; PICStep v2.0 Firmware - PIC based microstepping motor controller
; Copyright (C) 2004 Alan Garfield <alan@fromorbit.com>
; This program is free software; you can redistribute it and/or
; modify it under the terms of the GNU General Public License
; as published by the Free Software Foundation; either version 2
; of the License, or (at your option) any later version.
; This program is distributed in the hope that it will be useful,
; but WITHOUT ANY WARRANTY; without even the implied warranty of
; MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
; GNU General Public License for more details.
; You should have received a copy of the GNU General Public License
; along with this program; if not, write to the Free Software
; Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA  02111-1307, USA.
 title "PICStep V2.0"
  LIST R=DEC
  #INCLUDE P16F628A.INC
  #define TIMEOUT_ENABLED
; Registers
  UDATA 0x020
step 			RES 1
portA_shadow 	RES 1
mode 			RES 1
lookup 			RES 1
temp			RES 1
timeout_reg		RES 1
timeout			RES 2
_w				RES 1
_status			RES 1
_fsr			RES 1
_pclath			RES 1
 __CONFIG _CP_OFF & _WDT_ON & _HS_OSC & _PWRTE_ON & _LVP_OFF & _BOREN_ON & _MCLRE_OFF
  org		0
  goto		Mainline		; Main line vector
  org 4
  goto		Interupt		; Interupt vector
CODE
Interupt
; Save Current Context
	movwf		_w				
	movf		STATUS, w
	bcf			STATUS, RP1
	bcf			STATUS, RP0
	movwf		_status
	movf		FSR, w
	movwf		_fsr
	movf		PCLATH, w
	movwf		_pclath
	clrf		PCLATH
; Interrupt service routine
	btfsc		INTCON, INTF
	  call INTB0				; Call INTBO interrupt handler
#ifdef TIMEOUT_ENABLED
	btfsc		PIR1, TMR2IF
	  call TIMEOUT				; Call TIMEOUT interrupt handler
#endif
; Reset Current Context
	movf		_pclath, w
	movwf		PCLATH
	movf		_fsr, w
	movwf		FSR
	movf		_status, w
	movwf		STATUS
	swapf		_w, f
	swapf		_w, w
	retfie
INTB0
; Handle interupt on RB0
	clrf		timeout  		; Reset timeout timer and register
	clrf		timeout + 1
	clrf		timeout_reg
#endif
; Advance the index position
	movlw		HIGH MODE_TABLE
	movwf		PCLATH
	movf		mode, w			; Load the current mode
	call		MODE_TABLE		; Get the advance value for this mode
	movwf		lookup			; Store it for later
	btfss		PORTB, 1		; Check on the direction pin (RB1)
	  goto		$ + 4			; Jump over step addition
	addwf		step, w			; Add the current mode to the current position value
	movwf		step			; Update step
	goto		$ + 3			; Jump over step subtraction
	subwf		step, w			; Subtract the current mode from the current position value
; Bounds check the table
	movlw		0x040			; Check if step has overflowed the edge of the table
	subwf		step, w
	btfsc		STATUS, Z
	  clrf		step
	movf		lookup, w		; Check if step has underflowed the edge of the table
	sublw		0x040
	subwf		step, w
	btfsc		STATUS, C
	  subwf		step, f
; Process DAC A
	movlw		HIGH STEP_TABLE_A
	movwf		PCLATH
	movf		step, w			; Reload step into w
	call		STEP_TABLE_A	; Get the result from the table
	movwf		lookup			; Store the fetched results for later
	  rlf		lookup, w		; Rotate to the alternate direction bit to fix a bug in LMD
	xorwf		PORTB, w		; Prepare the direction bit for DAC A
	andlw		B'10000000'		; Mask out the direction bit
	xorwf		PORTB, f		; Output the direction bit
	movf		lookup, w		; Reload the fetched table results
	andlw		B'00001111'		; Mask out the upper nibble
	movwf		PORTA			; Output the DAC results for A
; Process DAC B
	movlw		HIGH STEP_TABLE_B
	movwf		PCLATH
	call		STEP_TABLE_B	; Get the result from the table
	xorwf		PORTB, w		; Prepare the direction bit for DAC B
	andlw		B'01000000'		; Mask out the direction bit
	rlf			lookup, f		; Rotate lookup left in place
	rlf			lookup, w		; Rotate again but into WREG
	xorwf		PORTB, w
	andlw		B'00111100'		; Mask out the not needed bits
	xorwf		PORTB, f		; Output the DAC results for B  
	bcf			INTCON, INTF	; Clear RB0 Interrupt flag
	return
TIMEOUT
; Handle motor timeout TMR2 interrupt and return ASAP
	bsf			timeout_reg, 7	; Set the timeout bit so the count can increment
	bcf			PIR1, TMR2IF	; Clear TMR2 Interrupt flag
	return
#endif
Mainline
; Initialize Variables
	clrf		step
	clrf		mode
	clrf		lookup
	clrf		timeout  
	clrf		timeout + 1
	clrf		timeout_reg
#endif
; Setup I/O ports / Timers
	clrf		PORTA 			;Initialize PORTA
	clrf		PORTB			;Initialize PORTB
	movlw		(1 << CM0) | (1 << CM1) | (1 << CM2)	;Turn comparators off and
	movwf		CMCON									;enable pins for I/O
	bcf			STATUS, RP1
	bsf			STATUS, RP0		;Select Bank1
	movlw		B'11110000'		;Set RA<0:3> as outputs
	movwf		TRISA ^ 0x080
	movlw		B'00000011'		;Set RB<2:7> as outputs
	movwf		TRISB ^ 0x080
	movlw		(1 << INTEDG)	;Setup Interupt Edge
	movwf		OPTION_REG ^ 0x080
	movlw		(1 << TMR2IE)	; Enable TMR2 Interupt
	movwf     	PIE1 ^ 0x080
	bcf			STATUS, RP0		;Select Bank0
	movlw		B'01111111'		; Turn on TMR2 with 1/16 pre and post scaler
	movwf		T2CON ^ 0x080
#endif
	movlw		(1 << GIE) | (1 << INTE) | (1 << PEIE) ; Enable global interupts, perph and RB0 Interupts
	movwf		INTCON ^ 0x080
Loop
; Clear the watchdog timer (maximum loop for entire code is ~0.18ms watchdog is 18ms plenty of time!)
	clrwdt
; Monitor the mode switches
	movf		PORTA, w
	movwf		temp
	rrf			temp, f
	rrf			temp, f
	rrf			temp, f
	rrf			temp, w
	andlw		B'00000011'
	movwf		mode
; Motor timeout counter
	btfss		timeout_reg, 7		; Check to see if a timeout interrupt has occured
	  goto		Loop
	; Timeout interrupt occured updated counter
	bcf			timeout_reg, 7		; Reset the Interrupt flag
	incfsz		timeout, w			; Increment the 16 bit timeout value
	decf		timeout + 1, f
	incf		timeout + 1, f
	movwf		timeout
	iorwf		timeout + 1, w
	movwf		timeout				; Test if the timeout value has overflowed
	btfss		STATUS, Z
	  goto		Loop
	movwf		timeout + 1
	btfss		STATUS, Z
	  goto		Loop
	incf		timeout_reg, f		; Increase the timeout reg value
	btfss		timeout_reg, 2  	; Check we've been around the 4 times of the 16 bit counter (~5 minutes 45 seconds @ 20MHz)
	  goto		Loop
; Timeout!
	clrf		PORTA				; Reset PORTA and PORTB to turn off the motors
	clrf		PORTB				; The next INTB0 will awaken them again
#endif
	goto		Loop
org 0x100
; 1/16 Step DAC A Table
STEP_TABLE_A
  addwf		PCL, 1				;Deg			DAC A
  retlw		B'01000000'			;0        0.00    0		---
  retlw		B'00000001'			;5        0.10    1
  retlw		B'00000010'			;11       0.20    2
  retlw		B'00000100'			;16       0.29    4
  retlw		B'00000101'			;22       0.38    5
  retlw		B'00000111'			;28       0.47    7
  retlw		B'00001000'			;33       0.56    8
  retlw		B'00001001'			;39       0.63    9
  retlw		B'00001010'			;45       0.71    10
  retlw		B'00001011'			;50       0.77    11
  retlw		B'00001100'			;56       0.83    12
  retlw		B'00001101'			;61       0.88    13
  retlw		B'00001101'			;67       0.92    13
  retlw		B'00001110'			;73       0.96    14
  retlw		B'00001110'			;78       0.98    14
  retlw		B'00001110'			;84       1.00    14
  retlw		B'00001111'			;90       1.00    15	---
  retlw		B'00001110'			;95       1.00    14
  retlw		B'00001110'			;101      0.98    14
  retlw		B'00001110'			;106      0.96    14
  retlw		B'00001101'			;112      0.92    13
  retlw		B'00001101'			;118      0.88    13
  retlw		B'00001100'			;123      0.83    12
  retlw		B'00001011'			;129      0.77    11
  retlw		B'00001010'			;135      0.71    10
  retlw		B'00001001'			;140      0.63    9
  retlw		B'00001000'			;146      0.56    8
  retlw		B'00000111'			;151      0.47    7
  retlw		B'00000101'			;157      0.38    5
  retlw		B'00000100'			;163      0.29    4
  retlw		B'00000010'			;168      0.20    2
  retlw		B'00000001'			;174      0.10    1
  retlw		B'10000000'			;180      0.00    0		---
  retlw		B'11000001'			;185     -0.10   -1
  retlw		B'11000010'			;191     -0.20   -2
  retlw		B'11000100'			;196     -0.29   -4
  retlw		B'11000101'			;202     -0.38   -5
  retlw		B'11000111'			;208     -0.47   -7
  retlw		B'11001000'			;213     -0.56   -8
  retlw		B'11001001'			;219     -0.63   -9
  retlw		B'11001010'			;225     -0.71   -10
  retlw		B'11001011'			;230     -0.77   -11
  retlw		B'11001100'			;236     -0.83   -12
  retlw		B'11001101'			;241     -0.88   -13
  retlw		B'11001101'			;247     -0.92   -13
  retlw		B'11001110'			;253     -0.96   -14
  retlw		B'11001110'			;258     -0.98   -14
  retlw		B'11001110'			;264     -1.00   -14
  retlw		B'11001111'			;270     -1.00   -15
  retlw		B'11001110'			;275     -1.00   -14	---
  retlw		B'11001110'			;281     -0.98   -14
  retlw		B'11001110'			;286     -0.96   -14
  retlw		B'11001101'			;292     -0.92   -13
  retlw		B'11001101'			;298     -0.88   -13
  retlw		B'11001100'			;303     -0.83   -12
  retlw		B'11001011'			;309     -0.77   -11
  retlw		B'11001010'			;315     -0.71   -10
  retlw		B'11001001'			;320     -0.63   -9
  retlw		B'11001000'			;326     -0.56   -8
  retlw		B'11000111'			;331     -0.47   -7
  retlw		B'11000101'			;337     -0.38   -5
  retlw		B'11000100'			;343     -0.29   -4
  retlw		B'11000010'			;348     -0.20   -2
  retlw		B'11000001'			;354     -0.10   -1
; 1/16 Step DAC B Table
STEP_TABLE_B
  addwf		PCL, 1				;Deg	DAC B
  retlw		B'01101111'			;0      -1.00	-15		---
  retlw		B'01101110'			;5      -1.00	-14
  retlw		B'01101110'			;11     -0.98	-14
  retlw		B'01101110'			;16     -0.96	-14
  retlw		B'01101101'			;22     -0.92	-13
  retlw		B'01101101'			;28     -0.88	-13
  retlw		B'01101100'			;33     -0.83	-12
  retlw		B'01101011'			;39     -0.77	-11
  retlw		B'01101010'			;45     -0.71	-10
  retlw		B'01101001'			;50     -0.63	-9
  retlw		B'01101000'			;56     -0.56	-8
  retlw		B'01100111'			;61     -0.47	-7
  retlw		B'01100101'			;67     -0.38	-5
  retlw		B'01100100'			;73     -0.29	-4
  retlw		B'01100010'			;78     -0.20	-2
  retlw		B'01100001'			;84     -0.10	-1
  retlw		B'00100000'			;90      0.00	 0		--- 
  retlw		B'00000001'			;95      0.10	 1
  retlw		B'00000010'			;101     0.20	 2
  retlw		B'00000100'			;106     0.29	 4	
  retlw		B'00000101'			;112     0.38	 5
  retlw		B'00000111'			;118     0.47	 7
  retlw		B'00001000'			;123     0.56	 8
  retlw		B'00001001'			;129     0.63	 9
  retlw		B'00001011'			;140     0.77	 11
  retlw		B'00001100'			;146     0.83	 12
  retlw		B'00001101'			;151     0.88	 13
  retlw		B'00001101'			;157     0.92	 13
  retlw		B'00001110'			;163     0.96	 14
  retlw		B'00001110'			;168     0.98	 14
  retlw		B'00001110'			;174     1.00	 14
  retlw		B'00001111'			;180     1.00	 15		---
  retlw		B'00001110'			;185     1.00	 14
  retlw		B'00001110'			;191     0.98	 14
  retlw		B'00001110'			;196     0.96	 14
  retlw		B'00001101'			;202     0.92	 13
  retlw		B'00001101'			;208     0.88	 13
  retlw		B'00001100'			;213     0.83	 12
  retlw		B'00001011'			;219     0.77	 11
  retlw		B'00001010'			;225     0.71	 10
  retlw		B'00001001'			;230     0.63	 9
  retlw		B'00001000'			;236     0.56	 8
  retlw		B'00000111'			;241     0.47	 7
  retlw		B'00000101'			;247     0.38	 5
  retlw		B'00000100'			;253     0.29	 4
  retlw		B'00000010'			;258     0.20	 2
  retlw		B'00000001'			;264     0.10	 1
  retlw		B'01000000'			;270     0.00	 0		---
  retlw		B'01100001'			;275    -0.10	-1
  retlw		B'01100010'			;281    -0.20	-2
  retlw		B'01100100'			;286    -0.29	-4
  retlw		B'01100101'			;292    -0.38	-5
  retlw		B'01100111'			;298    -0.47	-7
  retlw		B'01101000'			;303    -0.56	-8
  retlw		B'01101001'			;309    -0.63	-9
  retlw		B'01101010'			;315    -0.71	-10
  retlw		B'01101011'			;320    -0.77	-11
  retlw		B'01101100'			;326    -0.83	-12
  retlw		B'01101101'			;331    -0.88	-13
  retlw		B'01101101'			;337    -0.92	-13
  retlw		B'01101110'			;343    -0.96	-14
  retlw		B'01101110'			;348    -0.98	-14
  retlw		B'01101110'			;354    -1.00	-14
MODE_TABLE
  addwf		PCL, 1
  retlw		0x001	; 1/16
  retlw		0x002	; 1/8
  retlw		0x004	; 1/4
  retlw		0x008	; 1/2
 end
