MPLINK 4.30, Linker
Linker Map File - Created Tue Mar 17 03:47:50 2009
                                 Section Info
                  Section       Type    Address   Location Size(Bytes)
                     rvec       code   0x000000    program   0x000004
                     ivec       code   0x000004    program   0x000002
                   .cinit    romdata   0x000005    program   0x000004
    rovidhosszu_megnyomas       code   0x000007    program   0x00028a
         kijelzesvezerles       code   0x00014c    program   0x000258
                     main       code   0x000278    program   0x0001e0
    programozaskodszekcio       code   0x000368    program   0x00018c
          eeprommenteskod       code   0x00042e    program   0x000184
          bytekonvertalas       code   0x0004f0    program   0x000154
        ontozeskodszekcio       code   0x00059a    program   0x000146
  timermegszakitasteendok       code   0x00063d    program   0x00013e
            nappalejszaka       code   0x0006dc    program   0x00009e
      kijelzo2x7frissites       code   0x00072b    program   0x000090
    kapcsolozarkodszekcio       code   0x000773    program   0x000076
 rovidmegnyomaskodszekcio       code   0x0007ae    program   0x000052
    aramkezeleskodszekcio       code   0x0007d7    program   0x00003e
         veszleallitaskod       code   0x0007f6    program   0x000000
hosszumegnyomaskodszekcio       code   0x000800    program   0x000034
                      isr       code   0x00081a    program   0x000030
                  .config       code   0x002007    program   0x000002
                  timerek      udata   0x000020       data   0x000011
rovid_hosszu_kapcsolo_megnyomas      udata   0x000031       data   0x00000c
        programozasadatok      udata   0x00003d       data   0x000008
             EEPROMmentes      udata   0x000045       data   0x000007
            main_valtozok      udata   0x00004c       data   0x000006
         ontozes_valtozok      udata   0x000052       data   0x000002
     kijelzo2x7_frissites      udata   0x000054       data   0x000002
         kijelzesvezerleS      udata   0x000056       data   0x000002
   nappalejszaka_valtozok      udata   0x000058       data   0x000001
bytekonvertalas_2x7kijelzore      udata   0x000059       data   0x000001
                              Program Memory Usage 
                               Start         End      
                            0x000000    0x000001      
                            0x000004    0x0007f5      
                            0x000800    0x000831      
                            0x002007    0x002007      
            2087 out of 8453 program addresses used, program memory utilization is 24%
                              Symbols - Sorted by Name
                     Name    Address   Location    Storage File                     
                AG_1_MENT   0x000615    program     static D:\PIC Projects\ontozo2009\ontozes.asm
                AG_2_MENT   0x00061e    program     static D:\PIC Projects\ontozo2009\ontozes.asm
           ARAMIDO_LEJART   0x0007eb    program     static D:\PIC Projects\ontozo2009\ARAMKEZELES.asm
              ARAMKEZELES   0x0007d7    program     extern D:\PIC Projects\ontozo2009\ARAMKEZELES.asm
           ARAM_KIJELZESE   0x000260    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
                   BIT1_H   0x0000a5    program     static D:\PIC Projects\ontozo2009\KAPCSOLO_KEZIONTOZO_KEZELES.asm
                   BIT2_H   0x0000a2    program     static D:\PIC Projects\ontozo2009\KAPCSOLO_KEZIONTOZO_KEZELES.asm
                   BIT3_H   0x00009f    program     static D:\PIC Projects\ontozo2009\KAPCSOLO_KEZIONTOZO_KEZELES.asm
                      DEL   0x0004cd    program     static D:\PIC Projects\ontozo2009\eeprom_mentes.asm
                     DEL1   0x0004d3    program     static D:\PIC Projects\ontozo2009\eeprom_mentes.asm
                     DEL2   0x0004d9    program     static D:\PIC Projects\ontozo2009\eeprom_mentes.asm
                    DELAY   0x0004c7    program     static D:\PIC Projects\ontozo2009\eeprom_mentes.asm
              EEPROM_IRAS   0x000478    program     static D:\PIC Projects\ontozo2009\eeprom_mentes.asm
           EEPROM_OLVASAS   0x0004bc    program     static D:\PIC Projects\ontozo2009\eeprom_mentes.asm
ERTEKEK_KISEBB_NAGYOBB_IRANY   0x000392    program     static D:\PIC Projects\ontozo2009\programozas.asm
ERTEKEK_NAGYOBB_KISEBB_IRANY   0x0003e6    program     static D:\PIC Projects\ontozo2009\programozas.asm
          HOSSZUT_AKARUNK   0x0000bf    program     static D:\PIC Projects\ontozo2009\KAPCSOLO_KEZIONTOZO_KEZELES.asm
      INTERRUPT_BEALLITAS   0x0002e2    program     static D:\PIC Projects\ontozo2009\main.asm
 KAPCSOLO_ARAM_FOLYAMATOK   0x000007    program     extern D:\PIC Projects\ontozo2009\KAPCSOLO_ARAM_KEZELES.asm
KAPCSOLO_ARAM_HOSSZU_MEGNYOMAS   0x000049    program     static D:\PIC Projects\ontozo2009\KAPCSOLO_ARAM_KEZELES.asm
KAPCSOLO_ARAM_ROVID_MEGNYOMAS   0x00003b    program     static D:\PIC Projects\ontozo2009\KAPCSOLO_ARAM_KEZELES.asm
      KAPCSOLO_ARAM_TIMER   0x00068d    program     static D:\PIC Projects\ontozo2009\timer_modul.asm
 KAPCSOLO_ARAM_TIMER_VEGE   0x000699    program     static D:\PIC Projects\ontozo2009\timer_modul.asm
KAPCSOLO_KEZIONTOZ_FOLYAMATOK   0x000055    program     extern D:\PIC Projects\ontozo2009\KAPCSOLO_KEZIONTOZO_KEZELES.asm
 KAPCSOLO_KEZIONTOZ_TIMER   0x000681    program     static D:\PIC Projects\ontozo2009\timer_modul.asm
KAPCSOLO_KEZIONTOZ_TIMER_VEGE   0x00068d    program     static D:\PIC Projects\ontozo2009\timer_modul.asm
KAPCSOLO_KEZIONT_HOSSZU_MEGNYOM   0x0000ab    program     static D:\PIC Projects\ontozo2009\KAPCSOLO_KEZIONTOZO_KEZELES.asm
KAPCSOLO_KEZIONT_ROVID_MEGNYOMAS   0x000089    program     static D:\PIC Projects\ontozo2009\KAPCSOLO_KEZIONTOZO_KEZELES.asm
KAPCSOLO_PORTA1_FOLYAMATOK   0x0000ce    program     extern D:\PIC Projects\ontozo2009\KAPCSOLO_PORTA1_KEZELES.asm
KAPCSOLO_PORTA1_HOSSZU_MEGNYOMAS   0x000104    program     static D:\PIC Projects\ontozo2009\KAPCSOLO_PORTA1_KEZELES.asm
KAPCSOLO_PORTA1_ROVID_MEGNYOMAS   0x000102    program     static D:\PIC Projects\ontozo2009\KAPCSOLO_PORTA1_KEZELES.asm
    KAPCSOLO_PORTA1_TIMER   0x000669    program     static D:\PIC Projects\ontozo2009\timer_modul.asm
KAPCSOLO_PORTA1_TIMER_VEGE   0x000675    program     static D:\PIC Projects\ontozo2009\timer_modul.asm
KAPCSOLO_PORTA2_FOLYAMATOK   0x00010d    program     extern D:\PIC Projects\ontozo2009\KAPCSOLO_PORTA2_KEZELES.asm
KAPCSOLO_PORTA2_HOSSZU_MEGNYOMAS   0x000143    program     static D:\PIC Projects\ontozo2009\KAPCSOLO_PORTA2_KEZELES.asm
KAPCSOLO_PORTA2_ROVID_MEGNYOMAS   0x000141    program     static D:\PIC Projects\ontozo2009\KAPCSOLO_PORTA2_KEZELES.asm
    KAPCSOLO_PORTA2_TIMER   0x000675    program     static D:\PIC Projects\ontozo2009\timer_modul.asm
KAPCSOLO_PORTA2_TIMER_VEGE   0x000681    program     static D:\PIC Projects\ontozo2009\timer_modul.asm
          KEVESEBBMINT_1S   0x000270    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
             KEZI_ONTOZES   0x0005f1    program     static D:\PIC Projects\ontozo2009\ontozes.asm
            LEALLAS_FAZIS   0x0005a5    program     static D:\PIC Projects\ontozo2009\ontozes.asm
             LEALLAS_LESZ   0x0000a8    program     static D:\PIC Projects\ontozo2009\KAPCSOLO_KEZIONTOZO_KEZELES.asm
                     LOOP   0x0002e5    program     static D:\PIC Projects\ontozo2009\main.asm
 MEGSZAKITAS_KEZELES_VEGE   0x0002ee    program     static D:\PIC Projects\ontozo2009\main.asm
    MINDENT_ALAPALLAPOTBA   0x0002be    program     static D:\PIC Projects\ontozo2009\main.asm
            MOST_KEZDODIK   0x000627    program     static D:\PIC Projects\ontozo2009\ontozes.asm
             NAPI_ONTOZES   0x0005fc    program     static D:\PIC Projects\ontozo2009\ontozes.asm
NAPI_ONTOZES_BEALLITAS_VEGE   0x000639    program     static D:\PIC Projects\ontozo2009\ontozes.asm
              NEDVES_FOLD   0x00062c    program     static D:\PIC Projects\ontozo2009\ontozes.asm
       NEM_UTOLSO_AG_VOLT   0x0005c2    program     static D:\PIC Projects\ontozo2009\ontozes.asm
             OF_kijelzese   0x00016a    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
                  ONTOZES   0x00059a    program     extern D:\PIC Projects\ontozo2009\ontozes.asm
    ONTOZES_ALAPALLAPOTBA   0x0005c8    program     static D:\PIC Projects\ontozo2009\ontozes.asm
            ONTOZES_FAZIS   0x0005d4    program     static D:\PIC Projects\ontozo2009\ontozes.asm
             On_kijelzese   0x000161    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
          PORTA1_FIGYELES   0x00032f    program     static D:\PIC Projects\ontozo2009\main.asm
 PORTA1_FOLYAMAT_FIGYELES   0x000336    program     static D:\PIC Projects\ontozo2009\main.asm
          PORTA2_FIGYELES   0x00033a    program     static D:\PIC Projects\ontozo2009\main.asm
 PORTA2_FOLYAMAT_FIGYELES   0x000341    program     static D:\PIC Projects\ontozo2009\main.asm
          PORTA3_FIGYELES   0x000345    program     static D:\PIC Projects\ontozo2009\main.asm
 PORTA3_FOLYAMAT_FIGYELES   0x00034c    program     static D:\PIC Projects\ontozo2009\main.asm
          PORTA4_FIGYELES   0x000350    program     static D:\PIC Projects\ontozo2009\main.asm
 PORTA4_FOLYAMAT_FIGYELES   0x000357    program     static D:\PIC Projects\ontozo2009\main.asm
        PROGRAMOZAS_BE_KI   0x00037c    program     extern D:\PIC Projects\ontozo2009\programozas.asm
PROGRAMOZAS_FELFELE_LEPTETES   0x000386    program     extern D:\PIC Projects\ontozo2009\programozas.asm
PROGRAMOZAS_KIJELZO_BYTE_0   0x0003fe    program     static D:\PIC Projects\ontozo2009\programozas.asm
PROGRAMOZAS_KIJELZO_BYTE_1   0x000406    program     static D:\PIC Projects\ontozo2009\programozas.asm
PROGRAMOZAS_KIJELZO_BYTE_2   0x00040e    program     static D:\PIC Projects\ontozo2009\programozas.asm
PROGRAMOZAS_KIJELZO_BYTE_3   0x000416    program     static D:\PIC Projects\ontozo2009\programozas.asm
PROGRAMOZAS_KIJELZO_BYTE_4   0x00041e    program     static D:\PIC Projects\ontozo2009\programozas.asm
PROGRAMOZAS_KIJELZO_BYTE_5   0x000426    program     static D:\PIC Projects\ontozo2009\programozas.asm
PROGRAMOZAS_KIJELZO_BYTE__0   0x0003aa    program     static D:\PIC Projects\ontozo2009\programozas.asm
PROGRAMOZAS_KIJELZO_BYTE__1   0x0003b2    program     static D:\PIC Projects\ontozo2009\programozas.asm
PROGRAMOZAS_KIJELZO_BYTE__2   0x0003ba    program     static D:\PIC Projects\ontozo2009\programozas.asm
PROGRAMOZAS_KIJELZO_BYTE__3   0x0003c2    program     static D:\PIC Projects\ontozo2009\programozas.asm
PROGRAMOZAS_KIJELZO_BYTE__4   0x0003ca    program     static D:\PIC Projects\ontozo2009\programozas.asm
PROGRAMOZAS_KIJELZO_BYTE__5   0x0003d2    program     static D:\PIC Projects\ontozo2009\programozas.asm
PROGRAMOZAS_LEFELE_LEPTETES   0x0003da    program     extern D:\PIC Projects\ontozo2009\programozas.asm
PROGRAMPONTOK_AG1_ARAM_IRANY   0x00038b    program     static D:\PIC Projects\ontozo2009\programozas.asm
PROGRAMPONTOK_ARAM_AG1_IRANY   0x0003df    program     static D:\PIC Projects\ontozo2009\programozas.asm
      RA1_HOSSZUMEGNYOMAS   0x000800    program     extern D:\PIC Projects\ontozo2009\PORTA1_PORTA2_hossz_megnyomas.asm
       RA1_rovidmegnyomas   0x0007ae    program     extern D:\PIC Projects\ontozo2009\PORTA1_PORTA2_rovid_megnyomas.asm
      RA2_HOSSZUMEGNYOMAS   0x00080b    program     extern D:\PIC Projects\ontozo2009\PORTA1_PORTA2_hossz_megnyomas.asm
       RA2_rovidmegnyomas   0x0007c7    program     extern D:\PIC Projects\ontozo2009\PORTA1_PORTA2_rovid_megnyomas.asm
RB0_MEGSZAKITAS_VIZSGALAT   0x000824    program     static D:\PIC Projects\ontozo2009\main.asm
          RB0_MEGSZ_VIZSG   0x0002ee    program     static D:\PIC Projects\ontozo2009\main.asm
              RB0_MEG_LOW   0x000466    program     static D:\PIC Projects\ontozo2009\eeprom_mentes.asm
RESET_KAPCSOLO_ARAM_TIMER   0x00004e    program     extern D:\PIC Projects\ontozo2009\KAPCSOLO_ARAM_KEZELES.asm
RESET_KAPCSOLO_KEZIONTOZ_TIMER   0x0000c7    program     extern D:\PIC Projects\ontozo2009\KAPCSOLO_KEZIONTOZO_KEZELES.asm
RESET_KAPCSOLO_PORTA1_TIMER   0x000106    program     extern D:\PIC Projects\ontozo2009\KAPCSOLO_PORTA1_KEZELES.asm
RESET_KAPCSOLO_PORTA2_TIMER   0x000145    program     extern D:\PIC Projects\ontozo2009\KAPCSOLO_PORTA2_KEZELES.asm
         RESET_TIMER_ARAM   0x0006d5    program     extern D:\PIC Projects\ontozo2009\timer_modul.asm
      RESET_TIMER_KIJELZO   0x0006b2    program     extern D:\PIC Projects\ontozo2009\timer_modul.asm
RESET_TIMER_NAPPALEJSZAKA   0x0006c0    program     extern D:\PIC Projects\ontozo2009\timer_modul.asm
      RESET_TIMER_ONTOZES   0x0006ce    program     extern D:\PIC Projects\ontozo2009\timer_modul.asm
RESET_TIMER_PCB_KAPCSOLOZAR   0x0006c7    program     extern D:\PIC Projects\ontozo2009\timer_modul.asm
  RESET_TIMER_PROGRAMOZAS   0x0006b9    program     extern D:\PIC Projects\ontozo2009\timer_modul.asm
              SZARAZ_FOLD   0x000631    program     static D:\PIC Projects\ontozo2009\ontozes.asm
 SZELEP_ELOBYTE_VIZSGALAT   0x00060f    program     static D:\PIC Projects\ontozo2009\ontozes.asm
                 TABLAZAT   0x00075c    program     static D:\PIC Projects\ontozo2009\kijelzo2x7_frissites.asm
               TIMER_ARAM   0x0006a5    program     static D:\PIC Projects\ontozo2009\timer_modul.asm
          TIMER_ARAM_VEGE   0x0006b1    program     static D:\PIC Projects\ontozo2009\timer_modul.asm
            TIMER_ONTOZES   0x000699    program     static D:\PIC Projects\ontozo2009\timer_modul.asm
       TIMER_ONTOZES_VEGE   0x0006a5    program     static D:\PIC Projects\ontozo2009\timer_modul.asm
    TIMER_PCB_KAPCSOLOZAR   0x00065d    program     static D:\PIC Projects\ontozo2009\timer_modul.asm
TIMER_PCB_KAPCSOLOZAR_VEGE   0x000669    program     static D:\PIC Projects\ontozo2009\timer_modul.asm
              TOBBMINT_1S   0x000267    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
           UTOLSO_AG_VOLT   0x0005be    program     static D:\PIC Projects\ontozo2009\ontozes.asm
                VARAKOZAS   0x000484    program     static D:\PIC Projects\ontozo2009\eeprom_mentes.asm
 ag_1_idotartam_kijelzese   0x0001c8    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
           ag_1_kijelzese   0x000193    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
 ag_2_idotartam_kijelzese   0x0001d0    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
           ag_2_kijelzese   0x000198    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
 ag_3_idotartam_kijelzese   0x0001d8    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
           ag_3_kijelzese   0x00019d    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
 aram_idotartam_kijelzese   0x0001f0    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
           aram_kijelzese   0x0001ac    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
bytekonvertalas_2x7kijelzore   0x0004f0    program     extern D:\PIC Projects\ontozo2009\bytekonvertalas_2x7kijelzore.asm
eeprom_kijelzes_folyamatban   0x0007bf    program     static D:\PIC Projects\ontozo2009\PORTA1_PORTA2_rovid_megnyomas.asm
eeprom_kijelzes_nem_folyik   0x0007c3    program     static D:\PIC Projects\ontozo2009\PORTA1_PORTA2_rovid_megnyomas.asm
         eeprom_kijelzese   0x0001f8    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
            eeprom_mentes   0x00042e    program     extern D:\PIC Projects\ontozo2009\eeprom_mentes.asm
        eeprom_visszairas   0x00048b    program     extern D:\PIC Projects\ontozo2009\eeprom_mentes.asm
          egyes_frissites   0x000730    program     static D:\PIC Projects\ontozo2009\kijelzo2x7_frissites.asm
        egyperc_vizsgalat   0x0006dc    program     extern D:\PIC Projects\ontozo2009\nappalejszaka.asm
      ejszakara_varakozas   0x000723    program     static D:\PIC Projects\ontozo2009\nappalejszaka.asm
elengedesi_pergesmentesites   0x0000f7    program     static D:\PIC Projects\ontozo2009\KAPCSOLO_PORTA1_KEZELES.asm
elengedesi_pergesmentesites   0x000030    program     static D:\PIC Projects\ontozo2009\KAPCSOLO_ARAM_KEZELES.asm
elengedesi_pergesmentesites   0x000136    program     static D:\PIC Projects\ontozo2009\KAPCSOLO_PORTA2_KEZELES.asm
elengedesi_pergesmentesites   0x00007e    program     static D:\PIC Projects\ontozo2009\KAPCSOLO_KEZIONTOZO_KEZELES.asm
ertekeket_allitottuk_eddig   0x000379    program     static D:\PIC Projects\ontozo2009\programozas.asm
   fenyerzekelo_vizsgalat   0x000710    program     static D:\PIC Projects\ontozo2009\nappalejszaka.asm
funkciok_idotartam_beallitasa   0x0001b1    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
 funkciok_kozt_valogatunk   0x000178    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
              hajnal_lett   0x000700    program     static D:\PIC Projects\ontozo2009\nappalejszaka.asm
hajnali_ontozesvisszaszamlalas   0x00020a    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
       hajnalra_varakozas   0x000715    program     static D:\PIC Projects\ontozo2009\nappalejszaka.asm
 hosszu_ontozes_idotartam   0x0001e8    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
 hosszu_ontozes_kijelzese   0x0001a7    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
  hosszumegnyomas_tortent   0x0000e6    program     static D:\PIC Projects\ontozo2009\KAPCSOLO_PORTA1_KEZELES.asm
  hosszumegnyomas_tortent   0x000125    program     static D:\PIC Projects\ontozo2009\KAPCSOLO_PORTA2_KEZELES.asm
  hosszumegnyomas_tortent   0x00006d    program     static D:\PIC Projects\ontozo2009\KAPCSOLO_KEZIONTOZO_KEZELES.asm
  hosszumegnyomas_tortent   0x00001f    program     static D:\PIC Projects\ontozo2009\KAPCSOLO_ARAM_KEZELES.asm
     hosszumegnyomas_utan   0x0000eb    program     static D:\PIC Projects\ontozo2009\KAPCSOLO_PORTA1_KEZELES.asm
     hosszumegnyomas_utan   0x00012a    program     static D:\PIC Projects\ontozo2009\KAPCSOLO_PORTA2_KEZELES.asm
     hosszumegnyomas_utan   0x000024    program     static D:\PIC Projects\ontozo2009\KAPCSOLO_ARAM_KEZELES.asm
     hosszumegnyomas_utan   0x000072    program     static D:\PIC Projects\ontozo2009\KAPCSOLO_KEZIONTOZO_KEZELES.asm
                      isr   0x00081a    program     static D:\PIC Projects\ontozo2009\main.asm
              kapcsolozar   0x000773    program     extern D:\PIC Projects\ontozo2009\kapcsolozar.asm
    kapcsolozar_kijelzese   0x00015a    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
      kapcsolozar_kioldas   0x000815    program     static D:\PIC Projects\ontozo2009\PORTA1_PORTA2_hossz_megnyomas.asm
 kell_e_kijelezni_valamit   0x000312    program     static D:\PIC Projects\ontozo2009\main.asm
        ket_sec_vizsgalat   0x0007a4    program     static D:\PIC Projects\ontozo2009\kapcsolozar.asm
        kijelzes_vezerles   0x00032a    program     static D:\PIC Projects\ontozo2009\main.asm
  kijelzes_vezerles_rutin   0x00014c    program     extern D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
        kijelzo_frissites   0x00072b    program     extern D:\PIC Projects\ontozo2009\kijelzo2x7_frissites.asm
kijelzo_vezerles_szakasz_vege   0x00032b    program     static D:\PIC Projects\ontozo2009\main.asm
              letelt_1min   0x00077a    program     static D:\PIC Projects\ontozo2009\kapcsolozar.asm
               letelt_55s   0x000790    program     static D:\PIC Projects\ontozo2009\kapcsolozar.asm
                     main   0x000278    program     extern D:\PIC Projects\ontozo2009\main.asm
         megszakitas_vege   0x000828    program     static D:\PIC Projects\ontozo2009\main.asm
                megvan_31   0x00024d    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
                megvan_36   0x00025c    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
        most_lett_kioldva   0x00079c    program     static D:\PIC Projects\ontozo2009\kapcsolozar.asm
  motorszimbolum_leptetes   0x00023f    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
mukodo_szelepszam_kiiratasa   0x00022a    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
   napi_ontozes_vizsgalat   0x0002fa    program     static D:\PIC Projects\ontozo2009\main.asm
    nem_most_lett_kioldva   0x0007a0    program     static D:\PIC Projects\ontozo2009\kapcsolozar.asm
         nem_telt_le_1min   0x000786    program     static D:\PIC Projects\ontozo2009\kapcsolozar.asm
          nem_telt_le_55s   0x000797    program     static D:\PIC Projects\ontozo2009\kapcsolozar.asm
nem_voltunk_programozasban   0x000384    program     static D:\PIC Projects\ontozo2009\programozas.asm
                 nincs_31   0x000222    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
                 nincs_36   0x000254    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
        ontozes_kijelzese   0x000213    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
      ontozes_nem_mukodik   0x000301    program     static D:\PIC Projects\ontozo2009\main.asm
         portd2_vizsgalat   0x0002f4    program     static D:\PIC Projects\ontozo2009\main.asm
         portd3_vizsgalat   0x0002f7    program     static D:\PIC Projects\ontozo2009\main.asm
  programozas_folyamatban   0x00030a    program     static D:\PIC Projects\ontozo2009\main.asm
       programozas_folyik   0x0007b8    program     static D:\PIC Projects\ontozo2009\PORTA1_PORTA2_rovid_megnyomas.asm
programozas_kijelzes_vege   0x0001f7    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
    programozas_kijelzese   0x000173    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
   programozas_nem_folyik   0x0007ba    program     static D:\PIC Projects\ontozo2009\PORTA1_PORTA2_rovid_megnyomas.asm
        programozas_nincs   0x0007d3    program     static D:\PIC Projects\ontozo2009\PORTA1_PORTA2_rovid_megnyomas.asm
programozas_nincs_folyamatban   0x00030e    program     static D:\PIC Projects\ontozo2009\main.asm
programozas_valtogatas_3s_kent   0x000368    program     extern D:\PIC Projects\ontozo2009\programozas.asm
    programozas_vizsgalat   0x000305    program     static D:\PIC Projects\ontozo2009\main.asm
   programozasban_vagyunk   0x0007d1    program     static D:\PIC Projects\ontozo2009\PORTA1_PORTA2_rovid_megnyomas.asm
   programozasban_voltunk   0x000381    program     static D:\PIC Projects\ontozo2009\programozas.asm
programpontok_voltak_eddig   0x000376    program     static D:\PIC Projects\ontozo2009\programozas.asm
  rovid_ontozes_idotartam   0x0001e0    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
  rovid_ontozes_kijelzese   0x0001a2    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
              szam0_9kozt   0x00051b    program     static D:\PIC Projects\ontozo2009\bytekonvertalas_2x7kijelzore.asm
            szam10_19kozt   0x000525    program     static D:\PIC Projects\ontozo2009\bytekonvertalas_2x7kijelzore.asm
            szam20_29kozt   0x000531    program     static D:\PIC Projects\ontozo2009\bytekonvertalas_2x7kijelzore.asm
            szam30_39kozt   0x00053d    program     static D:\PIC Projects\ontozo2009\bytekonvertalas_2x7kijelzore.asm
            szam40_49kozt   0x000549    program     static D:\PIC Projects\ontozo2009\bytekonvertalas_2x7kijelzore.asm
            szam50_59kozt   0x000555    program     static D:\PIC Projects\ontozo2009\bytekonvertalas_2x7kijelzore.asm
            szam60_69kozt   0x000561    program     static D:\PIC Projects\ontozo2009\bytekonvertalas_2x7kijelzore.asm
            szam70_79kozt   0x00056d    program     static D:\PIC Projects\ontozo2009\bytekonvertalas_2x7kijelzore.asm
            szam80_89kozt   0x000579    program     static D:\PIC Projects\ontozo2009\bytekonvertalas_2x7kijelzore.asm
            szam90_99kozt   0x000585    program     static D:\PIC Projects\ontozo2009\bytekonvertalas_2x7kijelzore.asm
        szelep2_megnezese   0x000233    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
             szelep3_megy   0x00023c    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
      szelepek_vizsgalata   0x0002ef    program     static D:\PIC Projects\ontozo2009\main.asm
       szimbolum_kijelzes   0x000248    program     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
            timer_kijelzo   0x00063d    program     static D:\PIC Projects\ontozo2009\timer_modul.asm
       timer_kijelzo_vege   0x000649    program     static D:\PIC Projects\ontozo2009\timer_modul.asm
      timer_nappalejszaka   0x000655    program     static D:\PIC Projects\ontozo2009\timer_modul.asm
 timer_nappalejszaka_vege   0x00065d    program     static D:\PIC Projects\ontozo2009\timer_modul.asm
        timer_programozas   0x000649    program     static D:\PIC Projects\ontozo2009\timer_modul.asm
   timer_programozas_vege   0x000655    program     static D:\PIC Projects\ontozo2009\timer_modul.asm
         timerekleptetese   0x00063d    program     extern D:\PIC Projects\ontozo2009\timer_modul.asm
          tizes_frissites   0x000746    program     static D:\PIC Projects\ontozo2009\kijelzo2x7_frissites.asm
             tobb_mint_99   0x000591    program     static D:\PIC Projects\ontozo2009\bytekonvertalas_2x7kijelzore.asm
   valami_ontozes_mukodik   0x0002fd    program     static D:\PIC Projects\ontozo2009\main.asm
              veszleallas   0x0007f6    program     extern D:\PIC Projects\ontozo2009\veszleallitas.asm
           AG_1_IDOTARTAM   0x00003e       data     extern D:\PIC Projects\ontozo2009\programozas.asm
           AG_2_IDOTARTAM   0x00003f       data     extern D:\PIC Projects\ontozo2009\programozas.asm
           AG_3_IDOTARTAM   0x000040       data     extern D:\PIC Projects\ontozo2009\programozas.asm
           ARAM_IDOTARTAM   0x000043       data     extern D:\PIC Projects\ontozo2009\programozas.asm
      ARAM_VISSZASZAMOLAS   0x00003d       data     extern D:\PIC Projects\ontozo2009\ARAMKEZELES.asm
        EEPROM_MENTESSZAM   0x000045       data     extern D:\PIC Projects\ontozo2009\eeprom_mentes.asm
            EGYESSZAMJEGY   0x000054       data     extern D:\PIC Projects\ontozo2009\kijelzo2x7_frissites.asm
         HOSSZU_IDOTARTAM   0x000042       data     extern D:\PIC Projects\ontozo2009\programozas.asm
    KAPCSOLO_ARAM_TIMER_1   0x000031       data     extern D:\PIC Projects\ontozo2009\KAPCSOLO_ARAM_KEZELES.asm
    KAPCSOLO_ARAM_TIMER_2   0x000032       data     extern D:\PIC Projects\ontozo2009\KAPCSOLO_ARAM_KEZELES.asm
KAPCSOLO_ARAM_TIMER_ALLAPOT   0x000033       data     extern D:\PIC Projects\ontozo2009\KAPCSOLO_ARAM_KEZELES.asm
KAPCSOLO_KEZIONTOZ_TIMER_1   0x000034       data     extern D:\PIC Projects\ontozo2009\KAPCSOLO_KEZIONTOZO_KEZELES.asm
KAPCSOLO_KEZIONTOZ_TIMER_2   0x000035       data     extern D:\PIC Projects\ontozo2009\KAPCSOLO_KEZIONTOZO_KEZELES.asm
KAPCSOLO_KEZIONTOZ_TIMER_ALLAPOT   0x000036       data     extern D:\PIC Projects\ontozo2009\KAPCSOLO_KEZIONTOZO_KEZELES.asm
  KAPCSOLO_PORTA1_TIMER_1   0x000037       data     extern D:\PIC Projects\ontozo2009\KAPCSOLO_PORTA1_KEZELES.asm
  KAPCSOLO_PORTA1_TIMER_2   0x000038       data     extern D:\PIC Projects\ontozo2009\KAPCSOLO_PORTA1_KEZELES.asm
KAPCSOLO_PORTA1_TIMER_ALLAPOT   0x000039       data     extern D:\PIC Projects\ontozo2009\KAPCSOLO_PORTA1_KEZELES.asm
  KAPCSOLO_PORTA2_TIMER_1   0x00003a       data     extern D:\PIC Projects\ontozo2009\KAPCSOLO_PORTA2_KEZELES.asm
  KAPCSOLO_PORTA2_TIMER_2   0x00003b       data     extern D:\PIC Projects\ontozo2009\KAPCSOLO_PORTA2_KEZELES.asm
KAPCSOLO_PORTA2_TIMER_ALLAPOT   0x00003c       data     extern D:\PIC Projects\ontozo2009\KAPCSOLO_PORTA2_KEZELES.asm
          KONVERTALO_BYTE   0x000059       data     extern D:\PIC Projects\ontozo2009\bytekonvertalas_2x7kijelzore.asm
    MEGSZAKITAS_JELZOBYTE   0x000051       data     static D:\PIC Projects\ontozo2009\main.asm
           MOTORSZIMBOLUM   0x000057       data     static D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
           MOTORSZIMBOLUM   0x00004e       data     static D:\PIC Projects\ontozo2009\main.asm
      NEGYED_SEC_SZAMLALO   0x000056       data     extern D:\PIC Projects\ontozo2009\kijelzes_vezerles_modul.asm
      NEGYED_SEC_SZAMLALO   0x00004f       data     static D:\PIC Projects\ontozo2009\main.asm
              ONTOZESSZAM   0x000050       data     extern D:\PIC Projects\ontozo2009\main.asm
        ONTOZES_IDOTARTAM   0x000052       data     extern D:\PIC Projects\ontozo2009\ontozes.asm
PERCSZAMOLO_NAPPALEJSZAKA   0x000058       data     extern D:\PIC Projects\ontozo2009\nappalejszaka.asm
 PROGRAMOZAS_KIJELZO_BYTE   0x000044       data     extern D:\PIC Projects\ontozo2009\programozas.asm
          ROVID_IDOTARTAM   0x000041       data     extern D:\PIC Projects\ontozo2009\programozas.asm
              STATUS_SAVE   0x00004d       data     static D:\PIC Projects\ontozo2009\main.asm
           SZELEP_ELOBYTE   0x000053       data     extern D:\PIC Projects\ontozo2009\ontozes.asm
                       T1   0x000046       data     static D:\PIC Projects\ontozo2009\eeprom_mentes.asm
                  T1ERTEK   0x000049       data     static D:\PIC Projects\ontozo2009\eeprom_mentes.asm
                       T2   0x000047       data     static D:\PIC Projects\ontozo2009\eeprom_mentes.asm
                  T2ERTEK   0x00004a       data     static D:\PIC Projects\ontozo2009\eeprom_mentes.asm
                       T3   0x000048       data     static D:\PIC Projects\ontozo2009\eeprom_mentes.asm
                  T3ERTEK   0x00004b       data     static D:\PIC Projects\ontozo2009\eeprom_mentes.asm
             TIMER_ARAM_1   0x00002b       data     extern D:\PIC Projects\ontozo2009\timer_modul.asm
             TIMER_ARAM_2   0x00002c       data     extern D:\PIC Projects\ontozo2009\timer_modul.asm
       TIMER_ARAM_ALLAPOT   0x00002d       data     extern D:\PIC Projects\ontozo2009\timer_modul.asm
          TIMER_KIJELZO_1   0x000020       data     extern D:\PIC Projects\ontozo2009\timer_modul.asm
          TIMER_KIJELZO_2   0x000021       data     extern D:\PIC Projects\ontozo2009\timer_modul.asm
    TIMER_KIJELZO_ALLAPOT   0x000022       data     extern D:\PIC Projects\ontozo2009\timer_modul.asm
    TIMER_NAPPALEJSZAKA_1   0x000026       data     extern D:\PIC Projects\ontozo2009\timer_modul.asm
    TIMER_NAPPALEJSZAKA_2   0x000027       data     extern D:\PIC Projects\ontozo2009\timer_modul.asm
          TIMER_ONTOZES_1   0x00002e       data     extern D:\PIC Projects\ontozo2009\timer_modul.asm
          TIMER_ONTOZES_2   0x00002f       data     extern D:\PIC Projects\ontozo2009\timer_modul.asm
    TIMER_ONTOZES_ALLAPOT   0x000030       data     extern D:\PIC Projects\ontozo2009\timer_modul.asm
  TIMER_PCB_KAPCSOLOZAR_1   0x000028       data     extern D:\PIC Projects\ontozo2009\timer_modul.asm
  TIMER_PCB_KAPCSOLOZAR_2   0x000029       data     extern D:\PIC Projects\ontozo2009\timer_modul.asm
TIMER_PCB_KAPCSOLOZAR_ALLAPOT   0x00002a       data     extern D:\PIC Projects\ontozo2009\timer_modul.asm
      TIMER_PROGRAMOZAS_1   0x000023       data     extern D:\PIC Projects\ontozo2009\timer_modul.asm
      TIMER_PROGRAMOZAS_2   0x000024       data     extern D:\PIC Projects\ontozo2009\timer_modul.asm
TIMER_PROGRAMOZAS_ALLAPOT   0x000025       data     extern D:\PIC Projects\ontozo2009\timer_modul.asm
            TIZESSZAMJEGY   0x000055       data     extern D:\PIC Projects\ontozo2009\kijelzo2x7_frissites.asm
                   W_SAVE   0x00004c       data     static D:\PIC Projects\ontozo2009\main.asm
                              Symbols - Sorted by Address
