PIC Microcontroller NoteThe firmware ( source code in C ) written in MikroC
//6 digit  clock
//Using timer1 16bit counter interrupt
// PIC16F627A or PIC16F628
// Internal Clock 4MHz
// PUNKKY@gmail.com
#define MODE PORTB.F4
#define SET PORTB.F5
#define Sec_port_l PORTA.F6
#define Sec_port_h PORTA.F4
#define Min_port_l PORTA.F3
#define Min_port_h PORTA.F2
#define Hr_port_l PORTA.F1
#define Hr_port_h PORTA.F0
#define Blink PORTA.F7
#define HTMR1 0x80
#define LTMR1 0x00
typedef unsigned short uns8;
uns8 i;
uns8 hr_h;
uns8 hr_l;
uns8 min_h;
uns8 min_l;
uns8 sec_h;
uns8 sec_l;
uns8 tick;
uns8 myTimer;
uns8 setting_time;
void setup ();
void set_time ();
void show_time ();
void display (uns8 digit);
void blink_digit (uns8 digit);
void check_bt ();
//void check_bt(); //chech button
void interrupt ()
        PIR1.TMR1IF = 0;
        // clears TMR1IF
        TMR1H = HTMR1;
        tick = 1;
        Blink = 1;
        sec_l ++;
        if(sec_l>9){
            sec_l = 0;
            sec_h++;
        if(sec_h>5){
            sec_h=0;
            min_l++;
        if(min_l>9){
            min_l = 0;
            min_h++;
        if(min_h>5){
            min_h = 0;
            hr_l++;
        if(hr_l>9){
            hr_l = 0;
            hr_h++;
        if(hr_h >2){
            hr_h = 0;
        if(hr_h >=2 && hr_l>3){
           hr_h = 0;
           hr_l = 0;
void main ()
        setup ();
        //Set time
        hr_h = 1;
        hr_l = 2;
        min_h = 3;
        min_l = 4;
        sec_h = 5;
        sec_l = 6;
        show_time ();
        setting_time = 1;
        set_time();
        while (1)
                //blink_digit();
                if (tick)
                        tick = 0;
                        show_time ();
                        Delay_ms (300);
                        Blink = 0;
                check_bt ();
void setup ()
        tick = 0;
//Digital output on PORTA
        CMCON = 0x07;
        //Input buttons + external clock
        TRISB = 0xB0;
        PORTB = 0x00;
        TRISA = 0x00;
        PORTA = 0x00;
        //Internal Clock 4MHz
        PCON.OSCF = 1;
        // Prescaler 1:1   external clock
        T1CON = 0x0F;
        PIE1.TMR1IE = 0;  // disable interupt to stop the clock
        INTCON = 0xC0;
        // Set GIE, PEIE
        TMR1L = LTMR1;
        TMR1H = HTMR1;
        // TMR1 starts at 0x0BDC = 3036 to make TMR1 counts to 62500 and
        // overclows in every 0.1 sec
        // Math: 1/500000*8*62500 = 0.1
        // 1/5000000 : time for 20MHz crystal (internal clock will be 20/4 = 5MHz)
        // 8: prescaler
        // 62500: TMR1 counts to 62500
        // Counting number of overflows to 10 will get 1 sec.
void show_time ()
        display (1);
        display (2);
        display (3);
        display (4);
        display (5);
        display (6);
        switch (digit)
                case 1 :
                PORTB = hr_h;
                Hr_port_h = 1;
                Hr_port_h = 0;
                break;
                case 2 :
                PORTB = hr_l;
                Hr_port_l = 1;
                Hr_port_l = 0;
                break;
                case 3 :
                PORTB = min_h;
                Min_port_h = 1;
                Min_port_h = 0;
                break;
                case 4 :
                PORTB = min_l;
                Min_port_l = 1;
                Min_port_l = 0;
                break;
                case 5 :
                PORTB = sec_h;
                Sec_port_h = 1;
                Sec_port_h = 0;
                break;
                case 6 :
                PORTB = sec_l;
                Sec_port_l = 1;
                Sec_port_l = 0;
                break;
        switch (digit)
                case 1 :
                PORTB = 0xFF;
                Hr_port_h = 1;
                Hr_port_h = 0;
                Delay_ms (100);
                display (1);
                Delay_ms (100);
                break;
                case 2 :
                PORTB = 0xFF;
                Hr_port_l = 1;
                Hr_port_l = 0;
                Delay_ms (100);
                display (2);
                Delay_ms (100);
                break;
                case 3 :
                PORTB = 0xFF;
                Min_port_h = 1;
                Min_port_h = 0;
                Delay_ms (100);
                display (3);
                Delay_ms (100);
                break;
                case 4 :
                PORTB = 0xFF;
                Min_port_l = 1;
                Min_port_l = 0;
                Delay_ms (100);
                display (4);
                Delay_ms (100);
                break;
                case 5 :
                PORTB = 0xFF;
                Sec_port_h = 1;
                Sec_port_h = 0;
                Delay_ms (100);
                display (5);
                Delay_ms (100);
                break;
                case 6 :
                PORTB = 0xFF;
                Sec_port_l = 1;
                Sec_port_l = 0;
                Delay_ms (100);
                display (6);
                Delay_ms (100);
                break;
void set_time ()
        i = 1;
        while (setting_time)
                blink_digit (i);
                while (SET == 0)
                        Delay_ms (5);
                        switch (i)
                                case 1 :
                                hr_h ++;
                                if (hr_h > 2)
                                        hr_h = 0;
                                break;
                                case 2 :
                                hr_l ++;
                                if (hr_l > 9)
                                        hr_l = 0;
                                if (hr_h >= 2 && hr_l > 3)
                                        hr_l = 0;
                                break;
                                case 3 :
                                min_h ++;
                                if (min_h > 5)
                                        min_h = 0;
                                break;
                                case 4 :
                                min_l ++;
                                if (min_l > 9)
                                        min_l = 0;
                                break;
                                case 5 :
                                sec_h ++;
                                if (sec_h > 5)
                                        sec_h = 0;
                                break;
                                case 6 :
                                sec_l ++;
                                if (sec_l > 9)
                                        sec_l = 0;
                                break;
                        while (SET == 0)
                                Delay_ms (5);
                while (MODE == 0)
                        Delay_ms (5);
                        i ++;
                        if (i > 6)
        sec_l--;
        TMR1H = 0x80;
        TMR1L = 0x00;
        PIE1.TMR1IE = 1;
        setting_time = 0;
                                break;
                        while (MODE == 0)
                                Delay_ms (5);
void check_bt ()
        myTimer = 0;
        if (setting_time == 0)
                while (MODE == 0)
                        Delay_ms (5);
                        myTimer ++;
                        if (myTimer > 200)
                                setting_time = 1;
                                myTimer = 0;
                                break;
        while (MODE == 0)
                PIE1.TMR1IE = 0;
                //Stop clock
                Delay_ms (5);
                blink_digit (1);
        set_time ();
