<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.6.0">
<drawing>
<settings>
<setting alwaysvectorfont="yes"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.05" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.0125" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="yes" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="yes" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="yes" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="yes" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="yes" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="yes" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="yes" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="yes" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="yes" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="yes" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="yes" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="yes" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="50" name="dxf" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="53" name="tGND_GNDA" color="7" fill="9" visible="no" active="no"/>
<layer number="54" name="bGND_GNDA" color="1" fill="9" visible="no" active="no"/>
<layer number="56" name="wert" color="7" fill="1" visible="no" active="no"/>
<layer number="57" name="tCAD" color="7" fill="1" visible="no" active="no"/>
<layer number="59" name="tCarbon" color="7" fill="1" visible="no" active="no"/>
<layer number="60" name="bCarbon" color="7" fill="1" visible="no" active="no"/>
<layer number="90" name="Modules" color="7" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
<layer number="99" name="SpiceOrder" color="7" fill="1" visible="no" active="no"/>
<layer number="100" name="Muster" color="7" fill="1" visible="no" active="no"/>
<layer number="101" name="Patch_Top" color="12" fill="4" visible="yes" active="yes"/>
<layer number="102" name="Vscore" color="7" fill="1" visible="yes" active="yes"/>
<layer number="103" name="fp3" color="7" fill="1" visible="yes" active="yes"/>
<layer number="104" name="Name" color="7" fill="1" visible="yes" active="yes"/>
<layer number="105" name="Beschreib" color="9" fill="1" visible="yes" active="yes"/>
<layer number="106" name="BGA-Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="107" name="BD-Top" color="5" fill="1" visible="yes" active="yes"/>
<layer number="108" name="fp8" color="7" fill="1" visible="yes" active="yes"/>
<layer number="109" name="fp9" color="7" fill="1" visible="yes" active="yes"/>
<layer number="110" name="fp0" color="7" fill="1" visible="yes" active="yes"/>
<layer number="111" name="LPC17xx" color="7" fill="1" visible="yes" active="yes"/>
<layer number="112" name="tSilk" color="7" fill="1" visible="yes" active="yes"/>
<layer number="113" name="ReferenceLS" color="7" fill="1" visible="no" active="no"/>
<layer number="116" name="Patch_BOT" color="9" fill="4" visible="yes" active="yes"/>
<layer number="118" name="Rect_Pads" color="7" fill="1" visible="no" active="no"/>
<layer number="121" name="_tsilk" color="7" fill="1" visible="yes" active="yes"/>
<layer number="122" name="_bsilk" color="7" fill="1" visible="yes" active="yes"/>
<layer number="123" name="tTestmark" color="7" fill="1" visible="yes" active="yes"/>
<layer number="124" name="bTestmark" color="7" fill="1" visible="yes" active="yes"/>
<layer number="125" name="_tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="126" name="_bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="127" name="_tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="128" name="_bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="129" name="Mask" color="7" fill="1" visible="yes" active="yes"/>
<layer number="131" name="tAdjust" color="7" fill="1" visible="yes" active="yes"/>
<layer number="132" name="bAdjust" color="7" fill="1" visible="yes" active="yes"/>
<layer number="144" name="Drill_legend" color="7" fill="1" visible="yes" active="yes"/>
<layer number="150" name="Notes" color="7" fill="1" visible="yes" active="yes"/>
<layer number="151" name="HeatSink" color="7" fill="1" visible="yes" active="yes"/>
<layer number="152" name="_bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="153" name="FabDoc1" color="6" fill="1" visible="no" active="no"/>
<layer number="154" name="FabDoc2" color="2" fill="1" visible="no" active="no"/>
<layer number="155" name="FabDoc3" color="7" fill="15" visible="no" active="no"/>
<layer number="199" name="Contour" color="7" fill="1" visible="yes" active="yes"/>
<layer number="200" name="200bmp" color="1" fill="10" visible="yes" active="yes"/>
<layer number="201" name="201bmp" color="2" fill="1" visible="no" active="no"/>
<layer number="202" name="202bmp" color="3" fill="1" visible="no" active="no"/>
<layer number="203" name="203bmp" color="4" fill="10" visible="yes" active="yes"/>
<layer number="204" name="204bmp" color="5" fill="10" visible="yes" active="yes"/>
<layer number="205" name="205bmp" color="6" fill="10" visible="yes" active="yes"/>
<layer number="206" name="206bmp" color="7" fill="10" visible="yes" active="yes"/>
<layer number="207" name="207bmp" color="8" fill="10" visible="yes" active="yes"/>
<layer number="208" name="208bmp" color="9" fill="10" visible="yes" active="yes"/>
<layer number="209" name="209bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="210" name="210bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="211" name="211bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="212" name="212bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="213" name="213bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="214" name="214bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="215" name="215bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="216" name="216bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="217" name="217bmp" color="18" fill="1" visible="no" active="no"/>
<layer number="218" name="218bmp" color="19" fill="1" visible="no" active="no"/>
<layer number="219" name="219bmp" color="20" fill="1" visible="no" active="no"/>
<layer number="220" name="220bmp" color="21" fill="1" visible="no" active="no"/>
<layer number="221" name="221bmp" color="22" fill="1" visible="no" active="no"/>
<layer number="222" name="222bmp" color="23" fill="1" visible="no" active="no"/>
<layer number="223" name="223bmp" color="24" fill="1" visible="no" active="no"/>
<layer number="224" name="224bmp" color="25" fill="1" visible="no" active="no"/>
<layer number="225" name="225bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="226" name="226bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="227" name="227bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="228" name="228bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="229" name="229bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="230" name="230bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="231" name="Eagle3D_PG1" color="7" fill="1" visible="no" active="no"/>
<layer number="232" name="Eagle3D_PG2" color="7" fill="1" visible="no" active="no"/>
<layer number="233" name="Eagle3D_PG3" color="7" fill="1" visible="no" active="no"/>
<layer number="248" name="Housing" color="7" fill="1" visible="yes" active="yes"/>
<layer number="249" name="Edge" color="7" fill="1" visible="yes" active="yes"/>
<layer number="250" name="Descript" color="7" fill="1" visible="no" active="no"/>
<layer number="251" name="SMDround" color="7" fill="1" visible="no" active="no"/>
<layer number="254" name="cooling" color="7" fill="1" visible="yes" active="yes"/>
<layer number="255" name="routoute" color="7" fill="1" visible="yes" active="yes"/>
</layers>
<board>
<plain>
<text x="29.21" y="5.08" size="1.27" layer="21" font="vector">Galdurino V0.1
(c)2017
Matthias Heinrichs</text>
<text x="2.54" y="49.53" size="1.27" layer="1" font="vector" ratio="20">TOP</text>
<text x="6.0325" y="49.53" size="1.27" layer="16" font="vector" ratio="20" rot="MR0">BOT</text>
</plain>
<libraries>
<library name="adafruit">
<packages>
<package name="ARDUINO">
<description>&lt;b&gt;Arduino Uno&lt;/b&gt;
&lt;p&gt;
Make a shield with ease, this package has all the named pins as well as the two mounting drill holes and an outline of the USB and DC power connector. The outline is on the DIMENSION layer, so if your board house uses it they will cut the outline to match.</description>
<wire x1="0" y1="0" x2="66.04" y2="0" width="0" layer="20"/>
<wire x1="66.04" y1="0" x2="66.04" y2="2.54" width="0" layer="20"/>
<wire x1="66.04" y1="2.54" x2="68.58" y2="5.08" width="0" layer="20"/>
<wire x1="68.58" y1="5.08" x2="68.58" y2="37.846" width="0" layer="20"/>
<wire x1="68.58" y1="37.846" x2="66.04" y2="40.386" width="0" layer="20"/>
<wire x1="66.04" y1="40.386" x2="66.04" y2="51.816" width="0" layer="20"/>
<wire x1="66.04" y1="51.816" x2="64.516" y2="53.34" width="0" layer="20"/>
<wire x1="64.516" y1="53.34" x2="0" y2="53.34" width="0" layer="20"/>
<wire x1="9.144" y1="31.75" x2="9.144" y2="44.45" width="0" layer="52"/>
<wire x1="9.144" y1="44.45" x2="-6.604" y2="44.45" width="0" layer="52"/>
<wire x1="-6.604" y1="44.45" x2="-6.604" y2="31.75" width="0" layer="52"/>
<wire x1="-6.604" y1="31.75" x2="9.144" y2="31.75" width="0" layer="52"/>
<wire x1="0" y1="53.34" x2="0" y2="0" width="0" layer="20"/>
<wire x1="-1.778" y1="3.81" x2="12.192" y2="3.81" width="0" layer="52"/>
<wire x1="12.192" y1="3.81" x2="12.192" y2="12.7" width="0" layer="52"/>
<wire x1="12.192" y1="12.7" x2="-1.778" y2="12.7" width="0" layer="52"/>
<wire x1="-1.778" y1="12.7" x2="-1.778" y2="3.81" width="0" layer="52"/>
<pad name="D4" x="53.34" y="50.8" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="A0" x="50.8" y="2.54" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="D3" x="55.88" y="50.8" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="D2" x="58.42" y="50.8" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="D1" x="60.96" y="50.8" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="D0" x="63.5" y="50.8" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="D5" x="50.8" y="50.8" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="D6" x="48.26" y="50.8" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="D7" x="45.72" y="50.8" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="D8" x="41.656" y="50.8" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="D9" x="39.116" y="50.8" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="D10" x="36.576" y="50.8" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="D11" x="34.036" y="50.8" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="D12" x="31.496" y="50.8" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="D13" x="28.956" y="50.8" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="GND" x="26.416" y="50.8" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="AREF" x="23.876" y="50.8" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="A1" x="53.34" y="2.54" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="A2" x="55.88" y="2.54" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="A3" x="58.42" y="2.54" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="A4" x="60.96" y="2.54" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="A5" x="63.5" y="2.54" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="VIN" x="45.72" y="2.54" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="GND1" x="43.18" y="2.54" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="GND2" x="40.64" y="2.54" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="5V" x="38.1" y="2.54" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="3V" x="35.56" y="2.54" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="RESET" x="33.02" y="2.54" drill="1" diameter="1.6764" shape="octagon"/>
<text x="31.2319" y="3.81" size="1.016" layer="21" font="vector">RST</text>
<text x="34.7523" y="3.81" size="1.016" layer="21" font="vector">3v</text>
<text x="37.5463" y="3.81" size="1.016" layer="21" font="vector">5v</text>
<text x="40.7771" y="3.81" size="1.016" layer="21" font="vector">Gnd</text>
<text x="44.7853" y="3.81" size="1.016" layer="21" font="vector">Vin</text>
<text x="54.1121" y="0.4623" size="1.016" layer="21" font="vector">Analog In</text>
<text x="50.419" y="3.81" size="1.016" layer="21" font="vector">0</text>
<text x="52.959" y="3.81" size="1.016" layer="21" font="vector">1</text>
<text x="55.499" y="3.81" size="1.016" layer="21" font="vector">2</text>
<text x="58.039" y="3.81" size="1.016" layer="21" font="vector">3</text>
<text x="60.579" y="3.81" size="1.016" layer="21" font="vector">4</text>
<text x="63.119" y="3.81" size="1.016" layer="21" font="vector">5</text>
<text x="24.765" y="49.53" size="1.016" layer="21" font="vector" rot="R180">ARef</text>
<text x="27.94" y="49.53" size="1.016" layer="21" font="vector" rot="R180">gnd</text>
<text x="30.099" y="49.53" size="1.016" layer="21" font="vector" rot="R180">13</text>
<text x="32.639" y="49.53" size="1.016" layer="21" font="vector" rot="R180">12</text>
<text x="35.179" y="49.53" size="1.016" layer="21" font="vector" rot="R180">11</text>
<text x="37.719" y="49.53" size="1.016" layer="21" font="vector" rot="R180">10</text>
<text x="39.751" y="49.53" size="1.016" layer="21" font="vector" rot="R180">9</text>
<text x="42.291" y="49.53" size="1.016" layer="21" font="vector" rot="R180">8</text>
<text x="46.355" y="49.53" size="1.016" layer="21" font="vector" rot="R180">7</text>
<text x="48.895" y="49.53" size="1.016" layer="21" font="vector" rot="R180">6</text>
<text x="51.435" y="49.53" size="1.016" layer="21" font="vector" rot="R180">5</text>
<text x="53.975" y="49.53" size="1.016" layer="21" font="vector" rot="R180">4</text>
<text x="56.515" y="49.53" size="1.016" layer="21" font="vector" rot="R180">3</text>
<text x="59.055" y="49.53" size="1.016" layer="21" font="vector" rot="R180">2</text>
<text x="61.595" y="49.53" size="1.016" layer="21" font="vector" rot="R180">1</text>
<text x="64.135" y="49.53" size="1.016" layer="21" font="vector" rot="R180">0</text>
<text x="31.623" y="52.07" size="1.016" layer="21" font="vector">Digital I/O</text>
<text x="50.927" y="52.07" size="1.016" layer="21" font="vector">Digital I/O</text>
<hole x="15.24" y="50.8" drill="3.2"/>
<hole x="66.04" y="35.56" drill="3.2"/>
<hole x="13.97" y="2.54" drill="3.2"/>
</package>
</packages>
</library>
<library name="74xx-eu">
<description>&lt;b&gt;TTL Devices, 74xx Series with European Symbols&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Texas Instruments &lt;i&gt;TTL Data Book&lt;/i&gt;&amp;nbsp;&amp;nbsp;&amp;nbsp;Volume 1, 1996.
&lt;li&gt;TTL Data Book, Volume 2 , 1993
&lt;li&gt;National Seminconductor Databook 1990, ALS/LS Logic
&lt;li&gt;ttl 74er digital data dictionary, ECA Electronic + Acustic GmbH, ISBN 3-88109-032-0
&lt;li&gt;http://icmaster.com/ViewCompare.asp
&lt;/ul&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="DIL14">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="8.89" y1="2.921" x2="-8.89" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-2.921" x2="8.89" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="8.89" y1="2.921" x2="8.89" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.921" x2="-8.89" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-2.921" x2="-8.89" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="1.016" x2="-8.89" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="0" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="0" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="-2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="-5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="-7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-9.271" y="-3.048" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-6.731" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="rcl">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
http://www.secc.co.jp/pdf/os_e/2004/e_os_all.pdf &lt;b&gt;(SANYO)&lt;/b&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0&gt;
&lt;tr valign="top"&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;</description>
<packages>
<package name="C025-025X050">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 2.5 mm, outline 2.5 x 5 mm</description>
<wire x1="-2.159" y1="1.27" x2="2.159" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.27" x2="-2.159" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.27" x2="2.413" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.016" x2="-2.159" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.27" x2="2.413" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.016" x2="-2.159" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="0.762" y1="0" x2="0.381" y2="0" width="0.1524" layer="51"/>
<wire x1="0.381" y1="0" x2="0.254" y2="0" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="0.762" width="0.254" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0.762" x2="-0.254" y2="0" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.381" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.286" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2,5-7">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 2.54 mm, diameter 7 mm</description>
<wire x1="-3.048" y1="0" x2="-2.286" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="-0.381" x2="-2.667" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.762" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="3.429" width="0.1524" layer="21"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.6002"/>
<text x="3.048" y="2.032" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.048" y="-3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="E2,5-5">
grid 2.54 mm, diameter 5 mm</description>
<wire x1="-1.651" y1="1.27" x2="-1.397" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.016" x2="-1.397" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.27" x2="-1.143" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.27" x2="-1.397" y2="1.524" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.54" width="0.1524" layer="21"/>
<text x="2.413" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.413" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0207/2V">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
type 0207, grid 2.5 mm</description>
<wire x1="-1.27" y1="0" x2="-0.381" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.254" y1="0" x2="0.254" y2="0" width="0.6096" layer="21"/>
<wire x1="0.381" y1="0" x2="1.27" y2="0" width="0.6096" layer="51"/>
<circle x="-1.27" y="0" radius="1.27" width="0.1524" layer="21"/>
<circle x="-1.27" y="0" radius="1.016" width="0.1524" layer="51"/>
<text x="-0.0508" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.0508" y="-2.2352" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RM7D12_5">
<pad name="P$1" x="3.5" y="0" drill="1"/>
<pad name="P$2" x="-3.5" y="0" drill="1"/>
<circle x="0" y="0" radius="8.514690625" width="0.127" layer="21"/>
<text x="-3" y="9" size="1.27" layer="25">&gt;NAME</text>
<text x="-4" y="-11" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="transistor-small-signal">
<description>&lt;b&gt;Small Signal Transistors&lt;/b&gt;&lt;p&gt;
Packages from :&lt;br&gt;
www.infineon.com; &lt;br&gt;
www.semiconductors.com;&lt;br&gt;
www.irf.com&lt;p&gt;
<packages>
<package name="SOT54E">
<description>&lt;b&gt;SOT-54&lt;/b&gt;&lt;p&gt;
grid 2.54 mm</description>
<wire x1="-0.9692" y1="2.2098" x2="0.9692" y2="2.2098" width="0.1524" layer="51" curve="-47.3637"/>
<wire x1="-1.631" y1="-1.778" x2="-0.9689" y2="2.2098" width="0.1524" layer="21" curve="-113.782"/>
<wire x1="0.9689" y1="2.2098" x2="1.631" y2="-1.778" width="0.1524" layer="21" curve="-113.782"/>
<wire x1="-1.631" y1="-1.778" x2="1.631" y2="-1.778" width="0.1524" layer="21"/>
<pad name="D" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="G" x="0" y="1.905" drill="0.8128" shape="octagon"/>
<pad name="S" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="3.175" y="-1.905" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="3.175" y="0" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
</packages>
</library>
<library name="resistor-net">
<description>&lt;b&gt;Generic Resistor Networks&lt;/b&gt;&lt;p&gt;
<packages>
<package name="RN-10">
<description>&lt;b&gt;RESISTOR NETWORK&lt;/b&gt;</description>
<wire x1="12.7" y1="-1.27" x2="12.7" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="1.27" x2="-12.7" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="-1.27" x2="-12.065" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="1.27" x2="-12.065" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="1.27" x2="-10.795" y2="0.635" width="0.1524" layer="21"/>
<wire x1="12.7" y1="1.27" x2="-10.16" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-1.27" x2="-10.795" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="-1.27" x2="-10.16" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="1.27" x2="-10.16" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="1.27" x2="-12.7" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-1.27" x2="12.7" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-12.0396" y1="0.6096" x2="-10.8204" y2="-0.6096" width="0.1524" layer="51"/>
<wire x1="-12.0396" y1="-0.6096" x2="-10.8204" y2="0.6096" width="0.1524" layer="51"/>
<pad name="1" x="-11.43" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-8.89" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-6.35" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-3.81" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-1.27" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="1.27" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="3.81" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="6.35" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="8.89" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="11.43" y="0" drill="0.8128" shape="long" rot="R90"/>
<text x="-10.16" y="-3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-10.16" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
</packages>
</library>
<library name="microchip">
<description>&lt;b&gt;Microchip PIC Microcontrollers and other Devices&lt;/b&gt;&lt;p&gt;
Based on the following sources :
&lt;ul&gt;
&lt;li&gt;Microchip Data Book, 1993
&lt;li&gt;THE EMERGING WORLD STANDARD, 1995/1996
&lt;li&gt;Microchip, Technical Library CD-ROM, June 1998
&lt;li&gt;www.microchip.com
&lt;/ul&gt;
<packages>
<package name="DIL8">
<description>&lt;B&gt;Dual In Line&lt;/B&gt;&lt;p&gt;
package type P</description>
<wire x1="-5.08" y1="-0.635" x2="-5.08" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="-5.08" y2="0.635" width="0.1524" layer="21" curve="180"/>
<wire x1="5.08" y1="-2.54" x2="-5.08" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-2.54" x2="5.08" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.54" x2="5.08" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.54" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90" first="yes"/>
<pad name="2" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-5.2578" y="-2.54" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="7.239" y="-2.54" size="1.778" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="pal">
<description>&lt;b&gt;PALs&lt;/b&gt;&lt;p&gt;
<packages>
<package name="DIL20">
<wire x1="12.7" y1="2.921" x2="-12.7" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="-2.921" x2="12.7" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="12.7" y1="2.921" x2="12.7" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="2.921" x2="-12.7" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="-2.921" x2="-12.7" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="1.016" x2="-12.7" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="-6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="-8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="-11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-13.081" y="-3.048" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="-9.779" y="-0.381" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="DIL24-3">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt; 0.3 inch</description>
<wire x1="-14.986" y1="-0.635" x2="-14.986" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-14.986" y1="0.635" x2="-14.986" y2="-0.635" width="0.1524" layer="21" curve="-180"/>
<wire x1="14.986" y1="-2.794" x2="14.986" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-14.986" y1="-2.794" x2="14.986" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-14.986" y1="2.794" x2="14.986" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-14.986" y1="2.794" x2="-14.986" y2="0.635" width="0.1524" layer="21"/>
<pad name="1" x="-13.97" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="13.97" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="13.97" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="-6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="-11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="-13.97" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-15.2908" y="-2.667" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-13.462" y="-0.889" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="ON Semiconductor_By_element14_Batch_1">
<description>Developed by element14 :&lt;br&gt;
element14 CAD Library consolidation.ulp
at 30/07/2012 14:34:29</description>
<packages>
<package name="DIP254P762X533-8">
<pad name="1" x="-7.62" y="7.62" drill="1.1176" shape="square"/>
<pad name="2" x="-7.62" y="5.08" drill="1.1176"/>
<pad name="3" x="-7.62" y="2.54" drill="1.1176"/>
<pad name="4" x="-7.62" y="0" drill="1.1176"/>
<pad name="5" x="0" y="0" drill="1.1176"/>
<pad name="6" x="0" y="2.54" drill="1.1176"/>
<pad name="7" x="0" y="5.08" drill="1.1176"/>
<pad name="8" x="0" y="7.62" drill="1.1176"/>
<wire x1="-7.2898" y1="-1.27" x2="-0.3302" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.3302" y1="8.89" x2="-3.5052" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-3.5052" y1="8.89" x2="-4.1148" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-4.1148" y1="8.89" x2="-6.477" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-3.5052" y1="8.89" x2="-4.1148" y2="8.89" width="0.1524" layer="21" curve="-180"/>
<text x="-8.2042" y="8.7376" size="1.27" layer="21" ratio="6" rot="SR0">*</text>
<wire x1="-7.366" y1="7.0612" x2="-7.366" y2="8.1788" width="0" layer="51"/>
<wire x1="-7.366" y1="8.1788" x2="-8.1788" y2="8.1788" width="0" layer="51"/>
<wire x1="-8.1788" y1="8.1788" x2="-8.1788" y2="7.0612" width="0" layer="51"/>
<wire x1="-8.1788" y1="7.0612" x2="-7.366" y2="7.0612" width="0" layer="51"/>
<wire x1="-7.366" y1="4.5212" x2="-7.366" y2="5.6388" width="0" layer="51"/>
<wire x1="-7.366" y1="5.6388" x2="-8.1788" y2="5.6388" width="0" layer="51"/>
<wire x1="-8.1788" y1="5.6388" x2="-8.1788" y2="4.5212" width="0" layer="51"/>
<wire x1="-8.1788" y1="4.5212" x2="-7.366" y2="4.5212" width="0" layer="51"/>
<wire x1="-7.366" y1="1.9812" x2="-7.366" y2="3.0988" width="0" layer="51"/>
<wire x1="-7.366" y1="3.0988" x2="-8.1788" y2="3.0988" width="0" layer="51"/>
<wire x1="-8.1788" y1="3.0988" x2="-8.1788" y2="1.9812" width="0" layer="51"/>
<wire x1="-8.1788" y1="1.9812" x2="-7.366" y2="1.9812" width="0" layer="51"/>
<wire x1="-7.366" y1="-0.5588" x2="-7.366" y2="0.5588" width="0" layer="51"/>
<wire x1="-7.366" y1="0.5588" x2="-8.1788" y2="0.5588" width="0" layer="51"/>
<wire x1="-8.1788" y1="0.5588" x2="-8.1788" y2="-0.5588" width="0" layer="51"/>
<wire x1="-8.1788" y1="-0.5588" x2="-7.366" y2="-0.5588" width="0" layer="51"/>
<wire x1="-0.254" y1="0.5588" x2="-0.254" y2="-0.5588" width="0" layer="51"/>
<wire x1="-0.254" y1="-0.5588" x2="0.5588" y2="-0.5588" width="0" layer="51"/>
<wire x1="0.5588" y1="-0.5588" x2="0.5588" y2="0.5588" width="0" layer="51"/>
<wire x1="0.5588" y1="0.5588" x2="-0.254" y2="0.5588" width="0" layer="51"/>
<wire x1="-0.254" y1="3.0988" x2="-0.254" y2="1.9812" width="0" layer="51"/>
<wire x1="-0.254" y1="1.9812" x2="0.5588" y2="1.9812" width="0" layer="51"/>
<wire x1="0.5588" y1="1.9812" x2="0.5588" y2="3.0988" width="0" layer="51"/>
<wire x1="0.5588" y1="3.0988" x2="-0.254" y2="3.0988" width="0" layer="51"/>
<wire x1="-0.254" y1="5.6388" x2="-0.254" y2="4.5212" width="0" layer="51"/>
<wire x1="-0.254" y1="4.5212" x2="0.5588" y2="4.5212" width="0" layer="51"/>
<wire x1="0.5588" y1="4.5212" x2="0.5588" y2="5.6388" width="0" layer="51"/>
<wire x1="0.5588" y1="5.6388" x2="-0.254" y2="5.6388" width="0" layer="51"/>
<wire x1="-0.254" y1="8.1788" x2="-0.254" y2="7.0612" width="0" layer="51"/>
<wire x1="-0.254" y1="7.0612" x2="0.5588" y2="7.0612" width="0" layer="51"/>
<wire x1="0.5588" y1="7.0612" x2="0.5588" y2="8.1788" width="0" layer="51"/>
<wire x1="0.5588" y1="8.1788" x2="-0.254" y2="8.1788" width="0" layer="51"/>
<wire x1="-7.366" y1="-1.27" x2="-0.254" y2="-1.27" width="0" layer="51"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="8.89" width="0" layer="51"/>
<wire x1="-0.254" y1="8.89" x2="-3.5052" y2="8.89" width="0" layer="51"/>
<wire x1="-3.5052" y1="8.89" x2="-4.1148" y2="8.89" width="0" layer="51"/>
<wire x1="-4.1148" y1="8.89" x2="-7.366" y2="8.89" width="0" layer="51"/>
<wire x1="-7.366" y1="8.89" x2="-7.366" y2="-1.27" width="0" layer="51"/>
<wire x1="-3.5052" y1="8.89" x2="-4.1148" y2="8.89" width="0" layer="51" curve="-180"/>
<text x="-8.2042" y="8.7376" size="1.27" layer="51" ratio="6" rot="SR0">*</text>
<text x="-8.5344" y="10.795" size="2.0828" layer="25" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-7.2644" y="-5.08" size="2.0828" layer="27" ratio="10" rot="SR0">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="diode">
<description>&lt;b&gt;Diodes&lt;/b&gt;&lt;p&gt;
&lt;ul&gt;
&lt;li&gt;Motorola : www.onsemi.com
&lt;li&gt;Fairchild : www.fairchildsemi.com
&lt;li&gt;Philips : www.semiconductors.com
&lt;li&gt;Vishay : www.vishay.de
&lt;/ul&gt;
<packages>
<package name="DO41-7.6">
<description>&lt;b&gt;DO41&lt;/b&gt; 7.6mm x 2mm&lt;p&gt;
Source: http://www.diodes.com/datasheets/ds23001.pdf</description>
<wire x1="2.082" y1="-0.92" x2="-2.082" y2="-0.92" width="0.1524" layer="21"/>
<wire x1="2.082" y1="-0.92" x2="2.082" y2="0.92" width="0.1524" layer="21"/>
<wire x1="-2.082" y1="0.92" x2="2.082" y2="0.92" width="0.1524" layer="21"/>
<wire x1="-2.082" y1="0.92" x2="-2.082" y2="-0.92" width="0.1524" layer="21"/>
<wire x1="3.81" y1="0" x2="2.494" y2="0" width="0.85" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.519" y2="0" width="0.85" layer="51"/>
<wire x1="-0.635" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.635" x2="1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<pad name="C" x="-3.81" y="0" drill="1.1" diameter="1.7"/>
<pad name="A" x="3.81" y="0" drill="1.1" diameter="1.7"/>
<text x="-2.032" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-0.95" x2="-1.143" y2="0.92" layer="21"/>
<rectangle x1="2.082" y1="-0.425" x2="2.717" y2="0.425" layer="21"/>
<rectangle x1="-2.717" y1="-0.425" x2="-2.082" y2="0.425" layer="21"/>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules name="Eagle-DRU - 1203 - LeitOn - 01 and 02 layers *">
<description language="de">&lt;b&gt;LeitOn Design-Regeln&lt;/b&gt;
&lt;p&gt;
Diese DRU-Datei enthält viele erforderliche Design Einstellungen, damit Ihre Standardleiterplatte bei uns fehlerfrei und ohne Zusatzkosten produziert werden kann. Die Optionen Shapes und Misc sind nicht relevant und der minimale und maximale Wert für Roundness Shapes kann frei gewählt werden. Nach unten abweichende Design-Regeln sind möglich, können jedoch Aufpreise erfordern. Hinweis: Freistellungen und Streichstärken von Bestückungsdruck werden nicht im Eagle-DRC geprüft!
&lt;br&gt;&lt;br&gt;
&lt;b&gt;Übersicht der LeitOn Regeln:&lt;/b&lt;&lt;br&gt;&lt;br&gt;
&lt;u&gt;allgemein:&lt;/u&gt;&lt;br&gt;
minimale Leiterbahnbreite/-abstand: &lt;b&gt;0.15 mm&lt;/b&gt;&lt;br&gt;
(Strichstärke für Kupferschrift sollte mind. 0.2 mm sein um gut lesbar zu bleiben)&lt;br&gt;
kleinster Bohrdurchmesser: &lt;b&gt;0.3 mm&lt;/b&gt;&lt;br&gt;&lt;br&gt;
&lt;u&gt;Kupferrestringe um DK-Bohrungen:&lt;/u&gt;&lt;br&gt;
Aussenlagen: &lt;b&gt;0.15 mm&lt;/b&gt;&lt;br&gt;
Innenlagen:  &lt;b&gt;0.2 mm&lt;/b&gt;&lt;br&gt;
&lt;br&gt;
&lt;u&gt;Masselagen-Freimachungen:&lt;/u&gt;&lt;br&gt;
Innenlagen: &lt;b&gt;0.35 mm&lt;/b&gt;&lt;br&gt;
&lt;br&gt;
&lt;u&gt;Bestückungsdruck (wird nicht im DRU überprüft!)&lt;/u&gt;&lt;br&gt;
minimale Strichstärke: &lt;b&gt;0.2 mm&lt;/b&gt;&lt;br&gt;&lt;br&gt;
&lt;b&gt;&lt;u&gt;&lt;font color= &quot;blue&quot;&gt;Wichtig:&lt;/font&gt;&lt;/b&gt;&lt;/u&gt; Verwenden Sie als Strichstärke für Masseflächen keine Strichstärken kleiner 0.1mm. Es entstehen sonst extrem große Datenmengen, weil Eagle die Massefläche stets mit Polygonen der gleichen Strichstärke füllt.
&lt;/p&gt;</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.71mm 0.36mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.36mm"/>
<param name="mdWireWire" value="6mil"/>
<param name="mdWirePad" value="6mil"/>
<param name="mdWireVia" value="6mil"/>
<param name="mdPadPad" value="6mil"/>
<param name="mdPadVia" value="6mil"/>
<param name="mdViaVia" value="6mil"/>
<param name="mdSmdPad" value="6mil"/>
<param name="mdSmdVia" value="6mil"/>
<param name="mdSmdSmd" value="6mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="20mil"/>
<param name="mdDrill" value="10mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="6mil"/>
<param name="msDrill" value="0.3mm"/>
<param name="msMicroVia" value="999mil"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0"/>
<param name="rvPadInner" value="0"/>
<param name="rvPadBottom" value="0"/>
<param name="rvViaOuter" value="0"/>
<param name="rvViaInner" value="0"/>
<param name="rvMicroViaOuter" value="0"/>
<param name="rvMicroViaInner" value="0"/>
<param name="rlMinPadTop" value="8mil"/>
<param name="rlMaxPadTop" value="100mil"/>
<param name="rlMinPadInner" value="8mil"/>
<param name="rlMaxPadInner" value="100mil"/>
<param name="rlMinPadBottom" value="8mil"/>
<param name="rlMaxPadBottom" value="100mil"/>
<param name="rlMinViaOuter" value="6mil"/>
<param name="rlMaxViaOuter" value="100mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="100mil"/>
<param name="rlMinMicroViaOuter" value="99mil"/>
<param name="rlMaxMicroViaOuter" value="999mil"/>
<param name="rlMinMicroViaInner" value="99mil"/>
<param name="rlMaxMicroViaInner" value="999mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="0"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="0"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="3mil"/>
<param name="mlMaxStopFrame" value="3mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="7mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="8mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="|"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="-"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="U$1" library="adafruit" package="ARDUINO" value="ARDUINOUNO" x="0" y="0"/>
<element name="IC1" library="74xx-eu" package="DIL14" value="74LS06N" x="22.86" y="13.97" smashed="yes" rot="R90">
<attribute name="NAME" x="25.908" y="4.699" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="23.495" y="7.239" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="C1" library="rcl" package="C025-025X050" value="100nF" x="33.02" y="40.64" smashed="yes" rot="R90">
<attribute name="NAME" x="35.941" y="40.259" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="35.814" y="38.354" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="C2" library="rcl" package="C025-025X050" value="100nF" x="20.32" y="1.905" smashed="yes">
<attribute name="NAME" x="17.526" y="1.2065" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="18.034" y="-0.889" size="1.27" layer="27" ratio="10"/>
</element>
<element name="C3" library="rcl" package="C025-025X050" value="100nF" x="64.77" y="40.64" smashed="yes" rot="R90">
<attribute name="NAME" x="64.1985" y="35.814" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="67.564" y="38.354" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="C4" library="rcl" package="C025-025X050" value="100nF" x="65.405" y="29.845" smashed="yes" rot="R90">
<attribute name="NAME" x="68.326" y="27.559" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="68.199" y="27.559" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="C5" library="rcl" package="C025-025X050" value="100nF" x="65.405" y="19.05" smashed="yes" rot="R90">
<attribute name="NAME" x="66.929" y="19.1135" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="68.199" y="16.764" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="C6" library="rcl" package="C025-025X050" value="100nF" x="25.0825" y="26.035" smashed="yes" rot="R270">
<attribute name="NAME" x="26.6065" y="25.781" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="22.2885" y="28.321" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="C7" library="rcl" package="E2,5-5" value="100µF/16V" x="12.065" y="10.4775" smashed="yes" rot="R180">
<attribute name="NAME" x="13.462" y="7.3025" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="9.652" y="12.8905" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C8" library="rcl" package="E2,5-7" value="330µF/35V" x="18.0975" y="26.035" smashed="yes" rot="R270">
<attribute name="NAME" x="13.208" y="25.7175" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="15.6845" y="23.622" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="Q1" library="transistor-small-signal" package="SOT54E" value="BS250" x="63.5" y="8.89" smashed="yes">
<attribute name="VALUE" x="66.675" y="6.985" size="1.27" layer="27" ratio="10"/>
<attribute name="NAME" x="65.405" y="10.795" size="1.27" layer="25" ratio="10"/>
</element>
<element name="Q2" library="transistor-small-signal" package="SOT54E" value="BS250" x="29.21" y="31.75" smashed="yes">
<attribute name="VALUE" x="32.385" y="29.845" size="1.27" layer="27" ratio="10"/>
<attribute name="NAME" x="26.67" y="32.385" size="0.8128" layer="25" ratio="10" rot="R90"/>
</element>
<element name="R1" library="rcl" package="0207/2V" value="4k7" x="64.77" y="5.08" smashed="yes" rot="R180">
<attribute name="NAME" x="62.9158" y="6.604" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="64.8208" y="7.3152" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R2" library="rcl" package="0207/2V" value="4k7" x="29.21" y="36.195" smashed="yes" rot="R180">
<attribute name="NAME" x="30.226" y="39.4208" size="1.016" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="29.2608" y="38.4302" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R3" library="rcl" package="0207/2V" value="56k" x="24.13" y="30.48" smashed="yes" rot="R270">
<attribute name="NAME" x="25.146" y="30.5308" size="0.8128" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="21.8948" y="30.5308" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R4" library="rcl" package="0207/2V" value="4k7" x="21.59" y="30.48" smashed="yes" rot="R270">
<attribute name="NAME" x="23.114" y="29.1592" size="0.8128" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="19.3548" y="30.5308" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R5" library="rcl" package="0207/2V" value="1k" x="29.21" y="27.94" smashed="yes">
<attribute name="NAME" x="29.1592" y="25.4635" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="29.1592" y="25.7048" size="1.27" layer="27" ratio="10"/>
</element>
<element name="RN1" library="resistor-net" package="RN-10" value="" x="52.07" y="13.97" smashed="yes" rot="R180">
<attribute name="OC_NEWARK" value="unknown" x="52.07" y="13.97" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="52.07" y="13.97" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MF" value="" x="52.07" y="13.97" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="52.07" y="13.97" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="62.23" y="17.145" size="1.27" layer="27" ratio="10" rot="R180"/>
<attribute name="NAME" x="65.0875" y="13.335" size="1.27" layer="25" ratio="10"/>
</element>
<element name="R6" library="rcl" package="0207/2V" value="4k7" x="35.56" y="12.7" smashed="yes" rot="R90">
<attribute name="NAME" x="34.3408" y="12.0015" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="37.7952" y="12.6492" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="U3" library="microchip" package="DIL8" value="MCP 4151-103E/P" x="25.4" y="43.18" smashed="yes" rot="R180">
<attribute name="NAME" x="30.6578" y="46.99" size="1.778" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="18.161" y="45.72" size="1.778" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R7" library="rcl" package="0207/2V" value="56k" x="24.13" y="35.56" smashed="yes" rot="R90">
<attribute name="NAME" x="25.9715" y="35.8267" size="0.8128" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="26.3652" y="35.5092" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="R8" library="rcl" package="0207/2V" value="3k3" x="21.59" y="35.56" smashed="yes" rot="R90">
<attribute name="NAME" x="22.2885" y="37.5158" size="0.8128" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="23.8252" y="35.5092" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="16V8" library="pal" package="DIL20" value="" x="49.53" y="43.18" smashed="yes" rot="R180">
<attribute name="OC_NEWARK" value="97K0449" x="49.53" y="43.18" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="GAL16V8D-7LPN" x="49.53" y="43.18" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MF" value="" x="49.53" y="43.18" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="9699740" x="49.53" y="43.18" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="62.9285" y="48.133" size="1.27" layer="25" rot="R270"/>
<attribute name="VALUE" x="59.309" y="43.561" size="1.27" layer="27" rot="R180"/>
</element>
<element name="20V8" library="pal" package="DIL24-3" value="" x="46.99" y="32.385" smashed="yes" rot="R180">
<attribute name="OC_NEWARK" value="70C8546" x="46.99" y="32.385" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="GAL20V8B-25QP" x="46.99" y="32.385" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MF" value="FARNELL" x="46.99" y="32.385" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="3327462" x="46.99" y="32.385" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="62.5983" y="35.052" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="60.452" y="33.274" size="1.778" layer="27" ratio="10" rot="R180"/>
</element>
<element name="22V10" library="pal" package="DIL24-3" value="" x="46.99" y="21.59" smashed="yes" rot="R180">
<attribute name="OC_NEWARK" value="97M0480" x="46.99" y="21.59" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="GAL22V10D-7LPN" x="46.99" y="21.59" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MF" value="" x="46.99" y="21.59" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="1571925" x="46.99" y="21.59" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="62.5983" y="24.892" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="60.452" y="22.479" size="1.778" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R9" library="rcl" package="0207/2V" value="1k" x="38.1" y="12.7" smashed="yes" rot="R90">
<attribute name="NAME" x="39.6367" y="10.8585" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="40.3352" y="12.6492" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="U1" library="ON Semiconductor_By_element14_Batch_1" package="DIP254P762X533-8" value="MC33063AP1G" x="11.43" y="16.51" smashed="yes">
<attribute name="PACKAGE" value="PDIP-8" x="11.43" y="16.51" size="1.778" layer="27" display="off"/>
<attribute name="OC_NEWARK" value="45J1156" x="11.43" y="16.51" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="MC33063AP1G" x="11.43" y="16.51" size="1.778" layer="27" display="off"/>
<attribute name="SUPPLIER" value="ON SEMICONDUCTOR" x="11.43" y="16.51" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="9664432" x="11.43" y="16.51" size="1.778" layer="27" display="off"/>
<attribute name="NAME" x="2.54" y="22.2631" size="2.0828" layer="25" ratio="10" rot="SR90"/>
<attribute name="VALUE" x="4.1656" y="6.35" size="2.0828" layer="27" ratio="10" rot="SR0"/>
</element>
<element name="R10" library="rcl" package="0207/2V" value="180" x="13.97" y="22.86" smashed="yes" rot="R90">
<attribute name="NAME" x="15.5067" y="20.3835" size="0.8128" layer="25" ratio="10"/>
<attribute name="VALUE" x="16.2052" y="22.8092" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="C10" library="rcl" package="C025-025X050" value="1.5nF" x="1.27" y="17.78" smashed="yes" rot="R270">
<attribute name="NAME" x="0.5715" y="15.3035" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="-1.524" y="20.066" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R11" library="rcl" package="0207/2V" value="0.5" x="15.24" y="18.7325" smashed="yes">
<attribute name="NAME" x="15.1892" y="16.891" size="0.8128" layer="25" ratio="10"/>
<attribute name="VALUE" x="15.1892" y="16.4973" size="1.27" layer="27" ratio="10"/>
</element>
<element name="L1" library="rcl" package="RM7D12_5" value="180µH Reichelt: L-09HCP 180µ" x="8.89" y="35.56" smashed="yes" rot="R270">
<attribute name="NAME" x="8.6825" y="46.815" size="1.27" layer="25" rot="R270"/>
<attribute name="VALUE" x="1.08" y="44.88" size="1.27" layer="27"/>
</element>
<element name="D1" library="diode" package="DO41-7.6" value="1N5819-B" x="19.05" y="34.925" smashed="yes" rot="R90">
<attribute name="NAME" x="17.7165" y="30.0355" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="21.971" y="32.893" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="C9" library="rcl" package="C025-025X050" value="100nF" x="14.605" y="14.605" smashed="yes">
<attribute name="NAME" x="9.779" y="13.589" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="12.319" y="11.811" size="1.27" layer="27" ratio="10"/>
</element>
</elements>
<signals>
<signal name="GND">
<contactref element="U$1" pad="GND"/>
<contactref element="IC1" pad="7"/>
<contactref element="IC1" pad="13"/>
<contactref element="IC1" pad="11"/>
<contactref element="IC1" pad="9"/>
<contactref element="IC1" pad="5"/>
<contactref element="U$1" pad="GND2"/>
<contactref element="U$1" pad="GND1"/>
<contactref element="C8" pad="-"/>
<contactref element="C7" pad="-"/>
<contactref element="C5" pad="2"/>
<contactref element="C4" pad="2"/>
<contactref element="C3" pad="2"/>
<contactref element="C2" pad="2"/>
<contactref element="C1" pad="2"/>
<contactref element="C6" pad="2"/>
<contactref element="R4" pad="1"/>
<contactref element="RN1" pad="1"/>
<contactref element="U3" pad="4"/>
<contactref element="R8" pad="1"/>
<contactref element="R9" pad="1"/>
<contactref element="16V8" pad="10"/>
<contactref element="20V8" pad="12"/>
<contactref element="22V10" pad="12"/>
<polygon width="0.254" layer="16">
<vertex x="0" y="53.34"/>
<vertex x="64.77" y="53.34"/>
<vertex x="66.04" y="52.07"/>
<vertex x="66.04" y="40.64"/>
<vertex x="68.58" y="38.1"/>
<vertex x="68.58" y="5.08"/>
<vertex x="66.04" y="2.54"/>
<vertex x="66.04" y="0"/>
<vertex x="0" y="0"/>
</polygon>
<polygon width="0.254" layer="1">
</polygon>
<contactref element="U1" pad="2"/>
<contactref element="U1" pad="4"/>
<contactref element="C10" pad="2"/>
<via x="1.27" y="1.27" extent="1-16" drill="0.3"/>
<via x="2.54" y="1.27" extent="1-16" drill="0.3"/>
<via x="1.27" y="2.54" extent="1-16" drill="0.3"/>
<via x="1.27" y="52.07" extent="1-16" drill="0.3"/>
<via x="2.54" y="52.07" extent="1-16" drill="0.3"/>
<via x="1.27" y="50.8" extent="1-16" drill="0.3"/>
<via x="64.77" y="48.26" extent="1-16" drill="0.3"/>
<via x="64.77" y="46.99" extent="1-16" drill="0.3"/>
<via x="64.77" y="45.72" extent="1-16" drill="0.3"/>
<via x="62.23" y="52.07" extent="1-16" drill="0.3"/>
<via x="67.31" y="6.35" extent="1-16" drill="0.3"/>
<via x="67.31" y="7.62" extent="1-16" drill="0.3"/>
<via x="67.31" y="8.89" extent="1-16" drill="0.3"/>
<via x="64.77" y="1.27" extent="1-16" drill="0.3"/>
<contactref element="C9" pad="2"/>
</signal>
<signal name="VIN">
<contactref element="U$1" pad="VIN"/>
</signal>
<signal name="3V">
<contactref element="U$1" pad="3V"/>
</signal>
<signal name="VCC">
<contactref element="IC1" pad="14"/>
<contactref element="U$1" pad="5V"/>
<contactref element="C2" pad="1"/>
<contactref element="C1" pad="1"/>
<contactref element="Q1" pad="S"/>
<contactref element="R1" pad="1"/>
<contactref element="R6" pad="1"/>
<contactref element="U3" pad="8"/>
<contactref element="C7" pad="+"/>
<contactref element="U1" pad="6"/>
<contactref element="R11" pad="1"/>
<wire x1="38.1" y1="2.54" x2="36.195" y2="4.445" width="0.8128" layer="16"/>
<wire x1="36.195" y1="4.445" x2="35.56" y2="4.445" width="0.8128" layer="16"/>
<wire x1="35.56" y1="4.445" x2="30.48" y2="4.445" width="0.8128" layer="16"/>
<wire x1="19.05" y1="1.905" x2="19.05" y2="6.35" width="0.8128" layer="16"/>
<wire x1="13.335" y1="17.145" x2="11.43" y2="19.05" width="0.8128" layer="16"/>
<wire x1="29.21" y1="39.37" x2="33.02" y2="39.37" width="0.4064" layer="16"/>
<wire x1="35.56" y1="11.43" x2="35.56" y2="4.445" width="0.4064" layer="1"/>
<via x="35.56" y="4.445" extent="1-16" drill="0.3"/>
<wire x1="29.21" y1="39.37" x2="31.75" y2="36.83" width="0.6096" layer="1"/>
<wire x1="31.75" y1="36.83" x2="31.75" y2="27.305" width="0.6096" layer="1"/>
<wire x1="31.75" y1="27.305" x2="30.48" y2="26.035" width="0.6096" layer="1"/>
<wire x1="30.48" y1="26.035" x2="30.48" y2="4.445" width="0.6096" layer="1"/>
<via x="30.48" y="4.445" extent="1-16" drill="0.3"/>
<wire x1="38.1" y1="2.54" x2="40.005" y2="4.445" width="0.8128" layer="16"/>
<wire x1="40.005" y1="4.445" x2="60.325" y2="4.445" width="0.8128" layer="16"/>
<wire x1="60.325" y1="4.445" x2="64.77" y2="8.89" width="0.8128" layer="16"/>
<wire x1="66.04" y1="5.08" x2="66.04" y2="7.62" width="0.8128" layer="16"/>
<wire x1="66.04" y1="7.62" x2="64.77" y2="8.89" width="0.8128" layer="16"/>
<wire x1="30.48" y1="4.445" x2="21.59" y2="4.445" width="0.8128" layer="16"/>
<wire x1="21.59" y1="4.445" x2="19.05" y2="1.905" width="0.8128" layer="16"/>
<wire x1="17.4625" y1="1.905" x2="19.05" y2="1.905" width="0.8128" layer="16"/>
<wire x1="17.4625" y1="1.905" x2="16.8275" y2="2.54" width="0.8128" layer="16"/>
<wire x1="16.8275" y1="2.54" x2="16.8275" y2="4.445" width="0.8128" layer="16"/>
<wire x1="16.8275" y1="4.445" x2="13.335" y2="7.9375" width="0.8128" layer="16"/>
<wire x1="13.335" y1="7.9375" x2="13.335" y2="10.4775" width="0.8128" layer="16"/>
<contactref element="C9" pad="1"/>
<wire x1="13.335" y1="10.4775" x2="13.335" y2="14.605" width="0.8128" layer="16"/>
<wire x1="13.335" y1="14.605" x2="13.335" y2="17.145" width="0.8128" layer="16"/>
<wire x1="11.43" y1="19.05" x2="13.6525" y2="19.05" width="0.8128" layer="16"/>
<wire x1="13.6525" y1="19.05" x2="13.97" y2="18.7325" width="0.8128" layer="16"/>
</signal>
<signal name="VPP">
<contactref element="C6" pad="1"/>
<contactref element="C8" pad="+"/>
<contactref element="Q2" pad="S"/>
<contactref element="R2" pad="1"/>
<contactref element="R3" pad="1"/>
<contactref element="R7" pad="1"/>
<contactref element="D1" pad="C"/>
<wire x1="24.13" y1="34.29" x2="24.13" y2="31.75" width="0.4064" layer="1"/>
<wire x1="30.48" y1="36.195" x2="30.48" y2="31.75" width="0.4064" layer="1"/>
<wire x1="24.13" y1="31.75" x2="25.4" y2="30.48" width="0.6096" layer="16"/>
<wire x1="25.4" y1="30.48" x2="26.67" y2="30.48" width="0.6096" layer="16"/>
<wire x1="18.0975" y1="27.305" x2="19.05" y2="28.2575" width="0.8128" layer="16"/>
<wire x1="19.05" y1="28.2575" x2="19.05" y2="31.115" width="0.8128" layer="16"/>
<wire x1="25.0825" y1="27.305" x2="18.0975" y2="27.305" width="0.8128" layer="16"/>
<wire x1="25.0825" y1="27.305" x2="25.4" y2="27.6225" width="0.8128" layer="16"/>
<wire x1="25.4" y1="27.6225" x2="25.4" y2="29.21" width="0.8128" layer="16"/>
<wire x1="25.4" y1="29.21" x2="26.67" y2="30.48" width="0.8128" layer="16"/>
<wire x1="26.67" y1="30.48" x2="29.21" y2="30.48" width="0.8128" layer="16"/>
<wire x1="29.21" y1="30.48" x2="30.48" y2="31.75" width="0.8128" layer="16"/>
</signal>
<signal name="N$3">
<contactref element="R2" pad="2"/>
<contactref element="Q2" pad="G"/>
<contactref element="IC1" pad="4"/>
<wire x1="27.94" y1="36.195" x2="27.94" y2="34.925" width="0.4064" layer="1"/>
<wire x1="27.94" y1="34.925" x2="29.21" y2="33.655" width="0.4064" layer="1"/>
<wire x1="29.21" y1="15.24" x2="29.21" y2="33.655" width="0.4064" layer="1"/>
<wire x1="29.21" y1="15.24" x2="27.94" y2="13.97" width="0.4064" layer="1"/>
<wire x1="27.94" y1="13.97" x2="26.67" y2="13.97" width="0.4064" layer="1"/>
</signal>
<signal name="N$4">
<contactref element="Q1" pad="G"/>
<contactref element="IC1" pad="2"/>
<contactref element="R1" pad="2"/>
<wire x1="26.67" y1="8.89" x2="59.69" y2="8.89" width="0.4064" layer="16"/>
<wire x1="59.69" y1="8.89" x2="61.595" y2="10.795" width="0.4064" layer="16"/>
<wire x1="61.595" y1="10.795" x2="63.5" y2="10.795" width="0.4064" layer="16"/>
<wire x1="63.5" y1="5.08" x2="63.5" y2="10.795" width="0.4064" layer="1"/>
</signal>
<signal name="VCC_GAL">
<contactref element="Q1" pad="D"/>
<contactref element="16V8" pad="20"/>
<contactref element="20V8" pad="24"/>
<contactref element="22V10" pad="24"/>
<contactref element="C5" pad="1"/>
<contactref element="C4" pad="1"/>
<contactref element="C3" pad="1"/>
<wire x1="62.23" y1="8.89" x2="63.1825" y2="8.89" width="0.6096" layer="16"/>
<wire x1="63.1825" y1="8.89" x2="65.405" y2="11.1125" width="0.6096" layer="16"/>
<wire x1="65.405" y1="11.1125" x2="65.405" y2="17.78" width="0.6096" layer="16"/>
<wire x1="65.405" y1="17.78" x2="66.04" y2="17.78" width="0.6096" layer="1"/>
<wire x1="66.04" y1="17.78" x2="66.675" y2="18.415" width="0.6096" layer="1"/>
<wire x1="66.675" y1="18.415" x2="66.675" y2="27.305" width="0.6096" layer="1"/>
<wire x1="66.675" y1="27.305" x2="65.405" y2="28.575" width="0.6096" layer="1"/>
<wire x1="65.405" y1="28.575" x2="66.675" y2="29.845" width="0.6096" layer="1"/>
<wire x1="60.96" y1="39.37" x2="64.77" y2="39.37" width="0.6096" layer="16"/>
<wire x1="60.96" y1="28.575" x2="65.405" y2="28.575" width="0.6096" layer="16"/>
<wire x1="60.96" y1="17.78" x2="65.405" y2="17.78" width="0.6096" layer="16"/>
<wire x1="66.675" y1="29.845" x2="66.675" y2="32.385" width="0.6096" layer="1"/>
<wire x1="66.675" y1="32.385" x2="66.04" y2="33.02" width="0.6096" layer="1"/>
<wire x1="66.04" y1="33.02" x2="64.77" y2="33.02" width="0.6096" layer="1"/>
<wire x1="64.77" y1="33.02" x2="63.5" y2="34.29" width="0.6096" layer="1"/>
<wire x1="63.5" y1="34.29" x2="63.5" y2="38.1" width="0.6096" layer="1"/>
<wire x1="63.5" y1="38.1" x2="64.77" y2="39.37" width="0.6096" layer="1"/>
</signal>
<signal name="MEASURE">
<contactref element="R4" pad="2"/>
<contactref element="R3" pad="2"/>
<contactref element="U$1" pad="A2"/>
<wire x1="21.59" y1="29.21" x2="24.13" y2="29.21" width="0.4064" layer="16"/>
<wire x1="24.13" y1="29.21" x2="24.13" y2="28.2575" width="0.4064" layer="1"/>
<wire x1="24.13" y1="28.2575" x2="22.86" y2="26.9875" width="0.4064" layer="1"/>
<wire x1="22.86" y1="26.9875" x2="22.86" y2="7.62" width="0.4064" layer="1"/>
<via x="22.86" y="7.62" extent="1-16" drill="0.3"/>
<via x="55.88" y="7.62" extent="1-16" drill="0.3"/>
<wire x1="55.88" y1="7.62" x2="55.88" y2="2.54" width="0.4064" layer="1"/>
<wire x1="22.86" y1="7.62" x2="55.88" y2="7.62" width="0.4064" layer="16"/>
</signal>
<signal name="N$1">
<contactref element="Q2" pad="D"/>
<contactref element="R5" pad="1"/>
<wire x1="27.94" y1="31.75" x2="27.94" y2="27.94" width="0.4064" layer="1"/>
</signal>
<signal name="EDIT">
<contactref element="R5" pad="2"/>
<contactref element="16V8" pad="2"/>
<contactref element="20V8" pad="2"/>
<contactref element="22V10" pad="2"/>
<wire x1="58.42" y1="46.99" x2="59.69" y2="45.72" width="0.4064" layer="1"/>
<wire x1="59.69" y1="45.72" x2="59.69" y2="37.465" width="0.4064" layer="1"/>
<wire x1="59.69" y1="37.465" x2="58.42" y2="36.195" width="0.4064" layer="1"/>
<wire x1="58.42" y1="36.195" x2="58.42" y2="34.29" width="0.4064" layer="1"/>
<wire x1="58.42" y1="34.29" x2="59.69" y2="33.02" width="0.4064" layer="1"/>
<wire x1="59.69" y1="31.75" x2="59.69" y2="26.67" width="0.4064" layer="1"/>
<wire x1="59.69" y1="26.67" x2="58.42" y2="25.4" width="0.4064" layer="1"/>
<wire x1="30.48" y1="27.94" x2="30.48" y2="29.21" width="0.4064" layer="16"/>
<wire x1="30.48" y1="29.21" x2="33.02" y2="31.75" width="0.4064" layer="16"/>
<wire x1="33.02" y1="31.75" x2="59.69" y2="31.75" width="0.4064" layer="16"/>
<via x="59.69" y="31.75" extent="1-16" drill="0.3"/>
<wire x1="59.69" y1="31.75" x2="59.69" y2="33.02" width="0.4064" layer="1"/>
</signal>
<signal name="SDO">
<contactref element="R6" pad="2"/>
<contactref element="16V8" pad="12"/>
<contactref element="22V10" pad="14"/>
<contactref element="20V8" pad="15"/>
<wire x1="35.56" y1="13.97" x2="35.56" y2="17.78" width="0.4064" layer="1"/>
<wire x1="35.56" y1="17.78" x2="35.56" y2="22.86" width="0.4064" layer="1"/>
<wire x1="35.56" y1="22.86" x2="36.83" y2="24.13" width="0.4064" layer="1"/>
<wire x1="36.83" y1="24.13" x2="36.83" y2="27.305" width="0.4064" layer="1"/>
<wire x1="36.83" y1="27.305" x2="38.1" y2="28.575" width="0.4064" layer="1"/>
<wire x1="38.1" y1="28.575" x2="38.1" y2="33.02" width="0.4064" layer="1"/>
<wire x1="38.1" y1="33.02" x2="39.37" y2="34.29" width="0.4064" layer="1"/>
<wire x1="39.37" y1="34.29" x2="39.37" y2="38.1" width="0.4064" layer="1"/>
<wire x1="39.37" y1="38.1" x2="40.64" y2="39.37" width="0.4064" layer="1"/>
<contactref element="U$1" pad="D12"/>
<wire x1="31.496" y1="50.8" x2="31.496" y2="43.434" width="0.4064" layer="1"/>
<wire x1="31.496" y1="43.434" x2="31.75" y2="43.18" width="0.4064" layer="1"/>
<via x="31.75" y="43.18" extent="1-16" drill="0.3"/>
<wire x1="31.75" y1="43.18" x2="40.64" y2="43.18" width="0.4064" layer="16"/>
<via x="40.64" y="43.18" extent="1-16" drill="0.3"/>
<wire x1="40.64" y1="43.18" x2="40.64" y2="39.37" width="0.4064" layer="1"/>
</signal>
<signal name="CSR">
<contactref element="U3" pad="1"/>
<contactref element="U$1" pad="D10"/>
<wire x1="29.21" y1="46.99" x2="36.195" y2="46.99" width="0.4064" layer="16"/>
<via x="36.195" y="46.99" extent="1-16" drill="0.3"/>
<wire x1="36.195" y1="46.99" x2="36.576" y2="47.371" width="0.4064" layer="1"/>
<wire x1="36.576" y1="47.371" x2="36.576" y2="50.8" width="0.4064" layer="1"/>
</signal>
<signal name="SDI">
<contactref element="U3" pad="3"/>
<contactref element="U$1" pad="D11"/>
<contactref element="16V8" pad="9"/>
<contactref element="22V10" pad="11"/>
<contactref element="20V8" pad="11"/>
<wire x1="35.56" y1="25.4" x2="34.29" y2="26.67" width="0.4064" layer="1"/>
<wire x1="34.29" y1="26.67" x2="34.29" y2="33.02" width="0.4064" layer="1"/>
<wire x1="34.29" y1="33.02" x2="35.56" y2="34.29" width="0.4064" layer="1"/>
<wire x1="35.56" y1="34.29" x2="35.56" y2="36.195" width="0.4064" layer="1"/>
<wire x1="35.56" y1="36.195" x2="35.56" y2="45.085" width="0.4064" layer="1"/>
<via x="35.56" y="45.085" extent="1-16" drill="0.3"/>
<wire x1="35.56" y1="45.085" x2="40.005" y2="45.085" width="0.4064" layer="16"/>
<wire x1="40.005" y1="45.085" x2="40.64" y2="45.72" width="0.4064" layer="16"/>
<wire x1="40.64" y1="45.72" x2="40.64" y2="46.99" width="0.4064" layer="16"/>
<wire x1="24.13" y1="46.99" x2="26.035" y2="48.895" width="0.4064" layer="16"/>
<wire x1="26.035" y1="48.895" x2="33.02" y2="48.895" width="0.4064" layer="16"/>
<wire x1="33.02" y1="48.895" x2="34.036" y2="49.911" width="0.4064" layer="16"/>
<wire x1="34.036" y1="49.911" x2="34.036" y2="50.165" width="0.4064" layer="16"/>
<wire x1="34.036" y1="50.165" x2="34.036" y2="50.8" width="0.4064" layer="16"/>
<wire x1="40.64" y1="46.99" x2="40.64" y2="48.26" width="0.4064" layer="16"/>
<wire x1="40.64" y1="48.26" x2="40.005" y2="48.895" width="0.4064" layer="16"/>
<wire x1="40.005" y1="48.895" x2="35.306" y2="48.895" width="0.4064" layer="16"/>
<wire x1="35.306" y1="48.895" x2="34.036" y2="50.165" width="0.4064" layer="16"/>
</signal>
<signal name="VREF">
<contactref element="U3" pad="6"/>
<contactref element="R7" pad="2"/>
<contactref element="U1" pad="5"/>
<wire x1="24.13" y1="39.37" x2="24.13" y2="36.83" width="0.4064" layer="1"/>
<wire x1="22.86" y1="35.56" x2="24.13" y2="36.83" width="0.4064" layer="1"/>
<wire x1="22.86" y1="35.56" x2="20.32" y2="35.56" width="0.4064" layer="1"/>
<wire x1="20.32" y1="35.56" x2="10.16" y2="25.4" width="0.4064" layer="1"/>
<wire x1="10.16" y1="25.4" x2="10.16" y2="17.78" width="0.4064" layer="1"/>
<wire x1="10.16" y1="17.78" x2="11.43" y2="16.51" width="0.4064" layer="1"/>
</signal>
<signal name="N$8">
<contactref element="U3" pad="5"/>
<contactref element="R8" pad="2"/>
<wire x1="21.59" y1="39.37" x2="21.59" y2="36.83" width="0.4064" layer="1"/>
</signal>
<signal name="N$9">
<contactref element="IC1" pad="3"/>
<contactref element="U$1" pad="A0"/>
<wire x1="27.94" y1="10.16" x2="50.8" y2="10.16" width="0.4064" layer="16"/>
<via x="50.8" y="10.16" extent="1-16" drill="0.3"/>
<wire x1="50.8" y1="10.16" x2="50.8" y2="2.54" width="0.4064" layer="1"/>
<wire x1="26.67" y1="11.43" x2="27.94" y2="10.16" width="0.4064" layer="16"/>
</signal>
<signal name="N$10">
<contactref element="IC1" pad="1"/>
<contactref element="U$1" pad="A1"/>
<via x="53.34" y="6.35" extent="1-16" drill="0.3"/>
<wire x1="53.34" y1="6.35" x2="53.34" y2="2.54" width="0.4064" layer="1"/>
<wire x1="26.67" y1="6.35" x2="53.34" y2="6.35" width="0.4064" layer="16"/>
</signal>
<signal name="STB">
<contactref element="U$1" pad="A3"/>
<contactref element="16V8" pad="11"/>
<contactref element="22V10" pad="13"/>
<contactref element="20V8" pad="13"/>
<wire x1="58.42" y1="2.54" x2="58.42" y2="11.43" width="0.4064" layer="1"/>
<via x="58.42" y="11.43" extent="1-16" drill="0.3"/>
<wire x1="58.42" y1="11.43" x2="40.64" y2="11.43" width="0.4064" layer="16"/>
<wire x1="40.64" y1="11.43" x2="39.37" y2="12.7" width="0.4064" layer="16"/>
<wire x1="39.37" y1="12.7" x2="33.02" y2="12.7" width="0.4064" layer="16"/>
<via x="33.02" y="12.7" extent="1-16" drill="0.3"/>
<wire x1="33.02" y1="12.7" x2="33.02" y2="17.78" width="0.4064" layer="1"/>
<wire x1="33.02" y1="28.575" x2="33.02" y2="33.02" width="0.4064" layer="1"/>
<wire x1="33.02" y1="33.02" x2="34.29" y2="34.29" width="0.4064" layer="1"/>
<wire x1="34.29" y1="34.29" x2="34.29" y2="39.37" width="0.4064" layer="1"/>
<via x="34.29" y="39.37" extent="1-16" drill="0.3"/>
<wire x1="34.29" y1="39.37" x2="38.1" y2="39.37" width="0.4064" layer="16"/>
<wire x1="33.02" y1="17.78" x2="31.75" y2="19.05" width="0.4064" layer="1"/>
<wire x1="31.75" y1="19.05" x2="31.75" y2="26.3525" width="0.4064" layer="1"/>
<wire x1="31.75" y1="26.3525" x2="33.02" y2="27.6225" width="0.4064" layer="1"/>
<wire x1="33.02" y1="27.6225" x2="33.02" y2="28.575" width="0.4064" layer="1"/>
</signal>
<signal name="SCK">
<contactref element="U$1" pad="D13"/>
<contactref element="U3" pad="2"/>
<contactref element="16V8" pad="8"/>
<contactref element="22V10" pad="10"/>
<contactref element="20V8" pad="10"/>
<wire x1="28.956" y1="49.276" x2="28.956" y2="50.8" width="0.4064" layer="1"/>
<wire x1="38.1" y1="25.4" x2="36.83" y2="26.67" width="0.4064" layer="16"/>
<wire x1="36.83" y1="26.67" x2="36.83" y2="30.48" width="0.4064" layer="16"/>
<via x="36.83" y="30.48" extent="1-16" drill="0.3"/>
<wire x1="36.83" y1="30.48" x2="36.83" y2="34.925" width="0.4064" layer="1"/>
<wire x1="36.83" y1="34.925" x2="38.1" y2="36.195" width="0.4064" layer="1"/>
<wire x1="38.1" y1="36.195" x2="38.1" y2="36.83" width="0.4064" layer="1"/>
<wire x1="38.1" y1="36.83" x2="36.83" y2="38.1" width="0.4064" layer="1"/>
<wire x1="36.83" y1="38.1" x2="36.83" y2="41.91" width="0.4064" layer="1"/>
<wire x1="36.83" y1="41.91" x2="38.89375" y2="43.97375" width="0.4064" layer="1"/>
<wire x1="39.37" y1="44.45" x2="40.64" y2="44.45" width="0.4064" layer="1"/>
<wire x1="40.64" y1="44.45" x2="43.18" y2="46.99" width="0.4064" layer="1"/>
<wire x1="26.67" y1="46.99" x2="26.67" y2="44.1325" width="0.4064" layer="1"/>
<via x="26.67" y="44.1325" extent="1-16" drill="0.3"/>
<wire x1="26.67" y1="44.1325" x2="38.735" y2="44.1325" width="0.4064" layer="16"/>
<wire x1="38.735" y1="44.1325" x2="38.89375" y2="43.97375" width="0.4064" layer="16"/>
<via x="38.89375" y="43.97375" extent="1-16" drill="0.3"/>
<wire x1="38.89375" y1="43.97375" x2="39.37" y2="44.45" width="0.4064" layer="1"/>
<wire x1="26.67" y1="46.99" x2="28.956" y2="49.276" width="0.4064" layer="1"/>
</signal>
<signal name="RA0">
<contactref element="U$1" pad="D9"/>
<contactref element="16V8" pad="18"/>
<contactref element="22V10" pad="6"/>
<contactref element="20V8" pad="21"/>
<wire x1="48.26" y1="25.4" x2="48.26" y2="24.13" width="0.4064" layer="16"/>
<wire x1="48.26" y1="24.13" x2="49.53" y2="22.86" width="0.4064" layer="16"/>
<wire x1="49.53" y1="22.86" x2="53.34" y2="22.86" width="0.4064" layer="16"/>
<wire x1="53.34" y1="22.86" x2="54.61" y2="24.13" width="0.4064" layer="16"/>
<wire x1="54.61" y1="24.13" x2="54.61" y2="27.305" width="0.4064" layer="16"/>
<wire x1="54.61" y1="27.305" x2="53.34" y2="28.575" width="0.4064" layer="16"/>
<wire x1="53.34" y1="28.575" x2="53.34" y2="33.9725" width="0.4064" layer="1"/>
<via x="53.34" y="33.9725" extent="1-16" drill="0.3"/>
<wire x1="53.34" y1="33.9725" x2="54.61" y2="35.2425" width="0.4064" layer="16"/>
<wire x1="54.61" y1="35.2425" x2="54.61" y2="38.1" width="0.4064" layer="16"/>
<wire x1="54.61" y1="38.1" x2="55.88" y2="39.37" width="0.4064" layer="16"/>
<wire x1="54.61" y1="48.895" x2="41.021" y2="48.895" width="0.4064" layer="16"/>
<wire x1="41.021" y1="48.895" x2="39.116" y2="50.8" width="0.4064" layer="16"/>
<wire x1="55.88" y1="39.37" x2="55.88" y2="41.91" width="0.4064" layer="1"/>
<wire x1="55.88" y1="41.91" x2="54.61" y2="43.18" width="0.4064" layer="1"/>
<wire x1="54.61" y1="43.18" x2="54.61" y2="48.895" width="0.4064" layer="1"/>
<via x="54.61" y="48.895" extent="1-16" drill="0.3"/>
</signal>
<signal name="P/V">
<contactref element="U$1" pad="D8"/>
<contactref element="16V8" pad="19"/>
<contactref element="22V10" pad="3"/>
<contactref element="20V8" pad="22"/>
<wire x1="55.88" y1="25.4" x2="55.88" y2="28.575" width="0.4064" layer="1"/>
<wire x1="55.88" y1="28.575" x2="55.88" y2="28.8925" width="0.4064" layer="1"/>
<wire x1="55.88" y1="28.8925" x2="57.15" y2="30.1625" width="0.4064" layer="1"/>
<wire x1="57.15" y1="30.1625" x2="57.15" y2="38.1" width="0.4064" layer="1"/>
<wire x1="57.15" y1="38.1" x2="58.42" y2="39.37" width="0.4064" layer="1"/>
<wire x1="58.42" y1="39.37" x2="58.42" y2="43.18" width="0.4064" layer="1"/>
<wire x1="58.42" y1="43.18" x2="57.15" y2="44.45" width="0.4064" layer="1"/>
<wire x1="57.15" y1="44.45" x2="57.15" y2="51.7525" width="0.4064" layer="1"/>
<wire x1="57.15" y1="51.7525" x2="56.8325" y2="52.07" width="0.4064" layer="1"/>
<wire x1="56.8325" y1="52.07" x2="42.926" y2="52.07" width="0.4064" layer="1"/>
<wire x1="42.926" y1="52.07" x2="41.656" y2="50.8" width="0.4064" layer="1"/>
</signal>
<signal name="RA5">
<contactref element="U$1" pad="D7"/>
<contactref element="16V8" pad="7"/>
<contactref element="22V10" pad="9"/>
<contactref element="20V8" pad="9"/>
<wire x1="45.72" y1="50.8" x2="45.72" y2="46.99" width="0.4064" layer="1"/>
<wire x1="40.64" y1="25.4" x2="39.37" y2="26.67" width="0.4064" layer="16"/>
<wire x1="39.37" y1="26.67" x2="39.37" y2="30.48" width="0.4064" layer="16"/>
<via x="39.37" y="30.48" extent="1-16" drill="0.3"/>
<wire x1="39.37" y1="30.48" x2="39.37" y2="33.02" width="0.4064" layer="1"/>
<wire x1="39.37" y1="33.02" x2="40.64" y2="34.29" width="0.4064" layer="1"/>
<wire x1="40.64" y1="34.29" x2="40.64" y2="36.195" width="0.4064" layer="1"/>
<wire x1="40.64" y1="36.195" x2="40.64" y2="36.83" width="0.4064" layer="16"/>
<wire x1="40.64" y1="36.83" x2="41.91" y2="38.1" width="0.4064" layer="16"/>
<wire x1="41.91" y1="38.1" x2="41.91" y2="43.18" width="0.4064" layer="16"/>
<wire x1="41.91" y1="43.18" x2="45.72" y2="46.99" width="0.4064" layer="16"/>
</signal>
<signal name="RA4">
<contactref element="U$1" pad="D6"/>
<contactref element="16V8" pad="6"/>
<contactref element="22V10" pad="8"/>
<contactref element="20V8" pad="8"/>
<wire x1="48.26" y1="50.8" x2="48.26" y2="46.99" width="0.4064" layer="1"/>
<wire x1="43.18" y1="25.4" x2="44.45" y2="26.67" width="0.4064" layer="16"/>
<wire x1="44.45" y1="26.67" x2="44.45" y2="29.845" width="0.4064" layer="16"/>
<via x="44.45" y="29.845" extent="1-16" drill="0.3"/>
<wire x1="44.45" y1="29.845" x2="44.45" y2="34.925" width="0.4064" layer="1"/>
<wire x1="44.45" y1="34.925" x2="43.18" y2="36.195" width="0.4064" layer="1"/>
<wire x1="43.18" y1="36.195" x2="43.18" y2="36.83" width="0.4064" layer="1"/>
<wire x1="43.18" y1="36.83" x2="44.45" y2="38.1" width="0.4064" layer="1"/>
<wire x1="44.45" y1="38.1" x2="44.45" y2="43.18" width="0.4064" layer="1"/>
<wire x1="44.45" y1="43.18" x2="48.26" y2="46.99" width="0.4064" layer="1"/>
</signal>
<signal name="RA3">
<contactref element="U$1" pad="D5"/>
<contactref element="16V8" pad="5"/>
<contactref element="22V10" pad="7"/>
<contactref element="20V8" pad="5"/>
<wire x1="50.8" y1="50.8" x2="50.8" y2="46.99" width="0.4064" layer="1"/>
<wire x1="45.72" y1="25.4" x2="46.99" y2="26.67" width="0.4064" layer="16"/>
<wire x1="46.99" y1="26.67" x2="46.99" y2="29.845" width="0.4064" layer="16"/>
<wire x1="46.99" y1="29.845" x2="47.9425" y2="30.7975" width="0.4064" layer="16"/>
<wire x1="47.9425" y1="30.7975" x2="49.53" y2="30.7975" width="0.4064" layer="16"/>
<via x="49.53" y="30.7975" extent="1-16" drill="0.3"/>
<wire x1="49.53" y1="30.7975" x2="50.8" y2="32.0675" width="0.4064" layer="1"/>
<wire x1="50.8" y1="32.0675" x2="50.8" y2="36.195" width="0.4064" layer="1"/>
<wire x1="50.8" y1="36.195" x2="50.8" y2="36.83" width="0.4064" layer="16"/>
<wire x1="50.8" y1="36.83" x2="49.53" y2="38.1" width="0.4064" layer="16"/>
<wire x1="49.53" y1="38.1" x2="49.53" y2="45.72" width="0.4064" layer="16"/>
<wire x1="49.53" y1="45.72" x2="50.8" y2="46.99" width="0.4064" layer="16"/>
</signal>
<signal name="RA2">
<contactref element="U$1" pad="D4"/>
<contactref element="16V8" pad="4"/>
<contactref element="22V10" pad="4"/>
<contactref element="20V8" pad="4"/>
<wire x1="53.34" y1="50.8" x2="53.34" y2="46.99" width="0.4064" layer="1"/>
<wire x1="53.34" y1="25.4" x2="54.61" y2="26.67" width="0.4064" layer="1"/>
<wire x1="54.61" y1="26.67" x2="54.61" y2="34.925" width="0.4064" layer="1"/>
<wire x1="54.61" y1="34.925" x2="53.34" y2="36.195" width="0.4064" layer="1"/>
<wire x1="53.34" y1="36.195" x2="53.34" y2="36.83" width="0.4064" layer="1"/>
<wire x1="53.34" y1="36.83" x2="54.61" y2="38.1" width="0.4064" layer="1"/>
<wire x1="54.61" y1="38.1" x2="54.61" y2="40.64" width="0.4064" layer="1"/>
<wire x1="54.61" y1="40.64" x2="53.34" y2="41.91" width="0.4064" layer="1"/>
<wire x1="53.34" y1="41.91" x2="53.34" y2="46.99" width="0.4064" layer="1"/>
</signal>
<signal name="RA1">
<contactref element="U$1" pad="D3"/>
<contactref element="16V8" pad="3"/>
<contactref element="22V10" pad="5"/>
<contactref element="20V8" pad="3"/>
<wire x1="55.88" y1="50.8" x2="55.88" y2="46.99" width="0.4064" layer="1"/>
<wire x1="50.8" y1="25.4" x2="52.07" y2="26.67" width="0.4064" layer="16"/>
<wire x1="52.07" y1="26.67" x2="52.07" y2="29.845" width="0.4064" layer="16"/>
<wire x1="52.07" y1="29.845" x2="52.705" y2="30.48" width="0.4064" layer="16"/>
<wire x1="52.705" y1="30.48" x2="55.88" y2="30.48" width="0.4064" layer="16"/>
<via x="55.88" y="30.48" extent="1-16" drill="0.3"/>
<wire x1="55.88" y1="30.48" x2="55.88" y2="36.195" width="0.4064" layer="1"/>
<wire x1="55.88" y1="36.195" x2="55.88" y2="36.83" width="0.4064" layer="16"/>
<wire x1="55.88" y1="36.83" x2="57.15" y2="38.1" width="0.4064" layer="16"/>
<wire x1="57.15" y1="38.1" x2="57.15" y2="45.72" width="0.4064" layer="16"/>
<wire x1="57.15" y1="45.72" x2="55.88" y2="46.99" width="0.4064" layer="16"/>
</signal>
<signal name="TX">
<contactref element="U$1" pad="D1"/>
</signal>
<signal name="RX">
<contactref element="U$1" pad="D0"/>
</signal>
<signal name="PD0">
<contactref element="RN1" pad="2"/>
<contactref element="16V8" pad="1"/>
<contactref element="20V8" pad="1"/>
<contactref element="22V10" pad="1"/>
<wire x1="60.96" y1="46.99" x2="62.23" y2="45.72" width="0.4064" layer="1"/>
<wire x1="62.23" y1="45.72" x2="62.23" y2="37.465" width="0.4064" layer="1"/>
<wire x1="62.23" y1="37.465" x2="60.96" y2="36.195" width="0.4064" layer="1"/>
<wire x1="60.96" y1="36.195" x2="60.96" y2="34.29" width="0.4064" layer="1"/>
<wire x1="60.96" y1="34.29" x2="62.23" y2="33.02" width="0.4064" layer="1"/>
<wire x1="62.23" y1="33.02" x2="62.23" y2="26.67" width="0.4064" layer="1"/>
<wire x1="62.23" y1="26.67" x2="60.96" y2="25.4" width="0.4064" layer="1"/>
<wire x1="60.96" y1="25.4" x2="60.96" y2="24.13" width="0.4064" layer="1"/>
<wire x1="60.96" y1="24.13" x2="62.23" y2="22.86" width="0.4064" layer="1"/>
<wire x1="62.23" y1="22.86" x2="62.23" y2="15.24" width="0.4064" layer="1"/>
<wire x1="62.23" y1="15.24" x2="60.96" y2="13.97" width="0.4064" layer="1"/>
</signal>
<signal name="PD1">
<contactref element="16V8" pad="13"/>
<contactref element="22V10" pad="19"/>
<contactref element="20V8" pad="17"/>
<contactref element="RN1" pad="7"/>
<wire x1="48.26" y1="13.97" x2="48.26" y2="17.78" width="0.4064" layer="1"/>
<wire x1="48.26" y1="17.78" x2="48.26" y2="19.05" width="0.4064" layer="1"/>
<wire x1="48.26" y1="19.05" x2="44.45" y2="22.86" width="0.4064" layer="1"/>
<wire x1="44.45" y1="22.86" x2="44.45" y2="27.305" width="0.4064" layer="1"/>
<wire x1="44.45" y1="27.305" x2="43.18" y2="28.575" width="0.4064" layer="1"/>
<wire x1="43.18" y1="28.575" x2="43.18" y2="33.655" width="0.4064" layer="1"/>
<wire x1="43.18" y1="33.655" x2="41.91" y2="34.925" width="0.4064" layer="1"/>
<wire x1="41.91" y1="34.925" x2="41.91" y2="38.1" width="0.4064" layer="1"/>
<wire x1="41.91" y1="38.1" x2="43.18" y2="39.37" width="0.4064" layer="1"/>
</signal>
<signal name="PD2">
<contactref element="16V8" pad="14"/>
<contactref element="22V10" pad="20"/>
<contactref element="20V8" pad="18"/>
<contactref element="RN1" pad="6"/>
<wire x1="50.8" y1="13.97" x2="50.8" y2="17.78" width="0.4064" layer="1"/>
<wire x1="50.8" y1="17.78" x2="50.8" y2="19.05" width="0.4064" layer="1"/>
<wire x1="50.8" y1="19.05" x2="46.99" y2="22.86" width="0.4064" layer="1"/>
<wire x1="46.99" y1="22.86" x2="46.99" y2="27.305" width="0.4064" layer="1"/>
<wire x1="46.99" y1="27.305" x2="45.72" y2="28.575" width="0.4064" layer="1"/>
<wire x1="45.72" y1="28.575" x2="45.72" y2="33.02" width="0.4064" layer="1"/>
<wire x1="45.72" y1="33.02" x2="46.99" y2="34.29" width="0.4064" layer="1"/>
<wire x1="46.99" y1="34.29" x2="46.99" y2="38.1" width="0.4064" layer="1"/>
<wire x1="46.99" y1="38.1" x2="45.72" y2="39.37" width="0.4064" layer="1"/>
</signal>
<signal name="PD3">
<contactref element="RN1" pad="5"/>
<contactref element="16V8" pad="15"/>
<contactref element="22V10" pad="21"/>
<contactref element="20V8" pad="19"/>
<wire x1="53.34" y1="13.97" x2="53.34" y2="17.78" width="0.4064" layer="1"/>
<wire x1="53.34" y1="17.78" x2="53.34" y2="19.05" width="0.4064" layer="1"/>
<wire x1="53.34" y1="19.05" x2="49.53" y2="22.86" width="0.4064" layer="1"/>
<wire x1="49.53" y1="22.86" x2="49.53" y2="27.305" width="0.4064" layer="1"/>
<wire x1="49.53" y1="27.305" x2="48.26" y2="28.575" width="0.4064" layer="1"/>
<wire x1="48.26" y1="28.575" x2="48.26" y2="31.115" width="0.4064" layer="1"/>
<wire x1="48.26" y1="31.115" x2="49.53" y2="32.385" width="0.4064" layer="1"/>
<wire x1="49.53" y1="32.385" x2="49.53" y2="38.1" width="0.4064" layer="1"/>
<wire x1="49.53" y1="38.1" x2="48.26" y2="39.37" width="0.4064" layer="1"/>
</signal>
<signal name="PD4">
<contactref element="16V8" pad="16"/>
<contactref element="22V10" pad="22"/>
<contactref element="20V8" pad="20"/>
<contactref element="RN1" pad="4"/>
<wire x1="55.88" y1="13.97" x2="55.88" y2="17.78" width="0.4064" layer="1"/>
<wire x1="55.88" y1="17.78" x2="55.88" y2="19.05" width="0.4064" layer="1"/>
<wire x1="55.88" y1="19.05" x2="52.07" y2="22.86" width="0.4064" layer="1"/>
<wire x1="52.07" y1="22.86" x2="52.07" y2="27.305" width="0.4064" layer="1"/>
<wire x1="52.07" y1="27.305" x2="50.8" y2="28.575" width="0.4064" layer="1"/>
<wire x1="50.8" y1="28.575" x2="50.8" y2="30.48" width="0.4064" layer="1"/>
<wire x1="50.8" y1="30.48" x2="52.07" y2="31.75" width="0.4064" layer="1"/>
<wire x1="52.07" y1="31.75" x2="52.07" y2="38.1" width="0.4064" layer="1"/>
<wire x1="52.07" y1="38.1" x2="50.8" y2="39.37" width="0.4064" layer="1"/>
</signal>
<signal name="PD5">
<contactref element="16V8" pad="17"/>
<contactref element="20V8" pad="23"/>
<contactref element="22V10" pad="23"/>
<contactref element="RN1" pad="3"/>
<wire x1="58.42" y1="13.97" x2="58.42" y2="17.78" width="0.4064" layer="1"/>
<wire x1="58.42" y1="17.78" x2="57.15" y2="19.05" width="0.4064" layer="1"/>
<wire x1="57.15" y1="19.05" x2="57.15" y2="27.305" width="0.4064" layer="1"/>
<wire x1="57.15" y1="27.305" x2="58.42" y2="28.575" width="0.4064" layer="1"/>
<wire x1="58.42" y1="28.575" x2="58.42" y2="32.385" width="0.4064" layer="1"/>
<wire x1="58.42" y1="32.385" x2="58.1025" y2="32.7025" width="0.4064" layer="1"/>
<via x="58.1025" y="32.7025" extent="1-16" drill="0.3"/>
<wire x1="58.1025" y1="32.7025" x2="53.34" y2="32.7025" width="0.4064" layer="16"/>
<wire x1="53.34" y1="32.7025" x2="52.07" y2="33.9725" width="0.4064" layer="16"/>
<wire x1="52.07" y1="33.9725" x2="52.07" y2="38.1" width="0.4064" layer="16"/>
<wire x1="52.07" y1="38.1" x2="53.34" y2="39.37" width="0.4064" layer="16"/>
</signal>
<signal name="PD6">
<contactref element="RN1" pad="8"/>
<contactref element="20V8" pad="6"/>
<contactref element="22V10" pad="18"/>
<wire x1="45.72" y1="13.97" x2="45.72" y2="17.78" width="0.4064" layer="1"/>
<wire x1="45.72" y1="17.78" x2="45.72" y2="19.05" width="0.4064" layer="16"/>
<wire x1="45.72" y1="19.05" x2="41.91" y2="22.86" width="0.4064" layer="16"/>
<wire x1="41.91" y1="22.86" x2="41.91" y2="30.1625" width="0.4064" layer="16"/>
<wire x1="41.91" y1="30.1625" x2="42.545" y2="30.7975" width="0.4064" layer="16"/>
<wire x1="42.545" y1="30.7975" x2="46.6725" y2="30.7975" width="0.4064" layer="16"/>
<via x="46.6725" y="30.7975" extent="1-16" drill="0.3"/>
<wire x1="46.6725" y1="30.7975" x2="48.26" y2="32.385" width="0.4064" layer="1"/>
<wire x1="48.26" y1="32.385" x2="48.26" y2="36.195" width="0.4064" layer="1"/>
</signal>
<signal name="PD7">
<contactref element="RN1" pad="9"/>
<contactref element="20V8" pad="7"/>
<contactref element="22V10" pad="17"/>
<wire x1="43.18" y1="13.97" x2="43.18" y2="17.78" width="0.4064" layer="1"/>
<wire x1="43.18" y1="17.78" x2="43.18" y2="19.05" width="0.4064" layer="1"/>
<wire x1="43.18" y1="19.05" x2="41.91" y2="20.32" width="0.4064" layer="1"/>
<wire x1="41.91" y1="20.32" x2="41.91" y2="33.3375" width="0.4064" layer="1"/>
<via x="41.91" y="33.3375" extent="1-16" drill="0.3"/>
<wire x1="41.91" y1="33.3375" x2="44.45" y2="33.3375" width="0.4064" layer="16"/>
<wire x1="44.45" y1="33.3375" x2="45.72" y2="34.6075" width="0.4064" layer="16"/>
<wire x1="45.72" y1="34.6075" x2="45.72" y2="36.195" width="0.4064" layer="16"/>
</signal>
<signal name="PD8">
<contactref element="RN1" pad="10"/>
<contactref element="20V8" pad="14"/>
<contactref element="22V10" pad="16"/>
<wire x1="40.64" y1="13.97" x2="40.64" y2="17.78" width="0.4064" layer="1"/>
<wire x1="40.64" y1="17.78" x2="40.64" y2="19.05" width="0.4064" layer="16"/>
<wire x1="40.64" y1="19.05" x2="39.37" y2="20.32" width="0.4064" layer="16"/>
<wire x1="39.37" y1="20.32" x2="38.1" y2="20.32" width="0.4064" layer="16"/>
<wire x1="38.1" y1="20.32" x2="34.29" y2="24.13" width="0.4064" layer="16"/>
<wire x1="34.29" y1="24.13" x2="34.29" y2="27.305" width="0.4064" layer="16"/>
<wire x1="34.29" y1="27.305" x2="35.56" y2="28.575" width="0.4064" layer="16"/>
</signal>
<signal name="PD9">
<contactref element="R9" pad="2"/>
<contactref element="20V8" pad="16"/>
<contactref element="22V10" pad="15"/>
<wire x1="38.1" y1="13.97" x2="38.1" y2="17.78" width="0.4064" layer="1"/>
<wire x1="38.1" y1="17.78" x2="38.1" y2="22.86" width="0.4064" layer="1"/>
<wire x1="38.1" y1="22.86" x2="39.37" y2="24.13" width="0.4064" layer="1"/>
<wire x1="39.37" y1="24.13" x2="39.37" y2="27.305" width="0.4064" layer="1"/>
<wire x1="39.37" y1="27.305" x2="40.64" y2="28.575" width="0.4064" layer="1"/>
</signal>
<signal name="N$2">
<contactref element="U1" pad="8"/>
<contactref element="R10" pad="2"/>
<wire x1="11.43" y1="24.13" x2="13.97" y2="24.13" width="0.4064" layer="16"/>
</signal>
<signal name="N$7">
<contactref element="U1" pad="3"/>
<contactref element="C10" pad="1"/>
<wire x1="1.27" y1="19.05" x2="3.81" y2="19.05" width="0.8128" layer="16"/>
</signal>
<signal name="N$5">
<contactref element="R10" pad="1"/>
<contactref element="U1" pad="7"/>
<contactref element="R11" pad="2"/>
<contactref element="L1" pad="P$1"/>
<wire x1="11.43" y1="21.59" x2="13.97" y2="21.59" width="0.8128" layer="16"/>
<wire x1="11.43" y1="21.59" x2="11.1125" y2="21.59" width="0.8128" layer="16"/>
<wire x1="11.1125" y1="21.59" x2="8.89" y2="23.8125" width="0.8128" layer="16"/>
<wire x1="8.89" y1="23.8125" x2="8.89" y2="32.06" width="0.8128" layer="16"/>
<wire x1="16.51" y1="18.7325" x2="16.51" y2="19.05" width="0.8128" layer="16"/>
<wire x1="16.51" y1="19.05" x2="13.97" y2="21.59" width="0.8128" layer="16"/>
</signal>
<signal name="N$6">
<contactref element="L1" pad="P$2"/>
<contactref element="D1" pad="A"/>
<contactref element="U1" pad="1"/>
<wire x1="3.81" y1="24.13" x2="3.81" y2="33.98" width="0.8128" layer="16"/>
<wire x1="3.81" y1="33.98" x2="8.89" y2="39.06" width="0.8128" layer="16"/>
<wire x1="8.89" y1="39.06" x2="18.725" y2="39.06" width="0.8128" layer="16"/>
<wire x1="18.725" y1="39.06" x2="19.05" y2="38.735" width="0.8128" layer="16"/>
</signal>
</signals>
</board>
</drawing>
<compatibility>
<note version="6.3" minversion="6.2.2" severity="warning">
Since Version 6.2.2 text objects can contain more than one line,
which will not be processed correctly with this version.
</note>
</compatibility>
</eagle>
