; Source created with Parsic Version 3.x
; at              : 2009.02.07. 19:52:29
; Project File    : C:\PROGRA~1\Parsic\HE\2XBCD.PIC
; Project Version : 1.0.1
; Created         : 2009.02.07. 19:25:19
; Last change     : 2009.02.07. 19:52:27
	PROCESSOR 16F84
	INCLUDE P16F84.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_ON & _WDT_OFF & _XT_OSC
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
ZV1	= 12	; located in Bank 0, 1
ZV1_FD	= 13	; located in Bank 0, 1
S5	= 14	; located in Bank 0, 1
S0	= 15	; located in Bank 0, 1
SYS_TMP1	= 16	; located in Bank 0, 1
SYS_TMP2	= 17	; located in Bank 0, 1
SYS_TMP3	= 18	; located in Bank 0, 1
SYS_TMP4	= 19	; located in Bank 0, 1
S1	= 20	; located in Bank 0, 1
S2	= 21	; located in Bank 0, 1
S3	= 22	; located in Bank 0, 1
SYS_WSAV	= 23	; located in Bank 0, 1
SYS_SSAV	= 24	; located in Bank 0, 1
TR1	= 25	; located in Bank 0, 1
TR1_HI	= 26	; located in Bank 0, 1
OS1_FD	= 27	; located in Bank 0, 1
S4	= 28	; located in Bank 0, 1
OS2_FD	= 29	; located in Bank 0, 1
SYS_FSAV	= 30	; located in Bank 0, 1
RAM	= 31	; located in Bank 0, 1
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	CLRF STATUS	; switch to RAM-Bank 0
	GOTO SYS_INIT
	NOP
	NOP
;Interrupt-Adress
	MOVWF SYS_WSAV	; save register
	SWAPF STATUS,W
	CLRF STATUS	; bank 0
	MOVWF SYS_SSAV
	MOVFW FSR
	MOVWF SYS_FSAV
	BTFSS INTCON,T0IF	; TMR0 ?
	GOTO NOTMR0INT
	BCF INTCON,T0IF	; Interrupt quitieren
	INCFSZ TR1,F
	GOTO SYS_INT_LABEL_0
	INCF TR1_HI,F
SYS_INT_LABEL_0
NOTMR0INT
EXITINT
	MOVFW SYS_FSAV
	MOVWF FSR
	SWAPF SYS_SSAV,W	; Register zurück
	MOVWF STATUS
	SWAPF SYS_WSAV,F
	SWAPF SYS_WSAV,W
	RETFIE
; Multiplication 8 - Bit
SYSMUL8
	CLRF SYS_TMP3
	MOVLW 8
	MOVWF SYS_TMP4
SYSMUL8_1
	MOVFW SYS_TMP1
	RRF SYS_TMP2,F
	BTFSC STATUS,CARRY
	ADDWF SYS_TMP3,F
	RLF SYS_TMP1,F
	DECFSZ SYS_TMP4,F
	GOTO SYSMUL8_1
	RETURN
; Division 8 - Bit
SYSDIV8
	MOVF SYS_TMP2,F
	BTFSC STATUS,ZERO
	GOTO SYSDIV8_ERROR
	CLRF SYS_TMP3	; Ergebnis löschen
	MOVLW 1
	MOVWF SYS_TMP4
SYSDIV8_0
	BTFSC SYS_TMP2,7	; OP2 linksbündig
	GOTO SYSDIV8_1
	INCF SYS_TMP4,F
	BCF STATUS,CARRY
	RLF SYS_TMP2,F
	GOTO SYSDIV8_0
SYSDIV8_1
	MOVFW SYS_TMP2	; vergleichen
	SUBWF SYS_TMP1,F	; F-W -> W
	BTFSC STATUS,CARRY
	GOTO SYSDIV8_2
	ADDWF SYS_TMP1,F	; F+W -> F
	BCF STATUS,CARRY
SYSDIV8_2
	RLF SYS_TMP3,F
	RRF SYS_TMP2,F
	DECFSZ SYS_TMP4,F
	GOTO SYSDIV8_1
	RETURN
SYSDIV8_ERROR
	MOVLW 255
	MOVWF SYS_TMP3
	RETURN
; Subroutines
;Initialisierung
SYS_INIT
	MOVLW B'00100000'
	MOVWF INTCON
; Set output before direction
	BCF STATUS,RP0	; Bank 0
	MOVLW B'00000000'
	MOVWF PORTA
	MOVLW B'00000001'
	MOVWF PORTB
	MOVLW 143
	BSF STATUS,RP0	; Bank 1
	MOVWF OPTION_REG
; Richtung setzen
	MOVLW B'11110000'
	MOVWF TRISA
	MOVLW B'11111100'
	MOVWF TRISB
; init vars
; Clear RAM
	MOVLW 12
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	MOVFW FSR
	SUBLW 80
	BTFSS STATUS,ZERO
	GOTO CR1
	CLRF TMR0
	BCF INTCON,T0IF
	BSF INTCON,GIE	; Interrupt freigeben
;******* Haupt-Programm ***********
MAIN
; Zähler -> ZV1
	BTFSS S5,1	; Reset ?
	GOTO LABEL_ZV1_COUNT
	CLRF ZV1
	GOTO LABEL_ZV1_SETOUT
LABEL_ZV1_COUNT
; Test auf positive Flanke
	BTFSS S5,0
	GOTO LABEL_ZV1_SETFD
	BTFSC ZV1_FD,0
	BSF ZV1_FD,0
	BTFSC PORTB,3	; Vorwärts oder Rückwärts ?
	GOTO LABEL_ZV1_BACKWARD
	INCF ZV1,F
LABEL_ZV1_BACKWARD
	DECF ZV1,F
LABEL_ZV1_SETOUT
LABEL_ZV1_SETFD
; Test auf negative Flanke
	BTFSC S5,0
	GOTO LABEL_ZV1_EXIT
	BCF ZV1_FD,0
LABEL_ZV1_EXIT
; Schmitt-Trigger 8-Bit -> ST1
	BTFSC S5,1	; Ausgang gesetzt ?
	GOTO LABEL_ST1_MH	; dann mit Hysterese ?
	MOVLW 100
	GOTO LABEL_ST1_TEST
LABEL_ST1_MH
	MOVLW 100
LABEL_ST1_TEST
	SUBWF ZV1,W
	BTFSS STATUS,CARRY
	GOTO LABEL_ST1_RESET
	BSF S5,1	; if greater or equal
	GOTO LABEL_ST1_ENDE
LABEL_ST1_RESET
	BCF S5,1	; if less
LABEL_ST1_ENDE
;AF1
	MOVFW ZV1
	MOVWF SYS_TMP1
	MOVLW 10
	MOVWF SYS_TMP2
	CALL SYSDIV8
	MOVFW SYS_TMP3
	MOVWF S0
LABEL_AF1_EXIT
;AF2
	MOVFW S0
	MOVWF SYS_TMP1
	MOVLW 10
	MOVWF SYS_TMP2
	CALL SYSMUL8
	MOVFW SYS_TMP3
	MOVWF S1
LABEL_AF2_EXIT
;AF3
	MOVFW S1
	SUBWF ZV1,W	; F - W -> W
	MOVWF S2
LABEL_AF3_EXIT
; Verteiler -> BV1
	BTFSC S3,0
	GOTO LABEL_BV1_0
	BCF PORTA,0
	GOTO LABEL_BV1_0_END
LABEL_BV1_0
	BSF PORTA,0
LABEL_BV1_0_END
	BTFSC S3,1
	GOTO LABEL_BV1_1
	BCF PORTA,1
	GOTO LABEL_BV1_1_END
LABEL_BV1_1
	BSF PORTA,1
LABEL_BV1_1_END
	BTFSC S3,2
	GOTO LABEL_BV1_2
	BCF PORTA,2
	GOTO LABEL_BV1_2_END
LABEL_BV1_2
	BSF PORTA,2
LABEL_BV1_2_END
	BTFSC S3,3
	GOTO LABEL_BV1_3
	BCF PORTA,3
	GOTO LABEL_BV1_3_END
LABEL_BV1_3
	BSF PORTA,3
LABEL_BV1_3_END
; Multiplexer -> MX1
	CLRF SYS_TMP1
	MOVFW S4
	BTFSS STATUS,ZERO
	GOTO LABEL_MX1_CHECKCONTROL1
	MOVFW S2
	MOVWF S3
	GOTO LABEL_MX1_END
	INCF SYS_TMP1,F
	MOVFW S4
	SUBWF SYS_TMP1,W
	BTFSS STATUS,ZERO
	GOTO LABEL_MX1_CHECKCONTROL2
	MOVFW S0
	MOVWF S3
	GOTO LABEL_MX1_END
LABEL_MX1_END
; Timer -> TR1
	MOVLW 0	; Test auf >=
	SUBWF TR1_HI,W	;F-W -> W
	BTFSS STATUS,ZERO
	GOTO LABEL_TR1_CHECK
	MOVLW 12
	SUBWF TR1,W	;F-W -> W
LABEL_TR1_CHECK
	BTFSS STATUS,CARRY
	GOTO LABEL_TR1_ENDE
LABEL_TR1_RESET
	SUBWF TR1_HI,F	;F-W -> F
	MOVLW 12
	SUBWF TR1,F	;F-W -> F
	BTFSS STATUS,CARRY
	DECF TR1_HI,F
LABEL_TR1_SET	; toggel output
	BTFSC S5,2
	GOTO LABEL_TR1_CLR
	BSF S5,2
	GOTO LABEL_TR1_ENDE
LABEL_TR1_CLR
	BCF S5,2
LABEL_TR1_ENDE
; RS-FLIP-FLOP -> RS1
	BTFSC S5,5
	GOTO LABEL_RS1_RESET
	BTFSS S5,4
	GOTO LABEL_RS1_ENDE
	BSF S5,3	; Ausgang setzen
	GOTO LABEL_RS1_ENDE
LABEL_RS1_RESET
	BCF S5,3	; Ausgang zurücksetzen
LABEL_RS1_ENDE
; One Shot -> OS1
	BTFSS S5,2
	GOTO LABEL_OS1_1
	BTFSC OS1_FD,0
	GOTO LABEL_OS1_1
	BSF OS1_FD,0
	BSF S5,6
	GOTO LABEL_OS1_2
LABEL_OS1_1
	BCF S5,6
	BTFSC S5,2
	GOTO LABEL_OS1_2
	BCF OS1_FD,0
LABEL_OS1_2
; UND - Gatter -> LG1
LABEL_LG1_1
	BTFSS S5,3
	GOTO LABEL_LG1_FALSE
LABEL_LG1_2
	BTFSS S5,6
LABEL_LG1_TRUE
	BSF S5,5
	GOTO LABEL_LG1_ENDE
LABEL_LG1_FALSE
	BCF S5,5
LABEL_LG1_ENDE
; UND - Gatter -> LG2
LABEL_LG2_1
	BTFSS S5,6
	GOTO LABEL_LG2_FALSE
LABEL_LG2_2
	BTFSC S5,3
LABEL_LG2_TRUE
	BSF S5,4
	GOTO LABEL_LG2_ENDE
LABEL_LG2_FALSE
	BCF S5,4
LABEL_LG2_ENDE
; Verteiler -> BV2
	MOVLW 0 
	BTFSC S5,3	; IN0
	IORLW 1
	MOVWF S4	; OUT
; UND - Gatter -> LG3
LABEL_LG3_1
	BTFSS S5,3
	GOTO LABEL_LG3_FALSE
LABEL_LG3_TRUE
	BCF PORTB,0
	GOTO LABEL_LG3_ENDE
LABEL_LG3_FALSE
	BSF PORTB,0
LABEL_LG3_ENDE
; UND - Gatter -> LG4
LABEL_LG4_1
	BTFSS S5,3
	GOTO LABEL_LG4_FALSE
LABEL_LG4_TRUE
	BSF PORTB,1
	GOTO LABEL_LG4_ENDE
LABEL_LG4_FALSE
	BCF PORTB,1
LABEL_LG4_ENDE
; One Shot -> OS2
	BTFSC PORTB,2
	GOTO LABEL_OS2_1
	BTFSC OS2_FD,0
	GOTO LABEL_OS2_1
	BSF OS2_FD,0
	BSF S5,0
	GOTO LABEL_OS2_2
LABEL_OS2_1
	BCF S5,0
	BTFSS PORTB,2
	GOTO LABEL_OS2_2
	BCF OS2_FD,0
LABEL_OS2_2
	GOTO MAIN
	END
