; Source created with Parsic Version 3.x
; at              : 2009.02.13. 20:16:37
; Project File    : C:\PROGRA~1\Parsic\ÁTJ_01.PIC
; Project Version : 1.0.3
; Created         : 2009.02.11. 20:53:00
; Last change     : 2009.02.13. 20:14:25
	PROCESSOR 16F628
	INCLUDE P16F628.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_ON & _WDT_OFF & _BODEN_ON & _XT_OSC & _LVP_OFF & _MCLRE_ON
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
UD1_FD	= 32	; located in Bank 0
S0	= 33	; located in Bank 0
UD2_FD	= 34	; located in Bank 0
UA1RSFLAG	= 35	; located in Bank 0
CIM	= 36	; located in Bank 0
MF1	= 37	; located in Bank 0
MF1_HI	= 38	; located in Bank 0
OS1_FD	= 39	; located in Bank 0
OS2_FD	= 40	; located in Bank 0
OS3_FD	= 41	; located in Bank 0
UA1OUTBUF	= 42	; located in Bank 0
UA1OUTBUF1	= 43	; located in Bank 0
UA1OUTBUF2	= 44	; located in Bank 0
UA1OUTBUF3	= 45	; located in Bank 0
UA1INBUF	= 46	; located in Bank 0
UA1INBUF1	= 47	; located in Bank 0
UA1INBUF2	= 48	; located in Bank 0
UA1INBUF3	= 49	; located in Bank 0
UA1INBUF4	= 50	; located in Bank 0
RAM	= 51	; located in Bank 0
SYS_WSAV	= 112	; located in Bank 0, 1, 2, 3
SYS_SSAV	= 113	; located in Bank 0, 1, 2, 3
SYS_FSAV	= 114	; located in Bank 0, 1, 2, 3
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	CLRF STATUS	; switch to RAM-Bank 0
	GOTO SYS_INIT
	NOP
	NOP
;Interrupt-Adress
	MOVWF SYS_WSAV	; save register
	SWAPF STATUS,W
	CLRF STATUS	; bank 0
	MOVWF SYS_SSAV
	MOVFW FSR
	MOVWF SYS_FSAV
	BTFSS INTCON,T0IF	; TMR0 ?
	GOTO NOTMR0INT
	BCF INTCON,T0IF	; Interrupt quitieren
	BCF STATUS,RP0	; Bank 0
	BCF STATUS,RP1	; Bank 0
	INCFSZ MF1,F
	GOTO SYS_INT_LABEL_0
	INCF MF1_HI,F
SYS_INT_LABEL_0
NOTMR0INT
; UART -> UA1
	BTFSS PIR1,RCIF	; byte received?
	GOTO UA1CHKTX	; no
	MOVFW RCSTA	; error ?
	ANDLW B'110'
	BTFSS STATUS,ZERO
	GOTO UA1RCERROR	; yes
	MOVFW UA1INBUF+1	; all received ? 
	BTFSC STATUS,ZERO	; length =0 ?
	GOTO UA1RCINT2	; yes
	ERRORLEVEL -312
	BANKISEL UA1INBUF
	ERRORLEVEL +312
	MOVFW UA1INBUF
	MOVWF FSR
	INCF UA1INBUF,F	; pointer+1
	MOVFW RCREG	; store
	MOVWF INDF
	ADDWF UA1INBUF+2,F	; checksum
	DECFSZ UA1INBUF+1,F	; length-1
	GOTO EXITINT
	SUBWF UA1INBUF+2,F	; checksum
	BSF UA1RSFLAG,0		; ready
	GOTO EXITINT
UA1RCINT2
	MOVFW RCREG	; trash
	GOTO EXITINT
UA1RCERROR
	MOVFW RCREG	; reset error status
	BCF RCSTA,CREN
	BSF RCSTA,CREN
	BSF UA1RSFLAG,1	; error
	GOTO EXITINT
UA1CHKTX
	BTFSS PIR1,TXIF	; send byte ?
	GOTO UA1ENDINT	; no
	MOVFW UA1OUTBUF+1	; all transmitted ? 
	BTFSC STATUS,ZERO
	GOTO UA1TXINT1
	ERRORLEVEL -312
	BANKISEL UA1OUTBUF	; FILE INDIREKT
	ERRORLEVEL +312
	MOVFW UA1OUTBUF	; pointer
	INCF UA1OUTBUF,F	; pointer+1
	MOVWF FSR
	MOVFW INDF	; data
	MOVWF TXREG	; Transmit Register
	DECF UA1OUTBUF+1,F	; length-1
	GOTO EXITINT	; that's all
UA1TXINT1
	BSF STATUS,RP0	; Bank 1
	BCF STATUS,RP1	; Bank 1
	BTFSS TXSTA,TRMT	; last byte transmitted ?
	GOTO EXITINT	; no
	BCF TXSTA,TXEN	; transmitter off
	BSF UA1RSFLAG,2	; ready
	GOTO EXITINT
UA1ENDINT
EXITINT
	MOVFW SYS_FSAV
	MOVWF FSR
	SWAPF SYS_SSAV,W	; Register zurück
	MOVWF STATUS
	SWAPF SYS_WSAV,F
	SWAPF SYS_WSAV,W
	RETFIE
; Subroutines
;Initialisierung
SYS_INIT
	MOVLW B'00100000'
	MOVWF INTCON
; Set output before direction
	MOVLW B'00000000'
	MOVWF PORTA
	MOVLW B'00000100'
	MOVWF PORTB
	MOVLW 15
	MOVWF OPTION_REG
; Richtung setzen
	MOVLW B'11111111'
	MOVWF TRISA
	MOVLW B'11111011'
	MOVWF TRISB
	MOVLW 7	; Comparators off
	MOVWF CMCON
; init vars
; Clear RAM
	BCF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	BTFSS FSR,7
	GOTO CR1
	BSF FSR,5
CR2
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR2
	BSF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR3
	CLRF INDF
	INCF FSR,F
	MOVLW H'50'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR3
; initalisize UA1
	MOVLW B'10010000'	; serial enable,8-bit,continous-enable
	MOVWF RCSTA
	MOVLW 25
	MOVWF SPBRG	; BAUDRATE GENERATOR
	MOVLW B'00000100'	; 8-BIt,TRANSMIT DISABLED,ASYNCHRON,BRGH=1=HIGH SPEED
	MOVWF TXSTA
	BSF PIE1,TXIE	; enable INTERRUPT for transmit
	BSF PIE1,RCIE	; enable INTERRUPT for receive
	BSF INTCON,PEIE	; PERIPHERIE INT ENABLE
	CLRF TMR0
	BCF INTCON,T0IF
	BSF INTCON,GIE	; Interrupt freigeben
;******* Haupt-Programm ***********
MAIN
; UDATA -> UD1
	BTFSC S0,0	; active
	GOTO LABEL_UD1_1	; yes
; test positive edge
	BTFSS S0,1
	GOTO LABEL_UD1_SETFD
	BTFSC UD1_FD,0
	BSF UD1_FD,0
	BCF UA1RSFLAG,0	; set nothing received
	BCF UA1RSFLAG,1	; set no error
	BSF S0,0	; active
	MOVLW LOW UA1INBUF+3	; set pointer (adress)
	MOVWF UA1INBUF
	MOVLW H'AA'	; init checksum
	MOVWF UA1INBUF+2
	MOVLW 2	; 2 bytes
	MOVWF UA1INBUF+1
LABEL_UD1_1
	BTFSC UA1RSFLAG,1	; error ?
	GOTO LABEL_UD1_3	; break
	BTFSS UA1RSFLAG,0	; received ?
	GOTO LABEL_UD1_2	; no
	MOVFW UA1INBUF+2	; checksum
	SUBWF UA1INBUF+4,W	; checksum
	BTFSS STATUS,ZERO
	BCF INTCON,GIE	; disable interrupts
	BTFSC INTCON,GIE	; disabled ?
	GOTO $-2	; no
	MOVFW UA1INBUF+3
	MOVWF CIM
	BSF INTCON,GIE	; enable interrupts
LABEL_UD1_3
	BCF S0,0	; not active
LABEL_UD1_2
LABEL_UD1_SETFD
; test negative edge
	BTFSC S0,1
	GOTO LABEL_UD1_EXIT
	BCF UD1_FD,0
LABEL_UD1_EXIT
; UDATA -> UD2
	BTFSC S0,7	; active
	GOTO LABEL_UD2_1	; yes
	BTFSS S0,4
	GOTO LABEL_UD2_SETFD
	BTFSC UD2_FD,0
	BSF UD2_FD,0
	BCF UA1RSFLAG,2		; set not ready
	BSF S0,7	; active
	MOVLW LOW UA1OUTBUF+2	; set pointer (ADRESS)
	MOVWF UA1OUTBUF
	MOVWF UA1OUTBUF+3
	MOVLW 2	; 2 bytes
	MOVWF UA1OUTBUF+1
	GOTO $-2	; no
	MOVFW CIM
	MOVWF UA1OUTBUF+2
	ADDWF UA1OUTBUF+3,F
	BSF TXSTA,TXEN
LABEL_UD2_1
	BTFSS UA1RSFLAG,2	; transmit ready ?
	GOTO LABEL_UD2_2	; no
	BCF S0,7	; not active
LABEL_UD2_2
LABEL_UD2_SETFD
	BTFSC S0,4
	GOTO LABEL_UD2_EXIT
	BCF UD2_FD,0
LABEL_UD2_EXIT
; Anzug-Verzögerung -> MF1
	BTFSS S0,0	; Eingang auf Low ?
	GOTO LABEL_MF1_CHKTIME	; Ja
; RESET
	CLRF MF1
	CLRF MF1_HI
	BCF S0,2
	GOTO LABEL_MF1_EXIT	; raus
LABEL_MF1_CHKTIME
	BTFSC S0,2	; Ausgang schon auf High ?
	GOTO LABEL_MF1_EXIT	; Ja
	MOVLW 0
	SUBWF MF1_HI,W
	BTFSS STATUS,CARRY
	GOTO LABEL_MF1_EXIT
	MOVLW 78
	SUBWF MF1,W
	BTFSS STATUS,CARRY
	GOTO LABEL_MF1_EXIT
	BSF S0,2
LABEL_MF1_EXIT
; One Shot -> OS1
	BTFSS S0,2
	GOTO LABEL_OS1_1
	BTFSC OS1_FD,0
	GOTO LABEL_OS1_1
	BSF OS1_FD,0
	BSF S0,3
	GOTO LABEL_OS1_2
LABEL_OS1_1
	BCF S0,3
	BTFSC S0,2
	GOTO LABEL_OS1_2
	BCF OS1_FD,0
LABEL_OS1_2
; One Shot -> OS2
	BTFSC S0,3
	GOTO LABEL_OS2_1
	BTFSC OS2_FD,0
	GOTO LABEL_OS2_1
	BSF OS2_FD,0
	BSF S0,5
	GOTO LABEL_OS2_2
LABEL_OS2_1
	BCF S0,5
	BTFSS S0,3
	GOTO LABEL_OS2_2
	BCF OS2_FD,0
LABEL_OS2_2
; RS-FLIP-FLOP -> RS1
	BTFSC S0,6
	GOTO LABEL_RS1_RESET
	BTFSS S0,3
	GOTO LABEL_RS1_ENDE
	BSF S0,4	; Ausgang setzen
	GOTO LABEL_RS1_ENDE
LABEL_RS1_RESET
	BCF S0,4	; Ausgang zurücksetzen
LABEL_RS1_ENDE
; One Shot -> OS3
	BTFSC S0,5
	GOTO LABEL_OS3_1
	BTFSC OS3_FD,0
	GOTO LABEL_OS3_1
	BSF OS3_FD,0
	BSF S0,6
	GOTO LABEL_OS3_2
LABEL_OS3_1
	BCF S0,6
	BTFSS S0,5
	GOTO LABEL_OS3_2
	BCF OS3_FD,0
LABEL_OS3_2
; UND - Gatter -> LG1
LABEL_LG1_1
	BTFSC S0,4
	GOTO LABEL_LG1_FALSE
LABEL_LG1_TRUE
	BSF S0,1
	GOTO LABEL_LG1_ENDE
LABEL_LG1_FALSE
	BCF S0,1
LABEL_LG1_ENDE
	GOTO MAIN
	END
