; Source created with Parsic Version 3.x
; at              : 2009.01.01. 23:48:45
; Project File    : C:\PROGRA~1\PARSIC\Pwm01.PIC
; Project Version : 1.0.19
; Created         : 2009.01.01. 20:34:41
; Last change     : 2009.01.01. 23:48:44
	PROCESSOR 16F628
	INCLUDE P16F628.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_ON & _WDT_OFF & _BODEN_ON & _XT_OSC & _LVP_OFF & _MCLRE_ON
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
TR1	= 32	; located in Bank 0
TR1_HI	= 33	; located in Bank 0
S0	= 34	; located in Bank 0
ZV1	= 35	; located in Bank 0
ZV1_HI	= 36	; located in Bank 0
ZV1_FD	= 37	; located in Bank 0
OS1_FD	= 38	; located in Bank 0
PO1_FD	= 39	; located in Bank 0
ZR1	= 40	; located in Bank 0
ZR1_FD	= 41	; located in Bank 0
S1	= 42	; located in Bank 0
RAM	= 43	; located in Bank 0
SYS_WSAV	= 112	; located in Bank 0, 1, 2, 3
SYS_SSAV	= 113	; located in Bank 0, 1, 2, 3
SYS_TMP1	= 114	; located in Bank 0, 1, 2, 3
SYS_TMP2	= 115	; located in Bank 0, 1, 2, 3
SYS_FSAV	= 116	; located in Bank 0, 1, 2, 3
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	CLRF STATUS	; switch to RAM-Bank 0
	GOTO SYS_INIT
	NOP
	NOP
;Interrupt-Adress
	MOVWF SYS_WSAV	; save register
	SWAPF STATUS,W
	CLRF STATUS	; bank 0
	MOVWF SYS_SSAV
	MOVFW FSR
	MOVWF SYS_FSAV
	BTFSS INTCON,T0IF	; TMR0 ?
	GOTO NOTMR0INT
	BCF INTCON,T0IF	; Interrupt quitieren
	BCF STATUS,RP0	; Bank 0
	BCF STATUS,RP1	; Bank 0
	INCFSZ TR1,F
	GOTO SYS_INT_LABEL_0
	INCF TR1_HI,F
SYS_INT_LABEL_0
NOTMR0INT
EXITINT
	MOVFW SYS_FSAV
	MOVWF FSR
	SWAPF SYS_SSAV,W	; Register zurück
	MOVWF STATUS
	SWAPF SYS_WSAV,F
	SWAPF SYS_WSAV,W
	RETFIE
; Subroutines
;Initialisierung
SYS_INIT
	MOVLW B'00100000'
	MOVWF INTCON
; Set output before direction
	MOVLW B'00000000'
	MOVWF PORTA
	MOVLW B'00000000'
	MOVWF PORTB
	MOVLW 143
	BSF STATUS,RP0	; Bank 1
	MOVWF OPTION_REG
; Richtung setzen
	MOVLW B'11111111'
	MOVWF TRISA
	MOVLW B'11110111'
	MOVWF TRISB
	MOVLW 7	; Comparators off
	MOVWF CMCON
; init vars
; Clear RAM
	BCF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	BTFSS FSR,7
	GOTO CR1
	BSF FSR,5
CR2
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR2
	BSF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR3
	CLRF INDF
	INCF FSR,F
	MOVLW H'50'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR3
	BCF STATUS,RP1	; Bank 1
	MOVLW 255	; init PWM
	MOVWF PR2
	MOVLW 12	; PWM mode
	MOVWF CCP1CON
	CLRF CCPR1L
	MOVLW 4	; TIMER2 ON
	MOVWF T2CON
	CLRF TMR0
	BCF INTCON,T0IF
	BSF INTCON,GIE	; Interrupt freigeben
;******* Haupt-Programm ***********
MAIN
; Timer -> TR1
	MOVLW 0	; Test auf >=
	SUBWF TR1_HI,W	;F-W -> W
	BTFSS STATUS,ZERO
	GOTO LABEL_TR1_CHECK
	MOVLW 39
	SUBWF TR1,W	;F-W -> W
LABEL_TR1_CHECK
	BTFSS STATUS,CARRY
	GOTO LABEL_TR1_ENDE
LABEL_TR1_RESET
	SUBWF TR1_HI,F	;F-W -> F
	MOVLW 39
	SUBWF TR1,F	;F-W -> F
	BTFSS STATUS,CARRY
	DECF TR1_HI,F
LABEL_TR1_SET	; toggel output
	BTFSC S0,0
	GOTO LABEL_TR1_CLR
	BSF S0,0
	GOTO LABEL_TR1_ENDE
LABEL_TR1_CLR
	BCF S0,0
LABEL_TR1_ENDE
; Zähler -> ZV1
	BTFSS S0,4	; Reset ?
	GOTO LABEL_ZV1_COUNT
	CLRF ZV1
	CLRF ZV1_HI
	GOTO LABEL_ZV1_SETOUT
LABEL_ZV1_COUNT
; Test auf positive Flanke
	BTFSS S1,0
	GOTO LABEL_ZV1_SETFD
	BTFSC ZV1_FD,0
	BSF ZV1_FD,0
	BTFSC S0,3	; Vorwärts oder Rückwärts ?
	GOTO LABEL_ZV1_BACKWARD
	INCFSZ ZV1,F
	INCF ZV1_HI,F
LABEL_ZV1_BACKWARD
	DECF ZV1,F
	INCFSZ ZV1,W
	DECF ZV1_HI,F
LABEL_ZV1_SETOUT
LABEL_ZV1_SETFD
; Test auf negative Flanke
	BTFSC S1,0
	GOTO LABEL_ZV1_EXIT
	BCF ZV1_FD,0
LABEL_ZV1_EXIT
; UND - Gatter -> LG1
LABEL_LG1_1
	BTFSS S0,0
	GOTO LABEL_LG1_FALSE
LABEL_LG1_2
	BTFSC S0,1
LABEL_LG1_3
	BTFSS S0,7
LABEL_LG1_TRUE
	BSF S0,2
	GOTO LABEL_LG1_ENDE
LABEL_LG1_FALSE
	BCF S0,2
LABEL_LG1_ENDE
; One Shot -> OS1
	BTFSC PORTA,0
	GOTO LABEL_OS1_1
	BTFSC OS1_FD,0
	GOTO LABEL_OS1_1
	BSF OS1_FD,0
	BSF S0,4
	GOTO LABEL_OS1_2
LABEL_OS1_1
	BCF S0,4
	BTFSS PORTA,0
	GOTO LABEL_OS1_2
	BCF OS1_FD,0
LABEL_OS1_2
; Set PWM PO1
	BTFSS S0,0
	GOTO LABEL_PO1_SETFD
	BTFSC PO1_FD,0
	BSF PO1_FD,0
	SWAPF ZV1,W
	ANDLW B'00110000'
	IORLW B'00001100'
	MOVWF CCP1CON
	RRF ZV1_HI,W
	MOVWF SYS_TMP1
	RRF ZV1,W
	MOVWF SYS_TMP2
	RRF SYS_TMP1,W
	RRF SYS_TMP2,W
	MOVWF CCPR1L
LABEL_PO1_SETFD
	BTFSC S0,0
	GOTO LABEL_PO1_EXIT
	BCF PO1_FD,0
LABEL_PO1_EXIT
; GND
	BCF S0,3	; immer Low
; RS-FLIP-FLOP -> RS1
	BTFSC S0,5
	GOTO LABEL_RS1_RESET
	BTFSS S0,6
	GOTO LABEL_RS1_ENDE
	BSF S0,7	; Ausgang setzen
	GOTO LABEL_RS1_ENDE
LABEL_RS1_RESET
	BCF S0,7	; Ausgang zurücksetzen
LABEL_RS1_ENDE
; UND - Gatter -> LG2
LABEL_LG2_1
	BTFSS S0,7
	GOTO LABEL_LG2_FALSE
LABEL_LG2_2
	BTFSS S0,4
LABEL_LG2_TRUE
	BSF S0,5
	GOTO LABEL_LG2_ENDE
LABEL_LG2_FALSE
	BCF S0,5
LABEL_LG2_ENDE
; UND - Gatter -> LG3
LABEL_LG3_1
	BTFSS S0,4
	GOTO LABEL_LG3_FALSE
LABEL_LG3_2
	BTFSC S0,7
LABEL_LG3_TRUE
	BSF S0,6
	GOTO LABEL_LG3_ENDE
LABEL_LG3_FALSE
	BCF S0,6
LABEL_LG3_ENDE
; Vergleich -> IF1
	MOVLW HIGH 1022
	SUBWF ZV1_HI,W	; F - W -> W
	BTFSS STATUS,ZERO	; Wenn ZERO gesetzt LOW-Byte testen
	GOTO LABEL_IF1_CHECK
	MOVLW LOW 1022
	SUBWF ZV1,W	; F - W -> W
LABEL_IF1_CHECK
	BTFSS STATUS,CARRY	; Test auf -> >=
	GOTO LABEL_IF1_FALSE
LABEL_IF1_TRUE
	BSF S0,1
	GOTO LABEL_IF1_EXIT
LABEL_IF1_FALSE
	BCF S0,1
LABEL_IF1_EXIT
; Zähler -> ZR1
	BTFSS S0,3	; Reset ?
	GOTO LABEL_ZR1_COUNT
	CLRF ZR1
	GOTO LABEL_ZR1_SETOUT
LABEL_ZR1_COUNT
	BTFSC ZR1_FD,0
	GOTO LABEL_ZR1_SETFD
	BTFSS S0,2
	INCF ZR1,F
LABEL_ZR1_SETOUT
; Output Q0
	BTFSS ZR1,0
	GOTO LABEL_ZR1_SETOUT0
	BSF S1,2
	GOTO LABEL_ZR1_SETOUT0_END
LABEL_ZR1_SETOUT0
	BCF S1,2
; Output Q1
	BTFSS ZR1,1
	GOTO LABEL_ZR1_SETOUT1
	BSF S1,1
	GOTO LABEL_ZR1_SETOUT1_END
LABEL_ZR1_SETOUT1
	BCF S1,1
; Output Q2
	BTFSS ZR1,2
	GOTO LABEL_ZR1_SETOUT2
	BSF S1,0
	GOTO LABEL_ZR1_SETOUT2_END
LABEL_ZR1_SETOUT2
	BCF S1,0
LABEL_ZR1_SETFD
	BTFSS S0,2
	GOTO LABEL_ZR1_SETFD2
	BSF ZR1_FD,0
	GOTO LABEL_ZR1_END
LABEL_ZR1_SETFD2
	BCF ZR1_FD,0
LABEL_ZR1_END
	GOTO MAIN
	END
