#include <p16F887.inc>
	__CONFIG    _CONFIG1, _LVP_OFF & _FCMEN_OFF & _IESO_OFF & _BOR_OFF & _CPD_OFF & _CP_OFF & _MCLRE_OFF & _PWRTE_ON & _WDT_OFF & _INTRC_OSC_NOCLKOUT
	__CONFIG    _CONFIG2, _WRT_OFF & _BOR21V
     cblock 0x20
Delay1           ; Assign an address to label Delay1
Delay2
Display          ; define a variable to hold the diplay
     endc
     org 0
Start:
     bsf       STATUS,RP0     ; select Register Bank 1
     movlw     0xFF
     movwf     TRISA          ; Make PortA all input
     clrf      TRISD          ; Make PortD all output
     movlw     0x00           ; Left Justified, Vdd-Vss referenced
     movwf     ADCON1
     bsf       STATUS,RP1     ; select Register Bank 3
     movlw     0xFF           ; we want all Port A pins Analog
     movwf     ANSEL
     bcf       STATUS,RP0     ; back to Register Bank 0
     bcf       STATUS,RP1
     movlw     0x41
     movwf     ADCON0         ; configure A2D for Fosc/8, Channel 0 (RA0), and turn on the A2D module
MainLoop:
     nop                      ; wait 5uS for A2D amp to settle and capacitor to charge.
     nop                      ; wait 1uS
     nop                      ; wait 1uS
     nop                      ; wait 1uS 
     nop                      ; wait 1uS
     bsf       ADCON0,GO_DONE ; start conversion
     btfss     ADCON0,GO_DONE ; this bit will change to zero when the conversion is complete
     goto      $-1
     movf      ADRESH,w       ; Copy the display to the LEDs
     movwf     PORTD
     goto      MainLoop
     end
