFT_Init_ILI9481_Custom326
NOP	
L__TFT_Init_ILI9481_Custom632:
;__Lib_TFT_Defs.mbas,2882 :: 		TFT_Set_Index_Ptr = @TFT_Set_Index
LUI	R2, hi_addr(_TFT_Set_Index+0)
ORI	R2, R2, lo_addr(_TFT_Set_Index+0)
SW	R2, Offset(_TFT_Set_Index_Ptr+0)(GP)
;__Lib_TFT_Defs.mbas,2883 :: 		TFT_Write_Command_Ptr = @TFT_Write_Command
LUI	R2, hi_addr(_TFT_Write_Command+0)
ORI	R2, R2, lo_addr(_TFT_Write_Command+0)
SW	R2, Offset(_TFT_Write_Command_Ptr+0)(GP)
;__Lib_TFT_Defs.mbas,2884 :: 		TFT_Write_Data_Ptr = @TFT_16bit_Write_Data
SW	R2, Offset(_TFT_Write_Data_Ptr+0)(GP)
L__TFT_Init_ILI9481_Custom326:
;__Lib_TFT_Defs.mbas,2887 :: 		TFT_DISP_WIDTH = display_width
SH	R25, Offset(_TFT_DISP_WIDTH+0)(GP)
;__Lib_TFT_Defs.mbas,2888 :: 		TFT_DISP_HEIGHT = display_height
SH	R26, Offset(_TFT_DISP_HEIGHT+0)(GP)
;__Lib_TFT_Defs.mbas,2889 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init_ILI9481_Custom633
NOP	
J	L__TFT_Init_ILI9481_Custom329
NOP	
L__TFT_Init_ILI9481_Custom633:
;__Lib_TFT_Defs.mbas,2890 :: 		TFT_Disp_Rotation = 0
SB	R0, Offset(__Lib_TFT_Defs_TFT_Disp_Rotation+0)(GP)
J	L__TFT_Init_ILI9481_Custom330
NOP	
;__Lib_TFT_Defs.mbas,2891 :: 		else
L__TFT_Init_ILI9481_Custom329:
;__Lib_TFT_Defs.mbas,2892 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
SB	R2, Offset(__Lib_TFT_Defs_TFT_Disp_Rotation+0)(GP)
;__Lib_TFT_Defs.mbas,2893 :: 		end if
L__TFT_Init_ILI9481_Custom330:
;__Lib_TFT_Defs.mbas,2895 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,2896 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
JAL	_TFT_Set_Brush+0
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,2898 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
JAL	_TFT_Move_Cursor+0
NOP	
;__Lib_TFT_Defs.mbas,2899 :: 		TFT_Clear_Fonts()
JAL	_TFT_Clear_Fonts+0
NOP	
;__Lib_TFT_Defs.mbas,2901 :: 		TFT_Reset_ILI9481()
NOP	
;__Lib_TFT_Defs.mbas,2902 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address_ILI9481
SW	R2, Offset(_TFT_Set_Address_Ptr+0)(GP)
;__Lib_TFT_Defs.mbas,2903 :: 		end sub
L_end_TFT_Init_ILI9481_Custom:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
; end of _TFT_Init_ILI9481_Custom
_TFT_Init_ILI9481_8bit:
;__Lib_TFT_Defs.mbas,2912 :: 		sub procedure TFT_Init_ILI9481_8bit(dim display_width as word display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,2913 :: 		__controller = _8BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 255
;__Lib_TFT_Defs.mbas,2914 :: 		if (Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init_ILI9481_8bit636
NOP	
J	L__TFT_Init_ILI9481_8bit333
NOP	
L__TFT_Init_ILI9481_8bit636:
;__Lib_TFT_Defs.mbas,2915 :: 		TFT_Set_Index_Ptr = @TFT_Set_Index
;__Lib_TFT_Defs.mbas,2916 :: 		TFT_Write_Command_Ptr = @TFT_Write_Command
;__Lib_TFT_Defs.mbas,2917 :: 		TFT_Write_Data_Ptr = @TFT_Write_Data
LUI	R2, hi_addr(_TFT_Write_Data+0)
ORI	R2, R2, lo_addr(_TFT_Write_Data+0)
L__TFT_Init_ILI9481_8bit333:
;__Lib_TFT_Defs.mbas,2920 :: 		TFT_DISP_WIDTH = display_width
;__Lib_TFT_Defs.mbas,2921 :: 		TFT_DISP_HEIGHT = display_height
;__Lib_TFT_Defs.mbas,2922 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init_ILI9481_8bit637
NOP	
J	L__TFT_Init_ILI9481_8bit336
NOP	
L__TFT_Init_ILI9481_8bit637:
;__Lib_TFT_Defs.mbas,2923 :: 		TFT_Disp_Rotation = 0
J	L__TFT_Init_ILI9481_8bit337
NOP	
;__Lib_TFT_Defs.mbas,2924 :: 		else
L__TFT_Init_ILI9481_8bit336:
;__Lib_TFT_Defs.mbas,2925 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
;__Lib_TFT_Defs.mbas,2926 :: 		end if
L__TFT_Init_ILI9481_8bit337:
;__Lib_TFT_Defs.mbas,2928 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,2929 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,2931 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,2932 :: 		TFT_Clear_Fonts()
NOP	
;__Lib_TFT_Defs.mbas,2933 :: 		TFT_Set_DataPort_Direction()
NOP	
;__Lib_TFT_Defs.mbas,2935 :: 		TFT_Reset_ILI9481()
NOP	
;__Lib_TFT_Defs.mbas,2936 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address_ILI9481
;__Lib_TFT_Defs.mbas,2937 :: 		end sub
L_end_TFT_Init_ILI9481_8bit:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
; end of _TFT_Init_ILI9481_8bit
_TFT_Init_ILI9481_8bit_Custom:
;__Lib_TFT_Defs.mbas,2947 :: 		sub procedure TFT_Init_ILI9481_8bit_Custom(dim display_width as word display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,2948 :: 		__controller = _8BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 255
;__Lib_TFT_Defs.mbas,2949 :: 		if (Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init_ILI9481_8bit_Custom640
NOP	
J	L__TFT_Init_ILI9481_8bit_Custom340
NOP	
L__TFT_Init_ILI9481_8bit_Custom640:
;__Lib_TFT_Defs.mbas,2950 :: 		TFT_Set_Index_Ptr = @TFT_Set_Index
;__Lib_TFT_Defs.mbas,2951 :: 		TFT_Write_Command_Ptr = @TFT_Write_Command
;__Lib_TFT_Defs.mbas,2952 :: 		TFT_Write_Data_Ptr = @TFT_Write_Data
L__TFT_Init_ILI9481_8bit_Custom340:
;__Lib_TFT_Defs.mbas,2955 :: 		TFT_DISP_WIDTH = display_width
;__Lib_TFT_Defs.mbas,2956 :: 		TFT_DISP_HEIGHT = display_height
;__Lib_TFT_Defs.mbas,2957 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init_ILI9481_8bit_Custom641
NOP	
J	L__TFT_Init_ILI9481_8bit_Custom343
NOP	
L__TFT_Init_ILI9481_8bit_Custom641:
;__Lib_TFT_Defs.mbas,2958 :: 		TFT_Disp_Rotation = 0
J	L__TFT_Init_ILI9481_8bit_Custom344
NOP	
;__Lib_TFT_Defs.mbas,2959 :: 		else
L__TFT_Init_ILI9481_8bit_Custom343:
;__Lib_TFT_Defs.mbas,2960 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
;__Lib_TFT_Defs.mbas,2961 :: 		end if
L__TFT_Init_ILI9481_8bit_Custom344:
;__Lib_TFT_Defs.mbas,2963 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,2964 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,2966 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,2967 :: 		TFT_Clear_Fonts()
NOP	
;__Lib_TFT_Defs.mbas,2969 :: 		TFT_Reset_ILI9481()
NOP	
;__Lib_TFT_Defs.mbas,2970 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address_ILI9481
;__Lib_TFT_Defs.mbas,2971 :: 		end sub
L_end_TFT_Init_ILI9481_8bit_Custom:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
; end of _TFT_Init_ILI9481_8bit_Custom
_TFT_Set_Address_SSD1963II:
;__Lib_TFT_Defs.mbas,2984 :: 		dim s_col, e_col, s_page, e_page, _width, _height as word
ADDIU	SP, SP, -16
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,2988 :: 		if ((TFT_DISP_WIDTH > 480) or (TFT_DISP_HEIGHT > 480)) then
SW	R25, 4(SP)
SLTIU	R3, R2, 481
XORI	R3, R3, 1
BEQ	R3, R0, L__TFT_Set_Address_SSD1963II644
NOP	
ADDIU	R3, R0, -1
L__TFT_Set_Address_SSD1963II644:
SLTIU	R2, R2, 481
XORI	R2, R2, 1
BEQ	R2, R0, L__TFT_Set_Address_SSD1963II646
NOP	
ADDIU	R2, R0, -1
L__TFT_Set_Address_SSD1963II646:
OR	R2, R3, R2
BNE	R2, R0, L__TFT_Set_Address_SSD1963II648
NOP	
J	L__TFT_Set_Address_SSD1963II347
NOP	
L__TFT_Set_Address_SSD1963II648:
;__Lib_TFT_Defs.mbas,2989 :: 		_width  = 800
; _width start address is: 20 (R5)
ORI	R5, R0, 800
;__Lib_TFT_Defs.mbas,2990 :: 		_height = 480
; _height start address is: 16 (R4)
ORI	R4, R0, 480
; _height end address is: 16 (R4)
; _width end address is: 20 (R5)
J	L__TFT_Set_Address_SSD1963II348
NOP	
;__Lib_TFT_Defs.mbas,2991 :: 		else
L__TFT_Set_Address_SSD1963II347:
;__Lib_TFT_Defs.mbas,2992 :: 		_width  = 480
ORI	R5, R0, 480
;__Lib_TFT_Defs.mbas,2993 :: 		_height = 272
ORI	R4, R0, 272
;__Lib_TFT_Defs.mbas,2994 :: 		end if
L__TFT_Set_Address_SSD1963II348:
;__Lib_TFT_Defs.mbas,2995 :: 		if (TFT_DISP_ROTATION = 90) then
ORI	R2, R0, 90
BEQ	R3, R2, L__TFT_Set_Address_SSD1963II649
NOP	
J	L__TFT_Set_Address_SSD1963II350
NOP	
L__TFT_Set_Address_SSD1963II649:
;__Lib_TFT_Defs.mbas,2996 :: 		if (Is_TFT_Rotated_180()) then
NOP	
BNE	R2, R0, L__TFT_Set_Address_SSD1963II651
NOP	
J	L__TFT_Set_Address_SSD1963II353
NOP	
L__TFT_Set_Address_SSD1963II651:
;__Lib_TFT_Defs.mbas,2997 :: 		s_col = (_width - 1) - y2                   ' {TFT_DISP_WIDTH}
ADDIU	R3, R5, -1
SUBU	R2, R3, R28
SH	R2, 8(SP)
;__Lib_TFT_Defs.mbas,2998 :: 		e_col = (_width - 1) - y1                   ' {TFT_DISP_WIDTH}
SUBU	R2, R3, R26
SH	R2, 10(SP)
;__Lib_TFT_Defs.mbas,2999 :: 		s_page = x1
SH	R25, 12(SP)
;__Lib_TFT_Defs.mbas,3000 :: 		e_page = x2
SH	R27, 14(SP)
J	L__TFT_Set_Address_SSD1963II354
NOP	
;__Lib_TFT_Defs.mbas,3001 :: 		else
L__TFT_Set_Address_SSD1963II353:
;__Lib_TFT_Defs.mbas,3002 :: 		s_col = y1
SH	R26, 8(SP)
;__Lib_TFT_Defs.mbas,3003 :: 		e_col = y2
SH	R28, 10(SP)
;__Lib_TFT_Defs.mbas,3004 :: 		s_page = (_height - 1) - x2                  ' {TFT_DISP_HEIGHT}
ADDIU	R3, R4, -1
SUBU	R2, R3, R27
SH	R2, 12(SP)
;__Lib_TFT_Defs.mbas,3005 :: 		e_page = (_height - 1) - x1                  ' {TFT_DISP_HEIGHT}
SUBU	R2, R3, R25
SH	R2, 14(SP)
;__Lib_TFT_Defs.mbas,3006 :: 		end if
L__TFT_Set_Address_SSD1963II354:
J	L__TFT_Set_Address_SSD1963II351
NOP	
;__Lib_TFT_Defs.mbas,3007 :: 		else
L__TFT_Set_Address_SSD1963II350:
;__Lib_TFT_Defs.mbas,3008 :: 		if (Is_TFT_Rotated_180()) then
NOP	
BNE	R2, R0, L__TFT_Set_Address_SSD1963II653
NOP	
J	L__TFT_Set_Address_SSD1963II356
NOP	
L__TFT_Set_Address_SSD1963II653:
;__Lib_TFT_Defs.mbas,3009 :: 		s_col = (_width - 1) - x2                   ' {TFT_DISP_WIDTH}
ADDIU	R3, R5, -1
SUBU	R2, R3, R27
SH	R2, 8(SP)
;__Lib_TFT_Defs.mbas,3010 :: 		e_col = (_width - 1) - x1                   ' {TFT_DISP_WIDTH}
SUBU	R2, R3, R25
SH	R2, 10(SP)
;__Lib_TFT_Defs.mbas,3011 :: 		s_page = (_height - 1) - y2                  ' {TFT_DISP_HEIGHT}
ADDIU	R3, R4, -1
SUBU	R2, R3, R28
SH	R2, 12(SP)
;__Lib_TFT_Defs.mbas,3012 :: 		e_page = (_height - 1) - y1                  ' {TFT_DISP_HEIGHT}
SUBU	R2, R3, R26
SH	R2, 14(SP)
J	L__TFT_Set_Address_SSD1963II357
NOP	
;__Lib_TFT_Defs.mbas,3013 :: 		else
L__TFT_Set_Address_SSD1963II356:
;__Lib_TFT_Defs.mbas,3014 :: 		s_col = x1
SH	R25, 8(SP)
;__Lib_TFT_Defs.mbas,3015 :: 		e_col = x2
SH	R27, 10(SP)
;__Lib_TFT_Defs.mbas,3016 :: 		s_page = y1
SH	R26, 12(SP)
;__Lib_TFT_Defs.mbas,3017 :: 		e_page = y2
SH	R28, 14(SP)
;__Lib_TFT_Defs.mbas,3018 :: 		end if
L__TFT_Set_Address_SSD1963II357:
;__Lib_TFT_Defs.mbas,3019 :: 		end if
L__TFT_Set_Address_SSD1963II351:
;__Lib_TFT_Defs.mbas,3020 :: 		TFT_Set_Index_Ptr(0x2a)             ' SET column address
ORI	R25, R0, 42
LW	R30, Offset(_TFT_Set_Index_Ptr+0)(GP)
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3021 :: 		TFT_Write_Command_Ptr(s_col >> 8)
LHU	R2, 8(SP)
SRL	R2, R2, 8
ANDI	R25, R2, 65535
LW	R30, Offset(_TFT_Write_Command_Ptr+0)(GP)
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3022 :: 		TFT_Write_Command_Ptr(s_col)
LHU	R25, 8(SP)
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3023 :: 		TFT_Write_Command_Ptr(e_col >> 8)
LHU	R2, 10(SP)
SRL	R2, R2, 8
ANDI	R25, R2, 65535
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3024 :: 		TFT_Write_Command_Ptr(e_col)
LHU	R25, 10(SP)
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3026 :: 		TFT_Set_Index_Ptr(0x2b)             ' SET page address
ORI	R25, R0, 43
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3027 :: 		TFT_Write_Command_Ptr(s_page >> 8)
LHU	R2, 12(SP)
SRL	R2, R2, 8
ANDI	R25, R2, 65535
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3028 :: 		TFT_Write_Command_Ptr(s_page)
LHU	R25, 12(SP)
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3029 :: 		TFT_Write_Command_Ptr(e_page >> 8)
LHU	R2, 14(SP)
SRL	R2, R2, 8
ANDI	R25, R2, 65535
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3030 :: 		TFT_Write_Command_Ptr(e_page)
LHU	R25, 14(SP)
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3031 :: 		TFT_Set_Index_Ptr(0x2C)
ORI	R25, R0, 44
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3032 :: 		end sub
L_end_TFT_Set_Address_SSD1963II:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 16
JR	RA
NOP	
; end of _TFT_Set_Address_SSD1963II
_TFT_Set_Address_SSD1963:
;__Lib_TFT_Defs.mbas,3040 :: 		sub procedure TFT_Set_Address_SSD1963(dim x as word y as word)
ADDIU	SP, SP, -12
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,3041 :: 		TFT_Set_Index_Ptr(0x2a)                'SET column address
SW	R25, 4(SP)
SH	R26, 8(SP)
SH	R25, 10(SP)
ORI	R25, R0, 42
JALR	RA, R30
NOP	
LHU	R25, 10(SP)
;__Lib_TFT_Defs.mbas,3042 :: 		TFT_Write_Command_Ptr((x) >> 8)       'SET start column address=0
ANDI	R2, R25, 65535
SRL	R2, R2, 8
SH	R25, 10(SP)
ANDI	R25, R2, 65535
JALR	RA, R30
NOP	
LHU	R25, 10(SP)
;__Lib_TFT_Defs.mbas,3043 :: 		TFT_Write_Command_Ptr(x)
JALR	RA, R30
NOP	
LHU	R26, 8(SP)
;__Lib_TFT_Defs.mbas,3044 :: 		if (TFT_Disp_Rotation = 90) then
ORI	R2, R0, 90
BEQ	R3, R2, L__TFT_Set_Address_SSD1963655
NOP	
J	L__TFT_Set_Address_SSD1963360
NOP	
L__TFT_Set_Address_SSD1963655:
;__Lib_TFT_Defs.mbas,3045 :: 		TFT_Write_Command_Ptr(271 >> 8)   'SET end column address=271
SH	R26, 8(SP)
ORI	R25, R0, 1
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3046 :: 		TFT_Write_Command_Ptr(0x0F)
ORI	R25, R0, 15
JALR	RA, R30
NOP	
LHU	R26, 8(SP)
J	L__TFT_Set_Address_SSD1963361
NOP	
;__Lib_TFT_Defs.mbas,3047 :: 		else
L__TFT_Set_Address_SSD1963360:
;__Lib_TFT_Defs.mbas,3048 :: 		TFT_Write_Command_Ptr(479 >> 8)   'SET end column address=479
SH	R26, 8(SP)
ORI	R25, R0, 1
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3049 :: 		TFT_Write_Command_Ptr(0xDF)
ORI	R25, R0, 223
JALR	RA, R30
NOP	
LHU	R26, 8(SP)
;__Lib_TFT_Defs.mbas,3050 :: 		end if
L__TFT_Set_Address_SSD1963361:
;__Lib_TFT_Defs.mbas,3052 :: 		TFT_Set_Index_Ptr(0x2b)                'SET page address
SH	R26, 8(SP)
ORI	R25, R0, 43
JALR	RA, R30
NOP	
LHU	R26, 8(SP)
;__Lib_TFT_Defs.mbas,3053 :: 		TFT_Write_Command_Ptr((y) >> 8)       'SET start page address=0
ANDI	R2, R26, 65535
SRL	R2, R2, 8
SH	R26, 8(SP)
ANDI	R25, R2, 65535
JALR	RA, R30
NOP	
LHU	R26, 8(SP)
;__Lib_TFT_Defs.mbas,3054 :: 		TFT_Write_Command_Ptr(y)
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3055 :: 		if(TFT_Disp_Rotation = 90) then
ORI	R2, R0, 90
BEQ	R3, R2, L__TFT_Set_Address_SSD1963656
NOP	
J	L__TFT_Set_Address_SSD1963363
NOP	
L__TFT_Set_Address_SSD1963656:
;__Lib_TFT_Defs.mbas,3056 :: 		TFT_Write_Command_Ptr(479 >> 8)   'SET end page address=479
ORI	R25, R0, 1
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3057 :: 		TFT_Write_Command_Ptr(0xDF)
ORI	R25, R0, 223
JALR	RA, R30
NOP	
J	L__TFT_Set_Address_SSD1963364
NOP	
;__Lib_TFT_Defs.mbas,3058 :: 		else
L__TFT_Set_Address_SSD1963363:
;__Lib_TFT_Defs.mbas,3059 :: 		TFT_Write_Command_Ptr(271 >> 8)   'SET end page address=271
ORI	R25, R0, 1
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3060 :: 		TFT_Write_Command_Ptr(0x0F)
ORI	R25, R0, 15
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3061 :: 		end if
L__TFT_Set_Address_SSD1963364:
;__Lib_TFT_Defs.mbas,3062 :: 		TFT_Set_Index_Ptr(0x2c)
ORI	R25, R0, 44
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3063 :: 		end sub
L_end_TFT_Set_Address_SSD1963:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 12
JR	RA
NOP	
_TFT_Set_Invert_Mode_SSD1963:
;__Lib_TFT_Defs.mbas,3069 :: 		sub procedure TFT_Set_Invert_Mode_SSD1963()
ADDIU	SP, SP, -8
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,3070 :: 		TFT_CS = 0
SW	R25, 4(SP)
_LX	
INS	R2, R0, BitPos(TFT_CS+0), 1
_SX	
;__Lib_TFT_Defs.mbas,3071 :: 		TFT_Set_Index_Ptr(0x21)
ORI	R25, R0, 33
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3072 :: 		TFT_CS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3073 :: 		end sub
L_end_TFT_Set_Invert_Mode_SSD1963:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 8
JR	RA
NOP	
; end of _TFT_Set_Invert_Mode_SSD1963
_TFT_Exit_Invert_Mode_SSD1963:
;__Lib_TFT_Defs.mbas,3079 :: 		sub procedure TFT_Exit_Invert_Mode_SSD1963()
ADDIU	SP, SP, -8
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,3080 :: 		TFT_CS = 0
SW	R25, 4(SP)
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3081 :: 		TFT_Set_Index_Ptr(0x20)
ORI	R25, R0, 32
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3082 :: 		TFT_CS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3083 :: 		end sub
L_end_TFT_Exit_Invert_Mode_SSD1963:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 8
JR	RA
NOP	
; end of _TFT_Exit_Invert_Mode_SSD1963
_TFT_Set_Display_OFF_SSD1963:
;__Lib_TFT_Defs.mbas,3089 :: 		sub procedure TFT_Set_Display_OFF_SSD1963()
ADDIU	SP, SP, -8
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,3090 :: 		TFT_CS = 0
SW	R25, 4(SP)
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3091 :: 		TFT_Set_Index_Ptr(0x28)
ORI	R25, R0, 40
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3092 :: 		TFT_CS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3093 :: 		end sub
L_end_TFT_Set_Display_OFF_SSD1963:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 8
JR	RA
NOP	
; end of _TFT_Set_Display_OFF_SSD1963
_TFT_Set_Display_ON_SSD1963:
;__Lib_TFT_Defs.mbas,3099 :: 		sub procedure TFT_Set_Display_ON_SSD1963()
ADDIU	SP, SP, -8
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,3100 :: 		TFT_CS = 0
SW	R25, 4(SP)
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3101 :: 		TFT_Set_Index_Ptr(0x29)
ORI	R25, R0, 41
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3102 :: 		TFT_CS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3103 :: 		end sub
L_end_TFT_Set_Display_ON_SSD1963:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 8
JR	RA
NOP	
; end of _TFT_Set_Display_ON_SSD1963
_TFT_Enter_Sleep_Mode_SSD1963:
;__Lib_TFT_Defs.mbas,3109 :: 		sub procedure TFT_Enter_Sleep_Mode_SSD1963()
ADDIU	SP, SP, -8
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,3110 :: 		TFT_CS = 0
SW	R25, 4(SP)
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3111 :: 		TFT_Set_Index_Ptr(0x10)
ORI	R25, R0, 16
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3112 :: 		TFT_CS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3115 :: 		Delay_5ms()
JAL	_Delay_5ms+0
NOP	
;__Lib_TFT_Defs.mbas,3116 :: 		end sub
L_end_TFT_Enter_Sleep_Mode_SSD1963:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 8
JR	RA
NOP	
; end of _TFT_Enter_Sleep_Mode_SSD1963
_TFT_Exit_Sleep_Mode_SSD1963:
;__Lib_TFT_Defs.mbas,3122 :: 		sub procedure TFT_Exit_Sleep_Mode_SSD1963()
ADDIU	SP, SP, -8
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,3123 :: 		TFT_CS = 0
SW	R25, 4(SP)
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3124 :: 		TFT_Set_Index_Ptr(0x11)
ORI	R25, R0, 17
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3125 :: 		TFT_CS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3126 :: 		end sub
L_end_TFT_Exit_Sleep_Mode_SSD1963:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 8
JR	RA
NOP	
; end of _TFT_Exit_Sleep_Mode_SSD1963
_TFT_Enter_Normal_Mode_SSD1963:
;__Lib_TFT_Defs.mbas,3132 :: 		sub procedure TFT_Enter_Normal_Mode_SSD1963()
ADDIU	SP, SP, -8
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,3133 :: 		TFT_CS = 0
SW	R25, 4(SP)
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3134 :: 		TFT_Set_Index_Ptr(0x13)
ORI	R25, R0, 19
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3135 :: 		TFT_CS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3136 :: 		end sub
L_end_TFT_Enter_Normal_Mode_SSD1963:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 8
JR	RA
NOP	
; end of _TFT_Enter_Normal_Mode_SSD1963
_TFT_Enter_Idle_Mode_SSD1963:
;__Lib_TFT_Defs.mbas,3142 :: 		sub procedure TFT_Enter_Idle_Mode_SSD1963()
ADDIU	SP, SP, -8
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,3143 :: 		TFT_CS = 0
SW	R25, 4(SP)
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3144 :: 		TFT_Set_Index_Ptr(0x39)
ORI	R25, R0, 57
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3145 :: 		TFT_CS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3146 :: 		end sub
L_end_TFT_Enter_Idle_Mode_SSD1963:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 8
JR	RA
NOP	
; end of _TFT_Enter_Idle_Mode_SSD1963
_TFT_Exit_Idle_Mode_SSD1963:
;__Lib_TFT_Defs.mbas,3149 :: 		sub procedure TFT_Exit_Idle_Mode_SSD1963()
ADDIU	SP, SP, -8
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,3150 :: 		TFT_CS = 0
SW	R25, 4(SP)
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3151 :: 		TFT_Set_Index_Ptr(0x38)
ORI	R25, R0, 56
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3152 :: 		TFT_CS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3153 :: 		end sub
L_end_TFT_Exit_Idle_Mode_SSD1963:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 8
JR	RA
NOP	
; end of _TFT_Exit_Idle_Mode_SSD1963
_TFT_Set_DBC_SSD1963:
;__Lib_TFT_Defs.mbas,3161 :: 		sub procedure TFT_Set_DBC_SSD1963(dim value as byte)
ADDIU	SP, SP, -12
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,3162 :: 		TFT_CS = 0
SW	R25, 4(SP)
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3163 :: 		TFT_Set_Index_Ptr(0xBE)
SB	R25, 8(SP)
ORI	R25, R0, 190
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3164 :: 		TFT_Write_Command_Ptr(0x06)
ORI	R25, R0, 6
JALR	RA, R30
NOP	
LBU	R25, 8(SP)
;__Lib_TFT_Defs.mbas,3165 :: 		TFT_Write_Command_Ptr(value)
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3166 :: 		TFT_Write_Command_Ptr(0x01)
ORI	R25, R0, 1
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3167 :: 		TFT_Write_Command_Ptr(0xFF)
ORI	R25, R0, 255
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3168 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3169 :: 		TFT_Write_Command_Ptr(0x01)
ORI	R25, R0, 1
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3170 :: 		TFT_CS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3171 :: 		end sub
L_end_TFT_Set_DBC_SSD1963:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 12
JR	RA
NOP	
; end of _TFT_Set_DBC_SSD1963
__Lib_TFT_Defs_TFT_Reset_SSD1963:
;__Lib_TFT_Defs.mbas,3177 :: 		sub procedure TFT_Reset_SSD1963()
ADDIU	SP, SP, -8
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,3179 :: 		TFT_RST = 0
SW	R25, 4(SP)
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3181 :: 		TFT_RST_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3184 :: 		TFT_RS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3186 :: 		TFT_RS_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3189 :: 		TFT_CS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3191 :: 		TFT_CS_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3193 :: 		TFT_RD_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3194 :: 		TFT_WR_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3195 :: 		TFT_RD = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3196 :: 		TFT_WR = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3198 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,3199 :: 		TFT_RST = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3200 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,3201 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,3203 :: 		TFT_CS = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3204 :: 		TFT_Set_Index_Ptr(0x01)     'Software Reset
ORI	R25, R0, 1
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3205 :: 		TFT_Set_Index_Ptr(0x01)
ORI	R25, R0, 1
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3206 :: 		TFT_Set_Index_Ptr(0x01)
ORI	R25, R0, 1
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3208 :: 		TFT_Set_Index_Ptr(0xE2)
ORI	R25, R0, 226
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3209 :: 		TFT_Write_Command_Ptr(35)    ' PLLclk = REFclk * 36 (360MHz)
ORI	R25, R0, 35
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3210 :: 		TFT_Write_Command_Ptr(2)     ' SYSclk = PLLclk / 3  (120MHz)
ORI	R25, R0, 2
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3211 :: 		TFT_Write_Command_Ptr(0x54)  ' validate M and N
ORI	R25, R0, 84
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3216 :: 		TFT_Set_Index_Ptr(0xe0)
ORI	R25, R0, 224
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3217 :: 		TFT_Write_Command_Ptr(0x01) ' START PLL
ORI	R25, R0, 1
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3219 :: 		Delay_50us() Delay_50us()
JAL	_Delay_50uS+0
NOP	
JAL	_Delay_50uS+0
NOP	
;__Lib_TFT_Defs.mbas,3221 :: 		TFT_Set_Index_Ptr(0xe0)
ORI	R25, R0, 224
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3222 :: 		TFT_Write_Command_Ptr(0x03) ' LOCK PLL
ORI	R25, R0, 3
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3224 :: 		TFT_Set_Index_Ptr(0xb0)          'SET LCD MODE  SET TFT 18Bits MODE
ORI	R25, R0, 176
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3225 :: 		if (Is_TFT_MM_Plus = 0) then
JAL	_Is_TFT_MM_Plus+0
NOP	
ANDI	R2, R2, 255
BEQ	R2, R0, L___Lib_TFT_Defs_TFT_Reset_SSD1963668
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_SSD1963377
NOP	
L___Lib_TFT_Defs_TFT_Reset_SSD1963668:
;__Lib_TFT_Defs.mbas,3226 :: 		TFT_Write_Command_Ptr(0x08)     'SET TFT MODE & hsync+Vsync+DEN MODE
ORI	R25, R0, 8
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3227 :: 		TFT_Write_Command_Ptr(0x80)     'SET TFT MODE & hsync+Vsync+DEN MODE
ORI	R25, R0, 128
JALR	RA, R30
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_SSD1963378
NOP	
;__Lib_TFT_Defs.mbas,3228 :: 		else
L___Lib_TFT_Defs_TFT_Reset_SSD1963377:
;__Lib_TFT_Defs.mbas,3229 :: 		TFT_Write_Command_Ptr(0x28)     'SET TFT MODE & hsync+Vsync+DEN MODE
ORI	R25, R0, 40
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3230 :: 		TFT_Write_Command_Ptr(0x20)     'SET TFT MODE & hsync+Vsync+DEN MODE
ORI	R25, R0, 32
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3231 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_SSD1963378:
;__Lib_TFT_Defs.mbas,3232 :: 		TFT_Write_Command_Ptr(0x01)      'SET horizontal size=480-1 HightByte
ORI	R25, R0, 1
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3233 :: 		TFT_Write_Command_Ptr(0xdf)      'SET horizontal size=480-1 LowByte
ORI	R25, R0, 223
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3234 :: 		TFT_Write_Command_Ptr(0x01)      'SET vertical size=272-1 HightByte
ORI	R25, R0, 1
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3235 :: 		TFT_Write_Command_Ptr(0x0f)      'SET vertical size=272-1 LowByte
ORI	R25, R0, 15
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3236 :: 		TFT_Write_Command_Ptr(0x00)      'SET even/odd line RGB seq.=RGB
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3238 :: 		TFT_Set_Index_Ptr(0xf0)
ORI	R25, R0, 240
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3239 :: 		TFT_Write_Command_Ptr(0x03)      '3 -16bit,0 -8bit        'SET pixel data I/F format=8bit
ORI	R25, R0, 3
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3240 :: 		TFT_Set_Index_Ptr(0x3A)
ORI	R25, R0, 58
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3241 :: 		TFT_Write_Command_Ptr(0x60)      ' SET R G B format = 6 6 6
ORI	R25, R0, 96
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3246 :: 		TFT_Set_Index_Ptr(0xe6)          'SET PCLK freq=10MHz   pixel clock frequency
ORI	R25, R0, 230
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3247 :: 		TFT_Write_Command_Ptr(0x01)
ORI	R25, R0, 1
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3248 :: 		TFT_Write_Command_Ptr(0x45)
ORI	R25, R0, 69
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3249 :: 		TFT_Write_Command_Ptr(0x47)
ORI	R25, R0, 71
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3251 :: 		TFT_Set_Index_Ptr(0xb4)          'SET HBP,
ORI	R25, R0, 180
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3252 :: 		TFT_Write_Command_Ptr(0x02)      'SET HSYNC Tatol 525
ORI	R25, R0, 2
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3253 :: 		TFT_Write_Command_Ptr(0x0d)
ORI	R25, R0, 13
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3254 :: 		TFT_Write_Command_Ptr(0x00)      'SET HBP 43
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3255 :: 		TFT_Write_Command_Ptr(0x2b)
ORI	R25, R0, 43
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3256 :: 		TFT_Write_Command_Ptr(0x28)      'SET VBP 41=40+1
ORI	R25, R0, 40
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3257 :: 		TFT_Write_Command_Ptr(0x00)      'SET Hsync pulse start position
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3258 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3259 :: 		TFT_Write_Command_Ptr(0x00)      'SET Hsync pulse subpixel start position
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3261 :: 		TFT_Set_Index_Ptr(0xb6)          'SET VBP,
ORI	R25, R0, 182
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3262 :: 		TFT_Write_Command_Ptr(0x01)      'SET Vsync total 286=285+1
ORI	R25, R0, 1
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3263 :: 		TFT_Write_Command_Ptr(0x1d)
ORI	R25, R0, 29
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3264 :: 		TFT_Write_Command_Ptr(0x00)      'SET VBP=12
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3265 :: 		TFT_Write_Command_Ptr(0x0c)
ORI	R25, R0, 12
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3266 :: 		TFT_Write_Command_Ptr(0x09)      'SET Vsync pulse 10=9+1
ORI	R25, R0, 9
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3267 :: 		TFT_Write_Command_Ptr(0x00)      'SET Vsync pulse start position
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3268 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3270 :: 		TFT_Set_Index_Ptr(0x36)     ' memory access control
ORI	R25, R0, 54
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3271 :: 		if (TFT_Disp_Rotation = 90) then
ORI	R2, R0, 90
BEQ	R3, R2, L___Lib_TFT_Defs_TFT_Reset_SSD1963669
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_SSD1963380
NOP	
L___Lib_TFT_Defs_TFT_Reset_SSD1963669:
;__Lib_TFT_Defs.mbas,3272 :: 		if (Is_TFT_Rotated_180() = 1) then
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BEQ	R3, R2, L___Lib_TFT_Defs_TFT_Reset_SSD1963670
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_SSD1963383
NOP	
L___Lib_TFT_Defs_TFT_Reset_SSD1963670:
;__Lib_TFT_Defs.mbas,3273 :: 		TFT_Write_Command_Ptr(0x60)
ORI	R25, R0, 96
JALR	RA, R30
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_SSD1963384
NOP	
;__Lib_TFT_Defs.mbas,3274 :: 		else
L___Lib_TFT_Defs_TFT_Reset_SSD1963383:
;__Lib_TFT_Defs.mbas,3275 :: 		TFT_Write_Command_Ptr(0xA0)
ORI	R25, R0, 160
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3276 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_SSD1963384:
J	L___Lib_TFT_Defs_TFT_Reset_SSD1963381
NOP	
;__Lib_TFT_Defs.mbas,3277 :: 		else
L___Lib_TFT_Defs_TFT_Reset_SSD1963380:
;__Lib_TFT_Defs.mbas,3278 :: 		if (Is_TFT_Rotated_180() = 1) then
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BEQ	R3, R2, L___Lib_TFT_Defs_TFT_Reset_SSD1963671
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_SSD1963386
NOP	
L___Lib_TFT_Defs_TFT_Reset_SSD1963671:
;__Lib_TFT_Defs.mbas,3279 :: 		TFT_Write_Command_Ptr(0xC0)
ORI	R25, R0, 192
JALR	RA, R30
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_SSD1963387
NOP	
;__Lib_TFT_Defs.mbas,3280 :: 		else
L___Lib_TFT_Defs_TFT_Reset_SSD1963386:
;__Lib_TFT_Defs.mbas,3281 :: 		TFT_Write_Command_Ptr(0x00)
MOVZ	R25, R0, R0
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3282 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_SSD1963387:
;__Lib_TFT_Defs.mbas,3283 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_SSD1963381:
;__Lib_TFT_Defs.mbas,3285 :: 		TFT_Set_Index_Ptr(0x29)                'SET display on
ORI	R25, R0, 41
JALR	RA, R30
NOP	
;__Lib_TFT_Defs.mbas,3286 :: 		TFT_CS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3287 :: 		end sub
L_end_TFT_Reset_SSD1963:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 8
JR	RA
NOP	
; end of __Lib_TFT_Defs_TFT_Reset_SSD1963
_TFT_Init_SSD1963:
;__Lib_TFT_Defs.mbas,3294 :: 		sub procedure TFT_Init_SSD1963(dim display_width as word display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,3295 :: 		__controller = _16BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 65535
;__Lib_TFT_Defs.mbas,3296 :: 		TFT_Set_SSD1963()
JAL	_TFT_Set_SSD1963+0
NOP	
;__Lib_TFT_Defs.mbas,3297 :: 		if (Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init_SSD1963674
NOP	
J	L__TFT_Init_SSD1963390
NOP	
L__TFT_Init_SSD1963674:
;__Lib_TFT_Defs.mbas,3298 :: 		TFT_Set_Index_Ptr = @TFT_Set_Index
;__Lib_TFT_Defs.mbas,3299 :: 		TFT_Write_Command_Ptr = @TFT_Write_Command
;__Lib_TFT_Defs.mbas,3300 :: 		TFT_Write_Data_Ptr = @TFT_16bit_Write_Data
LUI	R2, hi_addr(_TFT_16bit_Write_Data+0)
ORI	R2, R2, lo_addr(_TFT_16bit_Write_Data+0)
L__TFT_Init_SSD1963390:
;__Lib_TFT_Defs.mbas,3303 :: 		TFT_DISP_WIDTH = display_width
;__Lib_TFT_Defs.mbas,3304 :: 		TFT_DISP_HEIGHT = display_height
;__Lib_TFT_Defs.mbas,3305 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init_SSD1963675
NOP	
J	L__TFT_Init_SSD1963393
NOP	
L__TFT_Init_SSD1963675:
;__Lib_TFT_Defs.mbas,3306 :: 		TFT_Disp_Rotation = 0
J	L__TFT_Init_SSD1963394
NOP	
;__Lib_TFT_Defs.mbas,3307 :: 		else
L__TFT_Init_SSD1963393:
;__Lib_TFT_Defs.mbas,3308 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
;__Lib_TFT_Defs.mbas,3309 :: 		end if
L__TFT_Init_SSD1963394:
;__Lib_TFT_Defs.mbas,3311 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,3312 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,3314 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,3315 :: 		TFT_Clear_Fonts()
NOP	
;__Lib_TFT_Defs.mbas,3316 :: 		TFT_Set_DataPort_Direction()
JAL	__Lib_TFT_Defs_TFT_Set_DataPort_Direction+0
NOP	
;__Lib_TFT_Defs.mbas,3318 :: 		TFT_Reset_SSD1963()
JAL	__Lib_TFT_Defs_TFT_Reset_SSD1963+0
NOP	
;__Lib_TFT_Defs.mbas,3319 :: 		TFT_SSD1963_Set_Address_Ptr = @TFT_Set_Address_SSD1963II
LUI	R2, hi_addr(_TFT_Set_Address_SSD1963II+0)
ORI	R2, R2, lo_addr(_TFT_Set_Address_SSD1963II+0)
SW	R2, Offset(_TFT_SSD1963_Set_Address_Ptr+0)(GP)
;__Lib_TFT_Defs.mbas,3320 :: 		end sub
L_end_TFT_Init_SSD1963:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
; end of _TFT_Init_SSD1963
_TFT_Init_SSD1963_Custom:
;__Lib_TFT_Defs.mbas,3330 :: 		sub procedure TFT_Init_SSD1963_Custom(dim display_width as word display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,3331 :: 		__controller = _16BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 65535
;__Lib_TFT_Defs.mbas,3332 :: 		TFT_Set_SSD1963()
NOP	
;__Lib_TFT_Defs.mbas,3333 :: 		if (Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init_SSD1963_Custom678
NOP	
J	L__TFT_Init_SSD1963_Custom397
NOP	
L__TFT_Init_SSD1963_Custom678:
;__Lib_TFT_Defs.mbas,3334 :: 		TFT_Set_Index_Ptr = @TFT_Set_Index
;__Lib_TFT_Defs.mbas,3335 :: 		TFT_Write_Command_Ptr = @TFT_Write_Command
;__Lib_TFT_Defs.mbas,3336 :: 		TFT_Write_Data_Ptr = @TFT_16bit_Write_Data
L__TFT_Init_SSD1963_Custom397:
;__Lib_TFT_Defs.mbas,3339 :: 		TFT_DISP_WIDTH = display_width
;__Lib_TFT_Defs.mbas,3340 :: 		TFT_DISP_HEIGHT = display_height
;__Lib_TFT_Defs.mbas,3341 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init_SSD1963_Custom679
NOP	
J	L__TFT_Init_SSD1963_Custom400
NOP	
L__TFT_Init_SSD1963_Custom679:
;__Lib_TFT_Defs.mbas,3342 :: 		TFT_Disp_Rotation = 0
J	L__TFT_Init_SSD1963_Custom401
NOP	
;__Lib_TFT_Defs.mbas,3343 :: 		else
L__TFT_Init_SSD1963_Custom400:
;__Lib_TFT_Defs.mbas,3344 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
;__Lib_TFT_Defs.mbas,3345 :: 		end if
L__TFT_Init_SSD1963_Custom401:
;__Lib_TFT_Defs.mbas,3347 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,3348 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,3350 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,3351 :: 		TFT_Clear_Fonts()
NOP	
;__Lib_TFT_Defs.mbas,3353 :: 		TFT_Reset_SSD1963()
NOP	
;__Lib_TFT_Defs.mbas,3354 :: 		TFT_SSD1963_Set_Address_Ptr = @TFT_Set_Address_SSD1963II
;__Lib_TFT_Defs.mbas,3355 :: 		end sub
L_end_TFT_Init_SSD1963_Custom:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
; end of _TFT_Init_SSD1963_Custom
_TFT_SSD1963_8bit_Set_Index:
;__Lib_TFT_Defs.mbas,3363 :: 		sub procedure TFT_SSD1963_8bit_Set_Index(dim index as byte)
ADDIU	SP, SP, -4
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,3364 :: 		Delay_1us()
JAL	_Delay_1uS+0
NOP	
;__Lib_TFT_Defs.mbas,3365 :: 		Delay_1us()
JAL	_Delay_1uS+0
NOP	
;__Lib_TFT_Defs.mbas,3366 :: 		TFT_CS = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3367 :: 		TFT_RD = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3368 :: 		TFT_RS = 0
_LX	
INS	R2, R0, BitPos(TFT_RS+0), 1
_SX	
;__Lib_TFT_Defs.mbas,3369 :: 		TFT_DataPort = index
SB	R25, Offset(TFT_DataPort+0)(GP)
;__Lib_TFT_Defs.mbas,3370 :: 		TFT_WR = 0
_LX	
INS	R2, R0, BitPos(TFT_WR+0), 1
_SX	
;__Lib_TFT_Defs.mbas,3371 :: 		TFT_WR = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3372 :: 		TFT_CS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3373 :: 		end sub
L_end_TFT_SSD1963_8bit_Set_Index:
LW	RA, 0(SP)
ADDIU	SP, SP, 4
JR	RA
NOP	
; end of _TFT_SSD1963_8bit_Set_Index
_TFT_SSD1963YT_8bit_Write_Command:
;__Lib_TFT_Defs.mbas,3379 :: 		sub procedure TFT_SSD1963YT_8bit_Write_Command(dim command_ as byte)
ADDIU	SP, SP, -4
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,3380 :: 		TFT_CS = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3381 :: 		TFT_RD = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3382 :: 		TFT_RS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3383 :: 		TFT_DataPort = command_
;__Lib_TFT_Defs.mbas,3384 :: 		TFT_WR = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3385 :: 		TFT_WR = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3386 :: 		TFT_CS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3387 :: 		Delay_1us()
JAL	_Delay_1uS+0
NOP	
;__Lib_TFT_Defs.mbas,3388 :: 		Delay_1us()
JAL	_Delay_1uS+0
NOP	
;__Lib_TFT_Defs.mbas,3389 :: 		end sub
L_end_TFT_SSD1963YT_8bit_Write_Command:
LW	RA, 0(SP)
ADDIU	SP, SP, 4
JR	RA
NOP	
; end of _TFT_SSD1963YT_8bit_Write_Command
_TFT_SSD1963_8bit_Write_Data:
;__Lib_TFT_Defs.mbas,3392 :: 		dim temp as byte volatile
ADDIU	SP, SP, -12
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,3393 :: 		temp = (color >> 11)
SW	R25, 4(SP)
ANDI	R2, R25, 65535
SRL	R2, R2, 11
; temp start address is: 12 (R3)
ANDI	R3, R2, 65535
;__Lib_TFT_Defs.mbas,3394 :: 		temp = (temp << 3)
ANDI	R2, R3, 255
; temp end address is: 12 (R3)
SLL	R2, R2, 3
; temp start address is: 16 (R4)
ANDI	R4, R2, 255
;__Lib_TFT_Defs.mbas,3395 :: 		if ((temp >> 7) = 1) then
ANDI	R2, R4, 255
SRL	R2, R2, 7
ANDI	R3, R2, 255
ORI	R2, R0, 1
BEQ	R3, R2, L__TFT_SSD1963_8bit_Write_Data683
NOP	
J	L__TFT_SSD1963_8bit_Write_Data455
NOP	
L__TFT_SSD1963_8bit_Write_Data683:
;__Lib_TFT_Defs.mbas,3396 :: 		temp = temp +  7
ADDIU	R2, R4, 7
; temp end address is: 16 (R4)
ANDI	R3, R2, 255
ANDI	R2, R3, 255
J	L__TFT_SSD1963_8bit_Write_Data406
NOP	
L__TFT_SSD1963_8bit_Write_Data455:
ANDI	R2, R4, 255
L__TFT_SSD1963_8bit_Write_Data406:
;__Lib_TFT_Defs.mbas,3398 :: 		TFT_SSD1963YT_8bit_Write_Command(temp)
; temp start address is: 8 (R2)
SH	R25, 8(SP)
; temp end address is: 8 (R2)
ANDI	R25, R2, 255
JAL	_TFT_SSD1963YT_8bit_Write_Command+0
NOP	
LHU	R25, 8(SP)
;__Lib_TFT_Defs.mbas,3399 :: 		temp = (color >> 5)
ANDI	R2, R25, 65535
SRL	R2, R2, 5
ANDI	R3, R2, 65535
;__Lib_TFT_Defs.mbas,3400 :: 		temp = (temp << 2)
ANDI	R2, R3, 255
SLL	R2, R2, 2
ANDI	R4, R2, 255
;__Lib_TFT_Defs.mbas,3401 :: 		if ((temp >> 7) = 1) then
ANDI	R2, R4, 255
SRL	R2, R2, 7
ANDI	R3, R2, 255
ORI	R2, R0, 1
BEQ	R3, R2, L__TFT_SSD1963_8bit_Write_Data684
NOP	
J	L__TFT_SSD1963_8bit_Write_Data456
NOP	
L__TFT_SSD1963_8bit_Write_Data684:
;__Lib_TFT_Defs.mbas,3402 :: 		temp = temp + 3
ADDIU	R2, R4, 3
ANDI	R3, R2, 255
ANDI	R2, R3, 255
J	L__TFT_SSD1963_8bit_Write_Data409
NOP	
L__TFT_SSD1963_8bit_Write_Data456:
ANDI	R2, R4, 255
L__TFT_SSD1963_8bit_Write_Data409:
;__Lib_TFT_Defs.mbas,3405 :: 		TFT_SSD1963YT_8bit_Write_Command(temp)
SH	R25, 8(SP)
ANDI	R25, R2, 255
NOP	
LHU	R25, 8(SP)
;__Lib_TFT_Defs.mbas,3406 :: 		temp = (color << 3)
ANDI	R2, R25, 65535
SLL	R2, R2, 3
ANDI	R4, R2, 255
;__Lib_TFT_Defs.mbas,3407 :: 		if ((temp >> 7) = 1) then
ANDI	R2, R4, 255
SRL	R2, R2, 7
ANDI	R3, R2, 255
ORI	R2, R0, 1
BEQ	R3, R2, L__TFT_SSD1963_8bit_Write_Data685
NOP	
J	L__TFT_SSD1963_8bit_Write_Data457
NOP	
L__TFT_SSD1963_8bit_Write_Data685:
;__Lib_TFT_Defs.mbas,3408 :: 		temp = temp + 7
ADDIU	R2, R4, 7
ANDI	R3, R2, 255
ANDI	R2, R3, 255
J	L__TFT_SSD1963_8bit_Write_Data412
NOP	
L__TFT_SSD1963_8bit_Write_Data457:
ANDI	R2, R4, 255
L__TFT_SSD1963_8bit_Write_Data412:
;__Lib_TFT_Defs.mbas,3411 :: 		TFT_SSD1963YT_8bit_Write_Command(temp)
ANDI	R25, R2, 255
NOP	
;__Lib_TFT_Defs.mbas,3412 :: 		end sub
L_end_TFT_SSD1963_8bit_Write_Data:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 12
JR	RA
NOP	
; end of _TFT_SSD1963_8bit_Write_Data
_TFT_SSD1963_8bit_Set_Reg:
;__Lib_TFT_Defs.mbas,3419 :: 		sub procedure TFT_SSD1963_8bit_Set_Reg(dim command_ as byte data1 as byte)
ADDIU	SP, SP, -8
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,3420 :: 		TFT_SSD1963_8bit_Set_Index(command_)
SW	R25, 4(SP)
JAL	_TFT_SSD1963_8bit_Set_Index+0
NOP	
;__Lib_TFT_Defs.mbas,3421 :: 		TFT_SSD1963YT_8bit_Write_Command(data1)
ANDI	R25, R26, 255
NOP	
;__Lib_TFT_Defs.mbas,3422 :: 		end sub
L_end_TFT_SSD1963_8bit_Set_Reg:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 8
JR	RA
NOP	
; end of _TFT_SSD1963_8bit_Set_Reg
_TFT_Set_Address_SSD1963_8bit:
;__Lib_TFT_Defs.mbas,3429 :: 		sub procedure TFT_Set_Address_SSD1963_8bit(dim x as word y as word)
ADDIU	SP, SP, -12
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,3430 :: 		TFT_SSD1963_8bit_Set_Index(0x2A)              ' SET column address
SW	R25, 4(SP)
SH	R25, 8(SP)
ORI	R25, R0, 42
NOP	
LHU	R25, 8(SP)
;__Lib_TFT_Defs.mbas,3431 :: 		TFT_SSD1963YT_8bit_Write_Command((x) >> 8)   ' SET start page address=0
ANDI	R2, R25, 65535
SRL	R2, R2, 8
SH	R25, 8(SP)
ANDI	R25, R2, 65535
NOP	
LHU	R25, 8(SP)
;__Lib_TFT_Defs.mbas,3432 :: 		TFT_SSD1963YT_8bit_Write_Command(x)
NOP	
;__Lib_TFT_Defs.mbas,3433 :: 		TFT_SSD1963YT_8bit_Write_Command(0x03)        ' SET start column address=0
ORI	R25, R0, 3
NOP	
;__Lib_TFT_Defs.mbas,3434 :: 		TFT_SSD1963YT_8bit_Write_Command(0x1F)
ORI	R25, R0, 31
NOP	
;__Lib_TFT_Defs.mbas,3435 :: 		TFT_SSD1963_8bit_Set_Index(0x2B)              ' SET page address
ORI	R25, R0, 43
NOP	
;__Lib_TFT_Defs.mbas,3436 :: 		TFT_SSD1963YT_8bit_Write_Command((y) >> 8)   ' SET start column address=0
ANDI	R2, R26, 65535
SRL	R2, R2, 8
ANDI	R25, R2, 65535
NOP	
;__Lib_TFT_Defs.mbas,3437 :: 		TFT_SSD1963YT_8bit_Write_Command(y)
ANDI	R25, R26, 65535
NOP	
;__Lib_TFT_Defs.mbas,3438 :: 		TFT_SSD1963YT_8bit_Write_Command(0x01)        ' SET start page address=0
ORI	R25, R0, 1
NOP	
;__Lib_TFT_Defs.mbas,3439 :: 		TFT_SSD1963YT_8bit_Write_Command(0xDF)
ORI	R25, R0, 223
NOP	
;__Lib_TFT_Defs.mbas,3440 :: 		TFT_SSD1963_8bit_Set_Index(0x2C)
ORI	R25, R0, 44
NOP	
;__Lib_TFT_Defs.mbas,3441 :: 		end sub
L_end_TFT_Set_Address_SSD1963_8bit:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 12
JR	RA
NOP	
; end of _TFT_Set_Address_SSD1963_8bit
__Lib_TFT_Defs_TFT_Reset_SSD1963_8bit:
;__Lib_TFT_Defs.mbas,3447 :: 		sub procedure TFT_Reset_SSD1963_8bit()
ADDIU	SP, SP, -8
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,3449 :: 		TFT_RST = 0
SW	R25, 4(SP)
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3451 :: 		TFT_RST_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3454 :: 		TFT_RS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3456 :: 		TFT_RS_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3459 :: 		TFT_CS = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3461 :: 		TFT_CS_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3463 :: 		TFT_RD_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3464 :: 		TFT_WR_Direction = 0
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3465 :: 		TFT_RD = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3466 :: 		TFT_WR = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3469 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,3470 :: 		TFT_RST = 1
_LX	
_SX	
;__Lib_TFT_Defs.mbas,3471 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,3472 :: 		Delay_100ms()
JAL	_Delay_100ms+0
NOP	
;__Lib_TFT_Defs.mbas,3474 :: 		TFT_SSD1963_8bit_Set_Index(0x01)     'Software Reset
ORI	R25, R0, 1
NOP	
;__Lib_TFT_Defs.mbas,3475 :: 		TFT_SSD1963_8bit_Set_Index(0x01)
ORI	R25, R0, 1
NOP	
;__Lib_TFT_Defs.mbas,3476 :: 		TFT_SSD1963_8bit_Set_Index(0x01)
ORI	R25, R0, 1
NOP	
;__Lib_TFT_Defs.mbas,3478 :: 		TFT_SSD1963_8bit_Set_Index(0xe0) 'START PLL
ORI	R25, R0, 224
NOP	
;__Lib_TFT_Defs.mbas,3479 :: 		TFT_SSD1963YT_8bit_Write_Command(0x01)
ORI	R25, R0, 1
NOP	
;__Lib_TFT_Defs.mbas,3481 :: 		Delay_50us() Delay_50us()
JAL	_Delay_50uS+0
NOP	
JAL	_Delay_50uS+0
NOP	
;__Lib_TFT_Defs.mbas,3482 :: 		TFT_SSD1963_8bit_Set_Index(0xe0)'LOCK PLL
ORI	R25, R0, 224
NOP	
;__Lib_TFT_Defs.mbas,3483 :: 		TFT_SSD1963YT_8bit_Write_Command(0x03)
ORI	R25, R0, 3
NOP	
;__Lib_TFT_Defs.mbas,3484 :: 		TFT_SSD1963_8bit_Set_Index(0xb0) 'SET LCD MODE  SET TFT 18Bits MODE
ORI	R25, R0, 176
NOP	
;__Lib_TFT_Defs.mbas,3485 :: 		TFT_SSD1963YT_8bit_Write_Command(0x08) 'SET TFT MODE & hsync+Vsync+DEN
ORI	R25, R0, 8
NOP	
;__Lib_TFT_Defs.mbas,3487 :: 		TFT_SSD1963YT_8bit_Write_Command(0x80) 'SET TFT MODE & hsync+Vsync+DEN
ORI	R25, R0, 128
NOP	
;__Lib_TFT_Defs.mbas,3489 :: 		TFT_SSD1963YT_8bit_Write_Command(0x03) 'SET horizontal size
ORI	R25, R0, 3
NOP	
;__Lib_TFT_Defs.mbas,3491 :: 		TFT_SSD1963YT_8bit_Write_Command(0x1f)        'SET horizontal size
ORI	R25, R0, 31
NOP	
;__Lib_TFT_Defs.mbas,3493 :: 		TFT_SSD1963YT_8bit_Write_Command(0x01) 'SET vertical size
ORI	R25, R0, 1
NOP	
;__Lib_TFT_Defs.mbas,3495 :: 		TFT_SSD1963YT_8bit_Write_Command(0xdf) 'SET vertical size LowByte
ORI	R25, R0, 223
NOP	
;__Lib_TFT_Defs.mbas,3496 :: 		TFT_SSD1963YT_8bit_Write_Command(0x2d) 'SET even/odd line RGB seq.=RGB
ORI	R25, R0, 45
NOP	
;__Lib_TFT_Defs.mbas,3497 :: 		TFT_SSD1963_8bit_Set_Index(0xF0)
ORI	R25, R0, 240
NOP	
;__Lib_TFT_Defs.mbas,3498 :: 		TFT_SSD1963YT_8bit_Write_Command(0x00)
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,3500 :: 		TFT_SSD1963_8bit_Set_Index(0x3A)
ORI	R25, R0, 58
NOP	
;__Lib_TFT_Defs.mbas,3501 :: 		TFT_SSD1963YT_8bit_Write_Command(0x60)
ORI	R25, R0, 96
NOP	
;__Lib_TFT_Defs.mbas,3503 :: 		TFT_SSD1963_8bit_Set_Index(0xe6)    'SET PCLK freq=33.26MHz
ORI	R25, R0, 230
NOP	
;__Lib_TFT_Defs.mbas,3504 :: 		TFT_SSD1963YT_8bit_Write_Command(0x02)
ORI	R25, R0, 2
NOP	
;__Lib_TFT_Defs.mbas,3505 :: 		TFT_SSD1963YT_8bit_Write_Command(0xef)
ORI	R25, R0, 239
NOP	
;__Lib_TFT_Defs.mbas,3506 :: 		TFT_SSD1963YT_8bit_Write_Command(0xff)
ORI	R25, R0, 255
NOP	
;__Lib_TFT_Defs.mbas,3508 :: 		TFT_SSD1963_8bit_Set_Index(0xb4) 'SET HBP, HFP
ORI	R25, R0, 180
NOP	
;__Lib_TFT_Defs.mbas,3509 :: 		TFT_SSD1963YT_8bit_Write_Command(0x20) 'SET HSYNC
ORI	R25, R0, 32
NOP	
;__Lib_TFT_Defs.mbas,3510 :: 		TFT_SSD1963YT_8bit_Write_Command(0xaf)
ORI	R25, R0, 175
NOP	
;__Lib_TFT_Defs.mbas,3511 :: 		TFT_SSD1963YT_8bit_Write_Command(0x00) 'SET HBP
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,3512 :: 		TFT_SSD1963YT_8bit_Write_Command(0xa3)
ORI	R25, R0, 163
NOP	
;__Lib_TFT_Defs.mbas,3513 :: 		TFT_SSD1963YT_8bit_Write_Command(0x07) 'SET VBP
ORI	R25, R0, 7
NOP	
;__Lib_TFT_Defs.mbas,3514 :: 		TFT_SSD1963YT_8bit_Write_Command(0x00) 'SET Hsync pulse start position
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,3515 :: 		TFT_SSD1963YT_8bit_Write_Command(0x00)
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,3516 :: 		TFT_SSD1963YT_8bit_Write_Command(0x00) 'SET Hsync pulse subpixel start
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,3518 :: 		TFT_SSD1963_8bit_Set_Index(0xb6)   'SET VBP, VFP
ORI	R25, R0, 182
NOP	
;__Lib_TFT_Defs.mbas,3519 :: 		TFT_SSD1963YT_8bit_Write_Command(0x01) 'SET Vsync
ORI	R25, R0, 1
NOP	
;__Lib_TFT_Defs.mbas,3520 :: 		TFT_SSD1963YT_8bit_Write_Command(0xef)
ORI	R25, R0, 239
NOP	
;__Lib_TFT_Defs.mbas,3521 :: 		TFT_SSD1963YT_8bit_Write_Command(0x00) 'SET VBP
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,3522 :: 		TFT_SSD1963YT_8bit_Write_Command(0x04)
ORI	R25, R0, 4
NOP	
;__Lib_TFT_Defs.mbas,3523 :: 		TFT_SSD1963YT_8bit_Write_Command(0x01) 'SET Vsync pulse
ORI	R25, R0, 1
NOP	
;__Lib_TFT_Defs.mbas,3524 :: 		TFT_SSD1963YT_8bit_Write_Command(0x00) 'SET Vsync pulse start position
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,3525 :: 		TFT_SSD1963YT_8bit_Write_Command(0x00)
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,3527 :: 		TFT_SSD1963_8bit_Set_Index(0x36)       ' memory access control
ORI	R25, R0, 54
NOP	
;__Lib_TFT_Defs.mbas,3528 :: 		if (TFT_Disp_Rotation = 90) then
ORI	R2, R0, 90
BEQ	R3, R2, L___Lib_TFT_Defs_TFT_Reset_SSD1963_8bit689
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_SSD1963_8bit418
NOP	
L___Lib_TFT_Defs_TFT_Reset_SSD1963_8bit689:
;__Lib_TFT_Defs.mbas,3529 :: 		if (Is_TFT_Rotated_180()) then
NOP	
BNE	R2, R0, L___Lib_TFT_Defs_TFT_Reset_SSD1963_8bit691
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_SSD1963_8bit421
NOP	
L___Lib_TFT_Defs_TFT_Reset_SSD1963_8bit691:
;__Lib_TFT_Defs.mbas,3530 :: 		TFT_SSD1963YT_8bit_Write_Command(0x60)
ORI	R25, R0, 96
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_SSD1963_8bit422
NOP	
;__Lib_TFT_Defs.mbas,3531 :: 		else
L___Lib_TFT_Defs_TFT_Reset_SSD1963_8bit421:
;__Lib_TFT_Defs.mbas,3532 :: 		TFT_SSD1963YT_8bit_Write_Command(0xA0)
ORI	R25, R0, 160
NOP	
;__Lib_TFT_Defs.mbas,3533 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_SSD1963_8bit422:
J	L___Lib_TFT_Defs_TFT_Reset_SSD1963_8bit419
NOP	
;__Lib_TFT_Defs.mbas,3534 :: 		else
L___Lib_TFT_Defs_TFT_Reset_SSD1963_8bit418:
;__Lib_TFT_Defs.mbas,3535 :: 		if (Is_TFT_Rotated_180()) then
NOP	
BNE	R2, R0, L___Lib_TFT_Defs_TFT_Reset_SSD1963_8bit693
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_SSD1963_8bit424
NOP	
L___Lib_TFT_Defs_TFT_Reset_SSD1963_8bit693:
;__Lib_TFT_Defs.mbas,3536 :: 		TFT_SSD1963YT_8bit_Write_Command(0xC0)
ORI	R25, R0, 192
NOP	
J	L___Lib_TFT_Defs_TFT_Reset_SSD1963_8bit425
NOP	
;__Lib_TFT_Defs.mbas,3537 :: 		else
L___Lib_TFT_Defs_TFT_Reset_SSD1963_8bit424:
;__Lib_TFT_Defs.mbas,3538 :: 		TFT_SSD1963YT_8bit_Write_Command(0x00)
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,3539 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_SSD1963_8bit425:
;__Lib_TFT_Defs.mbas,3540 :: 		end if
L___Lib_TFT_Defs_TFT_Reset_SSD1963_8bit419:
;__Lib_TFT_Defs.mbas,3542 :: 		TFT_SSD1963_8bit_Set_Index(0x29) 'SET display on
ORI	R25, R0, 41
NOP	
;__Lib_TFT_Defs.mbas,3543 :: 		end sub
L_end_TFT_Reset_SSD1963_8bit:
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 8
JR	RA
NOP	
; end of __Lib_TFT_Defs_TFT_Reset_SSD1963_8bit
_TFT_Init_SSD1963_8bit:
;__Lib_TFT_Defs.mbas,3550 :: 		sub procedure TFT_Init_SSD1963_8bit(dim display_width as word display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,3551 :: 		__controller = _8BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 255
;__Lib_TFT_Defs.mbas,3552 :: 		TFT_Set_SSD1963()
NOP	
;__Lib_TFT_Defs.mbas,3553 :: 		if (Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init_SSD1963_8bit696
NOP	
J	L__TFT_Init_SSD1963_8bit428
NOP	
L__TFT_Init_SSD1963_8bit696:
;__Lib_TFT_Defs.mbas,3554 :: 		TFT_Set_Index_Ptr = @TFT_SSD1963_8bit_Set_Index
LUI	R2, hi_addr(_TFT_SSD1963_8bit_Set_Index+0)
ORI	R2, R2, lo_addr(_TFT_SSD1963_8bit_Set_Index+0)
;__Lib_TFT_Defs.mbas,3555 :: 		TFT_Write_Command_Ptr = @TFT_SSD1963YT_8bit_Write_Command
LUI	R2, hi_addr(_TFT_SSD1963YT_8bit_Write_Command+0)
ORI	R2, R2, lo_addr(_TFT_SSD1963YT_8bit_Write_Command+0)
;__Lib_TFT_Defs.mbas,3556 :: 		TFT_Write_Data_Ptr = @TFT_SSD1963_8bit_Write_Data
LUI	R2, hi_addr(_TFT_SSD1963_8bit_Write_Data+0)
ORI	R2, R2, lo_addr(_TFT_SSD1963_8bit_Write_Data+0)
L__TFT_Init_SSD1963_8bit428:
;__Lib_TFT_Defs.mbas,3559 :: 		TFT_DISP_WIDTH = display_width
;__Lib_TFT_Defs.mbas,3560 :: 		TFT_DISP_HEIGHT = display_height
;__Lib_TFT_Defs.mbas,3561 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init_SSD1963_8bit697
NOP	
J	L__TFT_Init_SSD1963_8bit431
NOP	
L__TFT_Init_SSD1963_8bit697:
;__Lib_TFT_Defs.mbas,3562 :: 		TFT_Disp_Rotation = 0
J	L__TFT_Init_SSD1963_8bit432
NOP	
;__Lib_TFT_Defs.mbas,3563 :: 		else
L__TFT_Init_SSD1963_8bit431:
;__Lib_TFT_Defs.mbas,3564 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
;__Lib_TFT_Defs.mbas,3565 :: 		end if
L__TFT_Init_SSD1963_8bit432:
;__Lib_TFT_Defs.mbas,3567 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,3568 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,3570 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,3571 :: 		TFT_Clear_Fonts()
NOP	
;__Lib_TFT_Defs.mbas,3573 :: 		TFT_Set_DataPort_Direction()
NOP	
;__Lib_TFT_Defs.mbas,3574 :: 		TFT_Reset_SSD1963_8bit()
JAL	__Lib_TFT_Defs_TFT_Reset_SSD1963_8bit+0
NOP	
;__Lib_TFT_Defs.mbas,3575 :: 		TFT_SSD1963_Set_Address_Ptr = @TFT_Set_Address_SSD1963II
;__Lib_TFT_Defs.mbas,3576 :: 		end sub
L_end_TFT_Init_SSD1963_8bit:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
; end of _TFT_Init_SSD1963_8bit
_TFT_Init_SSD1963_8bit_Custom:
;__Lib_TFT_Defs.mbas,3586 :: 		sub procedure TFT_Init_SSD1963_8bit_Custom(dim display_width as word display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,3587 :: 		__controller = _8BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 255
;__Lib_TFT_Defs.mbas,3588 :: 		TFT_Set_SSD1963()
NOP	
;__Lib_TFT_Defs.mbas,3589 :: 		if (Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init_SSD1963_8bit_Custom700
NOP	
J	L__TFT_Init_SSD1963_8bit_Custom435
NOP	
L__TFT_Init_SSD1963_8bit_Custom700:
;__Lib_TFT_Defs.mbas,3590 :: 		TFT_Set_Index_Ptr = @TFT_SSD1963_8bit_Set_Index
;__Lib_TFT_Defs.mbas,3591 :: 		TFT_Write_Command_Ptr = @TFT_SSD1963YT_8bit_Write_Command
;__Lib_TFT_Defs.mbas,3592 :: 		TFT_Write_Data_Ptr = @TFT_SSD1963_8bit_Write_Data
L__TFT_Init_SSD1963_8bit_Custom435:
;__Lib_TFT_Defs.mbas,3595 :: 		TFT_DISP_WIDTH = display_width
;__Lib_TFT_Defs.mbas,3596 :: 		TFT_DISP_HEIGHT = display_height
;__Lib_TFT_Defs.mbas,3597 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init_SSD1963_8bit_Custom701
NOP	
J	L__TFT_Init_SSD1963_8bit_Custom438
NOP	
L__TFT_Init_SSD1963_8bit_Custom701:
;__Lib_TFT_Defs.mbas,3598 :: 		TFT_Disp_Rotation = 0
J	L__TFT_Init_SSD1963_8bit_Custom439
NOP	
;__Lib_TFT_Defs.mbas,3599 :: 		else
L__TFT_Init_SSD1963_8bit_Custom438:
;__Lib_TFT_Defs.mbas,3600 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
;__Lib_TFT_Defs.mbas,3601 :: 		end if
L__TFT_Init_SSD1963_8bit_Custom439:
;__Lib_TFT_Defs.mbas,3603 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,3604 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,3606 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,3607 :: 		TFT_Clear_Fonts()
NOP	
;__Lib_TFT_Defs.mbas,3609 :: 		TFT_Reset_SSD1963_8bit()
NOP	
;__Lib_TFT_Defs.mbas,3610 :: 		TFT_SSD1963_Set_Address_Ptr = @TFT_Set_Address_SSD1963II
;__Lib_TFT_Defs.mbas,3611 :: 		end sub
L_end_TFT_Init_SSD1963_8bit_Custom:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
; end of _TFT_Init_SSD1963_8bit_Custom
_TFT_Init_HX8347G_16bit:
;__Lib_TFT_Defs.mbas,3620 :: 		sub procedure TFT_Init_HX8347G_16bit(dim display_width as word display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,3621 :: 		__controller = _16BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 65535
;__Lib_TFT_Defs.mbas,3622 :: 		if (Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init_HX8347G_16bit704
NOP	
J	L__TFT_Init_HX8347G_16bit442
NOP	
L__TFT_Init_HX8347G_16bit704:
;__Lib_TFT_Defs.mbas,3623 :: 		TFT_Set_Index_Ptr = @TFT_Set_Index
;__Lib_TFT_Defs.mbas,3624 :: 		TFT_Write_Command_Ptr = @TFT_Write_Command
;__Lib_TFT_Defs.mbas,3625 :: 		TFT_Write_Data_Ptr = @TFT_16bit_Write_Data
L__TFT_Init_HX8347G_16bit442:
;__Lib_TFT_Defs.mbas,3628 :: 		TFT_DISP_WIDTH = display_width
;__Lib_TFT_Defs.mbas,3629 :: 		TFT_DISP_HEIGHT = display_height
;__Lib_TFT_Defs.mbas,3630 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init_HX8347G_16bit705
NOP	
J	L__TFT_Init_HX8347G_16bit445
NOP	
L__TFT_Init_HX8347G_16bit705:
;__Lib_TFT_Defs.mbas,3631 :: 		TFT_Disp_Rotation = 0
J	L__TFT_Init_HX8347G_16bit446
NOP	
;__Lib_TFT_Defs.mbas,3632 :: 		else
L__TFT_Init_HX8347G_16bit445:
;__Lib_TFT_Defs.mbas,3633 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
;__Lib_TFT_Defs.mbas,3634 :: 		end if
L__TFT_Init_HX8347G_16bit446:
;__Lib_TFT_Defs.mbas,3636 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,3637 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,3639 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,3640 :: 		TFT_Clear_Fonts()
NOP	
;__Lib_TFT_Defs.mbas,3641 :: 		TFT_Set_DataPort_Direction()
NOP	
;__Lib_TFT_Defs.mbas,3643 :: 		TFT_Reset_HX8347G()
JAL	__Lib_TFT_Defs_TFT_Reset_HX8347G+0
NOP	
;__Lib_TFT_Defs.mbas,3644 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address
LUI	R2, hi_addr(_TFT_Set_Address+0)
ORI	R2, R2, lo_addr(_TFT_Set_Address+0)
;__Lib_TFT_Defs.mbas,3645 :: 		end sub
L_end_TFT_Init_HX8347G_16bit:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
; end of _TFT_Init_HX8347G_16bit
_TFT_Init_HX8347G_16bit_Custom:
;__Lib_TFT_Defs.mbas,3655 :: 		sub procedure TFT_Init_HX8347G_16bit_Custom(dim display_width as word display_height as word)
ADDIU	SP, SP, -20
SW	RA, 0(SP)
;__Lib_TFT_Defs.mbas,3656 :: 		__controller = _16BIT_CONTROLLER
SW	R25, 4(SP)
SW	R26, 8(SP)
SW	R27, 12(SP)
SW	R28, 16(SP)
ORI	R2, R0, 65535
;__Lib_TFT_Defs.mbas,3657 :: 		if (Is_TFT_Set() <> 1) then
JAL	_Is_TFT_Set+0
NOP	
ANDI	R3, R2, 255
ORI	R2, R0, 1
BNE	R3, R2, L__TFT_Init_HX8347G_16bit_Custom708
NOP	
J	L__TFT_Init_HX8347G_16bit_Custom449
NOP	
L__TFT_Init_HX8347G_16bit_Custom708:
;__Lib_TFT_Defs.mbas,3658 :: 		TFT_Set_Index_Ptr = @TFT_Set_Index
;__Lib_TFT_Defs.mbas,3659 :: 		TFT_Write_Command_Ptr = @TFT_Write_Command
;__Lib_TFT_Defs.mbas,3660 :: 		TFT_Write_Data_Ptr = @TFT_16bit_Write_Data
L__TFT_Init_HX8347G_16bit_Custom449:
;__Lib_TFT_Defs.mbas,3663 :: 		TFT_DISP_WIDTH = display_width
;__Lib_TFT_Defs.mbas,3664 :: 		TFT_DISP_HEIGHT = display_height
;__Lib_TFT_Defs.mbas,3665 :: 		if (display_width >= display_height) then
ANDI	R3, R25, 65535
ANDI	R2, R26, 65535
SLTU	R2, R3, R2
BEQ	R2, R0, L__TFT_Init_HX8347G_16bit_Custom709
NOP	
J	L__TFT_Init_HX8347G_16bit_Custom452
NOP	
L__TFT_Init_HX8347G_16bit_Custom709:
;__Lib_TFT_Defs.mbas,3666 :: 		TFT_Disp_Rotation = 0
J	L__TFT_Init_HX8347G_16bit_Custom453
NOP	
;__Lib_TFT_Defs.mbas,3667 :: 		else
L__TFT_Init_HX8347G_16bit_Custom452:
;__Lib_TFT_Defs.mbas,3668 :: 		TFT_Disp_Rotation = 90
ORI	R2, R0, 90
;__Lib_TFT_Defs.mbas,3669 :: 		end if
L__TFT_Init_HX8347G_16bit_Custom453:
;__Lib_TFT_Defs.mbas,3671 :: 		TFT_Set_Pen(CL_BLACK, 1)
ORI	R26, R0, 1
MOVZ	R25, R0, R0
JAL	_TFT_Set_Pen+0
NOP	
;__Lib_TFT_Defs.mbas,3672 :: 		TFT_Set_Brush(0, 0, 0, 0, 0, 0)
MOVZ	R28, R0, R0
MOVZ	R27, R0, R0
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
ADDIU	SP, SP, -4
SH	R0, 2(SP)
SH	R0, 0(SP)
NOP	
ADDIU	SP, SP, 4
;__Lib_TFT_Defs.mbas,3674 :: 		TFT_Move_Cursor(0, 0)
MOVZ	R26, R0, R0
MOVZ	R25, R0, R0
NOP	
;__Lib_TFT_Defs.mbas,3675 :: 		TFT_Clear_Fonts()
NOP	
;__Lib_TFT_Defs.mbas,3677 :: 		TFT_Reset_HX8347G()
NOP	
;__Lib_TFT_Defs.mbas,3678 :: 		TFT_Set_Address_Ptr = @TFT_Set_Address
;__Lib_TFT_Defs.mbas,3679 :: 		end sub
L_end_TFT_Init_HX8347G_16bit_Custom:
LW	R28, 16(SP)
LW	R27, 12(SP)
LW	R26, 8(SP)
LW	R25, 4(SP)
LW	RA, 0(SP)
ADDIU	SP, SP, 20
JR	RA
NOP	
; end of _TFT_Init_HX8347G_16bit_Custom
