8 Channel PWM LED Chaser for PIC 16F628A
http://picprojects.org.uk
Release data 01/11/2008
Web Version 1.0.3
Unzip all files to a single directory
pwmc_main103.HEX is ready to program into PIC 16F628 / 16F628A
If you don't want to use the MPLAB IDE to edit and assemble the code you can
use the assemble.bat file in this zip file to assemble changes.
You must still download and install Microchip MPLAB IDE from the Microchip
website to install the required MPASM assembler.
Once you've edited your sequences in the pmwc_SeqDat.inc file, run
assemble.bat to assemble the source code to a new hex file.
The output hex file is pwmc_main103.HEX
If there are any errors you must fix these before attempting to program the
hex file into the PIC.
