    Bill of Materials                                           CD_PLAY2.PCB
    Quantity  Type              Value             Ref Designators
         1    C                 0.22F / 5V        C5
         2    C                 47p               C1,C2
         3    C                 100n              C4,C12,C13
         1    C                 680n              C3
         1    C trimmer         5-30 p            C9
         2    Csat. tuske       1 x 4             CN3,CN4
         1    Csat. tuske       2 x 40            CN1
         1    D                 1N4148            D1
         2    D                 BAT 47            D2,D3
         2    Elko              10uF/25V          C8,C10
         3    Elko              100uF/25V         C6,C7,C11
         1    IC                74HC245           U4
         1    IC                74HC573           U2
         1    IC                CD4028            U6
         1    IC                AT89C52           U1
         1    IC                PCF 8583          U3
         1    IC                74288             U5
         1    Kvarc             11.05 MHz         XTAL1
         1    Kvarc             32768 Hz          XTAL2
         1    LED               3mm               LED1
        11    NPN Trans.        2N 2222           Q1,Q2,Q3,Q4,Q5,Q6,Q7,Q8,
                                                  Q9,Q10,Q11
         8    Nyomogomb                           SW1,SW2,SW3,SW4,SW5,SW6,
                                                  SW7,SW8
        14    R                 10k               R5,R6,R7,R8,R9,R10,R11,
                                                  R12,R15,R16,R17,R18,R19,
                                                  R20
         1    R                 2.7k              R3
         2    R                 10 x 1k           RH1,RH2
         1    R                 33k               R2
         2    R                 60.4 Ohm R534     R13,R14
         2    R                 330               R1,R4
         1    Sorkapocs         4 pol             CN2
         1    VFD display       FIP7EM11 (NEC)    VFD1
    03-Sep-00  12:31                                                 Page  1
