0-30 VDC STABILIZED POWER
SUPPLY WITH CURRENT CONTROL 0.002-3 A
credits/author: smartkit
Copyright of this circuit belongs to
smart kit electronics. In this page we will use this circuit to
discuss for improvements and we will introduce some changes based on
original schematic.
This is a high quality power supply with a continuously
variable stabilised output adjustable at any value between 0 and 30VDC.
The circuit also incorporates an electronic output current limiter that
effectively controls the output current from a few milliamperes (2 mA)
to the maximum output of three amperes that the circuit can deliver.
This feature makes this power supply indispensable in the experimenters
laboratory as it is possible to limit the current to the typical maximum
that a circuit under test may require, and power it up then, without any
fear that it may be damaged if something goes wrong. There is also a
visual indication that the current limiter is in operation so that you
can see at a glance that your circuit is exceeding or not its preset
limits.
Technical Specifications - Characteristics
Technical
Specifications
Input Voltage: ................ 24 VAC
Input Current: ................ 3 A (max)
Output Voltage: ............. 0-30 V
adjustable
Output Current: ............. 2 mA-3 A
adjustable
Output Voltage Ripple: .... 0.01 % maximum
Features
- Reduced
dimensions, easy construction, simple operation. - Output
voltage easily adjustable. - Output current limiting with
visual indication. - Complete protection of the supplied device
against over loads and
malfunction. |
To start with, there is a step-down mains transformer with
a secondary winding rated at 24 V/3 A, which is connected across the
input points of the circuit at pins 1 & 2. (the quality of the
supplies output will be directly proportional to the quality of the
transformer). The AC voltage of the transformers secondary winding is
rectified by the bridge formed by the four diodes D1-D4. The DC voltage
taken across the output of the bridge is smoothed by the filter formed
by the reservoir capacitor C1 and the resistor R1. The circuit
incorporates some unique features which make it quite different from
other power supplies of its class. Instead of using a variable feedback
arrangement to control the output voltage, our circuit uses a constant
gain amplifier to provide the reference voltage necessary for its stable
operation. The reference voltage is generated at the output of U1.
The circuit operates as follows: The diode D8 is a 5.6 V
zener, which here operates at its zero temperature coefficient current.
The voltage in the output of U1 gradually increases till the diode D8 is
turned on. When this happens the circuit stabilises and the Zener
reference voltage (5.6 V) appears across the resistor R5. The current
which flows through the non inverting input of the op-amp is negligible,
therefore the same current flows through R5 and R6, and as the two
resistors have the same value the voltage across the two of them in
series will be exactly twice the voltage across each one. Thus the
voltage present at the output of the op-amp (pin 6 of U1) is 11.2 V,
twice the zeners reference voltage. The integrated circuit U2 has a
constant amplification factor of approximately 3 X, according to the
formula A=(R11+R12)/R11, and raises the 11.2 V reference voltage to
approximately 33 V. The trimmer RV1 and the resistor R10 are used for
the adjustment of the output voltages limits so that it can be reduced
to 0 V, despite any value tolerances of the other components in the
circuit.
Schematic
diagramm
click
for higher resolution
Another very important feature of the circuit, is the
possibility to preset the maximum output current which can be drawn from
the p.s.u., effectively converting it from a constant voltage source to
a constant current one. To make this possible the circuit detects the
voltage drop across a resistor (R7) which is connected in series with
the load. The IC responsible for this function of the circuit is U3. The
inverting input of U3 is biased at 0 V via R21. At the same time the non
inverting input of the same IC can be adjusted to any voltage by means
of P2.
Let us assume that for a given output of several volts, P2
is set so that the input of the IC is kept at 1 V. If the load is
increased the output voltage will be kept constant by the voltage
amplifier section of the circuit and the presence of R7 in series with
the output will have a negligible effect because of its low value and
because of its location outside the feedback loop of the voltage control
circuit. While the load is kept constant and the output voltage is not
changed the circuit is stable. If the load is increased so that the
voltage drop across R7 is greater than 1 V, IC3 is forced into action
and the circuit is shifted into the constant current mode. The output of
U3 is coupled to the non inverting input of U2 by D9. U2 is responsible
for the voltage control and as U3 is coupled to its input the latter can
effectively override its function. What happens is that the voltage
across R7 is monitored and is not allowed to increase above the preset
value (1 V in our example) by reducing the output voltage of the
circuit.
This is in effect a means of maintaining the output
current constant and is so accurate that it is possible to preset the
current limit to as low as 2 mA. The capacitor C8 is there to increase
the stability of the circuit. Q3 is used to drive the LED whenever the
current limiter is activated in order to provide a visual indication of
the limiters operation. In order to make it possible for U2 to control
the output voltage down to 0 V, it is necessary to provide a negative
supply rail and this is done by means of the circuit around C2 & C3.
The same negative supply is also used for U3. As U1 is working under
fixed conditions it can be run from the unregulated positive supply rail
and the earth.
The negative supply rail is produced by a simple voltage
pump circuit which is stabilised by means of R3 and D7. In order to
avoid uncontrolled situations at shut-down there is a protection circuit
built around Q1. As soon as the negative supply rail collapses Q1
removes all drive to the output stage. This in effect brings the output
voltage to zero as soon as the AC is removed protecting the circuit and
the appliances connected to its output. During normal operation Q1 is
kept off by means of R14 but when the negative supply rail collapses the
transistor is turned on and brings the output of U2 low. The IC has
internal protection and can not be damaged because of this effective
short circuiting of its output. It is a great advantage in experimental
work to be able to kill the output of a power supply without having to
wait for the capacitors to discharge and there is also an added
protection because the output of many stabilised power supplies tends to
rise instantaneously at switch off with disastrous results.
First of all let us consider a few basics in building
electronic circuits on a printed circuit board. The board is made of a
thin insulating material clad with a thin layer of conductive copper
that is shaped in such a way as to form the necessary conductors between
the various components of the circuit. The use of a properly designed
printed circuit board is very desirable as it speeds construction up
considerably and reduces the possibility of making errors. To protect
the board during storage from oxidation and assure it gets to you in
perfect condition the copper is tinned during manufacturing and covered
with a special varnish that protects it from getting oxidised and also
makes soldering easier.
Soldering the components to the board is the only way to
build your circuit and from the way you do it depends greatly your
success or failure. This work is not very difficult and if you stick to
a few rules you should have no problems. The soldering iron that you use
must be light and its power should not exceed the 25 Watts. The tip
should be fine and must be kept clean at all times. For this purpose
come very handy specially made sponges that are kept wet and from time
to time you can wipe the hot tip on them to remove all the residues that
tend to accumulate on it.
DO NOT file or sandpaper a dirty or worn out tip. If the
tip cannot be cleaned, replace it. There are many different types of
solder in the market and you should choose a good quality one that
contains the necessary flux in its core, to assure a perfect joint every
time. DO NOT use soldering flux apart from that which is already
included in your solder. Too much flux can cause many problems and is
one of the main causes of circuit malfunction. If nevertheless you have
to use extra flux, as it is the case when you have to tin copper wires,
clean it very thoroughly after you finish your work.
In order
to solder a component correctly you should do the
following:
Clean the
component leads with a small piece of emery paper.
Bend them at
the correct distance from the components body and insert he component
in its place on the board.
You may find
sometimes a component with heavier gauge leads than usual, that are
too thick to enter in the holes of the p.c. board. In this case use a
mini drill to enlarge the holes slightly. Do not make the holes too
large as this is going to make soldering difficult afterwards.
Take the hot
iron and place its tip on the component lead while holding the end of
the solder wire at the point where the lead emerges from the board.
The iron tip must touch the lead slightly above the p.c. board.
When the
solder starts to melt and flow wait till it covers evenly the area
around the hole and the flux boils and gets out from underneath the
solder.
The whole
operation should not take more than 5 seconds. Remove the iron and
allow the solder to cool naturally without blowing on it or moving the
component. If everything was done properly the surface of the joint
must have a bright metallic finish and its edges should be smoothly
ended on the component lead and the board track. If the solder looks
dull, cracked, or has the shape of a blob then you have made a dry
joint and you should remove the solder (with a pump, or a solder wick)
and redo it. Take care not to overheat the tracks as it is very easy
to lift them from the board and break them.
When you are
soldering a sensitive component it is good practice to hold the lead
from the component side of the board with a pair of long-nose pliers
to divert any heat that could possibly damage the component.
Make sure
that you do not use more solder than it is necessary as you are
running the risk of short-circuiting adjacent tracks on the board,
especially if they are very close together.
When you
finish your work, cut off the excess of the component leads and clean
the board thoroughly with a suitable solvent to remove all flux
residues that may still remain on it.
Construction (... continued) |
As it is recommended start working by identifying the
components and separating them in groups. Place first of all the sockets
for the ICs and the pins for the external connections and solder them in
their places. Continue with the resistors. Remember to mound R7 at a
certain distance from the printed circuit board as it tends to become
quite hot, especially when the circuit is supplying heavy currents, and
this could possibly damage the board. It is also advisable to mount R1
at a certain distance from the surface of the PCB as well. Continue with
the capacitors observing the polarity of the electrolytic and finally
solder in place the diodes and the transistors taking care not to
overheat them and being at the same time very careful to align them
correctly.
Mount the power transistor on the heatsink. To do this
follow the diagram and remember to use the mica insulator between the
transistor body and the heatsink and the special fibber washers to
insulate the screws from the heatsink. Remember to place the soldering
tag on one of the screws from the side of the transistor body, this is
going to be used as the collector lead of the transistor. Use a little
amount of Heat Transfer Compound between the transistor and the heatsink
to ensure the maximum transfer of heat between them, and tighten the
screws as far as they will go.
Attach a piece of insulated wire to each lead taking care
to make very good joints as the current that flows in this part of the
circuit is quite heavy, especially between the emitter and the collector
of the transistor. It is convenient to know where you are going to
place every thing inside the case that is going to accommodate your
power supply, in order to calculate the length of the wires to use
between the PCB and the potentiometers, the power transistor and for the
input and output connections to the circuit. (It does not really matter
if the wires are longer but it makes a much neater project if the wires
are trimmed at exactly the length necessary). Connect the
potentiometers, the LED and the power transistor and attach two pairs of
leads for the input and output connections. Make sure that you follow
the circuit diagram very care fully for these connections as there are
15 external connections to the circuit in total and if you make a
mistake it may be very difficult to find it afterwards. It is a good
idea to use cables of different colours in order to make trouble
shooting easier.
The external connections are: - 1 & 2 AC
input, the secondary of the transformer. - 3 (+) & 4 (-) DC
output. - 5, 10 & 12 to P1. - 6, 11 & 13 to P2. - 7
(E), 8 (B), 9 (E) to the power transistor Q4. - The LED should also
be placed on the front panel of the case where it is always visible but
the pins where it is connected at are not numbered.
When all the external connections have been finished make
a very careful inspection of the board and clean it to remove soldering
flux residues. Make sure that there are no bridges that may short
circuit adjacent tracks and if everything seems to be all right connect
the input of the circuit with the secondary of a suitable mains
transformer. Connect a voltmeter across the output of the circuit and
the primary of the transformer to the mains. DO NOT TOUCH ANY PART OF
THE CIRCUIT WHILE IT IS UNDER POWER.
The voltmeter should measure a voltage between 0 and 30
VDC depending on the setting of P1, and should follow any changes of
this setting to indicate that the variable voltage control is working
properly. Turning P2 counter-clockwise should turn the LED on,
indicating that the current limiter is in operation.
If you want the
output of your supply to be adjustable between 0 and 30 V you should
adjust RV1 to make sure that when P1 is at its minimum setting the
output of the supply is exactly 0 V. As it is not possible to measure
very small values with a conventional panel meter it is better to use a
digital meter for this adjustment, and to set it at a very low scale to
increase its sensitivity.
While using
electrical parts, handle power supply and equipment with great care,
following safety standards as described by international specs and
regulations.
CAUTION This
circuit works off the mains and there are 220 VAC present in some of its
parts. Voltages above 50 V are DANGEROUS and could even be
LETHAL. In order to avoid accidents that could be fatal to you or
members of your family please observe the following rules: - DO NOT
work if you are tired or in a hurry, double check every thing before
connecting your circuit to the mains and be ready - to disconnect it
if something looks wrong. - DO NOT touch any part of the circuit when
it is under power. - DO NOT leave mains leads exposed. All mains
leads should be well insulated. - DO NOT change the fuses with others
of higher rating or replace them with wire or aluminium foil. - DO
NOT work with wet hands. - If you are wearing a chain, necklace or
anything that may be hanging and touch an exposed part of the circuit BE
CAREFUL. - ALWAYS use a proper mains lead with the correct plug and
earth your circuit properly. - If the case of your project is made of
metal make sure that it is properly earthen. - If it is possible use
a mains transformer with a 1:1 ratio to isolate your circuit from the
mains. - When you are testing a circuit that works off the mains wear
shoes with rubber soles, stand on dry non conductive floor - and keep
one hand in your pocket or behind your back.
- If you take all
the above precautions you are reducing the - risks you are taking to
a minimum and this way you are protecting - yourself and those around
you. - A carefully built and well insulated device does not
constitute any danger for its user. - BEWARE: ELECTRICITY CAN KILL IF
YOU ARE NOT CAREFUL.
Check your work
for possible dry joints, bridges across adjacent tracks or soldering
flux residues that usually cause problems. Check again all the
external connections to and from the circuit to see if there is a
mistake there. - See that there are no components missing or inserted
in the wrong places. - Make sure that all the polarised components
have been soldered the right way round. - Make sure the supply has the
correct voltage and is connected the right way round to your circuit.
- Check your project for faulty or damaged components.
| R1 = 2,2 KOhm
1W |
| R2 = 82 Ohm
1/4W |
| R3 = 220 Ohm
1/4W |
| R4 = 4,7 KOhm
1/4W |
| R5, R6, R13, R20,
R21 = 10 KOhm 1/4W |
| R7 = 0,47 Ohm
5W |
| R8, R11 = 27 KOhm
1/4W |
| R9, R19 = 2,2 KOhm
1/4W |
| R10 = 270 KOhm
1/4W |
| R12, R18 = 56KOhm
1/4W |
| R14 = 1,5 KOhm
1/4W |
| R15, R16 = 1 KOhm
1/4W |
| R17 = 33 Ohm
1/4W |
| R22 = 3,9 KOhm
1/4W |
| RV1 = 100K
trimmer |
| P1, P2 =
10KOhm linear pontesiometer |
| C1 = 3300 uF/50V
electrolytic |
| C2, C3 = 47uF/50V
electrolytic |
| C4 = 100nF
polyester |
| C5 = 200nF
polyester |
| C6 = 100pF
ceramic |
| C7 = 10uF/50V
electrolytic |
| C8 = 330pF
ceramic |
| C9 = 100pF
ceramic |
| D1, D2, D3, D4 =
1N5402,3,4 diode 2A - RAX GI837U |
| D5, D6 =
1N4148 |
| D7, D8 = 5,6V
Zener |
| D9, D10 =
1N4148 |
| D11 = 1N4001 diode
1A |
| Q1 = BC548, NPN
transistor or BC547 |
| Q2 = 2N2219 NPN
transistor |
| Q3 = BC557, PNP
transistor or BC327 |
| Q4 = 2N3055 NPN
power transistor |
| U1, U2, U3 =
TL081, operational amplifier |
| D12 = LED
diode |
Please tell
me your experiences / thoughts building this power supply here
Also check the conversation about this project at
the community. Post you questions here.
