// Define baud rate
#define F_CPU 4000000
#define USART_BAUD 9600
#define USART_UBBR_VALUE 25   //((F_CPU/(USART_BAUD<<4))-1)
#include <stdint.h>
#include <avr/io.h>
#include <util/delay.h>
//#include <string.h>
#define leddisable          PORTB |= 8
#define ledenable           PORTB &= ~8
#define sckenable          PORTB |= 1
#define sckdisable         PORTB &= ~1
#define dataenable          PORTB |= 2
#define datadisable         PORTB &= ~2
#define csdisable          PORTB |= 4
#define csenable           PORTB &= ~4
#define senddelay		   _delay_us(208);
void USART_vInit(void)
// Set baud rate
UBRRL = USART_UBBR_VALUE;
// Set frame format to 8 data bits, no parity, 1 stop bit
UCSRC = (0<<USBS)|(1<<UCSZ1)|(1<<UCSZ0);
// Enable receiver and transmitter
UCSRB = (1<<RXEN)|(1<<TXEN);
void send(unsigned char u8Data)
// Wait if a byte is being transmitted
while((UCSRA&(1<<UDRE)) == 0);
// Transmit data
UDR = u8Data;
uint8_t receive()
// Wait until a byte has been received
while((UCSRA&(1<<RXC)) == 0);
// Return received data
return UDR;
void sendstring(char *str)
	int i;
	for(i=0;str[i];i++)
	   send(str[i]);
send(0x0D);
char* inttostr(int value,char *str)
int i;
for(i=0;i<16;i++)
if((value&1)) str[15-i]=0x31;
else str[15-i]=0x30;
value>>=1;
str[16]='\0';
return str;
void fract2str(int value, char* str, int accuracy) {
	int i;
	int temp;
	int integral, fraction;
	int draw = 0;
	char dectabla[10]="0123456789";
	if(accuracy > 2) accuracy = 2; // Tizedesjegyek szama max. 2 legyen
	if(value < 0) {	// Elojel-vizsgalat
		*str = '-';
		str++;
		value *= -1;
	integral = value >> 7;					// Egeszresz
	fraction = (value & 0x007F)*100/128;	// Tortresz (szazadok szama)
	for(i=100;i>=1;i/=10) {				// Egeszresz kiirasa
		if((temp = integral / i) > 0 || i==1) draw = 1; // Nullaval nem kezdunk szamot
		if(draw) {
			*str = dectabla[temp];
			integral -= i*temp;
			str++;
	if(accuracy < 1) {		// Ha nem kell tizedesjegy, akkor kesz
		*str = '\0';
		return;
	*str = '.';				// Tizedespont
	str++;
	for(i=10;i>=1;i/=10) {	// Tortresz kiirasa
		temp = fraction / i;
		fraction -= i*temp;
		str++;
		accuracy--;
		if(accuracy < 1) break;
	*str = '\0';	// Lezaro nulla
unsigned int readTC77()
  unsigned char temp1=0x00;
  unsigned char temp2=0x00;
  int i;
   sckdisable;
   csenable;
  _delay_ms(1);
  for(i=0;i<8;i++)
   temp1<<=1;
   _delay_ms(1);
   if ((PINB&2)) temp1++;
   sckenable;
   _delay_ms(1);
   sckdisable;
  for(i=0;i<8;i++)
   temp2<<=1;
   _delay_ms(1);
   if ((PINB&2)) temp2++;
   sckenable;
    _delay_ms(1);
   sckdisable;
csdisable;
i=(temp1<<8)+temp2;
return i;
int main(void)
char str[10];
unsigned int data;
char str1[20];
USART_vInit();
//init portD
DDRB=0b11111101;
PORTB=0x00;
csdisable;
while(1)
	data=readTC77();
	sendstring(inttostr(data,str1));
	//data<<=3;
	fract2str(data,str,1);
	sendstring(str);	
	_delay_ms(1000);
