<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="9.6.2">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="16" fill="1" visible="no" active="yes"/>
<layer number="3" name="Route3" color="17" fill="1" visible="no" active="yes"/>
<layer number="4" name="Route4" color="18" fill="1" visible="no" active="yes"/>
<layer number="5" name="Route5" color="19" fill="1" visible="no" active="yes"/>
<layer number="6" name="Route6" color="25" fill="1" visible="no" active="yes"/>
<layer number="7" name="Route7" color="26" fill="1" visible="no" active="yes"/>
<layer number="8" name="Route8" color="27" fill="1" visible="no" active="yes"/>
<layer number="9" name="Route9" color="28" fill="1" visible="no" active="yes"/>
<layer number="10" name="Route10" color="29" fill="1" visible="no" active="yes"/>
<layer number="11" name="Route11" color="30" fill="1" visible="no" active="yes"/>
<layer number="12" name="Route12" color="20" fill="1" visible="no" active="yes"/>
<layer number="13" name="Route13" color="21" fill="1" visible="no" active="yes"/>
<layer number="14" name="Route14" color="22" fill="1" visible="no" active="yes"/>
<layer number="15" name="Route15" color="23" fill="1" visible="no" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="24" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="88" name="SimResults" color="9" fill="1" visible="yes" active="yes"/>
<layer number="89" name="SimProbes" color="9" fill="1" visible="yes" active="yes"/>
<layer number="90" name="Modules" color="5" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
</layers>
<library>
<packages>
<package name="LR34">
<smd name="P$1" x="-4.5" y="-7.131" dx="2.27" dy="0.35" layer="1" rot="R90"/>
<smd name="P$2" x="-3.75" y="-7.131" dx="2.27" dy="0.35" layer="1" rot="R90"/>
<smd name="P$3" x="-3" y="-7.131" dx="2.27" dy="0.35" layer="1" rot="R90"/>
<smd name="P$4" x="-2.25" y="-7.131" dx="2.27" dy="0.35" layer="1" rot="R90"/>
<smd name="P$5" x="-1.5" y="-7.131" dx="2.27" dy="0.35" layer="1" rot="R90"/>
<smd name="P$6" x="-0.75" y="-7.131" dx="2.27" dy="0.35" layer="1" rot="R90"/>
<smd name="P$7" x="0" y="-7.131" dx="2.27" dy="0.35" layer="1" rot="R90"/>
<smd name="P$8" x="0.75" y="-7.131" dx="2.27" dy="0.35" layer="1" rot="R90"/>
<smd name="P$9" x="1.5" y="-7.131" dx="2.27" dy="0.35" layer="1" rot="R90"/>
<smd name="P$10" x="2.25" y="-7.131" dx="2.27" dy="0.35" layer="1" rot="R90"/>
<smd name="P$11" x="3" y="-7.131" dx="2.27" dy="0.35" layer="1" rot="R90"/>
<smd name="P$12" x="3.75" y="-7.131" dx="2.27" dy="0.35" layer="1" rot="R90"/>
<smd name="P$13" x="6.45" y="-4.481" dx="2.27" dy="0.35" layer="1" rot="R180"/>
<smd name="P$14" x="6.45" y="-3.731" dx="2.27" dy="0.35" layer="1" rot="R180"/>
<smd name="P$15" x="6.45" y="-2.981" dx="2.27" dy="0.35" layer="1" rot="R180"/>
<smd name="P$16" x="6.45" y="-2.231" dx="2.27" dy="0.35" layer="1" rot="R180"/>
<smd name="P$17" x="6.45" y="-1.481" dx="2.27" dy="0.35" layer="1" rot="R180"/>
<smd name="P$18" x="6.45" y="-0.731" dx="2.27" dy="0.35" layer="1" rot="R180"/>
<smd name="P$19" x="6.45" y="0.019" dx="2.27" dy="0.35" layer="1" rot="R180"/>
<smd name="P$20" x="6.45" y="0.769" dx="2.27" dy="0.35" layer="1" rot="R180"/>
<smd name="P$21" x="6.45" y="1.519" dx="2.27" dy="0.35" layer="1" rot="R180"/>
<smd name="P$22" x="6.45" y="2.269" dx="2.27" dy="0.35" layer="1" rot="R180"/>
<smd name="P$23" x="6.45" y="3.019" dx="2.27" dy="0.35" layer="1" rot="R180"/>
<smd name="P$24" x="6.45" y="3.769" dx="2.27" dy="0.35" layer="1" rot="R180"/>
<smd name="P$25" x="3.75" y="6.369" dx="2.27" dy="0.35" layer="1" rot="R270"/>
<smd name="P$26" x="3" y="6.369" dx="2.27" dy="0.35" layer="1" rot="R270"/>
<smd name="P$27" x="2.25" y="6.369" dx="2.27" dy="0.35" layer="1" rot="R270"/>
<smd name="P$28" x="1.5" y="6.369" dx="2.27" dy="0.35" layer="1" rot="R270"/>
<smd name="P$29" x="0.75" y="6.369" dx="2.27" dy="0.35" layer="1" rot="R270"/>
<smd name="P$30" x="0" y="6.369" dx="2.27" dy="0.35" layer="1" rot="R270"/>
<smd name="P$31" x="-0.75" y="6.369" dx="2.27" dy="0.35" layer="1" rot="R270"/>
<smd name="P$32" x="-1.5" y="6.369" dx="2.27" dy="0.35" layer="1" rot="R270"/>
<smd name="P$33" x="-2.25" y="6.369" dx="2.27" dy="0.35" layer="1" rot="R270"/>
<smd name="P$34" x="-3" y="6.369" dx="2.27" dy="0.35" layer="1" rot="R270"/>
<smd name="P$35" x="-3.75" y="6.369" dx="2.27" dy="0.35" layer="1" rot="R270"/>
<smd name="P$36" x="-4.5" y="6.369" dx="2.27" dy="0.35" layer="1" rot="R270"/>
<smd name="P$37" x="-7.26" y="3.749" dx="2.27" dy="0.35" layer="1"/>
<smd name="P$38" x="-7.26" y="2.999" dx="2.27" dy="0.35" layer="1"/>
<smd name="P$39" x="-7.26" y="2.249" dx="2.27" dy="0.35" layer="1"/>
<smd name="P$40" x="-7.26" y="1.499" dx="2.27" dy="0.35" layer="1"/>
<smd name="P$41" x="-7.26" y="0.749" dx="2.27" dy="0.35" layer="1"/>
<smd name="P$42" x="-7.26" y="-0.001" dx="2.27" dy="0.35" layer="1"/>
<smd name="P$43" x="-7.26" y="-0.751" dx="2.27" dy="0.35" layer="1"/>
<smd name="P$44" x="-7.26" y="-1.501" dx="2.27" dy="0.35" layer="1"/>
<smd name="P$45" x="-7.26" y="-2.251" dx="2.27" dy="0.35" layer="1"/>
<smd name="P$46" x="-7.26" y="-3.001" dx="2.27" dy="0.35" layer="1"/>
<smd name="P$47" x="-7.26" y="-3.751" dx="2.27" dy="0.35" layer="1"/>
<smd name="P$48" x="-7.26" y="-4.501" dx="2.27" dy="0.35" layer="1"/>
<circle x="-4.572" y="-4.699" radius="0.283978125" width="0.127" layer="21"/>
<wire x1="-5.334" y1="4.572" x2="4.572" y2="4.572" width="0.127" layer="21"/>
<wire x1="4.572" y1="4.572" x2="4.572" y2="-4.699" width="0.127" layer="21"/>
<wire x1="4.572" y1="-4.699" x2="3.81" y2="-5.461" width="0.127" layer="21"/>
<wire x1="3.81" y1="-5.461" x2="-5.334" y2="-5.461" width="0.127" layer="21"/>
<wire x1="-5.334" y1="-5.461" x2="-5.334" y2="4.572" width="0.127" layer="21"/>
</package>
</packages>
<symbols>
<symbol name="LR344">
</symbol>
</symbols>
<devicesets>
<deviceset name="LR34">
<gates>
</gates>
<devices>
<device name="" package="LR34">
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
