#include "PETCTL_cfg.h"
#define SPEED_MAX 20
#define DRIVER_STEP_TIME 2.5  // меняем задержку на 6 мкс
#include "GyverStepper.h"
GStepper<STEPPER2WIRE> stepper(200 * CFG_STEP_DIV, CFG_STEP_STEP_PIN, CFG_STEP_DIR_PIN, CFG_STEP_EN_PIN);
#include "GyverTimers.h"
#include <GyverOLED.h>
//#include "GyverOLED.h"
GyverOLED<SSH1106_128x64> oled;
#define CLK CFG_ENC_CLK
#define DT CFG_ENC_DT
#define SW CFG_ENC_SW
#include "GyverEncoder.h"
Encoder enc1(CLK, DT, SW);
int value = 0;
// Termistor definition
float prevTemp, curTemp = 0;
float targetTemp = CFG_TEMP_INIT;
float finalLength = 0;
#include "GyverPID.h"
GyverPID regulator(CFG_PID_P, CFG_PID_I, CFG_PID_D, 200);
boolean Heat = false;
//#define GEAR_RATIO ((float)CFG_RED_G1 * (float)CFG_RED_G2 * (float)CFG_RED_G3)
float GEAR_RATIO = 50;
Bobin round length
 74 * Pi = 232.478
 232.478 mm - bobin round length
#define BOBIN_ROUND_LENGTH ((float)3.1415926 * (float)CFG_BOBIN_DIAM)
const float REDCONST = BOBIN_ROUND_LENGTH /(360 * GEAR_RATIO * 1000);
boolean runMotor=false;
long SpeedX10 = (float)CFG_SPEED_INIT * 10;
/* Interactive statuses */
#define CHANGE_NO 0
#define CHANGE_TEMPERATURE 1
#define CHANGE_SPEED 2
int whatToChange = CHANGE_NO;
unsigned long interactive = millis();
/* Emergency stop reasons */
#define OVERHEAT 1
#define THERMISTOR_ERROR 2
void encRotationToValue (long* value, int inc = 1, long minValue = 0, long maxValue = 0);
void setup() {
initDisplay();
#if defined(SERIAL_DEBUG_TEMP) || defined(SERIAL_DEBUG_STEPPER) || defined(SERIAL_DEBUG_TEMP_PID)
  Serial.begin(9600);
#endif //SERIAL_DEBUG_TEMP || SERIAL_DEBUG_STEPPER
#if defined(SERIAL_DEBUG_STEPPER)
  Serial.print("Gear ratio: ");
  Serial.println(GEAR_RATIO);
  Serial.println("[deg/s],\t[step/s],\t[deg],\t[mm/s],\t[deg/s],\t[deg]");
#endif //SERIAL_DEBUG_STEPPER
#if defined(__LGT8F__)
  analogReadResolution(10);
#endif
  pinMode(CFG_ENDSTOP_PIN, INPUT_PULLUP);
  pinMode(CFG_EMENDSTOP_PIN, INPUT_PULLUP);
  pinMode(CFG_SOUND_PIN, OUTPUT);
  stepper.setRunMode(KEEP_SPEED);   // sebességtartó automatika üzemmód
#if defined(CFG_STEP_INVERT)
  stepper.reverse(true);            // fordított irány
#endif //CFG_STEP_INVERT
  stepper.autoPower(true);
  stepper.setAcceleration(300);
  stepper.setSpeedDeg(mmStoDeg((float)SPEED_MAX));
  stepper.getMinPeriod() / 2;
  stepper.brake();
  stepper.reset();                  
 //заставка
#if defined(CFG_SOUND_START)
  beepE();
#endif
  oled.setScale(3);
  oled.setCursor(13, 2);
  oled.println("PETCTL");
  oled.setScale(1);
  oled.setCursor(20, 7);
  oled.print("mvb   V 0.11");
  oled.update(); 
  delay(1000);
  oled.clear();
  oled.setScale(1);
  oled.setCursorXY(74,5);
  oled.println("*C");
  oled.setCursorXY(75,5+5+16);
  oled.println("mm/s");
  oled.setCursorXY(78,5+5+5+5+32);
  oled.println("m");
oled.update(); 
  enc1.setType(CFG_ENC_TYPE);
  enc1.setPinMode(LOW_PULL);
  regulator.setpoint = targetTemp;
  printSpeed(SpeedX10);
  printTargetTemp(targetTemp);
  printMilage(0.0);
void yield() {
  // egy mankó, minden esetre.
  stepper.tick();
void loop() {
    enc1.tick();
    stepper.tick();
    long newTargetTemp = targetTemp;
    long newSpeedX10 = SpeedX10;
    float rest;
    if (enc1.isDouble()) {
      whatToChange = CHANGE_SPEED;
      interactiveSet();
      printTargetTemp(targetTemp); // to clear selection
    if (enc1.isSingle()) {
      whatToChange = CHANGE_TEMPERATURE;
      interactiveSet();
      printSpeed(SpeedX10); // to clear selection
    if (!isInteractive()) {
    if( whatToChange == CHANGE_TEMPERATURE) {
      encRotationToValue(&newTargetTemp, 1, CFG_TEMP_MIN, CFG_TEMP_MAX - 10);
      if (enc1.isHolded()){
        Heat = ! Heat;
        printHeaterStatus(Heat);
      if (newTargetTemp != targetTemp) {
        targetTemp = newTargetTemp;
        regulator.setpoint = newTargetTemp;
        printTargetTemp(newTargetTemp);
    } else if (whatToChange == CHANGE_SPEED) {
      encRotationToValue(&newSpeedX10, 1, 0, SPEED_MAX * 10);
      if (enc1.isHolded()) {
        runMotor = ! runMotor;
        if (runMotor) {
          motorCTL(newSpeedX10);
        } else {
          motorCTL(-1);
          runMotor = false;
        interactiveSet();
      if (newSpeedX10 != SpeedX10) {
        SpeedX10 = newSpeedX10;
        if (runMotor) motorCTL(newSpeedX10);        // в градусах/сек
        printSpeed(newSpeedX10);
    if (runMotor) {
      printMilage(stepper.getCurrentDeg());
    curTemp = getTemp();
    stepper.tick();
    if (curTemp > CFG_TEMP_MAX - 10) emStop(OVERHEAT);
    if (curTemp < -10) emStop(THERMISTOR_ERROR);
    regulator.input = curTemp;
    if (curTemp != prevTemp) {
      prevTemp = curTemp;
      printCurrentTemp(curTemp);
    if (Heat) {
      int pidOut = (int) constrain(regulator.getResultTimer(), 0, 255);
      analogWrite(CFG_HEATER_PIN, pidOut);
      debugTemp(curTemp, pidOut);
    } else {
      analogWrite(CFG_HEATER_PIN, 0);
      debugTemp(curTemp, 0);
    oled.setCursorXY(90, 47);
    if(!digitalRead(CFG_ENDSTOP_PIN)) {
      if(!runMotor) {
        oled.setScale(2);
        oled.println("  *");
        //oled.update(); 
      } else {
        if (finalLength > 0){
          rest = finalLength - getMilage();
          if (rest >= 0) {
            oled.setScale(1);
            oled.setCursorXY(90, 55);
            oled.println(rest*100,1); // rest in cm
            oled.setScale(2);
           // oled.update(); 
          } else {
            runMotor = false;
            motorCTL(0);
            Heat = false;
            finalLength = 0;
            beepI();
        } else {
          finalLength = getMilage() + CFG_PULL_EXTRA_LENGTH;
    } else {
      oled.setScale(2);
      oled.println("   ");
     // oled.update(); 
      finalLength = 0;
    oled.setCursorXY(112, 24);
    //oled.update(); 
    if(!digitalRead(CFG_EMENDSTOP_PIN)) {
      if(!runMotor) {
        oled.setScale(2);
        oled.println("X");
        oled.update(); 
      } else {
        runMotor = false;
        motorCTL(-1);
        Heat = false;
        beepI();
        beepI();
    } else {
      oled.setScale(2);
      oled.println(" ");
      oled.update(); 
void debugTemp(float temp, int out) {
    static long debug_time;
    if (debug_time < millis() ) {
      debug_time = millis() + 200;
      Serial.print(temp);
#if defined(SERIAL_DEBUG_TEMP_PID)
      Serial.print(' ');
      Serial.print(out);
#endif // end SERIAL_DEBUG_TEMP_PID
      Serial.println(' ');
#endif //end SERIAL_DEBUG_TEMP
long mmStoDeg(float mmS) {
  return mmS / (REDCONST * 1000);
void beepE() {
  digitalWrite(CFG_SOUND_PIN, 1);
  delay(50);
  digitalWrite(CFG_SOUND_PIN, 0);
  delay(50);
void beepI() {
  beepE();
  beepE();
void beepT() {
  delay(600);
  delay(200);
void beepO() {
  beepT();
  beepT();
  beepT();
void emStop(int reason) {
  runMotor = false;
  motorCTL(-1);
  stepper.disable();
  Heat = false;
  oled.clear();
  oled.setScale(3);
  oled.setCursorXY(0,2);
  oled.println("*HALT!*");
  oled.setScale(2);
  oled.setCursorXY(3,40);
  oled.update(); 
  switch (reason) {
    case OVERHEAT:
      oled.println("Overheat");
      oled.update(); 
      break;
    case THERMISTOR_ERROR:
      oled.println("Thermistor");
      oled.update(); 
      break;
  for(;;){
    beepO();
    delay(60000);
float getMilage() {
  return stepper.getCurrentDeg() * REDCONST;
void motorCTL(long setSpeedX10) {
  Serial.print(stepper.getSpeedDeg());
  Serial.print(",\t");
  Serial.print(stepper.getSpeed());
  Serial.print(stepper.getCurrent());
#endif // SERIAL_DEBUG_STEPPER
  oled.setScale(2);
  oled.setCursorXY(0, 23);
 // oled.update(); 
  if (setSpeedX10 > 0) {
    stepper.setSpeedDeg(mmStoDeg((float)setSpeedX10/10), SMOOTH);        // [degree/sec]
    oled.println("*");
  } else if (setSpeedX10 == 0) {
    stepper.stop();
    oled.println(".");
    //oled.update(); 
  } else {
    stepper.brake();    
    oled.println(".");
   // oled.update(); 
  Serial.print((float)setSpeedX10/10);
  Serial.println(" ");
void printHeaterStatus(boolean status) {
  oled.setCursorXY(0, 0);
  //oled.update(); 
  if(status) 
    oled.println("*");
   // oled.update(); 
  else
    oled.println(".");
   // oled.update(); 
void encRotationToValue (long* value, int inc = 1, long minValue = 0, long maxValue = 0) {
      if (enc1.isRight()) { *value += inc; interactiveSet(); }     // если был поворот направо, увеличиваем на 1
      if (enc1.isFastR()) { *value += inc * 5; interactiveSet(); }    // если был быстрый поворот направо, увеличиваем на 10
      if (enc1.isLeft())  { *value -= inc; interactiveSet(); }     // если был поворот налево, уменьшаем на 1
      if (enc1.isFastL()) { *value -= inc * 5; interactiveSet(); }    // если был быстрый поворот налево, уменьшаем на на 10
      //if (minValue > 0 && *value < minValue) *value = minValue;
      if (*value < minValue) *value = minValue;
      //if (maxValue > 0 && *value > maxValue) *value = maxValue;
      if (*value > maxValue) *value = maxValue;
void printTargetTemp(float t){
      oled.setScale(2); 
     // oled.update();      
      if(whatToChange == CHANGE_TEMPERATURE)  oled.invertText(true);
      oled.setCursorXY(88, 0);
      oled.println((int)t, 1);  
      oled.invertText(false);
      //oled.update(); 
void printCurrentTemp(float t) {
      oled.setScale(2);      
      oled.setCursorXY(12, 0);
      oled.print(t, 1); 
      //oled.update();   
      if (t < 99.9) oled.print(" "); //oled.update();  //clean screen garbage
      if (t < 9.9) oled.print(" "); //oled.update(); 
void printSpeed(long s){
      // s -speed in mm/s * 10
      // // pint in mm/s
      oled.setScale(2);      
      oled.setCursorXY(12, 23);
      //oled.update(); 
      if(whatToChange == CHANGE_SPEED)  oled.invertText(true); 
      oled.print((float)s/10, 1);
      //oled.update(); 
      if (s<100) oled.print(" "); //fix display garbage 
     // oled.update(); 
void printMilage(float m){
      // m - current stepper position in degree
      // output to display in meters
      oled.setScale(2);
      oled.setCursorXY(12, 47);
      oled.println(m * REDCONST);  
     // oled.update(); 
void interactiveSet() {
  interactive = millis() + 15000;
void initDisplay()
  Wire.setClock(400000L);
  oled.init();  
  oled.clear();   
  oled.update(); 
boolean isInteractive() {
  return millis() < interactive;
float getTemp() {
  uint8_t i;
  float average;
  average = analogRead(CFG_TERM_PIN);
  // convert the value to resistance
  average = 1023 / average - 1;
  average = CFG_TERM_SERIAL_R / average;
  float steinhart;
  steinhart = average / CFG_TERM_VALUE;     // (R/Ro)
  steinhart = log(steinhart);                  // ln(R/Ro)
  steinhart /= CFG_TERM_B_COEFF;                   // 1/B * ln(R/Ro)
  steinhart += 1.0 / (CFG_TERM_VALUE_TEMP + 273.15); // + (1/To)
  steinhart = 1.0 / steinhart;                 // Invert
  steinhart -= 273.15;                         // convert absolute temp to C
  return simpleKalman(steinhart);
// Простой “Калман” 
// https://alexgyver.ru/lessons/filters/
float _err_measure = 0.8;  // примерный шум измерений
float _q = 0.02;   // скорость изменения значений 0.001-1, варьировать самому
float simpleKalman(float newVal) {
  float _kalman_gain, _current_estimate;
  static float _err_estimate = _err_measure;
  static float _last_estimate;
  _kalman_gain = (float)_err_estimate / (_err_estimate + _err_measure);
  _current_estimate = _last_estimate + (float)_kalman_gain * (newVal - _last_estimate);
  _err_estimate =  (1.0 - _kalman_gain) * _err_estimate + fabs(_last_estimate - _current_estimate) * _q;
  _last_estimate = _current_estimate;
  return _current_estimate;
