//**  Source name:   C:\Users\Apa\OneDrive\Mellékletek\Asztal\Flowcode1.fcfx
//**  Title:         
//**  Description:   
//**  Device:        PIC.12F.12F675
//**  Generated by:  Flowcode v10.1.2.40
//**  Date:          Sunday, October 11, 2026 07:01:47
//**  Users:         1
//**     NOT FOR COMMERCIAL USE
//**  https://www.flowcode.co.uk
#define MX_PIC
#define MX_CAL_PIC
#define MX_CLK_SPEED 4000000
#define FCP_NULL Unconnected_Port
#include <xc.h>
#include <math.h>
//Chip Configuration Settings
__PROG_CONFIG(0x1, 0x3FC4);
   Use :Include the type definitions
#include "C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\internals.c"
   Use :Include the chip adaption layer
#include "C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\includes.c"
   Use :User Project
       :Variable declarations
       :Macro implementations
#define FCV_FALSE (0)
#define FCV_TRUE (1)
MX_GLOBAL MX_UINT8 FCV_GOMB = (0x0);
MX_GLOBAL MX_BOOL FCV_GOMBFLAG = (0);
MX_GLOBAL MX_UINT8 FCV_SZAMOL2 = (0x0);
MX_GLOBAL MX_UINT8 FCV_SZAMOL1 = (0x0);
   Use :Main
void main()
	#ifdef INTOSCHELPER
		INTOSCHELPERCODE
	#endif
ANSEL = 0x20;
CMCON = 0x07;
OPTION_REG = 0xC0;
  // Loop
  while (1)
    // Input
    FCV_GOMB = GET_PORT_MASK(A,0x03);
    // Switch
    switch (FCV_GOMB)
      case 1:
        // Decision
        if (FCV_GOMBFLAG == 0)
          // Calculation
          FCV_SZAMOL1 = FCV_SZAMOL1 + 1;
          FCV_GOMBFLAG = 1;
          // Decision
          if (FCV_SZAMOL1 >= 3)
            // Output
            SET_PORT_PIN(A,4,(0));
            // Calculation
            FCV_SZAMOL1 = 0;
          } else {
            // Output
            SET_PORT_PIN(A,4,(1));
            // Output
            SET_PORT_PIN(A,5,(0));
            // Calculation
            FCV_SZAMOL2 = 0;
        // } else {
        break;
      case 2:
        // Decision
          // Calculation
          FCV_SZAMOL2 = FCV_SZAMOL2 + 1;
          FCV_GOMBFLAG = 1;
          // Output
          SET_PORT_PIN(A,5,(1));
          // Decision
          if (FCV_SZAMOL2 >= 3)
            // Output
            // Calculation
            FCV_SZAMOL2 = 0;
          } else {
            // Output
            // Output
            // Calculation
            FCV_SZAMOL1 = 0;
        // } else {
        break;
      // default:
    // Decision
    if (FCV_GOMBFLAG == 1 & FCV_GOMB == 0)
      // Calculation
      FCV_GOMBFLAG = 0;
    // } else {
	mainendloop: goto mainendloop;
   Use :Interrupt
void MX_INTERRUPT_MACRO(void)
