; Source created with Parsic Version 3.x
; at              : 2009.02.15. 16:11:30
; Project File    : C:\PROGRA~1\Parsic\HE\ADledlin.PIC
; Project Version : 1.0.11
; Created         : 2005.05.15. 21:34:00
; Last change     : 2009.02.15. 16:11:28
	PROCESSOR 16F877
	INCLUDE P16F877.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_ON & _WDT_OFF & _BODEN_ON & _XT_OSC & _LVP_OFF & _CPD_OFF & _DEBUG_OFF
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
S0	= 32	; located in Bank 0
S0_HI	= 33	; located in Bank 0
S1	= 34	; located in Bank 0
S1_HI	= 35	; located in Bank 0
S2	= 36	; located in Bank 0
S2_HI	= 37	; located in Bank 0
ADC0	= 38	; located in Bank 0
ADC0_HI	= 39	; located in Bank 0
RAM	= 40	; located in Bank 0
SYS_TMP1	= 114	; located in Bank 0, 1, 2, 3
SYS_TMP2	= 115	; located in Bank 0, 1, 2, 3
SYS_TMP3	= 116	; located in Bank 0, 1, 2, 3
SYS_TMP4	= 117	; located in Bank 0, 1, 2, 3
SYS_TMP5	= 118	; located in Bank 0, 1, 2, 3
SYS_TMP6	= 119	; located in Bank 0, 1, 2, 3
SYS_TMP7	= 120	; located in Bank 0, 1, 2, 3
SYS_FSAV	= 121	; located in Bank 0, 1, 2, 3
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	CLRF STATUS	; switch to RAM-Bank 0
	MOVLW HIGH SYS_INIT	; set page
	MOVWF PCLATH
	GOTO SYS_INIT
	RETURN
; Division 16 - Bit
; OP1 = SYS_TMP1,2
; OP2 = SYS_TMP3,4
SYSDIV16
	MOVFW SYS_TMP3	; Division durch 0 ?
	IORWF SYS_TMP4,W
	BTFSC STATUS,ZERO
	GOTO SYSDIV16_ERROR
	CLRF SYS_TMP5	; Ergebnis löschen
	CLRF SYS_TMP6
	MOVLW 1
	MOVWF SYS_TMP7
SYSDIV16_0
	BTFSC SYS_TMP4,7	; OP2 linksbündig
	GOTO SYSDIV16_1
	INCF SYS_TMP7,F
	BCF STATUS,CARRY
	RLF SYS_TMP3,F
	RLF SYS_TMP4,F
	GOTO SYSDIV16_0
SYSDIV16_1
	MOVFW SYS_TMP4	; OP1 und OP2 vergleichen
	SUBWF SYS_TMP2,W	; F-W -> W
	BTFSS STATUS,ZERO
	GOTO SYSDIV16_2
	MOVFW SYS_TMP3
	SUBWF SYS_TMP1,W	; F-W -> W
SYSDIV16_2
	BTFSS STATUS,CARRY
	GOTO SYSDIV16_3
	MOVFW SYS_TMP4	; OP1-OP2
	SUBWF SYS_TMP2,F	; F-W -> F
	MOVFW SYS_TMP3
	SUBWF SYS_TMP1,F	; F-W -> F
	BTFSS STATUS,CARRY
	DECF SYS_TMP2,F
	BSF STATUS,CARRY
SYSDIV16_3
	RLF SYS_TMP5,F	; Ergebnis aktualisieren
	RLF SYS_TMP6,F
	RRF SYS_TMP4,F	; OP2 nach rechts schieben
	RRF SYS_TMP3,F
	DECFSZ SYS_TMP7,F	; Zähler -1
	GOTO SYSDIV16_1
	RETURN
SYSDIV16_ERROR
	MOVLW 255
	MOVWF SYS_TMP5
	MOVWF SYS_TMP6
	RETURN
; Subroutines
; Direct jump into a table
SYSTABJMP
	BCF INTCON,GIE
	BTFSC INTCON,GIE
	GOTO SYSTABJMP
	MOVFW SYS_TMP2
	MOVWF PCLATH
	MOVFW SYS_TMP1
	MOVWF PCL
; Read  -> AN0
READ_AN0
	MOVLW B'100'
	BSF STATUS,RP0	; Bank 1
	BCF STATUS,RP1	; Bank 1
	MOVWF ADCON1
	BSF TRISA,0
	BSF ADCON1,ADFM	; Right-Justified
	MOVLW B'11000001'	; CH0
	BCF STATUS,RP0	; Bank 0
	MOVWF ADCON0
	MOVLW 5
	MOVWF SYS_TMP1
SYS_ADC_LABEL_0
	DECFSZ SYS_TMP1,F
	GOTO SYS_ADC_LABEL_0
	BSF ADCON0,GO	; Start convert
SYS_ADC_LABEL_1
	BTFSC ADCON0,GO	; ready ?
	GOTO SYS_ADC_LABEL_1	; no
	MOVFW ADRESL
	MOVWF ADC0
	MOVFW ADRESH
	MOVWF ADC0_HI
	MOVLW 6
	MOVWF ADCON1
	MOVLW B'11111111'
	MOVWF TRISA
	RETURN
;Initialisierung
SYS_INIT
	MOVLW B'00000000'
	MOVWF INTCON
; Set output before direction
	BCF STATUS,RP1	; Bank 0
	MOVLW B'00000000'
	MOVWF PORTA
	MOVLW B'00000000'
	MOVWF PORTB
	MOVLW B'00000000'
	MOVWF PORTC
	MOVLW B'00000000'
	MOVWF PORTD
	MOVLW B'00000000'
	MOVWF PORTE
	MOVLW 143
	MOVWF OPTION_REG
	MOVLW 6	; all Digital
	MOVWF ADCON1
; Richtung setzen
	MOVLW B'11111111'
	MOVWF TRISA
	MOVLW B'00000000'
	MOVWF TRISB
	MOVLW B'11111111'
	MOVWF TRISC
	MOVLW B'11111111'
	MOVWF TRISD
	MOVLW B'00000111'
	MOVWF TRISE
; init vars
; Clear RAM
	BCF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	BTFSS FSR,7
	GOTO CR1
	BSF FSR,5
CR2
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR2
	BSF STATUS,IRP
	MOVLW 16
	MOVWF FSR
CR3
	CLRF INDF
	INCF FSR,F
	MOVLW H'70'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR3
	MOVLW 144
	MOVWF FSR
CR4
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR4
;******* Haupt-Programm ***********
MAIN
	CALL READ_AN0
; Verteiler -> BV1
	BTFSC S0,0
	GOTO LABEL_BV1_0
	BCF PORTB,0
	GOTO LABEL_BV1_0_END
LABEL_BV1_0
	BSF PORTB,0
LABEL_BV1_0_END
	BTFSC S0,1
	GOTO LABEL_BV1_1
	BCF PORTB,1
	GOTO LABEL_BV1_1_END
LABEL_BV1_1
	BSF PORTB,1
LABEL_BV1_1_END
	BTFSC S0,2
	GOTO LABEL_BV1_2
	BCF PORTB,2
	GOTO LABEL_BV1_2_END
LABEL_BV1_2
	BSF PORTB,2
LABEL_BV1_2_END
	BTFSC S0,3
	GOTO LABEL_BV1_3
	BCF PORTB,3
	GOTO LABEL_BV1_3_END
LABEL_BV1_3
	BSF PORTB,3
LABEL_BV1_3_END
	BTFSC S0,4
	GOTO LABEL_BV1_4
	BCF PORTB,4
	GOTO LABEL_BV1_4_END
LABEL_BV1_4
	BSF PORTB,4
LABEL_BV1_4_END
	BTFSC S0,5
	GOTO LABEL_BV1_5
	BCF PORTB,5
	GOTO LABEL_BV1_5_END
LABEL_BV1_5
	BSF PORTB,5
LABEL_BV1_5_END
	BTFSC S0,6
	GOTO LABEL_BV1_6
	BCF PORTB,6
	GOTO LABEL_BV1_6_END
LABEL_BV1_6
	BSF PORTB,6
LABEL_BV1_6_END
	BTFSC S0,7
	GOTO LABEL_BV1_7
	BCF PORTB,7
	GOTO LABEL_BV1_7_END
LABEL_BV1_7
	BSF PORTB,7
LABEL_BV1_7_END
; Call subroutine BYTE_LIN
	MOVLW LOW BYTE_LIN
	MOVWF SYS_TMP1
	MOVLW HIGH BYTE_LIN
	MOVWF SYS_TMP2
	BCF STATUS,CARRY
	RLF S1,W
	ADDWF SYS_TMP1,F
	BTFSC STATUS,CARRY
	INCF SYS_TMP2,F
	MOVLW HIGH SYSTABJMP	; set page
	MOVWF PCLATH
	CALL SYSTABJMP
	MOVWF S0
	INCF SYS_TMP1,F
	BTFSC STATUS,ZERO
	INCF SYS_TMP2,F
	MOVWF PCLATH
	CALL SYSTABJMP
	MOVWF S0_HI
	BSF INTCON,GIE
	BCF PCLATH,3	; Page 0
	BCF PCLATH,4	; Page 0
;AF1
	MOVFW S2
	MOVWF SYS_TMP1
	MOVFW S2_HI
	MOVWF SYS_TMP2
	MOVLW LOW 128
	MOVWF SYS_TMP3
	MOVLW HIGH 128
	MOVWF SYS_TMP4
	MOVLW HIGH SYSDIV16
	MOVWF PCLATH
	CALL SYSDIV16
	MOVLW HIGH LABEL_AF1
	MOVWF PCLATH
LABEL_AF1
	MOVFW SYS_TMP5
	MOVWF S1
	MOVFW SYS_TMP6
	MOVWF S1_HI
LABEL_AF1_EXIT
;AF2
	MOVFW ADC0_HI
	ADDLW HIGH 1
	MOVWF S2_HI
	MOVFW ADC0
	ADDLW LOW 1
	MOVWF S2
	BTFSC STATUS,CARRY
	INCF S2_HI,F
LABEL_AF2_EXIT
	GOTO MAIN
; Table -> BYTE_LIN
BYTE_LIN
	RETLW 0	; // INDEX 0
	RETLW 1	; // INDEX 1
	RETLW 0	; // INDEX 1
	RETLW 3	; // INDEX 2
	RETLW 0	; // INDEX 2
	RETLW 7	; // INDEX 3
	RETLW 0	; // INDEX 3
	RETLW 15	; // INDEX 4
	RETLW 0	; // INDEX 4
	RETLW 31	; // INDEX 5
	RETLW 0	; // INDEX 5
	RETLW 63	; // INDEX 6
	RETLW 0	; // INDEX 6
	RETLW 127	; // INDEX 7
	RETLW 0	; // INDEX 7
	RETLW 255	; // INDEX 8
	RETLW 0	; // INDEX 8
	RETLW 9	; // INDEX 9
	RETLW 0	; // INDEX 9
	END
