* generated by lcd-image-converter rev.030b30d from 2019-03-17 01:38:34 +0500
* image
* filename: unsaved
* name: Inverter
* preset name: Color R1G2B1_Color_RLE
* data block size: 8 bit(s), uint8_t
* RLE compression enabled: yes
* conversion type: Color, not_used not_used
* split to rows: no
* bits per pixel: 4
* preprocess:
*  main scan direction: top_to_bottom
*  line scan direction: forward
*  inverse: no
#include "Icons.h"
static const uint8_t image_data_Inverter[931] = {
    0x02, 0x00, 0x01, 0x01, 0x18, 0x11, 0x01, 0x10, 0x03, 0x00, 0x01, 0x01, 0x1a, 0x11, 0x01, 0x10, 0x02, 0x00, 0x01, 0x01, 0x1a, 0x11, 0x01, 0x10, 0x02, 0x00, 0x02, 0x11, 0x18, 0x00, 0xfa, 0x01, 0x11, 0x00, 0x01, 0x11, 0x01, 0x18, 0x11, 0xfc, 0x10, 0x11, 0x10, 0x01, 0x1c, 0x11, 0xfe, 0x10, 0x01, 0x1c, 0x11, 0x01, 0x10, 0x7f, 0x11, 0x5a, 0x11, 0x05, 0x01, 0xfe, 0x00, 0x10, 0x09, 0x00, 0x0d, 0x11, 0x01, 0x10, 0x05, 0x00, 0x01, 0x01, 0x04, 0x00, 0x02, 0x10, 0xfe, 0x11, 0x01, 0x0f, 0x11, 0xfd, 0x10, 0x00, 0x10, 0x03, 0x00, 0x01, 0x11, 0x08, 0x00, 0x02, 0x01, 0x0d, 0x11, 0x02, 0x10, 0x03, 0x00, 0xfe, 0x01, 0x11, 0x08, 0x00, 0xfe, 0x11, 0x10, 0x0d, 0x11, 0xfb, 0x10, 0x00, 0x10, 0x11, 0x01, 0x02, 0x11, 0x01, 0x10, 0x08, 0x11, 0x01, 0x10, 0x0d, 0x11, 0xfb, 0x10, 0x11, 0x01, 0x11, 0x10, 0x02, 0x01, 0x09, 0x11, 0x01, 0x00, 0x0d, 0x11, 0xfe, 0x10, 0x00, 0x02, 0x11, 0xfe, 0x10, 0x01, 0x04, 0x11, 0xf9, 0x10, 0x11, 0x10, 0x00, 0x10, 0x11, 0x00, 0x0d, 0x11, 0xfd, 0x10, 0x01, 0x10, 0x08, 0x11, 0xfd, 0x01, 0x11, 0x01, 0x02, 0x11, 0x01, 0x00, 0x0d, 0x11, 0x02, 0x10, 0xfe, 0x11, 0x01, 0x05, 0x11, 0x01, 0x10, 0x02, 0x01, 0x02, 0x11, 0xfd, 0x01, 0x11, 0x00, 0x0d, 0x11, 0x02, 0x10, 0x01, 0x01, 0x08, 0x11, 0xfa, 0x01, 0x11, 0x00, 0x11, 0x10, 0x00, 0x0d, 0x11, 0xfe, 0x10, 0x00, 0x07, 0x11, 0x01, 0x01, 0x05, 0x11, 0xfe, 0x10, 0x00, 0x0d, 0x11, 0x02, 0x10, 0x03, 0x11, 0x01, 0x01, 0x05, 0x11, 0x01, 0x01, 0x03, 0x11, 0xfe, 0x10, 0x00, 0x0d, 0x11, 0xfd, 0x10, 0x00, 0x10, 0x04, 0x11, 0x01, 0x10, 0x03, 0x11, 0x02, 0x00, 0x02, 0x10, 0x02, 0x00, 0x0d, 0x11, 0x02, 0x10, 0x09, 0x11, 0x01, 0x01, 0x04, 0x11, 0x01, 0x00, 0x0d, 0x11, 0xfe, 0x10, 0x00, 0x02, 0x11, 0xfd, 0x01, 0x11, 0x10, 0x04, 0x11, 0xfa, 0x01, 0x11, 0x01, 0x10, 0x11, 0x00, 0x0d, 0x11, 0xfe, 0x10, 0x00, 0x09, 0x11, 0xfe, 0x00, 0x01, 0x03, 0x11, 0x01, 0x00, 0x0d, 0x11, 0x02, 0x10, 0x09, 0x11, 0xfe, 0x01, 0x11, 0x02, 0x10, 0xfe, 0x01, 0x00, 0x0d, 0x11, 0xfe, 0x10, 0x00, 0x04, 0x11, 0x04, 0x01, 0x04, 0x11, 0x01, 0x01, 0x02, 0x00, 0x0d, 0x11, 0xfe, 0x10, 0x00, 0x0b, 0x11, 0x01, 0x01, 0x03, 0x00, 0x0d, 0x11, 0x02, 0x10, 0x0a, 0x11, 0x03, 0x10, 0x02, 0x00, 0x0d, 0x11, 0x01, 0x10, 0x03, 0x00, 0x02, 0x10, 0xfe, 0x11, 0x10, 0x02, 0x00, 0xfe, 0x11, 0x10, 0x05, 0x00, 0x0d, 0x11, 0x02, 0x10, 0x03, 0x00, 0x02, 0x11, 0x01, 0x10, 0x02, 0x00, 0x01, 0x01, 0x06, 0x00, 0x0d, 0x11, 0xfe, 0x10, 0x01, 0x1c, 0x11, 0x01, 0x10, 0x0c, 0x00, 0x03, 0x10, 0x0f, 0x11, 0x0a, 0x00, 0x02, 0x11, 0x01, 0x10, 0x03, 0x11, 0x01, 0x01, 0x0d, 0x11, 0x05, 0x00, 0xfe, 0x10, 0x01, 0x02, 0x00, 0xfd, 0x10, 0x00, 0x11, 0x03, 0x01, 0x0f, 0x11, 0x04, 0x00, 0xf9, 0x11, 0x00, 0x01, 0x10, 0x01, 0x11, 0x01, 0x04, 0x11, 0x01, 0x10, 0x0e, 0x11, 0x01, 0x10, 0x03, 0x00, 0xfe, 0x01, 0x10, 0x02, 0x11, 0xfc, 0x01, 0x11, 0x01, 0x11, 0x03, 0x01, 0x10, 0x11, 0x03, 0x00, 0xfe, 0x01, 0x10, 0x03, 0x00, 0xfe, 0x11, 0x01, 0x02, 0x11, 0x01, 0x01, 0x11, 0x11, 0x01, 0x10, 0x05, 0x00, 0xfe, 0x11, 0x00, 0x02, 0x10, 0xfc, 0x11, 0x01, 0x11, 0x01, 0x11, 0x11, 0xfe, 0x10, 0x00, 0x03, 0x01, 0x01, 0x00, 0x03, 0x01, 0xfd, 0x11, 0x10, 0x01, 0x14, 0x11, 0x02, 0x00, 0xfa, 0x01, 0x11, 0x01, 0x11, 0x10, 0x00, 0x19, 0x11, 0x02, 0x01, 0x7f, 0x11, 0x45, 0x11, 0xfe, 0x10, 0x11, 0x07, 0x10, 0xfd, 0x01, 0x00, 0x10, 0x0d, 0x00, 0x01, 0x01, 0x03, 0x11, 0xfd, 0x10, 0x00, 0x10, 0x10, 0x00, 0x04, 0x01, 0x03, 0x11, 0x01, 0x10, 0x03, 0x11, 0xfd, 0x10, 0x00, 0x11, 0x0e, 0x00, 0x04, 0x10, 0x02, 0x11, 0x01, 0x01, 0x02, 0x11, 0xfe, 0x10, 0x00, 0x02, 0x11, 0xfd, 0x10, 0x00, 0x10, 0x0c, 0x00, 0x05, 0x01, 0x02, 0x11, 0x01, 0x01, 0x03, 0x11, 0x01, 0x10, 0x03, 0x11, 0xfd, 0x10, 0x00, 0x11, 0x0d, 0x00, 0xfe, 0x01, 0x00, 0x03, 0x10, 0x05, 0x11, 0xfe, 0x10, 0x00, 0x02, 0x11, 0xfd, 0x10, 0x00, 0x10, 0x0b, 0x00, 0x04, 0x01, 0x01, 0x10, 0x03, 0x11, 0x01, 0x01, 0x03, 0x11, 0x01, 0x10, 0x03, 0x11, 0xfd, 0x10, 0x00, 0x11, 0x0d, 0x00, 0xfe, 0x01, 0x00, 0x03, 0x10, 0x05, 0x11, 0x02, 0x10, 0x02, 0x11, 0xfd, 0x10, 0x00, 0x10, 0x0b, 0x00, 0x04, 0x10, 0xfe, 0x11, 0x01, 0x06, 0x11, 0x02, 0x10, 0x02, 0x11, 0xfd, 0x10, 0x00, 0x10, 0x0c, 0x00, 0x07, 0x01, 0x04, 0x11, 0x02, 0x10, 0x02, 0x11, 0xfd, 0x10, 0x00, 0x10, 0x0a, 0x00, 0x04, 0x10, 0xfe, 0x11, 0x01, 0x07, 0x11, 0x02, 0x10, 0x02, 0x11, 0xfd, 0x10, 0x00, 0x11, 0x0b, 0x00, 0x01, 0x10, 0x04, 0x01, 0x01, 0x10, 0x06, 0x11, 0x02, 0x10, 0x02, 0x11, 0xfd, 0x10, 0x00, 0x10, 0x09, 0x00, 0x02, 0x01, 0xfd, 0x00, 0x11, 0x01, 0x09, 0x11, 0x02, 0x10, 0x02, 0x11, 0xfd, 0x10, 0x00, 0x10, 0x0b, 0x00, 0x05, 0x10, 0xfe, 0x11, 0x10, 0x05, 0x11, 0x02, 0x10, 0x02, 0x11, 0xfd, 0x10, 0x00, 0x11, 0x08, 0x00, 0x06, 0x01, 0x01, 0x10, 0x08, 0x11, 0x02, 0x10, 0x02, 0x11, 0xfd, 0x10, 0x00, 0x10, 0x09, 0x00, 0x05, 0x01, 0x09, 0x11, 0x02, 0x10, 0x02, 0x11, 0xfd, 0x10, 0x00, 0x10, 0x08, 0x00, 0x04, 0x10, 0x02, 0x11, 0x01, 0x10, 0x08, 0x11, 0x02, 0x10, 0x02, 0x11, 0x01, 0x10, 0x09, 0x00, 0x01, 0x10, 0x03, 0x01, 0xfe, 0x11, 0x10, 0x0a, 0x11, 0x02, 0x10, 0x02, 0x11, 0x01, 0x10, 0x14, 0x00, 0x01, 0x10, 0x04, 0x11, 0x02, 0x10, 0x02, 0x11, 0x01, 0x10, 0x06, 0x00, 0xfa, 0x10, 0x00, 0x01, 0x00, 0x01, 0x00, 0x02, 0x10, 0x04, 0x01, 0xfc, 0x11, 0x10, 0x11, 0x10, 0x03, 0x11, 0x02, 0x10, 0x02, 0x11, 0xfe, 0x10, 0x01, 0x18, 0x00, 0x04, 0x11, 0x01, 0x10, 0x09, 0x11, 0xf7, 0x10, 0x11, 0x10, 0x11, 0x10, 0x11, 0x10, 0x11, 0x01, 0x03, 0x11, 0xfb, 0x01, 0x11, 0x10, 0x00, 0x01, 0x02, 0x11, 0x01, 0x01, 0x03, 0x10, 0x18, 0x00, 0xfb, 0x01, 0x10, 0x01, 0x11, 0x00, 0x03, 0x10, 0x16, 0x00, 0xfb, 0x11, 0x10, 0x00, 0x11, 0x10, 0x18, 0x00, 0xfe, 0x01, 0x11, 0x02, 0x00, 0x1c, 0x11, 0x02, 0x00, 0x01, 0x01, 0x1a, 0x11, 0x01, 0x10, 0x03, 0x00, 0x01, 0x01, 0x18, 0x11, 0x01, 0x10, 0x02, 0x00
const tImage Inverter = { image_data_Inverter, 60, 80, 8 };
