<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="9.5.1">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.057" unitdist="mm" unit="mm" style="lines" multiple="1" display="yes" altdistance="5" altunitdist="mil" altunit="mil"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="16" fill="1" visible="no" active="no"/>
<layer number="3" name="Route3" color="17" fill="1" visible="no" active="no"/>
<layer number="4" name="Route4" color="18" fill="1" visible="no" active="no"/>
<layer number="5" name="Route5" color="19" fill="1" visible="no" active="no"/>
<layer number="6" name="Route6" color="25" fill="1" visible="no" active="no"/>
<layer number="7" name="Route7" color="26" fill="1" visible="no" active="no"/>
<layer number="8" name="Route8" color="27" fill="1" visible="no" active="no"/>
<layer number="9" name="Route9" color="28" fill="1" visible="no" active="no"/>
<layer number="10" name="Route10" color="29" fill="1" visible="no" active="no"/>
<layer number="11" name="Route11" color="30" fill="1" visible="no" active="no"/>
<layer number="12" name="Route12" color="20" fill="1" visible="no" active="no"/>
<layer number="13" name="Route13" color="21" fill="1" visible="no" active="no"/>
<layer number="14" name="Route14" color="22" fill="1" visible="no" active="no"/>
<layer number="15" name="Route15" color="23" fill="1" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="24" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="no" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="no" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="yes"/>
<layer number="50" name="dxf" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
<layer number="99" name="SpiceOrder" color="5" fill="1" visible="no" active="no"/>
<layer number="100" name="vCut" color="13" fill="1" visible="no" active="yes"/>
<layer number="200" name="200bmp" color="1" fill="10" visible="yes" active="yes"/>
<layer number="201" name="201bmp" color="2" fill="10" visible="yes" active="yes"/>
<layer number="202" name="202bmp" color="3" fill="10" visible="yes" active="yes"/>
<layer number="250" name="Descript" color="3" fill="1" visible="no" active="no"/>
<layer number="251" name="SMDround" color="12" fill="11" visible="no" active="no"/>
</layers>
<board>
<plain>
<text x="19.3294" y="13.7668" size="1.27" layer="37">b</text>
<text x="20.5994" y="8.6868" size="1.27" layer="37">c</text>
<text x="16.7894" y="11.8618" size="1.27" layer="37">e</text>
<text x="59.5006" y="5.303" size="2.54" layer="28" font="vector" ratio="20" rot="MR0">+</text>
<text x="59.5126" y="2.738" size="2.54" layer="28" font="vector" ratio="20" rot="MR0">-</text>
<wire x1="0.0254" y1="0" x2="75.057" y2="0.0254" width="0" layer="20"/>
<wire x1="75.057" y1="0.0254" x2="75.1078" y2="45.2628" width="0" layer="20"/>
<wire x1="75.1078" y1="45.2628" x2="-0.0508" y2="45.2374" width="0" layer="20"/>
<wire x1="-0.0508" y1="45.2374" x2="0.0254" y2="0" width="0" layer="20"/>
<rectangle x1="61.6455" y1="26.1345" x2="61.7025" y2="26.1915" layer="200" rot="R270"/>
<rectangle x1="61.5885" y1="23.5695" x2="61.7595" y2="23.6265" layer="200" rot="R270"/>
<rectangle x1="60.99" y1="10.716" x2="62.358" y2="10.773" layer="200" rot="R270"/>
<rectangle x1="60.4485" y1="24.8805" x2="62.8995" y2="24.9375" layer="201" rot="R270"/>
<rectangle x1="55.632" y1="17.442" x2="67.716" y2="17.499" layer="201" rot="R270"/>
<rectangle x1="61.7025" y1="26.1345" x2="61.7595" y2="26.1915" layer="200" rot="R270"/>
<rectangle x1="61.3605" y1="24.7095" x2="62.1015" y2="24.7665" layer="200" rot="R270"/>
<rectangle x1="61.6455" y1="23.5695" x2="61.8165" y2="23.6265" layer="200" rot="R270"/>
<rectangle x1="55.2615" y1="16.5015" x2="68.2005" y2="16.5585" layer="200" rot="R270"/>
<rectangle x1="61.218" y1="25.593" x2="62.244" y2="25.65" layer="201" rot="R270"/>
<rectangle x1="61.389" y1="23.997" x2="62.073" y2="24.054" layer="201" rot="R270"/>
<rectangle x1="61.4745" y1="23.2275" x2="61.9875" y2="23.2845" layer="201" rot="R270"/>
<rectangle x1="61.7595" y1="26.1345" x2="61.8165" y2="26.1915" layer="200" rot="R270"/>
<rectangle x1="61.3035" y1="24.7665" x2="62.2725" y2="24.8235" layer="200" rot="R270"/>
<rectangle x1="61.7025" y1="23.5695" x2="61.8735" y2="23.6265" layer="200" rot="R270"/>
<rectangle x1="55.3185" y1="16.5015" x2="68.2575" y2="16.5585" layer="200" rot="R270"/>
<rectangle x1="61.3605" y1="25.6785" x2="62.2155" y2="25.7355" layer="201" rot="R270"/>
<rectangle x1="61.4745" y1="23.9685" x2="62.1015" y2="24.0255" layer="201" rot="R270"/>
<rectangle x1="61.5315" y1="23.2275" x2="62.0445" y2="23.2845" layer="201" rot="R270"/>
<rectangle x1="61.8165" y1="26.1345" x2="61.8735" y2="26.1915" layer="200" rot="R270"/>
<rectangle x1="61.3035" y1="24.8235" x2="62.3865" y2="24.8805" layer="200" rot="R270"/>
<rectangle x1="61.7595" y1="23.5695" x2="61.9305" y2="23.6265" layer="200" rot="R270"/>
<rectangle x1="60.0495" y1="21.2325" x2="63.6405" y2="21.2895" layer="200" rot="R270"/>
<rectangle x1="57.6555" y1="15.1335" x2="66.0345" y2="15.1905" layer="200" rot="R270"/>
<rectangle x1="61.4745" y1="25.7355" x2="62.2155" y2="25.7925" layer="201" rot="R270"/>
<rectangle x1="61.5315" y1="23.9685" x2="62.1585" y2="24.0255" layer="201" rot="R270"/>
<rectangle x1="61.617" y1="23.256" x2="62.073" y2="23.313" layer="201" rot="R270"/>
<rectangle x1="61.788" y1="19.38" x2="61.902" y2="19.437" layer="201" rot="R270"/>
<rectangle x1="61.389" y1="10.488" x2="62.301" y2="10.545" layer="201" rot="R270"/>
<rectangle x1="61.8735" y1="26.1345" x2="61.9305" y2="26.1915" layer="200" rot="R270"/>
<rectangle x1="61.275" y1="24.909" x2="62.529" y2="24.966" layer="200" rot="R270"/>
<rectangle x1="61.8165" y1="23.5695" x2="61.9875" y2="23.6265" layer="200" rot="R270"/>
<rectangle x1="60.1635" y1="21.2895" x2="63.6405" y2="21.3465" layer="200" rot="R270"/>
<rectangle x1="61.503" y1="18.639" x2="62.301" y2="18.696" layer="200" rot="R270"/>
<rectangle x1="61.5315" y1="17.8125" x2="62.2725" y2="17.8695" layer="200" rot="R270"/>
<rectangle x1="61.5885" y1="17.0715" x2="62.2155" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="61.56" y1="16.302" x2="62.244" y2="16.359" layer="200" rot="R270"/>
<rectangle x1="61.218" y1="15.162" x2="62.586" y2="15.219" layer="200" rot="R270"/>
<rectangle x1="60.135" y1="12.654" x2="63.669" y2="12.711" layer="200" rot="R270"/>
<rectangle x1="61.617" y1="25.821" x2="62.187" y2="25.878" layer="201" rot="R270"/>
<rectangle x1="61.5885" y1="23.9685" x2="62.2155" y2="24.0255" layer="201" rot="R270"/>
<rectangle x1="61.674" y1="23.256" x2="62.13" y2="23.313" layer="201" rot="R270"/>
<rectangle x1="61.6455" y1="19.2945" x2="62.1585" y2="19.3515" layer="201" rot="R270"/>
<rectangle x1="61.8735" y1="18.2115" x2="61.9305" y2="18.2685" layer="201" rot="R270"/>
<rectangle x1="61.8735" y1="17.4135" x2="61.9305" y2="17.4705" layer="201" rot="R270"/>
<rectangle x1="61.845" y1="16.701" x2="61.959" y2="16.758" layer="201" rot="R270"/>
<rectangle x1="61.845" y1="15.903" x2="61.959" y2="15.96" layer="201" rot="R270"/>
<rectangle x1="61.8735" y1="14.4495" x2="61.9305" y2="14.5065" layer="201" rot="R270"/>
<rectangle x1="61.4745" y1="10.4595" x2="62.3295" y2="10.5165" layer="201" rot="R270"/>
<rectangle x1="61.9305" y1="26.1345" x2="61.9875" y2="26.1915" layer="200" rot="R270"/>
<rectangle x1="61.275" y1="24.909" x2="62.643" y2="24.966" layer="200" rot="R270"/>
<rectangle x1="61.8735" y1="23.5695" x2="62.0445" y2="23.6265" layer="200" rot="R270"/>
<rectangle x1="60.2775" y1="21.3465" x2="63.6405" y2="21.4035" layer="200" rot="R270"/>
<rectangle x1="61.674" y1="18.639" x2="62.244" y2="18.696" layer="200" rot="R270"/>
<rectangle x1="61.7025" y1="17.0715" x2="62.2155" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="61.731" y1="15.618" x2="62.187" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="60.135" y1="12.597" x2="63.783" y2="12.654" layer="200" rot="R270"/>
<rectangle x1="61.7025" y1="25.8495" x2="62.2155" y2="25.9065" layer="201" rot="R270"/>
<rectangle x1="61.674" y1="23.94" x2="62.244" y2="23.997" layer="201" rot="R270"/>
<rectangle x1="61.731" y1="23.256" x2="62.187" y2="23.313" layer="201" rot="R270"/>
<rectangle x1="61.5885" y1="19.2945" x2="62.3295" y2="19.3515" layer="201" rot="R270"/>
<rectangle x1="61.446" y1="17.841" x2="62.472" y2="17.898" layer="201" rot="R270"/>
<rectangle x1="61.4745" y1="16.3305" x2="62.4435" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="61.4745" y1="14.9055" x2="62.4435" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="61.5885" y1="10.4025" x2="62.3295" y2="10.4595" layer="201" rot="R270"/>
<rectangle x1="61.9875" y1="26.1345" x2="62.0445" y2="26.1915" layer="200" rot="R270"/>
<rectangle x1="61.275" y1="24.909" x2="62.757" y2="24.966" layer="200" rot="R270"/>
<rectangle x1="61.9305" y1="23.5695" x2="62.1015" y2="23.6265" layer="200" rot="R270"/>
<rectangle x1="60.363" y1="21.432" x2="63.669" y2="21.489" layer="200" rot="R270"/>
<rectangle x1="61.731" y1="18.582" x2="62.301" y2="18.639" layer="200" rot="R270"/>
<rectangle x1="61.7595" y1="17.0715" x2="62.2725" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="61.788" y1="15.618" x2="62.244" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="60.1635" y1="12.5685" x2="63.8685" y2="12.6255" layer="200" rot="R270"/>
<rectangle x1="61.788" y1="25.878" x2="62.244" y2="25.935" layer="201" rot="R270"/>
<rectangle x1="61.7595" y1="23.9115" x2="62.2725" y2="23.9685" layer="201" rot="R270"/>
<rectangle x1="61.8165" y1="23.2845" x2="62.2155" y2="23.3415" layer="201" rot="R270"/>
<rectangle x1="61.56" y1="19.323" x2="62.472" y2="19.38" layer="201" rot="R270"/>
<rectangle x1="61.5315" y1="17.8125" x2="62.5005" y2="17.8695" layer="201" rot="R270"/>
<rectangle x1="61.5315" y1="16.3305" x2="62.5005" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="61.5315" y1="14.9055" x2="62.5005" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="61.674" y1="10.374" x2="62.358" y2="10.431" layer="201" rot="R270"/>
<rectangle x1="62.0445" y1="26.1345" x2="62.1015" y2="26.1915" layer="200" rot="R270"/>
<rectangle x1="61.275" y1="24.966" x2="62.871" y2="25.023" layer="200" rot="R270"/>
<rectangle x1="61.9875" y1="23.5695" x2="62.1585" y2="23.6265" layer="200" rot="R270"/>
<rectangle x1="60.4485" y1="21.4605" x2="63.6975" y2="21.5175" layer="200" rot="R270"/>
<rectangle x1="61.8165" y1="18.5535" x2="62.3295" y2="18.6105" layer="200" rot="R270"/>
<rectangle x1="61.8165" y1="17.0715" x2="62.3295" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="61.845" y1="15.618" x2="62.301" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="61.788" y1="14.136" x2="62.358" y2="14.193" layer="200" rot="R270"/>
<rectangle x1="60.705" y1="12.027" x2="63.441" y2="12.084" layer="200" rot="R270"/>
<rectangle x1="61.902" y1="25.935" x2="62.244" y2="25.992" layer="201" rot="R270"/>
<rectangle x1="61.8165" y1="23.9115" x2="62.3295" y2="23.9685" layer="201" rot="R270"/>
<rectangle x1="61.8735" y1="23.2845" x2="62.2725" y2="23.3415" layer="201" rot="R270"/>
<rectangle x1="61.56" y1="19.323" x2="62.586" y2="19.38" layer="201" rot="R270"/>
<rectangle x1="61.5885" y1="17.8125" x2="62.5575" y2="17.8695" layer="201" rot="R270"/>
<rectangle x1="61.5885" y1="16.3305" x2="62.5575" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="61.5885" y1="14.9055" x2="62.5575" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="61.845" y1="13.623" x2="62.301" y2="13.68" layer="201" rot="R270"/>
<rectangle x1="61.7595" y1="10.3455" x2="62.3865" y2="10.4025" layer="201" rot="R270"/>
<rectangle x1="62.1015" y1="26.1345" x2="62.1585" y2="26.1915" layer="200" rot="R270"/>
<rectangle x1="61.3035" y1="24.9945" x2="62.9565" y2="25.0515" layer="200" rot="R270"/>
<rectangle x1="62.1015" y1="23.5695" x2="62.1585" y2="23.6265" layer="200" rot="R270"/>
<rectangle x1="60.5055" y1="21.5175" x2="63.7545" y2="21.5745" layer="200" rot="R270"/>
<rectangle x1="61.902" y1="18.525" x2="62.358" y2="18.582" layer="200" rot="R270"/>
<rectangle x1="61.8735" y1="17.0715" x2="62.3865" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="61.902" y1="15.618" x2="62.358" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="61.8735" y1="14.1645" x2="62.3865" y2="14.2215" layer="200" rot="R270"/>
<rectangle x1="60.762" y1="11.97" x2="63.498" y2="12.027" layer="200" rot="R270"/>
<rectangle x1="61.9875" y1="25.9635" x2="62.2725" y2="26.0205" layer="201" rot="R270"/>
<rectangle x1="61.845" y1="23.883" x2="62.415" y2="23.94" layer="201" rot="R270"/>
<rectangle x1="61.9305" y1="23.3415" x2="62.3295" y2="23.3985" layer="201" rot="R270"/>
<rectangle x1="61.56" y1="19.323" x2="62.7" y2="19.38" layer="201" rot="R270"/>
<rectangle x1="61.6455" y1="17.8125" x2="62.6145" y2="17.8695" layer="201" rot="R270"/>
<rectangle x1="61.6455" y1="16.3305" x2="62.6145" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="61.6455" y1="14.9055" x2="62.6145" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="61.845" y1="13.623" x2="62.415" y2="13.68" layer="201" rot="R270"/>
<rectangle x1="61.845" y1="10.317" x2="62.415" y2="10.374" layer="201" rot="R270"/>
<rectangle x1="62.1585" y1="26.1345" x2="62.2155" y2="26.1915" layer="200" rot="R270"/>
<rectangle x1="61.3035" y1="24.9945" x2="63.0705" y2="25.0515" layer="200" rot="R270"/>
<rectangle x1="60.534" y1="21.546" x2="63.84" y2="21.603" layer="200" rot="R270"/>
<rectangle x1="61.9875" y1="18.4965" x2="62.3865" y2="18.5535" layer="200" rot="R270"/>
<rectangle x1="61.9305" y1="17.0715" x2="62.4435" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="61.959" y1="15.618" x2="62.415" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="61.959" y1="14.193" x2="62.415" y2="14.25" layer="200" rot="R270"/>
<rectangle x1="60.819" y1="11.913" x2="63.555" y2="11.97" layer="200" rot="R270"/>
<rectangle x1="62.073" y1="25.992" x2="62.301" y2="26.049" layer="201" rot="R270"/>
<rectangle x1="61.731" y1="23.655" x2="62.643" y2="23.712" layer="201" rot="R270"/>
<rectangle x1="61.5885" y1="19.2945" x2="62.7855" y2="19.3515" layer="201" rot="R270"/>
<rectangle x1="61.7025" y1="17.8125" x2="62.6715" y2="17.8695" layer="201" rot="R270"/>
<rectangle x1="61.7025" y1="16.3305" x2="62.6715" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="61.7025" y1="14.9055" x2="62.6715" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="61.845" y1="13.623" x2="62.529" y2="13.68" layer="201" rot="R270"/>
<rectangle x1="61.9305" y1="10.2885" x2="62.4435" y2="10.3455" layer="201" rot="R270"/>
<rectangle x1="62.2155" y1="26.1345" x2="62.2725" y2="26.1915" layer="200" rot="R270"/>
<rectangle x1="61.275" y1="24.966" x2="63.213" y2="25.023" layer="200" rot="R270"/>
<rectangle x1="60.5625" y1="21.5745" x2="63.9255" y2="21.6315" layer="200" rot="R270"/>
<rectangle x1="62.0445" y1="18.4965" x2="62.4435" y2="18.5535" layer="200" rot="R270"/>
<rectangle x1="61.9875" y1="17.0715" x2="62.5005" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="62.016" y1="15.618" x2="62.472" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="62.0445" y1="14.2215" x2="62.4435" y2="14.2785" layer="200" rot="R270"/>
<rectangle x1="60.876" y1="11.856" x2="63.612" y2="11.913" layer="200" rot="R270"/>
<rectangle x1="62.1585" y1="26.0205" x2="62.3295" y2="26.0775" layer="201" rot="R270"/>
<rectangle x1="61.8735" y1="23.6265" x2="62.6145" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="61.6455" y1="19.2945" x2="62.8425" y2="19.3515" layer="201" rot="R270"/>
<rectangle x1="61.7595" y1="17.8125" x2="62.7285" y2="17.8695" layer="201" rot="R270"/>
<rectangle x1="61.7595" y1="16.3305" x2="62.7285" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="61.7595" y1="14.9055" x2="62.7285" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="61.845" y1="13.623" x2="62.643" y2="13.68" layer="201" rot="R270"/>
<rectangle x1="62.016" y1="10.26" x2="62.472" y2="10.317" layer="201" rot="R270"/>
<rectangle x1="62.2725" y1="26.1345" x2="62.3295" y2="26.1915" layer="200" rot="R270"/>
<rectangle x1="61.275" y1="24.966" x2="63.327" y2="25.023" layer="200" rot="R270"/>
<rectangle x1="60.591" y1="21.66" x2="64.011" y2="21.717" layer="200" rot="R270"/>
<rectangle x1="62.1015" y1="18.4965" x2="62.5005" y2="18.5535" layer="200" rot="R270"/>
<rectangle x1="62.0445" y1="17.0715" x2="62.5575" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="62.073" y1="15.618" x2="62.529" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="62.13" y1="14.25" x2="62.472" y2="14.307" layer="200" rot="R270"/>
<rectangle x1="60.933" y1="11.799" x2="63.669" y2="11.856" layer="200" rot="R270"/>
<rectangle x1="62.244" y1="26.049" x2="62.358" y2="26.106" layer="201" rot="R270"/>
<rectangle x1="62.016" y1="23.655" x2="62.586" y2="23.712" layer="201" rot="R270"/>
<rectangle x1="61.674" y1="19.323" x2="62.928" y2="19.38" layer="201" rot="R270"/>
<rectangle x1="61.8165" y1="17.8125" x2="62.7855" y2="17.8695" layer="201" rot="R270"/>
<rectangle x1="61.8165" y1="16.3305" x2="62.7855" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="61.8165" y1="14.9055" x2="62.7855" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="61.845" y1="13.623" x2="62.757" y2="13.68" layer="201" rot="R270"/>
<rectangle x1="62.1015" y1="10.2315" x2="62.5005" y2="10.2885" layer="201" rot="R270"/>
<rectangle x1="62.3295" y1="26.1345" x2="62.3865" y2="26.1915" layer="200" rot="R270"/>
<rectangle x1="61.218" y1="24.852" x2="63.498" y2="24.909" layer="200" rot="R270"/>
<rectangle x1="62.301" y1="23.598" x2="62.415" y2="23.655" layer="200" rot="R270"/>
<rectangle x1="60.591" y1="21.717" x2="64.125" y2="21.774" layer="200" rot="R270"/>
<rectangle x1="62.187" y1="18.468" x2="62.529" y2="18.525" layer="200" rot="R270"/>
<rectangle x1="62.1015" y1="17.0715" x2="62.6145" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="62.3295" y1="16.6725" x2="62.3865" y2="16.7295" layer="200" rot="R270"/>
<rectangle x1="62.301" y1="16.017" x2="62.415" y2="16.074" layer="200" rot="R270"/>
<rectangle x1="62.13" y1="15.618" x2="62.586" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="62.187" y1="14.25" x2="62.529" y2="14.307" layer="200" rot="R270"/>
<rectangle x1="60.9615" y1="11.7705" x2="63.7545" y2="11.8275" layer="200" rot="R270"/>
<rectangle x1="62.301" y1="26.049" x2="62.415" y2="26.106" layer="201" rot="R270"/>
<rectangle x1="62.3295" y1="23.6835" x2="62.3865" y2="23.7405" layer="201" rot="R270"/>
<rectangle x1="62.3295" y1="23.5125" x2="62.3865" y2="23.5695" layer="201" rot="R270"/>
<rectangle x1="61.7025" y1="19.2945" x2="63.0135" y2="19.3515" layer="201" rot="R270"/>
<rectangle x1="61.8735" y1="17.8125" x2="62.8425" y2="17.8695" layer="201" rot="R270"/>
<rectangle x1="62.301" y1="16.758" x2="62.415" y2="16.815" layer="201" rot="R270"/>
<rectangle x1="62.073" y1="16.359" x2="62.643" y2="16.416" layer="201" rot="R270"/>
<rectangle x1="62.301" y1="15.903" x2="62.415" y2="15.96" layer="201" rot="R270"/>
<rectangle x1="61.8735" y1="14.9055" x2="62.8425" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="61.902" y1="13.623" x2="62.814" y2="13.68" layer="201" rot="R270"/>
<rectangle x1="62.187" y1="10.203" x2="62.529" y2="10.26" layer="201" rot="R270"/>
<rectangle x1="62.3865" y1="26.1345" x2="62.4435" y2="26.1915" layer="200" rot="R270"/>
<rectangle x1="59.394" y1="23.028" x2="65.436" y2="23.085" layer="200" rot="R270"/>
<rectangle x1="62.244" y1="18.468" x2="62.586" y2="18.525" layer="200" rot="R270"/>
<rectangle x1="62.1585" y1="17.0715" x2="62.6715" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="62.358" y1="16.644" x2="62.472" y2="16.701" layer="200" rot="R270"/>
<rectangle x1="62.358" y1="16.017" x2="62.472" y2="16.074" layer="200" rot="R270"/>
<rectangle x1="62.187" y1="15.618" x2="62.643" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="62.244" y1="14.25" x2="62.586" y2="14.307" layer="200" rot="R270"/>
<rectangle x1="61.0185" y1="11.7705" x2="63.8115" y2="11.8275" layer="200" rot="R270"/>
<rectangle x1="62.3865" y1="26.0775" x2="62.4435" y2="26.1345" layer="201" rot="R270"/>
<rectangle x1="61.731" y1="19.323" x2="63.099" y2="19.38" layer="201" rot="R270"/>
<rectangle x1="61.9305" y1="17.8125" x2="62.8995" y2="17.8695" layer="201" rot="R270"/>
<rectangle x1="62.358" y1="16.758" x2="62.472" y2="16.815" layer="201" rot="R270"/>
<rectangle x1="62.1585" y1="16.3305" x2="62.6715" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="62.358" y1="15.903" x2="62.472" y2="15.96" layer="201" rot="R270"/>
<rectangle x1="61.9305" y1="14.9055" x2="62.8995" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="61.959" y1="13.623" x2="62.871" y2="13.68" layer="201" rot="R270"/>
<rectangle x1="62.244" y1="10.203" x2="62.586" y2="10.26" layer="201" rot="R270"/>
<rectangle x1="59.394" y1="23.085" x2="65.55" y2="23.142" layer="200" rot="R270"/>
<rectangle x1="62.301" y1="18.468" x2="62.643" y2="18.525" layer="200" rot="R270"/>
<rectangle x1="62.2155" y1="17.0715" x2="62.7285" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="62.244" y1="15.618" x2="62.7" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="62.301" y1="14.25" x2="62.643" y2="14.307" layer="200" rot="R270"/>
<rectangle x1="61.047" y1="11.742" x2="63.897" y2="11.799" layer="200" rot="R270"/>
<rectangle x1="61.788" y1="19.323" x2="63.156" y2="19.38" layer="201" rot="R270"/>
<rectangle x1="61.9875" y1="17.8125" x2="62.9565" y2="17.8695" layer="201" rot="R270"/>
<rectangle x1="61.9875" y1="16.3305" x2="62.9565" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="61.9875" y1="14.9055" x2="62.9565" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="62.016" y1="13.623" x2="62.928" y2="13.68" layer="201" rot="R270"/>
<rectangle x1="62.3295" y1="10.1745" x2="62.6145" y2="10.2315" layer="201" rot="R270"/>
<rectangle x1="59.451" y1="23.085" x2="65.607" y2="23.142" layer="200" rot="R270"/>
<rectangle x1="62.3865" y1="18.4395" x2="62.6715" y2="18.4965" layer="200" rot="R270"/>
<rectangle x1="62.472" y1="17.898" x2="62.586" y2="17.955" layer="200" rot="R270"/>
<rectangle x1="62.5005" y1="17.6985" x2="62.5575" y2="17.7555" layer="200" rot="R270"/>
<rectangle x1="62.2725" y1="17.0715" x2="62.7855" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="62.301" y1="15.618" x2="62.757" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="62.358" y1="14.25" x2="62.7" y2="14.307" layer="200" rot="R270"/>
<rectangle x1="61.0755" y1="11.7135" x2="63.9825" y2="11.7705" layer="200" rot="R270"/>
<rectangle x1="61.8165" y1="19.2945" x2="63.2415" y2="19.3515" layer="201" rot="R270"/>
<rectangle x1="62.358" y1="18.126" x2="62.7" y2="18.183" layer="201" rot="R270"/>
<rectangle x1="62.472" y1="17.784" x2="62.586" y2="17.841" layer="201" rot="R270"/>
<rectangle x1="62.358" y1="17.499" x2="62.7" y2="17.556" layer="201" rot="R270"/>
<rectangle x1="62.0445" y1="16.3305" x2="63.0135" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="62.0445" y1="14.9055" x2="63.0135" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="62.073" y1="13.623" x2="62.985" y2="13.68" layer="201" rot="R270"/>
<rectangle x1="62.415" y1="10.146" x2="62.643" y2="10.203" layer="201" rot="R270"/>
<rectangle x1="59.508" y1="23.085" x2="65.664" y2="23.142" layer="200" rot="R270"/>
<rectangle x1="61.9875" y1="18.0405" x2="63.1845" y2="18.0975" layer="200" rot="R270"/>
<rectangle x1="62.3295" y1="17.0715" x2="62.8425" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="62.358" y1="15.618" x2="62.814" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="62.415" y1="14.25" x2="62.757" y2="14.307" layer="200" rot="R270"/>
<rectangle x1="61.1325" y1="11.7135" x2="64.0395" y2="11.7705" layer="200" rot="R270"/>
<rectangle x1="61.902" y1="19.323" x2="63.27" y2="19.38" layer="201" rot="R270"/>
<rectangle x1="62.529" y1="17.385" x2="62.643" y2="17.442" layer="201" rot="R270"/>
<rectangle x1="62.1015" y1="16.3305" x2="63.0705" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="62.1015" y1="14.9055" x2="63.0705" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="62.13" y1="13.623" x2="63.042" y2="13.68" layer="201" rot="R270"/>
<rectangle x1="62.472" y1="10.146" x2="62.7" y2="10.203" layer="201" rot="R270"/>
<rectangle x1="59.565" y1="23.085" x2="65.721" y2="23.142" layer="200" rot="R270"/>
<rectangle x1="62.0445" y1="18.0405" x2="63.2415" y2="18.0975" layer="200" rot="R270"/>
<rectangle x1="62.3865" y1="17.0715" x2="62.8995" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="62.415" y1="15.618" x2="62.871" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="62.4435" y1="14.2215" x2="62.8425" y2="14.2785" layer="200" rot="R270"/>
<rectangle x1="62.3865" y1="13.6515" x2="62.8995" y2="13.7085" layer="200" rot="R270"/>
<rectangle x1="61.7595" y1="12.3405" x2="63.5265" y2="12.3975" layer="200" rot="R270"/>
<rectangle x1="62.472" y1="10.374" x2="62.814" y2="10.431" layer="200" rot="R270"/>
<rectangle x1="61.959" y1="19.323" x2="63.327" y2="19.38" layer="201" rot="R270"/>
<rectangle x1="62.586" y1="17.385" x2="62.7" y2="17.442" layer="201" rot="R270"/>
<rectangle x1="62.1585" y1="16.3305" x2="63.1275" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="62.1585" y1="14.9055" x2="63.1275" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="62.586" y1="13.965" x2="62.7" y2="14.022" layer="201" rot="R270"/>
<rectangle x1="62.5575" y1="13.3095" x2="62.7285" y2="13.3665" layer="201" rot="R270"/>
<rectangle x1="62.187" y1="11.001" x2="63.099" y2="11.058" layer="201" rot="R270"/>
<rectangle x1="62.5575" y1="10.1175" x2="62.7285" y2="10.1745" layer="201" rot="R270"/>
<rectangle x1="59.5935" y1="23.0565" x2="65.8065" y2="23.1135" layer="200" rot="R270"/>
<rectangle x1="62.3865" y1="18.3255" x2="63.0135" y2="18.3825" layer="200" rot="R270"/>
<rectangle x1="62.529" y1="17.613" x2="62.871" y2="17.67" layer="200" rot="R270"/>
<rectangle x1="62.4435" y1="17.0715" x2="62.9565" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="62.472" y1="15.618" x2="62.928" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="62.472" y1="14.193" x2="62.928" y2="14.25" layer="200" rot="R270"/>
<rectangle x1="62.4435" y1="13.6515" x2="62.9565" y2="13.7085" layer="200" rot="R270"/>
<rectangle x1="61.8735" y1="12.4545" x2="63.5265" y2="12.5115" layer="200" rot="R270"/>
<rectangle x1="62.6145" y1="10.2885" x2="62.7855" y2="10.3455" layer="200" rot="R270"/>
<rectangle x1="62.0445" y1="19.2945" x2="63.3555" y2="19.3515" layer="201" rot="R270"/>
<rectangle x1="62.586" y1="17.898" x2="62.814" y2="17.955" layer="201" rot="R270"/>
<rectangle x1="62.643" y1="17.385" x2="62.757" y2="17.442" layer="201" rot="R270"/>
<rectangle x1="62.2155" y1="16.3305" x2="63.1845" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="62.2155" y1="14.9055" x2="63.1845" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="62.6715" y1="13.9365" x2="62.7285" y2="13.9935" layer="201" rot="R270"/>
<rectangle x1="62.643" y1="13.338" x2="62.757" y2="13.395" layer="201" rot="R270"/>
<rectangle x1="62.073" y1="11.001" x2="63.327" y2="11.058" layer="201" rot="R270"/>
<rectangle x1="62.6145" y1="10.1175" x2="62.7855" y2="10.1745" layer="201" rot="R270"/>
<rectangle x1="59.6505" y1="23.0565" x2="65.8635" y2="23.1135" layer="200" rot="R270"/>
<rectangle x1="62.4435" y1="18.3255" x2="63.0705" y2="18.3825" layer="200" rot="R270"/>
<rectangle x1="62.586" y1="17.613" x2="62.928" y2="17.67" layer="200" rot="R270"/>
<rectangle x1="62.5005" y1="17.0715" x2="63.0135" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="62.529" y1="15.618" x2="62.985" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="62.244" y1="13.908" x2="63.27" y2="13.965" layer="200" rot="R270"/>
<rectangle x1="61.9305" y1="12.5115" x2="63.5835" y2="12.5685" layer="200" rot="R270"/>
<rectangle x1="62.7" y1="10.26" x2="62.814" y2="10.317" layer="200" rot="R270"/>
<rectangle x1="62.1015" y1="19.2945" x2="63.4125" y2="19.3515" layer="201" rot="R270"/>
<rectangle x1="62.643" y1="17.898" x2="62.871" y2="17.955" layer="201" rot="R270"/>
<rectangle x1="62.7" y1="17.385" x2="62.814" y2="17.442" layer="201" rot="R270"/>
<rectangle x1="62.2725" y1="16.3305" x2="63.2415" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="62.2725" y1="14.9055" x2="63.2415" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="62.7285" y1="13.3665" x2="62.7855" y2="13.4235" layer="201" rot="R270"/>
<rectangle x1="62.073" y1="11.001" x2="63.441" y2="11.058" layer="201" rot="R270"/>
<rectangle x1="62.6715" y1="10.1175" x2="62.8425" y2="10.1745" layer="201" rot="R270"/>
<rectangle x1="62.4435" y1="25.7925" x2="63.1845" y2="25.8495" layer="200" rot="R270"/>
<rectangle x1="62.7855" y1="25.1085" x2="62.8425" y2="25.1655" layer="200" rot="R270"/>
<rectangle x1="61.275" y1="23.085" x2="64.353" y2="23.142" layer="200" rot="R270"/>
<rectangle x1="62.3865" y1="20.3205" x2="63.2415" y2="20.3775" layer="200" rot="R270"/>
<rectangle x1="62.472" y1="18.354" x2="63.156" y2="18.411" layer="200" rot="R270"/>
<rectangle x1="62.643" y1="17.613" x2="62.985" y2="17.67" layer="200" rot="R270"/>
<rectangle x1="62.5575" y1="17.0715" x2="63.0705" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="62.586" y1="15.618" x2="63.042" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="61.4745" y1="13.0815" x2="64.1535" y2="13.1385" layer="200" rot="R270"/>
<rectangle x1="62.757" y1="10.203" x2="62.871" y2="10.26" layer="200" rot="R270"/>
<rectangle x1="62.6715" y1="25.2795" x2="62.9565" y2="25.3365" layer="201" rot="R270"/>
<rectangle x1="62.586" y1="24.852" x2="63.042" y2="24.909" layer="201" rot="R270"/>
<rectangle x1="62.415" y1="21.147" x2="63.213" y2="21.204" layer="201" rot="R270"/>
<rectangle x1="62.2155" y1="19.2945" x2="63.4125" y2="19.3515" layer="201" rot="R270"/>
<rectangle x1="62.7" y1="17.898" x2="62.928" y2="17.955" layer="201" rot="R270"/>
<rectangle x1="62.757" y1="17.385" x2="62.871" y2="17.442" layer="201" rot="R270"/>
<rectangle x1="62.3295" y1="16.3305" x2="63.2985" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="62.3295" y1="14.9055" x2="63.2985" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="62.073" y1="11.001" x2="63.555" y2="11.058" layer="201" rot="R270"/>
<rectangle x1="62.757" y1="10.089" x2="62.871" y2="10.146" layer="201" rot="R270"/>
<rectangle x1="62.586" y1="25.878" x2="63.156" y2="25.935" layer="200" rot="R270"/>
<rectangle x1="61.5315" y1="23.1135" x2="64.2105" y2="23.1705" layer="200" rot="R270"/>
<rectangle x1="62.529" y1="20.235" x2="63.213" y2="20.292" layer="200" rot="R270"/>
<rectangle x1="62.5005" y1="18.3255" x2="63.2415" y2="18.3825" layer="200" rot="R270"/>
<rectangle x1="62.6715" y1="17.6415" x2="63.0705" y2="17.6985" layer="200" rot="R270"/>
<rectangle x1="62.6145" y1="17.0715" x2="63.1275" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="62.643" y1="15.618" x2="63.099" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="61.56" y1="13.11" x2="64.182" y2="13.167" layer="200" rot="R270"/>
<rectangle x1="62.8425" y1="10.1745" x2="62.8995" y2="10.2315" layer="200" rot="R270"/>
<rectangle x1="62.301" y1="25.023" x2="63.441" y2="25.08" layer="201" rot="R270"/>
<rectangle x1="62.2725" y1="21.1755" x2="63.4695" y2="21.2325" layer="201" rot="R270"/>
<rectangle x1="62.2725" y1="19.2945" x2="63.4695" y2="19.3515" layer="201" rot="R270"/>
<rectangle x1="62.814" y1="17.898" x2="62.928" y2="17.955" layer="201" rot="R270"/>
<rectangle x1="62.814" y1="17.385" x2="62.928" y2="17.442" layer="201" rot="R270"/>
<rectangle x1="62.3865" y1="16.3305" x2="63.3555" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="62.3865" y1="14.9055" x2="63.3555" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="62.073" y1="11.001" x2="63.669" y2="11.058" layer="201" rot="R270"/>
<rectangle x1="62.814" y1="10.089" x2="62.928" y2="10.146" layer="201" rot="R270"/>
<rectangle x1="62.6715" y1="25.9065" x2="63.1845" y2="25.9635" layer="200" rot="R270"/>
<rectangle x1="61.674" y1="23.085" x2="64.182" y2="23.142" layer="200" rot="R270"/>
<rectangle x1="62.6145" y1="20.2065" x2="63.2415" y2="20.2635" layer="200" rot="R270"/>
<rectangle x1="62.5575" y1="18.3825" x2="63.2985" y2="18.4395" layer="200" rot="R270"/>
<rectangle x1="62.871" y1="17.898" x2="62.985" y2="17.955" layer="200" rot="R270"/>
<rectangle x1="62.415" y1="17.271" x2="63.441" y2="17.328" layer="200" rot="R270"/>
<rectangle x1="62.643" y1="15.618" x2="63.213" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="62.529" y1="14.079" x2="63.327" y2="14.136" layer="200" rot="R270"/>
<rectangle x1="62.0445" y1="12.6825" x2="63.8115" y2="12.7395" layer="200" rot="R270"/>
<rectangle x1="62.2725" y1="24.9945" x2="63.5835" y2="25.0515" layer="201" rot="R270"/>
<rectangle x1="62.2725" y1="21.1755" x2="63.5835" y2="21.2325" layer="201" rot="R270"/>
<rectangle x1="62.358" y1="19.323" x2="63.498" y2="19.38" layer="201" rot="R270"/>
<rectangle x1="62.8995" y1="17.9835" x2="62.9565" y2="18.0405" layer="201" rot="R270"/>
<rectangle x1="62.8995" y1="17.8125" x2="62.9565" y2="17.8695" layer="201" rot="R270"/>
<rectangle x1="62.5005" y1="16.3305" x2="63.3555" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="62.5005" y1="14.9055" x2="63.3555" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="62.871" y1="13.623" x2="62.985" y2="13.68" layer="201" rot="R270"/>
<rectangle x1="62.0445" y1="10.9155" x2="63.8115" y2="10.9725" layer="201" rot="R270"/>
<rectangle x1="62.7855" y1="25.9635" x2="63.1845" y2="26.0205" layer="200" rot="R270"/>
<rectangle x1="61.788" y1="23.085" x2="64.182" y2="23.142" layer="200" rot="R270"/>
<rectangle x1="62.6715" y1="20.1495" x2="63.2985" y2="20.2065" layer="200" rot="R270"/>
<rectangle x1="62.586" y1="18.411" x2="63.384" y2="18.468" layer="200" rot="R270"/>
<rectangle x1="62.3865" y1="17.3565" x2="63.5835" y2="17.4135" layer="200" rot="R270"/>
<rectangle x1="62.6715" y1="15.6465" x2="63.2985" y2="15.7035" layer="200" rot="R270"/>
<rectangle x1="62.5575" y1="14.1075" x2="63.4125" y2="14.1645" layer="200" rot="R270"/>
<rectangle x1="62.1015" y1="12.6825" x2="63.8685" y2="12.7395" layer="200" rot="R270"/>
<rectangle x1="62.244" y1="25.023" x2="63.726" y2="25.08" layer="201" rot="R270"/>
<rectangle x1="62.2725" y1="21.1755" x2="63.6975" y2="21.2325" layer="201" rot="R270"/>
<rectangle x1="62.472" y1="19.323" x2="63.498" y2="19.38" layer="201" rot="R270"/>
<rectangle x1="62.9565" y1="17.9835" x2="63.0135" y2="18.0405" layer="201" rot="R270"/>
<rectangle x1="62.586" y1="16.359" x2="63.384" y2="16.416" layer="201" rot="R270"/>
<rectangle x1="62.586" y1="14.934" x2="63.384" y2="14.991" layer="201" rot="R270"/>
<rectangle x1="62.928" y1="13.623" x2="63.042" y2="13.68" layer="201" rot="R270"/>
<rectangle x1="62.1015" y1="10.9155" x2="63.8685" y2="10.9725" layer="201" rot="R270"/>
<rectangle x1="62.8425" y1="25.9635" x2="63.2415" y2="26.0205" layer="200" rot="R270"/>
<rectangle x1="61.8735" y1="23.1135" x2="64.2105" y2="23.1705" layer="200" rot="R270"/>
<rectangle x1="62.7285" y1="20.0925" x2="63.3555" y2="20.1495" layer="200" rot="R270"/>
<rectangle x1="62.586" y1="18.411" x2="63.498" y2="18.468" layer="200" rot="R270"/>
<rectangle x1="62.472" y1="17.328" x2="63.612" y2="17.385" layer="200" rot="R270"/>
<rectangle x1="62.7285" y1="15.6465" x2="63.3555" y2="15.7035" layer="200" rot="R270"/>
<rectangle x1="62.6145" y1="14.1075" x2="63.4695" y2="14.1645" layer="200" rot="R270"/>
<rectangle x1="62.187" y1="12.711" x2="63.897" y2="12.768" layer="200" rot="R270"/>
<rectangle x1="63.0135" y1="10.1175" x2="63.0705" y2="10.1745" layer="200" rot="R270"/>
<rectangle x1="62.301" y1="25.023" x2="63.783" y2="25.08" layer="201" rot="R270"/>
<rectangle x1="62.2725" y1="21.1755" x2="63.8115" y2="21.2325" layer="201" rot="R270"/>
<rectangle x1="62.586" y1="19.323" x2="63.498" y2="19.38" layer="201" rot="R270"/>
<rectangle x1="63.0135" y1="17.9265" x2="63.0705" y2="17.9835" layer="201" rot="R270"/>
<rectangle x1="62.643" y1="16.359" x2="63.441" y2="16.416" layer="201" rot="R270"/>
<rectangle x1="62.643" y1="14.934" x2="63.441" y2="14.991" layer="201" rot="R270"/>
<rectangle x1="62.985" y1="13.623" x2="63.099" y2="13.68" layer="201" rot="R270"/>
<rectangle x1="62.187" y1="11.001" x2="63.897" y2="11.058" layer="201" rot="R270"/>
<rectangle x1="63.0135" y1="10.0605" x2="63.0705" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="62.928" y1="25.992" x2="63.27" y2="26.049" layer="200" rot="R270"/>
<rectangle x1="63.042" y1="25.65" x2="63.156" y2="25.707" layer="200" rot="R270"/>
<rectangle x1="62.6145" y1="24.8235" x2="63.5835" y2="24.8805" layer="200" rot="R270"/>
<rectangle x1="63.0705" y1="24.1965" x2="63.1275" y2="24.2535" layer="200" rot="R270"/>
<rectangle x1="62.7" y1="23.37" x2="63.498" y2="23.427" layer="200" rot="R270"/>
<rectangle x1="62.757" y1="22.344" x2="63.441" y2="22.401" layer="200" rot="R270"/>
<rectangle x1="62.9565" y1="21.6885" x2="63.2415" y2="21.7455" layer="200" rot="R270"/>
<rectangle x1="63.0705" y1="21.4605" x2="63.1275" y2="21.5175" layer="200" rot="R270"/>
<rectangle x1="62.985" y1="21.204" x2="63.213" y2="21.261" layer="200" rot="R270"/>
<rectangle x1="62.757" y1="20.007" x2="63.441" y2="20.064" layer="200" rot="R270"/>
<rectangle x1="62.5575" y1="18.3825" x2="63.6405" y2="18.4395" layer="200" rot="R270"/>
<rectangle x1="62.586" y1="17.271" x2="63.612" y2="17.328" layer="200" rot="R270"/>
<rectangle x1="62.7855" y1="15.6465" x2="63.4125" y2="15.7035" layer="200" rot="R270"/>
<rectangle x1="62.814" y1="14.25" x2="63.384" y2="14.307" layer="200" rot="R270"/>
<rectangle x1="62.985" y1="13.794" x2="63.213" y2="13.851" layer="200" rot="R270"/>
<rectangle x1="62.985" y1="13.509" x2="63.213" y2="13.566" layer="200" rot="R270"/>
<rectangle x1="62.3865" y1="12.5685" x2="63.8115" y2="12.6255" layer="200" rot="R270"/>
<rectangle x1="63.042" y1="25.764" x2="63.156" y2="25.821" layer="201" rot="R270"/>
<rectangle x1="62.9565" y1="25.4505" x2="63.2415" y2="25.5075" layer="201" rot="R270"/>
<rectangle x1="63.042" y1="24.282" x2="63.156" y2="24.339" layer="201" rot="R270"/>
<rectangle x1="62.8995" y1="23.9685" x2="63.2985" y2="24.0255" layer="201" rot="R270"/>
<rectangle x1="62.9565" y1="22.8285" x2="63.2415" y2="22.8855" layer="201" rot="R270"/>
<rectangle x1="63.0135" y1="21.9165" x2="63.1845" y2="21.9735" layer="201" rot="R270"/>
<rectangle x1="63.0705" y1="21.5175" x2="63.1275" y2="21.5745" layer="201" rot="R270"/>
<rectangle x1="63.042" y1="21.375" x2="63.156" y2="21.432" layer="201" rot="R270"/>
<rectangle x1="62.7285" y1="20.7195" x2="63.4695" y2="20.7765" layer="201" rot="R270"/>
<rectangle x1="62.7285" y1="19.2945" x2="63.4695" y2="19.3515" layer="201" rot="R270"/>
<rectangle x1="63.0705" y1="17.8125" x2="63.1275" y2="17.8695" layer="201" rot="R270"/>
<rectangle x1="62.7" y1="16.359" x2="63.498" y2="16.416" layer="201" rot="R270"/>
<rectangle x1="62.7" y1="14.934" x2="63.498" y2="14.991" layer="201" rot="R270"/>
<rectangle x1="63.0705" y1="13.9365" x2="63.1275" y2="13.9935" layer="201" rot="R270"/>
<rectangle x1="63.0705" y1="13.6515" x2="63.1275" y2="13.7085" layer="201" rot="R270"/>
<rectangle x1="63.042" y1="13.338" x2="63.156" y2="13.395" layer="201" rot="R270"/>
<rectangle x1="62.187" y1="10.944" x2="64.011" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="63.099" y1="25.707" x2="63.213" y2="25.764" layer="200" rot="R270"/>
<rectangle x1="63.042" y1="25.251" x2="63.27" y2="25.308" layer="200" rot="R270"/>
<rectangle x1="62.928" y1="24.852" x2="63.384" y2="24.909" layer="200" rot="R270"/>
<rectangle x1="63.042" y1="24.396" x2="63.27" y2="24.453" layer="200" rot="R270"/>
<rectangle x1="62.928" y1="21.66" x2="63.384" y2="21.717" layer="200" rot="R270"/>
<rectangle x1="63.099" y1="21.204" x2="63.213" y2="21.261" layer="200" rot="R270"/>
<rectangle x1="62.7855" y1="19.9785" x2="63.5265" y2="20.0355" layer="200" rot="R270"/>
<rectangle x1="62.5575" y1="18.4395" x2="63.7545" y2="18.4965" layer="200" rot="R270"/>
<rectangle x1="62.643" y1="17.271" x2="63.669" y2="17.328" layer="200" rot="R270"/>
<rectangle x1="62.8425" y1="15.6465" x2="63.4695" y2="15.7035" layer="200" rot="R270"/>
<rectangle x1="62.8995" y1="14.2785" x2="63.4125" y2="14.3355" layer="200" rot="R270"/>
<rectangle x1="62.8995" y1="13.6515" x2="63.4125" y2="13.7085" layer="200" rot="R270"/>
<rectangle x1="62.472" y1="12.54" x2="63.84" y2="12.597" layer="200" rot="R270"/>
<rectangle x1="63.1275" y1="10.1175" x2="63.1845" y2="10.1745" layer="200" rot="R270"/>
<rectangle x1="62.9565" y1="25.9635" x2="63.3555" y2="26.0205" layer="201" rot="R270"/>
<rectangle x1="63.0135" y1="25.5075" x2="63.2985" y2="25.5645" layer="201" rot="R270"/>
<rectangle x1="63.1275" y1="25.1085" x2="63.1845" y2="25.1655" layer="201" rot="R270"/>
<rectangle x1="63.099" y1="24.567" x2="63.213" y2="24.624" layer="201" rot="R270"/>
<rectangle x1="61.959" y1="23.085" x2="64.353" y2="23.142" layer="201" rot="R270"/>
<rectangle x1="63.0705" y1="21.3465" x2="63.2415" y2="21.4035" layer="201" rot="R270"/>
<rectangle x1="62.757" y1="20.748" x2="63.555" y2="20.805" layer="201" rot="R270"/>
<rectangle x1="62.871" y1="19.323" x2="63.441" y2="19.38" layer="201" rot="R270"/>
<rectangle x1="63.1275" y1="17.8125" x2="63.1845" y2="17.8695" layer="201" rot="R270"/>
<rectangle x1="62.757" y1="16.359" x2="63.555" y2="16.416" layer="201" rot="R270"/>
<rectangle x1="62.757" y1="14.934" x2="63.555" y2="14.991" layer="201" rot="R270"/>
<rectangle x1="63.099" y1="13.965" x2="63.213" y2="14.022" layer="201" rot="R270"/>
<rectangle x1="63.0705" y1="13.3095" x2="63.2415" y2="13.3665" layer="201" rot="R270"/>
<rectangle x1="62.301" y1="11.001" x2="64.011" y2="11.058" layer="201" rot="R270"/>
<rectangle x1="63.1275" y1="10.0605" x2="63.1845" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="62.7855" y1="19.8645" x2="63.6405" y2="19.9215" layer="200" rot="R270"/>
<rectangle x1="62.529" y1="18.582" x2="63.897" y2="18.639" layer="200" rot="R270"/>
<rectangle x1="62.6715" y1="17.2995" x2="63.7545" y2="17.3565" layer="200" rot="R270"/>
<rectangle x1="62.8995" y1="15.6465" x2="63.5265" y2="15.7035" layer="200" rot="R270"/>
<rectangle x1="62.985" y1="14.307" x2="63.441" y2="14.364" layer="200" rot="R270"/>
<rectangle x1="63.0705" y1="13.7085" x2="63.3555" y2="13.7655" layer="200" rot="R270"/>
<rectangle x1="63.156" y1="13.452" x2="63.27" y2="13.509" layer="200" rot="R270"/>
<rectangle x1="62.529" y1="12.54" x2="63.897" y2="12.597" layer="200" rot="R270"/>
<rectangle x1="60.2775" y1="23.2275" x2="66.1485" y2="23.2845" layer="201" rot="R270"/>
<rectangle x1="63.1275" y1="19.3515" x2="63.2985" y2="19.4085" layer="201" rot="R270"/>
<rectangle x1="63.1845" y1="17.8695" x2="63.2415" y2="17.9265" layer="201" rot="R270"/>
<rectangle x1="62.814" y1="16.359" x2="63.612" y2="16.416" layer="201" rot="R270"/>
<rectangle x1="62.814" y1="14.934" x2="63.612" y2="14.991" layer="201" rot="R270"/>
<rectangle x1="63.099" y1="13.965" x2="63.327" y2="14.022" layer="201" rot="R270"/>
<rectangle x1="63.1845" y1="13.5375" x2="63.2415" y2="13.5945" layer="201" rot="R270"/>
<rectangle x1="63.1275" y1="13.3095" x2="63.2985" y2="13.3665" layer="201" rot="R270"/>
<rectangle x1="62.301" y1="10.944" x2="64.125" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="61.503" y1="18.525" x2="65.037" y2="18.582" layer="200" rot="R270"/>
<rectangle x1="62.9565" y1="15.6465" x2="63.5835" y2="15.7035" layer="200" rot="R270"/>
<rectangle x1="63.042" y1="14.307" x2="63.498" y2="14.364" layer="200" rot="R270"/>
<rectangle x1="62.6145" y1="12.5115" x2="63.9255" y2="12.5685" layer="200" rot="R270"/>
<rectangle x1="60.3345" y1="23.2275" x2="66.2055" y2="23.2845" layer="201" rot="R270"/>
<rectangle x1="62.871" y1="16.359" x2="63.669" y2="16.416" layer="201" rot="R270"/>
<rectangle x1="62.871" y1="14.934" x2="63.669" y2="14.991" layer="201" rot="R270"/>
<rectangle x1="62.814" y1="13.623" x2="63.726" y2="13.68" layer="201" rot="R270"/>
<rectangle x1="62.358" y1="10.944" x2="64.182" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="62.2155" y1="19.1805" x2="64.4385" y2="19.2375" layer="200" rot="R270"/>
<rectangle x1="63.27" y1="17.898" x2="63.384" y2="17.955" layer="200" rot="R270"/>
<rectangle x1="63.156" y1="17.613" x2="63.498" y2="17.67" layer="200" rot="R270"/>
<rectangle x1="63.042" y1="17.1" x2="63.612" y2="17.157" layer="200" rot="R270"/>
<rectangle x1="63.042" y1="15.618" x2="63.612" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="63.1275" y1="14.2785" x2="63.5265" y2="14.3355" layer="200" rot="R270"/>
<rectangle x1="62.6715" y1="12.5115" x2="63.9825" y2="12.5685" layer="200" rot="R270"/>
<rectangle x1="60.3915" y1="23.2275" x2="66.2625" y2="23.2845" layer="201" rot="R270"/>
<rectangle x1="63.27" y1="18.012" x2="63.384" y2="18.069" layer="201" rot="R270"/>
<rectangle x1="63.2985" y1="17.8125" x2="63.3555" y2="17.8695" layer="201" rot="R270"/>
<rectangle x1="63.2985" y1="17.4135" x2="63.3555" y2="17.4705" layer="201" rot="R270"/>
<rectangle x1="62.871" y1="16.359" x2="63.783" y2="16.416" layer="201" rot="R270"/>
<rectangle x1="62.8995" y1="14.9055" x2="63.7545" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="62.871" y1="13.623" x2="63.783" y2="13.68" layer="201" rot="R270"/>
<rectangle x1="62.415" y1="10.944" x2="64.239" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="63.2985" y1="20.9475" x2="63.4695" y2="21.0045" layer="200" rot="R270"/>
<rectangle x1="62.1585" y1="19.0665" x2="64.6095" y2="19.1235" layer="200" rot="R270"/>
<rectangle x1="63.213" y1="17.613" x2="63.555" y2="17.67" layer="200" rot="R270"/>
<rectangle x1="63.1275" y1="17.0715" x2="63.6405" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="63.156" y1="15.618" x2="63.612" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="63.213" y1="14.25" x2="63.555" y2="14.307" layer="200" rot="R270"/>
<rectangle x1="62.7285" y1="12.5115" x2="64.0395" y2="12.5685" layer="200" rot="R270"/>
<rectangle x1="60.819" y1="23.598" x2="65.949" y2="23.655" layer="201" rot="R270"/>
<rectangle x1="63.099" y1="20.577" x2="63.669" y2="20.634" layer="201" rot="R270"/>
<rectangle x1="63.3555" y1="17.8125" x2="63.4125" y2="17.8695" layer="201" rot="R270"/>
<rectangle x1="63.327" y1="17.385" x2="63.441" y2="17.442" layer="201" rot="R270"/>
<rectangle x1="62.8995" y1="16.3305" x2="63.8685" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="62.8995" y1="14.9055" x2="63.8685" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="62.928" y1="13.623" x2="63.84" y2="13.68" layer="201" rot="R270"/>
<rectangle x1="62.472" y1="10.944" x2="64.296" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="63.327" y1="20.919" x2="63.555" y2="20.976" layer="200" rot="R270"/>
<rectangle x1="62.016" y1="18.867" x2="64.866" y2="18.924" layer="200" rot="R270"/>
<rectangle x1="63.1845" y1="17.0715" x2="63.6975" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="63.213" y1="15.618" x2="63.669" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="63.27" y1="14.25" x2="63.612" y2="14.307" layer="200" rot="R270"/>
<rectangle x1="62.7855" y1="12.5115" x2="64.0965" y2="12.5685" layer="200" rot="R270"/>
<rectangle x1="60.876" y1="23.598" x2="66.006" y2="23.655" layer="201" rot="R270"/>
<rectangle x1="63.1845" y1="20.5485" x2="63.6975" y2="20.6055" layer="201" rot="R270"/>
<rectangle x1="63.384" y1="17.385" x2="63.498" y2="17.442" layer="201" rot="R270"/>
<rectangle x1="62.9565" y1="16.3305" x2="63.9255" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="62.9565" y1="14.9055" x2="63.9255" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="62.985" y1="13.623" x2="63.897" y2="13.68" layer="201" rot="R270"/>
<rectangle x1="62.529" y1="10.944" x2="64.353" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="63.384" y1="20.919" x2="63.612" y2="20.976" layer="200" rot="R270"/>
<rectangle x1="62.073" y1="18.867" x2="64.923" y2="18.924" layer="200" rot="R270"/>
<rectangle x1="63.2415" y1="17.0715" x2="63.7545" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="63.27" y1="15.618" x2="63.726" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="63.327" y1="14.25" x2="63.669" y2="14.307" layer="200" rot="R270"/>
<rectangle x1="62.8425" y1="12.5115" x2="64.1535" y2="12.5685" layer="200" rot="R270"/>
<rectangle x1="60.933" y1="23.598" x2="66.063" y2="23.655" layer="201" rot="R270"/>
<rectangle x1="63.2415" y1="20.5485" x2="63.7545" y2="20.6055" layer="201" rot="R270"/>
<rectangle x1="63.441" y1="17.385" x2="63.555" y2="17.442" layer="201" rot="R270"/>
<rectangle x1="63.0135" y1="16.3305" x2="63.9825" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="63.0135" y1="14.9055" x2="63.9825" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="63.042" y1="13.623" x2="63.954" y2="13.68" layer="201" rot="R270"/>
<rectangle x1="62.586" y1="10.944" x2="64.41" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="63.441" y1="20.919" x2="63.669" y2="20.976" layer="200" rot="R270"/>
<rectangle x1="62.5575" y1="19.2945" x2="64.5525" y2="19.3515" layer="200" rot="R270"/>
<rectangle x1="63.2985" y1="17.0715" x2="63.8115" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="63.327" y1="15.618" x2="63.783" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="63.384" y1="14.25" x2="63.726" y2="14.307" layer="200" rot="R270"/>
<rectangle x1="62.871" y1="12.54" x2="64.239" y2="12.597" layer="200" rot="R270"/>
<rectangle x1="60.99" y1="23.598" x2="66.12" y2="23.655" layer="201" rot="R270"/>
<rectangle x1="63.2985" y1="20.5485" x2="63.8115" y2="20.6055" layer="201" rot="R270"/>
<rectangle x1="63.0705" y1="17.8125" x2="64.0395" y2="17.8695" layer="201" rot="R270"/>
<rectangle x1="63.0705" y1="16.3305" x2="64.0395" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="63.0705" y1="14.9055" x2="64.0395" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="63.1275" y1="13.6515" x2="63.9825" y2="13.7085" layer="201" rot="R270"/>
<rectangle x1="62.643" y1="10.944" x2="64.467" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="63.4695" y1="20.8905" x2="63.7545" y2="20.9475" layer="200" rot="R270"/>
<rectangle x1="62.586" y1="19.323" x2="64.638" y2="19.38" layer="200" rot="R270"/>
<rectangle x1="63.3555" y1="17.0715" x2="63.8685" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="63.384" y1="15.618" x2="63.84" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="63.4125" y1="14.2215" x2="63.8115" y2="14.2785" layer="200" rot="R270"/>
<rectangle x1="62.928" y1="12.54" x2="64.296" y2="12.597" layer="200" rot="R270"/>
<rectangle x1="61.047" y1="23.598" x2="66.177" y2="23.655" layer="201" rot="R270"/>
<rectangle x1="63.4125" y1="20.5485" x2="63.8115" y2="20.6055" layer="201" rot="R270"/>
<rectangle x1="63.1275" y1="17.8125" x2="64.0965" y2="17.8695" layer="201" rot="R270"/>
<rectangle x1="63.1275" y1="16.3305" x2="64.0965" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="63.1275" y1="14.9055" x2="64.0965" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="63.213" y1="13.623" x2="64.011" y2="13.68" layer="201" rot="R270"/>
<rectangle x1="62.7" y1="10.944" x2="64.524" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="63.5265" y1="20.8905" x2="63.8115" y2="20.9475" layer="200" rot="R270"/>
<rectangle x1="62.643" y1="19.323" x2="64.695" y2="19.38" layer="200" rot="R270"/>
<rectangle x1="63.4125" y1="17.0715" x2="63.9255" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="63.441" y1="15.618" x2="63.897" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="63.441" y1="14.193" x2="63.897" y2="14.25" layer="200" rot="R270"/>
<rectangle x1="62.9565" y1="12.5685" x2="64.3815" y2="12.6255" layer="200" rot="R270"/>
<rectangle x1="61.104" y1="23.598" x2="66.234" y2="23.655" layer="201" rot="R270"/>
<rectangle x1="63.4695" y1="20.5485" x2="63.8685" y2="20.6055" layer="201" rot="R270"/>
<rectangle x1="63.1845" y1="17.8125" x2="64.1535" y2="17.8695" layer="201" rot="R270"/>
<rectangle x1="63.1845" y1="16.3305" x2="64.1535" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="63.1845" y1="14.9055" x2="64.1535" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="63.327" y1="13.623" x2="64.011" y2="13.68" layer="201" rot="R270"/>
<rectangle x1="62.757" y1="10.944" x2="64.581" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="63.555" y1="20.862" x2="63.897" y2="20.919" layer="200" rot="R270"/>
<rectangle x1="62.6715" y1="19.3515" x2="64.7805" y2="19.4085" layer="200" rot="R270"/>
<rectangle x1="63.4695" y1="17.0715" x2="63.9825" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="63.498" y1="15.618" x2="63.954" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="63.6975" y1="14.5635" x2="63.7545" y2="14.6205" layer="200" rot="R270"/>
<rectangle x1="63.4695" y1="14.1645" x2="63.9825" y2="14.2215" layer="200" rot="R270"/>
<rectangle x1="62.9565" y1="12.6255" x2="64.4955" y2="12.6825" layer="200" rot="R270"/>
<rectangle x1="61.161" y1="23.598" x2="66.291" y2="23.655" layer="201" rot="R270"/>
<rectangle x1="63.5835" y1="20.5485" x2="63.8685" y2="20.6055" layer="201" rot="R270"/>
<rectangle x1="63.2415" y1="17.8125" x2="64.2105" y2="17.8695" layer="201" rot="R270"/>
<rectangle x1="63.2415" y1="16.3305" x2="64.2105" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="63.327" y1="14.991" x2="64.125" y2="15.048" layer="201" rot="R270"/>
<rectangle x1="63.669" y1="14.478" x2="63.783" y2="14.535" layer="201" rot="R270"/>
<rectangle x1="63.4695" y1="13.6515" x2="63.9825" y2="13.7085" layer="201" rot="R270"/>
<rectangle x1="62.814" y1="10.944" x2="64.638" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="63.612" y1="20.862" x2="63.954" y2="20.919" layer="200" rot="R270"/>
<rectangle x1="62.7" y1="19.38" x2="64.866" y2="19.437" layer="200" rot="R270"/>
<rectangle x1="63.5265" y1="17.0715" x2="64.0395" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="63.555" y1="15.618" x2="64.011" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="63.726" y1="15.219" x2="63.84" y2="15.276" layer="200" rot="R270"/>
<rectangle x1="63.726" y1="14.592" x2="63.84" y2="14.649" layer="200" rot="R270"/>
<rectangle x1="63.4125" y1="14.0505" x2="64.1535" y2="14.1075" layer="200" rot="R270"/>
<rectangle x1="62.9565" y1="12.6825" x2="64.6095" y2="12.7395" layer="200" rot="R270"/>
<rectangle x1="63.7545" y1="10.1175" x2="63.8115" y2="10.1745" layer="200" rot="R270"/>
<rectangle x1="61.218" y1="23.598" x2="66.348" y2="23.655" layer="201" rot="R270"/>
<rectangle x1="63.669" y1="20.577" x2="63.897" y2="20.634" layer="201" rot="R270"/>
<rectangle x1="63.2985" y1="17.8125" x2="64.2675" y2="17.8695" layer="201" rot="R270"/>
<rectangle x1="63.2985" y1="16.3305" x2="64.2675" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="63.726" y1="15.333" x2="63.84" y2="15.39" layer="201" rot="R270"/>
<rectangle x1="63.5265" y1="14.9055" x2="64.0395" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="63.726" y1="14.478" x2="63.84" y2="14.535" layer="201" rot="R270"/>
<rectangle x1="63.6975" y1="13.5945" x2="63.8685" y2="13.6515" layer="201" rot="R270"/>
<rectangle x1="62.928" y1="11.001" x2="64.638" y2="11.058" layer="201" rot="R270"/>
<rectangle x1="63.7545" y1="10.0605" x2="63.8115" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="63.6975" y1="20.8905" x2="63.9825" y2="20.9475" layer="200" rot="R270"/>
<rectangle x1="62.7285" y1="19.4085" x2="64.9515" y2="19.4655" layer="200" rot="R270"/>
<rectangle x1="63.5835" y1="17.0715" x2="64.0965" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="63.612" y1="15.618" x2="64.068" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="63.783" y1="15.219" x2="63.897" y2="15.276" layer="200" rot="R270"/>
<rectangle x1="63.783" y1="14.592" x2="63.897" y2="14.649" layer="200" rot="R270"/>
<rectangle x1="62.5575" y1="13.1385" x2="65.1225" y2="13.1955" layer="200" rot="R270"/>
<rectangle x1="61.275" y1="23.598" x2="66.405" y2="23.655" layer="201" rot="R270"/>
<rectangle x1="63.726" y1="20.634" x2="63.954" y2="20.691" layer="201" rot="R270"/>
<rectangle x1="63.3555" y1="17.8125" x2="64.3245" y2="17.8695" layer="201" rot="R270"/>
<rectangle x1="63.3555" y1="16.3305" x2="64.3245" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="63.783" y1="15.333" x2="63.897" y2="15.39" layer="201" rot="R270"/>
<rectangle x1="63.5835" y1="14.9055" x2="64.0965" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="63.783" y1="14.478" x2="63.897" y2="14.535" layer="201" rot="R270"/>
<rectangle x1="62.928" y1="10.944" x2="64.752" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="63.726" y1="20.919" x2="64.068" y2="20.976" layer="200" rot="R270"/>
<rectangle x1="62.757" y1="19.437" x2="65.037" y2="19.494" layer="200" rot="R270"/>
<rectangle x1="63.6405" y1="17.0715" x2="64.1535" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="63.669" y1="15.618" x2="64.125" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="63.8685" y1="15.2475" x2="63.9255" y2="15.3045" layer="200" rot="R270"/>
<rectangle x1="63.8685" y1="14.5635" x2="63.9255" y2="14.6205" layer="200" rot="R270"/>
<rectangle x1="62.6145" y1="13.1385" x2="65.1795" y2="13.1955" layer="200" rot="R270"/>
<rectangle x1="61.3605" y1="23.6265" x2="66.4335" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="63.8115" y1="20.6625" x2="63.9825" y2="20.7195" layer="201" rot="R270"/>
<rectangle x1="63.4125" y1="17.8125" x2="64.3815" y2="17.8695" layer="201" rot="R270"/>
<rectangle x1="63.4125" y1="16.3305" x2="64.3815" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="63.84" y1="15.333" x2="63.954" y2="15.39" layer="201" rot="R270"/>
<rectangle x1="63.5835" y1="14.9055" x2="64.2105" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="63.84" y1="14.478" x2="63.954" y2="14.535" layer="201" rot="R270"/>
<rectangle x1="62.985" y1="10.944" x2="64.809" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="62.5575" y1="19.6935" x2="65.3505" y2="19.7505" layer="200" rot="R270"/>
<rectangle x1="63.6975" y1="17.0715" x2="64.2105" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="63.726" y1="15.618" x2="64.182" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="62.6715" y1="13.1385" x2="65.2365" y2="13.1955" layer="200" rot="R270"/>
<rectangle x1="61.4175" y1="23.6265" x2="66.4905" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="63.4695" y1="17.8125" x2="64.4385" y2="17.8695" layer="201" rot="R270"/>
<rectangle x1="63.4695" y1="16.3305" x2="64.4385" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="63.4695" y1="14.9055" x2="64.4385" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="63.042" y1="10.944" x2="64.866" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="62.6145" y1="19.6935" x2="65.4075" y2="19.7505" layer="200" rot="R270"/>
<rectangle x1="63.7545" y1="17.0715" x2="64.2675" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="63.783" y1="15.618" x2="64.239" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="62.7285" y1="13.1385" x2="65.2935" y2="13.1955" layer="200" rot="R270"/>
<rectangle x1="61.4745" y1="23.6265" x2="66.5475" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="63.5265" y1="17.8125" x2="64.4955" y2="17.8695" layer="201" rot="R270"/>
<rectangle x1="63.5265" y1="16.3305" x2="64.4955" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="63.5265" y1="14.9055" x2="64.4955" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="63.099" y1="10.944" x2="64.923" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="62.6715" y1="19.6935" x2="65.4645" y2="19.7505" layer="200" rot="R270"/>
<rectangle x1="63.8115" y1="17.0715" x2="64.3245" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="63.84" y1="15.618" x2="64.296" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="62.7855" y1="13.1385" x2="65.3505" y2="13.1955" layer="200" rot="R270"/>
<rectangle x1="61.5315" y1="23.6265" x2="66.6045" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="63.5835" y1="17.8125" x2="64.5525" y2="17.8695" layer="201" rot="R270"/>
<rectangle x1="63.5835" y1="16.3305" x2="64.5525" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="63.5835" y1="14.9055" x2="64.5525" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="63.156" y1="10.944" x2="64.98" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="62.7285" y1="19.6935" x2="65.5215" y2="19.7505" layer="200" rot="R270"/>
<rectangle x1="63.8685" y1="17.0715" x2="64.3815" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="63.897" y1="15.618" x2="64.353" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="62.8425" y1="13.1385" x2="65.4075" y2="13.1955" layer="200" rot="R270"/>
<rectangle x1="61.5885" y1="23.6265" x2="66.6615" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="63.6405" y1="17.8125" x2="64.6095" y2="17.8695" layer="201" rot="R270"/>
<rectangle x1="63.6405" y1="16.3305" x2="64.6095" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="63.6405" y1="14.9055" x2="64.6095" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="63.213" y1="10.944" x2="65.037" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="62.7855" y1="19.6935" x2="65.5785" y2="19.7505" layer="200" rot="R270"/>
<rectangle x1="63.9255" y1="17.0715" x2="64.4385" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="63.954" y1="15.618" x2="64.41" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="62.8995" y1="13.1385" x2="65.4645" y2="13.1955" layer="200" rot="R270"/>
<rectangle x1="61.6455" y1="23.6265" x2="66.7185" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="63.6975" y1="17.8125" x2="64.6665" y2="17.8695" layer="201" rot="R270"/>
<rectangle x1="63.6975" y1="16.3305" x2="64.6665" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="63.6975" y1="14.9055" x2="64.6665" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="63.27" y1="10.944" x2="65.094" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="62.8425" y1="19.6935" x2="65.6355" y2="19.7505" layer="200" rot="R270"/>
<rectangle x1="63.9825" y1="17.0715" x2="64.4955" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="64.011" y1="15.618" x2="64.467" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="62.9565" y1="13.1385" x2="65.5215" y2="13.1955" layer="200" rot="R270"/>
<rectangle x1="61.7025" y1="23.6265" x2="66.7755" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="63.7545" y1="17.8125" x2="64.7235" y2="17.8695" layer="201" rot="R270"/>
<rectangle x1="63.7545" y1="16.3305" x2="64.7235" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="63.7545" y1="14.9055" x2="64.7235" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="63.327" y1="10.944" x2="65.151" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="62.8995" y1="19.6935" x2="65.6925" y2="19.7505" layer="200" rot="R270"/>
<rectangle x1="64.0395" y1="17.0715" x2="64.5525" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="64.068" y1="15.618" x2="64.524" y2="15.675" layer="200" rot="R270"/>
<rectangle x1="63.0135" y1="13.1385" x2="65.5785" y2="13.1955" layer="200" rot="R270"/>
<rectangle x1="61.7595" y1="23.6265" x2="66.8325" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="63.8115" y1="17.8125" x2="64.7805" y2="17.8695" layer="201" rot="R270"/>
<rectangle x1="63.8115" y1="16.3305" x2="64.7805" y2="16.3875" layer="201" rot="R270"/>
<rectangle x1="63.8115" y1="14.9055" x2="64.7805" y2="14.9625" layer="201" rot="R270"/>
<rectangle x1="63.384" y1="10.944" x2="65.208" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="64.1535" y1="20.8905" x2="64.5525" y2="20.9475" layer="200" rot="R270"/>
<rectangle x1="60.363" y1="15.846" x2="68.343" y2="15.903" layer="200" rot="R270"/>
<rectangle x1="61.8165" y1="23.6265" x2="66.8895" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="63.9255" y1="20.2635" x2="64.7805" y2="20.3205" layer="201" rot="R270"/>
<rectangle x1="63.441" y1="10.944" x2="65.265" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="64.239" y1="20.919" x2="64.581" y2="20.976" layer="200" rot="R270"/>
<rectangle x1="60.42" y1="15.846" x2="68.4" y2="15.903" layer="200" rot="R270"/>
<rectangle x1="61.8735" y1="23.6265" x2="66.9465" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="63.954" y1="20.292" x2="64.866" y2="20.349" layer="201" rot="R270"/>
<rectangle x1="63.498" y1="10.944" x2="65.322" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="64.296" y1="20.919" x2="64.638" y2="20.976" layer="200" rot="R270"/>
<rectangle x1="60.4485" y1="15.8175" x2="68.4855" y2="15.8745" layer="200" rot="R270"/>
<rectangle x1="64.4385" y1="10.1175" x2="64.4955" y2="10.1745" layer="200" rot="R270"/>
<rectangle x1="61.9305" y1="23.6265" x2="67.0035" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="64.011" y1="20.292" x2="64.923" y2="20.349" layer="201" rot="R270"/>
<rectangle x1="63.6405" y1="10.9725" x2="65.2935" y2="11.0295" layer="201" rot="R270"/>
<rectangle x1="64.4385" y1="10.0605" x2="64.4955" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="64.41" y1="20.976" x2="64.638" y2="21.033" layer="200" rot="R270"/>
<rectangle x1="63.8115" y1="19.1235" x2="65.2365" y2="19.1805" layer="200" rot="R270"/>
<rectangle x1="61.5885" y1="14.7345" x2="67.4595" y2="14.7915" layer="200" rot="R270"/>
<rectangle x1="64.467" y1="10.146" x2="64.581" y2="10.203" layer="200" rot="R270"/>
<rectangle x1="61.9875" y1="23.6265" x2="67.0605" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="64.011" y1="20.349" x2="65.037" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="64.1535" y1="18.0405" x2="64.8945" y2="18.0975" layer="201" rot="R270"/>
<rectangle x1="63.726" y1="11.001" x2="65.322" y2="11.058" layer="201" rot="R270"/>
<rectangle x1="64.4955" y1="10.0605" x2="64.5525" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="64.0965" y1="21.3465" x2="65.0655" y2="21.4035" layer="200" rot="R270"/>
<rectangle x1="63.9825" y1="19.2375" x2="65.1795" y2="19.2945" layer="200" rot="R270"/>
<rectangle x1="61.7025" y1="14.6775" x2="67.4595" y2="14.7345" layer="200" rot="R270"/>
<rectangle x1="64.524" y1="10.146" x2="64.638" y2="10.203" layer="200" rot="R270"/>
<rectangle x1="62.415" y1="23.997" x2="66.747" y2="24.054" layer="201" rot="R270"/>
<rectangle x1="64.068" y1="20.349" x2="65.094" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="64.0395" y1="18.0975" x2="65.1225" y2="18.1545" layer="201" rot="R270"/>
<rectangle x1="63.783" y1="11.001" x2="65.379" y2="11.058" layer="201" rot="R270"/>
<rectangle x1="64.5525" y1="10.0605" x2="64.6095" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="64.068" y1="21.432" x2="65.208" y2="21.489" layer="200" rot="R270"/>
<rectangle x1="64.0395" y1="19.2375" x2="65.2365" y2="19.2945" layer="200" rot="R270"/>
<rectangle x1="61.788" y1="14.592" x2="67.488" y2="14.649" layer="200" rot="R270"/>
<rectangle x1="64.5525" y1="10.1745" x2="64.7235" y2="10.2315" layer="200" rot="R270"/>
<rectangle x1="62.5575" y1="24.0825" x2="66.7185" y2="24.1395" layer="201" rot="R270"/>
<rectangle x1="64.125" y1="20.349" x2="65.151" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="64.0395" y1="18.0405" x2="65.2365" y2="18.0975" layer="201" rot="R270"/>
<rectangle x1="63.897" y1="11.001" x2="65.379" y2="11.058" layer="201" rot="R270"/>
<rectangle x1="64.6095" y1="10.0605" x2="64.6665" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="64.0965" y1="21.4605" x2="65.2935" y2="21.5175" layer="200" rot="R270"/>
<rectangle x1="64.125" y1="19.266" x2="65.265" y2="19.323" layer="200" rot="R270"/>
<rectangle x1="64.296" y1="17.043" x2="65.094" y2="17.1" layer="200" rot="R270"/>
<rectangle x1="64.6095" y1="15.8175" x2="64.7805" y2="15.8745" layer="200" rot="R270"/>
<rectangle x1="64.6095" y1="14.8485" x2="64.7805" y2="14.9055" layer="200" rot="R270"/>
<rectangle x1="63.555" y1="12.825" x2="65.835" y2="12.882" layer="200" rot="R270"/>
<rectangle x1="64.581" y1="10.203" x2="64.809" y2="10.26" layer="200" rot="R270"/>
<rectangle x1="62.643" y1="24.111" x2="66.747" y2="24.168" layer="201" rot="R270"/>
<rectangle x1="64.182" y1="20.349" x2="65.208" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="64.068" y1="18.069" x2="65.322" y2="18.126" layer="201" rot="R270"/>
<rectangle x1="64.3245" y1="16.2735" x2="65.0655" y2="16.3305" layer="201" rot="R270"/>
<rectangle x1="64.296" y1="15.333" x2="65.094" y2="15.39" layer="201" rot="R270"/>
<rectangle x1="64.296" y1="14.364" x2="65.094" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="64.011" y1="11.001" x2="65.379" y2="11.058" layer="201" rot="R270"/>
<rectangle x1="64.6665" y1="10.0605" x2="64.7235" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="64.1535" y1="21.4605" x2="65.3505" y2="21.5175" layer="200" rot="R270"/>
<rectangle x1="64.182" y1="19.266" x2="65.322" y2="19.323" layer="200" rot="R270"/>
<rectangle x1="64.3815" y1="17.0145" x2="65.1225" y2="17.0715" layer="200" rot="R270"/>
<rectangle x1="64.695" y1="15.789" x2="64.809" y2="15.846" layer="200" rot="R270"/>
<rectangle x1="64.6665" y1="14.8485" x2="64.8375" y2="14.9055" layer="200" rot="R270"/>
<rectangle x1="63.5835" y1="12.7965" x2="65.9205" y2="12.8535" layer="200" rot="R270"/>
<rectangle x1="64.6095" y1="10.2315" x2="64.8945" y2="10.2885" layer="200" rot="R270"/>
<rectangle x1="62.7" y1="24.111" x2="66.804" y2="24.168" layer="201" rot="R270"/>
<rectangle x1="64.239" y1="20.349" x2="65.265" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="64.0965" y1="18.0405" x2="65.4075" y2="18.0975" layer="201" rot="R270"/>
<rectangle x1="64.353" y1="16.245" x2="65.151" y2="16.302" layer="201" rot="R270"/>
<rectangle x1="64.353" y1="15.333" x2="65.151" y2="15.39" layer="201" rot="R270"/>
<rectangle x1="64.353" y1="14.364" x2="65.151" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="64.125" y1="11.001" x2="65.379" y2="11.058" layer="201" rot="R270"/>
<rectangle x1="64.7235" y1="10.0605" x2="64.7805" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="64.182" y1="21.489" x2="65.436" y2="21.546" layer="200" rot="R270"/>
<rectangle x1="64.2675" y1="19.2945" x2="65.3505" y2="19.3515" layer="200" rot="R270"/>
<rectangle x1="64.4385" y1="17.0145" x2="65.1795" y2="17.0715" layer="200" rot="R270"/>
<rectangle x1="64.752" y1="15.789" x2="64.866" y2="15.846" layer="200" rot="R270"/>
<rectangle x1="64.7235" y1="14.8485" x2="64.8945" y2="14.9055" layer="200" rot="R270"/>
<rectangle x1="63.555" y1="12.711" x2="66.063" y2="12.768" layer="200" rot="R270"/>
<rectangle x1="64.7805" y1="10.9155" x2="64.8375" y2="10.9725" layer="200" rot="R270"/>
<rectangle x1="64.752" y1="10.716" x2="64.866" y2="10.773" layer="200" rot="R270"/>
<rectangle x1="64.581" y1="10.317" x2="65.037" y2="10.374" layer="200" rot="R270"/>
<rectangle x1="62.7855" y1="24.1395" x2="66.8325" y2="24.1965" layer="201" rot="R270"/>
<rectangle x1="64.296" y1="20.349" x2="65.322" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="64.125" y1="18.069" x2="65.493" y2="18.126" layer="201" rot="R270"/>
<rectangle x1="64.41" y1="16.245" x2="65.208" y2="16.302" layer="201" rot="R270"/>
<rectangle x1="64.41" y1="15.333" x2="65.208" y2="15.39" layer="201" rot="R270"/>
<rectangle x1="64.41" y1="14.364" x2="65.208" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="64.5525" y1="11.2005" x2="65.0655" y2="11.2575" layer="201" rot="R270"/>
<rectangle x1="64.752" y1="10.83" x2="64.866" y2="10.887" layer="201" rot="R270"/>
<rectangle x1="64.752" y1="10.602" x2="64.866" y2="10.659" layer="201" rot="R270"/>
<rectangle x1="64.7805" y1="10.0605" x2="64.8375" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="64.239" y1="21.489" x2="65.493" y2="21.546" layer="200" rot="R270"/>
<rectangle x1="64.3245" y1="19.2945" x2="65.4075" y2="19.3515" layer="200" rot="R270"/>
<rectangle x1="64.524" y1="16.986" x2="65.208" y2="17.043" layer="200" rot="R270"/>
<rectangle x1="64.809" y1="15.789" x2="64.923" y2="15.846" layer="200" rot="R270"/>
<rectangle x1="64.7805" y1="14.8485" x2="64.9515" y2="14.9055" layer="200" rot="R270"/>
<rectangle x1="62.928" y1="12.027" x2="66.804" y2="12.084" layer="200" rot="R270"/>
<rectangle x1="62.8425" y1="24.1395" x2="66.8895" y2="24.1965" layer="201" rot="R270"/>
<rectangle x1="64.353" y1="20.349" x2="65.379" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="64.1535" y1="18.0405" x2="65.5785" y2="18.0975" layer="201" rot="R270"/>
<rectangle x1="64.467" y1="16.245" x2="65.265" y2="16.302" layer="201" rot="R270"/>
<rectangle x1="64.467" y1="15.333" x2="65.265" y2="15.39" layer="201" rot="R270"/>
<rectangle x1="64.467" y1="14.364" x2="65.265" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="64.8375" y1="10.0605" x2="64.8945" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="64.296" y1="21.489" x2="65.55" y2="21.546" layer="200" rot="R270"/>
<rectangle x1="64.3815" y1="19.2945" x2="65.4645" y2="19.3515" layer="200" rot="R270"/>
<rectangle x1="64.581" y1="16.986" x2="65.265" y2="17.043" layer="200" rot="R270"/>
<rectangle x1="64.866" y1="15.789" x2="64.98" y2="15.846" layer="200" rot="R270"/>
<rectangle x1="64.8375" y1="14.8485" x2="65.0085" y2="14.9055" layer="200" rot="R270"/>
<rectangle x1="62.985" y1="12.027" x2="66.861" y2="12.084" layer="200" rot="R270"/>
<rectangle x1="62.8995" y1="24.1395" x2="66.9465" y2="24.1965" layer="201" rot="R270"/>
<rectangle x1="64.41" y1="20.349" x2="65.436" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="64.2105" y1="18.0405" x2="65.6355" y2="18.0975" layer="201" rot="R270"/>
<rectangle x1="64.524" y1="16.245" x2="65.322" y2="16.302" layer="201" rot="R270"/>
<rectangle x1="64.524" y1="15.333" x2="65.322" y2="15.39" layer="201" rot="R270"/>
<rectangle x1="64.524" y1="14.364" x2="65.322" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="64.8945" y1="10.0605" x2="64.9515" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="64.353" y1="21.489" x2="65.607" y2="21.546" layer="200" rot="R270"/>
<rectangle x1="64.4385" y1="19.2945" x2="65.5215" y2="19.3515" layer="200" rot="R270"/>
<rectangle x1="64.638" y1="16.986" x2="65.322" y2="17.043" layer="200" rot="R270"/>
<rectangle x1="64.923" y1="15.789" x2="65.037" y2="15.846" layer="200" rot="R270"/>
<rectangle x1="64.8945" y1="14.8485" x2="65.0655" y2="14.9055" layer="200" rot="R270"/>
<rectangle x1="63.042" y1="12.027" x2="66.918" y2="12.084" layer="200" rot="R270"/>
<rectangle x1="62.9565" y1="24.1395" x2="67.0035" y2="24.1965" layer="201" rot="R270"/>
<rectangle x1="64.467" y1="20.349" x2="65.493" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="64.2675" y1="18.0405" x2="65.6925" y2="18.0975" layer="201" rot="R270"/>
<rectangle x1="64.581" y1="16.245" x2="65.379" y2="16.302" layer="201" rot="R270"/>
<rectangle x1="64.581" y1="15.333" x2="65.379" y2="15.39" layer="201" rot="R270"/>
<rectangle x1="64.581" y1="14.364" x2="65.379" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="64.9515" y1="10.0605" x2="65.0085" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="64.3815" y1="21.5175" x2="65.6925" y2="21.5745" layer="200" rot="R270"/>
<rectangle x1="64.4955" y1="19.2945" x2="65.5785" y2="19.3515" layer="200" rot="R270"/>
<rectangle x1="64.695" y1="16.986" x2="65.379" y2="17.043" layer="200" rot="R270"/>
<rectangle x1="64.98" y1="15.789" x2="65.094" y2="15.846" layer="200" rot="R270"/>
<rectangle x1="64.9515" y1="14.8485" x2="65.1225" y2="14.9055" layer="200" rot="R270"/>
<rectangle x1="63.099" y1="12.027" x2="66.975" y2="12.084" layer="200" rot="R270"/>
<rectangle x1="63.042" y1="24.168" x2="67.032" y2="24.225" layer="201" rot="R270"/>
<rectangle x1="64.524" y1="20.349" x2="65.55" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="64.3245" y1="18.0405" x2="65.7495" y2="18.0975" layer="201" rot="R270"/>
<rectangle x1="64.638" y1="16.245" x2="65.436" y2="16.302" layer="201" rot="R270"/>
<rectangle x1="64.638" y1="15.333" x2="65.436" y2="15.39" layer="201" rot="R270"/>
<rectangle x1="64.638" y1="14.364" x2="65.436" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="65.0085" y1="10.0605" x2="65.0655" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="64.467" y1="21.489" x2="65.721" y2="21.546" layer="200" rot="R270"/>
<rectangle x1="64.5525" y1="19.2945" x2="65.6355" y2="19.3515" layer="200" rot="R270"/>
<rectangle x1="64.752" y1="16.986" x2="65.436" y2="17.043" layer="200" rot="R270"/>
<rectangle x1="65.037" y1="15.789" x2="65.151" y2="15.846" layer="200" rot="R270"/>
<rectangle x1="65.0085" y1="14.8485" x2="65.1795" y2="14.9055" layer="200" rot="R270"/>
<rectangle x1="63.156" y1="12.027" x2="67.032" y2="12.084" layer="200" rot="R270"/>
<rectangle x1="63.0705" y1="24.1395" x2="67.1175" y2="24.1965" layer="201" rot="R270"/>
<rectangle x1="64.581" y1="20.349" x2="65.607" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="64.3815" y1="18.0405" x2="65.8065" y2="18.0975" layer="201" rot="R270"/>
<rectangle x1="64.695" y1="16.245" x2="65.493" y2="16.302" layer="201" rot="R270"/>
<rectangle x1="64.695" y1="15.333" x2="65.493" y2="15.39" layer="201" rot="R270"/>
<rectangle x1="64.695" y1="14.364" x2="65.493" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="65.0655" y1="10.0605" x2="65.1225" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="64.524" y1="21.489" x2="65.778" y2="21.546" layer="200" rot="R270"/>
<rectangle x1="64.6095" y1="19.2945" x2="65.6925" y2="19.3515" layer="200" rot="R270"/>
<rectangle x1="64.809" y1="16.986" x2="65.493" y2="17.043" layer="200" rot="R270"/>
<rectangle x1="65.094" y1="15.789" x2="65.208" y2="15.846" layer="200" rot="R270"/>
<rectangle x1="65.0655" y1="14.8485" x2="65.2365" y2="14.9055" layer="200" rot="R270"/>
<rectangle x1="63.213" y1="12.027" x2="67.089" y2="12.084" layer="200" rot="R270"/>
<rectangle x1="63.1275" y1="24.1395" x2="67.1745" y2="24.1965" layer="201" rot="R270"/>
<rectangle x1="64.638" y1="20.349" x2="65.664" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="64.4385" y1="18.0405" x2="65.8635" y2="18.0975" layer="201" rot="R270"/>
<rectangle x1="64.752" y1="16.245" x2="65.55" y2="16.302" layer="201" rot="R270"/>
<rectangle x1="64.752" y1="15.333" x2="65.55" y2="15.39" layer="201" rot="R270"/>
<rectangle x1="64.752" y1="14.364" x2="65.55" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="65.1225" y1="10.0605" x2="65.1795" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="64.5525" y1="21.5175" x2="65.8635" y2="21.5745" layer="200" rot="R270"/>
<rectangle x1="64.6665" y1="19.2945" x2="65.7495" y2="19.3515" layer="200" rot="R270"/>
<rectangle x1="64.866" y1="16.986" x2="65.55" y2="17.043" layer="200" rot="R270"/>
<rectangle x1="65.151" y1="15.789" x2="65.265" y2="15.846" layer="200" rot="R270"/>
<rectangle x1="65.1225" y1="14.8485" x2="65.2935" y2="14.9055" layer="200" rot="R270"/>
<rectangle x1="64.125" y1="12.882" x2="66.291" y2="12.939" layer="200" rot="R270"/>
<rectangle x1="65.037" y1="10.26" x2="65.379" y2="10.317" layer="200" rot="R270"/>
<rectangle x1="63.213" y1="24.168" x2="67.203" y2="24.225" layer="201" rot="R270"/>
<rectangle x1="64.695" y1="20.349" x2="65.721" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="64.4955" y1="18.0405" x2="65.9205" y2="18.0975" layer="201" rot="R270"/>
<rectangle x1="64.809" y1="16.245" x2="65.607" y2="16.302" layer="201" rot="R270"/>
<rectangle x1="64.809" y1="15.333" x2="65.607" y2="15.39" layer="201" rot="R270"/>
<rectangle x1="64.809" y1="14.364" x2="65.607" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="64.524" y1="11.115" x2="65.892" y2="11.172" layer="201" rot="R270"/>
<rectangle x1="65.1795" y1="10.0605" x2="65.2365" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="64.638" y1="21.489" x2="65.892" y2="21.546" layer="200" rot="R270"/>
<rectangle x1="64.7235" y1="19.2945" x2="65.8065" y2="19.3515" layer="200" rot="R270"/>
<rectangle x1="64.923" y1="16.986" x2="65.607" y2="17.043" layer="200" rot="R270"/>
<rectangle x1="65.208" y1="15.789" x2="65.322" y2="15.846" layer="200" rot="R270"/>
<rectangle x1="65.1795" y1="14.8485" x2="65.3505" y2="14.9055" layer="200" rot="R270"/>
<rectangle x1="64.2105" y1="12.9105" x2="66.3195" y2="12.9675" layer="200" rot="R270"/>
<rectangle x1="65.094" y1="10.26" x2="65.436" y2="10.317" layer="200" rot="R270"/>
<rectangle x1="63.2415" y1="24.1395" x2="67.2885" y2="24.1965" layer="201" rot="R270"/>
<rectangle x1="64.752" y1="20.349" x2="65.778" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="64.5525" y1="18.0405" x2="65.9775" y2="18.0975" layer="201" rot="R270"/>
<rectangle x1="64.866" y1="16.245" x2="65.664" y2="16.302" layer="201" rot="R270"/>
<rectangle x1="64.866" y1="15.333" x2="65.664" y2="15.39" layer="201" rot="R270"/>
<rectangle x1="64.866" y1="14.364" x2="65.664" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="64.5525" y1="11.1435" x2="65.9775" y2="11.2005" layer="201" rot="R270"/>
<rectangle x1="65.2365" y1="10.0605" x2="65.2935" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="64.6665" y1="21.5175" x2="65.9775" y2="21.5745" layer="200" rot="R270"/>
<rectangle x1="64.7805" y1="19.2945" x2="65.8635" y2="19.3515" layer="200" rot="R270"/>
<rectangle x1="64.98" y1="16.986" x2="65.664" y2="17.043" layer="200" rot="R270"/>
<rectangle x1="65.265" y1="15.789" x2="65.379" y2="15.846" layer="200" rot="R270"/>
<rectangle x1="65.2365" y1="14.8485" x2="65.4075" y2="14.9055" layer="200" rot="R270"/>
<rectangle x1="64.2675" y1="12.9105" x2="66.3765" y2="12.9675" layer="200" rot="R270"/>
<rectangle x1="65.151" y1="10.26" x2="65.493" y2="10.317" layer="200" rot="R270"/>
<rectangle x1="63.327" y1="24.168" x2="67.317" y2="24.225" layer="201" rot="R270"/>
<rectangle x1="64.809" y1="20.349" x2="65.835" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="64.6095" y1="18.0405" x2="66.0345" y2="18.0975" layer="201" rot="R270"/>
<rectangle x1="64.923" y1="16.245" x2="65.721" y2="16.302" layer="201" rot="R270"/>
<rectangle x1="64.923" y1="15.333" x2="65.721" y2="15.39" layer="201" rot="R270"/>
<rectangle x1="64.923" y1="14.364" x2="65.721" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="64.6095" y1="11.1435" x2="66.0345" y2="11.2005" layer="201" rot="R270"/>
<rectangle x1="65.2935" y1="10.0605" x2="65.3505" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="64.752" y1="21.489" x2="66.006" y2="21.546" layer="200" rot="R270"/>
<rectangle x1="64.8375" y1="19.2945" x2="65.9205" y2="19.3515" layer="200" rot="R270"/>
<rectangle x1="65.0085" y1="17.0145" x2="65.7495" y2="17.0715" layer="200" rot="R270"/>
<rectangle x1="65.322" y1="15.789" x2="65.436" y2="15.846" layer="200" rot="R270"/>
<rectangle x1="65.2935" y1="14.8485" x2="65.4645" y2="14.9055" layer="200" rot="R270"/>
<rectangle x1="64.3245" y1="12.9105" x2="66.4335" y2="12.9675" layer="200" rot="R270"/>
<rectangle x1="65.208" y1="10.26" x2="65.55" y2="10.317" layer="200" rot="R270"/>
<rectangle x1="63.3555" y1="24.1395" x2="67.4025" y2="24.1965" layer="201" rot="R270"/>
<rectangle x1="64.866" y1="20.349" x2="65.892" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="64.695" y1="18.069" x2="66.063" y2="18.126" layer="201" rot="R270"/>
<rectangle x1="64.98" y1="16.245" x2="65.778" y2="16.302" layer="201" rot="R270"/>
<rectangle x1="64.98" y1="15.333" x2="65.778" y2="15.39" layer="201" rot="R270"/>
<rectangle x1="64.98" y1="14.364" x2="65.778" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="64.6665" y1="11.1435" x2="66.0915" y2="11.2005" layer="201" rot="R270"/>
<rectangle x1="65.3505" y1="10.0605" x2="65.4075" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="64.809" y1="21.489" x2="66.063" y2="21.546" layer="200" rot="R270"/>
<rectangle x1="64.8945" y1="19.2945" x2="65.9775" y2="19.3515" layer="200" rot="R270"/>
<rectangle x1="65.0655" y1="17.0145" x2="65.8065" y2="17.0715" layer="200" rot="R270"/>
<rectangle x1="65.379" y1="15.789" x2="65.493" y2="15.846" layer="200" rot="R270"/>
<rectangle x1="65.3505" y1="14.8485" x2="65.5215" y2="14.9055" layer="200" rot="R270"/>
<rectangle x1="64.3815" y1="12.9105" x2="66.4905" y2="12.9675" layer="200" rot="R270"/>
<rectangle x1="65.2365" y1="11.4285" x2="65.6355" y2="11.4855" layer="200" rot="R270"/>
<rectangle x1="65.208" y1="10.83" x2="65.664" y2="10.887" layer="200" rot="R270"/>
<rectangle x1="65.265" y1="10.26" x2="65.607" y2="10.317" layer="200" rot="R270"/>
<rectangle x1="63.4125" y1="24.1395" x2="67.4595" y2="24.1965" layer="201" rot="R270"/>
<rectangle x1="64.923" y1="20.349" x2="65.949" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="64.752" y1="18.069" x2="66.12" y2="18.126" layer="201" rot="R270"/>
<rectangle x1="65.037" y1="16.245" x2="65.835" y2="16.302" layer="201" rot="R270"/>
<rectangle x1="65.037" y1="15.333" x2="65.835" y2="15.39" layer="201" rot="R270"/>
<rectangle x1="65.037" y1="14.364" x2="65.835" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="65.322" y1="11.742" x2="65.55" y2="11.799" layer="201" rot="R270"/>
<rectangle x1="65.3505" y1="11.1435" x2="65.5215" y2="11.2005" layer="201" rot="R270"/>
<rectangle x1="65.3505" y1="10.5165" x2="65.5215" y2="10.5735" layer="201" rot="R270"/>
<rectangle x1="65.4075" y1="10.0605" x2="65.4645" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="64.8375" y1="21.4605" x2="66.1485" y2="21.5175" layer="200" rot="R270"/>
<rectangle x1="65.436" y1="20.634" x2="65.55" y2="20.691" layer="200" rot="R270"/>
<rectangle x1="64.752" y1="19.437" x2="66.234" y2="19.494" layer="200" rot="R270"/>
<rectangle x1="65.094" y1="17.043" x2="65.892" y2="17.1" layer="200" rot="R270"/>
<rectangle x1="65.436" y1="15.789" x2="65.55" y2="15.846" layer="200" rot="R270"/>
<rectangle x1="65.4075" y1="14.8485" x2="65.5785" y2="14.9055" layer="200" rot="R270"/>
<rectangle x1="64.4385" y1="12.9105" x2="66.5475" y2="12.9675" layer="200" rot="R270"/>
<rectangle x1="65.2935" y1="11.4285" x2="65.6925" y2="11.4855" layer="200" rot="R270"/>
<rectangle x1="65.2365" y1="10.8585" x2="65.7495" y2="10.9155" layer="200" rot="R270"/>
<rectangle x1="65.322" y1="10.26" x2="65.664" y2="10.317" layer="200" rot="R270"/>
<rectangle x1="63.4695" y1="24.1395" x2="67.5165" y2="24.1965" layer="201" rot="R270"/>
<rectangle x1="65.436" y1="20.748" x2="65.55" y2="20.805" layer="201" rot="R270"/>
<rectangle x1="65.2935" y1="20.3775" x2="65.6925" y2="20.4345" layer="201" rot="R270"/>
<rectangle x1="64.866" y1="18.069" x2="66.12" y2="18.126" layer="201" rot="R270"/>
<rectangle x1="65.094" y1="16.245" x2="65.892" y2="16.302" layer="201" rot="R270"/>
<rectangle x1="65.094" y1="15.333" x2="65.892" y2="15.39" layer="201" rot="R270"/>
<rectangle x1="65.094" y1="14.364" x2="65.892" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="65.379" y1="11.742" x2="65.607" y2="11.799" layer="201" rot="R270"/>
<rectangle x1="65.436" y1="11.172" x2="65.55" y2="11.229" layer="201" rot="R270"/>
<rectangle x1="65.4075" y1="10.5165" x2="65.5785" y2="10.5735" layer="201" rot="R270"/>
<rectangle x1="65.4645" y1="10.0605" x2="65.5215" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="63.84" y1="20.406" x2="67.26" y2="20.463" layer="200" rot="R270"/>
<rectangle x1="65.2935" y1="17.9835" x2="65.8065" y2="18.0405" layer="200" rot="R270"/>
<rectangle x1="65.1795" y1="17.0715" x2="65.9205" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="65.493" y1="15.789" x2="65.607" y2="15.846" layer="200" rot="R270"/>
<rectangle x1="65.4645" y1="14.8485" x2="65.6355" y2="14.9055" layer="200" rot="R270"/>
<rectangle x1="65.208" y1="13.623" x2="65.892" y2="13.68" layer="200" rot="R270"/>
<rectangle x1="65.322" y1="12.084" x2="65.778" y2="12.141" layer="200" rot="R270"/>
<rectangle x1="65.3505" y1="11.4285" x2="65.7495" y2="11.4855" layer="200" rot="R270"/>
<rectangle x1="65.2935" y1="10.8585" x2="65.8065" y2="10.9155" layer="200" rot="R270"/>
<rectangle x1="65.379" y1="10.26" x2="65.721" y2="10.317" layer="200" rot="R270"/>
<rectangle x1="63.5265" y1="24.1395" x2="67.5735" y2="24.1965" layer="201" rot="R270"/>
<rectangle x1="65.322" y1="18.468" x2="65.778" y2="18.525" layer="201" rot="R270"/>
<rectangle x1="65.4075" y1="17.5845" x2="65.6925" y2="17.6415" layer="201" rot="R270"/>
<rectangle x1="65.1225" y1="16.2735" x2="65.9775" y2="16.3305" layer="201" rot="R270"/>
<rectangle x1="65.151" y1="15.333" x2="65.949" y2="15.39" layer="201" rot="R270"/>
<rectangle x1="65.151" y1="14.364" x2="65.949" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="65.0655" y1="12.7965" x2="66.0345" y2="12.8535" layer="201" rot="R270"/>
<rectangle x1="65.436" y1="11.742" x2="65.664" y2="11.799" layer="201" rot="R270"/>
<rectangle x1="65.493" y1="11.172" x2="65.607" y2="11.229" layer="201" rot="R270"/>
<rectangle x1="65.4645" y1="10.5165" x2="65.6355" y2="10.5735" layer="201" rot="R270"/>
<rectangle x1="65.5215" y1="10.0605" x2="65.5785" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="63.897" y1="20.406" x2="67.317" y2="20.463" layer="200" rot="R270"/>
<rectangle x1="65.5785" y1="18.0405" x2="65.6355" y2="18.0975" layer="200" rot="R270"/>
<rectangle x1="65.55" y1="17.727" x2="65.664" y2="17.784" layer="200" rot="R270"/>
<rectangle x1="65.208" y1="17.1" x2="66.006" y2="17.157" layer="200" rot="R270"/>
<rectangle x1="65.55" y1="15.789" x2="65.664" y2="15.846" layer="200" rot="R270"/>
<rectangle x1="65.5215" y1="14.8485" x2="65.6925" y2="14.9055" layer="200" rot="R270"/>
<rectangle x1="65.2935" y1="13.6515" x2="65.9205" y2="13.7085" layer="200" rot="R270"/>
<rectangle x1="65.379" y1="12.084" x2="65.835" y2="12.141" layer="200" rot="R270"/>
<rectangle x1="65.4075" y1="11.4285" x2="65.8065" y2="11.4855" layer="200" rot="R270"/>
<rectangle x1="65.3505" y1="10.8585" x2="65.8635" y2="10.9155" layer="200" rot="R270"/>
<rectangle x1="65.436" y1="10.26" x2="65.778" y2="10.317" layer="200" rot="R270"/>
<rectangle x1="63.5835" y1="24.1395" x2="67.6305" y2="24.1965" layer="201" rot="R270"/>
<rectangle x1="65.2935" y1="18.3825" x2="65.9205" y2="18.4395" layer="201" rot="R270"/>
<rectangle x1="65.493" y1="17.898" x2="65.721" y2="17.955" layer="201" rot="R270"/>
<rectangle x1="65.5215" y1="17.5845" x2="65.6925" y2="17.6415" layer="201" rot="R270"/>
<rectangle x1="65.1795" y1="16.2735" x2="66.0345" y2="16.3305" layer="201" rot="R270"/>
<rectangle x1="65.208" y1="15.333" x2="66.006" y2="15.39" layer="201" rot="R270"/>
<rectangle x1="65.208" y1="14.364" x2="66.006" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="65.094" y1="12.825" x2="66.12" y2="12.882" layer="201" rot="R270"/>
<rectangle x1="65.493" y1="11.742" x2="65.721" y2="11.799" layer="201" rot="R270"/>
<rectangle x1="65.55" y1="11.172" x2="65.664" y2="11.229" layer="201" rot="R270"/>
<rectangle x1="65.5215" y1="10.5165" x2="65.6925" y2="10.5735" layer="201" rot="R270"/>
<rectangle x1="65.5785" y1="10.0605" x2="65.6355" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="63.954" y1="20.406" x2="67.374" y2="20.463" layer="200" rot="R270"/>
<rectangle x1="65.607" y1="17.955" x2="65.721" y2="18.012" layer="200" rot="R270"/>
<rectangle x1="65.2365" y1="17.0715" x2="66.0915" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="65.5785" y1="15.8175" x2="65.7495" y2="15.8745" layer="200" rot="R270"/>
<rectangle x1="65.5785" y1="14.8485" x2="65.7495" y2="14.9055" layer="200" rot="R270"/>
<rectangle x1="65.3505" y1="13.6515" x2="65.9775" y2="13.7085" layer="200" rot="R270"/>
<rectangle x1="65.436" y1="12.084" x2="65.892" y2="12.141" layer="200" rot="R270"/>
<rectangle x1="65.4645" y1="11.4285" x2="65.8635" y2="11.4855" layer="200" rot="R270"/>
<rectangle x1="65.4075" y1="10.8585" x2="65.9205" y2="10.9155" layer="200" rot="R270"/>
<rectangle x1="65.493" y1="10.26" x2="65.835" y2="10.317" layer="200" rot="R270"/>
<rectangle x1="63.6405" y1="24.1395" x2="67.6875" y2="24.1965" layer="201" rot="R270"/>
<rectangle x1="65.322" y1="18.354" x2="66.006" y2="18.411" layer="201" rot="R270"/>
<rectangle x1="65.4645" y1="17.6985" x2="65.8635" y2="17.7555" layer="201" rot="R270"/>
<rectangle x1="65.2935" y1="16.2735" x2="66.0345" y2="16.3305" layer="201" rot="R270"/>
<rectangle x1="65.265" y1="15.333" x2="66.063" y2="15.39" layer="201" rot="R270"/>
<rectangle x1="65.265" y1="14.364" x2="66.063" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="65.151" y1="12.825" x2="66.177" y2="12.882" layer="201" rot="R270"/>
<rectangle x1="65.55" y1="11.742" x2="65.778" y2="11.799" layer="201" rot="R270"/>
<rectangle x1="65.607" y1="11.172" x2="65.721" y2="11.229" layer="201" rot="R270"/>
<rectangle x1="65.5785" y1="10.5165" x2="65.7495" y2="10.5735" layer="201" rot="R270"/>
<rectangle x1="65.6355" y1="10.0605" x2="65.6925" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="65.037" y1="21.432" x2="66.405" y2="21.489" layer="200" rot="R270"/>
<rectangle x1="65.6925" y1="20.5485" x2="65.7495" y2="20.6055" layer="200" rot="R270"/>
<rectangle x1="64.923" y1="19.494" x2="66.519" y2="19.551" layer="200" rot="R270"/>
<rectangle x1="65.664" y1="17.841" x2="65.778" y2="17.898" layer="200" rot="R270"/>
<rectangle x1="63.6405" y1="15.4185" x2="67.8015" y2="15.4755" layer="200" rot="R270"/>
<rectangle x1="65.493" y1="12.084" x2="65.949" y2="12.141" layer="200" rot="R270"/>
<rectangle x1="65.5215" y1="11.4285" x2="65.9205" y2="11.4855" layer="200" rot="R270"/>
<rectangle x1="65.4645" y1="10.8585" x2="65.9775" y2="10.9155" layer="200" rot="R270"/>
<rectangle x1="65.55" y1="10.26" x2="65.892" y2="10.317" layer="200" rot="R270"/>
<rectangle x1="63.6975" y1="24.1395" x2="67.7445" y2="24.1965" layer="201" rot="R270"/>
<rectangle x1="65.6355" y1="20.6625" x2="65.8065" y2="20.7195" layer="201" rot="R270"/>
<rectangle x1="65.607" y1="20.406" x2="65.835" y2="20.463" layer="201" rot="R270"/>
<rectangle x1="65.322" y1="18.297" x2="66.12" y2="18.354" layer="201" rot="R270"/>
<rectangle x1="65.5785" y1="17.6415" x2="65.8635" y2="17.6985" layer="201" rot="R270"/>
<rectangle x1="65.208" y1="12.825" x2="66.234" y2="12.882" layer="201" rot="R270"/>
<rectangle x1="65.607" y1="11.742" x2="65.835" y2="11.799" layer="201" rot="R270"/>
<rectangle x1="65.664" y1="11.172" x2="65.778" y2="11.229" layer="201" rot="R270"/>
<rectangle x1="65.6355" y1="10.5165" x2="65.8065" y2="10.5735" layer="201" rot="R270"/>
<rectangle x1="65.6925" y1="10.0605" x2="65.7495" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="65.151" y1="21.489" x2="66.405" y2="21.546" layer="200" rot="R270"/>
<rectangle x1="65.208" y1="19.266" x2="66.348" y2="19.323" layer="200" rot="R270"/>
<rectangle x1="65.721" y1="17.784" x2="65.835" y2="17.841" layer="200" rot="R270"/>
<rectangle x1="63.6975" y1="15.4185" x2="67.8585" y2="15.4755" layer="200" rot="R270"/>
<rectangle x1="65.55" y1="12.084" x2="66.006" y2="12.141" layer="200" rot="R270"/>
<rectangle x1="65.5785" y1="11.4285" x2="65.9775" y2="11.4855" layer="200" rot="R270"/>
<rectangle x1="65.5215" y1="10.8585" x2="66.0345" y2="10.9155" layer="200" rot="R270"/>
<rectangle x1="65.607" y1="10.26" x2="65.949" y2="10.317" layer="200" rot="R270"/>
<rectangle x1="63.7545" y1="24.1395" x2="67.8015" y2="24.1965" layer="201" rot="R270"/>
<rectangle x1="65.265" y1="20.349" x2="66.291" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="65.3505" y1="18.2685" x2="66.2055" y2="18.3255" layer="201" rot="R270"/>
<rectangle x1="65.664" y1="17.613" x2="65.892" y2="17.67" layer="201" rot="R270"/>
<rectangle x1="65.265" y1="12.825" x2="66.291" y2="12.882" layer="201" rot="R270"/>
<rectangle x1="65.664" y1="11.742" x2="65.892" y2="11.799" layer="201" rot="R270"/>
<rectangle x1="65.721" y1="11.172" x2="65.835" y2="11.229" layer="201" rot="R270"/>
<rectangle x1="65.6925" y1="10.5165" x2="65.8635" y2="10.5735" layer="201" rot="R270"/>
<rectangle x1="65.7495" y1="10.0605" x2="65.8065" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="65.208" y1="21.489" x2="66.462" y2="21.546" layer="200" rot="R270"/>
<rectangle x1="65.265" y1="19.266" x2="66.405" y2="19.323" layer="200" rot="R270"/>
<rectangle x1="65.8065" y1="17.6985" x2="65.8635" y2="17.7555" layer="200" rot="R270"/>
<rectangle x1="63.7545" y1="15.4185" x2="67.9155" y2="15.4755" layer="200" rot="R270"/>
<rectangle x1="65.5785" y1="12.0555" x2="66.0915" y2="12.1125" layer="200" rot="R270"/>
<rectangle x1="65.6355" y1="11.4285" x2="66.0345" y2="11.4855" layer="200" rot="R270"/>
<rectangle x1="65.607" y1="10.83" x2="66.063" y2="10.887" layer="200" rot="R270"/>
<rectangle x1="65.664" y1="10.26" x2="66.006" y2="10.317" layer="200" rot="R270"/>
<rectangle x1="63.8115" y1="24.1395" x2="67.8585" y2="24.1965" layer="201" rot="R270"/>
<rectangle x1="65.322" y1="20.349" x2="66.348" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="65.3505" y1="18.2115" x2="66.3195" y2="18.2685" layer="201" rot="R270"/>
<rectangle x1="65.7495" y1="17.5845" x2="65.9205" y2="17.6415" layer="201" rot="R270"/>
<rectangle x1="65.322" y1="12.825" x2="66.348" y2="12.882" layer="201" rot="R270"/>
<rectangle x1="65.7495" y1="11.7135" x2="65.9205" y2="11.7705" layer="201" rot="R270"/>
<rectangle x1="65.7495" y1="11.1435" x2="65.9205" y2="11.2005" layer="201" rot="R270"/>
<rectangle x1="65.7495" y1="10.5165" x2="65.9205" y2="10.5735" layer="201" rot="R270"/>
<rectangle x1="65.8065" y1="10.0605" x2="65.8635" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="65.265" y1="21.489" x2="66.519" y2="21.546" layer="200" rot="R270"/>
<rectangle x1="65.322" y1="19.266" x2="66.462" y2="19.323" layer="200" rot="R270"/>
<rectangle x1="65.3505" y1="16.9575" x2="66.4335" y2="17.0145" layer="200" rot="R270"/>
<rectangle x1="64.41" y1="14.82" x2="67.374" y2="14.877" layer="200" rot="R270"/>
<rectangle x1="65.6355" y1="12.0555" x2="66.1485" y2="12.1125" layer="200" rot="R270"/>
<rectangle x1="65.721" y1="11.457" x2="66.063" y2="11.514" layer="200" rot="R270"/>
<rectangle x1="65.664" y1="10.83" x2="66.12" y2="10.887" layer="200" rot="R270"/>
<rectangle x1="65.721" y1="10.26" x2="66.063" y2="10.317" layer="200" rot="R270"/>
<rectangle x1="63.8685" y1="24.1395" x2="67.9155" y2="24.1965" layer="201" rot="R270"/>
<rectangle x1="65.379" y1="20.349" x2="66.405" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="65.2935" y1="18.0975" x2="66.4905" y2="18.1545" layer="201" rot="R270"/>
<rectangle x1="65.835" y1="16.359" x2="65.949" y2="16.416" layer="201" rot="R270"/>
<rectangle x1="65.379" y1="12.825" x2="66.405" y2="12.882" layer="201" rot="R270"/>
<rectangle x1="65.8065" y1="11.7135" x2="65.9775" y2="11.7705" layer="201" rot="R270"/>
<rectangle x1="65.778" y1="11.172" x2="66.006" y2="11.229" layer="201" rot="R270"/>
<rectangle x1="65.8065" y1="10.5165" x2="65.9775" y2="10.5735" layer="201" rot="R270"/>
<rectangle x1="65.8635" y1="10.0605" x2="65.9205" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="65.322" y1="21.489" x2="66.576" y2="21.546" layer="200" rot="R270"/>
<rectangle x1="65.379" y1="19.266" x2="66.519" y2="19.323" layer="200" rot="R270"/>
<rectangle x1="65.436" y1="16.986" x2="66.462" y2="17.043" layer="200" rot="R270"/>
<rectangle x1="64.4955" y1="14.7915" x2="67.4025" y2="14.8485" layer="200" rot="R270"/>
<rectangle x1="65.6925" y1="12.0555" x2="66.2055" y2="12.1125" layer="200" rot="R270"/>
<rectangle x1="65.8635" y1="11.4285" x2="66.0345" y2="11.4855" layer="200" rot="R270"/>
<rectangle x1="65.7495" y1="10.8015" x2="66.1485" y2="10.8585" layer="200" rot="R270"/>
<rectangle x1="65.778" y1="10.26" x2="66.12" y2="10.317" layer="200" rot="R270"/>
<rectangle x1="63.9255" y1="24.1395" x2="67.9725" y2="24.1965" layer="201" rot="R270"/>
<rectangle x1="65.436" y1="20.349" x2="66.462" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="65.3505" y1="18.0975" x2="66.5475" y2="18.1545" layer="201" rot="R270"/>
<rectangle x1="65.835" y1="16.359" x2="66.063" y2="16.416" layer="201" rot="R270"/>
<rectangle x1="65.436" y1="12.825" x2="66.462" y2="12.882" layer="201" rot="R270"/>
<rectangle x1="65.8065" y1="11.6565" x2="66.0915" y2="11.7135" layer="201" rot="R270"/>
<rectangle x1="65.778" y1="11.172" x2="66.12" y2="11.229" layer="201" rot="R270"/>
<rectangle x1="65.8635" y1="10.5165" x2="66.0345" y2="10.5735" layer="201" rot="R270"/>
<rectangle x1="65.9205" y1="10.0605" x2="65.9775" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="65.379" y1="21.489" x2="66.633" y2="21.546" layer="200" rot="R270"/>
<rectangle x1="65.4075" y1="19.2375" x2="66.6045" y2="19.2945" layer="200" rot="R270"/>
<rectangle x1="65.5215" y1="17.0145" x2="66.4905" y2="17.0715" layer="200" rot="R270"/>
<rectangle x1="64.5525" y1="14.7915" x2="67.4595" y2="14.8485" layer="200" rot="R270"/>
<rectangle x1="65.721" y1="12.027" x2="66.291" y2="12.084" layer="200" rot="R270"/>
<rectangle x1="65.892" y1="10.773" x2="66.12" y2="10.83" layer="200" rot="R270"/>
<rectangle x1="65.8065" y1="10.2885" x2="66.2055" y2="10.3455" layer="200" rot="R270"/>
<rectangle x1="63.9825" y1="24.1395" x2="68.0295" y2="24.1965" layer="201" rot="R270"/>
<rectangle x1="65.493" y1="20.349" x2="66.519" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="65.436" y1="18.069" x2="66.576" y2="18.126" layer="201" rot="R270"/>
<rectangle x1="65.8635" y1="16.3875" x2="66.1485" y2="16.4445" layer="201" rot="R270"/>
<rectangle x1="65.493" y1="12.825" x2="66.519" y2="12.882" layer="201" rot="R270"/>
<rectangle x1="65.5785" y1="11.3145" x2="66.4335" y2="11.3715" layer="201" rot="R270"/>
<rectangle x1="65.9205" y1="10.5735" x2="66.0915" y2="10.6305" layer="201" rot="R270"/>
<rectangle x1="65.9775" y1="10.0605" x2="66.0345" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="65.4075" y1="21.5175" x2="66.7185" y2="21.5745" layer="200" rot="R270"/>
<rectangle x1="65.4645" y1="19.2375" x2="66.6615" y2="19.2945" layer="200" rot="R270"/>
<rectangle x1="66.0345" y1="17.6985" x2="66.0915" y2="17.7555" layer="200" rot="R270"/>
<rectangle x1="65.55" y1="16.986" x2="66.576" y2="17.043" layer="200" rot="R270"/>
<rectangle x1="64.6095" y1="14.7915" x2="67.5165" y2="14.8485" layer="200" rot="R270"/>
<rectangle x1="65.778" y1="12.027" x2="66.348" y2="12.084" layer="200" rot="R270"/>
<rectangle x1="66.006" y1="11.172" x2="66.12" y2="11.229" layer="200" rot="R270"/>
<rectangle x1="65.8635" y1="10.2885" x2="66.2625" y2="10.3455" layer="200" rot="R270"/>
<rectangle x1="64.068" y1="24.168" x2="68.058" y2="24.225" layer="201" rot="R270"/>
<rectangle x1="65.55" y1="20.349" x2="66.576" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="65.607" y1="18.183" x2="66.519" y2="18.24" layer="201" rot="R270"/>
<rectangle x1="65.9775" y1="17.5845" x2="66.1485" y2="17.6415" layer="201" rot="R270"/>
<rectangle x1="65.949" y1="16.359" x2="66.177" y2="16.416" layer="201" rot="R270"/>
<rectangle x1="65.55" y1="12.825" x2="66.576" y2="12.882" layer="201" rot="R270"/>
<rectangle x1="65.8065" y1="11.4855" x2="66.3195" y2="11.5425" layer="201" rot="R270"/>
<rectangle x1="65.7495" y1="10.8015" x2="66.3765" y2="10.8585" layer="201" rot="R270"/>
<rectangle x1="66.0345" y1="10.0605" x2="66.0915" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="65.4645" y1="21.5175" x2="66.7755" y2="21.5745" layer="200" rot="R270"/>
<rectangle x1="65.55" y1="19.266" x2="66.69" y2="19.323" layer="200" rot="R270"/>
<rectangle x1="66.0915" y1="18.6105" x2="66.1485" y2="18.6675" layer="200" rot="R270"/>
<rectangle x1="66.063" y1="17.727" x2="66.177" y2="17.784" layer="200" rot="R270"/>
<rectangle x1="65.5785" y1="16.9575" x2="66.6615" y2="17.0145" layer="200" rot="R270"/>
<rectangle x1="64.638" y1="14.82" x2="67.602" y2="14.877" layer="200" rot="R270"/>
<rectangle x1="65.778" y1="11.97" x2="66.462" y2="12.027" layer="200" rot="R270"/>
<rectangle x1="66.006" y1="11.172" x2="66.234" y2="11.229" layer="200" rot="R270"/>
<rectangle x1="65.892" y1="10.317" x2="66.348" y2="10.374" layer="200" rot="R270"/>
<rectangle x1="64.125" y1="24.168" x2="68.115" y2="24.225" layer="201" rot="R270"/>
<rectangle x1="65.607" y1="20.349" x2="66.633" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="66.0915" y1="18.6675" x2="66.1485" y2="18.7245" layer="201" rot="R270"/>
<rectangle x1="65.721" y1="18.183" x2="66.519" y2="18.24" layer="201" rot="R270"/>
<rectangle x1="66.0345" y1="17.5845" x2="66.2055" y2="17.6415" layer="201" rot="R270"/>
<rectangle x1="66.063" y1="16.359" x2="66.177" y2="16.416" layer="201" rot="R270"/>
<rectangle x1="65.607" y1="12.825" x2="66.633" y2="12.882" layer="201" rot="R270"/>
<rectangle x1="65.949" y1="11.457" x2="66.291" y2="11.514" layer="201" rot="R270"/>
<rectangle x1="65.8635" y1="10.8015" x2="66.3765" y2="10.8585" layer="201" rot="R270"/>
<rectangle x1="66.0915" y1="10.0605" x2="66.1485" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="65.55" y1="21.489" x2="66.804" y2="21.546" layer="200" rot="R270"/>
<rectangle x1="65.55" y1="19.209" x2="66.804" y2="19.266" layer="200" rot="R270"/>
<rectangle x1="66.12" y1="17.727" x2="66.234" y2="17.784" layer="200" rot="R270"/>
<rectangle x1="64.0965" y1="15.4185" x2="68.2575" y2="15.4755" layer="200" rot="R270"/>
<rectangle x1="65.5215" y1="11.6565" x2="66.8325" y2="11.7135" layer="200" rot="R270"/>
<rectangle x1="65.892" y1="10.374" x2="66.462" y2="10.431" layer="200" rot="R270"/>
<rectangle x1="64.1535" y1="24.1395" x2="68.2005" y2="24.1965" layer="201" rot="R270"/>
<rectangle x1="65.664" y1="20.349" x2="66.69" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="65.778" y1="18.183" x2="66.576" y2="18.24" layer="201" rot="R270"/>
<rectangle x1="66.0915" y1="17.5845" x2="66.2625" y2="17.6415" layer="201" rot="R270"/>
<rectangle x1="65.664" y1="12.825" x2="66.69" y2="12.882" layer="201" rot="R270"/>
<rectangle x1="66.006" y1="10.83" x2="66.348" y2="10.887" layer="201" rot="R270"/>
<rectangle x1="66.1485" y1="10.0605" x2="66.2055" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="65.5785" y1="21.5175" x2="66.8895" y2="21.5745" layer="200" rot="R270"/>
<rectangle x1="65.6355" y1="19.2375" x2="66.8325" y2="19.2945" layer="200" rot="R270"/>
<rectangle x1="66.177" y1="17.784" x2="66.291" y2="17.841" layer="200" rot="R270"/>
<rectangle x1="64.1535" y1="15.4185" x2="68.3145" y2="15.4755" layer="200" rot="R270"/>
<rectangle x1="65.55" y1="11.628" x2="66.918" y2="11.685" layer="200" rot="R270"/>
<rectangle x1="65.892" y1="10.431" x2="66.576" y2="10.488" layer="200" rot="R270"/>
<rectangle x1="64.239" y1="24.168" x2="68.229" y2="24.225" layer="201" rot="R270"/>
<rectangle x1="65.721" y1="20.349" x2="66.747" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="65.835" y1="18.24" x2="66.633" y2="18.297" layer="201" rot="R270"/>
<rectangle x1="66.12" y1="17.613" x2="66.348" y2="17.67" layer="201" rot="R270"/>
<rectangle x1="65.721" y1="12.825" x2="66.747" y2="12.882" layer="201" rot="R270"/>
<rectangle x1="66.1485" y1="10.8585" x2="66.3195" y2="10.9155" layer="201" rot="R270"/>
<rectangle x1="66.2055" y1="10.0605" x2="66.2625" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="65.664" y1="21.489" x2="66.918" y2="21.546" layer="200" rot="R270"/>
<rectangle x1="65.721" y1="19.266" x2="66.861" y2="19.323" layer="200" rot="R270"/>
<rectangle x1="66.2625" y1="18.2685" x2="66.3195" y2="18.3255" layer="200" rot="R270"/>
<rectangle x1="66.2625" y1="18.1545" x2="66.3195" y2="18.2115" layer="200" rot="R270"/>
<rectangle x1="66.234" y1="17.784" x2="66.348" y2="17.841" layer="200" rot="R270"/>
<rectangle x1="64.2105" y1="15.4185" x2="68.3715" y2="15.4755" layer="200" rot="R270"/>
<rectangle x1="65.1795" y1="11.2005" x2="67.4025" y2="11.2575" layer="200" rot="R270"/>
<rectangle x1="64.2675" y1="24.1395" x2="68.3145" y2="24.1965" layer="201" rot="R270"/>
<rectangle x1="65.778" y1="20.349" x2="66.804" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="66.0915" y1="18.4965" x2="66.4905" y2="18.5535" layer="201" rot="R270"/>
<rectangle x1="66.2625" y1="18.2115" x2="66.3195" y2="18.2685" layer="201" rot="R270"/>
<rectangle x1="66.1485" y1="17.9835" x2="66.4335" y2="18.0405" layer="201" rot="R270"/>
<rectangle x1="66.177" y1="17.613" x2="66.405" y2="17.67" layer="201" rot="R270"/>
<rectangle x1="65.778" y1="12.825" x2="66.804" y2="12.882" layer="201" rot="R270"/>
<rectangle x1="66.2625" y1="10.0605" x2="66.3195" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="65.721" y1="21.489" x2="66.975" y2="21.546" layer="200" rot="R270"/>
<rectangle x1="65.778" y1="19.266" x2="66.918" y2="19.323" layer="200" rot="R270"/>
<rectangle x1="66.2625" y1="18.3825" x2="66.4335" y2="18.4395" layer="200" rot="R270"/>
<rectangle x1="66.3195" y1="18.0975" x2="66.3765" y2="18.1545" layer="200" rot="R270"/>
<rectangle x1="65.721" y1="16.872" x2="66.975" y2="16.929" layer="200" rot="R270"/>
<rectangle x1="65.949" y1="15.732" x2="66.747" y2="15.789" layer="200" rot="R270"/>
<rectangle x1="65.379" y1="14.307" x2="67.317" y2="14.364" layer="200" rot="R270"/>
<rectangle x1="65.2365" y1="11.2005" x2="67.4595" y2="11.2575" layer="200" rot="R270"/>
<rectangle x1="64.3245" y1="24.1395" x2="68.3715" y2="24.1965" layer="201" rot="R270"/>
<rectangle x1="65.835" y1="20.349" x2="66.861" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="66.234" y1="18.582" x2="66.462" y2="18.639" layer="201" rot="R270"/>
<rectangle x1="66.2625" y1="18.2115" x2="66.4335" y2="18.2685" layer="201" rot="R270"/>
<rectangle x1="66.063" y1="17.784" x2="66.633" y2="17.841" layer="201" rot="R270"/>
<rectangle x1="66.291" y1="16.188" x2="66.405" y2="16.245" layer="201" rot="R270"/>
<rectangle x1="66.3195" y1="15.3045" x2="66.3765" y2="15.3615" layer="201" rot="R270"/>
<rectangle x1="65.835" y1="12.825" x2="66.861" y2="12.882" layer="201" rot="R270"/>
<rectangle x1="66.3195" y1="10.0605" x2="66.3765" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="65.778" y1="21.489" x2="67.032" y2="21.546" layer="200" rot="R270"/>
<rectangle x1="65.8635" y1="19.2945" x2="66.9465" y2="19.3515" layer="200" rot="R270"/>
<rectangle x1="66.3195" y1="18.2115" x2="66.4905" y2="18.2685" layer="200" rot="R270"/>
<rectangle x1="66.3765" y1="17.7555" x2="66.4335" y2="17.8125" layer="200" rot="R270"/>
<rectangle x1="65.721" y1="16.815" x2="67.089" y2="16.872" layer="200" rot="R270"/>
<rectangle x1="66.348" y1="16.017" x2="66.462" y2="16.074" layer="200" rot="R270"/>
<rectangle x1="66.348" y1="15.675" x2="66.462" y2="15.732" layer="200" rot="R270"/>
<rectangle x1="66.348" y1="15.447" x2="66.462" y2="15.504" layer="200" rot="R270"/>
<rectangle x1="65.436" y1="14.307" x2="67.374" y2="14.364" layer="200" rot="R270"/>
<rectangle x1="65.7495" y1="11.6565" x2="67.0605" y2="11.7135" layer="200" rot="R270"/>
<rectangle x1="66.0345" y1="10.4595" x2="66.7755" y2="10.5165" layer="200" rot="R270"/>
<rectangle x1="64.3815" y1="24.1395" x2="68.4285" y2="24.1965" layer="201" rot="R270"/>
<rectangle x1="65.892" y1="20.349" x2="66.918" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="66.177" y1="18.525" x2="66.633" y2="18.582" layer="201" rot="R270"/>
<rectangle x1="66.234" y1="17.955" x2="66.576" y2="18.012" layer="201" rot="R270"/>
<rectangle x1="66.291" y1="17.613" x2="66.519" y2="17.67" layer="201" rot="R270"/>
<rectangle x1="66.3765" y1="16.1025" x2="66.4335" y2="16.1595" layer="201" rot="R270"/>
<rectangle x1="66.291" y1="15.846" x2="66.519" y2="15.903" layer="201" rot="R270"/>
<rectangle x1="66.348" y1="15.561" x2="66.462" y2="15.618" layer="201" rot="R270"/>
<rectangle x1="66.348" y1="15.333" x2="66.462" y2="15.39" layer="201" rot="R270"/>
<rectangle x1="65.892" y1="12.825" x2="66.918" y2="12.882" layer="201" rot="R270"/>
<rectangle x1="66.3195" y1="10.9155" x2="66.4905" y2="10.9725" layer="201" rot="R270"/>
<rectangle x1="66.3765" y1="10.0605" x2="66.4335" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="65.8635" y1="21.4605" x2="67.0605" y2="21.5175" layer="200" rot="R270"/>
<rectangle x1="65.9205" y1="19.2945" x2="67.0035" y2="19.3515" layer="200" rot="R270"/>
<rectangle x1="65.835" y1="16.758" x2="67.089" y2="16.815" layer="200" rot="R270"/>
<rectangle x1="66.405" y1="15.846" x2="66.519" y2="15.903" layer="200" rot="R270"/>
<rectangle x1="66.4335" y1="15.6465" x2="66.4905" y2="15.7035" layer="200" rot="R270"/>
<rectangle x1="66.405" y1="15.447" x2="66.519" y2="15.504" layer="200" rot="R270"/>
<rectangle x1="66.3195" y1="15.1905" x2="66.6045" y2="15.2475" layer="200" rot="R270"/>
<rectangle x1="65.6355" y1="14.1645" x2="67.2885" y2="14.2215" layer="200" rot="R270"/>
<rectangle x1="66.3765" y1="13.0815" x2="66.5475" y2="13.1385" layer="200" rot="R270"/>
<rectangle x1="66.405" y1="12.483" x2="66.519" y2="12.54" layer="200" rot="R270"/>
<rectangle x1="65.8065" y1="11.6565" x2="67.1175" y2="11.7135" layer="200" rot="R270"/>
<rectangle x1="66.0915" y1="10.4595" x2="66.8325" y2="10.5165" layer="200" rot="R270"/>
<rectangle x1="64.41" y1="24.111" x2="68.514" y2="24.168" layer="201" rot="R270"/>
<rectangle x1="65.949" y1="20.349" x2="66.975" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="65.778" y1="18.069" x2="67.146" y2="18.126" layer="201" rot="R270"/>
<rectangle x1="66.348" y1="16.017" x2="66.576" y2="16.074" layer="201" rot="R270"/>
<rectangle x1="66.405" y1="15.732" x2="66.519" y2="15.789" layer="201" rot="R270"/>
<rectangle x1="66.405" y1="15.561" x2="66.519" y2="15.618" layer="201" rot="R270"/>
<rectangle x1="66.4335" y1="15.3615" x2="66.4905" y2="15.4185" layer="201" rot="R270"/>
<rectangle x1="66.4335" y1="15.0195" x2="66.4905" y2="15.0765" layer="201" rot="R270"/>
<rectangle x1="66.3765" y1="13.2525" x2="66.5475" y2="13.3095" layer="201" rot="R270"/>
<rectangle x1="66.234" y1="12.768" x2="66.69" y2="12.825" layer="201" rot="R270"/>
<rectangle x1="66.405" y1="12.369" x2="66.519" y2="12.426" layer="201" rot="R270"/>
<rectangle x1="66.3765" y1="10.9155" x2="66.5475" y2="10.9725" layer="201" rot="R270"/>
<rectangle x1="66.4335" y1="10.0605" x2="66.4905" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="65.9205" y1="21.4605" x2="67.1175" y2="21.5175" layer="200" rot="R270"/>
<rectangle x1="65.9775" y1="19.2945" x2="67.0605" y2="19.3515" layer="200" rot="R270"/>
<rectangle x1="65.949" y1="16.815" x2="67.089" y2="16.872" layer="200" rot="R270"/>
<rectangle x1="66.3195" y1="15.9885" x2="66.7185" y2="16.0455" layer="200" rot="R270"/>
<rectangle x1="66.4905" y1="15.6465" x2="66.5475" y2="15.7035" layer="200" rot="R270"/>
<rectangle x1="66.291" y1="15.276" x2="66.747" y2="15.333" layer="200" rot="R270"/>
<rectangle x1="65.6925" y1="14.1645" x2="67.3455" y2="14.2215" layer="200" rot="R270"/>
<rectangle x1="66.4905" y1="13.1385" x2="66.5475" y2="13.1955" layer="200" rot="R270"/>
<rectangle x1="66.4905" y1="13.0245" x2="66.5475" y2="13.0815" layer="200" rot="R270"/>
<rectangle x1="66.4905" y1="12.6825" x2="66.5475" y2="12.7395" layer="200" rot="R270"/>
<rectangle x1="66.4905" y1="12.4545" x2="66.5475" y2="12.5115" layer="200" rot="R270"/>
<rectangle x1="65.8635" y1="11.6565" x2="67.1745" y2="11.7135" layer="200" rot="R270"/>
<rectangle x1="66.1485" y1="10.4595" x2="66.8895" y2="10.5165" layer="200" rot="R270"/>
<rectangle x1="64.467" y1="24.111" x2="68.571" y2="24.168" layer="201" rot="R270"/>
<rectangle x1="66.006" y1="20.349" x2="67.032" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="65.835" y1="18.069" x2="67.203" y2="18.126" layer="201" rot="R270"/>
<rectangle x1="66.4905" y1="16.2165" x2="66.5475" y2="16.2735" layer="201" rot="R270"/>
<rectangle x1="66.462" y1="15.732" x2="66.576" y2="15.789" layer="201" rot="R270"/>
<rectangle x1="66.462" y1="15.561" x2="66.576" y2="15.618" layer="201" rot="R270"/>
<rectangle x1="66.4905" y1="15.0195" x2="66.5475" y2="15.0765" layer="201" rot="R270"/>
<rectangle x1="66.4335" y1="13.2525" x2="66.6045" y2="13.3095" layer="201" rot="R270"/>
<rectangle x1="66.4905" y1="13.0815" x2="66.5475" y2="13.1385" layer="201" rot="R270"/>
<rectangle x1="66.3765" y1="12.8535" x2="66.6615" y2="12.9105" layer="201" rot="R270"/>
<rectangle x1="66.4335" y1="12.5685" x2="66.6045" y2="12.6255" layer="201" rot="R270"/>
<rectangle x1="66.462" y1="12.369" x2="66.576" y2="12.426" layer="201" rot="R270"/>
<rectangle x1="66.4335" y1="10.9155" x2="66.6045" y2="10.9725" layer="201" rot="R270"/>
<rectangle x1="66.4905" y1="10.0605" x2="66.5475" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="66.006" y1="21.432" x2="67.146" y2="21.489" layer="200" rot="R270"/>
<rectangle x1="66.0345" y1="19.2945" x2="67.1175" y2="19.3515" layer="200" rot="R270"/>
<rectangle x1="66.0345" y1="16.7865" x2="67.1175" y2="16.8435" layer="200" rot="R270"/>
<rectangle x1="66.4905" y1="16.1025" x2="66.6615" y2="16.1595" layer="200" rot="R270"/>
<rectangle x1="66.4905" y1="15.8745" x2="66.6615" y2="15.9315" layer="200" rot="R270"/>
<rectangle x1="66.5475" y1="15.6465" x2="66.6045" y2="15.7035" layer="200" rot="R270"/>
<rectangle x1="66.462" y1="15.39" x2="66.69" y2="15.447" layer="200" rot="R270"/>
<rectangle x1="66.4905" y1="15.1335" x2="66.6615" y2="15.1905" layer="200" rot="R270"/>
<rectangle x1="66.405" y1="14.82" x2="66.747" y2="14.877" layer="200" rot="R270"/>
<rectangle x1="65.9775" y1="13.9365" x2="67.1745" y2="13.9935" layer="200" rot="R270"/>
<rectangle x1="66.5475" y1="13.1385" x2="66.6045" y2="13.1955" layer="200" rot="R270"/>
<rectangle x1="66.5475" y1="12.9675" x2="66.6045" y2="13.0245" layer="200" rot="R270"/>
<rectangle x1="65.9205" y1="11.6565" x2="67.2315" y2="11.7135" layer="200" rot="R270"/>
<rectangle x1="66.2055" y1="10.4595" x2="66.9465" y2="10.5165" layer="200" rot="R270"/>
<rectangle x1="64.4955" y1="24.0825" x2="68.6565" y2="24.1395" layer="201" rot="R270"/>
<rectangle x1="66.063" y1="20.349" x2="67.089" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="65.8635" y1="18.0405" x2="67.2885" y2="18.0975" layer="201" rot="R270"/>
<rectangle x1="66.5475" y1="16.2165" x2="66.6045" y2="16.2735" layer="201" rot="R270"/>
<rectangle x1="66.5475" y1="15.9885" x2="66.6045" y2="16.0455" layer="201" rot="R270"/>
<rectangle x1="66.519" y1="15.732" x2="66.633" y2="15.789" layer="201" rot="R270"/>
<rectangle x1="66.519" y1="15.561" x2="66.633" y2="15.618" layer="201" rot="R270"/>
<rectangle x1="66.5475" y1="15.2475" x2="66.6045" y2="15.3045" layer="201" rot="R270"/>
<rectangle x1="66.5475" y1="15.0195" x2="66.6045" y2="15.0765" layer="201" rot="R270"/>
<rectangle x1="66.519" y1="14.592" x2="66.633" y2="14.649" layer="201" rot="R270"/>
<rectangle x1="66.4905" y1="13.2525" x2="66.6615" y2="13.3095" layer="201" rot="R270"/>
<rectangle x1="66.519" y1="13.053" x2="66.633" y2="13.11" layer="201" rot="R270"/>
<rectangle x1="66.2625" y1="12.6255" x2="66.8895" y2="12.6825" layer="201" rot="R270"/>
<rectangle x1="66.4905" y1="10.9155" x2="66.6615" y2="10.9725" layer="201" rot="R270"/>
<rectangle x1="66.5475" y1="10.0605" x2="66.6045" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="66.12" y1="21.375" x2="67.146" y2="21.432" layer="200" rot="R270"/>
<rectangle x1="66.0915" y1="19.2945" x2="67.1745" y2="19.3515" layer="200" rot="R270"/>
<rectangle x1="65.949" y1="16.644" x2="67.317" y2="16.701" layer="200" rot="R270"/>
<rectangle x1="66.576" y1="15.846" x2="66.69" y2="15.903" layer="200" rot="R270"/>
<rectangle x1="66.576" y1="15.675" x2="66.69" y2="15.732" layer="200" rot="R270"/>
<rectangle x1="66.6045" y1="15.4755" x2="66.6615" y2="15.5325" layer="200" rot="R270"/>
<rectangle x1="66.6045" y1="15.3045" x2="66.6615" y2="15.3615" layer="200" rot="R270"/>
<rectangle x1="66.348" y1="14.934" x2="66.918" y2="14.991" layer="200" rot="R270"/>
<rectangle x1="65.949" y1="13.851" x2="67.317" y2="13.908" layer="200" rot="R270"/>
<rectangle x1="66.576" y1="12.939" x2="66.69" y2="12.996" layer="200" rot="R270"/>
<rectangle x1="66.6045" y1="12.7395" x2="66.6615" y2="12.7965" layer="200" rot="R270"/>
<rectangle x1="65.9205" y1="11.7135" x2="67.3455" y2="11.7705" layer="200" rot="R270"/>
<rectangle x1="66.2625" y1="10.4595" x2="67.0035" y2="10.5165" layer="200" rot="R270"/>
<rectangle x1="64.4955" y1="24.0255" x2="68.7705" y2="24.0825" layer="201" rot="R270"/>
<rectangle x1="66.12" y1="20.349" x2="67.146" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="65.9205" y1="18.0405" x2="67.3455" y2="18.0975" layer="201" rot="R270"/>
<rectangle x1="66.6045" y1="15.9315" x2="66.6615" y2="15.9885" layer="201" rot="R270"/>
<rectangle x1="66.6045" y1="15.7605" x2="66.6615" y2="15.8175" layer="201" rot="R270"/>
<rectangle x1="66.576" y1="15.561" x2="66.69" y2="15.618" layer="201" rot="R270"/>
<rectangle x1="66.576" y1="15.39" x2="66.69" y2="15.447" layer="201" rot="R270"/>
<rectangle x1="66.6045" y1="15.2475" x2="66.6615" y2="15.3045" layer="201" rot="R270"/>
<rectangle x1="66.576" y1="14.592" x2="66.69" y2="14.649" layer="201" rot="R270"/>
<rectangle x1="66.5475" y1="13.0815" x2="66.7185" y2="13.1385" layer="201" rot="R270"/>
<rectangle x1="66.576" y1="12.825" x2="66.69" y2="12.882" layer="201" rot="R270"/>
<rectangle x1="66.4905" y1="12.5685" x2="66.7755" y2="12.6255" layer="201" rot="R270"/>
<rectangle x1="66.5475" y1="10.9155" x2="66.7185" y2="10.9725" layer="201" rot="R270"/>
<rectangle x1="66.6045" y1="10.0605" x2="66.6615" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="65.5215" y1="19.9215" x2="67.8585" y2="19.9785" layer="200" rot="R270"/>
<rectangle x1="65.9775" y1="16.6155" x2="67.4025" y2="16.6725" layer="200" rot="R270"/>
<rectangle x1="66.633" y1="15.732" x2="66.747" y2="15.789" layer="200" rot="R270"/>
<rectangle x1="65.55" y1="14.307" x2="67.83" y2="14.364" layer="200" rot="R270"/>
<rectangle x1="66.6615" y1="12.7965" x2="66.7185" y2="12.8535" layer="200" rot="R270"/>
<rectangle x1="65.9775" y1="11.7135" x2="67.4025" y2="11.7705" layer="200" rot="R270"/>
<rectangle x1="66.3195" y1="10.4595" x2="67.0605" y2="10.5165" layer="200" rot="R270"/>
<rectangle x1="64.1535" y1="23.6265" x2="69.2265" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="65.9775" y1="18.0405" x2="67.4025" y2="18.0975" layer="201" rot="R270"/>
<rectangle x1="66.633" y1="15.846" x2="66.747" y2="15.903" layer="201" rot="R270"/>
<rectangle x1="66.576" y1="15.561" x2="66.804" y2="15.618" layer="201" rot="R270"/>
<rectangle x1="66.519" y1="12.996" x2="66.861" y2="13.053" layer="201" rot="R270"/>
<rectangle x1="66.519" y1="12.597" x2="66.861" y2="12.654" layer="201" rot="R270"/>
<rectangle x1="66.6045" y1="10.9155" x2="66.7755" y2="10.9725" layer="201" rot="R270"/>
<rectangle x1="66.6615" y1="10.0605" x2="66.7185" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="65.5785" y1="19.9215" x2="67.9155" y2="19.9785" layer="200" rot="R270"/>
<rectangle x1="64.6665" y1="15.2475" x2="68.8275" y2="15.3045" layer="200" rot="R270"/>
<rectangle x1="66.0345" y1="11.7135" x2="67.4595" y2="11.7705" layer="200" rot="R270"/>
<rectangle x1="66.3765" y1="10.4595" x2="67.1175" y2="10.5165" layer="200" rot="R270"/>
<rectangle x1="64.2105" y1="23.6265" x2="69.2835" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="66.0345" y1="18.0405" x2="67.4595" y2="18.0975" layer="201" rot="R270"/>
<rectangle x1="66.3765" y1="12.7965" x2="67.1175" y2="12.8535" layer="201" rot="R270"/>
<rectangle x1="66.6615" y1="10.9155" x2="66.8325" y2="10.9725" layer="201" rot="R270"/>
<rectangle x1="66.7185" y1="10.0605" x2="66.7755" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="65.6355" y1="19.9215" x2="67.9725" y2="19.9785" layer="200" rot="R270"/>
<rectangle x1="64.752" y1="15.276" x2="68.856" y2="15.333" layer="200" rot="R270"/>
<rectangle x1="66.7755" y1="12.6255" x2="66.8325" y2="12.6825" layer="200" rot="R270"/>
<rectangle x1="66.0915" y1="11.7135" x2="67.5165" y2="11.7705" layer="200" rot="R270"/>
<rectangle x1="66.4335" y1="10.4595" x2="67.1745" y2="10.5165" layer="200" rot="R270"/>
<rectangle x1="64.2675" y1="23.6265" x2="69.3405" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="66.0915" y1="18.0405" x2="67.5165" y2="18.0975" layer="201" rot="R270"/>
<rectangle x1="66.519" y1="12.939" x2="67.089" y2="12.996" layer="201" rot="R270"/>
<rectangle x1="66.7185" y1="12.5115" x2="66.8895" y2="12.5685" layer="201" rot="R270"/>
<rectangle x1="66.7185" y1="10.9155" x2="66.8895" y2="10.9725" layer="201" rot="R270"/>
<rectangle x1="66.7755" y1="10.0605" x2="66.8325" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="66.747" y1="20.976" x2="66.975" y2="21.033" layer="200" rot="R270"/>
<rectangle x1="66.291" y1="19.323" x2="67.431" y2="19.38" layer="200" rot="R270"/>
<rectangle x1="64.7805" y1="15.2475" x2="68.9415" y2="15.3045" layer="200" rot="R270"/>
<rectangle x1="66.8325" y1="12.7395" x2="66.8895" y2="12.7965" layer="200" rot="R270"/>
<rectangle x1="66.1485" y1="11.7135" x2="67.5735" y2="11.7705" layer="200" rot="R270"/>
<rectangle x1="66.4905" y1="10.4595" x2="67.2315" y2="10.5165" layer="200" rot="R270"/>
<rectangle x1="64.3245" y1="23.6265" x2="69.3975" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="66.3765" y1="20.3775" x2="67.3455" y2="20.4345" layer="201" rot="R270"/>
<rectangle x1="66.1485" y1="18.0405" x2="67.5735" y2="18.0975" layer="201" rot="R270"/>
<rectangle x1="66.6615" y1="12.9675" x2="67.0605" y2="13.0245" layer="201" rot="R270"/>
<rectangle x1="66.7185" y1="12.5685" x2="67.0035" y2="12.6255" layer="201" rot="R270"/>
<rectangle x1="66.7755" y1="10.9155" x2="66.9465" y2="10.9725" layer="201" rot="R270"/>
<rectangle x1="66.8325" y1="10.0605" x2="66.8895" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="66.804" y1="20.976" x2="67.032" y2="21.033" layer="200" rot="R270"/>
<rectangle x1="66.3765" y1="19.2945" x2="67.4595" y2="19.3515" layer="200" rot="R270"/>
<rectangle x1="64.8375" y1="15.2475" x2="68.9985" y2="15.3045" layer="200" rot="R270"/>
<rectangle x1="66.8895" y1="12.7395" x2="66.9465" y2="12.7965" layer="200" rot="R270"/>
<rectangle x1="66.2055" y1="11.7135" x2="67.6305" y2="11.7705" layer="200" rot="R270"/>
<rectangle x1="66.5475" y1="10.4595" x2="67.2885" y2="10.5165" layer="200" rot="R270"/>
<rectangle x1="64.3815" y1="23.6265" x2="69.4545" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="66.405" y1="20.349" x2="67.431" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="66.2055" y1="18.0405" x2="67.6305" y2="18.0975" layer="201" rot="R270"/>
<rectangle x1="66.7185" y1="12.9675" x2="67.1175" y2="13.0245" layer="201" rot="R270"/>
<rectangle x1="66.7755" y1="12.5685" x2="67.0605" y2="12.6255" layer="201" rot="R270"/>
<rectangle x1="66.8325" y1="10.9155" x2="67.0035" y2="10.9725" layer="201" rot="R270"/>
<rectangle x1="66.8895" y1="10.0605" x2="66.9465" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="66.861" y1="20.976" x2="67.089" y2="21.033" layer="200" rot="R270"/>
<rectangle x1="66.4335" y1="19.2945" x2="67.5165" y2="19.3515" layer="200" rot="R270"/>
<rectangle x1="64.8945" y1="15.2475" x2="69.0555" y2="15.3045" layer="200" rot="R270"/>
<rectangle x1="66.9465" y1="12.7965" x2="67.0035" y2="12.8535" layer="200" rot="R270"/>
<rectangle x1="66.9465" y1="12.6825" x2="67.0035" y2="12.7395" layer="200" rot="R270"/>
<rectangle x1="65.8065" y1="11.2575" x2="68.1435" y2="11.3145" layer="200" rot="R270"/>
<rectangle x1="64.4385" y1="23.6265" x2="69.5115" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="66.462" y1="20.349" x2="67.488" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="66.2625" y1="18.0405" x2="67.6875" y2="18.0975" layer="201" rot="R270"/>
<rectangle x1="66.804" y1="12.996" x2="67.146" y2="13.053" layer="201" rot="R270"/>
<rectangle x1="66.9465" y1="12.7395" x2="67.0035" y2="12.7965" layer="201" rot="R270"/>
<rectangle x1="66.861" y1="12.54" x2="67.089" y2="12.597" layer="201" rot="R270"/>
<rectangle x1="66.9465" y1="10.0605" x2="67.0035" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="66.918" y1="20.976" x2="67.146" y2="21.033" layer="200" rot="R270"/>
<rectangle x1="66.4905" y1="19.2945" x2="67.5735" y2="19.3515" layer="200" rot="R270"/>
<rectangle x1="65.037" y1="15.333" x2="69.027" y2="15.39" layer="200" rot="R270"/>
<rectangle x1="67.0035" y1="13.1385" x2="67.0605" y2="13.1955" layer="200" rot="R270"/>
<rectangle x1="66.9465" y1="12.5115" x2="67.1175" y2="12.5685" layer="200" rot="R270"/>
<rectangle x1="65.9205" y1="11.2005" x2="68.1435" y2="11.2575" layer="200" rot="R270"/>
<rectangle x1="64.4955" y1="23.6265" x2="69.5685" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="66.519" y1="20.349" x2="67.545" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="66.3195" y1="18.0405" x2="67.7445" y2="18.0975" layer="201" rot="R270"/>
<rectangle x1="66.9465" y1="13.2525" x2="67.1175" y2="13.3095" layer="201" rot="R270"/>
<rectangle x1="66.7755" y1="12.8535" x2="67.2885" y2="12.9105" layer="201" rot="R270"/>
<rectangle x1="66.975" y1="12.369" x2="67.089" y2="12.426" layer="201" rot="R270"/>
<rectangle x1="67.0035" y1="10.0605" x2="67.0605" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="66.975" y1="20.976" x2="67.203" y2="21.033" layer="200" rot="R270"/>
<rectangle x1="66.5475" y1="19.2945" x2="67.6305" y2="19.3515" layer="200" rot="R270"/>
<rectangle x1="65.0655" y1="15.3615" x2="69.1125" y2="15.4185" layer="200" rot="R270"/>
<rectangle x1="67.0605" y1="13.1385" x2="67.1175" y2="13.1955" layer="200" rot="R270"/>
<rectangle x1="67.0035" y1="12.8535" x2="67.1745" y2="12.9105" layer="200" rot="R270"/>
<rectangle x1="67.0605" y1="12.6825" x2="67.1175" y2="12.7395" layer="200" rot="R270"/>
<rectangle x1="67.0605" y1="12.4545" x2="67.1175" y2="12.5115" layer="200" rot="R270"/>
<rectangle x1="65.9775" y1="11.2005" x2="68.2005" y2="11.2575" layer="200" rot="R270"/>
<rectangle x1="64.5525" y1="23.6265" x2="69.6255" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="66.576" y1="20.349" x2="67.602" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="66.405" y1="18.069" x2="67.773" y2="18.126" layer="201" rot="R270"/>
<rectangle x1="67.0035" y1="13.2525" x2="67.1745" y2="13.3095" layer="201" rot="R270"/>
<rectangle x1="67.0035" y1="13.0245" x2="67.1745" y2="13.0815" layer="201" rot="R270"/>
<rectangle x1="67.0605" y1="12.7395" x2="67.1175" y2="12.7965" layer="201" rot="R270"/>
<rectangle x1="67.0035" y1="12.5685" x2="67.1745" y2="12.6255" layer="201" rot="R270"/>
<rectangle x1="67.032" y1="12.369" x2="67.146" y2="12.426" layer="201" rot="R270"/>
<rectangle x1="67.0605" y1="10.0605" x2="67.1175" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="67.032" y1="20.976" x2="67.26" y2="21.033" layer="200" rot="R270"/>
<rectangle x1="66.576" y1="19.266" x2="67.716" y2="19.323" layer="200" rot="R270"/>
<rectangle x1="65.1225" y1="15.3615" x2="69.1695" y2="15.4185" layer="200" rot="R270"/>
<rectangle x1="67.0605" y1="13.0815" x2="67.2315" y2="13.1385" layer="200" rot="R270"/>
<rectangle x1="67.089" y1="12.483" x2="67.203" y2="12.54" layer="200" rot="R270"/>
<rectangle x1="66.0345" y1="11.2005" x2="68.2575" y2="11.2575" layer="200" rot="R270"/>
<rectangle x1="64.6095" y1="23.6265" x2="69.6825" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="66.633" y1="20.349" x2="67.659" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="66.4905" y1="18.0405" x2="67.8015" y2="18.0975" layer="201" rot="R270"/>
<rectangle x1="67.0605" y1="13.2525" x2="67.2315" y2="13.3095" layer="201" rot="R270"/>
<rectangle x1="66.918" y1="12.768" x2="67.374" y2="12.825" layer="201" rot="R270"/>
<rectangle x1="67.089" y1="12.369" x2="67.203" y2="12.426" layer="201" rot="R270"/>
<rectangle x1="67.1175" y1="10.0605" x2="67.1745" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="67.089" y1="20.976" x2="67.317" y2="21.033" layer="200" rot="R270"/>
<rectangle x1="66.633" y1="19.266" x2="67.773" y2="19.323" layer="200" rot="R270"/>
<rectangle x1="65.1795" y1="15.3615" x2="69.2265" y2="15.4185" layer="200" rot="R270"/>
<rectangle x1="66.0915" y1="11.2005" x2="68.3145" y2="11.2575" layer="200" rot="R270"/>
<rectangle x1="64.6665" y1="23.6265" x2="69.7395" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="66.69" y1="20.349" x2="67.716" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="66.5475" y1="18.0405" x2="67.8585" y2="18.0975" layer="201" rot="R270"/>
<rectangle x1="66.69" y1="12.825" x2="67.716" y2="12.882" layer="201" rot="R270"/>
<rectangle x1="67.1745" y1="10.0605" x2="67.2315" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="67.146" y1="20.976" x2="67.374" y2="21.033" layer="200" rot="R270"/>
<rectangle x1="66.69" y1="19.266" x2="67.83" y2="19.323" layer="200" rot="R270"/>
<rectangle x1="65.208" y1="15.39" x2="69.312" y2="15.447" layer="200" rot="R270"/>
<rectangle x1="66.1485" y1="11.2005" x2="68.3715" y2="11.2575" layer="200" rot="R270"/>
<rectangle x1="64.7235" y1="23.6265" x2="69.7965" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="66.747" y1="20.349" x2="67.773" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="66.633" y1="18.069" x2="67.887" y2="18.126" layer="201" rot="R270"/>
<rectangle x1="66.747" y1="12.825" x2="67.773" y2="12.882" layer="201" rot="R270"/>
<rectangle x1="67.2315" y1="10.0605" x2="67.2885" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="67.203" y1="20.976" x2="67.431" y2="21.033" layer="200" rot="R270"/>
<rectangle x1="66.7185" y1="19.2375" x2="67.9155" y2="19.2945" layer="200" rot="R270"/>
<rectangle x1="65.265" y1="15.39" x2="69.369" y2="15.447" layer="200" rot="R270"/>
<rectangle x1="66.2055" y1="11.2005" x2="68.4285" y2="11.2575" layer="200" rot="R270"/>
<rectangle x1="64.7805" y1="23.6265" x2="69.8535" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="66.804" y1="20.349" x2="67.83" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="66.7185" y1="18.0405" x2="67.9155" y2="18.0975" layer="201" rot="R270"/>
<rectangle x1="66.804" y1="12.825" x2="67.83" y2="12.882" layer="201" rot="R270"/>
<rectangle x1="67.2885" y1="10.0605" x2="67.3455" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="67.26" y1="20.976" x2="67.488" y2="21.033" layer="200" rot="R270"/>
<rectangle x1="66.7185" y1="19.1805" x2="68.0295" y2="19.2375" layer="200" rot="R270"/>
<rectangle x1="66.918" y1="17.1" x2="67.83" y2="17.157" layer="200" rot="R270"/>
<rectangle x1="66.8325" y1="15.3615" x2="67.9155" y2="15.4185" layer="200" rot="R270"/>
<rectangle x1="67.089" y1="13.623" x2="67.659" y2="13.68" layer="200" rot="R270"/>
<rectangle x1="66.2625" y1="11.2005" x2="68.4855" y2="11.2575" layer="200" rot="R270"/>
<rectangle x1="64.8375" y1="23.6265" x2="69.9105" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="66.861" y1="20.349" x2="67.887" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="66.8895" y1="18.0405" x2="67.8585" y2="18.0975" layer="201" rot="R270"/>
<rectangle x1="67.0035" y1="16.2735" x2="67.7445" y2="16.3305" layer="201" rot="R270"/>
<rectangle x1="66.918" y1="14.364" x2="67.83" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="66.861" y1="12.825" x2="67.887" y2="12.882" layer="201" rot="R270"/>
<rectangle x1="67.3455" y1="10.0605" x2="67.4025" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="67.317" y1="20.976" x2="67.545" y2="21.033" layer="200" rot="R270"/>
<rectangle x1="66.69" y1="19.095" x2="68.172" y2="19.152" layer="200" rot="R270"/>
<rectangle x1="67.146" y1="18.012" x2="67.716" y2="18.069" layer="200" rot="R270"/>
<rectangle x1="66.918" y1="17.157" x2="67.944" y2="17.214" layer="200" rot="R270"/>
<rectangle x1="66.8895" y1="15.3615" x2="67.9725" y2="15.4185" layer="200" rot="R270"/>
<rectangle x1="67.146" y1="13.623" x2="67.716" y2="13.68" layer="200" rot="R270"/>
<rectangle x1="66.3195" y1="11.2005" x2="68.5425" y2="11.2575" layer="200" rot="R270"/>
<rectangle x1="64.8945" y1="23.6265" x2="69.9675" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="66.918" y1="20.349" x2="67.944" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="67.4025" y1="18.3255" x2="67.4595" y2="18.3825" layer="201" rot="R270"/>
<rectangle x1="67.4025" y1="17.6985" x2="67.4595" y2="17.7555" layer="201" rot="R270"/>
<rectangle x1="67.0605" y1="16.2735" x2="67.8015" y2="16.3305" layer="201" rot="R270"/>
<rectangle x1="66.975" y1="14.364" x2="67.887" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="66.918" y1="12.825" x2="67.944" y2="12.882" layer="201" rot="R270"/>
<rectangle x1="67.4025" y1="10.0605" x2="67.4595" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="67.374" y1="20.976" x2="67.602" y2="21.033" layer="200" rot="R270"/>
<rectangle x1="65.9205" y1="18.2685" x2="69.0555" y2="18.3255" layer="200" rot="R270"/>
<rectangle x1="66.9465" y1="15.3615" x2="68.0295" y2="15.4185" layer="200" rot="R270"/>
<rectangle x1="67.203" y1="13.623" x2="67.773" y2="13.68" layer="200" rot="R270"/>
<rectangle x1="66.3765" y1="11.2005" x2="68.5995" y2="11.2575" layer="200" rot="R270"/>
<rectangle x1="64.9515" y1="23.6265" x2="70.0245" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="66.975" y1="20.349" x2="68.001" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="67.089" y1="16.302" x2="67.887" y2="16.359" layer="201" rot="R270"/>
<rectangle x1="67.032" y1="14.364" x2="67.944" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="66.975" y1="12.825" x2="68.001" y2="12.882" layer="201" rot="R270"/>
<rectangle x1="67.4595" y1="10.0605" x2="67.5165" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="67.431" y1="20.976" x2="67.659" y2="21.033" layer="200" rot="R270"/>
<rectangle x1="65.9775" y1="18.2685" x2="69.1125" y2="18.3255" layer="200" rot="R270"/>
<rectangle x1="67.032" y1="15.333" x2="68.058" y2="15.39" layer="200" rot="R270"/>
<rectangle x1="67.26" y1="13.623" x2="67.83" y2="13.68" layer="200" rot="R270"/>
<rectangle x1="66.4335" y1="11.2005" x2="68.6565" y2="11.2575" layer="200" rot="R270"/>
<rectangle x1="65.0085" y1="23.6265" x2="70.0815" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="67.032" y1="20.349" x2="68.058" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="67.1175" y1="16.2735" x2="67.9725" y2="16.3305" layer="201" rot="R270"/>
<rectangle x1="67.089" y1="14.364" x2="68.001" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="67.032" y1="12.825" x2="68.058" y2="12.882" layer="201" rot="R270"/>
<rectangle x1="67.5165" y1="10.0605" x2="67.5735" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="67.488" y1="20.976" x2="67.716" y2="21.033" layer="200" rot="R270"/>
<rectangle x1="66.0345" y1="18.2685" x2="69.1695" y2="18.3255" layer="200" rot="R270"/>
<rectangle x1="67.089" y1="15.333" x2="68.115" y2="15.39" layer="200" rot="R270"/>
<rectangle x1="67.317" y1="13.623" x2="67.887" y2="13.68" layer="200" rot="R270"/>
<rectangle x1="66.4905" y1="11.2005" x2="68.7135" y2="11.2575" layer="200" rot="R270"/>
<rectangle x1="65.0655" y1="23.6265" x2="70.1385" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="67.089" y1="20.349" x2="68.115" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="67.1745" y1="16.2735" x2="68.0295" y2="16.3305" layer="201" rot="R270"/>
<rectangle x1="67.146" y1="14.364" x2="68.058" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="67.089" y1="12.825" x2="68.115" y2="12.882" layer="201" rot="R270"/>
<rectangle x1="67.5735" y1="10.0605" x2="67.6305" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="67.545" y1="20.976" x2="67.773" y2="21.033" layer="200" rot="R270"/>
<rectangle x1="66.0915" y1="18.2685" x2="69.2265" y2="18.3255" layer="200" rot="R270"/>
<rectangle x1="67.1175" y1="15.3615" x2="68.2005" y2="15.4185" layer="200" rot="R270"/>
<rectangle x1="67.374" y1="13.623" x2="67.944" y2="13.68" layer="200" rot="R270"/>
<rectangle x1="66.5475" y1="11.2005" x2="68.7705" y2="11.2575" layer="200" rot="R270"/>
<rectangle x1="65.1225" y1="23.6265" x2="70.1955" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="67.146" y1="20.349" x2="68.172" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="67.26" y1="16.302" x2="68.058" y2="16.359" layer="201" rot="R270"/>
<rectangle x1="67.203" y1="14.364" x2="68.115" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="67.146" y1="12.825" x2="68.172" y2="12.882" layer="201" rot="R270"/>
<rectangle x1="67.6305" y1="10.0605" x2="67.6875" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="65.5215" y1="18.8955" x2="69.9105" y2="18.9525" layer="200" rot="R270"/>
<rectangle x1="67.1745" y1="15.3615" x2="68.2575" y2="15.4185" layer="200" rot="R270"/>
<rectangle x1="67.431" y1="13.623" x2="68.001" y2="13.68" layer="200" rot="R270"/>
<rectangle x1="66.6045" y1="11.2005" x2="68.8275" y2="11.2575" layer="200" rot="R270"/>
<rectangle x1="65.1795" y1="23.6265" x2="70.2525" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="67.317" y1="16.302" x2="68.115" y2="16.359" layer="201" rot="R270"/>
<rectangle x1="67.26" y1="14.364" x2="68.172" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="67.203" y1="12.825" x2="68.229" y2="12.882" layer="201" rot="R270"/>
<rectangle x1="67.6875" y1="10.0605" x2="67.7445" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="66.6615" y1="19.9785" x2="68.8845" y2="20.0355" layer="200" rot="R270"/>
<rectangle x1="67.5165" y1="18.2115" x2="68.0295" y2="18.2685" layer="200" rot="R270"/>
<rectangle x1="67.3455" y1="17.1285" x2="68.2005" y2="17.1855" layer="200" rot="R270"/>
<rectangle x1="67.2315" y1="15.3615" x2="68.3145" y2="15.4185" layer="200" rot="R270"/>
<rectangle x1="67.488" y1="13.623" x2="68.058" y2="13.68" layer="200" rot="R270"/>
<rectangle x1="66.6615" y1="11.2005" x2="68.8845" y2="11.2575" layer="200" rot="R270"/>
<rectangle x1="65.2365" y1="23.6265" x2="70.3095" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="67.5735" y1="18.6675" x2="67.9725" y2="18.7245" layer="201" rot="R270"/>
<rectangle x1="67.5735" y1="17.7555" x2="67.9725" y2="17.8125" layer="201" rot="R270"/>
<rectangle x1="67.374" y1="16.302" x2="68.172" y2="16.359" layer="201" rot="R270"/>
<rectangle x1="67.317" y1="14.364" x2="68.229" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="67.26" y1="12.825" x2="68.286" y2="12.882" layer="201" rot="R270"/>
<rectangle x1="67.7445" y1="10.0605" x2="67.8015" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="66.747" y1="20.007" x2="68.913" y2="20.064" layer="200" rot="R270"/>
<rectangle x1="67.6305" y1="18.2115" x2="68.0295" y2="18.2685" layer="200" rot="R270"/>
<rectangle x1="67.431" y1="17.1" x2="68.229" y2="17.157" layer="200" rot="R270"/>
<rectangle x1="67.2885" y1="15.3615" x2="68.3715" y2="15.4185" layer="200" rot="R270"/>
<rectangle x1="67.545" y1="13.623" x2="68.115" y2="13.68" layer="200" rot="R270"/>
<rectangle x1="66.7185" y1="11.2005" x2="68.9415" y2="11.2575" layer="200" rot="R270"/>
<rectangle x1="65.2935" y1="23.6265" x2="70.3665" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="67.5735" y1="18.6675" x2="68.0865" y2="18.7245" layer="201" rot="R270"/>
<rectangle x1="67.5735" y1="17.7555" x2="68.0865" y2="17.8125" layer="201" rot="R270"/>
<rectangle x1="67.431" y1="16.302" x2="68.229" y2="16.359" layer="201" rot="R270"/>
<rectangle x1="67.374" y1="14.364" x2="68.286" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="67.317" y1="12.825" x2="68.343" y2="12.882" layer="201" rot="R270"/>
<rectangle x1="67.8015" y1="10.0605" x2="67.8585" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="67.773" y1="20.976" x2="68.001" y2="21.033" layer="200" rot="R270"/>
<rectangle x1="67.4595" y1="19.4085" x2="68.3145" y2="19.4655" layer="200" rot="R270"/>
<rectangle x1="67.7445" y1="18.2115" x2="68.0295" y2="18.2685" layer="200" rot="R270"/>
<rectangle x1="67.5165" y1="17.0715" x2="68.2575" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="67.3455" y1="15.3615" x2="68.4285" y2="15.4185" layer="200" rot="R270"/>
<rectangle x1="67.602" y1="13.623" x2="68.172" y2="13.68" layer="200" rot="R270"/>
<rectangle x1="66.7755" y1="11.2005" x2="68.9985" y2="11.2575" layer="200" rot="R270"/>
<rectangle x1="65.3505" y1="23.6265" x2="70.4235" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="67.374" y1="20.349" x2="68.4" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="67.5735" y1="18.6675" x2="68.2005" y2="18.7245" layer="201" rot="R270"/>
<rectangle x1="67.5735" y1="17.7555" x2="68.2005" y2="17.8125" layer="201" rot="R270"/>
<rectangle x1="67.488" y1="16.302" x2="68.286" y2="16.359" layer="201" rot="R270"/>
<rectangle x1="67.431" y1="14.364" x2="68.343" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="67.374" y1="12.825" x2="68.4" y2="12.882" layer="201" rot="R270"/>
<rectangle x1="67.8585" y1="10.0605" x2="67.9155" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="67.83" y1="20.976" x2="68.058" y2="21.033" layer="200" rot="R270"/>
<rectangle x1="67.545" y1="19.437" x2="68.343" y2="19.494" layer="200" rot="R270"/>
<rectangle x1="67.659" y1="18.24" x2="68.229" y2="18.297" layer="200" rot="R270"/>
<rectangle x1="67.602" y1="17.043" x2="68.286" y2="17.1" layer="200" rot="R270"/>
<rectangle x1="67.4025" y1="15.3615" x2="68.4855" y2="15.4185" layer="200" rot="R270"/>
<rectangle x1="67.659" y1="13.623" x2="68.229" y2="13.68" layer="200" rot="R270"/>
<rectangle x1="66.8325" y1="11.2005" x2="69.0555" y2="11.2575" layer="200" rot="R270"/>
<rectangle x1="65.4075" y1="23.6265" x2="70.4805" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="67.431" y1="20.349" x2="68.457" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="67.6875" y1="18.7815" x2="68.2005" y2="18.8385" layer="201" rot="R270"/>
<rectangle x1="67.659" y1="17.67" x2="68.229" y2="17.727" layer="201" rot="R270"/>
<rectangle x1="67.545" y1="16.302" x2="68.343" y2="16.359" layer="201" rot="R270"/>
<rectangle x1="67.488" y1="14.364" x2="68.4" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="67.431" y1="12.825" x2="68.457" y2="12.882" layer="201" rot="R270"/>
<rectangle x1="67.9155" y1="10.0605" x2="67.9725" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="67.887" y1="20.976" x2="68.115" y2="21.033" layer="200" rot="R270"/>
<rectangle x1="67.6305" y1="19.4655" x2="68.3715" y2="19.5225" layer="200" rot="R270"/>
<rectangle x1="67.6875" y1="18.2685" x2="68.3145" y2="18.3255" layer="200" rot="R270"/>
<rectangle x1="67.659" y1="17.043" x2="68.343" y2="17.1" layer="200" rot="R270"/>
<rectangle x1="67.4595" y1="15.3615" x2="68.5425" y2="15.4185" layer="200" rot="R270"/>
<rectangle x1="67.716" y1="13.623" x2="68.286" y2="13.68" layer="200" rot="R270"/>
<rectangle x1="66.8895" y1="11.2005" x2="69.1125" y2="11.2575" layer="200" rot="R270"/>
<rectangle x1="65.4645" y1="23.6265" x2="70.5375" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="67.488" y1="20.349" x2="68.514" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="67.7445" y1="18.8385" x2="68.2575" y2="18.8955" layer="201" rot="R270"/>
<rectangle x1="67.716" y1="17.67" x2="68.286" y2="17.727" layer="201" rot="R270"/>
<rectangle x1="67.602" y1="16.302" x2="68.4" y2="16.359" layer="201" rot="R270"/>
<rectangle x1="67.545" y1="14.364" x2="68.457" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="67.488" y1="12.825" x2="68.514" y2="12.882" layer="201" rot="R270"/>
<rectangle x1="67.9725" y1="10.0605" x2="68.0295" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="67.944" y1="20.976" x2="68.172" y2="21.033" layer="200" rot="R270"/>
<rectangle x1="67.6875" y1="19.4655" x2="68.4285" y2="19.5225" layer="200" rot="R270"/>
<rectangle x1="67.7445" y1="18.2685" x2="68.3715" y2="18.3255" layer="200" rot="R270"/>
<rectangle x1="67.716" y1="17.043" x2="68.4" y2="17.1" layer="200" rot="R270"/>
<rectangle x1="67.5165" y1="15.3615" x2="68.5995" y2="15.4185" layer="200" rot="R270"/>
<rectangle x1="66.1485" y1="11.9985" x2="69.9675" y2="12.0555" layer="200" rot="R270"/>
<rectangle x1="65.5215" y1="23.6265" x2="70.5945" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="67.545" y1="20.349" x2="68.571" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="67.8015" y1="18.8385" x2="68.3145" y2="18.8955" layer="201" rot="R270"/>
<rectangle x1="67.773" y1="17.67" x2="68.343" y2="17.727" layer="201" rot="R270"/>
<rectangle x1="67.659" y1="16.302" x2="68.457" y2="16.359" layer="201" rot="R270"/>
<rectangle x1="67.602" y1="14.364" x2="68.514" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="68.0295" y1="10.0605" x2="68.0865" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="68.001" y1="20.976" x2="68.229" y2="21.033" layer="200" rot="R270"/>
<rectangle x1="67.7445" y1="19.4655" x2="68.4855" y2="19.5225" layer="200" rot="R270"/>
<rectangle x1="67.8015" y1="18.2685" x2="68.4285" y2="18.3255" layer="200" rot="R270"/>
<rectangle x1="67.773" y1="17.043" x2="68.457" y2="17.1" layer="200" rot="R270"/>
<rectangle x1="67.5735" y1="15.3615" x2="68.6565" y2="15.4185" layer="200" rot="R270"/>
<rectangle x1="66.2055" y1="11.9985" x2="70.0245" y2="12.0555" layer="200" rot="R270"/>
<rectangle x1="65.5785" y1="23.6265" x2="70.6515" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="67.602" y1="20.349" x2="68.628" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="67.8585" y1="18.8385" x2="68.3715" y2="18.8955" layer="201" rot="R270"/>
<rectangle x1="67.83" y1="17.67" x2="68.4" y2="17.727" layer="201" rot="R270"/>
<rectangle x1="67.716" y1="16.302" x2="68.514" y2="16.359" layer="201" rot="R270"/>
<rectangle x1="67.659" y1="14.364" x2="68.571" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="68.0865" y1="10.0605" x2="68.1435" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="68.058" y1="20.976" x2="68.286" y2="21.033" layer="200" rot="R270"/>
<rectangle x1="67.8015" y1="19.4655" x2="68.5425" y2="19.5225" layer="200" rot="R270"/>
<rectangle x1="68.115" y1="18.525" x2="68.229" y2="18.582" layer="200" rot="R270"/>
<rectangle x1="68.115" y1="18.297" x2="68.229" y2="18.354" layer="200" rot="R270"/>
<rectangle x1="68.0865" y1="18.0405" x2="68.2575" y2="18.0975" layer="200" rot="R270"/>
<rectangle x1="67.8015" y1="17.0145" x2="68.5425" y2="17.0715" layer="200" rot="R270"/>
<rectangle x1="67.6305" y1="15.3615" x2="68.7135" y2="15.4185" layer="200" rot="R270"/>
<rectangle x1="66.2625" y1="11.9985" x2="70.0815" y2="12.0555" layer="200" rot="R270"/>
<rectangle x1="65.6355" y1="23.6265" x2="70.7085" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="67.659" y1="20.349" x2="68.685" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="67.9155" y1="18.8385" x2="68.4285" y2="18.8955" layer="201" rot="R270"/>
<rectangle x1="68.115" y1="18.411" x2="68.229" y2="18.468" layer="201" rot="R270"/>
<rectangle x1="68.115" y1="18.183" x2="68.229" y2="18.24" layer="201" rot="R270"/>
<rectangle x1="67.887" y1="17.67" x2="68.457" y2="17.727" layer="201" rot="R270"/>
<rectangle x1="67.8015" y1="16.2735" x2="68.5425" y2="16.3305" layer="201" rot="R270"/>
<rectangle x1="67.716" y1="14.364" x2="68.628" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="68.1435" y1="10.0605" x2="68.2005" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="68.115" y1="20.976" x2="68.343" y2="21.033" layer="200" rot="R270"/>
<rectangle x1="67.8585" y1="19.4655" x2="68.5995" y2="19.5225" layer="200" rot="R270"/>
<rectangle x1="68.172" y1="18.525" x2="68.286" y2="18.582" layer="200" rot="R270"/>
<rectangle x1="68.172" y1="18.297" x2="68.286" y2="18.354" layer="200" rot="R270"/>
<rectangle x1="68.115" y1="18.069" x2="68.343" y2="18.126" layer="200" rot="R270"/>
<rectangle x1="67.8585" y1="17.0145" x2="68.5995" y2="17.0715" layer="200" rot="R270"/>
<rectangle x1="67.6875" y1="15.3615" x2="68.7705" y2="15.4185" layer="200" rot="R270"/>
<rectangle x1="66.3195" y1="11.9985" x2="70.1385" y2="12.0555" layer="200" rot="R270"/>
<rectangle x1="65.6925" y1="23.6265" x2="70.7655" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="67.716" y1="20.349" x2="68.742" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="67.9725" y1="18.8385" x2="68.4855" y2="18.8955" layer="201" rot="R270"/>
<rectangle x1="68.172" y1="18.411" x2="68.286" y2="18.468" layer="201" rot="R270"/>
<rectangle x1="68.2005" y1="18.2115" x2="68.2575" y2="18.2685" layer="201" rot="R270"/>
<rectangle x1="67.944" y1="17.67" x2="68.514" y2="17.727" layer="201" rot="R270"/>
<rectangle x1="67.8585" y1="16.2735" x2="68.5995" y2="16.3305" layer="201" rot="R270"/>
<rectangle x1="67.773" y1="14.364" x2="68.685" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="68.2005" y1="10.0605" x2="68.2575" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="68.172" y1="20.976" x2="68.4" y2="21.033" layer="200" rot="R270"/>
<rectangle x1="67.9155" y1="19.4655" x2="68.6565" y2="19.5225" layer="200" rot="R270"/>
<rectangle x1="67.9725" y1="18.2685" x2="68.5995" y2="18.3255" layer="200" rot="R270"/>
<rectangle x1="67.887" y1="16.986" x2="68.685" y2="17.043" layer="200" rot="R270"/>
<rectangle x1="67.716" y1="15.39" x2="68.856" y2="15.447" layer="200" rot="R270"/>
<rectangle x1="66.3765" y1="11.9985" x2="70.1955" y2="12.0555" layer="200" rot="R270"/>
<rectangle x1="65.7495" y1="23.6265" x2="70.8225" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="67.773" y1="20.349" x2="68.799" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="68.0295" y1="18.8385" x2="68.5425" y2="18.8955" layer="201" rot="R270"/>
<rectangle x1="68.001" y1="17.67" x2="68.571" y2="17.727" layer="201" rot="R270"/>
<rectangle x1="67.9725" y1="16.2735" x2="68.5995" y2="16.3305" layer="201" rot="R270"/>
<rectangle x1="67.83" y1="14.364" x2="68.742" y2="14.421" layer="201" rot="R270"/>
<rectangle x1="68.2575" y1="10.0605" x2="68.3145" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="68.229" y1="20.976" x2="68.457" y2="21.033" layer="200" rot="R270"/>
<rectangle x1="67.9725" y1="19.4655" x2="68.7135" y2="19.5225" layer="200" rot="R270"/>
<rectangle x1="68.0295" y1="18.2685" x2="68.6565" y2="18.3255" layer="200" rot="R270"/>
<rectangle x1="67.032" y1="16.074" x2="69.654" y2="16.131" layer="200" rot="R270"/>
<rectangle x1="68.286" y1="14.478" x2="68.4" y2="14.535" layer="200" rot="R270"/>
<rectangle x1="66.2055" y1="12.2265" x2="70.4805" y2="12.2835" layer="200" rot="R270"/>
<rectangle x1="65.8065" y1="23.6265" x2="70.8795" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="67.83" y1="20.349" x2="68.856" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="68.0865" y1="18.8385" x2="68.5995" y2="18.8955" layer="201" rot="R270"/>
<rectangle x1="68.058" y1="17.67" x2="68.628" y2="17.727" layer="201" rot="R270"/>
<rectangle x1="68.229" y1="14.649" x2="68.457" y2="14.706" layer="201" rot="R270"/>
<rectangle x1="68.3145" y1="14.3925" x2="68.3715" y2="14.4495" layer="201" rot="R270"/>
<rectangle x1="68.3145" y1="10.0605" x2="68.3715" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="68.286" y1="20.976" x2="68.514" y2="21.033" layer="200" rot="R270"/>
<rectangle x1="68.001" y1="19.437" x2="68.799" y2="19.494" layer="200" rot="R270"/>
<rectangle x1="68.0865" y1="18.2685" x2="68.7135" y2="18.3255" layer="200" rot="R270"/>
<rectangle x1="65.55" y1="14.535" x2="71.25" y2="14.592" layer="200" rot="R270"/>
<rectangle x1="68.229" y1="10.26" x2="68.571" y2="10.317" layer="200" rot="R270"/>
<rectangle x1="65.8635" y1="23.6265" x2="70.9365" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="67.887" y1="20.349" x2="68.913" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="68.172" y1="18.81" x2="68.628" y2="18.867" layer="201" rot="R270"/>
<rectangle x1="68.115" y1="17.67" x2="68.685" y2="17.727" layer="201" rot="R270"/>
<rectangle x1="67.773" y1="11.058" x2="69.027" y2="11.115" layer="201" rot="R270"/>
<rectangle x1="68.3715" y1="10.0605" x2="68.4285" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="68.343" y1="20.976" x2="68.571" y2="21.033" layer="200" rot="R270"/>
<rectangle x1="68.058" y1="19.437" x2="68.856" y2="19.494" layer="200" rot="R270"/>
<rectangle x1="68.2005" y1="18.2115" x2="68.7135" y2="18.2685" layer="200" rot="R270"/>
<rectangle x1="65.607" y1="14.535" x2="71.307" y2="14.592" layer="200" rot="R270"/>
<rectangle x1="68.286" y1="10.26" x2="68.628" y2="10.317" layer="200" rot="R270"/>
<rectangle x1="65.9205" y1="23.6265" x2="70.9935" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="67.944" y1="20.349" x2="68.97" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="68.172" y1="18.753" x2="68.742" y2="18.81" layer="201" rot="R270"/>
<rectangle x1="68.172" y1="17.67" x2="68.742" y2="17.727" layer="201" rot="R270"/>
<rectangle x1="67.83" y1="11.058" x2="69.084" y2="11.115" layer="201" rot="R270"/>
<rectangle x1="68.4285" y1="10.0605" x2="68.4855" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="68.4" y1="20.976" x2="68.628" y2="21.033" layer="200" rot="R270"/>
<rectangle x1="68.0865" y1="19.4085" x2="68.9415" y2="19.4655" layer="200" rot="R270"/>
<rectangle x1="68.343" y1="18.24" x2="68.685" y2="18.297" layer="200" rot="R270"/>
<rectangle x1="65.6355" y1="14.5635" x2="71.3925" y2="14.6205" layer="200" rot="R270"/>
<rectangle x1="68.343" y1="10.26" x2="68.685" y2="10.317" layer="200" rot="R270"/>
<rectangle x1="65.9775" y1="23.6265" x2="71.0505" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="68.001" y1="20.349" x2="69.027" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="68.229" y1="18.696" x2="68.799" y2="18.753" layer="201" rot="R270"/>
<rectangle x1="68.2005" y1="17.7555" x2="68.8275" y2="17.8125" layer="201" rot="R270"/>
<rectangle x1="67.887" y1="11.058" x2="69.141" y2="11.115" layer="201" rot="R270"/>
<rectangle x1="68.4855" y1="10.0605" x2="68.5425" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="68.457" y1="20.976" x2="68.685" y2="21.033" layer="200" rot="R270"/>
<rectangle x1="68.115" y1="19.38" x2="69.027" y2="19.437" layer="200" rot="R270"/>
<rectangle x1="68.343" y1="18.24" x2="68.799" y2="18.297" layer="200" rot="R270"/>
<rectangle x1="65.664" y1="14.592" x2="71.478" y2="14.649" layer="200" rot="R270"/>
<rectangle x1="68.5425" y1="10.6875" x2="68.5995" y2="10.7445" layer="200" rot="R270"/>
<rectangle x1="68.4" y1="10.26" x2="68.742" y2="10.317" layer="200" rot="R270"/>
<rectangle x1="66.0345" y1="23.6265" x2="71.1075" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="68.058" y1="20.349" x2="69.084" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="68.343" y1="18.696" x2="68.799" y2="18.753" layer="201" rot="R270"/>
<rectangle x1="68.3145" y1="17.7555" x2="68.8275" y2="17.8125" layer="201" rot="R270"/>
<rectangle x1="68.0865" y1="11.2005" x2="69.0555" y2="11.2575" layer="201" rot="R270"/>
<rectangle x1="68.457" y1="10.545" x2="68.685" y2="10.602" layer="201" rot="R270"/>
<rectangle x1="68.5425" y1="10.0605" x2="68.5995" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="68.514" y1="20.976" x2="68.742" y2="21.033" layer="200" rot="R270"/>
<rectangle x1="68.1435" y1="19.3515" x2="69.1125" y2="19.4085" layer="200" rot="R270"/>
<rectangle x1="68.286" y1="18.24" x2="68.97" y2="18.297" layer="200" rot="R270"/>
<rectangle x1="65.664" y1="14.649" x2="71.592" y2="14.706" layer="200" rot="R270"/>
<rectangle x1="68.457" y1="11.343" x2="68.799" y2="11.4" layer="200" rot="R270"/>
<rectangle x1="68.4" y1="10.773" x2="68.856" y2="10.83" layer="200" rot="R270"/>
<rectangle x1="68.457" y1="10.26" x2="68.799" y2="10.317" layer="200" rot="R270"/>
<rectangle x1="66.0915" y1="23.6265" x2="71.1645" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="68.115" y1="20.349" x2="69.141" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="68.4855" y1="18.7245" x2="68.7705" y2="18.7815" layer="201" rot="R270"/>
<rectangle x1="68.4855" y1="17.7555" x2="68.7705" y2="17.8125" layer="201" rot="R270"/>
<rectangle x1="68.5425" y1="11.5995" x2="68.7135" y2="11.6565" layer="201" rot="R270"/>
<rectangle x1="68.5425" y1="11.0865" x2="68.7135" y2="11.1435" layer="201" rot="R270"/>
<rectangle x1="68.571" y1="10.488" x2="68.685" y2="10.545" layer="201" rot="R270"/>
<rectangle x1="68.5995" y1="10.0605" x2="68.6565" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="65.949" y1="18.354" x2="71.421" y2="18.411" layer="200" rot="R270"/>
<rectangle x1="68.229" y1="13.908" x2="69.141" y2="13.965" layer="200" rot="R270"/>
<rectangle x1="67.8585" y1="12.5115" x2="69.5115" y2="12.5685" layer="200" rot="R270"/>
<rectangle x1="68.514" y1="11.343" x2="68.856" y2="11.4" layer="200" rot="R270"/>
<rectangle x1="68.457" y1="10.773" x2="68.913" y2="10.83" layer="200" rot="R270"/>
<rectangle x1="68.514" y1="10.26" x2="68.856" y2="10.317" layer="200" rot="R270"/>
<rectangle x1="66.1485" y1="23.6265" x2="71.2215" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="68.058" y1="14.991" x2="69.312" y2="15.048" layer="201" rot="R270"/>
<rectangle x1="68.628" y1="13.395" x2="68.742" y2="13.452" layer="201" rot="R270"/>
<rectangle x1="68.5995" y1="11.5995" x2="68.7705" y2="11.6565" layer="201" rot="R270"/>
<rectangle x1="68.5995" y1="11.0865" x2="68.7705" y2="11.1435" layer="201" rot="R270"/>
<rectangle x1="68.628" y1="10.488" x2="68.742" y2="10.545" layer="201" rot="R270"/>
<rectangle x1="68.6565" y1="10.0605" x2="68.7135" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="66.9465" y1="19.3515" x2="70.5375" y2="19.4085" layer="200" rot="R270"/>
<rectangle x1="68.001" y1="12.426" x2="69.483" y2="12.483" layer="200" rot="R270"/>
<rectangle x1="68.571" y1="11.343" x2="68.913" y2="11.4" layer="200" rot="R270"/>
<rectangle x1="68.514" y1="10.773" x2="68.97" y2="10.83" layer="200" rot="R270"/>
<rectangle x1="68.571" y1="10.26" x2="68.913" y2="10.317" layer="200" rot="R270"/>
<rectangle x1="66.234" y1="23.655" x2="71.25" y2="23.712" layer="201" rot="R270"/>
<rectangle x1="66.5475" y1="15.3615" x2="70.9365" y2="15.4185" layer="201" rot="R270"/>
<rectangle x1="68.6565" y1="11.5995" x2="68.8275" y2="11.6565" layer="201" rot="R270"/>
<rectangle x1="68.6565" y1="11.0865" x2="68.8275" y2="11.1435" layer="201" rot="R270"/>
<rectangle x1="68.685" y1="10.488" x2="68.799" y2="10.545" layer="201" rot="R270"/>
<rectangle x1="68.7135" y1="10.0605" x2="68.7705" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="66.6615" y1="19.7505" x2="70.9365" y2="19.8075" layer="200" rot="R270"/>
<rectangle x1="68.0865" y1="12.3975" x2="69.5115" y2="12.4545" layer="200" rot="R270"/>
<rectangle x1="68.628" y1="11.343" x2="68.97" y2="11.4" layer="200" rot="R270"/>
<rectangle x1="68.571" y1="10.773" x2="69.027" y2="10.83" layer="200" rot="R270"/>
<rectangle x1="68.628" y1="10.26" x2="68.97" y2="10.317" layer="200" rot="R270"/>
<rectangle x1="66.6615" y1="24.0255" x2="70.9365" y2="24.0825" layer="201" rot="R270"/>
<rectangle x1="66.5475" y1="15.3615" x2="71.0505" y2="15.4185" layer="201" rot="R270"/>
<rectangle x1="68.7135" y1="11.5995" x2="68.8845" y2="11.6565" layer="201" rot="R270"/>
<rectangle x1="68.7135" y1="11.0865" x2="68.8845" y2="11.1435" layer="201" rot="R270"/>
<rectangle x1="68.742" y1="10.488" x2="68.856" y2="10.545" layer="201" rot="R270"/>
<rectangle x1="68.7705" y1="10.0605" x2="68.8275" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="68.3145" y1="21.4035" x2="69.3975" y2="21.4605" layer="200" rot="R270"/>
<rectangle x1="67.7445" y1="18.7245" x2="69.9675" y2="18.7815" layer="200" rot="R270"/>
<rectangle x1="68.1435" y1="12.3975" x2="69.5685" y2="12.4545" layer="200" rot="R270"/>
<rectangle x1="68.685" y1="11.343" x2="69.027" y2="11.4" layer="200" rot="R270"/>
<rectangle x1="68.628" y1="10.773" x2="69.084" y2="10.83" layer="200" rot="R270"/>
<rectangle x1="68.685" y1="10.26" x2="69.027" y2="10.317" layer="200" rot="R270"/>
<rectangle x1="66.747" y1="24.054" x2="70.965" y2="24.111" layer="201" rot="R270"/>
<rectangle x1="68.343" y1="20.349" x2="69.369" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="66.6045" y1="15.3615" x2="71.1075" y2="15.4185" layer="201" rot="R270"/>
<rectangle x1="68.7705" y1="11.5995" x2="68.9415" y2="11.6565" layer="201" rot="R270"/>
<rectangle x1="68.7705" y1="11.0865" x2="68.9415" y2="11.1435" layer="201" rot="R270"/>
<rectangle x1="68.799" y1="10.488" x2="68.913" y2="10.545" layer="201" rot="R270"/>
<rectangle x1="68.8275" y1="10.0605" x2="68.8845" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="68.343" y1="21.432" x2="69.483" y2="21.489" layer="200" rot="R270"/>
<rectangle x1="67.773" y1="18.696" x2="70.053" y2="18.753" layer="200" rot="R270"/>
<rectangle x1="68.172" y1="12.426" x2="69.654" y2="12.483" layer="200" rot="R270"/>
<rectangle x1="68.742" y1="11.343" x2="69.084" y2="11.4" layer="200" rot="R270"/>
<rectangle x1="68.685" y1="10.773" x2="69.141" y2="10.83" layer="200" rot="R270"/>
<rectangle x1="68.742" y1="10.26" x2="69.084" y2="10.317" layer="200" rot="R270"/>
<rectangle x1="66.8325" y1="24.0825" x2="70.9935" y2="24.1395" layer="201" rot="R270"/>
<rectangle x1="68.4" y1="20.349" x2="69.426" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="66.7185" y1="15.3615" x2="71.1075" y2="15.4185" layer="201" rot="R270"/>
<rectangle x1="68.8275" y1="11.5995" x2="68.9985" y2="11.6565" layer="201" rot="R270"/>
<rectangle x1="68.8275" y1="11.0865" x2="68.9985" y2="11.1435" layer="201" rot="R270"/>
<rectangle x1="68.856" y1="10.488" x2="68.97" y2="10.545" layer="201" rot="R270"/>
<rectangle x1="68.8845" y1="10.0605" x2="68.9415" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="68.3715" y1="21.4605" x2="69.5685" y2="21.5175" layer="200" rot="R270"/>
<rectangle x1="64.8945" y1="15.7605" x2="73.0455" y2="15.8175" layer="200" rot="R270"/>
<rectangle x1="68.799" y1="11.343" x2="69.141" y2="11.4" layer="200" rot="R270"/>
<rectangle x1="68.742" y1="10.773" x2="69.198" y2="10.83" layer="200" rot="R270"/>
<rectangle x1="68.799" y1="10.26" x2="69.141" y2="10.317" layer="200" rot="R270"/>
<rectangle x1="66.918" y1="24.111" x2="71.022" y2="24.168" layer="201" rot="R270"/>
<rectangle x1="68.457" y1="20.349" x2="69.483" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="68.8845" y1="11.5995" x2="69.0555" y2="11.6565" layer="201" rot="R270"/>
<rectangle x1="68.8845" y1="11.0865" x2="69.0555" y2="11.1435" layer="201" rot="R270"/>
<rectangle x1="68.913" y1="10.488" x2="69.027" y2="10.545" layer="201" rot="R270"/>
<rectangle x1="68.9415" y1="10.0605" x2="68.9985" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="68.4" y1="21.489" x2="69.654" y2="21.546" layer="200" rot="R270"/>
<rectangle x1="68.628" y1="19.437" x2="69.426" y2="19.494" layer="200" rot="R270"/>
<rectangle x1="65.5215" y1="15.1905" x2="72.5325" y2="15.2475" layer="200" rot="R270"/>
<rectangle x1="68.913" y1="11.343" x2="69.141" y2="11.4" layer="200" rot="R270"/>
<rectangle x1="68.799" y1="10.773" x2="69.255" y2="10.83" layer="200" rot="R270"/>
<rectangle x1="68.856" y1="10.26" x2="69.198" y2="10.317" layer="200" rot="R270"/>
<rectangle x1="67.0035" y1="24.1395" x2="71.0505" y2="24.1965" layer="201" rot="R270"/>
<rectangle x1="68.514" y1="20.349" x2="69.54" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="68.856" y1="18.867" x2="69.198" y2="18.924" layer="201" rot="R270"/>
<rectangle x1="68.913" y1="11.571" x2="69.141" y2="11.628" layer="201" rot="R270"/>
<rectangle x1="68.913" y1="11.115" x2="69.141" y2="11.172" layer="201" rot="R270"/>
<rectangle x1="68.97" y1="10.488" x2="69.084" y2="10.545" layer="201" rot="R270"/>
<rectangle x1="68.9985" y1="10.0605" x2="69.0555" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="68.457" y1="21.489" x2="69.711" y2="21.546" layer="200" rot="R270"/>
<rectangle x1="68.7705" y1="19.5225" x2="69.3975" y2="19.5795" layer="200" rot="R270"/>
<rectangle x1="68.6565" y1="18.1545" x2="69.5115" y2="18.2115" layer="200" rot="R270"/>
<rectangle x1="68.058" y1="15.39" x2="70.11" y2="15.447" layer="200" rot="R270"/>
<rectangle x1="68.4285" y1="12.3405" x2="69.7395" y2="12.3975" layer="200" rot="R270"/>
<rectangle x1="69.027" y1="11.343" x2="69.141" y2="11.4" layer="200" rot="R270"/>
<rectangle x1="68.913" y1="10.773" x2="69.255" y2="10.83" layer="200" rot="R270"/>
<rectangle x1="68.913" y1="10.26" x2="69.255" y2="10.317" layer="200" rot="R270"/>
<rectangle x1="67.0605" y1="24.1395" x2="71.1075" y2="24.1965" layer="201" rot="R270"/>
<rectangle x1="68.571" y1="20.349" x2="69.597" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="68.7705" y1="18.8955" x2="69.3975" y2="18.9525" layer="201" rot="R270"/>
<rectangle x1="68.4285" y1="17.0715" x2="69.7395" y2="17.1285" layer="201" rot="R270"/>
<rectangle x1="68.4" y1="13.68" x2="69.768" y2="13.737" layer="201" rot="R270"/>
<rectangle x1="68.9415" y1="11.5425" x2="69.2265" y2="11.5995" layer="201" rot="R270"/>
<rectangle x1="68.913" y1="11.115" x2="69.255" y2="11.172" layer="201" rot="R270"/>
<rectangle x1="68.9985" y1="10.5165" x2="69.1695" y2="10.5735" layer="201" rot="R270"/>
<rectangle x1="69.0555" y1="10.0605" x2="69.1125" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="68.514" y1="21.489" x2="69.768" y2="21.546" layer="200" rot="R270"/>
<rectangle x1="68.856" y1="19.551" x2="69.426" y2="19.608" layer="200" rot="R270"/>
<rectangle x1="68.799" y1="18.183" x2="69.483" y2="18.24" layer="200" rot="R270"/>
<rectangle x1="68.1435" y1="15.3615" x2="70.1385" y2="15.4185" layer="200" rot="R270"/>
<rectangle x1="68.4855" y1="12.2835" x2="69.7965" y2="12.3405" layer="200" rot="R270"/>
<rectangle x1="69.0555" y1="10.7445" x2="69.2265" y2="10.8015" layer="200" rot="R270"/>
<rectangle x1="68.97" y1="10.26" x2="69.312" y2="10.317" layer="200" rot="R270"/>
<rectangle x1="67.1175" y1="24.1395" x2="71.1645" y2="24.1965" layer="201" rot="R270"/>
<rectangle x1="68.628" y1="20.349" x2="69.654" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="68.7705" y1="18.8955" x2="69.5115" y2="18.9525" layer="201" rot="R270"/>
<rectangle x1="68.4" y1="17.1" x2="69.882" y2="17.157" layer="201" rot="R270"/>
<rectangle x1="68.4285" y1="13.6515" x2="69.8535" y2="13.7085" layer="201" rot="R270"/>
<rectangle x1="68.742" y1="11.229" x2="69.54" y2="11.286" layer="201" rot="R270"/>
<rectangle x1="69.027" y1="10.545" x2="69.255" y2="10.602" layer="201" rot="R270"/>
<rectangle x1="69.1125" y1="10.0605" x2="69.1695" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="68.5425" y1="21.5175" x2="69.8535" y2="21.5745" layer="200" rot="R270"/>
<rectangle x1="68.9415" y1="19.5795" x2="69.4545" y2="19.6365" layer="200" rot="R270"/>
<rectangle x1="68.913" y1="18.183" x2="69.483" y2="18.24" layer="200" rot="R270"/>
<rectangle x1="68.058" y1="15.39" x2="70.338" y2="15.447" layer="200" rot="R270"/>
<rectangle x1="68.5995" y1="12.2265" x2="69.7965" y2="12.2835" layer="200" rot="R270"/>
<rectangle x1="69.141" y1="11.115" x2="69.255" y2="11.172" layer="200" rot="R270"/>
<rectangle x1="68.9985" y1="10.2885" x2="69.3975" y2="10.3455" layer="200" rot="R270"/>
<rectangle x1="67.203" y1="24.168" x2="71.193" y2="24.225" layer="201" rot="R270"/>
<rectangle x1="68.685" y1="20.349" x2="69.711" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="68.7705" y1="18.8955" x2="69.6255" y2="18.9525" layer="201" rot="R270"/>
<rectangle x1="68.514" y1="17.214" x2="69.882" y2="17.271" layer="201" rot="R270"/>
<rectangle x1="68.4855" y1="13.5375" x2="69.9105" y2="13.5945" layer="201" rot="R270"/>
<rectangle x1="68.97" y1="11.4" x2="69.426" y2="11.457" layer="201" rot="R270"/>
<rectangle x1="68.913" y1="10.773" x2="69.483" y2="10.83" layer="201" rot="R270"/>
<rectangle x1="69.1695" y1="10.0605" x2="69.2265" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="68.628" y1="21.489" x2="69.882" y2="21.546" layer="200" rot="R270"/>
<rectangle x1="68.9985" y1="19.5795" x2="69.5115" y2="19.6365" layer="200" rot="R270"/>
<rectangle x1="68.9985" y1="18.2115" x2="69.5115" y2="18.2685" layer="200" rot="R270"/>
<rectangle x1="68.001" y1="15.39" x2="70.509" y2="15.447" layer="200" rot="R270"/>
<rectangle x1="68.5995" y1="12.1695" x2="69.9105" y2="12.2265" layer="200" rot="R270"/>
<rectangle x1="69.141" y1="11.115" x2="69.369" y2="11.172" layer="200" rot="R270"/>
<rectangle x1="69.027" y1="10.317" x2="69.483" y2="10.374" layer="200" rot="R270"/>
<rectangle x1="67.2315" y1="24.1395" x2="71.2785" y2="24.1965" layer="201" rot="R270"/>
<rectangle x1="68.742" y1="20.349" x2="69.768" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="68.8275" y1="18.8955" x2="69.6825" y2="18.9525" layer="201" rot="R270"/>
<rectangle x1="68.5995" y1="17.2995" x2="69.9105" y2="17.3565" layer="201" rot="R270"/>
<rectangle x1="68.5995" y1="13.4805" x2="69.9105" y2="13.5375" layer="201" rot="R270"/>
<rectangle x1="69.1125" y1="11.3715" x2="69.3975" y2="11.4285" layer="201" rot="R270"/>
<rectangle x1="69.027" y1="10.773" x2="69.483" y2="10.83" layer="201" rot="R270"/>
<rectangle x1="69.2265" y1="10.0605" x2="69.2835" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="68.685" y1="21.489" x2="69.939" y2="21.546" layer="200" rot="R270"/>
<rectangle x1="69.084" y1="19.608" x2="69.54" y2="19.665" layer="200" rot="R270"/>
<rectangle x1="69.0555" y1="18.2115" x2="69.5685" y2="18.2685" layer="200" rot="R270"/>
<rectangle x1="67.9155" y1="15.4185" x2="70.7085" y2="15.4755" layer="200" rot="R270"/>
<rectangle x1="68.4" y1="11.856" x2="70.224" y2="11.913" layer="200" rot="R270"/>
<rectangle x1="69.084" y1="10.374" x2="69.54" y2="10.431" layer="200" rot="R270"/>
<rectangle x1="67.2885" y1="24.1395" x2="71.3355" y2="24.1965" layer="201" rot="R270"/>
<rectangle x1="68.799" y1="20.349" x2="69.825" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="68.856" y1="18.924" x2="69.768" y2="18.981" layer="201" rot="R270"/>
<rectangle x1="68.742" y1="17.385" x2="69.882" y2="17.442" layer="201" rot="R270"/>
<rectangle x1="68.685" y1="13.395" x2="69.939" y2="13.452" layer="201" rot="R270"/>
<rectangle x1="69.141" y1="10.773" x2="69.483" y2="10.83" layer="201" rot="R270"/>
<rectangle x1="69.255" y1="10.089" x2="69.369" y2="10.146" layer="201" rot="R270"/>
<rectangle x1="68.7135" y1="21.5175" x2="70.0245" y2="21.5745" layer="200" rot="R270"/>
<rectangle x1="69.141" y1="19.608" x2="69.597" y2="19.665" layer="200" rot="R270"/>
<rectangle x1="69.141" y1="18.24" x2="69.597" y2="18.297" layer="200" rot="R270"/>
<rectangle x1="67.887" y1="15.447" x2="70.851" y2="15.504" layer="200" rot="R270"/>
<rectangle x1="68.058" y1="11.457" x2="70.68" y2="11.514" layer="200" rot="R270"/>
<rectangle x1="67.374" y1="24.168" x2="71.364" y2="24.225" layer="201" rot="R270"/>
<rectangle x1="68.856" y1="20.349" x2="69.882" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="68.913" y1="18.924" x2="69.825" y2="18.981" layer="201" rot="R270"/>
<rectangle x1="68.8275" y1="17.4705" x2="69.9105" y2="17.5275" layer="201" rot="R270"/>
<rectangle x1="68.7705" y1="13.3665" x2="69.9675" y2="13.4235" layer="201" rot="R270"/>
<rectangle x1="69.312" y1="10.089" x2="69.426" y2="10.146" layer="201" rot="R270"/>
<rectangle x1="68.7705" y1="21.5175" x2="70.0815" y2="21.5745" layer="200" rot="R270"/>
<rectangle x1="69.198" y1="19.608" x2="69.654" y2="19.665" layer="200" rot="R270"/>
<rectangle x1="69.198" y1="18.24" x2="69.654" y2="18.297" layer="200" rot="R270"/>
<rectangle x1="67.887" y1="15.447" x2="70.965" y2="15.504" layer="200" rot="R270"/>
<rectangle x1="68.1435" y1="11.4285" x2="70.7085" y2="11.4855" layer="200" rot="R270"/>
<rectangle x1="67.431" y1="24.168" x2="71.421" y2="24.225" layer="201" rot="R270"/>
<rectangle x1="68.913" y1="20.349" x2="69.939" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="68.97" y1="18.924" x2="69.882" y2="18.981" layer="201" rot="R270"/>
<rectangle x1="68.913" y1="17.499" x2="69.939" y2="17.556" layer="201" rot="R270"/>
<rectangle x1="68.8275" y1="13.3095" x2="70.0245" y2="13.3665" layer="201" rot="R270"/>
<rectangle x1="69.369" y1="10.089" x2="69.483" y2="10.146" layer="201" rot="R270"/>
<rectangle x1="68.856" y1="21.489" x2="70.11" y2="21.546" layer="200" rot="R270"/>
<rectangle x1="69.255" y1="19.608" x2="69.711" y2="19.665" layer="200" rot="R270"/>
<rectangle x1="69.255" y1="18.24" x2="69.711" y2="18.297" layer="200" rot="R270"/>
<rectangle x1="67.8585" y1="15.4185" x2="71.1075" y2="15.4755" layer="200" rot="R270"/>
<rectangle x1="68.2005" y1="11.4285" x2="70.7655" y2="11.4855" layer="200" rot="R270"/>
<rectangle x1="67.4595" y1="24.1395" x2="71.5065" y2="24.1965" layer="201" rot="R270"/>
<rectangle x1="68.97" y1="20.349" x2="69.996" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="69.027" y1="18.924" x2="69.939" y2="18.981" layer="201" rot="R270"/>
<rectangle x1="68.9985" y1="17.5275" x2="69.9675" y2="17.5845" layer="201" rot="R270"/>
<rectangle x1="68.9415" y1="13.2525" x2="70.0245" y2="13.3095" layer="201" rot="R270"/>
<rectangle x1="69.426" y1="10.089" x2="69.54" y2="10.146" layer="201" rot="R270"/>
<rectangle x1="68.8845" y1="21.5175" x2="70.1955" y2="21.5745" layer="200" rot="R270"/>
<rectangle x1="69.2835" y1="19.5795" x2="69.7965" y2="19.6365" layer="200" rot="R270"/>
<rectangle x1="69.312" y1="18.24" x2="69.768" y2="18.297" layer="200" rot="R270"/>
<rectangle x1="67.8585" y1="15.4185" x2="71.2215" y2="15.4755" layer="200" rot="R270"/>
<rectangle x1="68.229" y1="11.4" x2="70.851" y2="11.457" layer="200" rot="R270"/>
<rectangle x1="67.545" y1="24.168" x2="71.535" y2="24.225" layer="201" rot="R270"/>
<rectangle x1="69.027" y1="20.349" x2="70.053" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="69.1125" y1="18.8955" x2="69.9675" y2="18.9525" layer="201" rot="R270"/>
<rectangle x1="69.084" y1="17.556" x2="69.996" y2="17.613" layer="201" rot="R270"/>
<rectangle x1="69.027" y1="13.224" x2="70.053" y2="13.281" layer="201" rot="R270"/>
<rectangle x1="69.5115" y1="10.0605" x2="69.5685" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="68.9415" y1="21.5175" x2="70.2525" y2="21.5745" layer="200" rot="R270"/>
<rectangle x1="69.3405" y1="19.5795" x2="69.8535" y2="19.6365" layer="200" rot="R270"/>
<rectangle x1="69.369" y1="18.924" x2="69.825" y2="18.981" layer="200" rot="R270"/>
<rectangle x1="69.369" y1="18.297" x2="69.825" y2="18.354" layer="200" rot="R270"/>
<rectangle x1="67.8585" y1="15.4185" x2="71.3355" y2="15.4755" layer="200" rot="R270"/>
<rectangle x1="68.799" y1="11.913" x2="70.395" y2="11.97" layer="200" rot="R270"/>
<rectangle x1="69.141" y1="10.545" x2="70.053" y2="10.602" layer="200" rot="R270"/>
<rectangle x1="67.602" y1="24.168" x2="71.592" y2="24.225" layer="201" rot="R270"/>
<rectangle x1="69.084" y1="20.349" x2="70.11" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="69.5115" y1="19.2375" x2="69.6825" y2="19.2945" layer="201" rot="R270"/>
<rectangle x1="69.5115" y1="18.6105" x2="69.6825" y2="18.6675" layer="201" rot="R270"/>
<rectangle x1="69.141" y1="17.613" x2="70.053" y2="17.67" layer="201" rot="R270"/>
<rectangle x1="69.1125" y1="13.1955" x2="70.0815" y2="13.2525" layer="201" rot="R270"/>
<rectangle x1="69.54" y1="11.058" x2="69.654" y2="11.115" layer="201" rot="R270"/>
<rectangle x1="69.5685" y1="10.0605" x2="69.6255" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="68.9985" y1="21.5175" x2="70.3095" y2="21.5745" layer="200" rot="R270"/>
<rectangle x1="69.3975" y1="19.5795" x2="69.9105" y2="19.6365" layer="200" rot="R270"/>
<rectangle x1="69.369" y1="18.924" x2="69.939" y2="18.981" layer="200" rot="R270"/>
<rectangle x1="69.426" y1="18.297" x2="69.882" y2="18.354" layer="200" rot="R270"/>
<rectangle x1="67.8585" y1="15.4185" x2="71.4495" y2="15.4755" layer="200" rot="R270"/>
<rectangle x1="68.856" y1="11.913" x2="70.452" y2="11.97" layer="200" rot="R270"/>
<rectangle x1="69.198" y1="10.545" x2="70.11" y2="10.602" layer="200" rot="R270"/>
<rectangle x1="67.659" y1="24.168" x2="71.649" y2="24.225" layer="201" rot="R270"/>
<rectangle x1="69.141" y1="20.349" x2="70.167" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="69.597" y1="19.266" x2="69.711" y2="19.323" layer="201" rot="R270"/>
<rectangle x1="69.597" y1="18.582" x2="69.711" y2="18.639" layer="201" rot="R270"/>
<rectangle x1="69.2265" y1="17.6415" x2="70.0815" y2="17.6985" layer="201" rot="R270"/>
<rectangle x1="69.198" y1="13.167" x2="70.11" y2="13.224" layer="201" rot="R270"/>
<rectangle x1="69.597" y1="11.058" x2="69.711" y2="11.115" layer="201" rot="R270"/>
<rectangle x1="69.6255" y1="10.0605" x2="69.6825" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="69.0555" y1="21.5175" x2="70.3665" y2="21.5745" layer="200" rot="R270"/>
<rectangle x1="69.2835" y1="19.4085" x2="70.1385" y2="19.4655" layer="200" rot="R270"/>
<rectangle x1="69.597" y1="18.81" x2="69.825" y2="18.867" layer="200" rot="R270"/>
<rectangle x1="69.4545" y1="18.3255" x2="69.9675" y2="18.3825" layer="200" rot="R270"/>
<rectangle x1="67.8585" y1="15.4185" x2="71.5635" y2="15.4755" layer="200" rot="R270"/>
<rectangle x1="68.913" y1="11.913" x2="70.509" y2="11.97" layer="200" rot="R270"/>
<rectangle x1="69.255" y1="10.545" x2="70.167" y2="10.602" layer="200" rot="R270"/>
<rectangle x1="67.716" y1="24.168" x2="71.706" y2="24.225" layer="201" rot="R270"/>
<rectangle x1="69.198" y1="20.349" x2="70.224" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="69.6825" y1="18.9525" x2="69.7395" y2="19.0095" layer="201" rot="R270"/>
<rectangle x1="69.654" y1="18.639" x2="69.768" y2="18.696" layer="201" rot="R270"/>
<rectangle x1="69.312" y1="17.67" x2="70.11" y2="17.727" layer="201" rot="R270"/>
<rectangle x1="69.2835" y1="13.1385" x2="70.1385" y2="13.1955" layer="201" rot="R270"/>
<rectangle x1="69.654" y1="11.058" x2="69.768" y2="11.115" layer="201" rot="R270"/>
<rectangle x1="69.6825" y1="10.0605" x2="69.7395" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="69.1125" y1="21.5175" x2="70.4235" y2="21.5745" layer="200" rot="R270"/>
<rectangle x1="69.3405" y1="19.4085" x2="70.1955" y2="19.4655" layer="200" rot="R270"/>
<rectangle x1="69.3405" y1="18.4965" x2="70.1955" y2="18.5535" layer="200" rot="R270"/>
<rectangle x1="67.887" y1="15.447" x2="71.649" y2="15.504" layer="200" rot="R270"/>
<rectangle x1="68.97" y1="11.913" x2="70.566" y2="11.97" layer="200" rot="R270"/>
<rectangle x1="69.312" y1="10.545" x2="70.224" y2="10.602" layer="200" rot="R270"/>
<rectangle x1="67.773" y1="24.168" x2="71.763" y2="24.225" layer="201" rot="R270"/>
<rectangle x1="69.255" y1="20.349" x2="70.281" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="69.7395" y1="18.9525" x2="69.7965" y2="19.0095" layer="201" rot="R270"/>
<rectangle x1="69.3975" y1="17.6985" x2="70.1385" y2="17.7555" layer="201" rot="R270"/>
<rectangle x1="69.3405" y1="13.1385" x2="70.1955" y2="13.1955" layer="201" rot="R270"/>
<rectangle x1="69.711" y1="11.058" x2="69.825" y2="11.115" layer="201" rot="R270"/>
<rectangle x1="69.7395" y1="10.0605" x2="69.7965" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="68.229" y1="20.577" x2="71.421" y2="20.634" layer="200" rot="R270"/>
<rectangle x1="69.426" y1="18.468" x2="70.224" y2="18.525" layer="200" rot="R270"/>
<rectangle x1="67.887" y1="15.447" x2="71.763" y2="15.504" layer="200" rot="R270"/>
<rectangle x1="69.027" y1="11.913" x2="70.623" y2="11.97" layer="200" rot="R270"/>
<rectangle x1="69.369" y1="10.545" x2="70.281" y2="10.602" layer="200" rot="R270"/>
<rectangle x1="67.83" y1="24.168" x2="71.82" y2="24.225" layer="201" rot="R270"/>
<rectangle x1="69.768" y1="18.924" x2="69.882" y2="18.981" layer="201" rot="R270"/>
<rectangle x1="69.483" y1="17.727" x2="70.167" y2="17.784" layer="201" rot="R270"/>
<rectangle x1="69.426" y1="13.11" x2="70.224" y2="13.167" layer="201" rot="R270"/>
<rectangle x1="69.768" y1="11.058" x2="69.882" y2="11.115" layer="201" rot="R270"/>
<rectangle x1="69.7965" y1="10.0605" x2="69.8535" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="68.2575" y1="20.5485" x2="71.5065" y2="20.6055" layer="200" rot="R270"/>
<rectangle x1="69.483" y1="18.468" x2="70.281" y2="18.525" layer="200" rot="R270"/>
<rectangle x1="67.887" y1="15.447" x2="71.877" y2="15.504" layer="200" rot="R270"/>
<rectangle x1="69.2265" y1="12.0555" x2="70.5375" y2="12.1125" layer="200" rot="R270"/>
<rectangle x1="69.8535" y1="11.2575" x2="69.9105" y2="11.3145" layer="200" rot="R270"/>
<rectangle x1="69.597" y1="10.374" x2="70.167" y2="10.431" layer="200" rot="R270"/>
<rectangle x1="67.887" y1="24.168" x2="71.877" y2="24.225" layer="201" rot="R270"/>
<rectangle x1="69.8535" y1="18.8955" x2="69.9105" y2="18.9525" layer="201" rot="R270"/>
<rectangle x1="69.5685" y1="17.7555" x2="70.1955" y2="17.8125" layer="201" rot="R270"/>
<rectangle x1="69.5115" y1="13.0815" x2="70.2525" y2="13.1385" layer="201" rot="R270"/>
<rectangle x1="69.825" y1="11.343" x2="69.939" y2="11.4" layer="201" rot="R270"/>
<rectangle x1="69.597" y1="10.944" x2="70.167" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="69.8535" y1="10.0605" x2="69.9105" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="67.887" y1="20.121" x2="71.991" y2="20.178" layer="200" rot="R270"/>
<rectangle x1="67.9155" y1="15.4755" x2="71.9625" y2="15.5325" layer="200" rot="R270"/>
<rectangle x1="69.312" y1="12.084" x2="70.566" y2="12.141" layer="200" rot="R270"/>
<rectangle x1="69.6825" y1="10.3455" x2="70.1955" y2="10.4025" layer="200" rot="R270"/>
<rectangle x1="67.944" y1="24.168" x2="71.934" y2="24.225" layer="201" rot="R270"/>
<rectangle x1="69.654" y1="17.784" x2="70.224" y2="17.841" layer="201" rot="R270"/>
<rectangle x1="69.5685" y1="13.0815" x2="70.3095" y2="13.1385" layer="201" rot="R270"/>
<rectangle x1="69.5115" y1="11.0295" x2="70.3665" y2="11.0865" layer="201" rot="R270"/>
<rectangle x1="69.9105" y1="10.0605" x2="69.9675" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="67.944" y1="20.121" x2="72.048" y2="20.178" layer="200" rot="R270"/>
<rectangle x1="67.944" y1="15.447" x2="72.048" y2="15.504" layer="200" rot="R270"/>
<rectangle x1="69.369" y1="12.084" x2="70.623" y2="12.141" layer="200" rot="R270"/>
<rectangle x1="69.711" y1="10.374" x2="70.281" y2="10.431" layer="200" rot="R270"/>
<rectangle x1="68.001" y1="24.168" x2="71.991" y2="24.225" layer="201" rot="R270"/>
<rectangle x1="69.711" y1="17.784" x2="70.281" y2="17.841" layer="201" rot="R270"/>
<rectangle x1="69.654" y1="13.053" x2="70.338" y2="13.11" layer="201" rot="R270"/>
<rectangle x1="69.597" y1="11.058" x2="70.395" y2="11.115" layer="201" rot="R270"/>
<rectangle x1="69.9675" y1="10.0605" x2="70.0245" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="69.3975" y1="21.5175" x2="70.7085" y2="21.5745" layer="200" rot="R270"/>
<rectangle x1="69.6255" y1="19.4085" x2="70.4805" y2="19.4655" layer="200" rot="R270"/>
<rectangle x1="69.9675" y1="18.7815" x2="70.1385" y2="18.8385" layer="200" rot="R270"/>
<rectangle x1="69.7965" y1="18.3255" x2="70.3095" y2="18.3825" layer="200" rot="R270"/>
<rectangle x1="67.9725" y1="15.4755" x2="72.1335" y2="15.5325" layer="200" rot="R270"/>
<rectangle x1="69.255" y1="11.913" x2="70.851" y2="11.97" layer="200" rot="R270"/>
<rectangle x1="69.6255" y1="10.5165" x2="70.4805" y2="10.5735" layer="200" rot="R270"/>
<rectangle x1="68.058" y1="24.168" x2="72.048" y2="24.225" layer="201" rot="R270"/>
<rectangle x1="69.54" y1="20.349" x2="70.566" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="69.996" y1="18.924" x2="70.11" y2="18.981" layer="201" rot="R270"/>
<rectangle x1="69.996" y1="18.639" x2="70.11" y2="18.696" layer="201" rot="R270"/>
<rectangle x1="69.7965" y1="17.8125" x2="70.3095" y2="17.8695" layer="201" rot="R270"/>
<rectangle x1="69.711" y1="13.053" x2="70.395" y2="13.11" layer="201" rot="R270"/>
<rectangle x1="69.9675" y1="11.0295" x2="70.1385" y2="11.0865" layer="201" rot="R270"/>
<rectangle x1="70.0245" y1="10.0605" x2="70.0815" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="69.4545" y1="21.5175" x2="70.7655" y2="21.5745" layer="200" rot="R270"/>
<rectangle x1="69.825" y1="19.551" x2="70.395" y2="19.608" layer="200" rot="R270"/>
<rectangle x1="69.8535" y1="18.9525" x2="70.3665" y2="19.0095" layer="200" rot="R270"/>
<rectangle x1="69.882" y1="18.297" x2="70.338" y2="18.354" layer="200" rot="R270"/>
<rectangle x1="67.9725" y1="15.4755" x2="72.2475" y2="15.5325" layer="200" rot="R270"/>
<rectangle x1="69.312" y1="11.913" x2="70.908" y2="11.97" layer="200" rot="R270"/>
<rectangle x1="69.6825" y1="10.5165" x2="70.5375" y2="10.5735" layer="200" rot="R270"/>
<rectangle x1="68.115" y1="24.168" x2="72.105" y2="24.225" layer="201" rot="R270"/>
<rectangle x1="69.597" y1="20.349" x2="70.623" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="70.0815" y1="19.2375" x2="70.1385" y2="19.2945" layer="201" rot="R270"/>
<rectangle x1="70.0245" y1="18.6105" x2="70.1955" y2="18.6675" layer="201" rot="R270"/>
<rectangle x1="69.882" y1="17.841" x2="70.338" y2="17.898" layer="201" rot="R270"/>
<rectangle x1="69.7965" y1="13.0245" x2="70.4235" y2="13.0815" layer="201" rot="R270"/>
<rectangle x1="70.0245" y1="11.0295" x2="70.1955" y2="11.0865" layer="201" rot="R270"/>
<rectangle x1="70.0815" y1="10.0605" x2="70.1385" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="69.5115" y1="21.5175" x2="70.8225" y2="21.5745" layer="200" rot="R270"/>
<rectangle x1="69.9105" y1="19.5795" x2="70.4235" y2="19.6365" layer="200" rot="R270"/>
<rectangle x1="69.9105" y1="18.9525" x2="70.4235" y2="19.0095" layer="200" rot="R270"/>
<rectangle x1="69.939" y1="18.297" x2="70.395" y2="18.354" layer="200" rot="R270"/>
<rectangle x1="68.001" y1="15.447" x2="72.333" y2="15.504" layer="200" rot="R270"/>
<rectangle x1="69.369" y1="11.913" x2="70.965" y2="11.97" layer="200" rot="R270"/>
<rectangle x1="69.7395" y1="10.5165" x2="70.5945" y2="10.5735" layer="200" rot="R270"/>
<rectangle x1="68.172" y1="24.168" x2="72.162" y2="24.225" layer="201" rot="R270"/>
<rectangle x1="69.654" y1="20.349" x2="70.68" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="70.11" y1="19.266" x2="70.224" y2="19.323" layer="201" rot="R270"/>
<rectangle x1="70.0815" y1="18.6105" x2="70.2525" y2="18.6675" layer="201" rot="R270"/>
<rectangle x1="69.939" y1="17.841" x2="70.395" y2="17.898" layer="201" rot="R270"/>
<rectangle x1="69.882" y1="12.996" x2="70.452" y2="13.053" layer="201" rot="R270"/>
<rectangle x1="70.0815" y1="11.0295" x2="70.2525" y2="11.0865" layer="201" rot="R270"/>
<rectangle x1="70.1385" y1="10.0605" x2="70.1955" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="69.5685" y1="21.5175" x2="70.8795" y2="21.5745" layer="200" rot="R270"/>
<rectangle x1="69.9675" y1="19.5795" x2="70.4805" y2="19.6365" layer="200" rot="R270"/>
<rectangle x1="70.0245" y1="18.2685" x2="70.4235" y2="18.3255" layer="200" rot="R270"/>
<rectangle x1="68.0295" y1="15.4755" x2="72.4185" y2="15.5325" layer="200" rot="R270"/>
<rectangle x1="69.426" y1="11.913" x2="71.022" y2="11.97" layer="200" rot="R270"/>
<rectangle x1="69.768" y1="10.545" x2="70.68" y2="10.602" layer="200" rot="R270"/>
<rectangle x1="68.229" y1="24.168" x2="72.219" y2="24.225" layer="201" rot="R270"/>
<rectangle x1="69.711" y1="20.349" x2="70.737" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="69.7965" y1="18.8955" x2="70.6515" y2="18.9525" layer="201" rot="R270"/>
<rectangle x1="70.0245" y1="17.8695" x2="70.4235" y2="17.9265" layer="201" rot="R270"/>
<rectangle x1="69.939" y1="12.996" x2="70.509" y2="13.053" layer="201" rot="R270"/>
<rectangle x1="70.167" y1="11.058" x2="70.281" y2="11.115" layer="201" rot="R270"/>
<rectangle x1="70.1955" y1="10.0605" x2="70.2525" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="69.6255" y1="21.5175" x2="70.9365" y2="21.5745" layer="200" rot="R270"/>
<rectangle x1="70.053" y1="19.608" x2="70.509" y2="19.665" layer="200" rot="R270"/>
<rectangle x1="70.0815" y1="18.2685" x2="70.4805" y2="18.3255" layer="200" rot="R270"/>
<rectangle x1="68.058" y1="15.447" x2="72.504" y2="15.504" layer="200" rot="R270"/>
<rectangle x1="69.483" y1="11.913" x2="71.079" y2="11.97" layer="200" rot="R270"/>
<rectangle x1="69.8535" y1="10.5165" x2="70.7085" y2="10.5735" layer="200" rot="R270"/>
<rectangle x1="68.286" y1="24.168" x2="72.276" y2="24.225" layer="201" rot="R270"/>
<rectangle x1="69.768" y1="20.349" x2="70.794" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="69.825" y1="18.924" x2="70.737" y2="18.981" layer="201" rot="R270"/>
<rectangle x1="70.0815" y1="17.8695" x2="70.4805" y2="17.9265" layer="201" rot="R270"/>
<rectangle x1="70.0245" y1="12.9675" x2="70.5375" y2="13.0245" layer="201" rot="R270"/>
<rectangle x1="70.1955" y1="11.0295" x2="70.3665" y2="11.0865" layer="201" rot="R270"/>
<rectangle x1="70.2525" y1="10.0605" x2="70.3095" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="69.6825" y1="21.5175" x2="70.9935" y2="21.5745" layer="200" rot="R270"/>
<rectangle x1="70.11" y1="19.608" x2="70.566" y2="19.665" layer="200" rot="R270"/>
<rectangle x1="70.1385" y1="18.2685" x2="70.5375" y2="18.3255" layer="200" rot="R270"/>
<rectangle x1="68.0865" y1="15.4755" x2="72.5895" y2="15.5325" layer="200" rot="R270"/>
<rectangle x1="69.54" y1="11.913" x2="71.136" y2="11.97" layer="200" rot="R270"/>
<rectangle x1="69.9105" y1="10.5165" x2="70.7655" y2="10.5735" layer="200" rot="R270"/>
<rectangle x1="68.343" y1="24.168" x2="72.333" y2="24.225" layer="201" rot="R270"/>
<rectangle x1="69.825" y1="20.349" x2="70.851" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="69.882" y1="18.924" x2="70.794" y2="18.981" layer="201" rot="R270"/>
<rectangle x1="70.167" y1="17.898" x2="70.509" y2="17.955" layer="201" rot="R270"/>
<rectangle x1="70.0815" y1="12.9675" x2="70.5945" y2="13.0245" layer="201" rot="R270"/>
<rectangle x1="70.2525" y1="11.0295" x2="70.4235" y2="11.0865" layer="201" rot="R270"/>
<rectangle x1="70.3095" y1="10.0605" x2="70.3665" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="69.7395" y1="21.5175" x2="71.0505" y2="21.5745" layer="200" rot="R270"/>
<rectangle x1="70.167" y1="19.608" x2="70.623" y2="19.665" layer="200" rot="R270"/>
<rectangle x1="70.1955" y1="18.2685" x2="70.5945" y2="18.3255" layer="200" rot="R270"/>
<rectangle x1="68.1435" y1="15.4755" x2="72.6465" y2="15.5325" layer="200" rot="R270"/>
<rectangle x1="69.597" y1="11.913" x2="71.193" y2="11.97" layer="200" rot="R270"/>
<rectangle x1="69.9675" y1="10.5735" x2="70.8225" y2="10.6305" layer="200" rot="R270"/>
<rectangle x1="68.4" y1="24.168" x2="72.39" y2="24.225" layer="201" rot="R270"/>
<rectangle x1="69.882" y1="20.349" x2="70.908" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="69.939" y1="18.924" x2="70.851" y2="18.981" layer="201" rot="R270"/>
<rectangle x1="70.224" y1="17.898" x2="70.566" y2="17.955" layer="201" rot="R270"/>
<rectangle x1="70.1385" y1="12.9675" x2="70.6515" y2="13.0245" layer="201" rot="R270"/>
<rectangle x1="70.338" y1="11.058" x2="70.452" y2="11.115" layer="201" rot="R270"/>
<rectangle x1="70.338" y1="10.089" x2="70.452" y2="10.146" layer="201" rot="R270"/>
<rectangle x1="69.825" y1="21.489" x2="71.079" y2="21.546" layer="200" rot="R270"/>
<rectangle x1="70.1955" y1="19.5795" x2="70.7085" y2="19.6365" layer="200" rot="R270"/>
<rectangle x1="70.2525" y1="18.2685" x2="70.6515" y2="18.3255" layer="200" rot="R270"/>
<rectangle x1="68.172" y1="15.504" x2="72.732" y2="15.561" layer="200" rot="R270"/>
<rectangle x1="69.1695" y1="11.4285" x2="71.7345" y2="11.4855" layer="200" rot="R270"/>
<rectangle x1="68.4285" y1="24.1395" x2="72.4755" y2="24.1965" layer="201" rot="R270"/>
<rectangle x1="69.939" y1="20.349" x2="70.965" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="70.0245" y1="18.8955" x2="70.8795" y2="18.9525" layer="201" rot="R270"/>
<rectangle x1="70.3095" y1="17.9265" x2="70.5945" y2="17.9835" layer="201" rot="R270"/>
<rectangle x1="70.1955" y1="12.9675" x2="70.7085" y2="13.0245" layer="201" rot="R270"/>
<rectangle x1="70.395" y1="10.089" x2="70.509" y2="10.146" layer="201" rot="R270"/>
<rectangle x1="69.882" y1="21.489" x2="71.136" y2="21.546" layer="200" rot="R270"/>
<rectangle x1="70.2525" y1="19.5795" x2="70.7655" y2="19.6365" layer="200" rot="R270"/>
<rectangle x1="70.3095" y1="18.2685" x2="70.7085" y2="18.3255" layer="200" rot="R270"/>
<rectangle x1="68.2005" y1="15.4755" x2="72.8175" y2="15.5325" layer="200" rot="R270"/>
<rectangle x1="69.2265" y1="11.4285" x2="71.7915" y2="11.4855" layer="200" rot="R270"/>
<rectangle x1="68.4855" y1="24.1395" x2="72.5325" y2="24.1965" layer="201" rot="R270"/>
<rectangle x1="69.996" y1="20.349" x2="71.022" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="70.0815" y1="18.8955" x2="70.9365" y2="18.9525" layer="201" rot="R270"/>
<rectangle x1="70.3665" y1="17.9265" x2="70.6515" y2="17.9835" layer="201" rot="R270"/>
<rectangle x1="70.281" y1="12.939" x2="70.737" y2="12.996" layer="201" rot="R270"/>
<rectangle x1="70.452" y1="10.089" x2="70.566" y2="10.146" layer="201" rot="R270"/>
<rectangle x1="69.939" y1="21.489" x2="71.193" y2="21.546" layer="200" rot="R270"/>
<rectangle x1="70.3095" y1="19.5795" x2="70.8225" y2="19.6365" layer="200" rot="R270"/>
<rectangle x1="70.338" y1="18.297" x2="70.794" y2="18.354" layer="200" rot="R270"/>
<rectangle x1="68.2575" y1="15.4755" x2="72.8745" y2="15.5325" layer="200" rot="R270"/>
<rectangle x1="69.2835" y1="11.4285" x2="71.8485" y2="11.4855" layer="200" rot="R270"/>
<rectangle x1="68.5425" y1="24.1395" x2="72.5895" y2="24.1965" layer="201" rot="R270"/>
<rectangle x1="70.053" y1="20.349" x2="71.079" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="70.167" y1="18.924" x2="70.965" y2="18.981" layer="201" rot="R270"/>
<rectangle x1="70.4235" y1="17.9265" x2="70.7085" y2="17.9835" layer="201" rot="R270"/>
<rectangle x1="70.338" y1="12.939" x2="70.794" y2="12.996" layer="201" rot="R270"/>
<rectangle x1="70.509" y1="10.089" x2="70.623" y2="10.146" layer="201" rot="R270"/>
<rectangle x1="69.996" y1="21.489" x2="71.25" y2="21.546" layer="200" rot="R270"/>
<rectangle x1="70.338" y1="19.551" x2="70.908" y2="19.608" layer="200" rot="R270"/>
<rectangle x1="70.395" y1="18.297" x2="70.851" y2="18.354" layer="200" rot="R270"/>
<rectangle x1="68.286" y1="15.504" x2="72.96" y2="15.561" layer="200" rot="R270"/>
<rectangle x1="69.3405" y1="11.4285" x2="71.9055" y2="11.4855" layer="200" rot="R270"/>
<rectangle x1="68.5995" y1="24.1395" x2="72.6465" y2="24.1965" layer="201" rot="R270"/>
<rectangle x1="70.11" y1="20.349" x2="71.136" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="70.2525" y1="18.8955" x2="70.9935" y2="18.9525" layer="201" rot="R270"/>
<rectangle x1="70.509" y1="17.955" x2="70.737" y2="18.012" layer="201" rot="R270"/>
<rectangle x1="70.395" y1="12.939" x2="70.851" y2="12.996" layer="201" rot="R270"/>
<rectangle x1="70.566" y1="10.089" x2="70.68" y2="10.146" layer="201" rot="R270"/>
<rectangle x1="70.0815" y1="21.4605" x2="71.2785" y2="21.5175" layer="200" rot="R270"/>
<rectangle x1="70.3665" y1="19.5225" x2="70.9935" y2="19.5795" layer="200" rot="R270"/>
<rectangle x1="70.4235" y1="18.3255" x2="70.9365" y2="18.3825" layer="200" rot="R270"/>
<rectangle x1="68.3145" y1="15.4755" x2="73.0455" y2="15.5325" layer="200" rot="R270"/>
<rectangle x1="69.996" y1="12.027" x2="71.364" y2="12.084" layer="200" rot="R270"/>
<rectangle x1="70.338" y1="10.488" x2="71.022" y2="10.545" layer="200" rot="R270"/>
<rectangle x1="68.628" y1="24.111" x2="72.732" y2="24.168" layer="201" rot="R270"/>
<rectangle x1="70.167" y1="20.349" x2="71.193" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="70.3665" y1="18.8955" x2="70.9935" y2="18.9525" layer="201" rot="R270"/>
<rectangle x1="70.566" y1="17.955" x2="70.794" y2="18.012" layer="201" rot="R270"/>
<rectangle x1="70.4805" y1="12.9105" x2="70.8795" y2="12.9675" layer="201" rot="R270"/>
<rectangle x1="70.4235" y1="11.0865" x2="70.9365" y2="11.1435" layer="201" rot="R270"/>
<rectangle x1="70.623" y1="10.089" x2="70.737" y2="10.146" layer="201" rot="R270"/>
<rectangle x1="70.1385" y1="21.4605" x2="71.3355" y2="21.5175" layer="200" rot="R270"/>
<rectangle x1="69.8535" y1="18.9525" x2="71.6205" y2="19.0095" layer="200" rot="R270"/>
<rectangle x1="68.3715" y1="15.4755" x2="73.1025" y2="15.5325" layer="200" rot="R270"/>
<rectangle x1="70.1385" y1="12.1125" x2="71.3355" y2="12.1695" layer="200" rot="R270"/>
<rectangle x1="70.5945" y1="10.2885" x2="70.8795" y2="10.3455" layer="200" rot="R270"/>
<rectangle x1="68.685" y1="24.111" x2="72.789" y2="24.168" layer="201" rot="R270"/>
<rectangle x1="70.224" y1="20.349" x2="71.25" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="70.623" y1="17.955" x2="70.851" y2="18.012" layer="201" rot="R270"/>
<rectangle x1="70.5375" y1="12.9105" x2="70.9365" y2="12.9675" layer="201" rot="R270"/>
<rectangle x1="70.1955" y1="10.9725" x2="71.2785" y2="11.0295" layer="201" rot="R270"/>
<rectangle x1="70.68" y1="10.089" x2="70.794" y2="10.146" layer="201" rot="R270"/>
<rectangle x1="70.224" y1="21.432" x2="71.364" y2="21.489" layer="200" rot="R270"/>
<rectangle x1="69.9105" y1="18.9525" x2="71.6775" y2="19.0095" layer="200" rot="R270"/>
<rectangle x1="68.4" y1="15.504" x2="73.188" y2="15.561" layer="200" rot="R270"/>
<rectangle x1="70.281" y1="12.198" x2="71.307" y2="12.255" layer="200" rot="R270"/>
<rectangle x1="70.6515" y1="10.2315" x2="70.9365" y2="10.2885" layer="200" rot="R270"/>
<rectangle x1="68.7135" y1="24.0825" x2="72.8745" y2="24.1395" layer="201" rot="R270"/>
<rectangle x1="70.281" y1="20.349" x2="71.307" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="70.7085" y1="17.9835" x2="70.8795" y2="18.0405" layer="201" rot="R270"/>
<rectangle x1="70.5945" y1="12.9105" x2="70.9935" y2="12.9675" layer="201" rot="R270"/>
<rectangle x1="70.1385" y1="11.0295" x2="71.4495" y2="11.0865" layer="201" rot="R270"/>
<rectangle x1="70.7655" y1="10.0605" x2="70.8225" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="70.338" y1="21.375" x2="71.364" y2="21.432" layer="200" rot="R270"/>
<rectangle x1="69.9675" y1="18.9525" x2="71.7345" y2="19.0095" layer="200" rot="R270"/>
<rectangle x1="68.4855" y1="15.5325" x2="73.2165" y2="15.5895" layer="200" rot="R270"/>
<rectangle x1="70.3665" y1="12.2265" x2="71.3355" y2="12.2835" layer="200" rot="R270"/>
<rectangle x1="70.737" y1="10.203" x2="70.965" y2="10.26" layer="200" rot="R270"/>
<rectangle x1="68.7135" y1="24.0255" x2="72.9885" y2="24.0825" layer="201" rot="R270"/>
<rectangle x1="70.338" y1="20.349" x2="71.364" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="70.7655" y1="17.9835" x2="70.9365" y2="18.0405" layer="201" rot="R270"/>
<rectangle x1="70.623" y1="12.939" x2="71.079" y2="12.996" layer="201" rot="R270"/>
<rectangle x1="70.1385" y1="11.0295" x2="71.5635" y2="11.0865" layer="201" rot="R270"/>
<rectangle x1="70.8225" y1="10.0605" x2="70.8795" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="70.851" y1="21.261" x2="70.965" y2="21.318" layer="200" rot="R270"/>
<rectangle x1="70.7655" y1="21.0045" x2="71.0505" y2="21.0615" layer="200" rot="R270"/>
<rectangle x1="70.0245" y1="18.9525" x2="71.7915" y2="19.0095" layer="200" rot="R270"/>
<rectangle x1="68.571" y1="15.561" x2="73.245" y2="15.618" layer="200" rot="R270"/>
<rectangle x1="70.452" y1="12.255" x2="71.364" y2="12.312" layer="200" rot="R270"/>
<rectangle x1="70.8225" y1="10.1745" x2="70.9935" y2="10.2315" layer="200" rot="R270"/>
<rectangle x1="68.4855" y1="23.7405" x2="73.3305" y2="23.7975" layer="201" rot="R270"/>
<rectangle x1="70.8795" y1="21.1755" x2="70.9365" y2="21.2325" layer="201" rot="R270"/>
<rectangle x1="70.395" y1="20.349" x2="71.421" y2="20.406" layer="201" rot="R270"/>
<rectangle x1="70.8225" y1="17.9835" x2="70.9935" y2="18.0405" layer="201" rot="R270"/>
<rectangle x1="70.6515" y1="12.9675" x2="71.1645" y2="13.0245" layer="201" rot="R270"/>
<rectangle x1="70.1385" y1="11.0295" x2="71.6775" y2="11.0865" layer="201" rot="R270"/>
<rectangle x1="70.8795" y1="10.0605" x2="70.9365" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="70.794" y1="20.919" x2="71.136" y2="20.976" layer="200" rot="R270"/>
<rectangle x1="70.0815" y1="18.9525" x2="71.8485" y2="19.0095" layer="200" rot="R270"/>
<rectangle x1="68.628" y1="15.561" x2="73.302" y2="15.618" layer="200" rot="R270"/>
<rectangle x1="70.509" y1="12.255" x2="71.421" y2="12.312" layer="200" rot="R270"/>
<rectangle x1="70.908" y1="10.146" x2="71.022" y2="10.203" layer="200" rot="R270"/>
<rectangle x1="68.4285" y1="23.6265" x2="73.5015" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="70.509" y1="20.292" x2="71.421" y2="20.349" layer="201" rot="R270"/>
<rectangle x1="70.8795" y1="17.9835" x2="71.0505" y2="18.0405" layer="201" rot="R270"/>
<rectangle x1="70.7085" y1="12.9675" x2="71.2215" y2="13.0245" layer="201" rot="R270"/>
<rectangle x1="70.167" y1="11.001" x2="71.763" y2="11.058" layer="201" rot="R270"/>
<rectangle x1="70.9365" y1="10.0605" x2="70.9935" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="70.851" y1="20.919" x2="71.193" y2="20.976" layer="200" rot="R270"/>
<rectangle x1="70.1385" y1="18.9525" x2="71.9055" y2="19.0095" layer="200" rot="R270"/>
<rectangle x1="70.281" y1="17.1" x2="71.763" y2="17.157" layer="200" rot="R270"/>
<rectangle x1="70.8795" y1="16.0455" x2="71.1645" y2="16.1025" layer="200" rot="R270"/>
<rectangle x1="70.5945" y1="15.3045" x2="71.4495" y2="15.3615" layer="200" rot="R270"/>
<rectangle x1="70.281" y1="14.079" x2="71.763" y2="14.136" layer="200" rot="R270"/>
<rectangle x1="70.566" y1="12.255" x2="71.478" y2="12.312" layer="200" rot="R270"/>
<rectangle x1="70.965" y1="10.146" x2="71.079" y2="10.203" layer="200" rot="R270"/>
<rectangle x1="68.4855" y1="23.6265" x2="73.5585" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="70.566" y1="20.292" x2="71.478" y2="20.349" layer="201" rot="R270"/>
<rectangle x1="70.908" y1="17.955" x2="71.136" y2="18.012" layer="201" rot="R270"/>
<rectangle x1="70.9365" y1="16.2735" x2="71.1075" y2="16.3305" layer="201" rot="R270"/>
<rectangle x1="70.9365" y1="15.8175" x2="71.1075" y2="15.8745" layer="201" rot="R270"/>
<rectangle x1="70.9935" y1="14.8485" x2="71.0505" y2="14.9055" layer="201" rot="R270"/>
<rectangle x1="70.7085" y1="13.0245" x2="71.3355" y2="13.0815" layer="201" rot="R270"/>
<rectangle x1="70.224" y1="11.001" x2="71.82" y2="11.058" layer="201" rot="R270"/>
<rectangle x1="70.9935" y1="10.0605" x2="71.0505" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="70.908" y1="20.919" x2="71.25" y2="20.976" layer="200" rot="R270"/>
<rectangle x1="70.1955" y1="18.9525" x2="71.9625" y2="19.0095" layer="200" rot="R270"/>
<rectangle x1="70.4235" y1="17.0715" x2="71.7345" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="70.9935" y1="16.0455" x2="71.1645" y2="16.1025" layer="200" rot="R270"/>
<rectangle x1="70.8795" y1="15.4185" x2="71.2785" y2="15.4755" layer="200" rot="R270"/>
<rectangle x1="71.022" y1="15.105" x2="71.136" y2="15.162" layer="200" rot="R270"/>
<rectangle x1="70.395" y1="14.022" x2="71.763" y2="14.079" layer="200" rot="R270"/>
<rectangle x1="70.6515" y1="12.2835" x2="71.5065" y2="12.3405" layer="200" rot="R270"/>
<rectangle x1="68.5425" y1="23.6265" x2="73.6155" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="70.623" y1="20.292" x2="71.535" y2="20.349" layer="201" rot="R270"/>
<rectangle x1="70.908" y1="17.898" x2="71.25" y2="17.955" layer="201" rot="R270"/>
<rectangle x1="70.9365" y1="16.2735" x2="71.2215" y2="16.3305" layer="201" rot="R270"/>
<rectangle x1="70.908" y1="15.789" x2="71.25" y2="15.846" layer="201" rot="R270"/>
<rectangle x1="71.0505" y1="15.1905" x2="71.1075" y2="15.2475" layer="201" rot="R270"/>
<rectangle x1="70.908" y1="14.877" x2="71.25" y2="14.934" layer="201" rot="R270"/>
<rectangle x1="70.7655" y1="13.0245" x2="71.3925" y2="13.0815" layer="201" rot="R270"/>
<rectangle x1="70.167" y1="10.944" x2="71.991" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="70.9365" y1="20.8905" x2="71.3355" y2="20.9475" layer="200" rot="R270"/>
<rectangle x1="70.2525" y1="18.9525" x2="72.0195" y2="19.0095" layer="200" rot="R270"/>
<rectangle x1="70.5375" y1="17.0715" x2="71.7345" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="71.079" y1="16.017" x2="71.193" y2="16.074" layer="200" rot="R270"/>
<rectangle x1="70.965" y1="15.39" x2="71.307" y2="15.447" layer="200" rot="R270"/>
<rectangle x1="71.079" y1="15.105" x2="71.193" y2="15.162" layer="200" rot="R270"/>
<rectangle x1="71.079" y1="14.877" x2="71.193" y2="14.934" layer="200" rot="R270"/>
<rectangle x1="70.4805" y1="13.9935" x2="71.7915" y2="14.0505" layer="200" rot="R270"/>
<rectangle x1="70.7085" y1="12.2835" x2="71.5635" y2="12.3405" layer="200" rot="R270"/>
<rectangle x1="68.5995" y1="23.6265" x2="73.6725" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="70.7085" y1="20.2635" x2="71.5635" y2="20.3205" layer="201" rot="R270"/>
<rectangle x1="70.9365" y1="17.8695" x2="71.3355" y2="17.9265" layer="201" rot="R270"/>
<rectangle x1="70.9365" y1="16.2735" x2="71.3355" y2="16.3305" layer="201" rot="R270"/>
<rectangle x1="70.9365" y1="15.7605" x2="71.3355" y2="15.8175" layer="201" rot="R270"/>
<rectangle x1="71.1075" y1="15.1905" x2="71.1645" y2="15.2475" layer="201" rot="R270"/>
<rectangle x1="71.079" y1="14.991" x2="71.193" y2="15.048" layer="201" rot="R270"/>
<rectangle x1="71.0505" y1="14.7345" x2="71.2215" y2="14.7915" layer="201" rot="R270"/>
<rectangle x1="70.8225" y1="13.0245" x2="71.4495" y2="13.0815" layer="201" rot="R270"/>
<rectangle x1="70.224" y1="10.944" x2="72.048" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="69.6825" y1="19.5795" x2="72.7035" y2="19.6365" layer="200" rot="R270"/>
<rectangle x1="70.623" y1="17.1" x2="71.763" y2="17.157" layer="200" rot="R270"/>
<rectangle x1="71.079" y1="16.302" x2="71.307" y2="16.359" layer="200" rot="R270"/>
<rectangle x1="71.1645" y1="16.0455" x2="71.2215" y2="16.1025" layer="200" rot="R270"/>
<rectangle x1="71.079" y1="15.789" x2="71.307" y2="15.846" layer="200" rot="R270"/>
<rectangle x1="71.1645" y1="15.4755" x2="71.2215" y2="15.5325" layer="200" rot="R270"/>
<rectangle x1="71.1645" y1="15.0765" x2="71.2215" y2="15.1335" layer="200" rot="R270"/>
<rectangle x1="71.1075" y1="14.8485" x2="71.2785" y2="14.9055" layer="200" rot="R270"/>
<rectangle x1="70.5945" y1="14.0505" x2="71.7915" y2="14.1075" layer="200" rot="R270"/>
<rectangle x1="70.7655" y1="12.2835" x2="71.6205" y2="12.3405" layer="200" rot="R270"/>
<rectangle x1="68.6565" y1="23.6265" x2="73.7295" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="70.9935" y1="17.8695" x2="71.3925" y2="17.9265" layer="201" rot="R270"/>
<rectangle x1="71.136" y1="16.473" x2="71.25" y2="16.53" layer="201" rot="R270"/>
<rectangle x1="71.136" y1="16.131" x2="71.25" y2="16.188" layer="201" rot="R270"/>
<rectangle x1="71.136" y1="15.96" x2="71.25" y2="16.017" layer="201" rot="R270"/>
<rectangle x1="71.1075" y1="15.5895" x2="71.2785" y2="15.6465" layer="201" rot="R270"/>
<rectangle x1="71.022" y1="15.276" x2="71.364" y2="15.333" layer="201" rot="R270"/>
<rectangle x1="71.136" y1="14.991" x2="71.25" y2="15.048" layer="201" rot="R270"/>
<rectangle x1="71.136" y1="14.706" x2="71.25" y2="14.763" layer="201" rot="R270"/>
<rectangle x1="70.8225" y1="13.0815" x2="71.5635" y2="13.1385" layer="201" rot="R270"/>
<rectangle x1="70.281" y1="10.944" x2="72.105" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="69.7395" y1="19.5795" x2="72.7605" y2="19.6365" layer="200" rot="R270"/>
<rectangle x1="70.7085" y1="17.0715" x2="71.7915" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="71.0505" y1="16.2165" x2="71.4495" y2="16.2735" layer="200" rot="R270"/>
<rectangle x1="71.136" y1="15.732" x2="71.364" y2="15.789" layer="200" rot="R270"/>
<rectangle x1="71.2215" y1="15.3045" x2="71.2785" y2="15.3615" layer="200" rot="R270"/>
<rectangle x1="71.1075" y1="14.9625" x2="71.3925" y2="15.0195" layer="200" rot="R270"/>
<rectangle x1="70.623" y1="14.022" x2="71.877" y2="14.079" layer="200" rot="R270"/>
<rectangle x1="70.8225" y1="12.2835" x2="71.6775" y2="12.3405" layer="200" rot="R270"/>
<rectangle x1="68.7135" y1="23.6265" x2="73.7865" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="71.022" y1="17.841" x2="71.478" y2="17.898" layer="201" rot="R270"/>
<rectangle x1="71.193" y1="16.473" x2="71.307" y2="16.53" layer="201" rot="R270"/>
<rectangle x1="71.1645" y1="15.9315" x2="71.3355" y2="15.9885" layer="201" rot="R270"/>
<rectangle x1="71.1075" y1="15.4755" x2="71.3925" y2="15.5325" layer="201" rot="R270"/>
<rectangle x1="71.1645" y1="15.1905" x2="71.3355" y2="15.2475" layer="201" rot="R270"/>
<rectangle x1="71.1645" y1="14.7345" x2="71.3355" y2="14.7915" layer="201" rot="R270"/>
<rectangle x1="70.908" y1="13.053" x2="71.592" y2="13.11" layer="201" rot="R270"/>
<rectangle x1="70.338" y1="10.944" x2="72.162" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="69.7965" y1="19.5795" x2="72.8175" y2="19.6365" layer="200" rot="R270"/>
<rectangle x1="70.7655" y1="17.0715" x2="71.8485" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="71.1075" y1="16.2165" x2="71.5065" y2="16.2735" layer="200" rot="R270"/>
<rectangle x1="71.193" y1="15.732" x2="71.421" y2="15.789" layer="200" rot="R270"/>
<rectangle x1="71.2785" y1="15.4755" x2="71.3355" y2="15.5325" layer="200" rot="R270"/>
<rectangle x1="71.25" y1="15.276" x2="71.364" y2="15.333" layer="200" rot="R270"/>
<rectangle x1="71.1645" y1="15.0195" x2="71.4495" y2="15.0765" layer="200" rot="R270"/>
<rectangle x1="70.623" y1="14.022" x2="71.991" y2="14.079" layer="200" rot="R270"/>
<rectangle x1="70.8795" y1="12.2835" x2="71.7345" y2="12.3405" layer="200" rot="R270"/>
<rectangle x1="68.7705" y1="23.6265" x2="73.8435" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="71.079" y1="17.841" x2="71.535" y2="17.898" layer="201" rot="R270"/>
<rectangle x1="71.25" y1="16.473" x2="71.364" y2="16.53" layer="201" rot="R270"/>
<rectangle x1="71.2215" y1="15.9315" x2="71.3925" y2="15.9885" layer="201" rot="R270"/>
<rectangle x1="71.25" y1="15.561" x2="71.364" y2="15.618" layer="201" rot="R270"/>
<rectangle x1="71.25" y1="15.39" x2="71.364" y2="15.447" layer="201" rot="R270"/>
<rectangle x1="71.2785" y1="15.1905" x2="71.3355" y2="15.2475" layer="201" rot="R270"/>
<rectangle x1="71.2215" y1="14.7915" x2="71.3925" y2="14.8485" layer="201" rot="R270"/>
<rectangle x1="70.9935" y1="13.0245" x2="71.6205" y2="13.0815" layer="201" rot="R270"/>
<rectangle x1="70.395" y1="10.944" x2="72.219" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="69.8535" y1="19.5795" x2="72.8745" y2="19.6365" layer="200" rot="R270"/>
<rectangle x1="70.8225" y1="17.0715" x2="71.9055" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="71.1645" y1="16.2165" x2="71.5635" y2="16.2735" layer="200" rot="R270"/>
<rectangle x1="71.25" y1="15.732" x2="71.478" y2="15.789" layer="200" rot="R270"/>
<rectangle x1="71.307" y1="15.447" x2="71.421" y2="15.504" layer="200" rot="R270"/>
<rectangle x1="71.3355" y1="15.2475" x2="71.3925" y2="15.3045" layer="200" rot="R270"/>
<rectangle x1="71.2215" y1="15.0195" x2="71.5065" y2="15.0765" layer="200" rot="R270"/>
<rectangle x1="70.6515" y1="13.9935" x2="72.0765" y2="14.0505" layer="200" rot="R270"/>
<rectangle x1="70.9365" y1="12.2835" x2="71.7915" y2="12.3405" layer="200" rot="R270"/>
<rectangle x1="68.8275" y1="23.6265" x2="73.9005" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="71.136" y1="17.841" x2="71.592" y2="17.898" layer="201" rot="R270"/>
<rectangle x1="71.307" y1="16.473" x2="71.421" y2="16.53" layer="201" rot="R270"/>
<rectangle x1="71.2785" y1="15.9315" x2="71.4495" y2="15.9885" layer="201" rot="R270"/>
<rectangle x1="71.307" y1="15.561" x2="71.421" y2="15.618" layer="201" rot="R270"/>
<rectangle x1="71.307" y1="15.333" x2="71.421" y2="15.39" layer="201" rot="R270"/>
<rectangle x1="71.3355" y1="15.1905" x2="71.3925" y2="15.2475" layer="201" rot="R270"/>
<rectangle x1="71.2785" y1="14.7915" x2="71.4495" y2="14.8485" layer="201" rot="R270"/>
<rectangle x1="71.079" y1="12.996" x2="71.649" y2="13.053" layer="201" rot="R270"/>
<rectangle x1="70.452" y1="10.944" x2="72.276" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="69.9105" y1="19.5795" x2="72.9315" y2="19.6365" layer="200" rot="R270"/>
<rectangle x1="70.8795" y1="17.0715" x2="71.9625" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="71.2785" y1="16.2735" x2="71.5635" y2="16.3305" layer="200" rot="R270"/>
<rectangle x1="71.3925" y1="16.0455" x2="71.4495" y2="16.1025" layer="200" rot="R270"/>
<rectangle x1="71.2785" y1="15.7605" x2="71.5635" y2="15.8175" layer="200" rot="R270"/>
<rectangle x1="71.3355" y1="15.4185" x2="71.5065" y2="15.4755" layer="200" rot="R270"/>
<rectangle x1="71.364" y1="15.105" x2="71.478" y2="15.162" layer="200" rot="R270"/>
<rectangle x1="71.364" y1="14.877" x2="71.478" y2="14.934" layer="200" rot="R270"/>
<rectangle x1="70.68" y1="13.908" x2="72.162" y2="13.965" layer="200" rot="R270"/>
<rectangle x1="70.9935" y1="12.2835" x2="71.8485" y2="12.3405" layer="200" rot="R270"/>
<rectangle x1="68.8845" y1="23.6265" x2="73.9575" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="71.193" y1="17.841" x2="71.649" y2="17.898" layer="201" rot="R270"/>
<rectangle x1="71.364" y1="16.473" x2="71.478" y2="16.53" layer="201" rot="R270"/>
<rectangle x1="71.3925" y1="16.1025" x2="71.4495" y2="16.1595" layer="201" rot="R270"/>
<rectangle x1="71.364" y1="15.96" x2="71.478" y2="16.017" layer="201" rot="R270"/>
<rectangle x1="71.364" y1="15.561" x2="71.478" y2="15.618" layer="201" rot="R270"/>
<rectangle x1="71.3355" y1="15.2475" x2="71.5065" y2="15.3045" layer="201" rot="R270"/>
<rectangle x1="71.364" y1="14.991" x2="71.478" y2="15.048" layer="201" rot="R270"/>
<rectangle x1="71.3355" y1="14.7345" x2="71.5065" y2="14.7915" layer="201" rot="R270"/>
<rectangle x1="71.193" y1="12.939" x2="71.649" y2="12.996" layer="201" rot="R270"/>
<rectangle x1="70.509" y1="10.944" x2="72.333" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="69.9675" y1="19.5795" x2="72.9885" y2="19.6365" layer="200" rot="R270"/>
<rectangle x1="70.908" y1="17.1" x2="72.048" y2="17.157" layer="200" rot="R270"/>
<rectangle x1="71.3925" y1="16.2735" x2="71.5635" y2="16.3305" layer="200" rot="R270"/>
<rectangle x1="71.4495" y1="16.0455" x2="71.5065" y2="16.1025" layer="200" rot="R270"/>
<rectangle x1="71.3925" y1="15.7605" x2="71.5635" y2="15.8175" layer="200" rot="R270"/>
<rectangle x1="71.364" y1="15.447" x2="71.592" y2="15.504" layer="200" rot="R270"/>
<rectangle x1="71.421" y1="15.105" x2="71.535" y2="15.162" layer="200" rot="R270"/>
<rectangle x1="71.4495" y1="14.8485" x2="71.5065" y2="14.9055" layer="200" rot="R270"/>
<rectangle x1="70.7085" y1="13.9365" x2="72.2475" y2="13.9935" layer="200" rot="R270"/>
<rectangle x1="71.0505" y1="12.2835" x2="71.9055" y2="12.3405" layer="200" rot="R270"/>
<rectangle x1="68.9415" y1="23.6265" x2="74.0145" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="71.2785" y1="17.8695" x2="71.6775" y2="17.9265" layer="201" rot="R270"/>
<rectangle x1="71.3925" y1="16.4445" x2="71.5635" y2="16.5015" layer="201" rot="R270"/>
<rectangle x1="71.421" y1="16.131" x2="71.535" y2="16.188" layer="201" rot="R270"/>
<rectangle x1="71.3925" y1="15.9315" x2="71.5635" y2="15.9885" layer="201" rot="R270"/>
<rectangle x1="71.421" y1="15.618" x2="71.535" y2="15.675" layer="201" rot="R270"/>
<rectangle x1="71.3925" y1="15.2475" x2="71.5635" y2="15.3045" layer="201" rot="R270"/>
<rectangle x1="71.3925" y1="14.9625" x2="71.5635" y2="15.0195" layer="201" rot="R270"/>
<rectangle x1="71.421" y1="14.763" x2="71.535" y2="14.82" layer="201" rot="R270"/>
<rectangle x1="71.25" y1="12.939" x2="71.706" y2="12.996" layer="201" rot="R270"/>
<rectangle x1="70.566" y1="10.944" x2="72.39" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="70.0245" y1="19.5795" x2="73.0455" y2="19.6365" layer="200" rot="R270"/>
<rectangle x1="70.9365" y1="17.0715" x2="72.1335" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="71.478" y1="16.017" x2="71.592" y2="16.074" layer="200" rot="R270"/>
<rectangle x1="71.3925" y1="15.4185" x2="71.6775" y2="15.4755" layer="200" rot="R270"/>
<rectangle x1="71.4495" y1="15.0765" x2="71.6205" y2="15.1335" layer="200" rot="R270"/>
<rectangle x1="70.7085" y1="13.9365" x2="72.3615" y2="13.9935" layer="200" rot="R270"/>
<rectangle x1="71.1075" y1="12.2835" x2="71.9625" y2="12.3405" layer="200" rot="R270"/>
<rectangle x1="68.9985" y1="23.6265" x2="74.0715" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="71.3355" y1="17.8695" x2="71.7345" y2="17.9265" layer="201" rot="R270"/>
<rectangle x1="71.3355" y1="16.2735" x2="71.7345" y2="16.3305" layer="201" rot="R270"/>
<rectangle x1="71.3355" y1="15.7605" x2="71.7345" y2="15.8175" layer="201" rot="R270"/>
<rectangle x1="71.478" y1="15.219" x2="71.592" y2="15.276" layer="201" rot="R270"/>
<rectangle x1="71.421" y1="14.877" x2="71.649" y2="14.934" layer="201" rot="R270"/>
<rectangle x1="71.3355" y1="12.9105" x2="71.7345" y2="12.9675" layer="201" rot="R270"/>
<rectangle x1="70.623" y1="10.944" x2="72.447" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="71.421" y1="20.919" x2="71.763" y2="20.976" layer="200" rot="R270"/>
<rectangle x1="70.338" y1="19.323" x2="72.846" y2="19.38" layer="200" rot="R270"/>
<rectangle x1="70.8795" y1="17.0715" x2="72.3045" y2="17.1285" layer="200" rot="R270"/>
<rectangle x1="71.3925" y1="15.9885" x2="71.7915" y2="16.0455" layer="200" rot="R270"/>
<rectangle x1="71.193" y1="15.276" x2="71.991" y2="15.333" layer="200" rot="R270"/>
<rectangle x1="70.737" y1="13.965" x2="72.447" y2="14.022" layer="200" rot="R270"/>
<rectangle x1="71.1645" y1="12.2835" x2="72.0195" y2="12.3405" layer="200" rot="R270"/>
<rectangle x1="69.0555" y1="23.6265" x2="74.1285" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="71.5065" y1="20.6625" x2="71.6775" y2="20.7195" layer="201" rot="R270"/>
<rectangle x1="71.4495" y1="17.9265" x2="71.7345" y2="17.9835" layer="201" rot="R270"/>
<rectangle x1="71.5065" y1="16.2735" x2="71.6775" y2="16.3305" layer="201" rot="R270"/>
<rectangle x1="71.535" y1="15.732" x2="71.649" y2="15.789" layer="201" rot="R270"/>
<rectangle x1="71.5635" y1="14.8485" x2="71.6205" y2="14.9055" layer="201" rot="R270"/>
<rectangle x1="71.3925" y1="12.9105" x2="71.7915" y2="12.9675" layer="201" rot="R270"/>
<rectangle x1="70.68" y1="10.944" x2="72.504" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="71.5065" y1="20.8905" x2="71.7915" y2="20.9475" layer="200" rot="R270"/>
<rectangle x1="70.4235" y1="19.2945" x2="72.8745" y2="19.3515" layer="200" rot="R270"/>
<rectangle x1="69.2835" y1="15.4755" x2="74.0145" y2="15.5325" layer="200" rot="R270"/>
<rectangle x1="71.2215" y1="12.2835" x2="72.0765" y2="12.3405" layer="200" rot="R270"/>
<rectangle x1="69.084" y1="23.598" x2="74.214" y2="23.655" layer="201" rot="R270"/>
<rectangle x1="71.535" y1="20.634" x2="71.763" y2="20.691" layer="201" rot="R270"/>
<rectangle x1="71.535" y1="17.955" x2="71.763" y2="18.012" layer="201" rot="R270"/>
<rectangle x1="71.4495" y1="12.9105" x2="71.8485" y2="12.9675" layer="201" rot="R270"/>
<rectangle x1="70.737" y1="10.944" x2="72.561" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="71.5635" y1="20.8905" x2="71.8485" y2="20.9475" layer="200" rot="R270"/>
<rectangle x1="70.509" y1="19.266" x2="72.903" y2="19.323" layer="200" rot="R270"/>
<rectangle x1="69.3405" y1="15.5325" x2="74.0715" y2="15.5895" layer="200" rot="R270"/>
<rectangle x1="71.2785" y1="12.2835" x2="72.1335" y2="12.3405" layer="200" rot="R270"/>
<rectangle x1="69.141" y1="23.598" x2="74.271" y2="23.655" layer="201" rot="R270"/>
<rectangle x1="71.5635" y1="20.6055" x2="71.8485" y2="20.6625" layer="201" rot="R270"/>
<rectangle x1="71.6205" y1="17.9835" x2="71.7915" y2="18.0405" layer="201" rot="R270"/>
<rectangle x1="71.478" y1="12.939" x2="71.934" y2="12.996" layer="201" rot="R270"/>
<rectangle x1="70.794" y1="10.944" x2="72.618" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="71.592" y1="20.919" x2="71.934" y2="20.976" layer="200" rot="R270"/>
<rectangle x1="70.5945" y1="19.2375" x2="72.9315" y2="19.2945" layer="200" rot="R270"/>
<rectangle x1="69.3975" y1="15.5325" x2="74.1285" y2="15.5895" layer="200" rot="R270"/>
<rectangle x1="71.3355" y1="12.2835" x2="72.1905" y2="12.3405" layer="200" rot="R270"/>
<rectangle x1="69.2265" y1="23.6265" x2="74.2995" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="71.592" y1="20.577" x2="71.934" y2="20.634" layer="201" rot="R270"/>
<rectangle x1="71.6775" y1="17.9835" x2="71.8485" y2="18.0405" layer="201" rot="R270"/>
<rectangle x1="71.535" y1="12.939" x2="71.991" y2="12.996" layer="201" rot="R270"/>
<rectangle x1="70.851" y1="10.944" x2="72.675" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="71.649" y1="20.919" x2="71.991" y2="20.976" layer="200" rot="R270"/>
<rectangle x1="70.68" y1="19.209" x2="72.96" y2="19.266" layer="200" rot="R270"/>
<rectangle x1="69.4545" y1="15.5325" x2="74.1855" y2="15.5895" layer="200" rot="R270"/>
<rectangle x1="71.3925" y1="12.2835" x2="72.2475" y2="12.3405" layer="200" rot="R270"/>
<rectangle x1="69.2835" y1="23.6265" x2="74.3565" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="71.6205" y1="20.5485" x2="72.0195" y2="20.6055" layer="201" rot="R270"/>
<rectangle x1="71.7345" y1="17.9835" x2="71.9055" y2="18.0405" layer="201" rot="R270"/>
<rectangle x1="71.592" y1="12.939" x2="72.048" y2="12.996" layer="201" rot="R270"/>
<rectangle x1="70.908" y1="10.944" x2="72.732" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="71.7345" y1="20.8905" x2="72.0195" y2="20.9475" layer="200" rot="R270"/>
<rectangle x1="70.737" y1="19.209" x2="73.017" y2="19.266" layer="200" rot="R270"/>
<rectangle x1="69.5685" y1="15.5325" x2="74.1855" y2="15.5895" layer="200" rot="R270"/>
<rectangle x1="71.4495" y1="12.2835" x2="72.3045" y2="12.3405" layer="200" rot="R270"/>
<rectangle x1="69.312" y1="23.598" x2="74.442" y2="23.655" layer="201" rot="R270"/>
<rectangle x1="71.6775" y1="20.5485" x2="72.0765" y2="20.6055" layer="201" rot="R270"/>
<rectangle x1="71.763" y1="17.955" x2="71.991" y2="18.012" layer="201" rot="R270"/>
<rectangle x1="71.6205" y1="12.9675" x2="72.1335" y2="13.0245" layer="201" rot="R270"/>
<rectangle x1="70.965" y1="10.944" x2="72.789" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="71.7915" y1="20.8905" x2="72.0765" y2="20.9475" layer="200" rot="R270"/>
<rectangle x1="70.794" y1="19.209" x2="73.074" y2="19.266" layer="200" rot="R270"/>
<rectangle x1="69.6255" y1="15.5325" x2="74.2425" y2="15.5895" layer="200" rot="R270"/>
<rectangle x1="71.5065" y1="12.2835" x2="72.3615" y2="12.3405" layer="200" rot="R270"/>
<rectangle x1="69.369" y1="23.598" x2="74.499" y2="23.655" layer="201" rot="R270"/>
<rectangle x1="71.7345" y1="20.5485" x2="72.1335" y2="20.6055" layer="201" rot="R270"/>
<rectangle x1="71.82" y1="17.955" x2="72.048" y2="18.012" layer="201" rot="R270"/>
<rectangle x1="71.6775" y1="12.9675" x2="72.1905" y2="13.0245" layer="201" rot="R270"/>
<rectangle x1="71.022" y1="10.944" x2="72.846" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="71.82" y1="20.862" x2="72.162" y2="20.919" layer="200" rot="R270"/>
<rectangle x1="70.8795" y1="19.1805" x2="73.1025" y2="19.2375" layer="200" rot="R270"/>
<rectangle x1="69.6825" y1="15.5325" x2="74.2995" y2="15.5895" layer="200" rot="R270"/>
<rectangle x1="71.5635" y1="12.2835" x2="72.4185" y2="12.3405" layer="200" rot="R270"/>
<rectangle x1="69.426" y1="23.598" x2="74.556" y2="23.655" layer="201" rot="R270"/>
<rectangle x1="71.7915" y1="20.4915" x2="72.1905" y2="20.5485" layer="201" rot="R270"/>
<rectangle x1="71.877" y1="17.955" x2="72.105" y2="18.012" layer="201" rot="R270"/>
<rectangle x1="71.7345" y1="12.9675" x2="72.2475" y2="13.0245" layer="201" rot="R270"/>
<rectangle x1="71.079" y1="10.944" x2="72.903" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="71.9625" y1="20.9475" x2="72.1335" y2="21.0045" layer="200" rot="R270"/>
<rectangle x1="70.9365" y1="19.1805" x2="73.1595" y2="19.2375" layer="200" rot="R270"/>
<rectangle x1="69.768" y1="15.561" x2="74.328" y2="15.618" layer="200" rot="R270"/>
<rectangle x1="71.6205" y1="12.2835" x2="72.4755" y2="12.3405" layer="200" rot="R270"/>
<rectangle x1="69.483" y1="23.598" x2="74.613" y2="23.655" layer="201" rot="R270"/>
<rectangle x1="71.763" y1="20.577" x2="72.333" y2="20.634" layer="201" rot="R270"/>
<rectangle x1="71.934" y1="17.955" x2="72.162" y2="18.012" layer="201" rot="R270"/>
<rectangle x1="71.763" y1="12.996" x2="72.333" y2="13.053" layer="201" rot="R270"/>
<rectangle x1="71.136" y1="10.944" x2="72.96" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="72.0765" y1="20.6625" x2="72.1335" y2="20.7195" layer="200" rot="R270"/>
<rectangle x1="70.9935" y1="19.1805" x2="73.2165" y2="19.2375" layer="200" rot="R270"/>
<rectangle x1="69.8535" y1="15.5325" x2="74.3565" y2="15.5895" layer="200" rot="R270"/>
<rectangle x1="71.6775" y1="12.2835" x2="72.5325" y2="12.3405" layer="200" rot="R270"/>
<rectangle x1="69.369" y1="23.427" x2="74.841" y2="23.484" layer="201" rot="R270"/>
<rectangle x1="71.934" y1="20.463" x2="72.276" y2="20.52" layer="201" rot="R270"/>
<rectangle x1="71.9625" y1="17.9265" x2="72.2475" y2="17.9835" layer="201" rot="R270"/>
<rectangle x1="71.82" y1="12.996" x2="72.39" y2="13.053" layer="201" rot="R270"/>
<rectangle x1="71.193" y1="10.944" x2="73.017" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="71.0505" y1="19.1805" x2="73.2735" y2="19.2375" layer="200" rot="R270"/>
<rectangle x1="69.939" y1="15.561" x2="74.385" y2="15.618" layer="200" rot="R270"/>
<rectangle x1="71.7345" y1="12.2835" x2="72.5895" y2="12.3405" layer="200" rot="R270"/>
<rectangle x1="69.2265" y1="23.2275" x2="75.0975" y2="23.2845" layer="201" rot="R270"/>
<rectangle x1="72.0195" y1="17.9265" x2="72.3045" y2="17.9835" layer="201" rot="R270"/>
<rectangle x1="71.8485" y1="13.0245" x2="72.4755" y2="13.0815" layer="201" rot="R270"/>
<rectangle x1="71.25" y1="10.944" x2="73.074" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="71.1075" y1="19.1805" x2="73.3305" y2="19.2375" layer="200" rot="R270"/>
<rectangle x1="70.0245" y1="15.5325" x2="74.4135" y2="15.5895" layer="200" rot="R270"/>
<rectangle x1="71.7915" y1="12.2835" x2="72.6465" y2="12.3405" layer="200" rot="R270"/>
<rectangle x1="69.2835" y1="23.2275" x2="75.1545" y2="23.2845" layer="201" rot="R270"/>
<rectangle x1="72.048" y1="17.898" x2="72.39" y2="17.955" layer="201" rot="R270"/>
<rectangle x1="71.9055" y1="13.0245" x2="72.5325" y2="13.0815" layer="201" rot="R270"/>
<rectangle x1="71.307" y1="10.944" x2="73.131" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="72.2475" y1="20.8905" x2="72.3045" y2="20.9475" layer="200" rot="R270"/>
<rectangle x1="71.1645" y1="19.1805" x2="73.3875" y2="19.2375" layer="200" rot="R270"/>
<rectangle x1="70.11" y1="15.561" x2="74.442" y2="15.618" layer="200" rot="R270"/>
<rectangle x1="71.8485" y1="12.2835" x2="72.7035" y2="12.3405" layer="200" rot="R270"/>
<rectangle x1="69.654" y1="23.541" x2="74.898" y2="23.598" layer="201" rot="R270"/>
<rectangle x1="71.991" y1="20.577" x2="72.561" y2="20.634" layer="201" rot="R270"/>
<rectangle x1="72.105" y1="17.898" x2="72.447" y2="17.955" layer="201" rot="R270"/>
<rectangle x1="71.934" y1="13.053" x2="72.618" y2="13.11" layer="201" rot="R270"/>
<rectangle x1="71.364" y1="10.944" x2="73.188" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="72.276" y1="20.976" x2="72.39" y2="21.033" layer="200" rot="R270"/>
<rectangle x1="71.9055" y1="19.9215" x2="72.7605" y2="19.9785" layer="200" rot="R270"/>
<rectangle x1="71.7915" y1="18.6105" x2="72.8745" y2="18.6675" layer="200" rot="R270"/>
<rectangle x1="70.167" y1="15.561" x2="74.499" y2="15.618" layer="200" rot="R270"/>
<rectangle x1="71.9055" y1="12.2835" x2="72.7605" y2="12.3405" layer="200" rot="R270"/>
<rectangle x1="69.768" y1="23.598" x2="74.898" y2="23.655" layer="201" rot="R270"/>
<rectangle x1="72.048" y1="20.634" x2="72.618" y2="20.691" layer="201" rot="R270"/>
<rectangle x1="72.162" y1="19.323" x2="72.504" y2="19.38" layer="201" rot="R270"/>
<rectangle x1="72.162" y1="17.898" x2="72.504" y2="17.955" layer="201" rot="R270"/>
<rectangle x1="71.991" y1="13.053" x2="72.675" y2="13.11" layer="201" rot="R270"/>
<rectangle x1="71.421" y1="10.944" x2="73.245" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="72.2475" y1="25.9635" x2="72.5325" y2="26.0205" layer="200" rot="R270"/>
<rectangle x1="72.276" y1="24.054" x2="72.504" y2="24.111" layer="200" rot="R270"/>
<rectangle x1="72.2475" y1="22.1445" x2="72.5325" y2="22.2015" layer="200" rot="R270"/>
<rectangle x1="72.048" y1="20.007" x2="72.732" y2="20.064" layer="200" rot="R270"/>
<rectangle x1="71.934" y1="18.525" x2="72.846" y2="18.582" layer="200" rot="R270"/>
<rectangle x1="70.281" y1="15.561" x2="74.499" y2="15.618" layer="200" rot="R270"/>
<rectangle x1="71.9625" y1="12.2835" x2="72.8175" y2="12.3405" layer="200" rot="R270"/>
<rectangle x1="72.3615" y1="26.1345" x2="72.4185" y2="26.1915" layer="201" rot="R270"/>
<rectangle x1="71.5635" y1="24.9945" x2="73.2165" y2="25.0515" layer="201" rot="R270"/>
<rectangle x1="71.5635" y1="23.1135" x2="73.2165" y2="23.1705" layer="201" rot="R270"/>
<rectangle x1="71.5635" y1="21.1755" x2="73.2165" y2="21.2325" layer="201" rot="R270"/>
<rectangle x1="72.048" y1="19.323" x2="72.732" y2="19.38" layer="201" rot="R270"/>
<rectangle x1="72.1905" y1="17.8695" x2="72.5895" y2="17.9265" layer="201" rot="R270"/>
<rectangle x1="72.0195" y1="13.0815" x2="72.7605" y2="13.1385" layer="201" rot="R270"/>
<rectangle x1="71.478" y1="10.944" x2="73.302" y2="11.001" layer="201" rot="R270"/>
<rectangle x1="72.276" y1="25.992" x2="72.618" y2="26.049" layer="200" rot="R270"/>
<rectangle x1="71.307" y1="23.085" x2="73.587" y2="23.142" layer="200" rot="R270"/>
<rectangle x1="72.105" y1="20.064" x2="72.789" y2="20.121" layer="200" rot="R270"/>
<rectangle x1="72.048" y1="18.468" x2="72.846" y2="18.525" layer="200" rot="R270"/>
<rectangle x1="70.338" y1="15.561" x2="74.556" y2="15.618" layer="200" rot="R270"/>
<rectangle x1="72.0195" y1="12.2835" x2="72.8745" y2="12.3405" layer="200" rot="R270"/>
<rectangle x1="72.4185" y1="10.1175" x2="72.4755" y2="10.1745" layer="200" rot="R270"/>
<rectangle x1="71.649" y1="25.023" x2="73.245" y2="25.08" layer="201" rot="R270"/>
<rectangle x1="71.6775" y1="21.1755" x2="73.2165" y2="21.2325" layer="201" rot="R270"/>
<rectangle x1="72.0195" y1="19.2945" x2="72.8745" y2="19.3515" layer="201" rot="R270"/>
<rectangle x1="72.2475" y1="17.8695" x2="72.6465" y2="17.9265" layer="201" rot="R270"/>
<rectangle x1="72.0765" y1="13.0815" x2="72.8175" y2="13.1385" layer="201" rot="R270"/>
<rectangle x1="71.592" y1="11.001" x2="73.302" y2="11.058" layer="201" rot="R270"/>
<rectangle x1="72.4185" y1="10.0605" x2="72.4755" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="72.3045" y1="25.9635" x2="72.7035" y2="26.0205" layer="200" rot="R270"/>
<rectangle x1="71.3355" y1="23.1135" x2="73.6725" y2="23.1705" layer="200" rot="R270"/>
<rectangle x1="72.162" y1="20.121" x2="72.846" y2="20.178" layer="200" rot="R270"/>
<rectangle x1="72.1335" y1="18.4395" x2="72.8745" y2="18.4965" layer="200" rot="R270"/>
<rectangle x1="70.452" y1="15.561" x2="74.556" y2="15.618" layer="200" rot="R270"/>
<rectangle x1="72.0765" y1="12.2835" x2="72.9315" y2="12.3405" layer="200" rot="R270"/>
<rectangle x1="72.4755" y1="10.1175" x2="72.5325" y2="10.1745" layer="200" rot="R270"/>
<rectangle x1="71.763" y1="25.023" x2="73.245" y2="25.08" layer="201" rot="R270"/>
<rectangle x1="71.763" y1="21.204" x2="73.245" y2="21.261" layer="201" rot="R270"/>
<rectangle x1="72.0195" y1="19.2945" x2="72.9885" y2="19.3515" layer="201" rot="R270"/>
<rectangle x1="72.276" y1="17.841" x2="72.732" y2="17.898" layer="201" rot="R270"/>
<rectangle x1="72.105" y1="13.11" x2="72.903" y2="13.167" layer="201" rot="R270"/>
<rectangle x1="71.649" y1="11.001" x2="73.359" y2="11.058" layer="201" rot="R270"/>
<rectangle x1="72.4755" y1="10.0605" x2="72.5325" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="72.333" y1="25.935" x2="72.789" y2="25.992" layer="200" rot="R270"/>
<rectangle x1="71.3355" y1="23.1135" x2="73.7865" y2="23.1705" layer="200" rot="R270"/>
<rectangle x1="72.2475" y1="20.1495" x2="72.8745" y2="20.2065" layer="200" rot="R270"/>
<rectangle x1="72.219" y1="18.411" x2="72.903" y2="18.468" layer="200" rot="R270"/>
<rectangle x1="70.5375" y1="15.5325" x2="74.5845" y2="15.5895" layer="200" rot="R270"/>
<rectangle x1="72.105" y1="12.255" x2="73.017" y2="12.312" layer="200" rot="R270"/>
<rectangle x1="72.4755" y1="10.1175" x2="72.6465" y2="10.1745" layer="200" rot="R270"/>
<rectangle x1="71.877" y1="25.023" x2="73.245" y2="25.08" layer="201" rot="R270"/>
<rectangle x1="71.8485" y1="21.1755" x2="73.2735" y2="21.2325" layer="201" rot="R270"/>
<rectangle x1="72.0195" y1="19.2945" x2="73.1025" y2="19.3515" layer="201" rot="R270"/>
<rectangle x1="72.3045" y1="17.8125" x2="72.8175" y2="17.8695" layer="201" rot="R270"/>
<rectangle x1="72.162" y1="13.11" x2="72.96" y2="13.167" layer="201" rot="R270"/>
<rectangle x1="71.763" y1="11.001" x2="73.359" y2="11.058" layer="201" rot="R270"/>
<rectangle x1="72.3615" y1="25.9065" x2="72.8745" y2="25.9635" layer="200" rot="R270"/>
<rectangle x1="71.307" y1="23.085" x2="73.929" y2="23.142" layer="200" rot="R270"/>
<rectangle x1="72.276" y1="20.235" x2="72.96" y2="20.292" layer="200" rot="R270"/>
<rectangle x1="72.276" y1="18.411" x2="72.96" y2="18.468" layer="200" rot="R270"/>
<rectangle x1="70.623" y1="15.561" x2="74.613" y2="15.618" layer="200" rot="R270"/>
<rectangle x1="72.162" y1="12.255" x2="73.074" y2="12.312" layer="200" rot="R270"/>
<rectangle x1="72.5325" y1="10.1175" x2="72.7035" y2="10.1745" layer="200" rot="R270"/>
<rectangle x1="71.991" y1="25.023" x2="73.245" y2="25.08" layer="201" rot="R270"/>
<rectangle x1="72.0195" y1="21.1755" x2="73.2165" y2="21.2325" layer="201" rot="R270"/>
<rectangle x1="72.048" y1="19.323" x2="73.188" y2="19.38" layer="201" rot="R270"/>
<rectangle x1="72.3615" y1="17.8125" x2="72.8745" y2="17.8695" layer="201" rot="R270"/>
<rectangle x1="72.1905" y1="13.1385" x2="73.0455" y2="13.1955" layer="201" rot="R270"/>
<rectangle x1="71.82" y1="11.001" x2="73.416" y2="11.058" layer="201" rot="R270"/>
<rectangle x1="72.3615" y1="25.8495" x2="72.9885" y2="25.9065" layer="200" rot="R270"/>
<rectangle x1="71.25" y1="23.085" x2="74.1" y2="23.142" layer="200" rot="R270"/>
<rectangle x1="72.3045" y1="20.2635" x2="73.0455" y2="20.3205" layer="200" rot="R270"/>
<rectangle x1="72.3615" y1="18.3825" x2="72.9885" y2="18.4395" layer="200" rot="R270"/>
<rectangle x1="70.737" y1="15.561" x2="74.613" y2="15.618" layer="200" rot="R270"/>
<rectangle x1="72.219" y1="12.255" x2="73.131" y2="12.312" layer="200" rot="R270"/>
<rectangle x1="72.561" y1="10.146" x2="72.789" y2="10.203" layer="200" rot="R270"/>
<rectangle x1="72.162" y1="25.023" x2="73.188" y2="25.08" layer="201" rot="R270"/>
<rectangle x1="72.162" y1="21.147" x2="73.188" y2="21.204" layer="201" rot="R270"/>
<rectangle x1="72.0765" y1="19.2945" x2="73.2735" y2="19.3515" layer="201" rot="R270"/>
<rectangle x1="72.39" y1="17.784" x2="72.96" y2="17.841" layer="201" rot="R270"/>
<rectangle x1="72.219" y1="13.167" x2="73.131" y2="13.224" layer="201" rot="R270"/>
<rectangle x1="71.9055" y1="11.0295" x2="73.4445" y2="11.0865" layer="201" rot="R270"/>
<rectangle x1="69.6255" y1="23.0565" x2="75.8385" y2="23.1135" layer="200" rot="R270"/>
<rectangle x1="72.4185" y1="18.3255" x2="73.0455" y2="18.3825" layer="200" rot="R270"/>
<rectangle x1="70.8225" y1="15.5325" x2="74.6415" y2="15.5895" layer="200" rot="R270"/>
<rectangle x1="72.2475" y1="12.2265" x2="73.2165" y2="12.2835" layer="200" rot="R270"/>
<rectangle x1="72.618" y1="10.146" x2="72.846" y2="10.203" layer="200" rot="R270"/>
<rectangle x1="72.0765" y1="19.2945" x2="73.3875" y2="19.3515" layer="201" rot="R270"/>
<rectangle x1="72.447" y1="17.727" x2="73.017" y2="17.784" layer="201" rot="R270"/>
<rectangle x1="72.276" y1="13.167" x2="73.188" y2="13.224" layer="201" rot="R270"/>
<rectangle x1="71.991" y1="11.001" x2="73.473" y2="11.058" layer="201" rot="R270"/>
<rectangle x1="69.6825" y1="23.0565" x2="75.8955" y2="23.1135" layer="200" rot="R270"/>
<rectangle x1="72.4755" y1="18.3255" x2="73.1025" y2="18.3825" layer="200" rot="R270"/>
<rectangle x1="70.908" y1="15.561" x2="74.67" y2="15.618" layer="200" rot="R270"/>
<rectangle x1="72.276" y1="12.198" x2="73.302" y2="12.255" layer="200" rot="R270"/>
<rectangle x1="72.618" y1="10.203" x2="72.96" y2="10.26" layer="200" rot="R270"/>
<rectangle x1="72.1335" y1="19.2945" x2="73.4445" y2="19.3515" layer="201" rot="R270"/>
<rectangle x1="72.504" y1="17.727" x2="73.074" y2="17.784" layer="201" rot="R270"/>
<rectangle x1="72.3045" y1="13.1955" x2="73.2735" y2="13.2525" layer="201" rot="R270"/>
<rectangle x1="72.1335" y1="11.0295" x2="73.4445" y2="11.0865" layer="201" rot="R270"/>
<rectangle x1="69.768" y1="23.085" x2="75.924" y2="23.142" layer="200" rot="R270"/>
<rectangle x1="72.5325" y1="18.3255" x2="73.1595" y2="18.3825" layer="200" rot="R270"/>
<rectangle x1="71.022" y1="15.561" x2="74.67" y2="15.618" layer="200" rot="R270"/>
<rectangle x1="72.2475" y1="12.1125" x2="73.4445" y2="12.1695" layer="200" rot="R270"/>
<rectangle x1="72.6465" y1="10.2315" x2="73.0455" y2="10.2885" layer="200" rot="R270"/>
<rectangle x1="72.162" y1="19.323" x2="73.53" y2="19.38" layer="201" rot="R270"/>
<rectangle x1="72.5325" y1="17.6985" x2="73.1595" y2="17.7555" layer="201" rot="R270"/>
<rectangle x1="72.333" y1="13.224" x2="73.359" y2="13.281" layer="201" rot="R270"/>
<rectangle x1="72.3045" y1="10.9725" x2="73.3875" y2="11.0295" layer="201" rot="R270"/>
<rectangle x1="69.825" y1="23.085" x2="75.981" y2="23.142" layer="200" rot="R270"/>
<rectangle x1="72.5895" y1="18.3255" x2="73.2165" y2="18.3825" layer="200" rot="R270"/>
<rectangle x1="71.136" y1="15.561" x2="74.67" y2="15.618" layer="200" rot="R270"/>
<rectangle x1="72.1905" y1="12.0555" x2="73.6155" y2="12.1125" layer="200" rot="R270"/>
<rectangle x1="72.6465" y1="10.3455" x2="73.1595" y2="10.4025" layer="200" rot="R270"/>
<rectangle x1="72.219" y1="19.323" x2="73.587" y2="19.38" layer="201" rot="R270"/>
<rectangle x1="72.561" y1="17.67" x2="73.245" y2="17.727" layer="201" rot="R270"/>
<rectangle x1="72.39" y1="13.281" x2="73.416" y2="13.338" layer="201" rot="R270"/>
<rectangle x1="72.5325" y1="10.9725" x2="73.2735" y2="11.0295" layer="201" rot="R270"/>
<rectangle x1="72.8745" y1="10.0605" x2="72.9315" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="69.882" y1="23.085" x2="76.038" y2="23.142" layer="200" rot="R270"/>
<rectangle x1="72.618" y1="18.297" x2="73.302" y2="18.354" layer="200" rot="R270"/>
<rectangle x1="71.2215" y1="15.5325" x2="74.6985" y2="15.5895" layer="200" rot="R270"/>
<rectangle x1="71.706" y1="11.514" x2="74.214" y2="11.571" layer="200" rot="R270"/>
<rectangle x1="72.903" y1="10.146" x2="73.017" y2="10.203" layer="200" rot="R270"/>
<rectangle x1="72.276" y1="19.323" x2="73.644" y2="19.38" layer="201" rot="R270"/>
<rectangle x1="72.618" y1="17.613" x2="73.302" y2="17.67" layer="201" rot="R270"/>
<rectangle x1="72.447" y1="13.281" x2="73.473" y2="13.338" layer="201" rot="R270"/>
<rectangle x1="72.9315" y1="10.2315" x2="72.9885" y2="10.2885" layer="201" rot="R270"/>
<rectangle x1="72.9315" y1="10.0605" x2="72.9885" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="69.939" y1="23.085" x2="76.095" y2="23.142" layer="200" rot="R270"/>
<rectangle x1="72.675" y1="18.297" x2="73.359" y2="18.354" layer="200" rot="R270"/>
<rectangle x1="71.3355" y1="15.5325" x2="74.6985" y2="15.5895" layer="200" rot="R270"/>
<rectangle x1="71.7915" y1="11.5425" x2="74.2425" y2="11.5995" layer="200" rot="R270"/>
<rectangle x1="72.96" y1="10.146" x2="73.074" y2="10.203" layer="200" rot="R270"/>
<rectangle x1="72.333" y1="19.551" x2="73.701" y2="19.608" layer="201" rot="R270"/>
<rectangle x1="72.6465" y1="17.5845" x2="73.3875" y2="17.6415" layer="201" rot="R270"/>
<rectangle x1="72.4755" y1="13.3095" x2="73.5585" y2="13.3665" layer="201" rot="R270"/>
<rectangle x1="72.96" y1="10.26" x2="73.074" y2="10.317" layer="201" rot="R270"/>
<rectangle x1="72.9885" y1="10.0605" x2="73.0455" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="73.0455" y1="26.1345" x2="73.1025" y2="26.1915" layer="200" rot="R270"/>
<rectangle x1="70.053" y1="23.028" x2="76.095" y2="23.085" layer="200" rot="R270"/>
<rectangle x1="72.7035" y1="18.2685" x2="73.4445" y2="18.3255" layer="200" rot="R270"/>
<rectangle x1="71.478" y1="15.561" x2="74.67" y2="15.618" layer="200" rot="R270"/>
<rectangle x1="71.82" y1="11.571" x2="74.328" y2="11.628" layer="200" rot="R270"/>
<rectangle x1="73.017" y1="10.146" x2="73.131" y2="10.203" layer="200" rot="R270"/>
<rectangle x1="73.0455" y1="26.0775" x2="73.1025" y2="26.1345" layer="201" rot="R270"/>
<rectangle x1="72.39" y1="19.323" x2="73.758" y2="19.38" layer="201" rot="R270"/>
<rectangle x1="72.7035" y1="17.5275" x2="73.4445" y2="17.5845" layer="201" rot="R270"/>
<rectangle x1="72.504" y1="13.395" x2="73.644" y2="13.452" layer="201" rot="R270"/>
<rectangle x1="73.017" y1="10.26" x2="73.131" y2="10.317" layer="201" rot="R270"/>
<rectangle x1="73.0455" y1="10.0605" x2="73.1025" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="73.1025" y1="26.1345" x2="73.1595" y2="26.1915" layer="200" rot="R270"/>
<rectangle x1="70.11" y1="23.028" x2="76.152" y2="23.085" layer="200" rot="R270"/>
<rectangle x1="72.732" y1="18.24" x2="73.53" y2="18.297" layer="200" rot="R270"/>
<rectangle x1="71.592" y1="15.561" x2="74.67" y2="15.618" layer="200" rot="R270"/>
<rectangle x1="71.8485" y1="11.6565" x2="74.4135" y2="11.7135" layer="200" rot="R270"/>
<rectangle x1="73.074" y1="10.146" x2="73.188" y2="10.203" layer="200" rot="R270"/>
<rectangle x1="73.1025" y1="26.0775" x2="73.1595" y2="26.1345" layer="201" rot="R270"/>
<rectangle x1="72.447" y1="19.323" x2="73.815" y2="19.38" layer="201" rot="R270"/>
<rectangle x1="72.7605" y1="17.4705" x2="73.5015" y2="17.5275" layer="201" rot="R270"/>
<rectangle x1="72.5895" y1="13.4805" x2="73.6725" y2="13.5375" layer="201" rot="R270"/>
<rectangle x1="73.0455" y1="10.2885" x2="73.2165" y2="10.3455" layer="201" rot="R270"/>
<rectangle x1="73.1025" y1="10.0605" x2="73.1595" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="73.1595" y1="26.1345" x2="73.2165" y2="26.1915" layer="200" rot="R270"/>
<rectangle x1="72.105" y1="24.909" x2="74.271" y2="24.966" layer="200" rot="R270"/>
<rectangle x1="71.3925" y1="21.7455" x2="74.9835" y2="21.8025" layer="200" rot="R270"/>
<rectangle x1="72.732" y1="18.183" x2="73.644" y2="18.24" layer="200" rot="R270"/>
<rectangle x1="71.7345" y1="15.5895" x2="74.6415" y2="15.6465" layer="200" rot="R270"/>
<rectangle x1="71.9055" y1="11.7135" x2="74.4705" y2="11.7705" layer="200" rot="R270"/>
<rectangle x1="73.1025" y1="10.1175" x2="73.2735" y2="10.1745" layer="200" rot="R270"/>
<rectangle x1="73.131" y1="26.049" x2="73.245" y2="26.106" layer="201" rot="R270"/>
<rectangle x1="73.0455" y1="23.6835" x2="73.3305" y2="23.7405" layer="201" rot="R270"/>
<rectangle x1="72.5325" y1="19.2945" x2="73.8435" y2="19.3515" layer="201" rot="R270"/>
<rectangle x1="72.846" y1="17.385" x2="73.53" y2="17.442" layer="201" rot="R270"/>
<rectangle x1="72.618" y1="13.566" x2="73.758" y2="13.623" layer="201" rot="R270"/>
<rectangle x1="73.074" y1="10.317" x2="73.302" y2="10.374" layer="201" rot="R270"/>
<rectangle x1="73.2165" y1="26.1345" x2="73.2735" y2="26.1915" layer="200" rot="R270"/>
<rectangle x1="72.2475" y1="24.9375" x2="74.2425" y2="24.9945" layer="200" rot="R270"/>
<rectangle x1="71.5635" y1="21.6315" x2="74.9265" y2="21.6885" layer="200" rot="R270"/>
<rectangle x1="72.447" y1="17.898" x2="74.043" y2="17.955" layer="200" rot="R270"/>
<rectangle x1="71.763" y1="15.561" x2="74.727" y2="15.618" layer="200" rot="R270"/>
<rectangle x1="71.5065" y1="12.2265" x2="74.9835" y2="12.2835" layer="200" rot="R270"/>
<rectangle x1="73.188" y1="10.146" x2="73.302" y2="10.203" layer="200" rot="R270"/>
<rectangle x1="73.1595" y1="26.0205" x2="73.3305" y2="26.0775" layer="201" rot="R270"/>
<rectangle x1="72.9315" y1="23.6265" x2="73.5585" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="72.618" y1="19.323" x2="73.872" y2="19.38" layer="201" rot="R270"/>
<rectangle x1="73.2165" y1="17.0715" x2="73.2735" y2="17.1285" layer="201" rot="R270"/>
<rectangle x1="73.188" y1="14.022" x2="73.302" y2="14.079" layer="201" rot="R270"/>
<rectangle x1="73.1025" y1="10.3455" x2="73.3875" y2="10.4025" layer="201" rot="R270"/>
<rectangle x1="73.2165" y1="10.0605" x2="73.2735" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="73.2735" y1="26.1345" x2="73.3305" y2="26.1915" layer="200" rot="R270"/>
<rectangle x1="72.39" y1="24.966" x2="74.214" y2="25.023" layer="200" rot="R270"/>
<rectangle x1="71.6205" y1="21.5745" x2="74.9835" y2="21.6315" layer="200" rot="R270"/>
<rectangle x1="69.198" y1="14.592" x2="77.406" y2="14.649" layer="200" rot="R270"/>
<rectangle x1="73.2165" y1="10.1175" x2="73.3875" y2="10.1745" layer="200" rot="R270"/>
<rectangle x1="73.188" y1="25.992" x2="73.416" y2="26.049" layer="201" rot="R270"/>
<rectangle x1="72.903" y1="23.655" x2="73.701" y2="23.712" layer="201" rot="R270"/>
<rectangle x1="72.7035" y1="19.2945" x2="73.9005" y2="19.3515" layer="201" rot="R270"/>
<rectangle x1="73.1595" y1="10.3455" x2="73.4445" y2="10.4025" layer="201" rot="R270"/>
<rectangle x1="73.3305" y1="26.1345" x2="73.3875" y2="26.1915" layer="200" rot="R270"/>
<rectangle x1="72.4755" y1="24.9945" x2="74.2425" y2="25.0515" layer="200" rot="R270"/>
<rectangle x1="71.7345" y1="21.5175" x2="74.9835" y2="21.5745" layer="200" rot="R270"/>
<rectangle x1="72.7605" y1="18.1545" x2="73.9575" y2="18.2115" layer="200" rot="R270"/>
<rectangle x1="72.219" y1="15.561" x2="74.499" y2="15.618" layer="200" rot="R270"/>
<rectangle x1="72.048" y1="11.856" x2="74.67" y2="11.913" layer="200" rot="R270"/>
<rectangle x1="73.2735" y1="10.1175" x2="73.4445" y2="10.1745" layer="200" rot="R270"/>
<rectangle x1="73.245" y1="25.992" x2="73.473" y2="26.049" layer="201" rot="R270"/>
<rectangle x1="72.8745" y1="23.6265" x2="73.8435" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="72.789" y1="19.323" x2="73.929" y2="19.38" layer="201" rot="R270"/>
<rectangle x1="72.9315" y1="17.1285" x2="73.7865" y2="17.1855" layer="201" rot="R270"/>
<rectangle x1="72.732" y1="13.794" x2="73.986" y2="13.851" layer="201" rot="R270"/>
<rectangle x1="73.188" y1="10.374" x2="73.53" y2="10.431" layer="201" rot="R270"/>
<rectangle x1="73.3875" y1="26.1345" x2="73.4445" y2="26.1915" layer="200" rot="R270"/>
<rectangle x1="72.618" y1="24.966" x2="74.214" y2="25.023" layer="200" rot="R270"/>
<rectangle x1="71.763" y1="21.489" x2="75.069" y2="21.546" layer="200" rot="R270"/>
<rectangle x1="72.8175" y1="18.2115" x2="74.0145" y2="18.2685" layer="200" rot="R270"/>
<rectangle x1="72.561" y1="15.561" x2="74.271" y2="15.618" layer="200" rot="R270"/>
<rectangle x1="72.162" y1="11.856" x2="74.67" y2="11.913" layer="200" rot="R270"/>
<rectangle x1="73.359" y1="10.146" x2="73.473" y2="10.203" layer="200" rot="R270"/>
<rectangle x1="73.245" y1="25.935" x2="73.587" y2="25.992" layer="201" rot="R270"/>
<rectangle x1="72.903" y1="23.655" x2="73.929" y2="23.712" layer="201" rot="R270"/>
<rectangle x1="72.903" y1="19.323" x2="73.929" y2="19.38" layer="201" rot="R270"/>
<rectangle x1="72.8175" y1="17.0145" x2="74.0145" y2="17.0715" layer="201" rot="R270"/>
<rectangle x1="72.618" y1="13.908" x2="74.214" y2="13.965" layer="201" rot="R270"/>
<rectangle x1="73.2165" y1="10.4025" x2="73.6155" y2="10.4595" layer="201" rot="R270"/>
<rectangle x1="73.3875" y1="10.0605" x2="73.4445" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="73.4445" y1="26.1345" x2="73.5015" y2="26.1915" layer="200" rot="R270"/>
<rectangle x1="72.732" y1="24.966" x2="74.214" y2="25.023" layer="200" rot="R270"/>
<rectangle x1="71.82" y1="21.432" x2="75.126" y2="21.489" layer="200" rot="R270"/>
<rectangle x1="72.8745" y1="18.2115" x2="74.0715" y2="18.2685" layer="200" rot="R270"/>
<rectangle x1="72.276" y1="11.913" x2="74.67" y2="11.97" layer="200" rot="R270"/>
<rectangle x1="73.416" y1="10.146" x2="73.53" y2="10.203" layer="200" rot="R270"/>
<rectangle x1="73.2735" y1="25.9065" x2="73.6725" y2="25.9635" layer="201" rot="R270"/>
<rectangle x1="72.903" y1="23.655" x2="74.043" y2="23.712" layer="201" rot="R270"/>
<rectangle x1="72.9885" y1="19.2945" x2="73.9575" y2="19.3515" layer="201" rot="R270"/>
<rectangle x1="71.2215" y1="15.3615" x2="75.7245" y2="15.4185" layer="201" rot="R270"/>
<rectangle x1="73.2165" y1="10.4595" x2="73.7295" y2="10.5165" layer="201" rot="R270"/>
<rectangle x1="73.4445" y1="10.0605" x2="73.5015" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="73.5015" y1="26.1345" x2="73.5585" y2="26.1915" layer="200" rot="R270"/>
<rectangle x1="72.8175" y1="24.9375" x2="74.2425" y2="24.9945" layer="200" rot="R270"/>
<rectangle x1="71.877" y1="21.375" x2="75.183" y2="21.432" layer="200" rot="R270"/>
<rectangle x1="72.903" y1="18.24" x2="74.157" y2="18.297" layer="200" rot="R270"/>
<rectangle x1="72.333" y1="11.97" x2="74.727" y2="12.027" layer="200" rot="R270"/>
<rectangle x1="73.4445" y1="10.1175" x2="73.6155" y2="10.1745" layer="200" rot="R270"/>
<rectangle x1="73.302" y1="25.878" x2="73.758" y2="25.935" layer="201" rot="R270"/>
<rectangle x1="72.9315" y1="23.6265" x2="74.1285" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="73.1025" y1="19.2945" x2="73.9575" y2="19.3515" layer="201" rot="R270"/>
<rectangle x1="71.307" y1="15.39" x2="75.753" y2="15.447" layer="201" rot="R270"/>
<rectangle x1="73.245" y1="10.488" x2="73.815" y2="10.545" layer="201" rot="R270"/>
<rectangle x1="73.5585" y1="26.1345" x2="73.6155" y2="26.1915" layer="200" rot="R270"/>
<rectangle x1="72.9315" y1="24.9375" x2="74.2425" y2="24.9945" layer="200" rot="R270"/>
<rectangle x1="71.9055" y1="21.3465" x2="75.2685" y2="21.4035" layer="200" rot="R270"/>
<rectangle x1="72.846" y1="18.24" x2="74.328" y2="18.297" layer="200" rot="R270"/>
<rectangle x1="72.39" y1="12.027" x2="74.784" y2="12.084" layer="200" rot="R270"/>
<rectangle x1="73.53" y1="10.146" x2="73.644" y2="10.203" layer="200" rot="R270"/>
<rectangle x1="73.3305" y1="25.8495" x2="73.8435" y2="25.9065" layer="201" rot="R270"/>
<rectangle x1="72.96" y1="23.655" x2="74.214" y2="23.712" layer="201" rot="R270"/>
<rectangle x1="73.245" y1="19.323" x2="73.929" y2="19.38" layer="201" rot="R270"/>
<rectangle x1="71.4495" y1="15.3615" x2="75.7245" y2="15.4185" layer="201" rot="R270"/>
<rectangle x1="73.2735" y1="10.5165" x2="73.9005" y2="10.5735" layer="201" rot="R270"/>
<rectangle x1="73.5585" y1="10.0605" x2="73.6155" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="73.6155" y1="26.1345" x2="73.6725" y2="26.1915" layer="200" rot="R270"/>
<rectangle x1="73.0455" y1="24.8805" x2="74.2425" y2="24.9375" layer="200" rot="R270"/>
<rectangle x1="71.877" y1="21.261" x2="75.411" y2="21.318" layer="200" rot="R270"/>
<rectangle x1="69.54" y1="14.991" x2="77.748" y2="15.048" layer="200" rot="R270"/>
<rectangle x1="73.587" y1="10.146" x2="73.701" y2="10.203" layer="200" rot="R270"/>
<rectangle x1="73.3305" y1="25.7925" x2="73.9575" y2="25.8495" layer="201" rot="R270"/>
<rectangle x1="73.017" y1="23.655" x2="74.271" y2="23.712" layer="201" rot="R270"/>
<rectangle x1="73.4445" y1="19.2945" x2="73.8435" y2="19.3515" layer="201" rot="R270"/>
<rectangle x1="73.302" y1="10.545" x2="73.986" y2="10.602" layer="201" rot="R270"/>
<rectangle x1="73.6155" y1="10.0605" x2="73.6725" y2="10.1175" layer="201" rot="R270"/>
<rectangle x1="73.6725" y1="26.1345" x2="73.7295" y2="26.1915" layer="200" rot="R270"/>
<rectangle x1="73.1595" y1="24.8235" x2="74.2425" y2="24.8805" layer="200" rot="R270"/>
<rectangle x1="67.6305" y1="16.9575" x2="79.7715" y2="17.0145" layer="200" rot="R270"/>
<rectangle x1="73.473" y1="10.545" x2="73.929" y2="10.602" layer="200" rot="R270"/>
<rectangle x1="73.587" y1="10.146" x2="73.815" y2="10.203" layer="200" rot="R270"/>
<rectangle x1="73.3305" y1="25.7355" x2="74.0715" y2="25.7925" layer="201" rot="R270"/>
<rectangle x1="73.074" y1="23.655" x2="74.328" y2="23.712" layer="201" rot="R270"/>
<rectangle x1="73.644" y1="10.83" x2="73.758" y2="10.887" layer="201" rot="R270"/>
<rectangle x1="73.6725" y1="10.2885" x2="73.7295" y2="10.3455" layer="201" rot="R270"/>
<rectangle x1="73.7295" y1="26.1345" x2="73.7865" y2="26.1915" layer="200" rot="R270"/>
<rectangle x1="73.302" y1="24.738" x2="74.214" y2="24.795" layer="200" rot="R270"/>
<rectangle x1="67.2885" y1="16.5015" x2="80.2275" y2="16.5585" layer="200" rot="R270"/>
<rectangle x1="73.302" y1="25.65" x2="74.214" y2="25.707" layer="201" rot="R270"/>
<rectangle x1="73.1025" y1="23.6265" x2="74.4135" y2="23.6835" layer="201" rot="R270"/>
<rectangle x1="73.7865" y1="26.1345" x2="73.8435" y2="26.1915" layer="200" rot="R270"/>
<rectangle x1="73.5015" y1="24.6525" x2="74.1285" y2="24.7095" layer="200" rot="R270"/>
<rectangle x1="67.374" y1="16.473" x2="80.256" y2="16.53" layer="200" rot="R270"/>
<rectangle x1="73.245" y1="25.536" x2="74.385" y2="25.593" layer="201" rot="R270"/>
<rectangle x1="73.1025" y1="23.6265" x2="74.5275" y2="23.6835" layer="201" rot="R270"/>
<text x="61.389" y="26.163" size="0.114" layer="201" font="vector" rot="R270">C:/Users/Z Gy/Desktop/mérők/stepp.bmp</text>
<text x="70.11" y="4.332" size="1.778" layer="28" rot="MR0">akku</text>
<text x="71.193" y="18.639" size="1.778" layer="28" rot="MR0">- 5V +</text>
<text x="25.935" y="7.125" size="1.778" layer="28" rot="MR0">menü</text>
<text x="24.738" y="19.209" size="1.778" layer="28" rot="MR0">ON</text>
<text x="4.959" y="10.431" size="1.778" layer="27" rot="R270">&gt;</text>
<text x="5.016" y="16.131" size="1.778" layer="27" rot="R270">&gt;</text>
<text x="5.358" y="13.965" size="2.54" layer="27">-</text>
<text x="5.358" y="15.162" size="2.54" layer="27">-</text>
<text x="5.358" y="9.519" size="2.54" layer="27">-</text>
<text x="6.555" y="7.752" size="2.54" layer="28" rot="MR0">-</text>
<text x="5.301" y="8.265" size="2.54" layer="27">-</text>
<text x="28.386" y="18.924" size="1.778" layer="27">47uF</text>
<wire x1="1.995" y1="25.422" x2="73.644" y2="25.422" width="0" layer="28" style="longdash"/>
<text x="73.986" y="35.055" size="1.778" layer="28" rot="MR0">5 közös katódos</text>
<text x="42.18" y="38.304" size="1.778" layer="28" rot="MR0">8x330</text>
<text x="52.896" y="16.074" size="1.778" layer="27" rot="R90">a</text>
<text x="47.766" y="16.074" size="1.778" layer="27" rot="R90">b</text>
<text x="37.506" y="16.074" size="1.778" layer="27" rot="R90">c</text>
<text x="45.258" y="16.074" size="1.778" layer="27" rot="R90">d</text>
<text x="32.49" y="16.131" size="1.778" layer="27" rot="R90">e</text>
<text x="24.852" y="16.074" size="1.778" layer="27" rot="R90">f</text>
<text x="29.982" y="16.188" size="1.778" layer="27" rot="R90">g</text>
<text x="40.071" y="16.074" size="1.4224" layer="27" rot="R90">dp</text>
<text x="51.414" y="11.286" size="1.778" layer="28" rot="MR180">1</text>
<text x="50.046" y="16.017" size="1.778" layer="27" rot="R90">10</text>
<text x="42.693" y="16.074" size="1.778" layer="27" rot="R90">100</text>
<text x="27.36" y="14.763" size="1.778" layer="27" rot="R90">10e</text>
<text x="35.112" y="16.131" size="1.778" layer="27" rot="R90">1e</text>
<text x="49.02" y="5.871" size="1.778" layer="27">C</text>
<wire x1="50.559" y1="6.27" x2="50.559" y2="3.192" width="0.2" layer="27"/>
<wire x1="50.502" y1="7.182" x2="50.502" y2="9.861" width="0.2" layer="27"/>
<wire x1="50.502" y1="9.861" x2="50.559" y2="9.918" width="0.2" layer="27"/>
<text x="51.3" y="9.519" size="1.778" layer="27">1</text>
<text x="22.401" y="16.131" size="1.778" layer="27" rot="R90">+5V</text>
<text x="19.836" y="14.991" size="1.778" layer="27" rot="R90">imp</text>
<text x="17.1" y="16.131" size="1.778" layer="27" rot="R90">on</text>
<text x="55.461" y="16.017" size="1.778" layer="27" rot="R90">1</text>
<text x="67.488" y="10.032" size="1.778" layer="27" rot="R90">MINICHG5</text>
<text x="69.996" y="12.483" size="1.778" layer="27" rot="R90">-USBC</text>
<text x="58.368" y="5.244" size="2.1844" layer="27">+</text>
<text x="60.135" y="2.907" size="2.1844" layer="27" rot="R90">-</text>
<text x="60.135" y="3.648" size="2.1844" layer="27" rot="R90">-</text>
<text x="64.125" y="5.415" size="2.1844" layer="27">Li-ion</text>
<text x="64.581" y="2.679" size="2.1844" layer="27">akku</text>
<text x="74.043" y="21.66" size="1.6764" layer="28" rot="MR0">1 imp/f 30-30e f/min 6 imp/f 5-4,8e f/min</text>
</plain>
<libraries>
<library name="rcl" urn="urn:adsk.eagle:library:334">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
http://www.secc.co.jp/pdf/os_e/2004/e_os_all.pdf &lt;b&gt;(SANYO)&lt;/b&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0&gt;
&lt;tr valign="top"&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;</description>
<packages>
<package name="R1206" urn="urn:adsk.eagle:footprint:23047/1" library_version="11">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;</description>
<wire x1="0.9525" y1="-0.8128" x2="-0.9652" y2="-0.8128" width="0.1524" layer="51"/>
<wire x1="0.9525" y1="0.8128" x2="-0.9652" y2="0.8128" width="0.1524" layer="51"/>
<wire x1="-2.473" y1="0.983" x2="2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="0.983" x2="2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-0.983" x2="-2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-0.983" x2="-2.473" y2="0.983" width="0.0508" layer="39"/>
<smd name="2" x="1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<smd name="1" x="-1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6891" y1="-0.8763" x2="-0.9525" y2="0.8763" layer="51"/>
<rectangle x1="0.9525" y1="-0.8763" x2="1.6891" y2="0.8763" layer="51"/>
<rectangle x1="-0.3" y1="-0.7" x2="0.3" y2="0.7" layer="35"/>
</package>
<package name="C1206" urn="urn:adsk.eagle:footprint:23125/1" library_version="11">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;</description>
<wire x1="-0.965" y1="0.787" x2="0.965" y2="0.787" width="0.1016" layer="51"/>
<wire x1="-0.965" y1="-0.787" x2="0.965" y2="-0.787" width="0.1016" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<rectangle x1="-1.7018" y1="-0.8509" x2="-0.9517" y2="0.8491" layer="51"/>
<rectangle x1="0.9517" y1="-0.8491" x2="1.7018" y2="0.8509" layer="51"/>
<rectangle x1="-0.1999" y1="-0.4001" x2="0.1999" y2="0.4001" layer="35"/>
</package>
<package name="E2,5-7" urn="urn:adsk.eagle:footprint:22847/1" library_version="11">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 2.54 mm, diameter 7 mm</description>
<wire x1="-3.048" y1="0" x2="-2.286" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="-0.381" x2="-2.667" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.762" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="3.429" width="0.1524" layer="21"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.6002"/>
<text x="3.048" y="2.032" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.048" y="-3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="0922/22" urn="urn:adsk.eagle:footprint:23084/1" library_version="11">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
type 0922, grid 22.5 mm</description>
<wire x1="11.43" y1="0" x2="10.795" y2="0" width="0.8128" layer="51"/>
<wire x1="-11.43" y1="0" x2="-10.795" y2="0" width="0.8128" layer="51"/>
<wire x1="-10.16" y1="-4.191" x2="-10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="4.572" x2="-8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="4.318" x2="-8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="-4.572" x2="-8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="-4.318" x2="-8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="4.318" x2="8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="4.318" x2="-8.636" y2="4.318" width="0.1524" layer="21"/>
<wire x1="8.636" y1="-4.318" x2="8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="-4.318" x2="-8.636" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="9.779" y1="4.572" x2="8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="9.779" y1="-4.572" x2="8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-4.191" x2="10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-4.191" x2="-9.779" y2="-4.572" width="0.1524" layer="21" curve="90"/>
<wire x1="-10.16" y1="4.191" x2="-9.779" y2="4.572" width="0.1524" layer="21" curve="-90"/>
<wire x1="9.779" y1="-4.572" x2="10.16" y2="-4.191" width="0.1524" layer="21" curve="90"/>
<wire x1="9.779" y1="4.572" x2="10.16" y2="4.191" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-11.43" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="11.43" y="0" drill="1.016" shape="octagon"/>
<text x="-10.16" y="5.1054" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.477" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-10.7188" y1="-0.4064" x2="-10.16" y2="0.4064" layer="51"/>
<rectangle x1="10.16" y1="-0.4064" x2="10.3124" y2="0.4064" layer="21"/>
<rectangle x1="-10.3124" y1="-0.4064" x2="-10.16" y2="0.4064" layer="21"/>
<rectangle x1="10.16" y1="-0.4064" x2="10.7188" y2="0.4064" layer="51"/>
</package>
<package name="RTRIM43P" urn="urn:adsk.eagle:footprint:23267/1" library_version="11">
<description>&lt;b&gt;Trimm resistor&lt;/b&gt; Spectrol&lt;p&gt;
waschfest MIL-R-22097</description>
<wire x1="-9.2" y1="2.2" x2="-9.2" y2="-2.2" width="0.254" layer="21"/>
<wire x1="-9.2" y1="-2.2" x2="8.1" y2="-2.2" width="0.254" layer="21"/>
<wire x1="8.1" y1="-2.2" x2="8.1" y2="2.2" width="0.254" layer="21"/>
<wire x1="8.1" y1="2.2" x2="-9.2" y2="2.2" width="0.254" layer="21"/>
<wire x1="8.2" y1="1.35" x2="9.65" y2="1.35" width="0.1524" layer="21"/>
<wire x1="9.65" y1="1.35" x2="9.65" y2="0.35" width="0.1524" layer="21"/>
<wire x1="9.65" y1="0.35" x2="9.15" y2="0.35" width="0.1524" layer="21"/>
<wire x1="9.15" y1="0.35" x2="9.15" y2="-0.35" width="0.1524" layer="21"/>
<wire x1="9.15" y1="-0.35" x2="9.65" y2="-0.35" width="0.1524" layer="21"/>
<wire x1="9.65" y1="-0.35" x2="9.65" y2="-1.35" width="0.1524" layer="21"/>
<wire x1="9.65" y1="-1.35" x2="8.2" y2="-1.35" width="0.1524" layer="21"/>
<pad name="1" x="-7.62" y="1.27" drill="0.9"/>
<pad name="2" x="0" y="-1.27" drill="0.9"/>
<pad name="3" x="5.08" y="1.27" drill="0.9"/>
<text x="-9.15" y="2.7" size="1.27" layer="25">&gt;NAME</text>
<text x="-6.3" y="0" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="0617/22" urn="urn:adsk.eagle:footprint:23082/1" library_version="11">
type 0617, grid 22.5 mm</description>
<wire x1="-10.287" y1="0" x2="-11.43" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.255" y1="-2.667" x2="-8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="3.048" x2="-6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="2.794" x2="-6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-3.048" x2="-6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-2.794" x2="-6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="2.794" x2="6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="2.794" x2="-6.731" y2="2.794" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.794" x2="6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.794" x2="-6.731" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="7.874" y1="3.048" x2="6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="7.874" y1="-3.048" x2="6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-2.667" x2="8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="11.43" y1="0" x2="10.287" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.255" y1="2.667" x2="-7.874" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="-8.255" y1="-2.667" x2="-7.874" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="7.874" y1="3.048" x2="8.255" y2="2.667" width="0.1524" layer="21" curve="-90"/>
<wire x1="7.874" y1="-3.048" x2="8.255" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<text x="-8.255" y="3.4544" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-10.1854" y1="-0.4064" x2="-8.255" y2="0.4064" layer="21"/>
<rectangle x1="8.255" y1="-0.4064" x2="10.1854" y2="0.4064" layer="21"/>
</package>
</packages>
<packages3d>
<package3d name="R1206" urn="urn:adsk.eagle:package:23540/2" type="model" library_version="11">
<description>RESISTOR</description>
<packageinstances>
<packageinstance name="R1206"/>
</packageinstances>
</package3d>
<package3d name="C1206" urn="urn:adsk.eagle:package:23618/2" type="model" library_version="11">
<description>CAPACITOR</description>
<packageinstances>
<packageinstance name="C1206"/>
</packageinstances>
</package3d>
<package3d name="E2,5-7" urn="urn:adsk.eagle:package:23345/1" type="box" library_version="11">
<description>ELECTROLYTIC CAPACITOR
<packageinstances>
<packageinstance name="E2,5-7"/>
</packageinstances>
</package3d>
<package3d name="0922/22" urn="urn:adsk.eagle:package:23580/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="0922/22"/>
</packageinstances>
</package3d>
<package3d name="RTRIM43P" urn="urn:adsk.eagle:package:23756/1" type="box" library_version="11">
<description>Trimm resistor Spectrol
<packageinstances>
<packageinstance name="RTRIM43P"/>
</packageinstances>
</package3d>
<package3d name="0617/22" urn="urn:adsk.eagle:package:23577/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="0617/22"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="microchip" urn="urn:adsk.eagle:library:294">
<description>&lt;b&gt;Microchip PIC Microcontrollers and other Devices&lt;/b&gt;&lt;p&gt;
Based on the following sources :
&lt;ul&gt;
&lt;li&gt;Microchip Data Book, 1993
&lt;li&gt;THE EMERGING WORLD STANDARD, 1995/1996
&lt;li&gt;Microchip, Technical Library CD-ROM, June 1998
&lt;li&gt;www.microchip.com
&lt;/ul&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="DIL18" urn="urn:adsk.eagle:footprint:20593/1" library_version="5">
<description>&lt;B&gt;Dual In Line&lt;/B&gt;&lt;p&gt;
package type P</description>
<wire x1="-11.43" y1="-0.635" x2="-11.43" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-0.635" x2="-11.43" y2="0.635" width="0.1524" layer="21" curve="180"/>
<wire x1="11.43" y1="-2.54" x2="-11.43" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="11.43" y1="-2.54" x2="11.43" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="2.54" x2="11.43" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="2.54" x2="-11.43" y2="0.635" width="0.1524" layer="21"/>
<pad name="1" x="-10.16" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="0" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="10.16" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="10.16" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="0" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="-2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="-5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="-7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="-10.16" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-11.8618" y="-2.54" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-10.16" y="-0.889" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="DIL18" urn="urn:adsk.eagle:package:20794/2" type="model" library_version="5">
<description>Dual In Line
<packageinstances>
<packageinstance name="DIL18"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="transistor-neu-to92" urn="urn:adsk.eagle:library:397">
<description>&lt;b&gt;NPN Transistors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="SOT23-BEC" urn="urn:adsk.eagle:footprint:28685/1" library_version="5">
<description>TO-236 ITT Intermetall</description>
<wire x1="1.4224" y1="0.6604" x2="1.4224" y2="-0.6604" width="0.127" layer="51"/>
<wire x1="1.4224" y1="-0.6604" x2="-1.4224" y2="-0.6604" width="0.127" layer="51"/>
<wire x1="-1.4224" y1="-0.6604" x2="-1.4224" y2="0.6604" width="0.127" layer="51"/>
<wire x1="-1.4224" y1="0.6604" x2="1.4224" y2="0.6604" width="0.127" layer="51"/>
<smd name="C" x="0" y="1.1" dx="1" dy="1.4" layer="1"/>
<smd name="E" x="0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<smd name="B" x="-0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.2286" y1="0.7112" x2="0.2286" y2="1.2954" layer="51"/>
<rectangle x1="0.7112" y1="-1.2954" x2="1.1684" y2="-0.7112" layer="51"/>
<rectangle x1="-1.1684" y1="-1.2954" x2="-0.7112" y2="-0.7112" layer="51"/>
</package>
</packages>
<packages3d>
<package3d name="SOT23-BEC" urn="urn:adsk.eagle:package:28748/2" type="model" library_version="5">
<packageinstances>
<packageinstance name="SOT23-BEC"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="solpad" urn="urn:adsk.eagle:library:364">
<description>&lt;b&gt;Solder Pads/Test Points&lt;/b&gt;&lt;p&gt;
<packages>
<package name="LSP10" urn="urn:adsk.eagle:footprint:26494/1" library_version="2">
<description>&lt;b&gt;SOLDER PAD&lt;/b&gt;&lt;p&gt;
drill 1.0 mm</description>
<wire x1="-1.27" y1="0.254" x2="-1.27" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.254" x2="1.27" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.254" x2="1.143" y2="0.254" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-0.254" x2="1.143" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-0.254" x2="-1.143" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0.254" x2="-1.143" y2="0.254" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.254" x2="0.635" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-1.143" y1="-0.254" x2="-0.635" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0.254" x2="0.635" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0.254" x2="-0.635" y2="0.254" width="0.1524" layer="51"/>
<wire x1="0.635" y1="-0.254" x2="1.143" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="0.254" x2="-0.635" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="0.254" x2="-1.143" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-0.254" x2="0.635" y2="-0.254" width="0.1524" layer="51"/>
<pad name="MP" x="0" y="0" drill="1.016" diameter="2.159" shape="octagon"/>
<text x="-1.27" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0" y="0.254" size="0.0254" layer="27">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="LSP10" urn="urn:adsk.eagle:package:26501/1" type="box" library_version="2">
<description>SOLDER PAD
<packageinstances>
<packageinstance name="LSP10"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="display-kingbright" urn="urn:adsk.eagle:library:213">
<description>&lt;b&gt;KINGBRIGHT Numeric Displays&lt;/b&gt;&lt;p&gt;
&lt;author&gt;librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="SA56-11" urn="urn:adsk.eagle:footprint:13061/1" library_version="1">
<description>&lt;b&gt;Kingbright 14.2mm (0.56 INCH) SINGLE DIGIT NUMERIC DUISPLAY&lt;/b&gt;&lt;p&gt;
Source: SA56-11EWA(Ver1189471036.pdf</description>
<wire x1="6.273" y1="-9.434" x2="6.273" y2="9.434" width="0.1524" layer="21"/>
<wire x1="-6.273" y1="9.434" x2="6.273" y2="9.434" width="0.1524" layer="21"/>
<wire x1="-6.273" y1="9.434" x2="-6.273" y2="-9.434" width="0.1524" layer="21"/>
<wire x1="6.273" y1="-9.434" x2="-6.273" y2="-9.434" width="0.1524" layer="21"/>
<wire x1="2.4372" y1="-6.5358" x2="2.107" y2="-6.866" width="0.4064" layer="51"/>
<circle x="4.572" y="-6.35" radius="0.381" width="0.762" layer="51"/>
<pad name="1" x="-5.08" y="-7.62" drill="0.8" shape="long" rot="R90"/>
<pad name="2" x="-2.54" y="-7.62" drill="0.8" shape="long" rot="R90"/>
<pad name="3" x="0" y="-7.62" drill="0.8" shape="long" rot="R90"/>
<pad name="4" x="2.54" y="-7.62" drill="0.8" shape="long" rot="R90"/>
<pad name="5" x="5.08" y="-7.62" drill="0.8" shape="long" rot="R90"/>
<pad name="6" x="5.08" y="7.62" drill="0.8" shape="long" rot="R90"/>
<pad name="7" x="2.54" y="7.62" drill="0.8" shape="long" rot="R90"/>
<pad name="8" x="0" y="7.62" drill="0.8" shape="long" rot="R90"/>
<pad name="9" x="-2.54" y="7.62" drill="0.8" shape="long" rot="R90"/>
<pad name="10" x="-5.08" y="7.62" drill="0.8" shape="long" rot="R90"/>
<text x="-6.35" y="10.16" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.35" y="-11.43" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<polygon width="0.4064" layer="51">
<vertex x="-1.425" y="6.1"/>
<vertex x="-1.25" y="7.1"/>
<vertex x="3.675" y="7.1"/>
<vertex x="3.55" y="6.1"/>
</polygon>
<vertex x="3.2565" y="1.0555"/>
<vertex x="4.3128" y="7.0544"/>
<vertex x="4.622" y="7.0626" curve="-104.72173"/>
<vertex x="5.2533" y="6.2038"/>
<vertex x="4.2" y="0.5"/>
<vertex x="3.725" y="0.5"/>
</polygon>
<vertex x="-2.95" y="1.1"/>
<vertex x="-1.9" y="7.1"/>
<vertex x="-2.175" y="7.1" curve="77.708822"/>
<vertex x="-3.075" y="6.375"/>
<vertex x="-4.1" y="0.5"/>
<vertex x="-3.525" y="0.5"/>
</polygon>
<vertex x="-3.05" y="0.025"/>
<vertex x="-2.425" y="0.65"/>
<vertex x="2.7" y="0.65"/>
<vertex x="3.075" y="0.125"/>
<vertex x="2.625" y="-0.35"/>
<vertex x="-2.675" y="-0.35"/>
</polygon>
<vertex x="1.5" y="-5.825"/>
<vertex x="1.325" y="-6.825"/>
<vertex x="-3.6" y="-6.825"/>
<vertex x="-3.475" y="-5.825"/>
</polygon>
<vertex x="-3.2565" y="-0.7305"/>
<vertex x="-4.2378" y="-6.7794"/>
<vertex x="-4.547" y="-6.7876" curve="-104.72173"/>
<vertex x="-5.1783" y="-5.9288"/>
<vertex x="-4.2" y="-0.175"/>
<vertex x="-3.725" y="-0.175"/>
</polygon>
<vertex x="2.975" y="-0.975"/>
<vertex x="1.975" y="-6.825"/>
<vertex x="2.25" y="-6.825" curve="77.708822"/>
<vertex x="3.15" y="-6.1"/>
<vertex x="4.1" y="-0.425"/>
<vertex x="3.525" y="-0.425"/>
</polygon>
</package>
</packages>
<packages3d>
<package3d name="SA56-11" urn="urn:adsk.eagle:package:13076/1" type="box" library_version="1">
<description>Kingbright 14.2mm (0.56 INCH) SINGLE DIGIT NUMERIC DUISPLAY
<packageinstances>
<packageinstance name="SA56-11"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="switch-omron" urn="urn:adsk.eagle:library:377">
<description>&lt;b&gt;Omron Switches&lt;/b&gt;&lt;p&gt;
<packages>
<package name="B3F-31XX" urn="urn:adsk.eagle:footprint:27478/1" library_version="3">
<description>&lt;b&gt;OMRON SWITCH&lt;/b&gt;</description>
<wire x1="3.683" y1="2.667" x2="3.683" y2="0" width="0.1524" layer="51"/>
<wire x1="3.683" y1="0" x2="3.683" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-3.556" x2="2.54" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="0" x2="-3.683" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="0" x2="-3.683" y2="2.667" width="0.1524" layer="51"/>
<wire x1="-3.683" y1="2.667" x2="-3.429" y2="2.667" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="2.667" x2="-3.429" y2="0" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="-3.302" x2="-0.635" y2="-3.302" width="0.1524" layer="21"/>
<wire x1="3.429" y1="0" x2="3.429" y2="2.667" width="0.1524" layer="51"/>
<wire x1="3.429" y1="2.667" x2="3.683" y2="2.667" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-3.556" x2="-2.54" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-3.81" x2="-1.27" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-3.556" x2="2.54" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-3.556" x2="-3.683" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-3.81" x2="-1.27" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-3.81" x2="1.27" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-4.191" x2="1.27" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-3.81" x2="1.27" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-3.81" x2="2.54" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-3.302" x2="-0.635" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-3.302" x2="0.635" y2="-3.302" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-2.286" x2="0.635" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-3.302" x2="0.635" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-3.302" x2="3.429" y2="-3.302" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="0" x2="-2.667" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0.254" x2="-2.667" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0.254" x2="-1.905" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="0" x2="-1.905" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="0" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-0.254" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-0.254" x2="0.762" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="0.762" y1="0" x2="0.762" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="0.762" y1="0" x2="1.778" y2="0" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0" x2="1.778" y2="0.254" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.254" x2="2.667" y2="0.254" width="0.1524" layer="21"/>
<wire x1="2.667" y1="0" x2="2.667" y2="0.254" width="0.1524" layer="21"/>
<wire x1="2.667" y1="0" x2="3.429" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="-0.889" x2="-0.762" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-0.889" x2="0.508" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="0.508" y1="-0.889" x2="1.651" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="0" y1="-1.27" x2="0" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.651" x2="0" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="0" y1="-1.651" x2="0.254" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="-0.508" x2="-3.429" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="-0.508" x2="-3.429" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.032" x2="-3.429" y2="-3.302" width="0.1524" layer="21"/>
<wire x1="3.429" y1="-2.032" x2="3.429" y2="-3.302" width="0.1524" layer="21"/>
<wire x1="3.429" y1="-0.508" x2="3.429" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="3.429" y1="-0.508" x2="3.429" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-2.2606" y="-1.2446" drill="1.016" shape="octagon"/>
<pad name="2" x="2.2606" y="-1.2446" drill="1.016" shape="octagon"/>
<pad name="3" x="-3.5052" y="1.2446" drill="1.4986" diameter="2.159"/>
<pad name="4" x="3.5052" y="1.2446" drill="1.4986" diameter="2.159"/>
<text x="-2.54" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.683" y="-5.969" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="B3F-31XX" urn="urn:adsk.eagle:package:27487/1" type="box" library_version="3">
<description>OMRON SWITCH</description>
<packageinstances>
<packageinstance name="B3F-31XX"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="linear" urn="urn:adsk.eagle:library:262">
<description>&lt;b&gt;Linear Devices&lt;/b&gt;&lt;p&gt;
Operational amplifiers,  comparators, voltage regulators, ADCs, DACs, etc.&lt;p&gt;
<packages>
<package name="SO08" urn="urn:adsk.eagle:footprint:16130/1" library_version="5">
<description>&lt;b&gt;Small Outline Package 8&lt;/b&gt;&lt;br&gt;
NS Package M08A</description>
<wire x1="2.4" y1="1.9" x2="2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.9" x2="-2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.9" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.4" x2="-2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="1.9" x2="2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<smd name="2" x="-0.635" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="7" x="-0.635" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="1" x="-1.905" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="3" x="0.635" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="4" x="1.905" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="8" x="-1.905" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="6" x="0.635" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="5" x="1.905" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<text x="-2.667" y="-1.905" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.937" y="-1.905" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.15" y1="-3.1" x2="-1.66" y2="-2" layer="51"/>
<rectangle x1="-0.88" y1="-3.1" x2="-0.39" y2="-2" layer="51"/>
<rectangle x1="0.39" y1="-3.1" x2="0.88" y2="-2" layer="51"/>
<rectangle x1="1.66" y1="-3.1" x2="2.15" y2="-2" layer="51"/>
<rectangle x1="1.66" y1="2" x2="2.15" y2="3.1" layer="51"/>
<rectangle x1="0.39" y1="2" x2="0.88" y2="3.1" layer="51"/>
<rectangle x1="-0.88" y1="2" x2="-0.39" y2="3.1" layer="51"/>
<rectangle x1="-2.15" y1="2" x2="-1.66" y2="3.1" layer="51"/>
</package>
</packages>
<packages3d>
<package3d name="SO08" urn="urn:adsk.eagle:package:16404/2" type="model" library_version="5">
<description>Small Outline Package 8
<packageinstances>
<packageinstance name="SO08"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="led" urn="urn:adsk.eagle:library:259">
<description>&lt;b&gt;LEDs&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;br&gt;
Extended by Federico Battaglin &lt;author&gt;&amp;lt;federico.rd@fdpinternational.com&amp;gt;&lt;/author&gt; with DUOLED</description>
<packages>
<package name="LED5MM" urn="urn:adsk.eagle:footprint:15655/1" library_version="5">
<description>&lt;B&gt;LED&lt;/B&gt;&lt;p&gt;
5 mm, round</description>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="1.905" width="0.2032" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="1.905" width="0.254" layer="21" curve="-286.260205"/>
<wire x1="-1.143" y1="0" x2="0" y2="1.143" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-1.143" x2="1.143" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="-1.651" y1="0" x2="0" y2="1.651" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-1.651" x2="1.651" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="-2.159" y1="0" x2="0" y2="2.159" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-2.159" x2="2.159" y2="0" width="0.1524" layer="51" curve="90"/>
<circle x="0" y="0" radius="2.54" width="0.1524" layer="21"/>
<pad name="A" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="K" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="3.175" y="0.5334" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.2004" y="-1.8034" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="LED5MM" urn="urn:adsk.eagle:package:15799/2" type="model" library_version="5">
<description>LED
<packageinstances>
<packageinstance name="LED5MM"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="jump-0r-smd" urn="urn:adsk.eagle:library:251">
<description>Soldering jumper and bridges</description>
<packages>
<package name="A0R-JMP" urn="urn:adsk.eagle:footprint:15382/1" library_version="2">
<description>&lt;b&gt;0R Jumper Variant A&lt;/b&gt;&lt;p&gt;
chip 0805</description>
<wire x1="0.635" y1="1.26" x2="0.635" y2="0.44" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="1.26" x2="-0.635" y2="0.44" width="0.1524" layer="51"/>
<smd name="1" x="0" y="1.7" dx="1.3" dy="1.5" layer="1" rot="R270"/>
<smd name="2" x="0" y="0" dx="1.3" dy="1.5" layer="1" rot="R270"/>
<smd name="3" x="0" y="-1.7" dx="1.3" dy="1.5" layer="1" rot="R270"/>
<text x="-0.762" y="2.716" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.762" y="-3.986" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.3235" y1="-0.5814" x2="0.3265" y2="0.8186" layer="51" rot="R270"/>
<rectangle x1="-0.3235" y1="0.8918" x2="0.3265" y2="2.2918" layer="51" rot="R270"/>
<rectangle x1="-0.1999" y1="-0.5001" x2="0.1999" y2="0.5001" layer="35"/>
</package>
</packages>
<packages3d>
<package3d name="A0R-JMP" urn="urn:adsk.eagle:package:15385/1" type="box" library_version="2">
<description>0R Jumper Variant A
<packageinstances>
<packageinstance name="A0R-JMP"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="con-amp-mt" urn="urn:adsk.eagle:library:123">
<description>&lt;b&gt;AMP Connectors, Type MT&lt;/b&gt;&lt;p&gt;
include  Type MT6; con-amp-mt6.lbr&lt;p&gt;
<packages>
<package name="L02P" urn="urn:adsk.eagle:footprint:5718/1" library_version="2">
<description>&lt;b&gt;AMP MT CONNECTOR&lt;/b&gt;</description>
<wire x1="2.418" y1="-4.345" x2="-2.331" y2="-4.345" width="0.1524" layer="21"/>
<wire x1="2.418" y1="6.45" x2="2.926" y2="7.339" width="0.1524" layer="21"/>
<wire x1="2.418" y1="-3.456" x2="-2.331" y2="-3.456" width="0.1524" layer="21"/>
<wire x1="2.418" y1="-3.456" x2="2.418" y2="-4.345" width="0.1524" layer="21"/>
<wire x1="2.418" y1="6.45" x2="2.418" y2="5.815" width="0.1524" layer="21"/>
<wire x1="2.418" y1="5.815" x2="2.418" y2="-3.456" width="0.1524" layer="21"/>
<wire x1="2.418" y1="5.815" x2="-2.331" y2="5.815" width="0.1524" layer="21"/>
<wire x1="-2.331" y1="-3.456" x2="-2.331" y2="-4.345" width="0.1524" layer="21"/>
<wire x1="-2.331" y1="5.815" x2="-2.331" y2="-3.456" width="0.1524" layer="21"/>
<wire x1="-4.871" y1="-5.869" x2="-4.871" y2="7.339" width="0.1524" layer="21"/>
<wire x1="-4.871" y1="7.339" x2="-2.839" y2="7.339" width="0.1524" layer="21"/>
<wire x1="-2.839" y1="7.339" x2="-2.331" y2="6.45" width="0.1524" layer="21"/>
<wire x1="-2.331" y1="6.45" x2="-2.331" y2="5.815" width="0.1524" layer="21"/>
<wire x1="4.933" y1="-5.869" x2="4.933" y2="7.339" width="0.1524" layer="21"/>
<wire x1="4.933" y1="7.339" x2="2.926" y2="7.339" width="0.1524" layer="21"/>
<wire x1="1.25" y1="3.529" x2="1.25" y2="3.021" width="0.6604" layer="21"/>
<wire x1="4.933" y1="-5.869" x2="2.241" y2="-5.869" width="0.1524" layer="21"/>
<wire x1="0.259" y1="-5.869" x2="2.241" y2="-5.869" width="0.1524" layer="51"/>
<wire x1="0.259" y1="-5.869" x2="-0.249" y2="-5.869" width="0.1524" layer="21"/>
<wire x1="-2.23" y1="-5.869" x2="-0.249" y2="-5.869" width="0.1524" layer="51"/>
<wire x1="-2.23" y1="-5.869" x2="-4.871" y2="-5.869" width="0.1524" layer="21"/>
<wire x1="-1.25" y1="3.529" x2="-1.25" y2="3.021" width="0.6604" layer="21"/>
<pad name="2" x="-1.25" y="-6.25" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="1.25" y="-6.25" drill="1.016" shape="long" rot="R90"/>
<text x="-4.7698" y="-8.79" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.195" y="-1.17" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="4.3742" y="-4.345" size="1.27" layer="21" ratio="10" rot="R90">1</text>
<text x="-2.7886" y="-4.472" size="1.27" layer="21" ratio="10" rot="R90">2</text>
<rectangle x1="0.9452" y1="-3.456" x2="1.5548" y2="3.148" layer="21"/>
<rectangle x1="0.9452" y1="-6.504" x2="1.5548" y2="-5.869" layer="51"/>
<rectangle x1="-1.544" y1="-3.456" x2="-0.9344" y2="3.148" layer="21"/>
<rectangle x1="-1.544" y1="-6.504" x2="-0.9344" y2="-5.869" layer="51"/>
</package>
</packages>
<packages3d>
<package3d name="L02P" urn="urn:adsk.eagle:package:5777/1" type="box" library_version="2">
<description>AMP MT CONNECTOR</description>
<packageinstances>
<packageinstance name="L02P"/>
</packageinstances>
</package3d>
</packages3d>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules name="default *">
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="6mil"/>
<param name="mdWirePad" value="6mil"/>
<param name="mdWireVia" value="6mil"/>
<param name="mdPadPad" value="6mil"/>
<param name="mdPadVia" value="6mil"/>
<param name="mdViaVia" value="6mil"/>
<param name="mdSmdPad" value="6mil"/>
<param name="mdSmdVia" value="6mil"/>
<param name="mdSmdSmd" value="6mil"/>
<param name="mdViaViaSameLayer" value="6mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="6mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="15mil"/>
<param name="msDrill" value="0.35mm"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="15mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="15mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="15mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="10mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="10mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="1"/>
<param name="psBottom" value="1"/>
<param name="psFirst" value="1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="20mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="checkStop" value="0"/>
<param name="checkValues" value="0"/>
<param name="checkNames" value="1"/>
<param name="checkWireStubs" value="1"/>
<param name="checkPolygonWidth" value="0"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="0.5mm"/>
<param name="AutoGrid" value="1"/>
<param name="Efforts" value="2"/>
<param name="TopRouterVariant" value="1"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="-"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="|"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="C3" library="rcl" library_urn="urn:adsk.eagle:library:334" package="E2,5-7" package3d_urn="urn:adsk.eagle:package:23345/1" value="47u" x="36.5887" y="19.7459625" smashed="yes" rot="R180">
<attribute name="NAME" x="40.3987" y="17.2059625" size="1.27" layer="25" rot="R180"/>
<attribute name="POPULARITY" value="17" x="36.5887" y="19.7459625" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="36.5887" y="19.7459625" size="1.778" layer="27" rot="R180" display="off"/>
</element>
<element name="C5" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="100n" x="39.30949375" y="6.71321875" smashed="yes" rot="MR90">
<attribute name="NAME" x="40.32549375" y="5.82421875" size="1.27" layer="26" rot="MR90"/>
<attribute name="POPULARITY" value="54" x="39.30949375" y="6.71321875" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="39.30949375" y="6.71321875" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="VALUE" x="37.52849375" y="6.04981875" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="R1" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0617/22" package3d_urn="urn:adsk.eagle:package:23577/1" value="00" x="46.9138" y="24.2824" smashed="yes" rot="MR90">
<attribute name="NAME" x="47.9298" y="23.5204" size="1.27" layer="26" rot="MR90"/>
<attribute name="POPULARITY" value="0" x="46.9138" y="24.2824" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="46.9138" y="24.2824" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="VALUE" x="44.6278" y="23.5204" size="1.27" layer="28" rot="MR90"/>
</element>
<element name="R2" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0617/22" package3d_urn="urn:adsk.eagle:package:23577/1" value="00" x="51.983640625" y="24.2316" smashed="yes" rot="MR90">
<attribute name="NAME" x="52.999640625" y="23.4696" size="1.27" layer="26" rot="MR90"/>
<attribute name="POPULARITY" value="0" x="51.983640625" y="24.2316" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="51.983640625" y="24.2316" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="VALUE" x="49.697640625" y="23.4696" size="1.27" layer="28" rot="MR90"/>
</element>
<element name="R3" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0617/22" package3d_urn="urn:adsk.eagle:package:23577/1" value="00" x="29.123640625" y="24.2062" smashed="yes" rot="MR90">
<attribute name="NAME" x="30.139640625" y="23.4442" size="1.27" layer="26" rot="MR90"/>
<attribute name="POPULARITY" value="0" x="29.123640625" y="24.2062" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="29.123640625" y="24.2062" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="VALUE" x="26.837640625" y="23.4442" size="1.27" layer="28" rot="MR90"/>
</element>
<element name="R4" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0617/22" package3d_urn="urn:adsk.eagle:package:23577/1" value="00" x="24.069040625" y="24.246840625" smashed="yes" rot="MR90">
<attribute name="NAME" x="25.085040625" y="23.484840625" size="1.27" layer="26" rot="MR90"/>
<attribute name="POPULARITY" value="0" x="24.069040625" y="24.246840625" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="24.069040625" y="24.246840625" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="VALUE" x="21.783040625" y="23.484840625" size="1.27" layer="28" rot="MR90"/>
</element>
<element name="R6" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0617/22" package3d_urn="urn:adsk.eagle:package:23577/1" value="00" x="36.763959375" y="24.292559375" smashed="yes" rot="MR90">
<attribute name="NAME" x="37.779959375" y="23.530559375" size="1.27" layer="26" rot="MR90"/>
<attribute name="POPULARITY" value="0" x="36.763959375" y="24.292559375" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="36.763959375" y="24.292559375" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="VALUE" x="34.477959375" y="23.530559375" size="1.27" layer="28" rot="MR90"/>
</element>
<element name="R8" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0617/22" package3d_urn="urn:adsk.eagle:package:23577/1" value="00" x="44.368725" y="24.3078" smashed="yes" rot="MR90">
<attribute name="NAME" x="45.384725" y="23.5458" size="1.27" layer="26" rot="MR90"/>
<attribute name="POPULARITY" value="0" x="44.368725" y="24.3078" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="44.368725" y="24.3078" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="VALUE" x="42.082725" y="23.5458" size="1.27" layer="28" rot="MR90"/>
</element>
<element name="R9" library="rcl" library_urn="urn:adsk.eagle:library:334" package="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="10k" x="42.656759375" y="6.843159375" smashed="yes" rot="MR270">
<attribute name="NAME" x="41.640759375" y="7.605159375" size="1.27" layer="26" rot="MR270"/>
<attribute name="POPULARITY" value="41" x="42.656759375" y="6.843159375" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="42.656759375" y="6.843159375" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="VALUE" x="43.857559375" y="7.589159375" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="R15" library="rcl" library_urn="urn:adsk.eagle:library:334" package="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="4,7k" x="55.890159375" y="7.254240625" smashed="yes">
<attribute name="NAME" x="50.810159375" y="9.667240625" size="1.27" layer="25" ratio="10"/>
<attribute name="POPULARITY" value="41" x="55.890159375" y="7.254240625" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="55.890159375" y="7.254240625" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="54.310759375" y="4.624240625" size="1.27" layer="27" ratio="10"/>
</element>
<element name="R16" library="rcl" library_urn="urn:adsk.eagle:library:334" package="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="330" x="44.642440625" y="31.790640625" smashed="yes" rot="MR270">
<attribute name="NAME" x="42.229440625" y="36.870640625" size="1.27" layer="26" ratio="10" rot="MR270"/>
<attribute name="POPULARITY" value="41" x="44.642440625" y="31.790640625" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="44.642440625" y="31.790640625" size="1.778" layer="28" rot="MR270" display="off"/>
</element>
<element name="R18" library="rcl" library_urn="urn:adsk.eagle:library:334" package="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="330" x="36.763440625" y="31.790640625" smashed="yes" rot="MR270">
<attribute name="NAME" x="34.350440625" y="36.870640625" size="1.27" layer="26" ratio="10" rot="MR270"/>
<attribute name="POPULARITY" value="41" x="36.763440625" y="31.790640625" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="36.763440625" y="31.790640625" size="1.778" layer="28" rot="MR270" display="off"/>
</element>
<element name="R20" library="rcl" library_urn="urn:adsk.eagle:library:334" package="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="330" x="24.063959375" y="39.481759375" smashed="yes" rot="MR90">
<attribute name="NAME" x="26.476959375" y="34.401759375" size="1.27" layer="26" ratio="10" rot="MR90"/>
<attribute name="POPULARITY" value="41" x="24.063959375" y="39.481759375" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="24.063959375" y="39.481759375" size="1.778" layer="28" rot="MR90" display="off"/>
</element>
<element name="R21" library="rcl" library_urn="urn:adsk.eagle:library:334" package="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="330" x="29.118559375" y="39.507159375" smashed="yes" rot="MR90">
<attribute name="NAME" x="31.531559375" y="34.427159375" size="1.27" layer="26" ratio="10" rot="MR90"/>
<attribute name="POPULARITY" value="41" x="29.118559375" y="39.507159375" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="29.118559375" y="39.507159375" size="1.778" layer="28" rot="MR90" display="off"/>
</element>
<element name="R22" library="rcl" library_urn="urn:adsk.eagle:library:334" package="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="330" x="51.978559375" y="39.532559375" smashed="yes" rot="MR90">
<attribute name="NAME" x="54.391559375" y="34.452559375" size="1.27" layer="26" ratio="10" rot="MR90"/>
<attribute name="POPULARITY" value="41" x="51.978559375" y="39.532559375" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="51.978559375" y="39.532559375" size="1.778" layer="28" rot="MR90" display="off"/>
</element>
<element name="R23" library="rcl" library_urn="urn:adsk.eagle:library:334" package="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="330" x="46.923959375" y="39.507159375" smashed="yes" rot="MR90">
<attribute name="NAME" x="49.336959375" y="34.427159375" size="1.27" layer="26" ratio="10" rot="MR90"/>
<attribute name="POPULARITY" value="41" x="46.923959375" y="39.507159375" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="46.923959375" y="39.507159375" size="1.778" layer="28" rot="MR90" display="off"/>
</element>
<element name="C6" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="100n" x="52.529359375" y="19.626640625" smashed="yes">
<attribute name="NAME" x="51.259359375" y="20.896640625" size="1.27" layer="25"/>
<attribute name="POPULARITY" value="54" x="52.529359375" y="19.626640625" size="2.54" layer="27" font="vector" ratio="20" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="52.529359375" y="19.626640625" size="2.54" layer="27" font="vector" ratio="20" display="off"/>
<attribute name="VALUE" x="50.518359375" y="21.190640625" size="1.27" layer="27"/>
</element>
<element name="IC4" library="microchip" library_urn="urn:adsk.eagle:library:294" package="DIL18" package3d_urn="urn:adsk.eagle:package:20794/2" value="PIC16F628P" x="39.309040625" y="6.492240625" smashed="yes" rot="R180">
<attribute name="MF" value="MICROCHIP" x="39.309040625" y="6.492240625" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="PIC16F628-04I/P" x="39.309040625" y="6.492240625" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="51.170840625" y="9.032240625" size="1.778" layer="25" ratio="10" rot="R270"/>
<attribute name="OC_FARNELL" value="9760407" x="39.309040625" y="6.492240625" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_NEWARK" value="19C7272" x="39.309040625" y="6.492240625" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="POPULARITY" value="0" x="39.309040625" y="6.492240625" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="47.067040625" y="7.043040625" size="1.778" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R5" library="rcl" library_urn="urn:adsk.eagle:library:334" package="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="330" x="29.850840625" y="31.790640625" smashed="yes" rot="MR270">
<attribute name="NAME" x="28.453840625" y="34.965640625" size="1.27" layer="26" ratio="10" rot="MR270"/>
<attribute name="POPULARITY" value="41" x="29.850840625" y="31.790640625" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="29.850840625" y="31.790640625" size="1.778" layer="28" rot="MR270" display="off"/>
</element>
<element name="R19" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0617/22" package3d_urn="urn:adsk.eagle:package:23577/1" value="00" x="31.709359375" y="24.215959375" smashed="yes" rot="MR90">
<attribute name="NAME" x="33.106359375" y="21.040959375" size="1.27" layer="26" ratio="10" rot="MR90"/>
<attribute name="POPULARITY" value="0" x="31.709359375" y="24.215959375" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="31.709359375" y="24.215959375" size="1.778" layer="28" rot="MR90" display="off"/>
</element>
<element name="T2" library="transistor-neu-to92" library_urn="urn:adsk.eagle:library:397" package="SOT23-BEC" package3d_urn="urn:adsk.eagle:package:28748/2" value="BC847" x="57.42431875" y="10.073640625" smashed="yes" rot="R90">
<attribute name="NAME" x="55.51931875" y="8.168640625" size="1.27" layer="25" rot="R90"/>
<attribute name="POPULARITY" value="0" x="57.42431875" y="10.073640625" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="61.770359375" y="13.57431875" size="1.27" layer="27" rot="R180"/>
</element>
<element name="T3" library="transistor-neu-to92" library_urn="urn:adsk.eagle:library:397" package="SOT23-BEC" package3d_urn="urn:adsk.eagle:package:28748/2" value="BC847" x="49.57011875" y="16.314121875" smashed="yes" rot="MR270">
<attribute name="NAME" x="47.66511875" y="18.219121875" size="1.27" layer="26" rot="MR270"/>
<attribute name="POPULARITY" value="0" x="49.57011875" y="16.314121875" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="VALUE" x="43.327878125" y="15.31011875" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="T4" library="transistor-neu-to92" library_urn="urn:adsk.eagle:library:397" package="SOT23-BEC" package3d_urn="urn:adsk.eagle:package:28748/2" value="BC847" x="36.794440625" y="16.677640625" smashed="yes" rot="MR270">
<attribute name="NAME" x="34.889440625" y="18.582640625" size="1.27" layer="26" rot="MR270"/>
<attribute name="POPULARITY" value="0" x="36.794440625" y="16.677640625" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="VALUE" x="30.035359375" y="15.668440625" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="T5" library="transistor-neu-to92" library_urn="urn:adsk.eagle:library:397" package="SOT23-BEC" package3d_urn="urn:adsk.eagle:package:28748/2" value="BC847" x="26.967040625" y="16.208640625" smashed="yes" rot="MR270">
<attribute name="NAME" x="25.062040625" y="18.113640625" size="1.27" layer="26" rot="MR270"/>
<attribute name="POPULARITY" value="0" x="26.967040625" y="16.208640625" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="VALUE" x="20.038359375" y="15.545040625" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="R7" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0922/22" package3d_urn="urn:adsk.eagle:package:23580/2" value="00" x="49.387759375" y="24.292559375" smashed="yes" rot="MR90">
<attribute name="NAME" x="50.784759375" y="21.117559375" size="1.27" layer="26" ratio="10" rot="MR90"/>
<attribute name="POPULARITY" value="0" x="49.387759375" y="24.292559375" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="49.387759375" y="24.292559375" size="1.778" layer="28" rot="MR90" display="off"/>
</element>
<element name="R11" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0922/22" package3d_urn="urn:adsk.eagle:package:23580/2" value="00" x="41.818559375" y="24.292559375" smashed="yes" rot="MR90">
<attribute name="NAME" x="43.215559375" y="21.117559375" size="1.27" layer="26" ratio="10" rot="MR90"/>
<attribute name="POPULARITY" value="0" x="41.818559375" y="24.292559375" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="41.818559375" y="24.292559375" size="1.778" layer="28" rot="MR90" display="off"/>
</element>
<element name="R12" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0922/22" package3d_urn="urn:adsk.eagle:package:23580/2" value="00" x="34.223959375" y="24.267159375" smashed="yes" rot="MR90">
<attribute name="NAME" x="35.620959375" y="21.092159375" size="1.27" layer="26" ratio="10" rot="MR90"/>
<attribute name="POPULARITY" value="0" x="34.223959375" y="24.267159375" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="34.223959375" y="24.267159375" size="1.778" layer="28" rot="MR90" display="off"/>
</element>
<element name="R17" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0922/22" package3d_urn="urn:adsk.eagle:package:23580/2" value="00" x="26.578559375" y="24.241759375" smashed="yes" rot="MR90">
<attribute name="NAME" x="27.975559375" y="21.066759375" size="1.27" layer="26" ratio="10" rot="MR90"/>
<attribute name="POPULARITY" value="0" x="26.578559375" y="24.241759375" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="26.578559375" y="24.241759375" size="1.778" layer="28" rot="MR90" display="off"/>
</element>
<element name="R24" library="rcl" library_urn="urn:adsk.eagle:library:334" package="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="4,7k" x="48.874678125" y="5.831840625" smashed="yes" rot="MR180">
<attribute name="NAME" x="47.604678125" y="4.561840625" size="1.27" layer="26" rot="MR180"/>
<attribute name="POPULARITY" value="41" x="48.874678125" y="5.831840625" size="1.778" layer="28" rot="MR180" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="48.874678125" y="5.831840625" size="1.778" layer="28" rot="MR180" display="off"/>
<attribute name="VALUE" x="47.490678125" y="8.594840625" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="T1" library="transistor-neu-to92" library_urn="urn:adsk.eagle:library:397" package="SOT23-BEC" package3d_urn="urn:adsk.eagle:package:28748/2" value="BC847" x="53.94451875" y="8.06704375" smashed="yes" rot="MR90">
<attribute name="NAME" x="55.84951875" y="6.16204375" size="1.27" layer="26" rot="MR90"/>
<attribute name="POPULARITY" value="0" x="47.79771875" y="3.03784375" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="VALUE" x="59.97195625" y="9.20651875" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="R25" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0922/22" package3d_urn="urn:adsk.eagle:package:23580/2" value="00" x="54.518559375" y="24.292559375" smashed="yes" rot="MR90">
<attribute name="NAME" x="55.915559375" y="21.117559375" size="1.27" layer="26" ratio="10" rot="MR90"/>
<attribute name="POPULARITY" value="0" x="48.879759375" y="24.292559375" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="48.879759375" y="24.292559375" size="1.778" layer="28" rot="MR90" display="off"/>
</element>
<element name="LSP2" library="solpad" library_urn="urn:adsk.eagle:library:364" package="LSP10" package3d_urn="urn:adsk.eagle:package:26501/1" value="LSP10" x="63.694278125" y="11.01548125" smashed="yes" rot="MR180">
<attribute name="NAME" x="62.424278125" y="9.74548125" size="1.27" layer="26" ratio="10" rot="MR180"/>
<attribute name="POPULARITY" value="52" x="63.694278125" y="11.01548125" size="0.111759375" layer="28" font="vector" rot="MR180" display="off"/>
<attribute name="VALUE" x="63.694278125" y="10.76148125" size="0.0254" layer="28" rot="MR180"/>
</element>
<element name="LSP3" library="solpad" library_urn="urn:adsk.eagle:library:364" package="LSP10" package3d_urn="urn:adsk.eagle:package:26501/1" value="LSP10" x="72.952884375" y="19.452440625" smashed="yes" rot="MR180">
<attribute name="NAME" x="71.682884375" y="18.182440625" size="1.27" layer="26" ratio="10" rot="MR180"/>
<attribute name="POPULARITY" value="52" x="72.952884375" y="19.452440625" size="0.111759375" layer="28" font="vector" rot="MR180" display="off"/>
<attribute name="VALUE" x="72.952884375" y="19.198440625" size="0.0254" layer="28" rot="MR180"/>
</element>
<element name="LSP4" library="solpad" library_urn="urn:adsk.eagle:library:364" package="LSP10" package3d_urn="urn:adsk.eagle:package:26501/1" value="LSP10" x="62.5045625" y="19.367959375" smashed="yes" rot="MR180">
<attribute name="NAME" x="61.2345625" y="18.097959375" size="1.27" layer="26" ratio="10" rot="MR180"/>
<attribute name="POPULARITY" value="52" x="62.5045625" y="19.367959375" size="0.111759375" layer="28" font="vector" rot="MR180" display="off"/>
<attribute name="VALUE" x="62.5045625" y="19.113959375" size="0.0254" layer="28" rot="MR180"/>
</element>
<element name="LSP1" library="solpad" library_urn="urn:adsk.eagle:library:364" package="LSP10" package3d_urn="urn:adsk.eagle:package:26501/1" value="LSP10" x="71.795240625" y="10.991040625" smashed="yes" rot="MR180">
<attribute name="NAME" x="70.525240625" y="9.721040625" size="1.27" layer="26" ratio="10" rot="MR180"/>
<attribute name="POPULARITY" value="52" x="71.795240625" y="10.991040625" size="0.111759375" layer="28" font="vector" rot="MR180" display="off"/>
<attribute name="VALUE" x="71.795240625" y="10.737040625" size="0.0254" layer="28" rot="MR180"/>
</element>
<element name="LED1" library="display-kingbright" library_urn="urn:adsk.eagle:library:213" package="SA56-11" package3d_urn="urn:adsk.eagle:package:13076/1" value="7-SEG_SA56-11" x="67.2084" y="35.4838" smashed="yes">
<attribute name="MF" value="" x="67.2084" y="35.4838" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="" x="67.2084" y="35.4838" size="1.778" layer="27" display="off"/>
<attribute name="NAME" x="60.8584" y="45.6438" size="1.27" layer="25" ratio="10"/>
<attribute name="OC_FARNELL" value="unknown" x="67.2084" y="35.4838" size="1.778" layer="27" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="67.2084" y="35.4838" size="1.778" layer="27" display="off"/>
</element>
<element name="LED2" library="display-kingbright" library_urn="urn:adsk.eagle:library:213" package="SA56-11" package3d_urn="urn:adsk.eagle:package:13076/1" value="7-SEG_SA56-11" x="54.5084" y="35.4838" smashed="yes">
<attribute name="MF" value="" x="54.5084" y="35.4838" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="" x="54.5084" y="35.4838" size="1.778" layer="27" display="off"/>
<attribute name="NAME" x="48.1584" y="45.6438" size="1.27" layer="25" ratio="10"/>
<attribute name="OC_FARNELL" value="unknown" x="54.5084" y="35.4838" size="1.778" layer="27" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="54.5084" y="35.4838" size="1.778" layer="27" display="off"/>
</element>
<element name="LED3" library="display-kingbright" library_urn="urn:adsk.eagle:library:213" package="SA56-11" package3d_urn="urn:adsk.eagle:package:13076/1" value="7-SEG_SA56-11" x="41.8084" y="35.4838" smashed="yes">
<attribute name="MF" value="" x="41.8084" y="35.4838" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="" x="41.8084" y="35.4838" size="1.778" layer="27" display="off"/>
<attribute name="NAME" x="35.4584" y="45.6438" size="1.27" layer="25" ratio="10"/>
<attribute name="OC_FARNELL" value="unknown" x="41.8084" y="35.4838" size="1.778" layer="27" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="41.8084" y="35.4838" size="1.778" layer="27" display="off"/>
</element>
<element name="LED4" library="display-kingbright" library_urn="urn:adsk.eagle:library:213" package="SA56-11" package3d_urn="urn:adsk.eagle:package:13076/1" value="7-SEG_SA56-11" x="29.1084" y="35.4838" smashed="yes">
<attribute name="MF" value="" x="29.1084" y="35.4838" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="" x="29.1084" y="35.4838" size="1.778" layer="27" display="off"/>
<attribute name="NAME" x="22.7584" y="45.6438" size="1.27" layer="25" ratio="10"/>
<attribute name="OC_FARNELL" value="unknown" x="29.1084" y="35.4838" size="1.778" layer="27" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="29.1084" y="35.4838" size="1.778" layer="27" display="off"/>
</element>
<element name="LED5" library="display-kingbright" library_urn="urn:adsk.eagle:library:213" package="SA56-11" package3d_urn="urn:adsk.eagle:package:13076/1" value="7-SEG_SA56-11" x="16.4084" y="35.4838" smashed="yes">
<attribute name="MF" value="" x="16.4084" y="35.4838" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="" x="16.4084" y="35.4838" size="1.778" layer="27" display="off"/>
<attribute name="NAME" x="10.0584" y="45.6438" size="1.27" layer="25" ratio="10"/>
<attribute name="OC_FARNELL" value="unknown" x="16.4084" y="35.4838" size="1.778" layer="27" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="16.4084" y="35.4838" size="1.778" layer="27" display="off"/>
</element>
<element name="R26" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0617/22" package3d_urn="urn:adsk.eagle:package:23577/1" value="00" x="39.2684" y="24.3082" smashed="yes" rot="MR90">
<attribute name="NAME" x="40.7924" y="21.2602" size="1.27" layer="26" ratio="10" rot="MR90"/>
<attribute name="POPULARITY" value="0" x="39.2684" y="24.3082" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="39.2684" y="24.3082" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="VALUE" x="38.6334" y="22.0476" size="1.27" layer="28" ratio="10" rot="MR90"/>
</element>
<element name="R28" library="rcl" library_urn="urn:adsk.eagle:library:334" package="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="330" x="39.5342" y="31.7754" smashed="yes" rot="MR270">
<attribute name="NAME" x="38.1372" y="34.9504" size="1.27" layer="26" ratio="10" rot="MR270"/>
<attribute name="POPULARITY" value="41" x="39.5342" y="31.7754" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="39.5342" y="31.7754" size="1.778" layer="28" rot="MR270" display="off"/>
</element>
<element name="S1" library="switch-omron" library_urn="urn:adsk.eagle:library:377" package="B3F-31XX" package3d_urn="urn:adsk.eagle:package:27487/1" value="menü" x="22.7076" y="4.064" smashed="yes">
<attribute name="MF" value="" x="22.7076" y="4.064" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="B3F-3100" x="22.7076" y="4.064" size="1.778" layer="27" display="off"/>
<attribute name="NAME" x="20.1676" y="6.604" size="1.27" layer="25" ratio="10"/>
<attribute name="OC_FARNELL" value="959704" x="22.7076" y="4.064" size="1.778" layer="27" display="off"/>
<attribute name="OC_NEWARK" value="36M3582" x="22.7076" y="4.064" size="1.778" layer="27" display="off"/>
<attribute name="POPULARITY" value="0" x="22.7076" y="4.064" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="13.8376" y="2.826" size="1.27" layer="27" ratio="10"/>
</element>
<element name="R29" library="rcl" library_urn="urn:adsk.eagle:library:334" package="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="10k" x="20.4724" y="9.1694" smashed="yes">
<attribute name="NAME" x="19.2024" y="10.4394" size="1.27" layer="25"/>
<attribute name="POPULARITY" value="41" x="20.4724" y="9.1694" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="20.4724" y="9.1694" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="14.7364" y="8.8944" size="1.27" layer="27"/>
</element>
<element name="IC1" library="linear" library_urn="urn:adsk.eagle:library:262" package="SO08" package3d_urn="urn:adsk.eagle:package:16404/2" value="LM393D" x="8.8392" y="17.262" smashed="yes" rot="MR180">
<attribute name="NAME" x="6.1722" y="19.167" size="1.27" layer="26" rot="MR270"/>
<attribute name="POPULARITY" value="0" x="8.8392" y="17.262" size="1.778" layer="28" rot="MR180" display="off"/>
<attribute name="VALUE" x="10.649" y="4.5328" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="R30" library="rcl" library_urn="urn:adsk.eagle:library:334" package="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="10k" x="4.2418" y="20.6756" smashed="yes" rot="MR270">
<attribute name="NAME" x="2.9718" y="21.9456" size="1.27" layer="26" rot="MR270"/>
<attribute name="POPULARITY" value="41" x="4.2418" y="20.6756" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="4.2418" y="20.6756" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="VALUE" x="6.3264" y="23.1978" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="R32" library="rcl" library_urn="urn:adsk.eagle:library:334" package="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="100" x="6.6802" y="6.3754" smashed="yes">
<attribute name="NAME" x="5.4102" y="7.6454" size="1.27" layer="25"/>
<attribute name="POPULARITY" value="41" x="6.6802" y="6.3754" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="6.6802" y="6.3754" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="5.4102" y="3.8354" size="1.27" layer="27"/>
</element>
<element name="R33" library="rcl" library_urn="urn:adsk.eagle:library:334" package="RTRIM43P" package3d_urn="urn:adsk.eagle:package:23756/1" value="10k" x="12.192" y="10.8712" smashed="yes" rot="R270">
<attribute name="NAME" x="14.892" y="20.0212" size="1.27" layer="25" rot="R270"/>
<attribute name="POPULARITY" value="4" x="12.192" y="10.8712" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEMODEL" value="X" x="12.192" y="10.8712" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIXL" value="POT" x="12.192" y="10.8712" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="12.192" y="17.1712" size="1.27" layer="27" rot="R270"/>
</element>
<element name="C2" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="100N" x="14.5542" y="21.5646" smashed="yes">
<attribute name="NAME" x="13.2842" y="22.8346" size="1.27" layer="25"/>
<attribute name="POPULARITY" value="54" x="14.5542" y="21.5646" size="1.778" layer="27" display="off"/>
<attribute name="SPICEPREFIX" value="C" x="14.5542" y="21.5646" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="7.7026" y="20.959" size="1.27" layer="27"/>
</element>
<element name="LED6" library="led" library_urn="urn:adsk.eagle:library:259" package="LED5MM" package3d_urn="urn:adsk.eagle:package:15799/2" value="szenzor" x="4.2672" y="15.6464" smashed="yes" rot="R90">
<attribute name="NAME" x="3.7338" y="18.8214" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="POPULARITY" value="93" x="4.2672" y="15.6464" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="2.0806" y="13.2608" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="LED7" library="led" library_urn="urn:adsk.eagle:library:259" package="LED5MM" package3d_urn="urn:adsk.eagle:package:15799/2" value="infra" x="4.2672" y="9.8552" smashed="yes" rot="R90">
<attribute name="NAME" x="3.7338" y="13.0302" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="POPULARITY" value="93" x="4.2672" y="9.8552" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="2.3656" y="8.2106" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="S2" library="switch-omron" library_urn="urn:adsk.eagle:library:377" package="B3F-31XX" package3d_urn="urn:adsk.eagle:package:27487/1" value="on-off" x="23.0124" y="20.8788" smashed="yes" rot="R180">
<attribute name="MF" value="" x="23.0124" y="20.8788" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="B3F-3100" x="23.0124" y="20.8788" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="25.5524" y="18.3388" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="OC_FARNELL" value="959704" x="23.0124" y="20.8788" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_NEWARK" value="36M3582" x="23.0124" y="20.8788" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="POPULARITY" value="0" x="23.0124" y="20.8788" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="31.5974" y="23.4848" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="LED8" library="led" library_urn="urn:adsk.eagle:library:259" package="LED5MM" package3d_urn="urn:adsk.eagle:package:15799/2" value="zöld" x="5.4102" y="39.5732" smashed="yes" rot="R90">
<attribute name="NAME" x="4.8768" y="42.7482" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="POPULARITY" value="93" x="5.4102" y="39.5732" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="7.0444" y="43.5796" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R31" library="rcl" library_urn="urn:adsk.eagle:library:334" package="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="470" x="8.9154" y="39.497" smashed="yes" rot="MR90">
<attribute name="NAME" x="10.1854" y="38.227" size="1.27" layer="26" rot="MR90"/>
<attribute name="POPULARITY" value="41" x="8.9154" y="39.497" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="8.9154" y="39.497" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="VALUE" x="13.814" y="39.2074" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="R34" library="rcl" library_urn="urn:adsk.eagle:library:334" package="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="470" x="2.9464" y="35.4584" smashed="yes" rot="MR90">
<attribute name="NAME" x="4.2164" y="34.1884" size="1.27" layer="26" rot="MR90"/>
<attribute name="POPULARITY" value="41" x="2.9464" y="35.4584" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="2.9464" y="35.4584" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="VALUE" x="7.4216" y="34.8344" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="LED9" library="led" library_urn="urn:adsk.eagle:library:259" package="LED5MM" package3d_urn="urn:adsk.eagle:package:15799/2" value="piros" x="5.3848" y="31.3182" smashed="yes" rot="R270">
<attribute name="NAME" x="5.9182" y="28.1432" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="POPULARITY" value="93" x="5.3848" y="31.3182" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="3.8022" y="34.4184" size="1.27" layer="27" ratio="10"/>
</element>
<element name="R36" library="rcl" library_urn="urn:adsk.eagle:library:334" package="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="47k" x="17.2466" y="15.4178" smashed="yes" rot="MR0">
<attribute name="NAME" x="18.5166" y="16.6878" size="1.27" layer="26" rot="MR0"/>
<attribute name="POPULARITY" value="41" x="17.2466" y="15.4178" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="17.2466" y="15.4178" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="VALUE" x="20.2266" y="16.9248" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="R37" library="rcl" library_urn="urn:adsk.eagle:library:334" package="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="47k" x="15.8496" y="20.1422" smashed="yes" rot="MR90">
<attribute name="NAME" x="17.1196" y="18.8722" size="1.27" layer="26" rot="MR90"/>
<attribute name="POPULARITY" value="41" x="15.8496" y="20.1422" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="15.8496" y="20.1422" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="VALUE" x="14.4728" y="20.6626" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="R35" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0922/22" package3d_urn="urn:adsk.eagle:package:23580/2" value="00" x="21.4884" y="24.2316" smashed="yes" rot="MR90">
<attribute name="NAME" x="26.5938" y="14.0716" size="1.27" layer="26" ratio="10" rot="MR90"/>
<attribute name="POPULARITY" value="0" x="21.4884" y="24.2316" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="21.4884" y="24.2316" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="VALUE" x="20.9042" y="17.7546" size="1.27" layer="28" ratio="10" rot="MR90"/>
</element>
<element name="R38" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0922/22" package3d_urn="urn:adsk.eagle:package:23580/2" value="00" x="18.923" y="24.2316" smashed="yes" rot="MR90">
<attribute name="NAME" x="24.0284" y="14.0716" size="1.27" layer="26" ratio="10" rot="MR90"/>
<attribute name="POPULARITY" value="0" x="18.923" y="24.2316" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="18.923" y="24.2316" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="VALUE" x="18.3388" y="17.7546" size="1.27" layer="28" ratio="10" rot="MR90"/>
</element>
<element name="R39" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0922/22" package3d_urn="urn:adsk.eagle:package:23580/2" value="00" x="16.383" y="24.2316" smashed="yes" rot="MR90">
<attribute name="NAME" x="21.4884" y="14.0716" size="1.27" layer="26" ratio="10" rot="MR90"/>
<attribute name="POPULARITY" value="0" x="16.383" y="24.2316" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="16.383" y="24.2316" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="VALUE" x="15.7988" y="17.7546" size="1.27" layer="28" ratio="10" rot="MR90"/>
</element>
<element name="JMP1" library="jump-0r-smd" library_urn="urn:adsk.eagle:library:251" package="A0R-JMP" package3d_urn="urn:adsk.eagle:package:15385/1" value="0R-JUMPA" x="16.225" y="8.7426" smashed="yes" rot="MR0">
<attribute name="NAME" x="16.987" y="11.4586" size="1.27" layer="26" rot="MR0"/>
<attribute name="POPULARITY" value="3" x="16.225" y="8.7426" size="1.778" layer="28" rot="MR0" display="off"/>
</element>
<element name="SV2" library="con-amp-mt" library_urn="urn:adsk.eagle:library:123" package="L02P" package3d_urn="urn:adsk.eagle:package:5777/1" value="" x="67.5894" y="5.0546" smashed="yes" rot="R270">
<attribute name="MF" value="" x="67.5894" y="5.0546" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MPN" value="" x="67.5894" y="5.0546" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="NAME" x="58.7994" y="9.8244" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="OC_FARNELL" value="unknown" x="67.5894" y="5.0546" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="67.5894" y="5.0546" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="POPULARITY" value="1" x="67.5894" y="5.0546" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="66.4194" y="8.2496" size="1.27" layer="27" ratio="10"/>
</element>
<element name="R13" library="rcl" library_urn="urn:adsk.eagle:library:334" package="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="4,7k" x="55.29" y="17.556" smashed="yes" rot="MR0">
<attribute name="NAME" x="56.56" y="18.826" size="1.27" layer="26" rot="MR0"/>
<attribute name="POPULARITY" value="41" x="55.29" y="17.556" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="55.29" y="17.556" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="VALUE" x="56.617" y="19.462" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="R14" library="rcl" library_urn="urn:adsk.eagle:library:334" package="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="4,7k" x="42.351" y="17.955" smashed="yes" rot="MR0">
<attribute name="NAME" x="43.621" y="19.225" size="1.27" layer="26" rot="MR0"/>
<attribute name="POPULARITY" value="41" x="42.351" y="17.955" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="42.351" y="17.955" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="VALUE" x="43.963" y="19.576" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="R27" library="rcl" library_urn="urn:adsk.eagle:library:334" package="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="4,7k" x="31.122" y="19.836" smashed="yes" rot="MR0">
<attribute name="NAME" x="32.392" y="21.106" size="1.27" layer="26" rot="MR0"/>
<attribute name="POPULARITY" value="41" x="31.122" y="19.836" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="SPICEPREFIX" value="R" x="31.122" y="19.836" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="VALUE" x="32.563" y="17.125" size="1.27" layer="28" rot="MR0"/>
</element>
</elements>
<signals>
<signal name="A1">
<contactref element="T2" pad="C"/>
<contactref element="R7" pad="1"/>
<wire x1="52.176678125" y1="10.073640625" x2="49.387759375" y2="12.862559375" width="0.4064" layer="1"/>
<wire x1="56.32431875" y1="10.073640625" x2="52.176678125" y2="10.073640625" width="0.4064" layer="1"/>
</signal>
<signal name="K2">
<contactref element="R15" pad="1"/>
<contactref element="IC4" pad="2"/>
<wire x1="46.929040625" y1="10.302240625" x2="46.929040625" y2="10.022840625" width="0.4064" layer="1"/>
<wire x1="46.929040625" y1="10.022840625" x2="49.697640625" y2="7.254240625" width="0.4064" layer="1"/>
<wire x1="49.697640625" y1="7.254240625" x2="54.468159375" y2="7.254240625" width="0.4064" layer="1"/>
</signal>
<signal name="K4">
<contactref element="IC4" pad="18"/>
<wire x1="49.469040625" y1="2.682240625" x2="49.469040625" y2="4.180840625" width="0.4064" layer="1"/>
<wire x1="49.469040625" y1="4.180840625" x2="45.6184" y2="8.03148125" width="0.4064" layer="1"/>
<wire x1="45.6184" y1="8.03148125" x2="45.6184" y2="17.526" width="0.4064" layer="1"/>
<via x="45.6184" y="17.526" extent="1-16" drill="0.35"/>
<contactref element="R14" pad="1"/>
<wire x1="43.773" y1="17.955" x2="45.1894" y2="17.955" width="0.4064" layer="16"/>
<wire x1="45.1894" y1="17.955" x2="45.6184" y2="17.526" width="0.4064" layer="16"/>
</signal>
<signal name="K3">
<contactref element="IC4" pad="1"/>
<wire x1="49.469040625" y1="10.302240625" x2="51.551840625" y2="10.302240625" width="0.4064" layer="16"/>
<wire x1="51.551840625" y1="10.302240625" x2="53.2638" y2="12.0142" width="0.4064" layer="16"/>
<wire x1="53.2638" y1="12.0142" x2="53.2638" y2="14.1224" width="0.4064" layer="16"/>
<wire x1="53.2638" y1="14.1224" x2="54.1782" y2="15.0368" width="0.4064" layer="16"/>
<wire x1="54.1782" y1="15.0368" x2="56.2102" y2="15.0368" width="0.4064" layer="16"/>
<contactref element="R13" pad="1"/>
<wire x1="56.2102" y1="15.0368" x2="56.712" y2="15.5386" width="0.4064" layer="16"/>
<wire x1="56.712" y1="15.5386" x2="56.712" y2="17.556" width="0.4064" layer="16"/>
</signal>
<signal name="B.PGD">
<contactref element="R1" pad="1"/>
<contactref element="IC4" pad="7"/>
<via x="42.8752" y="14.3764" extent="1-16" drill="0.35"/>
<wire x1="42.8752" y1="14.3764" x2="46.1264" y2="14.3764" width="0.4064" layer="16"/>
<wire x1="46.1264" y1="14.3764" x2="46.9392" y2="13.5636" width="0.4064" layer="16"/>
<wire x1="46.9392" y1="13.5636" x2="46.9392" y2="12.8778" width="0.4064" layer="16"/>
<wire x1="46.9392" y1="12.8778" x2="46.9138" y2="12.8524" width="0.4064" layer="16"/>
<wire x1="34.229040625" y1="10.302240625" x2="34.229040625" y2="10.886440625" width="0.4064" layer="16"/>
<wire x1="35.51935625" y1="13.37809375" x2="35.5346" y2="13.3933375" width="0.4064" layer="16"/>
<wire x1="35.5346" y1="13.3933375" x2="35.5346" y2="13.5636" width="0.4064" layer="16"/>
<wire x1="35.51935625" y1="12.17675625" x2="35.51935625" y2="13.37809375" width="0.4064" layer="16"/>
<wire x1="35.5346" y1="13.5636" x2="36.322" y2="14.351" width="0.4064" layer="16"/>
<wire x1="36.322" y1="14.351" x2="40.513" y2="14.351" width="0.4064" layer="16"/>
<wire x1="40.513" y1="14.351" x2="40.513" y2="14.3256" width="0.4064" layer="16"/>
<via x="40.513" y="14.3256" extent="1-16" drill="0.35"/>
<wire x1="40.513" y1="14.3256" x2="42.8244" y2="14.3256" width="0.4064" layer="1"/>
<wire x1="42.8244" y1="14.3256" x2="42.8752" y2="14.3764" width="0.4064" layer="1"/>
<wire x1="34.229040625" y1="10.886440625" x2="35.51935625" y2="12.17675625" width="0.4064" layer="16"/>
</signal>
<signal name="A.PGC">
<contactref element="R2" pad="1"/>
<contactref element="IC4" pad="6"/>
<wire x1="36.769040625" y1="10.302240625" x2="37.327840625" y2="10.302240625" width="0.4064" layer="16"/>
<wire x1="37.327840625" y1="10.302240625" x2="38.5572" y2="11.5316" width="0.4064" layer="16"/>
<wire x1="38.5572" y1="11.5316" x2="50.713640625" y2="11.5316" width="0.4064" layer="16"/>
<wire x1="50.713640625" y1="11.5316" x2="51.983640625" y2="12.8016" width="0.4064" layer="16"/>
</signal>
<signal name="F.PGM">
<contactref element="R4" pad="1"/>
<contactref element="IC4" pad="11"/>
<wire x1="24.069040625" y1="12.811759375" x2="24.069040625" y2="12.816840625" width="0.4064" layer="1"/>
<wire x1="26.6954" y1="10.1854" x2="24.069040625" y2="12.811759375" width="0.4064" layer="1"/>
<wire x1="31.689040625" y1="2.682240625" x2="26.6954" y2="7.67588125" width="0.4064" layer="1"/>
<wire x1="26.6954" y1="7.67588125" x2="26.6954" y2="10.1854" width="0.4064" layer="1"/>
</signal>
<signal name="C.">
<contactref element="R6" pad="1"/>
<contactref element="IC4" pad="8"/>
<wire x1="36.263484375" y1="12.862559375" x2="36.763959375" y2="12.862559375" width="0.4064" layer="1"/>
<wire x1="32.8777625" y1="11.4909625" x2="34.8918875" y2="11.4909625" width="0.4064" layer="1"/>
<wire x1="34.8918875" y1="11.4909625" x2="36.263484375" y2="12.862559375" width="0.4064" layer="1"/>
<wire x1="31.689040625" y1="10.302240625" x2="32.8777625" y2="11.4909625" width="0.4064" layer="1"/>
</signal>
<signal name="D.">
<contactref element="R8" pad="1"/>
<contactref element="IC4" pad="9"/>
<wire x1="29.149040625" y1="10.302240625" x2="30.4292" y2="11.5824" width="0.4064" layer="1"/>
<wire x1="30.4292" y1="11.5824" x2="30.4292" y2="13.7668" width="0.4064" layer="1"/>
<wire x1="30.4292" y1="13.7668" x2="32.258" y2="15.5956" width="0.4064" layer="1"/>
<wire x1="32.258" y1="15.5956" x2="43.6626" y2="15.5956" width="0.4064" layer="1"/>
<wire x1="43.6626" y1="15.5956" x2="44.368725" y2="14.889475" width="0.4064" layer="1"/>
<wire x1="44.368725" y1="14.889475" x2="44.368725" y2="12.8778" width="0.4064" layer="1"/>
</signal>
<signal name="G.">
<contactref element="R3" pad="1"/>
<contactref element="IC4" pad="12"/>
<wire x1="34.229040625" y1="2.682240625" x2="32.603440625" y2="4.307840625" width="0.4064" layer="1"/>
<wire x1="32.603440625" y1="4.307840625" x2="31.790640625" y2="4.307840625" width="0.4064" layer="1"/>
<wire x1="31.790640625" y1="4.307840625" x2="27.7114" y2="8.38708125" width="0.4064" layer="1"/>
<wire x1="27.7114" y1="11.363959375" x2="29.123640625" y2="12.7762" width="0.4064" layer="1"/>
<wire x1="27.7114" y1="8.38708125" x2="27.7114" y2="11.363959375" width="0.4064" layer="1"/>
</signal>
<signal name="BS">
<contactref element="R1" pad="2"/>
<contactref element="R23" pad="1"/>
<wire x1="46.9138" y1="35.7124" x2="46.923959375" y2="35.722559375" width="0.4064" layer="16"/>
<wire x1="46.923959375" y1="35.722559375" x2="46.923959375" y2="38.085159375" width="0.4064" layer="16"/>
</signal>
<signal name="AS">
<contactref element="R2" pad="2"/>
<contactref element="R22" pad="1"/>
<wire x1="51.983640625" y1="35.6616" x2="51.978559375" y2="35.66668125" width="0.4064" layer="16"/>
<wire x1="51.978559375" y1="35.66668125" x2="51.978559375" y2="38.110559375" width="0.4064" layer="16"/>
</signal>
<signal name="GS">
<contactref element="R3" pad="2"/>
<contactref element="R21" pad="1"/>
<wire x1="29.123640625" y1="35.6362" x2="29.123640625" y2="38.552078125" width="0.4064" layer="16"/>
<wire x1="29.123640625" y1="38.552078125" x2="29.118559375" y2="38.085159375" width="0.4064" layer="16"/>
</signal>
<signal name="FS">
<contactref element="R4" pad="2"/>
<contactref element="R20" pad="1"/>
<wire x1="24.069040625" y1="35.676840625" x2="24.063959375" y2="35.681921875" width="0.4064" layer="16"/>
<wire x1="24.063959375" y1="38.059759375" x2="24.063959375" y2="35.681921875" width="0.4064" layer="16"/>
</signal>
<signal name="CS">
<contactref element="R6" pad="2"/>
<contactref element="R18" pad="1"/>
<wire x1="36.763959375" y1="35.722559375" x2="36.763440625" y2="35.722040625" width="0.4064" layer="16"/>
<wire x1="36.763440625" y1="35.722040625" x2="36.763440625" y2="33.212640625" width="0.4064" layer="16"/>
</signal>
<signal name="DS">
<contactref element="R8" pad="2"/>
<contactref element="R16" pad="1"/>
<wire x1="44.642440625" y1="33.212640625" x2="44.642440625" y2="35.464084375" width="0.4064" layer="16"/>
<wire x1="44.642440625" y1="35.464084375" x2="44.368725" y2="35.7378" width="0.4064" layer="16"/>
</signal>
<signal name="GND">
<contactref element="T2" pad="E"/>
<contactref element="T3" pad="E"/>
<contactref element="T4" pad="E"/>
<contactref element="T5" pad="E"/>
<contactref element="T1" pad="E"/>
<polygon width="0.381" layer="16" isolate="0.4064">
<vertex x="-1.1746" y="23.7998"/>
<vertex x="75.0062" y="23.7998"/>
<vertex x="75.0062" y="-1.143"/>
<vertex x="-1.1746" y="-1.143"/>
</polygon>
<polygon width="0.381" layer="1" isolate="0.4064">
<vertex x="-2.2352" y="23.7744"/>
<vertex x="75.2856" y="23.7744"/>
<vertex x="75.2856" y="-0.9806"/>
<vertex x="-2.2352" y="-0.9806"/>
</polygon>
<contactref element="C2" pad="2"/>
<contactref element="IC1" pad="4"/>
<contactref element="C5" pad="2"/>
<contactref element="C3" pad="-"/>
<contactref element="C6" pad="2"/>
<contactref element="IC4" pad="5"/>
<contactref element="LSP3" pad="MP"/>
<contactref element="LSP2" pad="MP"/>
<contactref element="R36" pad="1"/>
<wire x1="58.52431875" y1="11.023640625" x2="58.219559375" y2="11.3284" width="0.4064" layer="1"/>
<wire x1="58.219559375" y1="11.3284" x2="54.3052" y2="11.3284" width="0.4064" layer="1"/>
<wire x1="54.0004" y1="11.0236" x2="54.3052" y2="11.3284" width="0.4064" layer="1"/>
<via x="54.0004" y="11.0236" extent="1-16" drill="0.35"/>
<wire x1="54.0004" y1="11.0236" x2="53.5432" y2="10.5664" width="0.4064" layer="16"/>
<wire x1="53.5432" y1="10.5664" x2="53.0606" y2="10.5664" width="0.4064" layer="16"/>
<wire x1="53.0606" y1="10.5664" x2="52.84451875" y2="10.35031875" width="0.4064" layer="16"/>
<wire x1="52.84451875" y1="10.35031875" x2="52.84451875" y2="9.01704375" width="0.4064" layer="16"/>
<wire x1="39.30949375" y1="8.11321875" x2="38.917875" y2="7.7216" width="0.8128" layer="16"/>
<wire x1="38.917875" y1="7.7216" x2="37.0332" y2="7.7216" width="0.8128" layer="16"/>
<via x="37.0332" y="7.7216" extent="1-16" drill="0.35"/>
<wire x1="37.0332" y1="7.7216" x2="30.6832" y2="7.7216" width="0.8128" layer="1"/>
<via x="30.6832" y="7.7216" extent="1-16" drill="0.35"/>
<wire x1="30.6832" y1="7.7216" x2="28.6766" y2="5.715" width="0.8128" layer="16"/>
<contactref element="R33" pad="3"/>
<contactref element="S1" pad="1"/>
<contactref element="SV2" pad="1"/>
</signal>
<signal name="MCLR">
<contactref element="R9" pad="1"/>
<contactref element="IC4" pad="4"/>
<wire x1="41.849040625" y1="10.302240625" x2="41.849040625" y2="9.972040625" width="0.4064" layer="16"/>
<wire x1="42.656759375" y1="9.164321875" x2="41.849040625" y2="9.972040625" width="0.4064" layer="16"/>
<wire x1="42.656759375" y1="9.164321875" x2="42.656759375" y2="8.265159375" width="0.4064" layer="16"/>
<wire x1="43.12411875" y1="7.7978" x2="42.656759375" y2="8.265159375" width="0.4064" layer="16"/>
<contactref element="S1" pad="2"/>
<wire x1="42.656759375" y1="8.265159375" x2="44.516040625" y2="8.265159375" width="0.4064" layer="16"/>
<wire x1="44.516040625" y1="8.265159375" x2="44.6024" y2="8.1788" width="0.4064" layer="16"/>
<wire x1="44.6024" y1="8.1788" x2="44.6278" y2="8.2042" width="0.4064" layer="16"/>
<via x="44.6278" y="8.2042" extent="1-16" drill="0.35"/>
<wire x1="44.6278" y1="8.2042" x2="42.9768" y2="6.5532" width="0.4064" layer="1"/>
<wire x1="42.9768" y1="6.5532" x2="30.8102" y2="6.5532" width="0.4064" layer="1"/>
<wire x1="30.8102" y1="6.5532" x2="30.81021875" y2="6.55321875" width="0.4064" layer="1"/>
<wire x1="30.81021875" y1="6.55321875" x2="30.91178125" y2="6.55321875" width="0.4064" layer="1"/>
<via x="30.91178125" y="6.55321875" extent="1-16" drill="0.35"/>
<wire x1="30.91178125" y1="6.55321875" x2="27.1779625" y2="2.8194" width="0.4064" layer="16"/>
<wire x1="27.1779625" y1="2.8194" x2="24.9682" y2="2.8194" width="0.4064" layer="16"/>
</signal>
<signal name="N$8">
<contactref element="R5" pad="1"/>
<contactref element="R19" pad="2"/>
<wire x1="31.709359375" y1="35.645959375" x2="31.424359375" y2="35.645959375" width="0.4064" layer="16"/>
<wire x1="31.424359375" y1="35.645959375" x2="29.850840625" y2="34.072440625" width="0.4064" layer="16"/>
<wire x1="29.850840625" y1="33.212640625" x2="29.850840625" y2="34.072440625" width="0.4064" layer="16"/>
</signal>
<signal name="N$13">
<contactref element="R19" pad="1"/>
<contactref element="IC4" pad="10"/>
<wire x1="30.4292" y1="11.5058" x2="31.709359375" y2="12.785959375" width="0.4064" layer="16"/>
<wire x1="31.9532" y1="5.4356" x2="29.199840625" y2="2.682240625" width="0.4064" layer="16"/>
<wire x1="29.149040625" y1="2.682240625" x2="29.199840625" y2="2.682240625" width="0.4064" layer="16"/>
<wire x1="31.9532" y1="5.4356" x2="31.9532" y2="8.255" width="0.4064" layer="16"/>
<wire x1="31.9532" y1="8.255" x2="30.4292" y2="9.779" width="0.4064" layer="16"/>
<wire x1="30.4292" y1="9.779" x2="30.4292" y2="11.5058" width="0.4064" layer="16"/>
</signal>
<signal name="N$4">
<contactref element="R15" pad="2"/>
<contactref element="T2" pad="B"/>
<wire x1="58.52431875" y1="9.123640625" x2="58.524315625" y2="8.376415625" width="0.4064" layer="1"/>
<wire x1="57.312159375" y1="7.254240625" x2="58.52431875" y2="8.4664" width="0.4064" layer="1"/>
<wire x1="58.52431875" y1="8.4664" x2="58.52431875" y2="9.123640625" width="0.4064" layer="1"/>
</signal>
<signal name="N$5">
<contactref element="T3" pad="B"/>
<wire x1="50.67011875" y1="17.264121875" x2="50.92411875" y2="17.518121875" width="0.381" layer="16"/>
<contactref element="R13" pad="2"/>
<wire x1="50.67011875" y1="17.264121875" x2="50.961996875" y2="17.556" width="0.4064" layer="16"/>
<wire x1="50.961996875" y1="17.556" x2="53.868" y2="17.556" width="0.4064" layer="16"/>
</signal>
<signal name="N$17">
<contactref element="T4" pad="B"/>
<contactref element="R14" pad="2"/>
<wire x1="37.894440625" y1="17.627640625" x2="38.2218" y2="17.955" width="0.4064" layer="16"/>
<wire x1="38.2218" y1="17.955" x2="40.929" y2="17.955" width="0.4064" layer="16"/>
</signal>
<signal name="N$18">
<contactref element="T5" pad="B"/>
<contactref element="R27" pad="2"/>
<wire x1="28.067040625" y1="17.158640625" x2="29.7" y2="18.7916" width="0.4064" layer="16"/>
<wire x1="29.7" y1="18.7916" x2="29.7" y2="19.836" width="0.4064" layer="16"/>
</signal>
<signal name="+5V">
<contactref element="R9" pad="2"/>
<contactref element="C3" pad="+"/>
<contactref element="C5" pad="1"/>
<contactref element="C6" pad="1"/>
<contactref element="IC4" pad="14"/>
<contactref element="R29" pad="1"/>
<contactref element="IC1" pad="8"/>
<contactref element="S2" pad="2"/>
<contactref element="R37" pad="2"/>
<contactref element="R35" pad="1"/>
<wire x1="27.94" y1="17.2212" x2="21.6154" y2="17.2212" width="0.8128" layer="1"/>
<wire x1="21.6154" y1="17.2212" x2="21.6154" y2="21.2598" width="0.8128" layer="1"/>
<wire x1="21.6154" y1="21.2598" x2="20.7518" y2="22.1234" width="0.8128" layer="1"/>
<wire x1="28.487" y1="17.7682" x2="27.94" y2="17.2212" width="0.8128" layer="1"/>
<wire x1="21.6154" y1="17.2212" x2="21.6154" y2="12.9286" width="0.6096" layer="1"/>
<wire x1="21.4884" y1="12.8016" x2="21.6154" y2="12.9286" width="0.6096" layer="1"/>
<wire x1="39.30949375" y1="5.31321875" x2="39.25869375" y2="5.26241875" width="0.4064" layer="16"/>
<wire x1="39.25869375" y1="5.26241875" x2="39.25869375" y2="2.7325875" width="0.4064" layer="16"/>
<wire x1="39.25869375" y1="2.7325875" x2="39.309040625" y2="2.682240625" width="0.4064" layer="16"/>
<wire x1="39.30949375" y1="5.31321875" x2="42.54881875" y2="5.31321875" width="0.4064" layer="16"/>
<wire x1="42.54881875" y1="5.31321875" x2="42.656759375" y2="5.421159375" width="0.4064" layer="16"/>
<via x="57.4294" y="13.462" extent="1-16" drill="0.35"/>
<wire x1="57.4294" y1="13.462" x2="57.4294" y2="7.112" width="0.4064" layer="16"/>
<wire x1="37.8587" y1="19.7459625" x2="37.8587" y2="19.2899625" width="0.8128" layer="1"/>
<wire x1="37.8587" y1="19.2899625" x2="36.3369375" y2="17.7682" width="0.8128" layer="1"/>
<wire x1="36.3369375" y1="17.7682" x2="28.487" y2="17.7682" width="0.8128" layer="1"/>
<wire x1="51.0862" y1="19.7459625" x2="37.8587" y2="19.7459625" width="0.6096" layer="1"/>
<wire x1="51.0862" y1="19.7459625" x2="51.129359375" y2="19.626640625" width="0.6096" layer="1"/>
<wire x1="56.726159375" y1="14.952640625" x2="52.953359375" y2="14.952640625" width="0.6096" layer="1"/>
<wire x1="52.953359375" y1="14.952640625" x2="51.129359375" y2="16.776640625" width="0.6096" layer="1"/>
<wire x1="51.129359375" y1="16.776640625" x2="51.129359375" y2="19.626640625" width="0.6096" layer="1"/>
<wire x1="56.726159375" y1="14.952640625" x2="57.4294" y2="14.2494" width="0.6096" layer="1"/>
<wire x1="57.4294" y1="14.2494" x2="57.4294" y2="13.462" width="0.6096" layer="1"/>
<wire x1="51.55404375" y1="1.23664375" x2="40.233596875" y2="1.2328125" width="0.4064" layer="16"/>
<wire x1="40.233596875" y1="1.2328125" x2="39.25869375" y2="2.207715625" width="0.4064" layer="16"/>
<wire x1="39.25869375" y1="2.207715625" x2="39.25869375" y2="2.7325875" width="0.4064" layer="16"/>
<wire x1="57.4294" y1="7.112" x2="51.55404375" y2="1.23664375" width="0.4064" layer="16"/>
<contactref element="R30" pad="2"/>
<contactref element="R32" pad="2"/>
<wire x1="4.2418" y1="19.2536" x2="4.3064" y2="19.2536" width="0.4064" layer="16"/>
<wire x1="6.9342" y1="16.6258" x2="6.9342" y2="14.662" width="0.4064" layer="16"/>
<wire x1="4.3064" y1="19.2536" x2="6.9342" y2="16.6258" width="0.4064" layer="16"/>
<contactref element="R33" pad="1"/>
<wire x1="6.9342" y1="14.662" x2="6.9342" y2="9.6774" width="0.4064" layer="16"/>
<wire x1="8.2169" y1="8.4201" x2="8.1915" y2="8.4201" width="0.4064" layer="16"/>
<wire x1="8.1915" y1="8.4201" x2="6.9342" y2="9.6774" width="0.4064" layer="16"/>
<via x="8.2169" y="8.4201" extent="1-16" drill="0.35"/>
<wire x1="8.2169" y1="8.4201" x2="8.2169" y2="8.4074" width="0.4064" layer="1"/>
<wire x1="8.1407" y1="8.4074" x2="8.1407" y2="6.4139" width="0.4064" layer="1"/>
<wire x1="8.1407" y1="6.4139" x2="8.1022" y2="6.3754" width="0.4064" layer="1"/>
<wire x1="19.0504" y1="9.1694" x2="18.2884" y2="8.4074" width="0.4064" layer="1"/>
<wire x1="18.2884" y1="8.4074" x2="8.2169" y2="8.4074" width="0.4064" layer="1"/>
<wire x1="8.2169" y1="8.4074" x2="8.1407" y2="8.4074" width="0.4064" layer="1"/>
<wire x1="21.4884" y1="12.725" x2="19.0504" y2="10.287" width="0.4064" layer="1"/>
<wire x1="19.0504" y1="9.1694" x2="19.0504" y2="10.287" width="0.4064" layer="1"/>
<wire x1="21.4884" y1="12.725" x2="21.4884" y2="12.8016" width="0.4064" layer="1"/>
<wire x1="15.8496" y1="21.5642" x2="16.4088" y2="22.1234" width="0.4064" layer="16"/>
<wire x1="16.4088" y1="22.1234" x2="20.7518" y2="22.1234" width="0.4064" layer="16"/>
<wire x1="15.8496" y1="21.5642" x2="13.462" y2="19.1766" width="0.4064" layer="16"/>
<wire x1="13.462" y1="19.1766" x2="13.462" y2="18.4912" width="0.4064" layer="16"/>
</signal>
<signal name="10">
<contactref element="R7" pad="2"/>
<contactref element="LED2" pad="3"/>
<wire x1="54.5084" y1="27.8638" x2="54.5084" y2="32.9946" width="0.4064" layer="16"/>
<wire x1="54.5084" y1="32.9946" x2="54.483" y2="32.9946" width="0.4064" layer="16"/>
<via x="54.483" y="32.9946" extent="1-16" drill="0.35"/>
<wire x1="54.483" y1="32.9946" x2="49.4284" y2="32.9946" width="0.4064" layer="1"/>
<wire x1="49.4284" y1="32.9946" x2="49.3776" y2="32.9438" width="0.4064" layer="1"/>
<via x="49.3776" y="32.9438" extent="1-16" drill="0.35"/>
<wire x1="49.3776" y1="32.9438" x2="49.3776" y2="35.7124" width="0.4064" layer="16"/>
<wire x1="49.3776" y1="35.7124" x2="49.387759375" y2="35.722559375" width="0.4064" layer="16"/>
</signal>
<signal name="N$3">
<contactref element="T3" pad="C"/>
<contactref element="R11" pad="1"/>
<wire x1="48.16531875" y1="16.009321875" x2="48.47011875" y2="16.314121875" width="0.4064" layer="16"/>
<wire x1="48.47011875" y1="16.314121875" x2="48.48808125" y2="16.332084375" width="0.4064" layer="16"/>
<wire x1="48.47011875" y1="16.314121875" x2="43.263521875" y2="16.314121875" width="0.381" layer="16"/>
<wire x1="43.263521875" y1="16.314121875" x2="41.818559375" y2="14.869159375" width="0.381" layer="16"/>
<wire x1="41.818559375" y1="12.862559375" x2="41.818559375" y2="14.869159375" width="0.381" layer="16"/>
</signal>
<signal name="N$6">
<contactref element="T4" pad="C"/>
<contactref element="R12" pad="1"/>
<wire x1="35.694440625" y1="16.677640625" x2="34.223959375" y2="15.207159375" width="0.381" layer="16"/>
<wire x1="34.223959375" y1="15.207159375" x2="34.223959375" y2="12.837159375" width="0.381" layer="16"/>
</signal>
<signal name="N$9">
<contactref element="T5" pad="C"/>
<contactref element="R17" pad="1"/>
<wire x1="26.578559375" y1="12.811759375" x2="26.578559375" y2="13.29586875" width="0.381" layer="16"/>
<wire x1="26.578559375" y1="13.29586875" x2="25.867040625" y2="14.420021875" width="0.381" layer="16"/>
<wire x1="25.867040625" y1="14.420021875" x2="25.867040625" y2="16.208640625" width="0.381" layer="16"/>
</signal>
<signal name="K5">
<contactref element="IC4" pad="17"/>
<wire x1="32.97935625" y1="6.62145625" x2="34.39270625" y2="5.20810625" width="0.4064" layer="16"/>
<wire x1="46.929040625" y1="2.682240625" x2="44.58208125" y2="5.0292" width="0.4064" layer="1"/>
<wire x1="44.58208125" y1="5.0292" x2="34.5716125" y2="5.0292" width="0.4064" layer="1"/>
<wire x1="34.39270625" y1="5.20810625" x2="34.5716125" y2="5.0292" width="0.4064" layer="1"/>
<via x="34.39270625" y="5.20810625" extent="1-16" drill="0.35"/>
<contactref element="R27" pad="1"/>
<wire x1="32.544" y1="19.836" x2="32.97935625" y2="19.40064375" width="0.4064" layer="16"/>
<wire x1="32.97935625" y1="19.40064375" x2="32.97935625" y2="6.62145625" width="0.4064" layer="16"/>
</signal>
<signal name="N$14">
<contactref element="R24" pad="2"/>
<contactref element="T1" pad="B"/>
<wire x1="50.296678125" y1="5.831840625" x2="51.559315625" y2="5.831840625" width="0.4064" layer="16"/>
<wire x1="51.559315625" y1="5.831840625" x2="52.84451875" y2="7.11704375" width="0.4064" layer="16"/>
</signal>
<signal name="N$15">
<contactref element="T1" pad="C"/>
<contactref element="R25" pad="1"/>
<wire x1="55.57791875" y1="11.8032" x2="55.57791875" y2="8.60044375" width="0.4064" layer="16"/>
<wire x1="55.04451875" y1="8.06704375" x2="55.57791875" y2="8.60044375" width="0.4064" layer="16"/>
<wire x1="55.57791875" y1="11.8032" x2="54.518559375" y2="12.862559375" width="0.4064" layer="16"/>
</signal>
<signal name="10000">
<contactref element="R17" pad="2"/>
<contactref element="LED5" pad="3"/>
<wire x1="16.4084" y1="27.8638" x2="16.4084" y2="31.369" width="0.4064" layer="16"/>
<wire x1="18.1102" y1="33.0708" x2="16.4084" y2="31.369" width="0.4064" layer="16"/>
<wire x1="18.1102" y1="33.0708" x2="18.1102" y2="33.0962" width="0.4064" layer="16"/>
<via x="18.1102" y="33.0962" extent="1-16" drill="0.35"/>
<wire x1="26.5176" y1="33.1244" x2="26.4894" y2="33.0962" width="0.4064" layer="1"/>
<wire x1="26.4894" y1="33.0962" x2="18.1102" y2="33.0962" width="0.4064" layer="1"/>
<via x="26.5176" y="33.1244" extent="1-16" drill="0.35"/>
<wire x1="26.5176" y1="33.1244" x2="26.5176" y2="35.6108" width="0.4064" layer="16"/>
<wire x1="26.5176" y1="35.6108" x2="26.578559375" y2="35.671759375" width="0.4064" layer="16"/>
</signal>
<signal name="1000">
<contactref element="R12" pad="2"/>
<contactref element="LED4" pad="3"/>
<wire x1="27.9114" y1="33.0962" x2="27.9114" y2="29.0608" width="0.4064" layer="16"/>
<wire x1="29.1084" y1="27.8638" x2="27.9114" y2="29.0608" width="0.4064" layer="16"/>
<via x="27.9114" y="33.0962" extent="1-16" drill="0.35"/>
<wire x1="27.9114" y1="33.0962" x2="31.6582" y2="33.0962" width="0.4064" layer="1"/>
<wire x1="31.6582" y1="33.0962" x2="31.6582" y2="33.0646" width="0.4064" layer="1"/>
<via x="31.6582" y="33.0646" extent="1-16" drill="0.35"/>
<wire x1="34.223959375" y1="35.697159375" x2="31.6582" y2="33.1314" width="0.4064" layer="16"/>
<wire x1="31.6582" y1="33.0646" x2="31.6582" y2="33.1314" width="0.4064" layer="16"/>
</signal>
<signal name="100">
<contactref element="R11" pad="2"/>
<contactref element="LED3" pad="3"/>
<wire x1="42.939" y1="34.60211875" x2="42.939" y2="28.9944" width="0.4064" layer="16"/>
<wire x1="41.8084" y1="27.8638" x2="42.939" y2="28.9944" width="0.4064" layer="16"/>
<wire x1="41.818559375" y1="35.722559375" x2="42.939" y2="34.60211875" width="0.4064" layer="16"/>
</signal>
<signal name="1">
<contactref element="LED1" pad="3"/>
<contactref element="R25" pad="2"/>
<wire x1="67.2084" y1="27.8638" x2="67.2084" y2="28.3198" width="0.4064" layer="16"/>
<wire x1="67.2084" y1="28.3198" x2="59.805640625" y2="35.722559375" width="0.4064" layer="16"/>
<wire x1="59.805640625" y1="35.722559375" x2="54.518559375" y2="35.722559375" width="0.4064" layer="16"/>
</signal>
<signal name="K1">
<contactref element="IC4" pad="15"/>
<contactref element="R24" pad="1"/>
<wire x1="41.849040625" y1="2.682240625" x2="42.484040625" y2="2.682240625" width="0.4064" layer="16"/>
<wire x1="45.633640625" y1="5.831840625" x2="47.452678125" y2="5.831840625" width="0.4064" layer="16"/>
<wire x1="42.484040625" y1="2.682240625" x2="45.633640625" y2="5.831840625" width="0.4064" layer="16"/>
</signal>
<signal name="A">
<contactref element="LED5" pad="7"/>
<contactref element="LED4" pad="7"/>
<contactref element="LED3" pad="7"/>
<contactref element="LED2" pad="7"/>
<contactref element="LED1" pad="7"/>
<contactref element="R22" pad="2"/>
<wire x1="69.7484" y1="43.1038" x2="65.532" y2="38.8874" width="0.4064" layer="1"/>
<wire x1="65.532" y1="38.8874" x2="57.023" y2="38.8874" width="0.4064" layer="1"/>
<wire x1="57.023" y1="38.8874" x2="43.0276" y2="38.8874" width="0.4064" layer="1"/>
<wire x1="43.0276" y1="38.8874" x2="31.5722" y2="38.8874" width="0.4064" layer="1"/>
<wire x1="31.5722" y1="38.8874" x2="18.8722" y2="38.8874" width="0.4064" layer="1"/>
<wire x1="18.9484" y1="43.1038" x2="18.9484" y2="38.9128" width="0.4064" layer="16"/>
<wire x1="18.9484" y1="38.9128" x2="18.8722" y2="38.8366" width="0.4064" layer="16"/>
<wire x1="18.8722" y1="38.8366" x2="18.8722" y2="38.8874" width="0.4064" layer="16"/>
<via x="18.8722" y="38.8874" extent="1-16" drill="0.35"/>
<wire x1="31.6484" y1="43.1038" x2="31.6484" y2="38.9636" width="0.4064" layer="16"/>
<via x="31.5722" y="38.8874" extent="1-16" drill="0.35"/>
<wire x1="31.6484" y1="38.9636" x2="31.5722" y2="38.8874" width="0.4064" layer="16"/>
<wire x1="44.3484" y1="43.1038" x2="43.053" y2="41.8084" width="0.4064" layer="16"/>
<wire x1="43.0276" y1="38.8874" x2="43.053" y2="38.9128" width="0.4064" layer="16"/>
<wire x1="43.053" y1="41.8084" x2="43.053" y2="38.9128" width="0.4064" layer="16"/>
<via x="43.0276" y="38.8874" extent="1-16" drill="0.35"/>
<wire x1="57.0484" y1="43.1038" x2="57.0484" y2="41.2595125" width="0.4064" layer="16"/>
<wire x1="57.0484" y1="41.0384" x2="57.0484" y2="38.9128" width="0.4064" layer="16"/>
<wire x1="57.0484" y1="38.9128" x2="57.1246" y2="38.8366" width="0.4064" layer="16"/>
<wire x1="57.1246" y1="38.8366" x2="57.0738" y2="38.8366" width="0.4064" layer="16"/>
<wire x1="57.0738" y1="38.8366" x2="57.023" y2="38.8874" width="0.4064" layer="16"/>
<via x="57.023" y="38.8874" extent="1-16" drill="0.35"/>
<wire x1="56.90560625" y1="41.011559375" x2="52.035559375" y2="41.011559375" width="0.4064" layer="16"/>
<wire x1="51.978559375" y1="40.954559375" x2="52.035559375" y2="41.011559375" width="0.4064" layer="16"/>
<wire x1="57.0484" y1="41.2595125" x2="57.034240625" y2="41.109559375" width="0.4064" layer="16"/>
<wire x1="57.034240625" y1="41.109559375" x2="56.933596875" y2="41.008915625" width="0.4064" layer="16"/>
<wire x1="56.933596875" y1="41.008915625" x2="56.90560625" y2="41.011559375" width="0.4064" layer="16"/>
<wire x1="57.0484" y1="41.0384" x2="57.0484" y2="43.1038" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="B">
<contactref element="LED5" pad="6"/>
<contactref element="LED4" pad="6"/>
<contactref element="LED3" pad="6"/>
<contactref element="LED2" pad="6"/>
<contactref element="LED1" pad="6"/>
<contactref element="R23" pad="2"/>
<wire x1="72.2884" y1="43.1038" x2="66.8782" y2="37.6936" width="0.4064" layer="1"/>
<wire x1="66.8782" y1="37.6936" x2="59.6392" y2="37.6936" width="0.4064" layer="1"/>
<wire x1="59.6392" y1="37.6936" x2="45.1104" y2="37.6936" width="0.4064" layer="1"/>
<wire x1="45.1104" y1="37.6936" x2="34.163" y2="37.6936" width="0.4064" layer="1"/>
<wire x1="34.163" y1="37.6936" x2="22.0472" y2="37.6936" width="0.4064" layer="1"/>
<wire x1="22.0472" y1="37.6936" x2="21.336" y2="37.6936" width="0.4064" layer="1"/>
<wire x1="20.2438" y1="41.8592" x2="20.2438" y2="38.989" width="0.4064" layer="16"/>
<wire x1="20.2438" y1="38.989" x2="21.4884" y2="37.7444" width="0.4064" layer="16"/>
<wire x1="21.4884" y1="43.1038" x2="20.2438" y2="41.8592" width="0.4064" layer="16"/>
<via x="21.4884" y="37.7444" extent="1-16" drill="0.35"/>
<wire x1="21.4884" y1="37.7444" x2="21.9964" y2="37.7444" width="0.4064" layer="1"/>
<wire x1="21.9964" y1="37.7444" x2="22.0472" y2="37.6936" width="0.4064" layer="1"/>
<wire x1="34.1884" y1="43.1038" x2="34.1884" y2="37.719" width="0.4064" layer="16"/>
<wire x1="34.1884" y1="37.719" x2="34.163" y2="37.6936" width="0.4064" layer="16"/>
<via x="34.163" y="37.6936" extent="1-16" drill="0.35"/>
<wire x1="45.0088" y1="41.2242" x2="45.0088" y2="40.4114" width="0.4064" layer="16"/>
<wire x1="45.0342" y1="40.4114" x2="45.0342" y2="37.6174" width="0.4064" layer="16"/>
<wire x1="45.0342" y1="37.6174" x2="45.0088" y2="37.592" width="0.4064" layer="16"/>
<wire x1="46.8884" y1="43.1038" x2="45.0088" y2="41.2242" width="0.4064" layer="16"/>
<via x="45.0088" y="37.592" extent="1-16" drill="0.35"/>
<wire x1="45.0088" y1="37.592" x2="45.1104" y2="37.6936" width="0.4064" layer="1"/>
<wire x1="59.5884" y1="43.1038" x2="59.6138" y2="43.0784" width="0.4064" layer="16"/>
<wire x1="59.6138" y1="43.0784" x2="59.6138" y2="37.6682" width="0.4064" layer="16"/>
<wire x1="59.6138" y1="37.6682" x2="59.6392" y2="37.6936" width="0.4064" layer="16"/>
<via x="59.6392" y="37.6936" extent="1-16" drill="0.35"/>
<wire x1="46.923959375" y1="40.929159375" x2="46.8782" y2="40.4114" width="0.4064" layer="16"/>
<wire x1="46.8782" y1="40.4114" x2="45.0342" y2="40.4114" width="0.4064" layer="16"/>
<wire x1="45.0342" y1="40.4114" x2="45.0088" y2="40.4114" width="0.4064" layer="16"/>
</signal>
<signal name="C">
<contactref element="LED5" pad="4"/>
<contactref element="LED4" pad="4"/>
<contactref element="LED3" pad="4"/>
<contactref element="LED2" pad="4"/>
<contactref element="LED1" pad="4"/>
<contactref element="R18" pad="2"/>
<wire x1="69.7484" y1="27.8638" x2="65.6336" y2="31.9786" width="0.4064" layer="1"/>
<wire x1="65.6336" y1="31.9786" x2="57.023" y2="31.9786" width="0.4064" layer="1"/>
<wire x1="57.023" y1="31.9786" x2="56.966" y2="32.0356" width="0.4064" layer="1"/>
<wire x1="56.966" y1="32.0356" x2="47.2874" y2="32.0356" width="0.4064" layer="1"/>
<wire x1="47.2874" y1="32.0356" x2="47.2558" y2="32.004" width="0.4064" layer="1"/>
<wire x1="47.2558" y1="32.004" x2="34.7044" y2="32.004" width="0.4064" layer="1"/>
<wire x1="34.7044" y1="32.004" x2="32.3992" y2="32.004" width="0.4064" layer="1"/>
<wire x1="32.3992" y1="32.004" x2="19.05" y2="32.004" width="0.4064" layer="1"/>
<wire x1="19.05" y1="32.004" x2="19.0246" y2="31.9786" width="0.4064" layer="1"/>
<wire x1="18.9484" y1="27.8638" x2="18.9484" y2="31.9786" width="0.4064" layer="16"/>
<wire x1="18.9484" y1="31.9786" x2="19.0246" y2="31.9786" width="0.4064" layer="16"/>
<via x="19.0246" y="31.9786" extent="1-16" drill="0.35"/>
<wire x1="31.6484" y1="27.8638" x2="32.6842" y2="28.8996" width="0.4064" layer="16"/>
<wire x1="32.6842" y1="31.719" x2="32.3992" y2="32.004" width="0.4064" layer="16"/>
<wire x1="32.6842" y1="31.719" x2="32.6842" y2="28.8996" width="0.4064" layer="16"/>
<via x="32.3992" y="32.004" extent="1-16" drill="0.35"/>
<wire x1="47.2812" y1="30.3016" x2="44.8434" y2="27.8638" width="0.4064" layer="16"/>
<wire x1="44.3484" y1="27.8638" x2="44.8434" y2="27.8638" width="0.4064" layer="16"/>
<wire x1="47.2812" y1="30.3016" x2="47.2812" y2="32.0356" width="0.4064" layer="16"/>
<wire x1="47.2812" y1="32.0356" x2="47.2874" y2="32.0356" width="0.4064" layer="16"/>
<via x="47.2874" y="32.0356" extent="1-16" drill="0.35"/>
<wire x1="57.0484" y1="27.8638" x2="57.0484" y2="31.9024" width="0.4064" layer="16"/>
<wire x1="57.0484" y1="31.9024" x2="57.0738" y2="31.9278" width="0.4064" layer="16"/>
<wire x1="57.0738" y1="31.9278" x2="57.0738" y2="31.9786" width="0.4064" layer="16"/>
<wire x1="57.0738" y1="31.9786" x2="57.023" y2="31.9786" width="0.4064" layer="16"/>
<via x="57.023" y="31.9786" extent="1-16" drill="0.35"/>
<wire x1="36.763440625" y1="30.368640625" x2="35.74434375" y2="30.70205625" width="0.4064" layer="16"/>
<wire x1="35.74434375" y1="30.70205625" x2="34.7044" y2="31.742" width="0.4064" layer="16"/>
<wire x1="34.7044" y1="32.004" x2="34.7044" y2="31.742" width="0.4064" layer="16"/>
<via x="34.7044" y="32.004" extent="1-16" drill="0.35"/>
</signal>
<signal name="D">
<contactref element="LED5" pad="2"/>
<contactref element="LED4" pad="2"/>
<contactref element="LED3" pad="2"/>
<contactref element="LED2" pad="2"/>
<contactref element="LED1" pad="2"/>
<contactref element="R16" pad="2"/>
<wire x1="64.6684" y1="27.8638" x2="61.7982" y2="30.734" width="0.4064" layer="1"/>
<wire x1="61.7982" y1="30.734" x2="51.9176" y2="30.734" width="0.4064" layer="1"/>
<wire x1="51.9176" y1="30.734" x2="46.2336" y2="30.734" width="0.4064" layer="1"/>
<wire x1="46.2386" y1="30.7594" x2="41.8338" y2="30.7594" width="0.4064" layer="1"/>
<wire x1="41.8338" y1="30.7594" x2="26.6192" y2="30.7594" width="0.4064" layer="1"/>
<wire x1="26.5938" y1="30.734" x2="13.8938" y2="30.734" width="0.4064" layer="1"/>
<wire x1="13.8684" y1="27.8638" x2="13.8684" y2="30.7848" width="0.4064" layer="16"/>
<wire x1="13.8684" y1="30.7848" x2="13.8938" y2="30.8102" width="0.4064" layer="16"/>
<wire x1="13.8938" y1="30.8102" x2="13.8938" y2="30.734" width="0.4064" layer="16"/>
<via x="13.8938" y="30.734" extent="1-16" drill="0.35"/>
<wire x1="26.5684" y1="27.8638" x2="26.5684" y2="30.7086" width="0.4064" layer="16"/>
<via x="26.5684" y="30.7086" extent="1-16" drill="0.35"/>
<wire x1="26.5684" y1="30.7086" x2="26.5938" y2="30.734" width="0.4064" layer="1"/>
<wire x1="26.5938" y1="30.734" x2="26.6192" y2="30.7594" width="0.4064" layer="1"/>
<wire x1="41.8338" y1="30.0302" x2="39.6674" y2="27.8638" width="0.4064" layer="16"/>
<wire x1="39.2684" y1="27.8638" x2="39.6674" y2="27.8638" width="0.4064" layer="16"/>
<wire x1="41.8338" y1="30.0302" x2="41.8338" y2="30.7594" width="0.4064" layer="16"/>
<wire x1="41.8338" y1="30.8356" x2="41.8338" y2="30.7594" width="0.4064" layer="16"/>
<via x="41.8338" y="30.7594" extent="1-16" drill="0.35"/>
<wire x1="51.9684" y1="27.8638" x2="51.9684" y2="30.7594" width="0.4064" layer="16"/>
<wire x1="51.9684" y1="30.7594" x2="51.943" y2="30.7594" width="0.4064" layer="16"/>
<wire x1="51.943" y1="30.7594" x2="51.9176" y2="30.734" width="0.4064" layer="16"/>
<via x="51.9176" y="30.734" extent="1-16" drill="0.35"/>
<wire x1="44.642440625" y1="30.368640625" x2="45.868240625" y2="30.368640625" width="0.4064" layer="16"/>
<wire x1="46.2336" y1="30.734" x2="45.868240625" y2="30.368640625" width="0.4064" layer="16"/>
<via x="46.2336" y="30.734" extent="1-16" drill="0.35"/>
<wire x1="46.2386" y1="30.7594" x2="46.2336" y2="30.734" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="E">
<contactref element="LED5" pad="1"/>
<contactref element="LED4" pad="1"/>
<contactref element="LED3" pad="1"/>
<contactref element="LED2" pad="1"/>
<contactref element="LED1" pad="1"/>
<contactref element="R5" pad="2"/>
<wire x1="11.3284" y1="27.8638" x2="13.1064" y2="29.6418" width="0.4064" layer="1"/>
<wire x1="13.1064" y1="29.6418" x2="24.0792" y2="29.6418" width="0.4064" layer="1"/>
<wire x1="24.0792" y1="29.6418" x2="31.6738" y2="29.6418" width="0.4064" layer="1"/>
<wire x1="31.6738" y1="29.6418" x2="36.6522" y2="29.6418" width="0.4064" layer="1"/>
<wire x1="36.6522" y1="29.6418" x2="49.53" y2="29.6418" width="0.4064" layer="1"/>
<wire x1="49.53" y1="29.6418" x2="60.452" y2="29.6418" width="0.4064" layer="1"/>
<wire x1="60.452" y1="29.6418" x2="62.1284" y2="27.9654" width="0.4064" layer="1"/>
<wire x1="62.1284" y1="27.9654" x2="62.1284" y2="27.8638" width="0.4064" layer="1"/>
<wire x1="24.0284" y1="27.8638" x2="24.0284" y2="29.591" width="0.4064" layer="1"/>
<wire x1="24.0284" y1="29.591" x2="24.0792" y2="29.6418" width="0.4064" layer="1"/>
<wire x1="36.7284" y1="27.8638" x2="36.7284" y2="29.5656" width="0.4064" layer="1"/>
<wire x1="36.7284" y1="29.5656" x2="36.6522" y2="29.6418" width="0.4064" layer="1"/>
<wire x1="49.4284" y1="27.8638" x2="49.4284" y2="29.5402" width="0.4064" layer="1"/>
<wire x1="49.4284" y1="29.5402" x2="49.53" y2="29.6418" width="0.4064" layer="1"/>
<wire x1="29.850840625" y1="30.368640625" x2="30.668275" y2="29.55120625" width="0.4064" layer="16"/>
<wire x1="30.7048" y1="29.54498125" x2="30.668275" y2="29.55120625" width="0.4064" layer="16"/>
<wire x1="31.57698125" y1="29.54498125" x2="30.7048" y2="29.54498125" width="0.4064" layer="16"/>
<wire x1="31.57698125" y1="29.54498125" x2="31.6738" y2="29.6418" width="0.4064" layer="16"/>
<via x="31.6738" y="29.6418" extent="1-16" drill="0.35"/>
</signal>
<signal name="F">
<contactref element="LED5" pad="9"/>
<contactref element="LED4" pad="9"/>
<contactref element="LED3" pad="9"/>
<contactref element="LED2" pad="9"/>
<contactref element="LED1" pad="9"/>
<contactref element="R20" pad="2"/>
<wire x1="64.6684" y1="42.799" x2="64.4652" y2="42.799" width="0.4064" layer="16"/>
<wire x1="13.8684" y1="43.1038" x2="15.5448" y2="41.4274" width="0.4064" layer="1"/>
<wire x1="15.5448" y1="41.4274" x2="26.4668" y2="41.4274" width="0.4064" layer="1"/>
<wire x1="26.4668" y1="41.4274" x2="39.2938" y2="41.4274" width="0.4064" layer="1"/>
<wire x1="39.2938" y1="41.4274" x2="51.9176" y2="41.4274" width="0.4064" layer="1"/>
<wire x1="51.9176" y1="41.4274" x2="63.8556" y2="41.4274" width="0.4064" layer="1"/>
<wire x1="63.8556" y1="41.4274" x2="64.6684" y2="42.2402" width="0.4064" layer="1"/>
<wire x1="64.6684" y1="42.2402" x2="64.6684" y2="43.1038" width="0.4064" layer="1"/>
<wire x1="26.5684" y1="43.1038" x2="26.5684" y2="41.529" width="0.4064" layer="1"/>
<wire x1="26.5684" y1="41.529" x2="26.4668" y2="41.4274" width="0.4064" layer="1"/>
<wire x1="24.063959375" y1="40.903759375" x2="24.063959375" y2="40.599359375" width="0.4064" layer="16"/>
<wire x1="24.063959375" y1="40.599359375" x2="26.5684" y2="43.1038" width="0.4064" layer="16"/>
<wire x1="39.2684" y1="43.1038" x2="39.2938" y2="43.0784" width="0.4064" layer="1"/>
<wire x1="39.2938" y1="43.0784" x2="39.2938" y2="41.4274" width="0.4064" layer="1"/>
<wire x1="51.9684" y1="43.1038" x2="51.9684" y2="41.4782" width="0.4064" layer="1"/>
<wire x1="51.9684" y1="41.4782" x2="51.9176" y2="41.4274" width="0.4064" layer="1"/>
<wire x1="64.6684" y1="43.1038" x2="64.6684" y2="42.799" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="G">
<contactref element="LED5" pad="10"/>
<contactref element="LED4" pad="10"/>
<contactref element="LED3" pad="10"/>
<contactref element="LED2" pad="10"/>
<contactref element="LED1" pad="10"/>
<contactref element="R21" pad="2"/>
<wire x1="62.1284" y1="43.053" x2="62.1284" y2="43.1038" width="0.4064" layer="16"/>
<wire x1="11.3284" y1="43.1038" x2="14.1478" y2="40.2844" width="0.4064" layer="1"/>
<wire x1="21.463" y1="40.2844" x2="21.5138" y2="40.2336" width="0.4064" layer="1"/>
<wire x1="21.463" y1="40.2844" x2="14.1478" y2="40.2844" width="0.4064" layer="1"/>
<wire x1="36.7284" y1="40.2336" x2="36.7538" y2="40.259" width="0.4064" layer="1"/>
<wire x1="36.7284" y1="40.2336" x2="26.543" y2="40.2336" width="0.4064" layer="1"/>
<wire x1="26.543" y1="40.2336" x2="21.5138" y2="40.2336" width="0.4064" layer="1"/>
<wire x1="36.7538" y1="40.259" x2="49.4284" y2="40.259" width="0.4064" layer="1"/>
<wire x1="49.4284" y1="40.259" x2="61.976" y2="40.259" width="0.4064" layer="1"/>
<wire x1="61.976" y1="40.259" x2="62.1792" y2="40.259" width="0.4064" layer="1"/>
<wire x1="24.0284" y1="43.1038" x2="23.5724" y2="43.1038" width="0.4064" layer="16"/>
<wire x1="23.5724" y1="43.1038" x2="21.494475" y2="41.025875" width="0.4064" layer="16"/>
<wire x1="21.494475" y1="41.025875" x2="21.494475" y2="40.303725" width="0.4064" layer="16"/>
<wire x1="21.5138" y1="40.2844" x2="21.5138" y2="40.2336" width="0.4064" layer="16"/>
<wire x1="21.5138" y1="40.2844" x2="21.494475" y2="40.303725" width="0.4064" layer="16"/>
<via x="21.5138" y="40.2336" extent="1-16" drill="0.35"/>
<wire x1="36.7284" y1="43.1038" x2="36.7284" y2="40.3606" width="0.4064" layer="16"/>
<wire x1="36.7284" y1="40.3606" x2="36.8046" y2="40.2844" width="0.4064" layer="16"/>
<wire x1="36.8046" y1="40.2844" x2="36.7792" y2="40.259" width="0.4064" layer="16"/>
<wire x1="36.7792" y1="40.259" x2="36.7538" y2="40.259" width="0.4064" layer="16"/>
<via x="36.7538" y="40.259" extent="1-16" drill="0.35"/>
<via x="49.4284" y="40.259" extent="1-16" drill="0.35"/>
<wire x1="49.4284" y1="43.1038" x2="49.4284" y2="40.259" width="0.4064" layer="16"/>
<wire x1="62.1284" y1="43.1038" x2="62.1284" y2="40.3606" width="0.4064" layer="16"/>
<wire x1="62.0268" y1="40.259" x2="61.976" y2="40.259" width="0.4064" layer="16"/>
<via x="61.976" y="40.259" extent="1-16" drill="0.35"/>
<wire x1="62.1284" y1="40.3606" x2="62.0268" y2="40.259" width="0.4064" layer="16"/>
<wire x1="29.118559375" y1="40.929159375" x2="26.838365625" y2="40.929159375" width="0.4064" layer="16"/>
<wire x1="26.838365625" y1="40.929159375" x2="26.760359375" y2="40.913159375" width="0.4064" layer="16"/>
<wire x1="26.543" y1="40.2336" x2="26.543" y2="40.6958" width="0.4064" layer="16"/>
<wire x1="26.760359375" y1="40.913159375" x2="26.543" y2="40.6958" width="0.4064" layer="16"/>
<via x="26.543" y="40.2336" extent="1-16" drill="0.35"/>
</signal>
<signal name="DP">
<contactref element="LED5" pad="5"/>
<contactref element="LED1" pad="5"/>
<contactref element="LED2" pad="5"/>
<contactref element="LED3" pad="5"/>
<contactref element="LED4" pad="5"/>
<contactref element="R28" pad="2"/>
<wire x1="72.2884" y1="27.8638" x2="66.04" y2="34.1122" width="0.4064" layer="1"/>
<wire x1="66.04" y1="34.1122" x2="59.6138" y2="34.1122" width="0.4064" layer="1"/>
<wire x1="59.6138" y1="34.1122" x2="48.3294" y2="34.1122" width="0.4064" layer="1"/>
<wire x1="48.3294" y1="34.1122" x2="41.35" y2="34.1122" width="0.4064" layer="1"/>
<wire x1="41.35" y1="34.1122" x2="34.163" y2="34.1122" width="0.4064" layer="1"/>
<wire x1="34.163" y1="34.1122" x2="22.7584" y2="34.1122" width="0.4064" layer="1"/>
<wire x1="21.4884" y1="27.8638" x2="21.4884" y2="32.8676" width="0.4064" layer="16"/>
<wire x1="21.4884" y1="32.8676" x2="22.7584" y2="34.1376" width="0.4064" layer="16"/>
<wire x1="22.7584" y1="34.1376" x2="22.7584" y2="34.1122" width="0.4064" layer="16"/>
<via x="22.7584" y="34.1122" extent="1-16" drill="0.35"/>
<wire x1="33.6438" y1="33.5422" x2="33.6438" y2="28.4084" width="0.4064" layer="16"/>
<wire x1="34.1884" y1="27.8638" x2="33.6438" y2="28.4084" width="0.4064" layer="16"/>
<wire x1="34.1884" y1="34.0868" x2="33.6438" y2="33.5422" width="0.4064" layer="16"/>
<via x="34.1884" y="34.0868" extent="1-16" drill="0.35"/>
<wire x1="34.1884" y1="34.0868" x2="34.163" y2="34.1122" width="0.4064" layer="1"/>
<wire x1="59.5884" y1="27.8638" x2="59.5884" y2="34.163" width="0.4064" layer="16"/>
<wire x1="59.5884" y1="34.163" x2="59.6138" y2="34.1884" width="0.4064" layer="16"/>
<wire x1="59.6138" y1="34.1884" x2="59.6138" y2="34.1122" width="0.4064" layer="16"/>
<via x="59.6138" y="34.1122" extent="1-16" drill="0.35"/>
<wire x1="46.8884" y1="27.8638" x2="48.3294" y2="29.3048" width="0.4064" layer="16"/>
<wire x1="48.3294" y1="29.3048" x2="48.3294" y2="34.1122" width="0.4064" layer="16"/>
<wire x1="48.3294" y1="34.1122" x2="48.3294" y2="34.1376" width="0.4064" layer="16"/>
<via x="48.3294" y="34.1122" extent="1-16" drill="0.35"/>
<wire x1="39.5342" y1="30.3534" x2="40.11515625" y2="30.59015625" width="0.4064" layer="16"/>
<wire x1="40.11515625" y1="30.59015625" x2="41.3816" y2="31.8566" width="0.4064" layer="16"/>
<wire x1="41.35" y1="34.1122" x2="41.3816" y2="34.0806" width="0.4064" layer="16"/>
<wire x1="41.3816" y1="34.0806" x2="41.3816" y2="31.8566" width="0.4064" layer="16"/>
<via x="41.35" y="34.1122" extent="1-16" drill="0.35"/>
</signal>
<signal name="N$1">
<contactref element="IC4" pad="13"/>
<contactref element="R26" pad="1"/>
<wire x1="35.499040625" y1="10.886840625" x2="35.499040625" y2="4.815840625" width="0.4064" layer="16"/>
<wire x1="36.769040625" y1="2.682240625" x2="36.769040625" y2="3.545840625" width="0.4064" layer="16"/>
<wire x1="36.769040625" y1="3.545840625" x2="35.499040625" y2="4.815840625" width="0.4064" layer="16"/>
<wire x1="37.465" y1="11.5066" x2="36.1188" y2="11.5066" width="0.4064" layer="16"/>
<wire x1="38.8366" y1="12.8782" x2="37.465" y2="11.5066" width="0.4064" layer="16"/>
<wire x1="38.8366" y1="12.8782" x2="39.2684" y2="12.8782" width="0.4064" layer="16"/>
<wire x1="36.1188" y1="11.5066" x2="35.499040625" y2="10.886840625" width="0.4064" layer="16"/>
</signal>
<signal name="N$2">
<contactref element="R26" pad="2"/>
<contactref element="R28" pad="1"/>
<wire x1="39.2684" y1="35.7382" x2="39.5342" y2="35.4724" width="0.4064" layer="16"/>
<wire x1="39.5342" y1="35.4724" x2="39.5342" y2="33.1974" width="0.4064" layer="16"/>
</signal>
<signal name="N$19">
<contactref element="IC1" pad="3"/>
<contactref element="R30" pad="1"/>
<contactref element="LED6" pad="K"/>
<wire x1="9.4742" y1="19.862" x2="9.4742" y2="21.774" width="0.4064" layer="16"/>
<wire x1="4.8772" y1="22.733" x2="4.2418" y2="22.0976" width="0.4064" layer="16"/>
<wire x1="4.2672" y1="16.9164" x2="2.8702" y2="16.9164" width="0.4064" layer="16"/>
<wire x1="2.3876" y1="17.399" x2="2.3876" y2="21.7932" width="0.4064" layer="16"/>
<wire x1="2.3876" y1="21.7932" x2="2.692" y2="22.0976" width="0.4064" layer="16"/>
<wire x1="2.692" y1="22.0976" x2="4.2418" y2="22.0976" width="0.4064" layer="16"/>
<wire x1="2.8702" y1="16.9164" x2="2.3876" y2="17.399" width="0.4064" layer="16"/>
<wire x1="9.4742" y1="21.774" x2="8.5152" y2="22.733" width="0.4064" layer="16"/>
<wire x1="8.5152" y1="22.733" x2="4.8772" y2="22.733" width="0.4064" layer="16"/>
</signal>
<signal name="N$20">
<contactref element="C2" pad="1"/>
<contactref element="IC1" pad="2"/>
<contactref element="R33" pad="2"/>
<via x="10.7126" y="17.6926" extent="1-16" drill="0.35"/>
<wire x1="13.1542" y1="21.5646" x2="10.7126" y2="19.123" width="0.4064" layer="1"/>
<wire x1="10.7126" y1="19.123" x2="10.7126" y2="17.6926" width="0.4064" layer="1"/>
<wire x1="10.7126" y1="17.6926" x2="10.7126" y2="11.0806" width="0.4064" layer="1"/>
<wire x1="10.7126" y1="11.0806" x2="10.922" y2="10.8712" width="0.4064" layer="1"/>
<wire x1="8.2042" y1="19.862" x2="8.151" y2="19.8088" width="0.4064" layer="16"/>
<wire x1="8.151" y1="19.8088" x2="8.151" y2="18.012" width="0.4064" layer="16"/>
<wire x1="8.151" y1="18.012" x2="8.4704" y2="17.6926" width="0.4064" layer="16"/>
<wire x1="8.4704" y1="17.6926" x2="10.7126" y2="17.6926" width="0.4064" layer="16"/>
</signal>
<signal name="N$10">
<contactref element="S2" pad="1"/>
<contactref element="LSP4" pad="MP"/>
<wire x1="25.273" y1="22.1234" x2="25.86278125" y2="22.7132" width="0.8128" layer="16"/>
<wire x1="59.159321875" y1="22.7132" x2="62.5045625" y2="19.367959375" width="0.8128" layer="16"/>
<wire x1="25.86278125" y1="22.7132" x2="59.159321875" y2="22.7132" width="0.8128" layer="16"/>
</signal>
<signal name="N$12">
<contactref element="R34" pad="1"/>
<contactref element="LED9" pad="A"/>
<wire x1="5.3848" y1="32.5882" x2="4.3946" y2="32.5882" width="0.4064" layer="16"/>
<wire x1="4.3946" y1="32.5882" x2="2.9464" y2="34.0364" width="0.4064" layer="16"/>
</signal>
<signal name="N$21">
<contactref element="R31" pad="2"/>
<contactref element="LED8" pad="K"/>
<wire x1="8.9154" y1="40.919" x2="8.8396" y2="40.8432" width="0.4064" layer="16"/>
<wire x1="8.8396" y1="40.8432" x2="5.4102" y2="40.8432" width="0.4064" layer="16"/>
</signal>
<signal name="N$22">
<contactref element="IC1" pad="6"/>
<contactref element="IC1" pad="1"/>
<wire x1="9.5312" y1="16.1172" x2="9.5312" y2="14.719" width="0.4064" layer="16"/>
<wire x1="9.4742" y1="14.662" x2="9.5312" y2="14.719" width="0.4064" layer="16"/>
<contactref element="JMP1" pad="1"/>
<wire x1="9.4742" y1="14.662" x2="9.4742" y2="13.2228" width="0.4064" layer="16"/>
<wire x1="15.1842" y1="10.4426" x2="16.225" y2="10.4426" width="0.4064" layer="16"/>
<wire x1="15.1842" y1="10.4426" x2="13.07" y2="12.5568" width="0.4064" layer="16"/>
<wire x1="9.4742" y1="13.2228" x2="10.1402" y2="12.5568" width="0.4064" layer="16"/>
<wire x1="10.1402" y1="12.5568" x2="13.07" y2="12.5568" width="0.4064" layer="16"/>
<wire x1="6.9342" y1="19.862" x2="6.9342" y2="17.9178" width="0.4064" layer="16"/>
<wire x1="8.0663" y1="16.7857" x2="8.8627" y2="16.7857" width="0.4064" layer="16"/>
<wire x1="6.9342" y1="17.9178" x2="8.0663" y2="16.7857" width="0.4064" layer="16"/>
<wire x1="8.8627" y1="16.7857" x2="9.5312" y2="16.1172" width="0.4064" layer="16"/>
</signal>
<signal name="N$23">
<contactref element="R36" pad="2"/>
<contactref element="R37" pad="1"/>
<contactref element="IC1" pad="5"/>
<wire x1="15.8246" y1="15.4178" x2="15.4436" y2="15.7988" width="0.4064" layer="16"/>
<wire x1="15.4436" y1="15.7988" x2="10.7442" y2="15.7988" width="0.4064" layer="16"/>
<wire x1="10.7442" y1="15.7988" x2="10.7442" y2="14.662" width="0.4064" layer="16"/>
<wire x1="15.8496" y1="18.7202" x2="15.8496" y2="15.4428" width="0.4064" layer="16"/>
<wire x1="15.8496" y1="15.4428" x2="15.8246" y2="15.4178" width="0.4064" layer="16"/>
</signal>
<signal name="N$24">
<contactref element="R35" pad="2"/>
<contactref element="LED8" pad="A"/>
<contactref element="R34" pad="2"/>
<wire x1="2.9464" y1="36.8804" x2="4.3692" y2="38.3032" width="0.4064" layer="16"/>
<wire x1="4.3692" y1="38.3032" x2="5.4102" y2="38.3032" width="0.4064" layer="16"/>
<wire x1="21.4884" y1="35.6616" x2="21.336" y2="35.6616" width="0.4064" layer="1"/>
<wire x1="21.336" y1="35.6616" x2="19.6342" y2="37.3634" width="0.4064" layer="1"/>
<wire x1="6.35" y1="37.3634" x2="5.4102" y2="38.3032" width="0.4064" layer="1"/>
<wire x1="19.6342" y1="37.3634" x2="6.35" y2="37.3634" width="0.4064" layer="1"/>
</signal>
<signal name="N$7">
<contactref element="R38" pad="1"/>
<contactref element="IC4" pad="3"/>
<contactref element="R29" pad="2"/>
<contactref element="JMP1" pad="2"/>
<wire x1="29.3751" y1="8.6995" x2="29.3624" y2="8.7122" width="0.4064" layer="16"/>
<via x="29.3751" y="8.6995" extent="1-16" drill="0.35"/>
<wire x1="43.8277" y1="8.8519" x2="29.5275" y2="8.8519" width="0.4064" layer="1"/>
<wire x1="29.3751" y1="8.6995" x2="29.5275" y2="8.8519" width="0.4064" layer="1"/>
<wire x1="44.389040625" y1="9.413240625" x2="44.389040625" y2="10.302240625" width="0.4064" layer="1"/>
<wire x1="43.8277" y1="8.8519" x2="44.389040625" y2="9.413240625" width="0.4064" layer="1"/>
<wire x1="18.923" y1="12.8016" x2="18.9738" y2="12.7508" width="0.4064" layer="16"/>
<wire x1="18.9738" y1="12.7508" x2="18.9738" y2="8.835" width="0.4064" layer="16"/>
<wire x1="18.9738" y1="8.7426" x2="16.225" y2="8.7426" width="0.4064" layer="16"/>
<wire x1="29.3751" y1="8.6995" x2="29.3181" y2="8.7565" width="0.4064" layer="16"/>
<wire x1="23.769" y1="8.664" x2="23.8615" y2="8.7565" width="0.4064" layer="16"/>
<wire x1="29.3181" y1="8.7565" x2="23.8615" y2="8.7565" width="0.4064" layer="16"/>
<via x="23.769" y="8.664" extent="1-16" drill="0.35"/>
<wire x1="23.769" y1="8.664" x2="23.2636" y2="9.1694" width="0.4064" layer="1"/>
<wire x1="23.2636" y1="9.1694" x2="21.8944" y2="9.1694" width="0.4064" layer="1"/>
<wire x1="23.769" y1="8.664" x2="23.712" y2="8.721" width="0.4064" layer="16"/>
<wire x1="23.712" y1="8.721" x2="19.0878" y2="8.721" width="0.4064" layer="16"/>
<wire x1="19.0878" y1="8.721" x2="18.9738" y2="8.835" width="0.4064" layer="16"/>
<wire x1="18.9738" y1="8.835" x2="18.9738" y2="8.7426" width="0.4064" layer="16"/>
</signal>
<signal name="N$25">
<contactref element="LED9" pad="K"/>
<contactref element="R38" pad="2"/>
<wire x1="18.923" y1="35.6616" x2="17.3482" y2="34.0868" width="0.4064" layer="16"/>
<wire x1="17.3482" y1="34.0868" x2="10.2108" y2="34.0868" width="0.4064" layer="16"/>
<wire x1="10.2108" y1="34.0868" x2="6.1722" y2="30.0482" width="0.4064" layer="16"/>
<wire x1="6.1722" y1="30.0482" x2="5.3848" y2="30.0482" width="0.4064" layer="16"/>
</signal>
<signal name="N$26">
<contactref element="R31" pad="1"/>
<contactref element="R39" pad="2"/>
<wire x1="8.9154" y1="38.075" x2="13.9696" y2="38.075" width="0.4064" layer="16"/>
<wire x1="13.9696" y1="38.075" x2="16.383" y2="35.6616" width="0.4064" layer="16"/>
</signal>
<signal name="N$28">
<contactref element="IC1" pad="7"/>
<contactref element="JMP1" pad="3"/>
<wire x1="8.2042" y1="14.662" x2="8.2042" y2="10.8294" width="0.4064" layer="16"/>
<wire x1="16.225" y1="7.0426" x2="15.883" y2="7.3846" width="0.4064" layer="16"/>
<wire x1="15.883" y1="7.3846" x2="11.649" y2="7.3846" width="0.4064" layer="16"/>
<wire x1="8.2042" y1="10.8294" x2="11.649" y2="7.3846" width="0.4064" layer="16"/>
</signal>
<signal name="N$27">
<contactref element="R32" pad="1"/>
<contactref element="LED7" pad="A"/>
<wire x1="4.2672" y1="8.5852" x2="5.2582" y2="7.5942" width="0.4064" layer="1"/>
<wire x1="5.2582" y1="7.5942" x2="5.2582" y2="6.3754" width="0.4064" layer="1"/>
</signal>
<signal name="N$29">
<contactref element="LED6" pad="A"/>
<contactref element="LED7" pad="K"/>
<contactref element="R39" pad="1"/>
<wire x1="4.2672" y1="11.1252" x2="4.2672" y2="14.3764" width="0.4064" layer="1"/>
<wire x1="16.383" y1="12.8016" x2="15.471" y2="12.8016" width="0.4064" layer="1"/>
<wire x1="15.471" y1="12.8016" x2="11.9348" y2="9.2654" width="0.4064" layer="1"/>
<wire x1="9.718" y1="9.2654" x2="7.8582" y2="11.1252" width="0.4064" layer="1"/>
<wire x1="7.8582" y1="11.1252" x2="4.2672" y2="11.1252" width="0.4064" layer="1"/>
<wire x1="11.9348" y1="9.2654" x2="9.718" y2="9.2654" width="0.4064" layer="1"/>
</signal>
<signal name="N$11">
<contactref element="LSP1" pad="MP"/>
<contactref element="SV2" pad="2"/>
<wire x1="71.795240625" y1="10.889440625" x2="67.2104" y2="6.3046" width="0.8128" layer="16"/>
<wire x1="61.3394" y1="6.3046" x2="67.2104" y2="6.3046" width="0.8128" layer="16"/>
<wire x1="71.795240625" y1="10.991040625" x2="71.795240625" y2="10.889440625" width="0.8128" layer="16"/>
</signal>
</signals>
<mfgpreviewcolors>
<mfgpreviewcolor name="soldermaskcolor" color="0xC8008000"/>
<mfgpreviewcolor name="silkscreencolor" color="0xFFFEFEFE"/>
<mfgpreviewcolor name="backgroundcolor" color="0xFF282828"/>
<mfgpreviewcolor name="coppercolor" color="0xFFFFBF00"/>
<mfgpreviewcolor name="substratecolor" color="0xFF786E46"/>
</mfgpreviewcolors>
</board>
</drawing>
<compatibility>
<note version="8.2" severity="warning">
Since Version 8.2, EAGLE supports online libraries. The ids
of those online libraries will not be understood (or retained)
with this version.
</note>
<note version="8.3" severity="warning">
Since Version 8.3, EAGLE supports URNs for individual library
assets (packages, symbols, and devices). The URNs of those assets
will not be understood (or retained) with this version.
</note>
Since Version 8.3, EAGLE supports the association of 3D packages
with devices in libraries, schematics, and board files. Those 3D
packages will not be understood (or retained) with this version.
</note>
</compatibility>
</eagle>
