** Drc report for /mnt/user-data/outputs/BDX_20V_nyak/BDX_20V.kicad_pcb **
** Created on 2026-11-26 09:32:55 **
** Found 83 DRC violations **
[silk_overlap]: Silkscreen overlap
    Rule: board setup constraints silk; Severity: warning
    @(145.0000 mm, 67.0000 mm): PCB Text 'T3 a bordára (bilincs)' on F.Silkscreen
    @(95.0000 mm, 68.0000 mm): Line on F.Silkscreen
    @(190.0000 mm, 71.0000 mm): Line on F.Silkscreen
    @(175.4200 mm, 70.2300 mm): Line on F.Silkscreen
    @(178.6900 mm, 70.2300 mm): Line on F.Silkscreen
    @(182.3910 mm, 70.2300 mm): Line on F.Silkscreen
    @(185.6600 mm, 70.2300 mm): Line on F.Silkscreen
    @(99.4200 mm, 70.2300 mm): Line on F.Silkscreen
    @(102.6900 mm, 70.2300 mm): Line on F.Silkscreen
    @(106.3910 mm, 70.2300 mm): Line on F.Silkscreen
    @(109.6600 mm, 70.2300 mm): Line on F.Silkscreen
    @(113.3800 mm, 81.3500 mm): Line on F.Silkscreen
    @(113.6700 mm, 99.0800 mm): Reference 'R15'
    @(90.5000 mm, 147.0000 mm): Value 'drót' of JP1
    @(90.5000 mm, 147.0000 mm): Reference 'JP1'
    @(90.5000 mm, 147.0000 mm): Line on F.Silkscreen
    @(90.8000 mm, 166.0000 mm): Line on F.Silkscreen
    @(111.1200 mm, 113.3800 mm): Line on F.Silkscreen
    @(110.5000 mm, 126.2500 mm): Reference 'C4'
    @(111.1200 mm, 126.6200 mm): Line on F.Silkscreen
    @(112.2500 mm, 120.0000 mm): Reference 'C3'
    @(112.6300 mm, 120.9200 mm): Reference 'R3'
[lib_footprint_issues]: The current configuration does not include the library ''.
    Local override; Severity: warning
    @(85.0000 mm, 122.0000 mm): Footprint R22
    @(167.0000 mm, 93.1600 mm): Footprint D2
    @(178.0000 mm, 73.5000 mm): Footprint T7
    @(84.0000 mm, 34.0000 mm): Footprint H1
    @(180.0000 mm, 156.0000 mm): Footprint R9
    @(193.0000 mm, 124.5000 mm): Footprint C10
    @(192.0000 mm, 80.0000 mm): Footprint R18
    @(105.5000 mm, 147.5000 mm): Footprint R5
    @(84.0000 mm, 176.0000 mm): Footprint H3
    @(86.0000 mm, 166.0000 mm): Footprint F2
    @(153.0000 mm, 161.0000 mm): Footprint C1
    @(143.0000 mm, 156.0000 mm): Footprint D1
    @(84.0000 mm, 87.0000 mm): Footprint R13
    @(102.0000 mm, 73.5000 mm): Footprint T8
    @(125.0000 mm, 79.0000 mm): Footprint R8
    @(204.0000 mm, 114.6000 mm): Footprint F1
    @(118.0000 mm, 80.0000 mm): Footprint R19
    @(145.0800 mm, 74.5000 mm): Footprint T3
    @(94.0000 mm, 93.0000 mm): Footprint T4
    @(144.0000 mm, 101.0000 mm): Footprint C5
    @(107.5000 mm, 96.0000 mm): Footprint R17
    @(100.0000 mm, 103.0000 mm): Footprint T6
    @(153.0000 mm, 93.0000 mm): Footprint R10
    @(184.0000 mm, 98.0000 mm): Footprint R16
    @(149.0000 mm, 80.0000 mm): Footprint R7
    @(150.0000 mm, 128.2400 mm): Footprint C9
    @(90.5000 mm, 147.0000 mm): Footprint JP1
    @(94.0000 mm, 173.0000 mm): Footprint J5
    @(84.0000 mm, 100.0000 mm): Footprint D3
    @(168.0000 mm, 99.0000 mm): Footprint T5
    @(206.0000 mm, 176.0000 mm): Footprint H4
    @(153.0000 mm, 86.0000 mm): Footprint R11
    @(130.0000 mm, 80.0000 mm): Footprint P1
    @(184.0000 mm, 124.5000 mm): Footprint R21
    @(103.5000 mm, 114.0000 mm): Footprint R6
    @(84.0000 mm, 81.0000 mm): Footprint C8
    @(148.0000 mm, 161.0000 mm): Footprint R1
    @(188.0000 mm, 118.0000 mm): Footprint C12
    @(90.5000 mm, 127.0000 mm): Footprint R4
    @(109.0000 mm, 115.0000 mm): Footprint C3
    @(110.0000 mm, 50.0000 mm): Footprint H5
    @(90.5000 mm, 110.0000 mm): Footprint C11
    @(164.0000 mm, 124.0000 mm): Footprint J4
    @(98.0000 mm, 142.0000 mm): Footprint T2
    @(90.5000 mm, 116.0000 mm): Footprint C13
    @(171.0000 mm, 85.0000 mm): Footprint C7
    @(108.0000 mm, 132.5000 mm): Footprint C4
    @(159.0000 mm, 148.0000 mm): Footprint J2
    @(168.0000 mm, 114.5000 mm): Footprint J6
    @(176.0000 mm, 94.0000 mm): Footprint R14
    @(175.0000 mm, 115.0000 mm): Footprint J7
    @(133.0000 mm, 160.5000 mm): Footprint C2
    @(115.0000 mm, 126.0000 mm): Footprint R3
    @(146.0000 mm, 113.0000 mm): Footprint R20
    @(118.0000 mm, 129.0000 mm): Footprint R2
    @(103.0000 mm, 94.5000 mm): Footprint C6
    @(113.0000 mm, 142.0000 mm): Footprint T1
    @(206.0000 mm, 34.0000 mm): Footprint H2
    @(154.0000 mm, 76.0000 mm): Footprint R12
    @(143.0000 mm, 170.0000 mm): Footprint J1
    @(111.3000 mm, 94.0000 mm): Footprint R15
    @(207.0000 mm, 128.0000 mm): Footprint J3
    @(175.0000 mm, 50.0000 mm): Footprint H6
[silk_edge_clearance]: Silkscreen clipped by board edge
    @(80.0000 mm, 180.0000 mm): Line on Edge.Cuts
    @(80.0000 mm, 154.7500 mm): Reference 'F2'
** Found 1 unconnected pads **
[unconnected_items]: Missing connection between items
    Local override; Severity: error
    @(90.5000 mm, 80.5000 mm): Track [VN] on B.Cu, length 66.5000 mm
    @(98.1200 mm, 147.0000 mm): Track [VN] on B.Cu, length 5.0014 mm
** Found 0 Footprint errors **
** End of Report **
